// Beispiel 1 - struct mit Cpp17 statt Cpp20 // [c] struct Daten { int8_t dir; int32_t rel; }; Daten enc; void setup (void) { Serial.begin(9600); Serial.println(F("\nuC Reset")); Serial.println(enc.dir); Serial.println(enc.rel); } void loop (void) { } [/c] Arduino: 1.8.19 (Windows 10), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)" C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\arduino-builder -dump-prefs -logger=machine -hardware C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\hardware -hardware C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages -tools C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\tools-builder -tools C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\hardware\tools\avr -tools C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages -built-in-libraries C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\libraries -libraries C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\sketchbook\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -vid-pid=0403_6001 -ide-version=10819 -build-path C:\Users\Worker\AppData\Local\Temp\arduino_build_224437 -warnings=all -build-cache C:\Users\Worker\AppData\Local\Temp\arduino_cache_57850 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avr-gcc.path=C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\tools\avrdude\6.3.0-arduino17 -verbose C:\Users\Worker\Documents\Arduino\WorkSpace_ATmega2560\eigene_Test-Sketche\Compiler_Internal_Error\Compiler_Internal_Error.ino C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\arduino-builder -compile -logger=machine -hardware C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\hardware -hardware C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages -tools C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\tools-builder -tools C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\hardware\tools\avr -tools C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages -built-in-libraries C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\libraries -libraries C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\sketchbook\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -vid-pid=0403_6001 -ide-version=10819 -build-path C:\Users\Worker\AppData\Local\Temp\arduino_build_224437 -warnings=all -build-cache C:\Users\Worker\AppData\Local\Temp\arduino_cache_57850 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avr-gcc.path=C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\tools\avrdude\6.3.0-arduino17 -verbose C:\Users\Worker\Documents\Arduino\WorkSpace_ATmega2560\eigene_Test-Sketche\Compiler_Internal_Error\Compiler_Internal_Error.ino Using board 'mega' from platform in folder: C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6 Using core 'arduino' from platform in folder: C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6 Detecting libraries used... "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -w -v -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\sketch\\Compiler_Internal_Error.ino.cpp" -o nul Generating function prototypes... "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -w -v -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\sketch\\Compiler_Internal_Error.ino.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\preproc\\ctags_target_for_gcc_minus_e.cpp" Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/device-specs/specs-atmega2560 COLLECT_GCC=C:\avrToolchain\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single Supported LTO compression algorithms: zlib gcc version 12.2.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-w' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-flto' '-w' '-E' '-CC' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\preproc\ctags_target_for_gcc_minus_e.cpp' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\preproc\' c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/avr/12.2.0/cc1plus.exe -E -quiet -CC -v -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega -imultilib avr6 -iprefix c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/ -D__AVR_ATmega2560__ -D__AVR_DEVICE_NAME__=atmega2560 -D F_CPU=16000000L -D ARDUINO=10819 -D ARDUINO_AVR_MEGA2560 -D ARDUINO_ARCH_AVR C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\sketch\Compiler_Internal_Error.ino.cpp -o C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\preproc\ctags_target_for_gcc_minus_e.cpp -mn-flash=4 -mno-skip-bug -mdouble=32 -mlong-double=64 -mmcu=avr6 -std=gnu++17 -Wno-error=narrowing -Wall -Wextra -w -w -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -fno-sized-deallocation -g -fworking-directory -Os -mn-flash=4 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -dumpdir C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\preproc\ -dumpbase ctags_target_for_gcc_minus_e.cpp -dumpbase-ext .cpp ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/avr/avr6" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/avr/avr6" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/include c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/include-fixed c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include End of search list. COMPILER_PATH=c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/avr/12.2.0/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/avr6/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/lib/avr6/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/lib/ "C:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\preproc\\ctags_target_for_gcc_minus_e.cpp" COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-w' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-flto' '-w' '-E' '-CC' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\preproc\ctags_target_for_gcc_minus_e.cpp' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\preproc\ctags_target_for_gcc_minus_e.' Sketch wird kompiliert... "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -v -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\sketch\\Compiler_Internal_Error.ino.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\sketch\\Compiler_Internal_Error.ino.cpp.o" Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/device-specs/specs-atmega2560 COLLECT_GCC=C:\avrToolchain\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single Supported LTO compression algorithms: zlib gcc version 12.2.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\sketch\Compiler_Internal_Error.ino.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\sketch\' c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/avr/12.2.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega -imultilib avr6 -iprefix c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\sketch\Compiler_Internal_Error.ino.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\sketch\Compiler_Internal_Error.ino.cpp.o -D__AVR_ATmega2560__ -D__AVR_DEVICE_NAME__=atmega2560 -D F_CPU=16000000L -D ARDUINO=10819 -D ARDUINO_AVR_MEGA2560 -D ARDUINO_ARCH_AVR C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\sketch\Compiler_Internal_Error.ino.cpp -mn-flash=4 -mno-skip-bug -quiet -dumpdir C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\sketch\ -dumpbase Compiler_Internal_Error.ino.cpp.cpp -dumpbase-ext .cpp -mdouble=32 -mlong-double=64 -mmcu=avr6 -g -Os -Wno-error=narrowing -Wall -Wextra -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -fno-sized-deallocation -mn-flash=4 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\ccLMDRNa.s GNU C++17 (GCC) version 12.2.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.1, isl version isl-0.24-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/avr/avr6" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/avr/avr6" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/include c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/include-fixed c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 12.2.