(kicad_pcb (version 20211014) (generator pcbnew) (general (thickness 1.6) ) (paper "A4") (layers (0 "F.Cu" signal) (31 "B.Cu" signal) (32 "B.Adhes" user "B.Adhesive") (33 "F.Adhes" user "F.Adhesive") (34 "B.Paste" user) (35 "F.Paste" user) (36 "B.SilkS" user "B.Silkscreen") (37 "F.SilkS" user "F.Silkscreen") (38 "B.Mask" user) (39 "F.Mask" user) (40 "Dwgs.User" user "User.Drawings") (41 "Cmts.User" user "User.Comments") (42 "Eco1.User" user "User.Eco1") (43 "Eco2.User" user "User.Eco2") (44 "Edge.Cuts" user) (45 "Margin" user) (46 "B.CrtYd" user "B.Courtyard") (47 "F.CrtYd" user "F.Courtyard") (48 "B.Fab" user) (49 "F.Fab" user) (50 "User.1" user) (51 "User.2" user) (52 "User.3" user) (53 "User.4" user) (54 "User.5" user) (55 "User.6" user) (56 "User.7" user) (57 "User.8" user) (58 "User.9" user) ) (setup (stackup (layer "F.SilkS" (type "Top Silk Screen")) (layer "F.Paste" (type "Top Solder Paste")) (layer "F.Mask" (type "Top Solder Mask") (thickness 0.01)) (layer "F.Cu" (type "copper") (thickness 0.035)) (layer "dielectric 1" (type "core") (thickness 1.51) (material "FR4") (epsilon_r 4.5) (loss_tangent 0.02)) (layer "B.Cu" (type "copper") (thickness 0.035)) (layer "B.Mask" (type "Bottom Solder Mask") (thickness 0.01)) (layer "B.Paste" (type "Bottom Solder Paste")) (layer "B.SilkS" (type "Bottom Silk Screen")) (copper_finish "None") (dielectric_constraints no) ) (pad_to_mask_clearance 0) (pcbplotparams (layerselection 0x00010d0_ffffffff) (disableapertmacros false) (usegerberextensions false) (usegerberattributes true) (usegerberadvancedattributes true) (creategerberjobfile true) (svguseinch false) (svgprecision 6) (excludeedgelayer true) (plotframeref false) (viasonmask false) (mode 1) (useauxorigin false) (hpglpennumber 1) (hpglpenspeed 20) (hpglpendiameter 15.000000) (dxfpolygonmode true) (dxfimperialunits true) (dxfusepcbnewfont true) (psnegative false) (psa4output false) (plotreference true) (plotvalue true) (plotinvisibletext false) (sketchpadsonfab false) (subtractmaskfromsilk false) (outputformat 1) (mirror false) (drillshape 0) (scaleselection 1) (outputdirectory "/dev/shm/") ) ) (net 0 "") (footprint "Connector:Banana_Jack_1Pin" (layer "F.Cu") (tedit 5A1AB217) (tstamp 014d25e9-9a8c-4eae-b65e-1c1801723f98) (at 35.2552 88.1634) (descr "Single banana socket, footprint - 6mm drill") (tags "banana socket") (attr through_hole) (fp_text reference "REF**" (at 0 -6.5) (layer "F.SilkS") (effects (font (size 1 1) (thickness 0.15))) (tstamp 7c2b2c04-2e51-4ac5-b95d-f85615cf7ea5) ) (fp_text value "Banana_Jack_1Pin" (at -0.25 6.5) (layer "F.Fab") (effects (font (size 1 1) (thickness 0.15))) (tstamp 9d66077f-d65c-4347-8e2a-9c45959f53fb) ) (fp_text user "${REFERENCE}" (at 0 0) (layer "F.Fab") (effects (font (size 0.8 0.8) (thickness 0.12))) (tstamp d9024bfc-1603-450c-9604-6084ca7e3672) ) (fp_circle (center 0 0) (end 5.5 0) (layer "F.SilkS") (width 0.12) (fill none) (tstamp bd07b2eb-5d56-44a5-9342-64c15ad829ec)) (fp_circle (center 0 0) (end 5.75 0) (layer "F.CrtYd") (width 0.05) (fill none) (tstamp 7f61f14c-4d23-4ed7-859d-56f5c9bd9a49)) (fp_circle (center 0 0) (end 4.85 0.05) (layer "F.Fab") (width 0.1) (fill none) (tstamp 399f509a-7034-47be-8135-c7b438d39747)) (fp_circle (center 0 0) (end 2 0) (layer "F.Fab") (width 0.1) (fill none) (tstamp 936b71b6-5519-4313-a95e-5c7f7ea4d831)) (pad "1" thru_hole circle (at 0 0) (size 10.16 10.16) (drill 6.1) (layers F&B.Cu *.Mask) (tstamp deafbeb0-b83a-4551-8dfe-9d4c905c41e2)) (model "${KICAD6_3DMODEL_DIR}/Connector.3dshapes/Banana_Jack_1Pin.wrl" (offset (xyz 0 0 0)) (scale (xyz 2 2 2)) (rotate (xyz 0 0 0)) ) ) (footprint "Connector:Banana_Jack_1Pin" (layer "F.Cu") (tedit 5A1AB217) (tstamp 03698857-8cc4-4a3e-b39a-8a587445208e) (at 35.247804 55.955519) (descr "Single banana socket, footprint - 6mm drill") (tags "banana socket") (attr through_hole) (fp_text reference "REF**" (at 0 -6.5) (layer "F.SilkS") (effects (font (size 1 1) (thickness 0.15))) (tstamp 7c2b2c04-2e51-4ac5-b95d-f85615cf7ea5) ) (fp_text value "Banana_Jack_1Pin" (at -0.25 6.5) (layer "F.Fab") (effects (font (size 1 1) (thickness 0.15))) (tstamp 9d66077f-d65c-4347-8e2a-9c45959f53fb) ) (fp_text user "${REFERENCE}" (at 0 0) (layer "F.Fab") (effects (font (size 0.8 0.8) (thickness 0.12))) (tstamp d9024bfc-1603-450c-9604-6084ca7e3672) ) (fp_circle (center 0 0) (end 5.5 0) (layer "F.SilkS") (width 0.12) (fill none) (tstamp bd07b2eb-5d56-44a5-9342-64c15ad829ec)) (fp_circle (center 0 0) (end 5.75 0) (layer "F.CrtYd") (width 0.05) (fill none) (tstamp 7f61f14c-4d23-4ed7-859d-56f5c9bd9a49)) (fp_circle (center 0 0) (end 4.85 0.05) (layer "F.Fab") (width 0.1) (fill none) (tstamp 399f509a-7034-47be-8135-c7b438d39747)) (fp_circle (center 0 0) (end 2 0) (layer "F.Fab") (width 0.1) (fill none) (tstamp 936b71b6-5519-4313-a95e-5c7f7ea4d831)) (pad "1" thru_hole circle (at 0 0) (size 10.16 10.16) (drill 6.1) (layers F&B.Cu *.Mask) (tstamp deafbeb0-b83a-4551-8dfe-9d4c905c41e2)) (model "${KICAD6_3DMODEL_DIR}/Connector.3dshapes/Banana_Jack_1Pin.wrl" (offset (xyz 0 0 0)) (scale (xyz 2 2 2)) (rotate (xyz 0 0 0)) ) ) (footprint "Connector:Banana_Jack_1Pin" (layer "F.Cu") (tedit 5A1AB217) (tstamp 09fa9ca5-e85c-49c1-9e8e-0d77b1fe08eb) (at 94.3356 71.8058) (descr "Single banana socket, footprint - 6mm drill") (tags "banana socket") (attr through_hole) (fp_text reference "REF**" (at 0 -6.5) (layer "F.SilkS") (effects (font (size 1 1) (thickness 0.15))) (tstamp 7c2b2c04-2e51-4ac5-b95d-f85615cf7ea5) ) (fp_text value "Banana_Jack_1Pin" (at -0.25 6.5) (layer "F.Fab") (effects (font (size 1 1) (thickness 0.15))) (tstamp 9d66077f-d65c-4347-8e2a-9c45959f53fb) ) (fp_text user "${REFERENCE}" (at 0 0) (layer "F.Fab") (effects (font (size 0.8 0.8) (thickness 0.12))) (tstamp d9024bfc-1603-450c-9604-6084ca7e3672) ) (fp_circle (center 0 0) (end 5.5 0) (layer "F.SilkS") (width 0.12) (fill none) (tstamp bd07b2eb-5d56-44a5-9342-64c15ad829ec)) (fp_circle (center 0 0) (end 5.75 0) (layer "F.CrtYd") (width 0.05) (fill none) (tstamp 7f61f14c-4d23-4ed7-859d-56f5c9bd9a49)) (fp_circle (center 0 0) (end 4.85 0.05) (layer "F.Fab") (width 0.1) (fill none) (tstamp 399f509a-7034-47be-8135-c7b438d39747)) (fp_circle (center 0 0) (end 2 0) (layer "F.Fab") (width 0.1) (fill none) (tstamp 936b71b6-5519-4313-a95e-5c7f7ea4d831)) (pad "1" thru_hole circle (at 0 0) (size 10.16 10.16) (drill 6.1) (layers F&B.Cu *.Mask) (tstamp deafbeb0-b83a-4551-8dfe-9d4c905c41e2)) (model "${KICAD6_3DMODEL_DIR}/Connector.3dshapes/Banana_Jack_1Pin.wrl" (offset (xyz 0 0 0)) (scale (xyz 2 2 2)) (rotate (xyz 0 0 0)) ) ) (footprint "" (layer "F.Cu") (tedit 0) (tstamp 138b0f74-f8b7-43a8-af01-1218126bf57b) (at 78.504004 55.879319) (fp_text reference "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp d5058ec7-339d-4b22-b528-86c836d33109) ) (fp_text value "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp e8f7b3cd-2d30-45a3-88ef-4bf62ee1f954) ) (pad "1" thru_hole circle (at 0 0) (size 10.16 10.16) (drill 6.1) (layers F&B.Cu *.Mask) (tstamp c8091646-d942-4641-bc92-aa3d503235cd)) ) (footprint "" (layer "F.Cu") (tedit 0) (tstamp 20cb281c-2bff-44cd-957c-f9afb6f52807) (at 123.7488 88.1126) (fp_text reference "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp 8b6fed3d-4823-4b09-97ef-1099af9a6c92) ) (fp_text value "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp d971bc4c-bc27-462a-83b4-8ce191d8caf7) ) (pad "1" thru_hole circle (at 0 0) (size 10.16 10.16) (drill 6.1) (layers F&B.Cu *.Mask) (tstamp 6bd531c9-0cf8-4b64-9688-1b653e4c221e)) ) (footprint "" (layer "F.Cu") (tedit 0) (tstamp 2e5bd943-cac3-4de6-9f7d-b2c44b2a3e83) (at 137.5918 71.7296) (fp_text reference "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp d5058ec7-339d-4b22-b528-86c836d33109) ) (fp_text value "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp e8f7b3cd-2d30-45a3-88ef-4bf62ee1f954) ) (pad "1" thru_hole circle (at 0 0) (size 10.16 10.16) (drill 6.1) (layers F&B.Cu *.Mask) (tstamp c8091646-d942-4641-bc92-aa3d503235cd)) ) (footprint "" (layer "F.Cu") (tedit 0) (tstamp 2fe9afe4-8f1b-4972-af8f-50dc819f5a8f) (at 64.661004 55.930119) (fp_text reference "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp 8b6fed3d-4823-4b09-97ef-1099af9a6c92) ) (fp_text value "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp d971bc4c-bc27-462a-83b4-8ce191d8caf7) ) (pad "1" thru_hole circle (at 0 0) (size 10.16 10.16) (drill 6.1) (layers F&B.Cu *.Mask) (tstamp 6bd531c9-0cf8-4b64-9688-1b653e4c221e)) ) (footprint "" (layer "F.Cu") (tedit 0) (tstamp 4d240381-c0a4-4388-a3ab-9150126524a7) (at 123.741404 55.904719) (fp_text reference "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp 8b6fed3d-4823-4b09-97ef-1099af9a6c92) ) (fp_text value "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp d971bc4c-bc27-462a-83b4-8ce191d8caf7) ) (pad "1" thru_hole circle (at 0 0) (size 10.16 10.16) (drill 6.1) (layers F&B.Cu *.Mask) (tstamp 6bd531c9-0cf8-4b64-9688-1b653e4c221e)) ) (footprint "Connector:Banana_Jack_1Pin" (layer "F.Cu") (tedit 5A1AB217) (tstamp 534f8d07-6b4b-4d72-bad6-47591230e2ad) (at 94.3356 40.1828) (descr "Single banana socket, footprint - 6mm drill") (tags "banana socket") (attr through_hole) (fp_text reference "REF**" (at 0 -6.5) (layer "F.SilkS") (effects (font (size 1 1) (thickness 0.15))) (tstamp 7c2b2c04-2e51-4ac5-b95d-f85615cf7ea5) ) (fp_text value "Banana_Jack_1Pin" (at -0.25 6.5) (layer "F.Fab") (effects (font (size 1 1) (thickness 0.15))) (tstamp 9d66077f-d65c-4347-8e2a-9c45959f53fb) ) (fp_text user "${REFERENCE}" (at 0 0) (layer "F.Fab") (effects (font (size 0.8 0.8) (thickness 0.12))) (tstamp d9024bfc-1603-450c-9604-6084ca7e3672) ) (fp_circle (center 0 0) (end 5.5 0) (layer "F.SilkS") (width 0.12) (fill none) (tstamp bd07b2eb-5d56-44a5-9342-64c15ad829ec)) (fp_circle (center 0 0) (end 5.75 0) (layer "F.CrtYd") (width 0.05) (fill none) (tstamp 7f61f14c-4d23-4ed7-859d-56f5c9bd9a49)) (fp_circle (center 0 0) (end 4.85 0.05) (layer "F.Fab") (width 0.1) (fill none) (tstamp 399f509a-7034-47be-8135-c7b438d39747)) (fp_circle (center 0 0) (end 2 0) (layer "F.Fab") (width 0.1) (fill none) (tstamp 936b71b6-5519-4313-a95e-5c7f7ea4d831)) (pad "1" thru_hole circle (at 0 0) (size 10.16 10.16) (drill 6.1) (layers F&B.Cu *.Mask) (tstamp deafbeb0-b83a-4551-8dfe-9d4c905c41e2)) (model "${KICAD6_3DMODEL_DIR}/Connector.3dshapes/Banana_Jack_1Pin.wrl" (offset (xyz 0 0 0)) (scale (xyz 2 2 2)) (rotate (xyz 0 0 0)) ) ) (footprint "" (layer "F.Cu") (tedit 0) (tstamp 53799552-5abd-4861-bc5e-a8e9c719a250) (at 108.171204 55.879319) (fp_text reference "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp 5dc3f1e1-9332-4b99-a0cf-cfc936f2ba70) ) (fp_text value "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp efe9d540-0496-40ff-afe8-c3aeb92a693d) ) (pad "1" thru_hole circle (at 0 0) (size 10.16 10.16) (drill 6.1) (layers F&B.Cu *.Mask) (tstamp 2674b4e6-6223-41b6-9238-dd08d0c80854)) ) (footprint "" (layer "F.Cu") (tedit 0) (tstamp 54f3a99f-e5cd-4a68-955e-13c7b9299887) (at 137.5918 40.1066) (fp_text reference "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp d5058ec7-339d-4b22-b528-86c836d33109) ) (fp_text value "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp e8f7b3cd-2d30-45a3-88ef-4bf62ee1f954) ) (pad "1" thru_hole circle (at 0 0) (size 10.16 10.16) (drill 6.1) (layers F&B.Cu *.Mask) (tstamp c8091646-d942-4641-bc92-aa3d503235cd)) ) (footprint "" (layer "F.Cu") (tedit 0) (tstamp 56a08456-1561-4752-8597-ab80a015f50a) (at 64.6684 40.1828) (fp_text reference "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp 8b6fed3d-4823-4b09-97ef-1099af9a6c92) ) (fp_text value "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp d971bc4c-bc27-462a-83b4-8ce191d8caf7) ) (pad "1" thru_hole circle (at 0 0) (size 10.16 10.16) (drill 6.1) (layers F&B.Cu *.Mask) (tstamp 6bd531c9-0cf8-4b64-9688-1b653e4c221e)) ) (footprint "" (layer "F.Cu") (tedit 0) (tstamp 5e3eb23d-fdb3-46df-be73-063c9aa032af) (at 78.5114 71.755) (fp_text reference "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp d5058ec7-339d-4b22-b528-86c836d33109) ) (fp_text value "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp e8f7b3cd-2d30-45a3-88ef-4bf62ee1f954) ) (pad "1" thru_hole circle (at 0 0) (size 10.16 10.16) (drill 6.1) (layers F&B.Cu *.Mask) (tstamp c8091646-d942-4641-bc92-aa3d503235cd)) ) (footprint "" (layer "F.Cu") (tedit 0) (tstamp 6a83bab7-a25d-4d42-a36a-46a892c34675) (at 123.7488 40.1574) (fp_text reference "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp 8b6fed3d-4823-4b09-97ef-1099af9a6c92) ) (fp_text value "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp d971bc4c-bc27-462a-83b4-8ce191d8caf7) ) (pad "1" thru_hole circle (at 0 0) (size 10.16 10.16) (drill 6.1) (layers F&B.Cu *.Mask) (tstamp 6bd531c9-0cf8-4b64-9688-1b653e4c221e)) ) (footprint "" (layer "F.Cu") (tedit 0) (tstamp 73aafdee-0781-4943-959c-2cf566928258) (at 49.0982 88.1126) (fp_text reference "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp 5dc3f1e1-9332-4b99-a0cf-cfc936f2ba70) ) (fp_text value "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp efe9d540-0496-40ff-afe8-c3aeb92a693d) ) (pad "1" thru_hole circle (at 0 0) (size 10.16 10.16) (drill 6.1) (layers F&B.Cu *.Mask) (tstamp 2674b4e6-6223-41b6-9238-dd08d0c80854)) ) (footprint "" (layer "F.Cu") (tedit 0) (tstamp 78db281d-152c-46af-8036-b47b4b2e73d8) (at 108.1786 40.132) (fp_text reference "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp 5dc3f1e1-9332-4b99-a0cf-cfc936f2ba70) ) (fp_text value "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp efe9d540-0496-40ff-afe8-c3aeb92a693d) ) (pad "1" thru_hole circle (at 0 0) (size 10.16 10.16) (drill 6.1) (layers F&B.Cu *.Mask) (tstamp 2674b4e6-6223-41b6-9238-dd08d0c80854)) ) (footprint "" (layer "F.Cu") (tedit 0) (tstamp 7cb2ab57-0509-45b7-9c5d-daf8e460d1a0) (at 64.6684 88.138) (fp_text reference "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp 8b6fed3d-4823-4b09-97ef-1099af9a6c92) ) (fp_text value "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp d971bc4c-bc27-462a-83b4-8ce191d8caf7) ) (pad "1" thru_hole circle (at 0 0) (size 10.16 10.16) (drill 6.1) (layers F&B.Cu *.Mask) (tstamp 6bd531c9-0cf8-4b64-9688-1b653e4c221e)) ) (footprint "" (layer "F.Cu") (tedit 0) (tstamp 80e5e52f-ab22-4129-8406-20e118382d7e) (at 108.1786 88.0872) (fp_text reference "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp 5dc3f1e1-9332-4b99-a0cf-cfc936f2ba70) ) (fp_text value "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp efe9d540-0496-40ff-afe8-c3aeb92a693d) ) (pad "1" thru_hole circle (at 0 0) (size 10.16 10.16) (drill 6.1) (layers F&B.Cu *.Mask) (tstamp 2674b4e6-6223-41b6-9238-dd08d0c80854)) ) (footprint "" (layer "F.Cu") (tedit 0) (tstamp 8b7e75d5-4c03-4aab-b9af-fe7b4279e304) (at 49.0982 40.1574) (fp_text reference "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp 5dc3f1e1-9332-4b99-a0cf-cfc936f2ba70) ) (fp_text value "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp efe9d540-0496-40ff-afe8-c3aeb92a693d) ) (pad "1" thru_hole circle (at 0 0) (size 10.16 10.16) (drill 6.1) (layers F&B.Cu *.Mask) (tstamp 2674b4e6-6223-41b6-9238-dd08d0c80854)) ) (footprint "" (layer "F.Cu") (tedit 0) (tstamp 97c817b2-edd2-4720-bcfd-a7d8346bc75f) (at 78.5114 88.0872) (fp_text reference "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp d5058ec7-339d-4b22-b528-86c836d33109) ) (fp_text value "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp e8f7b3cd-2d30-45a3-88ef-4bf62ee1f954) ) (pad "1" thru_hole circle (at 0 0) (size 10.16 10.16) (drill 6.1) (layers F&B.Cu *.Mask) (tstamp c8091646-d942-4641-bc92-aa3d503235cd)) ) (footprint "Connector:Banana_Jack_1Pin" (layer "F.Cu") (tedit 5A1AB217) (tstamp 981faa12-93a3-4c34-841e-7a8539f8104e) (at 35.2552 40.2082) (descr "Single banana socket, footprint - 6mm drill") (tags "banana socket") (attr through_hole) (fp_text reference "REF**" (at 0 -6.5) (layer "F.SilkS") (effects (font (size 1 1) (thickness 0.15))) (tstamp 7c2b2c04-2e51-4ac5-b95d-f85615cf7ea5) ) (fp_text value "Banana_Jack_1Pin" (at -0.25 6.5) (layer "F.Fab") (effects (font (size 1 1) (thickness 0.15))) (tstamp 9d66077f-d65c-4347-8e2a-9c45959f53fb) ) (fp_text user "${REFERENCE}" (at 0 0) (layer "F.Fab") (effects (font (size 0.8 0.8) (thickness 0.12))) (tstamp d9024bfc-1603-450c-9604-6084ca7e3672) ) (fp_circle (center 0 0) (end 5.5 0) (layer "F.SilkS") (width 0.12) (fill none) (tstamp bd07b2eb-5d56-44a5-9342-64c15ad829ec)) (fp_circle (center 0 0) (end 5.75 0) (layer "F.CrtYd") (width 0.05) (fill none) (tstamp 7f61f14c-4d23-4ed7-859d-56f5c9bd9a49)) (fp_circle (center 0 0) (end 4.85 0.05) (layer "F.Fab") (width 0.1) (fill none) (tstamp 399f509a-7034-47be-8135-c7b438d39747)) (fp_circle (center 0 0) (end 2 0) (layer "F.Fab") (width 0.1) (fill none) (tstamp 936b71b6-5519-4313-a95e-5c7f7ea4d831)) (pad "1" thru_hole circle (at 0 0) (size 10.16 10.16) (drill 6.1) (layers *.Cu *.Mask) (tstamp deafbeb0-b83a-4551-8dfe-9d4c905c41e2)) (model "${KICAD6_3DMODEL_DIR}/Connector.3dshapes/Banana_Jack_1Pin.wrl" (offset (xyz 0 0 0)) (scale (xyz 2 2 2)) (rotate (xyz 0 0 0)) ) ) (footprint "" (layer "F.Cu") (tedit 0) (tstamp 999cce69-2e79-4a66-ae12-546beb18b5f4) (at 137.584404 55.853919) (fp_text reference "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp d5058ec7-339d-4b22-b528-86c836d33109) ) (fp_text value "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp e8f7b3cd-2d30-45a3-88ef-4bf62ee1f954) ) (pad "1" thru_hole circle (at 0 0) (size 10.16 10.16) (drill 6.1) (layers F&B.Cu *.Mask) (tstamp