(kicad_pcb (version 20211014) (generator pcbnew)
  (general
    (thickness 1.6)
  (paper "A4")
  (layers
    (0 "F.Cu" signal)
    (31 "B.Cu" signal)
    (32 "B.Adhes" user "B.Adhesive")
    (33 "F.Adhes" user "F.Adhesive")
    (34 "B.Paste" user)
    (35 "F.Paste" user)
    (36 "B.SilkS" user "B.Silkscreen")
    (37 "F.SilkS" user "F.Silkscreen")
    (38 "B.Mask" user)
    (39 "F.Mask" user)
    (40 "Dwgs.User" user "User.Drawings")
    (41 "Cmts.User" user "User.Comments")
    (42 "Eco1.User" user "User.Eco1")
    (43 "Eco2.User" user "User.Eco2")
    (44 "Edge.Cuts" user)
    (45 "Margin" user)
    (46 "B.CrtYd" user "B.Courtyard")
    (47 "F.CrtYd" user "F.Courtyard")
    (48 "B.Fab" user)
    (49 "F.Fab" user)
    (50 "User.1" user)
    (51 "User.2" user)
    (52 "User.3" user)
    (53 "User.4" user)
    (54 "User.5" user)
    (55 "User.6" user)
    (56 "User.7" user)
    (57 "User.8" user)
    (58 "User.9" user)
  (setup
    (stackup
      (layer "F.SilkS" (type "Top Silk Screen"))
      (layer "F.Paste" (type "Top Solder Paste"))
      (layer "F.Mask" (type "Top Solder Mask") (thickness 0.01))
      (layer "F.Cu" (type "copper") (thickness 0.035))
      (layer "dielectric 1" (type "core") (thickness 1.51) (material "FR4") (epsilon_r 4.5) (loss_tangent 0.02))
      (layer "B.Cu" (type "copper") (thickness 0.035))
      (layer "B.Mask" (type "Bottom Solder Mask") (thickness 0.01))
      (layer "B.Paste" (type "Bottom Solder Paste"))
      (layer "B.SilkS" (type "Bottom Silk Screen"))
      (copper_finish "None")
      (dielectric_constraints no)
    (pad_to_mask_clearance 0)
    (pcbplotparams
      (layerselection 0x00010fc_ffffffff)
      (disableapertmacros false)
      (usegerberextensions false)
      (usegerberattributes true)
      (usegerberadvancedattributes true)
      (creategerberjobfile true)
      (svguseinch false)
      (svgprecision 6)
      (excludeedgelayer true)
      (plotframeref false)
      (viasonmask false)
      (mode 1)
      (useauxorigin false)
      (hpglpennumber 1)
      (hpglpenspeed 20)
      (hpglpendiameter 15.000000)
      (dxfpolygonmode true)
      (dxfimperialunits true)
      (dxfusepcbnewfont true)
      (psnegative false)
      (psa4output false)
      (plotreference true)
      (plotvalue true)
      (plotinvisibletext false)
      (sketchpadsonfab false)
      (subtractmaskfromsilk true)
      (outputformat 1)
      (mirror false)
      (drillshape 0)
      (scaleselection 1)
      (outputdirectory "Panel/")
  (net 0 "")
  (net 1 "Net-(BT1-Pad2)")
  (net 2 "Net-(C2-Pad1)")
  (net 3 "Net-(C1-Pad2)")
  (net 4 "Net-(C6-Pad1)")
  (net 5 "Net-(C7-Pad1)")
  (net 6 "Net-(C8-Pad1)")
  (net 7 "Net-(C9-Pad2)")
  (net 8 "Net-(C10-Pad2)")
  (net 9 "Net-(C12-Pad1)")
  (net 10 "Net-(C14-Pad1)")
  (net 11 "Net-(BT1-Pad1)")
  (net 12 "Net-(C25-Pad1)")
  (net 13 "Net-(C27-Pad1)")
  (net 14 "Net-(C28-Pad2)")
  (net 15 "Net-(C3-Pad1)")
  (net 16 "Net-(D3-Pad1)")
  (net 17 "Net-(D3-Pad2)")
  (net 18 "Net-(D4-Pad2)")
  (net 19 "Net-(D5-Pad2)")
  (net 20 "Net-(D6-Pad1)")
  (net 21 "Net-(D7-Pad2)")
  (net 22 "Net-(D8-Pad1)")
  (net 23 "Net-(F2-Pad1)")
  (net 24 "Net-(F3-Pad1)")
  (net 25 "Net-(J3-Pad1)")
  (net 26 "Net-(J3-Pad3)")
  (net 27 "Net-(J3-Pad4)")
  (net 28 "Net-(J14-Pad13)")
  (net 29 "Net-(J14-Pad14)")
  (net 30 "Net-(J14-Pad15)")
  (net 31 "Net-(J14-Pad16)")
  (net 32 "Net-(J14-Pad17)")
  (net 33 "Net-(J14-Pad19)")
  (net 34 "Net-(J14-Pad20)")
  (net 35 "Net-(J15-Pad1)")
  (net 36 "Net-(J15-Pad3)")
  (net 37 "Net-(J15-Pad4)")
  (net 38 "unconnected-(K1-Pad12)")
  (net 39 "unconnected-(K2-Pad12)")
  (net 40 "Net-(Q1-Pad2)")
  (net 41 "Net-(Q2-Pad2)")
  (net 42 "Net-(Q3-Pad2)")
  (net 43 "Net-(Q4-Pad2)")
  (net 44 "Net-(C11-Pad1)")
  (net 45 "Net-(J4-Pad2)")
  (net 46 "Net-(R8-Pad2)")
  (net 47 "Net-(J4-Pad4)")
  (net 48 "Net-(R18-Pad1)")
  (net 49 "Net-(J5-Pad3)")
  (net 50 "Net-(R20-Pad1)")
  (net 51 "Net-(R21-Pad1)")
  (net 52 "Net-(R22-Pad1)")
  (net 53 "Net-(R24-Pad1)")
  (net 54 "Net-(R25-Pad1)")
  (net 55 "Net-(J4-Pad6)")
  (net 56 "Net-(R26-Pad2)")
  (net 57 "Net-(R27-Pad1)")
  (net 58 "Net-(R27-Pad2)")
  (net 59 "Net-(R28-Pad1)")
  (net 60 "Net-(R29-Pad1)")
  (net 61 "Net-(R30-Pad1)")
  (net 62 "Net-(R31-Pad1)")
  (net 63 "Net-(R32-Pad1)")
  (net 64 "Net-(R33-Pad1)")
  (net 65 "Net-(R34-Pad1)")
  (net 66 "Net-(R35-Pad1)")
  (net 67 "Net-(R37-Pad1)")
  (net 68 "Net-(R38-Pad1)")
  (net 69 "Net-(R39-Pad1)")
  (net 70 "Net-(R41-Pad1)")
  (net 71 "Net-(R42-Pad1)")
  (net 72 "Net-(R43-Pad1)")
  (net 73 "Net-(R44-Pad1)")
  (net 74 "Net-(R45-Pad1)")
  (net 75 "Net-(R46-Pad1)")
  (net 76 "Net-(R47-Pad1)")
  (net 77 "Net-(R48-Pad1)")
  (net 78 "Net-(R49-Pad1)")
  (net 79 "Net-(R50-Pad1)")
  (net 80 "unconnected-(U1-Pad2)")
  (net 81 "unconnected-(U1-Pad3)")
  (net 82 "Net-(U6-Pad1)")
  (net 83 "Net-(U6-Pad2)")
  (net 84 "unconnected-(U6-Pad7)")
  (net 85 "Net-(C20-Pad1)")
  (net 86 "Net-(C31-Pad2)")
  (net 87 "Net-(D11-Pad1)")
  (net 88 "Net-(D11-Pad2)")
  (net 89 "Net-(R53-Pad1)")
  (net 90 "Net-(J12-Pad1)")
  (net 91 "Net-(J12-Pad2)")
  (net 92 "Net-(J12-Pad3)")
  (net 93 "Net-(J12-Pad4)")
  (net 94 "Net-(J12-Pad5)")
  (net 95 "Net-(J12-Pad6)")
  (net 96 "Net-(D12-Pad1)")
  (net 97 "Net-(C36-Pad1)")
  (net 98 "Net-(F4-Pad2)")
  (net 99 "unconnected-(K3-Pad12)")
  (net 100 "Net-(Q5-Pad2)")
  (net 101 "Net-(R52-Pad2)")
  (net 102 "Net-(R16-Pad2)")
  (net 103 "Net-(D9-Pad1)")
  (net 104 "Net-(D15-Pad2)")
  (net 105 "Net-(D16-Pad2)")
  (net 106 "Net-(R14-Pad2)")
  (net 107 "Net-(R24-Pad2)")
  (net 108 "Net-(R28-Pad2)")
  (net 109 "Net-(R31-Pad2)")
  (net 110 "Net-(R34-Pad2)")
  (net 111 "Net-(R38-Pad2)")
  (net 112 "Net-(R41-Pad2)")
  (net 113 "Net-(R54-Pad1)")
  (net 114 "Net-(RV1-Pad2)")
  (net 115 "unconnected-(U5-Pad7)")
  (net 116 "unconnected-(U5-Pad8)")
  (net 117 "unconnected-(U5-Pad9)")
  (net 118 "unconnected-(U5-Pad10)")
  (net 119 "Net-(J14-Pad18)")
  (net 120 "unconnected-(J12-Pad8)")
  (net 121 "Net-(D9-Pad2)")
  (net 122 "Net-(D10-Pad2)")
  (net 123 "unconnected-(J13-Pad8)")
  (net 124 "Net-(D13-Pad1)")
  (net 125 "Net-(J13-Pad6)")
  (net 126 "Net-(J13-Pad5)")
  (net 127 "Net-(J13-Pad4)")
  (net 128 "Net-(J13-Pad3)")
  (net 129 "Net-(J13-Pad2)")
  (net 130 "Net-(J13-Pad1)")
  (net 131 "Net-(D10-Pad1)")
  (net 132 "Net-(J12-Pad10)")
  (net 133 "Net-(D13-Pad2)")
  (net 134 "Net-(R55-Pad1)")
  (net 135 "Net-(J13-Pad9)")
  (footprint "Crystal:Crystal_HC49-4H_Vertical" (layer "F.Cu")
    (tedit 5A1AD3B7) (tstamp 007adc57-ad08-489e-b716-a1c2e3048a89)
    (at 25.527 94.887 90)
    (descr "Crystal THT HC-49-4H http://5hertz.com/pdfs/04404_D.pdf")
    (tags "THT crystalHC-49-4H")
    (property "Sheetfile" "Lauflicht_Steuerplatine.kicad_sch")
    (property "Sheetname" "")
    (path "/054a2c4f-d746-4821-a59d-70ff1ba60bec")
    (attr through_hole)
    (fp_text reference "Y2" (at 0.272 -3.525 90) (layer "F.SilkS")
      (effects (font (size 1 1) (thickness 0.15)))
      (tstamp 506ca2b0-39aa-4453-a619-4c6a97f598d7)
    (fp_text value "Crystal" (at 2.44 3.525 90) (layer "F.Fab")
      (tstamp 158ee4e7-7747-49ec-9ab5-fa1371f23e15)
    (fp_text user "${REFERENCE}" (at 2.44 0 90) (layer "F.Fab")
      (tstamp cfb6ba8b-3718-4b31-a120-d13e2196ca8e)
    (fp_line (start -0.76 -2.525) (end 5.64 -2.525) (layer "F.SilkS") (width 0.12) (tstamp 2eadb466-850f-4eaa-893d-69cdd94f5466))
    (fp_line (start -0.76 2.525) (end 5.64 2.525) (layer "F.SilkS") (width 0.12) (tstamp 920f82d6-6f42-4cc1-b388-7926dd4d27f9))
    (fp_arc (start 5.64 -2.525) (mid 8.165 0) (end 5.64 2.525) (layer "F.SilkS") (width 0.12) (tstamp 984836e4-f26f-4726-918b-868966b5db06))
    (fp_arc (start -0.76 2.525) (mid -3.285 0) (end -0.76 -2.525) (layer "F.SilkS") (width 0.12) (tstamp dfc90506-6df0-4e0c-8e76-87ee957ca528))
    (fp_line (start -3.6 2.8) (end 8.5 2.8) (layer "F.CrtYd") (width 0.05) (tstamp 762af22e-ac85-4bbf-950b-40967c99dbdb))
    (fp_line (start 8.5 -2.8) (end -3.6 -2.8) (layer "F.CrtYd") (width 0.05) (tstamp 930749ad-5f9f-447b-a48a-d1874a9bd6b0))
    (fp_line (start 8.5 2.8) (end 8.5 -2.8) (layer "F.CrtYd") (width 0.05) (tstamp d843bfba-b5e3-4811-ab73-0cda7708c0b6))
    (fp_line (start -3.6 -2.8) (end -3.6 2.8) (layer "F.CrtYd") (width 0.05) (tstamp e18fad80-f04c-4186-8213-cb3ce2e35bc2))
    (fp_line (start -0.76 2.325) (end 5.64 2.325) (layer "F.Fab") (width 0.1) (tstamp 16ec1b98-2747-4378-9d87-389f133f8af6))
    (fp_line (start -0.76 -2.325) (end 5.64 -2.325) (layer "F.Fab") (width 0.1) (tstamp 48cd6f4b-feea-4fe3-bd50-c73c080e95fc))
    (fp_line (start -0.56 2) (end 5.44 2) (layer "F.Fab") (width 0.1) (tstamp a65cd17b-cbad-4cd9-8e8d-8a1f3d3aaa09))
    (fp_line (start -0.56 -2) (end 5.44 -2) (layer "F.Fab") (width 0.1) (tstamp ef258e10-1e31-469f-a423-d99bb37952ce))
    (fp_arc (start -0.76 2.325) (mid -3.085 0) (end -0.76 -2.325) (layer "F.Fab") (width 0.1) (tstamp 98e610ee-9980-41f0-9011-31b4bd67e793))
    (fp_arc (start 5.64 -2.325) (mid 7.965 0) (end 5.64 2.325) (layer "F.Fab") (width 0.1) (tstamp af1cc9d1-35a4-4f29-af73-a801add47b7a))
    (fp_arc (start -0.56 2) (mid -2.56 0) (end -0.56 -2) (layer "F.Fab") (width 0.1) (tstamp b50b75ab-f9b1-4ab4-8355-83431295de98))
    (fp_arc (start 5.44 -2) (mid 7.44 0) (end 5.44 2) (layer "F.Fab") (width 0.1) (tstamp fab38428-7094-4c0a-add5-b13ec6a08dd2))
    (pad "1" thru_hole circle (at 0 0 90) (size 1.5 1.5) (drill 0.8) (layers *.Cu *.Mask)
      (net 14 "Net-(C28-Pad2)") (pinfunction "1") (pintype "passive") (tstamp 4f19de3a-d07a-4f93-8f2d-366989b3c9b8))
    (pad "2" thru_hole circle (at 4.88 0 90) (size 1.5 1.5) (drill 0.8) (layers *.Cu *.Mask)
      (net 13 "Net-(C27-Pad1)") (pinfunction "2") (pintype "passive") (tstamp fce99802-d71e-4566-b825-1fc429639556))
    (model "${KICAD6_3DMODEL_DIR}/Crystal.3dshapes/Crystal_HC49-4H_Vertical.wrl"
      (offset (xyz 0 0 0))
      (scale (xyz 1 1 1))
      (rotate (xyz 0 0 0))
  (footprint "Resistor_SMD:R_1210_3225Metric_Pad1.30x2.65mm_HandSolder" (layer "F.Cu")
    (tedit 5F68FEEE) (tstamp 0834879c-04aa-455e-801b-b2f4945c2083)
    (at 44.069 61.722 180)
    (descr "Resistor SMD 1210 (3225 Metric), square (rectangular) end terminal, IPC_7351 nominal with elongated pad for handsoldering. (Body size source: IPC-SM-782 page 72, https://www.pcb-3d.com/wordpress/wp-content/uploads/ipc-sm-782a_amendment_1_and_2.pdf), generated with kicad-footprint-generator")
    (tags "resistor handsolder")
    (path "/e8c61760-0ad6-4ce9-a7fc-01a1015e5774")
    (attr smd)
    (fp_text reference "R33" (at 3.302 0 90) (layer "F.SilkS")
      (tstamp 8f7412f0-d751-4929-bc86-74f619874166)
    (fp_text value "SMD 1/4W 10k" (at 0 2.28) (layer "F.Fab")
      (tstamp a34e04f9-4aaf-4839-8efa-8e79ed3afd1a)
    (fp_text user "${REFERENCE}" (at 0 0) (layer "F.Fab")
      (effects (font (size 0.8 0.8) (thickness 0.12)))
      (tstamp 1a0016d7-2b92-4b2d-91e6-3a56fca081ee)
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp 1a00bba8-929e-4f09-bbdb-abbae8bbe0c1))
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 9785d6cf-8a03-439c-915f-e87b8dc4dadc))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 16354bf1-4a4f-409f-acc9-f02d7d54113e))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp acfef3a1-b350-42b5-98d1-e5febc97c202))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp e0377b67-baea-4a53-9fc7-54aca1e5a3b7))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp fbf1491d-8ecd-472e-ba34-dc89e950ce2e))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp c7ac8298-d5e7-4efc-9bf4-0aaa0a4a5ee4))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp d3a00384-e556-4eb8-aaae-c452b27de93c))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp d9bbb698-38f8-4854-bbdf-c9cf3e0c8b30))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp e56d63b1-69a7-4bf9-b7f1-e8516b97a6c1))
    (pad "1" smd roundrect (at -1.55 0 180) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 64 "Net-(R33-Pad1)") (pintype "passive") (tstamp d962cad0-3732-4550-bd2f-f3d162364421))
    (pad "2" smd roundrect (at 1.55 0 180) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 85 "Net-(C20-Pad1)") (pintype "passive") (tstamp d1212a72-a0a9-411f-b0d4-73e77e0dd020))
    (model "${KICAD6_3DMODEL_DIR}/Resistor_SMD.3dshapes/R_1210_3225Metric.wrl"
      (scale (xyz 1 1 1))
  (footprint "Diode_THT:D_DO-35_SOD27_P7.62mm_Horizontal" (layer "F.Cu")
    (tedit 5AE50CD5) (tstamp 090774af-3c5d-4173-b433-1f4138345b9c)
    (at 99.441 55.88 180)
    (descr "Diode, DO-35_SOD27 series, Axial, Horizontal, pin pitch=7.62mm, , length*diameter=4*2mm^2, , http://www.diodes.com/_files/packages/DO-35.pdf")
    (tags "Diode DO-35_SOD27 series Axial Horizontal pin pitch 7.62mm  length 4mm diameter 2mm")
    (path "/baef9372-8f33-4005-b080-a297b7d97685")
    (attr through_hole)
    (fp_text reference "D7" (at 9.652 0.254 90) (layer "F.SilkS")
      (tstamp c1462e4d-5d56-4e82-ac71-9cdcf7a1307a)
    (fp_text value "1N4148" (at 3.81 2.12) (layer "F.Fab")
      (tstamp 4815d02a-cc26-4137-ade2-bb208cac1fb7)
    (fp_text user "K" (at 0 -2.032 90) (layer "F.SilkS")
      (tstamp e20ea462-52b4-4463-bd9a-e8cd015f85c5)
    (fp_text user "K" (at 0 -1.8) (layer "F.Fab")
      (tstamp 68ca2e8d-be11-42a5-a9a7-d3480ebbd3f2)
    (fp_text user "${REFERENCE}" (at 4.11 0) (layer "F.Fab")
      (tstamp 83164d77-bf37-4d5f-8f96-e08de3adfa79)
    (fp_line (start 6.58 0) (end 5.93 0) (layer "F.SilkS") (width 0.12) (tstamp 0f93cccd-257c-4932-9cc5-da4e89b3cc9f))
    (fp_line (start 1.69 -1.12) (end 1.69 1.12) (layer "F.SilkS") (width 0.12) (tstamp 1680d595-5e09-4c0d-903c-9f0e881d4217))
    (fp_line (start 2.41 -1.12) (end 2.41 1.12) (layer "F.SilkS") (width 0.12) (tstamp 3043976d-be16-4519-bbe4-7b974e04d62e))
    (fp_line (start 1.04 0) (end 1.69 0) (layer "F.SilkS") (width 0.12) (tstamp 329ecad6-bed5-44f0-b55a-3f7cf5b2221a))
    (fp_line (start 2.53 -1.12) (end 2.53 1.12) (layer "F.SilkS") (width 0.12) (tstamp 35c0db30-250a-4aab-900f-ac0fb756dee9))
    (fp_line (start 1.69 1.12) (end 5.93 1.12) (layer "F.SilkS") (width 0.12) (tstamp 5ad3a8da-8047-4720-b64a-8d1d8e2fac5d))
    (fp_line (start 5.93 1.12) (end 5.93 -1.12) (layer "F.SilkS") (width 0.12) (tstamp 5e8ea025-a10f-42ee-977c-edffeb87ebe4))
    (fp_line (start 2.29 -1.12) (end 2.29 1.12) (layer "F.SilkS") (width 0.12) (tstamp a6e0f64a-e32a-4fb0-9fc6-44a09d035be4))
    (fp_line (start 5.93 -1.12) (end 1.69 -1.12) (layer "F.SilkS") (width 0.12) (tstamp cf84c001-8bbe-4c26-abb3-1d5c2e9e162c))
    (fp_line (start -1.05 -1.25) (end -1.05 1.25) (layer "F.CrtYd") (width 0.05) (tstamp 1d437422-36c4-4b3a-a8cb-ba25c28d9189))
    (fp_line (start 8.67 1.25) (end 8.67 -1.25) (layer "F.CrtYd") (width 0.05) (tstamp 899092e0-8138-4eab-8c91-f5d160d060c3))
    (fp_line (start 8.67 -1.25) (end -1.05 -1.25) (layer "F.CrtYd") (width 0.05) (tstamp b5c7cd7f-3cba-41cb-9b66-b0812fbb9fd4))
    (fp_line (start -1.05 1.25) (end 8.67 1.25) (layer "F.CrtYd") (width 0.05) (tstamp f54e6e90-f833-4cc9-9307-370b1db0377e))
    (fp_line (start 0 0) (end 1.81 0) (layer "F.Fab") (width 0.1) (tstamp 1d7d9646-8065-4c3e-9dd2-a2a08864772e))
    (fp_line (start 1.81 -1) (end 1.81 1) (layer "F.Fab") (width 0.1) (tstamp 309e3232-b03f-401a-a869-42f3cbb6cd96))
    (fp_line (start 1.81 1) (end 5.81 1) (layer "F.Fab") (width 0.1) (tstamp 5a193252-4907-4a5a-9da0-a025e43b0522))
    (fp_line (start 5.81 -1) (end 1.81 -1) (layer "F.Fab") (width 0.1) (tstamp 6c2e6011-ebb5-4bb3-9c77-0615e1503b50))
    (fp_line (start 7.62 0) (end 5.81 0) (layer "F.Fab") (width 0.1) (tstamp 70adeda6-1064-4c93-8277-4e18d26c599a))
    (fp_line (start 5.81 1) (end 5.81 -1) (layer "F.Fab") (width 0.1) (tstamp 743e647d-c5e1-4e87-86ed-a8c0b5295dfd))
    (fp_line (start 2.41 -1) (end 2.41 1) (layer "F.Fab") (width 0.1) (tstamp 78e67145-33e6-4d28-879e-2e6284181098))
    (fp_line (start 2.31 -1) (end 2.31 1) (layer "F.Fab") (width 0.1) (tstamp 838ccb8b-6873-47b3-8418-bdfa400acd6b))
    (fp_line (start 2.51 -1) (end 2.51 1) (layer "F.Fab") (width 0.1) (tstamp 9de50d20-8739-49b2-8d86-7d76f7e964c5))
    (pad "1" thru_hole rect (at 0 0 180) (size 1.6 1.6) (drill 0.8) (layers *.Cu *.Mask)
      (net 17 "Net-(D3-Pad2)") (pinfunction "K") (pintype "passive") (tstamp 36225495-af4a-46e0-93a9-923c95610d06))
    (pad "2" thru_hole oval (at 7.62 0 180) (size 1.6 1.6) (drill 0.8) (layers *.Cu *.Mask)
      (net 21 "Net-(D7-Pad2)") (pinfunction "A") (pintype "passive") (tstamp 83c637ef-5db5-45b0-8617-000f3f33a188))
    (model "${KICAD6_3DMODEL_DIR}/Diode_THT.3dshapes/D_DO-35_SOD27_P7.62mm_Horizontal.wrl"
      (scale (xyz 1 1 1))
  (footprint "Library:OMR B3F-4000" (layer "F.Cu")
    (tedit 5D160D14) (tstamp 09fa4f45-1325-4e77-9167-d19ee1e5c88f)
    (at 100.049 157.56)
    (descr "SW PUSH 12mm https://www.e-switch.com/system/asset/product_line/data_sheet/143/TL1100.pdf")
    (tags "tact sw push 12mm")
    (path "/2dbb4bd6-c24e-44e1-b9ce-2eda71bd571d")
    (attr through_hole)
    (fp_text reference "SW3" (at -1.497 2.587 180) (layer "F.SilkS")
      (tstamp 8ad7139d-7c71-41c3-8be9-1f74c2315536)
    (fp_text value "X10" (at 6.62 9.93) (layer "F.Fab")
      (tstamp 6bee2a1d-086d-49f6-8e31-689219711daa)
    (fp_text user "${REFERENCE}" (at 6.35 2.54) (layer "F.Fab")
      (tstamp 117ee852-e45f-4a79-a842-158f5accce7b)
    (fp_line (start 0.1 8.65) (end 0.1 6.2) (layer "F.SilkS") (width 0.12) (tstamp 1856215d-86fc-4807-a7f3-fb5e090e29df))
    (fp_line (start 12.4 6.2) (end 12.4 8.65) (layer "F.SilkS") (width 0.12) (tstamp 486314d0-c9e9-4943-95e7-c48fd99a0416))
    (fp_line (start 12.4 8.65) (end 0.1 8.65) (layer "F.SilkS") (width 0.12) (tstamp 7fee6ea4-c96b-4bee-810b-798bc238604e))
    (fp_line (start 0.1 -1.1) (end 0.1 -3.65) (layer "F.SilkS") (width 0.12) (tstamp a8ca2d9b-4482-4587-9753-bde1a5775580))
    (fp_line (start 12.4 1.1) (end 12.4 3.8) (layer "F.SilkS") (width 0.12) (tstamp b8bc97c0-9a3f-49ef-adb2-477014101138))
    (fp_line (start 12.4 -3.65) (end 12.4 -1.1) (layer "F.SilkS") (width 0.12) (tstamp d8878518-2f2e-4ce2-909e-555f2aa66329))
    (fp_line (start 0.1 3.8) (end 0.1 1.3) (layer "F.SilkS") (width 0.12) (tstamp db93991f-ac19-4fa5-90cc-3be5e7eb8323))
    (fp_line (start 0.1 -3.65) (end 12.4 -3.65) (layer "F.SilkS") (width 0.12) (tstamp fc80ecb1-4e8e-4d12-9b80-148a4513f92a))
    (fp_circle (center 6.35 2.54) (end 10.16 5.08) (layer "F.SilkS") (width 0.12) (fill none) (tstamp 486fb1ec-a2e7-4edd-befd-a6b0e8253942))
    (fp_line (start -1.77 -3.75) (end 14.25 -3.75) (layer "F.CrtYd") (width 0.05) (tstamp 2a321a62-242d-4200-949b-2a78253397c3))
    (fp_line (start 14.25 8.75) (end 14.25 -3.75) (layer "F.CrtYd") (width 0.05) (tstamp 7f4886d8-64b6-4075-8d52-9b320ab1196e))
    (fp_line (start 14.25 8.75) (end -1.77 8.75) (layer "F.CrtYd") (width 0.05) (tstamp 8220b954-4be3-4584-a925-2bd6c0f6741c))
    (fp_line (start -1.77 -3.75) (end -1.77 8.75) (layer "F.CrtYd") (width 0.05) (tstamp 9fb81ead-0a65-4c16-8dbd-515c89e48469))
    (fp_line (start 0.25 -3.5) (end 12.25 -3.5) (layer "F.Fab") (width 0.1) (tstamp 17130622-57be-4ae2-91c0-3442d0d90b88))
    (fp_line (start 0.25 -3.5) (end 0.25 8.5) (layer "F.Fab") (width 0.1) (tstamp a0b1d4db-ed05-4312-8eb0-a44ec301e2b2))
    (fp_line (start 12.25 -3.5) (end 12.25 8.5) (layer "F.Fab") (width 0.1) (tstamp c758de8e-4ec6-430d-8eba-5bfe9a8013c1))
    (fp_line (start 0.25 8.5) (end 12.25 8.5) (layer "F.Fab") (width 0.1) (tstamp d9cf5c0a-af89-4aca-8ff8-49de6298cb26))
    (pad "1" thru_hole oval (at 12.5 5) (size 3.048 1.85) (drill 1.3) (layers *.Cu *.Mask)
      (net 125 "Net-(J13-Pad6)") (pinfunction "A") (pintype "passive") (tstamp b65aa23b-96e5-4c74-8999-5e1f918bdfd4))
    (pad "2" thru_hole oval (at 0 5) (size 3.048 1.85) (drill 1.3) (layers *.Cu *.Mask)
      (net 125 "Net-(J13-Pad6)") (pinfunction "A") (pintype "passive") (tstamp 758a6e37-f39d-4468-a28c-9c884117685e))
    (pad "3" thru_hole oval (at 12.5 0) (size 3.048 1.85) (drill 1.3) (layers *.Cu *.Mask)
      (net 128 "Net-(J13-Pad3)") (pinfunction "B") (pintype "passive") (tstamp 8d12829c-c7a3-4c1a-8aef-e9057cfee4a2))
    (pad "4" thru_hole oval (at 0 0) (size 3.048 1.85) (drill 1.3) (layers *.Cu *.Mask)
      (net 128 "Net-(J13-Pad3)") (pinfunction "B") (pintype "passive") (tstamp a0b1b577-175c-4c57-9964-d7742e93a0eb))
    (model "${KICAD6_3DMODEL_DIR}/Button_Switch_THT.3dshapes/SW_PUSH-12mm.wrl"
      (scale (xyz 1 1 1))
  (footprint "Fuse:Fuseholder_Cylinder-5x20mm_Schurter_0031_8201_Horizontal_Open" (layer "F.Cu")
    (tedit 5D717D34) (tstamp 0ab1ea0c-e5c4-4e94-a4ed-4c9fb545ed8b)
    (at 154.051 41.021 180)
    (descr "Fuseholder horizontal open, 5x20mm, 500V, 16A, Schurter 0031.8201, https://us.schurter.com/bundles/snceschurter/epim/_ProdPool_/newDS/en/typ_OGN.pdf")
    (tags "Fuseholder horizontal open 5x20 Schurter 0031.8201")
    (path "/01810933-c076-4bb6-8268-18f71e14c333")
    (attr through_hole)
    (fp_text reference "F3" (at 12.827 -5.969 180) (layer "F.SilkS")
      (tstamp 736b162b-7830-43e6-91c3-84fc4494de83)
    (fp_text value "Fuse" (at 11.25 6) (layer "F.Fab")
      (tstamp 7253bc80-9ddd-43ee-9257-07e56e2c2558)
    (fp_text user "${REFERENCE}" (at 11.25 4) (layer "F.Fab")
      (tstamp 7c2950bc-cf67-4e77-a2c7-c256e72462d7)
    (fp_line (start 22.61 -1.75) (end 22.61 -4.91) (layer "F.SilkS") (width 0.12) (tstamp 070ef19e-57ee-4c76-a40c-3dbdcca57dfd))
    (fp_line (start -0.11 -4.91) (end 22.61 -4.91) (layer "F.SilkS") (width 0.12) (tstamp 450925b7-fba2-4239-a2bd-07da0c2350fc))
    (fp_line (start 22.61 4.91) (end 22.61 1.75) (layer "F.SilkS") (width 0.12) (tstamp 4d81961a-6f5c-48a6-9a58-22e74e4aaf70))
    (fp_line (start -0.11 4.91) (end -0.11 1.75) (layer "F.SilkS") (width 0.12) (tstamp 7b71e53e-3bd9-4e60-baed-a11f9bee0dbc))
    (fp_line (start -0.11 -1.75) (end -0.11 -4.91) (layer "F.SilkS") (width 0.12) (tstamp 7e61a689-4e42-4f4e-a4c9-d57e85dbee57))
    (fp_line (start -0.11 4.91) (end 22.61 4.91) (layer "F.SilkS") (width 0.12) (tstamp ec7f9369-da71-4c1c-8b15-6865944404e0))
    (fp_line (start -1.75 5.05) (end -1.75 -5.05) (layer "F.CrtYd") (width 0.05) (tstamp 00f259e0-582f-43bb-9b22-ab598c1faa1e))
    (fp_line (start -1.75 -5.05) (end 24.25 -5.05) (layer "F.CrtYd") (width 0.05) (tstamp 6aff44bd-498c-44b5-82e0-2f2db9cd4642))
    (fp_line (start 24.25 -5.05) (end 24.25 5.05) (layer "F.CrtYd") (width 0.05) (tstamp ded96a48-6ab1-422f-8625-9e91bbd42e7a))
    (fp_line (start 24.25 5.05) (end -1.75 5.05) (layer "F.CrtYd") (width 0.05) (tstamp ff5826d1-d2e8-40fb-8e50-05dc6891305f))
    (fp_line (start 22.5 4.8) (end 22.5 -4.8) (layer "F.Fab") (width 0.1) (tstamp 5506e891-afd6-4b5d-81bb-ef86e421ca4d))
    (fp_line (start 22.5 -4.8) (end 0 -4.8) (layer "F.Fab") (width 0.1) (tstamp 79a64bac-538b-4048-a833-e41e9af5a690))
    (fp_line (start 0 -4.8) (end 0 4.8) (layer "F.Fab") (width 0.1) (tstamp 942351e7-b15e-4003-8fc5-5d11d41c128d))
    (fp_line (start 0 4.8) (end 22.5 4.8) (layer "F.Fab") (width 0.1) (tstamp b92a9580-2996-4aba-94a2-fa00e69d4275))
    (pad "" np_thru_hole circle (at 11.25 0 180) (size 2.7 2.7) (drill 2.7) (layers *.Cu *.Mask) (tstamp b8b3d37c-3bc8-4ce1-b176-7258b997aff9))
    (pad "1" thru_hole circle (at 0 0 180) (size 3 3) (drill 1.3) (layers *.Cu *.Mask)
      (net 24 "Net-(F3-Pad1)") (pintype "passive") (tstamp 19517cb0-1cab-4077-9662-1a0fd4cd4e04))
    (pad "2" thru_hole circle (at 22.5 0 180) (size 3 3) (drill 1.3) (layers *.Cu *.Mask)
      (net 44 "Net-(C11-Pad1)") (pintype "passive") (tstamp f5252df1-04de-4ab3-a512-8dcf11499bb4))
    (model "${KICAD6_3DMODEL_DIR}/Fuse.3dshapes/Fuseholder_Cylinder-5x20mm_Schurter_0031_8201_Horizontal_Open.wrl"
      (scale (xyz 1 1 1))
  (footprint "Capacitor_SMD:C_1206_3216Metric_Pad1.33x1.80mm_HandSolder" (layer "F.Cu")
    (tedit 5F68FEEF) (tstamp 0c7572a4-d696-477f-a1e3-6f148cd3c92e)
    (at 86.741 48.641 -90)
    (descr "Capacitor SMD 1206 (3216 Metric), square (rectangular) end terminal, IPC_7351 nominal with elongated pad for handsoldering. (Body size source: IPC-SM-782 page 76, https://www.pcb-3d.com/wordpress/wp-content/uploads/ipc-sm-782a_amendment_1_and_2.pdf), generated with kicad-footprint-generator")
    (tags "capacitor handsolder")
    (path "/6f9c31d1-d80e-4b28-b04d-eeefb7a3d16c")
    (attr smd)
    (fp_text reference "C34" (at -0.127 2.032 -90) (layer "F.SilkS")
      (tstamp 2fef0c49-1fbd-430a-87a1-3a392dbe9f09)
    (fp_text value "100n 25V" (at 0 1.85 90) (layer "F.Fab")
      (tstamp 1582c8d6-3555-4e94-85bf-3e3fa1e667f9)
    (fp_text user "${REFERENCE}" (at 0 0 90) (layer "F.Fab")
      (tstamp 2b854fd1-b5ad-4770-929f-47aa8ac763c3)
    (fp_line (start -0.711252 -0.91) (end 0.711252 -0.91) (layer "F.SilkS") (width 0.12) (tstamp 4252e383-a4db-4aba-9f50-b236fa869230))
    (fp_line (start -0.711252 0.91) (end 0.711252 0.91) (layer "F.SilkS") (width 0.12) (tstamp 92d9d9f7-5062-4a9a-b6ce-2530f934d719))
    (fp_line (start 2.48 1.15) (end -2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp 3401991d-5823-42ca-ba1d-2b1d097fa089))
    (fp_line (start -2.48 -1.15) (end 2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp 34bda435-aa26-4186-80f1-83bf9d279300))
    (fp_line (start -2.48 1.15) (end -2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp a1700cdf-ddf4-476e-895c-28abf7139f91))
    (fp_line (start 2.48 -1.15) (end 2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp b0f2fca6-f6e0-497b-895d-9ae15e47b2ea))
    (fp_line (start -1.6 0.8) (end -1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp 1a111731-8443-451e-9c31-d99eed9cb42d))
    (fp_line (start 1.6 0.8) (end -1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp 95000a54-85db-40af-a7c3-fc71d46af17a))
    (fp_line (start -1.6 -0.8) (end 1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp cefe4c8b-870a-4de9-af1b-df48fd7e2cb0))
    (fp_line (start 1.6 -0.8) (end 1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp da711479-6193-43ca-a276-9a1be45cdd02))
    (pad "1" smd roundrect (at -1.5625 0 270) (size 1.325 1.8) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1886792453)
      (net 3 "Net-(C1-Pad2)") (pintype "passive") (tstamp e2787c81-9b20-4772-a827-b0a4c37a715d))
    (pad "2" smd roundrect (at 1.5625 0 270) (size 1.325 1.8) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1886792453)
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp 0bfae083-dd8d-43e8-98a4-7590da0d639a))
    (model "${KICAD6_3DMODEL_DIR}/Capacitor_SMD.3dshapes/C_1206_3216Metric.wrl"
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp 0f1e35f1-1572-4b9c-8b06-a5ad79d83447)
    (at 45.974 55.779 90)
    (path "/694a455b-94ba-4ac1-95dc-b5a4ee62e240")
    (attr smd)
    (fp_text reference "R37" (at 0 -2.413 90) (layer "F.SilkS")
      (tstamp e34b9c0c-dc36-46db-b367-1c6297c33a66)
    (fp_text value "SMD 1/4W 10k" (at 0 2.28 90) (layer "F.Fab")
      (tstamp e5e37bb8-ff1b-4086-8bc7-5786bc8b7b1f)
      (tstamp ec673d23-e676-42bc-9b18-63d8a9b15144)
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp 24b2ceb2-ad0e-42d6-b6d2-9816272d1401))
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp d9b05dd2-b2e6-4a71-9ace-7fc68b7ad830))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 05fad9a6-9edf-4a9f-8395-987bb4cadf26))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 6ba2e1ea-1bc5-49df-bf87-35a2415f4285))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 9483ed2b-13ab-442b-ba1c-406c1aeaa1f5))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp c0c8dcf6-83cf-4826-9d3a-0779b4331e8e))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 03b77448-6de5-4880-a0d7-051a86cfbdcc))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 3dfe189f-8c56-4420-bfe6-ae8b66ae62ba))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 60f646c1-fcf3-4c1f-8b8e-b92b69caabae))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp dbdbf83a-9132-4ea5-8566-8d386d137dd7))
    (pad "1" smd roundrect (at -1.55 0 90) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 67 "Net-(R37-Pad1)") (pintype "passive") (tstamp 9a920c31-3cda-47b4-8cb1-0213ccc7123c))
    (pad "2" smd roundrect (at 1.55 0 90) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 85 "Net-(C20-Pad1)") (pintype "passive") (tstamp bf61090e-eac7-4e61-9a4c-900582f5c254))
      (scale (xyz 1 1 1))
  (footprint "Capacitor_THT:C_Disc_D5.0mm_W2.5mm_P2.50mm" (layer "F.Cu")
    (tedit 5AE50EF0) (tstamp 1613293f-1497-4eab-a086-affe20c673e3)
    (at 25.761 100.33 180)
    (descr "C, Disc series, Radial, pin pitch=2.50mm, , diameter*width=5*2.5mm^2, Capacitor, http://cdn-reichelt.de/documents/datenblatt/B300/DS_KERKO_TC.pdf")
    (tags "C Disc series Radial pin pitch 2.50mm  diameter 5mm width 2.5mm Capacitor")
    (path "/fcd968cd-593e-4b28-af23-8684c44f45dc")
    (attr through_hole)
    (fp_text reference "C28" (at 4.679 0 90) (layer "F.SilkS")
      (tstamp b9186d98-d95c-473d-a1ac-a0d02d4ef57d)
    (fp_text value " " (at 1.25 2.5) (layer "F.Fab")
      (tstamp 8bdae595-e405-43a0-9fef-ea05eb21493e)
    (fp_text user "${REFERENCE}" (at 1.25 0) (layer "F.Fab")
      (tstamp 40f169d5-3b77-44c7-9cde-a17d1254aade)
    (fp_line (start -1.37 1.37) (end 3.87 1.37) (layer "F.SilkS") (width 0.12) (tstamp 269d8ddd-4dd0-4a95-8544-926f762ec9d8))
    (fp_line (start 3.87 -1.37) (end 3.87 1.37) (layer "F.SilkS") (width 0.12) (tstamp 4bd9e633-c816-4804-93f9-1a368a81d308))
    (fp_line (start -1.37 -1.37) (end 3.87 -1.37) (layer "F.SilkS") (width 0.12) (tstamp 7d4b4d4c-c550-418e-af1d-62f1d721a3f6))
    (fp_line (start -1.37 -1.37) (end -1.37 1.37) (layer "F.SilkS") (width 0.12) (tstamp cc70fa40-6411-4d5e-8274-96f943bfa415))
    (fp_line (start 4 1.5) (end 4 -1.5) (layer "F.CrtYd") (width 0.05) (tstamp 20923c48-0326-4c2a-83e6-0653f56c4ba1))
    (fp_line (start -1.5 -1.5) (end -1.5 1.5) (layer "F.CrtYd") (width 0.05) (tstamp 4b1a82b2-5a74-44ec-a3fa-d76214d284a3))
    (fp_line (start -1.5 1.5) (end 4 1.5) (layer "F.CrtYd") (width 0.05) (tstamp 9626dda7-7432-4239-89e2-5cbcbfa275cf))
    (fp_line (start 4 -1.5) (end -1.5 -1.5) (layer "F.CrtYd") (width 0.05) (tstamp 9fdf5fde-695c-4b7c-8773-4ec7db1fd36d))
    (fp_line (start -1.25 -1.25) (end -1.25 1.25) (layer "F.Fab") (width 0.1) (tstamp 128651c1-37e4-42b4-9261-e7189687c91d))
    (fp_line (start 3.75 1.25) (end 3.75 -1.25) (layer "F.Fab") (width 0.1) (tstamp 57e8d05c-874e-4c1f-b23a-e0fd42c9f18b))
    (fp_line (start 3.75 -1.25) (end -1.25 -1.25) (layer "F.Fab") (width 0.1) (tstamp 782f38f7-6fed-4040-9638-6a9a8e46ba10))
    (fp_line (start -1.25 1.25) (end 3.75 1.25) (layer "F.Fab") (width 0.1) (tstamp 9eb0f338-71d3-4ad1-8990-d7af43f8cb47))
    (pad "1" thru_hole circle (at 0 0 180) (size 1.6 1.6) (drill 0.8) (layers *.Cu *.Mask)
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp 59125292-901e-4d73-b2d9-1821ee376b00))
    (pad "2" thru_hole circle (at 2.5 0 180) (size 1.6 1.6) (drill 0.8) (layers *.Cu *.Mask)
      (net 14 "Net-(C28-Pad2)") (pintype "passive") (tstamp 63575f9d-b4bf-466f-bf43-cb111e18d399))
    (model "${KICAD6_3DMODEL_DIR}/Capacitor_THT.3dshapes/C_Disc_D5.0mm_W2.5mm_P2.50mm.wrl"
      (scale (xyz 1 1 1))
  (footprint "TerminalBlock_RND:TerminalBlock_RND_205-00001_1x02_P5.00mm_Horizontal" (layer "F.Cu")
    (tedit 5B294F8C) (tstamp 168fa224-1963-4f2e-9b95-8dc6274a09df)
    (at 165.981 80.986 90)
    (descr "terminal block RND 205-00001, 2 pins, pitch 5mm, size 10x9mm^2, drill diamater 1.3mm, pad diameter 2.5mm, see http://cdn-reichelt.de/documents/datenblatt/C151/RND_205-00001_DB_EN.pdf, script-generated using https://github.com/pointhi/kicad-footprint-generator/scripts/TerminalBlock_RND")
    (tags "THT terminal block RND 205-00001 pitch 5mm size 10x9mm^2 drill 1.3mm pad 2.5mm")
    (path "/c73ae70e-afd1-4d0e-83e9-451014bbbd91")
    (attr through_hole)
    (fp_text reference "J9" (at 2.5 -6.06 90) (layer "F.SilkS")
      (tstamp a6c56a81-d935-4b81-98a3-6dfb40f41370)
    (fp_text value "DC 21V Out" (at 2.5 5.06 90) (layer "F.Fab")
      (tstamp 5e499a40-1a6c-4b69-98de-5b6560556472)
    (fp_text user "${REFERENCE}" (at 2.5 -6.06 90) (layer "F.Fab")
      (tstamp 7bac799d-4d6f-4104-819b-2717c51689de)
    (fp_line (start 6.07 -1.275) (end 6.011 -1.216) (layer "F.SilkS") (width 0.12) (tstamp 13544e31-0dc5-4dfa-8ffe-08c76e886a9a))
    (fp_line (start 7.56 -5.06) (end 7.56 4.06) (layer "F.SilkS") (width 0.12) (tstamp 2c58e99f-922b-4fec-931f-f7771142b9df))
    (fp_line (start 3.99 1.216) (end 3.931 1.274) (layer "F.SilkS") (width 0.12) (tstamp 4e0fe88b-a23c-4a2e-92ad-cfb650688e14))
    (fp_line (start -2.8 2.56) (end -2.8 4.3) (layer "F.SilkS") (width 0.12) (tstamp 58ce7a79-0827-4d4a-80e6-4774370a3f4c))
    (fp_line (start -2.56 -5.06) (end 7.56 -5.06) (layer "F.SilkS") (width 0.12) (tstamp 699a5123-7c9c-4b47-9fa0-f2ca3a5e62f0))
    (fp_line (start -2.56 2.5) (end 7.56 2.5) (layer "F.SilkS") (width 0.12) (tstamp 825b9a2d-7eda-498e-95cc-8b6d57a9d4f0))
    (fp_line (start 3.82 0.976) (end 3.726 1.069) (layer "F.SilkS") (width 0.12) (tstamp 99e44e02-e55f-41f2-b50f-e9d9dac96c75))
    (fp_line (start -2.56 4.06) (end 7.56 4.06) (layer "F.SilkS") (width 0.12) (tstamp a8d22da3-7f5c-487a-99dd-588054b6573c))
    (fp_line (start 6.275 -1.069) (end 6.181 -0.976) (layer "F.SilkS") (width 0.12) (tstamp d3dbc546-9c67-4bc7-a16d-19c057e3f685))
    (fp_line (start -2.8 4.3) (end -1.3 4.3) (layer "F.SilkS") (width 0.12) (tstamp d52f1c09-3305-47f4-8d1a-3170a68dfaa7))
    (fp_line (start -2.56 -5.06) (end -2.56 4.06) (layer "F.SilkS") (width 0.12) (tstamp dce60dd1-31fb-4fb8-991a-901f72fbf5f2))
    (fp_arc (start 0.029383 1.68045) (mid -0.392304 1.634281) (end -0.789 1.484) (layer "F.SilkS") (width 0.12) (tstamp 1cabe825-bd16-4233-9347-ea5ad1f83209))
    (fp_arc (start -0.789089 -1.483953) (mid -0.00005 -1.680708) (end 0.789 -1.484) (layer "F.SilkS") (width 0.12) (tstamp 2dac5e98-2261-4b45-91f0-376ee4f8da47))
    (fp_arc (start 1.483953 -0.789089) (mid 1.680708 -0.00005) (end 1.484 0.789) (layer "F.SilkS") (width 0.12) (tstamp 6d5f44bf-d3a6-4026-a2f3-dcc5c7579883))
    (fp_arc (start -1.483953 0.789089) (mid -1.680708 0.00005) (end -1.484 -0.789) (layer "F.SilkS") (width 0.12) (tstamp a7ee6e6f-dfec-4d27-972b-a21172e16a2c))
    (fp_arc (start 0.788712 1.483352) (mid 0.406429 1.630097) (end 0 1.68) (layer "F.SilkS") (width 0.12) (tstamp cb7b0a66-d365-4f54-ab76-d19c9d93623e))
    (fp_circle (center 0 -3) (end 0.9 -3) (layer "F.SilkS") (width 0.12) (fill none) (tstamp 7e5fe328-7749-4729-979f-26090caba8be))
    (fp_circle (center 5 -3) (end 5.9 -3) (layer "F.SilkS") (width 0.12) (fill none) (tstamp 817bc601-28bd-41f9-97be-ddd6da34def5))
    (fp_circle (center 5 0) (end 6.68 0) (layer "F.SilkS") (width 0.12) (fill none) (tstamp 82bb42cd-b017-48b2-a796-bf84d67e2658))
    (fp_line (start -3 4.5) (end 8 4.5) (layer "F.CrtYd") (width 0.05) (tstamp 2f723913-a903-4308-9274-a540f64601f5))
    (fp_line (start -3 -5.5) (end -3 4.5) (layer "F.CrtYd") (width 0.05) (tstamp a6edd00f-70f6-49d7-9cf9-53ec9130c66c))
    (fp_line (start 8 4.5) (end 8 -5.5) (layer "F.CrtYd") (width 0.05) (tstamp c91cef00-23b1-483a-9685-d263ccaf7494))
    (fp_line (start 8 -5.5) (end -3 -5.5) (layer "F.CrtYd") (width 0.05) (tstamp f565629e-07e8-4288-8e49-9107d2dbfd67))
    (fp_line (start 6.138 -0.955) (end 4.046 1.138) (layer "F.Fab") (width 0.1) (tstamp 047c85ba-0487-41e9-958f-d529d132ba2a))
    (fp_line (start 7.5 4) (end -1 4) (layer "F.Fab") (width 0.1) (tstamp 1e04f706-42a7-4575-bc9a-36e9a5ab4a2e))
    (fp_line (start 5.955 -1.138) (end 3.863 0.955) (layer "F.Fab") (width 0.1) (tstamp 3f0b606e-db92-4258-b627-0fc22b93717c))
    (fp_line (start 1.138 -0.955) (end -0.955 1.138) (layer "F.Fab") (width 0.1) (tstamp 434539f8-815b-4b44-8861-90b49b894162))
    (fp_line (start -2.5 2.5) (end 7.5 2.5) (layer "F.Fab") (width 0.1) (tstamp 460b209f-1ee9-4761-a2c3-184237f707a0))
    (fp_line (start -1 4) (end -2.5 2.5) (layer "F.Fab") (width 0.1) (tstamp 52cdcee7-460d-4f08-8c0c-c039163dfafc))
    (fp_line (start 7.5 -5) (end 7.5 4) (layer "F.Fab") (width 0.1) (tstamp 654ff61a-970c-4f69-801f-1be0dc9c6d70))
    (fp_line (start -2.5 -5) (end 7.5 -5) (layer "F.Fab") (width 0.1) (tstamp 7d85cd21-abd3-4e6d-bed1-4e416aa3c33f))
    (fp_line (start -2.5 2.5) (end -2.5 -5) (layer "F.Fab") (width 0.1) (tstamp c465d4e4-966b-42e7-a4b1-6821e24525d2))
    (fp_line (start 0.955 -1.138) (end -1.138 0.955) (layer "F.Fab") (width 0.1) (tstamp ce03d8d8-9733-45df-b391-afe2e39cfe37))
    (fp_circle (center 5 -3) (end 5.9 -3) (layer "F.Fab") (width 0.1) (fill none) (tstamp 44cb696c-2929-4412-86c5-04f705b1b4ee))
    (fp_circle (center 0 0) (end 1.5 0) (layer "F.Fab") (width 0.1) (fill none) (tstamp 53a3a34f-2d91-42b2-b255-47e74d6ec720))
    (fp_circle (center 5 0) (end 6.5 0) (layer "F.Fab") (width 0.1) (fill none) (tstamp b349f040-5e55-4cb9-b23a-f3dd3bb00c85))
    (fp_circle (center 0 -3) (end 0.9 -3) (layer "F.Fab") (width 0.1) (fill none) (tstamp c857fa63-d8a6-489b-890a-2b6705c7211f))
    (pad "1" thru_hole rect (at 0 0 90) (size 2.5 2.5) (drill 1.3) (layers *.Cu *.Mask)
      (net 10 "Net-(C14-Pad1)") (pinfunction "Pin_1") (pintype "passive") (tstamp 8f87956f-6004-43fe-b24d-67eef1757b76))
    (pad "2" thru_hole circle (at 5 0 90) (size 2.5 2.5) (drill 1.3) (layers *.Cu *.Mask)
      (net 1 "Net-(BT1-Pad2)") (pinfunction "Pin_2") (pintype "passive") (tstamp 7425987c-c179-4cd6-bef3-fbfb87e5bc3b))
    (model "${KICAD6_3DMODEL_DIR}/TerminalBlock_RND.3dshapes/TerminalBlock_RND_205-00001_1x02_P5.00mm_Horizontal.wrl"
      (scale (xyz 1 1 1))
  (footprint "Resistor_THT:R_Axial_Power_L25.0mm_W6.4mm_P30.48mm" (layer "F.Cu")
    (tedit 5AE5139B) (tstamp 19683235-b045-46d7-9b4a-4a7062f431f9)
    (at 133.731 81.031 90)
    (descr "Resistor, Axial_Power series, Box, pin pitch=30.48mm, 5W, length*width*height=25*6.4*6.4mm^3, http://cdn-reichelt.de/documents/datenblatt/B400/5WAXIAL_9WAXIAL_11WAXIAL_17WAXIAL%23YAG.pdf")
    (tags "Resistor Axial_Power series Box pin pitch 30.48mm 5W length 25mm width 6.4mm height 6.4mm")
    (path "/7e56ab13-160a-44e7-aa0a-4c3d9ff6b7a1")
    (attr through_hole)
    (fp_text reference "R17" (at 15.24 -4.32 90) (layer "F.SilkS")
      (tstamp 92b4aecf-f03e-4ded-af3e-b30f88be46b6)
    (fp_text value "18R 5W KH208-810B18R" (at 15.24 4.32 90) (layer "F.Fab")
      (tstamp 0170ee58-df10-4195-971d-7897af149621)
    (fp_text user "${REFERENCE}" (at 15.24 0 90) (layer "F.Fab")
      (tstamp 444c5e3b-3f04-4684-b873-4b2507676363)
    (fp_line (start 1.44 0) (end 2.62 0) (layer "F.SilkS") (width 0.12) (tstamp 26870e98-4b69-45b3-81e9-c32033d84410))
    (fp_line (start 29.04 0) (end 27.86 0) (layer "F.SilkS") (width 0.12) (tstamp 85a8f11a-038f-43a9-b4e2-e92d7926481b))
    (fp_line (start 2.62 3.32) (end 27.86 3.32) (layer "F.SilkS") (width 0.12) (tstamp a235e879-690e-4dfe-b4a6-79827a977676))
    (fp_line (start 27.86 3.32) (end 27.86 -3.32) (layer "F.SilkS") (width 0.12) (tstamp e55b69c7-460e-4111-8cde-e072f974ebf8))
    (fp_line (start 2.62 -3.32) (end 2.62 3.32) (layer "F.SilkS") (width 0.12) (tstamp fbe859fc-88f3-4cad-aace-5bf9be63b847))
    (fp_line (start 27.86 -3.32) (end 2.62 -3.32) (layer "F.SilkS") (width 0.12) (tstamp fc5d54ce-d4c4-4b00-994a-a5f7590189bc))
    (fp_line (start -1.45 -3.45) (end -1.45 3.45) (layer "F.CrtYd") (width 0.05) (tstamp 34e513fe-109c-420c-a45e-05a041551856))
    (fp_line (start 31.94 3.45) (end 31.94 -3.45) (layer "F.CrtYd") (width 0.05) (tstamp 5dfbfb45-0270-4c85-a819-adc84415b990))
    (fp_line (start -1.45 3.45) (end 31.94 3.45) (layer "F.CrtYd") (width 0.05) (tstamp a105df31-6415-44ad-9dd2-221d577922e2))
    (fp_line (start 31.94 -3.45) (end -1.45 -3.45) (layer "F.CrtYd") (width 0.05) (tstamp eccd99e8-1837-4cf1-92d8-117fd5ec8fa6))
    (fp_line (start 2.74 -3.2) (end 2.74 3.2) (layer "F.Fab") (width 0.1) (tstamp 020b486d-3e39-484b-8756-d4d59d97172c))
    (fp_line (start 2.74 3.2) (end 27.74 3.2) (layer "F.Fab") (width 0.1) (tstamp 875953f0-c2da-47df-a41e-3acc95489d7a))
    (fp_line (start 27.74 -3.2) (end 2.74 -3.2) (layer "F.Fab") (width 0.1) (tstamp 9b6aca3b-b310-4b39-afc9-66bdd52a1fb4))
    (fp_line (start 30.48 0) (end 27.74 0) (layer "F.Fab") (width 0.1) (tstamp ac2d63fc-7615-4a1a-b1fb-43937ec6da8d))
    (fp_line (start 0 0) (end 2.74 0) (layer "F.Fab") (width 0.1) (tstamp b210400b-75a4-4dbb-be53-9c02405a3e8c))
    (fp_line (start 27.74 3.2) (end 27.74 -3.2) (layer "F.Fab") (width 0.1) (tstamp c6f74b37-91d9-44cd-bbe8-2c6439bb7d17))
    (pad "1" thru_hole circle (at 0 0 90) (size 2.4 2.4) (drill 1.2) (layers *.Cu *.Mask)
      (net 10 "Net-(C14-Pad1)") (pintype "passive") (tstamp 197ccc6c-39c6-4952-b2e1-2088d8a51c87))
    (pad "2" thru_hole oval (at 30.48 0 90) (size 2.4 2.4) (drill 1.2) (layers *.Cu *.Mask)
      (net 15 "Net-(C3-Pad1)") (pintype "passive") (tstamp a85d3581-dfff-4ba7-b604-37a6a8d85dc8))
    (model "${KICAD6_3DMODEL_DIR}/Resistor_THT.3dshapes/R_Axial_Power_L25.0mm_W6.4mm_P30.48mm.wrl"
      (scale (xyz 1 1 1))
    (tedit 5F68FEEF) (tstamp 1a3b0d8a-b00b-45e0-9dd5-4940a9ee2c6d)
    (at 98.171 72.136 90)
    (path "/2bf256a4-b879-4dc0-91ee-916215be3b6b")
    (attr smd)
    (fp_text reference "C7" (at 0 -2.032 90) (layer "F.SilkS")
      (tstamp 898fde04-3776-45ca-930d-6b728a89708e)
    (fp_text value "22u 25V X5R-G1210 22" (at 0 1.85 90) (layer "F.Fab")
      (tstamp 60fef7ba-7a55-41e7-89d8-0954c7ad9c53)
      (tstamp 41be5b4e-9d84-4200-a6e5-3d67147fc9b5)
    (fp_line (start -0.711252 0.91) (end 0.711252 0.91) (layer "F.SilkS") (width 0.12) (tstamp afd0e542-a926-4fad-b4ea-ce584268b3c2))
    (fp_line (start -0.711252 -0.91) (end 0.711252 -0.91) (layer "F.SilkS") (width 0.12) (tstamp f76b555f-f97a-449c-bdf4-94e1d0b6f33c))
    (fp_line (start 2.48 1.15) (end -2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp 140f9412-a719-4390-b992-99f3e7d1a2f9))
    (fp_line (start -2.48 1.15) (end -2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp 3e7cc8bd-72df-40ea-8fd2-b0462cf5234e))
    (fp_line (start -2.48 -1.15) (end 2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp 733b316c-4481-4d48-b55e-ac61aedf6957))
    (fp_line (start 2.48 -1.15) (end 2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp ea2361cd-22bc-4f77-a8e4-2fd8b81fe277))
    (fp_line (start 1.6 -0.8) (end 1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp 4ab9ee2c-ec0d-4849-818a-32597c22eceb))
    (fp_line (start -1.6 0.8) (end -1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp bf67a228-ecfa-42f1-9638-8fb1324fca43))
    (fp_line (start -1.6 -0.8) (end 1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp e7dcc5af-47f0-4b05-9640-de8dca24bbcc))
    (fp_line (start 1.6 0.8) (end -1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp ff10d504-85c4-4fe5-bda3-37e9b9747d13))
    (pad "1" smd roundrect (at -1.5625 0 90) (size 1.325 1.8) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1886792453)
      (net 5 "Net-(C7-Pad1)") (pintype "passive") (tstamp 2d1ae4a8-cbd9-4635-b699-a0902552e8e9))
    (pad "2" smd roundrect (at 1.5625 0 90) (size 1.325 1.8) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1886792453)
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp 7f5a7344-fd2e-4a1d-9028-f8a9bf451330))
      (scale (xyz 1 1 1))
  (footprint "LED_SMD:LED_0805_2012Metric_Pad1.15x1.40mm_HandSolder" (layer "F.Cu")
    (tedit 5F68FEF1) (tstamp 1d8428fa-de61-40e9-8ad7-fcf5d409e019)
    (at 88.891 19.556 90)
    (descr "LED SMD 0805 (2012 Metric), square (rectangular) end terminal, IPC_7351 nominal, (Body size source: https://docs.google.com/spreadsheets/d/1BsfQQcO9C6DZCsRaXUlFlo91Tg2WpOkGARC1WS5S8t0/edit?usp=sharing), generated with kicad-footprint-generator")
    (tags "LED handsolder")
    (path "/20e32b12-1ea3-49bb-98a3-5d66038d2ec3")
    (attr smd)
    (fp_text reference "D12" (at 0.127 -1.905 270) (layer "F.SilkS")
      (tstamp cfa23489-f5cf-456b-9eea-3f57417908fd)
    (fp_text value "OSO LYR976 Grün" (at 0 1.65 90) (layer "F.Fab")
      (tstamp d050bded-7d3c-4692-9dfa-e859dc4bfcb2)
      (effects (font (size 0.5 0.5) (thickness 0.08)))
      (tstamp 55567c34-b989-4f0a-a085-1122ef29182d)
    (fp_line (start -1.86 -0.96) (end -1.86 0.96) (layer "F.SilkS") (width 0.12) (tstamp 52466243-47cf-497e-b9d9-3fd78bbc13fb))
    (fp_line (start 1 -0.96) (end -1.86 -0.96) (layer "F.SilkS") (width 0.12) (tstamp 73c3615d-6b13-41f3-8815-07ab4ee3f686))
    (fp_line (start -1.86 0.96) (end 1 0.96) (layer "F.SilkS") (width 0.12) (tstamp c1146a3b-17ae-4e4b-bd05-dcf6dfe1f5ab))
    (fp_line (start 1.85 0.95) (end -1.85 0.95) (layer "F.CrtYd") (width 0.05) (tstamp 7b7387eb-0041-4da8-8c5b-b0627bfac4d1))
    (fp_line (start -1.85 -0.95) (end 1.85 -0.95) (layer "F.CrtYd") (width 0.05) (tstamp 8bfa8068-1ef6-4f95-91d0-7138baef9785))
    (fp_line (start 1.85 -0.95) (end 1.85 0.95) (layer "F.CrtYd") (width 0.05) (tstamp 917616b3-4934-48cf-bf74-33b2bf2affb3))
    (fp_line (start -1.85 0.95) (end -1.85 -0.95) (layer "F.CrtYd") (width 0.05) (tstamp de5cd68c-f40a-4ef0-8b61-9f329fadb7cb))
    (fp_line (start -1 -0.3) (end -1 0.6) (layer "F.Fab") (width 0.1) (tstamp 177e630d-e4fa-409a-b51e-1e46a62ffda9))
    (fp_line (start -0.7 -0.6) (end -1 -0.3) (layer "F.Fab") (width 0.1) (tstamp 6d44fbb3-88a7-42da-a46e-ec55596676bf))
    (fp_line (start 1 -0.6) (end -0.7 -0.6) (layer "F.Fab") (width 0.1) (tstamp aeb4342f-087f-45e6-8324-763a6e4a1292))
    (fp_line (start 1 0.6) (end 1 -0.6) (layer "F.Fab") (width 0.1) (tstamp bef073f8-94b7-4338-806b-b2636a07988b))
    (fp_line (start -1 0.6) (end 1 0.6) (layer "F.Fab") (width 0.1) (tstamp d3d3fde4-c565-4187-8d13-c7d88e9ebac6))
    (pad "1" smd roundrect (at -1.025 0 90) (size 1.15 1.4) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.2173913043)
      (net 96 "Net-(D12-Pad1)") (pinfunction "K") (pintype "passive") (tstamp e154a3b4-10d4-476f-b9f1-274740140c43))
    (pad "2" smd roundrect (at 1.025 0 90) (size 1.15 1.4) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.2173913043)
      (net 87 "Net-(D11-Pad1)") (pinfunction "A") (pintype "passive") (tstamp c65c3384-3de6-40df-b97b-5b2331de3b35))
    (model "${KICAD6_3DMODEL_DIR}/LED_SMD.3dshapes/LED_0805_2012Metric.wrl"
      (scale (xyz 1 1 1))
    (tedit 5AE5139B) (tstamp 1dcc62bb-aff1-4c6e-9355-184dbdf93f4f)
    (at 82.926 88.646)
    (path "/d30617b9-f020-4033-9590-08e6f6547378")
    (attr through_hole)
    (fp_text reference "R9" (at -2.281 0 90) (layer "F.SilkS")
      (tstamp a26f1b81-a977-41eb-92b6-c8522c2c7bae)
    (fp_text value "2R7 5W AXIAL 2,7" (at 15.24 4.32) (layer "F.Fab")
      (tstamp eebadda9-e019-476a-9b82-111fa5c61bf4)
    (fp_text user "${REFERENCE}" (at 15.24 0) (layer "F.Fab")
      (tstamp 5f632d5b-29f5-4879-aaeb-47e59d85db4c)
    (fp_line (start 2.62 3.32) (end 27.86 3.32) (layer "F.SilkS") (width 0.12) (tstamp 3b2f406f-4164-4fd6-a137-eda45b783be8))
    (fp_line (start 29.04 0) (end 27.86 0) (layer "F.SilkS") (width 0.12) (tstamp 6fbb5d0b-d4a7-448d-84e6-4ce806d6fefa))
    (fp_line (start 1.44 0) (end 2.62 0) (layer "F.SilkS") (width 0.12) (tstamp 7cd92fbf-473f-42bb-93a8-9c373ba1d60d))
    (fp_line (start 2.62 -3.32) (end 2.62 3.32) (layer "F.SilkS") (width 0.12) (tstamp ab36d436-c2c6-4bbb-a738-ff0d25895608))
    (fp_line (start 27.86 -3.32) (end 2.62 -3.32) (layer "F.SilkS") (width 0.12) (tstamp abf43a9b-0b81-4d4a-a8c6-bac14eda47e6))
    (fp_line (start 27.86 3.32) (end 27.86 -3.32) (layer "F.SilkS") (width 0.12) (tstamp b2c5843e-e208-41dd-a300-5f3a14e7a54d))
    (fp_line (start 31.94 3.45) (end 31.94 -3.45) (layer "F.CrtYd") (width 0.05) (tstamp 1c763a17-3b62-4d66-80f9-a54460f8b07a))
    (fp_line (start -1.45 3.45) (end 31.94 3.45) (layer "F.CrtYd") (width 0.05) (tstamp 69b15b56-0b7c-473c-b153-2106b054ddec))
    (fp_line (start -1.45 -3.45) (end -1.45 3.45) (layer "F.CrtYd") (width 0.05) (tstamp cca69fcf-88bf-4992-8993-412dfcc4e2f9))
    (fp_line (start 31.94 -3.45) (end -1.45 -3.45) (layer "F.CrtYd") (width 0.05) (tstamp d5ae0d09-8d0a-42de-bf57-c38c28bc9021))
    (fp_line (start 2.74 -3.2) (end 2.74 3.2) (layer "F.Fab") (width 0.1) (tstamp 1d2b01a8-75f1-46e3-8ace-833410c1d4de))
    (fp_line (start 30.48 0) (end 27.74 0) (layer "F.Fab") (width 0.1) (tstamp a7cf2072-0669-43df-a422-e901046a2921))
    (fp_line (start 0 0) (end 2.74 0) (layer "F.Fab") (width 0.1) (tstamp b301bb2b-dd70-4160-893f-0109bdd55225))
    (fp_line (start 27.74 3.2) (end 27.74 -3.2) (layer "F.Fab") (width 0.1) (tstamp eb4f2bc4-dc4d-42cb-9ffb-ea64a5e1e81d))
    (fp_line (start 27.74 -3.2) (end 2.74 -3.2) (layer "F.Fab") (width 0.1) (tstamp f4408a58-0c36-406a-bbc9-63483879abd3))
    (fp_line (start 2.74 3.2) (end 27.74 3.2) (layer "F.Fab") (width 0.1) (tstamp fa595014-30e8-4c36-b422-3198d3f8a4b1))
    (pad "1" thru_hole circle (at 0 0) (size 2.4 2.4) (drill 1.2) (layers *.Cu *.Mask)
      (net 85 "Net-(C20-Pad1)") (pintype "passive") (tstamp a3c94792-e65b-46a7-9c09-ead34421ba06))
    (pad "2" thru_hole oval (at 30.48 0) (size 2.4 2.4) (drill 1.2) (layers *.Cu *.Mask)
      (net 104 "Net-(D15-Pad2)") (pintype "passive") (tstamp 513c1cae-fd9d-43b7-987f-6bc1e8e731ec))
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp 1eb0831d-5b1f-47cc-aa5c-fddf1cea4ff3)
    (at 53.721 112.522)
    (path "/1e9b7357-6eec-4b12-8fd4-5c8f51118fbe")
    (attr smd)
    (fp_text reference "R24" (at 3.302 0.127 90) (layer "F.SilkS")
      (tstamp 9a1311aa-2841-4f13-8129-6cf37b825dd8)
    (fp_text value "SMD 1/4W 1k" (at 0 2.28) (layer "F.Fab")
      (tstamp 195627f4-14b2-476a-bfe3-b283c62d0d2c)
    (fp_text user "${REFERENCE}" (at 0.026 0) (layer "F.Fab")
      (tstamp 53fa805a-816f-42ef-9f8c-eb56ee8df99f)
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 75eecd7e-1a83-4727-8fc6-a53b27991673))
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp 8c3613f0-944d-4855-9310-2ff7be15113f))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 0b096d72-89de-4fd6-b618-5fb1fda04d8e))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 125be97c-7c12-4451-883e-0cbb5fd1bbc0))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp eaceaef2-0deb-4af5-9f72-cedc253b0cb3))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp fe41840c-7ab1-4ec3-b806-023591868769))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 2a86442b-29b6-4727-af3c-2d4abac168d1))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 2dbc333d-5df8-4647-a0dc-74f42f60ea0a))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 99065673-d96f-4a30-988d-1001b0fc687b))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp ebfb7989-9339-4cff-bd18-b27671f0b9b7))
    (pad "1" smd roundrect (at -1.55 0) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 53 "Net-(R24-Pad1)") (pintype "passive") (tstamp 6772ac51-ad45-4137-9f76-5f5adead475d))
    (pad "2" smd roundrect (at 1.55 0) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 107 "Net-(R24-Pad2)") (pintype "passive") (tstamp 95789081-be92-4008-aa1e-2a95727de26a))
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp 1ee52aec-f6a3-4d33-a995-706c5aa8bf8b)
    (at 54.737 96.52 -90)
    (path "/00f374cb-77f6-41b6-949c-234812c4ccf8")
    (attr smd)
    (fp_text reference "R25" (at 0 2.286 90) (layer "F.SilkS")
      (tstamp 30a79a89-e29e-412d-a9ca-59084cf610e8)
    (fp_text value "SMD 1/4W 1k" (at 0 2.28 90) (layer "F.Fab")
      (tstamp 0d2ad1a0-4f5c-4bc0-8f78-22445e264550)
    (fp_text user "${REFERENCE}" (at -0.019 0.019 90) (layer "F.Fab")
      (tstamp 75e9fa35-87a7-45c3-91de-31fc7266dbb0)
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp 95171df2-23a0-4fbd-8391-a0c80cb8f0aa))
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp ecaf27df-173d-4ce7-b35a-14eee589b9c3))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 8236af74-b33e-4833-814a-5f929f75051a))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp ccba9123-3e51-4640-8aa7-710f97797cf2))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp d0d822ed-3c99-4911-a3d9-647929fc5dbe))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp ff51b400-11f2-4b20-aa98-d076e6bd7ab1))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 10d1be32-0c56-451f-babe-933d3c135ac8))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 9bee51cc-ece7-45d3-bf62-f12e25004973))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp e0e5c477-29ac-40bd-9a5a-986b4df04b84))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp f17cedb4-d9b4-477f-949b-40dba39e9188))
    (pad "1" smd roundrect (at -1.55 0 270) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 54 "Net-(R25-Pad1)") (pintype "passive") (tstamp 7f451279-a428-444e-b39d-7765f83dac99))
    (pad "2" smd roundrect (at 1.55 0 270) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 95 "Net-(J12-Pad6)") (pintype "passive") (tstamp 9b74f9a8-ebd6-4e68-9bf0-5f0326f1b7d9))
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp 219d13d4-611b-4c60-b517-ac1207232120)
    (at 81.661 36.576 180)
    (path "/dbc1d139-4e46-4c2a-8007-b1c7f2b218d9")
    (attr smd)
    (fp_text reference "R10" (at 3.302 0 90) (layer "F.SilkS")
      (tstamp 15992af7-4aaf-4e2f-8417-23330971777a)
    (fp_text value "SMD 1/4W 2k2" (at 0 2.28) (layer "F.Fab")
      (tstamp 384d1a9f-ab05-4113-bfd2-43afb7bb81d4)
      (tstamp dbfebff1-429b-4498-802c-e1ad0be0d66f)
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp a8fced1a-fb97-4348-8383-d503265ad7c5))
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp cc5df96c-0308-4d42-99bd-d5119be1476c))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 483c0311-e166-4bab-a933-092cd9109b47))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 9db281dd-2940-40de-a6ee-2440bd665358))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp c7342dc7-78b9-478c-ab1a-b8a3fca9de43))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp db1cf87a-e09c-4b1f-8f8c-9e8601190771))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 0eb1839b-2fe0-48a3-9a40-e0bc79abe94e))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 6fba806c-4d3d-4446-a4ec-f98b2e15c4d5))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp b1fd8bd9-f390-42ad-8887-d97ae42c04fa))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp e2f18626-c1ed-49f3-ba3a-9dbfe1f74f3f))
      (net 41 "Net-(Q2-Pad2)") (pintype "passive") (tstamp 8e773f60-f0a5-428a-9cef-8c8f2afabd25))
      (net 47 "Net-(J4-Pad4)") (pintype "passive") (tstamp 3864ac6d-6ace-466d-a40d-17adaeac327c))
      (scale (xyz 1 1 1))
    (tedit 5AE50CD5) (tstamp 22b80a27-6734-4ccb-b1f3-523b24ac4640)
    (at 86.995 112.141 180)
    (path "/88daecf1-4162-4897-aa06-873fb2405377")
    (attr through_hole)
    (fp_text reference "D4" (at 9.652 0 90) (layer "F.SilkS")
      (tstamp 3432c760-0da5-4c4f-a026-2b0d7e06fc35)
      (tstamp 7dd377c7-06c1-4f61-9c47-ad882a9e29db)
    (fp_text user "K" (at 0 -1.8) (layer "F.SilkS")
      (tstamp dd717836-88f8-4f63-ae21-cd947be12870)
      (tstamp 4851d170-e127-4a20-b21c-2e4ea147cd89)
      (tstamp e3142d6b-5108-4e65-9029-ac129438614d)
    (fp_line (start 1.69 -1.12) (end 1.69 1.12) (layer "F.SilkS") (width 0.12) (tstamp 19922290-a9df-45cb-bd8e-2ef6485ee1e0))
    (fp_line (start 2.29 -1.12) (end 2.29 1.12) (layer "F.SilkS") (width 0.12) (tstamp 270ffe15-3685-4cb9-b118-92bc4b9e8219))
    (fp_line (start 5.93 1.12) (end 5.93 -1.12) (layer "F.SilkS") (width 0.12) (tstamp 3a6bdc43-58eb-431b-8450-d942c50d9976))
    (fp_line (start 1.04 0) (end 1.69 0) (layer "F.SilkS") (width 0.12) (tstamp 4837fbd7-01ff-47ab-8b68-4bdd66a5200e))
    (fp_line (start 6.58 0) (end 5.93 0) (layer "F.SilkS") (width 0.12) (tstamp 5f2bb607-cb49-4bb2-8b01-abc049c3e452))
    (fp_line (start 2.41 -1.12) (end 2.41 1.12) (layer "F.SilkS") (width 0.12) (tstamp 7c6e60bb-10a7-49b3-bd47-9017b2e4950c))
    (fp_line (start 5.93 -1.12) (end 1.69 -1.12) (layer "F.SilkS") (width 0.12) (tstamp a06a1861-3a3b-4f26-9212-864c550140de))
    (fp_line (start 1.69 1.12) (end 5.93 1.12) (layer "F.SilkS") (width 0.12) (tstamp c1c70947-9b58-4507-829a-45e41890ad5f))
    (fp_line (start 2.53 -1.12) (end 2.53 1.12) (layer "F.SilkS") (width 0.12) (tstamp e4ea701c-879f-402c-aa02-a060b5913732))
    (fp_line (start 8.67 -1.25) (end -1.05 -1.25) (layer "F.CrtYd") (width 0.05) (tstamp 088a17b8-5db2-4a97-9b61-1c902d79f9ad))
    (fp_line (start 8.67 1.25) (end 8.67 -1.25) (layer "F.CrtYd") (width 0.05) (tstamp 0eb1a822-20d4-4551-a01c-f2e0f240978c))
    (fp_line (start -1.05 1.25) (end 8.67 1.25) (layer "F.CrtYd") (width 0.05) (tstamp 0fc0e6e2-72dd-4788-97a0-0c9011f50ced))
    (fp_line (start -1.05 -1.25) (end -1.05 1.25) (layer "F.CrtYd") (width 0.05) (tstamp 74bce7d2-de6d-431e-8792-5102d36db66c))
    (fp_line (start 5.81 1) (end 5.81 -1) (layer "F.Fab") (width 0.1) (tstamp 0ae7af05-b686-4ebd-8021-a91d9d9899af))
    (fp_line (start 7.62 0) (end 5.81 0) (layer "F.Fab") (width 0.1) (tstamp 256fc67b-91fd-4e01-8f29-e743f5d8d730))
    (fp_line (start 1.81 1) (end 5.81 1) (layer "F.Fab") (width 0.1) (tstamp 2719fdb3-d228-4220-8baf-590317349b08))
    (fp_line (start 5.81 -1) (end 1.81 -1) (layer "F.Fab") (width 0.1) (tstamp 47b9d37c-2d52-45c6-93eb-2de002075c64))
    (fp_line (start 2.31 -1) (end 2.31 1) (layer "F.Fab") (width 0.1) (tstamp 4a81eaf7-6cc5-478b-85f0-bfc05f38b0f1))
    (fp_line (start 1.81 -1) (end 1.81 1) (layer "F.Fab") (width 0.1) (tstamp 5c19274e-99f5-4d93-872d-7c537c0e496f))
    (fp_line (start 0 0) (end 1.81 0) (layer "F.Fab") (width 0.1) (tstamp 5fd80dd5-eb8d-4405-8c6a-bad013d0215f))
    (fp_line (start 2.41 -1) (end 2.41 1) (layer "F.Fab") (width 0.1) (tstamp 670269f5-c700-45ae-9ab3-f0b97980dac3))
    (fp_line (start 2.51 -1) (end 2.51 1) (layer "F.Fab") (width 0.1) (tstamp 87e0515b-517b-43e8-bf82-288502242b2a))
      (net 17 "Net-(D3-Pad2)") (pinfunction "K") (pintype "passive") (tstamp dcd86257-a9e8-468e-acec-f9c817910f33))
      (net 18 "Net-(D4-Pad2)") (pinfunction "A") (pintype "passive") (tstamp 3f4c87d4-a64e-444f-8e18-efcc4d41e2e2))
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp 24b9b552-bfe4-4f0e-8c34-6d4db8643396)
    (at 29.337 83.058 90)
    (path "/b27eb609-248a-4b23-a563-d60983ae7cf9")
    (attr smd)
    (fp_text reference "R51" (at -0.889 2.413 90) (layer "F.SilkS")
      (tstamp a3910835-81f5-4a56-beab-3c2ca078a608)
      (tstamp 76ece8df-2950-49ad-b3ea-9c5a1ebaf8cd)
      (tstamp e2cb87f2-8a8b-406b-acd2-5aac15361ecd)
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 4beadd38-87ce-424c-adcc-8aab75e7f687))
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp 741df4f0-3017-4557-be7b-c342045ae990))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 2308d78e-8f41-4573-9051-5ad755a67f64))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 3f407600-af26-4f60-96df-3bd2e79c3c9d))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 939a6e47-8ef2-4882-9209-bce4ed57c886))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 9941d918-8f4e-49be-b094-26b07fbf7a31))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 23edaac9-0e75-4a05-900e-f6b9ef556e0d))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp a0c848ea-9150-4539-83b7-4d81f2bf99e4))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp b6608153-afde-4172-aba4-677f7d685cdf))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp ce6bb83a-3fa2-4b90-b53a-3450a7779dfb))
      (net 85 "Net-(C20-Pad1)") (pintype "passive") (tstamp a477dd66-74fb-43e9-85ce-d224aee37cb0))
      (net 12 "Net-(C25-Pad1)") (pintype "passive") (tstamp 3b5d2899-e8e2-498c-85e7-0498fbee43f9))
      (scale (xyz 1 1 1))
    (tedit 5D160D14) (tstamp 28075ab5-a346-4fa2-81ad-02eeda649fd2)
    (at 127.989 129.62)
    (path "/20511bb1-ac3b-4d0e-9251-02a6050c77a1")
    (attr through_hole)
    (fp_text reference "SW8" (at -2.005 2.714) (layer "F.SilkS")
      (tstamp a23c5562-430d-43de-ad65-63be51f98b21)
    (fp_text value "Hoch" (at 6.62 9.93) (layer "F.Fab")
      (tstamp 54a4791d-8501-4d13-8626-0a1c147c0199)
      (tstamp 3159bd6c-1ea6-464d-92f3-7adc6e4f4ea8)
    (fp_line (start 12.4 -3.65) (end 12.4 -1.1) (layer "F.SilkS") (width 0.12) (tstamp 00659d78-5d82-4b3d-8fe4-67e52a57f529))
    (fp_line (start 12.4 1.1) (end 12.4 3.8) (layer "F.SilkS") (width 0.12) (tstamp 2e00c605-8c54-45f4-a84d-8041ca4089b9))
    (fp_line (start 0.1 3.8) (end 0.1 1.3) (layer "F.SilkS") (width 0.12) (tstamp 3423ba9a-e3cc-4ace-baf6-985c56291546))
    (fp_line (start 0.1 8.65) (end 0.1 6.2) (layer "F.SilkS") (width 0.12) (tstamp 4d674f24-811a-463b-ad32-8855033f2ae0))
    (fp_line (start 0.1 -3.65) (end 12.4 -3.65) (layer "F.SilkS") (width 0.12) (tstamp c7b12889-9c0f-4b5e-a213-80c16d6694fa))
    (fp_line (start 12.4 8.65) (end 0.1 8.65) (layer "F.SilkS") (width 0.12) (tstamp e6f78d77-b181-4b13-95f0-76ad35746de9))
    (fp_line (start 12.4 6.2) (end 12.4 8.65) (layer "F.SilkS") (width 0.12) (tstamp f8550c8e-3390-4873-8c69-677a9c2dc039))
    (fp_line (start 0.1 -1.1) (end 0.1 -3.65) (layer "F.SilkS") (width 0.12) (tstamp fdb757c6-97bc-47bf-b76f-716277ca6398))
    (fp_circle (center 6.35 2.54) (end 10.16 5.08) (layer "F.SilkS") (width 0.12) (fill none) (tstamp 70dc17c6-94ae-4033-8305-c8c6d6d6d990))
    (fp_line (start 14.25 8.75) (end 14.25 -3.75) (layer "F.CrtYd") (width 0.05) (tstamp 2792abf5-ef33-4e9f-b048-92415c3fbf34))
    (fp_line (start 14.25 8.75) (end -1.77 8.75) (layer "F.CrtYd") (width 0.05) (tstamp 4bdfc795-1ba8-4b05-81d8-33aee03ccfd7))
    (fp_line (start -1.77 -3.75) (end -1.77 8.75) (layer "F.CrtYd") (width 0.05) (tstamp e377f903-0347-4a9e-a35b-e8b0a007ca9c))
    (fp_line (start -1.77 -3.75) (end 14.25 -3.75) (layer "F.CrtYd") (width 0.05) (tstamp f35f2b86-d0d9-44fc-8b14-8da0db730ff5))
    (fp_line (start 12.25 -3.5) (end 12.25 8.5) (layer "F.Fab") (width 0.1) (tstamp 0736f029-996d-48fe-a0c2-d24e0f227cb1))
    (fp_line (start 0.25 8.5) (end 12.25 8.5) (layer "F.Fab") (width 0.1) (tstamp 27389545-f28a-471f-9ff8-badb3c094e41))
    (fp_line (start 0.25 -3.5) (end 0.25 8.5) (layer "F.Fab") (width 0.1) (tstamp 39f36346-8c5d-494b-a0b3-31bc57049ab7))
    (fp_line (start 0.25 -3.5) (end 12.25 -3.5) (layer "F.Fab") (width 0.1) (tstamp e7554a62-ea12-4f9f-b196-651865d9af86))
      (net 129 "Net-(J13-Pad2)") (pinfunction "A") (pintype "passive") (tstamp 10cb36b1-3e4c-4ed3-b86e-9045422e4074))
      (net 129 "Net-(J13-Pad2)") (pinfunction "A") (pintype "passive") (tstamp 2c6a2e3d-5ebc-48db-ae7f-3d7f2cc0742b))
      (net 127 "Net-(J13-Pad4)") (pinfunction "B") (pintype "passive") (tstamp 7da76865-d69e-4833-beaa-f7505a436023))
      (net 127 "Net-(J13-Pad4)") (pinfunction "B") (pintype "passive") (tstamp bdb06d4f-9603-4b6c-9caf-556b7cd62fcc))
      (scale (xyz 1 1 1))
    (tedit 5B294F8C) (tstamp 2a16bc65-e037-4613-9c07-0fdad84fcdc9)
    (at 165.981 93.686 90)
    (path "/0254d107-52ee-4582-89ad-6c43a3dd3183")
    (attr through_hole)
    (fp_text reference "J8" (at 2.5 -6.06 90) (layer "F.SilkS")
      (tstamp 0ab890f5-506d-41d4-b6b1-8f9a08711a82)
      (tstamp 37f9390e-06ed-4998-a9e2-faa04301f41f)
      (tstamp 6a7a2f62-4cd1-4c97-adb7-2cb7aa83ea4e)
    (fp_line (start -2.8 2.56) (end -2.8 4.3) (layer "F.SilkS") (width 0.12) (tstamp 1d4a497a-960e-49bf-949f-ba6683cb89bc))
    (fp_line (start 7.56 -5.06) (end 7.56 4.06) (layer "F.SilkS") (width 0.12) (tstamp 30d6f29b-5fa5-4e1a-addb-26b8db529e05))
    (fp_line (start 6.07 -1.275) (end 6.011 -1.216) (layer "F.SilkS") (width 0.12) (tstamp 38f8f543-e250-41a2-a209-ffcdbc597cf0))
    (fp_line (start -2.8 4.3) (end -1.3 4.3) (layer "F.SilkS") (width 0.12) (tstamp 4068d574-9b71-413a-b024-dc6778213aaf))
    (fp_line (start -2.56 4.06) (end 7.56 4.06) (layer "F.SilkS") (width 0.12) (tstamp 4c6e9de0-f9dc-4a24-8cf3-135af5465bff))
    (fp_line (start -2.56 2.5) (end 7.56 2.5) (layer "F.SilkS") (width 0.12) (tstamp 55a20c39-8d05-4c4d-8f4a-6dd19fe3b011))
    (fp_line (start 6.275 -1.069) (end 6.181 -0.976) (layer "F.SilkS") (width 0.12) (tstamp a206c441-0e6c-45c7-b0bf-8b3c5fe339dd))
    (fp_line (start -2.56 -5.06) (end -2.56 4.06) (layer "F.SilkS") (width 0.12) (tstamp a3794078-5a4e-4059-8fa2-f55ce57cec99))
    (fp_line (start 3.99 1.216) (end 3.931 1.274) (layer "F.SilkS") (width 0.12) (tstamp aac20fcd-2292-48da-ac4e-ac6d582913de))
    (fp_line (start 3.82 0.976) (end 3.726 1.069) (layer "F.SilkS") (width 0.12) (tstamp d1bafc29-42d6-4106-9c72-f8e5311d7368))
    (fp_line (start -2.56 -5.06) (end 7.56 -5.06) (layer "F.SilkS") (width 0.12) (tstamp ee7e372b-15db-425d-b461-67cdd0b1d104))
    (fp_arc (start -1.483953 0.789089) (mid -1.680708 0.00005) (end -1.484 -0.789) (layer "F.SilkS") (width 0.12) (tstamp 86f5b03f-706f-4513-8731-55408be700a2))
    (fp_arc (start 0.788712 1.483352) (mid 0.406429 1.630097) (end 0 1.68) (layer "F.SilkS") (width 0.12) (tstamp 951a5d72-bc10-4819-9a95-3d39b0b73c9a))
    (fp_arc (start 0.029383 1.68045) (mid -0.392304 1.634281) (end -0.789 1.484) (layer "F.SilkS") (width 0.12) (tstamp aa3a95cd-ddb5-42bf-a04a-582e87e49112))
    (fp_arc (start 1.483953 -0.789089) (mid 1.680708 -0.00005) (end 1.484 0.789) (layer "F.SilkS") (width 0.12) (tstamp bf781651-4db2-485b-b19e-d77f4954735d))
    (fp_arc (start -0.789089 -1.483953) (mid -0.00005 -1.680708) (end 0.789 -1.484) (layer "F.SilkS") (width 0.12) (tstamp ed56e192-5f24-43fa-a3fe-9e8b395a03a6))
    (fp_circle (center 5 -3) (end 5.9 -3) (layer "F.SilkS") (width 0.12) (fill none) (tstamp 79e2de0d-7da8-497e-b7b6-7eb00d4e9723))
    (fp_circle (center 0 -3) (end 0.9 -3) (layer "F.SilkS") (width 0.12) (fill none) (tstamp 7dee059b-0e2a-4f1e-aac6-b9b64f3a6fa2))
    (fp_circle (center 5 0) (end 6.68 0) (layer "F.SilkS") (width 0.12) (fill none) (tstamp b3767728-29ef-48cc-95f4-f9225a403c90))
    (fp_line (start 8 4.5) (end 8 -5.5) (layer "F.CrtYd") (width 0.05) (tstamp 39dba26c-4c03-43f9-a96c-ffa0cc6bf9e1))
    (fp_line (start -3 -5.5) (end -3 4.5) (layer "F.CrtYd") (width 0.05) (tstamp 5b4cd595-c94f-499b-aaef-b2da2b67bc6c))
    (fp_line (start 8 -5.5) (end -3 -5.5) (layer "F.CrtYd") (width 0.05) (tstamp 73710cdd-bf4e-4faf-a395-f616666265b2))
    (fp_line (start -3 4.5) (end 8 4.5) (layer "F.CrtYd") (width 0.05) (tstamp 7fd9d6c4-fc94-4fcd-bbd2-bc55273364ea))
    (fp_line (start -2.5 2.5) (end -2.5 -5) (layer "F.Fab") (width 0.1) (tstamp 2218b8b1-78d4-4c6a-94a0-5abeeddf4d39))
    (fp_line (start 7.5 -5) (end 7.5 4) (layer "F.Fab") (width 0.1) (tstamp 336f495a-83ec-497c-9430-592420e2e64f))
    (fp_line (start -1 4) (end -2.5 2.5) (layer "F.Fab") (width 0.1) (tstamp 37624e8b-a694-4603-b947-4d5f7fa30432))
    (fp_line (start -2.5 2.5) (end 7.5 2.5) (layer "F.Fab") (width 0.1) (tstamp 3d099486-2e44-4b03-93bb-5f80f8b09eb1))
    (fp_line (start 7.5 4) (end -1 4) (layer "F.Fab") (width 0.1) (tstamp 820aeae5-c8b0-4c11-b1ee-b4cfd63ff0f6))
    (fp_line (start -2.5 -5) (end 7.5 -5) (layer "F.Fab") (width 0.1) (tstamp 87a07835-0f76-42a0-9f04-95b3f45bf4b3))
    (fp_line (start 0.955 -1.138) (end -1.138 0.955) (layer "F.Fab") (width 0.1) (tstamp a165f3b6-f436-4529-9809-dff11d1246b7))
    (fp_line (start 6.138 -0.955) (end 4.046 1.138) (layer "F.Fab") (width 0.1) (tstamp b0d0b155-793c-4155-aa2a-9d3abb10b29f))
    (fp_line (start 1.138 -0.955) (end -0.955 1.138) (layer "F.Fab") (width 0.1) (tstamp bdce2b83-7267-4284-9ed2-2c12e3c9bc36))
    (fp_line (start 5.955 -1.138) (end 3.863 0.955) (layer "F.Fab") (width 0.1) (tstamp f5ff88c3-e220-4d77-80f6-4329ddf17c16))
    (fp_circle (center 5 -3) (end 5.9 -3) (layer "F.Fab") (width 0.1) (fill none) (tstamp 0662225f-8d65-413b-acb9-5cc41ae91e8c))
    (fp_circle (center 0 0) (end 1.5 0) (layer "F.Fab") (width 0.1) (fill none) (tstamp 40d5a0e8-1c6b-401c-9cf5-48637de4ccc1))
    (fp_circle (center 0 -3) (end 0.9 -3) (layer "F.Fab") (width 0.1) (fill none) (tstamp 83be0f78-78e9-4881-9761-d82fe316167d))
    (fp_circle (center 5 0) (end 6.5 0) (layer "F.Fab") (width 0.1) (fill none) (tstamp ebe6752d-64fb-49ee-b12a-3ad484bdb0bb))
      (net 10 "Net-(C14-Pad1)") (pinfunction "Pin_1") (pintype "passive") (tstamp e150b842-d281-4da8-b01d-514dfd514c2e))
      (net 1 "Net-(BT1-Pad2)") (pinfunction "Pin_2") (pintype "passive") (tstamp bd2f8bc3-0f28-4c09-bc97-8aeaea7d8902))
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp 2a804301-e6ad-4368-9dc8-6583c5e09603)
    (at 83.82 25.146 -90)
    (property "Sheetfile" "Lauflicht_Steuerplatine.kicad_sch")
    (property "Sheetname" "")
    (path "/60226e9d-7bc1-48d3-af7c-c9e5cd2416c9")
    (attr smd)
    (fp_text reference "R13" (at 0 2.413 -90) (layer "F.SilkS")
      (effects (font (size 1 1) (thickness 0.15)))
      (tstamp 8378a387-44ab-49ea-b212-7bfd9a4eea79)
      (tstamp 48c720d9-c49f-4eda-bc72-8ac63efd72cc)
      (tstamp 07feca63-9413-438f-9a23-fd6c45122f19)
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 14201f19-e57b-4321-a0e6-930859e67897))
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp e3fe3497-ff31-401e-b7e0-1f217accd0a6))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 10967dc1-87ec-4e85-8674-82b0ba4ce5b8))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 62334f6d-5e4b-4f1c-80fc-1bdd7b7fa5dc))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp e6bcd7f0-01d1-45ce-9f1f-b22c0b99503f))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp ee1b5630-88ba-43b3-a465-c3ad7c92e7b4))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp b12f7e27-4962-4175-9d8b-e91712779222))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp e060a789-4c94-40fc-a20c-aa5af2a0bada))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp e4a85895-690a-4183-a88b-1e1dfb9cb9f9))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp faffd7c6-89dd-412a-ba9e-64f73abe0363))
      (net 20 "Net-(D6-Pad1)") (pintype "passive") (tstamp a43ec446-944a-4cae-846a-c987cc2854b6))
      (net 21 "Net-(D7-Pad2)") (pintype "passive") (tstamp ac02711a-e326-4374-8504-c80236810a1b))
      (scale (xyz 1 1 1))
  (footprint "Package_TO_SOT_THT:TO-92_Inline" (layer "F.Cu")
    (tedit 5A1DD157) (tstamp 2b344e7a-524f-4abf-a045-f39021a7f04e)
    (at 89.281 44.196 90)
    (descr "TO-92 leads in-line, narrow, oval pads, drill 0.75mm (see NXP sot054_po.pdf)")
    (tags "to-92 sc-43 sc-43a sot54 PA33 transistor")
    (path "/838afd1a-b412-4385-9a80-e9412456a870")
    (attr through_hole)
    (fp_text reference "Q2" (at 1.27 -3.556 270) (layer "F.SilkS")
      (tstamp b0b2c868-a61d-4cca-ac17-74e58b286f14)
    (fp_text value "BC337" (at 1.27 2.79 90) (layer "F.Fab")
      (tstamp c97b0158-5783-411a-8a2b-fdac3c4a9e54)
    (fp_text user "${REFERENCE}" (at 1.27 0 90) (layer "F.Fab")
      (tstamp 22511062-1821-42bf-86b1-5df4f016462f)
    (fp_line (start -0.53 1.85) (end 3.07 1.85) (layer "F.SilkS") (width 0.12) (tstamp 49e5f5de-1ea8-4e0b-97ac-555a13e0631a))
    (fp_arc (start -0.568478 1.838478) (mid -1.132087 -0.994977) (end 1.27 -2.6) (layer "F.SilkS") (width 0.12) (tstamp aa6af7e7-404a-4f01-b8fe-0659b5cdc097))
    (fp_arc (start 1.27 -2.6) (mid 3.672087 -0.994977) (end 3.108478 1.838478) (layer "F.SilkS") (width 0.12) (tstamp ad4b617c-2e49-4d8f-949c-ba6d26fa1667))
    (fp_line (start 4 2.01) (end 4 -2.73) (layer "F.CrtYd") (width 0.05) (tstamp 0ec08a10-6e5f-423d-a45c-06a6fe726ac8))
    (fp_line (start -1.46 -2.73) (end -1.46 2.01) (layer "F.CrtYd") (width 0.05) (tstamp 39406567-6236-4566-92af-5e8de70e70ec))
    (fp_line (start 4 2.01) (end -1.46 2.01) (layer "F.CrtYd") (width 0.05) (tstamp 47abb18b-842c-4c88-a87f-a12b941f7898))
    (fp_line (start -1.46 -2.73) (end 4 -2.73) (layer "F.CrtYd") (width 0.05) (tstamp c9bd725c-b0a4-4a7a-93aa-061998553d1f))
    (fp_line (start -0.5 1.75) (end 3 1.75) (layer "F.Fab") (width 0.1) (tstamp 61bbd257-476d-480c-8fcf-369aab1f7460))
    (fp_arc (start 1.27 -2.48) (mid 3.561221 -0.949055) (end 3.023625 1.753625) (layer "F.Fab") (width 0.1) (tstamp 2218c101-9e74-4beb-a17b-18c9e86bde14))
    (fp_arc (start -0.483625 1.753625) (mid -1.021221 -0.949055) (end 1.27 -2.48) (layer "F.Fab") (width 0.1) (tstamp ef57fde3-8539-428a-8eda-f1bd4c65e56f))
    (pad "1" thru_hole rect (at 0 0 90) (size 1.05 1.5) (drill 0.75) (layers *.Cu *.Mask)
      (net 21 "Net-(D7-Pad2)") (pinfunction "C") (pintype "passive") (tstamp ee50ebc3-978b-4020-a08e-7a7a67e35518))
    (pad "2" thru_hole oval (at 1.27 0 90) (size 1.05 1.5) (drill 0.75) (layers *.Cu *.Mask)
      (net 41 "Net-(Q2-Pad2)") (pinfunction "B") (pintype "input") (tstamp bcf2c006-f8b9-4d91-8474-3b2bd266bb71))
    (pad "3" thru_hole oval (at 2.54 0 90) (size 1.05 1.5) (drill 0.75) (layers *.Cu *.Mask)
      (net 1 "Net-(BT1-Pad2)") (pinfunction "E") (pintype "passive") (tstamp 673e159a-af7a-4af8-971b-9b36c5c1a660))
    (model "${KICAD6_3DMODEL_DIR}/Package_TO_SOT_THT.3dshapes/TO-92_Inline.wrl"
      (offset (xyz 0 0 0))
      (scale (xyz 1 1 1))
      (rotate (xyz 0 0 0))
    (tedit 5D160D14) (tstamp 2ef4be8c-2346-4a49-a7dd-8e9ee877150e)
    (at 138.149 143.59)
    (path "/c2b315b8-e4b3-4d97-972c-74d083837fba")
    (attr through_hole)
    (fp_text reference "SW6" (at -1.497 2.714) (layer "F.SilkS")
      (tstamp 91dc4932-524d-4c93-88ac-3606f2acdf94)
    (fp_text value "Rechts" (at 6.62 9.93) (layer "F.Fab")
      (tstamp 3ae13116-420d-4820-8bad-6788d50d9e44)
      (tstamp b99e4435-71ac-462c-973a-ca470f76d962)
    (fp_line (start 0.1 -3.65) (end 12.4 -3.65) (layer "F.SilkS") (width 0.12) (tstamp 5f507417-f9da-45e6-85a0-ebf51f90afb5))
    (fp_line (start 12.4 1.1) (end 12.4 3.8) (layer "F.SilkS") (width 0.12) (tstamp 7557f447-9517-4a2d-a87d-521f113033ba))
    (fp_line (start 0.1 3.8) (end 0.1 1.3) (layer "F.SilkS") (width 0.12) (tstamp 9ba8f465-b4c7-48f7-b7ec-ff52c47048f6))
    (fp_line (start 0.1 8.65) (end 0.1 6.2) (layer "F.SilkS") (width 0.12) (tstamp c5822fad-806f-44e2-9cab-627f0747ec26))
    (fp_line (start 0.1 -1.1) (end 0.1 -3.65) (layer "F.SilkS") (width 0.12) (tstamp d0793ca5-93eb-496b-837e-1150581ba6c2))
    (fp_line (start 12.4 -3.65) (end 12.4 -1.1) (layer "F.SilkS") (width 0.12) (tstamp e7c76525-6950-4c73-8b6d-103038d0edd4))
    (fp_line (start 12.4 8.65) (end 0.1 8.65) (layer "F.SilkS") (width 0.12) (tstamp ec2f9de8-4187-4208-9bee-2f1f64f93d58))
    (fp_line (start 12.4 6.2) (end 12.4 8.65) (layer "F.SilkS") (width 0.12) (tstamp f0af9064-8bd3-4b83-b4d9-5557f3bf66a9))
    (fp_circle (center 6.35 2.54) (end 10.16 5.08) (layer "F.SilkS") (width 0.12) (fill none) (tstamp f354b601-7dfd-44f7-8757-c123064a3a96))
    (fp_line (start -1.77 -3.75) (end -1.77 8.75) (layer "F.CrtYd") (width 0.05) (tstamp 372b73bf-c5e3-4ade-a947-23a0eb46b059))
    (fp_line (start 14.25 8.75) (end 14.25 -3.75) (layer "F.CrtYd") (width 0.05) (tstamp 4201c19d-0884-47a0-93fc-249de5affc9b))
    (fp_line (start 14.25 8.75) (end -1.77 8.75) (layer "F.CrtYd") (width 0.05) (tstamp 4c9c34b0-3519-4e43-a4c7-1749b2a276c9))
    (fp_line (start -1.77 -3.75) (end 14.25 -3.75) (layer "F.CrtYd") (width 0.05) (tstamp b36f0c35-c1e1-4826-a349-016cee06ba43))
    (fp_line (start 0.25 -3.5) (end 0.25 8.5) (layer "F.Fab") (width 0.1) (tstamp 2bbe90c7-8118-42ea-9fe4-c68e531027b8))
    (fp_line (start 0.25 8.5) (end 12.25 8.5) (layer "F.Fab") (width 0.1) (tstamp 7f0fe82e-d820-4c0a-be69-94d7af062714))
    (fp_line (start 12.25 -3.5) (end 12.25 8.5) (layer "F.Fab") (width 0.1) (tstamp ba35476c-7312-400b-89e3-15c3f401f1f4))
    (fp_line (start 0.25 -3.5) (end 12.25 -3.5) (layer "F.Fab") (width 0.1) (tstamp fbc66297-3be3-489f-913d-06ce75f7ea7f))
      (net 126 "Net-(J13-Pad5)") (pinfunction "A") (pintype "passive") (tstamp c925a8d4-f8ae-4c80-afd5-b2403465bb50))
      (net 126 "Net-(J13-Pad5)") (pinfunction "A") (pintype "passive") (tstamp ad91eead-5e19-4aa5-9804-e706a6d3d6bf))
      (net 128 "Net-(J13-Pad3)") (pinfunction "B") (pintype "passive") (tstamp 0011d414-08fc-4d4e-9838-1b0ba02ccb70))
      (net 128 "Net-(J13-Pad3)") (pinfunction "B") (pintype "passive") (tstamp e39589ef-5ccc-46fc-b50c-22cd7cd45a3d))
      (scale (xyz 1 1 1))
  (footprint "Resistor_SMD:R_1210_3225Metric_Pad1.30x2.65mm_HandSolder" (layer "F.Cu")
    (tedit 5F68FEEE) (tstamp 311fb6a5-def6-4c47-9822-91d33aebfd45)
    (at 79 25 -90)
    (descr "Resistor SMD 1210 (3225 Metric), square (rectangular) end terminal, IPC_7351 nominal with elongated pad for handsoldering. (Body size source: IPC-SM-782 page 72, https://www.pcb-3d.com/wordpress/wp-content/uploads/ipc-sm-782a_amendment_1_and_2.pdf), generated with kicad-footprint-generator")
    (tags "resistor handsolder")
    (path "/c7f29597-2ffa-4e8c-80c9-db22fc90d36a")
    (attr smd)
    (fp_text reference "R6" (at 0 2.413 -90) (layer "F.SilkS")
      (tstamp 3f732f0f-ac5d-47b5-afba-7a2f5f6aaf70)
      (tstamp 64e33717-80e4-4981-aa81-daced710a8b6)
      (effects (font (size 0.8 0.8) (thickness 0.12)))
      (tstamp e9eac628-d660-40d9-9f78-2d7971313380)
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp b766ce07-0853-4bd1-81f8-3ec301846891))
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp e4d72bc0-adcf-4ab0-957a-6a1b1ac12e2e))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 07a7f338-bd81-4af9-89db-c22ec3a8e1fb))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 2e153a01-837f-4e8c-bcea-92827308fbef))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 3bd53480-7092-4392-b3fd-d1032ec66ef5))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 6e768b64-b38a-48f5-9191-c9ddeb8960b2))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 79f18551-2ae6-4272-be8b-7ae2ac115887))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 91f4d30e-02ec-4d29-a851-9be657177599))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp dfd5b3ef-4311-4db2-ab9e-6fb442034d36))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp f0ea292b-6417-4171-9046-460c05fce579))
      (net 16 "Net-(D3-Pad1)") (pintype "passive") (tstamp 8892a0a2-2ea5-4ac3-9934-fb8e7955e2c7))
      (net 18 "Net-(D4-Pad2)") (pintype "passive") (tstamp 52cbaa17-588a-4951-b1e3-b035b414ddb6))
    (model "${KICAD6_3DMODEL_DIR}/Resistor_SMD.3dshapes/R_1210_3225Metric.wrl"
      (scale (xyz 1 1 1))
    (tedit 5F68FEF1) (tstamp 31545f6f-b685-4e84-a716-231d0eac2b95)
    (at 156.083 128.27 90)
    (path "/ed67cb17-6033-4db5-b9f6-ac1abce89222")
    (attr smd)
    (fp_text reference "D9" (at 0 -1.65 90) (layer "F.SilkS")
      (tstamp ffe372d4-a917-454d-8124-d6dd569fcef0)
    (fp_text value "OSO LYR976 Rot" (at 0 1.65 90) (layer "F.Fab")
      (tstamp e5b1b28f-89d7-43c6-aec7-d68d2677cb51)
      (tstamp b0315de1-72d1-487a-94db-1dcef0f815c6)
    (fp_line (start 1 -0.96) (end -1.86 -0.96) (layer "F.SilkS") (width 0.12) (tstamp 0e033258-6696-488a-ac64-9f36e9557a82))
    (fp_line (start -1.86 0.96) (end 1 0.96) (layer "F.SilkS") (width 0.12) (tstamp 494cdc4f-d2c0-4a02-8bbf-b1987582bb4d))
    (fp_line (start -1.86 -0.96) (end -1.86 0.96) (layer "F.SilkS") (width 0.12) (tstamp 5143f86d-c669-49bc-ab3a-cf41b88c4958))
    (fp_line (start -1.85 -0.95) (end 1.85 -0.95) (layer "F.CrtYd") (width 0.05) (tstamp 29056b09-28a8-46e1-8972-0653dd09e443))
    (fp_line (start 1.85 0.95) (end -1.85 0.95) (layer "F.CrtYd") (width 0.05) (tstamp 2e63bba7-bc9e-401c-96b9-78c56b2e4975))
    (fp_line (start -1.85 0.95) (end -1.85 -0.95) (layer "F.CrtYd") (width 0.05) (tstamp 7470a3f4-5de6-4efc-ac1a-df7bc3124413))
    (fp_line (start 1.85 -0.95) (end 1.85 0.95) (layer "F.CrtYd") (width 0.05) (tstamp e8808a11-a1ce-4537-a883-ad6663825b2b))
    (fp_line (start -0.7 -0.6) (end -1 -0.3) (layer "F.Fab") (width 0.1) (tstamp 0e4067b9-a239-47f8-8eaf-46a7d35e68b2))
    (fp_line (start -1 0.6) (end 1 0.6) (layer "F.Fab") (width 0.1) (tstamp ad92130e-b90a-4157-9f04-c935f791426e))
    (fp_line (start -1 -0.3) (end -1 0.6) (layer "F.Fab") (width 0.1) (tstamp dd1a4f54-49a9-4093-98bd-367cc428995b))
    (fp_line (start 1 -0.6) (end -0.7 -0.6) (layer "F.Fab") (width 0.1) (tstamp ef394c8d-de66-4326-b7e4-ce5c1eca4165))
    (fp_line (start 1 0.6) (end 1 -0.6) (layer "F.Fab") (width 0.1) (tstamp f5801899-6405-48f1-a2e9-7cc5e858fd84))
      (net 103 "Net-(D9-Pad1)") (pinfunction "K") (pintype "passive") (tstamp 25425cf5-f3c6-4f28-b7b5-d385bf0b42ce))
      (net 121 "Net-(D9-Pad2)") (pinfunction "A") (pintype "passive") (tstamp 0acb8d52-f964-4eb2-a6da-792cb1a4c5ef))
      (scale (xyz 1 1 1))
    (tedit 5F68FEEF) (tstamp 322ca4de-2c1a-4250-ad95-a194e9d249d4)
    (at 26.543 55.118 90)
    (path "/88cae4c8-3067-4c95-a9d3-67144b52068f")
    (attr smd)
    (fp_text reference "C19" (at 0 -2.032 90) (layer "F.SilkS")
      (tstamp 2154778c-6396-4b35-b264-4969b31e6187)
    (fp_text value "100n 50V KEM X7R1206 1,0U" (at 0 1.85 90) (layer "F.Fab")
      (tstamp e2d9e3b1-42e3-4537-9ded-b2103b81fdac)
      (tstamp 78305364-9e46-4629-b645-4d4aea7151ce)
    (fp_line (start -0.711252 -0.91) (end 0.711252 -0.91) (layer "F.SilkS") (width 0.12) (tstamp 37bb381c-cb91-4604-840f-59dc0432cfd3))
    (fp_line (start -0.711252 0.91) (end 0.711252 0.91) (layer "F.SilkS") (width 0.12) (tstamp 46c1f19b-0377-4e8b-8a8f-b07d247d0866))
    (fp_line (start -2.48 1.15) (end -2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp 4e31a629-66de-48e1-8ded-7401eaa84512))
    (fp_line (start 2.48 -1.15) (end 2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp 50b622b3-a0fa-45a3-a456-46a73495a0b1))
    (fp_line (start -2.48 -1.15) (end 2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp 77d99de6-72c4-4764-9663-8160e744155d))
    (fp_line (start 2.48 1.15) (end -2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp afa7fc90-c7dc-4131-b6b8-38d7806a172d))
    (fp_line (start -1.6 0.8) (end -1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp 171da18f-1084-4433-b102-fc8668d781f1))
    (fp_line (start 1.6 -0.8) (end 1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp 76a19cf2-82c9-4060-85a9-08bfe8f3e924))
    (fp_line (start 1.6 0.8) (end -1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp acdac6dc-37da-4f2a-b703-5830e1127a31))
    (fp_line (start -1.6 -0.8) (end 1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp d08d2f0b-ec4e-4491-883b-dd1ba5d33472))
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp f056f106-1e15-45a7-a57c-e917501b80e2))
      (net 11 "Net-(BT1-Pad1)") (pintype "passive") (tstamp 95d9dbe7-d467-4d86-983e-e8d4055e5166))
      (scale (xyz 1 1 1))
  (footprint "Package_QFP:TQFP-44_10x10mm_P0.8mm" (layer "F.Cu")
    (tedit 5A02F146) (tstamp 328b33c9-3679-4d89-9b5d-5099bc3d1ba0)
    (at 39.516 90.151)
    (descr "44-Lead Plastic Thin Quad Flatpack (PT) - 10x10x1.0 mm Body [TQFP] (see Microchip Packaging Specification 00000049BS.pdf)")
    (tags "QFP 0.8")
    (path "/c42e8105-c050-4927-b93e-90d462498d75")
    (attr smd)
    (fp_text reference "U8" (at -5.48 -7.45) (layer "F.SilkS")
      (tstamp 43203136-b0af-4413-a37e-d0e0d4feb6df)
    (fp_text value "ATmega324A-A (TQFP)" (at 0 7.45) (layer "F.Fab")
      (tstamp 9bd07fbb-334c-42aa-8deb-82c799113fcc)
    (fp_text user "${REFERENCE}" (at 0 0) (layer "F.Fab")
      (tstamp fe55daec-6e32-45d4-a9aa-46f62a1a9313)
    (fp_line (start -5.175 5.175) (end -5.175 4.5) (layer "F.SilkS") (width 0.15) (tstamp 39076b07-ef84-455d-9ac5-1617bb231df5))
    (fp_line (start 5.175 -5.175) (end 4.5 -5.175) (layer "F.SilkS") (width 0.15) (tstamp 3fee61b6-a915-4001-96d3-eaf4b25cf148))
    (fp_line (start 5.175 5.175) (end 5.175 4.5) (layer "F.SilkS") (width 0.15) (tstamp 45430a9e-2e95-4206-a15a-9b2b3a4010a6))
    (fp_line (start -5.175 -5.175) (end -4.5 -5.175) (layer "F.SilkS") (width 0.15) (tstamp 46409e1c-0209-4c21-b780-35e5c6a8d189))
    (fp_line (start 5.175 5.175) (end 4.5 5.175) (layer "F.SilkS") (width 0.15) (tstamp 46c56807-e1e3-4943-b49e-4f37ed447fa9))
    (fp_line (start -5.175 5.175) (end -4.5 5.175) (layer "F.SilkS") (width 0.15) (tstamp 4731b6b3-f832-41b6-a736-506ced8d4aa1))
    (fp_line (start -5.175 -5.175) (end -5.175 -4.6) (layer "F.SilkS") (width 0.15) (tstamp 5f817c05-860e-4e59-919b-09da400f0140))
    (fp_line (start 5.175 -5.175) (end 5.175 -4.5) (layer "F.SilkS") (width 0.15) (tstamp ce3ab116-8280-4d09-a2c2-ab7957b447c9))
    (fp_line (start -5.175 -4.6) (end -6.45 -4.6) (layer "F.SilkS") (width 0.15) (tstamp e9252689-6d1f-4d58-a77e-e1d86c8e924b))
    (fp_line (start -6.7 6.7) (end 6.7 6.7) (layer "F.CrtYd") (width 0.05) (tstamp 4f005faa-6410-4296-9cd6-4919881c6117))
    (fp_line (start -6.7 -6.7) (end -6.7 6.7) (layer "F.CrtYd") (width 0.05) (tstamp a89c0de3-487a-49cf-8937-39842b7e6eb6))
    (fp_line (start -6.7 -6.7) (end 6.7 -6.7) (layer "F.CrtYd") (width 0.05) (tstamp c3606297-24a9-4b27-b18c-c65725a1f2bc))
    (fp_line (start 6.7 -6.7) (end 6.7 6.7) (layer "F.CrtYd") (width 0.05) (tstamp c9397336-c671-4c23-88c0-f6106a96cfe9))
    (fp_line (start -5 5) (end -5 -4) (layer "F.Fab") (width 0.15) (tstamp 265a47bd-dd1d-4713-99ae-227e572b551d))
    (fp_line (start 5 -5) (end 5 5) (layer "F.Fab") (width 0.15) (tstamp 2a2967d8-b928-41ac-be0d-69c59db94166))
    (fp_line (start 5 5) (end -5 5) (layer "F.Fab") (width 0.15) (tstamp 8ba713f6-1c59-4e74-9060-a6761374103f))
    (fp_line (start -5 -4) (end -4 -5) (layer "F.Fab") (width 0.15) (tstamp b841c631-0a9b-49eb-80ed-ae49038f5f98))
    (fp_line (start -4 -5) (end 5 -5) (layer "F.Fab") (width 0.15) (tstamp f89cf809-f520-4c97-9d68-7c6b0243eb46))
    (pad "1" smd rect (at -5.7 -4) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 37 "Net-(J15-Pad4)") (pinfunction "MOSI_PB5") (pintype "bidirectional") (tstamp 8a7e4497-19cf-47ef-96c5-a9263c6fbd5e))
    (pad "2" smd rect (at -5.7 -3.2) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 35 "Net-(J15-Pad1)") (pinfunction "MISO_PB6") (pintype "bidirectional") (tstamp 9eac0ce9-b5c1-4574-a2cf-a77b65131d73))
    (pad "3" smd rect (at -5.7 -2.4) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 36 "Net-(J15-Pad3)") (pinfunction "SCK_PB7") (pintype "bidirectional") (tstamp 3831483f-3fcf-4bcf-b692-d39dfd5d1806))
    (pad "4" smd rect (at -5.7 -1.6) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 12 "Net-(C25-Pad1)") (pinfunction "~{RESET}") (pintype "input") (tstamp d399b7e1-3841-4627-84d6-a577080bd673))
    (pad "5" smd rect (at -5.7 -0.8) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 85 "Net-(C20-Pad1)") (pinfunction "VCC") (pintype "power_in") (tstamp ae9d9b39-9f6f-4c65-8551-81b2a042b846))
    (pad "6" smd rect (at -5.7 0) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 1 "Net-(BT1-Pad2)") (pinfunction "GND") (pintype "power_in") (tstamp 1f6eb435-fb7c-42f0-a020-2b06f99d503f))
    (pad "7" smd rect (at -5.7 0.8) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 13 "Net-(C27-Pad1)") (pinfunction "XTAL2") (pintype "output") (tstamp 1b0cdd01-3535-4124-a4dc-a05085da7341))
    (pad "8" smd rect (at -5.7 1.6) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 14 "Net-(C28-Pad2)") (pinfunction "XTAL1") (pintype "input") (tstamp fe87fe07-bd01-4210-a208-55107d3492e0))
    (pad "9" smd rect (at -5.7 2.4) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 52 "Net-(R22-Pad1)") (pinfunction "PD0") (pintype "bidirectional") (tstamp 76ef484b-56a9-4cda-a416-dfe86853de98))
    (pad "10" smd rect (at -5.7 3.2) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 51 "Net-(R21-Pad1)") (pinfunction "PD1") (pintype "bidirectional") (tstamp da308342-1ca8-460a-a284-982a4538487e))
    (pad "11" smd rect (at -5.7 4) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 56 "Net-(R26-Pad2)") (pinfunction "INT0_PD2") (pintype "bidirectional") (tstamp 74c8bdc5-0fff-4f34-91e7-d72e3ed44b20))
    (pad "12" smd rect (at -4 5.7 90) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 48 "Net-(R18-Pad1)") (pinfunction "INT1_PD3") (pintype "bidirectional") (tstamp bdd6a923-310f-4693-b15e-27dc00f614f0))
    (pad "13" smd rect (at -3.2 5.7 90) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 62 "Net-(R31-Pad1)") (pinfunction "OC1B_PD4") (pintype "bidirectional") (tstamp 80d3cb67-8ea5-4e8a-bbf3-6943383092d7))
    (pad "14" smd rect (at -2.4 5.7 90) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 65 "Net-(R34-Pad1)") (pinfunction "OC1A_PD5") (pintype "bidirectional") (tstamp 2bda9ece-efa3-4b29-ae9b-3bbf33826147))
    (pad "15" smd rect (at -1.6 5.7 90) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 68 "Net-(R38-Pad1)") (pinfunction "OC2B_PD6") (pintype "bidirectional") (tstamp 98a9fb5c-0c5d-40e2-8bdd-a0e28e347357))
    (pad "16" smd rect (at -0.8 5.7 90) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 70 "Net-(R41-Pad1)") (pinfunction "OC2A_PD7") (pintype "bidirectional") (tstamp ac65ff36-5c13-411b-a198-cbff95f560d6))
    (pad "17" smd rect (at 0 5.7 90) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 85 "Net-(C20-Pad1)") (pinfunction "VCC") (pintype "passive") (tstamp a1a908b3-3580-4510-a46f-75dac8e42a4a))
    (pad "18" smd rect (at 0.8 5.7 90) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 1 "Net-(BT1-Pad2)") (pinfunction "GND") (pintype "passive") (tstamp 4d2ffba1-17e1-447a-9238-c9961cd8b57f))
    (pad "19" smd rect (at 1.6 5.7 90) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 71 "Net-(R42-Pad1)") (pinfunction "PC0") (pintype "bidirectional") (tstamp 1825a56b-1d2f-4e8e-bb68-c8189bf2abf0))
    (pad "20" smd rect (at 2.4 5.7 90) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 69 "Net-(R39-Pad1)") (pinfunction "PC1") (pintype "bidirectional") (tstamp a3d90939-3da7-4320-9787-a94865fe8c8d))
    (pad "21" smd rect (at 3.2 5.7 90) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 66 "Net-(R35-Pad1)") (pinfunction "PC2") (pintype "bidirectional") (tstamp 02909ca7-d5c7-48d6-ba5b-427e7b4bf1cd))
    (pad "22" smd rect (at 4 5.7 90) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 63 "Net-(R32-Pad1)") (pinfunction "PC3") (pintype "bidirectional") (tstamp 2d57ded3-bf1e-4418-aacb-8280dad86b3c))
    (pad "23" smd rect (at 5.7 4) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 60 "Net-(R29-Pad1)") (pinfunction "PC4") (pintype "bidirectional") (tstamp 10d10573-95ce-40d0-973c-e6b8ee38248b))
    (pad "24" smd rect (at 5.7 3.2) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 54 "Net-(R25-Pad1)") (pinfunction "PC5") (pintype "bidirectional") (tstamp 350f58a8-0f61-4de9-87f6-71d3a6885a8f))
    (pad "25" smd rect (at 5.7 2.4) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 134 "Net-(R55-Pad1)") (pinfunction "PC6") (pintype "bidirectional") (tstamp b45410dd-07f1-48ef-ae5a-d245941c1bd1))
    (pad "26" smd rect (at 5.7 1.6) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 50 "Net-(R20-Pad1)") (pinfunction "PC7") (pintype "bidirectional") (tstamp fe089f66-8d43-437e-b663-c3857ad250e7))
    (pad "27" smd rect (at 5.7 0.8) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 85 "Net-(C20-Pad1)") (pinfunction "AVCC") (pintype "power_in") (tstamp 3d63d2ca-e455-42ef-b40b-0f40db1b9f60))
    (pad "28" smd rect (at 5.7 0) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 1 "Net-(BT1-Pad2)") (pinfunction "GND") (pintype "passive") (tstamp f9281e23-5ff3-40b6-96b1-468e05806061))
    (pad "29" smd rect (at 5.7 -0.8) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 101 "Net-(R52-Pad2)") (pinfunction "AREF") (pintype "passive") (tstamp 2ffc9051-4eb0-4d7a-b93a-6542268711f3))
    (pad "30" smd rect (at 5.7 -1.6) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 58 "Net-(R27-Pad2)") (pinfunction "PA7") (pintype "bidirectional") (tstamp 0b44f652-39ec-40c3-9033-f8dd64a30c66))
    (pad "31" smd rect (at 5.7 -2.4) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 77 "Net-(R48-Pad1)") (pinfunction "PA6") (pintype "bidirectional") (tstamp b21b5de4-1a18-40cc-9578-4d4f667bfd5b))
    (pad "32" smd rect (at 5.7 -3.2) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 78 "Net-(R49-Pad1)") (pinfunction "PA5") (pintype "bidirectional") (tstamp 0bdbfcc5-fe1c-4320-ab53-94715b6c3536))
    (pad "33" smd rect (at 5.7 -4) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 79 "Net-(R50-Pad1)") (pinfunction "PA4") (pintype "bidirectional") (tstamp 16260514-2cc9-4e2f-9684-6578b9fae7e6))
    (pad "34" smd rect (at 4 -5.7 90) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 72 "Net-(R43-Pad1)") (pinfunction "PA3") (pintype "bidirectional") (tstamp b307312a-1aa2-42c0-8d01-8a8f1f6ba582))
    (pad "35" smd rect (at 3.2 -5.7 90) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 73 "Net-(R44-Pad1)") (pinfunction "PA2") (pintype "bidirectional") (tstamp c8a7067f-cc2c-40ea-ad7f-2f56251b5f0f))
    (pad "36" smd rect (at 2.4 -5.7 90) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 74 "Net-(R45-Pad1)") (pinfunction "PA1") (pintype "bidirectional") (tstamp 9859264c-8548-4b90-bd8a-a2e9919bec7f))
    (pad "37" smd rect (at 1.6 -5.7 90) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 75 "Net-(R46-Pad1)") (pinfunction "PA0") (pintype "bidirectional") (tstamp 232ac63d-5ff8-4071-aae9-96446dc8dd8b))
    (pad "38" smd rect (at 0.8 -5.7 90) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 85 "Net-(C20-Pad1)") (pinfunction "VCC") (pintype "passive") (tstamp e1ba301c-16fd-4584-bf64-b8abde54e77a))
    (pad "39" smd rect (at 0 -5.7 90) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 1 "Net-(BT1-Pad2)") (pinfunction "GND") (pintype "passive") (tstamp 576c53c8-2df9-4aa9-a330-8bb23c2d437e))
    (pad "40" smd rect (at -0.8 -5.7 90) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 61 "Net-(R30-Pad1)") (pinfunction "PB0") (pintype "bidirectional") (tstamp f35a0ab8-b329-4ed5-8b12-d37ecdab9299))
    (pad "41" smd rect (at -1.6 -5.7 90) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 67 "Net-(R37-Pad1)") (pinfunction "PB1") (pintype "bidirectional") (tstamp cf94b697-f04f-4c36-868a-99b9ee1008e8))
    (pad "42" smd rect (at -2.4 -5.7 90) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 53 "Net-(R24-Pad1)") (pinfunction "INT2_PB2") (pintype "bidirectional") (tstamp f2fcece3-68f9-4644-b340-f1619631e5fa))
    (pad "43" smd rect (at -3.2 -5.7 90) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 76 "Net-(R47-Pad1)") (pinfunction "OC0A_PB3") (pintype "bidirectional") (tstamp b174c462-c3de-4fd5-a4f3-fe46b00889cb))
    (pad "44" smd rect (at -4 -5.7 90) (size 1.5 0.55) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 59 "Net-(R28-Pad1)") (pinfunction "OC0B_PB4") (pintype "bidirectional") (tstamp a822b3c3-ec1d-4722-ace1-24453be7a2b7))
    (model "${KICAD6_3DMODEL_DIR}/Package_QFP.3dshapes/TQFP-44_10x10mm_P0.8mm.wrl"
      (scale (xyz 1 1 1))
  (footprint "Capacitor_SMD:C_1206_3216Metric_Pad1.33x1.80mm_HandSolder" (layer "F.Cu")
    (tedit 5F68FEEF) (tstamp 34b3f4bf-b9d6-4c3a-a6d3-a5e8fd4c1590)
    (at 50.038 89.916 90)
    (descr "Capacitor SMD 1206 (3216 Metric), square (rectangular) end terminal, IPC_7351 nominal with elongated pad for handsoldering. (Body size source: IPC-SM-782 page 76, https://www.pcb-3d.com/wordpress/wp-content/uploads/ipc-sm-782a_amendment_1_and_2.pdf), generated with kicad-footprint-generator")
    (tags "capacitor handsolder")
    (path "/a9ccb754-052f-4486-b8a3-fbfa5880f62e")
    (attr smd)
    (fp_text reference "C30" (at 0 -1.85 90) (layer "F.SilkS")
      (tstamp 5b7cb9dd-3090-4974-98b7-700ab514c33a)
      (tstamp ea35875b-2026-494f-930d-8111e7aaabab)
    (fp_text user "${REFERENCE}" (at 0 0 90) (layer "F.Fab")
      (tstamp 2a025591-84a1-4055-804e-fd6237836738)
    (fp_line (start -0.711252 -0.91) (end 0.711252 -0.91) (layer "F.SilkS") (width 0.12) (tstamp 30ee5752-fab1-4d32-9f4f-e0b484a36479))
    (fp_line (start -0.711252 0.91) (end 0.711252 0.91) (layer "F.SilkS") (width 0.12) (tstamp 7038197e-9203-494d-b235-bd4db8097db7))
    (fp_line (start -2.48 1.15) (end -2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp 2be6b5fb-0ea7-456c-9eb9-323660d11e98))
    (fp_line (start -2.48 -1.15) (end 2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp 2ef0f8dd-8819-4023-baeb-a1d1318e6ff4))
    (fp_line (start 2.48 -1.15) (end 2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp 520f550a-17f4-4e2f-b80e-ba39e5fa732a))
    (fp_line (start 2.48 1.15) (end -2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp f2a5dc5e-e0ec-4c63-aaec-f7ce0740e73f))
    (fp_line (start -1.6 -0.8) (end 1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp 303277c3-9247-414d-a59d-85c65e378cda))
    (fp_line (start 1.6 0.8) (end -1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp 6985fa36-3101-4b7f-96fc-e6168dff0916))
    (fp_line (start 1.6 -0.8) (end 1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp 7ce85f89-2072-4507-bba6-c72398dcb1bb))
    (fp_line (start -1.6 0.8) (end -1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp bf82f932-bbc5-4b50-a0fb-9da696e01983))
      (net 85 "Net-(C20-Pad1)") (pintype "passive") (tstamp 44b5c883-1b67-4c36-871e-53f633c6337d))
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp 92fd77b0-9eec-46ae-a1e2-485c45935cce))
    (model "${KICAD6_3DMODEL_DIR}/Capacitor_SMD.3dshapes/C_1206_3216Metric.wrl"
      (scale (xyz 1 1 1))
    (tedit 5F68FEEF) (tstamp 36a33ae3-c4bf-43fc-ab6a-a7415bf0516d)
    (at 39.0275 79.991 180)
    (path "/8cbf7a50-055a-4fd7-b035-1fc53b0aa0ae")
    (attr smd)
    (fp_text reference "C24" (at 0 -2.051) (layer "F.SilkS")
      (tstamp 52743973-73eb-42d5-bd37-2fe5b36687f5)
    (fp_text value "100n 50V KEM X7R1206 1,0U" (at 0 1.85) (layer "F.Fab")
      (tstamp 72d2747c-495c-4577-9bae-e588dabade68)
      (tstamp adca64ca-41d5-4bdf-89c8-ca5c072c8d48)
    (fp_line (start -0.711252 -0.91) (end 0.711252 -0.91) (layer "F.SilkS") (width 0.12) (tstamp 2da34166-6bf8-4a9d-afc8-9dc681ae9b3d))
    (fp_line (start -0.711252 0.91) (end 0.711252 0.91) (layer "F.SilkS") (width 0.12) (tstamp c7c67770-a542-46dd-af13-78abaef9e442))
    (fp_line (start 2.48 1.15) (end -2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp 0ec68838-1a11-48de-b01a-1ed8281b5459))
    (fp_line (start -2.48 -1.15) (end 2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp 2e158446-e133-4977-84cf-0dced8433aac))
    (fp_line (start -2.48 1.15) (end -2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp 87b1f15e-4f4a-4b19-a9af-28cbcef7ab15))
    (fp_line (start 2.48 -1.15) (end 2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp 8b1099bd-cf44-4350-a9d8-ddc78f9c0249))
    (fp_line (start -1.6 -0.8) (end 1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp 22076510-3be9-4d09-97a5-7fc6d54af8d5))
    (fp_line (start -1.6 0.8) (end -1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp 55acd2fc-aef0-4060-ae70-3e59659454d7))
    (fp_line (start 1.6 0.8) (end -1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp a250e0a0-691e-461b-bebf-c0ab79b094a9))
    (fp_line (start 1.6 -0.8) (end 1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp eb4698ef-5d78-4a4c-9f22-b335464cc17f))
    (pad "1" smd roundrect (at -1.5625 0 180) (size 1.325 1.8) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1886792453)
      (net 85 "Net-(C20-Pad1)") (pintype "passive") (tstamp 42605d0f-d0a4-4f87-9352-6607f31ee887))
    (pad "2" smd roundrect (at 1.5625 0 180) (size 1.325 1.8) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1886792453)
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp 4bdf868a-9c8a-4ca5-9b67-505c8220eaa6))
      (scale (xyz 1 1 1))
    (tedit 5F68FEF1) (tstamp 37db3675-f763-4eed-8932-f634fe6fca00)
    (at 79 19.556 90)
    (path "/758a4779-8a6b-4886-a761-89b01c8cba25")
    (attr smd)
    (fp_text reference "D3" (at -0.127 -1.905 270) (layer "F.SilkS")
      (tstamp f7a77811-13dd-4334-86d8-3ded529d75ed)
      (tstamp 9981df75-cd1d-4e4f-a773-8a7555d964a4)
      (tstamp 45e2375d-f82a-46f7-93bf-4ae821cac310)
    (fp_line (start -1.86 -0.96) (end -1.86 0.96) (layer "F.SilkS") (width 0.12) (tstamp 2ed72ae6-6fd4-4789-8182-168b33ed4545))
    (fp_line (start -1.86 0.96) (end 1 0.96) (layer "F.SilkS") (width 0.12) (tstamp 677a52f8-aa20-47d2-b4cb-c67bebefb484))
    (fp_line (start 1 -0.96) (end -1.86 -0.96) (layer "F.SilkS") (width 0.12) (tstamp e2c5f737-093f-47dc-a52f-8889cfb232e6))
    (fp_line (start -1.85 0.95) (end -1.85 -0.95) (layer "F.CrtYd") (width 0.05) (tstamp 21baf4aa-5bae-4c51-a4ce-bf1dcd2d7912))
    (fp_line (start -1.85 -0.95) (end 1.85 -0.95) (layer "F.CrtYd") (width 0.05) (tstamp 30060f5d-128f-49a9-b0d8-b2eec9ef097d))
    (fp_line (start 1.85 -0.95) (end 1.85 0.95) (layer "F.CrtYd") (width 0.05) (tstamp 5e0bd6b8-4764-47d0-876b-69678b882767))
    (fp_line (start 1.85 0.95) (end -1.85 0.95) (layer "F.CrtYd") (width 0.05) (tstamp f3f350b6-1c3c-4c6d-8e4f-afefa33bb4ae))
    (fp_line (start -0.7 -0.6) (end -1 -0.3) (layer "F.Fab") (width 0.1) (tstamp 537e2b60-2c5d-41b1-908c-3d48f8eedd81))
    (fp_line (start 1 0.6) (end 1 -0.6) (layer "F.Fab") (width 0.1) (tstamp 7ef845f2-ec8d-4f1b-9d18-4add39b8e042))
    (fp_line (start -1 -0.3) (end -1 0.6) (layer "F.Fab") (width 0.1) (tstamp bd43c441-8243-4bef-bc83-f111926b5068))
    (fp_line (start -1 0.6) (end 1 0.6) (layer "F.Fab") (width 0.1) (tstamp f3574862-6314-4b0b-b076-159bb4f9ba41))
    (fp_line (start 1 -0.6) (end -0.7 -0.6) (layer "F.Fab") (width 0.1) (tstamp f9f5a972-b978-4625-aff5-3f511e89e9ff))
      (net 16 "Net-(D3-Pad1)") (pinfunction "K") (pintype "passive") (tstamp cbf5900d-4280-4c01-87a3-5c91fd27ac76))
      (net 17 "Net-(D3-Pad2)") (pinfunction "A") (pintype "passive") (tstamp c864ab14-9cd6-410b-b5be-8e06f5d8736a))
      (scale (xyz 1 1 1))
  (footprint "Capacitor_THT:CP_Radial_D12.5mm_P5.00mm" (layer "F.Cu")
    (tedit 5AE50EF1) (tstamp 37f6edaf-3d02-44a3-9815-7cba657b7c18)
    (at 150.241 101.129959 90)
    (descr "CP, Radial series, Radial, pin pitch=5.00mm, , diameter=12.5mm, Electrolytic Capacitor")
    (tags "CP Radial series Radial pin pitch 5.00mm  diameter 12.5mm Electrolytic Capacitor")
    (path "/d918d19a-d642-4350-b121-e3da2f5b6278")
    (attr through_hole)
    (fp_text reference "C14" (at 2.5 -7.5 90) (layer "F.SilkS")
      (tstamp 8cb876bd-f65f-4c40-af7d-d1c92bfc8895)
    (fp_text value "ELKO 680/35 FK 1500/35 AM" (at 2.5 7.5 90) (layer "F.Fab")
      (tstamp 41f6e4c4-6d1f-42e9-8417-394d65b4c690)
    (fp_text user "${REFERENCE}" (at 2.5 0 90) (layer "F.Fab")
      (tstamp 340957be-44de-4978-a6a9-19addcb792b1)
    (fp_line (start 3.741 1.44) (end 3.741 6.209) (layer "F.SilkS") (width 0.12) (tstamp 0755c716-84dc-411a-b2c1-10376f3e55b5))
    (fp_line (start 6.461 -4.95) (end 6.461 4.95) (layer "F.SilkS") (width 0.12) (tstamp 087d186c-2487-425a-9cfa-8ed24bf4e6f9))
    (fp_line (start 4.021 1.44) (end 4.021 6.146) (layer "F.SilkS") (width 0.12) (tstamp 08c27e5e-7be1-4169-b8a5-c101a15f6535))
    (fp_line (start 4.301 1.44) (end 4.301 6.071) (layer "F.SilkS") (width 0.12) (tstamp 0917253b-6f80-4d3f-9eeb-14f3bcc53c20))
    (fp_line (start 3.701 -6.216) (end 3.701 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 0a180677-95c5-4d71-8fad-bc79a864d7a4))
    (fp_line (start 6.141 1.44) (end 6.141 5.188) (layer "F.SilkS") (width 0.12) (tstamp 0cd75ca9-7fac-407c-b969-8032939c8745))
    (fp_line (start 2.86 -6.32) (end 2.86 6.32) (layer "F.SilkS") (width 0.12) (tstamp 0e9c7732-0f30-45f3-a424-50249dc63dcf))
    (fp_line (start 4.781 -5.908) (end 4.781 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 0ef1489e-188d-4b66-8b78-0a90d320fffd))
    (fp_line (start 4.181 -6.105) (end 4.181 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 0ff2f1f0-b314-4ea3-a7d0-3e54d7a42e00))
    (fp_line (start 6.781 -4.678) (end 6.781 4.678) (layer "F.SilkS") (width 0.12) (tstamp 10975b79-c9e5-46f5-be2c-2ee1938c0e67))
    (fp_line (start 8.061 -3.069) (end 8.061 3.069) (layer "F.SilkS") (width 0.12) (tstamp 12c71492-5232-47a2-bd51-4a41b4e6a775))
    (fp_line (start 5.701 1.44) (end 5.701 5.468) (layer "F.SilkS") (width 0.12) (tstamp 13492d30-66d6-4aed-b13b-35130c473233))
    (fp_line (start 2.54 -6.33) (end 2.54 6.33) (layer "F.SilkS") (width 0.12) (tstamp 1371e2e4-65eb-4a09-abb7-782e5f70c205))
    (fp_line (start 8.101 -2.996) (end 8.101 2.996) (layer "F.SilkS") (width 0.12) (tstamp 1471ce04-0ef0-406a-95a3-5cba8cbb49f6))
    (fp_line (start 7.461 -3.957) (end 7.461 3.957) (layer "F.SilkS") (width 0.12) (tstamp 15c58803-d8a4-4aa7-b527-158dc36c1d56))
    (fp_line (start 5.221 -5.721) (end 5.221 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 16e0b66a-3090-4b6b-9ad8-368f77fd728f))
    (fp_line (start 3.941 1.44) (end 3.941 6.166) (layer "F.SilkS") (width 0.12) (tstamp 180d1789-6af7-43e6-a4d8-f9675fc10d21))
    (fp_line (start 5.101 1.44) (end 5.101 5.776) (layer "F.SilkS") (width 0.12) (tstamp 186b71c8-a3de-4335-95bc-496035fa1074))
    (fp_line (start 4.461 -6.021) (end 4.461 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 197b14fe-8338-47e4-81e4-87a85a2fcfcc))
    (fp_line (start 7.661 -3.696) (end 7.661 3.696) (layer "F.SilkS") (width 0.12) (tstamp 1b6ec085-8ec1-4419-bace-10d963e66a6c))
    (fp_line (start 4.661 1.44) (end 4.661 5.953) (layer "F.SilkS") (width 0.12) (tstamp 20bb8fad-d4fa-498c-b989-942cbb40ccbf))
    (fp_line (start 6.181 -5.16) (end 6.181 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 223dd022-5d7d-4538-99f7-d9f6ac103bdc))
    (fp_line (start 3.661 -6.224) (end 3.661 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 227cb272-0c3e-4602-8802-33cefd7ab5f7))
    (fp_line (start 5.021 -5.811) (end 5.021 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 22bc51c3-a2b3-468b-9df2-a4b51f09d096))
    (fp_line (start 8.781 -1.028) (end 8.781 1.028) (layer "F.SilkS") (width 0.12) (tstamp 245f69b7-bc5b-4ae8-9472-c48c5e3512ce))
    (fp_line (start 8.301 -2.594) (end 8.301 2.594) (layer "F.SilkS") (width 0.12) (tstamp 24b59fb3-2670-43d5-95d1-76295fddd691))
    (fp_line (start 6.021 1.44) (end 6.021 5.27) (layer "F.SilkS") (width 0.12) (tstamp 2510b478-af04-4940-bb97-f4674e83f0d6))
    (fp_line (start 4.661 -5.953) (end 4.661 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 269a0910-9ee2-4e8a-9eeb-5a09f3083d1c))
    (fp_line (start 4.021 -6.146) (end 4.021 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 27151a89-6552-4ef3-98a9-32aef4b0b4d8))
    (fp_line (start 6.421 -4.982) (end 6.421 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 28686fa6-118c-462f-ab6f-4caf977dcab3))
    (fp_line (start 5.221 1.44) (end 5.221 5.721) (layer "F.SilkS") (width 0.12) (tstamp 286df50b-c7bd-4440-bd1a-bf8c32ee40ed))
    (fp_line (start 6.501 -4.918) (end 6.501 4.918) (layer "F.SilkS") (width 0.12) (tstamp 29f390c1-7b98-4b67-a6c3-36e3a18d4501))
    (fp_line (start 8.141 -2.921) (end 8.141 2.921) (layer "F.SilkS") (width 0.12) (tstamp 2b2da7e0-5b4b-4274-ba49-bcdf3d8a3bc7))
    (fp_line (start 7.181 -4.282) (end 7.181 4.282) (layer "F.SilkS") (width 0.12) (tstamp 2bf99715-19a9-4af2-a2fa-85953714ad06))
    (fp_line (start 5.261 -5.702) (end 5.261 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 2c077414-c5dc-4bd0-8c6b-9c92892db381))
    (fp_line (start 4.821 -5.893) (end 4.821 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 2c17fe54-bc0a-49a3-8485-5d128d13d936))
    (fp_line (start 4.741 1.44) (end 4.741 5.924) (layer "F.SilkS") (width 0.12) (tstamp 2ce380e5-c469-4ac9-9d0b-63de585f0ba1))
    (fp_line (start 4.941 -5.845) (end 4.941 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 2cf5872a-075a-4a0e-a726-433b19656868))
    (fp_line (start 5.301 -5.682) (end 5.301 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 2e8bd573-ae3b-4feb-a7b3-72899fa2db3f))
    (fp_line (start 7.101 -4.367) (end 7.101 4.367) (layer "F.SilkS") (width 0.12) (tstamp 2ec6895a-fcef-4458-9214-c06a8f520ae9))
    (fp_line (start 3.381 -6.269) (end 3.381 6.269) (layer "F.SilkS") (width 0.12) (tstamp 2ef291d9-c9fe-4e03-9b3a-5b260edf062a))
    (fp_line (start 4.541 -5.995) (end 4.541 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 2f43e0da-09c0-49d9-bbee-dbe5c38c1e7f))
    (fp_line (start 7.021 -4.449) (end 7.021 4.449) (layer "F.SilkS") (width 0.12) (tstamp 3007e97c-bf96-4a7a-abb8-be62656dc172))
    (fp_line (start 8.461 -2.209) (end 8.461 2.209) (layer "F.SilkS") (width 0.12) (tstamp 30f33f82-7f06-4a64-8f97-77f7294b4a05))
    (fp_line (start 6.381 -5.012) (end 6.381 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 311c0756-02e1-41d2-a880-02f042560773))
    (fp_line (start 5.421 1.44) (end 5.421 5.622) (layer "F.SilkS") (width 0.12) (tstamp 31faeca4-af7d-48a5-8060-9379b792f8df))
    (fp_line (start 4.861 1.44) (end 4.861 5.877) (layer "F.SilkS") (width 0.12) (tstamp 3231303d-b025-4fd5-81db-e6329c5b29ad))
    (fp_line (start 5.141 1.44) (end 5.141 5.758) (layer "F.SilkS") (width 0.12) (tstamp 334e9501-98ca-40d3-82b3-39cb8230331d))
    (fp_line (start 5.901 -5.347) (end 5.901 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 35e72a48-a8bb-4201-9242-d8e4eb4bcdd6))
    (fp_line (start 4.381 -6.047) (end 4.381 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 3643997a-9e23-4f69-af1b-92baa6e2d1a3))
    (fp_line (start 7.581 -3.804) (end 7.581 3.804) (layer "F.SilkS") (width 0.12) (tstamp 379da22b-5edd-49af-9090-24c7e5daad28))
    (fp_line (start 4.421 -6.034) (end 4.421 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 3835ee51-8123-498c-8122-e3d5aa2f3601))
    (fp_line (start -4.317082 -3.575) (end -3.067082 -3.575) (layer "F.SilkS") (width 0.12) (tstamp 3965e793-e429-4f2d-a870-ffb40e03b296))
    (fp_line (start 4.581 1.44) (end 4.581 5.981) (layer "F.SilkS") (width 0.12) (tstamp 3acb2735-5f1e-42a3-905a-2b5f1102fa1d))
    (fp_line (start 6.301 -5.073) (end 6.301 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 3da771de-a425-4f7e-8fbd-2ebe7e2422b4))
    (fp_line (start 7.541 -3.856) (end 7.541 3.856) (layer "F.SilkS") (width 0.12) (tstamp 3e0e757a-c463-40b3-8047-c7348bcbed10))
    (fp_line (start 2.82 -6.322) (end 2.82 6.322) (layer "F.SilkS") (width 0.12) (tstamp 4001e8ca-fcfd-4357-b15e-874d6c9b4651))
    (fp_line (start 8.861 -0.317) (end 8.861 0.317) (layer "F.SilkS") (width 0.12) (tstamp 448670be-ee97-42a1-8aed-ff5809746898))
    (fp_line (start 6.261 1.44) (end 6.261 5.102) (layer "F.SilkS") (width 0.12) (tstamp 44a603da-328f-436f-bae6-276e19dceefc))
    (fp_line (start 4.381 1.44) (end 4.381 6.047) (layer "F.SilkS") (width 0.12) (tstamp 451535ab-0ebe-4105-8a06-de933abdcf39))
    (fp_line (start 3.261 -6.285) (end 3.261 6.285) (layer "F.SilkS") (width 0.12) (tstamp 45b658de-570a-4486-8687-ceb343424433))
    (fp_line (start 5.181 1.44) (end 5.181 5.739) (layer "F.SilkS") (width 0.12) (tstamp 46c4a8db-52a5-43b7-bd56-4ddb94962d53))
    (fp_line (start 5.781 -5.421) (end 5.781 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 48690dab-4854-42d8-95d7-30461a662b25))
    (fp_line (start 2.5 -6.33) (end 2.5 6.33) (layer "F.SilkS") (width 0.12) (tstamp 4a1bbfdc-dacc-4c28-9405-77a7384fd756))
    (fp_line (start 5.501 1.44) (end 5.501 5.58) (layer "F.SilkS") (width 0.12) (tstamp 4a47c0b6-31cf-4b2d-9f57-0159df4cdb41))
    (fp_line (start 3.02 -6.309) (end 3.02 6.309) (layer "F.SilkS") (width 0.12) (tstamp 4b06eda3-3fc3-4d0a-8f48-e2aaf4954af7))
    (fp_line (start 5.941 1.44) (end 5.941 5.322) (layer "F.SilkS") (width 0.12) (tstamp 4b363703-b202-44bd-a58c-b00f6ef40f05))
    (fp_line (start 4.421 1.44) (end 4.421 6.034) (layer "F.SilkS") (width 0.12) (tstamp 4ce6a077-8397-4ae3-a658-3768889379f7))
    (fp_line (start 5.981 1.44) (end 5.981 5.296) (layer "F.SilkS") (width 0.12) (tstamp 4d14c691-4e81-4d5c-be4b-490904df7ad6))
    (fp_line (start 4.221 -6.094) (end 4.221 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 4efaf6d1-850a-44ea-a6c4-a809193fdc66))
    (fp_line (start 8.501 -2.1) (end 8.501 2.1) (layer "F.SilkS") (width 0.12) (tstamp 4f5b3f0b-390d-4317-94c4-a1fe37d020ca))
    (fp_line (start 7.701 -3.64) (end 7.701 3.64) (layer "F.SilkS") (width 0.12) (tstamp 4f7c61da-3c61-4c3d-bfc5-43155c937be4))
    (fp_line (start 8.261 -2.681) (end 8.261 2.681) (layer "F.SilkS") (width 0.12) (tstamp 4fbba8ee-67f9-497e-b7d1-3dd39c6604a1))
    (fp_line (start 4.221 1.44) (end 4.221 6.094) (layer "F.SilkS") (width 0.12) (tstamp 50c2744a-46ea-4560-a516-a5d9bc8c3dd7))
    (fp_line (start 6.981 -4.489) (end 6.981 4.489) (layer "F.SilkS") (width 0.12) (tstamp 51486b9f-84ad-434c-a22c-0d1fdb81e87e))
    (fp_line (start 4.981 -5.828) (end 4.981 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 553427b2-62f9-4c1e-8a0a-c9995b7e418b))
    (fp_line (start 4.061 1.44) (end 4.061 6.137) (layer "F.SilkS") (width 0.12) (tstamp 55f7bcbe-b103-424d-b5a6-0406e4deae0b))
    (fp_line (start 3.06 -6.306) (end 3.06 6.306) (layer "F.SilkS") (width 0.12) (tstamp 57761edd-cd1e-42ae-9c02-37d33652e58a))
    (fp_line (start 3.981 -6.156) (end 3.981 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 5a77919e-6a16-42ad-8846-57473c0bf802))
    (fp_line (start 7.501 -3.907) (end 7.501 3.907) (layer "F.SilkS") (width 0.12) (tstamp 5b5ef64a-5cf6-48bc-8027-b26edcc330e5))
    (fp_line (start 8.581 -1.861) (end 8.581 1.861) (layer "F.SilkS") (width 0.12) (tstamp 5bbe3f0c-0a8a-4e02-ba9f-5fbbac211517))
    (fp_line (start 4.341 1.44) (end 4.341 6.059) (layer "F.SilkS") (width 0.12) (tstamp 5ce65a61-a281-436b-b210-69b1cedd1f2e))
    (fp_line (start 2.78 -6.324) (end 2.78 6.324) (layer "F.SilkS") (width 0.12) (tstamp 5d039334-5ef4-4362-9dea-005f44f7a76c))
    (fp_line (start 3.781 1.44) (end 3.781 6.201) (layer "F.SilkS") (width 0.12) (tstamp 5d7c593d-e4a1-4718-8698-3c420e62cbbc))
    (fp_line (start 3.341 -6.275) (end 3.341 6.275) (layer "F.SilkS") (width 0.12) (tstamp 5ffbf7a2-0711-4afe-a797-9e0e6f2f5a3b))
    (fp_line (start 3.861 1.44) (end 3.861 6.184) (layer "F.SilkS") (width 0.12) (tstamp 618a65ff-79ed-4f0f-bb5a-282ce1407a71))
    (fp_line (start 5.461 1.44) (end 5.461 5.601) (layer "F.SilkS") (width 0.12) (tstamp 623bb4d1-9657-4c48-a773-7ef5286e30de))
    (fp_line (start 4.901 1.44) (end 4.901 5.861) (layer "F.SilkS") (width 0.12) (tstamp 64301eb5-7cc4-4e53-8cbd-3643741e8732))
    (fp_line (start 5.061 -5.793) (end 5.061 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 66638c3e-68db-4eec-8dd2-38988406a050))
    (fp_line (start 4.901 -5.861) (end 4.901 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 6669901f-22ca-4260-861a-89fa0c70c322))
    (fp_line (start 3.501 -6.252) (end 3.501 6.252) (layer "F.SilkS") (width 0.12) (tstamp 6a341d75-042c-4cbe-b4a1-620fe86e5644))
    (fp_line (start 3.941 -6.166) (end 3.941 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 6ae1ba23-4134-4c66-951b-90420b2d16d7))
    (fp_line (start 3.741 -6.209) (end 3.741 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 6c7a5dd7-a0f6-4133-a91e-cc8f0344b83f))
    (fp_line (start 3.461 -6.258) (end 3.461 6.258) (layer "F.SilkS") (width 0.12) (tstamp 6cf134de-a20f-462a-bceb-4e0c351e9c38))
    (fp_line (start 3.621 -6.231) (end 3.621 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 6df8e58b-942f-4d45-aa20-af27d6b203a3))
    (fp_line (start 7.901 -3.339) (end 7.901 3.339) (layer "F.SilkS") (width 0.12) (tstamp 6f12165c-82ad-4098-b9eb-4279a1e343e6))
    (fp_line (start 4.141 1.44) (end 4.141 6.116) (layer "F.SilkS") (width 0.12) (tstamp 700c867b-42b1-4b9b-91c8-8331b29195b6))
    (fp_line (start 5.821 1.44) (end 5.821 5.397) (layer "F.SilkS") (width 0.12) (tstamp 707034e6-66f5-4bd7-a853-9ee15ae0041f))
    (fp_line (start 6.381 1.44) (end 6.381 5.012) (layer "F.SilkS") (width 0.12) (tstamp 70e820da-63ae-4658-b77b-adf30ae36ff8))
    (fp_line (start 4.621 -5.967) (end 4.621 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 723c9110-acea-46df-8f4b-91f80bd63103))
    (fp_line (start 8.421 -2.312) (end 8.421 2.312) (layer "F.SilkS") (width 0.12) (tstamp 74f84b87-2591-48f4-86e7-512283643128))
    (fp_line (start 2.98 -6.312) (end 2.98 6.312) (layer "F.SilkS") (width 0.12) (tstamp 7559e083-77a8-4295-9f21-585b6f99f5c6))
    (fp_line (start 6.101 -5.216) (end 6.101 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 758ea543-1ac7-413d-84c6-0f1731b226bf))
    (fp_line (start 4.741 -5.924) (end 4.741 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 769b0437-9d16-490c-9c65-0844e8228d04))
    (fp_line (start 4.701 -5.939) (end 4.701 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 7940a909-6d00-45b9-a99d-cd8ec8ffe913))
    (fp_line (start 8.021 -3.14) (end 8.021 3.14) (layer "F.SilkS") (width 0.12) (tstamp 7bac2f23-6a6e-4d07-9541-4ebdc361bb2d))
    (fp_line (start 3.301 -6.28) (end 3.301 6.28) (layer "F.SilkS") (width 0.12) (tstamp 7bda9c39-c966-489b-b7a7-485d4fccc5ea))
    (fp_line (start 3.1 -6.302) (end 3.1 6.302) (layer "F.SilkS") (width 0.12) (tstamp 7c075aef-85ac-4243-afba-cf34e6ee2220))
    (fp_line (start 5.861 1.44) (end 5.861 5.372) (layer "F.SilkS") (width 0.12) (tstamp 7f09a258-5c03-4e61-b8ab-90a003ad11b3))
    (fp_line (start 5.621 1.44) (end 5.621 5.514) (layer "F.SilkS") (width 0.12) (tstamp 7f4f5aae-b0ec-42e4-9bb3-2d72fb6e5dc8))
    (fp_line (start 3.621 1.44) (end 3.621 6.231) (layer "F.SilkS") (width 0.12) (tstamp 7fde077f-653d-477c-9314-09fb17f617e4))
    (fp_line (start 5.141 -5.758) (end 5.141 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 8504abf9-d65c-4273-ae98-eb89592d843d))
    (fp_line (start 8.181 -2.844) (end 8.181 2.844) (layer "F.SilkS") (width 0.12) (tstamp 862b5a81-b75c-46ed-81e8-139db16d34d3))
    (fp_line (start 5.621 -5.514) (end 5.621 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 885dc9b1-07e0-4497-8b1a-b4f6b6cd0340))
    (fp_line (start 6.181 1.44) (end 6.181 5.16) (layer "F.SilkS") (width 0.12) (tstamp 88d120ba-2c70-4f08-ae02-bca3fba30dd3))
    (fp_line (start 5.701 -5.468) (end 5.701 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 89f82e34-49d9-406a-aceb-95fef13c5c64))
    (fp_line (start 5.781 1.44) (end 5.781 5.421) (layer "F.SilkS") (width 0.12) (tstamp 8c75bf96-70a7-4817-81f8-ddb960ef4424))
    (fp_line (start 6.741 -4.714) (end 6.741 4.714) (layer "F.SilkS") (width 0.12) (tstamp 8d3bcfc0-5d52-4e5d-9c3c-b5495f7074c3))
    (fp_line (start 5.581 -5.536) (end 5.581 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 8f17b1a0-4720-4e6a-8ac8-75119b1f1060))
    (fp_line (start 4.301 -6.071) (end 4.301 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 8fdf2921-4f33-4339-aac1-7f06b3df3beb))
    (fp_line (start 5.821 -5.397) (end 5.821 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 9039d455-5d3f-46d9-8f28-88290a83b1bd))
    (fp_line (start 7.741 -3.583) (end 7.741 3.583) (layer "F.SilkS") (width 0.12) (tstamp 90a9575b-69b1-4abd-8118-74a49e102369))
    (fp_line (start 4.501 -6.008) (end 4.501 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 90f45c02-c392-4c1e-9955-57455c4f9792))
    (fp_line (start 3.221 -6.29) (end 3.221 6.29) (layer "F.SilkS") (width 0.12) (tstamp 91052aca-9fa7-4928-903f-5687be586736))
    (fp_line (start 4.701 1.44) (end 4.701 5.939) (layer "F.SilkS") (width 0.12) (tstamp 92818271-9bc9-4f03-b34b-ffad75f32962))
    (fp_line (start 5.261 1.44) (end 5.261 5.702) (layer "F.SilkS") (width 0.12) (tstamp 9288cc78-9483-491a-9357-6f9dc1a97924))
    (fp_line (start 7.421 -4.007) (end 7.421 4.007) (layer "F.SilkS") (width 0.12) (tstamp 92b9e581-1e37-4ac3-b504-4014d845978a))
    (fp_line (start 5.741 -5.445) (end 5.741 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 930b4117-0522-46f1-9722-71c5e536acd2))
    (fp_line (start 2.62 -6.329) (end 2.62 6.329) (layer "F.SilkS") (width 0.12) (tstamp 93370a59-3ff4-4d53-b726-a4e9c247a1e7))
    (fp_line (start 3.581 1.44) (end 3.581 6.238) (layer "F.SilkS") (width 0.12) (tstamp 93fcde20-27d6-4c22-ad5b-2072386cac5f))
    (fp_line (start 5.381 -5.642) (end 5.381 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 94dc1f83-86d6-434c-a936-69af703f3c40))
    (fp_line (start 5.381 1.44) (end 5.381 5.642) (layer "F.SilkS") (width 0.12) (tstamp 961612a9-30df-4b24-bcda-905817d1b0a2))
    (fp_line (start 5.181 -5.739) (end 5.181 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 968613e1-bc6b-44dc-a51b-da447a14fa0a))
    (fp_line (start 7.061 -4.408) (end 7.061 4.408) (layer "F.SilkS") (width 0.12) (tstamp 97258f9a-2afb-4318-9f95-1dc2745a6756))
    (fp_line (start 6.541 -4.885) (end 6.541 4.885) (layer "F.SilkS") (width 0.12) (tstamp 9745c3e0-d5bb-4340-a73d-b737196a01a9))
    (fp_line (start 4.981 1.44) (end 4.981 5.828) (layer "F.SilkS") (width 0.12) (tstamp 982fcef8-5772-4283-8ce1-13e20ae6af0d))
    (fp_line (start 3.821 -6.192) (end 3.821 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 9a254f1f-2ba4-426b-b6b9-cc8bddf1794c))
    (fp_line (start 7.781 -3.524) (end 7.781 3.524) (layer "F.SilkS") (width 0.12) (tstamp 9a39b5d3-726f-4b66-8dd6-9b7a1171b454))
    (fp_line (start 5.901 1.44) (end 5.901 5.347) (layer "F.SilkS") (width 0.12) (tstamp 9acba739-be05-4f88-ba23-46b3e47e7472))
    (fp_line (start 5.661 1.44) (end 5.661 5.491) (layer "F.SilkS") (width 0.12) (tstamp 9b2b9ad7-e0e1-493b-8839-8310c1e23a0a))
    (fp_line (start 4.061 -6.137) (end 4.061 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 9c097b92-c062-4685-9f35-fec1db0bb0e7))
    (fp_line (start 8.821 -0.757) (end 8.821 0.757) (layer "F.SilkS") (width 0.12) (tstamp a0b2fd0f-7bc1-4d8a-b8c2-9ac3757dafbd))
    (fp_line (start 5.941 -5.322) (end 5.941 -1.44) (layer "F.SilkS") (width 0.12) (tstamp a2877298-750e-4ae7-a7d1-d4690f76d316))
    (fp_line (start 2.74 -6.326) (end 2.74 6.326) (layer "F.SilkS") (width 0.12) (tstamp a2bf0812-ef7e-4fdb-a27e-3259d0c0a5bc))
    (fp_line (start 6.701 -4.75) (end 6.701 4.75) (layer "F.SilkS") (width 0.12) (tstamp a5babff6-a674-4350-a42e-49e643060301))
    (fp_line (start 3.18 -6.294) (end 3.18 6.294) (layer "F.SilkS") (width 0.12) (tstamp a6d55100-e66d-4df9-87e8-cab34f3566fb))
    (fp_line (start 6.221 1.44) (end 6.221 5.131) (layer "F.SilkS") (width 0.12) (tstamp a6e9e439-f8ba-4d0a-80ac-c16c9802a30a))
    (fp_line (start 7.621 -3.75) (end 7.621 3.75) (layer "F.SilkS") (width 0.12) (tstamp a7f62f28-0c16-4c85-a038-d3cd30c312da))
    (fp_line (start 8.221 -2.764) (end 8.221 2.764) (layer "F.SilkS") (width 0.12) (tstamp ab693363-02d4-4fe8-9b15-37848af88d3b))
    (fp_line (start 5.661 -5.491) (end 5.661 -1.44) (layer "F.SilkS") (width 0.12) (tstamp ac386963-2998-414e-bacb-5b0fc28a4472))
    (fp_line (start 6.221 -5.131) (end 6.221 -1.44) (layer "F.SilkS") (width 0.12) (tstamp ac5cb6f2-389a-44fd-8628-637ad67b08a2))
    (fp_line (start 5.861 -5.372) (end 5.861 -1.44) (layer "F.SilkS") (width 0.12) (tstamp b39fc76e-069c-449d-8a90-718e391122e0))
    (fp_line (start 5.101 -5.776) (end 5.101 -1.44) (layer "F.SilkS") (width 0.12) (tstamp b3d5fda4-d39f-4521-a170-405108b9e2ff))
    (fp_line (start 3.701 1.44) (end 3.701 6.216) (layer "F.SilkS") (width 0.12) (tstamp b60eb7e6-650e-47cd-9e0a-86d1c50f9c3b))
    (fp_line (start 5.741 1.44) (end 5.741 5.445) (layer "F.SilkS") (width 0.12) (tstamp b689c9b5-d649-4f15-a12a-f6f73987e0d0))
    (fp_line (start 5.341 1.44) (end 5.341 5.662) (layer "F.SilkS") (width 0.12) (tstamp b86941b2-3a62-43b7-8d16-b226ef112204))
    (fp_line (start 5.061 1.44) (end 5.061 5.793) (layer "F.SilkS") (width 0.12) (tstamp b8958b5a-34a3-4b83-86b2-b2c5a045ae7d))
    (fp_line (start 6.621 -4.819) (end 6.621 4.819) (layer "F.SilkS") (width 0.12) (tstamp b8c6a6ca-39db-4496-9980-717f861cdc48))
    (fp_line (start 5.501 -5.58) (end 5.501 -1.44) (layer "F.SilkS") (width 0.12) (tstamp b94fbfc3-95be-4452-a6e9-f4e01af0b6a7))
    (fp_line (start 6.821 -4.642) (end 6.821 4.642) (layer "F.SilkS") (width 0.12) (tstamp ba24c51e-93b2-4f1d-9199-cad49b21287c))
    (fp_line (start 4.261 -6.083) (end 4.261 -1.44) (layer "F.SilkS") (width 0.12) (tstamp bc0d908f-e7b1-461c-b375-67dcbb757f8a))
    (fp_line (start 4.621 1.44) (end 4.621 5.967) (layer "F.SilkS") (width 0.12) (tstamp bc152b9a-1232-493c-aa86-362e7cc23db3))
    (fp_line (start 7.981 -3.208) (end 7.981 3.208) (layer "F.SilkS") (width 0.12) (tstamp bc62f9af-2c54-4a34-8059-660de0579c26))
    (fp_line (start 4.581 -5.981) (end 4.581 -1.44) (layer "F.SilkS") (width 0.12) (tstamp bcee4cd0-ee74-4471-9bcb-1bc7c0fc51d7))
    (fp_line (start 3.901 1.44) (end 3.901 6.175) (layer "F.SilkS") (width 0.12) (tstamp bdade336-9215-489b-b908-2840312cf37e))
    (fp_line (start 4.261 1.44) (end 4.261 6.083) (layer "F.SilkS") (width 0.12) (tstamp bdae986d-938e-4e66-9af8-600e1e27385f))
    (fp_line (start 3.901 -6.175) (end 3.901 -1.44) (layer "F.SilkS") (width 0.12) (tstamp be2a4d8f-3e2c-4a78-ba8e-8ca661e903d2))
    (fp_line (start 5.021 1.44) (end 5.021 5.811) (layer "F.SilkS") (width 0.12) (tstamp bf01315e-826e-4ca6-a7cb-958fd69c90ed))
    (fp_line (start 5.421 -5.622) (end 5.421 -1.44) (layer "F.SilkS") (width 0.12) (tstamp c031d075-926c-448c-8ffe-d8fb99c45ee8))
    (fp_line (start 6.941 -4.528) (end 6.941 4.528) (layer "F.SilkS") (width 0.12) (tstamp c0f317d1-36f7-49f5-86d0-17db9155128a))
    (fp_line (start 4.861 -5.877) (end 4.861 -1.44) (layer "F.SilkS") (width 0.12) (tstamp c3b292c3-c410-4e01-8a79-b23f7229950a))
    (fp_line (start 2.94 -6.315) (end 2.94 6.315) (layer "F.SilkS") (width 0.12) (tstamp c437109f-1f05-40f8-be17-f8c067755d9b))
    (fp_line (start 6.301 1.44) (end 6.301 5.073) (layer "F.SilkS") (width 0.12) (tstamp c4c4d1b4-7428-4b21-ae8e-7eb3c5a8af23))
    (fp_line (start 2.66 -6.328) (end 2.66 6.328) (layer "F.SilkS") (width 0.12) (tstamp c5922fb6-2503-4501-9936-09831e2ac7ab))
    (fp_line (start 5.541 -5.558) (end 5.541 -1.44) (layer "F.SilkS") (width 0.12) (tstamp c68226ce-2857-484f-962d-46d91aa00780))
    (fp_line (start 5.301 1.44) (end 5.301 5.682) (layer "F.SilkS") (width 0.12) (tstamp c71613d0-440f-4132-8ce9-11be729e7d05))
    (fp_line (start 5.981 -5.296) (end 5.981 -1.44) (layer "F.SilkS") (width 0.12) (tstamp c76bc00c-5b45-4739-a811-0f33545d5ef7))
    (fp_line (start 4.181 1.44) (end 4.181 6.105) (layer "F.SilkS") (width 0.12) (tstamp c7c91009-9548-46b8-8933-3e4a1dcf104a))
    (fp_line (start 5.341 -5.662) (end 5.341 -1.44) (layer "F.SilkS") (width 0.12) (tstamp c808230d-bfc7-49f6-8bad-6c6e523b31fb))
    (fp_line (start 8.341 -2.504) (end 8.341 2.504) (layer "F.SilkS") (width 0.12) (tstamp ca078d3f-8d1c-4771-9925-9c89c67c7885))
    (fp_line (start 7.141 -4.325) (end 7.141 4.325) (layer "F.SilkS") (width 0.12) (tstamp caadf0d9-cca0-4771-95c1-6d541a32cf3a))
    (fp_line (start 2.58 -6.33) (end 2.58 6.33) (layer "F.SilkS") (width 0.12) (tstamp cb73abc4-2053-4f23-8f33-c2dde26cff1b))
    (fp_line (start 3.581 -6.238) (end 3.581 -1.44) (layer "F.SilkS") (width 0.12) (tstamp cbc80aaa-bd4c-4824-acdc-1b101541ae14))
    (fp_line (start 3.661 1.44) (end 3.661 6.224) (layer "F.SilkS") (width 0.12) (tstamp cbd587cf-0340-467e-b515-0bf96e4d0a91))
    (fp_line (start 4.101 -6.126) (end 4.101 -1.44) (layer "F.SilkS") (width 0.12) (tstamp cdad600e-28b5-4fe9-a32d-55ecdac241d0))
    (fp_line (start 5.541 1.44) (end 5.541 5.558) (layer "F.SilkS") (width 0.12) (tstamp cdc4b66b-23e4-444f-8925-173c96a60a59))
    (fp_line (start 6.061 -5.243) (end 6.061 -1.44) (layer "F.SilkS") (width 0.12) (tstamp cf2378f8-4f96-46a0-a2a2-2ad02f41ec52))
    (fp_line (start 6.021 -5.27) (end 6.021 -1.44) (layer "F.SilkS") (width 0.12) (tstamp cf7d4f5d-ad89-4364-aae0-967e216c7436))
    (fp_line (start 3.541 -6.245) (end 3.541 6.245) (layer "F.SilkS") (width 0.12) (tstamp d014c9df-525c-41c2-ac3a-11a16182b4fb))
    (fp_line (start 8.741 -1.241) (end 8.741 1.241) (layer "F.SilkS") (width 0.12) (tstamp d0affa49-53e6-4930-ba6d-dd9882f9045c))
    (fp_line (start 3.421 -6.264) (end 3.421 6.264) (layer "F.SilkS") (width 0.12) (tstamp d1765c3d-bbda-4490-bdd7-9268813e356e))
    (fp_line (start 7.861 -3.402) (end 7.861 3.402) (layer "F.SilkS") (width 0.12) (tstamp d3e8bb44-b998-48e4-9cd5-e2e8b9321e68))
    (fp_line (start 6.661 -4.785) (end 6.661 4.785) (layer "F.SilkS") (width 0.12) (tstamp d491299d-6b39-4b26-a83d-cafde41b4e2e))
    (fp_line (start 4.461 1.44) (end 4.461 6.021) (layer "F.SilkS") (width 0.12) (tstamp d576c43f-6020-452e-80f8-e12fa502a58c))
    (fp_line (start 4.941 1.44) (end 4.941 5.845) (layer "F.SilkS") (width 0.12) (tstamp d5e46684-ac01-4898-8803-2169468ef522))
    (fp_line (start 3.821 1.44) (end 3.821 6.192) (layer "F.SilkS") (width 0.12) (tstamp d61ca683-9cfb-4c70-a9f3-86cec7e3f913))
    (fp_line (start 3.14 -6.298) (end 3.14 6.298) (layer "F.SilkS") (width 0.12) (tstamp d85347ab-d84b-4316-91c4-e0072e6ff7e3))
    (fp_line (start 3.861 -6.184) (end 3.861 -1.44) (layer "F.SilkS") (width 0.12) (tstamp d90cb3cf-3b4c-4066-881f-5f9f22fa7fa8))
    (fp_line (start 7.261 -4.194) (end 7.261 4.194) (layer "F.SilkS") (width 0.12) (tstamp d95ed28b-34f9-4be5-9e3a-9a838b8e7695))
    (fp_line (start 7.941 -3.275) (end 7.941 3.275) (layer "F.SilkS") (width 0.12) (tstamp db9d62c8-8d51-4a3c-bd68-90745cc8bcf3))
    (fp_line (start 6.421 1.44) (end 6.421 4.982) (layer "F.SilkS") (width 0.12) (tstamp dd7464d0-d8f0-4969-835a-11a093ff6f3a))
    (fp_line (start 4.101 1.44) (end 4.101 6.126) (layer "F.SilkS") (width 0.12) (tstamp de2e8aed-0f6c-4390-9c3b-d9344612d3f7))
    (fp_line (start 4.141 -6.116) (end 4.141 -1.44) (layer "F.SilkS") (width 0.12) (tstamp df2c3551-bada-4b03-9c8d-ac1720432bb8))
    (fp_line (start 4.341 -6.059) (end 4.341 -1.44) (layer "F.SilkS") (width 0.12) (tstamp df3dcde7-55fd-44cf-ac9f-9da49d731c39))
    (fp_line (start 6.101 1.44) (end 6.101 5.216) (layer "F.SilkS") (width 0.12) (tstamp e0c46f0c-3c5f-4177-9162-fbd46a5b8180))
    (fp_line (start 6.581 -4.852) (end 6.581 4.852) (layer "F.SilkS") (width 0.12) (tstamp e2107461-92b4-48eb-bde0-1e31e4d0f500))
    (fp_line (start 8.661 -1.583) (end 8.661 1.583) (layer "F.SilkS") (width 0.12) (tstamp e2481079-555e-47fc-b4fb-67476ea6f7fb))
    (fp_line (start 4.541 1.44) (end 4.541 5.995) (layer "F.SilkS") (width 0.12) (tstamp e2f10d65-ae6a-43ed-8bb5-9baf4c0e0fef))
    (fp_line (start 7.381 -4.055) (end 7.381 4.055) (layer "F.SilkS") (width 0.12) (tstamp e3c29d52-f8c7-4d63-9a36-616132e67ede))
    (fp_line (start 6.061 1.44) (end 6.061 5.243) (layer "F.SilkS") (width 0.12) (tstamp e50fb362-b712-4e1d-bf9e-c4eba1e6d6f3))
    (fp_line (start 6.861 -4.605) (end 6.861 4.605) (layer "F.SilkS") (width 0.12) (tstamp e64eb786-edc9-4e65-b5ff-8fd9de89fb3e))
    (fp_line (start 7.221 -4.238) (end 7.221 4.238) (layer "F.SilkS") (width 0.12) (tstamp e64feeb6-12e2-4b18-95d9-519829e8b698))
    (fp_line (start 2.9 -6.318) (end 2.9 6.318) (layer "F.SilkS") (width 0.12) (tstamp e708cee6-8af3-4c9a-946e-500b6332287d))
    (fp_line (start 6.901 -4.567) (end 6.901 4.567) (layer "F.SilkS") (width 0.12) (tstamp ea73f3f8-5903-490a-9b7d-c620b84a8da6))
    (fp_line (start 8.621 -1.728) (end 8.621 1.728) (layer "F.SilkS") (width 0.12) (tstamp ea9a2b31-e707-48c8-a0aa-0f65e5347d8e))
    (fp_line (start 6.341 1.44) (end 6.341 5.043) (layer "F.SilkS") (width 0.12) (tstamp ec20298d-f763-4c6a-bc17-81af719ecbf1))
    (fp_line (start 6.261 -5.102) (end 6.261 -1.44) (layer "F.SilkS") (width 0.12) (tstamp ec2b0872-19a8-4ec4-b670-2b46385f8beb))
    (fp_line (start 3.781 -6.201) (end 3.781 -1.44) (layer "F.SilkS") (width 0.12) (tstamp ed6c9d3e-4436-4be3-9bd4-627207aeb0f3))
    (fp_line (start -3.692082 -4.2) (end -3.692082 -2.95) (layer "F.SilkS") (width 0.12) (tstamp ee272b3a-b132-4433-b2c8-71ec3cb5f428))
    (fp_line (start 6.141 -5.188) (end 6.141 -1.44) (layer "F.SilkS") (width 0.12) (tstamp ef40b66b-37f6-4d18-92c4-468f2367ba19))
    (fp_line (start 4.501 1.44) (end 4.501 6.008) (layer "F.SilkS") (width 0.12) (tstamp f12becfa-1080-47c0-93bc-dd1aaa2955cb))
    (fp_line (start 4.821 1.44) (end 4.821 5.893) (layer "F.SilkS") (width 0.12) (tstamp f23d8d21-bdd6-48e4-81a4-875877777692))
    (fp_line (start 2.7 -6.327) (end 2.7 6.327) (layer "F.SilkS") (width 0.12) (tstamp f3174fa9-37dc-41e5-97eb-6648c5c87926))
    (fp_line (start 8.541 -1.984) (end 8.541 1.984) (layer "F.SilkS") (width 0.12) (tstamp f40404c9-91e2-4d26-b3f0-72e4b6ee098a))
    (fp_line (start 4.781 1.44) (end 4.781 5.908) (layer "F.SilkS") (width 0.12) (tstamp f4b0031d-6401-4230-9b60-53a2ca68f607))
    (fp_line (start 7.301 -4.148) (end 7.301 4.148) (layer "F.SilkS") (width 0.12) (tstamp f5fb8a08-90aa-4a0c-8066-c14be000e699))
    (fp_line (start 7.821 -3.464) (end 7.821 3.464) (layer "F.SilkS") (width 0.12) (tstamp f6ad2df3-5237-46d0-8440-b30a9c972995))
    (fp_line (start 3.981 1.44) (end 3.981 6.156) (layer "F.SilkS") (width 0.12) (tstamp f6f9bc2e-84c0-48cb-a16b-77abe97d1c13))
    (fp_line (start 5.581 1.44) (end 5.581 5.536) (layer "F.SilkS") (width 0.12) (tstamp f91d272f-830e-4d19-b711-d70148ef356b))
    (fp_line (start 6.341 -5.043) (end 6.341 -1.44) (layer "F.SilkS") (width 0.12) (tstamp f9d048ee-a1c0-4ad6-a7f3-2fdfc1109dea))
    (fp_line (start 8.381 -2.41) (end 8.381 2.41) (layer "F.SilkS") (width 0.12) (tstamp f9f42ae6-fffd-4b93-83ff-c724842dcfef))
    (fp_line (start 8.701 -1.422) (end 8.701 1.422) (layer "F.SilkS") (width 0.12) (tstamp fb28cde4-8d05-4762-894b-3b1f7460a7f1))
    (fp_line (start 7.341 -4.102) (end 7.341 4.102) (layer "F.SilkS") (width 0.12) (tstamp fc83ca37-1701-460f-aef3-3db8e96c54bc))
    (fp_line (start 5.461 -5.601) (end 5.461 -1.44) (layer "F.SilkS") (width 0.12) (tstamp fff77062-ba33-4cf6-b3ff-0f5f078300e9))
    (fp_circle (center 2.5 0) (end 8.87 0) (layer "F.SilkS") (width 0.12) (fill none) (tstamp 3609bc1d-78d5-455a-b2dd-5cb06b36a02d))
    (fp_circle (center 2.5 0) (end 9 0) (layer "F.CrtYd") (width 0.05) (fill none) (tstamp 317573a4-80eb-4cbd-bc7e-dfc991222862))
    (fp_line (start -2.866489 -2.7375) (end -1.616489 -2.7375) (layer "F.Fab") (width 0.1) (tstamp 6eea9565-916d-4d2e-9419-25026d3a7447))
    (fp_line (start -2.241489 -3.3625) (end -2.241489 -2.1125) (layer "F.Fab") (width 0.1) (tstamp 89f4d63d-3b66-44a9-8b4f-3201ca7a7b65))
    (fp_circle (center 2.5 0) (end 8.75 0) (layer "F.Fab") (width 0.1) (fill none) (tstamp 5634af2e-cbf7-47ee-8f35-2de7ff0d8e98))
    (pad "1" thru_hole rect (at 0 0 90) (size 2.4 2.4) (drill 1.2) (layers *.Cu *.Mask)
      (net 10 "Net-(C14-Pad1)") (pintype "passive") (tstamp 039fd9d1-f6a6-4a67-851a-094949017235))
    (pad "2" thru_hole circle (at 5 0 90) (size 2.4 2.4) (drill 1.2) (layers *.Cu *.Mask)
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp 504e7c04-e7bc-4bc2-a21f-ceb01fcdbb31))
    (model "${KICAD6_3DMODEL_DIR}/Capacitor_THT.3dshapes/CP_Radial_D12.5mm_P5.00mm.wrl"
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp 3829c491-6cf9-49df-adf5-d56d352595c5)
    (at 63.881 96.901 90)
    (property "Sheetfile" "Lauflicht_Steuerplatine.kicad_sch")
    (property "Sheetname" "")
    (path "/df40a580-ab1a-427a-9bf7-af180e557062")
    (attr smd)
    (fp_text reference "R53" (at 0 2.667 90) (layer "F.SilkS")
      (effects (font (size 1 1) (thickness 0.15)))
      (tstamp 7fa116e8-7d8a-49ff-810b-ade0c0eb67b7)
    (fp_text value "SMD 1/4W Variabel" (at 0 2.28 90) (layer "F.Fab")
      (tstamp 74cc3717-14db-4767-a407-67fd5981f25a)
      (tstamp 2fc134c6-e6a1-45bd-bcd9-b2262c3a3193)
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp 12571fd8-7225-4632-af86-d94787adf704))
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 5124af8c-dcc7-4d66-8ee2-da73fa2b9f23))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 0df78afc-3e36-47e1-a1cd-dea7b7c92ccd))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp abd6fa2a-880e-41f4-95f1-57dce32289a5))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp c79551db-01f5-4f63-aa59-5dcd34f42aaa))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp e7d2856a-af51-4889-b038-2934ec8c4153))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 20eb72cf-caae-498b-80f7-a17f51c7d278))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 663e4cc3-928d-4a0c-b5c8-aa7bae31b9a8))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 81c8cd93-5984-4f04-8279-2202af8b916c))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp a4559674-e017-47ec-a72a-3c3d036bdc58))
    (pad "1" smd roundrect (at -1.55 0 90) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 89 "Net-(R53-Pad1)") (pintype "passive") (tstamp 8f05dac9-79bf-483b-9947-e4196cc8621b))
    (pad "2" smd roundrect (at 1.55 0 90) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 85 "Net-(C20-Pad1)") (pintype "passive") (tstamp 90bb5be0-55e7-4fe0-bb65-c2515cafce0a))
      (offset (xyz 0 0 0))
      (scale (xyz 1 1 1))
      (rotate (xyz 0 0 0))
  (footprint "LED_SMD:LED_0805_2012Metric_Pad1.15x1.40mm_HandSolder" (layer "F.Cu")
    (tedit 5F68FEF1) (tstamp 39bb211e-0530-46df-9985-086573ffb1c1)
    (at 83.891 19.556 90)
    (descr "LED SMD 0805 (2012 Metric), square (rectangular) end terminal, IPC_7351 nominal, (Body size source: https://docs.google.com/spreadsheets/d/1BsfQQcO9C6DZCsRaXUlFlo91Tg2WpOkGARC1WS5S8t0/edit?usp=sharing), generated with kicad-footprint-generator")
    (tags "LED handsolder")
    (path "/fd2835c0-1049-4a09-9a1f-de7fb4082628")
    (attr smd)
    (fp_text reference "D6" (at 0.127 -1.905 270) (layer "F.SilkS")
      (tstamp ff3f83ba-220e-4cba-83eb-ee84288204bb)
    (fp_text value "OSO LYR976 Grün" (at 0 1.65 90) (layer "F.Fab")
      (tstamp 16fe584a-e19c-4c63-865c-d3a2f0547abd)
      (effects (font (size 0.5 0.5) (thickness 0.08)))
      (tstamp ddfe48fd-e8ad-407a-9692-592b6279731f)
    (fp_line (start -1.86 0.96) (end 1 0.96) (layer "F.SilkS") (width 0.12) (tstamp 8a0c8d31-c898-4d0f-a8d7-3259b3404760))
    (fp_line (start 1 -0.96) (end -1.86 -0.96) (layer "F.SilkS") (width 0.12) (tstamp b5d9c6c3-70a1-4ed0-8fd2-8b742bd0f96e))
    (fp_line (start -1.86 -0.96) (end -1.86 0.96) (layer "F.SilkS") (width 0.12) (tstamp e4254fd1-ac42-4df9-9c84-6f69aaf25bf5))
    (fp_line (start -1.85 -0.95) (end 1.85 -0.95) (layer "F.CrtYd") (width 0.05) (tstamp 157298f7-b1bc-44e7-863b-be2c81e9b280))
    (fp_line (start 1.85 0.95) (end -1.85 0.95) (layer "F.CrtYd") (width 0.05) (tstamp 49b80f44-6e5b-4123-b94f-ddc4378a6569))
    (fp_line (start -1.85 0.95) (end -1.85 -0.95) (layer "F.CrtYd") (width 0.05) (tstamp 76d6a696-751f-4abd-9f7d-9198229aa458))
    (fp_line (start 1.85 -0.95) (end 1.85 0.95) (layer "F.CrtYd") (width 0.05) (tstamp f867f95e-67bf-47bf-9115-e8d7bd96f2c1))
    (fp_line (start -0.7 -0.6) (end -1 -0.3) (layer "F.Fab") (width 0.1) (tstamp 39d83702-fdd2-4dab-96dc-346087e132d2))
    (fp_line (start -1 -0.3) (end -1 0.6) (layer "F.Fab") (width 0.1) (tstamp 5235ff7f-34e2-497c-b09c-19f452fe2bce))
    (fp_line (start -1 0.6) (end 1 0.6) (layer "F.Fab") (width 0.1) (tstamp f5f069f0-5fe7-4889-9979-c0fb2d4c20f9))
    (fp_line (start 1 0.6) (end 1 -0.6) (layer "F.Fab") (width 0.1) (tstamp fae17504-9b7d-4d99-97ef-ad521b1f9594))
    (fp_line (start 1 -0.6) (end -0.7 -0.6) (layer "F.Fab") (width 0.1) (tstamp fbc9458a-8315-418f-bb40-07315b54000f))
    (pad "1" smd roundrect (at -1.025 0 90) (size 1.15 1.4) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.2173913043)
      (net 20 "Net-(D6-Pad1)") (pinfunction "K") (pintype "passive") (tstamp bc8a924b-3394-4a1b-a1e7-c22f04596168))
    (pad "2" smd roundrect (at 1.025 0 90) (size 1.15 1.4) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.2173913043)
      (net 17 "Net-(D3-Pad2)") (pinfunction "A") (pintype "passive") (tstamp 3ddcc60a-0aa4-4055-b63c-d6b22df6dacc))
    (model "${KICAD6_3DMODEL_DIR}/LED_SMD.3dshapes/LED_0805_2012Metric.wrl"
      (scale (xyz 1 1 1))
  (footprint "Resistor_SMD:R_1210_3225Metric_Pad1.30x2.65mm_HandSolder" (layer "F.Cu")
    (tedit 5F68FEEE) (tstamp 3a64ceff-8602-4a4b-9097-66b0a560af5d)
    (at 29.972 107.95 90)
    (descr "Resistor SMD 1210 (3225 Metric), square (rectangular) end terminal, IPC_7351 nominal with elongated pad for handsoldering. (Body size source: IPC-SM-782 page 72, https://www.pcb-3d.com/wordpress/wp-content/uploads/ipc-sm-782a_amendment_1_and_2.pdf), generated with kicad-footprint-generator")
    (tags "resistor handsolder")
    (path "/e08cea92-7088-4cc1-88dc-f9c3f6c0bd73")
    (attr smd)
    (fp_text reference "R26" (at -4.191 0.508 90) (layer "F.SilkS")
      (tstamp d62cc014-9797-4899-9a56-b11db8d8b16f)
    (fp_text value "SMD 1/4W 1k" (at 0 2.28 90) (layer "F.Fab")
      (tstamp 822564bb-bd22-46ca-a0bb-4b9cf91c2c45)
      (effects (font (size 0.8 0.8) (thickness 0.12)))
      (tstamp d506f66a-5e67-41ad-be1a-0a92767ae013)
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 39bac8b7-d4dc-4f8d-bade-45999f6c00d3))
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp 93d767a7-ce8a-4ad2-b886-173157c1309c))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 19135fae-5f9e-492b-9ba1-e59f60d0b4f6))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 5df59008-b8e9-4a57-b8ea-12706a4d2a9c))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 63f43756-b717-4ef3-afc8-8790ae627623))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 91e0609c-cf77-4f04-b300-4e5b755ca64e))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 5bf2421c-88bc-49fc-ad9f-39d6ff8157ca))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 62e2baa3-66c2-4124-90c4-6ae81aad8835))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 88461439-6bc7-404b-9d1e-08637f48719c))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp eb91ca47-9764-4f6b-9ae3-2020a7559f49))
      (net 55 "Net-(J4-Pad6)") (pintype "passive") (tstamp c63486cb-0b27-4799-a426-dd7b3046b35a))
      (net 56 "Net-(R26-Pad2)") (pintype "passive") (tstamp 8b729b47-eef5-4ac3-871c-9670537e54f3))
    (model "${KICAD6_3DMODEL_DIR}/Resistor_SMD.3dshapes/R_1210_3225Metric.wrl"
      (scale (xyz 1 1 1))
    (tedit 5F68FEEF) (tstamp 3e556767-c71c-435b-8d49-06bab317282e)
    (at 113.8835 64.516 -90)
    (path "/ba71fec3-30e7-4a44-a357-393dc6530934")
    (attr smd)
    (fp_text reference "C3" (at 0 1.9965 90) (layer "F.SilkS")
      (tstamp da4aba0a-bf95-46c4-ac62-0b4f909c43b9)
    (fp_text value "10u 50V KEM X5R1210 10U" (at 0 1.85 90) (layer "F.Fab")
      (tstamp f35d2880-2934-418c-b886-9b3f515bda55)
      (tstamp aee2f968-dd91-4d32-8949-c572b925276b)
    (fp_line (start -0.711252 0.91) (end 0.711252 0.91) (layer "F.SilkS") (width 0.12) (tstamp 13d99ae9-c40d-49af-8dd9-234ffa570752))
    (fp_line (start -0.711252 -0.91) (end 0.711252 -0.91) (layer "F.SilkS") (width 0.12) (tstamp 837fae4e-71f1-4bd2-80f2-ff4f775f6789))
    (fp_line (start -2.48 1.15) (end -2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp 0216ea0a-a7fe-43e7-87a2-fb6f135f33e1))
    (fp_line (start 2.48 1.15) (end -2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp 20e31f50-a5cd-44a6-b29a-fc916c7ca4ef))
    (fp_line (start 2.48 -1.15) (end 2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp c3b52cdb-daf9-42bf-bcbf-f6c95c611be9))
    (fp_line (start -2.48 -1.15) (end 2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp f6742f5f-1d7b-42d2-9560-0bfcd36076cb))
    (fp_line (start -1.6 0.8) (end -1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp 2dd118ab-f506-428f-8e74-0be65100d2e2))
    (fp_line (start 1.6 0.8) (end -1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp 8778347c-b1a5-4f4d-b638-5f57bb1be3fd))
    (fp_line (start 1.6 -0.8) (end 1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp ca7bd9c6-cade-4337-8351-8565852a416d))
    (fp_line (start -1.6 -0.8) (end 1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp d9d372e6-f87d-456c-befd-cfc2b035de97))
    (pad "1" smd roundrect (at -1.5625 0 270) (size 1.325 1.8) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1886792453)
      (net 15 "Net-(C3-Pad1)") (pintype "passive") (tstamp 44c4c9f4-1ea6-4ea7-828f-7f558f8253e4))
    (pad "2" smd roundrect (at 1.5625 0 270) (size 1.325 1.8) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1886792453)
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp 51c3f9ab-b720-41a0-8c8f-b9f4627592f0))
      (scale (xyz 1 1 1))
  (footprint "Connector_PinHeader_2.54mm:PinHeader_2x03_P2.54mm_Vertical" (layer "F.Cu")
    (tedit 59FED5CC) (tstamp 3fb43a09-31a3-4ffe-bf6e-cfadaa06d44f)
    (at 54.488 33.005 180)
    (descr "Through hole straight pin header, 2x03, 2.54mm pitch, double rows")
    (tags "Through hole pin header THT 2x03 2.54mm double row")
    (path "/92a8e7ac-5c59-4bc5-bdd7-0cee08ec6176")
    (attr through_hole)
    (fp_text reference "J4" (at 5.085 2.779 90) (layer "F.SilkS")
      (tstamp ce3e6605-2559-447b-97a4-d50f87093594)
    (fp_text value "Humper Programmieren" (at 5.085 2.525 90) (layer "F.Fab")
      (tstamp 382361e2-c98e-438b-b4d8-5af3b93b1ce4)
    (fp_text user "${REFERENCE}" (at 1.27 1.89 90) (layer "F.Fab")
      (tstamp cb40d231-0918-4f74-961d-886c57d26a45)
    (fp_line (start 1.27 -1.33) (end 3.87 -1.33) (layer "F.SilkS") (width 0.12) (tstamp 12980e40-b929-4b93-b5d3-f73cfa80aa70))
    (fp_line (start 1.27 1.27) (end 1.27 -1.33) (layer "F.SilkS") (width 0.12) (tstamp 32b8b99b-ea4a-4a86-8fa3-662664d375b2))
    (fp_line (start -1.33 -1.33) (end 0 -1.33) (layer "F.SilkS") (width 0.12) (tstamp 4f2db7ae-6e7f-4dbf-9703-3d03affda6bf))
    (fp_line (start 3.87 -1.33) (end 3.87 6.41) (layer "F.SilkS") (width 0.12) (tstamp 7fd42bb4-e9ca-43df-8c91-b62c2e465f66))
    (fp_line (start -1.33 1.27) (end 1.27 1.27) (layer "F.SilkS") (width 0.12) (tstamp 8c927692-d207-4ef9-b4aa-7fcc757a8846))
    (fp_line (start -1.33 0) (end -1.33 -1.33) (layer "F.SilkS") (width 0.12) (tstamp bc853f94-deaa-4ed1-aa20-5b3a39c71077))
    (fp_line (start -1.33 6.41) (end 3.87 6.41) (layer "F.SilkS") (width 0.12) (tstamp d321880c-f17a-4dcf-ad90-1e112758492d))
    (fp_line (start -1.33 1.27) (end -1.33 6.41) (layer "F.SilkS") (width 0.12) (tstamp da5b49c8-a878-43f7-8595-43f43ffd2b4a))
    (fp_line (start 4.35 6.85) (end 4.35 -1.8) (layer "F.CrtYd") (width 0.05) (tstamp 3ea04ed5-ab17-4aa0-bbe3-b99f88957ebc))
    (fp_line (start -1.8 6.85) (end 4.35 6.85) (layer "F.CrtYd") (width 0.05) (tstamp 46e3ea9a-d146-4613-84b3-8c5ef2d830a4))
    (fp_line (start 4.35 -1.8) (end -1.8 -1.8) (layer "F.CrtYd") (width 0.05) (tstamp 9d00de4e-d42e-4468-9195-7eab6b2994e0))
    (fp_line (start -1.8 -1.8) (end -1.8 6.85) (layer "F.CrtYd") (width 0.05) (tstamp fc879278-f9f6-4806-acae-faa700460399))
    (fp_line (start 3.81 6.35) (end -1.27 6.35) (layer "F.Fab") (width 0.1) (tstamp 2b84dd4f-92ec-426d-9a28-94cbbee6fd28))
    (fp_line (start 0 -1.27) (end 3.81 -1.27) (layer "F.Fab") (width 0.1) (tstamp 4579c9ba-793f-4f70-bd9d-d3530538b2f2))
    (fp_line (start 3.81 -1.27) (end 3.81 6.35) (layer "F.Fab") (width 0.1) (tstamp 6f922068-331a-444e-95c6-0b2dd8095f19))
    (fp_line (start -1.27 6.35) (end -1.27 0) (layer "F.Fab") (width 0.1) (tstamp 7a68359e-bbbf-4598-bf50-6ad34559548c))
    (fp_line (start -1.27 0) (end 0 -1.27) (layer "F.Fab") (width 0.1) (tstamp f4b3919a-9726-4621-9d9a-2b2be67c35c5))
    (pad "1" thru_hole rect (at 0 0 180) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 26 "Net-(J3-Pad3)") (pinfunction "Pin_1") (pintype "passive") (tstamp 919960f4-5912-4691-8b00-992634173b38))
    (pad "2" thru_hole oval (at 2.54 0 180) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 45 "Net-(J4-Pad2)") (pinfunction "Pin_2") (pintype "passive") (tstamp 372c1dd6-b5e1-4784-9293-42839e626d60))
    (pad "3" thru_hole oval (at 0 2.54 180) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 25 "Net-(J3-Pad1)") (pinfunction "Pin_3") (pintype "passive") (tstamp a543ce7a-a5a0-425f-aa93-86c51128988c))
    (pad "4" thru_hole oval (at 2.54 2.54 180) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 47 "Net-(J4-Pad4)") (pinfunction "Pin_4") (pintype "passive") (tstamp 6f3a779d-8a72-4b1a-a03e-e1fb03092c46))
    (pad "5" thru_hole oval (at 0 5.08 180) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 27 "Net-(J3-Pad4)") (pinfunction "Pin_5") (pintype "passive") (tstamp 1af5c326-b5ff-4bd4-82b1-83272b8cceab))
    (pad "6" thru_hole oval (at 2.54 5.08 180) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 55 "Net-(J4-Pad6)") (pinfunction "Pin_6") (pintype "passive") (tstamp 0043fc95-da77-4a8d-a3f3-0caa6edae832))
    (model "${KICAD6_3DMODEL_DIR}/Connector_PinHeader_2.54mm.3dshapes/PinHeader_2x03_P2.54mm_Vertical.wrl"
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp 42cef56a-bbc2-47d9-997e-ed0478442d9c)
    (at 88.773 25.146 -90)
    (path "/ffd6d6cd-f78b-4b25-88ef-7d1167006af7")
    (attr smd)
    (fp_text reference "R15" (at 0 2.413 -90) (layer "F.SilkS")
      (tstamp 8870594e-9e02-4129-a486-320169f1e09e)
    (fp_text value "SMD 1/4W 10k" (at 0 2.28 90) (layer "F.Fab")
      (tstamp e8998aae-742f-44ae-a26b-55dd61e701df)
      (tstamp 93d3e245-fc4e-4981-b6b7-aa652151b65b)
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp 70360129-140c-4a20-9322-db14e08a7acd))
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 7607c925-f2c3-475a-9414-f1d54efb8457))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 12e154a3-5798-4b00-9778-9024cd738328))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 2dc14fe3-7e31-4e21-af85-77600cb1c390))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 461d1d71-8d83-41c3-8fd2-b782dcf37742))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 554cbadc-8d08-4b18-b4f7-c5ba002e3d54))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 0ec478ca-e8bc-4a36-8c7b-815f9ac2a238))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 307e8fdc-d2b0-4454-ba48-f29725abe3a3))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp a34ac279-25d9-4333-89e2-a563c0ca028e))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp fec066f7-b8af-4057-8f78-98110889af5d))
    (pad "1" smd roundrect (at -1.55 0 270) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 96 "Net-(D12-Pad1)") (pintype "passive") (tstamp 0a3f5bfe-7a01-4bab-af3e-a7a15ce39ae2))
    (pad "2" smd roundrect (at 1.55 0 270) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 88 "Net-(D11-Pad2)") (pintype "passive") (tstamp 6b369bf7-d2ca-43de-aaa8-cb0eebf79829))
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp 45517da2-01e1-4e1b-9ea0-33762d95adb8)
    (at 49.149 42.672 90)
    (path "/e47505db-4ceb-4974-b4a3-7183e1e1005a")
    (attr smd)
    (fp_text reference "R20" (at 0 2.54 90) (layer "F.SilkS")
      (tstamp c9837887-e17c-4fed-b307-06533e0f018f)
      (tstamp 048dc7cc-f74c-475e-9d29-2b78141fd6b6)
      (tstamp 17b487d0-057c-441b-ae07-88168ea9b227)
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 70d2d3ff-8dbe-4941-8f54-5d4b8e8c4f62))
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp c0d490f7-9e74-4907-857a-c5b7246f6d4b))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 12d730a7-7c37-45d8-b3a4-99ddf96dce77))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 18c7df57-3dd0-443e-a472-5fe603395f25))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 63c6e2a3-dd7d-43a2-8a35-181b391b80ab))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp b79ae017-494a-4d0f-a060-92d5ca14d5a6))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 033644ef-b284-4ec5-8b1a-ae1465936d72))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 6f9eaa72-b40a-4ec5-ac20-ac56ef4f523a))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 95cbf1fa-0d35-46d5-8aa6-43ed924be444))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 9ce46fa6-acb7-4156-a997-7ec24cfd7694))
      (net 50 "Net-(R20-Pad1)") (pintype "passive") (tstamp 122fabfc-ee11-4ed8-909d-b13ec6070e45))
      (net 43 "Net-(Q4-Pad2)") (pintype "passive") (tstamp 3691ae7a-b991-4d75-af4c-511a83e1c574))
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp 45d30231-5c61-4d3e-ad7c-90bac4042615)
    (at 66.675 53.112 90)
    (path "/1b7bd6c0-e012-4d09-a68e-5edc08d48889")
    (attr smd)
    (fp_text reference "R7" (at -1.498 -2.54 90) (layer "F.SilkS")
      (tstamp 0d5a535b-4e07-4610-ad9d-5b1d7773d1f7)
    (fp_text value "SMD 1/4W 2k2" (at 0 2.28 90) (layer "F.Fab")
      (tstamp 97b9a7f9-73ae-4e10-8636-995d26dfb506)
      (tstamp d6f04acd-1b2a-491b-90e0-e8fcccb75cb6)
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 5c64305b-864a-4ed9-9a72-e1a89c071861))
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp 9939df8e-8270-4a68-ace5-a8cb1501d1da))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 17eb5eeb-6c30-4948-9dbc-d7656f4ff3a9))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 49212ae9-0545-450e-955b-1230f357b6f6))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 58d26bab-87dd-499e-a4c3-2762430c84de))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 9941d833-16e8-45a6-a60b-240c66dce697))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 82113720-2e5f-47c5-809b-f81ed17fc04c))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp b771e461-d3d5-4262-a8ab-ced3c381f7de))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp d8ad35fd-426e-4a03-9dce-de3d5e9b44c7))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp ddcc9a9a-5928-48ce-9545-5c5665ec7167))
