# /bin/ - Systemrelevant & user relevant abpoa abpoa.avx abpoa.avx2 abpoa.generic abpoa.sse3 abpoa.sse4.1 abpoa.ssse3 ash bash (1) - GNU Bourne-Again SHell bash-static brltty bsd-csh btrfs btrfs-convert btrfs-find-root btrfs-image btrfs-map-logical btrfs-select-super btrfsck btrfstune bunzip2 (1) - a block-sorting file compressor, v1.0.8 busybox bzcat (1) - decompresses files to stdout bzcmp (1) - compare bzip2 compressed files bzdiff (1) - compare bzip2 compressed files bzegrep (1) - search possibly bzip2 compressed files for a regular expression bzexe (1) - compress executable files in place bzfgrep (1) - search possibly bzip2 compressed files for a regular expression bzgrep (1) - search possibly bzip2 compressed files for a regular expression bzip2 (1) - a block-sorting file compressor, v1.0.8 bzip2recover (1) - recovers data from damaged bzip2 files bzless (1) - file perusal filter for crt viewing of bzip2 compressed text bzmore (1) - file perusal filter for crt viewing of bzip2 compressed text cat (1) - concatenate files and print on the standard output chacl (1) - change the access control list of a file or directory checkpassword.login checkproof chgrp (1) - change group ownership chmod (1) - change file mode bits chmod (2) - change permissions of a file chown (1) - change file owner and group chown (2) - change ownership of a file chvt con2fbmap coq.hb cp (1) - copy files and directories cpio (1) - copy files to and from archives dash (1) - command interpreter (shell) date (1) - print or set the system date and time dd (1) - convert and copy a file df (1) - report file system space usage dir (1) - list directory contents dmesg (1) - print or control the kernel ring buffer dnsdomainname (1) - show the system's DNS domain name domainname (1) - show or set the system's NIS/YP domain name dumpkeys e_axfilter e_deduction_server e_ltb_runner e_stratpar echo (1) - display a line of text echo (3ncurses) - curses input options ed efibootdump efibootmgr egrep (1) - print lines that match patterns eground ekb_create ekb_delete ekb_ginsert ekb_insert elogind-inhibit (1) - Execute a program with an inhibition lock taken elvis-tiny epclextract eprover false (1) - do nothing, unsuccessfully fbset fgconsole fgrep (1) - print lines that match patterns findmnt (8) - find a filesystem francine fuser (1) - identify processes using files or sockets fusermount (1) - mount and unmount FUSE filesystems fusermount3 (1) - mount and unmount FUSE filesystems getfacl (1) - get file access control lists grep (1) - print lines that match patterns gunzip (1) - compress or expand files gzexe (1) - compress executable files in place gzip (1) - compress or expand files hciconfig (1) - Configure Bluetooth devices hostname (1) - show or set the system's host name hostname (7) - hostname resolution description ip (7) - Linux IPv4 protocol implementation ip (8) - show / manipulate routing, network devices, interfaces and tunnels journalctl kbd_mode keyctl (2) - manipulate the kernel's key management facility kill (1) - send a signal to a process kill (2) - send signal to a process kmod (8) - Program to manage Linux Kernel modules ksh93 (1) - shell, the standard/restricted command and programming language live-boot live-config live-config-update live-medium-cache live-medium-eject live-partial-squashfs-updates live-persistence live-swapfile live-system live-toram live-update-initramfs live-update-initramfs-uuid lksh ln (1) - make links between files loadkeys login (1) - begin session on the system login (3) - write utmp and wtmp entries loginctl (1) - Control the elogind login manager logread lowntfs-3g (8) - Third Generation Read/Write NTFS Driver ls (1) - list directory contents lsblk (8) - list block devices lsmod (8) - Show the status of modules in the Linux Kernel machinectl membw mkdir (1) - make directories mkdir (2) - create a directory mknod (1) - make block or character special files mknod (2) - create a special or ordinary file mksh mksh-static mktemp (1) - create a temporary file or directory mktemp (3) - make a unique temporary filename modeline2fb more (1) - file perusal filter for crt viewing mount (2) - mount filesystem mount (8) - mount a filesystem mountpoint (1) - see if a directory or file is a mountpoint mt-gnu (1) - control magnetic tape drive operation mt-st mv (1) - move (rename) files nano (1) - Nano's ANOther editor, inspired by Pico nano-tiny nbd-server nbd-trdump nbd-trplay nc.openbsd (1) - arbitrary TCP and UDP connections and listens nc.traditional netstat (8) - Print network connections, routing tables, interface statistics, masquerade connections, and multicast memberships networkctl nisdomainname (1) - show or set the system's NIS/YP domain name ntfs-3g (8) - Third Generation Read/Write NTFS Driver ntfs-3g.probe (8) - Probe an NTFS volume mountability ntfscat (8) - print NTFS files and streams on the standard output ntfscluster (8) - identify files in a specified region of an NTFS volume. ntfscmp (8) - compare two NTFS filesystems and tell the differences ntfsfallocate (8) - preallocate space to a file on an NTFS volume ntfsfix (8) - fix common errors and force Windows to check NTFS ntfsinfo (8) - dump a file's attributes ntfsls (8) - list directory contents on an NTFS filesystem ntfsmove ntfsrecover (8) - Recover updates committed by Windows on an NTFS volume ntfssecaudit (8) - NTFS Security Data Auditing ntfstruncate (8) - truncate a file on an NTFS volume ntfsusermap (8) - NTFS Building a User Mapping File ntfswipe (8) - overwrite unused space on an NTFS volume nut-scanner openvt pax paxcpio paxtar pidof (8) - find the process ID of a running program ping (8) - send ICMP ECHO_REQUEST to network hosts ping4 (8) - send ICMP ECHO_REQUEST to network hosts ping6 (8) - send ICMP ECHO_REQUEST to network hosts portablectl prewikka-cli prewikka-crontab prewikka-httpd ps (1) - report a snapshot of the current processes. pwd (1) - print name of current/working directory qweborf rbash (1) - restricted bash, see bash(1) rc-status (8) - show status info about runlevels rdisc6 readlink (1) - print resolved symbolic links or canonical file names readlink (2) - read value of a symbolic link tc-red (8) - Random Early Detection rksh93 (1) - shell, the standard/restricted command and programming language rlksh rm (1) - remove files or directories rmdir (1) - remove empty directories rmdir (2) - delete a directory rmksh rnano (1) - a restricted nano run-parts (8) - run scripts or programs in a directory rzsh sash sed (1) - stream editor for filtering and transforming text setfacl (1) - set file access control lists setfont setserial setupcon sh (1) - command interpreter (shell) signify-openbsd sleep (1) - delay for a specified amount of time sleep (3) - sleep for a specified number of seconds ss (8) - another utility to investigate sockets startpar (1) - start runlevel scripts in parallel stty (1) - change and print terminal line settings stty (2) - unimplemented system calls su (1) - run a command with substitute user and group ID sync (1) - Synchronize cached writes to persistent storage sync (2) - commit filesystem caches to disk systemctl systemd systemd-ask-password systemd-creds systemd-escape systemd-firstboot systemd-hwdb systemd-inhibit systemd-machine-id-setup systemd-notify systemd-repart systemd-sysext systemd-sysusers systemd-tmpfiles systemd-tty-ask-password-agent tar (1) - an archiving utility tcsh tempfile (1) - create a temporary file in a safe manner touch (1) - change file timestamps touch (3ncurses) - curses refresh control routines toybox true (1) - do nothing, successfully udevadm (8) - udev management tool ulockmgr_server umount (2) - unmount filesystem umount (8) - unmount filesystems uname (1) - print system information uname (2) - get name and information about current kernel uncompress (1) - compress or expand files unicode_start upsc upscmd upslog upsrw upssched-cmd vdir (1) - list directory contents wdctl (8) - show hardware watchdog status ypdomainname (1) - show or set the system's NIS/YP domain name zcat (1) - compress or expand files zcmp (1) - compare compressed files zdiff (1) - compare compressed files zegrep (1) - search possibly compressed files for a regular expression zfgrep (1) - search possibly compressed files for a regular expression zforce (1) - force a '.gz' extension on all gzip files zgrep (1) - search possibly compressed files for a regular expression zless (1) - file perusal filter for crt viewing of compressed text zmore (1) - file perusal filter for crt viewing of compressed text znew (1) - recompress .Z files to .gz files zsh zsh-static zsh5 zsh5-static ztest zupdate # /sbin/ - Systemrelevant & Administrativ (braucht oft root) MAKEDEV (3) - manage a device number acorn-fdisk adjtimex (2) - tune kernel clock agetty (8) - alternative Linux getty amiga-fdisk aoe-discover aoe-flush aoe-interfaces aoe-mkdevs aoe-mkshelf aoe-revalidate aoe-sancheck aoe-stat aoe-version aoecfg aoeping apcaccess apctest apcupsd apparmor_parser (8) - loads AppArmor profiles into the kernel atmarp atmarpd audisp-remote audisp-syslog audispd-zos-remote auditctl auditd augenrules aureport ausearch autrace badblocks (8) - search a device for bad blocks bcachefs blkdeactivate (8) - utility to deactivate block devices blkdiscard (8) - discard sectors on a device blkid (8) - locate/print block device attributes blkzone (8) - run zone command on a device blockdev (8) - call block device ioctls from the command line bootlogd (8) - record boot messages bootpc brctl bridge (8) - show / manipulate bridge addresses and devices brltty cachefilesd capsh (1) - capability shell wrapper ccreds_chkpwd cfdisk (8) - display or manipulate a disk partition table cgdisk (8) - Curses-based GUID partition table (GPT) manipulator chcpu (8) - configure CPUs coldreboot coraid-update cryptdisks_start cryptdisks_stop cryptsetup cryptsetup-ssh ctrlaltdel (8) - set the function of the Ctrl-Alt-Del combination dcb (8) - show / manipulate DCB (Data Center Bridging) settings debugfs (8) - ext2/ext3/ext4 file system debugger debugfs.ocfs2 debugfs.reiser4 debugfs.reiserfs debugreiserfs defrag.f2fs defragfs.ocfs2 depmod (8) - Generate modules.dep and map files. devlink (8) - Devlink tool dhclient (8) - Dynamic Host Configuration Protocol Client dhclient-script (8) - DHCP client network configuration script discover discover-modprobe discover-pkginstall dmeventd dmraid dmraid-activate dmsetup (8) - low level logical volume management dmstats (8) - device-mapper statistics management dosfsck (8) - check and repair MS-DOS FAT filesystems dosfslabel (8) - set or get MS-DOS filesystem label or volume ID dphys-swapfile drbdadm drbdmeta drbdmon drbdsetup dump dump.f2fs dumpe2fs (8) - dump ext2/ext3/ext4 file system information e2fsck (8) - check a Linux ext2/ext3/ext4 file system e2fsck.static e2image (8) - Save critical ext2/ext3/ext4 file system metadata to a file e2label (8) - Change the label on an ext2/ext3/ext4 file system e2mmpstatus (8) - Check MMP status of an ext4 file system e2scrub (8) - check the contents of a mounted ext[234] file system e2scrub_all (8) - check all mounted ext[234] file systems for errors. e2undo (8) - Replay an undo log for an ext2/ext3/ext4 file system essidscan ethtool f2fs_io f2fscrypt f2fstat fake-hwclock fatlabel (8) - set or get MS-DOS filesystem label or volume ID fdisk (8) - manipulate disk partition table fgetty fibmap.f2fs findfs (8) - find a filesystem by label or UUID finit fixfiles fixparts (8) - MBR partition table repair utility freeramdisk fsadm fsck (8) - check and repair a Linux filesystem fsck.bcachefs fsck.btrfs fsck.cramfs (8) - fsck compressed ROM file system fsck.ext2 (8) - check a Linux ext2/ext3/ext4 file system fsck.ext3 (8) - check a Linux ext2/ext3/ext4 file system fsck.ext4 (8) - check a Linux ext2/ext3/ext4 file system fsck.f2fs fsck.fat (8) - check and repair MS-DOS FAT filesystems fsck.jfs fsck.minix (8) - check consistency of Minix filesystem fsck.msdos (8) - check and repair MS-DOS FAT filesystems fsck.nfs (8) - Dummy fsck.nfs script that always returns success. fsck.ocfs2 fsck.reiser4 fsck.reiserfs fsck.vfat (8) - check and repair MS-DOS FAT filesystems fsck.xfs fsfreeze (8) - suspend access to a filesystem (Ext3/4, ReiserFS, JFS, XFS) fstab-decode (8) - run a command with fstab-encoded arguments fstrim (8) - discard unused blocks on a mounted filesystem fxload gdisk (8) - Interactive GUID partition table (GPT) manipulator getcap (8) - examine file capabilities getpcaps (8) - display process capabilities getty (8) - alternative Linux getty gradm2 gradm_pam grlearn halt (5) - variables that affect the behavior of the shutdown scripts halt (8) - stop the system hdparm hwclock (5) - settings that affect the behaviour of the hwclock init script hwclock (8) - time clocks utility idle3ctl ifconfig (8) - configure a network interface ifctrstat ifdown ifparse ifquery ifreload ifrename ifscheme ifscheme-mapping ifup ifupdown init (8) - process control initialization insmod (8) - Simple program to insert a module into the Linux Kernel insserv (8) - boot sequence organizer using LSB init.d script dependency information install-mbr installkernel (8) - install a new kernel image integritysetup ip (7) - Linux IPv4 protocol implementation ip (8) - show / manipulate routing, network devices, interfaces and tunnels ipmaddr ipp-usb (8) - Daemon for IPP over USB printer support iptunnel (8) - Create and manage IP tunnels ipvsadm ipvsadm-restore ipvsadm-save iscsi-iname iscsi_discovery iscsiadm iscsid iscsistart iscsiuio isosize (8) - output the length of an iso9660 filesystem iw (8) - show / manipulate wireless devices and their configuration iwconfig iwevent iwgetid iwlist iwpriv iwspy jfs_debugfs jfs_fsck jfs_fscklog jfs_logdump jfs_mkfs jfs_tune kbdrate kexec key.dns_resolver killall5 (8) - send a signal to all processes klogd kpartx ldconfig (8) - configure dynamic linker run-time bindings load_policy logsave (8) - save the output of a command in a logfile losetup (8) - set up and control loop devices lsmod (8) - Show the status of modules in the Linux Kernel lspcmcia lvchange lvconvert lvcreate lvdisplay lvextend lvm lvmconfig lvmdbusd lvmdiskscan lvmdump lvmlockctl lvmlockd lvmpolld lvmsadc lvmsar lvreduce lvremove lvrename lvresize lvs lvscan madwimax mcstransd mdadm mdmon measurefs.reiser4 mgetty mii-tool (8) - view, manipulate media-independent interface status mingetty mkdosfs (8) - create an MS-DOS FAT filesystem mke2fs (8) - create an ext2/ext3/ext4 file system mkfs (8) - build a Linux filesystem mkfs.bcachefs mkfs.bfs (8) - make an SCO bfs filesystem mkfs.btrfs mkfs.cramfs (8) - make compressed ROM file system mkfs.ext2 (8) - create an ext2/ext3/ext4 file system mkfs.ext3 (8) - create an ext2/ext3/ext4 file system mkfs.ext4 (8) - create an ext2/ext3/ext4 file system mkfs.f2fs mkfs.fat (8) - create an MS-DOS FAT filesystem mkfs.jfs mkfs.minix (8) - make a Minix filesystem mkfs.msdos (8) - create an MS-DOS FAT filesystem mkfs.nilfs2 mkfs.ntfs (8) - create an NTFS file system mkfs.ocfs2 mkfs.reiser4 mkfs.reiserfs mkfs.vfat (8) - create an MS-DOS FAT filesystem mkfs.xfs mkhomedir_helper (8) - Helper binary that creates home directories mkntfs (8) - create an NTFS file system mkreiser4 mkreiserfs mkswap (8) - set up a Linux swap area modinfo (8) - Show information about a Linux Kernel module modprobe (8) - Add and remove modules from the Linux Kernel mount.aptfs mount.bcachefs.sh mount.ceph mount.cifs mount.crypt mount.crypt_LUKS mount.crypto_LUKS mount.diod mount.ecryptfs mount.ecryptfs_private mount.exfat-fuse mount.fuse (8) - configuration and mount options for FUSE file systems mount.fuse-ext2 mount.fuse.ceph mount.fuse3 (8) - configuration and mount options for FUSE file systems mount.fuseext2 mount.glusterfs mount.lowntfs-3g (8) - Third Generation Read/Write NTFS Driver mount.mergerfs mount.moosefs mount.nfs mount.nfs4 mount.nilfs2 mount.ntfs (8) - Third Generation Read/Write NTFS Driver mount.ntfs-3g (8) - Third Generation Read/Write NTFS Driver mount.ocfs2 mount.ploop mount.posixovl mount.smb3 mounted.ocfs2 mpathpersist multipath multipathd nameif (8) - name network interfaces based on MAC addresses nbd-client netplugd netscript nfsdcltrack ngetty ngetty-argv ngetty-helper nilfs_cleanerd ntfsclone (8) - Efficiently clone, image, restore or rescue an NTFS ntfscp (8) - copy file to an NTFS volume. ntfslabel (8) - display/change the label on an ntfs file system ntfsresize (8) - resize an NTFS filesystem without data loss ntfsundelete (8) - recover a deleted file from an NTFS volume. o2cb o2cb_ctl o2cluster o2image ocfs2_hb_ctl octavia-agent-netns-start octavia-agent-netns-stop octavia-agent-ramfs-start octavia-agent-ramfs-stop olpc-switchd on_ac_power openrc (8) - stops and starts services for the specified runlevel openrc-init (8) - the parent of all processes openrc-run (8) - a means of hooking shell commands into a service openrc-shutdown (8) - bring the system down palo pam-tmpdir-helper pam_namespace_helper (8) - Helper binary that creates home directories parse.f2fs parted (8) - a partition manipulation program partprobe (8) - inform the OS of partition table changes paxctl pccardctl pivot_root (2) - change the root mount pivot_root (8) - change the root filesystem plipconfig (8) - fine tune PLIP device parameters pm-hibernate pm-suspend pm-suspend-hybrid powerd poweroff (8) - stop the system pvchange pvck pvcreate pvdisplay pvmove pvremove pvresize pvs pvscan pwhistory_helper (8) - Helper binary that transfers password hashes from passwd or shadow to opasswd quotacheck quotaoff quotaon rarp (8) - manipulate the system RARP table rc-service (8) - locate and run an OpenRC service with the given arguments rc-sstat (8) - show status info about services supervised by s6 then rc-status info rc-update (8) - add and remove services to and from a runlevel rdnssd rdump reboot (2) - reboot or enable/disable Ctrl-Alt-Del reboot (8) - stop the system reiserfsck reiserfstune request-key resize.f2fs resize2fs (8) - ext2/ext3/ext4 file system resizer resize_reiserfs resolvconf restore restorecon restorecon_xattr rmmod (8) - Simple program to remove a module from the Linux Kernel route (8) - show / manipulate the IP routing table rpc.statd rpcbind (3t) - library routines for RPC bind service rrestore rtacct (8) - network statistics tools. rtmon (8) - listens to and monitors RTnetlink rungetty runit runlevel (8) - find the previous and current system runlevel runuser (1) - run a command with substitute user and group ID scsi-spin scsidev scsiinfo setcap (8) - set file capabilities setfiles sfdisk (8) - display or manipulate a disk partition table sgdisk (8) - Command-line GUID partition table (GPT) manipulator for Linux and Unix shadowconfig shorewall shorewall-init shorewall-lite shorewall6 shorewall6-lite showmount shutdown (2) - shut down part of a full-duplex connection shutdown (8) - bring the system down slattach (8) - attach a network interface to a serial line sload.f2fs sm-notify start-stop-daemon (8) - start and stop system daemon programs stinit sulogin (8) - single-user login supervise-daemon (8) - starts a daemon and restarts it if it crashes swaplabel (8) - print or change the label or UUID of a swap area swapoff (2) - start/stop swapping to file/device swapoff (8) - enable/disable devices and files for paging and swapping swapon (2) - start/stop swapping to file/device swapon (8) - enable/disable devices and files for paging and swapping switch_root (8) - switch to another filesystem as the root of the mount tree sysctl (2) - read/write system parameters sysctl (8) - configure kernel parameters at runtime syslogd tc (8) - show / manipulate traffic control settings telinit (8) - process control initialization tipc (8) - a TIPC configuration and management tool tomoyo-init tune2fs (8) - adjust tunable file system parameters on ext2/ext3/ext4 file systems tunefs.ocfs2 tunefs.reiserfs udhcpc umount.crypt umount.crypt_LUKS umount.crypto_LUKS umount.ecryptfs umount.ecryptfs_private umount.nfs umount.nfs4 umount.nilfs2 umount.ploop umount.udisks2 (8) - unmount file systems that have been mounted by UDisks2 unix_chkpwd (8) - Helper binary that verifies the password of the current user unix_update (8) - Helper binary that updates the password of a given user update-service upsd upsdrvctl upsdrvsvcctl upsmon upssched uruk uruk-save urukctl vconfig vdpa (8) - vdpa management tool veritysetup vgcfgbackup vgcfgrestore vgchange vgck vgconvert vgcreate vgdisplay vgexport vgextend vgimport vgimportclone vgmerge vgmknodes vgreduce vgremove vgrename vgs vgscan vgsplit vmcore-dmesg wifichoice.sh wipefs (8) - wipe a signature from a device wondershaper wpa_action (8) - wpa_cli action script wpa_cli (8) - WPA command line client wpa_supplicant (8) - Wi-Fi Protected Access client and IEEE 802.1X supplicant writeboost xfs_repair xfsdump xfsrestore zdb zfs zfs-fuse zpool zramctl (8) - set up and control zram devices zstreamdump # /usr/bin/ - Sonstige programme 0alias 0desktop 0install 0launch 0store 0store-secure-add 0xFFFF 2csv 2d-slam-demo 2ff 2ft 2html 2ndscore 2ping 2ping6 2to3 2vcard 2xml 3BandEQ 3BandSplitter 3d-rotation-converter 3dsdump 3dtopos 411toppm 4Pane 4channels 4pane 4ti2-circuits 4ti2-genmodel 4ti2-gensymm 4ti2-graver 4ti2-groebner 4ti2-hilbert 4ti2-markov 4ti2-minimize 4ti2-normalform 4ti2-output 4ti2-ppi 4ti2-qsolve 4ti2-rays 4ti2-walk 4ti2-zbasis 4ti2-zsolve 5axisgui 5tt2gmwmi 5tt2vis 5ttcheck 5ttedit 5ttgen 64tass 6ft 6tunnel 7z (1) - A file archiver with high compression ratio format 7za (1) - A file archiver with high compression ratio format 7zr (1) - A file archiver with high compression ratio format 7zz 9bind 9menu 9mount 9umount 9wm AClock ASFileBrowser ASMount ASRun ASWallpaper ATR_analysis AccurateMassSearch AdapterRemoval AddressManager AdunCore AdunServer Affiche AlignRecords.py AlignSets.py AmplitudeImposer Animate AppCSXCAD Arrange AssayGeneratorMetabo AssemblePairs.py Assemblytics AssignGenes.py AtomicParsley AudMeS AusweisApp2 AutoSearch BAGEL BALLView BRP_PACU BaitFilter BaitFisher BambooTracker Bandage Banner Barcode_split BaselineFilter BasketLosses BermudanSwaption Bonds BuildConsensus.py BuildTrees.py Burrow C-Sibelia.py CAI CAT (1) - concatenate files and print on the standard output CDS CMEncrypt CTDConverter CVAIRS CVInspector Calculator CallableBonds Camera Canonicalise CartConvert Catrack Cenon Charmap (5) - character set description file Chess ChimeraSlayer ChromHMM ChromImpute ClonalFrame ClonalFrameML CloudCompare ClusterMassTraces ClusterMassTracesByPrecursor ClusterSets.py Cn3D-3.0 CollapseSeq.py CometAdapter CompNovo CompNovoCID ConicProj ConsensusID ConsensusMapNormalizer ConvertAmicasJPEG2000FilesetToDicom ConvertDb.py ConvertHeaders.py ConvertMapData ConvertibleBonds CreateDOMDocument CreateGermlines.py CruxAdapter CsoundQt-d-cs6 CubicSDR CuraEngine CurrencyConverter CuteSdr CycleShifter Cynthiune DAM2fasta DAScover DASedit DASmap DASpatch DASqv DASrealign DAStrim DB2arrow DB2fasta DB2quiva DBa2b DBb2a DBcp DBdump DBdust DBmv DBrm DBshow DBsplit DBstats DBtrim DBwipe DHT_bootstrap DOMCount DOMPrint DPMDyMFoam DPMFoam DRAWEXE DRAWxtl55 DSMIDIWiFi DTAExtractor DatabaseFilter DatabaseSuitability DeMeanderize Decharger DecoyDatabase DefineClones.py DicomCleaner DicomImageBlackout DicomImageViewer DicomSRValidator DictionaryReader DifOdometry-Camera DifOdometry-Datasets Digestor DigestorMotif DiscreteHedging DistanceEst DoseUtility DragonflyEarlyReflections DragonflyHallReverb DragonflyPlateReverb DragonflyRoomReverb DrawGram DrawTree Drop-seq_alignment.sh DtdToHaskell DyssolC DyssolGUI EDTSurf EICExtractor ERPairFinder ESingular ETL-config EdenMath EnumVal Epifany EquityOption Esetroot EstimateError.py Etbg Etbg_update_list Etcolors Eterm Etsearch Ettable ExecutePipeline ExplicateUTF8 ExternalCalibration FBReader FCluster FFEval FLOTTER FRA FTP FaCT++ FalseDiscoveryRate Fapropos Fast5_to_seq_summary FastTree FastaUnique FaustWorks Fdata Fdescr FeatureFinderCentroided FeatureFinderIdentification FeatureFinderIsotopeWavelet FeatureFinderMRM FeatureFinderMetabo FeatureFinderMetaboIdent FeatureFinderMultiplex FeatureFinderSuperHirn FeatureLinkerLabeled FeatureLinkerUnlabeled FeatureLinkerUnlabeledKD FeatureLinkerUnlabeledQT Fenv (3) - floating-point rounding and exception handling Fgo Fgrids Fhelp FidoAdapter FileCheck-13 FileCheck-14 FileCheck-15 FileConverter FileFilter FileInfo FileMerger FilterSeq.py Findex Finstall FittedBondCurve FontManager Fpalette Fpatch Fpattern Fprint_template Fpurge (3) - purge a stream FreeFem++ FreeFem++-mpi FreeFem++-nw Fsort FuzzyDiff Fvwm2Command Fvwm3Command GDSIIConvert GENtle GET (1p) - Simple command line user agent GNPSExport GNUMail GSMarkupBrowser GSMarkupLocalizableStrings GSSpeechRecognitionServer GSSpeechServer GSTest GTAMSAnalyzer GWAMA GWAS_boxcox GWAS_manhattanplots GWCommand GWorkspace Gaussian1dModels GenPat GenX_IR GenericWrapper GeoConvert GeodSolve GeodesicProj GeoidEval GlobalOptimizer GoldenCheetah Gomoku Gorm GrandOrgue GrandOrguePerfTest GrandOrgueTool GraphicsMagick++-config GraphicsMagick-config GraphicsMagickWand-config Gravity GridmapNavSimul Grr HDFCompass HEAD (1p) - Simple command line user agent head (1) - output the first part of files HMMEd HPC.daligner HPC.damapper HPXcvt HSAILasm HTMLLinker HYPHYMPI HandBrakeCLI HelpViewer HerculesStudio HighResPrecursorMassCorrector Honey Honey.py HsColour HtFileType IDConflictResolver IDDecoyProbability IDExtractor IDFileConverter IDFilter IDMapper IDMassAccuracy IDMerger IDPosteriorErrorProbability IDRTCalibration IDRipper IDScoreSwitcher IDSplitter INIFileEditor INIUpdater ITGDec ITGLog ITGManager ITGRecv ITGSend Ident ImageCreator ImageToDicom InclusionExclusionListCreator Ink InspectAdapter InternalCalibration IsobaricAnalyzer JFractionLab JSONStream Jamulus Jelly Jelly.py JxrDecApp (1) - JPEG XR Decoder Utility JxrEncApp (1) - JPEG XR Encoder Utility KBtin KWStyle Kars KlustaKwik LAa2b LAb2a LAcat LAcheck LAdump LAmerge LAshow LAsort LAsplit LabeledEval LatentModel LeakCheck LimeQuickTest LimeSuiteGUI LimeUtil LinkHut LogolExec LogolMultiExec LuciphorAdapter LuserNET Lynkeos M1 M2 M2-binary M2VRequantiser MDFinder MP4Box MP4Client MPDCon MPPICDyMFoam MPPICFoam MPPICInterFoam MQTTAsync_publish MQTTAsync_publish_time MQTTAsync_subscribe MQTTClient_publish MQTTClient_publish_async MQTTClient_subscribe MQTTVersion MRIConvert MRMMapper MRMPairFinder MRMTransitionGroupPicker MSFraggerAdapter MSGFPlusAdapter MSPCollect MSSimulator MSstatsConverter MVerb MX-calibrate MaBitcrush MaFreeverb MaGigaverb MaPitchshift MaRaClusterAdapter Magick++-config Magick-config MagneticField Mailsound MakeDb.py MakeNcl MapAlignerIdentification MapAlignerPoseClustering MapAlignerSpectrum MapAlignerTreeGuided MapNormalizer MapRTTransformer MapStatistics Mapper MarketModels MascotAdapter MascotAdapterOnline MaskPrimers.py MassCalculator MassTraceExtractor MediaImporter MemParse MeshDenoiser MeshSDFilter MetaProSIP MetaboliteAdductDecharger MetaboliteSpectralMatcher MicrobeGPS MinOZW MindTheGap MiniStocks MkOneOf MolDS.out MonitorWharf MulticurveBootstrapping MultidimIntegral MultiplexResolver MyriMatchAdapter MzMLSplitter MzTabExporter NAST-iEr NCLconverter NDist NEXUSnormalizer NEXUSvalidator NF NIfTI1ToDicom NPlam NPlam2 NPmpich2 NPopenmpi NPopenmpi2 NPpvm NPtcp NRRDToDicom NSBrowserTest NSImageTest NSPanelTest NSScreenTest NUT-Monitor NUT-Monitor-py3qt5 NanoFilt NanoLyse NanoSV NanoStat Nekobi NiViewer NiViewer2 NitrokeyAuthenticator NoiseFilterGaussian NoiseFilterSGolay NovorAdapter NucleicAcidSearchEngine OMSSAAdapter OSCAR OgreMeshUpgrader OgreXMLConverter Open3DConvertPointCloud Open3DGLInfo Open3DManuallyCropGeometry Open3DMergeMesh Open3DViewGeometry OpenBoard OpenMSInfo OpenMesh-Analyzer OpenMesh-DecimaterGui OpenMesh-Dualizer OpenMesh-ProgViewer OpenMesh-QtViewer OpenMesh-Smoothing OpenMesh-SubdividerGui OpenMesh-Synthesizer OpenMesh-commandlineAdaptiveSubdivider OpenMesh-commandlineDecimater OpenMesh-commandlineSubdivider OpenMesh-mconvert OpenMesh-mkbalancedpm OpenPepXL OpenPepXLLF OpenStereogram OpenSwathAnalyzer OpenSwathAssayGenerator OpenSwathChromatogramExtractor OpenSwathConfidenceScoring OpenSwathDIAPreScoring OpenSwathDecoyGenerator OpenSwathFeatureXMLToTSV OpenSwathFileSplitter OpenSwathMzMLFileCacher OpenSwathRTNormalizer OpenSwathRewriteToFeatureXML OpenSwathWorkflow OrthancRecoverCompressedFile OrthancWSIDicomToTiff OrthancWSIDicomizer PDFToDicomImage PDRFoam PDRMesh PDRblockMesh PDRsetFields POST (1p) - Simple command line user agent post (3form) - write or erase forms from associated subwindows post (3menu) - write or erase menus from associated subwindows POWplot PParse PRICE PSMFeatureExtractor PSVIWriter PTBatcherGUI PTModel PTPredict PTblender PTcrop PTinfo PTmasker PTmender PToptimizer PTroller PTtiff2psd PTtiffdump PTuncrop Pager (1) - opposite of more PairSeq.py Paje ParaFly ParseDb.py ParseHeaders.py ParseLog.py PeakPickerHiRes PeakPickerIterative PeakPickerWavelet PepNovoAdapter PeptideIndexer PerM PercolatorAdapter Perseus PerseusD PhosphoScoring PicardCommandLine PikoPixel PingPongPan PlanetarySystemStacker Planimeter PlopFolio Poe PosteRazor PrePARE PrecursorIonSelector PrecursorMassCorrector PreviSat Preview ProjectCenter Projucer ProteinInference ProteinQuantifier ProteinResolver ProteomicsLFQ Psequin Ptangle Pweave PyroDist PyroNoise PyroNoiseA PyroNoiseM PythonQwt PythonQwt-tests Q80_model_4_0_commandLine Q80_model_4_1_commandLine QCCalculator QCEmbedder QCExporter QCExtractor QCImporter QCMerger QCShrinker QFitsView QLogo QLogo-cli QLogo-tryway QSO QTLtools QuadraticSieve QualityControl R REPcover REPqv REPtrim RNADigestor RNAMassCalculator RNAcalibrate RNAeffective RNAhybrid RNPxlSearch RNPxlXICFilter ROPgadget RTEvaluation RTModel RTPredict R_mds RawLogViewer Ray ReactiveNav3D-Demo ReactiveNavigationDemo Recycler Redirect Replication Repo Resampler RhumbSolve Rscript RunRapMap.sh SAX2Count SAX2Print SAXCount SAXPrint SCMPrint SEnumVal SIBsim4 SNAPCommand SOAPsh SPASS SRFPimpleFoam SRFSimpleFoam STAR STARlong STKDemo SURVIVOR SWarp SalmID Sample-NiAudioSample Sample-NiBackRecorder Sample-NiCRead Sample-NiConvertXToONI Sample-NiHandTracker Sample-NiRecordSynthetic Sample-NiSimpleCreate Sample-NiSimpleRead Sample-NiSimpleSkeleton Sample-NiSimpleViewer Sample-NiUserSelection Sample-NiUserTracker Save SceneViewer SceneViewer3D SciTE SeedListGenerator SemanticValidator SeqDist SeqNoise SequenceCoverageCalculator Shape_PointInPoly Sibelia SimpleAgenda SimpleSearchEngine SimpleViewerExample Singular SiriusAdapter SoapySDRServer SoapySDRUtil SoulForce SpecLibCreator SpecLibSearcher SpectraFilterBernNorm SpectraFilterMarkerMower SpectraFilterNLargest SpectraFilterNormalizer SpectraFilterParentPeakMower SpectraFilterScaler SpectraFilterSqrtMower SpectraFilterThresholdMower SpectraFilterWindowMower SpectraMerger SpectraSTSearchAdapter SplitClusterClust SplitClusterEven SplitSeq.py StaticModification StdInParse StructuredReport SvmTheoreticalSpectrumGeneratorTrainer SvtAv1DecApp SvtAv1EncApp SwathWizard SweeD Swish SystemPreferences THESIAS TIATracker TICCalculator TIFFToDicom TMalign TMscore TOFCalibration TOPPAS TOPPView TSingular TalkSoup TargetedFileConverter Terminal TextEdit TextExporter Thunar (1) - File Manager for the Xfce Desktop Environment thunar (1) - File Manager for the Xfce Desktop Environment TimeMon TkAnt TransDecoder.LongOrfs TransDecoder.Predict TransformationEvaluation TransverseMercatorProj TrimmomaticPE TrimmomaticSE UEFIExtract UEFIFind UEFITool UL (1) - do underlining UnicodeNameMappingGenerator-15 UnifyHeaders.py UserFeedbackConsole VFDB_cdhit_to_csv VFDBgenus VFlib3-config VGAuthService VRMLConverter Validate VerificationSOPClassSCU ViewPDF VisualBoyAdvance VolumeControl WPEWebDriver WPrefs WRAPIT Wand-config WatchFolderAndSend WebKitWebDriver WebSearch Welcome2L Wharf WigeoN WinCommand WinList WinTabs WindowMaker WrapperFactory WriteLineFile WriteNameFile WritePlotcharData X (7) - a portable, network-transparent window system X0tigervnc X11 XFDR XInclude XML2Modelica XMLValidator XTandemAdapter Xalan Xdummy Xephyr (1) - X server outputting to a window on a pre-existing X display XiDyMFoam XiEngineFoam XiFoam Xnest Xorg (1) - X11R7 X server Xtigervnc Xtightvnc Xtract Xvfb Xwayland (1) - an X server for running X clients under Wayland. XyGrib YUView ZXingReader ZXingWriter ZaMaximX2 ZaMultiComp ZaMultiCompX2 ZamAutoSat ZamComp ZamCompX2 ZamDelay ZamDynamicEQ ZamEQ2 ZamGEQ31 ZamGate ZamGateX2 ZamGrains ZamHeadX2 ZamPhono ZamTube ZamVerb ZeGrapher Zipper ZydisDisasm ZydisInfo [ (1) - check file types and compare values _cvpcb.kiface _eeschema.kiface _gerbview.kiface _kipython.kiface _mocha _pcb_calculator.kiface _pcbnew.kiface _pl_editor.kiface _sahara-subprocess _toil_contained_executor _toil_worker a+ a10login a2crd a2j a2j_control a2jmidi_bridge a2jmidid a2ping a2ps a2ps-lpr-wrapper a2x a38tool a3m_database_extract a3m_database_filter a3m_database_reduce a3m_extract a3m_reduce a52dec a56 a56-keybld a56-tobin a56-toomf a5booklet a5toa4 a68g aa aa-easyprof aa-enabled (1) - test whether AppArmor is enabled aa-exec (1) - confine a program with the specified AppArmor profile aa-features-abi (1) - Extract, validate and manipulate AppArmor feature abis aa-notify aa3d aafigure aafire aaflip aagcloudwatcher_test_ng aaindexextract aainfo aalib-config aaphoto aapt aapt2 aarch64-linux-gnu-addr2line aarch64-linux-gnu-ar aarch64-linux-gnu-as aarch64-linux-gnu-c++filt aarch64-linux-gnu-cpp aarch64-linux-gnu-cpp-10 aarch64-linux-gnu-cpp-11 aarch64-linux-gnu-cpp-12 aarch64-linux-gnu-dwp aarch64-linux-gnu-elfedit aarch64-linux-gnu-g++ aarch64-linux-gnu-g++-10 aarch64-linux-gnu-g++-11 aarch64-linux-gnu-g++-12 aarch64-linux-gnu-gcc aarch64-linux-gnu-gcc-10 aarch64-linux-gnu-gcc-11 aarch64-linux-gnu-gcc-12 aarch64-linux-gnu-gcc-ar aarch64-linux-gnu-gcc-ar-10 aarch64-linux-gnu-gcc-ar-11 aarch64-linux-gnu-gcc-ar-12 aarch64-linux-gnu-gcc-nm aarch64-linux-gnu-gcc-nm-10 aarch64-linux-gnu-gcc-nm-11 aarch64-linux-gnu-gcc-nm-12 aarch64-linux-gnu-gcc-ranlib aarch64-linux-gnu-gcc-ranlib-10 aarch64-linux-gnu-gcc-ranlib-11 aarch64-linux-gnu-gcc-ranlib-12 aarch64-linux-gnu-gccgo aarch64-linux-gnu-gccgo-10 aarch64-linux-gnu-gccgo-11 aarch64-linux-gnu-gccgo-12 aarch64-linux-gnu-gcov aarch64-linux-gnu-gcov-10 aarch64-linux-gnu-gcov-11 aarch64-linux-gnu-gcov-12 aarch64-linux-gnu-gcov-dump aarch64-linux-gnu-gcov-dump-10 aarch64-linux-gnu-gcov-dump-11 aarch64-linux-gnu-gcov-dump-12 aarch64-linux-gnu-gcov-tool aarch64-linux-gnu-gcov-tool-10 aarch64-linux-gnu-gcov-tool-11 aarch64-linux-gnu-gcov-tool-12 aarch64-linux-gnu-gdc aarch64-linux-gnu-gdc-10 aarch64-linux-gnu-gdc-11 aarch64-linux-gnu-gdc-12 aarch64-linux-gnu-gfortran aarch64-linux-gnu-gfortran-10 aarch64-linux-gnu-gfortran-11 aarch64-linux-gnu-gfortran-12 aarch64-linux-gnu-gm2 aarch64-linux-gnu-gm2-10 aarch64-linux-gnu-gm2-11 aarch64-linux-gnu-gm2-12 aarch64-linux-gnu-gnat aarch64-linux-gnu-gnat-10 aarch64-linux-gnu-gnat-11 aarch64-linux-gnu-gnat-12 aarch64-linux-gnu-gnatbind aarch64-linux-gnu-gnatbind-10 aarch64-linux-gnu-gnatbind-11 aarch64-linux-gnu-gnatbind-12 aarch64-linux-gnu-gnatchop aarch64-linux-gnu-gnatchop-10 aarch64-linux-gnu-gnatchop-11 aarch64-linux-gnu-gnatchop-12 aarch64-linux-gnu-gnatclean aarch64-linux-gnu-gnatclean-10 aarch64-linux-gnu-gnatclean-11 aarch64-linux-gnu-gnatclean-12 aarch64-linux-gnu-gnatfind aarch64-linux-gnu-gnatfind-10 aarch64-linux-gnu-gnatfind-11 aarch64-linux-gnu-gnatgcc aarch64-linux-gnu-gnathtml aarch64-linux-gnu-gnathtml-10 aarch64-linux-gnu-gnathtml-11 aarch64-linux-gnu-gnathtml-12 aarch64-linux-gnu-gnatkr aarch64-linux-gnu-gnatkr-10 aarch64-linux-gnu-gnatkr-11 aarch64-linux-gnu-gnatkr-12 aarch64-linux-gnu-gnatlink aarch64-linux-gnu-gnatlink-10 aarch64-linux-gnu-gnatlink-11 aarch64-linux-gnu-gnatlink-12 aarch64-linux-gnu-gnatls aarch64-linux-gnu-gnatls-10 aarch64-linux-gnu-gnatls-11 aarch64-linux-gnu-gnatls-12 aarch64-linux-gnu-gnatmake aarch64-linux-gnu-gnatmake-10 aarch64-linux-gnu-gnatmake-11 aarch64-linux-gnu-gnatmake-12 aarch64-linux-gnu-gnatname aarch64-linux-gnu-gnatname-10 aarch64-linux-gnu-gnatname-11 aarch64-linux-gnu-gnatname-12 aarch64-linux-gnu-gnatprep aarch64-linux-gnu-gnatprep-10 aarch64-linux-gnu-gnatprep-11 aarch64-linux-gnu-gnatprep-12 aarch64-linux-gnu-gnatxref aarch64-linux-gnu-gnatxref-10 aarch64-linux-gnu-gnatxref-11 aarch64-linux-gnu-gprof aarch64-linux-gnu-ld aarch64-linux-gnu-ld.bfd aarch64-linux-gnu-ld.gold aarch64-linux-gnu-lto-dump-10 aarch64-linux-gnu-lto-dump-11 aarch64-linux-gnu-lto-dump-12 aarch64-linux-gnu-nm aarch64-linux-gnu-objcopy aarch64-linux-gnu-objdump aarch64-linux-gnu-ranlib aarch64-linux-gnu-readelf aarch64-linux-gnu-size aarch64-linux-gnu-strings aarch64-linux-gnu-strip aasavefont aasvg aatest aaxine ab abacas abc2abc abc2ly abc2midi abcde abcde-musicbrainz-tool abcl abcm2ps abcmatch abi-compliance-checker abi-dump abi-dumper abi-monitor abi-tracker abicheck abicompat abidiff abidw abilint abinit abipkgdiff abisip-find abitk abiview abiword abook abootimg abootimg-pack-initrd abootimg-unpack-initrd abr2gbr abw2epub abw2odt abx abyss-fixmate abyss-pe ac ac++ acat accerciser accn-at-a-time accountwizard accs acctdump accuraterip-checksum acdc acdcheck acdgalaxy acdlog acdpretty acdtable acdtrace acdvalid ace ace2sam ace_gperf ace_netsvcs acetoneiso acheck achilles ack acl2 aclgen aclients aclocal-1.11 aclocal-1.16 (1) - manual page for aclocal 1.16.5 acme acme-tiny aconnect (1) - ALSA sequencer connection manager aconnectgui acorn acorn2sfd acpi acpi_fakekey acpi_listen acpibin acpidump acpiexec acpihelp acpisrc acpitail acpitool acpixtract acpl acpl-int32 acpl-int64 acpl-long acr acr-cat acr-install acr-sh act actdiag3 actexec actiona activate-global-python-argcomplete activemq actool acyclic (1) - make directed graph acyclic ad ada_count adb add-apt-repository (1) - Adds a repository into the /etc/apt/sources.list or /etc/apt/sources.list.d or removes an existing one add-calamares-desktop-icon add-node-component add-patch add.modules addMessages addUnalignedIntervals add_metadata_tree.py add_tradis_tags add_vs_cmap addcr adddebug addftinfo addhost addld addpart (8) - tell the kernel about the existence of a partition addpix addr2line (1) - convert addresses or symbol+offset into file names and line numbers addr2name addr6 addressinfogenerator addresstool addrinfo addwords adequate adf2hdf adgnumailconverter adhocfilelist adiabaticFlameT adiff adios_config adios_lint.mpich adios_lint.openmpi adiosxml2h adjointOptimisationFoam adjointShapeOptimizationFoam admesh admsCheck admsXml adnmz adnsheloex adnshost adnslogres adnsresfilter adplay adplugdb adr adserver adsf adsh adtrace adtsummary_tap advdef advi advmng advpng advzip adwaita-1-demo aec aecat aedesc aegisub-3.2 aegrep aeinfo aelevels aemakeflic aeolus aerc aesfix aeskeyfind aeskulap aeson-pretty aespasswd aespipe aesubdump aevol_create aevol_misc_ancestor_robustness aevol_misc_ancestor_stats aevol_misc_create_eps aevol_misc_extract aevol_misc_lineage aevol_misc_mutagenesis aevol_misc_robustness aevol_misc_view aevol_modify aevol_propagate aevol_run aewan aewm++ aewm++_appbar aewm++_fspanel aewm++_setrootimage aewm++_xsession afdconnectivity afdko afetch afew affcat affcompare affconvert affcopy affcrypto affdiskprint affinfo affix affixcompress affrecover affsegment affsign affstats affuse affverify affxml afio afl-analyze afl-c++ afl-cc afl-clang afl-clang++ afl-clang-fast afl-clang-fast++ afl-cmin afl-cmin.bash afl-fuzz afl-g++ afl-g++-fast afl-gcc afl-gcc-fast afl-gotcpu afl-network-client afl-network-server afl-persistent-config afl-plot afl-showmap afl-system-config afl-tmin afl-whatsup aflr3_to_cgns afm2afm afm2pl afm2tfm afmtodit afpldaptest afppasswd afpstats afslog afssh aft aft-mtp-cli aft-mtp-mount afterimage-config afterimage-libs afterstep afterstepdoc afuse afuse-avahissh ag ag++ ag-backup ag-tool age age-keygen agedu agentxtrap aggregartp aggregate aggregate-avatars aggregate-ios aggregateBinDepths.pl aggregateContigOverlapsByBin.pl aggregate_profile aggregate_scores_in_intervals.py agh-profile-gen aghermann agmrancid agrep agusload aha aid aide aidl aidl-cpp aiksaurus aim aimk ainsl aiosmtpd aiozmq-proxy air-quality-sensor aircrack-ng airdecap-ng airdecloak-ng airgraph-ng airodump-join airolib-ng airport-config airport-hostmon airport-linkmon airport-modem airport2-config airport2-ipinspector airport2-portinspector airr-tools airscan-discover (1) - Discover sane-airscan compatible scanners airspy_gpio airspy_gpiodir airspy_info airspy_lib_version airspy_r820t airspy_rx airspy_si5351c airspy_spiflash airspyhf_calibrate airspyhf_gpio airspyhf_info airspyhf_lib_version airspyhf_rx aisdecode aj aj-snapshot aj5 ajbrowser ajc ajdoc akaidump akaiextract aklog-kafs akonadi2xml akonadi_agent_launcher akonadi_agent_server akonadi_akonotes_resource akonadi_archivemail_agent akonadi_birthdays_resource akonadi_contacts_resource akonadi_control akonadi_davgroupware_resource akonadi_ews_resource akonadi_ewsmta_resource akonadi_followupreminder_agent akonadi_google_resource akonadi_ical_resource akonadi_icaldir_resource akonadi_imap_resource akonadi_indexing_agent akonadi_knut_resource akonadi_kolab_resource akonadi_maildir_resource akonadi_maildispatcher_agent akonadi_mailfilter_agent akonadi_mailmerge_agent akonadi_mbox_resource akonadi_migration_agent akonadi_mixedmaildir_resource akonadi_newmailnotifier_agent akonadi_notes_agent akonadi_notes_resource akonadi_openxchange_resource akonadi_pop3_resource akonadi_rds akonadi_sendlater_agent akonadi_tomboynotes_resource akonadi_unifiedmailbox_agent akonadi_vcard_resource akonadi_vcarddir_resource akonadiconsole akonadictl akonadiimportwizard akonadiselftest akonadiserver akonaditest akregator akregatorstorageexporter al al2 alacarte aladin aldo ale ale-bin alembic aleph alertmanager-irc-relay alevt alevt-cap alevt-date alevtd alex alf alfa alfilldb algobox algotutor ali2consensus ali2gff alias_manager alice alien alien_hunter align-cache align-info align_dna align_image_stack align_print_template.py aligncopy aligncopypair alignment-cat alignment-chop-internal alignment-consensus alignment-distances alignment-draw alignment-find alignment-gild alignment-indices alignment-info alignment-max alignment-thin alignment-translate alignmentProjector alignmentSieve alignment_stator alignments-diff aliki aliki-rt alimask alistat all-knowing-dns all_dists allcm allec allegro-config alleleCounter alleleCounter.pl alleleCounterToJson.pl allneeded alltray allversusall almanah aln2bed aln2wig alogin alot alpha-linux-gnu-addr2line alpha-linux-gnu-ar alpha-linux-gnu-as alpha-linux-gnu-c++filt alpha-linux-gnu-cpp alpha-linux-gnu-cpp-10 alpha-linux-gnu-cpp-11 alpha-linux-gnu-cpp-12 alpha-linux-gnu-elfedit alpha-linux-gnu-g++ alpha-linux-gnu-g++-10 alpha-linux-gnu-g++-11 alpha-linux-gnu-g++-12 alpha-linux-gnu-gcc alpha-linux-gnu-gcc-10 alpha-linux-gnu-gcc-11 alpha-linux-gnu-gcc-12 alpha-linux-gnu-gcc-ar alpha-linux-gnu-gcc-ar-10 alpha-linux-gnu-gcc-ar-11 alpha-linux-gnu-gcc-ar-12 alpha-linux-gnu-gcc-nm alpha-linux-gnu-gcc-nm-10 alpha-linux-gnu-gcc-nm-11 alpha-linux-gnu-gcc-nm-12 alpha-linux-gnu-gcc-ranlib alpha-linux-gnu-gcc-ranlib-10 alpha-linux-gnu-gcc-ranlib-11 alpha-linux-gnu-gcc-ranlib-12 alpha-linux-gnu-gccgo alpha-linux-gnu-gccgo-10 alpha-linux-gnu-gccgo-11 alpha-linux-gnu-gccgo-12 alpha-linux-gnu-gcov alpha-linux-gnu-gcov-10 alpha-linux-gnu-gcov-11 alpha-linux-gnu-gcov-12 alpha-linux-gnu-gcov-dump alpha-linux-gnu-gcov-dump-10 alpha-linux-gnu-gcov-dump-11 alpha-linux-gnu-gcov-dump-12 alpha-linux-gnu-gcov-tool alpha-linux-gnu-gcov-tool-10 alpha-linux-gnu-gcov-tool-11 alpha-linux-gnu-gcov-tool-12 alpha-linux-gnu-gdc-10 alpha-linux-gnu-gdc-11 alpha-linux-gnu-gfortran alpha-linux-gnu-gfortran-10 alpha-linux-gnu-gfortran-11 alpha-linux-gnu-gfortran-12 alpha-linux-gnu-gm2 alpha-linux-gnu-gm2-10 alpha-linux-gnu-gm2-11 alpha-linux-gnu-gm2-12 alpha-linux-gnu-gnat alpha-linux-gnu-gnat-10 alpha-linux-gnu-gnat-11 alpha-linux-gnu-gnat-12 alpha-linux-gnu-gnatbind alpha-linux-gnu-gnatbind-10 alpha-linux-gnu-gnatbind-11 alpha-linux-gnu-gnatbind-12 alpha-linux-gnu-gnatchop alpha-linux-gnu-gnatchop-10 alpha-linux-gnu-gnatchop-11 alpha-linux-gnu-gnatchop-12 alpha-linux-gnu-gnatclean alpha-linux-gnu-gnatclean-10 alpha-linux-gnu-gnatclean-11 alpha-linux-gnu-gnatclean-12 alpha-linux-gnu-gnatfind alpha-linux-gnu-gnatfind-10 alpha-linux-gnu-gnatfind-11 alpha-linux-gnu-gnatgcc alpha-linux-gnu-gnathtml alpha-linux-gnu-gnathtml-10 alpha-linux-gnu-gnathtml-11 alpha-linux-gnu-gnathtml-12 alpha-linux-gnu-gnatkr alpha-linux-gnu-gnatkr-10 alpha-linux-gnu-gnatkr-11 alpha-linux-gnu-gnatkr-12 alpha-linux-gnu-gnatlink alpha-linux-gnu-gnatlink-10 alpha-linux-gnu-gnatlink-11 alpha-linux-gnu-gnatlink-12 alpha-linux-gnu-gnatls alpha-linux-gnu-gnatls-10 alpha-linux-gnu-gnatls-11 alpha-linux-gnu-gnatls-12 alpha-linux-gnu-gnatmake alpha-linux-gnu-gnatmake-10 alpha-linux-gnu-gnatmake-11 alpha-linux-gnu-gnatmake-12 alpha-linux-gnu-gnatname alpha-linux-gnu-gnatname-10 alpha-linux-gnu-gnatname-11 alpha-linux-gnu-gnatname-12 alpha-linux-gnu-gnatprep alpha-linux-gnu-gnatprep-10 alpha-linux-gnu-gnatprep-11 alpha-linux-gnu-gnatprep-12 alpha-linux-gnu-gnatxref alpha-linux-gnu-gnatxref-10 alpha-linux-gnu-gnatxref-11 alpha-linux-gnu-gprof alpha-linux-gnu-ld alpha-linux-gnu-ld.bfd alpha-linux-gnu-lto-dump-10 alpha-linux-gnu-lto-dump-11 alpha-linux-gnu-lto-dump-12 alpha-linux-gnu-nm alpha-linux-gnu-objcopy alpha-linux-gnu-objdump alpha-linux-gnu-ranlib alpha-linux-gnu-readelf alpha-linux-gnu-size alpha-linux-gnu-strings alpha-linux-gnu-strip alpha2f.x alpine alpinef als alsa_delay alsa_in alsa_loopback alsa_out alsabat (1) - command-line sound tester for ALSA sound card driver alsaloop (1) - command-line PCM loopback alsamixer (1) - soundcard mixer for ALSA soundcard driver, with ncurses interface alsamixergui alsaplayer alsatplg (1) - ALSA Topology Compiler alsaucm (1) - ALSA Use Case Manager alsearch alt-ergo alt_getopt alt_getopt.sh altair altairz80 alter-sequence-alignment altermime altos-map altos-mapd altos-mapj altosui altree altree-add-S altree-convert alttab alurecdplay alureplay alurestream am7xxx-modeswitch am7xxx-play amap ambdec ambdec_cli amberc ambiguous_words ambix-deinterleave ambix-info ambix-interleave ambix-jplay ambix-jrecord amd_hdmi_compliance amdgpu_stress ament_clang_format ament_clang_tidy ament_copyright ament_cppcheck ament_cpplint ament_flake8 ament_index ament_lint_cmake ament_mypy ament_pep257 ament_pycodestyle ament_pyflakes ament_uncrustify ament_xmllint amf-to-stl amfora amide amideco amidi (1) - read from and write to ALSA RawMIDI ports aminer aminer-persistence aminerremotecontrol amino-acid-composition amispammer amixer (1) - command-line mixer for ALSA soundcard driver amk_ccc amk_ccc-int32 amk_ccc-int64 amk_ccc-long amk_fft2 amk_fft2-int32 amk_fft2-int64 amk_fft2-long amk_grf amk_grf-int32 amk_grf-int64 amk_grf-long amk_hy amk_hy-int32 amk_hy-int64 amk_hy-long amk_m2 amk_m2-int32 amk_m2-int64 amk_m2-long amk_p2 amk_p2-int32 amk_p2-int64 amk_p2-long amo-changelog amp-compress amp-plotconvergence amp2response amp2sh ampID ampboot ampctl ampctld amphora-agent amphora-health-checker amphora-interface amphost ample amplist amprate amprule ampstat amptest amptone amptool ampwait amqp-consume amqp-declare-queue amqp-delete-queue amqp-get amqp-publish amr ams amstex amsynth amtool amtterm amttool amuFormat.sh amule-emc an-fitstopnm an-pnmtofits anaddb anal_gloc.pl analizo analog analyse-build-log analyse-sbuild-log analyseplugin analyze-build-13 analyze-build-14 analyze-build-15 analyze-dmk anchors ancient andi androapkid androarsc androaxml androcg androdd androdis androguard androgui android-file-transfer androidmk androlyze androsign angelfish angelfish-webapp animate animate-im6.q16 animate-im6.q16hdri anjuta anjuta-launcher anjuta-tags anlogin ann2fig ann_sample ann_test annex-review-unused annex-to-annex annex-to-annex-dropunused annex-to-annex-reinject annlib.python annlib.show_build_path annlib.show_dist_paths annotate annotate-output annotateBed annotate_outputs.py annotationViewer anomaly anonip anorack ansi2html ansi2txt ansible ansible-community ansible-config ansible-connection ansible-console ansible-doc ansible-galaxy ansible-inventory ansible-lint ansible-playbook ansible-pull ansible-runner ansible-test ansible-vault ansifilter ansifilter-gui ansilove ansiweather ansysToFoam ant (1) - a Java based make tool. antennavis anthy-agent anthy-dic-tool antigenic antimicrox antimony antiword antlr antlr-config antlr3 antlr4 antpm-downloader antpm-fit2gpx antpm-garmin-ant-downloader antpm-usbmon2ant anu-nq any2djvu anymarkup anymeal anypaper anyremote anytooff anytopnm anytoucd anytun-config anytun-controld anytun-showtables ao-bitbang ao-cal-accel ao-cal-freq ao-dbg ao-dump-up ao-dumpflash ao-edit-telem ao-eeprom ao-ejection ao-elftohex ao-flash-lpc ao-flash-stm ao-flash-stm32f0x ao-list ao-load ao-makebin ao-rawload ao-reset-lpc ao-send-telem ao-sky-flash ao-telem ao-test-baro ao-test-flash ao-test-gps ao-test-igniter ao-usbload ao-usbtrng aobook aodh aodh-api aodh-config-generator aodh-dbsync aodh-evaluator aodh-expirer aodh-listener aodh-notifier aodh-status aoeui aoflagger aomdec aomenc aoqplot aoquality aosd_cat aoss ap-auth ap-config ap-gl ap-mrtg ap-rrd ap-tftp apack apbs apertium apertium-adapt-docx apertium-anaphora apertium-apy apertium-cleanstream apertium-deshtml apertium-deshtml-alt apertium-deshtml-noent apertium-deslatex apertium-desmediawiki apertium-desodt apertium-despptx apertium-desrtf apertium-destxt apertium-deswxml apertium-desxlsx apertium-desxpresstag apertium-editdist apertium-eval-translator apertium-filter-ambiguity apertium-filter-dix apertium-filter-rules apertium-filter-xml apertium-gen-deformat apertium-gen-modes apertium-gen-reformat apertium-genvdix apertium-genvldix apertium-genvrdix apertium-get apertium-interchunk apertium-metalrx apertium-metalrx-to-lrx apertium-multiple-translations apertium-perceptron-trace apertium-postchunk apertium-postlatex apertium-postlatex-raw apertium-posttransfer apertium-prelatex apertium-preprocess-transfer apertium-pretransfer apertium-regtest apertium-rehtml apertium-rehtml-alt apertium-rehtml-noent apertium-relatex apertium-remediawiki apertium-reodt apertium-repptx apertium-rertf apertium-retxt apertium-rewxml apertium-rexlsx apertium-rexpresstag apertium-streamparser apertium-tagger apertium-tagger-apply-new-rules apertium-tagger-readwords apertium-tmxbuild apertium-transfer apertium-translate-to-default-equivalent apertium-unformat apertium-utils-fixlatex apertium-validate-acx apertium-validate-anaphora apertium-validate-dictionary apertium-validate-interchunk apertium-validate-lrx apertium-validate-modes apertium-validate-postchunk apertium-validate-tagger apertium-validate-transfer apertium-validate-trx apertium-wblank-attach apertium-wblank-detach apertium-wblank-mode apg (1) - generates several random passwords apgbfm (1) - APG Bloom filter management program apgdiff api-sanity-checker apitrace apkinfo apksigcopier apksigner apktool apkverifier aplay (1) - command-line sound recorder and player for ALSA soundcard driver aplaymidi (1) - play Standard MIDI Files apng2gif apngasm apngdis apngopt apol apop_db_to_crosstab apop_plot_query apop_text_to_db apparix append2simg append_sff appendpdf apper apple_dump apply-multiarch-hints applyBoundaryLayer apply_diff_relay_logs applycal applydeltaiso applydeltarpm applygeo applypatch applyplugin appres (1) - list X application resource database apprise appserver appstream-compose appstream-util appstreamcli apr-1-config apr-config apriboot apriltag aprofutil apropos (1) - search the manual page names and descriptions apt (8) - command-line interface apt-add-repository (1) - Adds a repository into the /etc/apt/sources.list or /etc/apt/sources.list.d or removes an existing one apt-build apt-cache (8) - query the APT cache apt-cdrom (8) - APT CD-ROM management utility apt-config (8) - APT Configuration Query program apt-cudf apt-cudf-get apt-dater apt-dater-host apt-extracttemplates (1) - Utility to extract debconf config and templates from Debian packages apt-file (1) - - APT package searching utility -- command-line interface apt-forktracer apt-ftparchive (1) - Utility to generate index files apt-get (8) - APT package handling utility -- command-line interface apt-get-build-depends apt-key (8) - Deprecated APT key management utility apt-listbugs apt-listchanges apt-mark (8) - show, set and unset various settings for a package apt-mirror apt-move apt-offline apt-offline-gui apt-offline-gui-pkexec apt-rdepends apt-show-source apt-show-versions apt-sortpkgs (1) - Utility to sort package index files apt-src apt-venv aptitude-changelog-parser aptitude-create-state-bundle aptitude-curses aptitude-run-state-bundle aptly aptly-publisher apu-1-config apu-config apulse apvlv apwal apxs apxs2 aqbanking-cli aqebics-tool aqemu aqhbci-tool4 aqpaypal-tool ar (1) - create, modify, and extract from archives ar65 ar86 arachne-pnr aragorn arancid arandr aranym aranym-jit aranym-mmu arara aratapif arborist arc arc-job-cgroup arc-linux-gnu-addr2line arc-linux-gnu-ar arc-linux-gnu-as arc-linux-gnu-c++filt arc-linux-gnu-cpp arc-linux-gnu-cpp-11 arc-linux-gnu-cpp-12 arc-linux-gnu-elfedit arc-linux-gnu-g++ arc-linux-gnu-g++-11 arc-linux-gnu-g++-12 arc-linux-gnu-gcc arc-linux-gnu-gcc-11 arc-linux-gnu-gcc-12 arc-linux-gnu-gcc-ar arc-linux-gnu-gcc-ar-11 arc-linux-gnu-gcc-ar-12 arc-linux-gnu-gcc-nm arc-linux-gnu-gcc-nm-11 arc-linux-gnu-gcc-nm-12 arc-linux-gnu-gcc-ranlib arc-linux-gnu-gcc-ranlib-11 arc-linux-gnu-gcc-ranlib-12 arc-linux-gnu-gcov arc-linux-gnu-gcov-11 arc-linux-gnu-gcov-12 arc-linux-gnu-gcov-dump arc-linux-gnu-gcov-dump-11 arc-linux-gnu-gcov-dump-12 arc-linux-gnu-gcov-tool arc-linux-gnu-gcov-tool-11 arc-linux-gnu-gcov-tool-12 arc-linux-gnu-gfortran arc-linux-gnu-gfortran-11 arc-linux-gnu-gfortran-12 arc-linux-gnu-gm2 arc-linux-gnu-gm2-11 arc-linux-gnu-gm2-12 arc-linux-gnu-gprof arc-linux-gnu-ld arc-linux-gnu-ld.bfd arc-linux-gnu-lto-dump-11 arc-linux-gnu-lto-dump-12 arc-linux-gnu-nm arc-linux-gnu-objcopy arc-linux-gnu-objdump arc-linux-gnu-ranlib arc-linux-gnu-readelf arc-linux-gnu-size arc-linux-gnu-strings arc-linux-gnu-strip arcanist arccat arccert-ui arcclean arccp arcemiestest arcget arch (1) - print machine hardware name (same as uname -m) arch-chroot arch-test (1) - detect architectures your kernel can run binaries of archfs archive-pubmed archive_agent archive_cleaner archive_server archivemount archlinux-keyring-wkd-sync archmage archmbox archpath archpkgs2solv archrepo2solv arcinfo arckill arcls arcmkdir arcperftest arcplugin arcproxy arcproxy-ui arcrename arcrenew arcresub arcresume arcrm arcsign arcstat arcstat-ui arcstorage-ui arcsub arcsub-ui arcsync arctest arcverify ard-reset-arduino arden-analyze arden-create arden-filter ardour ardour7-copy-mixer ardour7-export ardour7-lua ardour7-new_empty_session ardour7-new_session arduino arduino-add-groups arduino-builder arduino-ctags aread arecord (1) - command-line sound recorder and player for ALSA soundcard driver arecordmidi (1) - record Standard MIDI Files arename arepack ares argon2 argon2-calibrate argparse-manpage args argv0 aria2c aria_chk (1) - Aria table-maintenance utility aria_dump_log (1) - Dump content of Aria log pages. aria_ftdump (1) - display full-text index information aria_pack (1) - generate compressed, read-only Aria tables aria_read_log (1) - display Aria log file contents aria_s3_copy ario arj (1) - Archiver for .arj files arj-register (1) - Register the ARJ archiver arjdisp (1) - ARJ simple graphical interface ark arlatex arm-linux-gnueabi-addr2line arm-linux-gnueabi-ar arm-linux-gnueabi-as arm-linux-gnueabi-c++filt arm-linux-gnueabi-cpp arm-linux-gnueabi-cpp-10 arm-linux-gnueabi-cpp-11 arm-linux-gnueabi-cpp-12 arm-linux-gnueabi-dwp arm-linux-gnueabi-elfedit arm-linux-gnueabi-g++ arm-linux-gnueabi-g++-10 arm-linux-gnueabi-g++-11 arm-linux-gnueabi-g++-12 arm-linux-gnueabi-gcc arm-linux-gnueabi-gcc-10 arm-linux-gnueabi-gcc-11 arm-linux-gnueabi-gcc-12 arm-linux-gnueabi-gcc-ar arm-linux-gnueabi-gcc-ar-10 arm-linux-gnueabi-gcc-ar-11 arm-linux-gnueabi-gcc-ar-12 arm-linux-gnueabi-gcc-nm arm-linux-gnueabi-gcc-nm-10 arm-linux-gnueabi-gcc-nm-11 arm-linux-gnueabi-gcc-nm-12 arm-linux-gnueabi-gcc-ranlib arm-linux-gnueabi-gcc-ranlib-10 arm-linux-gnueabi-gcc-ranlib-11 arm-linux-gnueabi-gcc-ranlib-12 arm-linux-gnueabi-gccgo arm-linux-gnueabi-gccgo-10 arm-linux-gnueabi-gccgo-11 arm-linux-gnueabi-gccgo-12 arm-linux-gnueabi-gcov arm-linux-gnueabi-gcov-10 arm-linux-gnueabi-gcov-11 arm-linux-gnueabi-gcov-12 arm-linux-gnueabi-gcov-dump arm-linux-gnueabi-gcov-dump-10 arm-linux-gnueabi-gcov-dump-11 arm-linux-gnueabi-gcov-dump-12 arm-linux-gnueabi-gcov-tool arm-linux-gnueabi-gcov-tool-10 arm-linux-gnueabi-gcov-tool-11 arm-linux-gnueabi-gcov-tool-12 arm-linux-gnueabi-gdc arm-linux-gnueabi-gdc-10 arm-linux-gnueabi-gdc-11 arm-linux-gnueabi-gdc-12 arm-linux-gnueabi-gfortran arm-linux-gnueabi-gfortran-10 arm-linux-gnueabi-gfortran-11 arm-linux-gnueabi-gfortran-12 arm-linux-gnueabi-gm2 arm-linux-gnueabi-gm2-10 arm-linux-gnueabi-gm2-11 arm-linux-gnueabi-gm2-12 arm-linux-gnueabi-gnat arm-linux-gnueabi-gnat-10 arm-linux-gnueabi-gnat-11 arm-linux-gnueabi-gnat-12 arm-linux-gnueabi-gnatbind arm-linux-gnueabi-gnatbind-10 arm-linux-gnueabi-gnatbind-11 arm-linux-gnueabi-gnatbind-12 arm-linux-gnueabi-gnatchop arm-linux-gnueabi-gnatchop-10 arm-linux-gnueabi-gnatchop-11 arm-linux-gnueabi-gnatchop-12 arm-linux-gnueabi-gnatclean arm-linux-gnueabi-gnatclean-10 arm-linux-gnueabi-gnatclean-11 arm-linux-gnueabi-gnatclean-12 arm-linux-gnueabi-gnatfind arm-linux-gnueabi-gnatfind-10 arm-linux-gnueabi-gnatfind-11 arm-linux-gnueabi-gnatgcc arm-linux-gnueabi-gnathtml arm-linux-gnueabi-gnathtml-10 arm-linux-gnueabi-gnathtml-11 arm-linux-gnueabi-gnathtml-12 arm-linux-gnueabi-gnatkr arm-linux-gnueabi-gnatkr-10 arm-linux-gnueabi-gnatkr-11 arm-linux-gnueabi-gnatkr-12 arm-linux-gnueabi-gnatlink arm-linux-gnueabi-gnatlink-10 arm-linux-gnueabi-gnatlink-11 arm-linux-gnueabi-gnatlink-12 arm-linux-gnueabi-gnatls arm-linux-gnueabi-gnatls-10 arm-linux-gnueabi-gnatls-11 arm-linux-gnueabi-gnatls-12 arm-linux-gnueabi-gnatmake arm-linux-gnueabi-gnatmake-10 arm-linux-gnueabi-gnatmake-11 arm-linux-gnueabi-gnatmake-12 arm-linux-gnueabi-gnatname arm-linux-gnueabi-gnatname-10 arm-linux-gnueabi-gnatname-11 arm-linux-gnueabi-gnatname-12 arm-linux-gnueabi-gnatprep arm-linux-gnueabi-gnatprep-10 arm-linux-gnueabi-gnatprep-11 arm-linux-gnueabi-gnatprep-12 arm-linux-gnueabi-gnatxref arm-linux-gnueabi-gnatxref-10 arm-linux-gnueabi-gnatxref-11 arm-linux-gnueabi-gprof arm-linux-gnueabi-ld arm-linux-gnueabi-ld.bfd arm-linux-gnueabi-ld.gold arm-linux-gnueabi-lto-dump-10 arm-linux-gnueabi-lto-dump-11 arm-linux-gnueabi-lto-dump-12 arm-linux-gnueabi-nm arm-linux-gnueabi-objcopy arm-linux-gnueabi-objdump arm-linux-gnueabi-ranlib arm-linux-gnueabi-readelf arm-linux-gnueabi-size arm-linux-gnueabi-strings arm-linux-gnueabi-strip arm-linux-gnueabihf-addr2line arm-linux-gnueabihf-ar arm-linux-gnueabihf-as arm-linux-gnueabihf-c++filt arm-linux-gnueabihf-cpp arm-linux-gnueabihf-cpp-10 arm-linux-gnueabihf-cpp-11 arm-linux-gnueabihf-cpp-12 arm-linux-gnueabihf-dwp arm-linux-gnueabihf-elfedit arm-linux-gnueabihf-g++ arm-linux-gnueabihf-g++-10 arm-linux-gnueabihf-g++-11 arm-linux-gnueabihf-g++-12 arm-linux-gnueabihf-gcc arm-linux-gnueabihf-gcc-10 arm-linux-gnueabihf-gcc-11 arm-linux-gnueabihf-gcc-12 arm-linux-gnueabihf-gcc-ar arm-linux-gnueabihf-gcc-ar-10 arm-linux-gnueabihf-gcc-ar-11 arm-linux-gnueabihf-gcc-ar-12 arm-linux-gnueabihf-gcc-nm arm-linux-gnueabihf-gcc-nm-10 arm-linux-gnueabihf-gcc-nm-11 arm-linux-gnueabihf-gcc-nm-12 arm-linux-gnueabihf-gcc-ranlib arm-linux-gnueabihf-gcc-ranlib-10 arm-linux-gnueabihf-gcc-ranlib-11 arm-linux-gnueabihf-gcc-ranlib-12 arm-linux-gnueabihf-gccgo arm-linux-gnueabihf-gccgo-10 arm-linux-gnueabihf-gccgo-11 arm-linux-gnueabihf-gccgo-12 arm-linux-gnueabihf-gcov arm-linux-gnueabihf-gcov-10 arm-linux-gnueabihf-gcov-11 arm-linux-gnueabihf-gcov-12 arm-linux-gnueabihf-gcov-dump arm-linux-gnueabihf-gcov-dump-10 arm-linux-gnueabihf-gcov-dump-11 arm-linux-gnueabihf-gcov-dump-12 arm-linux-gnueabihf-gcov-tool arm-linux-gnueabihf-gcov-tool-10 arm-linux-gnueabihf-gcov-tool-11 arm-linux-gnueabihf-gcov-tool-12 arm-linux-gnueabihf-gdc arm-linux-gnueabihf-gdc-10 arm-linux-gnueabihf-gdc-11 arm-linux-gnueabihf-gdc-12 arm-linux-gnueabihf-gfortran arm-linux-gnueabihf-gfortran-10 arm-linux-gnueabihf-gfortran-11 arm-linux-gnueabihf-gfortran-12 arm-linux-gnueabihf-gm2 arm-linux-gnueabihf-gm2-10 arm-linux-gnueabihf-gm2-11 arm-linux-gnueabihf-gm2-12 arm-linux-gnueabihf-gnat arm-linux-gnueabihf-gnat-10 arm-linux-gnueabihf-gnat-11 arm-linux-gnueabihf-gnat-12 arm-linux-gnueabihf-gnatbind arm-linux-gnueabihf-gnatbind-10 arm-linux-gnueabihf-gnatbind-11 arm-linux-gnueabihf-gnatbind-12 arm-linux-gnueabihf-gnatchop arm-linux-gnueabihf-gnatchop-10 arm-linux-gnueabihf-gnatchop-11 arm-linux-gnueabihf-gnatchop-12 arm-linux-gnueabihf-gnatclean arm-linux-gnueabihf-gnatclean-10 arm-linux-gnueabihf-gnatclean-11 arm-linux-gnueabihf-gnatclean-12 arm-linux-gnueabihf-gnatfind arm-linux-gnueabihf-gnatfind-10 arm-linux-gnueabihf-gnatfind-11 arm-linux-gnueabihf-gnatgcc arm-linux-gnueabihf-gnathtml arm-linux-gnueabihf-gnathtml-10 arm-linux-gnueabihf-gnathtml-11 arm-linux-gnueabihf-gnathtml-12 arm-linux-gnueabihf-gnatkr arm-linux-gnueabihf-gnatkr-10 arm-linux-gnueabihf-gnatkr-11 arm-linux-gnueabihf-gnatkr-12 arm-linux-gnueabihf-gnatlink arm-linux-gnueabihf-gnatlink-10 arm-linux-gnueabihf-gnatlink-11 arm-linux-gnueabihf-gnatlink-12 arm-linux-gnueabihf-gnatls arm-linux-gnueabihf-gnatls-10 arm-linux-gnueabihf-gnatls-11 arm-linux-gnueabihf-gnatls-12 arm-linux-gnueabihf-gnatmake arm-linux-gnueabihf-gnatmake-10 arm-linux-gnueabihf-gnatmake-11 arm-linux-gnueabihf-gnatmake-12 arm-linux-gnueabihf-gnatname arm-linux-gnueabihf-gnatname-10 arm-linux-gnueabihf-gnatname-11 arm-linux-gnueabihf-gnatname-12 arm-linux-gnueabihf-gnatprep arm-linux-gnueabihf-gnatprep-10 arm-linux-gnueabihf-gnatprep-11 arm-linux-gnueabihf-gnatprep-12 arm-linux-gnueabihf-gnatxref arm-linux-gnueabihf-gnatxref-10 arm-linux-gnueabihf-gnatxref-11 arm-linux-gnueabihf-gprof arm-linux-gnueabihf-ld arm-linux-gnueabihf-ld.bfd arm-linux-gnueabihf-ld.gold arm-linux-gnueabihf-lto-dump-10 arm-linux-gnueabihf-lto-dump-11 arm-linux-gnueabihf-lto-dump-12 arm-linux-gnueabihf-nm arm-linux-gnueabihf-objcopy arm-linux-gnueabihf-objdump arm-linux-gnueabihf-ranlib arm-linux-gnueabihf-readelf arm-linux-gnueabihf-size arm-linux-gnueabihf-strings arm-linux-gnueabihf-strip arm-none-eabi-addr2line arm-none-eabi-ar arm-none-eabi-as arm-none-eabi-c++ arm-none-eabi-c++filt arm-none-eabi-cpp arm-none-eabi-elfedit arm-none-eabi-g++ arm-none-eabi-gcc arm-none-eabi-gcc-11.3.1 arm-none-eabi-gcc-ar arm-none-eabi-gcc-nm arm-none-eabi-gcc-ranlib arm-none-eabi-gcov arm-none-eabi-gcov-dump arm-none-eabi-gcov-tool arm-none-eabi-gprof arm-none-eabi-ld arm-none-eabi-ld.bfd arm-none-eabi-lto-dump arm-none-eabi-nm arm-none-eabi-objcopy arm-none-eabi-objdump arm-none-eabi-ranlib arm-none-eabi-readelf arm-none-eabi-size arm-none-eabi-strings arm-none-eabi-strip arm2hpdl arno-fwfilter arpaname arping arqiver arraylist arriero arrow2DB art art_454 art_SOLiD art_illumina art_profiler_454 art_profiler_illumina artfastqgenerator artha artikulate artikulate_editor aruba arv-tool-0.8 arv-viewer-0.8 as (1) - the portable GNU assembler. as10k1 as2gbmap as31 as86 asan_symbolize asan_symbolize-13 asan_symbolize-14 asan_symbolize-15 asapcat asc2log asc2xml ascd ascdc ascii (7) - ASCII character set encoded in octal, decimal, and hexadecimal ascii-xfr ascii2binary ascii2uni ascii85 asciiart asciidoc asciidoctor asciidoctor-pdf asciidoctor-pdf-optimize asciinema asciitopgm asciiview ascjs asclock ascolor ascommand ascompose asdfg asdftool ase asebachallenge asebacmd asebadummynode asebadump asebaeventlogger asebaexec asebahttp asebahttp2 asebajoy asebamassloader asebamedulla asebaplay asebaplayground asebarec asebastudio asebaswitch aseqdump (1) - show the events received at an ALSA sequencer port aseqjoy aseqnet (1) - ALSA sequencer connectors over network asfxload asg-hevc asip-status.pl askmara askmara-tcp asl-hardware asm_count asmail asmdecl asmix asmixer asmon asmping asn1Coding asn1Decoding asn1Parser asn1_compile asn1_compiler asn1_print asn1c asn2all asn2asn asn2deb (1) - Create a Debian package for BER monitoring from ASN.1 asn2ff asn2fsa asn2gb asn2idx asn2xml asndhuff asndisc asnmacro asntool asnval asp-perl asp-state asp-state4 aspcud aspell (1) - interactive spell checker aspell-import (1) - import old personal dictionaries into GNU Aspell aspic aspline asql assa-genesis-3.5 assa-hexdump-3.5 assembly-stats assemblyget assimp assistant assword astap astap_cli astarithmetic astbuildprog astcenc astconvertt astconvolve astcosmiccal astcrop asterisk-config-custom astfits astmatch astmkcatalog astmknoise astmkprof astnoisechisel astquery astroid astrometry-engine astscript-ds9-region astscript-fits-view astscript-psf-scale-factor astscript-psf-select-stars astscript-psf-stamp astscript-psf-subtract astscript-psf-unite astscript-radial-profile astscript-sort-by-night astsegment aststatistics asttable astwarp astyle asunder asused asy at (1) - queue, examine, or delete jobs for later execution atac ataglist ataqv atari-convert-dir atari-hd-image atdcat atdep atdgen atdgen-cppo atdts atest atf-sh atfsit atfsrepair atftp atheme-dbverify atheme-ecdsakeygen atheme-services athena-jot atig atk6-address6 atk6-alive6 atk6-connect6 atk6-connsplit6 atk6-covert_send6 atk6-covert_send6d atk6-denial6 atk6-detect-new-ip6 atk6-detect_sniffer6 atk6-dnsdict6 atk6-dnsrevenum6 atk6-dnssecwalk atk6-dos-new-ip6 atk6-dump_dhcp6 atk6-dump_router6 atk6-exploit6 atk6-extract_hosts6 atk6-extract_networks6 atk6-fake_advertise6 atk6-fake_dhcps6 atk6-fake_dns6d atk6-fake_dnsupdate6 atk6-fake_mipv6 atk6-fake_mld26 atk6-fake_mld6 atk6-fake_mldrouter6 atk6-fake_pim6 atk6-fake_router26 atk6-fake_router6 atk6-fake_solicitate6 atk6-firewall6 atk6-flood_advertise6 atk6-flood_dhcpc6 atk6-flood_mld26 atk6-flood_mld6 atk6-flood_mldrouter6 atk6-flood_redir6 atk6-flood_router26 atk6-flood_router6 atk6-flood_rs6 atk6-flood_solicitate6 atk6-flood_unreach6 atk6-four2six atk6-fragmentation6 atk6-fragrouter6 atk6-fuzz_dhcpc6 atk6-fuzz_dhcps6 atk6-fuzz_ip6 atk6-implementation6 atk6-implementation6d atk6-inject_alive6 atk6-inverse_lookup6 atk6-kill_router6 atk6-ndpexhaust26 atk6-ndpexhaust6 atk6-node_query6 atk6-parasite6 atk6-passive_discovery6 atk6-randicmp6 atk6-redir6 atk6-redirsniff6 atk6-rsmurf6 atk6-sendpees6 atk6-sendpeesmp6 atk6-smurf6 atk6-thcping6 atk6-thcsyn6 atk6-toobig6 atk6-toobigsniff6 atk6-trace6 atktopbm atlas atlas-atest-mgrids atlas-gaussian-latitudes atlas-grids atlas-io-list atlas-meshgen atlc atlys-find-board atlys-manage-firmware atlys-mode-switch atmdiag atmdump atmswitch atobm (1) - bitmap editor and converter utilities for the X Window System atoc_conv atool atq (1) - queue, examine, or delete jobs for later execution atril (1) - The MATE Document Viewer atril-previewer (1) - show print preview for a document atril-thumbnailer (1) - create png thumbnails from atril supported documents atrm (1) - queue, examine, or delete jobs for later execution atropos atsa atsc_epg atst atst-int32 atst-int64 atst-long attachMesh attachtty attr (3ncurses) - curses character and window attribute control routines aubio aubiocut aubiomfcc aubionotes aubioonset aubiopitch aubioquiet aubiotrack aucat auconvert auctl audacious audacity audemo audial audio2tape audio_rename audiolink audiotools-config audit2allow audit2why audtool audtty auedit augmatch augparse augtool augur augustus auinfo aulast aulastlog aumeta aumix aunpack aupanel auphone auplay aurecord auscope austin ausyscall authbind authorindex authoritydbus authorized-keys-test authprogs authvar auto-07p auto-apt-proxy auto-editor auto-multiple-choice autoPatch autob5 autoclass autoconf (1) - Generate configuration scripts autoconf-dickey autoconf2.13 autoconf2.64 autoconf2.69 autocutsel autodep8 autodia autodoap autodock4 autoexpect autoflake autogb autogen autogrid4 autogsdoc autoheader (1) - Create a template header for configure autoheader-dickey autoheader2.13 autoheader2.64 autoheader2.69 autoimport autoinst autojump autokey-gtk autokey-qt autokey-run autokey-shell autom4te (1) - Generate files and scripts thanks to M4 autom4te2.64 autom4te2.69 automake-1.11 automake-1.16 (1) - manual page for automake 1.16.5 automat-visualize3 autool autooptimiser autoopts-config autopasswd autopep8 autopkgtest autopkgtest-build-docker autopkgtest-build-lxc autopkgtest-build-lxd autopkgtest-build-podman autopkgtest-build-qemu autopkgtest-buildvm-ubuntu-cloud autopkgtest-virt-chroot autopkgtest-virt-docker autopkgtest-virt-lxc autopkgtest-virt-lxd autopkgtest-virt-null autopkgtest-virt-podman autopkgtest-virt-qemu autopkgtest-virt-schroot autopkgtest-virt-ssh autopkgtest-virt-unshare autopoint autoproject autopsy autopvf autorandr autoreconf (1) - Update generated configuration files autoreconf-dickey autoreconf2.13 autoreconf2.64 autoreconf2.69 autorenamer autorevision autoscan (1) - Generate a preliminary configure.ac autoscan-dickey autoscan2.13 autoscan2.64 autoscan2.69 autosp autossh autossh-argv0 autosuspend autotailor autotest autoupdate (1) - Update a configure.ac to a newer Autoconf autoupdate-dickey autoupdate2.13 autoupdate2.64 autoupdate2.69 autox auvirt auwave aux2bib av7110_loadkeys ava avahi-browse (1) - Browse for mDNS/DNS-SD services using the Avahi daemon avahi-browse-domains (1) - Browse for mDNS/DNS-SD services using the Avahi daemon avahi-discover avahi-publish (1) - Register an mDNS/DNS-SD service or host name or address mapping using the Avahi daemon avahi-publish-address (1) - Register an mDNS/DNS-SD service or host name or address mapping using the Avahi daemon avahi-publish-service (1) - Register an mDNS/DNS-SD service or host name or address mapping using the Avahi daemon avahi-resolve (1) - Resolve one or more mDNS/DNS host name(s) to IP address(es) (and vice versa) using the Avahi daemon avahi-resolve-address (1) - Resolve one or more mDNS/DNS host name(s) to IP address(es) (and vice versa) using the Avahi daemon avahi-resolve-host-name (1) - Resolve one or more mDNS/DNS host name(s) to IP address(es) (and vice versa) using the Avahi daemon avahi-set-host-name (1) - Change mDNS host name avarice avcdelete avcexport avcimport avctest aven average average.x average_genome_size average_nucleotide_identity.py avfs-config avfsd avibench avicat aview avifdec avifenc avifile-config avimake avitype avobabel avocjsontocml avogadro avogadro2 avogen avologin avr-addr2line avr-ar avr-as avr-c++ avr-c++filt avr-cpp avr-elfedit avr-g++ avr-gcc avr-gcc-5.4.0 avr-gcc-ar avr-gcc-nm avr-gcc-ranlib avr-gcov avr-gcov-tool avr-gdb avr-gdb-add-index avr-gprof avr-ld avr-ld.bfd avr-man avr-nm avr-objcopy avr-objdump avr-ranlib avr-readelf avr-run avr-size avr-strings avr-strip avra avrdude (1) - driver program for ``simple'' Atmel AVR MCU programmer avro avroappend avrocat avromod avropipe avrp avs2ps avstopam awardeco away aweset awesome awesome-client awffull awk_count awrite aws aws-nuke aws-rb aws_completer awstats axcall axe-demux axel axfer (1) - command-line sound recorder and player for sound devices and nodes supported by Linux sound subsystem (Advanced Linux Sound Architecture, also known as ALSA). axgetlist axgetmail axgetmsg axgetput axi-cache axiom axiom-test axis axis-remote axlisten axohelp axt_extract_ranges.py axt_to_fasta.py axt_to_lav.py axt_to_maf.py ayatana-settings ayatana-webmail ayatana-webmail-clear ayatana-webmail-reset ayatana-webmail-settings ayatana-webmail-url aylet aylet-gtk az azap b1ee b2 b2m.xemacs21 b2sum (1) - compute and check BLAKE2 message digest b3270 b3sum b4 bCNC babel-minify babeljs-7 babeljs-7-external-helpers babeljs-7-node babeljs-7-parser babeltrace babeltrace-log babeltrace2 babylon backblaze-b2 backbone_global_to_local backdoor-factory backend-test-tools backintime backintime-askpass backintime-qt backintime-qt_polkit backport-dsc backportpackage backtranambig backtranseq backup-checkallused backup-driver backup-labeltape backup-loaded backup-manager-purge backup-manager-upload backup-snaprsync backup-takedown backup-whatsthis backup2l backuptodo bacon bacteria_tradis badger bagpipe-bgp bagpipe-bgp-cleanup bagpipe-fakerr bagpipe-impex2dot bagpipe-looking-glass bagpipe-rest-attach balboa balboa-backend-console balboa-rocksdb bali-phy bali-phy-pkg bali-subsample balloon balls baloo_file baloo_file_extractor baloo_filemetadata_temp_extractor balooctl baloosearch balooshow balsa balsa-ab bam bam-load bam-read bam12auxmerge bam12split bam12strip bam2bed bam2bed_gnuParallel bam2bed_sge bam2bed_slurm bam2bedgraph bam2hints bam2sam bam2starch bam2starch_gnuParallel bam2starch_sge bam2starch_slurm bam2wig bamCompare bamCoverage bamPEFragmentSize bamToBed bamToFastq bamToGBrowse.pl bam_coverage_windows bamadapterclip bamadapterfind bamalignfrac bamauxmerge bamauxmerge2 bamauxsort bamcat bamchecksort bamcleanheader.py bamclipXT bamclipper.sh bamclipreinsert bamcollate2 bamdepth bamdepthintersect bamdifference bamdownsamplerandom bamexplode bamexploderef bamfastcat bamfastexploderef bamfastnumextract bamfastsplit bamfeaturecount bamfillquery bamfilteraux bamfiltereofblocks bamfilterflags bamfilterheader bamfilterheader2 bamfilterk bamfilterlength bamfiltermc bamfilternames bamfilterrefid bamfilterrg bamfilterrg.py bamfixflags.py bamfixmateinformation bamfixpairinfo bamflagsplit bamg bamg2geo bamgroupreads.py bamheadrg.py bamindex bamintervalcomment bamintervalcommenthist bamleftalign bamlibs.py bammapdist bammarkduplicates bammarkduplicates2 bammarkduplicatesopt bammaskflags bammdnm bammerge bamnumericalindex bamnumericalindexstats bamrank bamranksort bamrecalculatecigar bamrecompress bamrefextract bamrefinterval bamreheader bamreplacechecksums bamreset bamscrapcount bamseqchksum bamsormadup bamsort bamsplit bamsplitdiv bamstreamingmarkduplicates bamtofastq bamtofastq.py bamtools bamvalidate bamview bamzztoname banana band2eps bandit bandit-baseline bandit-config-generator bands.x banner baobab bar barbican barbican-api barbican-db-manage barbican-keystone-listener barbican-manage barbican-retry barbican-status barbican-worker barbican-wsgi-api barcode bardecode barebox-state barectf baremetal baresip barman barman-cloud-backup barman-cloud-backup-delete barman-cloud-backup-keep barman-cloud-backup-list barman-cloud-check-wal-archive barman-cloud-restore barman-cloud-wal-archive barman-cloud-wal-restore barman-wal-archive barman-wal-restore barnowl barrier barrierc barriers barrnap bart base16 base32 (1) - base32 encode/decode data and print to standard output base32hex base32plain base58 base64 (1) - base64 encode/decode data and print to standard output base64mime base64pem base64plain base64url baseCalling_Matrix_analyzer baseCalling_Matrix_calculator baseCalling_Matrix_calculator.0 baseCalling_Matrix_merger baseCalling_Matrix_merger.old base_evolve baseml basemlg basename (1) - strip directory and suffix from filenames basename (3) - parse pathname components basenc (1) - Encode/decode data and print to standard output basepods baseprog basex basexclient basexgui basexserver basez bashate bashbug (1) - report a bug in bash basic256 basictopvf basis basket bat2gts batalert batcat batch (1) - queue, examine, or delete jobs for later execution batch_crop batch_image_convert batch_rubber_sheet batmon bats battery-graph battery-log bbAnalyze bbFilter bbduk.sh bbe bbl2bib bbmail bbmap.sh bbnorm.sh bbox bboxx bbpager bbrun bbstored-certs bbtime BC (3ncurses) - curses emulation of termcap bc (1) - An arbitrary precision calculator language bcal bcalm bcat bcc bcc-lua bcftools bchunk bcmserver bcomps (1) - biconnected components filter for graphs bcop bcp bcpp bcrontab bct_dump bd bd_info bd_list_titles bd_splice bdbvu bdebstrap bdeinfo bdemount bdf2gdfont bdf2psf bdf2sfd bdfimplode bdfresize bdftobogl bdftogd bdftopcf (1) - convert X font from Bitmap Distribution Format to Portable Compiled Format bdftruncate (1) - generate truncated BDF font from ISO 10646-1-encoded BDF font bdump bdy beads beagle beaker beaker-hostgenerator beam-eval-until-stable bean-bake bean-check bean-doctor bean-example bean-extract bean-file bean-format bean-identify bean-price bean-query bean-report bean-sql bean-web beanstalkd bear bearing beast-mcmc beast-tracer beast2-mcmc beauti beauti2 beav bed12ToBed6 bed2bed_display bed2gff3 bed2sga bedToBam bedToIgv bed_bigwig_profile.py bed_build_windows.py bed_complement.py bed_count_by_interval.py bed_count_overlapping.py bed_coverage.py bed_coverage_by_interval.py bed_diff_basewise_summary.py bed_extend_to.py bed_intersect.py bed_intersect_basewise.py bed_merge_overlapping.py bed_rand_intersect.py bed_subtract_basewise.py bedextract bedmap bedops bedops-starch bedpeToBam bedtools beef beep (3ncurses) - curses bell and screen flash routines beer beet behave bel-resources belenios-tool belvu bemenu bemenu-run ben benchcmp benchmark benchmark_xl benchmarking-image-features bepasty-object bepasty-server berdecode (1) - decode BER encoded data berkeley-abc berkeley-express besside-ng-crawler best_enantiomers.sh beta2uni betaradio bettercap between-two-genes bez2mesh bf_compact-bdb bf_compact-sqlite bf_compact-tokyocabinet bf_copy-bdb bf_copy-sqlite bf_copy-tokyocabinet bf_tar-bdb bf_tar-sqlite bf_tar-tokyocabinet bfbtester bfs bg-installer bg5+latex bg5+pdflatex bg5conv bg5latex bg5pdflatex bg_gen_unified_kernel bg_printenv bg_setenv bget bgolly bgpdump bgpq3 bgpq4 bgzip biabam bib2bib bib2gls bib2pdf bib2xml bibclean bibcursed bibdoiadd biber bibexport bibhva biblatex2xml bible bibledit bibledit-cloud bibletime bibmradd biboumi bibtex-to-dep12 bibtex-validate bibtex.original bibtex.pybtex bibtex2html bibtex8 bibtexconv bibtexconv-odt bibtexu bibtool biburl2doi bibzbladd bidiv bifcl biff biglybt biglybtd biglybtd-gui bigwigCompare bijiben bin2c bin2fex bin2h bin2obj-3.2.2 bin2rec binary2ascii bincat binclock bindechexascii bindfs bindgen binfmtasm-interpreter binfmtc-interpreter binfmtcxx-interpreter binfmtf-interpreter binfmtf95-interpreter binfmtgcj-interpreter binhex binoculars binoculars-fitaid binoculars-gui binoculars-processgui binpac binstats binvox2bt binwalk (1) - tool for searching binary images for embedded files and executable code bio-eagle bio-rainbow bio-vcf bioauth bioawk bioblend-galaxy-tests biocUpdate bioctl bioctl-helper biodrvctl biogenesis biom biomaj-cli biomaj-cli.py biomaj-daemon-consumer biomaj-daemon-web biomaj-download-consumer biomaj-download-web biomaj-process-consumer biomaj-process-web biomaj-users biomaj-users-web biomaj-users.py biomaj_daemon_consumer.py biomaj_download_consumer.py biomaj_migrate_database.py biomaj_process_consumer.py biometric-auth-client biometric-config-tool biometric-device-discover biometric-manager biometryd bioradtopgm biorestart biosed biosig2gdf biosig_fhir bip bip32gen bipgenconfig bipmkpw birdfont birdfont-autotrace birdfont-export birdfont-import birdtray birthday bison (1) - GNU Project parser generator (yacc replacement) bison++ bison++.yacc bison.yacc (1) - GNU Project parser generator bisonc++ bit2fp bitesize bitmap (1) - bitmap editor and converter utilities for the X Window System bitmap-editor bitmap2component bitmeter bitparse bitstormlite bittwist bittwiste bitwise bjam bkchem bl2seq black blackbox blade bladeRF-cli bladeRF-fsk bladeRF-install-firmware bladerf-tool blaeu-cert blaeu-reach blaeu-resolve blaeu-traceroute blag blahtexml blame blasr blast2sam.pl blast_formatter blast_report blast_top_hits blastall blastdb_aliastool blastdb_convert blastdb_path blastdbcheck blastdbcmd blastdbcp blastn blastn_to_phandango blastp blastpgp blastx blat2gff blazar blaze blaze-add blaze-config blaze-edit blaze-init blaze-list blaze-log blaze-make blaze-remove bld_signames bleachbit blend bless blhc bliss blitz blixem blixemh blkcalc (1) - Converts between unallocated disk unit numbers and regular disk unit numbers. blkcat (1) - Display the contents of file system data unit in a disk image. blkiomon blkls (1) - List or output file system data units. blkparse blkrawverify blkreplay blkstat (1) - Display details of a file system data unit (i.e. block or sector) blockMesh blockdiag3 blocksplit blogin blood-elf bloom bloom-export-upstream bloom-generate bloom-release bloom-update bloomfilter.sh bls-standalone bluealsa bluealsa-aplay bluedevil-sendfile bluedevil-wizard bluefeather bluefish blueman-adapters blueman-applet blueman-manager blueman-sendto blueman-services blueman-tray bluemon-client bluemon-query bluemoon (1) - Bluemoon configuration utility blueprint-compiler bluetooth bluetooth-sendto (1) - GTK application for transferring files over Bluetooth bluetoothService bluetoothctl (1) - interactive bluetooth control tool blur_image bmake bmaptool bmf bmfconv bmon bmore bmp bmptopnm bmptoppm bmtoa (1) - bitmap editor and converter utilities for the X Window System bnMapper.py bn_camera bn_darknet bn_dashboard bn_data_collector bn_gmail bn_telegram bnamazu bnd bnep-tester bnfc bno_plot boats bochs bochs-bin bodrparse bogofilter-bdb bogofilter-sqlite bogofilter-tokyocabinet bogolexer-bdb bogolexer-sqlite bogolexer-tokyocabinet bogotune-bdb bogotune-sqlite bogotune-tokyocabinet bogoupgrade-bdb bogoupgrade-sqlite bogoupgrade-tokyocabinet bogoutil-bdb bogoutil-sqlite bogoutil-tokyocabinet boinc boinccmd boincmgr boincscr boinctui bolt boltctl (1) - control the thunderbolt device manager bombadillo bombardment bomstrip bomstrip-files bond2team bones-info boogie bookletimposer bookman booldnf boolector boomaga boost.gcd boost.lcm boost.python boost.show_build_path boost.show_dist_paths boost_adaptbx.divide_by_zero boost_adaptbx.double_overflow boost_adaptbx.inexact boost_adaptbx.int_overflow boost_adaptbx.nested_cpp_loops_with_check_signals boost_adaptbx.segmentation_fault boost_adaptbx.show_environ_usage boost_adaptbx.show_platform_info bootcd bootcd2chroot bootcd2disk bootcdbackup bootcdmk2diskconf bootcdwrite bootctl bootgen borg borgbackup borgfs borgmatic bornagain bosh bosixnet_daemon bosixnet_webui bossa bossac bossash bot-basicbot-pluggable bot-training botan botch-add-arch botch-annotate-strong botch-apply-ma-diff botch-bin2src botch-build-fixpoint botch-build-order-from-zero botch-buildcheck-more-problems botch-buildgraph2packages botch-buildgraph2srcgraph botch-calcportsmetric botch-calculate-fas botch-check-ma-same-versions botch-checkfas botch-clean-repository botch-collapse-srcgraph botch-convert-arch botch-create-graph botch-cross botch-distcheck-more-problems botch-dose2html botch-download-pkgsrc botch-droppable-diff botch-droppable-union botch-extract-scc botch-fasofstats botch-filter-src-builds-for botch-find-fvs botch-fix-cross-problems botch-graph-ancestors botch-graph-descendants botch-graph-difference botch-graph-info botch-graph-neighborhood botch-graph-shortest-path botch-graph-sinks botch-graph-sources botch-graph-tred botch-graph2text botch-graphml2dot botch-latest-version botch-ma-diff botch-multiarch-interpreter-problem botch-native botch-optuniv botch-packages-diff botch-packages-difference botch-packages-intersection botch-packages-union botch-partial-order botch-print-stats botch-profile-build-fvs botch-remove-virtual-disjunctions botch-src2bin botch-stat-html botch-transition botch-wanna-build-sortblockers botch-y-u-b-d-transitive-essential botch-y-u-no-bootstrap boundaryFoam bowtie bowtie-align-l bowtie-align-l-debug bowtie-align-s bowtie-align-s-debug bowtie-build bowtie-build-l bowtie-build-l-debug bowtie-build-s bowtie-build-s-debug bowtie-inspect bowtie-inspect-l bowtie-inspect-l-debug bowtie-inspect-s bowtie-inspect-s-debug bowtie2 bowtie2-align-l bowtie2-align-s bowtie2-build bowtie2-build-l bowtie2-build-s bowtie2-inspect bowtie2-inspect-l bowtie2-inspect-s bowtie2sam.pl boxTurb boxer boxes boxshade bp bp-analyze bp2bp.mpich bp2bp.openmpi bp2ncd.mpich bp2ncd.openmpi bp_aacomp bp_biofetch_genbank_proxy bp_bioflat_index bp_biogetseq bp_bulk_load_gff bp_das_server bp_dbsplit bp_download_query_genbank bp_einfo bp_extract_feature_seq bp_fast_load_gff bp_fastam9_to_table bp_fetch bp_filter_search bp_find-blast-matches bp_flanks bp_gccalc bp_genbank2gff bp_genbank2gff3 bp_genbank_ref_extractor bp_generate_histogram bp_hmmer_to_table.pl bp_index bp_load_gff bp_local_taxonomydb_query bp_make_mrna_protein bp_mask_by_search bp_meta_gff bp_mrtrans bp_multi_hmmsearch.pl bp_mutate bp_nexus2nh bp_nrdb bp_oligo_count bp_pairwise_kaks bp_panalysis.pl bp_papplmaker.pl bp_parse_hmmsearch.pl bp_process_gadfly bp_process_sgd bp_process_wormbase.pl bp_query_entrez_taxa bp_remote_blast.pl bp_revtrans-motif bp_run_neighbor.pl bp_run_protdist.pl bp_search2alnblocks bp_search2gff bp_search2table bp_search2tribe bp_seq_length bp_seqconvert bp_seqcut bp_seqfeature_delete bp_seqfeature_gff3 bp_seqfeature_load bp_seqpart bp_seqret bp_seqretsplit bp_split_seq bp_sreformat bp_taxid4species bp_taxonomy2tree bp_translate_seq bp_tree2pag bp_unflatten_seq bpappend.mpich bpappend.openmpi bpdb bpdb3 bpdump.mpich bpdump.openmpi bpf-addr2line bpf-ar bpf-as bpf-c++filt bpf-cpp bpf-elfedit bpf-gcc bpf-gcc-ar bpf-gcc-nm bpf-gcc-ranlib bpf-gdb bpf-gdb-add-index bpf-gprof bpf-ld bpf-ld.bfd bpf-nm bpf-objcopy bpf-objdump bpf-ranlib bpf-readelf bpf-run bpf-size bpf-strings bpf-strip bpfix bpfmt bpftrace bpftrace-aotrt bpgettime.mpich bpgettime.openmpi bpglob bplay bpls.mpich bpls.openmpi bpm bpm-graph bpm-tag bpmodify bppalnoptim bppalnscore bppancestor bppconsense bppdist bppmixedlikelihoods bppml bpppars bppphysamp bpppopstats bppreroot bppseqgen bppseqman bpptreedraw bpsplit.mpich bpsplit.openmpi bput bpython bpython-curses bpython-urwid bpython3 bpython3-curses bpython3-urwid bpytop br braa brag braillefont braillegraph brailleutils branch brancid brandy brasero break_filelist breathe-apidoc brebis brec breeze-settings5 bref3 brewtarget brfs brig brightd brightnessctl brighton bristol bristoljackstats brlogin brltty-atb brltty-clip brltty-ctb brltty-hid brltty-ktb brltty-lscmds brltty-morse brltty-trtxt brltty-ttb brltty-tune bro-cut broadwayd (1) - Broadway display server brotli browser browser-insert-module-globals browser-pack browser-unpack browserify browserify-lite browserslist brushtopbm brutefir bruteforce-luks bruteforce-salted-openssl bruteforce-wallet brutespray brz bs11_config bs1770gain bs2bconvert bs2bstream bsd-mailx bsdcat bsdcpio bsdiff bsdl2jtag bsdtar bse_main.x bsetbg bsetroot bsh bshell bskk bson2json bson2toml bson2yaml bspatch bspc bspwm bsqldb bsqlodbc bssh bssl-tool bst bstyleconvert bsvplay bt-adapter bt-agent bt-device bt-network bt-obex bt2vrml btattach (1) - Attach serial devices to BlueZ stack btcflash btcheck bterm btest btest-ask-update btest-bg-run btest-bg-run-helper btest-bg-wait btest-diff btest-diff-rst btest-progress btest-rst-cmd btest-rst-include btest-rst-pipe btest-setsid btfdiff btfs btfsstat bti bti-shrink-urls btmgmt (1) - A command-line interface of BlueZ for management Usage: btmon (1) - Bluetooth monitor btop btplay btrbk btrfs-balance-least-used btrfs-extent-same btrfs-heatmap btrfs-orphan-cleaner-progress btrfs-search-metadata btrfs-space-calculator btrfs-usage-report bts bts-retitle bts-srcpkg btscanner btt btvirt btwisted btyacc bubblefishymon buble bucardo buddy-ng budgie-control-center budgie-daemon budgie-desktop budgie-desktop-settings budgie-extras-daemon budgie-panel budgie-polkit-dialog budgie-run-dialog budgie-screenshot budgie-wm buffer bufr-sanity-check bufr_0t2 bufr_88t89 bufr_add_bias bufr_check bufr_compare bufr_compare_dir bufr_compress bufr_copy bufr_count bufr_decode bufr_decode_all bufr_dump bufr_filter bufr_get bufr_index_build bufr_key bufr_ls bufr_merg bufr_merge_tovs bufr_nt1 bufr_ntm bufr_obs_filter bufr_repack bufr_repack_206t205 bufr_repack_satid bufr_set bufr_ship_anmh bufr_ship_anmh_ERA bufr_simulate bufr_split bufrscan bugpoint bugpoint-13 bugpoint-14 bugpoint-15 bugwarrior-pull bugwarrior-uda bugwarrior-vault bugz bugzilla buici-clock build-and-provide-package build-astrometry-index build-progress.sh build-rdeps build-simple-cdd build_blast_atlas build_blast_atlas_all_vs_all build_cog_db build_firefox build_tmdb buildah buildapp buildbench buildbot buildbot-worker buildd buildd-abort buildd-mail buildd-mail-wrapper buildd-synclogs