c8091646-d942-4641-bc92-aa3d503235cd)) ) (footprint "" (layer "F.Cu") (tedit 0) (tstamp 9d9d76a5-184e-4fc4-a61d-99c3a26cdbcd) (at 78.5114 40.132) (fp_text reference "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp d5058ec7-339d-4b22-b528-86c836d33109) ) (fp_text value "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp e8f7b3cd-2d30-45a3-88ef-4bf62ee1f954) ) (pad "1" thru_hole circle (at 0 0) (size 10.16 10.16) (drill 6.1) (layers F&B.Cu *.Mask) (tstamp c8091646-d942-4641-bc92-aa3d503235cd)) ) (footprint "Connector:Banana_Jack_1Pin" (layer "F.Cu") (tedit 5A1AB217) (tstamp b36875a6-5741-45ca-bb7c-2dadfbe9c6c7) (at 94.328204 55.930119) (descr "Single banana socket, footprint - 6mm drill") (tags "banana socket") (attr through_hole) (fp_text reference "REF**" (at 0 -6.5) (layer "F.SilkS") (effects (font (size 1 1) (thickness 0.15))) (tstamp 7c2b2c04-2e51-4ac5-b95d-f85615cf7ea5) ) (fp_text value "Banana_Jack_1Pin" (at -0.25 6.5) (layer "F.Fab") (effects (font (size 1 1) (thickness 0.15))) (tstamp 9d66077f-d65c-4347-8e2a-9c45959f53fb) ) (fp_text user "${REFERENCE}" (at 0 0) (layer "F.Fab") (effects (font (size 0.8 0.8) (thickness 0.12))) (tstamp d9024bfc-1603-450c-9604-6084ca7e3672) ) (fp_circle (center 0 0) (end 5.5 0) (layer "F.SilkS") (width 0.12) (fill none) (tstamp bd07b2eb-5d56-44a5-9342-64c15ad829ec)) (fp_circle (center 0 0) (end 5.75 0) (layer "F.CrtYd") (width 0.05) (fill none) (tstamp 7f61f14c-4d23-4ed7-859d-56f5c9bd9a49)) (fp_circle (center 0 0) (end 4.85 0.05) (layer "F.Fab") (width 0.1) (fill none) (tstamp 399f509a-7034-47be-8135-c7b438d39747)) (fp_circle (center 0 0) (end 2 0) (layer "F.Fab") (width 0.1) (fill none) (tstamp 936b71b6-5519-4313-a95e-5c7f7ea4d831)) (pad "1" thru_hole circle (at 0 0) (size 10.16 10.16) (drill 6.1) (layers F&B.Cu *.Mask) (tstamp deafbeb0-b83a-4551-8dfe-9d4c905c41e2)) (model "${KICAD6_3DMODEL_DIR}/Connector.3dshapes/Banana_Jack_1Pin.wrl" (offset (xyz 0 0 0)) (scale (xyz 2 2 2)) (rotate (xyz 0 0 0)) ) ) (footprint "" (layer "F.Cu") (tedit 0) (tstamp bce0caac-1d97-4a66-91bb-966ced07ac41) (at 123.7488 71.7804) (fp_text reference "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp 8b6fed3d-4823-4b09-97ef-1099af9a6c92) ) (fp_text value "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp d971bc4c-bc27-462a-83b4-8ce191d8caf7) ) (pad "1" thru_hole circle (at 0 0) (size 10.16 10.16) (drill 6.1) (layers F&B.Cu *.Mask) (tstamp 6bd531c9-0cf8-4b64-9688-1b653e4c221e)) ) (footprint "Connector:Banana_Jack_1Pin" (layer "F.Cu") (tedit 5A1AB217) (tstamp c5115e22-f321-48ff-aea5-b76ca3c4bf20) (at 35.2552 71.8312) (descr "Single banana socket, footprint - 6mm drill") (tags "banana socket") (attr through_hole) (fp_text reference "REF**" (at 0 -6.5) (layer "F.SilkS") (effects (font (size 1 1) (thickness 0.15))) (tstamp 7c2b2c04-2e51-4ac5-b95d-f85615cf7ea5) ) (fp_text value "Banana_Jack_1Pin" (at -0.25 6.5) (layer "F.Fab") (effects (font (size 1 1) (thickness 0.15))) (tstamp 9d66077f-d65c-4347-8e2a-9c45959f53fb) ) (fp_text user "${REFERENCE}" (at 0 0) (layer "F.Fab") (effects (font (size 0.8 0.8) (thickness 0.12))) (tstamp d9024bfc-1603-450c-9604-6084ca7e3672) ) (fp_circle (center 0 0) (end 5.5 0) (layer "F.SilkS") (width 0.12) (fill none) (tstamp bd07b2eb-5d56-44a5-9342-64c15ad829ec)) (fp_circle (center 0 0) (end 5.75 0) (layer "F.CrtYd") (width 0.05) (fill none) (tstamp 7f61f14c-4d23-4ed7-859d-56f5c9bd9a49)) (fp_circle (center 0 0) (end 4.85 0.05) (layer "F.Fab") (width 0.1) (fill none) (tstamp 399f509a-7034-47be-8135-c7b438d39747)) (fp_circle (center 0 0) (end 2 0) (layer "F.Fab") (width 0.1) (fill none) (tstamp 936b71b6-5519-4313-a95e-5c7f7ea4d831)) (pad "1" thru_hole circle (at 0 0) (size 10.16 10.16) (drill 6.1) (layers F&B.Cu *.Mask) (tstamp deafbeb0-b83a-4551-8dfe-9d4c905c41e2)) (model "${KICAD6_3DMODEL_DIR}/Connector.3dshapes/Banana_Jack_1Pin.wrl" (offset (xyz 0 0 0)) (scale (xyz 2 2 2)) (rotate (xyz 0 0 0)) ) ) (footprint "" (layer "F.Cu") (tedit 0) (tstamp cd2ea6c7-3aba-4638-8587-6706fdc154ec) (at 49.0982 71.7804) (fp_text reference "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp 5dc3f1e1-9332-4b99-a0cf-cfc936f2ba70) ) (fp_text value "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp efe9d540-0496-40ff-afe8-c3aeb92a693d) ) (pad "1" thru_hole circle (at 0 0) (size 10.16 10.16) (drill 6.1) (layers F&B.Cu *.Mask) (tstamp 2674b4e6-6223-41b6-9238-dd08d0c80854)) ) (footprint "" (layer "F.Cu") (tedit 0) (tstamp ce9c1f27-15e0-4d74-adc6-aa4de1199929) (at 49.090804 55.904719) (fp_text reference "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp 5dc3f1e1-9332-4b99-a0cf-cfc936f2ba70) ) (fp_text value "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp efe9d540-0496-40ff-afe8-c3aeb92a693d) ) (pad "1" thru_hole circle (at 0 0) (size 10.16 10.16) (drill 6.1) (layers F&B.Cu *.Mask) (tstamp 2674b4e6-6223-41b6-9238-dd08d0c80854)) ) (footprint "" (layer "F.Cu") (tedit 0) (tstamp e326b3d7-f107-4dad-be94-06d6d91d68e4) (at 64.6684 71.8058) (fp_text reference "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp 8b6fed3d-4823-4b09-97ef-1099af9a6c92) ) (fp_text value "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp d971bc4c-bc27-462a-83b4-8ce191d8caf7) ) (pad "1" thru_hole circle (at 0 0) (size 10.16 10.16) (drill 6.1) (layers F&B.Cu *.Mask) (tstamp 6bd531c9-0cf8-4b64-9688-1b653e4c221e)) ) (footprint "Connector:Banana_Jack_1Pin" (layer "F.Cu") (tedit 5A1AB217) (tstamp e8a2dada-eefe-47ae-a3fa-e669050fb731) (at 94.3356 88.138) (descr "Single banana socket, footprint - 6mm drill") (tags "banana socket") (attr through_hole) (fp_text reference "REF**" (at 0 -6.5) (layer "F.SilkS") (effects (font (size 1 1) (thickness 0.15))) (tstamp 7c2b2c04-2e51-4ac5-b95d-f85615cf7ea5) ) (fp_text value "Banana_Jack_1Pin" (at -0.25 6.5) (layer "F.Fab") (effects (font (size 1 1) (thickness 0.15))) (tstamp 9d66077f-d65c-4347-8e2a-9c45959f53fb) ) (fp_text user "${REFERENCE}" (at 0 0) (layer "F.Fab") (effects (font (size 0.8 0.8) (thickness 0.12))) (tstamp d9024bfc-1603-450c-9604-6084ca7e3672) ) (fp_circle (center 0 0) (end 5.5 0) (layer "F.SilkS") (width 0.12) (fill none) (tstamp bd07b2eb-5d56-44a5-9342-64c15ad829ec)) (fp_circle (center 0 0) (end 5.75 0) (layer "F.CrtYd") (width 0.05) (fill none) (tstamp 7f61f14c-4d23-4ed7-859d-56f5c9bd9a49)) (fp_circle (center 0 0) (end 4.85 0.05) (layer "F.Fab") (width 0.1) (fill none) (tstamp 399f509a-7034-47be-8135-c7b438d39747)) (fp_circle (center 0 0) (end 2 0) (layer "F.Fab") (width 0.1) (fill none) (tstamp 936b71b6-5519-4313-a95e-5c7f7ea4d831)) (pad "1" thru_hole circle (at 0 0) (size 10.16 10.16) (drill 6.1) (layers F&B.Cu *.Mask) (tstamp deafbeb0-b83a-4551-8dfe-9d4c905c41e2)) (model "${KICAD6_3DMODEL_DIR}/Connector.3dshapes/Banana_Jack_1Pin.wrl" (offset (xyz 0 0 0)) (scale (xyz 2 2 2)) (rotate (xyz 0 0 0)) ) ) (footprint "" (layer "F.Cu") (tedit 0) (tstamp ea8f6ff4-c600-4b75-b4f4-6aaf3907e6c9) (at 108.1786 71.755) (fp_text reference "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp 5dc3f1e1-9332-4b99-a0cf-cfc936f2ba70) ) (fp_text value "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp efe9d540-0496-40ff-afe8-c3aeb92a693d) ) (pad "1" thru_hole circle (at 0 0) (size 10.16 10.16) (drill 6.1) (layers F&B.Cu *.Mask) (tstamp 2674b4e6-6223-41b6-9238-dd08d0c80854)) ) (footprint "" (layer "F.Cu") (tedit 0) (tstamp ec32829b-a555-48f8-b221-4eb92996be60) (at 137.5918 88.0618) (fp_text reference "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp d5058ec7-339d-4b22-b528-86c836d33109) ) (fp_text value "" (at 0 0) (layer "F.SilkS") (effects (font (size 1.27 1.27) (thickness 0.15))) (tstamp e8f7b3cd-2d30-45a3-88ef-4bf62ee1f954) ) (pad "1" thru_hole circle (at 0 0) (size 10.16 10.16) (drill 6.1) (layers F&B.Cu *.Mask) (tstamp c8091646-d942-4641-bc92-aa3d503235cd)) ) (gr_line (start 137.5918 64.6176) (end 137.5918 71.7042) (layer "Dwgs.User") (width 0.1) (tstamp 0699af37-815d-4f16-b85f-79d79ef8a506)) (gr_line (start 35.2552 64.6938) (end 35.2552 71.7804) (layer "Dwgs.User") (width 0.1) (tstamp 07b154e1-c81f-4ad5-b064-6e8707727ee7)) (gr_line (start 64.6176 68.707) (end 78.4606 68.707) (layer "Dwgs.User") (width 0.1) (tstamp 084d4543-8bc9-49f9-8459-791b5b0d7815)) (gr_rect (start 27.907204 62.000719) (end 56.355204 63.499319) (layer "Dwgs.User") (width 0.1) (fill none) (tstamp 0aa034a6-410c-49f0-a60a-aaa019620b96)) (gr_arc (start 111.2774 88.138) (mid 105.079901 88.162988) (end 111.276997 88.088026) (layer "Dwgs.User") (width 0.1) (tstamp 0afd5d5c-d4fc-46c6-80a3-7457d5b9a3c8)) (gr_line (start 49.0982 81.0006) (end 49.0982 88.0872) (layer "Dwgs.User") (width 0.1) (tstamp 0dbbd775-2138-4cfd-a954-59d279d7f550)) (gr_line (start 94.2848 68.707) (end 108.1278 68.707) (layer "Dwgs.User") (width 0.1) (tstamp 0ed398b7-a5cf-4de2-92ff-c9460d6a4626)) (gr_rect (start 86.987604 48.767319) (end 115.435604 61.975319) (layer "Dwgs.User") (width 0.1) (fill none) (tstamp 0efd722f-8888-4b4c-a1a5-7236f958cfd7)) (gr_line (start 35.197004 52.856719) (end 49.040004 52.856719) (layer "Dwgs.User") (width 0.1) (tstamp 0fac926d-8cd9-4610-84cc-b04819ae722f)) (gr_rect (start 86.995 94.1832) (end 115.443 95.6818) (layer "Dwgs.User") (width 0.1) (fill none) (tstamp 117eb060-29ea-4e08-8210-9a0e7f01f890)) (gr_arc (start 97.3328 40.1828) (mid 91.135301 40.20779) (end 97.332397 40.132826) (layer "Dwgs.User") (width 0.1) (tstamp 12431d51-5603-4642-aff4-20ea722c9e3a)) (gr_line (start 123.698 85.0138) (end 137.541 85.0138) (layer "Dwgs.User") (width 0.1) (tstamp 153d8b1d-1dfe-47fb-982f-5429c06b7200)) (gr_line (start 94.3356 81.0006) (end 94.3356 88.0872) (layer "Dwgs.User") (width 0.1) (tstamp 18b4fb5d-2c61-4033-aca1-84fdfa4c6ce9)) (gr_line (start 123.698 37.0586) (end 137.541 37.0586) (layer "Dwgs.User") (width 0.1) (tstamp 18da7d65-c953-4e85-8f25-6335c3813b9c)) (gr_line (start 57.3405 71.8058) (end 64.6303 71.8058) (layer "Dwgs.User") (width 0.1) (tstamp 1e393d72-20c9-4dbb-803d-335ee84ee7d6)) (gr_line (start 49.0982 71.7804) (end 56.388 71.7804) (layer "Dwgs.User") (width 0.1) (tstamp 1fb50565-80f9-4b4e-af67-cdad428bfaf0)) (gr_arc (start 126.746 40.1574) (mid 120.548501 40.18239) (end 126.745597 40.107426) (layer "Dwgs.User") (width 0.1) (tstamp 214eac48-5d34-47e9-aed3-6aadf54dac88)) (gr_arc (start 111.2774 71.8058) (mid 105.079901 71.83079) (end 111.276997 71.755826) (layer "Dwgs.User") (width 0.1) (tstamp 27130b58-384c-4af1-985b-2cf98650bc86)) (gr_line (start 108.1786 88.0872) (end 115.4684 88.0872) (layer "Dwgs.User") (width 0.1) (tstamp 2e2d1a31-7611-49e8-bda5-66054beaca15)) (gr_rect (start 27.907204 48.792719) (end 56.355204 62.000719) (layer "Dwgs.User") (width 0.1) (fill none) (tstamp 300f909e-46dd-4978-8b24-980276327718)) (gr_line (start 78.5114 80.9752) (end 78.5114 88.0618) (layer "Dwgs.User") (width 0.1) (tstamp 30eedb97-78eb-45d0-9ed7-34402fce53fc)) (gr_line (start 64.6176 85.0392) (end 78.4606 85.0392) (layer "Dwgs.User") (width 0.1) (tstamp 31d05ac8-b3c3-4405-8aa6-f63fbb8d3154)) (gr_arc (start 140.6906 71.7804) (mid 134.493101 71.80539) (end 140.690197 71.730426) (layer "Dwgs.User") (width 0.1) (tstamp 3656858c-2dc5-4b13-a37f-4c64d688573a)) (gr_rect (start 57.320404 48.767319) (end 85.768404 61.975319) (layer "Dwgs.User") (width 0.1) (fill none) (tstamp 36d71bae-5218-48cb-81e6-7ea6dd4e3951)) (gr_line (start 35.2552 33.0708) (end 35.2552 40.1574) (layer "Dwgs.User") (width 0.1) (tstamp 39808e4b-516b-4cfd-9cad-3a15f41d4866)) (gr_line (start 137.5918 32.9946) (end 137.5918 40.0812) (layer "Dwgs.User") (width 0.1) (tstamp 3bb3abfa-2b16-4d5f-a053-23b497fe25df)) (gr_line (start 87.0077 71.8058) (end 94.2975 71.8058) (layer "Dwgs.User") (width 0.1) (tstamp 3d577ceb-7497-4a87-8323-b34cac243fe2)) (gr_line (start 78.5114 88.0872) (end 85.8012 88.0872) (layer "Dwgs.User") (width 0.1) (tstamp 43409f3e-da46-4a97-a9d2-1f5e561f605c)) (gr_line (start 64.661004 48.792719) (end 64.661004 55.879319) (layer "Dwgs.User") (width 0.1) (tstamp 48309164-baaa-4bde-a38c-5f3a0fa8285e)) (gr_line (start 57.333104 55.930119) (end 64.622904 55.930119) (layer "Dwgs.User") (width 0.1) (tstamp 4842b6ea-e6ef-4ebd-8f70-e71037c39851)) (gr_arc (start 126.746 71.7804) (mid 120.548501 71.80539) (end 126.745597 71.730426) (layer "Dwgs.User") (width 0.1) (tstamp 4a31bd4e-2427-444e-a5c7-3c84eaa327a8)) (gr_arc (start 81.6102 88.138) (mid 75.412701 88.162988) (end 81.609797 88.088026) (layer "Dwgs.User") (width 0.1) (tstamp 4aee85b9-e2cd-4161-91a8-d9ed0410a856)) (gr_line (start 78.5114 64.643) (end 78.5114 71.7296) (layer "Dwgs.User") (width 0.1) (tstamp 4c387b7b-4dc6-40be-b89f-f058fe0163f6)) (gr_line (start 137.584404 55.853919) (end 144.874204 55.853919) (layer "Dwgs.User") (width 0.1) (tstamp 4f2999a9-5363-44e8-a0c5-b476c88cb6e3)) (gr_rect (start 116.400804 61.949919) (end 144.848804 63.448519) (layer "Dwgs.User") (width 0.1) (fill none) (tstamp 54dcad7c-219d-453c-885f-ca55b5aed419)) (gr_line (start 116.4209 71.7804) (end 123.7107 71.7804) (layer "Dwgs.User") (width 0.1) (tstamp 55b04e03-e3ca-4a54-abb7-2ff7864bb718)) (gr_line (start 49.0982 33.0454) (end 49.0982 40.132) (layer "Dwgs.User") (width 0.1) (tstamp 56f1bb2c-aef9-4708-a970-c53f2b4ed2ce)) (gr_arc (start 126.738604 55.904719) (mid 120.541105 55.929709) (end 126.738201 55.854745) (layer "Dwgs.User") (width 0.1) (tstamp 5a87a4c5-365e-4bc3-bd4e-ab432b47b5d3)) (gr_line (start 123.698 68.6816) (end 137.541 68.6816) (layer "Dwgs.User") (width 0.1) (tstamp 5b747fef-47c4-4255-81a6-aec4f370ce23)) (gr_line (start 49.0982 40.1574) (end 56.388 40.1574) (layer "Dwgs.User") (width 0.1) (tstamp 5d146614-59fe-4535-ad89-3f67274aa287)) (gr_rect (start 57.320404 61.975319) (end 85.768404 63.473919) (layer "Dwgs.User") (width 0.1) (fill none) (tstamp 62af59bc-19fd-446b-b3cc-ffd304eb757c)) (gr_line (start 49.090804 55.904719) (end 56.380604 55.904719) (layer "Dwgs.User") (width 0.1) (tstamp 64a740ee-b7fd-4403-a1ef-a46069ad3361)) (gr_rect (start 86.987604 61.975319) (end 115.435604 63.473919) (layer "Dwgs.User") (width 0.1) (fill none) (tstamp 65a4644f-8d15-431a-9c7c-f67a3655231d)) (gr_rect (start 116.4082 46.2026) (end 144.8562 47.7012) (layer "Dwgs.User") (width 0.1) (fill none) (tstamp 669981b5-aa89-4b6f-a4db-b68cdad4129a)) (gr_rect (start 116.400804 48.741919) (end 144.848804 61.949919) (layer "Dwgs.User") (width 0.1) (fill none) (tstamp 67da0c51-b68a-4bee-94d7-ca21c0c46472)) (gr_arc (start 38.2524 40.2082) (mid 32.054901 40.233188) (end 38.251997 40.158226) (layer "Dwgs.User") (width 0.1) (tstamp 6896907c-27b4-4c98-8038-3df8aac558e0)) (gr_arc (start 81.602804 55.930119) (mid 75.405305 55.955109) (end 81.602401 55.880145) (layer "Dwgs.User") (width 0.1) (tstamp 6a3e767b-aee7-4ea5-9e3f-7056ac25b71e)) (gr_line (start 57.3405 88.138) (end 64.6303 88.138) (layer "Dwgs.User") (width 0.1) (tstamp 6b637dcb-6dde-4170-bdbd-9ed2824a2881)) (gr_rect (start 86.995 80.9752) (end 115.443 94.1832) (layer "Dwgs.User") (width 0.1) (fill none) (tstamp 6d99c156-827e-4fb5-8e5c-897dd0de5230)) (gr_arc (start 81.6102 71.8058) (mid 75.412701 71.83079) (end 81.609797 71.755826) (layer "Dwgs.User") (width 0.1) (tstamp 6ed1d6e6-bfda-41c4-ab02-0251489284bc)) (gr_rect (start 57.3278 64.643) (end 85.7758 77.851) (layer "Dwgs.User") (width 0.1) (fill none) (tstamp 73ced536-383b-4fcb-9625-2acb55f65ac6)) (gr_rect (start 86.995 77.851) (end 115.443 79.3496) (layer "Dwgs.User") (width 0.1) (fill none) (tstamp 750e2ea6-befa-44a5-980e-516335df1202)) (gr_rect (start 27.9146 64.6684) (end 56.3626 77.8764) (layer "Dwgs.User") (width 0.1) (fill none) (tstamp 7649c05c-291f-4ecc-97ac-79971072675d)) (gr_arc (start 111.270004 55.930119) (mid 105.072505 55.955109) (end 111.269601 55.880145) (layer "Dwgs.User") (width 0.1) (tstamp 7867010c-cc10-49b4-9753-c1ffe8004d3e)) (gr_line (start 116.4209 40.1574) (end 123.7107 40.1574) (layer "Dwgs.User") (width 0.1) (tstamp 7938c164-7bc3-447c-967c-e0150594ca70)) (gr_line (start 87.0077 40.1828) (end 94.2975 40.1828) (layer "Dwgs.User") (width 0.1) (tstamp 798fa9de-b8ce-4349-b244-3ea274e8ed8a)) (gr_arc (start 38.2524 71.8312) (mid 32.054901 71.85619) (end 38.251997 71.781226) (layer "Dwgs.User") (width 0.1) (tstamp 79a0cae5-57d2-4672-8c96-ddddd59649ef)) (gr_line (start 35.2552 81.026) (end 35.2552 88.1126) (layer "Dwgs.User") (width 0.1) (tstamp 7e34bc50-266f-4c4a-8541-4956f8d8977f)) (gr_line (start 49.0982 64.6684) (end 49.0982 71.755) (layer "Dwgs.User") (width 0.1) (tstamp 7f8ab8ca-2645-4958-8319-8f263d254d5f)) (gr_arc (start 97.3328 88.138) (mid 91.135301 88.162988) (end 97.332397 88.088026) (layer "Dwgs.User") (width 0.1) (tstamp 8247403b-1001-41e3-8733-49004ceaab51)) (gr_line (start 94.328204 48.792719) (end 94.328204 55.879319) (layer "Dwgs.User") (width 0.1) (tstamp 8308c9c5-7568-491c-b1f9-fff4dae9710c)) (gr_rect (start 57.3278 94.1832) (end 85.7758 95.6818) (layer "Dwgs.User") (width 0.1) (fill none) (tstamp 8356d6e2-fa09-4ad0-b228-da90a06aeda0)) (gr_rect (start 57.3278 77.851) (end 85.7758 79.3496) (layer "Dwgs.User") (width 0.1) (fill none) (tstamp 841d4139-407a-444a-9b58-4860d9eb648e)) (gr_arc (start 140.6906 88.1126) (mid 134.493101 88.137588) (end 140.690197 88.062626) (layer "Dwgs.User") (width 0.1) (tstamp 8613f8a5-2cb0-4210-b92c-942d006fec12)) (gr_line (start 27.9273 71.8312) (end 35.2171 71.8312) (layer "Dwgs.User") (width 0.1) (tstamp 877946e7-0353-4073-9cda-a7333aab8879)) (gr_line (start 108.1786 71.755) (end 115.4684 71.755) (layer "Dwgs.User") (width 0.1) (tstamp 8868ccc8-1d40-4b91-9fde-6adacabba7d0)) (gr_rect (start 27.9146 77.8764) (end 56.3626 79.375) (layer "Dwgs.User") (width 0.1) (fill none) (tstamp 890829f1-a06e-4386-a7c0-3620ae6ad635)) (gr_line (start 64.6684 81.0006) (end 64.6684 88.0872) (layer "Dwgs.User") (width 0.1) (tstamp 8c031242-ec5d-4e7f-acf5-ba3717aa3714)) (gr_line (start 108.171204 48.767319) (end 108.171204 55.853919) (layer "Dwgs.User") (width 0.1) (tstamp 8dda4bfd-ab3b-4d21-a906-525f7e7cfe83)) (gr_arc (start 67.6656 88.138) (mid 61.468101 88.162988) (end 67.665197 88.088026) (layer "Dwgs.User") (width 0.1) (tstamp 8ddf3508-0411-44d3-bad1-4c73efb9ffec)) (gr_rect (start 116.4082 94.1578) (end 144.8562 95.6564) (layer "Dwgs.User") (width 0.1) (fill none) (tstamp 8fa9289f-711a-4ece-b4ff-a21b4f721415)) (gr_line (start 35.2044 85.0646) (end 49.0474 85.0646) (layer "Dwgs.User") (width 0.1) (tstamp 905db137-3883-4ada-8c0c-b52baf4415bc)) (gr_line (start 94.2848 85.0392) (end 108.1278 85.0392) (layer "Dwgs.User") (width 0.1) (tstamp 91001fd4-cf07-4af5-85b2-feae8bb09b22)) (gr_rect (start 27.9146 94.2086) (end 56.3626 95.7072) (layer "Dwgs.User") (width 0.1) (fill none) (tstamp 912ae19d-bd54-481d-b656-d43eb2f16799)) (gr_line (start 137.5918 80.9498) (end 137.5918 88.0364) (layer "Dwgs.User") (width 0.1) (tstamp 91816078-aa10-4276-90ec-5c8df35bf31a)) (gr_line (start 35.247804 48.818119) (end 35.247804 55.904719) (layer "Dwgs.User") (width 0.1) (tstamp 91d06db2-ab39-46c4-8a32-0e3061a492da)) (gr_line (start 94.277404 52.831319) (end 108.120404 52.831319) (layer "Dwgs.User") (width 0.1) (tstamp 91e0e949-65d3-40e2-858f-db5b8a62ccb9)) (gr_line (start 64.6684 64.6684) (end 64.6684 71.755) (layer "Dwgs.User") (width 0.1) (tstamp 92bfbd24-08d5-474d-b869-a86d2a2b1a61)) (gr_rect (start 116.4082 64.6176) (end 144.8562 77.8256) (layer "Dwgs.User") (width 0.1) (fill none) (tstamp 9503074f-1f62-49cb-87e0-16b08c8424af)) (gr_line (start 108.1786 33.02) (end 108.1786 40.1066) (layer "Dwgs.User") (width 0.1) (tstamp 959173ff-b1e9-43a5-8385-5d05b0ea5a9d)) (gr_line (start 94.3356 33.0454) (end 94.3356 40.132) (layer "Dwgs.User") (width 0.1) (tstamp 96e4f648-9583-4b30-8d9a-58fbcada2664)) (gr_line (start 78.5114 71.755) (end 85.8012 71.755) (layer "Dwgs.User") (width 0.1) (tstamp 9ace7858-20e9-4696-bcd7-90f52cae358a)) (gr_arc (start 140.6906 40.1574) (mid 134.493101 40.18239) (end 140.690197 40.107426) (layer "Dwgs.User") (width 0.1) (tstamp 9ad1e8de-ecfa-4632-a239-9dcf8e2823ec)) (gr_line (start 108.1786 40.132) (end 115.4684 40.132) (layer "Dwgs.User") (width 0.1) (tstamp 9b1edfc6-0c8d-4795-9021-624ed758c99e)) (gr_line (start 123.7488 64.643) (end 123.7488 71.7296) (layer "Dwgs.User") (width 0.1) (tstamp 9d63836b-8a3b-4940-95c8-bd4973e43450)) (gr_line (start 78.504004 55.879319) (end 85.793804 55.879319) (layer "Dwgs.User") (width 0.1) (tstamp 9de2bc45-d381-4830-9369-4154a38a0b65)) (gr_line (start 108.171204 55.879319) (end 115.461004 55.879319) (layer "Dwgs.User") (width 0.1) (tstamp a1512475-1c5c-4e11-a95b-bc4f5dcf519d)) (gr_arc (start 67.6656 71.8058) (mid 61.468101 71.83079) (end 67.665197 71.755826) (layer "Dwgs.User") (width 0.1) (tstamp a2855ac5-b2d7-4406-8c02-67eeef407110)) (gr_arc (start 52.197 88.1634) (mid 45.999501 88.188388) (end 52.196597 88.113426) (layer "Dwgs.User") (width 0.1) (tstamp a2ee4805-7c3c-4143-b02f-557ae35f52ea)) (gr_rect (start 116.4082 80.9498) (end 144.8562 94.1578) (layer "Dwgs.User") (width 0.1) (fill none) (tstamp a6f5048e-7e39-4379-884f-cc57bf8a6e4b)) (gr_arc (start 52.197 71.8312) (mid 45.999501 71.85619) (end 52.196597 71.781226) (layer "Dwgs.User") (width 0.1) (tstamp a7560b46-0a22-4660-9b53-1ed4c0cd8de3)) (gr_line (start 123.7488 33.02) (end 123.7488 40.1066) (layer "Dwgs.User") (width 0.1) (tstamp aa383613-44e4-478d-b11b-8dcdb83540b7)) (gr_line (start 57.3405 40.1828) (end 64.6303 40.1828) (layer "Dwgs.User") (width 0.1) (tstamp aade4cf9-a8b0-46ad-bc45-7ee0f17a8a5a)) (gr_line (start 94.2848 37.084) (end 108.1278 37.084) (layer "Dwgs.User") (width 0.1) (tstamp ac38aba8-e1af-471b-9bce-be0a32cce827)) (gr_rect (start 57.3278 33.02) (end 85.7758 46.228) (layer "Dwgs.User") (width 0.1) (fill none) (tstamp ad55a2ba-6dfc-4881-a4b4-fcaf2813797f)) (gr_arc (start 38.245004 55.955519) (mid 32.047505 55.980509) (end 38.244601 55.905545) (layer "Dwgs.User") (width 0.1) (tstamp ae935c57-2ea1-4364-91ce-bf777debda22)) (gr_line (start 49.0982 88.1126) (end 56.388 88.1126) (layer "Dwgs.User") (width 0.1) (tstamp b0244187-8f9b-4383-8c88-6e3ab3b4a20e)) (gr_rect (start 57.3278 46.228) (end 85.7758 47.7266) (layer "Dwgs.User") (width 0.1) (fill none) (tstamp b1b6f756-7d3d-4dcd-90f1-b64be5b7fd5f)) (gr_line (start 137.584404 48.741919) (end 137.584404 55.828519) (layer "Dwgs.User") (width 0.1) (tstamp b2330474-d597-4b2c-b848-75c3da74b18f)) (gr_line (start 78.504004 48.767319) (end 78.504004 55.853919) (layer "Dwgs.User") (width 0.1) (tstamp b8233bc6-861d-494a-91b6-7c723d9cc8b8)) (gr_line (start 27.9273 40.2082) (end 35.2171 40.2082) (layer "Dwgs.User") (width 0.1) (tstamp ba2c13b9-5853-4697-8108-b1a3ff42289e)) (gr_line (start 27.9273 88.1634) (end 35.2171 88.1634) (layer "Dwgs.User") (width 0.1) (tstamp bc462663-a0f2-47be-a973-86715f0694cd)) (gr_rect (start 116.4082 77.8256) (end 144.8562 79.3242) (layer "Dwgs.User") (width 0.1) (fill none) (tstamp beab6403-09a1-4534-adcc-6b2cfb2b93ee)) (gr_rect (start 116.4082 32.9946) (end 144.8562 46.2026) (layer "Dwgs.User") (width 0.1) (fill none) (tstamp bfb35659-e1a0-4e4f-a3f8-769d4eed5e5d)) (gr_arc (start 67.658204 55.930119) (mid 61.460705 55.955109) (end 67.657801 55.880145) (layer "Dwgs.User") (width 0.1) (tstamp c0472152-65f5-40b3-b3a5-4f6c92b56dc1)) (gr_line (start 108.1786 80.9752) (end 108.1786 88.0618) (layer "Dwgs.User") (width 0.1) (tstamp c0ebc7ef-438a-4ab1-b256-9b044df4aca4)) (gr_line (start 49.090804 48.792719) (end 49.090804 55.879319) (layer "Dwgs.User") (width 0.1) (tstamp c5d55955-ce9e-4f6c-9a0c-453ead07ddd7)) (gr_arc (start 111.2774 40.1828) (mid 105.079901 40.20779) (end 111.276997 40.132826) (layer "Dwgs.User") (width 0.1) (tstamp c6e5e18a-296c-491b-b3d4-f4bfca879174)) (gr_arc (start 67.6656 40.1828) (mid 61.468101 40.207788) (end 67.665197 40.132826) (layer "Dwgs.User") (width 0.1) (tstamp c76f34bc-7bc7-49e0-aafc-240a1a76f79e)) (gr_arc (start 52.197 40.2082) (mid 45.999501 40.233188) (end 52.196597 40.158226) (layer "Dwgs.User") (width 0.1) (tstamp c7af7317-6a1d-4fd4-ac6a-a952f32c52e7)) (gr_line (start 35.2044 37.1094) (end 49.0474 37.1094) (layer "Dwgs.User") (width 0.1) (tstamp c87d1894-afcf-4b7e-bb67-33da528b6380)) (gr_line (start 137.5918 40.1066) (end 144.8816 40.1066) (layer "Dwgs.User") (width 0.1) (tstamp c87f4998-e9e4-4738-8699-054d7f2b27c4)) (gr_arc (start 126.746 88.1126) (mid 120.548501 88.137588) (end 126.745597 88.062626) (layer "Dwgs.User") (width 0.1) (tstamp c8a94eff-3703-4c32-bd7c-fe5f46fecde3)) (gr_rect (start 86.995 64.643) (end 115.443 77.851) (layer "Dwgs.User") (width 0.1) (fill none) (tstamp c8bfcd93-4650-43b6-a053-de2c85fbc3bd)) (gr_arc (start 97.325404 55.930119) (mid 91.127905 55.955109) (end 97.325001 55.880145) (layer "Dwgs.User") (width 0.1) (tstamp ca4b4d3f-2b54-4b1b-aa6c-cd2a53a1d521)) (gr_line (start 35.2044 68.7324) (end 49.0474 68.7324) (layer "Dwgs.User") (width 0.1) (tstamp ca967836-f573-4adc-b6cc-33560820580a)) (gr_line (start 137.5918 71.7296) (end 144.8816 71.7296) (layer "Dwgs.User") (width 0.1) (tstamp cea7a3f5-3ead-4ca2-a03e-621a71852ac8)) (gr_rect (start 86.995 46.228) (end 115.443 47.7266) (layer "Dwgs.User") (width 0.1) (fill none) (tstamp cfe43069-4446-4012-a454-51c258a6fd4f)) (gr_line (start 123.741404 48.767319) (end 123.741404 55.853919) (layer "Dwgs.User") (width 0.1) (tstamp d1fc3c20-4e46-4787-9354-37b49dfa3a33)) (gr_line (start 64.6176 37.084) (end 78.4606 37.084) (layer "Dwgs.User") (width 0.1) (tstamp d8932f3f-b5d8-4317-8ab7-50b93f90a375)) (gr_line (start 78.5114 33.02) (end 78.5114 40.1066) (layer "Dwgs.User") (width 0.1) (tstamp d8ab3481-0d68-489a-9990-1e260dc59b8c)) (gr_line (start 64.610204 52.831319) (end 78.453204 52.831319) (layer "Dwgs.User") (width 0.1) (tstamp dc616b66-1289-418c-8f72-2befb7a30db6)) (gr_line (start 94.3356 64.6684) (end 94.3356 71.755) (layer "Dwgs.User") (width 0.1) (tstamp e4724185-1e5f-42b7-964c-3949b6f294fb)) (gr_line (start 137.5918 88.0618) (end 144.8816 88.0618) (layer "Dwgs.User") (width 0.1) (tstamp e6a0319c-bd1d-48c9-aa49-865daa556341)) (gr_line (start 64.6684 33.0454) (end 64.6684 40.132) (layer "Dwgs.User") (width 0.1) (tstamp e847d967-83f5-4b48-9d18-bb833ebdb2e9)) (gr_line (start 116.413504 55.904719) (end 123.703304 55.904719) (layer "Dwgs.User") (width 0.1) (tstamp e8f5429e-1aa2-4d15-9fbd-53796f3fc7b7)) (gr_rect (start 57.3278 80.9752) (end 85.7758 94.1832) (layer "Dwgs.User") (width 0.1) (fill none) (tstamp e9a8a217-4795-4373-8837-e5a950b9beb5)) (gr_line (start 123.7488 80.9752) (end 123.7488 88.0618) (layer "Dwgs.User") (width 0.1) (tstamp ec537a02-0e09-405b-ade1-b3c3faa938cd)) (gr_arc (start 140.683204 55.904719) (mid 134.485705 55.929709) (end 140.682801 55.854745) (layer "Dwgs.User") (width 0.1) (tstamp f0ac7a33-b675-4471-9d0a-71351bce8666)) (gr_arc (start 52.189604 55.955519) (mid 45.992105 55.980509) (end 52.189201 55.905545) (layer "Dwgs.User") (width 0.1) (tstamp f1d3e422-71a4-474a-a529-20758f5e4b49)) (gr_line (start 123.690604 52.805919) (end 137.533604 52.805919) (layer "Dwgs.User") (width 0.1) (tstamp f2f6b72f-3f03-4be1-8f6b-6f7f5ec6ab9f)) (gr_line (start 78.5114 40.132) (end 85.8012 40.132) (layer "Dwgs.User") (width 0.1) (tstamp f309c219-ff5b-4cb0-bce0-4d7d2330a6f4)) (gr_arc (start 38.2524 88.1634) (mid 32.054901 88.188388) (end 38.251997 88.113426) (layer "Dwgs.User") (width 0.1) (tstamp f3c27767-a06d-4e81-967a-16757675b5eb)) (gr_line (start 27.919904 55.955519) (end 35.209704 55.955519) (layer "Dwgs.User") (width 0.1) (tstamp f4eeb952-14de-43fb-90b7-8c5a4e8f30c8)) (gr_rect (start 86.995 33.02) (end 115.443 46.228) (layer "Dwgs.User") (width 0.1) (fill none) (tstamp f5606773-0da9-47f4-bbbf-d7d0734f2399)) (gr_line (start 87.0077 88.138) (end 94.2975 88.138) (layer "Dwgs.User") (width 0.1) (tstamp f5b459a7-a778-44d1-b12f-5622648ea104)) (gr_rect (start 27.9146 46.2534) (end 56.3626 47.752) (layer "Dwgs.User") (width 0.1) (fill none) (tstamp f71d78bb-f81b-43ab-ba15-1768f94e5872)) (gr_rect (start 27.9146 81.0006) (end 56.3626 94.2086) (layer "Dwgs.User") (width 0.1) (fill none) (tstamp f9831150-53b9-4997-9a12-85d5cbe7091b)) (gr_line (start 87.000304 55.930119) (end 94.290104 55.930119) (layer "Dwgs.User") (width 0.1) (tstamp fa2b2f05-d900-4a43-9e5b-b882ac37339a)) (gr_arc (start 81.6102 40.1828) (mid 75.412701 40.207788) (end 81.609797 40.132826) (layer "Dwgs.User") (width 0.1) (tstamp fa35b602-a6d6-449a-9241-edfe09ad90f1)) (gr_line (start 116.4209 88.1126) (end 123.7107 88.1126) (layer "Dwgs.User") (width 0.1) (tstamp faa2c560-11ee-4f38-bf9a-508a61f34978)) (gr_rect (start 27.9146 33.0454) (end 56.3626 46.2534) (layer "Dwgs.User") (width 0.1) (fill none) (tstamp fab74644-b301-4ce3-9398-a5788c2ed0a3)) (gr_arc (start 97.3328 71.8058) (mid 91.135301 71.83079) (end 97.332397 71.755826) (layer "Dwgs.User") (width 0.1) (tstamp fb5ec0f9-b553-4a74-985f-0cd6b0c0965d)) (gr_line (start 108.1786 64.643) (end 108.1786 71.7296) (layer "Dwgs.User") (width 0.1) (tstamp fe2f2d42-d943-4624-86f5-81a2ab5a88a6)) (gr_rect (start 27.9146 33.02) (end 144.8562 95.631) (layer "Edge.Cuts") (width 0.05) (fill none) (tstamp 6309e922-0352-4af3-a62f-409c8e5d5639)) (gr_rect (start 27.907204 48.792719) (end 56.355204 63.499319) (layer "Margin") (width 0.1) (fill none) (tstamp 05f844bd-4da1-4c52-80ab-268e86145883)) (gr_rect (start 116.400804 48.741919) (end 144.848804 63.448519) (layer "Margin") (width 0.1) (fill none) (tstamp 1348412e-76e1-46cf-9869-993c7df25bbc)) (gr_rect (start 86.995 64.643) (end 115.443 79.3496) (layer "Margin") (width 0.1) (fill none) (tstamp 2c136d10-377f-43c8-86aa-74af4d9a5039)) (gr_rect (start 86.987604 48.767319) (end 115.435604 63.473919) (layer "Margin") (width 0.1) (fill none) (tstamp 2e1f3bf6-f27c-4a3e-86ae-b193af5dc907)) (gr_rect (start 86.995 33.02) (end 115.443 47.7266) (layer "Margin") (width 0.1) (fill none) (tstamp 3af3220f-62f8-4232-ba53-318a7fa7aa55)) (gr_rect (start 116.4082 80.9498) (end 144.8562 95.6564) (layer "Margin") (width 0.1) (fill none) (tstamp 3bf3557b-c4a9-4c8d-888b-71ecc3a547f5)) (gr_rect (start 27.9146 64.6684) (end 56.3626 79.375) (layer "Margin") (width 0.1) (fill none) (tstamp 4368978c-5805-470a-89bc-e8df4856061a)) (gr_rect (start 27.9146 81.0006) (end 56.3626 95.7072) (layer "Margin") (width 0.1) (fill none) (tstamp 7694cba1-5c4b-4a6d-8c7b-1d3b7840ab65)) (gr_rect (start 57.3278 80.9752) (end 85.7758 95.6818) (layer "Margin") (width 0.1) (fill none) (tstamp 84a05061-1d9b-484f-ba11-31dc6b149fdb)) (gr_rect (start 57.320404 48.767319) (end 85.768404 63.473919) (layer "Margin") (width 0.1) (fill none) (tstamp 9d069dc8-5f92-479d-b0cf-1e1525cfb022)) (gr_rect (start 27.9146 33.0454) (end 56.3626 47.752) (layer "Margin") (width 0.1) (fill none) (tstamp b1ca6dda-3423-4f58-b6fe-6bee005f276c)) (gr_rect (start 86.995 80.9752) (end 115.443 95.6818) (layer "Margin") (width 0.1) (fill none) (tstamp be25e467-abdd-47ce-9759-42e35e512dce)) (gr_rect (start 57.3278 33.02) (end 85.7758 47.7266) (layer "Margin") (width 0.1) (fill none) (tstamp e73bf290-db2b-46cd-92f9-5d73b0833fe2)) (gr_rect (start 116.4082 32.9946) (end 144.8562 47.7012) (layer "Margin") (width 0.1) (fill none) (tstamp e799dc5a-a53d-4bcb-86ca-93554b913f38)) (gr_rect (start 57.3278 64.643) (end 85.7758 79.3496) (layer "Margin") (width 0.1) (fill none) (tstamp f57b52eb-784f-4bee-a490-33c1be53b034)) (gr_rect (start 116.4082 64.6176) (end 144.8562 79.3242) (layer "Margin") (width 0.1) (fill none) (tstamp fdcb8874-1493-4005-81de-3dc1c1a57a02)) (zone (net 0) (net_name "") (layer "F.Cu") (tstamp 06d2613c-3394-46f4-9c0a-81c6b089c316) (hatch edge 0.508) (connect_pads (clearance 0.508)) (min_thickness 0.254) (filled_areas_thickness no) (fill yes (thermal_gap 0.508) (thermal_bridge_width 0.508)) (polygon (pts (xy 40.607204 63.499319) (xy 28.161204 63.499319) (xy 28.186604 49.021319) (xy 40.607204 49.021319) ) ) (filled_polygon (layer "F.Cu") (island) (pts (xy 40.549325 49.371221) (xy 40.595818 49.424877) (xy 40.607204 49.477219) (xy 40.607204 62.814819) (xy 40.587202 62.88294) (xy 40.533546 62.929433) (xy 40.481204 62.940819) (xy 28.591704 62.940819) (xy 28.523583 62.920817) (xy 28.47709 62.867161) (xy 28.465704 62.814819) (xy 28.465704 55.955519) (xy 31.634352 55.955519) (xy 31.654147 56.333228) (xy 31.713315 56.706798) (xy 31.811207 57.072137) (xy 31.946751 57.425242) (xy 32.118463 57.762245) (xy 32.32446 58.079453) (xy 32.562486 58.37339) (xy 32.829933 58.640837) (xy 33.12387 58.878863) (xy 33.441078 59.08486) (xy 33.444012 59.086355) (xy 33.444019 59.086359) (xy 33.775141 59.255074) (xy 33.778081 59.256572) (xy 34.131186 59.392116) (xy 34.496525 59.490008) (xy 34.694962 59.521437) (xy 34.866847 59.548662) (xy 34.866855 59.548663) (xy 34.870095 59.549176) (xy 35.247804 59.568971) (xy 35.625513 59.549176) (xy 35.628753 59.548663) (xy 35.628761 59.548662) (xy 35.800646 59.521437) (xy 35.999083 59.490008) (xy 36.364422 59.392116) (xy 36.717527 59.256572) (xy 36.720467 59.255074) (xy 37.051589 59.086359) (xy 37.051596 59.086355) (xy 37.05453 59.08486) (xy 37.371738 58.878863) (xy 37.665675 58.640837) (xy 37.933122 58.37339) (xy 38.171148 58.079453) (xy 38.377145 57.762245) (xy 38.548857 57.425242) (xy 38.684401 57.072137) (xy 38.782293 56.706798) (xy 38.841461 56.333228) (xy 38.861256 55.955519) (xy 38.841461 55.57781) (xy 38.782293 55.20424) (xy 38.684401 54.838901) (xy 38.548857 54.485796) (xy 38.377145 54.148793) (xy 38.171148 53.831585) (xy 37.933122 53.537648) (xy 37.665675 53.270201) (xy 37.371738 53.032175) (xy 37.05453 52.826178) (xy 37.051596 52.824683) (xy 37.051589 52.824679) (xy 36.720467 52.655964) (xy 36.717527 52.654466) (xy 36.364422 52.518922) (xy 35.999083 52.42103) (xy 35.800646 52.389601) (xy 35.628761 52.362376) (xy 35.628753 52.362375) (xy 35.625513 52.361862) (xy 35.247804 52.342067) (xy 34.870095 52.361862) (xy 34.866855 52.362375) (xy 34.866847 52.362376) (xy 34.694962 52.389601) (xy 34.496525 52.42103) (xy 34.131186 52.518922) (xy 33.778081 52.654466) (xy 33.775141 52.655964) (xy 33.444019 52.824679) (xy 33.444012 52.824683) (xy 33.441078 52.826178) (xy 33.12387 53.032175) (xy 32.829933 53.270201) (xy 32.562486 53.537648) (xy 32.32446 53.831585) (xy 32.118463 54.148793) (xy 31.946751 54.485796) (xy 31.811207 54.838901) (xy 31.713315 55.20424) (xy 31.654147 55.57781) (xy 31.634352 55.955519) (xy 28.465704 55.955519) (xy 28.465704 49.477219) (xy 28.485706 49.409098) (xy 28.539362 49.362605) (xy 28.591704 49.351219) (xy 40.481204 49.351219) ) ) ) (zone (net 0) (net_name "") (layer "F.Cu") (tstamp 0a1fcb87-7a8f-4f52-96eb-5584c82734c3) (hatch edge 0.508) (connect_pads (clearance 0.508)) (min_thickness 0.254) (filled_areas_thickness no) (fill yes (thermal_gap 0.508) (thermal_bridge_width 0.508)) (polygon (pts (xy 144.653 47.7012) (xy 116.6622 47.7012) (xy 116.6876 33.2232) (xy 144.653 33.2232) ) ) (filled_polygon (layer "F.Cu") (island) (pts (xy 144.239821 33.573102) (xy 144.286314 33.626758) (xy 144.2977 33.6791) (xy 144.2977 47.0167) (xy 144.277698 47.084821) (xy 144.224042 47.131314) (xy 144.1717 47.1427) (xy 117.0927 47.1427) (xy 117.024579 47.122698) (xy 116.978086 47.069042) (xy 116.9667 47.0167) (xy 116.9667 40.1574) (xy 120.135348 40.1574) (xy 120.155143 40.535109) (xy 120.214311 40.908679) (xy 120.312203 41.274018) (xy 