xTalk Version 6.7.0.0 Log File Start Time: 10/01/2022 21:10:35 Computer Name: TESTPC Operating System: MS Windows Sever 2012 or Windows 8 Version 6.2 (Build 9200) ____________________________________________________________ Start: 10/01/2022 21:10:35 Device: QUANTUM DLT-V4 MYL6F04233 0:0:255 Start: Device_Health_Check ----------- Script Build Information ------------- V:21.02 \DATA\QUANTUM\SRC\XTALK\TRUNK\DLTSAGE\SHARED\SCRIPTS\TESTS\DEVICE HEALTH CHECK.SCS Description: This series of diagnostic functions will aid in determining the wellness of your device. It will verify the mechanics electronics and the ability to read and write data to and from the removable media in your storage device. V:0.00 ..\CORE\_COLORS.HCS Description: Color Table For Script Usage V:5.00 ..\CORE\CDBS.HCS Description: CDB Master List V:9.00 ..\CORE\SK.HCS Description: SenseKey Table V:1.21 ..\CORE\CORE.HCS Description: Core Script V:1.00 ..\CORE\LOGPAGES.HCS Description: Log Page Handler V:0.00 ..\..\GLOBALS\DRIVETYPES.H Description: null V:4.00 ..\CORE\WARNING.HCS Description: Warning Message V:15.01 ..\TASKS\SET DLTICE FUNCTIONALITY.SCS Description: This tasks allows you to make a cartridge DLTSage WORM compatible. This only works on a cartridge that has no data already written on it. Valid device-cartridge combinations are: SDLT 600 with a Super DLTtape II cartridge DLT-S4 with a Super DLTtape II or Super DLTtape III cartridge or DLT-V4 with a DLTtape VS1 cartridge. V:1.00 ..\CORE\TIMETABLE.HCS Description: Test Time Table V:14.01 C:\DATA\QUANTUM\SRC\XTALK\TRUNK\DLTSAGE\SHARED\SCRIPTS\TESTS\SCSI INTERCONNECT TEST.SCS Description: This test determines whether the device is communicating correctly with the SCSI bus. To pass this test the device must be able to write 64 data bytes to the data buffer and read the same 64 data bytes from the data buffer 100 times. V:9.01 C:\DATA\QUANTUM\SRC\XTALK\TRUNK\DLTSAGE\SHARED\SCRIPTS\TESTS\LOAD TAPE TEST.SCS Description: This test determines whether the tape drive is ready to load a data cartridge and if it is performs the load operation. V:10.01 C:\DATA\QUANTUM\SRC\XTALK\TRUNK\DLTSAGE\SHARED\SCRIPTS\TESTS\QUICK WRITE READ TEST.SCS Description: This test performs quick write and read operations to validate the tape drive V:10.01 C:\DATA\QUANTUM\SRC\XTALK\TRUNK\DLTSAGE\SHARED\SCRIPTS\TESTS\SMALL BUFFER WRITE READ TEST.SCS Description: This test checks write and read tape operations. To pass this test the device must be able to write one block of data to tape and read the same block of data from the tape. When comparing the written and read data no data mismatches or check conditions may exist. V:11.02 C:\DATA\QUANTUM\SRC\XTALK\TRUNK\DLTSAGE\SHARED\SCRIPTS\TESTS\SYSTEM LEVEL TEST.SCS Description: This test writes 100 blocks of data in uncompressed fixed block mode with 65532 bytes per block. V:4.00 ..\CORE\BC8008.HCS Description: This test writes 1900 blocks of 32K data bytes. To pass this test the drive must be able to write 1900 data blocks to the tape drive and read the same data blocks from the tape drive. V:9.01 C:\DATA\QUANTUM\SRC\XTALK\TRUNK\DLTSAGE\SHARED\SCRIPTS\TESTS\PATTERN TEST.SCS Description: This test performs write-read operations with six different data patterns. Patterns 1 through 4 are the same size whereas patterns 5 and 6 are different. Compression is on for all patterns. V:20.00 C:\DATA\QUANTUM\SRC\XTALK\TRUNK\DLTSAGE\SHARED\SCRIPTS\TESTS\DROP OUT SCREEN.SCS Description: This test writes one to ten GBs of data based upon the tape drive type detected. After writing 3.276 MB the script queries the drive V:4.00 ..