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.1, isl version isl-0.24-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d7ad23a6c302228c09124ad6813f1124 COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\sketch\Compiler_Internal_Error.ino.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\sketch\' c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega --gdwarf-5 -mmcu=avr6 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\sketch\Compiler_Internal_Error.ino.cpp.o C:\Users\Worker\AppData\Local\Temp\ccLMDRNa.s GNU assembler version 2.39 (avr) using BFD version (GNU Binutils) 2.39 COMPILER_PATH=c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/avr/12.2.0/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/bin/ Compiling libraries... Compiling core... LIBRARY_PATH=c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/avr6/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/lib/avr6/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/lib/ "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-gcc" -c -g -x assembler-with-cpp -flto -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\wiring_pulse.S" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\wiring_pulse.S.o" COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\sketch\Compiler_Internal_Error.ino.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\sketch\Compiler_Internal_Error.ino.cpp.' "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\WInterrupts.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\WInterrupts.c.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\wiring.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\wiring.c.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\wiring_analog.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\wiring_analog.c.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\wiring_digital.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\wiring_digital.c.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\wiring_pulse.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\wiring_pulse.c.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\wiring_shift.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\wiring_shift.c.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\hooks.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\hooks.c.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -v -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\HardwareSerial3.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\HardwareSerial3.cpp.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -v -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\HardwareSerial0.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\HardwareSerial0.cpp.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -v -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\CDC.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\CDC.cpp.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -v -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\WMath.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\WMath.cpp.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -v -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\IPAddress.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\IPAddress.cpp.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -v -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\USBCore.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\USBCore.cpp.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -v -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\WString.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\WString.cpp.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -v -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\PluggableUSB.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\PluggableUSB.cpp.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -v -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\Print.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\Print.cpp.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -v -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\Tone.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\Tone.cpp.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -v -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\HardwareSerial.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\HardwareSerial.cpp.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -v -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\main.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\main.cpp.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -v -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\HardwareSerial1.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\HardwareSerial1.cpp.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -v -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\HardwareSerial2.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\HardwareSerial2.cpp.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -v -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\Stream.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\Stream.cpp.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -v -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\abi.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\abi.cpp.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -v -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Arduino IDE Portable\\Mega2560\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\new.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\new.cpp.o" Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/device-specs/specs-atmega2560 COLLECT_GCC=C:\avrToolchain\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single Supported LTO compression algorithms: zlib gcc version 12.2.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\HardwareSerial3.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\' c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/avr/12.2.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega -imultilib avr6 -iprefix c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\HardwareSerial3.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\HardwareSerial3.cpp.o -D__AVR_ATmega2560__ -D__AVR_DEVICE_NAME__=atmega2560 -D F_CPU=16000000L -D ARDUINO=10819 -D ARDUINO_AVR_MEGA2560 -D ARDUINO_ARCH_AVR C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino\HardwareSerial3.cpp -mn-flash=4 -mno-skip-bug -quiet -dumpdir C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\ -dumpbase HardwareSerial3.cpp.cpp -dumpbase-ext .cpp -mdouble=32 -mlong-double=64 -mmcu=avr6 -g -Os -Wno-error=narrowing -Wall -Wextra -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -fno-sized-deallocation -mn-flash=4 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\ccO3VX1c.s Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/device-specs/specs-atmega2560 COLLECT_GCC=C:\avrToolchain\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single Supported LTO compression algorithms: zlib gcc version 12.2.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\CDC.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\' c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/avr/12.2.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega -imultilib avr6 -iprefix c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\CDC.