120.447747 41.627123) (xy 120.449245 41.630063) (xy 120.592077 41.910385) (xy 120.619459 41.964126) (xy 120.825456 42.281334) (xy 121.063482 42.575271) (xy 121.330929 42.842718) (xy 121.624866 43.080744) (xy 121.942074 43.286741) (xy 121.945008 43.288236) (xy 121.945015 43.28824) (xy 122.1817 43.408837) (xy 122.279077 43.458453) (xy 122.632182 43.593997) (xy 122.997521 43.691889) (xy 123.195958 43.723318) (xy 123.367843 43.750543) (xy 123.367851 43.750544) (xy 123.371091 43.751057) (xy 123.7488 43.770852) (xy 124.126509 43.751057) (xy 124.129749 43.750544) (xy 124.129757 43.750543) (xy 124.301642 43.723318) (xy 124.500079 43.691889) (xy 124.865418 43.593997) (xy 125.218523 43.458453) (xy 125.3159 43.408837) (xy 125.552585 43.28824) (xy 125.552592 43.288236) (xy 125.555526 43.286741) (xy 125.872734 43.080744) (xy 126.166671 42.842718) (xy 126.434118 42.575271) (xy 126.672144 42.281334) (xy 126.878141 41.964126) (xy 126.905524 41.910385) (xy 127.048355 41.630063) (xy 127.049853 41.627123) (xy 127.185397 41.274018) (xy 127.283289 40.908679) (xy 127.342457 40.535109) (xy 127.362252 40.1574) (xy 127.35959 40.1066) (xy 133.978348 40.1066) (xy 133.998143 40.484309) (xy 134.057311 40.857879) (xy 134.155203 41.223218) (xy 134.290747 41.576323) (xy 134.462459 41.913326) (xy 134.668456 42.230534) (xy 134.906482 42.524471) (xy 135.173929 42.791918) (xy 135.467866 43.029944) (xy 135.785074 43.235941) (xy 135.788008 43.237436) (xy 135.788015 43.23744) (xy 135.884774 43.286741) (xy 136.122077 43.407653) (xy 136.475182 43.543197) (xy 136.840521 43.641089) (xy 137.038958 43.672518) (xy 137.210843 43.699743) (xy 137.210851 43.699744) (xy 137.214091 43.700257) (xy 137.5918 43.720052) (xy 137.969509 43.700257) (xy 137.972749 43.699744) (xy 137.972757 43.699743) (xy 138.144642 43.672518) (xy 138.343079 43.641089) (xy 138.708418 43.543197) (xy 139.061523 43.407653) (xy 139.298826 43.286741) (xy 139.395585 43.23744) (xy 139.395592 43.237436) (xy 139.398526 43.235941) (xy 139.715734 43.029944) (xy 140.009671 42.791918) (xy 140.277118 42.524471) (xy 140.515144 42.230534) (xy 140.721141 41.913326) (xy 140.892853 41.576323) (xy 141.028397 41.223218) (xy 141.126289 40.857879) (xy 141.185457 40.484309) (xy 141.205252 40.1066) (xy 141.185457 39.728891) (xy 141.126289 39.355321) (xy 141.028397 38.989982) (xy 140.892853 38.636877) (xy 140.891355 38.633937) (xy 140.72264 38.302815) (xy 140.722636 38.302808) (xy 140.721141 38.299874) (xy 140.515144 37.982666) (xy 140.277118 37.688729) (xy 140.009671 37.421282) (xy 139.715734 37.183256) (xy 139.398526 36.977259) (xy 139.395592 36.975764) (xy 139.395585 36.97576) (xy 139.064463 36.807045) (xy 139.061523 36.805547) (xy 138.708418 36.670003) (xy 138.343079 36.572111) (xy 138.144642 36.540682) (xy 137.972757 36.513457) (xy 137.972749 36.513456) (xy 137.969509 36.512943) (xy 137.5918 36.493148) (xy 137.214091 36.512943) (xy 137.210851 36.513456) (xy 137.210843 36.513457) (xy 137.038958 36.540682) (xy 136.840521 36.572111) (xy 136.475182 36.670003) (xy 136.122077 36.805547) (xy 136.119137 36.807045) (xy 135.788015 36.97576) (xy 135.788008 36.975764) (xy 135.785074 36.977259) (xy 135.467866 37.183256) (xy 135.173929 37.421282) (xy 134.906482 37.688729) (xy 134.668456 37.982666) (xy 134.462459 38.299874) (xy 134.460964 38.302808) (xy 134.46096 38.302815) (xy 134.292245 38.633937) (xy 134.290747 38.636877) (xy 134.155203 38.989982) (xy 134.057311 39.355321) (xy 133.998143 39.728891) (xy 133.978348 40.1066) (xy 127.35959 40.1066) (xy 127.342457 39.779691) (xy 127.283289 39.406121) (xy 127.185397 39.040782) (xy 127.049853 38.687677) (xy 126.878141 38.350674) (xy 126.672144 38.033466) (xy 126.434118 37.739529) (xy 126.166671 37.472082) (xy 125.872734 37.234056) (xy 125.555526 37.028059) (xy 125.552592 37.026564) (xy 125.552585 37.02656) (xy 125.221463 36.857845) (xy 125.218523 36.856347) (xy 124.865418 36.720803) (xy 124.500079 36.622911) (xy 124.301642 36.591482) (xy 124.129757 36.564257) (xy 124.129749 36.564256) (xy 124.126509 36.563743) (xy 123.7488 36.543948) (xy 123.371091 36.563743) (xy 123.367851 36.564256) (xy 123.367843 36.564257) (xy 123.195958 36.591482) (xy 122.997521 36.622911) (xy 122.632182 36.720803) (xy 122.279077 36.856347) (xy 122.276137 36.857845) (xy 121.945015 37.02656) (xy 121.945008 37.026564) (xy 121.942074 37.028059) (xy 121.624866 37.234056) (xy 121.330929 37.472082) (xy 121.063482 37.739529) (xy 120.825456 38.033466) (xy 120.619459 38.350674) (xy 120.447747 38.687677) (xy 120.312203 39.040782) (xy 120.214311 39.406121) (xy 120.155143 39.779691) (xy 120.135348 40.1574) (xy 116.9667 40.1574) (xy 116.9667 33.6791) (xy 116.986702 33.610979) (xy 117.040358 33.564486) (xy 117.0927 33.5531) (xy 144.1717 33.5531) ) ) ) (zone (net 0) (net_name "") (layer "F.Cu") (tstamp 0a5f5a32-8977-45ac-a2ed-057ecea97eb9) (hatch edge 0.508) (connect_pads (clearance 0.508)) (min_thickness 0.254) (filled_areas_thickness no) (fill yes (thermal_gap 0.508) (thermal_bridge_width 0.508)) (polygon (pts (xy 99.687604 63.473919) (xy 87.241604 63.473919) (xy 87.267004 48.995919) (xy 99.687604 48.995919) ) ) (filled_polygon (layer "F.Cu") (island) (pts (xy 99.629725 49.345821) (xy 99.676218 49.399477) (xy 99.687604 49.451819) (xy 99.687604 62.789419) (xy 99.667602 62.85754) (xy 99.613946 62.904033) (xy 99.561604 62.915419) (xy 87.672104 62.915419) (xy 87.603983 62.895417) (xy 87.55749 62.841761) (xy 87.546104 62.789419) (xy 87.546104 55.930119) (xy 90.714752 55.930119) (xy 90.734547 56.307828) (xy 90.793715 56.681398) (xy 90.891607 57.046737) (xy 91.027151 57.399842) (xy 91.198863 57.736845) (xy 91.40486 58.054053) (xy 91.642886 58.34799) (xy 91.910333 58.615437) (xy 92.20427 58.853463) (xy 92.521478 59.05946) (xy 92.524412 59.060955) (xy 92.524419 59.060959) (xy 92.855541 59.229674) (xy 92.858481 59.231172) (xy 93.211586 59.366716) (xy 93.576925 59.464608) (xy 93.775362 59.496037) (xy 93.947247 59.523262) (xy 93.947255 59.523263) (xy 93.950495 59.523776) (xy 94.328204 59.543571) (xy 94.705913 59.523776) (xy 94.709153 59.523263) (xy 94.709161 59.523262) (xy 94.881046 59.496037) (xy 95.079483 59.464608) (xy 95.444822 59.366716) (xy 95.797927 59.231172) (xy 95.800867 59.229674) (xy 96.131989 59.060959) (xy 96.131996 59.060955) (xy 96.13493 59.05946) (xy 96.452138 58.853463) (xy 96.746075 58.615437) (xy 97.013522 58.34799) (xy 97.251548 58.054053) (xy 97.457545 57.736845) (xy 97.629257 57.399842) (xy 97.764801 57.046737) (xy 97.862693 56.681398) (xy 97.921861 56.307828) (xy 97.941656 55.930119) (xy 97.921861 55.55241) (xy 97.862693 55.17884) (xy 97.764801 54.813501) (xy 97.629257 54.460396) (xy 97.457545 54.123393) (xy 97.251548 53.806185) (xy 97.013522 53.512248) (xy 96.746075 53.244801) (xy 96.452138 53.006775) (xy 96.13493 52.800778) (xy 96.131996 52.799283) (xy 96.131989 52.799279) (xy 95.800867 52.630564) (xy 95.797927 52.629066) (xy 95.444822 52.493522) (xy 95.079483 52.39563) (xy 94.881046 52.364201) (xy 94.709161 52.336976) (xy 94.709153 52.336975) (xy 94.705913 52.336462) (xy 94.328204 52.316667) (xy 93.950495 52.336462) (xy 93.947255 52.336975) (xy 93.947247 52.336976) (xy 93.775362 52.364201) (xy 93.576925 52.39563) (xy 93.211586 52.493522) (xy 92.858481 52.629066) (xy 92.855541 52.630564) (xy 92.524419 52.799279) (xy 92.524412 52.799283) (xy 92.521478 52.800778) (xy 92.20427 53.006775) (xy 91.910333 53.244801) (xy 91.642886 53.512248) (xy 91.40486 53.806185) (xy 91.198863 54.123393) (xy 91.027151 54.460396) (xy 90.891607 54.813501) (xy 90.793715 55.17884) (xy 90.734547 55.55241) (xy 90.714752 55.930119) (xy 87.546104 55.930119) (xy 87.546104 49.451819) (xy 87.566106 49.383698) (xy 87.619762 49.337205) (xy 87.672104 49.325819) (xy 99.561604 49.325819) ) ) ) (zone (net 0) (net_name "") (layer "F.Cu") (tstamp 1eb2bead-ef81-490e-97a7-c5b460fe699d) (hatch edge 0.508) (connect_pads (clearance 0.508)) (min_thickness 0.254) (filled_areas_thickness no) (fill yes (thermal_gap 0.508) (thermal_bridge_width 0.508)) (polygon (pts (xy 115.189 47.718184) (xy 102.743 47.718184) (xy 102.7684 33.265584) (xy 115.189 33.265584) ) ) (filled_polygon (layer "F.Cu") (island) (pts (xy 114.826621 33.598502) (xy 114.873114 33.652158) (xy 114.8845 33.7045) (xy 114.8845 47.0421) (xy 114.864498 47.110221) (xy 114.810842 47.156714) (xy 114.7585 47.1681) (xy 102.870189 47.1681) (xy 102.802068 47.148098) (xy 102.755575 47.094442) (xy 102.744189 47.041879) (xy 102.756333 40.132) (xy 104.565148 40.132) (xy 104.584943 40.509709) (xy 104.644111 40.883279) (xy 104.742003 41.248618) (xy 104.877547 41.601723) (xy 105.049259 41.938726) (xy 105.255256 42.255934) (xy 105.493282 42.549871) (xy 105.760729 42.817318) (xy 106.054666 43.055344) (xy 106.371874 43.261341) (xy 106.374808 43.262836) (xy 106.374815 43.26284) (xy 106.705937 43.431555) (xy 106.708877 43.433053) (xy 107.061982 43.568597) (xy 107.427321 43.666489) (xy 107.625758 43.697918) (xy 107.797643 43.725143) (xy 107.797651 43.725144) (xy 107.800891 43.725657) (xy 108.1786 43.745452) (xy 108.556309 43.725657) (xy 108.559549 43.725144) (xy 108.559557 43.725143) (xy 108.731442 43.697918) (xy 108.929879 43.666489) (xy 109.295218 43.568597) (xy 109.648323 43.433053) (xy 109.651263 43.431555) (xy 109.982385 43.26284) (xy 109.982392 43.262836) (xy 109.985326 43.261341) (xy 110.302534 43.055344) (xy 110.596471 42.817318) (xy 110.863918 42.549871) (xy 111.101944 42.255934) (xy 111.307941 41.938726) (xy 111.479653 41.601723) (xy 111.615197 41.248618) (xy 111.713089 40.883279) (xy 111.772257 40.509709) (xy 111.792052 40.132) (xy 111.772257 39.754291) (xy 111.713089 39.380721) (xy 111.615197 39.015382) (xy 111.479653 38.662277) (xy 111.307941 38.325274) (xy 111.101944 38.008066) (xy 110.863918 37.714129) (xy 110.596471 37.446682) (xy 110.302534 37.208656) (xy 109.985326 37.002659) (xy 109.982392 37.001164) (xy 109.982385 37.00116) (xy 109.651263 36.832445) (xy 109.648323 36.830947) (xy 109.295218 36.695403) (xy 108.929879 36.597511) (xy 108.731442 36.566082) (xy 108.559557 36.538857) (xy 108.559549 36.538856) (xy 108.556309 36.538343) (xy 108.1786 36.518548) (xy 107.800891 36.538343) (xy 107.797651 36.538856) (xy 107.797643 36.538857) (xy 107.625758 36.566082) (xy 107.427321 36.597511) (xy 107.061982 36.695403) (xy 106.708877 36.830947) (xy 106.705937 36.832445) (xy 106.374815 37.00116) (xy 106.374808 37.001164) (xy 106.371874 37.002659) (xy 106.054666 37.208656) (xy 105.760729 37.446682) (xy 105.493282 37.714129) (xy 105.255256 38.008066) (xy 105.049259 38.325274) (xy 104.877547 38.662277) (xy 104.742003 39.015382) (xy 104.644111 39.380721) (xy 104.584943 39.754291) (xy 104.565148 40.132) (xy 102.756333 40.132) (xy 102.767629 33.704279) (xy 102.787751 33.636193) (xy 102.841488 33.589795) (xy 102.893629 33.5785) (xy 114.7585 33.5785) ) ) ) (zone (net 0) (net_name "") (layer "F.Cu") (tstamp 3190f87a-a058-48b8-81ac-c9012688c156) (hatch edge 0.508) (connect_pads (clearance 0.508)) (min_thickness 0.254) (filled_areas_thickness no) (fill yes (thermal_gap 0.508) (thermal_bridge_width 0.508)) (polygon (pts (xy 144.653 95.6564) (xy 116.6622 95.6564) (xy 116.6876 81.1784) (xy 144.653 81.1784) ) ) (filled_polygon (layer "F.Cu") (island) (pts (xy 144.239821 81.528302) (xy 144.286314 81.581958) (xy 144.2977 81.6343) (xy 144.2977 94.9719) (xy 144.277698 95.040021) (xy 144.224042 95.086514) (xy 144.1717 95.0979) (xy 117.0927 95.0979) (xy 117.024579 95.077898) (xy 116.978086 95.024242) (xy 116.9667 94.9719) (xy 116.9667 88.1126) (xy 120.135348 88.1126) (xy 120.155143 88.490309) (xy 120.214311 88.863879) (xy 120.312203 89.229218) (xy 120.447747 89.582323) (xy 120.449245 89.585263) (xy 120.592077 89.865585) (xy 120.619459 89.919326) (xy 120.825456 90.236534) (xy 121.063482 90.530471) (xy 121.330929 90.797918) (xy 121.624866 91.035944) (xy 121.942074 91.241941) (xy 121.945008 91.243436) (xy 121.945015 91.24344) (xy 122.1817 91.364037) (xy 122.279077 91.413653) (xy 122.632182 91.549197) (xy 122.997521 91.647089) (xy 123.195958 91.678518) (xy 123.367843 91.705743) (xy 123.367851 91.705744) (xy 123.371091 91.706257) (xy 123.7488 91.726052) (xy 124.126509 91.706257) (xy 124.129749 91.705744) (xy 124.129757 91.705743) (xy 124.301642 91.678518) (xy 124.500079 91.647089) (xy 124.865418 91.549197) (xy 125.218523 91.413653) (xy 125.3159 91.364037) (xy 125.552585 91.24344) (xy 125.552592 91.243436) (xy 125.555526 91.241941) (xy 125.872734 91.035944) (xy 126.166671 90.797918) (xy 126.434118 90.530471) (xy 126.672144 90.236534) (xy 126.878141 89.919326) (xy 126.905524 89.865585) (xy 127.048355 89.585263) (xy 127.049853 89.582323) (xy 127.185397 89.229218) (xy 127.283289 88.863879) (xy 127.342457 88.490309) (xy 127.362252 88.1126) (xy 127.35959 88.0618) (xy 133.978348 88.0618) (xy 133.998143 88.439509) (xy 134.057311 88.813079) (xy 134.155203 89.178418) (xy 134.290747 89.531523) (xy 134.462459 89.868526) (xy 134.668456 90.185734) (xy 134.906482 90.479671) (xy 135.173929 90.747118) (xy 135.467866 90.985144) (xy 135.785074 91.191141) (xy 135.788008 91.192636) (xy 135.788015 91.19264) (xy 135.884774 91.241941) (xy 136.122077 91.362853) (xy 136.475182 91.498397) (xy 136.840521 91.596289) (xy 137.038958 91.627718) (xy 137.210843 91.654943) (xy 137.210851 91.654944) (xy 137.214091 91.655457) (xy 137.5918 91.675252) (xy 137.969509 91.655457) (xy 137.972749 91.654944) (xy 137.972757 91.654943) (xy 138.144642 91.627718) (xy 138.343079 91.596289) (xy 138.708418 91.498397) (xy 139.061523 91.362853) (xy 139.298826 91.241941) (xy 139.395585 91.19264) (xy 139.395592 91.192636) (xy 139.398526 91.191141) (xy 139.715734 90.985144) (xy 140.009671 90.747118) (xy 140.277118 90.479671) (xy 140.515144 90.185734) (xy 140.721141 89.868526) (xy 140.892853 89.531523) (xy 141.028397 89.178418) (xy 141.126289 88.813079) (xy 141.185457 88.439509) (xy 141.205252 88.0618) (xy 141.185457 87.684091) (xy 141.126289 87.310521) (xy 141.028397 86.945182) (xy 140.892853 86.592077) (xy 140.891355 86.589137) (xy 140.72264 86.258015) (xy 140.722636 86.258008) (xy 140.721141 86.255074) (xy 140.515144 85.937866) (xy 140.277118 85.643929) (xy 140.009671 85.376482) (xy 139.715734 85.138456) (xy 139.398526 84.932459) (xy 139.395592 84.930964) (xy 139.395585 84.93096) (xy 139.064463 84.762245) (xy 139.061523 84.760747) (xy 138.708418 84.625203) (xy 138.343079 84.527311) (xy 138.144642 84.495882) (xy 137.972757 84.468657) (xy 137.972749 84.468656) (xy 137.969509 84.468143) (xy 137.5918 84.448348) (xy 137.214091 84.468143) (xy 137.210851 84.468656) (xy 137.210843 84.468657) (xy 137.038958 84.495882) (xy 136.840521 84.527311) (xy 136.475182 84.625203) (xy 136.122077 84.760747) (xy 136.119137 84.762245) (xy 135.788015 84.93096) (xy 135.788008 84.930964) (xy 135.785074 84.932459) (xy 135.467866 85.138456) (xy 135.173929 85.376482) (xy 134.906482 85.643929) (xy 134.668456 85.937866) (xy 134.462459 86.255074) (xy 134.460964 86.258008) (xy 134.46096 86.258015) (xy 134.292245 86.589137) (xy 134.290747 86.592077) (xy 134.155203 86.945182) (xy 134.057311 87.310521) (xy 133.998143 87.684091) (xy 133.978348 88.0618) (xy 127.35959 88.0618) (xy 127.342457 87.734891) (xy 127.283289 87.361321) (xy 127.185397 86.995982) (xy 127.049853 86.642877) (xy 126.878141 86.305874) (xy 126.672144 85.988666) (xy 126.434118 85.694729) (xy 126.166671 85.427282) (xy 125.872734 85.189256) (xy 125.555526 84.983259) (xy 125.552592 84.981764) (xy 125.552585 84.98176) (xy 125.221463 84.813045) (xy 125.218523 84.811547) (xy 124.865418 84.676003) (xy 124.500079 84.578111) (xy 124.301642 84.546682) (xy 124.129757 84.519457) (xy 124.129749 84.519456) (xy 124.126509 84.518943) (xy 123.7488 84.499148) (xy 123.371091 84.518943) (xy 123.367851 84.519456) (xy 123.367843 84.519457) (xy 123.195958 84.546682) (xy 122.997521 84.578111) (xy 122.632182 84.676003) (xy 122.279077 84.811547) (xy 122.276137 84.813045) (xy 121.945015 84.98176) (xy 121.945008 84.981764) (xy 121.942074 84.983259) (xy 121.624866 85.189256) (xy 121.330929 85.427282) (xy 121.063482 85.694729) (xy 120.825456 85.988666) (xy 120.619459 86.305874) (xy 120.447747 86.642877) (xy 120.312203 86.995982) (xy 120.214311 87.361321) (xy 120.155143 87.734891) (xy 120.135348 88.1126) (xy 116.9667 88.1126) (xy 116.9667 81.6343) (xy 116.986702 81.566179) (xy 117.040358 81.519686) (xy 117.0927 81.5083) (xy 144.1717 81.5083) ) ) ) (zone (net 0) (net_name "") (layer "F.Cu") (tstamp 375d72c0-cc28-41d2-b608-a6ba84fef037) (hatch edge 0.508) (connect_pads (clearance 0.508)) (min_thickness 0.254) (filled_areas_thickness no) (fill yes (thermal_gap 0.508) (thermal_bridge_width 0.508)) (polygon (pts (xy 144.645604 63.448519) (xy 116.654804 63.448519) (xy 116.680204 48.970519) (xy 144.645604 48.970519) ) ) (filled_polygon (layer "F.Cu") (island) (pts (xy 144.232425 49.320421) (xy 144.278918 49.374077) (xy 144.290304 49.426419) (xy 144.290304 62.764019) (xy 144.270302 62.83214) (xy 144.216646 62.878633) (xy 144.164304 62.890019) (xy 117.085304 62.890019) (xy 117.017183 62.870017) (xy 116.97069 62.816361) (xy 116.959304 62.764019) (xy 116.959304 55.904719) (xy 120.127952 55.904719) (xy 120.147747 56.282428) (xy 120.206915 56.655998) (xy 120.304807 57.021337) (xy 120.440351 57.374442) (xy 120.441849 57.377382) (xy 120.584681 57.657704) (xy 120.612063 57.711445) (xy 120.81806 58.028653) (xy 121.056086 58.32259) (xy 121.323533 58.590037) (xy 121.61747 58.828063) (xy 121.934678 59.03406) (xy 121.937612 59.035555) (xy 121.937619 59.035559) (xy 122.174304 59.156156) (xy 122.271681 59.205772) (xy 