      (net 40 "Net-(Q1-Pad2)") (pintype "passive") (tstamp c41f000f-426c-450d-9871-31c98963101f))
      (net 45 "Net-(J4-Pad2)") (pintype "passive") (tstamp 826310c5-b48c-48ba-9896-e5f2060b8237))
      (scale (xyz 1 1 1))
  (footprint "TerminalBlock_RND:TerminalBlock_RND_205-00001_1x02_P5.00mm_Horizontal" (layer "F.Cu")
    (tedit 5B294F8C) (tstamp 4616adde-e894-42e5-a838-063cc949f081)
    (at 165.981 106.386 90)
    (descr "terminal block RND 205-00001, 2 pins, pitch 5mm, size 10x9mm^2, drill diamater 1.3mm, pad diameter 2.5mm, see http://cdn-reichelt.de/documents/datenblatt/C151/RND_205-00001_DB_EN.pdf, script-generated using https://github.com/pointhi/kicad-footprint-generator/scripts/TerminalBlock_RND")
    (tags "THT terminal block RND 205-00001 pitch 5mm size 10x9mm^2 drill 1.3mm pad 2.5mm")
    (path "/1487257e-b748-4e9c-933c-5e20b87b3b8c")
    (attr through_hole)
    (fp_text reference "J7" (at 2.5 -6.06 90) (layer "F.SilkS")
      (tstamp 88e7fe1b-4c27-44b9-92d4-cc377f106da2)
    (fp_text value "DC 21V Out" (at 2.5 5.06 90) (layer "F.Fab")
      (tstamp 9ab7ed28-b349-4f1c-8631-cfa7cd952140)
    (fp_text user "${REFERENCE}" (at 2.5 -6.06 90) (layer "F.Fab")
      (tstamp d7b3b6cb-1719-4035-a03e-c72381fef1b2)
    (fp_line (start -2.8 2.56) (end -2.8 4.3) (layer "F.SilkS") (width 0.12) (tstamp 0886b937-3a70-4131-944a-5511f759da23))
    (fp_line (start 6.07 -1.275) (end 6.011 -1.216) (layer "F.SilkS") (width 0.12) (tstamp 0e2d53be-3392-4fc3-9405-429cf78cf82a))
    (fp_line (start -2.56 -5.06) (end 7.56 -5.06) (layer "F.SilkS") (width 0.12) (tstamp 15485262-230b-424c-827d-01c91f09fbe8))
    (fp_line (start -2.56 -5.06) (end -2.56 4.06) (layer "F.SilkS") (width 0.12) (tstamp 16d83d0a-fa1e-4038-b35e-a0fe30348449))
    (fp_line (start 3.82 0.976) (end 3.726 1.069) (layer "F.SilkS") (width 0.12) (tstamp 1760fc4e-2695-48d4-9074-f9ea0f2348b9))
    (fp_line (start 3.99 1.216) (end 3.931 1.274) (layer "F.SilkS") (width 0.12) (tstamp 1822c0f6-b5eb-4a63-9d5f-5485806e2220))
    (fp_line (start -2.56 2.5) (end 7.56 2.5) (layer "F.SilkS") (width 0.12) (tstamp 6be01c2c-3c63-453b-9949-4daea248ecc3))
    (fp_line (start -2.56 4.06) (end 7.56 4.06) (layer "F.SilkS") (width 0.12) (tstamp 726758fe-e0ce-4733-a95b-f8978c8f5c12))
    (fp_line (start -2.8 4.3) (end -1.3 4.3) (layer "F.SilkS") (width 0.12) (tstamp 83a536ce-77f0-4ff6-a8d9-8cae74062fbd))
    (fp_line (start 7.56 -5.06) (end 7.56 4.06) (layer "F.SilkS") (width 0.12) (tstamp 8b78feae-8af8-4488-b77e-4501f1a00c3d))
    (fp_line (start 6.275 -1.069) (end 6.181 -0.976) (layer "F.SilkS") (width 0.12) (tstamp e5723c02-f052-469a-91fa-51746ad7a272))
    (fp_arc (start 0.029383 1.68045) (mid -0.392304 1.634281) (end -0.789 1.484) (layer "F.SilkS") (width 0.12) (tstamp 07b920f6-b3a2-4f70-a0da-24e75a704cc5))
    (fp_arc (start 0.788712 1.483352) (mid 0.406429 1.630097) (end 0 1.68) (layer "F.SilkS") (width 0.12) (tstamp 270a6688-90c7-48f4-b707-c8d8f260bd82))
    (fp_arc (start -0.789089 -1.483953) (mid -0.00005 -1.680708) (end 0.789 -1.484) (layer "F.SilkS") (width 0.12) (tstamp 80e97927-1017-4bb5-a3a1-ce8d9bb33971))
    (fp_arc (start -1.483953 0.789089) (mid -1.680708 0.00005) (end -1.484 -0.789) (layer "F.SilkS") (width 0.12) (tstamp bd4d99b3-7f7a-4b2e-b88b-16010a4fa538))
    (fp_arc (start 1.483953 -0.789089) (mid 1.680708 -0.00005) (end 1.484 0.789) (layer "F.SilkS") (width 0.12) (tstamp c5141072-aaa2-490f-9541-eb39cdc93f72))
    (fp_circle (center 5 -3) (end 5.9 -3) (layer "F.SilkS") (width 0.12) (fill none) (tstamp 047142c8-82eb-4a68-bcc6-7c407ddcc30d))
    (fp_circle (center 5 0) (end 6.68 0) (layer "F.SilkS") (width 0.12) (fill none) (tstamp 1305476f-fe44-4a89-87a8-b3e1c0884c43))
    (fp_circle (center 0 -3) (end 0.9 -3) (layer "F.SilkS") (width 0.12) (fill none) (tstamp b9cd028f-53a6-4f87-9c61-e7422e28ce5d))
    (fp_line (start 8 4.5) (end 8 -5.5) (layer "F.CrtYd") (width 0.05) (tstamp 77295717-7f3f-4cdd-a28b-69cf4d91bb2e))
    (fp_line (start -3 -5.5) (end -3 4.5) (layer "F.CrtYd") (width 0.05) (tstamp 8263ef4c-20d5-48c7-abf3-5d9998fabf6d))
    (fp_line (start 8 -5.5) (end -3 -5.5) (layer "F.CrtYd") (width 0.05) (tstamp c3758fdc-a580-4fb8-a0de-5db2bb9ea67d))
    (fp_line (start -3 4.5) (end 8 4.5) (layer "F.CrtYd") (width 0.05) (tstamp f1737770-e35d-4d05-a0a6-09b20199acc4))
    (fp_line (start 7.5 4) (end -1 4) (layer "F.Fab") (width 0.1) (tstamp 02a61454-1132-4050-a49f-8b0e15b85082))
    (fp_line (start 5.955 -1.138) (end 3.863 0.955) (layer "F.Fab") (width 0.1) (tstamp 250924b7-d90f-4690-8a3b-813803437e32))
    (fp_line (start 6.138 -0.955) (end 4.046 1.138) (layer "F.Fab") (width 0.1) (tstamp 4319c8bb-14c1-4102-a60c-c19d063a33c1))
    (fp_line (start -2.5 2.5) (end -2.5 -5) (layer "F.Fab") (width 0.1) (tstamp 5b65da46-1b66-4a02-8e49-820b10f1410f))
    (fp_line (start -2.5 2.5) (end 7.5 2.5) (layer "F.Fab") (width 0.1) (tstamp 5ec8d00f-d7e6-4f65-bc31-03bbe0b891f4))
    (fp_line (start -1 4) (end -2.5 2.5) (layer "F.Fab") (width 0.1) (tstamp 7a4dfcb4-82f4-4307-92f2-dc7605f8c670))
    (fp_line (start 0.955 -1.138) (end -1.138 0.955) (layer "F.Fab") (width 0.1) (tstamp ab19a66d-0603-4dfe-a03e-abe729ffc0c9))
    (fp_line (start 1.138 -0.955) (end -0.955 1.138) (layer "F.Fab") (width 0.1) (tstamp c1c129ea-c2fc-4054-bd38-8fa39f3898e6))
    (fp_line (start 7.5 -5) (end 7.5 4) (layer "F.Fab") (width 0.1) (tstamp d982f44a-a7de-4c98-b16a-8c01ba16ba26))
    (fp_line (start -2.5 -5) (end 7.5 -5) (layer "F.Fab") (width 0.1) (tstamp f18ef167-63a7-4934-acb9-67108ca3d01f))
    (fp_circle (center 0 -3) (end 0.9 -3) (layer "F.Fab") (width 0.1) (fill none) (tstamp 1211f312-c875-4dda-9d33-1d9fced2da9f))
    (fp_circle (center 0 0) (end 1.5 0) (layer "F.Fab") (width 0.1) (fill none) (tstamp 9d8b5ec8-0a73-486d-b83c-cfd7b420e66b))
    (fp_circle (center 5 -3) (end 5.9 -3) (layer "F.Fab") (width 0.1) (fill none) (tstamp c818cabf-8d08-4b86-8d4f-39cb105fbf5d))
    (fp_circle (center 5 0) (end 6.5 0) (layer "F.Fab") (width 0.1) (fill none) (tstamp d69352a0-60bd-4b9e-9911-c99aef2c38c3))
    (pad "1" thru_hole rect (at 0 0 90) (size 2.5 2.5) (drill 1.3) (layers *.Cu *.Mask)
      (net 10 "Net-(C14-Pad1)") (pinfunction "Pin_1") (pintype "passive") (tstamp 203bb37e-b023-44eb-a679-cfbb6ad40e8b))
    (pad "2" thru_hole circle (at 5 0 90) (size 2.5 2.5) (drill 1.3) (layers *.Cu *.Mask)
      (net 1 "Net-(BT1-Pad2)") (pinfunction "Pin_2") (pintype "passive") (tstamp d7fb3527-2b10-4c70-b4af-018affcea9c9))
    (model "${KICAD6_3DMODEL_DIR}/TerminalBlock_RND.3dshapes/TerminalBlock_RND_205-00001_1x02_P5.00mm_Horizontal.wrl"
      (scale (xyz 1 1 1))
  (footprint "Capacitor_SMD:C_1206_3216Metric_Pad1.33x1.80mm_HandSolder" (layer "F.Cu")
    (tedit 5F68FEEF) (tstamp 49f8a469-297d-43e9-8c18-cf9a393dfa1a)
    (at 86.741 54.991 90)
    (descr "Capacitor SMD 1206 (3216 Metric), square (rectangular) end terminal, IPC_7351 nominal with elongated pad for handsoldering. (Body size source: IPC-SM-782 page 76, https://www.pcb-3d.com/wordpress/wp-content/uploads/ipc-sm-782a_amendment_1_and_2.pdf), generated with kicad-footprint-generator")
    (tags "capacitor handsolder")
    (path "/ea798af9-b2ae-4321-80c3-62fdaddd177e")
    (attr smd)
    (fp_text reference "C11" (at 0.127 -2.032 270) (layer "F.SilkS")
      (tstamp 65e6ad1a-5465-4a39-99c2-d0f652c8b6cc)
    (fp_text value "330n 50V" (at 0 1.85 90) (layer "F.Fab")
      (tstamp 64173719-6a08-4c10-a723-f98f2397fe4f)
    (fp_text user "${REFERENCE}" (at 0 0 90) (layer "F.Fab")
      (tstamp 7e89728b-985f-44c1-b2f4-71422e1da510)
    (fp_line (start -0.711252 -0.91) (end 0.711252 -0.91) (layer "F.SilkS") (width 0.12) (tstamp 7fd89c18-26dc-420b-a4d7-5078154d70bf))
    (fp_line (start -0.711252 0.91) (end 0.711252 0.91) (layer "F.SilkS") (width 0.12) (tstamp c8bb3a14-f481-4602-91ce-9b38595c51b6))
    (fp_line (start -2.48 -1.15) (end 2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp 8324b8f2-85ce-446d-a767-212c1425d929))
    (fp_line (start 2.48 1.15) (end -2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp 9318a753-9294-44a4-a955-6a09b5b8b30d))
    (fp_line (start -2.48 1.15) (end -2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp 959e6c7d-e576-4f98-94e8-e7eb00251af2))
    (fp_line (start 2.48 -1.15) (end 2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp de4cd8e7-8b10-4e12-8649-028ed198b8ce))
    (fp_line (start -1.6 0.8) (end -1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp 74ac6769-279e-4311-bda6-5346b2113bd3))
    (fp_line (start 1.6 -0.8) (end 1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp c387f1f5-3dfd-481a-8a68-e3f5e6b799f6))
    (fp_line (start -1.6 -0.8) (end 1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp e6d78dfe-7589-4ae7-82c9-a636497d83d7))
    (fp_line (start 1.6 0.8) (end -1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp fbc5331a-0007-45a8-8c07-0728481833f8))
    (pad "1" smd roundrect (at -1.5625 0 90) (size 1.325 1.8) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1886792453)
      (net 44 "Net-(C11-Pad1)") (pintype "passive") (tstamp 8d944359-b9ec-4952-81ae-823221ddd6ab))
    (pad "2" smd roundrect (at 1.5625 0 90) (size 1.325 1.8) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1886792453)
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp 642e425f-da4d-493f-8f5b-faeacf739079))
    (model "${KICAD6_3DMODEL_DIR}/Capacitor_SMD.3dshapes/C_1206_3216Metric.wrl"
      (scale (xyz 1 1 1))
  (footprint "Resistor_THT:R_Axial_DIN0309_L9.0mm_D3.2mm_P12.70mm_Horizontal" (layer "F.Cu")
    (tedit 5AE5139B) (tstamp 4be1f6f2-1171-483d-a62d-19cee7187387)
    (at 73.787 72.136 90)
    (descr "Resistor, Axial_DIN0309 series, Axial, Horizontal, pin pitch=12.7mm, 0.5W = 1/2W, length*diameter=9*3.2mm^2, http://cdn-reichelt.de/documents/datenblatt/B400/1_4W%23YAG.pdf")
    (tags "Resistor Axial_DIN0309 series Axial Horizontal pin pitch 12.7mm 0.5W = 1/2W length 9mm diameter 3.2mm")
    (path "/4ef6527b-4eb9-4650-9ae0-9109f2377f5e")
    (attr through_hole)
    (fp_text reference "F1" (at 3.81 -2.667 90) (layer "F.SilkS")
      (tstamp a906b122-c900-4a97-8838-a16082d3296e)
    (fp_text value "Fuse" (at 6.35 2.72 90) (layer "F.Fab")
      (tstamp cec5dc60-333b-48e2-8913-7442ca86666b)
    (fp_text user "${REFERENCE}" (at 6.35 0 90) (layer "F.Fab")
      (tstamp e7e3e263-130f-414b-aaa3-822ec86c42dc)
    (fp_line (start 1.73 -1.72) (end 1.73 1.72) (layer "F.SilkS") (width 0.12) (tstamp 48ba332d-280b-4ea6-b011-2e7d310f3a8c))
    (fp_line (start 1.73 1.72) (end 10.97 1.72) (layer "F.SilkS") (width 0.12) (tstamp 50af8d3f-4df1-438a-a4a6-381a3ea50b5b))
    (fp_line (start 1.04 0) (end 1.73 0) (layer "F.SilkS") (width 0.12) (tstamp 60d4f7da-4866-498b-9050-43314194da45))
    (fp_line (start 10.97 -1.72) (end 1.73 -1.72) (layer "F.SilkS") (width 0.12) (tstamp 66cfa838-213b-47d7-8a5d-2df2f302722e))
    (fp_line (start 10.97 1.72) (end 10.97 -1.72) (layer "F.SilkS") (width 0.12) (tstamp af3adfa7-76d4-4f45-8711-dec2ff0d50b0))
    (fp_line (start 11.66 0) (end 10.97 0) (layer "F.SilkS") (width 0.12) (tstamp efd4aad8-3d31-4b42-bb83-d9bef7bed597))
    (fp_line (start 13.75 -1.85) (end -1.05 -1.85) (layer "F.CrtYd") (width 0.05) (tstamp 2f5d8f41-b97f-4afc-ba81-f0e07b7cbf3b))
    (fp_line (start 13.75 1.85) (end 13.75 -1.85) (layer "F.CrtYd") (width 0.05) (tstamp 88bef4ac-3194-42f7-84e6-461a78c20525))
    (fp_line (start -1.05 -1.85) (end -1.05 1.85) (layer "F.CrtYd") (width 0.05) (tstamp da12e768-9b87-45a2-8550-bbcc9dbd8430))
    (fp_line (start -1.05 1.85) (end 13.75 1.85) (layer "F.CrtYd") (width 0.05) (tstamp e8001ece-6d5d-472d-8893-06e3f845f3f0))
    (fp_line (start 1.85 -1.6) (end 1.85 1.6) (layer "F.Fab") (width 0.1) (tstamp 50bfe512-9b4d-4e6d-9881-fc96d2cb278b))
    (fp_line (start 0 0) (end 1.85 0) (layer "F.Fab") (width 0.1) (tstamp 5744c310-fe17-412a-841f-1c61f48c84f6))
    (fp_line (start 12.7 0) (end 10.85 0) (layer "F.Fab") (width 0.1) (tstamp a27965e7-3205-4ba9-907b-8b34d4660615))
    (fp_line (start 1.85 1.6) (end 10.85 1.6) (layer "F.Fab") (width 0.1) (tstamp c3737760-fddd-48dd-bbc9-3834815b7257))
    (fp_line (start 10.85 1.6) (end 10.85 -1.6) (layer "F.Fab") (width 0.1) (tstamp ed0d983c-ac0c-470f-af72-c1d2e5e65635))
    (fp_line (start 10.85 -1.6) (end 1.85 -1.6) (layer "F.Fab") (width 0.1) (tstamp f241e66c-e3d1-4d1f-8ba3-d15be341240f))
    (pad "1" thru_hole circle (at 0 0 90) (size 1.6 1.6) (drill 0.8) (layers *.Cu *.Mask)
      (net 17 "Net-(D3-Pad2)") (pintype "passive") (tstamp e8129d3d-c235-4419-a6b5-380de728cd98))
    (pad "2" thru_hole oval (at 12.7 0 90) (size 1.6 1.6) (drill 0.8) (layers *.Cu *.Mask)
      (net 15 "Net-(C3-Pad1)") (pintype "passive") (tstamp 32577131-4022-49de-90af-3040bef16239))
    (model "${KICAD6_3DMODEL_DIR}/Resistor_THT.3dshapes/R_Axial_DIN0309_L9.0mm_D3.2mm_P12.70mm_Horizontal.wrl"
      (scale (xyz 1 1 1))
  (footprint "Connector:FanPinHeader_1x03_P2.54mm_Vertical" (layer "F.Cu")
    (tedit 5A19DCDF) (tstamp 4ced240c-5764-4c6b-b303-eb829bb5b489)
    (at 37.891 19.691)
    (descr "3-pin CPU fan Through hole pin header, see http://www.formfactors.org/developer%5Cspecs%5Crev1_2_public.pdf")
    (tags "pin header 3-pin CPU fan")
    (path "/d498e373-4db4-4219-ac1b-e64e45f597a5")
    (attr through_hole)
    (fp_text reference "J5" (at -2.712 -1.911 90) (layer "F.SilkS")
      (tstamp 8c7cebf5-7369-47c3-8ede-85fc45175269)
    (fp_text value "Fan" (at 2.55 4.5) (layer "F.Fab")
      (tstamp a47b582c-d750-4d62-96ae-636febafbe35)
    (fp_text user "${REFERENCE}" (at 2.45 1.8) (layer "F.Fab")
      (tstamp cc2b2676-611b-4298-ac8e-dd4a69d76c6d)
    (fp_line (start 0 2.29) (end 5.08 2.29) (layer "F.SilkS") (width 0.12) (tstamp 4affd905-e3a1-47e1-842c-d52e37463daa))
    (fp_line (start 6.45 -2.65) (end 6.45 3.4) (layer "F.SilkS") (width 0.12) (tstamp 550e69d1-aab5-45db-ad87-5b723b41355d))
    (fp_line (start 6.45 3.4) (end -1.35 3.4) (layer "F.SilkS") (width 0.12) (tstamp 5bfb97a3-0580-4e00-aed9-94bc411e0627))
    (fp_line (start 0 3.3) (end 0 2.29) (layer "F.SilkS") (width 0.12) (tstamp 6d998b52-7ffb-4cfb-a48b-9c74557dd08d))
    (fp_line (start -1.35 -2.65) (end 6.45 -2.65) (layer "F.SilkS") (width 0.12) (tstamp 8534c7b9-8f38-47b0-94de-d1f54016b7ea))
    (fp_line (start -1.35 3.4) (end -1.35 -2.65) (layer "F.SilkS") (width 0.12) (tstamp 85ff230e-cfcf-4209-8a90-bba85181252d))
    (fp_line (start 5.08 2.29) (end 5.08 3.3) (layer "F.SilkS") (width 0.12) (tstamp 9cb6ac00-196e-450d-9e86-70c740ec9e6e))
    (fp_line (start -1.75 3.8) (end -1.75 -3.05) (layer "F.CrtYd") (width 0.05) (tstamp 86d51ad9-9888-49f6-bb4c-7f0ee53834b7))
    (fp_line (start -1.75 3.8) (end 6.85 3.8) (layer "F.CrtYd") (width 0.05) (tstamp 9194732a-5ca3-4f0c-b59f-e31fcd98105e))
    (fp_line (start 6.85 -3.05) (end 6.85 3.8) (layer "F.CrtYd") (width 0.05) (tstamp bf1da4b2-a7e3-477f-b314-22830ac946a4))
    (fp_line (start 6.85 -3.05) (end -1.75 -3.05) (layer "F.CrtYd") (width 0.05) (tstamp d71bb9c0-8450-4896-9905-119fbb2b9022))
    (fp_line (start 5.05 3.3) (end 5.05 2.3) (layer "F.Fab") (width 0.1) (tstamp 12731aa7-c1ce-4ab8-abf8-77fd0526dc02))
    (fp_line (start 0 2.3) (end 0 3.3) (layer "F.Fab") (width 0.1) (tstamp 219c368e-1a4c-4cba-92f9-d838eabb204d))
    (fp_line (start 5.05 2.3) (end 0 2.3) (layer "F.Fab") (width 0.1) (tstamp 25efec2b-634a-4745-abdb-6b01604d5bc7))
    (fp_line (start -1.25 -2.55) (end 6.35 -2.55) (layer "F.Fab") (width 0.1) (tstamp 397f59a9-a76c-41ae-bfb4-ebfca569d5cf))
    (fp_line (start 6.35 3.3) (end -1.25 3.3) (layer "F.Fab") (width 0.1) (tstamp 7288f1e2-de02-4db5-8e1a-eabd2203d619))
    (fp_line (start 6.35 -2.55) (end 6.35 3.3) (layer "F.Fab") (width 0.1) (tstamp 9b0b07f1-0d2f-4e46-800b-c794501eafb8))
    (fp_line (start -1.25 3.3) (end -1.25 -2.55) (layer "F.Fab") (width 0.1) (tstamp f55dbd46-4bd3-4766-b698-c3f1857e2954))
    (pad "1" thru_hole rect (at 0 0 90) (size 2.03 1.73) (drill 1.02) (layers *.Cu *.Mask)
      (net 9 "Net-(C12-Pad1)") (pinfunction "Pin_1") (pintype "passive") (tstamp ca61e63e-5469-451f-9062-64be501a22be))
    (pad "2" thru_hole oval (at 2.54 0 90) (size 2.03 1.73) (drill 1.02) (layers *.Cu *.Mask)
      (net 1 "Net-(BT1-Pad2)") (pinfunction "Pin_2") (pintype "passive") (tstamp 719ae2a4-1810-4222-83f8-33a978f31737))
    (pad "3" thru_hole oval (at 5.08 0 90) (size 2.03 1.73) (drill 1.02) (layers *.Cu *.Mask)
      (net 49 "Net-(J5-Pad3)") (pinfunction "Pin_3") (pintype "passive") (tstamp b93db7b6-1b1b-4468-9cb8-70c360488ec4))
    (model "${KICAD6_3DMODEL_DIR}/Connector.3dshapes/FanPinHeader_1x03_P2.54mm_Vertical.wrl"
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp 4d578a08-6932-413c-a0f8-76d2d6348187)
    (at 68.834 25.1206 -90)
    (path "/c6c0b199-33ff-441a-966b-a7090d2119bb")
    (attr smd)
    (fp_text reference "R56" (at 0.0254 2.3876 -90) (layer "F.SilkS")
      (tstamp 7713ca0a-a32d-4659-abce-dcbdce1d94dc)
      (tstamp 4fc5ba03-7376-4334-8892-cc767c126598)
      (tstamp 4269f920-3a8f-469f-b8f8-3112a4932f86)
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 54d17f02-3c14-4307-b9e2-dc83e02b4030))
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp 8f432baa-bf52-4dcd-b3b0-e7484dd6f391))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 507bf356-61b5-477e-9490-491dd43e378c))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 60ebd5f6-3b68-4508-916a-231fc221deb9))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 90089cf3-6fb8-4902-bbd6-fc2880bb5d88))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp a18c62e7-10ac-44cb-ac9a-d30aee6c4ccb))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 11950de4-a058-4a52-8d41-88f8cd1e8151))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 276dc980-18f9-46a1-935d-29ce4ea342b8))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 90baed6c-4fc2-4958-9ba9-4c9d5304de19))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp c825ac2f-9b63-4257-8a0a-cb15b4453818))
      (net 124 "Net-(D13-Pad1)") (pintype "passive") (tstamp 55dea015-3d25-408d-aebd-04abee2a8b21))
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp 44180bd3-7dc5-4117-86a5-abca8abe78ab))
      (scale (xyz 1 1 1))
  (footprint "Connector_IDC:IDC-Header_2x05_P2.54mm_Vertical" (layer "F.Cu")
    (tedit 5EAC9A07) (tstamp 524b4c0c-b4c2-45c3-b1cc-26473edc3be7)
    (at 129.154 121.965 90)
    (descr "Through hole IDC box header, 2x05, 2.54mm pitch, DIN 41651 / IEC 60603-13, double rows, https://docs.google.com/spreadsheets/d/16SsEcesNF15N3Lb4niX7dcUr-NY5_MFPQhobNuNppn4/edit#gid=0")
    (tags "Through hole vertical IDC box header THT 2x05 2.54mm double row")
    (path "/33b1e186-f52a-4498-9f2c-82ab6ffdb3d9")
    (attr through_hole)
    (fp_text reference "J13" (at 1.27 -6.1 90) (layer "F.SilkS")
      (tstamp 6e201cfa-816f-4119-b69b-3b97196bcccf)
    (fp_text value "In Tastenfeld" (at 1.27 16.26 90) (layer "F.Fab")
      (tstamp 9124814a-d4a9-461a-9f04-061101942c37)
    (fp_text user "${REFERENCE}" (at 1.27 5.08 180) (layer "F.Fab")
      (tstamp 12cad4da-8c54-46a6-9b72-95d4db9a7fcf)
    (fp_line (start -1.98 3.03) (end -1.98 -3.91) (layer "F.SilkS") (width 0.12) (tstamp 068aa5b5-08ae-462a-9baf-efad26bd590f))
    (fp_line (start -1.95 -6.9) (end -1.45 -5.9) (layer "F.SilkS") (width 0.12) (tstamp 06a75677-b92f-46d8-bacc-fdc58fe3763a))
    (fp_line (start -1.98 14.07) (end -1.98 7.13) (layer "F.SilkS") (width 0.12) (tstamp 1d109ca8-882d-42f9-bdb3-43fbcdceb09a))
    (fp_line (start -1.98 -3.91) (end 4.52 -3.91) (layer "F.SilkS") (width 0.12) (tstamp 2623bed7-4612-4b24-b2b5-0fd975e46f57))
    (fp_line (start -3.29 15.37) (end -3.29 -5.21) (layer "F.SilkS") (width 0.12) (tstamp 2ad39b94-c9e3-4784-b6e1-6c342c4ccb76))
    (fp_line (start -1.98 7.13) (end -1.98 7.13) (layer "F.SilkS") (width 0.12) (tstamp 2b9f2009-60ba-44af-8777-3e7b7fa10cdd))
    (fp_line (start -3.29 -5.21) (end 5.83 -5.21) (layer "F.SilkS") (width 0.12) (tstamp 335f5ad9-bca5-432a-b16e-cac1ba404512))
    (fp_line (start -3.29 3.03) (end -1.98 3.03) (layer "F.SilkS") (width 0.12) (tstamp 677b9501-fb8c-46bc-85a4-5a0c64e7b1f3))
    (fp_line (start -0.95 -6.9) (end -1.95 -6.9) (layer "F.SilkS") (width 0.12) (tstamp 6f73881c-b306-4801-89be-54edc7d7e5e4))
    (fp_line (start 4.52 -3.91) (end 4.52 14.07) (layer "F.SilkS") (width 0.12) (tstamp 77b925c1-99d6-4c5c-92c3-5098e95c1593))
    (fp_line (start 5.83 -5.21) (end 5.83 15.37) (layer "F.SilkS") (width 0.12) (tstamp a61acb85-f9bf-4d1a-aea0-c08ad1acfc1f))
    (fp_line (start 5.83 15.37) (end -3.29 15.37) (layer "F.SilkS") (width 0.12) (tstamp b99c6d1e-753a-4d15-9f4d-b0d088c89d59))
    (fp_line (start 4.52 14.07) (end -1.98 14.07) (layer "F.SilkS") (width 0.12) (tstamp e1085d00-1231-443b-a157-0c1f7f30ebfd))
    (fp_line (start -1.98 7.13) (end -3.29 7.13) (layer "F.SilkS") (width 0.12) (tstamp f1f3e3cf-685a-4059-8088-e58c4f5e4015))
    (fp_line (start -1.45 -5.9) (end -0.95 -6.9) (layer "F.SilkS") (width 0.12) (tstamp f28d6071-038c-4d92-8519-6ecd4063aff6))
    (fp_line (start -3.68 15.76) (end 6.22 15.76) (layer "F.CrtYd") (width 0.05) (tstamp 1f88e3dc-b505-4d99-947f-8b5faf070d6f))
    (fp_line (start 6.22 15.76) (end 6.22 -5.6) (layer "F.CrtYd") (width 0.05) (tstamp 3fc07d2b-9277-45eb-80e8-d0da82a3fc7d))
    (fp_line (start 6.22 -5.6) (end -3.68 -5.6) (layer "F.CrtYd") (width 0.05) (tstamp 539b90bb-d516-4347-a684-b38a3d7fec75))
    (fp_line (start -3.68 -5.6) (end -3.68 15.76) (layer "F.CrtYd") (width 0.05) (tstamp ab729d62-ced9-4d2c-9943-10c6a4c381ea))
    (fp_line (start -3.18 3.03) (end -1.98 3.03) (layer "F.Fab") (width 0.1) (tstamp 0edc0189-e82d-42e8-ab19-09ce982a9166))
    (fp_line (start 4.52 14.07) (end -1.98 14.07) (layer "F.Fab") (width 0.1) (tstamp 28935b0f-bca6-4008-beb6-9e9ee492551c))
    (fp_line (start -1.98 -3.91) (end 4.52 -3.91) (layer "F.Fab") (width 0.1) (tstamp 446187fc-1633-467f-b49f-7ffcc4f0f3e4))
    (fp_line (start -2.18 -5.1) (end 5.72 -5.1) (layer "F.Fab") (width 0.1) (tstamp 7a42973d-7b96-4d8b-8c14-65ec7d90d19e))
    (fp_line (start -3.18 -4.1) (end -2.18 -5.1) (layer "F.Fab") (width 0.1) (tstamp 8fd65476-2a78-4015-92c7-8827796d9f6d))
    (fp_line (start -3.18 15.26) (end -3.18 -4.1) (layer "F.Fab") (width 0.1) (tstamp caff2251-a2ba-4a36-ac34-141919389054))
    (fp_line (start -1.98 3.03) (end -1.98 -3.91) (layer "F.Fab") (width 0.1) (tstamp d865fdce-0ef4-4854-bf44-4b1043b47581))
    (fp_line (start 5.72 -5.1) (end 5.72 15.26) (layer "F.Fab") (width 0.1) (tstamp d950f3d9-57ad-41c0-b2af-38de62ee4df0))
    (fp_line (start -1.98 14.07) (end -1.98 7.13) (layer "F.Fab") (width 0.1) (tstamp d97cd5b7-c17b-464e-a391-3fd00e1b5cbe))
    (fp_line (start -1.98 7.13) (end -3.18 7.13) (layer "F.Fab") (width 0.1) (tstamp df086805-12f5-4d0b-b4af-9eedd75471cb))
    (fp_line (start -1.98 7.13) (end -1.98 7.13) (layer "F.Fab") (width 0.1) (tstamp df8dafc3-dbbd-4bd7-bcf8-f4fd476af892))
    (fp_line (start 4.52 -3.91) (end 4.52 14.07) (layer "F.Fab") (width 0.1) (tstamp f28fd860-cabf-44ec-8ed4-357f73650e58))
    (fp_line (start 5.72 15.26) (end -3.18 15.26) (layer "F.Fab") (width 0.1) (tstamp f4083356-af41-494c-9945-22c31462e6a5))
    (pad "1" thru_hole roundrect (at 0 0 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask) (roundrect_rratio 0.1470588235)
      (net 130 "Net-(J13-Pad1)") (pinfunction "Pin_1") (pintype "passive") (tstamp 399773d5-e4d4-448c-b5c7-864ffa1a0954))
    (pad "2" thru_hole circle (at 2.54 0 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 129 "Net-(J13-Pad2)") (pinfunction "Pin_2") (pintype "passive") (tstamp fe2eec87-d5e8-4f6f-8ca8-c7b6012c41b0))
    (pad "3" thru_hole circle (at 0 2.54 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 128 "Net-(J13-Pad3)") (pinfunction "Pin_3") (pintype "passive") (tstamp 429a5e7f-a5c1-4708-a3e0-fc0eba782800))
    (pad "4" thru_hole circle (at 2.54 2.54 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 127 "Net-(J13-Pad4)") (pinfunction "Pin_4") (pintype "passive") (tstamp b187ab4a-a9f0-4d0d-afb2-abe4167206e9))
    (pad "5" thru_hole circle (at 0 5.08 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 126 "Net-(J13-Pad5)") (pinfunction "Pin_5") (pintype "passive") (tstamp 603d1b16-88d3-4d51-b0c5-69d133174e51))
    (pad "6" thru_hole circle (at 2.54 5.08 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 125 "Net-(J13-Pad6)") (pinfunction "Pin_6") (pintype "passive") (tstamp f81163dc-e50e-4b9c-bd1d-1d0e91d8707b))
    (pad "7" thru_hole circle (at 0 7.62 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 121 "Net-(D9-Pad2)") (pinfunction "Pin_7") (pintype "passive") (tstamp 20778bac-70c3-4c79-8ec0-996cba1b158d))
    (pad "8" thru_hole circle (at 2.54 7.62 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 123 "unconnected-(J13-Pad8)") (pinfunction "Pin_8") (pintype "passive") (tstamp 7c4d54aa-0ab5-4074-89b9-eb4a9dd317bc))
    (pad "9" thru_hole circle (at 0 10.16 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 135 "Net-(J13-Pad9)") (pinfunction "Pin_9") (pintype "passive") (tstamp 368e51d8-2dab-41ae-b23f-ec45f70185cf))
    (pad "10" thru_hole circle (at 2.54 10.16 90) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 122 "Net-(D10-Pad2)") (pinfunction "Pin_10") (pintype "passive") (tstamp 791ac44c-5b4a-463b-b16b-b0d0958f85d9))
    (model "${KICAD6_3DMODEL_DIR}/Connector_IDC.3dshapes/IDC-Header_2x05_P2.54mm_Vertical.wrl"
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp 528345b7-5795-416c-8df2-9a0c707c9355)
    (at 48.133 101.6 -90)
    (path "/140be77a-c3c9-4f97-8f8e-c9ac1c9723c5")
    (attr smd)
    (fp_text reference "R35" (at 3.81 -0.127 90) (layer "F.SilkS")
      (tstamp 0aad61c7-e08b-4e81-b31f-867215fad456)
      (tstamp 03e05db9-6cff-4503-ab67-fff7fd6f37fc)
      (tstamp 711b5bca-c900-4754-939d-9c23b65f0a42)
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 8f502f39-bb8e-45f2-a3db-ad51447f8459))
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp 9c546123-bde1-4fef-bff8-100e870d6df2))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 30ba5d87-4b55-4067-8fdf-7eb8c39da57a))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 31937531-0fea-4cac-a2f9-f56a60c81f5a))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp a180de0c-b2cb-4003-89c0-3907e4eadab9))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp d31e07bf-f0c0-4f58-b68f-761928c97a58))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 0efe69fb-92f8-4ddf-8977-8ee252a81211))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp b348c99f-7638-4192-a8ca-ce476cc618d0))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp bbeebb4a-b983-4ece-a399-0d2dcc8fbbc4))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp be002f73-31b2-4515-972e-9c4b93cb000a))
      (net 66 "Net-(R35-Pad1)") (pintype "passive") (tstamp a0e59221-5116-4c58-bddc-7343e1b20c64))
      (net 92 "Net-(J12-Pad3)") (pintype "passive") (tstamp 93d0db0a-b855-4b19-83e2-4b5fdb2c48d9))
      (scale (xyz 1 1 1))
  (footprint "Package_TO_SOT_THT:TO-220-3_Vertical" (layer "F.Cu")
    (tedit 5AC8BA0D) (tstamp 560b025d-9e8b-4fa5-bc62-3c6a02b02206)
    (at 103.576 65.786 -90)
    (descr "TO-220-3, Vertical, RM 2.54mm, see https://www.vishay.com/docs/66542/to-220-1.pdf")
    (tags "TO-220-3 Vertical RM 2.54mm")
    (path "/32090d61-caed-461d-afef-ae7b09d00175")
    (attr through_hole)
    (fp_text reference "U3" (at 2.54 2.357 90) (layer "F.SilkS")
      (tstamp a5ea9978-c26a-4172-9191-e553ccad231b)
    (fp_text value "LM78M05_TO220" (at 2.54 2.5 90) (layer "F.Fab")
      (tstamp 591f2a1f-842b-4b0e-970b-f6d98154ea54)
    (fp_text user "${REFERENCE}" (at 2.54 -4.27 90) (layer "F.Fab")
      (tstamp 2bf31c35-97a4-4208-80a9-7b88e76cc90a)
    (fp_line (start -2.58 -3.27) (end -2.58 1.371) (layer "F.SilkS") (width 0.12) (tstamp 0acafb5d-3991-4041-ae7a-47c39f9e3568))
    (fp_line (start -2.58 -3.27) (end 7.66 -3.27) (layer "F.SilkS") (width 0.12) (tstamp 31c7728c-24c2-4751-9864-3939f9a2ae3f))
    (fp_line (start 7.66 -3.27) (end 7.66 1.371) (layer "F.SilkS") (width 0.12) (tstamp 4a267ff6-8bfd-46e2-8aab-e98924e9adb9))
    (fp_line (start 0.69 -3.27) (end 0.69 -1.76) (layer "F.SilkS") (width 0.12) (tstamp 4a7f0613-5b61-4be5-98a5-274ea724a1c6))
    (fp_line (start -2.58 1.371) (end 7.66 1.371) (layer "F.SilkS") (width 0.12) (tstamp 8188a55b-d313-4108-8b04-78acfc27b430))
    (fp_line (start -2.58 -1.76) (end 7.66 -1.76) (layer "F.SilkS") (width 0.12) (tstamp 975550fe-4c3b-468f-8310-721a655a5c58))
    (fp_line (start 4.391 -3.27) (end 4.391 -1.76) (layer "F.SilkS") (width 0.12) (tstamp cc37e33d-01f1-46eb-b85d-febeefc67a15))
    (fp_line (start -2.71 1.51) (end 7.79 1.51) (layer "F.CrtYd") (width 0.05) (tstamp 2317f1d7-7d5c-4564-aa00-8b980d3ce441))
    (fp_line (start 7.79 -3.4) (end -2.71 -3.4) (layer "F.CrtYd") (width 0.05) (tstamp 4d3e2989-18da-4cb4-9351-f2ecb7a6d31c))
    (fp_line (start -2.71 -3.4) (end -2.71 1.51) (layer "F.CrtYd") (width 0.05) (tstamp 5d3040df-c125-4424-bd4e-5ba37d279080))
    (fp_line (start 7.79 1.51) (end 7.79 -3.4) (layer "F.CrtYd") (width 0.05) (tstamp ce9afae0-1ced-4316-a605-61d971a95314))
    (fp_line (start 0.69 -3.15) (end 0.69 -1.88) (layer "F.Fab") (width 0.1) (tstamp 3033d2dc-317a-4061-b4e6-b89825473e85))
    (fp_line (start 4.39 -3.15) (end 4.39 -1.88) (layer "F.Fab") (width 0.1) (tstamp 6a924e07-d32e-4bbf-9577-c8f568849dd8))
    (fp_line (start -2.46 -3.15) (end -2.46 1.25) (layer "F.Fab") (width 0.1) (tstamp 77d1a21a-28b5-4bcb-8d54-e84f9d9b2ceb))
    (fp_line (start 7.54 -3.15) (end -2.46 -3.15) (layer "F.Fab") (width 0.1) (tstamp 84e6b23c-0f72-4aa2-9f7f-40a09a7aad9f))
    (fp_line (start 7.54 1.25) (end 7.54 -3.15) (layer "F.Fab") (width 0.1) (tstamp c6419d9b-030d-447d-b95b-7170528a62c8))
    (fp_line (start -2.46 1.25) (end 7.54 1.25) (layer "F.Fab") (width 0.1) (tstamp eb629609-6447-4568-876a-5e528f789578))
    (fp_line (start -2.46 -1.88) (end 7.54 -1.88) (layer "F.Fab") (width 0.1) (tstamp fa90d8cb-0857-41c1-bf5d-3b6f56904aa0))
    (pad "1" thru_hole rect (at 0 0 270) (size 1.905 2) (drill 1.1) (layers *.Cu *.Mask)
      (net 15 "Net-(C3-Pad1)") (pinfunction "VI") (pintype "power_in") (tstamp efec3a94-f754-4c64-8ed1-c2ba780f13eb))
    (pad "2" thru_hole oval (at 2.54 0 270) (size 1.905 2) (drill 1.1) (layers *.Cu *.Mask)
      (net 1 "Net-(BT1-Pad2)") (pinfunction "GND") (pintype "power_in") (tstamp 2dd0802d-aa39-4927-bf85-d703c6ef2941))
    (pad "3" thru_hole oval (at 5.08 0 270) (size 1.905 2) (drill 1.1) (layers *.Cu *.Mask)
      (net 5 "Net-(C7-Pad1)") (pinfunction "VO") (pintype "power_out") (tstamp 1d0589c1-c007-491d-b174-1e9363825c15))
    (model "${KICAD6_3DMODEL_DIR}/Package_TO_SOT_THT.3dshapes/TO-220-3_Vertical.wrl"
      (scale (xyz 1 1 1))
    (tedit 5F68FEEF) (tstamp 5a982621-5224-49d5-b73a-9c180f1c0a1c)
    (at 75.311 32.131 -90)
    (path "/0e95ab2e-3013-4182-9e87-51acd3256c77")
    (attr smd)
    (fp_text reference "C10" (at -3.175 0 180) (layer "F.SilkS")
      (tstamp 3435512b-64f3-46c4-8b23-3251ed6ea06b)
    (fp_text value "1µ 50V KEM X7R1206 1,0U" (at 0 1.85 90) (layer "F.Fab")
      (tstamp 6e9e433b-eab7-4b0a-af2f-0e631332d5e1)
      (tstamp 46e65f00-a66e-4e17-8429-363024a3b170)
    (fp_line (start -0.711252 0.91) (end 0.711252 0.91) (layer "F.SilkS") (width 0.12) (tstamp 1c0d0be0-0165-409c-bfdc-7195b31145a9))
    (fp_line (start -0.711252 -0.91) (end 0.711252 -0.91) (layer "F.SilkS") (width 0.12) (tstamp 8d8c0a69-2464-426e-bcc7-2c410648a133))
    (fp_line (start 2.48 -1.15) (end 2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp 4b82aebb-52a6-4e9b-8c98-f652c6627e52))
    (fp_line (start -2.48 1.15) (end -2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp 52d2ac41-5142-43f8-9395-82dbeefe7ba8))
    (fp_line (start 2.48 1.15) (end -2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp 5b1d2d14-aa51-4c8b-9c54-82285e2219a6))
    (fp_line (start -2.48 -1.15) (end 2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp c1f27267-c4fd-4ef9-a850-03d1cb912e90))
    (fp_line (start 1.6 0.8) (end -1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp 3f0c4212-6f26-4a27-9998-287a9ba4c5ea))
    (fp_line (start 1.6 -0.8) (end 1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp 62e1de4a-144b-43f3-b587-1b2dadbfc093))
    (fp_line (start -1.6 0.8) (end -1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp ab00a464-cfa8-46e2-90b4-cd23e9fce6bb))
    (fp_line (start -1.6 -0.8) (end 1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp c5c16109-90da-4a6c-b614-8083cb15ff07))
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp 07e4bbf6-faca-415f-8e1b-09ddcef42765))
      (net 8 "Net-(C10-Pad2)") (pintype "passive") (tstamp e821130f-c018-46fd-9230-806c3fa73b83))
      (scale (xyz 1 1 1))
    (tedit 5EAC9A07) (tstamp 5aac0b1d-5a01-469b-a2ca-255422cc18db)
    (at 37.211 160.8995 90)
    (path "/d78c92d6-e272-4543-9321-4570cf5048c3")
    (attr through_hole)
    (fp_text reference "J12" (at 1.2605 -6.604 90) (layer "F.SilkS")
      (tstamp abb604d4-0109-4cc2-aad6-7c242be7f752)
    (fp_text value "Out Tastenfeld" (at 1.27 16.26 90) (layer "F.Fab")
      (tstamp 4b9f08a4-28bf-4164-bd86-38d428471ca1)
    (fp_text user "${REFERENCE}" (at 1.27 5.08) (layer "F.Fab")
      (tstamp df6b8e3a-3798-4717-bbb1-fa130dca3b46)
    (fp_line (start -4.68 -0.5) (end -4.68 0.5) (layer "F.SilkS") (width 0.12) (tstamp 2081d418-2076-4b0d-b3b7-c56a875d9c5a))
    (fp_line (start 5.83 -5.21) (end 5.83 15.37) (layer "F.SilkS") (width 0.12) (tstamp 2703d303-2fff-4c85-9603-9396669a92ef))
    (fp_line (start 4.52 14.07) (end -1.98 14.07) (layer "F.SilkS") (width 0.12) (tstamp 3177f639-f798-4877-b5bf-5aff953571be))
    (fp_line (start -1.98 14.07) (end -1.98 7.13) (layer "F.SilkS") (width 0.12) (tstamp 3dd23168-ceba-44ad-9d75-286b66af0401))
    (fp_line (start -3.29 -5.21) (end 5.83 -5.21) (layer "F.SilkS") (width 0.12) (tstamp 3e232323-1283-4000-a4c0-09eeca6e1a49))
    (fp_line (start -4.68 0.5) (end -3.68 0) (layer "F.SilkS") (width 0.12) (tstamp 4a679bb8-81c3-48ba-a6f1-8f22cb479b89))
    (fp_line (start -1.98 7.13) (end -1.98 7.13) (layer "F.SilkS") (width 0.12) (tstamp 5738ceb7-d112-4a2c-8f3b-10a3fb251bac))
    (fp_line (start -3.29 3.03) (end -1.98 3.03) (layer "F.SilkS") (width 0.12) (tstamp 5d60daa4-aac2-4441-b7ac-d10ccc76c8f2))
    (fp_line (start -1.98 -3.91) (end 4.52 -3.91) (layer "F.SilkS") (width 0.12) (tstamp 7e81c563-46c8-46cf-826a-9c132650e9bf))
    (fp_line (start -1.98 7.13) (end -3.29 7.13) (layer "F.SilkS") (width 0.12) (tstamp 91aa0fb0-5284-4af2-a329-fe0ba60402e7))
    (fp_line (start 5.83 15.37) (end -3.29 15.37) (layer "F.SilkS") (width 0.12) (tstamp 921dfe82-7c25-499d-95ac-09910a685af6))
    (fp_line (start 4.52 -3.91) (end 4.52 14.07) (layer "F.SilkS") (width 0.12) (tstamp 94eda983-d11d-4157-958f-397cda23eec2))
    (fp_line (start -1.98 3.03) (end -1.98 -3.91) (layer "F.SilkS") (width 0.12) (tstamp a4e69d2e-2e42-47d0-ae2f-48b322d4bc71))
    (fp_line (start -3.29 15.37) (end -3.29 -5.21) (layer "F.SilkS") (width 0.12) (tstamp ca049971-28db-4c24-8f89-7c43c685c410))
    (fp_line (start -3.68 0) (end -4.68 -0.5) (layer "F.SilkS") (width 0.12) (tstamp f0b78164-2979-4276-bce6-0a8f1148cbae))
    (fp_line (start 6.22 -5.6) (end -3.68 -5.6) (layer "F.CrtYd") (width 0.05) (tstamp 01f34ebb-449b-4eee-8076-38ec06e0aec0))
    (fp_line (start -3.68 -5.6) (end -3.68 15.76) (layer "F.CrtYd") (width 0.05) (tstamp 2a2631a1-9ddc-4259-b71d-ba7e85f1059f))
    (fp_line (start -3.68 15.76) (end 6.22 15.76) (layer "F.CrtYd") (width 0.05) (tstamp 9f8b9c15-7cac-433b-b228-f056872fc9c7))
    (fp_line (start 6.22 15.76) (end 6.22 -5.6) (layer "F.CrtYd") (width 0.05) (tstamp cf67e9c6-47ab-4d60-afae-632ef2656326))
    (fp_line (start 5.72 15.26) (end -3.18 15.26) (layer "F.Fab") (width 0.1) (tstamp 09b6dcbc-47d7-4653-beb4-0705199842d7))
    (fp_line (start -1.98 3.03) (end -1.98 -3.91) (layer "F.Fab") (width 0.1) (tstamp 2541e116-71d1-4ce5-afed-39ff4cbd6ca1))
    (fp_line (start -3.18 -4.1) (end -2.18 -5.1) (layer "F.Fab") (width 0.1) (tstamp 2a3ef1bf-03ab-4e95-8d5f-2f9a44fb01ae))
    (fp_line (start -3.18 3.03) (end -1.98 3.03) (layer "F.Fab") (width 0.1) (tstamp 4d4ea18a-8fa0-4e1e-ab35-f7b94bf9dbf5))
    (fp_line (start -2.18 -5.1) (end 5.72 -5.1) (layer "F.Fab") (width 0.1) (tstamp 85a5b731-4d56-4de5-81c1-91c5e1f631ef))
    (fp_line (start -1.98 -3.91) (end 4.52 -3.91) (layer "F.Fab") (width 0.1) (tstamp 879f5b8a-9daa-4d06-a063-55a3c8d603ac))
    (fp_line (start -1.98 7.13) (end -1.98 7.13) (layer "F.Fab") (width 0.1) (tstamp 916bcd3a-c4a8-4eef-affc-c7ffc4104580))
    (fp_line (start -1.98 7.13) (end -3.18 7.13) (layer "F.Fab") (width 0.1) (tstamp a79438a4-94b3-4ea6-b129-3ac081a604b7))
    (fp_line (start 4.52 -3.91) (end 4.52 14.07) (layer "F.Fab") (width 0.1) (tstamp b158902d-6ada-4a10-a3e6-880fe1bfd07b))
    (fp_line (start -1.98 14.07) (end -1.98 7.13) (layer "F.Fab") (width 0.1) (tstamp b649777d-bd69-4943-877a-c13b783aab44))
    (fp_line (start 5.72 -5.1) (end 5.72 15.26) (layer "F.Fab") (width 0.1) (tstamp f3c796af-bde9-4c65-9186-83d6084eb752))
    (fp_line (start -3.18 15.26) (end -3.18 -4.1) (layer "F.Fab") (width 0.1) (tstamp f5d2c630-f553-48c0-a26c-ebcbe18cb893))
    (fp_line (start 4.52 14.07) (end -1.98 14.07) (layer "F.Fab") (width 0.1) (tstamp fc34c6fd-19d9-4abc-89d9-24b771f1b97d))
      (net 90 "Net-(J12-Pad1)") (pinfunction "Pin_1") (pintype "passive") (tstamp 4be82668-01c6-4b7d-b81a-a858effb28ca))
      (net 91 "Net-(J12-Pad2)") (pinfunction "Pin_2") (pintype "passive") (tstamp 7b91c3d4-d46b-4b49-8b6b-505c3e3d99a2))
      (net 92 "Net-(J12-Pad3)") (pinfunction "Pin_3") (pintype "passive") (tstamp 352c947c-42b7-452e-ac63-bac2f31569d0))
      (net 93 "Net-(J12-Pad4)") (pinfunction "Pin_4") (pintype "passive") (tstamp e18e1243-c11c-4343-8578-b056f532c6ea))
      (net 94 "Net-(J12-Pad5)") (pinfunction "Pin_5") (pintype "passive") (tstamp 53a8d060-5d56-40fc-8949-57732e609ae9))
      (net 95 "Net-(J12-Pad6)") (pinfunction "Pin_6") (pintype "passive") (tstamp a8cc75c0-3684-43df-9ca7-ce43cd3fdebf))
      (net 133 "Net-(D13-Pad2)") (pinfunction "Pin_7") (pintype "passive") (tstamp 055c24a4-6f43-453e-8af9-7814f4225e21))
      (net 120 "unconnected-(J12-Pad8)") (pinfunction "Pin_8") (pintype "passive") (tstamp a6ef950a-481a-4779-b34d-72b74e89c4ac))
      (net 1 "Net-(BT1-Pad2)") (pinfunction "Pin_9") (pintype "passive") (tstamp a8d8778d-f965-4285-86ea-4e7657649611))
      (net 132 "Net-(J12-Pad10)") (pinfunction "Pin_10") (pintype "passive") (tstamp 509fac52-2e72-4e8c-be97-c71f55995bdb))
      (scale (xyz 1 1 1))
  (footprint "Fuse:Fuseholder_Cylinder-5x20mm_Schurter_0031_8201_Horizontal_Open" (layer "F.Cu")
    (tedit 5D717D34) (tstamp 5cd48a79-76c3-43d2-8c44-83ee1091d3d3)
    (at 154.051 28.956 180)
    (descr "Fuseholder horizontal open, 5x20mm, 500V, 16A, Schurter 0031.8201, https://us.schurter.com/bundles/snceschurter/epim/_ProdPool_/newDS/en/typ_OGN.pdf")
    (tags "Fuseholder horizontal open 5x20 Schurter 0031.8201")
    (path "/79092eee-c5a7-4b2c-a266-8e61d5889254")
    (attr through_hole)
    (fp_text reference "F2" (at 12.573 5.842 180) (layer "F.SilkS")
      (tstamp 578609ce-b435-4f38-ac8d-26c97bcfe4ad)
    (fp_text value "Fuse" (at 11.25 6) (layer "F.Fab")
      (tstamp c7dafe28-5951-45be-a5eb-4d493f58d4f4)
    (fp_text user "${REFERENCE}" (at 11.25 4) (layer "F.Fab")
      (tstamp 6aa7a7e6-f9fd-4812-b9ac-ce8533b95352)
    (fp_line (start -0.11 -4.91) (end 22.61 -4.91) (layer "F.SilkS") (width 0.12) (tstamp 17284d16-8122-4c95-b8c1-4f81bc146730))
    (fp_line (start -0.11 4.91) (end -0.11 1.75) (layer "F.SilkS") (width 0.12) (tstamp 3fffa9a6-6ad9-4b16-846e-90b927ca8816))
    (fp_line (start -0.11 4.91) (end 22.61 4.91) (layer "F.SilkS") (width 0.12) (tstamp 406c3b58-2eb9-452c-b47e-b91e7d9349c2))
    (fp_line (start 22.61 -1.75) (end 22.61 -4.91) (layer "F.SilkS") (width 0.12) (tstamp 71cdd6f7-41a9-4b1a-b3a7-24b66b58a65b))
    (fp_line (start 22.61 4.91) (end 22.61 1.75) (layer "F.SilkS") (width 0.12) (tstamp d0f01a94-a143-4270-a6a7-8797913f2d86))
    (fp_line (start -0.11 -1.75) (end -0.11 -4.91) (layer "F.SilkS") (width 0.12) (tstamp e282d29f-423b-4f7e-83cf-41691f6ce2d9))
    (fp_line (start 24.25 -5.05) (end 24.25 5.05) (layer "F.CrtYd") (width 0.05) (tstamp 0a149e7d-f43f-40ac-9ab7-f2d8eb23ec22))
    (fp_line (start -1.75 -5.05) (end 24.25 -5.05) (layer "F.CrtYd") (width 0.05) (tstamp 7159ac70-cc76-4a19-b0e9-f239d4b94abc))
    (fp_line (start -1.75 5.05) (end -1.75 -5.05) (layer "F.CrtYd") (width 0.05) (tstamp 7368eac2-b5ff-4493-8f0b-f0e51633a454))
    (fp_line (start 24.25 5.05) (end -1.75 5.05) (layer "F.CrtYd") (width 0.05) (tstamp c9fce993-7855-490c-940a-ea3f0735e44c))
    (fp_line (start 22.5 -4.8) (end 0 -4.8) (layer "F.Fab") (width 0.1) (tstamp 2ae9a94a-434d-4ab2-a12f-fb2dd0c59211))
    (fp_line (start 0 4.8) (end 22.5 4.8) (layer "F.Fab") (width 0.1) (tstamp 48e87454-d0a5-43e0-ba32-882cd1e594c8))
    (fp_line (start 0 -4.8) (end 0 4.8) (layer "F.Fab") (width 0.1) (tstamp ac27afe6-3eee-4114-886c-ea70075455a6))
    (fp_line (start 22.5 4.8) (end 22.5 -4.8) (layer "F.Fab") (width 0.1) (tstamp e8d1c240-dc1d-4469-ab87-d1889d779ab4))
    (pad "" np_thru_hole circle (at 11.25 0 180) (size 2.7 2.7) (drill 2.7) (layers *.Cu *.Mask) (tstamp 51585b4a-90ec-4fea-923a-2661b4ba2f94))
    (pad "1" thru_hole circle (at 0 0 180) (size 3 3) (drill 1.3) (layers *.Cu *.Mask)
      (net 23 "Net-(F2-Pad1)") (pintype "passive") (tstamp e19d2b64-4864-474a-9235-97f6c0d4baa3))
    (pad "2" thru_hole circle (at 22.5 0 180) (size 3 3) (drill 1.3) (layers *.Cu *.Mask)
      (net 44 "Net-(C11-Pad1)") (pintype "passive") (tstamp 921172c9-6ca4-477a-845a-31eef73aea22))
    (model "${KICAD6_3DMODEL_DIR}/Fuse.3dshapes/Fuseholder_Cylinder-5x20mm_Schurter_0031_8201_Horizontal_Open.wrl"
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp 5d3b981b-165b-4a64-95ff-58ad459a82b9)
    (at 52.451 152.146)
    (path "/b5e2deeb-92bd-4e5c-9dfe-75c99638c9d2")
    (attr smd)
    (fp_text reference "R60" (at -3.556 -0.127 90) (layer "F.SilkS")
      (tstamp bdb21821-191e-4080-bdca-b30f788f60b8)
    (fp_text value "SMD 1/4W 2k2" (at 4.064 0.762) (layer "F.Fab")
      (tstamp 69bab6de-53ee-438e-81e6-f68476ef907d)
    (fp_text user "${REFERENCE}" (at 0 0) (layer "F.Fab")
      (tstamp 8d95a335-041a-4e6a-9d52-71cdde04a9a4)
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 9b0efa46-6e01-4000-b0ac-29cd6fbdd37c))
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp d9c1f517-9f27-43c2-8264-744282324e97))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 24675db8-f0f5-458a-a107-7fa16c4bb2cd))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 3b5cef53-e53f-48ee-9813-8ee27c232e8d))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 4c4a5f20-42b6-4337-8302-29a4237f48ef))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 66ca317f-056c-41c2-b208-2618d25db362))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 369e6a11-30da-40ef-869e-cac494414b7e))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 3e4347c1-f2d3-408c-addd-e57ba543deeb))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp b6c23190-4542-4daf-ac13-ed3b8c772258))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp e80f2ef5-dc26-4c20-910e-6478c2f8d7d2))
    (pad "1" smd roundrect (at -1.55 0) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 132 "Net-(J12-Pad10)") (pintype "passive") (tstamp 9f37e826-cfb5-4a7f-841b-7e7c9df60f1e))
    (pad "2" smd roundrect (at 1.55 0) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 85 "Net-(C20-Pad1)") (pintype "passive") (tstamp 780acebb-48fb-477f-b04c-3314d0031a7a))
      (scale (xyz 1 1 1))
    (tedit 5F68FEEF) (tstamp 5df98277-709b-44c9-b462-27106b428ead)
    (at 60.071 34.671 180)
    (property "Sheetfile" "Lauflicht_Steuerplatine.kicad_sch")
    (property "Sheetname" "")
    (path "/13fa7d2d-d486-4fad-bd5f-46af7f139d72")
    (attr smd)
    (fp_text reference "C2" (at 1.524 2.413 90) (layer "F.SilkS")
      (effects (font (size 1 1) (thickness 0.15)))
      (tstamp e687c70c-3ad6-4257-a9a2-39b512f74893)
    (fp_text value "100n 50V KEM X7R1206 1,0U" (at 0 1.85) (layer "F.Fab")
      (tstamp e637fb83-aa82-4cf3-9f66-63bfaad5462a)
      (tstamp ccda2341-18a5-41f5-9de2-6bbd49cfad8a)
    (fp_line (start -0.711252 -0.91) (end 0.711252 -0.91) (layer "F.SilkS") (width 0.12) (tstamp 3dd836d9-3d50-418e-b231-fd220b7cb3b3))
    (fp_line (start -0.711252 0.91) (end 0.711252 0.91) (layer "F.SilkS") (width 0.12) (tstamp 7a9cd848-9199-40ce-bb84-4a529644bd00))
    (fp_line (start 2.48 -1.15) (end 2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp 105c57b2-36a4-43ca-b19e-7b25701b54bc))
    (fp_line (start 2.48 1.15) (end -2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp 19b3c43b-63f9-40b9-91b2-19c6c7654a8c))
    (fp_line (start -2.48 1.15) (end -2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp 7c1af48c-da43-4ced-be93-787ad38deb50))
    (fp_line (start -2.48 -1.15) (end 2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp 918bf965-8a1f-43b0-9854-cfa339ef4fcd))
    (fp_line (start 1.6 -0.8) (end 1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp 29729d0b-58ba-4659-b943-873388fae6ca))
    (fp_line (start -1.6 -0.8) (end 1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp 40a2c7cd-8ea2-46a6-aaea-16207d24da4f))
    (fp_line (start -1.6 0.8) (end -1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp cb668777-dd3a-4786-84d9-187998ae83c8))
    (fp_line (start 1.6 0.8) (end -1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp f67555c0-3144-46fd-9067-e10767a5115f))
    (pad "1" smd roundrect (at -1.5625 0 180) (size 1.325 1.8) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1886792453)
      (net 2 "Net-(C2-Pad1)") (pintype "passive") (tstamp 0c6e3484-374e-4821-85c6-fac9f6f804f9))
    (pad "2" smd roundrect (at 1.5625 0 180) (size 1.325 1.8) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1886792453)
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp 4eff6346-1569-45f9-8bae-d6825f09c441))
      (offset (xyz 0 0 0))
      (scale (xyz 1 1 1))
      (rotate (xyz 0 0 0))
  (footprint "Library:OMR B3F-4000" (layer "F.Cu")
    (tedit 5D160D14) (tstamp 5f19bfc9-73d0-4eb5-bc5b-eef1173d32e0)
    (at 100.049 143.59)
    (descr "SW PUSH 12mm https://www.e-switch.com/system/asset/product_line/data_sheet/143/TL1100.pdf")
    (tags "tact sw push 12mm")
    (path "/4ef52e8c-a992-43c8-80a5-140915358977")
    (attr through_hole)
    (fp_text reference "SW2" (at -1.497 2.46) (layer "F.SilkS")
      (tstamp 51f94a80-11b2-41cf-aad9-adb7898e76fc)
    (fp_text value "Start" (at 6.62 9.93) (layer "F.Fab")
      (tstamp eae409f2-acbf-4bc1-94c4-e7823d74e733)
    (fp_text user "${REFERENCE}" (at 6.35 2.54) (layer "F.Fab")
      (tstamp 838d6563-7640-4190-a425-a698e2485b0d)
    (fp_line (start 12.4 -3.65) (end 12.4 -1.1) (layer "F.SilkS") (width 0.12) (tstamp 185f93c7-cf50-44d5-b7aa-85c498fa658c))
    (fp_line (start 0.1 -3.65) (end 12.4 -3.65) (layer "F.SilkS") (width 0.12) (tstamp 48451d48-2f5e-4c6d-9910-d8d8d0034001))
    (fp_line (start 12.4 1.1) (end 12.4 3.8) (layer "F.SilkS") (width 0.12) (tstamp 6594c2d1-dbab-418c-806e-4a68d1657a1a))
    (fp_line (start 12.4 8.65) (end 0.1 8.65) (layer "F.SilkS") (width 0.12) (tstamp 6b9a3432-e854-4cfc-ba81-6f0eb510c598))
    (fp_line (start 12.4 6.2) (end 12.4 8.65) (layer "F.SilkS") (width 0.12) (tstamp 6f838be0-e9d6-4a55-ba17-99d5d1163512))
    (fp_line (start 0.1 3.8) (end 0.1 1.3) (layer "F.SilkS") (width 0.12) (tstamp 7ba6c90a-a0dd-4168-a2d0-94bcc7f5fbb0))
    (fp_line (start 0.1 8.65) (end 0.1 6.2) (layer "F.SilkS") (width 0.12) (tstamp 87c59ac2-5812-46f3-b3d7-8743032ed27a))
    (fp_line (start 0.1 -1.1) (end 0.1 -3.65) (layer "F.SilkS") (width 0.12) (tstamp be53f5f7-67d9-4f8b-a1ae-452f01943dac))
    (fp_circle (center 6.35 2.54) (end 10.16 5.08) (layer "F.SilkS") (width 0.12) (fill none) (tstamp 195cb4d6-3d93-4736-96d4-0bbfadb0746d))
    (fp_line (start 14.25 8.75) (end 14.25 -3.75) (layer "F.CrtYd") (width 0.05) (tstamp 11a48965-c00a-4563-8975-de7823fa6cbb))
    (fp_line (start -1.77 -3.75) (end -1.77 8.75) (layer "F.CrtYd") (width 0.05) (tstamp 46e8e5a0-34eb-42f4-b753-1467ee6277e4))
    (fp_line (start 14.25 8.75) (end -1.77 8.75) (layer "F.CrtYd") (width 0.05) (tstamp c1819ace-d232-435f-a65b-b0d58eab9421))
    (fp_line (start -1.77 -3.75) (end 14.25 -3.75) (layer "F.CrtYd") (width 0.05) (tstamp e90d1413-b810-447c-ad3d-38fd021027e1))
    (fp_line (start 0.25 -3.5) (end 12.25 -3.5) (layer "F.Fab") (width 0.1) (tstamp 191ff158-37b4-4ebd-9746-284fe279fd31))
    (fp_line (start 0.25 -3.5) (end 0.25 8.5) (layer "F.Fab") (width 0.1) (tstamp cfb6d260-a8a1-4995-bde0-be9d6ec24b7e))
    (fp_line (start 0.25 8.5) (end 12.25 8.5) (layer "F.Fab") (width 0.1) (tstamp de172a03-1cef-440a-8260-4d7da9f7799f))
    (fp_line (start 12.25 -3.5) (end 12.25 8.5) (layer "F.Fab") (width 0.1) (tstamp e90fb4ed-6da1-4b55-bd73-1b66d6543709))
    (pad "1" thru_hole oval (at 12.5 5) (size 3.048 1.85) (drill 1.3) (layers *.Cu *.Mask)
      (net 125 "Net-(J13-Pad6)") (pinfunction "A") (pintype "passive") (tstamp 7c8e72d0-68b3-48b7-b909-8b538d01c88a))
    (pad "2" thru_hole oval (at 0 5) (size 3.048 1.85) (drill 1.3) (layers *.Cu *.Mask)
      (net 125 "Net-(J13-Pad6)") (pinfunction "A") (pintype "passive") (tstamp 5366b977-ba84-4ee4-8aa6-e41e3e770dc0))
    (pad "3" thru_hole oval (at 12.5 0) (size 3.048 1.85) (drill 1.3) (layers *.Cu *.Mask)
      (net 129 "Net-(J13-Pad2)") (pinfunction "B") (pintype "passive") (tstamp ed4071b5-92bc-45cd-9d93-f73f4ce1ab24))
    (pad "4" thru_hole oval (at 0 0) (size 3.048 1.85) (drill 1.3) (layers *.Cu *.Mask)
      (net 129 "Net-(J13-Pad2)") (pinfunction "B") (pintype "passive") (tstamp 135fd46f-0baa-469f-ab55-2e06eeabb30f))
    (model "${KICAD6_3DMODEL_DIR}/Button_Switch_THT.3dshapes/SW_PUSH-12mm.wrl"
      (scale (xyz 1 1 1))
  (footprint "Display:RC1602A Ohne Seitenpads" (layer "F.Cu")
    (tedit 5A02FE80) (tstamp 613f4a7b-dfc7-424e-bc81-e1922d346eb0)
    (at 59.309 106.222 -90)
    (descr "http://www.raystar-optronics.com/down.php?ProID=18")
    (tags "LCD 16x2 Alphanumeric 16pin")
    (path "/006ded8c-3363-48cd-a83b-22e0cbb37dbb")
    (attr through_hole)
    (fp_text reference "U5" (at -38.53 -3.41 90) (layer "F.SilkS")
      (tstamp c879d5ba-757f-4c72-a006-90194e9477d8)
    (fp_text value "LCD-PM 2X16-6 E" (at -37.22 43.58 90) (layer "F.Fab")
      (tstamp ee864ef1-f81c-401e-b423-d9daee039d8e)
    (fp_text user "${REFERENCE}" (at 0.185 21.705 90) (layer "F.Fab")
      (tstamp 37ddd5f3-de45-48ae-838a-45f6ee034b69)
    (fp_line (start -40.92 39.11) (end -39.1 39.11) (layer "F.SilkS") (width 0.12) (tstamp 13ba151d-8238-4c95-9207-7ebdeae67c29))
    (fp_line (start 41.5 39.11) (end 43.36 39.11) (layer "F.SilkS") (width 0.12) (tstamp 1ec0eb22-2365-417c-be29-35e231acddd5))
    (fp_line (start -40.92 0.2) (end -40.92 -2.14) (layer "F.SilkS") (width 0.12) (tstamp 25f7721f-a1f3-4175-a058-8b5b254276e0))
    (fp_line (start -1.5 -2.5) (end 1.5 -2.5) (layer "F.SilkS") (width 0.12) (tstamp 528b6435-799c-4a17-bb99-9678c1097f4e))
    (fp_line (start 43.36 -2.14) (end 43.36 0.5) (layer "F.SilkS") (width 0.12) (tstamp 61973fa9-ee52-45f3-abac-fe644270fe02))
    (fp_line (start 43.36 42.14) (end 40.1 42.14) (layer "F.SilkS") (width 0.12) (tstamp 6d1d1073-608d-468e-8f4f-0c548047a024))
    (fp_line (start -40.92 36.89) (end -39.1 36.89) (layer "F.SilkS") (width 0.12) (tstamp 721aeb90-210b-4362-95ca-b4359c6e8d59))
    (fp_line (start 43.36 39.11) (end 43.36 42.14) (layer "F.SilkS") (width 0.12) (tstamp 7503c2b7-bec0-42c5-a598-b33021b1641e))
    (fp_line (start -40.92 -2.14) (end -38.2 -2.14) (layer "F.SilkS") (width 0.12) (tstamp 7d8f8a89-90f7-4ff4-bc0c-9003beebd9fa))
    (fp_line (start -40.92 42.14) (end -40.92 39.11) (layer "F.SilkS") (width 0.12) (tstamp 8a0c8cae-0656-409a-a5fb-f347505dba48))
    (fp_line (start 40.132 -2.14) (end 43.36 -2.14) (layer "F.SilkS") (width 0.12) (tstamp a0693d01-f88b-4c93-b0f5-0ef80277dff6))
    (fp_line (start -37.8 42.2) (end -40.92 42.2) (layer "F.SilkS") (width 0.12) (tstamp beed3e90-6eec-48ab-8275-8982c1b4e642))
    (fp_line (start 43.36 36.89) (end 41.5 36.89) (layer "F.SilkS") (width 0.12) (tstamp db9f63c6-86cc-47fd-ab5c-7408841b93ec))
    (fp_arc (start 41.84 37.21) (mid 42.070574 38.233345) (end 41.51 39.12) (layer "F.SilkS") (width 0.12) (tstamp 472953dd-21e6-4011-b37e-498335b1780b))
    (fp_arc (start -39.39 38.82) (mid -39.644716 37.794939) (end -39.1 36.89) (layer "F.SilkS") (width 0.12) (tstamp 82cc78a4-afd2-4bad-a832-da2288529e17))
    (fp_arc (start 41.5 36.89) (mid 42.059361 37.759584) (end 41.84 38.77) (layer "F.SilkS") (width 0.12) (tstamp 8cd0f7e2-c9cb-4f24-b992-a6a319cbfdd6))
    (fp_arc (start -39.1 39.11) (mid -39.644716 38.205061) (end -39.39 37.18) (layer "F.SilkS") (width 0.12) (tstamp 9dd95203-58fa-4367-8b02-28c20368ac30))
    (fp_line (start 43.22 39.25) (end 43.22 42) (layer "F.Fab") (width 0.1) (tstamp 04e9801a-7291-41d5-a7d9-22c0e437a7a6))
    (fp_line (start 40.72 39.25) (end 43.22 39.25) (layer "F.Fab") (width 0.1) (tstamp 074302ff-05bb-4513-bf4d-df31baa3debf))
    (fp_line (start 43.22 -2) (end 43.22 36.75) (layer "F.Fab") (width 0.1) (tstamp 099922a6-a102-4dc1-9fc2-a50a2fb4a511))
    (fp_line (start -40.78 36.75) (end -40.78 -2) (layer "F.Fab") (width 0.1) (tstamp 219cfd2c-392b-4e62-b5b7-258372a0b16c))
    (fp_line (start -1 -2) (end 0 -1) (layer "F.Fab") (width 0.1) (tstamp 2aafc84e-ee8d-42b4-9fff-f98ad57c5bcb))
    (fp_line (start 0 -1) (end 1 -2) (layer "F.Fab") (width 0.1) (tstamp 2fa31e8d-7f7f-4336-ad8a-67b3f5442dc0))
    (fp_line (start -40.78 36.75) (end -38.28 36.75) (layer "F.Fab") (width 0.1) (tstamp 3035cff5-04f2-4340-86b9-302dee6247c9))
    (fp_line (start 1 -2) (end 43.22 -2) (layer "F.Fab") (width 0.1) (tstamp 688edabc-1912-4273-86d1-3ea63cd271c3))
    (fp_line (start -40.78 41.99) (end -40.78 39.25) (layer "F.Fab") (width 0.1) (tstamp 6fd1d3e8-ae9e-482a-8e1a-2d6a9c4b80dc))
    (fp_line (start -38.862 42) (end -40.78 42) (layer "F.Fab") (width 0.1) (tstamp 84d365fc-3709-46bd-a9c6-ff76b279e197))
    (fp_line (start -40.78 -2) (end -37.2 -2) (layer "F.Fab") (width 0.1) (tstamp d124e5cb-f632-4e40-aebe-b7839629238f))
    (fp_line (start -40.78 39.25) (end -38.28 39.25) (layer "F.Fab") (width 0.1) (tstamp d8983ba5-10f9-4981-aa42-190b7317b62f))
    (fp_line (start 43.22 36.75) (end 40.72 36.75) (layer "F.Fab") (width 0.1) (tstamp eeae584e-3c89-453b-8246-6da466a872a7))
    (fp_arc (start 39.47 37.99) (mid 39.843188 37.109045) (end 40.73 36.75) (layer "F.Fab") (width 0.1) (tstamp 34aa96e0-23ca-420a-851d-d0596a3dbbcf))
    (fp_arc (start 40.73 39.25) (mid 39.843188 38.890955) (end 39.47 38.01) (layer "F.Fab") (width 0.1) (tstamp 4974b203-8005-4376-a696-aded402f9af5))
    (fp_arc (start -38.28 36.76) (mid -37.403188 37.123188) (end -37.04 38) (layer "F.Fab") (width 0.1) (tstamp 7c830671-b097-4a2d-80e2-25e89cc89613))
    (fp_arc (start -37.04 38) (mid -37.403188 38.876812) (end -38.28 39.24) (layer "F.Fab") (width 0.1) (tstamp d9928855-a7f7-4a44-9716-a15128fde718))
    (pad "" np_thru_hole circle (at 40.72 38 90) (size 2.5 2.5) (drill 2.5) (layers F&B.Cu *.Mask)
      (clearance 1) (tstamp 0f1c0eca-87d4-4a89-9e40-33baa96205de))
    (pad "" np_thru_hole circle (at -36.78 2 90) (size 2.5 2.5) (drill 2.5) (layers F&B.Cu *.Mask)
      (clearance 1) (tstamp c54e5ca0-13d0-43d7-b8f1-dee0918dd6d9))
    (pad "" np_thru_hole circle (at -38.28 38 90) (size 2.5 2.5) (drill 2.5) (layers F&B.Cu *.Mask)
      (clearance 1) (tstamp d1e94416-6b30-4c15-8f23-7fd106f6ab29))
    (pad "" np_thru_hole circle (at 39.22 2 90) (size 2.5 2.5) (drill 2.5) (layers F&B.Cu *.Mask)
      (clearance 1) (tstamp f1387197-1fbf-4d17-aac5-acb526a3df23))
    (pad "1" thru_hole rect (at 0 0 90) (size 1.8 2.6) (drill 1.2) (layers *.Cu *.Mask)
      (net 1 "Net-(BT1-Pad2)") (pinfunction "VSS") (pintype "power_in") (tstamp adbf0728-9342-4006-9c8e-cb8d15cac3b4))
    (pad "2" thru_hole oval (at 2.54 0 90) (size 1.8 2.6) (drill 1.2) (layers *.Cu *.Mask)
      (net 85 "Net-(C20-Pad1)") (pinfunction "VDD") (pintype "power_in") (tstamp d0254a0d-3f8d-474d-9dc2-668567c3627b))
    (pad "3" thru_hole oval (at 5.08 0 90) (size 1.8 2.6) (drill 1.2) (layers *.Cu *.Mask)
      (net 114 "Net-(RV1-Pad2)") (pinfunction "VO") (pintype "power_in") (tstamp 82bd3a2f-2b1a-4b8d-a2ac-4341777f91b4))
    (pad "4" thru_hole oval (at 7.62 0 90) (size 1.8 2.6) (drill 1.2) (layers *.Cu *.Mask)
      (net 107 "Net-(R24-Pad2)") (pinfunction "RS") (pintype "input") (tstamp bb15ab0c-835b-49a8-81c5-f6b93e823c26))
    (pad "5" thru_hole oval (at 10.16 0 90) (size 1.8 2.6) (drill 1.2) (layers *.Cu *.Mask)
      (net 108 "Net-(R28-Pad2)") (pinfunction "R/W") (pintype "input") (tstamp 28803cdf-d03e-46f3-9e9b-3b96312a60e2))
    (pad "6" thru_hole oval (at 12.7 0 90) (size 1.8 2.6) (drill 1.2) (layers *.Cu *.Mask)
      (net 106 "Net-(R14-Pad2)") (pinfunction "E") (pintype "input") (tstamp 616d93d6-95e5-468b-ae5c-423715d5ffb6))
    (pad "7" thru_hole oval (at 15.24 0 90) (size 1.8 2.6) (drill 1.2) (layers *.Cu *.Mask)
      (net 115 "unconnected-(U5-Pad7)") (pinfunction "DB0") (pintype "bidirectional") (tstamp 2a76050b-b3c6-40d9-8073-a3c120efb9f9))
    (pad "8" thru_hole oval (at 17.78 0 90) (size 1.8 2.6) (drill 1.2) (layers *.Cu *.Mask)
      (net 116 "unconnected-(U5-Pad8)") (pinfunction "DB1") (pintype "bidirectional") (tstamp 9357ee24-6b87-45f7-b1de-aa7df63aba5e))
    (pad "9" thru_hole oval (at 20.32 0 90) (size 1.8 2.6) (drill 1.2) (layers *.Cu *.Mask)
      (net 117 "unconnected-(U5-Pad9)") (pinfunction "DB2") (pintype "bidirectional") (tstamp 982f5407-9145-429f-9690-f96987c4d88d))
    (pad "10" thru_hole oval (at 22.86 0 90) (size 1.8 2.6) (drill 1.2) (layers *.Cu *.Mask)
      (net 118 "unconnected-(U5-Pad10)") (pinfunction "DB3") (pintype "bidirectional") (tstamp b24bc206-4032-4af7-99dc-8b7c2c550b7b))
    (pad "11" thru_hole oval (at 25.4 0 90) (size 1.8 2.6) (drill 1.2) (layers *.Cu *.Mask)
      (net 109 "Net-(R31-Pad2)") (pinfunction "DB4") (pintype "bidirectional") (tstamp e14f967b-b611-41e6-be0e-bcca146f0cdb))
    (pad "12" thru_hole oval (at 27.94 0 90) (size 1.8 2.6) (drill 1.2) (layers *.Cu *.Mask)
      (net 110 "Net-(R34-Pad2)") (pinfunction "DB5") (pintype "bidirectional") (tstamp e7b9ce9c-54da-4604-af13-ac92da1447eb))
    (pad "13" thru_hole oval (at 30.48508 0.00254 90) (size 1.8 2.6) (drill 1.2) (layers *.Cu *.Mask)
      (net 111 "Net-(R38-Pad2)") (pinfunction "DB6") (pintype "bidirectional") (tstamp 51aa0124-e673-489a-a5b2-0a94a95049d1))
    (pad "14" thru_hole oval (at 33.02 0 90) (size 1.8 2.6) (drill 1.2) (layers *.Cu *.Mask)
      (net 112 "Net-(R41-Pad2)") (pinfunction "DB7") (pintype "bidirectional") (tstamp 30ecde39-3f84-46f2-a60f-eaa9281d8602))
    (pad "15" thru_hole oval (at -5.08 0 90) (size 1.8 2.6) (drill 1.2) (layers *.Cu *.Mask)
      (net 113 "Net-(R54-Pad1)") (pinfunction "A/VEE") (pintype "power_in") (tstamp a9f53d33-f425-4b0d-a2d8-ca42936825d4))
    (pad "16" thru_hole oval (at -2.53492 0.00254 90) (size 1.8 2.6) (drill 1.2) (layers *.Cu *.Mask)
      (net 1 "Net-(BT1-Pad2)") (pinfunction "K") (pintype "power_in") (tstamp cca964b4-8a4e-46a5-bcab-9fde62573996))
    (model "${KICAD6_3DMODEL_DIR}/Display.3dshapes/RC1602A.wrl"
      (offset (xyz 0 0 10))
      (scale (xyz 1 1 1))
  (footprint "Resistor_SMD:R_1210_3225Metric_Pad1.30x2.65mm_HandSolder" (layer "F.Cu")
    (tedit 5F68FEEE) (tstamp 61af6282-66ba-4715-93f2-a288123047da)
    (at 36.703 101.473 -90)
    (descr "Resistor SMD 1210 (3225 Metric), square (rectangular) end terminal, IPC_7351 nominal with elongated pad for handsoldering. (Body size source: IPC-SM-782 page 72, https://www.pcb-3d.com/wordpress/wp-content/uploads/ipc-sm-782a_amendment_1_and_2.pdf), generated with kicad-footprint-generator")
    (tags "resistor handsolder")
    (path "/6c7ca9cc-2a94-409e-81de-63b2e7b86022")
    (attr smd)
    (fp_text reference "R38" (at -3.175 -0.127 180) (layer "F.SilkS")
      (tstamp 941ea358-7ee9-443b-9dc9-764755427ded)
    (fp_text value "SMD 1/4W 1k" (at 0 2.28 90) (layer "F.Fab")
      (tstamp 2ecdb873-c233-4c60-baa4-391e3e81b6dd)
      (effects (font (size 0.8 0.8) (thickness 0.12)))
      (tstamp 599cc5e8-64fa-4a8a-a159-228d6f760584)
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 3d1e291a-6d96-4cd7-82bc-2b559ce3d8a5))
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp 6a94e984-77b3-4bdf-910c-c2fb94ab4e1a))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 5aa0ec3c-1225-46ff-9f04-ff877a80c833))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 650f5a76-8579-4ca9-a82f-3f07a3a7aecc))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp a05b9d9d-7074-43d3-b04d-01f8404f2492))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp cd16aea8-24e9-4720-8ebd-7a70ba60790b))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 153e784a-06ed-40f1-8f85-9c00407dc615))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 2de1c534-045d-4313-b143-78d59e02810a))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 83689090-89f9-484a-a032-075a3528b368))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp c36c54d3-72a6-4bee-9643-9edf5487019c))
    (pad "1" smd roundrect (at -1.55 0 270) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 68 "Net-(R38-Pad1)") (pintype "passive") (tstamp 3e89f865-7500-4081-a2c6-fb984164c170))
    (pad "2" smd roundrect (at 1.55 0 270) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 111 "Net-(R38-Pad2)") (pintype "passive") (tstamp fb0fdd70-1b47-480f-a2a4-310378be0a59))
    (model "${KICAD6_3DMODEL_DIR}/Resistor_SMD.3dshapes/R_1210_3225Metric.wrl"
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp 64c91446-ab60-473e-92c4-eb1bd4b12232)
    (at 74 25 -90)
    (path "/bd6bbb72-05d8-4306-b923-272c3baebbc8")
    (attr smd)
    (fp_text reference "R8" (at 0 2.413 -90) (layer "F.SilkS")
      (tstamp 934eb8e3-562a-45e7-bb91-d9c1648a526b)
    (fp_text value "SMD 1/4W 10k" (at 0 2.28 90) (layer "F.Fab")
      (tstamp 7dd1674c-2a9b-4fbd-ab59-365368c6bfac)
      (tstamp 1c1e2238-6c9a-4e31-99ee-80eba9c480f2)
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 75f83905-176b-4217-8bfd-035a0ca28961))
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp fe33658b-c4a0-45f6-a804-2d28f6a4dab3))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 16f3058a-2253-4485-bc63-e0fd75309ebf))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 6b9c24d5-d58d-4de0-ac8a-afb8d4cfa3b2))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp ba3766da-650c-4ad6-8161-ffc613872540))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp f06c3626-3dda-4159-b4b3-354bcc523db4))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 1495e47b-3515-4d16-b60e-bdd78f0aa19a))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 84823ee3-e782-43ef-8bba-4ac511c7740f))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp acf61351-8a02-45d9-a188-f25a8316c781))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp dff022fe-96ba-4e13-a40c-1c0328ca961c))
      (net 19 "Net-(D5-Pad2)") (pintype "passive") (tstamp 6b697ba1-3beb-4a9a-8d97-07e875d3e263))
      (net 46 "Net-(R8-Pad2)") (pintype "passive") (tstamp faea2c5c-78dd-469f-a564-6547d0c991eb))
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp 669c3ec4-6d2a-41a0-9d6b-e3831dbbcb25)
    (at 45.339 80.518)
    (path "/365aaf99-d385-4b46-bd8d-06a15a5c560d")
    (attr smd)
    (fp_text reference "R44" (at 1.397 2.286 180) (layer "F.SilkS")
      (tstamp 82766ba0-7baa-4d0b-8cff-98088073e83c)
    (fp_text value "SMD 1/4W 1k" (at 0 2.28) (layer "F.Fab")
      (tstamp fa0ef4c7-121c-4423-9591-94cbf8d558c3)
      (tstamp 85ad0d73-9e4b-437e-b6d1-03d431089ed0)
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp 28268565-9e59-4e36-907f-91f0f932b54c))
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 2c2962c0-b942-4f91-b883-1f1768471b04))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 049f918e-ea61-45fd-833e-f07dbb3fb875))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 36a2d94d-9f34-47e7-8662-67592bf7b2bf))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 7065b1c1-2931-4e25-a178-92a73a5dc07e))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 9052b9cb-a2ff-46a0-ba89-ba996ccbfc78))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 394e930f-2bd6-4ff1-ba6a-b39322588545))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp b4e4399a-c1c8-45fa-be93-c8fa65e36f4e))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp c4265386-ae09-4f28-b6f0-761008a7cbd3))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp fe8234f8-8cf9-42f9-a385-ed1fa639639b))
      (net 73 "Net-(R44-Pad1)") (pintype "passive") (tstamp 20c51d6b-bff6-4a1b-9d60-a348db94afb3))
      (net 32 "Net-(J14-Pad17)") (pintype "passive") (tstamp 7215d6c3-3270-417b-a567-245ce8343219))
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp 679ff509-7f5a-438d-96e1-4a41746abe00)
    (at 42.056 107.931 -90)
    (path "/0e14fa1a-f229-4c39-8532-aafea11c8a56")
    (attr smd)
    (fp_text reference "R42" (at 4.083 0.146 90) (layer "F.SilkS")
      (tstamp da98d2ed-bee3-4265-aa0f-b1ecd4f6e57c)
      (tstamp 6ad5cc7d-4a86-43a8-a47f-70a5ce2b4ade)
      (tstamp 90a15a1b-a2d6-4abd-bf51-53654bea679b)
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 25ce0ae8-0fae-4636-b5a0-d89989aaa73b))
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp c7b832fc-53f4-4b63-9405-416d53700fe2))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 085f0669-81f8-4047-adfa-dfdea3f38817))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 11077f30-e8f8-4ff8-b7a6-a2fbc31cfbfa))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 21900e7d-a52c-4d00-b93a-f412d9a4dae6))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp d4db1427-6e49-452a-b918-1b6232979178))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 51636994-e181-4cb5-8769-8ed400f7c28e))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 7fc4a8b0-098f-47be-bf86-71e461606a77))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 82d983e8-94da-4a0f-8985-4a702cd53641))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 8c47dba8-117f-450f-87d2-90270fe062f0))
      (net 71 "Net-(R42-Pad1)") (pintype "passive") (tstamp 79bc7368-d8ee-46ae-ae6b-80077670f1f4))
      (net 90 "Net-(J12-Pad1)") (pintype "passive") (tstamp 85edf545-0ceb-41d5-8a99-65b6cfb0e0ba))
      (scale (xyz 1 1 1))
    (tedit 5D160D14) (tstamp 68e5689c-5d00-4949-82bc-9d233d28e58d)
    (at 117.829 143.59)
    (path "/c6413b4c-74bc-4536-bd3f-e5b34e044e62")
    (attr through_hole)
    (fp_text reference "SW5" (at -1.751 2.714) (layer "F.SilkS")
      (tstamp e3c22713-d94f-4a88-8394-96299a682f1b)
    (fp_text value "Links" (at 6.62 9.93) (layer "F.Fab")
      (tstamp 602fa266-d277-45bd-abba-56085544f142)
      (tstamp 00c110af-700a-4756-9392-0e0732e1040f)
    (fp_line (start 0.1 3.8) (end 0.1 1.3) (layer "F.SilkS") (width 0.12) (tstamp 0fcb43bb-938b-4052-8def-657d04ff7ef3))
    (fp_line (start 0.1 8.65) (end 0.1 6.2) (layer "F.SilkS") (width 0.12) (tstamp 121c8b6c-cc18-4021-a30d-68060d9ade29))
    (fp_line (start 0.1 -3.65) (end 12.4 -3.65) (layer "F.SilkS") (width 0.12) (tstamp 3ebb1cf2-05fe-4504-bddf-7eb3e278fb0c))
    (fp_line (start 12.4 -3.65) (end 12.4 -1.1) (layer "F.SilkS") (width 0.12) (tstamp 4325e4ce-fea4-4f5d-89c8-33360cfd368d))
    (fp_line (start 0.1 -1.1) (end 0.1 -3.65) (layer "F.SilkS") (width 0.12) (tstamp 4887e531-7459-4d8d-a939-d56a9ffc874f))
    (fp_line (start 12.4 1.1) (end 12.4 3.8) (layer "F.SilkS") (width 0.12) (tstamp 7b0b0967-c529-4dae-80af-0d8f6bb9c26a))
    (fp_line (start 12.4 6.2) (end 12.4 8.65) (layer "F.SilkS") (width 0.12) (tstamp 7c26a80e-1493-4347-804c-6996642c9501))
    (fp_line (start 12.4 8.65) (end 0.1 8.65) (layer "F.SilkS") (width 0.12) (tstamp 83ef5113-74e9-4fb5-8cdb-a86229408274))
    (fp_circle (center 6.35 2.54) (end 10.16 5.08) (layer "F.SilkS") (width 0.12) (fill none) (tstamp bbce9372-13d2-42aa-bed2-be3e486af6c1))
    (fp_line (start -1.77 -3.75) (end 14.25 -3.75) (layer "F.CrtYd") (width 0.05) (tstamp 4239616b-e48a-46ad-aa15-ec3c541b9002))
    (fp_line (start -1.77 -3.75) (end -1.77 8.75) (layer "F.CrtYd") (width 0.05) (tstamp ad823efa-a36e-449d-9228-1fc10bcef2eb))
    (fp_line (start 14.25 8.75) (end 14.25 -3.75) (layer "F.CrtYd") (width 0.05) (tstamp b2df8fe5-5c35-4893-80b8-6d1275a020e1))
    (fp_line (start 14.25 8.75) (end -1.77 8.75) (layer "F.CrtYd") (width 0.05) (tstamp e9815f39-4fed-4bf2-8ff8-ff53d1614594))
    (fp_line (start 0.25 -3.5) (end 0.25 8.5) (layer "F.Fab") (width 0.1) (tstamp 98037b96-2a9d-4a52-ba1c-8532b96c989f))
    (fp_line (start 12.25 -3.5) (end 12.25 8.5) (layer "F.Fab") (width 0.1) (tstamp cd69e93e-1db1-4071-911f-cc25bf7c3770))
    (fp_line (start 0.25 8.5) (end 12.25 8.5) (layer "F.Fab") (width 0.1) (tstamp d697145d-9678-4547-be3c-b3bb27467588))
    (fp_line (start 0.25 -3.5) (end 12.25 -3.5) (layer "F.Fab") (width 0.1) (tstamp e91580c6-b165-4fb2-8b63-e26040555c0c))
      (net 126 "Net-(J13-Pad5)") (pinfunction "A") (pintype "passive") (tstamp 1e109b74-d891-4632-be2e-b0f9e29fd3bc))
      (net 126 "Net-(J13-Pad5)") (pinfunction "A") (pintype "passive") (tstamp 51341a07-5dcd-4b1e-a728-4ba8c36c25b6))
      (net 129 "Net-(J13-Pad2)") (pinfunction "B") (pintype "passive") (tstamp eab7c7a3-aeba-4b9f-93ff-173548183d7a))
      (net 129 "Net-(J13-Pad2)") (pinfunction "B") (pintype "passive") (tstamp 9614b039-9279-4820-ac8d-12142b6cf7ed))
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp 690b2ce8-b9af-4516-a4e6-0da3244e62dd)
    (at 59.563 96.901 90)
    (path "/2152830a-88c5-49ec-95f7-15de5cf37f24")
    (attr smd)
    (fp_text reference "R54" (at 0.254 -2.286 90) (layer "F.SilkS")
      (tstamp eae0a06c-cdd5-4de0-b947-72b673c52c7f)
    (fp_text value "SMD 1/4W 6R3" (at 0 2.28 90) (layer "F.Fab")
      (tstamp 270e96af-99aa-4b50-bd91-c5b1fa1120c4)
    (fp_text user "${REFERENCE}" (at 0 0 90) (layer "F.Fab")
      (tstamp cc411b4d-ecdf-4706-abcb-8223784b0c19)
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp 81db707c-2d55-4995-8585-4d1c7f7e9829))
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp b3932543-cb8e-4a6e-9707-871f68f52a22))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 25d2a37a-7e52-44e0-8848-4d01e612f8ae))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 433b33eb-e5a6-4130-ba4f-8771ceb82a65))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 479458e6-de73-4334-a904-212105a8c30c))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp a736343b-3947-484d-8719-51b88552daa5))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 3cdb80cb-b652-43ca-98aa-aaae7443da89))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 65a99ce1-c050-446c-9352-485095fb8457))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 9fc630f5-3880-4902-af9b-8d32011e0dc1))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp e680b752-4c6d-4d80-a9d4-d5685ea7188f))
    (pad "1" smd roundrect (at -1.55 0 90) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 113 "Net-(R54-Pad1)") (pintype "passive") (tstamp b16a66dc-028f-40c8-b705-9b8e6b4c381c))
    (pad "2" smd roundrect (at 1.55 0 90) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 89 "Net-(R53-Pad1)") (pintype "passive") (tstamp 9045b5c8-8d30-4424-be9e-dc9c17776d2c))
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp 69b322a9-2f97-42d6-9c8e-5dddecad7ad8)
    (at 49.149 96.52)
    (path "/4eaa8447-ef38-4b0f-a3f4-135e48b5ec31")
    (attr smd)
    (fp_text reference "R32" (at -0.381 -2.28) (layer "F.SilkS")
      (tstamp 3e920f2b-4b5d-4392-b407-e8ad37aca662)
      (tstamp be15a029-0797-473d-9482-3e6a3d4a866c)
      (tstamp ebe4a7bb-61f9-46ca-916f-321b476de5e3)
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp 1be53e7e-80bf-4a4e-8ee8-28b512684fe0))
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp ea0d007a-6cae-4621-9626-35a072a16f35))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 0e32887c-b68a-4e7a-b98a-069b8529a740))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 2d74f4b5-ebb4-4e3c-8661-e69e79de9c0d))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 381fc966-4143-4c67-b95d-1a4f21aba6d4))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp f1f0a418-1cf3-4241-8ff1-11df8e3d1c97))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 5c3162f6-2e3b-4a3e-a9e9-611ee56503b1))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 61a52fb8-0c7e-420b-90d9-55bbc7c3ca12))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp a9742d82-751a-4738-b06b-ebc74a431dfb))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp c76ad3cd-d0de-47d9-9d7f-62c78934fc61))
      (net 63 "Net-(R32-Pad1)") (pintype "passive") (tstamp c9767027-45d8-426b-9ab7-9a259f2275a9))
      (net 93 "Net-(J12-Pad4)") (pintype "passive") (tstamp 84ec96f4-133e-4958-b977-8a8d5d6c8cae))
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp 6a836606-7019-4644-8dc7-8cd3de90c14b)
    (at 44.069 75.692 90)
    (path "/b85c6deb-38c3-4edc-a92c-e9c6ef2221a4")
    (attr smd)
    (fp_text reference "R45" (at 0 2.413 90) (layer "F.SilkS")
      (tstamp 6f5803c3-1870-452d-b2f8-d6d7502ecab0)
      (tstamp e5ee9b92-1298-46d7-a1ce-d0d0f38e1c83)
      (tstamp b3620c53-7bb3-44f2-99d6-0969d10bf092)
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp 7e98f8d9-6ab2-4b1b-adf9-fedfad1d0ee4))
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp c70296b2-8e74-46cc-9b41-280ac1748399))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 4431ddff-dfe5-45e1-a5ed-041504a89f7d))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 5aa268ab-7f1a-4f64-b920-02abc57783d5))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 9b8b86f0-1e19-4621-8569-f96ba1c80298))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp f0447478-1f6f-4f6b-9ab0-a81ced248e1f))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 05a88603-9386-48cb-955e-1576334e8451))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 8af5b06c-49db-4718-9add-fdf68d51711f))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp f519c6ea-52fa-4af9-a6c9-ac2ce3ef1bd0))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp fb5d6dc0-263f-406c-87b2-ef8c1b5d46a3))
      (net 74 "Net-(R45-Pad1)") (pintype "passive") (tstamp f02a1e2b-fe0c-4ac8-b525-d8b8b0ca8493))
      (net 30 "Net-(J14-Pad15)") (pintype "passive") (tstamp c58f4dec-6b6a-4308-a5cf-9cc1aa0f5a6e))
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp 6adb5ee5-bfb3-430e-a31e-85999e9c74eb)
    (at 57.404 78.994 180)
    (path "/6e395f74-1fc5-4252-a693-9cdbd1ff2064")
    (attr smd)
    (fp_text reference "R27" (at -0.0508 2.2352 180) (layer "F.SilkS")
      (tstamp f648c384-c38a-4da2-b743-1f7efacf9b08)
      (tstamp f9f72d10-c113-4455-8875-d4977fbc6e07)
      (tstamp fc8182e0-2dad-4d5b-a36c-7061feb606c7)
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 17593101-9579-4f09-9ed8-93bbfdd87ff7))
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp cfa6eda2-5a05-4e7c-a777-debaa8d32546))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 45065309-1cd4-47d8-8b12-bb6f73e969c0))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp b0ce7330-5ce9-4ade-ae4c-08c0899bd513))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp d1ea0025-e02e-48f5-a164-abfcefa9478b))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp e89ea77c-6bf6-47d3-8fbd-488272dd3245))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 5c5b67ea-bb7b-4141-a2e1-eeb792f1295a))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 9eaacbe1-5b82-4e91-bad2-bcd87f72beb3))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp c081bc3a-9f7f-43df-b4a8-47e80edb5af5))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp cdb3b09f-6061-4d9b-9e97-0a64e1b9cdbb))
    (pad "1" smd roundrect (at -1.55 0 180) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 57 "Net-(R27-Pad1)") (pintype "passive") (tstamp 34681277-0cf3-4eea-a2e6-b8ecd5398156))
    (pad "2" smd roundrect (at 1.55 0 180) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 58 "Net-(R27-Pad2)") (pintype "passive") (tstamp 5321cea4-4d98-4248-83e3-bb3b6049f623))
      (scale (xyz 1 1 1))
  (footprint "Capacitor_THT:CP_Radial_D12.5mm_P5.00mm" (layer "F.Cu")
    (tedit 5AE50EF1) (tstamp 6b279a03-9fba-4759-9d19-5b5df547d4f4)
    (at 150.241 59.219959 90)
    (descr "CP, Radial series, Radial, pin pitch=5.00mm, , diameter=12.5mm, Electrolytic Capacitor")
    (tags "CP Radial series Radial pin pitch 5.00mm  diameter 12.5mm Electrolytic Capacitor")
    (path "/f1d980f6-39cf-402c-ad9f-5a5434d043e1")
    (attr through_hole)
    (fp_text reference "C17" (at 2.5 -7.5 90) (layer "F.SilkS")
      (tstamp a2b365a5-d297-4459-86ef-1c068eb3e12d)
    (fp_text value "ELKO 680/35 RAD FC 680/35" (at 2.5 7.5 90) (layer "F.Fab")
      (tstamp c220a662-1f6e-48f1-8e42-2311e0b969ab)
    (fp_text user "${REFERENCE}" (at 2.5 0 90) (layer "F.Fab")
      (tstamp 881cd6e4-14b0-4649-8cee-2a06f2e29571)
    (fp_line (start 2.9 -6.318) (end 2.9 6.318) (layer "F.SilkS") (width 0.12) (tstamp 01813a67-67d3-4c9a-bb8d-9b7a07ce7aa6))
    (fp_line (start 6.101 1.44) (end 6.101 5.216) (layer "F.SilkS") (width 0.12) (tstamp 020a059a-d42d-41a9-a56b-9daf26d77071))
    (fp_line (start 3.741 -6.209) (end 3.741 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 028acbf0-ad95-482a-abee-ef02de106b9b))
    (fp_line (start 4.381 1.44) (end 4.381 6.047) (layer "F.SilkS") (width 0.12) (tstamp 0521b2d0-0cf1-4f5c-898a-d38c1bb7e883))
    (fp_line (start 3.18 -6.294) (end 3.18 6.294) (layer "F.SilkS") (width 0.12) (tstamp 055c8400-2f39-4746-91f4-bd6c6d2bb794))
    (fp_line (start 5.981 -5.296) (end 5.981 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 061c203a-cb43-4de3-a40a-1f205054bbaa))
    (fp_line (start 5.461 -5.601) (end 5.461 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 06da0ac0-4dd6-4795-9935-f43f8dc9c231))
    (fp_line (start 4.061 -6.137) (end 4.061 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 0af33448-7821-44a6-a1e7-e4ca43280307))
    (fp_line (start 8.141 -2.921) (end 8.141 2.921) (layer "F.SilkS") (width 0.12) (tstamp 0c409433-e4c0-453b-afe7-a61441d7d8f3))
    (fp_line (start 7.501 -3.907) (end 7.501 3.907) (layer "F.SilkS") (width 0.12) (tstamp 0d6c6ef6-b164-43bd-ba2a-3e5eba2de922))
    (fp_line (start 4.261 1.44) (end 4.261 6.083) (layer "F.SilkS") (width 0.12) (tstamp 0e41e2d4-08ce-44c2-bcb2-073a8df1a8c9))
    (fp_line (start 5.101 1.44) (end 5.101 5.776) (layer "F.SilkS") (width 0.12) (tstamp 0e5353e2-9402-49e8-a40d-5368841fd74b))
    (fp_line (start 5.301 -5.682) (end 5.301 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 0e553a0f-d2c1-41b6-aeb5-5b4426408905))
    (fp_line (start 7.541 -3.856) (end 7.541 3.856) (layer "F.SilkS") (width 0.12) (tstamp 0fc34cda-5210-461f-99d7-426e6382b2d0))
    (fp_line (start 6.701 -4.75) (end 6.701 4.75) (layer "F.SilkS") (width 0.12) (tstamp 103cfe69-ba24-4eb1-8445-7299bfb2fdf4))
    (fp_line (start 3.781 1.44) (end 3.781 6.201) (layer "F.SilkS") (width 0.12) (tstamp 107c701e-3c60-4b3f-a082-755686078ad6))
    (fp_line (start 4.141 -6.116) (end 4.141 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 1086f934-3731-4a18-ab91-b36bfa7997f0))
    (fp_line (start 8.101 -2.996) (end 8.101 2.996) (layer "F.SilkS") (width 0.12) (tstamp 10d44f4b-8d70-4e47-b380-e1689c8bf8a5))
    (fp_line (start 3.301 -6.28) (end 3.301 6.28) (layer "F.SilkS") (width 0.12) (tstamp 10ee3f44-a5c8-4456-b6fa-8e0820266e42))
    (fp_line (start 5.581 1.44) (end 5.581 5.536) (layer "F.SilkS") (width 0.12) (tstamp 11a2c3be-b14d-4402-9a21-27341cb1d274))
    (fp_line (start 6.261 -5.102) (end 6.261 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 13187c61-c909-40c8-adfc-78cc47f30f25))
    (fp_line (start 5.421 -5.622) (end 5.421 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 141258aa-05a4-4cce-bbe8-8ee66f52da07))
    (fp_line (start 7.421 -4.007) (end 7.421 4.007) (layer "F.SilkS") (width 0.12) (tstamp 1422b96a-abfb-4d94-808a-cc1b579fdf44))
    (fp_line (start 3.861 -6.184) (end 3.861 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 15f964bf-7f66-4c3b-9540-66ea11fb15c7))
    (fp_line (start 7.861 -3.402) (end 7.861 3.402) (layer "F.SilkS") (width 0.12) (tstamp 177fe93f-0a0a-4b0d-8e6e-e6267d7868b2))
    (fp_line (start 7.661 -3.696) (end 7.661 3.696) (layer "F.SilkS") (width 0.12) (tstamp 17db1200-b90f-4c0b-be7b-cc2ee3ba4ce4))
    (fp_line (start 7.781 -3.524) (end 7.781 3.524) (layer "F.SilkS") (width 0.12) (tstamp 1a4408b6-e085-48ba-84ca-5de5e64661c4))
    (fp_line (start 3.621 -6.231) (end 3.621 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 1d0ef9b7-9d2e-465c-8ef1-5c20ed2a2597))
    (fp_line (start 7.381 -4.055) (end 7.381 4.055) (layer "F.SilkS") (width 0.12) (tstamp 1d163cc5-9039-4eab-9b61-076761499153))
    (fp_line (start 5.861 -5.372) (end 5.861 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 1d955a13-0ecb-4a03-b60c-f245fc13521d))
    (fp_line (start 5.901 -5.347) (end 5.901 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 1e0ef760-e7b3-4d5e-be5a-c7b769838765))
    (fp_line (start 4.781 1.44) (end 4.781 5.908) (layer "F.SilkS") (width 0.12) (tstamp 1e11699d-0e80-4b46-9dcd-9838eb9fa3dc))
    (fp_line (start 3.261 -6.285) (end 3.261 6.285) (layer "F.SilkS") (width 0.12) (tstamp 1f7c1542-e63a-4ab7-8a39-3c1d6ac089ef))
    (fp_line (start 4.341 -6.059) (end 4.341 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 204e7446-33a0-4a01-aefd-2d68ce67f593))
    (fp_line (start 8.861 -0.317) (end 8.861 0.317) (layer "F.SilkS") (width 0.12) (tstamp 20f0529f-c90f-43fc-b305-34da12a3ca1c))
    (fp_line (start 5.021 1.44) (end 5.021 5.811) (layer "F.SilkS") (width 0.12) (tstamp 2125ba70-f119-4b15-85f0-1c622e3f1592))
    (fp_line (start 6.021 -5.27) (end 6.021 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 21a61188-8c99-44ca-9ef5-2c69160d303d))
    (fp_line (start 4.221 -6.094) (end 4.221 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 2387af45-6c77-49e5-91a3-dc73c78f795e))
    (fp_line (start 2.94 -6.315) (end 2.94 6.315) (layer "F.SilkS") (width 0.12) (tstamp 242bb618-1ce7-48e1-8998-5559b0aa6004))
    (fp_line (start 4.261 -6.083) (end 4.261 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 25620aa6-d666-41ef-8ce7-7bc3d3a8ae13))
    (fp_line (start 4.981 1.44) (end 4.981 5.828) (layer "F.SilkS") (width 0.12) (tstamp 27410bb8-6dbb-4fa3-aef2-4632fa888230))
    (fp_line (start 3.821 1.44) (end 3.821 6.192) (layer "F.SilkS") (width 0.12) (tstamp 29693f1e-25d1-4e13-88eb-003383aa582f))
    (fp_line (start 5.981 1.44) (end 5.981 5.296) (layer "F.SilkS") (width 0.12) (tstamp 2a23f910-0600-40a5-ac3e-9bcd32791aa3))
    (fp_line (start 6.821 -4.642) (end 6.821 4.642) (layer "F.SilkS") (width 0.12) (tstamp 2b79a93a-750b-4172-a00f-af53561e468b))
    (fp_line (start 8.501 -2.1) (end 8.501 2.1) (layer "F.SilkS") (width 0.12) (tstamp 2c630eb8-6433-45ff-bcf1-bd1ca3837d9e))
    (fp_line (start 6.141 1.44) (end 6.141 5.188) (layer "F.SilkS") (width 0.12) (tstamp 2f014d6f-5b7c-43cc-a183-d893eb096839))
    (fp_line (start 4.061 1.44) (end 4.061 6.137) (layer "F.SilkS") (width 0.12) (tstamp 2f5bc2c0-cd4a-4e71-ac20-5e8dd3666407))
    (fp_line (start 3.861 1.44) (end 3.861 6.184) (layer "F.SilkS") (width 0.12) (tstamp 3203e54b-9012-445c-8b3f-0ac65f6ab013))
    (fp_line (start 5.021 -5.811) (end 5.021 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 324c3eea-c3d0-4419-b87f-368d1b1d4856))
    (fp_line (start 3.701 1.44) (end 3.701 6.216) (layer "F.SilkS") (width 0.12) (tstamp 3293cf42-29a3-47a7-afff-30f9974bea32))
    (fp_line (start 5.301 1.44) (end 5.301 5.682) (layer "F.SilkS") (width 0.12) (tstamp 35fe3611-80ac-482f-a8b7-92e9d499a05a))
    (fp_line (start 7.301 -4.148) (end 7.301 4.148) (layer "F.SilkS") (width 0.12) (tstamp 376ad8d7-ac51-41e8-a63a-fa7736a1c108))
    (fp_line (start 5.941 -5.322) (end 5.941 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 380e0881-fbd4-493c-8901-b72a609faa57))
    (fp_line (start 7.821 -3.464) (end 7.821 3.464) (layer "F.SilkS") (width 0.12) (tstamp 3887af0d-51c9-484b-9718-a34a21b69035))
    (fp_line (start 3.581 -6.238) (end 3.581 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 389a7ffc-447a-40d3-9b18-3889b44c30d2))
    (fp_line (start 4.941 -5.845) (end 4.941 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 3ad48d0e-224e-4322-acbb-4b9b2fa60a7c))
    (fp_line (start 6.141 -5.188) (end 6.141 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 3d5a7614-0e01-454a-be82-1079c3ad4653))
    (fp_line (start 7.261 -4.194) (end 7.261 4.194) (layer "F.SilkS") (width 0.12) (tstamp 3e788b1f-6f0e-4a5d-937d-8f824ff73e0a))
    (fp_line (start 3.781 -6.201) (end 3.781 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 3ea89c77-9e01-43d5-8953-6ebac6d68940))
    (fp_line (start 6.181 1.44) (end 6.181 5.16) (layer "F.SilkS") (width 0.12) (tstamp 3f217763-3075-4f19-8576-469ae7e67e98))
    (fp_line (start 2.74 -6.326) (end 2.74 6.326) (layer "F.SilkS") (width 0.12) (tstamp 415f700d-1a0f-411a-958f-d1f9c750ea83))
    (fp_line (start 4.501 1.44) (end 4.501 6.008) (layer "F.SilkS") (width 0.12) (tstamp 4344a53c-fd4e-4952-9086-7940fafec4ee))
    (fp_line (start 4.101 -6.126) (end 4.101 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 44c69e26-787b-47b4-a140-61394d7bb34b))
    (fp_line (start 5.821 1.44) (end 5.821 5.397) (layer "F.SilkS") (width 0.12) (tstamp 44f95d69-c5e3-4816-8185-2292c6fc645f))
    (fp_line (start 8.741 -1.241) (end 8.741 1.241) (layer "F.SilkS") (width 0.12) (tstamp 47690f1a-d6e1-4781-bcc3-0f161c5305d2))
    (fp_line (start 7.141 -4.325) (end 7.141 4.325) (layer "F.SilkS") (width 0.12) (tstamp 47ad1bf8-ed04-48b3-b94b-e700a98d4447))
    (fp_line (start 8.821 -0.757) (end 8.821 0.757) (layer "F.SilkS") (width 0.12) (tstamp 47b3ed8c-b346-4cb4-93e0-1b0ed9007e3d))
    (fp_line (start 8.301 -2.594) (end 8.301 2.594) (layer "F.SilkS") (width 0.12) (tstamp 49eb6c13-b7a9-4469-92b2-33811b2a5fd3))
    (fp_line (start 5.061 -5.793) (end 5.061 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 4ac34083-d18d-4d16-9273-5fdf6a27ed9d))
    (fp_line (start 5.861 1.44) (end 5.861 5.372) (layer "F.SilkS") (width 0.12) (tstamp 4b285823-e10b-48bf-9814-422f1d83c237))
    (fp_line (start 4.021 -6.146) (end 4.021 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 4cbc134f-962c-4ce7-84d6-d64d4ea4021f))
    (fp_line (start 7.221 -4.238) (end 7.221 4.238) (layer "F.SilkS") (width 0.12) (tstamp 4e8c0623-8c70-4bf9-9c70-73085f964b50))
    (fp_line (start 7.101 -4.367) (end 7.101 4.367) (layer "F.SilkS") (width 0.12) (tstamp 4f7cd757-720c-4cd3-9506-27fb58149527))
    (fp_line (start 8.221 -2.764) (end 8.221 2.764) (layer "F.SilkS") (width 0.12) (tstamp 50318486-394a-4928-a33b-511f3d6362bd))
    (fp_line (start 7.741 -3.583) (end 7.741 3.583) (layer "F.SilkS") (width 0.12) (tstamp 50ecd34c-51a0-4f1e-aec8-90303049e5b4))
    (fp_line (start 8.461 -2.209) (end 8.461 2.209) (layer "F.SilkS") (width 0.12) (tstamp 51a4287c-fffa-4b71-a59b-31cacc2eea99))
    (fp_line (start 6.421 1.44) (end 6.421 4.982) (layer "F.SilkS") (width 0.12) (tstamp 51e92192-9e7e-4e79-ba78-6b52838b11f1))
    (fp_line (start 4.741 -5.924) (end 4.741 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 527d100e-47b4-4317-8acf-072755ee42e5))
    (fp_line (start -3.692082 -4.2) (end -3.692082 -2.95) (layer "F.SilkS") (width 0.12) (tstamp 542c2dfc-6d88-4258-86c2-f41e2f3575a3))
    (fp_line (start 2.5 -6.33) (end 2.5 6.33) (layer "F.SilkS") (width 0.12) (tstamp 543cdc1f-083e-4f7a-9dad-2c59334de3c7))
    (fp_line (start 6.381 -5.012) (end 6.381 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 56cd7e62-7525-47c7-9a1e-17281e801b0f))
    (fp_line (start 6.341 1.44) (end 6.341 5.043) (layer "F.SilkS") (width 0.12) (tstamp 57a6f860-4f77-4055-b764-90c53033bb31))
    (fp_line (start 8.581 -1.861) (end 8.581 1.861) (layer "F.SilkS") (width 0.12) (tstamp 580ff536-d826-4a5a-a2ae-f0032430ac4c))
    (fp_line (start 4.461 -6.021) (end 4.461 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 58e3d8b6-2bf1-4b5e-8565-cbf0ce003a81))
    (fp_line (start 2.58 -6.33) (end 2.58 6.33) (layer "F.SilkS") (width 0.12) (tstamp 59f94960-bafa-461b-a1c3-a3a0fda8ea0d))
    (fp_line (start 4.421 1.44) (end 4.421 6.034) (layer "F.SilkS") (width 0.12) (tstamp 5a8587e9-4107-4827-abc5-e781f8ad280c))
    (fp_line (start 6.381 1.44) (end 6.381 5.012) (layer "F.SilkS") (width 0.12) (tstamp 5b34dcc0-c6d7-4ee7-91ca-dcf02f015294))
    (fp_line (start 5.821 -5.397) (end 5.821 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 5be42ecb-e68e-412f-b805-f080d6354589))
    (fp_line (start 5.061 1.44) (end 5.061 5.793) (layer "F.SilkS") (width 0.12) (tstamp 61b4bfac-7784-4a92-8610-9738dfa6bd07))
    (fp_line (start 5.501 -5.58) (end 5.501 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 63dc550c-d3a8-4bc5-ad37-b1aa2f42a5ad))
    (fp_line (start 8.541 -1.984) (end 8.541 1.984) (layer "F.SilkS") (width 0.12) (tstamp 6420e119-8a14-4ef7-b497-0cd269769ef6))
    (fp_line (start 3.981 1.44) (end 3.981 6.156) (layer "F.SilkS") (width 0.12) (tstamp 690bbee4-e3d2-400c-9a53-680dfe67ee46))
    (fp_line (start 6.101 -5.216) (end 6.101 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 6a911755-11f9-4c66-8857-d4b5d5caa7f3))
    (fp_line (start 4.341 1.44) (end 4.341 6.059) (layer "F.SilkS") (width 0.12) (tstamp 6ac4d6f0-dd57-4a0a-af5a-dc0beae5b9f9))
    (fp_line (start 5.261 -5.702) (end 5.261 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 6bbfaa6e-e2e0-43c1-b753-8d8e380bfc93))
    (fp_line (start 6.461 -4.95) (end 6.461 4.95) (layer "F.SilkS") (width 0.12) (tstamp 6cbcecee-6e2c-431c-a8f1-c01ec85f00ce))
    (fp_line (start 3.14 -6.298) (end 3.14 6.298) (layer "F.SilkS") (width 0.12) (tstamp 6e13c619-99b6-427e-89b2-910ed5a81bac))
    (fp_line (start 8.181 -2.844) (end 8.181 2.844) (layer "F.SilkS") (width 0.12) (tstamp 6e31d30b-766a-4e40-bc83-7f5e50ac4d4c))
    (fp_line (start 5.941 1.44) (end 5.941 5.322) (layer "F.SilkS") (width 0.12) (tstamp 6e3e625c-33bd-4fb4-8665-83f9181f32eb))
    (fp_line (start 5.501 1.44) (end 5.501 5.58) (layer "F.SilkS") (width 0.12) (tstamp 6f168e10-70c8-46a6-9049-b160d8353707))
    (fp_line (start 2.98 -6.312) (end 2.98 6.312) (layer "F.SilkS") (width 0.12) (tstamp 6f59d92c-2915-4b47-9dcd-ddb51434f1e4))
    (fp_line (start 7.621 -3.75) (end 7.621 3.75) (layer "F.SilkS") (width 0.12) (tstamp 6fae5db8-a098-4349-9394-a1c55a7c6f81))
    (fp_line (start 4.901 -5.861) (end 4.901 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 70e993e6-6e56-4a36-a3cf-6d4052d39ceb))
    (fp_line (start 8.021 -3.14) (end 8.021 3.14) (layer "F.SilkS") (width 0.12) (tstamp 724c66fa-e0fc-4cba-acaa-86d223ea1e59))
    (fp_line (start 5.341 1.44) (end 5.341 5.662) (layer "F.SilkS") (width 0.12) (tstamp 7400eab8-a00d-4d4e-8ecd-c349916f5864))
    (fp_line (start 4.741 1.44) (end 4.741 5.924) (layer "F.SilkS") (width 0.12) (tstamp 745b4671-d70a-4805-9cca-e1aa1662f3d8))
    (fp_line (start 5.581 -5.536) (end 5.581 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 74a0a640-0a8f-46c4-9c16-04fd4ae5b35e))
    (fp_line (start 4.541 1.44) (end 4.541 5.995) (layer "F.SilkS") (width 0.12) (tstamp 74cedd7a-5032-4759-bbf9-7f291659f7b9))
    (fp_line (start 4.181 1.44) (end 4.181 6.105) (layer "F.SilkS") (width 0.12) (tstamp 776964e5-8a9a-4a63-8cf3-d98b218e8b6a))
    (fp_line (start 6.301 -5.073) (end 6.301 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 787c9bc3-a530-4156-b810-fcf8d0f1f36d))
    (fp_line (start 8.661 -1.583) (end 8.661 1.583) (layer "F.SilkS") (width 0.12) (tstamp 7890b2ad-efec-4f80-b1f3-c36220353eb3))
    (fp_line (start 4.581 -5.981) (end 4.581 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 78b04db9-e7e5-4ddb-8645-412750c1fa13))
    (fp_line (start 5.381 1.44) (end 5.381 5.642) (layer "F.SilkS") (width 0.12) (tstamp 79da7867-888c-44a2-ac2c-4570981a3ff1))
    (fp_line (start 4.701 1.44) (end 4.701 5.939) (layer "F.SilkS") (width 0.12) (tstamp 7ab29b93-f701-431c-8bce-8ee3f5e6ef94))
    (fp_line (start 6.941 -4.528) (end 6.941 4.528) (layer "F.SilkS") (width 0.12) (tstamp 7bd5f049-1928-4040-b4b7-21dd896cf15d))
    (fp_line (start 4.861 1.44) (end 4.861 5.877) (layer "F.SilkS") (width 0.12) (tstamp 7c96f29d-804d-43ed-87a0-a4c284b3f813))
    (fp_line (start 3.461 -6.258) (end 3.461 6.258) (layer "F.SilkS") (width 0.12) (tstamp 7ef627f4-90a7-4ded-ae90-0262bbc2bf91))
    (fp_line (start 5.541 1.44) (end 5.541 5.558) (layer "F.SilkS") (width 0.12) (tstamp 80c66695-8ae0-4001-a41b-0500591dc1a8))
    (fp_line (start 8.341 -2.504) (end 8.341 2.504) (layer "F.SilkS") (width 0.12) (tstamp 80fd6145-18a2-42f2-aa60-88c56994e706))
    (fp_line (start -4.317082 -3.575) (end -3.067082 -3.575) (layer "F.SilkS") (width 0.12) (tstamp 82bf0323-726e-4689-bdaa-420de5755a6a))
    (fp_line (start 7.341 -4.102) (end 7.341 4.102) (layer "F.SilkS") (width 0.12) (tstamp 84628396-9ac7-4226-a211-0fc1c50d148b))
    (fp_line (start 6.661 -4.785) (end 6.661 4.785) (layer "F.SilkS") (width 0.12) (tstamp 853024d7-7005-46cf-aa4e-48bc052cc47b))
    (fp_line (start 3.661 1.44) (end 3.661 6.224) (layer "F.SilkS") (width 0.12) (tstamp 85ace77d-3b2e-415f-afa2-c2421206ce71))
    (fp_line (start 2.66 -6.328) (end 2.66 6.328) (layer "F.SilkS") (width 0.12) (tstamp 866b64b0-dd51-40cc-a4c3-43919b312e98))
    (fp_line (start 5.341 -5.662) (end 5.341 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 8901ff69-8f9b-4259-bbbb-ac7319b3b1f1))
    (fp_line (start 2.78 -6.324) (end 2.78 6.324) (layer "F.SilkS") (width 0.12) (tstamp 890c6c7f-714e-4e71-82a9-3d5e843631ca))
    (fp_line (start 6.341 -5.043) (end 6.341 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 891f9826-8f91-4682-818c-2ab71243483b))
    (fp_line (start 3.941 -6.166) (end 3.941 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 8ca54f4f-f1b9-48b1-ad99-7e07872ab4e2))
    (fp_line (start 3.06 -6.306) (end 3.06 6.306) (layer "F.SilkS") (width 0.12) (tstamp 8d20f755-33ee-4bac-a6a0-3ad45270d677))
    (fp_line (start 3.621 1.44) (end 3.621 6.231) (layer "F.SilkS") (width 0.12) (tstamp 8df6a205-df6c-47c4-917b-c2be76204888))
    (fp_line (start 6.541 -4.885) (end 6.541 4.885) (layer "F.SilkS") (width 0.12) (tstamp 8fdb0ac9-d62f-49b1-8868-0b2635469e1c))
    (fp_line (start 3.221 -6.29) (end 3.221 6.29) (layer "F.SilkS") (width 0.12) (tstamp 905528c1-f089-46b6-b96e-2149652238da))
    (fp_line (start 2.7 -6.327) (end 2.7 6.327) (layer "F.SilkS") (width 0.12) (tstamp 91e52235-ce39-4772-a6f6-cfb7e29a68a4))
    (fp_line (start 7.461 -3.957) (end 7.461 3.957) (layer "F.SilkS") (width 0.12) (tstamp 941265e6-89e5-4924-9a52-5d345de27e84))
    (fp_line (start 2.86 -6.32) (end 2.86 6.32) (layer "F.SilkS") (width 0.12) (tstamp 945affd6-7031-47fb-992d-6b64f8b5bef0))
    (fp_line (start 4.141 1.44) (end 4.141 6.116) (layer "F.SilkS") (width 0.12) (tstamp 95db3106-086a-4536-a6a1-b194884df1c5))
    (fp_line (start 4.381 -6.047) (end 4.381 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 968d103a-00ba-4041-82d9-95c2ab9c9217))
    (fp_line (start 5.901 1.44) (end 5.901 5.347) (layer "F.SilkS") (width 0.12) (tstamp 97c8d9c6-dc7b-47e3-bc15-d20d690b7976))
    (fp_line (start 4.621 1.44) (end 4.621 5.967) (layer "F.SilkS") (width 0.12) (tstamp 97d31da8-99fd-41dd-a2b6-c17d556d9ada))
    (fp_line (start 6.741 -4.714) (end 6.741 4.714) (layer "F.SilkS") (width 0.12) (tstamp 981e6856-d110-46b0-af80-9fca848ac6cc))
    (fp_line (start 4.661 -5.953) (end 4.661 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 98722e2b-1b7c-43e3-9b08-b2af95814c3d))
    (fp_line (start 6.261 1.44) (end 6.261 5.102) (layer "F.SilkS") (width 0.12) (tstamp 98cffc46-501a-410e-b12d-ef835cef270f))
    (fp_line (start 6.221 1.44) (end 6.221 5.131) (layer "F.SilkS") (width 0.12) (tstamp 992863dc-9610-40df-9b4a-68be42e2c66d))
    (fp_line (start 8.261 -2.681) (end 8.261 2.681) (layer "F.SilkS") (width 0.12) (tstamp 998419fd-2a51-44ea-b469-1dada6badeb7))
    (fp_line (start 5.141 1.44) (end 5.141 5.758) (layer "F.SilkS") (width 0.12) (tstamp 99c77ab0-b00f-41ba-90cb-129a1a11506d))
    (fp_line (start 4.821 -5.893) (end 4.821 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 9af5dd5d-68e2-4224-af91-7e6c7d49a05d))
    (fp_line (start 3.941 1.44) (end 3.941 6.166) (layer "F.SilkS") (width 0.12) (tstamp 9c7f090e-d486-4b96-9749-51558998fc0a))
    (fp_line (start 7.181 -4.282) (end 7.181 4.282) (layer "F.SilkS") (width 0.12) (tstamp 9cc9209b-ac93-49f1-b57e-d7a6e6c4bae6))
    (fp_line (start 4.501 -6.008) (end 4.501 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 9db30177-ef70-46ba-b4e2-850234ad5e07))
    (fp_line (start 3.1 -6.302) (end 3.1 6.302) (layer "F.SilkS") (width 0.12) (tstamp 9e269592-1d6a-435d-9945-d0bac36c81f6))
    (fp_line (start 6.061 -5.243) (end 6.061 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 9f4366fd-59ef-43bb-8df6-1ccb8366401a))
    (fp_line (start 5.181 1.44) (end 5.181 5.739) (layer "F.SilkS") (width 0.12) (tstamp a0544a11-ea3c-4155-a566-3f4559580254))
    (fp_line (start 5.141 -5.758) (end 5.141 -1.44) (layer "F.SilkS") (width 0.12) (tstamp a115bdfd-200b-4d6e-852e-90c3c325cbfe))
    (fp_line (start 4.101 1.44) (end 4.101 6.126) (layer "F.SilkS") (width 0.12) (tstamp a1f5c613-25e5-457f-9703-7fe277d0b1db))
    (fp_line (start 3.581 1.44) (end 3.581 6.238) (layer "F.SilkS") (width 0.12) (tstamp a21e749e-1e79-45fa-8fc6-9d5e3b886678))
    (fp_line (start 6.301 1.44) (end 6.301 5.073) (layer "F.SilkS") (width 0.12) (tstamp a2a0f3a3-c51b-4e42-846b-f21e45e3d3aa))
    (fp_line (start 4.701 -5.939) (end 4.701 -1.44) (layer "F.SilkS") (width 0.12) (tstamp a302607e-cde1-4846-9e52-ae52ca161a0d))
    (fp_line (start 4.621 -5.967) (end 4.621 -1.44) (layer "F.SilkS") (width 0.12) (tstamp a3542bb8-0586-45e1-a619-50cd99e4b580))
    (fp_line (start 8.421 -2.312) (end 8.421 2.312) (layer "F.SilkS") (width 0.12) (tstamp a4c2f7de-8326-4530-9a54-edd267def6f3))
    (fp_line (start 8.701 -1.422) (end 8.701 1.422) (layer "F.SilkS") (width 0.12) (tstamp a540ea5f-2154-4a38-9d86-c18db5b197a4))
    (fp_line (start 5.181 -5.739) (end 5.181 -1.44) (layer "F.SilkS") (width 0.12) (tstamp aa74c908-f3e1-4d8b-a27c-9ff6c48add9a))
    (fp_line (start 4.861 -5.877) (end 4.861 -1.44) (layer "F.SilkS") (width 0.12) (tstamp b0d91f5d-d45f-47ef-ba58-071a287ff86f))
    (fp_line (start 4.421 -6.034) (end 4.421 -1.44) (layer "F.SilkS") (width 0.12) (tstamp b1377534-cc80-4d34-aef8-3ce1d95e3e8e))
    (fp_line (start 7.021 -4.449) (end 7.021 4.449) (layer "F.SilkS") (width 0.12) (tstamp b14dcc4b-0d12-48c3-85d9-3ff9d841199d))
    (fp_line (start 6.901 -4.567) (end 6.901 4.567) (layer "F.SilkS") (width 0.12) (tstamp b4456c48-09bc-42a9-8b22-85aabf9d9da2))
    (fp_line (start 4.541 -5.995) (end 4.541 -1.44) (layer "F.SilkS") (width 0.12) (tstamp b5396fb6-1394-486d-b262-ae2f4894ccae))
    (fp_line (start 5.661 1.44) (end 5.661 5.491) (layer "F.SilkS") (width 0.12) (tstamp b57dc6d1-1051-43f5-9d42-a22ed55a72a5))
    (fp_line (start 3.701 -6.216) (end 3.701 -1.44) (layer "F.SilkS") (width 0.12) (tstamp b5bb90e3-910d-4e12-a37b-835fd90cf676))
    (fp_line (start 3.821 -6.192) (end 3.821 -1.44) (layer "F.SilkS") (width 0.12) (tstamp b61ab7c8-b93b-44a0-b40b-24cd43bf751f))
    (fp_line (start 4.581 1.44) (end 4.581 5.981) (layer "F.SilkS") (width 0.12) (tstamp b6572342-aad9-47ea-a0fe-fd971658c81b))
    (fp_line (start 5.781 -5.421) (end 5.781 -1.44) (layer "F.SilkS") (width 0.12) (tstamp b77b7e49-9dc6-4bcb-9803-678f269e4272))
    (fp_line (start 4.821 1.44) (end 4.821 5.893) (layer "F.SilkS") (width 0.12) (tstamp b8252d0c-08f4-43fa-a380-a0a672e3d6c2))
    (fp_line (start 6.781 -4.678) (end 6.781 4.678) (layer "F.SilkS") (width 0.12) (tstamp b863ce07-8d0f-4bc6-90fc-dced9d0fa6e1))
    (fp_line (start 2.82 -6.322) (end 2.82 6.322) (layer "F.SilkS") (width 0.12) (tstamp b90662f1-bc31-4cc2-ac40-ac22f4dbb6e8))
    (fp_line (start 6.981 -4.489) (end 6.981 4.489) (layer "F.SilkS") (width 0.12) (tstamp b9a56765-8a5d-4955-b03f-23a3b8db6d6f))
    (fp_line (start 3.541 -6.245) (end 3.541 6.245) (layer "F.SilkS") (width 0.12) (tstamp bb81470d-baab-4445-9b42-befffcac487a))
    (fp_line (start 4.021 1.44) (end 4.021 6.146) (layer "F.SilkS") (width 0.12) (tstamp bcc726bb-8ae7-42c2-a013-b15875332a35))
    (fp_line (start 6.061 1.44) (end 6.061 5.243) (layer "F.SilkS") (width 0.12) (tstamp c00a3a84-6f65-4b0c-a9fd-1f4380cecb5e))
    (fp_line (start 7.901 -3.339) (end 7.901 3.339) (layer "F.SilkS") (width 0.12) (tstamp c3a9a60e-a5c4-409e-91a0-49d492c35fbf))
    (fp_line (start 5.541 -5.558) (end 5.541 -1.44) (layer "F.SilkS") (width 0.12) (tstamp c5fbba64-39b6-4b6d-90c0-326f9343102a))
    (fp_line (start 8.381 -2.41) (end 8.381 2.41) (layer "F.SilkS") (width 0.12) (tstamp c6d33bb5-019f-451f-9514-00f06499e448))
    (fp_line (start 6.581 -4.852) (end 6.581 4.852) (layer "F.SilkS") (width 0.12) (tstamp c7aeec96-5e0c-4efe-86e4-3f0e18f561ad))
    (fp_line (start 5.621 1.44) (end 5.621 5.514) (layer "F.SilkS") (width 0.12) (tstamp c8caa85a-b06d-42ca-a911-326cca372ac4))
    (fp_line (start 5.381 -5.642) (end 5.381 -1.44) (layer "F.SilkS") (width 0.12) (tstamp c8cf4c1e-bc72-49dc-a8a3-4dd896fe7195))
    (fp_line (start 8.781 -1.028) (end 8.781 1.028) (layer "F.SilkS") (width 0.12) (tstamp c8fcaa23-9a50-4917-ae8c-0f08c4aae1b3))
    (fp_line (start 4.301 1.44) (end 4.301 6.071) (layer "F.SilkS") (width 0.12) (tstamp c9cd0742-16a3-4631-8f01-9bcc63c74238))
    (fp_line (start 6.221 -5.131) (end 6.221 -1.44) (layer "F.SilkS") (width 0.12) (tstamp caa61f5d-2789-4c0a-8982-b78088082a2c))
    (fp_line (start 6.421 -4.982) (end 6.421 -1.44) (layer "F.SilkS") (width 0.12) (tstamp cc4c6b37-feec-476e-baae-4bee256659e1))
    (fp_line (start 5.261 1.44) (end 5.261 5.702) (layer "F.SilkS") (width 0.12) (tstamp cdb5d759-a4fb-4f0c-9817-9de3a344d991))
    (fp_line (start 5.101 -5.776) (end 5.101 -1.44) (layer "F.SilkS") (width 0.12) (tstamp cee6ac76-acf0-4f4a-9c20-238abbc968e0))
    (fp_line (start 4.661 1.44) (end 4.661 5.953) (layer "F.SilkS") (width 0.12) (tstamp cfafcb18-1228-4d9e-8ddc-c6cee429049a))
    (fp_line (start 3.341 -6.275) (end 3.341 6.275) (layer "F.SilkS") (width 0.12) (tstamp d0bc0da6-2148-4883-b176-fd104b33ae53))
    (fp_line (start 3.381 -6.269) (end 3.381 6.269) (layer "F.SilkS") (width 0.12) (tstamp d13fb598-89fc-4640-a2b7-640679dadf6c))
    (fp_line (start 4.901 1.44) (end 4.901 5.861) (layer "F.SilkS") (width 0.12) (tstamp d1c2f3d0-8c6c-4e7e-9d88-e5befdadcc3e))
    (fp_line (start 6.861 -4.605) (end 6.861 4.605) (layer "F.SilkS") (width 0.12) (tstamp d20281b0-c799-4928-881e-5e4db76cecca))
    (fp_line (start 3.901 -6.175) (end 3.901 -1.44) (layer "F.SilkS") (width 0.12) (tstamp d2d8e607-d5f9-40e4-9f44-d5db93eded9b))
    (fp_line (start 4.781 -5.908) (end 4.781 -1.44) (layer "F.SilkS") (width 0.12) (tstamp d30fd880-9df2-45cb-b30d-16e2c56e754b))
    (fp_line (start 4.941 1.44) (end 4.941 5.845) (layer "F.SilkS") (width 0.12) (tstamp d3dd6d9e-ec76-4618-a49b-3a7bcc128934))
    (fp_line (start 5.701 -5.468) (end 5.701 -1.44) (layer "F.SilkS") (width 0.12) (tstamp d4b30d94-f5a2-4677-ae20-d96c2195f2b8))
    (fp_line (start 4.181 -6.105) (end 4.181 -1.44) (layer "F.SilkS") (width 0.12) (tstamp d5684e32-d16c-4bd1-9bdf-1f9e3ac10fdc))
    (fp_line (start 2.54 -6.33) (end 2.54 6.33) (layer "F.SilkS") (width 0.12) (tstamp d66b4421-0d3c-4103-a849-ee72dca5e1be))
    (fp_line (start 3.981 -6.156) (end 3.981 -1.44) (layer "F.SilkS") (width 0.12) (tstamp d74d2361-0c5e-4cb5-8547-4546d8cc83fa))
    (fp_line (start 7.981 -3.208) (end 7.981 3.208) (layer "F.SilkS") (width 0.12) (tstamp d8fb9e79-d3ab-434e-aeb8-3bd45ed049a5))
    (fp_line (start 5.781 1.44) (end 5.781 5.421) (layer "F.SilkS") (width 0.12) (tstamp d9b46fa8-9c51-43dc-8341-9651da561659))
    (fp_line (start 6.621 -4.819) (end 6.621 4.819) (layer "F.SilkS") (width 0.12) (tstamp d9c83cc8-c0c8-4bd1-81c5-6ba90a3fbefe))
    (fp_line (start 4.981 -5.828) (end 4.981 -1.44) (layer "F.SilkS") (width 0.12) (tstamp da763f8f-83c7-45af-a1e8-30e93b144f3f))
    (fp_line (start 3.741 1.44) (end 3.741 6.209) (layer "F.SilkS") (width 0.12) (tstamp db6bfce5-8a7e-4b0a-a9f3-647b53e8f7ec))
    (fp_line (start 3.501 -6.252) (end 3.501 6.252) (layer "F.SilkS") (width 0.12) (tstamp dbe0360d-59ad-4367-85a9-c2a2c08f52bf))
    (fp_line (start 3.421 -6.264) (end 3.421 6.264) (layer "F.SilkS") (width 0.12) (tstamp df1ee637-67cd-4a8f-b898-a6750594fc3e))
    (fp_line (start 8.621 -1.728) (end 8.621 1.728) (layer "F.SilkS") (width 0.12) (tstamp df65a1c8-ba07-41fe-a35d-14e4e100bcf1))
    (fp_line (start 5.661 -5.491) (end 5.661 -1.44) (layer "F.SilkS") (width 0.12) (tstamp dff6a8cc-2db2-4d31-be13-b346f90eb5d4))
    (fp_line (start 5.621 -5.514) (end 5.621 -1.44) (layer "F.SilkS") (width 0.12) (tstamp e027663f-04c0-435f-981a-0e7fe8c08736))
    (fp_line (start 5.741 1.44) (end 5.741 5.445) (layer "F.SilkS") (width 0.12) (tstamp e07e94ef-f600-429a-8d83-076c871fc8bc))
    (fp_line (start 7.581 -3.804) (end 7.581 3.804) (layer "F.SilkS") (width 0.12) (tstamp e29bd1c4-db4e-4e98-828b-1fc01782fa18))
    (fp_line (start 3.02 -6.309) (end 3.02 6.309) (layer "F.SilkS") (width 0.12) (tstamp e4db120e-517b-475c-ac20-f7cce170d9d2))
    (fp_line (start 4.461 1.44) (end 4.461 6.021) (layer "F.SilkS") (width 0.12) (tstamp e5023d2e-8374-4b32-8014-dd963c830e1b))
    (fp_line (start 5.221 -5.721) (end 5.221 -1.44) (layer "F.SilkS") (width 0.12) (tstamp e58cc2ff-0a4b-4310-b556-68b40947a127))
    (fp_line (start 3.901 1.44) (end 3.901 6.175) (layer "F.SilkS") (width 0.12) (tstamp e5bce28b-232d-47bc-8da4-fe92faa2f11e))
    (fp_line (start 7.941 -3.275) (end 7.941 3.275) (layer "F.SilkS") (width 0.12) (tstamp e6bfa4cf-7bde-469f-882a-dcc93b7251e7))
    (fp_line (start 2.62 -6.329) (end 2.62 6.329) (layer "F.SilkS") (width 0.12) (tstamp e6f707cd-484f-4242-8d44-e96932213847))
    (fp_line (start 4.221 1.44) (end 4.221 6.094) (layer "F.SilkS") (width 0.12) (tstamp e770d7c7-c775-4990-9cf7-b5cc9d23d3a4))
    (fp_line (start 8.061 -3.069) (end 8.061 3.069) (layer "F.SilkS") (width 0.12) (tstamp e9c276d5-7481-4f57-81fe-e723c2463c79))
    (fp_line (start 7.061 -4.408) (end 7.061 4.408) (layer "F.SilkS") (width 0.12) (tstamp ea3c2851-1f3f-44fd-a30c-3221dc4a307d))
    (fp_line (start 6.021 1.44) (end 6.021 5.27) (layer "F.SilkS") (width 0.12) (tstamp eab28b35-404d-4c9b-a1da-34b49d83d3c4))
    (fp_line (start 5.461 1.44) (end 5.461 5.601) (layer "F.SilkS") (width 0.12) (tstamp f032e7a3-f854-4144-823f-c6b3e8770339))
    (fp_line (start 6.181 -5.16) (end 6.181 -1.44) (layer "F.SilkS") (width 0.12) (tstamp f19b6bc7-d480-4bea-9052-bcd75dcee4b6))
    (fp_line (start 5.741 -5.445) (end 5.741 -1.44) (layer "F.SilkS") (width 0.12) (tstamp f210bece-6710-4ee6-b834-8d286177fdc7))
    (fp_line (start 5.221 1.44) (end 5.221 5.721) (layer "F.SilkS") (width 0.12) (tstamp f45b9583-4fd6-4f11-87f5-4ee2282d6fa2))
    (fp_line (start 3.661 -6.224) (end 3.661 -1.44) (layer "F.SilkS") (width 0.12) (tstamp f58af9fa-3f8e-4c54-bacc-a930fce3c3d2))
    (fp_line (start 7.701 -3.64) (end 7.701 3.64) (layer "F.SilkS") (width 0.12) (tstamp f82a0b6e-da39-4f86-91a0-81b46db1cc0e))
    (fp_line (start 6.501 -4.918) (end 6.501 4.918) (layer "F.SilkS") (width 0.12) (tstamp f8443c05-1e77-4d9d-a61d-6afe0d46daf1))
    (fp_line (start 5.701 1.44) (end 5.701 5.468) (layer "F.SilkS") (width 0.12) (tstamp f850d5fe-a55d-43ef-befb-76c4245de6a8))
    (fp_line (start 5.421 1.44) (end 5.421 5.622) (layer "F.SilkS") (width 0.12) (tstamp fb0c98e6-6ee3-49e1-87f0-9f806eeabe06))
    (fp_line (start 4.301 -6.071) (end 4.301 -1.44) (layer "F.SilkS") (width 0.12) (tstamp fc29a198-6120-4dc0-bce9-2483a8fc5430))
    (fp_circle (center 2.5 0) (end 8.87 0) (layer "F.SilkS") (width 0.12) (fill none) (tstamp 8d396e5a-1ae7-498a-bef1-744d9c1240cb))
    (fp_circle (center 2.5 0) (end 9 0) (layer "F.CrtYd") (width 0.05) (fill none) (tstamp 2754732a-02bc-4d1b-b255-753b692749e5))
    (fp_line (start -2.241489 -3.3625) (end -2.241489 -2.1125) (layer "F.Fab") (width 0.1) (tstamp b57eca3f-1254-4d04-bf69-16e7ed5a23dc))
    (fp_line (start -2.866489 -2.7375) (end -1.616489 -2.7375) (layer "F.Fab") (width 0.1) (tstamp d4ab1b7c-5207-4520-b9bb-49c744d8b65d))
    (fp_circle (center 2.5 0) (end 8.75 0) (layer "F.Fab") (width 0.1) (fill none) (tstamp 000add93-b0f2-4945-bd42-bd54eb43f165))
    (pad "1" thru_hole rect (at 0 0 90) (size 2.4 2.4) (drill 1.2) (layers *.Cu *.Mask)
      (net 10 "Net-(C14-Pad1)") (pintype "passive") (tstamp d0e3b7e3-dbcc-4cba-9f29-ba757ef7cf1a))
    (pad "2" thru_hole circle (at 5 0 90) (size 2.4 2.4) (drill 1.2) (layers *.Cu *.Mask)
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp adefb97e-b693-4a56-a444-9e238654a9c1))
    (model "${KICAD6_3DMODEL_DIR}/Capacitor_THT.3dshapes/CP_Radial_D12.5mm_P5.00mm.wrl"
      (offset (xyz 0 0 0))
      (scale (xyz 1 1 1))
      (rotate (xyz 0 0 0))
  (footprint "Capacitor_THT:C_Disc_D5.0mm_W2.5mm_P2.50mm" (layer "F.Cu")
    (tedit 5AE50EF0) (tstamp 6dc6b76f-3c4d-4e47-982c-7cfac7456506)
    (at 23.261 84.328)
    (descr "C, Disc series, Radial, pin pitch=2.50mm, , diameter*width=5*2.5mm^2, Capacitor, http://cdn-reichelt.de/documents/datenblatt/B300/DS_KERKO_TC.pdf")
    (tags "C Disc series Radial pin pitch 2.50mm  diameter 5mm width 2.5mm Capacitor")
    (property "Sheetfile" "Lauflicht_Steuerplatine.kicad_sch")
    (property "Sheetname" "")
    (path "/66a4b164-ecc2-444b-8d5c-4b453a42e0fd")
    (attr through_hole)
    (fp_text reference "C27" (at -2.306 -0.127 90) (layer "F.SilkS")
      (effects (font (size 1 1) (thickness 0.15)))
      (tstamp 59609a9c-a748-49ce-9680-5e3659909bd3)
    (fp_text value " " (at 1.25 2.5) (layer "F.Fab")
      (tstamp e38b6e16-a721-4827-9173-1fa1803ba7d4)
    (fp_text user "${REFERENCE}" (at 1.25 0) (layer "F.Fab")
      (tstamp 4c4d0e35-e4ec-4221-9f8a-8e702c44f77a)
    (fp_line (start -1.37 -1.37) (end -1.37 1.37) (layer "F.SilkS") (width 0.12) (tstamp 13368141-d679-48ea-b042-38b23f9468dc))
    (fp_line (start -1.37 -1.37) (end 3.87 -1.37) (layer "F.SilkS") (width 0.12) (tstamp 3d5b8750-7677-43ba-a020-dc83035cc724))
    (fp_line (start 3.87 -1.37) (end 3.87 1.37) (layer "F.SilkS") (width 0.12) (tstamp 6ac1f459-cb24-4e8d-9bc3-544827fde7bd))
    (fp_line (start -1.37 1.37) (end 3.87 1.37) (layer "F.SilkS") (width 0.12) (tstamp bada013d-75b9-419b-827c-cf118d7a42df))
    (fp_line (start 4 -1.5) (end -1.5 -1.5) (layer "F.CrtYd") (width 0.05) (tstamp 06b1f9bc-0a08-408b-aed3-042057ddf8f9))
    (fp_line (start -1.5 1.5) (end 4 1.5) (layer "F.CrtYd") (width 0.05) (tstamp 3c73ab70-ed85-41f8-a38e-11066cd8aec4))
    (fp_line (start 4 1.5) (end 4 -1.5) (layer "F.CrtYd") (width 0.05) (tstamp 72e3baf6-ef86-47d5-88ba-3f0d55021702))
    (fp_line (start -1.5 -1.5) (end -1.5 1.5) (layer "F.CrtYd") (width 0.05) (tstamp e4f4038b-73b7-4d14-bb85-90dd994fe083))
    (fp_line (start -1.25 -1.25) (end -1.25 1.25) (layer "F.Fab") (width 0.1) (tstamp 28aadfbc-e89a-464e-a253-76f3efe63d4c))
    (fp_line (start 3.75 -1.25) (end -1.25 -1.25) (layer "F.Fab") (width 0.1) (tstamp 59aa180f-1a29-4cfe-b274-0cb2a3160bd6))
    (fp_line (start -1.25 1.25) (end 3.75 1.25) (layer "F.Fab") (width 0.1) (tstamp 712084b2-029e-40ba-acf6-fc1ca4fee8c7))
    (fp_line (start 3.75 1.25) (end 3.75 -1.25) (layer "F.Fab") (width 0.1) (tstamp 789354de-2218-4c26-80fa-e4971ee17799))
    (pad "1" thru_hole circle (at 0 0) (size 1.6 1.6) (drill 0.8) (layers *.Cu *.Mask)
      (net 13 "Net-(C27-Pad1)") (pintype "passive") (tstamp 6008b84b-aafc-49ea-9a08-67141265920c))
    (pad "2" thru_hole circle (at 2.5 0) (size 1.6 1.6) (drill 0.8) (layers *.Cu *.Mask)
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp 5d1a3d90-9d93-4156-89ea-e15d936720ed))
    (model "${KICAD6_3DMODEL_DIR}/Capacitor_THT.3dshapes/C_Disc_D5.0mm_W2.5mm_P2.50mm.wrl"
      (scale (xyz 1 1 1))
    (tedit 5AE50EF1) (tstamp 6e7e2aed-51f7-442f-9bbc-4318a961aad2)
    (at 150.241 87.159959 90)
    (path "/de597ab6-dba7-4ff2-a48d-37a22b4607c1")
    (attr through_hole)
    (fp_text reference "C15" (at 2.5 -7.5 90) (layer "F.SilkS")
      (tstamp 53ac5c9c-4d50-475e-b88e-693ba32564bc)
    (fp_text value "ELKO 680/35 FK 1500/35 AM" (at 2.5 7.5 90) (layer "F.Fab")
      (tstamp 2544de70-c9b0-45cd-9078-e504f0b150c6)
      (tstamp 563c5165-d3c3-4079-ad16-f2edccc767e4)
    (fp_line (start 4.421 1.44) (end 4.421 6.034) (layer "F.SilkS") (width 0.12) (tstamp 00012f43-934b-43ea-b2ca-9f851be51789))
    (fp_line (start 7.781 -3.524) (end 7.781 3.524) (layer "F.SilkS") (width 0.12) (tstamp 003b86c8-1e9b-4b44-b40c-f99b6c415417))
    (fp_line (start 8.101 -2.996) (end 8.101 2.996) (layer "F.SilkS") (width 0.12) (tstamp 00ee69b9-ac3a-4354-b41f-7ca33224eb72))
    (fp_line (start -4.317082 -3.575) (end -3.067082 -3.575) (layer "F.SilkS") (width 0.12) (tstamp 015c2f19-966d-4f7e-b4fa-b2d3e1a54464))
    (fp_line (start 4.061 1.44) (end 4.061 6.137) (layer "F.SilkS") (width 0.12) (tstamp 020e7a68-3ba6-4f9b-a610-0e6a521f2102))
    (fp_line (start 6.421 -4.982) (end 6.421 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 027a549c-3214-4a9e-88f0-06acd11534cd))
    (fp_line (start 5.181 1.44) (end 5.181 5.739) (layer "F.SilkS") (width 0.12) (tstamp 033c0688-0a24-4c0e-8f63-ec451e0bcb93))
    (fp_line (start 3.901 1.44) (end 3.901 6.175) (layer "F.SilkS") (width 0.12) (tstamp 040966a6-7b34-47f4-9459-4e9bf08f4952))
    (fp_line (start 7.301 -4.148) (end 7.301 4.148) (layer "F.SilkS") (width 0.12) (tstamp 0557691b-66b8-41c8-bcd0-c7549b8b1e5f))
    (fp_line (start 5.501 -5.58) (end 5.501 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 0667c1fe-1b14-405d-a43f-28e91f186dc6))
    (fp_line (start 5.341 -5.662) (end 5.341 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 0849ae17-99c4-44b7-9ec9-45c50a6c4da4))
    (fp_line (start 2.78 -6.324) (end 2.78 6.324) (layer "F.SilkS") (width 0.12) (tstamp 0a0f565b-48b8-47b0-9674-119469d73756))
    (fp_line (start 3.741 1.44) (end 3.741 6.209) (layer "F.SilkS") (width 0.12) (tstamp 0a2bb340-54c2-49be-8abb-f21b66c393d2))
    (fp_line (start 4.541 -5.995) (end 4.541 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 0a5f430e-454d-4db2-9d0f-697e2c601506))
    (fp_line (start 5.101 1.44) (end 5.101 5.776) (layer "F.SilkS") (width 0.12) (tstamp 0ac73f21-968f-4b83-ada5-dfe7b8e8c76b))
    (fp_line (start 4.981 1.44) (end 4.981 5.828) (layer "F.SilkS") (width 0.12) (tstamp 0aeb27c1-15bc-42fe-8920-3f2687817a3f))
    (fp_line (start 5.461 1.44) (end 5.461 5.601) (layer "F.SilkS") (width 0.12) (tstamp 0c742e19-c36e-4148-a73a-4fee5b024ddd))
    (fp_line (start 3.421 -6.264) (end 3.421 6.264) (layer "F.SilkS") (width 0.12) (tstamp 0e4bee08-5a57-473c-8819-81d6dbd810a5))
    (fp_line (start 6.621 -4.819) (end 6.621 4.819) (layer "F.SilkS") (width 0.12) (tstamp 0eae6bbe-eeb3-411e-ab63-b284007ca338))
    (fp_line (start 4.181 -6.105) (end 4.181 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 100b6e78-f293-4ae9-8891-8f902a5c4f2a))
    (fp_line (start 8.301 -2.594) (end 8.301 2.594) (layer "F.SilkS") (width 0.12) (tstamp 13b4c0e8-b2fd-4970-93a0-0cb06a1ca94e))
    (fp_line (start 7.261 -4.194) (end 7.261 4.194) (layer "F.SilkS") (width 0.12) (tstamp 16b0c522-8917-4a9c-ae04-ba61e79e387b))
    (fp_line (start 6.421 1.44) (end 6.421 4.982) (layer "F.SilkS") (width 0.12) (tstamp 17ec1bd9-22ef-4e0d-8b12-51b3bc0ac01d))
    (fp_line (start 6.141 -5.188) (end 6.141 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 19968550-f90a-4544-9957-2601d92b660f))
    (fp_line (start 5.981 -5.296) (end 5.981 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 19be6a9b-3c67-45af-bd7b-ce04a21efb67))
    (fp_line (start 4.141 -6.116) (end 4.141 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 1a2d97a8-23e4-48f6-b9e5-6989cfe3eab1))
    (fp_line (start 4.701 1.44) (end 4.701 5.939) (layer "F.SilkS") (width 0.12) (tstamp 1aa029d0-bad9-432e-96c3-601b85a4058f))
    (fp_line (start 7.141 -4.325) (end 7.141 4.325) (layer "F.SilkS") (width 0.12) (tstamp 1b98f80c-594a-4ce6-8b5e-9d04fff2b70a))
    (fp_line (start 3.741 -6.209) (end 3.741 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 1d2f72e9-4c3f-4a1e-a15a-cb74c9b7da45))
    (fp_line (start 6.301 1.44) (end 6.301 5.073) (layer "F.SilkS") (width 0.12) (tstamp 1df7ec59-10b9-4d90-9c4c-e8379c7fd366))
    (fp_line (start 5.541 -5.558) (end 5.541 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 1e3701ce-010e-45c8-9236-5f218b1a480f))
    (fp_line (start 8.861 -0.317) (end 8.861 0.317) (layer "F.SilkS") (width 0.12) (tstamp 1e47328d-4214-4733-8142-192420d61531))
    (fp_line (start 5.141 -5.758) (end 5.141 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 1e9a6248-0e15-41a9-8bb9-31eea86f9b24))
    (fp_line (start 5.541 1.44) (end 5.541 5.558) (layer "F.SilkS") (width 0.12) (tstamp 1f4a406a-afb5-42c0-ac11-cb6b7b4fe0e7))
    (fp_line (start 7.661 -3.696) (end 7.661 3.696) (layer "F.SilkS") (width 0.12) (tstamp 2203b4b9-0d27-4b5e-9ce8-bfea55b87d7a))
    (fp_line (start 6.701 -4.75) (end 6.701 4.75) (layer "F.SilkS") (width 0.12) (tstamp 221a3d7d-34fe-48bf-9f6d-a8a98057bb54))
    (fp_line (start 2.5 -6.33) (end 2.5 6.33) (layer "F.SilkS") (width 0.12) (tstamp 22460fc0-e29e-4d0c-b332-33db02b1a940))
    (fp_line (start 5.221 -5.721) (end 5.221 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 24463778-a19d-4f3c-86b0-5c8383be0e20))
    (fp_line (start 7.941 -3.275) (end 7.941 3.275) (layer "F.SilkS") (width 0.12) (tstamp 25a26b49-56af-4c97-8a1e-a8e67070e161))
    (fp_line (start 3.261 -6.285) (end 3.261 6.285) (layer "F.SilkS") (width 0.12) (tstamp 292c7914-2605-4968-b8c6-7e90ac94c4a1))
    (fp_line (start 7.061 -4.408) (end 7.061 4.408) (layer "F.SilkS") (width 0.12) (tstamp 29830b81-7f76-4137-86d0-47a10990be13))
    (fp_line (start 7.341 -4.102) (end 7.341 4.102) (layer "F.SilkS") (width 0.12) (tstamp 2ae1d7b0-96e1-48e4-86ad-c819e51ca377))
    (fp_line (start 2.66 -6.328) (end 2.66 6.328) (layer "F.SilkS") (width 0.12) (tstamp 2c0edfb0-3d88-4bda-8638-c248df8fbca7))
    (fp_line (start 4.621 -5.967) (end 4.621 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 2ce3a64d-f18a-4302-a453-2aa731114222))
    (fp_line (start 7.981 -3.208) (end 7.981 3.208) (layer "F.SilkS") (width 0.12) (tstamp 2e81869b-e827-4380-bf45-2a0709026cfb))
    (fp_line (start 5.821 -5.397) (end 5.821 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 31b4a94f-c17e-4fa2-bb7d-f73328ea3ec6))
    (fp_line (start 3.661 -6.224) (end 3.661 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 34eb07e4-5e0f-4dea-a437-7c7bc69f42ed))
    (fp_line (start 4.381 1.44) (end 4.381 6.047) (layer "F.SilkS") (width 0.12) (tstamp 3597d663-df04-41bd-8251-55bd9c61a759))
    (fp_line (start 8.421 -2.312) (end 8.421 2.312) (layer "F.SilkS") (width 0.12) (tstamp 3ad34bc3-8ef7-45f8-a2e5-742387cfdfc4))
    (fp_line (start 5.141 1.44) (end 5.141 5.758) (layer "F.SilkS") (width 0.12) (tstamp 3b475de5-f226-4079-a986-a368d9a2e214))
    (fp_line (start 3.18 -6.294) (end 3.18 6.294) (layer "F.SilkS") (width 0.12) (tstamp 3ca0f662-6ecd-47f6-aea1-45d49607be70))
    (fp_line (start 5.061 1.44) (end 5.061 5.793) (layer "F.SilkS") (width 0.12) (tstamp 3d4e1e13-604c-4a84-ac35-dbb066def3a3))
    (fp_line (start 6.021 -5.27) (end 6.021 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 3e3d8a38-e625-43dc-abf2-b5b5c2abbde8))
    (fp_line (start 4.261 -6.083) (end 4.261 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 3fab3bf0-882a-4f9d-86a9-99bb515dce73))
    (fp_line (start 4.741 -5.924) (end 4.741 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 400d9e8a-c9dd-442e-962a-d2a50fc561a9))
    (fp_line (start 6.781 -4.678) (end 6.781 4.678) (layer "F.SilkS") (width 0.12) (tstamp 424b2d79-507b-42b8-a993-dff6125abd92))
    (fp_line (start 6.261 -5.102) (end 6.261 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 425f811f-240d-4dd9-9fa5-cafa8086218e))
    (fp_line (start 7.021 -4.449) (end 7.021 4.449) (layer "F.SilkS") (width 0.12) (tstamp 429e12ab-5b10-4b81-af72-7d499c5a332c))
    (fp_line (start 6.461 -4.95) (end 6.461 4.95) (layer "F.SilkS") (width 0.12) (tstamp 43ee6f59-2c08-4bc2-a1ad-7a378d9e4661))
    (fp_line (start 5.621 1.44) (end 5.621 5.514) (layer "F.SilkS") (width 0.12) (tstamp 44586bf9-36fe-42be-8626-64fc396a58f6))
    (fp_line (start -3.692082 -4.2) (end -3.692082 -2.95) (layer "F.SilkS") (width 0.12) (tstamp 446b1d47-5037-4ca8-9b25-5618dc82459b))
    (fp_line (start 8.021 -3.14) (end 8.021 3.14) (layer "F.SilkS") (width 0.12) (tstamp 45a3dfd7-74bf-4544-aef8-a2f18625e471))
    (fp_line (start 4.221 1.44) (end 4.221 6.094) (layer "F.SilkS") (width 0.12) (tstamp 47c6a2df-1326-431a-9ef5-71b127d29452))
    (fp_line (start 4.861 -5.877) (end 4.861 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 4acc1912-9a98-46f5-972e-1ff7cadb8144))
    (fp_line (start 4.941 -5.845) (end 4.941 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 4c625c2d-d329-4d83-8fa9-54819bb167be))
    (fp_line (start 7.421 -4.007) (end 7.421 4.007) (layer "F.SilkS") (width 0.12) (tstamp 4cea8820-c0de-4b79-ad7c-31033a0ef10a))
    (fp_line (start 8.781 -1.028) (end 8.781 1.028) (layer "F.SilkS") (width 0.12) (tstamp 4d175a9b-f2aa-43e0-8e7b-994344406d9a))
    (fp_line (start 3.621 1.44) (end 3.621 6.231) (layer "F.SilkS") (width 0.12) (tstamp 4f04a807-59f7-4b47-bd37-bc736dc820cc))
    (fp_line (start 3.981 -6.156) (end 3.981 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 542a7851-2463-47e1-b883-46c5c2d956e0))
    (fp_line (start 3.861 1.44) (end 3.861 6.184) (layer "F.SilkS") (width 0.12) (tstamp 5527d510-82eb-4041-8d02-57dfcb455a6a))
    (fp_line (start 5.021 -5.811) (end 5.021 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 55782fa4-a462-4b55-b3b1-48d445dcea77))
    (fp_line (start 2.54 -6.33) (end 2.54 6.33) (layer "F.SilkS") (width 0.12) (tstamp 57623bbb-610e-4b28-911d-322aad62e81c))
    (fp_line (start 3.381 -6.269) (end 3.381 6.269) (layer "F.SilkS") (width 0.12) (tstamp 57e6993a-c2cf-4a54-b3ed-1cf0a52aa958))
    (fp_line (start 4.541 1.44) (end 4.541 5.995) (layer "F.SilkS") (width 0.12) (tstamp 5977c0dc-1723-4830-9088-7772ce0cf62b))
    (fp_line (start 5.261 1.44) (end 5.261 5.702) (layer "F.SilkS") (width 0.12) (tstamp 59a48fcb-4bb4-4e63-90d8-77fd052e3956))
    (fp_line (start 5.661 -5.491) (end 5.661 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 5a0a7eb3-b78b-45e8-86da-8cf593924d3c))
    (fp_line (start 6.341 1.44) (end 6.341 5.043) (layer "F.SilkS") (width 0.12) (tstamp 5c4855d9-fac9-4d39-b89a-46ed9915420f))
    (fp_line (start 4.101 -6.126) (end 4.101 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 5dafc9c8-43d1-4c62-bbc0-5864fff52463))
    (fp_line (start 3.06 -6.306) (end 3.06 6.306) (layer "F.SilkS") (width 0.12) (tstamp 5dbd8b62-d198-49c9-83ff-fe8f698d49c6))
    (fp_line (start 7.741 -3.583) (end 7.741 3.583) (layer "F.SilkS") (width 0.12) (tstamp 5e47fc8a-311c-4fef-b186-9cb06ebc6d5f))
    (fp_line (start 3.621 -6.231) (end 3.621 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 5e555091-4ee3-4d7a-947e-948c8997dbc5))
    (fp_line (start 7.501 -3.907) (end 7.501 3.907) (layer "F.SilkS") (width 0.12) (tstamp 5ea05821-3d50-4bc7-805b-4606de02d79c))
    (fp_line (start 3.301 -6.28) (end 3.301 6.28) (layer "F.SilkS") (width 0.12) (tstamp 614fabc6-9076-4b2d-b9df-e730d8fb8c76))
    (fp_line (start 7.861 -3.402) (end 7.861 3.402) (layer "F.SilkS") (width 0.12) (tstamp 61e81ec5-13bb-4fb2-85e1-9a979faca9aa))
    (fp_line (start 4.701 -5.939) (end 4.701 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 620b70a2-aacb-4a5c-aaea-2a46d2128ac1))
    (fp_line (start 3.941 -6.166) (end 3.941 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 62e8299c-e790-4743-aa11-ae8c8b1c6c3a))
    (fp_line (start 5.301 1.44) (end 5.301 5.682) (layer "F.SilkS") (width 0.12) (tstamp 6307938f-c378-4f0e-aead-b64a120e5d8b))
    (fp_line (start 7.461 -3.957) (end 7.461 3.957) (layer "F.SilkS") (width 0.12) (tstamp 63754b15-15d8-4b79-9885-c679f64e70bd))
    (fp_line (start 7.901 -3.339) (end 7.901 3.339) (layer "F.SilkS") (width 0.12) (tstamp 645e0ae0-8bd7-4277-9a95-59c625aaeca5))
    (fp_line (start 7.701 -3.64) (end 7.701 3.64) (layer "F.SilkS") (width 0.12) (tstamp 67aa6f1e-a33e-4333-a30a-d4c0e11ca255))
    (fp_line (start 8.701 -1.422) (end 8.701 1.422) (layer "F.SilkS") (width 0.12) (tstamp 682def83-eb53-42de-98bc-31d719710e0a))
    (fp_line (start 4.261 1.44) (end 4.261 6.083) (layer "F.SilkS") (width 0.12) (tstamp 68408c58-240e-4534-a14b-6a4069fb031f))
    (fp_line (start 5.901 1.44) (end 5.901 5.347) (layer "F.SilkS") (width 0.12) (tstamp 687dd5af-cfac-4cac-b6a8-81b77e60500c))
    (fp_line (start 6.061 1.44) (end 6.061 5.243) (layer "F.SilkS") (width 0.12) (tstamp 69edfce9-5b98-44c3-98cc-0763d7b17d3d))
    (fp_line (start 4.901 1.44) (end 4.901 5.861) (layer "F.SilkS") (width 0.12) (tstamp 69f46ca2-ca17-43ab-8aa5-b98944ff26bc))
    (fp_line (start 6.861 -4.605) (end 6.861 4.605) (layer "F.SilkS") (width 0.12) (tstamp 6c05ef38-ced2-4f5e-ac0f-8606f4bfb48a))
    (fp_line (start 4.221 -6.094) (end 4.221 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 6caee1df-abc5-4a87-88ec-b8dc4cb41daf))
    (fp_line (start 5.301 -5.682) (end 5.301 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 6dbb4d0e-526e-4d82-99e4-ae79c9fbc1d6))
    (fp_line (start 4.021 -6.146) (end 4.021 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 6e19eac3-9b18-4f46-8968-7e9b66b2095e))
    (fp_line (start 4.781 -5.908) (end 4.781 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 6e3164d6-ae3a-4f9b-b1c3-f66a4f8451ca))
    (fp_line (start 3.461 -6.258) (end 3.461 6.258) (layer "F.SilkS") (width 0.12) (tstamp 6e410e0c-fa3f-446f-acea-aa7ec6a6145b))
    (fp_line (start 3.821 1.44) (end 3.821 6.192) (layer "F.SilkS") (width 0.12) (tstamp 71b14c81-2c99-4762-bb9c-ad0ae33a5e46))
    (fp_line (start 2.86 -6.32) (end 2.86 6.32) (layer "F.SilkS") (width 0.12) (tstamp 7312f6aa-5d1c-4af9-84a9-160d8ffc83bd))
    (fp_line (start 4.381 -6.047) (end 4.381 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 7335db26-fb8c-4391-a8e5-48f5de487f88))
    (fp_line (start 8.741 -1.241) (end 8.741 1.241) (layer "F.SilkS") (width 0.12) (tstamp 73413d43-6988-4683-80c8-0a3baaef5780))
    (fp_line (start 8.381 -2.41) (end 8.381 2.41) (layer "F.SilkS") (width 0.12) (tstamp 73b137f9-2a5a-4204-af7b-a85d71c9063d))
    (fp_line (start 3.781 1.44) (end 3.781 6.201) (layer "F.SilkS") (width 0.12) (tstamp 73be72c6-cc2f-45e9-a5cc-442e1071d9dd))
    (fp_line (start 4.661 -5.953) (end 4.661 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 75cb43ae-7d90-47e9-8fc9-ab07a723d13e))
    (fp_line (start 6.541 -4.885) (end 6.541 4.885) (layer "F.SilkS") (width 0.12) (tstamp 76a34cff-3053-484e-af7e-d031a9812caf))
    (fp_line (start 5.021 1.44) (end 5.021 5.811) (layer "F.SilkS") (width 0.12) (tstamp 78abe13b-aa8f-4d62-97f7-36780177db7f))
    (fp_line (start 6.061 -5.243) (end 6.061 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 78f54833-ab39-4903-a03a-78513123990f))
    (fp_line (start 4.821 -5.893) (end 4.821 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 7a374be5-c665-450d-a721-771b352d4ccd))
    (fp_line (start 5.741 -5.445) (end 5.741 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 7b565e12-2b0b-4c97-9506-84c980a8de18))
    (fp_line (start 2.82 -6.322) (end 2.82 6.322) (layer "F.SilkS") (width 0.12) (tstamp 7d01b0af-43fa-4105-8301-d54ca8a2322e))
    (fp_line (start 6.101 1.44) (end 6.101 5.216) (layer "F.SilkS") (width 0.12) (tstamp 7dbf369f-5c60-4bfb-a2ef-c6b6cd5c1360))
    (fp_line (start 4.021 1.44) (end 4.021 6.146) (layer "F.SilkS") (width 0.12) (tstamp 7df6f079-239c-4cbd-9de7-02405c916d1c))
    (fp_line (start 5.221 1.44) (end 5.221 5.721) (layer "F.SilkS") (width 0.12) (tstamp 7fb516dd-ea5d-44e2-b540-50ffbb85fba2))
    (fp_line (start 4.581 -5.981) (end 4.581 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 80153967-529f-4e5c-8d29-2bf8ab3ba72e))
    (fp_line (start 5.781 -5.421) (end 5.781 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 80fb6e0c-ceac-4453-8851-07a223d0f513))
    (fp_line (start 6.261 1.44) (end 6.261 5.102) (layer "F.SilkS") (width 0.12) (tstamp 821f7891-2c8c-45fc-9211-15063c9daff8))
    (fp_line (start 8.141 -2.921) (end 8.141 2.921) (layer "F.SilkS") (width 0.12) (tstamp 83f934e1-6fc8-4dc1-9ac5-c8cc83629dad))
    (fp_line (start 4.661 1.44) (end 4.661 5.953) (layer "F.SilkS") (width 0.12) (tstamp 881e1705-5f3b-4d4c-94bf-2f4ae3e81b07))
    (fp_line (start 4.301 -6.071) (end 4.301 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 89156b90-3020-4b75-9715-2ba7f5d747b7))
    (fp_line (start 6.661 -4.785) (end 6.661 4.785) (layer "F.SilkS") (width 0.12) (tstamp 8929117b-c9fe-49dc-992b-ebc72055d94e))
    (fp_line (start 5.581 -5.536) (end 5.581 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 8ae7e2aa-b0b4-46db-b9b1-c32f93f0a51b))
    (fp_line (start 6.301 -5.073) (end 6.301 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 8b2e5c40-1427-45ad-9b0a-a9b9876cd9a8))
    (fp_line (start 5.181 -5.739) (end 5.181 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 8bdc4772-c75c-4dd8-9e3a-76b74c09c12d))
    (fp_line (start 4.981 -5.828) (end 4.981 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 8c30cb87-c8e8-4669-9bfe-ab7c3c4627f4))
    (fp_line (start 6.981 -4.489) (end 6.981 4.489) (layer "F.SilkS") (width 0.12) (tstamp 8cd5e146-7ad2-4f36-b19c-e376a7d500ff))
    (fp_line (start 5.421 1.44) (end 5.421 5.622) (layer "F.SilkS") (width 0.12) (tstamp 8d370f48-4c4d-4352-8f4b-e054573be86d))
    (fp_line (start 6.501 -4.918) (end 6.501 4.918) (layer "F.SilkS") (width 0.12) (tstamp 8ee17b2d-fc0a-42dd-9419-bb1ae3290e11))
    (fp_line (start 4.461 -6.021) (end 4.461 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 8fbd790e-64b9-4430-8ad5-572c9acee556))
    (fp_line (start 8.581 -1.861) (end 8.581 1.861) (layer "F.SilkS") (width 0.12) (tstamp 8fcdae7f-31bb-4d7c-9727-23d064b7015e))
    (fp_line (start 4.781 1.44) (end 4.781 5.908) (layer "F.SilkS") (width 0.12) (tstamp 91e4f220-c469-4835-8d84-819e8212121d))
    (fp_line (start 6.341 -5.043) (end 6.341 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 93075909-f25d-433f-8856-250dbc2d72ff))
    (fp_line (start 8.461 -2.209) (end 8.461 2.209) (layer "F.SilkS") (width 0.12) (tstamp 94ea972b-b529-41eb-bb68-54f9d1b6c8df))
    (fp_line (start 5.981 1.44) (end 5.981 5.296) (layer "F.SilkS") (width 0.12) (tstamp 95f894e9-5491-4ec8-bc4a-741fb43aad92))
    (fp_line (start 4.141 1.44) (end 4.141 6.116) (layer "F.SilkS") (width 0.12) (tstamp 98f40e64-ebb4-4f26-9b16-638b5b80acbb))
    (fp_line (start 4.061 -6.137) (end 4.061 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 994988f3-60a7-4137-9458-f63eb4426bf3))
    (fp_line (start 3.981 1.44) (end 3.981 6.156) (layer "F.SilkS") (width 0.12) (tstamp 9b4d64a7-0806-43ea-b65a-7f24268c2969))
    (fp_line (start 5.581 1.44) (end 5.581 5.536) (layer "F.SilkS") (width 0.12) (tstamp 9b7340af-d745-4b2d-8bc0-195391a0c6a4))
    (fp_line (start 2.98 -6.312) (end 2.98 6.312) (layer "F.SilkS") (width 0.12) (tstamp 9b74ac8c-27c1-4ec2-9569-74b8fb239046))
    (fp_line (start 6.741 -4.714) (end 6.741 4.714) (layer "F.SilkS") (width 0.12) (tstamp 9e32c958-0e7c-44ea-8dd0-43dac6ea4e55))
    (fp_line (start 4.581 1.44) (end 4.581 5.981) (layer "F.SilkS") (width 0.12) (tstamp 9e368c4a-095a-4b31-86ab-7adf4f0abe15))
    (fp_line (start 5.461 -5.601) (end 5.461 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 9e8f42ef-c670-4601-a1c7-ca72b65e58a9))
    (fp_line (start 5.701 1.44) (end 5.701 5.468) (layer "F.SilkS") (width 0.12) (tstamp 9ecfdcbb-1047-4804-9df3-0bfcbb72d6ac))
    (fp_line (start 3.781 -6.201) (end 3.781 -1.44) (layer "F.SilkS") (width 0.12) (tstamp a0ae68e9-19cc-4915-a5b9-5c2c8a9875ce))
    (fp_line (start 8.661 -1.583) (end 8.661 1.583) (layer "F.SilkS") (width 0.12) (tstamp a121d404-0fdb-46c1-9589-52301b932a3e))
    (fp_line (start 5.341 1.44) (end 5.341 5.662) (layer "F.SilkS") (width 0.12) (tstamp a1fe24ec-0bf8-406e-9590-7231a11c65ee))
    (fp_line (start 6.381 1.44) (end 6.381 5.012) (layer "F.SilkS") (width 0.12) (tstamp a25326eb-a4b4-4b55-bcc5-b7c144222362))
    (fp_line (start 8.181 -2.844) (end 8.181 2.844) (layer "F.SilkS") (width 0.12) (tstamp a33a6bd0-9a86-48fe-b1b1-58e2b7a1a4cf))
    (fp_line (start 4.341 1.44) (end 4.341 6.059) (layer "F.SilkS") (width 0.12) (tstamp aa2274b8-cfc0-470c-9e20-113d77b42395))
    (fp_line (start 2.94 -6.315) (end 2.94 6.315) (layer "F.SilkS") (width 0.12) (tstamp aba253c6-21a3-4cfe-bda6-64af0d5e97b1))
    (fp_line (start 3.581 1.44) (end 3.581 6.238) (layer "F.SilkS") (width 0.12) (tstamp ace1b1ba-4bbc-4894-b70f-8f7b484f8eed))
    (fp_line (start 3.14 -6.298) (end 3.14 6.298) (layer "F.SilkS") (width 0.12) (tstamp ae610c51-b196-49c0-9129-4875671bb8b8))
    (fp_line (start 6.021 1.44) (end 6.021 5.27) (layer "F.SilkS") (width 0.12) (tstamp b0730312-a9b5-4010-9a87-68927786c094))
    (fp_line (start 6.221 1.44) (end 6.221 5.131) (layer "F.SilkS") (width 0.12) (tstamp b30f8447-0b33-49e9-954d-78af0304411e))
    (fp_line (start 5.381 1.44) (end 5.381 5.642) (layer "F.SilkS") (width 0.12) (tstamp b39e7bbf-84be-4ae5-a961-a100d5551c2b))
    (fp_line (start 3.941 1.44) (end 3.941 6.166) (layer "F.SilkS") (width 0.12) (tstamp b4a00c44-a22e-4db6-9cf1-d04cab0f0750))
    (fp_line (start 3.701 -6.216) (end 3.701 -1.44) (layer "F.SilkS") (width 0.12) (tstamp b5535265-4641-4876-b535-eede06de1f0c))
    (fp_line (start 4.341 -6.059) (end 4.341 -1.44) (layer "F.SilkS") (width 0.12) (tstamp b62bb02e-9565-434d-aaf8-66c0dec687e1))
    (fp_line (start 7.621 -3.75) (end 7.621 3.75) (layer "F.SilkS") (width 0.12) (tstamp b6332897-e264-48c4-a125-9da037723eee))
    (fp_line (start 3.221 -6.29) (end 3.221 6.29) (layer "F.SilkS") (width 0.12) (tstamp b6f08c59-46ce-4141-aff5-c5cad2645027))
    (fp_line (start 6.941 -4.528) (end 6.941 4.528) (layer "F.SilkS") (width 0.12) (tstamp b73ac238-54b4-420c-822e-ea544a74c869))
    (fp_line (start 3.581 -6.238) (end 3.581 -1.44) (layer "F.SilkS") (width 0.12) (tstamp b7cfb9f3-b701-4d06-990e-4ecb909ec318))
    (fp_line (start 8.341 -2.504) (end 8.341 2.504) (layer "F.SilkS") (width 0.12) (tstamp b81617ff-3888-4a2d-9b86-71b80fb28b4c))
    (fp_line (start 7.821 -3.464) (end 7.821 3.464) (layer "F.SilkS") (width 0.12) (tstamp b82a7626-96af-4a93-9e38-6ce8923f07ed))
    (fp_line (start 7.221 -4.238) (end 7.221 4.238) (layer "F.SilkS") (width 0.12) (tstamp bb0d714c-b19e-4bad-be65-8901b0155756))
    (fp_line (start 7.541 -3.856) (end 7.541 3.856) (layer "F.SilkS") (width 0.12) (tstamp bb80ae29-c252-47b2-bcb1-d2f78a3f3124))
    (fp_line (start 5.421 -5.622) (end 5.421 -1.44) (layer "F.SilkS") (width 0.12) (tstamp bba2b4ae-17f4-4306-a169-2b97d415f512))
    (fp_line (start 5.901 -5.347) (end 5.901 -1.44) (layer "F.SilkS") (width 0.12) (tstamp bd15ea8e-7ad6-472e-a496-2d71bdceb6ad))
    (fp_line (start 4.501 -6.008) (end 4.501 -1.44) (layer "F.SilkS") (width 0.12) (tstamp bdc45f36-b8c2-422e-874a-e712cfacbe87))
    (fp_line (start 6.581 -4.852) (end 6.581 4.852) (layer "F.SilkS") (width 0.12) (tstamp be7bf974-2285-4980-bb63-6a30921ff07d))
    (fp_line (start 4.821 1.44) (end 4.821 5.893) (layer "F.SilkS") (width 0.12) (tstamp bf22ce9d-7564-4770-b981-e289f127c406))
    (fp_line (start 4.461 1.44) (end 4.461 6.021) (layer "F.SilkS") (width 0.12) (tstamp c07bcdd5-2bcb-462d-b3ef-0c88106e0bce))
    (fp_line (start 3.341 -6.275) (end 3.341 6.275) (layer "F.SilkS") (width 0.12) (tstamp c0c781e2-37f1-4ead-9534-56f6d7137b51))
    (fp_line (start 5.941 1.44) (end 5.941 5.322) (layer "F.SilkS") (width 0.12) (tstamp c1a3d1ea-10f0-463c-b59d-e1a8bbecc033))
    (fp_line (start 3.02 -6.309) (end 3.02 6.309) (layer "F.SilkS") (width 0.12) (tstamp c1bdaccd-fbef-4a74-841a-e801a3cbd335))
    (fp_line (start 5.701 -5.468) (end 5.701 -1.44) (layer "F.SilkS") (width 0.12) (tstamp c3789301-9a39-4262-96d8-99f4a5bc779b))
    (fp_line (start 6.101 -5.216) (end 6.101 -1.44) (layer "F.SilkS") (width 0.12) (tstamp c37aeb49-8cc1-4fce-83b4-ec5b170c3a95))
    (fp_line (start 5.941 -5.322) (end 5.941 -1.44) (layer "F.SilkS") (width 0.12) (tstamp c78295e4-3fc5-443f-a7e2-472cc45c8551))
    (fp_line (start 5.261 -5.702) (end 5.261 -1.44) (layer "F.SilkS") (width 0.12) (tstamp c93f510c-ccbd-47f7-a134-bd5615425c52))
    (fp_line (start 3.501 -6.252) (end 3.501 6.252) (layer "F.SilkS") (width 0.12) (tstamp ca94abcf-6cd0-4c72-9e2e-a5a103c4440b))
    (fp_line (start 5.061 -5.793) (end 5.061 -1.44) (layer "F.SilkS") (width 0.12) (tstamp cbb270e8-c802-40d6-bfa7-3e28f71d1f8f))
    (fp_line (start 4.901 -5.861) (end 4.901 -1.44) (layer "F.SilkS") (width 0.12) (tstamp cd73c10d-40ac-457a-936a-146cadfbfa8d))
    (fp_line (start 7.101 -4.367) (end 7.101 4.367) (layer "F.SilkS") (width 0.12) (tstamp cdf68ba2-74eb-499a-b790-fa0a755cf2e8))
    (fp_line (start 6.181 -5.16) (end 6.181 -1.44) (layer "F.SilkS") (width 0.12) (tstamp ce653eb9-50bf-4877-993e-eabf7c24f97e))
    (fp_line (start 5.381 -5.642) (end 5.381 -1.44) (layer "F.SilkS") (width 0.12) (tstamp ce6e8009-9b77-406d-b84d-660060f638f0))
    (fp_line (start 3.541 -6.245) (end 3.541 6.245) (layer "F.SilkS") (width 0.12) (tstamp cee88a20-1ac8-4636-a659-b12fde996156))
    (fp_line (start 5.861 -5.372) (end 5.861 -1.44) (layer "F.SilkS") (width 0.12) (tstamp cf200206-3dbe-46ac-94dd-758ebf422f9f))
    (fp_line (start 4.101 1.44) (end 4.101 6.126) (layer "F.SilkS") (width 0.12) (tstamp cf5a11ba-946d-44ce-8790-15f9191c5ffd))
    (fp_line (start 8.541 -1.984) (end 8.541 1.984) (layer "F.SilkS") (width 0.12) (tstamp d05018ff-19df-479a-b672-2f56a620017e))
    (fp_line (start 6.141 1.44) (end 6.141 5.188) (layer "F.SilkS") (width 0.12) (tstamp d12adee8-7fad-470b-9750-c652f61298bc))
    (fp_line (start 6.821 -4.642) (end 6.821 4.642) (layer "F.SilkS") (width 0.12) (tstamp d30c4298-494d-4e6e-83fa-32ba8ff323f1))
    (fp_line (start 3.901 -6.175) (end 3.901 -1.44) (layer "F.SilkS") (width 0.12) (tstamp d4dddc27-8b51-445d-bc23-009f4f5ed95f))
    (fp_line (start 3.661 1.44) (end 3.661 6.224) (layer "F.SilkS") (width 0.12) (tstamp d60e5d3c-6a7b-4768-b98c-1506d9c95c47))
    (fp_line (start 4.941 1.44) (end 4.941 5.845) (layer "F.SilkS") (width 0.12) (tstamp d66a5a79-141c-49ea-9009-fcbed6a3ab78))
    (fp_line (start 4.301 1.44) (end 4.301 6.071) (layer "F.SilkS") (width 0.12) (tstamp d7c4d4b2-c530-48c2-8e63-c781b9630e7b))
    (fp_line (start 2.9 -6.318) (end 2.9 6.318) (layer "F.SilkS") (width 0.12) (tstamp d9012367-3ff5-403b-a3cb-249235bea619))
    (fp_line (start 2.74 -6.326) (end 2.74 6.326) (layer "F.SilkS") (width 0.12) (tstamp d9a9611c-db22-4eda-a28e-6a3a099aeb64))
    (fp_line (start 4.421 -6.034) (end 4.421 -1.44) (layer "F.SilkS") (width 0.12) (tstamp dc89f99b-82f4-4920-8e20-85ebd1e92bfe))
    (fp_line (start 6.221 -5.131) (end 6.221 -1.44) (layer "F.SilkS") (width 0.12) (tstamp dc914099-660f-434a-95bf-be17b21e3652))
    (fp_line (start 8.221 -2.764) (end 8.221 2.764) (layer "F.SilkS") (width 0.12) (tstamp ddf64f24-8c8b-411d-9bc3-249d16ea259a))
    (fp_line (start 7.581 -3.804) (end 7.581 3.804) (layer "F.SilkS") (width 0.12) (tstamp dee4341a-511a-4ac6-80cf-baa3c140ddcc))
    (fp_line (start 4.181 1.44) (end 4.181 6.105) (layer "F.SilkS") (width 0.12) (tstamp e000f3fa-8708-4245-8455-5baec220a52b))
    (fp_line (start 3.861 -6.184) (end 3.861 -1.44) (layer "F.SilkS") (width 0.12) (tstamp e076c89b-f640-470b-aa5a-f45e03cdbc77))
    (fp_line (start 7.381 -4.055) (end 7.381 4.055) (layer "F.SilkS") (width 0.12) (tstamp e21d6411-1a68-412d-8a6c-270ff0d50a1c))
    (fp_line (start 8.821 -0.757) (end 8.821 0.757) (layer "F.SilkS") (width 0.12) (tstamp e23d7e01-653d-4eea-8f70-f8c310296667))
    (fp_line (start 8.501 -2.1) (end 8.501 2.1) (layer "F.SilkS") (width 0.12) (tstamp e44d2a7c-4203-4120-84d8-80f0f7944d9a))
    (fp_line (start 8.061 -3.069) (end 8.061 3.069) (layer "F.SilkS") (width 0.12) (tstamp e46011c3-a8b6-4dc2-984b-911678e2edc9))
    (fp_line (start 5.621 -5.514) (end 5.621 -1.44) (layer "F.SilkS") (width 0.12) (tstamp e5cd113c-3a3f-41f1-8a80-06635504cf7c))
    (fp_line (start 3.701 1.44) (end 3.701 6.216) (layer "F.SilkS") (width 0.12) (tstamp e5e5844e-64b3-4de3-b414-29d028e76058))
    (fp_line (start 6.901 -4.567) (end 6.901 4.567) (layer "F.SilkS") (width 0.12) (tstamp e6f129f1-18c8-46fc-99c6-b217542f52e5))
    (fp_line (start 6.381 -5.012) (end 6.381 -1.44) (layer "F.SilkS") (width 0.12) (tstamp e79d7ca0-32e6-4b2f-a870-5994e036ead5))
    (fp_line (start 3.821 -6.192) (end 3.821 -1.44) (layer "F.SilkS") (width 0.12) (tstamp e7afc655-7859-4642-ab9e-ef65a1a43aa1))
    (fp_line (start 5.821 1.44) (end 5.821 5.397) (layer "F.SilkS") (width 0.12) (tstamp e8d40ca5-fbdf-4128-b34e-d8a6f4317d09))
    (fp_line (start 8.621 -1.728) (end 8.621 1.728) (layer "F.SilkS") (width 0.12) (tstamp e95469fe-6c14-4ff8-a6d7-1d694b1c19df))
    (fp_line (start 4.501 1.44) (end 4.501 6.008) (layer "F.SilkS") (width 0.12) (tstamp ead76fc5-33e5-4679-916a-95db0663f726))
    (fp_line (start 7.181 -4.282) (end 7.181 4.282) (layer "F.SilkS") (width 0.12) (tstamp ec403b3d-7b61-4eed-9d88-c05d6f08fd66))
    (fp_line (start 4.861 1.44) (end 4.861 5.877) (layer "F.SilkS") (width 0.12) (tstamp ec4e61c6-b4e3-42f6-b317-612035fc47f8))
    (fp_line (start 5.501 1.44) (end 5.501 5.58) (layer "F.SilkS") (width 0.12) (tstamp eca1dd4d-a2f3-46fb-a3dc-57c5fb8ddb6e))
    (fp_line (start 4.621 1.44) (end 4.621 5.967) (layer "F.SilkS") (width 0.12) (tstamp ede27e4a-9fe5-4d5d-be8e-50348d99e906))
    (fp_line (start 2.58 -6.33) (end 2.58 6.33) (layer "F.SilkS") (width 0.12) (tstamp efdbceba-0809-4824-8023-001450d61e09))
    (fp_line (start 8.261 -2.681) (end 8.261 2.681) (layer "F.SilkS") (width 0.12) (tstamp f07e1ccd-df23-40e5-a7e6-8e0de04a5bee))
    (fp_line (start 2.7 -6.327) (end 2.7 6.327) (layer "F.SilkS") (width 0.12) (tstamp f0f41944-5197-4463-a6c3-8d8847b5ed6a))
    (fp_line (start 3.1 -6.302) (end 3.1 6.302) (layer "F.SilkS") (width 0.12) (tstamp f1c9c429-726a-4f01-8461-e838ffcb5b48))
    (fp_line (start 4.741 1.44) (end 4.741 5.924) (layer "F.SilkS") (width 0.12) (tstamp f2af0e75-9150-4e8e-b4aa-42c937990d0c))
    (fp_line (start 5.781 1.44) (end 5.781 5.421) (layer "F.SilkS") (width 0.12) (tstamp f2afa456-03bd-4745-a77d-775bb6c18339))
    (fp_line (start 2.62 -6.329) (end 2.62 6.329) (layer "F.SilkS") (width 0.12) (tstamp f5516ed7-7b4a-411c-b719-e4031aab182d))
    (fp_line (start 6.181 1.44) (end 6.181 5.16) (layer "F.SilkS") (width 0.12) (tstamp f7051eb1-2f47-4511-a7fb-b5a7e3d5474a))
    (fp_line (start 5.661 1.44) (end 5.661 5.491) (layer "F.SilkS") (width 0.12) (tstamp f742174d-84f0-48b1-8277-34faa9a1baa5))
    (fp_line (start 5.861 1.44) (end 5.861 5.372) (layer "F.SilkS") (width 0.12) (tstamp f7fcabeb-9866-46db-a0b1-9da563c8798b))
    (fp_line (start 5.101 -5.776) (end 5.101 -1.44) (layer "F.SilkS") (width 0.12) (tstamp fc796969-06f1-40d6-a22f-ef6ea0045bc3))
    (fp_line (start 5.741 1.44) (end 5.741 5.445) (layer "F.SilkS") (width 0.12) (tstamp fd139e58-24dd-4473-abed-12f85686ad8c))
    (fp_circle (center 2.5 0) (end 8.87 0) (layer "F.SilkS") (width 0.12) (fill none) (tstamp 1d738a0a-50f1-4448-b053-ce933d0d9fee))
    (fp_circle (center 2.5 0) (end 9 0) (layer "F.CrtYd") (width 0.05) (fill none) (tstamp e7a579d5-1aae-487f-b1d3-8d6039db54fb))
    (fp_line (start -2.241489 -3.3625) (end -2.241489 -2.1125) (layer "F.Fab") (width 0.1) (tstamp 47bedfc5-eeea-463c-b8a3-b81474ca74d4))
    (fp_line (start -2.866489 -2.7375) (end -1.616489 -2.7375) (layer "F.Fab") (width 0.1) (tstamp 8ce8756f-f95a-4e4d-9eea-f30b1e328372))
    (fp_circle (center 2.5 0) (end 8.75 0) (layer "F.Fab") (width 0.1) (fill none) (tstamp 85e50596-b4db-4d77-a657-08affbb96314))
      (net 10 "Net-(C14-Pad1)") (pintype "passive") (tstamp 12edc0d1-fe56-4134-91aa-93bd57a037a9))
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp 5981f6ad-22e1-429c-8785-4e2337018114))
      (scale (xyz 1 1 1))
  (footprint "Resistor_SMD:R_1210_3225Metric_Pad1.30x2.65mm_HandSolder" (layer "F.Cu")
    (tedit 5F68FEEE) (tstamp 6ea59d20-9c75-4791-b9a5-a155704f23a2)
    (at 33.909 107.931 -90)
    (descr "Resistor SMD 1210 (3225 Metric), square (rectangular) end terminal, IPC_7351 nominal with elongated pad for handsoldering. (Body size source: IPC-SM-782 page 72, https://www.pcb-3d.com/wordpress/wp-content/uploads/ipc-sm-782a_amendment_1_and_2.pdf), generated with kicad-footprint-generator")
    (tags "resistor handsolder")
    (path "/c7c9953d-f9cf-46f5-9920-b8544fa052e5")
    (attr smd)
    (fp_text reference "R34" (at 4.1846 0.0254 90) (layer "F.SilkS")
      (tstamp 2a1e03ce-85d2-4f9c-b038-c2279e9a66ff)
    (fp_text value "SMD 1/4W 1k" (at 0 2.28 90) (layer "F.Fab")
      (tstamp 549180ea-3f08-4f0e-86a5-0a1d989f731b)
    (fp_text user "${REFERENCE}" (at 0.28 0 90) (layer "F.Fab")
      (effects (font (size 0.8 0.8) (thickness 0.12)))
      (tstamp f4c321b5-b704-4a73-98f9-5c2fbd8c2636)
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 5091e5de-3a78-4916-bc72-08bc0d90c9fd))
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp a8a9a48c-8082-4b9c-b235-2e6f11b89d8a))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 44f8a5da-d9fb-4238-89a1-9d8953d8cb6c))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 7012225b-de48-4155-9024-7478c6c8ca45))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 8b1043b1-8786-48a7-96d1-4ea9e85891b7))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 9e8e0c6f-b062-4ea5-9ff9-8a61d3d008ec))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 1b6236cf-2100-46ba-bb4d-00257620432f))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 5ca462e2-13a2-4b3c-886f-e6e5df3f580f))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp cb46b6d3-f55c-428e-a58e-fdd6c342a363))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp df1937d3-c743-4fa8-85de-fc91364c173a))
    (pad "1" smd roundrect (at -1.55 0 270) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 65 "Net-(R34-Pad1)") (pintype "passive") (tstamp fe8f1a3d-ce70-4097-89b0-ac5b0be181e9))
    (pad "2" smd roundrect (at 1.55 0 270) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 110 "Net-(R34-Pad2)") (pintype "passive") (tstamp a9c5b592-353b-4cbc-b391-6c2ca1768eae))
    (model "${KICAD6_3DMODEL_DIR}/Resistor_SMD.3dshapes/R_1210_3225Metric.wrl"
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp 7191d24d-5581-41fc-840e-d42d0a32cf38)
    (at 51.308 84.582)
    (path "/9f8209ed-144c-4aa1-a45b-d3eef41c02bc")
    (attr smd)
    (fp_text reference "R48" (at -3.0988 0.254 90) (layer "F.SilkS")
      (tstamp 111724cc-39c4-463e-ad0e-ce6f3f173d78)
    (fp_text value "SMD 1/4W 1k" (at 0 2.28) (layer "F.Fab")
      (tstamp 09007e41-eb21-4dd8-a786-e41664c6b26f)
    (fp_text user "${REFERENCE}" (at 0 0) (layer "F.Fab")
      (tstamp c05dec68-e600-4655-9367-1c5aa9603b37)
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp c0ab02a4-3172-467a-a971-b18912ca09c0))
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp e0d9dc5f-5c1b-46f1-a0fd-e6a3057427d6))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 94add457-155f-475e-a5e6-d4d13559518e))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp eaf91c16-6b48-4be3-9b8b-26a3b80a24c7))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp ec650f1d-474c-451e-8c70-b237bb4a0208))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp fca1c678-b577-48fd-9f10-f31856b581f6))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 605b57e6-b498-4cab-a09f-182d59731ad6))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 6cd757ff-cc77-4d68-8720-7c9cf744b227))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 9fa847b9-e33c-4585-8072-9f7cfc3476e1))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp a8d907cf-8d1d-4b50-a98c-2a03c9e6690f))
    (pad "1" smd roundrect (at -1.55 0) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 77 "Net-(R48-Pad1)") (pintype "passive") (tstamp 7e357672-b077-4b8a-b7d3-9ac68efba166))
    (pad "2" smd roundrect (at 1.55 0) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 29 "Net-(J14-Pad14)") (pintype "passive") (tstamp 93d06dae-02b5-46fd-a365-af584de7d0ba))
      (scale (xyz 1 1 1))
  (footprint "Connector_PinHeader_1.27mm:PinHeader_2x03_P1.27mm_Vertical_SMD" (layer "F.Cu")
    (tedit 59FED6E3) (tstamp 71cbfce8-cf80-466d-9df0-07424c296520)
    (at 21.844 60.706)
    (descr "surface-mounted straight pin header, 2x03, 1.27mm pitch, double rows")
    (tags "Surface mounted pin header SMD 2x03 1.27mm double row")
    (path "/3dbd241c-1212-4814-8c29-60a3fba11471")
    (attr smd)
    (fp_text reference "J15" (at -5.08 -0.381 90) (layer "F.SilkS")
      (tstamp 83a70a32-0e0e-42dd-9426-97d5b81f3b3f)
    (fp_text value "ISP" (at 0 2.965) (layer "F.Fab")
      (tstamp 06bcd80e-dfae-4500-a211-592b1edb9b1c)
    (fp_text user "${REFERENCE}" (at 0 0 90) (layer "F.Fab")
      (tstamp 90c21631-0916-41bf-91c3-a833b4094736)
    (fp_line (start -3.09 -1.9) (end -1.765 -1.9) (layer "F.SilkS") (width 0.12) (tstamp 63a3ad85-a073-469f-89f4-f49ecd200389))
    (fp_line (start 1.765 -1.965) (end 1.765 -1.9) (layer "F.SilkS") (width 0.12) (tstamp 764cfb42-8cb3-4d43-9749-ddcf46477924))
    (fp_line (start -1.765 1.965) (end 1.765 1.965) (layer "F.SilkS") (width 0.12) (tstamp 7d646cb4-b41a-47bd-974a-aa2cfcffdd0d))
    (fp_line (start -1.765 -1.965) (end -1.765 -1.9) (layer "F.SilkS") (width 0.12) (tstamp 81c5fcfe-a557-4846-b522-7d5571287fe2))
    (fp_line (start -1.765 1.9) (end -1.765 1.965) (layer "F.SilkS") (width 0.12) (tstamp 9ffd0317-9ce8-40e5-8aa8-762e60a71b3c))
    (fp_line (start 1.765 1.9) (end 1.765 1.965) (layer "F.SilkS") (width 0.12) (tstamp aa0294c6-a300-45c8-967d-0324630eabfa))
    (fp_line (start -1.765 -1.965) (end 1.765 -1.965) (layer "F.SilkS") (width 0.12) (tstamp b60f21b6-c2d3-4257-a0cc-d7febfbbd3b5))
    (fp_line (start -4.3 2.45) (end 4.3 2.45) (layer "F.CrtYd") (width 0.05) (tstamp 1c8a6ba0-af66-4678-89c6-c4b3aa5f0927))
    (fp_line (start 4.3 -2.45) (end -4.3 -2.45) (layer "F.CrtYd") (width 0.05) (tstamp 7811749b-3ff1-49e7-9600-d08e749533f9))
    (fp_line (start 4.3 2.45) (end 4.3 -2.45) (layer "F.CrtYd") (width 0.05) (tstamp c056f65d-97f4-4f82-aa4c-0cce3bd6454a))
    (fp_line (start -4.3 -2.45) (end -4.3 2.45) (layer "F.CrtYd") (width 0.05) (tstamp e280bbe8-7fb8-42ab-98a6-ef19b1af1ed0))
    (fp_line (start 1.705 -1.905) (end 1.705 1.905) (layer "F.Fab") (width 0.1) (tstamp 01d203d2-d1d4-41aa-b001-cb55ed9f59cf))
    (fp_line (start -1.705 -0.2) (end -2.75 -0.2) (layer "F.Fab") (width 0.1) (tstamp 030797f6-7a39-45e7-a719-6178fbb8cc11))
    (fp_line (start -2.75 1.07) (end -2.75 1.47) (layer "F.Fab") (width 0.1) (tstamp 2f86887c-61ce-4b2b-bb84-818ac16417dc))
    (fp_line (start 2.75 -1.47) (end 2.75 -1.07) (layer "F.Fab") (width 0.1) (tstamp 3ae7613e-01f9-4804-a529-ff527f428e6a))
    (fp_line (start 2.75 -1.07) (end 1.705 -1.07) (layer "F.Fab") (width 0.1) (tstamp 4c56d0c8-38ac-46f0-a3e2-58fd2889d857))
    (fp_line (start -1.705 1.905) (end -1.705 -1.47) (layer "F.Fab") (width 0.1) (tstamp 56c9eb43-43b3-4bbc-90ad-497e1b25a674))
    (fp_line (start -2.75 1.47) (end -1.705 1.47) (layer "F.Fab") (width 0.1) (tstamp 57d32abe-2c0e-4194-90c3-6dfc65988e63))
    (fp_line (start -2.75 -1.47) (end -2.75 -1.07) (layer "F.Fab") (width 0.1) (tstamp 5a6ffd81-fb9d-410f-99f3-970ef44143da))
    (fp_line (start -2.75 0.2) (end -1.705 0.2) (layer "F.Fab") (width 0.1) (tstamp 5bb194ac-7551-4398-bb26-17908c0fca3d))
    (fp_line (start -1.705 -1.47) (end -1.27 -1.905) (layer "F.Fab") (width 0.1) (tstamp 6a887ea9-db43-4a3b-a1e2-f58f22f6da3f))
