diff -r -U2 ComponentTester-1.47m.orig/probes.c ComponentTester-1.47m.fix-testpin-free-assignments/probes.c --- ComponentTester-1.47m.orig/probes.c 2022-02-18 17:57:40.000000000 +0100 +++ ComponentTester-1.47m.fix-testpin-free-assignments/probes.c 2022-12-09 19:55:39.079013128 +0100 @@ -364,5 +364,5 @@ continue; - U_c = ReadU(ID); /* get voltage of probe */ + U_c = ReadU(DATA_read_byte(&Channel_table[ID])); /* get voltage of probe */ if (U_c < U_old[ID]) /* voltage decreased */ @@ -413,5 +413,5 @@ Flags = DATA_read_byte(&Rh_table[ID]) | DATA_read_byte(&Rl_table[ID]); R_DDR &= ~Flags; /* disable load resistors */ - Check.U = ReadU(ID); /* get and save voltage */ + Check.U = ReadU(DATA_read_byte(&Channel_table[ID])); /* get and save voltage */ Counter = 0; /* end loop */ @@ -942,5 +942,5 @@ wait5ms(); R_DDR = Probes.Rl_2 | Probes.Rl_3; /* pull down base via Rl */ - U_1 = ReadU_5ms(Probe2); /* get voltage at collector */ + U_1 = ReadU_5ms(Probes.Ch_2); /* get voltage at collector */ /* @@ -978,5 +978,5 @@ R_DDR = Probes.Rl_1 | Probes.Rl_3; /* select Rl for probe-1 & Rl for probe-3 */ R_PORT = Probes.Rl_1 | Probes.Rl_3; /* pull up collector & base via Rl */ - U_1 = ReadU_5ms(Probe1); /* get voltage at collector */ + U_1 = ReadU_5ms(Probes.Ch_1) /* get voltage at collector */ /*