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\CDC.cpp.o -D__AVR_ATmega2560__ -D__AVR_DEVICE_NAME__=atmega2560 -D F_CPU=16000000L -D ARDUINO=10819 -D ARDUINO_AVR_MEGA2560 -D ARDUINO_ARCH_AVR C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino\CDC.cpp -mn-flash=4 -mno-skip-bug -quiet -dumpdir C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\ -dumpbase CDC.cpp.cpp -dumpbase-ext .cpp -mdouble=32 -mlong-double=64 -mmcu=avr6 -g -Os -Wno-error=narrowing -Wall -Wextra -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -fno-sized-deallocation -mn-flash=4 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\ccOxI7Gg.s Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/device-specs/specs-atmega2560 COLLECT_GCC=C:\avrToolchain\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single Supported LTO compression algorithms: zlib gcc version 12.2.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\HardwareSerial0.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\' c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/avr/12.2.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega -imultilib avr6 -iprefix c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\HardwareSerial0.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\HardwareSerial0.cpp.o -D__AVR_ATmega2560__ -D__AVR_DEVICE_NAME__=atmega2560 -D F_CPU=16000000L -D ARDUINO=10819 -D ARDUINO_AVR_MEGA2560 -D ARDUINO_ARCH_AVR C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino\HardwareSerial0.cpp -mn-flash=4 -mno-skip-bug -quiet -dumpdir C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\ -dumpbase HardwareSerial0.cpp.cpp -dumpbase-ext .cpp -mdouble=32 -mlong-double=64 -mmcu=avr6 -g -Os -Wno-error=narrowing -Wall -Wextra -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -fno-sized-deallocation -mn-flash=4 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\ccQSvcVg.s Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/device-specs/specs-atmega2560 COLLECT_GCC=C:\avrToolchain\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single Supported LTO compression algorithms: zlib gcc version 12.2.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\HardwareSerial2.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\' c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/avr/12.2.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega -imultilib avr6 -iprefix c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\HardwareSerial2.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\HardwareSerial2.cpp.o -D__AVR_ATmega2560__ -D__AVR_DEVICE_NAME__=atmega2560 -D F_CPU=16000000L -D ARDUINO=10819 -D ARDUINO_AVR_MEGA2560 -D ARDUINO_ARCH_AVR C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino\HardwareSerial2.cpp -mn-flash=4 -mno-skip-bug -quiet -dumpdir C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\ -dumpbase HardwareSerial2.cpp.cpp -dumpbase-ext .cpp -mdouble=32 -mlong-double=64 -mmcu=avr6 -g -Os -Wno-error=narrowing -Wall -Wextra -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -fno-sized-deallocation -mn-flash=4 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\ccESRbDf.s Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/device-specs/specs-atmega2560 COLLECT_GCC=C:\avrToolchain\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single Supported LTO compression algorithms: zlib gcc version 12.2.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\PluggableUSB.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\' c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/avr/12.2.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega -imultilib avr6 -iprefix c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\PluggableUSB.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\PluggableUSB.cpp.o -D__AVR_ATmega2560__ -D__AVR_DEVICE_NAME__=atmega2560 -D F_CPU=16000000L -D ARDUINO=10819 -D ARDUINO_AVR_MEGA2560 -D ARDUINO_ARCH_AVR C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino\PluggableUSB.cpp -mn-flash=4 -mno-skip-bug -quiet -dumpdir C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\ -dumpbase PluggableUSB.cpp.cpp -dumpbase-ext .cpp -mdouble=32 -mlong-double=64 -mmcu=avr6 -g -Os -Wno-error=narrowing -Wall -Wextra -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -fno-sized-deallocation -mn-flash=4 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\cc87GYRe.s Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/device-specs/specs-atmega2560 COLLECT_GCC=C:\avrToolchain\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single Supported LTO compression algorithms: zlib gcc version 12.2.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\WMath.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\' c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/avr/12.2.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega -imultilib avr6 -iprefix c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\WMath.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\WMath.cpp.o -D__AVR_ATmega2560__ -D__AVR_DEVICE_NAME__=atmega2560 -D F_CPU=16000000L -D ARDUINO=10819 -D ARDUINO_AVR_MEGA2560 -D ARDUINO_ARCH_AVR C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino\WMath.cpp -mn-flash=4 -mno-skip-bug -quiet -dumpdir C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\ -dumpbase WMath.cpp.cpp -dumpbase-ext .cpp -mdouble=32 -mlong-double=64 -mmcu=avr6 -g -Os -Wno-error=narrowing -Wall -Wextra -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -fno-sized-deallocation -mn-flash=4 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\ccmTAt6e.s Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/device-specs/specs-atmega2560 COLLECT_GCC=C:\avrToolchain\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single Supported LTO compression algorithms: zlib gcc version 12.2.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\Print.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\' c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/avr/12.2.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega -imultilib avr6 -iprefix c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\Print.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\Print.cpp.o -D__AVR_ATmega2560__ -D__AVR_DEVICE_NAME__=atmega2560 -D F_CPU=16000000L -D ARDUINO=10819 -D ARDUINO_AVR_MEGA2560 -D ARDUINO_ARCH_AVR C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino\Print.cpp -mn-flash=4 -mno-skip-bug -quiet -dumpdir C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\ -dumpbase Print.cpp.cpp -dumpbase-ext .cpp -mdouble=32 -mlong-double=64 -mmcu=avr6 -g -Os -Wno-error=narrowing -Wall -Wextra -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -fno-sized-deallocation -mn-flash=4 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\cc05l9lf.s Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/device-specs/specs-atmega2560 COLLECT_GCC=C:\avrToolchain\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single Supported LTO compression algorithms: zlib gcc version 12.2.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\IPAddress.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\' c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/avr/12.2.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega -imultilib avr6 -iprefix c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\IPAddress.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\IPAddress.cpp.o -D__AVR_ATmega2560__ -D__AVR_DEVICE_NAME__=atmega2560 -D F_CPU=16000000L -D ARDUINO=10819 -D ARDUINO_AVR_MEGA2560 -D ARDUINO_ARCH_AVR C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino\IPAddress.cpp -mn-flash=4 -mno-skip-bug -quiet -dumpdir C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\ -dumpbase IPAddress.cpp.cpp -dumpbase-ext .cpp -mdouble=32 -mlong-double=64 -mmcu=avr6 -g -Os -Wno-error=narrowing -Wall -Wextra -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -fno-sized-deallocation -mn-flash=4 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\ccGbQwXi.s GNU C++17 (GCC) version 12.2.