    (fp_line (start 2.75 1.07) (end 2.75 1.47) (layer "F.Fab") (width 0.1) (tstamp 6c0eccc8-33fe-41c3-8604-6c4041ddc4f3))
    (fp_line (start -1.705 -1.47) (end -2.75 -1.47) (layer "F.Fab") (width 0.1) (tstamp 92615488-791b-4853-a028-827450a3c374))
    (fp_line (start 1.705 1.07) (end 2.75 1.07) (layer "F.Fab") (width 0.1) (tstamp 9d1baa8d-4330-41f8-ac62-79c272670662))
    (fp_line (start 1.705 -0.2) (end 2.75 -0.2) (layer "F.Fab") (width 0.1) (tstamp a7195646-a6b7-458a-adb0-168ed5cd7d93))
    (fp_line (start 2.75 -0.2) (end 2.75 0.2) (layer "F.Fab") (width 0.1) (tstamp adb510e9-d0b9-4710-a241-92ad96836f98))
    (fp_line (start -1.27 -1.905) (end 1.705 -1.905) (layer "F.Fab") (width 0.1) (tstamp b3366bf7-019a-4f08-b1d8-3f53957ee91a))
    (fp_line (start 1.705 1.905) (end -1.705 1.905) (layer "F.Fab") (width 0.1) (tstamp c5f71f4e-47f5-405c-a498-fb89df6157f8))
    (fp_line (start 1.705 -1.47) (end 2.75 -1.47) (layer "F.Fab") (width 0.1) (tstamp d784dc62-c357-4c15-a540-3d1d30f8b3fa))
    (fp_line (start -2.75 -1.07) (end -1.705 -1.07) (layer "F.Fab") (width 0.1) (tstamp dbf47758-6d1c-49f0-9c7e-40341b2bd47a))
    (fp_line (start 2.75 0.2) (end 1.705 0.2) (layer "F.Fab") (width 0.1) (tstamp f1ad9cb2-f104-4626-9014-5fcfdc1cca70))
    (fp_line (start 2.75 1.47) (end 1.705 1.47) (layer "F.Fab") (width 0.1) (tstamp fc37a5e4-4df4-49ee-9ca8-92c059c07981))
    (fp_line (start -1.705 1.07) (end -2.75 1.07) (layer "F.Fab") (width 0.1) (tstamp fed2c407-0b8a-4538-8b93-5de1baf80fa1))
    (fp_line (start -2.75 -0.2) (end -2.75 0.2) (layer "F.Fab") (width 0.1) (tstamp ff642ad9-b5f6-4d44-a2bd-6ddfc88189a7))
    (pad "1" smd rect (at -1.95 -1.27) (size 2.4 0.74) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 35 "Net-(J15-Pad1)") (pinfunction "Pin_1") (pintype "passive") (tstamp 52d832b4-f157-48da-a0c8-da8c5536d15d))
    (pad "2" smd rect (at 1.95 -1.27) (size 2.4 0.74) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 85 "Net-(C20-Pad1)") (pinfunction "Pin_2") (pintype "passive") (tstamp 1e5c5883-a333-4100-bac5-687b8b9fe105))
    (pad "3" smd rect (at -1.95 0) (size 2.4 0.74) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 36 "Net-(J15-Pad3)") (pinfunction "Pin_3") (pintype "passive") (tstamp 8c42e40a-e5ca-43c4-9006-a528d53875c6))
    (pad "4" smd rect (at 1.95 0) (size 2.4 0.74) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 37 "Net-(J15-Pad4)") (pinfunction "Pin_4") (pintype "passive") (tstamp b8dcba08-05b3-41cc-9005-c05605735f2f))
    (pad "5" smd rect (at -1.95 1.27) (size 2.4 0.74) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 12 "Net-(C25-Pad1)") (pinfunction "Pin_5") (pintype "passive") (tstamp 0c7515c3-c20d-43c3-99ab-da99e818e519))
    (pad "6" smd rect (at 1.95 1.27) (size 2.4 0.74) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 1 "Net-(BT1-Pad2)") (pinfunction "Pin_6") (pintype "passive") (tstamp 74465ca0-3063-40b4-85a8-e98407ead8b8))
    (model "${KICAD6_3DMODEL_DIR}/Connector_PinHeader_1.27mm.3dshapes/PinHeader_2x03_P1.27mm_Vertical_SMD.wrl"
      (scale (xyz 1 1 1))
  (footprint "TerminalBlock_RND:TerminalBlock_RND_205-00001_1x02_P5.00mm_Horizontal" (layer "F.Cu")
    (tedit 5B294F8C) (tstamp 741f116b-28ce-4e6f-833b-336ce8224ef5)
    (at 165.981 42.056 90)
    (descr "terminal block RND 205-00001, 2 pins, pitch 5mm, size 10x9mm^2, drill diamater 1.3mm, pad diameter 2.5mm, see http://cdn-reichelt.de/documents/datenblatt/C151/RND_205-00001_DB_EN.pdf, script-generated using https://github.com/pointhi/kicad-footprint-generator/scripts/TerminalBlock_RND")
    (tags "THT terminal block RND 205-00001 pitch 5mm size 10x9mm^2 drill 1.3mm pad 2.5mm")
    (path "/4151c326-a3cc-4823-89a9-b95a9d9c61f9")
    (attr through_hole)
    (fp_text reference "J2" (at 2.5 -6.06 90) (layer "F.SilkS")
      (tstamp b12ea663-0c53-4d5a-b162-93781539c0a6)
    (fp_text value "DC 21V 2" (at 2.5 5.06 90) (layer "F.Fab")
      (tstamp b005a706-0ad0-4e00-a340-5df45e7133cc)
    (fp_text user "${REFERENCE}" (at 2.5 -6.06 90) (layer "F.Fab")
      (tstamp 9d7426c3-1d83-4ad6-ae37-27e3ec73076e)
    (fp_line (start 7.56 -5.06) (end 7.56 4.06) (layer "F.SilkS") (width 0.12) (tstamp 12831473-7b9b-434b-98c3-b44370d6b8a6))
    (fp_line (start 3.82 0.976) (end 3.726 1.069) (layer "F.SilkS") (width 0.12) (tstamp 1d059534-ad8b-43a7-8201-6ed4cc55b126))
    (fp_line (start 3.99 1.216) (end 3.931 1.274) (layer "F.SilkS") (width 0.12) (tstamp 21968ca6-ba47-4ce5-abd4-bdd25d78f239))
    (fp_line (start -2.56 2.5) (end 7.56 2.5) (layer "F.SilkS") (width 0.12) (tstamp 3f35d3a0-ba67-4ba6-96ff-50c79ab80bf4))
    (fp_line (start -2.8 2.56) (end -2.8 4.3) (layer "F.SilkS") (width 0.12) (tstamp 42db95c2-b7dd-433a-82f2-2796012c8661))
    (fp_line (start -2.8 4.3) (end -1.3 4.3) (layer "F.SilkS") (width 0.12) (tstamp 491194ce-4366-435a-869b-9d373210d72c))
    (fp_line (start -2.56 4.06) (end 7.56 4.06) (layer "F.SilkS") (width 0.12) (tstamp 73d3a983-89a1-41b5-82d3-e1c64361e03c))
    (fp_line (start 6.07 -1.275) (end 6.011 -1.216) (layer "F.SilkS") (width 0.12) (tstamp 9876583c-fe38-444a-b404-6ffe92001e99))
    (fp_line (start 6.275 -1.069) (end 6.181 -0.976) (layer "F.SilkS") (width 0.12) (tstamp 9e75a047-d5a9-4e20-bd87-b9411e49882f))
    (fp_line (start -2.56 -5.06) (end 7.56 -5.06) (layer "F.SilkS") (width 0.12) (tstamp ac73de78-c6a1-4226-bc7e-b7b28fc38179))
    (fp_line (start -2.56 -5.06) (end -2.56 4.06) (layer "F.SilkS") (width 0.12) (tstamp ca8e5766-9b95-4ce3-91e8-32898dcb9bba))
    (fp_arc (start 1.483953 -0.789089) (mid 1.680708 -0.00005) (end 1.484 0.789) (layer "F.SilkS") (width 0.12) (tstamp 6f349f00-f028-42a3-b50d-31710b2f608e))
    (fp_arc (start 0.029383 1.68045) (mid -0.392304 1.634281) (end -0.789 1.484) (layer "F.SilkS") (width 0.12) (tstamp 77d2af7b-203d-400e-8465-0f422fd00700))
    (fp_arc (start 0.788712 1.483352) (mid 0.406429 1.630097) (end 0 1.68) (layer "F.SilkS") (width 0.12) (tstamp c8ab31f3-436f-4fa0-82da-8133ef25d948))
    (fp_arc (start -0.789089 -1.483953) (mid -0.00005 -1.680708) (end 0.789 -1.484) (layer "F.SilkS") (width 0.12) (tstamp da47314f-94d5-4c49-9f7f-4ed475cff31d))
    (fp_arc (start -1.483953 0.789089) (mid -1.680708 0.00005) (end -1.484 -0.789) (layer "F.SilkS") (width 0.12) (tstamp f30df66c-f31e-45d9-be69-1afc93c0d94c))
    (fp_circle (center 5 -3) (end 5.9 -3) (layer "F.SilkS") (width 0.12) (fill none) (tstamp 4a81fe30-a0fb-43c4-bc71-d3f2db086131))
    (fp_circle (center 5 0) (end 6.68 0) (layer "F.SilkS") (width 0.12) (fill none) (tstamp cd372aba-29d9-4185-a4fa-ae9f485cfba7))
    (fp_circle (center 0 -3) (end 0.9 -3) (layer "F.SilkS") (width 0.12) (fill none) (tstamp ffc5c165-421e-4366-9678-d43c1ed92c19))
    (fp_line (start -3 4.5) (end 8 4.5) (layer "F.CrtYd") (width 0.05) (tstamp 05720ccb-7565-4117-b571-eeda17048704))
    (fp_line (start 8 -5.5) (end -3 -5.5) (layer "F.CrtYd") (width 0.05) (tstamp 936a7291-fbf8-4b5b-a32a-1aca960ac79d))
    (fp_line (start 8 4.5) (end 8 -5.5) (layer "F.CrtYd") (width 0.05) (tstamp a8f612c2-a73b-4262-84ba-3fefd523908c))
    (fp_line (start -3 -5.5) (end -3 4.5) (layer "F.CrtYd") (width 0.05) (tstamp e9d89651-9555-436d-8d7a-d3ac33b64cce))
    (fp_line (start 5.955 -1.138) (end 3.863 0.955) (layer "F.Fab") (width 0.1) (tstamp 0be7b79e-a0b6-419a-a9bc-8c4dd17f73c4))
    (fp_line (start -2.5 -5) (end 7.5 -5) (layer "F.Fab") (width 0.1) (tstamp 0f10855c-ff25-404a-a397-7d0c0d30f774))
    (fp_line (start 0.955 -1.138) (end -1.138 0.955) (layer "F.Fab") (width 0.1) (tstamp 19127d88-2b02-4d45-8d34-5365ab5ae5e5))
    (fp_line (start -2.5 2.5) (end 7.5 2.5) (layer "F.Fab") (width 0.1) (tstamp 5230d93f-8fdc-459b-bfcd-85e4c23e6bfe))
    (fp_line (start 1.138 -0.955) (end -0.955 1.138) (layer "F.Fab") (width 0.1) (tstamp 57ea177e-e280-49bf-8f35-1ad8d11aed2a))
    (fp_line (start 7.5 4) (end -1 4) (layer "F.Fab") (width 0.1) (tstamp 74a2a543-d05b-47e1-845c-0e82d19c2bb6))
    (fp_line (start -1 4) (end -2.5 2.5) (layer "F.Fab") (width 0.1) (tstamp 7e650424-e2fe-4ea6-b0cb-cf0b31585b85))
    (fp_line (start 6.138 -0.955) (end 4.046 1.138) (layer "F.Fab") (width 0.1) (tstamp a9130ee1-bfdc-412c-a1ff-4939daf52951))
    (fp_line (start -2.5 2.5) (end -2.5 -5) (layer "F.Fab") (width 0.1) (tstamp bd6ec4df-b004-4f53-adca-867d8cededd8))
    (fp_line (start 7.5 -5) (end 7.5 4) (layer "F.Fab") (width 0.1) (tstamp f9b34574-2d89-4202-98bd-4a7cc6aea0b5))
    (fp_circle (center 0 0) (end 1.5 0) (layer "F.Fab") (width 0.1) (fill none) (tstamp 3e1d2636-7adf-4fad-9d92-426523fd244d))
    (fp_circle (center 5 0) (end 6.5 0) (layer "F.Fab") (width 0.1) (fill none) (tstamp 676e037a-d357-4f2a-8d1d-e2aa8a46f5fb))
    (fp_circle (center 0 -3) (end 0.9 -3) (layer "F.Fab") (width 0.1) (fill none) (tstamp b9bc2c42-0c2c-4361-82ff-612494b9810c))
    (fp_circle (center 5 -3) (end 5.9 -3) (layer "F.Fab") (width 0.1) (fill none) (tstamp c1abb0ec-e8d5-42a1-ab1c-e359c8db8d17))
    (pad "1" thru_hole rect (at 0 0 90) (size 2.5 2.5) (drill 1.3) (layers *.Cu *.Mask)
      (net 24 "Net-(F3-Pad1)") (pinfunction "Pin_1") (pintype "passive") (tstamp 1b3d4851-c4a4-4ee9-9901-6b8a0213c39f))
    (pad "2" thru_hole circle (at 5 0 90) (size 2.5 2.5) (drill 1.3) (layers *.Cu *.Mask)
      (net 1 "Net-(BT1-Pad2)") (pinfunction "Pin_2") (pintype "passive") (tstamp f341dd7a-eb95-4ffb-83d3-cac96279b96a))
    (model "${KICAD6_3DMODEL_DIR}/TerminalBlock_RND.3dshapes/TerminalBlock_RND_205-00001_1x02_P5.00mm_Horizontal.wrl"
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp 750adcc3-e8f3-4634-87c1-2be768da3208)
    (at 160.655 133.35 -90)
    (path "/15318a2f-2182-4bc8-8d3a-8a0b657d18ac")
    (attr smd)
    (fp_text reference "R40" (at 0 2.159 90) (layer "F.SilkS")
      (tstamp b367b399-dc4a-4304-ac92-936bbd16528c)
    (fp_text value "SMD 1/4W 2k2" (at 0 2.28 90) (layer "F.Fab")
      (tstamp 0021229a-a6ef-4349-bb8a-34e381288ef1)
      (tstamp ef73ac76-ebba-4c05-865e-a4b15c125db7)
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 1af949a0-5687-4079-9d91-4b8d476d7c7b))
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp 435f8201-2cec-4623-a078-13d87cbc96d9))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 476a2e12-7067-4be4-bfcb-eefd6d8c211c))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 54a6eba0-f048-4624-994a-cd3b88a2c1c8))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 7dede676-7b4d-492e-9907-3ef9f63e7a4e))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp e27dabab-f24f-46f2-9099-5e7df4b71aab))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 3873e355-7c1f-4edb-9270-42c0d7312f15))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 92582024-5c7c-4771-ae91-332c73d825c3))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp bc4d5147-68bc-413c-bac4-a94709a90068))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp fcc828c3-e091-4a22-b13f-d0846148da43))
      (net 131 "Net-(D10-Pad1)") (pintype "passive") (tstamp 5cb79cd5-f129-4f34-ab67-a34f369ae9b1))
      (net 135 "Net-(J13-Pad9)") (pintype "passive") (tstamp ef283adf-d458-4154-a96c-67ea4ba16e35))
      (scale (xyz 1 1 1))
  (footprint "Package_TO_SOT_THT:TO-92_Inline" (layer "F.Cu")
    (tedit 5A1DD157) (tstamp 7770f644-fbc2-4ea5-af5c-d1cfbf5a0fd7)
    (at 80.666 51.181 -90)
    (descr "TO-92 leads in-line, narrow, oval pads, drill 0.75mm (see NXP sot054_po.pdf)")
    (tags "to-92 sc-43 sc-43a sot54 PA33 transistor")
    (path "/d5ef5fd1-3b33-40c4-8ddb-efd9598fe4c3")
    (attr through_hole)
    (fp_text reference "U9" (at 1.143 2.815 -90) (layer "F.SilkS")
      (tstamp 378b76ec-b094-4702-b4cb-a943c5064eff)
    (fp_text value "LM78L05_TO92" (at 1.27 2.79 90) (layer "F.Fab")
      (tstamp 1d0c0da3-d50d-43d5-b908-2c1894238e69)
    (fp_text user "${REFERENCE}" (at 1.27 0 90) (layer "F.Fab")
      (tstamp 30f821dc-18bd-4810-ae1f-df7c333164ab)
    (fp_line (start -0.53 1.85) (end 3.07 1.85) (layer "F.SilkS") (width 0.12) (tstamp 2e30a85d-4aca-40ac-b79a-9d272cad477b))
    (fp_arc (start -0.568478 1.838478) (mid -1.132087 -0.994977) (end 1.27 -2.6) (layer "F.SilkS") (width 0.12) (tstamp 662c43ab-afe0-4601-8e75-7319ada794dd))
    (fp_arc (start 1.27 -2.6) (mid 3.672087 -0.994977) (end 3.108478 1.838478) (layer "F.SilkS") (width 0.12) (tstamp c8a9d7ad-8e1f-4691-b3a4-b1055aa2236b))
    (fp_line (start -1.46 -2.73) (end 4 -2.73) (layer "F.CrtYd") (width 0.05) (tstamp 1dcdebd4-5b92-4a27-8bc5-b113f375d88f))
    (fp_line (start 4 2.01) (end -1.46 2.01) (layer "F.CrtYd") (width 0.05) (tstamp 3384d560-118c-4acb-a141-7a8e0db42639))
    (fp_line (start 4 2.01) (end 4 -2.73) (layer "F.CrtYd") (width 0.05) (tstamp a31cb7cc-8590-4e64-8efa-c8b920b527cd))
    (fp_line (start -1.46 -2.73) (end -1.46 2.01) (layer "F.CrtYd") (width 0.05) (tstamp f4161843-07b2-45b6-af6d-131f21f7c70c))
    (fp_line (start -0.5 1.75) (end 3 1.75) (layer "F.Fab") (width 0.1) (tstamp 769a34d6-b320-4425-810c-3cd0e1b3ba04))
    (fp_arc (start 1.27 -2.48) (mid 3.561221 -0.949055) (end 3.023625 1.753625) (layer "F.Fab") (width 0.1) (tstamp 1a592283-e0ad-4880-97bf-af59f35cc83c))
    (fp_arc (start -0.483625 1.753625) (mid -1.021221 -0.949055) (end 1.27 -2.48) (layer "F.Fab") (width 0.1) (tstamp 872e0d6d-bc50-4176-b92f-b4ca82421722))
    (pad "1" thru_hole rect (at 0 0 270) (size 1.05 1.5) (drill 0.75) (layers *.Cu *.Mask)
      (net 3 "Net-(C1-Pad2)") (pinfunction "VO") (pintype "power_out") (tstamp 6c248bbb-8248-454d-9ddc-b075325b25ed))
    (pad "2" thru_hole oval (at 1.27 0 270) (size 1.05 1.5) (drill 0.75) (layers *.Cu *.Mask)
      (net 1 "Net-(BT1-Pad2)") (pinfunction "GND") (pintype "power_in") (tstamp 28f30378-94e1-4516-85b7-8a30ff581701))
    (pad "3" thru_hole oval (at 2.54 0 270) (size 1.05 1.5) (drill 0.75) (layers *.Cu *.Mask)
      (net 44 "Net-(C11-Pad1)") (pinfunction "VI") (pintype "power_in") (tstamp 63aa8f80-b96f-4359-9786-d76dff501683))
    (model "${KICAD6_3DMODEL_DIR}/Package_TO_SOT_THT.3dshapes/TO-92_Inline.wrl"
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp 78b0c16b-f42a-4bef-8f6e-f010697f1ace)
    (at 53.467 89.916 90)
    (path "/6a152ba3-4306-4b7a-b60f-7d376a1704da")
    (attr smd)
    (fp_text reference "R52" (at 3.048 0.254 180) (layer "F.SilkS")
      (tstamp 1937068a-0f49-49bf-805c-4acdb26f821c)
    (fp_text value "100R 0W25 SMD 1/4W 100" (at 0 2.28 90) (layer "F.Fab")
      (tstamp 065e3f60-0848-4655-8d1f-680e59337b68)
      (tstamp 27c67b25-5ff2-42e8-8089-4a3080ae5e75)
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 051afe83-36ee-442d-a654-37198c1e4284))
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp a63e53b6-df06-42af-a1d2-58c0468b88e4))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 5eaae7d0-4e28-4639-9251-6d7facb4ea2a))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 89df46d1-eee7-423f-a9dc-09997f39cb3d))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 9f851484-0355-47b8-91b2-d2d7c8c3faa8))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp fbb41dd1-1857-4e60-8fcc-799d30fc3f9e))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 05f8c6cb-ae57-49d8-aa52-da7697faef9e))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 1bed7d03-6aaf-4d23-bf24-0c94d10b0aa4))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp e28e7cba-dab0-4f5a-a597-066bd91a5425))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp fb767abe-3a7a-4a3c-8ad4-bae20dd27ed2))
    (pad "1" smd roundrect (at -1.55 0 90) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 85 "Net-(C20-Pad1)") (pintype "passive") (tstamp 906fa08e-f9e7-4ac6-8a63-f67d3c477685))
    (pad "2" smd roundrect (at 1.55 0 90) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 101 "Net-(R52-Pad2)") (pintype "passive") (tstamp 8197ca95-8a54-46aa-8af5-827cce952f60))
      (scale (xyz 1 1 1))
  (footprint "Capacitor_THT:CP_Radial_D8.0mm_P3.50mm" (layer "F.Cu")
    (tedit 5AE50EF0) (tstamp 78cc2bce-8e6e-4a69-95aa-da35b0d381c9)
    (at 86.995 139.066651 90)
    (descr "CP, Radial series, Radial, pin pitch=3.50mm, , diameter=8mm, Electrolytic Capacitor")
    (tags "CP Radial series Radial pin pitch 3.50mm  diameter 8mm Electrolytic Capacitor")
    (path "/ecfbc8fe-0577-4c63-a836-6e34d6f525c2")
    (attr through_hole)
    (fp_text reference "C23" (at 5.208651 -4.699 270) (layer "F.SilkS")
      (tstamp 5a083ec1-e0ae-4465-ad74-4aa9d330a71a)
    (fp_text value "470U 10V RAD FC 470/10" (at 1.652651 5.334 270) (layer "F.Fab")
      (tstamp 3a14c819-d358-41bf-b74f-68d6d7ac2cba)
    (fp_text user "${REFERENCE}" (at 1.75 0 90) (layer "F.Fab")
      (tstamp 22770023-b94a-4609-bbf7-3ae785da2f9b)
    (fp_line (start 5.271 -2.102) (end 5.271 2.102) (layer "F.SilkS") (width 0.12) (tstamp 05fb9496-a053-4ee8-9202-6965c7615aa0))
    (fp_line (start 4.351 -3.156) (end 4.351 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 0652f181-bfd7-4689-a5f7-d298d65218ce))
    (fp_line (start 3.431 -3.722) (end 3.431 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 0ae44f24-3bc4-450a-9bec-dd1dbfd763d4))
    (fp_line (start 4.471 -3.055) (end 4.471 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 0bc0f5e4-4b2f-4444-abdd-5e289f6e19d1))
    (fp_line (start 5.591 -1.453) (end 5.591 1.453) (layer "F.SilkS") (width 0.12) (tstamp 170af24e-7d1e-4174-97c1-7444d4264dfb))
    (fp_line (start 1.79 -4.08) (end 1.79 4.08) (layer "F.SilkS") (width 0.12) (tstamp 172b686a-30ed-4df0-a6fd-1f692d38b67d))
    (fp_line (start 3.391 -3.74) (end 3.391 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 1750853a-d932-4ce9-b49e-907aa944cd07))
    (fp_line (start 2.791 1.04) (end 2.791 3.947) (layer "F.SilkS") (width 0.12) (tstamp 17548dd1-4c0f-47f6-a3e0-39d804bfa663))
    (fp_line (start 3.951 -3.444) (end 3.951 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 17a35c0b-81eb-4c9d-be56-566506857f38))
    (fp_line (start 5.111 -2.345) (end 5.111 2.345) (layer "F.SilkS") (width 0.12) (tstamp 180da554-c28a-4217-b575-9fc3609ac4c2))
    (fp_line (start 2.951 1.04) (end 2.951 3.902) (layer "F.SilkS") (width 0.12) (tstamp 191cb64b-592d-452d-8fc9-f43f0d708922))
    (fp_line (start 4.591 -2.945) (end 4.591 2.945) (layer "F.SilkS") (width 0.12) (tstamp 196c6eee-c5f9-46e6-83cb-29b2dd20bba3))
    (fp_line (start 3.271 1.04) (end 3.271 3.79) (layer "F.SilkS") (width 0.12) (tstamp 1b020240-551e-4f86-88e8-0f021fb43de8))
    (fp_line (start 3.831 1.04) (end 3.831 3.517) (layer "F.SilkS") (width 0.12) (tstamp 1ceb72da-0475-4f33-be9a-153724fc1a59))
    (fp_line (start 2.631 1.04) (end 2.631 3.985) (layer "F.SilkS") (width 0.12) (tstamp 1e063781-c0fb-4dbe-ba2a-ca2fd5f36071))
    (fp_line (start 4.071 -3.365) (end 4.071 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 1f371e32-d164-4507-be77-988127065df9))
    (fp_line (start 3.151 -3.835) (end 3.151 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 1f95fda8-21cf-4d4c-bde6-eb1e2326d2be))
    (fp_line (start 3.231 1.04) (end 3.231 3.805) (layer "F.SilkS") (width 0.12) (tstamp 23399f70-11a8-4724-a0f2-9b31ef370fd1))
    (fp_line (start 4.631 -2.907) (end 4.631 2.907) (layer "F.SilkS") (width 0.12) (tstamp 24fb2ef8-5d82-4857-8c6e-4e76f62f3751))
    (fp_line (start 1.75 -4.08) (end 1.75 4.08) (layer "F.SilkS") (width 0.12) (tstamp 258eb0b5-ff0c-4e8d-b3a6-942ef6d78082))
    (fp_line (start 2.551 -4.002) (end 2.551 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 2949d66f-a869-46e7-983e-fe59e0c6a67d))
    (fp_line (start 2.911 1.04) (end 2.911 3.914) (layer "F.SilkS") (width 0.12) (tstamp 2baf895b-0c8c-4492-82f6-f52c7ab17092))
    (fp_line (start 4.311 1.04) (end 4.311 3.189) (layer "F.SilkS") (width 0.12) (tstamp 2d8538f0-6e5a-406f-906d-e99d95f30f22))
    (fp_line (start 5.031 -2.454) (end 5.031 2.454) (layer "F.SilkS") (width 0.12) (tstamp 2e347916-2e63-4c62-99b3-8fbbb4ab7272))
    (fp_line (start 4.391 1.04) (end 4.391 3.124) (layer "F.SilkS") (width 0.12) (tstamp 319a7de9-17c0-4a5b-9c99-0fdac9fc07fa))
    (fp_line (start 2.671 1.04) (end 2.671 3.976) (layer "F.SilkS") (width 0.12) (tstamp 3481aa16-87be-475d-9667-4aa56b101e34))
    (fp_line (start 4.911 -2.604) (end 4.911 2.604) (layer "F.SilkS") (width 0.12) (tstamp 38a1a54c-b94e-46e8-9cdb-20ad4348984d))
    (fp_line (start 3.471 1.04) (end 3.471 3.704) (layer "F.SilkS") (width 0.12) (tstamp 3a44661e-1a6b-4292-bd9a-fc8aa157155e))
    (fp_line (start 5.831 -0.533) (end 5.831 0.533) (layer "F.SilkS") (width 0.12) (tstamp 3b538715-d733-41e6-aa1c-d35427f37226))
    (fp_line (start 4.511 -3.019) (end 4.511 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 409160df-d21c-47ac-b5ed-94d62d902f1b))
    (fp_line (start 5.351 -1.964) (end 5.351 1.964) (layer "F.SilkS") (width 0.12) (tstamp 414cdaf0-894a-4d04-bd45-159d672f141d))
    (fp_line (start 4.031 -3.392) (end 4.031 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 41581ae7-860d-40be-8413-8698d4182f39))
    (fp_line (start 3.231 -3.805) (end 3.231 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 4374d36e-faf6-4d18-9e1c-abf97f24b9b8))
    (fp_line (start 2.511 1.04) (end 2.511 4.01) (layer "F.SilkS") (width 0.12) (tstamp 437b633b-2a65-4b34-beb5-97ec6447e0e7))
    (fp_line (start 3.071 -3.863) (end 3.071 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 4afacca4-c883-4bba-9f97-c9eb9c01403d))
    (fp_line (start 3.631 1.04) (end 3.631 3.627) (layer "F.SilkS") (width 0.12) (tstamp 4b706312-c3bb-4a70-a254-dbe4bc697295))
    (fp_line (start 3.511 -3.686) (end 3.511 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 4c2d2fa3-7394-42cf-a3b6-1b0d22953e24))
    (fp_line (start 2.591 -3.994) (end 2.591 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 4dba47d4-4d9b-4ee1-8ea5-32d4d631bc61))
    (fp_line (start 3.671 -3.606) (end 3.671 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 4ed2b1ea-35e0-4adc-9180-44a8bda114ac))
    (fp_line (start 3.951 1.04) (end 3.951 3.444) (layer "F.SilkS") (width 0.12) (tstamp 4f173665-6a81-4433-9b5c-c35da5dcc42b))
    (fp_line (start 3.751 1.04) (end 3.751 3.562) (layer "F.SilkS") (width 0.12) (tstamp 4f925d3d-522c-4b47-b092-71f0281c2ba7))
    (fp_line (start 4.191 -3.28) (end 4.191 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 519eeac8-fc96-423e-9ba0-74a2000090b4))
    (fp_line (start 5.791 -0.768) (end 5.791 0.768) (layer "F.SilkS") (width 0.12) (tstamp 527f5150-c137-4995-89cf-f8087f449374))
    (fp_line (start 4.391 -3.124) (end 4.391 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 5901414f-a796-47b1-b922-192040097a8a))
    (fp_line (start 4.111 1.04) (end 4.111 3.338) (layer "F.SilkS") (width 0.12) (tstamp 597cab23-2ddf-4aad-88ed-095b7a1ebcb9))
    (fp_line (start 3.431 1.04) (end 3.431 3.722) (layer "F.SilkS") (width 0.12) (tstamp 59c247fc-4e0f-4eae-b050-fc5a2843b894))
    (fp_line (start 1.87 -4.079) (end 1.87 4.079) (layer "F.SilkS") (width 0.12) (tstamp 59e69491-5b04-4074-98d8-019629718125))
    (fp_line (start 5.191 -2.228) (end 5.191 2.228) (layer "F.SilkS") (width 0.12) (tstamp 5d841716-6c11-46c1-b840-867e97c31206))
    (fp_line (start 4.431 -3.09) (end 4.431 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 5dc1c1a2-5789-45a1-af34-6078e466f5fb))
    (fp_line (start 3.791 -3.54) (end 3.791 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 5fc15b19-5483-4754-b0c8-644aacd6d2ce))
    (fp_line (start 4.151 -3.309) (end 4.151 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 6085f2da-6ac0-4471-af9e-88bd3dec3af3))
    (fp_line (start 3.911 1.04) (end 3.911 3.469) (layer "F.SilkS") (width 0.12) (tstamp 61fba405-155f-4a47-a888-14879b1f177d))
    (fp_line (start 3.191 1.04) (end 3.191 3.821) (layer "F.SilkS") (width 0.12) (tstamp 62696f1e-69b1-4c29-93a8-3e7c62e6dd86))
    (fp_line (start 2.871 -3.925) (end 2.871 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 62b9fb6b-8108-433a-82f6-7fd2998aac2b))
    (fp_line (start 3.111 1.04) (end 3.111 3.85) (layer "F.SilkS") (width 0.12) (tstamp 64b6b48f-2e04-43d5-93ba-ff2013ca2090))
    (fp_line (start 4.791 -2.741) (end 4.791 2.741) (layer "F.SilkS") (width 0.12) (tstamp 64bc133d-8878-474f-af09-7c85d8fa609b))
    (fp_line (start 4.751 -2.784) (end 4.751 2.784) (layer "F.SilkS") (width 0.12) (tstamp 669c267b-f9ee-4a51-ba22-1f4ae55e341f))
    (fp_line (start 3.031 -3.877) (end 3.031 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 67b71f15-ffe2-4e4f-8dba-c926d749bfda))
    (fp_line (start 2.711 1.04) (end 2.711 3.967) (layer "F.SilkS") (width 0.12) (tstamp 6965e40b-380b-4124-a3b1-8b3d935ab127))
    (fp_line (start 3.351 1.04) (end 3.351 3.757) (layer "F.SilkS") (width 0.12) (tstamp 698eed78-4697-45b2-b510-d978413e4be0))
    (fp_line (start 5.391 -1.89) (end 5.391 1.89) (layer "F.SilkS") (width 0.12) (tstamp 6c2ecf71-06b4-4440-990b-758880f16fc3))
    (fp_line (start 5.631 -1.346) (end 5.631 1.346) (layer "F.SilkS") (width 0.12) (tstamp 71aafdfb-4e4a-4480-8593-587ab82b5e76))
    (fp_line (start 3.711 1.04) (end 3.711 3.584) (layer "F.SilkS") (width 0.12) (tstamp 74e9db44-7923-43e7-8030-8d04e25a2a0c))
    (fp_line (start 3.831 -3.517) (end 3.831 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 788b02a6-a8fc-4cbd-84a6-595b433a6ac3))
    (fp_line (start 5.151 -2.287) (end 5.151 2.287) (layer "F.SilkS") (width 0.12) (tstamp 7aa7ac5a-63ee-4550-a07d-e4632e9411b8))
    (fp_line (start 2.871 1.04) (end 2.871 3.925) (layer "F.SilkS") (width 0.12) (tstamp 7b69127c-3463-4266-adcb-19a0cea6b3d4))
    (fp_line (start 2.31 -4.042) (end 2.31 4.042) (layer "F.SilkS") (width 0.12) (tstamp 7bdc1960-8b37-4e9d-b0a5-61fc7bedaceb))
    (fp_line (start 2.11 -4.065) (end 2.11 4.065) (layer "F.SilkS") (width 0.12) (tstamp 7c47f478-9eef-4dcf-b282-90c1b7ae7b1f))
    (fp_line (start 3.271 -3.79) (end 3.271 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 7fe79316-8e61-46cf-a182-259cb0eb29a1))
    (fp_line (start 2.19 -4.057) (end 2.19 4.057) (layer "F.SilkS") (width 0.12) (tstamp 801c551c-8e12-4707-9702-4e2c65395701))
    (fp_line (start 2.791 -3.947) (end 2.791 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 80d7d57c-36ed-457a-a96b-e4d67a046f27))
    (fp_line (start 2.23 -4.052) (end 2.23 4.052) (layer "F.SilkS") (width 0.12) (tstamp 810b0cb9-856a-4d8f-89f0-5a488614f459))
    (fp_line (start 2.471 -4.017) (end 2.471 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 82eb0767-1006-4000-92fc-158b3edd5a27))
    (fp_line (start 2.951 -3.902) (end 2.951 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 845989fe-9348-4aab-a77e-a7abe7463cc6))
    (fp_line (start 4.231 1.04) (end 4.231 3.25) (layer "F.SilkS") (width 0.12) (tstamp 845fc42b-8777-4d71-a604-95732dc6e513))
    (fp_line (start 4.311 -3.189) (end 4.311 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 860625e5-5a75-4997-8928-a70b89509227))
    (fp_line (start 3.551 1.04) (end 3.551 3.666) (layer "F.SilkS") (width 0.12) (tstamp 897f53ab-198d-45c3-a9e4-e838ffb01a62))
    (fp_line (start 3.751 -3.562) (end 3.751 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 8b40ac79-955c-4224-98d7-ca0eb4b6e796))
    (fp_line (start 1.95 -4.076) (end 1.95 4.076) (layer "F.SilkS") (width 0.12) (tstamp 8c012ce7-da49-4e7f-a0d5-077d926b9fed))
    (fp_line (start 4.551 -2.983) (end 4.551 2.983) (layer "F.SilkS") (width 0.12) (tstamp 8d17d472-8ac6-4791-975a-f47e0e9d9c24))
    (fp_line (start 5.751 -0.948) (end 5.751 0.948) (layer "F.SilkS") (width 0.12) (tstamp 8f64c89d-9c30-4f07-9f9f-e31fe66a4b4e))
    (fp_line (start 2.631 -3.985) (end 2.631 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 9320219a-7d1b-4a39-b6ed-551275d6c48d))
    (fp_line (start 2.751 -3.957) (end 2.751 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 944a09fc-d824-4efa-8634-7d4bca3a780d))
    (fp_line (start 2.831 -3.936) (end 2.831 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 967ba08f-c049-4422-8f15-904019ff191e))
    (fp_line (start 3.991 -3.418) (end 3.991 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 97291ce4-7076-49b0-afb8-d01e55af9ccd))
    (fp_line (start 5.431 -1.813) (end 5.431 1.813) (layer "F.SilkS") (width 0.12) (tstamp 9794cc66-9c3c-484c-a649-afcbda13f660))
    (fp_line (start 2.471 1.04) (end 2.471 4.017) (layer "F.SilkS") (width 0.12) (tstamp 98cceb97-6d30-467e-908f-fe20c06f6bfd))
    (fp_line (start 4.871 -2.651) (end 4.871 2.651) (layer "F.SilkS") (width 0.12) (tstamp 9d34c5f3-d303-446f-9541-6810c358152e))
    (fp_line (start 4.511 1.04) (end 4.511 3.019) (layer "F.SilkS") (width 0.12) (tstamp 9e43fa9c-112c-4ff8-9231-2ef278f0263b))
    (fp_line (start 3.471 -3.704) (end 3.471 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 9ed59fde-22e3-4e99-844b-17a2e4c982ef))
    (fp_line (start 3.711 -3.584) (end 3.711 -1.04) (layer "F.SilkS") (width 0.12) (tstamp a6a529bc-2bd2-4990-8d02-12e834cabbbb))
    (fp_line (start 5.711 -1.098) (end 5.711 1.098) (layer "F.SilkS") (width 0.12) (tstamp a872af3c-ccf2-4fca-8a6e-153d9634d266))
    (fp_line (start 3.151 1.04) (end 3.151 3.835) (layer "F.SilkS") (width 0.12) (tstamp aa6a1750-88a1-461b-9270-16d792980808))
    (fp_line (start 2.991 1.04) (end 2.991 3.889) (layer "F.SilkS") (width 0.12) (tstamp abbb8d9a-0f44-45c3-a28b-2c7671925d7f))
    (fp_line (start 5.311 -2.034) (end 5.311 2.034) (layer "F.SilkS") (width 0.12) (tstamp aee4608e-0402-4795-8589-1851146dd546))
    (fp_line (start 4.271 -3.22) (end 4.271 -1.04) (layer "F.SilkS") (width 0.12) (tstamp b0c6946d-5a27-4027-9222-d5b7d87dd8f1))
    (fp_line (start 2.07 -4.068) (end 2.07 4.068) (layer "F.SilkS") (width 0.12) (tstamp b1d5cc56-338c-4865-a9f6-aff2937f21b9))
    (fp_line (start 4.671 -2.867) (end 4.671 2.867) (layer "F.SilkS") (width 0.12) (tstamp b235bb9d-ba84-4d52-b262-a83f72124b99))
    (fp_line (start 3.591 1.04) (end 3.591 3.647) (layer "F.SilkS") (width 0.12) (tstamp b2bcfcaa-d64e-45d5-a725-0ec45b353752))
    (fp_line (start 3.031 1.04) (end 3.031 3.877) (layer "F.SilkS") (width 0.12) (tstamp b4ea30a9-47f9-4619-9f6c-e5a539c349e3))
    (fp_line (start 2.03 -4.071) (end 2.03 4.071) (layer "F.SilkS") (width 0.12) (tstamp b92331e8-0e1e-4f26-b9f4-5f0f507db329))
    (fp_line (start 5.071 -2.4) (end 5.071 2.4) (layer "F.SilkS") (width 0.12) (tstamp bb6ac18b-bd21-4b83-bf75-516ff144e415))
    (fp_line (start 4.431 1.04) (end 4.431 3.09) (layer "F.SilkS") (width 0.12) (tstamp bc84f5cd-4f92-4eea-8444-91882a6d513b))
    (fp_line (start 3.671 1.04) (end 3.671 3.606) (layer "F.SilkS") (width 0.12) (tstamp bd183b49-4698-4719-bc95-8b2a6c9a82a7))
    (fp_line (start 4.831 -2.697) (end 4.831 2.697) (layer "F.SilkS") (width 0.12) (tstamp bd4cdc23-a147-48b1-9cb0-1873760ced12))
    (fp_line (start 4.951 -2.556) (end 4.951 2.556) (layer "F.SilkS") (width 0.12) (tstamp befca175-64d0-42bf-95a5-47fa34647b82))
    (fp_line (start 2.15 -4.061) (end 2.15 4.061) (layer "F.SilkS") (width 0.12) (tstamp bff16c69-f816-4f7d-b79d-f4d8bceb51be))
    (fp_line (start 5.551 -1.552) (end 5.551 1.552) (layer "F.SilkS") (width 0.12) (tstamp c2eb8350-c6a2-4ce4-bac7-42d6babcf6fa))
    (fp_line (start 2.751 1.04) (end 2.751 3.957) (layer "F.SilkS") (width 0.12) (tstamp c65fbf4e-76d2-432b-b320-1dd00c4fbf47))
    (fp_line (start 2.711 -3.967) (end 2.711 -1.04) (layer "F.SilkS") (width 0.12) (tstamp c78ac553-95d8-45b7-b933-963d69d16548))
    (fp_line (start 2.991 -3.889) (end 2.991 -1.04) (layer "F.SilkS") (width 0.12) (tstamp c8a36af8-49a2-4862-8c04-ae696c04fcfa))
    (fp_line (start 3.511 1.04) (end 3.511 3.686) (layer "F.SilkS") (width 0.12) (tstamp c8e432cf-61d7-45f6-b049-37e18b368783))
    (fp_line (start 4.351 1.04) (end 4.351 3.156) (layer "F.SilkS") (width 0.12) (tstamp c8f955da-c6c3-4101-a7c4-9ed7e9549cd8))
    (fp_line (start 3.351 -3.757) (end 3.351 -1.04) (layer "F.SilkS") (width 0.12) (tstamp c997ee4c-56b4-4b3f-8c56-3d40aeb329cc))
    (fp_line (start 2.831 1.04) (end 2.831 3.936) (layer "F.SilkS") (width 0.12) (tstamp cbdb2491-c777-4068-bd16-c107cf9f7e94))
    (fp_line (start 3.631 -3.627) (end 3.631 -1.04) (layer "F.SilkS") (width 0.12) (tstamp cc6fabf6-7fd0-4307-a88d-95aab8587688))
    (fp_line (start -2.659698 -2.315) (end -1.859698 -2.315) (layer "F.SilkS") (width 0.12) (tstamp cd7c3542-dae8-4755-a958-c9d39b61bb34))
    (fp_line (start -2.259698 -2.715) (end -2.259698 -1.915) (layer "F.SilkS") (width 0.12) (tstamp cd8bc9df-e19e-4ef0-a202-80f640d76ee8))
    (fp_line (start 4.031 1.04) (end 4.031 3.392) (layer "F.SilkS") (width 0.12) (tstamp d0d66124-6b7a-4cad-b6a4-48f1b108c922))
    (fp_line (start 2.35 -4.037) (end 2.35 4.037) (layer "F.SilkS") (width 0.12) (tstamp d4792588-6066-4f8f-b450-0d89683a4924))
    (fp_line (start 2.39 -4.03) (end 2.39 4.03) (layer "F.SilkS") (width 0.12) (tstamp d4d86a71-b409-478b-ab29-09919a7d2760))
    (fp_line (start 2.671 -3.976) (end 2.671 -1.04) (layer "F.SilkS") (width 0.12) (tstamp d5178686-73bc-4907-a178-fe02b044cd63))
    (fp_line (start 1.91 -4.077) (end 1.91 4.077) (layer "F.SilkS") (width 0.12) (tstamp d6c7712e-95a8-4607-a7c9-6321ca8750ac))
    (fp_line (start 2.591 1.04) (end 2.591 3.994) (layer "F.SilkS") (width 0.12) (tstamp d730e24a-2d27-400b-b93e-36f14f736e66))
    (fp_line (start 1.83 -4.08) (end 1.83 4.08) (layer "F.SilkS") (width 0.12) (tstamp d9a6658d-01f1-4a3c-95db-c416f3eca749))
    (fp_line (start 5.471 -1.731) (end 5.471 1.731) (layer "F.SilkS") (width 0.12) (tstamp d9b35afe-7f3e-4009-832e-cf8c2976f8ec))
    (fp_line (start 3.391 1.04) (end 3.391 3.74) (layer "F.SilkS") (width 0.12) (tstamp da86dda8-8b16-42e7-8d39-9c862f966ce4))
    (fp_line (start 3.871 -3.493) (end 3.871 -1.04) (layer "F.SilkS") (width 0.12) (tstamp dab446e2-97ce-4e9a-a576-7acf79115c2d))
    (fp_line (start 2.551 1.04) (end 2.551 4.002) (layer "F.SilkS") (width 0.12) (tstamp dc9d22f4-6dd8-4090-a169-173f321f6719))
    (fp_line (start 4.071 1.04) (end 4.071 3.365) (layer "F.SilkS") (width 0.12) (tstamp de1d3df9-83d8-4366-9ade-2c0ba5ec1fd6))
    (fp_line (start 4.231 -3.25) (end 4.231 -1.04) (layer "F.SilkS") (width 0.12) (tstamp deb7f0f3-a288-4594-8ce6-a59aa6c558c6))
    (fp_line (start 5.511 -1.645) (end 5.511 1.645) (layer "F.SilkS") (width 0.12) (tstamp e096f9e7-bee5-4a7e-b981-cd6370a251fe))
    (fp_line (start 5.231 -2.166) (end 5.231 2.166) (layer "F.SilkS") (width 0.12) (tstamp e1937b43-3565-4215-a7ee-07c0ab2639d2))
    (fp_line (start 4.151 1.04) (end 4.151 3.309) (layer "F.SilkS") (width 0.12) (tstamp e1b479c2-ad51-4d25-a3b2-bfab93f59a00))
    (fp_line (start 4.191 1.04) (end 4.191 3.28) (layer "F.SilkS") (width 0.12) (tstamp e1b8aaef-86f2-4a37-9b70-ea7fef96e652))
    (fp_line (start 4.111 -3.338) (end 4.111 -1.04) (layer "F.SilkS") (width 0.12) (tstamp e394bec6-72d9-4358-9d2f-09f8f843f63e))
    (fp_line (start 3.311 1.04) (end 3.311 3.774) (layer "F.SilkS") (width 0.12) (tstamp e4004343-474c-4d0f-afa2-d64bc3e97fdc))
    (fp_line (start 2.511 -4.01) (end 2.511 -1.04) (layer "F.SilkS") (width 0.12) (tstamp e46d32a5-87f4-4cea-a7e3-2889243a220e))
    (fp_line (start 4.711 -2.826) (end 4.711 2.826) (layer "F.SilkS") (width 0.12) (tstamp e5b173e0-a72f-4414-aaa5-e3992c2bf177))
    (fp_line (start 3.551 -3.666) (end 3.551 -1.04) (layer "F.SilkS") (width 0.12) (tstamp e735aa80-309e-4e84-aef4-1419dbc02a1c))
    (fp_line (start 4.471 1.04) (end 4.471 3.055) (layer "F.SilkS") (width 0.12) (tstamp e86c4758-2113-42ae-89f1-deee985bba5f))
    (fp_line (start 2.911 -3.914) (end 2.911 -1.04) (layer "F.SilkS") (width 0.12) (tstamp e8fa4955-c50f-42a9-84ac-425bad067ce5))
    (fp_line (start 3.111 -3.85) (end 3.111 -1.04) (layer "F.SilkS") (width 0.12) (tstamp eaaf7a86-ec82-4939-9f4c-37671a98aeb6))
    (fp_line (start 3.311 -3.774) (end 3.311 -1.04) (layer "F.SilkS") (width 0.12) (tstamp ec66acf3-b674-473e-bde0-81d274630461))
    (fp_line (start 2.27 -4.048) (end 2.27 4.048) (layer "F.SilkS") (width 0.12) (tstamp edb7a6e9-2f59-4383-bbb5-9988395a7ae4))
    (fp_line (start 3.911 -3.469) (end 3.911 -1.04) (layer "F.SilkS") (width 0.12) (tstamp ef3d1750-35ec-4fb5-bd5a-81bc3ec1d483))
    (fp_line (start 3.791 1.04) (end 3.791 3.54) (layer "F.SilkS") (width 0.12) (tstamp f149efd5-62b1-4abb-b23c-224562379d49))
    (fp_line (start 4.271 1.04) (end 4.271 3.22) (layer "F.SilkS") (width 0.12) (tstamp f2a694f8-9878-4cd8-9de7-6f1636665c5f))
    (fp_line (start 3.871 1.04) (end 3.871 3.493) (layer "F.SilkS") (width 0.12) (tstamp f5a95f1e-1f0c-474e-bfe3-438b66ec4437))
    (fp_line (start 2.43 -4.024) (end 2.43 4.024) (layer "F.SilkS") (width 0.12) (tstamp f699b967-644f-4b78-9e56-dfc7b248b654))
    (fp_line (start 3.991 1.04) (end 3.991 3.418) (layer "F.SilkS") (width 0.12) (tstamp f7405f47-182b-4576-a9a2-99c68edfa5cc))
    (fp_line (start 3.071 1.04) (end 3.071 3.863) (layer "F.SilkS") (width 0.12) (tstamp f90e65dd-0701-4528-8641-3b5a455fc62a))
    (fp_line (start 1.99 -4.074) (end 1.99 4.074) (layer "F.SilkS") (width 0.12) (tstamp fab604e9-9af5-4a36-879c-85e6f8c0df4f))
    (fp_line (start 4.991 -2.505) (end 4.991 2.505) (layer "F.SilkS") (width 0.12) (tstamp fb903adc-e7de-44c4-ac75-f2602cbe4cb8))
    (fp_line (start 5.671 -1.229) (end 5.671 1.229) (layer "F.SilkS") (width 0.12) (tstamp fcfdeb62-9825-4dd7-b6d1-af07ab8e22ee))
    (fp_line (start 3.591 -3.647) (end 3.591 -1.04) (layer "F.SilkS") (width 0.12) (tstamp fd809112-4a49-47fa-b9e7-d29bd266f312))
    (fp_line (start 3.191 -3.821) (end 3.191 -1.04) (layer "F.SilkS") (width 0.12) (tstamp ffe19846-dfe0-4d58-b14e-28c5d4aeb9b9))
    (fp_circle (center 1.75 0) (end 5.87 0) (layer "F.SilkS") (width 0.12) (fill none) (tstamp c2a13980-efc8-4b69-9f6f-3b3c3aa3b7e7))
    (fp_circle (center 1.75 0) (end 6 0) (layer "F.CrtYd") (width 0.05) (fill none) (tstamp 23bdde3a-90a9-475b-b79b-b0c71ad58257))
    (fp_line (start -1.276759 -2.1475) (end -1.276759 -1.3475) (layer "F.Fab") (width 0.1) (tstamp 00389e29-9a60-4a6a-9180-69f42d044d05))
    (fp_line (start -1.676759 -1.7475) (end -0.876759 -1.7475) (layer "F.Fab") (width 0.1) (tstamp 76f952f2-a1c4-435f-997d-11abd06e80d1))
    (fp_circle (center 1.75 0) (end 5.75 0) (layer "F.Fab") (width 0.1) (fill none) (tstamp 241ee051-9069-4608-b385-a2eaf874e5d0))
    (pad "1" thru_hole rect (at 0 0 90) (size 1.6 1.6) (drill 0.8) (layers *.Cu *.Mask)
      (net 85 "Net-(C20-Pad1)") (pintype "passive") (tstamp 89b217c2-f6e2-420b-8118-f93d4200fbfc))
    (pad "2" thru_hole circle (at 3.5 0 90) (size 1.6 1.6) (drill 0.8) (layers *.Cu *.Mask)
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp e9a282f9-61b8-4b80-b97c-ed1d5fc7c700))
    (model "${KICAD6_3DMODEL_DIR}/Capacitor_THT.3dshapes/CP_Radial_D8.0mm_P3.50mm.wrl"
      (offset (xyz 0 0 0))
      (scale (xyz 1 1 1))
      (rotate (xyz 0 0 0))
  (footprint "Capacitor_SMD:C_1206_3216Metric_Pad1.33x1.80mm_HandSolder" (layer "F.Cu")
    (tedit 5F68FEEF) (tstamp 78ee6b1b-72da-44fe-9666-b1854abb395d)
    (at 50.419 53.086)
    (descr "Capacitor SMD 1206 (3216 Metric), square (rectangular) end terminal, IPC_7351 nominal with elongated pad for handsoldering. (Body size source: IPC-SM-782 page 76, https://www.pcb-3d.com/wordpress/wp-content/uploads/ipc-sm-782a_amendment_1_and_2.pdf), generated with kicad-footprint-generator")
    (tags "capacitor handsolder")
    (property "Sheetfile" "Lauflicht_Steuerplatine.kicad_sch")
    (property "Sheetname" "")
    (path "/96eabcbd-31fc-4703-8f5b-b23712c02d19")
    (attr smd)
    (fp_text reference "C32" (at -3.556 -1.524 90) (layer "F.SilkS")
      (effects (font (size 1 1) (thickness 0.15)))
      (tstamp d0e6be6f-827f-4ef5-9694-0bf7a764ae49)
    (fp_text value "100n 50V KEM X7R1206 1,0U" (at 0 1.85) (layer "F.Fab")
      (tstamp 1a97bd3f-f092-414e-9ab6-98290ae5e078)
      (tstamp 413ce980-a972-4a72-8172-4cfd552f1f5e)
    (fp_line (start -0.711252 0.91) (end 0.711252 0.91) (layer "F.SilkS") (width 0.12) (tstamp c0c9382a-7d26-400b-8b94-52c971781dee))
    (fp_line (start -0.711252 -0.91) (end 0.711252 -0.91) (layer "F.SilkS") (width 0.12) (tstamp facc6668-ac26-46e7-86bf-228a03d0314f))
    (fp_line (start 2.48 -1.15) (end 2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp 3c979420-a683-4290-95e6-a225130d263d))
    (fp_line (start -2.48 1.15) (end -2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp 627e8e03-6120-48a4-be5d-351193645a78))
    (fp_line (start 2.48 1.15) (end -2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp d33fad25-37c5-4569-9bbc-720fb8b21c59))
    (fp_line (start -2.48 -1.15) (end 2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp d9b00170-626c-4675-b254-793adc830b75))
    (fp_line (start -1.6 0.8) (end -1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp 0b1ced82-4078-4283-8841-fb900698f72a))
    (fp_line (start -1.6 -0.8) (end 1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp 5c4cfc77-eafc-47f9-aac1-2ebb0ce68e14))
    (fp_line (start 1.6 0.8) (end -1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp 8aae1da6-a9b2-4b51-8f74-1e3d49e6ec21))
    (fp_line (start 1.6 -0.8) (end 1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp e9fd27d9-a441-463c-b880-49c7a5661924))
    (pad "1" smd roundrect (at -1.5625 0) (size 1.325 1.8) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1886792453)
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp d4b460ce-6a63-4d88-995f-7995ecc76009))
    (pad "2" smd roundrect (at 1.5625 0) (size 1.325 1.8) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1886792453)
      (net 85 "Net-(C20-Pad1)") (pintype "passive") (tstamp fa94f787-a142-4f36-94ef-8f33436a24a0))
    (model "${KICAD6_3DMODEL_DIR}/Capacitor_SMD.3dshapes/C_1206_3216Metric.wrl"
      (scale (xyz 1 1 1))
    (tedit 5B294F8C) (tstamp 7938a088-f759-4382-b2c9-761b7396b8d2)
    (at 165.981 68.286 90)
    (path "/26d2d476-7066-4e65-9dd5-26ea3945786b")
    (attr through_hole)
    (fp_text reference "J10" (at 2.5 -6.06 90) (layer "F.SilkS")
      (tstamp ecf8b027-5131-465b-abe6-db741a580394)
    (fp_text value "DC 21V Out" (at 2.5 5.06 90) (layer "F.Fab")
      (tstamp 2052fa05-343e-4159-a01e-ec73006d9536)
      (tstamp de35b336-e496-4caa-9c66-a966bd41f0e2)
    (fp_line (start 7.56 -5.06) (end 7.56 4.06) (layer "F.SilkS") (width 0.12) (tstamp 211cd3a9-c3c7-4064-8138-877554923836))
    (fp_line (start 6.07 -1.275) (end 6.011 -1.216) (layer "F.SilkS") (width 0.12) (tstamp 46a2501c-bf03-493b-a52a-8d58e32e71d6))
    (fp_line (start -2.56 4.06) (end 7.56 4.06) (layer "F.SilkS") (width 0.12) (tstamp 6d8540ac-c362-465b-aafb-68d435c85437))
    (fp_line (start 3.99 1.216) (end 3.931 1.274) (layer "F.SilkS") (width 0.12) (tstamp 72cf7472-3f25-4202-8ad5-bdbd6e982f2e))
    (fp_line (start -2.56 2.5) (end 7.56 2.5) (layer "F.SilkS") (width 0.12) (tstamp 8c2bcadf-d255-4a43-9965-52a09b66e0ba))
    (fp_line (start 3.82 0.976) (end 3.726 1.069) (layer "F.SilkS") (width 0.12) (tstamp b949cd65-7d3e-4bb2-a7ed-ab07c74579ba))
    (fp_line (start -2.56 -5.06) (end 7.56 -5.06) (layer "F.SilkS") (width 0.12) (tstamp c80db25e-1798-49c5-aa94-c663d0c004fc))
    (fp_line (start -2.56 -5.06) (end -2.56 4.06) (layer "F.SilkS") (width 0.12) (tstamp caae4f57-92ce-4d5c-8aba-1e5ce2ec786b))
    (fp_line (start -2.8 2.56) (end -2.8 4.3) (layer "F.SilkS") (width 0.12) (tstamp d1aa4b49-802c-46ee-8841-11a59d2305a8))
    (fp_line (start 6.275 -1.069) (end 6.181 -0.976) (layer "F.SilkS") (width 0.12) (tstamp dd4c40f1-2877-4ffb-94be-3da3e142cc66))
    (fp_line (start -2.8 4.3) (end -1.3 4.3) (layer "F.SilkS") (width 0.12) (tstamp e202779e-e11c-4b49-9192-b26776802cdb))
    (fp_arc (start -0.789089 -1.483953) (mid -0.00005 -1.680708) (end 0.789 -1.484) (layer "F.SilkS") (width 0.12) (tstamp 012debbf-4250-4bf8-9351-e509a5c6895d))
    (fp_arc (start 0.029383 1.68045) (mid -0.392304 1.634281) (end -0.789 1.484) (layer "F.SilkS") (width 0.12) (tstamp a07d4e58-5cfb-4ea2-8a63-d2eab9cfb483))
    (fp_arc (start 0.788712 1.483352) (mid 0.406429 1.630097) (end 0 1.68) (layer "F.SilkS") (width 0.12) (tstamp a643f480-9e97-40e2-aa8d-e96f726a6d54))
    (fp_arc (start -1.483953 0.789089) (mid -1.680708 0.00005) (end -1.484 -0.789) (layer "F.SilkS") (width 0.12) (tstamp ba5115e5-80d4-46de-a49d-6be235ed880d))
    (fp_arc (start 1.483953 -0.789089) (mid 1.680708 -0.00005) (end 1.484 0.789) (layer "F.SilkS") (width 0.12) (tstamp ba544980-ce10-4280-9ae2-db545f76f9e3))
    (fp_circle (center 5 0) (end 6.68 0) (layer "F.SilkS") (width 0.12) (fill none) (tstamp 2a25efa3-60bd-4e6f-bca7-9bf496f2dd9c))
    (fp_circle (center 5 -3) (end 5.9 -3) (layer "F.SilkS") (width 0.12) (fill none) (tstamp 510aee21-f657-4c55-aced-64b3aa06ab2c))
    (fp_circle (center 0 -3) (end 0.9 -3) (layer "F.SilkS") (width 0.12) (fill none) (tstamp 6468b688-a472-4f6b-a1fb-ac9e22c2387b))
    (fp_line (start -3 4.5) (end 8 4.5) (layer "F.CrtYd") (width 0.05) (tstamp 0959db14-3ca8-414f-9f21-fced62b2b709))
    (fp_line (start 8 4.5) (end 8 -5.5) (layer "F.CrtYd") (width 0.05) (tstamp 4d60f22a-f919-45af-901a-294d7e7d242d))
    (fp_line (start -3 -5.5) (end -3 4.5) (layer "F.CrtYd") (width 0.05) (tstamp 6b6fdcd3-631d-4eab-8ebb-68046dfaf9bc))
    (fp_line (start 8 -5.5) (end -3 -5.5) (layer "F.CrtYd") (width 0.05) (tstamp 9b129927-7aba-4055-9b23-ce77a7258eff))
    (fp_line (start -2.5 2.5) (end -2.5 -5) (layer "F.Fab") (width 0.1) (tstamp 122972f6-9d4d-4acc-a9cd-1005db69ab5c))
    (fp_line (start 7.5 -5) (end 7.5 4) (layer "F.Fab") (width 0.1) (tstamp 29bcb72a-c45d-444d-b6a0-43f2608e18d1))
    (fp_line (start 0.955 -1.138) (end -1.138 0.955) (layer "F.Fab") (width 0.1) (tstamp 2c4ad5f9-9194-4697-b4ca-bf6adb3228c4))
    (fp_line (start -2.5 -5) (end 7.5 -5) (layer "F.Fab") (width 0.1) (tstamp 32c31e73-be5f-4990-bb6a-f6f2b75165ff))
    (fp_line (start -1 4) (end -2.5 2.5) (layer "F.Fab") (width 0.1) (tstamp 477957ba-89a5-4cb9-9b44-4c56aebf45bd))
    (fp_line (start 7.5 4) (end -1 4) (layer "F.Fab") (width 0.1) (tstamp 6d2983ed-cfa5-4866-8f10-2d4fca1d0311))
    (fp_line (start 5.955 -1.138) (end 3.863 0.955) (layer "F.Fab") (width 0.1) (tstamp 8586ca50-1135-4a92-98db-d414846422fe))
    (fp_line (start -2.5 2.5) (end 7.5 2.5) (layer "F.Fab") (width 0.1) (tstamp b5d460c0-1eeb-48bc-9572-db2b7663a92b))
    (fp_line (start 6.138 -0.955) (end 4.046 1.138) (layer "F.Fab") (width 0.1) (tstamp c4c39f6d-2b22-48da-ad39-2c4d01345d65))
    (fp_line (start 1.138 -0.955) (end -0.955 1.138) (layer "F.Fab") (width 0.1) (tstamp e308ab64-75fc-4447-a61b-ce1b10ac791b))
    (fp_circle (center 5 -3) (end 5.9 -3) (layer "F.Fab") (width 0.1) (fill none) (tstamp 640f422c-0390-480a-a1dc-137952db135c))
    (fp_circle (center 0 0) (end 1.5 0) (layer "F.Fab") (width 0.1) (fill none) (tstamp 7f0c235d-36cd-4cdf-93b1-6bc9be83b8c8))
    (fp_circle (center 5 0) (end 6.5 0) (layer "F.Fab") (width 0.1) (fill none) (tstamp 93d1f197-86cc-489f-94db-b4d6a810b1a4))
    (fp_circle (center 0 -3) (end 0.9 -3) (layer "F.Fab") (width 0.1) (fill none) (tstamp e2f3ecf6-e938-4c88-a06f-74b64ab150a0))
      (net 10 "Net-(C14-Pad1)") (pinfunction "Pin_1") (pintype "passive") (tstamp 2aef706f-2b55-4090-b26f-0426694f23de))
      (net 1 "Net-(BT1-Pad2)") (pinfunction "Pin_2") (pintype "passive") (tstamp 258e0e15-6e4c-43aa-833e-05b9c84e7d53))
      (scale (xyz 1 1 1))
  (footprint "Package_TO_SOT_THT:TO-220-3_Vertical" (layer "F.Cu")
    (tedit 5AC8BA0D) (tstamp 7ae81651-8612-44a6-8422-59761ef31073)
    (at 119.2885 65.786 -90)
    (descr "TO-220-3, Vertical, RM 2.54mm, see https://www.vishay.com/docs/66542/to-220-1.pdf")
    (tags "TO-220-3 Vertical RM 2.54mm")
    (path "/4cc84471-bee2-4c0a-8638-d47abce43756")
    (attr through_hole)
    (fp_text reference "U2" (at 2.54 2.3215 90) (layer "F.SilkS")
      (tstamp fcf987bb-9bfb-4fb0-b21e-6914dd33a8ae)
    (fp_text value "LM78M05_TO220" (at 2.54 2.5 90) (layer "F.Fab")
      (tstamp 101c1a7d-eebf-4e29-aefa-d199b8df50c6)
    (fp_text user "${REFERENCE}" (at 2.54 -4.27 90) (layer "F.Fab")
      (tstamp 9268b509-924c-420b-902f-06f169c0cd0e)
    (fp_line (start -2.58 -3.27) (end 7.66 -3.27) (layer "F.SilkS") (width 0.12) (tstamp 2943d019-a3f0-430c-9570-cde376f158c8))
    (fp_line (start -2.58 1.371) (end 7.66 1.371) (layer "F.SilkS") (width 0.12) (tstamp 8672b5bc-0045-48ce-af49-aad3ea4deeb2))
    (fp_line (start 4.391 -3.27) (end 4.391 -1.76) (layer "F.SilkS") (width 0.12) (tstamp 9033e15e-12ca-48a1-b1c6-5ab94a518341))
    (fp_line (start -2.58 -3.27) (end -2.58 1.371) (layer "F.SilkS") (width 0.12) (tstamp 94948b1b-bb69-40a7-82b6-027ebe1dc7f4))
    (fp_line (start 7.66 -3.27) (end 7.66 1.371) (layer "F.SilkS") (width 0.12) (tstamp 9b272257-6e97-4f4d-9d6f-cb8d53bd0493))
    (fp_line (start -2.58 -1.76) (end 7.66 -1.76) (layer "F.SilkS") (width 0.12) (tstamp a4d8f951-f770-4e81-afd4-81fe2c18a8cf))
    (fp_line (start 0.69 -3.27) (end 0.69 -1.76) (layer "F.SilkS") (width 0.12) (tstamp b3320be7-339b-428b-ab74-bdaba5b8d055))
    (fp_line (start -2.71 -3.4) (end -2.71 1.51) (layer "F.CrtYd") (width 0.05) (tstamp 0622fd9c-b199-4aea-9120-33bee8455f68))
    (fp_line (start 7.79 1.51) (end 7.79 -3.4) (layer "F.CrtYd") (width 0.05) (tstamp 14b3453b-ec41-4194-bbe7-c28740b7342a))
    (fp_line (start 7.79 -3.4) (end -2.71 -3.4) (layer "F.CrtYd") (width 0.05) (tstamp 2571e23a-9d51-424c-9676-4d51a3bd7fc5))
    (fp_line (start -2.71 1.51) (end 7.79 1.51) (layer "F.CrtYd") (width 0.05) (tstamp f18bb40c-305e-4c97-beaf-567750f1813a))
    (fp_line (start -2.46 -1.88) (end 7.54 -1.88) (layer "F.Fab") (width 0.1) (tstamp 22c228a2-8680-4cda-9940-d9ce1e438d81))
    (fp_line (start 7.54 -3.15) (end -2.46 -3.15) (layer "F.Fab") (width 0.1) (tstamp 3dca3b58-baac-4c9d-b490-337fe1d09a5f))
    (fp_line (start -2.46 1.25) (end 7.54 1.25) (layer "F.Fab") (width 0.1) (tstamp ad3119e4-8272-4c31-a56e-6fa5a89e4ec9))
    (fp_line (start 0.69 -3.15) (end 0.69 -1.88) (layer "F.Fab") (width 0.1) (tstamp b95e7a63-4dbc-411a-ae6a-e8caee2a5924))
    (fp_line (start -2.46 -3.15) (end -2.46 1.25) (layer "F.Fab") (width 0.1) (tstamp ca1a2e03-4c09-4b71-9e1d-da6dd41004c2))
    (fp_line (start 4.39 -3.15) (end 4.39 -1.88) (layer "F.Fab") (width 0.1) (tstamp d2eeddf6-9294-4b68-9491-ac8b898d9c56))
    (fp_line (start 7.54 1.25) (end 7.54 -3.15) (layer "F.Fab") (width 0.1) (tstamp f68b7c34-06fe-4a2d-a64e-245ee82f8d0f))
    (pad "1" thru_hole rect (at 0 0 270) (size 1.905 2) (drill 1.1) (layers *.Cu *.Mask)
      (net 15 "Net-(C3-Pad1)") (pinfunction "VI") (pintype "power_in") (tstamp 24c69a41-2a5b-4c7e-95c9-d68357d38d7b))
    (pad "2" thru_hole oval (at 2.54 0 270) (size 1.905 2) (drill 1.1) (layers *.Cu *.Mask)
      (net 1 "Net-(BT1-Pad2)") (pinfunction "GND") (pintype "power_in") (tstamp d918b490-7e0f-49ca-8640-0876181038be))
    (pad "3" thru_hole oval (at 5.08 0 270) (size 1.905 2) (drill 1.1) (layers *.Cu *.Mask)
      (net 4 "Net-(C6-Pad1)") (pinfunction "VO") (pintype "power_out") (tstamp 3ddf44a6-47c2-4cc7-b972-d3795dc1f17e))
    (model "${KICAD6_3DMODEL_DIR}/Package_TO_SOT_THT.3dshapes/TO-220-3_Vertical.wrl"
      (scale (xyz 1 1 1))
  (footprint "Resistor_THT:R_Axial_DIN0309_L9.0mm_D3.2mm_P12.70mm_Horizontal" (layer "F.Cu")
    (tedit 5AE5139B) (tstamp 7e849c93-ab0b-4391-b91f-e390d05b9579)
    (at 96.901 18.796)
    (descr "Resistor, Axial_DIN0309 series, Axial, Horizontal, pin pitch=12.7mm, 0.5W = 1/2W, length*diameter=9*3.2mm^2, http://cdn-reichelt.de/documents/datenblatt/B400/1_4W%23YAG.pdf")
    (tags "Resistor Axial_DIN0309 series Axial Horizontal pin pitch 12.7mm 0.5W = 1/2W length 9mm diameter 3.2mm")
    (path "/a4ad4d5b-744e-4be3-bc0b-95630184f19e")
    (attr through_hole)
    (fp_text reference "F5" (at 3.81 -2.667) (layer "F.SilkS")
      (tstamp 40ec5aa8-cdee-480c-ad78-d29159f0bb74)
    (fp_text value "Fuse" (at 6.35 2.72) (layer "F.Fab")
      (tstamp 0d778a09-e1b7-43cb-8232-2313629225a8)
    (fp_text user "${REFERENCE}" (at 6.35 0) (layer "F.Fab")
      (tstamp 810b8140-2663-47fa-93ae-84f0f1e2d79f)
    (fp_line (start 11.66 0) (end 10.97 0) (layer "F.SilkS") (width 0.12) (tstamp 2bda17a4-f935-41c3-b6de-324ab390abd9))
    (fp_line (start 10.97 -1.72) (end 1.73 -1.72) (layer "F.SilkS") (width 0.12) (tstamp 2dff88d6-f730-436b-88bf-cabf02c1aa75))
    (fp_line (start 1.04 0) (end 1.73 0) (layer "F.SilkS") (width 0.12) (tstamp 4bd20b66-f4ab-49bd-9d6b-621258e93421))
    (fp_line (start 10.97 1.72) (end 10.97 -1.72) (layer "F.SilkS") (width 0.12) (tstamp 6b7350a7-6033-4583-b28d-5a9bfceebdf3))
    (fp_line (start 1.73 -1.72) (end 1.73 1.72) (layer "F.SilkS") (width 0.12) (tstamp abb96350-fc78-415d-a1ac-b981bce39b2e))
    (fp_line (start 1.73 1.72) (end 10.97 1.72) (layer "F.SilkS") (width 0.12) (tstamp b1ee2455-8ceb-4429-bebb-d5b04e490ecc))
    (fp_line (start 13.75 1.85) (end 13.75 -1.85) (layer "F.CrtYd") (width 0.05) (tstamp 12bfaa9f-8516-41c5-99ee-41ae9c6f1061))
    (fp_line (start -1.05 -1.85) (end -1.05 1.85) (layer "F.CrtYd") (width 0.05) (tstamp 14555987-c3e3-44db-8b40-3adf00976f2b))
    (fp_line (start -1.05 1.85) (end 13.75 1.85) (layer "F.CrtYd") (width 0.05) (tstamp 67a5bb4b-73eb-40e2-bb07-45a0f96d1220))
    (fp_line (start 13.75 -1.85) (end -1.05 -1.85) (layer "F.CrtYd") (width 0.05) (tstamp 7d832015-77df-4291-b28f-12bf937811b4))
    (fp_line (start 12.7 0) (end 10.85 0) (layer "F.Fab") (width 0.1) (tstamp 0f641526-fd1e-45b4-90b7-da3cddda5712))
    (fp_line (start 1.85 1.6) (end 10.85 1.6) (layer "F.Fab") (width 0.1) (tstamp 3b7e6cb4-fa36-44f5-876a-ff4eba3e5e00))
    (fp_line (start 10.85 -1.6) (end 1.85 -1.6) (layer "F.Fab") (width 0.1) (tstamp 9abaf1d1-50bd-4d72-8731-24def2b133c0))
    (fp_line (start 1.85 -1.6) (end 1.85 1.6) (layer "F.Fab") (width 0.1) (tstamp a1dcfb44-4f93-41e6-b779-0977f393bf36))
    (fp_line (start 0 0) (end 1.85 0) (layer "F.Fab") (width 0.1) (tstamp b60569e4-1439-4b27-a62e-ac714870a93a))
    (fp_line (start 10.85 1.6) (end 10.85 -1.6) (layer "F.Fab") (width 0.1) (tstamp d0339196-79a6-48bb-b9df-2c1054b0949c))
    (pad "1" thru_hole circle (at 0 0) (size 1.6 1.6) (drill 0.8) (layers *.Cu *.Mask)
      (net 87 "Net-(D11-Pad1)") (pintype "passive") (tstamp 1c2227fd-5ef4-4295-bdbc-df0c6e2d9b22))
    (pad "2" thru_hole oval (at 12.7 0) (size 1.6 1.6) (drill 0.8) (layers *.Cu *.Mask)
      (net 44 "Net-(C11-Pad1)") (pintype "passive") (tstamp bbe835ba-a86d-4136-8db5-9a844f63cddf))
    (model "${KICAD6_3DMODEL_DIR}/Resistor_THT.3dshapes/R_Axial_DIN0309_L9.0mm_D3.2mm_P12.70mm_Horizontal.wrl"
      (scale (xyz 1 1 1))
    (tedit 59FED6E3) (tstamp 817acf66-f4b1-40c1-9573-dcc86aa18444)
    (at 57.023 20.701 -90)
    (path "/a438aaa4-337f-4353-854c-eda8419221c0")
    (attr smd)
    (fp_text reference "J3" (at 3.683 3.302 90) (layer "F.SilkS")
      (tstamp 3729061b-485e-4d6f-9409-6fdded3a0312)
    (fp_text value "ISP" (at 0 2.965 90) (layer "F.Fab")
      (tstamp 8c09baf6-7cef-4185-ae9e-3fe0a3cb54aa)
      (tstamp db1319c6-80b8-4531-813e-4bbee85293bd)
    (fp_line (start -1.765 -1.965) (end -1.765 -1.9) (layer "F.SilkS") (width 0.12) (tstamp 125ba0e8-4e55-414f-9f7d-72f93ad774f9))
    (fp_line (start -1.765 -1.965) (end 1.765 -1.965) (layer "F.SilkS") (width 0.12) (tstamp 4f5b0d4d-c5b2-451a-a7f6-aef5eb4727d5))
    (fp_line (start 1.765 -1.965) (end 1.765 -1.9) (layer "F.SilkS") (width 0.12) (tstamp 7d329675-f169-46ab-b030-2e8404b3713b))
    (fp_line (start -1.765 1.9) (end -1.765 1.965) (layer "F.SilkS") (width 0.12) (tstamp b30e20c5-600e-4e3a-9b11-a61c0ca41f38))
    (fp_line (start -3.09 -1.9) (end -1.765 -1.9) (layer "F.SilkS") (width 0.12) (tstamp c1890b12-b719-474f-a7a4-55b5d8fe1e1c))
    (fp_line (start -1.765 1.965) (end 1.765 1.965) (layer "F.SilkS") (width 0.12) (tstamp c49a9d09-89c0-4c84-8a6d-5be2382ae0d6))
    (fp_line (start 1.765 1.9) (end 1.765 1.965) (layer "F.SilkS") (width 0.12) (tstamp c604a2c0-021c-438e-9b45-b16a58a8f0f2))
    (fp_line (start -4.3 2.45) (end 4.3 2.45) (layer "F.CrtYd") (width 0.05) (tstamp 1f7cc003-593b-44e3-ba1d-63c65f975a6d))
    (fp_line (start 4.3 -2.45) (end -4.3 -2.45) (layer "F.CrtYd") (width 0.05) (tstamp 334ad95d-cab4-4c19-9070-4ae8cf6bc0eb))
    (fp_line (start -4.3 -2.45) (end -4.3 2.45) (layer "F.CrtYd") (width 0.05) (tstamp 55b4e696-9dc4-4c7a-980b-ecb3126e4185))
    (fp_line (start 4.3 2.45) (end 4.3 -2.45) (layer "F.CrtYd") (width 0.05) (tstamp 5e7e4f46-6d3d-4eb1-a5cb-0bd002671b7d))
    (fp_line (start 1.705 1.905) (end -1.705 1.905) (layer "F.Fab") (width 0.1) (tstamp 02632e0d-1a1c-48b7-8fb6-84fdd9734c59))
    (fp_line (start -2.75 -1.47) (end -2.75 -1.07) (layer "F.Fab") (width 0.1) (tstamp 0a66cd93-2809-4c80-9912-f54367781606))
    (fp_line (start -1.705 -1.47) (end -1.27 -1.905) (layer "F.Fab") (width 0.1) (tstamp 1d0b3fec-b5c7-4711-a1c6-40cca81ffcce))
    (fp_line (start 2.75 1.07) (end 2.75 1.47) (layer "F.Fab") (width 0.1) (tstamp 2565988b-658e-4f9f-b5fa-dd0739220a13))
    (fp_line (start 1.705 -1.47) (end 2.75 -1.47) (layer "F.Fab") (width 0.1) (tstamp 29945afb-8c32-4c9f-a8af-42beec1ae245))
    (fp_line (start -1.705 1.07) (end -2.75 1.07) (layer "F.Fab") (width 0.1) (tstamp 3bcf045f-f8e8-41c6-9e7c-560ee378622a))
    (fp_line (start -2.75 -0.2) (end -2.75 0.2) (layer "F.Fab") (width 0.1) (tstamp 3d15ae88-94b7-459e-8430-222cd80d3e8c))
    (fp_line (start 1.705 -1.905) (end 1.705 1.905) (layer "F.Fab") (width 0.1) (tstamp 4129d0d4-f1b2-409b-b428-bb6401fd5724))
    (fp_line (start -2.75 0.2) (end -1.705 0.2) (layer "F.Fab") (width 0.1) (tstamp 66384b5b-731e-4953-8ae3-a7d31d5e3830))
    (fp_line (start -2.75 -1.07) (end -1.705 -1.07) (layer "F.Fab") (width 0.1) (tstamp 72f657e3-f559-4faa-be71-d4a318a4f856))
    (fp_line (start -2.75 1.47) (end -1.705 1.47) (layer "F.Fab") (width 0.1) (tstamp 81a12764-eeda-486b-8618-78a26e51bcb6))
    (fp_line (start -1.705 -1.47) (end -2.75 -1.47) (layer "F.Fab") (width 0.1) (tstamp 868ef5e6-4405-4718-8e39-f8fc05f0b69d))
    (fp_line (start -1.705 1.905) (end -1.705 -1.47) (layer "F.Fab") (width 0.1) (tstamp 89441177-98e6-4608-b274-c025d5a24fbc))
    (fp_line (start 2.75 -1.07) (end 1.705 -1.07) (layer "F.Fab") (width 0.1) (tstamp a02b1ece-488a-4d30-a37a-c79a44c51d7b))
    (fp_line (start 1.705 -0.2) (end 2.75 -0.2) (layer "F.Fab") (width 0.1) (tstamp a2e280f7-02ff-4672-b70c-0e321e754deb))
    (fp_line (start 2.75 -1.47) (end 2.75 -1.07) (layer "F.Fab") (width 0.1) (tstamp a76ab9f3-6833-49f5-9aba-502342375c9c))
    (fp_line (start 1.705 1.07) (end 2.75 1.07) (layer "F.Fab") (width 0.1) (tstamp c001e4ed-49ad-4ece-b1bd-e7d9d3293295))
    (fp_line (start -1.27 -1.905) (end 1.705 -1.905) (layer "F.Fab") (width 0.1) (tstamp c03781b2-a680-4e3c-ba48-4fc1116de926))
    (fp_line (start 2.75 0.2) (end 1.705 0.2) (layer "F.Fab") (width 0.1) (tstamp dffa5fcb-970f-4767-b053-7c0845406f13))
    (fp_line (start 2.75 -0.2) (end 2.75 0.2) (layer "F.Fab") (width 0.1) (tstamp e2b9d066-649f-4dde-ab60-e55e2b421052))
    (fp_line (start -2.75 1.07) (end -2.75 1.47) (layer "F.Fab") (width 0.1) (tstamp ee6a224c-d8f2-4a4e-91a8-f4a03585c1f6))
    (fp_line (start 2.75 1.47) (end 1.705 1.47) (layer "F.Fab") (width 0.1) (tstamp f0e6b10b-3ba2-4fa6-b784-8e3593f7625c))
    (fp_line (start -1.705 -0.2) (end -2.75 -0.2) (layer "F.Fab") (width 0.1) (tstamp f2b21fd7-fbc8-4b57-a97e-2bd012cf7559))
    (pad "1" smd rect (at -1.95 -1.27 270) (size 2.4 0.74) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 25 "Net-(J3-Pad1)") (pinfunction "Pin_1") (pintype "passive") (tstamp 06caf578-918b-454d-87c3-a3557092613e))
    (pad "2" smd rect (at 1.95 -1.27 270) (size 2.4 0.74) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 3 "Net-(C1-Pad2)") (pinfunction "Pin_2") (pintype "passive") (tstamp 3d8a3b88-1b6f-4230-96ec-f06a01b004f1))
    (pad "3" smd rect (at -1.95 0 270) (size 2.4 0.74) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 26 "Net-(J3-Pad3)") (pinfunction "Pin_3") (pintype "passive") (tstamp a2691e29-02f5-47eb-9402-31d05616199a))
    (pad "4" smd rect (at 1.95 0 270) (size 2.4 0.74) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 27 "Net-(J3-Pad4)") (pinfunction "Pin_4") (pintype "passive") (tstamp 48c86af4-9588-488c-9a8e-1544401ab87d))
    (pad "5" smd rect (at -1.95 1.27 270) (size 2.4 0.74) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 7 "Net-(C9-Pad2)") (pinfunction "Pin_5") (pintype "passive") (tstamp b352ede6-bdd9-4cf1-b2d7-69ba643f9e0b))
    (pad "6" smd rect (at 1.95 1.27 270) (size 2.4 0.74) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 1 "Net-(BT1-Pad2)") (pinfunction "Pin_6") (pintype "passive") (tstamp 78cf9ec2-b2c9-488f-aab5-7375f348551c))
      (scale (xyz 1 1 1))
  (footprint "Library:OMR B3F-4000" (layer "F.Cu")
    (tedit 5D160D14) (tstamp 821cef52-d912-416d-a1fa-0a619d9f541c)
    (at 100.049 129.072)
    (descr "SW PUSH 12mm https://www.e-switch.com/system/asset/product_line/data_sheet/143/TL1100.pdf")
    (tags "tact sw push 12mm")
    (path "/bbc48ae6-d33c-437b-81e4-8895634f1fad")
    (attr through_hole)
    (fp_text reference "SW1" (at -1.37 2.46) (layer "F.SilkS")
      (tstamp deab5cb4-f99c-477b-8e94-40138b828f97)
    (fp_text value "Stop" (at 6.62 9.93) (layer "F.Fab")
      (tstamp 20e49ad2-5c10-4dcb-a30c-948d05bb7d5a)
    (fp_text user "${REFERENCE}" (at 6.35 2.54) (layer "F.Fab")
      (tstamp 28eb5cdc-1021-4a46-8848-24d0166eed71)
    (fp_line (start 12.4 6.2) (end 12.4 8.65) (layer "F.SilkS") (width 0.12) (tstamp 206da053-d2f0-4fb6-b514-acc27a79f6c3))
    (fp_line (start 12.4 -3.65) (end 12.4 -1.1) (layer "F.SilkS") (width 0.12) (tstamp 2cd9d7d0-a262-4af2-bae3-f4a3da52069c))
    (fp_line (start 0.1 -1.1) (end 0.1 -3.65) (layer "F.SilkS") (width 0.12) (tstamp 76571ad8-b8ca-4d90-9128-1153a09b30bf))
    (fp_line (start 0.1 3.8) (end 0.1 1.3) (layer "F.SilkS") (width 0.12) (tstamp 7c53358a-2ff4-4fe2-81f1-43044aeca35e))
    (fp_line (start 0.1 -3.65) (end 12.4 -3.65) (layer "F.SilkS") (width 0.12) (tstamp 9994d76d-685a-4628-8987-64d046099f7e))
    (fp_line (start 12.4 8.65) (end 0.1 8.65) (layer "F.SilkS") (width 0.12) (tstamp d6941b86-18d8-4199-b314-0fa488ab4862))
    (fp_line (start 12.4 1.1) (end 12.4 3.8) (layer "F.SilkS") (width 0.12) (tstamp ebd67596-28b1-4ab8-992e-b34b9a140f9f))
    (fp_line (start 0.1 8.65) (end 0.1 6.2) (layer "F.SilkS") (width 0.12) (tstamp f4cfec97-29f7-4f76-8ade-7d2ee9cd8fed))
    (fp_circle (center 6.35 2.54) (end 10.16 5.08) (layer "F.SilkS") (width 0.12) (fill none) (tstamp b921cb10-ccfb-4e84-bfa8-9029e2614a62))
    (fp_line (start 14.25 8.75) (end -1.77 8.75) (layer "F.CrtYd") (width 0.05) (tstamp 0ddf3237-b33a-4cf9-8307-b797c4b52eee))
    (fp_line (start 14.25 8.75) (end 14.25 -3.75) (layer "F.CrtYd") (width 0.05) (tstamp 22547ad9-2a7e-46c1-bdad-5e45b89c4594))
    (fp_line (start -1.77 -3.75) (end -1.77 8.75) (layer "F.CrtYd") (width 0.05) (tstamp 575b2e9a-2347-4a12-89aa-54ebec42e8a6))
    (fp_line (start -1.77 -3.75) (end 14.25 -3.75) (layer "F.CrtYd") (width 0.05) (tstamp 963c239b-18e9-4d57-b0f9-9f0d1854628c))
    (fp_line (start 12.25 -3.5) (end 12.25 8.5) (layer "F.Fab") (width 0.1) (tstamp 4d34eacf-65b9-4373-bbc8-7b5f8601b373))
    (fp_line (start 0.25 8.5) (end 12.25 8.5) (layer "F.Fab") (width 0.1) (tstamp 7ee738bb-dd8c-4344-9c59-a28ca899390f))
    (fp_line (start 0.25 -3.5) (end 0.25 8.5) (layer "F.Fab") (width 0.1) (tstamp ae5b4c4e-39fe-46bb-a5a9-525d0138d63c))
    (fp_line (start 0.25 -3.5) (end 12.25 -3.5) (layer "F.Fab") (width 0.1) (tstamp df8fdefc-4aaa-409e-b88d-70695ebd5cc0))
    (pad "1" thru_hole oval (at 12.5 5) (size 3.048 1.85) (drill 1.3) (layers *.Cu *.Mask)
      (net 125 "Net-(J13-Pad6)") (pinfunction "A") (pintype "passive") (tstamp d523f817-5115-4a1e-a589-cc48c7354b54))
    (pad "2" thru_hole oval (at 0 5) (size 3.048 1.85) (drill 1.3) (layers *.Cu *.Mask)
      (net 125 "Net-(J13-Pad6)") (pinfunction "A") (pintype "passive") (tstamp d55ede51-1985-4f81-8f52-9431fa501c6a))
    (pad "3" thru_hole oval (at 12.5 0) (size 3.048 1.85) (drill 1.3) (layers *.Cu *.Mask)
      (net 130 "Net-(J13-Pad1)") (pinfunction "B") (pintype "passive") (tstamp 1c1037d8-903c-4351-86f1-015677ea154e))
    (pad "4" thru_hole oval (at 0 0) (size 3.048 1.85) (drill 1.3) (layers *.Cu *.Mask)
      (net 130 "Net-(J13-Pad1)") (pinfunction "B") (pintype "passive") (tstamp c67dabc6-5850-4dc0-b4d0-1413db6cb713))
    (model "${KICAD6_3DMODEL_DIR}/Button_Switch_THT.3dshapes/SW_PUSH-12mm.wrl"
      (scale (xyz 1 1 1))
  (footprint "LED_SMD:LED_0805_2012Metric_Pad1.15x1.40mm_HandSolder" (layer "F.Cu")
    (tedit 5F68FEF1) (tstamp 824bcb72-1b4c-4a81-81a3-816d11cf84c0)
    (at 160.655 128.27 90)
    (descr "LED SMD 0805 (2012 Metric), square (rectangular) end terminal, IPC_7351 nominal, (Body size source: https://docs.google.com/spreadsheets/d/1BsfQQcO9C6DZCsRaXUlFlo91Tg2WpOkGARC1WS5S8t0/edit?usp=sharing), generated with kicad-footprint-generator")
    (tags "LED handsolder")
    (path "/ea72a553-e993-426c-b73c-41c083a1fa1a")
    (attr smd)
    (fp_text reference "D10" (at 0 -1.65 90) (layer "F.SilkS")
      (tstamp 003534a6-3304-4251-84d0-26e4a31efc56)
    (fp_text value "OSO LYR976 Rot" (at 0 1.65 90) (layer "F.Fab")
      (tstamp 19acd281-039e-47b9-91d6-522f9e22b6a9)
    (fp_text user "${REFERENCE}" (at 0 0 90) (layer "F.Fab")
      (effects (font (size 0.5 0.5) (thickness 0.08)))
      (tstamp 55e929f5-9c3b-49cd-ad95-57623125a913)
    (fp_line (start 1 -0.96) (end -1.86 -0.96) (layer "F.SilkS") (width 0.12) (tstamp 192f8f7d-e566-43ae-b22c-f8a72992bb13))
    (fp_line (start -1.86 -0.96) (end -1.86 0.96) (layer "F.SilkS") (width 0.12) (tstamp 6e97f476-6c1f-44d0-a972-c9d389936618))
    (fp_line (start -1.86 0.96) (end 1 0.96) (layer "F.SilkS") (width 0.12) (tstamp 8dea5f0a-7a23-4dde-b18e-aef5bb32ffa6))
    (fp_line (start 1.85 0.95) (end -1.85 0.95) (layer "F.CrtYd") (width 0.05) (tstamp 165cb9d9-4ae8-4c9e-a540-f3abc81d02ea))
    (fp_line (start -1.85 -0.95) (end 1.85 -0.95) (layer "F.CrtYd") (width 0.05) (tstamp 1c1ae21b-cdf0-4371-af1e-6a55fe1423da))
    (fp_line (start -1.85 0.95) (end -1.85 -0.95) (layer "F.CrtYd") (width 0.05) (tstamp 224283df-700c-4d63-bbac-bbc78881281d))
    (fp_line (start 1.85 -0.95) (end 1.85 0.95) (layer "F.CrtYd") (width 0.05) (tstamp da0adde5-8b31-4a46-9261-b364e90c0f03))
    (fp_line (start 1 -0.6) (end -0.7 -0.6) (layer "F.Fab") (width 0.1) (tstamp 156bc8ce-5f40-4286-af41-b761700e4181))
    (fp_line (start -1 -0.3) (end -1 0.6) (layer "F.Fab") (width 0.1) (tstamp 58ed9d2f-3b61-433d-8ca2-bfb0b4431c5d))
    (fp_line (start 1 0.6) (end 1 -0.6) (layer "F.Fab") (width 0.1) (tstamp b793071d-36d0-4376-a685-0ec69efda730))
    (fp_line (start -0.7 -0.6) (end -1 -0.3) (layer "F.Fab") (width 0.1) (tstamp d84a4425-2ea4-4668-bfa4-2309a5d3f6cd))
    (fp_line (start -1 0.6) (end 1 0.6) (layer "F.Fab") (width 0.1) (tstamp eac725c5-6e92-4bcd-811a-cb90c99dd064))
    (pad "1" smd roundrect (at -1.025 0 90) (size 1.15 1.4) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.2173913043)
      (net 131 "Net-(D10-Pad1)") (pinfunction "K") (pintype "passive") (tstamp 1fc047a9-1933-4823-8d84-94b18b0ed1d6))
    (pad "2" smd roundrect (at 1.025 0 90) (size 1.15 1.4) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.2173913043)
      (net 122 "Net-(D10-Pad2)") (pinfunction "A") (pintype "passive") (tstamp e3f75193-f598-4b07-a330-d1ac4cc7254c))
    (model "${KICAD6_3DMODEL_DIR}/LED_SMD.3dshapes/LED_0805_2012Metric.wrl"
      (scale (xyz 1 1 1))
    (tedit 5A1DD157) (tstamp 829f7d19-7ce6-47f4-a1ea-bdce94aea9b2)
    (at 81.259 105.918 90)
    (path "/229d3868-7266-4061-935f-9542bcf0b1d8")
    (attr through_hole)
    (fp_text reference "Q1" (at 1.27 -3.56 90) (layer "F.SilkS")
      (tstamp c9cee0a1-f7c1-4d78-8993-de2f527378be)
    (fp_text value "BC337" (at 1.27 2.79 90) (layer "F.Fab")
      (tstamp 23bc7d57-fbc4-4f36-8cfa-865d9a73a1b0)
      (tstamp 824a1479-e654-41d0-b72e-1f46a6a3f7ab)
    (fp_line (start -0.53 1.85) (end 3.07 1.85) (layer "F.SilkS") (width 0.12) (tstamp 82c03ca3-a62d-40d2-8165-a4c20c7d2260))
    (fp_arc (start 1.27 -2.6) (mid 3.672087 -0.994977) (end 3.108478 1.838478) (layer "F.SilkS") (width 0.12) (tstamp 06bd277c-08b4-4441-bfa0-f3a5c47d5737))
    (fp_arc (start -0.568478 1.838478) (mid -1.132087 -0.994977) (end 1.27 -2.6) (layer "F.SilkS") (width 0.12) (tstamp a203c9b9-8530-46bf-8935-df27463013e7))
    (fp_line (start -1.46 -2.73) (end -1.46 2.01) (layer "F.CrtYd") (width 0.05) (tstamp 2a54909f-aa14-4974-bbe0-f2e5d61c5610))
    (fp_line (start 4 2.01) (end -1.46 2.01) (layer "F.CrtYd") (width 0.05) (tstamp 985a1809-8ba0-47eb-9e4b-3a6f4f670ed9))
    (fp_line (start -1.46 -2.73) (end 4 -2.73) (layer "F.CrtYd") (width 0.05) (tstamp bbfc11db-f114-4713-8312-9426db68e513))
    (fp_line (start 4 2.01) (end 4 -2.73) (layer "F.CrtYd") (width 0.05) (tstamp fd3280df-067b-4a8f-b323-9eefe21ccea8))
    (fp_line (start -0.5 1.75) (end 3 1.75) (layer "F.Fab") (width 0.1) (tstamp 7a43cdd3-39ed-4ffb-8026-5a7dc78ced63))
    (fp_arc (start -0.483625 1.753625) (mid -1.021221 -0.949055) (end 1.27 -2.48) (layer "F.Fab") (width 0.1) (tstamp c91d29a7-04e2-4a58-8ae2-5162ea50d109))
    (fp_arc (start 1.27 -2.48) (mid 3.561221 -0.949055) (end 3.023625 1.753625) (layer "F.Fab") (width 0.1) (tstamp fb2b6062-a795-489f-8158-607f877b63ea))
    (pad "1" thru_hole rect (at 0 0 90) (size 1.05 1.5) (drill 0.75) (layers *.Cu *.Mask)
      (net 18 "Net-(D4-Pad2)") (pinfunction "C") (pintype "passive") (tstamp 12ce9df4-88a7-4328-8cb8-415933a00d45))
    (pad "2" thru_hole oval (at 1.27 0 90) (size 1.05 1.5) (drill 0.75) (layers *.Cu *.Mask)
      (net 40 "Net-(Q1-Pad2)") (pinfunction "B") (pintype "input") (tstamp 628937ad-ac8c-476c-a1fe-6fe923c78297))
    (pad "3" thru_hole oval (at 2.54 0 90) (size 1.05 1.5) (drill 0.75) (layers *.Cu *.Mask)
      (net 1 "Net-(BT1-Pad2)") (pinfunction "E") (pintype "passive") (tstamp 657a4bdb-ce70-487a-a051-2e3343e127f0))
      (scale (xyz 1 1 1))
  (footprint "TerminalBlock_RND:TerminalBlock_RND_205-00001_1x02_P5.00mm_Horizontal" (layer "F.Cu")
    (tedit 5B294F8C) (tstamp 841f554e-15c5-4679-9068-2b922cb5f1f7)
    (at 165.981 55.586 90)
    (descr "terminal block RND 205-00001, 2 pins, pitch 5mm, size 10x9mm^2, drill diamater 1.3mm, pad diameter 2.5mm, see http://cdn-reichelt.de/documents/datenblatt/C151/RND_205-00001_DB_EN.pdf, script-generated using https://github.com/pointhi/kicad-footprint-generator/scripts/TerminalBlock_RND")
    (tags "THT terminal block RND 205-00001 pitch 5mm size 10x9mm^2 drill 1.3mm pad 2.5mm")
    (path "/3f639696-ae97-4240-88a9-b4256936d2d6")
    (attr through_hole)
    (fp_text reference "J11" (at 2.5 -6.06 90) (layer "F.SilkS")
      (tstamp 15a7cfa9-8d5d-497f-974b-82746d7de4c5)
      (tstamp f4faba13-61c2-416a-b99b-99b1cfae8cd8)
    (fp_text user "${REFERENCE}" (at 2.5 -6.06 90) (layer "F.Fab")
      (tstamp c96fef47-05bb-4328-9ac2-b388faa2aa19)
    (fp_line (start -2.56 2.5) (end 7.56 2.5) (layer "F.SilkS") (width 0.12) (tstamp 0170bd21-9255-468c-89fb-775298d6bf00))
    (fp_line (start -2.56 -5.06) (end -2.56 4.06) (layer "F.SilkS") (width 0.12) (tstamp 07b7189a-2106-478f-acc1-56e48d648320))
    (fp_line (start -2.8 4.3) (end -1.3 4.3) (layer "F.SilkS") (width 0.12) (tstamp 08cc1873-1cc2-454b-a00f-e014f3e77431))
    (fp_line (start 3.82 0.976) (end 3.726 1.069) (layer "F.SilkS") (width 0.12) (tstamp 0c8649c1-d045-48bb-a6d1-5f5c9f96ffc0))
    (fp_line (start 7.56 -5.06) (end 7.56 4.06) (layer "F.SilkS") (width 0.12) (tstamp 3a361bbb-f716-49d1-9d8c-3bf0c7862378))
    (fp_line (start -2.56 -5.06) (end 7.56 -5.06) (layer "F.SilkS") (width 0.12) (tstamp 93ea1164-62d4-406e-899c-3df54a052b00))
    (fp_line (start 3.99 1.216) (end 3.931 1.274) (layer "F.SilkS") (width 0.12) (tstamp 9495c161-0d0a-4b83-8601-f313c1108372))
    (fp_line (start -2.56 4.06) (end 7.56 4.06) (layer "F.SilkS") (width 0.12) (tstamp b4c51db9-36f9-4c57-a673-d5387661e3ff))
    (fp_line (start 6.07 -1.275) (end 6.011 -1.216) (layer "F.SilkS") (width 0.12) (tstamp d8d41949-491d-40a5-848d-20641a5989f2))
    (fp_line (start -2.8 2.56) (end -2.8 4.3) (layer "F.SilkS") (width 0.12) (tstamp f002cf1d-2c4b-4b8c-b409-6c1a015cabf4))
    (fp_line (start 6.275 -1.069) (end 6.181 -0.976) (layer "F.SilkS") (width 0.12) (tstamp f4d1c350-4b3c-41b6-83b8-1efc2c010cd7))
    (fp_arc (start 0.788712 1.483352) (mid 0.406429 1.630097) (end 0 1.68) (layer "F.SilkS") (width 0.12) (tstamp 0887d1ed-be66-4588-8311-395e5a044367))
    (fp_arc (start 1.483953 -0.789089) (mid 1.680708 -0.00005) (end 1.484 0.789) (layer "F.SilkS") (width 0.12) (tstamp 2bfdbdf5-7f81-4897-b74c-660c5bc16541))
    (fp_arc (start 0.029383 1.68045) (mid -0.392304 1.634281) (end -0.789 1.484) (layer "F.SilkS") (width 0.12) (tstamp 5da54490-b136-4ac3-b298-e8e749615e35))
    (fp_arc (start -1.483953 0.789089) (mid -1.680708 0.00005) (end -1.484 -0.789) (layer "F.SilkS") (width 0.12) (tstamp b6901679-2bae-47a3-bc2b-f34788fa1d60))
    (fp_arc (start -0.789089 -1.483953) (mid -0.00005 -1.680708) (end 0.789 -1.484) (layer "F.SilkS") (width 0.12) (tstamp f5223899-0dd5-400c-b052-6c82aa611b66))
    (fp_circle (center 5 0) (end 6.68 0) (layer "F.SilkS") (width 0.12) (fill none) (tstamp 24515987-6fef-414c-89c8-201be7a1b8c0))
    (fp_circle (center 0 -3) (end 0.9 -3) (layer "F.SilkS") (width 0.12) (fill none) (tstamp 65895c55-1472-435b-a60d-f129be18fa2c))
    (fp_circle (center 5 -3) (end 5.9 -3) (layer "F.SilkS") (width 0.12) (fill none) (tstamp e844695e-4522-4153-b963-c56d84af3bbc))
    (fp_line (start -3 -5.5) (end -3 4.5) (layer "F.CrtYd") (width 0.05) (tstamp 20e7d7d0-e120-4ee0-b8f0-d17d19771573))
    (fp_line (start 8 -5.5) (end -3 -5.5) (layer "F.CrtYd") (width 0.05) (tstamp 50fd926d-f896-4dac-ab7a-249d6a9f834a))
    (fp_line (start -3 4.5) (end 8 4.5) (layer "F.CrtYd") (width 0.05) (tstamp 5df810ed-eda1-4a67-8732-5f2963560ddc))
    (fp_line (start 8 4.5) (end 8 -5.5) (layer "F.CrtYd") (width 0.05) (tstamp cdd043e2-6e2f-49aa-beec-4764684a922d))
    (fp_line (start -2.5 -5) (end 7.5 -5) (layer "F.Fab") (width 0.1) (tstamp 0d7977e4-7524-4d42-a6ef-8f1691581472))
    (fp_line (start -2.5 2.5) (end 7.5 2.5) (layer "F.Fab") (width 0.1) (tstamp 193c2f8c-8df0-4198-b8f4-b08ecc79da47))
    (fp_line (start 1.138 -0.955) (end -0.955 1.138) (layer "F.Fab") (width 0.1) (tstamp 20763dab-4cac-45e9-85af-5e7b2f03f266))
    (fp_line (start 0.955 -1.138) (end -1.138 0.955) (layer "F.Fab") (width 0.1) (tstamp 5944d9dd-c5bb-4a14-bec8-02bace0ca988))
    (fp_line (start 6.138 -0.955) (end 4.046 1.138) (layer "F.Fab") (width 0.1) (tstamp 5fcb1783-4395-4279-972c-4b87d6d6e7f6))
    (fp_line (start -2.5 2.5) (end -2.5 -5) (layer "F.Fab") (width 0.1) (tstamp 91a9dc01-b0bb-4d05-8aa6-d7aa9c5f73fe))
    (fp_line (start 7.5 -5) (end 7.5 4) (layer "F.Fab") (width 0.1) (tstamp c33b9910-eab5-4ade-8710-962f00866f17))
    (fp_line (start 5.955 -1.138) (end 3.863 0.955) (layer "F.Fab") (width 0.1) (tstamp c74d4e4d-d85b-423f-ad12-7a11cf655338))
    (fp_line (start 7.5 4) (end -1 4) (layer "F.Fab") (width 0.1) (tstamp dbc5a968-7f6c-480d-9033-52a0118bc9e6))
    (fp_line (start -1 4) (end -2.5 2.5) (layer "F.Fab") (width 0.1) (tstamp f883912d-16ad-45dc-91ef-ceba55bc67c1))
    (fp_circle (center 5 -3) (end 5.9 -3) (layer "F.Fab") (width 0.1) (fill none) (tstamp 07cab4be-4d1c-43b3-bc54-ddea09d937da))
    (fp_circle (center 0 -3) (end 0.9 -3) (layer "F.Fab") (width 0.1) (fill none) (tstamp 26bbed30-6642-43ad-841d-35db74b9753d))
    (fp_circle (center 5 0) (end 6.5 0) (layer "F.Fab") (width 0.1) (fill none) (tstamp 3918ac76-2af3-4518-99f3-ad9ee8a2eb75))
    (fp_circle (center 0 0) (end 1.5 0) (layer "F.Fab") (width 0.1) (fill none) (tstamp a5f091ef-c02c-4ff7-bcc5-1c36af0db209))
    (pad "1" thru_hole rect (at 0 0 90) (size 2.5 2.5) (drill 1.3) (layers *.Cu *.Mask)
      (net 10 "Net-(C14-Pad1)") (pinfunction "Pin_1") (pintype "passive") (tstamp 4f6b75a1-a994-416e-91d9-783dcdd312ac))
    (pad "2" thru_hole circle (at 5 0 90) (size 2.5 2.5) (drill 1.3) (layers *.Cu *.Mask)
      (net 1 "Net-(BT1-Pad2)") (pinfunction "Pin_2") (pintype "passive") (tstamp 59bb4975-b9ce-48d2-8848-eacfa66077b8))
    (model "${KICAD6_3DMODEL_DIR}/TerminalBlock_RND.3dshapes/TerminalBlock_RND_205-00001_1x02_P5.00mm_Horizontal.wrl"
      (scale (xyz 1 1 1))
    (tedit 5F68FEEF) (tstamp 85ecb6c6-b207-4b9c-b252-d5b6b30c36a9)
    (at 113.8835 72.136 90)
    (path "/e761ba11-24d8-45e2-9eec-e7acbb42f9e7")
    (attr smd)
    (fp_text reference "C6" (at 0 -1.85 90) (layer "F.SilkS")
      (tstamp 97444c07-7e21-412b-955e-9cbe0833fcc7)
    (fp_text value "22u 25V X5R-G1210 22" (at 0 1.85 90) (layer "F.Fab")
      (tstamp 22abac55-ec2a-4796-9497-c41260126f68)
      (effects (font (size 0.8 0.8) (thickness 0.12)))
      (tstamp e6b2db06-0913-410f-aaa4-f03851928b6c)
    (fp_line (start -0.711252 0.91) (end 0.711252 0.91) (layer "F.SilkS") (width 0.12) (tstamp 06a7392a-1b2f-43e8-b22c-4d18040bf993))
    (fp_line (start -0.711252 -0.91) (end 0.711252 -0.91) (layer "F.SilkS") (width 0.12) (tstamp edf838f2-b5b2-4838-9cbd-3151e266af6f))
    (fp_line (start 2.48 -1.15) (end 2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp 453438e1-6e95-4c5d-9df2-cb76b9993070))
    (fp_line (start -2.48 1.15) (end -2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp 7aca2580-d235-44ab-b795-d3b7f9b89e64))
    (fp_line (start -2.48 -1.15) (end 2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp b6beccb5-2771-490f-8225-3ec2c047d17a))
    (fp_line (start 2.48 1.15) (end -2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp da60ba66-0e7c-4e35-bb43-54519a064b65))
    (fp_line (start 1.6 0.8) (end -1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp 18d0081d-0371-4b50-8820-325d3d529d07))
    (fp_line (start -1.6 -0.8) (end 1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp 48c18ecf-8c6e-40f0-9dfe-4cfb3e9f904d))
    (fp_line (start -1.6 0.8) (end -1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp 7d549bac-493f-49ad-be1f-118d19268f2d))
    (fp_line (start 1.6 -0.8) (end 1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp bd648d79-e203-4b47-9710-c25fdc2b7b44))
    (pad "1" smd roundrect (at -1.5625 0 90) (size 1.325 1.8) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1886792453)
      (net 4 "Net-(C6-Pad1)") (pintype "passive") (tstamp c67890c1-02c4-4165-a047-2796677e4de8))
    (pad "2" smd roundrect (at 1.5625 0 90) (size 1.325 1.8) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1886792453)
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp 80a75e31-811c-4b20-bf6b-a76d44e89499))
      (scale (xyz 1 1 1))
  (footprint "Capacitor_SMD:CP_Elec_6.3x7.7" (layer "F.Cu")
    (tedit 5BCA39D0) (tstamp 861263c1-c6cb-4b3b-8e46-09e76b5f6b5f)
    (at 60.071 51.308 180)
    (descr "SMD capacitor, aluminum electrolytic, Nichicon, 6.3x7.7mm")
    (tags "capacitor electrolytic")
    (path "/fd71a105-d733-4c95-aa95-43fa26edf7bb")
    (attr smd)
    (fp_text reference "C20" (at 4.826 2.794 90) (layer "F.SilkS")
      (tstamp f16d47bc-f094-41b4-bc46-5a1e6bab6414)
    (fp_text value "150µ 10V ECC ZJ100151MF6" (at 0 4.35) (layer "F.Fab")
      (tstamp 373fc445-4822-479c-9eb8-4c8501914f11)
    (fp_text user "${REFERENCE}" (at 0 0) (layer "F.Fab")
      (tstamp a667d122-7543-4a90-9b52-181eb40b809d)
    (fp_line (start 3.41 3.41) (end 3.41 1.06) (layer "F.SilkS") (width 0.12) (tstamp 0a7264c6-e1b0-430a-80d9-30f1631a9266))
    (fp_line (start -3.41 -2.345563) (end -2.345563 -3.41) (layer "F.SilkS") (width 0.12) (tstamp 0b2d4a47-b1b7-4f17-902b-3c2c8ec3e0b0))
    (fp_line (start -4.4375 -1.8475) (end -3.65 -1.8475) (layer "F.SilkS") (width 0.12) (tstamp 291679d2-8938-48cc-be24-e58b9a58e39f))
    (fp_line (start -2.345563 3.41) (end 3.41 3.41) (layer "F.SilkS") (width 0.12) (tstamp 5fec220b-d91e-4246-9e00-c0b2c4714d4e))
    (fp_line (start -4.04375 -2.24125) (end -4.04375 -1.45375) (layer "F.SilkS") (width 0.12) (tstamp 777ebcca-8a00-4c4e-933e-a1fab0264d0f))
    (fp_line (start -2.345563 -3.41) (end 3.41 -3.41) (layer "F.SilkS") (width 0.12) (tstamp 8e2da3a7-8fdc-4355-8616-ec071e515a7f))
    (fp_line (start -3.41 2.345563) (end -2.345563 3.41) (layer "F.SilkS") (width 0.12) (tstamp 8fa1eca9-5d95-4d19-aeae-e98fbe4d46e5))
    (fp_line (start -3.41 2.345563) (end -3.41 1.06) (layer "F.SilkS") (width 0.12) (tstamp 9e14469e-8a37-4155-8ddc-fba640add2df))
    (fp_line (start -3.41 -2.345563) (end -3.41 -1.06) (layer "F.SilkS") (width 0.12) (tstamp a6008d2d-d8e6-4bff-8f1d-02a1c1126ae7))
    (fp_line (start 3.41 -3.41) (end 3.41 -1.06) (layer "F.SilkS") (width 0.12) (tstamp bf84a2b7-276d-4bd3-9baf-5aeefe52ef38))
    (fp_line (start -3.55 -2.4) (end -2.4 -3.55) (layer "F.CrtYd") (width 0.05) (tstamp 00c57ba6-e0fa-4b23-84ac-6b361c68df14))
    (fp_line (start -3.55 2.4) (end -2.4 3.55) (layer "F.CrtYd") (width 0.05) (tstamp 022e6930-6a64-4bc4-805b-48f679f65166))
    (fp_line (start 4.7 -1.05) (end 4.7 1.05) (layer "F.CrtYd") (width 0.05) (tstamp 065c7f2d-c536-41e4-a12e-cb77e3161bb6))
    (fp_line (start -3.55 -1.05) (end -4.7 -1.05) (layer "F.CrtYd") (width 0.05) (tstamp 232f7b39-9c91-402b-baa5-cbbf11b96acc))
    (fp_line (start 3.55 -3.55) (end 3.55 -1.05) (layer "F.CrtYd") (width 0.05) (tstamp 2f2e359d-0384-4935-b737-b79d084447b0))
    (fp_line (start -2.4 -3.55) (end 3.55 -3.55) (layer "F.CrtYd") (width 0.05) (tstamp 413714ed-33af-4627-a98c-850873ade582))
    (fp_line (start -4.7 1.05) (end -3.55 1.05) (layer "F.CrtYd") (width 0.05) (tstamp 4707afd4-09bc-48b5-89c8-3e80b4d14db1))
    (fp_line (start -2.4 3.55) (end 3.55 3.55) (layer "F.CrtYd") (width 0.05) (tstamp 5b8192ee-ae81-4ac2-90a6-f2ff195daa56))
    (fp_line (start 4.7 1.05) (end 3.55 1.05) (layer "F.CrtYd") (width 0.05) (tstamp 8eb6e04f-5a15-42fb-9c70-0c9ea5fa269a))
    (fp_line (start 3.55 1.05) (end 3.55 3.55) (layer "F.CrtYd") (width 0.05) (tstamp a6c3e795-9048-4f2f-9d91-4d428fd1a0e6))
    (fp_line (start 3.55 -1.05) (end 4.7 -1.05) (layer "F.CrtYd") (width 0.05) (tstamp b3c1d05d-7484-47e3-97bd-71d5d647ad9e))
    (fp_line (start -4.7 -1.05) (end -4.7 1.05) (layer "F.CrtYd") (width 0.05) (tstamp bbcc026b-de70-406a-8f5e-f80e29ef8137))
    (fp_line (start -3.55 1.05) (end -3.55 2.4) (layer "F.CrtYd") (width 0.05) (tstamp e8bfd560-17c0-4fc0-aa8e-2783a8060d40))
    (fp_line (start -3.55 -2.4) (end -3.55 -1.05) (layer "F.CrtYd") (width 0.05) (tstamp fef21cc6-2461-48d3-b770-5a90a23c478b))
    (fp_line (start 3.3 -3.3) (end 3.3 3.3) (layer "F.Fab") (width 0.1) (tstamp 189af66b-0f14-4052-940c-43f5cba3f5fd))
    (fp_line (start -3.3 -2.3) (end -3.3 2.3) (layer "F.Fab") (width 0.1) (tstamp 2a97bb2e-8cba-4960-a3cd-e1396847eadf))
    (fp_line (start -3.3 -2.3) (end -2.3 -3.3) (layer "F.Fab") (width 0.1) (tstamp 37004dc7-72ad-465b-93b9-cda01c9132bf))
    (fp_line (start -2.389838 -1.645) (end -2.389838 -1.015) (layer "F.Fab") (width 0.1) (tstamp 40c2ad91-0bfa-4193-8e45-14f068ed3960))
    (fp_line (start -2.3 3.3) (end 3.3 3.3) (layer "F.Fab") (width 0.1) (tstamp 6369b4e3-93fa-450c-8567-e74c17909153))
    (fp_line (start -2.3 -3.3) (end 3.3 -3.3) (layer "F.Fab") (width 0.1) (tstamp 800f2fb9-0ffc-4207-8677-75e3a636807b))
    (fp_line (start -2.704838 -1.33) (end -2.074838 -1.33) (layer "F.Fab") (width 0.1) (tstamp 9ec81cb3-57d6-43c1-be2a-af52c3bc2dc4))
    (fp_line (start -3.3 2.3) (end -2.3 3.3) (layer "F.Fab") (width 0.1) (tstamp a7317d8a-132a-46a4-97df-f5cbb5d0aae7))
    (fp_circle (center 0 0) (end 3.15 0) (layer "F.Fab") (width 0.1) (fill none) (tstamp 35ee54cd-274b-4cdc-8218-49da1481405b))
    (pad "1" smd roundrect (at -2.7 0 180) (size 3.5 1.6) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.15625)
      (net 85 "Net-(C20-Pad1)") (pintype "passive") (tstamp b1dc9f5c-4f97-40af-a159-67fe9b862185))
    (pad "2" smd roundrect (at 2.7 0 180) (size 3.5 1.6) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.15625)
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp e2814ea9-f7db-4c65-b88e-9394b4bc18b1))
    (model "${KICAD6_3DMODEL_DIR}/Capacitor_SMD.3dshapes/CP_Elec_6.3x7.7.wrl"
      (scale (xyz 1 1 1))
  (footprint "Resistor_SMD:R_1210_3225Metric_Pad1.30x2.65mm_HandSolder" (layer "F.Cu")
    (tedit 5F68FEEE) (tstamp 86ecd5c3-e6ab-42f0-9d8d-aba166714fcb)
    (at 81.661 31.496 180)
    (descr "Resistor SMD 1210 (3225 Metric), square (rectangular) end terminal, IPC_7351 nominal with elongated pad for handsoldering. (Body size source: IPC-SM-782 page 72, https://www.pcb-3d.com/wordpress/wp-content/uploads/ipc-sm-782a_amendment_1_and_2.pdf), generated with kicad-footprint-generator")
    (tags "resistor handsolder")
    (path "/3f5c1e43-b953-4126-91bf-e3b5dec83692")
    (attr smd)
    (fp_text reference "R16" (at 3.302 0 90) (layer "F.SilkS")
      (tstamp b49f93c6-f4a1-47e9-851a-80320bb64723)
    (fp_text value "SMD 1/4W 2k2" (at 0 2.28) (layer "F.Fab")
      (tstamp 02f84200-e71c-4c49-b087-77ee97abc963)
      (tstamp 18ea2224-4cf3-4024-bef2-a812deb57a55)
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp 5c8e08fd-133d-460a-89fd-a36fb9cd2337))
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 81cf203e-b4dd-4be1-bbf2-ea458d607132))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 1c884c38-fcc6-412c-8162-313d4c723fb3))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 3df5bb7d-96ce-4a80-b177-e2bfc1e7f55b))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp b9aab02f-9be7-4546-93bc-3086c1c44b6a))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp c89f7ea4-89f5-4e73-ab39-d5c86b0052c2))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 57e22a59-c649-4e6f-9f52-6fa077e6db8f))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 858c7cf3-22d6-4bc9-b34e-cdf00f024caa))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp a2a56aca-919b-4dd1-84df-f02f06bff5bf))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp c76a4e6c-42fe-4a70-8f08-1a9743b32136))
    (pad "1" smd roundrect (at -1.55 0 180) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 100 "Net-(Q5-Pad2)") (pintype "passive") (tstamp c00b55b7-efcf-4705-a5e0-0fdfde35de7f))
    (pad "2" smd roundrect (at 1.55 0 180) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 102 "Net-(R16-Pad2)") (pintype "passive") (tstamp 1a0da416-9ad6-4f75-9813-831f4f688bad))
    (model "${KICAD6_3DMODEL_DIR}/Resistor_SMD.3dshapes/R_1210_3225Metric.wrl"
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp 87cd8933-dc26-46ab-8027-5b9ac1b280eb)
    (at 77.851 117.348 180)
    (path "/ce584889-43c8-4d47-a71e-eb60840e69ec")
    (attr smd)
    (fp_text reference "R59" (at 3.556 0 90) (layer "F.SilkS")
      (tstamp 5019a299-c4e1-4f9e-b284-b32c00bf221f)
    (fp_text value "SMD 1/4W 10k" (at 0 2.28) (layer "F.Fab")
      (tstamp 13b465c9-32d5-46ea-852f-bdde515e9f33)
      (tstamp b3420e8f-84ac-4a19-9207-88d47557b6cc)
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp 08af07f8-007b-41af-b2e5-8059b1215c6f))
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 57f4d948-c031-473b-9fd9-edc71f1cb251))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 2fe6940c-1087-4b7b-9084-173d991812d8))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 31377ca6-bc20-4d11-b6f5-e2ba4ec80197))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 444d0818-bf41-4757-88c7-e062e44a5483))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 7c17b90e-a7ca-4d95-8c3a-5c3560f02c66))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 159231e6-bab5-4e57-b6a8-cdf04c29d7d6))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 6e8205fc-b7d4-4907-924e-8d2b1106ab00))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 8441733c-8514-4e66-acfa-d4906015b228))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp e4cd78c1-f57a-4ea2-9992-257bbcec8980))
      (net 97 "Net-(C36-Pad1)") (pintype "passive") (tstamp 3903d131-3ce8-4602-a96e-2215234a158e))
      (net 105 "Net-(D16-Pad2)") (pintype "passive") (tstamp 770ce953-fa6a-4c90-b362-6223230c58d0))
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp 89fe634f-077b-463a-ab9f-f3b1d43e4c34)
    (at 52.578 102.108 -90)
    (path "/ce0f106b-3c69-4b12-a2f5-7a9f7615b3ea")
    (attr smd)
    (fp_text reference "R29" (at 4.064 0 90) (layer "F.SilkS")
      (tstamp 354f69a7-b489-4519-9ce7-b9b57769fcee)
    (fp_text value "SMD 1/4W 1k" (at -0.254 2.032 90) (layer "F.Fab")
      (tstamp a3d91066-f12e-44a3-be70-cf01827a690d)
      (tstamp bc1f34ce-e090-4371-8425-d1aa95b8d10c)
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 33c1c94a-358f-494b-b649-773ec23fdc7b))
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp c59ea803-6093-4e97-a723-b57d112c48d4))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 3ba02e55-28b1-4396-ad0e-9629bae89f1f))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 4b341d3c-7c6c-4697-8f75-7fb2662fb7b5))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 66a733d9-07fc-49b8-b688-ed7cf0bdde73))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp d7a32e96-50e0-4827-9156-ac81b104cb4d))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 2b23cbed-3d8d-452f-9f3d-7da13d210091))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 31369e17-2588-43f7-938a-3d712385b19b))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp c61af8b0-d168-4f7e-8931-a1b5da3985eb))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp f9fa756d-ba21-42bf-95a0-e94f7ddf0adb))
    (pad "1" smd roundrect (at -1.55 0 270) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 60 "Net-(R29-Pad1)") (pintype "passive") (tstamp 9be9268e-ea28-45a8-b164-5b779746a759))
    (pad "2" smd roundrect (at 1.55 0 270) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 94 "Net-(J12-Pad5)") (pintype "passive") (tstamp 216ce6d3-4ac3-4448-b42b-0031ca6b7ade))
      (scale (xyz 1 1 1))
    (tedit 5F68FEEF) (tstamp 8bdb146f-4f11-4044-97e0-818b67dbb4cc)
    (at 40.005 25.4)
    (path "/d62f19e4-a7d0-4163-88e2-38e1f06aa7ba")
    (attr smd)
    (fp_text reference "C13" (at -3.302 0 90) (layer "F.SilkS")
      (tstamp e1da3406-e39d-4f42-812a-2f5554f01365)
    (fp_text value "100n 50V KEM X7R1206 1,0U" (at -0.254 2.032) (layer "F.Fab")
      (tstamp e1350729-fdc0-4191-b2c6-20bca746e0fe)
      (tstamp d61832a8-836c-4bad-8b53-2de976ca2544)
    (fp_line (start -0.711252 0.91) (end 0.711252 0.91) (layer "F.SilkS") (width 0.12) (tstamp 87982122-1dac-4e83-b9ef-70fca938d4d1))
    (fp_line (start -0.711252 -0.91) (end 0.711252 -0.91) (layer "F.SilkS") (width 0.12) (tstamp c6d9b4a3-130a-4d33-b041-2e3469fd68ac))
    (fp_line (start 2.48 1.15) (end -2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp 1adae75d-254f-43cd-81b8-c29f3a98fc14))
    (fp_line (start -2.48 -1.15) (end 2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp 4ffd479d-14a5-4397-bde0-a01a7f0e626e))
    (fp_line (start 2.48 -1.15) (end 2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp 6c4cb7de-f27b-4e2b-8cc3-da62f117e33f))
    (fp_line (start -2.48 1.15) (end -2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp e0f23376-d782-4dab-a4b9-4439127f2abe))
    (fp_line (start -1.6 -0.8) (end 1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp 13205fae-62e3-47c4-a500-166a36b2f634))
    (fp_line (start -1.6 0.8) (end -1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp 5dc543ee-7fe6-4a3c-ad2d-0794fa7fb53d))
    (fp_line (start 1.6 -0.8) (end 1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp 832ef158-521f-48b9-90df-1d9b7a5318de))
    (fp_line (start 1.6 0.8) (end -1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp a86d5f93-cb73-409d-af46-92df4ca68f79))
      (net 9 "Net-(C12-Pad1)") (pintype "passive") (tstamp 12e2d4f0-58bc-4745-88f3-983977ec7cf9))
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp 53941a18-6ae4-4434-a46a-231ec0ba21c9))
      (scale (xyz 1 1 1))
  (footprint "Button_Switch_THT:SW_PUSH_6mm 1-4" (layer "F.Cu")
    (tedit 5A02FE31) (tstamp 8f1a5f36-3a58-4b01-8ecb-30d7d91dbcc4)
    (at 29.031 156.174 180)
    (descr "https://www.omron.com/ecb/products/pdf/en-b3f.pdf")
    (tags "tact sw push 6mm")
    (path "/2290120c-5dbf-48b1-8847-9daec66c2672")
    (attr through_hole)
    (fp_text reference "SW10" (at 8.965 2.631 90) (layer "F.SilkS")
      (tstamp 0787d2a8-14a5-4d63-9bba-04fda210102c)
    (fp_text value "reset" (at 3.75 6.7) (layer "F.Fab")
      (tstamp 89b8a9b1-ece9-4310-849d-6b75191915a1)
    (fp_text user "${REFERENCE}" (at 3.25 2.25) (layer "F.Fab")
      (tstamp 794de1f3-37b6-4a3c-ad82-c878cbc5dee3)
    (fp_line (start -0.25 1.5) (end -0.25 3) (layer "F.SilkS") (width 0.12) (tstamp 07aa8525-12d7-469c-91d5-d1449b5fc563))
    (fp_line (start 6.75 3) (end 6.75 1.5) (layer "F.SilkS") (width 0.12) (tstamp 9149c8c0-f1df-4cb9-a757-9e75fe1283eb))
    (fp_line (start 1 5.5) (end 5.5 5.5) (layer "F.SilkS") (width 0.12) (tstamp a05bccd8-d86a-4c93-ae30-3112144c5a90))
    (fp_line (start 5.5 -1) (end 1 -1) (layer "F.SilkS") (width 0.12) (tstamp f583a945-4c78-43f9-9e99-b2ea89037799))
    (fp_line (start 7.75 6) (end 8 6) (layer "F.CrtYd") (width 0.05) (tstamp 342534d0-af63-4e08-b33a-9892bb8c1ba9))
    (fp_line (start -1.5 5.75) (end -1.5 -1.25) (layer "F.CrtYd") (width 0.05) (tstamp 49bf63f1-0386-4387-9ced-3902852d1509))
    (fp_line (start -1.5 -1.5) (end -1.25 -1.5) (layer "F.CrtYd") (width 0.05) (tstamp 4ed2db63-2b2d-4ae6-9d72-f53c21bcc13a))
    (fp_line (start 8 -1.25) (end 8 5.75) (layer "F.CrtYd") (width 0.05) (tstamp 555fcb11-76dc-4c20-b293-0e1004b707ce))
    (fp_line (start -1.5 5.75) (end -1.5 6) (layer "F.CrtYd") (width 0.05) (tstamp 82ff6f23-db6a-430c-8786-467c1dc72d4b))
    (fp_line (start -1.5 -1.25) (end -1.5 -1.5) (layer "F.CrtYd") (width 0.05) (tstamp 8962fe84-f4a8-491c-8176-ed33353c10f1))
    (fp_line (start 7.75 -1.5) (end 8 -1.5) (layer "F.CrtYd") (width 0.05) (tstamp 97a4d668-b603-40c1-8dec-3c7d9d57c75e))
    (fp_line (start -1.5 6) (end -1.25 6) (layer "F.CrtYd") (width 0.05) (tstamp a4c4c857-c4d6-4bea-9edb-408935637b1d))
    (fp_line (start 8 6) (end 8 5.75) (layer "F.CrtYd") (width 0.05) (tstamp a82cf97c-d672-4338-8bca-e859ca2209d5))
    (fp_line (start -1.25 -1.5) (end 7.75 -1.5) (layer "F.CrtYd") (width 0.05) (tstamp bb02114a-ee91-4b05-8680-ef88122935a5))
    (fp_line (start 7.75 6) (end -1.25 6) (layer "F.CrtYd") (width 0.05) (tstamp bda2d24b-afb2-46ca-9e31-0f5fed788326))
    (fp_line (start 8 -1.5) (end 8 -1.25) (layer "F.CrtYd") (width 0.05) (tstamp d45c299c-ca16-4207-bce2-9b12dbe5a9d7))
    (fp_line (start 0.25 5.25) (end 0.25 -0.75) (layer "F.Fab") (width 0.1) (tstamp 0c7d32b1-bbaa-4906-b0bc-2fdd45fe2e4b))
    (fp_line (start 3.25 -0.75) (end 6.25 -0.75) (layer "F.Fab") (width 0.1) (tstamp 3232f1a7-22fb-4c07-9e3c-b4b43fbc304f))
    (fp_line (start 6.25 -0.75) (end 6.25 5.25) (layer "F.Fab") (width 0.1) (tstamp c0c3058b-aca7-4f2a-9e59-1e1d53056f77))
    (fp_line (start 0.25 -0.75) (end 3.25 -0.75) (layer "F.Fab") (width 0.1) (tstamp ddc9a3f5-153a-48ea-a58e-6ee7d1cdb650))
    (fp_line (start 6.25 5.25) (end 0.25 5.25) (layer "F.Fab") (width 0.1) (tstamp f7c73275-5041-456b-bff8-5d0a1a421b58))
    (fp_circle (center 3.25 2.25) (end 1.25 2.5) (layer "F.Fab") (width 0.1) (fill none) (tstamp 44416f2c-63d2-449a-8d45-67ba03b52b82))
    (pad "1" thru_hole circle (at 0 0 270) (size 2 2) (drill 1.1) (layers *.Cu *.Mask)
      (net 12 "Net-(C25-Pad1)") (pinfunction "A") (pintype "passive") (tstamp b31af4bf-c8ca-4ab7-8124-54aebe5c64d5))
    (pad "2" thru_hole circle (at 6.5 0 270) (size 2 2) (drill 1.1) (layers *.Cu *.Mask)
      (net 12 "Net-(C25-Pad1)") (pinfunction "A") (pintype "passive") (tstamp 8f33a516-a85a-463d-ae46-256e7447e1a8))
    (pad "3" thru_hole circle (at 0 4.5 270) (size 2 2) (drill 1.1) (layers *.Cu *.Mask)
      (net 1 "Net-(BT1-Pad2)") (pinfunction "B") (pintype "passive") (tstamp 9d2f0755-2260-4f93-976d-016567051b11))
    (pad "4" thru_hole circle (at 6.5 4.5 270) (size 2 2) (drill 1.1) (layers *.Cu *.Mask)
      (net 1 "Net-(BT1-Pad2)") (pinfunction "B") (pintype "passive") (tstamp f30752f1-56bb-4e59-9f72-2eba1692eea0))
    (model "${KICAD6_3DMODEL_DIR}/Button_Switch_THT.3dshapes/SW_PUSH_6mm.wrl"
      (scale (xyz 1 1 1))
    (tedit 5D160D14) (tstamp 8f6fcb18-7bfa-43b3-9e07-dc89b595b242)
    (at 155.929 143.59)
    (path "/06a9c790-9c08-42f7-8255-2c851efaeee3")
    (attr through_hole)
    (fp_text reference "SW7" (at -1.751 2.714) (layer "F.SilkS")
      (tstamp 1218946c-f861-49d7-a805-94a58a85cabd)
    (fp_text value "Zurück" (at 6.62 9.93) (layer "F.Fab")
      (tstamp 861a436d-4702-41ce-ae54-4e5929314435)
      (tstamp 91e59aef-0749-4098-b4d1-b0b2293d7d1b)
    (fp_line (start 12.4 -3.65) (end 12.4 -1.1) (layer "F.SilkS") (width 0.12) (tstamp 1b983ca6-7c5c-4700-920a-a3dc0ac07127))
    (fp_line (start 12.4 8.65) (end 0.1 8.65) (layer "F.SilkS") (width 0.12) (tstamp 4c56ec57-b3f1-48af-84c4-9a597f3ffaca))
    (fp_line (start 0.1 8.65) (end 0.1 6.2) (layer "F.SilkS") (width 0.12) (tstamp 54daa0a8-8b1c-44d6-bc58-96ffb2fd0427))
    (fp_line (start 0.1 3.8) (end 0.1 1.3) (layer "F.SilkS") (width 0.12) (tstamp 964a11c0-cb33-47ed-a24c-84a94a9e5c36))
    (fp_line (start 0.1 -1.1) (end 0.1 -3.65) (layer "F.SilkS") (width 0.12) (tstamp a02dcf45-2ece-4a7b-a7a1-1663b444b0e8))
    (fp_line (start 0.1 -3.65) (end 12.4 -3.65) (layer "F.SilkS") (width 0.12) (tstamp c889e5fa-0c62-4ee7-b3ac-d48064d659da))
    (fp_line (start 12.4 6.2) (end 12.4 8.65) (layer "F.SilkS") (width 0.12) (tstamp dde25077-0dc6-422d-b9b7-79a19af84576))
    (fp_line (start 12.4 1.1) (end 12.4 3.8) (layer "F.SilkS") (width 0.12) (tstamp efc3d34e-6e22-445a-b977-338fb4115bde))
    (fp_circle (center 6.35 2.54) (end 10.16 5.08) (layer "F.SilkS") (width 0.12) (fill none) (tstamp 8a932dee-c7f1-415c-93fe-8792a98f9a3f))
    (fp_line (start -1.77 -3.75) (end 14.25 -3.75) (layer "F.CrtYd") (width 0.05) (tstamp 4dae8ab2-c13d-441f-b537-5f988e846916))
    (fp_line (start -1.77 -3.75) (end -1.77 8.75) (layer "F.CrtYd") (width 0.05) (tstamp 743fc51d-7046-4924-9fd3-fc39fcba99a5))
    (fp_line (start 14.25 8.75) (end 14.25 -3.75) (layer "F.CrtYd") (width 0.05) (tstamp 850353c7-b982-4268-b9b4-cf4b72507213))
    (fp_line (start 14.25 8.75) (end -1.77 8.75) (layer "F.CrtYd") (width 0.05) (tstamp 9987dfe6-e9fb-4b04-b722-c52b38a89a8f))
    (fp_line (start 0.25 -3.5) (end 12.25 -3.5) (layer "F.Fab") (width 0.1) (tstamp 0a6b0c8a-da28-4dc3-8b43-1d4de6ed19fc))
    (fp_line (start 0.25 -3.5) (end 0.25 8.5) (layer "F.Fab") (width 0.1) (tstamp 6a99e2d5-24e8-4931-81cf-08d8932ff294))
    (fp_line (start 12.25 -3.5) (end 12.25 8.5) (layer "F.Fab") (width 0.1) (tstamp bd7c37d2-aa6f-4a74-98de-4b16d0e7a026))
    (fp_line (start 0.25 8.5) (end 12.25 8.5) (layer "F.Fab") (width 0.1) (tstamp ef305e7c-d032-4c0a-b9bf-b564e33d76f0))
      (net 127 "Net-(J13-Pad4)") (pinfunction "A") (pintype "passive") (tstamp e67d761a-a36b-4a26-b2bc-9fe02205c0cc))
      (net 127 "Net-(J13-Pad4)") (pinfunction "A") (pintype "passive") (tstamp 2503640a-321c-48ff-a77d-01ba9c290348))
      (net 130 "Net-(J13-Pad1)") (pinfunction "B") (pintype "passive") (tstamp 518ab355-402e-4ff4-a2f2-efec3981ce4a))
      (net 130 "Net-(J13-Pad1)") (pinfunction "B") (pintype "passive") (tstamp 422f1653-04cc-4148-b833-c24f593ed841))
      (scale (xyz 1 1 1))
    (tedit 5D160D14) (tstamp 92995488-67bb-4bca-85c7-8cd82c6ccc85)
    (at 127.989 157.56)
    (path "/6f342ae4-e476-4ef7-a822-d2f0ac3709e5")
    (attr through_hole)
    (fp_text reference "SW9" (at -1.751 2.714) (layer "F.SilkS")
      (tstamp 5ecef03e-ff07-4506-8c5d-252fc09eff7a)
    (fp_text value "Runter" (at 6.62 9.93) (layer "F.Fab")
      (tstamp 520fb445-6328-47ad-80e4-d23b37e9783a)
      (tstamp ae06c8ab-2686-40b8-92a6-7a289c60b416)
    (fp_line (start 12.4 1.1) (end 12.4 3.8) (layer "F.SilkS") (width 0.12) (tstamp 0178684a-35bf-499c-be60-87417b7581dc))
    (fp_line (start 0.1 -3.65) (end 12.4 -3.65) (layer "F.SilkS") (width 0.12) (tstamp 086a7e58-92c4-46c5-91cc-e465cf0e8b27))
    (fp_line (start 12.4 6.2) (end 12.4 8.65) (layer "F.SilkS") (width 0.12) (tstamp 0b9e393e-d2fe-4e5b-b540-bbbeec15afb8))
    (fp_line (start 12.4 -3.65) (end 12.4 -1.1) (layer "F.SilkS") (width 0.12) (tstamp 14b36b61-b9ed-4f21-ae50-339bd2bdc501))
    (fp_line (start 0.1 8.65) (end 0.1 6.2) (layer "F.SilkS") (width 0.12) (tstamp 2ee8eea7-d83a-441e-a734-b9fb3d4cd701))
    (fp_line (start 0.1 3.8) (end 0.1 1.3) (layer "F.SilkS") (width 0.12) (tstamp 7d39fda0-ba33-4168-8317-168faa8b8f40))
    (fp_line (start 12.4 8.65) (end 0.1 8.65) (layer "F.SilkS") (width 0.12) (tstamp ac6b8aab-f276-4c21-a206-f9f9542f6f39))
    (fp_line (start 0.1 -1.1) (end 0.1 -3.65) (layer "F.SilkS") (width 0.12) (tstamp f1ec0179-a81d-45d0-b61c-89fa300103d5))
    (fp_circle (center 6.35 2.54) (end 10.16 5.08) (layer "F.SilkS") (width 0.12) (fill none) (tstamp 289971a8-6341-4699-b31e-48e18a34adf0))
    (fp_line (start -1.77 -3.75) (end 14.25 -3.75) (layer "F.CrtYd") (width 0.05) (tstamp 0fe79142-aa0e-4ea0-be39-97a871b5686f))
    (fp_line (start 14.25 8.75) (end 14.25 -3.75) (layer "F.CrtYd") (width 0.05) (tstamp 76196751-cfb2-4293-ab27-6954660cbea5))
    (fp_line (start 14.25 8.75) (end -1.77 8.75) (layer "F.CrtYd") (width 0.05) (tstamp c47430a8-2bae-43e4-a2b5-8328b1f295ad))
    (fp_line (start -1.77 -3.75) (end -1.77 8.75) (layer "F.CrtYd") (width 0.05) (tstamp fd22a2ce-42ff-4e6c-82fb-420f311df751))
    (fp_line (start 0.25 -3.5) (end 0.25 8.5) (layer "F.Fab") (width 0.1) (tstamp 4e8cee89-fa79-40b1-8e29-5b9957af0325))
    (fp_line (start 0.25 8.5) (end 12.25 8.5) (layer "F.Fab") (width 0.1) (tstamp b2db00e6-7972-44f2-8cbc-affd52bad4c9))
    (fp_line (start 0.25 -3.5) (end 12.25 -3.5) (layer "F.Fab") (width 0.1) (tstamp bb69f31e-1168-44b3-92a0-8554a66da995))
    (fp_line (start 12.25 -3.5) (end 12.25 8.5) (layer "F.Fab") (width 0.1) (tstamp ca18dd3f-49a0-4258-8e91-a13f6b97abd1))
      (net 127 "Net-(J13-Pad4)") (pinfunction "A") (pintype "passive") (tstamp 62ecb7c1-f223-47c5-903b-17c175e6ab7c))
      (net 127 "Net-(J13-Pad4)") (pinfunction "A") (pintype "passive") (tstamp bc8f5d7b-e299-4bfe-875c-c1b899383a3f))
      (net 128 "Net-(J13-Pad3)") (pinfunction "B") (pintype "passive") (tstamp 84009305-0018-490c-b475-83fdd84e9a8c))
      (net 128 "Net-(J13-Pad3)") (pinfunction "B") (pintype "passive") (tstamp 164c8600-4bc3-4c0d-8a30-84d4939fd712))
      (offset (xyz 0 0 0))
      (scale (xyz 1 1 1))
      (rotate (xyz 0 0 0))
    (tedit 5F68FEEE) (tstamp 92ada16f-b6d7-4f9d-8073-e056c806fd63)
    (at 44.323 101.581 -90)
    (property "Sheetfile" "Lauflicht_Steuerplatine.kicad_sch")
    (property "Sheetname" "")
    (path "/dd4f9df4-1271-48f9-80c5-9611f89b309c")
    (attr smd)
    (fp_text reference "R39" (at -3.156 0.635 180) (layer "F.SilkS")
      (effects (font (size 1 1) (thickness 0.15)))
      (tstamp 66363240-7b66-4561-b066-5b68c486e64c)
    (fp_text value "SMD 1/4W 1k" (at 0 2.28 90) (layer "F.Fab")
      (tstamp b3cd1274-917b-4e0f-a72c-628c81c3a083)
      (tstamp cc5f0f3b-4fcc-4988-bd8a-9e781a896840)
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp 682da6e1-7964-465b-81b3-e84bb33d00e1))
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 834d8c41-92db-4398-b1f0-ac4970e729e8))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 135d2de6-e97c-4f95-809c-2322459b34e0))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 18b0e622-2ed8-4019-897d-7f11732c73f4))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 742a2e3e-14e0-43ed-8444-1cbe557e8790))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp eb5981c9-883f-4bd6-81d3-6fd7ef2c5dd3))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 204adf60-a483-4c5f-b983-c2d260df91b5))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 91e5d35c-38bc-4347-8ffc-ef7dd1e12ee0))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp a33f77bb-5bb6-42d9-b7f8-ab6deebb9613))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp ca880507-89db-4d91-ad07-05af9029c9d3))
      (net 69 "Net-(R39-Pad1)") (pintype "passive") (tstamp da9c505a-4cf9-4efd-81ef-a2a5337b4909))
      (net 91 "Net-(J12-Pad2)") (pintype "passive") (tstamp 09737130-127a-493b-9236-109e39945688))
      (scale (xyz 1 1 1))
  (footprint "Capacitor_SMD:C_1206_3216Metric_Pad1.33x1.80mm_HandSolder" (layer "F.Cu")
    (tedit 5F68FEEF) (tstamp 95433637-2fd7-4c08-a98e-f7b31e68fa86)
    (at 66.421 34.671)
    (descr "Capacitor SMD 1206 (3216 Metric), square (rectangular) end terminal, IPC_7351 nominal with elongated pad for handsoldering. (Body size source: IPC-SM-782 page 76, https://www.pcb-3d.com/wordpress/wp-content/uploads/ipc-sm-782a_amendment_1_and_2.pdf), generated with kicad-footprint-generator")
    (tags "capacitor handsolder")
    (path "/074a07e0-9f18-4e03-a454-e752497eda73")
    (attr smd)
    (fp_text reference "C31" (at 3.302 0.127 90) (layer "F.SilkS")
      (tstamp 812814e0-b372-415a-81d2-0d59021dea62)
    (fp_text value "1µ 50V KEM X7R1206 1,0U" (at 0 1.85) (layer "F.Fab")
      (tstamp d76e883b-2c32-4931-87dc-0d21b301c4f0)
      (tstamp 12a953fb-b76b-4995-8abb-c0197bc5d157)
    (fp_line (start -0.711252 -0.91) (end 0.711252 -0.91) (layer "F.SilkS") (width 0.12) (tstamp 8dc00243-16e0-4763-ac01-9df5b9bdf2c7))
    (fp_line (start -0.711252 0.91) (end 0.711252 0.91) (layer "F.SilkS") (width 0.12) (tstamp d99a5c36-1fd2-42ae-8671-f4055981bb2b))
    (fp_line (start 2.48 1.15) (end -2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp 4ec70128-780d-42f1-8f8b-45e05b3950fe))
    (fp_line (start 2.48 -1.15) (end 2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp b7904890-5e6d-47fd-ab04-755083e61d8e))
    (fp_line (start -2.48 -1.15) (end 2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp ead9fa98-6dba-424c-9930-d5fff16edaa5))
    (fp_line (start -2.48 1.15) (end -2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp f06dcd03-d06c-479a-96d8-0d5585454c50))
    (fp_line (start -1.6 -0.8) (end 1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp 3c3ca4fb-0247-438e-905b-9f9a93026d0a))
    (fp_line (start -1.6 0.8) (end -1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp 9d2e4db2-c87b-48cd-be63-3bf0311e332d))
    (fp_line (start 1.6 -0.8) (end 1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp 9dde794e-7651-4dc7-8c1a-0694ce695da2))
    (fp_line (start 1.6 0.8) (end -1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp b571e4ce-e59b-48bf-a35b-2124f506f91d))
    (pad "1" smd roundrect (at -1.5625 0) (size 1.325 1.8) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1886792453)
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp 253d25ed-9942-40dd-837b-e99acf786499))
    (pad "2" smd roundrect (at 1.5625 0) (size 1.325 1.8) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1886792453)
      (net 86 "Net-(C31-Pad2)") (pintype "passive") (tstamp 16f753bf-bc95-4de4-a51f-f869daada435))
    (model "${KICAD6_3DMODEL_DIR}/Capacitor_SMD.3dshapes/C_1206_3216Metric.wrl"
      (scale (xyz 1 1 1))
    (tedit 5D160D14) (tstamp 95f250ca-c16d-460c-9585-239e7a8d6878)
    (at 155.929 157.56)
    (path "/bd224530-9552-49c9-9aa9-7eba20654037")
    (attr through_hole)
    (fp_text reference "SW4" (at -1.751 2.714) (layer "F.SilkS")
      (tstamp 3245240d-51bd-4d1e-b3d8-53045926e263)
    (fp_text value "Ok" (at 6.62 9.93) (layer "F.Fab")
      (tstamp 245ab019-505b-46b4-9e5b-1cf8ab1b9422)
      (tstamp 81168469-742f-44a3-b3e0-4aa4107d96f3)
    (fp_line (start 0.1 8.65) (end 0.1 6.2) (layer "F.SilkS") (width 0.12) (tstamp 1cb7fecc-c01f-4f43-8e29-e91c3aaabd5a))
    (fp_line (start 12.4 -3.65) (end 12.4 -1.1) (layer "F.SilkS") (width 0.12) (tstamp 36a0f820-bcf2-43d9-a71e-6d889f03241f))
    (fp_line (start 0.1 3.8) (end 0.1 1.3) (layer "F.SilkS") (width 0.12) (tstamp 646d6b1c-602d-49da-b08a-57b9672af9e9))
    (fp_line (start 12.4 8.65) (end 0.1 8.65) (layer "F.SilkS") (width 0.12) (tstamp 8ac9c1dc-178b-4de3-9323-0d441bb31f49))
    (fp_line (start 0.1 -1.1) (end 0.1 -3.65) (layer "F.SilkS") (width 0.12) (tstamp 92ce00f8-a16a-4d15-8d3c-22f39cd9e2ec))
    (fp_line (start 12.4 1.1) (end 12.4 3.8) (layer "F.SilkS") (width 0.12) (tstamp d81b3f9d-9d87-4741-89de-45d6bc1d6f29))
    (fp_line (start 12.4 6.2) (end 12.4 8.65) (layer "F.SilkS") (width 0.12) (tstamp e5262910-d382-4fd4-8af4-76f153cdb03d))
    (fp_line (start 0.1 -3.65) (end 12.4 -3.65) (layer "F.SilkS") (width 0.12) (tstamp efb9d037-c119-46fa-8f54-824c3bcd665b))
    (fp_circle (center 6.35 2.54) (end 10.16 5.08) (layer "F.SilkS") (width 0.12) (fill none) (tstamp f100a071-9e8f-453f-960f-4ac3d6e9da3a))
    (fp_line (start 14.25 8.75) (end 14.25 -3.75) (layer "F.CrtYd") (width 0.05) (tstamp 67500845-4801-4dca-8e10-fd1312bf8f03))
    (fp_line (start 14.25 8.75) (end -1.77 8.75) (layer "F.CrtYd") (width 0.05) (tstamp 9ba65de2-6500-42c4-a1f6-06e4267d38b3))
    (fp_line (start -1.77 -3.75) (end 14.25 -3.75) (layer "F.CrtYd") (width 0.05) (tstamp eb63aff2-ba4c-48fb-970c-2ff7cf6a6de3))
    (fp_line (start -1.77 -3.75) (end -1.77 8.75) (layer "F.CrtYd") (width 0.05) (tstamp efec7d1c-0e85-49b9-aa1a-92e3fe8822cf))
    (fp_line (start 0.25 8.5) (end 12.25 8.5) (layer "F.Fab") (width 0.1) (tstamp 0b65b429-5796-4d2a-aa0f-6e33e0a1ccd6))
    (fp_line (start 0.25 -3.5) (end 12.25 -3.5) (layer "F.Fab") (width 0.1) (tstamp 4ac0b1c0-07e8-4b00-b0e6-cba03da94bdc))
    (fp_line (start 12.25 -3.5) (end 12.25 8.5) (layer "F.Fab") (width 0.1) (tstamp 6c0bebcd-fcf4-41cd-bf1b-f96a45a64de3))
    (fp_line (start 0.25 -3.5) (end 0.25 8.5) (layer "F.Fab") (width 0.1) (tstamp f2159b1f-e61b-48e2-9e4d-d85c119025e0))
      (net 126 "Net-(J13-Pad5)") (pinfunction "A") (pintype "passive") (tstamp 5306a73b-ed7b-454a-b01a-12da391607dd))
      (net 126 "Net-(J13-Pad5)") (pinfunction "A") (pintype "passive") (tstamp 2d7276d7-b339-4ee7-9c9e-d5219cbc097d))
      (net 130 "Net-(J13-Pad1)") (pinfunction "B") (pintype "passive") (tstamp ea89ad7e-04c4-4ae1-91fa-85ee504246bd))
      (net 130 "Net-(J13-Pad1)") (pinfunction "B") (pintype "passive") (tstamp 646f6b7e-f07c-4e8f-b278-cee40a777389))
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp 969259aa-6bd4-4021-8313-41be15509f18)
    (at 156.083 133.35 -90)
    (path "/8a6299e2-bd79-46b4-848c-0b934222113a")
    (attr smd)
    (fp_text reference "R36" (at 0 2.286 90) (layer "F.SilkS")
      (tstamp 012bfac5-71c4-4a11-af54-9e32b92c6924)
    (fp_text value "SMD 1/4W 2k2" (at 0 2.28 90) (layer "F.Fab")
      (tstamp 8f4ec2a2-a1a9-4806-9b5e-2356fc893b9d)
      (tstamp f938d060-edfa-4541-b82e-48164166979e)
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp 3e83d84a-4394-4b1a-a967-97749ecd288f))
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 44d38ad5-606e-4b1b-a859-a75dd8807507))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 1a593742-feba-4098-aaaa-d55506118974))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 339e5b6d-9996-4fd5-b66d-45d0553a926d))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 436d62aa-f384-41e5-8a1f-e59f589b93b5))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 9355d2f9-c03f-4999-8052-01d3659658b7))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 3410fdcc-d12b-4bae-9c09-d774c9adb618))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 4cda66f0-eecf-49bb-a233-3a8d75b5f01e))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 92c40bcf-dcdd-431e-a4f6-a5698443eaf5))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 9617d941-bf7f-4eb1-b2d3-7cfdb7597127))
      (net 103 "Net-(D9-Pad1)") (pintype "passive") (tstamp 0d0c13a2-2064-41cc-a607-161f2eede0c9))
      (net 135 "Net-(J13-Pad9)") (pintype "passive") (tstamp 8c02b0f9-cfae-45f6-909c-49df68355862))
      (scale (xyz 1 1 1))
    (tedit 5F68FEEF) (tstamp 98b4d6b0-b0b9-4f0c-9b79-c72c88fa5830)
    (at 30.861 55.626 180)
    (path "/d53dd1fb-38bb-44f7-bed7-f1cfad2a2225")
    (attr smd)
    (fp_text reference "C33" (at 1.778 -3.048 90) (layer "F.SilkS")
      (tstamp 0a3a9e8f-5b3e-4e40-a637-a252ef876872)
    (fp_text value "100n 50V KEM X7R1206 1,0U" (at 0 1.85) (layer "F.Fab")
      (tstamp 55aeffdd-d00b-4a2c-af5d-db8644ae804e)
      (tstamp 35762046-e253-4633-a0d2-47beb48352aa)
    (fp_line (start -0.711252 0.91) (end 0.711252 0.91) (layer "F.SilkS") (width 0.12) (tstamp 416561fe-0130-49ff-90ab-509533e167a5))
    (fp_line (start -0.711252 -0.91) (end 0.711252 -0.91) (layer "F.SilkS") (width 0.12) (tstamp f7d38c84-80c1-4ca7-a78c-a2a82e332f71))
    (fp_line (start -2.48 -1.15) (end 2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp 01ae93f3-2d0e-4d9e-bbcf-b8b1bc2ab96c))
    (fp_line (start 2.48 1.15) (end -2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp 3abbfd60-39eb-431e-8053-3dc1699492f8))
    (fp_line (start -2.48 1.15) (end -2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp adbafa5d-adfc-43a8-87a0-de0dcf095fac))
    (fp_line (start 2.48 -1.15) (end 2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp d08fef3e-c8b2-40c0-be3b-1846f02f128e))
    (fp_line (start 1.6 0.8) (end -1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp 25d273a2-9ef1-4e6d-b9cb-d66a6c3c7c40))
    (fp_line (start -1.6 -0.8) (end 1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp 6380f502-0d82-461c-95d0-9226ba5af6dd))
    (fp_line (start 1.6 -0.8) (end 1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp c1fd98fd-7753-4f07-abad-be4e1525034c))
    (fp_line (start -1.6 0.8) (end -1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp fdd23120-e52e-4281-bf5d-ecc0e79043d9))
    (pad "1" smd roundrect (at -1.5625 0 180) (size 1.325 1.8) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1886792453)
      (net 85 "Net-(C20-Pad1)") (pintype "passive") (tstamp 4efb3a40-dd33-43da-9587-17b24faee763))
    (pad "2" smd roundrect (at 1.5625 0 180) (size 1.325 1.8) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1886792453)
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp 54ffc5ee-9328-45e8-a7e6-ed301dc3ac00))
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp 999a3c8f-141b-491d-b52e-b8d156409dba)
    (at 53.721 121.666 90)
    (path "/947ea83a-ecc1-4c10-b913-7e18fd7a8175")
    (attr smd)
    (fp_text reference "R14" (at -0.127 2.54 90) (layer "F.SilkS")
      (tstamp 1bf0bb1a-c6f5-4d61-8d50-201a4d46ae54)
    (fp_text value "SMD 1/4W 10k" (at 0 2.28 90) (layer "F.Fab")
      (tstamp 4e3912f2-318a-4284-b7f0-4704040788a7)
      (tstamp e9e5ffe5-b2fe-47f1-b4b2-42a59e3304ed)
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 8f3f6740-b3bd-4016-b353-04e27d2b4d28))
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp c34a3dd5-21f6-4b49-a84c-88e2c8a5c859))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 327815e1-3fd4-48b7-af86-8e543366f842))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 48d53584-74ee-444d-8305-46028a10e892))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 99cb4725-562e-4145-96c6-6b2b0035b2fa))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp c923d973-4982-48f3-91dc-00d993c0d196))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 0601d3d4-09d1-4961-affa-9e156c5895cc))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 926c4cff-fba4-472e-8665-5f03fe5c90a7))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp d4569042-318f-4bfd-8076-e90d286b10b6))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp e6061e77-9bb4-46f0-ad6a-05489de2fd23))
    (pad "1" smd roundrect (at -1.55 0 90) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp 9a53c1cd-eb0e-43f3-afba-1075fc616432))
    (pad "2" smd roundrect (at 1.55 0 90) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 106 "Net-(R14-Pad2)") (pintype "passive") (tstamp 33c40f74-c4a6-4169-b5f9-00c08719c428))
      (scale (xyz 1 1 1))
  (footprint "Capacitor_THT:CP_Radial_D5.0mm_P2.00mm" (layer "F.Cu")
    (tedit 5AE50EF0) (tstamp 9cd0b1e2-59bf-4982-b9e4-d78b305008ac)
    (at 74.676 47.685888 -90)
    (descr "CP, Radial series, Radial, pin pitch=2.00mm, , diameter=5mm, Electrolytic Capacitor")
    (tags "CP Radial series Radial pin pitch 2.00mm  diameter 5mm Electrolytic Capacitor")
    (path "/802494d1-431d-476c-9840-75100e8995de")
    (attr through_hole)
    (fp_text reference "C35" (at 1.082112 3.683 -90) (layer "F.SilkS")
      (tstamp 86dcb972-5c94-489c-ac2c-a365ff1935bb)
    (fp_text value "GA-A 10U 16V" (at 1 3.75 90) (layer "F.Fab")
      (tstamp 58b5f064-246e-4b00-b078-ddf909bef950)
    (fp_text user "${REFERENCE}" (at 1 0 90) (layer "F.Fab")
      (tstamp 72316fcc-65ad-4117-8573-fca40fed5b97)
    (fp_line (start 1.16 -2.576) (end 1.16 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 01af78d3-12f9-4c75-87b7-cfdc4639af4d))
    (fp_line (start 2.041 1.04) (end 2.041 2.365) (layer "F.SilkS") (width 0.12) (tstamp 02571e14-eee3-4571-b231-68d16a3ac80b))
    (fp_line (start 1.52 -2.528) (end 1.52 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 02a333e9-557d-4317-8c2e-8029fefba7a7))
    (fp_line (start 2.081 -2.348) (end 2.081 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 02e6c18d-9e92-4297-bf52-7082fc064c0c))
    (fp_line (start 1.36 -2.556) (end 1.36 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 03e0a3e4-1ee6-4a94-97e4-cb9e598ee656))
    (fp_line (start 3.121 -1.5) (end 3.121 1.5) (layer "F.SilkS") (width 0.12) (tstamp 04963a91-aedb-4cdb-bda0-02a994b5d44d))
    (fp_line (start 2.401 1.04) (end 2.401 2.175) (layer "F.SilkS") (width 0.12) (tstamp 060f3cc0-e59b-407c-ac0e-c5f6e6d881a5))
    (fp_line (start 2.361 -2.2) (end 2.361 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 09cda832-e893-445b-ac7b-ce54f283ed5e))
    (fp_line (start 2.881 1.04) (end 2.881 1.785) (layer "F.SilkS") (width 0.12) (tstamp 0ad8b662-05f3-48f4-b5e0-e3436ac42aab))
    (fp_line (start 2.001 1.04) (end 2.001 2.382) (layer "F.SilkS") (width 0.12) (tstamp 0ec6c31d-1559-440e-a5c0-9ca90ad74d0b))
    (fp_line (start 2.001 -2.382) (end 2.001 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 0f379845-a80d-434c-9a4c-3721ce8179bc))
    (fp_line (start 1.2 1.04) (end 1.2 2.573) (layer "F.SilkS") (width 0.12) (tstamp 0fb989dd-aeea-4e62-a375-74e66ffd8835))
    (fp_line (start 1 1.04) (end 1 2.58) (layer "F.SilkS") (width 0.12) (tstamp 1081b8fd-8c63-4933-8b0f-ec414435394f))
    (fp_line (start 3.481 -0.805) (end 3.481 0.805) (layer "F.SilkS") (width 0.12) (tstamp 134ce285-e9fa-4f05-a35e-dd1151ed6949))
    (fp_line (start 1.08 1.04) (end 1.08 2.579) (layer "F.SilkS") (width 0.12) (tstamp 146245d7-4521-4503-a851-574b8f545f86))
    (fp_line (start 1.44 1.04) (end 1.44 2.543) (layer "F.SilkS") (width 0.12) (tstamp 1c10a253-ae18-4ab0-a905-956557bbbb64))
    (fp_line (start 1.761 -2.468) (end 1.761 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 1c86c2e7-6dce-4f4b-828e-a429c258ba06))
    (fp_line (start 1.12 1.04) (end 1.12 2.578) (layer "F.SilkS") (width 0.12) (tstamp 1e1159ab-4588-4f5b-8d0a-efd67328c978))
    (fp_line (start 1.68 1.04) (end 1.68 2.491) (layer "F.SilkS") (width 0.12) (tstamp 1f64db7e-89d4-43cd-9889-ab87e5e899f6))
    (fp_line (start 1.4 -2.55) (end 1.4 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 24abe61a-6036-4ab3-b528-82d72fc09f55))
    (fp_line (start 2.321 -2.224) (end 2.321 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 27a24e3a-9778-4faa-bff8-bc1701b5e7b2))
    (fp_line (start -1.554775 -1.725) (end -1.554775 -1.225) (layer "F.SilkS") (width 0.12) (tstamp 28dc1619-7870-4b30-b02f-2904f719fbba))
    (fp_line (start 2.241 -2.268) (end 2.241 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 2ed6d8db-129c-4c3c-8481-3fdc707b4ea9))
    (fp_line (start 2.321 1.04) (end 2.321 2.224) (layer "F.SilkS") (width 0.12) (tstamp 328e922a-f1e3-41c4-b55a-fe3063076d68))
    (fp_line (start 1.64 -2.501) (end 1.64 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 38692abe-b8ac-4f3c-add1-e9355b760deb))
    (fp_line (start 1.44 -2.543) (end 1.44 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 39488336-2019-444a-981c-4117e13b4c41))
    (fp_line (start 3.441 -0.915) (end 3.441 0.915) (layer "F.SilkS") (width 0.12) (tstamp 3c606e8b-5299-4255-ba4b-0674b2d82cb8))
    (fp_line (start 2.961 -1.699) (end 2.961 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 42496f0f-97ef-4bae-a807-a26438863374))
    (fp_line (start 2.121 -2.329) (end 2.121 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 48e47f42-e997-4d37-bf1c-aac88901dabe))
    (fp_line (start 2.361 1.04) (end 2.361 2.2) (layer "F.SilkS") (width 0.12) (tstamp 4b138b3d-597c-45ea-bb81-dc9b21c50057))
    (fp_line (start 3.041 -1.605) (end 3.041 1.605) (layer "F.SilkS") (width 0.12) (tstamp 4fa0c56d-456d-44b9-9649-8b3c44fcedca))
    (fp_line (start 1.841 -2.442) (end 1.841 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 4fe98a3e-1c67-4602-849b-030dc5d7c943))
    (fp_line (start 2.441 -2.149) (end 2.441 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 50400c84-e841-4e04-bbb0-128615e24110))
    (fp_line (start 1.961 -2.398) (end 1.961 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 53d24378-a212-449e-8d6e-b5eced696750))
    (fp_line (start 2.761 -1.901) (end 2.761 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 53fa81ed-5613-473e-9241-488d7cf031ee))
    (fp_line (start 1.16 1.04) (end 1.16 2.576) (layer "F.SilkS") (width 0.12) (tstamp 568c6766-feb6-40f4-9f8e-42a8816280d0))
    (fp_line (start 3.201 -1.383) (end 3.201 1.383) (layer "F.SilkS") (width 0.12) (tstamp 588d5f7d-767e-4842-ad68-10d197afd470))
    (fp_line (start 1.64 1.04) (end 1.64 2.501) (layer "F.SilkS") (width 0.12) (tstamp 5b6a7529-7ade-441f-9dcc-5ae1a63bb4e4))
    (fp_line (start 1.761 1.04) (end 1.761 2.468) (layer "F.SilkS") (width 0.12) (tstamp 5c9a2f2e-0300-43b4-9d81-a4b00fb54484))
    (fp_line (start 1.2 -2.573) (end 1.2 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 5c9c6c6d-2011-4120-93fe-ee0be4cd1b30))
    (fp_line (start 3.521 -0.677) (end 3.521 0.677) (layer "F.SilkS") (width 0.12) (tstamp 5cc3da3d-9029-40a2-bf87-817075833050))
    (fp_line (start 2.801 1.04) (end 2.801 1.864) (layer "F.SilkS") (width 0.12) (tstamp 5d9e81d7-fe19-4a40-af16-d7c1eccdbdd6))
    (fp_line (start 2.481 1.04) (end 2.481 2.122) (layer "F.SilkS") (width 0.12) (tstamp 63332e31-a300-4e90-8410-9215f23ffd06))
    (fp_line (start 1.6 -2.511) (end 1.6 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 6486f67e-0518-4600-b660-4d507670f0bd))
    (fp_line (start 1.68 -2.491) (end 1.68 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 648e8977-153d-4470-96d7-65ec822fc439))
    (fp_line (start 2.561 1.04) (end 2.561 2.065) (layer "F.SilkS") (width 0.12) (tstamp 65f7f0c4-71c1-4d5d-b260-8de7623834de))
    (fp_line (start 2.961 1.04) (end 2.961 1.699) (layer "F.SilkS") (width 0.12) (tstamp 66f8259a-1fa3-452b-96df-ff4be9bd78be))
    (fp_line (start 3.241 -1.319) (end 3.241 1.319) (layer "F.SilkS") (width 0.12) (tstamp 67bfc0b9-8f9e-4a35-9680-133c5b18d3a4))
    (fp_line (start 2.561 -2.065) (end 2.561 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 68e2fa73-0ecb-4e1f-a355-d35bc1e2cea3))
    (fp_line (start 1.04 -2.58) (end 1.04 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 6b708b2b-79c1-443a-b35d-e2e5c14f0052))
    (fp_line (start 1.801 -2.455) (end 1.801 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 6c558191-112b-4813-a682-6fdb8f3fdbf7))
    (fp_line (start 2.201 -2.29) (end 2.201 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 6c96f08e-e6d7-48f3-bc6b-c1dc4bd3f179))
    (fp_line (start 3.281 -1.251) (end 3.281 1.251) (layer "F.SilkS") (width 0.12) (tstamp 6c99b45c-419d-48b2-826c-b559c1c607e5))
    (fp_line (start 2.121 1.04) (end 2.121 2.329) (layer "F.SilkS") (width 0.12) (tstamp 6d744588-464b-4871-a69a-44a5f42304fb))
    (fp_line (start 2.681 1.04) (end 2.681 1.971) (layer "F.SilkS") (width 0.12) (tstamp 6de696e5-1e5a-4c9e-aa12-8fadf8b98ac6))
    (fp_line (start 1.32 1.04) (end 1.32 2.561) (layer "F.SilkS") (width 0.12) (tstamp 6f1b87d0-b733-44fe-a921-909bb12c450b))
    (fp_line (start 3.001 1.04) (end 3.001 1.653) (layer "F.SilkS") (width 0.12) (tstamp 71ca99c6-3407-4e82-97bd-aa42310cc27c))
    (fp_line (start 1.48 -2.536) (end 1.48 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 7289af0b-01f1-46a8-9c68-dd573f7f2d2f))
    (fp_line (start 1.921 -2.414) (end 1.921 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 73a62fe0-4cc5-447f-9b92-5442fe00effa))
    (fp_line (start 1.24 -2.569) (end 1.24 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 785b5a10-64d9-460e-b3de-9e1928b4aea8))
    (fp_line (start 1.4 1.04) (end 1.4 2.55) (layer "F.SilkS") (width 0.12) (tstamp 7a19ccc8-06a1-442d-bbc8-a35501397cc4))
    (fp_line (start 2.641 -2.004) (end 2.641 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 7ec15fcf-3db9-479c-a6fd-32409472c190))
    (fp_line (start 3.601 -0.284) (end 3.601 0.284) (layer "F.SilkS") (width 0.12) (tstamp 7ff4cb5d-3168-428b-9455-8af9fa9ccea0))
    (fp_line (start 2.641 1.04) (end 2.641 2.004) (layer "F.SilkS") (width 0.12) (tstamp 8483a49a-36c7-411e-950d-acae794a7284))
    (fp_line (start 1.881 -2.428) (end 1.881 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 8656b00f-71c9-4022-baf5-0a917f838e1a))
    (fp_line (start 1.36 1.04) (end 1.36 2.556) (layer "F.SilkS") (width 0.12) (tstamp 87b63aab-ffe1-4d11-a256-d98244efc759))
    (fp_line (start 3.081 -1.554) (end 3.081 1.554) (layer "F.SilkS") (width 0.12) (tstamp 888472e7-5a78-4df8-8974-d2aaa0ccf97d))
    (fp_line (start 1.841 1.04) (end 1.841 2.442) (layer "F.SilkS") (width 0.12) (tstamp 8bf9c317-dee7-4f2c-af5e-804c57a55b60))
    (fp_line (start 2.081 1.04) (end 2.081 2.348) (layer "F.SilkS") (width 0.12) (tstamp 8de4b0d7-4ed5-406e-be7a-39c3079bd7d6))
    (fp_line (start 1.881 1.04) (end 1.881 2.428) (layer "F.SilkS") (width 0.12) (tstamp 8e947313-2302-4f0b-981c-74d503abb330))
    (fp_line (start 2.161 -2.31) (end 2.161 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 8f1fc313-0b5e-4b0d-9bb9-43057c8be976))
    (fp_line (start 1.48 1.04) (end 1.48 2.536) (layer "F.SilkS") (width 0.12) (tstamp 92c7017c-3968-4fbc-bed1-a096a2f81554))
    (fp_line (start 2.681 -1.971) (end 2.681 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 97056da2-5152-4674-b069-56abe0aeaf79))
    (fp_line (start 1.801 1.04) (end 1.801 2.455) (layer "F.SilkS") (width 0.12) (tstamp 99c5da2a-63eb-4e5d-9dd2-9071d70f625c))
    (fp_line (start 2.401 -2.175) (end 2.401 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 9bfa6068-f3f1-4289-8499-11eaa1ee7051))
    (fp_line (start 2.841 1.04) (end 2.841 1.826) (layer "F.SilkS") (width 0.12) (tstamp 9f1e487d-1362-4e2d-9210-c77622d67434))
    (fp_line (start 2.921 1.04) (end 2.921 1.743) (layer "F.SilkS") (width 0.12) (tstamp a0a44510-367e-4b4f-b800-f782784e8790))
    (fp_line (start 1.28 1.04) (end 1.28 2.565) (layer "F.SilkS") (width 0.12) (tstamp a0fb356f-20be-4c8f-a2e5-753592e9655a))
    (fp_line (start 1.921 1.04) (end 1.921 2.414) (layer "F.SilkS") (width 0.12) (tstamp a583895b-d229-4bad-aa22-52d6dfcb8a77))
    (fp_line (start 1.24 1.04) (end 1.24 2.569) (layer "F.SilkS") (width 0.12) (tstamp a5b75240-2b4a-440d-b6e2-366bab145cab))
    (fp_line (start 1.12 -2.578) (end 1.12 -1.04) (layer "F.SilkS") (width 0.12) (tstamp a94fb259-6ca9-4d98-b4b9-3f8f86a840b9))
    (fp_line (start -1.804775 -1.475) (end -1.304775 -1.475) (layer "F.SilkS") (width 0.12) (tstamp aac85e4a-f17a-45cb-b6e0-4f480dde540d))
    (fp_line (start 1.56 1.04) (end 1.56 2.52) (layer "F.SilkS") (width 0.12) (tstamp abe9dd24-be20-4266-9b78-ad2a968b5d08))
    (fp_line (start 1.6 1.04) (end 1.6 2.511) (layer "F.SilkS") (width 0.12) (tstamp adcf6411-836e-449f-8dce-c604a7b84162))
    (fp_line (start 1.28 -2.565) (end 1.28 -1.04) (layer "F.SilkS") (width 0.12) (tstamp af56f939-0cd2-4516-a362-952b29cdbfec))
    (fp_line (start 1 -2.58) (end 1 -1.04) (layer "F.SilkS") (width 0.12) (tstamp b2ebe8b5-0c0c-40a1-8d5f-b5f46083244c))
    (fp_line (start 3.561 -0.518) (end 3.561 0.518) (layer "F.SilkS") (width 0.12) (tstamp b446b800-d4ad-4ecc-a9e0-21b6f46686aa))
    (fp_line (start 1.32 -2.561) (end 1.32 -1.04) (layer "F.SilkS") (width 0.12) (tstamp b4c64406-ac1d-4e6e-b6ab-0497c8b10bad))
    (fp_line (start 2.281 -2.247) (end 2.281 -1.04) (layer "F.SilkS") (width 0.12) (tstamp b539d96b-94da-4277-bb8d-0063309956d8))
    (fp_line (start 1.56 -2.52) (end 1.56 -1.04) (layer "F.SilkS") (width 0.12) (tstamp b8d3bc4c-43d3-4dd9-8bee-0c50df01667d))
    (fp_line (start 2.041 -2.365) (end 2.041 -1.04) (layer "F.SilkS") (width 0.12) (tstamp ba5f4dbb-755d-43be-a794-c9545f472679))
    (fp_line (start 1.08 -2.579) (end 1.08 -1.04) (layer "F.SilkS") (width 0.12) (tstamp baf8d9f5-355c-43f1-9277-f72092a06d58))
    (fp_line (start 2.601 -2.035) (end 2.601 -1.04) (layer "F.SilkS") (width 0.12) (tstamp becefb2f-0e48-4d0b-aa1d-f0cfd07ca3e1))
    (fp_line (start 2.281 1.04) (end 2.281 2.247) (layer "F.SilkS") (width 0.12) (tstamp c077153f-5971-4ffa-bd31-c65124cf9591))
    (fp_line (start 2.761 1.04) (end 2.761 1.901) (layer "F.SilkS") (width 0.12) (tstamp c21becd3-9605-4544-82e5-d39cab818a8b))
    (fp_line (start 3.001 -1.653) (end 3.001 -1.04) (layer "F.SilkS") (width 0.12) (tstamp c2c8fc7d-fbd5-4d8d-81b7-39cbe14da16b))
    (fp_line (start 1.961 1.04) (end 1.961 2.398) (layer "F.SilkS") (width 0.12) (tstamp c5b691f0-6e21-4866-9e1d-e7e9ff21402b))
    (fp_line (start 2.841 -1.826) (end 2.841 -1.04) (layer "F.SilkS") (width 0.12) (tstamp cb412f5a-4cd3-4247-9c8a-5b701b05fa51))
    (fp_line (start 2.921 -1.743) (end 2.921 -1.04) (layer "F.SilkS") (width 0.12) (tstamp cbcda5b8-4615-438a-9abd-b86ac98e38dd))
    (fp_line (start 1.721 1.04) (end 1.721 2.48) (layer "F.SilkS") (width 0.12) (tstamp cc86c5f7-e186-49dd-a6f1-faf3346e3a31))
    (fp_line (start 2.721 1.04) (end 2.721 1.937) (layer "F.SilkS") (width 0.12) (tstamp cea7f15e-6321-4556-9186-ed7d03f7ba85))
    (fp_line (start 2.601 1.04) (end 2.601 2.035) (layer "F.SilkS") (width 0.12) (tstamp d030125e-30f5-43fb-bdde-6f0927129c39))
    (fp_line (start 2.721 -1.937) (end 2.721 -1.04) (layer "F.SilkS") (width 0.12) (tstamp d0604c30-4e18-4101-af57-34d20b9cd7cd))
    (fp_line (start 2.881 -1.785) (end 2.881 -1.04) (layer "F.SilkS") (width 0.12) (tstamp d60614f7-f786-4a65-94f0-424500ecac78))
    (fp_line (start 2.521 1.04) (end 2.521 2.095) (layer "F.SilkS") (width 0.12) (tstamp dd378ff5-558b-46d2-b911-f3edda47b106))
    (fp_line (start 2.201 1.04) (end 2.201 2.29) (layer "F.SilkS") (width 0.12) (tstamp e158ea0f-ed21-45fb-be56-d9219fe6be0f))
    (fp_line (start 1.721 -2.48) (end 1.721 -1.04) (layer "F.SilkS") (width 0.12) (tstamp e48901e0-712e-4753-aa7b-032d9a064235))
    (fp_line (start 2.441 1.04) (end 2.441 2.149) (layer "F.SilkS") (width 0.12) (tstamp e5603d1d-ad93-4f3f-8c66-628467436097))
    (fp_line (start 3.161 -1.443) (end 3.161 1.443) (layer "F.SilkS") (width 0.12) (tstamp e6e8daf1-0c1a-49af-9c33-3d23e706838d))
    (fp_line (start 3.321 -1.178) (end 3.321 1.178) (layer "F.SilkS") (width 0.12) (tstamp e84e79e5-00ef-4cee-ae79-4151e345cc3b))
    (fp_line (start 3.361 -1.098) (end 3.361 1.098) (layer "F.SilkS") (width 0.12) (tstamp e92e359a-7ac6-426a-840a-108b38f4a345))
    (fp_line (start 2.481 -2.122) (end 2.481 -1.04) (layer "F.SilkS") (width 0.12) (tstamp e969753e-03f7-406b-9b1a-5372fc86d3f2))
    (fp_line (start 2.521 -2.095) (end 2.521 -1.04) (layer "F.SilkS") (width 0.12) (tstamp ecdff23d-ea1d-4efa-abe5-74a7dae0eabc))
    (fp_line (start 1.04 1.04) (end 1.04 2.58) (layer "F.SilkS") (width 0.12) (tstamp ee133d70-774d-4f10-b501-554afbb18957))
    (fp_line (start 2.241 1.04) (end 2.241 2.268) (layer "F.SilkS") (width 0.12) (tstamp ef179117-81e5-4add-8af8-65ae0ed2102e))
    (fp_line (start 2.161 1.04) (end 2.161 2.31) (layer "F.SilkS") (width 0.12) (tstamp f0145c27-b3d4-42ef-8265-8c6571c02823))
    (fp_line (start 2.801 -1.864) (end 2.801 -1.04) (layer "F.SilkS") (width 0.12) (tstamp f0c8a9de-f5d7-40fb-8d28-039a7d3978f9))
    (fp_line (start 3.401 -1.011) (end 3.401 1.011) (layer "F.SilkS") (width 0.12) (tstamp f1a45176-3d1e-4fa2-b5a0-0ce94ee7bd71))
    (fp_line (start 1.52 1.04) (end 1.52 2.528) (layer "F.SilkS") (width 0.12) (tstamp f6b36aa2-9c43-4db5-bd58-8213cc1832d7))
    (fp_circle (center 1 0) (end 3.62 0) (layer "F.SilkS") (width 0.12) (fill none) (tstamp 96ee3777-c16c-4b48-9fad-d80bb364b2b6))
    (fp_circle (center 1 0) (end 3.75 0) (layer "F.CrtYd") (width 0.05) (fill none) (tstamp 2f2cfa1e-0cfb-470f-820e-c50ad9577f8d))
    (fp_line (start -0.883605 -1.3375) (end -0.883605 -0.8375) (layer "F.Fab") (width 0.1) (tstamp 270b9454-c430-466c-8944-0433c80914c1))
    (fp_line (start -1.133605 -1.0875) (end -0.633605 -1.0875) (layer "F.Fab") (width 0.1) (tstamp ce88c368-51a2-4b56-a8a8-e6cc0257bf3b))
    (fp_circle (center 1 0) (end 3.5 0) (layer "F.Fab") (width 0.1) (fill none) (tstamp 7b1f193f-0339-4b3c-8e05-d7580ccca5f4))
    (pad "1" thru_hole rect (at 0 0 270) (size 1.6 1.6) (drill 0.8) (layers *.Cu *.Mask)
      (net 3 "Net-(C1-Pad2)") (pintype "passive") (tstamp 3e8f0c08-cb71-4512-8965-b6c953be6a28))
    (pad "2" thru_hole circle (at 2 0 270) (size 1.6 1.6) (drill 0.8) (layers *.Cu *.Mask)
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp da644441-d6df-4c74-a7b1-e734eee3e0c0))
    (model "${KICAD6_3DMODEL_DIR}/Capacitor_THT.3dshapes/CP_Radial_D5.0mm_P2.00mm.wrl"
      (scale (xyz 1 1 1))
  (footprint "Diode_THT:D_DO-41_SOD81_P10.16mm_Horizontal" (layer "F.Cu")
    (tedit 5AE50CD5) (tstamp 9e6c5503-e6b8-4b02-aecb-02492f687b16)
    (at 30.861 39.37 90)
    (descr "Diode, DO-41_SOD81 series, Axial, Horizontal, pin pitch=10.16mm, , length*diameter=5.2*2.7mm^2, , http://www.diodes.com/_files/packages/DO-41%20(Plastic).pdf")
    (tags "Diode DO-41_SOD81 series Axial Horizontal pin pitch 10.16mm  length 5.2mm diameter 2.7mm")
    (path "/609118d4-cf5e-4a81-a94b-894246bc3ddd")
    (attr through_hole)
    (fp_text reference "D8" (at 5.08 -2.47 90) (layer "F.SilkS")
      (tstamp 762ee416-1ab1-4b90-a9f6-db0386568942)
    (fp_text value "1N4007" (at 5.08 2.47 90) (layer "F.Fab")
      (tstamp 3ab86fb5-df90-4d12-851d-a478de608145)
    (fp_text user "K" (at 0 -2.1 90) (layer "F.SilkS")
      (tstamp a6e2ce37-0970-4cd6-8bd7-2d71d7904750)
    (fp_text user "${REFERENCE}" (at 5.47 0 90) (layer "F.Fab")
      (tstamp 11063ef4-9be8-4edc-992c-dd62ce343bc3)
    (fp_text user "K" (at 0 -2.1 90) (layer "F.Fab")
      (tstamp 2fc7a13c-dbc4-44e8-82f2-54b76655805f)
    (fp_line (start 1.34 0) (end 2.36 0) (layer "F.SilkS") (width 0.12) (tstamp 1190e9c2-0512-4cce-bc17-8bdb89d3e725))
    (fp_line (start 8.82 0) (end 7.8 0) (layer "F.SilkS") (width 0.12) (tstamp 39bdbbcb-f033-4ab3-b644-984c4ced3d84))
    (fp_line (start 7.8 1.47) (end 7.8 -1.47) (layer "F.SilkS") (width 0.12) (tstamp 53a353f8-0fc4-48e0-80fb-6cf7c78b0a9d))
    (fp_line (start 7.8 -1.47) (end 2.36 -1.47) (layer "F.SilkS") (width 0.12) (tstamp 858beb90-00bd-48c7-9463-5c9da3327e89))
    (fp_line (start 2.36 1.47) (end 7.8 1.47) (layer "F.SilkS") (width 0.12) (tstamp a79a8a32-9c18-466f-8fce-ec3b4c1ec034))
    (fp_line (start 3.26 -1.47) (end 3.26 1.47) (layer "F.SilkS") (width 0.12) (tstamp a9d51e9c-7c76-4c2b-bdb1-d485f8d2f15e))
    (fp_line (start 3.14 -1.47) (end 3.14 1.47) (layer "F.SilkS") (width 0.12) (tstamp be9ae76b-ff0c-4307-8fc6-59195cb78dc1))
    (fp_line (start 3.38 -1.47) (end 3.38 1.47) (layer "F.SilkS") (width 0.12) (tstamp f05370c3-c54a-4cdc-9b66-b39b555390f9))
    (fp_line (start 2.36 -1.47) (end 2.36 1.47) (layer "F.SilkS") (width 0.12) (tstamp fa436d7b-7389-4f45-af24-9d5970856271))
    (fp_line (start -1.35 1.6) (end 11.51 1.6) (layer "F.CrtYd") (width 0.05) (tstamp 0b1360c1-d852-483c-930a-b644b74b3159))
    (fp_line (start -1.35 -1.6) (end -1.35 1.6) (layer "F.CrtYd") (width 0.05) (tstamp 56fb32db-d0dd-4876-bc0d-493f1630b05e))
    (fp_line (start 11.51 1.6) (end 11.51 -1.6) (layer "F.CrtYd") (width 0.05) (tstamp 692dcb2b-6c27-4b02-a031-269bfd301b1d))
    (fp_line (start 11.51 -1.6) (end -1.35 -1.6) (layer "F.CrtYd") (width 0.05) (tstamp d4a24bb6-9b9c-4676-b0f1-1f75521f2ff4))
    (fp_line (start 3.26 -1.35) (end 3.26 1.35) (layer "F.Fab") (width 0.1) (tstamp 1329e67b-c903-4ea2-983f-06d2a9b60d26))
    (fp_line (start 3.16 -1.35) (end 3.16 1.35) (layer "F.Fab") (width 0.1) (tstamp 1fff447c-915a-4969-9639-3ff9045cab95))
    (fp_line (start 3.36 -1.35) (end 3.36 1.35) (layer "F.Fab") (width 0.1) (tstamp 62486d52-003d-4b38-a79e-3bce9d0cc6ff))
    (fp_line (start 2.48 1.35) (end 7.68 1.35) (layer "F.Fab") (width 0.1) (tstamp 91512ec3-0302-4eb8-99f7-13ed0ac4ecc1))
    (fp_line (start 7.68 1.35) (end 7.68 -1.35) (layer "F.Fab") (width 0.1) (tstamp bdeaa59f-145e-4edc-8833-0e06eb290f63))
    (fp_line (start 7.68 -1.35) (end 2.48 -1.35) (layer "F.Fab") (width 0.1) (tstamp d142ff4b-3573-4ac3-b272-087a00523fa9))
    (fp_line (start 2.48 -1.35) (end 2.48 1.35) (layer "F.Fab") (width 0.1) (tstamp d331ea60-6cd2-4a92-99e5-af0fa814ce1c))
    (fp_line (start 10.16 0) (end 7.68 0) (layer "F.Fab") (width 0.1) (tstamp ed01b26c-7a3a-4208-b904-6d1f5affefab))
    (fp_line (start 0 0) (end 2.48 0) (layer "F.Fab") (width 0.1) (tstamp ef17f51b-4395-44c0-a309-ff9d2e4c0c88))
    (pad "1" thru_hole rect (at 0 0 90) (size 2.2 2.2) (drill 1.1) (layers *.Cu *.Mask)
      (net 22 "Net-(D8-Pad1)") (pinfunction "K") (pintype "passive") (tstamp d61f5125-96e9-45a0-a55e-a2c0690da13d))
    (pad "2" thru_hole oval (at 10.16 0 90) (size 2.2 2.2) (drill 1.1) (layers *.Cu *.Mask)
      (net 9 "Net-(C12-Pad1)") (pinfunction "A") (pintype "passive") (tstamp 492ac616-38ab-4f05-bcfd-59cf2b0f53e5))
    (model "${KICAD6_3DMODEL_DIR}/Diode_THT.3dshapes/D_DO-41_SOD81_P10.16mm_Horizontal.wrl"
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp 9f462ef5-8c1b-4e89-9a34-6a1caa53fd63)
    (at 81.661 41.656 180)
    (path "/89caa565-1cc6-48ce-a65e-dabe1db79756")
    (attr smd)
    (fp_text reference "R11" (at 3.302 0 90) (layer "F.SilkS")
      (tstamp 108fdc62-2caf-408b-82e1-ee2ff07660ac)
    (fp_text value "SMD 1/4W 15k" (at 0 2.28) (layer "F.Fab")
      (tstamp 831b9992-6246-4a32-9a26-53e896ccc26e)
      (tstamp 6c2b4b90-9c5c-4c30-9acd-59cb50920f68)
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp 63a4abcd-d165-451b-b9da-9c8c10874857))
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 933cd68b-c28a-43b7-bdfd-e377f42e991c))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 259e8dca-91f2-4fff-8125-c2b3f95a7827))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 698d73fc-97fd-45f6-9f83-ea17d694cf17))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 91b42db7-152e-46e8-a25e-2a574d0e4b26))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp c825c855-479a-47f3-9dca-4006993edb02))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 04b919de-22e0-47ec-83da-2963556d2af4))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 93e40a70-5bba-42c4-98dc-77d85cf06083))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp d90f38c4-7f59-4617-9b82-a3978116cb6d))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp f6a315b8-a635-413f-8669-87303d9ad379))
      (net 10 "Net-(C14-Pad1)") (pintype "passive") (tstamp 7af7b6c9-59dd-4578-bfd5-e90786e74ad5))
      (net 8 "Net-(C10-Pad2)") (pintype "passive") (tstamp 4e905968-1c91-490b-a72d-52bd59516ef2))
      (scale (xyz 1 1 1))
  (footprint "Package_TO_SOT_THT:TO-92_Inline" (layer "F.Cu")
    (tedit 5A1DD157) (tstamp a01eeeb8-d265-4f7e-a0a7-76c5c76c156c)
    (at 38.375 41.275 -90)
    (descr "TO-92 leads in-line, narrow, oval pads, drill 0.75mm (see NXP sot054_po.pdf)")
    (tags "to-92 sc-43 sc-43a sot54 PA33 transistor")
    (path "/21884b67-7b6f-400d-9a89-274b38b22201")
    (attr through_hole)
    (fp_text reference "Q3" (at -0.635 2.942 90) (layer "F.SilkS")
      (tstamp eff34a3d-db32-4bcc-93f8-7853699d943a)
    (fp_text value "BC327" (at 1.27 2.79 90) (layer "F.Fab")
      (tstamp c50c3a9a-dd16-43f8-b9b6-2c8d973b8bf3)
    (fp_text user "${REFERENCE}" (at 1.27 0 90) (layer "F.Fab")
      (tstamp 461490c7-12b7-4763-bd8b-455488df928d)
    (fp_line (start -0.53 1.85) (end 3.07 1.85) (layer "F.SilkS") (width 0.12) (tstamp c99430ea-bb42-4639-bf3c-0f252a1f95bd))
    (fp_arc (start 1.27 -2.6) (mid 3.672087 -0.994977) (end 3.108478 1.838478) (layer "F.SilkS") (width 0.12) (tstamp c7ea283b-4b2d-48ee-8de7-cc6a33be26ff))
    (fp_arc (start -0.568478 1.838478) (mid -1.132087 -0.994977) (end 1.27 -2.6) (layer "F.SilkS") (width 0.12) (tstamp fa307034-80c3-4741-b172-53d44dd8abf2))
    (fp_line (start 4 2.01) (end 4 -2.73) (layer "F.CrtYd") (width 0.05) (tstamp 0db28e64-84c6-4de3-a5b3-58fb88682686))
    (fp_line (start 4 2.01) (end -1.46 2.01) (layer "F.CrtYd") (width 0.05) (tstamp 2e3ba78d-8840-4827-bf13-87c3d6c17b03))
    (fp_line (start -1.46 -2.73) (end 4 -2.73) (layer "F.CrtYd") (width 0.05) (tstamp c746ae37-ef45-43ee-82c7-789ca8708849))
    (fp_line (start -1.46 -2.73) (end -1.46 2.01) (layer "F.CrtYd") (width 0.05) (tstamp d50ee19f-4ba1-4cbc-83cc-ac17c114715a))
    (fp_line (start -0.5 1.75) (end 3 1.75) (layer "F.Fab") (width 0.1) (tstamp 31f204f4-b3f8-44ac-868c-26b3bd66d0e6))
    (fp_arc (start 1.27 -2.48) (mid 3.561221 -0.949055) (end 3.023625 1.753625) (layer "F.Fab") (width 0.1) (tstamp a13b8353-9d62-4ef0-ad41-a5a05340983d))
    (fp_arc (start -0.483625 1.753625) (mid -1.021221 -0.949055) (end 1.27 -2.48) (layer "F.Fab") (width 0.1) (tstamp c305f75f-12d3-46ab-9dde-5d8fff924912))
    (pad "1" thru_hole rect (at 0 0 270) (size 1.05 1.5) (drill 0.75) (layers *.Cu *.Mask)
      (net 22 "Net-(D8-Pad1)") (pinfunction "C") (pintype "passive") (tstamp 70eb290f-80c3-499c-9be0-b8a761b787c4))
    (pad "2" thru_hole oval (at 1.27 0 270) (size 1.05 1.5) (drill 0.75) (layers *.Cu *.Mask)
      (net 42 "Net-(Q3-Pad2)") (pinfunction "B") (pintype "input") (tstamp b290f416-2f39-42ad-b7e0-b34edeef1505))
    (pad "3" thru_hole oval (at 2.54 0 270) (size 1.05 1.5) (drill 0.75) (layers *.Cu *.Mask)
      (net 10 "Net-(C14-Pad1)") (pinfunction "E") (pintype "passive") (tstamp 04f10be2-74bd-4508-91dd-30db9c1b4dfe))
    (model "${KICAD6_3DMODEL_DIR}/Package_TO_SOT_THT.3dshapes/TO-92_Inline.wrl"
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp a253ffd4-1786-49cf-9cb8-4cb479e1fe7d)
    (at 37.973 49.377 90)
    (path "/2e4fe546-85b0-4fbe-85d2-65d01eb7941e")
    (attr smd)
    (fp_text reference "R22" (at -0.153 2.794 90) (layer "F.SilkS")
      (tstamp c9c9258d-a9b5-4ef9-a080-d697b9d76b5d)
      (tstamp 966bac65-a9e5-4e70-b46d-2ff85ff59d60)
    (fp_text user "${REFERENCE}" (at 0 0 90) (layer "F.Fab")
      (effects (font (size 0.8 0.8) (thickness 0.12)))
      (tstamp a1e302ef-257e-470d-9628-e74b8e3f3cf7)
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 34db8c30-52b9-4b23-ada2-b4d0cd86a918))
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp a374a93a-b301-468b-a212-cc92a31a7064))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 06e3ea08-afd6-48a5-9443-d7cca8a08c6e))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 3fc17dbb-9043-4092-92b2-d7acd62a7ea5))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp a41c70ab-1275-4319-b88e-a1c7f80bf5e9))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp b4bae625-ea8b-4a90-a4d4-9662235d1d1a))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 00789457-8ee5-4a2d-8aa6-0e04bd82b654))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 1a9a8fa2-fb83-40ec-8ad3-495c3b776a89))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 8eba7993-31c0-4602-9fd8-4e2b6a23985f))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp f7ba93fb-57db-419a-bb4e-753b6de2bb35))
      (net 52 "Net-(R22-Pad1)") (pintype "passive") (tstamp ef01d9b1-0a56-45d3-ad78-b99fed83c0a7))
      (net 85 "Net-(C20-Pad1)") (pintype "passive") (tstamp 6a69431c-3497-47a4-8fe4-fa7fe0a2a98e))
      (scale (xyz 1 1 1))
  (footprint "Relay_THT:Relay_SPDT_Finder_40.51" (layer "F.Cu")
    (tedit 5A5B3F25) (tstamp a499ec7c-9143-4a81-8592-1c7c3112d7c8)
    (at 87.7335 100.1785)
    (descr "Relay DPDT Finder 40.51, Pitch 5mm/7.5mm, https://www.finder-relais.net/de/finder-relais-serie-40.pdf")
    (tags "Relay DPDT Finder 40.51 Pitch 5mm")
    (path "/cd090e4c-07dc-4d2b-b788-59ee641b3b60")
    (attr through_hole)
    (fp_text reference "K1" (at 25.4235 -4.1665 90) (layer "F.SilkS")
      (tstamp 8a37fa9d-488f-44ea-a56e-76885c2488be)
    (fp_text value "FINDER-40.51" (at 12.192 11.43) (layer "F.Fab")
      (tstamp 9399e690-65e5-49b7-a5f3-9c63350f8d8f)
    (fp_text user "${REFERENCE}" (at 12.065 3.81) (layer "F.Fab")
      (tstamp 04933b3f-010d-49a1-806b-a0a73afd739a)
    (fp_line (start -3.1 10.1) (end -3.1 -2.6) (layer "F.SilkS") (width 0.12) (tstamp 29561a6b-cbd0-46ff-b55a-827f8b31da6c))
    (fp_line (start 2.54 2.54) (end 5.08 3.81) (layer "F.SilkS") (width 0.12) (tstamp 2b052f68-ad92-42c9-a023-66cadb7aa412))
    (fp_line (start 3.81 7.62) (end 2.54 7.62) (layer "F.SilkS") (width 0.12) (tstamp 38a658a3-d051-403c-835d-8e340c6e9eb0))
    (fp_line (start -3.1 -2.6) (end 26.1 -2.6) (layer "F.SilkS") (width 0.12) (tstamp 3f5bd3b4-f04b-41e4-b019-7dddab2f26c9))
    (fp_line (start 26.1 10.1) (end -3.1 10.1) (layer "F.SilkS") (width 0.12) (tstamp 5387f9e6-024d-4b0f-b986-c8b6d2aab521))
    (fp_line (start 3.81 0) (end 3.81 1.27) (layer "F.SilkS") (width 0.12) (tstamp 55f5c3e5-1905-47e2-8297-192fb1979dc4))
    (fp_line (start -3.3 -0.4) (end -3.3 -2.8) (layer "F.SilkS") (width 0.12) (tstamp 707827b5-bfc2-4f90-893a-dcb5d74c0a33))
    (fp_line (start 2.54 0) (end 3.81 0) (layer "F.SilkS") (width 0.12) (tstamp 7eaa4128-dd84-4ada-b32f-fdbc4c57bffb))
    (fp_line (start 26.1 8.9) (end 26.1 10.1) (layer "F.SilkS") (width 0.12) (tstamp 851d9102-15bf-4353-9dfd-23b0aa61f641))
    (fp_line (start 2.54 6.35) (end 2.54 1.27) (layer "F.SilkS") (width 0.12) (tstamp 9452fd9e-d359-4fdb-9b19-3b49c7df1c69))
    (fp_line (start 5.08 1.27) (end 5.08 6.35) (layer "F.SilkS") (width 0.12) (tstamp a6e40e07-104d-40ab-95ef-981e153a44c9))
    (fp_line (start 3.81 1.27) (end 5.08 1.27) (layer "F.SilkS") (width 0.12) (tstamp ab12f943-6b82-4420-b30c-d5bb5c01a763))
    (fp_line (start 26.1 -2.6) (end 26.1 6.1) (layer "F.SilkS") (width 0.12) (tstamp b692ea8a-3e52-4c09-b048-7525857b9c0d))
    (fp_line (start 5.08 6.35) (end 2.54 6.35) (layer "F.SilkS") (width 0.12) (tstamp d9204544-9695-439d-b2f1-72bc0e2b7396))
    (fp_line (start -0.9 -2.8) (end -3.3 -2.8) (layer "F.SilkS") (width 0.12) (tstamp dc25c93c-105c-44c7-8b1a-8c591c84d0fb))
    (fp_line (start 2.54 1.27) (end 3.81 1.27) (layer "F.SilkS") (width 0.12) (tstamp e80ead9b-f37e-4960-8bcd-a744169de836))
    (fp_line (start 3.81 6.35) (end 3.81 7.62) (layer "F.SilkS") (width 0.12) (tstamp fa80d6d8-69c3-4323-a8bb-7040b28e735e))
    (fp_line (start -3.25 -2.75) (end -3.25 10.25) (layer "F.CrtYd") (width 0.05) (tstamp 1d3903ec-d73f-4b8c-8986-1934a08df748))
    (fp_line (start 26.75 10.25) (end 26.75 -2.75) (layer "F.CrtYd") (width 0.05) (tstamp 4cc707d2-6459-48dd-be69-c34d88c60511))
    (fp_line (start -3.25 -2.75) (end 26.75 -2.75) (layer "F.CrtYd") (width 0.05) (tstamp ad3d274f-7898-47e8-b7d4-d64df64f22df))
    (fp_line (start 26.75 10.25) (end -3.25 10.25) (layer "F.CrtYd") (width 0.05) (tstamp cc248cf6-5e35-4cad-800d-c3ba2fe52b07))
    (fp_line (start -3 10) (end 26 10) (layer "F.Fab") (width 0.12) (tstamp 0c958be2-31c1-4ad0-b467-b6ee6c153852))
    (fp_line (start 26 10) (end 26 -2.5) (layer "F.Fab") (width 0.12) (tstamp 6d0021e5-cf87-4d4b-b289-3301aec5c47e))
    (fp_line (start -3 -1.4) (end -3 10) (layer "F.Fab") (width 0.12) (tstamp 800b16c2-9ff8-47bc-b764-373e70a40b6c))
    (fp_line (start 0 1.8) (end 0 5.8) (layer "F.Fab") (width 0.12) (tstamp cc355221-61ff-48ea-9dff-3f2786e498af))
    (fp_line (start -2 -2.5) (end -3 -1.4) (layer "F.Fab") (width 0.12) (tstamp d424c0d4-693c-4670-b285-ef1e58c4bbeb))
    (fp_line (start 26 -2.5) (end -2 -2.5) (layer "F.Fab") (width 0.12) (tstamp dad5ed8c-4261-46e9-a969-14130c0ff513))
    (pad "11" thru_hole circle (at 20 0) (size 3 3) (drill 1.5) (layers *.Cu *.Mask)
      (net 85 "Net-(C20-Pad1)") (pintype "passive") (tstamp fa97c30e-4778-44d4-ad0c-faa3e2783e74))
    (pad "12" thru_hole circle (at 15 7.5) (size 3 3) (drill 1.5) (layers *.Cu *.Mask)
      (net 38 "unconnected-(K1-Pad12)") (pintype "passive") (tstamp 4617d751-14e6-40b0-95a8-645b3f0bec47))
    (pad "14" thru_hole circle (at 25 7.5) (size 3 3) (drill 1.5) (layers *.Cu *.Mask)
      (net 104 "Net-(D15-Pad2)") (pintype "passive") (tstamp 16a29141-d1aa-447c-b07c-86cb6e9c41d6))
    (pad "A1" thru_hole rect (at 0 0) (size 3 3) (drill 1.5) (layers *.Cu *.Mask)
      (net 17 "Net-(D3-Pad2)") (pintype "passive") (tstamp 670e38d0-008c-42a4-9550-60803a4e3c37))
    (pad "A2" thru_hole circle (at 0 7.5) (size 3 3) (drill 1.5) (layers *.Cu *.Mask)
      (net 18 "Net-(D4-Pad2)") (pintype "passive") (tstamp 7d68c5f1-1b53-41a4-8865-30e7321b17a0))
    (model "${KICAD6_3DMODEL_DIR}/Relay_THT.3dshapes/Relay_SPDT_Finder_40.51.wrl"
      (scale (xyz 1 1 1))
  (footprint "Package_SO:SOIC-8_3.9x4.9mm_P1.27mm" (layer "F.Cu")
    (tedit 5D9F72B1) (tstamp a4c7e02a-888f-45f1-83ea-ef799a9bbd8e)
    (at 32.131 50.546)
    (descr "SOIC, 8 Pin (JEDEC MS-012AA, https://www.analog.com/media/en/package-pcb-resources/package/pkg_pdf/soic_narrow-r/r_8.pdf), generated with kicad-footprint-generator ipc_gullwing_generator.py")
    (tags "SOIC SO")
    (path "/0cab9de3-bfe6-42f6-9186-e43bf2742f51")
    (attr smd)
    (fp_text reference "U6" (at 4.826 2.159 180) (layer "F.SilkS")
      (tstamp 1fceda7f-657a-435b-8ae3-72041e9d1398)
    (fp_text value "DS1307Z RTC" (at 0 3.4) (layer "F.Fab")
      (tstamp e809b9cf-be22-4230-9bcf-8abb5586f93d)
    (fp_text user "${REFERENCE}" (at 0 0) (layer "F.Fab")
      (effects (font (size 0.98 0.98) (thickness 0.15)))
      (tstamp b4025610-d21b-40f7-ad1d-a6cf2780f6f4)
    (fp_line (start 0 2.56) (end 1.95 2.56) (layer "F.SilkS") (width 0.12) (tstamp 12cbd24f-e18c-46b5-b5de-413888b0e976))
    (fp_line (start 0 -2.56) (end -3.45 -2.56) (layer "F.SilkS") (width 0.12) (tstamp 42257fdd-3cf6-47d0-a3f1-1819f0afe9cb))
    (fp_line (start 0 2.56) (end -1.95 2.56) (layer "F.SilkS") (width 0.12) (tstamp ac58247e-41bb-4692-b7cb-a89d474c6fc6))
    (fp_line (start 0 -2.56) (end 1.95 -2.56) (layer "F.SilkS") (width 0.12) (tstamp eebd0886-a4d4-4297-8abf-0e2bbb324bf8))
    (fp_line (start -3.7 2.7) (end 3.7 2.7) (layer "F.CrtYd") (width 0.05) (tstamp 03a09f88-9e2c-4aec-b4e6-b6c6c26e342a))
    (fp_line (start 3.7 2.7) (end 3.7 -2.7) (layer "F.CrtYd") (width 0.05) (tstamp 1851f751-38ed-4cf1-8ffd-8aaa9936f42f))
    (fp_line (start -3.7 -2.7) (end -3.7 2.7) (layer "F.CrtYd") (width 0.05) (tstamp 20d11416-0a5b-4496-b70b-4e9fc85818e1))
    (fp_line (start 3.7 -2.7) (end -3.7 -2.7) (layer "F.CrtYd") (width 0.05) (tstamp 906b650f-05c0-49e7-ad0d-aa8219862c6b))
    (fp_line (start -0.975 -2.45) (end 1.95 -2.45) (layer "F.Fab") (width 0.1) (tstamp 0ea4208a-c410-4f11-8f51-4b73cd584ae8))
    (fp_line (start 1.95 2.45) (end -1.95 2.45) (layer "F.Fab") (width 0.1) (tstamp 7deb0bf4-1eef-409e-ab62-040de83d2dfb))
    (fp_line (start -1.95 -1.475) (end -0.975 -2.45) (layer "F.Fab") (width 0.1) (tstamp b5459f72-0c38-4a68-ae73-ee3773e96c8f))
    (fp_line (start 1.95 -2.45) (end 1.95 2.45) (layer "F.Fab") (width 0.1) (tstamp d5a113d2-87f2-47a3-bcdf-432523956f51))
    (fp_line (start -1.95 2.45) (end -1.95 -1.475) (layer "F.Fab") (width 0.1) (tstamp e3555b21-f548-4e74-a24b-40f9f5facefe))
    (pad "1" smd roundrect (at -2.475 -1.905) (size 1.95 0.6) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.25)
      (net 82 "Net-(U6-Pad1)") (pinfunction "X1") (pintype "input") (tstamp c7bf064e-f38e-4579-b62f-f211b0175b0f))
    (pad "2" smd roundrect (at -2.475 -0.635) (size 1.95 0.6) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.25)
      (net 83 "Net-(U6-Pad2)") (pinfunction "X2") (pintype "input") (tstamp 0a7adafe-af67-4872-a26a-36759c616681))
    (pad "3" smd roundrect (at -2.475 0.635) (size 1.95 0.6) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.25)
      (net 11 "Net-(BT1-Pad1)") (pinfunction "VBAT") (pintype "power_in") (tstamp bf18fd74-602b-4b6a-a63b-00fe701d5556))
    (pad "4" smd roundrect (at -2.475 1.905) (size 1.95 0.6) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.25)
      (net 1 "Net-(BT1-Pad2)") (pinfunction "GND") (pintype "power_in") (tstamp 49fb3906-0455-424a-b19e-2b59fa3b8ad7))
    (pad "5" smd roundrect (at 2.475 1.905) (size 1.95 0.6) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.25)
      (net 51 "Net-(R21-Pad1)") (pinfunction "SDA") (pintype "bidirectional") (tstamp 15033fc0-4a6f-4ba4-aa67-063b6cb1f562))