122.624786 59.341316) (xy 122.990125 59.439208) (xy 123.188562 59.470637) (xy 123.360447 59.497862) (xy 123.360455 59.497863) (xy 123.363695 59.498376) (xy 123.741404 59.518171) (xy 124.119113 59.498376) (xy 124.122353 59.497863) (xy 124.122361 59.497862) (xy 124.294246 59.470637) (xy 124.492683 59.439208) (xy 124.858022 59.341316) (xy 125.211127 59.205772) (xy 125.308504 59.156156) (xy 125.545189 59.035559) (xy 125.545196 59.035555) (xy 125.54813 59.03406) (xy 125.865338 58.828063) (xy 126.159275 58.590037) (xy 126.426722 58.32259) (xy 126.664748 58.028653) (xy 126.870745 57.711445) (xy 126.898128 57.657704) (xy 127.040959 57.377382) (xy 127.042457 57.374442) (xy 127.178001 57.021337) (xy 127.275893 56.655998) (xy 127.335061 56.282428) (xy 127.354856 55.904719) (xy 127.352194 55.853919) (xy 133.970952 55.853919) (xy 133.990747 56.231628) (xy 134.049915 56.605198) (xy 134.147807 56.970537) (xy 134.283351 57.323642) (xy 134.455063 57.660645) (xy 134.66106 57.977853) (xy 134.899086 58.27179) (xy 135.166533 58.539237) (xy 135.46047 58.777263) (xy 135.777678 58.98326) (xy 135.780612 58.984755) (xy 135.780619 58.984759) (xy 135.877378 59.03406) (xy 136.114681 59.154972) (xy 136.467786 59.290516) (xy 136.833125 59.388408) (xy 137.031562 59.419837) (xy 137.203447 59.447062) (xy 137.203455 59.447063) (xy 137.206695 59.447576) (xy 137.584404 59.467371) (xy 137.962113 59.447576) (xy 137.965353 59.447063) (xy 137.965361 59.447062) (xy 138.137246 59.419837) (xy 138.335683 59.388408) (xy 138.701022 59.290516) (xy 139.054127 59.154972) (xy 139.29143 59.03406) (xy 139.388189 58.984759) (xy 139.388196 58.984755) (xy 139.39113 58.98326) (xy 139.708338 58.777263) (xy 140.002275 58.539237) (xy 140.269722 58.27179) (xy 140.507748 57.977853) (xy 140.713745 57.660645) (xy 140.885457 57.323642) (xy 141.021001 56.970537) (xy 141.118893 56.605198) (xy 141.178061 56.231628) (xy 141.197856 55.853919) (xy 141.178061 55.47621) (xy 141.118893 55.10264) (xy 141.021001 54.737301) (xy 140.885457 54.384196) (xy 140.883959 54.381256) (xy 140.715244 54.050134) (xy 140.71524 54.050127) (xy 140.713745 54.047193) (xy 140.507748 53.729985) (xy 140.269722 53.436048) (xy 140.002275 53.168601) (xy 139.708338 52.930575) (xy 139.39113 52.724578) (xy 139.388196 52.723083) (xy 139.388189 52.723079) (xy 139.057067 52.554364) (xy 139.054127 52.552866) (xy 138.701022 52.417322) (xy 138.335683 52.31943) (xy 138.137246 52.288001) (xy 137.965361 52.260776) (xy 137.965353 52.260775) (xy 137.962113 52.260262) (xy 137.584404 52.240467) (xy 137.206695 52.260262) (xy 137.203455 52.260775) (xy 137.203447 52.260776) (xy 137.031562 52.288001) (xy 136.833125 52.31943) (xy 136.467786 52.417322) (xy 136.114681 52.552866) (xy 136.111741 52.554364) (xy 135.780619 52.723079) (xy 135.780612 52.723083) (xy 135.777678 52.724578) (xy 135.46047 52.930575) (xy 135.166533 53.168601) (xy 134.899086 53.436048) (xy 134.66106 53.729985) (xy 134.455063 54.047193) (xy 134.453568 54.050127) (xy 134.453564 54.050134) (xy 134.284849 54.381256) (xy 134.283351 54.384196) (xy 134.147807 54.737301) (xy 134.049915 55.10264) (xy 133.990747 55.47621) (xy 133.970952 55.853919) (xy 127.352194 55.853919) (xy 127.335061 55.52701) (xy 127.275893 55.15344) (xy 127.178001 54.788101) (xy 127.042457 54.434996) (xy 126.870745 54.097993) (xy 126.664748 53.780785) (xy 126.426722 53.486848) (xy 126.159275 53.219401) (xy 125.865338 52.981375) (xy 125.54813 52.775378) (xy 125.545196 52.773883) (xy 125.545189 52.773879) (xy 125.214067 52.605164) (xy 125.211127 52.603666) (xy 124.858022 52.468122) (xy 124.492683 52.37023) (xy 124.294246 52.338801) (xy 124.122361 52.311576) (xy 124.122353 52.311575) (xy 124.119113 52.311062) (xy 123.741404 52.291267) (xy 123.363695 52.311062) (xy 123.360455 52.311575) (xy 123.360447 52.311576) (xy 123.188562 52.338801) (xy 122.990125 52.37023) (xy 122.624786 52.468122) (xy 122.271681 52.603666) (xy 122.268741 52.605164) (xy 121.937619 52.773879) (xy 121.937612 52.773883) (xy 121.934678 52.775378) (xy 121.61747 52.981375) (xy 121.323533 53.219401) (xy 121.056086 53.486848) (xy 120.81806 53.780785) (xy 120.612063 54.097993) (xy 120.440351 54.434996) (xy 120.304807 54.788101) (xy 120.206915 55.15344) (xy 120.147747 55.52701) (xy 120.127952 55.904719) (xy 116.959304 55.904719) (xy 116.959304 49.426419) (xy 116.979306 49.358298) (xy 117.032962 49.311805) (xy 117.085304 49.300419) (xy 144.164304 49.300419) ) ) ) (zone (net 0) (net_name "") (layer "F.Cu") (tstamp 4838533a-5d42-4877-bad0-5d194d5a5373) (hatch edge 0.508) (connect_pads (clearance 0.508)) (min_thickness 0.254) (filled_areas_thickness no) (fill yes (thermal_gap 0.508) (thermal_bridge_width 0.508)) (polygon (pts (xy 40.6146 79.375) (xy 28.1686 79.375) (xy 28.194 64.897) (xy 40.6146 64.897) ) ) (filled_polygon (layer "F.Cu") (island) (pts (xy 40.556721 65.246902) (xy 40.603214 65.300558) (xy 40.6146 65.3529) (xy 40.6146 78.6905) (xy 40.594598 78.758621) (xy 40.540942 78.805114) (xy 40.4886 78.8165) (xy 28.5991 78.8165) (xy 28.530979 78.796498) (xy 28.484486 78.742842) (xy 28.4731 78.6905) (xy 28.4731 71.8312) (xy 31.641748 71.8312) (xy 31.661543 72.208909) (xy 31.720711 72.582479) (xy 31.818603 72.947818) (xy 31.954147 73.300923) (xy 32.125859 73.637926) (xy 32.331856 73.955134) (xy 32.569882 74.249071) (xy 32.837329 74.516518) (xy 33.131266 74.754544) (xy 33.448474 74.960541) (xy 33.451408 74.962036) (xy 33.451415 74.96204) (xy 33.782537 75.130755) (xy 33.785477 75.132253) (xy 34.138582 75.267797) (xy 34.503921 75.365689) (xy 34.702358 75.397118) (xy 34.874243 75.424343) (xy 34.874251 75.424344) (xy 34.877491 75.424857) (xy 35.2552 75.444652) (xy 35.632909 75.424857) (xy 35.636149 75.424344) (xy 35.636157 75.424343) (xy 35.808042 75.397118) (xy 36.006479 75.365689) (xy 36.371818 75.267797) (xy 36.724923 75.132253) (xy 36.727863 75.130755) (xy 37.058985 74.96204) (xy 37.058992 74.962036) (xy 37.061926 74.960541) (xy 37.379134 74.754544) (xy 37.673071 74.516518) (xy 37.940518 74.249071) (xy 38.178544 73.955134) (xy 38.384541 73.637926) (xy 38.556253 73.300923) (xy 38.691797 72.947818) (xy 38.789689 72.582479) (xy 38.848857 72.208909) (xy 38.868652 71.8312) (xy 38.848857 71.453491) (xy 38.789689 71.079921) (xy 38.691797 70.714582) (xy 38.556253 70.361477) (xy 38.384541 70.024474) (xy 38.178544 69.707266) (xy 37.940518 69.413329) (xy 37.673071 69.145882) (xy 37.379134 68.907856) (xy 37.061926 68.701859) (xy 37.058992 68.700364) (xy 37.058985 68.70036) (xy 36.727863 68.531645) (xy 36.724923 68.530147) (xy 36.371818 68.394603) (xy 36.006479 68.296711) (xy 35.808042 68.265282) (xy 35.636157 68.238057) (xy 35.636149 68.238056) (xy 35.632909 68.237543) (xy 35.2552 68.217748) (xy 34.877491 68.237543) (xy 34.874251 68.238056) (xy 34.874243 68.238057) (xy 34.702358 68.265282) (xy 34.503921 68.296711) (xy 34.138582 68.394603) (xy 33.785477 68.530147) (xy 33.782537 68.531645) (xy 33.451415 68.70036) (xy 33.451408 68.700364) (xy 33.448474 68.701859) (xy 33.131266 68.907856) (xy 32.837329 69.145882) (xy 32.569882 69.413329) (xy 32.331856 69.707266) (xy 32.125859 70.024474) (xy 31.954147 70.361477) (xy 31.818603 70.714582) (xy 31.720711 71.079921) (xy 31.661543 71.453491) (xy 31.641748 71.8312) (xy 28.4731 71.8312) (xy 28.4731 65.3529) (xy 28.493102 65.284779) (xy 28.546758 65.238286) (xy 28.5991 65.2269) (xy 40.4886 65.2269) ) ) ) (zone (net 0) (net_name "") (layer "F.Cu") (tstamp 4b99e3f8-88f2-40f1-84a5-4ce1c08f9a03) (hatch edge 0.508) (connect_pads (clearance 0.508)) (min_thickness 0.254) (filled_areas_thickness no) (fill yes (thermal_gap 0.508) (thermal_bridge_width 0.508)) (polygon (pts (xy 115.189 95.673384) (xy 102.743 95.673384) (xy 102.7684 81.220784) (xy 115.189 81.220784) ) ) (filled_polygon (layer "F.Cu") (island) (pts (xy 114.826621 81.553702) (xy 114.873114 81.607358) (xy 114.8845 81.6597) (xy 114.8845 94.9973) (xy 114.864498 95.065421) (xy 114.810842 95.111914) (xy 114.7585 95.1233) (xy 102.870189 95.1233) (xy 102.802068 95.103298) (xy 102.755575 95.049642) (xy 102.744189 94.997079) (xy 102.756333 88.0872) (xy 104.565148 88.0872) (xy 104.584943 88.464909) (xy 104.644111 88.838479) (xy 104.742003 89.203818) (xy 104.877547 89.556923) (xy 105.049259 89.893926) (xy 105.255256 90.211134) (xy 105.493282 90.505071) (xy 105.760729 90.772518) (xy 106.054666 91.010544) (xy 106.371874 91.216541) (xy 106.374808 91.218036) (xy 106.374815 91.21804) (xy 106.705937 91.386755) (xy 106.708877 91.388253) (xy 107.061982 91.523797) (xy 107.427321 91.621689) (xy 107.625758 91.653118) (xy 107.797643 91.680343) (xy 107.797651 91.680344) (xy 107.800891 91.680857) (xy 108.1786 91.700652) (xy 108.556309 91.680857) (xy 108.559549 91.680344) (xy 108.559557 91.680343) (xy 108.731442 91.653118) (xy 108.929879 91.621689) (xy 109.295218 91.523797) (xy 109.648323 91.388253) (xy 109.651263 91.386755) (xy 109.982385 91.21804) (xy 109.982392 91.218036) (xy 109.985326 91.216541) (xy 110.302534 91.010544) (xy 110.596471 90.772518) (xy 110.863918 90.505071) (xy 111.101944 90.211134) (xy 111.307941 89.893926) (xy 111.479653 89.556923) (xy 111.615197 89.203818) (xy 111.713089 88.838479) (xy 111.772257 88.464909) (xy 111.792052 88.0872) (xy 111.772257 87.709491) (xy 111.713089 87.335921) (xy 111.615197 86.970582) (xy 111.479653 86.617477) (xy 111.307941 86.280474) (xy 111.101944 85.963266) (xy 110.863918 85.669329) (xy 110.596471 85.401882) (xy 110.302534 85.163856) (xy 109.985326 84.957859) (xy 109.982392 84.956364) (xy 109.982385 84.95636) (xy 109.651263 84.787645) (xy 109.648323 84.786147) (xy 109.295218 84.650603) (xy 108.929879 84.552711) (xy 108.731442 84.521282) (xy 108.559557 84.494057) (xy 108.559549 84.494056) (xy 108.556309 84.493543) (xy 108.1786 84.473748) (xy 107.800891 84.493543) (xy 107.797651 84.494056) (xy 107.797643 84.494057) (xy 107.625758 84.521282) (xy 107.427321 84.552711) (xy 107.061982 84.650603) (xy 106.708877 84.786147) (xy 106.705937 84.787645) (xy 106.374815 84.95636) (xy 106.374808 84.956364) (xy 106.371874 84.957859) (xy 106.054666 85.163856) (xy 105.760729 85.401882) (xy 105.493282 85.669329) (xy 105.255256 85.963266) (xy 105.049259 86.280474) (xy 104.877547 86.617477) (xy 104.742003 86.970582) (xy 104.644111 87.335921) (xy 104.584943 87.709491) (xy 104.565148 88.0872) (xy 102.756333 88.0872) (xy 102.767629 81.659479) (xy 102.787751 81.591393) (xy 102.841488 81.544995) (xy 102.893629 81.5337) (xy 114.7585 81.5337) ) ) ) (zone (net 0) (net_name "") (layer "F.Cu") (tstamp 717e74a8-02a0-4441-8cd7-d251267eebe9) (hatch edge 0.508) (connect_pads (clearance 0.508)) (min_thickness 0.254) (filled_areas_thickness no) (fill yes (thermal_gap 0.508) (thermal_bridge_width 0.508)) (polygon (pts (xy 40.6146 95.7072) (xy 28.1686 95.7072) (xy 28.194 81.2292) (xy 40.6146 81.2292) ) ) (filled_polygon (layer "F.Cu") (island) (pts (xy 40.556721 81.579102) (xy 40.603214 81.632758) (xy 40.6146 81.6851) (xy 40.6146 95.0227) (xy 40.594598 95.090821) (xy 40.540942 95.137314) (xy 40.4886 95.1487) (xy 28.5991 95.1487) (xy 28.530979 95.128698) (xy 28.484486 95.075042) (xy 28.4731 95.0227) (xy 28.4731 88.1634) (xy 31.641748 88.1634) (xy 31.661543 88.541109) (xy 31.720711 88.914679) (xy 31.818603 89.280018) (xy 31.954147 89.633123) (xy 32.125859 89.970126) (xy 32.331856 90.287334) (xy 32.569882 90.581271) (xy 32.837329 90.848718) (xy 33.131266 91.086744) (xy 33.448474 91.292741) (xy 33.451408 91.294236) (xy 33.451415 91.29424) (xy 33.782537 91.462955) (xy 33.785477 91.464453) (xy 34.138582 91.599997) (xy 34.503921 91.697889) (xy 34.702358 91.729318) (xy 34.874243 91.756543) (xy 34.874251 91.756544) (xy 34.877491 91.757057) (xy 35.2552 91.776852) (xy 35.632909 91.757057) (xy 35.636149 91.756544) (xy 35.636157 91.756543) (xy 35.808042 91.729318) (xy 36.006479 91.697889) (xy 36.371818 91.599997) (xy 36.724923 91.464453) (xy 36.727863 91.462955) (xy 37.058985 91.29424) (xy 37.058992 91.294236) (xy 37.061926 91.292741) (xy 37.379134 91.086744) (xy 37.673071 90.848718) (xy 37.940518 90.581271) (xy 38.178544 90.287334) (xy 38.384541 89.970126) (xy 38.556253 89.633123) (xy 38.691797 89.280018) (xy 38.789689 88.914679) (xy 38.848857 88.541109) (xy 38.868652 88.1634) (xy 38.848857 87.785691) (xy 38.789689 87.412121) (xy 38.691797 87.046782) (xy 38.556253 86.693677) (xy 38.384541 86.356674) (xy 38.178544 86.039466) (xy 37.940518 85.745529) (xy 37.673071 85.478082) (xy 37.379134 85.240056) (xy 37.061926 85.034059) (xy 37.058992 85.032564) (xy 37.058985 85.03256) (xy 36.727863 84.863845) (xy 36.724923 84.862347) (xy 36.371818 84.726803) (xy 36.006479 84.628911) (xy 35.808042 84.597482) (xy 35.636157 84.570257) (xy 35.636149 84.570256) (xy 35.632909 84.569743) (xy 35.2552 84.549948) (xy 34.877491 84.569743) (xy 34.874251 84.570256) (xy 34.874243 84.570257) (xy 34.702358 84.597482) (xy 34.503921 84.628911) (xy 34.138582 84.726803) (xy 33.785477 84.862347) (xy 33.782537 84.863845) (xy 33.451415 85.03256) (xy 33.451408 85.032564) (xy 33.448474 85.034059) (xy 33.131266 85.240056) (xy 32.837329 85.478082) (xy 32.569882 85.745529) (xy 32.331856 86.039466) (xy 32.125859 86.356674) (xy 31.954147 86.693677) (xy 31.818603 87.046782) (xy 31.720711 87.412121) (xy 31.661543 87.785691) (xy 31.641748 88.1634) (xy 28.4731 88.1634) (xy 28.4731 81.6851) (xy 28.493102 81.616979) (xy 28.546758 81.570486) (xy 28.5991 81.5591) (xy 40.4886 81.5591) ) ) ) (zone (net 0) (net_name "") (layer "F.Cu") (tstamp 8e5b8afc-a745-4f80-b915-574bb3ac972c) (hatch edge 0.508) (connect_pads (clearance 0.508)) (min_thickness 0.254) (filled_areas_thickness no) (fill yes (thermal_gap 0.508) (thermal_bridge_width 0.508)) (polygon (pts (xy 56.1086 95.698784) (xy 43.6626 95.698784) (xy 43.688 81.246184) (xy 56.1086 81.246184) ) ) (filled_polygon (layer "F.Cu") (island) (pts (xy 55.746221 81.579102) (xy 55.792714 81.632758) (xy 55.8041 81.6851) (xy 55.8041 95.0227) (xy 55.784098 95.090821) (xy 55.730442 95.137314) (xy 55.6781 95.1487) (xy 43.789789 95.1487) (xy 43.721668 95.128698) (xy 43.675175 95.075042) (xy 43.663789 95.022479) (xy 43.675933 88.1126) (xy 45.484748 88.1126) (xy 45.504543 88.490309) (xy 45.563711 88.863879) (xy 45.661603 89.229218) (xy 45.797147 89.582323) (xy 45.968859 89.919326) (xy 46.174856 90.236534) (xy 46.412882 90.530471) (xy 46.680329 90.797918) (xy 46.974266 91.035944) (xy 47.291474 91.241941) (xy 47.294408 91.243436) (xy 47.294415 91.24344) (xy 47.625537 91.412155) (xy 47.628477 91.413653) (xy 47.981582 91.549197) (xy 48.346921 91.647089) (xy 48.545358 91.678518) (xy 48.717243 91.705743) (xy 48.717251 91.705744) (xy 48.720491 91.706257) (xy 49.0982 91.726052) (xy 49.475909 91.706257) (xy 49.479149 91.705744) (xy 49.479157 91.705743) (xy 49.651042 91.678518) (xy 49.849479 91.647089) (xy 50.214818 91.549197) (xy 50.567923 91.413653) (xy 50.570863 91.412155) (xy 50.901985 91.24344) (xy 50.901992 91.243436) (xy 50.904926 91.241941) (xy 51.222134 91.035944) (xy 51.516071 90.797918) (xy 51.783518 90.530471) (xy 52.021544 90.236534) (xy 52.227541 89.919326) (xy 52.399253 89.582323) (xy 52.534797 89.229218) (xy 52.632689 88.863879) (xy 52.691857 88.490309) (xy 52.711652 88.1126) (xy 52.691857 87.734891) (xy 52.632689 87.361321) (xy 52.534797 86.995982) (xy 52.399253 86.642877) (xy 52.227541 86.305874) (xy 52.021544 85.988666) (xy 51.783518 85.694729) (xy 51.516071 85.427282) (xy 51.222134 85.189256) (xy 50.904926 84.983259) (xy 50.901992 84.981764) (xy 50.901985 84.98176) (xy 50.570863 84.813045) (xy 50.567923 84.811547) (xy 50.214818 84.676003) (xy 49.849479 84.578111) (xy 49.651042 84.546682) (xy 49.479157 84.519457) (xy 49.479149 84.519456) (xy 49.475909 84.518943) (xy 49.0982 84.499148) (xy 48.720491 84.518943) (xy 48.717251 84.519456) (xy 48.717243 84.519457) (xy 48.545358 84.546682) (xy 48.346921 84.578111) (xy 47.981582 84.676003) (xy 47.628477 84.811547) (xy 47.625537 84.813045) (xy 47.294415 84.98176) (xy 47.294408 84.981764) (xy 47.291474 84.983259) (xy 46.974266 85.189256) (xy 46.680329 85.427282) (xy 46.412882 85.694729) (xy 46.174856 85.988666) (xy 45.968859 86.305874) (xy 45.797147 86.642877) (xy 45.661603 86.995982) (xy 45.563711 87.361321) (xy 45.504543 87.734891) (xy 45.484748 88.1126) (xy 43.675933 88.1126) (xy 43.687229 81.684879) (xy 43.707351 81.616793) (xy 43.761088 81.570395) (xy 43.813229 81.5591) (xy 55.6781 81.5591) ) ) ) (zone (net 0) (net_name "") (layer "F.Cu") (tstamp 9fc33050-90b4-4eac-bf4f-e163ca594107) (hatch edge 0.508) (connect_pads (clearance 0.508)) (min_thickness 0.254) (filled_areas_thickness no) (fill yes (thermal_gap 0.508) (thermal_bridge_width 0.508)) (polygon (pts (xy 85.5726 95.6818) (xy 57.5818 95.6818) (xy 57.6072 81.2038) (xy 85.5726 81.2038) ) ) (filled_polygon (layer "F.Cu") (island) (pts (xy 85.159421 81.553702) (xy 85.205914 81.607358) (xy 85.2173 81.6597) (xy 85.2173 94.9973) (xy 85.197298 95.065421) (xy 85.143642 95.111914) (xy 85.0913 95.1233) (xy 58.0123 95.1233) (xy 57.944179 95.103298) (xy 57.897686 95.049642) (xy 57.8863 94.9973) (xy 57.8863 88.138) (xy 61.054948 88.138) (xy 61.074743 88.515709) (xy 61.133911 88.889279) (xy 61.231803 89.254618) (xy 61.367347 89.607723) (xy 61.368845 89.610663) (xy 61.511677 89.890985) (xy 61.539059 89.944726) (xy 61.745056 90.261934) (xy 61.983082 90.555871) (xy 62.250529 90.823318) (xy 62.544466 91.061344) (xy 62.861674 91.267341) (xy 62.864608 91.268836) (xy 62.864615 91.26884) (xy 63.1013 91.389437) (xy 63.198677 91.439053) (xy 63.551782 91.574597) (xy 63.917121 91.672489) (xy 64.115558 91.703918) (xy 64.287443 