?hello.world efghhhhhhhhhhhhhhhhhhhhhhhihhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhjk Jump! Orginal init value: 202072BE cde profile->manufacturer_id (first 4B):DA94D7AD profile->data_per_page:2000 profile->page_per_block:100 blk 79 starts from page 700 klmnopqrstu5280 wait5280 wait4K&Detect H27UBG8T2B and enable read-retrial mode... Enable Read-retrial mode... load bbt...load env to (addr 0xa0010000, size 64KB)... page_start=0xf00 page_end=0x1900 get ENV fail!! load factory to (addr 0x80100000)... load bbt...ping_no =0xff pong_no =0xff there is no data in ping ,pong buffer current_factory_start=0x1900 current_factory_start + 0x400=0x1d00 tar end,not found tar end,not found default_tv_system= new default_tv_system=PAL EPHY: 8211E check_val=0x0 [HDMI]: Set I2C Speed = 50 kHz [HDMI]: Chk_HotPlug() TV is not connected. [HDMI]: Read_EDID abort, HDMI cable plug off. [HDMI]: TV is not connected. 2nd for PAL PAL logo REALTEK ROM Monitor, Revision ICIE.0402.1067. Copyright (c) Realtek Semiconductor Corp. - All Rights Reserved. For a list of available commands, type 'help'. Compilation time /version= Feb 19 2014 10:14:08 /ICIE.0402.1067 MAC address = 00.11.22.33.44.55 Processor Company ID/options = 0x01 (MIPS Technologies, Inc.) / 0x00 Processor ID/revision = 0x93 / 0x85 Endianness = Little Flash memory size = 4 GByte SDRAM size = 512 MByte First free SDRAM address = 0x800c4000 Press 'ESC' to Monitor mode ____________________Set ethernet register: 00000044 â–’râ–’â–’H) error! Entering rescue linux... Rescue kernel in FLASH, total size = 0x1f52d0 seg.1 addr 0xa0a06fd3, size = 0x1f52d0 seg.2 addr 0x0, size = 0x0 copy rescue0: from a0a06fd3 to 81000000, len = 1f52d0 decompressing rescue: from 81000000 to 80100000: size = 1f52d0 lzma finished decompressing rescue done go 0x80100000 defer 625p logo Reset Ethernet Mac. Address = 0x80100000 Linux version 2.6.34-VENUS (william@rtdmpsa-05) (gcc version 4.3.6 20110218 (prerelease) (GCC) ) #21 PREEMPT Wed Dec 4 13:08:14 CST 2013 Realtek LINUX started... Venus setting: ROSs have 4194304 bytes RAM. System CPU has 1 UART. System CPU uses internal timer interrupt. Bootloader version: ICIE.0402.1067. This version string is of new format. The information of this board: Company ID:0x0 CPU ID: 0x4 Board ID: 0x402 Ethernet Mac address: 00.11.22.33.44.55 Model Config length=6 Base year of RTC is 2010. ************************************************************** You didn't specify audio image address, use default instead... ************************************************************** audio addr: 0 Config serial console: console=ttyS0,115200n8r bootconsole [early0] enabled CPU revision is: 00019385 (MIPS 24Kc) FPU revision is: 01739300 Determined physical RAM map: memory: 00020000 @ 00000000 (reserved) memory: 000e0000 @ 00020000 (ROM data) memory: 01b00000 @ 00100000 (usable) memory: 00400000 @ 01c00000 (reserved) memory: 0e000000 @ 02000000 (usable) memory: 00100000 @ 10000000 (reserved) memory: 07f00000 @ 10100000 (usable) memory: 00100000 @ 18000000 (reserved) memory: 05b00000 @ 18100000 (usable) Wasting 8192 bytes for tracking 256 unused pages Initrd not found or empty - disabling initrd Zone PFN ranges: DMA 0x00000000 -> 0x00002000 Normal 0x00002000 -> 0x0001dc00 Movable zone start PFN for each node Node 0: 64512 early_node_map[1] active