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.1, isl version isl-0.24-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/avr/avr6" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/avr/avr6" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/include c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/include-fixed c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 12.2.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.1, isl version isl-0.24-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d7ad23a6c302228c09124ad6813f1124 Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/device-specs/specs-atmega2560 COLLECT_GCC=C:\avrToolchain\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single Supported LTO compression algorithms: zlib gcc version 12.2.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\Tone.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\' c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/avr/12.2.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega -imultilib avr6 -iprefix c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\Tone.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\Tone.cpp.o -D__AVR_ATmega2560__ -D__AVR_DEVICE_NAME__=atmega2560 -D F_CPU=16000000L -D ARDUINO=10819 -D ARDUINO_AVR_MEGA2560 -D ARDUINO_ARCH_AVR C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino\Tone.cpp -mn-flash=4 -mno-skip-bug -quiet -dumpdir C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\ -dumpbase Tone.cpp.cpp -dumpbase-ext .cpp -mdouble=32 -mlong-double=64 -mmcu=avr6 -g -Os -Wno-error=narrowing -Wall -Wextra -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -fno-sized-deallocation -mn-flash=4 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\cckmGTaj.s Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/device-specs/specs-atmega2560 COLLECT_GCC=C:\avrToolchain\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single Supported LTO compression algorithms: zlib gcc version 12.2.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\HardwareSerial.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\' c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/avr/12.2.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega -imultilib avr6 -iprefix c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\HardwareSerial.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\HardwareSerial.cpp.o -D__AVR_ATmega2560__ -D__AVR_DEVICE_NAME__=atmega2560 -D F_CPU=16000000L -D ARDUINO=10819 -D ARDUINO_AVR_MEGA2560 -D ARDUINO_ARCH_AVR C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino\HardwareSerial.cpp -mn-flash=4 -mno-skip-bug -quiet -dumpdir C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\ -dumpbase HardwareSerial.cpp.cpp -dumpbase-ext .cpp -mdouble=32 -mlong-double=64 -mmcu=avr6 -g -Os -Wno-error=narrowing -Wall -Wextra -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -fno-sized-deallocation -mn-flash=4 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\cc6i0hpj.s GNU C++17 (GCC) version 12.2.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.1, isl version isl-0.24-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/avr/avr6" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/avr/avr6" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/include c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/include-fixed c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 12.2.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.1, isl version isl-0.24-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d7ad23a6c302228c09124ad6813f1124 Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/device-specs/specs-atmega2560 COLLECT_GCC=C:\avrToolchain\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single Supported LTO compression algorithms: zlib gcc version 12.2.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\USBCore.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\' c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/avr/12.2.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega -imultilib avr6 -iprefix c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\USBCore.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\USBCore.cpp.o -D__AVR_ATmega2560__ -D__AVR_DEVICE_NAME__=atmega2560 -D F_CPU=16000000L -D ARDUINO=10819 -D ARDUINO_AVR_MEGA2560 -D ARDUINO_ARCH_AVR C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino\USBCore.cpp -mn-flash=4 -mno-skip-bug -quiet -dumpdir C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\ -dumpbase USBCore.cpp.cpp -dumpbase-ext .cpp -mdouble=32 -mlong-double=64 -mmcu=avr6 -g -Os -Wno-error=narrowing -Wall -Wextra -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -fno-sized-deallocation -mn-flash=4 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\cce9ejui.s Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/device-specs/specs-atmega2560 COLLECT_GCC=C:\avrToolchain\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single Supported LTO compression algorithms: zlib gcc version 12.2.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\Stream.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\' c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/avr/12.2.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega -imultilib avr6 -iprefix c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\Stream.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\Stream.cpp.o -D__AVR_ATmega2560__ -D__AVR_DEVICE_NAME__=atmega2560 -D F_CPU=16000000L -D ARDUINO=10819 -D ARDUINO_AVR_MEGA2560 -D ARDUINO_ARCH_AVR C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino\Stream.cpp -mn-flash=4 -mno-skip-bug -quiet -dumpdir C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\ -dumpbase Stream.cpp.cpp -dumpbase-ext .cpp -mdouble=32 -mlong-double=64 -mmcu=avr6 -g -Os -Wno-error=narrowing -Wall -Wextra -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -fno-sized-deallocation -mn-flash=4 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\ccQiuOIi.s Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/device-specs/specs-atmega2560 COLLECT_GCC=C:\avrToolchain\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single Supported LTO compression algorithms: zlib gcc version 12.2.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\WString.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\' c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/avr/12.2.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega -imultilib avr6 -iprefix c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\WString.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\WString.cpp.o -D__AVR_ATmega2560__ -D__AVR_DEVICE_NAME__=atmega2560 -D F_CPU=16000000L -D ARDUINO=10819 -D ARDUINO_AVR_MEGA2560 -D ARDUINO_ARCH_AVR C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino\WString.cpp -mn-flash=4 -mno-skip-bug -quiet -dumpdir C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\ -dumpbase WString.cpp.cpp -dumpbase-ext .cpp -mdouble=32 -mlong-double=64 -mmcu=avr6 -g -Os -Wno-error=narrowing -Wall -Wextra -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -fno-sized-deallocation -mn-flash=4 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\ccOPO8Vi.s GNU C++17 (GCC) version 12.2.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.1, isl version isl-0.24-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/avr/avr6" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/avr/avr6" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/include c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/include-fixed c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 12.2.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.1, isl version isl-0.24-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d7ad23a6c302228c09124ad6813f1124 GNU C++17 (GCC) version 12.2.