buildd-update-chroots buildd-uploader buildd-vlog buildd-watcher builder-c++ builder-cc buildhash buildlogs-summarise buildout buildtorrent buildxpi buku bully bumblebee-bugreport bumblebee-ctl bumblebee-status bumps bumpversion bundle bundle3.0 bundle3.1 bundledoc bundler bundler3.0 bundler3.1 bundt bunyan bunzip3 buoyantBoussinesqPimpleFoam buoyantBoussinesqSimpleFoam buoyantPimpleFoam buoyantSimpleFoam bup burner busco busctl (1) - Introspect the bus busted bustle bustle-pcap bustools buthead butt butteraugli butteraugli_main buttercup buzztrax-cmd buzztrax-edit bvd bvedit bvh_access bvh_builder bvi bview bvnc bw bwa bwbasic bwm-ng bwrap (1) - container setup utility bxhub bximage bxl2txt byacc (1) - an LALR(1) parser generator byaccj byebug byobu byobu-config byobu-ctrl-a byobu-disable byobu-disable-prompt byobu-enable byobu-enable-prompt byobu-export byobu-janitor byobu-keybindings byobu-launch byobu-launcher byobu-launcher-install byobu-launcher-uninstall byobu-layout byobu-prompt byobu-quiet byobu-reconnect-sockets byobu-screen byobu-select-backend byobu-select-profile byobu-select-session byobu-shell byobu-silent byobu-status byobu-status-detail byobu-tmux byobu-ugraph byobu-ulevel bytes-circle byzanz-playback byzanz-record bz3cat bz3grep bz3less bz3more bz3most bzip3 bzz c++-copy-class-and-file c++-rename-class-and-file c++decl c++filt (1) - demangle C++ and Java symbols c-icap c-icap-client c-icap-config c-icap-libicapapi-config c-icap-mkbdb c-icap-mods-sguardDB c-icap-stretch c-index-test c-index-test-13 c-index-test-14 c-index-test-15 c2050 c2bciter c2bimport c2dec c2enc c2go c2hs c2p c2x c2xml c3270 c44 c89-gcc (1) - ANSI (1989) C compiler c99-gcc (1) - ANSI (1999) C compiler c_count c_rehash (1ssl) - Create symbolic links to files named by the hash values ca65 cabal cabal-debian cabextract caca-config cacaclock cacademo cacafire cacaplay cacaserver cacaview cacaxine cache-info cache-mgr cache_bench cacheadm cachedas cachedbfetch cachedel cacheebeyesearch cacheensembl cachepic cachestats cad2d cadabra cadabra-server cadabra2 cadabra2-cli cadabra2-gtk cadabra2cadabra cadabra2html cadabra2ipynb cadabra2latex cadabra2python cadaver cadical cado cadrop cadubi cafeobj caff caffeinate caffeine caffeine-indicator cage cai caiksaurus cairo-analyse-trace cairo-dock cairo-dock-session cairo-perf-chart cairo-perf-compare-backends cairo-perf-diff-files cairo-perf-micro cairo-perf-print cairo-perf-trace cairo-trace cairosvg caja caja-actions-config-tool caja-actions-new caja-actions-print caja-actions-run caja-autorun-software caja-connect-server caja-file-management-properties caja-sendto tc-cake (8) - Common Applications Kept Enhanced (CAKE) cake.coffeescript cal (1) - displays a calendar and the date of Easter cal3d_converter calamares calamaris calc calcappclient calcdest calcwish calendar calendarjanitor calfjackhost calgebra calibrate_lens_gui calibrate_ppa calibre calibre-complete calibre-customize calibre-debug calibre-parallel calibre-server calibre-smtp calibredb calidns calife callaudiocli callaudiod callgraph callgrind_annotate (1) - post-processing tool for the Callgrind callgrind_control (1) - observe and control programs being run by Callgrind calligra calligraconverter calligragemini calligrageminithumbnailhelper calligraplan calligraplanwork calligrasheets calligrastage calligrawords callisto-sunschedule callpass calmjs calypso cam camera-calib cameratopam caml2html camlidl camlmix camlp4 camlp4boot camlp4o camlp4o.opt camlp4of camlp4of.opt camlp4oof camlp4oof.opt camlp4orf camlp4orf.opt camlp4prof camlp4r camlp4r.opt camlp4rf camlp4rf.opt camlp5 camlp5o camlp5o.opt camlp5r camlp5r.opt camlp5sch camv-rnd can-calc-bit-timing can_logconvert can_logger can_player can_viewer canadian-ham-exam canberra-gtk-play canbusload cancel (1) - cancel jobs cancelmsg cancompare canconvert candump caneda canfdtest cangen cangw canid canlisp canlock canlock-hfp canlock-mhp canlogserver cannacheck cannakill cannastat canon-gff3 canplayer cansend cansequence cansniffer cantata cantor cantor_pythonserver cantor_rserver cantor_scripteditor canu cap capify capinfos (1) - Prints information about capture files capnp capnpc capnpc-c++ capnpc-capnp cappuccino caprint caps2esc capstats capsule-nextflow captest captoinfo (1) - convert a termcap description into a terminfo description captype (1) - Prints the types of capture files car carbon-aggregator carbon-aggregator-cache carbon-c-relay carbon-cache carbon-client carbon-relay card card_eventmgr cardcommander cardos-tool cardpeek care cargo cargo-capi cargo-cbuild cargo-cinstall cargo-clippy cargo-cov cargo-ctest cargo-fmt cargo-lichking cargo-lock cargo-nm cargo-objcopy cargo-objdump cargo-outdated cargo-profdata cargo-readobj cargo-size cargo-strip caribou-preferences carmen2rawlog carmen2simplemap carmetal carto carton cartopy_feature_download cas_help casacore-update-tai_utc casahdf5support casparize caspol cassbeam cassie cassiopee cassiopeeknife castle-curves castle-engine castool castxml casync cat5rancid catalog_query catalog_server catalog_update catalyst.pl catatonit catcodec catdic catdoc catdvi catfish catfishq catgirl cathparse catimg catior catkin catkin_create_pkg catkin_find catkin_find_pkg catkin_generate_changelog catkin_init_workspace catkin_lint catkin_make catkin_make_isolated catkin_package_version catkin_prepare_release catkin_tag_changelog catkin_test_changelog catkin_test_results catkin_topological_order catm catman (8) - create or update the pre-formatted manual pages catmandu catmaster catod catof catppt catstomp catty cava caveconverter cavern cavitatingDyMFoam cavitatingFoam cb2bib cb2ti3 cb_console_runner cb_share_config cba cba-gtk cback3 cback3-amazons3-sync cback3-span cbatticon cbc cbcodec cbf.dump cbf2nexus cbflib.python cbflib.show_build_path cbflib.show_dist_paths cbflib.tst_memory cbindgen cbm cbmconvert cbootimage cbor cbor2comment cbor2diag cbor2js cbor2json cbp2make cc-tool cc1541 cc65 ccViewer ccache ccache-swig ccache-swig4.0 ccache2shishi ccal ccat ccbuild cccc cccd cccheck ccconfig ccd2iso ccdecrypt ccdiff ccecho ccencrypt ccextract ccframe ccguess cciss_vol_status cckd2ckd cckdcdsk cckdcomp cckddiag cckdswap ccl cclib-cda cclib-get cclive ccls ccmake ccmtcnvt ccom ccomps (1) - connected components filter for graphs ccon cconfig cconv ccp4io.python ccp4io.show_build_path ccp4io.show_dist_paths ccr ccrewrite ccrypt ccs-kinetics-bystrandify ccsm cct cctbx.HKLinfo cctbx.HKLviewer cctbx.brehm_diederichs cctbx.cod_select_and_pickle cctbx.convert_ccp4_symop_lib cctbx.data_viewer cctbx.development.ntc_validation cctbx.diffuse cctbx.eltbx.show_fp_fdp cctbx.euclidean_model_matching cctbx.find_distances cctbx.getting_started cctbx.image_viewer cctbx.isomorphous_difference_patterson cctbx.lattice_symmetry cctbx.loggraph cctbx.make_install_HKLviewer_ChimeraX cctbx.multiplicity_viewer cctbx.patterson_map cctbx.plot_anomalous_scattering cctbx.precession_view cctbx.python cctbx.show_build_path cctbx.show_dist_paths cctbx.show_systematic_absences cctbx.space_group_info cctbx.structure_factor_timings cctbx.subgroups cctbx.suitename cctbx.sym_equiv_sites cctbx.sys_abs_equiv_space_groups cctbx.version cctbx.visualize_r_factors cctbx.wavelength_units cctbx.web.install cctbx.wxpython cctbx.xray_structure.show cctbx_blobs cctbx_regression.test_nightly cctiff cctools_gpu_autodetect cctypeinfo ccutter ccwrite ccx ccxxmake ccze ccze-cssdump cd-circleprint cd-convert cd-create-profile (1) - Color Manager Profile Creation Tool cd-discid cd-drive cd-fix-profile (1) - Color Manager Testing Tool cd-hit cd-hit-2d cd-hit-2d-para cd-hit-454 cd-hit-div cd-hit-est cd-hit-est-2d cd-hit-para cd-iccdump cd-info cd-it8 (1) - Color Manager Testing Tool cd-paranoia cd-read cd-tkdesk cd5 cd_disect cd_sessions cda2dcm cdadd cdargs cdb cdb-nbtool cdbackup cdbdump cdbfasta cdbget cdbmake cdbs-edit-patch cdbstats cdbyank cdcd cdck cdclose cdcover cdctrl cdda-player cdda2mp3 cdda2ogg cdda2track cdda2wav cddainfo cddaplay cddb-tool cddbget cdde cddexec cddexec_gmp cde cde-exec cdebootstrap cdebootstrap-static cdecl cdeject cdf16bit cdf2levitusgrid2d cdf2matlab cdf2regular cdf_compress cdf_conv_zgr cdf_domain2bathy cdf_domain_modif cdf_dynadv_ubs cdf_remake_bathy cdf_xtrac_brokenline cdfbathy cdfbn2 cdfbotpressure cdfbottom cdfbottomsig cdfbuoyflx cdfcensus cdfcheckic cdfchgrid cdfclip cdfcmp cdfcofdis cdfcoloc cdfconvert cdfcsp cdfcurl cdfdegrad cdfdiff cdfdifmask cdfdiv cdfdynh_anom cdfeddyscale cdfeddyscale_pass1 cdfeke cdfenstat cdfets cdffindij cdffixanom cdffixtime cdffracinv cdffwc cdfgeo-uv cdfgeostrophy cdfgradT cdfheatc cdfhflx cdfhgradb cdfhgradv cdficb_clim cdficb_clv cdficb_diags cdficediags cdfimprovechk cdfinfo cdfisf_diags cdfisf_fill cdfisf_forcing cdfisf_poolchk cdfisf_rnf cdfisopsi cdflap cdflinreg cdfmaskdmp cdfmax cdfmaxmoc cdfmean cdfmeshmask cdfmhst cdfmht_gsop cdfmkmask cdfmkresto cdfmltmask cdfmoc cdfmocsig cdfmoy cdfmoy_freq cdfmoy_weighted cdfmoyt cdfmppini cdfmsk cdfmxl cdfmxlhcsc cdfmxlheatc cdfmxlsaltc cdfnamelist cdfnan cdfnorth_unfold cdfnrj_bci cdfnrj_bti cdfnrj_components cdfnrj_transfert cdfocape cdfokubow cdfpdf cdfpendep cdfpolymask cdfprobe cdfprofile cdfpsi cdfpvor cdfrhoproj cdfrichardson cdfrmsssh cdfscale cdfshift05 cdfsig0 cdfsigi cdfsiginsitu cdfsigintegr cdfsigntr cdfsigtrp cdfsigtrp_broken cdfsmooth cdfspeed cdfspice cdfstatcoord cdfstats cdfstd cdfstdevts cdfstdevw cdfstrain cdfsum cdfthic cdftransig_xy3d cdftransport cdfuv cdfuvwt cdfvFWov cdfvT cdfvar cdfvertmean cdfvhst cdfvint cdfvita cdfvsig cdfvtrp cdfw cdfweight cdfwflx cdfwhereij cdfzisot cdfzonalmean cdfzonalmeanvT cdfzonalout cdfzonalsum cdfzoom cdhit cdhit-2d cdhit-454 cdhit-est cdhit-est-2d cdi cdiff cdigidoc cdinfo cdir cdist cdist-dump cdist-new-type cdkcif2sdf cdkcif2smiles cdkcif2xyz cdkdepict cdkrecharge cdksdf2smiles cdlabelgen cdloop cdo cdown cdparanoia cdpause cdplay cdr2odg cdr2raw cdr2xhtml cdrdao cdrecord cdreset cdrestore cdrskin cdrwtool cdshuffle cdstop cdtoa cdtool2cddb cdvolume cdw cdxa2mpeg cec-client cec-compliance (1) - An application to verify remote CEC devices cec-ctl (1) - An application to control cec devices cec-follower (1) - An application to emulate CEC followers cecilia cef5conv cef5latex cef5pdflatex cefconv ceflatex cefpdflatex cefsconv cefslatex cefspdflatex ceilometer-agent-notification ceilometer-polling ceilometer-rootwrap ceilometer-send-sample ceilometer-status ceilometer-upgrade celery celeste_standalone cell2ibrav.x celluloid cellwriter cen64 cen64-qt censuslookup centrifuge centrifuge-build centrifuge-compress centrifuge-download centrifuge-inspect ceph ceph-authtool ceph-bluestore-tool ceph-clsinfo ceph-conf ceph-crash ceph-dencoder ceph-dns ceph-erasure-code-tool ceph-fuse ceph-immutable-object-cache ceph-info ceph-kvstore-tool ceph-log ceph-mds ceph-mgr ceph-mon ceph-monstore-tool ceph-objectstore-tool ceph-osd ceph-osdomap-tool ceph-post-file ceph-rbdnamer ceph-run ceph-syn cephfs-data-scan cephfs-journal-tool cephfs-mirror cephfs-shell cephfs-snap cephfs-table-tool cephfs-top cereal cert-sync cert-to-efi-hash-list cert-to-efi-sig-list cert2spc cert_create certbot certinfo certipy certmgr certspotter certtool certutil cervisia cewl cf-agent cf-check cf-execd cf-key cf-monitord cf-net cf-promises cf-runagent cf-secret cf-serverd cf-upgrade cfba2fba cfdg cffsubr cfftot1 cfg-clex cfgmaker cfgrib cfityk cflow cfm-seriation cfn-create-aws-symlinks cfn-get-metadata cfn-hup cfn-init cfn-push-stats cfn-signal cfourcc cfssl cfssl-bundle cfssl-certinfo cfssl-mkbundle cfssl-newkey cfssl-scan cfssljson cfte cftp3 cfx4ToFoam cg cg-comp cg-conv cg-load cg-mwesplit cg-proc cg-relabel cg-sort cg-strictify cg-untrace cg3 cg3-autobin.pl cg_annotate (1) - post-processing tool for Cachegrind cg_diff (1) - compares two Cachegrind output files cg_merge (1) - merges multiple Cachegrind output files into one cgal_create_CMakeLists cgal_create_cmake_script cgcc cgclassify cgcreate cgdb cgdelete cgexec cgflookup cgget cgi-fcgi (1) - bridge from CGI to FastCGI cgi-fcgi-interp cgiapp-starter cgicc-config cgiowish cgm2ncgm cgns_to_aflr3 cgns_to_fast cgns_to_plot3d cgns_to_tecplot cgns_to_vtk cgns_unitconv cgnscalc cgnscheck cgnscompress cgnsconvert cgnsdiff cgnslist cgnsnames cgnsnodes cgnsplot cgnsupdate cgnsview cgps cgpt cgrep cgroupfs-mount (8) - set up cgroupfs mount hierarchies cgroupfs-umount (8) - set up cgroupfs mount hierarchies cgset cgsnapshot cgview cgview_comparison_tool cgx ch-checkns ch-convert ch-fromhost ch-image ch-run ch-run-oci ch-ssh ch-test ch_lab ch_track ch_utt ch_wave chafa chage (1) - change user password expiry information chain2dim chainsaw chake chalow change-po-charset changeDictionary change_paired_read_orientation changelog changeme changeotheruserpwd changepagestring changepdfstring changerefkeys changestool changetrack changeuserpwd chaos chaosread chaosreader char2sp charactermanaj chardet (1) - universal character encoding detector chardetect (1) - universal character encoding detector charge charmap (5) - character set description file charmtimetracker chartex chartread chase chasen chasen-config chasquid chasquid-util chattr (1) - change file attributes on a Linux file system chatty chaussette chcat chcon (1) - change file security context chcp chdist chdman cheatmake check-dfsg-status check-enhancements check-manifest check-mir check-model check-module check-node check-openstack-debian-image check-regexp check-sendfile check-sort-order check-support-status check-symbols check-uuid checkFaMesh checkMesh checkTR checkUserPwd checkXML5 check_bed.pl check_calib check_compression check_env check_perldiag check_pgbackrest check_postgres check_postgres_archive_ready check_postgres_autovac_freeze check_postgres_backends check_postgres_bloat check_postgres_checkpoint check_postgres_cluster_id check_postgres_commitratio check_postgres_connection check_postgres_custom_query check_postgres_database_size check_postgres_dbstats check_postgres_disabled_triggers check_postgres_disk_space check_postgres_fsm_pages check_postgres_fsm_relations check_postgres_hitratio check_postgres_hot_standby_delay check_postgres_index_size check_postgres_indexes_size check_postgres_last_analyze check_postgres_last_autoanalyze check_postgres_last_autovacuum check_postgres_last_vacuum check_postgres_listener check_postgres_locks check_postgres_logfile check_postgres_new_version_bc check_postgres_new_version_box check_postgres_new_version_cp check_postgres_new_version_pg check_postgres_new_version_tnm check_postgres_pgagent_jobs check_postgres_pgb_pool_cl_active check_postgres_pgb_pool_cl_waiting check_postgres_pgb_pool_maxwait check_postgres_pgb_pool_sv_active check_postgres_pgb_pool_sv_idle check_postgres_pgb_pool_sv_login check_postgres_pgb_pool_sv_tested check_postgres_pgb_pool_sv_used check_postgres_pgbouncer_backends check_postgres_pgbouncer_checksum check_postgres_prepared_txns check_postgres_query_runtime check_postgres_query_time check_postgres_relation_size check_postgres_replicate_row check_postgres_replication_slots check_postgres_same_schema check_postgres_sequence check_postgres_settings_checksum check_postgres_slony_status check_postgres_table_size check_postgres_timesync check_postgres_total_relation_size check_postgres_txn_idle check_postgres_txn_time check_postgres_txn_wraparound check_postgres_version check_postgres_wal_files check_rabbitmq_aliveness check_rabbitmq_connections check_rabbitmq_objects check_rabbitmq_overview check_rabbitmq_partition check_rabbitmq_queue check_rabbitmq_server check_rabbitmq_shovels check_rabbitmq_watermark check_tradis_tags check_urdf checkapoppw checkbashism_tap checkbashisms checkbc checkbcphd checkbrack checkcites checkdigits checkdirfile checkflac checkgid checkinstall checkint checkisomd5 checkit_tiff checklink checklistings checkmail checkmk checkmodule checkndx checkpolicy checkpto checkpw checkqv checkqvphd checksctp checksec checkstyle checksub checktaxonnodes checktrans cheese cheetah-analyze3 cheetah-compile3 cheetah3 chem chemFoam chemdict_tool chemdiff chemeq chemkinToFoam chemps2 chemstruc chemtool cherryd3 cherrytree chewing-editor chewmail chezdav chezscheme chfn (1) - change real user name and information chg chi2 chiaki chiark-named-conf chiark-tcl-applet-wrapper chibicc chicken chicken-do chicken-install chicken-profile chicken-status chicken-uninstall childCheckpwdwithPAM chilight chimeraslayer chipcard-tool chipcenter chipcor chipextract chippart chippeak chips chipscore chirp chirp_audit_cluster chirp_benchmark chirp_distribute chirp_fuse chirp_get chirp_put chirp_server chirp_server.old chirp_status chirp_stream_files chirpw chkboot chkboot-check chkboot-desktopalert chkcon chkconc chkdvifont chkfont chklref chkmpqcval chknvm chknvm2 chkpib chkpib2 chkstow chktest chktex chktri chktrust chkweb chm_http chmcmd-3.2.2 chmls-3.2.2 chmoddic choom (1) - display and adjust OOM-killer score. chooseLines choosewm chopper choqok chordii chotkeys chprop chpst chr_replace_sga.pl chrcvt65 chrom_sizes.pl chroma chroma-v2 chromad chromad-v2 chrome-gnome-shell chromedriver chromeos-tpm-recovery chromium chromium-shell chronic chronicle chronicle-entry-filter chronicle-ping chronicle-rss-importer chronicle-spooler chronyc chrootuid chrpath chrt (1) - manipulate the real-time attributes of a process chsh (1) - change login shell chsh.ldap cht chtMultiRegionFoam chtMultiRegionSimpleFoam chtMultiRegionTwoPhaseEulerFoam chuck chuck.alsa chuck.pulse ci cif-diff cif-drop cif-grep cif-merge cif-to-utf8 cif-validate cif2cbf cif2cell cif2cod cif2csv cif2hkl cif2json cif2pdb cif2rdf cif2ref cif2xyz cif_CODify cif_Fcalc cif_adjust_journal_name_volume cif_automorphism cif_bounding_box cif_cell_contents cif_classify cif_cod_check cif_cod_deposit cif_cod_numbers cif_compare_dics cif_correct_tags cif_create_AMCSD_pressure_temp_tags cif_ddl1_dic_check cif_ddlm_dic_check cif_ddlm_dic_print cif_dictionary_tags cif_diff cif_distances cif_estimate_Z cif_eval_numbers cif_fillcell cif_filter cif_find_duplicates cif_find_symmetry cif_fix_values cif_hkl_COD_number cif_hkl_check cif_linguist cif_list_tags cif_mark_disorder cif_merge cif_molecule cif_mpod_v1_to_v2 cif_mpod_v1_to_v3 cif_mpod_v2_to_v1 cif_mpod_v3_to_v1 cif_overlay cif_p1 cif_parse cif_reduce_Niggli cif_reduce_cell cif_reformat_AMCSD_author_names cif_reformat_pubmed_author_names cif_reformat_uppercase_author_names cif_select cif_set_value cif_sort_atoms cif_split cif_split_primitive cif_symop_apply cif_tags_in_list cif_tcod_tree cif_validate cif_values cifparse cifscreds cifsdd cifsiostat cifvalues cil cinder cinder-api cinder-backup cinder-manage cinder-rootwrap cinder-rtstool cinder-scheduler cinder-status cinder-volume cinder-volume-usage-audit cinder-wsgi cindex cinnamon cinnamon-calendar-server cinnamon-close-dialog cinnamon-control-center cinnamon-dbus-command cinnamon-desktop-editor cinnamon-display-changes-dialog cinnamon-file-dialog cinnamon-hover-click cinnamon-install-spice cinnamon-json-makepot cinnamon-killer-daemon cinnamon-launcher cinnamon-looking-glass cinnamon-menu-editor cinnamon-preview-gtk-theme cinnamon-screensaver cinnamon-screensaver-command cinnamon-screensaver-lock-dialog cinnamon-session cinnamon-session-cinnamon cinnamon-session-cinnamon2d cinnamon-session-quit cinnamon-settings cinnamon-settings-users cinnamon-slideshow cinnamon-spice-updater cinnamon-subprocess-wrapper cinnamon-unlock-desktop cinnamon-xlet-makepot cinnamon2d ciptool (1) - Bluetooth Common ISDN Access Profile (CIP) circlator circle-be circle-fe-term circle-parse-eventdump circle-parse-yamllog circo (1) - filter for circular layout of graphs circos circuits.bench3 circuits.web3 cirdna cisco-decrypt cisco7crack cistopbm citadel citnames citydecoder citygmltest civetweb cjb2 cjet cjk-gs-integrate cjpeg cjpeg_hdr cjs cjs-console cjxl ck ckati ckb-next ckb-next-daemon ckb-next-dev-detect ckbcomp ckbcomp-mini ckbuilder ckd2cckd ckeygen3 ckon ckport cksfv cksum (1) - compute and verify file checksums cl cl-launch cl65 clFFT-client cl_respawn cl_status clamassassin clamav-config clambc clamconf clamdscan clamdtop clamfs clamscan clamsubmit clamtk clamz clang clang++ clang++-13 clang++-14 clang++-15 clang-13 clang-14 clang-15 clang-apply-replacements clang-apply-replacements-13 clang-apply-replacements-14 clang-apply-replacements-15 clang-change-namespace-13 clang-change-namespace-14 clang-change-namespace-15 clang-check clang-check-13 clang-check-14 clang-check-15 clang-cl-13 clang-cl-14 clang-cl-15 clang-cpp-13 clang-cpp-14 clang-cpp-15 clang-doc-13 clang-doc-14 clang-doc-15 clang-extdef-mapping-13 clang-extdef-mapping-14 clang-extdef-mapping-15 clang-format clang-format-13 clang-format-14 clang-format-15 clang-format-diff clang-format-diff-13 clang-format-diff-14 clang-format-diff-15 clang-include-fixer-13 clang-include-fixer-14 clang-include-fixer-15 clang-linker-wrapper-14 clang-linker-wrapper-15 clang-move-13 clang-move-14 clang-move-15 clang-nvlink-wrapper-14 clang-nvlink-wrapper-15 clang-offload-bundler-13 clang-offload-bundler-14 clang-offload-bundler-15 clang-offload-packager-15 clang-offload-wrapper-13 clang-offload-wrapper-14 clang-offload-wrapper-15 clang-pseudo-15 clang-query clang-query-13 clang-query-14 clang-query-15 clang-refactor-13 clang-refactor-14 clang-refactor-15 clang-rename-13 clang-rename-14 clang-rename-15 clang-reorder-fields-13 clang-reorder-fields-14 clang-reorder-fields-15 clang-repl-13 clang-repl-14 clang-repl-15 clang-scan-deps-13 clang-scan-deps-14 clang-scan-deps-15 clang-tidy clang-tidy-13 clang-tidy-14 clang-tidy-15 clang-tidy-diff clang-tidy-diff-13.py clang-tidy-diff-14.py clang-tidy-diff-15.py clangd clangd-13 clangd-14 clangd-15 clapper clash clashi clasp class-11d.x class-4d.x class-5d.x class-6d.x class.x classicladder classified-ads classifier_tester claw-config clawsker clazy clazy-standalone clblast_test_xamax clblast_test_xasum clblast_test_xaxpy clblast_test_xaxpybatched clblast_test_xcol2im clblast_test_xconvgemm clblast_test_xcopy clblast_test_xdot clblast_test_xdotc clblast_test_xdotu clblast_test_xgbmv clblast_test_xgemm clblast_test_xgemmbatched clblast_test_xgemmstridedbatched clblast_test_xgemv clblast_test_xger clblast_test_xgerc clblast_test_xgeru clblast_test_xhad clblast_test_xhbmv clblast_test_xhemm clblast_test_xhemv clblast_test_xher clblast_test_xher2 clblast_test_xher2k clblast_test_xherk clblast_test_xhpmv clblast_test_xhpr clblast_test_xhpr2 clblast_test_xim2col clblast_test_xnrm2 clblast_test_xomatcopy clblast_test_xsbmv clblast_test_xscal clblast_test_xspmv clblast_test_xspr clblast_test_xspr2 clblast_test_xswap clblast_test_xsymm clblast_test_xsymv clblast_test_xsyr clblast_test_xsyr2 clblast_test_xsyr2k clblast_test_xsyrk clblast_test_xtbmv clblast_test_xtpmv clblast_test_xtrmm clblast_test_xtrmv clblast_test_xtrsm clblast_test_xtrsv clblast_tuner_copy_fast clblast_tuner_copy_pad clblast_tuner_invert clblast_tuner_routine_xgemm clblast_tuner_routine_xtrsv clblast_tuner_transpose_fast clblast_tuner_transpose_pad clblast_tuner_xaxpy clblast_tuner_xconvgemm clblast_tuner_xdot clblast_tuner_xgemm clblast_tuner_xgemm_direct clblast_tuner_xgemv clblast_tuner_xger cldrparser-3.2.2 cldump cleanPolishes clean_genes cleanasn cleancss cleanlinks cleanup-blastdb-volumes cleanup_digikamdb clear (1) - clear the terminal screen clear (3ncurses) - clear all or part of a curses window clear_console (1) - clear the console clearcut clementine clementine-tagreader cleo clevercsv clevis clevis-decrypt clevis-decrypt-sss clevis-decrypt-tang clevis-decrypt-tpm2 clevis-encrypt-sss clevis-encrypt-tang clevis-encrypt-tpm2 clevis-luks-bind clevis-luks-common-functions clevis-luks-edit clevis-luks-list clevis-luks-pass clevis-luks-regen clevis-luks-report clevis-luks-unbind clevis-luks-unlock clex clfdomainsplit clfmerge clfsplit clfswm clhep-config cli-generate cli-spinner click click-man clickhouse-benchmark clickhouse-client clickhouse-compressor clickhouse-copier clickhouse-format clickhouse-performance-test clinfo clingo clip clipaccumulate clipbrowse clipedit clipf clipfilter clipit clipit.real clipjoin clipman clippy-driver clips cliquer clirr clisp clisp-link clit clitest clm clmake clmake-short cloc clock_info clockdiff clog (3) - natural logarithm of a complex number clogin clojure1.10 clojurec1.10 clonalorigin clone_study closest-features closestBed closest_point closure-compiler cloud-id cloud-init cloud-init-per cloud-localds cloud_enum cloud_sql_proxy cloudflare-ddns cloudkitty cloudkitty-api cloudkitty-dbsync cloudkitty-processor cloudkitty-status cloudkitty-storage-init cloudkitty-writer cloudstack clp clpeak clstr2tree clstr_merge clstr_merge_noorder clstr_reduce clstr_renumber clstr_rev clstr_sort_by clstr_sort_prot_by clsync clubak cluset clush clustalo clustalw clustalx cluster (1) - find clusters in a graph and augment the graph with this information. clusterBed cluster_gff clusterdb clusterssh clutter-scan-immodules cluttex clxdo clyc clzip cm108 cm2html cm2latex cm2man cm2pseudoxml cm2xetex cm2xml cm_to_wigeon cma_es.python cma_es.show_build_path cma_es.show_dist_paths cmake (1) - CMake Command-Line Reference cmake-annotate cmake-format cmake-genparsers cmake-gui cmake-lint cmalign cmark cmark-bkrs cmark-gfm cmatrix cmbuild cmcalibrate cmconvert cmdtest cme cmemit cmew cmfetch cmgen cmigemo cmis-client cml-to-smi cmp (1) - compare two files byte by byte cmp (1ssl) - OpenSSL application commands cmpfillin cmph cmpress cmscan cmsd cmsearch cmst cmstat cmsutil cmtime cmtk cmus cmus-remote cmuwmtopbm cmx2raw cmx2xhtml cnee cnid2_create cnt cntraining cntsh cnvgrib1to2 cnvgrib2to1 cnvkit cnvkit-cnv_annotate cnvkit-cnv_expression_correlate cnvkit-cnv_updater cnvkit-genome_instability_index cnvkit-guess_baits cnvkit-reference2targets cnvkit-skg_convert co co65 coalChemistryFoam coap-client coap-client-gnutls coap-client-notls coap-client-openssl coap-rd coap-rd-gnutls coap-rd-notls coap-rd-openssl coap-server coap-server-gnutls coap-server-notls coap-server-openssl coax cob-config cobc cobcrun cobertura-check cobertura-instrument cobertura-merge cobertura-report cobfusc cobol_count cobra-cli coccinella cockpit-bridge cococpp cococs cocoj cod-tools-version cod2rdf cod_fetch cod_manage_related codacheck codacmp codadd codadump codaeval codafind codcif2sdf codcmp codcopy code2html code_saturne codeblocks codecgen codecgraph codechanges codegroup codelite codelite-make codelite_fix_files codelite_open_helper codeml codepage codequery coderay coderet codes_bufr_filter codes_count codes_info codes_parser codes_split_file codespell codfis codiff codonw codonw-aau codonw-base3s codonw-bases codonw-cai codonw-cbi codonw-cu codonw-cutab codonw-cutot codonw-dinuc codonw-enc codonw-fop codonw-gc codonw-gc3s codonw-raau codonw-reader codonw-rscu codonw-tidy codonw-transl codxyz2fract codxyz2ortho coffee cog cogctl cohomcalg cohttp-curl-lwt cohttp-proxy-lwt cohttp-server-lwt coils-wrap coinst coinst-upgrades coinst_converter coinst_viewer col (1) - filter reverse line feeds from input col1 col2 col3 col4 col5 col6 col7 col8 col9 cola colcon colcrt (1) - filter nroff output for CRT previewing coldEngineFoam collapseEdges collapse_partials collateindex.pl collatinus collect collectd-nagios collectd-tg collectdctl collectl collectl2pcp collide collink colmap colmux color-chrs.pl color-picker color_matrix colorcet colordiff colordiff-git colored_dmesg colorfg colorhug-backlight colorhug-ccmx colorhug-cmd colorhug-flash colorhug-refresh colorit colorize colormake colormake-short colormap colormgr (1) - Color Manager Testing Tool colorsvn colortail colortest-16 colortest-16b colortest-256 colortest-8 colortest-python colplot colprof colrm (1) - remove columns from a file column (1) - columnate lists columns colverify com.github.akiraux.akira com.github.alecaddd.sequeler com.github.babluboy.bookworm com.github.jmoerman.go-for-it com.github.johnfactotum.Foliate com.github.muriloventuroso.easyssh com.github.phase1geo.minder com.github.rafostar.Clapper combine combine-dmk combineKmers combineMUMs combinePatchFaces combine_lang_model combine_tessdata combine_tradis_plots combinedeltarpm combinediff (1) - create a cumulative unified patch from two incremental patches combinesummaries combust comdraw comedi_board_info comedi_calibrate comedi_soft_calibrate comedi_test comet-ms comgt comicthumb comigrate comm (1) - compare two sorted files line by line command-not-found commander commit-partial commit-patch commit_agent commoncpp-config commonize compactsga compalign compare-im6.q16 compare-im6.q16hdri compareECL comparePolishes compare_2_profiles.pl compare_genomes compare_octrees compare_scheds comparepdf compel compface compileSpliceCands compile_encoding compile_et (1) - error table compiler compilebench compiler compiler_test compileserver-3.2.2 compiz compiz-boxmenu compiz-boxmenu-daemon compiz-boxmenu-dlist compiz-boxmenu-dplist compiz-boxmenu-editor compiz-boxmenu-vplist compiz-boxmenu-wlist compiz-decorator complementBed complexity Compose (5) - X client mappings for multi-key input sequences compose (1) - execute programs via entries in the mailcap file composeglyphs composer composite composite-im6.q16 composite-im6.q16hdri composite_rsr_plot compreffor compress (1) - compress and expand data compress_fast5 compressibleInterDyMFoam compressibleInterFilmFoam compressibleInterFoam compressibleMultiphaseInterFoam comprez comps2solv compseq compstruct comptext compton compton-conf compton-trans comptty computeBugHistory computeGCBias computeMatrix computeMatrixOperations computeMedians computeSensitivities compute_all compute_sloc_lang comterp comterp_run comtest concavity conch3 concordance condor_submit_makeflow condor_submit_workers conducti condure confclerk confget config-bundle-to-config config-gfarm config-gfarm-update config-gfsd config11 config2cfg config_data configurable-http-proxy configure-printer confuga_adm confusable_homoglyphs confy congruity conjugar conjugue conjugue-ISO-8859-1 conjugue-UTF-8 conjunct conjure conjure-im6.q16 conjure-im6.q16hdri conky conman conmen conmon conmux-attach conmux-console connect (2) - initiate a connection on a socket connect-EOAdaptor connect-proxy connect-tunnel connectome2tck connectomeedit connectomestats connman-gtk connman-ui-gtk connmanctl conpix consEntropy consambig console consolehelper consolehelper-gtk consolidate_genomicsdb_array conspy contactprintthemeeditor contactthemeeditor container container-shell containerd (8) - (unknown subject) containerd-shim containerd-shim-runc-v1 containerd-shim-runc-v2 containers-storage content-hub-send content-hub-service content-hub-test-exporter content-hub-test-importer content-hub-test-sharer context contextjit contigOverlaps contig_draw control_rancid convbin convbkmk convcal converseen convert convert-caffe2-to-onnx convert-dtsv0 convert-im6.q16 convert-im6.q16hdri convert-json convert-ly convert-onnx-to-caffe2 convert-sam-for-rsem convert2bed convert2blastmask convert2gpx convert2osm convert2syrthes4 convert4chan convertECL convertPolishes convertSamples convertToAtac convertToExtent convertXmlToText convert_bruker convert_coords convert_dataclass convert_image convert_location convert_octree convert_seq convert_to_should_syntax convert_trace convert_variables convert_vcf_to_features convertall convertdvbdb convertf convertfilestopdf convertfilestops convertformat convertgls2bib convertior convertkey convertsegfilestopdf convertsegfilestops converttopdf converttops convmv convmvfs cookiecutter cool-retro-term coolmail coordinateTranslate copac2xml copy-from-journal copy-to-journal copyBuggySource copycat copydatabase copydbf copylink copyq copyright-update coq-makefile-make-both-single-timing-files coq-makefile-make-both-time-files coq-makefile-make-one-time-file coq-planif-transition coq-tex coq-wanna-build coq_makefile coqc coqc.byte coqchk coqdep coqdoc coqide coqidetop.byte coqidetop.opt coqnative coqos_add coqos_info coqos_man coqos_mod coqos_rel coqpp coqproofworker.opt coqqueryworker.opt coqtacticworker.opt coqtags coqtop coqtop.byte coqtop.opt coqwc coqworkmgr coredhcp coredhcp-client coredhcp-generator coredumpctl coreinject corelist (1) - a commandline frontend to Module::CoreList corkscrew cormapy corona coronaspades coronaspades.py corosync-blackbox corosync-qnetd corosync-qnetd-certutil corosync-qnetd-tool corosync-vqsim corosync-xmlproc correctGCBias correct_abundances cosets coshp coturn count-13 count-14 count-15 count_extensions count_unknown_ext countperl countsga courier-config courierauthconfig couriermlm couriertls cover coverageBed coverage_to_topoview coveralls coverdump covertag coverview covtobed cow cow-shell cowbuilder-dist cowdancer-ilistcreate cowdancer-ilistdump cowpatty cowpoke coz cp.x cp2k cp2k.popt cp2k.psmp cp2k_shell cp2k_shell.psmp cpack (1) - CPack Command-Line Reference cpaldjvu cpan (1) - easily interact with CPAN from the command line cpan-audit cpan-listchanges cpan-outdated cpan-upload cpan2deb cpan2dist cpan2doap cpan2dsc cpan5.36-x86_64-linux-gnu (1) - easily interact with CPAN from the command line cpancover cpandb cpanel_json_xs (1p) - Cpanel::JSON::XS commandline utility cpanfile-dump cpangraph cpaninject cpanm cpanp cpanp-run-perl cpansign cpants_lint cpbm cpchop cpchop_depthtrend cpclean cpdic cpeGui cpfind cpgplot cpgreport cph cphead cphist cpif cpigs cpio-filter cpipe cplay-ng cpluff-console cpluff-loader cpm cpmchattr cpmchmod cpmcp cpmls cpmrm cpp cpp-10 cpp-11 cpp-12 cppcheck cppcheck-gui cppcheck-htmlreport cpphs cpphs-hugs cpplint cppo cppo-json cppp.x cpr cpregularize cproto cpsv cpu-info cpu-x cpufetch cpufreq-aperf cpufreq-info cpufreq-selector cpufreq-set cpufreqd-get cpufreqd-set cpuid (4) - x86 CPUID access device cpuid-dump cpuid_tool cpuinfo2cpuid cpulimit cpupower cputool cqmakedb cqrlog cqsearch crac crac-client crac-index crackNum cram3 cram_dump cram_filter cram_index cram_size cramfsswap (1) - swap endianness of a cram filesystem (cramfs) crash crashexport crashgetnode crashlist crashlistout crashmail crashmaint crashme crashstats crashwrite crasm crb-blast crc32 (1) - compute CRC-32 checksums for the given files crc32js cream create-cpmdb create-kxd-config create-native-map createBackboneMFA createBaffles createBoxTurb createExternalCoupledPatchGeometry createPYMB createPatch createZeroDirectory create_Drop-seq_reference_metadata.sh create_any_bitmap create_bmp_for_circ_in_circ create_bmp_for_circ_in_rect create_bmp_for_microstrip_coupler create_bmp_for_rect_cen_in_rect create_bmp_for_rect_cen_in_rect_coupler create_bmp_for_rect_in_circ create_bmp_for_rect_in_rect create_bmp_for_stripline_coupler create_bmp_for_symmetrical_stripline create_coverage_h5_file create_cvsignore create_gcov create_genomicsdb_workspace create_greyscale_module create_llvm_prof create_makefile create_makefiles create_matrix create_pan_genome create_pan_genome_plots create_print_entry create_svnignore create_zoomed_maps createcats createdb createfp createhdf createlang createrepo_c createsummary createuser creddump7 credential-sheets creduce cregexport creginfo cregmount crfreq cricket-compile crip crit critcl critterding crlf crlupdate crlutil crm crmgr cronic cronolog cronometer cronosplit crontab (1) - maintain crontab files for individual users (Vixie Cron) crontab (5) - tables for driving cron cross-gcc-gensource crossgrade-package-check crossgrader crossystem crsh crtsv crudini cruft cruft-ng crun crunch crunchjpgs crushtool crxdic crxgram cryfs cryfs-unmount crypt (3) - passphrase hashing crypt (5) - storage format for hashed passphrases and available hashing methods crypt-xordataexchange cryptdir cryptest cryptmount cryptoflex-tool cryptominisat cryptominisat5 cryptominisat5_simple cryptominisat_simple crys3d.model_viewer crys3d.python crys3d.qttbx.view_structure crys3d.show_build_path crys3d.show_dist_paths crystal crystal-facet-uml cs cs2cs csanalyze csb-bfit csb-bfite csb-buildhmm csb-csfrag csb-embd csb-hhfrag csb-hhsearch csb-precision csb-promix csb-test csb2format csb64enc csbeats csblogin csc cscope cscope-indexer csd-a11y-settings csd-automount csd-background csd-backlight-helper csd-clipboard csd-color csd-datetime-mechanism csd-housekeeping csd-input-helper csd-keyboard csd-list-wacom csd-locate-pointer csd-media-keys csd-power csd-print-notifications csd-printer csd-screensaver-proxy csd-smartcard csd-wacom csd-xsettings csdebugger csdp csdp-complement csdp-graphtoprob csdp-randgraph csdp-theta csdpcert csearch csepdjvu cset csf_parser csftp csg_boltzmann csg_call csg_density csg_dlptopol csg_dump csg_fluctuations csg_fmatch csg_gmxtopol csg_imc_solve csg_inverse csg_map csg_orientcorr csg_part_dist csg_partial_rdf csg_property csg_radii csg_resample csg_reupdate csg_sphericalorder csg_stat csg_traj_force csh_count csharp cshost csi csl_unsorted cslatex csmith csound csound_extract csoundqt csp_install csp_mkdircp csp_scp_keep_mode csp_sucp csplain csplit (1) - split a file into sections determined by context lines cspmonitor csr css-beautify-js css2xslfo csscapture_py3 csscombine_py3 cssdiff cssh cssmerge cssmin cssort cssparse_py3 cssrancid csstidy cssutil cst cstest cstocs cstool cstr cstream csv2 csv2json csv2kml csv2latex csv2mipe csv2ods csv2pdf csv2po csv2pskc csv2rdf (1) - converts CSV to RDF csv2rec csv2tbx csv2tsv csv2yapet csvSelect csv_to_gene_db csvclean (1) - manual page for csvclean 1.0.7 csvcut (1) - manual page for csvcut 1.0.7 csvfilt csvformat (1) - manual page for csvformat 1.0.7 csvgrep (1) - manual page for csvgrep 1.0.7 csvjoin (1) - manual page for csvjoin 1.0.7 csvjson (1) - manual page for csvjson 1.0.7 csvlook (1) - manual page for csvlook 1.0.7 csvmidi csvpy (1) - manual page for csvpy 1.0.7 csvsort (1) - manual page for csvsort 1.0.7 csvsql (1) - manual page for csvsql 1.0.7 csvstack (1) - manual page for csvstack 1.0.7 csvstat (1) - manual page for csvstat 1.0.7 csvtool csysdig ct2util ct_run ctags-exuberant ctags-universal ctags.emacs ctail ctan-o-mat ctanbib ctangle ctanglex ctanify ctanupload ctdb ctdb_diagnostics ctel ctemplate-diff_tpl_auto_escape ctemplate-make_tpl_varnames_h ctemplate-template-converter ctest (1) - CTest Command-Line Reference ctext2pgm cthumb ctie ctlib ctmconv ctmviewer ctn_version ctndisp ctnnetwork ctorrent ctow ctpl ctr (8) - (unknown subject) ctr-remote ctracer ctrans ctsim ctsimtext ctstat (8) - unified linux network statistics ctwill ctwill-refsort ctwill-twinx ctwm cu cube2font cubemap cubeview cucumber cudf-check cudf-parse-822 cudf2lp cuebreakpoints cueconvert cueprint cuetag cufilter cumulativeDisplacement cundecl cunloop cup cupdatecursor cupp cupp3 cups-calibrate cups-config cupstestppd (1) - test conformance of ppd files (deprecated) cupt cura curator curator_cli curconvd curl (1) - transfer a URL curl-config curlpp-config curtain curve_geometry curvecpclient curvecpmakekey curvecpmessage curvecpprintkey curvecpserver cusp custodia-cli cut (1) - remove sections from each line of files cut-range cut3d cutadapt cuteSV cutecom cutefish-clipboard cutefish-cpufreq cutefish-gmenuproxy cutefish-notificationd cutefish-polkit-agent cutefish-powerman cutefish-screen-brightness cutefish-sddm-helper cutefish-session cutefish-settings-daemon cutefish-shutdown cutefish-xembedsniproxy cutest cutgextract cutsel cutseq cuttlefish cutycapt cuum cvanal cvc-create cvc-print cvc4 cvd_calibrate cvd_display_image cvd_video_play_source cvdupdate cve cvise cvise-delta cvlc cvm-benchclient cvm-chain cvm-checkpassword cvm-mysql cvm-mysql-local cvm-mysql-udp cvm-pgsql cvm-pgsql-local cvm-pgsql-udp cvm-pwfile cvm-qmail cvm-testclient cvm-unix cvm-v1benchclient cvm-v1checkpassword cvm-v1testclient cvm-vmailmgr cvm-vmailmgr-local cvm-vmailmgr-udp cvmsh2 cvs cvs-adjustroot cvs-buildpackage cvs-clean cvs-debc cvs-debi cvs-debrelease cvs-debuild cvs-fast-export cvs-inject cvs-mailcommit cvs-repomove cvs-switchroot cvs-upgrade cvsaddcurrentdir cvsaskpass cvsbackport cvsblame cvscheck cvsconvert cvsdelta cvsforwardport cvsgraph cvslastchange cvslastlog cvsmgdiff cvsps cvsrevertlast cvsservice5 cvssync cvsversion cvt (1) - calculate VESA CVT mode lines cvtenc cvtsudoers (1) - convert between sudoers file formats cw cwcp cwddel cwdreg cweave cweavex cwebp cwgen cwhois cwl-explode cwl-format cwl-upgrader cwltool cwm cwnntouch cws-11d.x cws-4d.x cws-5d.x cws-6d.x cws.x cx18-ctl cxf2ti3 cxi.image2pickle cxi.image_average cxl cxpm cxref cxref-cc cxref-cpp cxref-cpp-configure cxref-cpp.upstream cxref-query cxxcom cxxmetric cxxtestgen cxxtools-config cxxtz cyborg cycfx2prog cycl cyclicdeadline cyclictest cyclograph cygdb3 cylc cyr cyradm cyrx cysignals-CSI cython3 cyvcf2 czap d-devlibdeps d-feet d-shlibmove d48 d52 da65 daa2iso dablin dablin_gtk dachs dact dadadodo daemon (3) - run in the background daemonize daemonlogger dafny daily-openstack-debian-image dailystrips dailystrips-clean dailystrips-update daisy-player daligner damapper dan dancer dancer2 danetool danmaQ dap-config dap-config-pkgconfig daphne dapltest daps daps-autobuild daps-check-deps daps-init daps-xmlformat daptup daq-modules-config dar dar_cp dar_cp_static dar_manager dar_slave dar_split dar_static dar_xform dares darkice darknet darkradiant darkslide darksnow darktable darktable-chart darktable-cli darktable-cltest darktable-cmstest darktable-generate-cache darktable-rs-identify darnwdl darts dasdcat dasdconv dasdcopy dasdinit dasdisup dasdlist dasdload dasdls dasdpdsu dasdseq dasher dask-scheduler dask-ssh dask-worker dasm dat dat2c dat2s datToFoam data2inc-3.2.2 datacopy datadriven-clear datalad datamash datastore-service dataurl date@ datefudge dateparser-download dateutils.dadd dateutils.dconv dateutils.ddiff dateutils.dgrep dateutils.dround dateutils.dseq dateutils.dsort dateutils.dtest dateutils.dzone dateutils.strptime datum_strip dav dav1d dave davix-cp davix-get davix-http davix-ls davix-mkdir davix-mv davix-put davix-rm davix-tester davix-unit-tests davmail davpass davs2 davserver3 dawg dawg2wordlist dawgdic-build dawgdic-find daxctl daxio dazcon dazzle-list-counters db2dvi db2html db2pdf db2ps db2rtf db2x_manxml db2x_texixml db2x_xsltproc db4-2-db5 db4otool db5-valid db5.3_archive db5.3_checkpoint db5.3_deadlock db5.3_dump db5.3_hotbackup db5.3_load db5.3_log_verify db5.3_printlog db5.3_recover db5.3_replicate db5.3_sql db5.3_stat db5.3_upgrade db5.3_verify db_archive db_bench db_checkpoint db_deadlock db_dump db_dump185 db_hotbackup db_load db_log_verify db_printlog db_recover db_replicate db_stat db_upgrade db_verify dba dbar dbclient dbd dbeacon dbf-rb dbf2mysql dbf_dump dbfadd dbfcat dbfcreate dbfcstocs dbfdump dbfinfo dbfutil1 dbfxtrct dbgh5 dbginfo dbiblast dbic_form_generator dbicadmin dbicdump dbifasta dbiflat dbigcg dbilogstrip (1p) - filter to normalize DBI trace logs for diff'ing dbiprof (1p) - command-line client for DBI::ProfileData dbiproxy (1p) - A proxy server for the DBD::Proxy driver dblatex dblook dbpmda dbs_dumptabdata dbs_dumptabstruct dbs_empty dbs_printtab dbs_update dbscan dbsessmgr dbsessmgr4 dbtell dbtoepub dbus-binding-tool dbus-broker dbus-broker-launch dbus-cleanup-sockets (1) - clean up leftover sockets in a directory dbus-cppc dbus-daemon (1) - Message bus daemon dbus-hslogger-client dbus-interface-diff dbus-interface-vcs-helper dbus-launch (1) - Utility to start a message bus from a shell script dbus-monitor (1) - debug probe to print message bus messages dbus-run-session (1) - start a process as a new D-Bus session dbus-send (1) - Send a message to a message bus dbus-test-runner dbus-test-tool dbus-update-activation-environment (1) - update environment used for D-Bus session services dbus-uuidgen (1) - Utility to generate UUIDs dbusxx-introspect dbusxx-xml2cpp dbview dbwrap_tool dbwtest dbxcompress dbxedam dbxfasta dbxflat dbxgcg dbxobo dbxreport dbxresource dbxstat dbxtax dbxtool dbxuncompress dc dc-tool dc1394_reset_bus dc3dd dcadec dccleancrw dccp dcdirdmp dcdump dcentvfy dcfile dcfldd dcfujigreen dcfujiturn dcfujiturn16 dch dch-repeat dchist dciodvfy dckey dcl2inc dclconfig dclfrt dclock dcm2json dcm2mnc dcm2niibatch dcm2niix dcm2pdf dcm2pnm dcm2xml dcm_add_fragments dcm_create_object dcm_ctnto10 dcm_diff dcm_dump_compressed dcm_dump_element dcm_dump_file dcm_make_object dcm_map_to_8 dcm_mask_image dcm_modify_elements dcm_modify_object dcm_print_dictionary dcm_resize dcm_rm_element dcm_rm_group dcm_snoop dcm_strip_odd_groups dcm_template dcm_to_html dcm_to_text dcm_verify dcm_vr_patterns dcm_x_disp dcmcjpeg dcmcjpls dcmconv dcmcrle dcmd dcmdjpeg dcmdjpls dcmdrle dcmdspfn dcmdump dcmedit dcmftest dcmgpdir dcmicmp dcminfo dcmj2pnm dcml2pnm dcmmkcrv dcmmkdir dcmmklut dcmodify dcmp2pgm dcmprscp dcmprscu dcmpschk dcmpsmk dcmpsprt dcmpsrcv dcmpssnd dcmqridx dcmqrscp dcmqrti dcmquant dcmrecv dcmscale dcmsend dcmsign dcmstack dcod2lum dconf (1) - Simple tool for manipulating a dconf database dconf (7) - A configuration system dconf-editor dconvlum dcparse dcposn dcrack dcraw dcraw2hdrgen dcraw_emu dcraw_half dcsort dcsrdump dcstats dctable dctopgm8 dctopgx dctopnm dcunrgb dcut dd-list ddate ddbd ddbugtopbm ddccontrol ddcmon ddcui ddcutil ddd dde-calendar dde-store ddgr ddir ddjvu ddl1-to-ddlm ddlm_validate ddpt ddpt_sgl ddptctl ddrescue ddrescuelog ddrescueview ddru_diskutility ddru_findbad ddru_ntfsbitmap ddru_ntfsfindbad ddrutility dds-dd dds2index dds2tar ddsperf ddstdecode ddstool ddtc ddupdate ddupdate-config ddv de-gfm de4dot deadline_test deallocvt deb-auto-backport deb-enable-rrr deb-fix-build deb-gview deb-import-uncommitted deb-janitor deb-new-upstream deb-reversion deb-scrub-obsolete deb-systemd-helper (1p) - subset of systemctl for machines not running systemd deb-systemd-invoke (1p) - wrapper around systemctl, respecting policy-rc.d deb-why-removed deb2solv deb3 debarchiver debaux-build debaux-publish debbisect debc debcargo debchange debcheck-node-repo debcheckout debci debclean debcommit debconf (1) - run a debconf-using program debconf-apt-progress (1) - install packages using debconf to display a progress bar debconf-communicate (1) - communicate with debconf debconf-copydb (1) - copy a debconf database debconf-escape (1) - helper when working with debconf's escape capability debconf-get-selections debconf-getlang debconf-gettextize debconf-kde-helper debconf-loadtemplate debconf-mergetemplate debconf-set-selections (1) - insert new values into the debconf database debconf-show (1) - query the debconf database debconf-updatepo debdate debdelta debdelta-upgrade debdeltas debdiff debdiff-apply debfoster debget debi debian-builder debian-distro-info debian-edu-copy-pki debian-edu-ldapserver debian-reference debian-rime-processor debianbts debiandoc2dbk debiandoc2dvi debiandoc2html debiandoc2info debiandoc2latex debiandoc2latexdvi debiandoc2latexpdf debiandoc2latexps debiandoc2pdf debiandoc2ps debiandoc2texinfo debiandoc2text debiandoc2textov debiandoc2wiki debianize debianize-vdrplugin debiman debiman-auxserver debiman-idx2rwmap debiman-minisrv debmake debman debmany debmirror debocker debootsnap deborphan debos debpatch debpear debpkg debrebuild debrelease debrepro debroster debrsign debruijn debsecan debsig-verify debsign debsigs debsigs-autosign debsigs-installer debsigs-signchanges debsnap debspawn debsums debtags debtree debug-me debugapp debugedit (1) - debug source path manipulation tool debuginfod debuginfod-find debuglevel debugperl debugviewer debuild debuild-pbuilder dec-tr-stat deck declone decode-dimms decode-edid decode-vaio decode_and_encode decode_aprs decode_emimsg decode_teergrube decode_tm6000 decodemail (1) - decode messages. decolor decomment decomposePar decopy decorate decryptdir decvpp_tool dedupe.sh dee-tool deep deepin-album deepin-boot-maker deepin-calculator deepin-deb-installer deepin-deb-installer-dependsInstall deepin-desktop-ts-convert deepin-generate-mo deepin-image-viewer deepin-log-viewer deepin-menu deepin-movie deepin-music deepin-picker deepin-policy-ts-convert deepin-screen-recorder deepin-shortcut-viewer deepin-terminal deepin-update-pot deepnano_basecall deepnano_basecall_no_metrichor deeptools defaults defcolors defectDensity defid deflate-js defmt-c defmt-sh defncopy deformedGeom degapseq deghosting_mask degrep deheader dehtmldiff (1) - get usable diff from an HTML page dehydrated deillustrate deja-dup deken del-node-component delaunay (1) - constructs the constrained Delaunay triangulation of the input delay delcr deletall deletepdfpage delhead deliverquota.courier delly delp-3.2.2 delpart (8) - tell the kernel to forget about a partition delta-filter delta2blocks delta2maf delta_filter_wrapper.py deltablast deltadb_query deltadb_upgrade_log deltainfoxml2solv deluge deluge-console deluge-gtk deluge-web deluged delv (1) - DNS lookup and validation utility delwcs delwords demandoc demux demux_fast5 dendropy-format denemo denemo_file_update densify-Bragg density density-fitness denss.align.py denss.align2xyz.py denss.align_and_average.py denss.align_by_principal_axes.py denss.all.py denss.average.py denss.calcfsc.py denss.fit_data.py denss.get_info.py denss.mrcops.py denss.pdb2mrc.py denss.py denss.refine.py denss.rho2dat.py dep12-validate dep3changelog depdiagram_generate_all depinfo deploy_to_remote_sandboxes depqbf depthOfPolishes depthchargectl depythontex der2dmk derailed derb derbyctl derdump descseq design_coupler designate-agent designate-api designate-api-wsgi designate-central designate-manage designate-mdns designate-producer designate-rootwrap designate-sink designate-status designate-worker designer desktop-autoloader desktop-check-mime-types desktop-file-edit (1) - Installation and edition of desktop files desktop-file-install (1) - Installation and edition of desktop files desktop-file-validate (1) - Validate desktop entry files desktop2menu desktopfolder desktoptojson (8) - Converts a .desktop file to a .json file. desproxy desproxy-dns desproxy-inetd desproxy-socksserver detachtty detect-requirements detectChimera detectchain detector2nexus determine-phred determine_maximum_mpps detex detok detox deurlname dev.dxtbx.debug_memory dev.dxtbx.read_sequence dev.tchx84.Portfolio dev_debug_vboot devcal devdump devede developers-reference devhelp device-info device2grub devilspie devilspie2 devio devmon devnag devtodo devweb deweb dewoff dex dexdump dexdump2 dexlist dexqv dexta dextract dfa2dot dfbdump dfbdumpinput dfbfx dfbg dfbinfo dfbinput dfbinspector dfblayer dfbmaster dfbpenmount dfbplay dfbscreen dfbshow dfbswitch dfc dfcgen-gtk dfgrep dfits dfont2res dfrs dfu-prefix dfu-programmer dfu-suffix dfu-tool dfu-util dfuse-pack dgedit dget dggath dggath-int32 dggath-int64 dggath-long dgit dgit-badcommit-fixup dgit-mirror-rsync dgit-mirror-ssh-wrap dgit-repos-admin-debian dgit-repos-policy-debian dgit-repos-policy-trusting dgit-repos-server dgit-ssh-dispatch dglob dgmap dgmap-int32 dgmap-int64 dgmap-long dgnova dgord dgord-int32 dgord-int64 dgord-long dgpart dgpart-int32 dgpart-int64 dgpart-long dgrep dgscat dgscat-int32 dgscat-int64 dgscat-long dgt dgtst dgtst-int32 dgtst-int64 dgtst-long dgvalidator dh dh-dzil-refresh dh-exec dh-make-R dh-make-elpa dh-make-golang dh-make-node dh-make-perl dh-make-raku dh-make-ruby dh-update-R dh_acc dh_apache2 dh_apparmor dh_aspell-simple dh_assistant dh_asterisk dh_auto_build dh_auto_build_nant dh_auto_clean dh_auto_clean_nant dh_auto_configure dh_auto_install dh_auto_test dh_autoreconf dh_autoreconf_clean dh_autotools-dev_restoreconfig (1) - restore config.sub and config.guess dh_autotools-dev_updateconfig (1) - update config.sub and config.guess dh_bash-completion (1) - install bash completions for package dh_bugfiles dh_builddeb dh_buildinfo dh_clean dh_click dh_clideps dh_clifixperms dh_cligacpolicy dh_clistrip dh_cmake_install dh_cme_upgrade dh_compress dh_configpackage dh_consoledata dh_coq dh_cpack_generate dh_cpack_install dh_cpack_substvars dh_ctest_build dh_ctest_clean dh_ctest_configure dh_ctest_start dh_ctest_submit dh_ctest_test dh_ctest_update dh_di_kernel_gencontrol dh_di_kernel_install dh_di_numbers dh_dist_zilla_origtar dh_dkms dh_doxygen (1) - helps with packaging doxygen-generated documentation dh_dwz dh_dzil_build dh_dzil_clean dh_elpa dh_elpa_test dh_fixperms dh_fortran_mod dh_gencontrol dh_germinate_clean dh_germinate_metapackage dh_girepository dh_gnome dh_gnome_clean dh_gnustep dh_golang dh_golang_autopkgtest dh_gstscancodecs dh_haskell_blurbs dh_haskell_compiler dh_haskell_depends dh_haskell_depends_cabal dh_haskell_depends_haddock dh_haskell_depends_hugs dh_haskell_description dh_haskell_extra_depends_ghc dh_haskell_install_development_libs dh_haskell_install_ghc_registration dh_haskell_install_haddock dh_haskell_install_htmldocs dh_haskell_install_profiling_libs dh_haskell_provides dh_haskell_provides_ghc dh_haskell_recommends_documentation_references dh_haskell_shlibdeps dh_haskell_suggests dh_icons dh_install dh_installalternatives dh_installcatalogs dh_installchangelogs dh_installcliframework dh_installcligac dh_installcron dh_installdeb dh_installdebconf dh_installdirs dh_installdocs dh_installemacsen dh_installexamples dh_installgsettings dh_installifupdown dh_installinfo dh_installinit dh_installinitramfs dh_installlogcheck dh_installlogrotate dh_installman dh_installmanpages dh_installmenu dh_installmime dh_installmodules dh_installnss dh_installpam dh_installppp dh_installsystemd dh_installsystemduser dh_installsysusers dh_installtex dh_installtmpfiles dh_installudev dh_installwm dh_installxfonts dh_installxmlcatalogs (1) - install and register XML catalog files dh_installxsp dh_installyorick dh_kodiaddon_depends dh_libva dh_link dh_linktree dh_lintian dh_lisp dh_listpackages dh_lua dh_make dh_make_pgxs dh_makeclilibs dh_makefont dh_makeshlibs dh_md5sums dh_missing dh_mkdocs dh_movefiles dh_movelibkdeinit dh_nginx dh_nodejs_autodocs dh_nodejs_build_debug_package dh_nodejs_substvars dh_numpy3 dh_ocaml dh_ocamlclean dh_ocamldoc dh_ocamlinit dh_octave_changelogs dh_octave_check dh_octave_clean dh_octave_examples dh_octave_make dh_octave_substvar dh_octave_version dh_pdl dh_perl dh_perl6_depsfile dh_perl6_maintscript dh_perl6_test dh_perl_dbi (1) - add dependencies required for DBI modules dh_perl_imager dh_perl_openssl (1) - add dependencies required for OpenSSL modules dh_pgxs_test dh_php dh_phpcomposer dh_phppear dh_pidgin dh_ppp dh_prep dh_puredata_substvar dh_pyppd dh_python3 dh_python3-ply (1) - generate versioned dependencies on python3-ply dh_qmlcdeps dh_quilt_patch dh_quilt_unpatch dh_raku_build dh_raku_install dh_raku_test dh_rebar dh_ruby dh_ruby_fixdepends dh_ruby_fixdocs dh_runit dh_sameversiondep dh_scour dh_shlibdeps dh_sip3 dh_sodeps dh_sphinxdoc dh_strip dh_strip_nondeterminism dh_systemd_enable dh_systemd_start dh_sysuser dh_testdir dh_testroot dh_ucf dh_update_autotools_config dh_usrlocal dh_uwsgi dh_vagrant_plugin dh_vdrplugin_depends dh_vdrplugin_enable dh_vignette dh_vim-addon dh_virtualenv dh_webext dh_xine dh_xsf_substvars dh_xul-ext dh_zathura dhamma dhav2mkv dhcp_lease_time dhcp_release dhcp_release6 dhcpcd-gtk dhcpcd-online dhcpd-pools dhcpig dhcpstarv dhelp dhex dhomepage dht dhtnode di di-netboot-assistant dia dia2code diadia diagram-viewer diagtool-13 diagtool-14 diagtool-15 dial_tone dialect dialign-tx dialign2-2 dialog dials.data dialyzer diameterc diamond diamond-aligner dianara diatheke dib-lint dib-run-parts dib3000-watch dic2markdown dicar dicelab diceware dico dicod dicodconfig dicom_echo dicomdump dicomfind dicomhead dicomimageviewer dicompull dicomscope dicomtocsv dicomtodicom dicomtonifti dicp dict dict_lookup dictconv dictfmt dictfmt_index2suffix dictfmt_index2word diction dictl dictunformat dictunzip dictzcat dictzip didiwiki dieharder diff (1) - compare files line by line diff.scm diff2patches diff2php diff3 (1) - compare three files line by line diff_map diff_tomo diffeet difference diffimg (1) - Calculates intersection between two images diffmon diffoscope diffpdf diffpos diffpp diffseq diffstat (1) - make histogram from diff-output diffuse dig (1) - DNS lookup utility digikam digitaglinktree digitemp_DS9097 digitemp_DS9097U digraph digup dijitso dijkstra (1) - single-source distance filter for Graphviz dillo dillo-install-hyphenation dimacs-solver dimacs-to-lgf dimbl dimstrap din din-wrapper ding dinifti dino-im diodon dioptas dipole dipy_align_affine dipy_align_syn dipy_apply_transform dipy_buan_lmm dipy_buan_profiles dipy_buan_shapes dipy_correct_motion dipy_denoise_lpca dipy_denoise_mppca dipy_denoise_nlmeans dipy_denoise_patch2self dipy_fetch dipy_fit_csa dipy_fit_csd dipy_fit_dki dipy_fit_dti dipy_fit_ivim dipy_fit_mapmri dipy_gibbs_ringing dipy_horizon dipy_info dipy_labelsbundles dipy_mask dipy_median_otsu dipy_recobundles dipy_reslice dipy_slr dipy_snr_in_cc dipy_split dipy_track dipy_track_pft dir2ogg dir2slideshow dir2vclt dirb dirb-gendict dircolors (1) - color setup for ls dirconv dircproxy dircproxy-crypt dirdiff directfb-csource directomatic directvnc directvnc-xmapconv direnv direvent direwolf dirfile2ascii dirflip dirgen dirhash dirmerge dirmngr (8) - GnuPG's network access daemon dirmngr-client (1) - Tool to access the Dirmngr services dirname (1) - strip last component from file name dirname (3) - parse pathname components dirorder dirsearch dirsplit dirstat dirt dirvish-locate dis51 disc-cover discid disco discogrok discover-config discover-tempest-config discovery.etcd.io discus disdvi dish disjoint_union_adj disjoint_union_sep disk-filltest disk-image-create disk2zip disk_allocator diskd diskscan diskseekd disktype dislocate dislocker dislocker-bek dislocker-file dislocker-find dislocker-fuse dislocker-metadata disorderfs dispcal displacement_geometry display display-dhammapada display-im6.q16 display-im6.q16hdri display_qt display_rate_matrix display_to_hlg displaycal displaycal-3dlut-maker displaycal-apply-profiles displaycal-curve-viewer displaycal-eecolor-to-madvr-converter displaycal-profile-info displaycal-scripting-client displaycal-synthprofile displaycal-testchart-editor displaycal-vrml-to-x3d-converter displaycal-vrml-to-x3d-converter-console displayfont dispread dispwin dissop distcc distcc-pump distccd distccmon-gnome distccmon-text distinkt-dist distinkt-travisyml distl.find_active_area distl.image_viewer distl.mp_spotfinder_server_read_file distl.signal_strength distl.sweep_strength distl.thin_client distmat distro-info distrobox distrobox-create distrobox-enter distrobox-ephemeral distrobox-export distrobox-generate-entry distrobox-host-exec distrobox-init distrobox-list distrobox-rm distrobox-stop distrobox-upgrade disulfinder ditaa div_snp_table_chr.py divide-by-zero divxcomp django-admin djinn djpeg djview4 djvm djvmcvt djvubind djvudigital djvudump djvuextract djvumake djvups djvused djvuserve djvutoxml djvutxt djvuxmlparser djxl dk_make_protocol dkim-keygen dkim-milter dkim-rotate dkim-verify dkimproxy-sign dkimproxy-verify dkimpy-milter dkimsign dkimverify dknewkey dkopp dl10n-check dl10n-html dl10n-mail dl10n-nmu dl10n-pts dl10n-spider dl10n-txt dlc3 dlg dlint dll dllogin dlmodel2deb dlmodel_source dlocate (1) - program to view debian package information dlsdump dlt-adaptor-stdin dlt-adaptor-udp dlt-control dlt-convert dlt-daemon dlt-dbus dlt-kpi dlt-logstorage-ctrl dlt-parser dlt-passive-node-ctrl dlt-receive dlt-system dlt-viewer dlume dlv dm-tool dmail dman dmap2hrc dmarc-cat dmarc-lookup dmarc-policy-find dmcs dmenu dmenu_path dmenu_run dmg2img dmitry dmrconf dmrconfig dmrg dms dmtracedump dmtxquery dmtxread dmtxwrite dmypy dnaclust dnaclust-abun dnaclust-ref dnadiff dnal dnapi.py dnaplotter dnarrange dnarrange-genes dnarrange-link dnarrange-merge dnet dnet-config dnf dnf-3 dng dnie-tool dnoise dns-flood-detector dns2tcpc dns2tcpd dnsFoam dnsbulktest dnscap dnscap-rssm-rssac002 dnsdbq dnsdist dnsenum dnseval dnsfilter dnsget dnsgram dnsip dnsipq dnsjit dnsmap dnsmap-bulk dnsmx dnsname dnspcap2calidns dnspcap2protobuf dnsperf dnsping dnsq dnsqr dnsrecon dnsreplay dnss dnsscan dnsscope dnssec-cds dnssec-dsfromkey dnssec-importkey dnssec-keyfromlabel dnssec-keygen dnssec-revoke dnssec-settime dnssec-signzone dnssec-trigger-panel dnssec-verify dnssort dnstap dnstap-ldns dnstap-read (1) - print dnstap data in human-readable form dnstcpbench dnstop dnstrace dnstracer dnstracesort dnstwist dnstxt dnsvi dnswalk dnswasher doas doc2odt doc2pdf doc8 docbook-to-man docbook2dvi docbook2html docbook2man docbook2pdf docbook2ps docbook2rtf docbook2tex docbook2texi docbook2txt docbook2x-man docbook2x-texi doccentral docdiff docformatter dochelp docker (1) - Docker image and container command line interface docker-clean docker-compose (1) - Define and run multi-container applications with Docker. docker-credential-ecr-login docker-credential-pass docker-credential-secretservice docker-init docker-proxy docker-registry dockerd (8) - Enable daemon mode dockerd-rootless-setuptool.sh dockerd-rootless.sh docknot doclava doclifter doctest doctorj doctrine-dbal documentAnalyzer docx2txt docxcompose dodgy dogtail-detect-session dogtail-logout dogtail-run-headless dogtail-run-headless-next doilit doit dokujclient dokuwiki-addsite dokuwiki-delsite dolfin-convert dolfin-get-demos dolfin-order dolfin-plot dolfin-version dolfinx-scaling-test dolphin dom-mrconfig dom-new-git-repo domainalign domainnr domainrep domainreso domainseqs domainsse donkey doodle doodled doona dos.x dos2unix dosage dosbox dosbox-debug doscan doschk dose-builddebcheck dose-ceve dose-challenged dose-deb-coinstall dose-debcheck dose-distcheck dose-eclipsecheck dose-outdated dose-rpmcheck dosepsbin doseutility dot (1) - filter for drawing directed graphs dot-forward dot2gxl (1) - GXL-GV converters dot2tex dot_builtins dot_mcp dotenv dotenv-rust dotextwrap dotforward dothost dotlock.mailutils (1) - lock mail spool files. dotlockfile dotmatcher dotpath dotter dottojs dottup dotty (1) - A Customizable Graph Editor double doublecmd douceur dov4l doveadm doveconf dovecot-sysreport download-ncbi-data download-pubmed download-sequence download_atm_correction_luts download_rsr downloadosmtiles downsample-fits downtime downtimes doxygen (1) - documentation system for various programming languages doxygen-filter-perl doxygen2man doxyindexer (1) - creates a search index from raw search data doxyparse doxypypy doxyqml doxysearch.cgi (1) - search engine used for searching in doxygen documentation. doxywizard dozzaqueux dp dpatch2quilt dpbindic dpcd_reg dpd2dot dpdk-devbind.py dpdk-dumpcap dpdk-hugepages.py dpdk-pdump dpdk-pmdinfo.py dpdk-proc-info dpdk-telemetry.py dpdk-test dpdk-test-acl dpdk-test-bbdev dpdk-test-cmdline dpdk-test-compress-perf dpdk-test-crypto-perf dpdk-test-eventdev dpdk-test-fib dpdk-test-flow-perf dpdk-test-gpudev dpdk-test-pipeline dpdk-test-regex dpdk-test-sad dpdk-testpmd dpdusage dphys-config dpic dpigs dpipe Dpkg (3perl) - module with core variables dpkg (1) - package manager for Debian dpkg-architecture (1) - set and determine the architecture for package building dpkg-awk dpkg-buildflags (1) - returns build flags to use during package build dpkg-buildpackage (1) - build binary or source packages from sources dpkg-checkbuilddeps (1) - check build dependencies and conflicts dpkg-checkdeps dpkg-cross dpkg-deb (1) - Debian package archive (.deb) manipulation tool dpkg-depcheck dpkg-distaddfile (1) - add entries to debian/files dpkg-divert (1) - override a package's version of a file dpkg-genbuilddeps dpkg-genbuildinfo (1) - generate Debian .buildinfo files dpkg-genchanges (1) - generate Debian .changes files dpkg-gencontrol (1) - generate Debian control files dpkg-gensymbols (1) - generate symbols files (shared library dependency information) dpkg-info dpkg-maintscript-helper (1) - works around known dpkg limitations in maintainer scripts dpkg-mergechangelogs (1) - 3-way merge of debian/changelog files dpkg-name (1) - rename Debian packages to full package names dpkg-parsechangelog (1) - parse Debian changelog files dpkg-query (1) - a tool to query the dpkg database dpkg-realpath (1) - print the resolved pathname with DPKG_ROOT support dpkg-repack dpkg-ruby dpkg-scanpackages (1) - create Packages index files dpkg-scansources (1) - create Sources index files dpkg-shlibdeps (1) - generate shared library substvar dependencies dpkg-source (1) - Debian source package (.dsc) manipulation tool dpkg-split (1) - Debian package archive split/join tool dpkg-statoverride (1) - override ownership and mode of files dpkg-trigger (1) - a package trigger utility dpkg-vendor (1) - queries information about distribution vendors dpkg-www dpl4hydra dpmgr dpo-apply-compendium dpo-apply-templates dpo-check dpo-diff dpo-get-templates dpo-init-po dpo-make-patch dpo-wrap dprof2calltree dprofpp dpromdic dpt dptsv dpuser dput dpxdic dq dqlite dqlite-benchmark dqlite-demo dqtool dr_permutate dr_symlinks dr_unsort dr_watch draai draco_decoder draco_encoder draco_transcoder dracut dracut-catimages dragon draw-tree draw_lib_dependencies draw_tree drawing drawserv drawterm drawtool drawxtl drbl-bug-report drbl-doit drbl-run-parts drbl-uriparse drbl-wakeonlan drc dreadnaut dreg drfinddata drfindformat drfindid drfindresource drget drgn drhook-merge driftFluxFoam driftnet drill (1) - get (debug) information out of DNS(SEC) drivemap driverless (1) - PPD generator utility for driverless printing driverless-fax drkonqi-coredump-gui drm_info drmdevice drms droidlysis drone drool droopy drop-mia-uploaders drop-seq dropbearconvert dropbearkey dropdb droplang dropuser dropwatch drpmsync drracket drs_checkthredds drs_exam drs_exam_multi drs_tool drscl drsosc drtdump drtext drumgizmo drumkv1_jack drumstick-drumgrid drumstick-dumpmid drumstick-dumprmi drumstick-dumpsmf drumstick-dumpwrk drumstick-guiplayer drumstick-metronome drumstick-playsmf drumstick-sysinfo drumstick-vpiano ds-logpipe ds-replcheck ds9 ds_manager ds_worker dscextract dscverify dsdccx dsdp5 dselect dsh dshbak dsimulator dsk2dmk dskdump dskform dskid dskscan dsktrans dskutil dsmcFoam dsmcInitialise dspdfviewer dsr2html dsr2xml dsrdump dssi_analyse_plugin dssi_list_plugins dssi_osc_send dssi_osc_update dssp dst_test dstat dsv2dsv dsv2json dsymutil dsymutil-13 dsymutil-14 dsymutil-15 dsync dt-check-compatible dt-doc-validate dt-extract-example dt-extract-props dt-mk-schema dt-validate dt2dv dtach dtagnames dtb2py dtblint dtc dtd2po dtd2rng dtd2vim dtd2xsd dtddiff dtddiff2html dtdflatten dtdformat dtdiff dtdinst dtdparse dte dtest dtestcm dtestsrq dtestx dtfits dtmf2num dtos8cvt dtplite dtrace dtrx dtsdec dtxgen du (1) - estimate file space usage dualcoax dub dubdv dublin-traceroute duc duc-nox duck ducktype due duf duff duk dul-receive-pack dul-upload-pack dulwich duma dumb-init dumbnet-config dummy_tests dummydroid dump-mixers dump-perl-exports dump-stl dump.erofs dump1090-mutability dump2dcm dump2geo dump2pov dump2vtk dump3d dumpLA dumpRSAPublicKey dump_commit_requests dump_fmap dump_gcov dump_index dump_kernel_config dump_osc dump_xsettings dumpasn1 dumpcap (1) - Dump network traffic dumpelf dumpet dumphdr dumpimage dumpiso dumpleases dumpmscat dumppdf dumppsf dumprecs dumprtp dumpseg dumpsexp (1) - Debug tool for S-expressions dumpsolv dumpvtt dumpxsb dumresp dune dune-ctest dune-git-whitespace-hook dunecontrol duneproject dunst dunstctl dunstify dupeguru dupemap duperemove duplicity dupload duply durep dustmasker dv2dt dv4l dv4lstart dvb-fe-tool dvb-format-convert dvbackup dvbctrl dvbcut dvbdate dvbinfo dvblast dvblast_mmi.sh dvblastctl dvbnet dvbscan dvbstream dvbstreamer dvbtraffic dvbtune dvbv5-daemon dvbv5-scan dvbv5-zap dvconnect dvcont dvd+rw-booktype dvd+rw-format dvd+rw-mediainfo dvd-menu dvd-ram-control dvd-slideshow dvdauthor dvdbackup dvddirdel dvdtape dvdunauthor dvdxchap dvgrab dvi2dvi dvi2fax dvi2ps dvi2tty dviasm dvibook dviconcat dvicopy dvidvi dvigif dvihp dviinfox dvilj dvilj2p dvilj4 dvilj4l dvilj6 dvilualatex dvilualatex-dev dviluatex dvipdf (1) - Convert TeX DVI file to PDF using ghostscript and dvips dvipdfm dvipdfmx dvipdft dvipng dvipos dvips dvired dviselect dvispc dvisvgm dvitodvi dvitomp dvitype dvorak7min dvscf_q2r.x dvtm dvtm-editor dvtm-pager dwarfdump dwdiff dwdump dwebp dwespeak.sh dwfilter dwgsim dwi2adc dwi2fod dwi2mask dwi2response dwi2tensor dwibiascorrect dwicat dwidenoise dwiextract dwifslpreproc dwigradcheck dwinormalise dwishellmath dwm.default dwm.maintainer dwm.web dwm.winkey dwp (1) - The DWARF packaging utility dwww dwz dx dx2cube dxf2gcode dxf2idf dxf2vrml dxfsphere dxtbx.depends_on dxtbx.detector_superpose dxtbx.display_parallax_correction dxtbx.dlsnxs2cbf dxtbx.image2pickle dxtbx.image_average dxtbx.install_format dxtbx.overload dxtbx.plot_detector_models dxtbx.print_header dxtbx.print_matching_images dxtbx.python dxtbx.radial_average dxtbx.saturation dxtbx.show_build_path dxtbx.show_dist_paths dxtbx.show_mask_info dxtbx.show_matching_formats dxtbx.show_registry dxtool dynaconf dynamic_scene dynamite dynare++ dynare-preprocessor dynmat.x dz80 dzegrep dzen2 dzen2-dbar dzen2-gcpubar dzen2-gdbar dzen2-textwidth dzfgrep dzgrep dzil e e-PCR e-mem e00conv e2cp e2ln e2lpr e2ls e2mkdir e2mtiff e2mv e2pall e2ps e2rm e2tail e2tools e3 e3em e3ne e3pi e3vi e3ws eTktab ea-alc eaddress eancheck eapol_test earlyoom easy_eliza easychem easydev3_browse easyeffects easygen easyh10 easyjson easyssh easytag eatmydata eb_client_egd eb_client_file eb_client_kernel_generic eb_client_linux_kernel eb_proxy_knuth_b eb_proxy_knuth_m eb_server_Araneus_Alea eb_server_ComScire_R2000KU eb_server_audio eb_server_egd eb_server_ext_proc eb_server_linux_kernel eb_server_push_file eb_server_smartcard eb_server_stream eb_server_timers eb_server_usb eb_server_v4l ebappendix ebb ebfont ebi2xml ebinfo eblast eblook ebnflint eboard-addtheme eboard-config ebook ebook-convert ebook-device ebook-edit ebook-meta ebook-polish ebook-speaker ebook-viewer ebook2cw ebook2cwgui ebook2epub ebook2odt ebrefile ebrowse.emacs ebshell ebstopcode ebumeter ebunzip ebur128 ebview ebview-client ebwxshell ebzip ebzipinfo ec2-metadata ec2metadata ecaccess ecaccess-association-delete ecaccess-association-delete.bat ecaccess-association-get ecaccess-association-get.bat ecaccess-association-list ecaccess-association-list.bat ecaccess-association-protocol ecaccess-association-protocol.bat ecaccess-association-put ecaccess-association-put.bat ecaccess-certificate-create ecaccess-certificate-create.bat ecaccess-certificate-list ecaccess-certificate-list.bat ecaccess-cosinfo ecaccess-cosinfo.bat ecaccess-ectrans-delete ecaccess-ectrans-delete.bat ecaccess-ectrans-list ecaccess-ectrans-list.bat ecaccess-ectrans-request ecaccess-ectrans-request.bat ecaccess-ectrans-restart ecaccess-ectrans-restart.bat ecaccess-event-clear ecaccess-event-clear.bat ecaccess-event-create ecaccess-event-create.bat ecaccess-event-delete ecaccess-event-delete.bat ecaccess-event-grant ecaccess-event-grant.bat ecaccess-event-list ecaccess-event-list.bat ecaccess-event-send ecaccess-event-send.bat ecaccess-file-chmod ecaccess-file-chmod.bat ecaccess-file-copy ecaccess-file-copy.bat ecaccess-file-delete ecaccess-file-delete.bat ecaccess-file-dir ecaccess-file-dir.bat ecaccess-file-get ecaccess-file-get.bat ecaccess-file-mdelete ecaccess-file-mdelete.bat ecaccess-file-mget ecaccess-file-mget.bat ecaccess-file-mkdir ecaccess-file-mkdir.bat ecaccess-file-modtime ecaccess-file-modtime.bat ecaccess-file-move ecaccess-file-move.bat ecaccess-file-mput ecaccess-file-mput.bat ecaccess-file-put ecaccess-file-put.bat ecaccess-file-rmdir ecaccess-file-rmdir.bat ecaccess-file-size ecaccess-file-size.bat ecaccess-gateway-connected ecaccess-gateway-connected.bat ecaccess-gateway-list ecaccess-gateway-list.bat ecaccess-gateway-name ecaccess-gateway-name.bat ecaccess-job-delete ecaccess-job-delete.bat ecaccess-job-get ecaccess-job-get.bat ecaccess-job-list ecaccess-job-list.bat ecaccess-job-restart ecaccess-job-restart.bat ecaccess-job-submit ecaccess-job-submit.bat ecaccess-queue-list ecaccess-queue-list.bat ecaccess.bat ecaconvert ecafixdc ecalength ecamonitor ecanormalize ecaplay ecasignalview ecasound ecattominc ecbuild ecdsakeygen ecdsasign ecdsautil ecdsaverify ecflow_client ecflow_fuse ecflow_standalone ecflow_ui ecflow_ui.x ecgviewer echo_supervisord_conf echomixer echoscu echosim ecitmatch ecj eckit-info eckit-version ecl ecl-config eclipseemu ecm ecoPCR ecoPCRFilter ecoPCRFormat ecoSort ecodbtaxstat ecofind ecogrep ecoisundertaxon econftool econtact econvert ecotag ecotaxspecificity ecotaxstat ecpg ecryptfs-add-passphrase ecryptfs-find ecryptfs-generate-tpm-key ecryptfs-insert-wrapped-passphrase-into-keyring ecryptfs-manager ecryptfs-migrate-home ecryptfs-mount-private ecryptfs-recover-private ecryptfs-rewrap-passphrase ecryptfs-rewrite-file ecryptfs-setup-private ecryptfs-setup-swap ecryptfs-stat ecryptfs-umount-private ecryptfs-unwrap-passphrase ecryptfs-verify ecryptfs-wrap-passphrase ecryptfsd ectrans ectrans-benchmark-dp ectrans-benchmark-sp ed-tkdesk ed2k-link ed2k_hash edac-util edamdef edamhasinput edamhasoutput edamisformat edamisid edamname edb edbrowse edentify edfbrowser edfcat edfhed edfhed-gtk edfviewer edgepaint (1) - edge coloring to disambiguate crossing edges edgeredef edhead edialign edict-grep edid-decode edirect edirutil edit (1) - execute programs via entries in the mailcap file edit-faxcover edit-patch edit_octree editcap (1) - Edit and/or translate the format of capture files editclient editcomment editdiff (1) - fix offsets and counts of a hand-edited diff editfilenames editorconfig editorconfig-0.12.5 editres (1) - a dynamic resource editor for X Toolkit applications edittodo edje_cc edje_codegen edje_decc edje_external_inspector edje_inspector edje_pick edje_player edje_recc edje_watch edlib-aligner edonr256-hash edonr512-hash edru edsu edusers eepget eeschema eet eetpack eeze_disk_ls eeze_mount eeze_scanner eeze_scanner_monitor eeze_umount efa efax efbu efetch efetch.ncbi efeu efi-readvar efi-updatevar efikeygen efilter efisiglist efitool-mkusb efivar efix efl_canvas_wl_test efl_canvas_wl_test_stack efl_debug efl_debugd eflite efm-langserver efreetd efricas efru efsu efte eg eg25-manager egctl eggdrop eggdrop-1.8.4 egk-tool eglinfo eglinfo.x86_64-linux-gnu eglretrace eiciel eid eidenv eigenstrat eigenstratQTL eiger-mask eiger2cbf eiger2crysalis eina_btlog eina_modinfo einfo einfo.ncbi einverted eiskaltdcpp-cli-jsonrpc eiskaltdcpp-daemon eiskaltdcpp-gtk eiskaltdcpp-qt eiskaltdcpp-web eja ejabberd2prosody eject (1) - eject removable media el elan eland2sga.pl elaps elastalert elastalert-create-index elastalert-rule-from-kibana elastalert-test-rule elastic_ruby_console elastix elbpcom elc3 eldbus-codegen electric electrostaticFoam electrum eledef elektroid elektroid-cli elementary_codegen elementary_config elementary_perf elementary_quicklaunch elementary_run elementary_test elementsinfo eleredef elf-arch (1) - recognize architecture of an ELF executable/shlib elfedit (1) - update ELF header and program property of ELF files elfrc elfx86exts elink elinks eliom-distillery eliombuild eliomc eliomcp eliomdep eliomdoc eliomopt eliompp eliot-prettyprint elisa elixir elixir-column elixir-compose elixir-resolve elixirc elk elk-bands elk-lapw elki elki-cli ellcc.xemacs21 elm elm_prefs_cc elogin elph elpi elpi-trace-elaborator elvish em++ em-config em_cons em_pscan emacs-gtk emacs-lucid emacs-nox emacsclient.emacs emacsql-sqlite email-extract-openpgp-certs email-print-mime-structure email-reminder-editor emar embossdata embossupdate embossversion embpexec embpmsgid embree-convert embree_tests embree_verify embryo_cc embuilder emcc emcmake emconfigure emd emdaemon emdump emdwp emerald emerald-theme-manager emf2svg-conv emi-canl-client emi-canl-delegation emi-canl-proxy-init emi-canl-server emixer emma emmake emmax emmax-kin emnm emoji-picker emos_tool emoslib_bufr_filter emot emowse emprofile empty-dmk empty-page emptyvss empy empy3 emranlib emrun emscons emsize emu8051-cli emu8051-gtk emveepee en_cas_help enable_dev_usb_boot enber enblend enc2xs (1) - - Perl Encode Module Generator enca encapsulate encfs encfsctl encfssh encguess (1) - guess character encodings of files enchant-2 (1) - a spellchecker enchant-lsmod-2 (1) - list provider and dictionary information encode_keychange encodedv encodefile enconv end2xml endeavour endlessh endnote-format endx2xml enfuse engauge engineCompRatio engineFoam engineSwirl engrampa enjarify enlightenment enlightenment_askpass enlightenment_filemanager enlightenment_fprint enlightenment_imc enlightenment_open enlightenment_paledit enlightenment_remote enlightenment_start enotify enq_ctndisp enq_ctnnetwork enscribe enscript ensop ent entagged entangle entr entret entrez entrez-phrase-search entrez2 entrigraph entropy_broker enum enum_chmLib enumdir_chmLib env (1) - run a program in a modified environment env.fakechroot env2 env_parallel env_parallel.ash env_parallel.bash env_parallel.csh env_parallel.dash env_parallel.fish env_parallel.ksh env_parallel.mksh env_parallel.sh env_parallel.tcsh env_parallel.zsh env_replace envdir envext envfrom2srs envify envml envpath envstore envsubst (1) - substitutes environment variables in shell format strings envuidgid envy24control eo_debug eoconv eog eolian_gen eom eos eos-application-manifest eos-html-extractor eos-json-extractor eos-profile eot2ttf eotinfo eox epa-tr-stat epa.x epdfinfo eperl epestfind ephemeral-port-reserve ephoto epic4 epic5 epinfo epiphany epiphany-browser epix eplain epm epmd epminstall epoptes epost eprimer3 eprimer32 eproxy eps2eps (1) - Ghostscript PostScript "distiller" eps2svg epsffit epsilon.x epspdf epspdftk epstool epstopdf eptex epubcheck epw.x epylint eqn (1) - format equations for troff or MathML eqn2eps eqn2graph eqonomize equalx equicktandem equilibriumCO equilibriumFlameT equivs-build equivs-control erancid erb erb3.0 erb3.1 erfs ergo eric eric6 eric6_api eric6_browser eric6_compare eric6_configure eric6_diff eric6_doc eric6_editor eric6_hexeditor eric6_iconeditor eric6_plugininstall eric6_pluginrepository eric6_pluginuninstall eric6_qregularexpression eric6_re eric6_shell eric6_snap eric6_sqlbrowser eric6_tray eric6_trpreviewer eric6_uipreviewer eric6_unittest erl erl_call erlang-depends erlang_count erlc errbot errhdr errno (3) - number of last error errno-map erubis es2_info es2_info.x86_64-linux-gnu es2gears_wayland es2gears_wayland.x86_64-linux-gnu es2gears_x11 es2gears_x11.x86_64-linux-gnu es2tri es2tri.x86_64-linux-gnu es2ts es_cas_help es_repo_mgr esample esbuild esc-m escodegen escp2topbm escputil escript escrow esd2esi esdots esearch esedbexport esedbinfo esfilter esgenerate eslint esmerge esmtp esnacc esolver esorex esparse espctag espdiff (6) - apply the appropriate transformation to a set of patches espeak espeak-ng espeakedit espeakup espefuse espell esponja espsecure esptool esreport esreverse est2genome estimate-gcode-time estimateDE estimateExpression estimateHyperPar estimateReadFiltering estimateScaleFactor estimateVBExpression estscan estwise estwisedb esummary esvalidate esysparticle eta etags.emacs etags.xemacs21 etandem etc1tool etcd etcdctl etckeeper etex etf2ly etherape etherpuppet ethflux ethstats ethstatus ethumb ethumbd ethumbd_client etm etraining etsf_io ettercap ettercap-pkexec etterfilter etterlog eu-addr2line eu-ar eu-elfclassify eu-elfcmp eu-elfcompress eu-elflint eu-findtextrel eu-make-debug-archive eu-nm eu-objdump eu-ranlib eu-readelf eu-size eu-stack eu-strings eu-strip eu-unstrip eugene eukleides euktoeps euktopdf euktopst euktotex euler euptex eureka eurephia_init eurephia_saltdecode eurephiadm eus eus0 eus1 eus2 euscomp eusg eusgl eusx eutp ev.x eval_octree_accuracy eval_predictions evaluate_model evcd2vcd evdev-joystick evec2pca evec2pca-ped evemu-describe evemu-device evemu-event evemu-play evemu-record eventc eventf events eventstat evilwm evince evince-previewer evince-thumbnailer evmctl evol evolution evolver-nox-d evolver-nox-ld evolver-nox-q evolver-ogl-d evolver-ogl-ld evolver-ogl-q evolvotron evolvotron_mutate evolvotron_render evse evtest evtexport evtinfo evtx_dump.py evtx_dump_chunk_slack.py evtx_eid_record_numbers.py evtx_extract_record.py evtx_filter_records.py evtx_info.py evtx_record_structure.py evtx_structure.py evtx_templates.py evtxexport evtxinfo ewfacquire ewfacquirestream ewfdebug ewfexport ewfinfo ewfmount ewfrecover ewfverify ewipe ex1_initiator ex2_initiator ex3_acceptor ex3_initiator ex4_acceptor ex4_initiator exa (4) - new 2D acceleration architecture for X.Org exabgp-cli exabgp-healthcheck exact-tandems exactSNP exactness exactness_inject exactness_inspect exactness_play exactness_record exadrums examl examl-OMP exceltex exclude-uid-lists exe-thumbnailer exe_update execlineb execute-json-from-fifo exedat exempi exfalso (1) - audio tag editor exif exif_loader exifautotran exifcom exifgrep exifprobe exiftags exiftime exiftool exiftran exim4-localscan-plugin-config exip existDB exiv2 exjdxgen exmendis exmenen exmh exo-desktop-item-edit (1) - Edit freedesktop.org .desktop files exo-open (1) - Open URLs and launch preferred applications exonerate exonerate-server exoniphy exonpairs exp_count exp_variogram expand (1) - convert tabs to spaces expand-current expandCols expect expect_autoexpect expect_autopasswd expect_cryptdir expect_decryptdir expect_dislocate expect_ftp-rfc expect_kibitz expect_lpunlock expect_mkpasswd expect_multixterm expect_passmass expect_rftp expect_rlogin-cwd expect_timed-read expect_timed-run expect_tknewsbiff expect_tkpasswd expect_unbuffer expect_weather expect_xkibitz expect_xpstat expeyes expeyes-doc expeyes-junior expeyes-junior-doc expeyes-progman-jr-doc expire-iso8601 expiry (1) - check and enforce password expiration policy explain expn export2sam.pl expr (1) - evaluate expressions exr2aces exrenvmap exrheader exrinfo exrmakepreview exrmaketiled exrmultipart exrmultiview exrstdattr ext2sim ext2spice ext3grep extconv extend extend_dmalloc extension-manager external-ip extlinux extra-data-locality extra-data-make-virtual-cxi extra-data-validate extrace extract extract++ extract-ancestors extract-transcript-to-gene-map-from-trinity extractBCITrees extractSamples extractTranscriptInfo extract_EST extract_UG_EST extract_a52 extract_ascii extract_chmLib extract_dca extract_dts extract_fastq extract_markers.py extract_metadata extract_mpeg2 extract_proteome_from_gff extract_qual extract_seq extract_subset extract_usage_from_stx extract_vba extractalign extractallimages extractattr extractbb extractfeat extracticc extractjpgs extractor extractpdfmark extractrc extractreads extractreads2 extractres extractseq extractttag extractvectors extrepo extresso extrude2DMesh extrudeMesh extrudeToRegionMesh extsmail extsmaild extundelete eyaml eye eye.pvm eyeD3 eyes17 eyes17-manuals eyuvtoppm ezdxf ezez4makefile_v4 ezez4makefile_v4.pl ezez4qsub_vx1 ezez4qsub_vx1.pl ezez_vx1 ezez_vx1.pl ezmapdemo ezmsim ezstream ezstream-cfgmigrate ezstream-file eztrace eztrace.preload eztrace_avail eztrace_cc eztrace_create_plugin f2c f2java f2py3 f2py3.10 f2py3.11 f3brew f3d f3fix f3probe f3read f3write f5ls f5pack f5rancid f90_count fa2fq fa2htgs faad fab fab-cewl fabio-convert fabio_viewer fable.cout fable.fem_include_search_paths fable.insert_write_at_start_of_each_procedure fable.python fable.read fable.show_build_path fable.show_calls fable.show_dist_paths fable.split fabmanager faceAgglomerate facedetect facter facterdb factor (1) - factor numbers factor.pl fadecut fahash fai fai-class fai-debconf fai-deps fai-do-scripts fai-kvm fai-link fai-mirror fai-mk-configspace fai-monitor-gui fai-sed faidx faifa fail2ban-client fail2ban-python fail2ban-regex fail2ban-server fail2ban-testcases faillog (5) - login failure logging file faillog (8) - display faillog records or set login failure limits faithpd fakeCMY fakebmc fakechanges fakechroot faked-sysv faked-tcp fakemachine fakenect fakenect-record faker fakeread fakeroot-pseudo fakeroot-sysv fakeroot-tcp faketime falcon-bench falcon-inspect-app falcon-print-routes falkon fallocate (1) - preallocate or deallocate space to a file fallocate (2) - manipulate file space falselogin famap famdef faqpods farcompilestrings farcreate farequal farextract farinfo farisomorphic farm-run.pl farprintstrings fasd fasm fast-discovery-server fast-import-filter fast-import-info fast-import-query fast5_subset fastANI fastBlockSearch fastDNAml fastDNAml-util fastQTL fast_to_cgns fasta-nr fasta-sanitize.pl fasta2DAM fasta2DB fasta2esd fasta36 fastaFromBed fasta_to_fastq.pl fasta_to_raw fastaannotatecdna fastachecksum fastaclean fastaclip fastacmd fastacomposition fastadiff fastaexplod fastaexplode fastafetch fastahack fastahardmask fastaindex fastalength fastanrdb fastaoverlap fastaq fastareformat fastaremove fastarevcomp fastasoftmask fastasort fastasplit fastasubseq fastatranslate fastavalidcds fastboot fastcgi-mono-server fastcgi-mono-server4 fastconv-float fastconvr-float fastd fastdds fastddsgen fastep fasterq-dump fasterq-dump-orig fastf36 fastforward fastjar fastm36 fastml fastnetmon_api_client fastnetmon_client fastp fastq-clipper fastq-dump fastq-dump-orig fastq-interleave fastq-join fastq-mcf fastq-multx fastq-stats fastq_pair fastqc fastqtobam fastqtobam2 fasts36 fasttext fasttree fasttreeMP fastx-graph fastx36 fasty36 fatattr fatcat fathom fatpack fatsort faucc faucet fauhdlc fauhdli faultstat faust faust2alqt faust2alsa faust2alsaconsole faust2api faust2atomsnippets faust2audiokit faust2bela faust2bench faust2cpalrust faust2csound faust2csvplot faust2daisy faust2dplug faust2dssi faust2dummy faust2dummymem faust2eps faust2esp32 faust2feh faust2firefox faust2gen faust2graph faust2graphviewer faust2jack faust2jackconsole faust2jackrust faust2jackserver faust2jaqt faust2jaqtchain faust2juce faust2ladspa faust2linuxunity faust2lv2 faust2mathdoc faust2mathviewer faust2md faust2minimal faust2netjackconsole faust2netjackqt faust2octave faust2owl faust2paqt faust2pdf faust2plot faust2png faust2portaudiojulia faust2portaudiorust faust2pure faust2puredata faust2raqt faust2ros faust2rosgtk faust2sam faust2sc faust2sc.py faust2sig faust2sigviewer faust2sndfile faust2soul faust2sublimecompletions faust2supercollider faust2svg faust2svgviewer faust2teensy faust2tidalcycles faust2unity faust2wasm faust2webaudiowasm faustremote fauxhai fava fax fax2ps fax2tiff faxalter faxcover faxmail faxq faxrm faxrunq faxspool faxstat fb fb_config fb_lock_print fba2cfba fbautostart fbcat fbcli fbgrab fbgs fbi fbless fbpager fbreader fbrun fbsetbg fbsetroot fbstat (1) - analyze firebird database fbsvcmgr (1) - access services API of Firebird fbterm fbterm_ucimf fbtracemgr fbtv fbwrap fbxine fbxkb fc fc-cache (1) - build font information cache files fc-cat (1) - read font information cache files fc-conflist (1) - Show the ruleset files information on the system fc-list (1) - list available fonts fc-match (1) - match available fonts fc-pattern (1) - parse and show pattern fc-query (1) - query font files fc-scan (1) - scan font files or directories fc-solve fc-validate (1) - validate font files fcal fcaps fcat (1) - Output the contents of a file based on its name. fccexam fcconv fcgistarter fcitx fcitx-autostart fcitx-config-gtk3 fcitx-configtool fcitx-dbus-watcher fcitx-diagnose fcitx-fbterm fcitx-fbterm-helper fcitx-imlist fcitx-qimpanel fcitx-qimpanel-configtool fcitx-remote fcitx-skin-installer fcitx4-config fcitx5 fcitx5-config-qt fcitx5-configtool fcitx5-diagnose fcitx5-fbterm fcitx5-migrator fcitx5-plasma-theme-generator fcitx5-remote fckit fckit-eval fckit-fypp fcm fcm_graphic_diff fcm_graphic_merge fcm_gui fcm_internal fcm_test_battery fcml-asm fcml-disasm fcomp fconvolver fcrackzip fcrackzipinfo fctest-generate-runner fd fd0ssh fd2pascal-3.2.2 fd2ps fdb fdb-copy fdb-dump fdb-dump-index fdb-dump-toc fdb-hammer fdb-hide fdb-info fdb-list fdb-lock fdb-monitor fdb-overlay fdb-patch fdb-purge fdb-read fdb-reconsolidate-toc fdb-root fdb-schema fdb-server fdb-stats fdb-status fdb-unlock fdb-where fdb-which fdb-wipe fdb-write fdesign fdf2fit fdfind fdlist fdm fdmdv_demod fdmdv_get_test_bits fdmdv_mod fdmdv_put_test_bits fdmount fdmountd fdp (1) - filter for drawing undirected graphs fdpowermon fdrawcmd fdroid fdroidcl fdsh fdtdump fdtget fdtoverlay fdtput fdumount fdupes featcopy feathernotes featherpad featmerge featreplace featreport feattext feature-check featureCounts feature_draw features-matching feed2exec feed2imap feed2imap-cleaner feed2imap-dumpconfig feed2imap-opmlimport feed2toot feedgnuplot feersum feff6l feff8l feff8l_ff2x feff8l_genfmt feff8l_pathfinder feff8l_pot feff8l_rdinp feff8l_xsph feff_plot_cross_section feff_plot_dos feh felix felix-framework femon fenics-version fenrir fenrir-daemon fermi_proj.x fermi_velocity.x fernet-keygen fernet-sign