91.731143) (xy 64.287451 91.731144) (xy 64.290691 91.731657) (xy 64.6684 91.751452) (xy 65.046109 91.731657) (xy 65.049349 91.731144) (xy 65.049357 91.731143) (xy 65.221242 91.703918) (xy 65.419679 91.672489) (xy 65.785018 91.574597) (xy 66.138123 91.439053) (xy 66.2355 91.389437) (xy 66.472185 91.26884) (xy 66.472192 91.268836) (xy 66.475126 91.267341) (xy 66.792334 91.061344) (xy 67.086271 90.823318) (xy 67.353718 90.555871) (xy 67.591744 90.261934) (xy 67.797741 89.944726) (xy 67.825124 89.890985) (xy 67.967955 89.610663) (xy 67.969453 89.607723) (xy 68.104997 89.254618) (xy 68.202889 88.889279) (xy 68.262057 88.515709) (xy 68.281852 88.138) (xy 68.27919 88.0872) (xy 74.897948 88.0872) (xy 74.917743 88.464909) (xy 74.976911 88.838479) (xy 75.074803 89.203818) (xy 75.210347 89.556923) (xy 75.382059 89.893926) (xy 75.588056 90.211134) (xy 75.826082 90.505071) (xy 76.093529 90.772518) (xy 76.387466 91.010544) (xy 76.704674 91.216541) (xy 76.707608 91.218036) (xy 76.707615 91.21804) (xy 76.804374 91.267341) (xy 77.041677 91.388253) (xy 77.394782 91.523797) (xy 77.760121 91.621689) (xy 77.958558 91.653118) (xy 78.130443 91.680343) (xy 78.130451 91.680344) (xy 78.133691 91.680857) (xy 78.5114 91.700652) (xy 78.889109 91.680857) (xy 78.892349 91.680344) (xy 78.892357 91.680343) (xy 79.064242 91.653118) (xy 79.262679 91.621689) (xy 79.628018 91.523797) (xy 79.981123 91.388253) (xy 80.218426 91.267341) (xy 80.315185 91.21804) (xy 80.315192 91.218036) (xy 80.318126 91.216541) (xy 80.635334 91.010544) (xy 80.929271 90.772518) (xy 81.196718 90.505071) (xy 81.434744 90.211134) (xy 81.640741 89.893926) (xy 81.812453 89.556923) (xy 81.947997 89.203818) (xy 82.045889 88.838479) (xy 82.105057 88.464909) (xy 82.124852 88.0872) (xy 82.105057 87.709491) (xy 82.045889 87.335921) (xy 81.947997 86.970582) (xy 81.812453 86.617477) (xy 81.810955 86.614537) (xy 81.64224 86.283415) (xy 81.642236 86.283408) (xy 81.640741 86.280474) (xy 81.434744 85.963266) (xy 81.196718 85.669329) (xy 80.929271 85.401882) (xy 80.635334 85.163856) (xy 80.318126 84.957859) (xy 80.315192 84.956364) (xy 80.315185 84.95636) (xy 79.984063 84.787645) (xy 79.981123 84.786147) (xy 79.628018 84.650603) (xy 79.262679 84.552711) (xy 79.064242 84.521282) (xy 78.892357 84.494057) (xy 78.892349 84.494056) (xy 78.889109 84.493543) (xy 78.5114 84.473748) (xy 78.133691 84.493543) (xy 78.130451 84.494056) (xy 78.130443 84.494057) (xy 77.958558 84.521282) (xy 77.760121 84.552711) (xy 77.394782 84.650603) (xy 77.041677 84.786147) (xy 77.038737 84.787645) (xy 76.707615 84.95636) (xy 76.707608 84.956364) (xy 76.704674 84.957859) (xy 76.387466 85.163856) (xy 76.093529 85.401882) (xy 75.826082 85.669329) (xy 75.588056 85.963266) (xy 75.382059 86.280474) (xy 75.380564 86.283408) (xy 75.38056 86.283415) (xy 75.211845 86.614537) (xy 75.210347 86.617477) (xy 75.074803 86.970582) (xy 74.976911 87.335921) (xy 74.917743 87.709491) (xy 74.897948 88.0872) (xy 68.27919 88.0872) (xy 68.262057 87.760291) (xy 68.202889 87.386721) (xy 68.104997 87.021382) (xy 67.969453 86.668277) (xy 67.797741 86.331274) (xy 67.591744 86.014066) (xy 67.353718 85.720129) (xy 67.086271 85.452682) (xy 66.792334 85.214656) (xy 66.475126 85.008659) (xy 66.472192 85.007164) (xy 66.472185 85.00716) (xy 66.141063 84.838445) (xy 66.138123 84.836947) (xy 65.785018 84.701403) (xy 65.419679 84.603511) (xy 65.221242 84.572082) (xy 65.049357 84.544857) (xy 65.049349 84.544856) (xy 65.046109 84.544343) (xy 64.6684 84.524548) (xy 64.290691 84.544343) (xy 64.287451 84.544856) (xy 64.287443 84.544857) (xy 64.115558 84.572082) (xy 63.917121 84.603511) (xy 63.551782 84.701403) (xy 63.198677 84.836947) (xy 63.195737 84.838445) (xy 62.864615 85.00716) (xy 62.864608 85.007164) (xy 62.861674 85.008659) (xy 62.544466 85.214656) (xy 62.250529 85.452682) (xy 61.983082 85.720129) (xy 61.745056 86.014066) (xy 61.539059 86.331274) (xy 61.367347 86.668277) (xy 61.231803 87.021382) (xy 61.133911 87.386721) (xy 61.074743 87.760291) (xy 61.054948 88.138) (xy 57.8863 88.138) (xy 57.8863 81.6597) (xy 57.906302 81.591579) (xy 57.959958 81.545086) (xy 58.0123 81.5337) (xy 85.0913 81.5337) ) ) ) (zone (net 0) (net_name "") (layer "F.Cu") (tstamp 9fcbaed3-744d-4684-bd8d-32ce19ebda3c) (hatch edge 0.508) (connect_pads (clearance 0.508)) (min_thickness 0.254) (filled_areas_thickness no) (fill yes (thermal_gap 0.508) (thermal_bridge_width 0.508)) (polygon (pts (xy 99.695 47.7266) (xy 87.249 47.7266) (xy 87.2744 33.2486) (xy 99.695 33.2486) ) ) (filled_polygon (layer "F.Cu") (island) (pts (xy 99.637121 33.598502) (xy 99.683614 33.652158) (xy 99.695 33.7045) (xy 99.695 47.0421) (xy 99.674998 47.110221) (xy 99.621342 47.156714) (xy 99.569 47.1681) (xy 87.6795 47.1681) (xy 87.611379 47.148098) (xy 87.564886 47.094442) (xy 87.5535 47.0421) (xy 87.5535 40.1828) (xy 90.722148 40.1828) (xy 90.741943 40.560509) (xy 90.801111 40.934079) (xy 90.899003 41.299418) (xy 91.034547 41.652523) (xy 91.206259 41.989526) (xy 91.412256 42.306734) (xy 91.650282 42.600671) (xy 91.917729 42.868118) (xy 92.211666 43.106144) (xy 92.528874 43.312141) (xy 92.531808 43.313636) (xy 92.531815 43.31364) (xy 92.862937 43.482355) (xy 92.865877 43.483853) (xy 93.218982 43.619397) (xy 93.584321 43.717289) (xy 93.782758 43.748718) (xy 93.954643 43.775943) (xy 93.954651 43.775944) (xy 93.957891 43.776457) (xy 94.3356 43.796252) (xy 94.713309 43.776457) (xy 94.716549 43.775944) (xy 94.716557 43.775943) (xy 94.888442 43.748718) (xy 95.086879 43.717289) (xy 95.452218 43.619397) (xy 95.805323 43.483853) (xy 95.808263 43.482355) (xy 96.139385 43.31364) (xy 96.139392 43.313636) (xy 96.142326 43.312141) (xy 96.459534 43.106144) (xy 96.753471 42.868118) (xy 97.020918 42.600671) (xy 97.258944 42.306734) (xy 97.464941 41.989526) (xy 97.636653 41.652523) (xy 97.772197 41.299418) (xy 97.870089 40.934079) (xy 97.929257 40.560509) (xy 97.949052 40.1828) (xy 97.929257 39.805091) (xy 97.870089 39.431521) (xy 97.772197 39.066182) (xy 97.636653 38.713077) (xy 97.464941 38.376074) (xy 97.258944 38.058866) (xy 97.020918 37.764929) (xy 96.753471 37.497482) (xy 96.459534 37.259456) (xy 96.142326 37.053459) (xy 96.139392 37.051964) (xy 96.139385 37.05196) (xy 95.808263 36.883245) (xy 95.805323 36.881747) (xy 95.452218 36.746203) (xy 95.086879 36.648311) (xy 94.888442 36.616882) (xy 94.716557 36.589657) (xy 94.716549 36.589656) (xy 94.713309 36.589143) (xy 94.3356 36.569348) (xy 93.957891 36.589143) (xy 93.954651 36.589656) (xy 93.954643 36.589657) (xy 93.782758 36.616882) (xy 93.584321 36.648311) (xy 93.218982 36.746203) (xy 92.865877 36.881747) (xy 92.862937 36.883245) (xy 92.531815 37.05196) (xy 92.531808 37.051964) (xy 92.528874 37.053459) (xy 92.211666 37.259456) (xy 91.917729 37.497482) (xy 91.650282 37.764929) (xy 91.412256 38.058866) (xy 91.206259 38.376074) (xy 91.034547 38.713077) (xy 90.899003 39.066182) (xy 90.801111 39.431521) (xy 90.741943 39.805091) (xy 90.722148 40.1828) (xy 87.5535 40.1828) (xy 87.5535 33.7045) (xy 87.573502 33.636379) (xy 87.627158 33.589886) (xy 87.6795 33.5785) (xy 99.569 33.5785) ) ) ) (zone (net 0) (net_name "") (layer "F.Cu") (tstamp a0c721fc-f9f3-4a5f-b5d6-b1c20d71eedf) (hatch edge 0.508) (connect_pads (clearance 0.508)) (min_thickness 0.254) (filled_areas_thickness no) (fill yes (thermal_gap 0.508) (thermal_bridge_width 0.508)) (polygon (pts (xy 115.189 79.341184) (xy 102.743 79.341184) (xy 102.7684 64.888584) (xy 115.189 64.888584) ) ) (filled_polygon (layer "F.Cu") (island) (pts (xy 114.826621 65.221502) (xy 114.873114 65.275158) (xy 114.8845 65.3275) (xy 114.8845 78.6651) (xy 114.864498 78.733221) (xy 114.810842 78.779714) (xy 114.7585 78.7911) (xy 102.870189 78.7911) (xy 102.802068 78.771098) (xy 102.755575 78.717442) (xy 102.744189 78.664879) (xy 102.756333 71.755) (xy 104.565148 71.755) (xy 104.584943 72.132709) (xy 104.644111 72.506279) (xy 104.742003 72.871618) (xy 104.877547 73.224723) (xy 105.049259 73.561726) (xy 105.255256 73.878934) (xy 105.493282 74.172871) (xy 105.760729 74.440318) (xy 106.054666 74.678344) (xy 106.371874 74.884341) (xy 106.374808 74.885836) (xy 106.374815 74.88584) (xy 106.705937 75.054555) (xy 106.708877 75.056053) (xy 107.061982 75.191597) (xy 107.427321 75.289489) (xy 107.625758 75.320918) (xy 107.797643 75.348143) (xy 107.797651 75.348144) (xy 107.800891 75.348657) (xy 108.1786 75.368452) (xy 108.556309 75.348657) (xy 108.559549 75.348144) (xy 108.559557 75.348143) (xy 108.731442 75.320918) (xy 108.929879 75.289489) (xy 109.295218 75.191597) (xy 109.648323 75.056053) (xy 109.651263 75.054555) (xy 109.982385 74.88584) (xy 109.982392 74.885836) (xy 109.985326 74.884341) (xy 110.302534 74.678344) (xy 110.596471 74.440318) (xy 110.863918 74.172871) (xy 111.101944 73.878934) (xy 111.307941 73.561726) (xy 111.479653 73.224723) (xy 111.615197 72.871618) (xy 111.713089 72.506279) (xy 111.772257 72.132709) (xy 111.792052 71.755) (xy 111.772257 71.377291) (xy 111.713089 71.003721) (xy 111.615197 70.638382) (xy 111.479653 70.285277) (xy 111.307941 69.948274) (xy 111.101944 69.631066) (xy 110.863918 69.337129) (xy 110.596471 69.069682) (xy 110.302534 68.831656) (xy 109.985326 68.625659) (xy 109.982392 68.624164) (xy 109.982385 68.62416) (xy 109.651263 68.455445) (xy 109.648323 68.453947) (xy 109.295218 68.318403) (xy 108.929879 68.220511) (xy 108.731442 68.189082) (xy 108.559557 68.161857) (xy 108.559549 68.161856) (xy 108.556309 68.161343) (xy 108.1786 68.141548) (xy 107.800891 68.161343) (xy 107.797651 68.161856) (xy 107.797643 68.161857) (xy 107.625758 68.189082) (xy 107.427321 68.220511) (xy 107.061982 68.318403) (xy 106.708877 68.453947) (xy 106.705937 68.455445) (xy 106.374815 68.62416) (xy 106.374808 68.624164) (xy 106.371874 68.625659) (xy 106.054666 68.831656) (xy 105.760729 69.069682) (xy 105.493282 69.337129) (xy 105.255256 69.631066) (xy 105.049259 69.948274) (xy 104.877547 70.285277) (xy 104.742003 70.638382) (xy 104.644111 71.003721) (xy 104.584943 71.377291) (xy 104.565148 71.755) (xy 102.756333 71.755) (xy 102.767629 65.327279) (xy 102.787751 65.259193) (xy 102.841488 65.212795) (xy 102.893629 65.2015) (xy 114.7585 65.2015) ) ) ) (zone (net 0) (net_name "") (layer "F.Cu") (tstamp a7e99fd8-6a59-492d-a8c1-c392a42f534f) (hatch edge 0.508) (connect_pads (clearance 0.508)) (min_thickness 0.254) (filled_areas_thickness no) (fill yes (thermal_gap 0.508) (thermal_bridge_width 0.508)) (polygon (pts (xy 115.181604 63.465503) (xy 102.735604 63.465503) (xy 102.761004 49.012903) (xy 115.181604 49.012903) ) ) (filled_polygon (layer "F.Cu") (island) (pts (xy 114.819225 49.345821) (xy 114.865718 49.399477) (xy 114.877104 49.451819) (xy 114.877104 62.789419) (xy 114.857102 62.85754) (xy 114.803446 62.904033) (xy 114.751104 62.915419) (xy 102.862793 62.915419) (xy 102.794672 62.895417) (xy 102.748179 62.841761) (xy 102.736793 62.789198) (xy 102.748937 55.879319) (xy 104.557752 55.879319) (xy 104.577547 56.257028) (xy 104.636715 56.630598) (xy 104.734607 56.995937) (xy 104.870151 57.349042) (xy 105.041863 57.686045) (xy 105.24786 58.003253) (xy 105.485886 58.29719) (xy 105.753333 58.564637) (xy 106.04727 58.802663) (xy 106.364478 59.00866) (xy 106.367412 59.010155) (xy 106.367419 59.010159) (xy 106.698541 59.178874) (xy 106.701481 59.180372) (xy 107.054586 59.315916) (xy 107.419925 59.413808) (xy 107.618362 59.445237) (xy 107.790247 59.472462) (xy 107.790255 59.472463) (xy 107.793495 59.472976) (xy 108.171204 59.492771) (xy 108.548913 59.472976) (xy 108.552153 59.472463) (xy 108.552161 59.472462) (xy 108.724046 59.445237) (xy 108.922483 59.413808) (xy 109.287822 59.315916) (xy 109.640927 59.180372) (xy 109.643867 59.178874) (xy 109.974989 59.010159) (xy 109.974996 59.010155) (xy 109.97793 59.00866) (xy 110.295138 58.802663) (xy 110.589075 58.564637) (xy 110.856522 58.29719) (xy 111.094548 58.003253) (xy 111.300545 57.686045) (xy 111.472257 57.349042) (xy 111.607801 56.995937) (xy 111.705693 56.630598) (xy 111.764861 56.257028) (xy 111.784656 55.879319) (xy 111.764861 55.50161) (xy 111.705693 55.12804) (xy 111.607801 54.762701) (xy 111.472257 54.409596) (xy 111.300545 54.072593) (xy 111.094548 53.755385) (xy 110.856522 53.461448) (xy 110.589075 53.194001) (xy 110.295138 52.955975) (xy 109.97793 52.749978) (xy 109.974996 52.748483) (xy 109.974989 52.748479) (xy 109.643867 52.579764) (xy 109.640927 52.578266) (xy 109.287822 52.442722) (xy 108.922483 52.34483) (xy 108.724046 52.313401) (xy 108.552161 52.286176) (xy 108.552153 52.286175) (xy 108.548913 52.285662) (xy 108.171204 52.265867) (xy 107.793495 52.285662) (xy 107.790255 52.286175) (xy 107.790247 52.286176) (xy 107.618362 52.313401) (xy 107.419925 52.34483) (xy 107.054586 52.442722) (xy 106.701481 52.578266) (xy 106.698541 52.579764) (xy 106.367419 52.748479) (xy 106.367412 52.748483) (xy 106.364478 52.749978) (xy 106.04727 52.955975) (xy 105.753333 53.194001) (xy 105.485886 53.461448) (xy 105.24786 53.755385) (xy 105.041863 54.072593) (xy 104.870151 54.409596) (xy 104.734607 54.762701) (xy 104.636715 55.12804) (xy 104.577547 55.50161) (xy 104.557752 55.879319) (xy 102.748937 55.879319) (xy 102.760233 49.451598) (xy 102.780355 49.383512) (xy 102.834092 49.337114) (xy 102.886233 49.325819) (xy 114.751104 49.325819) ) ) ) (zone (net 0) (net_name "") (layer "F.Cu") (tstamp b35cbf3b-e727-4bfe-927d-a657c3b692b7) (hatch edge 0.508) (connect_pads (clearance 0.508)) (min_thickness 0.254) (filled_areas_thickness no) (fill yes (thermal_gap 0.508) (thermal_bridge_width 0.508)) (polygon (pts (xy 99.695 79.3496) (xy 87.249 79.3496) (xy 87.2744 64.8716) (xy 99.695 64.8716) ) ) (filled_polygon (layer "F.Cu") (island) (pts (xy 99.637121 65.221502) (xy 99.683614 65.275158) (xy 99.695 65.3275) (xy 99.695 78.6651) (xy 99.674998 78.733221) (xy 99.621342 78.779714) (xy 99.569 78.7911) (xy 87.6795 78.7911) (xy 87.611379 78.771098) (xy 87.564886 78.717442) (xy 87.5535 78.6651) (xy 87.5535 71.8058) (xy 90.722148 71.8058) (xy 90.741943 72.183509) (xy 90.801111 72.557079) (xy 90.899003 72.922418) (xy 91.034547 73.275523) (xy 91.206259 73.612526) (xy 91.412256 73.929734) (xy 91.650282 74.223671) (xy 91.917729 74.491118) (xy 92.211666 74.729144) (xy 92.528874 74.935141) (xy 92.531808 74.936636) (xy 92.531815 74.93664) (xy 92.862937 75.105355) (xy 92.865877 75.106853) (xy 93.218982 75.242397) (xy 93.584321 75.340289) (xy 93.782758 75.371718) (xy 93.954643 75.398943) (xy 93.954651 75.398944) (xy 93.957891 75.399457) (xy 94.3356 75.419252) (xy 94.713309 75.399457) (xy 94.716549 75.398944) (xy 94.716557 75.398943) (xy 94.888442 75.371718) (xy 95.086879 75.340289) (xy 95.452218 75.242397) (xy 95.805323 75.106853) (xy 95.808263 75.105355) (xy 96.139385 74.93664) (xy 96.139392 74.936636) (xy 96.142326 74.935141) (xy 96.459534 74.729144) (xy 96.753471 74.491118) (xy 97.020918 74.223671) (xy 97.258944 73.929734) (xy 97.464941 73.612526) (xy 97.636653 73.275523) (xy 97.772197 72.922418) (xy 97.870089 72.557079) (xy 97.929257 72.183509) (xy 97.949052 71.8058) (xy 97.929257 71.428091) (xy 97.870089 71.054521) (xy 97.772197 70.689182) (xy 97.636653 70.336077) (xy 97.464941 69.999074) (xy 97.258944 69.681866) (xy 97.020918 69.387929) (xy 96.753471 69.120482) (xy 96.459534 68.882456) (xy 96.142326 68.676459) (xy 96.139392 68.674964) (xy 96.139385 68.67496) (xy 95.808263 68.506245) (xy 95.805323 68.504747) (xy 95.452218 68.369203) (xy 95.086879 68.271311) (xy 94.888442 68.239882) (xy 94.716557 68.212657) (xy 94.716549 68.212656) (xy 94.713309 68.212143) (xy 94.3356 68.192348) (xy 93.957891 68.212143) (xy 93.954651 68.212656) (xy 93.954643 68.212657) (xy 93.782758 68.239882) (xy 93.584321 68.271311) (xy 93.218982 68.369203) (xy 92.865877 68.504747) (xy 92.862937 68.506245) (xy 92.531815 68.67496) (xy 92.531808 68.674964) (xy 92.528874 68.676459) (xy 92.211666 68.882456) (xy 91.917729 69.120482) (xy 91.650282 69.387929) (xy 91.412256 69.681866) (xy 91.206259 69.999074) (xy 91.034547 70.336077) (xy 90.899003 70.689182) (xy 90.801111 71.054521) (xy 90.741943 71.428091) (xy 90.722148 71.8058) (xy 87.5535 71.8058) (xy 87.5535 65.3275) (xy 87.573502 65.259379) (xy 87.627158 65.212886) (xy 87.6795 65.2015) (xy 99.569 65.2015) ) ) ) (zone (net 0) (net_name "") (layer "F.Cu") (tstamp b6e1fbc7-865f-4cb0-8b5a-67c28c66e74b) (hatch edge 0.508) (connect_pads (clearance 0.508)) (min_thickness 0.254) (filled_areas_thickness no) (fill yes (thermal_gap 0.508) (thermal_bridge_width 0.508)) (polygon (pts (xy 85.5726 47.7266) (xy 57.5818 47.7266) (xy 57.6072 33.2486) (xy 85.5726 33.2486) ) ) (filled_polygon (layer "F.Cu") (island) (pts (xy 85.159421 33.598502) (xy 85.205914 33.652158) (xy 85.2173 33.7045) (xy 85.2173 47.0421) (xy 85.197298 47.110221) (xy 85.143642 47.156714) (xy 85.0913 47.1681) (xy 58.0123 47.1681) (xy 57.944179 47.148098) (xy 57.897686 47.094442) (xy 57.8863 47.0421) (xy 57.8863 40.1828) (xy 61.054948 40.1828) (xy 61.074743 40.560509) (xy 61.133911 40.934079) (xy 61.231803 41.299418) (xy 61.367347 41.652523) (xy 61.368845 41.655463) (xy 61.511677 41.935785) (xy 61.539059 41.989526) (xy 61.745056 42.306734) (xy 61.983082 42.600671) (xy 62.250529 42.868118) (xy 62.544466 43.106144) (xy 62.861674 43.312141) (xy 62.864608 43.313636) (xy 62.864615 43.31364) (xy 63.1013 43.434237) (xy 63.198677 43.483853) (xy 63.551782 43.619397) (xy 63.917121 43.717289) (xy 64.115558 43.748718) (xy 64.287443 43.775943) (xy 64.287451 43.775944) (xy 64.290691 43.776457) (xy 64.6684 43.796252) (xy 65.046109 43.776457) (xy 65.049349 43.775944) (xy 65.049357 43.775943) (xy 