/******************************************************************************************************** The program reads the radio weather forecast from hamsql.com and iap-kühlungsborn and outputs it to a display the datas are from "hamsql.com" by OM Paul Herrman , N0NBH -> THANKS a lot for it !! Thanks also to "Institut für Ionophärenphysik Rostock e.V. Aussenstelle Kühlungsborn" , Herrn Jens Mielich. Hardware: WEMOS D1 mini and an Adafruit_ILI9341 touch-display (320x240)[2.4" or 2.8" or 3.2" displays works also] get WEMOS D1 mini , 3.2" TFT w. Touch ILI9341 (or 2.4" or 2.8" or 3.2") from : ebay or similar providers it works with LOLIN-TFT 2.4" shield also - you have it to define in line 20 - or comment it out program idea and realization by Dr. Peter Heblik , DD6USB , version 2.5 from 5/1/2022 "OTA" means: the D1 mini can be programmed via WLAN - it does not have to be connected to a computer. how to program: in Arduino-IDE you find -> "Tools" -> "Ports" the Adress from "D1 mini for Solardat" and his local IP. Select it and download - thats all folks ! But attention! in OTA-mode the serial monitor does NOT work !!! ********************************************************************************************************/ String V_String = "ver 2.5ext edited 5/1/2022 by DD6USB" ; //#define debug // scratch out if not used (dont work by OTA) //#define debug1 // deep debug,scratch out if not used (dont work by OTA) #define WiFiOn // to switch WiFi & WWW on/off (for faster Tests) #define LOLIN_TFT_SHIED // if using LOLIN TFT-2.4" shield - otherwise uncomment it #include #include #include #include #include #include #include WiFiClientSecure client ; #include "Adafruit_GFX.h" // screen graphics #include "Adafruit_ILI9341.h" // hardware-spi #include //!!!!!write this in program direct!!!!!! char* ssid = "EasyBox-395521" ; // your SSID (for instance: "Area51") char* passw = "jcFfan3d6" ; // your password (for instance "11223344") //!!!!!!change your own path to these libraries !!!!! #include #include #include #ifdef LOLIN_TFT_SHIED #define TFT_DC D8 #define TFT_CS D0 #define TS_CS D3 #define TFT_RST -1 Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC, TFT_RST); XPT2046_Touchscreen ts(TS_CS); #else // Pins for the ILI9341 and ESP8266 (D1 mini) #define TFT_DC D2 #define TFT_CS D1 #define TFT_LED D8 #define TOUCH_CS D3 #define TOUCH_IRQ D4 Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC) ; // instance for the tft-screen XPT2046_Touchscreen ts(TOUCH_CS, TOUCH_IRQ) ; // instance for touch-screen #endif // all my known colors for ILI9341 TFT (but not all used in program) #define B_DD6USB 0x0006 // 0, 0, 4 my preferred background color !!! #define BLACK 0x0000 // 0, 0, 0 #define NAVY 0x000F // 0, 0, 123 #define DARKGREEN 0x03E0 // 0, 125, 0 #define DARKCYAN 0x03EF // 0, 125, 123 #define MAROON 0x7800 // 123, 0, 0 #define PURPLE 0x780F // 123, 0, 123 #define OLIVE 0x7BE0 // 123, 125, 0 #define LIGHTGREY 0xC618 // 198, 195, 198 #define DARKGREY 0x7BEF // 123, 125, 123 #define BLUE 0x001F // 0, 0, 255 #define GREEN 0x07E0 // 0, 255, 0 #define CYAN 0x07FF // 0, 255, 255 #define RED 0xF800 // 255, 0, 0 #define MAGENTA 0xF81F // 255, 0, 255 #define YELLOW 0xFFE0 // 255, 255, 0 #define WHITE 0xFFFF // 255, 255, 255 #define ORANGE 0xFD20 // 255, 165, 0 #define GREENYELLOW 0xAFE5 // 173, 255, 41 #define PINK 0xFC18 // 255, 130, 198 #define HOST "hamqsl.com" // source page in www #define HOST1 "www.ionosonde.iap-kborn.de" // another source page in www #define max_page 3 // only 4 pages, no more (at this time)[p0->p3] //============>> here the global variables: <<============= char atom ; // single char of content int8_t page_nr , old_page_nr ; // which page I am ? uint16_t color , x , k , pos , pos1 ; // for band-field-colors and string-positions uint16_t client_bytes = 1700 ; // max. bytes to read from content uint64_t start_time ; // for time_loop uint64_t loop_time = 900000 ; // 