    (pad "6" smd roundrect (at 2.475 0.635) (size 1.95 0.6) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.25)
      (net 52 "Net-(R22-Pad1)") (pinfunction "SCL") (pintype "input") (tstamp c65eb1d6-2de7-4ac3-87ef-193612da3fea))
    (pad "7" smd roundrect (at 2.475 -0.635) (size 1.95 0.6) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.25)
      (net 84 "unconnected-(U6-Pad7)") (pinfunction "SQW/OUT") (pintype "open_collector") (tstamp 519288fe-d9cd-481d-a1e6-f2afa5cd21c3))
    (pad "8" smd roundrect (at 2.475 -1.905) (size 1.95 0.6) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.25)
      (net 85 "Net-(C20-Pad1)") (pinfunction "VCC") (pintype "power_in") (tstamp 66948e93-ea75-4aa7-9c86-11a5c971e28d))
    (model "${KICAD6_3DMODEL_DIR}/Package_SO.3dshapes/SOIC-8_3.9x4.9mm_P1.27mm.wrl"
      (scale (xyz 1 1 1))
  (footprint "Inductor_THT:L_Radial_D9.5mm_P5.00mm_Fastron_07HVP" (layer "F.Cu")
    (tedit 5AE59B06) (tstamp a4da1ec2-ce73-477f-be48-5610374acac2)
    (at 41.021 31.536 -90)
    (descr "Inductor, Radial series, Radial, pin pitch=5.00mm, , diameter=9.5mm, Fastron, 07HVP, http://www.fastrongroup.com/image-show/107/07HVP%2007HVP_T.pdf?type=Complete-DataSheet&productType=series")
    (tags "Inductor Radial series Radial pin pitch 5.00mm  diameter 9.5mm Fastron 07HVP")
    (path "/b3d4c6e1-51d5-4860-b104-f8b91814176d")
    (attr through_hole)
    (fp_text reference "L1" (at 2.5 -6 90) (layer "F.SilkS")
      (tstamp dde496c9-5d7f-475f-8250-6c31b06bf429)
    (fp_text value "L-07HVP 820µ 0A53" (at 2.754 5.842 90) (layer "F.Fab")
      (tstamp bba4473e-ef9c-468b-8cb6-83e41d824799)
    (fp_text user "${REFERENCE}" (at 2.5 0 90) (layer "F.Fab")
      (tstamp e8ad0a54-1a92-4e91-bb74-ee9912728fd6)
    (fp_circle (center 2.5 0) (end 7.37 0) (layer "F.SilkS") (width 0.12) (fill none) (tstamp 9afa7b7d-860d-49e4-bfd4-dfb2af859d5a))
    (fp_circle (center 2.5 0) (end 7.5 0) (layer "F.CrtYd") (width 0.05) (fill none) (tstamp 2620265e-065a-4a5e-9926-fb12575ad329))
    (fp_circle (center 2.5 0) (end 7.25 0) (layer "F.Fab") (width 0.1) (fill none) (tstamp 3f601819-c19e-4d29-9e54-272ca4458692))
    (pad "1" thru_hole circle (at 0 0 270) (size 2.6 2.6) (drill 1.3) (layers *.Cu *.Mask)
      (net 9 "Net-(C12-Pad1)") (pintype "passive") (tstamp 04380b42-9dde-496b-8682-de4a05a5d5c0))
    (pad "2" thru_hole circle (at 5 0 270) (size 2.6 2.6) (drill 1.3) (layers *.Cu *.Mask)
      (net 22 "Net-(D8-Pad1)") (pintype "passive") (tstamp a5b7b404-2406-4bfa-84b6-7a8c65ac70cd))
    (model "${KICAD6_3DMODEL_DIR}/Inductor_THT.3dshapes/L_Radial_D9.5mm_P5.00mm_Fastron_07HVP.wrl"
      (scale (xyz 1 1 1))
  (footprint "Resistor_SMD:R_1210_3225Metric_Pad1.30x2.65mm_HandSolder" (layer "F.Cu")
    (tedit 5F68FEEE) (tstamp ad0f01ef-1681-4205-b430-3f3d68ddc873)
    (at 33.909 79.375 90)
    (descr "Resistor SMD 1210 (3225 Metric), square (rectangular) end terminal, IPC_7351 nominal with elongated pad for handsoldering. (Body size source: IPC-SM-782 page 72, https://www.pcb-3d.com/wordpress/wp-content/uploads/ipc-sm-782a_amendment_1_and_2.pdf), generated with kicad-footprint-generator")
    (tags "resistor handsolder")
    (path "/effaf3cf-7199-46dc-918e-70f9838a47a1")
    (attr smd)
    (fp_text reference "R47" (at 0.381 -2.413 90) (layer "F.SilkS")
      (tstamp 512a38d0-fc3d-43b6-b7aa-baf0b89881ae)
      (tstamp 400b95ce-877a-49b2-be1b-c9bcd692bd8a)
      (tstamp 2b78c8e9-1aeb-42b9-a9d8-d519ce7f4070)
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp 070e4c1d-720c-4211-a2ae-edc01dbc6a9b))
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 86163c81-e7aa-44f3-a8f3-ac168fd4dbac))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 13f3bbc1-e3e2-464b-8e7c-828e2078e7ee))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 35d8f502-8c6b-4274-b56a-b7ff75e0ff77))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 3600a621-8e95-4bed-9586-3a046f45841c))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp d3d75e53-3985-42d5-bb40-95995c883d4c))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 09189ee2-033e-4b94-98d3-8fc0cf2272b5))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 188c1e13-7c75-4835-83be-a8c99925d2c0))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 69bd5c2e-4ad8-4671-ab7c-d7db25e60946))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 9df94bdc-cc8a-4a04-9bce-91d4cd7d6e66))
      (net 76 "Net-(R47-Pad1)") (pintype "passive") (tstamp 7fb8fd53-2f41-48da-b879-fccd19683265))
      (net 119 "Net-(J14-Pad18)") (pintype "passive") (tstamp d344fa79-603a-446e-9a90-0ba9d5e4ca39))
    (model "${KICAD6_3DMODEL_DIR}/Resistor_SMD.3dshapes/R_1210_3225Metric.wrl"
      (scale (xyz 1 1 1))
    (tedit 5F68FEEF) (tstamp ad392ea0-0aeb-42ea-85c6-5e26f61da467)
    (at 81.4985 72.136 90)
    (path "/4f772b34-f260-4d9f-b2c7-f0c3a930c7bf")
    (attr smd)
    (fp_text reference "C8" (at 0 -1.85 90) (layer "F.SilkS")
      (tstamp cea08406-cd27-4409-ae40-982896af72d3)
    (fp_text value "22u 25V X5R-G1210 22" (at 0 1.85 90) (layer "F.Fab")
      (tstamp 34434260-9991-4fd8-9a23-34be903003dc)
      (tstamp 94d48fa1-6ef8-4ba5-b068-27839aefae0f)
    (fp_line (start -0.711252 -0.91) (end 0.711252 -0.91) (layer "F.SilkS") (width 0.12) (tstamp 9507f83a-805e-424a-9cfa-173837d3ca97))
    (fp_line (start -0.711252 0.91) (end 0.711252 0.91) (layer "F.SilkS") (width 0.12) (tstamp d81204fd-6d4e-41a4-a034-c6035e26ec66))
    (fp_line (start -2.48 -1.15) (end 2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp 1738ec1b-01e7-4c88-bd0c-0b48cedf5280))
    (fp_line (start 2.48 1.15) (end -2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp 565ef845-718c-4e6a-a944-cecb747c5c40))
    (fp_line (start 2.48 -1.15) (end 2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp 5876750a-cb0d-4993-aeff-11e3b0d3de04))
    (fp_line (start -2.48 1.15) (end -2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp c9cdb39f-2d48-4575-9d3b-90383614e101))
    (fp_line (start 1.6 -0.8) (end 1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp 13c8438a-655c-4b27-af8b-1771dd99239f))
    (fp_line (start -1.6 0.8) (end -1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp 77c3e296-20aa-4360-8e7a-0581b26f1053))
    (fp_line (start -1.6 -0.8) (end 1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp a55eaf75-3f2d-410e-8330-3907374fcd2f))
    (fp_line (start 1.6 0.8) (end -1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp e489c9b1-557f-4568-8824-3d87a933d8cb))
    (pad "1" smd roundrect (at -1.5625 0 90) (size 1.325 1.8) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1886792453)
      (net 6 "Net-(C8-Pad1)") (pintype "passive") (tstamp 60b20db5-48cc-40fd-88f1-387a7809ada7))
    (pad "2" smd roundrect (at 1.5625 0 90) (size 1.325 1.8) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1886792453)
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp 5cbbe0f9-a4f5-4e3a-861b-40b92b58666a))
      (scale (xyz 1 1 1))
  (footprint "Potentiometer_THT:Potentiometer_ACP_CA9-H5_Horizontal" (layer "F.Cu")
    (tedit 5A3D4994) (tstamp afa77a58-460f-42e7-bc51-9d1cb9300d9b)
    (at 63.54 139.257)
    (descr "Potentiometer, horizontal, ACP CA9-H5, http://www.acptechnologies.com/wp-content/uploads/2017/05/02-ACP-CA9-CE9.pdf")
    (tags "Potentiometer horizontal ACP CA9-H5")
    (path "/af5ddf99-97ea-4c91-a744-7440b89f2121")
    (attr through_hole)
    (fp_text reference "RV1" (at -0.294 -4.256 90) (layer "F.SilkS")
      (tstamp 5a44f9b6-30c1-4e19-824e-3dd11e7d7490)
    (fp_text value "76-40 10K" (at 0 8.65) (layer "F.Fab")
      (tstamp ac083b67-4e2d-4223-9f57-e003c2bbd17a)
    (fp_text user "${REFERENCE}" (at 5.548 1.713) (layer "F.Fab")
      (tstamp 7b882367-81a2-44b8-aff6-f21b3e12c4cb)
    (fp_line (start -0.121 -2.521) (end 4.92 -2.521) (layer "F.SilkS") (width 0.12) (tstamp 267f6da7-b580-44f9-be44-de3a2929dbbe))
    (fp_line (start 4.92 3.925) (end 4.92 4.12) (layer "F.SilkS") (width 0.12) (tstamp 2d57d365-dd53-4d03-b6da-ff0f901ebbd1))
    (fp_line (start -0.121 7.52) (end 4.92 7.52) (layer "F.SilkS") (width 0.12) (tstamp 54e57d0a-8793-4287-accf-4a3cdd42826f))
    (fp_line (start -0.121 1.426) (end -0.121 3.575) (layer "F.SilkS") (width 0.12) (tstamp 54fe07e6-6260-4142-97f2-bd7be8a9f61d))
    (fp_line (start 4.92 0.88) (end 4.92 1.075) (layer "F.SilkS") (width 0.12) (tstamp 79b7d66b-7cc5-43c5-976b-517d36453ae1))
    (fp_line (start 4.92 3.925) (end 4.92 7.52) (layer "F.SilkS") (width 0.12) (tstamp 88464391-4ef0-431f-9345-f64903760663))
    (fp_line (start 4.92 -2.521) (end 4.92 1.075) (layer "F.SilkS") (width 0.12) (tstamp a7fddcf2-7083-492d-a9a6-4c1b3e3fd81f))
    (fp_line (start -0.121 6.425) (end -0.121 7.52) (layer "F.SilkS") (width 0.12) (tstamp c17cd2f0-8354-448f-9479-1ca034f1aff7))
    (fp_line (start 1.237 4.12) (end 4.92 4.12) (layer "F.SilkS") (width 0.12) (tstamp c469fcd3-1e8c-4b31-9012-e73ae7d4f543))
    (fp_line (start -0.121 -2.521) (end -0.121 -1.426) (layer "F.SilkS") (width 0.12) (tstamp e9abc1c0-9adb-4c93-becb-a99269d2cac1))
    (fp_line (start -0.121 1.426) (end -0.121 3.575) (layer "F.SilkS") (width 0.12) (tstamp f5144380-450f-445e-ba01-3e8662f1d457))
    (fp_line (start 1.237 0.88) (end 4.92 0.88) (layer "F.SilkS") (width 0.12) (tstamp f8dfb149-2e92-41cb-8c82-5ab13b2062e6))
    (fp_line (start -1.45 -2.7) (end -1.45 7.65) (layer "F.CrtYd") (width 0.05) (tstamp 62de4b92-e121-459e-b132-555e8a73ab3a))
    (fp_line (start 6.45 7.65) (end 6.45 -2.7) (layer "F.CrtYd") (width 0.05) (tstamp 6f6162aa-e0db-425e-8d3f-282958611b5a))
    (fp_line (start 6.45 -2.7) (end -1.45 -2.7) (layer "F.CrtYd") (width 0.05) (tstamp b447103e-7f59-47fd-94e9-b13ff308dce2))
    (fp_line (start -1.45 7.65) (end 6.45 7.65) (layer "F.CrtYd") (width 0.05) (tstamp e7f6d05f-72ed-4d28-8bc2-c9f234189673))
    (fp_line (start 0 -2.4) (end 4.8 -2.4) (layer "F.Fab") (width 0.1) (tstamp 007bad23-8ed9-41e4-8871-fd1822a25299))
    (fp_line (start 0 1) (end 0 4) (layer "F.Fab") (width 0.1) (tstamp 27059325-60cc-4003-a216-bf1c14b086f5))
    (fp_line (start 4.8 7.4) (end 0 7.4) (layer "F.Fab") (width 0.1) (tstamp 317f6c7e-d1d1-4158-8eee-9646b05a02c0))
    (fp_line (start 4.8 -2.4) (end 4.8 7.4) (layer "F.Fab") (width 0.1) (tstamp 3fc2cf92-b4d2-4d38-ac22-201c1f67d119))
    (fp_line (start 0 4) (end 4.8 4) (layer "F.Fab") (width 0.1) (tstamp 96e9e8b0-683d-475b-86fe-7df9b6370141))
    (fp_line (start 0 7.4) (end 0 -2.4) (layer "F.Fab") (width 0.1) (tstamp a635f56f-8cc9-4f41-8f07-b59a7f63674c))
    (fp_line (start 4.8 1) (end 0 1) (layer "F.Fab") (width 0.1) (tstamp a96fbcbb-02f6-4484-9c64-365bf64ec6cc))
    (fp_line (start 4.8 4) (end 4.8 1) (layer "F.Fab") (width 0.1) (tstamp ad6bbee3-aa9c-4f30-b86c-acbf966e4e6d))
    (pad "1" thru_hole circle (at 0 0) (size 2.34 2.34) (drill 1.3) (layers *.Cu *.Mask)
      (net 1 "Net-(BT1-Pad2)") (pinfunction "1") (pintype "passive") (tstamp 0496d51b-491d-41f9-817e-78cb4e1078be))
    (pad "2" thru_hole circle (at 5 2.5) (size 2.34 2.34) (drill 1.3) (layers *.Cu *.Mask)
      (net 114 "Net-(RV1-Pad2)") (pinfunction "2") (pintype "passive") (tstamp bd4de2ef-e33f-4792-87be-d0398ad3bb6b))
    (pad "3" thru_hole circle (at 0 5) (size 2.34 2.34) (drill 1.3) (layers *.Cu *.Mask)
      (net 85 "Net-(C20-Pad1)") (pinfunction "3") (pintype "passive") (tstamp 193b8073-483c-48a9-b865-612a8d250b99))
    (model "${KICAD6_3DMODEL_DIR}/Potentiometer_THT.3dshapes/Potentiometer_ACP_CA9-H5_Horizontal.wrl"
      (offset (xyz 0 0 0))
      (scale (xyz 1 1 1))
      (rotate (xyz 0 0 0))
    (tedit 5F68FEEE) (tstamp b1212014-06cc-49f9-8b25-c5c64232d2ab)
    (at 33.02 101.981 -90)
    (property "Sheetfile" "Lauflicht_Steuerplatine.kicad_sch")
    (property "Sheetname" "")
    (path "/cac49034-3f7c-4bc2-8617-5daa97babcf3")
    (attr smd)
    (fp_text reference "R31" (at -3.175 -0.127 180) (layer "F.SilkS")
      (effects (font (size 1 1) (thickness 0.15)))
      (tstamp 5023f5f4-06a0-45f2-b17f-6f4276632a7a)
    (fp_text value "SMD 1/4W 1k" (at 0 2.28 90) (layer "F.Fab")
      (tstamp 44e33f89-fb2a-449c-8115-d17dd39efae8)
      (tstamp e6815062-3dc4-493b-b81e-ffa68334311a)
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 8cf07330-dc41-4a9d-9059-f0e5b871a1cc))
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp b6484c61-b2bb-4cc1-89e9-ec85ed684d79))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 710383d5-e567-45cd-88c8-19c3173a76ae))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 88b5a23b-4141-448e-b5b8-29448e21b309))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 9abf4ee2-0591-41bb-8389-e2bc2ce2490d))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp dbedf940-1d70-4acc-95b2-fafe19004ac0))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 16eeab02-92a6-43d1-b6c1-64ed3a2fe4b4))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 9960065c-a7fb-4fab-b645-e3fd02880c0a))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp aa3d5c5e-a590-4e92-ac6b-47283f652bb2))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp f33e7c2d-95f1-4d9c-b4c5-96b6280cf469))
    (pad "1" smd roundrect (at -1.55 0 270) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 62 "Net-(R31-Pad1)") (pintype "passive") (tstamp dbba970b-855f-4b4b-ba22-f3533e58373e))
    (pad "2" smd roundrect (at 1.55 0 270) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 109 "Net-(R31-Pad2)") (pintype "passive") (tstamp 453cf6fc-9a8d-429b-8c1e-4fb5c032cf99))
      (scale (xyz 1 1 1))
  (footprint "Relay_THT:Relay_SPDT_Finder_40.61" (layer "F.Cu")
    (tedit 5A5B3E92) (tstamp b17ba9ca-2d7a-4965-99fc-1c3d75c94fd0)
    (at 96.6235 43.0285)
    (descr "Relay DPDT Finder 40.52, Pitch 5mm/7.5mm, https://www.finder-relais.net/de/finder-relais-serie-40.pdf")
    (tags "Relay DPDT Finder 40.52 Pitch 5mm")
    (path "/a6a40470-9757-4ab3-a973-88a09b392ba0")
    (attr through_hole)
    (fp_text reference "K2" (at 21.7405 -3.5315) (layer "F.SilkS")
      (tstamp ff83418b-66ef-402d-90e4-c7f22190b1fe)
      (tstamp c49f77d4-e85f-47f4-b2c0-c6be65e95810)
      (tstamp 219ed59b-13bb-45cd-9fc2-3942d6b8367c)
    (fp_line (start 2.54 0) (end 3.81 0) (layer "F.SilkS") (width 0.12) (tstamp 289d433b-7d9c-458d-9ef4-42126d2174d6))
    (fp_line (start 5.08 6.35) (end 2.54 6.35) (layer "F.SilkS") (width 0.12) (tstamp 46dcd343-9f04-42e9-9912-bb80d2aafe4a))
    (fp_line (start 26.1 1.4) (end 26.1 6.1) (layer "F.SilkS") (width 0.12) (tstamp 48d61bed-8cbd-4cd2-be04-a775e9f6e83b))
    (fp_line (start 26.1 10.1) (end -3.1 10.1) (layer "F.SilkS") (width 0.12) (tstamp 5004fd01-eb3f-417f-afa2-908278fd82d6))
    (fp_line (start -3.1 -2.6) (end 26.1 -2.6) (layer "F.SilkS") (width 0.12) (tstamp 57252668-5afa-4e18-a19e-04cc35de55a9))
    (fp_line (start 3.81 1.27) (end 5.08 1.27) (layer "F.SilkS") (width 0.12) (tstamp 75a57349-2b46-483e-8cfb-c6aa5828fa64))
    (fp_line (start 2.54 2.54) (end 5.08 3.81) (layer "F.SilkS") (width 0.12) (tstamp 795b5851-651a-4873-af4d-4501f4b62c93))
    (fp_line (start 2.54 1.27) (end 3.81 1.27) (layer "F.SilkS") (width 0.12) (tstamp 7fee7b56-adc4-4032-aeae-840d2a55c954))
    (fp_line (start 2.54 6.35) (end 2.54 1.27) (layer "F.SilkS") (width 0.12) (tstamp a6c2f235-d5cf-4794-a44c-7318bdf04f3c))
    (fp_line (start 26.1 8.9) (end 26.1 10.1) (layer "F.SilkS") (width 0.12) (tstamp a7732f53-9a11-4617-a95f-53c9a324efc4))
    (fp_line (start 3.81 6.35) (end 3.81 7.62) (layer "F.SilkS") (width 0.12) (tstamp a81b4022-972a-4eb9-a62b-39e3f6f46cc9))
    (fp_line (start -3.1 10.1) (end -3.1 -2.6) (layer "F.SilkS") (width 0.12) (tstamp b00ee0e0-896a-4bbd-86f6-c1ae171b30ea))
    (fp_line (start -3.3 -0.4) (end -3.3 -2.8) (layer "F.SilkS") (width 0.12) (tstamp b83c9a1f-f35f-473d-b2b8-f383c2155031))
    (fp_line (start 26.1 -2.6) (end 26.1 -1.4) (layer "F.SilkS") (width 0.12) (tstamp cd1f01ae-421f-4fa0-928c-d9bee12cfc7c))
    (fp_line (start 5.08 1.27) (end 5.08 6.35) (layer "F.SilkS") (width 0.12) (tstamp ceac7132-3e58-43e7-86ce-c68ba3b2e051))
    (fp_line (start 3.81 0) (end 3.81 1.27) (layer "F.SilkS") (width 0.12) (tstamp d565e590-d0b7-4096-bbc4-635761ce91e1))
    (fp_line (start -0.9 -2.8) (end -3.3 -2.8) (layer "F.SilkS") (width 0.12) (tstamp eb85a3ab-c87d-40e3-abef-35ec5338cdde))
    (fp_line (start 3.81 7.62) (end 2.54 7.62) (layer "F.SilkS") (width 0.12) (tstamp efabfc91-b8f9-488c-884a-765f4cf833d2))
    (fp_line (start 26.75 10.25) (end -3.25 10.25) (layer "F.CrtYd") (width 0.05) (tstamp 1ae1f4d5-5d41-4582-afa6-a9aaa0b5ad16))
    (fp_line (start -3.25 -2.75) (end -3.25 10.25) (layer "F.CrtYd") (width 0.05) (tstamp 80b1e910-8bf6-4182-845c-5cbea272f230))
    (fp_line (start -3.25 -2.75) (end 26.75 -2.75) (layer "F.CrtYd") (width 0.05) (tstamp bb62d8b5-aa13-44ba-b52d-b8632f303094))
    (fp_line (start 26.75 10.25) (end 26.75 -2.75) (layer "F.CrtYd") (width 0.05) (tstamp bda5a40d-f6f2-4d99-9758-109e5a779905))
    (fp_line (start -3 10) (end 26 10) (layer "F.Fab") (width 0.12) (tstamp 349d88c8-5e96-434f-8337-8c5638accf89))
    (fp_line (start 26 -2.5) (end -2 -2.5) (layer "F.Fab") (width 0.12) (tstamp 86692f27-6144-4677-b60a-5e60a7d77427))
    (fp_line (start 26 10) (end 26 -2.5) (layer "F.Fab") (width 0.12) (tstamp 891f9ab1-e696-4c4c-9048-1cf6ecc27337))
    (fp_line (start 0 1.8) (end 0 5.8) (layer "F.Fab") (width 0.12) (tstamp 8e5f6c40-5831-410c-b7bb-5e832253c204))
    (fp_line (start -2 -2.5) (end -3 -1.4) (layer "F.Fab") (width 0.12) (tstamp af8cda9c-7b0a-4a32-a1c8-b1c70ae9af00))
    (fp_line (start -3 -1.4) (end -3 10) (layer "F.Fab") (width 0.12) (tstamp e337ee4a-3ef5-4f99-bfd4-f1859733d060))
    (pad "11" thru_hole circle (at 20 7.5) (size 3 3) (drill 1.5) (layers *.Cu *.Mask)
      (net 15 "Net-(C3-Pad1)") (pintype "passive") (tstamp b169108b-55d2-4bcc-9b22-cfca52f29f79))
      (net 15 "Net-(C3-Pad1)") (pintype "passive") (tstamp f21e3fcd-29db-4ccb-b1ca-622f3584a828))
      (net 39 "unconnected-(K2-Pad12)") (pintype "passive") (tstamp 1573a38c-f4a1-4897-841c-c0fdab96fc5c))
    (pad "12" thru_hole circle (at 15 0) (size 3 3) (drill 1.5) (layers *.Cu *.Mask)
      (net 39 "unconnected-(K2-Pad12)") (pintype "passive") (tstamp 5c73dbf2-f4ff-4b0d-a761-a1bf2b3cfdb5))
    (pad "14" thru_hole circle (at 25 0) (size 3 3) (drill 1.5) (layers *.Cu *.Mask)
      (net 10 "Net-(C14-Pad1)") (pintype "passive") (tstamp 7258e66d-f58e-4009-af12-14fa6a6c47e0))
      (net 10 "Net-(C14-Pad1)") (pintype "passive") (tstamp b0be303f-906b-4835-bd33-a180e838353c))
      (net 17 "Net-(D3-Pad2)") (pintype "passive") (tstamp 8bee6ce0-af5e-4c4e-b7c8-aed157ba8e41))
      (net 21 "Net-(D7-Pad2)") (pintype "passive") (tstamp 13ecd8fd-4e3e-4b34-bf4b-236bb0e978d4))
    (model "${KICAD6_3DMODEL_DIR}/Relay_THT.3dshapes/Relay_DPDT_Finder_40.52.wrl"
      (scale (xyz 1 1 1))
  (footprint "Capacitor_SMD:C_1206_3216Metric_Pad1.33x1.80mm_HandSolder" (layer "F.Cu")
    (tedit 5F68FEEF) (tstamp b1a336c1-e7a2-49c1-b17c-3cb93540dd49)
    (at 63.246 41.021 -90)
    (descr "Capacitor SMD 1206 (3216 Metric), square (rectangular) end terminal, IPC_7351 nominal with elongated pad for handsoldering. (Body size source: IPC-SM-782 page 76, https://www.pcb-3d.com/wordpress/wp-content/uploads/ipc-sm-782a_amendment_1_and_2.pdf), generated with kicad-footprint-generator")
    (tags "capacitor handsolder")
    (path "/b32d0dca-6711-45b6-8e98-b11395e2a263")
    (attr smd)
    (fp_text reference "C9" (at -3.683 -0.127 -90) (layer "F.SilkS")
      (tstamp ceceda3b-ba27-4f9c-a377-accfb334e1cb)
    (fp_text value "100n 50V KEM X7R1206 1,0U" (at 0 1.85 90) (layer "F.Fab")
      (tstamp 1407ff01-be06-4aed-9b48-9ae3efa21fc0)
      (tstamp 006e293c-4b63-4f7a-bebe-3b71e0183715)
    (fp_line (start -0.711252 -0.91) (end 0.711252 -0.91) (layer "F.SilkS") (width 0.12) (tstamp 1211db8f-16ee-4dfa-86bc-7a2ac0e9007b))
    (fp_line (start -0.711252 0.91) (end 0.711252 0.91) (layer "F.SilkS") (width 0.12) (tstamp 74411867-ac94-40e0-87e1-52b17962350c))
    (fp_line (start 2.48 1.15) (end -2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp 0401ce2b-b1e1-47f8-8c05-935a658d6519))
    (fp_line (start -2.48 1.15) (end -2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp 9629efa1-c1a1-4701-87b8-294f3c98c95a))
    (fp_line (start 2.48 -1.15) (end 2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp a6b01380-c876-4f6f-aabe-7681ba6282a1))
    (fp_line (start -2.48 -1.15) (end 2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp dbc71ed4-a7f9-4800-966d-96cb7533abe8))
    (fp_line (start -1.6 -0.8) (end 1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp 759d0776-26dd-4696-9764-49c3f60b0c4f))
    (fp_line (start -1.6 0.8) (end -1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp 989177f2-3921-4b10-9f06-9cc482700cde))
    (fp_line (start 1.6 0.8) (end -1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp c4cc4710-f057-423d-ad09-b2792871ecdb))
    (fp_line (start 1.6 -0.8) (end 1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp da544e57-6734-4bc5-afe3-334ede249563))
    (pad "1" smd roundrect (at -1.5625 0 270) (size 1.325 1.8) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1886792453)
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp 5429aa3a-910a-4cb2-be83-c58edce4fba3))
    (pad "2" smd roundrect (at 1.5625 0 270) (size 1.325 1.8) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1886792453)
      (net 7 "Net-(C9-Pad2)") (pintype "passive") (tstamp 638477d3-8133-46d9-ac10-9427bc7cdc2b))
    (model "${KICAD6_3DMODEL_DIR}/Capacitor_SMD.3dshapes/C_1206_3216Metric.wrl"
      (scale (xyz 1 1 1))
    (tedit 5A1DD157) (tstamp b42c867d-1f1e-4fab-9ce9-268a797f6086)
    (at 89.281 32.766 90)
    (path "/88def996-8c7a-4f2d-9533-2aac98ee50d6")
    (attr through_hole)
    (fp_text reference "Q5" (at 1.27 -3.81 270) (layer "F.SilkS")
      (tstamp db7667dd-6738-431b-9862-c7ac07ad777b)
    (fp_text value "BC337" (at 1.27 2.79 90) (layer "F.Fab")
      (tstamp ee85699a-409c-4c45-bc11-0a9a94f62ea6)
      (tstamp f8424551-d82d-46d1-81c4-4bfc8cb97881)
    (fp_line (start -0.53 1.85) (end 3.07 1.85) (layer "F.SilkS") (width 0.12) (tstamp 949c46f2-109c-4c71-9451-be60478fa9a5))
    (fp_arc (start 1.27 -2.6) (mid 3.672087 -0.994977) (end 3.108478 1.838478) (layer "F.SilkS") (width 0.12) (tstamp ade82ff1-65ef-48fb-a46d-5da15329d0cb))
    (fp_arc (start -0.568478 1.838478) (mid -1.132087 -0.994977) (end 1.27 -2.6) (layer "F.SilkS") (width 0.12) (tstamp d7cf4e73-a863-4e78-b9ba-bc5672894eb9))
    (fp_line (start 4 2.01) (end -1.46 2.01) (layer "F.CrtYd") (width 0.05) (tstamp 17b8f5a3-4d7b-43c8-a78d-0988cfae94b5))
    (fp_line (start -1.46 -2.73) (end 4 -2.73) (layer "F.CrtYd") (width 0.05) (tstamp 1c539995-0827-4015-9878-7973b18a9635))
    (fp_line (start -1.46 -2.73) (end -1.46 2.01) (layer "F.CrtYd") (width 0.05) (tstamp 23ad2e88-e28c-4c2e-9970-4f0857b3acb1))
    (fp_line (start 4 2.01) (end 4 -2.73) (layer "F.CrtYd") (width 0.05) (tstamp 624a6ffb-406e-4cb0-90ac-ace68a15018d))
    (fp_line (start -0.5 1.75) (end 3 1.75) (layer "F.Fab") (width 0.1) (tstamp 5f57f8e0-0dbe-4d45-a9dc-9d29a33a3b87))
    (fp_arc (start 1.27 -2.48) (mid 3.561221 -0.949055) (end 3.023625 1.753625) (layer "F.Fab") (width 0.1) (tstamp 2a9768fd-742d-4f91-9ade-5e0a6914cab2))
    (fp_arc (start -0.483625 1.753625) (mid -1.021221 -0.949055) (end 1.27 -2.48) (layer "F.Fab") (width 0.1) (tstamp e7cea2e6-7106-4f0d-9a7e-cf1d560359af))
    (pad "1" thru_hole rect (at 0 0 90) (size 1.05 1.5) (drill 0.75) (layers *.Cu *.Mask)
      (net 88 "Net-(D11-Pad2)") (pinfunction "C") (pintype "passive") (tstamp 429bd435-9f6b-455f-aea4-2af175875709))
    (pad "2" thru_hole oval (at 1.27 0 90) (size 1.05 1.5) (drill 0.75) (layers *.Cu *.Mask)
      (net 100 "Net-(Q5-Pad2)") (pinfunction "B") (pintype "input") (tstamp e2bcebc6-903a-45d0-a10f-7ab8076b827d))
    (pad "3" thru_hole oval (at 2.54 0 90) (size 1.05 1.5) (drill 0.75) (layers *.Cu *.Mask)
      (net 1 "Net-(BT1-Pad2)") (pinfunction "E") (pintype "passive") (tstamp a42ca081-3a8a-4f14-a834-125dc453d950))
      (scale (xyz 1 1 1))
    (tedit 5F68FEEF) (tstamp b4df2529-44ea-45a4-9d69-5d3a30e91638)
    (at 81.4985 64.516 90)
    (path "/b46b3b8e-d621-4ea0-b4c7-48aae29c100b")
    (attr smd)
    (fp_text reference "C5" (at 0 -1.85 90) (layer "F.SilkS")
      (tstamp 0fb40b84-76a5-47ec-9695-67455ebb3796)
    (fp_text value "10u 50V KEM X5R1210 10U" (at 0 1.85 90) (layer "F.Fab")
      (tstamp 47739cbc-890c-4399-9fa5-5724eb032805)
      (tstamp 35935632-bd99-4e3a-a1a2-b7e960d7084a)
    (fp_line (start -0.711252 0.91) (end 0.711252 0.91) (layer "F.SilkS") (width 0.12) (tstamp 879ef2ba-3154-4d71-ae9f-eef0a6482743))
    (fp_line (start -0.711252 -0.91) (end 0.711252 -0.91) (layer "F.SilkS") (width 0.12) (tstamp 9d49b2bd-b5db-4c90-9dad-a381b810be75))
    (fp_line (start 2.48 1.15) (end -2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp 0e0d2137-2d7a-43b6-b3af-7865e975ea97))
    (fp_line (start 2.48 -1.15) (end 2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp 35ffb246-d467-4393-8279-7eb717e064bf))
    (fp_line (start -2.48 1.15) (end -2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp e57b94fb-bbbd-4151-9226-65813b37b284))
    (fp_line (start -2.48 -1.15) (end 2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp f94e1099-eefc-4fbc-9898-3c4a33536f59))
    (fp_line (start -1.6 -0.8) (end 1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp 0892d393-d748-4543-95eb-4c1e7fccf5ae))
    (fp_line (start 1.6 0.8) (end -1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp 2a6e4b0c-dd37-4e6e-8a5c-b79535e99641))
    (fp_line (start 1.6 -0.8) (end 1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp 7da13a64-25b9-4d05-929e-7ea55a45fd1d))
    (fp_line (start -1.6 0.8) (end -1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp f7bf02d6-4738-42af-8f12-69211ab8e62b))
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp 72f67435-f2b3-487e-9337-6f5bb912d349))
      (net 15 "Net-(C3-Pad1)") (pintype "passive") (tstamp d24eaa92-f3ca-448f-b0df-61981ebe267d))
      (scale (xyz 1 1 1))
    (tedit 5F68FEEF) (tstamp b7824298-8d49-41b5-bdf5-10691bdfb8b6)
    (at 73.533 125.73 -90)
    (path "/8a906a34-fca6-4e0d-b8c1-9378cb7c8736")
    (attr smd)
    (fp_text reference "C36" (at 4.064 0 90) (layer "F.SilkS")
      (tstamp 5f7d8686-bf23-4d14-9f99-6c1fda1fe102)
      (tstamp 8eb872d8-1f4a-4298-af93-6a53e586eb4e)
      (tstamp 4fbcbf19-3f44-4ccd-8d41-204de08d57a9)
    (fp_line (start -0.711252 0.91) (end 0.711252 0.91) (layer "F.SilkS") (width 0.12) (tstamp 6de958af-b7ac-4b43-9984-727d004aa34f))
    (fp_line (start -0.711252 -0.91) (end 0.711252 -0.91) (layer "F.SilkS") (width 0.12) (tstamp cb3e5061-8d55-4c18-95a3-86904dd47192))
    (fp_line (start -2.48 1.15) (end -2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp 8e6bebe5-8da4-44d7-ab1d-47643b88f4cd))
    (fp_line (start 2.48 -1.15) (end 2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp bd8d783f-4f16-4c6c-bc35-e7e7770a9c4d))
    (fp_line (start 2.48 1.15) (end -2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp d89d398f-85ac-4fc5-8a09-88ea9ce00a3c))
    (fp_line (start -2.48 -1.15) (end 2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp f4639ba8-3a67-4c2d-ae83-bcbc34d5ee4c))
    (fp_line (start -1.6 0.8) (end -1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp 421d9ae3-ab3e-4760-be28-2087f5235f27))
    (fp_line (start 1.6 0.8) (end -1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp 84b33304-8fa7-4e55-b39e-d10f3b12e5b9))
    (fp_line (start -1.6 -0.8) (end 1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp 9ec81b78-2617-4588-9154-8d2b8ed5221f))
    (fp_line (start 1.6 -0.8) (end 1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp a5c9c7a1-db00-4e8f-b724-bb188ffa88c1))
      (net 97 "Net-(C36-Pad1)") (pintype "passive") (tstamp 988c1c31-2d13-4e6a-a9cb-8b28f2763311))
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp a54b83fc-6669-4fcd-b523-03cf7f7dbade))
      (scale (xyz 1 1 1))
  (footprint "Capacitor_THT:CP_Radial_D5.0mm_P2.00mm" (layer "F.Cu")
    (tedit 5AE50EF0) (tstamp b8eea8e6-d653-4096-9beb-61179850bdc4)
    (at 74.676 55.946113 90)
    (descr "CP, Radial series, Radial, pin pitch=2.00mm, , diameter=5mm, Electrolytic Capacitor")
    (tags "CP Radial series Radial pin pitch 2.00mm  diameter 5mm Electrolytic Capacitor")
    (path "/f74525fd-c7e8-4a14-a508-70ca448142a0")
    (attr through_hole)
    (fp_text reference "C18" (at 1 -3.75 90) (layer "F.SilkS")
      (tstamp 8ad9f986-d52e-411e-b81c-19b8c0cdb42c)
    (fp_text value "RAD FC 4,7U/50V" (at 1 3.75 90) (layer "F.Fab")
      (tstamp c460f604-0981-410b-9b7a-31fce926b3d7)
    (fp_text user "${REFERENCE}" (at 1 0 90) (layer "F.Fab")
      (tstamp 5fc202b2-1c30-4289-a613-36ab9e578a93)
    (fp_line (start 1.56 1.04) (end 1.56 2.52) (layer "F.SilkS") (width 0.12) (tstamp 0107d887-f9f3-4e8d-ad02-943b5e506556))
    (fp_line (start 1.56 -2.52) (end 1.56 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 0563eceb-f1b8-4857-bb86-879d31387b96))
    (fp_line (start 2.441 1.04) (end 2.441 2.149) (layer "F.SilkS") (width 0.12) (tstamp 0604b37e-61d6-4a6f-ac6b-9c862b11cb9e))
    (fp_line (start 1.44 -2.543) (end 1.44 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 0680e612-5f11-4d38-806a-4c787a76f14a))
    (fp_line (start 2.161 -2.31) (end 2.161 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 0712c70f-36b7-422b-b061-e49ee517f9eb))
    (fp_line (start 1 1.04) (end 1 2.58) (layer "F.SilkS") (width 0.12) (tstamp 075926bb-3b2d-4284-ac49-f145345b7615))
    (fp_line (start 2.441 -2.149) (end 2.441 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 092ed6d5-cb22-42c1-bb58-61dd62625afd))
    (fp_line (start 2.681 -1.971) (end 2.681 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 0ad3e56d-c2d9-472c-a769-3ddd1e124e28))
    (fp_line (start -1.554775 -1.725) (end -1.554775 -1.225) (layer "F.SilkS") (width 0.12) (tstamp 0c3d23da-2d8d-4a89-ad7a-7b0faff4150f))
    (fp_line (start 1.12 -2.578) (end 1.12 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 0f88fda2-5e76-4e8c-a8a0-8082122ad6c2))
    (fp_line (start 3.361 -1.098) (end 3.361 1.098) (layer "F.SilkS") (width 0.12) (tstamp 10395658-183f-4629-b853-911cb96a6f65))
    (fp_line (start 2.761 1.04) (end 2.761 1.901) (layer "F.SilkS") (width 0.12) (tstamp 11f1d12a-a4de-4929-b5a4-b21a45dd93f5))
    (fp_line (start 1.32 1.04) (end 1.32 2.561) (layer "F.SilkS") (width 0.12) (tstamp 1421f818-b2eb-4751-be80-7674c03f387a))
    (fp_line (start 2.121 -2.329) (end 2.121 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 16a5db36-0dd1-49d4-8a27-08e66e92c3f8))
    (fp_line (start 2.041 -2.365) (end 2.041 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 173d8476-71cc-4da7-bb0a-5857608783ff))
    (fp_line (start 2.481 -2.122) (end 2.481 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 183fb64c-b4f7-4b73-b74f-d1059830d32c))
    (fp_line (start 3.081 -1.554) (end 3.081 1.554) (layer "F.SilkS") (width 0.12) (tstamp 1c73a8dd-30be-4bf2-a84a-d283832f1e19))
    (fp_line (start 1.48 -2.536) (end 1.48 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 1dbcc106-49ef-40d7-8573-ef87c5ad46f7))
    (fp_line (start 1.44 1.04) (end 1.44 2.543) (layer "F.SilkS") (width 0.12) (tstamp 20d4430a-69e8-46c1-8697-e96de6cfdba2))
    (fp_line (start 1.28 -2.565) (end 1.28 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 22f3a5e6-8e43-4216-8cc3-96a021a6da73))
    (fp_line (start 2.561 1.04) (end 2.561 2.065) (layer "F.SilkS") (width 0.12) (tstamp 265e4d2f-9ff7-40b0-aa21-9de6c881ceb0))
    (fp_line (start 1.64 -2.501) (end 1.64 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 27ae0227-b06f-4703-b8a0-a0ffe365e8cf))
    (fp_line (start 1.4 1.04) (end 1.4 2.55) (layer "F.SilkS") (width 0.12) (tstamp 284d847b-e48a-4a9c-b3fe-0b0470f3944d))
    (fp_line (start 2.201 -2.29) (end 2.201 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 294e4e93-9870-4c06-aafd-5d6dd133fec2))
    (fp_line (start 2.321 1.04) (end 2.321 2.224) (layer "F.SilkS") (width 0.12) (tstamp 296c251d-1d30-45c7-aeb2-3f6cc183a097))
    (fp_line (start 1.08 -2.579) (end 1.08 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 2b0359c4-f793-407a-a559-8554e3aa34d9))
    (fp_line (start 1.28 1.04) (end 1.28 2.565) (layer "F.SilkS") (width 0.12) (tstamp 2c5c8c74-24a0-4fb0-8c5a-5d52352a2632))
    (fp_line (start 2.801 1.04) (end 2.801 1.864) (layer "F.SilkS") (width 0.12) (tstamp 2d3849c4-e5c0-4922-82c6-20f669d10477))
    (fp_line (start 1.36 1.04) (end 1.36 2.556) (layer "F.SilkS") (width 0.12) (tstamp 2f2dfeda-0e58-420a-a76c-ecd0e28205ed))
    (fp_line (start 2.761 -1.901) (end 2.761 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 337ccebb-a497-42cd-af6f-b6e17cc618f9))
    (fp_line (start 3.281 -1.251) (end 3.281 1.251) (layer "F.SilkS") (width 0.12) (tstamp 33bd6d44-c990-4bff-927f-afc13a4e638f))
    (fp_line (start 2.121 1.04) (end 2.121 2.329) (layer "F.SilkS") (width 0.12) (tstamp 345da14e-4194-4cc9-9cc6-52c4d331ada7))
    (fp_line (start 1.12 1.04) (end 1.12 2.578) (layer "F.SilkS") (width 0.12) (tstamp 3791d3b9-ae17-4833-8790-e5a7ae261560))
    (fp_line (start 2.961 -1.699) (end 2.961 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 3c0d8672-5413-497d-b122-e214c24f7ddd))
    (fp_line (start 3.121 -1.5) (end 3.121 1.5) (layer "F.SilkS") (width 0.12) (tstamp 4266f259-9517-4d55-83cc-6b773a034e68))
    (fp_line (start 1 -2.58) (end 1 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 43b711f9-7537-48ee-9e82-cec2b3cbfbe1))
    (fp_line (start 2.921 1.04) (end 2.921 1.743) (layer "F.SilkS") (width 0.12) (tstamp 4822d71f-e82e-41dd-b1ef-3a6a31fdaf3b))
    (fp_line (start 3.561 -0.518) (end 3.561 0.518) (layer "F.SilkS") (width 0.12) (tstamp 4929cb7c-52a1-4a48-a58b-95c9626203f7))
    (fp_line (start 2.721 -1.937) (end 2.721 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 4935f1ae-d0e9-405a-83b1-c723bbf64c0d))
    (fp_line (start 1.04 -2.58) (end 1.04 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 4a384f29-b55e-4825-9de7-2385ab03e979))
    (fp_line (start 2.881 -1.785) (end 2.881 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 4c68e44e-e0a6-480d-a1a4-8f4219231d08))
    (fp_line (start 2.041 1.04) (end 2.041 2.365) (layer "F.SilkS") (width 0.12) (tstamp 4ecd4fe1-475c-4c19-a9e6-a9b0ea9d43d9))
    (fp_line (start 2.961 1.04) (end 2.961 1.699) (layer "F.SilkS") (width 0.12) (tstamp 544ed438-b208-438e-b4a6-4d1132c4c824))
    (fp_line (start 2.001 1.04) (end 2.001 2.382) (layer "F.SilkS") (width 0.12) (tstamp 55683e4f-a7de-44ab-96fd-188d0f9fce88))
    (fp_line (start 1.721 1.04) (end 1.721 2.48) (layer "F.SilkS") (width 0.12) (tstamp 5bd180e5-f1fc-4a97-88bb-6c32a7b39738))
    (fp_line (start 3.041 -1.605) (end 3.041 1.605) (layer "F.SilkS") (width 0.12) (tstamp 5fc23402-67ba-412a-a141-447b5c8fffa3))
    (fp_line (start 1.16 -2.576) (end 1.16 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 674e6fc4-b428-4956-b720-360aead45b35))
    (fp_line (start 3.401 -1.011) (end 3.401 1.011) (layer "F.SilkS") (width 0.12) (tstamp 67f02f8f-d772-4349-95ce-eb42a46a40ce))
    (fp_line (start 2.921 -1.743) (end 2.921 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 6818c56c-a1ce-4407-ad2d-e3ea6a8ce402))
    (fp_line (start 2.201 1.04) (end 2.201 2.29) (layer "F.SilkS") (width 0.12) (tstamp 6becaccc-e6a6-4ee3-ba5c-a026aa2664c7))
    (fp_line (start 1.4 -2.55) (end 1.4 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 6dec841b-e239-4d03-9a38-d84c761f0dbc))
    (fp_line (start 1.721 -2.48) (end 1.721 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 6e3c11a9-4848-4f7d-b83e-14287e14bfcd))
    (fp_line (start 2.001 -2.382) (end 2.001 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 70987066-413a-4323-86a1-72e195779a7e))
    (fp_line (start 1.881 1.04) (end 1.881 2.428) (layer "F.SilkS") (width 0.12) (tstamp 718249a3-2cf8-4205-bb08-b5c95fe125f9))
    (fp_line (start 2.241 -2.268) (end 2.241 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 73e72037-478c-4c8a-9775-2f6b677d7f63))
    (fp_line (start 2.641 -2.004) (end 2.641 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 74336310-0d01-4b31-86e2-50ecbb51a61c))
    (fp_line (start 2.281 -2.247) (end 2.281 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 752ee8e5-4f9c-4982-a61e-480ff7ad7046))
    (fp_line (start 3.161 -1.443) (end 3.161 1.443) (layer "F.SilkS") (width 0.12) (tstamp 7659c983-370c-45cc-b04a-449009b1c256))
    (fp_line (start 2.641 1.04) (end 2.641 2.004) (layer "F.SilkS") (width 0.12) (tstamp 77d45385-0c23-4706-ad6f-964a995a84a1))
    (fp_line (start 2.361 -2.2) (end 2.361 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 78e7bca8-8b1b-469a-aec5-1d4c9a838984))
    (fp_line (start 3.241 -1.319) (end 3.241 1.319) (layer "F.SilkS") (width 0.12) (tstamp 7923de06-e3ab-424d-b08a-7a3639e08d94))
    (fp_line (start 1.841 -2.442) (end 1.841 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 7d15d067-b096-4c2e-8840-2b87f4c85819))
    (fp_line (start 1.961 -2.398) (end 1.961 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 7de7d370-9f37-4d61-b632-483d726d8a0a))
    (fp_line (start 1.52 1.04) (end 1.52 2.528) (layer "F.SilkS") (width 0.12) (tstamp 7f1d5343-e89d-4c08-b034-dbd88300c189))
    (fp_line (start 3.521 -0.677) (end 3.521 0.677) (layer "F.SilkS") (width 0.12) (tstamp 812c91e7-ae1f-4824-96bc-816d343bf23f))
    (fp_line (start 3.601 -0.284) (end 3.601 0.284) (layer "F.SilkS") (width 0.12) (tstamp 83543b0c-a002-46df-89e7-c8d9b8ae7237))
    (fp_line (start 2.241 1.04) (end 2.241 2.268) (layer "F.SilkS") (width 0.12) (tstamp 856b7e0f-513a-455d-b39b-246e43c7d842))
    (fp_line (start 2.561 -2.065) (end 2.561 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 8631ba19-df78-47e5-b09e-9edde6a5cf29))
    (fp_line (start 2.681 1.04) (end 2.681 1.971) (layer "F.SilkS") (width 0.12) (tstamp 8cf0b7f3-53ed-404f-9524-6b9ae09fb36b))
    (fp_line (start 1.961 1.04) (end 1.961 2.398) (layer "F.SilkS") (width 0.12) (tstamp 902b49cc-175b-4b82-bfd3-311944574cfb))
    (fp_line (start 3.481 -0.805) (end 3.481 0.805) (layer "F.SilkS") (width 0.12) (tstamp 9148bacb-6349-4dce-81d7-9a2319574d4a))
    (fp_line (start 3.321 -1.178) (end 3.321 1.178) (layer "F.SilkS") (width 0.12) (tstamp 9148d034-a9a8-4209-b825-9b7ecd366bec))
    (fp_line (start 1.32 -2.561) (end 1.32 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 9584643a-bcea-4b94-9c6a-9d8de8790eba))
    (fp_line (start 1.24 1.04) (end 1.24 2.569) (layer "F.SilkS") (width 0.12) (tstamp 97cb166c-fbed-4641-b410-f224e2efa1cf))
    (fp_line (start 1.68 1.04) (end 1.68 2.491) (layer "F.SilkS") (width 0.12) (tstamp 9eddbaa3-8de8-4468-815f-359f8b5de983))
    (fp_line (start 1.16 1.04) (end 1.16 2.576) (layer "F.SilkS") (width 0.12) (tstamp 9fb6e839-8b70-411d-ab3a-6042aa4037b3))
    (fp_line (start 1.36 -2.556) (end 1.36 -1.04) (layer "F.SilkS") (width 0.12) (tstamp a194b0dd-bc11-4c7c-86d1-db15e4fa7370))
    (fp_line (start 2.521 1.04) (end 2.521 2.095) (layer "F.SilkS") (width 0.12) (tstamp a36daaa1-85c8-4014-b80e-8fe03e17218a))
    (fp_line (start 1.921 1.04) (end 1.921 2.414) (layer "F.SilkS") (width 0.12) (tstamp a7827c9c-ed4e-45c5-b0d4-f01d1d3fb2ee))
    (fp_line (start 2.521 -2.095) (end 2.521 -1.04) (layer "F.SilkS") (width 0.12) (tstamp a7829b5c-ccd3-4549-937c-f92c34cdae0d))
    (fp_line (start 2.601 -2.035) (end 2.601 -1.04) (layer "F.SilkS") (width 0.12) (tstamp aaa030a4-c1cc-465a-b167-482637d074a6))
    (fp_line (start 1.2 1.04) (end 1.2 2.573) (layer "F.SilkS") (width 0.12) (tstamp ae30313a-929d-4502-8890-320072dbdeae))
    (fp_line (start 2.281 1.04) (end 2.281 2.247) (layer "F.SilkS") (width 0.12) (tstamp afc1bf1c-0586-45fd-8f0b-4b66820085de))
    (fp_line (start 1.881 -2.428) (end 1.881 -1.04) (layer "F.SilkS") (width 0.12) (tstamp b022e30d-bff4-44e5-821c-3470dc7091a8))
    (fp_line (start 3.201 -1.383) (end 3.201 1.383) (layer "F.SilkS") (width 0.12) (tstamp b02fcb2d-a732-47f0-84e0-780e4645fa73))
    (fp_line (start 2.801 -1.864) (end 2.801 -1.04) (layer "F.SilkS") (width 0.12) (tstamp b0585331-e3e8-499b-80d5-e0d7ddb7191b))
    (fp_line (start -1.804775 -1.475) (end -1.304775 -1.475) (layer "F.SilkS") (width 0.12) (tstamp b1a99a4f-9933-4b52-881a-aa955d683cd6))
    (fp_line (start 3.441 -0.915) (end 3.441 0.915) (layer "F.SilkS") (width 0.12) (tstamp b5a83b61-b583-4e39-8799-a1d39866cc31))
    (fp_line (start 1.801 1.04) (end 1.801 2.455) (layer "F.SilkS") (width 0.12) (tstamp b660c4d0-c2ee-459e-99fd-7af86de64f7b))
    (fp_line (start 2.361 1.04) (end 2.361 2.2) (layer "F.SilkS") (width 0.12) (tstamp b9989659-b18b-4c99-9de8-db9b4274f766))
    (fp_line (start 1.48 1.04) (end 1.48 2.536) (layer "F.SilkS") (width 0.12) (tstamp bd8451ec-0fc7-459e-9ad3-8513466ca4a0))
    (fp_line (start 1.6 -2.511) (end 1.6 -1.04) (layer "F.SilkS") (width 0.12) (tstamp c10ea943-6348-40f7-b6e4-0742406a5ef2))
    (fp_line (start 1.761 1.04) (end 1.761 2.468) (layer "F.SilkS") (width 0.12) (tstamp c20973f3-57f6-467e-b2b4-862217c27817))
    (fp_line (start 2.721 1.04) (end 2.721 1.937) (layer "F.SilkS") (width 0.12) (tstamp c5a84030-1082-405e-831b-45a7c0be7046))
    (fp_line (start 1.2 -2.573) (end 1.2 -1.04) (layer "F.SilkS") (width 0.12) (tstamp c6ac32df-4206-4af8-aa3e-190bea83db3b))
    (fp_line (start 1.68 -2.491) (end 1.68 -1.04) (layer "F.SilkS") (width 0.12) (tstamp c70a152d-ce40-4695-acc5-7ba19bb51d22))
    (fp_line (start 2.161 1.04) (end 2.161 2.31) (layer "F.SilkS") (width 0.12) (tstamp c736452b-5123-4697-9c3e-9e76222abfe6))
    (fp_line (start 1.08 1.04) (end 1.08 2.579) (layer "F.SilkS") (width 0.12) (tstamp cd19cbc8-81ab-4d5c-8377-ca7e01cc7b91))
    (fp_line (start 2.881 1.04) (end 2.881 1.785) (layer "F.SilkS") (width 0.12) (tstamp ce0634de-8dc0-4e35-beda-7e1104006934))
    (fp_line (start 2.481 1.04) (end 2.481 2.122) (layer "F.SilkS") (width 0.12) (tstamp d0118846-e11c-44c5-a1e5-a3fa994786b0))
    (fp_line (start 2.841 1.04) (end 2.841 1.826) (layer "F.SilkS") (width 0.12) (tstamp d26898d1-78ce-49cf-ae6f-d393f027ba80))
    (fp_line (start 1.6 1.04) (end 1.6 2.511) (layer "F.SilkS") (width 0.12) (tstamp d2cecdc8-9f81-408e-a92a-60072de5ad16))
    (fp_line (start 1.801 -2.455) (end 1.801 -1.04) (layer "F.SilkS") (width 0.12) (tstamp d413d4c5-e585-498a-98ad-c704c777c718))
    (fp_line (start 1.04 1.04) (end 1.04 2.58) (layer "F.SilkS") (width 0.12) (tstamp d73218aa-1081-4b65-bae7-e521ec4aabe4))
    (fp_line (start 1.921 -2.414) (end 1.921 -1.04) (layer "F.SilkS") (width 0.12) (tstamp d9a7d33b-eb3e-4ea1-a337-34c64edf2183))
    (fp_line (start 2.081 1.04) (end 2.081 2.348) (layer "F.SilkS") (width 0.12) (tstamp db9dec77-302a-4bba-a7f9-d9c3e087e0af))
    (fp_line (start 1.52 -2.528) (end 1.52 -1.04) (layer "F.SilkS") (width 0.12) (tstamp dc3904a1-0cc6-4cbe-93bd-55e30be52087))
    (fp_line (start 2.321 -2.224) (end 2.321 -1.04) (layer "F.SilkS") (width 0.12) (tstamp de1bffed-fe5b-425d-97e2-ccc036b8a7aa))
    (fp_line (start 3.001 -1.653) (end 3.001 -1.04) (layer "F.SilkS") (width 0.12) (tstamp de1eda65-2d81-47f5-b19e-1be83b144399))
    (fp_line (start 2.601 1.04) (end 2.601 2.035) (layer "F.SilkS") (width 0.12) (tstamp e93eef6e-ffbf-4c48-b3c9-aea24c921b86))
    (fp_line (start 2.841 -1.826) (end 2.841 -1.04) (layer "F.SilkS") (width 0.12) (tstamp edfbb189-ef20-442f-879d-b172f37be27b))
    (fp_line (start 1.761 -2.468) (end 1.761 -1.04) (layer "F.SilkS") (width 0.12) (tstamp ee21d1a3-bf2a-431b-8460-3ade2cd1b51b))
    (fp_line (start 1.841 1.04) (end 1.841 2.442) (layer "F.SilkS") (width 0.12) (tstamp f0d9321f-f116-4f14-b1be-4162cc269fe6))
    (fp_line (start 2.401 1.04) (end 2.401 2.175) (layer "F.SilkS") (width 0.12) (tstamp f307da71-cd0c-4f50-b483-546c626d29b4))
    (fp_line (start 1.24 -2.569) (end 1.24 -1.04) (layer "F.SilkS") (width 0.12) (tstamp f4ee747e-163d-48a2-a6f0-91c57efd704b))
    (fp_line (start 1.64 1.04) (end 1.64 2.501) (layer "F.SilkS") (width 0.12) (tstamp f6d54943-91d0-4a7c-a005-54a3cceaff40))
    (fp_line (start 3.001 1.04) (end 3.001 1.653) (layer "F.SilkS") (width 0.12) (tstamp f8650a6b-d079-4f5d-a89a-85b446aaad0a))
    (fp_line (start 2.081 -2.348) (end 2.081 -1.04) (layer "F.SilkS") (width 0.12) (tstamp fcaf5cf7-66af-4d7b-810e-2955d73b3eb1))
    (fp_line (start 2.401 -2.175) (end 2.401 -1.04) (layer "F.SilkS") (width 0.12) (tstamp fe9ea8ca-c0bc-4fbc-b3da-78d551eb63c4))
    (fp_circle (center 1 0) (end 3.62 0) (layer "F.SilkS") (width 0.12) (fill none) (tstamp 23a1774a-20e1-4f76-986d-174f6173eea9))
    (fp_circle (center 1 0) (end 3.75 0) (layer "F.CrtYd") (width 0.05) (fill none) (tstamp e5466858-d59e-457e-b66c-9520d3f47663))
    (fp_line (start -1.133605 -1.0875) (end -0.633605 -1.0875) (layer "F.Fab") (width 0.1) (tstamp 26472741-3599-4382-8380-9e8382d29508))
    (fp_line (start -0.883605 -1.3375) (end -0.883605 -0.8375) (layer "F.Fab") (width 0.1) (tstamp c75c7be1-86f2-40cb-a341-8d950314809a))
    (fp_circle (center 1 0) (end 3.5 0) (layer "F.Fab") (width 0.1) (fill none) (tstamp f757e99d-e485-4a44-b5fc-4e038099323f))
    (pad "1" thru_hole rect (at 0 0 90) (size 1.6 1.6) (drill 0.8) (layers *.Cu *.Mask)
      (net 44 "Net-(C11-Pad1)") (pintype "passive") (tstamp b8627655-7f13-482f-ab00-d579feb50563))
    (pad "2" thru_hole circle (at 2 0 90) (size 1.6 1.6) (drill 0.8) (layers *.Cu *.Mask)
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp a15730be-b38f-400b-94aa-df20a2385091))
    (model "${KICAD6_3DMODEL_DIR}/Capacitor_THT.3dshapes/CP_Radial_D5.0mm_P2.00mm.wrl"
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp bac929b8-4f35-4488-ac84-d0312b8995b5)
    (at 55.753 59.69 -90)
    (path "/21b2a17a-cc8d-4c01-a150-a3359facba60")
    (attr smd)
    (fp_text reference "R30" (at 0 -2.54 90) (layer "F.SilkS")
      (tstamp 11f12db4-72da-447c-b451-a42d7738b742)
    (fp_text value "SMD 1/4W 10k" (at 0 2.28 90) (layer "F.Fab")
      (tstamp fb565f40-65c3-4db8-a840-0c4fe1c81a98)
      (tstamp 95c08f64-78ff-464c-be6a-950c4529644d)
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp 41a69d52-a3a4-4888-bd4b-6db1b076847e))
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 7018bcf1-8ee8-4cd5-bf8b-7b4171492756))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 2658e2a9-d311-4d8b-8430-2795c2465ee0))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 2b1ca7c6-eca0-4420-a321-e9bbbf597827))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 6b17d37b-58bd-4b83-9c0e-70ce85611bed))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp c84bc651-754e-49aa-8b2a-8de2dc86383f))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 0e5e24e6-eec4-4e01-9715-77de1e6a61c1))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 6b590a60-2858-4550-98fb-1584edc4e032))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 9e8b09a0-a7f7-4b9c-bbbd-899a946f51f4))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp b91ae149-6359-44a2-90f5-36fdb25f9b67))
      (net 61 "Net-(R30-Pad1)") (pintype "passive") (tstamp abd1e326-a51a-4ee7-b461-36ae2b32c0c6))
      (net 85 "Net-(C20-Pad1)") (pintype "passive") (tstamp 22decb13-d5a9-47c8-b22d-b77d9a811be0))
      (scale (xyz 1 1 1))
  (footprint "Package_SO:SOIC-14_3.9x8.7mm_P1.27mm" (layer "F.Cu")
    (tedit 5D9F72B1) (tstamp bb808462-a5be-4333-8ffa-b3a8f44bb3b3)
    (at 69.596 41.021 90)
    (descr "SOIC, 14 Pin (JEDEC MS-012AB, https://www.analog.com/media/en/package-pcb-resources/package/pkg_pdf/soic_narrow-r/r_14.pdf), generated with kicad-footprint-generator ipc_gullwing_generator.py")
    (tags "SOIC SO")
    (path "/d754c026-4ec5-4133-b16c-641e96e3797a")
    (attr smd)
    (fp_text reference "U1" (at -0.127 5.461 270) (layer "F.SilkS")
      (tstamp a2435cec-301c-4af4-9a50-1de46c8265ed)
    (fp_text value "ATtiny44-20SS" (at 0 5.28 90) (layer "F.Fab")
      (tstamp db7329ed-995c-4c89-a540-7c8d5838540e)
      (tstamp 560b99a1-a7c1-4cab-bf1a-f4191f31957d)
    (fp_line (start 0 -4.435) (end -3.45 -4.435) (layer "F.SilkS") (width 0.12) (tstamp 291f98ed-6218-4555-b3e8-1be6a85365dd))
    (fp_line (start 0 4.435) (end -1.95 4.435) (layer "F.SilkS") (width 0.12) (tstamp 35b94c88-565e-4aae-89d7-162ccec4d690))
    (fp_line (start 0 4.435) (end 1.95 4.435) (layer "F.SilkS") (width 0.12) (tstamp bf688b69-57ab-4ffc-8892-f484930e0ac9))
    (fp_line (start 0 -4.435) (end 1.95 -4.435) (layer "F.SilkS") (width 0.12) (tstamp f3cd9bdc-4fee-4b8f-8c72-40db455a7590))
    (fp_line (start -3.7 -4.58) (end -3.7 4.58) (layer "F.CrtYd") (width 0.05) (tstamp 0f080c5b-00c1-4b9e-9100-f3fe5ccff609))
    (fp_line (start 3.7 -4.58) (end -3.7 -4.58) (layer "F.CrtYd") (width 0.05) (tstamp 5e2af256-2b6a-4dc8-84e2-5a31f2d699fd))
    (fp_line (start 3.7 4.58) (end 3.7 -4.58) (layer "F.CrtYd") (width 0.05) (tstamp 773cf8b2-3419-4ecd-ade3-b5397d40c2bf))
    (fp_line (start -3.7 4.58) (end 3.7 4.58) (layer "F.CrtYd") (width 0.05) (tstamp e7a3ae31-52c4-44ee-895a-b53e2cfcc829))
    (fp_line (start -0.975 -4.325) (end 1.95 -4.325) (layer "F.Fab") (width 0.1) (tstamp 1df14ad3-7e80-486f-a724-0baee032cd2b))
    (fp_line (start 1.95 4.325) (end -1.95 4.325) (layer "F.Fab") (width 0.1) (tstamp 844f4410-d5a5-4ac7-9ec9-98a279f31c1f))
    (fp_line (start -1.95 4.325) (end -1.95 -3.35) (layer "F.Fab") (width 0.1) (tstamp 8fc2c285-f0a8-4464-8eaf-0b1822171964))
    (fp_line (start -1.95 -3.35) (end -0.975 -4.325) (layer "F.Fab") (width 0.1) (tstamp cbbc0b62-fa21-448f-8f3b-542cfcc5f624))
    (fp_line (start 1.95 -4.325) (end 1.95 4.325) (layer "F.Fab") (width 0.1) (tstamp de708747-3393-4539-b0a3-6ee89d96a042))
    (pad "1" smd roundrect (at -2.475 -3.81 90) (size 1.95 0.6) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.25)
      (net 3 "Net-(C1-Pad2)") (pinfunction "VCC") (pintype "power_in") (tstamp ab482d02-e8f6-47ee-8528-662c0067114d))
    (pad "2" smd roundrect (at -2.475 -2.54 90) (size 1.95 0.6) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.25)
      (net 80 "unconnected-(U1-Pad2)") (pinfunction "XTAL1/PB0") (pintype "bidirectional") (tstamp 20930a4d-7494-4e1f-b9b5-7a14fb9d748b))
    (pad "3" smd roundrect (at -2.475 -1.27 90) (size 1.95 0.6) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.25)
      (net 81 "unconnected-(U1-Pad3)") (pinfunction "XTAL2/PB1") (pintype "bidirectional") (tstamp d393bbb2-1829-400d-b26e-c4d395d80a7d))
    (pad "4" smd roundrect (at -2.475 0 90) (size 1.95 0.6) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.25)
      (net 7 "Net-(C9-Pad2)") (pinfunction "~{RESET}/PB3") (pintype "bidirectional") (tstamp 43c7c2c0-94ab-4962-b42d-2110644b86cd))
    (pad "5" smd roundrect (at -2.475 1.27 90) (size 1.95 0.6) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.25)
      (net 46 "Net-(R8-Pad2)") (pinfunction "PB2") (pintype "bidirectional") (tstamp be59de88-958e-463d-b2fb-2dd80f1b0925))
    (pad "6" smd roundrect (at -2.475 2.54 90) (size 1.95 0.6) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.25)
      (net 57 "Net-(R27-Pad1)") (pinfunction "PA7") (pintype "bidirectional") (tstamp 09b1eecc-7283-44d8-a63c-4cd634670d53))
    (pad "7" smd roundrect (at -2.475 3.81 90) (size 1.95 0.6) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.25)
      (net 27 "Net-(J3-Pad4)") (pinfunction "MOSI_PA6") (pintype "bidirectional") (tstamp 17d3622e-09e1-44d6-8973-e128e444bd0f))
    (pad "8" smd roundrect (at 2.475 3.81 90) (size 1.95 0.6) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.25)
      (net 25 "Net-(J3-Pad1)") (pinfunction "MISO_ADC5_PA5") (pintype "bidirectional") (tstamp 882e79a5-9f79-44b9-931e-dc51ddc4d675))
    (pad "9" smd roundrect (at 2.475 2.54 90) (size 1.95 0.6) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.25)
      (net 26 "Net-(J3-Pad3)") (pinfunction "SCK_ADC4_PA4") (pintype "bidirectional") (tstamp c49baedd-1013-49d9-9209-3f45c142f134))
    (pad "10" smd roundrect (at 2.475 1.27 90) (size 1.95 0.6) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.25)
      (net 8 "Net-(C10-Pad2)") (pinfunction "ADC3_PA3") (pintype "bidirectional") (tstamp 1744e8e2-d8a9-46d6-babd-07e9f960b6b8))
    (pad "11" smd roundrect (at 2.475 0 90) (size 1.95 0.6) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.25)
      (net 102 "Net-(R16-Pad2)") (pinfunction "ADC2_PA2") (pintype "bidirectional") (tstamp 52e19b82-776a-4636-a23b-1c5d55f0afdc))
    (pad "12" smd roundrect (at 2.475 -1.27 90) (size 1.95 0.6) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.25)
      (net 86 "Net-(C31-Pad2)") (pinfunction "ADC1_PA1") (pintype "bidirectional") (tstamp 2518443a-65c0-49ce-9bb0-a511a0efc7e9))
    (pad "13" smd roundrect (at 2.475 -2.54 90) (size 1.95 0.6) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.25)
      (net 2 "Net-(C2-Pad1)") (pinfunction "AREF_ADC0_PA0") (pintype "bidirectional") (tstamp a1424056-4575-4281-b81c-bb8e13839ff8))
    (pad "14" smd roundrect (at 2.475 -3.81 90) (size 1.95 0.6) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.25)
      (net 1 "Net-(BT1-Pad2)") (pinfunction "GND") (pintype "power_in") (tstamp b03f6884-d899-4b03-b58d-d630fa506f61))
    (model "${KICAD6_3DMODEL_DIR}/Package_SO.3dshapes/SOIC-14_3.9x8.7mm_P1.27mm.wrl"
      (scale (xyz 1 1 1))
  (footprint "LED_SMD:LED_0805_2012Metric_Pad1.15x1.40mm_HandSolder" (layer "F.Cu")
    (tedit 5F68FEF1) (tstamp beb79ca9-9a6f-4ec7-8b6e-d6ceef44b99e)
    (at 74 19.558 90)
    (descr "LED SMD 0805 (2012 Metric), square (rectangular) end terminal, IPC_7351 nominal, (Body size source: https://docs.google.com/spreadsheets/d/1BsfQQcO9C6DZCsRaXUlFlo91Tg2WpOkGARC1WS5S8t0/edit?usp=sharing), generated with kicad-footprint-generator")
    (tags "LED handsolder")
    (path "/6e125ba9-a035-464e-858b-2757da444963")
    (attr smd)
    (fp_text reference "D5" (at 0.125 -1.802 90) (layer "F.SilkS")
      (tstamp a6c7f381-6f6d-445e-932d-287fbc9f200d)
    (fp_text value "OSO LYR976 Grün" (at 0 1.65 90) (layer "F.Fab")
      (tstamp 3bd2d822-ed45-4524-8f71-85109acd072b)
    (fp_text user "${REFERENCE}" (at 0 0 90) (layer "F.Fab")
      (effects (font (size 0.5 0.5) (thickness 0.08)))
      (tstamp e2fb3dec-8f67-4b16-83c2-f1d0779d2ec8)
    (fp_line (start -1.86 -0.96) (end -1.86 0.96) (layer "F.SilkS") (width 0.12) (tstamp 66722260-e3c2-4f95-9ff1-b597bf11911e))
    (fp_line (start -1.86 0.96) (end 1 0.96) (layer "F.SilkS") (width 0.12) (tstamp 9ca1b121-f1d8-4664-83e7-f994318682da))
    (fp_line (start 1 -0.96) (end -1.86 -0.96) (layer "F.SilkS") (width 0.12) (tstamp fa1e612f-c1bd-4c97-a8d1-b2201b62c3aa))
    (fp_line (start 1.85 -0.95) (end 1.85 0.95) (layer "F.CrtYd") (width 0.05) (tstamp 5e2716b6-3cf2-4ae3-9f0f-9c3311dff72c))
    (fp_line (start 1.85 0.95) (end -1.85 0.95) (layer "F.CrtYd") (width 0.05) (tstamp 87e9d91c-333e-4070-93c9-3883a5cfea8a))
    (fp_line (start -1.85 0.95) (end -1.85 -0.95) (layer "F.CrtYd") (width 0.05) (tstamp b81ed372-f163-4931-ba1f-90f8ae1688e1))
    (fp_line (start -1.85 -0.95) (end 1.85 -0.95) (layer "F.CrtYd") (width 0.05) (tstamp e9911089-d48b-4d3c-bff6-257e7a9f0baa))
    (fp_line (start 1 -0.6) (end -0.7 -0.6) (layer "F.Fab") (width 0.1) (tstamp 101d64d1-3aed-4436-a3fd-848e90f6cb89))
    (fp_line (start -1 0.6) (end 1 0.6) (layer "F.Fab") (width 0.1) (tstamp 2a3d9e8c-7a89-4ef8-ab16-54d601af66b5))
    (fp_line (start -0.7 -0.6) (end -1 -0.3) (layer "F.Fab") (width 0.1) (tstamp 39622ec1-87aa-40b8-ac3c-5f2c62d4ea12))
    (fp_line (start -1 -0.3) (end -1 0.6) (layer "F.Fab") (width 0.1) (tstamp 962d3ae2-33b8-44c9-a616-f5134363fcd5))
    (fp_line (start 1 0.6) (end 1 -0.6) (layer "F.Fab") (width 0.1) (tstamp c50bb094-0e8d-4c21-bc29-413a173a58b7))
    (pad "1" smd roundrect (at -1.025 0 90) (size 1.15 1.4) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.2173913043)
      (net 1 "Net-(BT1-Pad2)") (pinfunction "K") (pintype "passive") (tstamp a9313411-2f6a-4e73-bac7-bfc7c9520bdf))
    (pad "2" smd roundrect (at 1.025 0 90) (size 1.15 1.4) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.2173913043)
      (net 19 "Net-(D5-Pad2)") (pinfunction "A") (pintype "passive") (tstamp 9cfe9651-6940-4025-a2e6-1312937c6a1c))
    (model "${KICAD6_3DMODEL_DIR}/LED_SMD.3dshapes/LED_0805_2012Metric.wrl"
      (scale (xyz 1 1 1))
  (footprint "Capacitor_THT:CP_Radial_D8.0mm_P3.50mm" (layer "F.Cu")
    (tedit 5AE50EF0) (tstamp c060a9ae-cb45-4bc0-96f6-2506ef2d2d82)
    (at 86.741 148.972651 90)
    (descr "CP, Radial series, Radial, pin pitch=3.50mm, , diameter=8mm, Electrolytic Capacitor")
    (tags "CP Radial series Radial pin pitch 3.50mm  diameter 8mm Electrolytic Capacitor")
    (path "/bddd4dc8-fb89-4be7-a344-fd075f0f7cac")
    (attr through_hole)
    (fp_text reference "C22" (at 5.335651 -4.445 270) (layer "F.SilkS")
      (tstamp 18fd78af-71bd-478e-b511-ccf8d6ba4640)
    (fp_text value "470U 10V RAD FC 470/10" (at 1.398651 5.334 90) (layer "F.Fab")
      (tstamp 39e7d8f7-c8db-46cf-97f9-0c7c834ba138)
    (fp_text user "${REFERENCE}" (at 1.75 0 90) (layer "F.Fab")
      (tstamp f1ca7ec5-ecdb-48d3-8192-711afc611e1e)
    (fp_line (start 1.87 -4.079) (end 1.87 4.079) (layer "F.SilkS") (width 0.12) (tstamp 01f755f3-5bf0-49ce-b150-d035cc9d045e))
    (fp_line (start 1.91 -4.077) (end 1.91 4.077) (layer "F.SilkS") (width 0.12) (tstamp 02bc79a4-e42e-4499-98d5-86024bc48f86))
    (fp_line (start 2.991 1.04) (end 2.991 3.889) (layer "F.SilkS") (width 0.12) (tstamp 02f13c0e-50cd-47fa-81dd-52494c772c25))
    (fp_line (start 3.831 -3.517) (end 3.831 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 05f7dfea-5cfa-4e52-820a-886fa6013ab4))
    (fp_line (start 4.591 -2.945) (end 4.591 2.945) (layer "F.SilkS") (width 0.12) (tstamp 066d31b8-5bba-40a1-8463-1cdbb142c74c))
    (fp_line (start 3.991 1.04) (end 3.991 3.418) (layer "F.SilkS") (width 0.12) (tstamp 09f2045a-9159-4b7c-8fa6-05ec7c8cf256))
    (fp_line (start 5.391 -1.89) (end 5.391 1.89) (layer "F.SilkS") (width 0.12) (tstamp 0a295772-6c77-4c27-8ee8-07125ee9e2d9))
    (fp_line (start 3.951 1.04) (end 3.951 3.444) (layer "F.SilkS") (width 0.12) (tstamp 0aa258f8-b716-48ae-8a18-24bd92a9d32c))
    (fp_line (start 4.191 1.04) (end 4.191 3.28) (layer "F.SilkS") (width 0.12) (tstamp 0ae82fb6-6681-4091-b3fe-d9018794946e))
    (fp_line (start 4.271 1.04) (end 4.271 3.22) (layer "F.SilkS") (width 0.12) (tstamp 0b95e2ee-d8f4-4c49-a1c1-17e456c98a3a))
    (fp_line (start 5.671 -1.229) (end 5.671 1.229) (layer "F.SilkS") (width 0.12) (tstamp 0caf2580-fc93-4d3c-8a02-8cac57912c87))
    (fp_line (start 4.831 -2.697) (end 4.831 2.697) (layer "F.SilkS") (width 0.12) (tstamp 0e5f896a-d7d8-429a-bccd-07698c4a9035))
    (fp_line (start 4.191 -3.28) (end 4.191 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 0f72e814-d37b-49d4-a158-52b6233a7919))
    (fp_line (start 5.351 -1.964) (end 5.351 1.964) (layer "F.SilkS") (width 0.12) (tstamp 10bed915-03b1-4d4f-8bac-5a8000a15075))
    (fp_line (start 2.831 1.04) (end 2.831 3.936) (layer "F.SilkS") (width 0.12) (tstamp 11d305f3-d638-466b-bba1-0328afe89997))
    (fp_line (start 4.631 -2.907) (end 4.631 2.907) (layer "F.SilkS") (width 0.12) (tstamp 142b5a6e-aa04-4905-83f2-ceda0c3f354e))
    (fp_line (start 5.511 -1.645) (end 5.511 1.645) (layer "F.SilkS") (width 0.12) (tstamp 155b5407-55f3-472c-bd59-bcef73d4cc9f))
    (fp_line (start 5.551 -1.552) (end 5.551 1.552) (layer "F.SilkS") (width 0.12) (tstamp 1a2e4ac9-9194-4fc4-82bd-f1d9f19878c6))
    (fp_line (start 3.711 -3.584) (end 3.711 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 1c4916cc-4bba-4a81-81f5-4eebc2f66665))
    (fp_line (start 4.751 -2.784) (end 4.751 2.784) (layer "F.SilkS") (width 0.12) (tstamp 1d215c39-25c1-4d60-9084-efb05917a39c))
    (fp_line (start 4.471 1.04) (end 4.471 3.055) (layer "F.SilkS") (width 0.12) (tstamp 1f777541-920e-449b-b592-300fdc305d53))
    (fp_line (start 4.711 -2.826) (end 4.711 2.826) (layer "F.SilkS") (width 0.12) (tstamp 1fca8066-5c12-46a7-9b25-08d1a1635599))
    (fp_line (start 2.03 -4.071) (end 2.03 4.071) (layer "F.SilkS") (width 0.12) (tstamp 217f5c3b-4dc6-40d3-b196-f74a25aeb717))
    (fp_line (start 2.471 -4.017) (end 2.471 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 235fd76a-934c-4085-9d70-725f3e9ab09e))
    (fp_line (start 3.191 -3.821) (end 3.191 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 249b999b-f538-4b3b-a23c-b03c568bd0a6))
    (fp_line (start 3.591 -3.647) (end 3.591 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 250821e4-f9aa-45e6-b17f-ca6f703146dc))
    (fp_line (start 3.111 -3.85) (end 3.111 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 2595e00e-f56a-4bb8-9359-57dcf5c4ec4b))
    (fp_line (start 3.271 1.04) (end 3.271 3.79) (layer "F.SilkS") (width 0.12) (tstamp 29ee3463-e4b7-4436-8b92-116e3f0a2bbf))
    (fp_line (start 4.311 1.04) (end 4.311 3.189) (layer "F.SilkS") (width 0.12) (tstamp 2a1b27b4-5569-484f-8461-a997052fe652))
    (fp_line (start 2.11 -4.065) (end 2.11 4.065) (layer "F.SilkS") (width 0.12) (tstamp 2a45c26a-bed6-4b0c-af76-28a856a412dd))
    (fp_line (start 4.431 1.04) (end 4.431 3.09) (layer "F.SilkS") (width 0.12) (tstamp 2d260500-6200-4ea7-8183-47ffe5e9caae))
    (fp_line (start 3.471 1.04) (end 3.471 3.704) (layer "F.SilkS") (width 0.12) (tstamp 34eda3bc-e1b9-4726-89ac-bd83e8f109c0))
    (fp_line (start 2.07 -4.068) (end 2.07 4.068) (layer "F.SilkS") (width 0.12) (tstamp 370d96fb-a87f-438a-ab2f-6f35033c9466))
    (fp_line (start 2.631 1.04) (end 2.631 3.985) (layer "F.SilkS") (width 0.12) (tstamp 39acd42e-fdbe-49fb-a1f0-13af56522bd3))
    (fp_line (start 4.071 1.04) (end 4.071 3.365) (layer "F.SilkS") (width 0.12) (tstamp 3d6a814a-0c5e-41f8-9862-cdd3a033c7cd))
    (fp_line (start 5.831 -0.533) (end 5.831 0.533) (layer "F.SilkS") (width 0.12) (tstamp 3e1baeca-c098-4e29-b86a-aea1f8d325ad))
    (fp_line (start 2.751 -3.957) (end 2.751 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 42a2e3a7-b4f1-428f-852a-9af46126c805))
    (fp_line (start 4.071 -3.365) (end 4.071 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 436a16ee-7ca4-4b54-bbcf-e02cf20c7daf))
    (fp_line (start 3.191 1.04) (end 3.191 3.821) (layer "F.SilkS") (width 0.12) (tstamp 453423de-10ee-48b1-9b94-9c40f608bb0b))
    (fp_line (start 4.351 1.04) (end 4.351 3.156) (layer "F.SilkS") (width 0.12) (tstamp 47e35685-3611-4275-8533-67000f7c3594))
    (fp_line (start 2.31 -4.042) (end 2.31 4.042) (layer "F.SilkS") (width 0.12) (tstamp 48b45ab6-4b52-49a6-bdb2-274ad7bb92a2))
    (fp_line (start 5.431 -1.813) (end 5.431 1.813) (layer "F.SilkS") (width 0.12) (tstamp 4903176c-15bf-4584-8665-a0bc5cd0d9a8))
    (fp_line (start 2.871 -3.925) (end 2.871 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 49e5aaad-e219-4735-b283-72eeb7c38245))
    (fp_line (start 3.431 1.04) (end 3.431 3.722) (layer "F.SilkS") (width 0.12) (tstamp 4acdf157-f840-49e2-9ead-04a85a4bb440))
    (fp_line (start 5.751 -0.948) (end 5.751 0.948) (layer "F.SilkS") (width 0.12) (tstamp 4e8e1a4a-9a81-42c7-96ac-70c9b69bb0f9))
    (fp_line (start 2.951 1.04) (end 2.951 3.902) (layer "F.SilkS") (width 0.12) (tstamp 504edfc5-a767-4eb1-9c70-28268527d9ee))
    (fp_line (start 3.591 1.04) (end 3.591 3.647) (layer "F.SilkS") (width 0.12) (tstamp 50a1d272-36b4-4e97-9b25-18e3b0eb7264))
    (fp_line (start 3.511 1.04) (end 3.511 3.686) (layer "F.SilkS") (width 0.12) (tstamp 5106da32-fc91-46bb-a518-8474e81e487e))
    (fp_line (start 5.071 -2.4) (end 5.071 2.4) (layer "F.SilkS") (width 0.12) (tstamp 5185fb69-1c52-404f-94ca-be1b1fe381a7))
    (fp_line (start 4.391 -3.124) (end 4.391 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 51fa2357-b46c-4969-a9ac-1bc5720dcf21))
    (fp_line (start 3.311 -3.774) (end 3.311 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 53a78b62-c51e-4ca2-8b92-f04b0caa8d81))
    (fp_line (start 3.151 -3.835) (end 3.151 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 54aedc63-4820-47c4-a5d4-2b6368c3691d))
    (fp_line (start 4.871 -2.651) (end 4.871 2.651) (layer "F.SilkS") (width 0.12) (tstamp 59227215-fa8a-4955-bfb8-7b343ea4f765))
    (fp_line (start 2.551 1.04) (end 2.551 4.002) (layer "F.SilkS") (width 0.12) (tstamp 59bf990b-f89b-479d-bdd3-7053e633d721))
    (fp_line (start -2.259698 -2.715) (end -2.259698 -1.915) (layer "F.SilkS") (width 0.12) (tstamp 5add52d5-340a-4d36-be57-d4825cff5d3a))
    (fp_line (start 3.631 -3.627) (end 3.631 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 5c37640f-c0ec-4f39-a8c2-956d97c48697))
    (fp_line (start 2.911 1.04) (end 2.911 3.914) (layer "F.SilkS") (width 0.12) (tstamp 5f4135c8-a674-4337-9b4e-9f699e8f18a2))
    (fp_line (start 1.95 -4.076) (end 1.95 4.076) (layer "F.SilkS") (width 0.12) (tstamp 61fab6a9-33a6-4e45-afcf-cffd20e7086d))
    (fp_line (start 3.511 -3.686) (end 3.511 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 66897da2-f37f-4298-93bd-377e3dc4ddfc))
    (fp_line (start 3.431 -3.722) (end 3.431 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 6a92c89e-94fd-4e7c-a816-a69cd12bc04a))
    (fp_line (start 2.871 1.04) (end 2.871 3.925) (layer "F.SilkS") (width 0.12) (tstamp 6e77940c-9c45-42fc-83da-f0a980587072))
    (fp_line (start 4.511 -3.019) (end 4.511 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 6f948d38-3fa2-42df-8403-9c24f0a9a2be))
    (fp_line (start 5.231 -2.166) (end 5.231 2.166) (layer "F.SilkS") (width 0.12) (tstamp 75def097-e8c2-4f28-b2ea-0a6693dde13d))
    (fp_line (start 2.39 -4.03) (end 2.39 4.03) (layer "F.SilkS") (width 0.12) (tstamp 77504774-974f-4109-9ed1-d267330ab392))
    (fp_line (start 3.351 1.04) (end 3.351 3.757) (layer "F.SilkS") (width 0.12) (tstamp 77bd518a-705e-4591-898b-04caa8e8475f))
    (fp_line (start 4.431 -3.09) (end 4.431 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 7964f59a-37ad-43e1-912e-9217e754a6f5))
    (fp_line (start 3.631 1.04) (end 3.631 3.627) (layer "F.SilkS") (width 0.12) (tstamp 7f9a4743-3f6e-446e-8b25-1bc601b7757b))
    (fp_line (start 1.79 -4.08) (end 1.79 4.08) (layer "F.SilkS") (width 0.12) (tstamp 7fc96d2d-2d7d-4171-9ccf-de583f731549))
    (fp_line (start 2.991 -3.889) (end 2.991 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 80fb9a1c-e7ea-4626-99b1-ce09c2fa6aae))
    (fp_line (start 3.231 1.04) (end 3.231 3.805) (layer "F.SilkS") (width 0.12) (tstamp 81fd4278-788e-44d7-9fbf-8f70afb030fb))
    (fp_line (start 4.111 -3.338) (end 4.111 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 82c4d716-c95f-4011-9873-fb9d71562d5c))
    (fp_line (start 3.671 1.04) (end 3.671 3.606) (layer "F.SilkS") (width 0.12) (tstamp 82df47f8-be59-4a4f-b1b6-fcc0ceb3f8c3))
    (fp_line (start 2.631 -3.985) (end 2.631 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 863ba8f0-d09e-4722-9083-ed4d5f346dec))
    (fp_line (start 5.631 -1.346) (end 5.631 1.346) (layer "F.SilkS") (width 0.12) (tstamp 868e965b-e271-4526-89e4-ed1feb30abf6))
    (fp_line (start 2.43 -4.024) (end 2.43 4.024) (layer "F.SilkS") (width 0.12) (tstamp 87081709-ef07-45fc-8092-d6ffd5bb7308))
    (fp_line (start 3.751 -3.562) (end 3.751 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 8a20261e-5e91-49a5-842c-3c52daebecde))
    (fp_line (start 5.311 -2.034) (end 5.311 2.034) (layer "F.SilkS") (width 0.12) (tstamp 8bb9efa8-b8ee-471d-8db8-cceb54f462aa))
    (fp_line (start 3.031 -3.877) (end 3.031 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 8bd662bc-a4ba-4016-a24a-96cc37e22e38))
    (fp_line (start 2.19 -4.057) (end 2.19 4.057) (layer "F.SilkS") (width 0.12) (tstamp 8f452623-eb5e-41ab-8ef6-d90e5e5d3c6a))
    (fp_line (start 3.551 -3.666) (end 3.551 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 90abbd50-baa9-447e-8c03-f712039d3621))
    (fp_line (start 3.951 -3.444) (end 3.951 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 91e9f7ea-89b0-4e57-adf9-1271ef93b4af))
    (fp_line (start 4.991 -2.505) (end 4.991 2.505) (layer "F.SilkS") (width 0.12) (tstamp 92753e5e-4fa3-4c6f-94fb-e82fc6697c28))
    (fp_line (start 3.911 1.04) (end 3.911 3.469) (layer "F.SilkS") (width 0.12) (tstamp 97e9ae1b-632e-42d4-a65c-59642c07f3ec))
    (fp_line (start 3.711 1.04) (end 3.711 3.584) (layer "F.SilkS") (width 0.12) (tstamp 9800f2e0-0056-49a7-8be5-bfaa7c2599b1))
    (fp_line (start 5.191 -2.228) (end 5.191 2.228) (layer "F.SilkS") (width 0.12) (tstamp 9a570a52-ef60-4082-b0e7-9e573719b921))
    (fp_line (start 2.551 -4.002) (end 2.551 -1.04) (layer "F.SilkS") (width 0.12) (tstamp 9ab5dbe6-460b-48c8-a27e-be5c8a4cb05d))
    (fp_line (start 3.991 -3.418) (end 3.991 -1.04) (layer "F.SilkS") (width 0.12) (tstamp a04980f2-2da8-4af8-99ec-69784c50fcd5))
    (fp_line (start 1.83 -4.08) (end 1.83 4.08) (layer "F.SilkS") (width 0.12) (tstamp a6badd9a-04a3-43ef-9477-d66e39b28a9a))
    (fp_line (start 4.911 -2.604) (end 4.911 2.604) (layer "F.SilkS") (width 0.12) (tstamp a71130cb-ef42-48ab-9a40-fc917cc75e4d))
    (fp_line (start 3.791 1.04) (end 3.791 3.54) (layer "F.SilkS") (width 0.12) (tstamp a761c6a6-cdcb-480d-a0b3-7a48d33ba9f3))
    (fp_line (start 2.951 -3.902) (end 2.951 -1.04) (layer "F.SilkS") (width 0.12) (tstamp a86deee3-4387-4268-a43a-e955763150d8))
    (fp_line (start 4.151 1.04) (end 4.151 3.309) (layer "F.SilkS") (width 0.12) (tstamp aa1502fa-6f8b-4c5b-a0c8-f3c9ee2d60b8))
    (fp_line (start -2.659698 -2.315) (end -1.859698 -2.315) (layer "F.SilkS") (width 0.12) (tstamp ab2eac7c-be65-4823-959b-09c31d401c67))
    (fp_line (start 2.831 -3.936) (end 2.831 -1.04) (layer "F.SilkS") (width 0.12) (tstamp ac8c9f98-5f30-4f47-af4c-eefb53580ccb))
    (fp_line (start 4.311 -3.189) (end 4.311 -1.04) (layer "F.SilkS") (width 0.12) (tstamp ac971d84-d464-4aa7-a376-c9e4d02a410e))
    (fp_line (start 3.311 1.04) (end 3.311 3.774) (layer "F.SilkS") (width 0.12) (tstamp adc276d7-bcda-48e5-965f-c5963ff86224))
    (fp_line (start 3.071 -3.863) (end 3.071 -1.04) (layer "F.SilkS") (width 0.12) (tstamp ae9a29ee-90fb-4f55-9ead-e80b3b4e3b00))
    (fp_line (start 4.671 -2.867) (end 4.671 2.867) (layer "F.SilkS") (width 0.12) (tstamp af89bb0d-fac7-4d95-b302-4daac10aae9d))
    (fp_line (start 2.511 -4.01) (end 2.511 -1.04) (layer "F.SilkS") (width 0.12) (tstamp b0d3d9a2-828c-4b4b-848a-d49eaf6aa66c))
    (fp_line (start 2.27 -4.048) (end 2.27 4.048) (layer "F.SilkS") (width 0.12) (tstamp b12055d2-1577-436c-8793-2369d51d9fa5))
    (fp_line (start 2.911 -3.914) (end 2.911 -1.04) (layer "F.SilkS") (width 0.12) (tstamp b1f14a97-4de7-45ac-b748-84c182e2c22d))
    (fp_line (start 4.231 1.04) (end 4.231 3.25) (layer "F.SilkS") (width 0.12) (tstamp b3ecf2a0-0191-47c5-8746-7af661a98637))
    (fp_line (start 2.35 -4.037) (end 2.35 4.037) (layer "F.SilkS") (width 0.12) (tstamp b4cb89d4-07e5-4053-bdfa-6087c1c95fa6))
    (fp_line (start 2.591 -3.994) (end 2.591 -1.04) (layer "F.SilkS") (width 0.12) (tstamp b566a97a-fbca-4360-b64e-001101be0f9e))
    (fp_line (start 5.711 -1.098) (end 5.711 1.098) (layer "F.SilkS") (width 0.12) (tstamp b57c3e0d-e7cc-4918-8010-f7c063ce0c69))
    (fp_line (start 2.23 -4.052) (end 2.23 4.052) (layer "F.SilkS") (width 0.12) (tstamp b8406e45-8a87-4fe6-982b-2689e89c92f8))
    (fp_line (start 3.871 1.04) (end 3.871 3.493) (layer "F.SilkS") (width 0.12) (tstamp bad03b8f-8127-48ae-9781-d6479b3a26c8))
    (fp_line (start 5.031 -2.454) (end 5.031 2.454) (layer "F.SilkS") (width 0.12) (tstamp be2e6078-341f-471b-b8d3-15b8c2727a38))
    (fp_line (start 2.471 1.04) (end 2.471 4.017) (layer "F.SilkS") (width 0.12) (tstamp c02c2b41-2b55-4e96-96b6-4a52a5d95435))
    (fp_line (start 4.791 -2.741) (end 4.791 2.741) (layer "F.SilkS") (width 0.12) (tstamp c0d50f09-410c-438d-9814-a0d447aee302))
    (fp_line (start 3.471 -3.704) (end 3.471 -1.04) (layer "F.SilkS") (width 0.12) (tstamp c158bef8-83de-486c-ba6a-ac675166ad8b))
    (fp_line (start 4.511 1.04) (end 4.511 3.019) (layer "F.SilkS") (width 0.12) (tstamp c2db161b-4f88-43d4-90cf-6871894c29f4))
    (fp_line (start 4.151 -3.309) (end 4.151 -1.04) (layer "F.SilkS") (width 0.12) (tstamp c44dc927-8217-4a03-a49b-ae01cb8434e7))
    (fp_line (start 2.511 1.04) (end 2.511 4.01) (layer "F.SilkS") (width 0.12) (tstamp c57cb2b1-49db-4a13-a473-324d943df1c4))
    (fp_line (start 4.271 -3.22) (end 4.271 -1.04) (layer "F.SilkS") (width 0.12) (tstamp c873e9a6-805c-492f-8631-5a3e9b49d3e5))
    (fp_line (start 1.75 -4.08) (end 1.75 4.08) (layer "F.SilkS") (width 0.12) (tstamp ca4f828a-6b8e-4c9b-83ff-851253509d2f))
    (fp_line (start 3.351 -3.757) (end 3.351 -1.04) (layer "F.SilkS") (width 0.12) (tstamp caa01684-fccc-47aa-bd58-b1f1ef1929be))
    (fp_line (start 4.031 -3.392) (end 4.031 -1.04) (layer "F.SilkS") (width 0.12) (tstamp cb9b949c-b4ba-4a02-b6bf-7755e84a1270))
    (fp_line (start 3.551 1.04) (end 3.551 3.666) (layer "F.SilkS") (width 0.12) (tstamp cb9d7335-2bb0-4081-b058-da3e61e2e559))
    (fp_line (start 3.231 -3.805) (end 3.231 -1.04) (layer "F.SilkS") (width 0.12) (tstamp ce22870c-7303-4dc5-8c2e-0cc0400367df))
    (fp_line (start 3.111 1.04) (end 3.111 3.85) (layer "F.SilkS") (width 0.12) (tstamp cfe1911d-751d-460d-bca6-772d9e2ac3e7))
    (fp_line (start 2.711 1.04) (end 2.711 3.967) (layer "F.SilkS") (width 0.12) (tstamp d09ac6ef-0881-4d5f-8f86-37f32a0cd112))
    (fp_line (start 2.671 -3.976) (end 2.671 -1.04) (layer "F.SilkS") (width 0.12) (tstamp d1904e3e-b8d5-451e-b5e6-97b1da35b5cf))
    (fp_line (start 1.99 -4.074) (end 1.99 4.074) (layer "F.SilkS") (width 0.12) (tstamp d2e98314-dc24-44b4-a36a-11862e1d64f7))
    (fp_line (start 5.591 -1.453) (end 5.591 1.453) (layer "F.SilkS") (width 0.12) (tstamp d4704958-61cb-49f2-b329-02c939d3ecfe))
    (fp_line (start 4.951 -2.556) (end 4.951 2.556) (layer "F.SilkS") (width 0.12) (tstamp d6b4a091-fcf6-4a3c-8177-10f6b682716e))
    (fp_line (start 4.111 1.04) (end 4.111 3.338) (layer "F.SilkS") (width 0.12) (tstamp d7198244-d94c-433c-b1f0-b25f9035301c))
    (fp_line (start 4.551 -2.983) (end 4.551 2.983) (layer "F.SilkS") (width 0.12) (tstamp d7c56df5-a9e7-4683-852a-186b6607f76c))
    (fp_line (start 4.391 1.04) (end 4.391 3.124) (layer "F.SilkS") (width 0.12) (tstamp d9bef9d7-26a6-4f37-96e6-cdafcb1578c5))
    (fp_line (start 2.591 1.04) (end 2.591 3.994) (layer "F.SilkS") (width 0.12) (tstamp da64a9b5-86d5-492f-a7a7-12ecf8f09205))
    (fp_line (start 2.15 -4.061) (end 2.15 4.061) (layer "F.SilkS") (width 0.12) (tstamp db39067d-04af-4029-be96-ca02e72aec81))
    (fp_line (start 3.271 -3.79) (end 3.271 -1.04) (layer "F.SilkS") (width 0.12) (tstamp dd25dcff-e6c0-4982-b7e0-23b6fa600fe7))
    (fp_line (start 3.751 1.04) (end 3.751 3.562) (layer "F.SilkS") (width 0.12) (tstamp dd42e251-9e20-4577-a4c0-414203614fff))
    (fp_line (start 5.471 -1.731) (end 5.471 1.731) (layer "F.SilkS") (width 0.12) (tstamp e0229fed-2069-4cb2-aaaf-80b4c3b5af97))
    (fp_line (start 5.791 -0.768) (end 5.791 0.768) (layer "F.SilkS") (width 0.12) (tstamp e184c28b-01d8-4965-bb24-f3ec54c3d04e))
    (fp_line (start 4.471 -3.055) (end 4.471 -1.04) (layer "F.SilkS") (width 0.12) (tstamp e41ad8f4-af5d-4f82-8c7e-f9ce4afca53c))
    (fp_line (start 2.751 1.04) (end 2.751 3.957) (layer "F.SilkS") (width 0.12) (tstamp e57d8628-bf4e-406e-ba57-e04e65343ffa))
    (fp_line (start 5.271 -2.102) (end 5.271 2.102) (layer "F.SilkS") (width 0.12) (tstamp e63f00fc-e13a-4b17-ab2c-fb59d8f51a07))
    (fp_line (start 3.911 -3.469) (end 3.911 -1.04) (layer "F.SilkS") (width 0.12) (tstamp e658eb25-c3d4-479a-9d73-21c026ec78c4))
    (fp_line (start 5.151 -2.287) (end 5.151 2.287) (layer "F.SilkS") (width 0.12) (tstamp e91df222-fd6e-4d81-8219-9dfac5993966))
    (fp_line (start 3.031 1.04) (end 3.031 3.877) (layer "F.SilkS") (width 0.12) (tstamp eae69992-e645-4987-b0c4-e7a76e9f0071))
    (fp_line (start 2.671 1.04) (end 2.671 3.976) (layer "F.SilkS") (width 0.12) (tstamp eb082f38-f63c-4997-8986-bf14295fc519))
    (fp_line (start 3.871 -3.493) (end 3.871 -1.04) (layer "F.SilkS") (width 0.12) (tstamp ecb7aedc-d160-4b50-b095-f6039037b5ac))
    (fp_line (start 2.791 1.04) (end 2.791 3.947) (layer "F.SilkS") (width 0.12) (tstamp ed0c3d83-47e9-46ca-810e-a197ce98da0b))
    (fp_line (start 4.031 1.04) (end 4.031 3.392) (layer "F.SilkS") (width 0.12) (tstamp ee1cd9b8-c1a4-4050-93d2-ae56fe99bd6c))
    (fp_line (start 2.711 -3.967) (end 2.711 -1.04) (layer "F.SilkS") (width 0.12) (tstamp eee914f1-b153-44e1-8809-2774fbcd15e6))
    (fp_line (start 3.791 -3.54) (end 3.791 -1.04) (layer "F.SilkS") (width 0.12) (tstamp efd3f25c-397c-4c97-89f4-d4b0bba1ed0d))
    (fp_line (start 2.791 -3.947) (end 2.791 -1.04) (layer "F.SilkS") (width 0.12) (tstamp f0355eae-8e40-4ce2-b594-fc60b3dc3c1a))
    (fp_line (start 3.391 -3.74) (end 3.391 -1.04) (layer "F.SilkS") (width 0.12) (tstamp f0628dc1-c849-4803-9bbf-b86819db1baf))
    (fp_line (start 5.111 -2.345) (end 5.111 2.345) (layer "F.SilkS") (width 0.12) (tstamp f2fc3863-e5f6-4354-b1ec-bfecb51138bf))
    (fp_line (start 4.231 -3.25) (end 4.231 -1.04) (layer "F.SilkS") (width 0.12) (tstamp f560bf42-3d5d-4ff0-a629-bfa5fc6852bf))
    (fp_line (start 3.391 1.04) (end 3.391 3.74) (layer "F.SilkS") (width 0.12) (tstamp f5b6dc8b-2b33-407f-9c1f-cd4fadddf822))
    (fp_line (start 3.671 -3.606) (end 3.671 -1.04) (layer "F.SilkS") (width 0.12) (tstamp f7f12513-e18f-427f-ba0b-25c1d21f18bd))
    (fp_line (start 3.151 1.04) (end 3.151 3.835) (layer "F.SilkS") (width 0.12) (tstamp f9bb0173-1c8f-49af-beee-c2e4fb1416f6))
    (fp_line (start 4.351 -3.156) (end 4.351 -1.04) (layer "F.SilkS") (width 0.12) (tstamp fae7b369-0501-4380-acf0-2485a776189d))
    (fp_line (start 3.831 1.04) (end 3.831 3.517) (layer "F.SilkS") (width 0.12) (tstamp fca92857-b8d6-4ce6-8fb5-5c906e28fb61))
    (fp_line (start 3.071 1.04) (end 3.071 3.863) (layer "F.SilkS") (width 0.12) (tstamp fce7d5d9-6ad2-4303-aadb-9df286e6f73e))
    (fp_circle (center 1.75 0) (end 5.87 0) (layer "F.SilkS") (width 0.12) (fill none) (tstamp fcf0dccd-ee44-4d88-9528-b3162f119081))
    (fp_circle (center 1.75 0) (end 6 0) (layer "F.CrtYd") (width 0.05) (fill none) (tstamp 87ac69e7-ef23-45b3-861e-f5e9f4ebaadc))
    (fp_line (start -1.676759 -1.7475) (end -0.876759 -1.7475) (layer "F.Fab") (width 0.1) (tstamp 26d34cfc-5e1d-4312-b39f-a955342cc72c))
    (fp_line (start -1.276759 -2.1475) (end -1.276759 -1.3475) (layer "F.Fab") (width 0.1) (tstamp eebe0065-284a-4aaf-976f-ca555553d38e))
    (fp_circle (center 1.75 0) (end 5.75 0) (layer "F.Fab") (width 0.1) (fill none) (tstamp 26cca70b-acd4-404b-bd19-5c3776196245))
      (net 85 "Net-(C20-Pad1)") (pintype "passive") (tstamp 333c9d72-9906-47f5-a218-6fef6810a500))
    (pad "2" thru_hole circle (at 3.5 0 90) (size 1.6 1.6) (drill 0.8) (layers *.Cu *.Mask)
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp 6a9d0dae-2a36-4cd0-bcb0-7dfc2ef58310))
    (model "${KICAD6_3DMODEL_DIR}/Capacitor_THT.3dshapes/CP_Radial_D8.0mm_P3.50mm.wrl"
      (offset (xyz 0 0 0))
      (scale (xyz 1 1 1))
      (rotate (xyz 0 0 0))
  (footprint "Resistor_SMD:R_1210_3225Metric_Pad1.30x2.65mm_HandSolder" (layer "F.Cu")
    (tedit 5F68FEEE) (tstamp c7a48771-c435-4082-b3f9-ff63eb883056)
    (at 57.15 89.89 90)
    (descr "Resistor SMD 1210 (3225 Metric), square (rectangular) end terminal, IPC_7351 nominal with elongated pad for handsoldering. (Body size source: IPC-SM-782 page 72, https://www.pcb-3d.com/wordpress/wp-content/uploads/ipc-sm-782a_amendment_1_and_2.pdf), generated with kicad-footprint-generator")
    (tags "resistor handsolder")
    (property "Sheetfile" "Lauflicht_Steuerplatine.kicad_sch")
    (property "Sheetname" "")
    (path "/d8a08206-3cee-44a2-9072-a2f7bc57bf8f")
    (attr smd)
    (fp_text reference "R55" (at 3.149 0.127 180) (layer "F.SilkS")
      (effects (font (size 1 1) (thickness 0.15)))
      (tstamp 55666077-55c5-4de4-9e4a-aef041dc5568)
    (fp_text value "SMD 1/4W 1k" (at 0 2.28 90) (layer "F.Fab")
      (tstamp 5f10f5a0-3820-4e38-8cd8-f1530d6f56c5)
      (effects (font (size 0.8 0.8) (thickness 0.12)))
      (tstamp 762a2c11-e904-49a9-a663-5f2c64b69fde)
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp 001dbc98-62be-41d7-9210-6838e08f8eef))
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 697a543b-982b-4108-8e86-a35382537541))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 5a8ab001-898f-467d-b0db-778f5bce7950))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 5fc3d58d-bdf9-4858-ad59-30a2605523af))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp a0e56a3d-6596-44f3-82bc-b373a7c4138e))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp e477edec-4a72-43d4-bfd2-2c5db83108e2))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 6bcec1cd-73b7-4e40-8524-3feb17050310))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 6c725be2-309e-43e9-96a0-397c6bd3a01d))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 6c762e1f-23e3-4593-a104-702f53c70a5f))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp a7a87bbf-991f-43a0-aca9-d74ba584bd1a))
    (pad "1" smd roundrect (at -1.55 0 90) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 134 "Net-(R55-Pad1)") (pintype "passive") (tstamp 461a6bbd-4577-4614-81cf-c0c46a4902d9))
    (pad "2" smd roundrect (at 1.55 0 90) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 133 "Net-(D13-Pad2)") (pintype "passive") (tstamp 19551036-de89-422f-93e5-e3f1affe3f64))
    (model "${KICAD6_3DMODEL_DIR}/Resistor_SMD.3dshapes/R_1210_3225Metric.wrl"
      (scale (xyz 1 1 1))
  (footprint "Crystal:Crystal_C38-LF_D3.0mm_L8.0mm_Horizontal_1EP_style1" (layer "F.Cu")
    (tedit 5A0FD1B2) (tstamp c7d7d33c-c4dd-45b5-aaf0-7dc69f4df5b0)
    (at 26.731 50.716 180)
    (descr "Crystal THT C38-LF 8.0mm length 3.0mm diameter")
    (tags "['C38-LF']")
    (path "/e9c6361d-42e2-489f-8da3-c05e731a61d9")
    (attr through_hole)
    (fp_text reference "Y1" (at 4.252 0.17 90) (layer "F.SilkS")
      (tstamp 87ea8de7-bcdb-472f-87fe-63f2916dc810)
    (fp_text value "Crystal" (at 3.97 2.25 90) (layer "F.Fab")
      (tstamp 8bf7802a-cbf9-4a97-af4f-8d6b6361260a)
    (fp_text user "${REFERENCE}" (at 0.95 5.25) (layer "F.Fab")
      (effects (font (size 0.7 0.7) (thickness 0.105)))
      (tstamp 432bd202-76a1-41cb-90ce-001dd7e97602)
    (fp_line (start 1.9 1.15) (end 1.9 0.7) (layer "F.SilkS") (width 0.12) (tstamp 2d1c4ff0-7c24-46bc-bdee-ce0aa3c81b4a))
    (fp_line (start 1.495 2.3) (end 1.9 1.15) (layer "F.SilkS") (width 0.12) (tstamp 379d3a93-4dcc-4539-9bd4-7cb5fd0a44a7))
    (fp_line (start 0 1.15) (end 0 0.7) (layer "F.SilkS") (width 0.12) (tstamp 64c1d248-f08e-4fd1-9bf7-3e1c802f101f))
    (fp_line (start -0.75 2.8) (end -0.75 2.3) (layer "F.SilkS") (width 0.12) (tstamp 6df14895-4157-4a3e-8215-871b8dabe53c))
    (fp_line (start 2.65 2.3) (end 2.65 2.8) (layer "F.SilkS") (width 0.12) (tstamp ca23adea-15cc-4501-b9c7-4f108aeedd02))
    (fp_line (start 0.405 2.3) (end 0 1.15) (layer "F.SilkS") (width 0.12) (tstamp d0e1c4fc-6992-44f3-a618-7634bb3c43b6))
    (fp_line (start -0.75 2.3) (end 2.65 2.3) (layer "F.SilkS") (width 0.12) (tstamp d6be777e-882d-4c72-adde-265b4cb13e1f))
    (fp_line (start 3.2 11.3) (end 3.2 -0.8) (layer "F.CrtYd") (width 0.05) (tstamp 0d37ea1d-b963-4dd5-a8ba-01be7a4e7daf))
    (fp_line (start -1.3 11.3) (end 3.2 11.3) (layer "F.CrtYd") (width 0.05) (tstamp 81f260de-39a4-41f9-8a77-4011a8b9af41))
    (fp_line (start 3.2 -0.8) (end -1.3 -0.8) (layer "F.CrtYd") (width 0.05) (tstamp 909d5293-a4b7-4815-a6df-eff3900ce681))
    (fp_line (start -1.3 -0.8) (end -1.3 11.3) (layer "F.CrtYd") (width 0.05) (tstamp ddc7bc48-51c3-41c7-b174-01ca848950b6))
    (fp_line (start 2.45 10.5) (end 2.45 2.5) (layer "F.Fab") (width 0.1) (tstamp 0710e99a-be33-4dc6-ad2f-6f15e109702a))
    (fp_line (start 0 1.25) (end 0 0) (layer "F.Fab") (width 0.1) (tstamp 50c7f952-ca77-4663-bb71-7666a1a0c153))
    (fp_line (start 1.495 2.5) (end 1.9 1.25) (layer "F.Fab") (width 0.1) (tstamp 808d2d35-5a31-40ca-86b2-cd760ab58f67))
    (fp_line (start 2.45 2.5) (end -0.55 2.5) (layer "F.Fab") (width 0.1) (tstamp 9c532dae-16c8-4b0a-ab2e-2b7a2ce496be))
    (fp_line (start 0.405 2.5) (end 0 1.25) (layer "F.Fab") (width 0.1) (tstamp c7eee43a-342a-4237-8901-abcbc704727c))
    (fp_line (start -0.55 2.5) (end -0.55 10.5) (layer "F.Fab") (width 0.1) (tstamp cf701079-8960-4e2f-b3de-f1c26e94f190))
    (fp_line (start 1.9 1.25) (end 1.9 0) (layer "F.Fab") (width 0.1) (tstamp d31a7208-7ffc-4390-a82a-4be6e4412e4e))
    (fp_line (start -0.55 10.5) (end 2.45 10.5) (layer "F.Fab") (width 0.1) (tstamp e3fd5a5c-e106-4fc6-8cc2-6b1daa8be515))
    (pad "1" thru_hole circle (at 0 0 180) (size 1 1) (drill 0.5) (layers *.Cu *.Mask)
      (net 83 "Net-(U6-Pad2)") (pinfunction "1") (pintype "passive") (tstamp 480a5992-00fd-43ae-a235-3616477bd5b5))
    (pad "2" thru_hole circle (at 1.9 0 180) (size 1 1) (drill 0.5) (layers *.Cu *.Mask)
      (net 82 "Net-(U6-Pad1)") (pinfunction "2") (pintype "passive") (tstamp ea1991a9-b57f-441f-aa6b-d300f0101c84))
    (pad "3" smd rect (at 0.95 7 180) (size 3 8) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 1 "Net-(BT1-Pad2)") (tstamp e404d5fb-8e74-4bd1-b6ad-f2fd355b680c))
    (model "${KICAD6_3DMODEL_DIR}/Crystal.3dshapes/Crystal_C38-LF_D3.0mm_L8.0mm_Horizontal_1EP_style1.wrl"
      (scale (xyz 1 1 1))
  (footprint "Diode_SMD:D_SC-80_HandSoldering" (layer "F.Cu")
    (tedit 58A57D7F) (tstamp c80f7f68-ae05-448d-8a35-60dde1223de7)
    (at 70.739 125.222 90)
    (descr "JEITA SC-80")
    (tags "SC-80")
    (path "/3c62bd44-93a5-47f2-ac73-084a08bfb1e9")
    (attr smd)
    (fp_text reference "D16" (at -3.556 0 90) (layer "F.SilkS")
      (tstamp 6c016627-53d2-40e0-b7c0-cdb6d636654e)
    (fp_text value "SMD ZF 5,6" (at 0 1.6 90) (layer "F.Fab")
      (tstamp e67c6dba-34bf-41df-91e6-61cae6eb9634)
    (fp_text user "${REFERENCE}" (at 0 -1.5 90) (layer "F.Fab")
      (tstamp 271b31a9-b9e5-41df-91c2-ee38dab42b6e)
    (fp_line (start -1.8 -0.55) (end 0.7 -0.55) (layer "F.SilkS") (width 0.12) (tstamp 973a55c2-d4bb-45e2-ac4e-fa4c61df280f))
    (fp_line (start -1.8 0.55) (end 0.7 0.55) (layer "F.SilkS") (width 0.12) (tstamp ee04d59c-0773-4f4c-a46e-fb0a2b3f590d))
    (fp_line (start -1.8 -0.55) (end -1.8 0.55) (layer "F.SilkS") (width 0.12) (tstamp f273f597-53f4-4675-a629-6971d74ab981))
    (fp_line (start -1.9 0.7) (end -1.9 -0.7) (layer "F.CrtYd") (width 0.05) (tstamp 14dc90a4-27e3-4c6c-8f45-db93f89924e7))
    (fp_line (start 1.9 -0.7) (end -1.9 -0.7) (layer "F.CrtYd") (width 0.05) (tstamp 7d95ffca-8d26-4254-88a4-13a4c61dab43))
    (fp_line (start -1.9 0.7) (end 1.9 0.7) (layer "F.CrtYd") (width 0.05) (tstamp 8194dc4d-8e1b-4ca6-8e82-b62b955f7507))
    (fp_line (start 1.9 -0.7) (end 1.9 0.7) (layer "F.CrtYd") (width 0.05) (tstamp 8a366bfc-c0a0-4b33-a55c-139638e26a5f))
    (fp_line (start 0.65 0.4) (end -0.65 0.4) (layer "F.Fab") (width 0.1) (tstamp 0ec40325-8818-4f93-bccf-468c1a5cf1d1))
    (fp_line (start -0.2 0) (end 0.2 -0.225) (layer "F.Fab") (width 0.1) (tstamp 1733828f-cbd8-46ee-8c30-819d3f20498e))
    (fp_line (start 0.2 0) (end 0.45 0) (layer "F.Fab") (width 0.1) (tstamp 297879e9-40ea-4c4b-8887-90ab646e532d))
    (fp_line (start 0.2 -0.225) (end 0.2 0.225) (layer "F.Fab") (width 0.1) (tstamp 62ef7b14-fd0f-4c14-8a64-6164c61e6477))
    (fp_line (start -0.65 0.4) (end -0.65 -0.4) (layer "F.Fab") (width 0.1) (tstamp 6df5f9f1-4c6a-46c3-ba21-2ef10c9c3c40))
    (fp_line (start -0.2 -0.275) (end -0.2 0.275) (layer "F.Fab") (width 0.1) (tstamp 6e1d9230-64a5-43a3-b558-e8f23f407482))
    (fp_line (start -0.65 -0.4) (end 0.65 -0.4) (layer "F.Fab") (width 0.1) (tstamp 93cfee21-39bb-47ae-9f4f-025828d70d8f))
    (fp_line (start 0.2 0.225) (end -0.2 0) (layer "F.Fab") (width 0.1) (tstamp c7407891-41ec-4a2e-9bf1-f24e068618b2))
    (fp_line (start -0.2 0) (end -0.475 0) (layer "F.Fab") (width 0.1) (tstamp dd8246d3-07e0-4bfd-9de7-135c096b976b))
    (fp_line (start 0.65 -0.4) (end 0.65 0.4) (layer "F.Fab") (width 0.1) (tstamp f1e564f9-a298-448a-b723-705e808c1a3d))
    (pad "1" smd rect (at -1.1 0 90) (size 1.1 0.6) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 104 "Net-(D15-Pad2)") (pinfunction "K") (pintype "passive") (tstamp b3cfd909-55ff-41b6-8e6d-c77ba52bb8c9))
    (pad "2" smd rect (at 1.1 0 90) (size 1.1 0.6) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 105 "Net-(D16-Pad2)") (pinfunction "A") (pintype "passive") (tstamp e9a614fa-9fbf-4ca7-a3cd-391ef3477d3e))
    (model "${KICAD6_3DMODEL_DIR}/Diode_SMD.3dshapes/D_SC-80.wrl"
      (scale (xyz 1 1 1))
  (footprint "Capacitor_SMD:CP_Elec_6.3x7.7" (layer "F.Cu")
    (tedit 5BCA39D0) (tstamp c912e9a9-6515-4ae6-9d27-3d548015dc83)
    (at 62.738 88.646 90)
    (descr "SMD capacitor, aluminum electrolytic, Nichicon, 6.3x7.7mm")
    (tags "capacitor electrolytic")
    (path "/7b71f97e-c3c9-4fa4-be6a-2d4644dbf173")
    (attr smd)
    (fp_text reference "C21" (at 0 4.699 90) (layer "F.SilkS")
      (tstamp 2dc0093d-595d-4cc3-927a-97fc7d8eabcb)
    (fp_text value "150µ 10V ECC ZJ100151MF6" (at 0 4.35 90) (layer "F.Fab")
      (tstamp a94da07a-2ff6-415e-837f-1ce4e2c33178)
      (tstamp 536e2db9-70df-42ee-b37e-69e0c2c680f8)
    (fp_line (start 3.41 3.41) (end 3.41 1.06) (layer "F.SilkS") (width 0.12) (tstamp 02ba9c4f-106a-4b1f-be32-ce208bc1f877))
    (fp_line (start -4.04375 -2.24125) (end -4.04375 -1.45375) (layer "F.SilkS") (width 0.12) (tstamp 033f5b9d-c2d2-44ac-8611-3ca6fb287737))
    (fp_line (start -3.41 2.345563) (end -2.345563 3.41) (layer "F.SilkS") (width 0.12) (tstamp 120b9a39-70d7-457a-8540-ed22877f7d6a))
    (fp_line (start 3.41 -3.41) (end 3.41 -1.06) (layer "F.SilkS") (width 0.12) (tstamp 4c09a8a1-69dc-4f9a-9fdf-bf76523621e0))
    (fp_line (start -3.41 -2.345563) (end -3.41 -1.06) (layer "F.SilkS") (width 0.12) (tstamp 4fa8b091-6c5b-4931-bf99-f044fc50d4df))
    (fp_line (start -3.41 2.345563) (end -3.41 1.06) (layer "F.SilkS") (width 0.12) (tstamp 6698242c-06f0-467e-8c46-070c75a63c19))
    (fp_line (start -2.345563 3.41) (end 3.41 3.41) (layer "F.SilkS") (width 0.12) (tstamp 961fb272-1897-4178-878c-7cc189cefca9))
    (fp_line (start -2.345563 -3.41) (end 3.41 -3.41) (layer "F.SilkS") (width 0.12) (tstamp a66d6cf9-32cc-4b45-b474-19174971a673))
    (fp_line (start -4.4375 -1.8475) (end -3.65 -1.8475) (layer "F.SilkS") (width 0.12) (tstamp a8bb657f-1470-4370-ba0e-edfd23bfbfb5))
    (fp_line (start -3.41 -2.345563) (end -2.345563 -3.41) (layer "F.SilkS") (width 0.12) (tstamp c9998a32-a19d-49e3-9175-d452f2fb51b9))
    (fp_line (start -3.55 -2.4) (end -3.55 -1.05) (layer "F.CrtYd") (width 0.05) (tstamp 208ce6ed-be5c-4ee0-85cc-6a0e708f518f))
    (fp_line (start -3.55 2.4) (end -2.4 3.55) (layer "F.CrtYd") (width 0.05) (tstamp 45591c79-978a-4852-8fcb-7c200e822db4))
    (fp_line (start -4.7 1.05) (end -3.55 1.05) (layer "F.CrtYd") (width 0.05) (tstamp 484097ab-5cf6-4e66-b2ef-79fda1677b69))
    (fp_line (start -2.4 3.55) (end 3.55 3.55) (layer "F.CrtYd") (width 0.05) (tstamp 7c05228f-155e-4e02-b3d9-20cc5e8f7bdb))
    (fp_line (start -4.7 -1.05) (end -4.7 1.05) (layer "F.CrtYd") (width 0.05) (tstamp 882e090f-c8fb-46bb-a21c-26ad21aed441))
    (fp_line (start -2.4 -3.55) (end 3.55 -3.55) (layer "F.CrtYd") (width 0.05) (tstamp 8b9f25f9-f2a2-4bcc-95a9-f0aa2596cb83))
    (fp_line (start 3.55 -3.55) (end 3.55 -1.05) (layer "F.CrtYd") (width 0.05) (tstamp 8c9710e1-1e94-44fe-9d9d-8ecda5aa9c99))
    (fp_line (start -3.55 1.05) (end -3.55 2.4) (layer "F.CrtYd") (width 0.05) (tstamp b058d1fb-e082-43d6-b2af-29ae10f860ab))
    (fp_line (start 3.55 -1.05) (end 4.7 -1.05) (layer "F.CrtYd") (width 0.05) (tstamp b1d25ad1-935d-464c-a6e7-d3bdc52015af))
    (fp_line (start -3.55 -1.05) (end -4.7 -1.05) (layer "F.CrtYd") (width 0.05) (tstamp b398421f-67dc-4c73-aee6-8cc290a2da16))
    (fp_line (start 4.7 -1.05) (end 4.7 1.05) (layer "F.CrtYd") (width 0.05) (tstamp c645e2bd-323a-4166-8f8d-08464497d272))
    (fp_line (start 4.7 1.05) (end 3.55 1.05) (layer "F.CrtYd") (width 0.05) (tstamp d4244f0f-35e0-48a0-ac7a-4bd74c6a06c9))
    (fp_line (start -3.55 -2.4) (end -2.4 -3.55) (layer "F.CrtYd") (width 0.05) (tstamp df2d71e8-2e6c-4e21-9512-17f57257a6c6))
    (fp_line (start 3.55 1.05) (end 3.55 3.55) (layer "F.CrtYd") (width 0.05) (tstamp fc54c416-6095-42f0-a828-83c24f8ca318))
    (fp_line (start -2.704838 -1.33) (end -2.074838 -1.33) (layer "F.Fab") (width 0.1) (tstamp 111e3c4b-f11b-4137-a1df-20362f3d9f92))
    (fp_line (start 3.3 -3.3) (end 3.3 3.3) (layer "F.Fab") (width 0.1) (tstamp 21cf7bf3-1915-4a9d-9c96-b54930619b33))
    (fp_line (start -2.389838 -1.645) (end -2.389838 -1.015) (layer "F.Fab") (width 0.1) (tstamp 37a33324-3a91-4d81-a36b-ef62686d7d82))
    (fp_line (start -3.3 2.3) (end -2.3 3.3) (layer "F.Fab") (width 0.1) (tstamp 5b1f7a43-9025-4502-9bf6-59cc61544971))
    (fp_line (start -2.3 3.3) (end 3.3 3.3) (layer "F.Fab") (width 0.1) (tstamp 5e678f7e-ed3e-4789-b24e-b7c196152f19))
    (fp_line (start -3.3 -2.3) (end -3.3 2.3) (layer "F.Fab") (width 0.1) (tstamp 704c66e5-adca-4c02-a1d8-f1238b620bf4))
    (fp_line (start -3.3 -2.3) (end -2.3 -3.3) (layer "F.Fab") (width 0.1) (tstamp ce7f19be-30db-4a18-a1b1-db91c221bb4d))
    (fp_line (start -2.3 -3.3) (end 3.3 -3.3) (layer "F.Fab") (width 0.1) (tstamp f5d86023-df79-4141-a43b-2bb448deb2bb))
    (fp_circle (center 0 0) (end 3.15 0) (layer "F.Fab") (width 0.1) (fill none) (tstamp ab195a90-0a7a-4004-a2da-f52d4c716def))
    (pad "1" smd roundrect (at -2.7 0 90) (size 3.5 1.6) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.15625)
      (net 85 "Net-(C20-Pad1)") (pintype "passive") (tstamp 0c277a54-1314-4dd0-8ce5-a077f5eb4c9c))
    (pad "2" smd roundrect (at 2.7 0 90) (size 3.5 1.6) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.15625)
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp e40f5623-b991-428f-938f-c562cf413215))
    (model "${KICAD6_3DMODEL_DIR}/Capacitor_SMD.3dshapes/CP_Elec_6.3x7.7.wrl"
      (scale (xyz 1 1 1))
  (footprint "Capacitor_SMD:C_1206_3216Metric_Pad1.33x1.80mm_HandSolder" (layer "F.Cu")
    (tedit 5F68FEEF) (tstamp ca801df0-ba81-4d41-9981-62abe8a5b073)
    (at 98.171 64.516 -90)
    (descr "Capacitor SMD 1206 (3216 Metric), square (rectangular) end terminal, IPC_7351 nominal with elongated pad for handsoldering. (Body size source: IPC-SM-782 page 76, https://www.pcb-3d.com/wordpress/wp-content/uploads/ipc-sm-782a_amendment_1_and_2.pdf), generated with kicad-footprint-generator")
    (tags "capacitor handsolder")
    (path "/62426d97-4abf-4283-b501-845d6c73ff69")
    (attr smd)
    (fp_text reference "C4" (at 0 2.032 90) (layer "F.SilkS")
      (tstamp daae043e-fde2-4ef8-a9ce-8b5a56cb3dd7)
    (fp_text value "10u 50V KEM X5R1210 10U" (at 0 1.85 90) (layer "F.Fab")
      (tstamp ce154c91-c3ae-4fd3-ab55-1d50d412721f)
      (tstamp 9a554552-e146-4d30-9836-8252ee810f5c)
    (fp_line (start -0.711252 -0.91) (end 0.711252 -0.91) (layer "F.SilkS") (width 0.12) (tstamp 6b88e9bf-b6a5-48ad-8ef1-c5dc302bca79))
    (fp_line (start -0.711252 0.91) (end 0.711252 0.91) (layer "F.SilkS") (width 0.12) (tstamp cb08c7f3-4174-4695-a0ee-5ce0807c1f9a))
    (fp_line (start 2.48 -1.15) (end 2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp 3d8b9dcb-29a1-4007-afe4-c677985bf842))
    (fp_line (start -2.48 -1.15) (end 2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp 5d5db281-547f-465c-8010-cc8c1c4f93f1))
    (fp_line (start 2.48 1.15) (end -2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp 617b4fab-e107-4fb6-86c7-00f42535fa0a))
    (fp_line (start -2.48 1.15) (end -2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp debfa221-5082-4d32-9224-9b282f5d2df2))
    (fp_line (start -1.6 -0.8) (end 1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp 2bd4acba-b003-46a6-b82f-995ab8e0041b))
    (fp_line (start -1.6 0.8) (end -1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp ca74476a-5b54-4fd9-8703-5d1c7613cbe4))
    (fp_line (start 1.6 -0.8) (end 1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp ce127d90-183c-42f8-88d5-850238f12961))
    (fp_line (start 1.6 0.8) (end -1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp fb0dcc1a-0d81-401f-9b84-550ae0fa6727))
    (pad "1" smd roundrect (at -1.5625 0 270) (size 1.325 1.8) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1886792453)
      (net 15 "Net-(C3-Pad1)") (pintype "passive") (tstamp b78d07ae-5a61-4a48-a9fa-ee9975148035))
    (pad "2" smd roundrect (at 1.5625 0 270) (size 1.325 1.8) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1886792453)
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp ba28517a-1c0c-47d9-8a01-f684fea76a00))
    (model "${KICAD6_3DMODEL_DIR}/Capacitor_SMD.3dshapes/C_1206_3216Metric.wrl"
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp cd0d5a73-65b3-4d64-99dd-02bcb8604f76)
    (at 57.023 82.804)
    (path "/f818a637-b1f5-4a87-bbe4-98c6fd8aff56")
    (attr smd)
    (fp_text reference "R49" (at 3.377 0.996 90) (layer "F.SilkS")
      (effects (font (size 0.8 0.8) (thickness 0.15)))
      (tstamp 22d144d5-4b04-4300-acc7-c55931e87bc9)
    (fp_text value "SMD 1/4W 1k" (at 0 2.28) (layer "F.Fab")
      (tstamp ad7c63cb-d143-4cf2-ac16-9ff18cdde854)
    (fp_text user "${REFERENCE}" (at 0.127 0.127) (layer "F.Fab")
      (tstamp 334e218a-04fc-496f-8853-d96e3e551ddf)
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 9d81fb72-9b76-48a5-942d-f6d3d4a42358))
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp a66500e5-137c-46bd-9eba-9ecd0bfdb66b))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 2a62d8c2-262e-427b-aaea-eacf17897227))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp a9301d12-54ea-49c5-8e4b-5dd67b03c637))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp dbe05c7d-ed7a-484f-a13f-c0662b40dd02))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp efe31be8-df7a-4931-8e56-6d924e8822fc))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 267c0fc9-ab51-411a-88df-fc9407662788))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 2ee1cfb1-ea65-4755-8438-284922bc0ec1))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 531abdc4-de9e-4a07-9c2e-8f46ab0bf53a))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp d7727bda-0d1d-4f92-b649-5369c778c8a5))
    (pad "1" smd roundrect (at -1.55 0) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 78 "Net-(R49-Pad1)") (pintype "passive") (tstamp 3729e525-943e-4d8d-aa32-b7ccc8cac0d8))
    (pad "2" smd roundrect (at 1.55 0) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 31 "Net-(J14-Pad16)") (pintype "passive") (tstamp c4d425d1-94e9-44de-ac58-b7c499851738))
      (scale (xyz 1 1 1))
  (footprint "Fuse:Fuseholder_Cylinder-5x20mm_Schurter_0031_8201_Horizontal_Open" (layer "F.Cu")
    (tedit 5D717D34) (tstamp d0743deb-7a21-40b9-b3ff-8db64b138d85)
    (at 122.301 108.966 90)
    (descr "Fuseholder horizontal open, 5x20mm, 500V, 16A, Schurter 0031.8201, https://us.schurter.com/bundles/snceschurter/epim/_ProdPool_/newDS/en/typ_OGN.pdf")
    (tags "Fuseholder horizontal open 5x20 Schurter 0031.8201")
    (path "/b49d7b25-325b-49e1-97f8-c673715fec34")
    (attr through_hole)
    (fp_text reference "F4" (at 10.033 -5.842 90) (layer "F.SilkS")
      (tstamp 168ef210-b22d-459c-8461-29e866fabd27)
    (fp_text value "Fuse" (at 11.25 6 90) (layer "F.Fab")
      (tstamp 673c3c1d-82c1-4a26-ba27-3ba901c9d688)
    (fp_text user "${REFERENCE}" (at 11.25 4 90) (layer "F.Fab")
      (tstamp 1536fe92-6b5a-4409-a4b7-a3edc99dfc3c)
    (fp_line (start -0.11 4.91) (end 22.61 4.91) (layer "F.SilkS") (width 0.12) (tstamp 1bb9ad1e-5326-47ef-85f9-8d921348dbdc))
    (fp_line (start -0.11 -4.91) (end 22.61 -4.91) (layer "F.SilkS") (width 0.12) (tstamp 2649ce2f-7d41-4970-9353-c0d877e86a4e))
    (fp_line (start 22.61 4.91) (end 22.61 1.75) (layer "F.SilkS") (width 0.12) (tstamp 87c0158a-bb62-4762-b709-5a267c75e6e3))
    (fp_line (start -0.11 4.91) (end -0.11 1.75) (layer "F.SilkS") (width 0.12) (tstamp a6b6c300-ea3f-465b-b514-84f5de3252a0))
    (fp_line (start 22.61 -1.75) (end 22.61 -4.91) (layer "F.SilkS") (width 0.12) (tstamp c3b70b50-ae45-46c8-8f4e-92182cc0183d))
    (fp_line (start -0.11 -1.75) (end -0.11 -4.91) (layer "F.SilkS") (width 0.12) (tstamp de823774-c255-489e-b65f-7631fa8c17a1))
    (fp_line (start -1.75 5.05) (end -1.75 -5.05) (layer "F.CrtYd") (width 0.05) (tstamp 1833a2df-1ca9-4058-b91f-b7ec3d91d968))
    (fp_line (start 24.25 -5.05) (end 24.25 5.05) (layer "F.CrtYd") (width 0.05) (tstamp a5bdb9a9-0035-4a67-a1c9-1d3857eaff06))
    (fp_line (start 24.25 5.05) (end -1.75 5.05) (layer "F.CrtYd") (width 0.05) (tstamp de7923dc-70bd-4e38-9395-120dd2d53b73))
    (fp_line (start -1.75 -5.05) (end 24.25 -5.05) (layer "F.CrtYd") (width 0.05) (tstamp e5ee8418-9f8b-4ece-b423-4d9fd2c36d5b))
    (fp_line (start 22.5 4.8) (end 22.5 -4.8) (layer "F.Fab") (width 0.1) (tstamp 00f0b7c7-3af1-4895-b6d8-ce8416eaab44))
    (fp_line (start 0 4.8) (end 22.5 4.8) (layer "F.Fab") (width 0.1) (tstamp 3b650229-8ec8-4c75-b51e-e9667bfe77f7))
    (fp_line (start 0 -4.8) (end 0 4.8) (layer "F.Fab") (width 0.1) (tstamp c17994b8-0705-450a-8761-6afb4a0aac75))
    (fp_line (start 22.5 -4.8) (end 0 -4.8) (layer "F.Fab") (width 0.1) (tstamp fd609d79-72e9-4633-a1cb-841335a5c6e1))
    (pad "" np_thru_hole circle (at 11.25 0 90) (size 2.7 2.7) (drill 2.7) (layers *.Cu *.Mask) (tstamp 9560d7eb-532e-43b5-9a74-9af74cba6c52))
    (pad "1" thru_hole circle (at 0 0 90) (size 3 3) (drill 1.3) (layers *.Cu *.Mask)
      (net 104 "Net-(D15-Pad2)") (pintype "passive") (tstamp 6f11939b-6f8c-41f8-be01-45336dac8983))
    (pad "2" thru_hole circle (at 22.5 0 90) (size 3 3) (drill 1.3) (layers *.Cu *.Mask)
      (net 98 "Net-(F4-Pad2)") (pintype "passive") (tstamp aa3f1ec5-e00c-447b-a3c2-87a2ef947061))
    (model "${KICAD6_3DMODEL_DIR}/Fuse.3dshapes/Fuseholder_Cylinder-5x20mm_Schurter_0031_8201_Horizontal_Open.wrl"
      (scale (xyz 1 1 1))
  (footprint "Capacitor_SMD:CP_Elec_6.3x5.9" (layer "F.Cu")
    (tedit 5BCA39D0) (tstamp d44a8fae-e40b-4962-a1cd-3beaf97d4bc3)
    (at 31.891 22.606 -90)
    (descr "SMD capacitor, aluminum electrolytic, Panasonic C6, 6.3x5.9mm")
    (path "/9cef63f2-dee3-47cc-9918-0a0c9a54ee91")
    (attr smd)
    (fp_text reference "C12" (at -4.318 3.824 -90) (layer "F.SilkS")
      (tstamp 99a42ae4-8d33-4f56-be5c-30edcc0b23d6)
    (fp_text value "100µ 35V ECC ZA350101MF8" (at 0 4.35 90) (layer "F.Fab")
      (tstamp 8245bff5-30f5-4c66-a5f3-fa2f82c5ea83)
      (tstamp 8a866a9a-2f7d-454d-9128-6785fe59f558)
    (fp_line (start -2.345563 3.41) (end 3.41 3.41) (layer "F.SilkS") (width 0.12) (tstamp 0b605d61-0a4a-4d72-af38-d935df9709c8))
    (fp_line (start -4.04375 -2.24125) (end -4.04375 -1.45375) (layer "F.SilkS") (width 0.12) (tstamp 4699972e-fef2-4771-afdd-2aeaa19fde12))
    (fp_line (start 3.41 -3.41) (end 3.41 -1.06) (layer "F.SilkS") (width 0.12) (tstamp 5293194e-b98d-411c-8060-a52e940a2cef))
    (fp_line (start -3.41 2.345563) (end -3.41 1.06) (layer "F.SilkS") (width 0.12) (tstamp 5448d801-d675-4ec7-ae7f-134aec2a4427))
    (fp_line (start -3.41 2.345563) (end -2.345563 3.41) (layer "F.SilkS") (width 0.12) (tstamp 5ed6eaa8-c72f-4858-80e0-c451a092432f))
    (fp_line (start -4.4375 -1.8475) (end -3.65 -1.8475) (layer "F.SilkS") (width 0.12) (tstamp 79189880-eebb-4c8a-b1ae-0adb2bd74a88))
    (fp_line (start -2.345563 -3.41) (end 3.41 -3.41) (layer "F.SilkS") (width 0.12) (tstamp 9d1117e3-d7e9-4723-8586-273ae327a3c3))
    (fp_line (start -3.41 -2.345563) (end -3.41 -1.06) (layer "F.SilkS") (width 0.12) (tstamp b6fd4ad1-d691-44cd-82a5-901ebb2a0dfb))
    (fp_line (start 3.41 3.41) (end 3.41 1.06) (layer "F.SilkS") (width 0.12) (tstamp b9ec498a-1db7-4228-bdf3-4d372451ef69))
    (fp_line (start -3.41 -2.345563) (end -2.345563 -3.41) (layer "F.SilkS") (width 0.12) (tstamp d37df8f2-d0cd-4a80-a39a-92bf6fa16fb8))
    (fp_line (start 4.8 -1.05) (end 4.8 1.05) (layer "F.CrtYd") (width 0.05) (tstamp 0dd2adfb-00c5-4446-9548-6fa7f27ef3d6))
    (fp_line (start -3.55 -1.05) (end -4.8 -1.05) (layer "F.CrtYd") (width 0.05) (tstamp 2f1c8839-359b-4039-a86c-20101bc65baa))
    (fp_line (start -2.4 3.55) (end 3.55 3.55) (layer "F.CrtYd") (width 0.05) (tstamp 5085832c-1376-4549-9c33-c2e1fcde6180))
    (fp_line (start -3.55 1.05) (end -3.55 2.4) (layer "F.CrtYd") (width 0.05) (tstamp 5e39fbbb-3618-41ab-b008-00c986883e3c))
    (fp_line (start -3.55 2.4) (end -2.4 3.55) (layer "F.CrtYd") (width 0.05) (tstamp 88442131-dbaf-4656-b922-b2bbd7a7217a))
    (fp_line (start -3.55 -2.4) (end -3.55 -1.05) (layer "F.CrtYd") (width 0.05) (tstamp 887c76a3-86bf-4329-a780-42944eeba5e0))
    (fp_line (start -4.8 -1.05) (end -4.8 1.05) (layer "F.CrtYd") (width 0.05) (tstamp 9de1c9e4-7515-4c3f-b70b-d79506a130ed))
    (fp_line (start -4.8 1.05) (end -3.55 1.05) (layer "F.CrtYd") (width 0.05) (tstamp be739045-68a0-44aa-9d7e-d62e90259598))
    (fp_line (start 3.55 -3.55) (end 3.55 -1.05) (layer "F.CrtYd") (width 0.05) (tstamp cc97357b-cc71-4b17-a520-f574df3fc5e8))
    (fp_line (start 3.55 1.05) (end 3.55 3.55) (layer "F.CrtYd") (width 0.05) (tstamp ccc5fb59-d183-4746-a847-124359b15b39))
    (fp_line (start 4.8 1.05) (end 3.55 1.05) (layer "F.CrtYd") (width 0.05) (tstamp cfd848ed-0a89-40c3-8015-f89640eaceb0))
    (fp_line (start -2.4 -3.55) (end 3.55 -3.55) (layer "F.CrtYd") (width 0.05) (tstamp db74cf5c-8941-4f44-b81a-3359d07aa47b))
    (fp_line (start -3.55 -2.4) (end -2.4 -3.55) (layer "F.CrtYd") (width 0.05) (tstamp dba9eb83-5cfd-4af7-8838-827c3807e6aa))
    (fp_line (start 3.55 -1.05) (end 4.8 -1.05) (layer "F.CrtYd") (width 0.05) (tstamp fc1e1715-7b0e-4614-b4bf-ce2f7cea22dc))
    (fp_line (start -3.3 2.3) (end -2.3 3.3) (layer "F.Fab") (width 0.1) (tstamp 0641c39f-12e3-4f35-945e-559cec78e63c))
    (fp_line (start -2.389838 -1.645) (end -2.389838 -1.015) (layer "F.Fab") (width 0.1) (tstamp 30835a54-aed7-4d0e-8407-bc3ebf1260e9))
    (fp_line (start -3.3 -2.3) (end -3.3 2.3) (layer "F.Fab") (width 0.1) (tstamp 6d77ca97-3418-4dd1-8c6c-118d8d863a57))
    (fp_line (start -3.3 -2.3) (end -2.3 -3.3) (layer "F.Fab") (width 0.1) (tstamp 72cf50fe-4aa0-483c-b517-cfde6a6c599b))
    (fp_line (start -2.3 3.3) (end 3.3 3.3) (layer "F.Fab") (width 0.1) (tstamp 77629da3-0a27-4058-a12d-15d220e2513b))
    (fp_line (start -2.704838 -1.33) (end -2.074838 -1.33) (layer "F.Fab") (width 0.1) (tstamp a0e70c81-7e75-4ca1-9450-3b449ff86fd6))
    (fp_line (start 3.3 -3.3) (end 3.3 3.3) (layer "F.Fab") (width 0.1) (tstamp c93484e4-5bc4-4406-93b9-18f7274f7aa4))
    (fp_line (start -2.3 -3.3) (end 3.3 -3.3) (layer "F.Fab") (width 0.1) (tstamp dd9641bf-ea96-4785-a014-44eb23601434))
    (fp_circle (center 0 0) (end 3.15 0) (layer "F.Fab") (width 0.1) (fill none) (tstamp cad114d5-9767-480d-a43b-69d9d3be2453))
    (pad "1" smd roundrect (at -2.8 0 270) (size 3.5 1.6) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.15625)
      (net 9 "Net-(C12-Pad1)") (pintype "passive") (tstamp a0238c16-8023-4240-b71b-302d4fa5539b))
    (pad "2" smd roundrect (at 2.8 0 270) (size 3.5 1.6) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.15625)
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp e26d2921-3f06-4652-b1e4-ea729c8d29f5))
    (model "${KICAD6_3DMODEL_DIR}/Capacitor_SMD.3dshapes/CP_Elec_6.3x5.9.wrl"
      (scale (xyz 1 1 1))
  (footprint "Relay_THT:Relay_SPDT_Finder_40.61" (layer "F.Cu")
    (tedit 5A5B3E92) (tstamp d516ae98-1553-4267-bba0-c44b55774911)
    (at 96.6235 23.9785)
    (descr "Relay DPDT Finder 40.52, Pitch 5mm/7.5mm, https://www.finder-relais.net/de/finder-relais-serie-40.pdf")
    (tags "Relay DPDT Finder 40.52 Pitch 5mm")
    (path "/731c1931-3178-4d18-bf94-6dfba367df18")
    (attr through_hole)
    (fp_text reference "K3" (at 21.7405 -3.4625) (layer "F.SilkS")
      (tstamp af17e057-6be8-4670-bc8f-8f5c7d2df3eb)
    (fp_text value "FINDER-40.51" (at 12.192 11.43) (layer "F.Fab")
      (tstamp 74cffaa0-b0a3-4f1f-b0a5-d420e486b100)
    (fp_text user "${REFERENCE}" (at 12.065 3.81) (layer "F.Fab")
      (tstamp da8ca24e-a3c7-48ea-bf0b-3aa5b98f5f0b)
    (fp_line (start 2.54 1.27) (end 3.81 1.27) (layer "F.SilkS") (width 0.12) (tstamp 03c1ff72-07a3-4397-8e22-6f392be5051f))
    (fp_line (start 26.1 8.9) (end 26.1 10.1) (layer "F.SilkS") (width 0.12) (tstamp 0e544c83-ad87-49e4-8806-c03d01caa1c3))
    (fp_line (start 26.1 10.1) (end -3.1 10.1) (layer "F.SilkS") (width 0.12) (tstamp 1d71a11a-2acf-44bb-b82b-a2417c91ce68))
    (fp_line (start 3.81 7.62) (end 2.54 7.62) (layer "F.SilkS") (width 0.12) (tstamp 2f65d8f3-44ad-4db7-b26d-12039d182bec))
    (fp_line (start -3.3 -0.4) (end -3.3 -2.8) (layer "F.SilkS") (width 0.12) (tstamp 4253106a-ffc9-41da-be40-778666a8f905))
    (fp_line (start 5.08 1.27) (end 5.08 6.35) (layer "F.SilkS") (width 0.12) (tstamp 42e3d8d2-4cd6-413b-9af0-05d3594c86f9))
    (fp_line (start -3.1 10.1) (end -3.1 -2.6) (layer "F.SilkS") (width 0.12) (tstamp 63f316d1-2d43-43fc-9331-1446564ffe28))
    (fp_line (start 2.54 2.54) (end 5.08 3.81) (layer "F.SilkS") (width 0.12) (tstamp 88379e1e-35be-4363-9c73-120de4c42db2))
    (fp_line (start 26.1 -2.6) (end 26.1 -1.4) (layer "F.SilkS") (width 0.12) (tstamp 9159ee8e-2334-4bb4-887c-d8a880c043c9))
    (fp_line (start 3.81 6.35) (end 3.81 7.62) (layer "F.SilkS") (width 0.12) (tstamp 91bbb849-07f0-4260-941d-5dd88bfd766c))
    (fp_line (start 3.81 1.27) (end 5.08 1.27) (layer "F.SilkS") (width 0.12) (tstamp 9271c5df-b853-487e-b2e9-dc32ef55ec25))
    (fp_line (start 2.54 0) (end 3.81 0) (layer "F.SilkS") (width 0.12) (tstamp a5b11458-af10-4cdf-bb68-2c8f0da6d1d4))
    (fp_line (start 5.08 6.35) (end 2.54 6.35) (layer "F.SilkS") (width 0.12) (tstamp aa441004-97a0-4854-8079-f2e2b8baed8a))
    (fp_line (start 3.81 0) (end 3.81 1.27) (layer "F.SilkS") (width 0.12) (tstamp aeaba60e-e838-4d64-b635-cb723e0db18f))
    (fp_line (start 2.54 6.35) (end 2.54 1.27) (layer "F.SilkS") (width 0.12) (tstamp cba21921-5347-425d-9b3b-8f00334c2b6f))
    (fp_line (start 26.1 1.4) (end 26.1 6.1) (layer "F.SilkS") (width 0.12) (tstamp cd648194-34e9-4443-8fd0-327133fd6da5))
    (fp_line (start -3.1 -2.6) (end 26.1 -2.6) (layer "F.SilkS") (width 0.12) (tstamp e1b27746-5ca5-468b-bf96-b213a9688e0f))
    (fp_line (start -0.9 -2.8) (end -3.3 -2.8) (layer "F.SilkS") (width 0.12) (tstamp f6815f18-047f-4a87-9238-4ce8a0a0a0f4))
    (fp_line (start -3.25 -2.75) (end 26.75 -2.75) (layer "F.CrtYd") (width 0.05) (tstamp 335380a4-a9c1-406a-ab0a-a2103e091f41))
    (fp_line (start 26.75 10.25) (end -3.25 10.25) (layer "F.CrtYd") (width 0.05) (tstamp 3fedc03e-d234-448e-9fde-867b8ff58b84))
    (fp_line (start -3.25 -2.75) (end -3.25 10.25) (layer "F.CrtYd") (width 0.05) (tstamp 6e57e4d9-18a5-468f-ad5b-839ea59cb721))
    (fp_line (start 26.75 10.25) (end 26.75 -2.75) (layer "F.CrtYd") (width 0.05) (tstamp b5917539-9663-4c8f-b706-344078d30b05))
    (fp_line (start -2 -2.5) (end -3 -1.4) (layer "F.Fab") (width 0.12) (tstamp 618ed347-2bb1-4db2-bfcc-1e269fc30e6b))
    (fp_line (start -3 10) (end 26 10) (layer "F.Fab") (width 0.12) (tstamp 6f6a3183-187f-4e5d-bd9e-36f88a455cd2))
    (fp_line (start -3 -1.4) (end -3 10) (layer "F.Fab") (width 0.12) (tstamp 8025a67f-098c-4f22-b269-e3908d25be59))
    (fp_line (start 26 -2.5) (end -2 -2.5) (layer "F.Fab") (width 0.12) (tstamp a4ac852b-717a-4a9b-a4f2-a2a80a9f3a19))
    (fp_line (start 0 1.8) (end 0 5.8) (layer "F.Fab") (width 0.12) (tstamp a98a46cf-bb5e-4428-8c52-a1437f9cd337))
    (fp_line (start 26 10) (end 26 -2.5) (layer "F.Fab") (width 0.12) (tstamp d833635b-688c-4721-868d-c620379452bb))
    (pad "11" thru_hole circle (at 20 7.5) (size 3 3) (drill 1.5) (layers *.Cu *.Mask)
      (net 15 "Net-(C3-Pad1)") (pintype "passive") (tstamp 2cc5bfa6-0473-453f-a117-4527051dafa8))
    (pad "11" thru_hole circle (at 20 0) (size 3 3) (drill 1.5) (layers *.Cu *.Mask)
      (net 15 "Net-(C3-Pad1)") (pintype "passive") (tstamp a6b52173-ab97-429d-9437-7b6653a0940c))
    (pad "12" thru_hole circle (at 15 7.5) (size 3 3) (drill 1.5) (layers *.Cu *.Mask)
      (net 99 "unconnected-(K3-Pad12)") (pintype "passive") (tstamp 2acdaca1-8d72-48d3-8801-b3027c9e2675))
    (pad "12" thru_hole circle (at 15 0) (size 3 3) (drill 1.5) (layers *.Cu *.Mask)
      (net 99 "unconnected-(K3-Pad12)") (pintype "passive") (tstamp 2fb328c9-957b-432a-a6e6-e62414da2d0c))
    (pad "14" thru_hole circle (at 25 7.5) (size 3 3) (drill 1.5) (layers *.Cu *.Mask)
      (net 44 "Net-(C11-Pad1)") (pintype "passive") (tstamp 49f08081-692b-47e3-b3ee-b6c9b257c683))
    (pad "14" thru_hole circle (at 25 0) (size 3 3) (drill 1.5) (layers *.Cu *.Mask)
      (net 44 "Net-(C11-Pad1)") (pintype "passive") (tstamp 6a42878e-7b54-4b3c-a86d-2db2d74529f5))
    (pad "A1" thru_hole rect (at 0 0) (size 3 3) (drill 1.5) (layers *.Cu *.Mask)
      (net 87 "Net-(D11-Pad1)") (pintype "passive") (tstamp 4d694f6e-45df-42c0-9a7f-339bfabe675b))
    (pad "A2" thru_hole circle (at 0 7.5) (size 3 3) (drill 1.5) (layers *.Cu *.Mask)
      (net 88 "Net-(D11-Pad2)") (pintype "passive") (tstamp 29d36b0e-62f7-4584-b157-ec49c37f8736))
    (model "${KICAD6_3DMODEL_DIR}/Relay_THT.3dshapes/Relay_DPDT_Finder_40.52.wrl"
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp d5591094-7d87-43e4-8fd5-17f9f1841e6e)
    (at 37.973 107.931 -90)
    (path "/f51ed81c-236d-43fe-9388-2487cd5ebfc7")
    (attr smd)
    (fp_text reference "R41" (at 3.9306 -0.127 90) (layer "F.SilkS")
      (tstamp 650fa1ca-89b8-4d67-b983-5ef3dc7b95e4)
      (tstamp efc8dca8-3cff-4a76-83ab-90a077f9551d)
      (tstamp cebf079d-8cf9-4dad-9b41-444b71032a31)
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 031154a9-4a3b-4cdf-a430-5fdcde28e00f))
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp fb4a19f0-9e93-40fd-b5e7-96ea43f28ad1))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 27e28117-7faf-43b9-af3c-0a308168ca97))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 750ad41d-e321-426b-91e0-d0cbe8ed4b5a))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 83e2ab7c-7453-493c-8322-09f1a79eea8b))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp d0fb4691-ce0b-4896-949b-0f910ba9f097))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 05d8a71c-9000-4c6f-89ba-f3dd1b854e96))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 16f0e2c9-1f67-45d3-8d51-ebd737e45ee9))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 73642380-cf82-4df3-99cd-a25ccb747a78))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 9272cff0-458e-4e98-b439-910305b9b159))
    (pad "1" smd roundrect (at -1.55 0 270) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 70 "Net-(R41-Pad1)") (pintype "passive") (tstamp 5586157d-69ec-4854-8356-d5bb9cdf66d2))
    (pad "2" smd roundrect (at 1.55 0 270) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 112 "Net-(R41-Pad2)") (pintype "passive") (tstamp c1114e87-8e0b-4745-926b-a5ac8c5fe91a))
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp d6c5d9ca-305a-4a3a-8640-f25603d48126)
    (at 31.877 43.307)
    (path "/61c415d0-ddd4-4fc9-8d4c-5c241ac4fe59")
    (attr smd)
    (fp_text reference "R19" (at -3.175 0 90) (layer "F.SilkS")
      (tstamp d84297a5-a018-48f8-9958-a46a6ad36e2e)
    (fp_text value "SMD 1/4W 22k" (at 0 2.28) (layer "F.Fab")
      (tstamp 88f95492-9fe3-4dae-8637-034e66c20fa4)
    (fp_text user "${REFERENCE}" (at 0 0) (layer "F.Fab")
      (tstamp 089cce66-9b70-453c-a67a-49958bffc672)
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp 161b1e13-48de-40c8-a30d-5a1e3d2f64e5))
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp d32e45cc-5e0c-4c46-ac43-85bcb65e07c3))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 6faae213-c9bf-4509-8507-802088b75bd6))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp c95eec3c-e1f8-4df7-a9df-e74a110f0e80))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp e2149ce0-087b-455a-8d63-45477c235f3c))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp e74d6d35-3d7c-45f4-8657-0a5599af5798))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 21955800-4f64-48b3-be46-ccc5316b2f77))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 2b7ba72f-17dc-4cc3-a0f7-a17df9e9844d))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 92b736a0-13d8-40e7-a792-c2f1a96a0e02))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp f6e9f63d-833e-4d03-8b61-f743463edaae))
      (net 10 "Net-(C14-Pad1)") (pintype "passive") (tstamp 3964b347-8e48-4632-820e-2d2f1f5d674f))
      (net 42 "Net-(Q3-Pad2)") (pintype "passive") (tstamp c9ebe25a-adca-460e-959a-c25c3bfffd0c))
      (scale (xyz 1 1 1))
  (footprint "Connector_IDC:IDC-Header_2x10_P2.54mm_Vertical" (layer "F.Cu")
    (tedit 5EAC9A07) (tstamp d94aa074-b129-443b-bf9a-6cc65153d53d)
    (at 84.201 158.3785 -90)
    (descr "Through hole IDC box header, 2x10, 2.54mm pitch, DIN 41651 / IEC 60603-13, double rows, https://docs.google.com/spreadsheets/d/16SsEcesNF15N3Lb4niX7dcUr-NY5_MFPQhobNuNppn4/edit#gid=0")
    (tags "Through hole vertical IDC box header THT 2x10 2.54mm double row")
    (path "/4c50002d-46f6-4705-8728-b086a666f703")
    (attr through_hole)
    (fp_text reference "J14" (at 0.8795 29.464 90) (layer "F.SilkS")
      (tstamp ec0ca60d-5255-4255-80d5-be05fd23f5fd)
    (fp_text value "Data Out" (at 1.27 28.96 90) (layer "F.Fab")
      (tstamp 262da0c6-4b1b-4fd3-9598-996188cc395b)
    (fp_text user "${REFERENCE}" (at 1.27 11.43) (layer "F.Fab")
      (tstamp 2c1b4fc7-d402-4f4a-a63a-d6dac24e1ea6)
    (fp_line (start 5.83 28.07) (end -3.29 28.07) (layer "F.SilkS") (width 0.12) (tstamp 0585f94b-dffd-4822-9990-e5783dcb1aee))
    (fp_line (start -1.98 13.48) (end -1.98 13.48) (layer "F.SilkS") (width 0.12) (tstamp 15a04d8e-60f0-49ba-8107-bd5a6a037a20))
    (fp_line (start -3.29 28.07) (end -3.29 -5.21) (layer "F.SilkS") (width 0.12) (tstamp 3bcf617f-5c3e-493e-804e-aa8fce5b001b))
    (fp_line (start -1.98 -3.91) (end 4.52 -3.91) (layer "F.SilkS") (width 0.12) (tstamp 551b7252-8b7a-4590-b3ee-c7aefce66ebf))
    (fp_line (start -1.98 13.48) (end -3.29 13.48) (layer "F.SilkS") (width 0.12) (tstamp 6dce6604-22cf-4c29-a107-b970ecd8b398))
    (fp_line (start -1.98 9.38) (end -1.98 -3.91) (layer "F.SilkS") (width 0.12) (tstamp 727a9d42-0c4b-4cd8-b9ca-606a700ca7df))
    (fp_line (start -3.29 -5.21) (end 5.83 -5.21) (layer "F.SilkS") (width 0.12) (tstamp 7a039d95-ab73-45a8-901c-e566c4124590))
    (fp_line (start -4.68 0.5) (end -3.68 0) (layer "F.SilkS") (width 0.12) (tstamp 8ca7b732-acdf-4872-92ff-dc1a052c6df6))
    (fp_line (start 4.52 26.77) (end -1.98 26.77) (layer "F.SilkS") (width 0.12) (tstamp a2258aba-22fd-4622-9fb8-078419f42b32))
    (fp_line (start 5.83 -5.21) (end 5.83 28.07) (layer "F.SilkS") (width 0.12) (tstamp b83eab8a-6477-4401-b38e-37ddb2e5d5de))
    (fp_line (start -3.68 0) (end -4.68 -0.5) (layer "F.SilkS") (width 0.12) (tstamp b954b64d-d83f-46d2-b40e-e8ba65f57dd2))
    (fp_line (start 4.52 -3.91) (end 4.52 26.77) (layer "F.SilkS") (width 0.12) (tstamp e8d416f2-c29f-4de9-b765-6c136bdbb982))
    (fp_line (start -3.29 9.38) (end -1.98 9.38) (layer "F.SilkS") (width 0.12) (tstamp ec5be47f-c251-43ce-9248-6921c572a507))
    (fp_line (start -1.98 26.77) (end -1.98 13.48) (layer "F.SilkS") (width 0.12) (tstamp f5aa41d2-1729-445c-979c-d55a31fea4d3))
    (fp_line (start -4.68 -0.5) (end -4.68 0.5) (layer "F.SilkS") (width 0.12) (tstamp f684c8a3-cf97-4901-b47a-fb960824070a))
    (fp_line (start 6.22 28.46) (end 6.22 -5.6) (layer "F.CrtYd") (width 0.05) (tstamp 0da82c8f-8013-41c7-8e39-3b4bdda30d3d))
    (fp_line (start 6.22 -5.6) (end -3.68 -5.6) (layer "F.CrtYd") (width 0.05) (tstamp 5bb272ad-2d71-4a7f-bf4a-d45831ece8be))
    (fp_line (start -3.68 28.46) (end 6.22 28.46) (layer "F.CrtYd") (width 0.05) (tstamp a550ca6a-8ea2-47c2-aebd-69f85bf83c58))
    (fp_line (start -3.68 -5.6) (end -3.68 28.46) (layer "F.CrtYd") (width 0.05) (tstamp d00ef627-7cb2-4e3b-99db-88399771ce40))
    (fp_line (start -3.18 9.38) (end -1.98 9.38) (layer "F.Fab") (width 0.1) (tstamp 0c900268-4538-4e5b-9228-210abca51721))
    (fp_line (start -1.98 13.48) (end -1.98 13.48) (layer "F.Fab") (width 0.1) (tstamp 3af8ea8e-7535-460e-b7b2-8de2dbd47257))
    (fp_line (start -1.98 26.77) (end -1.98 13.48) (layer "F.Fab") (width 0.1) (tstamp 41e4946a-e85e-4c1a-a1e7-847eafe3f44c))
    (fp_line (start -1.98 9.38) (end -1.98 -3.91) (layer "F.Fab") (width 0.1) (tstamp 49ddcf51-9f7c-429b-9f59-0151fcf489f4))
    (fp_line (start -1.98 13.48) (end -3.18 13.48) (layer "F.Fab") (width 0.1) (tstamp 97b87e7b-0f2f-4c7a-b547-2db8ba90f91b))
    (fp_line (start 5.72 27.96) (end -3.18 27.96) (layer "F.Fab") (width 0.1) (tstamp 998e445e-9e70-450e-935d-b8213d53df64))
    (fp_line (start 4.52 26.77) (end -1.98 26.77) (layer "F.Fab") (width 0.1) (tstamp aa1f83e3-7eab-4099-8eab-4f27be2bc141))
    (fp_line (start -1.98 -3.91) (end 4.52 -3.91) (layer "F.Fab") (width 0.1) (tstamp b0dc321d-05cb-4ec6-af36-5c048f243147))
    (fp_line (start 4.52 -3.91) (end 4.52 26.77) (layer "F.Fab") (width 0.1) (tstamp bbba7337-30fa-4525-9356-6a662d4916d6))
    (fp_line (start -3.18 -4.1) (end -2.18 -5.1) (layer "F.Fab") (width 0.1) (tstamp d68d7a5f-719e-4aa9-9f83-0900fc8957ab))
    (fp_line (start -2.18 -5.1) (end 5.72 -5.1) (layer "F.Fab") (width 0.1) (tstamp d75375db-e48a-48a6-b884-cc2a99273247))
    (fp_line (start -3.18 27.96) (end -3.18 -4.1) (layer "F.Fab") (width 0.1) (tstamp db90976c-5a4a-4f3f-ab57-485188e44742))
    (fp_line (start 5.72 -5.1) (end 5.72 27.96) (layer "F.Fab") (width 0.1) (tstamp f189043d-57c2-4404-8610-1434da4d05be))
    (pad "1" thru_hole roundrect (at 0 0 270) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask) (roundrect_rratio 0.1470588235)
      (net 85 "Net-(C20-Pad1)") (pinfunction "Pin_1") (pintype "passive") (tstamp ddc85245-9245-4fab-aaf1-82ff91fdf506))
    (pad "2" thru_hole circle (at 2.54 0 270) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 85 "Net-(C20-Pad1)") (pinfunction "Pin_2") (pintype "passive") (tstamp 85ff41f9-429a-4971-8fa3-44b5e4d4e6f6))
    (pad "3" thru_hole circle (at 0 2.54 270) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 85 "Net-(C20-Pad1)") (pinfunction "Pin_3") (pintype "passive") (tstamp 593b580a-0c19-4243-a4fb-81f861d25006))
    (pad "4" thru_hole circle (at 2.54 2.54 270) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 85 "Net-(C20-Pad1)") (pinfunction "Pin_4") (pintype "passive") (tstamp cec11496-1d8f-4055-80ce-83befda17829))
    (pad "5" thru_hole circle (at 0 5.08 270) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 85 "Net-(C20-Pad1)") (pinfunction "Pin_5") (pintype "passive") (tstamp f551b956-95e3-49aa-9624-d4adeffa061b))
    (pad "6" thru_hole circle (at 2.54 5.08 270) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 85 "Net-(C20-Pad1)") (pinfunction "Pin_6") (pintype "passive") (tstamp 842b1564-54a1-4a49-9733-89dc27b710ec))
    (pad "7" thru_hole circle (at 0 7.62 270) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 1 "Net-(BT1-Pad2)") (pinfunction "Pin_7") (pintype "passive") (tstamp 0dbe007c-6280-4c5e-bfcb-424110bf5e03))
    (pad "8" thru_hole circle (at 2.54 7.62 270) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 1 "Net-(BT1-Pad2)") (pinfunction "Pin_8") (pintype "passive") (tstamp 9a2e9516-1ab2-41d9-acda-1babb2ab8d89))
    (pad "9" thru_hole circle (at 0 10.16 270) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 1 "Net-(BT1-Pad2)") (pinfunction "Pin_9") (pintype "passive") (tstamp b872b92c-f250-459b-93ac-a364dd9b2ca1))
    (pad "10" thru_hole circle (at 2.54 10.16 270) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 1 "Net-(BT1-Pad2)") (pinfunction "Pin_10") (pintype "passive") (tstamp 5a512e63-ae05-48e2-a7aa-5a41412a7a0b))
    (pad "11" thru_hole circle (at 0 12.7 270) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 1 "Net-(BT1-Pad2)") (pinfunction "Pin_11") (pintype "passive") (tstamp 1d067ae0-b5e2-4941-bb67-cc87ae000e07))
    (pad "12" thru_hole circle (at 2.54 12.7 270) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 1 "Net-(BT1-Pad2)") (pinfunction "Pin_12") (pintype "passive") (tstamp 6d593bf6-aca2-4c2a-8b90-e36a9e49f48d))
    (pad "13" thru_hole circle (at 0 15.24 270) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 28 "Net-(J14-Pad13)") (pinfunction "Pin_13") (pintype "passive") (tstamp 3a4c8f67-91ac-49fc-80aa-8fe78119a513))
    (pad "14" thru_hole circle (at 2.54 15.24 270) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 29 "Net-(J14-Pad14)") (pinfunction "Pin_14") (pintype "passive") (tstamp ed31eea7-683c-422e-ad36-cf4ecfb3d661))
    (pad "15" thru_hole circle (at 0 17.78 270) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 30 "Net-(J14-Pad15)") (pinfunction "Pin_15") (pintype "passive") (tstamp 31c07664-d184-4bac-91ac-85b65a01aae1))
    (pad "16" thru_hole circle (at 2.54 17.78 270) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 31 "Net-(J14-Pad16)") (pinfunction "Pin_16") (pintype "passive") (tstamp 8013effe-dc1c-4914-a88c-4e5de2f6a15d))
    (pad "17" thru_hole circle (at 0 20.32 270) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 32 "Net-(J14-Pad17)") (pinfunction "Pin_17") (pintype "passive") (tstamp 8a9cb02c-6bb7-47ca-9c40-483907e70122))
    (pad "18" thru_hole circle (at 2.54 20.32 270) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 119 "Net-(J14-Pad18)") (pinfunction "Pin_18") (pintype "passive") (tstamp d37bf0ca-3203-44e2-8f2e-91ca1ad6bc2d))
    (pad "19" thru_hole circle (at 0 22.86 270) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 33 "Net-(J14-Pad19)") (pinfunction "Pin_19") (pintype "passive") (tstamp 2d68c352-aec6-47bf-acb2-f4205e83883b))
    (pad "20" thru_hole circle (at 2.54 22.86 270) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask)
      (net 34 "Net-(J14-Pad20)") (pinfunction "Pin_20") (pintype "passive") (tstamp 9357d81d-801e-4d00-8960-3c62540acdfe))
    (model "${KICAD6_3DMODEL_DIR}/Connector_IDC.3dshapes/IDC-Header_2x10_P2.54mm_Vertical.wrl"
      (scale (xyz 1 1 1))
  (footprint "Package_TO_SOT_THT:TO-220-3_Vertical" (layer "F.Cu")
    (tedit 5AC8BA0D) (tstamp da066674-fadd-4790-8352-7cb791636cd3)
    (at 78.796 127.762 90)
    (descr "TO-220-3, Vertical, RM 2.54mm, see https://www.vishay.com/docs/66542/to-220-1.pdf")
    (tags "TO-220-3 Vertical RM 2.54mm")
    (path "/83e32d63-93aa-4730-8976-5d575b055aea")
    (attr through_hole)
    (fp_text reference "D15" (at 2.54 2.357 90) (layer "F.SilkS")
      (tstamp c87e1536-1e78-423d-a997-61fda33d40ef)
    (fp_text value "FS 1610DH" (at 2.54 2.5 90) (layer "F.Fab")
      (tstamp e138a9cd-a891-4f90-8926-b427a4f8bdaf)
    (fp_text user "${REFERENCE}" (at 2.54 -4.27 90) (layer "F.Fab")
      (tstamp 66259482-82b4-4d91-b435-320df04564fd)
    (fp_line (start -2.58 -3.27) (end 7.66 -3.27) (layer "F.SilkS") (width 0.12) (tstamp 1a7786b7-53e8-4011-b34e-272e18e31523))
    (fp_line (start -2.58 1.371) (end 7.66 1.371) (layer "F.SilkS") (width 0.12) (tstamp 38f700ca-21b7-4792-aed7-b713da94d1d0))
    (fp_line (start -2.58 -1.76) (end 7.66 -1.76) (layer "F.SilkS") (width 0.12) (tstamp 48a184f5-78d8-4bd5-ae7d-cc1f9a19351b))
    (fp_line (start 4.391 -3.27) (end 4.391 -1.76) (layer "F.SilkS") (width 0.12) (tstamp 4d74e05d-b345-4b40-8725-f47d5e6ebf3a))
    (fp_line (start 0.69 -3.27) (end 0.69 -1.76) (layer "F.SilkS") (width 0.12) (tstamp 935ece2b-a53e-4790-9712-18e3aae63c3e))
    (fp_line (start -2.58 -3.27) (end -2.58 1.371) (layer "F.SilkS") (width 0.12) (tstamp f1921635-7785-40df-9096-372bc3e3331a))
    (fp_line (start 7.66 -3.27) (end 7.66 1.371) (layer "F.SilkS") (width 0.12) (tstamp fd248798-0319-4e6a-86ea-e5788395f133))
    (fp_line (start 7.79 1.51) (end 7.79 -3.4) (layer "F.CrtYd") (width 0.05) (tstamp 0edc1d2c-b315-4637-bf41-97cc7dbac592))
    (fp_line (start 7.79 -3.4) (end -2.71 -3.4) (layer "F.CrtYd") (width 0.05) (tstamp 56b8c96b-41ba-4097-8537-ceae1e534bf1))
    (fp_line (start -2.71 1.51) (end 7.79 1.51) (layer "F.CrtYd") (width 0.05) (tstamp 79063f49-e0f9-4492-8e89-8629be9e08fb))
    (fp_line (start -2.71 -3.4) (end -2.71 1.51) (layer "F.CrtYd") (width 0.05) (tstamp f612e1e4-3c49-443a-9591-0ee1349698ad))
    (fp_line (start -2.46 -3.15) (end -2.46 1.25) (layer "F.Fab") (width 0.1) (tstamp 39fa7b25-b5d0-423c-95b2-6e6d1adf7ee9))
    (fp_line (start 7.54 -3.15) (end -2.46 -3.15) (layer "F.Fab") (width 0.1) (tstamp 4e689b21-e5c0-43f0-879f-796647b85190))
    (fp_line (start 0.69 -3.15) (end 0.69 -1.88) (layer "F.Fab") (width 0.1) (tstamp 541b1f8b-6676-4745-b68a-023237627e5d))
    (fp_line (start -2.46 -1.88) (end 7.54 -1.88) (layer "F.Fab") (width 0.1) (tstamp 6006797c-03f1-4ed6-94c5-afeaf1bb3598))
    (fp_line (start 4.39 -3.15) (end 4.39 -1.88) (layer "F.Fab") (width 0.1) (tstamp 93d99efe-63fd-48d0-a9d7-c9ae6d9ff715))
    (fp_line (start 7.54 1.25) (end 7.54 -3.15) (layer "F.Fab") (width 0.1) (tstamp 9a88b870-3d33-4af1-9826-ee8645bc4166))
    (fp_line (start -2.46 1.25) (end 7.54 1.25) (layer "F.Fab") (width 0.1) (tstamp aaf2dbaf-41bf-405f-b656-af6311d88e54))
    (pad "1" thru_hole rect (at 0 0 90) (size 1.905 2) (drill 1.1) (layers *.Cu *.Mask)
      (net 1 "Net-(BT1-Pad2)") (pinfunction "K") (pintype "passive") (tstamp cc285f00-a666-462c-96d1-673d3403727a))
    (pad "2" thru_hole oval (at 2.54 0 90) (size 1.905 2) (drill 1.1) (layers *.Cu *.Mask)
      (net 104 "Net-(D15-Pad2)") (pinfunction "A") (pintype "passive") (tstamp 35f78f69-6607-4887-b934-0fe87abf8ca0))
    (pad "3" thru_hole oval (at 5.08 0 90) (size 1.905 2) (drill 1.1) (layers *.Cu *.Mask)
      (net 97 "Net-(C36-Pad1)") (pinfunction "G") (pintype "input") (tstamp 3b36eafe-3ef1-4119-a54a-e1653f55fd7b))
    (model "${KICAD6_3DMODEL_DIR}/Package_TO_SOT_THT.3dshapes/TO-220-3_Vertical.wrl"
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp dab8d38e-f8c3-4fad-832d-13ad874422bf)
    (at 53.721 116.332)
    (path "/97133c9a-1832-4602-9f91-c0ac29af28ba")
    (attr smd)
    (fp_text reference "R28" (at 3.302 0 90) (layer "F.SilkS")
      (tstamp 377fb1d5-826f-4396-8592-eec4da420543)
      (tstamp ef00f782-c317-4d96-9866-a82045c8779c)
      (tstamp d5203d76-08dd-4304-a5a0-9fe1f9b5e0c3)
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp 93172b08-a29d-4a3e-858f-de5dabbbfbf6))
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp e61dff59-c91d-4c8e-85c2-13c97facc40d))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 5b99c2cf-aa37-4b99-a43b-942edfae7603))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 94d36ad3-9459-42de-a238-340f78d76c9f))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp abba54e0-c43f-4b32-bd9e-eed1921e4657))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp b5ead1e8-22ca-410d-9abd-c9af72f1015d))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 36b81cc2-977d-4e84-8387-fe3b0abf69a1))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 5b503ca0-c004-42e5-98dc-fa41c038d96a))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp a5780a5b-a2d5-400f-bfaf-3b96f4d26d3c))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp e002442c-b8ed-43a4-b074-ad931885f1ff))
      (net 59 "Net-(R28-Pad1)") (pintype "passive") (tstamp 33fefa0f-e665-491f-9505-53a3cd53e793))
      (net 108 "Net-(R28-Pad2)") (pintype "passive") (tstamp fc9ffcdb-ac24-4d57-9fc7-6c0da5b8193f))
      (scale (xyz 1 1 1))
  (footprint "Battery:KHZ 20PCB-V CR2032" (layer "F.Cu")
    (tedit 0) (tstamp dd397a7c-439c-4eaf-815c-d89011977b6e)
    (at 30.7145 28.086 -90)
    (path "/263c264e-1a7f-4dfc-8f20-a98f0e3119e5")
    (attr through_hole)
    (fp_text reference "BT1" (at 2.775 11.4105 90 unlocked) (layer "F.SilkS")
      (tstamp 06262094-3769-41f2-85c4-3cb16f1ccc86)
    (fp_text value "CR2032 KEYSTONE 1058" (at -0.3 13.0615 90 unlocked) (layer "F.Fab")
      (tstamp 3dd8e1ed-84c2-42a4-982a-e962d614b4f1)
    (fp_text user "${REFERENCE}" (at 0 7.5 -90 unlocked) (layer "F.Fab")
      (tstamp e1906ed8-59a8-445d-8abd-1fea24e2a087)
    (fp_rect (start -7 4) (end 6.2 10.5) (layer "F.SilkS") (width 0.12) (fill none) (tstamp 42331d94-64eb-40ff-934b-d53740b75d8c))
    (fp_rect (start -11.75 3.9) (end 10.95 10.6) (layer "F.CrtYd") (width 0.05) (fill none) (tstamp 380b5017-03bb-432e-919e-372b8f82c1b4))
    (pad "" thru_hole oval (at -5.2 8.9 270) (size 2.8 2.2) (drill 1.3) (layers *.Cu *.Mask) (tstamp 0c1f800b-d9e9-4ba8-b2e9-3e2a4d7eca20))
    (pad "1" thru_hole oval (at 4.5 8.9 270) (size 2.8 2.2) (drill 1.3) (layers *.Cu *.Mask)
      (net 11 "Net-(BT1-Pad1)") (pinfunction "+") (pintype "passive") (tstamp 2e695462-62a7-4683-81b1-b79631326cc7))
    (pad "2" thru_hole oval (at -0.5 5.5 270) (size 2.8 2.2) (drill 1.3) (layers *.Cu *.Mask)
      (net 1 "Net-(BT1-Pad2)") (pinfunction "-") (pintype "passive") (tstamp 05aa6cda-696b-4f6d-ae1e-6f4afa0573c0))
    (tedit 5F68FEEF) (tstamp dea81a28-86dd-4931-a1c3-8416c2670ca4)
    (at 60.071 41.021 -90)
    (path "/83326ff1-a6f3-4895-9021-6ab4e8318772")
    (attr smd)
    (fp_text reference "C1" (at -3.683 -0.254 -90) (layer "F.SilkS")
      (tstamp bbdf771c-bb66-49a1-ae13-f6703ef9a9ca)
    (fp_text value "100n 50V KEM X7R1206 1,0U" (at 0 1.85 90) (layer "F.Fab")
      (tstamp 92bf2cef-cecd-49c2-bb1f-f7524709c42c)
    (fp_text user "${REFERENCE}" (at 0 0 90) (layer "F.Fab")
      (tstamp 3d70945e-2305-402f-8012-ee17e2b19e11)
    (fp_line (start -0.711252 -0.91) (end 0.711252 -0.91) (layer "F.SilkS") (width 0.12) (tstamp e450cc6c-4d5d-42eb-be6c-827486475371))
    (fp_line (start -0.711252 0.91) (end 0.711252 0.91) (layer "F.SilkS") (width 0.12) (tstamp eb375379-098f-4f78-af98-92af9c8e4806))
    (fp_line (start -2.48 -1.15) (end 2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp 2a64d347-bde0-4a60-ae36-d80693ae94f2))
    (fp_line (start 2.48 1.15) (end -2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp 5fbd759f-6b73-4f8c-bf73-d406b746834e))
    (fp_line (start -2.48 1.15) (end -2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp 792df3b0-bf73-4d5d-b341-bcbefc60b6da))
    (fp_line (start 2.48 -1.15) (end 2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp 7d087317-34ca-439a-a6e1-3fad5fe1caa1))
    (fp_line (start 1.6 0.8) (end -1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp 0430d259-ddc9-41df-b1c1-2b3fa06e7fb1))
    (fp_line (start 1.6 -0.8) (end 1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp 1bf940f0-5427-4ee4-a676-049ea5d26a93))
    (fp_line (start -1.6 -0.8) (end 1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp 2a53b984-2122-4282-bf51-3555eb4298c5))
    (fp_line (start -1.6 0.8) (end -1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp 39c928e8-6d7a-4848-ba10-79f975b69d96))
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp 2bb65a30-6ad7-4123-8749-ff2612548cc0))
      (net 3 "Net-(C1-Pad2)") (pintype "passive") (tstamp 7ea92b0c-8bfd-4ce9-99ec-da36d9cafc35))
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp df39506b-7208-4e0a-baeb-8867ab9180bf)
    (at 113.8835 78.206 -90)
    (path "/54b6beaa-4f06-405d-bfaa-7f6dcc639e6c")
    (attr smd)
    (fp_text reference "R1" (at 0 -2.28 90) (layer "F.SilkS")
      (tstamp 5fde208c-7037-47bb-81a6-d5d190e2d894)
    (fp_text value "SMD 1/4W 0R1" (at 0 2.28 90) (layer "F.Fab")
      (tstamp 29aefd7e-9cb4-4129-8d3e-c885bead1dd5)
      (tstamp d6c50eac-63b5-4d9a-b6f9-a993fc126ee8)
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 0e68e806-c8e8-4e97-94a4-846d7cb09f04))
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp ebb36147-a962-447d-8f88-668f8b26e093))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 11620a35-982a-49cb-b6c2-6e5cdffb63ae))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 672a2f8c-7525-4bfd-8ad2-1e040446518a))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 978e2918-b8c2-439f-98a4-af1f05fa8b95))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp e3c42103-6160-4a15-8706-a2f9973d40ea))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 291d5b33-944f-4c02-b1ab-4ab5fcc24adf))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 6fe322b8-1d14-40c3-aaf6-0ec44e56f837))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 806d12f5-37a1-4878-9bc4-1ea0d30a71a7))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp ea5f151e-2f19-4cb4-9141-922e078fce3a))
      (net 4 "Net-(C6-Pad1)") (pintype "passive") (tstamp dbad3bb5-81fd-4674-88fc-d41f6c85adc3))
      (net 98 "Net-(F4-Pad2)") (pintype "passive") (tstamp eaccf40d-335f-4229-b14f-597cdfc73e54))
      (scale (xyz 1 1 1))
  (footprint "TerminalBlock_RND:TerminalBlock_RND_205-00001_1x02_P5.00mm_Horizontal" (layer "F.Cu")
    (tedit 5B294F8C) (tstamp e0412809-3dcb-45ed-bece-45266c8f65f0)
    (at 165.989 28.956 90)
    (descr "terminal block RND 205-00001, 2 pins, pitch 5mm, size 10x9mm^2, drill diamater 1.3mm, pad diameter 2.5mm, see http://cdn-reichelt.de/documents/datenblatt/C151/RND_205-00001_DB_EN.pdf, script-generated using https://github.com/pointhi/kicad-footprint-generator/scripts/TerminalBlock_RND")
    (tags "THT terminal block RND 205-00001 pitch 5mm size 10x9mm^2 drill 1.3mm pad 2.5mm")
    (path "/421a5400-c049-4a1a-8368-3cef6f476b2a")
    (attr through_hole)
    (fp_text reference "J1" (at 2.5 -6.06 90) (layer "F.SilkS")
      (tstamp f361e38a-1dd1-4f6a-8bd1-b7be1113209b)
    (fp_text value "DC 21V 1" (at 2.5 5.06 90) (layer "F.Fab")
      (tstamp 231280c2-a3fc-458d-bd04-59e92239ea01)
    (fp_text user "${REFERENCE}" (at 2.5 -6.06 90) (layer "F.Fab")
      (tstamp af3c3f74-0796-4f64-9eda-0baa3b593c1d)
    (fp_line (start 6.275 -1.069) (end 6.181 -0.976) (layer "F.SilkS") (width 0.12) (tstamp 276baca2-6cc6-418e-9dc0-251c091f93d3))
    (fp_line (start 7.56 -5.06) (end 7.56 4.06) (layer "F.SilkS") (width 0.12) (tstamp 3b9e4b21-b66a-4dcb-99ef-4be5eff35aa0))
    (fp_line (start -2.56 -5.06) (end -2.56 4.06) (layer "F.SilkS") (width 0.12) (tstamp 42c1c6e1-f2c3-4e69-afc4-03ac66ea85d2))
    (fp_line (start -2.56 4.06) (end 7.56 4.06) (layer "F.SilkS") (width 0.12) (tstamp 6f1b82ca-9b7b-479c-9a5f-ca949643ac6a))
    (fp_line (start -2.56 -5.06) (end 7.56 -5.06) (layer "F.SilkS") (width 0.12) (tstamp 6fc6e59d-1891-4198-b73c-9a1b7b9aca4d))
    (fp_line (start -2.8 4.3) (end -1.3 4.3) (layer "F.SilkS") (width 0.12) (tstamp 6fee2b24-4fce-45cf-8165-832fcae016d6))
    (fp_line (start 3.82 0.976) (end 3.726 1.069) (layer "F.SilkS") (width 0.12) (tstamp 7d4e2777-08c4-426a-8c9b-027cd8753415))
    (fp_line (start 3.99 1.216) (end 3.931 1.274) (layer "F.SilkS") (width 0.12) (tstamp 9412fe7b-d21b-4387-8e2a-da63f22322c2))
    (fp_line (start -2.8 2.56) (end -2.8 4.3) (layer "F.SilkS") (width 0.12) (tstamp 9c46fb49-42ab-42ca-a2fd-fa4059d97c34))
    (fp_line (start -2.56 2.5) (end 7.56 2.5) (layer "F.SilkS") (width 0.12) (tstamp c0f0ef0c-e0d2-4178-ae81-f6aeaea05fbf))
    (fp_line (start 6.07 -1.275) (end 6.011 -1.216) (layer "F.SilkS") (width 0.12) (tstamp ca666d56-67bd-41ae-b898-344e44b32f64))
    (fp_arc (start -0.789089 -1.483953) (mid -0.00005 -1.680708) (end 0.789 -1.484) (layer "F.SilkS") (width 0.12) (tstamp 13b2acb1-7139-4771-8583-f127c69fe040))
    (fp_arc (start 0.788712 1.483352) (mid 0.406429 1.630097) (end 0 1.68) (layer "F.SilkS") (width 0.12) (tstamp 316794d4-7454-487f-8ab2-c1a94d9b79aa))
    (fp_arc (start 0.029383 1.68045) (mid -0.392304 1.634281) (end -0.789 1.484) (layer "F.SilkS") (width 0.12) (tstamp 6305337f-1eb3-4474-9666-e349ed16060e))
    (fp_arc (start 1.483953 -0.789089) (mid 1.680708 -0.00005) (end 1.484 0.789) (layer "F.SilkS") (width 0.12) (tstamp 77801906-8f18-4571-8f94-e5665605d3ee))
    (fp_arc (start -1.483953 0.789089) (mid -1.680708 0.00005) (end -1.484 -0.789) (layer "F.SilkS") (width 0.12) (tstamp 80382d01-0536-4e23-8787-1cbf4d833c28))
    (fp_circle (center 5 -3) (end 5.9 -3) (layer "F.SilkS") (width 0.12) (fill none) (tstamp 949e7553-f2c7-456b-90f6-771c447d1c23))
    (fp_circle (center 0 -3) (end 0.9 -3) (layer "F.SilkS") (width 0.12) (fill none) (tstamp c4591cd0-fd15-442f-9fbd-f4f38f3e867d))
    (fp_circle (center 5 0) (end 6.68 0) (layer "F.SilkS") (width 0.12) (fill none) (tstamp da03ae75-718a-44a3-af9f-3443355e74b0))
    (fp_line (start -3 4.5) (end 8 4.5) (layer "F.CrtYd") (width 0.05) (tstamp 257d8c85-6d99-442b-ac74-fb898714fc42))
    (fp_line (start -3 -5.5) (end -3 4.5) (layer "F.CrtYd") (width 0.05) (tstamp 6a967bda-56d8-433b-9a60-f434f9bf50a7))
    (fp_line (start 8 4.5) (end 8 -5.5) (layer "F.CrtYd") (width 0.05) (tstamp c7e5a57e-cccb-4046-883e-47a95ad50524))
    (fp_line (start 8 -5.5) (end -3 -5.5) (layer "F.CrtYd") (width 0.05) (tstamp d6ca838e-3007-47ae-8c83-1f67e8953f4c))
    (fp_line (start 7.5 4) (end -1 4) (layer "F.Fab") (width 0.1) (tstamp 06ba7a59-e99f-4276-9ff9-5a6e79bae9e1))
    (fp_line (start 0.955 -1.138) (end -1.138 0.955) (layer "F.Fab") (width 0.1) (tstamp 4d7ae38f-8c8a-44a1-9e97-2f60556e5609))
    (fp_line (start -2.5 2.5) (end 7.5 2.5) (layer "F.Fab") (width 0.1) (tstamp 612df966-0938-430f-b640-7612998252a8))
    (fp_line (start -2.5 -5) (end 7.5 -5) (layer "F.Fab") (width 0.1) (tstamp 7cef02fa-59a3-4c0f-81ca-2269fb2cbbd8))
    (fp_line (start -2.5 2.5) (end -2.5 -5) (layer "F.Fab") (width 0.1) (tstamp a158fba8-f379-4513-aae9-29ba69618322))
    (fp_line (start 1.138 -0.955) (end -0.955 1.138) (layer "F.Fab") (width 0.1) (tstamp b1d85b29-3995-4968-9068-3298b2b7f02f))
    (fp_line (start -1 4) (end -2.5 2.5) (layer "F.Fab") (width 0.1) (tstamp ccd9ebe8-62be-4408-a00b-d9dc3e4faad1))
    (fp_line (start 6.138 -0.955) (end 4.046 1.138) (layer "F.Fab") (width 0.1) (tstamp ed8f61b1-023f-473a-8f8e-a272cf0b3d93))
    (fp_line (start 5.955 -1.138) (end 3.863 0.955) (layer "F.Fab") (width 0.1) (tstamp f26b1160-a4fc-4404-9cb0-5b4769f1eeac))
    (fp_line (start 7.5 -5) (end 7.5 4) (layer "F.Fab") (width 0.1) (tstamp fdbbc516-1d62-442e-b786-6fec1214062e))
    (fp_circle (center 5 -3) (end 5.9 -3) (layer "F.Fab") (width 0.1) (fill none) (tstamp 04a02232-351f-4ec7-8df3-59c5f908de5d))
    (fp_circle (center 5 0) (end 6.5 0) (layer "F.Fab") (width 0.1) (fill none) (tstamp 4eea0358-1885-4c14-ad44-df65e30aa429))
    (fp_circle (center 0 -3) (end 0.9 -3) (layer "F.Fab") (width 0.1) (fill none) (tstamp 7f83619f-0e57-4057-b930-f83e983f8f75))
    (fp_circle (center 0 0) (end 1.5 0) (layer "F.Fab") (width 0.1) (fill none) (tstamp 8d9c0176-7656-43b5-b1bc-8fb7c09813f8))
    (pad "1" thru_hole rect (at 0 0 90) (size 2.5 2.5) (drill 1.3) (layers *.Cu *.Mask)
      (net 23 "Net-(F2-Pad1)") (pinfunction "Pin_1") (pintype "passive") (tstamp 73dbf1d2-535d-4889-8568-e9f17ea18753))
    (pad "2" thru_hole circle (at 5 0 90) (size 2.5 2.5) (drill 1.3) (layers *.Cu *.Mask)
      (net 1 "Net-(BT1-Pad2)") (pinfunction "Pin_2") (pintype "passive") (tstamp 927ec09b-9698-40b4-911a-69a1726e5bad))
    (model "${KICAD6_3DMODEL_DIR}/TerminalBlock_RND.3dshapes/TerminalBlock_RND_205-00001_1x02_P5.00mm_Horizontal.wrl"
      (offset (xyz 0 0 0))
      (scale (xyz 1 1 1))
      (rotate (xyz 0 0 0))
  (footprint "Diode_THT:D_DO-35_SOD27_P7.62mm_Horizontal" (layer "F.Cu")
    (tedit 5AE50CD5) (tstamp e3fc352f-87f2-4894-b791-66419dd30396)
    (at 99.441 36.576 180)
    (descr "Diode, DO-35_SOD27 series, Axial, Horizontal, pin pitch=7.62mm, , length*diameter=4*2mm^2, , http://www.diodes.com/_files/packages/DO-35.pdf")
    (tags "Diode DO-35_SOD27 series Axial Horizontal pin pitch 7.62mm  length 4mm diameter 2mm")
    (property "Sheetfile" "Lauflicht_Steuerplatine.kicad_sch")
    (property "Sheetname" "")
    (path "/3204c0ff-8cd3-46e7-931f-335cdc74bd4f")
    (attr through_hole)
    (fp_text reference "D11" (at 9.652 0 90) (layer "F.SilkS")
      (effects (font (size 1 1) (thickness 0.15)))
      (tstamp 8942056b-1b48-4dc0-81ce-b4f8fb16eec4)
    (fp_text value "1N4148" (at 3.81 2.12) (layer "F.Fab")
      (tstamp d7d521c4-0871-46f2-a628-71ec02e5929d)
    (fp_text user "K" (at 0 -2.032 90) (layer "F.SilkS")
      (tstamp b46b4cb9-bd10-4b55-86e0-2598059239d2)
    (fp_text user "${REFERENCE}" (at 3.81 0) (layer "F.Fab")
      (effects (font (size 0.8 0.8) (thickness 0.12)))
      (tstamp 4cfbd009-5098-4106-af15-57a456502a6b)
    (fp_text user "K" (at 0 -1.8) (layer "F.Fab")
      (tstamp 8ea5a36c-2a9d-4313-b555-1e4556cc30a2)
    (fp_line (start 1.69 1.12) (end 5.93 1.12) (layer "F.SilkS") (width 0.12) (tstamp 11d14b14-3457-46c3-bc54-32420e84066c))
    (fp_line (start 1.69 -1.12) (end 1.69 1.12) (layer "F.SilkS") (width 0.12) (tstamp 234f6fb4-df46-4d1c-89ba-f5586080b66b))
    (fp_line (start 2.29 -1.12) (end 2.29 1.12) (layer "F.SilkS") (width 0.12) (tstamp 2ccc6612-0c4f-4e72-9762-29aa648a0796))
    (fp_line (start 2.41 -1.12) (end 2.41 1.12) (layer "F.SilkS") (width 0.12) (tstamp 3fef498e-a8a9-403e-975a-aaf34ecac855))
    (fp_line (start 5.93 1.12) (end 5.93 -1.12) (layer "F.SilkS") (width 0.12) (tstamp 45a9b09d-c41b-45f5-942b-0dfbdff9c063))
    (fp_line (start 1.04 0) (end 1.69 0) (layer "F.SilkS") (width 0.12) (tstamp 4974051f-3c50-458a-ab72-9565644b0bab))
    (fp_line (start 6.58 0) (end 5.93 0) (layer "F.SilkS") (width 0.12) (tstamp abea3577-9010-4d2c-a19a-6c4c90e48eef))
    (fp_line (start 2.53 -1.12) (end 2.53 1.12) (layer "F.SilkS") (width 0.12) (tstamp c91cc026-e810-4883-b574-d522d7e38300))
    (fp_line (start 5.93 -1.12) (end 1.69 -1.12) (layer "F.SilkS") (width 0.12) (tstamp fd3adc1c-16ac-4121-871c-9decbebde965))
    (fp_line (start -1.05 -1.25) (end -1.05 1.25) (layer "F.CrtYd") (width 0.05) (tstamp 66da9fc8-44d9-4bc3-9795-41935e9e97a9))
    (fp_line (start -1.05 1.25) (end 8.67 1.25) (layer "F.CrtYd") (width 0.05) (tstamp 75a723c4-9d7e-49e5-98d2-5c5991ee3c91))
    (fp_line (start 8.67 -1.25) (end -1.05 -1.25) (layer "F.CrtYd") (width 0.05) (tstamp e42dfdea-0a3e-46c0-941b-27a09572327a))
    (fp_line (start 8.67 1.25) (end 8.67 -1.25) (layer "F.CrtYd") (width 0.05) (tstamp f8a11076-ca09-464b-8edd-b6d98465ccf7))
    (fp_line (start 1.81 -1) (end 1.81 1) (layer "F.Fab") (width 0.1) (tstamp 02dcd3e2-b996-4f62-918a-9099359a6c8a))
    (fp_line (start 2.51 -1) (end 2.51 1) (layer "F.Fab") (width 0.1) (tstamp 3049caa5-40f7-4767-954a-5c3727beedbe))
    (fp_line (start 7.62 0) (end 5.81 0) (layer "F.Fab") (width 0.1) (tstamp 38e0c77e-480a-4d19-9db2-609f360ec820))
    (fp_line (start 2.31 -1) (end 2.31 1) (layer "F.Fab") (width 0.1) (tstamp 52e7d50d-2dc6-44a8-b652-4cf852798f17))
    (fp_line (start 5.81 -1) (end 1.81 -1) (layer "F.Fab") (width 0.1) (tstamp 5aab4cc8-f526-4ec1-870f-dc5693fdee26))
    (fp_line (start 1.81 1) (end 5.81 1) (layer "F.Fab") (width 0.1) (tstamp 7ec988ad-2f31-4a66-9585-a060b6a22fd7))
    (fp_line (start 0 0) (end 1.81 0) (layer "F.Fab") (width 0.1) (tstamp 97dabac9-f85f-4c71-9494-08910db01584))
    (fp_line (start 5.81 1) (end 5.81 -1) (layer "F.Fab") (width 0.1) (tstamp b8bdd8b1-c562-4c5c-ba68-da324fb8f735))
    (fp_line (start 2.41 -1) (end 2.41 1) (layer "F.Fab") (width 0.1) (tstamp fe35414d-2663-40af-9550-4c433a7f014f))
    (pad "1" thru_hole rect (at 0 0 180) (size 1.6 1.6) (drill 0.8) (layers *.Cu *.Mask)
      (net 87 "Net-(D11-Pad1)") (pinfunction "K") (pintype "passive") (tstamp 365ac05a-ca9b-4b6f-897a-4eadd535b52a))
    (pad "2" thru_hole oval (at 7.62 0 180) (size 1.6 1.6) (drill 0.8) (layers *.Cu *.Mask)
      (net 88 "Net-(D11-Pad2)") (pinfunction "A") (pintype "passive") (tstamp 1b869d05-6f1f-4e40-9c89-28271b830c6a))
    (model "${KICAD6_3DMODEL_DIR}/Diode_THT.3dshapes/D_DO-35_SOD27_P7.62mm_Horizontal.wrl"
      (scale (xyz 1 1 1))
  (footprint "Diode_SMD:D_MELF_Handsoldering" (layer "F.Cu")
    (tedit 5905D89D) (tstamp e5d8eb61-8e2d-4c94-8ebe-864047795f9f)
    (at 140.97 19.812)
    (descr "Diode MELF Handsoldering")
    (tags "Diode MELF Handsoldering")
    (path "/bc7f5f81-6929-49ca-bf5e-8b8576061d2d")
    (attr smd)
    (fp_text reference "D1" (at -6.276 0 90) (layer "F.SilkS")
      (tstamp 1bfbb4a6-a805-4907-a347-689cec0da1d1)
    (fp_text value "SA265" (at 0 2.25) (layer "F.Fab")
      (tstamp 0d38ff9d-11dd-4af9-9f7f-b89a2e4a9169)
    (fp_text user "${REFERENCE}" (at 0 -2.25) (layer "F.Fab")
      (tstamp c5681750-acc1-41fb-bd3c-7c7ededae0e7)
    (fp_line (start 3.4 -1.5) (end -5.3 -1.5) (layer "F.SilkS") (width 0.12) (tstamp 81a0e397-00b0-44de-a64d-c6ce4c5fa96e))
    (fp_line (start -5.3 1.5) (end 3.4 1.5) (layer "F.SilkS") (width 0.12) (tstamp 9d2ceacb-e06b-4bcf-9ff3-4dc81d6a5076))
    (fp_line (start -5.3 -1.5) (end -5.3 1.5) (layer "F.SilkS") (width 0.12) (tstamp e6d709a5-c314-47f6-afd0-fdea86a91888))
    (fp_line (start 5.4 -1.6) (end 5.4 1.6) (layer "F.CrtYd") (width 0.05) (tstamp 0e282261-78a3-4d12-9515-0efeda54933e))
    (fp_line (start -5.4 -1.6) (end 5.4 -1.6) (layer "F.CrtYd") (width 0.05) (tstamp c3dcedbb-ca42-4263-8738-824af46f023a))
    (fp_line (start 5.4 1.6) (end -5.4 1.6) (layer "F.CrtYd") (width 0.05) (tstamp d38a2b56-f514-467a-8b87-5d8c88d3880e))
    (fp_line (start -5.4 1.6) (end -5.4 -1.6) (layer "F.CrtYd") (width 0.05) (tstamp e564da1e-ce49-494b-9938-8785531cc0ea))
    (fp_line (start -0.64944 0.00102) (end 0.50118 -0.79908) (layer "F.Fab") (width 0.1) (tstamp 61ebd49a-cf15-491c-9c30-6e9b33a1236e))
    (fp_line (start -0.64944 0.00102) (end -1.55114 0.00102) (layer "F.Fab") (width 0.1) (tstamp 8b45608e-5800-4fb3-8e96-aeb23999e65a))
    (fp_line (start 2.6 1.3) (end 2.6 -1.3) (layer "F.Fab") (width 0.1) (tstamp 90e4f776-58e7-4217-a94d-cfeab2e76bd0))
    (fp_line (start -2.6 -1.3) (end -2.6 1.3) (layer "F.Fab") (width 0.1) (tstamp 99da672e-bc94-4fa9-a5ad-97578505310e))
    (fp_line (start 0.50118 0.75032) (end 0.50118 -0.79908) (layer "F.Fab") (width 0.1) (tstamp 9af568c8-a3e6-4976-b7fe-43f0b9b45e3c))
    (fp_line (start -0.64944 0.00102) (end 0.50118 0.75032) (layer "F.Fab") (width 0.1) (tstamp 9e0f24bd-5811-4a55-88a0-6e012e810249))
    (fp_line (start -0.64944 -0.79908) (end -0.64944 0.80112) (layer "F.Fab") (width 0.1) (tstamp a606c0fe-2e06-4fa3-937f-c74fda7d1d38))
    (fp_line (start 0.50118 0.00102) (end 1.4994 0.00102) (layer "F.Fab") (width 0.1) (tstamp b3e596aa-cf3f-4c1e-b584-3fbd939203c9))
    (fp_line (start -2.6 1.3) (end 2.6 1.3) (layer "F.Fab") (width 0.1) (tstamp d72ba159-08f5-4218-ae1c-600855e6bc10))
    (fp_line (start 2.6 -1.3) (end -2.6 -1.3) (layer "F.Fab") (width 0.1) (tstamp df5db079-23eb-4fe3-99a9-194a44d698fb))
    (pad "1" smd rect (at -3.4 0) (size 3.5 2.7) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 44 "Net-(C11-Pad1)") (pinfunction "K") (pintype "passive") (tstamp 22ef1eed-f185-4770-a739-61aa1993d790))
    (pad "2" smd rect (at 3.4 0) (size 3.5 2.7) (layers "F.Cu" "F.Paste" "F.Mask")
      (net 1 "Net-(BT1-Pad2)") (pinfunction "A") (pintype "passive") (tstamp aae40d76-9a9f-42cc-bca0-ba0c21f11d9f))
    (model "${KICAD6_3DMODEL_DIR}/Diode_SMD.3dshapes/D_MELF.wrl"
      (scale (xyz 1 1 1))
  (footprint "Resistor_SMD:R_1210_3225Metric_Pad1.30x2.65mm_HandSolder" (layer "F.Cu")
    (tedit 5F68FEEE) (tstamp e5fbe627-8cfd-4a85-a940-39f9d69aa9b2)
    (at 40.259 75.692 90)
    (descr "Resistor SMD 1210 (3225 Metric), square (rectangular) end terminal, IPC_7351 nominal with elongated pad for handsoldering. (Body size source: IPC-SM-782 page 72, https://www.pcb-3d.com/wordpress/wp-content/uploads/ipc-sm-782a_amendment_1_and_2.pdf), generated with kicad-footprint-generator")
    (tags "resistor handsolder")
    (path "/1d1f5bf0-0e40-45be-9d4c-bbc665431435")
    (attr smd)
    (fp_text reference "R46" (at 0 -2.28 90) (layer "F.SilkS")
      (tstamp 9ceeb01d-1ace-45a9-9c5f-c487d9afd027)
    (fp_text value "SMD 1/4W 1k" (at 0 2.28 90) (layer "F.Fab")
      (tstamp 578a316e-c3a7-4bea-943e-7b43a43c15d8)
      (tstamp f7322e51-8a87-49e5-bcca-13ef39be32fd)
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp 19c010bc-2585-4d13-85cb-f3e6166491b2))
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 35b6b4ae-8c4e-45c7-8e1a-ced639c38976))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 07f99fc7-37e9-4c52-aa91-b31e1e6c735a))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 42321990-3a9d-4ed8-939e-470aa58fa1f5))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 5be8e43b-f7a3-4d43-849b-234aabf89f50))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 760c4289-9582-48bc-808e-c8719db07ebe))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 18c5e63f-8edc-46ff-ab0b-2833816d2fd9))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 42a913c6-f15e-4842-ba9c-df3c2032e4eb))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 6e936cd1-2d7a-465c-b767-0b5a1ba09417))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 8e21984f-fdb9-4a94-9bc1-3b100caa52af))