\CORE\FEATURES.HCS Description: Drive Feature Flags Script V:8.00 ..\TASKS\LOG PAGE 7.SCS Description: This task collects and then displays the drives Log Page 7 information. V:10.01 C:\DATA\QUANTUM\SRC\XTALK\TRUNK\DLTSAGE\SHARED\SCRIPTS\TESTS\TIMED PERFORMANCE TEST.SCS Description: This test performs a timed write operation. To pass the operation must complete in 15 seconds. Due to overhead during small writes DAT320 may take a little longer. V:4.00 ..\CORE\TYPETEST.HCS Description: Drive Type Detection Test Script V:1.13 ..\TASKS\DRIVE INFORMATION.SCS Description: This task queries the device and displays detailed device information including serial number firmware revision and device activity. V:3.00 ..\CORE\BRICKINFO.HCS Description: Query The Drive Brick Part Number V:5.00 ..\TASKS\_DAT72_INFORMATION.SCS Description: DAT-72 Drive Information Report Generator V:6.00 ..\TASKS\_GOVAULT_REPORTER.SCS Description: This task queries the device and displays detailed device information including serial number firmware revision and device activity. V:0.00 ..\CORE\LPCOMMON.HCS Description: null V:3.03 C:\DATA\QUANTUM\SRC\XTALK\TRUNK\DLTSAGE\SHARED\SCRIPTS\TESTS\LTO_ERRORRATE_TEST.SCS Description: This test writes and reads 4 to 18 GBs calculates the error rates per head in both directions and applies the limits for determining if the drive is operating correctly. V:1.02 C:\DATA\QUANTUM\SRC\XTALK\TRUNK\DLTSAGE\SHARED\SCRIPTS\TESTS\DELL_WR_TEST_SHORT.SCS Description: This test performs a short write-read test in fixed block mode with compression off and random data. -------------------------------------------------- ____________________________________________________________ Ready Test No Problem Detected ____________________________________________________________ Record Drive Settings Current Compression Status = Enabled No Problem Detected ____________________________________________________________ Drive Detection Test Drive Type:DLT V4 No Problem Detected ____________________________________________________________ SCSI Interconnect Test Write/Read Pass @ 10 of 100 Write/Read Pass @ 20 of 100 Write/Read Pass @ 30 of 100 Write/Read Pass @ 40 of 100 Write/Read Pass @ 50 of 100 Write/Read Pass @ 60 of 100 Write/Read Pass @ 70 of 100 Write/Read Pass @ 80 of 100 Write/Read Pass @ 90 of 100 Write/Read Pass @ 100 of 100 No Problem Detected ____________________________________________________________ Drive Information Report Drive Type ---------------- : DLT V4 Drive Serial Number ------- : MYL6F04233 Device Type --------------- : Tape ANSI Version -------------- : SPC-2 Media Changer Present ----- : No SftRe --------------------- : No Tagged Command Queuing ---- : No Linked Commands Support --- : No Synchronous Data Transfers : No 16-bit Data Transfer ------ : No 32-bit Data Transfer ------ : No Relative Addressing ------- : No Vendor ID ---------------- : QUANTUM Product ID ---------------- : DLT-V4 Product Revision Level ---- : 0A00 Product Family ------------ : 160.0 / 320.0 GB Released Firmware --------- : Released Code Vxxx Firmware Major Version ---- : 10 Firmware Minor Version ---- : 0 EEPROM Fmt Major Version -- : 1 EEPROM Fmt Minor Version -- : 30 Firmware Personality ------ : 0 Firmware SubPersonality --- : 1 TapeDir Format Version ---- : 0 Controller HW Version ----- : 0 Drive EEPROM Version ------ : 0 Drive HW Version ---------- : 0 Media