(kicad_pcb (version 20211014) (generator pcbnew) (general (thickness 1.6) ) (paper "A4") (layers (0 "F.Cu" signal) (31 "B.Cu" signal) (32 "B.Adhes" user "B.Adhesive") (33 "F.Adhes" user "F.Adhesive") (34 "B.Paste" user) (35 "F.Paste" user) (36 "B.SilkS" user "B.Silkscreen") (37 "F.SilkS" user "F.Silkscreen") (38 "B.Mask" user) (39 "F.Mask" user) (40 "Dwgs.User" user "User.Drawings") (41 "Cmts.User" user "User.Comments") (42 "Eco1.User" user "User.Eco1") (43 "Eco2.User" user "User.Eco2") (44 "Edge.Cuts" user) (45 "Margin" user) (46 "B.CrtYd" user "B.Courtyard") (47 "F.CrtYd" user "F.Courtyard") (48 "B.Fab" user) (49 "F.Fab" user) (50 "User.1" user) (51 "User.2" user) (52 "User.3" user) (53 "User.4" user) (54 "User.5" user) (55 "User.6" user) (56 "User.7" user) (57 "User.8" user) (58 "User.9" user) ) (setup (pad_to_mask_clearance 0) (pcbplotparams (layerselection 0x00010fc_ffffffff) (disableapertmacros false) (usegerberextensions false) (usegerberattributes true) (usegerberadvancedattributes true) (creategerberjobfile true) (svguseinch false) (svgprecision 6) (excludeedgelayer true) (plotframeref false) (viasonmask false) (mode 1) (useauxorigin false) (hpglpennumber 1) (hpglpenspeed 20) (hpglpendiameter 15.000000) (dxfpolygonmode true) (dxfimperialunits true) (dxfusepcbnewfont true) (psnegative false) (psa4output false) (plotreference true) (plotvalue true) (plotinvisibletext false) (sketchpadsonfab false) (subtractmaskfromsilk false) (outputformat 1) (mirror false) (drillshape 1) (scaleselection 1) (outputdirectory "") ) ) (net 0 "") (footprint "MountingHole:MountingHole_6.4mm_M6_DIN965_Pad" (layer "F.Cu") (tedit 56D1B4CB) (tstamp 4e736cfe-07a4-4d72-8e88-52c5e3357027) (at 101.6 76.2) (descr "Mounting Hole 6.4mm, M6, DIN965") (tags "mounting hole 6.4mm m6 din965") (attr exclude_from_pos_files exclude_from_bom) (fp_text reference "REF**" (at 0 -6.5) (layer "F.SilkS") (effects (font (size 1 1) (thickness 0.15))) (tstamp 11f278d8-21f5-45b2-b4d1-a39236201ec6) ) (fp_text value "MountingHole_6.4mm_M6_DIN965_Pad" (at 0 6.5) (layer "F.Fab") (effects (font (size 1 1) (thickness 0.15))) (tstamp ddbcbe31-0b89-429f-85d1-84b841f3fc62) ) (fp_text user "${REFERENCE}" (at 0 0) (layer "F.Fab") (effects (font (size 1 1) (thickness 0.15))) (tstamp f8855770-33e0-4747-80c1-197190c931cc) ) (fp_circle (center 0 0) (end 5.5 0) (layer "Cmts.User") (width 0.15) (fill none) (tstamp a18ecac2-c75a-467c-b0ce-d180692aba6f)) (fp_circle (center 0 0) (end 5.75 0) (layer "F.CrtYd") (width 0.05) (fill none) (tstamp d4034127-020c-4306-b05e-c700a7257ada)) (pad "1" thru_hole circle (at 0 0) (size 11 11) (drill 6.4) (layers *.Cu *.Mask) (tstamp 1d5babe3-2e29-4ea6-9a47-f356ccb99d5b)) ) (gr_rect (start 76.2 50.8) (end 127 101.6) (layer "Dwgs.User") (width 0.1) (fill none) (tstamp 6e390ec4-b11c-4258-8503-75a63395e95a)) (gr_rect (start 76.2 50.8) (end 127 101.6) (layer "Edge.Cuts") (width 0.05) (fill none) (tstamp 9989fe07-4ba7-40b8-a6bd-33093c154e98)) (gr_rect (start 76.2 50.8) (end 127 101.6) (layer "Margin") (width 0.1) (fill none) (tstamp 8a917d29-5c34-4839-8d00-a94a97096660)) (zone (net 0) (net_name "") (layer "F.Cu") (tstamp 45408f9f-0442-456e-9bae-511f4eebf9b1) (hatch edge 0.508) (connect_pads (clearance 0.508)) (min_thickness 0.254) (filled_areas_thickness no) (fill yes (thermal_gap 0.508) (thermal_bridge_width 0.508)) (polygon (pts (xy 124.46 99.06) (xy 78.74 99.06) (xy 78.74 53.34) (xy 124.46 53.34) ) ) (filled_polygon (layer "F.Cu") (island) (pts (xy 124.402121 53.360002) (xy 124.448614 53.413658) (xy 124.46 53.466) (xy 124.46 98.934) (xy 124.439998 99.002121) (xy 124.386342 99.048614) (xy 124.334 99.06) (xy 78.866 99.06) (xy 78.797879 99.039998) (xy 78.751386 98.986342) (xy 78.74 98.934) (xy 78.74 76.137029) (xy 95.586953 76.137029) (xy 95.601271 76.619472) (xy 95.601548 76.621983) (xy 95.601549 76.621994) (xy 95.622327 76.810191) (xy 95.654235 77.099212) (xy 95.745503 77.57316) (xy 95.874487 78.038261) (xy 95.875356 78.040635) (xy 96.039486 78.489144) (xy 96.039491 78.489155) (xy 96.040356 78.49152) (xy 96.041411 78.493814) (xy 96.041414 78.493821) (xy 96.240977 78.927701) (xy 96.242042 78.930016) (xy 96.478245 79.350925) (xy 96.747443 79.751535) (xy 97.047903 80.129264) (xy 97.049633 80.131113) (xy 97.049641 80.131122) (xy 97.181569 80.272103) (xy 97.377689 80.481681) (xy 97.734676 80.806514) (xy 97.73667 80.808055) (xy 97.736677 80.808061) (xy 97.888825 80.925654) (xy 98.116564 81.101671) (xy 98.118678 81.103049) (xy 98.518774 81.363869) (xy 98.51878 81.363873) (xy 98.520893 81.36525) (xy 98.523115 81.366457) (xy 98.523121 81.36646) (xy 98.691908 81.458103) (xy 98.945059 81.595553) (xy 99.386328 81.791097) (xy 99.841859 81.950621) (xy 100.308716 82.073099) (xy 100.783891 82.15774) (xy 100.786397 82.157981) (xy 100.786402 82.157982) (xy 100.967875 82.175456) (xy 101.264324 82.204001) (xy 101.266859 82.204041) (xy 101.266862 82.204041) (xy 101.421979 82.206478) (xy 101.74692 82.211582) (xy 101.749439 82.211419) (xy 101.749443 82.211419) (xy 102.226035 82.180599) (xy 102.226038 82.180599) (xy 102.228569 82.180435) (xy 102.231072 82.18007) (xy 102.23108 82.180069) (xy 102.422789 82.152101) (xy 102.706169 82.110761) (xy 103.176642 82.003008) (xy 103.636959 81.857871) (xy 104.084153 81.676284) (xy 104.298053 81.568704) (xy 104.513095 81.460549) (xy 104.513102 81.460545) (xy 104.515343 81.459418) (xy 104.927752 81.208669) (xy 104.929786 81.207197) (xy 104.929793 81.207192) (xy 105.097284 81.085949) (xy 105.318723 80.925654) (xy 