    (pad "1" smd roundrect (at -1.55 0 90) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 75 "Net-(R46-Pad1)") (pintype "passive") (tstamp 5eb5279e-9eb9-4478-8438-5899230086cb))
    (pad "2" smd roundrect (at 1.55 0 90) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 28 "Net-(J14-Pad13)") (pintype "passive") (tstamp c5fba0b8-4254-4bd6-972f-8ace4e83747d))
    (model "${KICAD6_3DMODEL_DIR}/Resistor_SMD.3dshapes/R_1210_3225Metric.wrl"
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp e6697d2a-e0ab-49a5-887a-45a00a96c8f2)
    (at 56.261 41.021 90)
    (path "/c46477a6-2311-4533-b6f5-0097a3d0ebce")
    (attr smd)
    (fp_text reference "R4" (at 3.683 0.254 270) (layer "F.SilkS")
      (tstamp fd1274af-1b6f-44b9-8c5c-554680cc7db6)
    (fp_text value "SMD 1/4W 10k" (at 0 2.28 90) (layer "F.Fab")
      (tstamp d169eb27-a2b8-474a-92b2-5b6ead9cfeb9)
      (tstamp 559be330-23f6-44e6-aabb-a0de9401dc66)
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 02257417-6188-4ac2-9150-30db07ef7fec))
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp d95462c7-9b35-4420-ad51-c00befeb878c))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 00563073-2dcc-4a23-9f7f-adde53444861))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 1916938f-618e-41b8-a26e-c298efe8eee9))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 932ad76f-38d7-4410-b0e3-2e863d2a3a58))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp f3560ce9-38f7-4e68-8680-affe22b8a5e4))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 045976b4-a6d2-4bb9-87ac-09abdbb6c820))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp ad300cdf-c3e2-4b8f-9d78-7864fa1d4e20))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp d0ed2f5e-96df-4a96-842f-d1bf0619fee7))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp e90dd853-4734-4b25-8ca6-6d2a1e279fbc))
      (net 3 "Net-(C1-Pad2)") (pintype "passive") (tstamp 4fde5d21-a71e-4e82-88ae-6b07cdd81c1b))
      (net 7 "Net-(C9-Pad2)") (pintype "passive") (tstamp 68382a4f-2939-48e9-bdca-78735c1ca4e3))
      (scale (xyz 1 1 1))
  (footprint "LED_SMD:LED_0805_2012Metric_Pad1.15x1.40mm_HandSolder" (layer "F.Cu")
    (tedit 5F68FEF1) (tstamp e8f9a58f-e19f-4cac-a3ab-818d1f2c4fa2)
    (at 68.891 19.556 90)
    (descr "LED SMD 0805 (2012 Metric), square (rectangular) end terminal, IPC_7351 nominal, (Body size source: https://docs.google.com/spreadsheets/d/1BsfQQcO9C6DZCsRaXUlFlo91Tg2WpOkGARC1WS5S8t0/edit?usp=sharing), generated with kicad-footprint-generator")
    (tags "LED handsolder")
    (path "/5fc92d99-835d-46f3-8bd5-566d46c23fc2")
    (attr smd)
    (fp_text reference "D13" (at 0.127 -1.651 270) (layer "F.SilkS")
      (tstamp 3d6f2237-38d3-4bd3-924c-69739db035da)
    (fp_text value "OSO LYR976 Grün" (at 0 1.65 90) (layer "F.Fab")
      (tstamp f669be45-40f4-4864-a7c0-a9e3b31eace7)
      (effects (font (size 0.5 0.5) (thickness 0.08)))
      (tstamp 3aeca653-8474-4ba9-9839-cfb79c56e4af)
    (fp_line (start -1.86 -0.96) (end -1.86 0.96) (layer "F.SilkS") (width 0.12) (tstamp 2f0de0ae-251c-43d4-a4f9-a7e7e9eed630))
    (fp_line (start -1.86 0.96) (end 1 0.96) (layer "F.SilkS") (width 0.12) (tstamp 583710d5-7cf5-4775-b234-df0ae921b6b6))
    (fp_line (start 1 -0.96) (end -1.86 -0.96) (layer "F.SilkS") (width 0.12) (tstamp 5c422d99-9fc9-42d0-a5e5-efb22e227689))
    (fp_line (start -1.85 -0.95) (end 1.85 -0.95) (layer "F.CrtYd") (width 0.05) (tstamp 36f38c28-a935-4e88-b81a-e47ab17377b9))
    (fp_line (start -1.85 0.95) (end -1.85 -0.95) (layer "F.CrtYd") (width 0.05) (tstamp 3b73e503-039e-44e6-896b-bc50e5083527))
    (fp_line (start 1.85 -0.95) (end 1.85 0.95) (layer "F.CrtYd") (width 0.05) (tstamp a26d966d-7bf6-4a5d-8db9-09a17288e804))
    (fp_line (start 1.85 0.95) (end -1.85 0.95) (layer "F.CrtYd") (width 0.05) (tstamp c2c5f571-5094-493d-a71b-98d6fca2546a))
    (fp_line (start -0.7 -0.6) (end -1 -0.3) (layer "F.Fab") (width 0.1) (tstamp 2f64a5a0-9029-448a-97b1-2d8a1df771d1))
    (fp_line (start -1 -0.3) (end -1 0.6) (layer "F.Fab") (width 0.1) (tstamp 38033ac4-5f89-4eec-90e8-5b27bb13fde1))
    (fp_line (start 1 0.6) (end 1 -0.6) (layer "F.Fab") (width 0.1) (tstamp 6f603391-c947-4ee7-a536-469d4118576d))
    (fp_line (start -1 0.6) (end 1 0.6) (layer "F.Fab") (width 0.1) (tstamp d0ee2714-160f-463f-b2b5-5e2fe2a4fee8))
    (fp_line (start 1 -0.6) (end -0.7 -0.6) (layer "F.Fab") (width 0.1) (tstamp d63fc5b0-7189-4486-8139-4b3f44b4a0fd))
    (pad "1" smd roundrect (at -1.025 0 90) (size 1.15 1.4) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.2173913043)
      (net 124 "Net-(D13-Pad1)") (pinfunction "K") (pintype "passive") (tstamp 9d66df56-a6ab-458f-9de4-5ae06572c9d2))
    (pad "2" smd roundrect (at 1.025 0 90) (size 1.15 1.4) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.2173913043)
      (net 133 "Net-(D13-Pad2)") (pinfunction "A") (pintype "passive") (tstamp e9b11f11-1592-4e48-ae2d-c39bd9611d21))
    (model "${KICAD6_3DMODEL_DIR}/LED_SMD.3dshapes/LED_0805_2012Metric.wrl"
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp eac103fa-c5a1-46cb-81b3-fff4eab12213)
    (at 98.171 78.206 -90)
    (path "/cda6c373-39cf-41dc-a76a-631d9e440ea6")
    (attr smd)
    (fp_text reference "R2" (at 0.026 2.54 90) (layer "F.SilkS")
      (tstamp 77409a06-71e2-4239-8086-bf4cd530c9e0)
      (tstamp 703c7852-6c74-4e9b-b442-b157cb0cdb4c)
    (fp_text user "${REFERENCE}" (at -0.088 -0.026 90) (layer "F.Fab")
      (tstamp fd01dd29-2bcf-44b1-86a8-9acfd9e226b2)
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp 84cf4d29-343c-439e-996b-38c534868aa3))
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp f97bb1b4-bdfe-4ce2-9e9f-bd75bcb54e49))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 0b51015a-4ca4-4f75-80df-02409b7521fa))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 827ca108-685b-4d75-b5ab-f4ed003d6c6b))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp b25eaf7e-8349-40c4-90a9-6023a70ae2b6))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp fa674d63-c938-4b18-8b4d-3aab61f312f9))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 2df7d154-a29b-45b6-a6f5-ce3075894cf7))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 522f31d4-8fe3-42df-ac30-0ac978a787b8))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp ad100fb4-9c75-4802-ba2b-0ab984336180))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp c42f2489-8813-4afa-a413-1ac402469ae9))
      (net 5 "Net-(C7-Pad1)") (pintype "passive") (tstamp 96fb3d4b-579a-4a06-89fa-765d5ae92f10))
      (net 98 "Net-(F4-Pad2)") (pintype "passive") (tstamp 437b97ed-4fbf-488e-80b7-729ae34d6c96))
      (scale (xyz 1 1 1))
  (footprint "Capacitor_SMD:C_1206_3216Metric_Pad1.33x1.80mm_HandSolder" (layer "F.Cu")
    (tedit 5F68FEEF) (tstamp ebd27f26-bc50-4899-9c70-a515d289aaea)
    (at 28.956 77.597 90)
    (descr "Capacitor SMD 1206 (3216 Metric), square (rectangular) end terminal, IPC_7351 nominal with elongated pad for handsoldering. (Body size source: IPC-SM-782 page 76, https://www.pcb-3d.com/wordpress/wp-content/uploads/ipc-sm-782a_amendment_1_and_2.pdf), generated with kicad-footprint-generator")
    (tags "capacitor handsolder")
    (path "/c9e8a864-64e5-4742-b1e4-2e7e6cc3bd0b")
    (attr smd)
    (fp_text reference "C25" (at 0 -1.85 90) (layer "F.SilkS")
      (tstamp 33b1e69a-e9c7-401e-974f-182333b86e43)
      (tstamp 34bdc5fe-2eb6-448a-afee-617da470cb6d)
      (tstamp 6e27652f-3465-48c4-a0de-8dae739fafb7)
    (fp_line (start -0.711252 -0.91) (end 0.711252 -0.91) (layer "F.SilkS") (width 0.12) (tstamp 2cc8d1b0-7f62-4539-8a21-cf668e4596db))
    (fp_line (start -0.711252 0.91) (end 0.711252 0.91) (layer "F.SilkS") (width 0.12) (tstamp d8c04b6b-caa2-475c-a179-416227f19b1b))
    (fp_line (start 2.48 -1.15) (end 2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp 42347a39-89ad-4747-93d9-a22ae1b097db))
    (fp_line (start -2.48 -1.15) (end 2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp 9f1b1ad0-3137-40cb-906a-10e50eaf211a))
    (fp_line (start -2.48 1.15) (end -2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp be2a0d25-1db4-469d-bf0e-d57dfaeaad38))
    (fp_line (start 2.48 1.15) (end -2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp e91df5c6-3e45-45e1-96d0-e75181255e88))
    (fp_line (start 1.6 0.8) (end -1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp 28c021a8-7501-4854-b646-6bc660d63494))
    (fp_line (start 1.6 -0.8) (end 1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp 46bdd0c3-eb35-48a8-9407-f8ba162a606a))
    (fp_line (start -1.6 -0.8) (end 1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp 64ca8523-8002-4360-b3ab-b52fed55b9d0))
    (fp_line (start -1.6 0.8) (end -1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp b2ca6f48-2a86-4198-82f4-2d805fa1caf6))
    (pad "1" smd roundrect (at -1.5625 0 90) (size 1.325 1.8) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1886792453)
      (net 12 "Net-(C25-Pad1)") (pintype "passive") (tstamp 90bd01e4-a14e-4328-a748-eb4dfdb53448))
    (pad "2" smd roundrect (at 1.5625 0 90) (size 1.325 1.8) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1886792453)
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp fd5420ee-773b-4619-a10e-c61972ba9523))
    (model "${KICAD6_3DMODEL_DIR}/Capacitor_SMD.3dshapes/C_1206_3216Metric.wrl"
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp ed11e3a6-a6d2-4bc4-ad2c-0d476faba2ad)
    (at 66.421 30.226)
    (path "/ca04895f-09d0-42b2-b0ae-60720364d1fb")
    (attr smd)
    (fp_text reference "R5" (at -3.302 0 90) (layer "F.SilkS")
      (tstamp 69ab72fc-2783-4ee5-8447-0815b2efd76f)
    (fp_text value "SMD 1/4W 1k" (at 0 2.28) (layer "F.Fab")
      (tstamp 94a1c6d9-8295-446f-a54d-0fe430ff907b)
      (tstamp b913cc72-3b83-437f-9773-4069a435c1f3)
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 6365bc05-03ef-4d54-a79d-6bb91a98e35f))
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp e0d9a4eb-0ca9-4a77-a28f-9846dc4e0c57))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 250c0075-6526-4c38-994d-f1f0c849cc61))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 2f4bc1e6-4b12-4cae-b74b-eef069c04cad))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 61e32ba2-881e-410b-96ac-2cd06b8c0f8a))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp d29bb0d3-4ff9-448b-983d-27bde4cf53e5))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 8066ee9e-1fc0-43d1-a9d7-ac24a670e68d))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp b9389943-07b0-4a70-baed-e737e8315d55))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp bd4504e2-abae-4f2f-acfe-8622ef64dc6b))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp f9d43455-26a8-4184-8642-d793cbf69127))
    (pad "1" smd roundrect (at -1.55 0) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 85 "Net-(C20-Pad1)") (pintype "passive") (tstamp c576c464-767e-4cc5-a941-ed8f54145d33))
    (pad "2" smd roundrect (at 1.55 0) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 86 "Net-(C31-Pad2)") (pintype "passive") (tstamp 638f1f80-56ab-4a39-a9a8-05c70c049975))
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp ede1fc70-a5a4-4e31-bc4d-cc402f6ef23a)
    (at 72.009 32.131 90)
    (path "/4c2bd15b-3587-4da8-a929-69ddc284f68f")
    (attr smd)
    (fp_text reference "R12" (at 0.127 -2.286 270) (layer "F.SilkS")
      (tstamp 70be2817-ba48-4468-86e7-0110aca14cf6)
    (fp_text value "SMD 1/4W 3k3" (at 0 2.28 90) (layer "F.Fab")
      (tstamp 6606372e-a4b3-4c39-b6d6-d0cf7a01f446)
    (fp_text user "${REFERENCE}" (at -0.168 0.082 90) (layer "F.Fab")
      (tstamp 9fa3a6dc-b68a-45f4-9130-2d4682b5b835)
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 9928a975-d03a-488d-8196-5340bbbd5e27))
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp a94eeb04-86f9-4a87-b4bc-ca593c833f31))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 6f860918-0622-4571-9f8b-5f1163a8e863))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 7b00d40d-d2ae-4955-a11a-2c96302b459f))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 84a2610b-679f-4750-83cf-b317500a047d))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp eb3092e5-150f-4f85-b58c-ece33889d2f8))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 1c3db47b-cf0a-42ff-9ff3-7a12a0c66d0a))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 3210399d-bdf5-4543-b85e-0503d9a0989d))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp c3630454-8a12-4360-92a7-3cf352bf2509))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp dd36149e-7597-4f58-b0a3-8f6a70d4c56f))
      (net 8 "Net-(C10-Pad2)") (pintype "passive") (tstamp 67615eb3-6b72-471d-be2c-e4f959561dfc))
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp 97e78fae-c3eb-4946-86ce-ea74bca5bdf5))
      (scale (xyz 1 1 1))
    (tedit 5F68FEEF) (tstamp f5c5ef68-4cf4-49f6-8fdf-2b691308afb0)
    (at 30.099 89.516 -90)
    (path "/5483a5a8-9a6c-49a2-9ad9-4c28a48b145b")
    (attr smd)
    (fp_text reference "C29" (at 0 -1.85 90) (layer "F.SilkS")
      (tstamp d0a3a9fb-03fa-4c8c-8e53-ba9459239567)
      (tstamp 71cb77c3-38bf-4006-accd-842a63fc4c0f)
      (tstamp d39eed53-9b14-49c9-86d2-14d39825200d)
    (fp_line (start -0.711252 -0.91) (end 0.711252 -0.91) (layer "F.SilkS") (width 0.12) (tstamp 1b2afdfa-1a4d-447c-8650-08bc41982832))
    (fp_line (start -0.711252 0.91) (end 0.711252 0.91) (layer "F.SilkS") (width 0.12) (tstamp db2c90a7-dc88-4367-9d88-880cbcb8f7ca))
    (fp_line (start -2.48 -1.15) (end 2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp 0280ccd4-9d8e-49b7-89c9-201330f21f67))
    (fp_line (start -2.48 1.15) (end -2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp e1912f37-9f0d-4069-989f-c90ef0530492))
    (fp_line (start 2.48 -1.15) (end 2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp ebdc28e6-d763-4be0-b690-c290ce14c2f0))
    (fp_line (start 2.48 1.15) (end -2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp fa764c36-19b7-47ca-8f41-5e951f566515))
    (fp_line (start 1.6 0.8) (end -1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp 08d3a6c7-da63-40ec-8427-edfc9c36ac22))
    (fp_line (start -1.6 -0.8) (end 1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp 771301d9-2447-4965-8d00-8b4853ce247c))
    (fp_line (start 1.6 -0.8) (end 1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp 81fe9d21-b1da-4845-9bc7-16cc2a7dd5dc))
    (fp_line (start -1.6 0.8) (end -1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp 8b198e2a-95ed-44c0-b15f-804f0937a684))
    (pad "1" smd roundrect (at -1.5625 0 270) (size 1.325 1.8) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1886792453)
      (net 85 "Net-(C20-Pad1)") (pintype "passive") (tstamp c499f3aa-299b-4a74-b1f5-a22ec51f7272))
    (pad "2" smd roundrect (at 1.5625 0 270) (size 1.325 1.8) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1886792453)
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp f25b2fad-6a58-4577-8db1-c8e7b8e66348))
      (scale (xyz 1 1 1))
  (footprint "Package_TO_SOT_THT:TO-92_Inline" (layer "F.Cu")
    (tedit 5A1DD157) (tstamp f879ec3e-4da1-4967-b39c-a17fc20374de)
    (at 45.191 43.815 90)
    (descr "TO-92 leads in-line, narrow, oval pads, drill 0.75mm (see NXP sot054_po.pdf)")
    (tags "to-92 sc-43 sc-43a sot54 PA33 transistor")
    (path "/248eabde-9772-4627-9901-b188ffa4d897")
    (attr through_hole)
    (fp_text reference "Q4" (at 5.207 1.672 90) (layer "F.SilkS")
      (tstamp b7f3c737-043a-4992-93b6-e9769ae42c7b)
    (fp_text value "BC337" (at 1.27 2.79 90) (layer "F.Fab")
      (tstamp b0f71b7d-83a4-4aaa-a972-153940249cb3)
    (fp_text user "${REFERENCE}" (at 1.27 0 90) (layer "F.Fab")
      (tstamp c520be07-9d2c-4d04-82ff-24d7f9c94e6f)
    (fp_line (start -0.53 1.85) (end 3.07 1.85) (layer "F.SilkS") (width 0.12) (tstamp 8a46dabc-3583-4fc0-a7b8-3e82d86e7751))
    (fp_arc (start -0.568478 1.838478) (mid -1.132087 -0.994977) (end 1.27 -2.6) (layer "F.SilkS") (width 0.12) (tstamp 4cad9e54-23f4-4690-9809-8f1d897fabcd))
    (fp_arc (start 1.27 -2.6) (mid 3.672087 -0.994977) (end 3.108478 1.838478) (layer "F.SilkS") (width 0.12) (tstamp feda2c2e-ca9b-480b-abb6-09e60be0ee84))
    (fp_line (start -1.46 -2.73) (end -1.46 2.01) (layer "F.CrtYd") (width 0.05) (tstamp 1866c071-a6ca-40ce-a0b6-3d277c3cab11))
    (fp_line (start -1.46 -2.73) (end 4 -2.73) (layer "F.CrtYd") (width 0.05) (tstamp 52e9402e-38d7-4c67-8bea-34b3b93c774c))
    (fp_line (start 4 2.01) (end -1.46 2.01) (layer "F.CrtYd") (width 0.05) (tstamp 9077240d-41db-45de-b94a-5a1771bd8a79))
    (fp_line (start 4 2.01) (end 4 -2.73) (layer "F.CrtYd") (width 0.05) (tstamp a482bddb-4e57-4a0f-b036-c9e9786b74c3))
    (fp_line (start -0.5 1.75) (end 3 1.75) (layer "F.Fab") (width 0.1) (tstamp 887129a7-5959-4271-b867-3e9470733b45))
    (fp_arc (start 1.27 -2.48) (mid 3.561221 -0.949055) (end 3.023625 1.753625) (layer "F.Fab") (width 0.1) (tstamp 7cccd598-9758-4b3b-b18f-03e2e5c104dc))
    (fp_arc (start -0.483625 1.753625) (mid -1.021221 -0.949055) (end 1.27 -2.48) (layer "F.Fab") (width 0.1) (tstamp ea237653-ba58-4c65-810b-07a9a568d861))
    (pad "1" thru_hole rect (at 0 0 90) (size 1.05 1.5) (drill 0.75) (layers *.Cu *.Mask)
      (net 42 "Net-(Q3-Pad2)") (pinfunction "C") (pintype "passive") (tstamp 11251d12-f640-4148-bf9d-f2545cb2fe41))
    (pad "2" thru_hole oval (at 1.27 0 90) (size 1.05 1.5) (drill 0.75) (layers *.Cu *.Mask)
      (net 43 "Net-(Q4-Pad2)") (pinfunction "B") (pintype "input") (tstamp 9d8fe1d3-383c-4a9d-a96e-e51fc6857e5d))
    (pad "3" thru_hole oval (at 2.54 0 90) (size 1.05 1.5) (drill 0.75) (layers *.Cu *.Mask)
      (net 1 "Net-(BT1-Pad2)") (pinfunction "E") (pintype "passive") (tstamp 6b50419d-c345-4a39-82c1-ff71a4b11af6))
    (model "${KICAD6_3DMODEL_DIR}/Package_TO_SOT_THT.3dshapes/TO-92_Inline.wrl"
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp f9620e02-6ea3-448d-90c1-ae8eacede876)
    (at 72.517 120.65)
    (path "/896289a1-0c03-47b9-b40e-647dabd66ea9")
    (attr smd)
    (fp_text reference "R58" (at -1.778 -3.302 90) (layer "F.SilkS")
      (tstamp 9bd2ba99-a9eb-4444-9e2f-988c3badbb4a)
    (fp_text value "SMD 1/4W 10k" (at 0 2.28) (layer "F.Fab")
      (tstamp 50ec49a3-6a0d-4445-851a-eb69ae2fdf00)
      (tstamp 46f23683-8e4b-4835-a60c-2a3570c6ff5d)
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp 4f2f765d-ce9f-4a59-822d-9c445653ef8b))
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp b7ce896e-b8ac-478c-aea9-3df416f8b36d))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 513cab79-2903-4690-b9ea-6efe74c8f7e3))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 9d3e4be6-dc40-4a41-9e4d-9da0f0e2c16d))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp c351e614-a2c8-4a8a-b665-39488a0c63c5))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp dbf48a25-3da1-4b23-ad86-1194bba278ff))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 1d376f0a-1f3b-4f19-ae02-57276979ca5c))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 207eab8f-bc4f-4ac8-a8ed-584c66815444))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 3fa9a53d-6a40-4f0f-b6f9-6969614cdb42))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp f793e064-0acd-4a7e-9426-1d1960fd5c49))
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp f6299520-8952-47c7-8d88-b42286776c78))
      (net 105 "Net-(D16-Pad2)") (pintype "passive") (tstamp 1079908f-912b-46c8-96f8-7ec10a0d1e27))
      (scale (xyz 1 1 1))
    (tedit 5F68FEEF) (tstamp faaf627d-c0ee-4514-a9b8-95d776a7ed8b)
    (at 40.64 100.838 90)
    (path "/d41f5d68-903d-4829-a722-5aa2d160ee48")
    (attr smd)
    (fp_text reference "C26" (at 3.175 0 180) (layer "F.SilkS")
      (tstamp d700c8fe-f7c6-4140-b4d0-0c9f7afefb12)
      (tstamp 11307f53-ba20-46df-a91a-2b023353614b)
      (tstamp 5ad23fe7-b74c-429a-ada1-de1b3c083199)
    (fp_line (start -0.711252 0.91) (end 0.711252 0.91) (layer "F.SilkS") (width 0.12) (tstamp 3717e367-a15f-4870-8b0c-e8448046c253))
    (fp_line (start -0.711252 -0.91) (end 0.711252 -0.91) (layer "F.SilkS") (width 0.12) (tstamp ccd8bd04-5442-473b-a97c-5daeab3ced0f))
    (fp_line (start 2.48 -1.15) (end 2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp 4561f115-f54b-4548-864d-ac4e1399af63))
    (fp_line (start -2.48 1.15) (end -2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp 6930c952-2a0d-47e4-a5a2-c47344ed1db3))
    (fp_line (start 2.48 1.15) (end -2.48 1.15) (layer "F.CrtYd") (width 0.05) (tstamp 69ffc06a-2977-4d2f-8536-298a9d7061b6))
    (fp_line (start -2.48 -1.15) (end 2.48 -1.15) (layer "F.CrtYd") (width 0.05) (tstamp c3ef4e07-d1a0-4ac7-98c2-28595b397ae0))
    (fp_line (start -1.6 0.8) (end -1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp 06858adf-7eb9-493f-9952-64aa5b169fd1))
    (fp_line (start 1.6 0.8) (end -1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp 17f144de-2c0a-4e20-86b9-b05e32145605))
    (fp_line (start 1.6 -0.8) (end 1.6 0.8) (layer "F.Fab") (width 0.1) (tstamp 6f2ea27a-1621-4cbc-a6b9-b4d4ebc5c377))
    (fp_line (start -1.6 -0.8) (end 1.6 -0.8) (layer "F.Fab") (width 0.1) (tstamp d8304c60-9740-4865-a200-151c5c9a7f37))
      (net 85 "Net-(C20-Pad1)") (pintype "passive") (tstamp fd35d1b4-02c5-43b7-b647-e07172d849d0))
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp d0943343-9b34-41c4-9573-3c5dc5c9031a))
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp fad8b725-c7de-4971-8d0a-18f16317975f)
    (at 51.181 80.518)
    (path "/828c1496-aaea-4d79-8985-2ae686a37013")
    (attr smd)
    (fp_text reference "R50" (at 0.889 -6.985) (layer "F.SilkS")
      (tstamp 187a5772-fe95-4650-9beb-6c7b7468ee47)
      (tstamp 64b33f60-31ba-4367-9bd0-fe4904d86433)
    (fp_text user "${REFERENCE}" (at 0 0.121) (layer "F.Fab")
      (tstamp 1611ed43-3ec4-4ca9-8e0b-6149eca1a074)
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp 5bdb5243-edab-4ec7-b06f-480d3ec23d58))
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp c48e5163-e1fc-404e-84e0-4279d5dcccff))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 324f8c31-41bc-4bd3-8831-a5340f056044))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 515e5772-510d-4970-81a9-ff86e6da2c45))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp c19efc5d-5f21-437c-b76f-560a6736bff3))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp fd0a1399-8fe8-416e-9a76-0d8bb092d571))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 451ad284-5f74-4f2a-a16f-c2d02f4da6c6))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 4e4dacf0-ff57-48c3-89ea-8688122682a5))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp a98b8084-5554-4640-9b39-08b1e9994c51))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp db9798cd-2af2-4ee5-ac93-a161069fa79e))
      (net 79 "Net-(R50-Pad1)") (pintype "passive") (tstamp 6d3376a8-098f-41d9-9563-f5591c9dec6d))
      (net 34 "Net-(J14-Pad20)") (pintype "passive") (tstamp 7548ce2a-af25-4361-acb1-c5c77e3e6925))
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp fb927f3f-35c9-4762-9abc-9defd9309c4b)
    (at 51.181 76.708)
    (path "/d065145b-5f7c-4e43-a22e-99517bdacc51")
    (attr smd)
    (fp_text reference "R43" (at 0.889 -4.572) (layer "F.SilkS")
      (tstamp 558d4cef-63d8-4bd7-8163-9f0f97015d0b)
      (tstamp 61807789-fecf-4af0-a2d5-318407d29118)
    (fp_text user "${REFERENCE}" (at 0 0) (layer "F.Fab")
      (tstamp 2dcfd466-076e-44d1-beb5-09d0115744f7)
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 83e3202b-a882-4fd9-afce-aabc1c8d6256))
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp c2e38ae8-d382-48aa-8af0-3c4fc605bf1a))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 072a747f-fdbb-4a3e-b286-e72c8636ae7f))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 80a0fc06-9f78-4445-8d9f-4e280337717a))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp a4c7d9a3-4c8e-4cb1-b5a4-f9cc7113c83a))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp b283a74e-5310-480c-9d32-0c91ad6c78c0))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 07c0a9b6-eac1-4f27-8dd8-b0cc9f99d784))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 758c3f63-894f-4446-bd1e-ff851526b07b))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 9e037771-9f3e-4b13-ba1d-48a28df177a1))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp dd125ff0-006f-48c3-a508-bd0c51ab046f))
      (net 72 "Net-(R43-Pad1)") (pintype "passive") (tstamp f24e7d9f-7a3f-4782-89f9-08f33f34ea88))
      (net 33 "Net-(J14-Pad19)") (pintype "passive") (tstamp b90456c2-7dac-4ac7-abfd-4789f3e34471))
      (scale (xyz 1 1 1))
  (footprint "Capacitor_THT:CP_Radial_D12.5mm_P5.00mm" (layer "F.Cu")
    (tedit 5AE50EF1) (tstamp fbb58511-6435-4a77-a88d-22e97743ab23)
    (at 150.241 73.189959 90)
    (descr "CP, Radial series, Radial, pin pitch=5.00mm, , diameter=12.5mm, Electrolytic Capacitor")
    (tags "CP Radial series Radial pin pitch 5.00mm  diameter 12.5mm Electrolytic Capacitor")
    (path "/3e079e30-e94e-4b5f-b20b-0a1362959815")
    (attr through_hole)
    (fp_text reference "C16" (at 2.5 -7.5 90) (layer "F.SilkS")
      (tstamp 8292b581-b706-43ec-b752-6965697d8ac2)
    (fp_text value "ELKO 680/35 FK 1500/35 AM" (at 2.5 7.5 90) (layer "F.Fab")
      (tstamp b7466c98-6cbd-4ac7-9a80-dc21692a588c)
    (fp_text user "${REFERENCE}" (at 2.5 0 90) (layer "F.Fab")
      (tstamp 70ee9f81-c47c-4ffb-883e-164c33de8cbc)
    (fp_line (start 4.461 1.44) (end 4.461 6.021) (layer "F.SilkS") (width 0.12) (tstamp 002f51aa-c7e7-4087-8125-48031c9fb67f))
    (fp_line (start 4.541 -5.995) (end 4.541 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 011f6f9c-ea3f-45c5-b0eb-b2f7551184b7))
    (fp_line (start 4.661 1.44) (end 4.661 5.953) (layer "F.SilkS") (width 0.12) (tstamp 02209372-af2f-42ef-b869-3238167382bc))
    (fp_line (start 6.101 -5.216) (end 6.101 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 035d59fd-32eb-4855-a838-fecaef153fe8))
    (fp_line (start 4.141 -6.116) (end 4.141 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 041552d0-d065-40ee-b69d-c3fbd475fbff))
    (fp_line (start 5.781 1.44) (end 5.781 5.421) (layer "F.SilkS") (width 0.12) (tstamp 04f391a7-8c5e-4e25-8a19-bc859aa866d1))
    (fp_line (start 6.541 -4.885) (end 6.541 4.885) (layer "F.SilkS") (width 0.12) (tstamp 06044cef-b2b1-46a7-8173-c8bdabf00675))
    (fp_line (start 6.741 -4.714) (end 6.741 4.714) (layer "F.SilkS") (width 0.12) (tstamp 06339130-a0eb-4cdb-afc7-59056c1f9ee4))
    (fp_line (start 5.581 -5.536) (end 5.581 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 06eca415-4ca2-452c-aeb7-0b36d5329159))
    (fp_line (start 4.341 1.44) (end 4.341 6.059) (layer "F.SilkS") (width 0.12) (tstamp 06f359f7-c206-4b1c-8276-907caf71ec42))
    (fp_line (start 5.341 1.44) (end 5.341 5.662) (layer "F.SilkS") (width 0.12) (tstamp 077182e0-41a0-48d4-b5be-2d2bddb31988))
    (fp_line (start 5.061 -5.793) (end 5.061 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 098fed26-190a-46a8-9742-3bcc3313fa99))
    (fp_line (start 5.741 -5.445) (end 5.741 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 0a475659-86e4-404b-aa7d-11661607b56d))
    (fp_line (start 4.221 1.44) (end 4.221 6.094) (layer "F.SilkS") (width 0.12) (tstamp 0ac25b9e-76c7-4fcc-b461-9cf5825b786d))
    (fp_line (start 4.101 1.44) (end 4.101 6.126) (layer "F.SilkS") (width 0.12) (tstamp 0b84276b-99ef-4805-940e-d0ba679403e4))
    (fp_line (start 5.461 1.44) (end 5.461 5.601) (layer "F.SilkS") (width 0.12) (tstamp 0d60aa82-a32f-4c4b-890c-269450af7f82))
    (fp_line (start 6.061 1.44) (end 6.061 5.243) (layer "F.SilkS") (width 0.12) (tstamp 0e905b3d-71d8-433f-8e33-e3ca7fac3cfd))
    (fp_line (start 7.421 -4.007) (end 7.421 4.007) (layer "F.SilkS") (width 0.12) (tstamp 0fd21fe3-f461-4c7d-ab29-c547b408c1a7))
    (fp_line (start 4.981 -5.828) (end 4.981 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 11e4b71c-9efb-4c4b-8c50-b64c2db1a220))
    (fp_line (start 6.301 1.44) (end 6.301 5.073) (layer "F.SilkS") (width 0.12) (tstamp 12cd764e-0cbd-4cdc-b8e3-852283ea7c19))
    (fp_line (start 4.261 -6.083) (end 4.261 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 1345a590-48c5-445e-88db-407a87aec5b8))
    (fp_line (start 6.261 1.44) (end 6.261 5.102) (layer "F.SilkS") (width 0.12) (tstamp 145ed5a3-bad7-49ce-9342-3050726f71b2))
    (fp_line (start 4.581 1.44) (end 4.581 5.981) (layer "F.SilkS") (width 0.12) (tstamp 15ba611f-40da-4737-9894-3d90525c5b9e))
    (fp_line (start 7.141 -4.325) (end 7.141 4.325) (layer "F.SilkS") (width 0.12) (tstamp 15c925ff-2229-453c-8e98-b3e38f691010))
    (fp_line (start 7.501 -3.907) (end 7.501 3.907) (layer "F.SilkS") (width 0.12) (tstamp 16001636-7b3e-4ba5-ba14-2fd87edfe1da))
    (fp_line (start 3.621 -6.231) (end 3.621 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 16d90fe3-a0c5-4771-8a5c-c0b8cbca7879))
    (fp_line (start 4.301 1.44) (end 4.301 6.071) (layer "F.SilkS") (width 0.12) (tstamp 197ee5af-942b-4c3f-964a-afd197767b64))
    (fp_line (start 5.701 -5.468) (end 5.701 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 1a4ce599-8cc3-4207-802e-93b68223f825))
    (fp_line (start 7.901 -3.339) (end 7.901 3.339) (layer "F.SilkS") (width 0.12) (tstamp 1a9aedf3-97f8-4928-9a0e-2460e6583126))
    (fp_line (start 8.261 -2.681) (end 8.261 2.681) (layer "F.SilkS") (width 0.12) (tstamp 1b6d50d2-157f-4737-90c9-b6a82f61056a))
    (fp_line (start 3.861 1.44) (end 3.861 6.184) (layer "F.SilkS") (width 0.12) (tstamp 1be75901-f1ec-44cf-b64a-7d0cff2e4cab))
    (fp_line (start 3.781 -6.201) (end 3.781 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 1bf3fdc3-61f8-4b36-9e23-1866e17d6061))
    (fp_line (start 5.301 -5.682) (end 5.301 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 1c66980e-5e1e-4924-9c99-4988ac6d90f7))
    (fp_line (start 7.821 -3.464) (end 7.821 3.464) (layer "F.SilkS") (width 0.12) (tstamp 1d5467bc-b797-4320-af81-2adc00fc99a2))
    (fp_line (start 6.701 -4.75) (end 6.701 4.75) (layer "F.SilkS") (width 0.12) (tstamp 20fcacee-2c85-43cf-b0bd-d0bd12691723))
    (fp_line (start 3.661 -6.224) (end 3.661 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 2162964b-cdf9-4828-b07d-91b0df447f40))
    (fp_line (start 6.421 1.44) (end 6.421 4.982) (layer "F.SilkS") (width 0.12) (tstamp 217d2943-d069-41fd-9c98-30d90afce8a3))
    (fp_line (start 5.181 1.44) (end 5.181 5.739) (layer "F.SilkS") (width 0.12) (tstamp 2339cbdb-a1f0-437e-a44d-65ef6c97651b))
    (fp_line (start 4.741 1.44) (end 4.741 5.924) (layer "F.SilkS") (width 0.12) (tstamp 2438a7f2-b2b7-4a74-b29b-08d75abdacad))
    (fp_line (start 5.621 1.44) (end 5.621 5.514) (layer "F.SilkS") (width 0.12) (tstamp 24dbce5a-ed71-4541-bc7a-b25755cbd1ac))
    (fp_line (start 6.381 1.44) (end 6.381 5.012) (layer "F.SilkS") (width 0.12) (tstamp 27ca7cb3-110d-466d-a03f-caefbb252b8f))
    (fp_line (start 2.58 -6.33) (end 2.58 6.33) (layer "F.SilkS") (width 0.12) (tstamp 27dc0a17-0191-4c66-a72e-22b84d5d7fce))
    (fp_line (start 2.86 -6.32) (end 2.86 6.32) (layer "F.SilkS") (width 0.12) (tstamp 2898ec18-206f-412f-b542-7f57cfc0dc8d))
    (fp_line (start 8.101 -2.996) (end 8.101 2.996) (layer "F.SilkS") (width 0.12) (tstamp 29082b5a-aeed-4cbe-bc81-38687df46541))
    (fp_line (start 4.181 -6.105) (end 4.181 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 2a0268b2-0ca8-4523-9890-c0de5aac715a))
    (fp_line (start 3.1 -6.302) (end 3.1 6.302) (layer "F.SilkS") (width 0.12) (tstamp 2a218209-e364-4ff1-8f98-c4939b505802))
    (fp_line (start 5.421 1.44) (end 5.421 5.622) (layer "F.SilkS") (width 0.12) (tstamp 2af3edf8-4745-439e-8815-9570aa36a05d))
    (fp_line (start 5.861 1.44) (end 5.861 5.372) (layer "F.SilkS") (width 0.12) (tstamp 2cabfa24-3962-4967-9de5-28f9c68a90d0))
    (fp_line (start 5.261 1.44) (end 5.261 5.702) (layer "F.SilkS") (width 0.12) (tstamp 2e68214e-62a8-4734-b38e-be7abf9defd4))
    (fp_line (start 4.621 1.44) (end 4.621 5.967) (layer "F.SilkS") (width 0.12) (tstamp 2f677fa5-6ebe-4feb-a29a-fd50651927d8))
    (fp_line (start 2.82 -6.322) (end 2.82 6.322) (layer "F.SilkS") (width 0.12) (tstamp 2fdf7d07-23ba-4288-9c03-c4774cc8cd41))
    (fp_line (start -3.692082 -4.2) (end -3.692082 -2.95) (layer "F.SilkS") (width 0.12) (tstamp 30ddd1d2-9150-42fe-b2c6-a6d3608500a5))
    (fp_line (start 5.661 1.44) (end 5.661 5.491) (layer "F.SilkS") (width 0.12) (tstamp 324bb4d6-89a8-47f2-b1ed-f126d8f7bcb0))
    (fp_line (start 2.74 -6.326) (end 2.74 6.326) (layer "F.SilkS") (width 0.12) (tstamp 33b65b5b-1013-4774-bc8f-0827b1d9b12f))
    (fp_line (start 6.981 -4.489) (end 6.981 4.489) (layer "F.SilkS") (width 0.12) (tstamp 34bb016c-b134-4cfa-a553-124cbe80e181))
    (fp_line (start 6.181 1.44) (end 6.181 5.16) (layer "F.SilkS") (width 0.12) (tstamp 34c6d1d4-1aad-42db-9e03-ac8f09c7c89a))
    (fp_line (start 7.381 -4.055) (end 7.381 4.055) (layer "F.SilkS") (width 0.12) (tstamp 358b79e3-e2a6-4053-ad77-5b5b9855d2f4))
    (fp_line (start 4.021 -6.146) (end 4.021 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 3930713a-54b1-4f0e-80c1-eae69ccafec7))
    (fp_line (start 5.621 -5.514) (end 5.621 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 3a20c4be-6d0c-4ed7-80a0-73a2eac4d1a9))
    (fp_line (start 8.341 -2.504) (end 8.341 2.504) (layer "F.SilkS") (width 0.12) (tstamp 3a6333b7-c82a-43b1-924a-aef6fb926422))
    (fp_line (start 3.861 -6.184) (end 3.861 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 3d85bc58-4b4b-490f-a538-adca22c274b0))
    (fp_line (start 3.581 1.44) (end 3.581 6.238) (layer "F.SilkS") (width 0.12) (tstamp 3dd16ed2-fe47-4dd6-ba27-7a82cd69a426))
    (fp_line (start 7.021 -4.449) (end 7.021 4.449) (layer "F.SilkS") (width 0.12) (tstamp 3e3ed570-fee6-4f49-a753-4ba2a0901626))
    (fp_line (start 3.421 -6.264) (end 3.421 6.264) (layer "F.SilkS") (width 0.12) (tstamp 3e5922fb-7a56-410e-8a93-b8c599deeefa))
    (fp_line (start 3.821 -6.192) (end 3.821 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 3ee3988c-e9a3-4e1f-b8ad-b753b8b51695))
    (fp_line (start 5.021 -5.811) (end 5.021 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 3f7e2a45-e4ef-4b5c-9b41-72c2f022687b))
    (fp_line (start 4.061 1.44) (end 4.061 6.137) (layer "F.SilkS") (width 0.12) (tstamp 42ab536a-9903-4340-88e2-94816677fb23))
    (fp_line (start 4.941 1.44) (end 4.941 5.845) (layer "F.SilkS") (width 0.12) (tstamp 463bb006-e773-4275-a7dd-6fc9cbbe1173))
    (fp_line (start 7.181 -4.282) (end 7.181 4.282) (layer "F.SilkS") (width 0.12) (tstamp 46a6be61-7c11-4c05-b5df-10fda7bd2813))
    (fp_line (start 4.781 -5.908) (end 4.781 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 4754202e-982c-40e8-a4f7-490875afef4e))
    (fp_line (start 3.14 -6.298) (end 3.14 6.298) (layer "F.SilkS") (width 0.12) (tstamp 4adec132-7f92-474e-850a-6bac0b6aaa57))
    (fp_line (start 5.421 -5.622) (end 5.421 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 4cb32264-27c0-4b81-90fb-9564b0ad6468))
    (fp_line (start 5.901 -5.347) (end 5.901 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 4d6408fb-5830-41dd-97e8-0feaf4f86128))
    (fp_line (start 4.621 -5.967) (end 4.621 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 4d77182e-174b-4d8d-9f1f-8cbdf1a3aae7))
    (fp_line (start 8.181 -2.844) (end 8.181 2.844) (layer "F.SilkS") (width 0.12) (tstamp 4e00d21a-4241-4f3e-b516-7fe79995da6b))
    (fp_line (start 4.021 1.44) (end 4.021 6.146) (layer "F.SilkS") (width 0.12) (tstamp 4fd905ac-bed5-4c27-b187-42a418aaa054))
    (fp_line (start 5.901 1.44) (end 5.901 5.347) (layer "F.SilkS") (width 0.12) (tstamp 5032bae0-6e8e-4e94-8beb-dec1714b612d))
    (fp_line (start 5.501 -5.58) (end 5.501 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 505df086-ab74-46f9-8905-8ec1b420072d))
    (fp_line (start 5.181 -5.739) (end 5.181 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 50731191-7f27-46c2-a1c4-92938d9fef78))
    (fp_line (start 4.701 1.44) (end 4.701 5.939) (layer "F.SilkS") (width 0.12) (tstamp 509a95c5-b4be-47c6-9017-0fc25a2affa8))
    (fp_line (start 4.261 1.44) (end 4.261 6.083) (layer "F.SilkS") (width 0.12) (tstamp 51dd28d6-d0d8-49f1-8459-6450df6a083c))
    (fp_line (start 3.981 1.44) (end 3.981 6.156) (layer "F.SilkS") (width 0.12) (tstamp 541eee66-d61a-4440-89ea-5b14c9bbe372))
    (fp_line (start 8.581 -1.861) (end 8.581 1.861) (layer "F.SilkS") (width 0.12) (tstamp 55c4519d-e3af-4230-bc5f-82846f403768))
    (fp_line (start 8.861 -0.317) (end 8.861 0.317) (layer "F.SilkS") (width 0.12) (tstamp 55e703e8-0216-4ae5-a909-dbdabc420b87))
    (fp_line (start 6.461 -4.95) (end 6.461 4.95) (layer "F.SilkS") (width 0.12) (tstamp 587ffd7f-7d06-428e-932e-9b0312ef9d7d))
    (fp_line (start 5.221 -5.721) (end 5.221 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 59399936-0085-4610-9f3e-84d9ddb0aa63))
    (fp_line (start 3.741 -6.209) (end 3.741 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 59472962-6cc4-4760-950d-ca2387e23ad7))
    (fp_line (start 8.741 -1.241) (end 8.741 1.241) (layer "F.SilkS") (width 0.12) (tstamp 59b61853-7da3-4119-89e9-3d49e45e7e49))
    (fp_line (start 4.701 -5.939) (end 4.701 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 5a8cbb79-634e-40e6-927a-f7f956147e3b))
    (fp_line (start 5.381 1.44) (end 5.381 5.642) (layer "F.SilkS") (width 0.12) (tstamp 5aa0a4f4-fe28-4bc9-bf16-41d29debf80a))
    (fp_line (start 4.901 -5.861) (end 4.901 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 5f6feb46-b4ea-464b-b907-4dcca8985435))
    (fp_line (start 8.821 -0.757) (end 8.821 0.757) (layer "F.SilkS") (width 0.12) (tstamp 600109d3-e0f5-4af2-af98-09c7114ef805))
    (fp_line (start 8.541 -1.984) (end 8.541 1.984) (layer "F.SilkS") (width 0.12) (tstamp 60f6f277-9939-4c02-b601-5459b31380a6))
    (fp_line (start 7.061 -4.408) (end 7.061 4.408) (layer "F.SilkS") (width 0.12) (tstamp 61438ab4-b49f-47e1-a870-c94c40999abd))
    (fp_line (start 7.741 -3.583) (end 7.741 3.583) (layer "F.SilkS") (width 0.12) (tstamp 61999e60-af90-42ba-8033-5bddbb012dbf))
    (fp_line (start 5.061 1.44) (end 5.061 5.793) (layer "F.SilkS") (width 0.12) (tstamp 62d24a53-34dd-4e4b-ae15-f26b734b0e1a))
    (fp_line (start 8.021 -3.14) (end 8.021 3.14) (layer "F.SilkS") (width 0.12) (tstamp 63536356-d26f-46fa-9d8a-761cff677686))
    (fp_line (start 5.341 -5.662) (end 5.341 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 6484a25d-5b9b-4a5a-8d20-80ca71c57c24))
    (fp_line (start 3.941 -6.166) (end 3.941 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 67aafe5f-d31e-4798-bbcc-22c40cdb64f6))
    (fp_line (start 4.101 -6.126) (end 4.101 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 67c463b8-27eb-4975-99da-92ced8326a31))
    (fp_line (start 4.461 -6.021) (end 4.461 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 683a911b-6714-489d-9db9-c4f1d3621962))
    (fp_line (start 8.421 -2.312) (end 8.421 2.312) (layer "F.SilkS") (width 0.12) (tstamp 68f7d54d-0601-47e4-bdc5-7a856776ba7d))
    (fp_line (start 7.941 -3.275) (end 7.941 3.275) (layer "F.SilkS") (width 0.12) (tstamp 6955f62f-db13-4d10-8143-f6c854d86db9))
    (fp_line (start 3.821 1.44) (end 3.821 6.192) (layer "F.SilkS") (width 0.12) (tstamp 6959920f-c449-4beb-9a78-1e0aee837ca0))
    (fp_line (start 7.701 -3.64) (end 7.701 3.64) (layer "F.SilkS") (width 0.12) (tstamp 6b322c81-12d6-4695-bbc6-a379ee7d55ed))
    (fp_line (start 6.861 -4.605) (end 6.861 4.605) (layer "F.SilkS") (width 0.12) (tstamp 71133488-e9e4-4d79-8db6-2cdd7fed824d))
    (fp_line (start 3.381 -6.269) (end 3.381 6.269) (layer "F.SilkS") (width 0.12) (tstamp 738578c9-0453-479a-ad2f-f25b100d1032))
    (fp_line (start 4.341 -6.059) (end 4.341 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 74a95e3b-01be-46fb-a5a5-02a32f36686f))
    (fp_line (start 4.901 1.44) (end 4.901 5.861) (layer "F.SilkS") (width 0.12) (tstamp 75d2f709-d52b-4d37-806d-cb02ccc296dd))
    (fp_line (start 4.381 -6.047) (end 4.381 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 769f29c2-09fe-4105-a5c9-e41fd96ef34e))
    (fp_line (start 4.221 -6.094) (end 4.221 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 77bed390-2a12-4dea-9a81-513225c62c8d))
    (fp_line (start 3.661 1.44) (end 3.661 6.224) (layer "F.SilkS") (width 0.12) (tstamp 78d70388-14cc-4035-8c07-ccad3078b6c5))
    (fp_line (start 4.861 1.44) (end 4.861 5.877) (layer "F.SilkS") (width 0.12) (tstamp 791b60d2-10e2-483e-afeb-99c71bf2e2df))
    (fp_line (start 4.501 1.44) (end 4.501 6.008) (layer "F.SilkS") (width 0.12) (tstamp 7a37324c-6950-471d-bd15-e9dd1c91438c))
    (fp_line (start 7.301 -4.148) (end 7.301 4.148) (layer "F.SilkS") (width 0.12) (tstamp 7b6405d4-ea4a-4cad-acc6-2f3ffc788bd1))
    (fp_line (start 3.501 -6.252) (end 3.501 6.252) (layer "F.SilkS") (width 0.12) (tstamp 7decfdad-37d8-4bcf-9641-7d9d240a9e77))
    (fp_line (start 5.301 1.44) (end 5.301 5.682) (layer "F.SilkS") (width 0.12) (tstamp 7f503718-a5b9-4122-bece-631411ee07bb))
    (fp_line (start 5.501 1.44) (end 5.501 5.58) (layer "F.SilkS") (width 0.12) (tstamp 824e57f7-055a-4223-a12b-0caea5067dab))
    (fp_line (start 4.821 1.44) (end 4.821 5.893) (layer "F.SilkS") (width 0.12) (tstamp 82b6433e-3d08-4de6-bdd6-2c1e124f8f87))
    (fp_line (start 7.981 -3.208) (end 7.981 3.208) (layer "F.SilkS") (width 0.12) (tstamp 83ec2c87-569f-45a0-a8ac-e459ba57d95d))
    (fp_line (start 6.341 1.44) (end 6.341 5.043) (layer "F.SilkS") (width 0.12) (tstamp 8408c3e7-bfd2-4bff-9baf-ba5468af9f2d))
    (fp_line (start 3.461 -6.258) (end 3.461 6.258) (layer "F.SilkS") (width 0.12) (tstamp 84b260e0-3e44-414a-8891-0106b8e9a5b6))
    (fp_line (start 5.941 1.44) (end 5.941 5.322) (layer "F.SilkS") (width 0.12) (tstamp 861a6c6e-5f1c-400c-8e65-831a13002151))
    (fp_line (start 6.181 -5.16) (end 6.181 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 872c97cb-a887-41b6-8a33-27707e229de7))
    (fp_line (start 2.7 -6.327) (end 2.7 6.327) (layer "F.SilkS") (width 0.12) (tstamp 87b5715f-9c40-47b8-a154-60f2cda69c79))
    (fp_line (start 5.101 1.44) (end 5.101 5.776) (layer "F.SilkS") (width 0.12) (tstamp 87fcfe67-2929-4b9c-84b0-d0a4628c2309))
    (fp_line (start 8.461 -2.209) (end 8.461 2.209) (layer "F.SilkS") (width 0.12) (tstamp 8995a143-ea3b-4f5e-a312-9ea3ae87e457))
    (fp_line (start 5.861 -5.372) (end 5.861 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 89c505cd-e626-4aed-b9fa-469e4375b2a9))
    (fp_line (start 3.901 -6.175) (end 3.901 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 8b5dc5ba-f5e9-4929-a4f6-9859e01ff334))
    (fp_line (start 4.061 -6.137) (end 4.061 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 8b811596-8160-49d9-9eba-c7e0ee513b0a))
    (fp_line (start 4.181 1.44) (end 4.181 6.105) (layer "F.SilkS") (width 0.12) (tstamp 8d63f2e9-df01-4f56-a2a9-cfc4bc5dd817))
    (fp_line (start 5.781 -5.421) (end 5.781 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 8dc7b789-118f-41f4-b427-ec348d6db679))
    (fp_line (start 6.221 1.44) (end 6.221 5.131) (layer "F.SilkS") (width 0.12) (tstamp 8f0bcae3-70e3-4f8b-975e-f748299f691a))
    (fp_line (start 3.581 -6.238) (end 3.581 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 8f21601b-be1b-4740-93fd-bf84ef0edcd3))
    (fp_line (start 4.861 -5.877) (end 4.861 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 92caf3a8-31b4-4861-b287-97db4ff6ef0b))
    (fp_line (start 6.221 -5.131) (end 6.221 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 93fd2a38-1196-4943-8479-5874c0338445))
    (fp_line (start 5.141 1.44) (end 5.141 5.758) (layer "F.SilkS") (width 0.12) (tstamp 941a8ec9-65a3-4667-9d53-4ee0529a6d4b))
    (fp_line (start 7.221 -4.238) (end 7.221 4.238) (layer "F.SilkS") (width 0.12) (tstamp 971b9320-0dec-4d70-b9da-93a6d30df649))
    (fp_line (start 3.541 -6.245) (end 3.541 6.245) (layer "F.SilkS") (width 0.12) (tstamp 99962306-2734-4c13-a01b-7cad0c386021))
    (fp_line (start 8.141 -2.921) (end 8.141 2.921) (layer "F.SilkS") (width 0.12) (tstamp 999ba9a9-f468-4caa-acff-cebec233a64d))
    (fp_line (start 2.94 -6.315) (end 2.94 6.315) (layer "F.SilkS") (width 0.12) (tstamp 9a461803-9560-4173-903d-0086d9f27493))
    (fp_line (start 6.261 -5.102) (end 6.261 -1.44) (layer "F.SilkS") (width 0.12) (tstamp 9f005a07-3b0e-44a0-9662-ec8611f3e76b))
    (fp_line (start 6.781 -4.678) (end 6.781 4.678) (layer "F.SilkS") (width 0.12) (tstamp a0701d54-4163-4053-a89b-d032bc6fe574))
    (fp_line (start 6.141 -5.188) (end 6.141 -1.44) (layer "F.SilkS") (width 0.12) (tstamp a37eaa94-7a53-47a4-acb5-0e30647d083f))
    (fp_line (start 5.141 -5.758) (end 5.141 -1.44) (layer "F.SilkS") (width 0.12) (tstamp a386f8f7-1f2b-452f-9799-c74b41220334))
    (fp_line (start 6.421 -4.982) (end 6.421 -1.44) (layer "F.SilkS") (width 0.12) (tstamp a3da89c8-2cec-443d-8f4a-913d9a7cc882))
    (fp_line (start 5.461 -5.601) (end 5.461 -1.44) (layer "F.SilkS") (width 0.12) (tstamp a4341b61-a0ac-4e20-81ef-b464543cadb3))
    (fp_line (start 2.5 -6.33) (end 2.5 6.33) (layer "F.SilkS") (width 0.12) (tstamp a4bf06a1-a76e-4bf1-bad8-69da6dd55092))
    (fp_line (start 6.021 1.44) (end 6.021 5.27) (layer "F.SilkS") (width 0.12) (tstamp a50f5a7a-87e8-42e7-bc9f-143a6ca9ace4))
    (fp_line (start 5.821 1.44) (end 5.821 5.397) (layer "F.SilkS") (width 0.12) (tstamp a63642ca-3180-4cfe-b3b9-89d156779efc))
    (fp_line (start 3.18 -6.294) (end 3.18 6.294) (layer "F.SilkS") (width 0.12) (tstamp a6fed7dd-96b6-4d93-b1d1-3b30e1006ada))
    (fp_line (start 6.061 -5.243) (end 6.061 -1.44) (layer "F.SilkS") (width 0.12) (tstamp a7350a2a-c60e-44e3-9d5a-ce13f23d59e4))
    (fp_line (start 4.541 1.44) (end 4.541 5.995) (layer "F.SilkS") (width 0.12) (tstamp a74657d3-cbed-4d99-801d-da2446f81583))
    (fp_line (start 5.581 1.44) (end 5.581 5.536) (layer "F.SilkS") (width 0.12) (tstamp a7d13465-09d1-4b39-a8a2-b40c5c8fc922))
    (fp_line (start 4.301 -6.071) (end 4.301 -1.44) (layer "F.SilkS") (width 0.12) (tstamp a87ea870-d931-4bd5-9c15-5aba9e65defa))
    (fp_line (start 8.381 -2.41) (end 8.381 2.41) (layer "F.SilkS") (width 0.12) (tstamp a88f38b7-2f19-4ed1-a86c-ba8e1492bafb))
    (fp_line (start 5.541 -5.558) (end 5.541 -1.44) (layer "F.SilkS") (width 0.12) (tstamp aa35444f-a72e-4bfb-8267-2fe44742fcd5))
    (fp_line (start 8.701 -1.422) (end 8.701 1.422) (layer "F.SilkS") (width 0.12) (tstamp aaffcd2a-a7f3-4c18-8b66-bcceaf5d1776))
    (fp_line (start 8.221 -2.764) (end 8.221 2.764) (layer "F.SilkS") (width 0.12) (tstamp abe7cc13-0676-49d2-985b-165c28425635))
    (fp_line (start 6.941 -4.528) (end 6.941 4.528) (layer "F.SilkS") (width 0.12) (tstamp ad99ebe9-3af9-482d-a0a7-47bdb91761a5))
    (fp_line (start 6.821 -4.642) (end 6.821 4.642) (layer "F.SilkS") (width 0.12) (tstamp af52d125-f1db-4e62-a4c0-b692ea79f2ec))
    (fp_line (start 2.98 -6.312) (end 2.98 6.312) (layer "F.SilkS") (width 0.12) (tstamp afa21252-ca2d-4568-ac50-840a92235be4))
    (fp_line (start 6.621 -4.819) (end 6.621 4.819) (layer "F.SilkS") (width 0.12) (tstamp b11f4fb4-042f-4042-9f84-05d225775ae9))
    (fp_line (start 5.221 1.44) (end 5.221 5.721) (layer "F.SilkS") (width 0.12) (tstamp b3cb9953-372f-4151-9490-797880a65f5e))
    (fp_line (start 3.06 -6.306) (end 3.06 6.306) (layer "F.SilkS") (width 0.12) (tstamp b40a2fe9-557f-429d-ab13-857923ef7470))
    (fp_line (start 4.821 -5.893) (end 4.821 -1.44) (layer "F.SilkS") (width 0.12) (tstamp b4d0b44d-40f9-46c7-ae9a-c599ac1cd840))
    (fp_line (start 3.221 -6.29) (end 3.221 6.29) (layer "F.SilkS") (width 0.12) (tstamp b5ab1eb4-cac9-48cf-8b17-209f3112d5b0))
    (fp_line (start 6.101 1.44) (end 6.101 5.216) (layer "F.SilkS") (width 0.12) (tstamp b6677b3e-15aa-4978-a734-96bb29843f83))
    (fp_line (start 3.261 -6.285) (end 3.261 6.285) (layer "F.SilkS") (width 0.12) (tstamp b85dcb3f-e28a-4295-ac49-b671d902a419))
    (fp_line (start 3.341 -6.275) (end 3.341 6.275) (layer "F.SilkS") (width 0.12) (tstamp b995ebe8-00f5-4fc6-8e84-59e34e6d96a5))
    (fp_line (start 3.941 1.44) (end 3.941 6.166) (layer "F.SilkS") (width 0.12) (tstamp baf466ed-c8f0-49fd-b525-fb30f478a05d))
    (fp_line (start 7.861 -3.402) (end 7.861 3.402) (layer "F.SilkS") (width 0.12) (tstamp bb6e3b46-350d-4087-be72-a9cd7c075486))
    (fp_line (start 6.341 -5.043) (end 6.341 -1.44) (layer "F.SilkS") (width 0.12) (tstamp bbe1205c-b6ef-4ec8-9527-7943ae68b193))
    (fp_line (start 5.741 1.44) (end 5.741 5.445) (layer "F.SilkS") (width 0.12) (tstamp bcb2c93d-375b-424e-b195-bd07141378ab))
    (fp_line (start 6.021 -5.27) (end 6.021 -1.44) (layer "F.SilkS") (width 0.12) (tstamp be57e9bc-9f16-4c72-a9ed-77bcdcce4131))
    (fp_line (start 8.621 -1.728) (end 8.621 1.728) (layer "F.SilkS") (width 0.12) (tstamp bf33141a-a328-4ef9-971f-efa4d5e1157c))
    (fp_line (start 2.9 -6.318) (end 2.9 6.318) (layer "F.SilkS") (width 0.12) (tstamp bf938930-6527-437e-9678-7d7f8ac94e71))
    (fp_line (start 8.061 -3.069) (end 8.061 3.069) (layer "F.SilkS") (width 0.12) (tstamp c0090dd3-ec00-4d0f-9504-f7fa4dde6461))
    (fp_line (start 5.661 -5.491) (end 5.661 -1.44) (layer "F.SilkS") (width 0.12) (tstamp c03e539d-d181-4ac4-a97f-1e103f24374f))
    (fp_line (start 3.701 1.44) (end 3.701 6.216) (layer "F.SilkS") (width 0.12) (tstamp c11015b3-099d-43b7-8a07-a0b4f7cf7648))
    (fp_line (start 3.701 -6.216) (end 3.701 -1.44) (layer "F.SilkS") (width 0.12) (tstamp c11f55af-1c6f-4310-b13a-4b7c8b033d13))
    (fp_line (start 7.101 -4.367) (end 7.101 4.367) (layer "F.SilkS") (width 0.12) (tstamp c2f7688e-d627-4be6-8214-730702238687))
    (fp_line (start 5.021 1.44) (end 5.021 5.811) (layer "F.SilkS") (width 0.12) (tstamp c59cc071-7bdb-4309-b911-2adee85cdab9))
    (fp_line (start 5.541 1.44) (end 5.541 5.558) (layer "F.SilkS") (width 0.12) (tstamp c6855934-66a1-4ddc-95eb-1224093c2b32))
    (fp_line (start 2.66 -6.328) (end 2.66 6.328) (layer "F.SilkS") (width 0.12) (tstamp c75ffaa6-4656-4946-ad7b-20c26c1bff9a))
    (fp_line (start 5.261 -5.702) (end 5.261 -1.44) (layer "F.SilkS") (width 0.12) (tstamp ca3862bc-73af-4c84-810d-cd9b92b6f016))
    (fp_line (start 3.621 1.44) (end 3.621 6.231) (layer "F.SilkS") (width 0.12) (tstamp caf942e7-3950-4b3a-abe8-d1a39d84d96f))
    (fp_line (start 4.141 1.44) (end 4.141 6.116) (layer "F.SilkS") (width 0.12) (tstamp cb12a97f-bdeb-4574-bb42-fb78c5b41261))
    (fp_line (start 7.341 -4.102) (end 7.341 4.102) (layer "F.SilkS") (width 0.12) (tstamp cb69fd04-bfe3-4021-98e3-c93a3cf36f07))
    (fp_line (start 3.741 1.44) (end 3.741 6.209) (layer "F.SilkS") (width 0.12) (tstamp cc29586c-5b06-4fc2-9842-32415a15bed2))
    (fp_line (start 4.661 -5.953) (end 4.661 -1.44) (layer "F.SilkS") (width 0.12) (tstamp cde88fec-7a5e-408f-a4e8-05f37a64ca59))
    (fp_line (start 4.421 1.44) (end 4.421 6.034) (layer "F.SilkS") (width 0.12) (tstamp cf4fec20-16de-46f8-a5e5-31f1908d2ee7))
    (fp_line (start 4.501 -6.008) (end 4.501 -1.44) (layer "F.SilkS") (width 0.12) (tstamp d008a7c5-8d09-40ca-b4db-12a31cd40d4f))
    (fp_line (start 5.381 -5.642) (end 5.381 -1.44) (layer "F.SilkS") (width 0.12) (tstamp d04ad8fb-8995-4038-a95f-47488f8c0df4))
    (fp_line (start 4.581 -5.981) (end 4.581 -1.44) (layer "F.SilkS") (width 0.12) (tstamp d0a65bde-9c8d-4f53-bb14-f0e22d5d4559))
    (fp_line (start -4.317082 -3.575) (end -3.067082 -3.575) (layer "F.SilkS") (width 0.12) (tstamp d1384fec-bc55-42c5-b3b8-eeb855a72982))
    (fp_line (start 2.62 -6.329) (end 2.62 6.329) (layer "F.SilkS") (width 0.12) (tstamp d1501199-8d15-47cf-8263-d7b6aa10b392))
    (fp_line (start 2.78 -6.324) (end 2.78 6.324) (layer "F.SilkS") (width 0.12) (tstamp d2d24772-f69d-4460-b0c2-882ea2a4259a))
    (fp_line (start 6.901 -4.567) (end 6.901 4.567) (layer "F.SilkS") (width 0.12) (tstamp d3574d03-5cd7-4bb1-bf95-654460c778c3))
    (fp_line (start 4.981 1.44) (end 4.981 5.828) (layer "F.SilkS") (width 0.12) (tstamp d3e0b708-5df6-495b-9e9d-91f49de0b56e))
    (fp_line (start 6.581 -4.852) (end 6.581 4.852) (layer "F.SilkS") (width 0.12) (tstamp d42ea87e-41d9-45f1-93d2-d40f8f633fa1))
    (fp_line (start 7.541 -3.856) (end 7.541 3.856) (layer "F.SilkS") (width 0.12) (tstamp d4351575-ea60-4a20-aba6-d0ee491236f1))
    (fp_line (start 8.661 -1.583) (end 8.661 1.583) (layer "F.SilkS") (width 0.12) (tstamp da0520de-3b22-4b8e-b0ee-13f022897d84))
    (fp_line (start 6.661 -4.785) (end 6.661 4.785) (layer "F.SilkS") (width 0.12) (tstamp dbc711bb-9f70-4251-ae30-4a6bb97a4c86))
    (fp_line (start 7.621 -3.75) (end 7.621 3.75) (layer "F.SilkS") (width 0.12) (tstamp de06be25-7837-4cc5-a28b-0348215d5642))
    (fp_line (start 2.54 -6.33) (end 2.54 6.33) (layer "F.SilkS") (width 0.12) (tstamp df81990a-f325-40e7-ad60-2a8257166c6d))
    (fp_line (start 7.461 -3.957) (end 7.461 3.957) (layer "F.SilkS") (width 0.12) (tstamp dfb4e068-aa98-4a71-b86f-f48bd0366658))
    (fp_line (start 8.301 -2.594) (end 8.301 2.594) (layer "F.SilkS") (width 0.12) (tstamp e0d88c31-be35-4057-9369-74b0b947375d))
    (fp_line (start 7.781 -3.524) (end 7.781 3.524) (layer "F.SilkS") (width 0.12) (tstamp e12092ce-7318-4dd8-81ef-791247fbf1f3))
    (fp_line (start 7.261 -4.194) (end 7.261 4.194) (layer "F.SilkS") (width 0.12) (tstamp e193fbe4-70bc-49af-9f2b-c048529493bd))
    (fp_line (start 3.981 -6.156) (end 3.981 -1.44) (layer "F.SilkS") (width 0.12) (tstamp e25acef1-ea60-4294-a2f2-548f67f8a431))
    (fp_line (start 4.421 -6.034) (end 4.421 -1.44) (layer "F.SilkS") (width 0.12) (tstamp e36564dc-b93a-4ec5-9a67-93e267d05441))
    (fp_line (start 5.941 -5.322) (end 5.941 -1.44) (layer "F.SilkS") (width 0.12) (tstamp e3fb7895-c742-48e9-8056-bd1f18d0e5cd))
    (fp_line (start 6.301 -5.073) (end 6.301 -1.44) (layer "F.SilkS") (width 0.12) (tstamp e5adb1b0-5c87-47f1-a217-61b9ae2cbfea))
    (fp_line (start 5.981 -5.296) (end 5.981 -1.44) (layer "F.SilkS") (width 0.12) (tstamp e6210c19-11f5-450a-871c-12a4751f7e8f))
    (fp_line (start 5.821 -5.397) (end 5.821 -1.44) (layer "F.SilkS") (width 0.12) (tstamp e872dd59-03b3-4202-a1af-92c0261542eb))
    (fp_line (start 3.781 1.44) (end 3.781 6.201) (layer "F.SilkS") (width 0.12) (tstamp e945e159-049f-47c0-b3e8-c880239b9b75))
    (fp_line (start 4.741 -5.924) (end 4.741 -1.44) (layer "F.SilkS") (width 0.12) (tstamp ecddc345-3ce8-4731-bd16-d51ca5679805))
    (fp_line (start 7.661 -3.696) (end 7.661 3.696) (layer "F.SilkS") (width 0.12) (tstamp eeb10afb-9051-4a68-a482-728d2e30cfda))
    (fp_line (start 7.581 -3.804) (end 7.581 3.804) (layer "F.SilkS") (width 0.12) (tstamp ef474a39-1c26-45f6-aea1-ab19ddd16585))
    (fp_line (start 6.381 -5.012) (end 6.381 -1.44) (layer "F.SilkS") (width 0.12) (tstamp f2573cf5-0f00-4793-8f08-3908ce1262a4))
    (fp_line (start 3.301 -6.28) (end 3.301 6.28) (layer "F.SilkS") (width 0.12) (tstamp f32e0042-3400-4db4-858a-ccfa36d86505))
    (fp_line (start 6.501 -4.918) (end 6.501 4.918) (layer "F.SilkS") (width 0.12) (tstamp f3e6d278-b089-4384-a90f-1e31072fbfba))
    (fp_line (start 8.781 -1.028) (end 8.781 1.028) (layer "F.SilkS") (width 0.12) (tstamp f48bd3fc-24ca-4f12-a58d-466347730e7e))
    (fp_line (start 5.701 1.44) (end 5.701 5.468) (layer "F.SilkS") (width 0.12) (tstamp f664c4cf-cedc-4040-8884-c6225b1ddeff))
    (fp_line (start 3.901 1.44) (end 3.901 6.175) (layer "F.SilkS") (width 0.12) (tstamp f8485c50-4513-4944-bc43-2d4af4a9791f))
    (fp_line (start 3.02 -6.309) (end 3.02 6.309) (layer "F.SilkS") (width 0.12) (tstamp f8ec8778-1f48-4ecc-8775-a95b147fe6a7))
    (fp_line (start 4.941 -5.845) (end 4.941 -1.44) (layer "F.SilkS") (width 0.12) (tstamp f9a11493-16e0-4c65-bd78-3c828488a601))
    (fp_line (start 4.781 1.44) (end 4.781 5.908) (layer "F.SilkS") (width 0.12) (tstamp fa10804b-9857-490c-9a3b-1f8edfbcbc22))
    (fp_line (start 5.101 -5.776) (end 5.101 -1.44) (layer "F.SilkS") (width 0.12) (tstamp fa73ff98-cf6a-4af1-800d-0bc6ca97aa0b))
    (fp_line (start 5.981 1.44) (end 5.981 5.296) (layer "F.SilkS") (width 0.12) (tstamp fcaafd2d-ec99-4e02-a2fc-1b70f9682b1d))
    (fp_line (start 8.501 -2.1) (end 8.501 2.1) (layer "F.SilkS") (width 0.12) (tstamp fd33477a-19da-4d8a-8153-22a9d3c75f84))
    (fp_line (start 4.381 1.44) (end 4.381 6.047) (layer "F.SilkS") (width 0.12) (tstamp fd92ca32-7fe4-44cb-a41e-4677ab0f9875))
    (fp_line (start 6.141 1.44) (end 6.141 5.188) (layer "F.SilkS") (width 0.12) (tstamp fee12255-a24b-4fbb-9551-95ab0d9151d3))
    (fp_circle (center 2.5 0) (end 8.87 0) (layer "F.SilkS") (width 0.12) (fill none) (tstamp a770d400-0864-47af-a93d-2c5335b78e26))
    (fp_circle (center 2.5 0) (end 9 0) (layer "F.CrtYd") (width 0.05) (fill none) (tstamp db9f7a51-baae-4b6e-b82d-c7f34f8971df))
    (fp_line (start -2.241489 -3.3625) (end -2.241489 -2.1125) (layer "F.Fab") (width 0.1) (tstamp 0d2e6c5e-0192-4088-baba-e4c32b43efd9))
    (fp_line (start -2.866489 -2.7375) (end -1.616489 -2.7375) (layer "F.Fab") (width 0.1) (tstamp 1b313341-9c94-492d-bd4e-90449e09ca4b))
    (fp_circle (center 2.5 0) (end 8.75 0) (layer "F.Fab") (width 0.1) (fill none) (tstamp 44a4eb4a-88da-442b-a352-c3676d74b7f4))
    (pad "1" thru_hole rect (at 0 0 90) (size 2.4 2.4) (drill 1.2) (layers *.Cu *.Mask)
      (net 10 "Net-(C14-Pad1)") (pintype "passive") (tstamp 0027a75e-1fd2-4596-b720-31ea00ed4b7a))
    (pad "2" thru_hole circle (at 5 0 90) (size 2.4 2.4) (drill 1.2) (layers *.Cu *.Mask)
      (net 1 "Net-(BT1-Pad2)") (pintype "passive") (tstamp 9b44bc23-c513-49b1-9ffc-114b23ed4b51))
    (model "${KICAD6_3DMODEL_DIR}/Capacitor_THT.3dshapes/CP_Radial_D12.5mm_P5.00mm.wrl"
      (offset (xyz 0 0 0))
      (scale (xyz 1 1 1))
      (rotate (xyz 0 0 0))
  (footprint "Package_TO_SOT_THT:TO-220-3_Vertical" (layer "F.Cu")
    (tedit 5AC8BA0D) (tstamp fbed07f9-5790-4b61-b4e0-e07d5b5a4282)
    (at 86.9035 65.786 -90)
    (descr "TO-220-3, Vertical, RM 2.54mm, see https://www.vishay.com/docs/66542/to-220-1.pdf")
    (tags "TO-220-3 Vertical RM 2.54mm")
    (property "Sheetfile" "Lauflicht_Steuerplatine.kicad_sch")
    (property "Sheetname" "")
    (path "/6dbb8e11-186b-423d-8211-b46eb5bd83e8")
    (attr through_hole)
    (fp_text reference "U4" (at 2.54 2.4485 90) (layer "F.SilkS")
      (effects (font (size 1 1) (thickness 0.15)))
      (tstamp 5cc69564-656c-4583-bb97-dd57b57fa977)
    (fp_text value "LM78M05_TO220" (at 2.54 2.5 90) (layer "F.Fab")
      (tstamp b463a838-8819-4a72-82c9-9f6f4caf10cf)
    (fp_text user "${REFERENCE}" (at 2.54 -4.27 90) (layer "F.Fab")
      (tstamp a72b293b-2779-41a5-bfe8-18cabc1e23c0)
    (fp_line (start -2.58 -3.27) (end 7.66 -3.27) (layer "F.SilkS") (width 0.12) (tstamp 11622449-de4d-4a34-804c-dbc00f5e3e3d))
    (fp_line (start 0.69 -3.27) (end 0.69 -1.76) (layer "F.SilkS") (width 0.12) (tstamp 17f057b9-9ffc-49ee-b610-316c1f299176))
    (fp_line (start -2.58 -1.76) (end 7.66 -1.76) (layer "F.SilkS") (width 0.12) (tstamp 41791f38-60e9-4f72-87d7-a125629cf257))
    (fp_line (start 4.391 -3.27) (end 4.391 -1.76) (layer "F.SilkS") (width 0.12) (tstamp 69cc4057-9569-4c40-88da-9c06a3acda6a))
    (fp_line (start -2.58 1.371) (end 7.66 1.371) (layer "F.SilkS") (width 0.12) (tstamp c8ecc1a7-a5b3-464b-a9b2-ef6f85534c70))
    (fp_line (start 7.66 -3.27) (end 7.66 1.371) (layer "F.SilkS") (width 0.12) (tstamp d212bf84-bfd6-4945-b5c8-a62a0a848d44))
    (fp_line (start -2.58 -3.27) (end -2.58 1.371) (layer "F.SilkS") (width 0.12) (tstamp e4e7b0aa-4e1d-44e4-acd6-52dea22740a8))
    (fp_line (start -2.71 1.51) (end 7.79 1.51) (layer "F.CrtYd") (width 0.05) (tstamp 1f968de1-f09e-4a0f-8300-7e1dbe10bbe4))
    (fp_line (start -2.71 -3.4) (end -2.71 1.51) (layer "F.CrtYd") (width 0.05) (tstamp 3592160e-46b1-4e85-bd89-0df23b4ff69f))
    (fp_line (start 7.79 1.51) (end 7.79 -3.4) (layer "F.CrtYd") (width 0.05) (tstamp 43ddf4c5-7e54-4457-9859-1966d9627dec))
    (fp_line (start 7.79 -3.4) (end -2.71 -3.4) (layer "F.CrtYd") (width 0.05) (tstamp eef11f18-2e93-4d61-a9d4-f8173a720b28))
    (fp_line (start -2.46 1.25) (end 7.54 1.25) (layer "F.Fab") (width 0.1) (tstamp 023be5a9-07a7-4b8b-85c8-c1129275d847))
    (fp_line (start -2.46 -3.15) (end -2.46 1.25) (layer "F.Fab") (width 0.1) (tstamp 0da01381-7e1c-4004-9959-c18bd867c788))
    (fp_line (start 7.54 1.25) (end 7.54 -3.15) (layer "F.Fab") (width 0.1) (tstamp 21c9fea0-0a8b-4245-90ae-2637bdf6c666))
    (fp_line (start -2.46 -1.88) (end 7.54 -1.88) (layer "F.Fab") (width 0.1) (tstamp 87b07f5f-91e6-4208-a156-805cdfba131a))
    (fp_line (start 0.69 -3.15) (end 0.69 -1.88) (layer "F.Fab") (width 0.1) (tstamp a571f128-2b7b-4c6d-9329-3b4e06dc0514))
    (fp_line (start 7.54 -3.15) (end -2.46 -3.15) (layer "F.Fab") (width 0.1) (tstamp a664b7d3-66fa-4742-9371-b83df175dfec))
    (fp_line (start 4.39 -3.15) (end 4.39 -1.88) (layer "F.Fab") (width 0.1) (tstamp da7cc27d-7bc1-490d-8562-72fb1efbee67))
    (pad "1" thru_hole rect (at 0 0 270) (size 1.905 2) (drill 1.1) (layers *.Cu *.Mask)
      (net 15 "Net-(C3-Pad1)") (pinfunction "VI") (pintype "power_in") (tstamp 84c4e66e-5add-41c5-8198-2aa4c5de844c))
    (pad "2" thru_hole oval (at 2.54 0 270) (size 1.905 2) (drill 1.1) (layers *.Cu *.Mask)
      (net 1 "Net-(BT1-Pad2)") (pinfunction "GND") (pintype "power_in") (tstamp bf8e9564-c665-4aa5-aaf9-5502acd2bca3))
    (pad "3" thru_hole oval (at 5.08 0 270) (size 1.905 2) (drill 1.1) (layers *.Cu *.Mask)
      (net 6 "Net-(C8-Pad1)") (pinfunction "VO") (pintype "power_out") (tstamp c33dedcc-a853-4238-ab75-493b5e8dbe73))
    (model "${KICAD6_3DMODEL_DIR}/Package_TO_SOT_THT.3dshapes/TO-220-3_Vertical.wrl"
      (scale (xyz 1 1 1))
  (footprint "Resistor_SMD:R_1210_3225Metric_Pad1.30x2.65mm_HandSolder" (layer "F.Cu")
    (tedit 5F68FEEE) (tstamp fc4def70-2e02-410f-8290-acab87c7ba2b)
    (at 36.322 55.245 180)
    (descr "Resistor SMD 1210 (3225 Metric), square (rectangular) end terminal, IPC_7351 nominal with elongated pad for handsoldering. (Body size source: IPC-SM-782 page 72, https://www.pcb-3d.com/wordpress/wp-content/uploads/ipc-sm-782a_amendment_1_and_2.pdf), generated with kicad-footprint-generator")
    (tags "resistor handsolder")
    (path "/c7150d80-641f-463f-8093-b0f4c12d2ee4")
    (attr smd)
    (fp_text reference "R21" (at -3.429 -0.127 90) (layer "F.SilkS")
      (tstamp d4b03068-aeff-44ed-b584-16f3f8c6b6f1)
      (tstamp 25e26756-47c8-49fc-83a4-6a4d0b23f294)
      (effects (font (size 0.8 0.8) (thickness 0.12)))
      (tstamp d303d6b6-df73-4944-874b-b169d9042cd3)
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 79027e6a-678c-4ab8-bc75-3538537f27b0))
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp 9e7278ac-b966-468f-b9b3-9d9d1b57c812))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 27c863fa-595d-49fd-adf3-5c66d6761b08))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 2991990e-e456-43bf-8e3b-80f9e493f9f4))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 33005fc3-3810-4a88-98dd-7256381dfa2b))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp 74c91cda-abfd-4aac-bfe4-f89ae5b2bccf))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 5433435f-4d2d-4ec1-be53-0b8934c3fa8a))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp b1c4151c-717b-440e-a1a6-51a50a359b5f))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp b8493a2e-6ffe-42c5-9308-18d38c3c0233))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp f258c675-9df9-479f-88eb-f1147c8e2cef))
    (pad "1" smd roundrect (at -1.55 0 180) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 51 "Net-(R21-Pad1)") (pintype "passive") (tstamp ba1f5ae7-7f99-46ea-9077-ffd884239b1a))
    (pad "2" smd roundrect (at 1.55 0 180) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 85 "Net-(C20-Pad1)") (pintype "passive") (tstamp 694fbc6f-167e-4468-8f99-10df9ed797ca))
    (model "${KICAD6_3DMODEL_DIR}/Resistor_SMD.3dshapes/R_1210_3225Metric.wrl"
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp fddc7615-46e1-492d-b970-ab5d5a5d58c0)
    (at 81.4985 78.206 -90)
    (path "/6de3e6cd-dfa7-4c9a-b6b0-1390d06f3a0f")
    (attr smd)
    (fp_text reference "R3" (at 0 -2.28 90) (layer "F.SilkS")
      (tstamp 4c91f902-2a07-4b00-93b4-ece9ebab6cf7)
    (fp_text value "SMD 1/4W 0R1" (at 0 2.28 90) (layer "F.Fab")
      (tstamp 1b540a46-339b-48cb-80b5-b5e6c7dd5b93)
    (fp_text user "${REFERENCE}" (at 0 0 90) (layer "F.Fab")
      (tstamp 7f5dbea4-a523-4b81-b69f-d06fafdc8b24)
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp 14f94cf0-e671-4529-be3e-a20304571c35))
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp ef87b4fc-4218-4d3d-9959-0ac464c46d97))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 82d49c6b-6d17-438a-9dcc-9b586bed06fa))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp d4da6180-694b-44d9-ba30-f397971802b6))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp dce2ecb6-22ef-4446-a2bd-cc13096308dd))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp e77f5e0f-b8d5-4484-a838-58eab77796de))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 16a68359-5f34-4e75-952e-f3a6e03ad4f3))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp 34534d82-3d45-4da7-9a72-2c6f21250aa6))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 828deb6f-1251-4328-a89c-f5ef359fea39))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp a7f295c0-1473-42a2-b562-96b0c007aa19))
    (pad "1" smd roundrect (at -1.55 0 270) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 6 "Net-(C8-Pad1)") (pintype "passive") (tstamp 44223bd7-cbcd-4fa2-b4c0-b2bcd9b881fe))
    (pad "2" smd roundrect (at 1.55 0 270) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 98 "Net-(F4-Pad2)") (pintype "passive") (tstamp d4c49252-abc6-46ac-ba2e-80de71e0686c))
      (scale (xyz 1 1 1))
    (tedit 5F68FEEE) (tstamp fed146c6-d715-46da-adff-c377d667102b)
    (at 45.466 26.416 90)
    (path "/0b783ebc-b5b0-48e1-a8d9-456af58a14f7")
    (attr smd)
    (fp_text reference "R18" (at -0.254 2.413 270) (layer "F.SilkS")
      (tstamp a60bd93e-b111-46ab-9de2-9287d69ad276)
    (fp_text value "SMD 1/4W 1k" (at 1.778 2.667 180) (layer "F.Fab")
      (tstamp ba42f0cb-4642-4535-8232-b4f17f72da13)
      (tstamp 84b802b5-1c8a-417a-803b-cbfe0fbb175c)
    (fp_line (start -0.723737 -1.355) (end 0.723737 -1.355) (layer "F.SilkS") (width 0.12) (tstamp 55146d99-b0da-4972-a48c-d8523d5a1971))
    (fp_line (start -0.723737 1.355) (end 0.723737 1.355) (layer "F.SilkS") (width 0.12) (tstamp f5064aa5-11ba-47c2-8481-25ad8def658c))
    (fp_line (start -2.45 1.58) (end -2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 092e9de5-9779-4586-b745-f5f533c3c1ec))
    (fp_line (start -2.45 -1.58) (end 2.45 -1.58) (layer "F.CrtYd") (width 0.05) (tstamp 10a7133b-f469-4991-acec-b1795e66a15d))
    (fp_line (start 2.45 1.58) (end -2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp e85041e8-8459-4a32-977c-ef5712949213))
    (fp_line (start 2.45 -1.58) (end 2.45 1.58) (layer "F.CrtYd") (width 0.05) (tstamp f2d70b95-cd76-4c23-b75b-0bf578dbac62))
    (fp_line (start -1.6 1.245) (end -1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp 9e7ce5b3-adb4-4cd4-b4f5-1f5f05182271))
    (fp_line (start 1.6 1.245) (end -1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp efc89236-3e51-4baa-a367-cc6e6ed97b9c))
    (fp_line (start 1.6 -1.245) (end 1.6 1.245) (layer "F.Fab") (width 0.1) (tstamp fc283ebe-5180-475c-9e0c-1a1ebce010cb))
    (fp_line (start -1.6 -1.245) (end 1.6 -1.245) (layer "F.Fab") (width 0.1) (tstamp fd872928-36d6-4380-b420-748b2b2da710))
    (pad "1" smd roundrect (at -1.55 0 90) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 48 "Net-(R18-Pad1)") (pintype "passive") (tstamp d47633e1-3773-473f-82d8-cfa53a391cc7))
    (pad "2" smd roundrect (at 1.55 0 90) (size 1.3 2.65) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.1923076923)
      (net 49 "Net-(J5-Pad3)") (pintype "passive") (tstamp 292f8bf9-f136-415d-a47e-d695321245a0))
      (scale (xyz 1 1 1))
  (footprint "Package_SO:SOIC-8_3.9x4.9mm_P1.27mm" (layer "F.Cu")
    (tedit 5D9F72B1) (tstamp feff2c5c-a311-45b0-af01-6fd5ebdfe9e6)
    (at 50.673 59.182 -90)
    (descr "SOIC, 8 Pin (JEDEC MS-012AA, https://www.analog.com/media/en/package-pcb-resources/package/pkg_pdf/soic_narrow-r/r_8.pdf), generated with kicad-footprint-generator ipc_gullwing_generator.py")
    (tags "SOIC SO")
    (path "/08ef6648-1986-481d-95ca-9f83e83f1dcf")
    (attr smd)
    (fp_text reference "U7" (at 4.826 2.032 90) (layer "F.SilkS")
      (tstamp e3de487f-76c5-49f7-8085-e74bab9b8818)
    (fp_text value "25A512-ISN 512kb" (at 0 3.4 90) (layer "F.Fab")
      (tstamp fc7e7089-fc04-464e-b3be-6ee46d73a405)
      (effects (font (size 0.98 0.98) (thickness 0.15)))
      (tstamp e421b260-f9cf-46fb-a568-d4ec9727d99f)
    (fp_line (start 0 -2.56) (end 1.95 -2.56) (layer "F.SilkS") (width 0.12) (tstamp 502bd319-0402-4363-a80b-5e5f89564309))
    (fp_line (start 0 -2.56) (end -3.45 -2.56) (layer "F.SilkS") (width 0.12) (tstamp cbd60b04-3118-4b09-8895-d1af5386e7aa))
    (fp_line (start 0 2.56) (end 1.95 2.56) (layer "F.SilkS") (width 0.12) (tstamp cf20167c-37b6-43fe-be0a-ecedbf270ecf))
    (fp_line (start 0 2.56) (end -1.95 2.56) (layer "F.SilkS") (width 0.12) (tstamp fe316ddb-ba1f-4a48-ae74-7d10b1949b70))
    (fp_line (start -3.7 -2.7) (end -3.7 2.7) (layer "F.CrtYd") (width 0.05) (tstamp 31df5aea-27e3-461f-973f-5e78135de28e))
    (fp_line (start -3.7 2.7) (end 3.7 2.7) (layer "F.CrtYd") (width 0.05) (tstamp 3d7ca1e5-8591-4bed-b109-2bc84f13e85a))
    (fp_line (start 3.7 -2.7) (end -3.7 -2.7) (layer "F.CrtYd") (width 0.05) (tstamp 4d81a837-b1d7-4789-a55f-cc90d30558c3))
    (fp_line (start 3.7 2.7) (end 3.7 -2.7) (layer "F.CrtYd") (width 0.05) (tstamp a911ef12-96b2-4dcb-acd6-eb6c38ce267f))
    (fp_line (start 1.95 2.45) (end -1.95 2.45) (layer "F.Fab") (width 0.1) (tstamp 6714a4fe-3f35-415f-9091-3f479f265a62))
    (fp_line (start -0.975 -2.45) (end 1.95 -2.45) (layer "F.Fab") (width 0.1) (tstamp 7392f4bb-de0c-4416-8534-11338061fb3f))
    (fp_line (start 1.95 -2.45) (end 1.95 2.45) (layer "F.Fab") (width 0.1) (tstamp bc7e32f4-5349-4118-9a4c-8399575b9520))
    (fp_line (start -1.95 -1.475) (end -0.975 -2.45) (layer "F.Fab") (width 0.1) (tstamp c5a16d02-1756-4076-9eff-d0e20bad9386))
    (fp_line (start -1.95 2.45) (end -1.95 -1.475) (layer "F.Fab") (width 0.1) (tstamp f1f2c99b-b97d-41ba-82fb-7b368f551dd4))
    (pad "1" smd roundrect (at -2.475 -1.905 270) (size 1.95 0.6) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.25)
      (net 61 "Net-(R30-Pad1)") (pinfunction "~{CS}") (pintype "input") (tstamp 72a39bc4-dafe-4a45-bc0e-cfbaf0a1042a))
    (pad "2" smd roundrect (at -2.475 -0.635 270) (size 1.95 0.6) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.25)
      (net 35 "Net-(J15-Pad1)") (pinfunction "MISO") (pintype "tri_state") (tstamp e877fa6d-96e6-4b65-9d55-ec8343ded989))
    (pad "3" smd roundrect (at -2.475 0.635 270) (size 1.95 0.6) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.25)
      (net 67 "Net-(R37-Pad1)") (pinfunction "~{WP}") (pintype "input") (tstamp 6d1fdf77-156d-42f4-9dc9-1d2d48a70b0c))
    (pad "4" smd roundrect (at -2.475 1.905 270) (size 1.95 0.6) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.25)
      (net 1 "Net-(BT1-Pad2)") (pinfunction "GND") (pintype "power_in") (tstamp 03228839-200e-4a1e-a907-668d1fa21e2f))
    (pad "5" smd roundrect (at 2.475 1.905 270) (size 1.95 0.6) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.25)
      (net 37 "Net-(J15-Pad4)") (pinfunction "MOSI") (pintype "input") (tstamp 8e8f488a-aacd-4464-b26a-0cb3daa1e108))
    (pad "6" smd roundrect (at 2.475 0.635 270) (size 1.95 0.6) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.25)
      (net 36 "Net-(J15-Pad3)") (pinfunction "SCK") (pintype "input") (tstamp 44837ef8-8e8f-49bf-a252-62fc3278b34b))
    (pad "7" smd roundrect (at 2.475 -0.635 270) (size 1.95 0.6) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.25)
      (net 64 "Net-(R33-Pad1)") (pinfunction "~{HOLD}") (pintype "input") (tstamp 74de33ca-9cbe-4cf3-95a4-b778254be184))
    (pad "8" smd roundrect (at 2.475 -1.905 270) (size 1.95 0.6) (layers "F.Cu" "F.Paste" "F.Mask") (roundrect_rratio 0.25)
      (net 85 "Net-(C20-Pad1)") (pinfunction "VCC") (pintype "power_in") (tstamp d28722fa-8ff5-4299-8707-b79ba5dac34a))
    (model "${KICAD6_3DMODEL_DIR}/Package_SO.3dshapes/SOIC-8_3.9x4.9mm_P1.27mm.wrl"
      (scale (xyz 1 1 1))
  (gr_line (start 158.623 26.162) (end 158.496 45.085) (layer "B.Paste") (width 1) (tstamp 797605da-b401-40ee-bf98-93cdb01d0846))
  (gr_line (start 48.641 37.846) (end 48.641 26.67) (layer "B.SilkS") (width 0.15) (tstamp 03ec37a1-4ab1-49ca-bd4e-b8f490764c8d))
  (gr_line (start 72.136 88.646) (end 72.136 112.776) (layer "B.SilkS") (width 0.15) (tstamp 06d250a5-6be4-4248-af0c-bc847b511bfe))
  (gr_line (start 72.136 112.776) (end 72.136 114.046) (layer "B.SilkS") (width 0.15) (tstamp 08ff0f9c-2da5-4e9e-ba5c-d044d5ed635b))
  (gr_line (start 48.641 15.748) (end 60.706 15.748) (layer "B.SilkS") (width 0.15) (tstamp 2d784d80-59e9-4f27-b832-00d710e15ead))
  (gr_rect (start 94.869 114.3) (end 173.609 168.91) (layer "B.SilkS") (width 0.15) (fill none) (tstamp 4d7bd941-27c7-46cd-9d19-3c7b360081de))
  (gr_line (start 53.721 46.736) (end 70.866 46.736) (layer "B.SilkS") (width 0.15) (tstamp 52d50110-551e-4d21-8b90-07f1e5678e42))
  (gr_line (start 60.706 15.748) (end 60.706 28.321) (layer "B.SilkS") (width 0.15) (tstamp 57fc043a-ca5a-45b1-aa24-3093609cb530))
  (gr_rect (start 68.961 114.046) (end 81.661 131.191) (layer "B.SilkS") (width 0.15) (fill none) (tstamp 5a5a37e0-3998-4486-a5dd-dd87ef8ad09f))
  (gr_line (start 48.641 23.749) (end 48.641 23.114) (layer "B.SilkS") (width 0.15) (tstamp 615ea4b2-0876-473a-9a88-690d83bde443))
  (gr_line (start 71.501 46.736) (end 72.136 46.736) (layer "B.SilkS") (width 0.15) (tstamp 66f431a5-f648-4606-9c51-36d9867b479b))
  (gr_line (start 60.706 28.321) (end 92.456 28.321) (layer "B.SilkS") (width 0.15) (tstamp 7b63eb9a-fe7d-497b-8c53-9f40ebc9d6d0))
  (gr_line (start 53.721 37.846) (end 48.641 37.846) (layer "B.SilkS") (width 0.15) (tstamp 8034b77a-3abd-4cb8-b783-98f1934c8ddb))
  (gr_line (start 27.051 46.736) (end 53.721 46.736) (layer "B.SilkS") (width 0.15) (tstamp 8d794b1e-d5c4-40f8-9259-a71f07a9e0bd))
  (gr_line (start 53.721 46.736) (end 53.721 37.846) (layer "B.SilkS") (width 0.15) (tstamp a75eadaa-96d9-4b01-b749-f67cd8cd6dc7))
  (gr_line (start 27.051 16.256) (end 27.051 46.736) (layer "B.SilkS") (width 0.15) (tstamp b4c08b05-e357-4aa4-b69e-ec297fc7c43c))
  (gr_line (start 48.641 26.67) (end 48.641 23.749) (layer "B.SilkS") (width 0.15) (tstamp c5c27eb6-6aae-40c1-aeaa-9fb3488ea4e7))
  (gr_line (start 60.706 15.748) (end 92.456 15.748) (layer "B.SilkS") (width 0.15) (tstamp d20162fb-6d21-4d7a-9a40-42d01d406109))
  (gr_line (start 72.136 46.736) (end 72.136 88.646) (layer "B.SilkS") (width 0.15) (tstamp d8afe1ac-4f4a-4607-83a0-69232e7534d5))
  (gr_line (start 48.641 15.748) (end 48.641 16.256) (layer "B.SilkS") (width 0.15) (tstamp da22485a-ad13-491f-97e4-b5db9bdbfa52))
  (gr_line (start 27.051 15.748) (end 48.641 15.748) (layer "B.SilkS") (width 0.15) (tstamp daad4448-2f80-4b53-93df-5541fd16a304))
  (gr_line (start 70.866 46.736) (end 71.501 46.736) (layer "B.SilkS") (width 0.15) (tstamp f667bd49-103f-49bb-960b-703d1735180b))
  (gr_line (start 92.456 28.321) (end 92.456 15.748) (layer "B.SilkS") (width 0.15) (tstamp fc628308-eec0-49fe-a727-56861e6a9b10))
  (gr_circle (center 64.77 43.942) (end 65.024 43.942) (layer "F.SilkS") (width 0.15) (fill none) (tstamp 155d7e70-1c19-4684-a3a4-a1198f7db86c))
  (gr_circle (center 86.868 64.262) (end 87.122 64.262) (layer "F.SilkS") (width 0.15) (fill none) (tstamp 2108934d-1647-4f02-a6e9-d8ca3010ef69))
  (gr_circle (center 103.632 64.262) (end 103.886 64.262) (layer "F.SilkS") (width 0.15) (fill none) (tstamp 2ae56b9b-d116-49b2-9d00-4bc1266c124c))
  (gr_circle (center 19.558 58.166) (end 19.812 58.166) (layer "F.SilkS") (width 0.15) (fill none) (tstamp 31d44333-a4e9-4abe-b236-e02ae7d31b5b))
  (gr_line (start 52.07 74.168) (end 52.07 74.803) (layer "F.SilkS") (width 0.15) (tstamp 334598b6-b26f-4aec-9154-9eeb41e5fc91))
  (gr_circle (center 36.322 86.36) (end 36.576 86.36) (layer "F.SilkS") (width 0.15) (fill none) (tstamp 45a76bb4-7fd3-467c-9520-77a6716a43dc))
  (gr_line (start 52.07 74.803) (end 51.816 74.676) (layer "F.SilkS") (width 0.15) (tstamp 5e0482e3-992f-4a65-a83a-17a4092c248f))
  (gr_line (start 52.07 74.803) (end 52.324 74.676) (layer "F.SilkS") (width 0.15) (tstamp 687d10a9-58bc-4ab6-a87a-4a1689ba2499))
  (gr_circle (center 53.848 56.642) (end 54.102 56.642) (layer "F.SilkS") (width 0.15) (fill none) (tstamp 6ecbe2b7-abe8-4d7a-a521-18a8768008bd))
  (gr_circle (center 119.38 64.262) (end 119.634 64.262) (layer "F.SilkS") (width 0.15) (fill none) (tstamp 6ef766bb-7e8c-4cc7-8b7c-1fdc7ef3deaf))
  (gr_circle (center 33.528 84.836) (end 33.782 84.836) (layer "F.SilkS") (width 0.15) (fill none) (tstamp 92b0ec41-1cbe-4110-a55c-6075c62f2c4f))
  (gr_line (start 76.708 165.1) (end 71.12 165.1) (layer "F.SilkS") (width 0.15) (tstamp ac5e85c7-9e1a-4d8e-bf55-37d2861d7397))
  (gr_rect (start 173.609 114.3) (end 94.869 168.91) (layer "F.SilkS") (width 0.15) (fill none) (tstamp ae4332ad-75eb-4608-96de-2d3176c2ff35))
  (gr_line (start 78.74 165.1) (end 84.836 165.1) (layer "F.SilkS") (width 0.15) (tstamp b0a6fed3-bfd6-4ac2-9cbf-a7c76773f2d2))
  (gr_circle (center 59.436 18.288) (end 59.69 18.288) (layer "F.SilkS") (width 0.15) (fill none) (tstamp ec68080a-55f4-40e3-aa2e-6ad82efe4bf0))
  (gr_circle (center 77.851 145.796) (end 79.851 148.296) (layer "Edge.Cuts") (width 0.1) (fill none) (tstamp 05deff6a-318d-46e3-9fc5-99f041d66139))
  (gr_circle (center 49.784 19.685) (end 51.784 22.185) (layer "Edge.Cuts") (width 0.1) (fill none) (tstamp 0fc05e34-c952-4ae7-833b-5d2b5d8e72d3))
  (gr_circle (center 21.336 162.941) (end 23.336 165.441) (layer "Edge.Cuts") (width 0.1) (fill none) (tstamp 100bcebd-8af6-4131-804c-c793f71e69bf))
  (gr_circle (center 18.891 46.736) (end 20.891 49.236) (layer "Edge.Cuts") (width 0.1) (fill none) (tstamp 1dea06b1-552f-4df2-819b-b9cb754aa7d0))
  (gr_circle (center 119.761 163.576) (end 121.761 166.076) (layer "Edge.Cuts") (width 0.1) (fill none) (tstamp 39eec320-3a07-4bd5-8ef4-bed1097f7ed0))
  (gr_circle (center 63.246 61.341) (end 65.246 63.841) (layer "Edge.Cuts") (width 0.1) (fill none) (tstamp 3cb4dc1e-6434-4eff-9265-a2f496ec065a))
  (gr_circle (center 119.126 58.166) (end 121.126 60.666) (layer "Edge.Cuts") (width 0.1) (fill none) (tstamp bd215cc6-640a-4150-84b9-789735745f4d))
  (gr_circle (center 148.971 163.576) (end 150.971 166.076) (layer "Edge.Cuts") (width 0.1) (fill none) (tstamp be43770c-9d5b-49e8-adee-af5d4032a439))
  (gr_circle (center 101.981 120.396) (end 103.981 122.896) (layer "Edge.Cuts") (width 0.1) (fill none) (tstamp c092b17b-97ec-46c0-b573-37fbc62b1f4b))
  (gr_circle (center 166.751 120.396) (end 168.751 122.896) (layer "Edge.Cuts") (width 0.1) (fill none) (tstamp c1f3b185-31a2-4e02-b783-afce26fcdc33))
  (gr_circle (center 155.321 18.796) (end 157.321 21.296) (layer "Edge.Cuts") (width 0.1) (fill none) (tstamp c715f493-fadf-44be-923c-2ea3fd6f8f22))
  (gr_circle (center 135.662562 108.966) (end 137.662562 111.466) (layer "Edge.Cuts") (width 0.1) (fill none) (tstamp d290eb65-fff8-432d-a2b2-68ea81855e75))
  (gr_rect (start 174.371 169.291) (end 14.351 14.605) (layer "Edge.Cuts") (width 0.1) (fill none) (tstamp fc0214b0-33fb-4ebe-ba0c-f2c83b6610cb))
  (gr_rect (start 173.609 114.3) (end 94.869 168.91) (layer "User.2") (width 0.15) (fill none) (tstamp b26035ae-b12b-45b7-88c6-a4470eaeec01))
  (gr_text "X10" (at 106.68 167.513) (layer "F.SilkS") (tstamp 0bdabe3d-9c78-4f80-9fe7-1a58899b5f44)
  (gr_text "Links" (at 124.079 153.416) (layer "F.SilkS") (tstamp 0faa2f7a-bc4b-4b52-8173-ed89671efe22)
  (gr_text "Betrieb ______\nPause - - -\nStörung  . . ." (at 63.246 22.733 90) (layer "F.SilkS") (tstamp 172163df-6dd7-4913-b20f-9bdb8ad09fcf)
  (gr_text "Reset\n" (at 27.94 160.02 90) (layer "F.SilkS") (tstamp 1d0b4c45-f74e-48a3-aaed-257cfabc15b8)
  (gr_text "DC21V 1" (at 171.704 26.543 90) (layer "F.SilkS") (tstamp 1e9512bd-0879-4699-80cb-92089e99cd56)
  (gr_text "M2,5A" (at 116.332 94.615 90) (layer "F.SilkS") (tstamp 22392e9f-883a-48c2-b06a-1ff9019422a6)
  (gr_text "Netz" (at 107.0864 35.306) (layer "F.SilkS") (tstamp 267112b3-a6ad-4f08-a0d0-a08d97dcfe6f)
  (gr_text "CLK" (at 69.088 166.116 90) (layer "F.SilkS") (tstamp 28f29b74-8575-4c72-b1b0-0ca4cdafe202)
  (gr_text "OK" (at 162.687 167.513) (layer "F.SilkS") (tstamp 2cd8dd3d-61a1-494a-bf98-42f302890672)
  (gr_text "LA'" (at 66.548 165.608 90) (layer "F.SilkS") (tstamp 322bc7a8-c2c1-44e5-ae65-2b4980d4485f)
  (gr_text "SDO5" (at 61.468 166.624 90) (layer "F.SilkS") (tstamp 34e1fe12-12b0-45fb-ab9f-f55b5d51dcb5)
  (gr_text "Start" (at 106.299 153.035) (layer "F.SilkS") (tstamp 3891bbe0-1921-4d05-b952-007ac665a3dc)
  (gr_text "Hoch" (at 134.493 139.319) (layer "F.SilkS") (tstamp 3e061d4f-7c11-4a22-b1ef-7ffdb01fd6cb)
  (gr_text "Panel 2" (at 171.45 65.659 90) (layer "F.SilkS") (tstamp 40a43a76-6ddb-4327-839a-e5030c5336a2)
  (gr_text "CR2032" (at 19.304 25.654 90) (layer "F.SilkS") (tstamp 431749ee-db4f-4def-8e45-5dda02dc66f9)
  (gr_text "Panel 4" (at 171.45 91.44 90) (layer "F.SilkS") (tstamp 43343342-4e18-4fd9-897c-4c435f33c4ce)
  (gr_text "5V" (at 78.994 16.891) (layer "F.SilkS") (tstamp 475685d9-5ac3-4190-aaeb-18e411dd6f73)
  (gr_text "SDO4" (at 61.468 152.908 90) (layer "F.SilkS") (tstamp 53d1db76-0e82-4bd9-81de-a0470b9121c3)
  (gr_text "M10A" (at 144.526 46.99) (layer "F.SilkS") (tstamp 6c74f579-4f27-49d5-9c0a-efd5adbdb09a)
  (gr_text "ISP PCPU" (at 60.452 20.955 90) (layer "F.SilkS") (tstamp 768a2c79-855a-4b15-b38f-1d7745d03065)
  (gr_text "Zurück" (at 162.306 153.162) (layer "F.SilkS") (tstamp 7983c738-eec3-46b5-8923-f664b91e1ab9)
  (gr_text "M10A" (at 144.78 23.114) (layer "F.SilkS") (tstamp 79d31d70-c455-4e27-9743-b23a16130d2e)
  (gr_text "Stop" (at 106.045 138.684) (layer "F.SilkS") (tstamp 7e23c1e5-8a46-4cc5-bcf2-2ee4d3c07e6a)
  (gr_text "Netz" (at 88.646 16.891) (layer "F.SilkS") (tstamp 836ac675-9be7-4171-b49f-1e1834f5fe94)
  (gr_text "SDO2" (at 66.548 152.908 90) (layer "F.SilkS") (tstamp 86435a77-571b-486c-b66e-261e0cff0e32)
  (gr_text "5V" (at 81.915 166.116) (layer "F.SilkS") (tstamp 95e91a42-9ddd-4f35-9364-4cf2f0303f22)
  (gr_text "SDO3" (at 64.008 152.908 90) (layer "F.SilkS") (tstamp 9b8f8d38-2999-4bf2-882a-03e527cc95d1)
  (gr_text "OE'" (at 64.008 165.608 90) (layer "F.SilkS") (tstamp 9d78db97-24d5-439f-9c3c-484d7e9938f6)
  (gr_text "Ab" (at 134.874 167.513) (layer "F.SilkS") (tstamp 9f50aa71-35a9-49eb-adee-f48e3a9b4729)
  (gr_text "Panel 3" (at 171.45 78.232 90) (layer "F.SilkS") (tstamp a59a241b-872a-4983-9944-f5c627b002a5)
  (gr_text "Panel 1\n" (at 171.45 52.959 90) (layer "F.SilkS") (tstamp a62e706f-2596-4973-9e47-928cddbd128c)
  (gr_text "M0,2A" (at 104.267 16.129) (layer "F.SilkS") (tstamp a69ab45c-72a6-40c5-9a4b-ef0c511f6863)
  (gr_text "HCPU" (at 68.834 16.891) (layer "F.SilkS") (tstamp ab84960c-3a43-44d7-a2c7-8379d3ced3ad)
  (gr_text "Panel 5" (at 171.45 104.14 90) (layer "F.SilkS") (tstamp b6e16c5c-daf7-4947-81e3-45a0a8b1a05f)
  (gr_text "DC21V 2" (at 171.577 39.878 90) (layer "F.SilkS") (tstamp b8780f6c-3e9d-4021-b69f-4f16915f7c07)
  (gr_text "ISP HCPU" (at 20.828 57.404) (layer "F.SilkS") (tstamp c0d1c35c-b316-41fc-9e5c-d7c29902858f)
  (gr_text "SDO1" (at 69.088 152.908 90) (layer "F.SilkS") (tstamp c5683b5f-1eee-4ab5-b590-8d7aa2e7b5f3)
  (gr_text "M0,2A" (at 71.12 64.77 90) (layer "F.SilkS") (tstamp c6781a92-ab61-42dc-a9a3-f0103584c77f)
  (gr_text "Rechts" (at 144.78 153.543) (layer "F.SilkS") (tstamp e4291a06-ee66-4f8e-b828-7c698a62627b)
  (gr_text "GND" (at 73.66 166.116) (layer "F.SilkS") (tstamp ecd34d6a-c430-415c-9759-48cf2e7d50a3)
  (gr_text "20,00" (at 21.971 91.186 90) (layer "F.SilkS") (tstamp ee22ed5d-f345-47fd-8cc1-c5575d50d5ed)
  (gr_text "PCPU" (at 74.041 16.891) (layer "F.SilkS") (tstamp f81ae1c2-de52-4267-90dd-a0744cac7148)
  (gr_text "21V" (at 83.947 16.891) (layer "F.SilkS") (tstamp fc48f2ef-5fa2-4cbc-93c7-1d4904189543)
  (segment (start 62.357 32.231259) (end 62.357 28.321) (width 0.2) (layer "F.Cu") (net 1) (tstamp 014c80d7-5d01-4b40-92c4-5e6eaaf6af26))
  (segment (start 40.316 95.851) (end 40.316 94.05) (width 0.25) (layer "F.Cu") (net 1) (tstamp 02617fb2-2345-4a82-b628-54aeeb1e4fc2))
  (segment (start 78.867 42.634241) (end 76.618759 40.386) (width 0.2) (layer "F.Cu") (net 1) (tstamp 03c4d53d-8d21-4435-9a0c-bf8adfd28a39))
  (segment (start 63.246 37.973) (end 63.119 37.846) (width 0.2) (layer "F.Cu") (net 1) (tstamp 054e9788-a3f3-457d-9f21-e72a38f8f44b))
  (segment (start 64.77 38.608) (end 64.135 37.973) (width 0.2) (layer "F.Cu") (net 1) (tstamp 08e8533a-c558-44fe-a10c-23b5dae3f92d))
  (segment (start 128.397 90.678) (end 144.78 107.061) (width 3) (layer "F.Cu") (net 1) (tstamp 091c015e-ae64-4fe8-8fbb-1615d3394703))
  (segment (start 103.576 68.326) (end 101.854 68.326) (width 2) (layer "F.Cu") (net 1) (tstamp 0a9c224f-0a50-4687-846b-6026ef881c39))
  (segment (start 78.867 43.688) (end 78.867 42.634241) (width 0.2) (layer "F.Cu") (net 1) (tstamp 0ab14b62-b122-4065-93bc-c84f91b66063))
  (segment (start 27.3945 25.406) (end 25.2145 27.586) (width 0.5) (layer "F.Cu") (net 1) (tstamp 0acae014-852c-4163-b9db-635c8705dc8a))
  (segment (start 30.861 54.102) (end 28.321 54.102) (width 0.25) (layer "F.Cu") (net 1) (tstamp 0c429b56-8ba7-420d-9b24-ec6f12844ee6))
  (segment (start 144.78 107.061) (end 157.099 107.061) (width 3) (layer "F.Cu") (net 1) (tstamp 0c8d11e7-4578-4372-ba3c-5fcd73cd442b))
  (segment (start 40.891 20.151) (end 40.891 24.3125) (width 0.5) (layer "F.Cu") (net 1) (tstamp 0ca9903f-0993-49d1-bb5e-35c35a71a017))
  (segment (start 62.865 85.946) (end 61.628 85.946) (width 0.5) (layer "F.Cu") (net 1) (tstamp 0d94527d-9430-4295-aea5-813481eb63fd))
  (segment (start 48.8565 55.8565) (end 48.8565 52.324) (width 0.25) (layer "F.Cu") (net 1) (tstamp 115114da-4120-4dcf-87b4-04ac5770ceb5))
  (segment (start 68.834 26.6706) (end 68.834 28.194) (width 0.2) (layer "F.Cu") (net 1) (tstamp 119361be-f6ba-4da8-98e6-b57e65e696f8))
  (segment (start 70.993 22.733) (end 70.993 28.321) (width 0.2) (layer "F.Cu") (net 1) (tstamp 13d41834-4c3b-4a5e-8080-bd78e7984092))
  (segment (start 76.618759 40.386) (end 65.786 40.386) (width 0.2) (layer "F.Cu") (net 1) (tstamp 13e040e5-b229-4b59-886f-7bcb5b796855))
  (segment (start 121.539 68.326) (end 122.301 69.088) (width 2) (layer "F.Cu") (net 1) (tstamp 1576a7aa-a0ef-4c15-b59f-99fd61b28de1))
  (segment (start 59.309 37.084) (end 59.9055 36.4875) (width 0.2) (layer "F.Cu") (net 1) (tstamp 1644be03-b4a9-4727-8f77-ef1cf815ff68))
  (segment (start 26.543 55.88) (end 26.543 56.6805) (width 0.2) (layer "F.Cu") (net 1) (tstamp 16bff583-11dd-4674-aa77-1d8bb12d2d84))
  (segment (start 64.77 40.132) (end 64.77 38.608) (width 0.2) (layer "F.Cu") (net 1) (tstamp 175ab218-bd15-4ca6-bd8a-10bcec97a665))
  (segment (start 30.9185 90.151) (end 29.991 91.0785) (width 0.25) (layer "F.Cu") (net 1) (tstamp 1bb1cae1-56df-4d4e-8071-6e54d5c6e470))
  (segment (start 41.5675 26.9625) (end 41.5675 25.4) (width 0.254) (layer "F.Cu") (net 1) (tstamp 1cefd12c-0efd-48cb-b84d-c7c6534f9f3d))
  (segment (start 34.29 27.432) (end 32.264 25.406) (width 0.5) (layer "F.Cu") (net 1) (tstamp 1e91af3e-4d91-4957-8ff7-98e5af2f0893))
  (segment (start 37.954 79.991) (end 37.9535 79.991) (width 0.25) (layer "F.Cu") (net 1) (tstamp 1f04eec9-3879-4ae1-b207-6c429f995f3f))
  (segment (start 113.8835 66.0785) (end 113.8835 68.326) (width 0.7) (layer "F.Cu") (net 1) (tstamp 20579d6b-a569-4652-94f7-c5e3edb57683))
  (segment (start 29.2985 52.8085) (end 29.656 52.451) (width 0.25) (layer "F.Cu") (net 1) (tstamp 20771227-a2ba-4649-9cb8-a2f479c218fe))
  (segment (start 60.768489 32.957511) (end 61.630748 32.957511) (width 0.2) (layer "F.Cu") (net 1) (tstamp 25a393a0-0f02-4e75-af17-b1271ebb243c))
  (segment (start 63.246 35.306) (end 63.881 34.671) (width 0.2) (layer "F.Cu") (net 1) (tstamp 29728b47-7fb9-4951-b8c8-62d86dfb7d94))
  (segment (start 119.2885 68.326) (end 113.8835 68.326) (width 2) (layer "F.Cu") (net 1) (tstamp 2c703400-4c25-480d-80ae-f0841fbd44fb))
  (segment (start 63.246 39.4585) (end 63.246 37.973) (width 0.2) (layer "F.Cu") (net 1) (tstamp 2d59216d-9399-44df-8db2-154292c8e907))
  (segment (start 113.8835 68.326) (end 113.8835 70.5735) (width 0.7) (layer "F.Cu") (net 1) (tstamp 2e9c4912-50be-4dd1-ba12-e805e4d8ab47))
  (segment (start 86.741 50.2035) (end 86.741 53.4285) (width 0.25) (layer "F.Cu") (net 1) (tstamp 2fa80cd5-2cc4-4ff2-b705-b01a699fdb67))
  (segment (start 64.135 37.973) (end 63.246 37.973) (width 0.2) (layer "F.Cu") (net 1) (tstamp 2ff6434b-0fd5-4341-b9e8-da4a7585a218))
  (segment (start 80.666 52.451) (end 76.171113 52.451) (width 0.25) (layer "F.Cu") (net 1) (tstamp 30ad6975-d025-4b5d-b683-4f3e52843bd4))
  (segment (start 60.96 24.80898) (end 60.96 27.559) (width 0.2) (layer "F.Cu") (net 1) (tstamp 312aa253-e62c-49d7-a5cf-7dd07ae74fa9))
  (segment (start 79.121 43.942) (end 78.867 43.688) (width 0.2) (layer "F.Cu") (net 1) (tstamp 3223a221-284f-4c6d-8c57-8237e42bae0b))
  (segment (start 39.516 81.553) (end 37.954 79.991) (width 0.25) (layer "F.Cu") (net 1) (tstamp 36ae872e-24f4-4f57-b426-e927fba5dee9))
  (segment (start 76.171113 52.451) (end 74.676 53.946113) (width 0.25) (layer "F.Cu") (net 1) (tstamp 37991a2e-fab3-403f-be5e-3dc18f8c04a2))
  (segment (start 84.201 68.326) (end 78.994 68.326) (width 2) (layer "F.Cu") (net 1) (tstamp 396b7cc1-bcf3-4010-87d8-7bd6bcf35f8d))
  (segment (start 28.956 92.48994) (end 28.956 92.2215) (width 0.25) (layer "F.Cu") (net 1) (tstamp 39bcf973-dc5f-4c58-b652-4d18b223ef7b))
  (segment (start 71.755 68.326) (end 79.883 68.326) (width 3) (layer "F.Cu") (net 1) (tstamp 3bb0b53a-6fa1-4a33-8f97-5ea3ff800429))
  (segment (start 59.309 37.084) (end 58.5085 36.2835) (width 0.2) (layer "F.Cu") (net 1) (tstamp 3d4ea9fb-49ec-4e1e-afd4-e7f97b6ba950))
  (segment (start 65.786 40.386) (end 65.786 39.497) (width 0.2) (layer "F.Cu") (net 1) (tstamp 3fea17fd-ab26-436b-9c2d-dbf83dcbcf92))
  (segment (start 28.956 76.0345) (end 28.956 74.168) (width 0.25) (layer "F.Cu") (net 1) (tstamp 41f33049-1dbc-4864-815f-daa99c321ace))
  (segment (start 32.137 25.406) (end 31.891 25.406) (width 0.5) (layer "F.Cu") (net 1) (tstamp 422b4fa2-6142-4387-84bf-33dd1702c7ac))
  (segment (start 43.161 90.151) (end 43.053 90.043) (width 0.25) (layer "F.Cu") (net 1) (tstamp 42ff7b7d-4a55-46bd-94f0-e790d2413022))
  (segment (start 68.961 28.321) (end 70.993 28.321) (width 0.2) (layer "F.Cu") (net 1) (tstamp 4334bc4e-c274-43a1-8951-953e4c4ad505))
  (segment (start 60.071 39.4585) (end 60.071 37.973) (width 0.2) (layer "F.Cu") (net 1) (tstamp 455b5c96-ef57-43a5-a46b-00aaceb5115d))
  (segment (start 63.5 28.321) (end 68.961 28.321) (width 0.2) (layer "F.Cu") (net 1) (tstamp 4985db36-4825-4ee8-8403-afc3fd876142))
  (segment (start 79.121 47.371) (end 77.851 47.371) (width 0.5) (layer "F.Cu") (net 1) (tstamp 49a50931-a9cc-4394-81a3-b5ba50b9f9c6))
  (segment (start 54.991 49.403) (end 56.134 49.403) (width 0.5) (layer "F.Cu") (net 1) (tstamp 4b717de8-438f-4df1-9907-ca67f9e5d432))
  (segment (start 63.119 37.846) (end 60.071 37.846) (width 0.2) (layer "F.Cu") (net 1) (tstamp 4cdf2d9f-0068-4d1e-8ead-72751216bde8))
  (segment (start 60.91602 24.765) (end 60.96 24.80898) (width 0.2) (layer "F.Cu") (net 1) (tstamp 50c5b8b8-165f-4cc6-9565-3ab6e2d023ff))
  (segment (start 80.666 52.451) (end 85.7635 52.451) (width 0.25) (layer "F.Cu") (net 1) (tstamp 50d3d94e-3014-4bc1-ad22-5242c39a5f5e))
  (segment (start 71.755 68.326) (end 71.247 67.818) (width 2) (layer "F.Cu") (net 1) (tstamp 52484c83-de4f-41f8-a1ff-bb8b548fc75c))
  (segment (start 32.264 25.406) (end 27.3945 25.406) (width 0.5) (layer "F.Cu") (net 1) (tstamp 5398bc6a-86e6-4de0-aca1-4de64681625e))
  (segment (start 59.9055 36.4875) (end 59.9055 33.8205) (width 0.2) (layer "F.Cu") (net 1) (tstamp 53cdbc2c-d244-460b-b403-b85b19b8e854))
  (segment (start 86.9035 68.326) (end 88.773 68.326) (width 2) (layer "F.Cu") (net 1) (tstamp 54f3239b-2657-451f-b9a6-b33b6fbabe02))
  (segment (start 56.896 124.206) (end 55.727 124.206) (width 0.25) (layer "F.Cu") (net 1) (tstamp 552a02cb-2ea6-45c1-ab61-e6691caec494))
  (segment (start 39.516 84.451) (end 39.516 81.553) (width 0.25) (layer "F.Cu") (net 1) (tstamp 56ccd615-b116-495c-a70b-6497e5863db9))
  (segment (start 62.357 28.321) (end 63.5 28.321) (width 0.2) (layer "F.Cu") (net 1) (tstamp 58f0f21e-8a22-4552-9332-95d8048e4a2e))
  (segment (start 85.7635 52.451) (end 86.741 53.4285) (width 0.25) (layer "F.Cu") (net 1) (tstamp 5d928e05-f207-469a-920f-afb8948241cc))
  (segment (start 31.242 53.721) (end 30.861 54.102) (width 0.25) (layer "F.Cu") (net 1) (tstamp 5f66208a-dcfd-41d6-ae33-9d3678a27e18))
  (segment (start 119.2885 68.326) (end 121.539 68.326) (width 2) (layer "F.Cu") (net 1) (tstamp 602ecd00-1ae0-42b2-9099-cec7aa2c8f18))
  (segment (start 28.956 92.2215) (end 30.099 91.0785) (width 0.25) (layer "F.Cu") (net 1) (tstamp 607fc57d-1e7f-4763-a445-25936570fca6))
  (segment (start 98.171 68.326) (end 98.171 70.5735) (width 0.7) (layer "F.Cu") (net 1) (tstamp 6656e2bf-b2f3-4579-99ae-95abe10cddae))
  (segment (start 80.391 43.942) (end 79.121 43.942) (width 0.2) (layer "F.Cu") (net 1) (tstamp 6675b632-5be7-493d-b8bb-fc215c7148df))
  (segment (start 73.533 127.2925) (end 74.0025 127.762) (width 0.25) (layer "F.Cu") (net 1) (tstamp 691c07c3-7256-4a61-a614-4b42d8c6e134))
  (segment (start 28.702 44.958) (end 28.448 45.212) (width 0.25) (layer "F.Cu") (net 1) (tstamp 69bbf555-0139-4362-a6dd-ea45dc7f1692))
  (segment (start 69.723 121.894) (end 69.723 127.254) (width 0.25) (layer "F.Cu") (net 1) (tstamp 6b614e9e-c659-4e2c-8eb3-a298ba69146a))
  (segment (start 61.630748 32.957511) (end 62.357 32.231259) (width 0.2) (layer "F.Cu") (net 1) (tstamp 6beee327-a99d-4aa9-b53d-ee70674164a5))
  (segment (start 81.4985 66.0785) (end 81.4985 68.326) (width 0.7) (layer "F.Cu") (net 1) (tstamp 6eebbff2-b3d2-4570-aa9f-8117a4149633))
  (segment (start 39.516 84.451) (end 39.516 86.468) (width 0.25) (layer "F.Cu") (net 1) (tstamp 6f81e3e3-d450-497f-b721-7f7d31fe77ac))
  (segment (start 65.786 39.4585) (end 65.786 38.546) (width 0.25) (layer "F.Cu") (net 1) (tstamp 701259a4-6b89-4bd8-bde9-c817da10b701))
  (segment (start 28.448 45.212) (end 26.035 45.212) (width 0.25) (layer "F.Cu") (net 1) (tstamp 71aa397e-9a82-4efd-b81b-d50c22ee387b))
  (segment (start 69.723 127.254) (end 70.739 128.27) (width 0.25) (layer "F.Cu") (net 1) (tstamp 733d70e3-b7a5-4c8d-9c24-bf0881c5f4ad))
  (segment (start 48.895 53.0475) (end 48.8565 53.086) (width 0.25) (layer "F.Cu") (net 1) (tstamp 7583d3cb-8489-40a8-a876-505d857640e8))
  (segment (start 45.191 41.275) (end 45.191 38.121) (width 0.254) (layer "F.Cu") (net 1) (tstamp 77415a0b-2025-45a6-bee0-3940b412b70c))
  (segment (start 49.676 88.5885) (end 48.1135 90.151) (width 0.25) (layer "F.Cu") (net 1) (tstamp 7ef3e13c-21cc-4f41-a1a9-45c45b2b401f))
  (segment (start 56.134 50.071) (end 57.371 51.308) (width 0.5) (layer "F.Cu") (net 1) (tstamp 8086f3a4-63e7-4891-918e-1e2dab9ba26a))
  (segment (start 61.722 28.321) (end 62.357 28.321) (width 0.2) (layer "F.Cu") (net 1) (tstamp 80a283ec-37a2-4def-adb6-01de3bb0a2b2))
  (segment (start 61.62468 103.68708) (end 59.30646 103.68708) (width 0.5) (layer "F.Cu") (net 1) (tstamp 8142b05c-36f9-4236-93d3-7ea5400962c2))
  (segment (start 70.993 28.321) (end 72.1985 29.5265) (width 0.2) (layer "F.Cu") (net 1) (tstamp 84fc07be-80b6-4da4-b411-5bed4a002d76))
  (segment (start 81.4985 68.326) (end 81.4985 70.5735) (width 0.7) (layer "F.Cu") (net 1) (tstamp 85b699c1-b791-4be1-88ac-6b7b59e3883b))
  (segment (start 29.2985 55.626) (end 29.2985 53.8865) (width 0.25) (layer "F.Cu") (net 1) (tstamp 8638ba04-0a81-4f04-b345-5d10467daf9b))
  (segment (start 72.1985 29.5265) (end 72.1985 30.5685) (width 0.2) (layer "F.Cu") (net 1) (tstamp 87bacaaf-e3f2-4d11-a060-a109d1ae44a1))
  (segment (start 48.895 51.308) (end 48.895 53.0475) (width 0.25) (layer "F.Cu") (net 1) (tstamp 8c3f5dbb-615a-4217-b4a7-204c9c252e45))
  (segment (start 62.611 135.636) (end 63.54 136.565) (width 0.25) (layer "F.Cu") (net 1) (tstamp 8e3ab08b-1d57-4aee-ae15-92d659614b03))
  (segment (start 40.316 95.851) (end 40.316 98.9515) (width 0.2) (layer "F.Cu") (net 1) (tstamp 908f913d-7835-4eda-896b-2c4af441d3ce))
  (segment (start 33.816 90.151) (end 35.922 90.151) (width 0.25) (layer "F.Cu") (net 1) (tstamp 93035eef-6e16-4733-9024-1f4543632764))
  (segment (start 88.773 68.326) (end 89.662 68.326) (width 2) (layer "F.Cu") (net 1) (tstamp 9319dabe-955a-4b6a-b930-ea7bb017130c))
  (segment (start 63.246 37.973) (end 63.246 35.306) (width 0.2) (layer "F.Cu") (net 1) (tstamp 96392b1d-7d92-4e40-b4a1-bb77c8a0074a))
  (segment (start 61.6458 103.7082) (end 61.62468 103.68708) (width 0.5) (layer "F.Cu") (net 1) (tstamp 965bdea4-fe1c-4e04-8bcc-fae9b9e38840))
  (segment (start 39.5355 27.432) (end 34.29 27.432) (width 0.5) (layer "F.Cu") (net 1) (tstamp 96fe7e9a-e342-42a9-8ad6-b5d555572f91))
  (segment (start 65.786 40.386) (end 65.024 40.386) (width 0.2) (layer "F.Cu") (net 1) (tstamp 97e5ef87-afe0-4ecc-b924-ff8f38218b30))
  (segment (start 40.316 98.9515) (end 40.64 99.2755) (width 0.2) (layer "F.Cu") (net 1) (tstamp 99675ac3-94bb-482b-9d32-89376195f84e))
  (segment (start 46.736 32.131) (end 41.5675 26.9625) (width 0.254) (layer "F.Cu") (net 1) (tstamp 99bc6596-0963-48b4-8f9d-ae3513dff619))
  (segment (start 68.834 28.194) (end 68.961 28.321) (width 0.2) (layer "F.Cu") (net 1) (tstamp 9bace731-8d09-4cad-891a-0027044da717))
  (segment (start 147.955 20.447) (end 147.32 19.812) (width 1) (layer "F.Cu") (net 1) (tstamp 9c4b777e-1da8-4326-9d32-3bad09f08740))
  (segment (start 122.301 69.088) (end 128.397 75.184) (width 3) (layer "F.Cu") (net 1) (tstamp 9caab44f-2ce2-446b-bf06-aa908e762d7b))
  (segment (start 72.5555 128.27) (end 73.533 127.2925) (width 0.25) (layer "F.Cu") (net 1) (tstamp 9cae5717-97db-4fc0-ad97-02d177d40292))
  (segment (start 61.5958 106.222) (end 59.309 106.222) (width 0.25) (layer "F.Cu") (net 1) (tstamp 9de7cae0-e09c-41f5-90a5-c349bd4fd548))
  (segment (start 56.134 49.403) (end 56.134 50.071) (width 0.5) (layer "F.Cu") (net 1) (tstamp a1c66396-fe94-4d01-96a5-c6b4632d82a4))
  (segment (start 147.32 19.812) (end 144.37 19.812) (width 1) (layer "F.Cu") (net 1) (tstamp a283198d-4300-4500-a077-0bfa55694aca))
  (segment (start 63.54 136.565) (end 63.54 139.257) (width 0.25) (layer "F.Cu") (net 1) (tstamp a32a9430-5f08-432e-9b7b-5c0d496f6b78))
  (segment (start 65.024 40.386) (end 64.77 40.132) (width 0.2) (layer "F.Cu") (net 1) (tstamp a85a1b7c-b68c-475a-b72c-428312873b8c))
  (segment (start 71.882 21.844) (end 70.993 22.733) (width 0.2) (layer "F.Cu") (net 1) (tstamp a92aec00-4595-4d1f-bf3f-ba292a4b2bcc))
  (segment (start 74.676 53.946113) (end 74.676 49.685888) (width 0.25) (layer "F.Cu") (net 1) (tstamp a92ba305-13ca-47bd-b92d-65e66792a086))
  (segment (start 23.794 61.976) (end 26.035 61.976) (width 0.2) (layer "F.Cu") (net 1) (tstamp ad657733-11cc-4438-a8f0-0a2eaa15270a))
  (segment (start 65.786 39.497) (end 65.786 38.546) (width 0.25) (layer "F.Cu") (net 1) (tstamp ada0e54a-1529-4cdc-9072-022f2419fd23))
  (segment (start 73.406 21.844) (end 71.882 21.844) (width 0.2) (layer "F.Cu") (net 1) (tstamp addbb059-264d-45cd-b5da-44fa3fd8376a))
  (segment (start 71.247 67.818) (end 71.247 65.278) (width 2) (layer "F.Cu") (net 1) (tstamp aec2c045-a65a-4781-adc3-a0b36f62d956))
  (segment (start 79.4512 47.0408) (end 79.121 47.371) (width 0.5) (layer "F.Cu") (net 1) (tstamp afe14c65-7044-4165-8239-69faeab5bb6f))
  (segment (start 45.191 38.121) (end 46.736 36.576) (width 0.254) (layer "F.Cu") (net 1) (tstamp b0edb768-f1dd-4c49-ac3f-f44254e5c26f))
  (segment (start 86.9035 68.326) (end 84.201 68.326) (width 2) (layer "F.Cu") (net 1) (tstamp b2632c2f-2134-4886-904d-ebd22a5ba437))
  (segment (start 74 20.583) (end 74 21.25) (width 0.2) (layer "F.Cu") (net 1) (tstamp b3fe493a-4438-43b5-8164-84ec2593d298))
  (segment (start 74 21.25) (end 73.406 21.844) (width 0.2) (layer "F.Cu") (net 1) (tstamp b8c7b8b0-f094-4712-8a03-b29b1538664a))
  (segment (start 59.9055 33.8205) (end 60.768489 32.957511) (width 0.2) (layer "F.Cu") (net 1) (tstamp b911064e-54c9-44f2-8f26-d41c0e8dd241))
  (segment (start 72.1985 30.5685) (end 75.311 30.5685) (width 0.25) (layer "F.Cu") (net 1) (tstamp c17c1b5a-fb0b-4b14-a99e-56c35d1132a0))
  (segment (start 74.0025 127.762) (end 78.796 127.762) (width 0.25) (layer "F.Cu") (net 1) (tstamp c6c8256f-0868-4f66-a73e-f33ba2c5710f))
  (segment (start 35.922 90.151) (end 35.941 90.17) (width 0.25) (layer "F.Cu") (net 1) (tstamp c711adc7-13bb-4624-b671-b84e650a348e))
  (segment (start 63.881 34.671) (end 64.8585 34.671) (width 0.2) (layer "F.Cu") (net 1) (tstamp c7fb55b0-f787-4fcf-a3d7-2c1f29d41035))
  (segment (start 58.5085 36.2835) (end 58.5085 34.671) (width 0.2) (layer "F.Cu") (net 1) (tstamp c9ef5821-66d7-4c8b-a920-7e7f2a89e03e))
  (segment (start 40.891 24.3125) (end 41.773 25.1945) (width 0.5) (layer "F.Cu") (net 1) (tstamp ca23f623-731e-4f8c-a0b8-57bd02bb9fb3))
  (segment (start 60.071 37.846) (end 59.309 37.084) (width 0.2) (layer "F.Cu") (net 1) (tstamp cde634e3-7b8a-4aac-a58f-079af32311da))
  (segment (start 100.965 68.326) (end 105.283 68.326) (width 2) (layer "F.Cu") (net 1) (tstamp cf1fba99-32c0-4252-8c32-cdd92b61f418))
  (segment (start 54.864 49.276) (end 54.991 49.403) (width 0.5) (layer "F.Cu") (net 1) (tstamp cf4aced4-9b73-4701-a4c7-b69143d46d45))
  (segment (start 41.5675 25.4) (end 39.5355 27.432) (width 0.5) (layer "F.Cu") (net 1) (tstamp d09990bb-c496-4c41-9e28-ab867993094b))
  (segment (start 39.516 86.468) (end 39.497 86.487) (width 0.25) (layer "F.Cu") (net 1) (tstamp d130567e-3b37-406c-9504-f174c2b46b24))
  (segment (start 61.628 85.946) (end 60.96 86.614) (width 0.5) (layer "F.Cu") (net 1) (tstamp d1d1622b-5a53-4ead-b381-65052f2a3a3a))
  (segment (start 60.071 37.973) (end 60.071 37.846) (width 0.2) (layer "F.Cu") (net 1) (tstamp d209bc43-e796-471c-b0ea-340cf6da1302))
  (segment (start 70.739 128.27) (end 72.5555 128.27) (width 0.25) (layer "F.Cu") (net 1) (tstamp d254d4a1-8b21-4547-a2a7-11e8c9d3933e))
  (segment (start 48.1135 90.151) (end 45.216 90.151) (width 0.25) (layer "F.Cu") (net 1) (tstamp dae8e21b-6240-43ac-b759-94ced031a6e4))
  (segment (start 55.727 124.206) (end 54.61 123.089) (width 0.25) (layer "F.Cu") (net 1) (tstamp de3d7d85-9943-457f-85c3-f771b9cc66c3))
  (segment (start 40.431 19.691) (end 40.891 20.151) (width 0.5) (layer "F.Cu") (net 1) (tstamp e0d7f811-c3b0-4850-a60b-1ef095b5ac05))
  (segment (start 46.736 36.576) (end 46.736 32.131) (width 0.254) (layer "F.Cu") (net 1) (tstamp e235e02f-5cc6-4354-b896-3715c82df735))
  (segment (start 33.816 90.151) (end 30.9185 90.151) (width 0.25) (layer "F.Cu") (net 1) (tstamp e3862f5a-5f0f-4adf-b10f-af9aa280c949))
  (segment (start 29.2985 53.8865) (end 29.2985 52.8085) (width 0.25) (layer "F.Cu") (net 1) (tstamp e41658a9-e5ba-468a-8a4f-cd3754fdbdab))
  (segment (start 105.283 68.326) (end 106.172 68.326) (width 2) (layer "F.Cu") (net 1) (tstamp e4efa99b-c117-4f7f-830d-41c04a5a0c68))
  (segment (start 28.321 54.102) (end 26.543 55.88) (width 0.2) (layer "F.Cu") (net 1) (tstamp e57210d2-aff7-4c91-a971-f4e40ce1dd8f))
  (segment (start 31.369 53.721) (end 31.242 53.721) (width 0.25) (layer "F.Cu") (net 1) (tstamp ead5e57a-5c6d-456e-b6a7-92c2181c1c67))
  (segment (start 89.662 68.326) (end 100.965 68.326) (width 2) (layer "F.Cu") (net 1) (tstamp eb8d8ea6-9077-4fa6-ace8-2fd70e155a24))
  (segment (start 106.172 68.326) (end 113.8835 68.326) (width 2) (layer "F.Cu") (net 1) (tstamp ed56d35e-3f0b-4206-8aba-4db00e35e651))
  (segment (start 70.967 120.65) (end 69.723 121.894) (width 0.25) (layer "F.Cu") (net 1) (tstamp edeee36d-e39c-49c9-b090-958729d8a7ab))
  (segment (start 55.753 24.511) (end 55.753 22.651) (width 0.2) (layer "F.Cu") (net 1) (tstamp ee41235c-d0b4-4c06-83a9-510d5eeebd2a))
  (segment (start 98.171 66.0785) (end 98.171 68.326) (width 0.7) (layer "F.Cu") (net 1) (tstamp eed986e4-7421-4247-9743-1f25f64a1634))
  (segment (start 128.397 75.184) (end 128.397 90.678) (width 3) (layer "F.Cu") (net 1) (tstamp ef9c2026-65e2-4617-ad2f-b53b09fe8c1b))
  (segment (start 60.96 27.559) (end 61.722 28.321) (width 0.2) (layer "F.Cu") (net 1) (tstamp f5937144-d500-4d93-9468-2d1bf99d970c))
  (segment (start 41.773 25.1945) (end 41.5675 25.4) (width 0.25) (layer "F.Cu") (net 1) (tstamp f8aa4ad4-1f67-4510-8cff-4b5f39715119))
  (segment (start 45.216 90.151) (end 43.161 90.151) (width 0.25) (layer "F.Cu") (net 1) (tstamp fc66d61d-17b6-48a3-b1f6-8c8836f54fd9))
  (segment (start 40.316 94.05) (end 40.386 93.98) (width 0.25) (layer "F.Cu") (net 1) (tstamp ff6a63b8-3f43-400c-a4e1-dd9414570a59))
  (via (at 84.201 52.451) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 1) (tstamp 00d64338-0cb3-45bb-a0ef-4f7a1372979b))
  (via (at 62.611 135.636) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 1) (tstamp 06a403b9-2065-4f3f-9e40-d3d16f6a4540))
  (via (at 84.201 68.326) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 1) (tstamp 0830dd84-80d3-4c83-94cb-cf1c755c5687))
  (via (at 147.32 19.812) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 1) (tstamp 0f17fe8a-d76a-4d44-aaaf-93630bfb6e9a))
  (via (at 157.861 107.061) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 1) (tstamp 10a3ee75-5de6-48e7-b275-d426e87380c2))
  (via (at 71.247 66.167) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 1) (tstamp 13dd378d-4d20-4df7-8a0b-03105549cb38))
  (via (at 71.247 65.278) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 1) (tstamp 25ba18b8-37e9-49b0-b1d0-55cba78e9075))
  (via (at 79.883 68.326) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 1) (tstamp 27663a5f-e74e-4a07-a290-3be29be9dc1c))
  (via (at 156.083 107.061) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 1) (tstamp 2b9550d3-c023-40e7-855a-cedfe3b3afdf))
  (via (at 156.972 107.061) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 1) (tstamp 2d79fb7a-e401-4312-bb31-04829d0ad34f))
  (via (at 122.047 68.834) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 1) (tstamp 2f1b5b19-ee5e-460a-badb-0dc27e4e2fb3))
  (via (at 71.247 68.834) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 1) (tstamp 332110d9-8c2f-40bc-8ed7-e49b3a6094ea))
  (via (at 147.955 20.447) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 1) (tstamp 350f3a85-80d1-4ebd-9b78-db754cf292b4))
  (via (at 61.6458 103.7082) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 1) (tstamp 3ad994ab-3173-4415-ad44-8618efaec7f8))
  (via (at 106.172 68.326) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 1) (tstamp 4c3f30c3-b905-413d-bb93-8124cb336c19))
  (via (at 40.386 93.98) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 1) (tstamp 4dba89f2-d17e-4c84-99a4-430889bb250b))
  (via (at 79.4512 47.0408) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 1) (tstamp 5082275b-a775-49c7-b3cd-aedbefe27ea6))
  (via (at 78.994 68.326) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 1) (tstamp 526d73e2-3e46-4147-9fb3-710731c4eebf))
  (via (at 71.247 67.945) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 1) (tstamp 62db07bd-0738-400a-b7d7-01385207a9e4))
  (via (at 100.965 68.326) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 1) (tstamp 65080eee-f1e5-4ac1-a2c0-26abc6797e7a))
  (via (at 48.895 51.308) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 1) (tstamp 6b6de0b6-4d7d-4491-916a-326ae20f99a2))
  (via (at 39.497 86.487) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 1) (tstamp 6f38a785-8d5a-4646-9d0a-eac080694e37))
  (via (at 55.753 24.511) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 1) (tstamp 7a627e6c-97ea-4b4c-96ec-27091ff55c8d))
  (via (at 26.035 61.976) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 1) (tstamp 7b42e4ab-0fd2-4bda-9449-b378135a6949))
  (via (at 80.391 43.942) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 1) (tstamp 8ff399af-435c-4d86-861e-24d5461069bc))
  (via (at 28.702 44.958) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 1) (tstamp 91054e3e-f43e-4350-8cae-605a47dc1139))
  (via (at 85.09 68.326) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 1) (tstamp 92cedadf-cabd-47b1-a8ac-47bebd300155))
  (via (at 101.854 68.326) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 1) (tstamp 99a6b36a-af7f-4878-9296-1d196586a344))
  (via (at 89.662 68.326) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 1) (tstamp a736c095-b25d-44ab-8a71-f0ccccc80c78))
  (via (at 121.285 68.326) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 1) (tstamp b09b8614-818d-459f-91eb-de3be44c4319))
  (via (at 117.602 68.326) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 1) (tstamp b56ee16a-f005-4004-982d-d380b8709d3d))
  (via (at 61.6712 106.1466) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 1) (tstamp b692ec90-3325-4812-a133-54bc2fb36b54))
  (via (at 28.956 74.168) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 1) (tstamp b80d98de-1959-4041-adf4-312d06250b5c))
  (via (at 80.899 68.326) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 1) (tstamp bf90f101-fdde-44a4-9598-f35c60fcb723))
  (via (at 54.864 49.276) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 1) (tstamp c36b574a-00a2-4b44-8e5e-cff91c935dad))
  (via (at 60.91602 24.765) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 1) (tstamp c765c62b-f1c9-4111-b1d7-a17811bed4e1))
  (via (at 28.956 92.48994) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 1) (tstamp c8b6987b-ad38-46fe-8f7e-353b876b1af7))
  (via (at 77.851 47.371) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 1) (tstamp c978ee78-5353-42ad-8051-67a9538da37a))
  (via (at 88.773 68.326) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 1) (tstamp c9845e4a-22b6-4e2e-9c7b-ae59217aee26))
  (via (at 56.896 124.206) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 1) (tstamp c9c390e0-277f-46e3-aa7b-ce953ea663b9))
  (via (at 116.713 68.326) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 1) (tstamp ceedda71-a0d1-43d6-b3f9-00ef640f4ebc))
  (via (at 71.247 67.056) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 1) (tstamp d7b086bf-90e5-40f6-9460-125dcb61a048))
  (via (at 31.369 53.721) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 1) (tstamp df89379c-3e94-4bea-acc7-a46c8fe500cc))
  (via (at 43.053 90.043) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 1) (tstamp f17cc87f-688c-4d75-96bb-de671f71652a))
  (via (at 56.134 49.403) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 1) (tstamp fa073c46-9ada-44e4-a1c1-330e94d663f7))
  (via (at 60.96 86.614) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 1) (tstamp fbe74d50-cf7c-45bf-81bb-7aa9333c3958))
  (via (at 35.941 90.17) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 1) (tstamp fdd8f583-f344-4f98-954c-9b9c7aa6427f))
  (via (at 105.283 68.326) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 1) (tstamp ffceba03-9d0f-46c4-be1d-84293694c670))
  (segment (start 27.598 150.241) (end 25.908 150.241) (width 0.25) (layer "B.Cu") (net 1) (tstamp 0005520b-50b8-4eb4-bb3c-f8c90c5a7c3f))
  (segment (start 28.559 151.638) (end 28.559 151.241) (width 0.25) (layer "B.Cu") (net 1) (tstamp 00871c70-0e3d-40b3-8e88-8f9781487d51))
  (segment (start 28.956 92.202) (end 30.988 90.17) (width 0.25) (layer "B.Cu") (net 1) (tstamp 05870a34-5524-44fd-8343-38f639acef26))
  (segment (start 61.722 99.441) (end 61.722 89.281) (width 0.5) (layer "B.Cu") (net 1) (tstamp 05ad3621-017a-45f4-8975-cd902f8cbd0f))
  (segment (start 103.576 68.326) (end 86.9035 68.326) (width 2) (layer "B.Cu") (net 1) (tstamp 06b86533-ea4f-4506-a5ac-a1f565b06e6b))
  (segment (start 79.756 68.326) (end 79.121 67.691) (width 0.5) (layer "B.Cu") (net 1) (tstamp 075b83f4-a6c5-4638-8861-20afeaaa0e2a))
  (segment (start 157.226 107.061) (end 146.05 107.061) (width 3) (layer "B.Cu") (net 1) (tstamp 08f71e66-6b22-48bb-8098-835e68b2b470))
  (segment (start 60.66202 24.511) (end 55.753 24.511) (width 0.2) (layer "B.Cu") (net 1) (tstamp 0de244ee-f7d7-400a-8d22-1d6ea65f6419))
  (segment (start 81.407 116.332) (end 79.629 116.332) (width 3) (layer "B.Cu") (net 1) (tstamp 0ebb427c-8af2-4f40-93f2-226db82bc2b5))
  (segment (start 77.089 100.965) (end 77.089 108.966) (width 2) (layer "B.Cu") (net 1) (tstamp 0fecd439-cba3-4246-a9d3-a3ccba021938))
  (segment (start 54.61 47.498) (end 54.61 49.022) (width 0.5) (layer "B.Cu") (net 1) (tstamp 11f2cf1b-8c51-495e-803d-8565e82123ab))
  (segment (start 81.915 102.722) (end 81.259 103.378) (width 0.5) (layer "B.Cu") (net 1) (tstamp 16ca1386-5c84-4b4a-98c0-3fadfe681b5b))
  (segment (start 165.981 63.286) (end 161.711 63.286) (width 4) (layer "B.Cu") (net 1) (tstamp 17dee68d-5c92-482b-8baa-002a99009bb5))
  (segment (start 41.656 46.101) (end 41.656 42.926) (width 0.5) (layer "B.Cu") (net 1) (tstamp 18c37865-2379-4395-ac51-4773ed647652))
  (segment (start 87.376 30.881) (end 87.376 41.021) (width 0.5) (layer "B.Cu") (net 1) (tstamp 1b966a2f-0410-48cb-aa1b-d90135f8ef76))
  (segment (start 128.397 90.678) (end 128.397 88.011) (width 3) (layer "B.Cu") (net 1) (tstamp 1c8cacb9-97d9-484f-a54e-0811388270f4))
  (segment (start 157.861 107.061) (end 156.083 107.061) (width 3) (layer "B.Cu") (net 1) (tstamp 1d59bbcc-1e89-4942-9653-66fc9e911ee4))
  (segment (start 165.981 37.056) (end 160.881 37.056) (width 5) (layer "B.Cu") (net 1) (tstamp 1e36a6c7-7d31-4822-9376-d09599c24b92))
  (segment (start 71.4915 160.9185) (end 71.501 160.9185) (width 0.5) (layer "B.Cu") (net 1) (tstamp 1e592932-3939-47d5-b5a9-cdbbab6bae54))
  (segment (start 165.989 23.956) (end 163.369 23.956) (width 5) (layer "B.Cu") (net 1) (tstamp 1e85096d-a02c-4104-9ec6-efdba726e314))
  (segment (start 78.796 127.762) (end 83.947 127.762) (width 1) (layer "B.Cu") (net 1) (tstamp 203f0abd-cdac-4847-b498-296af829df6e))
  (segment (start 128.397 75.184) (end 127.127 73.914) (width 3) (layer "B.Cu") (net 1) (tstamp 205ed380-dd46-49b3-9802-be17b168e694))
  (segment (start 62.103 99.822) (end 76.454 99.822) (width 2) (layer "B.Cu") (net 1) (tstamp 21357e39-cbd7-4b9a-be84-91dfef55cd50))
  (segment (start 76.581 110.49) (end 76.581 109.728) (width 3) (layer "B.Cu") (net 1) (tstamp 22114651-12b7-43d5-a15b-d61b1badd4a4))
  (segment (start 56.896 124.206) (end 56.896 107.442) (width 0.25) (layer "B.Cu") (net 1) (tstamp 23d1c95a-bb87-4aa2-a6ce-913241321c14))
  (segment (start 86.9035 68.326) (end 85.09 68.326) (width 2) (layer "B.Cu") (net 1) (tstamp 2437d186-b670-47ce-9fa1-d84645e96796))
  (segment (start 27.305 95.377) (end 26.65 96.032) (width 0.5) (layer "B.Cu") (net 1) (tstamp 25fbc693-a31c-4f3d-b063-10121b3aa286))
  (segment (start 61.595 134.62) (end 61.595 126.111) (width 0.25) (layer "B.Cu") (net 1) (tstamp 26318c2d-1ec1-4bb7-a9c9-38bb7302dc02))
  (segment (start 84.201 127.508) (end 84.201 135.128) (width 3) (layer "B.Cu") (net 1) (tstamp 267ec6b7-1b50-42c3-872f-ea23bbb4df3f))
  (segment (start 143.002 105.283) (end 130.302 92.583) (width 3) (layer "B.Cu") (net 1) (tstamp 268b5245-f80b-480b-8194-ec8cd2e94d46))
  (segment (start 165.981 88.686) (end 161.711 88.686) (width 4) (layer "B.Cu") (net 1) (tstamp 26a71346-5132-4835-8677-729ad60d1992))
  (segment (start 81.4705 45.0215) (end 84.836 41.656) (width 0.5) (layer "B.Cu") (net 1) (tstamp 26f22748-6b88-4a00-a4a2-5b09812b24fa))
  (segment (start 84.201 142.24) (end 84.201 144.526) (width 3) (layer "B.Cu") (net 1) (tstamp 28b66292-35b2-44d6-a2f2-1b165eb4adf3))
  (segment (start 27.305 89.027) (end 27.305 91.567) (width 0.5) (layer "B.Cu") (net 1) (tstamp 28cd80c0-f649-4701-b170-d6ecc7ac1d25))
  (segment (start 22.531 151.674) (end 23.964 150.241) (width 0.25) (layer "B.Cu") (net 1) (tstamp 2c369b3e-e72f-4992-b32f-4193a5fc025b))
  (segment (start 84.639651 135.566651) (end 84.201 135.128) (width 1) (layer "B.Cu") (net 1) (tstamp 31bfd634-9ed7-4557-bcd2-ffc42489402b))
  (segment (start 77.09496 78.87296) (end 73.406 75.184) (width 2) (layer "B.Cu") (net 1) (tstamp 32898266-f4cd-4cdd-8515-0fcfe447120b))
  (segment (start 89.281 30.226) (end 88.031 30.226) (width 0.5) (layer "B.Cu") (net 1) (tstamp 3324e956-5003-4df4-85f9-86176ef54cf4))
  (segment (start 87.376 41.021) (end 88.011 41.656) (width 0.5) (layer "B.Cu") (net 1) (tstamp 3572c658-951d-42aa-9aab-e7cc940f3db5))
  (segment (start 61.6458 103.7082) (end 61.6712 103.7336) (width 0.5) (layer "B.Cu") (net 1) (tstamp 35cea228-1612-4ba8-bb75-62937d5e2428))
  (segment (start 26.65 99.441) (end 25.761 100.33) (width 0.5) (layer "B.Cu") (net 1) (tstamp 39f2f649-f00d-4df3-a361-dc5300f22b51))
  (segment (start 77.09496 100.95904) (end 77.09496 99.43504) (width 2) (layer "B.Cu") (net 1) (tstamp 3a9b0f8e-0a05-4f63-a5f6-39427d5f87a3))
  (segment (start 43.053 90.043) (end 43.688 90.043) (width 0.5) (layer "B.Cu") (net 1) (tstamp 3e35a673-8cb6-4573-905f-5cf3d217d9a7))
  (segment (start 61.595 126.111) (end 60.96 125.476) (width 0.25) (layer "B.Cu") (net 1) (tstamp 3f316da8-bc55-42b1-bc7b-2c2f1b2bd89b))
  (segment (start 76.581 113.284) (end 76.581 110.49) (width 3) (layer "B.Cu") (net 1) (tstamp 3f37ad6c-d011-4c6d-ad11-4b6691610960))
  (segment (start 152.146 24.638) (end 158.115 24.638) (width 1) (layer "B.Cu") (net 1) (tstamp 4253f26a-a1fa-40bb-9ba3-c43c172eec84))
  (segment (start 53.213 46.101) (end 54.61 47.498) (width 0.5) (layer "B.Cu") (net 1) (tstamp 43cadffd-c41a-4bb0-ade7-4b77aeafb3ed))
  (segment (start 79.121 67.691) (end 79.121 60.071) (width 0.5) (layer "B.Cu") (net 1) (tstamp 470f9a46-a902-4545-9257-96cb5411bbf5))
  (segment (start 60.96 125.476) (end 60.80148 125.31748) (width 0.2) (layer "B.Cu") (net 1) (tstamp 48b902eb-58ad-4c64-8677-af551b7b06b4))
  (segment (start 54.61 49.022) (end 54.864 49.276) (width 0.5) (layer "B.Cu") (net 1) (tstamp 4937c6eb-d962-4000-8665-62cf3f250148))
  (segment (start 26.035 100.056) (end 26.035 104.521) (width 0.25) (layer "B.Cu") (net 1) (tstamp 4aec61a2-80e4-45ce-9c49-3d86dea83d17))
  (segment (start 77.851 154.94) (end 84.201 148.59) (width 3) (layer "B.Cu") (net 1) (tstamp 4bbb1083-43e6-46fb-8239-d3e445465f46))
  (segment (start 39.116 86.487) (end 39.497 86.487) (width 0.25) (layer "B.Cu") (net 1) (tstamp 4ed2e6d7-7a76-4ff4-a3a6-1fa321f41e74))
  (segment (start 61.722 89.281) (end 60.96 88.519) (width 0.5) (layer "B.Cu") (net 1) (tstamp 4fd80ce9-b5fd-47aa-b60d-4f1d9b0b4229))
  (segment (start 31.369 45.974) (end 31.369 46.99) (width 0.25) (layer "B.Cu") (net 1) (tstamp 51c96986-6d26-44a2-9f99-01a912c89a68))
  (segment (start 25.2145 27.586) (end 25.2145 41.4705) (width 0.5) (layer "B.Cu") (net 1) (tstamp 533836d5-a4a4-408f-80eb-f148ced454be))
  (segment (start 74.549 154.94) (end 75.565 154.94) (width 3) (layer "B.Cu") (net 1) (tstamp 53f5de0a-2ebc-4993-b75c-006775a1ba2b))
  (segment (start 62.611 135.636) (end 61.595 134.62) (width 0.25) (layer "B.Cu") (net 1) (tstamp 5471efbe-2f2a-4a4a-bbd4-76f64b706ac8))
  (segment (start 35.941 90.17) (end 35.941 89.662) (width 0.25) (layer "B.Cu") (net 1) (tstamp 5579eace-1043-4961-869b-a14f9647416a))
  (segment (start 31.623 46.101) (end 41.656 46.101) (width 0.25) (layer "B.Cu") (net 1) (tstamp 5821711a-d4ff-424d-a047-ecf2367f4838))
  (segment (start 165.981 50.586) (end 161.584 50.586) (width 4) (layer "B.Cu") (net 1) (tstamp 5a393e1d-3dd9-4d12-aa41-dcd33d139d85))
  (segment (start 86.995 135.566651) (end 84.639651 135.566651) (width 1) (layer "B.Cu") (net 1) (tstamp 5b3bf19e-44a7-4d4d-81e6-401ab7c62c1a))
  (segment (start 41.656 42.926) (end 43.307 41.275) (width 0.5) (layer "B.Cu") (net 1) (tstamp 5e28e809-fe81-45a1-a5cc-55a547b7f72d))
  (segment (start 84.836 41.656) (end 89.281 41.656) (width 0.5) (layer "B.Cu") (net 1) (tstamp 5e91013a-0821-4040-93ff-75dcd22ff3d9))
  (segment (start 79.756 68.326) (end 80.645 69.215) (width 0.5) (layer "B.Cu") (net 1) (tstamp 5eccfb32-90de-429b-9284-cb0823e242ee))
  (segment (start 26.65 96.032) (end 26.65 99.441) (width 0.5) (layer "B.Cu") (net 1) (tstamp 5f5a165d-7047-4e18-a51d-cc406dbd6941))
  (segment (start 26.035 61.976) (end 28.194 64.135) (width 0.25) (layer "B.Cu") (net 1) (tstamp 61c205c0-dc49-457a-b8bc-86c5c5577c63))
  (segment (start 74.549 154.94) (end 76.327 154.94) (width 1) (layer "B.Cu") (net 1) (tstamp 63bde6ee-8736-4941-bfee-be7762d3e3f7))
  (segment (start 25.908 104.648) (end 25.908 150.241) (width 0.25) (layer "B.Cu") (net 1) (tstamp 6406ffc4-c445-4256-b231-6177f364fb91))
  (segment (start 58.116 106.222) (end 59.309 106.222) (width 0.25) (layer "B.Cu") (net 1) (tstamp 6430bb29-9790-46a9-92c8-22998f0953c2))
  (segment (start 158.496 48.895) (end 158.496 103.759) (width 9) (layer "B.Cu") (net 1) (tstamp 64875f14-7d77-4da7-8071-63aa20b2c7e7))
  (segment (start 165.981 75.986) (end 160.441 75.986) (width 4) (layer "B.Cu") (net 1) (tstamp 648a4a71-c2c3-4df3-a22e-b12cadf4c105))
  (segment (start 57.49948 125.31748) (end 56.896 124.714) (width 0.25) (layer "B.Cu") (net 1) (tstamp 64ba6965-39d3-4820-9cfe-4ec9b2031423))
  (segment (start 158.115 24.638) (end 160.401 26.924) (width 1) (layer "B.Cu") (net 1) (tstamp 6882cf3d-f05e-4bcb-ad82-ff5d85f93a0b))
  (segment (start 160.401 44.831) (end 160.401 36.576) (width 6) (layer "B.Cu") (net 1) (tstamp 6990e34c-3dfc-442a-b815-49b247cb0162))
  (segment (start 31.369 53.721) (end 31.369 56.642) (width 0.3) (layer "B.Cu") (net 1) (tstamp 6df50022-5f5e-4200-9eb0-afb56c4d78fe))
  (segment (start 147.32 19.812) (end 152.146 24.638) (width 1) (layer "B.Cu") (net 1) (tstamp 6fd36f3d-8e8d-44dd-99e8-3b34c3e783ab))
  (segment (start 25.761 84.328) (end 25.761 87.483) (width 0.5) (layer "B.Cu") (net 1) (tstamp 70327e0f-dfb7-4404-9a97-8472adb9a098))
  (segment (start 28.956 92.48994) (end 28.956 92.202) (width 0.25) (layer "B.Cu") (net 1) (tstamp 709c0f3a-1fcf-4812-9731-a794dd84c89b))
  (segment (start 35.941 90.767) (end 35.941 90.17) (width 0.25) (layer "B.Cu") (net 1) (tstamp 70be6f0a-2b25-4264-ad3f-d7efe8abb9c4))
  (segment (start 146.05 107.061) (end 144.78 107.061) (width 3) (layer "B.Cu") (net 1) (tstamp 70bff6e1-f951-4ebd-ad90-de70a142669a))
  (segment (start 40.386 93.98) (end 39.154 93.98) (width 0.25) (layer "B.Cu") (net 1) (tstamp 7126ec19-99de-46f5-8005-505451a1950b))
  (segment (start 122.301 69.088) (end 121.539 68.326) (width 2) (layer "B.Cu") (net 1) (tstamp 76abe618-57dc-470c-ad27-79a1a7173163))
  (segment (start 150.241 54.219959) (end 153.660959 54.219959) (width 4) (layer "B.Cu") (net 1) (tstamp 7d379ba7-ade9-4d1b-bd31-292a72ca88c0))
  (segment (start 119.2885 68.326) (end 103.576 68.326) (width 2) (layer "B.Cu") (net 1) (tstamp 7fcd35c2-929f-4658-8f5a-a6dee75f2cf6))
  (segment (start 80.645 69.215) (end 80.645 80.772) (width 0.5) (layer "B.Cu") (net 1) (tstamp 801b8372-2583-4f27-908b-5b788dafa7c8))
  (segment (start 52.832 51.308) (end 48.895 51.308) (width 0.25) (layer "B.Cu") (net 1) (tstamp 804ff4a3-8d1a-49ef-b592-2fa9c86d3621))
  (segment (start 84.201 135.128) (end 84.201 142.24) (width 3) (layer "B.Cu") (net 1) (tstamp 8103ebe6-7027-4e25-a071-a8ff510cea89))
  (segment (start 81.407 116.332) (end 84.201 119.126) (width 3) (layer "B.Cu") (net 1) (tstamp 81e7b74a-fb70-4c8b-a9b3-e7756e760431))
  (segment (start 35.941 89.662) (end 39.116 86.487) (width 0.25) (layer "B.Cu") (net 1) (tstamp 82216c19-5e6f-4d15-b294-0d5eb495ff7d))
  (segment (start 88.031 30.226) (end 87.376 30.881) (width 0.5) (layer "B.Cu") (net 1) (tstamp 82bfc14b-aaf0-4d1e-9c98-131119ab5c7c))
  (segment (start 85.147651 145.472651) (end 84.201 144.526) (width 1) (layer "B.Cu") (net 1) (tstamp 83394afc-4a97-46f3-b88f-6d1f22b95931))
  (segment (start 158.496 103.759) (end 158.496 104.648) (width 5) (layer "B.Cu") (net 1) (tstamp 846dc473-da83-40fa-bcc9-7e0f55891e0c))
  (segment (start 29.031 151.674) (end 27.598 150.241) (width 0.25) (layer "B.Cu") (net 1) (tstamp 85d5ae50-9ab6-4d56-ad2c-533bc3e5c96b))
  (segment (start 31.369 53.721) (end 31.369 46.99) (width 0.25) (layer "B.Cu") (net 1) (tstamp 892178a9-7102-4192-8318-2fab952e45c8))
  (segment (start 31.369 56.642) (end 26.035 61.976) (width 0.3) (layer "B.Cu") (net 1) (tstamp 8a01f44a-1ac6-4dcc-9532-7c065e85a3e9))
  (segment (start 79.4512 47.0408) (end 81.4705 45.0215) (width 0.5) (layer "B.Cu") (net 1) (tstamp 8b2137e7-6360-422d-8281-b6f23ff9bcb5))
  (segment (start 26.035 104.521) (end 25.908 104.648) (width 0.25) (layer "B.Cu") (net 1) (tstamp 910f1b08-fac7-4b14-be76-c01928d44dc5))
  (segment (start 43.053 91.313) (end 40.386 93.98) (width 0.25) (layer "B.Cu") (net 1) (tstamp 919f25ee-8f8c-4bd5-a885-25b504ed287d))
  (segment (start 74.676 49.685888) (end 76.171112 49.685888) (width 0.5) (layer "B.Cu") (net 1) (tstamp 92383800-4754-4187-bd71-062665e975a0))
  (segment (start 28.956 92.48994) (end 28.956 74.168) (width 0.25) (layer "B.Cu") (net 1) (tstamp 93f745ab-5d3a-4c63-8cb4-a35cf7f1fe1e))
  (segment (start 56.896 107.442) (end 58.116 106.222) (width 0.25) (layer "B.Cu") (net 1) (tstamp 9678f3f5-234b-4e2d-b6c8-aa4c8224c680))
  (segment (start 25.2145 41.4705) (end 29.845 46.101) (width 0.5) (layer "B.Cu") (net 1) (tstamp 96816ecf-ce97-4aa7-9360-3cb7b75875cc))
  (segment (start 81.026 97.25527) (end 81.915 98.14427) (width 0.5) (layer "B.Cu") (net 1) (tstamp 97f5552b-7e93-4f32-807c-5fd6e77a70a2))
  (segment (start 39.154 93.98) (end 35.941 90.767) (width 0.25) (layer "B.Cu") (net 1) (tstamp 9914f18e-9af0-40cb-853a-e7a0ddf9bc3b))
  (segment (start 39.916 86.487) (end 39.497 86.487) (width 0.25) (layer "B.Cu") (net 1) (tstamp 99adc786-e830-4424-a8aa-fa7b73c63b6b))
  (segment (start 76.581 108.966) (end 76.581 108.204) (width 3) (layer "B.Cu") (net 1) (tstamp 9a7277db-3f52-4f9f-a435-7e3877eee4ea))
  (segment (start 163.369 23.956) (end 160.401 26.924) (width 5) (layer "B.Cu") (net 1) (tstamp 9cbbd8bb-514a-4333-835a-80ac9e4c1030))
  (segment (start 43.053 90.043) (end 43.053 91.313) (width 0.25) (layer "B.Cu") (net 1) (tstamp 9ce5f3f8-82b8-49e3-8ca6-ef5d6b9b4539))
  (segment (start 153.660959 54.219959) (end 155.584041 54.219959) (width 4) (layer "B.Cu") (net 1) (tstamp 9de42b0b-6134-4f13-a161-938887f414d6))
  (segment (start 29.718 45.974) (end 31.369 45.974) (width 0.25) (layer "B.Cu") (net 1) (tstamp 9e2d3807-945f-47e8-8a22-1ae35f79f9cb))
  (segment (start 28.194 73.406) (end 28.956 74.168) (width 0.25) (layer "B.Cu") (net 1) (tstamp a00184b5-f85c-4099-84dc-db7c8abf840f))
  (segment (start 28.194 64.135) (end 28.194 73.406) (width 0.25) (layer "B.Cu") (net 1) (tstamp a2e4c4bd-2652-4fff-8be4-8391b3310a2e))
  (segment (start 62.103 99.822) (end 61.722 99.441) (width 0.5) (layer "B.Cu") (net 1) (tstamp a5d7e40d-3854-48d5-b8ec-0d92ad3734ab))
  (segment (start 76.327 154.94) (end 76.835 155.448) (width 1) (layer "B.Cu") (net 1) (tstamp a7aba36e-35a8-4b8c-9471-ba167e411204))
  (segment (start 79.629 116.332) (end 76.581 113.284) (width 3) (layer "B.Cu") (net 1) (tstamp a80a7c74-7ab0-4b85-b78d-0b2f7f41ea3a))
  (segment (start 80.645 80.772) (end 81.026 81.153) (width 0.5) (layer "B.Cu") (net 1) (tstamp a8c5a9ac-5290-40cb-a6bf-0845eb71ef45))
  (segment (start 43.053 90.043) (end 43.053 89.624) (width 0.25) (layer "B.Cu") (net 1) (tstamp a9466007-0620-44b4-949c-abe5b6acdd4e))
  (segment (start 77.089 100.965) (end 77.09496 100.95904) (width 2) (layer "B.Cu") (net 1) (tstamp aad1ba74-5d66-463b-8340-b42055012b5a))
  (segment (start 76.454 99.822) (end 76.581 99.949) (width 2) (layer "B.Cu") (net 1) (tstamp aef509da-89ca-4d3f-92e3-5b874fa5268d))
  (segment (start 47.371 86.36) (end 58.801 86.36) (width 0.5) (layer "B.Cu") (net 1) (tstamp af679abd-b953-4a9f-8f4f-21943d7f9061))
  (segment (start 77.09496 99.43504) (end 77.09496 78.87296) (width 2) (layer "B.Cu") (net 1) (tstamp af89b8c2-db7e-4266-b6b9-3ee2534a425b))
  (segment (start 83.947 127.762) (end 84.201 127.508) (width 1) (layer "B.Cu") (net 1) (tstamp afd09ea9-89d2-4455-bbae-9ebbe8677e6b))
  (segment (start 60.96 88.519) (end 60.96 86.614) (width 0.5) (layer "B.Cu") (net 1) (tstamp b04be458-5dff-4473-b767-951a9d34cf0e))
  (segment (start 76.171112 49.685888) (end 77.851 48.006) (width 0.5) (layer "B.Cu") (net 1) (tstamp b267b59b-a22f-4d34-8e65-45528b377857))
  (segment (start 80.391 43.942) (end 81.4705 45.0215) (width 0.3) (layer "B.Cu") (net 1) (tstamp b4079e39-6806-49d1-b5b8-b9852193da74))
  (segment (start 23.003 151.241) (end 23.003 151.638) (width 0.25) (layer "B.Cu") (net 1) (tstamp b6fca9d0-c277-4c5d-b66d-6d7ea760a35d))
  (segment (start 162.981 101.386) (end 165.981 101.386) (width 4) (layer "B.Cu") (net 1) (tstamp b7456921-e230-49cb-935b-434943aeb852))
  (segment (start 25.761 87.483) (end 27.305 89.027) (width 0.5) (layer "B.Cu") (net 1) (tstamp b965dd43-b202-48ca-90f4-611502dbcb66))
  (segment (start 80.899 68.326) (end 79.883 68.326) (width 2) (layer "B.Cu") (net 1) (tstamp b9a95204-6206-4f3b-8190-e921d12b0b4e))
  (segment (start 62.103 99.822) (end 61.722 100.203) (width 0.5) (layer "B.Cu") (net 1) (tstamp b9bcba74-0531-49eb-bbde-4c6003121ccb))
  (segment (start 84.201 119.126) (end 84.201 127.508) (width 3) (layer "B.Cu") (net 1) (tstamp bb9e8ef6-781d-477b-ac5f-94c457431023))
  (segment (start 31.369 46.99) (end 31.369 46.355) (width 0.25) (layer "B.Cu") (net 1) (tstamp bc9f0671-85e2-4426-b34b-aa4b930989e8))
  (segment (start 85.09 68.326) (end 80.899 68.326) (width 2) (layer "B.Cu") (net 1) (tstamp c24cc0d4-c2b7-4a4e-a9c8-bdf745b637e5))
  (segment (start 84.201 54.991) (end 84.201 52.451) (width 0.5) (layer "B.Cu") (net 1) (tstamp c26fe7ba-c74c-4954-a493-267fe5e17989))
  (segment (start 88.011 41.656) (end 89.281 41.656) (width 0.5) (layer "B.Cu") (net 1) (tstamp c2f52891-2249-469a-915a-9a8f23f88082))
  (segment (start 160.401 26.924) (end 160.401 34.036) (width 6) (layer "B.Cu") (net 1) (tstamp c4642357-5c56-4422-93d5-6eff4854aa12))
  (segment (start 28.03306 91.567) (end 27.305 91.567) (width 0.5) (layer "B.Cu") (net 1) (tstamp c47aa638-c5a8-44d4-8da7-fdc0a5a729f6))
  (segment (start 81.026 81.153) (end 81.026 97.25527) (width 0.5) (layer "B.Cu") (net 1) (tstamp c4d625ff-4b1a-4640-bece-77cc4b902188))
  (segment (start 150.241 68.189959) (end 160.264959 68.189959) (width 4) (layer "B.Cu") (net 1) (tstamp c7919610-3bc7-4c28-95f8-a83617f8f290))
  (segment (start 157.226 48.006) (end 160.401 44.831) (width 6) (layer "B.Cu") (net 1) (tstamp c7e5c101-0cd1-41c4-8574-cf989c32c132))
  (segment (start 128.397 88.011) (end 128.397 75.184) (width 3) (layer "B.Cu") (net 1) (tstamp c8c6170c-f617-4c75-a912-ae7b0ec33991))
  (segment (start 74.549 154.94) (end 77.851 154.94) (width 3) (layer "B.Cu") (net 1) (tstamp c916e113-d39d-4f75-bffb-271c49393cef))
  (segment (start 130.302 92.583) (end 128.397 90.678) (width 3) (layer "B.Cu") (net 1) (tstamp c9e952cf-5224-49e8-8caf-cd1a2e8cd777))
  (segment (start 28.956 92.48994) (end 27.432 94.01394) (width 0.25) (layer "B.Cu") (net 1) (tstamp cdea5ed2-7007-418d-95da-889cf6f0fe9a))
  (segment (start 61.6712 103.7336) (end 61.6712 106.1466) (width 0.5) (layer "B.Cu") (net 1) (tstamp ce3582ca-a081-46f2-ac7f-b61c5b553d45))
  (segment (start 81.915 98.14427) (end 81.915 102.722) (width 0.5) (layer "B.Cu") (net 1) (tstamp ceb33c00-4d03-4d55-9214-25741b03a41b))
  (segment (start 144.78 107.061) (end 143.002 105.283) (width 3) (layer "B.Cu") (net 1) (tstamp cfa8f5b9-c994-47a9-aefa-2c16f2f21c4a))
  (segment (start 79.883 68.326) (end 79.756 68.326) (width 2) (layer "B.Cu") (net 1) (tstamp cffe18b2-7df2-4cdb-926d-7a89b091157e))
  (segment (start 54.991 49.403) (end 56.134 49.403) (width 0.5) (layer "B.Cu") (net 1) (tstamp d12fa9d9-00dd-49e0-8ef9-61c00116a29d))
  (segment (start 127.127 73.914) (end 122.301 69.088) (width 3) (layer "B.Cu") (net 1) (tstamp d372f8fa-9f0a-4cca-b81f-d9f03f4a1e7c))
  (segment (start 79.121 60.071) (end 84.201 54.991) (width 0.5) (layer "B.Cu") (net 1) (tstamp d3851638-8292-4fec-96e5-cc74e76b6478))
  (segment (start 160.401 34.036) (end 160.401 36.576) (width 6) (layer "B.Cu") (net 1) (tstamp d42d9444-7c2d-4ffb-b218-b7f95de96262))
  (segment (start 28.956 92.48994) (end 28.03306 91.567) (width 0.5) (layer "B.Cu") (net 1) (tstamp d61e60c2-6c84-466d-88df-c383b8feece1))
  (segment (start 43.053 89.624) (end 39.916 86.487) (width 0.25) (layer "B.Cu") (net 1) (tstamp d77c3cc5-6997-4db9-9c1c-fe62cb1a97d6))
  (segment (start 60.80148 125.31748) (end 57.49948 125.31748) (width 0.2) (layer "B.Cu") (net 1) (tstamp d975be2f-ed51-4ed4-be2d-dc23180fccf3))
  (segment (start 30.988 90.17) (end 35.941 90.17) (width 0.25) (layer "B.Cu") (net 1) (tstamp d9b84fe9-fa95-4bbb-8758-5fcf69986f55))
  (segment (start 84.201 148.59) (end 84.201 144.526) (width 3) (layer "B.Cu") (net 1) (tstamp daf9e2df-8b14-4d86-b67e-35c8d4818df6))
  (segment (start 29.845 46.101) (end 41.656 46.101) (width 0.5) (layer "B.Cu") (net 1) (tstamp dc7cd8e2-9f6b-40f5-8f33-548164cb01de))
  (segment (start 60.91602 24.765) (end 60.66202 24.511) (width 0.2) (layer "B.Cu") (net 1) (tstamp dd909a71-3938-48c4-b967-30f1e37ee658))
  (segment (start 74.041 154.94) (end 73.787 154.94) (width 1) (layer "B.Cu") (net 1) (tstamp de33ab8c-f2ca-4b04-98e9-e5bf1d7dac12))
  (segment (start 76.581 99.949) (end 77.09496 99.43504) (width 2) (layer "B.Cu") (net 1) (tstamp df3df41d-c039-43e6-834c-f1bd5d407010))
  (segment (start 54.864 49.276) (end 54.991 49.403) (width 0.5) (layer "B.Cu") (net 1) (tstamp e0be6daf-6772-440a-8543-6583b7edd1a6))
  (segment (start 58.801 86.36) (end 60.96 88.519) (width 0.5) (layer "B.Cu") (net 1) (tstamp e290c22a-1d9e-48b0-9620-6e2195cec047))
  (segment (start 27.432 95.25) (end 26.67 96.012) (width 0.25) (layer "B.Cu") (net 1) (tstamp e3bdef0c-f316-4534-a113-468f14b022de))
  (segment (start 121.539 68.326) (end 119.2885 68.326) (width 2) (layer "B.Cu") (net 1) (tstamp e3cfcedc-7c9e-4132-8236-1b8bd62cbe02))
  (segment (start 26.67 96.012) (end 26.67 99.421) (width 0.25) (layer "B.Cu") (net 1) (tstamp e4134238-9200-4714-afe0-a6bb4227d91e))
  (segment (start 41.656 46.101) (end 53.213 46.101) (width 0.5) (layer "B.Cu") (net 1) (tstamp e4e29525-0f12-4aa9-b9cc-10a1d5616c88))
  (segment (start 27.305 91.567) (end 27.305 95.377) (width 0.5) (layer "B.Cu") (net 1) (tstamp e57e5a26-48a0-490a-9b1f-c6cbcb012127))
  (segment (start 31.369 46.355) (end 31.623 46.101) (width 0.25) (layer "B.Cu") (net 1) (tstamp e63bafe7-a804-40db-85f5-6fceba11a52e))
  (segment (start 56.896 124.714) (end 56.896 124.206) (width 0.25) (layer "B.Cu") (net 1) (tstamp e87aa98f-8b99-4c08-9247-8c6dd09b6127))
  (segment (start 23.964 150.241) (end 25.908 150.241) (width 0.25) (layer "B.Cu") (net 1) (tstamp eaaf7aee-e8ed-4da2-a7f8-324d8e02ca67))
  (segment (start 61.722 100.203) (end 61.722 103.632) (width 0.5) (layer "B.Cu") (net 1) (tstamp ecd30a00-dfba-434f-94ba-6ccf0ace6b85))
  (segment (start 160.881 37.056) (end 160.401 36.576) (width 5) (layer "B.Cu") (net 1) (tstamp ece19121-1edd-40f1-80c0-5fb817d8fec7))
  (segment (start 77.851 48.006) (end 77.851 47.371) (width 0.5) (layer "B.Cu") (net 1) (tstamp ee8d97e1-8681-4f21-b748-3f06b18cf056))
  (segment (start 158.496 104.648) (end 156.083 107.061) (width 3) (layer "B.Cu") (net 1) (tstamp ef168a28-a3b9-4c50-85aa-a160a2089aab))
  (segment (start 43.307 41.275) (end 45.191 41.275) (width 0.5) (layer "B.Cu") (net 1) (tstamp f1bc6f73-9b9e-4cd1-ad01-f875fad2c809))
  (segment (start 150.241 82.159959) (end 160.264959 82.159959) (width 4) (layer "B.Cu") (net 1) (tstamp f1da00c3-f67e-4247-bbd5-5b836b2ed981))
  (segment (start 150.241 96.129959) (end 160.264959 96.129959) (width 4) (layer "B.Cu") (net 1) (tstamp f23ccf36-b3d5-4a06-a0f6-08e3f6bcdca5))
  (segment (start 76.581 108.204) (end 76.581 107.442) (width 3) (layer "B.Cu") (net 1) (tstamp f7232cb0-730f-42f4-a84c-c7175dca7b09))
  (segment (start 79.883 68.326) (end 79.17552 68.326) (width 2) (layer "B.Cu") (net 1) (tstamp f7828975-9f3f-43ea-9d0e-fb0b073bc6a1))
  (segment (start 26.67 99.421) (end 26.035 100.056) (width 0.25) (layer "B.Cu") (net 1) (tstamp f7d09ac5-54b5-46a9-bf4e-7e2a38b1361a))
  (segment (start 86.741 145.472651) (end 85.147651 145.472651) (width 1) (layer "B.Cu") (net 1) (tstamp f8eb1daa-9c5f-4768-9614-374e245ffc94))
  (segment (start 61.722 103.632) (end 61.6458 103.7082) (width 0.5) (layer "B.Cu") (net 1) (tstamp f95e5359-18f5-4691-a460-bb3d6920cfa8))
  (segment (start 54.864 49.276) (end 52.832 51.308) (width 0.25) (layer "B.Cu") (net 1) (tstamp f995d380-4f28-4db5-a467-eede711dcfff))
  (segment (start 43.688 90.043) (end 47.371 86.36) (width 0.5) (layer "B.Cu") (net 1) (tstamp facbfd7a-0f7c-4fb1-b1bb-b9cba4848b49))
  (segment (start 76.581 109.728) (end 76.581 108.966) (width 3) (layer "B.Cu") (net 1) (tstamp fdcb061a-d235-460c-8e87-414fdf023a4e))
  (segment (start 27.432 94.01394) (end 27.432 95.25) (width 0.25) (layer "B.Cu") (net 1) (tstamp ffac2835-7668-4005-9a9c-252a9797d1a8))
  (segment (start 61.6335 34.671) (end 61.6335 34.20725) (width 0.25) (layer "F.Cu") (net 2) (tstamp 4604f60a-f017-4eae-bb0d-82804b6e8d89))
  (segment (start 62.357 34.671) (end 63.881 33.147) (width 0.2) (layer "F.Cu") (net 2) (tstamp 80925c2d-4c67-4052-983c-39299f98b5cd))
  (segment (start 61.6335 34.20725) (end 62.09725 34.671) (width 0.2) (layer "F.Cu") (net 2) (tstamp b7e71edf-27b3-4932-88f2-8f8a9ecff84a))
  (segment (start 65.532 33.147) (end 66.167 33.782) (width 0.2) (layer "F.Cu") (net 2) (tstamp b8f94fae-ba58-4a0e-8591-247e358c38fe))
  (segment (start 66.167 36.195) (end 67.056 37.084) (width 0.2) (layer "F.Cu") (net 2) (tstamp b9f1ed71-5235-49a5-b5f0-6f9ebf689da2))
  (segment (start 62.09725 34.671) (end 62.357 34.671) (width 0.2) (layer "F.Cu") (net 2) (tstamp c422f951-40fb-4e67-b1a8-916caf1582e1))
  (segment (start 67.056 37.084) (end 67.056 38.546) (width 0.2) (layer "F.Cu") (net 2) (tstamp e5c66c9d-ee30-4e3c-9931-309518b22949))
  (segment (start 66.167 33.782) (end 66.167 36.195) (width 0.2) (layer "F.Cu") (net 2) (tstamp e646a7bb-9702-40c1-9eeb-b27d2d7b775c))
  (segment (start 63.881 33.147) (end 65.532 33.147) (width 0.2) (layer "F.Cu") (net 2) (tstamp ecc2fd72-f801-43a2-8c41-31ea6936ebd3))
  (segment (start 65.786 43.496) (end 65.786 44.577) (width 0.25) (layer "F.Cu") (net 3) (tstamp 0102d7b2-6697-4e9e-945b-928c8779c613))
  (segment (start 58.293 22.651) (end 58.293 25.273) (width 0.2) (layer "F.Cu") (net 3) (tstamp 0697861c-13a7-463e-b4ff-73c396e415ac))
  (segment (start 52.959 36.83) (end 50.546 34.417) (width 0.2) (layer "F.Cu") (net 3) (tstamp 08dd961b-b03d-464c-99cf-d1ceabdf6233))
  (segment (start 72.188274 47.685888) (end 74.676 47.685888) (width 0.25) (layer "F.Cu") (net 3) (tstamp 0995f833-ff1a-4527-ae3a-ffb760edfffc))
  (segment (start 53.721 40.64) (end 53.721 38.227) (width 0.2) (layer "F.Cu") (net 3) (tstamp 0a35c0d1-766d-4076-b872-1506ec30b702))
  (segment (start 54.356 43.942) (end 57.277 43.942) (width 0.2) (layer "F.Cu") (net 3) (tstamp 1435be52-99b6-4829-8ee9-6ce261bf45a7))
  (segment (start 78.171112 51.181) (end 74.676 47.685888) (width 0.25) (layer "F.Cu") (net 3) (tstamp 1e444136-616a-4945-ba36-b1a910bc3a17))
  (segment (start 50.673 25.273) (end 55.753 25.273) (width 0.2) (layer "F.Cu") (net 3) (tstamp 2330e706-06fe-4aa1-b18e-374e0e46b345))
  (segment (start 80.666 51.181) (end 78.171112 51.181) (width 0.25) (layer "F.Cu") (net 3) (tstamp 300f48d0-6624-47aa-a785-5e8039e53f3f))
  (segment (start 70.739 44.958) (end 71.284489 45.503489) (width 0.25) (layer "F.Cu") (net 3) (tstamp 325bffed-2529-4379-ae51-a15261d34af1))
  (segment (start 60.071 42.5835) (end 60.071 43.561) (width 0.25) (layer "F.Cu") (net 3) (tstamp 44356f50-1c35-4fd4-b0aa-3316a2920aed))
  (segment (start 71.284489 46.782103) (end 72.188274 47.685888) (width 0.25) (layer "F.Cu") (net 3) (tstamp 48253b35-4db3-4611-80a5-0cf474dd6fc0))
  (segment (start 53.721 36.83) (end 52.959 36.83) (width 0.2) (layer "F.Cu") (net 3) (tstamp 4f18122a-7726-4884-bcfb-5992096b6472))
  (segment (start 53.721 43.307) (end 54.356 43.942) (width 0.2) (layer "F.Cu") (net 3) (tstamp 61d4c669-5534-4c5f-a9af-b2fac7d0ef71))
  (segment (start 57.277 43.942) (end 56.642 43.942) (width 0.2) (layer "F.Cu") (net 3) (tstamp 7703e2e0-a517-479e-b734-0e852cb87662))
  (segment (start 53.721 40.64) (end 53.721 43.307) (width 0.2) (layer "F.Cu") (net 3) (tstamp 81973e79-6baf-4211-a1d6-aeb91c8b80b8))
  (segment (start 82.6385 51.181) (end 80.666 51.181) (width 0.25) (layer "F.Cu") (net 3) (tstamp 81db3d45-3d9a-47a4-b43f-f92f19178a94))
  (segment (start 60.452 43.942) (end 65.786 43.942) (width 0.25) (layer "F.Cu") (net 3) (tstamp 834bac47-0436-4cf8-8bd2-5dc3a2746db0))
  (segment (start 50.546 25.4) (end 50.673 25.273) (width 0.2) (layer "F.Cu") (net 3) (tstamp 8d4c766a-7066-4677-9aea-00e368600e1b))
  (segment (start 86.741 47.0785) (end 82.6385 51.181) (width 0.25) (layer "F.Cu") (net 3) (tstamp 9325d298-e7fd-4012-bf46-84f167f01d40))
  (segment (start 66.167 44.958) (end 70.739 44.958) (width 0.25) (layer "F.Cu") (net 3) (tstamp b06f2945-7f9d-49b6-9b47-4b0bbc197ff2))
  (segment (start 56.642 43.942) (end 56.261 43.561) (width 0.2) (layer "F.Cu") (net 3) (tstamp b1036f8b-d930-4f7b-b5be-6e2cfc135f54))
  (segment (start 71.284489 45.503489) (end 71.284489 46.782103) (width 0.25) (layer "F.Cu") (net 3) (tstamp b4a129b8-470b-41e7-aeeb-1c479c4142ea))
  (segment (start 60.452 43.942) (end 57.277 43.942) (width 0.2) (layer "F.Cu") (net 3) (tstamp b78368d5-0bc9-4f42-9858-098e5e9f33d8))
  (segment (start 65.786 43.942) (end 65.786 43.496) (width 0.25) (layer "F.Cu") (net 3) (tstamp bd89fa6b-7f24-4029-be00-b57041c099b4))
  (segment (start 60.071 43.561) (end 60.452 43.942) (width 0.25) (layer "F.Cu") (net 3) (tstamp c3260209-ef5a-4424-8898-596f76a13925))
  (segment (start 56.261 43.561) (end 56.261 42.571) (width 0.2) (layer "F.Cu") (net 3) (tstamp cb751e71-0ff2-4ff2-9079-6f08f3292d9a))
  (segment (start 65.786 44.577) (end 66.167 44.958) (width 0.25) (layer "F.Cu") (net 3) (tstamp fb908ecc-09a3-4939-b4a2-e9350e2016e7))
  (segment (start 50.546 34.417) (end 50.546 25.4) (width 0.2) (layer "F.Cu") (net 3) (tstamp fef98ee9-d735-4e2c-9900-371273afd4fb))
  (via (at 55.753 25.273) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 3) (tstamp 82152e88-9cf7-47aa-8335-d25a865bb52c))
  (via (at 53.721 38.227) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 3) (tstamp 84233b2e-fe96-4ddc-a19d-d770bc819842))
  (via (at 58.293 25.273) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 3) (tstamp bcd5dd45-36e8-43e6-8f93-c3b4b0845dc1))
  (via (at 53.721 36.83) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 3) (tstamp e9eee3f9-78d6-4d75-9d77-236f0be40370))
  (segment (start 53.721 38.227) (end 53.721 36.83) (width 0.25) (layer "B.Cu") (net 3) (tstamp 507f14d2-36e6-4cb1-8f59-142710e6f5c8))
  (segment (start 58.293 25.273) (end 55.753 25.273) (width 0.2) (layer "B.Cu") (net 3) (tstamp 7cd0e6ad-bd8e-4b66-b232-acd6bcc07114))
  (segment (start 116.131 73.6985) (end 113.8835 73.6985) (width 1) (layer "F.Cu") (net 4) (tstamp 02bc6786-6220-4687-b1c6-2a2690f3b911))
  (segment (start 118.9635 70.866) (end 116.131 73.6985) (width 1) (layer "F.Cu") (net 4) (tstamp 09832d54-dd84-4bb8-9559-4d709315a565))
  (segment (start 119.2885 70.866) (end 118.9635 70.866) (width 1) (layer "F.Cu") (net 4) (tstamp 34682606-634e-477b-90b1-ca282e4d6f1f))
  (segment (start 113.8835 73.6985) (end 113.8835 76.656) (width 1) (layer "F.Cu") (net 4) (tstamp cb329af2-cbce-4535-8f34-95d9f14f2663))
  (segment (start 98.171 73.6985) (end 98.171 76.656) (width 1) (layer "F.Cu") (net 5) (tstamp 8ca19c30-1180-4d74-b340-53ce294f229a))
  (segment (start 103.576 70.866) (end 103.251 70.866) (width 1) (layer "F.Cu") (net 5) (tstamp 8e9807b2-9b0a-4170-9e35-f2e1588dba4d))
  (segment (start 103.251 70.866) (end 100.4185 73.6985) (width 1) (layer "F.Cu") (net 5) (tstamp e6071b9d-5187-4caf-81df-0c23878ecb1c))
  (segment (start 100.4185 73.6985) (end 98.171 73.6985) (width 1) (layer "F.Cu") (net 5) (tstamp f885cee1-6349-43d5-a1ef-62e937c14d73))
  (segment (start 86.5785 70.866) (end 83.746 73.6985) (width 1) (layer "F.Cu") (net 6) (tstamp 1398341a-03f5-49ef-8447-800590e127c6))
  (segment (start 86.9035 70.866) (end 86.5785 70.866) (width 1) (layer "F.Cu") (net 6) (tstamp a86b65e4-86eb-4b73-a21d-a050d4a8020e))
  (segment (start 83.746 73.6985) (end 81.4985 73.6985) (width 1) (layer "F.Cu") (net 6) (tstamp b211d1e3-a2ef-4793-8270-07880e065482))
  (segment (start 81.4985 73.6985) (end 81.4985 76.656) (width 1) (layer "F.Cu") (net 6) (tstamp f5420d0a-0367-4041-ae2a-bb91403e0b93))
  (segment (start 63.246 41.021) (end 62.865 41.021) (width 0.25) (layer "F.Cu") (net 7) (tstamp 08ac0d44-cd68-4d09-ba04-ba883adac2d9))
  (segment (start 62.865 41.021) (end 58.674 41.021) (width 0.25) (layer "F.Cu") (net 7) (tstamp 0d1dc3fa-e360-459c-ba23-b34619391bf1))
  (segment (start 50.09648 34.652962) (end 52.908518 37.465) (width 0.2) (layer "F.Cu") (net 7) (tstamp 17aa59cd-d62a-438a-b396-fb3bfe3941f9))
  (segment (start 55.753 18.751) (end 55.753 20.32) (width 0.2) (layer "F.Cu") (net 7) (tstamp 25aaa593-733c-45a4-bc77-590518aa7d87))
  (segment (start 50.09648 25.249159) (end 50.09648 34.652962) (width 0.2) (layer "F.Cu") (net 7) (tstamp 3135cf2a-0a56-4087-91c2-5f771040f31f))
  (segment (start 69.596 41.783) (end 69.596 42.291) (width 0.25) (layer "F.Cu") (net 7) (tstamp 354cb680-b382-47df-bea7-33ee49eab98f))
  (segment (start 50.497159 24.84848) (end 50.09648 25.249159) (width 0.2) (layer "F.Cu") (net 7) (tstamp 4221fc26-8e7c-4d45-9773-3c01f092e470))
  (segment (start 54.65352 21.41948) (end 54.65352 23.70548) (width 0.2) (layer "F.Cu") (net 7) (tstamp 4783bfb9-33e3-4bcc-a244-1bddd8f16a0d))
  (segment (start 62.865 41.021) (end 68.834 41.021) (width 0.25) (layer "F.Cu") (net 7) (tstamp 4cc50548-d119-47c3-87be-87f3b70288ec))
  (segment (start 54.65352 23.70548) (end 53.51052 24.84848) (width 0.2) (layer "F.Cu") (net 7) (tstamp 5fa80373-6301-4f90-980a-419cd88bcae0))
  (segment (start 55.499 37.465) (end 56.261 37.465) (width 0.2) (layer "F.Cu") (net 7) (tstamp 622ae846-c9f9-4c5a-891a-fa005b92b274))
  (segment (start 58.293 38.1) (end 57.658 37.465) (width 0.2) (layer "F.Cu") (net 7) (tstamp 6457e542-9ab3-4326-b13d-955af43098dd))
  (segment (start 63.246 42.5835) (end 63.246 41.021) (width 0.25) (layer "F.Cu") (net 7) (tstamp 6808d4d3-62d3-456d-99b1-2b6f3f7107e3))
  (segment (start 56.261 37.465) (end 56.261 39.471) (width 0.2) (layer "F.Cu") (net 7) (tstamp 69e706ca-ddb5-4c4a-9452-4c3535161a6b))
  (segment (start 68.834 41.021) (end 69.596 41.783) (width 0.25) (layer "F.Cu") (net 7) (tstamp 7c157485-16c0-4a80-a9d9-c4c765d0719d))
  (segment (start 52.908518 37.465) (end 55.499 37.465) (width 0.2) (layer "F.Cu") (net 7) (tstamp 8a4d247c-b5fd-4c08-ab89-680be9adf415))
  (segment (start 57.658 37.465) (end 55.499 37.465) (width 0.2) (layer "F.Cu") (net 7) (tstamp 91884e6f-a236-4b98-9619-e43785ab17c7))
  (segment (start 58.293 40.64) (end 58.293 38.1) (width 0.2) (layer "F.Cu") (net 7) (tstamp b37b6827-ea4d-4352-a7b4-afb1c417722e))
  (segment (start 69.596 42.291) (end 69.596 43.496) (width 0.2) (layer "F.Cu") (net 7) (tstamp c229a44a-95dd-4aef-a11b-ada97aee629c))
  (segment (start 55.753 20.32) (end 54.65352 21.41948) (width 0.2) (layer "F.Cu") (net 7) (tstamp c812f416-7888-49f0-bdbd-cdd872cdcdf5))
  (segment (start 53.51052 24.84848) (end 50.497159 24.84848) (width 0.2) (layer "F.Cu") (net 7) (tstamp cd2c3454-8b62-46ae-a81e-02ec4f228d8b))
  (segment (start 58.674 41.021) (end 58.293 40.64) (width 0.2) (layer "F.Cu") (net 7) (tstamp d2f1cd99-10cd-4c9f-903c-f952ff849ebf))
  (segment (start 75.311 33.6935) (end 75.311 38.354) (width 0.2) (layer "F.Cu") (net 8) (tstamp 06d2abaf-692e-46f1-8038-65f2993e27d1))
  (segment (start 71.501 33.681) (end 72.009 33.681) (width 0.2) (layer "F.Cu") (net 8) (tstamp 171bc26a-7280-4722-818f-316840210ed0))
  (segment (start 75.311 33.6935) (end 71.5135 33.6935) (width 0.2) (layer "F.Cu") (net 8) (tstamp 23e5a4e8-f40b-4789-ade5-6bc3ccc249e4))
  (segment (start 70.866 35.814) (end 70.866 38.546) (width 0.2) (layer "F.Cu") (net 8) (tstamp 2bfa421e-140b-4b0a-a993-506f83700d6b))
  (segment (start 78.613 41.656) (end 80.111 41.656) (width 0.2) (layer "F.Cu") (net 8) (tstamp 619a51c7-4ed2-46eb-b469-e46dd3ca3e0f))
  (segment (start 75.311 38.354) (end 78.613 41.656) (width 0.2) (layer "F.Cu") (net 8) (tstamp 6cd37875-c29d-4e70-b23e-216244af0fdd))
  (segment (start 72.009 34.671) (end 70.866 35.814) (width 0.2) (layer "F.Cu") (net 8) (tstamp 79f9973f-9b6e-4f40-83ea-703378cc3e36))
  (segment (start 71.5135 33.6935) (end 71.501 33.681) (width 0.25) (layer "F.Cu") (net 8) (tstamp 9eaf0ec2-a88a-4046-87e7-d6247b036619))
  (segment (start 72.009 33.681) (end 72.009 34.671) (width 0.2) (layer "F.Cu") (net 8) (tstamp be5605eb-fec1-409a-b8d0-02e5a588f3fb))
  (segment (start 33.274 31.623) (end 30.861 29.21) (width 0.5) (layer "F.Cu") (net 9) (tstamp 3cc8fcc2-2be6-4b40-8dc5-54bddd6aae73))
  (segment (start 38.608 25.2345) (end 38.4425 25.4) (width 0.25) (layer "F.Cu") (net 9) (tstamp 4915a224-dc39-4ab8-a6a4-dafc2d68c683))
  (segment (start 32.639 19.806) (end 32.754 19.691) (width 0.5) (layer "F.Cu") (net 9) (tstamp 62b41af3-9e64-4d93-a1e2-d5200f84df66))
  (segment (start 32.754 19.691) (end 37.891 19.691) (width 0.5) (layer "F.Cu") (net 9) (tstamp 948f4956-68d3-459d-ab31-ff3b3cc60410))
  (segment (start 41.021 31.536) (end 40.934 31.623) (width 0.5) (layer "F.Cu") (net 9) (tstamp c534edd7-fba4-4ecd-b8e5-1988f4a80eae))
  (segment (start 37.891 19.691) (end 37.891 24.302) (width 0.5) (layer "F.Cu") (net 9) (tstamp c85c59d7-2c3f-41c5-8a16-633771bb7942))
  (segment (start 37.891 24.302) (end 38.608 25.019) (width 0.5) (layer "F.Cu") (net 9) (tstamp d1a5cb24-4d82-4bdf-9a9d-0c150c4c5037))
  (segment (start 40.934 31.623) (end 33.274 31.623) (width 0.5) (layer "F.Cu") (net 9) (tstamp fa829c29-0224-453d-a7e7-04d1293be3b4))
  (segment (start 38.608 25.019) (end 38.608 25.2345) (width 0.25) (layer "F.Cu") (net 9) (tstamp fd88ed06-1019-4bf5-b79a-8c50cb5336c1))
  (segment (start 39.8235 23.556) (end 39.8235 30.3385) (width 0.5) (layer "B.Cu") (net 9) (tstamp 11c7827a-597c-461a-82ad-fdfc560e5f3a))
  (segment (start 39.8235 30.3385) (end 41.021 31.536) (width 0.5) (layer "B.Cu") (net 9) (tstamp a364b68a-9b4e-4456-9a5a-be489d105b08))
  (segment (start 37.891 21.6235) (end 39.8235 23.556) (width 0.5) (layer "B.Cu") (net 9) (tstamp b07d8082-b4a2-416f-bf58-97a6183c3496))
  (segment (start 37.891 19.691) (end 37.891 21.6235) (width 0.5) (layer "B.Cu") (net 9) (tstamp d9a0e506-980b-44b8-9542-453f9ca6a1a3))
  (segment (start 150.241 87.159959) (end 142.710041 87.159959) (width 4) (layer "F.Cu") (net 10) (tstamp 00a94e7b-07e4-48ef-891b-54205737cad8))
  (segment (start 121.6235 47.7945) (end 121.6235 50.5285) (width 4) (layer "F.Cu") (net 10) (tstamp 03f4f1b8-5adf-4383-83d7-f7f05248ab9a))
  (segment (start 37.084 45.466) (end 38.629 43.921) (width 0.5) (layer "F.Cu") (net 10) (tstamp 08c2f0c4-5cd5-4cdd-b492-a0e0ba990118))
  (segment (start 150.241 59.219959) (end 141.605 59.219959) (width 4) (layer "F.Cu") (net 10) (tstamp 096cb8ca-b463-4732-94e3-6bc8da0dec36))
  (segment (start 121.6235 47.7945) (end 121.6235 46.7785) (width 4) (layer "F.Cu") (net 10) (tstamp 098f37f3-3a5d-4bac-955b-7214e2ce9ae7))
  (segment (start 142.621 59.309) (end 142.621 72.771) (width 5) (layer "F.Cu") (net 10) (tstamp 13ee8c09-dd82-4ca9-9936-84d18f74c4d6))
  (segment (start 161.711 80.986) (end 160.441 82.256) (width 4) (layer "F.Cu") (net 10) (tstamp 219aea8a-89b4-4b6a-a39b-5487fccdaba9))
  (segment (start 142.621 59.309) (end 142.494 59.182) (width 5) (layer "F.Cu") (net 10) (tstamp 286640c2-4dfc-4537-b518-04368198c5d2))
  (segment (start 150.241 87.159959) (end 159.347041 87.159959) (width 4) (layer "F.Cu") (net 10) (tstamp 2bb7f821-278d-4285-9479-6fd23931460c))
  (segment (start 162.901 106.386) (end 165.981 106.386) (width 4) (layer "F.Cu") (net 10) (tstamp 311ead4b-6af0-4104-8d8a-87a5f4bdb4ab))