900.000 milli-secs = 15 min bool is_basic_pattern ; // flag for page0-pattern bool flag_color = false ; // flag for color change or not String pbuf, old_pbuf, t, t2 ; // to hold the old and new compressed content String old_iap , new_iap , iap_buf ; // hold the iap-datas for comparison String content_strings3[10] ; // hold the iap-datas //*************************************************************************** void setup(void) { tft.begin(); // initialize the screen #ifndef LOLIN_TFT_SHIED pinMode(TFT_LED, OUTPUT) ; // Pin for Backlight digitalWrite(TFT_LED, HIGH) ; // switch Backlight on #endif tft.setRotation(0) ; // orientation of the screen Serial.begin(115200) ; // initialize the serial interface tft.fillScreen(BLACK) ; // clear the screen #ifdef WiFiOn WiFi.mode(WIFI_STA) ; // for connect with WLAN WiFi.disconnect() ; // if an old connection exists delay(100) ; #endif #ifdef debug Serial.print("==> trying connecting Wifi: ") ; Serial.println(ssid) ; #endif WiFi.begin(ssid, passw) ; // connect to WLAN now while (WiFi.status() != WL_CONNECTED) { #ifdef debug Serial.print(".") ; #endif delay(250) ; } #ifdef debug Serial.print("\n WiFi connected ; ") ; Serial.print("my IP address: ") ; Serial.println(WiFi.localIP()) ; // show the IP in local WLAN #endif client.setInsecure() ; handle_OTA() ; // initialize OTA #ifdef debug Serial.println(" * Initializing touch screen now...") ; #endif ts.begin() ; // initialize the touch-screen ts.setRotation(2) ; // set orientation for touch-screen is_basic_pattern = false ; // flag for screen 0 page_nr = 0 ; // start-page handle_pages() ; // go a "first round" start_time = millis() ; // start timeloop } //*************************************************************** void loop(void) { ArduinoOTA.handle(); // occur new OTA programming ? if (ts.touched()) // new page wanted ? { page_nr == max_page ? page_nr = 0 : page_nr++ ; // rolling pages handle_pages() ; } if (time_loop_finished()) { if ((new_iap != old_iap) || !check_N0NBH_datas()) { #ifdef debug Serial.println("old_iap = " + old_iap) ; Serial.println("new_iap = " + new_iap) ; Serial.println(check_N0NBH_datas()) ; #endif old_iap = new_iap ; handle_pages() ; } start_time = millis() ; } } //************************************************************** void handle_pages(void) { old_page_nr != page_nr ? old_page_nr = page_nr : page_nr ; switch (page_nr) // good for handling more pages (maybe in future) { case 0 : { handle_page0() ; // work page 0 break ; } case 1 : { handle_page1() ; // work page 1 break ; } case 2 : { handle_page2() ; // work page 2 break ; } case 3 : { handle_page3() ; // work page 3 break ; } default: break ; } } //*************************************************************** void handle_page0(void) // side of the band openings { if (!is_basic_pattern) { draw_basic_pattern() ; // draw the basic pattern } #ifdef WiFiOn get_and_compress_all_client_data() ; // read the main content of the webpage get_and_show_bottombar_datas() ; // create the bottom-bar get_and_show_topbar_datas() ; // create the top-bar get_and_show_band_colors() ; // show band colors #endif } //************************************************************** void handle_page2(void) // first side of the solar datas { char * content_strings1[] = { "", "", "", "", "", "", "", "", "", "", "", "" } ; // names of content (part 1) flag_color = true ; // flag for changing colors tft.setFont() ; tft.fillScreen(B_DD6USB + 7); // background for the page is_basic_pattern = false ; // flag for page0 tft.fillRoundRect(0, 0, 240, 20, 5, MAROON) ; tft.setCursor(180, 5) ; // generate the top bar tft.setTextColor(GREEN) ; tft.print("tnx:N0NBH") ; get_and_show_topbar_datas() ; // show top bar tft.setFont(&FreeSans9pt7b) ; tft.setCursor(0, 40) ; // start displaying the sun values color = GREEN ; tft.setTextColor(color) ; for (uint8_t i = 0 ; i < 12 ; i++) // list the content (part 