#include "WS2812.h" #define numleds 2 uint8_t pixel[numleds*3]; #define PWM_CT1_B 10 //OC1B #define PWM_CT2_B 3 //OC2B #define Vout A1 #define Vin A0 #define maxpwm 4*248 #define minpwm 0 float V_set_in = 17.0; float V_set_out = 14.4; int measct; int calibct; void ct1_init() { pinMode(PWM_CT1_B,OUTPUT); // 64 khz TCCR1A = (1 << COM1B0)|(1 << COM1B1)|(1 << WGM11)|(1 << WGM10); //fast PWM INV 10bit TCCR1B = (1 << CS10)|(1 << WGM12); // prescaler 0 OCR1B = 1; // pwm value } void setup() { pinMode(LED_BUILTIN, OUTPUT); pinMode(Vout, INPUT); pinMode(Vin, INPUT); Serial.begin(115200); ws2812_init(); ct1_init(); measct = 50; } int V_out, V_in; uint16_t pwm; float fpwm; char in_ch; uint8_t ledct; void loop() { float V_out_f, V_in_f; float in_diff, out_diff; V_in = analogRead(Vin); // 18.02 610 V_out = analogRead(Vout);// 14.20 476 V_in_f = V_in * 0.0295; V_out_f = V_out * 0.0298; in_diff = V_set_in - V_in_f; out_diff = V_set_out - V_out_f; if (out_diff <= -0.1) // batt volt high { fpwm += 3.5 * out_diff; digitalWrite(LED_BUILTIN,HIGH); } else // follow Vin { fpwm -= 2.0 * in_diff; digitalWrite(LED_BUILTIN,LOW); } fpwm = constrain(fpwm,minpwm,maxpwm); if (measct > 0) { pwm = minpwm; measct--; if (measct == 0) { V_set_in = 0.8 * V_in_f; fpwm = 0.0; } } else pwm = (uint16_t)fpwm; OCR1B = pwm; if (Serial.available()) { in_ch = Serial.read(); if (in_ch == '1') V_set_in -= 0.5; if (in_ch == '2') V_set_in += 0.5; if (in_ch == '3') V_set_out -= 0.1; if (in_ch == '4') V_set_out += 0.1; if (in_ch == '5') measct = 50; } //Serial.print(V_in); Serial.print(", "); //Serial.print(V_out); Serial.print(", "); Serial.print((float)pwm/32.0); Serial.print(", "); Serial.print(V_set_in); Serial.print(", "); Serial.print(V_in_f); Serial.print(", "); //Serial.print(in_diff); Serial.print(", "); //Serial.print(V_in); Serial.print(", "); Serial.print(V_set_out); Serial.print(", "); Serial.print(V_out_f); Serial.print(", "); //Serial.print(out_diff); Serial.print(", "); //Serial.print(V_out); Serial.print(", "); Serial.println(); ledct++; if (ledct >= 15) // 300ms { ledct = 0; for (uint8_t i=0;i<3*numleds;i++) pixel[i] = 0; if (out_diff > 0.2) pixel[4]=0x5a; // bat volt else pixel[3]=0x5a; if (in_diff > 0.1) pixel[1]=0x5a; // in volt else pixel[0]=0x5a; if (measct > 0) pixel[2]=0x5a; ws2812_sendarray(pixel,numleds*3); calibct++; if (calibct > 2000) // 10 min { measct=50; calibct = 0; } } delay(20); }