65.221242 43.748718) (xy 65.419679 43.717289) (xy 65.785018 43.619397) (xy 66.138123 43.483853) (xy 66.2355 43.434237) (xy 66.472185 43.31364) (xy 66.472192 43.313636) (xy 66.475126 43.312141) (xy 66.792334 43.106144) (xy 67.086271 42.868118) (xy 67.353718 42.600671) (xy 67.591744 42.306734) (xy 67.797741 41.989526) (xy 67.825124 41.935785) (xy 67.967955 41.655463) (xy 67.969453 41.652523) (xy 68.104997 41.299418) (xy 68.202889 40.934079) (xy 68.262057 40.560509) (xy 68.281852 40.1828) (xy 68.27919 40.132) (xy 74.897948 40.132) (xy 74.917743 40.509709) (xy 74.976911 40.883279) (xy 75.074803 41.248618) (xy 75.210347 41.601723) (xy 75.382059 41.938726) (xy 75.588056 42.255934) (xy 75.826082 42.549871) (xy 76.093529 42.817318) (xy 76.387466 43.055344) (xy 76.704674 43.261341) (xy 76.707608 43.262836) (xy 76.707615 43.26284) (xy 76.804374 43.312141) (xy 77.041677 43.433053) (xy 77.394782 43.568597) (xy 77.760121 43.666489) (xy 77.958558 43.697918) (xy 78.130443 43.725143) (xy 78.130451 43.725144) (xy 78.133691 43.725657) (xy 78.5114 43.745452) (xy 78.889109 43.725657) (xy 78.892349 43.725144) (xy 78.892357 43.725143) (xy 79.064242 43.697918) (xy 79.262679 43.666489) (xy 79.628018 43.568597) (xy 79.981123 43.433053) (xy 80.218426 43.312141) (xy 80.315185 43.26284) (xy 80.315192 43.262836) (xy 80.318126 43.261341) (xy 80.635334 43.055344) (xy 80.929271 42.817318) (xy 81.196718 42.549871) (xy 81.434744 42.255934) (xy 81.640741 41.938726) (xy 81.812453 41.601723) (xy 81.947997 41.248618) (xy 82.045889 40.883279) (xy 82.105057 40.509709) (xy 82.124852 40.132) (xy 82.105057 39.754291) (xy 82.045889 39.380721) (xy 81.947997 39.015382) (xy 81.812453 38.662277) (xy 81.810955 38.659337) (xy 81.64224 38.328215) (xy 81.642236 38.328208) (xy 81.640741 38.325274) (xy 81.434744 38.008066) (xy 81.196718 37.714129) (xy 80.929271 37.446682) (xy 80.635334 37.208656) (xy 80.318126 37.002659) (xy 80.315192 37.001164) (xy 80.315185 37.00116) (xy 79.984063 36.832445) (xy 79.981123 36.830947) (xy 79.628018 36.695403) (xy 79.262679 36.597511) (xy 79.064242 36.566082) (xy 78.892357 36.538857) (xy 78.892349 36.538856) (xy 78.889109 36.538343) (xy 78.5114 36.518548) (xy 78.133691 36.538343) (xy 78.130451 36.538856) (xy 78.130443 36.538857) (xy 77.958558 36.566082) (xy 77.760121 36.597511) (xy 77.394782 36.695403) (xy 77.041677 36.830947) (xy 77.038737 36.832445) (xy 76.707615 37.00116) (xy 76.707608 37.001164) (xy 76.704674 37.002659) (xy 76.387466 37.208656) (xy 76.093529 37.446682) (xy 75.826082 37.714129) (xy 75.588056 38.008066) (xy 75.382059 38.325274) (xy 75.380564 38.328208) (xy 75.38056 38.328215) (xy 75.211845 38.659337) (xy 75.210347 38.662277) (xy 75.074803 39.015382) (xy 74.976911 39.380721) (xy 74.917743 39.754291) (xy 74.897948 40.132) (xy 68.27919 40.132) (xy 68.262057 39.805091) (xy 68.202889 39.431521) (xy 68.104997 39.066182) (xy 67.969453 38.713077) (xy 67.797741 38.376074) (xy 67.591744 38.058866) (xy 67.353718 37.764929) (xy 67.086271 37.497482) (xy 66.792334 37.259456) (xy 66.475126 37.053459) (xy 66.472192 37.051964) (xy 66.472185 37.05196) (xy 66.141063 36.883245) (xy 66.138123 36.881747) (xy 65.785018 36.746203) (xy 65.419679 36.648311) (xy 65.221242 36.616882) (xy 65.049357 36.589657) (xy 65.049349 36.589656) (xy 65.046109 36.589143) (xy 64.6684 36.569348) (xy 64.290691 36.589143) (xy 64.287451 36.589656) (xy 64.287443 36.589657) (xy 64.115558 36.616882) (xy 63.917121 36.648311) (xy 63.551782 36.746203) (xy 63.198677 36.881747) (xy 63.195737 36.883245) (xy 62.864615 37.05196) (xy 62.864608 37.051964) (xy 62.861674 37.053459) (xy 62.544466 37.259456) (xy 62.250529 37.497482) (xy 61.983082 37.764929) (xy 61.745056 38.058866) (xy 61.539059 38.376074) (xy 61.367347 38.713077) (xy 61.231803 39.066182) (xy 61.133911 39.431521) (xy 61.074743 39.805091) (xy 61.054948 40.1828) (xy 57.8863 40.1828) (xy 57.8863 33.7045) (xy 57.906302 33.636379) (xy 57.959958 33.589886) (xy 58.0123 33.5785) (xy 85.0913 33.5785) ) ) ) (zone (net 0) (net_name "") (layer "F.Cu") (tstamp b8307675-1159-4dc3-ba86-ebebd225ddc3) (hatch edge 0.508) (connect_pads (clearance 0.508)) (min_thickness 0.254) (filled_areas_thickness no) (fill yes (thermal_gap 0.508) (thermal_bridge_width 0.508)) (polygon (pts (xy 56.1086 47.743584) (xy 43.6626 47.743584) (xy 43.688 33.290984) (xy 56.1086 33.290984) ) ) (filled_polygon (layer "F.Cu") (island) (pts (xy 55.746221 33.623902) (xy 55.792714 33.677558) (xy 55.8041 33.7299) (xy 55.8041 47.0675) (xy 55.784098 47.135621) (xy 55.730442 47.182114) (xy 55.6781 47.1935) (xy 43.789789 47.1935) (xy 43.721668 47.173498) (xy 43.675175 47.119842) (xy 43.663789 47.067279) (xy 43.675933 40.1574) (xy 45.484748 40.1574) (xy 45.504543 40.535109) (xy 45.563711 40.908679) (xy 45.661603 41.274018) (xy 45.797147 41.627123) (xy 45.968859 41.964126) (xy 46.174856 42.281334) (xy 46.412882 42.575271) (xy 46.680329 42.842718) (xy 46.974266 43.080744) (xy 47.291474 43.286741) (xy 47.294408 43.288236) (xy 47.294415 43.28824) (xy 47.625537 43.456955) (xy 47.628477 43.458453) (xy 47.981582 43.593997) (xy 48.346921 43.691889) (xy 48.545358 43.723318) (xy 48.717243 43.750543) (xy 48.717251 43.750544) (xy 48.720491 43.751057) (xy 49.0982 43.770852) (xy 49.475909 43.751057) (xy 49.479149 43.750544) (xy 49.479157 43.750543) (xy 49.651042 43.723318) (xy 49.849479 43.691889) (xy 50.214818 43.593997) (xy 50.567923 43.458453) (xy 50.570863 43.456955) (xy 50.901985 43.28824) (xy 50.901992 43.288236) (xy 50.904926 43.286741) (xy 51.222134 43.080744) (xy 51.516071 42.842718) (xy 51.783518 42.575271) (xy 52.021544 42.281334) (xy 52.227541 41.964126) (xy 52.399253 41.627123) (xy 52.534797 41.274018) (xy 52.632689 40.908679) (xy 52.691857 40.535109) (xy 52.711652 40.1574) (xy 52.691857 39.779691) (xy 52.632689 39.406121) (xy 52.534797 39.040782) (xy 52.399253 38.687677) (xy 52.227541 38.350674) (xy 52.021544 38.033466) (xy 51.783518 37.739529) (xy 51.516071 37.472082) (xy 51.222134 37.234056) (xy 50.904926 37.028059) (xy 50.901992 37.026564) (xy 50.901985 37.02656) (xy 50.570863 36.857845) (xy 50.567923 36.856347) (xy 50.214818 36.720803) (xy 49.849479 36.622911) (xy 49.651042 36.591482) (xy 49.479157 36.564257) (xy 49.479149 36.564256) (xy 49.475909 36.563743) (xy 49.0982 36.543948) (xy 48.720491 36.563743) (xy 48.717251 36.564256) (xy 48.717243 36.564257) (xy 48.545358 36.591482) (xy 48.346921 36.622911) (xy 47.981582 36.720803) (xy 47.628477 36.856347) (xy 47.625537 36.857845) (xy 47.294415 37.02656) (xy 47.294408 37.026564) (xy 47.291474 37.028059) (xy 46.974266 37.234056) (xy 46.680329 37.472082) (xy 46.412882 37.739529) (xy 46.174856 38.033466) (xy 45.968859 38.350674) (xy 45.797147 38.687677) (xy 45.661603 39.040782) (xy 45.563711 39.406121) (xy 45.504543 39.779691) (xy 45.484748 40.1574) (xy 43.675933 40.1574) (xy 43.687229 33.729679) (xy 43.707351 33.661593) (xy 43.761088 33.615195) (xy 43.813229 33.6039) (xy 55.6781 33.6039) ) ) ) (zone (net 0) (net_name "") (layer "F.Cu") (tstamp b84c0b42-33d1-475d-8768-23271d706145) (hatch edge 0.508) (connect_pads (clearance 0.508)) (min_thickness 0.254) (filled_areas_thickness no) (fill yes (thermal_gap 0.508) (thermal_bridge_width 0.508)) (polygon (pts (xy 56.1086 79.366584) (xy 43.6626 79.366584) (xy 43.688 64.913984) (xy 56.1086 64.913984) ) ) (filled_polygon (layer "F.Cu") (island) (pts (xy 55.746221 65.246902) (xy 55.792714 65.300558) (xy 55.8041 65.3529) (xy 55.8041 78.6905) (xy 55.784098 78.758621) (xy 55.730442 78.805114) (xy 55.6781 78.8165) (xy 43.789789 78.8165) (xy 43.721668 78.796498) (xy 43.675175 78.742842) (xy 43.663789 78.690279) (xy 43.675933 71.7804) (xy 45.484748 71.7804) (xy 45.504543 72.158109) (xy 45.563711 72.531679) (xy 45.661603 72.897018) (xy 45.797147 73.250123) (xy 45.968859 73.587126) (xy 46.174856 73.904334) (xy 46.412882 74.198271) (xy 46.680329 74.465718) (xy 46.974266 74.703744) (xy 47.291474 74.909741) (xy 47.294408 74.911236) (xy 47.294415 74.91124) (xy 47.625537 75.079955) (xy 47.628477 75.081453) (xy 47.981582 75.216997) (xy 48.346921 75.314889) (xy 48.545358 75.346318) (xy 48.717243 75.373543) (xy 48.717251 75.373544) (xy 48.720491 75.374057) (xy 49.0982 75.393852) (xy 49.475909 75.374057) (xy 49.479149 75.373544) (xy 49.479157 75.373543) (xy 49.651042 75.346318) (xy 49.849479 75.314889) (xy 50.214818 75.216997) (xy 50.567923 75.081453) (xy 50.570863 75.079955) (xy 50.901985 74.91124) (xy 50.901992 74.911236) (xy 50.904926 74.909741) (xy 51.222134 74.703744) (xy 51.516071 74.465718) (xy 51.783518 74.198271) (xy 52.021544 73.904334) (xy 52.227541 73.587126) (xy 52.399253 73.250123) (xy 52.534797 72.897018) (xy 52.632689 72.531679) (xy 52.691857 72.158109) (xy 52.711652 71.7804) (xy 52.691857 71.402691) (xy 52.632689 71.029121) (xy 52.534797 70.663782) (xy 52.399253 70.310677) (xy 52.227541 69.973674) (xy 52.021544 69.656466) (xy 51.783518 69.362529) (xy 51.516071 69.095082) (xy 51.222134 68.857056) (xy 50.904926 68.651059) (xy 50.901992 68.649564) (xy 50.901985 68.64956) (xy 50.570863 68.480845) (xy 50.567923 68.479347) (xy 50.214818 68.343803) (xy 49.849479 68.245911) (xy 49.651042 68.214482) (xy 49.479157 68.187257) (xy 49.479149 68.187256) (xy 49.475909 68.186743) (xy 49.0982 68.166948) (xy 48.720491 68.186743) (xy 48.717251 68.187256) (xy 48.717243 68.187257) (xy 48.545358 68.214482) (xy 48.346921 68.245911) (xy 47.981582 68.343803) (xy 47.628477 68.479347) (xy 47.625537 68.480845) (xy 47.294415 68.64956) (xy 47.294408 68.649564) (xy 47.291474 68.651059) (xy 46.974266 68.857056) (xy 46.680329 69.095082) (xy 46.412882 69.362529) (xy 46.174856 69.656466) (xy 45.968859 69.973674) (xy 45.797147 70.310677) (xy 45.661603 70.663782) (xy 45.563711 71.029121) (xy 45.504543 71.402691) (xy 45.484748 71.7804) (xy 43.675933 71.7804) (xy 43.687229 65.352679) (xy 43.707351 65.284593) (xy 43.761088 65.238195) (xy 43.813229 65.2269) (xy 55.6781 65.2269) ) ) ) (zone (net 0) (net_name "") (layer "F.Cu") (tstamp c3ae2558-ce64-4435-a5c7-61a4798e127e) (hatch edge 0.508) (connect_pads (clearance 0.508)) (min_thickness 0.254) (filled_areas_thickness no) (fill yes (thermal_gap 0.508) (thermal_bridge_width 0.508)) (polygon (pts (xy 56.101204 63.490903) (xy 43.655204 63.490903) (xy 43.680604 49.038303) (xy 56.101204 49.038303) ) ) (filled_polygon (layer "F.Cu") (island) (pts (xy 55.738825 49.371221) (xy 55.785318 49.424877) (xy 55.796704 49.477219) (xy 55.796704 62.814819) (xy 55.776702 62.88294) (xy 55.723046 62.929433) (xy 55.670704 62.940819) (xy 43.782393 62.940819) (xy 43.714272 62.920817) (xy 43.667779 62.867161) (xy 43.656393 62.814598) (xy 43.668537 55.904719) (xy 45.477352 55.904719) (xy 45.497147 56.282428) (xy 45.556315 56.655998) (xy 45.654207 57.021337) (xy 45.789751 57.374442) (xy 45.961463 57.711445) (xy 46.16746 58.028653) (xy 46.405486 58.32259) (xy 46.672933 58.590037) (xy 46.96687 58.828063) (xy 47.284078 59.03406) (xy 47.287012 59.035555) (xy 47.287019 59.035559) (xy 47.618141 59.204274) (xy 47.621081 59.205772) (xy 47.974186 59.341316) (xy 48.339525 59.439208) (xy 48.537962 59.470637) (xy 48.709847 59.497862) (xy 48.709855 59.497863) (xy 48.713095 59.498376) (xy 49.090804 59.518171) (xy 49.468513 59.498376) (xy 49.471753 59.497863) (xy 49.471761 59.497862) (xy 49.643646 59.470637) (xy 49.842083 59.439208) (xy 50.207422 59.341316) (xy 50.560527 59.205772) (xy 50.563467 59.204274) (xy 50.894589 59.035559) (xy 50.894596 59.035555) (xy 50.89753 59.03406) (xy 51.214738 58.828063) (xy 51.508675 58.590037) (xy 51.776122 58.32259) (xy 52.014148 58.028653) (xy 52.220145 57.711445) (xy 52.391857 57.374442) (xy 52.527401 57.021337) (xy 52.625293 56.655998) (xy 52.684461 56.282428) (xy 52.704256 55.904719) (xy 52.684461 55.52701) (xy 52.625293 55.15344) (xy 52.527401 54.788101) (xy 52.391857 54.434996) (xy 52.220145 54.097993) (xy 52.014148 53.780785) (xy 51.776122 53.486848) (xy 51.508675 53.219401) (xy 51.214738 52.981375) (xy 50.89753 52.775378) (xy 50.894596 52.773883) (xy 50.894589 52.773879) (xy 50.563467 52.605164) (xy 50.560527 52.603666) (xy 50.207422 52.468122) (xy 49.842083 52.37023) (xy 49.643646 52.338801) (xy 49.471761 52.311576) (xy 49.471753 52.311575) (xy 49.468513 52.311062) (xy 49.090804 52.291267) (xy 48.713095 52.311062) (xy 48.709855 52.311575) (xy 48.709847 52.311576) (xy 48.537962 52.338801) (xy 48.339525 52.37023) (xy 47.974186 52.468122) (xy 47.621081 52.603666) (xy 47.618141 52.605164) (xy 47.287019 52.773879) (xy 47.287012 52.773883) (xy 47.284078 52.775378) (xy 46.96687 52.981375) (xy 46.672933 53.219401) (xy 46.405486 53.486848) (xy 46.16746 53.780785) (xy 45.961463 54.097993) (xy 45.789751 54.434996) (xy 45.654207 54.788101) (xy 45.556315 55.15344) (xy 45.497147 55.52701) (xy 45.477352 55.904719) (xy 43.668537 55.904719) (xy 43.679833 49.476998) (xy 43.699955 49.408912) (xy 43.753692 49.362514) (xy 43.805833 49.351219) (xy 55.670704 49.351219) ) ) ) (zone (net 0) (net_name "") (layer "F.Cu") (tstamp c79c6224-56f6-432f-88b2-ece1198842e0) (hatch edge 0.508) (connect_pads (clearance 0.508)) (min_thickness 0.254) (filled_areas_thickness no) (fill yes (thermal_gap 0.508) (thermal_bridge_width 0.508)) (polygon (pts (xy 85.565204 63.473919) (xy 57.574404 63.473919) (xy 57.599804 48.995919) (xy 85.565204 48.995919) ) ) (filled_polygon (layer "F.Cu") (island) (pts (xy 85.152025 49.345821) (xy 85.198518 49.399477) (xy 85.209904 49.451819) (xy 85.209904 62.789419) (xy 85.189902 62.85754) (xy 85.136246 62.904033) (xy 85.083904 62.915419) (xy 58.004904 62.915419) (xy 57.936783 62.895417) (xy 57.89029 62.841761) (xy 57.878904 62.789419) (xy 57.878904 55.930119) (xy 61.047552 55.930119) (xy 61.067347 56.307828) (xy 61.126515 56.681398) (xy 61.224407 57.046737) (xy 61.359951 57.399842) (xy 61.361449 57.402782) (xy 61.504281 57.683104) (xy 61.531663 57.736845) (xy 61.73766 58.054053) (xy 61.975686 58.34799) (xy 62.243133 58.615437) (xy 62.53707 58.853463) (xy 62.854278 59.05946) (xy 62.857212 59.060955) (xy 62.857219 59.060959) (xy 63.093904 59.181556) (xy 63.191281 59.231172) (xy 63.544386 59.366716) (xy 63.909725 59.464608) (xy 64.108162 59.496037) (xy 64.280047 59.523262) (xy 64.280055 59.523263) (xy 64.283295 59.523776) (xy 64.661004 59.543571) (xy 65.038713 59.523776) (xy 65.041953 59.523263) (xy 65.041961 59.523262) (xy 65.213846 59.496037) (xy 65.412283 59.464608) (xy 65.777622 59.366716) (xy 66.130727 59.231172) (xy 66.228104 59.181556) (xy 66.464789 59.060959) (xy 66.464796 59.060955) (xy 66.46773 59.05946) (xy 66.784938 58.853463) (xy 67.078875 58.615437) (xy 67.346322 58.34799) (xy 67.584348 58.054053) (xy 67.790345 57.736845) (xy 67.817728 57.683104) (xy 67.960559 57.402782) (xy 67.962057 57.399842) (xy 68.097601 57.046737) (xy 68.195493 56.681398) (xy 68.254661 56.307828) (xy 68.274456 55.930119) (xy 68.271794 55.879319) (xy 74.890552 55.879319) (xy 74.910347 56.257028) (xy 74.969515 56.630598) (xy 75.067407 56.995937) (xy 75.202951 57.349042) (xy 75.374663 57.686045) (xy 75.58066 58.003253) (xy 75.818686 58.29719) (xy 76.086133 58.564637) (xy 76.38007 58.802663) (xy 76.697278 59.00866) (xy 76.700212 59.010155) (xy 76.700219 59.010159) (xy 76.796978 59.05946) (xy 77.034281 59.180372) (xy 77.387386 59.315916) (xy 77.752725 59.413808) (xy 77.951162 59.445237) (xy 78.123047 59.472462) (xy 78.123055 59.472463) (xy 78.126295 59.472976) (xy 78.504004 59.492771) (xy 78.881713 59.472976) (xy 78.884953 59.472463) (xy 78.884961 59.472462) (xy 79.056846 59.445237) (xy 79.255283 59.413808) (xy 79.620622 59.315916) (xy 79.973727 59.180372) (xy 80.21103 59.05946) (xy 80.307789 59.010159) (xy 80.307796 59.010155) (xy 80.31073 59.00866) (xy 80.627938 58.802663) (xy 80.921875 58.564637) (xy 81.189322 58.29719) (xy 81.427348 58.003253) (xy 81.633345 57.686045) (xy 81.805057 57.349042) (xy 81.940601 56.995937) (xy 82.038493 56.630598) (xy 82.097661 56.257028) (xy 82.117456 55.879319) (xy 82.097661 55.50161) (xy 82.038493 55.12804) (xy 81.940601 54.762701) (xy 81.805057 54.409596) (xy 81.803559 54.406656) (xy 81.634844 54.075534) (xy 81.63484 54.075527) (xy 81.633345 54.072593) (xy 81.427348 53.755385) (xy 81.189322 53.461448) (xy 80.921875 53.194001) (xy 80.627938 52.955975) (xy 80.31073 52.749978) (xy 80.307796 52.748483) (xy 80.307789 52.748479) (xy 79.976667 52.579764) (xy 79.973727 52.578266) (xy 79.620622 52.442722) (xy 79.255283 52.34483) (xy 79.056846 52.313401) (xy 78.884961 52.286176) (xy 78.884953 52.286175) (xy 78.881713 52.285662) (xy 78.504004 52.265867) (xy 78.126295 52.285662) (xy 78.123055 52.286175) (xy 78.123047 52.286176) (xy 77.951162 52.313401) (xy 77.752725 52.34483) (xy 77.387386 52.442722) (xy 77.034281 52.578266) (xy 77.031341 52.579764) (xy 76.700219 52.748479) (xy 76.700212 52.748483) (xy 76.697278 52.749978) (xy 76.38007 52.955975) (xy 76.086133 53.194001) (xy 75.818686 53.461448) (xy 75.58066 53.755385) (xy 75.374663 54.072593) (xy 75.373168 54.075527) (xy 75.373164 54.075534) (xy 75.204449 54.406656) (xy 75.202951 54.409596) (xy 75.067407 54.762701) (xy 74.969515 55.12804) (xy 74.910347 55.50161) (xy 74.890552 55.879319) (xy 68.271794 55.879319) (xy 68.254661 55.55241) (xy 68.195493 55.17884) (xy 68.097601 54.813501) (xy 67.962057 54.460396) (xy 67.790345 54.123393) (xy 67.584348 53.806185) (xy 67.346322 53.512248) (xy 67.078875 53.244801) (xy 66.784938 53.006775) (xy 66.46773 52.800778) (xy 66.464796 52.799283) (xy 66.464789 52.799279) (xy 66.133667 52.630564) (xy 66.130727 52.629066) (xy 65.777622 52.493522) (xy 65.412283 52.39563) (xy 65.213846 52.364201) (xy 