1) { parse_string_and_tftprint(content_strings1[i]) ; } tft.setTextColor(WHITE) ; tft.setCursor(0, 307) ; tft.print("===>> continued next page") ; //hint for page 2 flag_color = false ; } //*************************************************************** void handle_page3(void) // second side of the solar datas { char * content_strings2[] = {"", "", "", "", "", "", "" } ; // names of content (part 2) flag_color = true ; // flag for changing colors tft.setFont() ; tft.fillScreen(B_DD6USB + 7); // background for the page is_basic_pattern = false ; // flag for page0 tft.fillRoundRect(0, 0, 240, 20, 5, MAROON) ; tft.setCursor(180, 5) ; // generate the top bar tft.setTextColor(GREEN) ; tft.print("tnx:N0NBH") ; // thanks PAUL ! get_and_show_topbar_datas() ; // show top bar tft.setFont(&FreeSans9pt7b) ; tft.setCursor(0, 43) ; // start display of the sun values color = GREEN ; tft.setTextColor(color) ; for (uint8_t i = 0 ; i < 7 ; i++) // list the content (part 2) { parse_string_and_tftprint(content_strings2[i]) ; } tft.print("\n =====>> EOM <<=====") ; // END OF MESSAGE ! tft.setFont() ; tft.fillRoundRect(0, 300, 240, 20, 5, MAROON) ; tft.drawRoundRect(0, 300, 240, 20, 5, WHITE) ; tft.setTextColor(CYAN) ; tft.setCursor(15, 306) ; tft.setTextColor(WHITE) ; tft.print(V_String) ; // show version-number flag_color = false ; } //************************************************************** void handle_page1(void) // side of the MUF-table { String km_string[8] = {" 100", " 200", " 400", " 600", " 800", "1000", "1500", "3000"} ; uint16_t g ; flag_color = true ; new_iap = "" ; //state of affairs is_basic_pattern = false ; // flag for page0 tft.fillScreen(BLACK) ; // clear blue screen tft.fillRoundRect(0, 0, 240, 16, 5, MAROON) ; // build top header tft.drawRoundRect(0, 0, 240, 17, 5, WHITE) ; tft.setTextColor(CYAN) ; read_iap_datas() ; // get the muf-table-datas tft.setFont() ; tft.setCursor(3, 5) ; tft.print(" " + content_strings3[10] + " UTC ") ; //show the last change-time tft.setTextColor(WHITE) ; tft.print(" tnx:iap_kborn.de") ; tft.fillRoundRect(3, 19, 234, 298, 5, B_DD6USB + 12) ;// background tft.drawRoundRect(3, 19, 234, 298, 5, YELLOW) ; // generate the borders tft.setCursor(10, 35) ; // headline position tft.setTextColor(GREEN) ; // headline color tft.setFont(&FreeSans9pt7b) ; // headline font tft.print(" Juliusruh MUF-Table") ; // generate headline tft.setTextColor(WHITE) ; tft.setCursor(0, 69) ; tft.println(" km MHz") ;// table header tft.setFont(&FreeSans12pt7b) ; tft.setTextColor(YELLOW) ; tft.setCursor(0, 100) ; // startposition of table-text for (g = 0 ; g < 8 ; g++) // print the values in her columns & rows { tft.print(" " + km_string[g]) ; tft.setCursor(150 , 100 + g * 29) ; if (content_strings3[7 - g].toInt() < 10) tft.print(" ") ; // arrange positions tft.println(content_strings3[7 - g]) ; // print the MUF-values } tft.drawFastVLine(120, 53, 256, CYAN) ; // build column-bar tft.drawRect(11, 50, 218, 262, CYAN) ; // generate table-frame for (g = 77 ; g < 300 ; g += 29) // build the table-rows { tft.drawFastHLine(12, g , 216, CYAN) ; } } //************************************************************** void read_iap_datas(void) { iap_buf = "" ; // clear pbuf if (!client.connect(HOST1, 443)) //Open iap-server Connection { #ifdef debug Serial.println(F("Connection failed")) ; #endif return ; } else { #ifdef debug Serial.println(F("\thost is connected now")) ; #endif } client.print(F("GET ")) ; // question to client client.print("/latest_JR055_MUF.txt") ; // go to table-page client.println(F(" HTTP/1.1")) ; // send question header client.print(F("Host: ")) ; client.println(HOST1) ; client.println(F("Cache-Control: no-cache")) ; // no old cache please! if (client.println() == 0) { #ifdef debug Serial.println(F("client error")) ; #endif return ; } delay(10); char endOfHeaders[] = "\r\n\r\n" ; // ignore HTTP Header if (!client.find(endOfHeaders)) { #ifdef debug Serial.println(F("server error")) ; #endif return ; } //===============>> now read the webpage <<================== for ( uint16_t i = 0 ; i < 180 ; i++) { atom = client.read() ; if (atom != 0xFF) //"forget" the unused atoms { iap_buf = iap_buf + atom ; } } #ifdef debug Serial.println("===========================================") ; Serial.print(iap_buf) ; Serial.println("===========================================") ; #endif new_iap = "" ; for (uint8_t z = 0 ; z < 8 ; z++) // parse iap_content { pos = iap_buf.lastIndexOf("\n") ; // search for every newline t = iap_buf.substring(pos - 5 , pos) ; // ectract substring iap_buf = iap_buf.substring(0, pos - 5 ) ; // build iap_substring t.trim() ; // delete whitespace content_strings3[z] = t ; // create iap_fullstring new_iap = new_iap + t ; #ifdef debug Serial.println("\n " + content_strings3[z]) ; #endif } if (old_iap = "") old_iap = new_iap ; // first initialization of old_iap content_strings3[10] = iap_buf.substring(16, 32) ; // len = 16 holds: date & time content_strings3[10].setCharAt(4, '/') ; // change single signs content_strings3[10].setCharAt(7, '/') ; content_strings3[10].setCharAt(10, ' ') ; content_strings3[10].setCharAt(13, ':') ; #ifdef debug Serial.println(content_strings3[10]) ; #endif } //************************************************************** void parse_string_and_tftprint(String s11) // side of the band openings { t2 = "Yellow } } //*************************************************************** bool time_loop_finished(void) { if ((start_time + loop_time) > millis()) { return false ; } else { return true ; } } //*************************************************************** void draw_basic_pattern(void) { tft.fillScreen(B_DD6USB + 3) ; // a little more intense draw_WiFi_Quality() ; // draw top bar WiFi draw_band_pattern() ; } //*************************************************************** void draw_band_pattern(void) { for ( int i = 20; i < 280; i += 40) { tft.drawFastHLine(0, i, 240, YELLOW) ; } tft.drawFastVLine(180, 20, 280, YELLOW) ; tft.drawFastVLine(122, 20, 200, YELLOW) ; tft.drawFastVLine( 0, 20, 280, YELLOW) ; tft.drawFastVLine(239, 20, 280, YELLOW) ; tft.setFont(&FreeSans12pt7b) ; tft.setCursor(25, 48) ; tft.setTextColor(YELLOW) ; tft.print("Band") ; tft.setCursor(5, 87) ; tft.print("80m - 40m") ; tft.setCursor(5, 127) ; tft.print("30m - 20m") ; tft.setCursor(5, 167) ; tft.print("17m - 15m") ; tft.setCursor(5, 207) ; tft.print("12m - 10m") ; tft.setCursor(0, 247) ; tft.print(" E - skip 6m [EU]") ; tft.setCursor(0, 287) ; tft.print(" E - skip 4m [EU]") ; tft.setFont(&FreeMono9pt7b) ; tft.setTextColor(WHITE) ; tft.setCursor(133, 45) ; tft.print("day") ; tft.setTextColor(CYAN) ; tft.setCursor(183, 45) ; tft.print("night") ; } //*************************************************************** int8_t getWifiQuality() // converts the dBm to a range between 0 and 100% { int32_t dbm = WiFi.RSSI() ; // get WiFi RSSI if (dbm <= -100) { return 0 ; } else if (dbm >= -50) { return 100; } else { return 2 * (dbm + 100); } } //****************************************************************** void draw_WiFi_Quality(void) { tft.setFont() ; char buf[10] ; int8_t quality = getWifiQuality() ; tft.setTextColor(GREEN) ; tft.setTextSize(1) ; tft.setCursor(170, 5) ; sprintf(buf, "RSSI:%2d%c", quality, '%') ; tft.print(buf) ; for (int8_t i = 0; i < 4; i++) { for (int8_t j = 0; j < 2 * (i + 1); j++) { if (quality > i * 25 || j == 0) { tft.drawPixel(224 + 2 * i, 12 - j, YELLOW); } } } } //****************************************************************** void get_and_compress_all_client_data(void) { pbuf = "" ; // clear pbuf String sbuf = "" ; if (!client.connect(HOST, 443)) //Open Server Connection { #ifdef debug Serial.println(F("Connection failed")) ; #endif return ; } else { #ifdef debug Serial.println(F("\thost is connected now")) ; #endif } client.print(F("GET ")) ; // question to client client.print("/solarxml.php") ; // go to www.hamsql.com/solarxml.php) client.println(F(" HTTP/1.1")) ; // send