ferret ferret_c festival festival_client fet fet-cl fetch-ebook-metadata fetch-pubmed fetch_all_refseq_bacterial_genomes fetch_all_refseq_chloroplast_genomes fetch_all_refseq_mitochondrial_genomes fetch_cif_dict fetch_genome_by_accession fetch_refseq_bacterial_genomes_by_name fetch_tles fetchfile fetchmail fetchyahoo fever fex2bin feynmf ff-c++ ff-get-dep ff-mpirun ff-pkg-download ff2jpg ff2pam ff2png ff2ppm ffado-bridgeco-downloader ffado-dbus-server ffado-diag ffado-dice-firmware ffado-fireworks-downloader ffado-mixer ffado-set-nickname ffado-test ffado-test-isorecv ffado-test-isoxmit ffado-test-streaming ffado-test-streaming-ipc ffado-test-streaming-ipcclient ffbamg ffc ffc-3 ffcfstress ffcvt ffcx ffe ffglut ffihugs ffind (1) - Finds the name of the file or directory using a given inode ffindex_apply ffindex_apply_mpi ffindex_build ffindex_from_fasta ffindex_from_fasta_with_split ffindex_from_tsv ffindex_get ffindex_modify ffindex_order ffindex_reduce ffindex_unpack ffjson fflas-ffpack-config ffmaster ffmedit ffmpeg (1) - ffmpeg video converter ffmpeg_harvid ffmpegfs ffmpegthumbnailer ffmsindex ffmvforce ffplay (1) - FFplay media player ffprobe (1) - ffprobe media prober ffprobe_harvid ffproxy ffset fft-float fftest fftprof fftw-wisdom fftw-wisdom-to-conf fftwf-wisdom fftwl-wisdom fftwq-wisdom ffuf fgallery fgexample fghack fh2odg fhist fi_info fi_pingpong fi_strerror fiarith fiascotopnm fiat fiat-printbinding ficalib fiche ficombine ficonv fid fidentify fido2-assert fido2-cred fido2-token field (3form) - make and break connections between fields and forms fierce fig2dev fig2eps fig2pdf fig2ps fig2ps2tex fig2sxd fig4latex figlet-figlet figlet-toilet figlist figtoipe figtree fiheader fiign fiinfo filament-resgen filamesh filan (1) - Multipurpose relay (SOcket CAT) FILE (3) - input/output stream file (1) - determine file type file-rename (1p) - renames multiple files file-roller file2 file2brl (1) - Translate an xml or a text file into an embosser-ready braille file file2fuzz file65 filecap filecompare fileconvert-v1-to-v2 filedumper filedumper-slim filedumperx fileinfo filelight filename fileroot filetype filext fill-aa fill-an-ac fill-fs fill-ref-md5 fillImageDB fillRSA fillRSAImpInterp fillpdffields filter (3ncurses) - miscellaneous curses utility routines filter (7) - cups file conversion filter interface filter-stop-words filterBam filterBugs filterPolishes filter_blat filter_contigs filter_counts filter_hssp filter_mysqlbinlog filter_seer filter_tradis_tags filterdiff (1) - extract or exclude diffs from a diff file filterm filtlong fim fimgs finalcif financialFoam finch fincore (1) - count pages of file contents in core find (1) - search for files in a directory hierarchy find-all-symbols-13 find-all-symbols-14 find-all-symbols-15 find-corrupt-whisper-files find-dbgsym-packages find-debuginfo (1) - finds debuginfo and processes it find-large-clusters find-requires find_in_sorted_file.py find_numbers find_optimal_dimensions_for_microstrip_coupler findaffix findbugs findbugs-csr findbugs-dbStats findbugs-msv findbugs2 findcontact finddup findent findg findhyph findimagedupes findkm findknownsnps findmeastable findmissingcrystal findorule findproxyfile findpython findrule (1p) - command line wrapper to File::Find::Rule findscu findspl findstrip findtable findunsupportededges findv finger finger@ fingerw fio fio-btrace2fio fio-dedupe fio-genzipf fio-verify-state fio2gnuplot fio_generate_plots fio_jsonplus_clat2csv fiona fiphot fiptool firandom fireFoam fireToFoam firecfg firefox firefox-esr (1) - a Web browser for X11 derived from the Mozilla browser firejail firejail-ui firemon firetools firewall-applet firewall-cmd firewall-config firewall-offline-cmd firmdl3 first firstprimes fis_server fische fish fish_indent fish_key_reader fishdescriptor fisql fission fistar fit-wcs fitgcp fitrans fits-column-merge fits-flip-endian fits-guess-scale fits2bitmap fits2table fitscheck fitscopy fitscut fitsdiff fitsgetext fitshdr fitsheader fitsinfo fitsmd5 fitsort fitspng fitstopnm fitsverify fityk fiu-ctrl fiu-ls fiu-run fiwalk (1) - print the filesystem statistics and exit fix-include.sh fix-qdf fix-trinity-output fixPolishesIID fix_include fix_latin fixcrio fixcvsdiff (1) - fix problematic diff files fixdlsrps fixel2peaks fixel2sh fixel2tsf fixel2voxel fixelcfestats fixelconnectivity fixelconvert fixelcorrespondence fixelcrop fixelfilter fixelreorient fixfmps fiximports fixkdeincludes fixnt fixpix fixproc fixps fixpsditps fixpspps fixscribeps fixtd fixtpps fixuifiles fixwfwps fixwpps fixwwps fizsh fl2k_file fl2k_fm fl2k_tcp fl2k_test flac flacsplt flactag flake flake8 flam3-animate flam3-convert flam3-genome flam3-render flamerobin flameshot flamethrower flamethrowerd flamp flankBed flappclient flappserver flarq flash (3ncurses) - curses bell and screen flash routines flash-var flashbench flashbench-erase flashtool flask flatc flatlatex flatpak flatpak-bisect flatpak-builder flatpak-coredumpctl flattenMesh flatten_json.py flatxml2po flatzinc flawfinder fldiff fldigi flent flent-gui flex (1) - the fast lexical analyser generator flex++ (1) - the fast lexical analyser generator flexc++ flexloader flexml flexpart.ecmwf flexpart.gfs flextra.ecmwf flextra.gfs flickcurl flickcurl-config flickr_dump_stored_config flickr_make_stored_config flickr_make_test_values flickr_upload flickrdf flightcrew-cli flightcrew-gui fling flip flipbook flipdiff (1) - exchange the order of two incremental patches flipx flit flite flite_cmu_time_awb flite_cmu_us_awb flite_cmu_us_kal flite_cmu_us_kal16 flite_cmu_us_rms flite_cmu_us_slt flite_time flix flmsg floatbg flock (1) - manage locks from shell scripts flock (2) - apply or remove an advisory lock on an open file flog flogin flogtool flookup floppycontrol floppyd floppyd_installtest floppymeter floptool tc-flow (8) - flow based traffic control filter flow-node flow-remove-types flowblade flowgrind flowgrind-stop flpsed flrig fls (1) - List file and directory names in a disk image. fltk-config fluent3DMeshToFoam fluentMeshToFoam fluid fluidsynth fluxbox fluxbox-remote fluxbox-update_configs flvmeta flvstreamer flwm flwrap flye flye-modules fm fm2ps fm_demod fmaster1 fmeasure fmerge fmfconv fmit fml-asm fmscan fmt (1) - simple optimal text formatter fmtave fmtutil fmtutil-sys fmtutil-user fnid fnlogin fnt fntsample foamDataToFluent foamDictionary foamFormatConvert foamHelp foamListRegions foamListTimes foamMeshToFluent foamRestoreFields foamToEnsight foamToEnsightParts foamToFireMesh foamToGMV foamToStarMesh foamToSurface foamToTetDualMesh foamToVTK foamUpgradeCyclics focuswriter fod2dec fod2fixel fold (1) - wrap each input line to fit in specified width fold2Bloch foliate folks-import folks-inspect foma fondu font font-manager fontc fontcustom fontdata fontdump fontforge fontimage fontinst fontlint fontmake fontmatrix fonttools fonttosfnt (1) - Wrap a bitmap font in a sfnt (TrueType) wrapper foo-yc20 foo-yc20-cli foo2ddst foo2ddst-wrapper foo2hbpl2 foo2hbpl2-wrapper foo2hiperc foo2hiperc-wrapper foo2hp foo2hp2600-wrapper foo2lava foo2lava-wrapper foo2oak foo2oak-wrapper foo2qpdl foo2qpdl-wrapper foo2slx foo2slx-wrapper foo2xqx foo2xqx-wrapper foo2zjs foo2zjs-icc2ps foo2zjs-pstops foo2zjs-wrapper fookb foomatic-combo-xml foomatic-compiledb foomatic-configure foomatic-datafile foomatic-perl-data foomatic-ppd-options foomatic-ppd-to-xml foomatic-ppdfile foomatic-printjob foomatic-rip (1) - Universal print filter/RIP wrapper foomatic-searchprinter foot footclient fop fop-ttfreader for_each forcpp foreman foremancli foremost forge forkstat form (3form) - curses extension for programming forms formail formatdb formiko formiko-vim formula_sum forsort fort fort77 fortc fortls fortran_count fosmount fosread fosrec fossil fotoxx fox fox-config-1.6 foxeye foxeye-0.12.1 foxtrotgps fp-3.2.2 fp-fix-timestamps fp2bit fp2preview fp2subc fpack fpad fparser2 fpart fpc-depends-3.2.2 fpcalc fpcjres-3.2.2 fpclasschart-3.2.2 fpcmake-3.2.2 fpcsubst-3.2.2 fpdns fpdoc-3.2.2 fped fping fping6 fplll fppkg-3.2.2 fprcp-3.2.2 fprintd-delete fprintd-enroll fprintd-list fprintd-verify fps2sga.pl fpsync fpwmake fpzip tc-fq (8) - Fair Queue traffic policing fq2fa fqha.x fqterm fqterm.bin fr_cas_help fracextract fracplanet fractalnow fractalpooluser fractgen fragiso fragmaster frama-c frama-c-config frama-c-gui frama-c-gui.byte frama-c-script frama-c.byte frame-test-x11 frameq fraqtive freak free (1) - Display amount of free and used memory in the system free (3) - allocate and free dynamic memory free42bin free42dec freeDiameterd free_bift free_gpa free_guinier free_rg freealut-config freeaptxdec freeaptxenc freebayes freebcp freebirth freebirth-alsa freecell-solver-range-parallel-solve freecontact freedom-maker freedv freefem freenect-camtest freenect-chunkview freenect-cpp_pcview freenect-cppview freenect-glpclview freenect-glview freenect-hiview freenect-micview freenect-regtest freenect-regview freenect-tiltdemo freenect-wavrecord freeplane freerdp-shadow-cli freesas freesasa freesrp-ctl freesrp-io freetable freetuxtv freezer freezer-agent freezer-api freezer-api-wsgi freezer-manage freezer-manager-status freezer-scheduler french-conjugator french-deconjugator frend frescobaldi freshclam fribidi fricas fricas-test friso fritzing fritzing.real frm.mailutils (1) - display From: lines. frm_admin frm_purged frm_xfragent frm_xfrd frobby frog frogr from.mailutils (1) - display from and subject. frombin fromdos frommac front-end-cal frsg frze fs-uae fs-uae-arcade fs-uae-device-helper fs.x fs_mark fsa fsa-translate fsa_assemble fsa_ctg_bridge fsa_ol_filter fsa_rd_stat fsapfsinfo fsapfsmount fsc2res.py fsck.cpm fsck.erofs fsck.winregfs fscrypt fsdeploy fsed.cpm fsextinfo fsfs-access-map fsfs-stats fshfsinfo fsk_mod fslave1 fslsfonts fsm-lite fsnotifywait fsnotifywatch fsntfsinfo fsntfsmount fspanel fspl fspmd fspy fsstat (1) - Display general details of a file system fssync fst-compact fst-compare fst-compiler fst-compiler-utf8 fst-generate fst-infl fst-infl2 fst-infl2-daemon fst-infl3 fst-lattice fst-lowmem fst-match fst-mor fst-parse fst-parse2 fst-print fst-text2bin fst-train fst2vcd fst4sim fstarcsort fstclosure fstcompile fstcompose fstcompress fstconcat fstconnect fstconvert fstdeterminize fstdifference fstdisambiguate fstdraw fstencode fstepsnormalize fstequal fstequivalent fstinfo fstintersect fstinvert fstisomorphic fstl fstlinear fstloglinearapply fstmap fstminer fstminimize fstobdf fstopgm fstprint fstproject fstprune fstpush fstrandgen fstrcmp fstrelabel fstreplace fstreverse fstreweight fstrm_capture fstrm_dump fstrm_replay fstrmepsilon fstshortestdistance fstshortestpath fstsymbols fstsynchronize fsttopsort fstunion fsverity fsview fsvs fswatch fswatcher fswebcam fsxfsinfo fsynth ft8code ftangle ftbench ftconf.py ftdi_eeprom ftdi_urls.py ftdiff ftdump fte fteqcc ftff ftgamma ftgrid ftlint ftmulti ftnchek ftp-cp ftp-ls ftp-rfc ftp-ssl ftp-upload ftpcopy ftpcount ftpcp ftpdctl ftpgrab ftpls ftppass ftpsync ftpsync-cron ftptop ftpwatch ftpwho ftsdf ftstring ftvalid ftview ftwhich fuidshift fulla fullcircle fullquottel funcalc funcen funcnts funcoeszz funcone fundisp funhead funhist funimage funindex funjoin funmerge funnel funpack funsky funtable funtbl funzip (1) - filter for extracting from a ZIP archive in a pipe fuse-ext2 fuse-gtk fuse-overlayfs fuse-sdl fuse-zip fuse2fs fuseext2 fusefat fuseiso fuseiso9660 fusermount-glusterfs fusion-icon fusioninventory-agent fusioninventory-esx fusioninventory-injector fusioninventory-inventory fusioninventory-netdiscovery fusioninventory-netinventory fusioninventory-remoteinventory fusioninventory-wakeonlan futatabi futility fuzz fuzzel fuzzer_corpus fuzznuc fuzzpro fuzztran fuzzylite fv fvdeinfo fvdemount fvdewipekey fvwm-crystal fvwm-crystal.apps fvwm-crystal.generate-menu fvwm-crystal.infoline fvwm-crystal.mplayer-wrapper fvwm-crystal.play-movies fvwm-crystal.videomodeswitch+ fvwm-crystal.videomodeswitch- fvwm-crystal.wallpaper fvwm1 fvwm2 fvwm2-config fvwm2-convert-2.6 fvwm2-menu-desktop fvwm2-menu-directory fvwm2-menu-headlines fvwm2-menu-xlock fvwm2-perllib fvwm2-root fvwm3 fvwm3-config fvwm3-convert-2.6 fvwm3-menu-desktop fvwm3-menu-directory fvwm3-menu-xlock fvwm3-perllib fvwm3-root tc-fw (8) - fwmark traffic control filter fw_printenv fw_setenv fwanalog fwb_compile_all fwb_iosacl fwb_ipf fwb_ipfw fwb_ipt fwb_pf fwb_pix fwb_procurve_acl fwbedit fwbuilder fweave fwexec fwflash fwknop fwupdagent fwupdate fwupdmgr fwupdtool fxlogin fxt_print fy-compose fy-dump fy-filter fy-join fy-testsuite fy-tool fy-ypath fyre fz fzf fzf-tmux fzn-gecode fzy g++ g++-10 g++-11 g++-12 g-ir-annotation-tool g-ir-compiler g-ir-doc-tool g-ir-generate g-ir-inspect g-ir-scanner g-lensfun-update-data g10k g213-led g2c g2p-sk g32pbm g3cat g3data g3dviewer g3tolj g3topbm g3toxwd g410-led g413-led g512-led g513-led g610-led g810-led g815-led g910-led ga-config gabbi-run gabedit gac gacutil (1) - Global Assembly Cache management utility. gadap-config gaeval gaffitter gaiksaurus gainLoss gajim gajim-remote galculator (1) - a GTK 2 / GTK 3 based scientific calculator galera_new_cluster (1) - starting a new Galera cluster galera_recovery (1) - recover from non-graceful shutdown galileo gallery-dl gallery1-to-slideshow galleta galternatives gambas3 gambas3.gambas gambcomp-C gambcomp-java gambcomp-js gambcomp-php gambcomp-python gambcomp-ruby gambdoc gambitToFoam gameconqueror gamemoded gamgi gamma4scanimage (1) - create a gamma table for scanimage gammaray gammastep gammastep-indicator gammu gammu-config gammu-detect gammu-smsd gammu-smsd-inject gammu-smsd-monitor ganesha-rados-grace ganesha.nfsd ganglia2pcp gant ganyremote gap gap-tester gap2deb gap4 gap5 gapcleaner gapi2-codegen gapi2-fixup gapi2-parser gapi3-codegen gapi3-fixup gapi3-parser gappa gapplication (1) - D-Bus application launcher gaps garagemq garb-systemd garbd garli garli-mpi garlic garmin_dump garmin_gchart garmin_get_info garmin_gmap garmin_gpx garmin_save_runs garnier gather_stx_titles gatttool (1) - tool for Bluetooth Low Energy device gaupol gaussian_analyzer gausssum gav1_decode gavf-demux gavf-encode gavf-filter gavf-info gavf-mux gavf-read gavf-recompress gavf-record gavf-tee gavo gawk (1) - pattern scanning and processing language gba3 gbacorr gbaepfit gbak (1) - - backup /restore Firebird database gbalafit gbb_utility gbbin gbboot gbc3 gbconvtable gbdfed gbdist gbdummyfy gbemol gbenv gbepfit gbf2xml gbfilternear gbfun gbgcorr gbget gbglreg gbgoffice gbgrid gbh3 gbh3.gambas gbhill gbhisto gbhisto2d gbi3 gbinterp gbker gbker2d gbklatex gbkpdflatex gbkreg gbkreg2d gblaepfit gblafit gblreg gbmave gbmodes gbmstat gbnear gbnlmult gbnlpanel gbnlpolyit gbnlprobit gbnlqreg gbnlreg gbonds gbp gbplot gbquant gbr3 gbrand gbrowse_aws_balancer gbrowse_change_passwd gbrowse_clean gbrowse_configure_slaves gbrowse_create_account gbrowse_grow_cloud_vol gbrowse_import_ucsc_db gbrowse_metadb_config gbrowse_set_admin_passwd gbrowse_slave gbrowse_syn_load_alignment_database gbrowse_syn_load_alignments_msa gbrowse_sync_aws_slave gbs2gb gbs3 gbs3.gambas gbseqget gbsinfo gbsplay gbstat gbtest gbw3 gbx3 gbxcorr gc (1) - count graph components gc-eigensoft gc_coverage_bias gc_coverage_bias_plot gcab gcal gcal2txt gcalccmd gcalcli gcap gcaps gcc gcc-10 gcc-11 gcc-12 gcc-ar (1) - a wrapper around ar adding the --plugin option gcc-ar-10 (1) - a wrapper around ar adding the --plugin option gcc-ar-11 gcc-ar-12 (1) - a wrapper around ar adding the --plugin option gcc-nm (1) - a wrapper around nm adding the --plugin option gcc-nm-10 (1) - a wrapper around nm adding the --plugin option gcc-nm-11 gcc-nm-12 (1) - a wrapper around nm adding the --plugin option gcc-ranlib (1) - a wrapper around ranlib adding the --plugin option gcc-ranlib-10 (1) - a wrapper around ranlib adding the --plugin option gcc-ranlib-11 gcc-ranlib-12 (1) - a wrapper around ranlib adding the --plugin option gccbrig-10 gccbrig-11 gccgo gccgo-10 gccgo-11 gccgo-12 gccmakedep gcdiff gchem3d gchem3d-0.14 gchemcalc gchemcalc-0.14 gchempaint gchempaint-0.14 gchemtable gchemtable-0.14 gcin gcin-exit gcin-gb-toggle gcin-kbm-toggle gcin-message gcin-tools gcin2tab gcl gclock gclose gcloseall gcm-import gcm-inspect gcm-picker gcm-viewer gcmd-block gcnmz gcode_sectioncut gcolor3 gconf-merge-tree gconftool gconftool-2 gconjugue gcore (1) - Generate core files for running processes gcov gcov-10 gcov-11 gcov-12 gcov-dump gcov-dump-10 gcov-dump-11 gcov-dump-12 gcov-tool gcov-tool-10 gcov-tool-11 gcov-tool-12 gcov2perl gcovr gcp gcr-viewer gcrystal gcrystal-0.14 gct-tool gcv gcv-int32 gcv-int64 gcv-long gcx gd2copypal gd2i gd2togif gd2topng gda-list-config-5.0 gda-list-server-op-5.0 gda-sql-5.0 gda-test-connection-5.0 gdal-config gdal2tiles.py gdal2xyz.py gdal_calc.py gdal_contour gdal_create gdal_edit.py gdal_fillnodata.py gdal_grid gdal_merge.py gdal_pansharpen.py gdal_polygonize.py gdal_proximity.py gdal_rasterize gdal_retile.py gdal_sieve.py gdal_translate gdal_viewshed gdaladdo gdalattachpct.py gdalbuildvrt gdalcompare.py gdaldem gdalenhance gdalinfo gdallocationinfo gdalmanage gdalmdiminfo gdalmdimtranslate gdalmove.py gdalsrsinfo gdaltindex gdaltransform gdalwarp gdb gdb-add-index gdb-multiarch gdbdump gdbload gdbm_dump gdbm_dump-nolfs gdbm_load gdbm_load-nolfs gdbmtool gdbmtool-nolfs gdbserver gdbtui gdbus (1) - Tool for working with D-Bus objects gdbus-codegen (1) - D-Bus code and documentation generator gdc gdc-10 gdc-11 gdc-12 gdcm2pnm gdcm2vtk gdcmanon gdcmclean gdcmconv gdcmdiff gdcmdump gdcmgendir gdcmimg gdcminfo gdcmpap3 gdcmpdf gdcmpgif gdcmraw gdcmscanner gdcmscu gdcmtar gdcmviewer gdcmxml gddccontrol gdebi gdebi-gtk gdf_merger gdialog gdiffmk gdigi gdis gdistribution gdk-pixbuf-csource (1) - C code generation utility for GdkPixbuf images gdk-pixbuf-pixdata (1) - GDK Pixbuf library gdk-pixbuf-thumbnailer gdk_pixbuf_mlsource gdl gdlpp gdm-control gdm-screenshot (1) - take a picture of the screen gdm3 (8) - take a picture of the screen gdmap gdmd gdmflexiserver (1) - take a picture of the screen gdnc gdomap gdparttopng gdpc gdtopng gdu gdump gdump-int32 gdump-int64 gdump-long ge geany gearadmin gearman gearmand geary gedit geecee geeqie geg gegl gegl-imgcmp gegps geldkarte gelemental gem gem2deb gem2deb-test-runner gem2tgz gem3.0 gem3.1 gemma gemmi gemtopbm gemtopnm gen gen-auth gen-ctl-io gen-multiple-pysol-layouts gen-psf-block gen-ruby-trans-pkgs gen-torrent-from-ptcl gen_binary_files gen_keymap gen_packets gen_scheme gen_unigram genbank_get_genomes_by_taxon.py genbrk gencat (1) - Generate message catalog gencfg gencfu gencnval gencoil genconfig2 gendarme gendarme-wizard gendef gendesc gendict gendiff (1) - utility to aid in error-free diff file generation gene2xml gene_fourfold_sites.py gene_info_reader geneparse geneparse-mpi generate-borgmatic-config generate-git-snapshot generate-reprepro-codename generate-subunit generate-svn-snapshot generate_lut_template generate_pbs_nodefile generate_test_clusters generic generic_count genewise genewisedb genext2fs genfio genfstab gengetopt genhash genhtml genidl genimage geninfo genior genisoimage genius genl-ctrl-list genmakefile genmk genny genome genome-model-tools genomeCoverageBed genomeCoverageBed.pl genomewise genotype2mipe genpat genpeimg genpmda genpmk genpng genpyt genrb genresscript genromfs gensample genserkins gensiot genspic2gnuplot gensquashfs gentest gentoo gentrigrams genwqe_cksum genwqe_csv2vpd genwqe_echo genwqe_ffdc genwqe_gunzip genwqe_gzip genwqe_memcopy genwqe_mt_perf genwqe_peek genwqe_poke genwqe_test_gz genwqe_update genwqe_vpdconv genwqe_vpdupdate genx genxdr genxs geo geocode geocpset geod geoedit geogebra geoiplookup geoiplookup6 geomet geomview geophar georss2foxtrotgps-poi geos-config geosop geotifcp geotranz geqn (1) - format equations for troff or MathML gerbera gerbv gerbview germinate germinate-pkg-diff germinate-update-metapackage gerris2D gerris3D gertty ges-launch-1.0 get-default-ips get-drbl-conf-param get-edid get-healpix get-latest-ocs-live-ver get-theme-d-config-var get-wcs getAlignmentWindows getCounts getData getFoldChange getFromNpmCache getGeneExpression getOrthologList getOverlap getPPLR getSeq getVariance getWithinGeneExpression get_all_vfdb get_comment get_environment get_fragment_length.py get_genus_vfdb get_machine get_moz_enUS get_root_domain get_scores_in_intervals.py get_sloc get_sloc_details get_species_taxids getabstime getaddrinfo (3) - network address and service translation getafm getbuildlog getcert getcifsacl getcol getconf (1) - Query system configuration variables getdap getdap4 getdate (3) - convert a date-plus-time string to broken-down time getdefs getdns_query getdns_server_mon getdp getdp-sparskit geteltorito getent (1) - get entries from Name Service Switch libraries getent.ldap getfattr getfdprm getfem-config getfits getgo gethead gethist gethost gethostip geticonset getinstrs getkeycodes getmail getmail-gmail-xoauth-tokens getmail_fetch getmail_maildir getmail_mbox getmails getmapdl getmesh getmlst getopt (1) - parse command options (enhanced) getopt (3) - Parse command-line options getorf getpdffontobject getpdfpage getpdfpageobject getpdftext getpeername (2) - get name of connected peer socket getpib getpix getpub getscu getsockname (2) - get socket name getstream getstyle getsubids gettab gettext (1) - translate message gettext (3) - translate message gettext.sh gettextize (1) - install or upgrade gettext infrastructure getwordfreq gexamp gexample gexec gf2pbm gf_add gf_div gf_inline_time gf_methods gf_mult gf_poly gf_time gf_unit gfadiff gfal-archivepoll gfal-bringonline gfal-cat gfal-chmod gfal-copy gfal-evict gfal-legacy-bringonline gfal-legacy-register gfal-legacy-replicas gfal-legacy-unregister gfal-ls gfal-mkdir gfal-rename gfal-rm gfal-save gfal-stat gfal-sum gfal-token gfal-xattr gfal2_version gfal_srm_ifce_version gfan gfan_bases gfan_buchberger gfan_combinerays gfan_doesidealcontain gfan_fancommonrefinement gfan_fanhomology gfan_fanisbalanced gfan_fanlink gfan_fanproduct gfan_fansubfan gfan_genericlinearchange gfan_groebnercone gfan_groebnerfan gfan_homogeneityspace gfan_homogenize gfan_initialforms gfan_interactive gfan_ismarkedgroebnerbasis gfan_krulldimension gfan_latticeideal gfan_leadingterms gfan_list gfan_markpolynomialset gfan_minkowskisum gfan_minors gfan_mixedvolume gfan_overintegers gfan_padic gfan_polynomialsetunion gfan_render gfan_renderstaircase gfan_resultantfan gfan_saturation gfan_secondaryfan gfan_stats gfan_substitute gfan_symmetries gfan_tolatex gfan_topolyhedralfan gfan_tropicalbasis gfan_tropicalbruteforce gfan_tropicalcurve gfan_tropicalevaluation gfan_tropicalfunction gfan_tropicalhypersurface gfan_tropicalintersection gfan_tropicallifting gfan_tropicallinearspace gfan_tropicalmultiplicity gfan_tropicalrank gfan_tropicalstartingcone gfan_tropicaltraverse gfan_tropicalweildivisor gfan_version gfapy-convert gfapy-mergelinear gfapy-renumber gfapy-validate gfarm-pcp gfarm-prun gfarm-ptool gfarm.arch.guess gfarm2fs gfarmbb gfchgrp gfchmod gfchown gfcksum gfcombine gfdf gfdirpath gfdirquota gfdump.postgresql gfedquota gfeeds gfexport gff2aplot gff2bed gff2gff.py gff2ps gff2sga.pl gff2starch gffindxmlattr gffread gffutils-cli gfgetfacl gfgroup gfhost gfhostgroup gfio gfix (1) - - miscelenous Firebird database maintenance gfjournal gfjournaladmin gfjournaldump gfkey gflags2man gfln gfls gflsof gfm gfmdhost gfmkdir gfmv gfncopy gforth gforth-0.7.3 gforth-fast gforth-fast-0.7.3 gforth-itc gforth-itc-0.7.3 gforthmi gforthmi-0.7.3 gfortran gfortran-10 gfortran-11 gfortran-12 gfpath gfpcopy gfpcopy-stress gfpcopy-test.sh gfprep gfquota gfquotacheck gfreg gfrep gfrm gfrmdir gfruntest gfs-highlight gfs2gfs gfs2oogl2D gfs2oogl3D gfsched gfscombine2D gfscombine3D gfscompare2D gfscompare3D gfsec-split gfsec-split-gpg gfsec-use gfservice gfservice-agent gfservice-timeout gfsetfacl gfsjoin gfsjoin2D gfsjoin3D gfsplit gfsplot gfspooldigest gfspoolgen gfspoolinum gfspoolmd5 gfspoolpath gfstat gfstatus gfsudo gfsview gfsview-batch2D gfsview-batch3D gfsview2D gfsview3D gfsxref gftest gftodvi gftools gftools-add-axis gftools-add-font gftools-build-font2ttf gftools-build-ofl gftools-build-vf gftools-check-bbox gftools-check-category gftools-check-copyright-notices gftools-check-font-version gftools-check-gf-github gftools-check-name gftools-check-sandbox-family gftools-check-vf-avar gftools-check-vtt-compatibility gftools-check-vtt-compile gftools-compare-font gftools-dump-names gftools-family-html-snippet gftools-find-features gftools-fix-ascii-fontmetadata gftools-fix-cmap gftools-fix-dsig gftools-fix-family gftools-fix-familymetadata gftools-fix-font gftools-fix-fsselection gftools-fix-fstype gftools-fix-gasp gftools-fix-glyph-private-encoding gftools-fix-glyphs gftools-fix-hinting gftools-fix-isfixedpitch gftools-fix-nameids gftools-fix-nonhinting gftools-fix-ttfautohint gftools-fix-unwanted-tables gftools-fix-vendorid gftools-fix-vertical-metrics gftools-fix-vf-meta gftools-fix-weightclass gftools-font-diff gftools-font-weights-coverage gftools-gen-stat gftools-list-italicangle gftools-list-panose gftools-list-variable-source gftools-list-weightclass gftools-list-widthclass gftools-metadata-vs-api gftools-namelist gftools-nametable-from-filename gftools-ots gftools-packager gftools-push-status gftools-qa gftools-rangify gftools-rename-font gftools-sanity-check gftools-space-check gftools-test-gf-coverage gftools-ttf2cp gftools-unicode-names gftools-update-families gftools-update-nameids gftools-update-version gftools-varfont-info gftools-what-subsets gftopk gftp gftp-gtk gftp-text gftype gfusage gfuser gfwhere gfwhoami gfxattr gfxboot gfxboot-compile gfxboot-font gfxrecon-capture.py gfxrecon-compress gfxrecon-extract gfxrecon-info gfxrecon-optimize gfxrecon-replay gfxrecon.py gfxtest ggobi ggrapher ggrc ggsearch36 ggthumb gh gh-gitsome ghb ghc ghc-9.0.2 ghc-events ghc-pkg ghc-pkg-9.0.2 ghcal ghcal-he ghci ghci-9.0.2 ghdiff ghemical gherkin-generate-ast gherkin-generate-pickles gherkin-generate-tokens ghex ghkl ghmm-cluster ghmm-config ghostess ghostess_universal_gui ghostscript (1) - Ghostscript (PostScript and PDF language interpreter and previewer) ghoz ghp-import ghwdump gi-docgen giac giada giblib-config gid gidmigrator gids-tool gie gif2h5 gif2hdf gif2rgb gif2webp gifbuild gifclrmp gifdiff giffix gifshuffle gifsicle giftext gifti_test gifti_tool giftogd2 giftool giftopnm giftrans gifview gifwrap gig2mono gig2stereo gigdump gigextract giggle gigmerge gigolo gil2bin gimagereader-gtk gimagereader-qt5 gimp gimp-2.10 gimp-console gimp-console-2.10 gimp-test-clipboard-2.0 gimptool-2.0 ginga ginkgo ginsh ginstall-info ginsttest-runner gio (1) - GIO commandline tool gio-querymodules (1) - GIO module cache creation gip gipddecode gir-generator girtod gist gist-paste Git (3pm) - Perl interface to the Git version control system git (1) - the stupid content tracker git-abort git-alias git-annex git-annex-remote-datalad git-annex-remote-datalad-archives git-annex-remote-ora git-annex-remote-rclone git-annex-reviewunused git-annex-shell git-archive-file git-authors git-autofixup git-big-picture git-bloom-branch git-bloom-config git-bloom-generate git-bloom-import-upstream git-bloom-patch git-bloom-release git-branchmove git-browse git-browse-ci git-brv git-build-recipe git-bulk git-bump git-cache-proxy git-changelog git-clang-format git-clang-format-13 git-clang-format-14 git-clang-format-15 git-clean-forge-fork git-clean-forge-repo git-clear git-clear-soft git-coauthor git-cola git-cola-sequence-editor git-commits-since git-contrib git-count git-cp git-create-branch git-credential-datalad git-crypt git-cvsserver git-dag git-debcherry git-debimport git-deborig git-debpush git-debrebase git-delete-branch git-delete-merged-branches git-delete-squashed-branches git-delete-submodule git-delete-tag git-delta git-dpm git-effort git-evtag git-extras git-feature git-filter-repo git-flow git-flow-bugfix git-flow-config git-flow-feature git-flow-hotfix git-flow-init git-flow-log git-flow-release git-flow-support git-flow-version git-force-clone git-fork git-fresh-branch git-ftp git-graft git-guilt git-hg-helper git-hub git-icdiff git-ignore git-ignore-io git-ime git-imerge git-info git-latexdiff git-lfs git-linguist git-local-commits git-lock git-locked git-magic git-merge-changelog git-merge-into git-merge-repo git-missing git-mr git-nuke-forge-fork git-obliterate git-os-job git-paste git-pbuilder git-phab git-pr git-psykorebase git-publish git-pull-request git-pw git-quick-stats git-reauthor git-rebase-patch git-receive-pack (1) - Receive what is pushed into the repository git-reintegrate git-release git-remote-gcrypt git-remote-hg git-remote-tor-annex git-rename-branch git-rename-remote git-rename-tag git-repair git-repl git-reset-file git-review git-revise git-root git-rscp git-scp git-secret git-secrets git-sed git-setup git-shell (1) - Restricted login shell for Git-only SSH access git-show-merged-branches git-show-tree git-show-unmerged-branches git-squash git-stamp git-standup git-summary git-sync git-touch git-undo git-unlock git-upload-archive (1) - Send archive back to git-archive git-upload-pack (1) - Send objects packed back to git-fetch-pack git-utimes git2cl gita gitbatch gitbrute gitdiff gitdiffview gitflow-common gitflow-shFlags gitg github-debian-upstream github-linguist github-markup gitinspector gitk gitkeeper gitlab-api-v4 gitlab-markup gitlab-rulez gitlabracadabra gitlint gitolite gitpkg gitpuller gitso gitsome gitup givaro-config gjackclock gjacktransport gjh_asl_json gjiten gjs gjs-console gk gkbd-keyboard-display gkdebconf gkdebconf-term gkermit gkrellm gkrellmd gksm2ps gl glBars gla11y glabels-3 glabels-3-batch glacier2router glad glade glade-previewer gladevcp gladevcp_demo gladtex glam2 glam2-purge glam2format glam2mask glam2scan glance glance-api glance-cache-cleaner glance-cache-manage glance-cache-prefetcher glance-cache-pruner glance-control glance-manage glance-rootwrap glance-scrubber glance-status glance-wsgi-api glances glare glasscoder glasscommander glassconv glassgui glav glbsp glcontexts glean_parser glewinfo glewlwyd glfer glfunctions glib-compile-resources (1) - GLib resource compiler glib-compile-schemas (1) - GSettings schema compiler glib-genmarshal (1) - C code marshaller generation utility for GLib closures glib-gettextize (1) - gettext internationalization utility glib-mkenums (1) - C language enum description generation utility glilypond glimpse glimpseindex glimpseserver glistcompare glistmaker glistquery gliv glmark2 glmark2-drm glmark2-es2 glmark2-es2-drm glmark2-es2-wayland glmark2-wayland glmeta global globaltime globash globus-domainname globus-gass-cache globus-gass-cache-destroy globus-gass-cache-util globus-gass-server globus-gass-server-shutdown globus-hostname globus-job-cancel globus-job-clean globus-job-get-output globus-job-get-output-helper globus-job-run globus-job-status globus-job-submit globus-makefile-header globus-personal-gatekeeper globus-sh-exec globus-url-copy globus-version globus-xioperf globusrun glocal glogg glogic glom glom_create_from_example glom_test_connection glosstex glpsol glqueries glretrace glsearch36 glslangValidator glslminifier glsweep gltbx.python gltbx.show_build_path gltbx.show_dist_paths gltbx.try_imports gltfpack gltpd gltrim glue glue-sprite glurp glusterfind glxdemo glxdemo.x86_64-linux-gnu glxgears glxgears.x86_64-linux-gnu glxheads glxheads.x86_64-linux-gnu glxinfo glxinfo.x86_64-linux-gnu glyph_help glyphs2ufo glyphsets glyphterp glyrc gm gm-convert_file gm-create_datamatrix gm-describe_file gm-import_incoming gm-move_backups_offsite gm-print_doc gm-remove_person gm2 gm2-10 gm2-11 gm2-12 gm_ctl_client gmac gmail-imap-label gmake (1) - GNU make utility to maintain groups of programs gman gmanedit gmap gmap.nosimd gmap.sse2 gmap_build gmapl gmapl.nosimd gmapl.sse2 gmbi gmdns gmds gmediarender gmemusage gmenudbusmenuproxy gmer_caller gmer_counter gmerlin gmerlin-controlpanel gmerlin-controlpanel-ctl gmerlin-mediainfo gmerlin-play gmerlin-playerproxy gmerlin-record gmerlin-remote gmerlin-renderer gmerlin-server gmerlin-transcoder gmerlin-video-thumbnailer gmerlin_launcher gmerlin_recorder gmessage gmetric gmi gmi2email gmic gmic_krita_qt gmidimonitor gmime-uudecode gmime-uuencode gmixvm gmk_hy gmk_hy-int32 gmk_hy-int64 gmk_hy-long gmk_m2 gmk_m2-int32 gmk_m2-int64 gmk_m2-long gmk_m3 gmk_m3-int32 gmk_m3-int64 gmk_m3-long gmk_msh gmk_msh-int32 gmk_msh-int64 gmk_msh-long gmk_ub2 gmk_ub2-int32 gmk_ub2-int64 gmk_ub2-long gml2gv (1) - GML-DOT converters gmoccapy gmotionlive gmp3info gmpc gmrun gmsh gmshToFoam gmt gmt-config gmt_shell_functions.sh gmtkbabel gmtp gmtst gmtst-int32 gmtst-int64 gmtst-long gmtswitch gmx gmx_d gmx_mpi gmx_mpi_d gn gnarwl gnat gnat-10 gnat-11 gnat-12 gnatbind gnatbind-10 gnatbind-11 gnatbind-12 gnatchop gnatchop-10 gnatchop-11 gnatchop-12 gnatclean gnatclean-10 gnatclean-11 gnatclean-12 gnatfind gnatfind-10 gnatfind-11 gnatgcc gnathtml gnathtml-10 gnathtml-11 gnathtml-12 gnatkr gnatkr-10 gnatkr-11 gnatkr-12 gnatlink gnatlink-10 gnatlink-11 gnatlink-12 gnatls gnatls-10 gnatls-11 gnatls-12 gnatmake gnatmake-10 gnatmake-11 gnatmake-12 gnatname gnatname-10 gnatname-11 gnatname-12 gnatprep gnatprep-10 gnatprep-11 gnatprep-12 gnatxref gnatxref-10 gnatxref-11 gnb_crypto gnc-fq-check gnc-fq-dump gnc-fq-helper gnc-fq-update gngb gniall gnmanalyse gnmmanage gnocchi gnocchi-amqpd gnocchi-api gnocchi-change-sack-size gnocchi-config-generator gnocchi-injector gnocchi-metricd gnocchi-statsd gnocchi-upgrade gnokii gnomad2 gnome-activity-journal gnome-autogen.sh gnome-boxes gnome-builder gnome-calculator gnome-calendar gnome-calls gnome-characters gnome-clocks gnome-commander gnome-connections gnome-contacts gnome-control-center (1) - Configure GNOME settings gnome-desktop-testing-runner gnome-dictionary gnome-disk-image-mounter gnome-disks gnome-dvb-control gnome-dvb-daemon gnome-dvb-setup gnome-epub-thumbnailer gnome-extensions (1) - Command line tool for managing GNOME extensions gnome-extensions-app gnome-firmware gnome-flashback gnome-flashback-xmonad gnome-font-viewer gnome-genius gnome-help (1) - browse system documentation gnome-keyring (1) - The gnome-keyring commandline tool gnome-keyring-3 (1) - The gnome-keyring commandline tool gnome-keyring-daemon (1) - The gnome-keyring daemon gnome-keysign gnome-keysign-sign-key gnome-keysign-split-uids gnome-logs gnome-maps gnome-mobi-thumbnailer gnome-multi-writer gnome-music gnome-nds-thumbnailer gnome-nettool gnome-network-displays gnome-paint gnome-panel gnome-panel-control gnome-photos gnome-pie gnome-pomodoro gnome-power-statistics gnome-screensaver gnome-screensaver-command gnome-screenshot gnome-session (1) - Start the GNOME desktop environment gnome-session-classic gnome-session-inhibit (1) - inhibit gnome-session functionality gnome-session-quit (1) - End the current GNOME session gnome-session-remmina gnome-shell (1) - Graphical shell for the GNOME desktop gnome-shell-extension-prefs gnome-shell-extension-tool gnome-shell-perf-tool gnome-software gnome-sound-recorder gnome-split gnome-system-log gnome-system-log-pkexec gnome-system-monitor gnome-terminal gnome-terminal.wrapper gnome-text-editor gnome-thumbnail-font gnome-todo gnome-tweaks gnome-usage gnome-video-arcade gnome-weather gnomekiss gnomint gnomint-cli gnomint-upgrade-db gnote gnss-sdr gntp-send gnuais gnuaisgui gnuattach.xemacs21 gnubiff gnucap gnucap-conf gnucap-modelgen gnucap2genspic gnucash gnucash-cli gnuclient.xemacs21 gnudoit.xemacs21 gnuhtml2latex gnulib-tool gnumed gnumeric gnunet-arm gnunet-ats gnunet-auto-share gnunet-base32 gnunet-bugreport gnunet-cadet gnunet-config gnunet-consensus-profiler gnunet-conversation gnunet-conversation-gtk gnunet-conversation-test gnunet-core gnunet-crypto-tvg gnunet-datastore gnunet-dht-get gnunet-dht-hello gnunet-dht-monitor gnunet-dht-put gnunet-did gnunet-directory gnunet-download gnunet-ecc gnunet-fs gnunet-fs-gtk gnunet-fuse gnunet-gns gnunet-gns-proxy-setup-ca gnunet-gnsrecord-tvg gnunet-identity gnunet-messenger gnunet-namecache gnunet-namestore gnunet-namestore-gtk gnunet-nat gnunet-nat-auto gnunet-nat-server gnunet-nse gnunet-peerinfo gnunet-peerinfo-gtk gnunet-peerstore gnunet-publish gnunet-qr gnunet-reclaim gnunet-resolver gnunet-revocation gnunet-revocation-tvg gnunet-scalarproduct gnunet-scrypt gnunet-search gnunet-secretsharing-profiler gnunet-set-profiler gnunet-seti-profiler gnunet-setu-profiler gnunet-setup gnunet-setup-pkexec gnunet-statistics gnunet-statistics-gtk gnunet-suidfix gnunet-testbed-profiler gnunet-testing gnunet-transport gnunet-transport-certificate-creation gnunet-unindex gnunet-uri gnunet-vpn gnunet-zoneimport gnupg-pkcs11-scd gnupg-pkcs11-scd-proxy gnupg-pkcs11-scd-proxy-server gnuplot-nox gnuplot-qt gnuplot-x11 gnupod_INIT gnupod_addsong gnupod_check gnupod_convert_APE gnupod_convert_FLAC gnupod_convert_MIDI gnupod_convert_OGG gnupod_convert_RIFF gnupod_otgsync gnupod_search gnuradio-companion gnuradio-config-info gnusim8085 gnustep-config gnustep-tests gnutls-cli gnutls-cli-debug gnutls-serv gnutv go go-10 go-11 go-12 go-apply-xslt go-bindata go-contrib-init go-dag-summary go-export-graph go-export-prolog go-filter-subset go-for-it go-git go-infocmp go-md2man go-mmproxy go-mtpfs go-org go-rpmdb go-sendxmpp go-show-assocs-by-node go-show-paths-to-root go-staticcheck go2chadoxml go2error_report go2fmt go2godb_prestore go2obo go2obo_html go2obo_text go2obo_xml go2owl go2pathlist go2prolog go2rdf go2rdfxml go2summary go2sxpr go2tbl go2text_html go2xml goaccess goattracker gob2 gobby gobby-0.5 gobby-infinote gobgp gobgpd gobject-query (1) - display a tree of types gobuster goby gocc gocr gocr-tk gocryptfs gocryptfs-xray god godef godex godoc godot3 godot3-runner godot3-server gofail gofmt gofmt-10 gofmt-11 gofmt-12 goiardi goid-tool goimports gojay gojq gokey gol golang-authtest golang-bundle golang-cookieauth golang-eg golang-fieldalignment golang-findcall golang-gitauth golang-guru golang-ifaceassert golang-lostcancel golang-netrcauth golang-nilness golang-petname golang-shadow golang-statik golang-stress golang-stringintconv golang-unmarshal gold (1) - The GNU ELF linker goldendict goldeneye gomidas gomvpkg goname goo goobook goobox goodvibes goodvibes-client google-authenticator google-oauthlib-tool google-pprof google-wire google_authorized_keys google_authorized_keys_sk google_guest_agent google_metadata_script_runner google_oslogin_control google_oslogin_nss_cache googler googlism gopackages gopass gopchop gopen gopher gophfilt gopls gord gord-int32 gord-int64 gord-long gorename gorge gortr gosop gost12-256-hash gost12-512-hash gost12sum gostsum gosty gotail gotestsum gotox gotst gotst-int32 gotst-int64 gotst-long gotype gouldtoppm gource gourmand gout gout-int32 gout-int64 gout-long govulncheck gox goxkcdpwgen goyacc gozer gozilla gp gp-2.15 gp-archive (1) - archive gprofng experiment data gp-collect-app (1) - collect performance data for the target application gp-display-html (1) - generate an HTML based directory structure to browse the profiles gp-display-src (1) - display the source code, optionally interleaved with the disassembly of the target object gp-display-text (1) - display the performance data in plain text format gp-saml-gui gp2c gp2c-dbg gp2c-run gpa gpac gpasm gpasswd (1) - administer /etc/group and /etc/gshadow gpaste-client gpaw gpaw-analyse-basis gpaw-basis gpaw-plot-parallel-timings gpaw-runscript gpaw-setup gpaw-upfplot gpbs gpdasm gperf gperiodic gperl gpg (1) - OpenPGP encryption and signing tool gpg-agent (1) - Secret key management for GnuPG gpg-connect-agent (1) - Communicate with a running agent gpg-error gpg-key2latex gpg-key2ps gpg-mailkeys gpg-remailer gpg-sign-all gpg-wks-server (1) - Server providing the Web Key Service gpg-zip (1) - encrypt or sign files into an archive gpg1 gpg2 (1) - OpenPGP encryption and signing tool gpgcompose (1) - Generate a stream of OpenPGP packets gpgconf (1) - Modify .gnupg home directories gpgdir gpglist gpgmailtunl gpgme-tool gpgparsemail (1) - Parse a mail message into an annotated format gpgparticipants gpgparticipants-filter gpgparticipants-prefill gpgrt-config gpgsigs gpgsm (1) - CMS encryption and signing tool gpgsplit (1) - Split an OpenPGP message into packets gpgtar (1) - Encrypt or sign files into an archive gpgv (1) - Verify OpenPGP signatures gpgv-static gpgv1 gpgv2 gpgwrap gphelp gphoto2 gphotofs gpic (1) - compile pictures for troff or TeX gpick gpicview gpinyin gpiodetect gpiofind gpioget gpioinfo gpiomon gpioset gpk-application gpk-log gpk-prefs gpk-update-viewer gplib gplink gpmetis gpo gpodder gpodder-migrate2tres gpomme gpp gpre (1) - Firebird source pre-processor gpredict gprename gpro-led gprocmeter3 gprof (1) - display call graph profile data gprofng (1) - the driver for the gprofng tool suite gprompter gps2rawlog gps2udp gpsbabel gpsbabelfe gpscat gpscorrelate gpscorrelate-gui gpscsv gpsctl gpsdecode gpsfake gpsh gpsim gpsman gpsmon gpspipe gpsplot gpsprof gpsprune gpsrinex gpssubframe gpstrans gpstrip gpt gpu-chk gpu-ls gpu-mon gpu-pac gpu-plot gpvc gpvo gpw gpx gpx2osm gpxinfo gpxlogger gpxviewer gqinitq gqkillq gqrx gr-ctrlport-monitor gr-perf-monitorx gr2fonttest gr_filter_design gr_modtool gr_plot gr_plot_const gr_plot_fft gr_plot_iq gr_plot_psd gr_plot_qt gr_read_file_metadata gr_satellites grab-account grab-merge grab_vcsa-3.2.2 grabber grabc grabix grabserial grace grace-thumbnailer gracebat gracket gracket-text gradle grads grafx2 grail-test-3-1 grail-test-atomic grail-test-edge grail-test-propagation grainextract gram-ga grammalecte-cli grammalecte-server gramofile gramps granite-7-demo granite-demo grantlee_strings_extractor.py grap grap2graph graph graph-easy graph-includes graph-slam graph2tree graphc graphchk graphdefang.pl graphdraw graphdump graphite-build-search-index graphite-manage graphlan graphlan_annotate graphml2gv (1) - GRAPHML-DOT converter graphslam-engine grass gravit graywolf grc grc65 grcat grcc grcollect grcompiler grconvert grdctl (1) - Command line tool for configuring GNOME Remote Desktop grdecl2vtu grdecldips grdesktop greflector gregorio gremlin_view grep-aptavail (1) - grep Debian control files grep-available (1) - grep Debian control files grep-dctrl (1) - grep Debian control files grep-debtags (1) - grep Debian control files grep-excuses grep-merges grep-status (1) - grep Debian control files grepcidr grepdiff (1) - show files modified by a diff containing a regex grepjar grepmail grepmidi grepseq gresource (1) - GResource tool gretl gretl_edit gretl_x11 gretlcli gretlmpi greylist greytiff grfcodec grfid grfstrip grgsm_capture grgsm_channelize grgsm_decode grgsm_livemon grgsm_livemon_headless grgsm_scanner grgsm_trx gri gri-2.12.27 gri909 gri_merge gri_unpage grib2bufr grib2fdb5 grib2ppm grib2scan grib_compare grib_copy grib_count grib_dump grib_filter grib_get grib_get_data grib_histogram grib_index_build grib_list grib_ls grib_merge grib_repack grib_set grib_to_netcdf gribmap gribscan grid-ca-create grid-ca-package grid-ca-sign grid-cert-diagnostics grid-cert-info grid-cert-request grid-change-pass-phrase grid-matching grid-proxy-destroy grid-proxy-info grid-proxy-init grid_geometry griffe grig grilo-test-ui-0.3 grim grimshot grind grinder gringo gringotts grisbi grk_compress grk_decompress grk_dump grl-inspect-0.3 grl-launch-0.3 grmatch grn grndb grodvi groff (1) - front-end for the groff document formatting system groffer grog (1) - guess options for a following groff command grok grokevt-addlog grokevt-builddb grokevt-dumpmsgs grokevt-findlogs grokevt-parselog grokevt-ripdll grolbp grolj4 gromit gromit-mpx gron groo-ga groonga groonga-suggest-create-dataset groonga-suggest-httpd groonga-suggest-learner grop gropdf grops (1) - PostScript driver for groff gropt grotty (1) - groff driver for typewriter-like devices group-manager-server groupBy groupmanage groups (1) - print the groups a user is in grow_fuse growisofs growl growpart grpc_cpp_plugin grpc_csharp_plugin grpc_java_plugin grpc_node_plugin grpc_objective_c_plugin grpc_php_plugin grpc_python_plugin grpc_ruby_plugin grpc_tools_ruby_protoc grpc_tools_ruby_protoc_plugin grpn grsync grsync-batch grtrans grub-customizer grub-editenv grub-emu grub-emu-lite grub-file grub-fstest grub-glue-efi grub-kbdcomp grub-menulst2cfg grub-mkfont grub-mkimage grub-mklayout grub-mknetdir grub-mkpasswd-pbkdf2 grub-mkrelpath grub-mkrescue grub-mkstandalone grub-mount grub-ntldr-img grub-render-label grub-script-check grub-syslinux2cfg grun grunt gs (1) - Ghostscript (PostScript and PDF language interpreter and previewer) gs-mount gs-netcat gs-sftp gs.pvm gs2_vfd gsa gsasl gsbj (1) - Format and print text for BubbleJet printer using ghostscript gsc gsc-script gscan2pdf gscanbus gscat gscat-int32 gscat-int64 gscat-long gsch2pcb-rnd gscreen gscriptor gsd gsdh_gnustep gsdj (1) - Format and print text for DeskJet printer using ghostscript gsdj500 (1) - Format and print text for DeskJet 500 BubbleJet using ghostscript gse_mapviewer gsec (1) - - deprecated Firebird user management utility gsequencer gsetroot gsettings (1) - GSettings configuration tool gsettings-data-convert gsettings-schema-convert gsf gsf-office-thumbnailer gsf-vba-dump gsftopk gsharp gsi gsi-script gsimplecal gsl gsl-config gsl-histogram gsl-randist gslj (1) - Format and print text for LaserJet printer using ghostscript gslp (1) - Format and print text using ghostscript gsmartcontrol-root gsmctl gsmpb gsmsendsms gsmsiectl gsmsiexfer gsmsmsd gsmsmsrequeue gsmsmsspool gsmsmsstore gsnap gsnap.nosimd gsnap.sse2 gsnapl gsnapl.nosimd gsnapl.sse2 gsnd (1) - Run ghostscript (PostScript and PDF engine) without display gsocket gsort gsound-play gspath gspectrum gspectrum-0.14 gss gss-client gss-server gssdp-device-sniffer gssdp-discover gsstool gst-device-monitor-1.0 gst-discoverer-1.0 gst-inspect-1.0 (1) - print info about a GStreamer plugin or element gst-launch-1.0 (1) - build and run a GStreamer pipeline gst-omx-listcomponents gst-play-1.0 gst-stats-1.0 (1) - print info gathered from a GStreamer log file gst-tester-1.0 gst-transcoder-1.0 gst-typefind-1.0 (1) - print Media type of file gst123 gst2ascii gstat gsutil gt gt5 gt7cvt gt_mpi_gather gta2dot gtab-db-gen gtab-merge gtags gtags-cscope gtbl (1) - format tables for troff gtdcleanup gted gtester (1) - test running utility gtester-report (1) - test report formatting utility gtf (1) - calculate VESA GTF mode lines gtf2bed gtf2gff3 gtf2starch gtg_compress gtg_decompress gth gthbssmbuild gthbssmfileinfo gthbssmprint gthbssmrmsd gthbssmtrain gthcli gthconsensus gthd gthfilestat gthgetseq gthmkbssmfiles gthsplit gthumb gtick gtimelog gtimer gtk-builder-convert gtk-builder-tool (1) - GtkBuilder file utility gtk-chtheme gtk-demo gtk-encode-symbolic-svg (1) - Symbolic icon conversion utility gtk-launch (1) - Launch an application gtk-layer-demo gtk-query-settings (1) - Utility to print name and value of all GtkSettings properties gtk-redshift gtk-sharp2-examples-list gtk-theme-switch2 gtk-update-icon-cache (1) - Icon theme caching utility gtk-wave-cleaner gtk-window-decorator gtk2hsC2hs gtk2hsHookGenerator gtk2hsTypeGen gtk3-demo gtk3-demo-application gtk3-icon-browser gtk3-nocsd gtk3-widget-factory gtk4-broadwayd (1) - The Broadway display server gtk4-builder-tool (1) - GtkBuilder File Utility gtk4-demo gtk4-demo-application gtk4-encode-symbolic-svg (1) - Symbolic icon conversion utility gtk4-icon-browser gtk4-launch (1) - Launch an application gtk4-node-editor gtk4-print-editor gtk4-query-settings (1) - Print name and value of GTK settings gtk4-update-icon-cache (1) - Icon theme caching utility gtk4-widget-factory gtkam gtkcrypto gtkdoc-check gtkdoc-depscan gtkdoc-fixxref gtkdoc-mkdb gtkdoc-mkhtml gtkdoc-mkhtml2 gtkdoc-mkman gtkdoc-mkpdf gtkdoc-rebase gtkdoc-scan gtkdoc-scangobj gtkdocize gtkguitune gtkhash gtklp gtklpq gtkmorph gtkpod gtksourceview5-widget gtkspu gtkterm gtkwave gtlsclient gtlssh gtlssh-keygen gtlssync gtml gtp-echo-responder gtranscribe gtranslator gts-config (1) - defines values for programs using gts. gts2dxf (1) - converts a GTS file to DXF format. gts2oogl (1) - converts a GTS file to OOGL file format (Geomview). gts2stl (1) - converts a GTS file to STL format gts2xyz gts_compare gts_copy gts_count gts_dump gts_filter gts_get gts_ls gtscheck (1) - checks that a surface defines a closed, orientable non self-intersecting manifold. gtscompare (1) - compare two GTS files. gtst gtst-int32 gtst-int64 gtst-long gtstemplate (1) - generates of a template used to create new object classes. gtts-cli gtypist guake guake-indicator guake-toggle guard guards gubbins_drawer gucharmap gucumber gudhi-alpha-complex-3d-persistence gudhi-alpha-complex-persistence gudhi-bottleneck-distance gudhi-cech-persistence gudhi-cubical-complex-persistence gudhi-distance-matrix-edge-collapse-rips-persistence gudhi-nerve gudhi-off-file-from-shape-generator gudhi-periodic-cubical-complex-persistence gudhi-point-cloud-edge-collapse-rips-persistence gudhi-rips-correlation-matrix-persistence gudhi-rips-distance-matrix-persistence gudhi-rips-persistence gudhi-sparse-rips-persistence gudhi-voronoi-gic gudhi-witness-complex-strong-witness-persistence gudhi-witness-complex-weak-witness-persistence gudhui guess-ploidy.py guess-upstream-metadata guessit guestfish guestmount guestunmount guetzli gui-compare guidata-tests guidedog guider guild-3.0 guile-3.0 guile-config-3.0 guile-snarf-3.0 guile-tools-3.0 guimb guiqwt-tests guitarix guix guix-daemon gulkan-cube gulp gummi guncat gunicorn gunicorn3 gunicorn_pecan gupnp-av-cp gupnp-binding-tool-1.6 gupnp-dlna-info gupnp-dlna-ls-profiles gupnp-event-dumper gupnp-network-light gupnp-universal-cp gupnp-upload guppy gusbcmd gusload gustaf guvcview guymager gv gv-update-userconfig gv2gml (1) - GML-DOT converters gv2gxl (1) - GXL-GV converters gvb gvcolor (1) - flow colors through a ranked digraph gvf2bed gvf2starch gvgen (1) - generate graphs gvidm gvimtutor gvmap (1) - find clusters and create a geographical map highlighting clusters. gvmap.sh (1) - pipeline for running gvmap gvnccapture gvncviewer gvpack (1) - merge and pack disjoint graphs gvpectrl gvpr (1) - graph pattern scanning and processing language gw-config gwaei gwakeonlan gwbuild gwcbatch gwcli gwenview gwenview_importer gwhois gworldclock gww.x gww_fit.x gwyddion gwyddion-thumbnailer gxditview gxemul gxkb gxl2dot (1) - GXL-GV converters gxl2gv (1) - GXL-GV converters gxmessage gxneur gxtuner gxxdm gyoto gyoto-mpi-worker.8 gyotoy gyp gyrus gzbd gzbd-viewer gzrecover gztool h2cli h2load h2o h2pas-3.2.2 h2paspp-3.2.2 h2ph (1) - convert .h C header files to .ph Perl header files h2player h2xs (1) - convert .h C header files to Perl extensions h316 h4cc h4fc h4fromh5 h4redeploy h52gif h5ar h5c++ h5c++.mpich h5c++.openmpi h5cc h5clear h5copy h5debug h5diff h5dump h5fc h5fromh4 h5fromtxt h5import h5jam h5ls h5mkgrp h5pcc.mpich h5pcc.openmpi h5perf_serial h5pfc.mpich h5pfc.openmpi h5redeploy h5repack h5repart h5stat h5topng h5totxt h5tovtk h5unjam h8300-hitachi-coff-addr2line h8300-hitachi-coff-ar h8300-hitachi-coff-as h8300-hitachi-coff-c++ h8300-hitachi-coff-c++filt h8300-hitachi-coff-cpp h8300-hitachi-coff-g++ h8300-hitachi-coff-gcc h8300-hitachi-coff-gcc-3.4.6 h8300-hitachi-coff-ld h8300-hitachi-coff-nm h8300-hitachi-coff-objcopy h8300-hitachi-coff-objdump h8300-hitachi-coff-ranlib h8300-hitachi-coff-readelf h8300-hitachi-coff-size h8300-hitachi-coff-strings h8300-hitachi-coff-strip h8300-hms-addr2line h8300-hms-ar h8300-hms-as h8300-hms-c++ h8300-hms-c++filt h8300-hms-cpp h8300-hms-g++ h8300-hms-gcc h8300-hms-gcc-3.4.6 h8300-hms-ld h8300-hms-nm h8300-hms-objcopy h8300-hms-objdump h8300-hms-ranlib h8300-hms-readelf h8300-hms-size h8300-hms-strings h8300-hms-strip ha_cluster_exporter haarz hacha hachoir-grep hachoir-metadata hachoir-strip hachoir-urwid hachoir-wx hackage-tracker hackbench hackrf_clock hackrf_cpldjtag hackrf_debug hackrf_info hackrf_operacake hackrf_spiflash hackrf_sweep hackrf_transfer hacktv haddock haddock-ghc-9.0.2 hadori hair_geometry hakyll-init hal-histogram hal_input hal_manualtoolchange halcmd halcmd_twopass halcompile half_mt halibut halmeter halog halreport halrmt halrun halsampler halscope halshow halstreamer haltcl halui hamexam haml hamlit hamster handbrake handbrake-gtk handlebars handy-1-demo happy haproxy-vrrp-check haproxy_log_analysis haproxyctl hardening-check hardinfo hardlink (1) - link multiple copies of a file harep harminv harmony harpcheck harpcollocate harpconvert harpdump harpmerge haruna harvesttools harvid has160-hash haserl hash-to-efi-sig-list hash_exp hash_extract hash_list hash_sff hash_tar hashalot hashcash hashcat hashcheck hashdeep hashid hashrat hashstats haskell_count hasktags hatari hatari-prg-args hatari_profile hatchling hatop hattrib haxe haxelib hb-ot-shape-closure hb-shape hb-view hbal hbf2gf hbmgui hboot hbpldecode hc hcal hcc hcd hcdplay hcheck hci-tester hciattach (1) - attach serial devices via UART HCI to BlueZ stack hcidump hcitool (1) - Configure Bluetooth connections hcloud hcltool hconsole hcopy hcp hcxdumptool hcxeiutool hcxessidtool hcxhash2cap hcxhashcattool hcxhashtool hcxmactool hcxpcapngtool hcxpioff hcxpmkidtool hcxpmktool hcxpsktool hcxwltool hd (1) - display file contents in hexadecimal, decimal, octal, or ascii hd (4) - MFM/IDE hard disk devices hda-verb hdajackretask hdajacksensetest hdate hdav hdcpd hddemux hdel hdf24to8 hdf2adf hdf2gif hdf2jpeg hdf8to24 hdfcomp hdfed hdfimport hdfls hdfpack hdfs hdftopal hdftor8 hdfunpac hdhomerun_config hdiff hdifftopam hdir hdmi2usb-find-board hdmi2usb-manage-firmware hdmi2usb-mode-switch hdp hdrmerge hdspconf hdspmixer he HEAD (1p) - Simple command line user agent head (1) - output the first part of files head.x headPolishes headache headerthemeeditor healpy_get_wmap_maps.sh health-check heaptrack heaptrack_gui heaptrack_print heapy hearse heartbleeder heat heat-all heat-api heat-api-cfn heat-db-setup heat-engine heat-keystone-setup heat-keystone-setup-domain heat-manage heat-status heat-wsgi-api heat-wsgi-api-cfn hebcal heif-convert heif-enc heif-info heif-thumbnailer heimdal-history heimdal-strength heimdall heimdall-frontend heimtools heka2itx helical helix2solv helixturnhelix hellfire hello hello.pvm hello_other hello_xr help2man helpdev helpman helpmidas helpviewer helpztags (1) - generate the help tags file for directory hera-bottleneck hera-wasserstein hera-wasserstein-dipha herbstclient herbstluftwm hercules heri-eval heri-split heri-stat heri-stat-addons herold hershey-font-gnuplot hersheydemo hesinfo het_export het_import hetget hetinit hetmap hetro hetupd hevc_fei_extractor hevea hex hex2 hex2bdf hex2hcd (1) - Broadcom Bluetooth firmware converter hex2otf hex2sfd hexagui hexbin hexbox hexbraille hexchat hexcompare hexdraw hexdump (1) - display file contents in hexadecimal, decimal, octal, or ascii hexec hexedit hexer hexkinya hexmerge hexterm hexyl hey hf77 hfd-service-tools-leds hfd-service-tools-vibrator hfind (1) - Lookup a hash value in a hash database hformat hfp hfs hfssh hfst-affix-guessify hfst-apertium-proc hfst-calculate hfst-compare hfst-compose hfst-compose-intersect hfst-concatenate hfst-conjunct hfst-determinise hfst-determinize hfst-disjunct hfst-edit-metadata hfst-eliminate-flags hfst-expand hfst-expand-equivalences hfst-flookup hfst-format hfst-fst2fst hfst-fst2strings hfst-fst2txt hfst-grep hfst-guess hfst-guessify hfst-head hfst-info hfst-insert-freely hfst-intersect hfst-invert hfst-lexc hfst-lookup hfst-minimise hfst-minimize hfst-minus hfst-multiply hfst-name hfst-optimised-lookup hfst-optimized-lookup hfst-ospell hfst-ospell-office hfst-pair-test hfst-pmatch hfst-pmatch2fst hfst-priority-disjunct hfst-priority-union hfst-proc hfst-proc2 hfst-project hfst-prune-alphabet hfst-push-labels hfst-push-weights hfst-realign hfst-regexp2fst hfst-remove-epsilons hfst-repeat hfst-reverse hfst-reweight hfst-reweight-tagger hfst-sfstpl2fst hfst-shuffle hfst-split hfst-strings2fst hfst-substitute hfst-subtract hfst-summarise hfst-summarize hfst-tag hfst-tail hfst-tokenise hfst-tokenize hfst-traverse hfst-twolc hfst-txt2fst hfst-union hfst-xfst hg hg-ssh hgtk hhalign hhalign_omp hhblits hhblits_ca3m hhblits_omp hhconsensus hhfilter hhmake hhsearch hhsearch_omp hidl-gen hiera hierarch28 highlight hikidoc hikisetup hilive hilive-build himdcli hime hime-cin2gtab hime-env hime-exit hime-gb-toggle hime-gtab-merge hime-gtab2cin hime-juyin-learn hime-kbm-toggle hime-message hime-phoa2d hime-phod2a hime-setup hime-sim hime-sim2trad hime-trad hime-trad2sim hime-ts-edit hime-tsa2d32 hime-tsd2a32 hime-tsin2gtab-phrase hime-tslearn hinawa-alesis-io-cli hinawa-apogee-duet-cli hinawa-apogee-ensemble-cli hinawa-bebob-connection-cli hinawa-bebob-plug-parser hinawa-config-rom-printer hinawa-dg003-cli hinawa-dg00x-common-cli hinawa-dice-common-cli hinawa-dice-extension-cli hinawa-edirol-fa-cli hinawa-fireface-cli hinawa-fireworks-cli hinawa-focusrite-saffirepro-io-cli hinawa-griffin-firewave-cli hinawa-lacie-speakers-cli hinawa-maudio-bebob-cli hinawa-motu-common-cli hinawa-oxfw-generic-cli hinawa-tascam-fireone-cli hinawa-tascam-fw-console-cli hinawa-tascam-fw-rack-cli hinawa-yamaha-terratec-cli hindent hinfo hinge hip_embed_pch.sh hipcc hipcc.pl hipcc_cmake_linker_helper hipconfig hipconfig.pl hipdemangleatp hipercdecode hipercontracer hipstopgm hipvars.pm hisat2 hisat2-align-l hisat2-align-s hisat2-build hisat2-build-l hisat2-build-s hisat2-inspect hisat2-inspect-l hisat2-inspect-s hisat2_extract_exons.py hisat2_extract_snps_haplotypes_UCSC.py hisat2_extract_snps_haplotypes_VCF.py hisat2_extract_splice_sites.py hishrink hist histogram histretch hitc hitc_slave hitex hits_to_fastq hivelytracker hivexget hivexml hivexregedit hivexsh hjsmin hjson-cli hledger hledger-autosync hledger-interest hledger-ui hledger-web hlins hlint hlogin hls hmac256 (1) - Compute an HMAC-SHA-256 MAC hman hmaptool-13 hmaptool-14 hmaptool-15 hmkdir hmm-assembler.pl hmm-info hmm2align hmm2build hmm2calibrate hmm2convert hmm2emit hmm2fetch hmm2index hmm2pfam hmm2search hmm_train hmm_tweak hmm_view hmmalign hmmbuild hmmconvert hmmemit hmmfetch hmmlogo hmmpgmd hmmpgmd_shard hmmpress hmmscan hmmsearch hmmsim hmmstat hmoment hmount hmsa hmt-slam hmt-slam-gui hmtMapViewer hnb hocon hocr hocr2pdf hodie hol88 holes hollywood holonomic-navigator-demo homGeneMapping home_bbs homebank homectl homescrape homesick hopm horde-db-migrate-component horde-prefs horde-service-weather-metar-database horde-vfs horgand horizon-eda horizon-imp hose host (1) - DNS lookup utility hostbyname hostfiles hostid (1) - print the numeric identifier for the current host hostnamectl hostsed hoteldruid-launcher hotspot hovercraft how-can-i-help howdoi hoz hp-align hp-check hp-check-plugin hp-clean hp-colorcal hp-config_usb_printer hp-devicesettings hp-diagnose_plugin hp-diagnose_queues hp-doctor hp-fab hp-faxsetup hp-firmware hp-info hp-levels hp-linefeedcal hp-logcapture hp-makecopies hp-makeuri hp-pkservice hp-plugin hp-pqdiag hp-print hp-printsettings hp-probe hp-query hp-scan hp-search-mac hp-sendfax hp-setup hp-systray hp-testpage hp-timedate hp-toolbox hp-wificonfig hp.x hp2100 hp2ps hp2xx hp48cc hpack hpanel hpav hpavkey hpavkeys hpc hpcc hpcd hpcdtoppm hpcopy hpcttrigger hpfsck hpftodit hpi_shell hpialarms hpidomain hpiel hpievents hpifan hpigensimdata hpiinv hpijs hpilo_cli hpionIBMblade hpipower hpireset hpisensor hpisettime hpithres hpitop hpitree hpiwdt hpixml hpls hpmkdir hpmount hppa-linux-gnu-addr2line hppa-linux-gnu-ar hppa-linux-gnu-as hppa-linux-gnu-c++filt hppa-linux-gnu-cpp hppa-linux-gnu-cpp-10 hppa-linux-gnu-cpp-11 hppa-linux-gnu-cpp-12 hppa-linux-gnu-elfedit hppa-linux-gnu-g++ hppa-linux-gnu-g++-10 hppa-linux-gnu-g++-11 hppa-linux-gnu-g++-12 hppa-linux-gnu-gcc hppa-linux-gnu-gcc-10 hppa-linux-gnu-gcc-11 hppa-linux-gnu-gcc-12 hppa-linux-gnu-gcc-ar hppa-linux-gnu-gcc-ar-10 hppa-linux-gnu-gcc-ar-11 hppa-linux-gnu-gcc-ar-12 hppa-linux-gnu-gcc-nm hppa-linux-gnu-gcc-nm-10 hppa-linux-gnu-gcc-nm-11 hppa-linux-gnu-gcc-nm-12 hppa-linux-gnu-gcc-ranlib hppa-linux-gnu-gcc-ranlib-10 hppa-linux-gnu-gcc-ranlib-11 hppa-linux-gnu-gcc-ranlib-12 hppa-linux-gnu-gcov hppa-linux-gnu-gcov-10 hppa-linux-gnu-gcov-11 hppa-linux-gnu-gcov-12 hppa-linux-gnu-gcov-dump hppa-linux-gnu-gcov-dump-10 hppa-linux-gnu-gcov-dump-11 hppa-linux-gnu-gcov-dump-12 hppa-linux-gnu-gcov-tool hppa-linux-gnu-gcov-tool-10 hppa-linux-gnu-gcov-tool-11 hppa-linux-gnu-gcov-tool-12 hppa-linux-gnu-gdc hppa-linux-gnu-gdc-10 hppa-linux-gnu-gdc-11 hppa-linux-gnu-gdc-12 hppa-linux-gnu-gfortran hppa-linux-gnu-gfortran-10 hppa-linux-gnu-gfortran-11 hppa-linux-gnu-gfortran-12 hppa-linux-gnu-gm2 hppa-linux-gnu-gm2-10 hppa-linux-gnu-gm2-11 hppa-linux-gnu-gm2-12 hppa-linux-gnu-gnat hppa-linux-gnu-gnat-10 hppa-linux-gnu-gnat-11 hppa-linux-gnu-gnat-12 hppa-linux-gnu-gnatbind hppa-linux-gnu-gnatbind-10 hppa-linux-gnu-gnatbind-11 hppa-linux-gnu-gnatbind-12 hppa-linux-gnu-gnatchop hppa-linux-gnu-gnatchop-10 hppa-linux-gnu-gnatchop-11 hppa-linux-gnu-gnatchop-12 hppa-linux-gnu-gnatclean hppa-linux-gnu-gnatclean-10 hppa-linux-gnu-gnatclean-11 hppa-linux-gnu-gnatclean-12 hppa-linux-gnu-gnatfind hppa-linux-gnu-gnatfind-10 hppa-linux-gnu-gnatfind-11 hppa-linux-gnu-gnatgcc hppa-linux-gnu-gnathtml hppa-linux-gnu-gnathtml-10 hppa-linux-gnu-gnathtml-11 hppa-linux-gnu-gnathtml-12 hppa-linux-gnu-gnatkr hppa-linux-gnu-gnatkr-10 hppa-linux-gnu-gnatkr-11 hppa-linux-gnu-gnatkr-12 hppa-linux-gnu-gnatlink hppa-linux-gnu-gnatlink-10 hppa-linux-gnu-gnatlink-11 hppa-linux-gnu-gnatlink-12 hppa-linux-gnu-gnatls hppa-linux-gnu-gnatls-10 hppa-linux-gnu-gnatls-11 hppa-linux-gnu-gnatls-12 hppa-linux-gnu-gnatmake hppa-linux-gnu-gnatmake-10 hppa-linux-gnu-gnatmake-11 hppa-linux-gnu-gnatmake-12 hppa-linux-gnu-gnatname hppa-linux-gnu-gnatname-10 hppa-linux-gnu-gnatname-11 hppa-linux-gnu-gnatname-12 hppa-linux-gnu-gnatprep hppa-linux-gnu-gnatprep-10 hppa-linux-gnu-gnatprep-11 hppa-linux-gnu-gnatprep-12 hppa-linux-gnu-gnatxref hppa-linux-gnu-gnatxref-10 hppa-linux-gnu-gnatxref-11 hppa-linux-gnu-gprof hppa-linux-gnu-ld hppa-linux-gnu-ld.bfd hppa-linux-gnu-lto-dump-10 hppa-linux-gnu-lto-dump-11 hppa-linux-gnu-lto-dump-12 hppa-linux-gnu-nm hppa-linux-gnu-objcopy hppa-linux-gnu-objdump hppa-linux-gnu-ranlib hppa-linux-gnu-readelf hppa-linux-gnu-size hppa-linux-gnu-strings hppa-linux-gnu-strip hppa64-linux-gnu-addr2line hppa64-linux-gnu-ar hppa64-linux-gnu-as hppa64-linux-gnu-c++filt hppa64-linux-gnu-cpp-10 hppa64-linux-gnu-cpp-11 hppa64-linux-gnu-cpp-12 hppa64-linux-gnu-elfedit hppa64-linux-gnu-gcc hppa64-linux-gnu-gcc-10 hppa64-linux-gnu-gcc-11 hppa64-linux-gnu-gcc-12 hppa64-linux-gnu-gcc-ar hppa64-linux-gnu-gcc-ar-10 hppa64-linux-gnu-gcc-ar-11 hppa64-linux-gnu-gcc-ar-12 hppa64-linux-gnu-gcc-nm hppa64-linux-gnu-gcc-nm-10 hppa64-linux-gnu-gcc-nm-11 hppa64-linux-gnu-gcc-nm-12 hppa64-linux-gnu-gcc-ranlib hppa64-linux-gnu-gcc-ranlib-10 hppa64-linux-gnu-gcc-ranlib-11 hppa64-linux-gnu-gcc-ranlib-12 hppa64-linux-gnu-gprof hppa64-linux-gnu-ld hppa64-linux-gnu-ld.bfd hppa64-linux-gnu-nm hppa64-linux-gnu-objcopy hppa64-linux-gnu-objdump hppa64-linux-gnu-ranlib hppa64-linux-gnu-readelf hppa64-linux-gnu-size hppa64-linux-gnu-strings hppa64-linux-gnu-strip hppwd hprm hpsplit hpumount hpwd hrancid hrename hrepack hrmdir hroller hsbrainfuck hsc2hs hsc2hs-hugs hscan hscolour hsdump hsetroot hsmwiz hspace hspec-discover hspell hspell-gui hspell-gui-heb hspell-i hsqldb-databasemanager hsqldb-databasemanagerswing hsqldb-sqltool hsqldb-transfer hsqueeze hstr hsx2hs ht htag htags htags-server htc htcacheclean htcontext htcp htdb_dump htdb_load htdb_stat htdbm htdig htdig-pdfparser htdigest htdump hte htfind htfuzzy htlatex htll htload htlogin htls htmerge htmex htmkdir html-beautify-js html-pipeline html-to-markdown html2 html2article html2dic html2haml html2markdown.py3 html2pdbtxt html2po html2ps html2text html2wiki html2wml html2xhtml html5debug html_formfu_deploy.pl html_formfu_dumpconf.pl htmlclean htmlcopy htmlcxx htmldoc htmlmin htmlproofer htmlsp htmltoc htmv htnotify htntlm htop htp htpasswd htping htproxy htproxydestroy htproxyinfo htproxyput htproxyrenew htproxytime htproxyunixtime htpurge htrancid htremote htrm hts hts-nim-tools hts_engine hts_nim_tools htseq-count htseq-count-barcodes htseq-qa htsfile htstat httest httex httexi http http@ httparty httpcfg httpclient httpdirfs httperf httpfs2 httpie httpindex httping httprecorder https httpsearch httpserv httpx httrack htxelatex htxetex hub hug hugeadm hugectl hugeedit hugin hugin_executor hugin_hdrmerge hugin_lensdb hugin_stacker hugin_stitch_project hugo hugo-mx-gateway hugs humanfriendly humfsify humount hunspell hupper3 hv3 hvectext hvol hw-probe hwasan_symbolize-13 hwasan_symbolize-14 hwasan_symbolize-15 hwloc-annotate hwloc-bind hwloc-calc hwloc-compress-dir hwloc-diff hwloc-distrib hwloc-gather-cpuid hwloc-gather-topology hwloc-info hwloc-ls hwloc-patch hwloc-ps hwp-thumbnailer hxaddid hxcite hxcite-mkbib hxclean hxcopy hxcount hxextract hxincl hxindex hxmkbib hxmultitoc hxname2id hxnetload hxnormalize hxnsxml hxnum hxpipe hxprintlinks hxprune hxref hxremove hxselect hxtabletrans hxtoc hxtool hxuncdata hxunent hxunpipe hxunxmlns hxwls hxxmlns hy_gt_vfd hy_vfd hyakubm hyakux11 hydra hydra-wizard hydra_nameserver hydra_persist hydra_pmi_proxy hydrapaper hydrogen hypercorn hyperfine hypertoc hyphen_show hyphy hypnotoad hypothesis i-ls i1401 i1620 i18nspector i2cscan.py i2f i2pd i2prouter i2prouter-nowrapper i3 i3-config-wizard i3-dmenu-desktop i3-dump-log i3-input i3-migrate-config-to-v4 i3-msg i3-nagbar i3-save-tree i3-sensible-editor i3-sensible-pager i3-sensible-terminal i3-with-shmlog i386 (8) - change reported architecture in new program environment and/or set personality flags i386-pc-msdosdjgpp-addr2line i386-pc-msdosdjgpp-ar i386-pc-msdosdjgpp-as i386-pc-msdosdjgpp-c++filt i386-pc-msdosdjgpp-elfedit i386-pc-msdosdjgpp-gprof i386-pc-msdosdjgpp-ld i386-pc-msdosdjgpp-ld.bfd i386-pc-msdosdjgpp-nm i386-pc-msdosdjgpp-objcopy i386-pc-msdosdjgpp-objdump i386-pc-msdosdjgpp-ranlib i386-pc-msdosdjgpp-readelf i386-pc-msdosdjgpp-size i386-pc-msdosdjgpp-strings i386-pc-msdosdjgpp-strip i386-tcc i3bar i3blocks i3lock i3lock-fancy i3pystatus i3pystatus-setting-util i3status i40e_sysfs_command i586-pc-msdosdjgpp-addr2line i586-pc-msdosdjgpp-ar i586-pc-msdosdjgpp-as i586-pc-msdosdjgpp-c++filt i586-pc-msdosdjgpp-elfedit i586-pc-msdosdjgpp-gprof i586-pc-msdosdjgpp-ld i586-pc-msdosdjgpp-nm i586-pc-msdosdjgpp-objcopy i586-pc-msdosdjgpp-objdump i586-pc-msdosdjgpp-ranlib i586-pc-msdosdjgpp-readelf i586-pc-msdosdjgpp-size i586-pc-msdosdjgpp-strings i586-pc-msdosdjgpp-strip i686-gnu-addr2line i686-gnu-ar i686-gnu-as i686-gnu-c++filt i686-gnu-dwp i686-gnu-elfedit i686-gnu-gprof i686-gnu-ld i686-gnu-ld.bfd i686-gnu-ld.gold i686-gnu-nm i686-gnu-objcopy i686-gnu-objdump i686-gnu-ranlib i686-gnu-readelf i686-gnu-size i686-gnu-strings i686-gnu-strip i686-kfreebsd-gnu-addr2line i686-kfreebsd-gnu-ar i686-kfreebsd-gnu-as i686-kfreebsd-gnu-c++filt i686-kfreebsd-gnu-dwp i686-kfreebsd-gnu-elfedit i686-kfreebsd-gnu-gprof i686-kfreebsd-gnu-ld i686-kfreebsd-gnu-ld.bfd i686-kfreebsd-gnu-ld.gold i686-kfreebsd-gnu-nm i686-kfreebsd-gnu-objcopy i686-kfreebsd-gnu-objdump i686-kfreebsd-gnu-ranlib i686-kfreebsd-gnu-readelf i686-kfreebsd-gnu-size i686-kfreebsd-gnu-strings i686-kfreebsd-gnu-strip i686-linux-gnu-addr2line i686-linux-gnu-ar i686-linux-gnu-as i686-linux-gnu-c++filt i686-linux-gnu-cpp i686-linux-gnu-cpp-10 i686-linux-gnu-cpp-11 i686-linux-gnu-cpp-12 i686-linux-gnu-dwp i686-linux-gnu-elfedit i686-linux-gnu-g++ i686-linux-gnu-g++-10 i686-linux-gnu-g++-11 i686-linux-gnu-g++-12 i686-linux-gnu-gcc i686-linux-gnu-gcc-10 i686-linux-gnu-gcc-11 i686-linux-gnu-gcc-12 i686-linux-gnu-gcc-ar i686-linux-gnu-gcc-ar-10 i686-linux-gnu-gcc-ar-11 i686-linux-gnu-gcc-ar-12 i686-linux-gnu-gcc-nm i686-linux-gnu-gcc-nm-10 i686-linux-gnu-gcc-nm-11 i686-linux-gnu-gcc-nm-12 i686-linux-gnu-gcc-ranlib i686-linux-gnu-gcc-ranlib-10 i686-linux-gnu-gcc-ranlib-11 i686-linux-gnu-gcc-ranlib-12 i686-linux-gnu-gccbrig-10 i686-linux-gnu-gccbrig-11 i686-linux-gnu-gccgo i686-linux-gnu-gccgo-10 i686-linux-gnu-gccgo-11 i686-linux-gnu-gccgo-12 i686-linux-gnu-gcov i686-linux-gnu-gcov-10 i686-linux-gnu-gcov-11 i686-linux-gnu-gcov-12 i686-linux-gnu-gcov-dump i686-linux-gnu-gcov-dump-10 i686-linux-gnu-gcov-dump-11 i686-linux-gnu-gcov-dump-12 i686-linux-gnu-gcov-tool i686-linux-gnu-gcov-tool-10 i686-linux-gnu-gcov-tool-11 i686-linux-gnu-gcov-tool-12 i686-linux-gnu-gdc i686-linux-gnu-gdc-10 i686-linux-gnu-gdc-11 i686-linux-gnu-gdc-12 i686-linux-gnu-gfortran i686-linux-gnu-gfortran-10 i686-linux-gnu-gfortran-11 i686-linux-gnu-gfortran-12 i686-linux-gnu-gm2 i686-linux-gnu-gm2-10 i686-linux-gnu-gm2-11 i686-linux-gnu-gm2-12 i686-linux-gnu-gnat i686-linux-gnu-gnat-10 i686-linux-gnu-gnat-11 i686-linux-gnu-gnat-12 i686-linux-gnu-gnatbind i686-linux-gnu-gnatbind-10 i686-linux-gnu-gnatbind-11 i686-linux-gnu-gnatbind-12 i686-linux-gnu-gnatchop i686-linux-gnu-gnatchop-10 i686-linux-gnu-gnatchop-11 i686-linux-gnu-gnatchop-12 i686-linux-gnu-gnatclean i686-linux-gnu-gnatclean-10 i686-linux-gnu-gnatclean-11 i686-linux-gnu-gnatclean-12 i686-linux-gnu-gnatfind i686-linux-gnu-gnatfind-10 i686-linux-gnu-gnatfind-11 i686-linux-gnu-gnatgcc i686-linux-gnu-gnathtml i686-linux-gnu-gnathtml-10 i686-linux-gnu-gnathtml-11 i686-linux-gnu-gnathtml-12 i686-linux-gnu-gnatkr i686-linux-gnu-gnatkr-10 i686-linux-gnu-gnatkr-11 i686-linux-gnu-gnatkr-12 i686-linux-gnu-gnatlink i686-linux-gnu-gnatlink-10 i686-linux-gnu-gnatlink-11 i686-linux-gnu-gnatlink-12 i686-linux-gnu-gnatls i686-linux-gnu-gnatls-10 i686-linux-gnu-gnatls-11 i686-linux-gnu-gnatls-12 i686-linux-gnu-gnatmake i686-linux-gnu-gnatmake-10 i686-linux-gnu-gnatmake-11 i686-linux-gnu-gnatmake-12 i686-linux-gnu-gnatname i686-linux-gnu-gnatname-10 i686-linux-gnu-gnatname-11 i686-linux-gnu-gnatname-12 i686-linux-gnu-gnatprep i686-linux-gnu-gnatprep-10 i686-linux-gnu-gnatprep-11 i686-linux-gnu-gnatprep-12 i686-linux-gnu-gnatxref i686-linux-gnu-gnatxref-10 i686-linux-gnu-gnatxref-11 i686-linux-gnu-gprof i686-linux-gnu-ld i686-linux-gnu-ld.bfd i686-linux-gnu-ld.gold i686-linux-gnu-lto-dump-10 i686-linux-gnu-lto-dump-11 i686-linux-gnu-lto-dump-12 i686-linux-gnu-nm i686-linux-gnu-objcopy i686-linux-gnu-objdump i686-linux-gnu-ranlib i686-linux-gnu-readelf i686-linux-gnu-size i686-linux-gnu-strings i686-linux-gnu-strip i686-w64-mingw32-addr2line i686-w64-mingw32-ar i686-w64-mingw32-as i686-w64-mingw32-c++-posix i686-w64-mingw32-c++-win32 i686-w64-mingw32-c++filt i686-w64-mingw32-cpp-posix i686-w64-mingw32-cpp-win32 i686-w64-mingw32-dlltool i686-w64-mingw32-dllwrap i686-w64-mingw32-elfedit i686-w64-mingw32-g++-posix i686-w64-mingw32-g++-win32 i686-w64-mingw32-gcc-10-posix i686-w64-mingw32-gcc-10-win32 i686-w64-mingw32-gcc-ar-posix i686-w64-mingw32-gcc-ar-win32 i686-w64-mingw32-gcc-nm-posix i686-w64-mingw32-gcc-nm-win32 i686-w64-mingw32-gcc-posix i686-w64-mingw32-gcc-ranlib-posix i686-w64-mingw32-gcc-ranlib-win32 i686-w64-mingw32-gcc-win32 i686-w64-mingw32-gcov-dump-posix i686-w64-mingw32-gcov-dump-win32 i686-w64-mingw32-gcov-posix i686-w64-mingw32-gcov-tool-posix i686-w64-mingw32-gcov-tool-win32 i686-w64-mingw32-gcov-win32 i686-w64-mingw32-gdb i686-w64-mingw32-gdb-add-index i686-w64-mingw32-gfortran-posix i686-w64-mingw32-gfortran-win32 i686-w64-mingw32-gnat-posix i686-w64-mingw32-gnat-win32 i686-w64-mingw32-gnatbind-posix i686-w64-mingw32-gnatbind-win32 i686-w64-mingw32-gnatchop-posix i686-w64-mingw32-gnatchop-win32 i686-w64-mingw32-gnatclean-posix i686-w64-mingw32-gnatclean-win32 i686-w64-mingw32-gnatfind-posix i686-w64-mingw32-gnatfind-win32 i686-w64-mingw32-gnatkr-posix i686-w64-mingw32-gnatkr-win32 i686-w64-mingw32-gnatlink-posix i686-w64-mingw32-gnatlink-win32 i686-w64-mingw32-gnatls-posix i686-w64-mingw32-gnatls-win32 i686-w64-mingw32-gnatmake-posix i686-w64-mingw32-gnatmake-win32 i686-w64-mingw32-gnatname-posix i686-w64-mingw32-gnatname-win32 i686-w64-mingw32-gnatprep-posix i686-w64-mingw32-gnatprep-win32 i686-w64-mingw32-gnatxref-posix i686-w64-mingw32-gnatxref-win32 i686-w64-mingw32-gprof i686-w64-mingw32-ld i686-w64-mingw32-ld.bfd i686-w64-mingw32-lto-dump-posix i686-w64-mingw32-lto-dump-win32 i686-w64-mingw32-nm i686-w64-mingw32-objcopy i686-w64-mingw32-objdump i686-w64-mingw32-pkg-config i686-w64-mingw32-ranlib i686-w64-mingw32-readelf i686-w64-mingw32-size i686-w64-mingw32-strings i686-w64-mingw32-strip i686-w64-mingw32-widl i686-w64-mingw32-windmc i686-w64-mingw32-windres i7094 i810rotate i810switch i8kctl i8kfan i8kmon i915-perf-configs i915-perf-control i915-perf-reader i915-perf-recorder ia ia64-linux-gnu-addr2line ia64-linux-gnu-ar ia64-linux-gnu-as ia64-linux-gnu-c++filt ia64-linux-gnu-elfedit ia64-linux-gnu-gprof ia64-linux-gnu-ld ia64-linux-gnu-ld.bfd ia64-linux-gnu-nm ia64-linux-gnu-objcopy ia64-linux-gnu-objdump ia64-linux-gnu-ranlib ia64-linux-gnu-readelf ia64-linux-gnu-size ia64-linux-gnu-strings ia64-linux-gnu-strip iannix iasecc-tool iasl iaxmodem ib_acme ib_atomic_bw ib_atomic_lat ib_read_bw ib_read_lat ib_send_bw ib_send_lat ib_write_bw ib_write_lat ibanchk ibdiagnet ibdiagpath ibdiagui ibdmchk ibdmsh ibdmtr ibis ibnlparse ibrav2cell.x ibsim ibsim-run ibtopodiff ibus (5) - dconf database file for IBus ibus (1) - command line utility for ibus ibus-braille ibus-braille-abbreviation-editor ibus-braille-language-editor ibus-braille-preferences ibus-daemon (1) - daemon program for ibus ibus-setup (1) - configuration program for ibus ibus-setup-cangjie ibus-setup-hangul ibus-table-createdb ibus-ui-emojier-plasma ibv_asyncwatch ibv_devices ibv_devinfo ibv_rc_pingpong ibv_srq_pingpong ibv_uc_pingpong ibv_ud_pingpong ibv_xsrq_pingpong ibwtest ical ical2html ical2po icalendar icalfilter icalmerge icas icat (1) - Output the contents of a file based on its inode number. iccdump iccgamut icclu iccvcgt icdiff ice-gdb ice-insight iceauth (1) - ICE authority file utility icebox icebox++11 icebox_chipdb icebox_colbuf icebox_diff icebox_explain icebox_html icebox_maps icebox_vlog iceboxadmin icebram icebridge icecast2 icecc icecc-create-env icecc-test-env icecream icecream-sundae icedax icegridadmin icegriddb icegridgui icegridnode icegridregistry icehelp icemon icemulti icepack icepatch2calc icepatch2client icepatch2server icepll iceprog icerun ices2 icesh icesound icestormadmin icestormdb icetime iceunpack icewm icewm-experimental icewm-lite icewm-menu-fdo icewm-menu-xrandr icewm-session icewm-session-experimental icewm-session-lite icewmbg icewmhint icheck icingacli iclass iclingo icloud icmake icmbuild icmd icmptx icmpush icmstart icns2png ico (1) - animate an icosahedron or other polyhedron icoFoam icoReactingMultiphaseInterFoam icoUncoupledKinematicParcelDyMFoam icoUncoupledKinematicParcelFoam icoextract icolist icom icombine icon icon_append_file icon_append_index icon_dump_file icon_dump_index icont icontainer2icns icontopbm iconv (1) - convert text from one character encoding to another iconv (3) - perform character set conversion iconvert iconx icotool icp icp-slam icp-slam-live icpfind ictrans icuexportdata icuinfo id (1) - print real and effective user and group IDs id-shr-extract id16 id3 id32 id3convert id3cp id3info id3ren id3tag id3tool id3v2 idate idba idba_hybrid idba_tran idba_ud idconvert ideasUnvToFoam idemo ident identify identify-cli identify-im6.q16 identify-im6.q16hdri idesk idevice_id idevicebackup idevicebackup2 idevicecrashreport idevicedate idevicedebug idevicedebugserverproxy idevicediagnostics ideviceenterrecovery ideviceimagemounter ideviceinfo ideviceinstaller idevicename idevicenotificationproxy idevicepair ideviceprovision idevicerestore idevicescreenshot idevicesetlocation idevicesyslog idf2vrml idfcyl idfetch idfrect idiag-socket-details idiff idiscover idl2deb (1) - Create a Debian package for CORBA monitoring from IDL idl2tcl idl2wrs (1) - CORBA IDL to Wireshark Plugin Generator idlc idle (2) - make process 0 idle idle-python3.10 idle-python3.11 idleconn idlestat idml2po idn idn2 idngram_merge idraw ids2ngram idseq-bench-compare idseq-bench-generate idseq-bench-score idt idwcc idxmerge idzebra-abs2dom iec16022 iecset (1) - Set or dump IEC958 status bits ieee-copyout iem-plugin-allradecoder iem-plugin-binauraldecoder iem-plugin-coordinateconverter iem-plugin-directionalcompressor iem-plugin-directivityshaper iem-plugin-distancecompensator iem-plugin-dualdelay iem-plugin-energyvisualizer iem-plugin-fdnreverb iem-plugin-matrixmultiplier iem-plugin-multibandcompressor iem-plugin-multiencoder iem-plugin-multieq iem-plugin-omnicompressor iem-plugin-probedecoder iem-plugin-roomencoder iem-plugin-scenerotator iem-plugin-simpledecoder iem-plugin-stereoencoder iem-plugin-toolbox iep ietf2bibtex ievents iex if1 if2 ifdata ifetch ifexport ifile ifind (1) - Find the meta-data structure that has allocated a given disk unit or file name. ifinfo ifnames (1) - Extract CPP conditionals from a set of files ifnames-dickey ifnames2.13 ifnames2.64 ifnames2.69 ifne ifollowQ ifollowQmerge ifollowQplot ifpc-3.2.2 ifqQ ifstat ifuse iga64 igal2 igdiscover ign ign_remotery_vis ignition-validate igor igor-compute_pgen igorbinarywave igorpackedexperiment igrep igt_stats igv igzip ii iinfo iio_adi_xflow_check iio_attr iio_genxml iio_info iio_readdev iio_reg iio_stresstest iio_writedev iitii ij ijoin ijs_pxljr ikarus ikarus-scheme-script ikdasm ike-scan ikhal iki-git-hook-update iki-git-shell iki-ssh-unsafe ikidns ikisite ikisite-delete-unfinished-site ikisite-wrapper ikiwiki ikiwiki-calendar ikiwiki-comment ikiwiki-hosting-web-backup ikiwiki-hosting-web-daily ikiwiki-makerepo ikiwiki-transition ikiwiki-update-wikilist ikslint iksperf iksroster ilasm ilbmtoppm ilink illinkanalyzer illumina-dump illuminapairedend illumread illustrate ilorest ils (1) - List inode information ilur im-config im-launch image-factory image-factory-sudo-helper image-to-gcode image-to-pascal image2fits image2gridmap image2xy image_server imagebuilder imagecalc imageindex imageio_download_bin imageio_remove_bin imagej imagen imageregrid imageslice imagespread imagetooth imagetops imagination imake imali imap-dl imapcopy imapd imapfilter imaprowl imaptool imcat imcatalog imcd imclean imcopy imediff imextract imfill img2cif img2dcm img2pdf img2png img2py img2simg img2sixel img2txt img2webp img2xpm img_cat (1) - Output contents of an image file. img_stat (1) - Display details of an image file imget imgmerge imgp imgrep imgsize imgsizer imgtool imgtoppm imhead imhist imhsync imjoin imlib2-config imlib2_bumpmap imlib2_colorspace imlib2_conv imlib2_grab imlib2_load imlib2_poly imlib2_show imlib2_test imlib2_view imls immatch immknmz immv imp2gbs imp2ld imp2vs impack impacket-netview impacket-rpcdump impacket-samrdump impacket-secretsdump impacket-wmiexec impass impath implantisomd5 import import-bug-from-debian import-im6.q16 import-im6.q16hdri import_interpolation importlab impose impressive impressive-display impressive-gettransitions imput impwagent imresize imrm imrot imsetup imsize imsmooth imsort imstack imstar imstore imtar imv imv-folder imv-msg imv-wayland imv-x11 imview ImVirt (3pm) - detects several virtualizations imvirt-report (1) - system reporting to improve detection imwcs imwheel imx_uart imx_usb in-toto-keygen in-toto-mock in-toto-record in-toto-run in-toto-sign in-toto-verify in2csv (1) - manual page for in2csv 1.0.7 inadyn inb (2) - port I/O inchi_main include-what-you-use includemocs includeres incm increase-version-number incrontab indelCoder indelFit indelHistory indelible indelstat_sam_bam indent index++ index-extras index-pubmed index_dump index_tar indexdb_rna indexer indexlr indexmaker indexpub indextool indi_aaf2_focus indi_aagcloudwatcher_ng indi_activefocuser_focus indi_apogee_ccd indi_apogee_wheel indi_arduinost4 indi_armadillo_focus indi_astrolink4 indi_astromech_lpm indi_astromechfoc indi_astrometry indi_astrotrac_telescope indi_azgti_telescope indi_baader_dome indi_beaver_dome indi_beefocus indi_bresserexos2 indi_canon_ccd indi_celestron_gps indi_celestron_sct_focus indi_crux_mount indi_ddw_dome indi_deepskydad_af1_focus indi_deepskydad_af2_focus indi_deepskydad_af3_focus indi_deepskydad_fp1 indi_deepskydad_fr1 indi_dmfc_focus indi_domepro2_dome indi_dragonfly_dome indi_dreamfocuser_focus indi_dsc_telescope indi_dsi_ccd indi_efa_focus indi_eq500x_telescope indi_eqmod_telescope indi_esattoarco_focus indi_eval indi_falcon_rotator indi_fcusb_focus indi_ffmv_ccd indi_fli_ccd indi_fli_focus indi_fli_wheel indi_flipflat indi_fuji_ccd indi_gemini_focus indi_getprop indi_gige_ccd indi_gphoto_ccd indi_gpsd indi_gpsnmea indi_gpusb indi_hid_test indi_hitecastrodc_focus indi_ieq_telescope indi_ieqlegacy_telescope indi_imager_agent indi_integra_focus indi_ioptronHC8406 indi_ioptronv3_telescope indi_joystick indi_lacerta_mfoc_focus indi_lakeside_focus indi_limesdr_receiver indi_lx200_10micron indi_lx200_16 indi_lx200_OnStep indi_lx200_TeenAstro indi_lx200aok indi_lx200ap indi_lx200ap_gtocp2 indi_lx200ap_v2 indi_lx200autostar indi_lx200basic indi_lx200classic indi_lx200fs2 indi_lx200gemini indi_lx200generic indi_lx200gotonova indi_lx200gps indi_lx200pulsar2 indi_lx200ss2000pc indi_lx200stargo indi_lx200zeq25 indi_lynx_focus indi_manual_wheel indi_maxdomeii indi_mbox_weather indi_meta_weather indi_mgenautoguider indi_microtouch_focus indi_moonlite_focus indi_moonlitedro_focus indi_myfocuserpro2_focus indi_nexdome indi_nexdome_beaver indi_nfocus indi_nframe_rotator indi_nightcrawler_focus indi_nightscape_ccd indi_nikon_ccd indi_nstep_focus indi_onfocus_focus indi_openweathermap_weather indi_optec_wheel indi_orion_ssg3_ccd indi_paramount_telescope indi_pegasus_flatmaster indi_pegasus_focuscube indi_pegasus_ppb indi_pegasus_ppba indi_pegasus_scopsoag indi_pegasus_uch indi_pegasus_upb indi_pentax_ccd indi_perfectstar_focus indi_planewave_deltat indi_platypus_focus indi_pmc8_telescope indi_pyxis_rotator indi_qhycfw1_wheel indi_qhycfw2_wheel indi_qhycfw3_wheel indi_quantum_wheel indi_rainbow_telescope indi_rainbowrsf_focus indi_rbfocus_focus indi_rigel_dome indi_robo_focus indi_rolloff_dome indi_rtklib indi_scopedome_dome indi_script_dome indi_script_telescope indi_seletek_rotator indi_sestosenso2_focus indi_sestosenso_focus indi_setprop indi_shelyakeshel_spectrograph indi_shelyakspox_spectrograph indi_siefs_focus indi_simulator_ccd indi_simulator_dome indi_simulator_focus indi_simulator_gps indi_simulator_guide indi_simulator_lightpanel indi_simulator_receiver indi_simulator_rotator indi_simulator_sqm indi_simulator_telescope indi_simulator_weather indi_simulator_wheel indi_skycommander_telescope indi_skysafari indi_skywatcherAltAzMount indi_skywatcherAltAzSimple indi_smartfocus_focus indi_snapcap indi_sony_ccd indi_spectracyber indi_sqm_weather indi_star2000 indi_staradventurer2i_telescope indi_starbook_telescope indi_starbook_ten indi_steeldrive2_focus indi_steeldrive_focus indi_sx_ao indi_sx_ccd indi_sx_wheel indi_synscan_telescope indi_synscanlegacy_telescope indi_talon6 indi_tcfs3_focus indi_tcfs_focus indi_teenastro_focus indi_temma_telescope indi_trutech_wheel indi_usbdewpoint indi_usbfocusv3_focus indi_v4l2_ccd indi_vantage_weather indi_wanderer_lite_rotator indi_watchdog indi_watcher_weather indi_weather_safety_proxy indi_webcam_ccd indi_xagyl_wheel indicator-sensors indigo-cano indigo-deco indigo-depict indiserver indxbib inetcat inetsim inetutils-dnsdomainname inetutils-ftp inetutils-hostname inetutils-ifconfig inetutils-logger inetutils-talk inetutils-telnet inetutils-traceroute inews infinoted infinoted-0.7 inflate-js influx influxd infnoise-bin2hex infnoise-dice infnoise-entcheck infnoise-findlongest infnoise-flipbits infnoise-healthcheck infnoise-hex2bin infnoise-passgen info (1ssl) - OpenSSL application commands info2man info2pod infoalign infoassembly infobase infocmp (1) - compare or print out terminfo descriptions inforesidue inform inform6 infoseq infotocap (1) - convert a terminfo description into a termcap description infotopam ingests inherit1 inherit2 inherit3 inherita inheritb inhomog ini2po ini2yaml inifile inimf initex initial_state.x inivar ink inkscape inkview inl (2) - port I/O inline-detox inline2test inmidas innetgr (3) - handle network group entries innochecksum (1) - offline InnoDB file checksum utility innoextract innotop (1) - MySQL and InnoDB transaction/status monitor. inoticoming inotify-hookable inotifywait inotifywatch input input-events input-kbd input-pad input-remapper-control input-remapper-gtk input-remapper-helper input-remapper-service inputattach inputgen inputplug insdseqget insegt insert_errors insideCells inspect inspectrum inspectsocks inst2xsd install (1) - copy files and set attributes install-debian install-info install-menu install-mimic install-printerdriver install-xpi installastheme installation-birthday installcheck installdeb-aspell installdeb-hunspell installdeb-ispell installdeb-myspell installdeb-wordlist installfont-tl installmgr installsieve installvst installwatch instaloader instanced_geometry instant instmodsh (1) - A shell to examine installed modules int64host int6k int6kbaud int6kboot int6kdetect int6keth int6kf int6khost int6kid int6klist int6klog int6kmdio int6kmdio2 int6kmod int6krate int6krule int6kstat int6ktest int6ktone int6kuart int6kwait int_seqs_to_char_strings.py intel-gen4asm intel-gen4disasm intel-gpu-overlay intel-virtual-output intel2gas intel_audio_dump intel_backlight intel_bios_dumper intel_display_crc intel_display_poller intel_dp_compliance intel_dump_decode intel_error_decode intel_firmware_decode intel_forcewaked intel_framebuffer_dump intel_gem_info intel_gpu_abrt intel_gpu_frequency intel_gpu_time intel_gpu_top intel_gtt intel_guc_logger intel_gvtg_test intel_infoframes intel_l3_parity intel_lid intel_opregion_decode intel_panel_fitter intel_perf_counters intel_pm_rpm intel_reg intel_reg_checker intel_residency intel_stepping intel_vbt_decode intel_watermark interCondensatingEvaporatingFoam interFoam interIsoFoam interMixingFoam interPhaseChangeDyMFoam interPhaseChangeFoam intercalc intercept intercept-build-13 intercept-build-14 intercept-build-15 interception interdiff (1) - show differences between two diff files interimap interpolate_cgns interpolate_sam.pl interpolation intersect-uid-lists intersectBed intersection_filter interval_count_intersections.py interval_join.py intltool-extract intltool-merge intltool-prepare intltool-update intltoolize inv invert_raw_image invgeod invoke invprofcheck invproj inw (2) - port I/O inxi io io_demo io_lib-config ioctl-tester iodbc-config iodbcadm-gtk iodbctest iofits ionice (1) - set or get process I/O scheduling class and priority ionit ioping ioprof iordump iostat iostat2pcp iotbx.blast_pdb iotbx.build_phil_cache iotbx.cbf_read iotbx.cif.as_miller_arrays iotbx.cif.as_xray_structure iotbx.cif.validate iotbx.cif_as_mtz iotbx.cif_as_pdb iotbx.cns.reflection_reader iotbx.cns.sdb_reader iotbx.cns.transfer_crystal_symmetry iotbx.crystal_symmetry_from_any iotbx.dano_as_amplitudes iotbx.distance_least_squares iotbx.dtrek.to_cns iotbx.emma iotbx.export_scalepack_unmerged iotbx.fetch_pdb iotbx.file_reader iotbx.french_wilson iotbx.get_pubmed_citation iotbx.lattice_symmetry iotbx.merging_statistics iotbx.mtz.dump iotbx.pdb.add_conformations iotbx.pdb.as_xray_structure iotbx.pdb.box_around_molecule iotbx.pdb.flip_symmetric_amino_acids iotbx.pdb.get_citation iotbx.pdb.insert_scale_records iotbx.pdb.join_fragment_files iotbx.pdb.link_as_geometry_restraints_edits iotbx.pdb.print_sequence iotbx.pdb.show_connectivity iotbx.pdb.sort_atoms iotbx.pdb.split_models iotbx.pdb.superpose_atoms_by_name iotbx.pdb.superpose_centers_of_mass iotbx.pdb_as_fasta iotbx.pdb_labels_comparison iotbx.pdb_labels_diff iotbx.pdb_remediator iotbx.phil iotbx.poscar_as_xray_structure iotbx.python iotbx.r_free_flags_accumulation iotbx.r_free_flags_as_cns iotbx.r_free_flags_completion_simple iotbx.reflection_file_converter iotbx.reflection_file_editor iotbx.reflection_file_reader iotbx.shelx.as_cif iotbx.shelx.as_xray_structure iotbx.shelx.dump_as_python iotbx.show_build_path iotbx.show_dist_paths iotbx.show_distances iotbx.simple_map_coefficients iotbx.split_data_cif iotbx.symmetry_search iotbx.unique_with_biomt iotbx.xplor.map.show_summary iov2 iowatcher iox-introspection-client iox-roudi ip-info ip2host ipa ipa-clustercheck ipa-getcert ipa-healthcheck ipaccess-config ipaccess-proxy ipbt ipcalc ipcalc-ng ipcluster ipcmk (1) - make various IPC resources ipcontroller ipcress ipcrm (1) - remove certain IPC resources ipcs (1) - show information on IPC facilities ipdSummary ipdb3 ipe ipe5toxml ipe6upgrade ipecurl ipeextract ipengine ipepresenter