PFN ranges 0: 0x00000000 -> 0x0001dc00 zone DMA size: 2000 realsize: 2000 zone Normal size: dc00 realsize: dc00 zone Movable size: e000 realsize: e000 zonelist: Movable Normal DMA Built 1 zonelists in Zone order, mobility grouping off. Total pages: 121856 Kernel command line: console=ttyS0,115200n8r ip=192.168.0.9::192.168.0.254:255.0.0.0::: PID hash table entries: 2048 (order: 1, 8192 bytes) Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes. Primary data cache 64kB, 4-way, PIPT, no aliases, linesize 32 bytes Writing ErrCtl register=0000ed72 Readback ErrCtl register=0000ed72 Memory: 468824k/480256k available (3506k kernel code, 11432k reserved, 852k data, 2600k init, 0k highmem) Hierarchical RCU implementation. NR_IRQS:8 Estimated CPU frequency: 796.54 MHz Console: colour dummy device 80x25 Calibrating delay loop... 529.20 BogoMIPS (lpj=2646016) Mount-cache hash table entries: 512 devtmpfs: initialized NET: Registered protocol family 16 prom_flashsize = 0x100000000 Flash size is 0x2000000 bio: create slab at 0 SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb cfg80211: Calling CRDA to update world regulatory domain Switching to clocksource MIPS-DMP NET: Registered protocol family 2 IP route cache hash table entries: 4096 (order: 2, 16384 bytes) Switched to NOHz mode on CPU #0 TCP established hash table entries: 16384 (order: 5, 131072 bytes) TCP bind hash table entries: 16384 (order: 4, 65536 bytes) TCP: Hash tables configured (established 16384 bind 16384) TCP reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. ***************** se init module ********************* se init module major number = 253 ***************** md init module ********************* md init module major number = 252 size of RPC_POLL_Dev 52 and RPC_INTR_Dev 52... init_vdso successfull rtktlb: Hello, Realtek TLB Mapper... AllocBP size: 688128 order: 8 offset: 0 <<>> 0: 0 1: 0 2: 0 3: 0 4: 0 5: 0 6: 0 7: 0 8: 0 9: 0 10: 0 11: 0 12: 0 13: 7 Addr: 82000000, order: 13 Addr: 84000000, order: 13 Addr: 86000000, order: 13 Addr: 88000000, order: 13 Addr: 8a000000, order: 13 Addr: 8c000000, order: 13 Addr: 8e000000, order: 13 NTFS driver 2.1.29 [Flags: R/O]. msgmni has been set to 915 alg: No test for stdrng (krng) io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) Serial: 8250/16550 driver, 2 ports, IRQ sharing enabled serial8250: ttyS0 at MMIO 0x0 (irq = 3) is a 16550A console [ttyS0] enabled, bootconsole disabled console [ttyS0] enabled, bootconsole disabled serial8250: ttyS1 at MMIO 0x0 (irq = 3) is a 16550A brd: module loaded loop: module loaded Realtek Bulid-In SATA Driver Rev:SATURN (2011-02-24 15:10) sata_rtk sata_rtk: version 0.01 sata_rtk sata_rtk: slots 32 ports 1 scsi0 : sata_rtk ata1: SATA max UDMA/133 irq 4 BGA PackageRealtek NAND Flash Driver Rev:337905 (2010-10-18) (X)Enable interrupt mechanism of NAND driver. Get parameter from register... [rtk_nand_init]Bootcode size 0x3200000 [rtk_nand_init]Factory parameter size 0x400000 [rtk_nand_init]Disable NFCP... nand_base_rtk version:0824-2011 (X)NAND_POWEROFF_CARDREADER_WITH_MULTI_READ (X)NAND_READ_SKIP_UPDATE_BBT Detect H27UBG8T2B and enable read-retrial mode... Enable Read-retrial mode... Enable Randomized mechanism READ ID:0xad 0xd7 0x94 0xda 0x74 0xc3 One H27UBG8T2B chip has 1 die(s) on board nand