library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity tb_komparator_4_bit is end entity tb_komparator_4_bit ; architecture tb of tb_komparator_4_bit is signal s_X : std_logic_vector(3 downto 0) := (others => '0'); signal s_Y : std_logic_vector(3 downto 0) := (others => '0'); signal s_GROESSER : std_logic := '0'; signal s_KLEINER : std_logic := '0'; signal s_GLEICH : std_logic := '0'; signal s_lfsr : std_logic_vector(31 downto 0) := x"01234567"; begin process begin for i in 0 to 1023 loop s_lfsr <= s_lfsr(30 downto 0) & not(s_lfsr(31) xor s_lfsr(22) xor s_lfsr(2) xor s_lfsr(1)); s_X <= s_lfsr(7 downto 4); s_Y <= s_lfsr(19 downto 16); wait for 1 ns; if unsigned(s_X) > unsigned(s_Y) then if s_GROESSER = '0' or s_KLEINER = '1' or s_GLEICH = '1' then report "Fehler" severity error; end if; elsif unsigned(s_X) < unsigned(s_Y) then if s_GROESSER = '1' or s_KLEINER = '0' or s_GLEICH = '1' then report "Fehler" severity error; end if; else if s_GROESSER = '1' or s_KLEINER = '1' or s_GLEICH = '0' then report "Fehler" severity error; end if; end if; wait for 1 ns; end loop; wait; end process; inst_KOMPARATOR_4_BIT : entity work.KOMPARATOR_4_BIT port map ( X => s_X, Y => s_Y, GROESSER => s_GROESSER, KLEINER => s_KLEINER, GLEICH => s_GLEICH ); end;