iperender iperender-par iperf iperf3 iperl ipescript ipetoipe ipfix2csv ipfixDump ipfixstat ipfs_cid ipig ipmctl ipmi_sim ipmi_ui ipmicmd ipmilan ipmish ipmitool ipmitool.py ipmiutil ipod-read-sysinfo-extended ipod-time-sync ippfind (1) - find internet printing protocol printers ipptool (1) - perform internet printing protocol requests ipqalc iprange ipraytime iproxy ips ipseckey ipsetbuild ipsetcat ipsetdot ipsvd-cdb iptables-xml (1) - Convert iptables-save format to XML iptc iptux ipv4calc ipv6calc ipv6loganon ipv6logconv ipv6logstats ipv6pref ipython3 iqtree2 iqtree2-mpi iqtree2-omp ir-ctl (1) - a swiss-knife tool to handle raw IR and to set lirc options ir-keytable irafcl irb irb3.0 irb3.1 irb_tioga ircII ircat irclog2html irclogsearch irclogserver ircmarkers ircp irdb-get irecovery iredis ireminder irexec irk irkerd irkerhook irkerhook-debian irkerhook-git irman.test_func irman.test_func_sw irman.test_io irman.test_io_sw irman.test_name irman.test_name_sw irobex_palm3 iroffer ironic ironic-api ironic-api-wsgi ironic-conductor ironic-dbsync ironic-inspector ironic-inspector-api-wsgi ironic-inspector-conductor ironic-inspector-dbsync ironic-inspector-migrate-data ironic-inspector-rootwrap ironic-inspector-status ironic-neutron-agent ironic-rootwrap ironic-status irony-server irpipe irpty irqtop irrecord irsend irsimreceive irsimsend irssi irstlm irstlm-ranker irtestcase irteus irteusgl irtext2udp irtt irw irxevent irxfer is-docker isa-info isabelle_client isag isbg isbg_sa_unwrap ischroot (1) - detect if running in a chroot iscsi-inq iscsi-ls iscsi-perf iscsi-readcapacity16 iscsi-swp iscsi-test-cu iscsiadm isdnsync isdv4-serial-debugger isdv4-serial-inputattach isect_mercator_alignment_gff iselect isenkram-lookup isenkramd isfile isfits isi2bib isi2xml ismrmrd_generate_cartesian_shepp_logan ismrmrd_info ismrmrd_read_timing_test ismrmrd_recon_cartesian_2d ismrmrd_test_xml isnum iso iso-info iso-read iso-tester isochore isochron isochron-daemon isochron-orchestrate isochron-rcv isochron-report isochron-send isodatetime isodump isogmt isohybrid isohybrid.pl isoinfo isomaster isoqlog isoquery isort isotest isotovideo isotpdump isotpperf isotprecv isotpsend isotpserver isotpsniffer isotptun isovfy ispdb ispell ispell-wrapper (1) - smart wrapper for ispell ispellaff2myspell isql-fb (1) - - Firebird Interactive SQL shell isql-fb (1) - - Firebird Interactive SQL shell isql-vt isqlw-vt isrange isrcsubmit iss issndfile istanbul istat (1) - Display details of a meta-data structure (i.e. inode) isutf8 isympy (1) - interactive shell for SymPy isympy3 (1) - interactive shell for SymPy itamae iterative_cdhit itilestator itkTestDriver itox itp_from_debian_dir itpp-config itstool iusql iv iv2toiv1 iva iva_qc iva_qc_make_db ivar ivcat ivdowngrade iverilog iverilog-vpi ivfix ivinfo ivstools ivtext ivtv-ctl ivview iwatch iwctl iwmon iwpan iwyu iwyu_tool ixfrdist ixplore iyt j1939acd j1939cat j1939spy j1939sr j2 j2amidi_bridge j4-dmenu-desktop jaaa jabber-querybot jabref jack-dssi-host jack-keyboard jack-stdin jack-stdout jack_alias jack_bufsize jack_capture jack_capture_gui jack_connect jack_control jack_cpu jack_cpu_load jack_delay jack_disconnect jack_evmon jack_freewheel jack_iodelay jack_latent_client jack_load jack_lsp jack_mclk_dump jack_meter jack_metro jack_midi_clock jack_midi_dump jack_midi_latency_test jack_midiseq jack_midisine jack_mix_box jack_mixer jack_monitor_client jack_multiple_metro jack_net_master jack_net_slave jack_property jack_rec jack_samplerate jack_server_control jack_session_notify jack_showtime jack_simdtests jack_simple_client jack_simple_session_client jack_test jack_thru jack_transport jack_unload jack_wait jack_zombie jackd jackdbus jackhmmer jacktrip-cli jacktrip-gui jadetex jadmaker jags jailcheck jailtest jake jaligner jalv jalv.gtk3 jalv.qt5 jalview jam.perforce jameica jamo-normalize janinoc japa japi-compliance-checker japicompat japilist japiohtml japiotext japize jardetector jardiff jargon jarwrapper jasmin jasmine jaspextract jaspscan jattach java-event-log-tags java-propose-classpath java2html java_count javacc javacc4 javacc5 javamorph javascript_count javax2jakarta javr jaxe jaxe-editeurconfig jbgtopbm jbgtopbm85 jbig2dec jbigtopnm jc jcadencii jcal jcasgen jcat (1) - Show the contents of a block in the file system journal. jcat-tool jclassinfo jclic jclic-libmanager jclicauthor jclicreports jconv jconvolver jd jdate jdg-build-and-provide-package jdg-debc jdg-generate-git-snapshot jdg-generate-reprepro-codename jdg-generate-svn-snapshot jdg-increase-version-number jdg-lintian-junit-report jdg-piuparts-wrapper jdg-remove-reprepro-codename jdg-repository-checker jdg-tap-adtsummary jdg-tap-checkbashism jdg-tap-pep8 jdg-tap-perlcritic jdg-tap-piuparts jdg-tap-shellcheck jdg-tap-tool-dispatcher jdiff jdim jdns jdresolve jdupes jed jedecparse jedit jedutil jeex jello jellyfish jellyfish1 jemboss jembossctl jenkins-jobs jeprof jerancid jest jest-repl jest-runtime jest-runtime-cli jetring-accept jetring-apply jetring-build jetring-checksum jetring-diff jetring-explode jetring-gen jetring-review jetring-signindex jets3t-cockpit jets3t-cockpitlite jets3t-synchronize jets3t-uploader jeuclid-cli jeuclid-mathviewer jflex jfmutil jftp jgi_summarize_bam_contig_depths jgit jgmenu jgmenu_run jgraph jgrep jh7100-recover jh_build jh_classpath jh_clean jh_compilefeatures jh_depends jh_exec jh_generateorbitdir jh_installeclipse jh_installjavadoc jh_installlibs jh_linkjars jh_makepkg jh_manifest jh_repack jh_setupenvironment jhbuild jhead jhindexer jhsearch jid jigdo-file jigdo-gen-checksum-list jigdo-lite jigdo-mirror jigdump jigit-mkimage jigl jigl2slideshow jigsaw-generate jigsum jigsum-sha256 jikespg jimsh jing jirashell jison jison-lex jitterdebugger jitterplot jittersamples jjdoc jjdoc4 jjdoc5 jjtree jjtree4 jjtree5 jk_uchroot jkmeter jlex jlha jlogin jls (1) - List the contents of a file system journal jmac jmacro jmacs jmake jmapviewer jmeter jmeter-server jmeters jmkmf jmodeltest jmol jmtpfs jnoise jnoisemeter jny jo joblauncher jodconverter joe johab2ucs2 join (1) - join lines of two files on a common field join-dctrl (1) - perform relational join on data in dctrl format join-into-groups-of joingenes joinleave jool jool_siit joold jose josm jot journal-brief jove joy2key jp jp2a jp2dump jparse jpeg jpeg2hdf jpeg2hdrgen jpeg2ktopam jpeg2yuv jpeg_extract (1) - jpeg extractor jpegdump jpegexiforient jpeghotp jpeginfo jpegjudge jpegoptim jpegparse jpegpixi jpegqs jpegtopnm jpegtran jpg2ff jpgicc jpico jpnevulator jpylyzer jq (1) - Command-line JSON processor jqp jrpcgen js-beautify-js js-beautify-py js-yaml js102 js102-config js2cbor js78 js78-config js8 js8call js_beautify js_of_eliom js_of_ocaml jsamp jsc jscal jscal-restore jscal-store jsdoc jsesc jshon json-diff json-glib-format json-glib-validate json-patch json-patch-jsondiff json2bson json2cbor json2cif json2csv json2dsv json2module json2pas-3.2.2 json2po json2toml json2tsv json2yaml json5 json_pp (1) - JSON::PP command utility json_reformat json_verify json_xs jsondiff-jsondiff jsonlint jsonlint-php jsonnet jsonnetfmt jsonpatch jsonpath jsonpath.py jsonpointer jsonrpcstub jsonschema jsonschema_suite jsontoml jsoo_fs jsoo_link jsoo_listunits jsoo_minify jsoo_mkcmis jsoo_mktop jsp_count jstar jstest jstest-gtk jsurf-alggeo jsvc jsvn jsvnadmin jsvndumpfilter jsvnlook jsvnsync jsvnversion jt4code jt65code jt9 jt9code jtag jtb jtdiff jtdx jtdxjt9 jtightvncviewer jtreg jube jube-autorun juffed jugglinglab juk juman junit junitmsgfmt junitparser jupp jupyter jupyter-bundlerextension jupyter-console jupyter-dejavu jupyter-execute jupyter-kernel jupyter-kernelspec jupyter-migrate jupyter-nbclassic jupyter-nbconvert jupyter-nbextension jupyter-notebook jupyter-qtconsole jupyter-run jupyter-server jupyter-serverextension jupyter-troubleshoot jupyter-trust jupyterhub jupyterhub-singleuser juyin-learn jverein jw jwm jwt jx2env jx2json jx_repl jxl_from_tree jxlinfo jxplorer jy1sat_ssdv jython k2pdfopt k3b k4dirstat k5srvutil (1) - host key table (keytab) manipulation utility k5start kDepIDB kDepObj kDepPre kEsetroot kObjCache kaccess kactivities-cli kaddressbook kadmin (1) - Kerberos V5 database administration program kadmin.heimdal kaem kaeru kaffeine kafka-tools kafs-check-config kaget kaidan kajiki kak kakasi kakasi-config kalarm kalarmautostart kalendar kalendarac kalgebra kalgebramobile kali kalign kalignfmt kaliprint kallisto kalzium kamcli kamoso kanagram kanatest kanboard kanif kanji-config-updmap kanji-config-updmap-sys kanji-config-updmap-user kanji-fontmap-creator kanjidraw kanshi kanyremote kapidox-depdiagram-generate kapidox-depdiagram-prepare kapidox-generate kappanhang kapplymousetheme kapptemplate kaptan kaptive.py kaput kar karabo-bridge-glimpse karabo-bridge-monitor karabo-bridge-serve-files karabo-bridge-server-sim karbon karbor karma_helper karplong kas kas-container kash kasumi katarakt kate (1) - Advanced text editor by KDE kate-syntax-highlighter katex katod katof kazam kbackup kbd-config kbd-layout-viewer kbd-layout-viewer5 kbd-test kbdd kbdinfo kbm2 kbookmarkmerger kbroadcastnotification kbruch kbtin kbuildsycoca5 (8) - Rebuilds the KService desktop file system configuration cache kbxutil (1) - List, export, import Keybox data kcachegrind kcalc kcapi-dgst kcapi-enc kcapi-rng kcat kcc kccachetest kcdirmgr kcdirtest kcforestmgr kcforesttest kcgrasstest kcharselect kchashmgr kchashtest kchmviewer kclangctest kcm-touchpad-list-devices kcminit kcminit_startup kcmshell5 kcollectd kcolorchooser kcolorschemeeditor kconfig kconfig-conf kconfig-diff kconfig-gettext kconfig-mconf kconfig-merge kconfig-nconf kconfig-qconf kconfig-tweak kcookiejar5 (8) - Command line interface to the KDE HTTP cookie daemon kcpolymgr kcpolytest kcprototest kcptun-client kcptun-server kcreatewebarchive kcstashtest kctreemgr kctreetest kcutilmgr kcutiltest kdb3_sqlite3_dump kdbmeta kdc2jpeg kdc2tiff kde-add-printer kde-geo-uri-handler kde-inhibit kde-open kde-open5 kde-print-queue kde-systemd-start-condition kde-systemsettings-tree.py kde_generate_export_header kde_wacom_tabletfinder kdebugdialog5 kdebugsettings kdeconnect-app kdeconnect-cli kdeconnect-handler kdeconnect-indicator kdeconnect-settings kdeconnect-sms kdecp kdecp5 kded5 (8) - KDE daemon - triggers Sycoca database updates when needed. kdedoc kdeinit5 (8) - Launcher for applications built with kdeinit support, and for KIO slaves. kdeinit5_shutdown kdeinit5_wrapper kdekillall kdelnk2desktop.py kdemangen.pl kdemv kdemv5 kdenlive kdenlive_render kdestroy (1) - destroy Kerberos tickets kdestroy.heimdal kdesvn kdesvnaskpass kdev-pg-qt kdev_dbus_socket_transformer kdev_format_source kdev_includepathsconverter kdevelop kdevelop! kdevplatform_shell_environment.sh kdf (1ssl) - OpenSSL application commands kdialog kdialog_progress_helper kdiff3 kdig kdocker kdrfc kdrill kdt2kdt kdtoa kdtquery kdwsdl2cpp keditbookmarks keditfiletype keditfiletype5 keepassx (1) - password manager keepassxc keepassxc-cli keepassxc-proxy kel-agent kelbt kephra kermit kermit-sshsub kernel-install kernel-wedge kernelshark kerneltop kernprof ketcindy keurocalc kexi-3.2 key key-mapper-control key-mapper-gtk key-mapper-service key2odp key2raw key2text key2xhtml keyanalyze keyart keychain keydctl keyhead keylookup keynav keyring keyringer keystone-manage keystone-status keystone-wsgi-admin keystone-wsgi-public keytest keywait kf kf-slam kf5-config kf5kross kfind kfloppy kfmclient kfontinst kfontview kgb kgb-ci-report kgb-client kgendesignerplugin kgeography kget kgetcred kglobalaccel5 kgpg kgx khal khangman khard khelpcenter khmer khost kibitz kicad kicad2step kickpass kiconfinder5 kid3 kid3-cli kid3-qt kig kile kill-avarice kill_ctndisp kill_ctnnetwork killall (1) - kill processes by name Proc::Killall (3pm) - Kill all instances of a process by pattern matching the command-line killposte kim-api-collections-management kimagemapeditor kincidenceeditor kinect-3d-slam kinect-3d-view kinect-stereo-calib kinfocenter king king-probe kinit (1) - obtain and cache Kerberos ticket-granting ticket kinit.heimdal kinput2-canna kinput2-canna-wnn kinput2-wnn kioclient kioclient5 kioku kirigami2gallery kism3d kissnp2 kissplice kissreads2 kissutil kiten kitengen kitenkanjibrowser kitenradselect kitpost kitsend kitty kivaToFoam kiwi kiwi-ng kiwix-compile-i18n kiwix-compile-resources kiwix-desktop kiwix-manage kiwix-search kiwix-serve kjots kjs5 kjscmd5 kjsconsole kkc klatexformula klatexformula_cmdl klaus klavaro klayout klcc kleborate kleopatra klettres klick klipper klist (1) - list cached Kerberos tickets klist.heimdal klog kluppe klystrack km-config km-kvk2ldml km-package-get km-package-install km-package-list-installed km-package-uninstall kma kma_index kma_shm kmag kmail kmail-refresh-settings kmail_antivir kmail_clamav kmail_fprot kmail_sav kmc kmc_dump kmc_tools kmdaemon kmds kmenuedit kmer-mask kmerresistance kmetronome kmflcomp kmidiff kmimetypefinder kmimetypefinder5 kmix kmixctrl kmixremote kmk kmk_append kmk_ash kmk_cat kmk_chmod kmk_cmp kmk_cp kmk_echo kmk_expr kmk_gmake kmk_install kmk_ln kmk_md5sum kmk_mkdir kmk_mv kmk_printf kmk_redirect kmk_rm kmk_rmdir kmk_sed kmk_sleep kmk_test kmk_time kmk_touch kml2pykml kmon kmousetool kmouth kmplot kmscon kmscube kmview kmymoney knapsack knetattach knews knewsd knewstuff-dialog knock knockpy knotes knowthelist knsec3hash knsupdate knxd knxtool kodak2ti3 kodev kodi kodi-TexturePacker kodi-ps3remote kodi-send kodi-standalone kodi-wiiremote koi8rxterm (1) - X terminal emulator for KOI8-R environments kolourpaint komkindex kompare komposter kongress kongressac konqueror konsole konsolekalendar konsoleprofile kontact kontrast konversation konwert kookbook kookbooktouch kore korg2gig korganizer korgdump kpa-backup.sh kpa-thumbnailtool kpackagelauncherqml kpackagetool5 (1) - Install, list, remove Plasma packages kpagsh kpartloader kpasswd (1) - change a user's Kerberos password kpasswd.heimdal kpcli kpdic kpeg kphotoalbum kplymouththemeinstaller kpoints.x kpseaccess kpsepath kpsereadlink kpsestat kpsetool kpsewhere kpsewhich kpsexpand kquitapp5 kraft kraken kraken-build kraken-filter kraken-mpa-report kraken-report kraken-translate kraken2 kraken2-build kraken2-inspect kramdown kramdown-rfc kramdown-rfc-autolink-iref-cleanup kramdown-rfc-cache-i-d-bibxml kramdown-rfc-cache-subseries-bibxml kramdown-rfc-extract-markdown kramdown-rfc2629 krazy-licensecheck krb5-auth-dialog krb5-config (1) - tool for linking against MIT Kerberos libraries krb5-config.heimdal krb5-config.mit (1) - tool for linking against MIT Kerberos libraries krb5-strength-wordlist krdc kreadconfig5 krename krenew krfb krfb-virtualmonitor krita krita_version kritarunner kronatools_updateTaxonomy kronometer krop kruler krunner krunner-plugininstaller krusader kscreen-console kscreen-doctor kshark-record kshark-su-record kshell5 kshutdown ksmserver ksnip ksplashqml ksshaskpass kst2 kstars kstart kstart5 kstats kstatsviewer ksu (1) - Kerberized super-user ksu.heimdal ksuid ksvgtopng ksvgtopng5 kswitch (1) - switch primary ticket cache kswitch.heimdal ksystemlog ksystemstats ktClassifyBLAST ktGetContigMagnitudes ktGetLCA ktGetLibPath ktGetTaxIDFromAcc ktGetTaxInfo ktImportBLAST ktImportDiskUsage ktImportEC ktImportFCP ktImportGalaxy ktImportKrona ktImportMETAREP-BLAST ktImportMETAREP-EC ktImportMGRAST ktImportPhymmBL ktImportRDP ktImportRDPComparison ktImportTaxonomy ktImportText ktImportXML kteatime ktechlab ktelnetservice5 kthresher ktikz ktimer ktmagnetdownloader ktnef ktoblzcheck ktorrent ktouch ktp-contactlist ktp-debugger ktp-dialout-ui ktp-log-viewer ktp-send-file ktraderclient5 ktrash5 ktrip ktupnptest kturtle ktutil (1) - Kerberos keytab file maintenance utility ktutil.heimdal kubecolor kubectl kubectx kubens kubernetes-split-yaml kubetail kuiviewer kup kup-daemon kup-filedigger kup-purger kup-server kupfer kupfer-exec kuttypy-gui kuum kuvert kuvert_submit kvantummanager kvantumpreview kvirc kvkcard kvm (1) - kvm-enabling link for qemu-system-x86_64 kvno (1) - print key version numbers of Kerberos principals kwalify kwalitee-metrics kwallet-query (1) - KDE Wallet command-line manipulation tool kwalletaskpass kwalletcli kwalletcli_getpin kwalletd5 kwalletmanager5 kwartz-cloud kwartzproxy kwatchgnupg kwave kwboot kwddel kwdreg kwikdisk kwin kwin_wayland kwin_wayland_wrapper kwin_x11 kwnmz kwnntouch kwordquiz kwrapper5 kwrite kwriteconfig5 kxc kxc-add-key kxc-cryptsetup kxd kxd-add-client-key kxgencert kxstitch kydisplayswitch kylin-nm kylin-scanner kylin-video-new kytos kyua kzonecheck kzonesign l2cap-tester l2ping (1) - Send L2CAP echo request and receive answer l2test (1) - L2CAP testing tool l3afpad l3build l4p-tmpl label2colour label2mesh label3d labelconvert labelit.png labelme labelme_draw_json labelme_draw_label_png labelme_json_to_dataset labelsgmfix labelstats labgrid-suggest lablgl lablglut lablgtk2 lablie labltk labplot2 lacheck lacme-accountd ladspalist lagan.pl lagan_chaos lakbak lakclear lake lakres lalign36 lalrpop lam_conv lamarc lamassemble lambda lambda-term-actions lambda.x lambda2 lambda_indexer lamboot lamclean lamd lame lamexec lamgrow lamhalt laminfo lamnodes lamshrink lamtrace lamwipe landslide langdrill langford_adc_util langford_rf_fsynth langford_rx_rf_bb_vga langford_util langident lapackprof lapcat laplacianFoam laps laptop-detect larch larch_cli larch_server laserboy laserboy-2012.11.11 last (1) - show a listing of last logged in users last-dotplot last-map-probs last-merge-batches last-multiplot last-pair-probs last-postmask last-split last-split5 last-train lastal lastal5 lastb (1) - show a listing of last logged in users lastcomm lastdb lastdb5 lastlog (8) - reports the most recent login of all users or of a given user lastrelease lasts lastz lastz_D latency-histogram latency-plot latency-test latex latex-dev latex-encode latex-git-log latex-mk latex-papersize latex-wordcount latex209 latex2dvi latex2gif latex2html latex2man latex2nemeth latex2pdf latex2png latex2ps latex2rtf latex2text latex2utf8 latexdef latexdiff latexdiff-cvs latexdiff-fast latexdiff-git latexdiff-hg latexdiff-rcs latexdiff-svn latexdiff-vc latexdraw latexencode latexfileversion latexila latexindent latexmk latexml latexmlc latexmlfind latexmlmath latexmlpost latexpand latexrevise latexwalker latf-load latte-dock latticegen launchSysDbus launchdbus launchn launchy lav2avi lav2mpeg lav2wav lav2yuv lav_to_axt.py lav_to_maf.py lavacli lavaddwav lavadecode lavinfo lavpipe lavplay lavtrans lazarus-ide-2.2.4 lazbuild-2.2.4 lazpaint lazres-2.2.4 lazy_geometry lazygal lb lbcdclient lbdb-fetchaddr lbdb_dotlock lbdbq lbfgsb-examples_driver1_77 lbfgsb-examples_driver1_90 lbfgsb-examples_driver2_77 lbfgsb-examples_driver2_90 lbfgsb-examples_driver3_77 lbfgsb-examples_driver3_90 lbt lbt2dot lbunzip2 lbzcat lbzip2 lc lc-compliance lcab lcalc lcdexec lcdgps lcdproc lcdvc lcf (1) - Determine which of the historical versions of a config is installed lchfn lchsh lckdo lcm-gen lcm-logger lcm-logplayer lcm-logplayer-gui lcm-spy lconvert lcov lcp ld (1) - The GNU linker ld-musl-config ld.bfd (1) - The GNU linker ld.gold (1) - The GNU ELF linker ld.hugetlbfs ld.lld-11 (1) - ELF linker from the LLVM project ld.lld-13 ld.lld-14 ld.lld-15 ld.mold ld.so (8) - dynamic linker/loader ld1.x ld64.lld-13 ld64.lld-14 ld64.lld-15 ld64.lld.darwinnew-13 ld64.lld.darwinold-13 ld64.mold ld65 ld86 ldactoasc ldap-add-host-to-netgroup ldap-add-user-to-group ldap-createuser-krb5 ldap-debian-edu-install ldap-schema-manager ldap2dns ldap2netgroup ldap2tinydns-conf ldapadd (1) - LDAP modify entry and LDAP add entry tools ldapcompare (1) - LDAP compare tool ldapdelete (1) - LDAP delete entry tool ldapdomaindump ldapexop (1) - issue LDAP extended operations ldapmodify (1) - LDAP modify entry and LDAP add entry tools ldapmodrdn (1) - LDAP rename entry tool ldappasswd (1) - change the password of an LDAP entry ldapsearch (1) - LDAP search tool ldapurl (1) - LDAP URL formatting tool ldapvi ldapwhoami (1) - LDAP who am i? tool ldb ldbadd ldbash ldbdel ldbedit ldbmodify ldbrename ldbsearch ldc-build-runtime ldc-profdata ldc-prune-cache ldc2 ldclt ldd (1) - print shared object dependencies ldd.fakechroot ldd2bloodhound ldd2pretty lddt lddtree ldif-duplicate-attrs ldif-leading-spaces ldmd2 ldmtool ldns-chaos (1) - give some information about a nameserver ldns-compare-zones (1) - read and compare two zonefiles and print differences ldns-dane (1) - verify or create TLS authentication with DANE (RFC6698) ldns-dpa (1) - DNS Packet Analyzer. Analyze DNS packets in ip trace files ldns-gen-zone (1) - read a zonefile and print it while adding DS records and extra RR's ldns-key2ds (1) - transform a DNSKEY RR to a DS RR ldns-keyfetcher (1) - retrieve the DNSSEC DNSKEYs for a zone ldns-keygen (1) - generate a DNSSEC key pair ldns-mx (1) - print out the mx record(s) for a domain ldns-notify (1) - notify DNS servers that updates are available ldns-nsec3-hash (1) - print out the NSEC3 hash for a domain name ldns-read-zone (1) - read a zonefile and print it ldns-resolver (1) - tries to create a resolver from a resolv.conf file. ldns-revoke (1) - sets the revoke bit of a DNSKEY ldns-rrsig (1) - print out the inception and expiration dates in human readable form ldns-signzone (1) - sign a zonefile with DNSSEC data ldns-test-edns (1) - test if dns cache supports EDNS and DNSSEC. ldns-testns (1) - simple fake nameserver tool ldns-update (1) - send a dynamic update packet ldns-verify-zone (1) - read a DNSSEC signed zone and verify it. ldns-version (1) - print out the version of the ldns-library and tools on this system ldns-walk (1) - Retrieve the contents of a DNSSEC signed zone ldns-zcat (1) - reunite (z)split up a zone files ldns-zsplit (1) - split up a zone file ldnsd (1) - simple daemon example code ldo65 ldoc ldrdf ldresample ldverify le leaff leafnode-version leaftoppm leak-analyze leak-memory lean leanc leanchecker leanmake leanpkg leanproject learnkeys leave lebiniou lecm ledger ledger-autosync ledger2beancount ledit lefse2circlader.py lefse_format_input.py lefse_plot_cladogram.py lefse_plot_features.py lefse_plot_res.py lefse_run.py lefty (1) - A Programmable Graphics Editor leg legacy_blast legend legit lei lein lemon lemonbar lensfun-add-adapter lensfun-update-data leo leocad leon lepton-archive lepton-attrib lepton-cli lepton-config lepton-embed lepton-export lepton-netlist lepton-pcb_backannotate lepton-refdes_renum lepton-sch2pcb lepton-schdiff lepton-schematic lepton-shell lepton-symcheck lepton-symfix lepton-tragesym lepton-upcfg lepton-update lesana less (1) - opposite of more less2scss less_trivial_synth lessc lesscpy lessecho (1) - expand metacharacters lessfile (1) - "input preprocessor" for less. lesskey (1) - specify key bindings for less lessp lesspipe (1) - "input preprocessor" for less. lesstty letsencrypt letterize levee lex (1) - the fast lexical analyser generator lex_count lexcount1 lexd lexgrog (1) - parse header information in man pages lexicon leye lf lfit lfm lft.db (1) - print the route packets trace to network host lftp lftpget lgf-gen lgogdownloader lgp lgrep lhasa lhs2TeX libIDL-config-2 libais_stats libart2-config libassuan-config libast-config libcamerify libcangjie_bench libcangjie_cli libcangjie_dbbuilder libcdaudio-config libde265-dec265 libde265-sherlock265 libdecor-c++-demo libdecor-demo libdecor-egl libdeflate-gunzip libdeflate-gzip libdkimtest libecasoundc-config libemos_version libervia-backend libervia-cli libervia-tui libevdev-tweak-device libfm-pref-apps libftdi-config libftdi1-config libgcrypt-config (1) - script to get information about the installed version of libgcrypt. libguestfs-test-tool libifstat-config libime_history libime_jyutpingdict libime_migrate_fcitx4_pinyin libime_migrate_fcitx4_table libime_pinyindict libime_prediction libime_slm_build_binary libime_tabledict libinput (4) - libinput-based X.Org input driver liblinear-predict liblinear-train libmcrypt-config libmikmod-config libnet-config libnetcfg (1) - configure libnet libnfo-reader libnovaconfig libotf-config libpng-config libpng16-config libprelude-config libquicktime_config librados-config librarian-puppet librecad librecaptcha libreoffice (1) - LibreOffice office suite libsixel-config libslirp-helper libtbx.add_from_future_import_division libtbx.analyse_code_comments libtbx.any2unix libtbx.assert_line_count libtbx.assert_not_show_diff libtbx.assert_stdin libtbx.assert_stdin_contains_strings libtbx.assert_stdin_does_not_contain_strings libtbx.assert_stdin_ends_with libtbx.bash libtbx.bibtex libtbx.bootstrap libtbx.bundle_as_exe libtbx.bundle_as_selfx libtbx.check_libcpp libtbx.chunk libtbx.clean_clutter libtbx.clear_paths libtbx.configure libtbx.create_cctbx_bundle_for_installer libtbx.create_install_script_bat libtbx.create_installer libtbx.create_mac_app libtbx.create_selfx libtbx.create_unzipsfx libtbx.create_windows_exe libtbx.csh libtbx.dtrace libtbx.easy_qsub libtbx.env_run libtbx.epydoc_run libtbx.exec libtbx.extract_code_from_txt libtbx.find_clutter libtbx.find_files libtbx.find_in_repositories libtbx.find_old_style_classes libtbx.find_reserved_names libtbx.find_under_build libtbx.find_untested libtbx.find_unused_imports libtbx.find_unused_imports_crude libtbx.gdb libtbx.git_avoid_merges libtbx.help libtbx.import_all_ext libtbx.import_all_python libtbx.install libtbx.install_conda libtbx.latex libtbx.line_count libtbx.list_files libtbx.list_modules libtbx.list_source_files_sorted_by_size libtbx.make_dist libtbx.make_sphinx_html libtbx.nequal libtbx.parallel_simple libtbx.path_utility libtbx.pdflatex libtbx.phil libtbx.prime_factors_of libtbx.printenv libtbx.py_compile_all libtbx.python libtbx.raise_exception_for_testing libtbx.refresh libtbx.remote_processing libtbx.remove_tree libtbx.run_pickled_function libtbx.run_tests_parallel libtbx.scons libtbx.seconds_since_the_epoch libtbx.sge_available_slots libtbx.sge_qstat_counts libtbx.sh libtbx.show_all_on_path libtbx.show_bin_path libtbx.show_build_options libtbx.show_build_path libtbx.show_but_no_repr libtbx.show_commands libtbx.show_date_and_time libtbx.show_dist_paths libtbx.show_env libtbx.show_environ_usage libtbx.show_full_command_path libtbx.show_host_and_user libtbx.show_include_paths libtbx.show_lib_path libtbx.show_module_dependencies libtbx.show_number_of_processors libtbx.show_numeric_version libtbx.show_numpy_version libtbx.show_python_dependencies libtbx.show_python_sys_executable libtbx.show_pythonpath libtbx.show_repository_paths libtbx.show_tests libtbx.show_variable_names libtbx.start_binary_bundle libtbx.start_process libtbx.tcsh libtbx.unpack_in_sources libtbx.valgrind libtbx.wait_for_file libtool libtoolize (1) - Prepare a package to use libtool libtree libunity-tool libusb-config libwacom-list-devices libwacom-list-local-devices libwacom-show-stylus libwacom-update-db libwebsockets-test-client libwebsockets-test-lejp libwebsockets-test-server libwebsockets-test-server-extpoll libwmf-config libxsmm_gemm_generator libzt-test licensecheck licensing lid lie lifeograph liferea liferea-add-feed lift liggghts light light-locker light-locker-command light_correct lightdm-gtk-greeter-settings lightdm-gtk-greeter-settings-pkexec lightdm-settings lighter lightspeed likwid-bench likwid-features likwid-genTopoCfg likwid-memsweeper likwid-mpirun likwid-perfctr likwid-perfscope likwid-pin likwid-powermeter likwid-setFrequencies likwid-topology lilv-bench lilymidi lilypond lilypond-book lilypond-invoke-editor lilysong linbox-config linclassif lincredits lindna line_select.py lineardelta linefind lingot linguist link (1) - call the link function to create a link to a file link (2) - make a new name for a file link-generator link-parser linkchecker linkicc linkify-filelist linklint linkltc linkmap links links2 linksBed linogram linpac linphone linphone-daemon linphonec linphonecsh linssid-pkexec lintex lintian (1) - Static analysis tool for Debian packages lintian-annotate-hints (1) - give detailed information about Lintian's error tags lintian-brush lintian-explain-tags (1) - offer more information about Lintian's tags lintian-info (1) - give detailed information about Lintian's error tags lintian-junit-report lintopvf linux-boot-prober linux-check-removal linux-show-player linux-update-symlinks linux-version linux.uml linux32 (8) - change reported architecture in new program environment and/or set personality flags linux64 (8) - change reported architecture in new program environment and/or set personality flags linux_logo linuxcnc linuxcnc_info linuxcnc_module_helper linuxcnc_var linuxcnclcd linuxcncmkdesktop linuxcncrsh linuxcncsvr linuxcnctop linuxdoc linuxinfo linuxlogo lios liquidFilmFoam liquidctl liquidprompt_activate liquidsoap lirc-config-tool lirc-init-db lirc-lsremotes lirc-make-devinput lirc-setup lircrcd lisaac lisgd lisp_count lispmtopgm list-node-components list-node-modules list-unreleased listBugDatabaseInfo list_audio_tracks listadmin listbasic listbib listen (2) - listen for connections on a socket listfonts listgeo listimages listings-ext listor listpdffields listplugins listres (1) - list resources in widgets listserialportsc listsources listtodo lit2epub litecli litecoin litecoin-cli litecoind litl_merge litl_print litl_split litmus littcvt littlewizard littlewizardtest live-build live-clone livereload lkbib ll2utm llc llc-13 llc-14 llc-15 lld lld-13 lld-14 lld-15 lld-link lld-link-13 lld-link-14 lld-link-15 lldb lldb-13 lldb-14 lldb-15 lldb-argdumper lldb-argdumper-13 lldb-argdumper-14 lldb-argdumper-15 lldb-instr-13 lldb-instr-14 lldb-instr-15 lldb-server lldb-server-13 lldb-server-14 lldb-server-15 lldb-vscode-13 lldb-vscode-14 lldb-vscode-15 llgal lli lli-13 lli-14 lli-15 lli-child-target-13 lli-child-target-14 lli-child-target-15 llmnr-query lloconv llogin llt lltag lltsv llvm-PerfectShuffle llvm-PerfectShuffle-13 llvm-PerfectShuffle-14 llvm-PerfectShuffle-15 llvm-addr2line llvm-addr2line-13 llvm-addr2line-14 llvm-addr2line-15 llvm-ar llvm-ar-13 llvm-ar-14 llvm-ar-15 llvm-as llvm-as-13 llvm-as-14 llvm-as-15 llvm-bcanalyzer llvm-bcanalyzer-13 llvm-bcanalyzer-14 llvm-bcanalyzer-15 llvm-bitcode-strip-13 llvm-bitcode-strip-14 llvm-bitcode-strip-15 llvm-bolt-15 llvm-bolt-heatmap-15 llvm-boltdiff-15 llvm-c-test llvm-c-test-13 llvm-c-test-14 llvm-c-test-15 llvm-cat llvm-cat-13 llvm-cat-14 llvm-cat-15 llvm-cfi-verify llvm-cfi-verify-13 llvm-cfi-verify-14 llvm-cfi-verify-15 llvm-config llvm-config-13 llvm-config-14 llvm-config-15 llvm-cov llvm-cov-13 llvm-cov-14 llvm-cov-15 llvm-cvtres llvm-cvtres-13 llvm-cvtres-14 llvm-cvtres-15 llvm-cxxdump llvm-cxxdump-13 llvm-cxxdump-14 llvm-cxxdump-15 llvm-cxxfilt llvm-cxxfilt-13 llvm-cxxfilt-14 llvm-cxxfilt-15 llvm-cxxmap-13 llvm-cxxmap-14 llvm-cxxmap-15 llvm-debuginfod-15 llvm-debuginfod-find-14 llvm-debuginfod-find-15 llvm-diff llvm-diff-13 llvm-diff-14 llvm-diff-15 llvm-dis llvm-dis-13 llvm-dis-14 llvm-dis-15 llvm-dlltool llvm-dlltool-13 llvm-dlltool-14 llvm-dlltool-15 llvm-dwarfdump llvm-dwarfdump-13 llvm-dwarfdump-14 llvm-dwarfdump-15 llvm-dwarfutil-15 llvm-dwp llvm-dwp-13 llvm-dwp-14 llvm-dwp-15 llvm-exegesis llvm-exegesis-13 llvm-exegesis-14 llvm-exegesis-15 llvm-extract llvm-extract-13 llvm-extract-14 llvm-extract-15 llvm-gsymutil-13 llvm-gsymutil-14 llvm-gsymutil-15 llvm-ifs-13 llvm-ifs-14 llvm-ifs-15 llvm-install-name-tool-13 llvm-install-name-tool-14 llvm-install-name-tool-15 llvm-jitlink-13 llvm-jitlink-14 llvm-jitlink-15 llvm-jitlink-executor-13 llvm-jitlink-executor-14 llvm-jitlink-executor-15 llvm-lib llvm-lib-13 llvm-lib-14 llvm-lib-15 llvm-libtool-darwin-13 llvm-libtool-darwin-14 llvm-libtool-darwin-15 llvm-link llvm-link-13 llvm-link-14 llvm-link-15 llvm-lipo-13 llvm-lipo-14 llvm-lipo-15 llvm-lto llvm-lto-13 llvm-lto-14 llvm-lto-15 llvm-lto2 llvm-lto2-13 llvm-lto2-14 llvm-lto2-15 llvm-mc llvm-mc-13 llvm-mc-14 llvm-mc-15 llvm-mca llvm-mca-13 llvm-mca-14 llvm-mca-15 llvm-ml-13 llvm-ml-14 llvm-ml-15 llvm-modextract llvm-modextract-13 llvm-modextract-14 llvm-modextract-15 llvm-mt llvm-mt-13 llvm-mt-14 llvm-mt-15 llvm-nm llvm-nm-13 llvm-nm-14 llvm-nm-15 llvm-objcopy llvm-objcopy-13 llvm-objcopy-14 llvm-objcopy-15 llvm-objdump llvm-objdump-13 llvm-objdump-14 llvm-objdump-15 llvm-omp-device-info-13 llvm-omp-device-info-14 llvm-omp-device-info-15 llvm-opt-report llvm-opt-report-13 llvm-opt-report-14 llvm-opt-report-15 llvm-otool-13 llvm-otool-14 llvm-otool-15 llvm-pdbutil llvm-pdbutil-13 llvm-pdbutil-14 llvm-pdbutil-15 llvm-profdata llvm-profdata-13 llvm-profdata-14 llvm-profdata-15 llvm-profgen-13 llvm-profgen-14 llvm-profgen-15 llvm-ranlib llvm-ranlib-13 llvm-ranlib-14 llvm-ranlib-15 llvm-rc llvm-rc-13 llvm-rc-14 llvm-rc-15 llvm-readelf llvm-readelf-13 llvm-readelf-14 llvm-readelf-15 llvm-readobj llvm-readobj-13 llvm-readobj-14 llvm-readobj-15 llvm-reduce-13 llvm-reduce-14 llvm-reduce-15 llvm-remark-size-diff-15 llvm-rtdyld llvm-rtdyld-13 llvm-rtdyld-14 llvm-rtdyld-15 llvm-sim-13 llvm-sim-14 llvm-sim-15 llvm-size llvm-size-13 llvm-size-14 llvm-size-15 llvm-spirv-14 llvm-spirv-15 llvm-split llvm-split-13 llvm-split-14 llvm-split-15 llvm-stress llvm-stress-13 llvm-stress-14 llvm-stress-15 llvm-strings llvm-strings-13 llvm-strings-14 llvm-strings-15 llvm-strip llvm-strip-13 llvm-strip-14 llvm-strip-15 llvm-symbolizer llvm-symbolizer-13 llvm-symbolizer-14 llvm-symbolizer-15 llvm-tapi-diff-13 llvm-tapi-diff-14 llvm-tapi-diff-15 llvm-tblgen llvm-tblgen-13 llvm-tblgen-14 llvm-tblgen-15 llvm-tli-checker-14 llvm-tli-checker-15 llvm-undname llvm-undname-13 llvm-undname-14 llvm-undname-15 llvm-windres-13 llvm-windres-14 llvm-windres-15 llvm-xray llvm-xray-13 llvm-xray-14 llvm-xray-15 lm4flash lmawk lmbi lmdb_cat lmdb_copy lmdb_stat lmicdi lmms lmove lmp lnav lndir lneato (1) - A Customizable Graph Editor lnkinfo lnnmz lnpdll lnpdllx lnptest lnptest2 lnstat (8) - unified linux network statistics lo10k1 lo10k1.bin load-EOAdaptor load2db load2sqlitedb load_control load_genbank loader_eye loadunimap loadwatch lobase (1) - LibreOffice office suite local-getcert localc (1) - LibreOffice office suite locale (1) - get locale-specific information locale (5) - describes a locale definition file locale (7) - description of multilanguage support localectl localedef (1) - compile locale definition files localehelper localinfo localslackirc locate.findutils (1) - list files in databases that match a pattern locatediff location location-importer loch lock_jars lockfile lockfile-check lockfile-create lockfile-remove lockfile-touch lockfs-notify lockmail.courier lockmail.maildrop lockout locktest lockutils-wrapper locuspocus locust lodraw (1) - LibreOffice office suite lodscore loess loffice (1) - LibreOffice office suite lofromtemplate (1) - LibreOffice office suite log2asc log2gpx log2graph log2long log4c-config log4cpp-config logViewerAuth logViewerTruncate loganalyser logapp logcheck-test logcombiner logconv logcvs logformat loggedfs loggen logger (1) - enter messages into the system log loggerhead-serve logid logilab-pytest logisim logmake logname (1) - print user's login name lognormalizer logontime logprn logresolve logs2html logstalgia logsvn logswan logtool logtop loimpress (1) - LibreOffice office suite lokalize loki loki_count loki_dist loki_ext loki_freq loki_sort_error lola lollipop lollypop lomath (1) - LibreOffice office suite lomiri-app-info lomiri-app-launch lomiri-app-launch-appids lomiri-app-launch-profiler-lttng lomiri-app-launch-tracepoints lomiri-app-list lomiri-app-list-pids lomiri-app-pid lomiri-app-stop lomiri-app-test lomiri-app-triplet lomiri-app-usage lomiri-app-watch lomiri-appstart-profile lomiri-appstart-test lomiri-download-manager lomiri-gallery-app lomiri-helper-list lomiri-helper-start lomiri-helper-stop lomiri-thumbnailer-admin lomiri-ui-toolkit-launcher lomiri-upload-manager lomiri-url-dispatcher lomiri-url-dispatcher-dump lomoco londiste look (1) - display lines beginning with a given string lookandfeelexplorer lookandfeeltool lookatme lookbib looking-glass-client looktxt lookup loook loose-envify lopsubgen loqui lorem lou_allround lou_checkhyphens lou_checktable lou_checkyaml lou_debug lou_tableinfo lou_trace lou_translate loudgain louvain-community love-11.4 low_level_make_sandbox lowdown lowdown-diff loweb (1) - LibreOffice office suite lowriter (1) - LibreOffice office suite lp (1) - print files lp (4) - line printer devices lp-attach lp-auto-answer lp-bug-dupe-properties lp-capture-bug-counts lp-check-membership lp-force-branch-mirror lp-get-branches lp-grab-attachments lp-list-bugs lp-milestone2ical lp-milestones lp-project lp-project-upload lp-recipe-status lp-remove-team-members lp-sendmsg lp-set-dup lp-shell lp_solve (1) - a mixed integer linear programming (MILP) solver lpanal lpass lpc21isp lpc_binary_check lpc_export lpc_import lpcisp lpconvert lpcprog lpe lpoptions (1) - display or set printer options and defaults lpq (1) - show printer queue status lpr (1) - print files lprdvi lprint lprm (1) - cancel print jobs lpstat (1) - print cups status information lptest lpunlock lqa lqt_transcode lqtplay lqtremux lr lrcalc lrelease lrf2lrs lrfviewer lrs lrs2lrf lrsnash lrstolfm-2.2.4 lrunzip lrx-comp lrx-proc lrz lrzcat lrzip lrztar lrzuntar ls2ti3 lsar lsattr (1) - list file attributes on a Linux second extended file system lsb_release (1) - print distribution-specific information (minimal implementation). lsbilibop lsbtr lsc lscgroup lscolors lsconv lscp lscpu (1) - display information about the CPU architecture lsdev lsdic lsdiff (1) - show which files are modified by a patch lsdistcc lsdvb lsdvd lsfd (1) - list file descriptors lsftp lsfupdater lsgpu lsh lsh-authorize lsh-decode-key lsh-decrypt-key lsh-export-key lsh-keygen lsh-make-seed lsh-upgrade lsh-upgrade-key lsh-writekey lshg lshw lshw-gtk lsinitramfs lsinitrd lsinput lsipc (1) - show information on IPC facilities currently employed in the system lsirq (1) - utility to display kernel interrupt information lslocks (8) - list local system locks lslogins (1) - display information about known users in the system lsmbox lsmdev lsmem (1) - list the ranges of available memory with their online status lsmf lsmount lsns (8) - list namespaces lsof (8) - list open files lsp-plugins-art-delay-mono lsp-plugins-art-delay-stereo lsp-plugins-comp-delay-mono lsp-plugins-comp-delay-stereo lsp-plugins-comp-delay-x2-stereo lsp-plugins-compressor-lr lsp-plugins-compressor-mono lsp-plugins-compressor-ms lsp-plugins-compressor-stereo lsp-plugins-crossover-lr lsp-plugins-crossover-mono lsp-plugins-crossover-ms lsp-plugins-crossover-stereo lsp-plugins-dyna-processor-lr lsp-plugins-dyna-processor-mono lsp-plugins-dyna-processor-ms lsp-plugins-dyna-processor-stereo lsp-plugins-expander-lr lsp-plugins-expander-mono lsp-plugins-expander-ms lsp-plugins-expander-stereo lsp-plugins-gate-lr lsp-plugins-gate-mono lsp-plugins-gate-ms lsp-plugins-gate-stereo lsp-plugins-graph-equalizer-x16-lr lsp-plugins-graph-equalizer-x16-mono lsp-plugins-graph-equalizer-x16-ms lsp-plugins-graph-equalizer-x16-stereo lsp-plugins-graph-equalizer-x32-lr lsp-plugins-graph-equalizer-x32-mono lsp-plugins-graph-equalizer-x32-ms lsp-plugins-graph-equalizer-x32-stereo lsp-plugins-impulse-responses-mono lsp-plugins-impulse-responses-stereo lsp-plugins-impulse-reverb-mono lsp-plugins-impulse-reverb-stereo lsp-plugins-latency-meter lsp-plugins-limiter-mono lsp-plugins-limiter-stereo lsp-plugins-loud-comp-mono lsp-plugins-loud-comp-stereo lsp-plugins-mb-compressor-lr lsp-plugins-mb-compressor-mono lsp-plugins-mb-compressor-ms lsp-plugins-mb-compressor-stereo lsp-plugins-mb-expander-lr lsp-plugins-mb-expander-mono lsp-plugins-mb-expander-ms lsp-plugins-mb-expander-stereo lsp-plugins-mb-gate-lr lsp-plugins-mb-gate-mono lsp-plugins-mb-gate-ms lsp-plugins-mb-gate-stereo lsp-plugins-multisampler-x12 lsp-plugins-multisampler-x12-do lsp-plugins-multisampler-x24 lsp-plugins-multisampler-x24-do lsp-plugins-multisampler-x48 lsp-plugins-multisampler-x48-do lsp-plugins-oscillator-mono lsp-plugins-oscilloscope-x1 lsp-plugins-oscilloscope-x2 lsp-plugins-oscilloscope-x4 lsp-plugins-para-equalizer-x16-lr lsp-plugins-para-equalizer-x16-mono lsp-plugins-para-equalizer-x16-ms lsp-plugins-para-equalizer-x16-stereo lsp-plugins-para-equalizer-x32-lr lsp-plugins-para-equalizer-x32-mono lsp-plugins-para-equalizer-x32-ms lsp-plugins-para-equalizer-x32-stereo lsp-plugins-phase-detector lsp-plugins-profiler-mono lsp-plugins-profiler-stereo lsp-plugins-room-builder-mono lsp-plugins-room-builder-stereo lsp-plugins-sampler-mono lsp-plugins-sampler-stereo lsp-plugins-sc-compressor-lr lsp-plugins-sc-compressor-mono lsp-plugins-sc-compressor-ms lsp-plugins-sc-compressor-stereo lsp-plugins-sc-dyna-processor-lr lsp-plugins-sc-dyna-processor-mono lsp-plugins-sc-dyna-processor-ms lsp-plugins-sc-dyna-processor-stereo lsp-plugins-sc-expander-lr lsp-plugins-sc-expander-mono lsp-plugins-sc-expander-ms lsp-plugins-sc-expander-stereo lsp-plugins-sc-gate-lr lsp-plugins-sc-gate-mono lsp-plugins-sc-gate-ms lsp-plugins-sc-gate-stereo lsp-plugins-sc-limiter-mono lsp-plugins-sc-limiter-stereo lsp-plugins-sc-mb-compressor-lr lsp-plugins-sc-mb-compressor-mono lsp-plugins-sc-mb-compressor-ms lsp-plugins-sc-mb-compressor-stereo lsp-plugins-sc-mb-expander-lr lsp-plugins-sc-mb-expander-mono lsp-plugins-sc-mb-expander-ms lsp-plugins-sc-mb-expander-stereo lsp-plugins-sc-mb-gate-lr lsp-plugins-sc-mb-gate-mono lsp-plugins-sc-mb-gate-ms lsp-plugins-sc-mb-gate-stereo lsp-plugins-slap-delay-mono lsp-plugins-slap-delay-stereo lsp-plugins-spectrum-analyzer-x1 lsp-plugins-spectrum-analyzer-x12 lsp-plugins-spectrum-analyzer-x16 lsp-plugins-spectrum-analyzer-x2 lsp-plugins-spectrum-analyzer-x4 lsp-plugins-spectrum-analyzer-x8 lsp-plugins-surge-filter-mono lsp-plugins-surge-filter-stereo lsp-plugins-trigger-midi-mono lsp-plugins-trigger-midi-stereo lsp-plugins-trigger-mono lsp-plugins-trigger-stereo lspci (8) - list all PCI devices lspgpot (1) - extracts the ownertrust values from PGP keyrings and list them in GnuPG ownertrust format. lspower lspst lsrc lss16toppm lsscsi lssu lssubsys lstmeval lstmtraining lstopo lstopo-no-graphics lsusb lsw lswm lsx-comp lsx-proc lsxfel lsyncd lt-append lt-apply-acx lt-comp lt-compose lt-expand lt-invert lt-paradigm lt-print lt-proc lt-restrict lt-tmxcomp lt-tmxproc lt-trim ltdbtool ltnu lto-dump-10 lto-dump-11 lto-dump-12 ltpanel ltpretty ltrace ltrsift ltrsift_encode lttng lttng-analyses-record lttng-cputop lttng-cputop-mi lttng-crash lttng-gen-tp lttng-iolatencyfreq lttng-iolatencyfreq-mi lttng-iolatencystats lttng-iolatencystats-mi lttng-iolatencytop lttng-iolatencytop-mi lttng-iolog lttng-iolog-mi lttng-iousagetop lttng-iousagetop-mi lttng-irqfreq lttng-irqfreq-mi lttng-irqlog lttng-irqlog-mi lttng-irqstats lttng-irqstats-mi lttng-memtop lttng-memtop-mi lttng-periodfreq lttng-periodfreq-mi lttng-periodlog lttng-periodlog-mi lttng-periodstats lttng-periodstats-mi lttng-periodtop lttng-periodtop-mi lttng-relayd lttng-schedfreq lttng-schedfreq-mi lttng-schedlog lttng-schedlog-mi lttng-schedstats lttng-schedstats-mi lttng-schedtop lttng-schedtop-mi lttng-sessiond lttng-syscallstats lttng-syscallstats-mi lttng-track-process ltunify ltx2crossrefxml ltxfileinfo ltximg lu-comment-extractor lu-sh lua-any lua-create-gitbuildpackage-layout lua-create-svnbuildpackage-layout lua5.1 lua5.2 lua5.3 lua5.4 luac5.1 luac5.2 luac5.3 luac5.4 luacheck luadoc luahbtex luajit luajithbtex luajittex luakit lualatex lualatex-dev luaotfload-tool luarocks luarocks-5.1 luarocks-5.2 luarocks-5.3 luarocks-5.4 luarocks-admin luarocks-admin-5.1 luarocks-admin-5.2 luarocks-admin-5.3 luarocks-admin-5.4 luatex luatools luau luckybackup luckybackup-pkexec luckyluks lucy ludevit ludevit_tk luit (1) - Locale and ISO 2022 support for Unicode terminals luksdeinfo luksdemount luksmeta lumin luminance-hdr luminance-hdr-cli lumpedPointForces lumpedPointMovement lumpedPointZones lumper lumpy lumpy_filter lumpyexpress lunar lunar-date lunzip lupdate lur-command lut lutefisk lv lv2_validate lv2apply lv2bench lv2file lv2info lv2ls lv2peg lv2proc lv2soname lw-ctl lwarpmk lwatch lwm lwp-download (1p) - Fetch large files from the web lwp-dump (1p) - See what headers and content is returned for a URL lwp-mirror (1p) - Simple mirror utility lwp-request (1p) - Simple command line user agent lxappearance (1) - GTK+ theme switcher lxc lxc-attach lxc-autostart lxc-cgroup lxc-checkconfig lxc-checkpoint lxc-config lxc-console lxc-copy lxc-create lxc-destroy lxc-device lxc-execute lxc-freeze lxc-info lxc-ls lxc-monitor lxc-snapshot lxc-start lxc-stop lxc-test-api-reboot lxc-test-apparmor lxc-test-apparmor-generated lxc-test-apparmor-mount lxc-test-arch-parse lxc-test-attach lxc-test-automount lxc-test-autostart lxc-test-basic lxc-test-capabilities lxc-test-cgpath lxc-test-checkpoint-restore lxc-test-cloneconfig lxc-test-clonetest lxc-test-concurrent lxc-test-config-jump-table lxc-test-console lxc-test-console-log lxc-test-containertests lxc-test-createconfig lxc-test-createtest lxc-test-criu-check-feature lxc-test-cve-2019-5736 lxc-test-destroytest lxc-test-device-add-remove lxc-test-exit-code lxc-test-get_item lxc-test-getkeys lxc-test-list lxc-test-locktests lxc-test-lxc-attach lxc-test-lxcpath lxc-test-may-control lxc-test-mount-injection lxc-test-no-new-privs lxc-test-parse-config-file lxc-test-proc-pid lxc-test-procsys lxc-test-raw-clone lxc-test-reboot lxc-test-rootfs lxc-test-rootfs-options lxc-test-saveconfig lxc-test-share-ns lxc-test-shortlived lxc-test-shutdowntest lxc-test-snapdeps lxc-test-snapshot lxc-test-startone lxc-test-state-server lxc-test-symlink lxc-test-sys-mixed lxc-test-sysctls lxc-test-unpriv lxc-test-usernic lxc-test-usernsexec lxc-test-utils lxc-to-lxd lxc-top lxc-unfreeze lxc-unpriv-attach lxc-unpriv-start lxc-unshare lxc-update-config lxc-usernsexec lxc-wait lxcfs lxclipboard lxctl lxd lxd-agent lxd-benchmark lxd-migrate lxd-user lxde-logout lxdm-config lxhotkey lxi lximage-qt lxinput lxlauncher lxlock lxpanel lxpanelctl lxpolkit lxqt-about lxqt-admin-time lxqt-admin-user lxqt-admin-user-helper lxqt-archiver lxqt-backlight_backend lxqt-config lxqt-config-appearance lxqt-config-brightness lxqt-config-file-associations lxqt-config-globalkeyshortcuts lxqt-config-input lxqt-config-locale lxqt-config-monitor lxqt-config-notificationd lxqt-config-powermanagement lxqt-config-session lxqt-globalkeysd lxqt-leave lxqt-notificationd lxqt-openssh-askpass lxqt-panel lxqt-policykit-agent lxqt-powermanagement lxqt-runner lxqt-session lxqt-sudo lxqt-transupdate lxrandr lxsession lxsession-db lxsession-default lxsession-default-apps lxsession-default-terminal lxsession-edit lxsession-logout lxsession-xdg-autostart lxsettings-daemon (1) - lightweight XSettings daemon for LXDE lxshortcut lxsu lxsudo lxt2miner lxt2vcd lxtask lxterm (1) - locale-sensitive wrapper for xterm lxterminal ly ly-server lybniz lynx (1) - a general purpose distributed information browser for the World Wide Web lyx lyxclient lz (1) - gunzips and shows a listing of a gzip'd tar'd archive lz4 lz4c lz4cat lz4jsoncat lz4toolsCli lzd lzip.clzip lzip.lunzip lzip.lzip (1) - reduces the size of files lzip.lziprecover lzip.minilzip lzip.pdlzip lzip.plzip lzip.xlunzip lziprecover lzma_alone lzmadec lzmainfo (1) - show information stored in the .lzma file header lzmp lzop (1) - compress or expand files lzop_build_offset_table.py m-a m-tx m16c-flash m17n-conv m17n-date m17n-db m17n-dump m17n-edit m17n-im-config m17n-view m2300w m2300w-wrapper m2400w m2adapter m2gmetis m2o m2r m2sh m2ts2ts m4 (1) - macro processor m4ctl m68hc11-addr2line m68hc11-ar m68hc11-as m68hc11-c++filt m68hc11-elfedit m68hc11-gprof m68hc11-ld m68hc11-ld.bfd m68hc11-nm m68hc11-objcopy m68hc11-objdump m68hc11-ranlib m68hc11-readelf m68hc11-size m68hc11-strings m68hc11-strip m68k-linux-gnu-addr2line m68k-linux-gnu-ar m68k-linux-gnu-as m68k-linux-gnu-c++filt m68k-linux-gnu-cpp m68k-linux-gnu-cpp-10 m68k-linux-gnu-cpp-11 m68k-linux-gnu-cpp-12 m68k-linux-gnu-elfedit m68k-linux-gnu-g++ m68k-linux-gnu-g++-10 m68k-linux-gnu-g++-11 m68k-linux-gnu-g++-12 m68k-linux-gnu-gcc m68k-linux-gnu-gcc-10 m68k-linux-gnu-gcc-11 m68k-linux-gnu-gcc-12 m68k-linux-gnu-gcc-ar m68k-linux-gnu-gcc-ar-10 m68k-linux-gnu-gcc-ar-11 m68k-linux-gnu-gcc-ar-12 m68k-linux-gnu-gcc-nm m68k-linux-gnu-gcc-nm-10 m68k-linux-gnu-gcc-nm-11 m68k-linux-gnu-gcc-nm-12 m68k-linux-gnu-gcc-ranlib m68k-linux-gnu-gcc-ranlib-10 m68k-linux-gnu-gcc-ranlib-11 m68k-linux-gnu-gcc-ranlib-12 m68k-linux-gnu-gcov m68k-linux-gnu-gcov-10 m68k-linux-gnu-gcov-11 m68k-linux-gnu-gcov-12 m68k-linux-gnu-gcov-dump m68k-linux-gnu-gcov-dump-10 m68k-linux-gnu-gcov-dump-11 m68k-linux-gnu-gcov-dump-12 m68k-linux-gnu-gcov-tool m68k-linux-gnu-gcov-tool-10 m68k-linux-gnu-gcov-tool-11 m68k-linux-gnu-gcov-tool-12 m68k-linux-gnu-gdc-10 m68k-linux-gnu-gdc-11 m68k-linux-gnu-gfortran m68k-linux-gnu-gfortran-10 m68k-linux-gnu-gfortran-11 m68k-linux-gnu-gfortran-12 m68k-linux-gnu-gm2 m68k-linux-gnu-gm2-10 m68k-linux-gnu-gm2-11 m68k-linux-gnu-gm2-12 m68k-linux-gnu-gnat m68k-linux-gnu-gnat-10 m68k-linux-gnu-gnat-12 m68k-linux-gnu-gnatbind m68k-linux-gnu-gnatbind-10 m68k-linux-gnu-gnatbind-12 m68k-linux-gnu-gnatchop m68k-linux-gnu-gnatchop-10 m68k-linux-gnu-gnatchop-12 m68k-linux-gnu-gnatclean m68k-linux-gnu-gnatclean-10 m68k-linux-gnu-gnatclean-12 m68k-linux-gnu-gnatfind m68k-linux-gnu-gnatfind-10 m68k-linux-gnu-gnatgcc m68k-linux-gnu-gnathtml m68k-linux-gnu-gnathtml-10 m68k-linux-gnu-gnathtml-12 m68k-linux-gnu-gnatkr m68k-linux-gnu-gnatkr-10 m68k-linux-gnu-gnatkr-12 m68k-linux-gnu-gnatlink m68k-linux-gnu-gnatlink-10 m68k-linux-gnu-gnatlink-12 m68k-linux-gnu-gnatls m68k-linux-gnu-gnatls-10 m68k-linux-gnu-gnatls-12 m68k-linux-gnu-gnatmake m68k-linux-gnu-gnatmake-10 m68k-linux-gnu-gnatmake-12 m68k-linux-gnu-gnatname m68k-linux-gnu-gnatname-10 m68k-linux-gnu-gnatname-12 m68k-linux-gnu-gnatprep m68k-linux-gnu-gnatprep-10 m68k-linux-gnu-gnatprep-12 m68k-linux-gnu-gnatxref m68k-linux-gnu-gnatxref-10 m68k-linux-gnu-gprof m68k-linux-gnu-ld m68k-linux-gnu-ld.bfd m68k-linux-gnu-lto-dump-10 m68k-linux-gnu-lto-dump-11 m68k-linux-gnu-lto-dump-12 m68k-linux-gnu-nm m68k-linux-gnu-objcopy m68k-linux-gnu-objdump m68k-linux-gnu-ranlib m68k-linux-gnu-readelf m68k-linux-gnu-size m68k-linux-gnu-strings m68k-linux-gnu-strip mAdd mAddCube mArchiveExec mArchiveGet mArchiveList mBackground mBestImage mBgExec mBgModel mCalExec mCalibrate mCaller mCatMap mCatSearch mConcatFit mConvert mCoverageCheck mDAG mDAGFiles mDAGGalacticPlane mDAGTbls mDiff mDiffExec mDiffFit mDiffFitExec mExamine mExec mExecTG mFitExec mFitplane mFixHdr mFixNaN mFlattenExec mGetHdr mGridExec mHdr mHdrCheck mHdrWWT mHdrWWTExec mHdrtbl mHistogram mImgtbl mMK_bitset.py mMakeHdr mMakeImg mNotify mNotifyTG mOverlaps mPNGWWTExec mPad mPix2Coord mPresentation mProjExec mProjWWTExec mProject mProjectCube mProjectPP mProjectQL mPutHdr mRotate mShrink mShrinkCube mShrinkHdr mSubCube mSubimage mTANHdr mTblExec mTblSort mTileHdr mTileImage mTranspose mViewer mab2_convert mac-robber mac2pw mac2pwd mac2unix macchanger macpack macping macptopbm macro1 macro7 macro8x macroave macs2 macsave macstream macsyconfig macsydata macsyfinder macsymerge macsyprofile macsysplit mactelnet mactime (1) - Create an ASCII time line of file activity macunpack macusers maddr madison-lite madplay maf-convert maf-cut maf-join maf-sort maf-swap maf_build_index.py maf_chop.py maf_chunk.py maf_col_counts.py maf_col_counts_all.py maf_count.py maf_covered_ranges.py maf_covered_regions.py maf_div_sites.py maf_drop_overlapping.py maf_extract_chrom_ranges.py maf_extract_ranges.py maf_extract_ranges_indexed.py maf_filter.py maf_filter_max_wc.py maf_gap_frequency.py maf_gc_content.py maf_interval_alignibility.py maf_limit_to_species.py maf_mapping_word_frequency.py maf_mask_cpg.py maf_mean_length_ungapped_piece.py maf_parse maf_percent_columns_matching.py maf_percent_identity.py maf_print_chroms.py maf_print_scores.py maf_randomize.py maf_region_coverage_by_src.py maf_select.py maf_shuffle_columns.py maf_species_in_all_files.py maf_split_by_src.py maf_thread_for_species.py maf_tile.py maf_tile_2.py maf_tile_2bit.py maf_to_axt.py maf_to_concat_fasta.py maf_to_fasta.py maf_to_int_seqs.py maf_translate_chars.py maf_truncate.py maf_word_frequency.py maffilter mafft mafft-homologs mafft-profile mag magic (5) - file command's magic pattern file magicrescue magics magicsCompatibilityChecker magicsort magjson magjsonx magml magmlx magnet-link magneticFoam magnum magnum-api magnum-api-wsgi magnum-conductor magnum-db-manage magnum-driver-manage magnum-status magnus magrep maho600gui mahoniconv mail-expire mail-lock mail-touchlock mail-unlock mail.mailutils (1) - process mail messages mail_room mailagent mailbot mailbox-preview mailcheck maildir-filter maildir-import-patch maildiracl maildirkw maildirmake.courier maildirmake.dovecot maildirmake.maildrop maildirsync maildist maildrop mailexporter mailfilter mailhelp maillist mailmail3 mailman mailman-web mailman-wrapper mailnag mailnag-config mailodf mailpatch mailq (8) - a Mail Transfer Agent mailq.userv mailsound mailsplit mailstat mailsync mailtextbody mailutil mailutils mailutils-config mailutime maim mairix makdbs make (1) - GNU make utility to maintain groups of programs make-cadir make-first-existing-target (1) - runs make on one of several targets make-lingua-identify-language make-microsoft-freecell-board make-passwd.tiarra make-pod-from-help make-pysol-freecell-board make2graph make4ht makeBadgerMatrix makeFaMesh makeHKY makeMauveWargFile makeSCF makeSH make_ataqv_pipeline make_bed make_combined_log2 make_das_conf make_db make_encmap make_filelists make_growfs make_iupac_cmp.pl make_metadata make_method make_multi_seq make_multiple_custom_sandbox make_multiple_sandbox make_replication_sandbox make_sandbox make_sandbox_from_installed make_sandbox_from_source make_sandbox_from_url make_services make_strings make_wagon_desc makeacm makeastheme makebdb makebin makeblastdb makebootfat makebuildserver makecbf makecert makeconv makecsd makedat.courier makedat.maildrop makedatprog makedb makedeltaiso makedeltarpm makedepend makedepf90 makedic makedist makedtx makedumpfile makedumpfile-R.pl makeedict makefile2graph makefile_count makefilegen makeflow makeflow_amazon_batch_cleanup makeflow_amazon_batch_setup makeflow_analyze makeflow_archive_query makeflow_blasr makeflow_blast makeflow_bwa makeflow_ec2_cleanup makeflow_ec2_estimate makeflow_ec2_setup makeflow_gatk makeflow_graph_log makeflow_lambda_cleanup makeflow_lambda_setup makeflow_linker makeflow_linker_perl_driver makeflow_linker_python_driver makeflow_monitor makeflow_mpi_starter makeflow_mpi_submitter makeflow_status makeflow_viz makeg makegdbm makeglossaries makeglossaries-lite makehmmerdb makehrtf makeindex makeinfo makeivs-ng makejvf makembindex makemime makensis makenucseq makeobj makepage makeparallel makepasswd makepatch makepkg makepkg-template makepp makepp_build_cache_control makeppbuiltin makeppclean makeppgraph makeppinfo makepplog makeppreplay makeprofiledb makeprotseq makeself makeset makeskel-3.2.2 makeskkcdbdic makesmat maketext maketx makexvpics makmdm mako mako-render makoctl malaga malcontent-client (8) - Parental Controls Access Utility malcontent-control maliit-keyboard maliit-server mallex malmake malrul malshow malsym malt-build malt-run man (1) - an interface to the system reference manuals man (7) - macros to format man pages man-recode (1) - convert manual pages to another encoding man2html mandb (8) - create or update the manual page index caches mandelbrot-solver manderlbot mandoc mangler mangoapp mangohud mangohudctl manicheck manifake manifest manila manila-all manila-api manila-data manila-manage manila-rootwrap manila-scheduler manila-share manila-status manila-wsgi manilist manlifter manpage-alert manpath (1) - determine search path for manual pages manpath (5) - format of the /etc/manpath.config file mantis-xray manuskript manycp.x map-partition map2img map2slim mapBed mapDamage mapFields mapFieldsPar mapMers mapMers-depth map_back map_coords map_db map_gff_coords mapcache_detail mapcache_seed mapcode mapgen_clip maphimbu mapivi mapla mapnik-config mapnik-index mapnik-plugin-base mapnik-render mappedCoverage mapping_to_phandango mapproxy-seed mapproxy-util mapropos mapscrn mapsembler2_extend mapsembler2_extremities mapsembler2_kissreads mapsembler2_kissreads_graph mapsembler_extend mapserv maptool mapview maq maq.pl maq2sam-long maq2sam-short maq_eval.pl maq_plot.pl maqindex maqindex_socks maqview marble marble-behaim marble-maps marble-qt marc marc2dc marc2xml marcdump marclint marco marco-compton marco-glx marco-message marco-no-composite marco-picom marco-theme-viewer marco-window-demo marco-xr_glx_hybrid marco-xrender marcvalidate maria maria-cso maria-vis mariabackup mariadb (1) - the MariaDB command-line tool (mysql is now a symlink to mariadb) mariadb-access (1) - client for checking access privileges (mysqlaccess is now a symlink to mariadb-access) mariadb-admin (1) - client for administering a MariaDB server (mysqladmin is now a symlink to mariadb-admin) mariadb-analyze (1) - a table maintenance program (mysqlcheck is now a symlink to mariadb-check) mariadb-backup mariadb-binlog (1) - utility for processing binary log files (mysqlbinlog is now a symlink to mariadb-binlog) mariadb-check (1) - a table maintenance program (mysqlcheck is now a symlink to mariadb-check) mariadb-client-test mariadb-client-test-embedded mariadb-config mariadb-conv (1) - character set conversion utility for MariaDB mariadb-convert-table-format (1) - convert tables to use a given storage engine (mysql_convert_table_format is now a symlink to mariadb-convert-table-format) mariadb-dump (1) - a database backup program (mysqldump is now a symlink to mariadb-dump) mariadb-dumpslow (1) - Summarize slow query log files (mysqldumpslow is now a symlink to mariadb-dumpslow) mariadb-find-rows (1) - extract SQL statements from files (mysql_find_rows is now a symlink to mariadb-find-rows) mariadb-fix-extensions (1) - normalize table file name extensions (mysql_fix_extensions is now a symlink to mariadb-fix-extensions) mariadb-hotcopy (1) - a database backup program (mysqlhotcopy is now a symlink to mariadb-hotcopy) mariadb-import (1) - a data import program (mysqlimport is now a symlink to mariadb-import) mariadb-install-db (1) - initialize MariaDB data directory (mysql_install_db is now a symlink to mariadb-install-db) mariadb-ldb mariadb-optimize (1) - a table maintenance program (mysqlcheck is now a symlink to mariadb-check) mariadb-plugin (1) - configure MariaDB server plugins (mysql_plugin is now a symlink to mariadb-plugin) mariadb-repair (1) - a table maintenance program (mysqlcheck is now a symlink to mariadb-check) mariadb-report (1) - Makes a friendly report of important MySQL status values mariadb-secure-installation (1) - improve MariaDB installation security (mysql_secure_installation is now a symlink to mariadb-secure-installation) mariadb-service-convert (1) - generate a mariadb.service file based on the current mysql/mariadb settings mariadb-setpermission (1) - interactively set permissions in grant tables (mysql_setpermission is now a symlink to mariadb-setpermission) mariadb-show (1) - display database, table, and column information (mysqlshow is now a symlink to mariadb-show) mariadb-slap (1) - load emulation client (mysqlslap is now a symlink to mariadb-slap) mariadb-test mariadb-test-embedded mariadb-tzinfo-to-sql (1) - load the time zone tables (mysql_tzinfo_to_sql is now a symlink to mariadb-tzinfo-to-sql) mariadb-upgrade (1) - check tables for MariaDB upgrade (mysql_upgrade is now a symlink to mariadb-upgrade) mariadb-waitpid (1) - kill process and wait for its termination (mysql_waitpid is now a symlink to mariadb-waitpid) mariadb_config mariadbcheck (1) - a table maintenance program (mysqlcheck is now a symlink to mariadb-check) mariadbd-multi (1) - manage multiple MariaDB servers (mysqld_multi is now a symlink to mariadbd-multi) mariadbd-safe (1) - MariaDB server startup script (mysqld_safe is now a symlink to mariadbd-safe) mariadbd-safe-helper (1) - helper script (mysqld_safe_helper is now a symlink to mariadbd-safe-helper) marisa-benchmark marisa-build marisa-common-prefix-search marisa-dump marisa-lookup marisa-predictive-search marisa-reverse-lookup markdent-html markdown markdown-calibre markdown-it markdown-unlit markdown2 markdown2html markdown2latex markdown2man markdown_py marked marked-man marscan maruku marutex masakari-api masakari-engine masakari-hostmonitor masakari-instancemonitor masakari-introspectiveinstancemonitor masakari-manage masakari-processmonitor masakari-status masakari-wsgi mash mash2matrix maskFastaFromBed mask_quality.py maskambignuc maskambigprot maskdump maskfeat maskfilter maskred maskseq masktest mason mason-gui-text mason.pl mason_frag_sequencing mason_genome mason_materializer mason_methylation mass-bug masscan massif-visualizer massxpert master1 masterha_check_repl masterha_check_ssh masterha_check_status masterha_conf_host masterha_manager masterha_master_monitor masterha_master_switch masterha_secondary_check masterha_stop mat2 matc match_parens matchbox-desktop matchbox-keyboard matchbox-panel matchbox-remote matchbox-session matchbox-window-manager matchcluster matcher matdump matdyn.x mate-about mate-about-me mate-appearance-properties mate-applet-appmenu-disable mate-applet-appmenu-enable mate-at-properties mate-autogen mate-calc mate-calc-cmd mate-calculator mate-color-select mate-control-center mate-cpufreq-selector mate-default-applications-properties mate-desktop-item-edit mate-dictionary mate-disk-image-mounter mate-disk-usage-analyzer mate-display-properties mate-doc-common mate-eiciel mate-file-share-properties mate-font-viewer mate-keybinding-properties mate-keyboard-properties mate-maximus mate-menu mate-mouse-properties mate-network-properties mate-notification-properties mate-panel mate-panel-screenshot mate-panel-test-applets mate-polkit mate-power-manager mate-power-preferences mate-power-statistics mate-screensaver mate-screensaver-command mate-screensaver-preferences mate-screenshot mate-seahorse-tool mate-search-tool mate-session mate-session-inhibit mate-session-properties mate-session-save mate-settings-daemon mate-system-log mate-system-monitor mate-terminal mate-terminal.wrapper mate-thumbnail-font mate-time-admin mate-tweak mate-typing-monitor mate-user-admin mate-window-properties mate-wm math2oogl matho matho-mult matho-pascal matho-primes matho-sum matho-sumsq mathomatic mathspic mathtex matinfo matroxset mattrib (1) - change MSDOS file attribute flags maude mautil mauve mauve-contig-mover mauveAligner mauveToXMFA maven-cache-cleanup mawk (1) - pattern scanning and text processing language max5gui maxcut maxima maxima-sage mayavi2 maybe mb mb-applet-battery mb-applet-clock mb-applet-launcher mb-applet-menu-launcher mb-applet-system-monitor mb-applet-wireless mb-mpi mb2gmn mb2hal mb2md mb2org mb2txt mbadblocks (1) - tests a floppy disk, and marks the bad blocks in the FAT mbchk mbconv mbed-test-wrapper mbedflsh mbedhtrun mbedls mbfa mbfa-mpi mbim-network (1) - Simple network management of MBIM devices mbimcli (1) - Control MBIM devices mblaze-less mblaze-sort mblem mbma mbmon mbmon-rrd mbnc mbox-extract-patch mbox2maildir mboxgrep mboximporter mbpanelmgr mbpoll mbstream mbsync mbsync-get-cert mbt mbtg mbtserver mbuffer mbuild-hybrid mbw mc mc-encode mc-tool mc-wait-for-name mca2edf mcabber mcat (1) - dump raw disk image mcd (1) - change MSDOS directory mcdiff mcedit mcfirst mcheck (1) - verify all files on an MS-DOS formatted disk mcheck (3) - heap consistency checking mckey mcl mclasserase (1) - erase memory cards mcmc_analysis mcmctree mco mcolor mcom mcomix mcomp (1) - Compares two files using mtools mconfig mconnect mconnect-io mcookie (1) - generate magic cookies for xauth mcopy (1) - copy MSDOS files to/from Unix mcp mcpani mcpl2phits mcpl2ssw mcplexample_filter mcplexample_pyread mcplexample_read mcplexample_write mcpltool mcpmv mcpp mcron mcrypt mcs mctr mctr_cli mctree-mean-lengths mcu8051ide mcv mcv-int32 mcv-int64 mcv-long mcverter mcview mcx mcxarray mcxdeblast mcxdump mcxi mcxload mcxmap mcxsubs md-mx-ctrl md2term md3serial md5Digest md5cp md5deep md5fa md5pass md5sum (1) - compute and check MD5 message digest md5sum-lite md5sum.textutils (1) - compute and check MD5 message digest mdEquilibrationFoam mdFoam mdInitialise md_toc mda-lmtp mdassembler mdate mdatopbm mdb-array mdb-count mdb-export mdb-header mdb-hexdump mdb-json mdb-parsecsv mdb-prop mdb-queries mdb-schema mdb-sql mdb-tables mdb-tool mdb-ver mdb_copy mdb_dump mdb_load mdb_stat mdbrebase mdconvert mdconvert-mdtraj mdecrypt mdel (1) - delete an MSDOS file mdeliver mdeltree (1) - recursively delete an MSDOS directory and its contents mdetect mdevctl mdexport mdextractor mdf2iso mdfind mdi mdig (1) - DNS pipelined lookup utility mdinspect mdioblock mdioblock2 mdiodump mdiogen mdir (1) - display an MSDOS directory mdirs mdk2solv mdm-run mdm-sync mdm.screen mdmv mdns-scan mdoc mdoc-assemble mdoc-export-html mdoc-export-msxdoc mdoc-update mdoc-validate mdp mdquery mdsearch mdsum mdu (1) - display the amount of space occupied by an MSDOS directory mdump mdump2 mdump3 mdump4 mdustats mdvalidater meas_json meas_vis measuresdata mecab mecab-config mecat mecat2cns mecat2extseqs mecat2lcr mecat2map mecat2pcan mecat2pm4 mecat2splitreads mecat2trimbases mecat2viewdb mech-dump (1p) - Dumps information about a web page med med-bio med-bio-dev med-cloud med-config med-data med-dental med-epi med-his med-imaging med-imaging-dev med-laboratory med-oncology med-pharmacy med-physics med-practice med-psychology med-research med-statistics med-tools med-typesetting med2bib med2xml medcon medconforme media-ctl mediaconch mediaconch-gui mediainfo mediainfo-gui mediastream mediathekview mediawiki2latex mediawiki2latex-pyqt medimport medusa meep megablast megacopy megadepth megadf megadl megaexport megaget megahit megahit_core megahit_core_no_hw_accel megahit_core_popcnt megahit_toolkit megals megamerger megamkdir megan megapixels megapixels-camera-test megapixels-list-devices megaput megareg megarm megatest megatools meinproc5 meld melfagui melt melt-7 melting mem_image membernator members memcached memcard memccapable memccat memccp memcdump memcerror memcexist memcflush memcparse memcping memcrm memcslap memcstat memctouch memdiskfind memhog memkind-auto-dax-kmem-nodes memkind-hbw-nodes memo memprof2calltree memstat memtier memtool memusage (1) - profile memory usage of a program memusagestat (1) - generate graphic from memory profiling data mencal mender mender-artifact mender-cli mendex menhir menulibre menulibre-menu-validate merci mercurial-buildpackage mercurial-importdsc mercurial-importorig mercurial-port mercurial-pristinetar mercurial-tagversion merge merge-changelog merge-event-log-tags merge-fdata-15 merge-info mergeBed mergeMeshes mergeOrSplitBaffles mergePolishes merge_chunks.py merge_depths.pl merge_mate_pairs merge_metadata merge_metaphlan_tables.py merge_unicharsets mergebad mergebdf mergecap (1) - Merges two or more capture files into one mergechanges mergeit mergelib mergelog mergelogs merger mergerepo_c mergerfs mergerfs-fusermount mergesolv mergeword merkaartor meryl mes mes-gcc-static mesa-overlay-control.py mesaflash mesar mescc mescc.scm mesg (1) - display (or do not display) messages from other users mesh-cfgclient mesh-cfgtest mesh-tester mesh2pov mesh2voxel meshconvert meshctl meshfilter meshio meshlab meshlabserver meshs3d meson message-pass message_aggregator messages.mailutils (1) - count the number of messages in a mailbox metabase-profile metabat1 metabat2 metacam metacity metacity-message metacity-theme-viewer metaconfig metadata-cleaner metadata-json-lint metaflac metaflac2time metalfinder metalint metamath metamonger metaphlan metaphlan2krona.py metapixel metapixel-imagesize metapixel-prepare metapixel-sizesort metar metar_compare metar_copy metar_dump metar_filter metar_get metar_ls metaspades metaspades.py metastore metastudent metaxref meteo-qt meterbridge metgram metgram.sh metgramx metview mev mew-pinentry mewcat mewdecode mewencode mewest mewl mewstunnel mex mexport mf mf-nowin mf2pt1 mf_mesos_executor mf_mesos_scheduler mf_mesos_setting mfa2xmfa mfcuk mfdbtool mflag mflow mflua mflua-nowin mfluajit mfluajit-nowin mfmt mfoc mformat (1) - add an MSDOS filesystem to a low-level formatted floppy disk mfplain mfsappendchunks mfscheckfile mfschkarchive mfscli mfsclrarchive mfscopyeattr mfscopygoal mfscopyquota mfscopysclass mfscopytrashtime mfsdeleattr mfsdelquota mfsdirinfo mfsfileinfo mfsfilepaths mfsfilerepair mfsgeteattr mfsgetgoal mfsgetquota mfsgetsclass mfsgettrashtime mfslistsclass mfsmakesnapshot mfsmount mfsrgetgoal mfsrgettrashtime mfsrmsnapshot mfsrsetgoal mfsrsettrashtime mfsscadmin mfssetarchive mfsseteattr mfssetgoal mfssetquota mfssetsclass mfssettrashtime mfstools mfsxchgsclass mft mftext mftrace mftraining mfwd mfx-tracer-config mg mgaps mgb mgdiff mgen mgenmid mgitstatus mgl.cgi mglconv mgllab mgltask mglview mgmt-tester mgp mgp2html mgp2latex mgp2ps mgpembed mgpnet mgrtopbm mh_checkrepo mh_clean mh_cleanpom mh_genrules mh_install mh_installjar mh_installpom mh_installpoms mh_installsite mh_linkjar mh_linkjars mh_linkrepojar mh_lspoms mh_make mh_patchpom mh_patchpoms mh_resolve_dependencies mh_unpatchpoms mha-dbedit mha-dbrecover mha-decode mhap mhc mhdFoam mhddfs mhdr mheard mhf_server mhf_tickle mhgui mhonarc mhwaveedit mi mia-2davgmasked mia-2dbinarycombine mia-2dcost mia-2ddeform mia-2ddistance mia-2deval-transformquantity mia-2dfluid mia-2dfluid-syn-registration mia-2dforce mia-2dfuzzysegment mia-2dgrayimage-combine-to-rgb mia-2dgroundtruthreg mia-2dimagecombine-dice mia-2dimagecombiner mia-2dimagecreator mia-2dimagefilter mia-2dimagefilterstack mia-2dimagefullstats mia-2dimageregistration mia-2dimageselect mia-2dimageseries-maximum-intensity-projection mia-2dimagestack-cmeans mia-2dimagestats mia-2dlerp mia-2dmany2one-nonrigid mia-2dmulti-force mia-2dmultiimageregistration mia-2dmultiimageto3d mia-2dmultiimagevar mia-2dmyocard-ica mia-2dmyocard-icaseries mia-2dmyocard-segment mia-2dmyoica-full mia-2dmyoica-nonrigid mia-2dmyoica-nonrigid-parallel mia-2dmyoica-nonrigid2 mia-2dmyoicapgt mia-2dmyomilles mia-2dmyoperiodic-nonrigid mia-2dmyopgt-nonrigid mia-2dmyoserial-nonrigid mia-2dmyoseries-compdice mia-2dmyoseries-dice mia-2dmyoset-all2one-nonrigid mia-2dsegcompare mia-2dseghausdorff mia-2dsegment-ahmed mia-2dsegment-fuzzyw mia-2dsegment-local-cmeans mia-2dsegment-local-kmeans mia-2dsegment-per-pixel-kmeans mia-2dsegmentcropbox mia-2dsegseriesstats mia-2dsegshift mia-2dsegshiftperslice mia-2dseries-mincorr mia-2dseries-sectionmask mia-2dseries-segdistance mia-2dseries2dordermedian mia-2dseries2sets mia-2dseriescorr mia-2dseriesgradMAD mia-2dseriesgradvariation mia-2dserieshausdorff mia-2dseriessmoothgradMAD mia-2dseriestovolume mia-2dstack-cmeans-presegment mia-2dstackfilter mia-2dto3dimage mia-2dto3dimageb mia-2dtrackpixelmovement mia-2dtransform mia-2dtransformation-to-strain mia-3dbinarycombine mia-3dbrainextractT1 mia-3dcombine-imageseries mia-3dcombine-mr-segmentations mia-3dcost mia-3dcost-translatedgrad mia-3dcrispsegment mia-3ddeform mia-3ddistance mia-3ddistance-stats mia-3deval-transformquantity mia-3dfield2norm mia-3dfluid mia-3dfluid-syn-registration mia-3dforce mia-3dfuzzysegment mia-3dgetsize mia-3dgetslice mia-3dimageaddattributes mia-3dimagecombine mia-3dimagecreator mia-3dimagefilter mia-3dimagefilterstack mia-3dimageselect mia-3dimagestatistics-in-mask mia-3dimagestats mia-3disosurface-from-stack mia-3disosurface-from-volume mia-3dlandmarks-distances mia-3dlandmarks-transform mia-3dlerp mia-3dmany2one-nonrigid mia-3dmaskseeded mia-3dmotioncompica-nonrigid mia-3dnonrigidreg mia-3dnonrigidreg-alt mia-3dprealign-nonrigid mia-3dpropose-boundingbox mia-3drigidreg mia-3dsegment-ahmed mia-3dsegment-local-cmeans mia-3dserial-nonrigid mia-3dseries-track-intensity mia-3dtrackpixelmovement mia-3dtransform mia-3dtransform2vf mia-3dvectorfieldcreate mia-3dvf2transform mia-3dvfcompare mia-cmeans mia-filenumberpattern mia-labelsort mia-lmpick mia-mesh-deformable-model mia-mesh-to-maskimage mia-meshdistance-to-stackmask mia-meshfilter mia-multihist mia-myowavelettest mia-plugin-help mia-raw2image mia-raw2volume mia-viewitgui mia-wavelettrans mib2c mib2c-update mibdump micalc miceil miconv micro micro_razers microbe microcom microdc2 microfactory microhope microhope-doc micropeak microsocks microtests mid3cp (1) - copy ID3 tags mid3iconv (1) - convert ID3 tag encodings mid3v2 (1) - audio tag editor similar to 'id3v2' midge midi2abc midi2ly midi2mg midi2xml midicat midicopy midicsv midish midisnoop mido3-connect mido3-play mido3-ports mido3-serve mieye mif2rtf mifare-classic-format mifare-classic-read-ndef mifare-classic-write-ndef mifare-desfire-access mifare-desfire-create-ndef mifare-desfire-ev1-configure-ats mifare-desfire-ev1-configure-default-key mifare-desfire-ev1-configure-random-uid mifare-desfire-format mifare-desfire-info mifare-desfire-read-ndef mifare-desfire-write-ndef mifare-ultralight-info mighty mighty-mkindex mightyctl migrate migrate-ebs-image migrate-pubring-from-classic-gpg (1) - Migrate a public keyring from "classic" to "modern" GnuPG migrate-repository migratepages migspeed miio-extract-tokens miiocli mikmod milkytracker milltask millturngui miltertest mime-construct mime-dump mime-extractor mime-tool mimedefang mimedefang-multiplexor mimedefang-util mimedefang.pl mimefilter mimegpg mimeopen (1p) - Open files by mimetype mimetex mimetype (1p) - Determine file type mimeview (1) - display files, using mailcap mechanism. min12xxw mina minc minc_modify_header mincaverage mincblob minccalc minccmp mincconcat mincconvert minccopy mincdiff mincdump mincedit mincexpand mincextract mincgen mincheader minchistory mincinfo minclookup mincmakescalar mincmakevector mincmath mincmorph mincpik mincresample mincreshape mincsample mincstats minctoecat minctoraw mincview mincwindow mineBugHistory minexpert minfo (1) - print the parameters of a MSDOS filesystem mingle (1) - fast edge bundling mingw-genlib mini-dinstall mini-inetd mini-soong minia miniasm minibp minica minicom minicpan minidjvu minify minifycss minifyjs minil minilzip minimac4 minimal minimap minimap2 minimap2.py minimodem minisat minisat+ minisign ministat minitube miniunzip minizinc minizinc-ide minizip minlog mint-iso-verify mintegrate mintpy mintstick minuet minvoke mipe06to07 mipe08to09 mipe0_9to1_0 mipe2dbSTS mipe2fas mipe2genotypes mipe2html mipe2pcroverview mipe2pcrprimers mipe2putativesbeprimers mipe2sbeprimers mipe2snps mipeCheckSanity mipgen miplug mips-linux-gnu-addr2line mips-linux-gnu-ar mips-linux-gnu-as mips-linux-gnu-c++filt mips-linux-gnu-cpp mips-linux-gnu-cpp-10 mips-linux-gnu-cpp-11 mips-linux-gnu-cpp-12 mips-linux-gnu-dwp mips-linux-gnu-elfedit mips-linux-gnu-g++ mips-linux-gnu-g++-10 mips-linux-gnu-g++-11 mips-linux-gnu-g++-12 mips-linux-gnu-gcc mips-linux-gnu-gcc-10 mips-linux-gnu-gcc-11 mips-linux-gnu-gcc-12 mips-linux-gnu-gcc-ar mips-linux-gnu-gcc-ar-10 mips-linux-gnu-gcc-ar-11 mips-linux-gnu-gcc-ar-12 mips-linux-gnu-gcc-nm mips-linux-gnu-gcc-nm-10 mips-linux-gnu-gcc-nm-11 mips-linux-gnu-gcc-nm-12 mips-linux-gnu-gcc-ranlib mips-linux-gnu-gcc-ranlib-10 mips-linux-gnu-gcc-ranlib-11 mips-linux-gnu-gcc-ranlib-12 mips-linux-gnu-gccgo mips-linux-gnu-gccgo-10 mips-linux-gnu-gccgo-11 mips-linux-gnu-gccgo-12 mips-linux-gnu-gcov mips-linux-gnu-gcov-10 mips-linux-gnu-gcov-11 mips-linux-gnu-gcov-12 mips-linux-gnu-gcov-dump mips-linux-gnu-gcov-dump-10 mips-linux-gnu-gcov-dump-11 mips-linux-gnu-gcov-dump-12 mips-linux-gnu-gcov-tool mips-linux-gnu-gcov-tool-10 mips-linux-gnu-gcov-tool-11 mips-linux-gnu-gcov-tool-12 mips-linux-gnu-gdc mips-linux-gnu-gdc-10 mips-linux-gnu-gdc-11 mips-linux-gnu-gdc-12 mips-linux-gnu-gfortran mips-linux-gnu-gfortran-10 mips-linux-gnu-gfortran-11 mips-linux-gnu-gfortran-12 mips-linux-gnu-gm2 mips-linux-gnu-gm2-10 mips-linux-gnu-gm2-11 mips-linux-gnu-gm2-12 mips-linux-gnu-gnat mips-linux-gnu-gnat-10 mips-linux-gnu-gnat-11 mips-linux-gnu-gnat-12 mips-linux-gnu-gnatbind mips-linux-gnu-gnatbind-10 mips-linux-gnu-gnatbind-11 mips-linux-gnu-gnatbind-12 mips-linux-gnu-gnatchop mips-linux-gnu-gnatchop-10 mips-linux-gnu-gnatchop-11 mips-linux-gnu-gnatchop-12 mips-linux-gnu-gnatclean mips-linux-gnu-gnatclean-10 mips-linux-gnu-gnatclean-11 mips-linux-gnu-gnatclean-12 mips-linux-gnu-gnatfind mips-linux-gnu-gnatfind-10 mips-linux-gnu-gnatfind-11 mips-linux-gnu-gnatgcc mips-linux-gnu-gnathtml mips-linux-gnu-gnathtml-10 mips-linux-gnu-gnathtml-11 mips-linux-gnu-gnathtml-12 mips-linux-gnu-gnatkr mips-linux-gnu-gnatkr-10 mips-linux-gnu-gnatkr-11 mips-linux-gnu-gnatkr-12 mips-linux-gnu-gnatlink mips-linux-gnu-gnatlink-10 mips-linux-gnu-gnatlink-11 mips-linux-gnu-gnatlink-12 mips-linux-gnu-gnatls mips-linux-gnu-gnatls-10 mips-linux-gnu-gnatls-11 mips-linux-gnu-gnatls-12 mips-linux-gnu-gnatmake mips-linux-gnu-gnatmake-10 mips-linux-gnu-gnatmake-11 mips-linux-gnu-gnatmake-12 mips-linux-gnu-gnatname mips-linux-gnu-gnatname-10 mips-linux-gnu-gnatname-11 mips-linux-gnu-gnatname-12 mips-linux-gnu-gnatprep mips-linux-gnu-gnatprep-10 mips-linux-gnu-gnatprep-11 mips-linux-gnu-gnatprep-12 mips-linux-gnu-gnatxref mips-linux-gnu-gnatxref-10 mips-linux-gnu-gnatxref-11 mips-linux-gnu-gprof mips-linux-gnu-ld mips-linux-gnu-ld.bfd mips-linux-gnu-ld.gold mips-linux-gnu-lto-dump-10 mips-linux-gnu-lto-dump-11 mips-linux-gnu-lto-dump-12 mips-linux-gnu-nm mips-linux-gnu-objcopy mips-linux-gnu-objdump mips-linux-gnu-ranlib mips-linux-gnu-readelf mips-linux-gnu-size mips-linux-gnu-strings mips-linux-gnu-strip mips64-linux-gnuabi64-addr2line mips64-linux-gnuabi64-ar mips64-linux-gnuabi64-as mips64-linux-gnuabi64-c++filt mips64-linux-gnuabi64-cpp mips64-linux-gnuabi64-cpp-10 mips64-linux-gnuabi64-cpp-11 mips64-linux-gnuabi64-cpp-12 mips64-linux-gnuabi64-dwp mips64-linux-gnuabi64-elfedit mips64-linux-gnuabi64-g++ mips64-linux-gnuabi64-g++-10 mips64-linux-gnuabi64-g++-11 mips64-linux-gnuabi64-g++-12 mips64-linux-gnuabi64-gcc mips64-linux-gnuabi64-gcc-10 mips64-linux-gnuabi64-gcc-11 mips64-linux-gnuabi64-gcc-12 mips64-linux-gnuabi64-gcc-ar mips64-linux-gnuabi64-gcc-ar-10 mips64-linux-gnuabi64-gcc-ar-11 mips64-linux-gnuabi64-gcc-ar-12 mips64-linux-gnuabi64-gcc-nm mips64-linux-gnuabi64-gcc-nm-10 mips64-linux-gnuabi64-gcc-nm-11 mips64-linux-gnuabi64-gcc-nm-12 mips64-linux-gnuabi64-gcc-ranlib mips64-linux-gnuabi64-gcc-ranlib-10 mips64-linux-gnuabi64-gcc-ranlib-11 mips64-linux-gnuabi64-gcc-ranlib-12 mips64-linux-gnuabi64-gccgo mips64-linux-gnuabi64-gccgo-10 mips64-linux-gnuabi64-gccgo-11 mips64-linux-gnuabi64-gccgo-12 mips64-linux-gnuabi64-gcov mips64-linux-gnuabi64-gcov-10 mips64-linux-gnuabi64-gcov-11 mips64-linux-gnuabi64-gcov-12 mips64-linux-gnuabi64-gcov-dump mips64-linux-gnuabi64-gcov-dump-10 mips64-linux-gnuabi64-gcov-dump-11 mips64-linux-gnuabi64-gcov-dump-12 mips64-linux-gnuabi64-gcov-tool mips64-linux-gnuabi64-gcov-tool-10 mips64-linux-gnuabi64-gcov-tool-11 mips64-linux-gnuabi64-gcov-tool-12 mips64-linux-gnuabi64-gdc mips64-linux-gnuabi64-gdc-10 mips64-linux-gnuabi64-gdc-11 mips64-linux-gnuabi64-gdc-12 mips64-linux-gnuabi64-gfortran mips64-linux-gnuabi64-gfortran-10 mips64-linux-gnuabi64-gfortran-11 mips64-linux-gnuabi64-gfortran-12 mips64-linux-gnuabi64-gm2 mips64-linux-gnuabi64-gm2-10 mips64-linux-gnuabi64-gm2-11 mips64-linux-gnuabi64-gm2-12 mips64-linux-gnuabi64-gnat mips64-linux-gnuabi64-gnat-10 mips64-linux-gnuabi64-gnat-11 mips64-linux-gnuabi64-gnat-12 mips64-linux-gnuabi64-gnatbind mips64-linux-gnuabi64-gnatbind-10 mips64-linux-gnuabi64-gnatbind-11 mips64-linux-gnuabi64-gnatbind-12 mips64-linux-gnuabi64-gnatchop mips64-linux-gnuabi64-gnatchop-10 mips64-linux-gnuabi64-gnatchop-11 mips64-linux-gnuabi64-gnatchop-12 mips64-linux-gnuabi64-gnatclean mips64-linux-gnuabi64-gnatclean-10 mips64-linux-gnuabi64-gnatclean-11 mips64-linux-gnuabi64-gnatclean-12 mips64-linux-gnuabi64-gnatfind mips64-linux-gnuabi64-gnatfind-10 mips64-linux-gnuabi64-gnatfind-11 mips64-linux-gnuabi64-gnatgcc mips64-linux-gnuabi64-gnathtml mips64-linux-gnuabi64-gnathtml-10 mips64-linux-gnuabi64-gnathtml-11 mips64-linux-gnuabi64-gnathtml-12 mips64-linux-gnuabi64-gnatkr mips64-linux-gnuabi64-gnatkr-10 mips64-linux-gnuabi64-gnatkr-11 mips64-linux-gnuabi64-gnatkr-12 mips64-linux-gnuabi64-gnatlink mips64-linux-gnuabi64-gnatlink-10 mips64-linux-gnuabi64-gnatlink-11 mips64-linux-gnuabi64-gnatlink-12 mips64-linux-gnuabi64-gnatls mips64-linux-gnuabi64-gnatls-10 mips64-linux-gnuabi64-gnatls-11 mips64-linux-gnuabi64-gnatls-12 mips64-linux-gnuabi64-gnatmake mips64-linux-gnuabi64-gnatmake-10 mips64-linux-gnuabi64-gnatmake-11 mips64-linux-gnuabi64-gnatmake-12 mips64-linux-gnuabi64-gnatname mips64-linux-gnuabi64-gnatname-10 mips64-linux-gnuabi64-gnatname-11 mips64-linux-gnuabi64-gnatname-12 mips64-linux-gnuabi64-gnatprep mips64-linux-gnuabi64-gnatprep-10 mips64-linux-gnuabi64-gnatprep-11 mips64-linux-gnuabi64-gnatprep-12 mips64-linux-gnuabi64-gnatxref mips64-linux-gnuabi64-gnatxref-10 mips64-linux-gnuabi64-gnatxref-11 mips64-linux-gnuabi64-gprof mips64-linux-gnuabi64-ld mips64-linux-gnuabi64-ld.bfd mips64-linux-gnuabi64-ld.gold mips64-linux-gnuabi64-lto-dump-10 mips64-linux-gnuabi64-lto-dump-11 mips64-linux-gnuabi64-lto-dump-12 mips64-linux-gnuabi64-nm mips64-linux-gnuabi64-objcopy mips64-linux-gnuabi64-objdump mips64-linux-gnuabi64-ranlib mips64-linux-gnuabi64-readelf mips64-linux-gnuabi64-size mips64-linux-gnuabi64-strings mips64-linux-gnuabi64-strip mips64-linux-gnuabin32-addr2line mips64-linux-gnuabin32-ar mips64-linux-gnuabin32-as mips64-linux-gnuabin32-c++filt mips64-linux-gnuabin32-dwp mips64-linux-gnuabin32-elfedit mips64-linux-gnuabin32-gprof mips64-linux-gnuabin32-ld mips64-linux-gnuabin32-ld.bfd mips64-linux-gnuabin32-ld.gold mips64-linux-gnuabin32-nm mips64-linux-gnuabin32-objcopy mips64-linux-gnuabin32-objdump mips64-linux-gnuabin32-ranlib mips64-linux-gnuabin32-readelf mips64-linux-gnuabin32-size mips64-linux-gnuabin32-strings mips64-linux-gnuabin32-strip mips64el-linux-gnuabi64-addr2line mips64el-linux-gnuabi64-ar mips64el-linux-gnuabi64-as mips64el-linux-gnuabi64-c++filt mips64el-linux-gnuabi64-cpp mips64el-linux-gnuabi64-cpp-10 mips64el-linux-gnuabi64-cpp-11 mips64el-linux-gnuabi64-cpp-12 mips64el-linux-gnuabi64-dwp mips64el-linux-gnuabi64-elfedit mips64el-linux-gnuabi64-g++ mips64el-linux-gnuabi64-g++-10 mips64el-linux-gnuabi64-g++-11 mips64el-linux-gnuabi64-g++-12 mips64el-linux-gnuabi64-gcc mips64el-linux-gnuabi64-gcc-10 mips64el-linux-gnuabi64-gcc-11 mips64el-linux-gnuabi64-gcc-12 mips64el-linux-gnuabi64-gcc-ar mips64el-linux-gnuabi64-gcc-ar-10 mips64el-linux-gnuabi64-gcc-ar-11 mips64el-linux-gnuabi64-gcc-ar-12 mips64el-linux-gnuabi64-gcc-nm mips64el-linux-gnuabi64-gcc-nm-10 mips64el-linux-gnuabi64-gcc-nm-11 mips64el-linux-gnuabi64-gcc-nm-12 mips64el-linux-gnuabi64-gcc-ranlib mips64el-linux-gnuabi64-gcc-ranlib-10 mips64el-linux-gnuabi64-gcc-ranlib-11 mips64el-linux-gnuabi64-gcc-ranlib-12 mips64el-linux-gnuabi64-gccgo mips64el-linux-gnuabi64-gccgo-10 mips64el-linux-gnuabi64-gccgo-11 mips64el-linux-gnuabi64-gccgo-12 mips64el-linux-gnuabi64-gcov mips64el-linux-gnuabi64-gcov-10 mips64el-linux-gnuabi64-gcov-11 mips64el-linux-gnuabi64-gcov-12 mips64el-linux-gnuabi64-gcov-dump mips64el-linux-gnuabi64-gcov-dump-10 mips64el-linux-gnuabi64-gcov-dump-11 mips64el-linux-gnuabi64-gcov-dump-12 mips64el-linux-gnuabi64-gcov-tool mips64el-linux-gnuabi64-gcov-tool-10 mips64el-linux-gnuabi64-gcov-tool-11 mips64el-linux-gnuabi64-gcov-tool-12 mips64el-linux-gnuabi64-gdc mips64el-linux-gnuabi64-gdc-10 mips64el-linux-gnuabi64-gdc-11 mips64el-linux-gnuabi64-gdc-12 mips64el-linux-gnuabi64-gfortran mips64el-linux-gnuabi64-gfortran-10 mips64el-linux-gnuabi64-gfortran-11 mips64el-linux-gnuabi64-gfortran-12 mips64el-linux-gnuabi64-gm2 mips64el-linux-gnuabi64-gm2-10 mips64el-linux-gnuabi64-gm2-11 mips64el-linux-gnuabi64-gm2-12 mips64el-linux-gnuabi64-gnat mips64el-linux-gnuabi64-gnat-10 mips64el-linux-gnuabi64-gnat-11 mips64el-linux-gnuabi64-gnat-12 mips64el-linux-gnuabi64-gnatbind mips64el-linux-gnuabi64-gnatbind-10 mips64el-linux-gnuabi64-gnatbind-11 mips64el-linux-gnuabi64-gnatbind-12 mips64el-linux-gnuabi64-gnatchop mips64el-linux-gnuabi64-gnatchop-10 mips64el-linux-gnuabi64-gnatchop-11 mips64el-linux-gnuabi64-gnatchop-12 mips64el-linux-gnuabi64-gnatclean mips64el-linux-gnuabi64-gnatclean-10 mips64el-linux-gnuabi64-gnatclean-11 mips64el-linux-gnuabi64-gnatclean-12 mips64el-linux-gnuabi64-gnatfind mips64el-linux-gnuabi64-gnatfind-10 mips64el-linux-gnuabi64-gnatfind-11 mips64el-linux-gnuabi64-gnatgcc mips64el-linux-gnuabi64-gnathtml mips64el-linux-gnuabi64-gnathtml-10 mips64el-linux-gnuabi64-gnathtml-11 mips64el-linux-gnuabi64-gnathtml-12 mips64el-linux-gnuabi64-gnatkr mips64el-linux-gnuabi64-gnatkr-10 mips64el-linux-gnuabi64-gnatkr-11 mips64el-linux-gnuabi64-gnatkr-12 mips64el-linux-gnuabi64-gnatlink mips64el-linux-gnuabi64-gnatlink-10 mips64el-linux-gnuabi64-gnatlink-11 mips64el-linux-gnuabi64-gnatlink-12 mips64el-linux-gnuabi64-gnatls mips64el-linux-gnuabi64-gnatls-10 mips64el-linux-gnuabi64-gnatls-11 mips64el-linux-gnuabi64-gnatls-12 mips64el-linux-gnuabi64-gnatmake mips64el-linux-gnuabi64-gnatmake-10 mips64el-linux-gnuabi64-gnatmake-11 mips64el-linux-gnuabi64-gnatmake-12 mips64el-linux-gnuabi64-gnatname mips64el-linux-gnuabi64-gnatname-10 mips64el-linux-gnuabi64-gnatname-11 mips64el-linux-gnuabi64-gnatname-12 mips64el-linux-gnuabi64-gnatprep mips64el-linux-gnuabi64-gnatprep-10 mips64el-linux-gnuabi64-gnatprep-11 mips64el-linux-gnuabi64-gnatprep-12 mips64el-linux-gnuabi64-gnatxref mips64el-linux-gnuabi64-gnatxref-10 mips64el-linux-gnuabi64-gnatxref-11 mips64el-linux-gnuabi64-gprof mips64el-linux-gnuabi64-ld mips64el-linux-gnuabi64-ld.bfd mips64el-linux-gnuabi64-ld.gold mips64el-linux-gnuabi64-lto-dump-10 mips64el-linux-gnuabi64-lto-dump-11 mips64el-linux-gnuabi64-lto-dump-12 mips64el-linux-gnuabi64-nm mips64el-linux-gnuabi64-objcopy mips64el-linux-gnuabi64-objdump mips64el-linux-gnuabi64-ranlib mips64el-linux-gnuabi64-readelf mips64el-linux-gnuabi64-size mips64el-linux-gnuabi64-strings mips64el-linux-gnuabi64-strip mips64el-linux-gnuabin32-addr2line mips64el-linux-gnuabin32-ar mips64el-linux-gnuabin32-as mips64el-linux-gnuabin32-c++filt mips64el-linux-gnuabin32-dwp mips64el-linux-gnuabin32-elfedit mips64el-linux-gnuabin32-gprof mips64el-linux-gnuabin32-ld mips64el-linux-gnuabin32-ld.bfd mips64el-linux-gnuabin32-ld.gold mips64el-linux-gnuabin32-nm mips64el-linux-gnuabin32-objcopy mips64el-linux-gnuabin32-objdump mips64el-linux-gnuabin32-ranlib mips64el-linux-gnuabin32-readelf mips64el-linux-gnuabin32-size mips64el-linux-gnuabin32-strings mips64el-linux-gnuabin32-strip mipsel-linux-gnu-addr2line mipsel-linux-gnu-ar mipsel-linux-gnu-as mipsel-linux-gnu-c++filt mipsel-linux-gnu-cpp mipsel-linux-gnu-cpp-10 mipsel-linux-gnu-cpp-11 mipsel-linux-gnu-cpp-12 mipsel-linux-gnu-dwp mipsel-linux-gnu-elfedit mipsel-linux-gnu-g++ mipsel-linux-gnu-g++-10 mipsel-linux-gnu-g++-11 mipsel-linux-gnu-g++-12 mipsel-linux-gnu-gcc mipsel-linux-gnu-gcc-10 mipsel-linux-gnu-gcc-11 mipsel-linux-gnu-gcc-12 mipsel-linux-gnu-gcc-ar mipsel-linux-gnu-gcc-ar-10 mipsel-linux-gnu-gcc-ar-11 mipsel-linux-gnu-gcc-ar-12 mipsel-linux-gnu-gcc-nm mipsel-linux-gnu-gcc-nm-10 mipsel-linux-gnu-gcc-nm-11 mipsel-linux-gnu-gcc-nm-12 mipsel-linux-gnu-gcc-ranlib mipsel-linux-gnu-gcc-ranlib-10 mipsel-linux-gnu-gcc-ranlib-11 mipsel-linux-gnu-gcc-ranlib-12 mipsel-linux-gnu-gccgo mipsel-linux-gnu-gccgo-10 mipsel-linux-gnu-gccgo-11 mipsel-linux-gnu-gccgo-12 mipsel-linux-gnu-gcov mipsel-linux-gnu-gcov-10 mipsel-linux-gnu-gcov-11 mipsel-linux-gnu-gcov-12 mipsel-linux-gnu-gcov-dump mipsel-linux-gnu-gcov-dump-10 mipsel-linux-gnu-gcov-dump-11 mipsel-linux-gnu-gcov-dump-12 mipsel-linux-gnu-gcov-tool mipsel-linux-gnu-gcov-tool-10 mipsel-linux-gnu-gcov-tool-11 mipsel-linux-gnu-gcov-tool-12 mipsel-linux-gnu-gdc mipsel-linux-gnu-gdc-10 mipsel-linux-gnu-gdc-11 mipsel-linux-gnu-gdc-12 mipsel-linux-gnu-gfortran mipsel-linux-gnu-gfortran-10 mipsel-linux-gnu-gfortran-11 mipsel-linux-gnu-gfortran-12 mipsel-linux-gnu-gm2 mipsel-linux-gnu-gm2-10 mipsel-linux-gnu-gm2-11 mipsel-linux-gnu-gm2-12 mipsel-linux-gnu-gnat mipsel-linux-gnu-gnat-10 mipsel-linux-gnu-gnat-11 mipsel-linux-gnu-gnat-12 mipsel-linux-gnu-gnatbind mipsel-linux-gnu-gnatbind-10 mipsel-linux-gnu-gnatbind-11 mipsel-linux-gnu-gnatbind-12 mipsel-linux-gnu-gnatchop mipsel-linux-gnu-gnatchop-10 mipsel-linux-gnu-gnatchop-11 mipsel-linux-gnu-gnatchop-12 mipsel-linux-gnu-gnatclean mipsel-linux-gnu-gnatclean-10 mipsel-linux-gnu-gnatclean-11 