//converts bin32/16 to 4/3/2 byte packed bcd and revers 4/3/2 byte packed bcd to bin32/16 //based on double babble algorithm https://en.wikipedia.org/wiki/Double_dabble #define BIN2BCD_ENROLLED //#define BIN2BCD_DIGITS_6 //default 8 digits #define BIN2BCD_DIGITS_4 #ifdef BIN2BCD_DIGITS_6 #define BIN2BCD_DIGITS 6 #define BIN2BCD_TYPE uint32_t #define BIN2BCD_BITS 32 #elif defined BIN2BCD_DIGITS_4 #define BIN2BCD_DIGITS 4 #define BIN2BCD_TYPE uint16_t #define BIN2BCD_BITS 16 #else #define BIN2BCD_DIGITS 8 #define BIN2BCD_TYPE uint32_t #define BIN2BCD_BITS 32 #endif //converts bin32/16 to 4/3/2 byte packed bcd BIN2BCD_TYPE bin2bcd(BIN2BCD_TYPE x) { //double dabble algorithm #ifdef BIN2BCD_DIGITS_4 union {uint16_t w42; struct{uint8_t l8,h8;};} bcd={.w42=0}, bin={.w42=x}; #else union {uint32_t w42; struct{uint8_t l8,ml8,mh8,h8;};} bcd={.w42=0}, bin={.w42=x}; #endif //to speed up search/count for first 1-bit position to skip leading 0-bits uint8_t n; for (uint8_t i=BIN2BCD_BITS; i; i--) { if (bin.h8 & 0x80) {n=i; break;} bin.w42 <<= 1; } for (uint8_t i=n; i; i--) { //digit value >4 needs 3 shifts therefore skip first 2 shifts as well as leading 0-bits if (i < n-2) { //check all digits for > 4 and add 3 # ifndef BIN2BCD_ENROLLED uint8_t *pbcd = &bcd.w42; for (uint8_t i=BIN2BCD_DIGITS/2; i; pbcd++,i--) { if ((*pbcd & 0xF0) > 0x40) *pbcd += 0x30; if ((*pbcd & 0x0F) > 0x04) *pbcd += 0x03; } # endif # ifdef BIN2BCD_ENROLLED #if BIN2BCD_DIGITS > 6 if ((bcd.h8 & 0xF0) > 0x40) bcd.h8 += 0x30; if ((bcd.h8 & 0x0F) > 0x04) bcd.h8 += 0x03; #endif #if BIN2BCD_DIGITS > 4 if ((bcd.mh8 & 0xF0) > 0x40) bcd.mh8 += 0x30; if ((bcd.mh8 & 0x0F) > 0x04) bcd.mh8 += 0x03; #endif #if BIN2BCD_DIGITS < 6 if ((bcd.h8 & 0xF0) > 0x40) bcd.h8 += 0x30; if ((bcd.h8 & 0x0F) > 0x04) bcd.h8 += 0x03; #else if ((bcd.ml8 & 0xF0) > 0x40) bcd.ml8 += 0x30; if ((bcd.ml8 & 0x0F) > 0x04) bcd.ml8 += 0x03; #endif if ((bcd.l8 & 0xF0) > 0x40) bcd.l8 += 0x30; if ((bcd.l8 & 0x0F) > 0x04) bcd.l8 += 0x03; # endif } bcd.w42 <<= 1; if (bin.h8 & 0x80) bcd.l8 |= 0x01; bin.w42 <<= 1; } return bcd.w42; } //converts 4/3/2 byte packed bcd to bin32/16 BIN2BCD_TYPE bcd2bin(BIN2BCD_TYPE x) { //double dabble algorithm #ifdef BIN2BCD_DIGITS_4 union {uint16_t w42; struct{uint8_t l8,h8;};} bcd={.w42=x}, bin={.w42=0}; #else union {uint32_t w42; struct{uint8_t l8,ml8,mh8,h8;};} bcd={.w42=x}, bin={.w42=0}; #endif //to speed up search&count for leading 0-digits to skip correction of related digits uint8_t n; for (uint8_t i=0; i>n)) break; } for (uint8_t i=BIN2BCD_BITS; i; i--) { bin.w42 >>= 1; if (bcd.l8 & 0x01) bin.h8 |= 0x80; bcd.w42 >>= 1; //0-digits don't need correction therefore skip leading 0-digits if (i > n) { //check all digits for value > 7 and sub 3 # ifndef BIN2BCD_ENROLLED uint8_t *pbcd = &bcd.w42; for (uint8_t i=BIN2BCD_DIGITS/2; i; pbcd++,i--) { if ((*pbcd & 0xF0) > 0x70) *pbcd -= 0x30; if ((*pbcd & 0x0F) > 0x07) *pbcd -= 0x03; } # endif # ifdef BIN2BCD_ENROLLED #if BIN2BCD_DIGITS > 6 if ((bcd.h8 & 0xF0) > 0x70) bcd.h8 -= 0x30; if ((bcd.h8 & 0x0F) > 0x07) bcd.h8 -= 0x03; #endif #if BIN2BCD_DIGITS > 4 if ((bcd.mh8 & 0xF0) > 0x70) bcd.mh8 -= 0x30; if ((bcd.mh8 & 0x0F) > 0x07) bcd.mh8 -= 0x03; #endif #ifdef BIN2BCD_DIGITS < 6 if ((bcd.h8 & 0xF0) > 0x70) bcd.h8 -= 0x30; if ((bcd.h8 & 0x0F) > 0x07) bcd.h8 -= 0x03; #else if ((bcd.ml8 & 0xF0) > 0x70) bcd.ml8 -= 0x30; if ((bcd.ml8 & 0x0F) > 0x07) bcd.ml8 -= 0x03; #endif if ((bcd.l8 & 0xF0) > 0x70) bcd.l8 -= 0x30; if ((bcd.l8 & 0x0F) > 0x07) bcd.l8 -= 0x03; # endif } } return bin.w42; }