Loader FW Version --- : 0 Media Loader HW Version --- : 0 Media Loader Mech Version - : 0 Loader Present ------------ : No Library Present ----------- : No Module Revision ----------- : 00000003 Servo FW Revision --------- : 24305742h Servo FW Checksum --------- : 335E93DCh Servo EEPROM Checksum ----- : 31342D46h Controller FW Checksum ---- : 65622D32h Controller FW Build Date -- : 007 10:27:52 A00A Power On Hours ------------ : 6543 Tape Motion Hours --------- : 15 # of Tape Loads ----------- : 13 MB Written ---------------- : 0 MB Read ------------------- : 0 Report Complete ____________________________________________________________ Pre - Test Log Page 7 Report ******************************************************************************* Packet #0018, POH=1, PwrCycles=1, Rev:8.0 UpTime:0d::1:48:17.427_542 Temp:31.5C ***BUGCHECK***->#040109D0 FFData1:00000001 FFData2:04010624 FFData3:84010208 Packet #0019, POH=2, PwrCycles=5, Rev:8.0 UpTime:0d::1:23:05.879_322 Temp:42.0C ***CodeUpdate***->OldRev:8.0 NewRev:9.0 Packet #0020, POH=6538, PwrCycles=23, Rev:9.0 UpTime:0d::0:27:30.640_429 Temp:34.5C ***CodeUpdate***->OldRev:9.0 NewRev:10.0 Log Page 7 Event Tally Report BugCheck = 1 Cup = 2 Log Page 7 Event Time Line Report POH: 1 Events: 1 Packet #0018, POH=1, PwrCycles=1, Rev:8.0 UpTime:0d::1:48:17.427_542 Temp:31.5C ***BUGCHECK***->#040109D0 FFData1:00000001 FFData2:04010624 FFData3:84010208 POH: 2 Events: 1 Packet #0019, POH=2, PwrCycles=5, Rev:8.0 UpTime:0d::1:23:05.879_322 Temp:42.0C ***CodeUpdate***->OldRev:8.0 NewRev:9.0 POH: 6538 Events: 1 Packet #0020, POH=6538, PwrCycles=23, Rev:9.0 UpTime:0d::0:27:30.640_429 Temp:34.5C ***CodeUpdate***->OldRev:9.0 NewRev:10.0 Report Complete ____________________________________________________________ Analyze Log Page 7 Pre-Test No Problem Detected ____________________________________________________________ Quick Write Read Test Setting compression on Setting variable block mode Rewinding Write 2 4k blocks with random data and 2 filemarks... Write 2 file marks Rewinding Read 1st block Read 2nd block Read 1st file mark Read 2nd file mark Rewinding No Problem Detected ____________________________________________________________ Small Buffer Write Read Test Setting the compression on Setting to variable block mode Rewinding Write 1 32k block of FFs... Rewinding Read compare 1 32k block... No Problem Detected ____________________________________________________________ System Level Test Setting fixed block mode Setting the compression off Rewinding Write 100 blocks with compression off Rewinding Read compare 100 blocks Rewinding Setting the compression on Write 100 blocks with compression on Rewinding Read compare 100 blocks Rewinding No Problem Detected ____________________________________________________________ Bug Check 8008 Test Setting the compression off Rewinding Setting to variable block mode Write 1900 blocks Rewinding Read and compare 1900 blocks Rewinding No Problem Detected ____________________________________________________________ Timed Performance Test Setting the compression off Setting the block size : 32K Rewinding Starting the clock Stopping the clock Data Transfer Time: 0:0:3.217 Test Time: 0:0:3.218 Rewinding No Problem Detected ____________________________________________________________ Pattern Test Setting to fixed block mode Setting the compression on Rewinding Writing Pattern #1 Rewinding Reading Pattern #1 Rewinding Writing Pattern #2 Rewinding Reading Pattern #2 Rewinding