--Copyright 2022, Lutz Locus --for educational purposes only library IEEE; use IEEE.std_logic_1164.all; use IEEE.numeric_std.all; entity Debounce_Test is port( BTN_i : in std_logic; LED_o : out std_logic_vector(7 downto 0)); end entity Debounce_Test; architecture rtl of Debounce_Test is signal shift_reg_q : std_logic_vector(7 downto 0):= (others => '0'); signal first_done_q : std_logic := '0'; begin process(BTN_i) begin if rising_edge(BTN_i) then if first_done_q = '0' then first_done_q <= '1'; shift_reg_q(0) <= '1'; else shift_reg_q <= shift_reg_q(6 downto 0) & shift_reg_q(7); end if; end if; end process; LED_o <= shift_reg_q; end architecture rtl;
