#include <stdint.h>
#include "stm32f0xx.h"
#define GPIOAEN			(1U<<17)
#define UART2EN			(1U<<17)
#define CR1_TE			(1U<<3)
#define CR1_UE			(1U<<0)
#define SR_TXE			(1U<<7)
#define SYS_FREQ		16000000	// 16MHz
#define APB1_CLK		SYS_FREQ
#define UART_BAUDRATE	115200
static void uart_set_baudrate(USART_TypeDef *USARTx, uint32_t PeriphCLK, uint32_t BaudRate);
static uint16_t compute_uart_bd(uint32_t PeriphCLK, uint32_t BaudRate);
void uar2_tx_init(void);
void uart2_write(int ch);
int main(void)
	uar2_tx_init();
	while(1)
		uart2_write('Y');
	/*Enable clock access to gpioa */
	RCC->AHBENR |= GPIOAEN;
	/*Set PA2 mode to alternate function mode*/
	GPIOA->MODER &=~(1U<<4);
	GPIOA->MODER |= (1U<<5);
	/*Set PA2 alternate function type to UART_TX (AF1)*/
	GPIOA->AFR[0] |= (1U<<8); // AFR[0] is for low register and AFR[1] for high register
	GPIOA->AFR[0] &=~(1U<<9);
	GPIOA->AFR[0] &=~(1U<<10);
	GPIOA->AFR[0] &=~(1U<<11);
	/****************Configure uart module*******************/
	/*Enable clock access to uart2 */
	RCC->APB1ENR |= UART2EN;
	/*Configure baudrate*/
	uart_set_baudrate(USART2,APB1_CLK,UART_BAUDRATE);
	/*Configure the transfer direction*/
	USART2->CR1 = CR1_TE;
	/*Enable uart module*/
	USART2->CR1 |= CR1_UE;
	/*Make sure the transmit data register is empty*/
	while(!(USART2->ISR & SR_TXE))
	/*Write to transmit data register*/
	USART2->TDR = (ch & 0xFF);
	USARTx->BRR = compute_uart_bd(PeriphCLK, BaudRate);
/* This formula gives the value back to baudrate register*/
	return ((PeriphCLK + (BaudRate/2U))/BaudRate);