Writing Pattern #3 Rewinding Reading Pattern #3 Rewinding Writing Pattern #4 Rewinding Reading Pattern #4 Rewinding Writing Pattern #5 Rewinding Reading Pattern #5 Rewinding Writing Pattern #6 Rewinding Reading Pattern #6 Rewinding No Problem Detected ____________________________________________________________ Drop Out Screen Test Setting test parameters for DLT-V4 GBs to Process: 5 Load tape Rewinding Resetting Internal Counters Setting the compression off Setting to fixed block mode Write Loop @ 1 Total Bytes Processed: 0.359 Gb Ratio: 0.000 Rewrite/Gb Write Loop @ 2 Total Bytes Processed: 0.743 Gb Ratio: 0.000 Rewrite/Gb Write Loop @ 3 Total Bytes Processed: 1.126 Gb Ratio: 0.888 Rewrite/Gb Write Loop @ 4 Total Bytes Processed: 1.510 Gb Ratio: 0.662 Rewrite/Gb Write Loop @ 5 Total Bytes Processed: 1.893 Gb Ratio: 0.528 Rewrite/Gb Write Loop @ 6 Total Bytes Processed: 2.275 Gb Ratio: 0.440 Rewrite/Gb Write Loop @ 7 Total Bytes Processed: 2.660 Gb Ratio: 0.376 Rewrite/Gb Write Loop @ 8 Total Bytes Processed: 3.042 Gb Ratio: 0.329 Rewrite/Gb Write Loop @ 9 Total Bytes Processed: 3.427 Gb Ratio: 0.292 Rewrite/Gb Write Loop @ 10 Total Bytes Processed: 3.809 Gb Ratio: 0.263 Rewrite/Gb Write Loop @ 11 Total Bytes Processed: 4.194 Gb Ratio: 0.238 Rewrite/Gb Write Loop @ 12 Total Bytes Processed: 4.576 Gb Ratio: 0.219 Rewrite/Gb Write Loop @ 13 Total Bytes Processed: 4.959 Gb Ratio: 0.202 Rewrite/Gb Write Loop @ 14 Total Bytes Processed: 5.343 Gb Ratio: 0.187 Rewrite/Gb Rewinding No Problem Detected ____________________________________________________________ Post-Test Log Page 7 Report ******************************************************************************* Packet #0018, POH=1, PwrCycles=1, Rev:8.0 UpTime:0d::1:48:17.427_542 Temp:31.5C ***BUGCHECK***->#040109D0 FFData1:00000001 FFData2:04010624 FFData3:84010208 Packet #0019, POH=2, PwrCycles=5, Rev:8.0 UpTime:0d::1:23:05.879_322 Temp:42.0C ***CodeUpdate***->OldRev:8.0 NewRev:9.0 Packet #0020, POH=6538, PwrCycles=23, Rev:9.0 UpTime:0d::0:27:30.640_429 Temp:34.5C ***CodeUpdate***->OldRev:9.0 NewRev:10.0 Log Page 7 Event Tally Report BugCheck = 1 Cup = 2 Log Page 7 Event Time Line Report POH: 1 Events: 1 Packet #0018, POH=1, PwrCycles=1, Rev:8.0 UpTime:0d::1:48:17.427_542 Temp:31.5C ***BUGCHECK***->#040109D0 FFData1:00000001 FFData2:04010624 FFData3:84010208 POH: 2 Events: 1 Packet #0019, POH=2, PwrCycles=5, Rev:8.0 UpTime:0d::1:23:05.879_322 Temp:42.0C ***CodeUpdate***->OldRev:8.0 NewRev:9.0 POH: 6538 Events: 1 Packet #0020, POH=6538, PwrCycles=23, Rev:9.0 UpTime:0d::0:27:30.640_429 Temp:34.5C ***CodeUpdate***->OldRev:9.0 NewRev:10.0 Report Complete No packets found in the Post-Test Log Page 7 ____________________________________________________________ Restore Drive Settings ____________________________________________________________ Test Summary Drive Detection Test -------- : Passed SCSI Interconnect Test ------ : Passed Pre Test Log Page 7 --------- : Passed Tape Load Test -------------- : Passed Quick Write/Read Test ------- : Passed Small Buffer Wr/Rd Test ----- : Passed System Level Test ----------- : Passed Bug Check 8008 Test --------- : Passed Time Test ------------------- : Passed Multi-Pattern Test ---------- : Passed Drop Out Screen Test -------- : Passed Collect Log Page 7 ---------- : Passed Call Support ( 040109D0 ) No Problem Detected ____________________________________________________________ Elapsed Time: 00:11:54.93 Finish: 10/01/2022 21:22:30 Stop Time: 10/01/2022 21:22:30