mipsel-linux-gnu-gnatclean-12 mipsel-linux-gnu-gnatfind mipsel-linux-gnu-gnatfind-10 mipsel-linux-gnu-gnatfind-11 mipsel-linux-gnu-gnatgcc mipsel-linux-gnu-gnathtml mipsel-linux-gnu-gnathtml-10 mipsel-linux-gnu-gnathtml-11 mipsel-linux-gnu-gnathtml-12 mipsel-linux-gnu-gnatkr mipsel-linux-gnu-gnatkr-10 mipsel-linux-gnu-gnatkr-11 mipsel-linux-gnu-gnatkr-12 mipsel-linux-gnu-gnatlink mipsel-linux-gnu-gnatlink-10 mipsel-linux-gnu-gnatlink-11 mipsel-linux-gnu-gnatlink-12 mipsel-linux-gnu-gnatls mipsel-linux-gnu-gnatls-10 mipsel-linux-gnu-gnatls-11 mipsel-linux-gnu-gnatls-12 mipsel-linux-gnu-gnatmake mipsel-linux-gnu-gnatmake-10 mipsel-linux-gnu-gnatmake-11 mipsel-linux-gnu-gnatmake-12 mipsel-linux-gnu-gnatname mipsel-linux-gnu-gnatname-10 mipsel-linux-gnu-gnatname-11 mipsel-linux-gnu-gnatname-12 mipsel-linux-gnu-gnatprep mipsel-linux-gnu-gnatprep-10 mipsel-linux-gnu-gnatprep-11 mipsel-linux-gnu-gnatprep-12 mipsel-linux-gnu-gnatxref mipsel-linux-gnu-gnatxref-10 mipsel-linux-gnu-gnatxref-11 mipsel-linux-gnu-gprof mipsel-linux-gnu-ld mipsel-linux-gnu-ld.bfd mipsel-linux-gnu-ld.gold mipsel-linux-gnu-lto-dump-10 mipsel-linux-gnu-lto-dump-11 mipsel-linux-gnu-lto-dump-12 mipsel-linux-gnu-nm mipsel-linux-gnu-objcopy mipsel-linux-gnu-objdump mipsel-linux-gnu-ranlib mipsel-linux-gnu-readelf mipsel-linux-gnu-size mipsel-linux-gnu-strings mipsel-linux-gnu-strip mipsisa32r6-linux-gnu-addr2line mipsisa32r6-linux-gnu-ar mipsisa32r6-linux-gnu-as mipsisa32r6-linux-gnu-c++filt mipsisa32r6-linux-gnu-cpp mipsisa32r6-linux-gnu-cpp-10 mipsisa32r6-linux-gnu-cpp-11 mipsisa32r6-linux-gnu-cpp-12 mipsisa32r6-linux-gnu-dwp mipsisa32r6-linux-gnu-elfedit mipsisa32r6-linux-gnu-g++ mipsisa32r6-linux-gnu-g++-10 mipsisa32r6-linux-gnu-g++-11 mipsisa32r6-linux-gnu-g++-12 mipsisa32r6-linux-gnu-gcc mipsisa32r6-linux-gnu-gcc-10 mipsisa32r6-linux-gnu-gcc-11 mipsisa32r6-linux-gnu-gcc-12 mipsisa32r6-linux-gnu-gcc-ar mipsisa32r6-linux-gnu-gcc-ar-10 mipsisa32r6-linux-gnu-gcc-ar-11 mipsisa32r6-linux-gnu-gcc-ar-12 mipsisa32r6-linux-gnu-gcc-nm mipsisa32r6-linux-gnu-gcc-nm-10 mipsisa32r6-linux-gnu-gcc-nm-11 mipsisa32r6-linux-gnu-gcc-nm-12 mipsisa32r6-linux-gnu-gcc-ranlib mipsisa32r6-linux-gnu-gcc-ranlib-10 mipsisa32r6-linux-gnu-gcc-ranlib-11 mipsisa32r6-linux-gnu-gcc-ranlib-12 mipsisa32r6-linux-gnu-gccgo mipsisa32r6-linux-gnu-gccgo-10 mipsisa32r6-linux-gnu-gccgo-11 mipsisa32r6-linux-gnu-gccgo-12 mipsisa32r6-linux-gnu-gcov mipsisa32r6-linux-gnu-gcov-10 mipsisa32r6-linux-gnu-gcov-11 mipsisa32r6-linux-gnu-gcov-12 mipsisa32r6-linux-gnu-gcov-dump mipsisa32r6-linux-gnu-gcov-dump-10 mipsisa32r6-linux-gnu-gcov-dump-11 mipsisa32r6-linux-gnu-gcov-dump-12 mipsisa32r6-linux-gnu-gcov-tool mipsisa32r6-linux-gnu-gcov-tool-10 mipsisa32r6-linux-gnu-gcov-tool-11 mipsisa32r6-linux-gnu-gcov-tool-12 mipsisa32r6-linux-gnu-gdc mipsisa32r6-linux-gnu-gdc-10 mipsisa32r6-linux-gnu-gdc-11 mipsisa32r6-linux-gnu-gdc-12 mipsisa32r6-linux-gnu-gfortran mipsisa32r6-linux-gnu-gfortran-10 mipsisa32r6-linux-gnu-gfortran-11 mipsisa32r6-linux-gnu-gfortran-12 mipsisa32r6-linux-gnu-gm2 mipsisa32r6-linux-gnu-gm2-10 mipsisa32r6-linux-gnu-gm2-11 mipsisa32r6-linux-gnu-gm2-12 mipsisa32r6-linux-gnu-gnat mipsisa32r6-linux-gnu-gnat-10 mipsisa32r6-linux-gnu-gnat-11 mipsisa32r6-linux-gnu-gnat-12 mipsisa32r6-linux-gnu-gnatbind mipsisa32r6-linux-gnu-gnatbind-10 mipsisa32r6-linux-gnu-gnatbind-11 mipsisa32r6-linux-gnu-gnatbind-12 mipsisa32r6-linux-gnu-gnatchop mipsisa32r6-linux-gnu-gnatchop-10 mipsisa32r6-linux-gnu-gnatchop-11 mipsisa32r6-linux-gnu-gnatchop-12 mipsisa32r6-linux-gnu-gnatclean mipsisa32r6-linux-gnu-gnatclean-10 mipsisa32r6-linux-gnu-gnatclean-11 mipsisa32r6-linux-gnu-gnatclean-12 mipsisa32r6-linux-gnu-gnatfind mipsisa32r6-linux-gnu-gnatfind-10 mipsisa32r6-linux-gnu-gnatfind-11 mipsisa32r6-linux-gnu-gnatgcc mipsisa32r6-linux-gnu-gnathtml mipsisa32r6-linux-gnu-gnathtml-10 mipsisa32r6-linux-gnu-gnathtml-11 mipsisa32r6-linux-gnu-gnathtml-12 mipsisa32r6-linux-gnu-gnatkr mipsisa32r6-linux-gnu-gnatkr-10 mipsisa32r6-linux-gnu-gnatkr-11 mipsisa32r6-linux-gnu-gnatkr-12 mipsisa32r6-linux-gnu-gnatlink mipsisa32r6-linux-gnu-gnatlink-10 mipsisa32r6-linux-gnu-gnatlink-11 mipsisa32r6-linux-gnu-gnatlink-12 mipsisa32r6-linux-gnu-gnatls mipsisa32r6-linux-gnu-gnatls-10 mipsisa32r6-linux-gnu-gnatls-11 mipsisa32r6-linux-gnu-gnatls-12 mipsisa32r6-linux-gnu-gnatmake mipsisa32r6-linux-gnu-gnatmake-10 mipsisa32r6-linux-gnu-gnatmake-11 mipsisa32r6-linux-gnu-gnatmake-12 mipsisa32r6-linux-gnu-gnatname mipsisa32r6-linux-gnu-gnatname-10 mipsisa32r6-linux-gnu-gnatname-11 mipsisa32r6-linux-gnu-gnatname-12 mipsisa32r6-linux-gnu-gnatprep mipsisa32r6-linux-gnu-gnatprep-10 mipsisa32r6-linux-gnu-gnatprep-11 mipsisa32r6-linux-gnu-gnatprep-12 mipsisa32r6-linux-gnu-gnatxref mipsisa32r6-linux-gnu-gnatxref-10 mipsisa32r6-linux-gnu-gnatxref-11 mipsisa32r6-linux-gnu-gprof mipsisa32r6-linux-gnu-ld mipsisa32r6-linux-gnu-ld.bfd mipsisa32r6-linux-gnu-ld.gold mipsisa32r6-linux-gnu-lto-dump-10 mipsisa32r6-linux-gnu-lto-dump-11 mipsisa32r6-linux-gnu-lto-dump-12 mipsisa32r6-linux-gnu-nm mipsisa32r6-linux-gnu-objcopy mipsisa32r6-linux-gnu-objdump mipsisa32r6-linux-gnu-ranlib mipsisa32r6-linux-gnu-readelf mipsisa32r6-linux-gnu-size mipsisa32r6-linux-gnu-strings mipsisa32r6-linux-gnu-strip mipsisa32r6el-linux-gnu-addr2line mipsisa32r6el-linux-gnu-ar mipsisa32r6el-linux-gnu-as mipsisa32r6el-linux-gnu-c++filt mipsisa32r6el-linux-gnu-cpp mipsisa32r6el-linux-gnu-cpp-10 mipsisa32r6el-linux-gnu-cpp-11 mipsisa32r6el-linux-gnu-cpp-12 mipsisa32r6el-linux-gnu-dwp mipsisa32r6el-linux-gnu-elfedit mipsisa32r6el-linux-gnu-g++ mipsisa32r6el-linux-gnu-g++-10 mipsisa32r6el-linux-gnu-g++-11 mipsisa32r6el-linux-gnu-g++-12 mipsisa32r6el-linux-gnu-gcc mipsisa32r6el-linux-gnu-gcc-10 mipsisa32r6el-linux-gnu-gcc-11 mipsisa32r6el-linux-gnu-gcc-12 mipsisa32r6el-linux-gnu-gcc-ar mipsisa32r6el-linux-gnu-gcc-ar-10 mipsisa32r6el-linux-gnu-gcc-ar-11 mipsisa32r6el-linux-gnu-gcc-ar-12 mipsisa32r6el-linux-gnu-gcc-nm mipsisa32r6el-linux-gnu-gcc-nm-10 mipsisa32r6el-linux-gnu-gcc-nm-11 mipsisa32r6el-linux-gnu-gcc-nm-12 mipsisa32r6el-linux-gnu-gcc-ranlib mipsisa32r6el-linux-gnu-gcc-ranlib-10 mipsisa32r6el-linux-gnu-gcc-ranlib-11 mipsisa32r6el-linux-gnu-gcc-ranlib-12 mipsisa32r6el-linux-gnu-gccgo mipsisa32r6el-linux-gnu-gccgo-10 mipsisa32r6el-linux-gnu-gccgo-11 mipsisa32r6el-linux-gnu-gccgo-12 mipsisa32r6el-linux-gnu-gcov mipsisa32r6el-linux-gnu-gcov-10 mipsisa32r6el-linux-gnu-gcov-11 mipsisa32r6el-linux-gnu-gcov-12 mipsisa32r6el-linux-gnu-gcov-dump mipsisa32r6el-linux-gnu-gcov-dump-10 mipsisa32r6el-linux-gnu-gcov-dump-11 mipsisa32r6el-linux-gnu-gcov-dump-12 mipsisa32r6el-linux-gnu-gcov-tool mipsisa32r6el-linux-gnu-gcov-tool-10 mipsisa32r6el-linux-gnu-gcov-tool-11 mipsisa32r6el-linux-gnu-gcov-tool-12 mipsisa32r6el-linux-gnu-gdc mipsisa32r6el-linux-gnu-gdc-10 mipsisa32r6el-linux-gnu-gdc-11 mipsisa32r6el-linux-gnu-gdc-12 mipsisa32r6el-linux-gnu-gfortran mipsisa32r6el-linux-gnu-gfortran-10 mipsisa32r6el-linux-gnu-gfortran-11 mipsisa32r6el-linux-gnu-gfortran-12 mipsisa32r6el-linux-gnu-gm2 mipsisa32r6el-linux-gnu-gm2-10 mipsisa32r6el-linux-gnu-gm2-11 mipsisa32r6el-linux-gnu-gm2-12 mipsisa32r6el-linux-gnu-gnat mipsisa32r6el-linux-gnu-gnat-10 mipsisa32r6el-linux-gnu-gnat-11 mipsisa32r6el-linux-gnu-gnat-12 mipsisa32r6el-linux-gnu-gnatbind mipsisa32r6el-linux-gnu-gnatbind-10 mipsisa32r6el-linux-gnu-gnatbind-11 mipsisa32r6el-linux-gnu-gnatbind-12 mipsisa32r6el-linux-gnu-gnatchop mipsisa32r6el-linux-gnu-gnatchop-10 mipsisa32r6el-linux-gnu-gnatchop-11 mipsisa32r6el-linux-gnu-gnatchop-12 mipsisa32r6el-linux-gnu-gnatclean mipsisa32r6el-linux-gnu-gnatclean-10 mipsisa32r6el-linux-gnu-gnatclean-11 mipsisa32r6el-linux-gnu-gnatclean-12 mipsisa32r6el-linux-gnu-gnatfind mipsisa32r6el-linux-gnu-gnatfind-10 mipsisa32r6el-linux-gnu-gnatfind-11 mipsisa32r6el-linux-gnu-gnatgcc mipsisa32r6el-linux-gnu-gnathtml mipsisa32r6el-linux-gnu-gnathtml-10 mipsisa32r6el-linux-gnu-gnathtml-11 mipsisa32r6el-linux-gnu-gnathtml-12 mipsisa32r6el-linux-gnu-gnatkr mipsisa32r6el-linux-gnu-gnatkr-10 mipsisa32r6el-linux-gnu-gnatkr-11 mipsisa32r6el-linux-gnu-gnatkr-12 mipsisa32r6el-linux-gnu-gnatlink mipsisa32r6el-linux-gnu-gnatlink-10 mipsisa32r6el-linux-gnu-gnatlink-11 mipsisa32r6el-linux-gnu-gnatlink-12 mipsisa32r6el-linux-gnu-gnatls mipsisa32r6el-linux-gnu-gnatls-10 mipsisa32r6el-linux-gnu-gnatls-11 mipsisa32r6el-linux-gnu-gnatls-12 mipsisa32r6el-linux-gnu-gnatmake mipsisa32r6el-linux-gnu-gnatmake-10 mipsisa32r6el-linux-gnu-gnatmake-11 mipsisa32r6el-linux-gnu-gnatmake-12 mipsisa32r6el-linux-gnu-gnatname mipsisa32r6el-linux-gnu-gnatname-10 mipsisa32r6el-linux-gnu-gnatname-11 mipsisa32r6el-linux-gnu-gnatname-12 mipsisa32r6el-linux-gnu-gnatprep mipsisa32r6el-linux-gnu-gnatprep-10 mipsisa32r6el-linux-gnu-gnatprep-11 mipsisa32r6el-linux-gnu-gnatprep-12 mipsisa32r6el-linux-gnu-gnatxref mipsisa32r6el-linux-gnu-gnatxref-10 mipsisa32r6el-linux-gnu-gnatxref-11 mipsisa32r6el-linux-gnu-gprof mipsisa32r6el-linux-gnu-ld mipsisa32r6el-linux-gnu-ld.bfd mipsisa32r6el-linux-gnu-ld.gold mipsisa32r6el-linux-gnu-lto-dump-10 mipsisa32r6el-linux-gnu-lto-dump-11 mipsisa32r6el-linux-gnu-lto-dump-12 mipsisa32r6el-linux-gnu-nm mipsisa32r6el-linux-gnu-objcopy mipsisa32r6el-linux-gnu-objdump mipsisa32r6el-linux-gnu-ranlib mipsisa32r6el-linux-gnu-readelf mipsisa32r6el-linux-gnu-size mipsisa32r6el-linux-gnu-strings mipsisa32r6el-linux-gnu-strip mipsisa64r6-linux-gnuabi64-addr2line mipsisa64r6-linux-gnuabi64-ar mipsisa64r6-linux-gnuabi64-as mipsisa64r6-linux-gnuabi64-c++filt mipsisa64r6-linux-gnuabi64-cpp mipsisa64r6-linux-gnuabi64-cpp-10 mipsisa64r6-linux-gnuabi64-cpp-11 mipsisa64r6-linux-gnuabi64-cpp-12 mipsisa64r6-linux-gnuabi64-dwp mipsisa64r6-linux-gnuabi64-elfedit mipsisa64r6-linux-gnuabi64-g++ mipsisa64r6-linux-gnuabi64-g++-10 mipsisa64r6-linux-gnuabi64-g++-11 mipsisa64r6-linux-gnuabi64-g++-12 mipsisa64r6-linux-gnuabi64-gcc mipsisa64r6-linux-gnuabi64-gcc-10 mipsisa64r6-linux-gnuabi64-gcc-11 mipsisa64r6-linux-gnuabi64-gcc-12 mipsisa64r6-linux-gnuabi64-gcc-ar mipsisa64r6-linux-gnuabi64-gcc-ar-10 mipsisa64r6-linux-gnuabi64-gcc-ar-11 mipsisa64r6-linux-gnuabi64-gcc-ar-12 mipsisa64r6-linux-gnuabi64-gcc-nm mipsisa64r6-linux-gnuabi64-gcc-nm-10 mipsisa64r6-linux-gnuabi64-gcc-nm-11 mipsisa64r6-linux-gnuabi64-gcc-nm-12 mipsisa64r6-linux-gnuabi64-gcc-ranlib mipsisa64r6-linux-gnuabi64-gcc-ranlib-10 mipsisa64r6-linux-gnuabi64-gcc-ranlib-11 mipsisa64r6-linux-gnuabi64-gcc-ranlib-12 mipsisa64r6-linux-gnuabi64-gccgo mipsisa64r6-linux-gnuabi64-gccgo-10 mipsisa64r6-linux-gnuabi64-gccgo-11 mipsisa64r6-linux-gnuabi64-gccgo-12 mipsisa64r6-linux-gnuabi64-gcov mipsisa64r6-linux-gnuabi64-gcov-10 mipsisa64r6-linux-gnuabi64-gcov-11 mipsisa64r6-linux-gnuabi64-gcov-12 mipsisa64r6-linux-gnuabi64-gcov-dump mipsisa64r6-linux-gnuabi64-gcov-dump-10 mipsisa64r6-linux-gnuabi64-gcov-dump-11 mipsisa64r6-linux-gnuabi64-gcov-dump-12 mipsisa64r6-linux-gnuabi64-gcov-tool mipsisa64r6-linux-gnuabi64-gcov-tool-10 mipsisa64r6-linux-gnuabi64-gcov-tool-11 mipsisa64r6-linux-gnuabi64-gcov-tool-12 mipsisa64r6-linux-gnuabi64-gdc mipsisa64r6-linux-gnuabi64-gdc-10 mipsisa64r6-linux-gnuabi64-gdc-11 mipsisa64r6-linux-gnuabi64-gdc-12 mipsisa64r6-linux-gnuabi64-gfortran mipsisa64r6-linux-gnuabi64-gfortran-10 mipsisa64r6-linux-gnuabi64-gfortran-11 mipsisa64r6-linux-gnuabi64-gfortran-12 mipsisa64r6-linux-gnuabi64-gm2 mipsisa64r6-linux-gnuabi64-gm2-10 mipsisa64r6-linux-gnuabi64-gm2-11 mipsisa64r6-linux-gnuabi64-gm2-12 mipsisa64r6-linux-gnuabi64-gnat mipsisa64r6-linux-gnuabi64-gnat-10 mipsisa64r6-linux-gnuabi64-gnat-11 mipsisa64r6-linux-gnuabi64-gnat-12 mipsisa64r6-linux-gnuabi64-gnatbind mipsisa64r6-linux-gnuabi64-gnatbind-10 mipsisa64r6-linux-gnuabi64-gnatbind-11 mipsisa64r6-linux-gnuabi64-gnatbind-12 mipsisa64r6-linux-gnuabi64-gnatchop mipsisa64r6-linux-gnuabi64-gnatchop-10 mipsisa64r6-linux-gnuabi64-gnatchop-11 mipsisa64r6-linux-gnuabi64-gnatchop-12 mipsisa64r6-linux-gnuabi64-gnatclean mipsisa64r6-linux-gnuabi64-gnatclean-10 mipsisa64r6-linux-gnuabi64-gnatclean-11 mipsisa64r6-linux-gnuabi64-gnatclean-12 mipsisa64r6-linux-gnuabi64-gnatfind mipsisa64r6-linux-gnuabi64-gnatfind-10 mipsisa64r6-linux-gnuabi64-gnatfind-11 mipsisa64r6-linux-gnuabi64-gnatgcc mipsisa64r6-linux-gnuabi64-gnathtml mipsisa64r6-linux-gnuabi64-gnathtml-10 mipsisa64r6-linux-gnuabi64-gnathtml-11 mipsisa64r6-linux-gnuabi64-gnathtml-12 mipsisa64r6-linux-gnuabi64-gnatkr mipsisa64r6-linux-gnuabi64-gnatkr-10 mipsisa64r6-linux-gnuabi64-gnatkr-11 mipsisa64r6-linux-gnuabi64-gnatkr-12 mipsisa64r6-linux-gnuabi64-gnatlink mipsisa64r6-linux-gnuabi64-gnatlink-10 mipsisa64r6-linux-gnuabi64-gnatlink-11 mipsisa64r6-linux-gnuabi64-gnatlink-12 mipsisa64r6-linux-gnuabi64-gnatls mipsisa64r6-linux-gnuabi64-gnatls-10 mipsisa64r6-linux-gnuabi64-gnatls-11 mipsisa64r6-linux-gnuabi64-gnatls-12 mipsisa64r6-linux-gnuabi64-gnatmake mipsisa64r6-linux-gnuabi64-gnatmake-10 mipsisa64r6-linux-gnuabi64-gnatmake-11 mipsisa64r6-linux-gnuabi64-gnatmake-12 mipsisa64r6-linux-gnuabi64-gnatname mipsisa64r6-linux-gnuabi64-gnatname-10 mipsisa64r6-linux-gnuabi64-gnatname-11 mipsisa64r6-linux-gnuabi64-gnatname-12 mipsisa64r6-linux-gnuabi64-gnatprep mipsisa64r6-linux-gnuabi64-gnatprep-10 mipsisa64r6-linux-gnuabi64-gnatprep-11 mipsisa64r6-linux-gnuabi64-gnatprep-12 mipsisa64r6-linux-gnuabi64-gnatxref mipsisa64r6-linux-gnuabi64-gnatxref-10 mipsisa64r6-linux-gnuabi64-gnatxref-11 mipsisa64r6-linux-gnuabi64-gprof mipsisa64r6-linux-gnuabi64-ld mipsisa64r6-linux-gnuabi64-ld.bfd mipsisa64r6-linux-gnuabi64-ld.gold mipsisa64r6-linux-gnuabi64-lto-dump-10 mipsisa64r6-linux-gnuabi64-lto-dump-11 mipsisa64r6-linux-gnuabi64-lto-dump-12 mipsisa64r6-linux-gnuabi64-nm mipsisa64r6-linux-gnuabi64-objcopy mipsisa64r6-linux-gnuabi64-objdump mipsisa64r6-linux-gnuabi64-ranlib mipsisa64r6-linux-gnuabi64-readelf mipsisa64r6-linux-gnuabi64-size mipsisa64r6-linux-gnuabi64-strings mipsisa64r6-linux-gnuabi64-strip mipsisa64r6-linux-gnuabin32-addr2line mipsisa64r6-linux-gnuabin32-ar mipsisa64r6-linux-gnuabin32-as mipsisa64r6-linux-gnuabin32-c++filt mipsisa64r6-linux-gnuabin32-dwp mipsisa64r6-linux-gnuabin32-elfedit mipsisa64r6-linux-gnuabin32-gprof mipsisa64r6-linux-gnuabin32-ld mipsisa64r6-linux-gnuabin32-ld.bfd mipsisa64r6-linux-gnuabin32-ld.gold mipsisa64r6-linux-gnuabin32-nm mipsisa64r6-linux-gnuabin32-objcopy mipsisa64r6-linux-gnuabin32-objdump mipsisa64r6-linux-gnuabin32-ranlib mipsisa64r6-linux-gnuabin32-readelf mipsisa64r6-linux-gnuabin32-size mipsisa64r6-linux-gnuabin32-strings mipsisa64r6-linux-gnuabin32-strip mipsisa64r6el-linux-gnuabi64-addr2line mipsisa64r6el-linux-gnuabi64-ar mipsisa64r6el-linux-gnuabi64-as mipsisa64r6el-linux-gnuabi64-c++filt mipsisa64r6el-linux-gnuabi64-cpp mipsisa64r6el-linux-gnuabi64-cpp-10 mipsisa64r6el-linux-gnuabi64-cpp-11 mipsisa64r6el-linux-gnuabi64-cpp-12 mipsisa64r6el-linux-gnuabi64-dwp mipsisa64r6el-linux-gnuabi64-elfedit mipsisa64r6el-linux-gnuabi64-g++ mipsisa64r6el-linux-gnuabi64-g++-10 mipsisa64r6el-linux-gnuabi64-g++-11 mipsisa64r6el-linux-gnuabi64-g++-12 mipsisa64r6el-linux-gnuabi64-gcc mipsisa64r6el-linux-gnuabi64-gcc-10 mipsisa64r6el-linux-gnuabi64-gcc-11 mipsisa64r6el-linux-gnuabi64-gcc-12 mipsisa64r6el-linux-gnuabi64-gcc-ar mipsisa64r6el-linux-gnuabi64-gcc-ar-10 mipsisa64r6el-linux-gnuabi64-gcc-ar-11 mipsisa64r6el-linux-gnuabi64-gcc-ar-12 mipsisa64r6el-linux-gnuabi64-gcc-nm mipsisa64r6el-linux-gnuabi64-gcc-nm-10 mipsisa64r6el-linux-gnuabi64-gcc-nm-11 mipsisa64r6el-linux-gnuabi64-gcc-nm-12 mipsisa64r6el-linux-gnuabi64-gcc-ranlib mipsisa64r6el-linux-gnuabi64-gcc-ranlib-10 mipsisa64r6el-linux-gnuabi64-gcc-ranlib-11 mipsisa64r6el-linux-gnuabi64-gcc-ranlib-12 mipsisa64r6el-linux-gnuabi64-gccgo mipsisa64r6el-linux-gnuabi64-gccgo-10 mipsisa64r6el-linux-gnuabi64-gccgo-11 mipsisa64r6el-linux-gnuabi64-gccgo-12 mipsisa64r6el-linux-gnuabi64-gcov mipsisa64r6el-linux-gnuabi64-gcov-10 mipsisa64r6el-linux-gnuabi64-gcov-11 mipsisa64r6el-linux-gnuabi64-gcov-12 mipsisa64r6el-linux-gnuabi64-gcov-dump mipsisa64r6el-linux-gnuabi64-gcov-dump-10 mipsisa64r6el-linux-gnuabi64-gcov-dump-11 mipsisa64r6el-linux-gnuabi64-gcov-dump-12 mipsisa64r6el-linux-gnuabi64-gcov-tool mipsisa64r6el-linux-gnuabi64-gcov-tool-10 mipsisa64r6el-linux-gnuabi64-gcov-tool-11 mipsisa64r6el-linux-gnuabi64-gcov-tool-12 mipsisa64r6el-linux-gnuabi64-gdc mipsisa64r6el-linux-gnuabi64-gdc-10 mipsisa64r6el-linux-gnuabi64-gdc-11 mipsisa64r6el-linux-gnuabi64-gdc-12 mipsisa64r6el-linux-gnuabi64-gfortran mipsisa64r6el-linux-gnuabi64-gfortran-10 mipsisa64r6el-linux-gnuabi64-gfortran-11 mipsisa64r6el-linux-gnuabi64-gfortran-12 mipsisa64r6el-linux-gnuabi64-gm2 mipsisa64r6el-linux-gnuabi64-gm2-10 mipsisa64r6el-linux-gnuabi64-gm2-11 mipsisa64r6el-linux-gnuabi64-gm2-12 mipsisa64r6el-linux-gnuabi64-gnat mipsisa64r6el-linux-gnuabi64-gnat-10 mipsisa64r6el-linux-gnuabi64-gnat-11 mipsisa64r6el-linux-gnuabi64-gnat-12 mipsisa64r6el-linux-gnuabi64-gnatbind mipsisa64r6el-linux-gnuabi64-gnatbind-10 mipsisa64r6el-linux-gnuabi64-gnatbind-11 mipsisa64r6el-linux-gnuabi64-gnatbind-12 mipsisa64r6el-linux-gnuabi64-gnatchop mipsisa64r6el-linux-gnuabi64-gnatchop-10 mipsisa64r6el-linux-gnuabi64-gnatchop-11 mipsisa64r6el-linux-gnuabi64-gnatchop-12 mipsisa64r6el-linux-gnuabi64-gnatclean mipsisa64r6el-linux-gnuabi64-gnatclean-10 mipsisa64r6el-linux-gnuabi64-gnatclean-11 mipsisa64r6el-linux-gnuabi64-gnatclean-12 mipsisa64r6el-linux-gnuabi64-gnatfind mipsisa64r6el-linux-gnuabi64-gnatfind-10 mipsisa64r6el-linux-gnuabi64-gnatfind-11 mipsisa64r6el-linux-gnuabi64-gnatgcc mipsisa64r6el-linux-gnuabi64-gnathtml mipsisa64r6el-linux-gnuabi64-gnathtml-10 mipsisa64r6el-linux-gnuabi64-gnathtml-11 mipsisa64r6el-linux-gnuabi64-gnathtml-12 mipsisa64r6el-linux-gnuabi64-gnatkr mipsisa64r6el-linux-gnuabi64-gnatkr-10 mipsisa64r6el-linux-gnuabi64-gnatkr-11 mipsisa64r6el-linux-gnuabi64-gnatkr-12 mipsisa64r6el-linux-gnuabi64-gnatlink mipsisa64r6el-linux-gnuabi64-gnatlink-10 mipsisa64r6el-linux-gnuabi64-gnatlink-11 mipsisa64r6el-linux-gnuabi64-gnatlink-12 mipsisa64r6el-linux-gnuabi64-gnatls mipsisa64r6el-linux-gnuabi64-gnatls-10 mipsisa64r6el-linux-gnuabi64-gnatls-11 mipsisa64r6el-linux-gnuabi64-gnatls-12 mipsisa64r6el-linux-gnuabi64-gnatmake mipsisa64r6el-linux-gnuabi64-gnatmake-10 mipsisa64r6el-linux-gnuabi64-gnatmake-11 mipsisa64r6el-linux-gnuabi64-gnatmake-12 mipsisa64r6el-linux-gnuabi64-gnatname mipsisa64r6el-linux-gnuabi64-gnatname-10 mipsisa64r6el-linux-gnuabi64-gnatname-11 mipsisa64r6el-linux-gnuabi64-gnatname-12 mipsisa64r6el-linux-gnuabi64-gnatprep mipsisa64r6el-linux-gnuabi64-gnatprep-10 mipsisa64r6el-linux-gnuabi64-gnatprep-11 mipsisa64r6el-linux-gnuabi64-gnatprep-12 mipsisa64r6el-linux-gnuabi64-gnatxref mipsisa64r6el-linux-gnuabi64-gnatxref-10 mipsisa64r6el-linux-gnuabi64-gnatxref-11 mipsisa64r6el-linux-gnuabi64-gprof mipsisa64r6el-linux-gnuabi64-ld mipsisa64r6el-linux-gnuabi64-ld.bfd mipsisa64r6el-linux-gnuabi64-ld.gold mipsisa64r6el-linux-gnuabi64-lto-dump-10 mipsisa64r6el-linux-gnuabi64-lto-dump-11 mipsisa64r6el-linux-gnuabi64-lto-dump-12 mipsisa64r6el-linux-gnuabi64-nm mipsisa64r6el-linux-gnuabi64-objcopy mipsisa64r6el-linux-gnuabi64-objdump mipsisa64r6el-linux-gnuabi64-ranlib mipsisa64r6el-linux-gnuabi64-readelf mipsisa64r6el-linux-gnuabi64-size mipsisa64r6el-linux-gnuabi64-strings mipsisa64r6el-linux-gnuabi64-strip mipsisa64r6el-linux-gnuabin32-addr2line mipsisa64r6el-linux-gnuabin32-ar mipsisa64r6el-linux-gnuabin32-as mipsisa64r6el-linux-gnuabin32-c++filt mipsisa64r6el-linux-gnuabin32-dwp mipsisa64r6el-linux-gnuabin32-elfedit mipsisa64r6el-linux-gnuabin32-gprof mipsisa64r6el-linux-gnuabin32-ld mipsisa64r6el-linux-gnuabin32-ld.bfd mipsisa64r6el-linux-gnuabin32-ld.gold mipsisa64r6el-linux-gnuabin32-nm mipsisa64r6el-linux-gnuabin32-objcopy mipsisa64r6el-linux-gnuabin32-objdump mipsisa64r6el-linux-gnuabin32-ranlib mipsisa64r6el-linux-gnuabin32-readelf mipsisa64r6el-linux-gnuabin32-size mipsisa64r6el-linux-gnuabin32-strings mipsisa64r6el-linux-gnuabin32-strip mir-shell mir-smoke-test-runner mir_demo_client_basic mir_demo_client_chain_jumping_buffers mir_demo_client_fingerpaint mir_demo_client_flicker mir_demo_client_multiwin mir_demo_client_prerendered_frames mir_demo_client_progressbar mir_demo_client_prompt_session mir_demo_client_release_at_exit mir_demo_client_screencast mir_demo_client_wayland mir_demo_client_wayland_egl_spinner mir_demo_server mir_performance_tests mir_platform_graphics_test_harness mir_stress mir_wayland_generator mira mirabait miraconvert mirage miral-app miral-kiosk miral-shell miral-system-compositor miral-terminal miramem miramer miri_sdr mirin mirmon mirobo mirout mirrorMesh mirror_grid mirrorbits mirscreencast mirtop misery misfortune mispipe missfits missidentify misspell-fixer mistletoe mistral mistral-db-manage mistral-server mistral-wsgi-api mit-scheme-x86-64 mit-scheme-x86-64-11.2 mitmdump mitmproxy mitmweb mitsub_vfd miview miwm miwm-session mix mixasm mixconv mixer mixguile mixlib-install mixtureAdiabaticFlameT mixvm mixxx mizuho mizuho-asciidoc mjs2cjs mk-build-deps mk-origtargz mk-sbuild mk4ht mkThumbs mk_cmds mk_modmap mka64ins-3.2.2 mkafmmap mkalias mkarmins-3.2.2 mkarv mkatfs mkbimage mkbindic mkbitmap mkbootimg mkbundle mkc_check_compiler mkc_check_custom mkc_check_decl mkc_check_funclib mkc_check_header mkc_check_prog mkc_check_sizeof mkc_check_version mkc_compiler_settings mkc_install mkc_which mkcamlp4 mkcamlp5 mkcamlp5.opt mkcert mkchdr (1) - creates a C header file from a type table mkchromecast mkcmake mkcomdepend mkcp mkd2html mkdarts mkdep mkdepthcharge mkdfiff mkdgiff mkdgifft mkdic mkdirhier mkdiskimage mkdist mkdna6idx mkdns323fw mkdoc mkdocs mkdssp mkdtdskel mkdtskel mkeficapsule mkenvimage mkeot mkepmlist mkfastmod mkfifo (1) - make FIFOs (named pipes) mkfifo (3) - make a FIFO special file (a named pipe) mkfontdir (1) - create an index of X font files in a directory mkfontscale (1) - create an index of scalable font files for X mkfs.cpm mkfs.erofs mkgeo_ball mkgeo_contraction mkgeo_couette mkgeo_grid mkgeo_obstacle mkgeo_sector mkgeo_ugrid mkgmap mkgmap-splitter mkgmapgui mkgrkindex mkhtmlindex mkid mkimage mkindex mkinsadd-3.2.2 mkisofs mkjavadepend mkjobtexmf mkkanwa mklibs mklibs-copy mklibs-readelf mklistdoc mkmanifest (1) - makes list of file names and their DOS 8+3 equivalent mknmz mkocp mkoctfile mkofm mkosi mkpasswd (1) - Overfeatured front end to crypt(3) mkpasswd.pl mkpic mkpkg mkr2mrc mkrc mkrfc2734 mkromdic mkroot mksquashfs (1) - tool to create and append to squashfs filesystems mkstatic mksunxiboot mkt1font mktexdepend mktexfmt mktexlsr mktexmf mktexpk mktextfm mktip mktorrent mktunes mkvappend mkvextract mkvgafont mkvinfo mkvmerge mkvpropedit mkvstream mkvtoolnix-gui mkvtree mkwinpeimg mkx86ins-3.2.2 mkxlax mkxmltype mkzftree ml-antlr ml-build ml-burg ml-lex ml-makedepend ml-nlffigen ml-ulex ml-yacc ml2ovn-trace ml_count mlabel (1) - make an MSDOS volume label mlagan mlbplay mlbstreamer mlcc mlclient mle mlink mlir-cpu-runner-13 mlir-cpu-runner-14 mlir-cpu-runner-15 mlir-linalg-ods-gen-13 mlir-linalg-ods-yaml-gen-13 mlir-linalg-ods-yaml-gen-14 mlir-linalg-ods-yaml-gen-15 mlir-lsp-server-13 mlir-lsp-server-14 mlir-lsp-server-15 mlir-opt-13 mlir-opt-14 mlir-opt-15 mlir-pdll-14 mlir-pdll-lsp-server-15 mlir-reduce-13 mlir-reduce-14 mlir-reduce-15 mlir-tblgen-13 mlir-tblgen-14 mlir-tblgen-15 mlir-translate-13 mlir-translate-14 mlir-translate-15 mlist mllatex mllp_send mlmmj-bounce mlmmj-list mlmmj-maintd mlmmj-make-ml mlmmj-process mlmmj-receive mlmmj-recieve mlmmj-send mlmmj-sub mlmmj-unsub mln mlock (2) - lock and unlock memory mlogc mlpost mlr mlterm mltex mlv-smile mm-common-get mm-common-prepare mm-config mm2gv (1) - Matrix Market-DOT converters mm3d mmCQL mma mma-gb mma-libdoc mma-mnx mma-renum mma-rm2std mma-splitrec mmafm mmake mman mmark mmc mmc-tool mmc_format mmcat (1) - Output the contents of a partition to stdout mmcli (1) - Control and monitor the ModemManager mmd (1) - make an MSDOS subdirectory mmdblookup mmdbresolve (1) - Read IPv4 and IPv6 addresses and print their IP geolocation information. mmdebstrap mmdir mme mmime mmk_m2 mmk_m2-int32 mmk_m2-int64 mmk_m2-long mmk_m3 mmk_m3-int32 mmk_m3-int64 mmk_m3-long mmkdir mml2musicxml mmllint mmls (1) - Display the partition layout of a volume system (partition tables) mmmulti mmount (1) - mount an MSDOS disk mmove (1) - move or rename an MSDOS file or subdirectory mmpfb mmroff mmsdtng mmseg mmseqs mmseqs-avx mmseqs-avx2 mmseqs-sse3 mmseqs-sse4.1 mmseqs-ssse3 mmstat (1) - Display details about the volume system (partition tables) mmtarfilter mmtbx.afitt mmtbx.afitt_fd mmtbx.altloc_remediate mmtbx.analyze_peptides mmtbx.analyze_static_disorder mmtbx.anneal_real_space mmtbx.apply_ncs_to_ligand mmtbx.bfactor_plot mmtbx.build_alternate_conformations mmtbx.cdl_lookup mmtbx.compare_ligands mmtbx.compute_map_coefficients mmtbx.density_modification mmtbx.development.aev mmtbx.distance_difference mmtbx.dssp mmtbx.emringer_score mmtbx.estimate_bijvoet_ratio mmtbx.extend_sidechains mmtbx.fft mmtbx.find_peaks_holes mmtbx.find_residue_in_pdb mmtbx.fix_rama_outliers mmtbx.fix_rotamer_outliers mmtbx.flipbase mmtbx.fmodel_simple mmtbx.generate_disorder mmtbx.get_related_ensemble mmtbx.hydrogenate mmtbx.massage_data mmtbx.matthews mmtbx.model_vs_data mmtbx.mon_lib_cif_triage mmtbx.monomer_library.comp_as_motif mmtbx.mp_geo mmtbx.nonbonded_overlaps mmtbx.nqh_minimize mmtbx.partial_omit_map mmtbx.pdb_interpretation mmtbx.pdb_statistics mmtbx.pdb_view_ad_hoc mmtbx.prepare_pdb_deposition mmtbx.probe2 mmtbx.process_predicted_model mmtbx.prune_model mmtbx.python mmtbx.quantum_interface mmtbx.rama_z mmtbx.rebuild_cablam_cache mmtbx.rebuild_rotarama_cache mmtbx.reduce2 mmtbx.refine_anomalous_substructure mmtbx.rigid_bond_test mmtbx.ringer mmtbx.search_pdb_symmetry mmtbx.select_best_starting_model mmtbx.show_build_path mmtbx.show_dist_paths mmtbx.show_r_factors_by_shell mmtbx.show_suspicious_residues mmtbx.simple_build_alt_confs mmtbx.simulate_low_res_data mmtbx.ss_idealization mmtbx.ssm_rmsd_for_chains mmtbx.strip_model mmtbx.super mmtbx.superpose mmtbx.table_one mmtbx.validate_ions mmtbx.validate_ligands mmtbx.validate_waters mmtbx.validation_summary mmtbx.verify_mon_lib_data mmtbx.water_screen mmtbx.xtriage mmtbx.xtriage_gui mmv mmval mn mnc2nii mndp mne mnemosyne mnexec moar mobical mobidrm mobile-atlas-creator mobimeta mobitool moc-qt5 (1) - generate Qt meta object support code mocassin mocassinOutput mocassinPlot mocassinWarm mocha mockery mockgen mocp mod mod-mono-server mod-mono-server4 mod2html mod2imp mod2opus mod2osis mod2vpl mod2zmod modFreqs mod_python mode2 model_P modelicac modelicat modem-cmd modem-manager-gui modemtest modeprint modes_rx modetest modhex modifyMesh modifyrepo_c modpib modplug123 modpods modsclean modula3_count modularize-13 modularize-14 modularize-15 module-assistant module-deps module-faker module-size module-starter module_info modulecmd modulemaker modulemd-validator modules-used modutil moggsplit (1) - split Ogg logical streams mogrify mogrify-im6.q16 mogrify-im6.q16hdri mojo mokutil molcif2sdf molck mold molds molecularnexafs.x molecularpdos.x molequeue molly-brown moloslave molostart molotov molprobity.cablam molprobity.cbetadev molprobity.clashscore molprobity.kinemage molprobity.molprobity molprobity.omegalyze molprobity.probescore_ligand molprobity.ramalyze molprobity.rna_validate molprobity.rotalyze molprobity.suitename molrender mona monado-cli monado-ctl monado-gui monado-service monajat-applet monajat-mod monasca moncmd monero-blockchain-ancestry monero-blockchain-depth monero-blockchain-export monero-blockchain-import monero-blockchain-mark-spent-outputs monero-blockchain-prune monero-blockchain-prune-known-spent-data monero-blockchain-stats monero-blockchain-usage monero-gen-ssl-cert monero-gen-trusted-multisig monero-wallet-cli monero-wallet-rpc monerod monfailures mongoose mongrel2 monit monitor monitor-sensor monitor-xhc-hb04 monitorix monmaptool mono (1) - Mono's ECMA-CLI native code generator (Just-in-Time and Ahead-of-Time) mono-api-check mono-api-html mono-api-info mono-boehm mono-cil-strip mono-configuration-crypto mono-csc mono-find-provides mono-find-requires mono-fpm mono-hang-watchdog mono-heapviz mono-service mono-sgen mono-shlib-cop mono-symbolicate mono-test-install mono-upnp-gtk mono-upnp-simple-media-server mono-xmltool monodis monodoc-http monodocer monodocs2html monodocs2slashdoc monop monop2 monshow montage montage-im6.q16 montage-im6.q16hdri monteverdi moonphases moonshot moonshot-webp mopidy morbig morbo mord mord-int32 mord-int64 mord-long morfessor morfessor-evaluate morfessor-segment morfessor-train mori-11d.x mori-4d.x mori-5d.x mori-6d.x mori.x morla morph morse morse2ascii morseALSA morseLinux morseOSS morseX11 morsegen morty mosdepth mosh mosh-client mosh-server mosquitto_ctrl mosquitto_passwd mosquitto_pub mosquitto_rr mosquitto_sub most mothur motion-logger motion_blur_geometry mou2gmn mount-image-callback mount.aptfs mount.winregfs mountavfs mouse-dpi-tool mousepad (1) - simple text editor for Xfce mousetrap mousetweaks moveDynamicMesh moveEngineMesh moveMesh movemail.mailutils (1) - move messages across mailboxes. moveoff_gui movescu moz-version moz2po mozc_emacs_helper mozcerts-qt5 mozfunny2prop mozillavpn mozlang2po mozo mozroots mp mp2enc mp2eps mp2pdf mp2png mp32 mp32vclt mp3blaster mp3burn mp3cd mp3check mp3cue mp3cut mp3diags mp3fs mp3gain mp3guessenc mp3info mp3info2 mp3length mp3rename mp3report mp3roaster mp3splt mp3splt-gtk mp3tag mp3val mp3wrap mp4h mp64 mpDris2 mp_plot mpack mpartition (1) - partition an MSDOS hard disk mpath mpb mpb-data mpb-mpi mpb-split mpbi mpbi-data mpbi-mpi mpbi-split mpc mpc-ace mpc123 mpc2sv8 mpcchap mpccut mpcdec mpcenc mpcgain mpcp mpd mpd-dump-ratings mpd-dynamic mpd-rate mpd-sima mpdas mpdcron mpdscribble mpdtcompose mpdtexpand mpdtinfo mpdtreverse mpeg2dec mpeg2desc mpeg2enc mpeg3cat mpeg3dump mpeg3peek mpeg3toc mpegcat mpegdemux mpegtranscode mperfmon mpexpand mpfade mpg123-alsa mpg123-id3dump mpg123-jack mpg123-nas mpg123-openal mpg123-oss mpg123-portaudio mpg123-pulse mpg123-strip mpg123.bin mpg321 mpgcat mpgdemux mpgenplaylists mpginfo mpgjoin mpgrafic mpgsplit mpgtx mpiCC.openmpi mpic++.lam mpic++.openmpi mpicalc mpicc.lam mpicc.mpich mpicc.openmpi mpichversion mpick mpicxx.mpich mpicxx.openmpi mpiexec.hydra mpiexec.lam mpiexec.mpich mpiexec.openmpi mpiexec.slurm mpif77.lam mpif77.mpich mpif77.openmpi mpif90.mpich mpif90.openmpi mpifort.mpich mpifort.openmpi mpijavac mpijavac.pl mpimsg mpinsert mpipython mpirun.lam mpirun.mpich mpirun.openmpi mpitask mpivars mpjboot mpjclean mpjdaemon mpjhalt mpjinfo mpjrun mpjstatus mplength mplex mpload mplrs mpmetis mpmv mpop mpopd mpost mpp mppb mppbcc mppc mppcheck mppg mppi mppl mpplu mppprof mppr mpqc mpqcval mprand mprandomwalk mprev mpris-proxy (1) - Bluetooth mpris-proxy mprof-decoder mprof-heap-viewer mprof-report mprompt mpskip mpsolve mpstat mpstore mpswap mptcpize mptoggle mptopdf mptp mpv mpxstats mpy.mpich2 mpy.openmpi mqtt mquery mquote mr mrancid mraverageheader mrb mrc mrc2mkr mrcal-calibrate-cameras mrcal-convert-lensmodel mrcal-cull-corners mrcal-from-cahvor mrcal-graft-models mrcal-is-within-valid-intrinsics-region mrcal-reproject-image mrcal-reproject-points mrcal-show-distortion-off-pinhole mrcal-show-geometry mrcal-show-projection-diff mrcal-show-projection-uncertainty mrcal-show-residuals mrcal-show-residuals-board-observation mrcal-show-splined-model-correction mrcal-show-valid-intrinsics-region mrcal-stereo mrcal-to-cahvor mrcal-triangulate mrcalc mrcat mrcentroid mrcfile-header mrcfile-validate mrcheckerboardmask mrclusterstats mrcolour mrconvert mrd (1) - remove an MSDOS subdirectory mrdegibbs mrdump mred mred-text mredit mrefile mren (1) - rename an existing MSDOS file mrename mrep mrest mrest-cli mrest-standalone mrfilter mrftopbm mrgddb mrgdv mrggkk mrgingham mrgingham-observe-pixel-uncertainty mrgingham-rotate-corners mrgrid mrgscr mrhistmatch mrhistogram mricron mrinfo mrmath mrmetric mrpt-performance mrregister mrstats mrt-print-all mrt-slice mrt-summary mrt2bgpdump mrt2exabgp mrtdreader mrtg mrtg-apache mrtg-ip-acct mrtg-load mrtg-ping-probe mrtg-sensors mrtg-traffic-sum mrtg-uptime mrtg2pcp mrthreshold mrtransform mrtrix3.py mrtrix_cleanup mrview mrvlogin msSingleScan ms_print (1) - post-processing tool for Massif msa_diff msa_split msa_view msandbox msb msbar msc-gen mscan mscat mscgen mscompress msconvert mscore mscore3 msd msd-datetime-mechanism msd-locate-pointer msed mseed2sac msencrypt mseq msexpand msg_parse msgattrib (1) - attribute matching and manipulation on message catalog msgcat (1) - combines several message catalogs msgcleanup msgcmp (1) - compare message catalog and template msgcomm (1) - match two message catalogs msgconv (1) - character set conversion for message catalog msgconvert msgen (1) - create English message catalog msgexec (1) - process translations of message catalog msgfilter (1) - edit translations of message catalog msgfmt (1) - compile message catalog to binary format msggrep (1) - pattern matching on message catalog msghack msginit (1) - initialize a message catalog msgmerge (1) - merge message catalog and template msgp msgunfmt (1) - uncompile message catalog from binary format msguniq (1) - unify duplicate translations in message catalog msguntypot msh2geo msh2xdmf mshToFoam mshortname (1) - shows short name of a file mshow mshowfat (1) - shows FAT clusters allocated to file mshrable msi-keyboard msibuild msidiff msidump msiecfexport msiecfinfo msiexec-stable msiextract msiinfo msk144code msktutil msm_dp_compliance msmtp msmtpd msoelim msoffcrypto-tool msp430mcu-config mspdebug msql2mysql (1) - convert mSQL programs for use with MySQL msselect mssh mstack msva-perl msva-query-agent msvmocas msword2brl msxlint mt-dds mta-sts-daemon mta-sts-query mtail mtasim mtbatch mtbl_dump mtbl_info mtbl_merge mtbl_verify mtcvtfix mtcvtodd mtcvtv23 mtdev-test mtdump mthread mtile mtink mtinkc mtkbabel mtlogin mtnormalise mtools (1) - utilities to access DOS disks in Unix. mtools (5) - mtools configuration files mtoolstest (1) - tests and displays the configuration mtp mtp-albumart mtp-albums mtp-connect mtp-delfile mtp-detect mtp-emptyfolders mtp-files mtp-filetree mtp-folders mtp-format mtp-getfile mtp-getplaylist mtp-hotplug mtp-newfolder mtp-newplaylist mtp-playlists mtp-reset mtp-sendfile mtp-sendtr mtp-thumb mtp-tracks mtp-trexist mtpaint mtpolicyd mtr mtr-packet mtrace (1) - interpret the malloc trace log mtrace (3) - malloc tracing mtree mtst mtst-int32 mtst-int64 mtst-long mtt mtvtoppm mtxrun mtxrunjit mtype (1) - display contents of an MSDOS file mu muchsync mudita24 mueval mueval-core muffin mugshot mujoco-basic mujoco-compile mujoco-derivative mujoco-record mujoco-simulate mujoco-testspeed mujoco-testxml mujs multiBamCov multiBamSummary multiBigwigSummary multiIntersectBed multi_to_single_fast5 multibibliography multibinit multicat multicat_validate multidelta multigem multilive multilog multimarkdown multimon multimon-ng multiphaseEulerFoam multiphaseInterFoam multiqc multirender_test multirootca multiruby multiruby_setup multiscene_geometry multispell multispot5_headless multitail multitee multitime multitrans multiwatch multixterm mumble mumble-overlay mummer mummer-annotate mummerplot mumudvb munch munchlist munge munin-check munin-cron munin-get munindoc munipack munpack muon mup2mma mupdf mupdf-gl muplot murano murano-api murano-cfapi murano-cfapi-db-manage murano-db-manage murano-engine murano-manage murano-pkg-check murano-status murano-test-runner murano-wsgi-api muranoagent murasaki murasaki-mpi muraster murmur-user-wrapper muroard muroarstream murphi2c murphi2murphi murphi2uclid murphi2xml muscle muscle3 muse muse-song-convert muse_plugin_scan museragent musescore musescore3 music music123 musicxml2ly musixflx musixtex musl-gcc musl-ldd mussh mussort mustache mustache.js mustang mutagen-inspect (1) - view Mutagen-supported audio tags mutagen-pony (1) - scan a collection of MP3 files mute mutool mutt mutt_dotlock mutt_ldap_query mutt_vc_query mutter (1) - Clutter based compositing GTK2 Window Manager muttprint muttprofile mutual mux mvdic mvs mvxattr mwaw2epub mwaw2html mwaw2odf mwaw2raw mwaw2text mwc mwc-ace mwcfeedserver mwcontam mwfilter mwhatis mwic mwlQuery mwm mwrank mwrap mx-run mxtar (1) - Wrapper for using GNU tar directly from a floppy disk my_print_defaults (1) - display options from option files myatscc mycli mydumper myfilelength mygpo-bpsync mygpo-list-devices mygpo-simple-client myisam_ftdump (1) - display full-text index information myisamchk (1) - MyISAM table-maintenance utility myisamlog (1) - display MyISAM log file contents myisampack (1) - generate compressed, read-only MyISAM tables myloader mylvmbackup mymake mymd5sum mymeta-cpanfile mypager mypaint mypaint-ora-thumbnailer myproxy-change-pass-phrase myproxy-destroy myproxy-get-delegation myproxy-get-trustroots myproxy-info myproxy-init myproxy-logon myproxy-retrieve myproxy-store mypy mypyc myrocks_hotbackup mysecureshell mysofa2json mysql (1) - the MariaDB command-line tool (mysql is now a symlink to mariadb) mysql-schema-diff mysql2dbf mysql_client_test mysql_client_test_embedded mysql_config mysql_convert_table_format (1) - convert tables to use a given storage engine (mysql_convert_table_format is now a symlink to mariadb-convert-table-format) mysql_find_rows (1) - extract SQL statements from files (mysql_find_rows is now a symlink to mariadb-find-rows) mysql_fix_extensions (1) - normalize table file name extensions (mysql_fix_extensions is now a symlink to mariadb-fix-extensions) mysql_import_combined_log2 mysql_install_db (1) - initialize MariaDB data directory (mysql_install_db is now a symlink to mariadb-install-db) mysql_ldb mysql_plugin (1) - configure MariaDB server plugins (mysql_plugin is now a symlink to mariadb-plugin) mysql_secure_installation (1) - improve MariaDB installation security (mysql_secure_installation is now a symlink to mariadb-secure-installation) mysql_setpermission (1) - interactively set permissions in grant tables (mysql_setpermission is now a symlink to mariadb-setpermission) mysql_tzinfo_to_sql (1) - load the time zone tables (mysql_tzinfo_to_sql is now a symlink to mariadb-tzinfo-to-sql) mysql_upgrade (1) - check tables for MariaDB upgrade (mysql_upgrade is now a symlink to mariadb-upgrade) mysql_waitpid (1) - kill process and wait for its termination (mysql_waitpid is now a symlink to mariadb-waitpid) mysqlaccess (1) - client for checking access privileges (mysqlaccess is now a symlink to mariadb-access) mysqladmin (1) - client for administering a MariaDB server (mysqladmin is now a symlink to mariadb-admin) mysqlanalyze (1) - a table maintenance program (mysqlcheck is now a symlink to mariadb-check) mysqlbinlog (1) - utility for processing binary log files (mysqlbinlog is now a symlink to mariadb-binlog) mysqlcheck (1) - a table maintenance program (mysqlcheck is now a symlink to mariadb-check) mysqld_multi (1) - manage multiple MariaDB servers (mysqld_multi is now a symlink to mariadbd-multi) mysqld_safe (1) - MariaDB server startup script (mysqld_safe is now a symlink to mariadbd-safe) mysqld_safe_helper (1) - helper script (mysqld_safe_helper is now a symlink to mariadbd-safe-helper) mysqldump (1) - a database backup program (mysqldump is now a symlink to mariadb-dump) mysqldumpslow (1) - Summarize slow query log files (mysqldumpslow is now a symlink to mariadb-dumpslow) mysqlhotcopy (1) - a database backup program (mysqlhotcopy is now a symlink to mariadb-hotcopy) mysqlimport (1) - a data import program (mysqlimport is now a symlink to mariadb-import) mysqloptimize (1) - a table maintenance program (mysqlcheck is now a symlink to mariadb-check) mysqlrepair (1) - a table maintenance program (mysqlcheck is now a symlink to mariadb-check) mysqlreport (1) - Makes a friendly report of important MySQL status values mysqlshow (1) - display database, table, and column information (mysqlshow is now a symlink to mariadb-show) mysqlslap (1) - load emulation client (mysqlslap is now a symlink to mariadb-slap) mysqltest mysqltest_embedded mysqltuner myst-anchors myst-docutils-html myst-docutils-html5 myst-docutils-latex myst-docutils-pseudoxml myst-docutils-xml mystiq mythtv-status mythtv_recording_now mythtv_recording_soon mytool mytop (1) - display MariaDB server performance info like 'top' mzc mzclient mzip (1) - change protection mode and eject disk on Zip/Jaz drive mzn2doc mzpp mzscheme mztext na_play na_record nabi nacl-sha256 nacl-sha512 nad nadoka nageru nagstamon nagzillac nagzillad nala nam nama namazu name2addr namecheap namecheck nameclt named-checkconf named-checkzone named-compilezone named-journalprint named-nzd2nzf named-rrchecker namei (1) - follow a pathname until a terminal point is found nanoc nanocat nanoid nanook nanopb_generator.py nanopolish nanopolish_makerange nasd nasm nast nast-ier nasty nat-traverse natbraille natlog natpmpc natsort naturaldocs nautic nautilus nautilus-autorun-software nautilus-scripts-manager nauty-NRswitchg nauty-addedgeg nauty-addptg nauty-amtog nauty-ancestorg nauty-assembleg nauty-biplabg nauty-bliss2dre nauty-catg nauty-checks6 nauty-complg nauty-converseg nauty-copyg nauty-countg nauty-cubhamg nauty-deledgeg nauty-delptg nauty-dimacs2g nauty-directg nauty-dretodot nauty-dretog nauty-edgetransg nauty-genbg nauty-genbgL nauty-geng nauty-gengL nauty-genposetg nauty-genquarticg nauty-genrang nauty-genspecialg nauty-gentourng nauty-gentreeg nauty-hamheuristic nauty-labelg nauty-linegraphg nauty-listg nauty-multig nauty-nbrhoodg nauty-newedgeg nauty-pickg nauty-planarg nauty-productg nauty-ranlabg nauty-shortg nauty-showg nauty-subdivideg nauty-sumlines nauty-twohamg nauty-underlyingg nauty-vcolg nauty-watercluster2 navarp navit navlog-viewer nb2plots nbackup (1) - Physical backup manager for Firebird nbc nbdcopy nbddump nbdfuse nbdinfo nbdkit nbdsh nbibfind nbibtex nbtscan nc-config nc3tonc4 nc4tonc3 ncal (1) - displays a calendar and the date of Easter ncap2 ncargcc ncargex ncargf77 ncargf90 ncargfile ncargpath ncargrun ncargversion ncargworld ncarlogo2ps ncarvversion ncat ncatted ncbi-acc-download ncbi-seg ncbi_search ncbo ncclimo nccopy ncdc ncdiff ncdt ncdu ncdump ncdump-hdf ncea ncecat nces ncflint ncftp3 ncftpbatch ncftpbookmarks ncftpget ncftpls ncftpput ncftpspooler ncgen ncgen-hdf ncgen3 ncgm2cgm ncgmstat ncinfo ncks ncl ncl_convert2nc ncl_filedump ncl_grib2nc ncl_quicklook ncmpc ncmpcpp ncmpidiff ncmpidump ncmpigen ncoffsets ncoils ncpdq ncpus ncra ncrack ncrcat ncremap ncrename ncrystal-config ncrystal_endf2ncmat ncrystal_example_c ncrystal_example_cpp ncrystal_example_customphysics ncrystal_example_py ncrystal_hfg2ncmat ncrystal_inspectfile ncrystal_ncmat2cpp ncrystal_ncmat2hkl ncrystal_onlinedb2ncmat ncrystal_preparemcstasdir ncrystal_vdos2ncmat ncrystal_verifyatompos nctool ncurses5-config ncurses6-config ncursesw5-config ncursesw6-config ncvalidator ncview ncwa ncxx4-config ncz2psx nd nd-autoinstall nd-configurerepo nd_adddist nd_adddistall nd_apachelogs2subscriptionstats nd_backport nd_build nd_build4all nd_build4allnd nd_build4debianmain nd_build_testrdepends nd_execute nd_fetch_bdepends nd_freeze nd_gitbuild nd_login nd_popcon2stats nd_querycfg nd_rebuildarchive nd_updateall nd_updatedist nd_verifymirrors ndctl ndg_httpclient ndiff ndisasm ndisc6 ndmetis ndpiReader ndptool ndrdump ndsctl ndselect ne nearblack neat neato (1) - filter for drawing undirected graphs neb.x nec2c nedit nedit-nc needle needleall needrestart-session needs-restarting nef-11d.x nef-4d.x nef-5d.x nef-6d.x nef.x nefte negroni neko nekoc nekoml nekotools nemo nemo-autorun-software nemo-connect-server nemo-desktop nemo-epub2text nemo-mso-to-txt nemo-open-with nemo-ppt-to-txt nemo-xls-to-txt neo neobio neochat neofetch neomutt neon-config neotoppm neovim-ruby-host neqn (1) - format equations for ASCII output ner nescc nescc-mig nescc-ncg nescc-wiring net net-server net-snmp-config net-snmp-create-v3-user netaddr netcap netctl netctl-auto netgen netgen-lvs netgenNeutralToFoam netgroup nethttp netkey-tool netkit-ntalk netkit-rcp netkit-rlogin netkit-rsh netload netmask netmate netmdcli netperfmeter netplex-admin netr netread netrik netsed netselect netselect-apt netstat-nat netstress netsurf-fb netsurf-gtk nettle-hash nettle-lfib-stream nettle-pbkdf2 netwag network-test netwox netwrite neutron neutron-api neutron-bgp-dragent neutron-db-manage neutron-debug neutron-dhcp-agent neutron-ha-tool neutron-ipset-cleanup neutron-keepalived-state-change neutron-l3-agent neutron-linuxbridge-agent neutron-linuxbridge-cleanup neutron-macvtap-agent neutron-metadata-agent neutron-metering-agent neutron-netns-cleanup neutron-openvswitch-agent neutron-ovn-db-sync-util neutron-ovn-metadata-agent neutron-ovn-migration-mtu neutron-ovs-cleanup neutron-pd-notify neutron-plugin-manage neutron-remove-duplicated-port-bindings neutron-rootwrap neutron-rootwrap-daemon neutron-rpc-server neutron-sanitize-port-binding-profile-allocation neutron-sanitize-port-mac-addresses neutron-sanity-check neutron-server neutron-sriov-nic-agent neutron-status neutron-usage-audit neutron-vm-check neutron-vpn-netns-wrapper new-wcs newaliases (8) - a Mail Transfer Agent newcpgreport newcpgseek newfits newfs_udf newgidmap newgrp (1) - log in to a new group newicktops newicktotxt newinclude newlisp newlispdoc newmail newnet newpid newrole news newsboat newsbody newseq newslock newsq newuidmap nex next_hit nextcloud nextcloud-spreed-signaling-client nextcloud-spreed-signaling-proxy nextcloud-spreed-signaling-server nextcloudcmd nextepc-hssd nextepc-mmed nextepc-pcrfd nextepc-pgwd nextepc-sgwd nextpnr-generic nextpnr-ice40 nf-config nf-ct-add nf-ct-events nf-ct-list nf-exp-add nf-exp-delete nf-exp-list nf-log nf-monitor nf-queue nf2csv nf2ff nfanon nfc nfc-anticol nfc-barcode nfc-dep-initiator nfc-dep-target nfc-emulate-forum-tag2 nfc-emulate-forum-tag4 nfc-emulate-tag nfc-emulate-uid nfc-jewel nfc-list nfc-mfclassic nfc-mfsetuid nfc-mfultralight nfc-poll nfc-read-forum-tag3 nfc-relay nfc-relay-picc nfc-scan-device nfcapd nfdump nfexpire nforenum nfoview nfpcapd nfprofile nfreplay nfs-cat nfs-cp nfs-ls nfs4_editfacl nfs4_getfacl nfs4_setfacl nfstrace nftrack ng ng-cjk ng-cjk-canna ng-latin ng-nailgun ng4ex ngcgui ngettext (1) - translate message and choose plural form ngettext (3) - translate message and choose plural form nghttp nginx-confgen ngmlr ngp2 ngram_build ngram_test ngrams ngraph ngrep ngsfilter ngspice ngspice2genspic nheko nhlcc nhlf77 nhlf90 nhmmer nhmmscan niLicense niReg nib-conform nib-dicomfs nib-diff nib-ls nib-nifti-dx nib-roi nib-stats nib-tck2trk nib-trk2tck nib_chrom_intervals_to_fasta.py nib_intervals_to_fasta.py nib_length.py nice (1) - run a program with modified scheduling priority nice (2) - change process priority niceload nick2ldif nickle nics nicstat nifti1_tool nifti_stats nifti_tool niftidump niftitodicom nii2mnc nik4 nim nimble nimgrep nimsuggest ninja nip2 nipy_3dto4d nipy_4d_realign nipy_4dto3d nipy_diagnose nipy_tsdiffana nitool nitpic nitrocli nitrogen nitrokey-app nix nix-build nix-channel nix-collect-garbage nix-copy-closure nix-daemon nix-env nix-hash nix-instantiate nix-prefetch-url nix-shell nix-store nixnote2 njb-cursesplay njb-delfile njb-deltr njb-dumpeax njb-dumptime njb-files njb-fwupgrade njb-getfile njb-getowner njb-gettr njb-getusage njb-handshake njb-pl njb-play njb-playlists njb-sendfile njb-sendtr njb-setowner njb-setpbm njb-settime njb-tagtr njb-tracks njplot nkf nl (1) - number lines of files nl (3ncurses) - curses input options nl-addr-add nl-addr-delete nl-addr-list nl-class-add nl-class-delete nl-class-list nl-classid-lookup nl-cls-add nl-cls-delete nl-cls-list nl-fib-lookup nl-link-enslave nl-link-ifindex2name nl-link-list nl-link-name2ifindex nl-link-release nl-link-set nl-link-stats nl-list-caches nl-list-sockets nl-monitor nl-neigh-add nl-neigh-delete nl-neigh-list nl-neightbl-list nl-pktloc-lookup nl-qdisc-add nl-qdisc-delete nl-qdisc-list nl-route-add nl-route-delete nl-route-get nl-route-list nl-rule-list nl-tctree-list nl-util-addr nlanr-tr-stat nlkt nload nlogin nltk nm (1) - list symbols from object files nm-applet nm-connection-editor nm-online nm-tray nm86 nmap (1) - Network exploration tool and security / port scanner nmapsi4 nmblookup nmbug nmcli nmixer nmlc nmon nmrpflash nmtui nmtui-connect nmtui-edit nmtui-hostname nmudiff nmz-config nmzcat nmzegrep nmzgrep nmzmail nmzmerge nn nnadmin nnalg nnbatch nncheck nncp-ack nncp-bundle nncp-call nncp-caller nncp-cfgdir nncp-cfgenc nncp-cfgmin nncp-cfgnew nncp-check nncp-cronexpr nncp-daemon nncp-exec nncp-file nncp-freq nncp-hash nncp-log nncp-pkt nncp-reass nncp-rm nncp-stat nncp-toss nncp-trns nncp-xfer nngcat nngoback nngrab nngrep nnn nnpost nns nnsd nnslog nnstats nntidy nntp-get nntp-list nntp-pull nntp-push nntpid nnum nnusage nnview noblenote nocache nodau node (1) - server-side JavaScript runtime node-coveralls node-gyp node-pre-gyp node-sass node-static nodeattr nodeenv nodefs nodejs (1) - server-side JavaScript runtime nodelist2lbdb nodepath nodeset nodeunit nodup nohtml nohup (1) - run a command immune to hangups, with output to a non-tty noindex noise noklogin nokogiri nomarch nonNewtonianIcoFoam nona noncvslist nonsvnlist nop (1) - pretty-print graph file nopaste nopaste-it noping noreturn normal-blending normal3d normalisefasta normaliz normalize-audio normalize-mp3 normalize-ogg normalizer noroff noroots norsnet norsp nose2-3 nosetests3 nospace not-13 not-14 not-15 notab notangle notary notary-server notary-signer note notedeln notfound notice notify notify-send (1) - a program to send desktop notifications notion notionflux notmuch notmuch-addrlookup notmuch-emacs-mua notmuch-extract-patch notmuch-git notmuch-import-patch notmuch-mutt notmuch-slurp-debbug notseq nountangle nova nova-api nova-api-wsgi nova-compute nova-conductor nova-manage nova-metadata-wsgi nova-novncproxy nova-policy nova-rootwrap nova-rootwrap-daemon nova-scheduler nova-serialproxy nova-spicehtml5proxy nova-status novo2sam.pl noweave noweb nowhere nox npa-tool npd6 nping (1) - Network packet generation tool / ping utility npm npm-arborist npm2deb npmrc nproc (1) - print the number of processing units available nproxy nps2gps npth-config npx nq nqc nqp nqp-m nquire nr nrancid nrefactory-demo-gtk nrefactory-demo-swf nrg2iso nrngui nrniv nrnivmodl nrnoc nroff (1) - use groff to format documents for TTY devices ns ns3++ nse nsec3dig nsec3hash nsenter (1) - run program in different namespaces nslogin nslookup (1) - query Internet name servers interactively nsntrace nspr-config nsrancid nss-addbuiltin nss-config nss-dbtest nss-passwords nss-pp nsscache nstat (8) - network statistics tools. nstk nstreams nsupdate (1) - dynamic DNS update utility nsxiv ntcard ntdpal nted ntfsck ntfsdecrypt (8) - decrypt or update NTFS files encrypted according to EFS ntfsdump_logfile ntfsmftalloc nthash nthll nthseq nthseqset ntlm_auth ntpdig ntpmon ntpq ntpshmmon ntpstat ntptrace ntpviz ntsc-cc ntthal nucBed nucmer nucmer2xfig nudatus nuget nuitka3 nuitka3-run nulib2 nullmailer-dsn nullmailer-inject nullmailer-smtpd num num2words numactl numad numastat numatop numaverage numbers2csv numbers2ods numbers2raw numbers2text numberstation numbound numdiff numfmt (1) - Convert numbers from/to human-readable strings numgrep numinterval numlockx numnormalize numprocess numrandom numrange numround numsum nunit-console nunit-gui nunjucks-precompile nuntius nup nuspell nut nuttcp nuweb2noweb nvassemble nvcompress nvddsinfo nvdecompress nvi nview nvim nvim-qt nvimgdiff nvlc nvmmerge nvmsplit nvptx-none-ar nvptx-none-as nvptx-none-ld nvptx-none-ranlib nvptx-none-run nvptx-none-run-single nvpy nvzoom nw nwall nwchem nwchem.mpich nwchem.openmpi nwdiag3 nxagent nxbrowse nxconvert nxdialog nxdir nxproxy nxsh nxsummary nxt-update-firmware nxtranslate nxtraverse nxtrim nxwish ny nyancat nyancat-server nyc nytprofcalls nytprofcg nytprofcsv nytprofhtml nytprofmerge nytprofpf nyx nzbget o-saft o2info o2m o2v oLschema2ldif oai_browser oai_pmh oakdecode oaklisp oarcp oardel oarhold oarmonitor_graph_gen oarnodechecklist oarnodecheckquery oarnodes oarprint oarresume oarsh oarstat oarsub oarwalltime oasis oathtool oauth obabel obamenu obconf obconf-qt obconformer obdistgen obenergy obex_find obex_tcp obex_test obexautofs obexctl (1) - A command-line interface of BlueZ for OBEX (file transfer) obexfs obexftp obexftpd obexget obexls obexput obexrm obfit obfitall obfs-local obfs-server obfs4proxy obgen obgrep obgui obiaddtaxids obiannotate obiclean obicomplement obiconvert obicount obicut obidistribute obiextract obigrep obihead obijoinpairedend obipr2 obisample obiselect obisilva obisort obisplit obistat obisubset obitab obitail obitaxonomy obiuniq obj2yaml obj2yaml-13 obj2yaml-14 obj2yaml-15 objToVTK objc_count objcopy (1) - copy and translate object files objdump (1) - display information from object files objdump86 obminimize obmm obprobe obprop obrms obrotamer obrotate obs obs-build obs-buildvc obs-cli obs_productconvert observations2map obsession-exit obsession-logout obspectrophore obsym obtautomer obthermo obuild obuild-simple obus-dump obus-gen-client obus-gen-interface obus-gen-server obus-idl2xml obus-introspect obus-xml2idl obxprop ocaml ocaml-gettext ocaml-lintian ocaml-md5sums ocaml-xgettext ocamlbuild ocamlc ocamlc.byte ocamlc.opt ocamlcmt ocamlcp ocamlcp.byte ocamlcp.opt ocamldebug ocamldep ocamldep.byte ocamldep.opt ocamldoc ocamldoc.opt ocamldot ocamldsort ocamldumpobj ocamlfind ocamlify ocamllex ocamllex.byte ocamllex.opt ocamllibdep ocamlmklib ocamlmklib.byte ocamlmklib.opt ocamlmktop ocamlmktop.byte ocamlmktop.opt ocamlmod ocamlobjinfo ocamlobjinfo.byte ocamlobjinfo.opt ocamlopt ocamlopt.byte ocamlopt.opt ocamloptp ocamloptp.byte ocamloptp.opt ocamlprof ocamlprof.byte ocamlprof.opt ocamlrpcgen ocamlrun ocamlrund ocamlruni ocamlviz-ascii ocamlviz-gui ocamlwc ocamlweb ocamlyacc occt-draw occt-draw-7.6 occtl oci-image-tool ociobakelut ociocheck ociochecklut ocioconvert ociodisplay ociolutimage ociomakeclf ocioperf ociowrite oclgrind oclgrind-kernel oclingo ocloc oclock (1) - round X clock ocp ocp-curses ocp-indent ocp-sdl2 ocp-vcsa ocpasswd ocpp5 ocproxy ocrad ocradcheck ocrfeeder ocrfeeder-cli ocrmypdf ocs ocs-get-nic-fw-lst ocs-scan-disk ocs-socket ocserv-fw ocsigenserver ocsigenserver.opt ocsinventory-agent ocspclnt ocsptool octanol octave octave-cli octave-config octavia-agent-lvs-masquerade octavia-api octavia-db-manage octavia-driver-agent octavia-health-manager octavia-housekeeping octavia-status octavia-worker octavia-wsgi octocatalog-diff octorpki octovis od (1) - dump files in octal and other formats od-tkdesk od65 odb odb-to-request odbcinst odbx-sql odbxplustest odbxtest odbxtest.master odc odc-0d oddcomp oddjob_request ode ode-config odf2mht odf2pod odf2xhtml odf2xliff odf2xml odf_set_fields odf_set_title odfbuild odfextract odffilesearch odffindbasic odfhighlight odfimgimport odflint odfmeta odfmetadoc odfoutline odfsearch odfuserfield odidx odil odin odinreco odmgr odoc odoo odp2pdf odp2ppt odp2txt odr-dabmux odr-padenc odr-zmq2edi ods-hsmspeed ods-hsmutil ods-kasp2html ods-kaspcheck ods2pdf ods2tsv ods2txt odt2bib odt2doc odt2docbook odt2html odt2lt odt2pdf odt2rtf odt2sdw odt2sxw odt2txt.odt2txt odt2txt.unoconv odt2xhtml odt2xml odvicopy odvitype oeminst offconsol offlineimap offsets ofl ofm2opl ofs2rva ofx2qif ofxclient ofxconnect ofxdump ofxstatement ogdi-config ogdi_import ogdi_info ogg123 oggCat oggCut oggDump oggJoin oggLength oggSilence oggSlideshow oggSplit oggThumb oggTranscode oggdec oggenc oggfwd ogginfo oggsplt oggz oggz-chop oggz-codecs oggz-comment oggz-diff oggz-dump oggz-info oggz-known-codecs oggz-merge oggz-rip oggz-scan oggz-sort oggz-validate ogmcat ogmdemux ogminfo ogmmerge ogmsplit ogni ogonkify ogr2ogr ogr_layer_algebra.py ogrinfo ogrlineref ogrmerge.py ogrtindex ohai ohcount ohdomainlist ohhandler ohparam oidc-add oidc-agent oidc-agent-service oidc-gen oidc-keychain oidc-prompt oidc-token oiiotool ojph_compress ojph_expand okteta okular (1) - a universal document viewer okularkirigami ola_artnet ola_dev_info ola_dmxconsole ola_dmxmonitor ola_e131 ola_patch ola_plugin_info ola_plugin_state ola_rdm_discover ola_rdm_get ola_rdm_set ola_recorder ola_set_dmx ola_set_priority ola_streaming_client ola_timecode ola_trigger ola_uni_info ola_uni_merge ola_uni_name ola_uni_stats ola_usbpro olad oldatonewa olecfexport olecfinfo olecfmount oligotag oligotm olive-editor olpc-brightness olpc-nosleep olpc-rotate olpc-volume ols ols_test omake omegat omfonts omindex omindex-list omniMapper omniNames omnicpp (1) - OmniORB cpp preprocessor for IDL compiler omnidb-server omniidl (1) - omniORB idl compiler omniidlrun ompi-clean ompi-server ompi_info ompl_benchmark_statistics omptbx.python omptbx.show_build_path omptbx.show_dist_paths omshell omxregister-bellagio omxregister-bellagio-0 on_ac_power onak onboard onboard-settings ondir one_field_per_line.py onedrive onesixtyone onioncircuits onionprobe onionshare onionshare-cli onlinequoteseditor5 only onnode onsgmls ontocount ontoget ontogetcommon ontogetdown ontogetobsolete ontogetroot ontogetsibs ontogetup ontoisobsolete ontospy ontotext oo2po oo2xliff oodoc_test oogl2rib oogl2vrml oogl2vrml2 oom-sort oomctl oomd ooo-thumbnailer ooxml2doc ooxml2odt ooxml2pdf op-tkdesk op2calltree opa_osd_dump opa_osd_exercise opa_osd_load opa_osd_perf opa_osd_query opa_osd_query_many opal_wrapper opalc++ opalcc opam opam-installer opari opari2 opari2-config open-raw.pl open3d open3d-gui openEMS open_grid.x open_jtalk openal-info openapi-gen openapi2smd openapp openaptxdec openaptxenc openbox openbox-gnome-session openbox-kde-session openbox-lxde openbox-menu openbox-session openbsd-cwm opencc opencc_dict opencc_phrase_extract opencfu opencolladavalidator opencsgexample opencv_annotation opencv_interactive-calibration opencv_model_diagnostics opencv_version opencv_visualisation opencv_waldboost_detector opendkim-spam opendrop opener openfortivpn openguides-setup-db openipmi_eventd openipmicmd openipmish openjade-1.4devel openlibrary2lesana openlp openmotor openmpt123 openmsx openmsx-catapult openmsx-debugger opennds opennlp openocd openpgp-applet openpgp-tool openpgpkey openqa-cli openqa-clone-job openqa-dump-templates openqa-label-all openqa-load-templates openqa-validate-yaml openrazer-daemon opensc-asn1 opensc-explorer opensc-notify opensc-tool openscad openscad-testrun opensearch-discover opensearch-genquery openshot-audio-demo openshot-qt openslide-quickhash1sum openslide-show-properties openslide-write-png openssl (1ssl) - OpenSSL command line program openstack openstack-debian-images-updater openstack-inventory openstack-tempest-ci openstack-tempest-ci_mgmt-lan openstack-tempest-merge-repo opensysusers-sysusers opentool opentracker openxr_runtime_list operon (1) - command line music tagger opgpcard ophcrack ophcrack-cli oping opj_compress opj_dec_server opj_decompress opj_dump opj_jpip_addxml opj_jpip_test opj_jpip_transcode opj_jpip_viewer opj_server opl2ofm opldecode opmhash opmpack opsis-find-board opsis-manage-firmware opsis-mode-switch opt opt-13 opt-14 opt-15 optcvt optex optgeo optic opticalraytracer optimir optimise optimize2bw optimizegraphics optipng optirun optscript optuna opusdec opusenc opusinfo oqmd2cif or1k-elf-addr2line or1k-elf-ar or1k-elf-as or1k-elf-c++filt or1k-elf-cpp or1k-elf-elfedit or1k-elf-gcc or1k-elf-gcc-ar or1k-elf-gcc-nm or1k-elf-gcc-ranlib or1k-elf-gprof or1k-elf-ld or1k-elf-ld.bfd or1k-elf-nm or1k-elf-objcopy or1k-elf-objdump or1k-elf-ranlib or1k-elf-readelf or1k-elf-size or1k-elf-strings or1k-elf-strip ora2pg ora2pg_scanner orage orc-bugreport orca (1) - a scriptable screen reader orca-dm-wrapper orcc orcus-css-dump orcus-csv orcus-detect orcus-gnumeric orcus-json orcus-mso-encryption orcus-ods orcus-styles-ods orcus-xls-xml orcus-xlsx orcus-xml orcus-yaml orcus-zip-dump order oregano org-ruby org.buddiesofbudgie.budgie-desktop-view org.gnome.PortalTest.Gtk4 organize orientFaceZone original-awk origtargz ormolu orpie orpie-curses-keys orte-clean orte-info orte-server ortecc orted orterun os-apply-config os-collect-config os-config-applier os-faults os-inject-fault os-prober os-refresh-config osage (1) - filter for drawing clustered graphs osb2foxtrot osbf-util osc oscap oscap-chroot oscap-docker oscap-podman oscap-run-sce-script oscap-ssh oscap-vm oscdump oscsend oscsendfile osd_cat osd_clock osdctl osdlyrics osdlyrics-create-lyricsource osdlyrics-daemon osdmaptool osdsh osdshconfig osg2cpp osgSSBO osganalysis osganimate osganimationeasemotion osganimationhardware osganimationmakepath osganimationmorph osganimationnode osganimationskinning osganimationsolid osganimationtimeline osganimationviewer osgarchive osgatomiccounter osgautocapture osgautotransform osgbillboard osgbindlesstext osgblenddrawbuffers osgblendequation osgcallback osgcamera osgcatch osgclip osgcluster osgcompositeviewer osgcomputeshaders osgconv osgcopy osgcubemap osgdatabaserevisions osgdeferred osgdepthpartition osgdepthpeeling osgdistortion osgdrawinstanced osgfadetext osgfilecache osgfont osgforest osgfpdepth osgfxbrowser osggameoflife osggeometry osggeometryshaders osggpucull osggpx osggraphicscost osghangglide osghud osgimagesequence osgimpostor osgintersection osgkdtree osgkeyboard osgkeyboardmouse osgkeystone osglauncher osglight osglightpoint osglogicop osglogo osgmanipulator osgmemorytest osgmlnorm osgmotionblur osgmovie osgmultiplemovies osgmultiplerendertargets osgmultitexture osgmultitexturecontrol osgmultitouch osgmultiviewpaging osgobjectcache osgoccluder osgocclusionquery osgoit osgoscdevice osgoutline osgpackeddepthstencil osgpagedlod osgparametric osgparticle osgparticleeffects osgparticleshader osgpdf osgphotoalbum osgpick osgplanets osgpoints osgpointsprite osgposter osgprecipitation osgprerender osgprerendercubemap osgreflect osgrobot osgsampler osgscalarbar osgscreencapture osgscribe osgsequence osgshadercomposition osgshadergen osgshadermultiviewport osgshaderpipeline osgshaders osgshaderterrain osgshadow osgshape osgsharedarray osgsidebyside osgsimpleMDI osgsimplegl3 osgsimpleshaders osgsimplifier osgsimulation osgslice osgspacewarp osgspheresegment osgspotlight osgstereoimage osgstereomatch osgteapot osgterrain osgtessellate osgtessellationshaders osgtext osgtext3D osgtexture1D osgtexture2D osgtexture2DArray osgtexture3D osgtexturecompression osgtexturerectangle osgthirdpersonview osgthreadedterrain osgtransferfunction osgtransformfeedback osguniformbuffer osgunittests osguserdata osguserstats osgversion osgvertexattributes osgvertexprogram osgviewer osgvirtualprogram osgvolume osgwidgetaddremove osgwidgetbox osgwidgetcanvas osgwidgetframe osgwidgetinput osgwidgetlabel osgwidgetmenu osgwidgetmessagebox osgwidgetnotebook osgwidgetperformance osgwidgetscrolled osgwidgetshader osgwidgetstyled osgwidgettable osgwidgetwindow osgwindows osh oshCC oshc++ oshcc oshcxx oshfort oshmem_info oshrun osinfo-db-export osinfo-db-import osinfo-db-path osinfo-db-validate osinfo-detect osinfo-install-script osinfo-query osirrox osis2mod osk-sdl osken osken-manager oslat oslo-config-generator oslo-config-validator oslo-messaging-send-notification oslo-metrics oslo-rootwrap oslo-rootwrap-daemon oslo_debug_helper oslo_run_cross_tests oslo_run_pre_release_tests oslopolicy-checker oslopolicy-convert-json-to-yaml oslopolicy-list-redundant oslopolicy-policy-generator oslopolicy-policy-upgrade oslopolicy-sample-generator oslopolicy-validator osm2pgrouting osm2pgsql osm2pgsql-replication osmcoastline osmcoastline_filter osmcoastline_readmeta osmcoastline_segments osmcoastline_ways osmconvert osmfilter osmium osmo osmo-arfcn osmo-auc-gen osmo-bsc osmo-bts-omldummy osmo-bts-trx osmo-bts-virtual osmo-euse-demo osmo-ggsn osmo-gtphub osmo-hlr osmo-hlr-db-tool osmo-meas-pcap2db osmo-meas-udp2db osmo-mgw osmo-msc osmo-mslookup-client osmo-pcu osmo-sgsn osmo-stp osmo-trx-lms osmo_sdr osmocom_fft osmocom_siggen_nogui osmosis osmpbf-outline osmupdate osnoise ospam ospcat ospenroll ospent osprofiler osptest osql osra osslsigncode ost ost-compare-structures ostestr ostinato ostree ostree-push ostree-receive ostree-receive-shell osx ot2kpx otTreeInspect otangle otbApplicationLauncherCommandLine otbApplicationLauncherQt otbQgisDescriptor otbTestDriver otbcli otbcli_BandMath otbcli_BandMathX otbcli_BinaryMorphologicalOperation otbcli_BlockMatching otbcli_BundleToPerfectSensor otbcli_ClassificationMapRegularization otbcli_ColorMapping otbcli_CompareImages otbcli_ComputeConfusionMatrix otbcli_ComputeImagesStatistics otbcli_ComputeModulusAndPhase otbcli_ComputeOGRLayersFeaturesStatistics otbcli_ConcatenateImages otbcli_ConcatenateVectorData otbcli_ConnectedComponentSegmentation otbcli_ContrastEnhancement otbcli_ConvertCartoToGeoPoint otbcli_ConvertSensorToGeoPoint otbcli_Despeckle otbcli_DimensionalityReduction otbcli_DisparityMapToElevationMap otbcli_DomainTransform otbcli_DynamicConvert otbcli_EdgeExtraction otbcli_EndmemberNumberEstimation otbcli_ExtractROI otbcli_FastNLMeans otbcli_FineRegistration otbcli_FusionOfClassifications otbcli_GeneratePlyFile otbcli_GrayScaleMorphologicalOperation otbcli_GridBasedImageResampling otbcli_HaralickTextureExtraction otbcli_HomologousPointsExtraction otbcli_HooverCompareSegmentation otbcli_HyperspectralUnmixing otbcli_ImageClassifier otbcli_ImageDimensionalityReduction otbcli_ImageEnvelope otbcli_ImageRegression otbcli_KmzExport otbcli_LSMSSegmentation otbcli_LSMSSmallRegionsMerging otbcli_LSMSVectorization otbcli_LargeScaleMeanShift otbcli_LineSegmentDetection otbcli_LocalRxDetection otbcli_LocalStatisticExtraction otbcli_ManageNoData otbcli_MeanShiftSmoothing otbcli_MorphologicalClassification otbcli_MorphologicalMultiScaleDecomposition otbcli_MorphologicalProfilesAnalysis otbcli_Mosaic otbcli_MultiImageSamplingRate otbcli_MultiResolutionPyramid otbcli_MultivariateAlterationDetector otbcli_OGRLayerClassifier otbcli_OSMDownloader otbcli_ObtainUTMZoneFromGeoPoint otbcli_OrthoRectification otbcli_Pansharpening otbcli_PantexTextureExtraction otbcli_PixelValue otbcli_PolygonClassStatistics otbcli_Quicklook otbcli_RadiometricIndices otbcli_Rasterization otbcli_ReadImageInfo otbcli_Rescale otbcli_ResetMargin otbcli_RigidTransformResample otbcli_SARBurstExtraction otbcli_SARCalibration otbcli_SARConcatenateBursts otbcli_SARDeburst otbcli_SARDecompositions otbcli_SARPolarMatrixConvert otbcli_SARPolarSynth otbcli_SFSTextureExtraction otbcli_SOMClassification otbcli_SampleAugmentation otbcli_SampleExtraction otbcli_SampleSelection otbcli_Segmentation otbcli_SmallRegionsMerging otbcli_Smoothing otbcli_SpectralAngleClassification otbcli_SplitImage otbcli_StereoFramework otbcli_StereoRectificationGridGenerator otbcli_Superimpose otbcli_Synthetize otbcli_TestApplication otbcli_TileFusion otbcli_TrainDimensionalityReduction otbcli_TrainImagesClassifier otbcli_TrainImagesRegression otbcli_TrainRegression otbcli_TrainVectorClassifier otbcli_TrainVectorRegression otbcli_VectorClassifier otbcli_VectorDataExtractROI otbcli_VectorDataReprojection otbcli_VectorDataSetField otbcli_VectorDataTransform otbcli_VectorDimensionalityReduction otbcli_VectorRegression otbcli_VertexComponentAnalysis otbcli_ZonalStatistics otbgui otbgui_BandMath otbgui_BandMathX otbgui_BinaryMorphologicalOperation otbgui_BlockMatching otbgui_BundleToPerfectSensor otbgui_ClassificationMapRegularization otbgui_ColorMapping otbgui_CompareImages otbgui_ComputeConfusionMatrix otbgui_ComputeImagesStatistics otbgui_ComputeModulusAndPhase otbgui_ComputeOGRLayersFeaturesStatistics otbgui_ConcatenateImages otbgui_ConcatenateVectorData otbgui_ConnectedComponentSegmentation otbgui_ContrastEnhancement otbgui_ConvertCartoToGeoPoint otbgui_ConvertSensorToGeoPoint otbgui_Despeckle otbgui_DimensionalityReduction otbgui_DisparityMapToElevationMap otbgui_DomainTransform otbgui_DynamicConvert otbgui_EdgeExtraction otbgui_EndmemberNumberEstimation otbgui_ExtractROI otbgui_FastNLMeans otbgui_FineRegistration otbgui_FusionOfClassifications otbgui_GeneratePlyFile otbgui_GrayScaleMorphologicalOperation otbgui_GridBasedImageResampling otbgui_HaralickTextureExtraction otbgui_HomologousPointsExtraction otbgui_HooverCompareSegmentation otbgui_HyperspectralUnmixing otbgui_ImageClassifier otbgui_ImageDimensionalityReduction otbgui_ImageEnvelope otbgui_ImageRegression otbgui_KmzExport otbgui_LSMSSegmentation otbgui_LSMSSmallRegionsMerging otbgui_LSMSVectorization otbgui_LargeScaleMeanShift otbgui_LineSegmentDetection otbgui_LocalRxDetection otbgui_LocalStatisticExtraction otbgui_ManageNoData otbgui_MeanShiftSmoothing otbgui_MorphologicalClassification otbgui_MorphologicalMultiScaleDecomposition otbgui_MorphologicalProfilesAnalysis otbgui_Mosaic otbgui_MultiImageSamplingRate otbgui_MultiResolutionPyramid otbgui_MultivariateAlterationDetector otbgui_OGRLayerClassifier otbgui_OSMDownloader otbgui_ObtainUTMZoneFromGeoPoint otbgui_OrthoRectification otbgui_Pansharpening otbgui_PantexTextureExtraction otbgui_PixelValue otbgui_PolygonClassStatistics otbgui_Quicklook otbgui_RadiometricIndices otbgui_Rasterization otbgui_ReadImageInfo otbgui_Rescale otbgui_ResetMargin otbgui_RigidTransformResample otbgui_SARBurstExtraction otbgui_SARCalibration otbgui_SARConcatenateBursts otbgui_SARDeburst otbgui_SARDecompositions otbgui_SARPolarMatrixConvert otbgui_SARPolarSynth otbgui_SFSTextureExtraction otbgui_SOMClassification otbgui_SampleAugmentation otbgui_SampleExtraction otbgui_SampleSelection otbgui_Segmentation otbgui_SmallRegionsMerging otbgui_Smoothing otbgui_SpectralAngleClassification otbgui_SplitImage otbgui_StereoFramework otbgui_StereoRectificationGridGenerator otbgui_Superimpose otbgui_Synthetize otbgui_TestApplication otbgui_TileFusion otbgui_TrainDimensionalityReduction otbgui_TrainImagesClassifier otbgui_TrainImagesRegression otbgui_TrainRegression otbgui_TrainVectorClassifier otbgui_TrainVectorRegression otbgui_VectorClassifier otbgui_VectorDataExtractROI otbgui_VectorDataReprojection otbgui_VectorDataSetField otbgui_VectorDataTransform otbgui_VectorDimensionalityReduction otbgui_VectorRegression otbgui_VertexComponentAnalysis otbgui_ZonalStatistics otcldoc otclsh otf2-config otf2-estimator otf2-marker otf2-print otf2-snapshots otf2bdf otfaux otfcompress otfconfig otfdecompress otfdump otfinfo otfinfo-trace otflist otfmerge otfmerge-mpi otfprint otfprofile otfprofile-mpi otfshrink otftobdf otftotfm otfview otp otp2ocp otpclient otpclient-cli otpprint otpw-gen otr_mackey otr_modify otr_parse otr_readforge otr_remac otr_sesskeys ots ots-sanitize otsubtree ott out123 out_to_chain.py outb (2) - port I/O outdeg1count outguess outguess-extract outl (2) - port I/O outocp output outw (2) - port I/O over overBuoyantPimpleDyMFoam overInterDyMFoam overLaplacianDyMFoam overPimpleDyMFoam overPotentialFoam overRhoPimpleDyMFoam overRhoSimpleFoam overSimpleFoam ovf2ovp ovn-appctl ovn-controller ovn-controller-vtep ovn-detrace ovn-docker-overlay-driver ovn-docker-underlay-driver ovn-ic ovn-ic-nbctl ovn-ic-sbctl ovn-nbctl ovn-northd ovn-sbctl ovn-trace ovn_migration.sh ovp2ovf ovs-appctl ovs-docker ovs-dpctl ovs-dpctl-top ovs-l3ping ovs-ofctl ovs-parse-backtrace ovs-pcap ovs-pki ovs-tcpdump ovs-tcpundump ovs-test ovs-testcontroller ovs-vlan-test ovs-vsctl ovsdb-client ovsdb-tool owdir owexist owexternal owfs owftpd owget owhttpd owish owmon owncloud owncloudcmd owpresent owread owserver owtap owusbprobe owwrite oxref oxygen-demo5 oxygen-settings5 oz-cleanup-cache oz-customize oz-generate-icicle oz-install p++ p-link p11-kit (8) - Tool for operating on configured PKCS#11 modules p11tool p2wgui p7content p7env p7sign p7verify p7zip (1) - Wrapper on 7-Zip file archiver with high compression ratio pa-info paargs pacat (1) - Play back or record raw or encoded audio streams on a PulseAudio sound server pacbio-load pack package package-update-indicator package-update-indicator-prefs package_crystalsvg packagesearch packdbf packer packetdiag3 packetforge-ng packeth packetsender packihx packinit packmol packup packxxk pacman pacman-conf pacman-db-upgrade pacman-key pacman4consoleedit pacmd (1) - Reconfigure a PulseAudio sound server during runtime paco2porg pacote pacoxph pacpl pacstrap pactester pactl (1) - Control a running PulseAudio sound server pad-file paddrspacesize pads pads-report padsp (1) - PulseAudio OSS Wrapper padthv1_jack paexec paexec_reorder paf page (3form) - set and get form page number page-crunch pageant pageedit pagein pagekite pages2epub pages2html pages2odt pages2raw pages2text pagesize paho_c_pub paho_c_pub_static paho_c_sub paho_c_sub_static paho_cs_pub paho_cs_pub_static paho_cs_sub paho_cs_sub_static pahole pairToBed pairToPair pair_align pairtools pal pal2nal.pl pal2rgb palbart paleomix palindrome palinear palm-datebook-reminders palmtopnm palogist paltohdf pam_abl pamaddnoise pamaltsat pamarith pambackground pambayer pambrighten pamchannel pamcomp pamcrater pamcut pamdeinterlace pamdepth pamdice pamditherbw pamedge pamendian pamenlarge pamexec pamfile pamfind pamfix pamfixtrunc pamflip pamfunc pamgauss pamgetcolor pamgradient pamhomography pamhue pamix pamixer paml-evolver pamlevels pamlookup pammasksharpen pammixinterlace pammixmulti pammosaicknit pamoil pamon (1) - Play back or record raw or encoded audio streams on a PulseAudio sound server pamp pampaintspill pamperspective pamphletangler pampi pampi-nonfree pampick pampop9 pamrecolor pamrgbatopng pamrubber pamscale pamseq pamshadedrelief pamsharpmap pamsharpness pamsistoaglyph pamslice pamsplit pamstack pamstereogram pamstretch pamstretch-gen pamsumm pamsummcol pamtable pamtester pamthreshold pamtilt pamtoavs pamtodjvurle pamtofits pamtogif pamtohdiff pamtohtmltbl pamtojpeg2k pamtompfont pamtooctaveimg pamtopam pamtopdbimg pamtopfm pamtopng pamtopnm pamtosrf pamtosvg pamtotga pamtotiff pamtouil pamtowinicon pamtoxvmini pamtris pamu2fcfg pamundice pamunlookup pamvalidate pamwipeout pamx pan pan-config pan-control-systems pan-control-systems-dev pan-data-reduction-frameworks pan-data-reduction-frameworks-dev pan-diffraction pan-gid pan-microscopy pan-mx pan-powder pan-small-angle-scattering pan-spectroscopy pan-tomography pan-xas pan_genome_assembly_statistics pan_genome_core_alignment pan_genome_post_analysis pan_genome_reorder_spreadsheet panctl pandoc (1) - general markup converter pandoc-citeproc-preamble pandoc-plantuml pandoc-sidenote panel-daemon panelctl panelui pango-list pango-segmentation pango-view pangoterm panicparse panicweb panko panlogin pano_modify pano_trafo panoinfo panoramisk pantalaimon paperconf (1) - print paper configuration information paperkey paperwork-cli paperwork-gtk paperwork-json papi_avail papi_clockres papi_command_line papi_component_avail papi_cost papi_decode papi_error_codes papi_event_chooser papi_hardware_avail papi_hl_output_writer papi_mem_info papi_multiplex_cost papi_native_avail papi_version papi_xml_event_info paplay (1) - Play back or record raw or encoded audio streams on a PulseAudio sound server pappl-makeresheader paprefs paps par par-archive par2 par2create par2repair par2verify paraclu paraclu-cut.sh paracode parallel parallel-fasta parallel-fastq parallel-fastq-dump parallel-nuke parallel-rsync parallel-scp parallel-slurp parallel-ssh parallel-sums parallel_all_against_all_blastp parallel_blat parallel_cucumber parallel_rna_blat parallel_rspec parallel_spinach parallel_test parasail_aligner parasail_stats paraview paraview-config parcat parcellite parchive parcimonie parec (1) - Play back or record raw or encoded audio streams on a PulseAudio sound server parecord (1) - Play back or record raw or encoded audio streams on a PulseAudio sound server pareorder parfive parform parkill parl parlatype parldyn parley parmed parole (1) - Gstreamer-based media player parrec2nii parse-edid parse-examl parse-mars-request parseAlignment parseSNP parse_xsd2 parseblast parsediasql parser3 parsero parset parsetrigrams parseval parsewiki parsinsert parsnp parsort particleTracks partit2bed.pl partit2gff.pl partitionmanager partx (8) - tell the kernel about the presence and numbering of on-disk partitions pas2fpm-3.2.2 pas2jni-3.2.2 pas2js-3.2.2 pas2ut-3.2.2 pascal_count pasco pasdoc pasmo pass pass-git-helper passenger passenger-config passes-gtk passmass passt passt.avx2 passwd (1) - change user password passwd (1ssl) - OpenSSL application commands passwd (5) - the password file passwd-in-image password-gorilla passwordmaker pasta pasta.avx2 paste (1) - merge lines of files pastebinit paster3 pasteseq pasuspender (1) - Temporarily suspend PulseAudio pasystray pat pat-winlink pat2dat pat2ppm patator patatt patbase patch (1) - apply a diff file to an original patch-hmm.pl patchSummary patchedit patchelf patchperl patchview (1) - Without options, show numbered files modified by the patch. With options, behave as filterdiff. patchwork (1) - filter for drawing clustered graphs as treemaps patcil patclean patcol patdiff patextract patftp patgen path_interpolation.x pathchk (1) - check whether file names are valid or portable pathoc pathod pathspec-rb pathtracer patindex patlog patmake patman patmatdb patmatmotifs patname patnotify patool patpost patran_to_cgns patroni patroni_aws patroni_raft_controller patroni_wale_restore patronictl patscc patsend patsnap patsopt pattrs pauseme pauvre pavucontrol (1) - A volume control for the PulseAudio sound server pavucontrol-qt pavumeter pawplot.x pax11publish (1) - PulseAudio X11 Credential Utility paxtest pbbamify pbdagcon pbget pbibtex pbindex pbindexdump pbm2g3 pbmclean pbmerge pbmlife pbmmake pbmmask pbmminkowski pbmnoise pbmpage pbmpscale pbmreduce pbmtext pbmtextps pbmto10x pbmto4425 pbmtoascii pbmtoatk pbmtobbnbg pbmtocis pbmtocmuwm pbmtodjvurle pbmtoepsi pbmtoepson pbmtoescp2 pbmtog3 pbmtogem pbmtogo pbmtoibm23xx pbmtoicon pbmtojbg pbmtojbg85 pbmtolj pbmtoln03 pbmtolps pbmtomacp pbmtomatrixorbital pbmtomda pbmtomgr pbmtomrf pbmtonokia pbmtopgm pbmtopi3 pbmtopk pbmtoplot pbmtoppa pbmtopsg3 pbmtoptx pbmtosunicon pbmtowbmp pbmtox10bm pbmtoxbm pbmtoybm pbmtozinc pbmupc pbn2dds pbopen pbput pbputs pbr pbs_submit_workers pbsim pbsnodes pbuilder-dist pbuilder-dist-simple pbwtest pbyacc pbzip2 pc-compare pc-makegnuplot pc-project pc1toppm pca pcal pcalendar pcap-config (1) - write libpcap compiler and linker flags to standard output pcap-queryparse pcapdump pcapfix pcapinfo pcapip pcappick pcapreport pcapuc pcatoy pcb-gtk pcb-lesstif pcb-prj2lht pcb-rnd pcb-rnd-svg pcb_calculator pcbasic pcbnew pcc pcc-cpp pcdindex pcdovtoppm pcf2bdf pcf2vpnc pchrt pcl2ttf pcl_add_gaussian_noise pcl_boundary_estimation pcl_cluster_extraction pcl_compute_cloud_error pcl_compute_hausdorff pcl_compute_hull pcl_concatenate_points_pcd pcl_convert_pcd_ascii_binary pcl_converter pcl_convolve pcl_crf_segmentation pcl_crop_to_hull pcl_demean_cloud pcl_dinast_grabber pcl_elch pcl_extract_feature pcl_face_trainer pcl_fast_bilateral_filter pcl_feature_matching pcl_fpfh_estimation pcl_fs_face_detector pcl_generate pcl_gp3_surface pcl_grabcut_2d pcl_grid_min pcl_ground_based_rgbd_people_detector pcl_hdl_grabber pcl_hdl_viewer_simple pcl_icp pcl_icp2d pcl_image_grabber_saver pcl_image_grabber_viewer pcl_in_hand_scanner pcl_linemod_detection pcl_local_max pcl_lum pcl_manual_registration pcl_marching_cubes_reconstruction pcl_match_linemod_template pcl_mesh2pcd pcl_mesh_sampling pcl_mls_smoothing pcl_modeler pcl_morph pcl_multiscale_feature_persistence_example pcl_ndt2d pcl_ndt3d pcl_ni_agast pcl_ni_brisk pcl_ni_linemod pcl_ni_susan pcl_ni_trajkovic pcl_nn_classification_example pcl_normal_estimation pcl_obj2pcd pcl_obj2ply pcl_obj2vtk pcl_obj_rec_ransac_accepted_hypotheses pcl_obj_rec_ransac_hash_table pcl_obj_rec_ransac_model_opps pcl_obj_rec_ransac_orr_octree pcl_obj_rec_ransac_orr_octree_zprojection pcl_obj_rec_ransac_result pcl_obj_rec_ransac_scene_opps pcl_octree_viewer pcl_offline_integration pcl_oni2pcd pcl_oni_viewer pcl_openni2_viewer pcl_openni_3d_concave_hull pcl_openni_3d_convex_hull pcl_openni_boundary_estimation pcl_openni_change_viewer pcl_openni_face_detector pcl_openni_fast_mesh pcl_openni_feature_persistence pcl_openni_grabber_depth_example pcl_openni_grabber_example pcl_openni_ii_normal_estimation pcl_openni_image pcl_openni_klt pcl_openni_mls_smoothing pcl_openni_mobile_server pcl_openni_octree_compression pcl_openni_organized_compression pcl_openni_organized_edge_detection pcl_openni_organized_multi_plane_segmentation pcl_openni_passthrough pcl_openni_pcd_recorder pcl_openni_planar_convex_hull pcl_openni_planar_segmentation pcl_openni_save_image pcl_openni_shift_to_depth_conversion pcl_openni_tracking pcl_openni_uniform_sampling pcl_openni_viewer pcl_openni_voxel_grid pcl_organized_segmentation_demo pcl_outlier_removal pcl_outofcore_print pcl_outofcore_process pcl_outofcore_viewer pcl_passthrough_filter pcl_pcd2ply pcl_pcd2png pcl_pcd2vtk pcl_pcd_change_viewpoint pcl_pcd_convert_NaN_nan pcl_pcd_grabber_viewer pcl_pcd_image_viewer pcl_pcd_introduce_nan pcl_pcd_organized_edge_detection pcl_pcd_organized_multi_plane_segmentation pcl_pcd_select_object_plane pcl_pcd_video_player pcl_pclzf2pcd pcl_plane_projection pcl_ply2obj pcl_ply2pcd pcl_ply2ply pcl_ply2raw pcl_ply2vtk pcl_plyheader pcl_png2pcd pcl_point_cloud_editor pcl_poisson_reconstruction pcl_ppf_object_recognition pcl_progressive_morphological_filter pcl_pyramid_surface_matching pcl_radius_filter pcl_registration_visualizer pcl_sac_segmentation_plane pcl_spin_estimation pcl_statistical_multiscale_interest_region_extraction_example pcl_stereo_ground_segmentation pcl_surfel_smoothing_test pcl_test_search_speed pcl_tiff2pcd pcl_timed_trigger_test pcl_train_linemod_template pcl_train_unary_classifier pcl_transform_from_viewpoint pcl_transform_point_cloud pcl_unary_classifier_segment pcl_uniform_sampling pcl_vfh_estimation pcl_viewer pcl_virtual_scanner pcl_vlp_viewer pcl_voxel_grid pcl_voxel_grid_occlusion_estimation pcl_vtk2obj pcl_vtk2pcd pcl_vtk2ply pcl_xyz2pcd pcm-client pcmanfm (1) - A lightweight Gtk+ based file manager for X Window. pcmanfm-qt pcmanx pcmdiff pcmmix pconsole pconsole-ssh pcp pcp2csv pcp2elasticsearch pcp2graphite pcp2influxdb pcp2json pcp2spark pcp2xlsx pcp2xml pcp2zabbix pcpp pcre-config pcre2-config (1) - program to return PCRE2 configuration pcre2grep pcre2test pcregrep pcsc-spy pcsc_scan pct-scanner-script pct2rgb.py pcxtoppm pd-gem pd-gui pd-gui-plugin pd-iem pd-mapper pda pdb pdb2cif pdb2mdb pdb2pqr pdb2pqr30 pdb3 (1) - the Python debugger pdb3.10 (1) - the Python debugger pdb3.11 (1) - the Python debugger pdb_b pdb_chain pdb_chainbows pdb_chainxseg pdb_chkensemble pdb_delchain pdb_delelem pdb_delhetatm pdb_delinsertion pdb_delres pdb_delresname pdb_element pdb_fetch pdb_fixinsert pdb_fromcif pdb_gap pdb_head pdb_intersect pdb_keepcoord pdb_merge pdb_mkensemble pdb_occ pdb_reatom pdb_reres pdb_rplchain pdb_rplresname pdb_seg pdb_segxchain pdb_selaltloc pdb_selatom pdb_selchain pdb_selelem pdb_selhetatm pdb_selmodel pdb_selres pdb_selresname pdb_selseg pdb_shiftres pdb_sort pdb_splitchain pdb_splitmodel pdb_splitseg pdb_tidy pdb_tocif pdb_tofasta pdb_uniqname pdb_validate pdb_wc pdbedit pdbfixer pdbimgtopam pdbtool pdbtxt2html pdcp pdd pddet pdebuild pdepend pdetach pdf-extract-outline pdf-presenter-console pdf-slatex pdf-slices pdf2brl pdf2dcm pdf2djvu pdf2dsc (1) - generate a PostScript page list of a PDF document pdf2ps (1) - Ghostscript PDF to PostScript translator pdf2svg pdf2txt pdfPlot pdf_presenter_console pdfannotextractor pdfarranger pdfatfi pdfattach (1) - Portable Document Format (PDF) document embedded file creator (version 3.03) pdfbklt pdfbook2 pdfchain pdfclose pdfconcat pdfcrack pdfcrop pdfcslatex pdfcsplain pdfcube pdfdetach (1) - Portable Document Format (PDF) document embedded file extractor (version 3.03) pdfembedfonts pdfetex pdffonts (1) - Portable Document Format (PDF) font analyzer (version 3.03) pdfgrep pdfimages (1) - Portable Document Format (PDF) image extractor (version 3.03) pdfinfo (1) - Portable Document Format (PDF) document information extractor (version 3.03) pdfinfo.cam-pdf pdfjadetex pdfjam pdflatex pdflatex-dev pdflatexpicscale pdfmex pdfmom pdfopen pdfoutline pdfpc pdfposter pdfresurrect pdfrevert pdfroff pdfsam pdfsandwich pdfseparate (1) - Portable Document Format (PDF) page extractor pdfsig (1) - Portable Document Format (PDF) digital signatures tool pdfstamp pdftex pdftex-quiet pdftexi2dvi pdftk.pdftk-java pdftocairo (1) - Portable Document Format (PDF) to PNG/JPEG/TIFF/PDF/PS/EPS/SVG using cairo pdftohtml (1) - program to convert PDF files into HTML, XML and PNG images pdftoipe pdftoppm (1) - Portable Document Format (PDF) to Portable Pixmap (PPM) converter (version 3.03) pdftops (1) - Portable Document Format (PDF) to PostScript converter (version 3.03) pdftosrc pdftotext (1) - Portable Document Format (PDF) to text converter (version 3.03) pdftrimwhite pdfunite (1) - Portable Document Format (PDF) page merger pdfxmltex pdfxup pdict pdiff pdistreport3 pdl pdl2 pdldoc pdlzip pdm pdns_control pdns_notify pdnsutil pdp-config pdp1 pdp10 pdp11 pdp15 pdp4 pdp7 pdp8 pdp9 pdreceive pdsend pdsh pdsh.bin pdtcompose pdtexpand pdtinfo pdtreplace pdtreverse pdtshortestpath pduclient pdvitomp pdvitype pdwtags peakfinder peakidentifier peaks2amp peaks2fixel pear peardev peas-demo pebble pebble-challtestsrv pecan pecl peco pecomato pedigree pedis pedump pee peek peekfd (1) - peek at file descriptors of running processes peet peg peg-go pegjs pegrep pehash peicon pekwm peldd pelican pelican-import pelican-plugins pelican-quickstart pelican-themes pem pen pencil2d penctl penlog penlogd peony peony-qt-desktop pep8-simul pep8_tap pepack pepcoil pepdigest pepinfo pepnet pepstats pepwheel pepwindow pepwindowall percentid percol peres perf perf2bolt-15 perl (1) - The Perl 5 language interpreter perl-depends perl-reversion perl-stacktrace perl2html perl5.36-x86_64-linux-gnu (1) - The Perl 5 language interpreter perl5.36.0 (1) - The Perl 5 language interpreter perl6 perl6-debug perl6-debug-m perl6-gdb-m perl6-lldb-m perl6-m perl6-valgrind-m perl_count perlanet perlbal perlbrew perlbug (1) - how to submit bug reports on Perl perlconsole perlcritic perlcritic_tap perldig perldl perldoc perli11ndoc perlimports perlindex perlivp (1) - Perl Installation Verification Procedure perlprimer perlsh perltex perlthanks (1) - how to submit bug reports on Perl perltidier perltidy perltidy-sweet perlver perlver-fast perm permview perror (1) - explain error codes perror (3) - print a system error message persalys persepolis persist-tool peruse perusecreator pescan pesec pesigcheck pesign pesign-client pestr pesubst petite pev pevent peverify pex pexec pf-localization pf2afm (1) - Make an AFM file from Postscript (PFB/PFA/PFM) font files using ghostscript pfadecrypt pfarrei pfb2pfa pfb2t1c pfbtopfa (1) - Convert Postscript .pfb fonts to .pfa format using ghostscript pfbtops pfc pfcalibrateV3 pfcat pfdump pfemit pffexport pffinfo pfgtop pfhtop pfindex pflags pfm pfmake pfmtopam pfpam pfs_automerge pfs_split_exposures.py pfsabsolute pfscale pfscan pfscanV3 pfscat pfsclamp pfscolortransform pfscut pfsdisplayfunction pfsearch pfsearchV3 pfsextractchannels pfsflip pfsgamma pfsglview pfshdrcalibrate pfsin pfsindcraw pfsinexr pfsinhdrgen pfsinimgmagick pfsinme pfsinpfm pfsinppm pfsinrgbe pfsintiff pfsinyuv pfsoctavelum pfsoctavergb pfsout pfsoutexr pfsouthdrhtml pfsoutimgmagick pfsoutpfm pfsoutppm pfsoutrgbe pfsouttiff pfsoutyuv pfspad pfspanoramic pfsplotresponse pfsretime pfsrotate pfssize pfsstat pfstag pfstmo_drago03 pfstmo_durand02 pfstmo_fattal02 pfstmo_ferradans11 pfstmo_mai11 pfstmo_mantiuk06 pfstmo_mantiuk08 pfstmo_pattanaik00 pfstmo_reinhard02 pfstmo_reinhard05 pfstore pfsv pfsview pfunc pfunct pfw pg2mma pg_activity pg_archivecleanup pg_autoctl pg_backupcluster pg_basebackup pg_bsd_indent pg_buildext pg_cloudconfig pg_comparator pg_config pg_conftool pg_createcluster pg_createconfig_patroni pg_ctlcluster pg_dropcluster pg_dump pg_dumpall pg_format pg_isready pg_ldap_sync pg_lsclusters pg_prove pg_receivewal pg_receivexlog pg_recvlogical pg_renamecluster pg_restore pg_restorecluster pg_tapgen pg_top pg_upgradecluster pg_virtualenv pgagent pgbackrest pgbadger pgbench pgcli pgcluu pgcluu_collectd pgcopydb pgdbf pgen_compress pgiac pglistener pglistener-update pgloader pglobal pgmabel pgmbentley pgmcrater pgmdeshadow pgmedge pgmenhance pgmhist pgmkernel pgmmake pgmmedian pgmminkowski pgmmorphconv pgmnoise pgmnorm pgmodeler pgmodeler-ch pgmodeler-cli pgmodeler-se pgmoil pgmramp pgmslice pgmtexture pgmtofs pgmtolispm pgmtopbm pgmtopgm pgmtoppm pgmtosbig pgmtost4 pgmtoy4m pgn2web pgp-clean pgp-fixkey pgpainless-cli pgpdump pgpgpg pgpring pgqd pgrep (1) - look