INFO Reading configuration /config/esphome/hz-m404.yaml... INFO Starting log output from hz-m404.local using esphome API INFO Successfully connected to hz-m404.local [18:57:39][I][app:102]: ESPHome version 2022.12.3 compiled on Jan 20 2023, 16:18:45 [18:57:39][C][wifi:504]: WiFi: [18:57:39][C][wifi:362]: Local MAC: AC:0B:FB:DA:86:7B [18:57:39][C][wifi:363]: SSID: 'WLAN'[redacted] [18:57:39][C][wifi:364]: IP Address: 192.168.1.224 [18:57:39][C][wifi:365]: BSSID: 8C:19:B5:18:7F:61[redacted] [18:57:39][C][wifi:367]: Hostname: 'hz-m404' [18:57:39][C][wifi:369]: Signal strength: -80 dB ▂▄▆█ [18:57:39][C][wifi:373]: Channel: 11 [18:57:39][C][wifi:374]: Subnet: 255.255.255.0 [18:57:39][C][wifi:375]: Gateway: 192.168.1.1 [18:57:39][C][wifi:376]: DNS1: 192.168.1.1 [18:57:39][C][wifi:377]: DNS2: 0.0.0.0 [18:57:39][C][logger:293]: Logger: [18:57:39][C][logger:294]: Level: DEBUG [18:57:39][C][logger:295]: Log Baud Rate: 0 [18:57:39][C][logger:296]: Hardware UART: UART0 [18:57:39][C][uart.arduino_esp8266:102]: UART Bus: [18:57:39][C][uart.arduino_esp8266:103]: TX Pin: GPIO1 [18:57:39][C][uart.arduino_esp8266:104]: RX Pin: GPIO3 [18:57:39][C][uart.arduino_esp8266:106]: RX Buffer Size: 256 [18:57:39][C][uart.arduino_esp8266:108]: Baud Rate: 2400 baud [18:57:39][C][uart.arduino_esp8266:109]: Data Bits: 8 [18:57:39][C][uart.arduino_esp8266:110]: Parity: NONE [18:57:39][C][uart.arduino_esp8266:111]: Stop bits: 1 [18:57:39][C][uart.arduino_esp8266:113]: Using hardware serial interface. [18:57:39][C][gpio.output:010]: GPIO Binary Output: [18:57:39][C][gpio.output:011]: Pin: GPIO14 [18:57:39][C][gpio.output:010]: GPIO Binary Output: [18:57:39][C][gpio.output:011]: Pin: GPIO4 [18:57:39][D][uart_debug:158]: <<< "\x02" [18:57:39][C][status:034]: Status Binary Sensor 'M404 UART Status' [18:57:39][C][status:034]: Device Class: 'connectivity' [18:57:39][C][restart:076]: Restart Switch 'M404 UART Restart' [18:57:39][C][restart:078]: Icon: 'mdi:restart' [18:57:39][C][restart:098]: Restore Mode: restore defaults to OFF [18:57:39][C][wifi_info:013]: WifiInfo Mac Address 'M404 Mac Wifi Address' [18:57:39][C][version.text_sensor:021]: Version Text Sensor 'M404 ESPHome Version Version' [18:57:39][C][version.text_sensor:021]: Icon: 'mdi:new-box' [18:57:39][C][captive_portal:088]: Captive Portal: [18:57:39][C][mdns:103]: mDNS: [18:57:39][C][mdns:104]: Hostname: hz-m404 [18:57:39][C][ota:093]: Over-The-Air Updates: [18:57:39][C][ota:094]: Address: hz-m404.local:8266 [18:57:39][C][ota:097]: Using Password. [18:57:39][C][api:138]: API Server: [18:57:39][C][api:139]: Address: hz-m404.local:6053 [18:57:39][C][api:141]: Using noise encryption: YES [18:57:39][C][wifi_signal.sensor:009]: WiFi Signal 'M404 WiFi Signal' [18:57:39][C][wifi_signal.sensor:009]: Device Class: 'signal_strength' [18:57:39][C][wifi_signal.sensor:009]: State Class: 'measurement' [18:57:39][C][wifi_signal.sensor:009]: Unit of Measurement: 'dBm' [18:57:39][C][wifi_signal.sensor:009]: Accuracy Decimals: 0 [18:57:39][C][wifi_signal.sensor:009]: Icon: 'mdi:wifi' [18:57:39][C][wifi_info:009]: WifiInfo IPAddress 'M404 IP Address' [18:57:39][C][wifi_info:011]: WifiInfo SSID 'M404 Connected SSID' [18:57:39][C][wifi_info:012]: WifiInfo BSSID 'M404 Connected BSSID' [18:57:39][C][wifi_info:010]: WifiInfo Scan Results 'M404 Latest Scan Results' [18:57:40][D][uart_debug:158]: <<< "\x02" [18:57:41][D][sensor:126]: 'M404 WiFi Signal': Sending state -80.00000 dBm with 0 decimals of accuracy [18:57:42][D][uart_debug:158]: >>> "\x10" [18:57:42][D][uart_debug:158]: <<< "\x11\x05A\x10\x03F" [18:57:50][D][uart_debug:158]: <<< "\x02" [18:57:50][D][uart_debug:158]: >>> "\x10" [18:57:50][D][uart_debug:158]: <<< "a\x16\x02\x10\x03f" [18:58:00][D][uart_debug:158]: <<< "\x02" [18:58:00][D][uart_debug:158]: >>> "\x10" [18:58:01][D][uart_debug:158]: <<< "a\x16\x04\x10\x03`" [18:58:07][D][uart_debug:158]: <<< "\x02" [18:58:07][D][uart_debug:158]: >>> "\x10" [18:58:07][D][uart_debug:158]: <<< "\x11\x05@\x10\x03G" [18:58:10][D][uart_debug:158]: <<< "\x02" [18:58:11][D][uart_debug:158]: >>> "\x10" [18:58:11][D][uart_debug:158]: <<< "\b\x03\xA4\x10\x03\xBC" [18:58:20][D][uart_debug:158]: <<< "\x02" [18:58:21][D][uart_debug:158]: >>> "\x10" [18:58:21][D][uart_debug:158]: <<< "a\x16\x02\x10\x03f" [18:58:30][D][uart_debug:158]: <<< "\x02" [18:58:30][D][uart_debug:158]: >>> "\x10" [18:58:31][D][uart_debug:158]: <<< "a\x16\x04\x10\x03`" [18:58:37][D][uart_debug:158]: <<< "\x02" [18:58:38][D][uart_debug:158]: >>> "\x10" [18:58:38][D][uart_debug:158]: <<< "\x11\x05?\x10\x038" [18:58:40][D][uart_debug:158]: <<< "\x02" [18:58:41][D][uart_debug:158]: >>> "\x10" [18:58:41][D][uart_debug:158]: <<< "\b\x03\xA4\x10\x03\xBC" [18:58:42][D][sensor:126]: 'M404 WiFi Signal': Sending state -80.00000 dBm with 0 decimals of accuracy [18:58:50][D][uart_debug:158]: <<< "\x02" [18:58:50][D][uart_debug:158]: >>> "\x10" [18:58:51][D][uart_debug:158]: <<< "a\x16\x02\x10\x03f" [18:59:00][D][uart_debug:158]: <<< "\x02" [18:59:00][D][uart_debug:158]: >>> "\x10" [18:59:00][D][uart_debug:158]: <<< "a\x16\x04\x10\x03`" [18:59:08][D][uart_debug:158]: <<< "\x02" [18:59:08][D][uart_debug:158]: >>> "\x10" [18:59:08][D][uart_debug:158]: <<< "\x11\x05=\x10\x03:" [18:59:10][D][uart_debug:158]: <<< "\x02" [18:59:11][D][uart_debug:158]: >>> "\x10" [18:59:11][D][uart_debug:158]: <<< "\b\x03\xA4\x10\x03\xBC" [18:59:20][D][uart_debug:158]: <<< "\x02" [18:59:20][D][uart_debug:158]: >>> "\x10" [18:59:21][D][uart_debug:158]: <<< "a\x16\x02\x10\x03f" [18:59:23][D][uart_debug:158]: <<< "\x02" [18:59:24][D][uart_debug:158]: >>> "\x10" [18:59:24][D][uart_debug:158]: <<< "\x11\x05<\x10\x03;" [18:59:30][D][uart_debug:158]: <<< "\x02" [18:59:30][D][uart_debug:158]: >>> "\x10" [18:59:31][D][uart_debug:158]: <<< "a\x16\x04\x10\x03`" [18:59:38][D][uart_debug:158]: <<< "\x02" [18:59:39][D][uart_debug:158]: >>> "\x10" [18:59:39][D][uart_debug:158]: <<< "\x11\x05;\x10\x03<" [18:59:41][D][sensor:126]: 'M404 WiFi Signal': Sending state -80.00000 dBm with 0 decimals of accuracy [18:59:42][D][uart_debug:158]: >>> "\x10" [18:59:50][D][uart_debug:158]: <<< "\x02" [18:59:50][D][uart_debug:158]: >>> "\x10" [18:59:51][D][uart_debug:158]: <<< "a\x16\x02\x10\x03f" [18:59:53][D][uart_debug:158]: <<< "\x02" [18:59:54][D][uart_debug:158]: >>> "\x10" [18:59:54][D][uart_debug:158]: <<< "\x11\x05:\x10\x03=" [19:00:00][D][uart_debug:158]: <<< "\x02" [19:00:00][D][uart_debug:158]: >>> "\x10" [19:00:01][D][uart_debug:158]: <<< "\b\x03\xA4\x10\x03\xBC" [19:00:08][D][uart_debug:158]: <<< "\x02" [19:00:09][D][uart_debug:158]: >>> "\x10" [19:00:10][D][uart_debug:158]: <<< "\x11\x059\x10\x03>" [19:00:20][D][uart_debug:158]: <<< "\x02" [19:00:21][D][uart_debug:158]: >>> "\x10" [19:00:21][D][uart_debug:158]: <<< "\b\x03\xA4\x10\x03\xBC" [19:00:30][D][uart_debug:158]: <<< "\x02" [19:00:30][D][uart_debug:158]: >>> "\x10" [19:00:31][D][uart_debug:158]: <<< "a\x16\x03\x10\x03g" [19:00:39][D][uart_debug:158]: <<< "\x02" [19:00:39][D][uart_debug:158]: >>> "\x10" [19:00:40][D][uart_debug:158]: <<< "\x11\x058\x10\x03?" [19:00:41][D][sensor:126]: 'M404 WiFi Signal': Sending state -80.00000 dBm with 0 decimals of accuracy [19:00:42][D][uart_debug:158]: >>> "\x10" [19:00:50][D][uart_debug:158]: <<< "\x02" [19:00:50][D][uart_debug:158]: >>> "\x10" [19:00:51][D][uart_debug:158]: <<< "a\x16\x05\x10\x03a" [19:00:54][D][uart_debug:158]: <<< "\x02" [19:00:55][D][uart_debug:158]: >>> "\x10" [19:00:55][D][uart_debug:158]: <<< "\x11\x057\x10\x030" [19:01:00][D][uart_debug:158]: <<< "\x02" [19:01:00][D][uart_debug:158]: >>> "\x10" [19:01:01][D][uart_debug:158]: <<< "\b\x03\xAC\x10\x03\xB4" [19:01:09][D][uart_debug:158]: <<< "\x02" [19:01:10][D][uart_debug:158]: >>> "\x10" [19:01:10][D][uart_debug:158]: <<< "\x11\x056\x10\x031" [19:01:20][D][uart_debug:158]: <<< "\x02" [19:01:20][D][uart_debug:158]: >>> "\x10" [19:01:21][D][uart_debug:158]: <<< "\b\x03\xAC\x10\x03\xB4" [19:01:24][D][uart_debug:158]: <<< "\x02" [19:01:25][D][uart_debug:158]: >>> "\x10" [19:01:25][D][uart_debug:158]: <<< "\x11\x055\x10\x032" [19:01:30][D][uart_debug:158]: <<< "\x02" [19:01:30][D][uart_debug:158]: >>> "\x10" [19:01:31][D][uart_debug:158]: <<< "a\x16\x04\x10\x03`" [19:01:40][D][uart_debug:158]: <<< "\x02" [19:01:40][D][uart_debug:158]: >>> "\x10" [19:01:40][D][uart_debug:158]: <<< "\x11\x054\x10\x033" [19:01:41][D][sensor:126]: 'M404 WiFi Signal': Sending state -80.00000 dBm with 0 decimals of accuracy