105.685737 80.612194) (xy 105.817646 80.479824) (xy 106.024642 80.272103) (xy 106.026429 80.27031) (xy 106.028067 80.268379) (xy 106.336974 79.90413) (xy 106.33698 79.904122) (xy 106.338606 79.902205) (xy 106.448382 79.749436) (xy 106.618781 79.512299) (xy 106.620255 79.510248) (xy 106.869562 79.096966) (xy 107.084922 78.665022) (xy 107.264947 78.217197) (xy 107.408476 77.756376) (xy 107.514586 77.28553) (xy 107.582593 76.80769) (xy 107.612058 76.325935) (xy 107.613377 76.2) (xy 107.594007 75.717734) (xy 107.536023 75.238574) (xy 107.535522 75.236112) (xy 107.53552 75.236099) (xy 107.440302 74.768092) (xy 107.439797 74.765608) (xy 107.305949 74.301883) (xy 107.135343 73.850386) (xy 106.929076 73.414026) (xy 106.82876 73.239571) (xy 106.689744 72.997813) (xy 106.689738 72.997803) (xy 106.688479 72.995614) (xy 106.4151 72.597845) (xy 106.110701 72.223282) (xy 105.777243 71.874339) (xy 105.730445 71.832643) (xy 105.418761 71.554943) (xy 105.418757 71.55494) (xy 105.416874 71.553262) (xy 105.366554 71.515205) (xy 105.033922 71.263637) (xy 105.03392 71.263636) (xy 105.031916 71.26212) (xy 104.624849 71.00279) (xy 104.622612 71.001606) (xy 104.622599 71.001598) (xy 104.200541 70.77813) (xy 104.200537 70.778128) (xy 104.198295 70.776941) (xy 103.755002 70.586029) (xy 103.297826 70.431283) (xy 102.829712 70.313701) (xy 102.827231 70.313286) (xy 102.827227 70.313285) (xy 102.670552 70.287067) (xy 102.353676 70.23404) (xy 101.872785 70.192813) (xy 101.615242 70.191465) (xy 101.392667 70.190299) (xy 101.392661 70.190299) (xy 101.390136 70.190286) (xy 101.239056 70.201646) (xy 100.911376 70.226284) (xy 100.911368 70.226285) (xy 100.90884 70.226475) (xy 100.431996 70.301147) (xy 99.962676 70.41382) (xy 99.960286 70.414601) (xy 99.960276 70.414604) (xy 99.506303 70.562986) (xy 99.506298 70.562988) (xy 99.503905 70.56377) (xy 99.276102 70.659062) (xy 99.060974 70.749052) (xy 99.060965 70.749056) (xy 99.058637 70.75003) (xy 98.629741 70.971399) (xy 98.219981 71.226453) (xy 97.831995 71.513547) (xy 97.468284 71.830833) (xy 97.13119 72.176265) (xy 96.822885 72.54762) (xy 96.821432 72.549687) (xy 96.82143 72.54969) (xy 96.644763 72.801062) (xy 96.545356 72.942504) (xy 96.544074 72.944681) (xy 96.544073 72.944682) (xy 96.512777 72.997813) (xy 96.30039 73.358374) (xy 96.299286 73.360647) (xy 96.299282 73.360655) (xy 96.090672 73.790269) (xy 96.090667 73.790281) (xy 96.089565 73.79255) (xy 95.91424 74.242236) (xy 95.775544 74.704534) (xy 95.674371 75.176466) (xy 95.611372 75.654992) (xy 95.611245 75.657506) (xy 95.611244 75.657513) (xy 95.608194 75.717734) (xy 95.586953 76.137029) (xy 78.74 76.137029) (xy 78.74 53.466) (xy 78.760002 53.397879) (xy 78.813658 53.351386) (xy 78.866 53.34) (xy 124.334 53.34) ) ) ) )