part=H27UBG8T2B, id=add794da, device_size=4294967296, chip_size=4294967296, num_chips=1, page_size=8192, isLastPage=1, eccBits=24 [rtk_nand_scan_bbt] have created bbt B1, just loads it !! [dump_BBT] Nand BBT Content [0] (0, 27, 0, 2047) RTK: using the whole nand as a partitoin [rtk_nand_init]Randomized enabled [rtk_nand_init]Ecc bit select 24 Realtek Nand Flash Driver is successfully installing. VenusSFC MTD init... NOR flash support list .. (X) HWSEMA support. (V) AUTO_HW_POLL support. (X) 4Bytes mode support. (V) Max erase size support. (V) Sfc_delay support. [venus_sfc_init]FLASH_BASE: 0xbdc00000 [venus_sfc_init]Flash size: 0x2000000 Read id orginal value : 0xc22015c2 --RDID Seq: 0xc2 | 0x20 | 0x15 VenusSFC MTD: MXIC MX25L1605 detected. SFC_4KB_ERASE VenusSFC MTD: Enable VenusSFC MD PP callback function. MD_READ Enable.. MD_WRITE Enable.. [venus_sfc_init]descriptor size 0x2000000 RedBoot partition parsing not available Venus SFC: using single partition Venus SFC: (for SST/SPANSION/MXIC SPI Flash) this Jupiter eth RX_OFFSET = 0x0 8139cplus: 10/100 PCI Ethernet driver v1.2 (Mar 22, 2004) MAC address = 0x00.11.22.33.44.55 eth0: RTL-8139C+ at 0xb8016000, 00:11:22:33:44:55, IRQ 2 ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [usb_param] setting for saturn #@# cfyeh-debug USBPHY_Register_Setting(861) 0xb8013808 = 0x4400a081 #@# cfyeh-debug USBPHY_Register_Setting(863) 0xb8013808 = 0x4400a080 #@# cfyeh-debug USBPHY_SetReg_Default_33_port(210) port 1 dr 7 #@# cfyeh-debug USBPHY_SetReg_Default_33_port(210) port 2 dr 7 #@#[cfyeh-debug] USBPHY_Register_Setting(933) #@#[cfyeh-debug] USBPHY_Register_Setting(935) #@#[cfyeh-debug] USBPHY_Register_Setting(937) #@# cfyeh-debug USBPHY_SetReg_Default_39(289) tx_delay 2 [usb1_param] usbphy reg 32, set sh = 0xa, get sh = 0xa, 4bit [usb1_param] usbphy reg 35, set src = 0x7, get src = 0x7, 3bit [usb1_param] usbphy reg 36, set senh = 0xa, get senh = 0xa, 4bit [usb1_param] usbphy reg 32, set sen = 0x9, get sen = 0x9, 4bit [usb1_param] usbphy reg 33, set dr = 0x7, get dr = 0x7, 3bit [usb2_param] usbphy reg 32, set sh = 0xa, get sh = 0xa, 4bit [usb2_param] usbphy reg 35, set src = 0x7, get src = 0x7, 3bit [usb2_param] usbphy reg 36, set senh = 0xa, get senh = 0xa, 4bit [usb2_param] usbphy reg 32, set sen = 0x9, get sen = 0x9, 4bit [usb2_param] usbphy reg 33, set dr = 0x7, get dr = 0x7, 3bit ehci ehci: Rtk Dmp EHCI ehci ehci: new USB bus registered, assigned bus number 1 ehci ehci: irq 2, io mem 0xb8013000 Hotplcp_hotplug ug got one Net Hotplug of "Add" from "eth0". It may be Realtek's wireless device. ehci ehci: USB 0.0 started, EHCI 1.00 hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [usb_param] setting for saturn #@# cfyeh-debug USBPHY_Register_Setting(861) 0xb8013808 = 0x4400a080 #@# cfyeh-debug USBPHY_Register_Setting(863) 0xb8013808 = 0x4400a080 #@# cfyeh-debug USBPHY_SetReg_Default_33_port(210) port 1 dr 7 #@# cfyeh-debug USBPHY_SetReg_Default_33_port(210) port 2 dr 7 #@#[cfyeh-debug] USBPHY_Register_Setting(933) #@#[cfyeh-debug] USBPHY_Register_Setting(935) #@#[cfyeh-debug] USBPHY_Register_Setting(937) #@# cfyeh-debug USBPHY_SetReg_Default_39(289) tx_delay 2 [usb1_param] usbphy reg 32, set sh = 0xa, get sh = 0xa, 4bit [usb1_param] usbphy reg 35, set src = 0x7, get src = 0x7, 3bit [usb1_param] usbphy reg 36, set senh = 0xa, get senh = 0xa, 4bit [usb1_param] usbphy reg 32, set sen = 0x9, get sen = 0x9, 4bit [usb1_param] usbphy reg 33, set dr = 0x7, get dr = 0x7, 3bit [usb2_param] usbphy reg 32, set sh = 0xa, get sh = 0xa, 4bit [usb2_param] usbphy reg 35, set src = 0x7, get src = 0x7, 3bit [usb2_param] usbphy reg 36, set senh = 0xa, get senh = 0xa, 4bit [usb2_param] usbphy reg 32, set sen = 0x9, get sen = 0x9, 4bit [usb2_param] usbphy reg 33, set dr = 0x7, get dr = 0x7, 3bit ohci ohci: Rtk Dmp OHCI ohci ohci: new USB bus registered, assigned bus number 2 ohci ohci: irq 2, io mem 0xb8013400 ata1: SATA link down (SStatus 0 SControl 300) hub 2-0:1.0: USB hub found hub 2-0:1.0: 2 ports detected #@# cfyeh-debug usb3_phy_setting_saturn(38) +++ #@# cfyeh-debug usb3_phy_setting_saturn(227) --- xhci xhci: Rtk Dmp XHCI xhci xhci: new USB bus registered, assigned bus number 3 xhci xhci: irq 2, io mem 0xb8020000 #@# cfyeh-debug xhci_irq(1747) 0x000002a0 0x002802a0 #@# cfyeh-debug handle_port_status(1096) 0x000002a0 0x002802a0 #@#[cfyeh-debug] handle_port_status(1124) NOT in U0 usb usb3: config 1 interface 0 altsetting 0 endpoint 0x81 has no SuperSpeed companion descriptor hub 3-0:1.0: USB hub found hub 3-0:1.0: 2 ports detected #@# cfyeh-debug xhci_hub_control(287) hack for usb3 portsc #@# cfyeh-debug usb3_mac_setting_saturn(232) +++ #@# cfyeh-debug usb3_mac_setting_saturn(253) 16bit #@# cfyeh-debug usb3_mac_setting_saturn(254) *(unsigned int volatile *)0xb8028200=0x2440 #@# cfyeh-debug usb3_mac_setting_saturn(255) *(unsigned int volatile *)0xb8028200=0x2440 #@# cfyeh-debug usb3_mac_setting_saturn(257) *(unsigned int volatile *)0xb8028200=0x2400 #@# cfyeh-debug usb3_mac_setting_saturn(268) 0xb8013258 = 0x7; #@# cfyeh-debug usb3_mac_setting_saturn(270) 0xb8013258 = 0x7; #@# cfyeh-debug usb3_mac_setting_saturn(274) GTXTHRCFG #@# cfyeh-debug usb3_mac_setting_saturn(275) 0xb8028108 = 0x02400008 #@# cfyeh-debug usb3_mac_setting_saturn(280) 0xb8028108 = 0x21010000 #@# cfyeh-debug usb3_mac_setting_saturn(283) GRXTHRCFG #@# cfyeh-debug usb3_mac_setting_saturn(284) 0xb802810c = 0x02000008 #@# cfyeh-debug usb3_mac_setting_saturn(289) 0xb802810c = 0x21080000 #@# cfyeh-debug usb3_mac_setting_saturn(294) disable usb mulit request #@# cfyeh-debug usb3_mac_setting_saturn(295) *(unsigned int volatile *)0xb8013200=0x0 #@# cfyeh-debug usb3_mac_setting_saturn(297) *(unsigned int volatile *)0xb8013200=0x0 #@# cfyeh-debug usb3_mac_setting_saturn(302) GUSB3PIPECTL #@# cfyeh-debug usb3_mac_setting_saturn(303) 0xb80282c0 = 0x00060002 #@# cfyeh-debug usb3_mac_setting_saturn(306) 0xb80282c0 = 0x00060202 #@# cfyeh-debug usb3_mac_setting_saturn(309) --- Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. i2c /dev entries driver [I2C0] i2c speed changed to 100 KHz I2C0 Bus Status Check.... OK ========================= = VER : 2.1b ========================= = PHY : 0 = MODEL: Saturn = SPD : 100 = SAR : 0x024 (7 bits) = TX FIFO DEPTH : 32 = RX FIFO DEPTH : 32 = FIFO THRESHOLD: 4 = BUS JAM RECORVER 3: ON = NON STOP WRITE : ON = GPIO RW SUPPORT : ON ========================= [I2C1] i2c speed changed to 100 KHz I2C1 Bus Status Check.... OK ========================= = VER : 2.1b ========================= = PHY : 1 = MODEL: Saturn = SPD : 100 = SAR : 0x024 (7 bits) = TX FIFO DEPTH : 32 = RX FIFO DEPTH : 32 = FIFO THRESHOLD: 4 = BUS JAM RECORVER 3: ON = NON STOP