  (segment (start 52.705 44.196) (end 52.705 40.132) (width 0.3) (layer "F.Cu") (net 10) (tstamp 388e6c0c-4b97-4c5c-92cf-b9820d2ffed1))
  (segment (start 142.494 59.182) (end 130.277 59.182) (width 5) (layer "F.Cu") (net 10) (tstamp 3df9c4c2-0108-464a-8bd0-a55833e67c39))
  (segment (start 150.241 59.219959) (end 160.363041 59.219959) (width 4) (layer "F.Cu") (net 10) (tstamp 404e3ce3-4bfb-4afb-a979-3b1fbc625796))
  (segment (start 70.260986 45.5325) (end 70.194486 45.466) (width 0.3) (layer "F.Cu") (net 10) (tstamp 429c6964-fb20-4897-8e24-01d8c01aba3e))
  (segment (start 84.455 44.831) (end 78.232 44.831) (width 0.3) (layer "F.Cu") (net 10) (tstamp 4324fccc-c449-4cf6-86e5-3332d0bf05f0))
  (segment (start 121.6235 45.7625) (end 121.6235 43.0285) (width 4) (layer "F.Cu") (net 10) (tstamp 4bd475ac-835f-4791-8091-80b9a2ec47b0))
  (segment (start 160.441 73.446) (end 160.441 82.256) (width 4) (layer "F.Cu") (net 10) (tstamp 5ba59e98-1032-4c95-8c51-594d02d3bab8))
  (segment (start 160.441 82.256) (end 160.441 86.066) (width 4) (layer "F.Cu") (net 10) (tstamp 5e7d4767-2811-42f0-9dfb-939134dba6c1))
  (segment (start 30.327 43.307) (end 30.327 43.535) (width 0.5) (layer "F.Cu") (net 10) (tstamp 68c69664-51df-441a-9f53-d8dd528c12d3))
  (segment (start 160.401 103.886) (end 162.901 106.386) (width 4) (layer "F.Cu") (net 10) (tstamp 695ec155-7f66-4d48-9486-10070c0105f4))
  (segment (start 160.441 103.846) (end 160.401 103.886) (width 4) (layer "F.Cu") (net 10) (tstamp 6b476339-1984-4fac-9c77-470c763ef868))
  (segment (start 160.184959 73.189959) (end 160.441 73.446) (width 4) (layer "F.Cu") (net 10) (tstamp 6bcf7cf2-bff8-4f81-a199-d5955397829b))
  (segment (start 131.801 79.101) (end 133.731 81.031) (width 2) (layer "F.Cu") (net 10) (tstamp 6d25fd10-51df-4380-a584-77dd77d13ca7))
  (segment (start 150.241 101.129959) (end 158.914959 101.129959) (width 4) (layer "F.Cu") (net 10) (tstamp 73754893-a948-41f6-912b-54174c79878f))
  (segment (start 160.441 69.556) (end 160.441 73.446) (width 4) (layer "F.Cu") (net 10) (tstamp 78794b90-6752-41b8-8442-ca293a02f727))
  (segment (start 70.194486 45.466) (end 53.975 45.466) (width 0.3) (layer "F.Cu") (net 10) (tstamp 7cacf3ae-49ff-4c59-8615-13c67b7dbac1))
  (segment (start 78.232 44.831) (end 77.597 45.466) (width 0.3) (layer "F.Cu") (net 10) (tstamp 848a8fa3-dedd-4ab1-83b4-0536e15c6fdf))
  (segment (start 160.441 93.686) (end 160.441 102.656) (width 4) (layer "F.Cu") (net 10) (tstamp 8a19d340-39da-4f9c-965b-8311ae078f36))
  (segment (start 84.709 44.577) (end 84.709 42.291) (width 0.2) (layer "F.Cu") (net 10) (tstamp 8c1351d1-af5e-4dd3-beed-09b21e7e12b0))
  (segment (start 53.975 45.466) (end 52.705 44.196) (width 0.3) (layer "F.Cu") (net 10) (tstamp 8da00e26-5968-4f96-875b-eb51f4ec7070))
  (segment (start 160.441 102.656) (end 160.441 103.846) (width 4) (layer "F.Cu") (net 10) (tstamp 8df1cbf1-e099-4611-b61e-b27e0bef6ea8))
  (segment (start 158.914959 101.129959) (end 160.441 102.656) (width 4) (layer "F.Cu") (net 10) (tstamp 8fbb52ec-6f45-499f-81e2-6c659970e888))
  (segment (start 77.597 45.466) (end 73.279 45.466) (width 0.3) (layer "F.Cu") (net 10) (tstamp 90c790e0-3ea8-4bc1-97bc-45c32a032afc))
  (segment (start 38.629 43.921) (end 38.629 43.815) (width 0.5) (layer "F.Cu") (net 10) (tstamp 931e13dd-42ae-49a7-9fee-d5901fc5fc29))
  (segment (start 84.074 41.656) (end 83.211 41.656) (width 0.2) (layer "F.Cu") (net 10) (tstamp 940b0324-c0ba-447b-8c76-695722a264ff))
  (segment (start 84.709 42.291) (end 84.074 41.656) (width 0.2) (layer "F.Cu") (net 10) (tstamp 9d6fdf74-02ca-4982-a3bc-ab57564e3130))
  (segment (start 161.711 68.286) (end 160.441 69.556) (width 4) (layer "F.Cu") (net 10) (tstamp acfedbf7-41d8-4d45-bb22-2592d3d75533))
  (segment (start 142.621 98.044) (end 145.706959 101.129959) (width 4) (layer "F.Cu") (net 10) (tstamp b12d4fb6-cf11-4bdc-bec5-60b7afbfea43))
  (segment (start 145.706959 101.129959) (end 150.241 101.129959) (width 4) (layer "F.Cu") (net 10) (tstamp b2836c22-9292-4f55-9fde-17d199ea6018))
  (segment (start 160.441 69.556) (end 160.441 58.801) (width 4) (layer "F.Cu") (net 10) (tstamp b8d1f9a7-acca-4fd8-abe8-81cab9ea8f08))
  (segment (start 160.441 86.066) (end 160.441 93.686) (width 4) (layer "F.Cu") (net 10) (tstamp bc33c4e2-d195-44ad-a492-6d2a610d799f))
  (segment (start 142.621 87.249) (end 142.621 98.044) (width 4) (layer "F.Cu") (net 10) (tstamp be05813b-d1c7-4c15-abe4-6c53b756cdf5))
  (segment (start 163.656 55.586) (end 165.981 55.586) (width 4) (layer "F.Cu") (net 10) (tstamp bee8c072-47e8-430c-84cc-eaa8866f71d7))
  (segment (start 121.6235 46.7785) (end 121.6235 45.7625) (width 4) (layer "F.Cu") (net 10) (tstamp c2550ebe-f7ea-4122-bc9a-6aa3f067407b))
  (segment (start 130.277 59.182) (end 121.6235 50.5285) (width 5) (layer "F.Cu") (net 10) (tstamp c37d3814-0906-4e60-929e-c4a96f107ebf))
  (segment (start 131.801 61.112) (end 131.801 79.101) (width 2) (layer "F.Cu") (net 10) (tstamp c496c000-6146-4b18-b01a-ebd2b8594dc8))
  (segment (start 32.258 45.466) (end 37.084 45.466) (width 0.5) (layer "F.Cu") (net 10) (tstamp cd36e218-c7d6-4ea8-8e0f-1a38fa134c7c))
  (segment (start 165.981 93.686) (end 160.441 93.686) (width 4) (layer "F.Cu") (net 10) (tstamp d4347e35-b207-491d-8443-ff0ff7ef51c3))
  (segment (start 159.347041 87.159959) (end 160.441 86.066) (width 4) (layer "F.Cu") (net 10) (tstamp dba24d57-5b67-4996-8a3c-efec5daa24fc))
  (segment (start 30.327 43.535) (end 32.258 45.466) (width 0.5) (layer "F.Cu") (net 10) (tstamp e1e3d075-1000-4fb6-b84c-3f725fe358b5))
  (segment (start 165.981 80.986) (end 161.711 80.986) (width 4) (layer "F.Cu") (net 10) (tstamp e28d770d-e4a6-4ca8-bbe9-1fad91edffe8))
  (segment (start 84.5312 44.7548) (end 84.709 44.577) (width 0.2) (layer "F.Cu") (net 10) (tstamp e5ebfa18-3bd3-4c64-8f1e-31bb1331f857))
  (segment (start 142.621 72.771) (end 142.621 87.249) (width 4) (layer "F.Cu") (net 10) (tstamp e915462b-5def-4185-ad78-c1cf469d11ba))
  (segment (start 143.039959 73.189959) (end 142.621 72.771) (width 4) (layer "F.Cu") (net 10) (tstamp e99191ab-4174-4f90-aa89-a66d7fe916cd))
  (segment (start 142.710041 87.159959) (end 142.621 87.249) (width 4) (layer "F.Cu") (net 10) (tstamp ea8ad440-2ac6-4c14-9472-d93e6fd4bfa3))
  (segment (start 165.981 68.286) (end 161.711 68.286) (width 4) (layer "F.Cu") (net 10) (tstamp f082f4ae-4fd1-45e1-8bd0-fb2f7efe3561))
  (segment (start 150.241 73.189959) (end 143.039959 73.189959) (width 4) (layer "F.Cu") (net 10) (tstamp f28030a4-bcd3-4b5b-9a6f-ceae5e528985))
  (segment (start 160.363041 59.219959) (end 160.401 59.182) (width 4) (layer "F.Cu") (net 10) (tstamp fb5c6547-febe-46dd-9027-61b80e30b6e7))
  (segment (start 160.441 58.801) (end 163.656 55.586) (width 4) (layer "F.Cu") (net 10) (tstamp fbcc6a68-8505-42a3-a979-5450caeb8295))
  (segment (start 150.241 73.189959) (end 160.184959 73.189959) (width 4) (layer "F.Cu") (net 10) (tstamp fe818cd4-1cf7-4424-8fb2-d7fd63e403ed))
  (via (at 148.209 87.122) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 10) (tstamp 01a73fd3-b284-4dbc-951f-d99f0ec20c54))
  (via (at 121.666 45.339) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 10) (tstamp 1780fd13-a8b8-4880-a2e8-848458b203d3))
  (via (at 123.317 52.324) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 10) (tstamp 2c084f51-b855-437b-8754-52a83c5e7937))
  (via (at 147.32 73.152) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 10) (tstamp 35b3257c-e261-4690-aa24-746e95f6f0a0))
  (via (at 147.32 59.182) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 10) (tstamp 361761a6-116a-457c-b12f-136730522326))
  (via (at 148.209 59.182) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 10) (tstamp 481592c9-4b21-4ff3-9210-eb44048f402b))
  (via (at 147.32 101.092) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 10) (tstamp 5b0c2d89-a0ab-4e2e-a735-0c7fd82c93e0))
  (via (at 146.431 59.182) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 10) (tstamp 69178def-59ff-460e-a756-2db743f16296))
  (via (at 84.5312 44.7548) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 10) (tstamp 7e9ce538-468d-4b69-9988-ea15e8b99ce2))
  (via (at 122.682 45.339) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 10) (tstamp 87300985-4250-4baf-8daf-b93170a4d324))
  (via (at 148.209 101.092) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 10) (tstamp 906b9922-1f0f-4c56-9cbc-d23eb6f3e30f))
  (via (at 148.209 73.152) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 10) (tstamp bb0ae053-19fc-4056-b653-8972c99fb787))
  (via (at 146.431 87.122) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 10) (tstamp be23c103-b28c-409f-a311-dc6aa4597d3c))
  (via (at 147.32 87.122) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 10) (tstamp c3b37356-0a95-4cfb-9dcc-bb83cc8bdcac))
  (via (at 122.555 52.959) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 10) (tstamp cdc9beb3-4c56-4d9f-a34b-dbf1b070ebc3))
  (via (at 70.260986 45.5325) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 10) (tstamp df6838bf-9797-4a40-93fb-856c7ec4983e))
  (via (at 124.079 51.689) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 10) (tstamp e16b8b8d-23ae-4a63-a670-8afb94ac8b44))
  (via (at 120.65 45.339) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 10) (tstamp e817bde3-321f-4d2a-82b2-86441c5b794b))
  (via (at 73.279 45.466) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 10) (tstamp ec1392ec-2a0a-4a3c-92a1-836eee6c3849))
  (via (at 146.431 101.092) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 10) (tstamp ed34f019-d154-46b2-9e7a-0d8b1b454450))
  (via (at 52.705 40.132) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 10) (tstamp fbc4e867-e8d3-4e9b-a10a-60864956e2a7))
  (via (at 146.431 73.152) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 10) (tstamp fc0adb1f-ea63-496b-afb0-75033e01d59c))
  (segment (start 121.6235 47.7945) (end 121.6235 43.0285) (width 4) (layer "B.Cu") (net 10) (tstamp 042fb6ff-c53f-4346-aabf-ef629fe942d9))
  (segment (start 70.327486 45.466) (end 73.279 45.466) (width 0.3) (layer "B.Cu") (net 10) (tstamp 0e2aff65-8145-43cd-ad79-dfd965f73506))
  (segment (start 86.2584 46.482) (end 100.838 46.482) (width 0.5) (layer "B.Cu") (net 10) (tstamp 1794f7ac-bcbb-410d-bfb1-a7026e408dca))
  (segment (start 130.277 59.182) (end 142.494 59.182) (width 5) (layer "B.Cu") (net 10) (tstamp 1e265681-ef54-45f4-a8b9-bb72ca7a16af))
  (segment (start 142.621 98.044) (end 145.706959 101.129959) (width 4) (layer "B.Cu") (net 10) (tstamp 22e4d17e-6260-45dd-a32b-4cf9f534c617))
  (segment (start 84.5312 44.7548) (end 86.2584 46.482) (width 0.5) (layer "B.Cu") (net 10) (tstamp 556db0fe-fdea-43cb-bbfd-4c3f5659b55e))
  (segment (start 107.696 53.34) (end 118.812 53.34) (width 0.5) (layer "B.Cu") (net 10) (tstamp 63c9e577-50bf-4450-8d66-e50ab16f9652))
  (segment (start 142.531959 59.219959) (end 150.241 59.219959) (width 4) (layer "B.Cu") (net 10) (tstamp 67ecf088-ddfa-4273-9d06-b5020d175cea))
  (segment (start 52.705 40.132) (end 51.943 39.37) (width 0.3) (layer "B.Cu") (net 10) (tstamp 7af86a18-f278-4c84-84d3-a429a94208fc))
  (segment (start 40.513 41.91) (end 40.513 43.18) (width 0.3) (layer "B.Cu") (net 10) (tstamp 7d06bb3e-02ef-468b-99a9-31d106563886))
  (segment (start 142.710041 87.159959) (end 142.621 87.249) (width 4) (layer "B.Cu") (net 10) (tstamp 8a577b00-5d2a-4873-8d65-40c6eff39e35))
  (segment (start 142.621 72.771) (end 142.621 87.249) (width 4) (layer "B.Cu") (net 10) (tstamp 9871c911-14db-4e73-ba37-708dccc5cb16))
  (segment (start 118.812 53.34) (end 121.6235 50.5285) (width 0.5) (layer "B.Cu") (net 10) (tstamp 99c99997-fc43-4437-964e-01440a4c0c91))
  (segment (start 121.6235 50.5285) (end 130.277 59.182) (width 5) (layer "B.Cu") (net 10) (tstamp 9a3e8822-1cdb-4ceb-b00b-8fc278f8d871))
  (segment (start 142.621 87.249) (end 142.621 98.044) (width 4) (layer "B.Cu") (net 10) (tstamp 9b6aa342-f5b9-4f29-b217-c40c5335fb3b))
  (segment (start 150.241 73.189959) (end 143.039959 73.189959) (width 4) (layer "B.Cu") (net 10) (tstamp a3199fcd-b900-4125-a863-f087c4ad85cd))
  (segment (start 40.513 43.18) (end 39.878 43.815) (width 0.3) (layer "B.Cu") (net 10) (tstamp aa73654f-3f1d-4326-887d-4ffb22a98555))
  (segment (start 142.621 59.309) (end 142.621 72.771) (width 5) (layer "B.Cu") (net 10) (tstamp b639ad7b-407d-4afa-829d-c341735b55e9))
  (segment (start 51.943 39.37) (end 43.053 39.37) (width 0.3) (layer "B.Cu") (net 10) (tstamp bef37c92-e0fd-483a-b7ee-85084f2217a2))
  (segment (start 121.6235 46.7785) (end 121.6235 50.5285) (width 4) (layer "B.Cu") (net 10) (tstamp bf096a87-969a-48b0-b15e-3e16498328b8))
  (segment (start 142.494 59.182) (end 142.621 59.309) (width 5) (layer "B.Cu") (net 10) (tstamp c21a3bd9-e2fb-4f64-8eb8-75e39f6e7d7f))
  (segment (start 100.838 46.482) (end 107.696 53.34) (width 0.5) (layer "B.Cu") (net 10) (tstamp ca88f499-1314-4615-a334-c34c8a90a7b2))
  (segment (start 143.039959 73.189959) (end 142.621 72.771) (width 4) (layer "B.Cu") (net 10) (tstamp d53bd391-caa4-4f6e-8116-4399e9c9aa57))
  (segment (start 43.053 39.37) (end 40.513 41.91) (width 0.3) (layer "B.Cu") (net 10) (tstamp dcc019c8-dc41-4a61-954f-a9db32dbd4b8))
  (segment (start 145.706959 101.129959) (end 150.241 101.129959) (width 4) (layer "B.Cu") (net 10) (tstamp ed47bf98-7e45-4e2c-97ca-32832f61d889))
  (segment (start 39.878 43.815) (end 38.375 43.815) (width 0.3) (layer "B.Cu") (net 10) (tstamp f6015832-255a-4a3f-a2d2-53bfbd1fe552))
  (segment (start 150.241 87.159959) (end 142.710041 87.159959) (width 4) (layer "B.Cu") (net 10) (tstamp fb700986-e4e7-4407-9b43-831ea5f403ad))
  (segment (start 70.260986 45.5325) (end 70.327486 45.466) (width 0.3) (layer "B.Cu") (net 10) (tstamp fd991535-9b99-4201-8406-29da10416014))
  (segment (start 27.3435 52.0315) (end 26.543 52.832) (width 0.25) (layer "F.Cu") (net 11) (tstamp 0ea83c71-1a7f-40b0-b277-ff1a85781429))
  (segment (start 21.8145 34.3875) (end 21.8145 32.586) (width 0.25) (layer "F.Cu") (net 11) (tstamp 2a070067-c201-4399-9ae3-8ca03e9df503))
  (segment (start 27.4705 52.0315) (end 27.432 52.0315) (width 0.25) (layer "F.Cu") (net 11) (tstamp 3e5ebe37-6b22-4063-b1e3-32dd1dabf3dc))
  (segment (start 28.321 51.181) (end 27.4705 52.0315) (width 0.25) (layer "F.Cu") (net 11) (tstamp 466b2c6d-ad8f-41e0-bb4d-9908d42dee51))
  (segment (start 23.241 35.814) (end 21.8145 34.3875) (width 0.25) (layer "F.Cu") (net 11) (tstamp 4c87515c-a3a4-412e-adee-c7bb191456e9))
  (segment (start 23.7105 52.0315) (end 23.241 51.562) (width 0.25) (layer "F.Cu") (net 11) (tstamp 59788d05-0909-4adc-8e7e-e33db3e2a4e7))
  (segment (start 27.3935 52.0315) (end 23.7105 52.0315) (width 0.25) (layer "F.Cu") (net 11) (tstamp 5cd91dcc-5096-4d2b-8735-643a9c0d2c0e))
  (segment (start 27.432 52.07) (end 27.3935 52.0315) (width 0.25) (layer "F.Cu") (net 11) (tstamp b0909a58-643d-4091-ab08-72dfcc6c595d))
  (segment (start 29.656 51.181) (end 28.321 51.181) (width 0.25) (layer "F.Cu") (net 11) (tstamp b1d492ff-9761-4e17-b56d-3ecdf4b31363))
  (segment (start 26.543 52.832) (end 26.543 53.5555) (width 0.25) (layer "F.Cu") (net 11) (tstamp e0f90806-11cf-4217-9ff0-abb61599d8b4))
  (segment (start 23.241 51.562) (end 23.241 35.814) (width 0.25) (layer "F.Cu") (net 11) (tstamp e308d75f-2740-4d00-9584-eb89a7994cc4))
  (segment (start 18.161 63.627) (end 18.58552 64.05152) (width 0.2) (layer "F.Cu") (net 12) (tstamp 04cd2552-f9d5-438d-a285-c4965ce0f745))
  (segment (start 28.956 80.3148) (end 28.956 79.1595) (width 0.25) (layer "F.Cu") (net 12) (tstamp 13de45a2-4dd9-4b5d-9ab0-22235418a308))
  (segment (start 31.134 86.849) (end 31.134 83.547) (width 0.25) (layer "F.Cu") (net 12) (tstamp 14067af2-a862-4dac-9da5-e871919ec253))
  (segment (start 31.134 83.547) (end 30.817481 83.230481) (width 0.25) (layer "F.Cu") (net 12) (tstamp 194ae5dc-3107-40e3-ac82-11e129047b62))
  (segment (start 27.432 156.21) (end 28.487 156.21) (width 0.25) (layer "F.Cu") (net 12) (tstamp 226979d9-3071-49fe-8603-3b6292353d7b))
  (segment (start 23.876 69.37592) (end 23.876 64.262) (width 0.2) (layer "F.Cu") (net 12) (tstamp 2345e0a3-ebe0-4dbc-848e-071d7293dbeb))
  (segment (start 30.042881 83.230481) (end 29.337 82.5246) (width 0.25) (layer "F.Cu") (net 12) (tstamp 2385626e-8624-4f86-b19d-5d311005b2db))
  (segment (start 19.894 61.976) (end 18.415 61.976) (width 0.2) (layer "F.Cu") (net 12) (tstamp 26de5151-2006-454d-b4f0-5af211cddd45))
  (segment (start 23.876 64.262) (end 23.66552 64.05152) (width 0.2) (layer "F.Cu") (net 12) (tstamp 2913eaec-a453-4e9e-9d43-f2b31bfce9cc))
  (segment (start 22.0125 79.375) (end 22.615976 79.375) (width 0.25) (layer "F.Cu") (net 12) (tstamp 410dcc4f-8b30-400f-8fd2-c84186cfbbd1))
  (segment (start 19.71494 79.311903) (end 19.564949 79.161912) (width 0.2) (layer "F.Cu") (net 12) (tstamp 4392ed2f-8d59-4bd2-96d3-b2ce550e64a8))
  (segment (start 18.161 62.23) (end 18.161 63.627) (width 0.2) (layer "F.Cu") (net 12) (tstamp 4a2e3828-b4bc-4d55-8fa8-a08ff24bd786))
  (segment (start 19.564949 73.686971) (end 23.876 69.37592) (width 0.2) (layer "F.Cu") (net 12) (tstamp 5179154e-b62a-4322-bb83-39b8df25ba51))
  (segment (start 18.415 61.976) (end 18.161 62.23) (width 0.2) (layer "F.Cu") (net 12) (tstamp 60aeb412-53c8-482b-83bd-976f584da2ee))
  (segment (start 19.839921 79.436884) (end 19.839921 103.174289) (width 0.25) (layer "F.Cu") (net 12) (tstamp 66831387-fc17-4451-b4d1-9890046e44be))
  (segment (start 21.285712 104.62008) (end 24.99108 104.62008) (width 0.25) (layer "F.Cu") (net 12) (tstamp 6dfa1566-78e5-4d94-a522-5390f96676e5))
  (segment (start 19.71494 79.311903) (end 19.839921 79.436884) (width 0.25) (layer "F.Cu") (net 12) (tstamp 732a7d97-1ee6-4ca1-babf-c2550300aded))
  (segment (start 33.816 88.551) (end 32.836 88.551) (width 0.25) (layer "F.Cu") (net 12) (tstamp 755ef7dd-4969-4eaa-9ff2-867fe0343897))
  (segment (start 18.58552 64.05152) (end 23.66552 64.05152) (width 0.2) (layer "F.Cu") (net 12) (tstamp 7796eadb-cd96-4d2a-a8f4-64f54b33ab33))
  (segment (start 32.836 88.551) (end 31.134 86.849) (width 0.25) (layer "F.Cu") (net 12) (tstamp a183533a-b682-40aa-a7d5-0ad6fb5659c6))
  (segment (start 30.817481 83.230481) (end 30.042881 83.230481) (width 0.25) (layer "F.Cu") (net 12) (tstamp af84a08e-ded9-47c9-bbbf-b16c7df20089))
  (segment (start 28.956 81.127) (end 29.337 81.508) (width 0.25) (layer "F.Cu") (net 12) (tstamp bd9559fa-6d54-48ab-b132-34745e37acd9))
  (segment (start 25.908 154.686) (end 27.432 156.21) (width 0.25) (layer "F.Cu") (net 12) (tstamp c9dd184f-d3b6-4aa1-a6c9-21f9447a1fa6))
  (segment (start 29.337 81.75) (end 29.102 81.515) (width 0.25) (layer "F.Cu") (net 12) (tstamp cb5e0267-5e3f-4b19-9724-debf014ccd2a))
  (segment (start 24.384 156.21) (end 23.075 156.21) (width 0.25) (layer "F.Cu") (net 12) (tstamp d1b94d73-8198-4601-be1e-e681e8f5715f))
  (segment (start 28.487 156.21) (end 29.031 155.666) (width 0.25) (layer "F.Cu") (net 12) (tstamp e10f9efb-d707-44e1-82cd-b88d37d8f0de))
  (segment (start 28.956 79.1595) (end 28.956 81.127) (width 0.25) (layer "F.Cu") (net 12) (tstamp e1d54a74-b42f-481e-968d-7f9f5f6145c2))
  (segment (start 25.908 105.537) (end 25.908 154.686) (width 0.25) (layer "F.Cu") (net 12) (tstamp e7fc36c0-41cf-4821-9c2b-194676ae2c5d))
  (segment (start 25.908 154.686) (end 24.384 156.21) (width 0.25) (layer "F.Cu") (net 12) (tstamp eb1b83c9-9700-4d25-b696-4b4a201731b3))
  (segment (start 23.075 156.21) (end 22.531 155.666) (width 0.25) (layer "F.Cu") (net 12) (tstamp f3402625-7f6b-40a1-bcc1-8e45457c4e0c))
  (segment (start 19.839921 103.174289) (end 21.285712 104.62008) (width 0.25) (layer "F.Cu") (net 12) (tstamp f63ab221-ba97-413d-a02b-6eee98a8810f))
  (segment (start 22.615976 79.375) (end 23.555776 80.3148) (width 0.25) (layer "F.Cu") (net 12) (tstamp f711cfdf-9344-456f-a08b-c02e3d9a005e))
  (segment (start 19.564949 79.161912) (end 19.564949 73.686971) (width 0.2) (layer "F.Cu") (net 12) (tstamp f779584d-959e-453a-a198-aca989cf41e8))
  (segment (start 24.99108 104.62008) (end 25.908 105.537) (width 0.25) (layer "F.Cu") (net 12) (tstamp f7ccc92a-6767-4037-9b55-fa8bd3105ec4))
  (segment (start 29.337 82.5246) (end 29.337 81.75) (width 0.25) (layer "F.Cu") (net 12) (tstamp f9ee3edb-5804-4e9c-ae69-cbaffc8fbb54))
  (segment (start 23.555776 80.3148) (end 28.956 80.3148) (width 0.25) (layer "F.Cu") (net 12) (tstamp fcea47f2-b9ac-43e9-9cf5-f874bf7ad62b))
  (via (at 19.71494 79.311903) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 12) (tstamp 521c4ce0-5f87-4da8-86eb-60f6f80d0fed))
  (via (at 22.0125 79.375) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 12) (tstamp c101ca42-2660-4a9d-91e1-3dcac83f0cbb))
  (segment (start 19.71494 79.311903) (end 21.949403 79.311903) (width 0.2) (layer "B.Cu") (net 12) (tstamp 2219f273-6e2b-40fe-8b56-42a4358e023a))
  (segment (start 21.949403 79.311903) (end 22.0125 79.375) (width 0.2) (layer "B.Cu") (net 12) (tstamp 7b608ebc-1874-4564-ba97-672d197ee861))
  (segment (start 27.93644 93.21444) (end 30.10256 93.21444) (width 0.25) (layer "F.Cu") (net 13) (tstamp 31d8163b-3787-4b51-93a2-2e45f2047130))
  (segment (start 25.527 90.805) (end 27.93644 93.21444) (width 0.25) (layer "F.Cu") (net 13) (tstamp 5469017b-a2c6-49f8-9036-a63b33b57099))
  (segment (start 32.366 90.951) (end 33.816 90.951) (width 0.25) (layer "F.Cu") (net 13) (tstamp 6b1ddda0-59f4-4102-9c3c-69cd98f96d08))
  (segment (start 25.527 90.007) (end 23.261 87.741) (width 0.2) (layer "F.Cu") (net 13) (tstamp 73233346-c76f-49d7-94b0-fa605d0c34b6))
  (segment (start 23.261 87.741) (end 23.261 84.328) (width 0.2) (layer "F.Cu") (net 13) (tstamp de5aee3f-0ae1-4620-b8cf-e5133e11069a))
  (segment (start 25.527 90.007) (end 25.527 90.805) (width 0.25) (layer "F.Cu") (net 13) (tstamp e28ed263-82e0-4fcd-a5ee-335983cabefb))
  (segment (start 30.10256 93.21444) (end 32.366 90.951) (width 0.25) (layer "F.Cu") (net 13) (tstamp e794c628-987b-40c0-a5c4-b2a890a231c1))
  (segment (start 26.8806 94.887) (end 28.10364 93.66396) (width 0.25) (layer "F.Cu") (net 14) (tstamp 07d722bd-7b09-44bd-a2f6-76d8d79acee8))
  (segment (start 28.10364 93.66396) (end 30.288758 93.66396) (width 0.25) (layer "F.Cu") (net 14) (tstamp 47652097-cbb4-448d-a1e3-d1eb33e4e92e))
  (segment (start 23.261 100.33) (end 24.15 99.441) (width 0.2) (layer "F.Cu") (net 14) (tstamp 5caa7ec4-00a9-4a1c-a018-710d34a3a0da))
  (segment (start 32.201718 91.751) (end 33.816 91.751) (width 0.25) (layer "F.Cu") (net 14) (tstamp 5f63709f-abe6-48a2-8dc2-631352a64e25))
  (segment (start 30.288758 93.66396) (end 32.201718 91.751) (width 0.25) (layer "F.Cu") (net 14) (tstamp 6f8f9d47-8d62-4bad-af2f-1a158dc4505a))
  (segment (start 24.15 99.441) (end 24.15 96.264) (width 0.2) (layer "F.Cu") (net 14) (tstamp afbb2d6d-4b22-4626-a7bd-580c245bbe73))
  (segment (start 24.15 96.264) (end 25.527 94.887) (width 0.2) (layer "F.Cu") (net 14) (tstamp c7c348ca-4cb6-49a2-a35f-70ba2aee3845))
  (segment (start 25.871 94.887) (end 26.8806 94.887) (width 0.25) (layer "F.Cu") (net 14) (tstamp e7c0bd15-db2c-4887-afac-b3a7e85abbf1))
  (segment (start 103.576 64.841) (end 101.6885 62.9535) (width 1) (layer "F.Cu") (net 15) (tstamp 00541d5b-8160-4ed1-bae1-6fa6383bc8ba))
  (segment (start 116.6235 23.9785) (end 116.6235 50.5285) (width 4) (layer "F.Cu") (net 15) (tstamp 0ca7970b-2aac-43ec-821f-08a3a1b96fa8))
  (segment (start 81.661 62.791) (end 81.4985 62.9535) (width 1) (layer "F.Cu") (net 15) (tstamp 16f34155-2fbc-4312-abed-aa1b3c8e53eb))
  (segment (start 98.171 59.436) (end 81.661 59.436) (width 2) (layer "F.Cu") (net 15) (tstamp 1a665c4a-87df-4a1d-9840-1a3738e13c78))
  (segment (start 116.6235 52.7945) (end 111.76 57.658) (width 2) (layer "F.Cu") (net 15) (tstamp 24b84ef0-65bb-4f0e-a535-dc406f18a6bc))
  (segment (start 127 45.72) (end 131.831 50.551) (width 1) (layer "F.Cu") (net 15) (tstamp 24c0734a-1bd4-4af3-93cb-37bce7574c44))
  (segment (start 119.2885 64.841) (end 117.401 62.9535) (width 1) (layer "F.Cu") (net 15) (tstamp 2784f45f-75cc-4eb0-92a1-a80b94cf262a))
  (segment (start 98.171 59.436) (end 98.171 62.9535) (width 0.7) (layer "F.Cu") (net 15) (tstamp 2eafc751-8b45-46df-b18c-9ebb3ff739f0))
  (segment (start 127 39.37) (end 127 45.72) (width 1) (layer "F.Cu") (net 15) (tstamp 41b0cfef-cf04-480a-858b-b27563708802))
  (segment (start 117.401 62.9535) (end 113.8835 62.9535) (width 1) (layer "F.Cu") (net 15) (tstamp 4c4c435c-91f3-49f6-bbbd-a99b42251a75))
  (segment (start 103.251 59.436) (end 98.171 59.436) (width 2) (layer "F.Cu") (net 15) (tstamp 4fa5a989-03f8-49ec-9744-c4e727fbe876))
  (segment (start 124.2435 36.6135) (end 127 39.37) (width 1) (layer "F.Cu") (net 15) (tstamp 608e33a8-5e07-4598-a0ef-ac9982489c2d))
  (segment (start 85.016 62.9535) (end 81.4985 62.9535) (width 1) (layer "F.Cu") (net 15) (tstamp 82414562-900c-4954-9ee5-4f547d24a4d0))
  (segment (start 111.76 57.658) (end 111.76 59.436) (width 2) (layer "F.Cu") (net 15) (tstamp 837f5e70-0e65-4893-b295-344178e4ad57))
  (segment (start 116.6235 36.6135) (end 124.2435 36.6135) (width 1) (layer "F.Cu") (net 15) (tstamp 84a180a8-f3a6-4f1c-9cef-cc2426eac242))
  (segment (start 111.76 59.436) (end 103.251 59.436) (width 2) (layer "F.Cu") (net 15) (tstamp 8f249c6e-c666-4c05-a31c-c3b2f428176d))
  (segment (start 86.9035 64.841) (end 85.016 62.9535) (width 1) (layer "F.Cu") (net 15) (tstamp 92949555-8d2e-42bc-981e-ead45c3288f7))
  (segment (start 103.576 65.786) (end 103.576 64.841) (width 1) (layer "F.Cu") (net 15) (tstamp 9de6da90-6f22-45aa-a10e-b3d08b7e0edd))
  (segment (start 131.831 50.551) (end 133.731 50.551) (width 1) (layer "F.Cu") (net 15) (tstamp a178882a-8a3e-4ac5-ae8a-8d95a202545a))
  (segment (start 81.661 59.436) (end 81.661 62.791) (width 0.7) (layer "F.Cu") (net 15) (tstamp b27adc3e-3e50-4e5d-bae3-0db26b0b35b9))
  (segment (start 119.2885 65.786) (end 119.2885 64.841) (width 1) (layer "F.Cu") (net 15) (tstamp bd9f2746-816f-414c-bc1b-1e39f816abe7))
  (segment (start 111.633 59.436) (end 113.411 61.214) (width 0.7) (layer "F.Cu") (net 15) (tstamp c5002d4a-bf4b-48a8-8a04-6b1ac97fe9e6))
  (segment (start 81.661 59.436) (end 73.787 59.436) (width 0.7) (layer "F.Cu") (net 15) (tstamp d5b37e99-21cf-4042-9394-18ef10037b06))
  (segment (start 113.411 62.481) (end 113.8835 62.9535) (width 0.7) (layer "F.Cu") (net 15) (tstamp e2bf3e32-e316-4887-9d12-13e1026e9386))
  (segment (start 113.411 61.214) (end 113.411 62.481) (width 0.7) (layer "F.Cu") (net 15) (tstamp e6707582-e2ba-48ea-a8f7-99be66b822f4))
  (segment (start 86.9035 65.786) (end 86.9035 64.841) (width 1) (layer "F.Cu") (net 15) (tstamp e80df5c9-5527-4753-bcde-efb442dd7665))
  (segment (start 101.6885 62.9535) (end 98.171 62.9535) (width 1) (layer "F.Cu") (net 15) (tstamp ed8a0748-d612-4c11-a271-ec5f564bc8b9))
  (segment (start 116.6235 50.5285) (end 116.6235 52.7945) (width 2) (layer "F.Cu") (net 15) (tstamp f37a8e35-4980-4dbd-8d01-7fdbc7c6327d))
  (via (at 118.11 36.576) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 15) (tstamp 0d1845a9-2e3e-4e3b-a3fd-7e672a7045a9))
  (via (at 116.586 40.767) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 15) (tstamp 59cd22fa-9553-4553-8993-e0576dc6ce59))
  (via (at 116.586 26.162) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 15) (tstamp 60f6f508-4632-4385-9168-4be0e7944750))
  (via (at 116.586 33.782) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 15) (tstamp 621ef154-dc79-48b2-9bd0-6a6fb40c9e1c))
  (via (at 117.602 26.162) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 15) (tstamp 767605cf-c227-4dc3-8617-71d27eedb9d4))
  (via (at 115.57 48.26) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 15) (tstamp 7dcdb5ee-3dae-4b8a-96c6-6f50f4434dac))
  (via (at 115.57 33.782) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 15) (tstamp 8a3032a6-840f-41dd-a518-3670abd077f9))
  (via (at 117.602 48.26) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 15) (tstamp cad59912-2ac2-4070-950a-00c0744f4c45))
  (via (at 115.57 26.162) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 15) (tstamp d857ce1d-824d-4904-a501-e242c77e7c56))
  (via (at 117.602 33.782) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 15) (tstamp da4bc159-6d6e-4fa4-bc34-2c14672197e2))
  (via (at 117.602 40.767) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 15) (tstamp deee4a80-aa4c-43dc-9072-6b92efb5853c))
  (via (at 116.586 48.26) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 15) (tstamp ed5de7de-78dc-40fd-bd7b-33f623e8457d))
  (via (at 115.57 40.767) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 15) (tstamp fbbde121-ddda-42c2-8dd8-9f8e1ef4638f))
  (segment (start 116.6235 43.0285) (end 116.6235 50.5285) (width 4) (layer "B.Cu") (net 15) (tstamp cf6c65de-91fb-4255-8ee1-5035bd7be7b5))
  (segment (start 116.6235 31.4785) (end 116.6235 43.0285) (width 4) (layer "B.Cu") (net 15) (tstamp d50a2364-a6be-4da3-929f-f555f1b3147e))
  (segment (start 116.6235 23.9785) (end 116.6235 31.4785) (width 4) (layer "B.Cu") (net 15) (tstamp d5659631-1075-44a7-9637-988b9d6df56a))
  (segment (start 79 20.581) (end 79 23.45) (width 0.2) (layer "F.Cu") (net 16) (tstamp ac761f6e-b24e-49ae-bff8-f7408b7042d7))
  (segment (start 83.693 57.531) (end 77.724 57.531) (width 0.5) (layer "F.Cu") (net 17) (tstamp 1a6865de-ae17-4fda-a74d-4a46eeb3be19))
  (segment (start 91.186 17.018) (end 84.709 17.018) (width 0.2) (layer "F.Cu") (net 17) (tstamp 1ded94cf-8e0c-4d9f-9831-fbad67859968))
  (segment (start 87.7335 100.1785) (end 80.7965 100.1785) (width 0.5) (layer "F.Cu") (net 17) (tstamp 2464654f-c95a-41d0-8b0b-e7c7b10b0e2c))
  (segment (start 96.6235 43.0285) (end 96.6235 45.4425) (width 0.5) (layer "F.Cu") (net 17) (tstamp 51b3416c-1fdc-4035-b59b-e0be9a8ca8b5))
  (segment (start 79 17.52) (end 79.502 17.018) (width 0.2) (layer "F.Cu") (net 17) (tstamp 5d0f7247-db79-4dfd-9795-8ec5e3c8a683))
  (segment (start 83.891 17.582) (end 83.891 18.531) (width 0.2) (layer "F.Cu") (net 17) (tstamp 6114864b-0937-4c5a-9be8-216f06c8e695))
  (segment (start 80.7965 100.1785) (end 80.645 100.33) (width 0.5) (layer "F.Cu") (net 17) (tstamp 62712cde-94fe-4fd2-9aa7-d33c1083da01))
  (segment (start 79 18.531) (end 79 17.52) (width 0.2) (layer "F.Cu") (net 17) (tstamp 9981209e-40e5-44eb-a2b5-c2491b62db96))
  (segment (start 84.455 17.018) (end 83.891 17.582) (width 0.2) (layer "F.Cu") (net 17) (tstamp b6267ac6-f7e4-47a8-8682-bcf16405b502))
  (segment (start 84.709 17.018) (end 79.502 17.018) (width 0.2) (layer "F.Cu") (net 17) (tstamp bbb4903b-1b1d-42b3-b6d0-abc134f956e2))
  (segment (start 77.724 57.531) (end 77.216 58.039) (width 0.5) (layer "F.Cu") (net 17) (tstamp ca0bfa53-28cb-4b06-aa91-df4ea7c50e2f))
  (segment (start 96.6235 45.4425) (end 99.441 48.26) (width 0.5) (layer "F.Cu") (net 17) (tstamp d4989137-672e-4a41-a910-00b0933359f2))
  (segment (start 99.441 48.26) (end 99.441 55.88) (width 0.5) (layer "F.Cu") (net 17) (tstamp f715be9e-9c95-4ce5-ad5e-57d8eacb56e1))
  (segment (start 84.709 17.018) (end 84.455 17.018) (width 0.2) (layer "F.Cu") (net 17) (tstamp f84c4bd2-082e-4925-aa50-137c2a4a47b9))
  (via (at 83.693 57.531) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 17) (tstamp 569ea31d-0b3b-43a6-8b25-f9d6d2b16d08))
  (via (at 80.645 100.33) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 17) (tstamp e2af40b8-7336-4dab-a108-a981cf41d9b5))
  (via (at 91.186 17.018) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 17) (tstamp ecd2a466-2e4a-4d2b-8622-b6e74dda16af))
  (via (at 77.216 58.039) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 17) (tstamp fe34f805-08fa-42c4-945d-47316ad33b56))
  (segment (start 87.7335 100.1785) (end 87.7335 103.6085) (width 0.25) (layer "B.Cu") (net 17) (tstamp 11dc8231-01f1-48f0-9c10-089b2180189c))
  (segment (start 80.645 100.33) (end 80.645 98.806) (width 0.5) (layer "B.Cu") (net 17) (tstamp 13fa7657-9c7b-440a-92d2-2f24dd9e65dc))
  (segment (start 80.645 98.806) (end 78.994 97.155) (width 0.5) (layer "B.Cu") (net 17) (tstamp 17f04be7-893b-431c-8fc8-1076371a8318))
  (segment (start 99.441 57.531) (end 99.06 57.912) (width 0.5) (layer "B.Cu") (net 17) (tstamp 27ba0ca9-830d-4814-9637-8849e88d9ece))
  (segment (start 77.089 58.166) (end 77.089 72.136) (width 0.5) (layer "B.Cu") (net 17) (tstamp 40cef8ea-ce20-4f93-ae1a-f26eaaf68a34))
  (segment (start 99.06 57.912) (end 84.074 57.912) (width 0.5) (layer "B.Cu") (net 17) (tstamp 5097e6a1-2018-4226-b39f-326da0f21772))
  (segment (start 99.441 55.88) (end 99.441 57.531) (width 0.5) (layer "B.Cu") (net 17) (tstamp 54af9c1c-a518-441d-9b9d-32d3b79180c7))
  (segment (start 91.186 17.018) (end 91.313 17.018) (width 0.5) (layer "B.Cu") (net 17) (tstamp 54cb6668-a4cf-4ec5-bccd-d516de55585b))
  (segment (start 94.7175 43.0285) (end 96.6235 43.0285) (width 0.2) (layer "B.Cu") (net 17) (tstamp 65a6af1f-ddca-45a4-8aa6-9cce726e8674))
  (segment (start 78.994 74.041) (end 77.089 72.136) (width 0.5) (layer "B.Cu") (net 17) (tstamp 748630bf-0c4c-42dd-9c70-52402b4396f7))
  (segment (start 91.313 17.018) (end 93.726 19.431) (width 0.2) (layer "B.Cu") (net 17) (tstamp 7e14a8c1-c089-46fd-bc72-eb64dc8e3b35))
  (segment (start 87.7335 103.6085) (end 90.805 106.68) (width 0.25) (layer "B.Cu") (net 17) (tstamp 8591132e-45c5-40ec-96c3-9f5fe68336d9))
  (segment (start 93.726 19.431) (end 93.726 42.037) (width 0.2) (layer "B.Cu") (net 17) (tstamp 95d5df77-3523-40de-9445-827ffb77c0be))
  (segment (start 93.726 42.037) (end 94.7175 43.0285) (width 0.2) (layer "B.Cu") (net 17) (tstamp a113f803-3ccf-4c65-8786-d27a64f0f422))
  (segment (start 77.089 72.136) (end 73.787 72.136) (width 0.5) (layer "B.Cu") (net 17) (tstamp bc1b6b80-a3c4-4c85-9cf3-55dbf2498a7b))
  (segment (start 90.805 106.68) (end 90.805 108.712) (width 0.25) (layer "B.Cu") (net 17) (tstamp c3389122-934c-46d1-8087-a294ce3e3865))
  (segment (start 90.805 108.712) (end 87.376 112.141) (width 0.25) (layer "B.Cu") (net 17) (tstamp c59fea7b-ff94-4b15-95cd-9791fdc8f73a))
  (segment (start 77.216 58.039) (end 77.089 58.166) (width 0.5) (layer "B.Cu") (net 17) (tstamp e6bf72d7-d447-497c-9da9-e9499a511262))
  (segment (start 84.074 57.912) (end 83.693 57.531) (width 0.5) (layer "B.Cu") (net 17) (tstamp f558c2c7-8def-4fad-91eb-18341e3d3709))
  (segment (start 78.994 97.155) (end 78.994 74.041) (width 0.5) (layer "B.Cu") (net 17) (tstamp f6adf7bb-9060-4abc-9003-e257118a768d))
  (segment (start 74.041 29.083) (end 77.851 29.083) (width 0.2) (layer "F.Cu") (net 18) (tstamp 1ac530e3-8d4f-4f91-8bc4-d41fdba2211e))
  (segment (start 82.931 105.918) (end 81.259 105.918) (width 0.25) (layer "F.Cu") (net 18) (tstamp 35bb70c3-e2ae-4540-a299-72391f6201c3))
  (segment (start 79.629 101.346) (end 82.931 101.346) (width 0.25) (layer "F.Cu") (net 18) (tstamp 38cb6827-41a5-4195-a0f5-013b04496a52))
  (segment (start 83.947 102.362) (end 83.947 104.902) (width 0.25) (layer "F.Cu") (net 18) (tstamp 5b244cc4-460b-4897-b784-bd6f1c6c5773))
  (segment (start 78.867 100.584) (end 79.629 101.346) (width 0.25) (layer "F.Cu") (net 18) (tstamp 918eb238-6b85-4bd9-b3e3-562289fef8e7))
  (segment (start 77.851 29.083) (end 79 27.934) (width 0.2) (layer "F.Cu") (net 18) (tstamp 9ab6be05-0a04-475a-b514-308600b6aa1a))
  (segment (start 83.947 104.902) (end 82.931 105.918) (width 0.25) (layer "F.Cu") (net 18) (tstamp da19ca03-04da-426f-be54-27efeaf33ce7))
  (segment (start 82.931 101.346) (end 83.947 102.362) (width 0.25) (layer "F.Cu") (net 18) (tstamp dc100627-2764-4a44-9223-da77d90a6ee6))
  (segment (start 79 27.934) (end 79 26.55) (width 0.2) (layer "F.Cu") (net 18) (tstamp f04dc5ff-ccd5-4531-b45c-278de9b560d7))
  (via (at 74.041 29.083) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 18) (tstamp 17e2141f-79c4-4346-84b1-1a74a0069202))
  (via (at 78.867 100.584) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 18) (tstamp 7cb849b0-cca0-4033-9320-73ac7e6e0ff7))
  (segment (start 78.41948 75.11748) (end 78.41948 100.13648) (width 0.25) (layer "B.Cu") (net 18) (tstamp 016c3588-60d1-48de-ab1f-a5c9f76da4fd))
  (segment (start 76.708 73.406) (end 78.41948 75.11748) (width 0.25) (layer "B.Cu") (net 18) (tstamp 0ae7a295-5025-4d75-89e5-1a9dff7e5db6))
  (segment (start 72.39 72.644) (end 73.152 73.406) (width 0.25) (layer "B.Cu") (net 18) (tstamp 1651fb0f-b102-46d1-a763-d49670ae8fdd))
  (segment (start 74.041 29.083) (end 74.041 35.306) (width 0.2) (layer "B.Cu") (net 18) (tstamp 29c23d1d-04ba-4d09-9fd7-2f7896659e87))
  (segment (start 72.662489 47.450377) (end 72.39 47.722866) (width 0.25) (layer "B.Cu") (net 18) (tstamp 2adffee2-e6d9-46fd-82ab-23592bf66611))
  (segment (start 87.7335 107.6785) (end 85.4885 107.6785) (width 0.25) (layer "B.Cu") (net 18) (tstamp 2d3358fe-2e9f-4cad-a823-37be5aaff990))
  (segment (start 81.026 112.141) (end 79.756 112.141) (width 0.25) (layer "B.Cu") (net 18) (tstamp 42a52d89-5431-4eb8-9d34-dfc51864e637))
  (segment (start 85.4885 107.6785) (end 81.026 112.141) (width 0.25) (layer "B.Cu") (net 18) (tstamp 5b4c901e-aaa4-4169-9ea5-11c1a73b9b5c))
  (segment (start 72.39 47.722866) (end 72.39 72.644) (width 0.25) (layer "B.Cu") (net 18) (tstamp 84a43ba4-5d14-4d44-8359-df50d60c4cb9))
  (segment (start 73.152 73.406) (end 76.708 73.406) (width 0.25) (layer "B.Cu") (net 18) (tstamp 9938472f-0fb6-4376-a9f0-0a7dcf354cb6))
  (segment (start 85.4885 107.6785) (end 83.728 105.918) (width 0.25) (layer "B.Cu") (net 18) (tstamp bca2564a-31b7-4515-aad3-2f02ee2e4ebb))
  (segment (start 75.565 36.83) (end 75.565 44.547866) (width 0.2) (layer "B.Cu") (net 18) (tstamp bf4008e7-531b-4028-af77-f24c9a99f237))
  (segment (start 74.041 35.306) (end 75.565 36.83) (width 0.2) (layer "B.Cu") (net 18) (tstamp c04ef8c3-af2d-4671-9855-6da827f61bcf))
  (segment (start 78.41948 100.13648) (end 78.867 100.584) (width 0.25) (layer "B.Cu") (net 18) (tstamp c74bdf9c-c7b7-45e7-aa8b-3c19794af28b))
  (segment (start 83.728 105.918) (end 81.259 105.918) (width 0.25) (layer "B.Cu") (net 18) (tstamp d440b9c5-371b-4216-9b6a-091260908aed))
  (segment (start 75.565 44.547866) (end 72.662489 47.450377) (width 0.2) (layer "B.Cu") (net 18) (tstamp ec77a6a9-96e3-4070-acac-b30e0780302a))
  (segment (start 74 17.567) (end 74 18.533) (width 0.2) (layer "F.Cu") (net 19) (tstamp 2aa5d2fa-d751-4e08-b7a6-1018631c8414))
  (segment (start 75.438 21.082) (end 75.438 17.526) (width 0.2) (layer "F.Cu") (net 19) (tstamp 52d4930a-d014-43ef-ab27-f000c0d6bf45))
  (segment (start 74.295 17.272) (end 74 17.567) (width 0.2) (layer "F.Cu") (net 19) (tstamp 9280e215-bbb7-415f-a383-98a9b980885e))
  (segment (start 74 23.45) (end 74 22.52) (width 0.2) (layer "F.Cu") (net 19) (tstamp a81cdf12-83ec-4eca-a949-f347aa668637))
  (segment (start 75.184 17.272) (end 74.295 17.272) (width 0.2) (layer "F.Cu") (net 19) (tstamp c141f985-b81b-48e0-b599-91c315f6ce89))
  (segment (start 74 22.52) (end 75.438 21.082) (width 0.2) (layer "F.Cu") (net 19) (tstamp e71313c2-e0bc-434d-9de1-2ec53a801bf4))
  (segment (start 75.438 17.526) (end 75.184 17.272) (width 0.2) (layer "F.Cu") (net 19) (tstamp f15589d2-a9ac-4e0d-b453-52bc73a72687))
  (segment (start 83.891 20.581) (end 83.82 20.652) (width 0.2) (layer "F.Cu") (net 20) (tstamp 45ec31e9-5185-42b7-a86a-7ab1aa7deb37))
  (segment (start 83.82 20.652) (end 83.82 23.596) (width 0.2) (layer "F.Cu") (net 20) (tstamp e0284f3f-5ce6-4bee-a504-2c0ad8786e33))
  (segment (start 96.6235 47.4745) (end 96.6235 50.5285) (width 0.5) (layer "F.Cu") (net 21) (tstamp 08dcbe71-435e-443a-8403-82869d5ef8af))
  (segment (start 83.566 26.696) (end 85.191 28.321) (width 0.2) (layer "F.Cu") (net 21) (tstamp 1f7c3e69-3b4b-4071-a0f7-3f9815c90405))
  (segment (start 96.6235 50.5285) (end 91.821 55.331) (width 0.5) (layer "F.Cu") (net 21) (tstamp 20fb04e2-7e30-4b6d-88c6-33b48ae37256))
  (segment (start 89.916 28.321) (end 90.551 28.956) (width 0.2) (layer "F.Cu") (net 21) (tstamp 7db938ef-40f0-42e4-8822-79e638016717))
  (segment (start 91.821 55.331) (end 91.821 55.626) (width 0.5) (layer "F.Cu") (net 21) (tstamp 8a5b256f-5e1f-441b-83d7-dd20dbb04f2d))
  (segment (start 89.281 44.196) (end 93.345 44.196) (width 0.5) (layer "F.Cu") (net 21) (tstamp 9a614608-4f97-4ee8-a104-e4d214f83e33))
  (segment (start 93.345 44.196) (end 96.6235 47.4745) (width 0.5) (layer "F.Cu") (net 21) (tstamp ada1bc42-7f90-4024-a0a9-325d3629130a))
  (segment (start 85.191 28.321) (end 89.916 28.321) (width 0.2) (layer "F.Cu") (net 21) (tstamp b8eb21f5-f79c-465a-acc9-79b81ca7a20a))
  (via (at 90.551 28.956) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 21) (tstamp edb261fd-d6ed-4ccd-a437-0557a86d1f4b))
  (segment (start 90.551 28.956) (end 90.551 43.471489) (width 0.25) (layer "B.Cu") (net 21) (tstamp 65a52050-7f7f-4f3e-a164-02bc684999a2))
  (segment (start 89.826489 44.196) (end 89.281 44.196) (width 0.25) (layer "B.Cu") (net 21) (tstamp 9084ca8b-030d-4151-9c58-c131b7cede83))
  (segment (start 90.551 43.471489) (end 89.826489 44.196) (width 0.25) (layer "B.Cu") (net 21) (tstamp a028c090-df9c-42e9-b20a-e59fadf83822))
  (segment (start 33.528 39.37) (end 30.861 39.37) (width 0.5) (layer "F.Cu") (net 22) (tstamp 2413f7ee-5514-48ba-9ad4-549f04a0c474))
  (segment (start 38.481 41.127) (end 38.481 39.076) (width 0.5) (layer "F.Cu") (net 22) (tstamp 75913e5d-8e5b-499f-980c-12302cf84c6c))
  (segment (start 36.362 36.536) (end 33.528 39.37) (width 0.5) (layer "F.Cu") (net 22) (tstamp 90d26146-f52a-4e47-a407-f80233a2a1f5))
  (segment (start 41.021 36.536) (end 36.362 36.536) (width 0.5) (layer "F.Cu") (net 22) (tstamp d278fac3-68b5-43dc-a2c9-7118c94e4c9c))
  (segment (start 38.481 39.076) (end 41.021 36.536) (width 0.5) (layer "F.Cu") (net 22) (tstamp f38dac2f-b568-4fb0-a36e-52c361eb6a1a))
  (segment (start 165.989 28.956) (end 154.051 28.956) (width 5) (layer "F.Cu") (net 23) (tstamp d32f881d-dfde-456d-81b7-3add28f6c58b))
  (segment (start 154.051 41.021) (end 155.086 42.056) (width 5) (layer "F.Cu") (net 24) (tstamp 888c2d02-d326-4e79-810e-3f5f3eff1469))
  (segment (start 155.086 42.056) (end 165.981 42.056) (width 5) (layer "F.Cu") (net 24) (tstamp fd586e43-9e1d-444b-b262-8555b7254ce3))
  (segment (start 60.198 27.743006) (end 60.21652 27.724486) (width 0.2) (layer "F.Cu") (net 25) (tstamp 0ff92605-caad-4e09-8733-4d9dfd314713))
  (segment (start 60.579 30.988) (end 60.198 30.607) (width 0.2) (layer "F.Cu") (net 25) (tstamp 40dc6d1e-4476-45c5-a64d-26aac7969a51))
  (segment (start 58.547 20.447) (end 58.293 20.193) (width 0.2) (layer "F.Cu") (net 25) (tstamp 4dd76c54-4ccb-499a-bee6-4996eac2f458))
  (segment (start 60.198 30.607) (end 60.198 27.743006) (width 0.2) (layer "F.Cu") (net 25) (tstamp 7fd3238a-0f66-49b4-8466-4372b66409f6))
  (segment (start 59.495197 20.447) (end 58.547 20.447) (width 0.2) (layer "F.Cu") (net 25) (tstamp 853f745d-25db-45e5-a135-964849b64588))
  (segment (start 58.293 20.193) (end 58.293 18.751) (width 0.2) (layer "F.Cu") (net 25) (tstamp b5a5748c-e7d2-4461-9389-8a8dbc2b55e9))
  (segment (start 73.406 35.433) (end 73.279 35.306) (width 0.25) (layer "F.Cu") (net 25) (tstamp b80071bd-6664-4cde-8e98-61fa135589e5))
  (segment (start 60.21652 27.724486) (end 60.21652 21.168323) (width 0.2) (layer "F.Cu") (net 25) (tstamp d720e208-d0c6-4f51-989c-bebe1efb60ec))
  (segment (start 60.21652 21.168323) (end 59.495197 20.447) (width 0.2) (layer "F.Cu") (net 25) (tstamp d9ad7995-3e63-46e8-b761-9afd22d4a244))
  (segment (start 73.406 38.546) (end 73.406 35.433) (width 0.2) (layer "F.Cu") (net 25) (tstamp efc699f8-739b-419f-8aaa-b0569ef636ef))
  (via (at 73.279 35.306) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 25) (tstamp 9728c823-51b7-41fe-9d3a-6df0e9a84c3c))
  (via (at 60.579 30.988) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 25) (tstamp e106562a-68e2-48db-b6cb-155d6ed05b8f))
  (segment (start 71.501 33.528) (end 73.279 35.306) (width 0.2) (layer "B.Cu") (net 25) (tstamp 12b19173-0650-43d2-bfe9-643986085e83))
  (segment (start 61.586386 33.528) (end 71.501 33.528) (width 0.2) (layer "B.Cu") (net 25) (tstamp 30a13267-33e1-471c-ac70-d940a88c6f87))
  (segment (start 60.579 30.988) (end 60.056 30.465) (width 0.2) (layer "B.Cu") (net 25) (tstamp 432df691-384c-467d-9808-4c2ed7b5cc4e))
  (segment (start 60.579 30.988) (end 60.616489 31.025489) (width 0.25) (layer "B.Cu") (net 25) (tstamp 72146af4-f972-4179-a22c-7f00a39ad368))
  (segment (start 60.616489 31.025489) (end 60.616489 32.558103) (width 0.2) (layer "B.Cu") (net 25) (tstamp 8afd6f26-6138-4c42-9883-946c6d388fb9))
  (segment (start 60.056 30.465) (end 54.488 30.465) (width 0.2) (layer "B.Cu") (net 25) (tstamp ad245961-ec58-4bea-ab69-3838a6d02db9))
  (segment (start 60.616489 32.558103) (end 61.586386 33.528) (width 0.2) (layer "B.Cu") (net 25) (tstamp d384e72e-0b5b-4faf-a3a4-98c8e8880780))
  (segment (start 59.817 21.336) (end 59.32752 20.84652) (width 0.2) (layer "F.Cu") (net 26) (tstamp 05ff5189-d1f1-4358-ba79-06ee3b0233b2))
  (segment (start 59.32752 20.84652) (end 57.67652 20.84652) (width 0.2) (layer "F.Cu") (net 26) (tstamp 221a8e15-c854-42ba-b00b-bb9c6bfcbbb8))
  (segment (start 72.263 38.419) (end 72.263 35.814) (width 0.2) (layer "F.Cu") (net 26) (tstamp 3af78453-b0d0-4f5a-ace1-0f8acd80f7b8))
  (segment (start 57.67652 20.84652) (end 57.023 20.193) (width 0.2) (layer "F.Cu") (net 26) (tstamp 4d078828-ff79-4eb9-994e-acce60bf7a9a))
  (segment (start 59.817 27.559) (end 58.308 29.068) (width 0.2) (layer "F.Cu") (net 26) (tstamp 5da0452e-0c5f-4759-94e6-4c02301edc67))
  (segment (start 58.308 29.068) (end 58.308 33.005) (width 0.2) (layer "F.Cu") (net 26) (tstamp b1b25488-0ae2-475e-bbbd-3a5ffedeb58b))
  (segment (start 59.817 27.559) (end 59.817 21.336) (width 0.2) (layer "F.Cu") (net 26) (tstamp b283df19-7e57-4c61-b6e9-c7bc5fa84171))
  (segment (start 57.023 20.193) (end 57.023 18.751) (width 0.2) (layer "F.Cu") (net 26) (tstamp c15ec4fd-8449-4287-b958-c2566c4a16b7))
  (segment (start 72.136 38.546) (end 72.263 38.419) (width 0.25) (layer "F.Cu") (net 26) (tstamp e5e59526-b874-4347-a7b5-b68034961665))
  (via (at 58.308 33.005) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 26) (tstamp c7c6bed1-5a03-4670-a5ea-b91d69e1cbcd))
  (via (at 72.263 35.814) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 26) (tstamp f48b37f4-c2f1-411d-bcda-3df0a315ea2d))
  (segment (start 60.833 34.29) (end 59.548 33.005) (width 0.2) (layer "B.Cu") (net 26) (tstamp 3f0298e6-d800-4aac-9bb7-d906c52754ba))
  (segment (start 72.263 35.814) (end 70.739 34.29) (width 0.2) (layer "B.Cu") (net 26) (tstamp 606f2467-426d-45aa-a105-7bbdd6efcf56))
  (segment (start 70.739 34.29) (end 60.833 34.29) (width 0.2) (layer "B.Cu") (net 26) (tstamp 80f5857e-2246-42a7-b1ba-41caa9f92d78))
  (segment (start 59.548 33.005) (end 58.308 33.005) (width 0.2) (layer "B.Cu") (net 26) (tstamp 8c2d96aa-9232-4a99-bc22-6d0844acb01d))
  (segment (start 58.308 33.005) (end 54.488 33.005) (width 0.2) (layer "B.Cu") (net 26) (tstamp bd930ab4-9c90-4b71-b58f-5a55550dacbc))
  (segment (start 74.803 41.5935) (end 73.8495 41.5935) (width 0.2) (layer "F.Cu") (net 27) (tstamp 0389078e-806a-41db-af53-352913d5356e))
  (segment (start 57.023 27.813) (end 57.023 22.651) (width 0.2) (layer "F.Cu") (net 27) (tstamp 143ff65c-7e3e-4e3c-a440-1fe9afa70356))
  (segment (start 57.023 27.813) (end 57.023 34.29) (width 0.2) (layer "F.Cu") (net 27) (tstamp 2746d5d1-5f3c-4e4d-9e3e-05446843f7a8))
  (segment (start 57.023 34.29) (end 56.896 34.417) (width 0.25) (layer "F.Cu") (net 27) (tstamp 277a4a1b-9b61-4e34-b4cc-0e5b3580697e))
  (segment (start 73.8495 41.5935) (end 73.406 42.037) (width 0.2) (layer "F.Cu") (net 27) (tstamp 75acbe92-1ba7-4ae1-b357-83df14f5edbb))
  (segment (start 56.911 27.925) (end 54.488 27.925) (width 0.2) (layer "F.Cu") (net 27) (tstamp 9efdee0d-2377-4bca-bf07-1a995696978e))
  (segment (start 57.023 27.813) (end 56.911 27.925) (width 0.2) (layer "F.Cu") (net 27) (tstamp a09ec3f6-31b5-426d-9214-de5a6b441993))
  (segment (start 73.406 42.037) (end 73.406 43.496) (width 0.2) (layer "F.Cu") (net 27) (tstamp ed4a373d-3bf7-424d-a136-9893670a3814))
  (via (at 56.896 34.417) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 27) (tstamp 389768f5-bf74-43b3-913f-c2493989890b))
  (via (at 74.803 41.5935) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 27) (tstamp 5328b6c0-cbb3-4d8e-a1f2-ab59d6e5984b))
  (segment (start 70.231 35.052) (end 57.531 35.052) (width 0.2) (layer "B.Cu") (net 27) (tstamp 90bd5ac0-2e80-4ddf-84fe-d561b8d96fe1))
  (segment (start 57.531 35.052) (end 56.896 34.417) (width 0.2) (layer "B.Cu") (net 27) (tstamp a5ef5571-de4b-45d6-b7c7-ff8dc0831e4b))
  (segment (start 74.803 39.624) (end 70.231 35.052) (width 0.2) (layer "B.Cu") (net 27) (tstamp f3655511-8022-493b-a40b-7a2f5c838b33))
  (segment (start 74.803 39.624) (end 74.803 41.5935) (width 0.2) (layer "B.Cu") (net 27) (tstamp f8b438f9-d6f5-46c5-9f14-cbed08c9313d))
  (segment (start 70.104011 84.282578) (end 70.104011 82.747005) (width 0.2) (layer "F.Cu") (net 28) (tstamp 0e08efce-8e7a-4cc4-a238-b05eddf3d61a))
  (segment (start 68.579999 103.482266) (end 69.758998 102.303267) (width 0.2) (layer "F.Cu") (net 28) (tstamp 35c8804b-394d-4b8f-a172-c1bd4b3efcf7))
  (segment (start 45.579983 72.854011) (end 40.937989 72.854011) (width 0.2) (layer "F.Cu") (net 28) (tstamp 3b4fc58d-8849-43d0-a84d-ffeba09169aa))
  (segment (start 55.982081 71.68091) (end 46.753084 71.68091) (width 0.2) (layer "F.Cu") (net 28) (tstamp 3cedcf36-f957-4232-aff9-0c7a379814e3))
  (segment (start 69.758998 102.303267) (end 69.758998 84.627591) (width 0.2) (layer "F.Cu") (net 28) (tstamp 463a7ff7-48c9-488d-9f09-9d04b3581cd9))
  (segment (start 56.307531 72.00636) (end 55.982081 71.68091) (width 0.2) (layer "F.Cu") (net 28) (tstamp 465b6d60-5bef-4435-baad-edfa2aa20865))
  (segment (start 73.52768 136.895654) (end 68.326 131.693974) (width 0.25) (layer "F.Cu") (net 28) (tstamp 4a26f094-06b4-44bc-9ab4-ecf9ea6263b1))
  (segment (start 73.52768 145.16632) (end 73.52768 136.895654) (width 0.25) (layer "F.Cu") (net 28) (tstamp 61520394-029a-4237-a62c-9f126ddd5d6a))
  (segment (start 68.326 103.736263) (end 68.579999 103.482266) (width 0.25) (layer "F.Cu") (net 28) (tstamp 71cf8197-6bb6-4752-9a3a-fbc93648a712))
  (segment (start 46.753084 71.68091) (end 45.579983 72.854011) (width 0.2) (layer "F.Cu") (net 28) (tstamp 725140ed-86f0-4118-b175-6dc99f34752f))
  (segment (start 40.937989 72.854011) (end 40.259 73.533) (width 0.2) (layer "F.Cu") (net 28) (tstamp 79f71020-e8b8-49bd-b8ca-7fa151a7a2d4))
  (segment (start 69.758998 84.627591) (end 70.104011 84.282578) (width 0.2) (layer "F.Cu") (net 28) (tstamp a8253a63-9306-4744-908f-3f37f677099b))
  (segment (start 68.326 131.693974) (end 68.326 103.736263) (width 0.25) (layer "F.Cu") (net 28) (tstamp ac8bf44e-c868-4af0-b2c5-f181b8cfb34b))
  (segment (start 70.104011 82.747005) (end 59.363366 72.00636) (width 0.2) (layer "F.Cu") (net 28) (tstamp c6b96238-f730-4b9e-8b92-5e28338d872c))
  (segment (start 40.259 73.533) (end 40.259 74.142) (width 0.2) (layer "F.Cu") (net 28) (tstamp e9d8ae49-bac6-4594-a87d-692592b74f1f))
  (segment (start 59.363366 72.00636) (end 56.307531 72.00636) (width 0.2) (layer "F.Cu") (net 28) (tstamp f3a25be3-ba25-4c8b-bbac-25e71885beab))
  (segment (start 68.961 149.733) (end 73.52768 145.16632) (width 0.25) (layer "F.Cu") (net 28) (tstamp fbd410fc-1ff9-44d7-ba5c-8abf21c029c9))
  (segment (start 68.961 158.3785) (end 68.961 149.733) (width 0.25) (layer "F.Cu") (net 28) (tstamp fd9f8a19-a619-470e-81e6-00ae3cf92d6b))
  (segment (start 67.87648 131.880171) (end 67.87648 103.550067) (width 0.25) (layer "F.Cu") (net 29) (tstamp 176c9330-6d4a-43d0-bb5d-71e8558e9681))
  (segment (start 67.6656 152.0444) (end 67.6656 150.392682) (width 0.25) (layer "F.Cu") (net 29) (tstamp 23389e96-4de0-4dbd-9ea8-1f1040af878c))
  (segment (start 61.341 83.693) (end 60.452 84.582) (width 0.25) (layer "F.Cu") (net 29) (tstamp 2c1494ff-7783-4a7b-9158-7704a77cbb85))
  (segment (start 73.07816 137.081852) (end 67.87648 131.880171) (width 0.25) (layer "F.Cu") (net 29) (tstamp 2d20ef58-72bf-4789-a313-df03d3499025))
  (segment (start 60.452 84.582) (end 52.858 84.582) (width 0.25) (layer "F.Cu") (net 29) (tstamp 2d43f63e-4930-4504-8fce-47f91aac5e40))
  (segment (start 69.359478 84.462105) (end 69.359478 102.067068) (width 0.2) (layer "F.Cu") (net 29) (tstamp 4d1b147f-353b-439e-bda7-ecfe784d81a7))
  (segment (start 65.613817 83.693) (end 61.341 83.693) (width 0.25) (layer "F.Cu") (net 29) (tstamp 6c4b2a13-feb8-4471-bac8-2f7ed945c9eb))
  (segment (start 69.5545 84.267083) (end 69.359478 84.462105) (width 0.2) (layer "F.Cu") (net 29) (tstamp 72c9875a-41e8-401e-ada0-a6253698d9f6))
  (segment (start 67.6656 152.0444) (end 67.691 152.0698) (width 0.2) (layer "F.Cu") (net 29) (tstamp 83756611-b528-4a05-bd11-37ab9dd9e0d8))
  (segment (start 73.07816 144.980122) (end 73.07816 137.081852) (width 0.25) (layer "F.Cu") (net 29) (tstamp ac3b1392-5b7e-4783-81c2-8002e30d9229))
  (segment (start 67.87648 103.550067) (end 68.13048 103.296066) (width 0.25) (layer "F.Cu") (net 29) (tstamp ae621d7b-2b93-492a-82a4-6be4a4a1c8aa))
  (segment (start 69.359478 102.067068) (end 68.13048 103.296066) (width 0.2) (layer "F.Cu") (net 29) (tstamp af3ba21b-d42c-4819-89bd-e01a8f853f45))
  (segment (start 67.6656 150.392682) (end 73.07816 144.980122) (width 0.25) (layer "F.Cu") (net 29) (tstamp d39c2844-f2dd-4117-afba-f4efa76a0c33))
  (segment (start 67.691 159.6485) (end 68.961 160.9185) (width 0.2) (layer "F.Cu") (net 29) (tstamp d8f0de1d-9634-4c8b-827b-f76216e95811))
  (segment (start 67.691 152.0698) (end 67.691 159.6485) (width 0.2) (layer "F.Cu") (net 29) (tstamp da4b8917-900a-4efe-887f-748f2011e99b))
  (segment (start 69.5545 83.693) (end 69.5545 84.267083) (width 0.2) (layer "F.Cu") (net 29) (tstamp fc75b393-b9ae-455a-b39c-cbc2ee453439))
  (via (at 69.5545 83.693) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 29) (tstamp 3e2a0fb6-38af-4460-b6cb-8419f5ef2818))
  (via (at 65.613817 83.693) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 29) (tstamp d43f26b1-0e69-4aa7-89c6-341a05a63fd6))
  (segment (start 69.5545 83.693) (end 65.613817 83.693) (width 0.25) (layer "B.Cu") (net 29) (tstamp c815fb35-c4a1-4d89-b620-7899720c1808))
  (segment (start 69.342 83.143489) (end 69.342 82.55) (width 0.2) (layer "F.Cu") (net 30) (tstamp 069dc59d-a032-49cc-a545-665e3ef84c7e))
  (segment (start 72.62864 137.26805) (end 67.42696 132.066368) (width 0.25) (layer "F.Cu") (net 30) (tstamp 103a2360-efd3-41dd-ae18-72537d8571ca))
  (segment (start 56.142045 72.40588) (end 55.816594 72.080429) (width 0.2) (layer "F.Cu") (net 30) (tstamp 10943483-1191-4e18-8c79-e2664642b10a))
  (segment (start 67.42696 132.066368) (end 67.42696 103.363869) (width 0.25) (layer "F.Cu") (net 30) (tstamp 21475640-6c75-4527-8fe5-57ac40a25737))
  (segment (start 55.816594 72.080429) (end 46.918571 72.080429) (width 0.2) (layer "F.Cu") (net 30) (tstamp 3d503964-6c5c-45e1-925b-ec757e8af2ba))
  (segment (start 44.857 74.142) (end 44.069 74.142) (width 0.2) (layer "F.Cu") (net 30) (tstamp 55ee8d22-ed78-4fb0-8239-2fb7f28021b6))
  (segment (start 69.004989 83.465384) (end 69.326884 83.143489) (width 0.2) (layer "F.Cu") (net 30) (tstamp 6e646ff0-c0ad-4752-a125-4eff51f5df15))
  (segment (start 68.959958 84.296619) (end 69.004989 84.251588) (width 0.2) (layer "F.Cu") (net 30) (tstamp 942b46ae-fa81-4c2d-92ad-d7492e958730))
  (segment (start 66.421 151.001564) (end 72.62864 144.793924) (width 0.25) (layer "F.Cu") (net 30) (tstamp 965010bc-9bfb-4cb9-91fd-5e600a0edece))
  (segment (start 68.959958 101.830871) (end 68.959958 84.296619) (width 0.2) (layer "F.Cu") (net 30) (tstamp a069592e-04b5-4bdc-9477-42027b988261))
  (segment (start 67.68096 103.109869) (end 68.959958 101.830871) (width 0.2) (layer "F.Cu") (net 30) (tstamp a207cd06-f193-4ece-bf83-6c6964a34315))
  (segment (start 46.918571 72.080429) (end 44.857 74.142) (width 0.2) (layer "F.Cu") (net 30) (tstamp a75c6d9a-7f0d-4f91-84fa-3a86be46fdba))
  (segment (start 67.42696 103.363869) (end 67.68096 103.109869) (width 0.25) (layer "F.Cu") (net 30) (tstamp b21c9e2b-aab5-40dc-873e-7fa55cefb423))
  (segment (start 44.984 74.142) (end 44.069 74.142) (width 0.25) (layer "F.Cu") (net 30) (tstamp b890f310-cd74-4926-8acf-d4c80ffc5d27))
  (segment (start 66.421 158.3785) (end 66.421 151.001564) (width 0.25) (layer "F.Cu") (net 30) (tstamp c484b684-e867-403d-bcf3-cab1dcc8b067))
  (segment (start 72.62864 144.793924) (end 72.62864 137.26805) (width 0.25) (layer "F.Cu") (net 30) (tstamp c779014f-7f5f-4830-9c33-ce67ba475f5b))
  (segment (start 69.326884 83.143489) (end 69.342 83.143489) (width 0.2) (layer "F.Cu") (net 30) (tstamp cb4b6de3-76de-44ee-9e0b-723fa67db349))
  (segment (start 59.19788 72.40588) (end 56.142045 72.40588) (width 0.2) (layer "F.Cu") (net 30) (tstamp dd1ae135-e49c-4d8d-b00a-e8ea143b34dd))
  (segment (start 69.342 82.55) (end 59.19788 72.40588) (width 0.2) (layer "F.Cu") (net 30) (tstamp e96fb6ec-3e01-467e-9940-13d27a056362))
  (segment (start 69.004989 84.251588) (end 69.004989 83.465384) (width 0.2) (layer "F.Cu") (net 30) (tstamp fca108c8-1d87-4156-b433-ec5495b10179))
  (segment (start 68.605469 84.086102) (end 68.560438 84.131133) (width 0.2) (layer "F.Cu") (net 31) (tstamp 00cc2c74-fbf7-4be8-ba82-f43ba6c5fbc4))
  (segment (start 65.3635 82.993497) (end 59.879815 82.993497) (width 0.25) (layer "F.Cu") (net 31) (tstamp 32a86cf1-fb14-448d-989d-e186e5e597f0))
  (segment (start 65.151 159.6485) (end 65.151 153.266472) (width 0.2) (layer "F.Cu") (net 31) (tstamp 535179bd-25ef-4a9e-9050-ae9c575be8ff))
  (segment (start 66.97744 132.252565) (end 66.97744 103.177671) (width 0.25) (layer "F.Cu") (net 31) (tstamp 5ca5ea1d-cdda-429a-860a-58dbba13852b))
  (segment (start 68.605469 83.087792) (end 68.605469 84.086102) (width 0.2) (layer "F.Cu") (net 31) (tstamp 6b668a65-d05d-4caf-a56e-fa61871d174f))
  (segment (start 68.710429 82.982832) (end 68.605469 83.087792) (width 0.2) (layer "F.Cu") (net 31) (tstamp 7bbff9ce-fd22-4f60-9f7c-8ff1e8e77128))
  (segment (start 72.17912 144.607726) (end 72.17912 137.454248) (width 0.25) (layer "F.Cu") (net 31) (tstamp 8a0e9b01-f5d0-4180-bd40-fdbed81242b3))
  (segment (start 66.421 160.9185) (end 65.151 159.6485) (width 0.2) (layer "F.Cu") (net 31) (tstamp b184bbcb-2843-427b-85b2-95bdb8d37211))
  (segment (start 68.560438 101.594674) (end 67.23144 102.923672) (width 0.2) (layer "F.Cu") (net 31) (tstamp b59e5cbe-ff05-4753-870f-03861e6bb3c6))
  (segment (start 65.1764 151.610446) (end 72.17912 144.607726) (width 0.25) (layer "F.Cu") (net 31) (tstamp c31a6135-a486-47e9-a7ba-c3f1a04f5ebf))
  (segment (start 68.560438 84.131133) (end 68.560438 101.594674) (width 0.2) (layer "F.Cu") (net 31) (tstamp cc0e3841-0bb3-4975-b9d1-aa766d21b806))
  (segment (start 65.151 153.266472) (end 65.1764 153.241072) (width 0.2) (layer "F.Cu") (net 31) (tstamp d08311b7-66f0-435e-9063-d30d348f4d44))
  (segment (start 59.690318 82.804) (end 58.573 82.804) (width 0.25) (layer "F.Cu") (net 31) (tstamp e6ea40a5-2eb1-4b9e-a9ea-ae56d06a28c0))
  (segment (start 72.17912 137.454248) (end 66.97744 132.252565) (width 0.25) (layer "F.Cu") (net 31) (tstamp f00de355-3d0d-414c-b197-67376b2a8920))
  (segment (start 66.97744 103.177671) (end 67.23144 102.923672) (width 0.25) (layer "F.Cu") (net 31) (tstamp f8d22521-329e-4974-b51f-247ac453bd84))
  (segment (start 65.1764 153.241072) (end 65.1764 151.610446) (width 0.25) (layer "F.Cu") (net 31) (tstamp fe1d017c-61de-4cae-8b2c-7adec136d3d1))
  (segment (start 59.879815 82.993497) (end 59.690318 82.804) (width 0.25) (layer "F.Cu") (net 31) (tstamp ffd1f88f-bc5c-4df1-96be-3acba692330e))
  (via (at 68.710429 82.982832) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 31) (tstamp 1a57dca4-f960-4f09-ad91-3ce3151b6f17))
  (via (at 65.3635 82.993497) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 31) (tstamp 87181dba-daae-491c-86f5-c5ae3e83cb48))
  (segment (start 65.428003 83.058) (end 65.3635 82.993497) (width 0.2) (layer "B.Cu") (net 31) (tstamp 565e185a-2fa1-4434-869b-63367a075ab4))
  (segment (start 68.635261 83.058) (end 65.428003 83.058) (width 0.2) (layer "B.Cu") (net 31) (tstamp 573f6b55-2e29-4707-a9f2-8d800e3bc4bc))
  (segment (start 68.710429 82.982832) (end 68.635261 83.058) (width 0.2) (layer "B.Cu") (net 31) (tstamp c461b55a-d4d5-4ca9-9594-314231794601))
  (segment (start 71.7296 144.421528) (end 71.7296 137.640446) (width 0.25) (layer "F.Cu") (net 32) (tstamp 07074b6b-1b19-4291-9a75-cc53339fae9b))
  (segment (start 55.651108 72.479949) (end 55.976559 72.8054) (width 0.2) (layer "F.Cu") (net 32) (tstamp 341c7977-9413-4523-a222-88749ccc200f))
  (segment (start 55.976559 72.8054) (end 58.9624 72.8054) (width 0.2) (layer "F.Cu") (net 32) (tstamp 35684313-fb66-4e3c-bece-d0f9c1b23ed3))
  (segment (start 66.52792 132.438762) (end 66.52792 102.991473) (width 0.25) (layer "F.Cu") (net 32) (tstamp 37fba0f8-da34-4673-8d1b-634174acd03f))
  (segment (start 45.974 73.590006) (end 47.084057 72.479949) (width 0.2) (layer "F.Cu") (net 32) (tstamp 3a75c054-b8f3-498c-9c49-2f2c94afc2d7))
  (segment (start 58.9624 72.8054) (end 68.160918 82.003918) (width 0.2) (layer "F.Cu") (net 32) (tstamp 44a328e1-dd4e-4a81-91f1-086b454083e4))
  (segment (start 66.52792 102.991473) (end 66.7258 102.793593) (width 0.25) (layer "F.Cu") (net 32) (tstamp 7e7818e8-424b-4610-80dc-d8871f15630a))
  (segment (start 45.974 80.137) (end 45.974 73.590006) (width 0.2) (layer "F.Cu") (net 32) (tstamp 815f60be-d3b9-4097-8a42-2cb5f7393b6f))
  (segment (start 63.881 152.270128) (end 71.7296 144.421528) (width 0.25) (layer "F.Cu") (net 32) (tstamp 880c466a-6b81-4de5-ad8e-ffb905082775))
  (segment (start 46.355 80.518) (end 45.974 80.137) (width 0.2) (layer "F.Cu") (net 32) (tstamp 8ded7944-2a2c-4e19-8526-973c418f6bf5))
  (segment (start 47.084057 72.479949) (end 55.651108 72.479949) (width 0.2) (layer "F.Cu") (net 32) (tstamp 9319347c-0afa-4209-8228-ac35543f16fc))
  (segment (start 46.889 80.518) (end 46.355 80.518) (width 0.2) (layer "F.Cu") (net 32) (tstamp 9ee7fcd9-4048-47f1-9ad5-3ef24dea4153))
  (segment (start 63.881 158.3785) (end 63.881 152.270128) (width 0.25) (layer "F.Cu") (net 32) (tstamp b12caec7-a4ec-4a3c-a8a0-0584c8610245))
  (segment (start 71.7296 137.640446) (end 66.52792 132.438762) (width 0.25) (layer "F.Cu") (net 32) (tstamp b48dba19-a0db-4b61-b237-af29bc7c52dc))
  (segment (start 68.160918 101.358475) (end 66.7258 102.793593) (width 0.2) (layer "F.Cu") (net 32) (tstamp b85a447a-c734-4751-b235-3f075c14f853))
  (segment (start 68.160918 82.003918) (end 68.160918 101.358475) (width 0.2) (layer "F.Cu") (net 32) (tstamp edcb6423-ecb3-4891-a2d1-16f5c2e30c93))
  (segment (start 58.535458 73.60444) (end 67.361878 82.43086) (width 0.2) (layer "F.Cu") (net 33) (tstamp 0f841fbf-18ee-4b1a-96fc-d030c4a8ed53))
  (segment (start 61.341 153.538692) (end 70.83056 144.049132) (width 0.25) (layer "F.Cu") (net 33) (tstamp 2698b395-9b46-4d52-a007-50a56e30f4e1))
  (segment (start 65.62888 102.619079) (end 65.82676 102.421198) (width 0.25) (layer "F.Cu") (net 33) (tstamp 319e241c-05fc-4c15-bd25-36fced33fd34))
  (segment (start 54.890384 73.304469) (end 55.345616 73.304469) (width 0.2) (layer "F.Cu") (net 33) (tstamp 39f1cd9b-0e38-46cc-b3bf-f0a1e3af7ecc))
  (segment (start 70.83056 138.012842) (end 65.62888 132.811161) (width 0.25) (layer "F.Cu") (net 33) (tstamp 5c485ca0-d4ed-4531-bce2-a11e1ef3d8ca))
  (segment (start 65.62888 132.811161) (end 65.62888 102.619079) (width 0.25) (layer "F.Cu") (net 33) (tstamp 5f7f1b6d-bcc6-4b70-a7f7-5e266c9c0ac7))
  (segment (start 67.361878 82.43086) (end 67.361878 100.913122) (width 0.2) (layer "F.Cu") (net 33) (tstamp 7adf3990-27a7-4829-a9cc-e313b39b1ae9))
  (segment (start 55.345616 73.304469) (end 55.645587 73.60444) (width 0.2) (layer "F.Cu") (net 33) (tstamp 7db55a08-c958-48d8-869f-613514f45687))
  (segment (start 55.645587 73.60444) (end 58.535458 73.60444) (width 0.2) (layer "F.Cu") (net 33) (tstamp 96ada233-5946-4ac8-aeae-b180c423befa))
  (segment (start 54.356 73.838853) (end 54.890384 73.304469) (width 0.2) (layer "F.Cu") (net 33) (tstamp c7a96fed-863c-4932-9dfb-88d7204c7554))
  (segment (start 65.853802 102.421198) (end 65.82676 102.421198) (width 0.2) (layer "F.Cu") (net 33) (tstamp cf7f17b2-f82f-41ef-a0fd-702a11aacca3))
  (segment (start 61.341 158.3785) (end 61.341 153.538692) (width 0.25) (layer "F.Cu") (net 33) (tstamp d62ef56f-e4d9-46d9-8ea6-94d74a009d30))
  (segment (start 54.356 76.073) (end 53.721 76.708) (width 0.2) (layer "F.Cu") (net 33) (tstamp de00260c-7f32-43f5-a795-9b9bd639dd16))
  (segment (start 53.721 76.708) (end 52.731 76.708) (width 0.2) (layer "F.Cu") (net 33) (tstamp e3ef3eef-a2da-446a-b42d-6cdeea7c800c))
  (segment (start 67.361878 100.913122) (end 65.853802 102.421198) (width 0.2) (layer "F.Cu") (net 33) (tstamp e96dbf02-0b06-4898-865f-0b4dd4c4906d))
  (segment (start 70.83056 144.049132) (end 70.83056 138.012842) (width 0.25) (layer "F.Cu") (net 33) (tstamp ee667ee3-9fb3-4787-8641-49015fbf1da1))
  (segment (start 54.356 73.85398) (end 54.356 73.838853) (width 0.2) (layer "F.Cu") (net 33) (tstamp f3037e83-cbb4-44a5-8d3d-a262a288adfc))
  (segment (start 54.356 75.3525) (end 54.356 76.073) (width 0.2) (layer "F.Cu") (net 33) (tstamp f61123f2-7bde-4c34-833f-1b4af322db15))
  (via (at 54.356 73.85398) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 33) (tstamp 67380def-b8d9-4052-ba10-abd551881df3))
  (via (at 54.356 75.3525) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 33) (tstamp 6c8468a5-ad11-4f9f-bef5-08d20fc80b1c))
  (segment (start 54.356 73.85398) (end 54.356 75.3525) (width 0.2) (layer "B.Cu") (net 33) (tstamp 60ffd647-65f6-4784-99be-254a7bd1c681))
  (segment (start 70.38104 143.74096) (end 70.38104 138.19904) (width 0.25) (layer "F.Cu") (net 34) (tstamp 00761f46-5540-4479-a629-2ab8a77b6114))
  (segment (start 55.118 75.3525) (end 55.118 75.876006) (width 0.2) (layer "F.Cu") (net 34) (tstamp 06be24c4-ffbf-4c36-bf3e-5028f4f4ca36))
  (segment (start 65.17936 102.432882) (end 65.37724 102.235) (width 0.25) (layer "F.Cu") (net 34) (tstamp 0f0e25e0-b585-4d65-aa94-7677a42460ce))
  (segment (start 65.17936 132.997358) (end 65.17936 102.432882) (width 0.25) (layer "F.Cu") (net 34) (tstamp 26277b05-bd4b-47c2-b1ef-d0e1c416f393))
  (segment (start 70.38104 138.19904) (end 65.17936 132.997358) (width 0.25) (layer "F.Cu") (net 34) (tstamp 2e401322-3f89-49b1-bf3e-020c33f31567))
  (segment (start 55.26798 74.00396) (end 58.369972 74.00396) (width 0.2) (layer "F.Cu") (net 34) (tstamp 3fcf8dde-aaf2-4f25-979e-9d034af89bb8))
  (segment (start 58.369972 74.00396) (end 66.962358 82.596346) (width 0.2) (layer "F.Cu") (net 34) (tstamp 3fff61fa-3b7d-46e4-bd02-e8da39a20bb6))
  (segment (start 54.356 76.638006) (end 54.356 78.893) (width 0.2) (layer "F.Cu") (net 34) (tstamp 534fafd0-3aa8-4d2f-a19b-b930dbca7ee1))
  (segment (start 66.962358 82.596346) (end 66.962358 100.677642) (width 0.2) (layer "F.Cu") (net 34) (tstamp 6c82b5c2-c822-4c77-a573-ea77c74e37a8))
  (segment (start 65.405 102.235) (end 65.37724 102.235) (width 0.2) (layer "F.Cu") (net 34) (tstamp 7981dc4a-2c71-4207-903f-56e9819f1de6))
  (segment (start 61.341 160.9185) (end 59.944 159.5215) (width 0.25) (layer "F.Cu") (net 34) (tstamp 91f2d6a0-7c1a-4c0e-8ea2-a081909bc9c7))
  (segment (start 55.118 75.876006) (end 54.356 76.638006) (width 0.2) (layer "F.Cu") (net 34) (tstamp 98687b19-f7c2-483e-809b-438e9d5895fb))
  (segment (start 54.356 78.893) (end 52.731 80.518) (width 0.2) (layer "F.Cu") (net 34) (tstamp ab825bef-6a32-4842-8c0f-572b36408a77))
  (segment (start 59.944 154.178) (end 70.38104 143.74096) (width 0.25) (layer "F.Cu") (net 34) (tstamp af874d1c-9c41-4cfb-8014-5674f8dce032))
  (segment (start 66.962358 100.677642) (end 65.405 102.235) (width 0.2) (layer "F.Cu") (net 34) (tstamp c00af5a1-710f-4dd1-85cf-dcbc4568ebc0))
  (segment (start 59.944 159.5215) (end 59.944 154.178) (width 0.25) (layer "F.Cu") (net 34) (tstamp dfe1aa15-6dde-41e2-a1b7-7f71eac7aa08))
  (segment (start 55.118 73.85398) (end 55.26798 74.00396) (width 0.2) (layer "F.Cu") (net 34) (tstamp e7fb8bac-b189-47b4-a80b-fbae8393a1fb))
  (via (at 55.118 73.85398) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 34) (tstamp 39aed184-eea0-444d-a3a7-b21eeee407ec))
  (via (at 55.118 75.3525) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 34) (tstamp cfab5b30-bcd1-4a4d-8609-c520ddf72936))
  (segment (start 55.118 73.85398) (end 55.118 75.3525) (width 0.2) (layer "B.Cu") (net 34) (tstamp 0a5f3011-2cd4-45a0-9e54-85681f55bb28))
  (segment (start 21.463 59.436) (end 19.894 59.436) (width 0.2) (layer "F.Cu") (net 35) (tstamp 0861f41b-d100-48ca-94f9-c7edb07e4b15))
  (segment (start 31.64152 72.87948) (end 33.12848 71.39252) (width 0.2) (layer "F.Cu") (net 35) (tstamp 0912f33b-5667-4917-9829-01ce961456b3))
  (segment (start 36.68448 63.22748) (end 22.46048 63.22748) (width 0.2) (layer "F.Cu") (net 35) (tstamp 1810c86e-ae46-4271-a6cf-0b5e41dec5a1))
  (segment (start 22.098 60.071) (end 21.463 59.436) (width 0.2) (layer "F.Cu") (net 35) (tstamp 1a3da88c-63a7-4005-99cf-6f9e0822022d))
  (segment (start 36.422508 71.39252) (end 37.102519 70.712509) (width 0.2) (layer "F.Cu") (net 35) (tstamp 29f2480a-a59a-4a2a-ae58-e361eac3c35c))
  (segment (start 31.64152 82.889152) (end 31.64152 72.87948) (width 0.2) (layer "F.Cu") (net 35) (tstamp 2d1cd8e6-883e-44bf-9856-b7cfb503f94a))
  (segment (start 38.633259 63.839489) (end 39.328489 63.839489) (width 0.2) (layer "F.Cu") (net 35) (tstamp 36db6922-b729-4391-92ab-69d1a734b335))
  (segment (start 39.328489 63.839489) (end 39.403955 63.914955) (width 0.2) (layer "F.Cu") (net 35) (tstamp 3968218a-7567-4bdc-84f1-31abbb9da4f6))
  (segment (start 44.356955 63.59306) (end 44.356955 60.418045) (width 0.2) (layer "F.Cu") (net 35) (tstamp 3d1bdf17-ac61-4f46-b86b-ea52a0706e51))
  (segment (start 45.93048 58.84452) (end 50.50248 58.84452) (width 0.2) (layer "F.Cu") (net 35) (tstamp 4633bc66-d756-4987-9ef0-a39b9b9f8ed6))
  (segment (start 51.308 58.039) (end 51.308 56.707) (width 0.2) (layer "F.Cu") (net 35) (tstamp 4aa64128-b802-4668-94a1-25fa2384f326))
  (segment (start 22.46048 63.22748) (end 22.098 62.865) (width 0.2) (layer "F.Cu") (net 35) (tstamp 663767d0-f64d-412e-a5b5-9d01703ccbd4))
  (segment (start 37.102519 65.370229) (end 38.633259 63.839489) (width 0.2) (layer "F.Cu") (net 35) (tstamp 6740bf34-fc69-428c-a81d-31d144439ffe))
  (segment (start 37.102519 70.712509) (end 37.102519 65.370229) (width 0.2) (layer "F.Cu") (net 35) (tstamp 6905d896-3b36-4812-aea0-868a73059714))
  (segment (start 44.03506 63.914955) (end 44.356955 63.59306) (width 0.2) (layer "F.Cu") (net 35) (tstamp 785f044d-8abe-4dcd-bca4-a6ecd5a3b84e))
  (segment (start 31.958039 83.205671) (end 31.64152 82.889152) (width 0.2) (layer "F.Cu") (net 35) (tstamp 7a76876b-9fe7-42c7-bb81-e62b338454d5))
  (segment (start 37.139944 63.682944) (end 36.68448 63.22748) (width 0.2) (layer "F.Cu") (net 35) (tstamp 7b168ede-fec5-4f24-ae1a-aba222d54015))
  (segment (start 39.403955 63.914955) (end 44.03506 63.914955) (width 0.2) (layer "F.Cu") (net 35) (tstamp 909fdcc5-9af3-4f3e-9bb0-c15f3bdfe20a))
  (segment (start 44.356955 60.418045) (end 45.93048 58.84452) (width 0.2) (layer "F.Cu") (net 35) (tstamp 9f190bb2-b879-4469-91c8-97eac3ada03b))
  (segment (start 33.816 86.951) (end 32.866 86.951) (width 0.2) (layer "F.Cu") (net 35) (tstamp ab2cbb78-bae5-458d-ac9b-8df56e0e2a8d))
  (segment (start 31.95804 86.04304) (end 31.958039 83.205671) (width 0.2) (layer "F.Cu") (net 35) (tstamp c08fb478-06de-4ae6-8eb7-b33da4f1fd59))
  (segment (start 50.50248 58.84452) (end 51.308 58.039) (width 0.2) (layer "F.Cu") (net 35) (tstamp d4d1486b-0700-4add-b9a7-1096250c563d))
  (segment (start 22.098 62.865) (end 22.098 60.071) (width 0.2) (layer "F.Cu") (net 35) (tstamp dd0c8233-3aeb-4354-a17e-efba2ec87612))
  (segment (start 32.866 86.951) (end 31.95804 86.04304) (width 0.2) (layer "F.Cu") (net 35) (tstamp e920e144-afa4-4bdf-8548-45779bd66db3))
  (segment (start 33.12848 71.39252) (end 36.422508 71.39252) (width 0.2) (layer "F.Cu") (net 35) (tstamp f330cd88-8065-4fe0-adb4-0683e3ebcb66))
  (via (at 37.139944 63.682944) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 35) (tstamp 39179971-a785-4290-8dd3-a7b96257c107))
  (via (at 37.964874 64.507874) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 35) (tstamp a69f80c3-70e6-462b-8dcd-d7dde9f3ade6))
  (segment (start 37.964874 64.507874) (end 37.139944 63.682944) (width 0.25) (layer "B.Cu") (net 35) (tstamp 32173683-9438-4101-865e-790e8401f2cb))
  (segment (start 37.737258 63.958363) (end 37.415363 64.280258) (width 0.2) (layer "F.Cu") (net 36) (tstamp 0c185313-7f7d-4494-9b01-cb618b5235b6))
  (segment (start 37.949379 63.958363) (end 37.737258 63.958363) (width 0.2) (layer "F.Cu") (net 36) (tstamp 152904e2-a544-4fe6-8bb1-383cec8473ed))
  (segment (start 41.148 63.365455) (end 41.140455 63.373) (width 0.2) (layer "F.Cu") (net 36) (tstamp 1e609289-2e83-4536-b7f1-df3caccb8e23))
  (segment (start 21.336 60.706) (end 21.59 60.96) (width 0.2) (layer "F.Cu") (net 36) (tstamp 2ab692d0-3f27-43c3-a1c3-597f0e9e31de))
  (segment (start 32.893 70.993) (end 31.242 72.644) (width 0.2) (layer "F.Cu") (net 36) (tstamp 3574437e-cce0-4a78-8d70-d6ca25d06fcf))
  (segment (start 36.703 70.547022) (end 36.257022 70.993) (width 0.2) (layer "F.Cu") (net 36) (tstamp 38e40d8d-f52f-45a5-8cf2-ac7ac881113a))
  (segment (start 37.415363 64.280258) (end 37.415363 64.492379) (width 0.2) (layer "F.Cu") (net 36) (tstamp 3dbff364-c1e1-43ee-a9f4-77008b9c348b))
  (segment (start 33.100994 87.751) (end 33.816 87.751) (width 0.2) (layer "F.Cu") (net 36) (tstamp 3f399ac7-0bdb-463d-93d2-c9ab593c718a))
  (segment (start 36.257022 70.993) (end 32.893 70.993) (width 0.2) (layer "F.Cu") (net 36) (tstamp 477e3089-f228-4cf8-a5b4-37e41849f16b))
  (segment (start 50.038 63.754) (end 50.038 61.657) (width 0.2) (layer "F.Cu") (net 36) (tstamp 5731179f-5a1b-4f4c-88da-8646c79e0f7b))
  (segment (start 38.534742 63.373) (end 37.949379 63.958363) (width 0.2) (layer "F.Cu") (net 36) (tstamp 6135a229-035c-4d74-9a6a-beac83c866d4))
  (segment (start 48.895 64.897) (end 50.038 63.754) (width 0.2) (layer "F.Cu") (net 36) (tstamp 7168d6ab-0d27-4669-bf49-f2163285b1e6))
  (segment (start 35.433 63.627) (end 36.703 64.897) (width 0.2) (layer "F.Cu") (net 36) (tstamp 79b01236-5dfd-49bb-9802-2d07c339c277))
  (segment (start 22.225 63.627) (end 35.433 63.627) (width 0.2) (layer "F.Cu") (net 36) (tstamp 7b2cb701-acd3-4501-8a07-0eb2224f189b))
  (segment (start 37.415363 64.492379) (end 37.010742 64.897) (width 0.2) (layer "F.Cu") (net 36) (tstamp 82a74dcf-1845-4910-835a-ce1dc9d90c3e))
  (segment (start 31.55852 86.208526) (end 33.100994 87.751) (width 0.2) (layer "F.Cu") (net 36) (tstamp 885b6851-6b70-4de0-b24b-f68716d86544))
  (segment (start 21.59 60.96) (end 21.59 62.992) (width 0.2) (layer "F.Cu") (net 36) (tstamp 9bce1bd5-bbd2-49d5-8a68-cc90d86cfb08))
  (segment (start 36.703 64.897) (end 36.703 70.547022) (width 0.2) (layer "F.Cu") (net 36) (tstamp a3432602-0487-4733-8736-39c1776edbaa))
  (segment (start 41.140455 63.373) (end 38.534742 63.373) (width 0.2) (layer "F.Cu") (net 36) (tstamp ac0c868e-2eee-4cc9-8048-f2db3ac73784))
  (segment (start 41.8245 64.897) (end 48.895 64.897) (width 0.2) (layer "F.Cu") (net 36) (tstamp acb0a671-c470-4e92-ab50-67ac662a7786))
  (segment (start 31.558519 83.371157) (end 31.55852 86.208526) (width 0.2) (layer "F.Cu") (net 36) (tstamp bcff2376-ddc3-47c7-a46e-090b2227df6d))
  (segment (start 21.59 62.992) (end 22.225 63.627) (width 0.2) (layer "F.Cu") (net 36) (tstamp bd3b3cac-7c32-46af-af65-24bdf34868bb))
  (segment (start 31.242 83.054638) (end 31.558519 83.371157) (width 0.2) (layer "F.Cu") (net 36) (tstamp c49b7cf1-0613-4983-95c1-236e1eed43c4))
  (segment (start 37.010742 64.897) (end 36.703 64.897) (width 0.2) (layer "F.Cu") (net 36) (tstamp d0fddec8-eb7e-48d1-b3a6-cfd2c56b5357))
  (segment (start 19.894 60.706) (end 21.336 60.706) (width 0.2) (layer "F.Cu") (net 36) (tstamp e1c96df8-e99d-4ac5-ab2a-08c4a3d1d711))
  (segment (start 41.783 64.9385) (end 41.8245 64.897) (width 0.2) (layer "F.Cu") (net 36) (tstamp ea5ccbcd-2fb3-43aa-83be-8cc665c58289))
  (segment (start 31.242 72.644) (end 31.242 83.054638) (width 0.2) (layer "F.Cu") (net 36) (tstamp ec3224ce-5e1e-4e1b-a15c-922ef6aa5388))
  (via (at 41.783 64.9385) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 36) (tstamp 9e69b801-12aa-40c9-93a9-cb37260600c2))
  (via (at 41.148 63.365455) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 36) (tstamp c9b31b8f-9073-41b8-a3da-ccb46dd8a411))
  (segment (start 41.783 64.000455) (end 41.783 64.9385) (width 0.2) (layer "B.Cu") (net 36) (tstamp 31e088e8-cd22-4916-a350-03667977ccd2))
  (segment (start 41.148 63.365455) (end 41.783 64.000455) (width 0.2) (layer "B.Cu") (net 36) (tstamp 5ada7872-8498-472a-8add-7ea6f50f666d))
  (segment (start 32.04104 73.044966) (end 33.293966 71.79204) (width 0.2) (layer "F.Cu") (net 37) (tstamp 053048c5-6a7d-4e4b-aeaf-a4c8010d1acb))
  (segment (start 32.976 86.151) (end 32.35756 85.53256) (width 0.2) (layer "F.Cu") (net 37) (tstamp 25ce86ac-8f8b-4d65-9b4c-7fd533823208))
  (segment (start 25.754259 60.706) (end 23.794 60.706) (width 0.2) (layer "F.Cu") (net 37) (tstamp 2a2ac4c1-d3e5-43a3-8895-54b41947a370))
  (segment (start 47.752 64.389) (end 48.768 63.373) (width 0.2) (layer "F.Cu") (net 37) (tstamp 2e0750f0-d694-42f2-b7eb-614e1834e8fd))
  (segment (start 33.293966 71.79204) (end 36.587995 71.792039) (width 0.2) (layer "F.Cu") (net 37) (tstamp 4129e363-9cf9-46b6-82ff-40723f3b0871))
  (segment (start 32.35756 85.53256) (end 32.357558 83.702131) (width 0.2) (layer "F.Cu") (net 37) (tstamp 4c80ed09-3f40-47dd-bb1e-145bb4d7cbe3))
  (segment (start 36.587995 71.792039) (end 37.502038 70.877996) (width 0.2) (layer "F.Cu") (net 37) (tstamp 5edc0984-5131-4542-a2a8-9730344de984))
  (segment (start 27.786259 62.738) (end 25.754259 60.706) (width 0.2) (layer "F.Cu") (net 37) (tstamp 6ed1806e-6a6d-4cc1-9462-d62de50da2ca))
  (segment (start 37.526371 62.738) (end 27.786259 62.738) (width 0.2) (layer "F.Cu") (net 37) (tstamp 75463073-a2f4-4a87-87d3-38cbd012405d))
  (segment (start 37.959501 63.17113) (end 37.526371 62.738) (width 0.2) (layer "F.Cu") (net 37) (tstamp 94d7046f-8365-4f4b-93a0-64419de31509))
  (segment (start 33.816 86.151) (end 32.976 86.151) (width 0.2) (layer "F.Cu") (net 37) (tstamp b34a8aa3-3763-47c8-87fe-5c11f11de48e))
  (segment (start 32.357558 83.702131) (end 32.357559 83.040186) (width 0.2) (layer "F.Cu") (net 37) (tstamp ba1fc8c5-4c5c-4e24-aed5-1c9b247c10a5))
  (segment (start 37.502039 65.748961) (end 38.862 64.389) (width 0.2) (layer "F.Cu") (net 37) (tstamp ba8b207e-bbce-4e88-ac49-c19459179dc3))
  (segment (start 37.502038 70.877996) (end 37.502039 65.748961) (width 0.2) (layer "F.Cu") (net 37) (tstamp c749ab9b-2dd5-421f-a77a-b91052d6c79b))
  (segment (start 32.04104 82.723666) (end 32.04104 73.044966) (width 0.2) (layer "F.Cu") (net 37) (tstamp ca060c98-d3d0-4778-9b0d-22d81eabe266))
  (segment (start 32.357559 83.040186) (end 32.04104 82.723666) (width 0.2) (layer "F.Cu") (net 37) (tstamp cdfd31f1-bfaf-4e24-a406-7d53d8c359e3))
  (segment (start 38.862 64.389) (end 47.752 64.389) (width 0.2) (layer "F.Cu") (net 37) (tstamp d64a6918-dd5f-4d19-9bf0-3c06464f7bd1))
  (segment (start 48.768 63.373) (end 48.768 61.657) (width 0.2) (layer "F.Cu") (net 37) (tstamp e815e6bc-b949-47eb-9b67-6642ecad4d6d))
  (via (at 38.862 64.389) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 37) (tstamp 25151aa5-ff68-4148-abad-8868b7838b07))
  (via (at 37.959501 63.17113) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 37) (tstamp 3924898a-05fd-46a1-af46-cbfa317e6ed4))
  (segment (start 37.959501 63.17113) (end 38.862 64.073629) (width 0.2) (layer "B.Cu") (net 37) (tstamp 4bdae765-0772-4499-8e53-c590b9423b0f))
  (segment (start 38.862 64.073629) (end 38.862 64.389) (width 0.2) (layer "B.Cu") (net 37) (tstamp 6ea22fab-987f-4b39-bee9-7d55080e598e))
  (segment (start 111.6235 43.0285) (end 111.6235 50.5285) (width 2) (layer "F.Cu") (net 39) (tstamp 428f34a8-fc5c-4a19-8297-1f5518f2698b))
  (segment (start 73.21648 76.39148) (end 68.199 71.374) (width 0.25) (layer "F.Cu") (net 40) (tstamp 02cf92dd-c98f-4d60-a839-ab85497e51fa))
  (segment (start 66.854 54.662) (end 66.675 54.662) (width 0.25) (layer "F.Cu") (net 40) (tstamp 0dab862f-7c47-46c7-a9b0-cedbae86785b))
  (segment (start 75.311 104.648) (end 81.259 104.648) (width 0.25) (layer "F.Cu") (net 40) (tstamp 0fae218e-aa84-4b25-a19d-6cdf8d78e963))
  (segment (start 68.199 56.007) (end 66.854 54.662) (width 0.25) (layer "F.Cu") (net 40) (tstamp 3dda65cd-caaa-4463-ba38-e90dbae18b7d))
  (segment (start 72.517 92.3935) (end 72.771 92.6475) (width 0.25) (layer "F.Cu") (net 40) (tstamp 6dabf300-db9a-4b46-ae17-5c38796d1655))
  (segment (start 72.517 90.424) (end 73.21648 89.72452) (width 0.25) (layer "F.Cu") (net 40) (tstamp 7d070c71-c321-44c4-8393-f7b42bc736fb))
  (segment (start 68.199 71.374) (end 68.199 56.007) (width 0.25) (layer "F.Cu") (net 40) (tstamp 8c082d88-421f-451e-bf71-fdf7d83e95d2))
  (segment (start 73.21648 89.72452) (end 73.21648 76.39148) (width 0.25) (layer "F.Cu") (net 40) (tstamp a29119c8-5c6f-48f8-8d28-6fe5075b232f))
  (segment (start 72.517 90.9945) (end 72.517 90.424) (width 0.25) (layer "F.Cu") (net 40) (tstamp bf7cdcdf-bafc-4c19-8863-8938859588f1))
  (segment (start 72.771 92.6475) (end 72.771 104.648) (width 0.25) (layer "F.Cu") (net 40) (tstamp d87e7a6a-9698-452e-882a-757d8585f953))
  (via (at 72.517 92.3935) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 40) (tstamp 3e7bbb95-d09e-4cdf-bc48-a907520cac89))
  (via (at 72.517 90.9945) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 40) (tstamp 8a1e45d2-d79b-4760-82c6-384cfc52a72d))
  (via (at 72.771 104.648) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 40) (tstamp dc7c2c3a-96a0-43a0-8405-b98c4bc03f40))
  (via (at 75.311 104.648) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 40) (tstamp f0be63b1-e375-49a7-b4e1-e7de22e0334b))
  (segment (start 72.517 92.3935) (end 72.517 90.9945) (width 0.25) (layer "B.Cu") (net 40) (tstamp 419ff4a5-3743-4293-a55a-9ec068143e8b))
  (segment (start 72.771 104.648) (end 75.311 104.648) (width 0.25) (layer "B.Cu") (net 40) (tstamp fddd0f02-beed-4280-be08-186189e93dab))
  (segment (start 85.471 41.656) (end 85.471 37.465) (width 0.2) (layer "F.Cu") (net 41) (tstamp 0e4e1004-a2da-4f31-9e0b-0df50bc0ba43))
  (segment (start 89.281 42.926) (end 86.741 42.926) (width 0.2) (layer "F.Cu") (net 41) (tstamp 35cb2da8-7d7d-44d9-8415-29b0d84169dd))
  (segment (start 84.582 36.576) (end 83.211 36.576) (width 0.2) (layer "F.Cu") (net 41) (tstamp 4ac44b15-1ee7-4405-9766-e05b70638e16))
  (segment (start 86.741 42.926) (end 85.471 41.656) (width 0.2) (layer "F.Cu") (net 41) (tstamp 7f4e3d9e-ad18-443a-8cc8-456ce77e6286))
  (segment (start 85.471 37.465) (end 84.582 36.576) (width 0.2) (layer "F.Cu") (net 41) (tstamp f0b182de-070b-47f9-9db7-b3b54ef2ed07))
  (segment (start 43.18 43.815) (end 45.191 43.815) (width 0.5) (layer "F.Cu") (net 42) (tstamp 02884fc8-9644-439b-bd64-4788cdfaf9b8))
  (segment (start 41.91 42.545) (end 43.18 43.815) (width 0.5) (layer "F.Cu") (net 42) (tstamp 56744360-a0b8-478b-a429-4c5002f43017))
  (segment (start 34.925 43.307) (end 35.687 42.545) (width 0.5) (layer "F.Cu") (net 42) (tstamp 7f2f8ec9-ebb6-494e-b1f8-59eb3d3b5130))
  (segment (start 33.427 43.307) (end 34.925 43.307) (width 0.5) (layer "F.Cu") (net 42) (tstamp 82cbf61d-54df-4572-92e7-ed30535290fd))
  (segment (start 35.687 42.545) (end 41.91 42.545) (width 0.5) (layer "F.Cu") (net 42) (tstamp e2c38320-42c4-4287-93ca-028eb20adf50))
  (segment (start 49.123 41.148) (end 49.149 41.122) (width 0.25) (layer "F.Cu") (net 43) (tstamp 11105eb5-3a0c-4e42-9207-a5337330a6fc))
  (segment (start 49.123 42.063) (end 49.123 41.148) (width 0.254) (layer "F.Cu") (net 43) (tstamp 36c2b37f-92d8-4526-893a-80d1558c6218))
  (segment (start 48.641 42.545) (end 49.123 42.063) (width 0.254) (layer "F.Cu") (net 43) (tstamp ca5fa629-cebb-4598-8694-339c82d1bb3e))
  (segment (start 45.191 42.545) (end 48.641 42.545) (width 0.254) (layer "F.Cu") (net 43) (tstamp d5b9efb7-b406-43e4-b915-7c2b4619e823))
  (segment (start 133.858 19.812) (end 137.57 19.812) (width 1) (layer "F.Cu") (net 44) (tstamp 01f241fa-02a5-442e-933a-e7acea2fd928))
  (segment (start 91.821 42.291) (end 94.996 39.116) (width 0.5) (layer "F.Cu") (net 44) (tstamp 04527ff6-d086-4f85-b05d-af8a7fe4950c))
  (segment (start 87.7185 56.5535) (end 86.741 56.5535) (width 0.5) (layer "F.Cu") (net 44) (tstamp 24a71ffe-35ea-4337-9801-ec86a92a32c4))
  (segment (start 83.9085 53.721) (end 86.741 56.5535) (width 0.25) (layer "F.Cu") (net 44) (tstamp 2be7f867-ba5d-49a9-9032-454add98e039))
  (segment (start 103.124 39.116) (end 106.68 35.56) (width 0.5) (layer "F.Cu") (net 44) (tstamp 2ecbfdfc-7e79-404a-afb2-ef960bcf209f))
  (segment (start 131.551 28.956) (end 121.666 28.956) (width 4) (layer "F.Cu") (net 44) (tstamp 351f3140-f268-4a70-a5a2-c629821e74dc))
  (segment (start 133.858 19.812) (end 131.551 22.119) (width 1) (layer "F.Cu") (net 44) (tstamp 3f255442-1f39-48b9-8dfa-283d2156e320))
  (segment (start 109.601 19.939) (end 109.601 18.796) (width 0.5) (layer "F.Cu") (net 44) (tstamp 4b470949-b5d1-4923-8d11-0ed62ed385b3))
  (segment (start 76.901113 53.721) (end 74.676 55.946113) (width 0.25) (layer "F.Cu") (net 44) (tstamp 504d1c3b-de35-4a59-931b-de691e40ca3d))
  (segment (start 106.68 22.86) (end 109.601 19.939) (width 0.5) (layer "F.Cu") (net 44) (tstamp 54313ee5-4714-44a3-a6a8-ee0a5d0a1d71))
  (segment (start 121.6235 28.9985) (end 121.666 28.956) (width 4) (layer "F.Cu") (net 44) (tstamp 671be7b3-d1aa-4038-b714-e1904837a95a))
  (segment (start 121.6235 23.9785) (end 121.6235 28.9135) (width 4) (layer "F.Cu") (net 44) (tstamp 6cee382b-27d7-4e3d-a5ea-626ce7079ecc))
  (segment (start 119.126 18.796) (end 109.601 18.796) (width 0.5) (layer "F.Cu") (net 44) (tstamp 732a2e8b-a184-4e72-a5de-22b28f769c54))
  (segment (start 91.821 43.18) (end 91.821 42.291) (width 0.5) (layer "F.Cu") (net 44) (tstamp 76afffb1-2945-42db-9299-07da39dcfbab))
  (segment (start 80.666 53.721) (end 83.9085 53.721) (width 0.25) (layer "F.Cu") (net 44) (tstamp 76d30701-cbd9-47fa-bdf8-be12d2bec1ba))
  (segment (start 106.68 35.56) (end 106.68 22.86) (width 0.5) (layer "F.Cu") (net 44) (tstamp 7aec06d0-06fc-4410-9c53-5952f6c3564a))
  (segment (start 131.551 22.119) (end 131.551 28.956) (width 1) (layer "F.Cu") (net 44) (tstamp 978baa7b-7661-4712-846b-fac80445a8a3))
  (segment (start 121.6235 21.2935) (end 119.126 18.796) (width 0.5) (layer "F.Cu") (net 44) (tstamp 9d61a85c-dcc7-451a-b0c6-d71f6d8fedb1))
  (segment (start 91.821 52.451) (end 87.7185 56.5535) (width 0.5) (layer "F.Cu") (net 44) (tstamp 9d9b14a9-95b1-41c2-9ac2-206bf2e7008d))
  (segment (start 131.551 28.956) (end 131.551 41.021) (width 4) (layer "F.Cu") (net 44) (tstamp aac50952-f285-4420-aa50-1be0b4475d23))
  (segment (start 121.6235 31.4785) (end 121.6235 28.9985) (width 4) (layer "F.Cu") (net 44) (tstamp da6a32d2-11cf-4a69-aa2d-40b34f253528))
  (segment (start 91.821 45.212) (end 91.821 52.451) (width 0.5) (layer "F.Cu") (net 44) (tstamp de2db1b6-cd10-4f87-a4da-712cf0ff8ccf))
  (segment (start 80.666 53.721) (end 76.901113 53.721) (width 0.25) (layer "F.Cu") (net 44) (tstamp ee224a98-2e56-4666-aab6-e874643f4298))
  (segment (start 121.6235 23.9785) (end 121.6235 21.2935) (width 0.5) (layer "F.Cu") (net 44) (tstamp f3785f42-eaab-4a01-a10b-7b4252d5f62e))
  (segment (start 94.996 39.116) (end 103.124 39.116) (width 0.5) (layer "F.Cu") (net 44) (tstamp fb468cf7-acb0-4c02-817b-53959eba86ab))
  (via (at 123.19 25.654) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 44) (tstamp 09d88a6c-09d0-4d58-b877-1fbedbf0f426))
  (via (at 122.047 29.337) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 44) (tstamp 230d773d-268c-46da-bff9-4f5c5ac4110b))
  (via (at 131.064 38.735) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 44) (tstamp 274ef268-b381-4acb-a6e7-1496bedb715b))
  (via (at 91.821 43.18) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 44) (tstamp 46196d42-8cb2-4e44-9e3e-a06d7a4f6fa9))
  (via (at 132.969 38.735) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 44) (tstamp 5e390534-93d3-44db-8439-c7bd4ef419b6))
  (via (at 132.08 38.735) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 44) (tstamp 5e9819aa-b2c5-4b34-a116-59974600b47b))
  (via (at 123.571 30.353) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 44) (tstamp 692c3495-1529-465c-a8ea-54e547ea7fd6))
  (via (at 129.032 29.464) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 44) (tstamp 69ba09ae-543a-48f4-b869-0e62a2c62b65))
  (via (at 129.032 30.353) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 44) (tstamp 6ca396b2-333c-4f3f-a0ef-4f44ec9d37e6))
  (via (at 121.539 26.162) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 44) (tstamp 7fede576-fd54-477b-a514-42d35336bc4a))
  (via (at 130.175 38.735) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 44) (tstamp 895afeed-2cde-439e-8de0-6bd42505dce6))
  (via (at 122.936 29.718) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 44) (tstamp 91c456ad-64f8-4c6a-95e2-e6af719f5a69))
  (via (at 129.032 28.448) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 44) (tstamp b2fbd1eb-9377-4ef3-8948-6c37a087e79e))
  (via (at 122.428 26.035) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 44) (tstamp df5abc50-fbf1-425a-82fb-e65bc8c75ddc))
  (via (at 129.032 27.559) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 44) (tstamp e54be4dc-70da-48be-9a0c-b745baff1923))
  (via (at 91.821 45.212) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 44) (tstamp fb4d84aa-5a43-4a95-9246-c9827150d160))
  (segment (start 121.6235 23.9785) (end 121.6235 31.4785) (width 4) (layer "B.Cu") (net 44) (tstamp 0fbbd558-404c-4a84-b071-8138102c114e))
  (segment (start 91.821 45.212) (end 91.821 43.18) (width 0.5) (layer "B.Cu") (net 44) (tstamp 30ca550a-3fd9-4b24-a28d-95a7822fbf51))
  (segment (start 131.551 41.021) (end 131.551 35.835) (width 4) (layer "B.Cu") (net 44) (tstamp 315e9fcd-d82a-40c7-a9ae-62787a50a412))
  (segment (start 131.551 28.956) (end 122.597 28.956) (width 4) (layer "B.Cu") (net 44) (tstamp 4209da3b-3034-465a-96a3-1a210e3e5f0c))
  (segment (start 131.551 28.956) (end 131.551 35.835) (width 4) (layer "B.Cu") (net 44) (tstamp e4a7ce26-9548-4c0b-960b-72f30931eb97))
  (segment (start 66.675 50.038) (end 66.675 51.562) (width 0.2) (layer "F.Cu") (net 45) (tstamp 84a6634e-8c2f-4fbd-b656-d5e048996174))
  (via (at 66.675 50.038) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 45) (tstamp c47c6f63-091e-4765-b7f4-919a8a0eb32b))
  (segment (start 51.948 34.549) (end 51.948 33.005) (width 0.25) (layer "B.Cu") (net 45) (tstamp 2b9b2e77-98c0-49bc-884c-9540c7097d5e))
  (segment (start 66.167 35.814) (end 53.213 35.814) (width 0.2) (layer "B.Cu") (net 45) (tstamp 34ad8214-ab21-42b2-b07b-7f5a95e2a78b))
  (segment (start 53.213 35.814) (end 51.948 34.549) (width 0.25) (layer "B.Cu") (net 45) (tstamp 76bdcb5d-d9ba-4ea2-bd30-2ba613658553))
  (segment (start 66.675 50.038) (end 66.675 36.322) (width 0.2) (layer "B.Cu") (net 45) (tstamp c77ecb86-9905-4230-ba67-f34002e6d2e2))
  (segment (start 66.675 36.322) (end 66.167 35.814) (width 0.2) (layer "B.Cu") (net 45) (tstamp fab2ac7c-a98b-4663-ae22-af298fbd17ad))
  (segment (start 77.6224 42.418) (end 77.5716 42.418) (width 0.2) (layer "F.Cu") (net 46) (tstamp 0a0f93bc-ce7b-4b43-8090-fd6d34ff24d8))
  (segment (start 74.676 28.115) (end 74 27.439) (width 0.25) (layer "F.Cu") (net 46) (tstamp 18bda1ef-cf75-45b4-b7e2-b20e21616db0))
  (segment (start 70.866 41.783) (end 70.866 43.496) (width 0.2) (layer "F.Cu") (net 46) (tstamp 22c33651-d046-4498-9904-e230b1ed92df))
  (segment (start 74.676 28.194) (end 74.676 28.115) (width 0.25) (layer "F.Cu") (net 46) (tstamp 3b2cbe8f-7ec2-4d31-a0a3-9926dc129d91))
  (segment (start 76.0476 40.894) (end 71.755 40.894) (width 0.2) (layer "F.Cu") (net 46) (tstamp 8f1e7770-381c-42d5-a3e8-bdcd4a0190f6))
  (segment (start 74 27.439) (end 74 26.55) (width 0.25) (layer "F.Cu") (net 46) (tstamp 9718e4bf-cc83-49f4-8199-36cabb97e9ea))
  (segment (start 77.5716 42.418) (end 76.0476 40.894) (width 0.2) (layer "F.Cu") (net 46) (tstamp dd37ce6f-8b4e-42c1-9a54-2b3ef912594e))
  (segment (start 71.755 40.894) (end 70.866 41.783) (width 0.2) (layer "F.Cu") (net 46) (tstamp e2a343f7-c2ba-4aaf-a19b-393c66024911))
  (via (at 74.676 28.194) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 46) (tstamp 576a6462-6785-4a92-83f0-ba222eb063aa))
  (via (at 77.6224 42.418) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 46) (tstamp a243844a-a2da-4530-84e5-de9bcc7c701a))
  (segment (start 78.65652 41.38388) (end 78.65652 31.340414) (width 0.2) (layer "B.Cu") (net 46) (tstamp 3b147e97-c42e-46b8-b4d7-f55e07862a9b))
  (segment (start 76.835 30.353) (end 74.676 28.194) (width 0.2) (layer "B.Cu") (net 46) (tstamp 5d148996-bb38-4f4f-a5fd-c324c1f5e05d))
  (segment (start 78.65652 31.340414) (end 77.669106 30.353) (width 0.2) (layer "B.Cu") (net 46) (tstamp 6edc689f-8296-47c4-bfd5-56756ca01028))
  (segment (start 77.6224 42.418) (end 78.65652 41.38388) (width 0.2) (layer "B.Cu") (net 46) (tstamp 8e87524b-3482-4e4c-8817-a3660b727f58))
  (segment (start 77.669106 30.353) (end 76.835 30.353) (width 0.2) (layer "B.Cu") (net 46) (tstamp e5d1c510-13b1-4c37-9594-b99e82eace48))
  (segment (start 70.196362 32.131) (end 69.561362 32.766) (width 0.2) (layer "F.Cu") (net 47) (tstamp 1bdc0012-a542-4e82-9527-8a01e7c16a08))
  (segment (start 77.3055 36.576) (end 80.111 36.576) (width 0.2) (layer "F.Cu") (net 47) (tstamp 1f3735d4-573a-4bcd-a9e7-1b1ffd3b5a03))
  (segment (start 77.343 32.258) (end 77.34196 32.25696) (width 0.25) (layer "F.Cu") (net 47) (tstamp 33bab338-eea3-4bc6-9421-2344f7b1c604))
  (segment (start 59.69 31.877) (end 60.071 32.258) (width 0.2) (layer "F.Cu") (net 47) (tstamp 72cd07fd-6c84-4471-a054-f02762ba7e2d))
  (segment (start 60.071 32.258) (end 61.341 32.258) (width 0.2) (layer "F.Cu") (net 47) (tstamp 7430b7f7-ff75-4cd8-bf26-e187d60a9dd0))
  (segment (start 77.216 32.131) (end 70.196362 32.131) (width 0.2) (layer "F.Cu") (net 47) (tstamp 79b1511c-41b0-4132-9e1a-fa0ccc1272cc))
  (segment (start 77.343 34.29) (end 77.3055 34.3275) (width 0.25) (layer "F.Cu") (net 47) (tstamp b025117d-aa2d-4b6e-bbb2-fece67b45b93))
  (segment (start 77.34196 32.25696) (end 77.216 32.131) (width 0.2) (layer "F.Cu") (net 47) (tstamp b561ae23-f7e7-497b-98da-3b7f32ce4dd5))
  (segment (start 69.561362 32.766) (end 68.199 32.766) (width 0.2) (layer "F.Cu") (net 47) (tstamp de3cdce4-871b-4aa5-8f92-467e9da037bb))
  (segment (start 77.3055 34.3275) (end 77.3055 36.576) (width 0.2) (layer "F.Cu") (net 47) (tstamp fac6a8e7-b7f5-4c1f-a017-7862ed454c1f))
  (via (at 77.343 34.29) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 47) (tstamp 3ead58e8-de06-4c0a-b18b-e3172d3ca51b))
  (via (at 77.343 32.258) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 47) (tstamp 5bef2a32-a1a9-4086-bedd-ab0380b95f86))
  (via (at 59.69 31.877) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 47) (tstamp 7504d202-c74b-44c6-8412-cde02072dd1e))
  (via (at 61.341 32.258) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 47) (tstamp be91ef46-9394-4a57-b230-c7b69d02669b))
  (via (at 68.199 32.766) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 47) (tstamp c32e4e60-aa22-4c94-b070-83e41f9413aa))
  (segment (start 59.69 31.877) (end 59.186299 31.373299) (width 0.2) (layer "B.Cu") (net 47) (tstamp 031478b2-65a4-4789-b6af-76f345a614e4))
  (segment (start 55.753 31.75) (end 53.233 31.75) (width 0.2) (layer "B.Cu") (net 47) (tstamp 0e5d5141-a382-49a9-9e6b-209045080462))
  (segment (start 68.199 32.766) (end 64.007283 32.766) (width 0.2) (layer "B.Cu") (net 47) (tstamp 1b7973da-33da-4a32-b7fd-2c7f1f793745))
  (segment (start 59.186299 31.373299) (end 56.129701 31.373299) (width 0.2) (layer "B.Cu") (net 47) (tstamp 1fc23b92-1b29-4957-93bf-e4d15d594bd2))
  (segment (start 63.499283 32.258) (end 61.341 32.258) (width 0.2) (layer "B.Cu") (net 47) (tstamp 2c8c8d46-85d0-48e5-b335-362576532786))
  (segment (start 56.129701 31.373299) (end 55.753 31.75) (width 0.2) (layer "B.Cu") (net 47) (tstamp 5aa3e98a-9db1-4a22-99e7-67416bd99ae7))
  (segment (start 53.233 31.75) (end 51.948 30.465) (width 0.2) (layer "B.Cu") (net 47) (tstamp 9b4ec47b-8f43-45c4-b4bb-ca29f819d8f2))
  (segment (start 64.007283 32.766) (end 63.499283 32.258) (width 0.2) (layer "B.Cu") (net 47) (tstamp b2333d5c-eefd-43d9-a781-fbc8c9d2c3d1))
  (segment (start 77.343 34.29) (end 77.343 32.258) (width 0.25) (layer "B.Cu") (net 47) (tstamp b716a56f-6fa1-423b-b852-2ce08b023856))
  (segment (start 51.181 37.846) (end 51.181 46.847873) (width 0.2) (layer "F.Cu") (net 48) (tstamp 0ce4471b-7a4e-4e2e-926c-4bd0d2cfe556))
  (segment (start 31.75 95.885) (end 30.988 95.885) (width 0.2) (layer "F.Cu") (net 48) (tstamp 15e42cef-063a-4ec8-bfe4-1aa28abf0b01))
  (segment (start 21.971718 73.152) (end 25.146718 69.977) (width 0.25) (layer "F.Cu") (net 48) (tstamp 22df8a46-41de-4137-ac6c-988ee172774e))
  (segment (start 21.62704 103.79604) (end 20.66396 102.83296) (width 0.2) (layer "F.Cu") (net 48) (tstamp 2754e010-9c08-4c77-9ffc-561360ece060))
  (segment (start 48.197949 31.560949) (end 45.466 28.829) (width 0.2) (layer "F.Cu") (net 48) (tstamp 2a5c70a5-1f5c-438b-8c91-3af551811d93))
  (segment (start 29.972 96.901) (end 29.972 101.346) (width 0.2) (layer "F.Cu") (net 48) (tstamp 323c3364-30de-4a62-b777-924152059c8d))
  (segment (start 21.971 77.8095) (end 21.971 73.152) (width 0.25) (layer "F.Cu") (net 48) (tstamp 38111fe1-c7b8-42fe-ae79-f22dc7f93c86))
  (segment (start 48.197949 34.862949) (end 51.181 37.846) (width 0.2) (layer "F.Cu") (net 48) (tstamp 3b8c672f-9a65-4088-9be1-55a5547f359f))
  (segment (start 22.0125 77.851) (end 21.971 77.8095) (width 0.25) (layer "F.Cu") (net 48) (tstamp 3f49b2cf-c229-4c0b-bb03-2c0915d53dd6))
  (segment (start 39.915038 57.607974) (end 38.557972 58.96504) (width 0.2) (layer "F.Cu") (net 48) (tstamp 4b2368fb-3299-4763-b36c-ab6dc4afd920))
  (segment (start 51.32652 48.62248) (end 41.814508 48.62248) (width 0.2) (layer "F.Cu") (net 48) (tstamp 55a7ece4-fa1f-4782-949d-8a55efdd684f))
  (segment (start 30.988 95.885) (end 29.972 96.901) (width 0.2) (layer "F.Cu") (net 48) (tstamp 6ac8e5d3-7e1e-4df8-8b99-0837c74a40c0))
  (segment (start 20.66396 102.83296) (end 20.66396 78.00098) (width 0.2) (layer "F.Cu") (net 48) (tstamp 72e8012f-0782-4546-b47a-49e6693699b3))
  (segment (start 25.146718 69.977) (end 29.464 69.977) (width 0.25) (layer "F.Cu") (net 48) (tstamp 7fb4fb24-4322-4402-8eb1-21db790975de))
  (segment (start 32.47496 58.96504) (end 32.006006 59.433994) (width 0.2) (layer "F.Cu") (net 48) (tstamp 80210ce5-6b53-4b19-a7df-70ecca0ee395))
  (segment (start 20.66396 78.00098) (end 20.51398 77.851) (width 0.2) (layer "F.Cu") (net 48) (tstamp 9a52651a-d139-4d06-8e3d-c0dcc2905da2))
  (segment (start 51.857511 47.524384) (end 51.857511 48.091489) (width 0.2) (layer "F.Cu") (net 48) (tstamp 9a583468-a13a-42d1-8f92-57f9bc917688))
  (segment (start 21.971 73.152) (end 21.971718 73.152) (width 0.25) (layer "F.Cu") (net 48) (tstamp a23fe70f-8d02-43ad-8342-3e2c5ad3c0b9))
  (segment (start 51.857511 48.091489) (end 51.32652 48.62248) (width 0.2) (layer "F.Cu") (net 48) (tstamp a390a1d1-b60b-4e87-b0e0-4725676b6e0e))
  (segment (start 38.557972 58.96504) (end 32.47496 58.96504) (width 0.2) (layer "F.Cu") (net 48) (tstamp ab0d54dc-1d5c-4009-9845-e5293d1fb5e9))
  (segment (start 33.0708 95.8596) (end 33.0794 95.851) (width 0.2) (layer "F.Cu") (net 48) (tstamp ac7fc5ca-a880-4957-b096-603226c7c6bf))
  (segment (start 41.814508 48.62248) (end 39.91504 50.521948) (width 0.2) (layer "F.Cu") (net 48) (tstamp af90960c-ff05-406b-935d-e48d21d57c4c))
  (segment (start 29.464 69.977) (end 32.004 67.437) (width 0.25) (layer "F.Cu") (net 48) (tstamp b30027f0-dcb7-436d-b2e8-885cfd5d835d))
  (segment (start 39.91504 50.521948) (end 39.915038 57.607974) (width 0.2) (layer "F.Cu") (net 48) (tstamp b5d54c66-aa9c-41a0-aed6-8dcde5e9dd87))
  (segment (start 33.0794 95.851) (end 35.516 95.851) (width 0.2) (layer "F.Cu") (net 48) (tstamp ca1001f3-6c8a-4300-9096-213f5cc9a9dd))
  (segment (start 48.197949 34.798) (end 48.197949 31.560949) (width 0.2) (layer "F.Cu") (net 48) (tstamp cd2b8839-b508-4e71-9f7c-156c9b0d254c))
  (segment (start 27.52196 103.79604) (end 21.62704 103.79604) (width 0.2) (layer "F.Cu") (net 48) (tstamp ce26d2d8-723d-4047-87fa-3bf63f6da037))
  (segment (start 29.972 101.346) (end 27.52196 103.79604) (width 0.2) (layer "F.Cu") (net 48) (tstamp d16995c7-9972-4ddf-9d31-0ad2287efe16))
  (segment (start 51.181 46.847873) (end 51.857511 47.524384) (width 0.2) (layer "F.Cu") (net 48) (tstamp da9737d1-90f2-4318-98d8-0b676074a08e))
  (segment (start 48.197949 34.798) (end 48.197949 34.862949) (width 0.2) (layer "F.Cu") (net 48) (tstamp dcd76fdd-f3df-43ff-a4bb-81e585fed8f6))
  (segment (start 32.006006 59.433994) (end 32.006006 61.722) (width 0.2) (layer "F.Cu") (net 48) (tstamp e3c0be50-b23f-47d6-a959-a188f4984aad))
  (segment (start 32.004 67.437) (end 32.004 64.262) (width 0.25) (layer "F.Cu") (net 48) (tstamp fac4c562-55ce-4434-8bff-d9116f50d57d))
  (segment (start 45.466 28.829) (end 45.466 27.966) (width 0.2) (layer "F.Cu") (net 48) (tstamp ff6a3ba3-51d5-4187-ac59-20ad112d56aa))
  (via (at 32.006006 61.722) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 48) (tstamp 292eb4b1-4926-458d-895a-fe5901338eeb))
  (via (at 33.0708 95.8596) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 48) (tstamp 309b6f35-4e1f-4bc3-a19f-0f8f50205c25))
  (via (at 31.75 95.885) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 48) (tstamp 424a98c1-d63c-43d4-9b46-aa192e7a16eb))
  (via (at 32.004 64.262) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 48) (tstamp 6f78584a-f83b-4041-8ab8-d546a29b5f59))
  (via (at 20.51398 77.851) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 48) (tstamp 6f8cfda5-dceb-4537-950f-bae19aaeb749))
  (via (at 22.0125 77.851) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 48) (tstamp d45d630f-67f0-4bf5-8e6c-32eec277df7d))
  (segment (start 32.006006 61.722) (end 32.006006 64.262) (width 0.25) (layer "B.Cu") (net 48) (tstamp 1c0bca75-b569-4dfb-8b49-e1bd1fed8c83))
  (segment (start 33.0454 95.885) (end 33.0708 95.8596) (width 0.2) (layer "B.Cu") (net 48) (tstamp 44d7c79c-4dd8-47e6-a170-8085961c53dd))
  (segment (start 31.75 95.885) (end 33.0454 95.885) (width 0.2) (layer "B.Cu") (net 48) (tstamp c2ef8292-813d-4831-b68f-7f7d09291a2d))
  (segment (start 22.0125 77.851) (end 20.51398 77.851) (width 0.2) (layer "B.Cu") (net 48) (tstamp cf399cab-55b6-424d-a095-427f36cf90f1))
  (segment (start 42.971 23.26) (end 44.831 25.12) (width 0.25) (layer "F.Cu") (net 49) (tstamp 75c4402f-6c8e-4f1e-bfc6-91d0222d9e1c))
  (segment (start 42.971 19.691) (end 42.971 23.26) (width 0.25) (layer "F.Cu") (net 49) (tstamp efd404a8-5fdf-4364-87cb-488b0090ae60))
  (segment (start 70.50353 82.56853) (end 70.50353 84.448065) (width 0.2) (layer "F.Cu") (net 50) (tstamp 26db3e64-7636-4863-97db-76d3bdfa2c64))
  (segment (start 52.857233 49.301233) (end 53.550481 49.994481) (width 0.2) (layer "F.Cu") (net 50) (tstamp 42812a5b-a355-49eb-ac0f-83bbaf3f8f74))
  (segment (start 65.214297 93.091) (end 64.550638 93.091) (width 0.25) (layer "F.Cu") (net 50) (tstamp 5582306f-7be1-47a1-90c1-fb7ef92c59cd))
  (segment (start 58.37648 57.579842) (end 58.37648 66.342842) (width 0.2) (layer "F.Cu") (net 50) (tstamp 55f454d7-9aba-4326-83d9-67a8e183eaf7))
  (segment (start 49.149 45.593) (end 49.149 44.222) (width 0.2) (layer "F.Cu") (net 50) (tstamp 5f17835d-b748-4d81-8d6a-d30284fe6f7d))
  (segment (start 46.92 91.751) (end 48.006 92.837) (width 0.2) (layer "F.Cu") (net 50) (tstamp 65b818f4-cc13-4a94-abe3-5d257077308f))
  (segment (start 70.50353 84.448065) (end 70.158518 84.793077) (width 0.2) (layer "F.Cu") (net 50) (tstamp 784a5f51-7239-4d19-a90e-002c8c47da8f))
  (segment (start 70.158518 84.793077) (end 70.158518 92.94102) (width 0.2) (layer "F.Cu") (net 50) (tstamp 7e206bbe-ac38-412c-9bb7-0994bbe9f2e1))
  (segment (start 53.55048 52.753841) (end 58.37648 57.579842) (width 0.2) (layer "F.Cu") (net 50) (tstamp 8539d978-b3e8-4174-bd57-91c659bacb24))
  (segment (start 64.550638 93.091) (end 63.915638 93.726) (width 0.25) (layer "F.Cu") (net 50) (tstamp 8e0ed4d8-6dd0-4f1d-9133-15e28cd8a66e))
  (segment (start 59.90048 71.96548) (end 70.50353 82.56853) (width 0.2) (layer "F.Cu") (net 50) (tstamp 94bc97d6-9989-4b6a-962a-4cf30bc114c7))
  (segment (start 53.550481 49.994481) (end 53.55048 52.753841) (width 0.2) (layer "F.Cu") (net 50) (tstamp 993b3184-7bc5-4eef-bea2-98ab57229711))
  (segment (start 48.006 92.837) (end 56.134 92.837) (width 0.2) (layer "F.Cu") (net 50) (tstamp 9e2e2b87-ef80-43b9-ad22-82c079803284))
  (segment (start 63.915638 93.726) (end 57.835466 93.726) (width 0.25) (layer "F.Cu") (net 50) (tstamp b7fcd230-5011-469a-8b2a-a45c9af10c16))
  (segment (start 45.216 91.751) (end 46.92 91.751) (width 0.2) (layer "F.Cu") (net 50) (tstamp d02b1a76-81bb-4bfa-973f-5aa34f99446b))
  (segment (start 51.308 47.752) (end 49.149 45.593) (width 0.2) (layer "F.Cu") (net 50) (tstamp d6d120b8-3ce0-4a69-a2be-334782fa1602))
  (segment (start 70.158518 92.94102) (end 70.308498 93.091) (width 0.2) (layer "F.Cu") (net 50) (tstamp d9ae35f7-7bad-4125-9a4b-fce5fa96459c))
  (segment (start 59.90048 67.866842) (end 59.90048 71.96548) (width 0.2) (layer "F.Cu") (net 50) (tstamp e5435b33-44c8-428e-993b-4955ef796cc0))
  (segment (start 57.835466 93.726) (end 57.810233 93.751233) (width 0.25) (layer "F.Cu") (net 50) (tstamp eca33d22-62c8-4ad7-b901-1c634d114032))
  (segment (start 58.37648 66.342842) (end 59.90048 67.866842) (width 0.2) (layer "F.Cu") (net 50) (tstamp ef98fcf8-b98a-4f88-9b8d-fd5803fb92d5))
  (via (at 52.857233 49.301233) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 50) (tstamp 200d7f44-33ad-47a1-bf23-583339cb3864))
  (via (at 57.810233 93.751233) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 50) (tstamp 31990c42-b881-4b81-a6de-54b923d3d70d))
  (via (at 56.116211 92.789458) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 50) (tstamp 35a6e1ea-b457-447b-840f-2683cb51b9d6))
  (via (at 65.214297 93.091) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 50) (tstamp 5e7bcb9d-4e71-4369-992b-58ebeb2ef076))
  (via (at 51.308 47.752) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 50) (tstamp b73f6483-0472-4c9c-ac6f-b412e0309852))
  (via (at 70.308498 93.091) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 50) (tstamp e418d08c-d4a8-4f28-b53d-a187b7ee1623))
  (segment (start 57.810233 93.751233) (end 57.077986 93.751233) (width 0.2) (layer "B.Cu") (net 50) (tstamp 4b53f929-69f8-49ad-9c02-ae6717bc5490))
  (segment (start 52.857233 49.301233) (end 51.308 47.752) (width 0.2) (layer "B.Cu") (net 50) (tstamp 615e1849-a5bf-40c1-81e2-33f925aa20ef))
  (segment (start 65.214297 93.091) (end 70.308498 93.091) (width 0.25) (layer "B.Cu") (net 50) (tstamp 69bb055b-8e6a-4010-b964-ca0ae61c7008))
  (segment (start 57.077986 93.751233) (end 56.116211 92.789458) (width 0.2) (layer "B.Cu") (net 50) (tstamp e5bc00c2-2a8b-4e4f-a63d-35cc4217ecec))
  (segment (start 37.973 55.346) (end 37.973 57.658) (width 0.2) (layer "F.Cu") (net 51) (tstamp 049e1fb2-1af6-4239-a93d-e37eb078f293))
  (segment (start 24.891282 68.961) (end 21.336 72.516282) (width 0.25) (layer "F.Cu") (net 51) (tstamp 1223655f-eaad-428b-a393-881147bb0baa))
  (segment (start 30.607 59.055) (end 30.607 61.722) (width 0.2) (layer "F.Cu") (net 51) (tstamp 13779e35-1545-427e-9ec3-28af17f487e1))
  (segment (start 21.336 72.516282) (end 21.336 72.517) (width 0.25) (layer "F.Cu") (net 51) (tstamp 14a91e09-cfa8-4cb1-be71-389e5f9ece14))
  (segment (start 31.496 58.166) (end 30.607 59.055) (width 0.2) (layer "F.Cu") (net 51) (tstamp 16fdc099-10ba-4900-a95b-8759ede711cd))
  (segment (start 21.06348 102.34348) (end 21.06348 80.01) (width 0.2) (layer "F.Cu") (net 51) (tstamp 1e812f43-a292-41e0-9b42-974d85bdf01c))
  (segment (start 30.861 94.488) (end 29.521006 94.488) (width 0.2) (layer "F.Cu") (net 51) (tstamp 2518de10-fcaa-4b50-bf03-268dfceb1a6f))
  (segment (start 31.998 93.351) (end 30.861 94.488) (width 0.2) (layer "F.Cu") (net 51) (tstamp 25a72e42-2d94-4552-ae27-d57550bb5bfa))
  (segment (start 34.606 52.451) (end 36.957 52.451) (width 0.2) (layer "F.Cu") (net 51) (tstamp 25fd9ee9-afe7-40e1-9833-dff39866f3ce))
  (segment (start 37.973 57.658) (end 37.465 58.166) (width 0.2) (layer "F.Cu") (net 51) (tstamp 392414eb-7998-4f84-b159-379dd3465601))
  (segment (start 22.11652 103.39652) (end 21.06348 102.34348) (width 0.2) (layer "F.Cu") (net 51) (tstamp 397a3f55-e328-4fa5-be1c-91e4e90eb35f))
  (segment (start 21.336 72.517) (end 21.06348 72.78952) (width 0.2) (layer "F.Cu") (net 51) (tstamp 51c1c55a-774f-4654-982a-ead04c947bf5))
  (segment (start 33.816 93.351) (end 31.998 93.351) (width 0.2) (layer "F.Cu") (net 51) (tstamp 55ca614a-853e-412a-8055-70c528dee995))
  (segment (start 36.957 52.451) (end 37.872 53.366) (width 0.2) (layer "F.Cu") (net 51) (tstamp 61c5ab10-f30d-47c1-9e60-b7f773073699))
  (segment (start 29.208564 68.961) (end 24.891282 68.961) (width 0.25) (layer "F.Cu") (net 51) (tstamp 6525f59e-a1a3-4d20-9a3f-54009a996619))
  (segment (start 21.06348 72.78952) (end 21.06348 80.137) (width 0.2) (layer "F.Cu") (net 51) (tstamp 6b7c6b67-3e55-4170-beaa-1f2dc425b482))
  (segment (start 37.465 58.166) (end 31.496 58.166) (width 0.2) (layer "F.Cu") (net 51) (tstamp 855bdae1-edb6-4974-89f7-6d177d3e8a95))
  (segment (start 37.872 55.245) (end 37.973 55.346) (width 0.2) (layer "F.Cu") (net 51) (tstamp 9c90cfc2-21a1-4691-a67d-0006aabfd627))
  (segment (start 29.464 94.545006) (end 29.464 101.022006) (width 0.2) (layer "F.Cu") (net 51) (tstamp 9e294b66-1028-44a8-8c0f-29d10ffa033a))
  (segment (start 30.542497 64.262) (end 30.607 64.326503) (width 0.25) (layer "F.Cu") (net 51) (tstamp b42da613-5e81-438d-8e61-b4d693f4607a))
  (segment (start 29.521006 94.488) (end 29.464 94.545006) (width 0.2) (layer "F.Cu") (net 51) (tstamp ca47bc54-9b5e-4c7f-9d2a-9b5acc08a483))
  (segment (start 30.607 67.562564) (end 29.208564 68.961) (width 0.25) (layer "F.Cu") (net 51) (tstamp dbc5f508-20d9-4a97-923d-ef638f5816f4))
  (segment (start 29.464 101.022006) (end 27.089486 103.39652) (width 0.2) (layer "F.Cu") (net 51) (tstamp e63828d1-3753-44bf-90e1-4e37e70508d0))
  (segment (start 27.089486 103.39652) (end 22.11652 103.39652) (width 0.2) (layer "F.Cu") (net 51) (tstamp f304c823-762d-4e00-a513-7d624475bdf2))
  (segment (start 37.872 53.366) (end 37.872 55.245) (width 0.2) (layer "F.Cu") (net 51) (tstamp f7c1b347-e4f6-4729-88d2-03cf6f3d44a3))
  (segment (start 30.607 64.326503) (end 30.607 67.562564) (width 0.25) (layer "F.Cu") (net 51) (tstamp fd793ca6-19c5-4368-888c-ad5858240d14))
  (via (at 30.542497 64.262) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 51) (tstamp 94b59786-0a53-475b-be07-6a341362fedd))
  (via (at 30.607 61.722) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 51) (tstamp e04f4369-4148-4cb1-bc46-770ab1925473))
  (segment (start 30.607 64.197497) (end 30.542497 64.262) (width 0.25) (layer "B.Cu") (net 51) (tstamp f034fdd6-32d9-4031-9e88-56ca1243d254))
  (segment (start 30.607 61.722) (end 30.607 64.197497) (width 0.25) (layer "B.Cu") (net 51) (tstamp f47145c9-4a58-4ff3-bf1d-29679cbd2e8e))
  (segment (start 31.306503 61.722) (end 31.306503 59.136017) (width 0.2) (layer "F.Cu") (net 52) (tstamp 01e0b500-983c-4e68-af22-eea20a695f25))
  (segment (start 31.242 67.563282) (end 29.336282 69.469) (width 0.25) (layer "F.Cu") (net 52) (tstamp 169b86c0-71a5-4e18-8324-d06f0c7c90f6))
  (segment (start 22.352 102.997) (end 26.924 102.997) (width 0.2) (layer "F.Cu") (net 52) (tstamp 3c547387-c5ee-4ba7-8702-6b778772ebf3))
  (segment (start 29.336282 69.469) (end 25.019 69.469) (width 0.25) (layer "F.Cu") (net 52) (tstamp 420058ac-b5da-449d-9b5d-bf6181fa1031))
  (segment (start 31.877 58.56552) (end 37.82748 58.56552) (width 0.2) (layer "F.Cu") (net 52) (tstamp 46c56361-08a2-4c95-b857-1eb439f273cd))
  (segment (start 31.306503 59.136017) (end 31.877 58.56552) (width 0.2) (layer "F.Cu") (net 52) (tstamp 4ec2fd7e-2b88-4d55-9137-2f0843435b81))
  (segment (start 21.463 102.108) (end 22.352 102.997) (width 0.2) (layer "F.Cu") (net 52) (tstamp 56b35c64-689a-4b3e-aa29-a1effb1ce58e))
  (segment (start 32.163 92.551) (end 33.816 92.551) (width 0.2) (layer "F.Cu") (net 52) (tstamp 67034a3f-3ac5-4b42-b1ee-93b4dec774f8))
  (segment (start 21.463 73.025) (end 21.463 102.108) (width 0.2) (layer "F.Cu") (net 52) (tstamp 72b95c6a-a1e8-4eeb-8270-6821037ede45))
  (segment (start 21.78552 72.70248) (end 21.463 73.025) (width 0.2) (layer "F.Cu") (net 52) (tstamp 73934171-7645-4da8-b546-0e22eb1a13fc))
  (segment (start 39.116 57.277) (end 39.116 52.07) (width 0.2) (layer "F.Cu") (net 52) (tstamp 75c5159b-bdf7-4c8f-95fb-51003c50efaf))
  (segment (start 25.019 69.469) (end 21.78552 72.70248) (width 0.25) (layer "F.Cu") (net 52) (tstamp 76422d4f-f60d-4efc-a9cf-b782fc0d3796))
  (segment (start 29.35552 94.08848) (end 30.62552 94.08848) (width 0.2) (layer "F.Cu") (net 52) (tstamp 858dd8bc-21c3-427b-9206-07e6f5573351))
  (segment (start 39.116 52.07) (end 37.973 50.927) (width 0.2) (layer "F.Cu") (net 52) (tstamp 8a969a58-5dbf-41cb-aa00-485068361b14))
  (segment (start 37.82748 58.56552) (end 39.116 57.277) (width 0.2) (layer "F.Cu") (net 52) (tstamp 94c68cac-5096-40ef-8ce2-fccd182833a9))
  (segment (start 31.242 64.262) (end 31.242 67.563282) (width 0.25) (layer "F.Cu") (net 52) (tstamp a32ac6a9-edc1-4c40-92ae-accf6d3ed0ab))
  (segment (start 30.62552 94.08848) (end 32.163 92.551) (width 0.2) (layer "F.Cu") (net 52) (tstamp c0e82c45-16f0-49ac-a2ca-70908c1958a7))
  (segment (start 28.956 94.488) (end 29.35552 94.08848) (width 0.2) (layer "F.Cu") (net 52) (tstamp d12817a6-cf7c-4702-b0d1-b36d5f3f36d5))
  (segment (start 38.201 51.181) (end 34.606 51.181) (width 0.25) (layer "F.Cu") (net 52) (tstamp e14c9a98-9e9d-425a-bd1e-26eb073cf612))
  (segment (start 28.956 100.965) (end 28.956 94.488) (width 0.2) (layer "F.Cu") (net 52) (tstamp e2306090-c485-4386-a12d-f3108b4f68a2))
  (segment (start 26.924 102.997) (end 28.956 100.965) (width 0.2) (layer "F.Cu") (net 52) (tstamp ee7c1484-644b-43ea-a457-d6e3bcece2d6))
  (via (at 31.242 64.262) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 52) (tstamp 640793dc-e509-4265-a1ef-2981e6737c30))
  (via (at 31.306503 61.722) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 52) (tstamp b151ccc1-4fa2-4d0c-9859-e419164d5a0c))
  (segment (start 31.306503 61.722) (end 31.306503 64.262) (width 0.25) (layer "B.Cu") (net 52) (tstamp 83e5325c-8055-4342-befe-e139551b94b9))
  (segment (start 58.039 74.803) (end 47.879 74.803) (width 0.2) (layer "F.Cu") (net 53) (tstamp 03f62968-2898-4ea5-ac62-6844ebf2c636))
  (segment (start 66.163317 82.927317) (end 58.039 74.803) (width 0.2) (layer "F.Cu") (net 53) (tstamp 1a39ed4f-1df5-47af-a2bc-4bc0c357ff40))
  (segment (start 52.171 110.897) (end 52.959 110.109) (width 0.25) (layer "F.Cu") (net 53) (tstamp 392d612f-fd31-41d2-8438-155614893bd2))
  (segment (start 64.034072 102.4128) (end 66.163317 100.283555) (width 0.2) (layer "F.Cu") (net 53) (tstamp 4b78db98-ea7f-4cb1-8c2b-55853ba12b3b))
  (segment (start 37.111441 84.446441) (end 37.116 84.451) (width 0.25) (layer "F.Cu") (net 53) (tstamp 543db223-fabc-433f-8f04-5da2919f9a1b))
  (segment (start 52.959 107.823) (end 58.3692 102.4128) (width 0.2) (layer "F.Cu") (net 53) (tstamp 5e6e543c-171d-4f8c-b39b-7c1090d58f53))
  (segment (start 66.163317 100.283555) (end 66.163317 82.927317) (width 0.2) (layer "F.Cu") (net 53) (tstamp 6f47398b-669b-42d9-987a-1d2c1f8c6a0c))
  (segment (start 58.3692 102.4128) (end 64.034072 102.4128) (width 0.2) (layer "F.Cu") (net 53) (tstamp 8e88295b-26d3-4b23-acd8-a14baa16877b))
  (segment (start 47.879 74.803) (end 46.736 73.66) (width 0.2) (layer "F.Cu") (net 53) (tstamp 90d5de79-93b4-4dcc-9074-7b397bd8c0d1))
  (segment (start 38.227 78.359) (end 38.227 73.279) (width 0.2) (layer "F.Cu") (net 53) (tstamp 9dfaeb9c-0a43-4fa3-b28d-2738e4d33fc4))
  (segment (start 45.1705 72.263) (end 45.212 72.3045) (width 0.2) (layer "F.Cu") (net 53) (tstamp a7d9413a-12c1-4ee2-bde1-9340b0b037c4))
  (segment (start 52.171 112.522) (end 52.171 110.897) (width 0.25) (layer "F.Cu") (net 53) (tstamp c1771bff-bc74-45be-9383-d281c052a96c))
  (segment (start 38.227 73.279) (end 39.243 72.263) (width 0.2) (layer "F.Cu") (net 53) (tstamp c6d32894-e603-42fa-8092-edf6e55359df))
  (segment (start 39.243 72.263) (end 45.1705 72.263) (width 0.2) (layer "F.Cu") (net 53) (tstamp c8c7e201-e70c-4e15-84d1-fce93211900e))
  (segment (start 52.959 110.109) (end 52.959 107.823) (width 0.2) (layer "F.Cu") (net 53) (tstamp d4435772-a75a-4987-892a-7e45e0c96d3d))
  (segment (start 37.111441 82.395559) (end 37.111441 84.446441) (width 0.25) (layer "F.Cu") (net 53) (tstamp efa9991c-ac60-4bd3-8f4c-7fba971c4edf))
  (via (at 37.111441 82.395559) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 53) (tstamp 4881eb5c-3ea9-48cb-a2ee-f6878bb5cc40))
  (via (at 38.227 78.359) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 53) (tstamp 557d986e-02d6-4121-91e7-96e6781aa84c))
  (via (at 45.212 72.3045) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 53) (tstamp 6c879b67-7d75-4d30-826c-85f1915280af))
  (via (at 46.736 73.66) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 53) (tstamp bde28a86-5e74-4a33-bee7-bd5f88b990c4))
  (segment (start 38.227 80.772) (end 37.111441 81.887559) (width 0.2) (layer "B.Cu") (net 53) (tstamp 1e999119-2264-4b37-813c-c1f1287dd892))
  (segment (start 46.736 73.66) (end 45.3805 72.3045) (width 0.2) (layer "B.Cu") (net 53) (tstamp 66240175-35ed-4e7c-9e22-052c6ae52649))
  (segment (start 45.3805 72.3045) (end 45.212 72.3045) (width 0.2) (layer "B.Cu") (net 53) (tstamp a7a02d2e-d29e-414e-98dd-b3a238b8e1e7))
  (segment (start 37.111441 81.887559) (end 37.111441 82.395559) (width 0.2) (layer "B.Cu") (net 53) (tstamp df4e94a5-1b80-4ff4-bebf-71774c062e57))
  (segment (start 38.227 78.359) (end 38.227 80.772) (width 0.2) (layer "B.Cu") (net 53) (tstamp e21cca21-6ef5-4d9d-8897-b6bec644cc61))
  (segment (start 54.001 93.726) (end 54.737 94.462) (width 0.25) (layer "F.Cu") (net 54) (tstamp 4a77d4a3-c594-473b-8c39-e554a14d4daa))
  (segment (start 45.216 93.351) (end 46.869 93.351) (width 0.25) (layer "F.Cu") (net 54) (tstamp 5aefd830-f1cf-48b6-aa54-88c8f4701b67))
  (segment (start 47.244 93.726) (end 54.001 93.726) (width 0.25) (layer "F.Cu") (net 54) (tstamp 71390430-9ff6-406b-b422-931433979756))
  (segment (start 46.869 93.351) (end 47.244 93.726) (width 0.25) (layer "F.Cu") (net 54) (tstamp bfdc808d-13ca-4c91-950a-d1165e682a52))
  (segment (start 27.585 109.5) (end 29.972 109.5) (width 0.2) (layer "F.Cu") (net 55) (tstamp 04584734-5e24-4528-b983-24d8e46b286b))
  (segment (start 49.53 34.29) (end 49.53 28.09802) (width 0.2) (layer "F.Cu") (net 55) (tstamp 050bc229-b5c9-4c7f-981e-82d998ce8b86))
  (segment (start 38.736446 59.36456) (end 40.314559 57.786447) (width 0.2) (layer "F.Cu") (net 55) (tstamp 0d0b80d4-4b43-42f0-b353-66089bc76d73))
  (segment (start 26.416 108.331) (end 27.585 109.5) (width 0.2) (layer "F.Cu") (net 55) (tstamp 1eff338b-b8e6-4def-b647-850736070a63))
  (segment (start 25.45556 104.19556) (end 26.416 105.156) (width 0.2) (layer "F.Cu") (net 55) (tstamp 262a080f-1ed2-432a-b824-3ca9016081aa))
  (segment (start 40.314559 57.786447) (end 40.31456 50.74444) (width 0.2) (layer "F.Cu") (net 55) (tstamp 2fb39897-1ddc-4d8d-8f03-bc61abc6e7ec))
  (segment (start 32.705509 61.722) (end 32.705509 59.877491) (width 0.2) (layer "F.Cu") (net 55) (tstamp 3c1292e7-4db7-4c3e-96ce-53aeb903c582))
  (segment (start 33.21844 59.36456) (end 38.736446 59.36456) (width 0.2) (layer "F.Cu") (net 55) (tstamp 3fe1e749-38b8-4343-b4cc-46aabb19d547))
  (segment (start 51.98004 46.060413) (end 51.98004 37.136884) (width 0.2) (layer "F.Cu") (net 55) (tstamp 446ade77-19a7-45a7-876a-780c1a1171e1))
  (segment (start 52.492511 48.091489) (end 52.492511 46.572884) (width 0.2) (layer "F.Cu") (net 55) (tstamp 4c5404ff-f3f7-434d-a846-18ac3e2fd850))
  (segment (start 25.274436 70.485) (end 29.591718 70.485) (width 0.25) (layer "F.Cu") (net 55) (tstamp 4e2f506c-8f3b-4b23-9502-b423705020e5))
  (segment (start 51.562 49.022) (end 52.492511 48.091489) (width 0.2) (layer "F.Cu") (net 55) (tstamp 5569b7c3-8e09-4faa-a18d-f6eb7a5f2112))
  (segment (start 22.587011 73.172425) (end 25.274436 70.485) (width 0.25) (layer "F.Cu") (net 55) (tstamp 5576a0a9-5105-4cb6-998d-7a5a54a8e87d))
  (segment (start 26.416 105.156) (end 26.416 108.331) (width 0.2) (layer "F.Cu") (net 55) (tstamp 60bf3156-244d-4c1b-8945-7bf8120bed24))
  (segment (start 21.461553 104.195559) (end 25.45556 104.19556) (width 0.2) (layer "F.Cu") (net 55) (tstamp 62e6bb2d-0dea-4706-be66-750d52cb9f70))
  (segment (start 32.705509 59.877491) (end 33.21844 59.36456) (width 0.2) (layer "F.Cu") (net 55) (tstamp 691c7832-b4ca-4a06-8cb4-9f6665cab3ef))
  (segment (start 32.767377 67.309341) (end 32.767377 64.284206) (width 0.25) (layer "F.Cu") (net 55) (tstamp 6f80d36e-fba7-44d2-b353-4724dab586ef))
  (segment (start 20.11446 78.613) (end 20.26444 78.76298) (width 0.2) (layer "F.Cu") (net 55) (tstamp 7d1a867e-dc34-4886-a5fe-06410ab348ed))
  (segment (start 40.31456 50.74444) (end 42.037 49.022) (width 0.2) (layer "F.Cu") (net 55) (tstamp 834b02d4-9b45-48fb-8a1a-e7ef308cda33))
  (segment (start 49.53 28.09802) (end 49.37198 27.94) (width 0.25) (layer "F.Cu") (net 55) (tstamp 86ccacad-0350-41b7-8128-1bb87863d20c))
  (segment (start 51.98004 37.136884) (end 49.53 34.686844) (width 0.2) (layer "F.Cu") (net 55) (tstamp 89e522fb-8769-402d-ac7b-18b4aade0c2b))
  (segment (start 22.098 78.613) (end 22.587011 78.123989) (width 0.25) (layer "F.Cu") (net 55) (tstamp 9947d9b4-2588-4253-a00a-7bc713076855))
  (segment (start 49.53 34.686844) (end 49.53 34.29) (width 0.2) (layer "F.Cu") (net 55) (tstamp 9eec7aec-06e2-465c-a3a4-20cc1474799d))
  (segment (start 42.037 49.022) (end 51.562 49.022) (width 0.2) (layer "F.Cu") (net 55) (tstamp a2d04f71-e6a5-4cb8-b0ab-bc11239c90a6))
  (segment (start 20.26444 102.998446) (end 21.461553 104.195559) (width 0.2) (layer "F.Cu") (net 55) (tstamp aa131e61-e617-4653-82a3-b95126443bfc))
  (segment (start 20.26444 78.76298) (end 20.26444 102.998446) (width 0.2) (layer "F.Cu") (net 55) (tstamp ce0e3b2c-caa3-4fe5-89ce-e952681a6880))
  (segment (start 22.587011 78.123989) (end 22.587011 73.172425) (width 0.25) (layer "F.Cu") (net 55) (tstamp d0e6d99f-a293-44c1-9d47-c69b41e9ee29))
  (segment (start 52.492511 46.572884) (end 51.98004 46.060413) (width 0.2) (layer "F.Cu") (net 55) (tstamp e2e8e3c8-64e3-4c03-b2e1-db170977d8e8))
  (segment (start 29.591718 70.485) (end 32.767377 67.309341) (width 0.25) (layer "F.Cu") (net 55) (tstamp e9cc4943-5eab-436f-af80-91267be06294))
  (via (at 20.11446 78.613) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 55) (tstamp 12d3d897-c28f-4901-8adb-465d6f99d691))
  (via (at 49.37198 27.94) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 55) (tstamp 275046cf-ad54-44a2-a9ca-53da225c5da4))
  (via (at 32.767377 64.284206) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 55) (tstamp 32ed585a-39d3-4ecd-a96e-5a2640048b33))
  (via (at 22.098 78.613) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 55) (tstamp 3ef26ae8-d848-4220-94da-fc87a82e9579))
  (via (at 32.705509 61.722) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 55) (tstamp c41da222-49fa-478a-9885-ad9fdce0e216))
  (segment (start 49.38698 27.925) (end 51.948 27.925) (width 0.2) (layer "B.Cu") (net 55) (tstamp 69791e7f-9e6d-4410-b39f-3eb9ec9efa38))
  (segment (start 49.37198 27.94) (end 49.38698 27.925) (width 0.2) (layer "B.Cu") (net 55) (tstamp a5746ff1-966b-441e-b0d8-5f958a791ae3))
  (segment (start 32.705509 61.722) (end 32.705509 64.262) (width 0.25) (layer "B.Cu") (net 55) (tstamp cecd4bce-99f2-4ee2-a8c8-b7073c925154))
  (segment (start 22.098 78.613) (end 20.11446 78.613) (width 0.25) (layer "B.Cu") (net 55) (tstamp ec198931-53c7-448a-a53d-9031ec3745a3))
  (segment (start 32.385 94.615) (end 32.385 96.266) (width 0.2) (layer "F.Cu") (net 56) (tstamp 1b73ff79-0753-44c2-93d3-e57f24166b66))
  (segment (start 32.385 96.266) (end 31.115 97.536) (width 0.2) (layer "F.Cu") (net 56) (tstamp 251ab8b1-1831-4166-be2c-3530c19dd218))
  (segment (start 33.816 94.151) (end 32.849 94.151) (width 0.2) (layer "F.Cu") (net 56) (tstamp 292be1a4-92dd-48c8-b794-d97d8436b930))
  (segment (start 31.115 104.749) (end 29.464 106.4) (width 0.2) (layer "F.Cu") (net 56) (tstamp d7b1186f-8be4-4c4c-894e-2fc132875382))
  (segment (start 31.115 97.536) (end 31.115 104.749) (width 0.2) (layer "F.Cu") (net 56) (tstamp df4255a8-fe5f-4b6e-84a9-c83773fd547c))
  (segment (start 32.849 94.151) (end 32.385 94.615) (width 0.2) (layer "F.Cu") (net 56) (tstamp f8829dc1-ce9d-4667-a336-9f3b1df7d3fa))
  (segment (start 61.396944 78.938056) (end 61.386377 78.927489) (width 0.25) (layer "F.Cu") (net 57) (tstamp 1844c5e4-80f5-4842-b71d-7555a7e806be))
  (segment (start 59.020511 78.927489) (end 58.954 78.994) (width 0.25) (layer "F.Cu") (net 57) (tstamp 1b9f5185-2810-4cd9-a494-b35c46524079))
  (segment (start 64.129178 75.316822) (end 64.129178 75.417067) (width 0.2) (layer "F.Cu") (net 57) (tstamp 3166659b-3bd5-44e9-a943-97494f768cbb))
  (segment (start 67.335301 56.167899) (end 67.437 56.269598) (width 0.2) (layer "F.Cu") (net 57) (tstamp 5ed6abcf-30c9-46e7-bc4b-e28229fa3641))
  (segment (start 67.437 56.269598) (end 67.437 72.009) (width 0.2) (layer "F.Cu") (net 57) (tstamp 71f40894-4279-4050-a72b-4f3eb953f6e9))
  (segment (start 61.386377 78.927489) (end 59.020511 78.927489) (width 0.25) (layer "F.Cu") (net 57) (tstamp c4cecedd-459f-495a-901f-9f6a13ac99c8))
  (segment (start 67.437 72.009) (end 64.129178 75.316822) (width 0.2) (layer "F.Cu") (net 57) (tstamp eb45b409-5a05-4388-a658-8a530f3003b0))
  (segment (start 72.136 46.355) (end 72.136 43.496) (width 0.25) (layer "F.Cu") (net 57) (tstamp f11e0868-b42f-488d-a0a6-eb01fa66a747))
  (via (at 67.335301 56.167899) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 57) (tstamp 3104b48a-6aa3-4edb-8cd9-7d6801140261))
  (via (at 61.396944 78.938056) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 57) (tstamp 3699375b-6dd3-4aea-a89f-b3806e0606fa))
  (via (at 64.129178 75.417067) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 57) (tstamp 36c35487-b536-40a5-9411-09925bf48d9a))
  (via (at 72.136 46.2155) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 57) (tstamp 4d61af17-b63e-4d42-b528-02537f671401))
  (segment (start 72.1235 46.228) (end 72.136 46.2155) (width 0.25) (layer "B.Cu") (net 57) (tstamp 2e492dc5-ab27-462c-93fc-b71c2c2025e4))
  (segment (start 67.335301 56.167899) (end 67.437 56.0662) (width 0.25) (layer "B.Cu") (net 57) (tstamp 6505bfef-f79d-45e4-b260-56a41d4814a5))
  (segment (start 68.072 46.228) (end 72.1235 46.228) (width 0.25) (layer "B.Cu") (net 57) (tstamp 7a2d79ad-54d9-4279-ac6c-99b583bd14a6))
  (segment (start 64.129178 75.443822) (end 61.396944 78.176056) (width 0.2) (layer "B.Cu") (net 57) (tstamp 7fdb30b1-c959-4579-9874-3bb6753d1249))
  (segment (start 67.437 56.0662) (end 67.437 46.863) (width 0.25) (layer "B.Cu") (net 57) (tstamp 9c634fdd-3afe-45b6-8286-4069a23bb508))
  (segment (start 64.129178 75.417067) (end 64.129178 75.443822) (width 0.2) (layer "B.Cu") (net 57) (tstamp c35970d8-2bd3-4b5d-b809-ed1a027238a7))
  (segment (start 61.396944 78.176056) (end 61.396944 78.938056) (width 0.2) (layer "B.Cu") (net 57) (tstamp d76db2b8-5808-44de-b4fd-13b426140e9e))
  (segment (start 67.437 46.863) (end 68.072 46.228) (width 0.25) (layer "B.Cu") (net 57) (tstamp fc744127-86a2-4d30-8c2f-3e2ae1e52d33))
  (segment (start 48.40552 86.72248) (end 46.577 88.551) (width 0.2) (layer "F.Cu") (net 58) (tstamp 4b8047ff-93a4-4592-8c42-9d28537847e8))
  (segment (start 46.577 88.551) (end 45.216 88.551) (width 0.2) (layer "F.Cu") (net 58) (tstamp 7eb09665-ed9b-4795-b85a-96ff1ccddf18))
  (segment (start 54.102 80.264) (end 55.245 79.121) (width 0.25) (layer "F.Cu") (net 58) (tstamp 86304e96-b428-4278-bc56-d44677a9cf56))
  (segment (start 53.86652 86.72248) (end 48.40552 86.72248) (width 0.2) (layer "F.Cu") (net 58) (tstamp a1ade821-3bde-4a40-8e92-8f5e77cc220a))
  (segment (start 54.102 85.217) (end 54.102 86.487) (width 0.2) (layer "F.Cu") (net 58) (tstamp c6eda67e-7824-495d-9ffa-f27c435ee662))
  (segment (start 55.245 79.121) (end 55.473 79.121) (width 0.25) (layer "F.Cu") (net 58) (tstamp ca9fdb6b-be9c-4e51-94d3-a70ceaf9f66e))
  (segment (start 54.102 86.487) (end 53.86652 86.72248) (width 0.2) (layer "F.Cu") (net 58) (tstamp ee67beea-4103-447f-8fd2-83a23c68b42b))
  (segment (start 54.102 82.0005) (end 54.102 80.264) (width 0.25) (layer "F.Cu") (net 58) (tstamp fb24fb4c-fd0d-4f52-ab7a-05acab4a503b))
  (via (at 54.102 82.0005) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 58) (tstamp 20ac27b3-d51f-4e73-83d1-40acc6d9fefe))
  (via (at 54.102 85.217) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 58) (tstamp ed3f4647-c32d-47c1-9054-249fc030b374))
  (segment (start 54.102 85.217) (end 54.102 82.0005) (width 0.25) (layer "B.Cu") (net 58) (tstamp 772a0832-aae6-4a3c-a476-8dc05f205727))
  (segment (start 35.552444 82.811556) (end 35.516 82.848) (width 0.2) (layer "F.Cu") (net 59) (tstamp 0b28096c-8874-4a11-9d3b-69cc3b9adae3))
  (segment (start 53.848 114.935) (end 53.848 107.95) (width 0.2) (layer "F.Cu") (net 59) (tstamp 1c62301a-2796-4e0a-946f-62dd65c374ef))
  (segment (start 37.421011 73.519983) (end 39.185994 71.755) (width 0.2) (layer "F.Cu") (net 59) (tstamp 1f3fba13-ee81-4b7c-b85d-ec1999e682b6))
  (segment (start 64.75484 104.28216) (end 64.75484 102.257038) (width 0.2) (layer "F.Cu") (net 59) (tstamp 1fa73c97-1a0d-4f4f-8351-07eb5860ec05))
  (segment (start 58.204486 74.40348) (end 48.62248 74.40348) (width 0.2) (layer "F.Cu") (net 59) (tstamp 3f98eb49-955c-4a79-b95e-d73c87b79845))
  (segment (start 48.62248 74.40348) (end 47.371 73.152) (width 0.2) (layer "F.Cu") (net 59) (tstamp 5b2419db-fb22-477e-b60a-5b099f2ac1a3))
  (segment (start 53.848 107.95) (end 56.8452 104.9528) (width 0.2) (layer "F.Cu") (net 59) (tstamp 673c91c7-1dca-47f8-96b5-aac11a48ec99))
  (segment (start 52.171 116.332) (end 52.451 116.332) (width 0.2) (layer "F.Cu") (net 59) (tstamp 6a80a0aa-5a5c-4813-8179-f9d5f3b4b762))
  (segment (start 66.562837 100.449041) (end 66.562836 82.76183) (width 0.2) (layer "F.Cu") (net 59) (tstamp 6db8a694-d37f-4015-a060-d11a8224f766))
  (segment (start 66.562836 82.76183) (end 58.204486 74.40348) (width 0.2) (layer "F.Cu") (net 59) (tstamp 76145493-c24a-4cb6-bb4f-d7a3fcf64f23))
  (segment (start 56.8452 104.9528) (end 64.0842 104.9528) (width 0.2) (layer "F.Cu") (net 59) (tstamp 76b252d5-6f80-497c-813f-78c78cafa794))
  (segment (start 35.516 82.848) (end 35.516 84.451) (width 0.2) (layer "F.Cu") (net 59) (tstamp 7adf24c0-9f7a-4846-b198-e4b4823e9654))
  (segment (start 37.421011 78.315011) (end 37.421011 73.519983) (width 0.2) (layer "F.Cu") (net 59) (tstamp b897a87c-b018-4ac1-ad87-d541494aef94))
  (segment (start 37.465 78.359) (end 37.421011 78.315011) (width 0.2) (layer "F.Cu") (net 59) (tstamp bcadc96f-e028-481a-a55a-950eb5a8d2a7))
  (segment (start 39.185994 71.755) (end 45.847 71.755) (width 0.2) (layer "F.Cu") (net 59) (tstamp d17309dd-85b5-4d4c-b6d8-94085ff93677))
  (segment (start 64.75484 102.257038) (end 66.562837 100.449041) (width 0.2) (layer "F.Cu") (net 59) (tstamp e86c71c1-c61b-4def-b012-480a24d4acb6))
  (segment (start 64.0842 104.9528) (end 64.75484 104.28216) (width 0.2) (layer "F.Cu") (net 59) (tstamp fbfdc9b7-7d39-407b-a9f8-4af85b91f9cd))
  (segment (start 52.451 116.332) (end 53.848 114.935) (width 0.2) (layer "F.Cu") (net 59) (tstamp fde7923b-e5b2-44d3-a588-ca6d015ed9fc))
  (via (at 47.371 73.152) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 59) (tstamp 669fe5e0-1f45-470c-9bb0-c114181217b2))
  (via (at 37.465 78.359) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 59) (tstamp 9ac77842-c4d5-415b-aeb9-99c5d53ac69d))
  (via (at 45.847 71.755) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 59) (tstamp 9ca29e63-fda1-4f14-94ca-17c888fd7467))
  (via (at 35.552444 82.811556) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 59) (tstamp ea88fe67-ca1c-4665-b9c2-252c6c7d502d))
  (segment (start 37.465 78.359) (end 37.465 80.391) (width 0.25) (layer "B.Cu") (net 59) (tstamp 5c61b38c-9e65-45c1-836c-600d142af8d5))
  (segment (start 45.974 71.755) (end 47.371 73.152) (width 0.25) (layer "B.Cu") (net 59) (tstamp 711017d1-af3c-4da7-b28c-1e682d7c7962))
  (segment (start 35.552444 82.303556) (end 35.552444 82.811556) (width 0.25) (layer "B.Cu") (net 59) (tstamp 7aa8d83c-b6d0-489e-8003-9eba392ab7b6))
  (segment (start 37.465 80.391) (end 35.552444 82.303556) (width 0.25) (layer "B.Cu") (net 59) (tstamp a6b64dcc-397a-4867-b51e-8040f52d878d))
  (segment (start 45.847 71.755) (end 45.974 71.755) (width 0.25) (layer "B.Cu") (net 59) (tstamp f0588dac-4192-4394-9e07-23f5eddc99a2))
  (segment (start 46.863 94.107) (end 47.371 94.615) (width 0.25) (layer "F.Cu") (net 60) (tstamp 0957ca1a-9dc7-4ba7-b80f-b34607a0aea8))
  (segment (start 45.26 94.107) (end 46.863 94.107) (width 0.25) (layer "F.Cu") (net 60) (tstamp 33902e5e-1c67-42b2-a138-76e3b79bc398))
  (segment (start 45.216 94.151) (end 45.26 94.107) (width 0.25) (layer "F.Cu") (net 60) (tstamp 6bcb1043-2426-46d2-a485-e8716a13832f))
  (segment (start 51.943 99.542) (end 52.451 100.05) (width 0.25) (layer "F.Cu") (net 60) (tstamp 9c80977a-5f3f-47b8-9a68-83198abe58ce))
  (segment (start 51.943 95.123) (end 51.943 99.542) (width 0.25) (layer "F.Cu") (net 60) (tstamp aa59f51b-8590-4900-b9f2-163ca1787144))
  (segment (start 47.371 94.615) (end 51.435 94.615) (width 0.25) (layer "F.Cu") (net 60) (tstamp cff2b34d-2857-4307-9d52-a849f81bb651))
  (segment (start 51.435 94.615) (end 51.943 95.123) (width 0.25) (layer "F.Cu") (net 60) (tstamp d60039d1-4ea2-4c3f-91fa-eadde30b883b))
  (segment (start 50.589989 65.996011) (end 38.595967 65.996011) (width 0.2) (layer "F.Cu") (net 61) (tstamp 0be0ac20-5590-4424-9edc-45dfd01b6770))
  (segment (start 38.326077 71.290037) (end 36.322 73.294114) (width 0.2) (layer "F.Cu") (net 61) (tstamp 14e2bcf2-2e8b-4925-96e0-c2862bfaf2e7))
  (segment (start 36.741486 81.38848) (end 37.44648 81.38848) (width 0.2) (layer "F.Cu") (net 61) (tstamp 2759fce2-87d0-4256-8dfb-53f8cecae80d))
  (segment (start 51.943 64.643) (end 50.589989 65.996011) (width 0.2) (layer "F.Cu") (net 61) (tstamp 2cd61e02-117f-4a30-97c7-9dd37745187e))
  (segment (start 54.483 55.372) (end 56.261 57.15) (width 0.25) (layer "F.Cu") (net 61) (tstamp 306a5c75-1f96-4c68-ac03-7f5734034b96))
  (segment (start 36.322 80.968994) (end 36.741486 81.38848) (width 0.2) (layer "F.Cu") (net 61) (tstamp 3b761b01-27d7-42b1-b5c4-088d519c6b97))
  (segment (start 52.578 54.991) (end 52.578 56.707) (width 0.2) (layer "F.Cu") (net 61) (tstamp 52ae3ba7-d864-4616-8b94-0c1923aed542))
  (segment (start 52.578 58.547) (end 51.943 59.182) (width 0.2) (layer "F.Cu") (net 61) (tstamp 60a1c861-65cf-4034-8a55-9cca3bd2154e))
  (segment (start 38.326077 66.265901) (end 38.326077 71.290037) (width 0.2) (layer "F.Cu") (net 61) (tstamp 6775c995-b0f8-425c-bc31-68e3960f95f5))
  (segment (start 54.4455 55.372) (end 54.483 55.372) (width 0.25) (layer "F.Cu") (net 61) (tstamp 6b9beb52-faae-457c-bb2c-63b13661c9ff))
  (segment (start 56.261 57.15) (end 56.261 58.14) (width 0.25) (layer "F.Cu") (net 61) (tstamp 6beac13a-30e6-4cb5-84ef-e75a878b8a15))
  (segment (start 38.595967 65.996011) (end 38.326077 66.265901) (width 0.2) (layer "F.Cu") (net 61) (tstamp 7174a3e8-f86f-4b18-b72b-b6dfc3abcfe3))
  (segment (start 51.943 59.182) (end 51.943 64.643) (width 0.2) (layer "F.Cu") (net 61) (tstamp 838e8a14-cae8-46e5-bb1c-33a25ebf0784))
  (segment (start 37.44648 81.38848) (end 38.716 82.658) (width 0.2) (layer "F.Cu") (net 61) (tstamp 9e63a8cf-5ab9-45b2-a7f1-a610bb2037eb))
  (segment (start 38.716 82.658) (end 38.716 83.547) (width 0.2) (layer "F.Cu") (net 61) (tstamp b5f31d07-e5df-4a69-8779-570fab5b2796))
  (segment (start 52.451 54.864) (end 52.578 54.991) (width 0.25) (layer "F.Cu") (net 61) (tstamp c33b819a-53d4-4dcf-b0ee-58d2529a105a))
  (segment (start 36.322 73.294114) (end 36.322 80.968994) (width 0.2) (layer "F.Cu") (net 61) (tstamp c40a1bd1-da80-4887-b7a1-6dcccd776a35))
  (segment (start 52.578 56.707) (end 52.578 58.547) (width 0.2) (layer "F.Cu") (net 61) (tstamp cb40e9f4-a3e6-45b7-8590-d0a7fd278266))
  (segment (start 38.716 83.547) (end 38.716 84.451) (width 0.25) (layer "F.Cu") (net 61) (tstamp f44f2b8b-3db9-4895-b03e-64aadac2d582))
  (via (at 54.4455 55.372) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 61) (tstamp 9f908f29-85f3-4cdd-a726-e0a42f28a355))
  (via (at 52.451 54.864) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 61) (tstamp a1f4e9fc-5c13-4f8e-ab58-ce14fd5eb94f))
  (segment (start 53.9375 54.864) (end 52.451 54.864) (width 0.25) (layer "B.Cu") (net 61) (tstamp 4bf845f0-5ed5-44f2-b7a6-0af03cbffc71))
  (segment (start 54.4455 55.372) (end 53.9375 54.864) (width 0.25) (layer "B.Cu") (net 61) (tstamp 9c03b03d-67c6-45a1-8b70-6ad61b2c01c0))
  (segment (start 36.316 95.851) (end 36.316 97.149) (width 0.2) (layer "F.Cu") (net 62) (tstamp 2cc83063-ac23-48c3-a600-7de85311d09b))
  (segment (start 34.544 98.806) (end 34.036 98.806) (width 0.2) (layer "F.Cu") (net 62) (tstamp 5387faa5-8cbd-4116-b51e-f712a97afd06))
  (segment (start 36.316 97.149) (end 36.201 97.149) (width 0.2) (layer "F.Cu") (net 62) (tstamp 6a05fba2-ebb7-4f7c-bdbc-69b473416192))
  (segment (start 33.02 99.822) (end 33.02 99.923) (width 0.2) (layer "F.Cu") (net 62) (tstamp 7076a465-4e0d-496d-828c-2ef1573c8560))
  (segment (start 34.036 98.806) (end 33.02 99.822) (width 0.2) (layer "F.Cu") (net 62) (tstamp 9cfa79c0-4fdf-4242-a2c1-64a0a2ad6a16))
  (segment (start 36.201 97.149) (end 34.544 98.806) (width 0.2) (layer "F.Cu") (net 62) (tstamp d43a4b23-93b2-42e8-90c9-913488c0b610))
  (segment (start 43.516 95.851) (end 43.516 96.437) (width 0.25) (layer "F.Cu") (net 63) (tstamp 3055427f-4f8b-4a1b-970c-a0f9cd1d24f4))
  (segment (start 43.516 96.437) (end 44.361 97.282) (width 0.25) (layer "F.Cu") (net 63) (tstamp 79f65670-87b5-4d52-9b45-4ee01f989028))
  (segment (start 46.837 97.282) (end 47.599 96.52) (width 0.25) (layer "F.Cu") (net 63) (tstamp c77bf834-7544-4e7f-83c6-98cc807ef93d))
  (segment (start 44.361 97.282) (end 46.837 97.282) (width 0.25) (layer "F.Cu") (net 63) (tstamp e3653fef-5698-4cdd-9c47-e133f344a548))
  (segment (start 45.619 60.299) (end 46.101 59.817) (width 0.2) (layer "F.Cu") (net 64) (tstamp 04c80086-5520-4be2-bc3b-8904b2cc92a9))
  (segment (start 51.308 60.198) (end 51.308 61.657) (width 0.2) (layer "F.Cu") (net 64) (tstamp 4a65fbc3-01d3-4594-ab1c-66fee77172f2))
  (segment (start 45.619 61.722) (end 45.619 60.299) (width 0.25) (layer "F.Cu") (net 64) (tstamp 585014fc-e0de-4b3c-88c8-15706e4eee9c))
  (segment (start 50.927 59.817) (end 51.308 60.198) (width 0.2) (layer "F.Cu") (net 64) (tstamp 7c52d287-c1a0-4713-8460-8a635a118eb2))
  (segment (start 46.101 59.817) (end 50.927 59.817) (width 0.2) (layer "F.Cu") (net 64) (tstamp d2e3fb94-f256-4f83-9488-55bd51da7863))
  (segment (start 36.481486 97.54852) (end 37.116 96.914006) (width 0.2) (layer "F.Cu") (net 65) (tstamp 0ca435eb-a3a4-455b-a599-93a3d0d08989))
  (segment (start 37.116 96.914006) (end 37.116 95.851) (width 0.2) (layer "F.Cu") (net 65) (tstamp 0f7cdc0c-1fe6-4ca7-bd4e-d10a4dceab76))
  (segment (start 34.925 104.4702) (end 34.925 98.990006) (width 0.2) (layer "F.Cu") (net 65) (tstamp 10c50bef-e793-42eb-bf44-230cd3e8a938))
  (segment (start 36.366486 97.54852) (end 36.481486 97.54852) (width 0.2) (layer "F.Cu") (net 65) (tstamp 98f2285b-aa3f-456f-897a-888fe3cb6183))
  (segment (start 33.909 105.4862) (end 34.925 104.4702) (width 0.2) (layer "F.Cu") (net 65) (tstamp a4737fc9-0263-4536-bcc4-feb37aad09ef))
  (segment (start 33.909 106.381) (end 33.909 105.4862) (width 0.2) (layer "F.Cu") (net 65) (tstamp cdd7425a-6f28-4af8-b40f-cf4e8e448d2a))
  (segment (start 34.925 98.990006) (end 36.366486 97.54852) (width 0.2) (layer "F.Cu") (net 65) (tstamp e8db1e3f-d443-4e63-b9e0-1b410fb95b63))
  (segment (start 42.716 95.851) (end 42.716 96.851) (width 0.25) (layer "F.Cu") (net 66) (tstamp 6b2b33d0-bb42-4f1e-9579-64178b8552e7))
  (segment (start 46.616 98.533) (end 48.133 100.05) (width 0.25) (layer "F.Cu") (net 66) (tstamp af15f3e4-b458-488b-a454-bcd548aed661))
  (segment (start 42.716 96.851) (end 44.398 98.533) (width 0.25) (layer "F.Cu") (net 66) (tstamp d4b03db7-7e37-4c24-8ef4-555e8ad1c356))
  (segment (start 44.398 98.533) (end 46.616 98.533) (width 0.25) (layer "F.Cu") (net 66) (tstamp e9c619be-23f0-4b68-b1b9-3a878d409db1))
  (segment (start 35.87248 81.08448) (end 36.576 81.788) (width 0.2) (layer "F.Cu") (net 67) (tstamp 084092c0-2593-4aff-b5bf-4ff1107c3886))
  (segment (start 45.535994 58.42) (end 45.9105 58.42) (width 0.2) (layer "F.Cu") (net 67) (tstamp 1a065a3b-f9ce-46ae-9f2d-fc0781e9a1f0))
  (segment (start 37.916 82.423006) (end 37.916 83.509) (width 0.2) (layer "F.Cu") (net 67) (tstamp 1ae50e8b-c5cb-475a-9b6a-5a5a207db011))
  (segment (start 38.494972 65.532) (end 37.926557 66.100415) (width 0.2) (layer "F.Cu") (net 67) (tstamp 215f96fb-c255-4ded-875c-b341dba47daa))
  (segment (start 49.403 58.42) (end 47.117 58.42) (width 0.2) (layer "F.Cu") (net 67) (tstamp 22b8a414-869b-4d25-86ba-6d0e76cbb831))
  (segment (start 37.926557 71.039443) (end 35.87248 73.09352) (width 0.2) (layer "F.Cu") (net 67) (tstamp 367a6790-f7fa-473f-8139-4ac802354990))
  (segment (start 37.916 83.509) (end 37.916 84.451) (width 0.25) (layer "F.Cu") (net 67) (tstamp 3c867f10-4e8f-4d52-adb4-86368e531a10))
  (segment (start 37.926557 66.100415) (end 37.926557 71.039443) (width 0.2) (layer "F.Cu") (net 67) (tstamp 47bbf0eb-3301-469a-ab45-b0cb5c0143a4))
  (segment (start 45.974 58.42) (end 45.974 57.329) (width 0.2) (layer "F.Cu") (net 67) (tstamp 566a2631-e27f-4143-97e4-d38dfa6d0e19))
  (segment (start 43.815 63.357888) (end 43.815 60.140994) (width 0.2) (layer "F.Cu") (net 67) (tstamp 5d4efd51-eaef-40f6-94e5-91424413c602))
  (segment (start 43.807444 63.365444) (end 43.815 63.357888) (width 0.2) (layer "F.Cu") (net 67) (tstamp 6a28c7ad-9696-4aa6-8ffb-580e0ec841e4))
  (segment (start 45.9105 58.42) (end 45.974 58.3565) (width 0.2) (layer "F.Cu") (net 67) (tstamp 72a83b1a-0707-4524-ac04-be7600ef1149))
  (segment (start 47.117 58.42) (end 45.974 58.42) (width 0.2) (layer "F.Cu") (net 67) (tstamp 72dcbe8c-00a5-40b3-a9d7-4bb76585771d))
  (segment (start 50.038 56.707) (end 50.038 57.785) (width 0.25) (layer "F.Cu") (net 67) (tstamp 96e817f9-de75-44bd-a861-5024ed4d0765))
  (segment (start 43.815 60.140994) (end 45.535994 58.42) (width 0.2) (layer "F.Cu") (net 67) (tstamp 9c642650-505c-4b53-97bf-3ae039d2fd1c))
  (segment (start 43.815 65.446511) (end 43.729511 65.532) (width 0.2) (layer "F.Cu") (net 67) (tstamp b48bb59f-9d12-400b-90e1-e9a09f397928))
  (segment (start 50.038 57.785) (end 49.403 58.42) (width 0.2) (layer "F.Cu") (net 67) (tstamp c21b04f0-1375-49bc-b92d-8321bf0e4844))
  (segment (start 35.87248 73.09352) (end 35.87248 81.08448) (width 0.2) (layer "F.Cu") (net 67) (tstamp c5d41884-5c38-4eb5-bfac-788a646cb28e))
  (segment (start 37.280994 81.788) (end 37.916 82.423006) (width 0.2) (layer "F.Cu") (net 67) (tstamp ca7c3455-2ffb-4f7d-aac2-59b3deb5d235))
  (segment (start 36.576 81.788) (end 37.280994 81.788) (width 0.2) (layer "F.Cu") (net 67) (tstamp d4e6eb94-e28c-44cc-9cfe-e035e6d0d34d))
  (segment (start 45.974 58.3565) (end 45.974 57.329) (width 0.2) (layer "F.Cu") (net 67) (tstamp e7a28ded-df5b-42fb-ac4f-6adeef37e2a9))
  (segment (start 43.729511 65.532) (end 38.494972 65.532) (width 0.2) (layer "F.Cu") (net 67) (tstamp fb329e74-44be-4c93-a660-133e28b94c04))
  (via (at 43.807444 63.365444) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 67) (tstamp 1b875bd5-4166-402c-b7ad-32b120a08af4))
  (via (at 43.815 65.446511) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 67) (tstamp 51b0737d-e69d-46a1-badb-f4437551f65b))
  (segment (start 43.815 65.446511) (end 43.807444 65.438955) (width 0.2) (layer "B.Cu") (net 67) (tstamp 2daaad38-7e46-4f44-a105-86e7d34de68f))
  (segment (start 43.807444 65.438955) (end 43.807444 63.365444) (width 0.2) (layer "B.Cu") (net 67) (tstamp 424aed18-58dc-4f33-9d57-67b8bc66e524))
  (segment (start 36.703 98.552) (end 36.703 99.923) (width 0.2) (layer "F.Cu") (net 68) (tstamp 000c0c63-730a-4273-86da-1cc2f67d1eed))
  (segment (start 37.916 95.851) (end 37.916 97.339) (width 0.2) (layer "F.Cu") (net 68) (tstamp 1c7b18f1-b80f-47cc-a1e1-bd82ab4e2594))
  (segment (start 37.916 97.339) (end 36.703 98.552) (width 0.2) (layer "F.Cu") (net 68) (tstamp 7c0d62de-b413-43a7-89ad-c8c74ed212b5))
  (segment (start 41.916 95.851) (end 41.916 97.123) (width 0.25) (layer "F.Cu") (net 69) (tstamp 4a7d403b-8eb8-413a-97fe-b5f6b64e61d4))
  (segment (start 44.596 99.803) (end 44.596 100.031) (width 0.25) (layer "F.Cu") (net 69) (tstamp 7f4c8edb-79c2-418c-8e74-3e368ca2a89e))
  (segment (start 41.916 97.123) (end 44.596 99.803) (width 0.25) (layer "F.Cu") (net 69) (tstamp 9d16acdf-8bab-4a41-aefe-5b0e277e74e8))
  (segment (start 37.973 106.127) (end 38.227 106.381) (width 0.25) (layer "F.Cu") (net 70) (tstamp 166d7ec9-4f5f-4d25-b006-60c7c2f59875))
  (segment (start 38.716 95.851) (end 38.716 97.136) (width 0.25) (layer "F.Cu") (net 70) (tstamp 5fa640da-67f1-4f37-bd16-2762e197f70f))
  (segment (start 38.716 97.136) (end 38.862 97.282) (width 0.25) (layer "F.Cu") (net 70) (tstamp 6dc9b286-d6d6-4176-a8df-7865e8bc4028))
  (segment (start 38.862 97.282) (end 38.862 104.394) (width 0.25) (layer "F.Cu") (net 70) (tstamp 86379f84-ce1c-4262-83b6-d18177818010))
  (segment (start 38.862 104.394) (end 37.973 105.283) (width 0.25) (layer "F.Cu") (net 70) (tstamp 946fd173-2102-44b3-929a-e2a3ebb8d9f8))
  (segment (start 37.973 105.283) (end 37.973 106.127) (width 0.25) (layer "F.Cu") (net 70) (tstamp a8dde199-8874-4230-a58b-ad6adb2249bd))
  (segment (start 41.116 95.851) (end 41.116 97.085) (width 0.25) (layer "F.Cu") (net 71) (tstamp 31381662-664d-470a-a459-9f66a6f1227d))
  (segment (start 42.31 98.279) (end 42.31 105.0608) (width 0.25) (layer "F.Cu") (net 71) (tstamp 44c3daae-0aa5-4889-a284-7baf9b76bd52))
  (segment (start 41.116 97.085) (end 42.31 98.279) (width 0.25) (layer "F.Cu") (net 71) (tstamp 5a416573-5c35-441d-b9fc-371b22574e71))
  (segment (start 42.31 105.0608) (end 42.056 105.3148) (width 0.25) (layer "F.Cu") (net 71) (tstamp ccacdcd1-d0bc-436b-941b-462c4cbf4fb4))
  (segment (start 42.056 105.3148) (end 42.056 106.381) (width 0.25) (layer "F.Cu") (net 71) (tstamp d90fa6a0-4784-42e1-af46-dc5210700ca6))
  (segment (start 49.631 76.708) (end 48.514 76.708) (width 0.2) (layer "F.Cu") (net 72) (tstamp 5c00c343-7005-415b-880a-d4e27771e9b1))
  (segment (start 43.516 83.23) (end 43.516 84.451) (width 0.2) (layer "F.Cu") (net 72) (tstamp 7a747662-e576-45ab-9c63-de41e4fa1911))
  (segment (start 47.440994 82.804) (end 43.942 82.804) (width 0.2) (layer "F.Cu") (net 72) (tstamp 8fc3a160-2fb0-425f-a693-8fae325d7e4d))
  (segment (start 48.26 76.962) (end 48.26 81.984994) (width 0.2) (layer "F.Cu") (net 72) (tstamp 965637c0-83c0-4f01-8b3b-86e030fc4b04))
  (segment (start 43.942 82.804) (end 43.516 83.23) (width 0.2) (layer "F.Cu") (net 72) (tstamp cb6decf3-355b-40c8-a180-1a7c2050b52a))
  (segment (start 48.514 76.708) (end 48.26 76.962) (width 0.2) (layer "F.Cu") (net 72) (tstamp eefb310e-a27e-4e78-b7fa-6101fb64c9a1))
  (segment (start 48.26 81.984994) (end 47.440994 82.804) (width 0.2) (layer "F.Cu") (net 72) (tstamp fc7cee6d-9bba-436c-8b9c-cd3d18556245))
  (segment (start 42.716 84.451) (end 42.716 81.591) (width 0.25) (layer "F.Cu") (net 73) (tstamp 08860e92-5e14-49ab-a7a2-92535394cf7d))
  (segment (start 42.716 81.591) (end 43.789 80.518) (width 0.25) (layer "F.Cu") (net 73) (tstamp 505ab633-e83d-450d-9801-e708800bae65))
  (segment (start 42.291 81.28) (end 42.291 78.74) (width 0.25) (layer "F.Cu") (net 74) (tstamp 13e7c31f-c670-4d75-a0c1-92757c7a1b3a))
  (segment (start 41.916 84.451) (end 41.916 81.655) (width 0.25) (layer "F.Cu") (net 74) (tstamp 2f811882-51bc-4da6-8dcc-8d25afeb6203))
  (segment (start 41.916 81.655) (end 42.291 81.28) (width 0.25) (layer "F.Cu") (net 74) (tstamp 35661683-5bca-4af2-8ea0-b582cde30851))
  (segment (start 43.789 77.242) (end 44.069 77.242) (width 0.25) (layer "F.Cu") (net 74) (tstamp 9416bc75-6348-48f1-91a2-7590822c2766))
  (segment (start 42.291 78.74) (end 43.789 77.242) (width 0.25) (layer "F.Cu") (net 74) (tstamp 9fcfcf42-9fc7-4d0e-9513-9a62fa26c066))
  (segment (start 41.783 81.026) (end 41.783 78.766) (width 0.25) (layer "F.Cu") (net 75) (tstamp 1eede00b-8859-41db-b3c5-4d4f92390a32))
  (segment (start 41.116 84.451) (end 41.116 81.693) (width 0.25) (layer "F.Cu") (net 75) (tstamp 8af7e77d-f4bc-479f-bf68-44b6d52be431))
  (segment (start 41.783 78.766) (end 40.259 77.242) (width 0.25) (layer "F.Cu") (net 75) (tstamp c0b2572c-a5e0-46a9-883f-c133a81e0a27))
  (segment (start 41.116 81.693) (end 41.783 81.026) (width 0.25) (layer "F.Cu") (net 75) (tstamp f42662dc-4ec9-4bb1-801f-bbb494be8821))
  (segment (start 33.909 80.925) (end 34.443 80.925) (width 0.2) (layer "F.Cu") (net 76) (tstamp 2ed6005f-e0a8-4d85-9d00-63cab8f50940))
  (segment (start 34.443 80.925) (end 36.316 82.798) (width 0.2) (layer "F.Cu") (net 76) (tstamp 39f8bc1c-66d4-47df-ac60-8d491f8ab2bb))
  (segment (start 36.316 82.798) (end 36.316 84.451) (width 0.2) (layer "F.Cu") (net 76) (tstamp ac8f152a-0a63-41ac-ae79-84ea2d5736cc))
  (segment (start 48.39864 85.00216) (end 48.8188 84.582) (width 0.2) (layer "F.Cu") (net 77) (tstamp 13c9cdd2-6b6d-4d61-b5f8-386a9dab5ea7))
  (segment (start 48.39864 85.717366) (end 48.39864 85.00216) (width 0.2) (layer "F.Cu") (net 77) (tstamp 571c3f7d-76da-4d43-a7f8-f5840e58b021))
  (segment (start 46.365006 87.751) (end 48.39864 85.717366) (width 0.2) (layer "F.Cu") (net 77) (tstamp 668c728a-8c0d-4b5a-8c1e-da4c400d1528))
  (segment (start 45.216 87.751) (end 46.365006 87.751) (width 0.2) (layer "F.Cu") (net 77) (tstamp a778e1d9-2625-4ac8-8b2a-6628cf2f617a))
  (segment (start 48.8188 84.582) (end 49.758 84.582) (width 0.2) (layer "F.Cu") (net 77) (tstamp e6768f5b-58ad-4b07-8524-27ae94109134))
  (segment (start 47.99912 83.44588) (end 47.99912 85.55188) (width 0.2) (layer "F.Cu") (net 78) (tstamp 0457b488-dea8-40fd-b5dc-813fa621d1be))
  (segment (start 55.219 82.55) (end 48.895 82.55) (width 0.2) (layer "F.Cu") (net 78) (tstamp 1d1a44f8-4397-4733-b9e4-363121289cf1))
  (segment (start 55.219 82.55) (end 55.473 82.804) (width 0.25) (layer "F.Cu") (net 78) (tstamp 4c8acf4e-2520-4c6f-8d55-b72b0ef596cd))
  (segment (start 48.895 82.55) (end 47.99912 83.44588) (width 0.2) (layer "F.Cu") (net 78) (tstamp 5962da00-1d6c-4420-9256-68980ab19f84))
  (segment (start 47.99912 85.55188) (end 46.6 86.951) (width 0.2) (layer "F.Cu") (net 78) (tstamp 8ba3b99e-e93e-4b2d-bac2-5989b98dd128))
  (segment (start 46.6 86.951) (end 45.216 86.951) (width 0.2) (layer "F.Cu") (net 78) (tstamp effd2314-bf45-4c0f-b70a-e731c850b99a))