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.1, isl version isl-0.24-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/avr/avr6" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/avr/avr6" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/include c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/include-fixed c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 12.2.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.1, isl version isl-0.24-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d7ad23a6c302228c09124ad6813f1124 Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/device-specs/specs-atmega2560 COLLECT_GCC=C:\avrToolchain\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single Supported LTO compression algorithms: zlib gcc version 12.2.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\HardwareSerial1.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\' c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/avr/12.2.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega -imultilib avr6 -iprefix c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\HardwareSerial1.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\HardwareSerial1.cpp.o -D__AVR_ATmega2560__ -D__AVR_DEVICE_NAME__=atmega2560 -D F_CPU=16000000L -D ARDUINO=10819 -D ARDUINO_AVR_MEGA2560 -D ARDUINO_ARCH_AVR C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino\HardwareSerial1.cpp -mn-flash=4 -mno-skip-bug -quiet -dumpdir C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\ -dumpbase HardwareSerial1.cpp.cpp -dumpbase-ext .cpp -mdouble=32 -mlong-double=64 -mmcu=avr6 -g -Os -Wno-error=narrowing -Wall -Wextra -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -fno-sized-deallocation -mn-flash=4 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\cc0XLLZh.s Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/device-specs/specs-atmega2560 COLLECT_GCC=C:\avrToolchain\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single Supported LTO compression algorithms: zlib gcc version 12.2.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\main.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\' c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/avr/12.2.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega -imultilib avr6 -iprefix c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\main.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\main.cpp.o -D__AVR_ATmega2560__ -D__AVR_DEVICE_NAME__=atmega2560 -D F_CPU=16000000L -D ARDUINO=10819 -D ARDUINO_AVR_MEGA2560 -D ARDUINO_ARCH_AVR C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino\main.cpp -mn-flash=4 -mno-skip-bug -quiet -dumpdir C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\ -dumpbase main.cpp.cpp -dumpbase-ext .cpp -mdouble=32 -mlong-double=64 -mmcu=avr6 -g -Os -Wno-error=narrowing -Wall -Wextra -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -fno-sized-deallocation -mn-flash=4 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\ccyprq0h.s Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/device-specs/specs-atmega2560 COLLECT_GCC=C:\avrToolchain\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single Supported LTO compression algorithms: zlib gcc version 12.2.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\abi.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\' c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/avr/12.2.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega -imultilib avr6 -iprefix c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\abi.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\abi.cpp.o -D__AVR_ATmega2560__ -D__AVR_DEVICE_NAME__=atmega2560 -D F_CPU=16000000L -D ARDUINO=10819 -D ARDUINO_AVR_MEGA2560 -D ARDUINO_ARCH_AVR C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino\abi.cpp -mn-flash=4 -mno-skip-bug -quiet -dumpdir C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\ -dumpbase abi.cpp.cpp -dumpbase-ext .cpp -mdouble=32 -mlong-double=64 -mmcu=avr6 -g -Os -Wno-error=narrowing -Wall -Wextra -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -fno-sized-deallocation -mn-flash=4 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\cc812Kdi.s Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/device-specs/specs-atmega2560 COLLECT_GCC=C:\avrToolchain\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single Supported LTO compression algorithms: zlib gcc version 12.2.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\new.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\' c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/avr/12.2.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega -imultilib avr6 -iprefix c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\new.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\new.cpp.o -D__AVR_ATmega2560__ -D__AVR_DEVICE_NAME__=atmega2560 -D F_CPU=16000000L -D ARDUINO=10819 -D ARDUINO_AVR_MEGA2560 -D ARDUINO_ARCH_AVR C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino\new.cpp -mn-flash=4 -mno-skip-bug -quiet -dumpdir C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\ -dumpbase new.cpp.cpp -dumpbase-ext .cpp -mdouble=32 -mlong-double=64 -mmcu=avr6 -g -Os -Wno-error=narrowing -Wall -Wextra -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -fno-sized-deallocation -mn-flash=4 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\ccC9w5ch.s GNU C++17 (GCC) version 12.2.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.1, isl version isl-0.24-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/avr/avr6" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/avr/avr6" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/include c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/include-fixed c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 12.2.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.1, isl version isl-0.24-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d7ad23a6c302228c09124ad6813f1124 GNU C++17 (GCC) version 12.2.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.1, isl version isl-0.24-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/avr/avr6" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/avr/avr6" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/include c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/include-fixed c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 12.2.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.1, isl version isl-0.24-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d7ad23a6c302228c09124ad6813f1124 GNU C++17 (GCC) version 12.2.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.1, isl version isl-0.24-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/avr/avr6" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/avr/avr6" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/include c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/include-fixed c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 12.2.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.1, isl version isl-0.24-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d7ad23a6c302228c09124ad6813f1124 GNU C++17 (GCC) version 12.2.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.1, isl version isl-0.24-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/avr/avr6" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/avr/avr6" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/include c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/include-fixed c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 12.2.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.1, isl version isl-0.24-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d7ad23a6c302228c09124ad6813f1124 COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\HardwareSerial3.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\' c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega --gdwarf-5 -mmcu=avr6 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\HardwareSerial3.cpp.o C:\Users\Worker\AppData\Local\Temp\ccO3VX1c.s COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\CDC.