question header client.print(F("Host: ")) ; client.println(HOST) ; client.println(F("Cache-Control: no-cache")) ; if (client.println() == 0) { Serial.println(F("client error")) ; return ; } delay(10); char endOfHeaders[] = "\r\n\r\n" ; // ignore HTTP Header if (!client.find(endOfHeaders)) { Serial.println(F("server error")) ; return ; } //===============>> now read the webpage <<================== for ( int i = 0 ; i < client_bytes ; i++) { atom = client.read() ; sbuf = sbuf + atom ; } #ifdef debug1 Serial.println(sbuf) ; Serial.print(" len sbuf = ") ; Serial.println(sbuf.length()) ; #endif //===============>> now compress the content <<================== // means: delete all: cr,lf,",space,tab and shortening the string String t = "" ; // begin of "interest" of the content String t1 = "" ; // end of "interest" of the content for (int j = (sbuf.indexOf(t) + t.length()) ; j < sbuf.indexOf(t1) ; j++) { atom = sbuf[j] ; if (!isWhitespace(atom) && !isControl(atom) && (atom != 34) && (atom != 255)) { pbuf = pbuf + atom ; // build the compressed string } } // in pbuf is now the compessed content-ready for parsing #ifdef debug Serial.println() ; Serial.println(pbuf) ; Serial.print(" len pbuf = ") ; Serial.println(pbuf.length()) ; #endif } //******************************************************************* void get_and_show_bottombar_datas(void) { char * content_string[] = {"", "", ""} ; String Flux, SN, Muf ; char kbuf[30] ; flag_color = false ; tft.setFont() ; tft.fillRoundRect(0, 300, 240, 20, 5, MAROON) ; tft.drawRoundRect(0, 300, 240, 20, 5, WHITE) ; tft.fillRoundRect(1, 302, 57, 16, 5, BLACK) ; tft.setTextColor(CYAN) ; tft.setCursor(2, 306) ; tft.print("tnx:N0NBH") ; parse_string_and_tftprint(content_string[0]) ; Flux = pbuf.substring(pos, pos1) ; parse_string_and_tftprint(content_string[1]) ; SN = pbuf.substring(pos, pos1) ; parse_string_and_tftprint(content_string[2]) ; Muf = pbuf.substring(pos, pos1) ; if (isAlpha(Muf.charAt(1))) { Muf = "noInfo" ; } tft.setCursor(51, 306) ; tft.setTextColor(WHITE) ; sprintf(kbuf, " Flux:%s S/N:%s MUF:%s", Flux, SN, Muf) ; tft.print(kbuf) ; #ifdef debug1 Serial.println(kbuf) ; #endif } //*************************************************************** void get_and_show_topbar_datas(void) { tft.setFont() ; tft.setTextSize(1) ; tft.setTextColor(CYAN) ; char buf1[30] ; String date1 = pbuf.substring(0, 2) ; // day String date2 = pbuf.substring(2, 5) ; // month String date3 = pbuf.substring(5, 9) ; // year String date4 = pbuf.substring(9, 11) ; // hour String date5 = pbuf.substring(11, 13) ; // min #ifdef debug Serial.println("string-parts:" + date1 + "," + date2 + "," + date3 + "," + date4 + "," + date5) ; #endif sprintf(buf1, "from %s %s %s %s:%s UTC", date1, date2, date3, date4, date5) ; tft.setCursor(5, 5) ; tft.print(buf1) ; tft.drawRoundRect(0, 0, 240, 18, 5, WHITE) ; } //****************************************************************** int check_color(String) // colors of the Ham-band-areas { if (t == "P") // check "poor" { color = RED ; } else if ( t == "F") // check "fair" { color = YELLOW ; } else if ( t == "G") // check "good" { color = GREEN ; } return (color) ; } //******************************************************************** int check_day_80_40m(void) { t = "40mtime=day>" ; x = pbuf.indexOf(t) + t.length(); t = pbuf.substring(x, x + 1) ; // one letter is significant return (check_color(t)) ; } //******************************************************************** int check_night_80_40m(void) { t = "40mtime=night>" ; x = pbuf.indexOf(t) + t.length() ; t = pbuf.substring(x, x + 1) ; return (check_color(t)) ; } //******************************************************************** int check_day_30_20m(void) { t = "20mtime=day>" ; x = pbuf.indexOf(t) + t.length() ; t = pbuf.substring(x, x + 1) ; return (check_color(t)) ; } //******************************************************************** int