  (segment (start 47.5996 85.1154) (end 47.5996 83.2104) (width 0.2) (layer "F.Cu") (net 79) (tstamp 05e2005c-539b-460a-a1b2-3030444967ac))
  (segment (start 46.564 86.151) (end 47.5996 85.1154) (width 0.2) (layer "F.Cu") (net 79) (tstamp 81c27eb4-f4c8-44f3-9c96-b441d90e8ea8))
  (segment (start 47.5996 83.2104) (end 49.631 81.179) (width 0.2) (layer "F.Cu") (net 79) (tstamp 93345668-40f9-4f1e-a635-e8435a941754))
  (segment (start 45.216 86.151) (end 46.564 86.151) (width 0.2) (layer "F.Cu") (net 79) (tstamp f9508734-b677-4d1b-9578-68bdd121ebbc))
  (segment (start 49.631 81.179) (end 49.631 80.518) (width 0.2) (layer "F.Cu") (net 79) (tstamp fef5d704-de37-4456-b183-75afb8ef5989))
  (segment (start 26.271 49.276) (end 24.831 50.716) (width 0.25) (layer "F.Cu") (net 82) (tstamp 3ec4a624-a06e-424f-ba16-430f0841495e))
  (segment (start 29.656 48.641) (end 28.194 48.641) (width 0.25) (layer "F.Cu") (net 82) (tstamp 61bf439b-319a-4a36-b282-557b83288686))
  (segment (start 28.194 48.641) (end 27.559 49.276) (width 0.25) (layer "F.Cu") (net 82) (tstamp 64b75867-0251-4905-8f9e-b2498cba73ce))
  (segment (start 27.559 49.276) (end 26.271 49.276) (width 0.25) (layer "F.Cu") (net 82) (tstamp f9c5505e-3174-4837-a5b4-4abb85ae5261))
  (segment (start 27.536 49.911) (end 26.731 50.716) (width 0.25) (layer "F.Cu") (net 83) (tstamp 1febcd74-46f6-4d7a-8725-179c4dfbb93f))
  (segment (start 29.656 49.911) (end 27.536 49.911) (width 0.25) (layer "F.Cu") (net 83) (tstamp 281a94ed-709d-4456-ac0b-c6bfed08a1ae))
  (segment (start 25.084621 59.436) (end 27.987101 62.33848) (width 0.2) (layer "F.Cu") (net 85) (tstamp 011150e2-7038-408c-a0fa-16ed25904847))
  (segment (start 41.275 59.944) (end 40.894 60.325) (width 0.2) (layer "F.Cu") (net 85) (tstamp 04197b16-dc87-4f63-ae56-ee13783e059d))
  (segment (start 29.337 84.608) (end 29.337 85.8266) (width 0.25) (layer "F.Cu") (net 85) (tstamp 046510f3-922f-4790-9ca4-28d9010ca605))
  (segment (start 65.763798 92.560798) (end 64.897 91.694) (width 0.2) (layer "F.Cu") (net 85) (tstamp 0905d8cc-224f-4820-8980-e31efca09c09))
  (segment (start 40.767 90.043) (end 41.675 90.951) (width 0.25) (layer "F.Cu") (net 85) (tstamp 0b0109d9-37c6-4de0-8072-c8c299ebf052))
  (segment (start 51.9815 49.3645) (end 53.594 47.752) (width 0.25) (layer "F.Cu") (net 85) (tstamp 0d53f3f9-aa16-4205-8c83-30c48ea29060))
  (segment (start 74.041 112.014) (end 76.962 114.935) (width 1) (layer "F.Cu") (net 85) (tstamp 0fca3f94-6c41-4751-a87a-659e3406347c))
  (segment (start 86.106 94.996) (end 93.521 94.996) (width 1) (layer "F.Cu") (net 85) (tstamp 10abb9d9-0cf9-4dbd-b0e8-6aedb9eed3f2))
  (segment (start 90.043 113.665) (end 89.535 114.173) (width 3) (layer "F.Cu") (net 85) (tstamp 113437bb-95fb-4a1d-a5bd-4149037d5f39))
  (segment (start 53.721 59.309) (end 53.721 54.8255) (width 0.25) (layer "F.Cu") (net 85) (tstamp 11830dea-8d07-4ef4-a5a0-a7b56711c0d8))
  (segment (start 74.003511 91.604489) (end 74.003511 90.842489) (width 0.5) (layer "F.Cu") (net 85) (tstamp 13abcb2a-5560-4634-b5fd-4891930ac052))
  (segment (start 51.9815 49.8225) (end 51.9815 49.3645) (width 0.25) (layer "F.Cu") (net 85) (tstamp 13d3e04b-e165-41f9-a1f9-4bb37c0f96c8))
  (segment (start 89.535 127.381) (end 89.535 150.876) (width 3) (layer "F.Cu") (net 85) (tstamp 182a3617-fe7c-4ea9-afdf-a1117c1d6a9b))
  (segment (start 52.07 49.276) (end 51.562 49.784) (width 0.25) (layer "F.Cu") (net 85) (tstamp 1b73a441-697d-4e7e-9945-a8b040863e56))
  (segment (start 54.001 151.892) (end 55.245 151.892) (width 0.5) (layer "F.Cu") (net 85) (tstamp 1ccb0e30-b4da-48c0-b7c5-09eb51129f1e))
  (segment (start 31.3885 89.351) (end 33.816 89.351) (width 0.25) (layer "F.Cu") (net 85) (tstamp 1f2da0eb-eb58-4f7b-8ba9-adb49d8b7fdd))
  (segment (start 41.132873 61.849) (end 42.392 61.849) (width 0.2) (layer "F.Cu") (net 85) (tstamp 2a59351a-ce44-42d9-ae7e-93488fe176a8))
  (segment (start 39.516 96.916638) (end 39.28652 97.146118) (width 0.2) (layer "F.Cu") (net 85) (tstamp 2bf33066-ae22-4ba7-bf68-ac7b54f4aa0d))
  (segment (start 82.926 91.816) (end 86.106 94.996) (width 1) (layer "F.Cu") (net 85) (tstamp 2d167002-7aed-4aad-9dc3-8eb880036ff2))
  (segment (start 44.704 52.832) (end 45.339 52.832) (width 0.2) (layer "F.Cu") (net 85) (tstamp 2e777a9c-aa19-4262-87b2-10f1d9cf24dc))
  (segment (start 40.075 89.351) (end 40.767 90.043) (width 0.25) (layer "F.Cu") (net 85) (tstamp 3173a2cc-8256-4b18-9962-e49393cd0830))
  (segment (start 52.578 60.452) (end 52.578 61.657) (width 0.25) (layer "F.Cu") (net 85) (tstamp 33f3f316-6d44-4450-98fb-bcc3e343b78d))
  (segment (start 39.497 49.149) (end 39.878 49.53) (width 0.25) (layer "F.Cu") (net 85) (tstamp 35b28cdf-4cd2-4716-bbb7-db96965c94ed))
  (segment (start 32.4235 55.626) (end 32.4235 49.6185) (width 0.25) (layer "F.Cu") (net 85) (tstamp 36f3977c-b0b2-4dc5-931b-0ab08d47b0df))
  (segment (start 47.498 51.689) (end 46.355 52.832) (width 0.2) (layer "F.Cu") (net 85) (tstamp 3bae6097-7cd6-434b-8d6a-6a4fd5a38b8e))
  (segment (start 53.721 59.309) (end 52.578 60.452) (width 0.25) (layer "F.Cu") (net 85) (tstamp 4202a571-806b-481f-aeac-e8c09acd68ef))
  (segment (start 40.316 80.7535) (end 41.0785 79.991) (width 0.25) (layer "F.Cu") (net 85) (tstamp 422961d8-378b-4910-850a-3d2e330c7fb8))
  (segment (start 44.069 58.293) (end 44.069 53.467) (width 0.2) (layer "F.Cu") (net 85) (tstamp 44009b37-34b2-4033-b3c2-4a45be1fad5d))
  (segment (start 29.337 85.8266) (end 30.0228 86.5124) (width 0.25) (layer "F.Cu") (net 85) (tstamp 4471ea8d-0ba2-4e9b-8f2c-6f6d401c028e))
  (segment (start 42.418 59.944) (end 44.069 58.293) (width 0.2) (layer "F.Cu") (net 85) (tstamp 44ffcb83-77ef-48fb-890b-6931cb565e93))
  (segment (start 51.9815 53.086) (end 51.9815 49.8225) (width 0.25) (layer "F.Cu") (net 85) (tstamp 4565427c-e58d-4879-a3d3-6b7e350371af))
  (segment (start 37.973 49.149) (end 36.576 49.149) (width 0.2) (layer "F.Cu") (net 85) (tstamp 4689bc3e-e832-4c5a-b739-77e2c46562d7))
  (segment (start 107.7335 100.1785) (end 98.7035 100.1785) (width 3) (layer "F.Cu") (net 85) (tstamp 47ef2166-8168-444b-9e4a-5f6695f33d92))
  (segment (start 37.973 47.827) (end 37.973 49.149) (width 0.2) (layer "F.Cu") (net 85) (tstamp 48f333bd-f70d-4aa3-9747-4cd84e376257))
  (segment (start 40.316 89.592) (end 40.767 90.043) (width 0.25) (layer "F.Cu") (net 85) (tstamp 4a96cf48-f77d-47a1-a75b-f847efb05faf))
  (segment (start 70.858018 91.694) (end 73.914 91.694) (width 0.5) (layer "F.Cu") (net 85) (tstamp 4ad9c6f0-1a79-446a-ba90-0c1d0bd2c610))
  (segment (start 39.28652 97.146118) (end 39.28652 101.04702) (width 0.2) (layer "F.Cu") (net 85) (tstamp 4bdd2ef4-6298-497c-aaa4-50480e333972))
  (segment (start 74.003511 90.842489) (end 74.041 90.805) (width 0.25) (layer "F.Cu") (net 85) (tstamp 538290e9-c4ac-4c10-b3e5-447d7a0cc544))
  (segment (start 62.738 91.346) (end 63.152 91.346) (width 0.2) (layer "F.Cu") (net 85) (tstamp 5426bf28-18e0-4929-a6d6-c14c8ef71054))
  (segment (start 56.769 153.416) (end 56.769 160.528) (width 0.5) (layer "F.Cu") (net 85) (tstamp 54575979-f8f6-4733-a885-5aa3bf1091ca))
  (segment (start 44.069 53.467) (end 44.704 52.832) (width 0.2) (layer "F.Cu") (net 85) (tstamp 5a9003b2-f265-4a6d-889d-97bada659ebc))
  (segment (start 62.17152 111.62452) (end 59.309 108.762) (width 0.25) (layer "F.Cu") (net 85) (tstamp 5ae8b4a0-788a-4cef-bb23-b3752d143f4a))
  (segment (start 94.869 108.585) (end 94.869 108.839) (width 3) (layer "F.Cu") (net 85) (tstamp 5cd06247-2c46-451e-9cb6-36c52f6423d3))
  (segment (start 69.215 50.8) (end 69.215 70.866) (width 1) (layer "F.Cu") (net 85) (tstamp 5e4c9ca7-5f67-46aa-b693-ee5f76914b20))
  (segment (start 77.343 31.242) (end 76.85352 31.73148) (width 0.2) (layer "F.Cu") (net 85) (tstamp 5f438c49-cbaa-46d5-8934-bfb13a6b3456))
  (segment (start 53.467 90.805) (end 54.356 89.916) (width 0.5) (layer "F.Cu") (net 85) (tstamp 6415595e-e186-4385-952e-df5b054bc240))
  (segment (start 46.355 52.832) (end 45.339 52.832) (width 0.2) (layer "F.Cu") (net 85) (tstamp 64c2eefa-5d7a-4800-a521-781382c57222))
  (segment (start 49.676 91.7135) (end 48.9135 90.951) (width 0.5) (layer "F.Cu") (net 85) (tstamp 65f84377-eca5-41d1-8af7-f8ad90568605))
  (segment (start 53.594 47.752) (end 55.372 47.752) (width 0.25) (layer "F.Cu") (net 85) (tstamp 66790b5f-794b-43a2-8760-4ab9ad3d5420))
  (segment (start 98.7035 100.1785) (end 94.869 104.013) (width 3) (layer "F.Cu") (net 85) (tstamp 67efe67f-e7cf-42e7-a8b3-42c58beab4be))
  (segment (start 32.4235 49.6185) (end 33.401 48.641) (width 0.25) (layer "F.Cu") (net 85) (tstamp 6a63da42-79ed-44f7-8cbe-dc1fc86ce566))
  (segment (start 65.763798 100.098202) (end 65.763798 92.560798) (width 0.2) (layer "F.Cu") (net 85) (tstamp 6f4d5c06-cb97-4fa5-9a66-ebc7e66b7c93))
  (segment (start 34.391 55.626) (end 34.772 55.245) (width 0.2) (layer "F.Cu") (net 85) (tstamp 71176923-d1b5-4106-bb0c-9eed95cc7449))
  (segment (start 54.102 59.69) (end 55.245 59.69) (width 0.2) (layer "F.Cu") (net 85) (tstamp 7147703a-27e5-4444-b511-9bc501aa2346))
  (segment (start 93.521 94.996) (end 98.7035 100.1785) (width 1) (layer "F.Cu") (net 85) (tstamp 72c931f3-5775-476c-95f4-3f093477321b))
  (segment (start 62.771 51.308) (end 62.771 47.846) (width 0.5) (layer "F.Cu") (net 85) (tstamp 73a170cd-9ccc-4de8-b1e9-66b54ed858cd))
  (segment (start 66.167 47.752) (end 69.215 50.8) (width 1) (layer "F.Cu") (net 85) (tstamp 743f70de-601d-4666-b4be-afb95cb3f483))
  (segment (start 53.721 54.8255) (end 51.9815 53.086) (width 0.25) (layer "F.Cu") (net 85) (tstamp 75e50b70-4c7c-4600-9e78-c3292a569ded))
  (segment (start 36.068 48.641) (end 34.606 48.641) (width 0.2) (layer "F.Cu") (net 85) (tstamp 76137b7e-978f-425b-94fe-1221e30f478a))
  (segment (start 76.85352 31.73148) (end 69.99552 31.73148) (width 0.2) (layer "F.Cu") (net 85) (tstamp 79955ce7-7510-4a9d-a4bf-09ad51eec412))
  (segment (start 47.498 49.784) (end 47.498 51.689) (width 0.2) (layer "F.Cu") (net 85) (tstamp 7a504209-40f0-4a09-b3ed-b842e8c7b2d4))
  (segment (start 39.516 93.11) (end 39.516 95.851) (width 0.25) (layer "F.Cu") (net 85) (tstamp 7b4e7987-895e-4097-9514-a63f1ae8ea01))
  (segment (start 53.4545 91.4785) (end 53.467 91.466) (width 0.2) (layer "F.Cu") (net 85) (tstamp 7c53e19c-0d55-4071-bed5-6f3457b5c533))
  (segment (start 54.356 89.916) (end 60.198 89.916) (width 0.5) (layer "F.Cu") (net 85) (tstamp 7d3d70a9-0c7a-4f2a-9778-e474c0953077))
  (segment (start 88.519 114.935) (end 88.9 114.935) (width 1) (layer "F.Cu") (net 85) (tstamp 7dc3cde0-ef3b-4268-a408-c774c642f7f7))
  (segment (start 23.794 59.436) (end 24.511 59.436) (width 0.25) (layer "F.Cu") (net 85) (tstamp 7fee1845-5eda-42f7-8edb-dab5cbe3d56c))
  (segment (start 53.721 59.309) (end 54.102 59.69) (width 0.2) (layer "F.Cu") (net 85) (tstamp 82810cf1-6a34-463d-8e02-ec1d0de58f3d))
  (segment (start 40.894 60.325) (end 40.894 61.610127) (width 0.2) (layer "F.Cu") (net 85) (tstamp 87086822-cfb1-48da-910f-88904436e621))
  (segment (start 59.309 108.762) (end 60.91 108.762) (width 0.25) (layer "F.Cu") (net 85) (tstamp 88cf24bc-f31c-4b27-a93e-3f5962b57fee))
  (segment (start 59.309 163.068) (end 77.724 163.068) (width 0.5) (layer "F.Cu") (net 85) (tstamp 8a00a64f-1054-4fed-bf48-37c9acfd3b4a))
  (segment (start 55.245 59.69) (end 55.753 60.198) (width 0.2) (layer "F.Cu") (net 85) (tstamp 8cb752c7-8e98-402f-9e8a-3115945d1e9d))
  (segment (start 65.405 142.392) (end 65.405 137.287) (width 0.25) (layer "F.Cu") (net 85) (tstamp 8ce64723-bc14-445e-87a3-0be70daeee23))
  (segment (start 74.041 90.805) (end 74.041 112.014) (width 1) (layer "F.Cu") (net 85) (tstamp 8e1c2f5a-3474-4094-869f-0f0481a8ad72))
  (segment (start 51.562 49.784) (end 47.498 49.784) (width 0.25) (layer "F.Cu") (net 85) (tstamp 8e3c1105-b86e-439e-a37c-f4b0a2d23cd3))
  (segment (start 27.987101 62.33848) (end 40.643393 62.33848) (width 0.2) (layer "F.Cu") (net 85) (tstamp 8ebe50ea-e9c7-411a-9912-040a0d683fe6))
  (segment (start 42.392 61.849) (end 42.519 61.722) (width 0.25) (layer "F.Cu") (net 85) (tstamp 920dd651-35ea-4c79-be89-7263910649ca))
  (segment (start 76.962 114.935) (end 88.519 114.935) (width 1) (layer "F.Cu") (net 85) (tstamp 9364b856-fe08-4e8d-be61-9b9dbd3babb2))
  (segment (start 41.675 90.951) (end 39.516 93.11) (width 0.25) (layer "F.Cu") (net 85) (tstamp 97b28488-93bb-4f80-a5eb-e40199e92ce8))
  (segment (start 64.545545 93.696455) (end 63.881 94.361) (width 0.2) (layer "F.Cu") (net 85) (tstamp a1d42899-ebcc-47f1-aa7f-8a62648faf2e))
  (segment (start 24.511 59.436) (end 25.084621 59.436) (width 0.2) (layer "F.Cu") (net 85) (tstamp a333a17d-f0eb-4542-acae-68647a478a3a))
  (segment (start 63.246 30.226) (end 64.871 30.226) (width 0.2) (layer "F.Cu") (net 85) (tstamp a5d82a35-8ef5-4b04-beb6-6ef8457b4825))
  (segment (start 89.535 150.876) (end 85.09 155.321) (width 3) (layer "F.Cu") (net 85) (tstamp a6009425-f319-44c1-85da-fceca1a63d25))
  (segment (start 31.3885 89.351) (end 29.991 87.9535) (width 0.25) (layer "F.Cu") (net 85) (tstamp a6a56465-447d-40b8-9d63-68ed87aae7dd))
  (segment (start 94.869 108.839) (end 90.043 113.665) (width 3) (layer "F.Cu") (net 85) (tstamp a6b63220-2b1a-4f6f-bdfa-bd9cccc00cf5))
  (segment (start 60.198 89.916) (end 61.628 91.346) (width 0.5) (layer "F.Cu") (net 85) (tstamp a86608fd-749b-4b62-b9c7-fbf5fa44c8be))
  (segment (start 77.724 163.068) (end 79.121 161.671) (width 0.5) (layer "F.Cu") (net 85) (tstamp a9112cc2-af67-4d36-a237-d6d901b6a9ae))
  (segment (start 82.926 88.646) (end 82.926 91.816) (width 1) (layer "F.Cu") (net 85) (tstamp ab22eafd-f2fb-4744-a6c9-c1c66b7676bb))
  (segment (start 69.909559 31.682559) (end 69.655559 31.682559) (width 0.2) (layer "F.Cu") (net 85) (tstamp ab3a03fa-b4b2-4950-8343-34b28ddaaac2))
  (segment (start 65.405 137.287) (end 62.17152 134.05352) (width 0.25) (layer "F.Cu") (net 85) (tstamp ac55e8b6-dc80-44dd-af52-bc10b17213db))
  (segment (start 33.401 48.641) (end 34.606 48.641) (width 0.25) (layer "F.Cu") (net 85) (tstamp ac931682-4f7b-4518-a8c3-2b706f7158a8))
  (segment (start 62.17152 134.05352) (end 62.17152 111.62452) (width 0.25) (layer "F.Cu") (net 85) (tstamp ad460c73-0a8f-4c1f-a39d-43f175fa3080))
  (segment (start 94.869 104.013) (end 94.869 108.585) (width 3) (layer "F.Cu") (net 85) (tstamp ad866545-64ed-449d-a70f-b141df1d06f8))
  (segment (start 45.974 52.832) (end 45.339 52.832) (width 0.2) (layer "F.Cu") (net 85) (tstamp b0807788-d907-47b0-b3d3-f98aaf052176))
  (segment (start 47.498 49.784) (end 42.052112 49.784) (width 0.25) (layer "F.Cu") (net 85) (tstamp b15a2db0-9a29-47b4-9f86-554fd735820c))
  (segment (start 40.316 84.451) (end 40.316 89.592) (width 0.25) (layer "F.Cu") (net 85) (tstamp b51a594b-6d69-451d-b88b-6407fa12d516))
  (segment (start 65.763797 93.696455) (end 64.545545 93.696455) (width 0.2) (layer "F.Cu") (net 85) (tstamp b57524b7-714e-4b8b-b410-30be07a5547e))
  (segment (start 61.628 91.346) (end 62.865 91.346) (width 0.5) (layer "F.Cu") (net 85) (tstamp b772e538-cbb8-44b6-922e-66b8d7064e6e))
  (segment (start 39.28652 101.04702) (end 40.64 102.4005) (width 0.2) (layer "F.Cu") (net 85) (tstamp b82bfd31-5c75-4170-bd78-f57182014913))
  (segment (start 63.086 91.694) (end 62.738 91.346) (width 0.25) (layer "F.Cu") (net 85) (tstamp baa36e7e-b2c3-463c-8a08-3f5d9d15e983))
  (segment (start 40.316 84.451) (end 40.316 80.7535) (width 0.25) (layer "F.Cu") (net 85) (tstamp bb80f24c-a58d-4e75-baa9-eab71ea175c6))
  (segment (start 53.467 91.466) (end 53.467 90.805) (width 0.5) (layer "F.Cu") (net 85) (tstamp bd51bf03-65af-46b2-835c-2823d36ba121))
  (segment (start 64.153536 101.708464) (end 65.763798 100.098202) (width 0.2) (layer "F.Cu") (net 85) (tstamp be0b1b62-0ee9-4542-b96e-277f075a0e85))
  (segment (start 56.769 160.528) (end 59.309 163.068) (width 0.5) (layer "F.Cu") (net 85) (tstamp c0f1e0e6-55f3-42e4-aed8-68190bd44d44))
  (segment (start 41.675 90.951) (end 45.216 90.951) (width 0.3) (layer "F.Cu") (net 85) (tstamp c5840cbd-57be-49e9-97c1-5da5ce6eb245))
  (segment (start 37.973 49.149) (end 39.497 49.149) (width 0.25) (layer "F.Cu") (net 85) (tstamp c5efaa8d-0eaa-44fd-bc04-76920e5f42f4))
  (segment (start 30.0228 86.5124) (end 30.0228 87.5407) (width 0.25) (layer "F.Cu") (net 85) (tstamp c884e3b6-78db-4da5-99d1-88fa0df84af4))
  (segment (start 36.576 49.149) (end 36.068 48.641) (width 0.2) (layer "F.Cu") (net 85) (tstamp c9af5a14-ec16-497c-aa63-814ad851b4ec))
  (segment (start 45.974 54.229) (end 45.974 52.832) (width 0.2) (layer "F.Cu") (net 85) (tstamp cd03ef1d-3919-46b3-8cbb-8700330f0eeb))
  (segment (start 65.763797 92.560797) (end 65.763797 93.696455) (width 0.2) (layer "F.Cu") (net 85) (tstamp d11b2d3e-e7cb-4a61-8480-fcefefae55db))
  (segment (start 40.894 61.610127) (end 41.132873 61.849) (width 0.2) (layer "F.Cu") (net 85) (tstamp d322353c-acdd-429b-813f-48f7ae68a417))
  (segment (start 32.4235 55.626) (end 34.391 55.626) (width 0.2) (layer "F.Cu") (net 85) (tstamp d566eb8e-821d-496b-a7f4-bfc167318125))
  (segment (start 79.121 161.671) (end 79.121 160.9185) (width 0.5) (layer "F.Cu") (net 85) (tstamp dbe4f9ea-4377-4a3a-add7-ca545bfa57da))
  (segment (start 39.516 95.851) (end 39.516 96.916638) (width 0.2) (layer "F.Cu") (net 85) (tstamp df061125-9c42-443b-a5e4-152e7638aade))
  (segment (start 48.9135 90.951) (end 45.216 90.951) (width 0.5) (layer "F.Cu") (net 85) (tstamp e035fa56-f00f-44e2-a168-fbdefa14bbde))
  (segment (start 55.753 60.198) (end 55.753 61.24) (width 0.2) (layer "F.Cu") (net 85) (tstamp e26942ae-1523-4175-8714-e03a8184ee9a))
  (segment (start 63.881 94.361) (end 63.881 95.351) (width 0.2) (layer "F.Cu") (net 85) (tstamp e294cb56-a030-4896-a5e6-1c058ea9168e))
  (segment (start 63.54 144.257) (end 65.405 142.392) (width 0.25) (layer "F.Cu") (net 85) (tstamp e4948f6f-565c-4ab3-88b8-b7d5439391b9))
  (segment (start 42.052112 49.784) (end 42.044556 49.791556) (width 0.25) (layer "F.Cu") (net 85) (tstamp e6643ba3-9ec8-4f07-9e30-def9250f55c4))
  (segment (start 64.897 91.694) (end 65.763797 92.560797) (width 0.2) (layer "F.Cu") (net 85) (tstamp e6d884ee-7f5e-47db-a644-bc4355d73495))
  (segment (start 40.643393 62.33848) (end 41.132873 61.849) (width 0.2) (layer "F.Cu") (net 85) (tstamp e7e31087-a547-489c-adda-c0db554b0d3e))
  (segment (start 74.041 75.692) (end 74.041 90.805) (width 1) (layer "F.Cu") (net 85) (tstamp eb2db18c-cfbe-4072-b36d-e9460d9d686b))
  (segment (start 73.914 91.694) (end 74.003511 91.604489) (width 0.5) (layer "F.Cu") (net 85) (tstamp eb7cf95d-f31d-43e4-93cd-c72a4c82d77d))
  (segment (start 85.09 155.321) (end 83.439 155.321) (width 3) (layer "F.Cu") (net 85) (tstamp ebe7e015-8176-4408-a707-8a794c3c96be))
  (segment (start 69.215 70.866) (end 74.041 75.692) (width 1) (layer "F.Cu") (net 85) (tstamp ec2a0a22-45b0-4b9c-9a33-5fadfec574fc))
  (segment (start 69.977 31.75) (end 69.909559 31.682559) (width 0.2) (layer "F.Cu") (net 85) (tstamp edba4063-f2bb-4f62-8670-493c7ebfc5f7))
  (segment (start 42.418 59.944) (end 41.275 59.944) (width 0.2) (layer "F.Cu") (net 85) (tstamp eedcd431-b23c-4a85-aca9-197407a2349a))
  (segment (start 80.1765 88.646) (end 82.926 88.646) (width 0.25) (layer "F.Cu") (net 85) (tstamp ef83dbb0-5739-412a-9513-fd094508ef06))
  (segment (start 60.91 108.762) (end 63.754 105.918) (width 0.25) (layer "F.Cu") (net 85) (tstamp f1cc2818-efe8-4fe7-bd7e-d2844a11543d))
  (segment (start 89.535 114.173) (end 89.535 122.809) (width 3) (layer "F.Cu") (net 85) (tstamp f2b9ecef-7804-4cc5-a90d-5b88305c326a))
  (segment (start 55.372 47.752) (end 62.738 47.752) (width 0.5) (layer "F.Cu") (net 85) (tstamp f5890d22-612a-485a-a9d0-8e7da4588171))
  (segment (start 64.897 91.694) (end 63.086 91.694) (width 0.5) (layer "F.Cu") (net 85) (tstamp f5a73985-2068-4734-9ed2-58c5544b908a))
  (segment (start 55.245 151.892) (end 56.769 153.416) (width 0.5) (layer "F.Cu") (net 85) (tstamp f681fa4a-db7b-4625-b5bb-0ffed2df6301))
  (segment (start 63.749164 101.708464) (end 64.153536 101.708464) (width 0.2) (layer "F.Cu") (net 85) (tstamp f6fc7ebe-dde6-4140-b0b1-46c5e5454274))
  (segment (start 33.816 89.351) (end 40.075 89.351) (width 0.25) (layer "F.Cu") (net 85) (tstamp f80d7acd-3440-499a-86d4-b61b662be336))
  (segment (start 62.738 47.752) (end 66.167 47.752) (width 1) (layer "F.Cu") (net 85) (tstamp fae77484-00ec-4c09-9ab4-2fcd2d4f5b9b))
  (segment (start 50.038 91.4785) (end 53.4545 91.4785) (width 0.5) (layer "F.Cu") (net 85) (tstamp fe796022-7ba3-4617-bf4d-082a282b19f1))
  (via (at 88.519 114.935) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 85) (tstamp 0f427ad7-7d8e-4b9c-bf2d-fcb4a278f9d6))
  (via (at 63.749164 101.708464) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 85) (tstamp 1748a20f-8877-48ca-a31e-5da210a24e5a))
  (via (at 98.298 99.568) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 85) (tstamp 18ed4d36-ea7c-4061-b6b1-d9c135afb405))
  (via (at 90.17 127.127) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 85) (tstamp 1f763ef1-6636-4d5c-85ae-676d4766fac9))
  (via (at 88.9 127.127) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 85) (tstamp 293c886f-bec0-4454-a6a7-98590c957c3e))
  (via (at 105.537 99.441) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 85) (tstamp 2b36d8d7-5820-42f0-87f3-675d1e497f93))
  (via (at 69.655559 31.682559) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 85) (tstamp 2f47b756-fa5e-441b-9b3a-616c260c1c55))
  (via (at 63.754 105.918) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 85) (tstamp 37229425-915b-4873-be1b-81f90d486a7e))
  (via (at 88.9 123.19) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 85) (tstamp 46f89422-777d-40da-b2a5-d2165834f7b2))
  (via (at 88.646 139.573) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 85) (tstamp 4914fad4-8db8-463d-acf0-0e0bdd9e8ddb))
  (via (at 42.044556 49.791556) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 85) (tstamp 69049dc8-1605-492d-8e3c-33c902c3df74))
  (via (at 88.646 138.684) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 85) (tstamp 8d6faf2e-5cd8-41de-9f05-e6de4888b7b0))
  (via (at 88.646 149.479) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 85) (tstamp 9da83388-5f3a-43b7-85bf-37647397c029))
  (via (at 64.897 91.694) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 85) (tstamp 9f2d2032-7acb-47e3-ade8-47506453593c))
  (via (at 105.537 100.838) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 85) (tstamp a1739b17-3345-44cc-9ed6-57db3caf597c))
  (via (at 88.646 148.59) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 85) (tstamp a383ac21-54a0-4d04-a882-819d8c4b437b))
  (via (at 39.878 49.53) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 85) (tstamp b65894db-a0c9-4cb3-bfc3-b9ddf17f2eb2))
  (via (at 63.246 30.226) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 85) (tstamp b882bed7-bb4a-4e10-ae34-9ebf4245cf9a))
  (via (at 80.1765 88.646) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 85) (tstamp d3ea6147-2d06-4266-b812-13c551b916da))
  (via (at 82.677 155.575) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 85) (tstamp d7c722fd-9126-4a7f-b10d-db4bd5d41a96))
  (via (at 70.858018 91.694) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 85) (tstamp d84c2c27-7184-4236-ad9b-84526ccc7c24))
  (via (at 83.693 155.575) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 85) (tstamp da213d7e-94fd-4cc6-9510-18218c56ac23))
  (via (at 84.709 155.575) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 85) (tstamp dfbaf842-1dec-4eb8-bbbf-40054f88a200))
  (via (at 90.17 123.19) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 85) (tstamp e8b8b8e9-494e-4f56-a138-48c3ded56909))
  (via (at 77.343 31.242) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 85) (tstamp fc22e424-3131-4026-b817-cce2f12e1c20))
  (segment (start 86.995 139.066651) (end 89.406349 139.066651) (width 1) (layer "B.Cu") (net 85) (tstamp 05ad1daa-53c8-4ecf-acd3-0ebd851f4fc3))
  (segment (start 70.858018 91.694) (end 64.897 91.694) (width 0.5) (layer "B.Cu") (net 85) (tstamp 075601dd-4383-4c68-8fc1-1b1c6e44a372))
  (segment (start 79.121 158.3785) (end 82.5595 154.94) (width 0.5) (layer "B.Cu") (net 85) (tstamp 07e7046a-4c3c-43a4-bf92-5b4e556a33b6))
  (segment (start 81.661 160.9185) (end 81.661 158.3785) (width 0.5) (layer "B.Cu") (net 85) (tstamp 185f54c8-c202-4537-8925-58152bbf2658))
  (segment (start 89.409651 148.972651) (end 89.535 149.098) (width 1) (layer "B.Cu") (net 85) (tstamp 1e1994bd-cc87-4e57-b134-c30a0021abfc))
  (segment (start 85.09 155.321) (end 89.535 150.876) (width 3) (layer "B.Cu") (net 85) (tstamp 1ef3e631-799b-418b-becb-7706a587ace5))
  (segment (start 76.7588 45.0088) (end 77.343 45.593) (width 0.2) (layer "B.Cu") (net 85) (tstamp 203d1e20-fbd9-4b09-8729-359c92f1e2bc))
  (segment (start 94.869 104.013) (end 94.869 108.839) (width 3) (layer "B.Cu") (net 85) (tstamp 20495797-4826-4585-a8b6-84311bfaf046))
  (segment (start 80.137 81.357224) (end 79.883 81.103224) (width 0.25) (layer "B.Cu") (net 85) (tstamp 22c2b224-47cd-4357-b721-c5f43b4c8f41))
  (segment (start 84.328 155.321) (end 83.439 155.321) (width 3) (layer "B.Cu") (net 85) (tstamp 24111178-276b-43e4-976b-050c1f12b548))
  (segment (start 89.535 114.173) (end 89.535 128.778) (width 3) (layer "B.Cu") (net 85) (tstamp 252c84a5-fdf7-4e03-bac9-eb0dd53603f8))
  (segment (start 63.246 31.369) (end 63.246 30.226) (width 0.2) (layer "B.Cu") (net 85) (tstamp 3645a40a-b275-4ee7-b1f7-d0b9431f9f69))
  (segment (start 78.575511 46.825511) (end 77.343 45.593) (width 0.25) (layer "B.Cu") (net 85) (tstamp 3ace66e3-83d8-4be4-9ce0-088df20a9cad))
  (segment (start 94.869 108.839) (end 89.535 114.173) (width 3) (layer "B.Cu") (net 85) (tstamp 3d061846-7942-42e3-b06e-290d01c7f709))
  (segment (start 80.1765 88.646) (end 80.137 88.6065) (width 0.25) (layer "B.Cu") (net 85) (tstamp 45642366-6066-4b0b-9875-ad16b778412a))
  (segment (start 77.804897 41.185489) (end 76.7588 42.231586) (width 0.2) (layer "B.Cu") (net 85) (tstamp 46a14df9-9299-44bc-b600-200ade980716))
  (segment (start 63.881 32.004) (end 63.246 31.369) (width 0.2) (layer "B.Cu") (net 85) (tstamp 559a2d08-b72e-401d-b99e-56ac73c51e11))
  (segment (start 81.661 156.464) (end 83.185 154.94) (width 0.5) (layer "B.Cu") (net 85) (tstamp 595fd9f8-388d-4253-84ab-dbb86df83d03))
  (segment (start 78.232 32.258) (end 78.232 40.767) (width 0.2) (layer "B.Cu") (net 85) (tstamp 5a0e5f8c-d355-4206-a262-534dca66877c))
  (segment (start 78.486 51.181) (end 78.575511 51.091489) (width 0.25) (layer "B.Cu") (net 85) (tstamp 5bf68fab-fa80-4d20-91f5-9ea32057bf3f))
  (segment (start 89.535 138.938) (end 89.535 149.098) (width 3) (layer "B.Cu") (net 85) (tstamp 65e9f675-15c5-49f7-9943-af8a35ab7a9b))
  (segment (start 79.121 160.9185) (end 79.121 158.3785) (width 0.5) (layer "B.Cu") (net 85) (tstamp 68f67c2b-1667-451a-ba99-230786feddd0))
  (segment (start 78.232 40.767) (end 77.813511 41.185489) (width 0.2) (layer "B.Cu") (net 85) (tstamp 7a9e351f-3318-44fc-9869-3e2fa9256067))
  (segment (start 86.741 148.972651) (end 89.409651 148.972651) (width 1) (layer "B.Cu") (net 85) (tstamp 83dde932-26b4-4062-8eb3-c27e3ab557c8))
  (segment (start 89.535 128.778) (end 89.535 138.938) (width 3) (layer "B.Cu") (net 85) (tstamp 8436feb4-c074-43f8-bcef-cc1e21778423))
  (segment (start 40.139556 49.791556) (end 39.878 49.53) (width 0.25) (layer "B.Cu") (net 85) (tstamp 8708c57d-e4a4-4a36-ba29-dd33bef238d7))
  (segment (start 78.232 32.258) (end 78.232 32.122386) (width 0.25) (layer "B.Cu") (net 85) (tstamp 8798789b-f7f0-49f5-9c48-4dee4fc722e3))
  (segment (start 69.334118 32.004) (end 63.881 32.004) (width 0.2) (layer "B.Cu") (net 85) (tstamp 88823ed2-6b50-42d5-a8bb-98746075ce1c))
  (segment (start 107.7335 100.1785) (end 98.7035 100.1785) (width 3) (layer "B.Cu") (net 85) (tstamp 88a455d0-bbbe-4b1e-b731-95f871312a7a))
  (segment (start 77.851 69.596) (end 77.851 65.9765) (width 0.25) (layer "B.Cu") (net 85) (tstamp 8bbb6782-690e-406c-8470-8fb741f01b0a))
  (segment (start 79.883 81.103224) (end 79.883 71.628) (width 0.25) (layer "B.Cu") (net 85) (tstamp 920980eb-d9b2-4054-90cc-16ea0607f2fe))
  (segment (start 84.328 155.321) (end 85.09 155.321) (width 3) (layer "B.Cu") (net 85) (tstamp 9321d6be-2017-463c-af1e-266b3ec34f82))
  (segment (start 80.137 88.6065) (end 80.137 81.357224) (width 0.25) (layer "B.Cu") (net 85) (tstamp 97191758-02d7-425a-b206-3239c9aba758))
  (segment (start 84.328 155.321) (end 84.201 155.448) (width 0.5) (layer "B.Cu") (net 85) (tstamp 9da93be9-295b-4215-aaab-c78ddbbe0ec5))
  (segment (start 69.655559 31.682559) (end 69.334118 32.004) (width 0.25) (layer "B.Cu") (net 85) (tstamp 9f84ad9e-1415-4981-bfe6-061dcb817920))
  (segment (start 78.232 32.122386) (end 77.351614 31.242) (width 0.25) (layer "B.Cu") (net 85) (tstamp a4090dc7-2ca6-4b44-8e07-46d43fca433d))
  (segment (start 63.754 101.7133) (end 63.749164 101.708464) (width 0.25) (layer "B.Cu") (net 85) (tstamp a7af1c03-31d4-4ac1-81f1-f0f3dd4cfc0f))
  (segment (start 84.201 160.9185) (end 84.201 158.3785) (width 0.5) (layer "B.Cu") (net 85) (tstamp b6743897-a39a-4b42-ba83-63fae8a5d9e0))
  (segment (start 81.661 160.9185) (end 79.121 160.9185) (width 0.5) (layer "B.Cu") (net 85) (tstamp b6c22c0d-d541-4bcb-ae00-d35227fea3a4))
  (segment (start 78.575511 51.091489) (end 78.575511 46.825511) (width 0.25) (layer "B.Cu") (net 85) (tstamp bb9ac314-87ab-4844-8bf3-8335e925b007))
  (segment (start 98.7035 100.1785) (end 94.869 104.013) (width 3) (layer "B.Cu") (net 85) (tstamp c3963e65-65a3-4cc0-88ce-898231c48782))
  (segment (start 79.883 71.628) (end 77.851 69.596) (width 0.25) (layer "B.Cu") (net 85) (tstamp ccd32bdb-1635-4162-a2f7-7eb103f4bd78))
  (segment (start 81.661 158.3785) (end 81.661 156.464) (width 0.5) (layer "B.Cu") (net 85) (tstamp d22c3776-cfae-4c34-bf87-de666a4c901d))
  (segment (start 77.351614 31.242) (end 77.343 31.242) (width 0.25) (layer "B.Cu") (net 85) (tstamp e04dc9f9-4e62-4147-ad5c-6b446ce06134))
  (segment (start 76.7588 42.231586) (end 76.7588 45.0088) (width 0.2) (layer "B.Cu") (net 85) (tstamp e46c95a8-bf91-4cda-add2-6646fd1ef303))
  (segment (start 63.754 105.918) (end 63.754 101.7133) (width 0.25) (layer "B.Cu") (net 85) (tstamp e69457a9-39fc-4c68-829c-b06eabb807d7))
  (segment (start 89.406349 139.066651) (end 89.535 138.938) (width 1) (layer "B.Cu") (net 85) (tstamp e7e6bbf2-ea25-498c-ba36-0b13664c0131))
  (segment (start 84.201 155.448) (end 84.201 158.3785) (width 0.5) (layer "B.Cu") (net 85) (tstamp ec3fda19-1846-4263-98d4-7e7ba21742c3))
  (segment (start 84.201 160.9185) (end 81.661 160.9185) (width 0.5) (layer "B.Cu") (net 85) (tstamp eda55da4-5285-486f-8e52-677317ea0f75))
  (segment (start 42.044556 49.791556) (end 40.139556 49.791556) (width 0.25) (layer "B.Cu") (net 85) (tstamp efe42e7b-aaf1-4cbd-8c9b-4c74adde1d65))
  (segment (start 78.486 65.3415) (end 78.486 51.181) (width 0.25) (layer "B.Cu") (net 85) (tstamp f3bc2138-ba25-427c-932b-e60b08edf406))
  (segment (start 89.535 150.876) (end 89.535 149.098) (width 3) (layer "B.Cu") (net 85) (tstamp f7bb6b6e-bff0-4b37-ae24-273b169451ee))
  (segment (start 77.851 65.9765) (end 78.486 65.3415) (width 0.25) (layer "B.Cu") (net 85) (tstamp f80c0662-7b6e-46e1-b168-21ef946a99f7))
  (segment (start 66.675 34.671) (end 66.675 35.56) (width 0.2) (layer "F.Cu") (net 86) (tstamp 00ddde94-8e08-4d48-88c4-74c80ec53328))
  (segment (start 68.326 37.211) (end 68.326 38.546) (width 0.2) (layer "F.Cu") (net 86) (tstamp 6e791f09-0366-434a-87be-ea849da50205))
  (segment (start 67.971 30.226) (end 67.056 30.226) (width 0.2) (layer "F.Cu") (net 86) (tstamp cc1585de-abfa-42a2-8ad3-f4eadfe95d1f))
  (segment (start 67.056 30.226) (end 66.675 30.607) (width 0.2) (layer "F.Cu") (net 86) (tstamp da4c38eb-0ffc-403f-83fe-2dc204afd72c))
  (segment (start 66.675 35.56) (end 68.326 37.211) (width 0.2) (layer "F.Cu") (net 86) (tstamp ddb3f67f-4590-4504-9510-3a95d27d68ca))
  (segment (start 67.9835 34.671) (end 66.675 34.671) (width 0.2) (layer "F.Cu") (net 86) (tstamp df33fdcb-78af-44be-9df4-8aaae45b15c1))
  (segment (start 66.675 30.607) (end 66.675 34.671) (width 0.2) (layer "F.Cu") (net 86) (tstamp eb5fa25a-09d8-4abc-bebe-da167e009174))
  (segment (start 96.901 18.796) (end 96.901 23.701) (width 0.5) (layer "F.Cu") (net 87) (tstamp 26d38aef-1746-403c-bc27-3b53c949a2ab))
  (segment (start 96.6235 27.4085) (end 99.441 30.226) (width 0.5) (layer "F.Cu") (net 87) (tstamp 3fbde416-b970-40cd-9a90-dc03ada91c68))
  (segment (start 88.646 18.406) (end 89.036 18.796) (width 0.25) (layer "F.Cu") (net 87) (tstamp 60f46875-494b-4d1b-8f34-74efd1a4f267))
  (segment (start 96.6235 23.9785) (end 96.6235 27.4085) (width 0.5) (layer "F.Cu") (net 87) (tstamp 6814f115-406c-4199-8272-f89162ecd1bd))
  (segment (start 99.441 30.226) (end 99.441 36.576) (width 0.5) (layer "F.Cu") (net 87) (tstamp 6deb9dbb-e520-423e-9abf-c28ce54bcd9e))
  (segment (start 96.901 23.701) (end 96.6235 23.9785) (width 0.5) (layer "F.Cu") (net 87) (tstamp 85bb2f08-a59a-49e8-8d8f-e97c70fef9cd))
  (segment (start 89.036 18.796) (end 96.901 18.796) (width 0.25) (layer "F.Cu") (net 87) (tstamp e72ca24f-a129-4cc0-9e6b-e2076bc9ae7f))
  (segment (start 88.646 26.696) (end 90.196 26.696) (width 0.25) (layer "F.Cu") (net 88) (tstamp 01c8f3b6-09b8-49d3-9082-df8e4452bc82))
  (segment (start 96.6235 31.4785) (end 95.6485 31.4785) (width 0.5) (layer "F.Cu") (net 88) (tstamp 7707221d-a832-4ffe-9fdb-12bd4a37b234))
  (segment (start 90.196 26.696) (end 91.313 27.813) (width 0.2) (layer "F.Cu") (net 88) (tstamp 7b29d387-c1ad-4af9-a149-023c4d217d22))
  (segment (start 91.821 35.306) (end 89.281 32.766) (width 0.5) (layer "F.Cu") (net 88) (tstamp 8fb7d9a6-ef18-4249-acfe-2c05fbd53411))
  (segment (start 91.821 36.576) (end 91.821 35.306) (width 0.5) (layer "F.Cu") (net 88) (tstamp a2074bb8-9cc5-4b6b-af37-1958819aae6d))
  (segment (start 91.313 27.813) (end 91.313 33.02) (width 0.2) (layer "F.Cu") (net 88) (tstamp b7992508-f5b1-4df1-908b-7df5b848bc6c))
  (segment (start 91.313 33.02) (end 90.424 33.909) (width 0.2) (layer "F.Cu") (net 88) (tstamp ee3c7e26-1198-418c-835a-94d76aad1688))
  (segment (start 95.6485 31.4785) (end 91.821 35.306) (width 0.5) (layer "F.Cu") (net 88) (tstamp f4c06a1b-8310-49cb-bbe6-05d255b759aa))
  (segment (start 63.881 97.663) (end 63.881 98.451) (width 0.2) (layer "F.Cu") (net 89) (tstamp 1a96a6c7-0ff5-43de-954c-cc7d4f8a6e3f))
  (segment (start 63.119 96.901) (end 63.881 97.663) (width 0.2) (layer "F.Cu") (net 89) (tstamp 3175e50c-89b9-46b7-ac33-e56da7c9914c))
  (segment (start 60.325 96.901) (end 63.119 96.901) (width 0.2) (layer "F.Cu") (net 89) (tstamp 521f5f5d-3dbb-4295-ac81-7f0e70557de4))
  (segment (start 59.563 95.351) (end 59.563 96.139) (width 0.2) (layer "F.Cu") (net 89) (tstamp b6fb061c-0776-4094-9541-dd1f698b6ebf))
  (segment (start 59.563 96.139) (end 60.325 96.901) (width 0.2) (layer "F.Cu") (net 89) (tstamp d0e6dd30-4883-450d-8521-1afe84e2b656))
  (segment (start 42.056 109.481) (end 42.056 110.8392) (width 0.25) (layer "F.Cu") (net 90) (tstamp 044a20f5-29a9-4697-a85d-8828ef3eb81b))
  (segment (start 35.941 159.6295) (end 37.211 160.8995) (width 0.2) (layer "F.Cu") (net 90) (tstamp 823d6003-779f-4404-a191-7975109d1915))
  (segment (start 44.069 147.952847) (end 35.941 156.080847) (width 0.25) (layer "F.Cu") (net 90) (tstamp 8b9fb022-4260-463d-9ecd-9af82aec4d10))
  (segment (start 44.069 112.8522) (end 44.069 147.952847) (width 0.25) (layer "F.Cu") (net 90) (tstamp bfa88994-a283-4bf8-9c17-eb6c92c31a46))
  (segment (start 42.056 110.8392) (end 44.069 112.8522) (width 0.25) (layer "F.Cu") (net 90) (tstamp dae54fc0-3243-42d5-98d9-c046dc21548a))
  (segment (start 35.941 156.080847) (end 35.941 159.6295) (width 0.2) (layer "F.Cu") (net 90) (tstamp f5cb8054-2966-45aa-a482-b9321520bf5f))
  (segment (start 37.211 155.446565) (end 37.211 158.3595) (width 0.25) (layer "F.Cu") (net 91) (tstamp 05b6860c-c8e1-4d2b-9bca-dca59023403e))
  (segment (start 44.596 103.131) (end 44.596 148.061565) (width 0.25) (layer "F.Cu") (net 91) (tstamp 34d8e4f5-6158-4afe-8456-75e4a1aa4fa0))
  (segment (start 44.596 148.061565) (end 37.211 155.446565) (width 0.25) (layer "F.Cu") (net 91) (tstamp 4e71756a-60e1-42d0-9aad-734b68df89ef))
  (segment (start 47.872 104.1724) (end 47.23632 104.80808) (width 0.25) (layer "F.Cu") (net 92) (tstamp 5a5115ce-d37f-4b51-9cf4-67b537d3cedf))
  (segment (start 47.872 103.131) (end 47.872 104.1724) (width 0.25) (layer "F.Cu") (net 92) (tstamp 81182c03-d5d5-490d-84fe-5d541b4537ee))
  (segment (start 45.104 106.025282) (end 45.104 148.189283) (width 0.25) (layer "F.Cu") (net 92) (tstamp 895b2d73-8dc5-4a2a-82ca-18f3e8324b69))
  (segment (start 45.104 148.189283) (end 38.481 154.812283) (width 0.25) (layer "F.Cu") (net 92) (tstamp b4bde552-bd1d-4c48-808d-d6c77a2783c2))
  (segment (start 46.321202 104.80808) (end 45.104 106.025282) (width 0.25) (layer "F.Cu") (net 92) (tstamp ba452d8d-9850-4f2a-8bdc-391fdcb7e5e8))
  (segment (start 38.481 156.718) (end 38.481 159.6295) (width 0.2) (layer "F.Cu") (net 92) (tstamp decbb0f2-5a81-4e43-b9f1-20bac186ed8c))
  (segment (start 38.481 154.812283) (end 38.481 156.718) (width 0.25) (layer "F.Cu") (net 92) (tstamp e16764b0-0cf9-4a75-b563-dbd8df2a3352))
  (segment (start 38.481 159.6295) (end 39.751 160.8995) (width 0.2) (layer "F.Cu") (net 92) (tstamp e6de1072-d872-4c07-8c5b-2287ef2d6213))
  (segment (start 47.23632 104.80808) (end 46.321202 104.80808) (width 0.25) (layer "F.Cu") (net 92) (tstamp ed945e02-f7a6-458f-aaaa-ea251efcc117))
  (segment (start 49.276 105.2576) (end 46.5074 105.2576) (width 0.25) (layer "F.Cu") (net 93) (tstamp 1827b40b-ebc3-4c6c-9d98-c38fcedbe50e))
  (segment (start 39.751 154.178) (end 39.751 158.3595) (width 0.25) (layer "F.Cu") (net 93) (tstamp 297b235a-f894-4d7e-b131-0bbda3d891e8))
  (segment (start 50.699 96.52) (end 50.699 98.286) (width 0.25) (layer "F.Cu") (net 93) (tstamp 437dff56-781c-4537-a100-4dd90006b788))
  (segment (start 50.699 98.286) (end 50.165 98.82) (width 0.25) (layer "F.Cu") (net 93) (tstamp 4e33e233-c214-429a-abba-49eea1950180))
  (segment (start 45.612 148.317) (end 39.751 154.178) (width 0.25) (layer "F.Cu") (net 93) (tstamp 96776bec-df78-44f7-a13f-8b4d2888fa7f))
  (segment (start 46.5074 105.2576) (end 45.612 106.153) (width 0.25) (layer "F.Cu") (net 93) (tstamp a176b6d7-4ffe-4ea5-be46-03de8ae58aac))
  (segment (start 50.165 98.82) (end 50.165 104.3686) (width 0.25) (layer "F.Cu") (net 93) (tstamp d129706d-c408-4074-b94b-b076480320dd))
  (segment (start 50.165 104.3686) (end 49.276 105.2576) (width 0.25) (layer "F.Cu") (net 93) (tstamp d540d006-b208-4a99-ac3e-9eb7f9ecad9a))
  (segment (start 45.612 106.153) (end 45.612 148.317) (width 0.25) (layer "F.Cu") (net 93) (tstamp e1bbab59-f11e-459b-a461-bba9c6cd7a0a))
  (segment (start 51.31844 105.75516) (end 46.77184 105.75516) (width 0.25) (layer "F.Cu") (net 94) (tstamp 0ce4ebbe-ed65-498b-b6b1-014db1e2e553))
  (segment (start 41.021 156.972) (end 41.021 159.766) (width 0.2) (layer "F.Cu") (net 94) (tstamp 1ed36a58-920c-4231-87f2-64ad4f9723be))
  (segment (start 46.101 110.236) (end 46.06152 110.27548) (width 0.25) (layer "F.Cu") (net 94) (tstamp 27c123a1-0aa7-4996-a67c-7d70b85bfde3))
  (segment (start 46.77184 105.75516) (end 46.101 106.426) (width 0.25) (layer "F.Cu") (net 94) (tstamp 372ac32e-ce08-49bd-bfe5-1b2afd5a9cc6))
  (segment (start 42.1545 160.8995) (end 42.291 160.8995) (width 0.25) (layer "F.Cu") (net 94) (tstamp 488bfe01-43ea-4fe3-80ba-145dd078d976))
  (segment (start 52.451 104.6226) (end 51.31844 105.75516) (width 0.25) (layer "F.Cu") (net 94) (tstamp 4b88bba6-1468-4b07-83d4-f0d15cf6d2ab))
  (segment (start 52.451 103.15) (end 52.451 104.6226) (width 0.25) (layer "F.Cu") (net 94) (tstamp 548551fe-5851-4325-b2f3-f349f3de4dcd))
  (segment (start 46.06152 148.503198) (end 41.021 153.543718) (width 0.25) (layer "F.Cu") (net 94) (tstamp 62b9f785-4b26-4883-bd36-3560bdc310de))
  (segment (start 46.101 106.426) (end 46.101 110.236) (width 0.25) (layer "F.Cu") (net 94) (tstamp 6abbd9b9-6852-45f6-819a-6ed1b98b1dbe))
  (segment (start 41.021 153.543718) (end 41.021 156.972) (width 0.25) (layer "F.Cu") (net 94) (tstamp aaf1044c-2486-4712-a0e3-50bc636c19da))
  (segment (start 41.021 159.766) (end 42.1545 160.8995) (width 0.2) (layer "F.Cu") (net 94) (tstamp b04a085d-f14c-4a21-998e-01d2550c8c88))
  (segment (start 46.06152 110.27548) (end 46.06152 148.503198) (width 0.25) (layer "F.Cu") (net 94) (tstamp d96bdd49-4be2-4901-b5a5-4c769bec81e6))
  (segment (start 54.737 97.562) (end 54.737 104.394) (width 0.25) (layer "F.Cu") (net 95) (tstamp 09ac1297-0023-4d09-94f2-cd8fca5f2ecf))
  (segment (start 52.92632 106.20468) (end 47.33832 106.20468) (width 0.25) (layer "F.Cu") (net 95) (tstamp 1a7d7049-fda9-4fef-a236-8b8e4e2b34e0))
  (segment (start 54.737 104.394) (end 52.92632 106.20468) (width 0.25) (layer "F.Cu") (net 95) (tstamp 262b6d67-14bc-4afa-a3c7-d9db1b72c06b))
  (segment (start 42.291 152.909435) (end 42.291 158.3595) (width 0.25) (layer "F.Cu") (net 95) (tstamp 49a2c456-769d-4f80-8797-9539ec645817))
  (segment (start 47.33832 106.20468) (end 46.609 106.934) (width 0.25) (layer "F.Cu") (net 95) (tstamp 5606c9ac-33da-4cf3-b3a7-399d89da3468))
  (segment (start 46.609 148.591435) (end 42.291 152.909435) (width 0.25) (layer "F.Cu") (net 95) (tstamp d06246bf-a0d1-4ead-bd3e-d0178b21a1ae))
  (segment (start 46.609 106.934) (end 46.609 148.591435) (width 0.25) (layer "F.Cu") (net 95) (tstamp e3d7cf83-5433-45b7-9c53-450eed62a40f))
  (segment (start 88.891 20.581) (end 88.773 20.699) (width 0.2) (layer "F.Cu") (net 96) (tstamp 0f412868-276d-4f29-a113-8b038ae0c53f))
  (segment (start 88.773 20.699) (end 88.773 23.596) (width 0.2) (layer "F.Cu") (net 96) (tstamp 9044d5a9-6e99-44a4-a1d5-8cad97173f33))
  (segment (start 73.533 124.1675) (end 75.0185 122.682) (width 0.25) (layer "F.Cu") (net 97) (tstamp 2ee7e949-52a7-450c-a124-35bb742b85ce))
  (segment (start 79.375 117.576) (end 79.375 120.396) (width 0.25) (layer "F.Cu") (net 97) (tstamp 4b3c4d92-c707-4e33-a7e1-8125e53f671a))
  (segment (start 75.0185 122.682) (end 78.796 122.682) (width 0.25) (layer "F.Cu") (net 97) (tstamp 6c8ea0c3-517c-45d9-8f77-0c213f387d3a))
  (segment (start 79.375 120.396) (end 78.796 120.975) (width 0.25) (layer "F.Cu") (net 97) (tstamp aece3f4c-7ea2-4ae2-8004-6c9028449ebb))
  (segment (start 78.796 120.975) (end 78.796 122.682) (width 0.25) (layer "F.Cu") (net 97) (tstamp b6373b80-af7c-4b3b-bf2b-b8faff539301))
  (segment (start 122.301 86.466) (end 118.512 82.677) (width 2) (layer "F.Cu") (net 98) (tstamp 55042f33-f966-4a2e-aeb7-772e80ddad1e))
  (segment (start 117.983 82.677) (end 83.566 82.677) (width 2) (layer "F.Cu") (net 98) (tstamp 59c6a70a-15e2-4153-a298-751395f30162))
  (segment (start 118.512 82.677) (end 117.983 82.677) (width 2) (layer "F.Cu") (net 98) (tstamp 5e83a584-477f-49f1-9db6-0a9ecf20d62c))
  (segment (start 81.4985 79.756) (end 84.0385 82.296) (width 1) (layer "F.Cu") (net 98) (tstamp 63de02e6-62f6-4967-a89f-fc29c01a13bb))
  (segment (start 98.171 79.756) (end 98.171 82.296) (width 1) (layer "F.Cu") (net 98) (tstamp c39fa797-4839-4e8f-a2a0-f32ac8fe865c))
  (segment (start 113.8835 79.756) (end 113.8835 82.2605) (width 1) (layer "F.Cu") (net 98) (tstamp fb4bc483-c381-48b8-855c-f67b9813d465))
  (via (at 97.79 82.296) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 98) (tstamp 00ab6b14-e6c5-4c26-b9e2-31911bda0056))
  (via (at 120.396 85.217) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 98) (tstamp 264ed55c-daaa-4dec-97ae-50d15f5717cd))
  (via (at 83.312 82.423) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 98) (tstamp 7217ec3f-41c2-4106-94e5-b2c19f4a9186))
  (via (at 113.411 82.296) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 98) (tstamp 8c490279-2662-402d-893c-ec5a32868988))
  (via (at 121.158 84.582) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 98) (tstamp a4d581cc-e5f9-4072-be43-411f1039b3cc))
  (via (at 98.679 82.296) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 98) (tstamp f019df35-3e18-4666-a999-f0646d28f18c))
  (via (at 84.201 82.296) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 98) (tstamp fcda5405-0bb7-4957-8e65-1eb470b43c99))
  (via (at 114.3 82.296) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 98) (tstamp ffbeb84d-338b-4b3d-9270-eca8daae6c19))
  (segment (start 122.301 86.466) (end 118.512 82.677) (width 2) (layer "B.Cu") (net 98) (tstamp a98c8959-bda2-4303-a12a-768b52a23552))
  (segment (start 111.252 82.677) (end 83.566 82.677) (width 2) (layer "B.Cu") (net 98) (tstamp b605f71d-94fc-4dd1-a277-a759f74d80b2))
  (segment (start 118.512 82.677) (end 111.252 82.677) (width 2) (layer "B.Cu") (net 98) (tstamp cd1dc24b-8f96-424d-b2fc-b0de92e93dcf))
  (segment (start 111.6235 23.9785) (end 111.6235 31.4785) (width 2) (layer "F.Cu") (net 99) (tstamp 0e0ff08b-1279-4662-8a16-98f4b6be0ff1))
  (segment (start 89.281 31.496) (end 83.211 31.496) (width 0.2) (layer "F.Cu") (net 100) (tstamp 92d345dd-94ba-4e93-a2fc-ae7325adac22))
  (segment (start 48.768 87.122) (end 46.539 89.351) (width 0.2) (layer "F.Cu") (net 101) (tstamp 5aab5e7d-7deb-4378-b13c-9979193cbaa2))
  (segment (start 53.467 87.757) (end 52.832 87.122) (width 0.2) (layer "F.Cu") (net 101) (tstamp 6dc4b989-ce95-424e-86b4-49be3a8b9aee))
  (segment (start 53.467 88.366) (end 53.467 87.757) (width 0.2) (layer "F.Cu") (net 101) (tstamp 7de50e87-ce60-465c-a604-e173c0bf8bee))
  (segment (start 46.539 89.351) (end 45.216 89.351) (width 0.2) (layer "F.Cu") (net 101) (tstamp 8c4b17c7-29e2-4119-ad1a-475ddc93db5c))
  (segment (start 52.832 87.122) (end 48.768 87.122) (width 0.2) (layer "F.Cu") (net 101) (tstamp b37abcf8-167f-4f29-acf4-51cf5ce7226b))
  (segment (start 78.587 33.02) (end 80.111 31.496) (width 0.25) (layer "F.Cu") (net 102) (tstamp 353a06b3-903c-4bcd-b48e-17edee69e413))
  (segment (start 69.596 33.401) (end 70.46648 32.53052) (width 0.2) (layer "F.Cu") (net 102) (tstamp 4cbfaa3b-3604-45b4-bcb9-209b11ed8832))
  (segment (start 70.46648 32.53052) (end 76.47252 32.53052) (width 0.2) (layer "F.Cu") (net 102) (tstamp a6df3426-ec4e-4e6e-9f08-5ad494841651))
  (segment (start 76.962 33.02) (end 78.587 33.02) (width 0.2) (layer "F.Cu") (net 102) (tstamp a9ec0907-2764-4aa5-a957-598ff76fcc1b))
  (segment (start 69.596 38.546) (end 69.596 33.401) (width 0.2) (layer "F.Cu") (net 102) (tstamp d9190f44-cf7e-47c2-a830-4e568bc67a62))
  (segment (start 76.47252 32.53052) (end 76.962 33.02) (width 0.2) (layer "F.Cu") (net 102) (tstamp f414525f-b58c-422d-a8c7-f2d88f91bc72))
  (segment (start 156.083 129.295) (end 156.083 131.8) (width 0.2) (layer "F.Cu") (net 103) (tstamp c303eeea-aa85-4847-b85b-4528aaec5a25))
  (segment (start 70.739 126.322) (end 71.331 125.73) (width 0.25) (layer "F.Cu") (net 104) (tstamp 24c57b1c-4587-4bfa-abaa-db4318cd35ef))
  (segment (start 96.52 110.744) (end 91.948 115.316) (width 1) (layer "F.Cu") (net 104) (tstamp 2b9173fc-2a6f-4f19-a39e-c4698040dc13))
  (segment (start 112.7335 107.6785) (end 112.7335 108.3735) (width 1) (layer "F.Cu") (net 104) (tstamp 30b5e7e9-9cf3-491d-9d83-aa8f30861f64))
  (segment (start 76.581 125.222) (end 78.796 125.222) (width 0.25) (layer "F.Cu") (net 104) (tstamp 32b89dc4-73d3-455d-b8ed-8823e0e33601))
  (segment (start 90.84552 125.18148) (end 78.83652 125.18148) (width 1) (layer "F.Cu") (net 104) (tstamp 347fba12-534a-47fc-bd37-9fe4ba50b297))
  (segment (start 91.948 115.316) (end 91.948 124.079) (width 1) (layer "F.Cu") (net 104) (tstamp 3fde46af-1839-4b6b-beeb-a1005bd978d5))
  (segment (start 78.83652 125.18148) (end 78.796 125.222) (width 1) (layer "F.Cu") (net 104) (tstamp 5dfc434b-b8c1-4314-a936-b4a209865191))
  (segment (start 113.406 88.646) (end 113.406 107.006) (width 1) (layer "F.Cu") (net 104) (tstamp 6fde31eb-8fd3-409e-8595-9cfe11156d5b))
  (segment (start 91.948 124.079) (end 90.84552 125.18148) (width 1) (layer "F.Cu") (net 104) (tstamp 8361e9a9-0e7d-4127-bfdd-3bf6bda9b2f7))
  (segment (start 120.015 108.966) (end 114.021 108.966) (width 3) (layer "F.Cu") (net 104) (tstamp a9069ebd-f4be-4e00-88c9-6a7ec89e3bdd))
  (segment (start 122.301 108.966) (end 120.015 108.966) (width 3) (layer "F.Cu") (net 104) (tstamp b8142aaf-20e7-475a-a61b-1bc5be99cfd9))
  (segment (start 110.363 110.744) (end 96.52 110.744) (width 1) (layer "F.Cu") (net 104) (tstamp c9750455-a5aa-431f-a0ed-f6ec9dc146f8))
  (segment (start 113.406 107.006) (end 112.7335 107.6785) (width 1) (layer "F.Cu") (net 104) (tstamp d173e001-fc05-4efb-b699-a49ad39c0cbd))
  (segment (start 71.331 125.73) (end 76.073 125.73) (width 0.25) (layer "F.Cu") (net 104) (tstamp da29d6ca-dab0-4449-a96f-e8b7054b114e))
  (segment (start 76.073 125.73) (end 76.581 125.222) (width 0.25) (layer "F.Cu") (net 104) (tstamp e7c403e6-04fc-4468-a3db-1668504a7b75))
  (segment (start 112.7335 108.3735) (end 110.363 110.744) (width 1) (layer "F.Cu") (net 104) (tstamp ef239ea3-4a8f-4652-b7ee-16f21893f1f1))
  (segment (start 114.021 108.966) (end 112.7335 107.6785) (width 3) (layer "F.Cu") (net 104) (tstamp f7f8d298-f4bb-432c-984b-9c70300b8ce6))
  (via (at 114.935 108.585) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 104) (tstamp 34c3437a-d178-4967-bc54-0780b5657340))
  (via (at 120.015 108.331) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 104) (tstamp 9c9948f3-610b-46f9-a963-5bb8e9d17f37))
  (via (at 120.015 109.347) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 104) (tstamp a0112576-3a2f-44a8-811c-bbeb00316aa3))
  (via (at 114.3 109.474) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (free) (net 104) (tstamp e3c91a19-454b-494b-b199-86ca2ee0675f))
  (segment (start 112.7335 107.6785) (end 112.7585 107.6785) (width 3) (layer "B.Cu") (net 104) (tstamp 65821850-2092-429e-af45-6c21a630a86f))
  (segment (start 114.681 108.966) (end 122.301 108.966) (width 3) (layer "B.Cu") (net 104) (tstamp a03b7e65-a267-484a-9d90-74091c2618b2))
  (segment (start 114.046 108.966) (end 114.681 108.966) (width 3) (layer "B.Cu") (net 104) (tstamp e02cd758-6822-4393-bf74-4bcb9a5890b2))
  (segment (start 112.7585 107.6785) (end 114.046 108.966) (width 3) (layer "B.Cu") (net 104) (tstamp ff4cfea6-047c-4b84-9c45-f25e8257ca3c))
  (segment (start 74.067 120.65) (end 73.406 120.65) (width 0.25) (layer "F.Cu") (net 105) (tstamp 0d4a9286-1068-4080-9cf9-b0eb912046de))
  (segment (start 76.047 117.348) (end 75.1075 117.348) (width 0.25) (layer "F.Cu") (net 105) (tstamp 6a750343-a677-4bbb-a38c-89f42094dc53))
  (segment (start 74.067 118.3885) (end 74.067 120.65) (width 0.25) (layer "F.Cu") (net 105) (tstamp 6b6f0020-1b7e-42d0-961e-d15f7b3f699c))
  (segment (start 75.1075 117.348) (end 74.067 118.3885) (width 0.25) (layer "F.Cu") (net 105) (tstamp a6cef98e-0924-4249-acf5-e1d91005decc))
  (segment (start 70.739 123.317) (end 70.739 124.122) (width 0.25) (layer "F.Cu") (net 105) (tstamp c4b4b734-14d0-4951-aa07-ba79c3c6e0f0))
  (segment (start 73.406 120.65) (end 70.739 123.317) (width 0.25) (layer "F.Cu") (net 105) (tstamp d50fa020-0105-4d85-8326-ae26411baa4d))
  (segment (start 55.677 118.922) (end 54.61 119.989) (width 0.25) (layer "F.Cu") (net 106) (tstamp 3ee9a885-42e8-4027-b0ea-76fd4eb82726))
  (segment (start 59.309 118.922) (end 55.677 118.922) (width 0.25) (layer "F.Cu") (net 106) (tstamp 786d773e-4d64-4fd0-8499-33a3b3abf51f))
  (segment (start 56.591 113.842) (end 59.309 113.842) (width 0.25) (layer "F.Cu") (net 107) (tstamp 4fbaa8e0-baf6-4d4c-91ec-93873e79b2c6))
  (segment (start 55.271 112.522) (end 56.591 113.842) (width 0.25) (layer "F.Cu") (net 107) (tstamp 704644b6-3824-4713-b097-70b47bb612e1))
  (segment (start 55.321 116.382) (end 59.309 116.382) (width 0.25) (layer "F.Cu") (net 108) (tstamp 502cb40c-2143-4147-9497-26656647978b))
  (segment (start 55.271 116.332) (end 55.321 116.382) (width 0.25) (layer "F.Cu") (net 108) (tstamp e6cd034a-393a-4d77-9d51-20f8fd5752ff))
  (segment (start 47.929 131.622) (end 47.879 131.572) (width 0.25) (layer "F.Cu") (net 109) (tstamp 07191eca-24c6-4180-b33c-f7f8964572fb))
  (segment (start 31.877 105.537) (end 33.02 104.394) (width 0.25) (layer "F.Cu") (net 109) (tstamp 25e6a028-5bd8-4c4b-a0a2-ac3f0ece3f68))
  (segment (start 32.893 111.506) (end 31.877 110.49) (width 0.25) (layer "F.Cu") (net 109) (tstamp 272ff07c-c03a-44cf-b0ad-0872666b5253))
  (segment (start 33.02 104.394) (end 33.02 103.531) (width 0.25) (layer "F.Cu") (net 109) (tstamp 4b8fc668-ce7b-48ca-8940-3d01dcabf4be))
  (segment (start 31.877 110.49) (end 31.877 105.537) (width 0.25) (layer "F.Cu") (net 109) (tstamp 4f3075e2-da62-4c50-a667-5be6eb91e40f))
  (segment (start 41.783 131.064) (end 42.037 130.81) (width 0.25) (layer "F.Cu") (net 109) (tstamp 53b806f0-87da-472a-9aa5-208e8605ceb9))
  (segment (start 42.037 130.81) (end 42.037 113.5634) (width 0.25) (layer "F.Cu") (net 109) (tstamp 5a148e66-fcac-4602-8737-a96b6f601fe2))
  (segment (start 34.671 111.506) (end 32.893 111.506) (width 0.25) (layer "F.Cu") (net 109) (tstamp 71005bf5-b5ec-48d9-9bf1-e8ca8e29457f))
  (segment (start 41.402 112.9284) (end 36.0934 112.9284) (width 0.25) (layer "F.Cu") (net 109) (tstamp d4319a43-4670-46cb-b99e-e9ff41483cdf))
  (segment (start 59.309 131.622) (end 47.929 131.622) (width 0.25) (layer "F.Cu") (net 109) (tstamp dfa8d483-ea4b-4e49-a1b1-0292438b6247))
  (segment (start 36.0934 112.9284) (end 34.671 111.506) (width 0.25) (layer "F.Cu") (net 109) (tstamp e8f9363e-9448-48ed-aa4e-c483840909fa))
  (segment (start 42.037 113.5634) (end 41.402 112.9284) (width 0.25) (layer "F.Cu") (net 109) (tstamp f4bb3f03-fe82-4b23-a396-0c1050858f44))
  (via (at 41.783 131.064) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 109) (tstamp 9eb431fc-e036-4303-85c7-dd5a433ec36d))
  (via (at 47.879 131.572) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 109) (tstamp b7681594-2a62-46b7-b8a6-bf19c30244a4))
  (segment (start 41.783 131.064) (end 42.299614 131.064) (width 0.25) (layer "B.Cu") (net 109) (tstamp 50d2bae4-b7c3-4443-bc55-fad82f3bdca4))
  (segment (start 42.299614 131.064) (end 42.857614 131.622) (width 0.25) (layer "B.Cu") (net 109) (tstamp 8aff1c39-9583-49b0-b08b-12a57f51a0c0))
  (segment (start 42.857614 131.622) (end 47.829 131.622) (width 0.25) (layer "B.Cu") (net 109) (tstamp ada4d2ac-2600-4330-801d-67618686d64e))
  (segment (start 47.829 131.622) (end 47.879 131.572) (width 0.25) (layer "B.Cu") (net 109) (tstamp dd15d352-3449-4f1a-a5d3-f9b174e5919c))
  (segment (start 50.038 132.588) (end 47.894524 132.588) (width 0.25) (layer "F.Cu") (net 110) (tstamp 0d7c06b0-8869-40cb-bd34-a0056fc07121))
  (segment (start 34.857198 111.05648) (end 34.39928 111.05648) (width 0.25) (layer "F.Cu") (net 110) (tstamp 1e5b9c0d-015d-429a-b78b-327e79746694))
  (segment (start 42.309758 132.098742) (end 42.545 131.8635) (width 0.25) (layer "F.Cu") (net 110) (tstamp 38fa802c-629b-42b4-9a7c-27160e71ae83))
  (segment (start 47.894524 132.588) (end 47.878026 132.571502) (width 0.25) (layer "F.Cu") (net 110) (tstamp 3da00d7f-fba6-4657-a06f-81bda42a9ae7))
  (segment (start 42.545 113.3602) (end 41.66368 112.47888) (width 0.25) (layer "F.Cu") (net 110) (tstamp 4605f8d7-dd8f-43bf-ae8f-b4dc0c885150))
  (segment (start 51.612 134.162) (end 50.038 132.588) (width 0.25) (layer "F.Cu") (net 110) (tstamp 71a6454c-0330-4f6b-9e62-5d20ebe2c882))
  (segment (start 59.309 134.162) (end 51.612 134.162) (width 0.25) (layer "F.Cu") (net 110) (tstamp 986fe38e-1737-46ca-974e-3949a6db6114))
  (segment (start 33.909 110.5662) (end 33.909 109.481) (width 0.25) (layer "F.Cu") (net 110) (tstamp a2f2ac67-58ab-464b-9401-76e010e23bbb))
  (segment (start 34.39928 111.05648) (end 33.909 110.5662) (width 0.25) (layer "F.Cu") (net 110) (tstamp c3ea118f-8e51-4127-bf7c-36c1346ae0f2))
  (segment (start 42.545 131.8635) (end 42.545 113.3602) (width 0.25) (layer "F.Cu") (net 110) (tstamp c870fcc7-b7f3-42a8-a4de-56271985d98d))
  (segment (start 36.279598 112.47888) (end 34.857198 111.05648) (width 0.25) (layer "F.Cu") (net 110) (tstamp e6a8d2c0-07f3-41a1-ba3c-cef07c6b1e71))
  (segment (start 41.66368 112.47888) (end 36.279598 112.47888) (width 0.25) (layer "F.Cu") (net 110) (tstamp f5baa943-e3f4-46b8-8e04-73b5eb9d6204))
  (via (at 47.878026 132.571502) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 110) (tstamp 8528eae3-dd83-4267-a5d4-85ecf3798723))
  (via (at 42.309758 132.098742) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 110) (tstamp a7c4e6a9-e6aa-477c-8480-0a85f29054e5))
  (segment (start 47.640524 132.334) (end 42.545016 132.334) (width 0.25) (layer "B.Cu") (net 110) (tstamp 0bb2e395-2405-4a3c-9fa2-2118eb1bd5b6))
  (segment (start 47.878026 132.571502) (end 47.640524 132.334) (width 0.25) (layer "B.Cu") (net 110) (tstamp 988454b1-d82d-4b95-86f9-89e8b33d33fc))
  (segment (start 42.545016 132.334) (end 42.309758 132.098742) (width 0.25) (layer "B.Cu") (net 110) (tstamp 9d6404dd-66fe-4f27-a2a5-42d6b1fa809e))
  (segment (start 43.053 132.8795) (end 43.053 113.232483) (width 0.25) (layer "F.Cu") (net 111) (tstamp 02ce00e1-d814-4fc2-9bad-823fab90fa83))
  (segment (start 47.752 133.604) (end 50.292 133.604) (width 0.25) (layer "F.Cu") (net 111) (tstamp 11280c1d-7164-46af-ad0e-2ca9882591a2))
  (segment (start 53.39508 136.70708) (end 59.30646 136.70708) (width 0.25) (layer "F.Cu") (net 111) (tstamp 22340b0c-cd9e-45c2-a980-4b771b6f19b2))
  (segment (start 42.8365 133.096) (end 43.053 132.8795) (width 0.25) (layer "F.Cu") (net 111) (tstamp 2f68d403-7f70-4330-bc5e-b31e88fc3a16))
  (segment (start 35.941 110.49) (end 35.941 105.271) (width 0.25) (layer "F.Cu") (net 111) (tstamp 3cabed8b-83ab-4aca-ae1c-b953a8c8501a))
  (segment (start 43.053 113.232483) (end 41.849877 112.02936) (width 0.25) (layer "F.Cu") (net 111) (tstamp 543ed98a-1b01-46d3-b2b8-52e40d793d8c))
  (segment (start 37.48036 112.02936) (end 35.941 110.49) (width 0.25) (layer "F.Cu") (net 111) (tstamp 5cb76764-4b93-426d-a444-e9d4a4b2666c))
  (segment (start 50.292 133.604) (end 53.39508 136.70708) (width 0.25) (layer "F.Cu") (net 111) (tstamp 887e49f0-d5bb-4c11-b762-16fca41de2f4))
  (segment (start 36.703 104.509) (end 36.703 103.023) (width 0.2) (layer "F.Cu") (net 111) (tstamp b57b38bc-b774-4416-a831-75f284034c52))
  (segment (start 41.849877 112.02936) (end 37.48036 112.02936) (width 0.25) (layer "F.Cu") (net 111) (tstamp d3d8df40-3225-40c9-82fd-189207af51ed))
  (segment (start 35.941 105.271) (end 36.703 104.509) (width 0.2) (layer "F.Cu") (net 111) (tstamp e9363617-5ff0-40ed-bbbc-8a05a38ae8fc))
  (via (at 47.752 133.604) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 111) (tstamp 4b4eead9-6468-4df2-983e-2d12ebfc7da5))
  (via (at 42.8365 133.096) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 111) (tstamp 8983725d-aa97-4736-9d3f-219a233129b0))
  (segment (start 47.244 133.096) (end 47.752 133.604) (width 0.25) (layer "B.Cu") (net 111) (tstamp a0b4aaae-690d-49eb-b99d-3b72185d551c))
  (segment (start 42.8365 133.096) (end 47.244 133.096) (width 0.25) (layer "B.Cu") (net 111) (tstamp e1e715b4-33d6-48e4-aeb9-e916c331008a))
  (segment (start 37.973 109.481) (end 37.973 110.4138) (width 0.25) (layer "F.Cu") (net 112) (tstamp 02704019-a169-4ddf-b077-e87f61f18477))
  (segment (start 50.529503 134.603503) (end 55.168 139.242) (width 0.25) (layer "F.Cu") (net 112) (tstamp 0e9d2135-7b9c-4118-b039-684d58ad3972))
  (segment (start 39.13904 111.57984) (end 42.036075 111.57984) (width 0.25) (layer "F.Cu") (net 112) (tstamp 23ba8d03-f91c-4793-b1c3-9b55f9225194))
  (segment (start 43.561 134.1495) (end 43.561 127.508) (width 0.25) (layer "F.Cu") (net 112) (tstamp 5993854a-4912-4cd5-b85d-434fa6ee56b2))
  (segment (start 37.973 110.4138) (end 39.13904 111.57984) (width 0.25) (layer "F.Cu") (net 112) (tstamp 5ceb3404-9486-4dd3-9ecf-0b63eafdd0f4))
  (segment (start 42.036075 111.57984) (end 43.561 113.104765) (width 0.25) (layer "F.Cu") (net 112) (tstamp 694f00cb-3ce6-4a95-827d-cefb3894445d))
  (segment (start 43.3445 134.366) (end 43.561 134.1495) (width 0.25) (layer "F.Cu") (net 112) (tstamp 780cb4a9-46f0-4d1c-ab9a-0d53e9ba69e9))
  (segment (start 47.752 134.603503) (end 50.529503 134.603503) (width 0.25) (layer "F.Cu") (net 112) (tstamp b55e8ca2-986f-44d4-8cf3-3fa63c314b76))
  (segment (start 43.561 113.104765) (end 43.561 128.27) (width 0.25) (layer "F.Cu") (net 112) (tstamp bdb15fb2-7f55-46f9-ab9d-ef939ed8e83d))
  (segment (start 55.168 139.242) (end 59.309 139.242) (width 0.25) (layer "F.Cu") (net 112) (tstamp f204d28e-76c9-4634-8d99-2f7e6b281669))
  (via (at 43.3445 134.366) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 112) (tstamp 137eb93a-93e9-426a-b58d-1270fa5f892b))
  (via (at 47.752 134.603503) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 112) (tstamp a8f76c7d-7b42-461b-a9aa-81cc82bc60f3))
  (segment (start 43.3445 134.366) (end 47.514497 134.366) (width 0.25) (layer "B.Cu") (net 112) (tstamp 143a0b19-8a32-4d14-85f3-21ba90a5c2ea))
  (segment (start 47.514497 134.366) (end 47.752 134.603503) (width 0.25) (layer "B.Cu") (net 112) (tstamp 2f38340c-9294-44d3-9663-fd75fac74813))
  (segment (start 59.563 98.451) (end 59.563 100.888) (width 0.5) (layer "F.Cu") (net 113) (tstamp 1f5cd48f-3b43-4bf9-affd-acfe0e9d2566))
  (segment (start 59.563 100.888) (end 59.309 101.142) (width 0.5) (layer "F.Cu") (net 113) (tstamp 551d3ee8-8af3-4abd-9a1a-d719861cd91a))
  (segment (start 65.786 145.542) (end 65.024 146.304) (width 0.25) (layer "F.Cu") (net 114) (tstamp 015ee1d8-84cc-4028-81d3-205cee875512))
  (segment (start 65.786 143.256) (end 65.786 145.542) (width 0.25) (layer "F.Cu") (net 114) (tstamp 03c30d63-c6c6-4817-9b70-48b5b2616309))
  (segment (start 61.468 111.887) (end 60.883 111.302) (width 0.25) (layer "F.Cu") (net 114) (tstamp 2552e7a4-7e07-42ba-bdcf-646c3657c49d))
  (segment (start 67.285 141.757) (end 65.786 143.256) (width 0.25) (layer "F.Cu") (net 114) (tstamp 2da42ec9-bc15-479d-afcb-a015feb5498d))
  (segment (start 65.024 146.304) (end 62.484 146.304) (width 0.25) (layer "F.Cu") (net 114) (tstamp 3ede0e81-2b92-419d-835b-ef1bb7ad2baa))
  (segment (start 60.883 111.302) (end 59.309 111.302) (width 0.25) (layer "F.Cu") (net 114) (tstamp 4668f8c7-b666-4caa-a95d-bfa48229e161))
  (segment (start 62.484 146.304) (end 61.468 145.288) (width 0.25) (layer "F.Cu") (net 114) (tstamp 76024778-1867-49b6-823b-186ee4622c33))
  (segment (start 68.54 141.757) (end 67.285 141.757) (width 0.25) (layer "F.Cu") (net 114) (tstamp 767e18c1-2aed-491e-a7fd-a4891dba363e))
  (segment (start 61.468 145.288) (end 61.468 111.887) (width 0.25) (layer "F.Cu") (net 114) (tstamp e8274814-6660-4fd6-abe9-8e99310e4552))
  (segment (start 35.32298 76.2) (end 34.798 76.2) (width 0.25) (layer "F.Cu") (net 119) (tstamp 0061e820-e1fb-452c-bc80-fc7c36eeaed8))
  (segment (start 55.811073 73.20492) (end 58.700944 73.20492) (width 0.2) (layer "F.Cu") (net 119) (tstamp 1828700b-92f8-4bfa-8f6d-b09057e7793b))
  (segment (start 62.5856 154.560436) (end 62.5856 152.92981) (width 0.25) (layer "F.Cu") (net 119) (tstamp 1918dab6-e9df-4e65-bf8e-1c0c4531a5a8))
  (segment (start 39.116 71.12) (end 36.83 73.406) (width 0.2) (layer "F.Cu") (net 119) (tstamp 194b2d7a-9f76-40f4-bd76-6fe97486088c))
  (segment (start 36.83 73.406) (end 36.83 73.617) (width 0.2) (layer "F.Cu") (net 119) (tstamp 2cefc9bf-9266-430c-9794-55db867d51f4))
  (segment (start 66.0784 132.624964) (end 66.0784 102.805276) (width 0.25) (layer "F.Cu") (net 119) (tstamp 2ec4dfaa-c51a-4385-a565-ab61bbb7485f))
  (segment (start 36.83 73.617) (end 36.83 73.386476) (width 0.2) (layer "F.Cu") (net 119) (tstamp 4d1bc711-65f9-4a18-9a27-8c400aa62181))
  (segment (start 48.26 73.02946) (end 48.38451 72.90495) (width 0.2) (layer "F.Cu") (net 119) (tstamp 6760223a-65b9-4775-a871-d54f8373447a))
  (segment (start 63.881 160.9185) (end 62.611 159.6485) (width 0.2) (layer "F.Cu") (net 119) (tstamp 718db098-bb4e-43b9-9900-1d18026fbddd))
  (segment (start 48.38451 72.90495) (end 55.511103 72.90495) (width 0.2) (layer "F.Cu") (net 119) (tstamp 75133142-ce93-4a53-9c45-40ffb31121c6))
  (segment (start 55.511103 72.90495) (end 55.811073 73.20492) (width 0.2) (layer "F.Cu") (net 119) (tstamp 78555c7f-70e9-4f02-a035-ff93e4fc8545))
  (segment (start 62.5856 152.92981) (end 71.28008 144.23533) (width 0.25) (layer "F.Cu") (net 119) (tstamp 7d318aa2-7659-49c3-a58a-d3069e85576e))
  (segment (start 71.28008 137.826644) (end 66.0784 132.624964) (width 0.25) (layer "F.Cu") (net 119) (tstamp 89908fca-6276-44f5-9edf-6aaf458f37d4))
  (segment (start 66.0784 102.805276) (end 66.27628 102.607396) (width 0.25) (layer "F.Cu") (net 119) (tstamp 8c4aede4-3d70-4095-8129-38fd7d026add))
  (segment (start 36.8715 76.073) (end 36.83 76.0315) (width 0.2) (layer "F.Cu") (net 119) (tstamp 90166b84-4d98-470b-bb2f-9789afa50f41))
  (segment (start 34.798 76.2) (end 33.909 77.089) (width 0.25) (layer "F.Cu") (net 119) (tstamp 985118f0-356a-4671-b4e6-3cea0031ba4f))
  (segment (start 67.761398 101.122278) (end 66.27628 102.607396) (width 0.2) (layer "F.Cu") (net 119) (tstamp 9ffbf823-f2eb-43a4-9703-a303faf258ae))
  (segment (start 46.355 71.12) (end 39.116 71.12) (width 0.2) (layer "F.Cu") (net 119) (tstamp ba9cd243-9d3e-4e05-a804-5a40368af9f4))
  (segment (start 62.611 154.585836) (end 62.5856 154.560436) (width 0.2) (layer "F.Cu") (net 119) (tstamp c2bedd1d-60c3-47ce-befd-3b07a3a7c752))
  (segment (start 71.28008 144.23533) (end 71.28008 137.826644) (width 0.25) (layer "F.Cu") (net 119) (tstamp c844fe34-e00b-44e0-af0e-fe32f3bb2ab9))
  (segment (start 67.761398 82.265374) (end 67.761398 101.122278) (width 0.2) (layer "F.Cu") (net 119) (tstamp d8c332f1-0b2a-4901-82d3-c6bc6572ce5c))
  (segment (start 33.909 77.089) (end 33.909 77.825) (width 0.25) (layer "F.Cu") (net 119) (tstamp dad7f4e8-181c-498b-a0e0-159caee983dd))
  (segment (start 58.700944 73.20492) (end 67.761398 82.265374) (width 0.2) (layer "F.Cu") (net 119) (tstamp dbbdfc58-3957-453c-afff-e188d53087ea))
  (segment (start 62.611 159.6485) (end 62.611 154.585836) (width 0.2) (layer "F.Cu") (net 119) (tstamp e10b7689-0092-4a77-a9f9-e458d634baf1))
  (segment (start 36.83 76.0315) (end 36.83 73.617) (width 0.2) (layer "F.Cu") (net 119) (tstamp e5a9f24d-4335-4751-be82-f1bd68d534ae))
  (via (at 46.355 71.12) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 119) (tstamp 0f7e587e-380c-4e69-8d43-606933cd64ec))
  (via (at 35.32298 76.2) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 119) (tstamp 3f9c195c-a6bd-41d8-897f-15d5db1b250e))
  (via (at 48.26 73.02946) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 119) (tstamp 99847c52-5002-47c3-9e44-8d1d99f815b5))
  (via (at 36.8715 76.073) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 119) (tstamp ad5bfb10-9a1b-4079-9385-db7058b50e7f))
  (segment (start 46.355 71.12) (end 46.355 71.12446) (width 0.25) (layer "B.Cu") (net 119) (tstamp 45402649-f2e2-40dd-a371-b4c96931afc8))
  (segment (start 46.355 71.12446) (end 48.26 73.02946) (width 0.25) (layer "B.Cu") (net 119) (tstamp 5a32452a-f3bd-4954-b873-9fd2a8771e05))
  (segment (start 36.7445 76.2) (end 36.8715 76.073) (width 0.2) (layer "B.Cu") (net 119) (tstamp 695aa829-fe86-465e-9151-a7ec4d580cc0))
  (segment (start 35.32298 76.2) (end 36.7445 76.2) (width 0.2) (layer "B.Cu") (net 119) (tstamp f6ed5191-ff49-4074-ba05-0dcd2a17c31d))
  (segment (start 156.083 124.46) (end 156.083 127.245) (width 0.2) (layer "F.Cu") (net 121) (tstamp 012fa6fb-817f-4ea9-9213-c2405427de10))
  (segment (start 140.360828 120.65) (end 142.616308 122.90548) (width 0.2) (layer "F.Cu") (net 121) (tstamp 20ddc494-d5a2-4985-8ad8-597fb8ef8b5e))
  (segment (start 154.52848 122.90548) (end 156.083 124.46) (width 0.2) (layer "F.Cu") (net 121) (tstamp 42760685-dc40-406e-845e-4207c3558784))
  (segment (start 138.089 120.65) (end 140.360828 120.65) (width 0.2) (layer "F.Cu") (net 121) (tstamp 659df5a3-c047-404e-ac2a-e3bdca987698))
  (segment (start 136.774 121.965) (end 138.089 120.65) (width 0.2) (layer "F.Cu") (net 121) (tstamp 8ce76fca-9de4-42c6-85b7-e35d8813a418))
  (segment (start 142.616308 122.90548) (end 154.52848 122.90548) (width 0.2) (layer "F.Cu") (net 121) (tstamp dc0973de-670b-44ce-b5a1-36c8eab4fb56))
  (segment (start 142.781794 122.50596) (end 158.95496 122.50596) (width 0.2) (layer "F.Cu") (net 122) (tstamp 1522c6cd-0fdf-4ca8-ac77-7c86badd22ad))
  (segment (start 139.314 119.425) (end 139.700834 119.425) (width 0.2) (layer "F.Cu") (net 122) (tstamp 1e7b1775-31ad-4ec8-853d-cf18d3e0ed4c))
  (segment (start 160.655 124.206) (end 160.655 127.245) (width 0.2) (layer "F.Cu") (net 122) (tstamp 26963a65-9ae7-40d0-bd79-d240c36e4c64))
  (segment (start 139.700834 119.425) (end 142.781794 122.50596) (width 0.2) (layer "F.Cu") (net 122) (tstamp 40d473ae-c2bb-441d-8ebd-b2a7d0fa0874))
  (segment (start 158.95496 122.50596) (end 160.655 124.206) (width 0.2) (layer "F.Cu") (net 122) (tstamp e4a5ef6a-ccf4-41de-a923-1a2fd43ec617))
  (segment (start 68.891 20.581) (end 68.834 20.638) (width 0.2) (layer "F.Cu") (net 124) (tstamp 249d2541-8b87-4fd2-97c8-a6334dc726c9))
  (segment (start 68.834 20.638) (end 68.834 23.5706) (width 0.2) (layer "F.Cu") (net 124) (tstamp 65ce791a-18b2-4b68-bb73-d32d549d994a))
  (segment (start 119.252282 125.476) (end 99.568 125.476) (width 0.25) (layer "F.Cu") (net 125) (tstamp 157bf46a-d1d7-4419-855c-eb87ec55918c))
  (segment (start 97.536 162.306) (end 97.79 162.56) (width 0.25) (layer "F.Cu") (net 125) (tstamp 237f4388-e1b5-4930-a46d-6960c641a978))
  (segment (start 112.549 134.072) (end 100.049 134.072) (width 0.5) (layer "F.Cu") (net 125) (tstamp 261987e7-2a0b-467e-bbbc-c10e6bb75a19))
  (segment (start 97.536 146.839) (end 97.536 162.306) (width 0.25) (layer "F.Cu") (net 125) (tstamp 26e85e21-3cb2-452b-b336-c4991d5d1dc9))
  (segment (start 126.618282 118.11) (end 119.252282 125.476) (width 0.25) (layer "F.Cu") (net 125) (tstamp 284597a1-f052-44d9-9bd8-cce3e7b1c5b3))
  (segment (start 97.79 162.56) (end 100.049 162.56) (width 0.25) (layer "F.Cu") (net 125) (tstamp 4f6a3e73-7d03-4946-8965-ced976f56b97))
  (segment (start 100.049 148.59) (end 112.549 148.59) (width 0.5) (layer "F.Cu") (net 125) (tstamp 583dc28c-1b31-4e7f-856a-890770921d0a))
  (segment (start 99.501 134.072) (end 100.049 134.62) (width 0.25) (layer "F.Cu") (net 125) (tstamp 7611d102-37a8-4ec3-8ed2-f0c421385611))
  (segment (start 132.919 118.11) (end 126.618282 118.11) (width 0.25) (layer "F.Cu") (net 125) (tstamp 9136d4d5-5a5c-47bc-bed8-0389f8b14938))
  (segment (start 97.536 134.072) (end 99.501 134.072) (width 0.25) (layer "F.Cu") (net 125) (tstamp 97c95a24-58bc-46d6-9590-17cb0250d13c))
  (segment (start 134.234 119.425) (end 132.919 118.11) (width 0.25) (layer "F.Cu") (net 125) (tstamp ad58919d-e49b-4348-9690-b884e95dae24))
  (segment (start 97.536 127.508) (end 97.536 134.072) (width 0.25) (layer "F.Cu") (net 125) (tstamp bf7d87c1-6d7a-43fd-b48b-0daf9cd6b9dd))
  (segment (start 100.049 162.56) (end 112.549 162.56) (width 0.5) (layer "F.Cu") (net 125) (tstamp cb460750-05e7-4291-bc1f-b4b0f9e11aa9))
  (segment (start 97.536 133.604) (end 97.536 146.839) (width 0.25) (layer "F.Cu") (net 125) (tstamp eb716a23-6be3-43ee-9207-43283ec3139e))
  (segment (start 97.536 148.59) (end 100.049 148.59) (width 0.25) (layer "F.Cu") (net 125) (tstamp fe605f47-7715-4590-b8b0-febd206ae034))
  (segment (start 99.568 125.476) (end 97.536 127.508) (width 0.25) (layer "F.Cu") (net 125) (tstamp ff4966ce-6837-4f92-827b-ae20da67972b))
  (segment (start 148.14318 138.36418) (end 150.810898 138.36418) (width 0.25) (layer "F.Cu") (net 126) (tstamp 02a3dd43-26c2-49fc-8c4e-f842ada11fb1))
  (segment (start 130.329 148.59) (end 117.829 148.59) (width 0.5) (layer "F.Cu") (net 126) (tstamp 1808f53f-f577-4c6c-9c81-2a9d62e1871d))
  (segment (start 146.304 125.476) (end 146.304 136.525) (width 0.25) (layer "F.Cu") (net 126) (tstamp 401ea14f-e174-4008-81da-36992ca2afa1))
  (segment (start 144.55752 123.72952) (end 146.304 125.476) (width 0.25) (layer "F.Cu") (net 126) (tstamp 40b0d8e0-f5f4-45bd-ad18-e389b5761982))
  (segment (start 138.149 148.59) (end 130.329 148.59) (width 0.25) (layer "F.Cu") (net 126) (tstamp 49efbb75-7411-4e19-99f3-7a088402f7b2))
  (segment (start 153.416 148.463) (end 153.289 148.59) (width 0.25) (layer "F.Cu") (net 126) (tstamp 4a848de2-518d-4d7b-89ef-dd26be2961d8))
  (segment (start 153.416 161.036) (end 154.94 162.56) (width 0.25) (layer "F.Cu") (net 126) (tstamp 54df5b10-03be-475f-89f5-c5e826a4a5ab))
  (segment (start 150.649 148.59) (end 138.149 148.59) (width 0.5) (layer "F.Cu") (net 126) (tstamp 5ad8893c-085c-43ce-ae8d-8dc372c38374))
  (segment (start 135.03252 123.72952) (end 144.55752 123.72952) (width 0.25) (layer "F.Cu") (net 126) (tstamp 5ae6bd8b-1dc2-4cb3-b2b4-4663b9ea794c))
  (segment (start 153.289 148.59) (end 153.416 148.717) (width 0.25) (layer "F.Cu") (net 126) (tstamp 5e21054a-27a3-4230-a4c5-50f966b79c1e))
  (segment (start 155.929 162.56) (end 168.429 162.56) (width 0.5) (layer "F.Cu") (net 126) (tstamp 61fee51c-85e9-4593-9b43-62f73993641b))
  (segment (start 154.94 162.56) (end 155.929 162.56) (width 0.25) (layer "F.Cu") (net 126) (tstamp 635f0f76-b7c2-4f6b-bed3-3dc291bcf41f))
  (segment (start 153.416 140.969282) (end 153.416 147.2584) (width 0.25) (layer "F.Cu") (net 126) (tstamp 665101a7-4ae8-4a84-a91c-e17fc98b5e6d))
  (segment (start 134.234 122.931) (end 135.03252 123.72952) (width 0.25) (layer "F.Cu") (net 126) (tstamp 6dde0d80-0df2-40d4-b559-af0ddaadca67))
  (segment (start 153.416 148.717) (end 153.416 161.036) (width 0.25) (layer "F.Cu") (net 126) (tstamp 74db9711-fece-4a04-ad32-ce13a210663f))
  (segment (start 146.304 136.525) (end 148.14318 138.36418) (width 0.25) (layer "F.Cu") (net 126) (tstamp aa5d29f6-bdc3-4bb4-923d-3bbcef944704))
  (segment (start 134.234 121.965) (end 134.234 122.931) (width 0.25) (layer "F.Cu") (net 126) (tstamp c15a677b-4436-4c4f-97bf-b8f00491f14c))
  (segment (start 153.416 145.415) (end 153.416 148.463) (width 0.25) (layer "F.Cu") (net 126) (tstamp c893b028-74d8-46b9-8405-3a824e56f5d2))
  (segment (start 153.289 148.59) (end 150.649 148.59) (width 0.25) (layer "F.Cu") (net 126) (tstamp e502371f-20aa-4948-9dde-fe8a5fa854bd))
  (segment (start 150.810898 138.36418) (end 153.416 140.969282) (width 0.25) (layer "F.Cu") (net 126) (tstamp f02bea31-2a4d-45e9-8ccb-80fe0673d33b))
  (segment (start 127.989 162.56) (end 140.489 162.56) (width 0.5) (layer "F.Cu") (net 127) (tstamp 0d4d7c10-667f-42e5-97f5-b76b993bbbae))
  (segment (start 145.796 125.73) (end 144.272 124.206) (width 0.25) (layer "F.Cu") (net 127) (tstamp 1bbe315e-e3fd-40a2-ba92-58b765fffcbb))
  (segment (start 133.985 124.206) (end 132.969 123.19) (width 0.25) (layer "F.Cu") (net 127) (tstamp 2708b336-87fc-4997-b3d0-81b75eca1759))
  (segment (start 143.002 153.924) (end 143.891 153.035) (width 0.25) (layer "F.Cu") (net 127) (tstamp 282e70ae-7501-4053-9229-9d6ba2ffc865))
  (segment (start 152.96648 147.00752) (end 152.96648 141.15548) (width 0.25) (layer "F.Cu") (net 127) (tstamp 2acd1fb5-918a-4099-bd6c-a46a25e8ff36))
  (segment (start 132.969 121.158) (end 132.461 120.65) (width 0.2) (layer "F.Cu") (net 127) (tstamp 2d5fd8d7-3f81-4f0c-ad5d-8f2ef8f4d200))
  (segment (start 143.002 161.2692) (end 143.002 153.924) (width 0.25) (layer "F.Cu") (net 127) (tstamp 5474ae0a-2469-4b25-8bee-b063b6737f25))
  (segment (start 132.969 123.19) (end 132.969 121.158) (width 0.2) (layer "F.Cu") (net 127) (tstamp 5b4f62f9-e4d6-4f8b-b7e0-1daf3577767a))
  (segment (start 123.698 122.266362) (end 123.698 129.10048) (width 0.2) (layer "F.Cu") (net 127) (tstamp 634f5b32-c791-46be-a706-2f955a38ee12))
  (segment (start 131.694 120.518) (end 131.694 119.425) (width 0.25) (layer "F.Cu") (net 127) (tstamp 63fd413c-1b78-4f98-8719-d20322cd9d61))
  (segment (start 152.019 153.035) (end 152.654 152.4) (width 0.25) (layer "F.Cu") (net 127) (tstamp 654c2f78-05ee-4952-a61a-8af711326e96))
  (segment (start 152.96648 141.15548) (end 152.654 140.843) (width 0.25) (layer "F.Cu") (net 127) (tstamp 6b0d0168-783e-423c-8e72-3c0e3b1f5545))
  (segment (start 143.891 153.035) (end 152.019 153.035) (width 0.25) (layer "F.Cu") (net 127) (tstamp 725d9fa4-2056-49e7-8147-9e0f70147958))
  (segment (start 152.654 152.4) (end 152.654 149.86) (width 0.25) (layer "F.Cu") (net 127) (tstamp 7ddc104f-b09b-4e01-948b-eb35a6e8d455))
  (segment (start 131.694 120.65) (end 125.314362 120.65) (width 0.2) (layer "F.Cu") (net 127) (tstamp 939d3c82-c579-433e-81aa-cf653d0fb4f5))
  (segment (start 132.461 120.65) (end 131.826 120.65) (width 0.2) (layer "F.Cu") (net 127) (tstamp 9468c163-161d-40d6-b48e-ca1ca93d1529))
  (segment (start 144.272 124.206) (end 133.985 124.206) (width 0.25) (layer "F.Cu") (net 127) (tstamp 97619eef-4afe-4471-8955-576cab23adf1))
  (segment (start 127.989 129.62) (end 140.489 129.62) (width 0.5) (layer "F.Cu") (net 127) (tstamp 98e61143-b2b3-41a0-90bd-c3806fff1196))
  (segment (start 123.698 129.10048) (end 124.21752 129.62) (width 0.2) (layer "F.Cu") (net 127) (tstamp a90b53a1-1f50-4bcc-86d1-c5b76faa8518))
  (segment (start 147.8307 138.8137) (end 145.796 136.779) (width 0.25) (layer "F.Cu") (net 127) (tstamp ac66f524-2095-4dfd-be78-368a2ddee1bd))
  (segment (start 145.796 136.779) (end 145.796 125.73) (width 0.25) (layer "F.Cu") (net 127) (tstamp b441922b-ed57-42f4-a9a0-215412937965))
  (segment (start 141.7112 162.56) (end 143.002 161.2692) (width 0.25) (layer "F.Cu") (net 127) (tstamp be39f22e-6e64-47dc-a8e5-18552af2dde9))
  (segment (start 131.694 119.425) (end 131.694 120.65) (width 0.2) (layer "F.Cu") (net 127) (tstamp bff4c960-a62e-4b77-b04c-c8aa91d3f648))
  (segment (start 140.489 162.56) (end 141.7112 162.56) (width 0.25) (layer "F.Cu") (net 127) (tstamp c24c90ec-3a92-4d01-a518-340286bb3afc))
  (segment (start 152.781 140.97) (end 150.6247 138.8137) (width 0.25) (layer "F.Cu") (net 127) (tstamp c43fb845-f3c6-4573-b0c8-497f079086e9))
  (segment (start 124.21752 129.62) (end 127.989 129.62) (width 0.2) (layer "F.Cu") (net 127) (tstamp ca391b01-58e6-4dd6-92e6-f07a37b13ca1))
  (segment (start 125.314362 120.65) (end 123.698 122.266362) (width 0.2) (layer "F.Cu") (net 127) (tstamp cf0dec50-143c-4ddc-857e-f5bcb0dbfaed))
  (segment (start 152.654 147.32) (end 152.96648 147.00752) (width 0.25) (layer "F.Cu") (net 127) (tstamp d072f662-3716-48af-b339-73981e89747e))
  (segment (start 168.429 148.59) (end 155.929 148.59) (width 0.5) (layer "F.Cu") (net 127) (tstamp e513c180-09e0-4487-a85d-0a453bfd9062))
  (segment (start 150.6247 138.8137) (end 147.8307 138.8137) (width 0.25) (layer "F.Cu") (net 127) (tstamp e749d5fa-5cab-483f-bd53-4150cdcca576))
  (via (at 152.654 147.32) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 127) (tstamp 804dfff6-54c6-42fd-bfb7-37f18aa9b099))
  (via (at 152.654 149.86) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 127) (tstamp 9e6be9db-c776-486e-bbd8-9d88009f9e21))
  (segment (start 152.781 147.447) (end 152.654 147.32) (width 0.25) (layer "B.Cu") (net 127) (tstamp 178591e3-2ae0-4004-8a6e-b0b6a843e2bc))
  (segment (start 152.781 148.463) (end 152.781 147.447) (width 0.25) (layer "B.Cu") (net 127) (tstamp 8e54c706-daba-4cea-995c-a416a67bff0b))
  (segment (start 152.654 149.86) (end 152.781 149.733) (width 0.25) (layer "B.Cu") (net 127) (tstamp 90e404e5-cc51-4df7-9eb3-755d5ba9bf81))
  (segment (start 152.908 148.59) (end 152.781 148.463) (width 0.25) (layer "B.Cu") (net 127) (tstamp b49e19ec-9c51-4f0a-920d-66781ce080b9))
  (segment (start 152.781 149.733) (end 152.781 148.463) (width 0.25) (layer "B.Cu") (net 127) (tstamp e0d11b23-333c-4dc2-89b5-90ddeca147e3))
  (segment (start 152.908 148.59) (end 155.929 148.59) (width 0.25) (layer "B.Cu") (net 127) (tstamp ea68a3a9-d8a9-4b10-a522-654dd2709daa))
  (segment (start 138.149 143.59) (end 135.816 145.923) (width 0.25) (layer "F.Cu") (net 128) (tstamp 030c6dd1-13a2-4fe3-a610-02fe24509bc2))
  (segment (start 131.694 121.965) (end 131.694 123.058) (width 0.25) (layer "F.Cu") (net 128) (tstamp 0d01ecf8-0bb5-4ef1-9189-44afc3ca86d9))
  (segment (start 127.989 157.56) (end 140.489 157.56) (width 0.5) (layer "F.Cu") (net 128) (tstamp 0d786185-71ad-41cf-98d4-aa20f63bc16f))
  (segment (start 133.35 124.714) (end 144.144282 124.714) (width 0.25) (layer "F.Cu") (net 128) (tstamp 20a54cd9-5f21-4917-b6d2-a70cf5456d4d))
  (segment (start 145.34648 142.68952) (end 144.446 143.59) (width 0.25) (layer "F.Cu") (net 128) (tstamp 20ccfbbb-34bb-42b7-8dd6-3c7dad3b16bd))
  (segment (start 125.222 157.56) (end 127.989 157.56) (width 0.25) (layer "F.Cu") (net 128) (tstamp 21ce8381-a5bd-4269-a7e8-1644cb8cd803))
  (segment (start 138.149 143.59) (end 144.446 143.59) (width 0.5) (layer "F.Cu") (net 128) (tstamp 25f9fb77-07e7-4e2a-b6c2-3bd4861c5d2c))
  (segment (start 144.144282 124.714) (end 145.34648 125.916198) (width 0.25) (layer "F.Cu") (net 128) (tstamp 6b7763d9-0f7d-4f17-a998-58bfe6d6bf6a))
  (segment (start 144.446 143.59) (end 150.649 143.59) (width 0.5) (layer "F.Cu") (net 128) (tstamp 7bbcb622-af2e-4573-93ef-38c0bc826885))
  (segment (start 135.816 145.923) (end 116.332 145.923) (width 0.25) (layer "F.Cu") (net 128) (tstamp 80b39545-14d2-474b-bcc1-65f3e77bdc7c))
  (segment (start 116.332 145.923) (end 115.189 147.066) (width 0.25) (layer "F.Cu") (net 128) (tstamp 836b750b-616c-47c3-a672-3140f3c726df))
  (segment (start 125.937 157.56) (end 115.142 157.56) (width 0.25) (layer "F.Cu") (net 128) (tstamp afaa8b51-7721-4553-9a75-f86d0b4ebde6))
  (segment (start 115.189 157.513) (end 115.142 157.56) (width 0.25) (layer "F.Cu") (net 128) (tstamp b7f92b00-0340-4032-bb3e-8421352cf199))
  (segment (start 131.694 123.058) (end 133.35 124.714) (width 0.25) (layer "F.Cu") (net 128) (tstamp c1d7b74a-df6c-4959-8883-0873723c7620))
  (segment (start 145.34648 125.916198) (end 145.34648 142.68952) (width 0.25) (layer "F.Cu") (net 128) (tstamp d29d1dce-4518-4aa8-97b0-e59b3ec83054))
  (segment (start 112.549 157.56) (end 100.049 157.56) (width 0.5) (layer "F.Cu") (net 128) (tstamp d3373f9d-4f2b-4c1c-9e14-e61784225057))
  (segment (start 115.142 157.56) (end 112.549 157.56) (width 0.25) (layer "F.Cu") (net 128) (tstamp d66e4e2f-cfae-4575-89be-2ca6dc2c8445))
  (segment (start 115.189 147.066) (end 115.189 157.513) (width 0.25) (layer "F.Cu") (net 128) (tstamp fc6f6cdc-6482-4d0a-8d30-3863962f0513))
  (segment (start 112.549 143.59) (end 100.049 143.59) (width 0.5) (layer "F.Cu") (net 129) (tstamp 2eed11aa-42df-482b-9ac2-d64a3f490b6e))
  (segment (start 115.179 142.24) (end 113.829 143.59) (width 0.25) (layer "F.Cu") (net 129) (tstamp 33e993df-c34c-44a8-9ef6-498ef1b0e7af))
  (segment (start 127.989 134.62) (end 116.586 134.62) (width 0.25) (layer "F.Cu") (net 129) (tstamp 36d5cfac-b309-4d62-9681-7381dcd40093))
  (segment (start 125.939 119.425) (end 123.27348 122.09052) (width 0.25) (layer "F.Cu") (net 129) (tstamp 3c809ddd-9caa-499d-b8da-e14d537b615a))
  (segment (start 116.529 143.59) (end 115.179 142.24) (width 0.25) (layer "F.Cu") (net 129) (tstamp 3d1a0b33-0c3f-4b3d-9eb4-cb0f51c1ee5c))
  (segment (start 117.829 143.59) (end 130.329 143.59) (width 0.5) (layer "F.Cu") (net 129) (tstamp 45f7b362-7a15-47f8-8beb-cbabd272b39a))
  (segment (start 117.829 143.59) (end 116.529 143.59) (width 0.25) (layer "F.Cu") (net 129) (tstamp 5e1d59c9-fdf3-4869-85da-56e18e18886a))
  (segment (start 129.154 119.425) (end 125.939 119.425) (width 0.25) (layer "F.Cu") (net 129) (tstamp 67debb6a-045f-479a-b5e1-5105902e401b))
  (segment (start 127.989 134.62) (end 140.489 134.62) (width 0.5) (layer "F.Cu") (net 129) (tstamp 8190996e-4613-461b-9a32-46fe6aec7d98))
  (segment (start 123.27348 122.09052) (end 123.27348 134.605) (width 0.25) (layer "F.Cu") (net 129) (tstamp c10dcdeb-307d-4a60-9871-a986fe590935))
  (segment (start 116.586 134.62) (end 115.179 136.027) (width 0.25) (layer "F.Cu") (net 129) (tstamp ccf28326-134f-428e-836a-2191858ce669))
  (segment (start 113.829 143.59) (end 112.549 143.59) (width 0.25) (layer "F.Cu") (net 129) (tstamp e89f398f-2cfe-481a-8f1a-7f595dbf5878))
  (segment (start 115.179 136.027) (end 115.179 142.24) (width 0.25) (layer "F.Cu") (net 129) (tstamp f65d33aa-3aff-415c-85a5-d279143f94e9))
  (segment (start 122.42198 126.365) (end 121.412 126.365) (width 0.25) (layer "F.Cu") (net 130) (tstamp 1c74f33c-df2c-43b1-be44-db9beee222dc))
  (segment (start 144.526 126.238) (end 143.7656 125.4776) (width 0.25) (layer "F.Cu") (net 130) (tstamp 22d47211-6ab1-4847-a02d-f618ba41c870))
  (segment (start 153.924 143.637) (end 153.924 156.2346) (width 0.25) (layer "F.Cu") (net 130) (tstamp 251dcc7a-c5c5-4398-a6d6-e3057a9a9459))
  (segment (start 155.2494 157.56) (end 155.929 157.56) (width 0.25) (layer "F.Cu") (net 130) (tstamp 268ec684-8070-4dd1-aa3e-292586dab88b))
  (segment (start 143.7656 125.4776) (end 133.2246 125.4776) (width 0.25) (layer "F.Cu") (net 130) (tstamp 2a89190c-32a4-4a35-b825-8eca2ab8c681))
  (segment (start 153.924 140.841564) (end 153.924 141.859) (width 0.25) (layer "F.Cu") (net 130) (tstamp 2fa976fc-af94-4d87-b230-b1a659fd58f6))
  (segment (start 133.2246 125.4776) (end 133.223 125.476) (width 0.25) (layer "F.Cu") (net 130) (tstamp 42f551f9-09c6-4836-8e31-f4af6c3941f5))
  (segment (start 153.035 139.952564) (end 153.924 140.841564) (width 0.25) (layer "F.Cu") (net 130) (tstamp 4a11d1ef-4739-4ec9-9c8e-30fce5883c17))
  (segment (start 121.412 126.365) (end 118.705 129.072) (width 0.25) (layer "F.Cu") (net 130) (tstamp 545828d5-e6f7-4206-9804-b30aab469244))
  (segment (start 112.549 129.072) (end 100.049 129.072) (width 0.5) (layer "F.Cu") (net 130) (tstamp 653ffbf9-c6a5-47a2-82ba-8ecc26cd5f7b))
  (segment (start 118.705 129.072) (end 113.097 129.072) (width 0.25) (layer "F.Cu") (net 130) (tstamp 6b8c001d-93dd-4eda-b8ed-75456771e3bf))
  (segment (start 129.159 125.349) (end 129.159 124.079) (width 0.25) (layer "F.Cu") (net 130) (tstamp 72b2974d-a30d-44bf-a818-9b4dde004e4e))
  (segment (start 150.997096 137.91466) (end 153.035 139.952564) (width 0.25) (layer "F.Cu") (net 130) (tstamp 77b6c1f5-6f3d-48eb-9252-322995ee0640))
  (segment (start 147.066 126.238) (end 146.75352 126.55048) (width 0.25) (layer "F.Cu") (net 130) (tstamp 81c7a07e-2e17-4a04-97c9-773d6eb37a65))
  (segment (start 155.929 157.56) (end 168.429 157.56) (width 0.5) (layer "F.Cu") (net 130) (tstamp 82ee76aa-7b91-4870-aeee-54b763957dd8))
  (segment (start 129.159 124.079) (end 129.154 124.074) (width 0.25) (layer "F.Cu") (net 130) (tstamp 8bd744d4-4bfa-453e-955f-695dd9f0db56))
  (segment (start 153.924 156.2346) (end 155.2494 157.56) (width 0.25) (layer "F.Cu") (net 130) (tstamp 8ee32b4d-1124-4020-bdd1-d208a59115b6))
  (segment (start 129.154 124.074) (end 129.154 121.965) (width 0.25) (layer "F.Cu") (net 130) (tstamp 933fa2de-3975-46fc-acc1-a190e7039879))
  (segment (start 153.924 141.859) (end 153.924 143.637) (width 0.25) (layer "F.Cu") (net 130) (tstamp 96fa04ee-92e3-4a0b-a370-3c35b1264a1a))
  (segment (start 125.476 125.476) (end 128.27 125.476) (width 0.25) (layer "F.Cu") (net 130) (tstamp a0f9069c-ee37-4c3f-8fc5-0c188f2a237e))
  (segment (start 113.097 129.072) (end 112.549 129.62) (width 0.25) (layer "F.Cu") (net 130) (tstamp ac687a53-8135-4fae-a845-3a0e86084a0f))
  (segment (start 122.54898 126.492) (end 122.42198 126.365) (width 0.25) (layer "F.Cu") (net 130) (tstamp ad9a8827-b49b-4762-b9ad-f334222167b8))
  (segment (start 146.75352 136.338802) (end 148.329378 137.91466) (width 0.25) (layer "F.Cu") (net 130) (tstamp b7ece0a8-cd6b-4441-93b6-0ae71d0ca702))
  (segment (start 153.971 143.59) (end 153.924 143.637) (width 0.25) (layer "F.Cu") (net 130) (tstamp c0e3ed48-f145-4a1f-bd2d-8a69babbafcb))
  (segment (start 155.929 143.59) (end 168.429 143.59) (width 0.5) (layer "F.Cu") (net 130) (tstamp c21ce5c1-3c2b-40ea-a5bc-cc81b6de35e2))
  (segment (start 124.46 126.492) (end 125.476 125.476) (width 0.25) (layer "F.Cu") (net 130) (tstamp d3d8755f-2c1b-477b-bf55-bb2be4e35251))
  (segment (start 129.032 125.476) (end 129.159 125.349) (width 0.25) (layer "F.Cu") (net 130) (tstamp d6947738-4d35-4793-b64d-c97fbf155134))
  (segment (start 148.329378 137.91466) (end 150.997096 137.91466) (width 0.25) (layer "F.Cu") (net 130) (tstamp e2a103c0-1bed-4717-a48f-c4d5ab1c4cf4))
  (segment (start 146.75352 126.55048) (end 146.75352 136.338802) (width 0.25) (layer "F.Cu") (net 130) (tstamp e51d94bb-8294-4d8e-9490-d32264761bae))
  (segment (start 155.929 143.59) (end 153.971 143.59) (width 0.25) (layer "F.Cu") (net 130) (tstamp e96c2207-1067-435d-b22e-d4a23e4ec251))
  (segment (start 128.27 125.476) (end 129.032 125.476) (width 0.25) (layer "F.Cu") (net 130) (tstamp effe421b-f586-4ec0-8907-785bcfde6e19))
  (segment (start 133.223 125.476) (end 128.27 125.476) (width 0.25) (layer "F.Cu") (net 130) (tstamp f6f299fa-a20e-486b-8cbc-2ba846220a36))
  (via (at 147.066 126.238) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 130) (tstamp 0c45b601-66b9-4718-8396-3a43462f46d5))
  (via (at 124.46 126.492) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 130) (tstamp 9d0dd6c0-72f7-4bcd-b058-904374d69b44))
  (via (at 144.526 126.238) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 130) (tstamp bf920240-8e28-439b-a4d8-63f3d2688471))
  (via (at 122.54898 126.492) (size 0.8) (drill 0.4) (layers "F.Cu" "B.Cu") (net 130) (tstamp ca5f654d-cc22-4f4f-9489-15469813f7a7))
  (segment (start 122.54898 126.492) (end 124.46 126.492) (width 0.25) (layer "B.Cu") (net 130) (tstamp 4b9d7780-4e17-40a8-9eac-e9d1556fa90f))
  (segment (start 144.526 126.238) (end 147.066 126.238) (width 0.25) (layer "B.Cu") (net 130) (tstamp 918e788b-b1da-4497-85d6-58a87002977e))
  (segment (start 160.655 129.295) (end 160.655 131.8) (width 0.2) (layer "F.Cu") (net 131) (tstamp d32920bb-95f0-4254-9c66-4fcccdb4dce1))
  (segment (start 47.371 158.3595) (end 47.371 154.432) (width 0.5) (layer "F.Cu") (net 132) (tstamp 07dd40b1-58ac-4171-9a9e-4a8de9e53ba6))
  (segment (start 49.911 151.892) (end 50.901 151.892) (width 0.5) (layer "F.Cu") (net 132) (tstamp 5b3cdd4e-c6bf-44ac-83da-ff56c7701630))
  (segment (start 47.371 154.432) (end 49.911 151.892) (width 0.5) (layer "F.Cu") (net 132) (tstamp 6c5ba9a4-7474-4ccd-929a-4d3b4f07885c))
  (segment (start 60.325 67.691) (end 58.800999 66.166999) (width 0.25) (layer "F.Cu") (net 133) (tstamp 0e5a9875-3051-4244-9552-9cfa527f0708))
  (segment (start 48.647469 34.550469) (end 48.647469 24.885531) (width 0.2) (layer "F.Cu") (net 133) (tstamp 0f158545-019c-4df1-850c-950e648d1695))
  (segment (start 51.943 46.8005) (end 51.58052 46.43802) (width 0.2) (layer "F.Cu") (net 133) (tstamp 0fa2257c-8bad-4954-8162-ff054e24b773))
  (segment (start 59.107 88.34) (end 57.15 88.34) (width 0.25) (layer "F.Cu") (net 133) (tstamp 1946b3b9-092b-41a7-aef2-a89c34f0bb6e))
  (segment (start 53.975 49.022) (end 53.594 48.641) (width 0.25) (layer "F.Cu") (net 133) (tstamp 23164c57-c69f-44ec-a0fe-8f319130086d))
  (segment (start 68.199 16.764) (end 68.891 17.456) (width 0.2) (layer "F.Cu") (net 133) (tstamp 26baeedd-648e-4339-aa32-291848a2d487))
  (segment (start 44.831 160.8995) (end 43.656489 159.724989) (width 0.2) (layer "F.Cu") (net 133) (tstamp 28542de0-5cf9-41c5-8f36-2874eadb9c0b))
  (segment (start 54.991 16.764) (end 61.3754 16.764) (width 0.2) (layer "F.Cu") (net 133) (tstamp 44d4d648-2d43-4c17-ac91-d93991fd145a))
  (segment (start 58.801 87.884) (end 58.801 85.2835) (width 0.25) (layer "F.Cu") (net 133) (tstamp 4a319f49-61ea-4fdd-b9ab-e879e839942e))
  (segment (start 47.033519 148.767278) (end 47.033519 107.144481) (width 0.2) (layer "F.Cu") (net 133) (tstamp 4fa8548e-adfc-4ebe-a6dc-eb9aa4571d13))
  (segment (start 68.891 17.456) (end 68.891 18.531) (width 0.2) (layer "F.Cu") (net 133) (tstamp 584b2866-c98c-4da1-8cd4-aba6857954b4))
  (segment (start 63.457806 74.922444) (end 60.325 71.789638) (width 0.25) (layer "F.Cu") (net 133) (tstamp 5cfa9cc4-8c9d-41b6-9507-ee2ee8039e9f))
  (segment (start 53.2638 106.6292) (end 56.769 103.124) (width 0.2) (layer "F.Cu") (net 133) (tstamp 5f90f468-be1e-4aa8-9f40-d8a6ae32b54e))
  (segment (start 43.688 156.464) (end 43.688 152.112797) (width 0.2) (layer "F.Cu") (net 133) (tstamp 6020909c-4826-425b-971e-f65feb3f1c0c))
  (segment (start 58.039 92.71) (end 56.769 93.98) (width 0.25) (layer "F.Cu") (net 133) (tstamp 64acb64e-8805-4d77-aecb-d2364b6069ea))
  (segment (start 43.656489 156.495511) (end 43.688 156.464) (width 0.2) (layer "F.Cu") (net 133) (tstamp 6ace17be-0ab5-4f5d-8d50-7c9f321650b4))
  (segment (start 58.801 85.2835) (end 58.674 85.1565) (width 0.25) (layer "F.Cu") (net 133) (tstamp 73ced376-213f-4c7d-bfee-afbfaea8f421))
  (segment (start 47.5488 106.6292) (end 53.2638 106.6292) (width 0.2) (layer "F.Cu") (net 133) (tstamp 754a238a-ab71-4237-8724-f1954c105dc3))
  (segment (start 63.634556 74.922444) (end 63.457806 74.922444) (width 0.25) (layer "F.Cu") (net 133) (tstamp 7b66a762-c723-47ef-853d-55096446d7fb))
  (segment (start 56.769 93.98) (end 56.769 103.124) (width 0.25) (layer "F.Cu") (net 133) (tstamp 7c1d09f2-fdaf-48b3-b533-f3e6bb9db2f2))
  (segment (start 58.800999 66.166999) (end 58.800999 57.403999) (width 0.25) (layer "F.Cu") (net 133) (tstamp 87a741ad-cdab-4b1b-9e40-25944d7d741f))
  (segment (start 53.17304 24.42396) (end 54.229 23.368) (width 0.2) (layer "F.Cu") (net 133) (tstamp 8a3f04e3-6651-45fb-90f6-05a3055aa335))
  (segment (start 53.975 52.578) (end 53.975 49.022) (width 0.25) (layer "F.Cu") (net 133) (tstamp 8cd7b57a-3419-4294-8c3d-89852ab42932))
  (segment (start 49.10904 24.42396) (end 53.17304 24.42396) (width 0.2) (layer "F.Cu") (net 133) (tstamp 926a4a92-ed00-4568-8add-9e5f60a93b63))
  (segment (start 60.2488 82.1944) (end 60.325 82.1182) (width 0.25) (layer "F.Cu") (net 133) (tstamp 9a72b9c3-8beb-4155-984b-976d27d02052))
  (segment (start 51.58052 37.48352) (end 48.895 34.798) (width 0.2) (layer "F.Cu") (net 133) (tstamp 9ae33a79-d60f-4b3e-a864-b6f0ffc21ad1))
  (segment (start 43.656489 159.724989) (end 43.656489 156.495511) (width 0.2) (layer "F.Cu") (net 133) (tstamp b3bf1008-598f-4838-ba58-ea0cca8ac78b))
  (segment (start 59.182 88.265) (end 59.107 88.34) (width 0.25) (layer "F.Cu") (net 133) (tstamp b3fed0ea-343c-4482-9963-a78687a56ec8))
  (segment (start 47.033519 107.144481) (end 47.5488 106.6292) (width 0.2) (layer "F.Cu") (net 133) (tstamp b5c57f18-f298-4ec2-adac-33c4078d10a2))
  (segment (start 54.229 23.368) (end 54.229 17.526) (width 0.2) (layer "F.Cu") (net 133) (tstamp d79febac-35c7-4707-9452-fdea2975486a))
  (segment (start 58.800999 57.403999) (end 53.975 52.578) (width 0.25) (layer "F.Cu") (net 133) (tstamp d8ab0cf3-eea0-4e7e-9814-f7c77abf38e0))
  (segment (start 43.688 152.112797) (end 47.033519 148.767278) (width 0.2) (layer "F.Cu") (net 133) (tstamp d957de35-6c3b-41c2-b36a-4ac2d8eefde2))
  (segment (start 60.325 71.789638) (end 60.325 67.691) (width 0.25) (layer "F.Cu") (net 133) (tstamp d9a0aa5b-11d9-472a-8c07-fe3cfc9b09ed))
  (segment (start 61.3754 16.764) (end 68.199 16.764) (width 0.2) (layer "F.Cu") (net 133) (tstamp dd3eb448-dc75-421d-89d8-fe022156e9cf))
  (segment (start 59.182 88.265) (end 58.801 87.884) (width 0.25) (layer "F.Cu") (net 133) (tstamp e9746813-8880-4cac-afcc-a91b7c2aa938))
  (segment (start 51.58052 46.43802) (end 51.58052 37.48352) (width 0.2) (layer "F.Cu") (net 133) (tstamp e9adcb41-48b0-4715-bb74-0e70d74257d4))
  (segment (start 60.325 82.1182) (end 60.325 79.502) (width 0.25) (layer "F.Cu") (net 133) (tstamp f22cac92-29fb-4904-b7c8-e57768ca28e3))
  (segment (start 48.895 34.798) (end 48.647469 34.550469) (width 0.25) (layer "F.Cu") (net 133) (tstamp f3cc2b97-4e6e-4abc-8932-be0536952e3c))
  (segment (start 48.647469 24.885531) (end 49.10904 24.42396) (width 0.2) (layer "F.Cu") (net 133) (tstamp f46c6b77-ef6b-45e0-9772-cc4c07e5adbe))
  (segment (start 54.229 17.526) (end 54.991 16.764) (width 0.2) (layer "F.Cu") (net 133) (tstamp f9db0dbc-0947-4071-84f6-5d2fc860a124))
  (via (at 60.325 79.502) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 133) (tstamp 1cb81eeb-912e-4967-8c7a-4cd9a2eddf64))
  (via (at 58.039 92.71) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 133) (tstamp 3d59da37-182f-4186-8f55-d58802619b75))
  (via (at 63.634556 74.922444) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 133) (tstamp 74e5ca3a-2730-4b07-9a88-dfc28f71c29e))
  (via (at 53.594 48.641) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 133) (tstamp 883ded46-7bf8-4048-afef-fa9e30cff32e))
  (via (at 51.943 46.8005) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 133) (tstamp 97e76669-60de-4af4-8bae-cb55272bf794))
  (via (at 59.182 88.265) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 133) (tstamp db3175bd-a5bb-4aa2-851b-439ff168fa99))
  (via (at 60.2488 82.1944) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 133) (tstamp f31124af-c18c-47b6-b1de-271b1da5aef2))
  (via (at 58.674 85.1565) (size 0.5) (drill 0.3) (layers "F.Cu" "B.Cu") (net 133) (tstamp f47f212b-5a7b-422e-a7e2-8b358782ae08))
  (segment (start 60.2488 82.1944) (end 60.2488 83.5817) (width 0.2) (layer "B.Cu") (net 133) (tstamp 0e0778f2-dae7-4300-a606-6d60499cf3f9))
  (segment (start 60.2488 83.5817) (end 58.674 85.1565) (width 0.2) (layer "B.Cu") (net 133) (tstamp 154d9c0e-e6d1-4297-b4dd-cc5cfd944bde))
  (segment (start 60.579 79.248) (end 60.579 77.978) (width 0.25) (layer "B.Cu") (net 133) (tstamp 1cc5f202-fd72-48f8-9e6b-1d4207aff431))
  (segment (start 60.579 77.978) (end 63.634556 74.922444) (width 0.25) (layer "B.Cu") (net 133) (tstamp 296fdd0c-1b97-4803-bc1e-d31edc6bc559))
  (segment (start 60.325 79.502) (end 60.579 79.248) (width 0.25) (layer "B.Cu") (net 133) (tstamp 2c7302ce-df82-4883-93e7-170d100924d7))
  (segment (start 59.182 88.265) (end 58.039 89.408) (width 0.25) (layer "B.Cu") (net 133) (tstamp 6a2560f8-356a-48be-a54b-06ff200c255b))
  (segment (start 58.039 89.408) (end 58.039 92.71) (width 0.25) (layer "B.Cu") (net 133) (tstamp 7149c8c8-3f2b-4714-804d-104691b5c5d4))
  (segment (start 51.943 46.99) (end 53.594 48.641) (width 0.25) (layer "B.Cu") (net 133) (tstamp 95411a36-c8da-49b1-ab4e-c96976140fb8))
  (segment (start 51.943 46.8005) (end 51.943 46.99) (width 0.25) (layer "B.Cu") (net 133) (tstamp 9fc16314-d3be-4aaa-88e9-39776d5d13b7))
  (segment (start 54.21433 93.338969) (end 56.622929 93.338969) (width 0.2) (layer "F.Cu") (net 134) (tstamp 2a9d7e6d-f66d-4dbc-b03c-fe38514375b0))
  (segment (start 57.15 92.811898) (end 57.15 91.44) (width 0.2) (layer "F.Cu") (net 134) (tstamp 3530a406-067e-43b3-8b91-6f2acaaca266))
  (segment (start 47.70848 93.30148) (end 54.176841 93.30148) (width 0.2) (layer "F.Cu") (net 134) (tstamp 43aa80a1-7a40-409b-b60e-ee0cebae28b3))
  (segment (start 45.248 92.583) (end 46.99 92.583) (width 0.2) (layer "F.Cu") (net 134) (tstamp 4a25cd88-f30e-4002-917f-54705f52cfec))
  (segment (start 45.216 92.551) (end 45.248 92.583) (width 0.2) (layer "F.Cu") (net 134) (tstamp 4e8521d7-c2ce-45fc-9013-fb623f6a3e48))
  (segment (start 46.99 92.583) (end 47.70848 93.30148) (width 0.2) (layer "F.Cu") (net 134) (tstamp 99ba662e-47c6-41f8-8f87-e0635aacf517))
  (segment (start 56.622929 93.338969) (end 57.15 92.811898) (width 0.2) (layer "F.Cu") (net 134) (tstamp a591f203-848e-41d6-be99-57a01be3e15d))
  (segment (start 54.176841 93.30148) (end 54.21433 93.338969) (width 0.2) (layer "F.Cu") (net 134) (tstamp c4c076b7-fe2b-4e6a-9bbe-c6dc5b72dac9))
  (segment (start 142.450821 123.304999) (end 141.110822 121.965) (width 0.2) (layer "F.Cu") (net 135) (tstamp 0a4de367-b51c-42b8-832f-3f68b4d95446))
  (segment (start 151.594006 134.9) (end 149.87852 133.184514) (width 0.2) (layer "F.Cu") (net 135) (tstamp 1719680f-8760-47f6-a8f8-cfa49dfc571e))
  (segment (start 160.655 134.9) (end 156.083 134.9) (width 0.2) (layer "F.Cu") (net 135) (tstamp 2788b14d-3a5e-4537-8f8f-fd565b79f5b3))
  (segment (start 156.083 134.9) (end 151.594006 134.9) (width 0.2) (layer "F.Cu") (net 135) (tstamp 390dc181-0a13-4590-995d-277e0930c360))
  (segment (start 149.87852 125.62152) (end 147.562 123.305) (width 0.2) (layer "F.Cu") (net 135) (tstamp 4bc4645b-9aae-4b1d-b6bf-012072fe40b7))
  (segment (start 141.110822 121.965) (end 139.314 121.965) (width 0.2) (layer "F.Cu") (net 135) (tstamp 54d80cd5-e956-4529-bc9c-7462c678d5ec))
  (segment (start 147.562 123.305) (end 142.450821 123.304999) (width 0.2) (layer "F.Cu") (net 135) (tstamp 790f42db-8796-4858-900f-d110bcafdb00))
  (segment (start 149.87852 133.184514) (end 149.87852 125.62152) (width 0.2) (layer "F.Cu") (net 135) (tstamp e7314ef5-2337-4c6f-9222-ec70b992ffdd))
  (zone (net 1) (net_name "Net-(BT1-Pad2)") (layer "B.Cu") (tstamp 87f3cd24-fcad-4acc-b622-f3b3c879ae12) (hatch edge 0.508)
    (connect_pads (clearance 0.2))
    (min_thickness 0.254) (filled_areas_thickness no)
    (fill yes (thermal_gap 0.38) (thermal_bridge_width 0.254))
    (polygon
      (pts
        (xy 27.94 43.942)
        (xy 28.956 44.957495)
        (xy 29.718 45.719495)
        (xy 30.429373 45.719495)
        (xy 66.04 45.847)
        (xy 66.040161 56.782377)
        (xy 72.389233 56.782711)
        (xy 72.39 59.817)
        (xy 72.339373 72.389495)
        (xy 76.2 77.469495)
        (xy 76.2 111.76)
        (xy 83.18502 118.749992)
        (xy 84.404373 150.494495)
        (xy 79.324373 155.574495)
        (xy 78.105 156.464)
        (xy 78.105 167.64)
        (xy 15.189373 167.639495)
        (xy 15.189373 15.493495)
        (xy 27.889373 15.493495)
    (filled_polygon
      (layer "B.Cu")
      (pts
        (xy 27.831718 15.513497)
        (xy 27.878211 15.567153)
        (xy 27.889597 15.61927)
        (xy 27.94 43.942)
        (xy 27.947553 43.949549)
        (xy 27.947553 43.94955)
        (xy 28.955999 44.957496)
        (xy 28.956022 44.957517)
        (xy 30.429201 45.719495)
        (xy 30.429653 45.719496)
        (xy 65.914455 45.84655)
        (xy 65.982502 45.866796)
        (xy 66.028802 45.920617)
        (xy 66.040002 45.972546)
        (xy 66.053705 56.782378)
        (xy 66.053706 56.782378)
        (xy 68.987905 56.782532)
        (xy 71.938508 56.782687)
        (xy 72.006626 56.802693)
        (xy 72.053116 56.856351)
        (xy 72.0645 56.908687)
        (xy 72.0645 72.62429)
        (xy 72.06402 72.635272)
        (xy 72.060736 72.672807)
        (xy 72.06359 72.683456)
        (xy 72.070491 72.70921)
        (xy 72.07287 72.719942)
        (xy 72.079412 72.757045)
        (xy 72.084923 72.76659)
        (xy 72.086115 72.769866)
        (xy 72.087592 72.773034)
        (xy 72.090446 72.783684)
        (xy 72.09677 72.792715)
        (xy 72.112055 72.814544)
        (xy 72.117961 72.823815)
        (xy 72.124055 72.834369)
        (xy 72.136806 72.856455)
        (xy 72.165682 72.880685)
        (xy 72.173785 72.888111)
        (xy 72.907889 73.622215)
        (xy 72.915316 73.630319)
        (xy 72.939545 73.659194)
        (xy 72.949094 73.664707)
        (xy 72.972185 73.678039)
        (xy 72.981456 73.683945)
        (xy 73.012316 73.705554)
        (xy 73.022966 73.708408)
        (xy 73.026134 73.709885)
        (xy 73.02941 73.711077)
        (xy 73.038955 73.716588)
        (xy 73.072699 73.722538)
        (xy 73.076058 73.72313)
        (xy 73.086785 73.725508)
        (xy 73.123193 73.735264)
        (xy 73.134169 73.734304)
        (xy 73.134172 73.734304)
        (xy 73.160743 73.731979)
        (xy 73.171724 73.7315)
        (xy 73.29675 73.7315)
        (xy 73.364871 73.751502)
        (xy 73.397068 73.781262)
        (xy 74.959457 75.837129)
        (xy 76.149121 77.402545)
        (xy 76.174318 77.435701)
        (xy 76.19961 77.502039)
        (xy 76.2 77.511939)
        (xy 76.2 111.76)
        (xy 76.207532 111.767537)
        (xy 76.207532 111.767538)
        (xy 83.150134 118.715082)
        (xy 83.184137 118.777407)
        (xy 83.186914 118.79931)
        (xy 84.40226 150.439489)
        (xy 84.384888 150.508327)
        (xy 84.365448 150.53342)
        (xy 79.331301 155.567567)
        (xy 79.316462 155.580266)
        (xy 78.119636 156.453323)
        (xy 78.119635 156.453324)
        (xy 78.105 156.464)
        (xy 78.105 158.087461)
        (xy 78.099102 158.125559)
        (xy 78.088484 158.159032)
        (xy 78.06552 158.363762)
        (xy 78.064405 158.363637)
        (xy 78.064126 158.364541)
        (xy 78.066777 158.378731)
        (xy 78.081164 158.550053)
        (xy 78.082759 158.569053)
        (xy 78.084458 158.574978)
        (xy 78.100119 158.629595)
        (xy 78.105 158.664325)
        (xy 78.105 160.627461)
        (xy 78.099102 160.665559)
        (xy 78.088484 160.699032)
        (xy 78.084596 160.733697)
        (xy 78.066331 160.896535)
        (xy 78.06552 160.903762)
        (xy 78.064405 160.903637)
        (xy 78.064126 160.904541)
        (xy 78.066777 160.918731)
        (xy 78.081164 161.090053)
        (xy 78.082759 161.109053)
        (xy 78.084458 161.114978)
        (xy 78.100119 161.169595)
        (xy 78.105 161.204325)
        (xy 78.105 167.513999)
        (xy 78.084998 167.58212)
        (xy 78.031342 167.628613)
        (xy 77.978999 167.639999)
        (xy 46.625034 167.639747)
        (xy 15.315372 167.639496)
        (xy 15.247251 167.619493)
        (xy 15.200759 167.565837)
        (xy 15.189373 167.513496)
        (xy 15.189373 162.929107)
        (xy 17.928962 162.929107)
        (xy 17.947605 163.297135)
        (xy 17.948142 163.30049)
        (xy 17.948143 163.300496)
        (xy 17.985574 163.534182)
        (xy 18.005886 163.660996)
        (xy 18.103123 164.016435)
        (xy 18.238179 164.359293)
        (xy 18.239762 164.362308)
        (xy 18.407889 164.682544)
        (xy 18.407894 164.682552)
        (xy 18.409473 164.68556)
        (xy 18.615002 164.991419)
        (xy 18.852361 165.273292)
        (xy 19.118774 165.527882)
        (xy 19.411124 165.75221)
        (xy 19.414037 165.753981)
        (xy 19.723077 165.941881)
        (xy 19.723082 165.941884)
        (xy 19.725992 165.943653)
        (xy 20.059693 166.09997)
        (xy 20.408325 166.219333)
        (xy 20.411648 166.220082)
        (xy 20.411652 166.220083)
        (xy 20.764484 166.299598)
        (xy 20.76449 166.299599)
        (xy 20.767809 166.300347)
        (xy 20.771188 166.300732)
        (xy 20.771194 166.300733)
        (xy 20.92451 166.318201)
        (xy 21.13394 166.342062)
        (xy 21.137345 166.34208)
        (xy 21.137348 166.34208)
        (xy 21.334323 166.343111)
        (xy 21.502434 166.343991)
        (xy 21.50582 166.343641)
        (xy 21.505822 166.343641)
        (xy 21.865589 166.306463)
        (xy 21.865598 166.306462)
        (xy 21.868981 166.306112)
        (xy 21.872314 166.305397)
        (xy 21.872317 166.305397)
        (xy 22.049825 166.267343)
        (xy 22.229294 166.228868)
        (xy 22.579157 166.113162)
        (xy 22.914477 165.960348)
        (xy 23.226416 165.775132)
        (xy 23.228387 165.773962)
        (xy 23.228392 165.773959)
        (xy 23.231332 165.772213)
        (xy 23.526015 165.550959)
        (xy 23.79508 165.299173)
        (xy 24.035378 165.019801)
        (xy 24.234341 164.730308)
        (xy 24.242168 164.71892)
        (xy 24.242173 164.718913)
        (xy 24.244098 164.716111)
        (xy 24.24571 164.713117)
        (xy 24.245715 164.713109)
        (xy 24.417177 164.394667)
        (xy 24.418799 164.391655)
        (xy 24.557438 164.05023)
        (xy 24.658391 163.695829)
        (xy 24.72048 163.332598)
        (xy 24.722444 163.300496)
        (xy 24.742866 162.966583)
        (xy 24.742976 162.964786)
        (xy 24.743059 162.941)
        (xy 24.723131 162.57304)
        (xy 24.66358 162.209384)
        (xy 24.565103 161.854287)
        (xy 24.563845 161.851125)
        (xy 24.563842 161.851117)
        (xy 24.445339 161.553334)
        (xy 36.1605 161.553334)
        (xy 36.163481 161.584869)
        (xy 36.208366 161.712684)
        (xy 36.213958 161.720254)
        (xy 36.213959 161.720257)
        (xy 36.268082 161.793533)
        (xy 36.28885 161.82165)
        (xy 36.296421 161.827242)
        (xy 36.390243 161.896541)
        (xy 36.390246 161.896542)
        (xy 36.397816 161.902134)
        (xy 36.525631 161.947019)
        (xy 36.533277 161.947742)
        (xy 36.533278 161.947742)
        (xy 36.539248 161.948306)
        (xy 36.557166 161.95)
        (xy 37.864834 161.95)
        (xy 37.882752 161.948306)
        (xy 37.888722 161.947742)
        (xy 37.888723 161.947742)
        (xy 37.896369 161.947019)
        (xy 38.024184 161.902134)
        (xy 38.031754 161.896542)
        (xy 38.031757 161.896541)
        (xy 38.125579 161.827242)
        (xy 38.13315 161.82165)
        (xy 38.153918 161.793533)
        (xy 38.208041 161.720257)
        (xy 38.208042 161.720254)
        (xy 38.213634 161.712684)
        (xy 38.258519 161.584869)
        (xy 38.2615 161.553334)
        (xy 38.2615 160.884762)
        (xy 38.69552 160.884762)
        (xy 38.698448 160.919632)
        (xy 38.701533 160.956362)
        (xy 38.712759 161.090053)
        (xy 38.714458 161.095978)
        (xy 38.737419 161.176051)
        (xy 38.769544 161.288086)
        (xy 38.772359 161.293563)
        (xy 38.77236 161.293566)
        (xy 38.793247 161.334207)
        (xy 38.863712 161.471318)
        (xy 38.991677 161.63277)
        (xy 38.99637 161.636764)
        (xy 38.996371 161.636765)
        (xy 39.058402 161.689557)
        (xy 39.148564 161.766291)
        (xy 39.328398 161.866797)
        (xy 39.386874 161.885797)
        (xy 39.518471 161.928556)
        (xy 39.518475 161.928557)
        (xy 39.524329 161.930459)
        (xy 39.728894 161.954851)
        (xy 39.735029 161.954379)
        (xy 39.735031 161.954379)
        (xy 39.795565 161.949721)
        (xy 39.9343 161.939046)
        (xy 39.94023 161.93739)
        (xy 39.940232 161.93739)
        (xy 40.074613 161.89987)
        (xy 40.132725 161.883645)
        (xy 40.138214 161.880872)
        (xy 40.13822 161.88087)
        (xy 40.311116 161.793533)
        (xy 40.31661 161.790758)
        (xy 40.323608 161.785291)
        (xy 40.474101 161.667713)
        (xy 40.478951 161.663924)
        (xy 40.528413 161.606622)
        (xy 40.60954 161.512634)
        (xy 40.60954 161.512633)
        (xy 40.613564 161.507972)
        (xy 40.61746 161.501115)
        (xy 40.701483 161.353207)
        (xy 40.715323 161.328844)
        (xy 40.780351 161.133363)
        (xy 40.806171 160.928974)
        (xy 40.806418 160.911333)
        (xy 40.806534 160.903022)
        (xy 40.806534 160.903018)
        (xy 40.806583 160.8995)
        (xy 40.805138 160.884762)
        (xy 41.23552 160.884762)
        (xy 41.238448 160.919632)
        (xy 41.241533 160.956362)
        (xy 41.252759 161.090053)
        (xy 41.254458 161.095978)
        (xy 41.277419 161.176051)
        (xy 41.309544 161.288086)
        (xy 41.312359 161.293563)
        (xy 41.31236 161.293566)
        (xy 41.333247 161.334207)
        (xy 41.403712 161.471318)
        (xy 41.531677 161.63277)
        (xy 41.53637 161.636764)
        (xy 41.536371 161.636765)
        (xy 41.598402 161.689557)
        (xy 41.688564 161.766291)
        (xy 41.868398 161.866797)
        (xy 41.926874 161.885797)
        (xy 42.058471 161.928556)
        (xy 42.058475 161.928557)
        (xy 42.064329 161.930459)
        (xy 42.268894 161.954851)
        (xy 42.275029 161.954379)
        (xy 42.275031 161.954379)
        (xy 42.335565 161.949721)
        (xy 42.4743 161.939046)
        (xy 42.48023 161.93739)
        (xy 42.480232 161.93739)
        (xy 42.614613 161.89987)
        (xy 42.672725 161.883645)
        (xy 42.678214 161.880872)
        (xy 42.67822 161.88087)
        (xy 42.851116 161.793533)
        (xy 42.85661 161.790758)
        (xy 42.863608 161.785291)
        (xy 43.014101 161.667713)
        (xy 43.018951 161.663924)
        (xy 43.068413 161.606622)
        (xy 43.14954 161.512634)
        (xy 43.14954 161.512633)
        (xy 43.153564 161.507972)
        (xy 43.15746 161.501115)
        (xy 43.241483 161.353207)
        (xy 43.255323 161.328844)
        (xy 43.320351 161.133363)
        (xy 43.346171 160.928974)
        (xy 43.346418 160.911333)
        (xy 43.346534 160.903022)
        (xy 43.346534 160.903018)
        (xy 43.346583 160.8995)
        (xy 43.345138 160.884762)
        (xy 43.77552 160.884762)
        (xy 43.778448 160.919632)
        (xy 43.781533 160.956362)
        (xy 43.792759 161.090053)
        (xy 43.794458 161.095978)
        (xy 43.817419 161.176051)
        (xy 43.849544 161.288086)
        (xy 43.852359 161.293563)
        (xy 43.85236 161.293566)
        (xy 43.873247 161.334207)
        (xy 43.943712 161.471318)
        (xy 44.071677 161.63277)
        (xy 44.07637 161.636764)
        (xy 44.076371 161.636765)
        (xy 44.138402 161.689557)
        (xy 44.228564 161.766291)
        (xy 44.408398 161.866797)
        (xy 44.466874 161.885797)
        (xy 44.598471 161.928556)
        (xy 44.598475 161.928557)
        (xy 44.604329 161.930459)
        (xy 44.808894 161.954851)
        (xy 44.815029 161.954379)
        (xy 44.815031 161.954379)
        (xy 44.875565 161.949721)
        (xy 45.0143 161.939046)
        (xy 45.02023 161.93739)
        (xy 45.020232 161.93739)
        (xy 45.154613 161.89987)
        (xy 45.212725 161.883645)
        (xy 45.218214 161.880872)
        (xy 45.21822 161.88087)
        (xy 45.268267 161.855589)
        (xy 46.59986 161.855589)
        (xy 46.609156 161.867605)
        (xy 46.749146 161.965626)
        (xy 46.758636 161.971105)
        (xy 46.943726 162.057414)
        (xy 46.954018 162.06116)
        (xy 47.151282 162.114016)
        (xy 47.162077 162.115919)
        (xy 47.365525 162.133719)
        (xy 47.376475 162.133719)
        (xy 47.579923 162.115919)
        (xy 47.590718 162.114016)
        (xy 47.787982 162.06116)
        (xy 47.798274 162.057414)
        (xy 47.983364 161.971105)
        (xy 47.992854 161.965626)
        (xy 48.133683 161.867017)
        (xy 48.142057 161.856541)
        (xy 48.134988 161.843093)
        (xy 47.383812 161.091917)
        (xy 47.369868 161.084303)
        (xy 47.368035 161.084434)
        (xy 47.36142 161.088685)
        (xy 46.60629 161.843815)
        (xy 45.391116 161.793533)
        (xy 45.39661 161.790758)
        (xy 45.403608 161.785291)
        (xy 45.554101 161.667713)
        (xy 45.558951 161.663924)
        (xy 45.608413 161.606622)
        (xy 45.68954 161.512634)
        (xy 45.68954 161.512633)
        (xy 45.693564 161.507972)
        (xy 45.69746 161.501115)
        (xy 45.781483 161.353207)
        (xy 45.795323 161.328844)
        (xy 45.860351 161.133363)
        (xy 45.886171 160.928974)
        (xy 45.886225 160.925099)
        (xy 45.88625 160.925018)
        (xy 45.886466 160.921938)
        (xy 45.887186 160.921988)
        (xy 45.890518 160.911199)
        (xy 45.887878 160.906177)
        (xy 45.886716 160.898386)
        (xy 46.134561 160.898386)
        (xy 46.137734 160.915871)
        (xy 46.154581 161.108423)
        (xy 46.156484 161.119218)
        (xy 46.20934 161.316482)
        (xy 46.213086 161.326774)
        (xy 46.299395 161.511864)
        (xy 46.304874 161.521354)
        (xy 46.403483 161.662183)
        (xy 46.413959 161.670557)
        (xy 46.427407 161.663488)
        (xy 47.178583 160.912312)
        (xy 47.184961 160.900632)
        (xy 47.555803 160.900632)
        (xy 47.555934 160.902465)
        (xy 47.560185 160.90908)
        (xy 48.315315 161.66421)
        (xy 48.327089 161.67064)
        (xy 48.339105 161.661344)
        (xy 48.437126 161.521354)
        (xy 48.442605 161.511864)
        (xy 48.528914 161.326774)
        (xy 48.53266 161.316482)
        (xy 48.585516 161.119218)
        (xy 48.587419 161.108423)
        (xy 48.605219 160.904975)
        (xy 48.605219 160.903762)
        (xy 60.28552 160.903762)
        (xy 60.287931 160.932478)
        (xy 60.301164 161.090053)
        (xy 60.302759 161.109053)
        (xy 60.304458 161.114978)
        (xy 60.351075 161.27755)
        (xy 60.359544 161.307086)
        (xy 60.362359 161.312563)
        (xy 60.36236 161.312566)
        (xy 60.450897 161.484841)
        (xy 60.453712 161.490318)
        (xy 60.581677 161.65177)
        (xy 60.58637 161.655764)
        (xy 60.586371 161.655765)
        (xy 60.617771 161.682488)
        (xy 60.738564 161.785291)
        (xy 60.918398 161.885797)
        (xy 61.013238 161.916613)
        (xy 61.108471 161.947556)
        (xy 61.108475 161.947557)
        (xy 61.114329 161.949459)
        (xy 61.318894 161.973851)
        (xy 61.325029 161.973379)
        (xy 61.325031 161.973379)
        (xy 61.381039 161.969069)
        (xy 61.5243 161.958046)
        (xy 61.53023 161.95639)
        (xy 61.530232 161.95639)
        (xy 61.716797 161.9043)
        (xy 61.716796 161.9043)
        (xy 61.722725 161.902645)
        (xy 61.728214 161.899872)
        (xy 61.72822 161.89987)
        (xy 61.860952 161.832822)
        (xy 61.90661 161.809758)
        (xy 62.068951 161.682924)
        (xy 62.079555 161.67064)
        (xy 62.19954 161.531634)
        (xy 62.19954 161.531633)
        (xy 62.203564 161.526972)
        (xy 62.206756 161.521354)
        (xy 62.242056 161.459214)
        (xy 62.305323 161.347844)
        (xy 62.370351 161.152363)
        (xy 62.396171 160.947974)
        (xy 62.396404 160.931312)
        (xy 62.396534 160.922022)
        (xy 62.396534 160.922018)
        (xy 62.396583 160.9185)
        (xy 62.395138 160.903762)
        (xy 62.82552 160.903762)
        (xy 62.827931 160.932478)
        (xy 62.841164 161.090053)
        (xy 62.842759 161.109053)
        (xy 62.844458 161.114978)
        (xy 62.891075 161.27755)
        (xy 62.899544 161.307086)
        (xy 62.902359 161.312563)
        (xy 62.90236 161.312566)
        (xy 62.990897 161.484841)
        (xy 62.993712 161.490318)
        (xy 63.121677 161.65177)
        (xy 63.12637 161.655764)
        (xy 63.126371 161.655765)
        (xy 63.157771 161.682488)
        (xy 63.278564 161.785291)
        (xy 63.458398 161.885797)
        (xy 63.553238 161.916613)
        (xy 63.648471 161.947556)
        (xy 63.648475 161.947557)
        (xy 63.654329 161.949459)
        (xy 63.858894 161.973851)
        (xy 63.865029 161.973379)
        (xy 63.865031 161.973379)
        (xy 63.921039 161.969069)
        (xy 64.0643 161.958046)
        (xy 64.07023 161.95639)
        (xy 64.070232 161.95639)
        (xy 64.256797 161.9043)
        (xy 64.256796 161.9043)
        (xy 64.262725 161.902645)
        (xy 64.268214 161.899872)
        (xy 64.26822 161.89987)
        (xy 64.400952 161.832822)
        (xy 64.44661 161.809758)
        (xy 64.608951 161.682924)
        (xy 64.619555 161.67064)
        (xy 64.73954 161.531634)
        (xy 64.73954 161.531633)
        (xy 64.743564 161.526972)
        (xy 64.746756 161.521354)
        (xy 64.782056 161.459214)
        (xy 64.845323 161.347844)
        (xy 64.910351 161.152363)
        (xy 64.936171 160.947974)
        (xy 64.936404 160.931312)
        (xy 64.936534 160.922022)
        (xy 64.936534 160.922018)
        (xy 64.936583 160.9185)
        (xy 64.935138 160.903762)
        (xy 65.36552 160.903762)
        (xy 65.367931 160.932478)
        (xy 65.381164 161.090053)
        (xy 65.382759 161.109053)
        (xy 65.384458 161.114978)
        (xy 65.431075 161.27755)
        (xy 65.439544 161.307086)
        (xy 65.442359 161.312563)
        (xy 65.44236 161.312566)
        (xy 65.530897 161.484841)
        (xy 65.533712 161.490318)
        (xy 65.661677 161.65177)
        (xy 65.66637 161.655764)
        (xy 65.666371 161.655765)
        (xy 65.697771 161.682488)
        (xy 65.818564 161.785291)
        (xy 65.998398 161.885797)
        (xy 66.093238 161.916613)
        (xy 66.188471 161.947556)
        (xy 66.188475 161.947557)
        (xy 66.194329 161.949459)
        (xy 66.398894 161.973851)
        (xy 66.405029 161.973379)
        (xy 66.405031 161.973379)
        (xy 66.461039 161.969069)
        (xy 66.6043 161.958046)
        (xy 66.61023 161.95639)
        (xy 66.610232 161.95639)
        (xy 66.796797 161.9043)
        (xy 66.796796 161.9043)
        (xy 66.802725 161.902645)
        (xy 66.808214 161.899872)
        (xy 66.80822 161.89987)
        (xy 66.940952 161.832822)
        (xy 66.98661 161.809758)
        (xy 67.148951 161.682924)
        (xy 67.159555 161.67064)
        (xy 67.27954 161.531634)
        (xy 67.27954 161.531633)
        (xy 67.283564 161.526972)
        (xy 67.286756 161.521354)
        (xy 67.322056 161.459214)
        (xy 67.385323 161.347844)
        (xy 67.450351 161.152363)
        (xy 67.476171 160.947974)
        (xy 67.476404 160.931312)
        (xy 67.476534 160.922022)
        (xy 67.476534 160.922018)
        (xy 67.476583 160.9185)
        (xy 67.475138 160.903762)
        (xy 67.90552 160.903762)
        (xy 67.907931 160.932478)
        (xy 67.921164 161.090053)
        (xy 67.922759 161.109053)
        (xy 67.924458 161.114978)
        (xy 67.971075 161.27755)
        (xy 67.979544 161.307086)
        (xy 67.982359 161.312563)
        (xy 67.98236 161.312566)
        (xy 68.070897 161.484841)
        (xy 68.073712 161.490318)
        (xy 68.201677 161.65177)
        (xy 68.20637 161.655764)
        (xy 68.206371 161.655765)
        (xy 68.237771 161.682488)
        (xy 68.358564 161.785291)
        (xy 68.538398 161.885797)
        (xy 68.633238 161.916613)
        (xy 68.728471 161.947556)
        (xy 68.728475 161.947557)
        (xy 68.734329 161.949459)
        (xy 68.938894 161.973851)
        (xy 68.945029 161.973379)
        (xy 68.945031 161.973379)
        (xy 69.001039 161.969069)
        (xy 69.1443 161.958046)
        (xy 69.15023 161.95639)
        (xy 69.150232 161.95639)
        (xy 69.336797 161.9043)
        (xy 69.336796 161.9043)
        (xy 69.342725 161.902645)
        (xy 69.348214 161.899872)
        (xy 69.34822 161.89987)
        (xy 69.398268 161.874589)
        (xy 70.72986 161.874589)
        (xy 70.739156 161.886605)
        (xy 70.879146 161.984626)
        (xy 70.888636 161.990105)
        (xy 71.073726 162.076414)
        (xy 71.084018 162.08016)
        (xy 71.281282 162.133016)
        (xy 71.292077 162.134919)
        (xy 71.495525 162.152719)
        (xy 71.506475 162.152719)
        (xy 71.709923 162.134919)
        (xy 71.720718 162.133016)
        (xy 71.917982 162.08016)
        (xy 71.928274 162.076414)
        (xy 72.113364 161.990105)
        (xy 72.122854 161.984626)
        (xy 72.263683 161.886017)
        (xy 72.272057 161.875541)
        (xy 72.271557 161.874589)
        (xy 73.26986 161.874589)
        (xy 73.279156 161.886605)
        (xy 73.419146 161.984626)
        (xy 73.428636 161.990105)
        (xy 73.613726 162.076414)
        (xy 73.624018 162.08016)
        (xy 73.821282 162.133016)
        (xy 73.832077 162.134919)
        (xy 74.035525 162.152719)
        (xy 74.046475 162.152719)
        (xy 74.249923 162.134919)
        (xy 74.260718 162.133016)
        (xy 74.457982 162.08016)
        (xy 74.468274 162.076414)
        (xy 74.653364 161.990105)
        (xy 74.662854 161.984626)
        (xy 74.803683 161.886017)
        (xy 74.812057 161.875541)
        (xy 74.811557 161.874589)
        (xy 75.80986 161.874589)
        (xy 75.819156 161.886605)
        (xy 75.959146 161.984626)
        (xy 75.968636 161.990105)
        (xy 76.153726 162.076414)
        (xy 76.164018 162.08016)
        (xy 76.361282 162.133016)
        (xy 76.372077 162.134919)
        (xy 76.575525 162.152719)
        (xy 76.586475 162.152719)
        (xy 76.789923 162.134919)
        (xy 76.800718 162.133016)
        (xy 76.997982 162.08016)
        (xy 77.008274 162.076414)
        (xy 77.193364 161.990105)
        (xy 77.202854 161.984626)
        (xy 77.343683 161.886017)
        (xy 77.352057 161.875541)
        (xy 77.344988 161.862093)
        (xy 76.593812 161.110917)
        (xy 76.579868 161.103303)
        (xy 76.578035 161.103434)
        (xy 76.57142 161.107685)
        (xy 75.81629 161.862815)
        (xy 74.804988 161.862093)
        (xy 74.053812 161.110917)
        (xy 74.039868 161.103303)
        (xy 74.038035 161.103434)
        (xy 74.03142 161.107685)
        (xy 73.27629 161.862815)
        (xy 72.264988 161.862093)
        (xy 71.513812 161.110917)
        (xy 71.499868 161.103303)
        (xy 71.498035 161.103434)
        (xy 71.49142 161.107685)
        (xy 70.73629 161.862815)
        (xy 69.480952 161.832822)
        (xy 69.52661 161.809758)
        (xy 69.688951 161.682924)
        (xy 69.699555 161.67064)
        (xy 69.81954 161.531634)
        (xy 69.81954 161.531633)
        (xy 69.823564 161.526972)
        (xy 69.826756 161.521354)
        (xy 69.862056 161.459214)
        (xy 69.925323 161.347844)
        (xy 69.990351 161.152363)
        (xy 70.016171 160.947974)
        (xy 70.016225 160.944099)
        (xy 70.01625 160.944018)
        (xy 70.016466 160.940938)
        (xy 70.017186 160.940988)
        (xy 70.020518 160.930199)
        (xy 70.017878 160.925177)
        (xy 70.016716 160.917386)
        (xy 70.264561 160.917386)
        (xy 70.267734 160.934871)
        (xy 70.284581 161.127423)
        (xy 70.286484 161.138218)
        (xy 70.33934 161.335482)
        (xy 70.343086 161.345774)
        (xy 70.429395 161.530864)
        (xy 70.434874 161.540354)
        (xy 70.533483 161.681183)
        (xy 70.543959 161.689557)
        (xy 70.557407 161.682488)
        (xy 71.308583 160.931312)
        (xy 71.314961 160.919632)
        (xy 71.685803 160.919632)
        (xy 71.685934 160.921465)
        (xy 71.690185 160.92808)
        (xy 72.445315 161.68321)
        (xy 72.457089 161.68964)
        (xy 72.469105 161.680344)
        (xy 72.567126 161.540354)
        (xy 72.572605 161.530864)
        (xy 72.656805 161.350296)
        (xy 72.703722 161.297011)
        (xy 72.772 161.27755)
        (xy 72.83996 161.298092)
        (xy 72.885195 161.350296)
        (xy 72.969395 161.530864)
        (xy 72.974874 161.540354)
        (xy 73.073483 161.681183)
        (xy 73.083959 161.689557)
        (xy 73.097407 161.682488)
        (xy 73.848583 160.931312)
        (xy 73.854961 160.919632)
        (xy 74.225803 160.919632)
        (xy 74.225934 160.921465)
        (xy 74.230185 160.92808)
        (xy 74.985315 161.68321)
        (xy 74.997089 161.68964)
        (xy 75.009105 161.680344)
        (xy 75.107126 161.540354)
        (xy 75.112605 161.530864)
        (xy 75.196805 161.350296)
        (xy 75.243722 161.297011)
        (xy 75.312 161.27755)
        (xy 75.37996 161.298092)
        (xy 75.425195 161.350296)
        (xy 75.509395 161.530864)
        (xy 75.514874 161.540354)
        (xy 75.613483 161.681183)
        (xy 75.623959 161.689557)
        (xy 75.637407 161.682488)
        (xy 76.388583 160.931312)
        (xy 76.394961 160.919632)
        (xy 76.765803 160.919632)
        (xy 76.765934 160.921465)
        (xy 76.770185 160.92808)
        (xy 77.525315 161.68321)
        (xy 77.537089 161.68964)
        (xy 77.549105 161.680344)
        (xy 77.647126 161.540354)
        (xy 77.652605 161.530864)
        (xy 77.738914 161.345774)
        (xy 77.74266 161.335482)
        (xy 77.795516 161.138218)
        (xy 77.797419 161.127423)
        (xy 77.815698 160.9185)
        (xy 77.816793 160.918596)
        (xy 77.814697 160.907042)
        (xy 77.797421 160.709589)
        (xy 77.795516 160.698782)
        (xy 77.74266 160.501518)
        (xy 77.738914 160.491226)
        (xy 77.652605 160.306136)
        (xy 77.647126 160.296646)
        (xy 77.548517 160.155817)
        (xy 77.538041 160.147443)
        (xy 77.524593 160.154512)
        (xy 76.773417 160.905688)
        (xy 76.396197 160.917368)
        (xy 76.396066 160.915535)
        (xy 76.391815 160.90892)
        (xy 75.636685 160.15379)
        (xy 75.624911 160.14736)
        (xy 75.612895 160.156656)
        (xy 75.514874 160.296646)
        (xy 75.509395 160.306136)
        (xy 75.425195 160.486704)
        (xy 75.378278 160.539989)
        (xy 75.31 160.55945)
        (xy 75.24204 160.538908)
        (xy 75.196805 160.486704)
        (xy 75.112605 160.306136)
        (xy 75.107126 160.296646)
        (xy 75.008517 160.155817)
        (xy 74.998041 160.147443)
        (xy 74.984593 160.154512)
        (xy 74.233417 160.905688)
        (xy 73.856197 160.917368)
        (xy 73.856066 160.915535)
        (xy 73.851815 160.90892)
        (xy 73.096685 160.15379)
        (xy 73.084911 160.14736)
        (xy 73.072895 160.156656)
        (xy 72.974874 160.296646)
        (xy 72.969395 160.306136)
        (xy 72.885195 160.486704)
        (xy 72.838278 160.539989)
        (xy 72.77 160.55945)
        (xy 72.70204 160.538908)
        (xy 72.656805 160.486704)
        (xy 72.572605 160.306136)
        (xy 72.567126 160.296646)
        (xy 72.468517 160.155817)
        (xy 72.458041 160.147443)
        (xy 72.444593 160.154512)
        (xy 71.693417 160.905688)
        (xy 71.316197 160.917368)
        (xy 71.316066 160.915535)
        (xy 71.311815 160.90892)
        (xy 70.556685 160.15379)
        (xy 70.544911 160.14736)
        (xy 70.532895 160.156656)
        (xy 70.434874 160.296646)
        (xy 70.429395 160.306136)
        (xy 70.343086 160.491226)
        (xy 70.33934 160.501518)
        (xy 70.286484 160.698782)
        (xy 70.284581 160.709577)
        (xy 70.266929 160.911333)
        (xy 70.016009 160.912646)
        (xy 70.01266 160.878487)
        (xy 69.99648 160.71347)
        (xy 69.936935 160.516249)
        (xy 69.840218 160.334349)
        (xy 69.748407 160.221778)
        (xy 69.713906 160.179475)
        (xy 69.713903 160.179472)
        (xy 69.710011 160.1747)
        (xy 69.6882 160.156656)
        (xy 69.556025 160.047311)
        (xy 69.556021 160.047309)
        (xy 69.551275 160.043382)
        (xy 69.370055 159.945397)
        (xy 69.173254 159.884477)
        (xy 69.167129 159.883833)
        (xy 69.167128 159.883833)
        (xy 68.974498 159.863587)
        (xy 68.974496 159.863587)
        (xy 68.968369 159.862943)
        (xy 68.881529 159.870846)
        (xy 68.769342 159.881055)
        (xy 68.769339 159.881056)
        (xy 68.763203 159.881614)
        (xy 68.565572 159.93978)
        (xy 68.560107 159.942637)
        (xy 68.544143 159.950983)
        (xy 68.383002 160.035226)
        (xy 68.378201 160.039086)
        (xy 68.378198 160.039088)
        (xy 68.233162 160.1557)
        (xy 68.222447 160.164315)
        (xy 68.090024 160.32213)
        (xy 68.087056 160.327528)
        (xy 68.087053 160.327533)
        (xy 68.007508 160.472226)
        (xy 67.990776 160.502662)
        (xy 67.928484 160.699032)
        (xy 67.927798 160.705149)
        (xy 67.927797 160.705153)
        (xy 67.919968 160.774953)
        (xy 67.45648 160.71347)
        (xy 67.396935 160.516249)
        (xy 67.300218 160.334349)
        (xy 67.208407 160.221778)
        (xy 67.173906 160.179475)
        (xy 67.173903 160.179472)
        (xy 67.170011 160.1747)
        (xy 67.1482 160.156656)
        (xy 67.016025 160.047311)
        (xy 67.016021 160.047309)
        (xy 67.011275 160.043382)
        (xy 66.830055 159.945397)
        (xy 66.633254 159.884477)
        (xy 66.627129 159.883833)
        (xy 66.627128 159.883833)
        (xy 66.434498 159.863587)
        (xy 66.434496 159.863587)
        (xy 66.428369 159.862943)
        (xy 66.341529 159.870846)
        (xy 66.229342 159.881055)
        (xy 66.229339 159.881056)
        (xy 66.223203 159.881614)
        (xy 66.025572 159.93978)
        (xy 66.020107 159.942637)
        (xy 66.004143 159.950983)
        (xy 65.843002 160.035226)
        (xy 65.838201 160.039086)
        (xy 65.838198 160.039088)
        (xy 65.693162 160.1557)
        (xy 65.682447 160.164315)
        (xy 65.550024 160.32213)
        (xy 65.547056 160.327528)
        (xy 65.547053 160.327533)
        (xy 65.467508 160.472226)
        (xy 65.450776 160.502662)
        (xy 65.388484 160.699032)
        (xy 65.387798 160.705149)
        (xy 65.387797 160.705153)
        (xy 65.379968 160.774953)
        (xy 64.91648 160.71347)
        (xy 64.856935 160.516249)
        (xy 64.760218 160.334349)
        (xy 64.668407 160.221778)
        (xy 64.633906 160.179475)
        (xy 64.633903 160.179472)
        (xy 64.630011 160.1747)
        (xy 64.6082 160.156656)
        (xy 64.476025 160.047311)
        (xy 64.476021 160.047309)
        (xy 64.471275 160.043382)
        (xy 64.290055 159.945397)
        (xy 64.093254 159.884477)
        (xy 64.087129 159.883833)
        (xy 64.087128 159.883833)
        (xy 63.894498 159.863587)
        (xy 63.894496 159.863587)
        (xy 63.888369 159.862943)
        (xy 63.801529 159.870846)
        (xy 63.689342 159.881055)
        (xy 63.689339 159.881056)
        (xy 63.683203 159.881614)
        (xy 63.485572 159.93978)
        (xy 63.480107 159.942637)
        (xy 63.464143 159.950983)
        (xy 63.303002 160.035226)
        (xy 63.298201 160.039086)
        (xy 63.298198 160.039088)
        (xy 63.153162 160.1557)
        (xy 63.142447 160.164315)
        (xy 63.010024 160.32213)
        (xy 63.007056 160.327528)
        (xy 63.007053 160.327533)
        (xy 62.927508 160.472226)
        (xy 62.910776 160.502662)
        (xy 62.848484 160.699032)
        (xy 62.847798 160.705149)
        (xy 62.847797 160.705153)
        (xy 62.839968 160.774953)
        (xy 62.37648 160.71347)
        (xy 62.316935 160.516249)
        (xy 62.220218 160.334349)
        (xy 62.128407 160.221778)
        (xy 62.093906 160.179475)
        (xy 62.093903 160.179472)
        (xy 62.090011 160.1747)
        (xy 62.0682 160.156656)
        (xy 61.936025 160.047311)
        (xy 61.936021 160.047309)
        (xy 61.931275 160.043382)
        (xy 61.750055 159.945397)
        (xy 61.553254 159.884477)
        (xy 61.547129 159.883833)
        (xy 61.547128 159.883833)
        (xy 61.354498 159.863587)
        (xy 61.354496 159.863587)
        (xy 61.348369 159.862943)
        (xy 61.261529 159.870846)
        (xy 61.149342 159.881055)
        (xy 61.149339 159.881056)
        (xy 61.143203 159.881614)
        (xy 60.945572 159.93978)
        (xy 60.940107 159.942637)
        (xy 60.924143 159.950983)
        (xy 60.763002 160.035226)
        (xy 60.758201 160.039086)
        (xy 60.758198 160.039088)
        (xy 60.613162 160.1557)
        (xy 60.602447 160.164315)
        (xy 60.470024 160.32213)
        (xy 60.467056 160.327528)
        (xy 60.467053 160.327533)
        (xy 60.387508 160.472226)
        (xy 60.370776 160.502662)
        (xy 60.308484 160.699032)
        (xy 60.307798 160.705149)
        (xy 60.307797 160.705153)
        (xy 60.299968 160.774953)
        (xy 48.605219 160.894025)
        (xy 48.587419 160.690577)
        (xy 48.585516 160.679782)
        (xy 48.53266 160.482518)
        (xy 48.528914 160.472226)
        (xy 48.442605 160.287136)
        (xy 48.437126 160.277646)
        (xy 48.338517 160.136817)
        (xy 48.328041 160.128443)
        (xy 48.314593 160.135512)
        (xy 47.563417 160.886688)
        (xy 47.186197 160.898368)
        (xy 47.186066 160.896535)
        (xy 47.181815 160.88992)
        (xy 46.426685 160.13479)
        (xy 46.414911 160.12836)
        (xy 46.402895 160.137656)
        (xy 46.304874 160.277646)
        (xy 46.299395 160.287136)
        (xy 46.213086 160.472226)
        (xy 46.20934 160.482518)
        (xy 46.156484 160.679782)
        (xy 46.154581 160.690577)
        (xy 46.136929 160.892333)
        (xy 45.886009 160.893646)
        (xy 45.870313 160.733566)
        (xy 45.86648 160.69447)
        (xy 45.806935 160.497249)
        (xy 45.710218 160.315349)
        (xy 45.621756 160.206884)
        (xy 45.583906 160.160475)
        (xy 45.583903 160.160472)
        (xy 45.580011 160.1557)
        (xy 45.5582 160.137656)
        (xy 45.426025 160.028311)
        (xy 45.426021 160.028309)
        (xy 45.421275 160.024382)
        (xy 45.269761 159.942459)
        (xy 46.599943 159.942459)
        (xy 46.607012 159.955907)
        (xy 47.358188 160.707083)
        (xy 47.372132 160.714697)
        (xy 47.373965 160.714566)
        (xy 47.38058 160.710315)
        (xy 48.13571 159.955185)
        (xy 48.14214 159.943411)
        (xy 48.132844 159.931395)
        (xy 47.992854 159.833374)
        (xy 47.983364 159.827895)
        (xy 47.798274 159.741586)
        (xy 47.787982 159.73784)
        (xy 47.590718 159.684984)
        (xy 47.579923 159.683081)
        (xy 47.376475 159.665281)
        (xy 47.374144 159.665281)
        (xy 47.373155 159.664991)
        (xy 47.371 159.664802)
        (xy 47.371038 159.664369)
        (xy 47.369769 159.663997)
        (xy 47.359661 159.665794)
        (xy 47.162077 159.683081)
        (xy 47.151282 159.684984)
        (xy 46.954018 159.73784)
        (xy 46.943726 159.741586)
        (xy 46.758636 159.827895)
        (xy 46.749146 159.833374)
        (xy 46.608317 159.931983)
        (xy 45.240055 159.926397)
        (xy 45.043254 159.865477)
        (xy 45.037129 159.864833)
        (xy 45.037128 159.864833)
        (xy 44.844498 159.844587)
        (xy 44.844496 159.844587)
        (xy 44.838369 159.843943)
        (xy 44.757988 159.851258)
        (xy 44.639342 159.862055)
        (xy 44.639339 159.862056)
        (xy 44.633203 159.862614)
        (xy 44.435572 159.92078)
        (xy 44.430107 159.923637)
        (xy 44.388484 159.945397)
        (xy 44.253002 160.016226)
        (xy 44.248201 160.020086)
        (xy 44.248198 160.020088)
        (xy 44.103016 160.136817)
        (xy 44.092447 160.145315)
        (xy 43.960024 160.30313)
        (xy 43.957056 160.308528)
        (xy 43.957053 160.308533)
        (xy 43.936239 160.346394)
        (xy 43.860776 160.483662)
        (xy 43.798484 160.680032)
        (xy 43.797798 160.686149)
        (xy 43.797797 160.686153)
        (xy 43.787837 160.774953)
        (xy 43.32648 160.69447)
        (xy 43.266935 160.497249)
        (xy 43.170218 160.315349)
        (xy 43.081756 160.206884)
        (xy 43.043906 160.160475)
        (xy 43.043903 160.160472)
        (xy 43.040011 160.1557)
        (xy 43.0182 160.137656)
        (xy 42.886025 160.028311)
        (xy 42.886021 160.028309)
        (xy 42.881275 160.024382)
        (xy 42.700055 159.926397)
        (xy 42.503254 159.865477)
        (xy 42.497129 159.864833)
        (xy 42.497128 159.864833)
        (xy 42.304498 159.844587)
        (xy 42.304496 159.844587)
        (xy 42.298369 159.843943)
        (xy 42.217988 159.851258)
        (xy 42.099342 159.862055)
        (xy 42.099339 159.862056)
        (xy 42.093203 159.862614)
        (xy 41.895572 159.92078)
        (xy 41.890107 159.923637)
        (xy 41.848484 159.945397)
        (xy 41.713002 160.016226)
        (xy 41.708201 160.020086)
        (xy 41.708198 160.020088)
        (xy 41.563016 160.136817)
        (xy 41.552447 160.145315)
        (xy 41.420024 160.30313)
        (xy 41.417056 160.308528)
        (xy 41.417053 160.308533)
        (xy 41.396239 160.346394)
        (xy 41.320776 160.483662)
        (xy 41.258484 160.680032)
        (xy 41.257798 160.686149)
        (xy 41.257797 160.686153)
        (xy 41.247837 160.774953)
        (xy 40.78648 160.69447)
        (xy 40.726935 160.497249)
        (xy 40.630218 160.315349)
        (xy 40.541756 160.206884)
        (xy 40.503906 160.160475)
        (xy 40.503903 160.160472)
        (xy 40.500011 160.1557)
        (xy 40.4782 160.137656)
        (xy 40.346025 160.028311)
        (xy 40.346021 160.028309)
        (xy 40.341275 160.024382)
        (xy 40.160055 159.926397)
        (xy 39.963254 159.865477)
        (xy 39.957129 159.864833)
        (xy 39.957128 159.864833)
        (xy 39.764498 159.844587)
        (xy 39.764496 159.844587)
        (xy 39.758369 159.843943)
        (xy 39.677988 159.851258)
        (xy 39.559342 159.862055)
        (xy 39.559339 159.862056)
        (xy 39.553203 159.862614)
        (xy 39.355572 159.92078)
        (xy 39.350107 159.923637)
        (xy 39.308484 159.945397)
        (xy 39.173002 160.016226)
        (xy 39.168201 160.020086)
        (xy 39.168198 160.020088)
        (xy 39.023016 160.136817)
        (xy 39.012447 160.145315)
        (xy 38.880024 160.30313)
        (xy 38.877056 160.308528)
        (xy 38.877053 160.308533)
        (xy 38.856239 160.346394)
        (xy 38.780776 160.483662)
        (xy 38.718484 160.680032)
        (xy 38.717798 160.686149)
        (xy 38.717797 160.686153)
        (xy 38.707837 160.774953)
        (xy 38.2615 160.245666)
        (xy 38.258519 160.214131)
        (xy 38.213634 160.086316)
        (xy 38.208042 160.078746)
        (xy 38.208041 160.078743)
        (xy 38.145665 159.994294)
        (xy 38.13315 159.97735)
        (xy 38.093856 159.948327)
        (xy 38.031757 159.902459)
        (xy 38.031754 159.902458)
        (xy 38.024184 159.896866)
        (xy 37.896369 159.851981)
        (xy 37.888723 159.851258)
        (xy 37.888722 159.851258)
        (xy 37.882752 159.850694)
        (xy 37.864834 159.849)
        (xy 36.557166 159.849)
        (xy 36.539248 159.850694)
        (xy 36.533278 159.851258)
        (xy 36.533277 159.851258)
        (xy 36.525631 159.851981)
        (xy 36.397816 159.896866)
        (xy 36.390246 159.902458)
        (xy 36.390243 159.902459)
        (xy 36.328144 159.948327)
        (xy 36.28885 159.97735)
        (xy 36.276335 159.994294)
        (xy 36.213959 160.078743)
        (xy 36.213958 160.078746)
        (xy 36.208366 160.086316)
        (xy 36.163481 160.214131)
        (xy 36.1605 160.245666)
        (xy 24.430111 161.515067)
        (xy 24.430107 161.515059)
        (xy 24.428851 161.511902)
        (xy 24.42314 161.501115)
        (xy 24.258014 161.189245)
        (xy 24.258012 161.189241)
        (xy 24.25642 161.186235)
        (xy 24.049824 160.881095)
        (xy 24.047619 160.878495)
        (xy 24.047613 160.878487)
        (xy 23.905383 160.710776)
        (xy 23.811483 160.600052)
        (xy 23.544183 160.346394)
        (xy 23.541476 160.344332)
        (xy 23.541468 160.344325)
        (xy 23.351216 160.199393)
        (xy 23.251051 160.123088)
        (xy 23.00869 159.976886)
        (xy 22.938438 159.934507)
        (xy 22.938437 159.934507)
        (xy 22.935517 159.932745)
        (xy 22.932427 159.931311)
        (xy 22.932422 159.931308)
        (xy 22.604368 159.779031)
        (xy 22.604366 159.77903)
        (xy 22.601272 159.777594)
        (xy 22.598037 159.776499)
        (xy 22.598032 159.776497)
        (xy 22.255461 159.660543)
        (xy 22.252226 159.659448)
        (xy 22.207354 159.6495)
        (xy 22.1977 159.64736)
        (xy 21.892461 159.57969)
        (xy 21.763574 159.565461)
        (xy 21.529568 159.539626)
        (xy 21.529563 159.539626)
        (xy 21.526187 159.539253)
        (xy 21.522788 159.539247)
        (xy 21.522787 159.539247)
        (xy 21.348708 159.538943)
        (xy 21.157688 159.53861)
        (xy 20.984922 159.557074)
        (xy 20.794659 159.577407)
        (xy 20.794653 159.577408)
        (xy 20.791275 159.577769)
        (xy 20.431235 159.65627)
        (xy 20.081778 159.773197)
        (xy 19.746993 159.92718)
        (xy 19.744059 159.928936)
        (xy 19.744057 159.928937)
        (xy 19.433725 160.114667)
        (xy 19.433717 160.114673)
        (xy 19.430797 160.11642)
        (xy 19.136888 160.338702)
        (xy 18.868704 160.591426)
        (xy 18.866492 160.594016)
        (xy 18.866491 160.594017)
        (xy 18.764469 160.71347)
        (xy 18.629383 160.871635)
        (xy 18.627469 160.874441)
        (xy 18.627465 160.874446)
        (xy 18.463384 161.114978)
        (xy 18.421723 161.176051)
        (xy 18.420122 161.179049)
        (xy 18.420118 161.179056)
        (xy 18.249761 161.498108)
        (xy 18.249757 161.498117)
        (xy 18.248156 161.501115)
        (xy 18.246887 161.504272)
        (xy 18.246885 161.504276)
        (xy 18.113438 161.836235)
        (xy 18.11071 161.843022)
        (xy 18.10979 161.846296)
        (xy 18.109788 161.846301)
        (xy 18.020412 162.164268)
        (xy 18.010994 162.197773)
        (xy 18.010432 162.20113)
        (xy 18.010432 162.201131)
        (xy 18.0013 162.255705)
        (xy 17.950174 162.561219)
        (xy 17.933712 162.846734)
        (xy 15.189373 158.344762)
        (xy 36.15552 158.344762)
        (xy 36.172759 158.550053)
        (xy 36.229544 158.748086)
        (xy 36.232359 158.753563)
        (xy 36.23236 158.753566)
        (xy 36.253247 158.794207)
        (xy 36.323712 158.931318)
        (xy 36.451677 159.09277)
        (xy 36.45637 159.096764)
        (xy 36.456371 159.096765)
        (xy 36.518402 159.149557)
        (xy 36.608564 159.226291)
        (xy 36.788398 159.326797)
        (xy 36.846874 159.345797)
        (xy 36.978471 159.388556)
        (xy 36.978475 159.388557)
        (xy 36.984329 159.390459)
        (xy 37.188894 159.414851)
        (xy 37.195029 159.414379)
        (xy 37.195031 159.414379)
        (xy 37.251039 159.410069)
        (xy 37.3943 159.399046)
        (xy 37.40023 159.39739)
        (xy 37.400232 159.39739)
        (xy 37.586797 159.3453)
        (xy 37.586796 159.3453)
        (xy 37.592725 159.343645)
        (xy 37.598214 159.340872)
        (xy 37.59822 159.34087)
        (xy 37.771116 159.253533)
        (xy 37.77661 159.250758)
        (xy 37.783608 159.245291)
        (xy 37.934101 159.127713)
        (xy 37.938951 159.123924)
        (xy 38.073564 158.967972)
        (xy 38.094387 158.931318)
        (xy 38.161483 158.813207)
        (xy 38.175323 158.788844)
        (xy 38.240351 158.593363)
        (xy 38.266171 158.388974)
        (xy 38.266513 158.364541)
        (xy 38.266534 158.363022)
        (xy 38.266534 158.363018)
        (xy 38.266583 158.3595)
        (xy 38.265138 158.344762)
        (xy 38.69552 158.344762)
        (xy 38.712759 158.550053)
        (xy 38.769544 158.748086)
        (xy 38.772359 158.753563)
        (xy 38.77236 158.753566)
        (xy 38.793247 158.794207)
        (xy 38.863712 158.931318)
        (xy 38.991677 159.09277)
        (xy 38.99637 159.096764)
        (xy 38.996371 159.096765)
        (xy 39.058402 159.149557)
        (xy 39.148564 159.226291)
        (xy 39.328398 159.326797)
        (xy 39.386874 159.345797)
        (xy 39.518471 159.388556)
        (xy 39.518475 159.388557)
        (xy 39.524329 159.390459)
        (xy 39.728894 159.414851)
        (xy 39.735029 159.414379)
        (xy 39.735031 159.414379)
        (xy 39.791039 159.410069)
        (xy 39.9343 159.399046)
        (xy 39.94023 159.39739)
        (xy 39.940232 159.39739)
        (xy 40.126797 159.3453)
        (xy 40.126796 159.3453)
        (xy 40.132725 159.343645)
        (xy 40.138214 159.340872)
        (xy 40.13822 159.34087)
        (xy 40.311116 159.253533)
        (xy 40.31661 159.250758)
        (xy 40.323608 159.245291)
        (xy 40.474101 159.127713)
        (xy 40.478951 159.123924)
        (xy 40.613564 158.967972)
        (xy 40.634387 158.931318)
        (xy 40.701483 158.813207)
        (xy 40.715323 158.788844)
        (xy 40.780351 158.593363)
        (xy 40.806171 158.388974)
        (xy 40.806513 158.364541)
        (xy 40.806534 158.363022)
        (xy 40.806534 158.363018)
        (xy 40.806583 158.3595)
        (xy 40.805138 158.344762)
        (xy 41.23552 158.344762)
        (xy 41.252759 158.550053)
        (xy 41.309544 158.748086)
        (xy 41.312359 158.753563)
        (xy 41.31236 158.753566)
        (xy 41.333247 158.794207)
        (xy 41.403712 158.931318)
        (xy 41.531677 159.09277)
        (xy 41.53637 159.096764)
        (xy 41.536371 159.096765)
        (xy 41.598402 159.149557)
        (xy 41.688564 159.226291)
        (xy 41.868398 159.326797)
        (xy 41.926874 159.345797)
        (xy 42.058471 159.388556)
        (xy 42.058475 159.388557)
        (xy 42.064329 159.390459)
        (xy 42.268894 159.414851)
        (xy 42.275029 159.414379)
        (xy 42.275031 159.414379)
        (xy 42.331039 159.410069)
        (xy 42.4743 159.399046)
        (xy 42.48023 159.39739)
        (xy 42.480232 159.39739)
        (xy 42.666797 159.3453)
        (xy 42.666796 159.3453)
        (xy 42.672725 159.343645)
        (xy 42.678214 159.340872)
        (xy 42.67822 159.34087)
        (xy 42.851116 159.253533)
        (xy 42.85661 159.250758)
        (xy 42.863608 159.245291)
        (xy 43.014101 159.127713)
        (xy 43.018951 159.123924)
        (xy 43.153564 158.967972)
        (xy 43.174387 158.931318)
        (xy 43.241483 158.813207)
        (xy 43.255323 158.788844)
        (xy 43.320351 158.593363)
        (xy 43.346171 158.388974)
        (xy 43.346513 158.364541)
        (xy 43.346534 158.363022)
        (xy 43.346534 158.363018)
        (xy 43.346583 158.3595)
        (xy 43.345138 158.344762)
        (xy 43.77552 158.344762)
        (xy 43.792759 158.550053)
        (xy 43.849544 158.748086)
        (xy 43.852359 158.753563)
        (xy 43.85236 158.753566)
        (xy 43.873247 158.794207)
        (xy 43.943712 158.931318)
        (xy 44.071677 159.09277)
        (xy 44.07637 159.096764)
        (xy 44.076371 159.096765)
        (xy 44.138402 159.149557)
        (xy 44.228564 159.226291)
        (xy 44.408398 159.326797)
        (xy 44.466874 159.345797)
        (xy 44.598471 159.388556)
        (xy 44.598475 159.388557)
        (xy 44.604329 159.390459)
        (xy 44.808894 159.414851)
        (xy 44.815029 159.414379)
        (xy 44.815031 159.414379)
        (xy 44.871039 159.410069)
        (xy 45.0143 159.399046)
        (xy 45.02023 159.39739)
        (xy 45.020232 159.39739)
        (xy 45.206797 159.3453)
        (xy 45.206796 159.3453)
        (xy 45.212725 159.343645)
        (xy 45.218214 159.340872)
        (xy 45.21822 159.34087)
        (xy 45.391116 159.253533)
        (xy 45.39661 159.250758)
        (xy 45.403608 159.245291)
        (xy 45.554101 159.127713)
        (xy 45.558951 159.123924)
        (xy 45.693564 158.967972)
        (xy 45.714387 158.931318)
        (xy 45.781483 158.813207)
        (xy 45.795323 158.788844)
        (xy 45.860351 158.593363)
        (xy 45.886171 158.388974)
        (xy 45.886513 158.364541)
        (xy 45.886534 158.363022)
        (xy 45.886534 158.363018)
        (xy 45.886583 158.3595)
        (xy 45.885138 158.344762)
        (xy 46.31552 158.344762)
        (xy 46.332759 158.550053)
        (xy 46.389544 158.748086)
        (xy 46.392359 158.753563)
        (xy 46.39236 158.753566)
        (xy 46.413247 158.794207)
        (xy 46.483712 158.931318)
        (xy 46.611677 159.09277)
        (xy 46.61637 159.096764)
        (xy 46.616371 159.096765)
        (xy 46.678402 159.149557)
        (xy 46.768564 159.226291)
        (xy 46.948398 159.326797)
        (xy 47.006874 159.345797)
        (xy 47.138471 159.388556)
        (xy 47.138475 159.388557)
        (xy 47.144329 159.390459)
        (xy 47.348894 159.414851)
        (xy 47.352242 159.414593)
        (xy 47.354844 159.415417)
        (xy 47.364477 159.413652)
        (xy 47.548159 159.399519)
        (xy 47.548164 159.399518)
        (xy 47.5543 159.399046)
        (xy 47.56023 159.39739)
        (xy 47.560232 159.39739)
        (xy 47.746797 159.3453)
        (xy 47.746796 159.3453)
        (xy 47.752725 159.343645)