up, signal, or wait for processes based on name and other attributes pgreplay pgrphack pgsql2shp pgstat pgtopo_export pgtopo_import pgxn pgxnclient pgzf pgzrun ph.x phar.default (1) - PHAR (PHP archive) command line tool phar.phar.default (1) - PHAR (PHP archive) command line tool phar.phar8.1 (1) - PHAR (PHP archive) command line tool phar8.1 (1) - PHAR (PHP archive) command line tool phar8.1.phar (1) - PHAR (PHP archive) command line tool phasertng.HKLviewer phasex phasex-convert-patch phast phastBias phastCons phastMotif phastOdds phat phcg.x phd1994 phenix.HKLinfo phenix.HKLviewer phenix.angle phenix.auto_sharpen phenix.cablam phenix.cablam_idealization phenix.cablam_training phenix.cablam_validate phenix.cbetadev phenix.cc_star phenix.chains_as_models phenix.cif_as_mtz phenix.cif_as_pdb phenix.clashscore phenix.cns_as_mtz phenix.comparama phenix.compare_datasets phenix.csv_as_mtz phenix.data_viewer phenix.diffuse phenix.dynamics phenix.emma phenix.emringer phenix.evalurama phenix.example_viewer phenix.explore_metric_symmetry phenix.f000 phenix.fab_elbow_angle phenix.fake_f_obs phenix.feature_enhanced_map phenix.fem phenix.fest phenix.fetch_pdb phenix.fft phenix.find_peaks_holes phenix.find_reticular_twin_laws phenix.find_tls_groups phenix.fmodel phenix.fobs_minus_fobs_map phenix.form_factor_query phenix.french_wilson phenix.geometry_minimization phenix.grow_density phenix.hbond phenix.helix_sheet_recs_as_pdb_files phenix.image_viewer phenix.kinemage phenix.map_box phenix.map_comparison phenix.map_to_model_histogram phenix.map_to_structure_factors phenix.map_value_at_point phenix.maps phenix.mask phenix.maximum_entropy_map phenix.merging_statistics phenix.model_idealization phenix.model_map phenix.model_model_distances phenix.model_vs_map phenix.model_vs_sequence phenix.models_as_chains phenix.molprobity phenix.mtz.dump phenix.mtz2map phenix.mtz_as_cif phenix.omegalyze phenix.pdb.b_factor_stats phenix.pdb.biomt_reconstruction phenix.pdb.hierarchy phenix.pdb.mtrix_reconstruction phenix.pdb_as_cif phenix.pdb_atom_selection phenix.pdb_editor phenix.pdb_interpretation phenix.pdbtools phenix.perigee phenix.plan_sad_experiment phenix.polder phenix.process_predicted_model phenix.r_factor_statistics phenix.rama_z phenix.ramalyze phenix.rank_scale_map phenix.real_space_correlation phenix.real_space_diff_map phenix.reciprocal_space_arrays phenix.reflection_file_converter phenix.reflection_statistics phenix.reindex phenix.remove_outliers phenix.resolution phenix.rna_validate phenix.rotalyze phenix.secondary_structure_restraints phenix.secondary_structure_validation phenix.segment_and_split_map phenix.sisa phenix.sort_hetatms phenix.suitename phenix.tls phenix.tls_analysis phenix.tls_as_xyz phenix.twin_map_utils phenix.unique_with_biomt phenix.validate_H phenix.xmanip phenix.xtriage pherkin phipack-phi phipack-ppma_2_bmp phipack-profile phits2mcpl phm2helix phm2if phm2pj phmmer phnxdeco phoa2d phoc phod2a phog phononsettings phonopy phonopy-bandplot phonopy-calc-convert phonopy-crystal-born phonopy-gruneisen phonopy-gruneisenplot phonopy-load phonopy-pdosplot phonopy-propplot phonopy-qha phonopy-tdplot phonopy-vasp-born phonopy-vasp-efe phosh phosh-antispam phosh-mobile-settings phosh-tour photocollage photofilmstrip photofilmstrip-cli photoflare photopc photoqt photorec phototonic php-cgi.default php-cgi8.1 php-config.default php-config8.1 php-parse php.default (1) - PHP Command Line Interface 'CLI' php2po php8.1 (1) - PHP Command Line Interface 'CLI' php_count phpab phpabtpl phpcbf phpcpd phpcs phpdbg.default phpdbg8.1 phpdox phpize.default phpize8.1 phplex phploc phpmd phpparse phppo2pypo phpunit phrase-search phylip phyloBoot phyloFit phyloP phylonium phyml phyml-mpi physicalunits physlock phyutility phyview pi pi1toppm pi3topbm pi500_vfd pi_stress pia pianobar pib2xml pibcomp pibdump pibruin pibrump pic (1) - compile pictures for troff or TeX pic2graph pic2plot pic2tpic picard picard-tools pick pickBestPolish pickUniquePolish pickout pico.alpine picocom picolisp picom picom-trans picomus piconv (1) - - iconv(1), reinvented in perl picopore picopore-realtime picopore-rename picopore-test picoproj picosat picosat.trace pid1 pidcat pidgin pidproxy pidstat pidwait (1) - look up, signal, or wait for processes based on name and other attributes piespy pifollowQmerge pig2vcd piggybacker piglit pigs pigz (1) - compress or expand files pike8.0 pil piler2 pilercr pilon pilot pimdataexporter pimdataexporterconsole pimpleFoam pinentry-curses (1) - PIN or pass-phrase entry dialog for GnuPG pinentry-fltk pinentry-gnome3 (1) - PIN or pass-phrase entry dialog for GnuPG pinentry-gtk-2 pinentry-kwallet pinentry-qt pinentry-tty pinentry-x2go pinfo ping_pong pingpongclient pinky (1) - lightweight finger pinot pinot-dbus-daemon pinot-index pinot-label pinot-prefs pinot-search pinout pinpoint pint-convert pinto pintod pinyin pip (1) - A tool for installing and managing Python packages pip-extra-reqs pip-missing-reqs pip3 (1) - A tool for installing and managing Python packages pip3.10 pip_stress pipdeptree pipebench pipemeter pipenv pipenv-resolver piper piper-convert piperka-client pipetty pipewire (1) - The PipeWire media server pipewire-avb pipewire-media-session pipewire-pulse (1) - The PipeWire PulseAudio replacement pipexec pipsi pipx pique-input pique-run pirb pirl pirs pisg pisoFoam pitchmark pitchplay pithos pitivi piuparts_slave_join piuparts_slave_run piuparts_slave_stop piuparts_tap piuparts_wrapper pius pius-keyring-mgr pius-party-worksheet pius-report piv-tool pixelize pixeltool pixiewps pixmap pixz pizzly pizzly_flatten_json.py pj2if pjHinterp pj_dump pj_equals pj_gantt pjinfo pjrec pjtoppm pk12util pk1sign pk2bm pk4 pk4-edith pk4-generate-index pk4-replace pkaction (1) - Get details about a registered action pkann pkannogr pkascii2img pkascii2ogr pkcheck (1) - Check whether a process is authorized pkcomposite pkcon pkcreatect pkcrop pkcs1-conv pkcs11-data pkcs11-dump pkcs11-kek-rewrap pkcs11-key-generation pkcs11-register pkcs11-tool pkcs11_eventmgr pkcs11_inspect pkcs11_listcerts pkcs11_make_hash_link pkcs11_setup pkcs15-crypt pkcs15-init pkcs15-tool pkdiff pkdsm2shadow pkdumpimg pkdumpogr pkegcs pkexec (1) - Execute a command as another user pkextractimg pkextractogr pkfillnodata pkfilter pkfilterascii pkfilterdem pkfix pkfix-helper pkfsann pkfssvm pkg-config (1) - a system for configuring build dependency information pkgconf (1) - a system for configuring build dependency information pkgdata pkgdiff pkgetmask pkginfo pkgjs-audit pkgjs-depends pkgjs-easy-to-update pkgjs-install pkgjs-install-minimal pkgjs-ln pkgjs-ls pkgjs-main pkgjs-pjson pkgjs-run pkgjs-utils pkgkde-debs2symbols pkgkde-gensymbols pkgkde-getbuildlogs pkgkde-git pkgkde-mark-qt5-private-symbols pkgkde-override-sc-dev-latest pkgkde-symbolshelper pkgkde-update-qt-copyright pkgkde-vcs pkgos-add-missing-options pkgos-alioth-new-git pkgos-alternative-bin pkgos-bb pkgos-bop pkgos-bop-jenkins pkgos-check-changelog pkgos-debpypi pkgos-dh_auto_install pkgos-dh_auto_test pkgos-fetch-fake-repo pkgos-fix-config-default pkgos-gen-completion pkgos-gen-systemd-unit pkgos-generate-snapshot pkgos-infra-build-pkg pkgos-infra-install-sbuild pkgos-keyring-package pkgos-merge-templates pkgos-parse-requirements pkgos-readd-keystone-authtoken-missing-options pkgos-reqsdiff pkgos-scan-repo pkgos-setup-sbuild pkgos-show-control-depends pkgos-testr pkgtools pki pkill (1) - look up, signal, or wait for processes based on name and other attributes pkinfo pkkalman pklogin_finder pkmon pkoptsvm pkpolygonize pkreclass pkreclassogr pkregann pksetmask pksieve pkstat pkstatascii pkstatogr pkstatprofile pksvm pksvmogr pktanon pktogf pktools-config pktopbm pkttyagent (1) - Textual authentication helper pktype pkwalify pl pl2link pl2pm (1) - Rough tool to translate Perl4 .pl files to Perl5 .pm modules. pl_editor plac_runner.py placement-api placement-manage placement-status plackup placnet plakativ plakativ-gui plan_avg.x planarity planetfilter planets planetsplitter planetsplitter-slim plank planner plannerarena plantuml plasma-apply-colorscheme plasma-apply-cursortheme plasma-apply-desktoptheme plasma-apply-lookandfeel plasma-apply-wallpaperimage plasma-browser-integration-host plasma-discover plasma-discover-update plasma-interactiveconsole plasma-localegen-helper plasma-open-settings plasma-remotecontrollers plasma-shutdown plasma-systemmonitor plasma_session plasma_waitforname plasmaengineexplorer plasmapkg2 (1) - Install, list, remove Plasma packages plasmashell plasmathemeexplorer plasmawindowed plasmid plasmidID plasmidseeker plasmidspades plasmidspades.py plasmoidviewer plast plastex plastimatch plater platex platex-dev play play_cell playbucket playdv playerctl playerctld playmidi plaympeg plcID plcboot plcdevs plcfwd plcget plchost plchostd plchostd2 plclist plclog plcmdio16 plcmdio32 plcotst plcrate plcrule plcset plcstat plctest plctone plctool plcwait pldd (1) - display dynamic shared objects linked into a process pldes ple-config please pleaseedit plex-3.2.2 plfit plgen plget pline plink plink1 plink1.9 plink2 plinth plipcmd plistutil plmerge plocate plog plogin plookup plot plot-ampliconstats plot-bamstats plot-constellations plot-netperfmeter-results plot-roh.py plot-vcfstats plot3dToFoam plot3d_to_cgns plotCorrelation plotCoverage plotCoverageVsIdentity plotEnrichment plotFingerprint plotHeatmap plotPCA plotProfile plot_rsr plot_tree_graphlan.py plotband.x plotchangelog plotcon ploteig plotfont ploticus plotorf plotproj.x plotquad plotrho.x plotsauce plotwish plotxy plover plover_send_command plp_program plparse plpftp plsense plsense-server-main plsense-server-resolve plsense-server-work plsense-worker-build plsense-worker-find plser plserver plt-games plt-help plt-r5rs plt-r6rs plt-web-server pltcl pltotf plug plugctl plugreport plum pluma plume-creator plutil plxload plyara plymouth plzip pm pm-collect pm-index pm-invert pm-is-supported pm-merge pm-prepare pm-promote pm-refresh pm-stash pm-uninstall pm_which pmacct pmafm pmake pmall pman pmap (1) - report memory map of a process pmap_dirty pmark pmat pmat-cat-svpv pmat-counts pmat-diff pmat-leakreport pmat-list-orphans pmbootstrap pmcat pmccabe pmchart pmcheck pmclient pmclient_fg pmconfirm pmd2odg pmdate pmdbg pmdesc pmdiff pmdk-convert pmdumplog pmdumptext pmempool pmerr pmeth pmevent pmexp pmfind pmfunc pmg pmgenmap pmidi pmie pmie2col pmieconf pmiectl pminclude pminfo pminst pmiostat pmix_info pmixcc pmjson pmlc pmload pmlogcheck pmlogconf pmlogctl pmlogextract pmlogger pmloglabel pmlogmv pmlogpaste pmlogsize pmlogsummary pmls pmmessage pmount pmpath pmpost pmprobe pmpython pmqtest pmquery pmrep pmrepconf pmrna pmsearch pmseries pmsocks pmstat pmstore pmtime pmtrace pmval pmvers pmw pmw.x pmx485 pmx485-test pmxab pmxchords pn pn2pdf pn53x-diagnose pn53x-sam pn53x-tamashell pncconf pnetcdf-config pnetcdf_version png-fix-IDAT-windowsize png-fix-itxt png23d png2ff png2html png2icns png2mng.pl png2pat png2yuv pngcheck pngchunkdesc pngchunks pngcomp pngcp pngcrush pngfix pnginfo pnginspect pngmeta pngnq pngphoon pngquant pngsplit pngtobogl pngtogd pngtogd2 pngtopam pngtopnm pnm2ppa pnmalias pnmarith pnmcat pnmcolormap pnmcomp pnmconvol pnmcrop pnmcut pnmdepth pnmenlarge pnmfile pnmflip pnmgamma pnmhisteq pnmhistmap pnmindex pnminterp pnminvert pnmixer pnmmargin pnmmercator pnmmontage pnmnlfilt pnmnoraw pnmnorm pnmpad pnmpaste pnmpsnr pnmquant pnmquantall pnmremap pnmrotate pnmscale pnmscalefixed pnmshear pnmsmooth pnmsplit pnmstitch pnmtile pnmto565fb pnmtoddif pnmtofiasco pnmtofits pnmtojbig pnmtojpeg pnmtopalm pnmtopclxl pnmtopgm pnmtoplainpnm pnmtopng pnmtopnm pnmtops pnmtorast pnmtorle pnmtosgi pnmtosir pnmtotiff pnmtotiffcmyk pnmtoxwd pnmtoy4m pnscan po2csv po2debconf po2dtd po2flatxml po2html po2ical po2idml po2ini po2json po2moz po2mozlang po2oo po2php po2prop po2rc po2resx po2sub po2symb po2tiki po2tmx po2ts po2txt po2web2py po2wordfast po2xliff po2xmi5 po2xml po2yaml po4a po4a-display-man po4a-display-pod po4a-gettextize po4a-normalize po4a-translate po4a-updatepo poa pob-2250 pob-3119 pob-fec poc-2250 poc-3119 poc-console poc-fec poc-http pocketsphinx_batch pocketsphinx_continuous pocketsphinx_mdef_convert pocklington poclcc poclean pocommentclean pocompendium pocompile poconflicts pocount pocsuite pod-minimumversion pod2docbook pod2html (1) - convert .pod files to .html files pod2latex pod2man (1) - Convert POD data to formatted *roff input pod2markdown pod2pdf pod2projdocs pod2readme pod2rst pod2sdf pod2test pod2texi pod2text (1) - Convert POD data to formatted ASCII text pod2thread pod2usage (1) - print usage messages from embedded pod docs in files pod2wiki pod2xhtml podboat podchecker (1) - check the syntax of POD format documentation files poddiff podebconf-display-po podebconf-report-po podebug podget podgrep podindex podlint podman podman-compose podofobox podofocolor podofocountpages podofocrop podofoencrypt podofogc podofoimg2pdf podofoimgextract podofoimpose podofoincrementalupdates podofomerge podofonooc podofopages podofopdfinfo podofosign podofotxt2pdf podofotxtextract podofouncompress podofoxmp podpath pods pods2html podselect podspell podtoc podtree2html podwebserver poe-gen-tests poeditor poet poetry poezio poezio_logs poff poff.wvdial pofilter pogg-http pogrep poi2osm point_geometry poke polar_channel_construction polari polenum policy-rc.d.fai policyd-client policyd-rate-limit policyd-spf policygentool polish_clusters pollen pollinate poly-11d.x poly-4d.x poly-5d.x poly-6d.x poly.x polyDualMesh polybar polybar-msg polydot polymake polymake-config polymerge polyphone pom2 pom2bp pom2mk pomdump pomerge pomigrate2 pompem pon pon.wvdial ponyprog poolcounterd pooltype pop-tkdesk pop3browser pop_auth popauth popbugs popclient popcon populaterefcache population_template populations popuretext porechop poreencode porestructure poretools porg porgball porousSimpleFoam port-for portal-test-gtk3 portal-test-qt portserver pos2kml posegment posh positionDB pospell posplit post-grohtml postChannel postProcess postahc.x postal-list postats postcss poster posterazor postfixadmin-cli postgresql_autodoc postgreyreport postmark postprocessing_benchmark postw32-3.2.2 postw90.x poswap pot2po potentialFoam potentialFreeSurfaceDyMFoam potentialFreeSurfaceFoam poterminology potool potooledit potrace povray powa-collector powercap-info powercap-set powerd-config powerline powerline-config powerline-daemon powerline-lint powerline-render powerman powerpc-linux-gnu-addr2line powerpc-linux-gnu-ar powerpc-linux-gnu-as powerpc-linux-gnu-c++filt powerpc-linux-gnu-cpp powerpc-linux-gnu-cpp-10 powerpc-linux-gnu-cpp-11 powerpc-linux-gnu-cpp-12 powerpc-linux-gnu-dwp powerpc-linux-gnu-elfedit powerpc-linux-gnu-g++ powerpc-linux-gnu-g++-10 powerpc-linux-gnu-g++-11 powerpc-linux-gnu-g++-12 powerpc-linux-gnu-gcc powerpc-linux-gnu-gcc-10 powerpc-linux-gnu-gcc-11 powerpc-linux-gnu-gcc-12 powerpc-linux-gnu-gcc-ar powerpc-linux-gnu-gcc-ar-10 powerpc-linux-gnu-gcc-ar-11 powerpc-linux-gnu-gcc-ar-12 powerpc-linux-gnu-gcc-nm powerpc-linux-gnu-gcc-nm-10 powerpc-linux-gnu-gcc-nm-11 powerpc-linux-gnu-gcc-nm-12 powerpc-linux-gnu-gcc-ranlib powerpc-linux-gnu-gcc-ranlib-10 powerpc-linux-gnu-gcc-ranlib-11 powerpc-linux-gnu-gcc-ranlib-12 powerpc-linux-gnu-gccgo powerpc-linux-gnu-gccgo-10 powerpc-linux-gnu-gccgo-11 powerpc-linux-gnu-gccgo-12 powerpc-linux-gnu-gcov powerpc-linux-gnu-gcov-10 powerpc-linux-gnu-gcov-11 powerpc-linux-gnu-gcov-12 powerpc-linux-gnu-gcov-dump powerpc-linux-gnu-gcov-dump-10 powerpc-linux-gnu-gcov-dump-11 powerpc-linux-gnu-gcov-dump-12 powerpc-linux-gnu-gcov-tool powerpc-linux-gnu-gcov-tool-10 powerpc-linux-gnu-gcov-tool-11 powerpc-linux-gnu-gcov-tool-12 powerpc-linux-gnu-gdc powerpc-linux-gnu-gdc-10 powerpc-linux-gnu-gdc-11 powerpc-linux-gnu-gdc-12 powerpc-linux-gnu-gfortran powerpc-linux-gnu-gfortran-10 powerpc-linux-gnu-gfortran-11 powerpc-linux-gnu-gfortran-12 powerpc-linux-gnu-gnat powerpc-linux-gnu-gnat-10 powerpc-linux-gnu-gnat-11 powerpc-linux-gnu-gnat-12 powerpc-linux-gnu-gnatbind powerpc-linux-gnu-gnatbind-10 powerpc-linux-gnu-gnatbind-11 powerpc-linux-gnu-gnatbind-12 powerpc-linux-gnu-gnatchop powerpc-linux-gnu-gnatchop-10 powerpc-linux-gnu-gnatchop-11 powerpc-linux-gnu-gnatchop-12 powerpc-linux-gnu-gnatclean powerpc-linux-gnu-gnatclean-10 powerpc-linux-gnu-gnatclean-11 powerpc-linux-gnu-gnatclean-12 powerpc-linux-gnu-gnatfind powerpc-linux-gnu-gnatfind-10 powerpc-linux-gnu-gnatfind-11 powerpc-linux-gnu-gnatgcc powerpc-linux-gnu-gnathtml powerpc-linux-gnu-gnathtml-10 powerpc-linux-gnu-gnathtml-11 powerpc-linux-gnu-gnathtml-12 powerpc-linux-gnu-gnatkr powerpc-linux-gnu-gnatkr-10 powerpc-linux-gnu-gnatkr-11 powerpc-linux-gnu-gnatkr-12 powerpc-linux-gnu-gnatlink powerpc-linux-gnu-gnatlink-10 powerpc-linux-gnu-gnatlink-11 powerpc-linux-gnu-gnatlink-12 powerpc-linux-gnu-gnatls powerpc-linux-gnu-gnatls-10 powerpc-linux-gnu-gnatls-11 powerpc-linux-gnu-gnatls-12 powerpc-linux-gnu-gnatmake powerpc-linux-gnu-gnatmake-10 powerpc-linux-gnu-gnatmake-11 powerpc-linux-gnu-gnatmake-12 powerpc-linux-gnu-gnatname powerpc-linux-gnu-gnatname-10 powerpc-linux-gnu-gnatname-11 powerpc-linux-gnu-gnatname-12 powerpc-linux-gnu-gnatprep powerpc-linux-gnu-gnatprep-10 powerpc-linux-gnu-gnatprep-11 powerpc-linux-gnu-gnatprep-12 powerpc-linux-gnu-gnatxref powerpc-linux-gnu-gnatxref-10 powerpc-linux-gnu-gnatxref-11 powerpc-linux-gnu-gprof powerpc-linux-gnu-ld powerpc-linux-gnu-ld.bfd powerpc-linux-gnu-ld.gold powerpc-linux-gnu-lto-dump-10 powerpc-linux-gnu-lto-dump-11 powerpc-linux-gnu-lto-dump-12 powerpc-linux-gnu-nm powerpc-linux-gnu-objcopy powerpc-linux-gnu-objdump powerpc-linux-gnu-ranlib powerpc-linux-gnu-readelf powerpc-linux-gnu-size powerpc-linux-gnu-strings powerpc-linux-gnu-strip powerpc64-linux-gnu-addr2line powerpc64-linux-gnu-ar powerpc64-linux-gnu-as powerpc64-linux-gnu-c++filt powerpc64-linux-gnu-cpp powerpc64-linux-gnu-cpp-10 powerpc64-linux-gnu-cpp-11 powerpc64-linux-gnu-cpp-12 powerpc64-linux-gnu-dwp powerpc64-linux-gnu-elfedit powerpc64-linux-gnu-g++ powerpc64-linux-gnu-g++-10 powerpc64-linux-gnu-g++-11 powerpc64-linux-gnu-g++-12 powerpc64-linux-gnu-gcc powerpc64-linux-gnu-gcc-10 powerpc64-linux-gnu-gcc-11 powerpc64-linux-gnu-gcc-12 powerpc64-linux-gnu-gcc-ar powerpc64-linux-gnu-gcc-ar-10 powerpc64-linux-gnu-gcc-ar-11 powerpc64-linux-gnu-gcc-ar-12 powerpc64-linux-gnu-gcc-nm powerpc64-linux-gnu-gcc-nm-10 powerpc64-linux-gnu-gcc-nm-11 powerpc64-linux-gnu-gcc-nm-12 powerpc64-linux-gnu-gcc-ranlib powerpc64-linux-gnu-gcc-ranlib-10 powerpc64-linux-gnu-gcc-ranlib-11 powerpc64-linux-gnu-gcc-ranlib-12 powerpc64-linux-gnu-gccgo powerpc64-linux-gnu-gccgo-10 powerpc64-linux-gnu-gccgo-11 powerpc64-linux-gnu-gccgo-12 powerpc64-linux-gnu-gcov powerpc64-linux-gnu-gcov-10 powerpc64-linux-gnu-gcov-11 powerpc64-linux-gnu-gcov-12 powerpc64-linux-gnu-gcov-dump powerpc64-linux-gnu-gcov-dump-10 powerpc64-linux-gnu-gcov-dump-11 powerpc64-linux-gnu-gcov-dump-12 powerpc64-linux-gnu-gcov-tool powerpc64-linux-gnu-gcov-tool-10 powerpc64-linux-gnu-gcov-tool-11 powerpc64-linux-gnu-gcov-tool-12 powerpc64-linux-gnu-gdc powerpc64-linux-gnu-gdc-10 powerpc64-linux-gnu-gdc-11 powerpc64-linux-gnu-gdc-12 powerpc64-linux-gnu-gfortran powerpc64-linux-gnu-gfortran-10 powerpc64-linux-gnu-gfortran-11 powerpc64-linux-gnu-gfortran-12 powerpc64-linux-gnu-gnat powerpc64-linux-gnu-gnat-10 powerpc64-linux-gnu-gnat-11 powerpc64-linux-gnu-gnat-12 powerpc64-linux-gnu-gnatbind powerpc64-linux-gnu-gnatbind-10 powerpc64-linux-gnu-gnatbind-11 powerpc64-linux-gnu-gnatbind-12 powerpc64-linux-gnu-gnatchop powerpc64-linux-gnu-gnatchop-10 powerpc64-linux-gnu-gnatchop-11 powerpc64-linux-gnu-gnatchop-12 powerpc64-linux-gnu-gnatclean powerpc64-linux-gnu-gnatclean-10 powerpc64-linux-gnu-gnatclean-11 powerpc64-linux-gnu-gnatclean-12 powerpc64-linux-gnu-gnatfind powerpc64-linux-gnu-gnatfind-10 powerpc64-linux-gnu-gnatfind-11 powerpc64-linux-gnu-gnatgcc powerpc64-linux-gnu-gnathtml powerpc64-linux-gnu-gnathtml-10 powerpc64-linux-gnu-gnathtml-11 powerpc64-linux-gnu-gnathtml-12 powerpc64-linux-gnu-gnatkr powerpc64-linux-gnu-gnatkr-10 powerpc64-linux-gnu-gnatkr-11 powerpc64-linux-gnu-gnatkr-12 powerpc64-linux-gnu-gnatlink powerpc64-linux-gnu-gnatlink-10 powerpc64-linux-gnu-gnatlink-11 powerpc64-linux-gnu-gnatlink-12 powerpc64-linux-gnu-gnatls powerpc64-linux-gnu-gnatls-10 powerpc64-linux-gnu-gnatls-11 powerpc64-linux-gnu-gnatls-12 powerpc64-linux-gnu-gnatmake powerpc64-linux-gnu-gnatmake-10 powerpc64-linux-gnu-gnatmake-11 powerpc64-linux-gnu-gnatmake-12 powerpc64-linux-gnu-gnatname powerpc64-linux-gnu-gnatname-10 powerpc64-linux-gnu-gnatname-11 powerpc64-linux-gnu-gnatname-12 powerpc64-linux-gnu-gnatprep powerpc64-linux-gnu-gnatprep-10 powerpc64-linux-gnu-gnatprep-11 powerpc64-linux-gnu-gnatprep-12 powerpc64-linux-gnu-gnatxref powerpc64-linux-gnu-gnatxref-10 powerpc64-linux-gnu-gnatxref-11 powerpc64-linux-gnu-gprof powerpc64-linux-gnu-ld powerpc64-linux-gnu-ld.bfd powerpc64-linux-gnu-ld.gold powerpc64-linux-gnu-lto-dump-10 powerpc64-linux-gnu-lto-dump-11 powerpc64-linux-gnu-lto-dump-12 powerpc64-linux-gnu-nm powerpc64-linux-gnu-objcopy powerpc64-linux-gnu-objdump powerpc64-linux-gnu-ranlib powerpc64-linux-gnu-readelf powerpc64-linux-gnu-size powerpc64-linux-gnu-strings powerpc64-linux-gnu-strip powerpc64le-linux-gnu-addr2line powerpc64le-linux-gnu-ar powerpc64le-linux-gnu-as powerpc64le-linux-gnu-c++filt powerpc64le-linux-gnu-cpp powerpc64le-linux-gnu-cpp-10 powerpc64le-linux-gnu-cpp-11 powerpc64le-linux-gnu-cpp-12 powerpc64le-linux-gnu-dwp powerpc64le-linux-gnu-elfedit powerpc64le-linux-gnu-g++ powerpc64le-linux-gnu-g++-10 powerpc64le-linux-gnu-g++-11 powerpc64le-linux-gnu-g++-12 powerpc64le-linux-gnu-gcc powerpc64le-linux-gnu-gcc-10 powerpc64le-linux-gnu-gcc-11 powerpc64le-linux-gnu-gcc-12 powerpc64le-linux-gnu-gcc-ar powerpc64le-linux-gnu-gcc-ar-10 powerpc64le-linux-gnu-gcc-ar-11 powerpc64le-linux-gnu-gcc-ar-12 powerpc64le-linux-gnu-gcc-nm powerpc64le-linux-gnu-gcc-nm-10 powerpc64le-linux-gnu-gcc-nm-11 powerpc64le-linux-gnu-gcc-nm-12 powerpc64le-linux-gnu-gcc-ranlib powerpc64le-linux-gnu-gcc-ranlib-10 powerpc64le-linux-gnu-gcc-ranlib-11 powerpc64le-linux-gnu-gcc-ranlib-12 powerpc64le-linux-gnu-gccgo powerpc64le-linux-gnu-gccgo-10 powerpc64le-linux-gnu-gccgo-11 powerpc64le-linux-gnu-gccgo-12 powerpc64le-linux-gnu-gcov powerpc64le-linux-gnu-gcov-10 powerpc64le-linux-gnu-gcov-11 powerpc64le-linux-gnu-gcov-12 powerpc64le-linux-gnu-gcov-dump powerpc64le-linux-gnu-gcov-dump-10 powerpc64le-linux-gnu-gcov-dump-11 powerpc64le-linux-gnu-gcov-dump-12 powerpc64le-linux-gnu-gcov-tool powerpc64le-linux-gnu-gcov-tool-10 powerpc64le-linux-gnu-gcov-tool-11 powerpc64le-linux-gnu-gcov-tool-12 powerpc64le-linux-gnu-gdc powerpc64le-linux-gnu-gdc-10 powerpc64le-linux-gnu-gdc-11 powerpc64le-linux-gnu-gdc-12 powerpc64le-linux-gnu-gfortran powerpc64le-linux-gnu-gfortran-10 powerpc64le-linux-gnu-gfortran-11 powerpc64le-linux-gnu-gfortran-12 powerpc64le-linux-gnu-gm2 powerpc64le-linux-gnu-gm2-10 powerpc64le-linux-gnu-gm2-11 powerpc64le-linux-gnu-gm2-12 powerpc64le-linux-gnu-gnat powerpc64le-linux-gnu-gnat-10 powerpc64le-linux-gnu-gnat-11 powerpc64le-linux-gnu-gnat-12 powerpc64le-linux-gnu-gnatbind powerpc64le-linux-gnu-gnatbind-10 powerpc64le-linux-gnu-gnatbind-11 powerpc64le-linux-gnu-gnatbind-12 powerpc64le-linux-gnu-gnatchop powerpc64le-linux-gnu-gnatchop-10 powerpc64le-linux-gnu-gnatchop-11 powerpc64le-linux-gnu-gnatchop-12 powerpc64le-linux-gnu-gnatclean powerpc64le-linux-gnu-gnatclean-10 powerpc64le-linux-gnu-gnatclean-11 powerpc64le-linux-gnu-gnatclean-12 powerpc64le-linux-gnu-gnatfind powerpc64le-linux-gnu-gnatfind-10 powerpc64le-linux-gnu-gnatfind-11 powerpc64le-linux-gnu-gnatgcc powerpc64le-linux-gnu-gnathtml powerpc64le-linux-gnu-gnathtml-10 powerpc64le-linux-gnu-gnathtml-11 powerpc64le-linux-gnu-gnathtml-12 powerpc64le-linux-gnu-gnatkr powerpc64le-linux-gnu-gnatkr-10 powerpc64le-linux-gnu-gnatkr-11 powerpc64le-linux-gnu-gnatkr-12 powerpc64le-linux-gnu-gnatlink powerpc64le-linux-gnu-gnatlink-10 powerpc64le-linux-gnu-gnatlink-11 powerpc64le-linux-gnu-gnatlink-12 powerpc64le-linux-gnu-gnatls powerpc64le-linux-gnu-gnatls-10 powerpc64le-linux-gnu-gnatls-11 powerpc64le-linux-gnu-gnatls-12 powerpc64le-linux-gnu-gnatmake powerpc64le-linux-gnu-gnatmake-10 powerpc64le-linux-gnu-gnatmake-11 powerpc64le-linux-gnu-gnatmake-12 powerpc64le-linux-gnu-gnatname powerpc64le-linux-gnu-gnatname-10 powerpc64le-linux-gnu-gnatname-11 powerpc64le-linux-gnu-gnatname-12 powerpc64le-linux-gnu-gnatprep powerpc64le-linux-gnu-gnatprep-10 powerpc64le-linux-gnu-gnatprep-11 powerpc64le-linux-gnu-gnatprep-12 powerpc64le-linux-gnu-gnatxref powerpc64le-linux-gnu-gnatxref-10 powerpc64le-linux-gnu-gnatxref-11 powerpc64le-linux-gnu-gprof powerpc64le-linux-gnu-ld powerpc64le-linux-gnu-ld.bfd powerpc64le-linux-gnu-ld.gold powerpc64le-linux-gnu-lto-dump-10 powerpc64le-linux-gnu-lto-dump-11 powerpc64le-linux-gnu-lto-dump-12 powerpc64le-linux-gnu-nm powerpc64le-linux-gnu-objcopy powerpc64le-linux-gnu-objdump powerpc64le-linux-gnu-ranlib powerpc64le-linux-gnu-readelf powerpc64le-linux-gnu-size powerpc64le-linux-gnu-strings powerpc64le-linux-gnu-strip powerprofilesctl powerstat powersupply-gtk powertop2tuned pp pp-trace-13 pp-trace-14 pp-trace-15 pp.x pp64 pp_simScore ppacf.x ppcx64-3.2.2 ppdc (1) - cups ppd compiler (deprecated) ppdep-3.2.2 ppdfilt ppdhtml (1) - cups html summary generator (deprecated) ppdi (1) - import ppd files (deprecated) ppdmerge (1) - merge ppd files (deprecated) ppdpo (1) - ppd message catalog generator (deprecated) pphs ppi2html ppic ppit ppkg-config ppl-config pplacer pplot ppltotf ppm2mpeg ppm2theora ppm2tiff ppm2video ppm3d ppmbrighten ppmchange ppmcie ppmcolormask ppmcolors ppmcombine ppmd ppmdcfont ppmddumpfont ppmdim ppmdist ppmdither ppmdmkfont ppmdraw ppmfade ppmflash ppmforge ppmglobe ppmhist ppmlabel ppmmake ppmmix ppmnorm ppmntsc ppmpat ppmquant ppmquantall ppmrainbow ppmrelief ppmrough ppmshadow ppmshift ppmspread ppmtoacad ppmtoapplevol ppmtoarbtxt ppmtoascii ppmtobmp ppmtoeyuv ppmtogif ppmtoicr ppmtoilbm ppmtojpeg ppmtoleaf ppmtolj ppmtolss16 ppmtomap ppmtomitsu ppmtompeg ppmtoneo ppmtopcx ppmtopgm ppmtopi1 ppmtopict ppmtopj ppmtopjxl ppmtoppm ppmtopuzz ppmtorgb3 ppmtosixel ppmtospu ppmtoterm ppmtotga ppmtouil ppmtowinicon ppmtoxpm ppmtoxvmini ppmtoy4m ppmtoyuv ppmtoyuvsplit ppmtv ppmwheel pprof-symbolize pprof2calltree pprofile3 pps ppscheck ppsctl ppserver ppsfind ppsh ppsldisc ppstest ppswatch ppt2odp pptemplate ppudump-3.2.2 ppufiles-3.2.2 ppumove-3.2.2 ppx_eliom_client ppx_eliom_server ppx_eliom_types pq_ctndisp pq_ctnnetwork pq_to_hlg pqiv pquery pr (1) - convert text files for printing pr3287 praat praat-open-files praat_nogui praelector pragha prank prctl (2) - operations on a process or thread pre-commit pre-commit-validate-config pre-commit-validate-manifest pre-grohtml pre2ncgm pre2ncgm.prog preamble precat (1) - prefix delta compressor for Aspell precious preconv (1) - convert encoding of input files to something GNU troff understands predictnls prefcnt prefetch prefetch-orig prefield prefix prefix_lines.py prefixadmin prefork-interp preg pregap4 preline.courier prelude-adduser prelude-admin prelude-correlator prelude-lml prelude-lml-rules-check prelude-manager preludedb-admin premailer premake4 prename (1p) - renames multiple files prep prepareAlign prepare_data prepare_missing_cran_package preparetips5 (1) - extract text from tips file prepmx prequest3 prerex presage_demo presage_demo_text presage_simulator present present2md present3D presentty presentty-console pretranslate pretty_table.py prettyping prettyplot prettyseq preunzip (1) - prefix delta compressor for Aspell previsat prezip (1) - prefix delta compressor for Aspell prezip-bin (1) - prefix zip delta word list compressor/decompressor primeDLRS primeDTLSR primeGEM primeGSRf primecount primer3_core primer_designer primersearch primes primesieve primorial primusrun princeprocessor prinseq-graphs prinseq-graphs-noPCA prinseq-graphs-noPCA.pl prinseq-graphs.pl prinseq-lite prinseq-lite.pl print (1) - execute programs via entries in the mailcap file print (3ncurses) - ship binary data to printer printAppVersion printClass print_client print_graph print_header.sh print_mgr print_server print_server_display print_sum printafm (1) - Print the metrics from a Postscript font in AFM format using ghostscript printcal printcbm printcore printemf printenv (1) - print all or part of environment printer-profile printf (1) - format and print data printf (3) - formatted output conversion printforward printmaillist printsextract printtarg prips pristine-bz2 pristine-gz pristine-lfs pristine-orig pristine-tar pristine-xz privoxy-log-parser privoxy-regression-test privsep-helper prlimit (1) - get and set process resource limits prlimit (2) - get/set resource limits vlimit (3) - get/set resource limits prn2ps proalign probabel probabel.pl probalign probcons probcons-RNA probdist probe procServ proc_iomem_count proc_stat_parse proc_stat_signal_decode procan (1) - Multipurpose relay (SOcket CAT) procdump procenv process-tagger-output process_keys process_sample_projects process_test_projects process_viewer procinfo proclint procmail procmeter3 procmeter3-gtk2 procmeter3-gtk3 procmeter3-lcd procmeter3-log procmeter3-xaw procyon proda prodigal prodigy produce prody profanity profbval profcheck profile-sync-daemon profile2map profile2mat profile_diff profile_merger profile_update profiles profilingSummary profisis profit profnet_bval profnet_chop profnet_con profnet_isis profnet_md profnet_norsnet profnet_prof profnet_snapfun profphd_net proftmb progen progendef progress progressiveMauve proguard proguardgui progvis proj project projectAndStrip projectM-jack projectM-pulseaudio projectMSDL projecteur projinfo projsync projwfc.x prok-geneseek prokka prokka-biocyc_to_fasta_db prokka-cdd_to_hmm prokka-clusters_to_hmm prokka-genbank_to_fasta_db prokka-genpept_to_fasta_db prokka-hamap_to_hmm prokka-uniprot_to_fasta_db prolagan prolix promer prometheus prometheus-alertmanager prometheus-apache-exporter prometheus-bind-exporter prometheus-bird-exporter prometheus-blackbox-exporter prometheus-elasticsearch-exporter prometheus-exporter-exporter prometheus-haproxy-exporter prometheus-homeplug-exporter prometheus-ipmi-exporter prometheus-libvirt-exporter prometheus-mongodb-exporter prometheus-mqtt-exporter prometheus-mysqld-exporter prometheus-nextcloud-exporter prometheus-nginx-exporter prometheus-node-exporter prometheus-openstack-exporter prometheus-pgbouncer-exporter prometheus-postfix-exporter prometheus-postgres-exporter prometheus-process-exporter prometheus-proxy prometheus-pushgateway prometheus-redis-exporter prometheus-smokeping-prober prometheus-snmp-exporter prometheus-snmp-generator prometheus-sql-exporter prometheus-squid-exporter prometheus-tplink-plug-exporter prometheus-trafficserver-exporter prometheus-varnish-exporter prometheus-xmpp-alerts promod promoterwise prompt promtool pronsole pronterface pronto2lirc proofgeneral prooftree proot prop2mozfunny prop2po propellor prophecy prophet propka propka3 proptest propwatch proselint prosextract prosody prosody-migrator prosodyctl prot2codon protein-neighbors protein_alignment_from_nucleotides proteinortho proteinortho2html.pl proteinortho2tree.pl proteinortho2xml.pl proteinortho6.pl proteinortho_cleanupblastgraph proteinortho_clustering proteinortho_compareProteinorthoGraphs.pl proteinortho_do_mcl.pl proteinortho_extract_from_graph.pl proteinortho_ffadj_mcs.py proteinortho_formatUsearch.pl proteinortho_grab_proteins.pl proteinortho_graphMinusRemovegraph proteinortho_history.pl proteinortho_singletons.pl proteinortho_summary.pl protobuf-bin-gen-rust-do-not-use protoc protoc-c protoc-gen-beefcake protoc-gen-c protoc-gen-combo protoc-gen-go protoc-gen-go-grpc protoc-gen-go-ttrpc protoc-gen-gofast protoc-gen-gogo protoc-gen-gogofast protoc-gen-gogofaster protoc-gen-gogoslick protoc-gen-gogottrpc protoc-gen-gogotypes protoc-gen-gostring protoc-gen-grpc-gateway protoc-gen-mypy protoc-gen-mypy_grpc protoc-gen-nanopb protoc-gen-rust protoc-gen-swagger protoc-gen-yarpc protoc-min-version protoc-perl protocoltojson protracker prottest proutes3 prov-compare prov-convert prove (1) - Run tests through a TAP harness. prove6 provean proxy (1) - Display the proxy server that should be used to reach a given a network resource proxychains3 proxychains4 proxychains4-daemon proxycheck proxytrack proxytunnel prt prtstat (1) - print statistics of a process pruby prune (1) - Prune directed graphs pruneemptydirs prxs pry ps-watcher ps2ascii (1) - Ghostscript translator from PostScript or PDF to ASCII ps2eps ps2epsi (1) - generate conforming Encapsulated PostScript ps2frag ps2gif ps2lexmark ps2pdf (1) - Convert PostScript to PDF using ghostscript ps2pdf12 (1) - Convert PostScript to PDF 1.2 (Acrobat 3-and-later compatible) using ghostscript ps2pdf13 (1) - Convert PostScript to PDF 1.3 (Acrobat 4-and-later compatible) using ghostscript ps2pdf14 (1) - Convert PostScript to PDF 1.4 (Acrobat 5-and-later compatible) using ghostscript ps2pdfwr (1) - Convert PostScript to PDF without specifying CompatibilityLevel, using ghostscript ps2pk ps2png ps2ps (1) - Ghostscript PostScript "distiller" ps2ps2 ps2ts ps2txt ps4pdf ps_scan.pl psa2msa psautohint psbl psblack psbook psc pscan pscan-tfbs pscan_chip pscap pscp psd psd-overlay-helper psd-tools psdots psdpng-float psensor psensor-server pserve3 pseudo pseudodb pseudolog psf psfaddtable psfex psfgettable psfstriptable psftp psfxtable psgraph pshell3 psi psi-notify psi-plus psi-plus-webkit psi-top psi2log psi3 psi4 psiblast psicc psidtopgm psignifit psin psiphi psjoin psk-crack psk31lx pskc2csv pskc2pskc pskctool pskey psktool psl psl-make-dafsa psl2bed psl2sam.pl psl2starch pslatex pslist pslog (1) - report current logs path of a process psmandup psmerge psmt2-frontend_bin psnotch psnup psort psout pspax pspell-config pspg psplit pspp pspp-convert pspp-dump-sav pspp-output psppire pspresent psql psreport psresize psrip psselect psset psst psstemhist pst2dii pst2ldif pst2pdf pstat psthreads pstoedit pstoepsi pstoimg pstopnm pstops pstree (1) - display a tree of processes pstree.x11 (1) - display a tree of processes psurface-convert psurface-simplify psurface-smooth psusan psw pswdb pswhite pt pt-align pt-archiver pt-config-diff pt-deadlock-logger pt-diskstats pt-duplicate-key-checker pt-fifo-split pt-find pt-fingerprint pt-fk-error-logger pt-heartbeat pt-index-usage pt-ioprofile pt-kill pt-mext pt-mysql-summary pt-online-schema-change pt-pmp pt-query-digest pt-show-grants pt-sift pt-slave-delay pt-slave-find pt-slave-restart pt-stalk pt-summary pt-table-checksum pt-table-sync pt-table-usage pt-tls-client pt-upgrade pt-variable-advisor pt-visual-explain pt2to3 ptable ptangle ptar (1) - a tar-like program written in perl ptardiff (1) - program that diffs an extracted archive against an unextracted one ptargrep (1) - Apply pattern matching to the contents of files in a tar archive ptask ptaskset ptbl (1) - print a type table ptdump ptee pterm ptex ptex2pdf ptftopl ptg-configurator pth-config (1) - Pth library build utility ptiptop ptipython ptipython3 ptipython3.10 ptked (1p) - an editor in Perl/Tk ptksh (1p) - Perl/Tk script to provide a graphical user interface for testing Perl/Tk commands and scripts. pto_gen pto_lensstack pto_mask pto_merge pto_move pto_template pto_var ptof ptoh ptop ptop-3.2.2 ptpython ptpython3 ptpython3.10 ptrepack pts-subscribe pts-unsubscribe ptsb ptscotch_esmumps ptscotch_esmumps-int32 ptscotch_esmumps-int64 ptscotch_esmumps-long ptsctl ptsematest pttree ptunnel-ng ptweens3 ptx (1) - produce a permuted index of file contents ptywrap pua pub2odg pub2raw pub2xhtml publ public-inbox-clone public-inbox-compact public-inbox-convert public-inbox-edit public-inbox-extindex public-inbox-fetch public-inbox-httpd public-inbox-imapd public-inbox-index public-inbox-init public-inbox-learn public-inbox-mda public-inbox-netd public-inbox-nntpd public-inbox-pop3d public-inbox-purge public-inbox-watch public-inbox-xcpdb public_clp_template.sh publican pubpaste pudb pudb3 puddletag puf pull-debian-ddebs pull-debian-debdiff pull-debian-debs pull-debian-source pull-debian-udebs pull-lp-ddebs pull-lp-debs pull-lp-source pull-lp-udebs pull-pkg pull-ppa-ddebs pull-ppa-debs pull-ppa-source pull-ppa-udebs pull-uca-ddebs pull-uca-debs pull-uca-source pull-uca-udebs pulldown-cmark pullimap pullseq pulptest pulsar pulseaudio (1) - The PulseAudio Sound System pulseeffects pulsemixer pulseview puma puma560gui pumactl pumagui pumount pumpa pup puppet puppet-lint pure-pw pure-pwconvert pure-statsdecode puredata purge-old-kernels purge_relay_logs purifyeps purple-remote purple-send purple-send-async purple-url-handler pushpin pushpin-handler pushpin-proxy pushpin-publish pussy put-dns putmail putty puttygen puzzle-diff pv (1) - monitor the progress of data through a pipe pv_export pv_import pval (1) - print BER values in ASN.1 value notation pvanal pvbatch pvbatch3.10 pvbatch3.11 pvdataserver pvfamp pvfcut pvfecho pvffft pvffile pvffilter pvfmix pvfnoise pvfreverse pvfsine pvfspeed pvftoau pvftobasic pvftolin pvftormd pvftovoc pvftowav pviews3 pvkrun pvlook pvm pvm_gstat pvmd pvmgetarch pvmgroups pvmgs pvpython pvpython3.10 pvpython3.11 pvrenderserver pvrg-jpeg pvserver pvtkpython pw-cat (1) - Play and record media with PipeWire pw-cli (1) - The PipeWire Command Line Interface pw-dot (1) - The PipeWire dot graph dump pw-dsdplay pw-dump pw-inspector pw-jack pw-link (1) - The PipeWire Link Command pw-loopback pw-metadata (1) - The PipeWire metadata pw-mididump (1) - The PipeWire MIDI dump pw-midiplay (1) - Play and record media with PipeWire pw-midirecord (1) - Play and record media with PipeWire pw-mon (1) - The PipeWire monitor pw-play (1) - Play and record media with PipeWire pw-profiler (1) - The PipeWire profiler pw-record (1) - Play and record media with PipeWire pw-reserve pw-top (1) - The PipeWire process viewer pw-v4l2 pw.x pw2bgw.x pw2critic.x pw2gw.x pw2wannier90.x pw4gww.x pwait pwcond.x pwdecrypt pwdhash pwdx (1) - report current working directory of a process pweave pweave-convert pwgen pwget pwi2xsf pwi2xsf.x pwiz pwmake pwman3 pwn pwo2xsf pwqcheck pwqfilter pwqgen pwritxnt pwsafe pwscore px px2_configure pxa3xx_dump pxaa2cdn pxbdfit pxbdsim pxboot pxbp pxcat pxclsq pxcltr pxcolt pxcomp pxconsq pxcontrates pxdvi-xaw pxelinux-options pxfqfilt pxlog pxlssq pxlstr pxmono pxmrca pxmrcacut pxmrcaname pxnj pxnw pxplot pxpoly pxrecode pxrevcomp pxrls pxrlt pxrmk pxrms pxrmt pxrr pxs2fa pxs2nex pxs2phy pxseqgen pxssort pxsstat pxstrec pxsw pxt2new pxt2nex pxtcol pxtcomb pxtgen pxtlate pxtrt pxtscale pxupgma pxvcf2fa py py-cpuinfo py.test (1) - pytest usage py.test-3 (1) - pytest usage py2dsc py2dsc-deb py2dsp py3-cmd py3clean (1) - removes .pyc and .pyo files py3compile (1) - byte compile Python 3 source files py3rsa-decrypt py3rsa-encrypt py3rsa-keygen py3rsa-priv2pub py3rsa-sign py3rsa-verify py3status py3versions (1) - print python3 version information py7zr pyFAI-average pyFAI-benchmark pyFAI-calib pyFAI-calib2 pyFAI-diffmap pyFAI-drawmask pyFAI-integrate pyFAI-recalib pyFAI-saxs pyFAI-waxs py_dlt_receive py_filter pyacc-3.2.2 pyacidobasic pyannotate pyasn_util_asnames.py pyasn_util_convert.py pyasn_util_download.py pyav pybabel-python3 pybel pybind11-config pybtex pybtex-convert pybtex-format pybuild pybuild-autopkgtest pycallgraph pycdlib-explorer pycdlib-extract-files pycdlib-genisoimage pychopper pycirkuit pycoQC pycode-browser pycode-browser-book pycodestyle pyconf pycorrfit pycrust pyct pydevd pydf pydicom pydiff pydle pydle-irccat pydoc pydoc3 (1) - the Python documentation tool pydoc3.10 (1) - the Python documentation tool pydoc3.11 (1) - the Python documentation tool pydocstyle pydoctor pyecm pyenigma.py pyensembl pyfastx pyferret3 pyfiglet pyflakes3 pyftmerge pyftsubset pygac-convert-patmosx-coefficients pygac-run pygalmesh pygettext3 (1) - Python equivalent of xgettext(1) pygettext3.10 (1) - Python equivalent of xgettext(1) pygettext3.11 (1) - Python equivalent of xgettext(1) pyghmicons pyghmiutil pyglossary pygmentize (1) - highlights the input file pygmsh-optimize pygrub pygrun pygtail pyhoca-cli pyhoca-gui pyhtmlizer3 pyjoke pyjunitxml pykig.py pykmip-server pykwalify pylama pylint pylint-config pylsp pylupdate5 (1) - create or update Qt Linguist translation files for PyQt5 applications pylupdate6 pymca pymcabatch pymcapostbatch pymcaroitool pymcpltool pymecavideo pyment pymetar pymoctool pymodbus.console pymodbus.server pymol pymolcas pympress pynag pyngcgui pynlpl-computepmi pynlpl-makefreqlist pynlpl-sampler pyocd-flashtool pyocd-gdbserver pyocd-tool pyosmium-get-changes pyosmium-up-to-date pyp pypass pypi-download pypi-install pypi2debian pypo2phppo pyppd pypprint pyprinttags pyprof2calltree pyproj pyproject-build pypublish pypump-shell pypy3 pypy3.8 pypy3clean pypy3compile pyqi pyqso pyraf pyrcc5 (1) - compile Qt resource files for PyQt5 applications pyreverse pyro4-check-config pyro4-flameserver pyro4-httpgateway pyro4-ns pyro4-nsc pyro4-test-echoserver pyroma3 pyroute2-cli pyroute2-dhcp-client pyroute2-test-platform pysassc pysatellites pyscanfcs pyscss pysemver pyserial-miniterm pyserial-ports pyshell pyside2-lupdate pyslices pyslicesshell pysnmpbulkwalk pysnmpget pysnmpset pysnmptranslate pysnmptrap pysnmpwalk pyspf pyspf-milter pyspf-type99 pysph pyspread pyssim pystache3 pysurfer pyterm.py pytest (1) - pytest usage pytest-3 (1) - pytest usage pytest-benchmark pytextile python3.11 (1) - an interpreted, interactive, object-oriented programming language python-argcomplete-check-easy-install-script python-argcomplete-tcsh x86_64-linux-gnu-python3.10-config (1) - output build options for python C/C++ extensions or embedding python-dotenv (1) - .env file manipulator python-gitlab python-mkdebian python-modernize python-semantic-release python-whiteboard python3 (1) - an interpreted, interactive, object-oriented programming language python3-activipy_tester python3-commonmark python3-config (1) - output build options for python C/C++ extensions or embedding python3-coverage python3-cymruwhois python3-dbg python3-dbg-config python3-futurize python3-mprof python3-pasteurize python3-pie python3-qr python3-tor-prompt python3-unidiff python3-unit2 python3.10 (1) - an interpreted, interactive, object-oriented programming language python3.10-config (1) - output build options for python C/C++ extensions or embedding python3.10-coverage python3.10-dbg python3.10-dbg-config python3.10d python3.10d-config python3.11 (1) - an interpreted, interactive, object-oriented programming language python3.11-config python3.11-coverage python3.11-dbg python3.11-dbg-config python3.11d python3.11d-config python3d python3d-config python_count python_package_analyze python_package_cache python_package_create python_package_run pythontex pythran (1) - part of pythran: ahead of time compiler for Python pythran-config (1) - part of pythran: ahead of time compiler for Python pytkdocs pytrainer pyui pyuic5 (1) - compile Qt5 user interfaces to Python code pyuic6 pyuicfg pyupgrade pyvcp pyvcp_demo pyvisa-info pyvisa-shell pyvows pywws-hourly pywws-livelog pywws-livelog-daemon pywws-reprocess pywws-setweatherstation pywws-testweatherstation pywws-version pywxrc pyxplot pyxplot_watch pyzo pyzor pyzor-migrate pyzord pzstd (1) - parallelised Zstandard compression, al la pigz q q2qstar.x q2r.x q4wine q4wine-cli q4wine-helper q65code q65sim qFlipper qFlipper-cli qabc qabcs qacct qalc qalculate-gtk qalter qapitrace qapt-batch qapt-deb-installer qaptworker3 qasconfig qashctl qasmixer qavg qbittorrent qbittorrent-nox qbrew qbs qbs-config qbs-config-ui qbs-create-project qbs-setup-android qbs-setup-qt qbs-setup-toolchains qcalcfilehash qcam qcat qcat-eval qcat-eval-truth qcat-roc qcatool-qt5 qcengine qcmd qcollectiongenerator qcomicbook qconf qconvex qcowinfo qcowmount qcp qcumber qd-config qdacco qdarkstyle qdarkstyle.example qdarkstyle.utils qdbus qdbus-simple-test-runner qdbuscpp2xml qdbusviewer qdbusxml2cpp qdbusxml2cpp-fix qdel qdelaunay qdirstat qdirstat-cache-writer qdl qdmr qdoc qdoc3 qelectrotech qemu-aarch64 qemu-aarch64-static qemu-aarch64_be qemu-aarch64_be-static qemu-alpha qemu-alpha-static qemu-arm qemu-arm-static qemu-armeb qemu-armeb-static qemu-cris qemu-cris-static qemu-hexagon qemu-hexagon-static qemu-hppa qemu-hppa-static qemu-i386 qemu-i386-static qemu-img (1) - QEMU disk image utility qemu-io (1) - QEMU Disk exerciser qemu-loongarch64 qemu-loongarch64-static qemu-m68k qemu-m68k-static qemu-microblaze qemu-microblaze-static qemu-microblazeel qemu-microblazeel-static qemu-mips qemu-mips-static qemu-mips64 qemu-mips64-static qemu-mips64el qemu-mips64el-static qemu-mipsel qemu-mipsel-static qemu-mipsn32 qemu-mipsn32-static qemu-mipsn32el qemu-mipsn32el-static qemu-nbd (8) - QEMU Disk Network Block Device Server qemu-nios2 qemu-nios2-static qemu-or1k qemu-or1k-static qemu-ppc qemu-ppc-static qemu-ppc64 qemu-ppc64-static qemu-ppc64le qemu-ppc64le-static qemu-pr-helper (8) - QEMU persistent reservation helper qemu-riscv32 qemu-riscv32-static qemu-riscv64 qemu-riscv64-static qemu-s390x qemu-s390x-static qemu-sh4 qemu-sh4-static qemu-sh4eb qemu-sh4eb-static qemu-sparc qemu-sparc-static qemu-sparc32plus qemu-sparc32plus-static qemu-sparc64 qemu-sparc64-static qemu-storage-daemon (1) - QEMU storage daemon qemu-system-aarch64 (1) - QEMU User Documentation qemu-system-alpha (1) - QEMU User Documentation qemu-system-arm (1) - QEMU User Documentation qemu-system-avr (1) - QEMU User Documentation qemu-system-cris (1) - QEMU User Documentation qemu-system-hppa (1) - QEMU User Documentation qemu-system-i386 (1) - QEMU User Documentation qemu-system-loongarch64 (1) - QEMU User Documentation qemu-system-m68k (1) - QEMU User Documentation qemu-system-microblaze (1) - QEMU User Documentation qemu-system-microblazeel (1) - QEMU User Documentation qemu-system-mips (1) - QEMU User Documentation qemu-system-mips64 (1) - QEMU User Documentation qemu-system-mips64el (1) - QEMU User Documentation qemu-system-mipsel (1) - QEMU User Documentation qemu-system-nios2 (1) - QEMU User Documentation qemu-system-or1k (1) - QEMU User Documentation qemu-system-ppc (1) - QEMU User Documentation qemu-system-ppc64 (1) - QEMU User Documentation qemu-system-ppc64le (1) - QEMU User Documentation qemu-system-riscv32 (1) - QEMU User Documentation qemu-system-riscv64 (1) - QEMU User Documentation qemu-system-rx (1) - QEMU User Documentation qemu-system-s390x (1) - QEMU User Documentation qemu-system-sh4 (1) - QEMU User Documentation qemu-system-sh4eb (1) - QEMU User Documentation qemu-system-sparc (1) - QEMU User Documentation qemu-system-sparc64 (1) - QEMU User Documentation qemu-system-tricore (1) - QEMU User Documentation qemu-system-x86_64 (1) - QEMU User Documentation qemu-system-x86_64-microvm (1) - QEMU User Documentation qemu-system-xtensa (1) - QEMU User Documentation qemu-system-xtensaeb (1) - QEMU User Documentation qemu-x86_64 qemu-x86_64-static qemu-xtensa qemu-xtensa-static qemu-xtensaeb qemu-xtensaeb-static qepcad qextract qflow qfractalnow qgis qgis.bin qgis_mapserver qgis_process qgis_process.bin qgit qgltf qhalf qhelpconverter qhelpgenerator qhimdtransfer qhold qhost qhull qiime qiime2lefse.py qimgv qiv qjackctl qjackrcd qjoypad qlalr qlcplus qlcplus-fixtureeditor qlipper qlogin qmake qmake6 qmake_sge qmapshack qmaptool qmi-firmware-update (1) - Update firmware in QMI devices qmi-network (1) - Simple network management of QMI devices qmicli (1) - Control QMI devices qmidiarp qmidinet qmidiroute qml qml1plugindump qmlbundle qmlcachegen qmleasing qmlimportscanner qmljs qmllint qmlmin qmlplugindump qmlprofiler qmlscene qmltestrunner qmlviewer qmmp qmmp-1 qmod qmon qmp3check qmp3cut qmp3info qmp3join qmp3report qmt_map2jnx qmt_rgb2pct qmv qnetstatview qoibench qoiconv qosmic qpaeq qpdecode qpdf qpdfview qpdldecode qperf qping qplay qprint qprogram-starter qps qpsmtpd-forkserver qpsmtpd-prefork qpwgraph qquota qqwing qrap qrazercfg qrazercfg-applet qrcode qrcode-terminal qrdel qreator qrencode qrenderdoc qrerun qresub qrls qrouter qrq qrqscore qrsh qrstat qrsub qrterminal qrtest qrtr-cfg qrtr-lookup qrtr-ns qrttoppm qsampler qsched qselect qsexec qsfilter2 qsgrep qsh qshutdown qslog qslogger qspeakers qspng qsrotate qssign qsstv qstail qstardict qstat qstatus qstopmotion qsub qsynth qt-faststart (1) - utility for Quicktime files qt-qconf qt2text qt5ct (1) - Qt5 Configuration Utility qt6ct qta-browser qtar qtattributionsscanner qtbeads qtchooser (1) - a wrapper used to select between Qt development binary versions qtconfig qtcreator qtcsh qtdechunk qtdiag qtdoc qtdump qtel qterm qterminal qtest qthid qthid-2.2 qtikz qtinfo qtltools_plotTrans.R qtltools_runFDR_atrans.R qtltools_runFDR_cis.R qtltools_runFDR_ftrans.R qtop qtox qtpass qtpaths qtpaths6 qtplasmac-cfg2prefs qtplasmac-materials qtplasmac-plasmac2qt qtplasmac_gcode qtplugininfo qtpy qtqr qtractor qtrechunk qtsass qtscrob qtstreamize qtvcp qtxdg-desktop-file-start qtxdg-iconfinder qtxdg-mat qtyuv4toyuv quadrature quakestat qual_offset.py qual_trim.py quality_check quantlib-benchmark quantlib-config quantlib-test-suite quart quassel quasselclient quasselcore quaternion quaternion_motion_blur qube quelcom query-starkd query_pan_genome querybts quest queuelat quickChick quickbook quickcal quickchar quickml-analog quickplot quickplot_shell quickstart quicktree quilt quisk quisk_vna quitcount quiterss quiva2DB qunit-selenium quodlibet (1) - audio library manager and player quorum quorum_create_database quorum_error_correct_reads quota quotasync qutebrowser qutemol quvi qv4l2 qv_to_bqv.py qvgeapp qviaggiatreno qvidcap qvkgen qvlc qvoronoi qwavcut qwavfade qwavheaderdump qwavinfo qwavjoin qwavsilence qwdctl qwo qxgedit qxp2epub qxp2odg qxp2raw qxp2svg qxp2text r r-mpost r-pmpost r-upmpost r10k r2e r2p r2r_show r2test r8tohdf ra rabbitmqadmin rabbitsign rabbitvcs rabema_build_gold_standard rabema_evaluate rabema_prepare_sam rabins racc racc2y racc3.0 racc3.1 rackdiag3 racket rackup racluster raco racon racon_wrapper.py raconvert racount rad_counter radark radclient radcrypt raddebug radeapclient radecode radeontop radicale radio radium_compressor radlast radmrouted radon rados radosgw radosgw-admin radosgw-es radosgw-object-expirer radosgw-token radsniff radsqlrelay radtest radump radwho radzap raevent rafilteraddr ragel ragout ragout-maf2synteny ragout-overlap ragraph ragrep rahisto rahosts rails rainbows rakarrack rakconvert rake rake-compiler rake3.0 rake3.1 rakgit2new raku raku-debug rakudo rakudo-debug rakudo-debug-m rakudo-gdb-m rakudo-lldb-m rakudo-m rakudo-valgrind-m rakverb rakverb2 ralabel rally rambo-k ramdisk-image-create rampler rancid rancid-cvs rancid-run rancid_par randmac random-ip random-path random-word randomBed randomFQ randomGeneSample random_lines.py randomplay randpkt (1) - Random packet generator randtest randverse rangen ranger ranlib (1) - generate an index to an archive ranonymize rapath rapid-photo-downloader rapl-info rapl-set rapmap rapmap_pseudoindex rapmap_pseudomap rapmap_quasiindex rapmap_quasimap rapolicy raports rapper raptor rarcrack rarpwatch ras2ccir601 rascat raservices rasgetpal rasls rasmol-classic rasmol-gtk rasort rasplit rasqal-config rasql rasqlinsert rasqltimeindex rassplit rasstat rastep raster2pgsql rasterio rasterizer (1) - SVG conversion rasterview rastream rastrip rasttopnm rasview ratbagctl ratbagd rate4site rate4site_doublerep ratemplate rateup ratfor ratimerange ratmenu ratop ratpoints ratpoints-debug ratpoison ratt rauc rauserdata rav1e raw-identify raw2hdf raw2psf raw2tiff raw2tostress raw_ethernet_burst_lat raw_ethernet_bw raw_ethernet_fs_rate raw_ethernet_lat raw_n50 raw_to_xgraph rawdns rawlog-edit rawlog-grabber rawshark (1) - Dump and analyze raw pcap data rawtextdump rawtherapee rawtherapee-cli rawtominc rawtopgm rawtoppm rawtran raxmlHPC raxmlHPC-PTHREADS raxmlHPC-PTHREADS-AVX raxmlHPC-PTHREADS-SSE3 razer-gamewrapper razercfg razerd razers razers3 razor-admin razor-check razor-client razor-report razor-revoke rb rbasm rbd rbd-fuse rbd-mirror rbd-nbd rbd-replay rbd-replay-many rbd-replay-prep rbd-target-api rbd-target-gw rbdmap rbeautify rbenv rblcheck rblogin rblsmtpd rbox rbpf-slam rbs3.0 rbs3.1 rbtrace rbwtest rc-alert rc.byron rc2po rcc rcdn rcexplain rchive rcl rcl-dot-resmap.pl rcl-qc rcl-qm.R rcl-relevel.pl rcl-select.pl rcldo.pl rclone rclone-browser rconclt rcongui rconshell rconsole rconsole-user rcopy rcopy-repeatedly rcS (5) - variables that affect the behavior of boot scripts rcs-checkin.xemacs21 rcs2atfs rcsclean rcsdiff rcsmerge rctest (1) - RFCOMM testing rcup rd2 rdacheck rdbg3.1 rdebsums rdesktop rdf2bin rdf2com rdf2dot (1) - A commandline tool for drawing RDF graphs in Graphviz DOT format rdf2ihx rdf2ith rdf2owl rdf2srec rdfdump rdfgraphisomorphism (1) - A commandline tool for testing if RDF graphs are isomorpic rdfind rdflib rdfns rdfpipe (1) - parsing RDF in different formats and serializing the resulting graph to a chosen format rdfproc rdfs2dot (1) - A commandline tool for drawing RDFS Class diagrams in Graphviz DOT format rdic_conv rdiff rdiff-backup rdiff-backup-delete rdiff-backup-fs rdiff-backup-statistics rdiffdir rdiscount rdjpgcom rdma (8) - RDMA tool rdma_client rdma_server rdma_xclient rdma_xserver rdmpro_sniffer rdoc rdoc3.0 rdoc3.1 rdp-alignment rdp-readseq rdp_classifier rds-ctl rdsquashfs rdswap rdx re re-PCR re.pl re2c re2go re2rust reactingFoam reactingHeterogenousParcelFoam reactingMultiphaseEulerFoam reactingParcelFoam reactingTwoPhaseEulerFoam read-filter-redact readPYBase readPYMB read_datamatrix read_fastx.py read_zbar readbin readbootlog (1) - show contents of the boot log, stripping away control characters readbuffer readdna readelf (1) - display information about ELF files readms readmsg.mailutils (1) - print messages. readmult readom readpdf readpe readproctitle readpst readseq readstat readtags readucks realcsh.c realcxxsh.cc realignPolishes realpath (1) - print the resolved path realpath (3) - return the canonicalized absolute pathname reapr rearj (1) - Converts other archive formats to .arj files reaver rebar rebar3 rebaseextract rebind rebound rebuild-pysnmp-mibs rec rec2bin rec2csv rec_control recdel receive recfix recfmt rechaos.pl recinf recins reclass recode recode-sr-latin (1) - convert Serbian text from Cyrillic to Latin script recoder recoll recollindex recollq recon recon-cli recon-ng recon-web reconcile reconstructPar reconstructParMesh record recordio recordmydesktop recountdiff (1) - recompute patch counts and offsets recoverdm recoverjpeg recovermov recsel recset recursive_lower redata redcarpet redcheck redcheck_gmp redcloth redet redfishtool redfishtool.py rediff (1) - fix offsets and counts of a hand-edited diff redir redis-benchmark redis-check-aof redis-check-rdb redis-cli redis-sentinel redis-server redistributePar redland-config redland-db-upgrade rednotebook redraw_maps redshift redshift-gtk reduce-font redund reentry refeature refer refine refineHexMesh refineMesh refineWallLayer refinementLevel reflex reformail reformat.sh reformat_output reformime refseqget refstack-client refurb regconcat regconvert regdiff regedit-stable regenerator regexp-assemble (1p) - Assemble a list of regular expressions from a file regexxer regfexport regfiledump regfiletype regfinfo regfmount regina regina-config regina-engine-config regina-gui regina-python register-python-argcomplete register_feed2toot_app regjsparser reglookup reglookup-recover reglookup-timeline regorge regpatch regshell regsvr32-stable regtree reify reindex reindexdb rejarForAnalysis relational relational-cli relatorio-render relion relion_align_symmetry relion_autopick relion_autopick_mpi relion_convert_star relion_convert_to_tiff relion_convert_to_tiff_mpi relion_ctf_mask_test relion_ctf_refine relion_ctf_refine_mpi relion_ctf_toolbox relion_demodulate relion_display relion_estimate_gain relion_external_reconstruct relion_find_tiltpairs relion_flex_analyse relion_flex_analyse_mpi relion_helix_inimodel2d relion_helix_toolbox relion_image_handler relion_import relion_localsym relion_localsym_mpi relion_manualpick relion_mask_create relion_merge_particles relion_motion_refine relion_motion_refine_mpi relion_mrc2vtk relion_particle_FCC relion_particle_reposition relion_particle_select relion_particle_subtract relion_particle_subtract_mpi relion_particle_symmetry_expand relion_pipeliner relion_plot_delocalisation relion_postprocess relion_postprocess_mpi relion_prepare_subtomo relion_preprocess relion_preprocess_mpi relion_project relion_reconstruct relion_reconstruct_mpi relion_refine relion_refine_mpi relion_reposition relion_run_ctffind relion_run_ctffind_mpi relion_run_motioncorr relion_run_motioncorr_mpi relion_scheduler relion_stack_create relion_star_datablock_ctfdat relion_star_datablock_singlefiles relion_star_datablock_stack relion_star_handler relion_star_loopheader relion_star_plottable relion_star_printtable relion_tiltpair_plot relion_tomo_test reloc65 relpath-3.2.2 rem rem2html rem2pdf rem2ps remake remap remaster-compose remaster-extract remaster-squashfs-editor remctl remhost remind remmina remmina-file-wrapper remmina-gnome remote-fuser remote-logon-config-agent remote-tty remote-viewer remotegv remotetrx remotinator remountresizereiserfs remove-duplicates remove-reprepro-codename removeDuplicate removeFaces removePcrFromMipe removeSbeFromMipe removeSnpFromMipe remove_long_seqs remove_short_seqs remove_tradis_tags remrun remunge rename-flac rename.ul (1) - rename files rename_file.pl renattach render render_expired render_hlg render_list render_msa render_old render_speedtest rendercheck (1) - simple tests of the X Render extension. renderd renderdoccmd renderpdf rendervplblocks renice (1) - alter priority of running processes reniced reno renrot renum renumberMesh reorder-columns reordercap (1) - Reorder input file by timestamp into output file reordertp rep rep-remote rep-xgettext repc repdoc repeat-match repeatmasker-recon repeatoire repetier-host repgen rephrase replace (1) - a string-replacement utility replacekey replacepdfobj reply repmgr repmgrd repo-add repo-elephant repo-remove repo2solv repobench repocutter repomapper repomdxml2solv repopush report-apt-deps-status report-hw reportAlignmentDifferences reportbug repository_checker reposurgeon repotool reprepro reproducible-check reprof reprotest reprounzip reprozip repsnapper repstopdf reptyr requestbackport requestsync reroot rerun rescale_ell rescan-scsi-bus.sh resdataparse reseq reserialize reset (1) - terminal initialization resgen resgen2 resize (1) - set environment and terminal settings to current xterm window size resize-part-image resizecons resizepart (8) - tell the kernel about the new size of a partition resolvconf-admin resolve_stack_dump (1) - resolve numeric stack trace dump to symbols resolvectl resolveip (1) - resolve host name to IP address or vice versa resolvertest resource_monitor resource_proof resperf resperf-report responsemean restclient restic restover restrict restructuredtext-lint reswrap-1.6 resx2po resynth retext retriangulate retrv retry retweet reuse rev (1) - reverse lines characterwise revcomp revelation reverse-depends reverse_markdown revertpdf revfix reviewboard-am revolt revpath revseq rewritepdf rex rexical rexify rexima rexx rezip rfcdiff rfcomm (1) - RFCOMM configuration utility rfcomm-tester rfdump rfigui rfnmz rfnoc_image_builder rg rgb2pat rgb2pct.py rgb3toppm rgbcorrelator rgbmap rgbpaint rgbpm rgfa-findcrisprs rgfa-mergelinear rgfa-simdebruijn rgrep (1) - print lines that match patterns rgw-gap-list rgw-gap-list-comparator rgxg rhash rheolef-config rhino rhino-debugger rhino-jsc rhinote rhoCentralDyMFoam rhoCentralFoam rhoPimpleAdiabaticFoam rhoPimpleFoam rhoPorousSimpleFoam rhoReactingBuoyantFoam rhoReactingFoam rhoSimpleFoam rhost rhythmbox rhythmbox-client ri ri3.0 ri3.1 ribbon rice riemann-client ries rifftree rifiuti rifiuti-vista rifiuti2 rifle rig rigctl rigctlcom rigctld rigmem rigsmtr rigswr rigtestlibusb rime_deployer rime_dict_manager rime_patch rimraf rings3d rio riocp riostream ripdataflac ripflac ripit ripmime ripper ripperX ripperX_plugin_tester ripperx ripser ripser-coeff ris2bib ris2xml ris_gateway riscv64-linux-gnu-addr2line riscv64-linux-gnu-ar riscv64-linux-gnu-as riscv64-linux-gnu-c++filt riscv64-linux-gnu-cpp riscv64-linux-gnu-cpp-10 riscv64-linux-gnu-cpp-11 riscv64-linux-gnu-cpp-12 riscv64-linux-gnu-elfedit riscv64-linux-gnu-g++ riscv64-linux-gnu-g++-10 riscv64-linux-gnu-g++-11 riscv64-linux-gnu-g++-12 riscv64-linux-gnu-gcc riscv64-linux-gnu-gcc-10 riscv64-linux-gnu-gcc-11 riscv64-linux-gnu-gcc-12 riscv64-linux-gnu-gcc-ar riscv64-linux-gnu-gcc-ar-10 riscv64-linux-gnu-gcc-ar-11 riscv64-linux-gnu-gcc-ar-12 riscv64-linux-gnu-gcc-nm riscv64-linux-gnu-gcc-nm-10 riscv64-linux-gnu-gcc-nm-11 riscv64-linux-gnu-gcc-nm-12 riscv64-linux-gnu-gcc-ranlib riscv64-linux-gnu-gcc-ranlib-10 riscv64-linux-gnu-gcc-ranlib-11 riscv64-linux-gnu-gcc-ranlib-12 riscv64-linux-gnu-gccgo riscv64-linux-gnu-gccgo-10 riscv64-linux-gnu-gccgo-11 riscv64-linux-gnu-gccgo-12 riscv64-linux-gnu-gcov riscv64-linux-gnu-gcov-10 riscv64-linux-gnu-gcov-11 riscv64-linux-gnu-gcov-12 riscv64-linux-gnu-gcov-dump riscv64-linux-gnu-gcov-dump-10 riscv64-linux-gnu-gcov-dump-11 riscv64-linux-gnu-gcov-dump-12 riscv64-linux-gnu-gcov-tool riscv64-linux-gnu-gcov-tool-10 riscv64-linux-gnu-gcov-tool-11 riscv64-linux-gnu-gcov-tool-12 riscv64-linux-gnu-gdc riscv64-linux-gnu-gdc-10 riscv64-linux-gnu-gdc-11 riscv64-linux-gnu-gdc-12 riscv64-linux-gnu-gfortran riscv64-linux-gnu-gfortran-10 riscv64-linux-gnu-gfortran-11 riscv64-linux-gnu-gfortran-12 riscv64-linux-gnu-gm2 riscv64-linux-gnu-gm2-10 riscv64-linux-gnu-gm2-11 riscv64-linux-gnu-gm2-12 riscv64-linux-gnu-gnat riscv64-linux-gnu-gnat-10 riscv64-linux-gnu-gnat-11 riscv64-linux-gnu-gnat-12 riscv64-linux-gnu-gnatbind riscv64-linux-gnu-gnatbind-10 riscv64-linux-gnu-gnatbind-11 riscv64-linux-gnu-gnatbind-12 riscv64-linux-gnu-gnatchop riscv64-linux-gnu-gnatchop-10 riscv64-linux-gnu-gnatchop-11 riscv64-linux-gnu-gnatchop-12 riscv64-linux-gnu-gnatclean riscv64-linux-gnu-gnatclean-10 riscv64-linux-gnu-gnatclean-11 riscv64-linux-gnu-gnatclean-12 riscv64-linux-gnu-gnatfind riscv64-linux-gnu-gnatfind-10 riscv64-linux-gnu-gnatfind-11 riscv64-linux-gnu-gnatgcc riscv64-linux-gnu-gnathtml riscv64-linux-gnu-gnathtml-10 riscv64-linux-gnu-gnathtml-11 riscv64-linux-gnu-gnathtml-12 riscv64-linux-gnu-gnatkr riscv64-linux-gnu-gnatkr-10 riscv64-linux-gnu-gnatkr-11 riscv64-linux-gnu-gnatkr-12 riscv64-linux-gnu-gnatlink riscv64-linux-gnu-gnatlink-10 riscv64-linux-gnu-gnatlink-11 riscv64-linux-gnu-gnatlink-12 riscv64-linux-gnu-gnatls riscv64-linux-gnu-gnatls-10 riscv64-linux-gnu-gnatls-11 riscv64-linux-gnu-gnatls-12 riscv64-linux-gnu-gnatmake riscv64-linux-gnu-gnatmake-10 riscv64-linux-gnu-gnatmake-11 riscv64-linux-gnu-gnatmake-12 riscv64-linux-gnu-gnatname riscv64-linux-gnu-gnatname-10 riscv64-linux-gnu-gnatname-11 riscv64-linux-gnu-gnatname-12 riscv64-linux-gnu-gnatprep riscv64-linux-gnu-gnatprep-10 riscv64-linux-gnu-gnatprep-11 riscv64-linux-gnu-gnatprep-12 riscv64-linux-gnu-gnatxref riscv64-linux-gnu-gnatxref-10 riscv64-linux-gnu-gnatxref-11 riscv64-linux-gnu-gprof riscv64-linux-gnu-ld riscv64-linux-gnu-ld.bfd riscv64-linux-gnu-lto-dump-10 riscv64-linux-gnu-lto-dump-11 riscv64-linux-gnu-lto-dump-12 riscv64-linux-gnu-nm riscv64-linux-gnu-objcopy riscv64-linux-gnu-objdump riscv64-linux-gnu-ranlib riscv64-linux-gnu-readelf riscv64-linux-gnu-size riscv64-linux-gnu-strings riscv64-linux-gnu-strip riscv64-unknown-elf-addr2line riscv64-unknown-elf-ar riscv64-unknown-elf-as riscv64-unknown-elf-c++ riscv64-unknown-elf-c++filt riscv64-unknown-elf-cpp riscv64-unknown-elf-elfedit riscv64-unknown-elf-g++ riscv64-unknown-elf-gcc riscv64-unknown-elf-gcc-12.1.0 riscv64-unknown-elf-gcc-ar riscv64-unknown-elf-gcc-nm riscv64-unknown-elf-gcc-ranlib riscv64-unknown-elf-gcov riscv64-unknown-elf-gcov-dump riscv64-unknown-elf-gcov-tool riscv64-unknown-elf-gprof riscv64-unknown-elf-ld riscv64-unknown-elf-ld.bfd riscv64-unknown-elf-lto-dump riscv64-unknown-elf-nm riscv64-unknown-elf-objcopy riscv64-unknown-elf-objdump riscv64-unknown-elf-ranlib riscv64-unknown-elf-readelf riscv64-unknown-elf-size riscv64-unknown-elf-strings riscv64-unknown-elf-strip riseup-vpn rist2rist ristosds ristreceiver ristretto (1) - lightweight picture-viewer for the Xfce desktop environment ristsender ristsrppasswd rivescript rivlogin rivrancid rjoe rkcrc rkdeveloptool rkey rkflashtool rkhunter rkill rkmisc rkpad rkparameters rkparametersblock rkunpack rkunsign rkward rl2sniff rl2tool rlatopam rletopnm rlfe rlm_ippool_tool rlm_sqlippool_tool rlmgr rlock rlog rlogin-cwd rlpq rlpr rlprd rlprm rltraceroute6 rlwrap rmadison rmagic rmail (8) - a Mail Transfer Agent rman rmath rmccmt rmcp rmcp_ping rmcvsdir-3.2.2 rmd160 rmdfile rmdic rmdtopvf rme rmedigicontrol rmeventc rmgdiff rmhist rmidish rmligamarks rmligs-german rmlint rmonitor_poll_example rmonitor_snapshot rmsgcat rmsgfmt rmsginit rmsgmerge rmsk2bed rmsk2starch rmtfs rnaspades rnaspades.py rnbyc rnc2rng rnetclient rnews rngtest rnp rnpkeys rnr-lsi rnr-mast rnr-prune rnr-tii rnx2rtkp ro ro-localization roar-config roarbidir roarcat roarcatplay roarclientpass roarctl roard roardtmf roarfilt roarify roarinterconnect roarlight roarmon roarmonhttp roarphone roarplaylistd roarpluginapplication roarpluginrunner roarradio roarshout roarsin roarsockconnect roartypes roarvio roarvorbis roarvumeter roary roary-create_pan_genome_plots.R roary-pan_genome_reorder_spreadsheet roary-query_pan_genome roary-unique_genes_per_sample robocut robot-map-gui robotic-arm-kinematics robottestingframework-testrunner robustirc-bridge roc-obj roc-obj-extract roc-obj-ls rocket_launcher rocketcea rockhopper rockhoppergui rocm-smi rocm_agent_enumerator rocminfo rocs rods roff2dvi roff2html roff2pdf roff2ps roff2text roff2x roffit rofi rofi-sensible-terminal rofi-theme-selector rofiles-fuse roguenarok-parallel roguenarok-single rollup rolo romcmp romheaders ronn roodi roodi-describe root-tail rootlessctl rootlesskit rootlesskit-docker-proxy rootv ropy roqet ros-discovery ros-map-yaml2mrpt rosbag rosbag2rawlog rosboost-cfg rosbuilder rosclean rosco rosconsole roscore roscreate-pkg rosdep rosdep-source rosdiagnostic rosdistro_build_cache rosdistro_freeze_source rosdistro_migrate_to_rep_141 rosdistro_migrate_to_rep_143 rosdistro_reformat rosegarden rosgraph rosidl rosinstall rosinstall_generator roslaunch roslaunch-complete roslaunch-deps roslaunch-logs roslocate rosmake rosmaster rosmsg rosmsg-proto rosnode rospack rosparam rosrun rosservice rossrv rosstack rostest rostopic rosunit rosversion rosws roswtf rot13 rotarydelta rotate rotateMesh rotatelogs rotctl rotctld rotextract rotix rotp rotter roughness-prefilter rougify route-rnd routel (8) - list routes with pretty output format routine-update routino-router routino-router+lib routino-router+lib-slim routino-router-slim rover rows rox rox-filer rpcclient rpcgen (1) - an RPC protocol compiler rpcinfo rpdcp rpdfcrop rpdump rping rpki-rov rpl rpl8 rplay rplaydsp rpld-codec-helper rpld-ctl rpld-import rpld-listplaylists rpld-listq rpld-next rpld-queueple rpld-setpointer rpld-showplaying rpld-storemgr rpload rpm (8) - RPM Package Manager rpm2archive (8) - Create tar archive from RPM Package Manager (RPM) package. rpm2cpio (8) - Extract cpio archive from RPM Package Manager (RPM) package. rpmbuild (8) - Build RPM Package(s) rpmdb (8) - RPM Database Tool rpmdb2solv rpmdiff rpmemd rpmgraph (8) - Display RPM Package Dependency Graph rpmkeys (8) - RPM Keyring rpmlint rpmmd2solv rpmquery (8) - RPM Package Manager rpms2solv rpmsign (8) - RPM Package Signing rpmspec (8) - RPM Spec Tool rpmverify (8) - RPM Package Manager rpost rppr rpsblast rpsblast+ rpstblastn rptp rpws rpyc_classic rpyc_registry rq rqinfo rqsh rqworker rr rr-collect-symbols rrancid rrd2whisper rrdcached rrdcgi rrdcreate rrdinfo rrdtool rrdupdate rredtool rrenice rrep rrsync (1) - a script to setup restricted rsync users via ssh logins rs rs274 rsakeyfind rsaperf rsass rsbackup rsbackup-graph rsbackup-mount rsbackup-snapshot-hook rsbackup.cron rscreen rsem-bam2readdepth rsem-bam2wig rsem-build-read-index rsem-calculate-credibility-intervals rsem-calculate-expression rsem-control-fdr rsem-extract-reference-transcripts rsem-gen-transcript-plots rsem-generate-data-matrix rsem-generate-ngvector rsem-get-unique rsem-gff3-to-gtf rsem-parse-alignments rsem-plot-model rsem-plot-transcript-wiggles rsem-prepare-reference rsem-preref rsem-refseq-extract-primary-assembly rsem-run-em rsem-run-gibbs rsem-sam-validator rsem-scan-for-paired-end-reads rsem-simulate-reads rsem-synthesis-reference-transcripts rsem-tbam2gbam rsem_perl_utils.pm rsh-redone-rlogin rsh-redone-rsh rsibreak rskeygen rsnapshot rsnapshot-diff rspamadm rspamc rspamd rspamd_stats rspec rspec-puppet-init rspregistrar rspserver rspterminal rss-glx_install rssguard rsstail rst rst-buildhtml rst-lint rst2html rst2html4 rst2html5 rst2latex rst2man rst2md rst2odt rst2odt_prepstyles rst2pdf rst2pseudoxml rst2s5 rst2xetex rst2xml rst_deck rstart (1) - a sample implementation of a Remote Start client rstartd (1) - a sample implementation of a Remote Start rsh helper rstbx.index rstbx.python rstbx.show_build_path rstbx.show_dist_paths rstbx.simage.create rstbx.simage.explore_completeness rstbx.simage.solver rstbx.simage.wx_display rstcheck rstconv-3.2.2 rstpep2html rstream rsurface2kdt rsvg-convert rsync (1) - a fast, versatile, remote (and local) file-copying tool rsync-ssl (1) - a helper script for connecting to an ssl rsync daemon rsync-ssl-tunnel rsyncrypto rsyncrypto_recover rsysinfo rt-4 rt-5 rt-app rt-assets-import-csv-4 rt-assets-import-csv-5 rt-crontool-4 rt-crontool-5 rt-mailgate-4 rt-mailgate-5 rt-migrate-test rt-repeat-ticket rt2 rtags-rc rtags-rdm rtail rtapi_app rtax rtd rtdClient rtdCubeDisplay rtdServer rtf2brl rtin rtkconv_qt rtkget_qt rtklaunch_qt rtknavi_qt rtkplot_qt rtkpost_qt rtkrcv rtl_433 rtl_adsb rtl_biast rtl_eeprom rtl_fm rtl_power rtl_sdr rtl_tcp rtl_test rtla rtlbrowse rtmpdump rtmux rtorrent rtp2264 rtpengine rtpengine-ctl rtpengine-ng-client rtpengine-recording rtpfeed rtrclient rtrdump rtrmon rtsp-server-perl rtstat (8) - unified linux network statistics rtv rtx-comp rtx-decomp rtx-proc rubber rubber-info rubber-lsmod rubber-pipe rubberband rubberband-r3 rubibtex rubikrotation rubiks_cubex rubiks_dikcube rubiks_optimal rubocop ruby ruby-beautify ruby-benchmark-suite ruby-build ruby-gitlab ruby-parse ruby-prof ruby-prof-check-trace ruby-rewrite ruby-standalone ruby3.0 ruby3.1 ruby_count ruby_parse ruby_parse_extract_error rubydns-check rugmentize ruli-getaddrinfo rumakeindex rumur rumur-run run-clang-tidy run-clang-tidy-13 run-clang-tidy-13.py run-clang-tidy-14 run-clang-tidy-14.py run-clang-tidy-15 run-clang-tidy-15.py run-escript3 run-escript3-mpi run-mailcap (1) - execute programs via entries in the mailcap file run-mummer1 run-mummer3 run-ncbi-converter run-on-ac run-on-bat run-roh.pl run-sepp.sh run-singularity run-split-theme-d-program run-theme-d-program run-with-aspell (1) - script to help use GNU Aspell as an ispell replacement runAE runJemboss.sh runMetaBat.sh runPearInstaller runPearMerger runPearPackager run_FastQTL_threaded.py run_abundance.py run_ataqv_example run_chunk.py run_dada.R run_discoSnp++.sh run_discoSnp++_ML.sh run_erl run_gubbins run_mappers run_mapsembler2_pipeline run_mopac7 run_perftest_loopback run_perftest_multi_devices run_resfinder.py run_selftest run_sepp.py run_tipp.py run_tipp_tool.py run_treeshrink.py runalarm runantlr runawk runc runcircos-gui runcon (1) - run command with specified security context rundig runghc runghc-9.0.2 runhaskell runhugs runjmodeltest-cluster runjmodeltest-gui runlim runlock runmirrors runmpj runoverssh runsc runscript runsnake runsnakemem runstat runsv runsvdir runtest runtimeestimator runxlrd (1) - extract data from Microsoft Excel spreadsheet files runzip rup ruptime ruscreen rusers rush-po rushlast rushwho rust-ar rust-clang rust-cov rust-gdb rust-gdbgui rust-ld rust-lld rust-lldb rust-llvm-dwp rust-markdown rust-nm rust-objcopy rust-objdump rust-profdata rust-readobj rust-size rust-strip rustc rustdoc rustdoc-stripper rustfilt rustfmt rusty-tags rva2ofs rvc rvcd rviz rvlc rwall rwho rx rxgettext rxp rxqueue rxrx rxstack rxvt rxvt-unicode rygel (1) - a collection of DLNA/UPnP AV services rygel-preferences rz rzip rzxcheck rzxdump rzxtool s-nail s-tui s3 s3270 s390x-linux-gnu-addr2line s390x-linux-gnu-ar s390x-linux-gnu-as s390x-linux-gnu-c++filt s390x-linux-gnu-cpp s390x-linux-gnu-cpp-10 s390x-linux-gnu-cpp-11 s390x-linux-gnu-cpp-12 s390x-linux-gnu-dwp s390x-linux-gnu-elfedit s390x-linux-gnu-g++ s390x-linux-gnu-g++-10 s390x-linux-gnu-g++-11 s390x-linux-gnu-g++-12 s390x-linux-gnu-gcc s390x-linux-gnu-gcc-10 s390x-linux-gnu-gcc-11 s390x-linux-gnu-gcc-12 s390x-linux-gnu-gcc-ar s390x-linux-gnu-gcc-ar-10 s390x-linux-gnu-gcc-ar-11 s390x-linux-gnu-gcc-ar-12 s390x-linux-gnu-gcc-nm s390x-linux-gnu-gcc-nm-10 s390x-linux-gnu-gcc-nm-11 s390x-linux-gnu-gcc-nm-12 s390x-linux-gnu-gcc-ranlib s390x-linux-gnu-gcc-ranlib-10 s390x-linux-gnu-gcc-ranlib-11 s390x-linux-gnu-gcc-ranlib-12 s390x-linux-gnu-gccgo s390x-linux-gnu-gccgo-10 s390x-linux-gnu-gccgo-11 s390x-linux-gnu-gccgo-12 s390x-linux-gnu-gcov s390x-linux-gnu-gcov-10 s390x-linux-gnu-gcov-11 s390x-linux-gnu-gcov-12 s390x-linux-gnu-gcov-dump s390x-linux-gnu-gcov-dump-10 s390x-linux-gnu-gcov-dump-11 s390x-linux-gnu-gcov-dump-12 s390x-linux-gnu-gcov-tool s390x-linux-gnu-gcov-tool-10 s390x-linux-gnu-gcov-tool-11 s390x-linux-gnu-gcov-tool-12 s390x-linux-gnu-gdc s390x-linux-gnu-gdc-10 s390x-linux-gnu-gdc-11 s390x-linux-gnu-gdc-12 s390x-linux-gnu-gfortran s390x-linux-gnu-gfortran-10 s390x-linux-gnu-gfortran-11 s390x-linux-gnu-gfortran-12 s390x-linux-gnu-gm2 s390x-linux-gnu-gm2-10 s390x-linux-gnu-gm2-11 s390x-linux-gnu-gm2-12 s390x-linux-gnu-gnat s390x-linux-gnu-gnat-10 s390x-linux-gnu-gnat-11 s390x-linux-gnu-gnat-12 s390x-linux-gnu-gnatbind s390x-linux-gnu-gnatbind-10 s390x-linux-gnu-gnatbind-11 s390x-linux-gnu-gnatbind-12 s390x-linux-gnu-gnatchop s390x-linux-gnu-gnatchop-10 s390x-linux-gnu-gnatchop-11 s390x-linux-gnu-gnatchop-12 s390x-linux-gnu-gnatclean s390x-linux-gnu-gnatclean-10 s390x-linux-gnu-gnatclean-11 s390x-linux-gnu-gnatclean-12 s390x-linux-gnu-gnatfind s390x-linux-gnu-gnatfind-10 s390x-linux-gnu-gnatfind-11 s390x-linux-gnu-gnatgcc s390x-linux-gnu-gnathtml s390x-linux-gnu-gnathtml-10 s390x-linux-gnu-gnathtml-11 s390x-linux-gnu-gnathtml-12 s390x-linux-gnu-gnatkr s390x-linux-gnu-gnatkr-10 s390x-linux-gnu-gnatkr-11 s390x-linux-gnu-gnatkr-12 s390x-linux-gnu-gnatlink s390x-linux-gnu-gnatlink-10 s390x-linux-gnu-gnatlink-11 s390x-linux-gnu-gnatlink-12 s390x-linux-gnu-gnatls s390x-linux-gnu-gnatls-10 s390x-linux-gnu-gnatls-11 s390x-linux-gnu-gnatls-12 s390x-linux-gnu-gnatmake s390x-linux-gnu-gnatmake-10 s390x-linux-gnu-gnatmake-11 s390x-linux-gnu-gnatmake-12 s390x-linux-gnu-gnatname s390x-linux-gnu-gnatname-10 s390x-linux-gnu-gnatname-11 s390x-linux-gnu-gnatname-12 s390x-linux-gnu-gnatprep s390x-linux-gnu-gnatprep-10 s390x-linux-gnu-gnatprep-11 s390x-linux-gnu-gnatprep-12 s390x-linux-gnu-gnatxref s390x-linux-gnu-gnatxref-10 s390x-linux-gnu-gnatxref-11 s390x-linux-gnu-gprof s390x-linux-gnu-ld s390x-linux-gnu-ld.bfd s390x-linux-gnu-ld.gold s390x-linux-gnu-lto-dump-10 s390x-linux-gnu-lto-dump-11 s390x-linux-gnu-lto-dump-12 s390x-linux-gnu-nm s390x-linux-gnu-objcopy s390x-linux-gnu-objdump s390x-linux-gnu-ranlib s390x-linux-gnu-readelf s390x-linux-gnu-size s390x-linux-gnu-strings s390x-linux-gnu-strip s3acl s3backer s3cl s3cmd s3curl s3d s3d_x11gate s3dfm s3dosm s3dvt s3fs s3gdump s3get s3ls s3mkbucket s3put s3rm s3rmbucket s4cmd s5 s51 s51dude s6-accessrules-cdb-from-fs s6-accessrules-fs-from-cdb s6-applyuidgid s6-cleanfifodir s6-connlimit s6-envdir s6-envuidgid s6-fdholder-daemon s6-fdholder-delete s6-fdholder-getdump s6-fdholder-list s6-fdholder-retrieve s6-fdholder-setdump s6-fdholder-store s6-fdholder-transferdump s6-fdholderd s6-fghack s6-ftrig-listen s6-ftrig-listen1 s6-ftrig-notify s6-ftrig-wait s6-ftrigrd s6-ioconnect s6-ipcclient s6-ipcserver s6-ipcserver-access s6-ipcserver-socketbinder s6-ipcserverd s6-log s6-mkfifodir s6-notifyoncheck s6-permafailon s6-setlock s6-setsid s6-setuidgid s6-socklog s6-softlimit s6-sudo s6-sudoc s6-sudod s6-supervise s6-svc s6-svdt s6-svdt-clear s6-svlink s6-svlisten s6-svlisten1 s6-svok s6-svperms s6-svscan s6-svscanctl s6-svstat s6-svunlink s6-svwait s6-tai64n s6-tai64nlocal s6-usertree-maker s6lockd s9 s9advgen s9c2html s9cols s9dupes s9edoc s9help s9htmlify s9hts s9resolve s9scm2html s9scmpp s9soccat sa-awl sa-check_spamd sa-compile sa-config sa-heatu sa-learn sa-update saaldump sac2mseed sacc sacct sacct-emulator sacctmgr sacctmgr-emulator sachesi sada sadf sadisplay sadt safe-rm safe_yaml safecat safecopy safeeyes safelease saga_cmd saga_gui sagan sagenb-export-python3 sahara-all sahara-api sahara-db-manage sahara-engine sahara-image-pack sahara-rootwrap sahara-status sahara-templates sahara-wsgi-api saidar sailcut saint-int-ctrl saint-reformat saint-spc-ctrl saint-spc-noctrl saint-spc-noctrl-matrix sak sakura salloc salloc-emulator salmon salsa salt-factories salt-pepper sam-dump sam-dump-orig sam-stats sam2bed sam2starch sam2vcf.pl samba-regedit samba-tool sambamba samblaster samclip samdump2 samlsign samosa.join samosa.scale samp_hub tc-sample (8) - packet sampling tc action sample2markers.py sample_decode sample_encode sample_merger sample_multi_transcode sample_reads sample_vpp samplv1_jack samtools samtools.pl sancov sancov-13 sancov-14 sancov-15 sandbox sane-find-scanner (1) - find SCSI and USB scanners and their device files sanstats sanstats-13 sanstats-14 sanstats-15 sapserver sar.sysstat sar2pcp sarg sas_disk_blink sasl-sample-client saslfinger sasm sass sass-convert sass-spec sass2css sassc sasview sat4j satpy_retrieve_all_aux_data sats sattach sattach-emulator sauce-bwlist sauce-setuserpolicy sav save save-param save2aecg save2gdf save2scp save_binary_logs savelog (8) - save a log file saveme savi sawfish sawfish-about sawfish-client sawfish-config sawfish-kde4-session sawfish-kde5-session sawfish-lumina-session sawfish-mate-session sawfish-xfce-session sawriter saxfr saxon-xslt saxonb-xquery saxonb-xslt say sayonara sayonara-ctl sayonara-query saytime sb sbatch sbatch-emulator sbattach sbcast sbcast-emulator sbcdec sbcenc sbcinfo sbcl sbe2mipe sbigtopgm sbiload sbkeysync sbmt sbsiglist sbsign sbtedit sbtool sbuild sbuild-abort sbuild-apt sbuild-checkpackages sbuild-clean sbuild-createchroot sbuild-debian-developer-setup sbuild-distupgrade sbuild-hold sbuild-qemu sbuild-qemu-boot sbuild-qemu-create sbuild-qemu-update sbuild-shell sbuild-unhold sbuild-update sbuild-upgrade sbuildlogs-summarise sbvarsign sbverify sbws sc sc-config sc-hsm-tool sc-im sc-libtool sc-mkf77sym sc_ally sc_analysis_dump sc_attach sc_bdrmap sc_erosprober sc_filterpolicy sc_ipiddump sc_pinger sc_prefixscan sc_radargun sc_remoted sc_speedtrap sc_tbitblind sc_tbitpmtud sc_tracediff sc_ttlexp sc_warts2json sc_warts2pcap sc_warts2text sc_wartscat sc_wartsdump sc_wartsfilter scado scafc scaffold scalarTransportFoam scale scale-to-fit scalebar scalene scalpel scamp scamper scan scan-build scan-build-13 scan-build-14 scan-build-15 scan-build-py-13 scan-build-py-14 scan-build-py-15 scan-copyrights scan-perl-prereqs scan-perl-prereqs-nqlite scan-view scan-view-13 scan-view-14 scan-view-15 scan_gbrowse scan_ibrav.x scan_mojibake scanadf scancel scancel-emulator scancodump scancotodicom scandeps (1p) - Scan file prerequisites scanelf scanimage (1) - scan an image scanin scanmacho scanmem scanssh scantool scantv scanwise scanwise_server scap-as-rpm scap-driver-loader scapy scapy3 scaragui scat sccainfo sccmap (1) - extract strongly connected components of directed graphs sccs sccstat scdd scdd_gmp scdoc scel2org scel2org5 scepclient scepserver scf_dump scf_info scf_update scfg_make scfg_parse scfg_test scfg_train schedrmt schedtool schedule schema-salad-doc schema-salad-tool schema2example schema2ldif scheme-elk scheme-ieee-1178-1990 scheme-r4rs scheme-r5rs scheme-r5rs.scheme48 scheme-srfi-0 scheme-srfi-7.scheme48 scheme48 scheme48-config schismtracker schleuder schleuder-api-daemon schleuder-cli schroot schubmult schwartzmon scide science-biology science-chemistry science-config science-dataacquisition science-dataacquisition-dev science-datamanagement science-distributedcomputing science-economics science-electrophysiology science-engineering science-engineering-dev science-financial science-geography science-geometry science-highenergy-physics science-highenergy-physics-dev science-imageanalysis science-imageanalysis-dev science-linguistics science-logic science-machine-learning science-mathematics science-mathematics-dev science-meteorology science-meteorology-dev science-nanoscale-physics science-nanoscale-physics-dev science-neuroscience-cognitive science-neuroscience-modeling science-numericalcomputation science-physics science-physics-dev science-presentation science-psychophysics science-robotics science-robotics-dev science-simulations science-statistics science-typesetting science-viewing science-viewing-dev science-workflow scilab scilab-adv-cli scilab-bin scilab-cli scilab-cli-bin scim scim-config-agent scim-im-agent scim-make-table scim-setup scinotes sciplot-realtime sciplot-xyplot scitbx.apply_tapenade_hints scitbx.generate_error_h scitbx.histogram scitbx.python scitbx.show_build_path scitbx.show_dist_paths scitbx.show_exp_times scitbx.show_sizes scitbx.unicode_examples scite sciteproj scitokens-create scitokens-list-access scitokens-test scitokens-test-access scitokens-verify scl2trd sclang scls scluster scmp_sys_resolver scncopy sco-tester scoary scoary_GUI scolasync scomp scons scons-configure-cache sconsign scontrol scontrol-emulator scopen scopparse scor2prt scorbot-er-3 scoreAlignment score_conservation scot scotch_esmumps scotch_esmumps-int32 scotch_esmumps-int64 scotch_esmumps-long scotch_gbase scotch_gbase-int32 scotch_gbase-int64 scotch_gbase-long scotch_gmap scotch_gmap-int32 scotch_gmap-int64 scotch_gmap-long scotch_gpart scotch_gpart-int32 scotch_gpart-int64 scotch_gpart-long scour scp (1) - OpenSSH secure file copy scp-dbus-service scp1 scpr scqref scram scram-gui scram_flagstat scram_merge scram_pileup scram_test scramble scramble_fasta.pl scrappie scrappie-avx scrappie-avx2 scrappie-plain scrappie-sse2 scrappie-sse3 scrappie-sse4.1 scrappie-ssse3 scrappy scrapy scratch screed screen (1) - screen manager with VT100/ANSI terminal emulation screen-ir screendump screenfetch screengrab screenie screenkey screentest scribble scribus scrip_check_input script (1) - make typescript of terminal session scriptindex scriptingclient scriptingcontrol scriptingserviceexample scriptlive (1) - re-run session typescripts, using timing information scriptor scriptreplay (1) - play back typescripts, using timing information scriv scrm scrobbler scrobbler-helper scrollz scrollz-2.2.3 scrot scrub scrub-files scrypt scsi_ch_swp scsi_logging_level scsi_mandat scsi_readcap scsi_ready scsi_satl scsi_start scsi_stop scsi_temperature scsi_vendor scsort scss scsynth sctk sctp_darn sctp_status sctp_test scythe sd (4) - driver for SCSI disk drives sd-c sd-eng sd-engf sd2epub sd2odf sd2raw sd2svg sd2text sdar sdas390 sdas6808 sdas8051 sdasgb sdaspdk13 sdaspdk14 sdaspdk15 sdasrab sdasstm8 sdastlcs90 sdasz80 sdate sdb sdc2csv sdcc sdcdb sdcpp sdcv sddm sddm-greeter sddmthemeinstaller sdf sdf-to-smi sdf_add_cod_data sdfapi sdfbatch sdfcli sdfget sdgen sdiag sdiag-emulator sdif2ad sdiff (1) - side-by-side merge of file differences sdig sdkmanager sdkserver sdl-config sdl2-config sdlBasic sdlBrt sdld sdld6808 sdldgb sdldpdk sdldstm8 sdldz80 sdmem sdngen sdnm sdobjcopy sdoc sdoc-merge sdop sdownload sdpa sdparm sdpb sdptool (1) - control and interrogate SDP servers sdram sdranlib sdrcomp sds sdsdump sdw2html sdw2odt seaf-cli seaf-daemon seafile-applet seahorse seahorse-daemon search++ search-ccsb search-citeseer search_overview searchd searchmonkey searchtool searpc-codegen searx-checker searx-run seascope seatd-launch seaview sec seccure-decrypt seccure-dh seccure-encrypt seccure-key seccure-sign seccure-signcrypt seccure-veridec seccure-verify sechecker secil2conf secil2tree secilc secon secpanel secrecy secret-tool secrets secsipidx sectosupp securefs secutil sed_count sediff sedparse sedsed sedta see (1) - execute programs via entries in the mailcap file seealso seeded-in-ubuntu seedtop seedtop+ seek_script seeman seer seetxt seewbmp seg-fault segemehl segmasker seinfo seinfoflow select-default-iwrap (1) - Selects the user default ispell dictionary for use with ispell-wrapper select-editor (1) - select your default sensible-editor from all installed editors selectCells select_all_rbcontig.pl select_best_rbcontig.pl select_best_rbcontig_plus_read1.pl select_sec_rbcontig.pl selektor selfserv selfsign-getcert selftest selftest_example selftest_rostest selint sem semind semodule_expand semodule_link semodule_package semodule_unpackage semver sen send-gcode send-reminders send2trash sendEmail send_image send_osc send_results send_study sendemail sendfax sendfile (2) - transfer data between file descriptors sendip sendiso sendkeys sendmsg (2) - send a message on a socket sendpage sendsms sendxmpp senlin-api senlin-conductor senlin-engine senlin-health-manager senlin-manage senlin-status senlin-wsgi-api sensible-browser (1) - sensible web browsing sensible-editor (1) - sensible editing sensible-pager (1) - sensible paging sensors (1) - print sensors information sensors-conf-convert (8) - sensors configuration conversion sent sentineldl sentinelsat sepdebugcrcfix (1) - fixes CRC for separate .debug files sepl sepol_check_access sepol_compute_av sepol_compute_member sepol_compute_relabel sepol_validate_transition sepolgen sepolgen-ifgen sepolgen-ifgen-attr-helper sepolicy seq (1) - print a sequence of numbers seq24 seq_cache_populate.pl seqalign seqan-needle seqan_tcoffee seqcount seqdb_perf seqdiag3 seqdiff seqfraggle seqkit seqkit-benchmark seqmagick seqmatchall seqnr seqprep seqret seqretsetall seqretsplit seqsearch seqsero seqsero_batch_pair-end seqsort seqsplit seqstat seqtk sequel sequin seqwords seqxref seqxrefget ser-player serdi serf serverspec-init serverspec-runner servertell servicemenuinstaller sesearch sessionmirror.py sessreg (1) - manage utmpx/wtmpx entries for non-init clients sestatus setAlphaField setBfree setBfreeUI setBugDatabaseInfo setExprBoundaryFields setExprFields setFields setSet set_show_service set_unicharset_properties setarch (8) - change reported architecture in new program environment and/or set personality flags setbrlkeys setcifsacl setdest setfattr setfdprm setfondname setforward setfx sethdlc sethead seticons setkeycodes setleds setlock setlogcons setmaillist setmetamode setop setpci (8) - configure PCI devices setpdfbackground setpdfmetadata setpdfpage setpib setpix setpriv (1) - run a program with different Linux privilege settings setreg setsToZones setsid (1) - run a program in a new session setsid (2) - creates a session and sets the process group ID setstyle setterm (1) - set terminal attributes setuid (2) - set user identity setuidgid setup-packaging-environment setup-plt setup-theme-d-bootstrap-env setup-theme-d-test-env setupdvbstreamer setvtrgb setxkbmap (1) - set the keyboard using the X Keyboard Extension setzer sexp-conv seyon seyon-emu sf2dump sf2extract sf2text sf3convert sfactor sfarkxtc sfcapd sfcgal-config sfconf sfconv sfconvert sfddiff sfdp (1) - filter for drawing large undirected graphs sfetch sff-dump sff2g3 sfftobmp sffview sfill sfind sfinfo sfmtcvt sfnt2woff sfnt2woff-zopfli sfparse sfront sfte sftovkb sftp (1) - OpenSSH secure file transfer sftp-admin sftp-kill sftp-state sftp-user sftp-verif sftp-who sfv-hash sfxload sfxr-qt sfxtest sg (1) - execute command as different group ID sg_bg_ctl sg_compare_and_write sg_copy_results sg_dd sg_decode_sense sg_emc_trespass sg_format sg_get_config sg_get_elem_status sg_get_lba_status sg_ident sg_inq sg_logs sg_luns sg_map sg_map26 sg_modes sg_opcodes sg_persist sg_prevent sg_raw sg_rbuf sg_rdac sg_read sg_read_attr sg_read_block_limits sg_read_buffer sg_read_long sg_readcap sg_reassign sg_referrals sg_rep_pip sg_rep_zones sg_requests sg_reset sg_reset_wp sg_rmsn sg_rtpg sg_safte sg_sanitize sg_sat_identify sg_sat_phy_event sg_sat_read_gplog sg_sat_set_features sg_scan sg_seek sg_senddiag sg_ses sg_ses_microcode