65.041961 52.336976) (xy 65.041953 52.336975) (xy 65.038713 52.336462) (xy 64.661004 52.316667) (xy 64.283295 52.336462) (xy 64.280055 52.336975) (xy 64.280047 52.336976) (xy 64.108162 52.364201) (xy 63.909725 52.39563) (xy 63.544386 52.493522) (xy 63.191281 52.629066) (xy 63.188341 52.630564) (xy 62.857219 52.799279) (xy 62.857212 52.799283) (xy 62.854278 52.800778) (xy 62.53707 53.006775) (xy 62.243133 53.244801) (xy 61.975686 53.512248) (xy 61.73766 53.806185) (xy 61.531663 54.123393) (xy 61.359951 54.460396) (xy 61.224407 54.813501) (xy 61.126515 55.17884) (xy 61.067347 55.55241) (xy 61.047552 55.930119) (xy 57.878904 55.930119) (xy 57.878904 49.451819) (xy 57.898906 49.383698) (xy 57.952562 49.337205) (xy 58.004904 49.325819) (xy 85.083904 49.325819) ) ) ) (zone (net 0) (net_name "") (layer "F.Cu") (tstamp d276a4a7-b9ee-455c-9717-6004e70fb0aa) (hatch edge 0.508) (connect_pads (clearance 0.508)) (min_thickness 0.254) (filled_areas_thickness no) (fill yes (thermal_gap 0.508) (thermal_bridge_width 0.508)) (polygon (pts (xy 85.5726 79.3496) (xy 57.5818 79.3496) (xy 57.6072 64.8716) (xy 85.5726 64.8716) ) ) (filled_polygon (layer "F.Cu") (island) (pts (xy 85.159421 65.221502) (xy 85.205914 65.275158) (xy 85.2173 65.3275) (xy 85.2173 78.6651) (xy 85.197298 78.733221) (xy 85.143642 78.779714) (xy 85.0913 78.7911) (xy 58.0123 78.7911) (xy 57.944179 78.771098) (xy 57.897686 78.717442) (xy 57.8863 78.6651) (xy 57.8863 71.8058) (xy 61.054948 71.8058) (xy 61.074743 72.183509) (xy 61.133911 72.557079) (xy 61.231803 72.922418) (xy 61.367347 73.275523) (xy 61.368845 73.278463) (xy 61.511677 73.558785) (xy 61.539059 73.612526) (xy 61.745056 73.929734) (xy 61.983082 74.223671) (xy 62.250529 74.491118) (xy 62.544466 74.729144) (xy 62.861674 74.935141) (xy 62.864608 74.936636) (xy 62.864615 74.93664) (xy 63.1013 75.057237) (xy 63.198677 75.106853) (xy 63.551782 75.242397) (xy 63.917121 75.340289) (xy 64.115558 75.371718) (xy 64.287443 75.398943) (xy 64.287451 75.398944) (xy 64.290691 75.399457) (xy 64.6684 75.419252) (xy 65.046109 75.399457) (xy 65.049349 75.398944) (xy 65.049357 75.398943) (xy 65.221242 75.371718) (xy 65.419679 75.340289) (xy 65.785018 75.242397) (xy 66.138123 75.106853) (xy 66.2355 75.057237) (xy 66.472185 74.93664) (xy 66.472192 74.936636) (xy 66.475126 74.935141) (xy 66.792334 74.729144) (xy 67.086271 74.491118) (xy 67.353718 74.223671) (xy 67.591744 73.929734) (xy 67.797741 73.612526) (xy 67.825124 73.558785) (xy 67.967955 73.278463) (xy 67.969453 73.275523) (xy 68.104997 72.922418) (xy 68.202889 72.557079) (xy 68.262057 72.183509) (xy 68.281852 71.8058) (xy 68.27919 71.755) (xy 74.897948 71.755) (xy 74.917743 72.132709) (xy 74.976911 72.506279) (xy 75.074803 72.871618) (xy 75.210347 73.224723) (xy 75.382059 73.561726) (xy 75.588056 73.878934) (xy 75.826082 74.172871) (xy 76.093529 74.440318) (xy 76.387466 74.678344) (xy 76.704674 74.884341) (xy 76.707608 74.885836) (xy 76.707615 74.88584) (xy 76.804374 74.935141) (xy 77.041677 75.056053) (xy 77.394782 75.191597) (xy 77.760121 75.289489) (xy 77.958558 75.320918) (xy 78.130443 75.348143) (xy 78.130451 75.348144) (xy 78.133691 75.348657) (xy 78.5114 75.368452) (xy 78.889109 75.348657) (xy 78.892349 75.348144) (xy 78.892357 75.348143) (xy 79.064242 75.320918) (xy 79.262679 75.289489) (xy 79.628018 75.191597) (xy 79.981123 75.056053) (xy 80.218426 74.935141) (xy 80.315185 74.88584) (xy 80.315192 74.885836) (xy 80.318126 74.884341) (xy 80.635334 74.678344) (xy 80.929271 74.440318) (xy 81.196718 74.172871) (xy 81.434744 73.878934) (xy 81.640741 73.561726) (xy 81.812453 73.224723) (xy 81.947997 72.871618) (xy 82.045889 72.506279) (xy 82.105057 72.132709) (xy 82.124852 71.755) (xy 82.105057 71.377291) (xy 82.045889 71.003721) (xy 81.947997 70.638382) (xy 81.812453 70.285277) (xy 81.810955 70.282337) (xy 81.64224 69.951215) (xy 81.642236 69.951208) (xy 81.640741 69.948274) (xy 81.434744 69.631066) (xy 81.196718 69.337129) (xy 80.929271 69.069682) (xy 80.635334 68.831656) (xy 80.318126 68.625659) (xy 80.315192 68.624164) (xy 80.315185 68.62416) (xy 79.984063 68.455445) (xy 79.981123 68.453947) (xy 79.628018 68.318403) (xy 79.262679 68.220511) (xy 79.064242 68.189082) (xy 78.892357 68.161857) (xy 78.892349 68.161856) (xy 78.889109 68.161343) (xy 78.5114 68.141548) (xy 78.133691 68.161343) (xy 78.130451 68.161856) (xy 78.130443 68.161857) (xy 77.958558 68.189082) (xy 77.760121 68.220511) (xy 77.394782 68.318403) (xy 77.041677 68.453947) (xy 77.038737 68.455445) (xy 76.707615 68.62416) (xy 76.707608 68.624164) (xy 76.704674 68.625659) (xy 76.387466 68.831656) (xy 76.093529 69.069682) (xy 75.826082 69.337129) (xy 75.588056 69.631066) (xy 75.382059 69.948274) (xy 75.380564 69.951208) (xy 75.38056 69.951215) (xy 75.211845 70.282337) (xy 75.210347 70.285277) (xy 75.074803 70.638382) (xy 74.976911 71.003721) (xy 74.917743 71.377291) (xy 74.897948 71.755) (xy 68.27919 71.755) (xy 68.262057 71.428091) (xy 68.202889 71.054521) (xy 68.104997 70.689182) (xy 67.969453 70.336077) (xy 67.797741 69.999074) (xy 67.591744 69.681866) (xy 67.353718 69.387929) (xy 67.086271 69.120482) (xy 66.792334 68.882456) (xy 66.475126 68.676459) (xy 66.472192 68.674964) (xy 66.472185 68.67496) (xy 66.141063 68.506245) (xy 66.138123 68.504747) (xy 65.785018 68.369203) (xy 65.419679 68.271311) (xy 65.221242 68.239882) (xy 65.049357 68.212657) (xy 65.049349 68.212656) (xy 65.046109 68.212143) (xy 64.6684 68.192348) (xy 64.290691 68.212143) (xy 64.287451 68.212656) (xy 64.287443 68.212657) (xy 64.115558 68.239882) (xy 63.917121 68.271311) (xy 63.551782 68.369203) (xy 63.198677 68.504747) (xy 63.195737 68.506245) (xy 62.864615 68.67496) (xy 62.864608 68.674964) (xy 62.861674 68.676459) (xy 62.544466 68.882456) (xy 62.250529 69.120482) (xy 61.983082 69.387929) (xy 61.745056 69.681866) (xy 61.539059 69.999074) (xy 61.367347 70.336077) (xy 61.231803 70.689182) (xy 61.133911 71.054521) (xy 61.074743 71.428091) (xy 61.054948 71.8058) (xy 57.8863 71.8058) (xy 57.8863 65.3275) (xy 57.906302 65.259379) (xy 57.959958 65.212886) (xy 58.0123 65.2015) (xy 85.0913 65.2015) ) ) ) (zone (net 0) (net_name "") (layer "F.Cu") (tstamp df33ef07-aacc-4a18-8218-b072058bc255) (hatch edge 0.508) (connect_pads (clearance 0.508)) (min_thickness 0.254) (filled_areas_thickness no) (fill yes (thermal_gap 0.508) (thermal_bridge_width 0.508)) (polygon (pts (xy 40.6146 47.752) (xy 28.1686 47.752) (xy 28.194 33.274) (xy 40.6146 33.274) ) ) (filled_polygon (layer "F.Cu") (island) (pts (xy 40.556721 33.623902) (xy 40.603214 33.677558) (xy 40.6146 33.7299) (xy 40.6146 47.0675) (xy 40.594598 47.135621) (xy 40.540942 47.182114) (xy 40.4886 47.1935) (xy 28.5991 47.1935) (xy 28.530979 47.173498) (xy 28.484486 47.119842) (xy 28.4731 47.0675) (xy 28.4731 40.2082) (xy 31.641748 40.2082) (xy 31.661543 40.585909) (xy 31.720711 40.959479) (xy 31.818603 41.324818) (xy 31.954147 41.677923) (xy 32.125859 42.014926) (xy 32.331856 42.332134) (xy 32.569882 42.626071) (xy 32.837329 42.893518) (xy 33.131266 43.131544) (xy 33.448474 43.337541) (xy 33.451408 43.339036) (xy 33.451415 43.33904) (xy 33.782537 43.507755) (xy 33.785477 43.509253) (xy 34.138582 43.644797) (xy 34.503921 43.742689) (xy 34.702358 43.774118) (xy 34.874243 43.801343) (xy 34.874251 43.801344) (xy 34.877491 43.801857) (xy 35.2552 43.821652) (xy 35.632909 43.801857) (xy 35.636149 43.801344) (xy 35.636157 43.801343) (xy 35.808042 43.774118) (xy 36.006479 43.742689) (xy 36.371818 43.644797) (xy 36.724923 43.509253) (xy 36.727863 43.507755) (xy 37.058985 43.33904) (xy 37.058992 43.339036) (xy 37.061926 43.337541) (xy 37.379134 43.131544) (xy 37.673071 42.893518) (xy 37.940518 42.626071) (xy 38.178544 42.332134) (xy 38.384541 42.014926) (xy 38.556253 41.677923) (xy 38.691797 41.324818) (xy 38.789689 40.959479) (xy 38.848857 40.585909) (xy 38.868652 40.2082) (xy 38.848857 39.830491) (xy 38.789689 39.456921) (xy 38.691797 39.091582) (xy 38.556253 38.738477) (xy 38.384541 38.401474) (xy 38.178544 38.084266) (xy 37.940518 37.790329) (xy 37.673071 37.522882) (xy 37.379134 37.284856) (xy 37.061926 37.078859) (xy 37.058992 37.077364) (xy 37.058985 37.07736) (xy 36.727863 36.908645) (xy 36.724923 36.907147) (xy 36.371818 36.771603) (xy 36.006479 36.673711) (xy 35.808042 36.642282) (xy 35.636157 36.615057) (xy 35.636149 36.615056) (xy 35.632909 36.614543) (xy 35.2552 36.594748) (xy 34.877491 36.614543) (xy 34.874251 36.615056) (xy 34.874243 36.615057) (xy 34.702358 36.642282) (xy 34.503921 36.673711) (xy 34.138582 36.771603) (xy 33.785477 36.907147) (xy 33.782537 36.908645) (xy 33.451415 37.07736) (xy 33.451408 37.077364) (xy 33.448474 37.078859) (xy 33.131266 37.284856) (xy 32.837329 37.522882) (xy 32.569882 37.790329) (xy 32.331856 38.084266) (xy 32.125859 38.401474) (xy 31.954147 38.738477) (xy 31.818603 39.091582) (xy 31.720711 39.456921) (xy 31.661543 39.830491) (xy 31.641748 40.2082) (xy 28.4731 40.2082) (xy 28.4731 33.7299) (xy 28.493102 33.661779) (xy 28.546758 33.615286) (xy 28.5991 33.6039) (xy 40.4886 33.6039) ) ) ) (zone (net 0) (net_name "") (layer "F.Cu") (tstamp f33a3b2f-c678-431f-b6b5-42e3c54de64b) (hatch edge 0.508) (connect_pads (clearance 0.508)) (min_thickness 0.254) (filled_areas_thickness no) (fill yes (thermal_gap 0.508) (thermal_bridge_width 0.508)) (polygon (pts (xy 99.695 95.6818) (xy 87.249 95.6818) (xy 87.2744 81.2038) (xy 99.695 81.2038) ) ) (filled_polygon (layer "F.Cu") (island) (pts (xy 99.637121 81.553702) (xy 99.683614 81.607358) (xy 99.695 81.6597) (xy 99.695 94.9973) (xy 99.674998 95.065421) (xy 99.621342 95.111914) (xy 99.569 95.1233) (xy 87.6795 95.1233) (xy 87.611379 95.103298) (xy 87.564886 95.049642) (xy 87.5535 94.9973) (xy 87.5535 88.138) (xy 90.722148 88.138) (xy 90.741943 88.515709) (xy 90.801111 88.889279) (xy 90.899003 89.254618) (xy 91.034547 89.607723) (xy 91.206259 89.944726) (xy 91.412256 90.261934) (xy 91.650282 90.555871) (xy 91.917729 90.823318) (xy 92.211666 91.061344) (xy 92.528874 91.267341) (xy 92.531808 91.268836) (xy 92.531815 91.26884) (xy 92.862937 91.437555) (xy 92.865877 91.439053) (xy 93.218982 91.574597) (xy 93.584321 91.672489) (xy 93.782758 91.703918) (xy 93.954643 91.731143) (xy 93.954651 91.731144) (xy 93.957891 91.731657) (xy 94.3356 91.751452) (xy 94.713309 91.731657) (xy 94.716549 91.731144) (xy 94.716557 91.731143) (xy 94.888442 91.703918) (xy 95.086879 91.672489) (xy 95.452218 91.574597) (xy 95.805323 91.439053) (xy 95.808263 91.437555) (xy 96.139385 91.26884) (xy 96.139392 91.268836) (xy 96.142326 91.267341) (xy 96.459534 91.061344) (xy 96.753471 90.823318) (xy 97.020918 90.555871) (xy 97.258944 90.261934) (xy 97.464941 89.944726) (xy 97.636653 89.607723) (xy 97.772197 89.254618) (xy 97.870089 88.889279) (xy 97.929257 88.515709) (xy 97.949052 88.138) (xy 97.929257 87.760291) (xy 97.870089 87.386721) (xy 97.772197 87.021382) (xy 97.636653 86.668277) (xy 97.464941 86.331274) (xy 97.258944 86.014066) (xy 97.020918 85.720129) (xy 96.753471 85.452682) (xy 96.459534 85.214656) (xy 96.142326 85.008659) (xy 96.139392 85.007164) (xy 96.139385 85.00716) (xy 95.808263 84.838445) (xy 95.805323 84.836947) (xy 95.452218 84.701403) (xy 95.086879 84.603511) (xy 94.888442 84.572082) (xy 94.716557 84.544857) (xy 94.716549 84.544856) (xy 94.713309 84.544343) (xy 94.3356 84.524548) (xy 93.957891 84.544343) (xy 93.954651 84.544856) (xy 93.954643 84.544857) (xy 93.782758 84.572082) (xy 93.584321 84.603511) (xy 93.218982 84.701403) (xy 92.865877 84.836947) (xy 92.862937 84.838445) (xy 92.531815 85.00716) (xy 92.531808 85.007164) (xy 92.528874 85.008659) (xy 92.211666 85.214656) (xy 91.917729 85.452682) (xy 91.650282 85.720129) (xy 91.412256 86.014066) (xy 91.206259 86.331274) (xy 91.034547 86.668277) (xy 90.899003 87.021382) (xy 90.801111 87.386721) (xy 90.741943 87.760291) (xy 90.722148 88.138) (xy 87.5535 88.138) (xy 87.5535 81.6597) (xy 87.573502 81.591579) (xy 87.627158 81.545086) (xy 87.6795 81.5337) (xy 99.569 81.5337) ) ) ) (zone (net 0) (net_name "") (layer "F.Cu") (tstamp f83d3583-a693-4a82-93ea-593759c9bdd7) (hatch edge 0.508) (connect_pads (clearance 0.508)) (min_thickness 0.254) (filled_areas_thickness no) (fill yes (thermal_gap 0.508) (thermal_bridge_width 0.508)) (polygon (pts (xy 144.653 79.3242) (xy 116.6622 79.3242) (xy 116.6876 64.8462) (xy 144.653 64.8462) ) ) (filled_polygon (layer "F.Cu") (island) (pts (xy 144.239821 65.196102) (xy 144.286314 65.249758) (xy 144.2977 65.3021) (xy 144.2977 78.6397) (xy 144.277698 78.707821) (xy 144.224042 78.754314) (xy 144.1717 78.7657) (xy 117.0927 78.7657) (xy 117.024579 78.745698) (xy 116.978086 78.692042) (xy 116.9667 78.6397) (xy 116.9667 71.7804) (xy 120.135348 71.7804) (xy 120.155143 72.158109) (xy 120.214311 72.531679) (xy 120.312203 72.897018) (xy 120.447747 73.250123) (xy 120.449245 73.253063) (xy 120.592077 73.533385) (xy 120.619459 73.587126) (xy 120.825456 73.904334) (xy 121.063482 74.198271) (xy 121.330929 74.465718) (xy 121.624866 74.703744) (xy 121.942074 74.909741) (xy 121.945008 74.911236) (xy 121.945015 74.91124) (xy 122.1817 75.031837) (xy 122.279077 75.081453) (xy 122.632182 75.216997) (xy 122.997521 75.314889) (xy 123.195958 75.346318) (xy 123.367843 75.373543) (xy 123.367851 75.373544) (xy 123.371091 75.374057) (xy 123.7488 75.393852) (xy 124.126509 75.374057) (xy 124.129749 75.373544) (xy 124.129757 75.373543) (xy 124.301642 75.346318) (xy 124.500079 75.314889) (xy 124.865418 75.216997) (xy 125.218523 75.081453) (xy 125.3159 75.031837) (xy 125.552585 74.91124) (xy 125.552592 74.911236) (xy 125.555526 74.909741) (xy 125.872734 74.703744) (xy 126.166671 74.465718) (xy 126.434118 74.198271) (xy 126.672144 73.904334) (xy 126.878141 73.587126) (xy 126.905524 73.533385) (xy 127.048355 73.253063) (xy 127.049853 73.250123) (xy 127.185397 72.897018) (xy 127.283289 72.531679) (xy 127.342457 72.158109) (xy 127.362252 71.7804) (xy 127.35959 71.7296) (xy 133.978348 71.7296) (xy 133.998143 72.107309) (xy 134.057311 72.480879) (xy 134.155203 72.846218) (xy 134.290747 73.199323) (xy 134.462459 73.536326) (xy 134.668456 73.853534) (xy 134.906482 74.147471) (xy 135.173929 74.414918) (xy 135.467866 74.652944) (xy 135.785074 74.858941) (xy 135.788008 74.860436) (xy 135.788015 74.86044) (xy 135.884774 74.909741) (xy 136.122077 75.030653) (xy 136.475182 75.166197) (xy 136.840521 75.264089) (xy 137.038958 75.295518) (xy 137.210843 75.322743) (xy 137.210851 75.322744) (xy 137.214091 75.323257) (xy 137.5918 75.343052) (xy 137.969509 75.323257) (xy 137.972749 75.322744) (xy 137.972757 75.322743) (xy 138.144642 75.295518) (xy 138.343079 75.264089) (xy 138.708418 75.166197) (xy 139.061523 75.030653) (xy 139.298826 74.909741) (xy 139.395585 74.86044) (xy 139.395592 74.860436) (xy 139.398526 74.858941) (xy 139.715734 74.652944) (xy 140.009671 74.414918) (xy 140.277118 74.147471) (xy 140.515144 73.853534) (xy 140.721141 73.536326) (xy 140.892853 73.199323) (xy 141.028397 72.846218) (xy 141.126289 72.480879) (xy 141.185457 72.107309) (xy 141.205252 71.7296) (xy 141.185457 71.351891) (xy 141.126289 70.978321) (xy 141.028397 70.612982) (xy 140.892853 70.259877) (xy 140.891355 70.256937) (xy 140.72264 69.925815) (xy 140.722636 69.925808) (xy 140.721141 69.922874) (xy 140.515144 69.605666) (xy 140.277118 69.311729) (xy 140.009671 69.044282) (xy 139.715734 68.806256) (xy 139.398526 68.600259) (xy 139.395592 68.598764) (xy 139.395585 68.59876) (xy 139.064463 68.430045) (xy 139.061523 68.428547) (xy 138.708418 68.293003) (xy 138.343079 68.195111) (xy 138.144642 68.163682) (xy 137.972757 68.136457) (xy 137.972749 68.136456) (xy 137.969509 68.135943) (xy 137.5918 68.116148) (xy 137.214091 68.135943) (xy 137.210851 68.136456) (xy 137.210843 68.136457) (xy 137.038958 68.163682) (xy 136.840521 68.195111) (xy 136.475182 68.293003) (xy 136.122077 68.428547) (xy 136.119137 68.430045) (xy 135.788015 68.59876) (xy 135.788008 68.598764) (xy 135.785074 68.600259) (xy 135.467866 68.806256) (xy 135.173929 69.044282) (xy 134.906482 69.311729) (xy 134.668456 69.605666) (xy 134.462459 69.922874) (xy 134.460964 69.925808) (xy 134.46096 69.925815) (xy 134.292245 70.256937) (xy 134.290747 70.259877) (xy 134.155203 70.612982) (xy 134.057311 70.978321) (xy 133.998143 71.351891) (xy 133.978348 71.7296) (xy 127.35959 71.7296) (xy 127.342457 71.402691) (xy 127.283289 71.029121) (xy 127.185397 70.663782) (xy 127.049853 70.310677) (xy 126.878141 69.973674) (xy 126.672144 69.656466) (xy 126.434118 69.362529) (xy 126.166671 69.095082) (xy 125.872734 68.857056) (xy 125.555526 68.651059) (xy 125.552592 68.649564) (xy 125.552585 68.64956) (xy 125.221463 68.480845) (xy 125.218523 68.479347) (xy 124.865418 68.343803) (xy 124.500079 68.245911) (xy 124.301642 68.214482) (xy 124.129757 68.187257) (xy 124.129749 68.187256) (xy 124.126509 68.186743) (xy 123.7488 68.166948) (xy 123.371091 68.186743) (xy 123.367851 68.187256) (xy 123.367843 68.187257) (xy 123.195958 68.214482) (xy 122.997521 68.245911) (xy 122.632182 68.343803) (xy 122.279077 68.479347) (xy 122.276137 68.480845) (xy 121.945015 68.64956) (xy 121.945008 68.649564) (xy 121.942074 68.651059) (xy 121.624866 68.857056) (xy 121.330929 69.095082) (xy 121.063482 69.362529) (xy 120.825456 69.656466) (xy 120.619459 69.973674) (xy 120.447747 70.310677) (xy 120.312203 70.663782) (xy 120.214311 71.029121) (xy 120.155143 71.402691) (xy 120.135348 71.7804) (xy 116.9667 71.7804) (xy 116.9667 65.3021) (xy 116.986702 65.233979) (xy 117.040358 65.187486) (xy 117.0927 65.1761) (xy 144.1717 65.1761) ) ) ) )
