--Copyright 2022, Lutz Locus --Verion 20221219a --for educational purposes only --synchronous to clk_i design with synchronous reset, --not using register initialization (as in xilinx) -- --target: FPGA-design (not PLD) Xilinx prefered, Altera (others will do also) --after Power up all bits in led_o are zero --with first rising edge at btn_1 a single '1' is set at (0) --with further rising edges at btn_1 the '1' is shown on the next (index+1) position ("Running '1'") -- --when at position (7) the bit will be set at Position (0) (rotating) library IEEE; use IEEE.std_logic_1164.all; --use IEEE.numeric_std.all; entity Debounce_Test is port( clk_i : in std_logic; rst_ni : in std_logic; -- btn_i : in std_logic; led_o : out std_logic_vector(7 downto 0)); end entity Debounce_Test; architecture rtl of Debounce_Test is signal first_done_q : std_logic; signal btn_del_q : std_logic; subtype T_CNT is integer range 0 to 7; signal bit_cnt_q : T_CNT; begin process(clk_i) begin if rising_edge(clk_i) then if rst_ni = '0' then --sync reset first_done_q <= '0'; btn_del_q <= '0'; bit_cnt_q <= T_CNT'low; else btn_del_q <= btn_i; --for edge detection -- if btn_del_q = '0' and btn_i = '1' then --rising edge button if first_done_q = '0' then --not started yet? first_done_q <= '1'; else if bit_cnt_q = T_CNT'high then --bit count overflow? bit_cnt_q <= T_CNT'low; else bit_cnt_q <= bit_cnt_q + 1; --count end if; end if; --first_done_q end if; --button end if; --rst_n end if; --clk end process; --combinatorical process for 1-out-of-8 encodung outputs --this drives the output led_o directly (no FF-buffering) process(bit_cnt_q, first_done_q) if first_done_q = '0' then LED_o(index) <= (others => '0'); else for index in 0 to 7 loop if index = bit_cnt_q then LED_o(index) <= '1'; else LED_o(index) <= '0'; end if; end loop; end if; end process; end architecture rtl;