sg_start sg_stpg sg_stream_ctl sg_sync sg_test_rwbuf sg_timestamp sg_turs sg_unmap sg_verify sg_vpd sg_wr_mode sg_write_buffer sg_write_long sg_write_same sg_write_verify sg_write_x sg_xcopy sg_zone sga sga-align sga-astat sga-bam2de sga-mergeDriver sga2bed sga2fps.pl sga2gff.pl sga2wig sgb_to_gtdb_profile.py sgclean sge-disable-submits sge-enable-submits sge_submit_makeflow sge_submit_workers sgen sgf2dg sgfsplit sgidispatch sginfo sgitopnm sgm_dd sgml-spell-checker sgml2html sgml2info sgml2latex sgml2lyx sgml2rtf sgml2txt sgml2xml-isoent sgmlcheck sgmldiff sgmlsasp sgmlspl sgp_dd sgrep sgsnemu sh-elf-addr2line sh-elf-ar sh-elf-as sh-elf-c++filt sh-elf-cpp sh-elf-elfedit sh-elf-gcc sh-elf-gcc-12 sh-elf-gcc-ar sh-elf-gcc-nm sh-elf-gcc-ranlib sh-elf-gcov sh-elf-gcov-dump sh-elf-gcov-tool sh-elf-gprof sh-elf-ld sh-elf-ld.bfd sh-elf-lto-dump sh-elf-nm sh-elf-objcopy sh-elf-objdump sh-elf-ranlib sh-elf-readelf sh-elf-run sh-elf-size sh-elf-strings sh-elf-strip sh2amp sh2peaks sh2power sh2response sh4-linux-gnu-addr2line sh4-linux-gnu-ar sh4-linux-gnu-as sh4-linux-gnu-c++filt sh4-linux-gnu-cpp sh4-linux-gnu-cpp-10 sh4-linux-gnu-cpp-11 sh4-linux-gnu-cpp-12 sh4-linux-gnu-elfedit sh4-linux-gnu-g++ sh4-linux-gnu-g++-10 sh4-linux-gnu-g++-11 sh4-linux-gnu-g++-12 sh4-linux-gnu-gcc sh4-linux-gnu-gcc-10 sh4-linux-gnu-gcc-11 sh4-linux-gnu-gcc-12 sh4-linux-gnu-gcc-ar sh4-linux-gnu-gcc-ar-10 sh4-linux-gnu-gcc-ar-11 sh4-linux-gnu-gcc-ar-12 sh4-linux-gnu-gcc-nm sh4-linux-gnu-gcc-nm-10 sh4-linux-gnu-gcc-nm-11 sh4-linux-gnu-gcc-nm-12 sh4-linux-gnu-gcc-ranlib sh4-linux-gnu-gcc-ranlib-10 sh4-linux-gnu-gcc-ranlib-11 sh4-linux-gnu-gcc-ranlib-12 sh4-linux-gnu-gcov sh4-linux-gnu-gcov-10 sh4-linux-gnu-gcov-11 sh4-linux-gnu-gcov-12 sh4-linux-gnu-gcov-dump sh4-linux-gnu-gcov-dump-10 sh4-linux-gnu-gcov-dump-11 sh4-linux-gnu-gcov-dump-12 sh4-linux-gnu-gcov-tool sh4-linux-gnu-gcov-tool-10 sh4-linux-gnu-gcov-tool-11 sh4-linux-gnu-gcov-tool-12 sh4-linux-gnu-gdc-10 sh4-linux-gnu-gdc-11 sh4-linux-gnu-gfortran sh4-linux-gnu-gfortran-10 sh4-linux-gnu-gfortran-11 sh4-linux-gnu-gfortran-12 sh4-linux-gnu-gnat sh4-linux-gnu-gnat-10 sh4-linux-gnu-gnat-11 sh4-linux-gnu-gnat-12 sh4-linux-gnu-gnatbind sh4-linux-gnu-gnatbind-10 sh4-linux-gnu-gnatbind-11 sh4-linux-gnu-gnatbind-12 sh4-linux-gnu-gnatchop sh4-linux-gnu-gnatchop-10 sh4-linux-gnu-gnatchop-11 sh4-linux-gnu-gnatchop-12 sh4-linux-gnu-gnatclean sh4-linux-gnu-gnatclean-10 sh4-linux-gnu-gnatclean-11 sh4-linux-gnu-gnatclean-12 sh4-linux-gnu-gnatfind sh4-linux-gnu-gnatfind-10 sh4-linux-gnu-gnatfind-11 sh4-linux-gnu-gnatgcc sh4-linux-gnu-gnathtml sh4-linux-gnu-gnathtml-10 sh4-linux-gnu-gnathtml-11 sh4-linux-gnu-gnathtml-12 sh4-linux-gnu-gnatkr sh4-linux-gnu-gnatkr-10 sh4-linux-gnu-gnatkr-11 sh4-linux-gnu-gnatkr-12 sh4-linux-gnu-gnatlink sh4-linux-gnu-gnatlink-10 sh4-linux-gnu-gnatlink-11 sh4-linux-gnu-gnatlink-12 sh4-linux-gnu-gnatls sh4-linux-gnu-gnatls-10 sh4-linux-gnu-gnatls-11 sh4-linux-gnu-gnatls-12 sh4-linux-gnu-gnatmake sh4-linux-gnu-gnatmake-10 sh4-linux-gnu-gnatmake-11 sh4-linux-gnu-gnatmake-12 sh4-linux-gnu-gnatname sh4-linux-gnu-gnatname-10 sh4-linux-gnu-gnatname-11 sh4-linux-gnu-gnatname-12 sh4-linux-gnu-gnatprep sh4-linux-gnu-gnatprep-10 sh4-linux-gnu-gnatprep-11 sh4-linux-gnu-gnatprep-12 sh4-linux-gnu-gnatxref sh4-linux-gnu-gnatxref-10 sh4-linux-gnu-gnatxref-11 sh4-linux-gnu-gprof sh4-linux-gnu-ld sh4-linux-gnu-ld.bfd sh4-linux-gnu-lto-dump-10 sh4-linux-gnu-lto-dump-11 sh4-linux-gnu-lto-dump-12 sh4-linux-gnu-nm sh4-linux-gnu-objcopy sh4-linux-gnu-objdump sh4-linux-gnu-ranlib sh4-linux-gnu-readelf sh4-linux-gnu-size sh4-linux-gnu-strings sh4-linux-gnu-strip sh5util sh_count sha1cdsum sha1deep sha1pass sha1sum (1) - compute and check SHA1 message digest sha224sum (1) - compute and check SHA224 message digest sha256 sha256deep sha256sum (1) - compute and check SHA256 message digest sha384 sha384sum (1) - compute and check SHA384 message digest sha3sum sha512 sha512sum (1) - compute and check SHA512 message digest shairplay shairport-sync shake shallowWaterFoam shanty shape shapeclustering shapeindex shapeit4 shapeit4.2 shapes shar shares-admin sharesec sharkd shasta shasum (1) - Print or Check SHA Checksums shbasis shc shc08 shcomp93 (1) - compile a ksh93 shell script shconv shed sheet2pcp shell-quote shellcheck shellcheck_tap shelldap shellex shellinaboxd shelltest shelr shelxle shfmt shib-metagen shiboken2 shiftBed shim shindo shindont shineenc shiny-server shisa shishi shjs shlibsign shmemCC shmemc++ shmemcc shmemcxx shmemfort shmemrun shmidcat shncat shncmp shnconv shncue shnfix shngen shnhash shninfo shnjoin shnlen shnpad shnsplit shnstrip shntool shntrim shodan shoelaces shoogle shortuuid shotcut shotwell shout shovill show-aligns show-coords show-diff show-shared-extents show-snps show-tiling show_all_colors show_dpu show_filecount showalign showchar showconsolefont showdb showfeat showfigfonts showfond showfont showfoto showinfilemanager showjournal showkey showorf showpep showq showrgb (1) - display an rgb color-name database showriff showseq showserver showstat4 showtable showtableinfo showtablelock showtree showttf showwal shp2pgsql shp_doctor shp_sanitize shpadd shpcat shpcentrd shpcreate shpdata shpdump shpdxf shpfix shpinfo shprewind shpsort shptree shptreedump shptreetst shptreevis shputils shpwkb shred (1) - overwrite a file to hide its contents, and optionally delete it shrink_width shrinksafe shtab shtool shtoolize shuf (1) - generate random permutations shuffle shuffleBed shuffle_reads shuffleseq shunit2 shush shutter shuttle shview siac siad sial sic sick sickle siconvert sid2wav sidcon sidedoor sidekiq sidekiqmon sidplay sidplay2 sidplayfp siege siege.config siege2csv sieve (1) - a mail filtering tool. sieve-connect sieve-dump sieve-filter sieve-test sievec sieveeditor sieveshell sift siftool sig-list-to-certs sig2dot sig2fv sigcensus sigcleave sigfilter sigfind (1) - Find a binary signature in a file siggen sightcalibrator sightrun sightviewer sigil siglevdetcal sigma sigmon sign-efi-sig-list signal-rr-recording signalgen signaltest signapk signcode signify signon-ui signond signonpluginprocess signtool signtos signver sigrok-cli sigscan sigtool sigviewer sigwaittest silent silentjack silex silock silodiff silofile silverjuke silx sim-torch sim2gff sim2trad sim4 sim4db sim65 sim_8086 sim_c sim_c++ sim_java sim_lisp sim_m2 sim_mira sim_pasc sim_pin sim_reads sim_reads_tran sim_text simavr simg2img simg2simg simg_dump simgrid-colorizer simgrid-graphicator simgrid_convert_TI_traces simgrid_update_xml simhash simka simkaCount simkaCountProcess simkaMerge simkaMin simkaMinCore simkaMin_update simpdftex tc-simple (8) - basic example action simple-ccsm simple-cdd simple-image-filter simple-image-reducer simple-pitchmark simple-scan simple.x simple2zoom simpleCoalParcelFoam simpleFoam simpleReactingParcelFoam simpleSprayFoam simple_bse.x simple_dcraw simple_ip.x simple_pacs simple_storage simpleproxy simplescreenrecorder simplyhtml simpos simrisc simstring simul-beacons simul-gridmap simul-landmarks simulate_probe simulide simulpic since sindex sinfo sinfo-client sinfo-emulator singleCellMesh single_to_multi_fast5 singledelta singularity sinntp sip sip-build sip-date sip-dig sip-distinfo sip-install sip-module sip-options sip-sdist sip-wheel sipcalc sipcrack sipdump sipgrep sipp sipsak siqs_ftdi siridb-server sirikali sirikali.pkexec siril siril-cli sirna sirtopnm sisc sisinstall sispmctl sisu sisu-concordance sisu-epub sisu-harvest sisu-html sisu-html-scroll sisu-html-seg sisu-odf sisu-pdf sisu-pdf-landscape sisu-pdf-portrait sisu-pg sisu-sqlite sisu-txt sisu-webrick sitecopy sitepods sitesummary2ldapdhcp six six-script sixel2png sixer sixpack size (1) - list section sizes and total size of binary files size86 sizeseq sj sjisconv sjislatex sjispdflatex ska skales-dtbtool skales-mkbootimg skanlite skeema skel skel_cat skel_extract skeldump.mpich skeldump.openmpi skesa sketch skewer skill (1) - send a signal or report process status skip-if-file-exists skip-tracker skipredundant skipseq skivi skk skk2cdb skkdic-count skkdic-expr skkdic-expr2 skkdic-sort skopeo skrooge skroogeconvert skx sky2xy skycat skycoor skylighting skymon skyview sl2h slabtop (1) - display kernel slab cache information in real time slack-diff slagan-mfa.pl slagan.pl slashtime slatex slave1 slc slcan_attach slcand slcanpty sldtoppm sleepctl sleepenh slic3r slice slice2cpp slice2cs slice2html slice2java slice2js slice2matlab slice2objc slice2php slice2py slice2rb slice2swift slice_fasta slice_fasta_gff slice_mercator_alignment sliceprint slick-greeter-check-hidpi slick-greeter-set-keyboard-layout slideshow slim (1) - Simple LogIn Manager slimit slimlock (1) - Unholy Screen Locker slinkwatch slirp slirp-fullbolt slirp4netns slirpvde slmbuild slminfo slmpack slmprune slmseg slmthread sloccount slock slogencrypt slogin (1) - OpenSSH remote login client slogkey slogverify slon slon_kill slon_start slon_status slon_watchdog slon_watchdog2 slonik slonik_add_node slonik_build_env slonik_create_set slonik_drop_node slonik_drop_sequence slonik_drop_set slonik_drop_table slonik_execute_script slonik_failover slonik_init_cluster slonik_merge_sets slonik_move_set slonik_print_preamble slonik_restart_node slonik_store_node slonik_subscribe_set slonik_uninstall_nodes slonik_unsubscribe_set slonik_update_nodes slony_logshipper slony_show_configuration slop slopBed slowhttptest slrn slrnface slrnpull slsh slt sludge-compiler sludge-floormaker sludge-projectmanager sludge-spritebankeditor sludge-translationeditor sludge-zbuffermaker slugify sluice slurm_srst2 slurm_submit_workers slurp slxdecode smTestDriver-pv5.11 sma smalt smapToFoam smart-notifier smarteigenstrat smartleia smartpca smartrel smartypants smascii smash smb-nat smb2-quota smb4k smbcacls smbclient smbcontrol smbcquotas smbencrypt smbget smbinfo smbmap smbmount smbnetfs smbpasswd smbspool smbstatus smbtar smbtorture smbtree smbumount smdevinfo smdiag smem smemcap smemstat smenu smew smfplay smfrec smfsh smi_canonicalise smi_isomorphism smi_parse smicache smidiff smidump smilint smime_keys smiquery smistrip smithwaterman smix smix_hmm smixlate sml smmixer smog_p_spectrum smp-tester smp_conf_general smp_conf_phy_event smp_conf_route_info smp_conf_zone_man_pass smp_conf_zone_perm_tbl smp_conf_zone_phy_info smp_discover smp_discover_list smp_ena_dis_zoning smp_phy_control smp_phy_test smp_read_gpio smp_rep_broadcast smp_rep_exp_route_tbl smp_rep_general smp_rep_manufacturer smp_rep_phy_err_log smp_rep_phy_event smp_rep_phy_event_list smp_rep_phy_sata smp_rep_route_info smp_rep_self_conf_stat smp_rep_zone_man_pass smp_rep_zone_perm_tbl smp_write_gpio smp_zone_activate smp_zone_lock smp_zone_unlock smp_zoned_broadcast smpeg-config smpicc smpicxx smpif90 smpiff smpirun smplayer smpq smproxy (1) - Session Manager Proxy smrawmount smrawverify sms4you smstrade_balance smstrade_send smtbx.absolute_structure smtbx.anom_refine smtbx.benchmark_refinement smtbx.masks smtbx.python smtbx.refine smtbx.show_build_path smtbx.show_dist_paths smtp smtp-check smtpping smtpsearch smtube sn snacc (1) - ASN.1 to C, C++ or type table Compiler snacc-config (1) - script to get information about the installed version of snacc snakemake snakemake-bash-completion snap snap-aligner snap-framework snap-hmm snap2tzx snapclient snapconv snapctl snapdump snapper snapper-gui snappyHexMesh snappyRefineMesh snapraid snapserver snarf snd.gui-jack snd.gui-pulse snd.nox snd2png sndfile-cmp sndfile-concat sndfile-convert sndfile-deinterleave sndfile-generate-chirp sndfile-info sndfile-interleave sndfile-jackplay sndfile-metadata-get sndfile-metadata-set sndfile-mix-to-mono sndfile-play sndfile-resample sndfile-salvage sndfile-spectrogram sndfile-waveform sndinfo sndioctl sndiod snek snek-board-install snek-duemilanove-big-install snek-duemilanove-install snek-grove-install snek-itsybitsy-install snek-lilypad-big-install snek-lilypad-install snek-mega-install snek-narrow-1284-install snek-uduino-install snek-uno-big-install snek-uno-install snekde sng sngrep sni-daemon sni-xembed-proxy snibbetracker snice (1) - send a signal or report process status sniff sniffglue sniffles snimpy snmp-bridge-mib snmpbulkget snmpbulkwalk snmpc snmpcheck snmpconf snmpdelta snmpdf snmpget snmpgetnext snmpinform snmpkey snmpnetstat snmpping snmprec snmpset snmpsim-datafile snmpsim-mib2dev snmpsim-pcap2dev snmpsimd snmpstatus snmptable snmptest snmptls snmptranslate snmptrap snmpusm snmpvacm snmpwalk snooze snow_key_repack snowflake-client snowflake-proxy snp-sites snp2mipe snpEff snpPosOnDesign snpPosOnSource snpSift snp_store snp_to_files snpfilter.sh sntop sntp soap soap2sam.pl soapcpp2 soapdenovo-127mer soapdenovo-31mer soapdenovo-63mer soapdenovo2-127mer soapdenovo2-63mer soapsnp soapsuds socat (1) - Multipurpose relay (SOcket CAT) sockaddr (3type) - socket address sockdown socket2socket socket_getaddrinfo socket_getnameinfo socklist socklog-check sockperf sockschain socksify socksify_ruby sockstat socnetv soelim (1) - interpret .so requests in groff input soffice softhsm2-dump-file softhsm2-keyconv softhsm2-migrate softhsm2-util softlimit software-properties-gtk software-properties-kde solaar solarpowerlog solfege solid-action-desktop-gen solid-hardware5 solidDisplacementFoam solidEquilibriumDisplacementFoam solid_auth sollya solo solo1 solterm solv solvate.tcl solve-field some_modes sonata sonetdiag songwrite3 sonic sonic-pi sonic-visualiser sonicDyMFoam sonicFoam sonicLiquidFoam soong_build sor sord_validate sordi sort (1) - sort lines of text files sort-bed sort-dctrl (1) - sort Debian control files sort-pictures sort-uniq-count sort-uniq-count-rank sortBed sortPolishes sort_fasta.pl sort_index_pairs.py sort_psl sort_reads sortbyquote sorter (1) - Sort files in an image into categories based on file type sorterr sortgrcd sortmail sortmerna sortshp sos sos-collector sosreport sotruss (1) - trace shared library calls through PLT sound-juicer sound2faust sound2file sound2reader soundconverter soundgrain soundinfo soundkonverter soundmodemconfig soundstretch soundtoh soundwrapper source-extractor source-highlight source-highlight-settings sourcefuncsize sow sox soxi sp2char sp32 sp64 sp65 spa-acp-tool spa-inspect spa-json-dump spa-monitor spa-resample spaced spacefm spacefm-auth spacegroup spacenavd spades spades.py spaln spamalyze spamassassin spamc spamoracle spamprobe sparc64-linux-gnu-addr2line sparc64-linux-gnu-ar sparc64-linux-gnu-as sparc64-linux-gnu-c++filt sparc64-linux-gnu-cpp sparc64-linux-gnu-cpp-10 sparc64-linux-gnu-cpp-11 sparc64-linux-gnu-cpp-12 sparc64-linux-gnu-dwp sparc64-linux-gnu-elfedit sparc64-linux-gnu-g++ sparc64-linux-gnu-g++-10 sparc64-linux-gnu-g++-11 sparc64-linux-gnu-g++-12 sparc64-linux-gnu-gcc sparc64-linux-gnu-gcc-10 sparc64-linux-gnu-gcc-11 sparc64-linux-gnu-gcc-12 sparc64-linux-gnu-gcc-ar sparc64-linux-gnu-gcc-ar-10 sparc64-linux-gnu-gcc-ar-11 sparc64-linux-gnu-gcc-ar-12 sparc64-linux-gnu-gcc-nm sparc64-linux-gnu-gcc-nm-10 sparc64-linux-gnu-gcc-nm-11 sparc64-linux-gnu-gcc-nm-12 sparc64-linux-gnu-gcc-ranlib sparc64-linux-gnu-gcc-ranlib-10 sparc64-linux-gnu-gcc-ranlib-11 sparc64-linux-gnu-gcc-ranlib-12 sparc64-linux-gnu-gccgo sparc64-linux-gnu-gccgo-10 sparc64-linux-gnu-gccgo-11 sparc64-linux-gnu-gccgo-12 sparc64-linux-gnu-gcov sparc64-linux-gnu-gcov-10 sparc64-linux-gnu-gcov-11 sparc64-linux-gnu-gcov-12 sparc64-linux-gnu-gcov-dump sparc64-linux-gnu-gcov-dump-10 sparc64-linux-gnu-gcov-dump-11 sparc64-linux-gnu-gcov-dump-12 sparc64-linux-gnu-gcov-tool sparc64-linux-gnu-gcov-tool-10 sparc64-linux-gnu-gcov-tool-11 sparc64-linux-gnu-gcov-tool-12 sparc64-linux-gnu-gdc-10 sparc64-linux-gnu-gdc-11 sparc64-linux-gnu-gfortran sparc64-linux-gnu-gfortran-10 sparc64-linux-gnu-gfortran-11 sparc64-linux-gnu-gfortran-12 sparc64-linux-gnu-gm2 sparc64-linux-gnu-gm2-10 sparc64-linux-gnu-gm2-11 sparc64-linux-gnu-gm2-12 sparc64-linux-gnu-gnat sparc64-linux-gnu-gnat-10 sparc64-linux-gnu-gnat-11 sparc64-linux-gnu-gnat-12 sparc64-linux-gnu-gnatbind sparc64-linux-gnu-gnatbind-10 sparc64-linux-gnu-gnatbind-11 sparc64-linux-gnu-gnatbind-12 sparc64-linux-gnu-gnatchop sparc64-linux-gnu-gnatchop-10 sparc64-linux-gnu-gnatchop-11 sparc64-linux-gnu-gnatchop-12 sparc64-linux-gnu-gnatclean sparc64-linux-gnu-gnatclean-10 sparc64-linux-gnu-gnatclean-11 sparc64-linux-gnu-gnatclean-12 sparc64-linux-gnu-gnatfind sparc64-linux-gnu-gnatfind-10 sparc64-linux-gnu-gnatfind-11 sparc64-linux-gnu-gnatgcc sparc64-linux-gnu-gnathtml sparc64-linux-gnu-gnathtml-10 sparc64-linux-gnu-gnathtml-11 sparc64-linux-gnu-gnathtml-12 sparc64-linux-gnu-gnatkr sparc64-linux-gnu-gnatkr-10 sparc64-linux-gnu-gnatkr-11 sparc64-linux-gnu-gnatkr-12 sparc64-linux-gnu-gnatlink sparc64-linux-gnu-gnatlink-10 sparc64-linux-gnu-gnatlink-11 sparc64-linux-gnu-gnatlink-12 sparc64-linux-gnu-gnatls sparc64-linux-gnu-gnatls-10 sparc64-linux-gnu-gnatls-11 sparc64-linux-gnu-gnatls-12 sparc64-linux-gnu-gnatmake sparc64-linux-gnu-gnatmake-10 sparc64-linux-gnu-gnatmake-11 sparc64-linux-gnu-gnatmake-12 sparc64-linux-gnu-gnatname sparc64-linux-gnu-gnatname-10 sparc64-linux-gnu-gnatname-11 sparc64-linux-gnu-gnatname-12 sparc64-linux-gnu-gnatprep sparc64-linux-gnu-gnatprep-10 sparc64-linux-gnu-gnatprep-11 sparc64-linux-gnu-gnatprep-12 sparc64-linux-gnu-gnatxref sparc64-linux-gnu-gnatxref-10 sparc64-linux-gnu-gnatxref-11 sparc64-linux-gnu-gprof sparc64-linux-gnu-ld sparc64-linux-gnu-ld.bfd sparc64-linux-gnu-ld.gold sparc64-linux-gnu-lto-dump-10 sparc64-linux-gnu-lto-dump-11 sparc64-linux-gnu-lto-dump-12 sparc64-linux-gnu-nm sparc64-linux-gnu-objcopy sparc64-linux-gnu-objdump sparc64-linux-gnu-ranlib sparc64-linux-gnu-readelf sparc64-linux-gnu-size sparc64-linux-gnu-strings sparc64-linux-gnu-strip sparse sparse-llvm sparsec sparsify-Bragg spatch spatialite spatialite-gui spatialite_convert spatialite_dem spatialite_dxf spatialite_gml spatialite_network spatialite_osm_filter spatialite_osm_map spatialite_osm_net spatialite_osm_overpass spatialite_osm_raw spatialite_tool spatialite_xml2utf8 spatialite_xml_collapse spatialite_xml_load spatialite_xml_print spatialite_xml_validator spawn-fcgi spc (1) - colorize and print to standard output spctoppm spd-conf (1) - configure Speech Dispatcher and diagnose problems spd-say (1) - send text-to-speech output request to speech-dispatcher spdsend speak speak-ng speaker-test (1) - command-line speaker test tone generator for ALSA speakup_setlocale speakupconf spec-beautifier spec2cie specplot spectacle spectest-interp spectgen spectool_curses spectool_gtk spectool_net spectool_raw spectra_correction.x spectre-meltdown-checker spectrwm specular-color speech-dispatcher (1) - speech synthesis daemon speechd-up speedcrunch speedometer speedtest speedtest-cli speexdec speexenc spell spelldump spellintian (1) - simple spellchecker based on Lintian's data files spew spf_example spfquery.libspf2 spfquery.mail-spf-perl spfquery.pyspf spftest spgen sphereSurfactantFoam sphinx-apidoc sphinx-autobuild sphinx-autogen sphinx-build sphinx-intl sphinx-multiversion sphinx-quickstart sphinx.build sphinx2md sphinx2nb sphinx2pxml sphinx2py sphinx_cepview sphinx_cont_seg sphinx_fe sphinx_jsgf2fsg sphinx_lm_convert sphinx_lm_eval sphinx_pitch sphinxtrain spi-config spi-pipe spice-vdagent spicy spicy-screenshot spicy-stats spidey spigot spim spin spinner spipe spiped spirv-as spirv-cfg spirv-cross spirv-dis spirv-lesspipe.sh spirv-link spirv-lint spirv-opt spirv-reduce spirv-remap spirv-val splain (1) - produce verbose warning diagnostics splash splat splat-hd splay splazers spliced_bam2gff spline splint split (1) - split a file into pieces split-file-13 split-file-14 split-file-15 split-select split2po splitCells splitMesh splitMeshRegions split_fa split_fq split_mate_pairs split_profile_file.pl split_scaffold split_stl splitdiff (1) - separate out incremental patches splitdns323fw splitdwarf splitfont splitindex splitkeys splitmail++ splitpatch splitsource splitter splitti3 splitvt splitword spm_decode spm_encode spm_export_vocab spm_normalize spm_train spmd spnavd_ctl spoa sponge sponsor-patch spotfinder.python spotfinder.show_build_path spotfinder.show_dist_paths spotlighter spotread spottopgm sprayDyMFoam sprayFoam spread-phy spring springgraph sprio sprio-emulator sprockets sprof (1) - read and display shared object profiling data sprop sptag-aggregator sptag-client sptag-indexbuilder sptag-indexsearcher sptag-quantizer sptag-server sptag-ssdserving sptk spumux sputnik sputoppm spuunmux spview spyder sq sq-keyring-linter sq-wot sqfs2tar sqfscat (1) - tool to cat files from a squashfs filesystem to stdout sqfsdiff sqfstar (1) - tool to create a squashfs filesystem from a tar archive sqitch sql sql-formatter sql-migrate sql-split sql2csv (1) - manual page for sql2csv 1.0.7 sql_count sqlacodegen sqlcipher sqldiff sqlformat sqlgrey-logstats sqlite-utils sqlite3 sqlite3_analyzer sqlitebrowser sqliterepo_c sqlline (1) - JDBC command-line utility for issuing SQL sqlmap sqlmapapi sqlmetal sqlobject-admin sqlobject-convertOldURI sqlrw sqlsharp sqlsmith sqlt sqlt-diagram sqlt-diff sqlt-diff-old sqlt-dumper sqlt-graph sqop sqt squashfuse squeak squeekboard squeekboard-entry squeekboard-restyled squeekboard-test-layout squeezelite squeezelite-pa squeezelite-pulseaudio squeue squeue-emulator squid-purge squidGuard squidclient squidview squiggle (1) - browser for SVG files squizz sqv sr sra-pileup sra-pileup-orig sra-sort sra-sort-cg sra-stat srain srapath srapath-orig sratools src src2latex src2man src2tex src_conv srcgen srch_strings (1) - display printable strings in files srconv srcredact srctblbrows_qt srec_cat srec_cmp srec_info srecparse sreformat sreport sreport-emulator sreview-autoreview sreview-config sreview-copy sreview-cut sreview-detect sreview-dispatch sreview-encode sreview-import sreview-inject sreview-inject-job sreview-notify sreview-previews sreview-skip sreview-titles sreview-transcode sreview-upload sreview-user sreview-web srf2fasta srf2fastq srf_dump_all srf_extract_hash srf_extract_linear srf_filter srf_index_hash srf_info srf_list srftopam srg srktool srm srm.pvm srp-gen srpc_generator srptool srs srs2envtol srsc srsd srst2 srt srt-deduplicate srt-ffplay srt-file-transmit srt-fixed-timeshift srt-linear-timeshift srt-lines-matching srt-live-transmit srt-mux srt-normalise srt-play srt-process srt-tunnel srtm2sdf srtm2sdf-hd srun srun-emulator srvarv srvsearch ss-local ss-manager ss-nat ss-redir ss-server ss-tunnel ss-v2ray-plugin ss2 ssa2srt ssadump ssake sscg sscm ssconvert ssdd ssdeep ssdiff ssearch36 ssed sselp ssematch ssft.sh ssg3d ssg_symop_canonical ssg_symop_check ssg_symop_matrices ssg_symop_string ssgrep ssh (1) - OpenSSH remote login client ssh-add (1) - adds private key identities to the OpenSSH authentication agent ssh-agent (1) - OpenSSH authentication agent ssh-agent-filter ssh-argv0 (1) - replaces the old ssh command-name as hostname handling ssh-askpass-fullscreen ssh-askpass-noinput ssh-audit ssh-certinfo ssh-contact ssh-conv ssh-copy-id (1) - use locally available keys to authorise logins on a remote machine ssh-cron ssh-diff ssh-facts ssh-force-password ssh-hostkeys ssh-import-id ssh-import-id-gh ssh-import-id-lp ssh-keygen (1) - OpenSSH authentication key utility ssh-keygen1 ssh-keyinfo ssh-keyscan (1) - gather SSH public keys from servers ssh-ping ssh-version ssh1 sshare sshare-emulator sshcommand sshesame sshfp sshfs (1) - filesystem client based on SSH sshpass sshpk-conv sshpk-sign sshpk-verify sshtunnel sshuttle sshvnc ssid ssimulacra_main ssindex ssite ssl-cert-check sslh sslscan sslsniff sslsplit ssltap ssmping ssmpingd ssocr sspace ssr ssr-aap.nox ssr-aap.qt ssr-binaural.nox ssr-binaural.qt ssr-brs.nox ssr-brs.qt ssr-dca.nox ssr-dca.qt ssr-generic.nox ssr-generic.qt ssr-glinject ssr-vbap.nox ssr-vbap.qt ssr-wfs.nox ssr-wfs.qt ssr.nox ssr.qt sss_ssh_authorizedkeys sss_ssh_knownhostsproxy sssh ssshd ssshtest ssss-combine ssss-split sst_dump sstat sstat-emulator sstm8 ssu ssvnc ssvncviewer ssw-align ssw2mcpl ssw_test sswap st (4) - SCSI tape device st-console st-flash st-info st-trace st-util st4topgm sta stacer stack stackprof stackprof-flamegraph.pl stackprof-gprof2dot.py stacks staden stag-autoddl stag-autoschema stag-autotemplate stag-db stag-diff stag-drawtree stag-filter stag-findsubtree stag-flatten stag-grep stag-handle stag-ir stag-itext2simple stag-itext2sxpr stag-itext2xml stag-join stag-merge stag-mogrify stag-parse stag-qsh stag-query stag-selectall_html stag-selectall_xml stag-splitter stag-storenode stag-view stag-xml2itext stalin stamppdf standardskriver stap stap-merge stap-prep stap-profile-annotate stap-report stap-server stapbpf staprun star-align star4ToFoam starch starch-diff starchcat starchcluster_gnuParallel starchcluster_sge starchcluster_slurm starchstrip starconvert stardict starman starpkg starplot starpu_calibrate_bus starpu_codelet_histo_profile starpu_codelet_profile starpu_env starpu_lp2paje starpu_machine_display starpu_mlr_analysis starpu_mlr_analysis.Rmd starpu_mpi_comm_matrix.py starpu_paje_draw_histogram starpu_paje_draw_histogram.R starpu_paje_state_stats starpu_paje_state_stats.R starpu_paje_summary starpu_paje_summary.Rmd starpu_perfmodel_display starpu_perfmodel_plot starpu_perfmodel_recdump starpu_sched_display starpu_tasks_rec_complete starpu_temanejo2.sh starpu_trace_state_stats.py starpu_workers_activity start-avarice start-nas start-pulseaudio-x11 (1) - PulseAudio Sound Server X11 Startup Script startBristol start_embedded start_server startfluxbox startlazarus-2.2.4 startlxde startlxqt startplasma-wayland startplasma-x11 startx (1) - initialize an X session startxfce4 (1) - initialize an Xfce session stat (1) - display file or file system status stat (2) - get file status stat (3type) - file status statcvs states statfs (2) - get filesystem statistics statgrab statgrab-make-mrtg-config statgrab-make-mrtg-index static statik statmake statnet statnews statreport stats-select statserial statsvn stayrtr stdbuf (1) - Run COMMAND, with modified buffering operations for its standard streams. stdcmapppm stdiscosrv stdpods stdsyslog steadyParticleTracks stealth stegcracker steghide stegosuite stegsnow stella stellar stellarium stemwords stenc stenocurl stenoread stenvironment step step-awskms-init step-ca step-pkcs11-init step-yubikey-init stepconf stepic stereo3d stest stestr stetl stexec stg stg-cvs stg-dispatch stg-fold-files-from stg-gitk stg-k stg-mdiff stg-show stg-show-old stg-swallow stg-unnew stg-whatchanged stiff stilts stilview stitchMesh stk-demo stl stl-to-amf stl2ascii stl2bin stl2dcm stl2gts (1) - convert an STL file to GTS format. stl_bbox stl_boolean stl_borders stl_cone stl_convex stl_count stl_cube stl_cylinder stl_empty stl_header stl_merge stl_normals stl_sphere stl_spreadsheet stl_threads stl_torus stl_transform stlink-gui stm32flash stnmap stoken stoken-gui stomp stompcat stompserver stone stone-py stopmotion stops stopwatch storage_classes storage_commit storeBackup storeBackupCheckBackup storeBackupConvertBackup storeBackupDel storeBackupMount storeBackupRecover storeBackupSearch storeBackupUpdateBackup storeBackupVersions storeBackup_du storeBackupls storescp storescu storj storm storymaps stow stpm-exfiltrate stpm-keygen stpm-sign stpm-verify str2str strace (1) - trace system calls and signals strace-log-merge (1) - merge strace -ff -tt output strain_transmission.py strainextract strainphlan stranslate strawberry strawberry-import-from-clementine stream-im6.q16 stream-im6.q16hdri stream-pubmed stream_ttyrec stream_type streamanime streamdeck streamer streamlink streamripper streams streamtuner2 streamzip (1) - create a zip file from stdin strelaysrv stress stress-ng stressant stressapptest stretcher stretchplayer strfile strigger strigger-emulator string2key stringer stringiphy strings (1) - print the sequences of printable characters in files stringtie strip (1) - discard symbols and other data from object files strip-nondeterminism stripGapColumns stripSubsetLCBs strip_stx stripfits stripttc strsclnt strsvr_qt struct2osd structure-synth structuredstorageexplorer stshell stssearch stterm stubby stubgen stubmaker stubquery stubtest stun stunc stunnel stunnel3 stunnel4 stx2any stxxl_tool sty2dtx style stylus su-to-root su1 sub2po subdivision_geometry subdownloader subfuse subindel subjunc sublime-music subliminal sublist3r sublong submitct submittodebian subnetcalc subpix subread-align subread-buildindex subs subsetMesh subtable subtitlecomposer subtitleeditor subtitles subtle subtler subtractBed subunit-1to2 subunit-2to1 subunit-describe-calls subunit-filter subunit-ls subunit-notify subunit-output subunit-stats subunit-tags subunit-trace subunit2csv subunit2disk subunit2gtk subunit2html subunit2junitxml subunit2pyunit subuser suck sucrack sudo (8) - execute a command as another user sudoedit (8) - execute a command as another user sudoreplay (8) - replay sudo session logs suffixfsm sugar sugar-activity-web sugar-activity3 sugar-backlight-helper sugar-backlight-setup sugar-control-panel sugar-erase-bundle sugar-install-bundle sugar-launch sugar-serial-number-helper suitename sum (1) - checksum and count the blocks in a file sumaclust sumatra summarise-mailbox-preserving-privacy summarize-ancestors summarizeModifications summarizePolishes summary summer sumpdos.x sumpix sumtrees sunclock sundazel sunflow sunicontopnm sunxi-bootinfo sunxi-fel sunxi-fexc sunxi-nand-part sunxi-pio sup sup-add sup-config sup-dump sup-import-dump sup-mail sup-psych-ify-config-files sup-recover-sources sup-sync sup-sync-back-maildir sup-tweak-labels super superdenss superformat superkb supermap.pl supermatcher supermin supernode supernova superpose supervise supervisorctl supervisord supfilesrv supscan supybot supybot-adduser supybot-botchk supybot-plugin-create supybot-plugin-doc supybot-reset-password supybot-test supybot-wizard supycomb supysonic-cli supysonic-daemon supysonic-server sur surankco-feature surankco-prediction surankco-score surankco-training sure surf surf-alggeo-nox surf-display surfaceAdd surfaceBooleanFeatures surfaceCheck surfaceClean surfaceCoarsen surfaceConvert surfaceFeatureConvert surfaceFeatureExtract surfaceFind surfaceHookUp surfaceInertia surfaceInflate surfaceLambdaMuSmooth surfaceMeshConvert surfaceMeshExport surfaceMeshExtract surfaceMeshImport surfaceMeshInfo surfaceOrient surfacePatch surfacePointMerge surfaceRedistributePar surfaceRefineRedGreen surfaceSplitByPatch surfaceSplitByTopology surfaceSplitNonManifolds surfaceSubset surfaceToPatch surfaceTransformPoints surfactantFoam surfraw surfraw-update-path suricata suricata-update suricatactl suricatasc surpyvor surserver survexport susetags2solv sushi sushycli suspicious-source sv svalidate svc svc_recv svc_send svcrack svcrash svcutil svd-ps_vfd svdrpsend svg2pdf svg2ttf svgpp (1) - pretty-printer for SVG files svgtoipe svgtopam svgtune svgview svi2dmk svicpm2dmk sview svim svlc svlogd svm-checkdata svm-easy svm-grid svm-predict svm-scale svm-subset svm-train svmap svmocas svn svn-all-fast-export svn-backup-dumps svn-bisect svn-buildpackage svn-clean svn-clean-kde svn-do svn-foreign svn-hot-backup svn-inject svn-load svn-mergeinfo-normalizer svn-multi svn-populate-node-origins-index svn-upgrade svn-vendor svn2cl svn2git svn2revisioninc-2.2.4 svn_apply_autoprops svn_load_dirs svnadmin svnauthz svnauthz-validate svnbackport svnbench svnchangesince svndiff svndiffview svndumpfilter svnforwardport svnfsfs svngettags svnintegrate svnlastchange svnlastlog svnlook svnmucc svnnotify svnpath svnraisetreeconflict svnrdump svnrevertlast svnserve svnsync svnversion svnversions svnweb-install svnwrap svok svreport svscan svscanboot svsematest svstat svtplay-dl svwar svxlink svxreflector swab (3) - swap adjacent bytes swaks swami swappo swarm swarp swatchdog swath sway swaybar swaybg swayidle swayimg swaykbdd swaylock swaymsg swaynag sweep sweeper sweepgen sweethome3d sweethome3d-furniture-editor sweethome3d-textures-editor swemini swetest swfparser swgen swift swift-account-audit swift-account-auditor swift-account-info swift-account-reaper swift-account-replicator swift-account-server swift-account-server-uwsgi swift-bench swift-bench-client swift-config swift-container-auditor swift-container-deleter swift-container-info swift-container-reconciler swift-container-replicator swift-container-server swift-container-server-uwsgi swift-container-sharder swift-container-sync swift-container-updater swift-dispersion-populate swift-dispersion-report swift-drive-audit swift-form-signature swift-get-nodes swift-manage-shard-ranges swift-object-auditor swift-object-expirer swift-object-info swift-object-reconstructor swift-object-relinker swift-object-replicator swift-object-server swift-object-server-uwsgi swift-object-updater swift-oldies swift-orphans swift-proxy-server swift-proxy-server-uwsgi swift-recon swift-recon-cron swift-reconciler-enqueue swift-ring-builder swift-ring-builder-analyzer swift-ring-composer swiften-config swig swig4.0 swindle swipl swipl-ld swish-config swish-e swish-search swisswatch switcherooctl switchsh switchvsmap swtpm swtpm_bios swtpm_cert swtpm_ioctl swtpm_localca swtpm_setup swugenerator swupdate swupdate-client swupdate-ipc swupdate-progress sx sx_ccd_test sxhkd sxid sxiv sxmo_aligned_sleep sxmo_appmenu.sh sxmo_audio.sh sxmo_autorotate.sh sxmo_battery_monitor.sh sxmo_bluetoothmenu.sh sxmo_bluetoothtoggle.sh sxmo_brightness.sh sxmo_common.sh sxmo_contactmenu.sh sxmo_contacts.sh sxmo_daemons.sh sxmo_deviceprofile_lge,hammerhead.sh sxmo_deviceprofile_longcheer,l8150.sh sxmo_deviceprofile_oneplus,cheeseburger.sh sxmo_deviceprofile_oneplus,dumpling.sh sxmo_deviceprofile_oneplus,enchilada.sh sxmo_deviceprofile_oneplus,fajita.sh sxmo_deviceprofile_pine64,pinenote.sh sxmo_deviceprofile_pine64,pinephone-1.0.sh sxmo_deviceprofile_pine64,pinephone-1.1.sh sxmo_deviceprofile_pine64,pinephone-1.2.sh sxmo_deviceprofile_pine64,pinephone-pro.sh sxmo_deviceprofile_purism,librem5r2.sh sxmo_deviceprofile_purism,librem5r3.sh sxmo_deviceprofile_purism,librem5r4.sh sxmo_deviceprofile_qcom,msm8226-mtp.sh sxmo_deviceprofile_samsung,a5u-eur.sh sxmo_deviceprofile_samsung,gt510.sh sxmo_deviceprofile_samsung,i9300.sh sxmo_deviceprofile_wingtech,wt88047.sh sxmo_deviceprofile_xiaomi,beryllium.sh sxmo_dmenu.sh sxmo_dmenu_with_kb.sh sxmo_dtmf.sh sxmo_edit_screen.sh sxmo_files.sh sxmo_flashtoggle.sh sxmo_hookmenu.sh sxmo_idle.sh sxmo_keyboard.sh sxmo_killwindow.sh sxmo_led.sh sxmo_menumode_toggler.sh sxmo_migrate.sh sxmo_mms.sh sxmo_mmsdconfig.sh sxmo_modem.sh sxmo_modemaudio.sh sxmo_modemcall.sh sxmo_modemdial.sh sxmo_modeminfo.sh sxmo_modemlog.sh sxmo_modemmonitor.sh sxmo_modemsendsms.sh sxmo_modemtext.sh sxmo_movement.sh sxmo_multikey.sh sxmo_mutex.sh sxmo_networkmonitor.sh sxmo_networks.sh sxmo_notificationmonitor.sh sxmo_notificationsmenu.sh sxmo_notificationwrite.sh sxmo_notify_user.sh sxmo_open.sh sxmo_phonemenu.sh sxmo_pipecomplete.sh sxmo_playerctl.sh sxmo_power.sh sxmo_record.sh sxmo_reddit.sh sxmo_rotate.sh sxmo_rss.sh sxmo_rtcwake.sh sxmo_run_aligned.sh sxmo_run_periodically.sh sxmo_screenshot.sh sxmo_screenshot_selection.sh sxmo_setpermissions.sh sxmo_soundmonitor.sh sxmo_status.sh sxmo_status_xsetroot.sh sxmo_surf_linkselect.sh sxmo_suspend.sh sxmo_swayinitconf.sh sxmo_terminal.sh sxmo_timer.sh sxmo_timezonechange.sh sxmo_type.sh sxmo_uniq_exec.sh sxmo_unlocksim.sh sxmo_upgrade.sh sxmo_urlhandler.sh sxmo_validnumber.sh sxmo_version.sh sxmo_vibrate sxmo_vvm.sh sxmo_vvmdconfig.sh sxmo_weather.sh sxmo_websearch.sh sxmo_wifitoggle.sh sxmo_winit.sh sxmo_wm.sh sxmo_wmmenu.sh sxmo_wob.sh sxmo_xinit.sh sxmo_youtube.sh sxmo_youtube_audio.sh sxpm sxw2odt sxw2txt syco syl-auth-helper syldbimport syldbquery sylfilter sylph-searcher sylpheed sylseg-sk sylseg-sk-training symb2po symilar syminv symkeyutil symlinks symmul symop_build_spacegroup symops sympa sympathy symphony sympow symtree synadm synapse synapse_export_signing_key synapse_generate_config synapse_generate_log_config synapse_generate_signing_key synapse_hash_password synapse_homeserver synapse_port_db synapse_register_new_matrix_user synapse_review_recent_signups synapse_update_database synapse_worker synaptic-pkexec sync-accounts sync-accounts-createuser sync-ui sync_httpsearch sync_smtpsearch sync_srvsearch sync_to_snapshot syncache-drb syncdic syncevo-http-server syncevo-webdav-lookup syncevolution synclient syncobj_admin syncpackage syncplay syncplay-server synctex syncthing syncthing-gtk syncthingctl syncthingtray synctl syndaemon syndie syndie-cli syndie-desktop synfig synfig-config synfigplayer synfigstudio synthcal synthread synthsplit synthv1_jack syrep syrthes-gui syrthes-post syrthes-pp syrthes-ppfunc syrthes4_create_case syrthes4ensight syrthes4med30 sysbench sysconftoolcheck sysconftoolize syscse sysdig syslinux syslinux2ansi sysprof sysprof-agent sysprof-cli system-config-printer (1) - configure a CUPS server system-config-printer-applet (1) - print job manager system3 system_analyzer systemctl systemd-analyze systemd-cat systemd-cgls systemd-cgtop systemd-cryptenroll systemd-delta systemd-detect-virt systemd-dissect systemd-id128 systemd-mount systemd-nspawn systemd-path systemd-run systemd-socket-activate systemd-stdio-bridge systemd-umount systemmonitor systemsettings systemsettings5 systool systray-mdstat sysvbanner sz sz80 szap t-prot t1ascii (1) - convert PostScript Type 1 font from binary to ASCII t1asm (1) - assemble PostScript Type 1 font t1binary (1) - convert PostScript Type 1 font from ASCII to binary t1c2pfb t1disasm (1) - disassemble PostScript Type 1 font t1dotlessj t1lint t1mac (1) - translate a PFA or PFB PostScript Type 1 font into Macintosh format t1rawafm t1reencode t1testpage t1unmac (1) - translate a Mac PostScript Type 1 font into PFA or PFB format t2html t2n t2p t3highlight t3keyc t3learnkeys t4ht t_coffee t_listen tab2graph tabbed.default tabbed.meta tabble tabble-wrapper tabix table_add_column.py table_filter.py tablefromascii tablify tablix2 tablix2_benchmark tablix2_kernel tablix2_output tablix2_plot tablix2_test tabmerge tabs (1) - set tabs on a terminal tabsort tabulate tac (1) - concatenate and print files in reverse tachyon-nox tachyon-ogl tack tacker tacks tad tag2thesaurus tagBam tagcloud taggrepper taglib-config taglib-extras-config taglog tagmp3 tagpending tags_demo tai64n tai64nlocal tail (1) - output the last part of files take-vector-screenshot taktuk tandem tang-show-keys tangence-dumptan tangence-introspect tangence-subscribeall tangle tango_admin tanidvr tantan tao tao-config tao2aiff tao2wav taoparse taosf tap tap-mocha-reporter tap-parser tap2junit tap2subunit tap_tool_dispatcher tape tape2pulses tape2wav tapecalc tapeconv tapecopy tapemap tapesplt tapestat tappy taptempo taql tar-split tar2sqfs tarantool tarantoolctl tardiff tardy targen targetcli targetclid targetctl tarlz task task0 task1 task_end taskd taskdctl tasksel (8) - a user interface for installing tasks taskset (1) - set or retrieve a process's CPU affinity tasksh tasm tastenbrett tasty-discover tatd tax2thesaurus taxblast taxget taxgetdown taxgetrank taxgetspecies taxgetup tbl (1) - format tables for troff tbl-dctrl (1) - generate tabular representations of data in dctrl format tbl2asn tblastn tblastx tblcvt tblgen-lsp-server-15 tbtadm tbx2po tc2html tc2html-toc tc2null tc2rtf tc2text tc_tracks tc_tracks_10t5 tc_tracks_det tc_tracks_eps tca_correct tcal tcamgr tcamttest tcat tcatest tcbd tcbmgr tcbmttest tcbtest tcc tcfmgr tcfmttest tcftest tchmgr tchmttest tchtest tck2connectome tck2fixel tckconvert tckdfc tckedit tckgen tckglobal tckinfo tckmap tckresample tcksample tcksift tcksift2 tckstats tcktransform tcl2c++ tcl3270 tcl_count tcldocstrip tclsh tclsh8.6 tcltk-depends tcm tcmd tcmt tcmu-runner tcode tcov2lcov tcp_relay tcpbench tcpbridge tcpbug tcpcapinfo tcpcat tcpclient tcpconnect tcpd tcpdump (8) - dump traffic on a network tcpdump2xplot tcpflow tcplisten tcpliveplay tcpprep tcpprof tcpreen tcpreplay tcpreplay-edit tcprewrite tcprules tcprulescheck tcpserver tcpslice tcpspray tcpspray.ndisc6 tcpspray6 tcpstat tcpsvd tcptrace tcptraceroute.mt tcptraceroute6 tcptrack tcpxtract tcrd tcs tctmgr tctmttest tcttest tcucodec tcumttest tcutest tcvt td tda tdb tdbbackup.tdbtools tdbdump tdbrestore tdbtool tdc tdcompare tdd tde tdfd tdiary-convert2 tdiary-setup tdl tdpackdemo tdpd tdr tdrecord tdreplay tdrerecord tdspool tdview te923con tea teach-in teachjove teamd teamdctl teamnl teckit_compile tecplot_to_cgns tee (1) - read from standard input and write to standard output and files tee (2) - duplicating pipe content teem-gprobe teem-ilk teem-miter teem-mrender teem-nrrdSanity teem-overrgb teem-puller teem-tend teem-unu teem-vprobe teensy_loader_cli tefd tei2mod tek2plot telegnome telegps telegram-desktop telem-balloon.pl telem-bits.pl telem-data.pl telem-data91.pl telem-eqns.pl telem-parm.pl telem-seq.sh telem-unit.pl telem-volts.py tellico tellico2lesana telnet-chatd telnet-client telnet-proxy telnet-ssl tempest tempest_debian_shell_wrapper tempest_for_eliza tempest_for_mp3 temporalInterpolate tensor2metric tentacle_client tercpp terd teredo-mire termcast termcat termdebug termdiff terminator terminatorX termineter terminews terminology terminus terminus_showhide termit termplay termrec termscu termshark termtime termtosvg terraingenerator terraintool terraphast terser tesd teseq tesh tesseract tessrun test (1) - check file types and compare values test-filter-module test-inspect test-regexp-pattern test-sra test_chmLib test_physfs test_sandbox test_version test_xrt_device_handle testasciidoc testdbfawk testdisk testfpzip testhost testj1939 testlibraw testmxlookup testparm testpkg testproxy testr testresize tests testscript testsolv testssl testtransposer tetgen tetgenToFoam tetgen_to_cgns tetrafile tetraproc tex tex2aspc tex2eps tex2lyx tex2mail tex2xindy tex4ebook tex4ht texconfig texconfig-dialog texconfig-sys texcount texdef texdiff texdirflatten texdoc texdoctk texexec texexpand texfind texfix texfont texfot texhash texi2any texi2dvi texi2dvi4a2ps texi2html texi2pdf texify texifyB texifyabel texifyada texifyasm texifyaxiom texifybeta texifybison texifyc texifyc++ texifyidl texifyjava texifylex texifylisp texifylogla texifymatlab texifyml texifyperl texifypromela texifypython texifyruby texifyscheme texifysim texifysql texifyvhdl texindex texindy texjava texlinks texliveonfly texloganalyser texlua texluac texluajit texluajitc texmaker texmfstart texosquery texosquery-jre5 texosquery-jre8 texplate texsis texstudio text2image text2ngram text2odf text2pcap (1) - Generate a capture file from an ASCII hexdump of packets text2ps text2sf text2table text2tt text2wave textconv textdraw textfmt textget textile textql textrr textsearch texturator texture-font-to-pascal texture_to_cube texworks tf-clean tf-extract tf-inject tf5 tf_remap tfastf36 tfastm36 tfasts36 tfastx36 tfasty36 tfdocgen tfet tfextract tfloc_summary.py tfm tfmtodit tform tfrt tfscan tftopl tftp tg tgatoppm tgd tgif tgks0a tgt tgtt tgz (1) - makes a gzip'd tar archive thb the theft-server thefuck theli theme theme-aliases theme-d-compile theme-d-link themole themonospot theora_dump_video theora_encoder_example theora_player_example theora_png2theora therion thermistor thermoFoam thesaurus2any thesaurus2htmls thesaurus2tex thesaurusTranslate theseus theseus_align theta thg thin thinkjettopbm thonny thor threadscope thrift thumbpdf Thunar (1) - File Manager for the Xfce Desktop Environment thunar (1) - File Manager for the Xfce Desktop Environment thunar-settings (1) - display thunar(1) preferences dialog thunar-volman (1) - controls configuration of thunar's removable media thunar-volman-settings (1) - controls configuration of thunar's removable media thunderbird thymioupgrader thymiownetconfig thymiownetconfig-cli tiarra tic (1) - the terminfo entry-description compiler ticker tickr tidc tiddit tids tidy tidy_changelog tidyall tidygff3 tie tiemu tiemu-skinedit tiff2bw tiff2jp2 tiff2pdf tiff2ps tiff2rgba tiffcmp tiffcp tiffcrop tiffdither tiffdump tifffastcrop tifffile tiffgamut tiffgt tiffinfo tiffmakemosaic tiffmedian tiffset tiffsplit tiffsplittiles tifftopnm tificc tig tiger-hash tigerdeep tigervncconfig tigervncpasswd tigervncserver tigge_check tightvncconnect tightvncpasswd tightvncserver tigr-glimmer tigr-run-glimmer3 tiki2po tikzit tikztosvg tilda tilde tile4ms tiled tilem2 tilemaker tilix tilix.wrapper tilp tilt tilt_analysis tilt_synthesis timage timbl timblclient timblserver time (2) - get time in seconds time (3am) - time functions for gawk time (7) - overview of time and timers time-admin time-decode timed-process timed-read timed-run timedatectl timekpra timekprc timekprd timelimit timelimit.netpipes timemachine timeout (1) - run a command with a time limit timeout (3ncurses) - curses input options timerlat timeshift timeshift-gtk timeshift-launcher timg timidity timing timing_slave tin tina tini tini-static tint2 tint2conf tintii tinydns-get tinydyndns-conf tinydyndns-data tinydyndns-update tinyirc tinyproxy tinyscheme tio tioga tipp10 tiptop tircd tirex-backend-manager tirex-batch tirex-check-config tirex-master tirex-rendering-control tirex-send tirex-status tirex-tiledir-check tirex-tiledir-stat titanium-starter titanver tixindex tj3 tj3client tj3d tj3man tj3ss_receiver tj3ss_sender tj3ts_receiver tj3ts_sender tj3ts_summary tj3webd tjbench tjf tjl tk-brief tk2 tk5 tk707 tkabber tkabber-remote tkcon tkconch3 tkcvs tkdesk tkdeskclient tkdict tkdiff tkdirdiff tkgate tkill (2) - send a signal to a thread tkinfo tkinspect tkjpeg (1p) - simple JPEG viewer using perl/Tk tkmib tkmolrender tkmore tknamazu tknewsbiff tkpasswd tkpod tkremind tkrzw_build_util tkrzw_dbm_perf tkrzw_dbm_tran tkrzw_dbm_util tkrzw_file_perf tkrzw_langc_check tkrzw_str_perf tkrzw_ulog_util tl-paper tl-parser tla tla-gpg-check tldextract tldr-hs tldr-py tlf tlmgr tload (1) - graphic representation of system load average tlocal tlog-play tlog-rec tlog-rec-session tlogin tlp-rdw tlp-stat tlsa tlsh tlsh_unittest tlslookup tmail tmap tmate tmd710_tncsetup tmexpand tmfs tmispell tml tmperamental tmpl tmserver tmux tmuxinator tmuxp tmx-POStagger tmx-explode tmx-tokenize tmx2html tmx2tmx tmxclean tmxgrep tmxrasterizer tmxsplit tmxuniq tmxviewer tmxwc tnat64 tnat64-validateconf tnb tnef tnftp to-data-uri toGrimmFormat toMultiFastA toRawSequence to_erl to_fasta.py toacme toast tobin toc2cddb toc2cue todo todo-txt todo.txt-base todoman todos toe (1) - table of (terminfo) entries tofi tofi-drun tofi-run tofits togeomview toil toil-cwl-runner toil-wdl-runner toilet toix toke tokenize-rt tolua tolua++5.1 tomac tomahawk-rsync3 tomahawk3 tomb tombo tomboy-ng tomcat9-instance-create tomf toml2bson toml2json toml2yaml tomljson tomll toms tone_map tones tool_mmap_read tool_watch tooledit toolstash toot tootle top (1) - display Linux processes topal topal-fix-email topal-fix-folder topcat topcom-B_A topcom-B_A_center topcom-B_D topcom-B_D_center topcom-B_S topcom-B_S_center topcom-Dnxk topcom-binomial topcom-check topcom-checkregularity topcom-chiro2allfinetriangs topcom-chiro2alltriangs topcom-chiro2circuits topcom-chiro2cocircuits topcom-chiro2dual topcom-chiro2finetriang topcom-chiro2finetriangs topcom-chiro2mintriang topcom-chiro2nallfinetriangs topcom-chiro2nalltriangs topcom-chiro2ncircuits topcom-chiro2ncocircuits topcom-chiro2nfinetriangs topcom-chiro2ntriangs topcom-chiro2placingtriang topcom-chiro2triangs topcom-cocircuits2facets topcom-cross topcom-cube topcom-cyclic topcom-hypersimplex topcom-kDn topcom-lattice topcom-permutahedron topcom-points2allfinetriangs topcom-points2alltriangs topcom-points2chiro topcom-points2circuits topcom-points2cocircuits topcom-points2facets topcom-points2finetriang topcom-points2finetriangs topcom-points2flips topcom-points2gale topcom-points2mintriang topcom-points2nallfinetriangs topcom-points2nalltriangs topcom-points2ncircuits topcom-points2ncocircuits topcom-points2nfinetriangs topcom-points2nflips topcom-points2ntriangs topcom-points2placingtriang topcom-points2prettyprint topcom-points2symmetries topcom-points2triangs topcom-points2vertices topcom-points2volume topcom-santos_22_triang topcom-santos_dim4_triang topcom-santos_triang topconvert topdiff topdiff_gui topfd topfd_gui topformflat tophat-recondition.py topindex topindex_gui topline topmerge topmerge_gui topmg topmg_gui topoSet toppic toppic_gui topplot toppred topydo tor tor-gencert tor-print-ed-signing-cert tor-resolve torchrun torify torque_submit_workers torsocks tortoize tosca-parser totalopenstation-cli-connector totalopenstation-cli-parser totalopenstation-gui totem totem-video-thumbnailer touch_newsgroup touchpad-edge-detector touchpad-state touchy toulbar2 tovrmlx3d towncrier tox tox-bootstrapd tox-delay tox-quickstart tox-to-nox toxic tp-magic-config tp512cvt tpage tpb tpic2pdftex tping tpm-nvsize tpm2 tpm2-initramfs-tool tpm2_activatecredential tpm2_certify tpm2_certifyX509certutil tpm2_certifycreation tpm2_changeauth tpm2_changeeps tpm2_changepps tpm2_checkquote tpm2_clear tpm2_clearcontrol tpm2_clockrateadjust tpm2_commit tpm2_create tpm2_createak tpm2_createek tpm2_createpolicy tpm2_createprimary tpm2_dictionarylockout tpm2_duplicate tpm2_ecdhkeygen tpm2_ecdhzgen tpm2_ecephemeral tpm2_encodeobject tpm2_encryptdecrypt tpm2_eventlog tpm2_evictcontrol tpm2_flushcontext tpm2_getcap tpm2_getcommandauditdigest tpm2_geteccparameters tpm2_getekcertificate tpm2_getpolicydigest tpm2_getrandom tpm2_getsessionauditdigest tpm2_gettestresult tpm2_gettime tpm2_hash tpm2_hierarchycontrol tpm2_hmac tpm2_import tpm2_incrementalselftest tpm2_load tpm2_loadexternal tpm2_makecredential tpm2_nvcertify tpm2_nvdefine tpm2_nvextend tpm2_nvincrement tpm2_nvread tpm2_nvreadlock tpm2_nvreadpublic tpm2_nvsetbits tpm2_nvundefine tpm2_nvwrite tpm2_nvwritelock tpm2_pcrallocate tpm2_pcrevent tpm2_pcrextend tpm2_pcrread tpm2_pcrreset tpm2_policyauthorize tpm2_policyauthorizenv tpm2_policyauthvalue tpm2_policycommandcode tpm2_policycountertimer tpm2_policycphash tpm2_policyduplicationselect tpm2_policylocality tpm2_policynamehash tpm2_policynv tpm2_policynvwritten tpm2_policyor tpm2_policypassword tpm2_policypcr tpm2_policyrestart tpm2_policysecret tpm2_policysigned tpm2_policytemplate tpm2_policyticket tpm2_print tpm2_ptool tpm2_quote tpm2_rc_decode tpm2_readclock tpm2_readpublic tpm2_rsadecrypt tpm2_rsaencrypt tpm2_selftest tpm2_send tpm2_sessionconfig tpm2_setclock tpm2_setcommandauditstatus tpm2_setprimarypolicy tpm2_shutdown tpm2_sign tpm2_startauthsession tpm2_startup tpm2_stirrandom tpm2_testparms tpm2_unseal tpm2_verifysignature tpm2_zgen2phase tpm_extendpcr tpm_getpcrhash tpm_getquote tpm_loadkey tpm_mkaik tpm_mkuuid tpm_sealdata tpm_unloadkey tpm_unsealdata tpm_updatepcrhash tpm_verifyquote tpmc tpmtoken_import tpmtoken_init tpmtoken_objects tpmtoken_protect tpmtoken_setpasswd tpot tpp tpsd tput (1) - initialize a terminal or query terminfo database tq tqdm tqftpserv tqs tqsl tr (1) - translate or delete characters trabucco trace-cmd trace-summary trace2dbest.pl trace_dump traceanon traceconvert tracedataimporter tracediff traceends tracefilter tracemerge tracepath tracepktdump traceproto.db (1) - print the route packets trace to network host tracer tracereplay tracereport traceroute-nanog (1) - print the route packets trace to network host traceroute.db (1) - print the route packets trace to network host traceroute6.db (1) - print the route packets trace to network host tracert6 tracertstats traceshark tracesplit tracesplit_dir tracestats tracesummary tracetop tracetopends track-video-features track2cdda track2track trackcat trackcmp tracker3 trackinfo tracklength tracklint trackplay trackrename tracksplit tracktag trackverify tractor trad2sim tradis_comparison tradis_essentiality tradis_gene_insert_sites tradis_merge_plots tradis_plot traffic_cache_tool traffic_crashlog traffic_ctl traffic_layout traffic_logcat traffic_logstats traffic_manager traffic_server traffic_top traffic_via train train-tesseract tran tranalign trancid trang transcalc transcriber transeq transfer_annotation_to_groups transfermii_cli transfermii_gui transfig transform (1) - apply geometric transformations to the input. transform-fdt transformPoints transformcalc transformcompose transformconvert transformix transformseq transformtags transfuse transgui transicc transip transit transit-tpp transition-check translate translate_cmip3 translit transmission-cli transmission-create transmission-daemon transmission-edit transmission-gtk transmission-qt transmission-remote transmission-remote-gtk transmission-show transmute transpose-freecell-board transposeLargeFile transset (1) - Set transparency on a window transterm traptoemail trash trash-empty trash-list trash-put trash-restore trash-rm traverso travis trayer trbdf trc_pkt_lister trcs trcsort tre tre-agrep tred (1) - transitive reduction filter for directed graphs tree (1) - list contents of directories in a tree-like format. tree-mean-lengths tree-ppuzzle tree-puzzle tree-tool tree2leafnames treeGen tree_doctor tree_recon treeannotator treeannotator2 treeify treeline trees-bootstrap trees-consensus trees-distances trees-to-SRQ treescan treeshrink.py treesize treestat treetime treeview treil trend trev trezorctl trf trial3 triangle_geometry tricensus trickle tricklectl trickled triehash trietool trietool-0.2 trim_galore trimage trimest trimseq trimspace trinculo trinity trip trisetcmp trivial_sampler trivial_synth trmon trna2sap trna2tbl trocla troff (1) - the troff processor of the groff text formatting system troff2html troff2null troff2rtf troff2text troffcvt trojan trove trove-api trove-conductor trove-fake-mode trove-guestagent trove-manage trove-mgmt-taskmanager trove-taskmanager trpc trpg trs trsg trueprint trufont truncate (1) - shrink or extend the size of a file to the specified size truncate (2) - truncate a file to a specified length truspades truspades.py trust (1) - Tool for operating on the trust policy store trust_router truststore trx-rx trx-tx tryaffix trydiffoscope tryto tryton tryton-client tryton-server tryton-server-admin tryton-server-console tryton-server-cron tryton-server-stat tryton-server-worker trytond trytond-admin trytond-console trytond-cron trytond-stat trytond-worker trytond_import_countries trytond_import_currencies trytond_import_postal_codes ts (1ssl) - OpenSSL application commands ts-contribute ts-contribute-en ts-edit ts-edit-en ts-jest ts-node ts-node-script ts-node-transpile-only ts2es ts2po ts_calibrate (1) - A test program to calibrate a touch screen used by tslib. ts_conf (1) - A test program to test the ts_conf_get() and ts_conf_set() API ts_filter ts_finddev (1) - Discover touch screen devices. ts_harvest (1) - Harvest hundreds of raw touch screen coordinates. ts_packet_insert ts_print (1) - A very basic test routine for tslib. ts_print_mt (1) - A very basic multitouch test routine for tslib. ts_print_raw (1) - A very basic test routine for tslib. ts_test (1) - A basic test routine for tslib. ts_test_mt (1) - A basic multitouch test program for tslib. ts_uinput (1) - A daemon program creating a tslib-filtered and calibrated input event device ts_verify (1) - A basic test routine for tslib's API. tsa2d32 tsc tscd tsd2a32 tsdecrypt_dvbcsa tsdecrypt_ffdecsa tsdvbsub tse3play tset (1) - terminal initialization tsfdivide tsfilter.tstools tsfinfo tsfmult tsfsmooth tsfthreshold tsfvalidate tshark tsin2gtab-phrase tsinfo tsk_comparedir (1) - compare the contents of a directory with the contents of an image or local device. tsk_gettimes (1) - Collect MAC times from a disk image into a body file. tsk_imageinfo tsk_loaddb (1) - populate a SQLite database with metadata from a disk image tsk_recover (1) - Export files from an image into a local directory tslearn tslmendian tslminfo tsmarty2c tsnd tsocks tsort (1) - perform topological sort tsp tsplay tsplot tspush tsqd tsql tsreport tss2 tss2_authorizepolicy tss2_changeauth tss2_createkey tss2_createnv tss2_createseal tss2_decrypt tss2_delete tss2_encrypt tss2_exportkey tss2_exportpolicy tss2_getappdata tss2_getcertificate tss2_getdescription tss2_getinfo tss2_getplatformcertificates tss2_getrandom tss2_gettpm2object tss2_gettpmblobs tss2_import tss2_list tss2_nvextend tss2_nvincrement tss2_nvread tss2_nvsetbits tss2_nvwrite tss2_pcrextend tss2_pcrread tss2_provision tss2_quote tss2_setappdata tss2_setcertificate tss2_setdescription tss2_sign tss2_unseal tss2_verifyquote tss2_verifysignature tss2_writeauthorizenv tssactivatecredential tsscertify tsscertifycreation tsschangeeps tsschangepps tssclear tssclearcontrol tssclockrateadjust tssclockset tsscommit tsscontextload tsscontextsave tsscreate tsscreateek tsscreateloaded tsscreateprimary tssd tssdictionaryattacklockreset tssdictionaryattackparameters tssduplicate tsseccparameters tssecephemeral tssencryptdecrypt tsserve tsserver tsseventextend tsseventsequencecomplete tssevictcontrol tssflushcontext tssgetcapability tssgetcommandauditdigest tssgetrandom tssgetsessionauditdigest tssgettime tsshash tsshashsequencestart tsshierarchychangeauth tsshierarchycontrol tsshmac tsshmacstart tssimaextend tssimport tssimportpem tssload tssloadexternal tssmakecredential tssntc2getconfig tssntc2lockconfig tssntc2preconfig tssnvcertify tssnvchangeauth tssnvdefinespace tssnvextend tssnvglobalwritelock tssnvincrement tssnvread tssnvreadlock tssnvreadpublic tssnvsetbits tssnvundefinespace tssnvundefinespacespecial tssnvwrite tssnvwritelock tssobjectchangeauth tsspcrallocate tsspcrevent tsspcrextend tsspcrread tsspcrreset tsspolicyauthorize tsspolicyauthorizenv tsspolicyauthvalue tsspolicycommandcode tsspolicycountertimer tsspolicycphash tsspolicygetdigest tsspolicymaker tsspolicymakerpcr tsspolicynv tsspolicynvwritten tsspolicyor tsspolicypassword tsspolicypcr tsspolicyrestart tsspolicysecret tsspolicysigned tsspolicytemplate tsspolicyticket tsspowerup tssquote tssreadclock tssreadpublic tssreturncode tssrewrap tssrsadecrypt tssrsaencrypt tsssequencecomplete tsssequenceupdate tsssetprimarypolicy tssshutdown tsssign tsssignapp tssstartauthsession tssstartup tssstirrandom tsstimepacket tssunseal tssverifysignature tsswriteapp tst tstclnt tstd tsung tsung-recorder tsv2csv tsv2json tsv2ods tsv2tmx tsvnc tsxs tt tt2text ttcalc ttcn3_compiler ttcn3_help ttcn3_logfilter ttcn3_logformat ttcn3_logmerge ttcn3_makefilegen ttcn3_profmerge ttcn3_repgen ttcn3_start ttconv ttcp_atm ttdebug ttdelete ttdt ttf2afm ttf2eps ttf2kotexfont ttf2pk ttf2svg (1) - font converter for SVG ttf2tfm ttf2ufm ttf2ufm_convert ttf2ufm_x2gs ttfautohint ttfautohintGUI ttfdump ttftotype42 tth tth-hash tthprep tthrfcat tthsplit tthsum ttink ttinsert ttlayout ttm ttmsplit ttree ttselect ttuner ttunique ttupdate ttut ttv ttx ttx2xgf tty (1) - print the file name of the terminal connected to standard input tty (4) - controlling terminal tty-share ttycat ttygif ttyload ttyplay ttyplot ttyrec ttyrec2ansi ttyrecv ttysend ttysig ttytime tucd tucnak tudu tulip tulip-config tulip_perspective tuna tunctl tunes2pod tunnelx tup tupi tuptime turbo_davidson.x turbo_eels.x turbo_lanczos.x turbo_spectrum.x turing turnadmin turnserver turnutils turnutils_natdiscovery turnutils_oauth turnutils_peer turnutils_stunclient turnutils_uclient tutka tuxcmd tuxguitar tuxpaint tuxpaint-config tuxpaint-import tv tv_augment tv_augment_tz tv_cat tv_check tv_count tv_extractinfo_ar tv_extractinfo_en tv_find_grabbers tv_grab_ar tv_grab_ch_search tv_grab_combiner tv_grab_eu_epgdata tv_grab_fi tv_grab_fi_sv tv_grab_fr tv_grab_huro tv_grab_is tv_grab_it tv_grab_it_dvb tv_grab_na_dd tv_grab_na_dtv tv_grab_na_tvmedia tv_grab_pt_meo tv_grab_pt_vodafone tv_grab_tr tv_grab_uk_tvguide tv_grab_zz_sdjson tv_grab_zz_sdjson_sqlite tv_grep tv_imdb tv_merge tv_remove_some_overlapping tv_sort tv_split tv_tmdb tv_to_latex tv_to_potatoe tv_to_text tv_validate_file tv_validate_grabber tvc tvcassembly tvcutils tvnamer tvoe tvtime tvtime-command tvtime-configure tvtime-scanner tvtk_doc twatch twclock tweak tweak-wrapper tweeper twiggy twiglet twill twine twinkle twinkle-console twinwave twist3 twistd3 twm twms twoLiquidMixingFoam twoPhaseEulerFoam twofeat twolame twopaco twopi (1) - filter for radial layouts of graphs twpsk twstats txiterm txixml2texi txt2bxl txt2gcal txt2gtab-phrase txt2html txt2man txt2mb txt2mzml txt2pdbdoc txt2po txt2regex txt2tags txt2ti3 txtar-addmod txtar-c txtar-goproxy txtar-x txtconv tyalpha tybg tycat tyls typecatcher typefortune typemaker typemaker2 typeoutfileinfo typeprof3.0 typeprof3.1 typeset_audio_dir typetest typop tyq tysend tz-converter tzap tzc tzdiff tzselect (1) - view timezones tzselect (8) - select a timezone tzwatch tzxlist u2f-host u2f-server u2o u8loc uacme ualpn uapevent uaputl ubuntu-build ubuntu-cloudimg-query ubuntu-core-launcher ubuntu-distro-info ubuntu-iso ubuntu-upload-permission ubxtool uc-echo ucat ucb-tr-stat ucblogo ucd-generate ucdtooff ucf (1) - Update Configuration File: preserve user changes in configuration files ucfq (1) - query the ucf database ucfr (1) - Update Configuration File Registry: associate packages with configuration files uchardet uchime ucimf_keyboard ucimf_start uclampset (1) - manipulate the utilization clamping attributes of the system or a process uclean ucmatose ucommon-config uconv ucpp ucrpf1host ucs2any (1) - generate BDF fonts containing subsets of ISO 10646-1 codepoints ucsc_gene_table_to_intervals.py ucsc_genes2gff ucspi-proxy ucspi-proxy-http-xlate ucspi-proxy-imap ucspi-proxy-log ucspi-proxy-pop3 ucspilogd ucto ucx_info ucx_perftest ucx_read_profile udaddy udav udevil udevmon udfclient udfdump udfinfo udiskie udiskie-info udiskie-mount udiskie-umount udisksctl (1) - The udisks command line tool udo udp-receiver udp-sender udp_daemon udp_daemon_jtdx udpong udpsvd udptunnel udunits2 udv ueberzug ufiformat ufo-launch ufo-mkfilter ufo-prof ufo-query ufo-runjson ufo2glyphs ufo2map ufo2otf ufomodel ufond ufonormalizer ufoslicer uftp uftp_keymgt uftpd uftpproxyd uftrace ug uget-gtk uget-gtk-1to2 uglifyjs ugrep uhd_adc_self_cal uhd_cal_rx_iq_balance uhd_cal_tx_dc_offset uhd_cal_tx_iq_balance uhd_config_info uhd_fft uhd_find_devices uhd_image_loader uhd_images_downloader uhd_rx_cfile uhd_rx_nogui uhd_siggen uhd_siggen_gui uhd_usrp_probe uhub uhub-passwd ui ui-auto-buildflags ui-auto-env ui-auto-release ui-auto-release-multi ui-auto-rsign ui-auto-shell ui-auto-sp2ui ui-auto-ubs ui-auto-update ui-auto-uvc ui-auto-version ui-gxmlcpp-version ui-utilcpp-version uic uic3 uil uim-chardict-qt5 uim-el-agent uim-el-helper-agent uim-fep uim-fep-tick uim-help uim-im-switcher-gtk uim-im-switcher-gtk3 uim-im-switcher-qt5 uim-input-pad-ja uim-input-pad-ja-gtk3 uim-m17nlib-relink-icons uim-module-manager uim-pref-gtk uim-pref-gtk3 uim-pref-qt5 uim-sh uim-toolbar-gtk uim-toolbar-gtk-systray uim-toolbar-gtk3 uim-toolbar-gtk3-systray uim-toolbar-qt5 uim-xim uinput uisp ujconv ujdet ujguess ukopp ukui-bluetooth ukui-control-center ukui-control-center-session ukui-flash-disk ukui-media-control-led ukui-menu ukui-notebook ukui-notebook-server ukui-panel ukui-power-manager-tray ukui-powermanagement ukui-powermanagement-service ukui-screensaver-backend ukui-screensaver-checkpass ukui-screensaver-command ukui-screensaver-dialog ukui-session ukui-session-tools ukui-settings-daemon ukui-sidebar ukui-system-monitor ukui-upower ukui-volume-control ukui-volume-control-applet ukui-volume-control-applet-qt ukui-window-switch ukwm ukydisplayswitch ul (1) - do underlining ulcc ulistd ulogin ulqda ultracopier um_add_service um_attach um_del_service um_fsalias um_ls_service umap umax_pp umbrello5 umd umegaya-adm umegaya-ddc-ping umegaya-guess-url umis uml_mconsole uml_mkcow uml_moo uml_mount uml_net uml_switch uml_watchdog umoci umockdev-record umockdev-run umockdev-wrapper umountavfs umps3 umps3-elf2umps umps3-mkdev umps3-objdump umshutdown umtprd umview unaccent unace unadf unagi unalz unar unattended-upgrade (8) - automatic installation of security (and other) upgrades unattended-upgrades (8) - automatic installation of security (and other) upgrades unber unbound-host unbuffer unburden-home-dir uncalled uncat unclutter-classic unclutter-xfixes uncolor uncompface uncompress.real (1) - compress and expand data uncoupledKinematicParcelDyMFoam uncoupledKinematicParcelFoam uncpk uncrustify uncrustify-kf5 undbx undelall undertime undexqv undexta unearth unexpand (1) - convert spaces to tabs unflatten (1) - adjust directed graphs to improve layout aspect ratio unhtml uni uni2ascii uni2beta unibdf2hex unibetaprep unibmp2hex unibmpbump unicharset_extractor unicode (7) - universal character set unicode_stop uniconv unicorn unicorn_rails unicoverage unicycler unicycler_align unicycler_check unicycler_polish unicycler_scrub unidesc unidup unifdef unifdefall unifont-viewer unifont1per unifontchojung unifontksx unifontpic unifuzz unigencircles unigenwidth unihelper-3.2.2 unihex2bmp unihex2png unihexfill unihexgen unihexrotate unihist unikmer uniname uninlinepdfimages union unionBedGraphs unionBugs unionfs unionfs-fuse unionfsctl unipagecount unipng2hex uniprint uniq (1) - report or omit repeated lines uniqPolishes uniqueMerCount uniquifyTrees unireverse unison unison-2.51+4.13.1 unison-2.51+4.13.1-gtk unison-2.52 unison-2.52-gtk unison-gtk unit_diff unitconv unitdiff-3.2.2 units (7) - decimal and binary prefixes units-filter units-master units_cur unity-scope-loader unix2dos unix2mac unixcat unixclient unixcmd unixserver unixterm unknown unlambda unleash-client unlink (1) - call the unlink function to remove the specified file unlink (2) - delete a name and possibly the file it refers to unlz4 unmass unmkinitramfs unmunch unmunge unoconv unopkg (1) - LibreOffice Extension Manager unp unpack_bootimg unpaper unparser unpigz (1) - compress or expand files unprocessed_raw unrar-free unroff unrooted unrpm unrtf unshar unshare (1) - run program in new namespaces unshare (2) - disassociate parts of the process execution context unshield unsort unsquashfs (1) - tool to uncompress, extract and list squashfs filesystems unstarch unstr unterm untex untoast untrigraph unworkable unwrapdiff (1) - demangle word-wrapped patches unxrandr unxz (1) - Compress or decompress .xz and .lzma files unyaffs unzck unzip (1) - list, test and extract compressed files in a ZIP archive unzip-mem unzipsfx (1) - self-extracting stub for prepending to ZIP archives unzstd (1) - zstd, zstdmt, unzstd, zstdcat - Compress or decompress .zst files unzzip unzzip-big unzzip-mem unzzip-mix upass upbibtex update-alternatives (1) - maintain symbolic links determining default commands update-boinc-applinks update-desktop-database (1) - Build cache database of MIME types handled by desktop files update-gap-workspace update-gconf-defaults update-ini-file update-maintainer update-menus update-mime-database (1) - a program to build the Shared MIME-Info database cache update-nut update-patterndb update-perl-sax-parsers (8) - (de)register Perl SAX parser modules update-sort-bed-migrate-candidates update-sort-bed-slurm update-sort-bed-starch-slurm update-storage-times update-xfonts-traditional update-yorickdoc update_blastdb update_ini update_ngon update_routes update_rubygems update_synapse_database updatedb.findutils (1) - update a file name database updateinfoxml2solv updatepofiles-2.2.4 updmap updmap-sys updmap-user updvitomp updvitype upet2mnc upfconv.x upgrade-borgmatic-config uphpmvault uplatex uplatex-dev upload-to-sheets upmendex upmpost upnpc UPower (7) - System-wide Power Management upower (1) - UPower command line tool uppltotf uprecords uprightdiff upscale_avg upscale_cap upscale_cond upscale_elasticity upscale_perm upscale_relperm upscale_relperm_benchmark upscale_relpermvisc upscale_steadystate_implicit upse123 uptex uptftopl uptime (1) - Tell how long the system has been running. upx-ucl ur urclock urdf_mem_test urdf_to_graphiz urdf_to_graphviz urifind urlbst urlencode urlextractor urlget urlout urlscan urlview urlwatch urxvt urxvtc urxvtcd urxvtd us428control usb-devices usb_printerid usbguard usbguard-notifier usbguard-notifier-cli usbguard-rule-parser usbhid-dump usbpro_firmware usbredirect usbrelay usbreset usbsdmux usbsdmux-configure usbsdmux-service usbtan-test usbview uscan usd-locate-pointer use-devel-checklib usepackage user-setup user_geometry userbindmount userchan-tester userdbctl userfeedbackctl userinfo usermetricsinput usermetricsinput-increment usermount userpasswd userpath users (1) - print the user names of users currently logged in to the current host users-admin userv usgs2sdf usnjls (1) - List the contents of a NTFS Update Sequence Number journal usrp2_card_burner usrpctl ussp-push ustreamer ustreamer-dump utalk utf7decode utf7encode utf8 (7) - an ASCII compatible multibyte Unicode encoding utf8-to-cif utf8gen utf8lookup utf8mex utf8trans utfcheck utfout utftrip utime (2) - change file last access and modification times utm2ll utmp_register utmpdump (1) - dump UTMP and WTMP files in raw format utop utop-full utox uucp uudecode uudeview uuencode uuenview uufilter uuid (3) - DCE compatible Universally Unique Identifier library uuid-config uuidcdef uuidgen (1) - create a new UUID value uuidparse (1) - a utility to parse unique identifiers uuidtrip uulog uum uuname uupdate uupick uustat uuto uuu uuwish uux uvccapture uvcdynctrl uvcdynctrl-0.2.6 uvicorn uvu uwsc uwsgi-core uwsgi_alarm_curl uwsgi_alarm_xmpp uwsgi_curl_cron uwsgi_emperor_pg uwsgi_gccgo uwsgi_geoip uwsgi_glusterfs uwsgi_graylog2 uwsgi_jvm_openjdk11 uwsgi_ldap uwsgi_lua51 uwsgi_lua52 uwsgi_mono uwsgi_php uwsgi_psgi uwsgi_python310 uwsgi_rack_ruby30 uwsgi_rados uwsgi_router_access uwsgi_sqlite3 uwsgi_xslt uxplay uxterm (1) - X terminal emulator for Unicode (UTF-8) environments uxvile uz (1) - gunzips and extracts a gzip'd tar'd archive v16-upgrade-primitives v2ctl v2ray v4l-conf v4l-info v4l2-compliance (1) - An application to test video4linux drivers v4l2-ctl (1) - An application to control video4linux drivers v4l2-sysfs-path v4l2loopback-ctl v4lctl v6pub v6tmp v_sim vacation vacuumdb vacuumlo vadm vagalume vagrant vagrant-package vainfo vala vala-0.56 vala-gen-introspect vala-gen-introspect-0.56 vala-panel vala-panel-runner valabind valabind-cc valac valac-0.56 valadoc valadoc-0.56 valentina valentina-puzzle valentina-tape valgrind (1) - a suite of tools for debugging and profiling programs valgrind-di-server (1) - Experimental debuginfo server for valgrind valgrind-listener (1) - listens on a socket for Valgrind commentary valgrind.bin (1) - a suite of tools for debugging and profiling programs validate-borgmatic-config validate-definitions validate-json validate-storage-schemas validateDescriptor validate_component validate_contigs_blat validate_contigs_mummer validate_hdmf_spec validate_kml validate_reads_blat validate_rna validateconf validns validxml valinor vam vamp-rdf-template-generator vamp-simple-host vamps vanessa_logger_sample vanessa_socket_pipe vanguards vapigen vapigen-0.56 varcall variant_caller_pipeline.py variationget variety varlink-go-certification varlink-go-interface-generator varlink-go-type-generator varna varnishadm varnishhist varnishlog varnishncsa varnishstat varnishstat_help_gen varnishtest varnishtop vart_dump_op_weights vart_dump_op_weights_2 vart_mem_read vart_mem_save vart_mem_write vart_version vasp2cif vattr vax vax780 vba vbackup vbackup-wizard vbind vbindiff vbltest vbrfix vbutil_firmware vbutil_kernel vbutil_key vbutil_keyblock vcard2pal vcat vcd-info vcd2fst vcd2lxt vcd2lxt2 vcd2vzt vcdimager vcdxbuild vcdxgen vcdxminfo vcdxrip vcf-annotate vcf-compare vcf-concat vcf-consensus vcf-contrast vcf-convert vcf-fix-newlines vcf-fix-ploidy vcf-indel-stats vcf-isec vcf-merge vcf-phased-join vcf-query vcf-shuffle-cols vcf-sort vcf-stats vcf-subset vcf-to-tab vcf-tstv vcf-validator vcf2bed vcf2birthday vcf2genomicsdb vcf2genomicsdb_init vcf2scoary vcf2starch vcf2tsv vcf_filter vcf_histogram vcf_melt vcf_sample_filter vcfallelicprimitives vcfanno vcfdiff vcffilter vcffixup vcfkeepinfo vcflib vcfstreamsort vcftools vcfuniq vcfuniqalleles vcfutils.pl vchan-socket-proxy vcs (4) - virtual console memory vcs-branch vcs-bzr vcs-custom vcs-diff vcs-export vcs-git vcs-help vcs-hg vcs-import vcs-log vcs-pull vcs-push vcs-remotes vcs-run vcs-status vcs-svn vcs-validate vcsaview vcsh vcut vd vdb-config vdb-copy vdb-decrypt vdb-diff vdb-dump vdb-dump-orig vdb-encrypt vdb-get vdb-lock vdb-passwd vdb-unlock vdb-validate vdb_lod vdb_print vdb_render vdb_view vde_autolink vde_cryptcab vde_l3 vde_over_ns vde_pcapplug vde_plug vde_plug2tap vde_switch vdens vdeq vdesk vdetelweb vdeterm vdiff vdirsyncer vdk-config-2 vdpauinfo vdr vdr-fbfe vdr-newplugin vdr-sxfe vdr-wlfe vdradmind vdw_kernelgen vecscreen vectorstats vectorstrip vedo vefte vegrep velodyne-view velvetg velvetg_127 velvetg_127_long velvetg_63 velvetg_63_long velvetg_de velvetg_long velveth velveth_127 velveth_127_long velveth_63 velveth_63_long velveth_de velveth_long velvetoptimiser vendian vennPolishes vera++ verbiste vercmp verdandi verga verify-proxy-tool verify-uselistorder verify-uselistorder-13 verify-uselistorder-14 verify-uselistorder-15 verify_blkparse verify_krb5_conf verifysmtp veroroute verse verse-dialog versioneer veusz veyon-auth-helper veyon-cli veyon-configurator veyon-master veyon-server veyon-service veyon-worker vf1 vfdb_vfd vfdecrypt vfgrep vfind vfit vfl2bdf vflbanner vfldisol vfldrvs vflmkajt vflmkcaptex vflmkekan vflmkfdb vflmkgf vflmkjpc vflmkpcf vflmkpk vflmkt1 vflmktex vflmktfm vflmkttf vflmkvf vflmkvfl vflpp vflserver vfltest vflx11 vfnmz vfontas vfs11_vfd vfte vftovp vfu vfychain vfyserv vg vgdb (1) - intermediary between Valgrind and GDB or a shell vgrabbj vgrep vgrid_to_cgns vhdiinfo vhdimount vhdl_count vhier viagee vibrate vicc victoria-metrics vidcat videogen vidir vieet view-mesh view-toolpaths view1090-mutability view3dscene viewFactorsGen view_frames viewer viewer_anim viewer_stream viewfax viewgam viewgar viewmount viewname viewnior viewperl viewres (1) - graphical class browser for Xt viewsu viewsudo viewumount vifm vifm-convert-dircolors vifm-pause vifm-screen-split vifn vig_optimize vigor vigpg viking vile vileget vilistextum vim-addon-manager vim-addons vim.basic vim.gtk3 vim.motif vim.nox vim.tiny vimdot (1) - Combined text editor and dot viewer vimix vimplate vimtutor (1) - the Vim tutor vina vina_split vinagre vinetto vip-manager vipagekite vipe vipl vips vips-8.13 vipsedit vipsheader vipsprofile vipsthumbnail virgl_test_server virsh virshbmc virt-admin virt-alignment-scan virt-builder virt-builder-repository virt-cat virt-clone virt-copy-in virt-copy-out virt-customize virt-df virt-dib virt-diff virt-edit virt-filesystems virt-format virt-get-kernel virt-host-validate virt-index-validate virt-inspector virt-install virt-log virt-login-shell virt-ls virt-make-fs virt-manager virt-p2v-make-disk virt-p2v-make-kickstart virt-p2v-make-kiwi virt-pki-query-dn virt-pki-validate virt-qemu-run virt-rescue virt-resize virt-sparsify virt-ssh-helper virt-sysprep virt-tail virt-tar-in virt-tar-out virt-v2v virt-v2v-in-place virt-viewer virt-win-reg virt-xml virt-xml-validate virt_mail virtaal virtnbd-nbdkit-plugin virtnbdbackup virtnbdmap virtnbdrestore virtual_v2.x virtualenv virtualenv-clone virtualjaguar virtuoso-t virulencefinder.py vis vis-clipboard vis-complete vis-digraph vis-menu vis-open visgrep visidata vislcg3 visolate visp-config vistrails visual-regexp visualinfo visualvm vit vitables vite viterbi vitodo vitrage vitrage-api vitrage-dbsync vitrage-dbsync-revision vitrage-dbsync-stamp vitrage-graph vitrage-ml vitrage-notifier vitrage-persistor vitrage-purge-data vitrage-snmp-parsing vitrage-status viwsl vkcube vkcube-wayland vkcubepp vkd3d-compiler vkd3d-gears vkd3d-triangle vkeybd vl vlbi_server_dummy vlbi_server_json vlc vlc-wrapper vldiff vlevel vlevel-jack vlmerge vlmgr vlna vlock vlog vlpatch vltsv vm vm-support vmagent vmake vmalert vmatch vmatchselect vmauth vmbackup vmctl vmdb2 vmdkinfo vmdkmount vmg vmgen vmgen-0.7.3 vmhgfs-fuse vmpk vmrestore vmstat (8) - Report virtual memory statistics vmtoolsd vmtouch vmware-alias-import vmware-checkvm vmware-hgfsclient vmware-namespace-cmd vmware-rpctool vmware-toolbox-cmd vmware-user vmware-user-suid-wrapper vmware-vgauth-cmd vmware-vmblock-fuse vmware-xferlogs vmwarectrl vmwgfxctrl vnccapture vncsnapshot vnl-align vnl-filter vnl-gen-header vnl-join vnl-make-matrix vnl-sort vnl-tail vnl-ts vnl-uniq vnstat vnstati vobcopy voctocore voctogui voctolight voctomix-generate-cut-list voctomix-ingest voctomix-record-mixed-av voctomix-record-timestamp voctopvf voikkogc voikkohyphenate voikkospell voikkovfstc vokoscreenNG volint volk-config-info volk_gnsssdr-config-info volk_gnsssdr_profile volk_modtool volk_profile voltron volume_key volumeicon voms-proxy-destroy2 voms-proxy-destroy3 voms-proxy-fake voms-proxy-info2 voms-proxy-info3 voms-proxy-init2 voms-proxy-init3 voms-proxy-list voms-verify vorbiscomment vorbisgain vorbistagedit voro++ voronoi voronota voronota-cadscore voronota-contacts voronota-membrane voronota-pocket voronota-resources voronota-volumes voronota-voromqa vorta votca_compare votca_help2doc votca_property votour vows voxel2fixel voxel2mesh voxeltoworld vp vpassert vpcd-config vpcs vpe vpl-inspect vpl2mod vpl2ovp vpl2vpl vpnbridge vpnclient vpncmd vpnns vpnserver vppreproc vprerex vptovf vpxdec vpxenc vramsteg vrename vrfy vrm vrml2oogl vrms vs2osisref vs2osisreftxt vsave vsd2odg vsd2raw vsd2text vsd2xhtml vsearch vseqinfo vseqselect vsftpdwho vshadowdebug vshadowinfo vshadowmount vshow vslvminfo vslvmmount vss2raw vss2text vss2xhtml vstp vstream-client vstree2tex vsubseqselect vt vtable-dumper vtep-ctl vterm-ctrl vterm-dump vtgamma vtk7 vtkEncodeString-7.1 vtkHashSource-7.1 vtkParseJava-7.1 vtkParseJava-9.1 vtkParseJava-pv5.11 vtkProbeOpenGLVersion-9.1 vtkProbeOpenGLVersion-pv5.11 vtkProcessXML-pv5.11 vtkUnstructuredToFoam vtkWrapClientServer-pv5.11 vtkWrapHierarchy-7.1 vtkWrapHierarchy-9.1 vtkWrapHierarchy-pv5.11 vtkWrapJava-7.1 vtkWrapJava-9.1 vtkWrapJava-pv5.11 vtkWrapPython-7.1 vtkWrapPython-9.1 vtkWrapPython-pv5.11 vtkWrapPythonInit-7.1 vtkWrapPythonInit-9.1 vtkWrapPythonInit-pv5.11 vtkWrapTcl-7.1 vtkWrapTclInit-7.1 vtkprotoc-pv5.11 vtkpython-9.0 vtprint vtprtoff vtprton vttdemux vttest (1) - test VT100-type terminal vtwm vulkaninfo vulture vuname vvmd vvmplayer vvp vwebp vym vzt2vcd vztminer w (1) - Show who is logged on and what they are doing. w1find w1retap w1sensors w2do w2html w2l w2text w3m w3mman w90chk2chk.x w90pov w90spn2spn.x w90vdw.x w9wm wApua w_scan wadc wadccli waei wafw00f wagon wagon_test wait-for-it wait41 waitress-serve wajig wakeonlan wall (1) - write a message to all users wallFunctionTable wallstreet walrus wamp wandiocat wannier90.x wannier_ham.x wannier_plot.x wapiti wapiti-getcookie wapua warg warp warp2metric warpconvert warpcorrect warpinit warpinvert wash wasm-as wasm-ctor-eval wasm-decompile wasm-dis wasm-emscripten-finalize wasm-fuzz-types wasm-interp wasm-ld wasm-ld-13 wasm-ld-14 wasm-ld-15 wasm-metadce wasm-objdump wasm-opcodecnt wasm-opt wasm-reduce wasm-shell wasm-split wasm-strip wasm-validate wasm2c wasm2js wasm2wat wast2json wat-desugar wat2wasm watch (1) - execute a program periodically, showing output fullscreen watch-mimedefang watch-multiple-mimedefangs.tcl watcher watcher-api watcher-api-wsgi watcher-applier watcher-db-manage watcher-decision-engine watcher-status watcher-sync watcher-wsgi-api watchgnupg (1) - Read and print logs from a socket watchgod watchman watchman-make watchman-wait watchmedo water waterfall watershed wav2cdr wavbreaker wavcmp wavemon wavesurfer wavgen wavinfo wavmerge wavpack wavtool-pl wavtopvf waybar wayfire wayland-scanner wayland-scanner++ wayout waypipe wayvnc wb wb-add-alias wb-add-claim wb-add-qualifier wb-add-reference wb-aliases wb-claims wb-config wb-convert wb-create-entity wb-data wb-delete-entity wb-description wb-edit-entity wb-generate-template wb-hub wb-id wb-label wb-lang wb-lemma wb-merge-entity wb-move-claim wb-move-qualifier wb-open wb-props wb-query wb-remove-alias wb-remove-claim wb-remove-qualifier wb-remove-reference wb-revisions wb-search wb-set-alias wb-set-description wb-set-label wb-sparql wb-summary wb-update-claim wb-update-qualifier wb_command wb_shortcuts wb_view wbar wbemcli wbinfo wbmp2xbm wbmptopbm wbox wbxml2xml wc (1) - print newline, word, and byte counts for each file wcalc wcap-decode wcc wcch wcd.exec wcgrep wcmgr wcs-grab wcs-match wcs-pv2sip wcs-rd2xy wcs-resample wcs-to-tan wcs-xy2rd wcsgrid wcshead wcsinfo wcslint wcsremap wcsware wd wdc wddel wdel wdf wdf-cat wdf-dump wdiff wdisplays wdm wdmLogin wdq wdread wdreg wdwrite we weasyprint weather weather-util weave web2disk web2py2po webalizer webassets webazolver webcam webcamd webcamd-setup webcamoid webcheckout webcollage-helper webdeploy webdis webdruid webdruid-resolve webfsd webgrab webhook webhttrack webidl2pas-3.2.2 webissues weblate-discover weblint weblogo webm2pes webm2ts webm_info webmlmd webmlmd.rc weborf webpack webpinfo webpmux webpng webquiz websocketd websockify websploit webtidy webtidy5 webvtt weechat weechat-curses weechat-headless weeder weevely weex weight weightwatcher weirdx weka welcome2l welle-cli welle-io weplab westcos-tool weston weston-calibrator weston-clickdot weston-cliptest weston-confine weston-content_protection weston-debug weston-dnd weston-editor weston-eventdemo weston-flower weston-fullscreen weston-image weston-info weston-multi-resource weston-presentation-shm weston-resizor weston-scaler weston-screenshooter weston-simple-damage weston-simple-dmabuf-egl weston-simple-dmabuf-feedback weston-simple-dmabuf-v4l weston-simple-egl weston-simple-shm weston-simple-touch weston-smoke weston-stacking weston-subsurfaces weston-terminal weston-touch-calibrator weston-transformed wev wf-recorder wfck2r.x wfdd.x wfindent wflinfo wfserver wfst_build wfst_run wfuse wfuzz wfview wg wg-quick wgdb wget (1) - The non-interactive network downloader. wget2 wgoto wgsim wgsim_eval.pl whalebuilder wham wham-build what-patch whatis (1) - display one-line manual page descriptions whatweb wheel wheezy.template-python3 when whenever wheneverize whereis (1) - locate the binary, source, and manual page files for a command which-pkg-broke which-pkg-broke-build which.debianutils (1) - locate a command which.gnu whichdb whichman whiff whip-client whipper whiptail (1) - display dialog boxes from shell scripts whirlpool-hash whirlpooldeep whirlpoolsum whisper-auto-resize whisper-auto-update whisper-create whisper-diff whisper-dump whisper-fetch whisper-fill whisper-info whisper-merge whisper-resize whisper-set-aggregation-method whisper-set-xfilesfactor whisper-update whitedune who (1) - show who is logged on who-permits-upload who-uploads who@ whoami (1) - print effective user name whodepends whohas whois (1) - client for the whois directory service whoismac whowatch why3 widemargin widget (1p) - Demonstration of Perl/Tk widgets widl-stable wifi wifi-menu wifi-qr wifi-status wig wig2bed wig2starch wigeon wiggle wiggle2gff3 wiggle_to_array_tree.py wiggle_to_binned_array.py wiggle_to_chr_binned_array.py wiggle_to_simple.py wiipdf wike wiki-toolkit-delete-node wiki-toolkit-rename-node wiki-toolkit-revert-to-date wiki-toolkit-setupdb wiki2beamer wikipedia wikipedia2text wikitrans wikkid-serve wildmidi wily wimappend wimapply wimcapture wimdelete wimdir wimexport wimextract wiminfo wimjoin wimlib-imagex wimmount wimmountrw wimoptimize wimsplit wimunmount wimupdate wimverify win (3form) - make and break form window and subwindow associations win (3menu) - make and break menu window and subwindow associations window-size windowBed windowMaker windowlab windowmasker windowmasker_2.2.22_adapter wine-stable wine64-stable wineboot-stable winebuild-stable winecfg-stable wineconsole-stable winecpp-stable winedbg-stable winedump-stable winefile-stable wineg++-stable winegcc-stable winemaker-stable winepath-stable wineserver-stable winff-gtk2 winff-qt wings3d winicontopam winicontoppm wininfo winpr-hash winpr-makecert winrmcp winsegshuffle winwrangler wipe wiredpanda wirefilter wireframe wireguard-go wireplumber wireshark (1) - Interactively dump and analyze network traffic wish wish8.6 wit with-lock-ex withsctp wixl wixl-heat wj200_vfd wkhtmltoimage wkhtmltopdf wks2csv wks2ods wks2raw wks2text wktimer wl-copy wl-paste wlancap2wpasec wlangenpmk wlangenpmkocl wlc wld wldd wlfreerdp wlmscpfs wlock wlogin wlogout wlr-randr wlsunset wm-icons-config wm2 wmCalClock wmWeather wmacpi wmacpi-cli wmagnify wmail wmaker wmanager wmanager-loop wmanagerrc-update wmauda wmb wmbattery wmbiff wmbubble wmbutton wmc-stable wmcalc wmcalclock wmccc wmcdplay wmcliphist wmclock wmclockmon wmclockmon-cal wmclockmon-config wmcoincoin wmcore wmcpuload wmctrl wmcube wmd wmdiskmon wmdocker wmdrawer wmf wmf2eps wmf2fig wmf2gd wmf2svg wmf2x wmfire wmforecast wmforkplop wmfrog wmfsm wmgenmenu wmget wmgtemp wmgui wmhdplop wmifinfo wmifs wminput wmitime wmiv wmix wmk wml wml-params-conf wmload wmlongrun wmlsc wmlsdasm wmmemload wmmenugen wmmisc wmmixer wmmon wmmoonclock wmname wmnd wmnet wmnut wmpanpan wmpinboard wmpomme wmppp wmrack wmressel wmsetbg wmshutdown wmslite wmstickynotes wmsun wmsysmon wmsystemtray wmtemp wmtime wmtop wmtv wmwave wmweather wmweather+ wmwork wmxres wn wnb wnck-urgency-monitor wnckprop wnntouch wnpp-alert wnpp-check wob wobble wod wodim woff woff2_compress woff2_decompress woff2_info woff2sfnt woff2sfnt-zopfli wofi wofm2opl wopen wopl2ofm word-at-a-time word-list-compress (1) - word list compressor/decompressor for GNU Aspell wordbib2xml wordbreaker wordcloud_cli wordcount wordfinder wordgrinder wordlist2dawg wordmatch wordnet wordview work_queue_example work_queue_factory work_queue_graph_log work_queue_pool work_queue_server work_queue_status work_queue_submit_common work_queue_worker worker workgen worklog workmanir workmanir_sw workrave worldtovoxel wormhole wormhole-william worms wossdata wossinput wossname wossoperation wossoutput wossparam wosstopic wovf2ovp wovp2ovf wp-setup wp2latex wp2t wp2x wpa_gui wpa_passphrase (8) - Generate a WPA PSK from an ASCII passphrase for a SSID wpaclean wpan-hwsim wpan-ping wpctl wpd2epub wpd2html wpd2odt wpd2raw wpd2text wpe wpexec wpg2odg wpg2raw wpg2svg wps2epub wps2html wps2odt wps2raw wps2text wput wq_maker wrap-and-sort wrapit77 wraplinux wrapsrv wrc-stable wreplace wrestool write (1) - send a message to another user write (2) - write to a file descriptor write-mime-multipart writeActiveDesignVariables writeMeshObj writeMorpherCPs write_datamatrix writebuffer writems wrjpgcom wrk wrudf wsapi.cgi wsapi.fcgi wscat wsclean wsdl wsdl2 wsdl2h wsdl2hed wsdl2perl wsdump wsh wsjtx wsjtx_app_version wsl wslcred wslecn wslenum wslget wslid wslinvoke wslput wsprd wsprd_jtdx wsrep_sst_backup (1) - backup helper script for the MariaDB Galera Cluster wsrep_sst_common (1) - common command line parser to be sourced by other SST scripts wsrep_sst_mariabackup (1) - mariabackup-based state snapshot transfer wsrep_sst_mysqldump (1) - mysqldump-based state snapshot transfer wsrep_sst_rsync (1) - rsync-based state snapshot transfer wsrep_sst_rsync_wan (1) - rsync_wan (rsync with delta transfers)-based state snapshot transfer wstool wt wtdbg-cns wtdbg2 wtoc wtpoa-cns wtype wuzz wuzzah wvAbw wvCleanLatex wvConvert wvDVI wvDocBook wvHtml wvLatex wvMime wvPDF wvPS wvRTF wvSummary wvText wvVersion wvWare wvWml wvdial wvdialconf wvgain wvkbd-mobintl wvtag wvtestrun wvunpack wwan wwl wwt wwwifetch wx2_conv wxAstroCapture wxcopy wxdemo wxdocs wxedid wxget wxglade wxmlgetvalue wxpaste wxperl_overload wxrc wxtbx.anomalous_differences_histogram wxtbx.inspect_r_free_flags wxtbx.plan_sad_experiment wxtbx.python wxtbx.show_build_path wxtbx.show_dist_paths wxtbx.show_file_info wxtbx.xtriage wyrd wys wzip x-grass x-tile x0tigervncserver x11-touchscreen-calibrator x11perf (1) - X11 server performance test program x11perfcomp (1) - X11 server performance comparison program x11vnc x264 x265 x2goagent x2gobasepath x2gobroker x2gobroker-daemon x2gobroker-ssh x2gobroker-testauth x2goclient x2gocmdexitmessage x2godesktopsharing x2goejectcd x2gofeature x2gofeaturelist x2gofm x2gogetapps x2gogetservers x2golistdesktops x2golistmounts x2golistsessions x2golistshadowsessions x2gomountdirs x2gopath x2goprint x2goresume-desktopsharing x2goresume-session x2goruncommand x2goserver-run-extensions x2gosessionlimit x2gosetkeyboard x2gostartagent x2gosuspend-desktopsharing x2gosuspend-session x2goterminate-desktopsharing x2goterminate-session x2goumount-session x2goversion x2vnc x2x x3270 x3270a x3270if x42-darc x42-dpl x42-fat1 x42-fil4 