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\' c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega --gdwarf-5 -mmcu=avr6 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\CDC.cpp.o C:\Users\Worker\AppData\Local\Temp\ccOxI7Gg.s GNU C++17 (GCC) version 12.2.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.1, isl version isl-0.24-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/avr/avr6" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/avr/avr6" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/include c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/include-fixed c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 12.2.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.1, isl version isl-0.24-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d7ad23a6c302228c09124ad6813f1124 GNU C++17 (GCC) version 12.2.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.1, isl version isl-0.24-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/avr/avr6" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/avr/avr6" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/include c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/include-fixed c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 12.2.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.1, isl version isl-0.24-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d7ad23a6c302228c09124ad6813f1124 GNU C++17 (GCC) version 12.2.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.1, isl version isl-0.24-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/avr/avr6" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/avr/avr6" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/include c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/include-fixed c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 12.2.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.1, isl version isl-0.24-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d7ad23a6c302228c09124ad6813f1124 GNU C++17 (GCC) version 12.2.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.1, isl version isl-0.24-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/avr/avr6" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/avr/avr6" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/include c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/include-fixed c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 12.2.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.1, isl version isl-0.24-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d7ad23a6c302228c09124ad6813f1124 COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\HardwareSerial0.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\' c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega --gdwarf-5 -mmcu=avr6 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\HardwareSerial0.cpp.o C:\Users\Worker\AppData\Local\Temp\ccQSvcVg.s COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\HardwareSerial2.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\' c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega --gdwarf-5 -mmcu=avr6 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\HardwareSerial2.cpp.o C:\Users\Worker\AppData\Local\Temp\ccESRbDf.s GNU C++17 (GCC) version 12.2.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.1, isl version isl-0.24-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/avr/avr6" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/avr/avr6" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/include c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/include-fixed c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 12.2.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.1, isl version isl-0.24-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d7ad23a6c302228c09124ad6813f1124 GNU C++17 (GCC) version 12.2.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.1, isl version isl-0.24-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/avr/avr6" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/avr/avr6" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/include c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/include-fixed c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 12.2.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.1, isl version isl-0.24-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d7ad23a6c302228c09124ad6813f1124 GNU C++17 (GCC) version 12.2.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.1, isl version isl-0.24-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/avr/avr6" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/avr/avr6" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/include c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/include-fixed c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 12.2.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.1, isl version isl-0.24-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d7ad23a6c302228c09124ad6813f1124 GNU C++17 (GCC) version 12.2.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.1, isl version isl-0.24-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/avr/avr6" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/avr/avr6" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/include c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/include-fixed c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 12.2.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.1, isl version isl-0.24-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d7ad23a6c302228c09124ad6813f1124 COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\WMath.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\' c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega --gdwarf-5 -mmcu=avr6 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\WMath.cpp.o C:\Users\Worker\AppData\Local\Temp\ccmTAt6e.s GNU C++17 (GCC) version 12.2.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.1, isl version isl-0.24-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/avr/avr6" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/avr/avr6" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include/c++/12.2.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/12.2.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/include c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/include-fixed c:\avrtoolchain\avr-gcc-12.2.0_binutils2.39_avrlibc2.1github\bin\../lib/gcc/avr/12.2.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 12.2.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.1, isl version isl-0.24-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d7ad23a6c302228c09124ad6813f1124 COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\IPAddress.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\' c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega --gdwarf-5 -mmcu=avr6 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\IPAddress.cpp.o C:\Users\Worker\AppData\Local\Temp\ccGbQwXi.s COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\PluggableUSB.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\' c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega --gdwarf-5 -mmcu=avr6 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\PluggableUSB.cpp.o C:\Users\Worker\AppData\Local\Temp\cc87GYRe.s COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\Print.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\' c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega --gdwarf-5 -mmcu=avr6 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\Print.cpp.o C:\Users\Worker\AppData\Local\Temp\cc05l9lf.s COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\Tone.