check_night_30_20m(void) { t = "20mtime=night>" ; x = pbuf.indexOf(t) + t.length() ; t = pbuf.substring(x, x + 1) ; return (check_color(t)) ; } //******************************************************************** int check_day_17_15m(void) { t = "15mtime=day>" ; x = pbuf.indexOf(t) + t.length() ; t = pbuf.substring(x, x + 1) ; return (check_color(t)) ; } //******************************************************************** int check_night_17_15m(void) { t = "15mtime=night>" ; x = pbuf.indexOf(t) + t.length() ; t = pbuf.substring(x, x + 1) ; return (check_color(t)) ; } //******************************************************************** int check_day_12_10m(void) { t = "10mtime=day>" ; x = pbuf.indexOf(t) + t.length() ; t = pbuf.substring(x, x + 1) ; return (check_color(t)) ; } //******************************************************************** int check_night_12_10m(void) { t = "10mtime=night>" ; x = pbuf.indexOf(t) + t.length() ; t = pbuf.substring(x, x + 1) ; return (check_color(t)) ; } //******************************************************************** int check_6m(void) { t = "_6m>" ; x = pbuf.indexOf(t) + t.length() ; t = pbuf.substring(x, x + 1) ; return (check_color(t)) ; } //******************************************************************** int check_4m(void) { t = "_4m>" ; x = pbuf.indexOf(t) + t.length() ; t = pbuf.substring(x, x + 1) ; return (check_color(t)) ; } //******************************************************************** void get_and_show_band_colors(void) { tft.fillRect(125, 63, 53, 35, check_day_80_40m()) ; // 80 day tft.fillRect(183, 63, 55, 36, check_night_80_40m()) ; // 80 night tft.fillRect(126, 103, 52, 35, check_day_30_20m()) ; // 20 day tft.fillRect(183, 103, 54, 35, check_night_30_20m()) ; // 20 night tft.fillRect(126, 143, 52, 35, check_day_17_15m()) ; // 15 day tft.fillRect(183, 143, 54, 35, check_night_17_15m()) ; // 15 night tft.fillRect(126, 183, 52, 35, check_day_12_10m()) ; // 10 day tft.fillRect(183, 183, 54, 35, check_night_12_10m()) ; // 10 night tft.fillRect(183, 223, 55, 35, check_6m()) ; // 6 tft.fillRect(183, 263, 54, 35, check_4m()) ; // 4 } //******************************************************************** bool check_N0NBH_datas(void) { old_pbuf = pbuf ; // hold the last values get_and_compress_all_client_data() ; // get the present values if (old_pbuf.substring(20, old_pbuf.length()) == pbuf.substring(20, pbuf.length())) { #ifdef debug Serial.println("N0NBH-Strings are equal") ; #endif return true ; } else { #ifdef debug Serial.println("N0NBH-Strings not equal !!") ; #endif old_page_nr = -1 ; //force updating of the present page return false ; } } //*************************************************************** void handle_OTA(void) { //ArduinoOTA.setPort(8266) ; // Port defaults to 8266 ArduinoOTA.setHostname("D1 mini for Solardat") ; // Hostname defaults to esp8266-[ChipID] // ArduinoOTA.setPassword((const char *)"123") ; // No authentication by default ArduinoOTA.onStart([]() { #ifdef debug Serial.println("Start") ; #endif } ) ; ArduinoOTA.onEnd([]() { #ifdef debug Serial.println("End") ; #endif } ) ; ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) { #ifdef debug Serial.printf("Progress: %u%%\n", (progress / (total / 100))) ; #endif } ) ; ArduinoOTA.onError([](ota_error_t error) { #ifdef debug Serial.printf("Error[%u]: ", error) ; if (error == OTA_AUTH_ERROR) Serial.println("Auth Failed") ; else if (error == OTA_BEGIN_ERROR) Serial.println("Begin Failed") ; else if (error == OTA_CONNECT_ERROR) Serial.println("Connect Failed") ; else if (error == OTA_RECEIVE_ERROR) Serial.println("Receive Failed") ; else if (error == OTA_END_ERROR) Serial.println("End Failed") ; #endif } ) ; ArduinoOTA.begin() ; #ifdef debug Serial.println("OTA READY") ; Serial.println("Ready") ; Serial.print("IP address: ") ; Serial.println(WiFi.localIP()) ; #endif } //***************************************************************************
