#include #include #include struct streaming_utf8_validator { uint_least8_t index : 3; uint_least8_t state : 4; }; static inline bool utf8_validate(struct streaming_utf8_validator*restrict const v, const int _ch){ const uint_least8_t ch = _ch & 0xFF; if(_ch == EOF){ if(v->index) goto bad; return true; } if(!v->index){ v->state = 0; if(ch < 0x80) return true; if(ch < 0xC2) goto bad; if(ch >= 0xFE) // Not yet defined goto bad; if(ch >= 0xF5) // Sequences above this value are defined, but not (yet?) allowed. goto bad; // If you remove this condition, make sure to check for the overlong characters for those longer sequeces unsigned length = 1 + (ch >= 0xE0) + (ch >= 0xF0) + (ch >= 0xF8) + (ch >= 0xFC); v->index = length; if(length == 2){ switch(ch){ case 0xE0: v->state = 1; break; // Overlong case 0xED: v->state = 2; break; // CESU-8 case 0xEF: v->state = 3; break; // noncharacter U+FFFE U+FFFF } } if(length == 3){ switch(ch){ case 0xF0: v->state = 5; break; // noncharacter case 0xF1: v->state = 8; break; // noncharacter case 0xF2: v->state = 8; break; // noncharacter case 0xF3: v->state = 8; break; // noncharacter case 0xF4: v->state = 6; break; // U+110000 - U+13FFFF, not yet used / allowed } } return true; } if((ch & 0xC0) != 0x80) goto bad; unsigned state = v->state; v->state = 0; switch(state){ case 1: if(ch >= 0x80 && ch <= 0x9F) goto bad; break; case 2: if(ch >= 0xA0 && ch <= 0xBF) goto bad; break; case 3: { if(ch == 0xBF) v->state = 4; if(ch == 0xB7) v->state = 7; } break; case 4: if(ch == 0xBE || ch == 0xBF) goto bad; break; case 5: { if(ch < 0x90 || ch > 0xBF) goto bad; if(ch == 0x9F || ch == 0xAF || ch == 0xBF) v->state = 9; } break; case 6: { if(ch < 0x80 || ch > 0x8F) goto bad; if(ch == 0x8F) v->state = 9; } break; case 7: if(ch >= 0x90 && ch <= 0xAF) goto bad; break; case 8: if(ch == 0x8F || ch == 0x9F || ch == 0xAF || ch == 0xBF) v->state = 9; break; case 9: if(ch == 0xBF) v->state = 4; break; } v->index -= 1; return true; bad: v->index = 0; return false; } int main(){ struct streaming_utf8_validator utf8_validator = {0}; bool valid = true; while(valid){ int ch = getchar(); if(!utf8_validate(&utf8_validator, ch)) valid = false; if(ch == EOF) break; } puts(valid ? "utf8: valid" : "utf8: INVALID"); }