WRITE : ON = GPIO RW SUPPORT : ON ========================= TCP cubic registered NET: Registered protocol family 10 IPv6 over IPv4 tunneling driver NET: Registered protocol family 17 Hotplug got one Net Hotplug of "Add" from "sit0". It may be Realtek's wireless device. cp_open alloc rings cp->rxdesc_buf =0xb82f4000 , cp->ring_dma=0x182f4000 init_hw eth0: Set multicast. jupiter/saturn 1g init_hw finished eth0: Set multicast. eth0: Set multicast. eth0: Set multicast. ADDRCONF(NETDEV_UP): eth0: link is not ready IP-Config: Complete: device=eth0, addr=192.168.0.9, mask=255.0.0.0, gw=192.168.0.254, host=192.168.0.9, domain=, nis-domain=(none), bootserver=255.255.255.255, rootserver=255.255.255.255, rootpath= Freeing prom memory: 896k freed Freeing unused kernel memory: 2600k freed Welcome to Realtek Rescue Linux for PhotoViewer /etc/init.d/rcS: line 49: cannot create /sys/bus/usb/devices/usb1/bEnableHubOnBoard_woone: nonexistent directory mount: mounting /dev/cdroms/cdrom0 on /mnt/usbmounts/cdrom failed: No such device mount: mounting /dev/hda1 on /mnt/usbmounts/hda1 failed: No such file or directory mount: mounting /dev/hda1 on /mnt/usbmounts/hda1 failed: No such file or directory mount: mounting /dev/hda1 on /mnt/usbmounts/hda1 failed: No such device Please press Enter to activate this console. #@#[cfyeh-debug] check_boot_code_size(1085) nand_boot_size 0x3200000 #@#[cfyeh-debug] check_boot_code_size(1091) factory_size 0x400000 >>>>>> loader start! (Dec 4 2013:13:08:04, version=00.01.01) #@#[cfyeh-debug] check_boot_code_size(1085) nand_boot_size 0x3200000 #@#[cfyeh-debug] check_boot_code_size(1091) factory_size 0x400000 get_mtd_block_name(/dev/mtdblock0) [JH] checksignatue(), open(/dev/mtdblock0) nand_boot_size(0x3200000) factory_size(0x400000) fail 4, sig(VERO) no IMG_XXXX signature found BUS_TYPE = (null) Hotplug: device "ram0" is skipped. BUS_TYPE = (null) Hotplug: device "ram2" is skipped. BUS_TYPE = (null) Hotplug: device "ram1" is skipped. BUS_TYPE = (null) Hotplug: device "ram3" is skipped. BUS_TYPE = (null) Hotplug: device "ram4" is skipped. BUS_TYPE = (null) Hotplug: device "ram6" is skipped. BUS_TYPE = (null) Hotplug: device "ram8" is skipped. BUS_TYPE = (null) Hotplug: device "ram9" is skipped. BUS_TYPE = (null) Hotplug: device "ram10" is skipped. BUS_TYPE = (null) Hotplug: device "ram5" is skipped. BUS_TYPE = (null) Hotplug: device "ram7" is skipped. BUS_TYPE = (null) Hotplug: device "ram13" is skipped. BUS_TYPE = (null) Hotplug: device "ram12" is skipped. BUS_TYPE = (null) Hotplug: device "ram14" is skipped. BUS_TYPE = (null) Hotplug: device "ram11" is skipped. BUS_TYPE = (null) Hotplug: device "ram15" is skipped. BUS_TYPE = (null) Hotplug: device "loop0" is skipped. BUS_TYPE = (null) Hotplug: device "loop1" is skipped. BUS_TYPE = (null) Hotplug: device "loop2" is skipped. BUS_TYPE = (null) Hotplug: device "loop4" is skipped. BUS_TYPE = (null) Hotplug: device "loop6" is skipped. BUS_TYPE = (null) Hotplug: device "loop7" is skipped. BUS_TYPE = (null) Hotplug: device "loop3" is skipped. BUS_TYPE = (null) Hotplug: device "mtdblock0" is skipped. BUS_TYPE = (null) Hotplug: device "mtdblock1" is skipped. BUS_TYPE = (null) Hotplug: device "loop5" is skipped. BusyBox v1.11.2 (2013-12-04 13:06:47 CST) built-in shell (ash) Enter 'help' for a list of built-in commands. / #