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\' c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega --gdwarf-5 -mmcu=avr6 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\Tone.cpp.o C:\Users\Worker\AppData\Local\Temp\cckmGTaj.s COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\HardwareSerial.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\' c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega --gdwarf-5 -mmcu=avr6 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\HardwareSerial.cpp.o C:\Users\Worker\AppData\Local\Temp\cc6i0hpj.s GNU assembler version 2.39 (avr) using BFD version (GNU Binutils) 2.39 GNU assembler version 2.39 (avr) using BFD version (GNU Binutils) 2.39 COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\USBCore.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\' c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega --gdwarf-5 -mmcu=avr6 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\USBCore.cpp.o C:\Users\Worker\AppData\Local\Temp\cce9ejui.s COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\Stream.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\' c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega --gdwarf-5 -mmcu=avr6 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\Stream.cpp.o C:\Users\Worker\AppData\Local\Temp\ccQiuOIi.s GNU assembler version 2.39 (avr) using BFD version (GNU Binutils) 2.39 GNU assembler version 2.39 (avr) using BFD version (GNU Binutils) 2.39 COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\HardwareSerial1.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\' c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega --gdwarf-5 -mmcu=avr6 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\HardwareSerial1.cpp.o C:\Users\Worker\AppData\Local\Temp\cc0XLLZh.s COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\WString.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\' c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega --gdwarf-5 -mmcu=avr6 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\WString.cpp.o C:\Users\Worker\AppData\Local\Temp\ccOPO8Vi.s COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\main.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\' c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega --gdwarf-5 -mmcu=avr6 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\main.cpp.o C:\Users\Worker\AppData\Local\Temp\ccyprq0h.s COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\abi.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\' c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega --gdwarf-5 -mmcu=avr6 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\abi.cpp.o C:\Users\Worker\AppData\Local\Temp\cc812Kdi.s C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino\new.cpp: In function 'void* operator new(std::size_t, std::nothrow_t)': C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino\new.cpp:59:60: warning: unused parameter 'tag' [-Wunused-parameter] 59 | void * operator new(std::size_t size, const std::nothrow_t tag) noexcept { | ~~~~~~~~~~~~~~~~~~~~~^~~ GNU assembler version 2.39 (avr) using BFD version (GNU Binutils) 2.39 COMPILER_PATH=c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/avr/12.2.0/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/avr6/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/lib/avr6/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\CDC.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\CDC.cpp.' COMPILER_PATH=c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/avr/12.2.0/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/avr6/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/lib/avr6/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\HardwareSerial3.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\HardwareSerial3.cpp.' COMPILER_PATH=c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/avr/12.2.0/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/avr6/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/lib/avr6/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\HardwareSerial2.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\HardwareSerial2.cpp.' COMPILER_PATH=c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/avr/12.2.0/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/avr6/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/lib/avr6/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\HardwareSerial0.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\HardwareSerial0.cpp.' GNU assembler version 2.39 (avr) using BFD version (GNU Binutils) 2.39 GNU assembler version 2.39 (avr) using BFD version (GNU Binutils) 2.39 GNU assembler version 2.39 (avr) using BFD version (GNU Binutils) 2.39 GNU assembler version 2.39 (avr) using BFD version (GNU Binutils) 2.39 GNU assembler version 2.39 (avr) using BFD version (GNU Binutils) 2.39 GNU assembler version 2.39 (avr) using BFD version (GNU Binutils) 2.39 GNU assembler version 2.39 (avr) using BFD version (GNU Binutils) 2.39 C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino\new.cpp: In function 'void* operator new [](std::size_t, const std::nothrow_t&)': C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino\new.cpp:68:63: warning: unused parameter 'tag' [-Wunused-parameter] 68 | void * operator new[](std::size_t size, const std::nothrow_t& tag) noexcept { | ~~~~~~~~~~~~~~~~~~~~~~^~~ GNU assembler version 2.39 (avr) using BFD version (GNU Binutils) 2.39 COMPILER_PATH=c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/avr/12.2.0/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/avr6/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/lib/avr6/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\WMath.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\WMath.cpp.' GNU assembler version 2.39 (avr) using BFD version (GNU Binutils) 2.39 GNU assembler version 2.39 (avr) using BFD version (GNU Binutils) 2.39 GNU assembler version 2.39 (avr) using BFD version (GNU Binutils) 2.39 C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino\new.cpp: In function 'void operator delete(void*, std::size_t)': C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino\new.cpp:95:45: warning: unused parameter 'size' [-Wunused-parameter] 95 | void operator delete(void* ptr, std::size_t size) noexcept { | ~~~~~~~~~~~~^~~~ COMPILER_PATH=c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/avr/12.2.0/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/avr6/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/lib/avr6/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\IPAddress.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\IPAddress.cpp.' COMPILER_PATH=c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/avr/12.2.0/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/avr6/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/lib/avr6/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\Print.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\Print.cpp.' COMPILER_PATH=c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/avr/12.2.0/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/avr6/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/lib/avr6/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\WString.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\WString.cpp.' COMPILER_PATH=c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/avr/12.2.0/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/avr6/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/lib/avr6/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\HardwareSerial.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\HardwareSerial.cpp.' COMPILER_PATH=c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/avr/12.2.0/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/avr6/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/lib/avr6/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\Tone.