%% Hilbert-Algo-Test pkg load signal % Hilbert Trafo für Controller-Implementation nach: https://www.mikrocontroller.net/topic/480404#7103779 % sample_in : das datensignal links am Eingang % delay_out : Der aktuelle Ausgang des Verzögerers (das kann nicht hier in der Funktion gemacht werden) % coeff : Der Koeffizient function [sample_out,delay_in]=block2_calc(sample_in,delay_out,coeff) signal_top_right = coeff * ( delay_out - sample_in ); delay_in = signal_top_right + sample_in; sample_out = signal_top_right + delay_out; endfunction % Hilbert Trafo für Controller-Implementation nach: https://www.mikrocontroller.net/topic/480404#7103779 % mit reellen Koeffizienten (wie im Bild) function sample_z=hilbert_algo_1(sample_in) % delay storage persistent i1=0; % inphase Z-1 persistent i2a=0,i2b=0; % inphase 0.3900 block persistent i3a=0,i3b=0; % inphase 0.8906 block persistent q1a=0,q1b=0; % quadratur 0.1206 block persistent q2a=0,q2b=0; % quadratur 0.6628 block % inphase % der inphase 0.3900 Teil [i2_out,delay_in]=block2_calc(i1,i2b,0.3900); i2b=i2a; i2a=delay_in; % der inphase 0.8906 Teil [sample_out_i,delay_in]=block2_calc(i2_out,i3b,0.8906); i3b=i3a; i3a=delay_in; % der inphase Z-1 Teil i1=sample_in; % quadratur % der quadratur 0.1206 Teil [q1_out,delay_in]=block2_calc(sample_in,q1b,0.1206); q1b=q1a; q1a=delay_in; % der quadratur 0.6628 Teil [sample_out_q,delay_in]=block2_calc(q1_out,q2b,0.6628); q2b=q2a; q2a=delay_in; sample_z=sample_out_i+i*sample_out_q; endfunction %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% %%% %%% %%% Main %%% %%% %%% %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% filename='wav/zahlen1_8kHz.wav'; [data,samplerate]=audioread(filename); data=data'; % Spaltenvektor draus machen %data=data(1:65000); % Ausschnitt zum testen --------------- max_amplitude=max(abs(data)); % Amplitude auf 1 normieren data=data/max_amplitude; %samplerate=8000; datalen=length(data); n=1:datalen; freq_axis=0.001*samplerate*n/datalen; freq_axis=freq_axis-0.001*samplerate/2; % Frequenzachse in kHz % eingebaute Hilbert-Trafo data_z_intern=hilbert(data); fft_data_z_intern=fft(data_z_intern); %% eigene Hilbert-Trafo berechnen data_z=zeros(1,datalen); for n=1:datalen, % im Streaming-Stil wie es im controller laufen würde data_z(n)=hilbert_algo_1(data(n)); if bitand(n,65535)==0 % Fortschrittsanzeige n endif end; fft_data_z=fft(data_z); %%%%%%%%%%%%%%%%%%%%%% Anzeige figure(101) semilogy(freq_axis,abs(fftshift(fft_data_z))+1e-6,freq_axis,abs(fftshift(fft_data_z_intern))+1e-6) % verschiedene Hilbert-Algo vergleichen %xlabel('Freq [kHz]'); title('FFT der Hilbert-Trafo') figure(102) % XY-Daten nach der Hilbert-Trafo plot(data_z)