x42-matrixmixer8x8 x42-meter x42-mixtri x42-phaserotate x42-scope x42-spectr x42-stepseq x42-tuna x42-whirl x509-util x52output x86_64 (8) - change reported architecture in new program environment and/or set personality flags x86_64-gnu-mig x86_64-kfreebsd-gnu-addr2line x86_64-kfreebsd-gnu-ar x86_64-kfreebsd-gnu-as x86_64-kfreebsd-gnu-c++filt x86_64-kfreebsd-gnu-dwp x86_64-kfreebsd-gnu-elfedit x86_64-kfreebsd-gnu-gprof x86_64-kfreebsd-gnu-ld x86_64-kfreebsd-gnu-ld.bfd x86_64-kfreebsd-gnu-ld.gold x86_64-kfreebsd-gnu-nm x86_64-kfreebsd-gnu-objcopy x86_64-kfreebsd-gnu-objdump x86_64-kfreebsd-gnu-ranlib x86_64-kfreebsd-gnu-readelf x86_64-kfreebsd-gnu-size x86_64-kfreebsd-gnu-strings x86_64-kfreebsd-gnu-strip x86_64-linux-gnu-accel-amdgcn-amdhsa-gcc x86_64-linux-gnu-accel-amdgcn-amdhsa-gcc-11 x86_64-linux-gnu-accel-amdgcn-amdhsa-gcc-12 x86_64-linux-gnu-accel-nvptx-none-gcc x86_64-linux-gnu-accel-nvptx-none-gcc-10 x86_64-linux-gnu-accel-nvptx-none-gcc-11 x86_64-linux-gnu-accel-nvptx-none-gcc-12 x86_64-linux-gnu-addr2line (1) - convert addresses or symbol+offset into file names and line numbers x86_64-linux-gnu-ar (1) - create, modify, and extract from archives x86_64-linux-gnu-as (1) - the portable GNU assembler. x86_64-linux-gnu-c++filt (1) - demangle C++ and Java symbols x86_64-linux-gnu-ccom x86_64-linux-gnu-cpp x86_64-linux-gnu-cpp-10 x86_64-linux-gnu-cpp-11 x86_64-linux-gnu-cpp-12 x86_64-linux-gnu-cxxcom x86_64-linux-gnu-dwp (1) - The DWARF packaging utility x86_64-linux-gnu-elfedit (1) - update ELF header and program property of ELF files x86_64-linux-gnu-fltk-config x86_64-linux-gnu-fpc-3.2.2 x86_64-linux-gnu-fpcmkcfg-3.2.2 x86_64-linux-gnu-fpcres-3.2.2 x86_64-linux-gnu-g++ x86_64-linux-gnu-g++-10 x86_64-linux-gnu-g++-11 x86_64-linux-gnu-g++-12 x86_64-linux-gnu-gcc x86_64-linux-gnu-gcc-10 x86_64-linux-gnu-gcc-11 x86_64-linux-gnu-gcc-12 x86_64-linux-gnu-gcc-ar (1) - a wrapper around ar adding the --plugin option x86_64-linux-gnu-gcc-ar-10 (1) - a wrapper around ar adding the --plugin option x86_64-linux-gnu-gcc-ar-11 x86_64-linux-gnu-gcc-ar-12 (1) - a wrapper around ar adding the --plugin option x86_64-linux-gnu-gcc-nm (1) - a wrapper around nm adding the --plugin option x86_64-linux-gnu-gcc-nm-10 (1) - a wrapper around nm adding the --plugin option x86_64-linux-gnu-gcc-nm-11 x86_64-linux-gnu-gcc-nm-12 (1) - a wrapper around nm adding the --plugin option x86_64-linux-gnu-gcc-ranlib (1) - a wrapper around ranlib adding the --plugin option x86_64-linux-gnu-gcc-ranlib-10 (1) - a wrapper around ranlib adding the --plugin option x86_64-linux-gnu-gcc-ranlib-11 x86_64-linux-gnu-gcc-ranlib-12 (1) - a wrapper around ranlib adding the --plugin option x86_64-linux-gnu-gccbrig-10 x86_64-linux-gnu-gccbrig-11 x86_64-linux-gnu-gccgo x86_64-linux-gnu-gccgo-10 x86_64-linux-gnu-gccgo-11 x86_64-linux-gnu-gccgo-12 x86_64-linux-gnu-gcov x86_64-linux-gnu-gcov-10 x86_64-linux-gnu-gcov-11 x86_64-linux-gnu-gcov-12 x86_64-linux-gnu-gcov-dump x86_64-linux-gnu-gcov-dump-10 x86_64-linux-gnu-gcov-dump-11 x86_64-linux-gnu-gcov-dump-12 x86_64-linux-gnu-gcov-tool x86_64-linux-gnu-gcov-tool-10 x86_64-linux-gnu-gcov-tool-11 x86_64-linux-gnu-gcov-tool-12 x86_64-linux-gnu-gdc x86_64-linux-gnu-gdc-10 x86_64-linux-gnu-gdc-11 x86_64-linux-gnu-gdc-12 x86_64-linux-gnu-gfortran x86_64-linux-gnu-gfortran-10 x86_64-linux-gnu-gfortran-11 x86_64-linux-gnu-gfortran-12 x86_64-linux-gnu-gm2 x86_64-linux-gnu-gm2-10 x86_64-linux-gnu-gm2-11 x86_64-linux-gnu-gm2-12 x86_64-linux-gnu-gnat x86_64-linux-gnu-gnat-10 x86_64-linux-gnu-gnat-11 x86_64-linux-gnu-gnat-12 x86_64-linux-gnu-gnatbind x86_64-linux-gnu-gnatbind-10 x86_64-linux-gnu-gnatbind-11 x86_64-linux-gnu-gnatbind-12 x86_64-linux-gnu-gnatchop x86_64-linux-gnu-gnatchop-10 x86_64-linux-gnu-gnatchop-11 x86_64-linux-gnu-gnatchop-12 x86_64-linux-gnu-gnatclean x86_64-linux-gnu-gnatclean-10 x86_64-linux-gnu-gnatclean-11 x86_64-linux-gnu-gnatclean-12 x86_64-linux-gnu-gnatfind x86_64-linux-gnu-gnatfind-10 x86_64-linux-gnu-gnatfind-11 x86_64-linux-gnu-gnatgcc x86_64-linux-gnu-gnathtml x86_64-linux-gnu-gnathtml-10 x86_64-linux-gnu-gnathtml-11 x86_64-linux-gnu-gnathtml-12 x86_64-linux-gnu-gnatkr x86_64-linux-gnu-gnatkr-10 x86_64-linux-gnu-gnatkr-11 x86_64-linux-gnu-gnatkr-12 x86_64-linux-gnu-gnatlink x86_64-linux-gnu-gnatlink-10 x86_64-linux-gnu-gnatlink-11 x86_64-linux-gnu-gnatlink-12 x86_64-linux-gnu-gnatls x86_64-linux-gnu-gnatls-10 x86_64-linux-gnu-gnatls-11 x86_64-linux-gnu-gnatls-12 x86_64-linux-gnu-gnatmake x86_64-linux-gnu-gnatmake-10 x86_64-linux-gnu-gnatmake-11 x86_64-linux-gnu-gnatmake-12 x86_64-linux-gnu-gnatname x86_64-linux-gnu-gnatname-10 x86_64-linux-gnu-gnatname-11 x86_64-linux-gnu-gnatname-12 x86_64-linux-gnu-gnatprep x86_64-linux-gnu-gnatprep-10 x86_64-linux-gnu-gnatprep-11 x86_64-linux-gnu-gnatprep-12 x86_64-linux-gnu-gnatxref x86_64-linux-gnu-gnatxref-10 x86_64-linux-gnu-gnatxref-11 x86_64-linux-gnu-go-10 x86_64-linux-gnu-go-11 x86_64-linux-gnu-go-12 x86_64-linux-gnu-gofmt-10 x86_64-linux-gnu-gofmt-11 x86_64-linux-gnu-gofmt-12 x86_64-linux-gnu-gold (1) - The GNU ELF linker x86_64-linux-gnu-gp-archive (1) - archive gprofng experiment data x86_64-linux-gnu-gp-collect-app (1) - collect performance data for the target application x86_64-linux-gnu-gp-display-html (1) - generate an HTML based directory structure to browse the profiles x86_64-linux-gnu-gp-display-src (1) - display the source code, optionally interleaved with the disassembly of the target object x86_64-linux-gnu-gp-display-text (1) - display the performance data in plain text format x86_64-linux-gnu-gprof (1) - display call graph profile data x86_64-linux-gnu-gprofng (1) - the driver for the gprofng tool suite x86_64-linux-gnu-ld (1) - The GNU linker x86_64-linux-gnu-ld.bfd (1) - The GNU linker x86_64-linux-gnu-ld.gold (1) - The GNU ELF linker x86_64-linux-gnu-lto-dump-10 x86_64-linux-gnu-lto-dump-11 x86_64-linux-gnu-lto-dump-12 x86_64-linux-gnu-nm (1) - list symbols from object files x86_64-linux-gnu-objcopy (1) - copy and translate object files x86_64-linux-gnu-objdump (1) - display information from object files x86_64-linux-gnu-p++ x86_64-linux-gnu-pcc x86_64-linux-gnu-pcc-cpp x86_64-linux-gnu-pcpp x86_64-linux-gnu-pkg-config x86_64-linux-gnu-pkgconf x86_64-linux-gnu-python3-config (1) - output build options for python C/C++ extensions or embedding x86_64-linux-gnu-python3-dbg-config x86_64-linux-gnu-python3.10-config (1) - output build options for python C/C++ extensions or embedding x86_64-linux-gnu-python3.10-dbg-config x86_64-linux-gnu-python3.10d-config x86_64-linux-gnu-python3.11-config x86_64-linux-gnu-python3.11-dbg-config x86_64-linux-gnu-python3.11d-config x86_64-linux-gnu-python3d-config x86_64-linux-gnu-qmake x86_64-linux-gnu-ranlib (1) - generate an index to an archive x86_64-linux-gnu-readelf (1) - display information about ELF files x86_64-linux-gnu-size (1) - list section sizes and total size of binary files x86_64-linux-gnu-strings (1) - print the sequences of printable characters in files x86_64-linux-gnu-strip (1) - discard symbols and other data from object files x86_64-linux-gnu-valac x86_64-linux-gnu-valac-0.56 x86_64-linux-gnux32-addr2line x86_64-linux-gnux32-ar x86_64-linux-gnux32-as x86_64-linux-gnux32-c++filt x86_64-linux-gnux32-cpp x86_64-linux-gnux32-cpp-10 x86_64-linux-gnux32-cpp-11 x86_64-linux-gnux32-cpp-12 x86_64-linux-gnux32-dwp x86_64-linux-gnux32-elfedit x86_64-linux-gnux32-g++ x86_64-linux-gnux32-g++-10 x86_64-linux-gnux32-g++-11 x86_64-linux-gnux32-g++-12 x86_64-linux-gnux32-gcc x86_64-linux-gnux32-gcc-10 x86_64-linux-gnux32-gcc-11 x86_64-linux-gnux32-gcc-12 x86_64-linux-gnux32-gcc-ar x86_64-linux-gnux32-gcc-ar-10 x86_64-linux-gnux32-gcc-ar-11 x86_64-linux-gnux32-gcc-ar-12 x86_64-linux-gnux32-gcc-nm x86_64-linux-gnux32-gcc-nm-10 x86_64-linux-gnux32-gcc-nm-11 x86_64-linux-gnux32-gcc-nm-12 x86_64-linux-gnux32-gcc-ranlib x86_64-linux-gnux32-gcc-ranlib-10 x86_64-linux-gnux32-gcc-ranlib-11 x86_64-linux-gnux32-gcc-ranlib-12 x86_64-linux-gnux32-gccbrig-10 x86_64-linux-gnux32-gccbrig-11 x86_64-linux-gnux32-gccgo x86_64-linux-gnux32-gccgo-10 x86_64-linux-gnux32-gccgo-11 x86_64-linux-gnux32-gccgo-12 x86_64-linux-gnux32-gcov x86_64-linux-gnux32-gcov-10 x86_64-linux-gnux32-gcov-11 x86_64-linux-gnux32-gcov-12 x86_64-linux-gnux32-gcov-dump x86_64-linux-gnux32-gcov-dump-10 x86_64-linux-gnux32-gcov-dump-11 x86_64-linux-gnux32-gcov-dump-12 x86_64-linux-gnux32-gcov-tool x86_64-linux-gnux32-gcov-tool-10 x86_64-linux-gnux32-gcov-tool-11 x86_64-linux-gnux32-gcov-tool-12 x86_64-linux-gnux32-gdc x86_64-linux-gnux32-gdc-10 x86_64-linux-gnux32-gdc-11 x86_64-linux-gnux32-gdc-12 x86_64-linux-gnux32-gfortran x86_64-linux-gnux32-gfortran-10 x86_64-linux-gnux32-gfortran-11 x86_64-linux-gnux32-gfortran-12 x86_64-linux-gnux32-gm2 x86_64-linux-gnux32-gm2-10 x86_64-linux-gnux32-gm2-11 x86_64-linux-gnux32-gm2-12 x86_64-linux-gnux32-gnat x86_64-linux-gnux32-gnat-10 x86_64-linux-gnux32-gnat-11 x86_64-linux-gnux32-gnat-12 x86_64-linux-gnux32-gnatbind x86_64-linux-gnux32-gnatbind-10 x86_64-linux-gnux32-gnatbind-11 x86_64-linux-gnux32-gnatbind-12 x86_64-linux-gnux32-gnatchop x86_64-linux-gnux32-gnatchop-10 x86_64-linux-gnux32-gnatchop-11 x86_64-linux-gnux32-gnatchop-12 x86_64-linux-gnux32-gnatclean x86_64-linux-gnux32-gnatclean-10 x86_64-linux-gnux32-gnatclean-11 x86_64-linux-gnux32-gnatclean-12 x86_64-linux-gnux32-gnatfind x86_64-linux-gnux32-gnatfind-10 x86_64-linux-gnux32-gnatfind-11 x86_64-linux-gnux32-gnatgcc x86_64-linux-gnux32-gnathtml x86_64-linux-gnux32-gnathtml-10 x86_64-linux-gnux32-gnathtml-11 x86_64-linux-gnux32-gnathtml-12 x86_64-linux-gnux32-gnatkr x86_64-linux-gnux32-gnatkr-10 x86_64-linux-gnux32-gnatkr-11 x86_64-linux-gnux32-gnatkr-12 x86_64-linux-gnux32-gnatlink x86_64-linux-gnux32-gnatlink-10 x86_64-linux-gnux32-gnatlink-11 x86_64-linux-gnux32-gnatlink-12 x86_64-linux-gnux32-gnatls x86_64-linux-gnux32-gnatls-10 x86_64-linux-gnux32-gnatls-11 x86_64-linux-gnux32-gnatls-12 x86_64-linux-gnux32-gnatmake x86_64-linux-gnux32-gnatmake-10 x86_64-linux-gnux32-gnatmake-11 x86_64-linux-gnux32-gnatmake-12 x86_64-linux-gnux32-gnatname x86_64-linux-gnux32-gnatname-10 x86_64-linux-gnux32-gnatname-11 x86_64-linux-gnux32-gnatname-12 x86_64-linux-gnux32-gnatprep x86_64-linux-gnux32-gnatprep-10 x86_64-linux-gnux32-gnatprep-11 x86_64-linux-gnux32-gnatprep-12 x86_64-linux-gnux32-gnatxref x86_64-linux-gnux32-gnatxref-10 x86_64-linux-gnux32-gnatxref-11 x86_64-linux-gnux32-gprof x86_64-linux-gnux32-ld x86_64-linux-gnux32-ld.bfd x86_64-linux-gnux32-ld.gold x86_64-linux-gnux32-lto-dump-10 x86_64-linux-gnux32-lto-dump-11 x86_64-linux-gnux32-lto-dump-12 x86_64-linux-gnux32-nm x86_64-linux-gnux32-objcopy x86_64-linux-gnux32-objdump x86_64-linux-gnux32-ranlib x86_64-linux-gnux32-readelf x86_64-linux-gnux32-size x86_64-linux-gnux32-strings x86_64-linux-gnux32-strip x86_64-linux-musl-gcc x86_64-w64-mingw32-addr2line x86_64-w64-mingw32-ar x86_64-w64-mingw32-as x86_64-w64-mingw32-c++-posix x86_64-w64-mingw32-c++-win32 x86_64-w64-mingw32-c++filt x86_64-w64-mingw32-cpp-posix x86_64-w64-mingw32-cpp-win32 x86_64-w64-mingw32-dlltool x86_64-w64-mingw32-dllwrap x86_64-w64-mingw32-elfedit x86_64-w64-mingw32-g++-posix x86_64-w64-mingw32-g++-win32 x86_64-w64-mingw32-gcc-10-posix x86_64-w64-mingw32-gcc-10-win32 x86_64-w64-mingw32-gcc-ar-posix x86_64-w64-mingw32-gcc-ar-win32 x86_64-w64-mingw32-gcc-nm-posix x86_64-w64-mingw32-gcc-nm-win32 x86_64-w64-mingw32-gcc-posix x86_64-w64-mingw32-gcc-ranlib-posix x86_64-w64-mingw32-gcc-ranlib-win32 x86_64-w64-mingw32-gcc-win32 x86_64-w64-mingw32-gcov-dump-posix x86_64-w64-mingw32-gcov-dump-win32 x86_64-w64-mingw32-gcov-posix x86_64-w64-mingw32-gcov-tool-posix x86_64-w64-mingw32-gcov-tool-win32 x86_64-w64-mingw32-gcov-win32 x86_64-w64-mingw32-gdb x86_64-w64-mingw32-gdb-add-index x86_64-w64-mingw32-gfortran-posix x86_64-w64-mingw32-gfortran-win32 x86_64-w64-mingw32-gnat-posix x86_64-w64-mingw32-gnat-win32 x86_64-w64-mingw32-gnatbind-posix x86_64-w64-mingw32-gnatbind-win32 x86_64-w64-mingw32-gnatchop-posix x86_64-w64-mingw32-gnatchop-win32 x86_64-w64-mingw32-gnatclean-posix x86_64-w64-mingw32-gnatclean-win32 x86_64-w64-mingw32-gnatfind-posix x86_64-w64-mingw32-gnatfind-win32 x86_64-w64-mingw32-gnatkr-posix x86_64-w64-mingw32-gnatkr-win32 x86_64-w64-mingw32-gnatlink-posix x86_64-w64-mingw32-gnatlink-win32 x86_64-w64-mingw32-gnatls-posix x86_64-w64-mingw32-gnatls-win32 x86_64-w64-mingw32-gnatmake-posix x86_64-w64-mingw32-gnatmake-win32 x86_64-w64-mingw32-gnatname-posix x86_64-w64-mingw32-gnatname-win32 x86_64-w64-mingw32-gnatprep-posix x86_64-w64-mingw32-gnatprep-win32 x86_64-w64-mingw32-gnatxref-posix x86_64-w64-mingw32-gnatxref-win32 x86_64-w64-mingw32-gprof x86_64-w64-mingw32-ld x86_64-w64-mingw32-ld.bfd x86_64-w64-mingw32-lto-dump-posix x86_64-w64-mingw32-lto-dump-win32 x86_64-w64-mingw32-nm x86_64-w64-mingw32-objcopy x86_64-w64-mingw32-objdump x86_64-w64-mingw32-pkg-config x86_64-w64-mingw32-ranlib x86_64-w64-mingw32-readelf x86_64-w64-mingw32-size x86_64-w64-mingw32-strings x86_64-w64-mingw32-strip x86_64-w64-mingw32-widl x86_64-w64-mingw32-windmc x86_64-w64-mingw32-windres x86dis x86info xa xaces3 xacpi-simple xadump xalan xandikos xaos xapers xapers-adder xapian-check xapian-compact xapian-config xapian-delve xapian-metadata xapian-pos xapian-progsrv xapian-replicate xapian-replicate-server xapian-tcpsrv xarchiver (1) - GTK+ front end for managing archives xarclock xargs (1) - build and execute command lines from standard input xas_viewer xastir xastir_udp_client xasy xattr (7) - Extended attributes xaumix xauth (1) - X authority file utility xautolock xavs2 xawtv xawtv-remote xaylet xbacklight xball xbanish xbatmon-simple xbatmon-simple-tray xbattbar xbflash.qspi xbiff (1) - mailbox flag for X xbindkeys xbindkeys-config xbindkeys_autostart xbindkeys_show xbmgmt xbmtopbm xboxdrv xboxdrvctl xbrlapi (1) - X11 BrlAPI helper for Linux/Unix xbrnetwork xbrnetwork-ui xbrzscale xbs xbsh xbtop xbuffy xbuild xbuilder xbuilder-simple xbutil xc xc-info xc-threshold xc2c_warp xc3sprog xca xcadabra xcalc (1) - scientific calculator for X xcalib xcam xcape xcas xcb xcfa xcfa_cli xchm xcircuit xclbinutil xclip xclip-copyfile xclip-cutfile xclip-pastefile xclipboard (1) - X clipboard client xclock (1) - analog / digital clock for X xcmsdb (1) - Device Color Characterization utility for X Color Management System xcolmix xcolors xcolorsel xcompmgr xconsole (1) - monitor system console messages with X xconv.pl xcos xcrysden xctest_qe_libxc.x xcursorgen (1) - create an X cursor file from a collection of PNG images xcutsel (1) - interchange between cut buffer and selection xcwcp xcwd xd xdaliclock xdelta xdelta-config xdelta3 xdemorse xdeview xdfcopy xdfformat xdg-autostart xdg-dbus-proxy (1) - D-Bus proxy xdg-desktop-icon (1) - command line tool for (un)installing icons to the desktop xdg-desktop-menu (1) - command line tool for (un)installing desktop menu items xdg-email (1) - command line tool for sending mail using the user's preferred e-mail composer xdg-icon-resource (1) - command line tool for (un)installing icon resources xdg-mime (1) - command line tool for querying information about file type handling and adding descriptions for new file types xdg-open (1) - opens a file or URL in the user's preferred application xdg-screensaver (1) - command line tool for controlling the screensaver xdg-settings (1) - get various settings from the desktop environment xdg-user-dir (1) - Find an XDG user dir xdg-user-dirs-gtk-update xdg-user-dirs-update (1) - Update XDG user dir configuration xdhamma xditview (1) - display ditroff output xdm xdms xdo xdot xdotool xdpyinfo (1) - display information utility for X xdrawchem xdriinfo (1) - query configuration information of DRI drivers xdt-autogen xdt-csource xdu xduplic-copier xdvi xdvi-xaw xdvipdfmx xdx xe xedit (1) - simple text editor for X xelatex xelatex-dev xemacs-21.4.24-mule xemacs-21.4.24-mule-canna-wnn xemacs-21.4.24-nomule xemacs21-mule xemacs21-mule-canna-wnn xemacs21-nomule xembedsniproxy xen-cpuid xen-create-image xen-create-nfs xen-delete-image xen-detect xen-list-images xen-resize-guest xen-update-image xenalyze xenapi_bootstrap xencons xencov_split xenstore xenstore-chmod xenstore-control xenstore-exists xenstore-list xenstore-ls xenstore-read xenstore-rm xenstore-watch xenstore-write xentrace_format xep xetex xev (1) - print contents of X events xeyes (1) - a follow the mouse X demo xfaces xfburn (1) - Simple CD/DVD burning tool xfce-build xfce-do-release xfce-get-release-notes xfce-get-translations xfce-update-news xfce4-about (1) - About and Credits dialog for Xfce xfce4-accessibility-settings (1) - Accessibility settings for Xfce xfce4-appearance-settings (1) - Appearance settings for Xfce xfce4-appfinder (1) - Xfce 4 Appfinder xfce4-appmenu-plugin-disable xfce4-appmenu-plugin-enable xfce4-clipman xfce4-clipman-history xfce4-clipman-settings xfce4-color-settings xfce4-dict (1) - a client program to query different dictionaries xfce4-display-settings (1) - Display settings for Xfce xfce4-find-cursor xfce4-keyboard-settings (1) - Keyboard settings for Xfce xfce4-mime-helper xfce4-mime-settings (1) - MIME settings for Xfce xfce4-mouse-settings (1) - Mouse settings for Xfce xfce4-notifyd-config (1) - configuration GUI for xfce4-notifyd xfce4-panel (1) - A panel for the Xfce4 desktop environment xfce4-panel-profiles xfce4-popup-applicationsmenu xfce4-popup-clipman xfce4-popup-clipman-actions xfce4-popup-directorymenu xfce4-popup-places (1) - quick access to folders, documents and removable media xfce4-popup-whiskermenu (1) - shows Whisker Menu xfce4-popup-windowmenu xfce4-power-manager (1) - The Xfce 4 Power manager xfce4-power-manager-settings (1) - Settings dialog for the Xfce 4 Power manager xfce4-screenshooter (1) - manual page for xfce4-screenshooter: Cannot open display: xfce4-sensors (1) - Sensors application for xfce4 xfce4-session (1) - Starts up the Xfce Desktop Environment xfce4-session-logout (1) - Logs out from Xfce xfce4-session-settings (1) - Session settings for Xfce xfce4-settings-editor (1) - Settings editor for Xfce xfce4-settings-manager (1) - Settings manager for Xfce xfce4-taskmanager (1) - a task (system process) manager for Xfce. xfce4-terminal (1) - A Terminal emulator for X xfce4-terminal.wrapper xfconf-query (1) - Command line utility for xfconf system xfd (1) - display all the characters in an X font xfdesktop (1) - The Xfce 4 Desktop Environment's desktop manager xfdesktop-settings (1) - Desktop settings for Xfce xfe xfhelp4 xfig xfimage xflock4 xfmconcat xfminvert xfoil xfontsel (1) - point and click selection of X11 font names xfpack xfpt xfreerdp xfrun4 (1) - Xfce 4 Appfinder xfsettingsd (1) - XSettings daemon for Xfce xfsinfo xfte xfwm4 (1) - Window manager for Xfce xfwm4-settings (1) - General settings for Xfce window manager xfwm4-tweaks-settings (1) - Advanced settings for Xfce window manager xfwm4-workspace-settings (1) - Workspace settings for Xfce window manager xfwrite xgamma (1) - Alter a monitor's gamma correction through the X server xgboost xgbsplay xgc (1) - X graphics demo xgettext (1) - extract gettext strings from source xgettext.pl xgfconfig xgfmerge xgfupdate xgnokii xgps xgpsspeed xgridfit xgterm xhc-hb04 xhc-hb04-accels xhc-whb04b-6 xhfs xhk xhlatex xhost (1) - server access control program for X xhtml2pdf3 xhtml2ps xhydra xiccd (8) - X color management daemon xicclu xidle xilogin ximtool ximtoppm xindex xindy xine xine-bugreport xine-check xine-list-1.2 xine-remote xininfo xinit (1) - X Window System initializer xinput xinput_calibrator xiph2vclt xiphos xiphos-nav xir xirancid xiterm+thai xjadeo xjdic xjdic_cl xjdic_sa xjdrad xjdserver xjdxgen xjed xjobs xjremote xkbbell (1) - XKB extension user utility xkbcli xkbcomp (1) - compile XKB keyboard description xkbevd (1) - XKB event daemon xkbind xkbprint (1) - print an XKB keyboard description xkbset (1) - user preference utility for XKB extensions for X xkbset-gui xkbvleds (1) - XKB extension user utility xkbwatch (1) - XKB extension user utility xkcdpass xkeycaps xkeystone xkibitz xkill (1) - kill a client by its X resource xlassie xlax xlbiff xless xlet-about-dialog xlet-settings xli xliff2odf xliff2oo xliff2po xlinks2 xlito xload (1) - system load average display for X xloadimage xlog xlogin xlogo (1) - X Window System logo xls2csv xls2ods xlsatoms (1) - list interned atoms defined on server xlsclients (1) - list client applications running on a display xlsfonts (1) - server font list displayer for X xlsx2csv xlunzip xmacroplay xmacroplay-keys xmacrorec xmacrorec2 xmag (1) - magnify parts of the screen xmake_anim xmakemol xman (1) - Manual page display program for the X Window System xmaxima xmbind xmbmon xmds2 xmdump xmdump2 xmdump3 xmdump4 xmedcon xmedcon-config xmessage (1) - display a message or query in a window (X-based /bin/echo) xmfa2maf xmfa2mfa.pl xmgrace xmi2pot5 xminicom xmix xmkmf xml-analyze xml-rpc-api2cpp xml-rpc-api2txt xml2 xml2-config xml2ads xml2ag xml2asc xml2bib xml2brl xml2dcm xml2dsr xml2end xml2gbs xml2isi xml2json xml2marc xml2odf xml2pib xml2pmx xml2pot xml2ris xml2stems xml2tbl xml2vdr xml2wbxml xml2wordbib xml2yaml xml_count xml_grep xml_merge xml_pp xml_spellcheck xml_split xmlcatalog (1) - Command line tool to parse and manipulate XML or SGML catalog files. xmlcopyeditor xmldiff xmlformat xmlget xmlif xmlindent xmllint (1) - command line XML tool xmlmantohtml xmlmerge xmlparse xmlpatch xmlpatterns xmlpatternsvalidator xmlpretty xmlroff xmlrpc xmlrpc-c-config xmlschema-json2xml xmlschema-validate xmlschema-xml2json xmlsec1 xmlsec1-config xmlsort xmlstarlet (1) - command line XML/XSLT toolkit xmltex xmltext xmltidy xmlto xmltoman xmltrip xmlwf xmobar xmode2 xmodmap (1) - utility for modifying keymaps and pointer button mappings in X xmonad xmonad-session xmore (1) - plain text display program for the X Window System xmorph xmotd xmount xmousepos xmp xmpi xmpp-dns xmppc xmpsolve xmunipack xnec2c xnecview xneur xonsh xonsh-uname xonsh-uptime xorrecord xorriso xorriso-dd-target xorriso-tcltk xorrisofs xoscope xosd-config xosview xotclsh xournal xournalpp xournalpp-thumbnailer xowish xpaaccess xpad xpaget xpainfo xpaint xpamb xpans xparmed xpaset xpath xpathFind xpdf xpdf.real xpenguins xpenguins-stop xpi-pack xpi-repack xpi-unpack xpl2gpl xplanet xplaymidi xplor2gmx xplot xplot.org xpmroot xpmtoppm xpore xppaut xpretty xprintidle xprop (1) - property displayer for X xps_exc xpstat xpstojpeg xpstopdf xpstopng xpstops xpstosvg xpython xq xqxdecode xrandr (1) - primitive command line interface to RandR extension xrdacctest xrdadler32 xrdb (1) - X server resource database utility xrdcks xrdcopy xrdcp xrdcrc32c xrdfs xrdgsiproxy xrdgsitest xrdmapc xrdp-dis xrdp-genkeymap xrdp-keygen xrdp-sesadmin xrdp-sesrun xrdpfc_print xrdpinls xrdpwdadmin xrdreplay xrdsssadmin xrefresh (1) - refresh all or part of an X screen xrestop xrfdisplay xrfdisplay_epics xrootconsole xrootd xrootd-config xrootdfs xrprof xrtQookStart xrt_mpd xrt_read_register xscanimage xschem xscreensaver xscreensaver-command xscreensaver-demo xscreensaver-settings xsct xsd xsd2inst xsd2ttcn xsdata xsdcxx xsddiagram xsdtree xsdvalidate xsec-c14n xsec-checksig xsec-cipher xsec-siginf xsec-templatesign xsec-txfmout xsec-xklient xsec-xtest xsecurelock xsel xsensors xset (1) - user preference utility for X xsetbg xsetmode (1) - set the mode for an X Input device xsetpointer (1) - set an X Input device as the main pointer xsetroot (1) - root window parameter setting utility for X xsettings-kde xsettingsd xsetwacom xsil2graphics2 xslate (1p) - Process Xslate Templates xslt-config xsltproc xsm (1) - X Session Manager xsp xsp4 xspectra.x xspim xspp xss-lock xssproxy xssstate xstarfish xstc xstdcmap (1) - X standard colormap utility xstow xsubpp (1) - compiler to convert Perl XS code into C code xsunpinyin xsunpinyin-preferences xsysinfo xt-create-xen-config xt-customize-image xt-guess-suite-and-mirror xt-install-image xt_geoip_query xtail xtb xtctl xte xtel xtensa-lx106-elf-addr2line xtensa-lx106-elf-ar xtensa-lx106-elf-as xtensa-lx106-elf-c++ xtensa-lx106-elf-c++filt xtensa-lx106-elf-cpp xtensa-lx106-elf-elfedit xtensa-lx106-elf-g++ xtensa-lx106-elf-gcc xtensa-lx106-elf-gcc-12.2.0 xtensa-lx106-elf-gcc-ar xtensa-lx106-elf-gcc-nm xtensa-lx106-elf-gcc-ranlib xtensa-lx106-elf-gcov xtensa-lx106-elf-gcov-dump xtensa-lx106-elf-gcov-tool xtensa-lx106-elf-gdc xtensa-lx106-elf-gprof xtensa-lx106-elf-ld xtensa-lx106-elf-ld.bfd xtensa-lx106-elf-lto-dump xtensa-lx106-elf-nm xtensa-lx106-elf-objcopy xtensa-lx106-elf-objdump xtensa-lx106-elf-ranlib xtensa-lx106-elf-readelf xtensa-lx106-elf-size xtensa-lx106-elf-strings xtensa-lx106-elf-strip xterm (1) - terminal emulator for X xtermcontrol xtermset xtherion xtigervncviewer xtightvncviewer xtitle xtokid xtotroff xtp_autogen_mapping xtp_basisset xtp_map xtp_modify_jobfile xtp_parallel xtp_qmmm2qm xtp_run xtp_tools xtp_update_mapfile xtrace xtract xtractore xtractprotos xtrkcad xtrlock xtrx_fft xttitle xtv xupdate xva-img xvfb-run xvidtune (1) - video mode tuner for Xorg xview xvile xvinfo (1) - Print out X-Video extension adaptor information xvkbd xvminitoppm xwallpaper xwatch xwax xwd (1) - dump an image of an X window xwdtopnm xwe xwiishow xwininfo (1) - window information utility for X xwintoppm xwit xwordgrinder xwpe xwrited xwrits xwud (1) - image displayer for X xx-cond-replace xx-cvs-diff xx-cvs-revcmp xx-diff-proxy xx-encrypted xx-filter xx-find-grep-sed xx-hg-merge xx-match xx-p4-unmerge xx-pyline xx-rename xx-sql-schemas xx-svn-diff xx-svn-resolve xx-svn-review xxd (1) - make a hexdump or do the reverse. xxdiff xxh128sum xxh32sum xxh64sum xxhsum xxkb xy-plot xy2sky xyacc xyb_range xyconv xyconvert xymoncmd xymonq xynagios xyscan xyz2kdt xyzac-trt-gui xyzbc-trt-gui xz (1) - Compress or decompress .xz and .lzma files xzcat (1) - Compress or decompress .xz and .lzma files xzcmp (1) - compare compressed files xzdec xzdiff (1) - compare compressed files xzegrep (1) - search compressed files for a regular expression xzfgrep (1) - search compressed files for a regular expression xzgrep (1) - search compressed files for a regular expression xzgv xzless (1) - view xz or lzma compressed (text) files xzmore (1) - view xz or lzma compressed (text) files xzoom y-websocket-server y2racc y4mcolorbars y4mdenoise y4mscaler y4mtopnm y4mtoppm y4munsharp yabar yabasic yabause-gtk yabause-qt yacas yacpi yad yad-icon-browser yadifa yadm yaegi yafc yagf yaggo yagi yagv yaha yakuake yambar yamdi yaml-bench-13 yaml-bench-14 yaml-bench-15 yaml2bson yaml2ini yaml2json yaml2obj yaml2obj-13 yaml2obj-14 yaml2obj-15 yaml2po yaml2toml yamllint yanagiba yangcli yangdump yanglint yangre yank yank-cli yanosim yapet yapet2csv yapf-diff yapf3 yapp yappi yapps2 yapra yaps yaql yara yara_indexer yara_mapper yarac yard yardoc yaret yarn yarnpkg yarsync yasat yash yaskkserv_make_dictionary yasm yasmet yasr yasw yat2m yatm yavta yaws yaz-asncomp yaz-client yaz-iconv yaz-icu yaz-illclient yaz-json-parse yaz-marcdump yaz-record-conv yaz-url yaz-ztest yazc ybmtopbm ycmd ydotool ydotoold ydump yeahconsole yelp (1) - browse system documentation yelp-build yelp-check yelp-new yersinia yes (1) - output a string repeatedly until killed yesod yforth yi ykchalresp ykclient ykgenerate ykinfo ykls ykman ykman-gui ykpamcfg ykparse ykpersonalize ykushcmd ylva ym2wav ymplayer ymuse yn00 ynew yodl yodl2html yodl2latex yodl2man yodl2txt yodl2whatever yodl2xml yodlpost yodlstriproff yodlverbinsert yokadi yokadid yorick yoshimi yosys yosys-abc yosys-config yosys-filterlib yosys-smtbmc yosys-witness youtube-dl youtube-download youtube-playlists youtubedl-gui yoyo yoyo-migrate ypcat ypchfn ypchsh yplan ypmatch yppasswd ypwhich yri ysh yt yt-dlp ytasm ytcc ytfzf ytnef ytnefprint ytnefprocess yubiclient yubico-piv-tool yubikey yubikey-agent yubikey-luks-enroll yubikey-luks-open yubikey-totp yubioath-desktop yubiserver yubiserver-admin yudit yui-compressor yum4 yuv2lav yuv4mpeg yuvconstants yuvconvert yuvcorrect yuvcorrect_tune yuvdeinterlace yuvdenoise yuvfps yuvinactive yuvkineco yuvmedianfilter yuvplay yuvscaler yuvsplittoppm yuvtoppm yuvycsnoise yuy2topam yyextract yyref yyt z3 z80-unknown-coff-addr2line z80-unknown-coff-ar z80-unknown-coff-as z80-unknown-coff-c++filt z80-unknown-coff-elfedit z80-unknown-coff-gprof z80-unknown-coff-ld z80-unknown-coff-ld.bfd z80-unknown-coff-nm z80-unknown-coff-objcopy z80-unknown-coff-objdump z80-unknown-coff-ranlib z80-unknown-coff-readelf z80-unknown-coff-size z80-unknown-coff-strings z80-unknown-coff-strip z80asm z80dasm z88 z88com z88d z88e z88f z88g z88h z88i1 z88i2 z88n z88o z88v z88x z_level_compensation zabbix_get zabbix_js zabbix_sender zanshin zanshin-migrator zap zaqar-bench zaqar-gc zaqar-server zaqar-sql-db-manage zaqar-status zart zathura zaway zbackup zbarcam (1) - scan and decode bar codes from a video device zbarcam-gtk zbarcam-qt zbarimg (1) - scan and decode bar codes from image file(s) zbd zcfan zck zck_delta_size zck_gen_zdict zck_read_header zckdl zcrypt zctl zdbsp zdump (8) - timezone dumper zeal zebraidx zebraidx-2.0 zebrasrv zebrasrv-2.0 zef zeisstopnm zeitgeist-daemon zeitgeist-datahub zemberek-demo zenity (1) - display GTK+ dialogs zenlisp zentest zerk zerofill zff2gff3.pl zfp zgz zhcon zile zim zimbench zimcheck zimdiff zimdump zimpatch zimrecreate zimsearch zimsplit zimwriterfs zinnia zinnia_convert zinnia_learn zint zint-qt zip zip2disk zip2st zip2zip zipUpMesh zipalign zipcloak zipcmp zipdetails (1) - display the internal structure of zip files zipgrep (1) - search files in a ZIP archive for lines matching a pattern zipinfo (1) - list detailed information about a ZIP archive zipmerge zipnote ziproxy ziproxylogtool zipserver zipsplit zipsync ziptime ziptool zita-a2j zita-at1 zita-bls1 zita-dc1 zita-dpl1 zita-j2a zita-j2n zita-lrx zita-mu1 zita-n2j zita-resampler zita-retune zita-rev1 zjsdecode zkacard-tool zkg zktop zl zleave zlib-flate zlib_mt_perf zlmdb zlocate zm_rtsp_server zmakebas zmaudit.pl zmc zmcamtool.pl zmcontrol.pl zmdc.pl zmergelog zmf2epub zmf2odg zmf2raw zmf2svg zmfilter.pl zmonvif-probe.pl zmonvif-trigger.pl zmpkg.pl zmqinput-keygen zmrecover.pl zmstats.pl zmsystemctl.pl zmtelemetry.pl zmtrack.pl zmtrigger.pl zmu zmupdate.pl zmvideo.pl zmwatch.pl zmx10.pl znc znc-buildmod znol zoe-loop zoem zomg zomghelper zone2json zone2ldap zone2sql zonemaster-cli zonetab2pot.py zooinspector zoom2sam.pl zoomsh zope-testrunner zope-testrunner3 zopfli zopflipng zoph zoxide zpaq zpcregrep zpspell zrio zrun zssh zstat zstd (1) - zstd, zstdmt, unzstd, zstdcat - Compress or decompress .zst files zstdcat (1) - zstd, zstdmt, unzstd, zstdcat - Compress or decompress .zst files zstdgrep (1) - print lines matching a pattern in zstandard-compressed files zstdless (1) - view zstandard-compressed files zstdmt (1) - zstd, zstdmt, unzstd, zstdcat - Compress or decompress .zst files zsync zsyncmake ztelnet zthread-config ztr_dump zuluCrypt-cli zuluCrypt-gui zuluMount-cli zuluMount-gui zuluPolkit zuluSafe-cli zum zun zurl zutty zvbi-atsc-cc zvbi-chains zvbi-ntsc-cc zvmsdk-gentoken zvmsdk-wsgi zwgc zwrite zx zxcvbn zxcvbn-password-strength zynaddsubfx zynaddsubfx-ext-gui zypp-CheckAccessDeleted zypp-NameReqPrv zypper zytrax zzat zzcat zzdir zzuf zzxorcat zzxorcopy zzxordir # /usr/sbin/ - Sonstige administrative programme 4g8 Almighty Ceni Crack Crack-Reporter Forcevideo-drbl-live LCDd MAKEFLOPPIES ModemManager (8) - mobile broadband modem management daemon NetworkManager Orthanc SNHELLO SNPOST a-rex-backtrace-collect a2disconf a2dismod a2dissite a2enconf a2enmod a2ensite a2query aa-audit aa-autodep aa-cleanprof aa-complain aa-decode aa-disable aa-enforce aa-genprof aa-logprof aa-mergeprof aa-remove-unknown (8) - remove unknown AppArmor profiles aa-status (8) - display various information about the current AppArmor policy. aa-teardown (8) - unload all AppArmor profiles aa-unconfined aa-update-browser accessdb (8) - dumps the content of a man-db database in a human readable format accton acpi_fakekeyd acpid activate-devpay adcli (8) - Tool for performing actions on an Active Directory domain add-shell (8) - add shells to the list of valid login shells addgnupghome (8) - Create .gnupg home directories addgroup (8) - add or manipulate users or groups addrconsole adduser (8) - add or manipulate users or groups adjtimexconfig aelparse afpd agreety ahcpd aideinit airbase-ng aireplay-ng airmon-ng airodump-ng airodump-ng-oui-update airserv-ng airtun-ng airventriloquist-ng ajoursat alfred alfred-gpsd aliaslookup alpine-chroot-install alsa-info (8) - command-line utility to gather information about the ALSA subsystem alsabat-test alsactl (1) - advanced controls for ALSA soundcard driver amaddclient amadmin amaespipe amanda-rest-server amarchiver amavis-mc amavis-services amavisd-agent amavisd-milter amavisd-nanny amavisd-new amavisd-new-cronjob amavisd-release amavisd-signer amavisd-snmp-subagent amavisd-snmp-subagent-zmq amavisd-status amavisd-submit ambackup amcheck amcheckdb amcheckdump amcleanup amcleanupdisk amcrypt amcrypt-ossl amcrypt-ossl-asym amcryptsimple amdevcheck amdump amdump_client amfetchdump amflush amgetconf amgpgcrypt amlabel amoldrecover amoverview amplot ampr-ripd amrecover amreindex amreport amrestore amrmtape amserverconfig amservice amssl amstatus amtape amtapetype amtoc amvault anacron (8) - runs commands periodically and androresolvd anope anytun ap-trapd ap51-flash apache2 (8) - Apache Hypertext Transfer Protocol Server apache2ctl apachectl apachetop apf apfsck apparmor_status (8) - display various information about the current AppArmor policy. applyfilter applygnupgdefaults (8) - Run gpgconf --apply-defaults for all users. approx approx-import aprsdigi aprsmon aprx aprx-stat apt-cacher apt-cacher-ng apt-listbugs apt-listdifferences apticron aptitude-robot aptitude-robot-session arcctl arched archery-manage arctica-greeter arctica-greeter-guest-account-script argdist-bpfcc argus arno-iptables-firewall arp (7) - Linux ARP kernel module. arp (8) - manipulate the system ARP cache arp-fingerprint arp-scan arp2ethers arpalert arpd (8) - userspace arp daemon. arpfetch arping arpon arpsnmp arpspoof arptables-legacy arptables-legacy-restore arptables-legacy-save arptables-nft (8) - ARP table administration (nft-based) arptables-nft-restore (8) - Restore ARP Tables (nft-based) arptables-nft-save (8) - dump arptables rules to stdout (nft-based) arpwatch array-info askPrinter aspell-autobuildhash (8) - Autobuilding aspell hash files for some dicts astcanary astdb2bdb astdb2sqlite3 asterisk astgenkey astraceroute astribank_allow astribank_hexload astribank_is_starting astribank_tool astversion atd (8) - run jobs queued for later execution atftpd atmaddr atmloop atmsigd atmtcp attrd_updater auth-otp authdaemond authenumerate authpasswd authtest autodir autolog automount automysqlbackup autopostgresqlbackup autosupport avahi-autoipd avahi-daemon (8) - The Avahi mDNS/DNS-SD daemon avahi-dnsconfd avcstat avivotool avr-evtd awffull_history_regen ax25_call ax25d ax25ipd ax25mond ax25rtctl ax25rtd axctl axdigi axfr-get axfrdns axfrdns-conf axmail axparms axspawn axwrapper babeld backup-manager backup.sh backup2l backupninja bacula-console bacula-dir bacula-fd bacula-sd bacula-tray-monitor bandwidthd barada-add bashreadline bashreadline-bpfcc bashreadline.bt bat batadv-vis batctl batmand battery-stats-collector baycomepp baycomusb bbackupctl bbackupd bbackupd-config bbackupquery bbconsjson bbstoreaccounts bbstored bbstored-config bcache-super-show bconsole bcopy (3) - copy byte sequence bcrelay bcron-exec bcron-sched bcron-spool bcron-start bcron-update bd_pgsql_purge bdii-update bdirjson beacon bearerbox besside-ng bextract bfdjson bgpctl bgpd bgplgd bhm bidentd bihourly bind2csv2 bindsnoop bindsnoop-bpfcc bing binkd binkdlogstat biolatency biolatency-bpfcc biolatency.bt biolatpcts-bpfcc biopattern biopattern-bpfcc biosdecode (8) - BIOS information decoder biosinfo biosnoop biosnoop-bpfcc biosnoop.bt biostacks biostacks.bt biotop-bpfcc bird bird6 birdc birdc6 birdcl bitesize bitesize-bpfcc bitesize-perf bitesize.bt bitlbee bitmask-root blackhole6 blend-role blend-update-menus blend-update-usermenus blend-user blkmapd blktool blktrace bls bluemon bluetoothd (8) - Bluetooth daemon bmc-config bmc-device bmc-info bmc-watchdog booth booth-keygen boothd bootinfoscript bootloader-config bootpd bootpef bootpgw bootptest bpfc bpflist-bpfcc bpfmon bpftool bpqparms bps br2684ctl bregex bscan bsdjson bsmtp btape btrace btraceback btrecord btreplay btrfsdist btrfsdist-bpfcc btrfsslower btrfsslower-bpfcc bucts build-openstack-debian-image bumblebeed bus bwbar bwild cache_check cache_dump cache_metadata_size cache_repair cache_restore cache_writeback cachestat cachestat-bpfcc cachestat-perf cachetop-bpfcc calibrate callback callisto calloutd cannaserver capable-bpfcc capable.bt carrousel cat_nvram cbfs-compression-tool cbfstool cc_dump cc_test cdpr ceph-create-keys ceph-volume ceph-volume-systemd cephadm cereal-admin certmonger cfingerd cgclear cgconfigparser cgrulesengd charon-cmd charon-systemd chat check-bios-nx check-selinux-installation check_forensic check_lft_balance checkgroups checkpasswd-service checkpc checkrad checkrestart checkrhosts checksecurity checksendmail chgpasswd (8) - update group passwords in batch mode chkconf chklastlog chkrootkit chkwtmp chmem (8) - configure memory chntpw choptest chpasswd (8) - update passwords in batch mode chronyd chroot (2) - change root directory chroot (8) - run command or interactive shell with special root directory chroot.fakechroot cibadmin cibsecret cifs.idmap cifs.upcall clamav-milter clamav-unofficial-sigs clamd clamonacc clamsmtpd clean-crl clickhouse-server cloneToSda clonezilla cmospwd cnid_dbd cnid_metad cntlm cnvt-ocs-dev cobjnew-bpfcc collect-reminders collectd collectdmon comedi_config comitup comitup-cli comitup-web compactsnoop-bpfcc compartment compsize compute_av compute_create compute_member compute_relabel comsatd configure-debian conmand conmux conmux-registry connman-vpnd connmand connmand-wait-online conntrack conntrackd conserver consolation convertquota corosync corosync-cfgtool corosync-cmapctl corosync-cpgtool corosync-keygen corosync-notifyd corosync-qdevice corosync-qdevice-net-certutil corosync-qdevice-tool corosync-quorumtool courier courier-mtaconfig courieresmtpd courierfilter couriergraph.pl courierldapaliasd courierlogger couriertcpd cowbuilder cpgr (8) - copy with locking the given file to the password or group file cppw (8) - copy with locking the given file to the password or group file cpu cpudist cpudist-bpfcc cpufreq cpufreqd cpufreqnextgovernor cpustat cpuunclaimed-bpfcc cpuwalk.bt cqtest cracklib-check (8) - Check passwords using libcrack2 cracklib-format (8) - cracklib dictionary utilities cracklib-packer (8) - cracklib dictionary utilities cracklib-unpacker (8) - cracklib dictionary utilities create-cracklib-dict (8) - Check passwords using libcrack2 create-debian-live create-drbl-live create-drbl-live-by-pkg create-gparted-live create-ocs-tmp-img create-ubuntu-live criticalstat-bpfcc criu criu-ns crm crm_attribute crm_diff crm_error crm_failcount crm_master crm_mon crm_node crm_report crm_resource crm_rule crm_shadow crm_simulate crm_standby crm_ticket crm_verify crmadmin cron (8) - daemon to execute scheduled commands (Vixie Cron) cron-apt crossfire-server crosshurd cryptmount-setup cserver csync2 csync2-compare ctdbd ctlinnd cups-browsed (8) - A daemon for browsing the Bonjour broadcasts of shared, remote CUPS printers cups-genppdupdate cupsaccept (8) - accept/reject jobs sent to a destination cupsctl (8) - configure cupsd.conf options cupsd (8) - cups scheduler cupsdisable (8) - stop/start printers and classes cupsenable (8) - stop/start printers and classes cupsfilter (8) - convert a file to another format using cups filters (deprecated) cupsreject (8) - accept/reject jobs sent to a destination curvedns curvedns-keygen curvetun custodia cv-ocsimg-v1-to-v2 cvsd cvsd-buginfo cvsd-buildroot cvsd-passwd cwdaemon cwnnkill cwnnstat cyclades-ser-cli cyclades-serial-client cyrdeliver cyrmaster cyrus cyrus-imspd dahdi_cfg dahdi_genconf dahdi_hardware dahdi_maint dahdi_monitor dahdi_registration dahdi_scan dahdi_span_assignments dahdi_span_types dahdi_test dahdi_tool dahdi_waitfor_span_assignments damnit danted darkstat das_watchdog dbackup dbcheck dbck dbconfig-generate-include dbconfig-load-include dbskkd-cdb dbslower-bpfcc dbstat-bpfcc dcbtool dcs dcsnoop-bpfcc dcsnoop.bt dcstat-bpfcc ddclient ddns-confgen deadlock-bpfcc deadwood debfoster2aptitude debian-edu-faiinstall debian-edu-fsautoresize debian-edu-ltsp-chroot debian-edu-ltsp-initrd debian-edu-ltsp-install debian-edu-ltsp-ipxe debian-edu-pxeinstall debian-edu-restart-services debian-edu-test-install debian-edu-update-netblock debian-installer-launcher debomatic debootstick debootstrap (8) - Bootstrap a basic Debian system debsecan-create-cron debugvmfs debugvmfs6 delgroup (8) - remove a user or group from the system deliverquota.maildrop dellLcdBrightness dellWirelessCtl delrconsole deluser (8) - remove a user or group from the system dhcp-edit dhcp-helper dhcp-lease-list dhcp6c dhcp6ctl dhcp6relay dhcp6s dhcp_probe dhcpcd dhcpd dhcpdump dhcping dhcpoptinj dhcpy6d dhcrelay dhelp_parse dhid dhisd dialtest dibbler-client dibbler-relay dibbler-server dictd dictdconfig digest-service digimend-debug diod diodcat dioddate diodload diodls diodmount diodshowmount dirtop-bpfcc dirvish dirvish-expire dirvish-runall diskdevstat dizzy-render dkms dl10k1 dlm_controld dlm_stonith dlm_tool dma dmascc_cfg dmidecode (8) - DMI table decoder dmucs dnscache dnscache-conf dnsmasq dnsproxy dnssec-trigger-control dnssec-trigger-control-setup dnssec-triggerd dnsspoof dnstraceroute doc_loadbios docfdisk docker-proxy dockerd (8) - Enable daemon mode dovecot downtimed dpkg-fsys-usrunmess (8) - undoes the merged-/usr-via-aliased-dirs mess dpkg-hold (8) - mark packages as `hold' to prevent installation dpkg-preconfigure (8) - let packages ask questions prior to their installation dpkg-purge (8) - mark packages for purge dpkg-reconfigure (8) - reconfigure an already installed package dpkg-remove (8) - mark packages for removal dpkg-unhold (8) - mark held packages for installation dpkg-unsafe-io dpkg-www-installer dpt-i2o-raideng dpt-i2o-raidutil dqcache dqcache-makekey dqcache-start drbl-3n-conf drbl-add-vir-netdev drbl-all-service drbl-aoe-img-dump drbl-aoe-serv drbl-autologin-env-reset drbl-autologin-home-reset drbl-clean-autologin-account drbl-clean-dhcpd-leases drbl-client-reautologin drbl-client-root-passwd drbl-client-service drbl-client-switch drbl-client-system-select drbl-collect-mac drbl-cp drbl-cp-host drbl-cp-user drbl-find-dhcp-srv drbl-fuh drbl-fuh-get drbl-fuh-put drbl-fuh-rm drbl-fuu drbl-fuu-get drbl-fuu-put drbl-fuu-rm drbl-gen-grub-efi-nb drbl-get-host drbl-get-user drbl-host-cp drbl-host-get drbl-host-rm drbl-live drbl-live-boinc drbl-live-hadoop drbl-login-switch drbl-netinstall drbl-ocs drbl-ocs-live-prep drbl-proxy-dhcp drbl-pxelinux-passwd drbl-rm-host drbl-rm-user drbl-sl drbl-swapfile drbl-syslinux-efi-pxe-sw drbl-syslinux-netinstall drbl-usb-netinstall drbl-user-cp drbl-user-env-reset drbl-user-get drbl-user-rm drbl-useradd drbl-useradd-file drbl-useradd-list drbl-useradd-range drbl-userdel drbl-userdel-file drbl-userdel-list drbl-userdel-range drbl4imp drblpush drblsrv drblsrv-offline driverctl dropbear drsnoop drsnoop-bpfcc dsconf dscreate dsctl dsidm dsniff dtop duende dumbnet dump-acct dump-remind dump-utmp dump.exfat (8) - Show on-disk information of exfat filesystem dump_fts dump_lfts dump_mfts dundee dwww-build dwww-build-menu dwww-cache dwww-convert dwww-find dwww-format-man dwww-index++ dwww-quickfind dwww-refresh-cache dwww-txt2html e2freefrag (8) - report free space fragmentation information e2guardian e4crypt (8) - ext4 file system encryption utility e4defrag (8) - online defragmenter for ext4 file system easside-ng ebsnvme-id ebtables-legacy ebtables-legacy-restore ebtables-legacy-save ebtables-nft (8) - Ethernet bridge frame table administration (nft-based) ebtables-nft-restore (8) - iptables using nftables kernel api ebtables-nft-save (8) - iptables using nftables kernel api ebtablesd ebtablesu ecflow_logserver ecflow_logsvr ecflow_server ecflow_start ecflow_stop ectool edac-ctl edge editmap edquota efingerd eggsh ejabberdctl ekey-rekey ekey-setkey ekeyd ekeyd-egd-linux ekeydctl elida elidad elogtool emacspeakconfig enitune epoptes-client eppfpga eql_enslave era_check era_dump era_invalidate era_restore escapesrc esekeyd esi esmtpd esmtpd-msa esmtpd-ssl ethersrv-linux etherwake ethflopd etrn eventlogadm execsnoop execsnoop-bpfcc execsnoop-perf execsnoop.bt exfat2img (8) - dump metadata of an exFAT filesystem exfatlabel (8) - Get or Set volume label or volume serial of an exFAT filesystem exicyclog (8) - Cycle exim's logfiles exigrep (8) - Search Exim's main log exim (8) - a Mail Transfer Agent exim4 (8) - a Mail Transfer Agent exim_checkaccess (8) - Check address acceptance from given IP exim_convert4r4 (8) - Convert Exim configuration from v3 to v4 format exim_dbmbuild (8) - Build a DBM file. exim_dumpdb (8) - Exim's hint databases maintenance (exim_dumpdb, exim_fixdb, exim_tidydb) exim_fixdb (8) - Exim's hint databases maintenance (exim_dumpdb, exim_fixdb, exim_tidydb) exim_lock (8) - Mailbox maintenance exim_tidydb (8) - Exim's hint databases maintenance (exim_dumpdb, exim_fixdb, exim_tidydb) eximon eximstats (8) - generates statistics from Exim mainlog or syslog files. exinext (8) - Finding individual retry times exipick (8) - selectively display messages from an Exim queue exiqgrep (8) - Search in the exim queue exiqsumm (8) - Summarising the queue exitsnoop exitsnoop-bpfcc exiwhat (8) - Finding out what Exim processes are doing exportfs ext4dist ext4dist-bpfcc ext4magic ext4slower ext4slower-bpfcc fai fai-cd fai-chboot fai-diskimage fai-make-nfsroot fai-mk-network fai-monitor fai-new-mac fai-setup fai-statoverride faillock (8) - Tool for displaying and modifying the authentication failure record files faireboot fake fancontrol farpd fastnetmon fatrace fatresize faxabort faxaddmodem faxadduser faxanswer faxconfig faxcron faxdeluser faxgetty faxinfo faxlock faxmodem faxmsg faxq faxqclean faxquit faxrunqd faxsend faxsetup faxstate faxwatch fbb fbbgetconf fbguard fcgiwrap fcheck fcm-add-svn-repos fcm-add-svn-repos-and-trac-env fcm-add-trac-env fcm-backup-svn-repos fcm-backup-trac-env fcm-commit-update fcm-daily-update fcm-install-svn-hook fcm-manage-trac-env-session fcm-manage-users fcm-recover-svn-repos fcm-recover-trac-env fcm-rpmbuild fcm-user-to-email fcm-vacuum-trac-env-db fcnsq fcoeadm fcoemon fcopy fcping fcrls fdutilsconfig fectest fence_ack_manual fence_aliyun fence_alom fence_amt fence_apc fence_apc_snmp fence_aws fence_azure_arm fence_bladecenter fence_brocade fence_cdu fence_cisco_mds fence_cisco_ucs fence_compute fence_crosslink fence_cyberpower_ssh fence_docker fence_drac fence_drac5 fence_dummy fence_eaton_snmp fence_emerson fence_eps fence_evacuate fence_gce fence_hds_cb fence_heuristics_ping fence_hpblade fence_ibm_powervs fence_ibm_vpc fence_ibmblade fence_ibmz fence_idrac fence_ifmib fence_ilo fence_ilo2 fence_ilo3 fence_ilo3_ssh fence_ilo4 fence_ilo4_ssh fence_ilo5 fence_ilo5_ssh fence_ilo_moonshot fence_ilo_mp fence_ilo_ssh fence_imm fence_intelmodular fence_ipdu fence_ipmilan fence_ipmilanplus fence_ironic fence_kdump fence_kubevirt fence_ldom fence_legacy fence_lindypdu fence_lpar fence_mpath fence_netio fence_openstack fence_ovh fence_powerman fence_pve fence_raritan fence_raritan_px3 fence_rcd_serial fence_redfish fence_rhevm fence_rsa fence_rsb fence_sanbox2 fence_sbd fence_scsi fence_skalar fence_tripplite_snmp fence_vbox fence_virsh fence_virt fence_virtd fence_vmware fence_vmware_rest fence_vmware_soap fence_vmware_vcloud fence_watchdog fence_wti fence_xenapi fence_xvm fence_zvmip ferm fetch-crl fetchnews fetchzone fgadm filefrag (8) - report on file fragmentation filelife filelife-bpfcc fileslower-bpfcc filesnarf filetea filetop filetop-bpfcc filetraq filterctl filtergen findoid fipvlan firebird firehol fireqos firewalk firewalld flash_erase flash_eraseall flash_lock flash_otp_dump flash_otp_erase flash_otp_info flash_otp_lock flash_otp_write flash_unlock flashcp flashrom flask-get-bool flask-getenforce flask-label-pci flask-loadpolicy flask-set-bool flask-setenforce flexd flow6 flowgrindd flowtop fmaptool fnotifystat foomatic-addpjloptions foomatic-cleanupdrivers foomatic-extract-text foomatic-fix-xml foomatic-getpjloptions foomatic-kitload foomatic-nonumericalids foomatic-preferred-driver foomatic-printermap-to-gutenprint-xml foomatic-replaceoldprinterids fprobe frag6 freeradius fsarchiver fsattr fsck.exfat (8) - check an exFAT filesystem fsck.gfs2 fsck.vmfs fsck.vmfs6 fsdist fsmount_kernel fsmove fsremap fsslower fstransform ftar ftl_check ftl_format ftp-proxy ftpasswd ftpd ftpmail ftpmirror ftpquota ftpscrub ftpshut ftpstats funccount-bpfcc funccount-perf funcgraph-perf funcinterval-bpfcc funclatency funclatency-bpfcc funcslower-bpfcc funcslower-perf functrace-perf fwcheck_psad fwknopd fwlogwatch fwlw_notify fwlw_respond fwsnort fxotune g15daemon ganeti-cleaner ganeti-confd ganeti-kvmd ganeti-listrunner ganeti-luxid ganeti-metad ganeti-mond ganeti-noded ganeti-rapi ganeti-watcher ganeti-wconfd gapd gconf-schemas gcpbasket gdbsx gdm3 (8) - take a picture of the screen gearmand gen-grub-efi-nb-menu genccode gencmn generate-pxe-menu genhomedircon genl (8) - generic netlink utility frontend gennorm2 gensprep geographiclib-get-geoids geographiclib-get-gravity geographiclib-get-magnetic geostore get-iab get-news get-oui getSystemId get_cyclictest_snapshot getconlist getdefaultcon getenforce getfilecon (3) - get SELinux security context of a file gethostlatency gethostlatency-bpfcc gethostlatency.bt getpidcon (3) - get SELinux security context of a process getscom getsebool getseuser getsram getweb getzone gf_attach gfmd gfork gfs-dynbe-client gfs-gfork-master gfs2_convert gfs2_edit gfs2_fsck gfs2_grow gfs2_jadd gfs2_lockcapture gfs2_mkfs gfs2_trace gfsd gjitenconfig gld globus-fork-starter globus-gatekeeper globus-gatekeeper-admin globus-gram-audit globus-gram-streamer globus-gridftp-password globus-gridftp-server globus-gridftp-server-enable-sshftp globus-gridftp-server-setup-chroot globus-job-manager globus-job-manager-lock-test globus-k5 globus-libc-hostname globus-redia globus-rvf-check globus-rvf-edit globus-scheduler-event-generator globus-scheduler-event-generator-admin globus-update-certificate-dir glocktop gluster gluster-eventsapi gluster-georep-sshkey gluster-mountbroker gluster-setgfid2path glusterd glustereventsd glusterfs glusterfsd gm-adjust_db_settings gm-backup gm-backup_data gm-backup_database gm-bootstrap_server gm-dump_schema gm-fingerprint_db gm-fixup_server gm-install_arriba gm-restore gm-restore_data gm-restore_database gm-set_gm-dbo_password gm-upgrade_server gm-zip+sign_backups gmetad gmond gnb gnb_ctl gnb_es gnokiid gnome-menus-blacklist gnt-backup gnt-cluster gnt-debug gnt-filter gnt-group gnt-instance gnt-job gnt-network gnt-node gnt-os gnt-storage gophernicus gosu gpart gparted gpm gpm-microtouch-setup gpm-mouse-test gpsd gpsdctl greetd greylistd greylistd-setup-exim4 grid-default-ca grid-mapfile-add-entry grid-mapfile-check-consistency grid-mapfile-delete-entry gridftpd grml-debootstrap grml2iso grml2usb groonga-httpd groonga-httpd-restart grossd groupadd (8) - create a new group groupdel (8) - delete a group groupmems (8) - administer members of a user's primary group groupmod (8) - modify a group definition on the system grpck (8) - verify integrity of group files grpconv (8) - convert to and from shadow passwords and groups grpunconv (8) - convert to and from shadow passwords and groups grub grub-bios-setup grub-floppy grub-install grub-macbless grub-md5-crypt grub-mkconfig grub-mkdevicemap grub-probe grub-reboot grub-set-default grub-terminfo gsm0710muxd gsmartcontrol gssproxy gt4-interface-install gtlsserver gtlsshd guess guess-helper guestfsd gvpe ha_logger halog hapolicy haproxy hardirqs hardirqs-bpfcc haveged hb_report hd-idle hdapsd hdup hfaxd hitch horst hostapd hostapd_cli hoststat hping3 hprop hpropd hpsockd htdigconfig htpasswd htpdate httpd httppower httpry httxt2dbm hunt huntd hv_fcopy_daemon hv_kvp_daemon hv_vss_daemon hwinfo hwlatdetect hwloc-dump-hwdata hwstamp_ctl hylafax_wrapper i-viewdb i2c-stub-from-dump i2cdetect i2cdump i2cget i2cset i2ctransfer i2pd i7z i7z_rw_registers ialarms iauth ibacm ibaddr ibcacheedit ibccconfig ibccquery ibfindnodesusing ibhosts ibidsverify iblinkinfo ibnetdiscover ibnodes ibping ibportstate ibqueryerrors ibroute ibrouters ibsrpdm ibstat ibstatus ibswitches ibsysstat ibtracert icecc-scheduler iceccd icinga2 icingadb icingadb-migrate icmd icmp6 icmpinfo iconfig iconvconfig (8) - create iconv module configuration cache icupkg ident2 ifdtool ifirewall ifittool ifmetric ifplugd ifplugstatus ifpps ifru ifstatus iftop ifwitool ifwum igetevent igmpproxy ihealth ihpm iio-sensor-proxy iiod ikectl iked ikiwiki-mass-rebuild iksd ilan ilmid imap4d imapd imapd-ssl imapfront-auth imapproxyd import-ferm in.comsat in.fingerd in.ftpd in.identtestd in.nnrpd in.ntalkd in.proftpd in.rexecd in.rlogind in.rshd in.talkd in.telnetd in.tftpd in.uucpd inadyn incrond inetd inetd2rlinetd inetutils-inetd infnoise init.lxc init.lxc.static inject-bpfcc innd inndstart innstat inputlircd inspircd inspircd-genssl inspircd-testssl install-docs install-keymap install-menu install-notion-cfg install-sgmlcatalog (8) - maintain transitional SGML catalog install_packages integrit intelmetool inteltool intelvbttool invoke-rc.d (8) - executes System-V style init script actions iodine iodine-client-start iodined iog iolatency-perf iosnoop-perf iotop-c iotop-py ip6tables-apply (8) - a safer way to update iptables remotely ip6tables-legacy (8) - iptables using old getsockopt/setsockopt-based kernel api ip6tables-legacy-restore (8) - iptables using old getsockopt/setsockopt-based kernel api ip6tables-legacy-save (8) - iptables using old getsockopt/setsockopt-based kernel api ip6tables-nft (8) - iptables using nftables kernel api ip6tables-nft-restore (8) - iptables using nftables kernel api ip6tables-nft-save (8) - iptables using nftables kernel api ip6tables-restore-translate (8) - translation tool to migrate from iptables to nftables ip6tables-translate (8) - translation tool to migrate from ip6tables to nftables ipa-certupdate ipa-client-automount ipa-client-install ipa-client-samba ipa-epn ipa-getkeytab ipa-join ipa-rmkeytab ipband ipfm ipgrab ipicmg ipip ipmi-chassis ipmi-chassis-config ipmi-config ipmi-console ipmi-dcmi ipmi-detect ipmi-fru ipmi-locate ipmi-oem ipmi-pef-config ipmi-pet ipmi-ping ipmi-power ipmi-raw ipmi-sel ipmi-sensors ipmi-sensors-config ipmi_port ipmiconsole ipmidetect ipmidetectd ipmievd ipmimonitoring ipmiping ipmipower ipmiseld ippeveprinter (1) - an ipp everywhere printer application for cups ippl iprop-log ipropd-master ipropd-slave ipsec ipset ipset-translate iptables-apply (8) - a safer way to update iptables remotely iptables-legacy (8) - iptables using old getsockopt/setsockopt-based kernel api iptables-legacy-restore (8) - iptables using old getsockopt/setsockopt-based kernel api iptables-legacy-save (8) - iptables using old getsockopt/setsockopt-based kernel api iptables-nft (8) - iptables using nftables kernel api iptables-nft-restore (8) - iptables using nftables kernel api iptables-nft-save (8) - iptables using nftables kernel api iptables-restore-translate (8) - translation tool to migrate from iptables to nftables iptables-translate (8) - translation tool to migrate from iptables to nftables iptaccount iptotal iptotald iptraf iptraf-ng iptstate ipwatchd ipwatchd-gnotify ipwatchd-script ircd ircd-hybrid ircd-ircu ircd-mkpasswd ircdwatch ircflush ircio ireset irqbalance irqbalance-ui isadump (8) - examine ISA registers isaset (8) - set ISA registers isatapd isel iseltime isenkram-autoinstall-firmware isenkram-pkginstall isensor iserial isnsadm isnsd isnsdd isnssetup iso8601 isol ispell-autobuildhash (8) - Autobuilding the ispell hash file for some dicts istgt istgtcontrol iuser iwdt iwpmd jabberd2-c2s jabberd2-router jabberd2-s2s jabberd2-sm jail_uml jamnntpd javacalls-bpfcc javaflow-bpfcc javagc-bpfcc javaobjnew-bpfcc javastat-bpfcc javathreads-bpfcc jffs2dump jffs2reader jitterentropy-rngd jk_check jk_chrootlaunch jk_chrootsh jk_cp jk_init jk_jailuser jk_list jk_lsh jk_socketd jk_update jnettop jobrep-admin john jserver json2file-go jumbo6 kacpimon kadmin.local kadmind kafs-preload kamailio kambdb_recover kamcmd kamctl kamdbctl kcatalogprint kcm kdb5_ldap_util kdb5_util kdigest kdump-config kea-admin kea-ctrl-agent kea-dhcp-ddns kea-dhcp4 kea-dhcp6 kea-lfc kea-shell keactrl keepalived keyd keymgr keypair keytab2shishi kgb-add-project kgb-bot kgb-split-config killer killsnoop killsnoop-bpfcc killsnoop-perf killsnoop.bt kimpersonate kissattach kissbridge kissnetd kissparms kjournalprint klockstat klockstat-bpfcc kmsgsd knock_helper_ipt.sh knockd knotc knotd komrunning kprobe-perf kprop kpropd kproplog krb5-sync krb5-sync-backend krb5_newrealm krb5kdc kres-cache-gc kresc kresd kserver ksmbd.addshare ksmbd.adduser ksmbd.control ksmbd.mountd ksmctl ksmtuned ksnoop kstash kvm-ok kvmexit-bpfcc kwartz-client-conf kwnnkill kwnnstat kxdpgun l2tpns labgrid-bound-connect lacme ladvd ladvdc laptop_mode latcp latd latencytop lbcd lcd4linux lchage lcp2_crtpol lcp2_crtpolelt lcp2_crtpollist lcp2_mlehash ld10k1 ldap-agent ldap-git-backup ldap2bind ldap2zone ldapaddgroup ldapaddmachine ldapadduser ldapaddusertogroup ldapdeletegroup ldapdeletemachine ldapdeleteuser ldapdeleteuserfromgroup ldapfinger ldapgid ldapid ldapinit ldapmodifygroup ldapmodifymachine ldapmodifyuser ldaprenamegroup ldaprenamemachine ldaprenameuser ldapsetpasswd ldapsetprimarygroup ldattach (8) - attach a line discipline to a serial line ldbashconfig ldirectord leafnode lecs ledctl ledmon les lft (1) - print the route packets trace to network host lgroupadd lgroupdel lgroupmod libguestfs-make-fixed-appliance libgvc6-config-update libuser-lid libvirt-dbus libvirtd lightdm lightdm-gtk-greeter lighttpd lighttpd-angel lighttpd-disable-mod lighttpd-enable-mod lighty-disable-mod lighty-enable-mod likwid-accessD likwid-setFreq linaro-bcb-util link-balancer linssid lirc-lsplugins lircd lircd-setup lircd-uinput lircmd llcstat llcstat-bpfcc lldpad lldpcli lldpctl lldpd lldptool llmnrd llng-fastcgi-server lltdscan lm-profiler lm-syslog-setup lmt-config-gui lmt-config-gui-pkexec lmtpd lnewusers lnpd loadavg loaderinfo loads.bt locale-gen (8) - generate localisation files from templates localepurge lockname logcheck login_duo logrotate (8) - rotates, compresses, and mails system logs logtail logtail2 logwatch lookupconfig lpadmin (8) - configure cups printers and classes lpasswd lpc (8) - line printer control program (deprecated) lpd lpdomatic lpf lpinfo (8) - show available devices or drivers (deprecated) lpmove (8) - move a job or all jobs to a new destination lprng_certs lprng_index_certs lrmadmin lsdahdi lsh-execuv lsh-krb-checkpw lsh-pam-checkpw lshd lsldap lsm lsmtd (8) - list memory technology devices ltsp luksformat luseradd luserdel lusermod lxdm lxdm-binary lynis lyskomd m6pack macfanctld macof mactelnetd magicfilter magicfilterconfig mailer mailfromd mailfront mailgraph mailq (8) - a Mail Transfer Agent mailsnarf mailstats make-bcache make-ssl-cert (8) - Debconf wrapper for openssl make_xtel_lignes makeacceptmailfor makealiases makechs makefs makehosteddomains makeimapaccess makemap makepercentrelay makesmtpaccess makesmtpaccess-msa makeuserdb makeuucpneighbors makewhatis mandocd mandos mandos-ctl mandos-keygen mandos-monitor maradns mariadbd (8) - the MariaDB server (mysqld is now a symlink to mariadbd) massagevendor matchpathcon (3) - get the default SELinux security context for the specified path from the file contexts configuration mate-display-properties-install-systemwide mate-power-backlight-helper mausezahn mbpfan mcatman mcollectived mcs2h mda mdflush mdflush-bpfcc mdflush.bt mdk3 mdk4 mdmdetect mdnsd meatclient mellon_create_metadata memdump memleak-bpfcc memlockd memtester merecat metaphlan2-data-convert mfsbdev mfscgiserv mfschunkserver mfschunktool mfscsstatsdump mfsmaster mfsmetadirinfo mfsmetadump mfsmetalogger mfsmetarestore mfsnetdump mfsstatsdump mgnokiidev mheardd micro-httpd mini_httpd minicoredumper minicoredumper_regd minicoredumper_trigger minidlnad minissdpd miniupnpd miredo miredo-checkconf miredo-server mk-runscript mkThumbs mkapfs mkdhparams mkesmtpdcert mkfs.exfat (8) - create an exFAT filesystem mkfs.gfs2 mkfs.jffs2 (1) - Create a JFFS2 file system image from directory mkfs.ubifs mkfs.udf mkimapdcert mkinitramfs mkiss mkjigsnap mklost+found (8) - create a lost+found directory on a mounted Linux second extended file system mknic-nbi mkpop3dcert mkrlconf mksubvolume mktirfs mkudffs mon mono-server-admin mono-server-update mono-server4-admin mono-server4-update mono-xsp4-admin mono-xsp4-update monopd mopidyctl moprc mosquitto mount.9P mount.davfs mount.fuse.sshfs mount.lockfs mount.sshfs mount.ubifs mount.unionfs mountsnoop mountsnoop-bpfcc mountstats mpcd mpt-status msgsnarf msktutil msrtool mtd_debug mtdinfo mtdpart mtinkd mtx mu-conference multistrap munged mungekey munin-libvirt-plugins-detect munin-node munin-node-c munin-node-configure munin-run murmurd mvrefind myproxy-admin-addservice myproxy-admin-adduser myproxy-admin-change-pass myproxy-admin-load-credential myproxy-admin-query myproxy-replicate myproxy-server myproxy-test myproxy-test-replicate myrescue myrescue-bitmap2ppm myrescue-stat mysqld (8) - the MariaDB server (mysqld is now a symlink to mariadbd) mysqld_qslower-bpfcc mysqmail-courier-logger mysqmail-dovecot-logger mysqmail-postfix-logger mysqmail-pure-ftpd-logger mythtv-update-motd na6 nacctd nagios4 nagios4stats named nanddump nandflipbits nandtest nandwrite naptime.bt nats-server ncaptool ncpd ndppd needrestart (1) - needrestart net2kiss netatalk netconf-subsystem netconfd netconsole-setup netdata netdata-claim.sh netdatacli netdevstat netdiscover netfilter-persistent nethogs netlabel-config netlabelctl netplan netproc netqtop-bpfcc netrom_call netromd netscsid netsniff-ng netwatch newaliases (8) - a Mail Transfer Agent newusers (8) - update and create new users in batch nfacct nfacctd nfct nfnl_osf (8) - OS fingerprint loader utility nfsconf nfsdcld nfsdclddb nfsdclnts nfsdist nfsdist-bpfcc nfsidmap nfsiostat nfslogsum nfsslower nfsslower-bpfcc nfsstat nfswatch nft nftl_format nftlb nftldump nghttpd nghttpx nginx ngircd ni6 nicinfo nield nilfs-clean nilfs-resize nilfs-tune ninjahelper nisserver-plugin-defs nmbd nodegc-bpfcc nodesave nodestat-bpfcc nodeusers nodm nohang nologin (5) - prevent unprivileged users from logging into the system nologin (8) - politely refuse a login nordugridmap nrattach nrparms nrpe nrpe-ng nrsdrv ns-slapd ns6 nsca nsca-ng nscd nsctl nsd nsd-checkconf nsd-checkzone nsd-control nsd-control-setup nslcd nsm nss-tlsd nss_updatedb nsscache ntfs2btrfs ntpctl ntpd ntpdate ntpdate-debian ntpkeygen ntpleapfetch ntploggps ntplogtemp ntptime ntpwait nullidentd nullmailer-queue nullmailer-send numamove nutcracker nvme nvram-wakeup nvramtool nwipe o2hbmonitor oar-database oar-server oar_phoenix oar_resources_add oar_resources_init oaraccounting oaradmissionrules oarmonitor oarnodesetting oarnotify oarproperty oarremoveresource obex-check-device obs_admin obs_mirror_project obs_project_update obs_serverstatus ocf-tester ocft ocs-btsrv ocs-chkimg ocs-chnthn ocs-clean-disk-part-fs ocs-cnvt-usb-zip-to-dsk ocs-console-font-size ocs-cvt-dev ocs-cvtimg-comp ocs-decrypt-img ocs-encrypt-img ocs-expand-gpt-pt ocs-expand-lvm ocs-expand-mbr-pt ocs-gen-bt-metainfo ocs-gen-bt-slices ocs-gen-grub2-efi-bldr ocs-get-dev-info ocs-img-2-vdk ocs-install-grub ocs-iso ocs-iso-2-onie ocs-label-dev ocs-lang-kbd-conf ocs-langkbdconf-bterm ocs-live ocs-live-bind-mount ocs-live-boot-menu ocs-live-bug-report ocs-live-dev ocs-live-feed-img ocs-live-final-action ocs-live-general ocs-live-get-img ocs-live-netcfg ocs-live-nicbonding ocs-live-preload ocs-live-repository ocs-live-restore ocs-live-run-menu ocs-live-save ocs-live-swap-kernel ocs-lvm2-start ocs-lvm2-stop ocs-makeboot ocs-match-checksum ocs-memtester ocs-onthefly ocs-park-disks ocs-prep-cache ocs-prep-repo ocs-put-signed-grub2-efi-bldr ocs-related-srv ocs-resize-part ocs-restore-ebr ocs-restore-mbr ocs-restore-mdisks ocs-restore-veracrypt-vh ocs-rm-win-swap-hib ocs-run-boot-param ocs-save-veracrypt-vh ocs-sr ocs-srv-live ocs-tune-conf-for-s3-swift ocs-tune-conf-for-webdav ocs-tux-postprocess ocs-update-initrd ocs-update-syslinux ocserv ocserv-worker ocsmgrd oddjobd ods-control ods-enforcer ods-enforcer-db-setup ods-enforcerd ods-migrate ods-signer ods-signerd offcputime offcputime-bpfcc offwaketime-bpfcc ofonod oidentd olpc-kbdshim-udev omniEvents ondelay onionbalance onionbalance-config oomkill oomkill-bpfcc oomkill.bt oor opa2rm opaallanalysis opacabletest opacapture opacaptureall opachassisadmin opachassisanalysis opacheckload opacmdall opadisablehosts opadisableports opadownloadall opaenableports opaesmanalysis opaexpandfile opaextractbadlinks opaextracterror opaextractlids opaextractlink opaextractmissinglinks opaextractperf opaextractperf2 opaextractsellinks opaextractstat opaextractstat2 opafabricanalysis opafabricinfo opafastfabric opafindgood opafirmware opafmcmd opafmcmdall opafmconfigcheck opafmconfigdiff opafmconfigpp opafmvf opagenchassis opagenesmchassis opagenswitches opagetvf opagetvf_env opahfirev opahostadmin opahostsmanalysis opainfo opal-gard opaledports opalinkanalysis opamergeperf2 opapacketcapture opapaquery opapingall opapmaquery opaportconfig opaportinfo opareport opareports oparesolvehfiport opasaquery opascpall opasetupssh opashowallports opashowmc opasmaquery opasorthosts opaswdisableall opaswenableall opaswitchadmin opatop opauploadall opaverifyhosts opaxlattopology opaxmlextract opaxmlfilter opaxmlgenerate opaxmlindent open_init_pty openconnect (8) - Multi-protocol VPN client, for Cisco AnyConnect VPNs and others opendkim opendkim-atpszone opendkim-expire opendkim-gengraphs opendkim-genkey opendkim-genstats opendkim-genzone opendkim-importstats opendkim-stats opendkim-testkey opendkim-testmsg opendmarc opendmarc-check opendmarc-expire opendmarc-import opendmarc-importstats opendmarc-params opendmarc-reports openhpid openldap_to_ds openntpd opensm opensnoop opensnoop-bpfcc opensnoop-perf opensnoop.bt openstack-deploy openstack-deploy-fix-heat openstack-deploy-fix-nova openstack-deploy-proxy-network openstack-deploy-tempest openstack-purge openstack-tempest-ci-build-live-image openstack-tempest-ci-build-live-image-clean openstack-tempest-ci-live-booter-config openstack-tempest-ci-start openstack-tempest-ci-stop openvpn orthanc_upgrade osmtest osspd ovrouter ovs-bugtool ovsdb-server ownership (8) - Compaq ownership tag retriever oxenstored p0f p0f-analyzer p10cfgd p910nd pac pacemaker-remoted pacemaker_remoted pacemakerd packit pagemon pagesend painintheapt pam-auth-update (8) - manage PAM configuration using packaged profiles pam_getenv (8) - get environment variables from /etc/environment pam_timestamp_check (8) - Check to see if the default timestamp is valid pandora_agent paperconfig (8) - configure the system default paper size parl-desktop-tidy parprouted partclone.apfs partclone.btrfs partclone.chkimg partclone.dd partclone.exfat partclone.ext2 partclone.ext3 partclone.ext4 partclone.ext4dev partclone.extfs partclone.f2fs partclone.fat partclone.fat12 partclone.fat16 partclone.fat32 partclone.hfs+ partclone.hfsp partclone.hfsplus partclone.imager partclone.info partclone.minix partclone.ntfs partclone.ntfsfixboot partclone.ntfsreloc partclone.reiser4 partclone.restore partclone.vfat partclone.xfs partimage partimaged partimaged-passwd passenger-memory-stats passenger-status path6 pbuilder pchar pcm pcm-accel pcm-bw-histogram pcm-core pcm-daemon pcm-iio pcm-latency pcm-lspci pcm-memory pcm-mmio pcm-msr pcm-numa pcm-pcicfg pcm-pcie pcm-power pcm-raw pcm-sensor pcm-sensor-server pcm-tsx pcp_attach_node pcp_detach_node pcp_health_check_stats pcp_node_count pcp_node_info pcp_pool_status pcp_proc_count pcp_proc_info pcp_promote_node pcp_recovery_node pcp_reload_config pcp_stop_pgpool pcp_watchdog_info pcs pcscd pcsd pdata_tools pdns_recursor pdns_server pdudaemon pef-config perdition perdition.imap4 perdition.imap4s perdition.imaps perdition.managesieve perdition.pop3 perdition.pop3s perditiondb_ldap_makedb perditiondb_mysql_makedb perditiondb_odbc_makedb perditiondb_postgresql_makedb perf-stat-hist-perf perfdhcp perfquery perlcalls-bpfcc perlflow-bpfcc perlstat-bpfcc pethtool3 pflash pflogsumm pfqueue pg_enc pg_md5 pg_updatedicts pgbouncer pgpool pgpool_setup pgproto phc2sys phc_ctl php-fpm8.1 phpcalls-bpfcc phpdismod phpenmod phpflow-bpfcc phpquery phpstat-bpfcc pidpersec-bpfcc pidpersec.bt pifconfig3 pimd pimpstat piuparts pkcscca pkcsconf pkcsicsf pkcsslotd pkgsync pkla-admin-identities (8) - List pklocalauthority-configured polkit administrators pkla-check-authorization (8) - Evaluate pklocalauthority authorization configuration pknlusr pktcdvd-check pktsetup pktstat plmpower plocate-build ploop ploop-balloon plotnetcfg plpfuse plpprintd plymouth-set-default-theme plymouthd pm-hibernate pm-powersave pm-suspend pm-suspend-hybrid pmacctd pmailq pmbgpd pmbmpd pmc pmh7tool pmt-ehd pmtelemetryd pmvarrun policy-rc.d-declarative policy-test policyd-weight policyvers pommed pop3d pop3d-ssl pop3front-auth pop3front-maildir popcon-largest-unused poppassd popularity-contest portsentry postal postalias postcat postconf postdrop postfix postfix-add-filter postfix-add-policy postfix-collate postfix-nochroot postfix-policyd-spf-perl postfwd1 postfwd2 postgrey postkick postlock postlog postmap postmulti postqueue postsrsd postsuper posttls-finger power-calibrate power-usage-report powerdebug powermand powertop ppp-gatekeeper pppconfig pppd pppdump pppoe pppoe-connect pppoe-discovery pppoe-relay pppoe-server pppoe-sniff pppoe-start pppoe-status pppoe-stop pppstats pptp pptpctrl pptpd pptpsetup pqos pqos-msr pqos-os praliases preload prep-ocsroot privoxy probemodem profile-bpfcc proftpd proftpd-gencert proxsmtpd psad psadwatchd ptp4l ptpd ptunnel puppetdb pure-authd pure-certd pure-ftpd pure-ftpd-control pure-ftpd-ldap pure-ftpd-ldap-virtualchroot pure-ftpd-mysql pure-ftpd-mysql-virtualchroot pure-ftpd-postgresql pure-ftpd-postgresql-virtualchroot pure-ftpd-virtualchroot pure-ftpd-wrapper pure-ftpwho pure-mrtginfo pure-quotacheck pure-uploadscript purgestat putscom pw2userdb pwauth pwck (8) - verify the integrity of password files pwconv (8) - convert to and from shadow passwords and groups pwmconfig pwunconv (8) - convert to and from shadow passwords and groups pynslcd pyroman python3-exabgp python3-exabgpcli pythoncalls-bpfcc pythonflow-bpfcc pythongc-bpfcc pythonstat-bpfcc qb-blackbox qemu-debootstrap qemu-ga qemu-make-debian-root (8) - Create a debian root image for qemu qemubuilder ql-dynamic-tgt-lun-disc ql-hba-snapshot ql-lun-state-online ql-set-cmd-timeout qmail-newaliases qmqp-sink qmqp-source qmqpfront-echo qmqpfront-qmail qmtpfront-echo qmtpfront-qmail qshape quickml quickml-ctl quicktun quota_nld quotastats quotatool ra6 rabbitmq-diagnostics rabbitmq-plugins rabbitmq-queues rabbitmq-server rabbitmq-upgrade rabbitmqctl rabid raddebug radeonreg radeontool radioclkd radium radmin radsecproxy radsecproxy-hash radvd radvdump raideng raidfile-config raidutil ramond rapiddisk rapiddiskd rarpd ras-mc-ctl rasdaemon rasterisk rbldns rbldns-conf rbldns-data rbldnsd rbldnsd.wrapper rbootd rcconf rd6 rdate rdma-ndd rdmsr rdtset readahead (2) - initiate file readahead into page cache readahead-bpfcc readprofile (8) - read kernel profiling information realksh.c really realm (8) - Manage enrollment in realms rear recap recaplog recaptool recv_image recvstats redoctober redsocks ree refind-install refind-mkdefault reged regionset register-stardata regtest remctl-shell remctld remove-default-ispell (8) - remove default ispell dictionary remove-default-wordlist (8) - remove default wordlist remove-shell (8) - remove shells from the list of valid login shells repowerd repowerd-brightness-tool repowerd-cli repowerd-light-tool repowerd-proximity-tool repowerd-wakeup-tool repquota reset-ftrace-perf reset-trace-bpfcc restartd restorecond rfddump rfdformat rfkill rinetd rinse rip98d rlinetd rmail (8) - a Mail Transfer Agent rmcp-ping rmcpping rmodtool rmt-dump rmt-tar (8) - remote magnetic tape server rndc rndc-confgen rngd rose_call rovclock rpc.bootparamd rpc.gssd rpc.idmapd rpc.mountd rpc.nfsd rpc.rquotad rpc.rstatd rpc.rusersd rpc.rwalld rpc.svcgssd rpc.yppasswdd rpc.ypxfrd rpcctl rpcdebug rpcinfo rpki-client rplayd rrdcollect rs6 rsattach rsdwnlnk rsmemsiz rsmtp (8) - a Mail Transfer Agent rsparms rsuplnk rsusers rsyslogd (8) - reliable and extended syslogd rt-attributes-viewer-4 rt-attributes-viewer-5 rt-clean-sessions-4 rt-clean-sessions-5 rt-dump-initialdata-5 rt-dump-metadata-4 rt-dump-metadata-5 rt-email-dashboards-4 rt-email-dashboards-5 rt-email-digest-4 rt-email-digest-5 rt-email-group-admin-4 rt-email-group-admin-5 rt-externalize-attachments-4 rt-externalize-attachments-5 rt-fulltext-indexer-4 rt-fulltext-indexer-5 rt-importer-4 rt-importer-5 rt-ldapimport-4 rt-ldapimport-5 rt-munge-attachments-4 rt-munge-attachments-5 rt-passwd-4 rt-passwd-5 rt-preferences-viewer-4 rt-preferences-viewer-5 rt-search-attributes-4 rt-search-attributes-5 rt-serializer-4 rt-serializer-5 rt-session-viewer-4 rt-session-viewer-5 rt-setup-database-4 rt-setup-database-5 rt-setup-fulltext-index-4 rt-setup-fulltext-index-5 rt-shredder-4 rt-shredder-5 rt-validate-aliases-4 rt-validate-aliases-5 rt-validator-4 rt-validator-5 rtc (4) - real-time clock rtcwake (8) - enter a system sleep state until specified wakeup time rtkitctl (8) - Realtime Policy and Watchdog daemon control rtmpgw rtmpsrv rtmpsuck rtpengine-iptables-setup rtpengine-recording-nfs-setup rubycalls-bpfcc rubyflow-bpfcc rubygc-bpfcc rubyobjnew-bpfcc rubystat-bpfcc run_init run_kannel_box runc runq (8) - a Mail Transfer Agent runqlat runqlat-bpfcc runqlat.bt runqlen runqlen-bpfcc runqlen.bt runqslower runqslower-bpfcc runsvchdir rush rwhod rxecho sa safe-ldif safe_asterisk safe_finger sagan samba samba-gpupdate samba_dnsupdate samba_downgrade_db samba_kcc samba_spnupdate samba_upgradedns samhain sampasswd samunlock samusrgrp saned (8) - SANE network daemon sanlk-reset sanlk-resetd sanlock sanoid saquery sarg-reports sasl-sample-server saslauthd sasldbconverter2 sasldblistusers2 saslpasswd2 saslpluginviewer satdoc satupdat sauce sauce-run sauce-setsyspolicy sauce9-convert sauceadmin savecore-lyskom sbd sbuild-adduser sbuild-destroychroot scan6 scanbd scanbm scanlogd sccinit sccparam scomes script6 scrounge-ntfs scsi-config scsieject scsiformat scsitape sdc seatd sefcontext_compile selabel_digest (3) - Return digest of specfiles and list of files used selabel_get_digests_all_partial_matches (3) - retrieve the partial matches digest and the xattr digest that applies to the supplied path - Only supported on file backend. selabel_lookup (3) - obtain SELinux security context from a string label selabel_lookup_best_match (3) - obtain a best match SELinux security context - Only supported on file backend. selabel_partial_match (3) - determine whether a direct or partial match is possible on a file path - Only supported on file backend. select-default-ispell (8) - select default ispell dictionary select-default-wordlist (8) - select default wordlist selinux-activate selinux-config-enforcing selinux-policy-upgrade selinux_check_access (3) - query the SELinux policy database in the kernel selinux_check_securetty_context (3) - check whether a SELinux tty security context is defined as a securetty context selinuxenabled selinuxexeccon semanage semodule send_arp send_nsca sendfax sendfiled sendmail (8) - a Mail Transfer Agent sendmailconfig sensible-mda sensors-detect (8) - detect hardware monitoring chips ser2net serve_image service (8) - run a System V init script sestatus setenforce setfilecon (3) - set SELinux security context of a file sethdlc setquota setsebool setuids.bt setup-storage setvesablank seunshare sfacctd sfex_init sfex_stat sge_coshepherd sge_execd sge_qmaster sge_shadowd sge_shepherd sharedindexinstall sharedindexsplit shib-keygen shib-seckeygen shibd shield-purge shield-trigger shield-trigger-iptables shield-trigger-ufw shishid shmsnoop-bpfcc siggen sigsnoop sinfod sitesummary-client sitesummary-makewebreport sitesummary-nodes sitesummary-update-munin sitesummary-update-nagios sitesummary-upload skdump skksearch sks sktest slabratetop slabratetop-bpfcc slack slapacl slapadd slapauth slapcat slapd slapdn slapindex slapmodify slappasswd slapschema slaptest slay sleepd slick-greeter slrn_getdescs slurmctld-wlm slurmctld-wlm-emulator slurmd-wlm slurmd-wlm-emulator slurmdbd slurmrestd slurmstepd-wlm slurmstepd-wlm-emulator smartctl smartd smartdns smbd smbios-battery-ctl smbios-get-ut-data smbios-keyboard-ctl smbios-lcd-brightness smbios-passwd smbios-state-byte-ctl smbios-sys-info smbios-sys-info-lite smbios-thermal-ctl smbios-token-ctl smbios-upflag-ctl smbios-wakeup-ctl smbios-wireless-ctl smbldap-config smbldap-groupadd smbldap-groupdel smbldap-grouplist smbldap-groupmod smbldap-groupshow smbldap-passwd smbldap-populate smbldap-useradd smbldap-userdel smbldap-userinfo smbldap-userlist smbldap-usermod smbldap-usershow smcroute smcroutectl smcrouted sminfo smokeinfo smokeping smpdump smpquery smsbox smsd smsq smtp-sink smtp-source smtpctl smtpd smtpfront-echo smtpfront-qmail snapperd sncancel sncat sndelgroup sndumpdb snexpire snfetch snget sngetd sniffit sniproxy snlockf snmail snmpd snmptrapd snmptrapfmt snmptrapfmthdlr snmptt snmpttconvert snmpttconvertmib snmptthandler snnewgroup snnewsq snntpd snntpd.bin snprimedb snscan snsend snsplit snstore socklog socklog-conf sofdsnoop-bpfcc softflowctl softflowd softirqs softirqs-bpfcc sogo-backup sogo-ealarms-notify sogo-slapd-sockd sogo-tool sogod solid-pop3d solisten solisten-bpfcc soundmodem sources-final sources-media spamass-milter spamassassin-maint spamd spampd spattach spfd.libspf2 spfd.mail-spf-perl spfqueue spice-vdagentd spice-webdavd spine spip_add_site spip_rm_site split-logfile splitkomdb sqlgrey squid squidtaild sraw sredird srp_daemon sshd (8) - OpenSSH daemon sshguard sshmitm sshow ssldump sslh sslh-select ssllatency.bt sslsniff-bpfcc sslsnoop.bt ssmtp sss_cache sss_debuglevel sss_obfuscate sss_override sss_seed sssctl sssd sstpc st_snapshot st_snapshot.hourly stackcount-bpfcc start-statd startsrv statnetd statsnoop statsnoop-bpfcc statsnoop.bt stenographer stenokeys stenotype stonith stonith_admin stund su-to-root sudo_logsrvd (8) - sudo event and I/O log server sudo_sendlog (8) - send sudo I/O log to log server sumtool superiotool swanctl swapin.bt swapspace switchconf synaptic (8) - graphical management of software packages sync-available (8) - sync dpkg's available database with apt's database syncoid syncsnoop-bpfcc syncsnoop.bt syscount syscount-bpfcc syscount-perf syscount.bt syslog-ng syslog-ng-ctl syslog-ng-debun syslog2eximlog (8) - make syslog output suitable for eximstats syslogd sysrqd system-tools-backends systraq systune systunedump sysv-rc-conf t50 tSmoke tableau-parm tagtest talkd talkwith tapeinfo tar-backup tar-restore tarcat (1) - concatenates the pieces of a GNU tar multi-volume archive tayga tb_polgen tclcalls-bpfcc tclflow-bpfcc tclobjnew-bpfcc tclstat-bpfcc tcp6 tcp_call tcpaccept-bpfcc tcpaccept.bt tcpblast tcpcong-bpfcc tcpconnect tcpconnect-bpfcc tcpconnect.bt tcpconnlat tcpconnlat-bpfcc tcpd tcpdchk tcpdmatch tcpdrop-bpfcc tcpdrop.bt tcpick tcpkill tcplay tcplife tcplife-bpfcc tcplife.bt tcpnice tcpretrans-bpfcc tcpretrans-perf tcpretrans.bt tcprtt tcprtt-bpfcc tcpspy tcpstates-bpfcc tcpsubnet-bpfcc tcpsynbl tcpsynbl-bpfcc tcpsynbl.bt tcptop-bpfcc tcptracer tcptracer-bpfcc tcptraceroute.db (8) - print the route packets trace to network host tcsd telnetd tenshi test_rt testsaslauthd texpire textfmt tgt-admin tgt-setup-lun tgtadm tgtd tgtimg th-cmd thd thermald thin_check thin_delta thin_dump thin_ls thin_metadata_size thin_repair thin_restore thin_rmap thin_trim thinkfan threadsnoop-bpfcc threadsnoop.bt tiffcheck tiger tigercron tigervncsession tigexp timemaster tincd tinydns tinydns-conf tinydns-data tinydns-edit tinysshd tinysshd-makekey tinysshd-printkey tinysshnoneauthd tk_scsiformat tkiptun-ng tlp tmpreaper togglesebool tomoyo-auditd tomoyo-checkpolicy tomoyo-diffpolicy tomoyo-domainmatch tomoyo-editpolicy tomoyo-findtemp tomoyo-loadpolicy tomoyo-notifyd tomoyo-patternize tomoyo-pstree tomoyo-queryd tomoyo-savepolicy tomoyo-selectpolicy tomoyo-setlevel tomoyo-setprofile tomoyo-sortpolicy tor tor-instance-create torrus tplist-bpfcc tpm2-abrmd tpm_changeownerauth tpm_clear tpm_createek tpm_getpubek tpm_nvdefine tpm_nvinfo tpm_nvread tpm_nvrelease tpm_nvwrite tpm_resetdalock tpm_restrictpubek tpm_restrictsrk tpm_revokeek tpm_selftest tpm_setactive tpm_setclearable tpm_setenable tpm_setoperatorauth tpm_setownable tpm_setpresence tpm_takeownership tpm_version tpoint-perf tpserv trace-bpfcc trafgen trafshow transponder transproxy tripwire try-from ts2phc tsig-keygen tsitest ttylinkd ttylog ttysnoop ttysnoop-bpfcc ttysnoops ttysrv tua tune.exfat (8) - adjust tunable filesystem parameters on an exFAT filesystem tuned tuned-adm tuned-gui tunegfs2 turbostat twadmin twinstar twprint txt-acminfo txt-parse_err txt-stat tzconfig u-boot-update u3-tool uacctd uanytun ubiattach ubiblock ubicrc32 ubidetach ubiformat ubihealthd ubimkvol ubinfo ubinize (8) - a tool for generating UBI images ubirename ubirmvol ubirsvol ubiscan ubiupdatevol ucalls ucarp udflabel udhcpd udp6 udpblast uflow ufw ugc uhubctl uif ukui-greeter ulogd umount.davfs ums2net umtprd-ffs unafs unbound unbound-anchor unbound-checkconf unbound-control unbound-control-setup undump.bt unhide unhide-gui unhide-linux unhide-posix unhide-tcp unhide.rb unhide_rb uniconfd unique unshadow uobjnew update-apt-xapian-index update-auctex-elisp update-binfmts (8) - maintain registry of executable binary formats update-ca-certificates (8) - update /etc/ssl/certs and ca-certificates.crt update-canna-dics_dir update-catalog (8) - create or update entry in SGML catalog file update-ccache-symlinks update-cmigemo-dict update-command-not-found update-cracklib (8) - Regenerate cracklib dictionary update-cudf-solvers update-debian-edu-artwork-buster update-debian-edu-artwork-homeworld update-debian-edu-artwork-softwaves update-debian-edu-artwork-spacefun update-default-aspell (8) - rebuild aspell database and emacsen stuff update-default-ispell (8) - update default ispell dictionary update-default-wordlist (8) - update default wordlist update-dictcommon-aspell (8) - rebuild aspell database and emacsen stuff update-dictcommon-hunspell (8) - rebuild hunspell database and emacsen stuff update-distcc-symlinks update-dlocatedb (8) - generate text database of installed files for dlocate update-efi-nvram-boot-entry update-exim4.conf (8) - Generate exim4 configuration files. update-exim4.conf.template (8) - Regenerate exim4 configuration file template. update-exim4defaults (8) - Manage exim4 daemon default file. update-fmtutil update-fonts-alias (8) - compile fonts.alias files update-fonts-dir (8) - compile fonts.dir files update-fonts-scale (8) - generate fonts.scale files update-grace-fonts update-grml-rescueboot update-grub update-grub2 update-gsfontmap update-hostname-from-ip update-icon-caches (8) - Update wrapper script for the icon caches update-ieee-data update-inetd (1) - create, remove, enable or disable entry /etc/inetd.conf update-info-dir update-initramfs update-ipsets update-java-alternatives (8) - update alternatives for jre/sdk installations update-language update-language-dat update-language-def update-language-lua update-ldh-gui-suite update-locale (8) - Modify global locale settings update-menu-lst update-mime (8) - create or update MIME information update-openssh-known-hosts update-passwd (8) - safely update /etc/passwd, /etc/shadow and /etc/group update-pciids (8) - download new version of the PCI ID list update-rc.d (8) - install and remove System-V style init script links update-rcconf-guide update-secureboot-policy update-service update-shells (8) - update the list of valid login shells update-skkdic update-skkdic-yaskkserv update-smart-drivedb update-squidguard update-texmf update-texmf-config update-tirfs update-tl-stacked-conffile update-updmap update-vflibcap update-xmlcatalog (8) - maintain XML catalog files updateLysKOM update_sqlgrey_config update_wdm_wmlist updatedb.plocate upgrade-from-grub-legacy upgrade-system uprobe-perf uptimed urlsnarf uronode usb_modeswitch (1) - control the mode of 'multi-state' USB devices usb_modeswitch_dispatcher (1) - Linux wrapper for usb_modeswitch (not intended for direct invocation) usbauth usbguard-daemon usbguard-dbus usbip usbipd usbmuxd (8) - Expose a socket to multiplex connections from and to iOS devices. usbrelayd usbtop useradd (8) - create a new user or update default new user information userdb userdb-test-cram-md5 userdbpw userdel (8) - delete a user account and related files userhelper userlist usermod (8) - modify a user account uservd ustat (2) - get filesystem statistics uthreads utmpset uucico uuidd (8) - UUID generation daemon uupoll uurate uusched uuxqt v4l2-dbg validatetrans validlocale (8) - Test if a given locale is available varnetload varnishd vbetool vblade vbladed vcstime vde_tunctl vdptool vendstat vfscount-bpfcc vfscount.bt vfsstat vfsstat-bpfcc vfsstat.bt vgetty via_regs_dump vigr (8) - edit the password, group, shadow-password or shadow-group file vipw (8) - edit the password, group, shadow-password or shadow-group file virt-sanlock-cleanup virt-what virtiostat-bpfcc virtlockd virtlogd visudo (8) - edit the sudoers file vlock-main vmfs-fuse vmfs-lvm vmfs6-fuse vmfs6-lvm vmm vnetbuild vnstatd voms vpcd vpddecode (8) - VPD structure decoder vpnc vpnc-connect vpnc-disconnect vrfydmn vsftpd vtund w3camd waagent wakeuptime-bpfcc walldns walldns-conf wapbox warnquota watchdog watchdog_setup wd_cli wd_identify wd_keepalive wdmd webgpg webmaild webmitm webspy weresync weresync-gui wesside-ng whereami whob wifite winbindd wnnkill wnnstat wpa_gui wrapper writeback.bt writeeeprom wrmsr wsdd wsdd2 wserv x2gobroker-authservice x2gobroker-daemon-debug x2gobroker-keygen x2gobroker-loadchecker x2gobroker-pubkeyauthorizer x2gobroker-testagent x2gocdmanager x2gocleansessions x2godbadmin x2golistsessions_root x2goshowblocks x2gothinclient_cleanup x2gothinclient_create x2gothinclient_preptftpboot x2gothinclient_shell x2gothinclient_update x2gothinclient_upgrade x2gothinclientd x86_energy_perf_policy xbuild-chroot-setup xdp-filter xdp-loader xdpdump xen xen-access xen-diag xen-hptool xen-hvmcrash xen-hvmctx xen-kdd xen-livepatch xen-lowmemd xen-mceinj xen-memshare xen-mfndump xen-ucode xen-vmtrace xenconsoled xencov xenhypfs xenlockprof xenperf xenpm xenpmd xenstored xentop xentrace xentrace_setsize xenwatchdogd xfbbC xfbbd xfce4-kiosk-query (8) - Queries Xfce4 kiosk capabilities xfce4-pm-helper xferfaxstats xfhdlcchpar xfhdlcst xfpm-power-backlight-helper (8) - control the brightness from the command line xfs_admin xfs_bmap xfs_copy xfs_db xfs_estimate xfs_freeze xfs_fsr xfs_growfs xfs_info xfs_io xfs_logprint xfs_mdrestore xfs_metadump xfs_mkfile xfs_ncheck xfs_quota xfs_rtcp xfs_scrub xfs_scrub_all xfs_spaceman xfsdist xfsdist-bpfcc xfsdist.bt xfsinvutil xfsmdiag xfsmmixer xfsslower xfsslower-bpfcc xinetd xjdicconfig xl xl2tpd xl2tpd-control xpp_blink xpp_sync xqmstats xrdp xrdp-chansrv xrdp-sesman xringd xtables-legacy-multi (8) - iptables using old getsockopt/setsockopt-based kernel api xtables-monitor (8) - show changes to rule set and trace-events xtables-nft-multi (8) - iptables using nftables kernel api xteld yadifad yakeyrolld yaku-getzone yaku-ns yamcfg yaskkserv_hairy yaskkserv_normal yaskkserv_simple yggdrasil yggdrasil-genkeys yggdrasilctl yp_dump_binding ypbind yppoll yppush ypserv ypset yptest yrmcdsd zabbix-java-gateway.jar zabbix_agent2 zabbix_agentd zabbix_proxy zabbix_server zabbix_web_service zblacklist zemberek-server zephyrd zeppelin zerofree zfsdist-bpfcc zfsslower-bpfcc zg-policy-rc.d zhm zic (8) - timezone compiler zmap zntune zoneserver zramswap zshutdown_notify ztee zvbid zypp-refresh zypper-log