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\Tone.cpp.' COMPILER_PATH=c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/avr/12.2.0/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/avr6/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/lib/avr6/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\PluggableUSB.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\PluggableUSB.cpp.' COMPILER_PATH=c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/avr/12.2.0/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/avr6/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/lib/avr6/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\Stream.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\Stream.cpp.' COMPILER_PATH=c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/avr/12.2.0/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/avr6/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/lib/avr6/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\USBCore.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\USBCore.cpp.' C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino\new.cpp: In function 'void operator delete [](void*, std::size_t)': C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino\new.cpp:98:48: warning: unused parameter 'size' [-Wunused-parameter] 98 | void operator delete[](void * ptr, std::size_t size) noexcept { | ~~~~~~~~~~~~^~~~ COMPILER_PATH=c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/avr/12.2.0/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/avr6/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/lib/avr6/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\HardwareSerial1.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\HardwareSerial1.cpp.' COMPILER_PATH=c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/avr/12.2.0/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/avr6/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/lib/avr6/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\abi.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\abi.cpp.' COMPILER_PATH=c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/avr/12.2.0/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/avr6/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/lib/avr6/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/lib/ "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\wiring_pulse.S.o" COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\main.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\main.cpp.' C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino\new.cpp: In function 'void operator delete(void*, const std::nothrow_t&)': C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino\new.cpp:103:55: warning: unused parameter 'tag' [-Wunused-parameter] 103 | void operator delete(void* ptr, const std::nothrow_t& tag) noexcept { | ~~~~~~~~~~~~~~~~~~~~~~^~~ C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino\new.cpp: In function 'void operator delete [](void*, const std::nothrow_t&)': C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino\new.cpp:106:57: warning: unused parameter 'tag' [-Wunused-parameter] 106 | void operator delete[](void* ptr, const std::nothrow_t& tag) noexcept { | ~~~~~~~~~~~~~~~~~~~~~~^~~ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\new.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\' c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino -I C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega --gdwarf-5 -mmcu=avr6 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\new.cpp.o C:\Users\Worker\AppData\Local\Temp\ccC9w5ch.s GNU assembler version 2.39 (avr) using BFD version (GNU Binutils) 2.39 COMPILER_PATH=c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/avr/12.2.0/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/avr6/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/lib/avr6/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-v' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_MEGA2560' '-D' 'ARDUINO_ARCH_AVR' '-fno-sized-deallocation' '-Wall' '-Wextra' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino' '-I' 'C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\variants\mega' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\new.cpp.o' '-mdouble=32' '-mlong-double=64' '-specs=device-specs/specs-atmega2560' '-mmcu=avr6' '-dumpdir' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_224437\core\new.cpp.' "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\WInterrupts.c.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\hooks.c.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\wiring.c.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\wiring_analog.c.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\wiring_digital.c.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\wiring_pulse.c.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\wiring_shift.c.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\CDC.cpp.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\HardwareSerial.cpp.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\HardwareSerial0.cpp.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\HardwareSerial1.cpp.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\HardwareSerial2.cpp.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\HardwareSerial3.cpp.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\IPAddress.cpp.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\PluggableUSB.cpp.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\Print.cpp.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\Stream.cpp.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\Tone.cpp.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\USBCore.cpp.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\WMath.cpp.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\WString.cpp.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\abi.cpp.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\main.cpp.o" "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\core\\new.cpp.o" Gebauter Kern wird archiviert (zwischengespeichert) in: C:\Users\Worker\AppData\Local\Temp\arduino_cache_57850\core\core_arduino_avr_mega_cpu_atmega2560_991b95454a2889a3c3f3cd19c290e476.a Linking everything together... "C:\\avrToolchain\\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-gcc" -Wall -Wextra -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega2560 -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437/Compiler_Internal_Error.ino.elf" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437\\sketch\\Compiler_Internal_Error.ino.cpp.o" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437/core\\core.a" "-LC:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_224437" -lm during RTL pass: combine C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino\Print.cpp: In function '_ZN5Print5printEli.part.0.constprop.isra': C:\Arduino IDE Portable\Mega2560\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\cores\arduino\Print.cpp:101:1: internal compiler error: in add_clobbers, at config/avr/avr-dimode.md:2705 101 | } | ^ libbacktrace could not find executable to open Please submit a full bug report, with preprocessed source (by using -freport-bug). See for instructions. lto-wrapper.exe: fatal error: C:\avrToolchain\avr-gcc-12.2.0_binutils2.39_avrLibc2.1GitHub/bin/avr-gcc returned 1 exit status compilation terminated. c:/avrtoolchain/avr-gcc-12.2.0_binutils2.39_avrlibc2.1github/bin/../lib/gcc/avr/12.2.0/../../../../avr/bin/ld.exe: error: lto-wrapper failed collect2.exe: error: ld returned 1 exit status exit status 1 Fehler beim Kompilieren für das Board Arduino Mega or Mega 2560.