        (xy 47.758214 159.340872)
        (xy 47.75822 159.34087)
        (xy 47.931116 159.253533)
        (xy 47.93661 159.250758)
        (xy 47.943608 159.245291)
        (xy 48.094101 159.127713)
        (xy 48.098951 159.123924)
        (xy 48.233564 158.967972)
        (xy 48.254387 158.931318)
        (xy 48.321483 158.813207)
        (xy 48.335323 158.788844)
        (xy 48.400351 158.593363)
        (xy 48.426171 158.388974)
        (xy 48.426513 158.364541)
        (xy 48.426524 158.363762)
        (xy 60.28552 158.363762)
        (xy 60.287931 158.392478)
        (xy 60.301164 158.550053)
        (xy 60.302759 158.569053)
        (xy 60.304458 158.574978)
        (xy 60.351075 158.73755)
        (xy 60.359544 158.767086)
        (xy 60.362359 158.772563)
        (xy 60.36236 158.772566)
        (xy 60.450897 158.944841)
        (xy 60.453712 158.950318)
        (xy 60.581677 159.11177)
        (xy 60.58637 159.115764)
        (xy 60.586371 159.115765)
        (xy 60.617771 159.142488)
        (xy 60.738564 159.245291)
        (xy 60.918398 159.345797)
        (xy 61.013238 159.376613)
        (xy 61.108471 159.407556)
        (xy 61.108475 159.407557)
        (xy 61.114329 159.409459)
        (xy 61.318894 159.433851)
        (xy 61.325029 159.433379)
        (xy 61.325031 159.433379)
        (xy 61.381939 159.429)
        (xy 61.5243 159.418046)
        (xy 61.53023 159.41639)
        (xy 61.530232 159.41639)
        (xy 61.716797 159.3643)
        (xy 61.716796 159.3643)
        (xy 61.722725 159.362645)
        (xy 61.728214 159.359872)
        (xy 61.72822 159.35987)
        (xy 61.901116 159.272533)
        (xy 61.90661 159.269758)
        (xy 62.068951 159.142924)
        (xy 62.085352 159.123924)
        (xy 62.19954 158.991634)
        (xy 62.19954 158.991633)
        (xy 62.203564 158.986972)
        (xy 62.224387 158.950318)
        (xy 62.302276 158.813207)
        (xy 62.305323 158.807844)
        (xy 62.370351 158.612363)
        (xy 62.396171 158.407974)
        (xy 62.396404 158.391312)
        (xy 62.396534 158.382022)
        (xy 62.396534 158.382018)
        (xy 62.396583 158.3785)
        (xy 62.395138 158.363762)
        (xy 62.82552 158.363762)
        (xy 62.827931 158.392478)
        (xy 62.841164 158.550053)
        (xy 62.842759 158.569053)
        (xy 62.844458 158.574978)
        (xy 62.891075 158.73755)
        (xy 62.899544 158.767086)
        (xy 62.902359 158.772563)
        (xy 62.90236 158.772566)
        (xy 62.990897 158.944841)
        (xy 62.993712 158.950318)
        (xy 63.121677 159.11177)
        (xy 63.12637 159.115764)
        (xy 63.126371 159.115765)
        (xy 63.157771 159.142488)
        (xy 63.278564 159.245291)
        (xy 63.458398 159.345797)
        (xy 63.553238 159.376613)
        (xy 63.648471 159.407556)
        (xy 63.648475 159.407557)
        (xy 63.654329 159.409459)
        (xy 63.858894 159.433851)
        (xy 63.865029 159.433379)
        (xy 63.865031 159.433379)
        (xy 63.921939 159.429)
        (xy 64.0643 159.418046)
        (xy 64.07023 159.41639)
        (xy 64.070232 159.41639)
        (xy 64.256797 159.3643)
        (xy 64.256796 159.3643)
        (xy 64.262725 159.362645)
        (xy 64.268214 159.359872)
        (xy 64.26822 159.35987)
        (xy 64.441116 159.272533)
        (xy 64.44661 159.269758)
        (xy 64.608951 159.142924)
        (xy 64.625352 159.123924)
        (xy 64.73954 158.991634)
        (xy 64.73954 158.991633)
        (xy 64.743564 158.986972)
        (xy 64.764387 158.950318)
        (xy 64.842276 158.813207)
        (xy 64.845323 158.807844)
        (xy 64.910351 158.612363)
        (xy 64.936171 158.407974)
        (xy 64.936404 158.391312)
        (xy 64.936534 158.382022)
        (xy 64.936534 158.382018)
        (xy 64.936583 158.3785)
        (xy 64.935138 158.363762)
        (xy 65.36552 158.363762)
        (xy 65.367931 158.392478)
        (xy 65.381164 158.550053)
        (xy 65.382759 158.569053)
        (xy 65.384458 158.574978)
        (xy 65.431075 158.73755)
        (xy 65.439544 158.767086)
        (xy 65.442359 158.772563)
        (xy 65.44236 158.772566)
        (xy 65.530897 158.944841)
        (xy 65.533712 158.950318)
        (xy 65.661677 159.11177)
        (xy 65.66637 159.115764)
        (xy 65.666371 159.115765)
        (xy 65.697771 159.142488)
        (xy 65.818564 159.245291)
        (xy 65.998398 159.345797)
        (xy 66.093238 159.376613)
        (xy 66.188471 159.407556)
        (xy 66.188475 159.407557)
        (xy 66.194329 159.409459)
        (xy 66.398894 159.433851)
        (xy 66.405029 159.433379)
        (xy 66.405031 159.433379)
        (xy 66.461939 159.429)
        (xy 66.6043 159.418046)
        (xy 66.61023 159.41639)
        (xy 66.610232 159.41639)
        (xy 66.796797 159.3643)
        (xy 66.796796 159.3643)
        (xy 66.802725 159.362645)
        (xy 66.808214 159.359872)
        (xy 66.80822 159.35987)
        (xy 66.981116 159.272533)
        (xy 66.98661 159.269758)
        (xy 67.148951 159.142924)
        (xy 67.165352 159.123924)
        (xy 67.27954 158.991634)
        (xy 67.27954 158.991633)
        (xy 67.283564 158.986972)
        (xy 67.304387 158.950318)
        (xy 67.382276 158.813207)
        (xy 67.385323 158.807844)
        (xy 67.450351 158.612363)
        (xy 67.476171 158.407974)
        (xy 67.476404 158.391312)
        (xy 67.476534 158.382022)
        (xy 67.476534 158.382018)
        (xy 67.476583 158.3785)
        (xy 67.475138 158.363762)
        (xy 67.90552 158.363762)
        (xy 67.907931 158.392478)
        (xy 67.921164 158.550053)
        (xy 67.922759 158.569053)
        (xy 67.924458 158.574978)
        (xy 67.971075 158.73755)
        (xy 67.979544 158.767086)
        (xy 67.982359 158.772563)
        (xy 67.98236 158.772566)
        (xy 68.070897 158.944841)
        (xy 68.073712 158.950318)
        (xy 68.201677 159.11177)
        (xy 68.20637 159.115764)
        (xy 68.206371 159.115765)
        (xy 68.237771 159.142488)
        (xy 68.358564 159.245291)
        (xy 68.538398 159.345797)
        (xy 68.633238 159.376613)
        (xy 68.728471 159.407556)
        (xy 68.728475 159.407557)
        (xy 68.734329 159.409459)
        (xy 68.938894 159.433851)
        (xy 68.945029 159.433379)
        (xy 68.945031 159.433379)
        (xy 69.001939 159.429)
        (xy 69.1443 159.418046)
        (xy 69.15023 159.41639)
        (xy 69.150232 159.41639)
        (xy 69.336797 159.3643)
        (xy 69.336796 159.3643)
        (xy 69.342725 159.362645)
        (xy 69.348214 159.359872)
        (xy 69.34822 159.35987)
        (xy 69.398267 159.334589)
        (xy 70.72986 159.334589)
        (xy 70.739156 159.346605)
        (xy 70.879146 159.444626)
        (xy 70.888636 159.450105)
        (xy 71.069204 159.534305)
        (xy 71.122489 159.581222)
        (xy 71.14195 159.6495)
        (xy 71.121408 159.71746)
        (xy 71.069204 159.762695)
        (xy 70.888636 159.846895)
        (xy 70.879146 159.852374)
        (xy 70.738317 159.950983)
        (xy 70.729943 159.961459)
        (xy 70.737012 159.974907)
        (xy 71.488188 160.726083)
        (xy 71.502132 160.733697)
        (xy 71.503965 160.733566)
        (xy 71.51058 160.729315)
        (xy 72.26571 159.974185)
        (xy 72.27214 159.962411)
        (xy 72.262844 159.950395)
        (xy 72.122854 159.852374)
        (xy 72.113364 159.846895)
        (xy 71.932796 159.762695)
        (xy 71.879511 159.715778)
        (xy 71.86005 159.6475)
        (xy 71.880592 159.57954)
        (xy 71.932796 159.534305)
        (xy 72.113364 159.450105)
        (xy 72.122854 159.444626)
        (xy 72.263683 159.346017)
        (xy 72.272057 159.335541)
        (xy 72.271557 159.334589)
        (xy 73.26986 159.334589)
        (xy 73.279156 159.346605)
        (xy 73.419146 159.444626)
        (xy 73.428636 159.450105)
        (xy 73.609204 159.534305)
        (xy 73.662489 159.581222)
        (xy 73.68195 159.6495)
        (xy 73.661408 159.71746)
        (xy 73.609204 159.762695)
        (xy 73.428636 159.846895)
        (xy 73.419146 159.852374)
        (xy 73.278317 159.950983)
        (xy 73.269943 159.961459)
        (xy 73.277012 159.974907)
        (xy 74.028188 160.726083)
        (xy 74.042132 160.733697)
        (xy 74.043965 160.733566)
        (xy 74.05058 160.729315)
        (xy 74.80571 159.974185)
        (xy 74.81214 159.962411)
        (xy 74.802844 159.950395)
        (xy 74.662854 159.852374)
        (xy 74.653364 159.846895)
        (xy 74.472796 159.762695)
        (xy 74.419511 159.715778)
        (xy 74.40005 159.6475)
        (xy 74.420592 159.57954)
        (xy 74.472796 159.534305)
        (xy 74.653364 159.450105)
        (xy 74.662854 159.444626)
        (xy 74.803683 159.346017)
        (xy 74.812057 159.335541)
        (xy 74.811557 159.334589)
        (xy 75.80986 159.334589)
        (xy 75.819156 159.346605)
        (xy 75.959146 159.444626)
        (xy 75.968636 159.450105)
        (xy 76.149204 159.534305)
        (xy 76.202489 159.581222)
        (xy 76.22195 159.6495)
        (xy 76.201408 159.71746)
        (xy 76.149204 159.762695)
        (xy 75.968636 159.846895)
        (xy 75.959146 159.852374)
        (xy 75.818317 159.950983)
        (xy 75.809943 159.961459)
        (xy 75.817012 159.974907)
        (xy 76.568188 160.726083)
        (xy 76.582132 160.733697)
        (xy 76.583965 160.733566)
        (xy 76.59058 160.729315)
        (xy 77.34571 159.974185)
        (xy 77.35214 159.962411)
        (xy 77.342844 159.950395)
        (xy 77.202854 159.852374)
        (xy 77.193364 159.846895)
        (xy 77.012796 159.762695)
        (xy 76.959511 159.715778)
        (xy 76.94005 159.6475)
        (xy 76.960592 159.57954)
        (xy 77.012796 159.534305)
        (xy 77.193364 159.450105)
        (xy 77.202854 159.444626)
        (xy 77.343683 159.346017)
        (xy 77.352057 159.335541)
        (xy 77.344988 159.322093)
        (xy 76.593812 158.570917)
        (xy 76.579868 158.563303)
        (xy 76.578035 158.563434)
        (xy 76.57142 158.567685)
        (xy 75.81629 159.322815)
        (xy 74.804988 159.322093)
        (xy 74.053812 158.570917)
        (xy 74.039868 158.563303)
        (xy 74.038035 158.563434)
        (xy 74.03142 158.567685)
        (xy 73.27629 159.322815)
        (xy 72.264988 159.322093)
        (xy 71.513812 158.570917)
        (xy 71.499868 158.563303)
        (xy 71.498035 158.563434)
        (xy 71.49142 158.567685)
        (xy 70.73629 159.322815)
        (xy 69.521116 159.272533)
        (xy 69.52661 159.269758)
        (xy 69.688951 159.142924)
        (xy 69.705352 159.123924)
        (xy 69.81954 158.991634)
        (xy 69.81954 158.991633)
        (xy 69.823564 158.986972)
        (xy 69.844387 158.950318)
        (xy 69.922276 158.813207)
        (xy 69.925323 158.807844)
        (xy 69.990351 158.612363)
        (xy 70.016171 158.407974)
        (xy 70.016225 158.404099)
        (xy 70.01625 158.404018)
        (xy 70.016466 158.400938)
        (xy 70.017186 158.400988)
        (xy 70.020518 158.390199)
        (xy 70.017878 158.385177)
        (xy 70.016716 158.377386)
        (xy 70.264561 158.377386)
        (xy 70.267734 158.394871)
        (xy 70.284581 158.587423)
        (xy 70.286484 158.598218)
        (xy 70.33934 158.795482)
        (xy 70.343086 158.805774)
        (xy 70.429395 158.990864)
        (xy 70.434874 159.000354)
        (xy 70.533483 159.141183)
        (xy 70.543959 159.149557)
        (xy 70.557407 159.142488)
        (xy 71.308583 158.391312)
        (xy 71.314961 158.379632)
        (xy 71.685803 158.379632)
        (xy 71.685934 158.381465)
        (xy 71.690185 158.38808)
        (xy 72.445315 159.14321)
        (xy 72.457089 159.14964)
        (xy 72.469105 159.140344)
        (xy 72.567126 159.000354)
        (xy 72.572605 158.990864)
        (xy 72.656805 158.810296)
        (xy 72.703722 158.757011)
        (xy 72.772 158.73755)
        (xy 72.83996 158.758092)
        (xy 72.885195 158.810296)
        (xy 72.969395 158.990864)
        (xy 72.974874 159.000354)
        (xy 73.073483 159.141183)
        (xy 73.083959 159.149557)
        (xy 73.097407 159.142488)
        (xy 73.848583 158.391312)
        (xy 73.854961 158.379632)
        (xy 74.225803 158.379632)
        (xy 74.225934 158.381465)
        (xy 74.230185 158.38808)
        (xy 74.985315 159.14321)
        (xy 74.997089 159.14964)
        (xy 75.009105 159.140344)
        (xy 75.107126 159.000354)
        (xy 75.112605 158.990864)
        (xy 75.196805 158.810296)
        (xy 75.243722 158.757011)
        (xy 75.312 158.73755)
        (xy 75.37996 158.758092)
        (xy 75.425195 158.810296)
        (xy 75.509395 158.990864)
        (xy 75.514874 159.000354)
        (xy 75.613483 159.141183)
        (xy 75.623959 159.149557)
        (xy 75.637407 159.142488)
        (xy 76.388583 158.391312)
        (xy 76.394961 158.379632)
        (xy 76.765803 158.379632)
        (xy 76.765934 158.381465)
        (xy 76.770185 158.38808)
        (xy 77.525315 159.14321)
        (xy 77.537089 159.14964)
        (xy 77.549105 159.140344)
        (xy 77.647126 159.000354)
        (xy 77.652605 158.990864)
        (xy 77.738914 158.805774)
        (xy 77.74266 158.795482)
        (xy 77.795516 158.598218)
        (xy 77.797419 158.587423)
        (xy 77.815698 158.3785)
        (xy 77.816793 158.378596)
        (xy 77.814697 158.367042)
        (xy 77.797421 158.169589)
        (xy 77.795516 158.158782)
        (xy 77.74266 157.961518)
        (xy 77.738914 157.951226)
        (xy 77.652605 157.766136)
        (xy 77.647126 157.756646)
        (xy 77.548517 157.615817)
        (xy 77.538041 157.607443)
        (xy 77.524593 157.614512)
        (xy 76.773417 158.365688)
        (xy 76.396197 158.377368)
        (xy 76.396066 158.375535)
        (xy 76.391815 158.36892)
        (xy 75.636685 157.61379)
        (xy 75.624911 157.60736)
        (xy 75.612895 157.616656)
        (xy 75.514874 157.756646)
        (xy 75.509395 157.766136)
        (xy 75.425195 157.946704)
        (xy 75.378278 157.999989)
        (xy 75.31 158.01945)
        (xy 75.24204 157.998908)
        (xy 75.196805 157.946704)
        (xy 75.112605 157.766136)
        (xy 75.107126 157.756646)
        (xy 75.008517 157.615817)
        (xy 74.998041 157.607443)
        (xy 74.984593 157.614512)
        (xy 74.233417 158.365688)
        (xy 73.856197 158.377368)
        (xy 73.856066 158.375535)
        (xy 73.851815 158.36892)
        (xy 73.096685 157.61379)
        (xy 73.084911 157.60736)
        (xy 73.072895 157.616656)
        (xy 72.974874 157.756646)
        (xy 72.969395 157.766136)
        (xy 72.885195 157.946704)
        (xy 72.838278 157.999989)
        (xy 72.77 158.01945)
        (xy 72.70204 157.998908)
        (xy 72.656805 157.946704)
        (xy 72.572605 157.766136)
        (xy 72.567126 157.756646)
        (xy 72.468517 157.615817)
        (xy 72.458041 157.607443)
        (xy 72.444593 157.614512)
        (xy 71.693417 158.365688)
        (xy 71.316197 158.377368)
        (xy 71.316066 158.375535)
        (xy 71.311815 158.36892)
        (xy 70.556685 157.61379)
        (xy 70.544911 157.60736)
        (xy 70.532895 157.616656)
        (xy 70.434874 157.756646)
        (xy 70.429395 157.766136)
        (xy 70.343086 157.951226)
        (xy 70.33934 157.961518)
        (xy 70.286484 158.158782)
        (xy 70.284581 158.169577)
        (xy 70.266929 158.371333)
        (xy 70.016009 158.372646)
        (xy 69.99845 158.193566)
        (xy 69.99648 158.17347)
        (xy 69.936935 157.976249)
        (xy 69.840218 157.794349)
        (xy 69.757666 157.693131)
        (xy 69.713906 157.639475)
        (xy 69.713903 157.639472)
        (xy 69.710011 157.6347)
        (xy 69.6882 157.616656)
        (xy 69.556025 157.507311)
        (xy 69.556021 157.507309)
        (xy 69.551275 157.503382)
        (xy 69.399761 157.421459)
        (xy 70.729943 157.421459)
        (xy 70.737012 157.434907)
        (xy 71.488188 158.186083)
        (xy 71.502132 158.193697)
        (xy 71.503965 158.193566)
        (xy 71.51058 158.189315)
        (xy 72.26571 157.434185)
        (xy 72.27214 157.422411)
        (xy 72.271403 157.421459)
        (xy 73.269943 157.421459)
        (xy 73.277012 157.434907)
        (xy 74.028188 158.186083)
        (xy 74.042132 158.193697)
        (xy 74.043965 158.193566)
        (xy 74.05058 158.189315)
        (xy 74.80571 157.434185)
        (xy 74.81214 157.422411)
        (xy 74.811403 157.421459)
        (xy 75.809943 157.421459)
        (xy 75.817012 157.434907)
        (xy 76.568188 158.186083)
        (xy 76.582132 158.193697)
        (xy 76.583965 158.193566)
        (xy 76.59058 158.189315)
        (xy 77.34571 157.434185)
        (xy 77.35214 157.422411)
        (xy 77.342844 157.410395)
        (xy 77.202854 157.312374)
        (xy 77.193364 157.306895)
        (xy 77.008274 157.220586)
        (xy 76.997982 157.21684)
        (xy 76.800718 157.163984)
        (xy 76.789923 157.162081)
        (xy 76.586475 157.144281)
        (xy 76.575525 157.144281)
        (xy 76.372077 157.162081)
        (xy 76.361282 157.163984)
        (xy 76.164018 157.21684)
        (xy 76.153726 157.220586)
        (xy 75.968636 157.306895)
        (xy 75.959146 157.312374)
        (xy 75.818317 157.410983)
        (xy 74.802844 157.410395)
        (xy 74.662854 157.312374)
        (xy 74.653364 157.306895)
        (xy 74.468274 157.220586)
        (xy 74.457982 157.21684)
        (xy 74.260718 157.163984)
        (xy 74.249923 157.162081)
        (xy 74.046475 157.144281)
        (xy 74.035525 157.144281)
        (xy 73.832077 157.162081)
        (xy 73.821282 157.163984)
        (xy 73.624018 157.21684)
        (xy 73.613726 157.220586)
        (xy 73.428636 157.306895)
        (xy 73.419146 157.312374)
        (xy 73.278317 157.410983)
        (xy 72.262844 157.410395)
        (xy 72.122854 157.312374)
        (xy 72.113364 157.306895)
        (xy 71.928274 157.220586)
        (xy 71.917982 157.21684)
        (xy 71.720718 157.163984)
        (xy 71.709923 157.162081)
        (xy 71.506475 157.144281)
        (xy 71.495525 157.144281)
        (xy 71.292077 157.162081)
        (xy 71.281282 157.163984)
        (xy 71.084018 157.21684)
        (xy 71.073726 157.220586)
        (xy 70.888636 157.306895)
        (xy 70.879146 157.312374)
        (xy 70.738317 157.410983)
        (xy 69.370055 157.405397)
        (xy 69.173254 157.344477)
        (xy 69.167129 157.343833)
        (xy 69.167128 157.343833)
        (xy 68.974498 157.323587)
        (xy 68.974496 157.323587)
        (xy 68.968369 157.322943)
        (xy 68.881529 157.330846)
        (xy 68.769342 157.341055)
        (xy 68.769339 157.341056)
        (xy 68.763203 157.341614)
        (xy 68.565572 157.39978)
        (xy 68.560107 157.402637)
        (xy 68.544143 157.410983)
        (xy 68.383002 157.495226)
        (xy 68.378201 157.499086)
        (xy 68.378198 157.499088)
        (xy 68.233162 157.6157)
        (xy 68.222447 157.624315)
        (xy 68.090024 157.78213)
        (xy 68.087056 157.787528)
        (xy 68.087053 157.787533)
        (xy 68.080315 157.79979)
        (xy 67.990776 157.962662)
        (xy 67.928484 158.159032)
        (xy 67.927798 158.165149)
        (xy 67.927797 158.165153)
        (xy 67.908338 158.338637)
        (xy 67.45648 158.17347)
        (xy 67.396935 157.976249)
        (xy 67.300218 157.794349)
        (xy 67.217666 157.693131)
        (xy 67.173906 157.639475)
        (xy 67.173903 157.639472)
        (xy 67.170011 157.6347)
        (xy 67.1482 157.616656)
        (xy 67.016025 157.507311)
        (xy 67.016021 157.507309)
        (xy 67.011275 157.503382)
        (xy 66.830055 157.405397)
        (xy 66.633254 157.344477)
        (xy 66.627129 157.343833)
        (xy 66.627128 157.343833)
        (xy 66.434498 157.323587)
        (xy 66.434496 157.323587)
        (xy 66.428369 157.322943)
        (xy 66.341529 157.330846)
        (xy 66.229342 157.341055)
        (xy 66.229339 157.341056)
        (xy 66.223203 157.341614)
        (xy 66.025572 157.39978)
        (xy 66.020107 157.402637)
        (xy 66.004143 157.410983)
        (xy 65.843002 157.495226)
        (xy 65.838201 157.499086)
        (xy 65.838198 157.499088)
        (xy 65.693162 157.6157)
        (xy 65.682447 157.624315)
        (xy 65.550024 157.78213)
        (xy 65.547056 157.787528)
        (xy 65.547053 157.787533)
        (xy 65.540315 157.79979)
        (xy 65.450776 157.962662)
        (xy 65.388484 158.159032)
        (xy 65.387798 158.165149)
        (xy 65.387797 158.165153)
        (xy 65.368338 158.338637)
        (xy 64.91648 158.17347)
        (xy 64.856935 157.976249)
        (xy 64.760218 157.794349)
        (xy 64.677666 157.693131)
        (xy 64.633906 157.639475)
        (xy 64.633903 157.639472)
        (xy 64.630011 157.6347)
        (xy 64.6082 157.616656)
        (xy 64.476025 157.507311)
        (xy 64.476021 157.507309)
        (xy 64.471275 157.503382)
        (xy 64.290055 157.405397)
        (xy 64.093254 157.344477)
        (xy 64.087129 157.343833)
        (xy 64.087128 157.343833)
        (xy 63.894498 157.323587)
        (xy 63.894496 157.323587)
        (xy 63.888369 157.322943)
        (xy 63.801529 157.330846)
        (xy 63.689342 157.341055)
        (xy 63.689339 157.341056)
        (xy 63.683203 157.341614)
        (xy 63.485572 157.39978)
        (xy 63.480107 157.402637)
        (xy 63.464143 157.410983)
        (xy 63.303002 157.495226)
        (xy 63.298201 157.499086)
        (xy 63.298198 157.499088)
        (xy 63.153162 157.6157)
        (xy 63.142447 157.624315)
        (xy 63.010024 157.78213)
        (xy 63.007056 157.787528)
        (xy 63.007053 157.787533)
        (xy 63.000315 157.79979)
        (xy 62.910776 157.962662)
        (xy 62.848484 158.159032)
        (xy 62.847798 158.165149)
        (xy 62.847797 158.165153)
        (xy 62.828338 158.338637)
        (xy 62.37648 158.17347)
        (xy 62.316935 157.976249)
        (xy 62.220218 157.794349)
        (xy 62.137666 157.693131)
        (xy 62.093906 157.639475)
        (xy 62.093903 157.639472)
        (xy 62.090011 157.6347)
        (xy 62.0682 157.616656)
        (xy 61.936025 157.507311)
        (xy 61.936021 157.507309)
        (xy 61.931275 157.503382)
        (xy 61.750055 157.405397)
        (xy 61.553254 157.344477)
        (xy 61.547129 157.343833)
        (xy 61.547128 157.343833)
        (xy 61.354498 157.323587)
        (xy 61.354496 157.323587)
        (xy 61.348369 157.322943)
        (xy 61.261529 157.330846)
        (xy 61.149342 157.341055)
        (xy 61.149339 157.341056)
        (xy 61.143203 157.341614)
        (xy 60.945572 157.39978)
        (xy 60.940107 157.402637)
        (xy 60.924143 157.410983)
        (xy 60.763002 157.495226)
        (xy 60.758201 157.499086)
        (xy 60.758198 157.499088)
        (xy 60.613162 157.6157)
        (xy 60.602447 157.624315)
        (xy 60.470024 157.78213)
        (xy 60.467056 157.787528)
        (xy 60.467053 157.787533)
        (xy 60.460315 157.79979)
        (xy 60.370776 157.962662)
        (xy 60.308484 158.159032)
        (xy 60.307798 158.165149)
        (xy 60.307797 158.165153)
        (xy 60.288338 158.338637)
        (xy 48.426534 158.363022)
        (xy 48.426534 158.363018)
        (xy 48.426583 158.3595)
        (xy 48.40648 158.15447)
        (xy 48.346935 157.957249)
        (xy 48.250218 157.775349)
        (xy 48.176859 157.685402)
        (xy 48.123906 157.620475)
        (xy 48.123903 157.620472)
        (xy 48.120011 157.6157)
        (xy 48.102786 157.60145)
        (xy 47.966025 157.488311)
        (xy 47.966021 157.488309)
        (xy 47.961275 157.484382)
        (xy 47.780055 157.386397)
        (xy 47.583254 157.325477)
        (xy 47.577129 157.324833)
        (xy 47.577128 157.324833)
        (xy 47.384498 157.304587)
        (xy 47.384496 157.304587)
        (xy 47.378369 157.303943)
        (xy 47.291529 157.311846)
        (xy 47.179342 157.322055)
        (xy 47.179339 157.322056)
        (xy 47.173203 157.322614)
        (xy 46.975572 157.38078)
        (xy 46.970107 157.383637)
        (xy 46.928484 157.405397)
        (xy 46.793002 157.476226)
        (xy 46.788201 157.480086)
        (xy 46.788198 157.480088)
        (xy 46.682196 157.565316)
        (xy 46.632447 157.605315)
        (xy 46.500024 157.76313)
        (xy 46.497056 157.768528)
        (xy 46.497053 157.768533)
        (xy 46.403743 157.938265)
        (xy 46.400776 157.943662)
        (xy 46.338484 158.140032)
        (xy 46.337798 158.146149)
        (xy 46.337797 158.146153)
        (xy 46.316207 158.338637)
        (xy 45.86648 158.15447)
        (xy 45.806935 157.957249)
        (xy 45.710218 157.775349)
        (xy 45.636859 157.685402)
        (xy 45.583906 157.620475)
        (xy 45.583903 157.620472)
        (xy 45.580011 157.6157)
        (xy 45.562786 157.60145)
        (xy 45.426025 157.488311)
        (xy 45.426021 157.488309)
        (xy 45.421275 157.484382)
        (xy 45.240055 157.386397)
        (xy 45.043254 157.325477)
        (xy 45.037129 157.324833)
        (xy 45.037128 157.324833)
        (xy 44.844498 157.304587)
        (xy 44.844496 157.304587)
        (xy 44.838369 157.303943)
        (xy 44.751529 157.311846)
        (xy 44.639342 157.322055)
        (xy 44.639339 157.322056)
        (xy 44.633203 157.322614)
        (xy 44.435572 157.38078)
        (xy 44.430107 157.383637)
        (xy 44.388484 157.405397)
        (xy 44.253002 157.476226)
        (xy 44.248201 157.480086)
        (xy 44.248198 157.480088)
        (xy 44.142196 157.565316)
        (xy 44.092447 157.605315)
        (xy 43.960024 157.76313)
        (xy 43.957056 157.768528)
        (xy 43.957053 157.768533)
        (xy 43.863743 157.938265)
        (xy 43.860776 157.943662)
        (xy 43.798484 158.140032)
        (xy 43.797798 158.146149)
        (xy 43.797797 158.146153)
        (xy 43.776207 158.338637)
        (xy 43.32648 158.15447)
        (xy 43.266935 157.957249)
        (xy 43.170218 157.775349)
        (xy 43.096859 157.685402)
        (xy 43.043906 157.620475)
        (xy 43.043903 157.620472)
        (xy 43.040011 157.6157)
        (xy 43.022786 157.60145)
        (xy 42.886025 157.488311)
        (xy 42.886021 157.488309)
        (xy 42.881275 157.484382)
        (xy 42.700055 157.386397)
        (xy 42.503254 157.325477)
        (xy 42.497129 157.324833)
        (xy 42.497128 157.324833)
        (xy 42.304498 157.304587)
        (xy 42.304496 157.304587)
        (xy 42.298369 157.303943)
        (xy 42.211529 157.311846)
        (xy 42.099342 157.322055)
        (xy 42.099339 157.322056)
        (xy 42.093203 157.322614)
        (xy 41.895572 157.38078)
        (xy 41.890107 157.383637)
        (xy 41.848484 157.405397)
        (xy 41.713002 157.476226)
        (xy 41.708201 157.480086)
        (xy 41.708198 157.480088)
        (xy 41.602196 157.565316)
        (xy 41.552447 157.605315)
        (xy 41.420024 157.76313)
        (xy 41.417056 157.768528)
        (xy 41.417053 157.768533)
        (xy 41.323743 157.938265)
        (xy 41.320776 157.943662)
        (xy 41.258484 158.140032)
        (xy 41.257798 158.146149)
        (xy 41.257797 158.146153)
        (xy 41.236207 158.338637)
        (xy 40.78648 158.15447)
        (xy 40.726935 157.957249)
        (xy 40.630218 157.775349)
        (xy 40.556859 157.685402)
        (xy 40.503906 157.620475)
        (xy 40.503903 157.620472)
        (xy 40.500011 157.6157)
        (xy 40.482786 157.60145)
        (xy 40.346025 157.488311)
        (xy 40.346021 157.488309)
        (xy 40.341275 157.484382)
        (xy 40.160055 157.386397)
        (xy 39.963254 157.325477)
        (xy 39.957129 157.324833)
        (xy 39.957128 157.324833)
        (xy 39.764498 157.304587)
        (xy 39.764496 157.304587)
        (xy 39.758369 157.303943)
        (xy 39.671529 157.311846)
        (xy 39.559342 157.322055)
        (xy 39.559339 157.322056)
        (xy 39.553203 157.322614)
        (xy 39.355572 157.38078)
        (xy 39.350107 157.383637)
        (xy 39.308484 157.405397)
        (xy 39.173002 157.476226)
        (xy 39.168201 157.480086)
        (xy 39.168198 157.480088)
        (xy 39.062196 157.565316)
        (xy 39.012447 157.605315)
        (xy 38.880024 157.76313)
        (xy 38.877056 157.768528)
        (xy 38.877053 157.768533)
        (xy 38.783743 157.938265)
        (xy 38.780776 157.943662)
        (xy 38.718484 158.140032)
        (xy 38.717798 158.146149)
        (xy 38.717797 158.146153)
        (xy 38.696207 158.338637)
        (xy 38.24648 158.15447)
        (xy 38.186935 157.957249)
        (xy 38.090218 157.775349)
        (xy 38.016859 157.685402)
        (xy 37.963906 157.620475)
        (xy 37.963903 157.620472)
        (xy 37.960011 157.6157)
        (xy 37.942786 157.60145)
        (xy 37.806025 157.488311)
        (xy 37.806021 157.488309)
        (xy 37.801275 157.484382)
        (xy 37.620055 157.386397)
        (xy 37.423254 157.325477)
        (xy 37.417129 157.324833)
        (xy 37.417128 157.324833)
        (xy 37.224498 157.304587)
        (xy 37.224496 157.304587)
        (xy 37.218369 157.303943)
        (xy 37.131529 157.311846)
        (xy 37.019342 157.322055)
        (xy 37.019339 157.322056)
        (xy 37.013203 157.322614)
        (xy 36.815572 157.38078)
        (xy 36.810107 157.383637)
        (xy 36.768484 157.405397)
        (xy 36.633002 157.476226)
        (xy 36.628201 157.480086)
        (xy 36.628198 157.480088)
        (xy 36.522196 157.565316)
        (xy 36.472447 157.605315)
        (xy 36.340024 157.76313)
        (xy 36.337056 157.768528)
        (xy 36.337053 157.768533)
        (xy 36.243743 157.938265)
        (xy 36.240776 157.943662)
        (xy 36.178484 158.140032)
        (xy 36.177798 158.146149)
        (xy 36.177797 158.146153)
        (xy 36.156207 158.338637)
        (xy 15.189373 156.14244)
        (xy 21.32577 156.14244)
        (xy 21.3402 156.362604)
        (xy 21.341621 156.3682)
        (xy 21.341622 156.368205)
        (xy 21.39309 156.570857)
        (xy 21.394511 156.576452)
        (xy 21.396928 156.581694)
        (xy 21.396928 156.581695)
        (xy 21.435046 156.664379)
        (xy 21.486883 156.776821)
        (xy 21.614222 156.957002)
        (xy 21.772264 157.110961)
        (xy 21.77706 157.114166)
        (xy 21.777063 157.114168)
        (xy 21.861261 157.170427)
        (xy 21.955717 157.23354)
        (xy 21.96102 157.235818)
        (xy 21.961023 157.23582)
        (xy 22.119584 157.303943)
        (xy 22.158436 157.320635)
        (xy 22.187887 157.327299)
        (xy 22.367995 157.368054)
        (xy 22.368001 157.368055)
        (xy 22.373632 157.369329)
        (xy 22.379403 157.369556)
        (xy 22.379405 157.369556)
        (xy 22.447211 157.37222)
        (xy 22.594098 157.377991)
        (xy 22.703275 157.362161)
        (xy 22.806738 157.34716)
        (xy 22.806743 157.347159)
        (xy 22.812452 157.346331)
        (xy 22.817916 157.344476)
        (xy 22.817921 157.344475)
        (xy 23.015907 157.277268)
        (xy 23.015912 157.277266)
        (xy 23.021379 157.27541)
        (xy 23.213884 157.167602)
        (xy 23.220523 157.162081)
        (xy 23.379086 157.030204)
        (xy 23.383518 157.026518)
        (xy 23.467716 156.925282)
        (xy 23.520908 156.861326)
        (xy 23.52091 156.861323)
        (xy 23.524602 156.856884)
        (xy 23.600436 156.721473)
        (xy 23.629586 156.669422)
        (xy 23.629587 156.66942)
        (xy 23.63241 156.664379)
        (xy 23.634266 156.658912)
        (xy 23.634268 156.658907)
        (xy 23.701475 156.460921)
        (xy 23.701476 156.460916)
        (xy 23.703331 156.455452)
        (xy 23.704159 156.449743)
        (xy 23.70416 156.449738)
        (xy 23.734458 156.240772)
        (xy 23.734991 156.237098)
        (xy 23.736643 156.174)
        (xy 23.733743 156.14244)
        (xy 27.82577 156.14244)
        (xy 27.8402 156.362604)
        (xy 27.841621 156.3682)
        (xy 27.841622 156.368205)
        (xy 27.89309 156.570857)
        (xy 27.894511 156.576452)
        (xy 27.896928 156.581694)
        (xy 27.896928 156.581695)
        (xy 27.935046 156.664379)
        (xy 27.986883 156.776821)
        (xy 28.114222 156.957002)
        (xy 28.272264 157.110961)
        (xy 28.27706 157.114166)
        (xy 28.277063 157.114168)
        (xy 28.361261 157.170427)
        (xy 28.455717 157.23354)
        (xy 28.46102 157.235818)
        (xy 28.461023 157.23582)
        (xy 28.619584 157.303943)
        (xy 28.658436 157.320635)
        (xy 28.687887 157.327299)
        (xy 28.867995 157.368054)
        (xy 28.868001 157.368055)
        (xy 28.873632 157.369329)
        (xy 28.879403 157.369556)
        (xy 28.879405 157.369556)
        (xy 28.947211 157.37222)
        (xy 29.094098 157.377991)
        (xy 29.203275 157.362161)
        (xy 29.306738 157.34716)
        (xy 29.306743 157.347159)
        (xy 29.312452 157.346331)
        (xy 29.317916 157.344476)
        (xy 29.317921 157.344475)
        (xy 29.515907 157.277268)
        (xy 29.515912 157.277266)
        (xy 29.521379 157.27541)
        (xy 29.713884 157.167602)
        (xy 29.720523 157.162081)
        (xy 29.879086 157.030204)
        (xy 29.883518 157.026518)
        (xy 29.967716 156.925282)
        (xy 30.020908 156.861326)
        (xy 30.02091 156.861323)
        (xy 30.024602 156.856884)
        (xy 30.100436 156.721473)
        (xy 30.129586 156.669422)
        (xy 30.129587 156.66942)
        (xy 30.13241 156.664379)
        (xy 30.134266 156.658912)
        (xy 30.134268 156.658907)
        (xy 30.201475 156.460921)
        (xy 30.201476 156.460916)
        (xy 30.203331 156.455452)
        (xy 30.204159 156.449743)
        (xy 30.20416 156.449738)
        (xy 30.234458 156.240772)
        (xy 30.234991 156.237098)
        (xy 30.236643 156.174)
        (xy 30.216454 155.954289)
        (xy 30.156565 155.741936)
        (xy 30.05898 155.544053)
        (xy 29.926967 155.367267)
        (xy 29.764949 155.217499)
        (xy 29.57835 155.099764)
        (xy 29.373421 155.018006)
        (xy 29.367761 155.01688)
        (xy 29.367757 155.016879)
        (xy 29.162691 154.976089)
        (xy 29.162688 154.976089)
        (xy 29.157024 154.974962)
        (xy 29.151249 154.974886)
        (xy 29.151245 154.974886)
        (xy 29.040504 154.973437)
        (xy 28.936406 154.972074)
        (xy 28.930709 154.973053)
        (xy 28.930708 154.973053)
        (xy 28.724654 155.008459)
        (xy 28.724653 155.008459)
        (xy 28.718957 155.009438)
        (xy 28.511957 155.085804)
        (xy 28.506996 155.088756)
        (xy 28.506995 155.088756)
        (xy 28.469627 155.110988)
        (xy 28.322341 155.198614)
        (xy 28.156457 155.34409)
        (xy 28.019863 155.51736)
        (xy 27.917131 155.71262)
        (xy 27.851703 155.923333)
        (xy 23.716454 155.954289)
        (xy 23.656565 155.741936)
        (xy 23.55898 155.544053)
        (xy 23.426967 155.367267)
        (xy 23.264949 155.217499)
        (xy 23.07835 155.099764)
        (xy 22.873421 155.018006)
        (xy 22.867761 155.01688)
        (xy 22.867757 155.016879)
        (xy 22.662691 154.976089)
        (xy 22.662688 154.976089)
        (xy 22.657024 154.974962)
        (xy 22.651249 154.974886)
        (xy 22.651245 154.974886)
        (xy 22.540504 154.973437)
        (xy 22.436406 154.972074)
        (xy 22.430709 154.973053)
        (xy 22.430708 154.973053)
        (xy 22.224654 155.008459)
        (xy 22.224653 155.008459)
        (xy 22.218957 155.009438)
        (xy 22.011957 155.085804)
        (xy 22.006996 155.088756)
        (xy 22.006995 155.088756)
        (xy 21.969627 155.110988)
        (xy 21.822341 155.198614)
        (xy 21.656457 155.34409)
        (xy 21.519863 155.51736)
        (xy 21.417131 155.71262)
        (xy 21.351703 155.923333)
        (xy 15.189373 152.736002)
        (xy 21.654637 152.736002)
        (xy 21.661781 152.746062)
        (xy 21.732777 152.805004)
        (xy 21.741211 152.81091)
        (xy 21.928218 152.920189)
        (xy 21.937507 152.924639)
        (xy 22.139847 153.001904)
        (xy 22.149737 153.004777)
        (xy 22.361966 153.047956)
        (xy 22.372219 153.049179)
        (xy 22.588652 153.057116)
        (xy 22.598936 153.056649)
        (xy 22.813782 153.029126)
        (xy 22.823847 153.026986)
        (xy 23.031313 152.964744)
        (xy 23.04089 152.960991)
        (xy 23.235406 152.865699)
        (xy 23.244244 152.86043)
        (xy 23.400852 152.748723)
        (xy 23.409252 152.738023)
        (xy 23.408178 152.736002)
        (xy 28.154637 152.736002)
        (xy 28.161781 152.746062)
        (xy 28.232777 152.805004)
        (xy 28.241211 152.81091)
        (xy 28.428218 152.920189)
        (xy 28.437507 152.924639)
        (xy 28.639847 153.001904)
        (xy 28.649737 153.004777)
        (xy 28.861966 153.047956)
        (xy 28.872219 153.049179)
        (xy 29.088652 153.057116)
        (xy 29.098936 153.056649)
        (xy 29.313782 153.029126)
        (xy 29.323847 153.026986)
        (xy 29.531313 152.964744)
        (xy 29.54089 152.960991)
        (xy 29.735406 152.865699)
        (xy 29.744244 152.86043)
        (xy 29.900852 152.748723)
        (xy 29.909252 152.738023)
        (xy 29.902265 152.72487)
        (xy 29.043812 151.866417)
        (xy 29.029868 151.858803)
        (xy 29.028035 151.858934)
        (xy 29.02142 151.863185)
        (xy 28.161896 152.722709)
        (xy 23.402265 152.72487)
        (xy 22.543812 151.866417)
        (xy 22.529868 151.858803)
        (xy 22.528035 151.858934)
        (xy 22.52142 151.863185)
        (xy 21.661896 152.722709)
        (xy 15.189373 151.645324)
        (xy 21.14698 151.645324)
        (xy 21.159448 151.861548)
        (xy 21.160884 151.871769)
        (xy 21.208499 152.083049)
        (xy 21.211578 152.092877)
        (xy 21.293066 152.293557)
        (xy 21.297709 152.302748)
        (xy 21.410879 152.487425)
        (xy 21.416964 152.495738)
        (xy 21.457409 152.54243)
        (xy 21.470495 152.550843)
        (xy 21.480468 152.544927)
        (xy 22.338583 151.686812)
        (xy 22.344961 151.675132)
        (xy 22.715803 151.675132)
        (xy 22.715934 151.676965)
        (xy 22.720185 151.68358)
        (xy 23.582142 152.545537)
        (xy 23.594152 152.552096)
        (xy 23.605892 152.543128)
        (xy 23.714927 152.391388)
        (xy 23.720238 152.38255)
        (xy 23.816195 152.188394)
        (xy 23.819994 152.178799)
        (xy 23.882953 151.97158)
        (xy 23.885132 151.961499)
        (xy 23.91364 151.744965)
        (xy 23.914159 151.738292)
        (xy 23.915648 151.677365)
        (xy 23.915454 151.670646)
        (xy 23.913372 151.645324)
        (xy 27.64698 151.645324)
        (xy 27.659448 151.861548)
        (xy 27.660884 151.871769)
        (xy 27.708499 152.083049)
        (xy 27.711578 152.092877)
        (xy 27.793066 152.293557)
        (xy 27.797709 152.302748)
        (xy 27.910879 152.487425)
        (xy 27.916964 152.495738)
        (xy 27.957409 152.54243)
        (xy 27.970495 152.550843)
        (xy 27.980468 152.544927)
        (xy 28.838583 151.686812)
        (xy 28.844961 151.675132)
        (xy 29.215803 151.675132)
        (xy 29.215934 151.676965)
        (xy 29.220185 151.68358)
        (xy 30.082142 152.545537)
        (xy 30.094152 152.552096)
        (xy 30.105892 152.543128)
        (xy 30.214927 152.391388)
        (xy 30.220238 152.38255)
        (xy 30.316195 152.188394)
        (xy 30.319994 152.178799)
        (xy 30.382953 151.97158)
        (xy 30.385132 151.961499)
        (xy 30.41364 151.744965)
        (xy 30.414159 151.738292)
        (xy 30.415648 151.677365)
        (xy 30.415454 151.670646)
        (xy 30.39756 151.452989)
        (xy 30.395877 151.442827)
        (xy 30.343113 151.232762)
        (xy 30.339792 151.223007)
        (xy 30.253432 151.024395)
        (xy 30.248554 151.015297)
        (xy 30.130917 150.833457)
        (xy 30.124626 150.825288)
        (xy 30.105703 150.804493)
        (xy 30.092137 150.796233)
        (xy 30.091882 150.796239)
        (xy 30.082869 150.801736)
        (xy 29.223417 151.661188)
        (xy 28.846197 151.672868)
        (xy 28.846066 151.671035)
        (xy 28.841815 151.66442)
        (xy 27.979937 150.802542)
        (xy 27.965993 150.794928)
        (xy 27.96492 150.795004)
        (xy 27.95765 150.799793)
        (xy 27.951944 150.806839)
        (xy 27.829903 150.985745)
        (xy 27.824805 150.994719)
        (xy 27.73362 151.19116)
        (xy 27.730057 151.200847)
        (xy 27.672179 151.409545)
        (xy 27.670248 151.419664)
        (xy 27.647232 151.635035)
        (xy 23.89756 151.452989)
        (xy 23.895877 151.442827)
        (xy 23.843113 151.232762)
        (xy 23.839792 151.223007)
        (xy 23.753432 151.024395)
        (xy 23.748554 151.015297)
        (xy 23.630917 150.833457)
        (xy 23.624626 150.825288)
        (xy 23.605703 150.804493)
        (xy 23.592137 150.796233)
        (xy 23.591882 150.796239)
        (xy 23.582869 150.801736)
        (xy 22.723417 151.661188)
        (xy 22.346197 151.672868)
        (xy 22.346066 151.671035)
        (xy 22.341815 151.66442)
        (xy 21.479937 150.802542)
        (xy 21.465993 150.794928)
        (xy 21.46492 150.795004)
        (xy 21.45765 150.799793)
        (xy 21.451944 150.806839)
        (xy 21.329903 150.985745)
        (xy 21.324805 150.994719)
        (xy 21.23362 151.19116)
        (xy 21.230057 151.200847)
        (xy 21.172179 151.409545)
        (xy 21.170248 151.419664)
        (xy 21.147232 151.635035)
        (xy 15.189373 150.611734)
        (xy 21.653924 150.611734)
        (xy 21.660669 150.624064)
        (xy 22.518188 151.481583)
        (xy 22.532132 151.489197)
        (xy 22.533965 151.489066)
        (xy 22.54058 151.484815)
        (xy 23.400406 150.624989)
        (xy 23.407427 150.612133)
        (xy 23.407136 150.611734)
        (xy 28.153924 150.611734)
        (xy 28.160669 150.624064)
        (xy 29.018188 151.481583)
        (xy 29.032132 151.489197)
        (xy 29.033965 151.489066)
        (xy 29.04058 151.484815)
        (xy 29.900406 150.624989)
        (xy 29.907427 150.612133)
        (xy 29.899654 150.601465)
        (xy 29.801352 150.52383)
        (xy 29.792779 150.518134)
        (xy 29.603155 150.413456)
        (xy 29.59376 150.409235)
        (xy 29.389597 150.336937)
        (xy 29.379631 150.334304)
        (xy 29.166402 150.296321)
        (xy 29.156152 150.295352)
        (xy 28.939576 150.292706)
        (xy 28.929292 150.293426)
        (xy 28.715205 150.326186)
        (xy 28.705177 150.328575)
        (xy 28.499314 150.395861)
        (xy 28.489805 150.399858)
        (xy 28.297699 150.499862)
        (xy 28.288974 150.505356)
        (xy 28.162378 150.600407)
        (xy 23.399654 150.601465)
        (xy 23.301352 150.52383)
        (xy 23.292779 150.518134)
        (xy 23.103155 150.413456)
        (xy 23.09376 150.409235)
        (xy 22.889597 150.336937)
        (xy 22.879631 150.334304)
        (xy 22.666402 150.296321)
        (xy 22.656152 150.295352)
        (xy 22.439576 150.292706)
        (xy 22.429292 150.293426)
        (xy 22.215205 150.326186)
        (xy 22.205177 150.328575)
        (xy 21.999314 150.395861)
        (xy 21.989805 150.399858)
        (xy 21.797699 150.499862)
        (xy 21.788974 150.505356)
        (xy 21.662378 150.600407)
        (xy 15.189373 146.989236)
        (xy 19.053958 146.989236)
        (xy 19.054321 146.993384)
        (xy 19.054321 146.993389)
        (xy 19.056903 147.022904)
        (xy 19.080014 147.287065)
        (xy 19.145232 147.578832)
        (xy 19.146676 147.582756)
        (xy 19.146676 147.582757)
        (xy 19.185289 147.687705)
        (xy 19.248464 147.85941)
        (xy 19.250415 147.86311)
        (xy 19.250417 147.863115)
        (xy 19.267615 147.895733)
        (xy 19.387898 148.12387)
        (xy 19.561084 148.367565)
        (xy 19.764979 148.586216)
        (xy 19.996 148.775979)
        (xy 20.25009 148.933521)
        (xy 20.522783 149.056074)
        (xy 20.618405 149.08458)
        (xy 20.80529 149.140293)
        (xy 20.805292 149.140293)
        (xy 20.809289 149.141485)
        (xy 20.813409 149.142138)
        (xy 20.813411 149.142138)
        (xy 20.899247 149.155733)
        (xy 21.104575 149.188254)
        (xy 21.147135 149.190187)
        (xy 21.196659 149.192436)
        (xy 21.196678 149.192436)
        (xy 21.198078 149.1925)
        (xy 21.384834 149.1925)
        (xy 21.607309 149.177723)
        (xy 21.900377 149.11863)
        (xy 22.183056 149.021296)
        (xy 22.186789 149.019427)
        (xy 22.186793 149.019425)
        (xy 22.44664 148.889303)
        (xy 22.446642 148.889302)
        (xy 22.450378 148.887431)
        (xy 22.697647 148.719387)
        (xy 22.707661 148.710434)
        (xy 22.917403 148.522904)
        (xy 22.917404 148.522903)
        (xy 22.92052 148.520117)
        (xy 23.115079 148.29312)
        (xy 23.203804 148.156496)
        (xy 23.275629 148.045896)
        (xy 23.275632 148.045891)
        (xy 23.277908 148.042386)
        (xy 23.406145 147.772319)
        (xy 23.497538 147.487664)
        (xy 23.535626 147.275979)
        (xy 23.549741 147.197531)
        (xy 23.549742 147.197526)
        (xy 23.55048 147.193422)
        (xy 23.555349 147.086216)
        (xy 23.563853 146.898934)
        (xy 23.563853 146.898929)
        (xy 23.564042 146.894764)
        (xy 23.562279 146.874605)
        (xy 23.549048 146.723379)
        (xy 23.537986 146.596935)
        (xy 23.472768 146.305168)
        (xy 23.462074 146.276101)
        (xy 23.370983 146.028523)
        (xy 23.369536 146.02459)
        (xy 23.35217 145.991651)
        (xy 23.232055 145.763834)
        (xy 23.232054 145.763833)
        (xy 23.230102 145.76013)
        (xy 23.056916 145.516435)
        (xy 23.031553 145.489236)
        (xy 55.053958 145.489236)
        (xy 55.054321 145.493384)
        (xy 55.054321 145.493389)
        (xy 55.057971 145.53511)
        (xy 55.080014 145.787065)
        (xy 55.145232 146.078832)
        (xy 55.146676 146.082756)
        (xy 55.146676 146.082757)
        (xy 55.170953 146.14874)
        (xy 55.248464 146.35941)
        (xy 55.250415 146.36311)
        (xy 55.250417 146.363115)
        (xy 55.349388 146.550829)
        (xy 55.387898 146.62387)
        (xy 55.561084 146.867565)
        (xy 55.764979 147.086216)
        (xy 55.996 147.275979)
        (xy 56.25009 147.433521)
        (xy 56.522783 147.556074)
        (xy 56.620847 147.585308)
        (xy 56.80529 147.640293)
        (xy 56.805292 147.640293)
        (xy 56.809289 147.641485)
        (xy 56.813409 147.642138)
        (xy 56.813411 147.642138)
        (xy 56.931423 147.660829)
        (xy 57.104575 147.688254)
        (xy 57.147135 147.690187)
        (xy 57.196659 147.692436)
        (xy 57.196678 147.692436)
        (xy 57.198078 147.6925)
        (xy 57.384834 147.6925)
        (xy 57.607309 147.677723)
        (xy 57.900377 147.61863)
        (xy 58.183056 147.521296)
        (xy 58.186789 147.519427)
        (xy 58.186793 147.519425)
        (xy 58.44664 147.389303)
        (xy 58.446642 147.389302)
        (xy 58.450378 147.387431)
        (xy 58.697647 147.219387)
        (xy 58.726688 147.193422)
        (xy 58.917403 147.022904)
        (xy 58.917404 147.022903)
        (xy 58.92052 147.020117)
        (xy 59.115079 146.79312)
        (xy 59.239778 146.601101)
        (xy 59.275629 146.545896)
        (xy 59.275632 146.545891)
        (xy 59.277908 146.542386)
        (xy 59.406145 146.272319)
        (xy 59.432272 146.190945)
        (xy 59.496258 145.991651)
        (xy 59.496258 145.99165)
        (xy 59.497538 145.987664)
        (xy 59.524448 145.838104)
        (xy 59.534164 145.784107)
        (xy 74.443962 145.784107)
        (xy 74.462605 146.152135)
        (xy 74.463142 146.15549)
        (xy 74.463143 146.155496)
        (xy 74.495175 146.355477)
        (xy 74.520886 146.515996)
        (xy 74.618123 146.871435)
        (xy 74.753179 147.214293)
        (xy 74.754762 147.217308)
        (xy 74.922889 147.537544)
        (xy 74.922894 147.537552)
        (xy 74.924473 147.54056)
        (xy 75.130002 147.846419)
        (xy 75.367361 148.128292)
        (xy 75.633774 148.382882)
        (xy 75.926124 148.60721)
        (xy 75.929037 148.608981)
        (xy 76.238077 148.796881)
        (xy 76.238082 148.796884)
        (xy 76.240992 148.798653)
        (xy 76.574693 148.95497)
        (xy 76.923325 149.074333)
        (xy 76.926648 149.075082)
        (xy 76.926652 149.075083)
        (xy 77.279484 149.154598)
        (xy 77.27949 149.154599)
        (xy 77.282809 149.155347)
        (xy 77.286188 149.155732)
        (xy 77.286194 149.155733)
        (xy 77.43951 149.173201)
        (xy 77.64894 149.197062)
        (xy 77.652345 149.19708)
        (xy 77.652348 149.19708)
        (xy 77.849323 149.198111)
        (xy 78.017434 149.198991)
        (xy 78.02082 149.198641)
        (xy 78.020822 149.198641)
        (xy 78.380589 149.161463)
        (xy 78.380598 149.161462)
        (xy 78.383981 149.161112)
        (xy 78.387314 149.160397)
        (xy 78.387317 149.160397)
        (xy 78.588501 149.117267)
        (xy 78.744294 149.083868)
        (xy 79.094157 148.968162)
        (xy 79.429477 148.815348)
        (xy 79.741416 148.630132)
        (xy 79.743387 148.628962)
        (xy 79.743392 148.628959)
        (xy 79.746332 148.627213)
        (xy 79.797398 148.588872)
        (xy 79.918545 148.497912)
        (xy 80.041015 148.405959)
        (xy 80.31008 148.154173)
        (xy 80.550378 147.874801)
        (xy 80.620812 147.772319)
        (xy 80.757168 147.57392)
        (xy 80.757173 147.573913)
        (xy 80.759098 147.571111)
        (xy 80.76071 147.568117)
        (xy 80.760715 147.568109)
        (xy 80.90984 147.291152)
        (xy 80.933799 147.246655)
        (xy 81.072438 146.90523)
        (xy 81.074232 146.898934)
        (xy 81.160257 146.596935)
        (xy 81.173391 146.550829)
        (xy 81.23548 146.187598)
        (xy 81.237444 146.155496)
        (xy 81.257866 145.821583)
        (xy 81.257976 145.819786)
        (xy 81.258059 145.796)
        (xy 81.238131 145.42804)
        (xy 81.17858 145.064384)
        (xy 81.080103 144.709287)
        (xy 81.078845 144.706125)
        (xy 81.078842 144.706117)
        (xy 80.945111 144.370067)
        (xy 80.945107 144.370059)
        (xy 80.943851 144.366902)
        (xy 80.93814 144.356115)
        (xy 80.773014 144.044245)
        (xy 80.773012 144.044241)
        (xy 80.77142 144.041235)
        (xy 80.564824 143.736095)
        (xy 80.562619 143.733495)
        (xy 80.562613 143.733487)
        (xy 80.32869 143.457655)
        (xy 80.326483 143.455052)
        (xy 80.059183 143.201394)
        (xy 80.056476 143.199332)
        (xy 80.056468 143.199325)
        (xy 79.84584 143.038871)
        (xy 79.766051 142.978088)
        (xy 79.476997 142.803719)
        (xy 79.453438 142.789507)
        (xy 79.453437 142.789507)
        (xy 79.450517 142.787745)
        (xy 79.447427 142.786311)
        (xy 79.447422 142.786308)
        (xy 79.119368 142.634031)
        (xy 79.119366 142.63403)
        (xy 79.116272 142.632594)
        (xy 79.113037 142.631499)
        (xy 79.113032 142.631497)
        (xy 78.770461 142.515543)
        (xy 78.767226 142.514448)
        (xy 78.407461 142.43469)
        (xy 78.278574 142.420461)
        (xy 78.044568 142.394626)
        (xy 78.044563 142.394626)
        (xy 78.041187 142.394253)
        (xy 78.037788 142.394247)
        (xy 78.037787 142.394247)
        (xy 77.863708 142.393943)
        (xy 77.672688 142.39361)
        (xy 77.499923 142.412074)
        (xy 77.309659 142.432407)
        (xy 77.309653 142.432408)
        (xy 77.306275 142.432769)
        (xy 76.946235 142.51127)
        (xy 76.596778 142.628197)
        (xy 76.261993 142.78218)
        (xy 76.259059 142.783936)
        (xy 76.259057 142.783937)
        (xy 75.948725 142.969667)
        (xy 75.948717 142.969673)
        (xy 75.945797 142.97142)
        (xy 75.651888 143.193702)
        (xy 75.383704 143.446426)
        (xy 75.381492 143.449016)
        (xy 75.381491 143.449017)
        (xy 75.275205 143.573462)
        (xy 75.144383 143.726635)
        (xy 75.142469 143.729441)
        (xy 75.142465 143.729446)
        (xy 74.954872 144.004446)
        (xy 74.936723 144.031051)
        (xy 74.935122 144.034049)
        (xy 74.935118 144.034056)
        (xy 74.764761 144.353108)
        (xy 74.764757 144.353117)
        (xy 74.763156 144.356115)
        (xy 74.761887 144.359272)
        (xy 74.761885 144.359276)
        (xy 74.724031 144.453442)
        (xy 74.62571 144.698022)
        (xy 74.62479 144.701296)
        (xy 74.624788 144.701301)
        (xy 74.535412 145.019268)
        (xy 74.525994 145.052773)
        (xy 74.525432 145.05613)
        (xy 74.525432 145.056131)
        (xy 74.468067 145.398934)
        (xy 74.465174 145.416219)
        (xy 74.448712 145.701734)
        (xy 59.549741 145.697531)
        (xy 59.549742 145.697526)
        (xy 59.55048 145.693422)
        (xy 59.553334 145.630592)
        (xy 59.563853 145.398934)
        (xy 59.563853 145.398929)
        (xy 59.564042 145.394764)
        (xy 59.563285 145.386105)
        (xy 59.55012 145.235634)
        (xy 59.537986 145.096935)
        (xy 59.472768 144.805168)
        (xy 59.455522 144.758293)
        (xy 59.370983 144.528523)
        (xy 59.369536 144.52459)
        (xy 59.329361 144.44839)
        (xy 59.232055 144.263834)
        (xy 59.232054 144.263833)
        (xy 59.230102 144.26013)
        (xy 59.204 144.223401)
        (xy 62.165214 144.223401)
        (xy 62.165511 144.228554)
        (xy 62.165511 144.228557)
        (xy 62.167345 144.260364)
        (xy 62.178186 144.44839)
        (xy 62.179323 144.453436)
        (xy 62.179324 144.453442)
        (xy 62.196245 144.528523)
        (xy 62.227732 144.66824)
        (xy 62.229674 144.673022)
        (xy 62.229675 144.673026)
        (xy 62.306143 144.861344)
        (xy 62.312519 144.877045)
        (xy 62.430271 145.069199)
        (xy 62.577825 145.239541)
        (xy 62.751219 145.383495)
        (xy 62.945797 145.497197)
        (xy 63.156332 145.577593)
        (xy 63.161398 145.578624)
        (xy 63.161399 145.578624)
        (xy 63.206049 145.587708)
        (xy 63.377171 145.622523)
        (xy 63.504303 145.627185)
        (xy 63.597219 145.630592)
        (xy 63.597223 145.630592)
        (xy 63.602383 145.630781)
        (xy 63.607503 145.630125)
        (xy 63.607505 145.630125)
        (xy 63.820793 145.602803)
        (xy 63.820796 145.602802)
        (xy 63.82592 145.602146)
        (xy 63.851799 145.594382)
        (xy 64.036824 145.538871)
        (xy 64.041777 145.537385)
        (xy 64.046416 145.535112)
        (xy 64.046422 145.53511)
        (xy 64.239522 145.440511)
        (xy 64.24416 145.438239)
        (xy 64.320908 145.383495)
        (xy 64.423419 145.310375)
        (xy 64.423424 145.310371)
        (xy 64.427631 145.30737)
        (xy 64.587265 145.148293)
        (xy 64.718774 144.965279)
        (xy 64.787248 144.826732)
        (xy 64.816332 144.767886)
        (xy 64.816333 144.767884)
        (xy 64.818626 144.763244)
        (xy 64.884139 144.547613)
        (xy 64.897202 144.44839)
        (xy 64.913118 144.3275)
        (xy 64.913119 144.327493)
        (xy 64.913555 144.324178)
        (xy 64.915197 144.257)
        (xy 64.907346 144.161504)
        (xy 64.897155 144.037546)
        (xy 64.897154 144.03754)
        (xy 64.896731 144.032395)
        (xy 64.86928 143.923108)
        (xy 64.843088 143.818832)
        (xy 64.843087 143.818828)
        (xy 64.841829 143.813821)
        (xy 64.805142 143.729446)
        (xy 64.754026 143.611887)
        (xy 64.754024 143.611884)
        (xy 64.751966 143.60715)
        (xy 64.655253 143.457655)
        (xy 64.632364 143.422273)
        (xy 64.632362 143.42227)
        (xy 64.629554 143.41793)
        (xy 64.547657 143.327926)
        (xy 64.48136 143.255067)
        (xy 64.481358 143.255066)
        (xy 64.477882 143.251245)
        (xy 64.473831 143.248046)
        (xy 64.473827 143.248042)
        (xy 64.346233 143.147275)
        (xy 64.301022 143.111569)
        (xy 64.103725 143.002655)
        (xy 63.988772 142.961948)
        (xy 63.896163 142.929153)
        (xy 63.896159 142.929152)
        (xy 63.891288 142.927427)
        (xy 63.886195 142.92652)
        (xy 63.886192 142.926519)
        (xy 63.674506 142.888812)
        (xy 63.6745 142.888811)
        (xy 63.669417 142.887906)
        (xy 63.595725 142.887006)
        (xy 63.449241 142.885216)
        (xy 63.449239 142.885216)
        (xy 63.444071 142.885153)
        (xy 63.221301 142.919242)
        (xy 63.00709 142.989257)
        (xy 63.002502 142.991645)
        (xy 63.002498 142.991647)
        (xy 62.835417 143.078624)
        (xy 62.80719 143.093318)
        (xy 62.803057 143.096421)
        (xy 62.803054 143.096423)
        (xy 62.631106 143.225525)
        (xy 62.626971 143.22863)
        (xy 62.60536 143.251245)
        (xy 62.497059 143.364575)
        (xy 62.471271 143.39156)
        (xy 62.468359 143.395829)
        (xy 62.398037 143.498918)
        (xy 62.344273 143.577733)
        (xy 62.249387 143.782147)
        (xy 62.189162 143.999314)
        (xy 59.056916 144.016435)
        (xy 58.865683 143.811362)
        (xy 58.855871 143.80084)
        (xy 58.855869 143.800838)
        (xy 58.853021 143.797784)
        (xy 58.622 143.608021)
        (xy 58.36791 143.450479)
        (xy 58.095217 143.327926)
        (xy 57.850816 143.255067)
        (xy 57.81271 143.243707)
        (xy 57.812708 143.243707)
        (xy 57.808711 143.242515)
        (xy 57.804591 143.241862)
        (xy 57.804589 143.241862)
        (xy 57.686577 143.223171)
        (xy 57.513425 143.195746)
        (xy 57.470865 143.193813)
        (xy 57.421341 143.191564)
        (xy 57.421322 143.191564)
        (xy 57.419922 143.1915)
        (xy 57.233166 143.1915)
        (xy 57.010691 143.206277)
        (xy 56.717623 143.26537)
        (xy 56.434944 143.362704)
        (xy 56.431211 143.364573)
        (xy 56.431207 143.364575)
        (xy 56.255268 143.452679)
        (xy 56.167622 143.496569)
        (xy 55.920353 143.664613)
        (xy 55.917239 143.667397)
        (xy 55.917238 143.667398)
        (xy 55.850985 143.726635)
        (xy 55.69748 143.863883)
        (xy 55.502921 144.09088)
        (xy 55.500647 144.094382)
        (xy 55.349258 144.3275)
        (xy 55.340092 144.341614)
        (xy 55.338298 144.345392)
        (xy 55.338297 144.345394)
        (xy 55.322888 144.377846)
        (xy 55.211855 144.611681)
        (xy 55.210576 144.615664)
        (xy 55.210575 144.615667)
        (xy 55.184688 144.696295)
        (xy 55.120462 144.896336)
        (xy 55.119721 144.900455)
        (xy 55.071691 145.167398)
        (xy 55.06752 145.190578)
        (xy 55.067331 145.194745)
        (xy 55.06733 145.194752)
        (xy 55.055691 145.451066)
        (xy 22.91206 145.361096)
        (xy 22.855871 145.30084)
        (xy 22.855869 145.300838)
        (xy 22.853021 145.297784)
        (xy 22.622 145.108021)
        (xy 22.36791 144.950479)
        (xy 22.095217 144.827926)
        (xy 21.920973 144.775982)
        (xy 21.81271 144.743707)
        (xy 21.812708 144.743707)
        (xy 21.808711 144.742515)
        (xy 21.804591 144.741862)
        (xy 21.804589 144.741862)
        (xy 21.61971 144.71258)
        (xy 21.513425 144.695746)
        (xy 21.470865 144.693813)
        (xy 21.421341 144.691564)
        (xy 21.421322 144.691564)
        (xy 21.419922 144.6915)
        (xy 21.233166 144.6915)
        (xy 21.010691 144.706277)
        (xy 20.717623 144.76537)
        (xy 20.434944 144.862704)
        (xy 20.431211 144.864573)
        (xy 20.431207 144.864575)
        (xy 20.221717 144.96948)
        (xy 20.167622 144.996569)
        (xy 19.920353 145.164613)
        (xy 19.917239 145.167397)
        (xy 19.917238 145.167398)
        (xy 19.886644 145.194752)
        (xy 19.69748 145.363883)
        (xy 19.502921 145.59088)
        (xy 19.500647 145.594382)
        (xy 19.370888 145.794193)
        (xy 19.340092 145.841614)
        (xy 19.211855 146.111681)
        (xy 19.210576 146.115664)
        (xy 19.210575 146.115667)
        (xy 19.13358 146.355477)
        (xy 19.120462 146.396336)
        (xy 19.119721 146.400455)
        (xy 19.07241 146.663402)
        (xy 19.06752 146.690578)
        (xy 19.067331 146.694745)
        (xy 19.06733 146.694752)
        (xy 19.054147 146.985066)
        (xy 15.189373 141.723401)
        (xy 67.165214 141.723401)
        (xy 67.178186 141.94839)
        (xy 67.179323 141.953436)
        (xy 67.179324 141.953442)
        (xy 67.199392 142.042487)
        (xy 67.227732 142.16824)
        (xy 67.229674 142.173022)
        (xy 67.229675 142.173026)
        (xy 67.266309 142.263244)
        (xy 67.312519 142.377045)
        (xy 67.430271 142.569199)
        (xy 67.577825 142.739541)
        (xy 67.751219 142.883495)
        (xy 67.945797 142.997197)
        (xy 67.950622 142.999039)
        (xy 67.950623 142.99904)
        (xy 67.998716 143.017405)
        (xy 68.156332 143.077593)
        (xy 68.161398 143.078624)
        (xy 68.161399 143.078624)
        (xy 68.214429 143.089413)
        (xy 68.377171 143.122523)
        (xy 68.504303 143.127185)
        (xy 68.597219 143.130592)
        (xy 68.597223 143.130592)
        (xy 68.602383 143.130781)
        (xy 68.607503 143.130125)
        (xy 68.607505 143.130125)
        (xy 68.820793 143.102803)
        (xy 68.820796 143.102802)
        (xy 68.82592 143.102146)
        (xy 68.907759 143.077593)
        (xy 69.036824 143.038871)
        (xy 69.041777 143.037385)
        (xy 69.046416 143.035112)
        (xy 69.046422 143.03511)
        (xy 69.239522 142.940511)
        (xy 69.24416 142.938239)
        (xy 69.314724 142.887906)
        (xy 69.423419 142.810375)
        (xy 69.423424 142.810371)
        (xy 69.427631 142.80737)
        (xy 69.587265 142.648293)
        (xy 69.718774 142.465279)
        (xy 69.818626 142.263244)
        (xy 69.884139 142.047613)
        (xy 69.897202 141.94839)
        (xy 69.913118 141.8275)
        (xy 69.913119 141.827493)
        (xy 69.913555 141.824178)
        (xy 69.915197 141.757)
        (xy 69.907906 141.668321)
        (xy 69.897155 141.537546)
        (xy 69.897154 141.53754)
        (xy 69.896731 141.532395)
        (xy 69.841829 141.313821)
        (xy 69.751966 141.10715)
        (xy 69.629554 140.91793)
        (xy 69.477882 140.751245)
        (xy 69.473831 140.748046)
        (xy 69.473827 140.748042)
        (xy 69.30508 140.614774)
        (xy 69.301022 140.611569)
        (xy 69.103725 140.502655)
        (xy 68.926412 140.439865)
        (xy 68.896163 140.429153)
        (xy 68.896159 140.429152)
        (xy 68.891288 140.427427)
        (xy 68.886195 140.42652)
        (xy 68.886192 140.426519)
        (xy 68.674506 140.388812)
        (xy 68.6745 140.388811)
        (xy 68.669417 140.387906)
        (xy 68.595725 140.387006)
        (xy 68.449241 140.385216)
        (xy 68.449239 140.385216)
        (xy 68.444071 140.385153)
        (xy 68.221301 140.419242)
        (xy 68.00709 140.489257)
        (xy 68.002502 140.491645)
        (xy 68.002498 140.491647)
        (xy 67.811779 140.590929)
        (xy 67.80719 140.593318)
        (xy 67.803057 140.596421)
        (xy 67.803054 140.596423)
        (xy 67.631106 140.725525)
        (xy 67.626971 140.72863)
        (xy 67.471271 140.89156)
        (xy 67.344273 141.077733)
        (xy 67.249387 141.282147)
        (xy 67.189162 141.499314)
        (xy 15.189373 140.439865)
        (xy 62.542885 140.439865)
        (xy 62.549672 140.449565)
        (xy 62.622356 140.511643)
        (xy 62.630332 140.517438)
        (xy 62.829919 140.639745)
        (xy 62.838713 140.644226)
        (xy 63.05497 140.733802)
        (xy 63.064355 140.736851)
        (xy 63.291964 140.791496)
        (xy 63.301711 140.793039)
        (xy 63.53507 140.811405)
        (xy 63.54493 140.811405)
        (xy 63.778289 140.793039)
        (xy 63.788036 140.791496)
        (xy 64.015645 140.736851)
        (xy 64.02503 140.733802)
        (xy 64.241287 140.644226)
        (xy 64.250081 140.639745)
        (xy 64.449668 140.517438)
        (xy 64.457644 140.511643)
        (xy 64.528761 140.450904)
        (xy 64.537188 140.437994)
        (xy 64.531181 140.427786)
        (xy 63.552812 139.449417)
        (xy 63.538868 139.441803)
        (xy 63.537035 139.441934)
        (xy 63.53042 139.446185)
        (xy 62.550277 140.426328)
        (xy 15.189373 139.187996)
        (xy 57.804814 139.187996)
        (xy 57.814523 139.397767)
        (xy 57.815927 139.403592)
        (xy 57.815927 139.403593)
        (xy 57.840084 139.503826)
        (xy 57.863724 139.601918)
        (xy 57.866206 139.607376)
        (xy 57.866207 139.60738)
        (xy 57.90932 139.702201)
        (xy 57.95064 139.793081)
        (xy 58.072137 139.96436)
        (xy 58.223831 140.109575)
        (xy 58.228866 140.112826)
        (xy 58.395209 140.220233)
        (xy 58.395212 140.220234)
        (xy 58.400246 140.223485)
        (xy 58.405809 140.225727)
        (xy 58.589455 140.299739)
        (xy 58.589458 140.29974)
        (xy 58.595019 140.301981)
        (xy 58.6009 140.303129)
        (xy 58.600905 140.303131)
        (xy 58.796676 140.341362)
        (xy 58.796679 140.341362)
        (xy 58.801122 140.34223)
        (xy 58.806643 140.3425)
        (xy 59.761469 140.3425)
        (xy 59.918046 140.327561)
        (xy 59.923802 140.325872)
        (xy 59.923804 140.325872)
        (xy 60.012883 140.299739)
        (xy 60.119549 140.268447)
        (xy 60.219947 140.216739)
        (xy 60.300908 140.175041)
        (xy 60.300911 140.175039)
        (xy 60.306239 140.172295)
        (xy 60.381947 140.112826)
        (xy 60.466662 140.046282)
        (xy 60.466667 140.046278)
        (xy 60.471379 140.042576)
        (xy 60.475311 140.038045)
        (xy 60.605079 139.888502)
        (xy 60.605083 139.888497)
        (xy 60.60901 139.883971)
        (xy 60.714166 139.702201)
        (xy 60.783053 139.503826)
        (xy 60.798431 139.397767)
        (xy 60.812325 139.301944)
        (xy 60.812325 139.301941)
        (xy 60.813186 139.296004)
        (xy 60.811609 139.26193)
        (xy 61.985595 139.26193)
        (xy 62.003961 139.495289)
        (xy 62.005504 139.505036)
        (xy 62.060149 139.732645)
        (xy 62.063198 139.74203)
        (xy 62.152774 139.958287)
        (xy 62.157255 139.967081)
        (xy 62.279562 140.166668)
        (xy 62.285357 140.174644)
        (xy 62.346096 140.245761)
        (xy 62.359006 140.254188)
        (xy 62.369214 140.248181)
        (xy 63.347583 139.269812)
        (xy 63.353961 139.258132)
        (xy 63.724803 139.258132)
        (xy 63.724934 139.259965)
        (xy 63.729185 139.26658)
        (xy 64.709328 140.246723)
        (xy 64.722865 140.254115)
        (xy 64.732565 140.247328)
        (xy 64.794643 140.174644)
        (xy 64.800438 140.166668)
        (xy 64.922745 139.967081)
        (xy 64.927226 139.958287)
        (xy 65.016802 139.74203)
        (xy 65.019851 139.732645)
        (xy 65.074496 139.505036)
        (xy 65.076039 139.495289)
        (xy 65.094405 139.26193)
        (xy 65.094405 139.25207)
        (xy 65.076039 139.018711)
        (xy 65.074496 139.008964)
        (xy 65.019851 138.781355)
        (xy 65.016802 138.77197)
        (xy 64.927226 138.555713)
        (xy 64.922745 138.546919)
        (xy 64.800438 138.347332)
        (xy 64.794643 138.339356)
        (xy 64.733904 138.268239)
        (xy 64.720994 138.259812)
        (xy 64.710786 138.265819)
        (xy 63.732417 139.244188)
        (xy 63.355197 139.255868)
        (xy 63.355066 139.254035)
        (xy 63.350815 139.24742)
        (xy 62.370672 138.267277)
        (xy 62.357135 138.259885)
        (xy 62.347435 138.266672)
        (xy 62.285357 138.339356)
        (xy 62.279562 138.347332)
        (xy 62.157255 138.546919)
        (xy 62.152774 138.555713)
        (xy 62.063198 138.77197)
        (xy 62.060149 138.781355)
        (xy 62.005504 139.008964)
        (xy 62.003961 139.018711)
        (xy 61.985595 139.25207)
        (xy 60.803477 139.086233)
        (xy 60.754276 138.882082)
        (xy 60.711258 138.787467)
        (xy 60.66984 138.696374)
        (xy 60.66736 138.690919)
        (xy 60.545863 138.51964)
        (xy 60.394169 138.374425)
        (xy 60.297033 138.311705)
        (xy 60.222791 138.263767)
        (xy 60.222788 138.263766)
        (xy 60.217754 138.260515)
        (xy 60.212191 138.258273)
        (xy 60.028545 138.184261)
        (xy 60.028542 138.18426)
        (xy 60.022981 138.182019)
        (xy 60.0171 138.180871)
        (xy 60.017095 138.180869)
        (xy 59.821324 138.142638)
        (xy 59.821321 138.142638)
        (xy 59.816878 138.14177)
        (xy 59.811357 138.1415)
        (xy 58.856531 138.1415)
        (xy 58.699954 138.156439)
        (xy 58.694198 138.158128)
        (xy 58.694196 138.158128)
        (xy 58.616679 138.180869)
        (xy 58.498451 138.215553)
        (xy 58.411152 138.260515)
        (xy 58.317092 138.308959)
        (xy 58.317089 138.308961)
        (xy 58.311761 138.311705)
        (xy 58.307046 138.315409)
        (xy 58.151338 138.437718)
        (xy 58.151333 138.437722)
        (xy 58.146621 138.441424)
        (xy 58.14269 138.445954)
        (xy 58.142689 138.445955)
        (xy 58.012921 138.595498)
        (xy 58.012917 138.595503)
        (xy 58.00899 138.600029)
        (xy 57.903834 138.781799)
        (xy 57.834947 138.980174)
        (xy 57.834086 138.986109)
        (xy 57.834086 138.986111)
        (xy 57.818701 139.092223)
        (xy 15.189373 138.076006)
        (xy 62.542812 138.076006)
        (xy 62.548819 138.086214)
        (xy 63.527188 139.064583)
        (xy 63.541132 139.072197)
        (xy 63.542965 139.072066)
        (xy 63.54958 139.067815)
        (xy 64.529723 138.087672)
        (xy 64.537115 138.074135)
        (xy 64.530328 138.064435)
        (xy 64.457644 138.002357)
        (xy 64.449668 137.996562)
        (xy 64.250081 137.874255)
        (xy 64.241287 137.869774)
        (xy 64.02503 137.780198)
        (xy 64.015645 137.777149)
        (xy 63.788036 137.722504)
        (xy 63.778289 137.720961)
        (xy 63.54493 137.702595)
        (xy 63.53507 137.702595)
        (xy 63.301711 137.720961)
        (xy 63.291964 137.722504)
        (xy 63.064355 137.777149)
        (xy 63.05497 137.780198)
        (xy 62.838713 137.869774)
        (xy 62.829919 137.874255)
        (xy 62.630332 137.996562)
        (xy 62.622356 138.002357)
        (xy 62.551239 138.063096)
        (xy 15.189373 136.653076)
        (xy 57.802274 136.653076)
        (xy 57.811983 136.862847)
        (xy 57.813387 136.868672)
        (xy 57.813387 136.868673)
        (xy 57.837544 136.968906)
        (xy 57.861184 137.066998)
        (xy 57.863666 137.072456)
        (xy 57.863667 137.07246)
        (xy 57.90678 137.167281)
        (xy 57.9481 137.258161)
        (xy 58.069597 137.42944)
        (xy 58.221291 137.574655)
        (xy 58.226326 137.577906)
        (xy 58.392669 137.685313)
        (xy 58.392672 137.685314)
        (xy 58.397706 137.688565)
        (xy 58.403269 137.690807)
        (xy 58.586915 137.764819)
        (xy 58.586918 137.76482)
        (xy 58.592479 137.767061)
        (xy 58.59836 137.768209)
        (xy 58.598365 137.768211)
        (xy 58.794136 137.806442)
        (xy 58.794139 137.806442)
        (xy 58.798582 137.80731)
        (xy 58.804103 137.80758)
        (xy 59.758929 137.80758)
        (xy 59.915506 137.792641)
        (xy 59.921262 137.790952)
        (xy 59.921264 137.790952)
        (xy 60.010343 137.764819)
        (xy 60.117009 137.733527)
        (xy 60.217407 137.681819)
        (xy 60.298368 137.640121)
        (xy 60.298371 137.640119)
        (xy 60.303699 137.637375)
        (xy 60.379407 137.577906)
        (xy 60.464122 137.511362)
        (xy 60.464127 137.511358)
        (xy 60.468839 137.507656)
        (xy 60.472771 137.503125)
        (xy 60.602539 137.353582)
        (xy 60.602543 137.353577)
        (xy 60.60647 137.349051)
        (xy 60.711626 137.167281)
        (xy 60.780513 136.968906)
        (xy 60.795891 136.862847)
        (xy 60.809785 136.767024)
        (xy 60.809785 136.767021)
        (xy 60.810646 136.761084)
        (xy 60.800937 136.551313)
        (xy 60.751736 136.347162)
        (xy 60.708718 136.252547)
        (xy 60.6673 136.161454)
        (xy 60.66482 136.155999)
        (xy 60.543323 135.98472)
        (xy 60.391629 135.839505)
        (xy 60.294493 135.776785)
        (xy 60.220251 135.728847)
        (xy 60.220248 135.728846)
        (xy 60.215214 135.725595)
        (xy 60.209651 135.723353)
        (xy 60.026005 135.649341)
        (xy 60.026002 135.64934)
        (xy 60.020441 135.647099)
        (xy 60.01456 135.645951)
        (xy 60.014555 135.645949)
        (xy 59.818784 135.607718)
        (xy 59.818781 135.607718)
        (xy 59.814338 135.60685)
        (xy 59.808817 135.60658)
        (xy 58.853991 135.60658)
        (xy 58.697414 135.621519)
        (xy 58.691658 135.623208)
        (xy 58.691656 135.623208)
        (xy 58.614139 135.645949)
        (xy 58.495911 135.680633)
        (xy 58.412965 135.723353)
        (xy 58.314552 135.774039)
        (xy 58.314549 135.774041)
        (xy 58.309221 135.776785)
        (xy 58.304506 135.780489)
        (xy 58.148798 135.902798)
        (xy 58.148793 135.902802)
        (xy 58.144081 135.906504)
        (xy 58.14015 135.911034)
        (xy 58.140149 135.911035)
        (xy 58.010381 136.060578)
        (xy 58.010377 136.060583)
        (xy 58.00645 136.065109)
        (xy 57.901294 136.246879)
        (xy 57.832407 136.445254)
        (xy 57.831546 136.451189)
        (xy 57.831546 136.451191)
        (xy 57.816161 136.557303)
        (xy 15.189373 131.064)
        (xy 41.177318 131.064)
        (xy 41.197956 131.220762)
        (xy 41.258464 131.366841)
        (xy 41.354718 131.492282)
        (xy 41.480159 131.588536)
        (xy 41.626238 131.649044)
        (xy 41.671884 131.655053)
        (xy 41.73681 131.683775)
        (xy 41.775902 131.74304)
        (xy 41.776747 131.814031)
        (xy 41.771846 131.828193)
        (xy 41.746456 131.889491)
        (xy 41.724714 131.94198)
        (xy 41.704076 132.098742)
        (xy 41.724714 132.255504)
        (xy 41.785222 132.401583)
        (xy 41.881476 132.527024)
        (xy 42.006917 132.623278)
        (xy 42.152996 132.683786)
        (xy 42.161184 132.684864)
        (xy 42.183903 132.687855)
        (xy 42.24883 132.716578)
        (xy 42.287921 132.775843)
        (xy 42.288766 132.846835)
        (xy 42.283865 132.860995)
        (xy 42.251456 132.939238)
        (xy 42.230818 133.096)
        (xy 42.251456 133.252762)
        (xy 42.311964 133.398841)
        (xy 42.408218 133.524282)
        (xy 42.533659 133.620536)
        (xy 42.679738 133.681044)
        (xy 42.8365 133.701682)
        (xy 42.844688 133.700604)
        (xy 42.852946 133.700604)
        (xy 42.852946 133.703867)
        (xy 42.907962 133.71244)
        (xy 42.961067 133.759561)
        (xy 42.980265 133.827913)
        (xy 42.959462 133.895793)
        (xy 42.930979 133.926391)
        (xy 42.922765 133.932694)
        (xy 42.916218 133.937718)
        (xy 42.819964 134.063159)
        (xy 42.759456 134.209238)
        (xy 42.738818 134.366)
        (xy 42.759456 134.522762)
        (xy 42.819964 134.668841)
        (xy 42.916218 134.794282)
        (xy 43.041659 134.890536)
        (xy 43.187738 134.951044)
        (xy 43.3445 134.971682)
        (xy 43.352688 134.970604)
        (xy 43.493074 134.952122)
        (xy 43.501262 134.951044)
        (xy 43.647341 134.890536)
        (xy 43.772782 134.794282)
        (xy 43.813823 134.740796)
        (xy 43.871161 134.698929)
        (xy 43.913786 134.6915)
        (xy 47.054282 134.6915)
        (xy 47.122403 134.711502)
        (xy 47.170691 134.769282)
        (xy 47.227464 134.906344)
        (xy 47.323718 135.031785)
        (xy 47.449159 135.128039)
        (xy 47.595238 135.188547)
        (xy 47.752 135.209185)
        (xy 47.760188 135.208107)
        (xy 47.900574 135.189625)
        (xy 47.908762 135.188547)
        (xy 48.054841 135.128039)
        (xy 48.180282 135.031785)
        (xy 48.276536 134.906344)
        (xy 48.337044 134.760265)
        (xy 48.357682 134.603503)
        (xy 48.337044 134.446741)
        (xy 48.276536 134.300662)
        (xy 48.184299 134.180456)
        (xy 48.158699 134.114235)
        (xy 48.159979 134.107996)
        (xy 57.804814 134.107996)
        (xy 57.814523 134.317767)
        (xy 57.815927 134.323592)
        (xy 57.815927 134.323593)
        (xy 57.843768 134.439112)
        (xy 57.863724 134.521918)
        (xy 57.866206 134.527376)
        (xy 57.866207 134.52738)
        (xy 57.90932 134.622201)
        (xy 57.95064 134.713081)
        (xy 58.072137 134.88436)
        (xy 58.095102 134.906344)
        (xy 58.219302 135.025239)
        (xy 58.223831 135.029575)
        (xy 58.228866 135.032826)
        (xy 58.395209 135.140233)
        (xy 58.395212 135.140234)
        (xy 58.400246 135.143485)
        (xy 58.405809 135.145727)
        (xy 58.589455 135.219739)
        (xy 58.589458 135.21974)
        (xy 58.595019 135.221981)
        (xy 58.6009 135.223129)
        (xy 58.600905 135.223131)
        (xy 58.796676 135.261362)
        (xy 58.796679 135.261362)
        (xy 58.801122 135.26223)
        (xy 58.806643 135.2625)
        (xy 59.761469 135.2625)
        (xy 59.918046 135.247561)
        (xy 59.923802 135.245872)
        (xy 59.923804 135.245872)
        (xy 60.048859 135.209185)
        (xy 60.119549 135.188447)
        (xy 60.219947 135.136739)
        (xy 60.300908 135.095041)
        (xy 60.300911 135.095039)
        (xy 60.306239 135.092295)
        (xy 60.383272 135.031785)
        (xy 60.466662 134.966282)
        (xy 60.466667 134.966278)
        (xy 60.471379 134.962576)
        (xy 60.484128 134.947884)
        (xy 60.605079 134.808502)
        (xy 60.605083 134.808497)
        (xy 60.60901 134.803971)
        (xy 60.714166 134.622201)
        (xy 60.783053 134.423826)
        (xy 60.79025 134.374188)
        (xy 60.812325 134.221944)
        (xy 60.812325 134.221941)
        (xy 60.813186 134.216004)
        (xy 60.803477 134.006233)
        (xy 60.763006 133.838304)
        (xy 60.755682 133.807915)
        (xy 60.755681 133.807913)
        (xy 60.754276 133.802082)
        (xy 60.746108 133.784116)
        (xy 60.673169 133.623696)
        (xy 60.66736 133.610919)
        (xy 60.545863 133.43964)
        (xy 60.409174 133.308789)
        (xy 60.398499 133.29857)
        (xy 60.394169 133.294425)
        (xy 60.297033 133.231705)
        (xy 60.222791 133.183767)
        (xy 60.222788 133.183766)
        (xy 60.217754 133.180515)
        (xy 60.165838 133.159592)
        (xy 60.028545 133.104261)
        (xy 60.028542 133.10426)
        (xy 60.022981 133.102019)
        (xy 60.0171 133.100871)
        (xy 60.017095 133.100869)
        (xy 59.821324 133.062638)
        (xy 59.821321 133.062638)
        (xy 59.816878 133.06177)
        (xy 59.811357 133.0615)
        (xy 58.856531 133.0615)
        (xy 58.699954 133.076439)
        (xy 58.694198 133.078128)
        (xy 58.694196 133.078128)
        (xy 58.616679 133.100869)
        (xy 58.498451 133.135553)
        (xy 58.451777 133.159592)
        (xy 58.317092 133.228959)
        (xy 58.317089 133.228961)
        (xy 58.311761 133.231705)
        (xy 58.307046 133.235409)
        (xy 58.151338 133.357718)
        (xy 58.151333 133.357722)
        (xy 58.146621 133.361424)
        (xy 58.14269 133.365954)
        (xy 58.142689 133.365955)
        (xy 58.012921 133.515498)
        (xy 58.012917 133.515503)
        (xy 58.00899 133.520029)
        (xy 57.903834 133.701799)
        (xy 57.834947 133.900174)
        (xy 57.834086 133.906109)
        (xy 57.834086 133.906111)
        (xy 57.814601 134.0405)
        (xy 48.172964 134.044687)
        (xy 48.184299 134.027049)
        (xy 48.271507 133.913396)
        (xy 48.271509 133.913392)
        (xy 48.276536 133.906841)
        (xy 48.337044 133.760762)
        (xy 48.357682 133.604)
        (xy 48.337044 133.447238)
        (xy 48.276536 133.301159)
        (xy 48.271508 133.294606)
        (xy 48.271506 133.294603)
        (xy 48.218721 133.225812)
        (xy 48.19312 133.159592)
        (xy 48.207385 133.090043)
        (xy 48.241979 133.049145)
        (xy 48.299762 133.004807)
        (xy 48.306308 132.999784)
        (xy 48.402562 132.874343)
        (xy 48.46307 132.728264)
        (xy 48.464609 132.716578)
        (xy 48.479497 132.603485)
        (xy 48.483708 132.571502)
        (xy 48.46307 132.41474)
        (xy 48.402562 132.268661)
        (xy 48.310812 132.149089)
        (xy 48.285212 132.08287)
        (xy 48.299477 132.013321)
        (xy 48.310812 131.995682)
        (xy 48.358639 131.933352)
        (xy 48.403536 131.874841)
        (xy 48.464044 131.728762)
        (xy 48.484682 131.572)
        (xy 48.484155 131.567996)
        (xy 57.804814 131.567996)
        (xy 57.814523 131.777767)
        (xy 57.815927 131.783592)
        (xy 57.815927 131.783593)
        (xy 57.840084 131.883826)
        (xy 57.863724 131.981918)
        (xy 57.866206 131.987376)
        (xy 57.866207 131.98738)
        (xy 57.90932 132.082201)
        (xy 57.95064 132.173081)
        (xy 58.072137 132.34436)
        (xy 58.223831 132.489575)
        (xy 58.228866 132.492826)
        (xy 58.395209 132.600233)
        (xy 58.395212 132.600234)
        (xy 58.400246 132.603485)
        (xy 58.405809 132.605727)
        (xy 58.589455 132.679739)
        (xy 58.589458 132.67974)
        (xy 58.595019 132.681981)
        (xy 58.6009 132.683129)
        (xy 58.600905 132.683131)
        (xy 58.796676 132.721362)
        (xy 58.796679 132.721362)
        (xy 58.801122 132.72223)
        (xy 58.806643 132.7225)
        (xy 59.761469 132.7225)
        (xy 59.918046 132.707561)
        (xy 59.923802 132.705872)
        (xy 59.923804 132.705872)
        (xy 60.012883 132.679739)
        (xy 60.119549 132.648447)
        (xy 60.253049 132.57969)
        (xy 60.300908 132.555041)
        (xy 60.300911 132.555039)
        (xy 60.306239 132.552295)
        (xy 60.381947 132.492826)
        (xy 60.466662 132.426282)
        (xy 60.466667 132.426278)
        (xy 60.471379 132.422576)
        (xy 60.496217 132.393953)
        (xy 60.605079 132.268502)
        (xy 60.605083 132.268497)
        (xy 60.60901 132.263971)
        (xy 60.714166 132.082201)
        (xy 60.783053 131.883826)
        (xy 60.785462 131.867211)
        (xy 60.812325 131.681944)
        (xy 60.812325 131.681941)
        (xy 60.813186 131.676004)
        (xy 60.803477 131.466233)
        (xy 60.762571 131.2965)
        (xy 60.755682 131.267915)
        (xy 60.755681 131.267913)
        (xy 60.754276 131.262082)
        (xy 60.747512 131.247204)
        (xy 60.66984 131.076374)
        (xy 60.66736 131.070919)
        (xy 60.545863 130.89964)
        (xy 60.404637 130.764446)
        (xy 60.398499 130.75857)
        (xy 60.394169 130.754425)
        (xy 60.297033 130.691705)
        (xy 60.222791 130.643767)
        (xy 60.222788 130.643766)
        (xy 60.217754 130.640515)
        (xy 60.193378 130.630691)
        (xy 60.028545 130.564261)
        (xy 60.028542 130.56426)
        (xy 60.022981 130.562019)
        (xy 60.0171 130.560871)
        (xy 60.017095 130.560869)
        (xy 59.821324 130.522638)
        (xy 59.821321 130.522638)
        (xy 59.816878 130.52177)
        (xy 59.811357 130.5215)
        (xy 58.856531 130.5215)
        (xy 58.699954 130.536439)
        (xy 58.694198 130.538128)
        (xy 58.694196 130.538128)
        (xy 58.672507 130.544491)
        (xy 58.498451 130.595553)
        (xy 58.430227 130.630691)
        (xy 58.317092 130.688959)
        (xy 58.317089 130.688961)
        (xy 58.311761 130.691705)
        (xy 58.307046 130.695409)
        (xy 58.151338 130.817718)
        (xy 58.151333 130.817722)
        (xy 58.146621 130.821424)
        (xy 58.14269 130.825954)
        (xy 58.142689 130.825955)
        (xy 58.012921 130.975498)
        (xy 58.012917 130.975503)
        (xy 58.00899 130.980029)
        (xy 57.903834 131.161799)
        (xy 57.834947 131.360174)
        (xy 57.834086 131.366109)
        (xy 57.834086 131.366111)
        (xy 57.814981 131.497878)
        (xy 48.464044 131.415238)
        (xy 48.403536 131.269159)
        (xy 48.307282 131.143718)
        (xy 48.181841 131.047464)
        (xy 48.035762 130.986956)
        (xy 47.879 130.966318)
        (xy 47.722238 130.986956)
        (xy 47.576159 131.047464)
        (xy 47.450718 131.143718)
        (xy 47.385747 131.228391)
        (xy 47.371311 131.247204)
        (xy 47.313973 131.289071)
        (xy 47.271348 131.2965)
        (xy 43.044632 131.2965)
        (xy 42.976511 131.276498)
        (xy 42.955537 131.259596)
        (xy 42.543718 130.847778)
        (xy 42.536291 130.839673)
        (xy 42.519155 130.819251)
        (xy 42.512069 130.810806)
        (xy 42.50252 130.805293)
        (xy 42.479429 130.791961)
        (xy 42.470158 130.786055)
        (xy 42.448329 130.77077)
        (xy 42.439298 130.764446)
        (xy 42.428648 130.761592)
        (xy 42.42548 130.760115)
        (xy 42.422204 130.758923)
        (xy 42.412659 130.753412)
        (xy 42.378915 130.747462)
        (xy 42.375556 130.74687)
        (xy 42.364829 130.744492)
        (xy 42.328422 130.734736)
        (xy 42.328891 130.732988)
        (xy 42.274996 130.711909)
        (xy 42.252134 130.688958)
        (xy 42.211282 130.635718)
        (xy 42.085841 130.539464)
        (xy 41.939762 130.478956)
        (xy 41.783 130.458318)
        (xy 41.626238 130.478956)
        (xy 41.480159 130.539464)
        (xy 41.354718 130.635718)
        (xy 41.349695 130.642264)
        (xy 41.348542 130.643767)
        (xy 41.258464 130.761159)
        (xy 41.197956 130.907238)
        (xy 15.189373 129.027996)
        (xy 57.804814 129.027996)
        (xy 57.814523 129.237767)
        (xy 57.815927 129.243592)
        (xy 57.815927 129.243593)
        (xy 57.840084 129.343826)
        (xy 57.863724 129.441918)
        (xy 57.866206 129.447376)
        (xy 57.866207 129.44738)
        (xy 57.90932 129.542201)
        (xy 57.95064 129.633081)
        (xy 58.072137 129.80436)
        (xy 58.223831 129.949575)
        (xy 58.228866 129.952826)
        (xy 58.395209 130.060233)
        (xy 58.395212 130.060234)
        (xy 58.400246 130.063485)
        (xy 58.405809 130.065727)
        (xy 58.589455 130.139739)
        (xy 58.589458 130.13974)
        (xy 58.595019 130.141981)
        (xy 58.6009 130.143129)
        (xy 58.600905 130.143131)
        (xy 58.796676 130.181362)
        (xy 58.796679 130.181362)
        (xy 58.801122 130.18223)
        (xy 58.806643 130.1825)
        (xy 59.761469 130.1825)
        (xy 59.918046 130.167561)
        (xy 59.923802 130.165872)
        (xy 59.923804 130.165872)
        (xy 60.012883 130.139739)
        (xy 60.119549 130.108447)
        (xy 60.219947 130.056739)
        (xy 60.300908 130.015041)
        (xy 60.300911 130.015039)
        (xy 60.306239 130.012295)
        (xy 60.381947 129.952826)
        (xy 60.466662 129.886282)
        (xy 60.466667 129.886278)
        (xy 60.471379 129.882576)
        (xy 60.475311 129.878045)
        (xy 60.605079 129.728502)
        (xy 60.605083 129.728497)
        (xy 60.60901 129.723971)
        (xy 60.714166 129.542201)
        (xy 60.783053 129.343826)
        (xy 60.798431 129.237767)
        (xy 60.812325 129.141944)
        (xy 60.812325 129.141941)
        (xy 60.813186 129.136004)
        (xy 60.803477 128.926233)
        (xy 60.760019 128.74591)
        (xy 77.416 128.74591)
        (xy 77.41667 128.75507)
        (xy 77.425569 128.815518)
        (xy 77.431311 128.833998)
        (xy 77.478162 128.92942)
        (xy 77.490118 128.94612)
        (xy 77.564914 129.020785)
        (xy 77.581637 129.032714)
        (xy 77.67715 129.079403)
        (xy 77.695615 129.08511)
        (xy 77.755469 129.093841)
        (xy 77.764544 129.0945)
        (xy 78.650885 129.0945)
        (xy 78.666124 129.090025)
        (xy 78.667329 129.088635)
        (xy 78.669 129.080952)
        (xy 78.669 129.076385)
        (xy 78.923 129.076385)
        (xy 78.927475 129.091624)
        (xy 78.928865 129.092829)
        (xy 78.936548 129.0945)
        (xy 79.82741 129.0945)
        (xy 79.83657 129.09383)
        (xy 79.897018 129.084931)
        (xy 79.915498 129.079189)
        (xy 80.01092 129.032338)
        (xy 80.02762 129.020382)
        (xy 80.102285 128.945586)
        (xy 80.114214 128.928863)
        (xy 80.160903 128.83335)
        (xy 80.16661 128.814885)
        (xy 80.175341 128.755031)
        (xy 80.176 128.745956)
        (xy 80.176 127.907115)
        (xy 80.171525 127.891876)
        (xy 80.170135 127.890671)
        (xy 80.162452 127.889)
        (xy 78.941115 127.889)
        (xy 78.925876 127.893475)
        (xy 78.924671 127.894865)
        (xy 78.923 127.902548)
        (xy 78.669 127.907115)
        (xy 78.664525 127.891876)
        (xy 78.663135 127.890671)
        (xy 78.655452 127.889)
        (xy 77.434115 127.889)
        (xy 77.418876 127.893475)
        (xy 77.417671 127.894865)
        (xy 77.416 127.902548)
        (xy 60.754276 128.722082)
        (xy 60.711258 128.627467)
        (xy 60.66984 128.536374)
        (xy 60.66736 128.530919)
        (xy 60.545863 128.35964)
        (xy 60.394169 128.214425)
        (xy 60.297033 128.151705)
        (xy 60.222791 128.103767)
        (xy 60.222788 128.103766)
        (xy 60.217754 128.100515)
        (xy 60.212191 128.098273)
        (xy 60.028545 128.024261)
        (xy 60.028542 128.02426)
        (xy 60.022981 128.022019)
        (xy 60.0171 128.020871)
        (xy 60.017095 128.020869)
        (xy 59.821324 127.982638)
        (xy 59.821321 127.982638)
        (xy 59.816878 127.98177)
        (xy 59.811357 127.9815)
        (xy 58.856531 127.9815)
        (xy 58.699954 127.996439)
        (xy 58.694198 127.998128)
        (xy 58.694196 127.998128)
        (xy 58.616679 128.020869)
        (xy 58.498451 128.055553)
        (xy 58.415505 128.098273)
        (xy 58.317092 128.148959)
        (xy 58.317089 128.148961)
        (xy 58.311761 128.151705)
        (xy 58.307046 128.155409)
        (xy 58.151338 128.277718)
        (xy 58.151333 128.277722)
        (xy 58.146621 128.281424)
        (xy 58.14269 128.285954)
        (xy 58.142689 128.285955)
        (xy 58.012921 128.435498)
        (xy 58.012917 128.435503)
        (xy 58.00899 128.440029)
        (xy 57.903834 128.621799)
        (xy 57.834947 128.820174)
        (xy 57.834086 128.826109)
        (xy 57.834086 128.826111)
        (xy 57.80586 129.020785)
        (xy 15.189373 126.487996)
        (xy 57.804814 126.487996)
        (xy 57.814523 126.697767)
        (xy 57.815927 126.703592)
        (xy 57.815927 126.703593)
        (xy 57.840084 126.803826)
        (xy 57.863724 126.901918)
        (xy 57.866206 126.907376)
        (xy 57.866207 126.90738)
        (xy 57.90932 127.002201)
        (xy 57.95064 127.093081)
        (xy 58.072137 127.26436)
        (xy 58.223831 127.409575)
        (xy 58.228866 127.412826)
        (xy 58.395209 127.520233)
        (xy 58.395212 127.520234)
        (xy 58.400246 127.523485)
        (xy 58.405809 127.525727)
        (xy 58.589455 127.599739)
        (xy 58.589458 127.59974)
        (xy 58.595019 127.601981)
        (xy 58.6009 127.603129)
        (xy 58.600905 127.603131)
        (xy 58.796676 127.641362)
        (xy 58.796679 127.641362)
        (xy 58.801122 127.64223)
        (xy 58.806643 127.6425)
        (xy 59.761469 127.6425)
        (xy 59.918046 127.627561)
        (xy 59.923802 127.625872)
        (xy 59.923804 127.625872)
        (xy 59.954438 127.616885)
        (xy 77.416 127.616885)
        (xy 77.420475 127.632124)
        (xy 77.421865 127.633329)
        (xy 77.429548 127.635)
        (xy 80.157885 127.635)
        (xy 80.173124 127.630525)
        (xy 80.174329 127.629135)
        (xy 80.176 127.621452)
        (xy 80.176 126.77809)
        (xy 80.17533 126.76893)
        (xy 80.166431 126.708482)
        (xy 80.160689 126.690002)
        (xy 80.113838 126.59458)
        (xy 80.101882 126.57788)
        (xy 80.027086 126.503215)
        (xy 80.010363 126.491286)
        (xy 79.91485 126.444597)
        (xy 79.896385 126.43889)
        (xy 79.836531 126.430159)
        (xy 79.827456 126.4295)
        (xy 79.532969 126.4295)
        (xy 79.464848 126.409498)
        (xy 79.418355 126.355842)
        (xy 79.408251 126.285568)
        (xy 79.437745 126.220988)
        (xy 79.45758 126.202542)
        (xy 79.613689 126.08597)
        (xy 79.61369 126.085969)
        (xy 79.618313 126.082517)
        (xy 79.762156 125.926909)
        (xy 79.875232 125.747694)
        (xy 79.953756 125.550873)
        (xy 79.95956 125.521697)
        (xy 79.99397 125.348705)
        (xy 79.99397 125.348702)
        (xy 79.995097 125.343038)
        (xy 79.995418 125.318549)
        (xy 79.997794 125.136931)
        (xy 79.99787 125.131149)
        (xy 79.99009 125.085872)
        (xy 79.962962 124.927993)
        (xy 79.962961 124.92799)
        (xy 79.961984 124.922303)
        (xy 79.88864 124.723494)
        (xy 79.790162 124.557968)
        (xy 79.783249 124.546348)
        (xy 79.783247 124.546345)
        (xy 79.780293 124.54138)
        (xy 79.640573 124.38206)
        (xy 79.636037 124.378484)
        (xy 79.478698 124.254448)
        (xy 79.478696 124.254447)
        (xy 79.474159 124.25087)
        (xy 79.469043 124.248179)
        (xy 79.469041 124.248177)
        (xy 79.291741 124.154895)
        (xy 79.291739 124.154894)
        (xy 79.286624 124.152203)
        (xy 79.084249 124.089364)
        (xy 78.98318 124.077402)
        (xy 78.917883 124.049532)
        (xy 78.878019 123.990783)
        (xy 78.876245 123.919809)
        (xy 78.913124 123.859142)
        (xy 78.976947 123.828045)
        (xy 78.98646 123.826804)
        (xy 79.048762 123.821079)
        (xy 79.048763 123.821079)
        (xy 79.054518 123.82055)
        (xy 79.06008 123.818981)
        (xy 79.060082 123.818981)
        (xy 79.156494 123.79179)
        (xy 79.258469 123.76303)
        (xy 79.448522 123.669306)
        (xy 79.48498 123.642082)
        (xy 79.613689 123.54597)
        (xy 79.61369 123.545969)
        (xy 79.618313 123.542517)
        (xy 79.762156 123.386909)
        (xy 79.875232 123.207694)
        (xy 79.953756 123.010873)
        (xy 79.95956 122.981697)
        (xy 79.99397 122.808705)
        (xy 79.99397 122.808702)
        (xy 79.995097 122.803038)
        (xy 79.995418 122.778549)
        (xy 79.997794 122.596931)
        (xy 79.99787 122.591149)
        (xy 79.99009 122.545872)
        (xy 79.962962 122.387993)
        (xy 79.962961 122.38799)
        (xy 79.961984 122.382303)
        (xy 79.88864 122.183494)
        (xy 79.790162 122.017968)
        (xy 79.783249 122.006348)
        (xy 79.783247 122.006345)
        (xy 79.780293 122.00138)
        (xy 79.640573 121.84206)
        (xy 79.636037 121.838484)
        (xy 79.478698 121.714448)
        (xy 79.478696 121.714447)
        (xy 79.474159 121.71087)
        (xy 79.469043 121.708179)
        (xy 79.469041 121.708177)
        (xy 79.291741 121.614895)
        (xy 79.291739 121.614894)
        (xy 79.286624 121.612203)
        (xy 79.084249 121.549364)
        (xy 79.070159 121.547696)
        (xy 78.915882 121.529436)
        (xy 78.915875 121.529436)
        (xy 78.912195 121.529)
        (xy 78.694739 121.529)
        (xy 78.537482 121.54345)
        (xy 78.53192 121.545019)
        (xy 78.531918 121.545019)
        (xy 78.435506 121.57221)
        (xy 78.333531 121.60097)
        (xy 78.143478 121.694694)
        (xy 78.138852 121.698148)
        (xy 78.138851 121.698149)
        (xy 78.096879 121.729491)
        (xy 77.973687 121.821483)
        (xy 77.829844 121.977091)
        (xy 77.716768 122.156306)
        (xy 77.638244 122.353127)
        (xy 77.637118 122.358787)
        (xy 77.637117 122.358791)
        (xy 77.599455 122.548131)
        (xy 77.596903 122.560962)
        (xy 77.596827 122.566737)
        (xy 77.596827 122.566741)
        (xy 77.596508 122.591149)
        (xy 77.59413 122.772851)
        (xy 77.595109 122.778548)
        (xy 77.595109 122.778549)
        (xy 77.628671 122.973867)
        (xy 77.630016 122.981697)
        (xy 77.70336 123.180506)
        (xy 77.811707 123.36262)
        (xy 77.951427 123.52194)
        (xy 77.955962 123.525515)
        (xy 77.955963 123.525516)
        (xy 78.111226 123.647915)
        (xy 78.117841 123.65313)
        (xy 78.122957 123.655821)
        (xy 78.122959 123.655823)
        (xy 78.300259 123.749105)
        (xy 78.305376 123.751797)
        (xy 78.507751 123.814636)
        (xy 78.60882 123.826598)
        (xy 78.674117 123.854468)
        (xy 78.713981 123.913217)
        (xy 78.715755 123.984191)
        (xy 78.678876 124.044858)
        (xy 78.615053 124.075955)
        (xy 78.60554 124.077196)
        (xy 78.543238 124.082921)
        (xy 78.543237 124.082921)
        (xy 78.537482 124.08345)
        (xy 78.53192 124.085019)
        (xy 78.531918 124.085019)
        (xy 78.435507 124.11221)
        (xy 78.333531 124.14097)
        (xy 78.143478 124.234694)
        (xy 78.138852 124.238148)
        (xy 78.138851 124.238149)
        (xy 78.096879 124.269491)
        (xy 77.973687 124.361483)
        (xy 77.829844 124.517091)
        (xy 77.716768 124.696306)
        (xy 77.638244 124.893127)
        (xy 77.637118 124.898787)
        (xy 77.637117 124.898791)
        (xy 77.599455 125.088131)
        (xy 77.596903 125.100962)
        (xy 77.596827 125.106737)
        (xy 77.596827 125.106741)
        (xy 77.596508 125.131149)
        (xy 77.59413 125.312851)
        (xy 77.595109 125.318548)
        (xy 77.595109 125.318549)
        (xy 77.628671 125.513867)
        (xy 77.630016 125.521697)
        (xy 77.70336 125.720506)
        (xy 77.811707 125.90262)
        (xy 77.951427 126.06194)
        (xy 77.955962 126.065515)
        (xy 77.955963 126.065516)
        (xy 78.113299 126.18955)
        (xy 78.113303 126.189553)
        (xy 78.117841 126.19313)
        (xy 78.122963 126.195825)
        (xy 78.126042 126.197824)
        (xy 78.172281 126.251699)
        (xy 78.182054 126.322019)
        (xy 78.152256 126.38646)
        (xy 78.09235 126.424562)
        (xy 78.057422 126.4295)
        (xy 77.76459 126.4295)
        (xy 77.75543 126.43017)
        (xy 77.694982 126.439069)
        (xy 77.676502 126.444811)
        (xy 77.58108 126.491662)
        (xy 77.56438 126.503618)
        (xy 77.489715 126.578414)
        (xy 77.477786 126.595137)
        (xy 77.431097 126.69065)
        (xy 77.42539 126.709115)
        (xy 77.416659 126.768969)
        (xy 77.416 126.778044)
        (xy 60.012883 127.599739)
        (xy 60.119549 127.568447)
        (xy 60.219947 127.516739)
        (xy 60.300908 127.475041)
        (xy 60.300911 127.475039)
        (xy 60.306239 127.472295)
        (xy 60.381947 127.412826)
        (xy 60.466662 127.346282)
        (xy 60.466667 127.346278)
        (xy 60.471379 127.342576)
        (xy 60.475311 127.338045)
        (xy 60.605079 127.188502)
        (xy 60.605083 127.188497)
        (xy 60.60901 127.183971)
        (xy 60.714166 127.002201)
        (xy 60.783053 126.803826)
        (xy 60.796786 126.709115)
        (xy 60.812325 126.601944)
        (xy 60.812325 126.601941)
        (xy 60.813186 126.596004)
        (xy 60.803477 126.386233)
        (xy 60.771054 126.251699)
        (xy 60.755682 126.187915)
        (xy 60.755681 126.187913)
        (xy 60.754276 126.182082)
        (xy 60.711258 126.087467)
        (xy 60.66984 125.996374)
        (xy 60.66736 125.990919)
        (xy 60.545863 125.81964)
        (xy 60.394169 125.674425)
        (xy 60.297033 125.611705)
        (xy 60.222791 125.563767)
        (xy 60.222788 125.563766)
        (xy 60.217754 125.560515)
        (xy 60.212191 125.558273)
        (xy 60.028545 125.484261)
        (xy 60.028542 125.48426)
        (xy 60.022981 125.482019)
        (xy 60.0171 125.480871)
        (xy 60.017095 125.480869)
        (xy 59.821324 125.442638)
        (xy 59.821321 125.442638)
        (xy 59.816878 125.44177)
        (xy 59.811357 125.4415)
        (xy 58.856531 125.4415)
        (xy 58.699954 125.456439)
        (xy 58.694198 125.458128)
        (xy 58.694196 125.458128)
        (xy 58.616679 125.480869)
        (xy 58.498451 125.515553)
        (xy 58.415505 125.558273)
        (xy 58.317092 125.608959)
        (xy 58.317089 125.608961)
        (xy 58.311761 125.611705)
        (xy 58.307046 125.615409)
        (xy 58.151338 125.737718)
        (xy 58.151333 125.737722)
        (xy 58.146621 125.741424)
        (xy 58.14269 125.745954)
        (xy 58.142689 125.745955)
        (xy 58.012921 125.895498)
        (xy 58.012917 125.895503)
        (xy 58.00899 125.900029)
        (xy 57.903834 126.081799)
        (xy 57.834947 126.280174)
        (xy 57.834086 126.286109)
        (xy 57.834086 126.286111)
        (xy 57.811076 126.444811)
        (xy 15.189373 123.947996)
        (xy 57.804814 123.947996)
        (xy 57.814523 124.157767)
        (xy 57.815927 124.163592)
        (xy 57.815927 124.163593)
        (xy 57.840084 124.263826)
        (xy 57.863724 124.361918)
        (xy 57.866206 124.367376)
        (xy 57.866207 124.36738)
        (xy 57.90932 124.462201)
        (xy 57.95064 124.553081)
        (xy 58.072137 124.72436)
        (xy 58.223831 124.869575)
        (xy 58.228866 124.872826)
        (xy 58.395209 124.980233)
        (xy 58.395212 124.980234)
        (xy 58.400246 124.983485)
        (xy 58.405809 124.985727)
        (xy 58.589455 125.059739)
        (xy 58.589458 125.05974)
        (xy 58.595019 125.061981)
        (xy 58.6009 125.063129)
        (xy 58.600905 125.063131)
        (xy 58.796676 125.101362)
        (xy 58.796679 125.101362)
        (xy 58.801122 125.10223)
        (xy 58.806643 125.1025)
        (xy 59.761469 125.1025)
        (xy 59.918046 125.087561)
        (xy 59.923802 125.085872)
        (xy 59.923804 125.085872)
        (xy 60.012883 125.059739)
        (xy 60.119549 125.028447)
        (xy 60.219947 124.976739)
        (xy 60.300908 124.935041)
        (xy 60.300911 124.935039)
        (xy 60.306239 124.932295)
        (xy 60.381947 124.872826)
        (xy 60.466662 124.806282)
        (xy 60.466667 124.806278)
        (xy 60.471379 124.802576)
        (xy 60.535301 124.728913)
        (xy 60.605079 124.648502)
        (xy 60.605083 124.648497)
        (xy 60.60901 124.643971)
        (xy 60.714166 124.462201)
        (xy 60.783053 124.263826)
        (xy 60.787277 124.234694)
        (xy 60.812325 124.061944)
        (xy 60.812325 124.061941)
        (xy 60.813186 124.056004)
        (xy 60.803477 123.846233)
        (xy 60.760837 123.669306)
        (xy 60.755682 123.647915)
        (xy 60.755681 123.647913)
        (xy 60.754276 123.642082)
        (xy 60.711258 123.547467)
        (xy 60.66984 123.456374)
        (xy 60.66736 123.450919)
        (xy 60.545863 123.27964)
        (xy 60.394169 123.134425)
        (xy 60.297033 123.071705)
        (xy 60.222791 123.023767)
        (xy 60.222788 123.023766)
        (xy 60.217754 123.020515)
        (xy 60.212191 123.018273)
        (xy 60.028545 122.944261)
        (xy 60.028542 122.94426)
        (xy 60.022981 122.942019)
        (xy 60.0171 122.940871)
        (xy 60.017095 122.940869)
        (xy 59.821324 122.902638)
        (xy 59.821321 122.902638)
        (xy 59.816878 122.90177)
        (xy 59.811357 122.9015)
        (xy 58.856531 122.9015)
        (xy 58.699954 122.916439)
        (xy 58.694198 122.918128)
        (xy 58.694196 122.918128)
        (xy 58.616679 122.940869)
        (xy 58.498451 122.975553)
        (xy 58.415505 123.018273)
        (xy 58.317092 123.068959)
        (xy 58.317089 123.068961)
        (xy 58.311761 123.071705)
        (xy 58.307046 123.075409)
        (xy 58.151338 123.197718)
        (xy 58.151333 123.197722)
        (xy 58.146621 123.201424)
        (xy 58.14269 123.205954)
        (xy 58.142689 123.205955)
        (xy 58.012921 123.355498)
        (xy 58.012917 123.355503)
        (xy 58.00899 123.360029)
        (xy 57.903834 123.541799)
        (xy 57.834947 123.740174)
        (xy 57.834086 123.746109)
        (xy 57.834086 123.746111)
        (xy 57.818701 123.852223)
        (xy 15.189373 121.407996)
        (xy 57.804814 121.407996)
        (xy 57.814523 121.617767)
        (xy 57.815927 121.623592)
        (xy 57.815927 121.623593)
        (xy 57.840084 121.723826)
        (xy 57.863724 121.821918)
        (xy 57.866206 121.827376)
        (xy 57.866207 121.82738)
        (xy 57.90932 121.922201)
        (xy 57.95064 122.013081)
        (xy 58.072137 122.18436)
        (xy 58.223831 122.329575)
        (xy 58.228866 122.332826)
        (xy 58.395209 122.440233)
        (xy 58.395212 122.440234)
        (xy 58.400246 122.443485)
        (xy 58.405809 122.445727)
        (xy 58.589455 122.519739)
        (xy 58.589458 122.51974)
        (xy 58.595019 122.521981)
        (xy 58.6009 122.523129)
        (xy 58.600905 122.523131)
        (xy 58.796676 122.561362)
        (xy 58.796679 122.561362)
        (xy 58.801122 122.56223)
        (xy 58.806643 122.5625)
        (xy 59.761469 122.5625)
        (xy 59.918046 122.547561)
        (xy 59.923802 122.545872)
        (xy 59.923804 122.545872)
        (xy 60.012883 122.519739)
        (xy 60.119549 122.488447)
        (xy 60.219947 122.436739)
        (xy 60.300908 122.395041)
        (xy 60.300911 122.395039)
        (xy 60.306239 122.392295)
        (xy 60.381947 122.332826)
        (xy 60.466662 122.266282)
        (xy 60.466667 122.266278)
        (xy 60.471379 122.262576)
        (xy 60.535301 122.188913)
        (xy 60.605079 122.108502)
        (xy 60.605083 122.108497)
        (xy 60.60901 122.103971)
        (xy 60.714166 121.922201)
        (xy 60.783053 121.723826)
        (xy 60.787277 121.694694)
        (xy 60.812325 121.521944)
        (xy 60.812325 121.521941)
        (xy 60.813186 121.516004)
        (xy 60.803477 121.306233)
        (xy 60.754276 121.102082)
        (xy 60.711258 121.007467)
        (xy 60.66984 120.916374)
        (xy 60.66736 120.910919)
        (xy 60.545863 120.73964)
        (xy 60.394169 120.594425)
        (xy 60.297033 120.531705)
        (xy 60.222791 120.483767)
        (xy 60.222788 120.483766)
        (xy 60.217754 120.480515)
        (xy 60.212191 120.478273)
        (xy 60.028545 120.404261)
        (xy 60.028542 120.40426)
        (xy 60.022981 120.402019)
        (xy 60.0171 120.400871)
        (xy 60.017095 120.400869)
        (xy 59.821324 120.362638)
        (xy 59.821321 120.362638)
        (xy 59.816878 120.36177)
        (xy 59.811357 120.3615)
        (xy 58.856531 120.3615)
        (xy 58.699954 120.376439)
        (xy 58.694198 120.378128)
        (xy 58.694196 120.378128)
        (xy 58.616679 120.400869)
        (xy 58.498451 120.435553)
        (xy 58.415505 120.478273)
        (xy 58.317092 120.528959)
        (xy 58.317089 120.528961)
        (xy 58.311761 120.531705)
        (xy 58.307046 120.535409)
        (xy 58.151338 120.657718)
        (xy 58.151333 120.657722)
        (xy 58.146621 120.661424)
        (xy 58.14269 120.665954)
        (xy 58.142689 120.665955)
        (xy 58.012921 120.815498)
        (xy 58.012917 120.815503)
        (xy 58.00899 120.820029)
        (xy 57.903834 121.001799)
        (xy 57.834947 121.200174)
        (xy 57.834086 121.206109)
        (xy 57.834086 121.206111)
        (xy 57.818701 121.312223)
        (xy 15.189373 118.867996)
        (xy 57.804814 118.867996)
        (xy 57.814523 119.077767)
        (xy 57.815927 119.083592)
        (xy 57.815927 119.083593)
        (xy 57.840084 119.183826)
        (xy 57.863724 119.281918)
        (xy 57.866206 119.287376)
        (xy 57.866207 119.28738)
        (xy 57.90932 119.382201)
        (xy 57.95064 119.473081)
        (xy 58.072137 119.64436)
        (xy 58.223831 119.789575)
        (xy 58.228866 119.792826)
        (xy 58.395209 119.900233)
        (xy 58.395212 119.900234)
        (xy 58.400246 119.903485)
        (xy 58.405809 119.905727)
        (xy 58.589455 119.979739)
        (xy 58.589458 119.97974)
        (xy 58.595019 119.981981)
        (xy 58.6009 119.983129)
        (xy 58.600905 119.983131)
        (xy 58.796676 120.021362)
        (xy 58.796679 120.021362)
        (xy 58.801122 120.02223)
        (xy 58.806643 120.0225)
        (xy 59.761469 120.0225)
        (xy 59.918046 120.007561)
        (xy 59.923802 120.005872)
        (xy 59.923804 120.005872)
        (xy 60.012883 119.979739)
        (xy 60.119549 119.948447)
        (xy 60.219947 119.896739)
        (xy 60.300908 119.855041)
        (xy 60.300911 119.855039)
        (xy 60.306239 119.852295)
        (xy 60.381947 119.792826)
        (xy 60.466662 119.726282)
        (xy 60.466667 119.726278)
        (xy 60.471379 119.722576)
        (xy 60.475311 119.718045)
        (xy 60.605079 119.568502)
        (xy 60.605083 119.568497)
        (xy 60.60901 119.563971)
        (xy 60.714166 119.382201)
        (xy 60.783053 119.183826)
        (xy 60.798431 119.077767)
        (xy 60.812325 118.981944)
        (xy 60.812325 118.981941)
        (xy 60.813186 118.976004)
        (xy 60.803477 118.766233)
        (xy 60.754276 118.562082)
        (xy 60.711258 118.467467)
        (xy 60.66984 118.376374)
        (xy 60.66736 118.370919)
        (xy 60.545863 118.19964)
        (xy 60.394169 118.054425)
        (xy 60.297033 117.991705)
        (xy 60.222791 117.943767)
        (xy 60.222788 117.943766)
        (xy 60.217754 117.940515)
        (xy 60.212191 117.938273)
        (xy 60.028545 117.864261)
        (xy 60.028542 117.86426)
        (xy 60.022981 117.862019)
        (xy 60.0171 117.860871)
        (xy 60.017095 117.860869)
        (xy 59.821324 117.822638)
        (xy 59.821321 117.822638)
        (xy 59.816878 117.82177)
        (xy 59.811357 117.8215)
        (xy 58.856531 117.8215)
        (xy 58.699954 117.836439)
        (xy 58.694198 117.838128)
        (xy 58.694196 117.838128)
        (xy 58.616679 117.860869)
        (xy 58.498451 117.895553)
        (xy 58.415505 117.938273)
        (xy 58.317092 117.988959)
        (xy 58.317089 117.988961)
        (xy 58.311761 117.991705)
        (xy 58.307046 117.995409)
        (xy 58.151338 118.117718)
        (xy 58.151333 118.117722)
        (xy 58.146621 118.121424)
        (xy 58.14269 118.125954)
        (xy 58.142689 118.125955)
        (xy 58.012921 118.275498)
        (xy 58.012917 118.275503)
        (xy 58.00899 118.280029)
        (xy 57.903834 118.461799)
        (xy 57.834947 118.660174)
        (xy 57.834086 118.666109)
        (xy 57.834086 118.666111)
        (xy 57.818701 118.772223)
        (xy 15.189373 116.327996)
        (xy 57.804814 116.327996)
        (xy 57.814523 116.537767)
        (xy 57.815927 116.543592)
        (xy 57.815927 116.543593)
        (xy 57.840084 116.643826)
        (xy 57.863724 116.741918)
        (xy 57.866206 116.747376)
        (xy 57.866207 116.74738)
        (xy 57.90932 116.842201)
        (xy 57.95064 116.933081)
        (xy 58.072137 117.10436)
        (xy 58.223831 117.249575)
        (xy 58.228866 117.252826)
        (xy 58.395209 117.360233)
        (xy 58.395212 117.360234)
        (xy 58.400246 117.363485)
        (xy 58.405809 117.365727)
        (xy 58.589455 117.439739)
        (xy 58.589458 117.43974)
        (xy 58.595019 117.441981)
        (xy 58.6009 117.443129)
        (xy 58.600905 117.443131)
        (xy 58.796676 117.481362)
        (xy 58.796679 117.481362)
        (xy 58.801122 117.48223)
        (xy 58.806643 117.4825)
        (xy 59.761469 117.4825)
        (xy 59.918046 117.467561)
        (xy 59.923802 117.465872)
        (xy 59.923804 117.465872)
        (xy 60.012883 117.439739)
        (xy 60.119549 117.408447)
        (xy 60.219947 117.356739)
        (xy 60.300908 117.315041)
        (xy 60.300911 117.315039)
        (xy 60.306239 117.312295)
        (xy 60.381947 117.252826)
        (xy 60.466662 117.186282)
        (xy 60.466667 117.186278)
        (xy 60.471379 117.182576)
        (xy 60.475311 117.178045)
        (xy 60.605079 117.028502)
        (xy 60.605083 117.028497)
        (xy 60.60901 117.023971)
        (xy 60.714166 116.842201)
        (xy 60.783053 116.643826)
        (xy 60.798431 116.537767)
        (xy 60.812325 116.441944)
        (xy 60.812325 116.441941)
        (xy 60.813186 116.436004)
        (xy 60.803477 116.226233)
        (xy 60.754276 116.022082)
        (xy 60.711258 115.927467)
        (xy 60.66984 115.836374)
        (xy 60.66736 115.830919)
        (xy 60.545863 115.65964)
        (xy 60.394169 115.514425)
        (xy 60.297033 115.451705)
        (xy 60.222791 115.403767)
        (xy 60.222788 115.403766)
        (xy 60.217754 115.400515)
        (xy 60.212191 115.398273)
        (xy 60.028545 115.324261)
        (xy 60.028542 115.32426)
        (xy 60.022981 115.322019)
        (xy 60.0171 115.320871)
        (xy 60.017095 115.320869)
        (xy 59.821324 115.282638)
        (xy 59.821321 115.282638)
        (xy 59.816878 115.28177)
        (xy 59.811357 115.2815)
        (xy 58.856531 115.2815)
        (xy 58.699954 115.296439)
        (xy 58.694198 115.298128)
        (xy 58.694196 115.298128)
        (xy 58.616679 115.320869)
        (xy 58.498451 115.355553)
        (xy 58.415505 115.398273)
        (xy 58.317092 115.448959)
        (xy 58.317089 115.448961)
        (xy 58.311761 115.451705)
        (xy 58.307046 115.455409)
        (xy 58.151338 115.577718)
        (xy 58.151333 115.577722)
        (xy 58.146621 115.581424)
        (xy 58.14269 115.585954)
        (xy 58.142689 115.585955)
        (xy 58.012921 115.735498)
        (xy 58.012917 115.735503)
        (xy 58.00899 115.740029)
        (xy 57.903834 115.921799)
        (xy 57.834947 116.120174)
        (xy 57.834086 116.126109)
        (xy 57.834086 116.126111)
        (xy 57.818701 116.232223)
        (xy 15.189373 113.787996)
        (xy 57.804814 113.787996)
        (xy 57.814523 113.997767)
        (xy 57.815927 114.003592)
        (xy 57.815927 114.003593)
        (xy 57.840084 114.103826)
        (xy 57.863724 114.201918)
        (xy 57.866206 114.207376)
        (xy 57.866207 114.20738)
        (xy 57.90932 114.302201)
        (xy 57.95064 114.393081)
        (xy 58.072137 114.56436)
        (xy 58.223831 114.709575)
        (xy 58.228866 114.712826)
        (xy 58.395209 114.820233)
        (xy 58.395212 114.820234)
        (xy 58.400246 114.823485)
        (xy 58.405809 114.825727)
        (xy 58.589455 114.899739)
        (xy 58.589458 114.89974)
        (xy 58.595019 114.901981)
        (xy 58.6009 114.903129)
        (xy 58.600905 114.903131)
        (xy 58.796676 114.941362)
        (xy 58.796679 114.941362)
        (xy 58.801122 114.94223)
        (xy 58.806643 114.9425)
        (xy 59.761469 114.9425)
        (xy 59.918046 114.927561)
        (xy 59.923802 114.925872)
        (xy 59.923804 114.925872)
        (xy 60.012883 114.899739)
        (xy 60.119549 114.868447)
        (xy 60.219947 114.816739)
        (xy 60.300908 114.775041)
        (xy 60.300911 114.775039)
        (xy 60.306239 114.772295)
        (xy 60.381947 114.712826)
        (xy 60.466662 114.646282)
        (xy 60.466667 114.646278)
        (xy 60.471379 114.642576)
        (xy 60.475311 114.638045)
        (xy 60.605079 114.488502)
        (xy 60.605083 114.488497)
        (xy 60.60901 114.483971)
        (xy 60.714166 114.302201)
        (xy 60.783053 114.103826)
        (xy 60.798431 113.997767)
        (xy 60.812325 113.901944)
        (xy 60.812325 113.901941)
        (xy 60.813186 113.896004)
        (xy 60.803477 113.686233)
        (xy 60.754276 113.482082)
        (xy 60.711258 113.387467)
        (xy 60.66984 113.296374)
        (xy 60.66736 113.290919)
        (xy 60.564647 113.146121)
        (xy 60.549329 113.124526)
        (xy 60.549328 113.124525)
        (xy 60.545863 113.11964)
        (xy 60.394169 112.974425)
        (xy 60.297033 112.911705)
        (xy 60.222791 112.863767)
        (xy 60.222788 112.863766)
        (xy 60.217754 112.860515)
        (xy 60.165284 112.839369)
        (xy 60.028545 112.784261)
        (xy 60.028542 112.78426)
        (xy 60.022981 112.782019)
        (xy 60.0171 112.780871)
        (xy 60.017095 112.780869)
        (xy 59.821324 112.742638)
        (xy 59.821321 112.742638)
        (xy 59.816878 112.74177)
        (xy 59.811357 112.7415)
        (xy 58.856531 112.7415)
        (xy 58.699954 112.756439)
        (xy 58.694198 112.758128)
        (xy 58.694196 112.758128)
        (xy 58.616679 112.780869)
        (xy 58.498451 112.815553)
        (xy 58.45221 112.839369)
        (xy 58.317092 112.908959)
        (xy 58.317089 112.908961)
        (xy 58.311761 112.911705)
        (xy 58.307046 112.915409)
        (xy 58.151338 113.037718)
        (xy 58.151333 113.037722)
        (xy 58.146621 113.041424)
        (xy 58.14269 113.045954)
        (xy 58.142689 113.045955)
        (xy 58.012921 113.195498)
        (xy 58.012917 113.195503)
        (xy 58.00899 113.200029)
        (xy 57.903834 113.381799)
        (xy 57.834947 113.580174)
        (xy 57.834086 113.586109)
        (xy 57.834086 113.586111)
        (xy 57.818701 113.692223)
        (xy 15.189373 111.247996)
        (xy 57.804814 111.247996)
        (xy 57.814523 111.457767)
        (xy 57.815927 111.463592)
        (xy 57.815927 111.463593)
        (xy 57.840084 111.563826)
        (xy 57.863724 111.661918)
        (xy 57.866206 111.667376)
        (xy 57.866207 111.66738)
        (xy 57.907361 111.757894)
        (xy 57.95064 111.853081)
        (xy 58.072137 112.02436)
        (xy 58.223831 112.169575)
        (xy 58.228866 112.172826)
        (xy 58.395209 112.280233)
        (xy 58.395212 112.280234)
        (xy 58.400246 112.283485)
        (xy 58.405809 112.285727)
        (xy 58.589455 112.359739)
        (xy 58.589458 112.35974)
        (xy 58.595019 112.361981)
        (xy 58.6009 112.363129)
        (xy 58.600905 112.363131)
        (xy 58.796676 112.401362)
        (xy 58.796679 112.401362)
        (xy 58.801122 112.40223)
        (xy 58.806643 112.4025)
        (xy 59.761469 112.4025)
        (xy 59.918046 112.387561)
        (xy 59.923802 112.385872)
        (xy 59.923804 112.385872)
        (xy 60.012883 112.359739)
        (xy 60.119549 112.328447)
        (xy 60.219947 112.276739)
        (xy 60.300908 112.235041)
        (xy 60.300911 112.235039)
        (xy 60.306239 112.232295)
        (xy 60.381947 112.172826)
        (xy 60.466662 112.106282)
        (xy 60.466667 112.106278)
        (xy 60.471379 112.102576)
        (xy 60.475311 112.098045)
        (xy 60.605079 111.948502)
        (xy 60.605083 111.948497)
        (xy 60.60901 111.943971)
        (xy 60.714166 111.762201)
        (xy 60.783053 111.563826)
        (xy 60.798431 111.457767)
        (xy 60.812325 111.361944)
        (xy 60.812325 111.361941)
        (xy 60.813186 111.356004)
        (xy 60.803477 111.146233)
        (xy 60.754276 110.942082)
        (xy 60.711258 110.847467)
        (xy 60.66984 110.756374)
        (xy 60.66736 110.750919)
        (xy 60.545863 110.57964)
        (xy 60.394169 110.434425)
        (xy 60.297033 110.371705)
        (xy 60.222791 110.323767)
        (xy 60.222788 110.323766)
        (xy 60.217754 110.320515)
        (xy 60.212191 110.318273)
        (xy 60.028545 110.244261)
        (xy 60.028542 110.24426)
        (xy 60.022981 110.242019)
        (xy 60.0171 110.240871)
        (xy 60.017095 110.240869)
        (xy 59.821324 110.202638)
        (xy 59.821321 110.202638)
        (xy 59.816878 110.20177)
        (xy 59.811357 110.2015)
        (xy 58.856531 110.2015)
        (xy 58.699954 110.216439)
        (xy 58.694198 110.218128)
        (xy 58.694196 110.218128)
        (xy 58.616679 110.240869)
        (xy 58.498451 110.275553)
        (xy 58.415505 110.318273)
        (xy 58.317092 110.368959)
        (xy 58.317089 110.368961)
        (xy 58.311761 110.371705)
        (xy 58.307046 110.375409)
        (xy 58.151338 110.497718)
        (xy 58.151333 110.497722)
        (xy 58.146621 110.501424)
        (xy 58.14269 110.505954)
        (xy 58.142689 110.505955)
        (xy 58.012921 110.655498)
        (xy 58.012917 110.655503)
        (xy 58.00899 110.660029)
        (xy 57.903834 110.841799)
        (xy 57.834947 111.040174)
        (xy 57.834086 111.046109)
        (xy 57.834086 111.046111)
        (xy 57.818701 111.152223)
        (xy 15.189373 107.15341)
        (xy 57.629 107.15341)
        (xy 57.62967 107.16257)
        (xy 57.638569 107.223018)
        (xy 57.644311 107.241498)
        (xy 57.691162 107.33692)
        (xy 57.703118 107.35362)
        (xy 57.777914 107.428285)
        (xy 57.794637 107.440214)
        (xy 57.89015 107.486903)
        (xy 57.908615 107.49261)
        (xy 57.968469 107.501341)
        (xy 57.977544 107.502)
        (xy 58.432094 107.502)
        (xy 58.500215 107.522002)
        (xy 58.546708 107.575658)
        (xy 58.556812 107.645932)
        (xy 58.527318 107.710512)
        (xy 58.489786 107.740016)
        (xy 58.317092 107.828959)
        (xy 58.317089 107.828961)
        (xy 58.311761 107.831705)
        (xy 58.307046 107.835409)
        (xy 58.151338 107.957718)
        (xy 58.151333 107.957722)
        (xy 58.146621 107.961424)
        (xy 58.14269 107.965954)
        (xy 58.142689 107.965955)
        (xy 58.012921 108.115498)
        (xy 58.012917 108.115503)
        (xy 58.00899 108.120029)
        (xy 57.903834 108.301799)
        (xy 57.834947 108.500174)
        (xy 57.834086 108.506109)
        (xy 57.834086 108.506111)
        (xy 57.818701 108.612223)
        (xy 57.804814 108.707996)
        (xy 57.814523 108.917767)
        (xy 57.815927 108.923592)
        (xy 57.815927 108.923593)
        (xy 57.840084 109.023826)
        (xy 57.863724 109.121918)
        (xy 57.866206 109.127376)
        (xy 57.866207 109.12738)
        (xy 57.90932 109.222201)
        (xy 57.95064 109.313081)
        (xy 58.072137 109.48436)
        (xy 58.223831 109.629575)
        (xy 58.228866 109.632826)
        (xy 58.395209 109.740233)
        (xy 58.395212 109.740234)
        (xy 58.400246 109.743485)
        (xy 58.405809 109.745727)
        (xy 58.589455 109.819739)
        (xy 58.589458 109.81974)
        (xy 58.595019 109.821981)
        (xy 58.6009 109.823129)
        (xy 58.600905 109.823131)
        (xy 58.796676 109.861362)
        (xy 58.796679 109.861362)
        (xy 58.801122 109.86223)
        (xy 58.806643 109.8625)
        (xy 59.761469 109.8625)
        (xy 59.918046 109.847561)
        (xy 59.923802 109.845872)
        (xy 59.923804 109.845872)
        (xy 60.012883 109.819739)
        (xy 60.119549 109.788447)
        (xy 60.219947 109.736739)
        (xy 60.300908 109.695041)
        (xy 60.300911 109.695039)
        (xy 60.306239 109.692295)
        (xy 60.381947 109.632826)
        (xy 60.466662 109.566282)
        (xy 60.466667 109.566278)
        (xy 60.471379 109.562576)
        (xy 60.475311 109.558045)
        (xy 60.605079 109.408502)
        (xy 60.605083 109.408497)
        (xy 60.60901 109.403971)
        (xy 60.714166 109.222201)
        (xy 60.783053 109.023826)
        (xy 60.798431 108.917767)
        (xy 60.812325 108.821944)
        (xy 60.812325 108.821941)
        (xy 60.813186 108.816004)
        (xy 60.803477 108.606233)
        (xy 60.754276 108.402082)
        (xy 60.711258 108.307467)
        (xy 60.66984 108.216374)
        (xy 60.66736 108.210919)
        (xy 60.545863 108.03964)
        (xy 60.394169 107.894425)
        (xy 60.297033 107.831705)
        (xy 60.222791 107.783767)
        (xy 60.222788 107.783766)
        (xy 60.217754 107.780515)
        (xy 60.129298 107.744866)
        (xy 60.073592 107.700851)
        (xy 60.050526 107.633705)
        (xy 60.067423 107.564749)
        (xy 60.118919 107.515874)
        (xy 60.176397 107.502)
        (xy 60.64041 107.502)
        (xy 60.64957 107.50133)
        (xy 60.710018 107.492431)
        (xy 60.728498 107.486689)
        (xy 60.82392 107.439838)
        (xy 60.84062 107.427882)
        (xy 60.915285 107.353086)
        (xy 60.927214 107.336363)
        (xy 60.973903 107.24085)
        (xy 60.97961 107.222385)
        (xy 60.988341 107.162531)
        (xy 60.989 107.153456)
        (xy 60.989 106.367115)
        (xy 60.984525 106.351876)
        (xy 60.983135 106.350671)
        (xy 60.975452 106.349)
        (xy 57.647115 106.349)
        (xy 57.631876 106.353475)
        (xy 57.630671 106.354865)
        (xy 57.629 106.362548)
        (xy 15.189373 106.076885)
        (xy 57.629 106.076885)
        (xy 57.633475 106.092124)
        (xy 57.634865 106.093329)
        (xy 57.642548 106.095)
        (xy 59.163885 106.095)
        (xy 59.179124 106.090525)
        (xy 59.180329 106.089135)
        (xy 59.182 106.081452)
        (xy 59.182 105.016097)
        (xy 59.17946 104.998429)
        (xy 59.17946 104.892983)
        (xy 59.43346 104.892983)
        (xy 59.436 104.910651)
        (xy 59.436 106.076885)
        (xy 59.440475 106.092124)
        (xy 59.441865 106.093329)
        (xy 59.449548 106.095)
        (xy 60.970885 106.095)
        (xy 60.986124 106.090525)
        (xy 60.987329 106.089135)
        (xy 60.989 106.081452)
        (xy 60.989 105.29059)
        (xy 60.98833 105.28143)
        (xy 60.979431 105.220982)
        (xy 60.973689 105.202502)
        (xy 60.926838 105.10708)
        (xy 60.914882 105.09038)
        (xy 60.840086 105.015715)
        (xy 60.823363 105.003786)
        (xy 60.72785 104.957097)
        (xy 60.709385 104.95139)
        (xy 60.649531 104.942659)
        (xy 60.640456 104.942)
        (xy 60.545481 104.942)
        (xy 60.47736 104.921998)
        (xy 60.430867 104.868342)
        (xy 60.420763 104.798068)
        (xy 60.450257 104.733488)
        (xy 60.47321 104.712787)
        (xy 60.52786 104.674521)
        (xy 60.536268 104.667465)
        (xy 60.686845 104.516888)
        (xy 60.693901 104.50848)
        (xy 60.81605 104.334033)
        (xy 60.821533 104.324538)
        (xy 60.911538 104.13152)
        (xy 60.915284 104.121228)
        (xy 60.970405 103.915512)
        (xy 60.972308 103.90472)
        (xy 60.978659 103.832126)
        (xy 60.975655 103.817179)
        (xy 60.963905 103.81408)
        (xy 59.451575 103.81408)
        (xy 59.436336 103.818555)
        (xy 59.435131 103.819945)
        (xy 59.43346 103.827628)
        (xy 59.17946 103.832195)
        (xy 59.174985 103.816956)
        (xy 59.173595 103.815751)
        (xy 59.165912 103.81408)
        (xy 57.650797 103.81408)
        (xy 57.636169 103.818375)
        (xy 57.634106 103.830352)
        (xy 57.640612 103.90472)
        (xy 57.642515 103.915512)
        (xy 57.697636 104.121228)
        (xy 57.701382 104.13152)
        (xy 57.791387 104.324537)
        (xy 57.79687 104.334033)
        (xy 57.919019 104.50848)
        (xy 57.926075 104.516888)
        (xy 58.076652 104.667465)
        (xy 58.08506 104.674521)
        (xy 58.13971 104.712787)
        (xy 58.184038 104.768244)
        (xy 58.191347 104.838863)
        (xy 58.159316 104.902224)
        (xy 58.098115 104.938209)
        (xy 58.067439 104.942)
        (xy 57.97759 104.942)
        (xy 57.96843 104.94267)
        (xy 57.907982 104.951569)
        (xy 57.889502 104.957311)
        (xy 57.79408 105.004162)
        (xy 57.77738 105.016118)
        (xy 57.702715 105.090914)
        (xy 57.690786 105.107637)
        (xy 57.644097 105.20315)
        (xy 57.63839 105.221615)
        (xy 57.629659 105.281469)
        (xy 57.629 105.290544)
        (xy 15.189373 103.542034)
        (xy 57.634261 103.542034)
        (xy 57.637265 103.556981)
        (xy 57.649015 103.56008)
        (xy 60.962123 103.56008)
        (xy 60.976751 103.555785)
        (xy 60.978814 103.543808)
        (xy 60.972308 103.46944)
        (xy 60.970405 103.458648)
        (xy 60.915284 103.252932)
        (xy 60.911538 103.24264)
        (xy 60.821533 103.049623)
        (xy 60.81605 103.040127)
        (xy 60.693901 102.86568)
        (xy 60.686845 102.857272)
        (xy 60.536268 102.706695)
        (xy 60.52786 102.699639)
        (xy 60.353413 102.57749)
        (xy 60.343917 102.572007)
        (xy 60.1509 102.482002)
        (xy 60.140608 102.478256)
        (xy 60.011382 102.44363)
        (xy 59.950759 102.406678)
        (xy 59.919738 102.342817)
        (xy 59.928166 102.272323)
        (xy 59.973369 102.217576)
        (xy 60.008524 102.201018)
        (xy 60.039675 102.191879)
        (xy 60.119549 102.168447)
        (xy 60.219947 102.116739)
        (xy 60.300908 102.075041)
        (xy 60.300911 102.075039)
        (xy 60.306239 102.072295)
        (xy 60.383883 102.011305)
        (xy 60.466662 101.946282)
        (xy 60.466667 101.946278)
        (xy 60.471379 101.942576)
        (xy 60.475311 101.938045)
        (xy 60.605079 101.788502)
        (xy 60.605083 101.788497)
        (xy 60.60901 101.783971)
        (xy 60.652692 101.708464)
        (xy 63.143482 101.708464)
        (xy 63.16412 101.865226)
        (xy 63.224628 102.011305)
        (xy 63.229655 102.017856)
        (xy 63.310707 102.123485)
        (xy 63.320882 102.136746)
        (xy 63.327428 102.141769)
        (xy 63.379204 102.181498)
        (xy 63.421071 102.238836)
        (xy 63.4285 102.281461)
        (xy 63.4285 105.348714)
        (xy 63.408498 105.416835)
        (xy 63.379204 105.448677)
        (xy 63.325718 105.489718)
        (xy 63.229464 105.615159)
        (xy 63.168956 105.761238)
        (xy 63.148318 105.918)
        (xy 63.168956 106.074762)
        (xy 63.172116 106.082391)
        (xy 63.175485 106.090525)
        (xy 63.229464 106.220841)
        (xy 63.325718 106.346282)
        (xy 63.451159 106.442536)
        (xy 63.597238 106.503044)
        (xy 63.754 106.523682)
        (xy 63.762188 106.522604)
        (xy 63.902574 106.504122)
        (xy 63.910762 106.503044)
        (xy 64.056841 106.442536)
        (xy 64.182282 106.346282)
        (xy 64.278536 106.220841)
        (xy 64.332515 106.090525)
        (xy 64.335884 106.082391)
        (xy 64.339044 106.074762)
        (xy 64.359682 105.918)
        (xy 64.339044 105.761238)
        (xy 64.278536 105.615159)
        (xy 64.182282 105.489718)
        (xy 64.128796 105.448677)
        (xy 64.086929 105.391339)
        (xy 64.0795 105.348714)
        (xy 64.0795 104.648)
        (xy 72.165318 104.648)
        (xy 72.185956 104.804762)
        (xy 72.246464 104.950841)
        (xy 72.342718 105.076282)
        (xy 72.468159 105.172536)
        (xy 72.614238 105.233044)
        (xy 72.771 105.253682)
        (xy 72.779188 105.252604)
        (xy 72.919574 105.234122)
        (xy 72.927762 105.233044)
        (xy 73.073841 105.172536)
        (xy 73.199282 105.076282)
        (xy 73.240323 105.022796)
        (xy 73.297661 104.980929)
        (xy 73.340286 104.9735)
        (xy 74.741714 104.9735)
        (xy 74.809835 104.993502)
        (xy 74.841677 105.022796)
        (xy 74.882718 105.076282)
        (xy 75.008159 105.172536)
        (xy 75.154238 105.233044)
        (xy 75.311 105.253682)
        (xy 75.319188 105.252604)
        (xy 75.459574 105.234122)
        (xy 75.467762 105.233044)
        (xy 75.613841 105.172536)
        (xy 75.739282 105.076282)
        (xy 75.835536 104.950841)
        (xy 75.896044 104.804762)
        (xy 75.916682 104.648)
        (xy 75.896044 104.491238)
        (xy 75.835536 104.345159)
        (xy 75.739282 104.219718)
        (xy 75.613841 104.123464)
        (xy 75.467762 104.062956)
        (xy 75.311 104.042318)
        (xy 75.154238 104.062956)
        (xy 75.008159 104.123464)
        (xy 74.882718 104.219718)
        (xy 74.877695 104.226264)
        (xy 74.841677 104.273204)
        (xy 74.784339 104.315071)
        (xy 74.741714 104.3225)
        (xy 73.340286 104.3225)
        (xy 73.272165 104.302498)
        (xy 73.240323 104.273204)
        (xy 73.204305 104.226264)
        (xy 73.199282 104.219718)
        (xy 73.073841 104.123464)
        (xy 72.927762 104.062956)
        (xy 72.771 104.042318)
        (xy 72.614238 104.062956)
        (xy 72.468159 104.123464)
        (xy 72.342718 104.219718)
        (xy 72.246464 104.345159)
        (xy 72.185956 104.491238)
        (xy 64.0795 102.274039)
        (xy 64.099502 102.205918)
        (xy 64.128797 102.174076)
        (xy 64.170897 102.141772)
        (xy 64.170901 102.141768)
        (xy 64.177446 102.136746)
        (xy 64.187622 102.123485)
        (xy 64.268673 102.017856)
        (xy 64.2737 102.011305)
        (xy 64.334208 101.865226)
        (xy 64.354846 101.708464)
        (xy 64.334208 101.551702)
        (xy 64.2737 101.405623)
        (xy 64.177446 101.280182)
        (xy 64.052005 101.183928)
        (xy 63.905926 101.12342)
        (xy 63.749164 101.102782)
        (xy 63.592402 101.12342)
        (xy 63.446323 101.183928)
        (xy 63.320882 101.280182)
        (xy 63.224628 101.405623)
        (xy 63.16412 101.551702)
        (xy 60.714166 101.602201)
        (xy 60.779361 101.414458)
        (xy 60.781086 101.409491)
        (xy 60.781086 101.409489)
        (xy 60.783053 101.403826)
        (xy 60.795129 101.320541)
        (xy 60.812325 101.201944)
        (xy 60.812325 101.201941)
        (xy 60.813186 101.196004)
        (xy 60.803477 100.986233)
        (xy 60.754276 100.782082)
        (xy 60.731986 100.733056)
        (xy 60.676997 100.612115)
        (xy 60.66736 100.590919)
        (xy 60.545863 100.41964)
        (xy 60.413828 100.293244)
        (xy 60.398499 100.27857)
        (xy 60.394169 100.274425)
        (xy 60.297033 100.211705)
        (xy 60.222791 100.163767)
        (xy 60.222788 100.163766)
        (xy 60.217754 100.160515)
        (xy 60.205851 100.155718)
        (xy 60.028545 100.084261)
        (xy 60.028542 100.08426)
        (xy 60.022981 100.082019)
        (xy 60.0171 100.080871)
        (xy 60.017095 100.080869)
        (xy 59.821324 100.042638)
        (xy 59.821321 100.042638)
        (xy 59.816878 100.04177)
        (xy 59.811357 100.0415)
        (xy 58.856531 100.0415)
        (xy 58.699954 100.056439)
        (xy 58.694198 100.058128)
        (xy 58.694196 100.058128)
        (xy 58.616679 100.080869)
        (xy 58.498451 100.115553)
        (xy 58.440894 100.145197)
        (xy 58.317092 100.208959)
        (xy 58.317089 100.208961)
        (xy 58.311761 100.211705)
        (xy 58.307046 100.215409)
        (xy 58.151338 100.337718)
        (xy 58.151333 100.337722)
        (xy 58.146621 100.341424)
        (xy 58.14269 100.345954)
        (xy 58.142689 100.345955)
        (xy 58.012921 100.495498)
        (xy 58.012917 100.495503)
        (xy 58.00899 100.500029)
        (xy 57.903834 100.681799)
        (xy 57.834947 100.880174)
        (xy 57.834086 100.886109)
        (xy 57.834086 100.886111)
        (xy 57.809274 101.057239)
        (xy 57.804814 101.087996)
        (xy 57.814523 101.297767)
        (xy 57.815927 101.303592)
        (xy 57.815927 101.303593)
        (xy 57.859199 101.483141)
        (xy 57.863724 101.501918)
        (xy 57.866206 101.507376)
        (xy 57.866207 101.50738)
        (xy 57.90932 101.602201)
        (xy 57.95064 101.693081)
        (xy 58.072137 101.86436)
        (xy 58.223831 102.009575)
        (xy 58.228866 102.012826)
        (xy 58.395209 102.120233)
        (xy 58.395212 102.120234)
        (xy 58.400246 102.123485)
        (xy 58.405809 102.125727)
        (xy 58.58946 102.199741)
        (xy 58.589463 102.199742)
        (xy 58.595019 102.201981)
        (xy 58.599533 102.202863)
        (xy 58.658773 102.241135)
        (xy 58.68811 102.305786)
        (xy 58.677837 102.376036)
        (xy 58.631216 102.429579)
        (xy 58.595961 102.445125)
        (xy 58.472312 102.478256)
        (xy 58.46202 102.482002)
        (xy 58.269003 102.572007)
        (xy 58.259507 102.57749)
        (xy 58.08506 102.699639)
        (xy 58.076652 102.706695)
        (xy 57.926075 102.857272)
        (xy 57.919019 102.86568)
        (xy 57.79687 103.040127)
        (xy 57.791387 103.049622)
        (xy 57.701382 103.24264)
        (xy 57.697636 103.252932)
        (xy 57.642515 103.458648)
        (xy 57.640612 103.46944)
        (xy 15.189373 100.315963)
        (xy 22.255757 100.315963)
        (xy 22.272175 100.511483)
        (xy 22.326258 100.700091)
        (xy 22.329076 100.705574)
        (xy 22.413123 100.869113)
        (xy 22.413126 100.869117)
        (xy 22.415944 100.874601)
        (xy 22.537818 101.028369)
        (xy 22.542511 101.032363)
        (xy 22.542512 101.032364)
        (xy 22.580901 101.065035)
        (xy 22.687238 101.155535)
        (xy 22.692616 101.158541)
        (xy 22.692618 101.158542)
        (xy 22.759649 101.196004)
        (xy 22.858513 101.251257)
        (xy 23.045118 101.311889)
        (xy 23.239946 101.335121)
        (xy 23.246081 101.334649)
        (xy 23.246083 101.334649)
        (xy 23.429434 101.320541)
        (xy 23.429438 101.32054)
        (xy 23.435576 101.320068)
        (xy 23.624556 101.267303)
        (xy 23.656302 101.251267)
        (xy 25.024488 101.251267)
        (xy 25.03437 101.263756)
        (xy 25.190737 101.368237)
        (xy 25.20085 101.373728)
        (xy 25.389495 101.454776)
        (xy 25.400428 101.458328)
        (xy 25.600683 101.503642)
        (xy 25.612092 101.505144)
        (xy 25.817253 101.513204)
        (xy 25.828735 101.512602)
        (xy 26.031932 101.483141)
        (xy 26.043115 101.480456)
        (xy 26.237537 101.414458)
        (xy 26.24804 101.409782)
        (xy 26.427178 101.30946)
        (xy 26.436672 101.302935)
        (xy 26.486978 101.261095)
        (xy 26.49543 101.24851)
        (xy 26.489257 101.237862)
        (xy 25.773812 100.522417)
        (xy 25.759868 100.514803)
        (xy 25.758035 100.514934)
        (xy 25.75142 100.519185)
        (xy 25.030684 101.239921)
        (xy 23.799689 101.178837)
        (xy 23.829515 101.155535)
        (xy 23.895656 101.10386)
        (xy 23.954303 101.05804)
        (xy 23.984084 101.023539)
        (xy 24.078485 100.914173)
        (xy 24.078485 100.914172)
        (xy 24.082509 100.909511)
        (xy 24.095388 100.886841)
        (xy 24.141007 100.806537)
        (xy 24.179425 100.738909)
        (xy 24.241358 100.552732)
        (xy 24.265949 100.358071)
        (xy 24.266162 100.342812)
        (xy 24.266292 100.333523)
        (xy 24.266292 100.333519)
        (xy 24.266341 100.33)
        (xy 24.263865 100.304745)
        (xy 24.576729 100.304745)
        (xy 24.590157 100.509615)
        (xy 24.591958 100.520985)
        (xy 24.642496 100.719979)
        (xy 24.646337 100.730826)
        (xy 24.732294 100.917282)
        (xy 24.738045 100.927243)
        (xy 24.829498 101.056646)
        (xy 24.840088 101.065035)
        (xy 24.853388 101.058007)
        (xy 25.568583 100.342812)
        (xy 25.574961 100.331132)
        (xy 25.945803 100.331132)
        (xy 25.945934 100.332965)
        (xy 25.950185 100.33958)
        (xy 26.667699 101.057094)
        (xy 26.681007 101.064361)
        (xy 26.691046 101.057239)
        (xy 26.733935 101.005672)
        (xy 26.74046 100.996178)
        (xy 26.840782 100.81704)
        (xy 26.845458 100.806537)
        (xy 26.911456 100.612115)
        (xy 26.914141 100.600932)
        (xy 26.943898 100.395695)
        (xy 26.944528 100.388312)
        (xy 26.945958 100.333704)
        (xy 26.945715 100.326305)
        (xy 26.92674 100.119798)
        (xy 26.924642 100.108477)
        (xy 26.868913 99.910878)
        (xy 26.864788 99.900131)
        (xy 26.77398 99.715991)
        (xy 26.76797 99.706183)
        (xy 26.691792 99.604169)
        (xy 26.680532 99.59572)
        (xy 26.668114 99.602491)
        (xy 25.953417 100.317188)
        (xy 25.576197 100.328868)
        (xy 25.576066 100.327035)
        (xy 25.571815 100.32042)
        (xy 24.854369 99.602974)
        (xy 24.841528 99.595962)
        (xy 24.830839 99.603757)
        (xy 24.770707 99.680035)
        (xy 24.764436 99.689691)
        (xy 24.668845 99.87138)
        (xy 24.664437 99.882023)
        (xy 24.603553 100.078098)
        (xy 24.601163 100.089342)
        (xy 24.57703 100.293244)
        (xy 24.247194 100.134728)
        (xy 24.245413 100.128829)
        (xy 24.245412 100.128824)
        (xy 24.192265 99.952793)
        (xy 24.190484 99.946894)
        (xy 24.09837 99.773653)
        (xy 23.974361 99.621602)
        (xy 23.82318 99.496535)
        (xy 23.665247 99.411141)
        (xy 25.025678 99.411141)
        (xy 25.031512 99.420907)
        (xy 25.748188 100.137583)
        (xy 25.762132 100.145197)
        (xy 25.763965 100.145066)
        (xy 25.77058 100.140815)
        (xy 26.489946 99.421449)
        (xy 26.49756 99.407505)
        (xy 26.497523 99.406988)
        (xy 26.491893 99.398593)
        (xy 26.486656 99.393753)
        (xy 26.477533 99.386752)
        (xy 26.303884 99.277187)
        (xy 26.293641 99.271969)
        (xy 26.102938 99.195886)
        (xy 26.09191 99.192619)
        (xy 25.890539 99.152564)
        (xy 25.879093 99.151361)
        (xy 25.673804 99.148674)
        (xy 25.662324 99.149577)
        (xy 25.459982 99.184346)
        (xy 25.448862 99.187326)
        (xy 25.256237 99.258389)
        (xy 25.245859 99.263339)
        (xy 25.069405 99.368317)
        (xy 25.060099 99.375079)
        (xy 25.034075 99.397902)
        (xy 23.650585 99.403213)
        (xy 23.537854 99.368317)
        (xy 23.469039 99.347015)
        (xy 23.469036 99.347014)
        (xy 23.463152 99.345193)
        (xy 23.457027 99.344549)
        (xy 23.457026 99.344549)
        (xy 23.274147 99.325327)
        (xy 23.274146 99.325327)
        (xy 23.268019 99.324683)
        (xy 23.145383 99.335844)
        (xy 23.078759 99.341907)
        (xy 23.078758 99.341907)
        (xy 23.072618 99.342466)
        (xy 23.066704 99.344207)
        (xy 23.066702 99.344207)
        (xy 22.984784 99.368317)
        (xy 22.884393 99.397864)
        (xy 22.878928 99.400721)
        (xy 22.715972 99.485912)
        (xy 22.715968 99.485915)
        (xy 22.710512 99.488767)
        (xy 22.705712 99.492627)
        (xy 22.705711 99.492627)
        (xy 22.671326 99.520273)
        (xy 22.5576 99.611711)
        (xy 22.43148 99.762016)
        (xy 22.428516 99.767408)
        (xy 22.428513 99.767412)
        (xy 22.371356 99.87138)
        (xy 22.336956 99.933954)
        (xy 22.277628 100.120978)
        (xy 15.189373 95.87944)
        (xy 31.294901 95.87944)
        (xy 31.296065 95.888342)
        (xy 31.296065 95.888345)
        (xy 31.310468 95.998489)
        (xy 31.310469 95.998493)
        (xy 31.311633 96.007394)
        (xy 31.31525 96.015614)
        (xy 31.358588 96.114107)
        (xy 31.363605 96.12551)
        (xy 31.369382 96.132383)
        (xy 31.369383 96.132384)
        (xy 31.431779 96.206613)
        (xy 31.446639 96.224291)
        (xy 31.454116 96.229268)
        (xy 31.519924 96.273073)
        (xy 31.55406 96.295796)
        (xy 31.677233 96.334278)
        (xy 31.686203 96.334442)
        (xy 31.686207 96.334443)
        (xy 31.744942 96.335519)
        (xy 31.806255 96.336643)
        (xy 31.89942 96.311243)
        (xy 31.922092 96.305062)
        (xy 31.922093 96.305062)
        (xy 31.930755 96.3027)
        (xy 31.938405 96.298003)
        (xy 31.938407 96.298002)
        (xy 32.033072 96.239878)
        (xy 32.033075 96.239875)
        (xy 32.040724 96.235179)
        (xy 32.048177 96.226945)
        (xy 32.049977 96.225843)
        (xy 32.053655 96.222789)
        (xy 32.054096 96.22332)
        (xy 32.10872 96.189864)
        (xy 32.141592 96.1855)
        (xy 32.709221 96.1855)
        (xy 32.779039 96.206613)
        (xy 32.87486 96.270396)
        (xy 32.95616 96.295796)
        (xy 32.985819 96.305062)
        (xy 32.998033 96.308878)
        (xy 33.007003 96.309042)
        (xy 33.007007 96.309043)
        (xy 33.065742 96.310119)
        (xy 33.127055 96.311243)
        (xy 33.201961 96.290821)
        (xy 33.242892 96.279662)
        (xy 33.242893 96.279662)
        (xy 33.251555 96.2773)
        (xy 33.259205 96.272603)
        (xy 33.259207 96.272602)
        (xy 33.353872 96.214478)
        (xy 33.353875 96.214475)
        (xy 33.361524 96.209779)
        (xy 33.36755 96.203122)
        (xy 33.4421 96.120761)
        (xy 33.442103 96.120757)
        (xy 33.448122 96.114107)
        (xy 33.504388 95.997975)
        (xy 33.525797 95.87072)
        (xy 33.525933 95.8596)
        (xy 33.51417 95.777462)
        (xy 33.508912 95.740745)
        (xy 33.508911 95.740742)
        (xy 33.507639 95.731859)
        (xy 33.491424 95.696195)
        (xy 33.457945 95.622562)
        (xy 33.457943 95.622559)
        (xy 33.454228 95.614388)
        (xy 33.424361 95.579726)
        (xy 33.375851 95.523426)
        (xy 33.375849 95.523424)
        (xy 33.369993 95.516628)
        (xy 33.261706 95.446441)
        (xy 33.253111 95.443871)
        (xy 33.25311 95.44387)
        (xy 33.146674 95.412038)
        (xy 33.146672 95.412038)
        (xy 33.138073 95.409466)
        (xy 33.129098 95.409411)
        (xy 33.129097 95.409411)
        (xy 33.074441 95.409077)
        (xy 33.009031 95.408678)
        (xy 32.997275 95.412038)
        (xy 32.893586 95.441672)
        (xy 32.893584 95.441673)
        (xy 32.884955 95.444139)
        (xy 32.877365 95.448928)
        (xy 32.837109 95.474328)
        (xy 32.775819 95.512999)
        (xy 32.750286 95.54191)
        (xy 32.6902 95.579726)
        (xy 32.655846 95.5845)
        (xy 32.143178 95.5845)
        (xy 32.075057 95.564498)
        (xy 32.060347 95.553447)
        (xy 32.055052 95.548827)
        (xy 32.049193 95.542028)
        (xy 31.940906 95.471841)
        (xy 31.932311 95.469271)
        (xy 31.93231 95.46927)
        (xy 31.825874 95.437438)
        (xy 31.825872 95.437438)
        (xy 31.817273 95.434866)
        (xy 31.808298 95.434811)
        (xy 31.808297 95.434811)
        (xy 31.753641 95.434477)
        (xy 31.688231 95.434078)
        (xy 31.644974 95.446441)
        (xy 31.572786 95.467072)
        (xy 31.572784 95.467073)
        (xy 31.564155 95.469539)
        (xy 31.556565 95.474328)
        (xy 31.47875 95.523426)
        (xy 31.455019 95.538399)
        (xy 31.449076 95.545128)
        (xy 31.449075 95.545129)
        (xy 31.44436 95.550468)
        (xy 31.369596 95.635122)
        (xy 31.365782 95.643245)
        (xy 31.365781 95.643247)
        (xy 31.344009 95.689621)
        (xy 31.314754 95.751932)
        (xy 31.305626 95.810558)
        (xy 31.296282 95.870567)
        (xy 31.296282 95.870571)
        (xy 15.189373 94.873665)
        (xy 24.571994 94.873665)
        (xy 24.587592 95.059414)
        (xy 24.638971 95.238595)
        (xy 24.724176 95.404385)
        (xy 24.839959 95.550468)
        (xy 24.981912 95.671279)
        (xy 25.144627 95.762217)
        (xy 25.321907 95.819819)
        (xy 25.506998 95.84189)
        (xy 25.513133 95.841418)
        (xy 25.513135 95.841418)
        (xy 25.68671 95.828062)
        (xy 25.686715 95.828061)
        (xy 25.692851 95.827589)
        (xy 25.698781 95.825933)
        (xy 25.698783 95.825933)
        (xy 25.866459 95.779117)
        (xy 25.866458 95.779117)
        (xy 25.872387 95.777462)
        (xy 26.038768 95.693417)
        (xy 26.063255 95.674286)
        (xy 26.180794 95.582454)
        (xy 26.180795 95.582453)
        (xy 26.185655 95.578656)
        (xy 26.307454 95.43755)
        (xy 26.399526 95.275474)
        (xy 26.458364 95.098601)
        (xy 26.481727 94.913668)
        (xy 26.482099 94.887)
        (xy 26.463909 94.701487)
        (xy 26.462128 94.695588)
        (xy 26.462127 94.695583)
        (xy 26.411814 94.528939)
        (xy 26.410033 94.52304)
        (xy 26.322522 94.358456)
        (xy 26.318632 94.353686)
        (xy 26.318629 94.353682)
        (xy 26.208605 94.21878)
        (xy 26.208602 94.218777)
        (xy 26.20471 94.214005)
        (xy 26.199056 94.209327)
        (xy 26.132897 94.154596)
        (xy 26.061085 94.095187)
        (xy 25.897116 94.006529)
        (xy 25.808082 93.978969)
        (xy 25.724936 93.953231)
        (xy 25.724933 93.95323)
        (xy 25.719049 93.951409)
        (xy 25.712924 93.950765)
        (xy 25.712923 93.950765)
        (xy 25.539796 93.932568)
        (xy 25.539795 93.932568)
        (xy 25.533668 93.931924)
        (xy 25.455549 93.939033)
        (xy 25.354171 93.948259)
        (xy 25.354168 93.94826)
        (xy 25.348032 93.948818)
        (xy 25.342122 93.950557)
        (xy 25.342119 93.950558)
        (xy 25.182067 93.997665)
        (xy 25.169214 94.001448)
        (xy 25.004023 94.087807)
        (xy 24.858752 94.204608)
        (xy 24.738935 94.347401)
        (xy 24.735971 94.352793)
        (xy 24.735968 94.352797)
        (xy 24.661256 94.488699)
        (xy 24.649135 94.510746)
        (xy 24.592772 94.688424)
        (xy 15.189373 92.783898)
        (xy 55.661112 92.783898)
        (xy 55.662276 92.7928)
        (xy 55.662276 92.792803)
        (xy 55.676679 92.902947)
        (xy 55.67668 92.902951)
        (xy 55.677844 92.911852)
        (xy 55.729816 93.029968)
        (xy 55.735593 93.036841)
        (xy 55.735594 93.036842)
        (xy 55.776445 93.08544)
        (xy 55.81285 93.128749)
        (xy 55.920271 93.200254)
        (xy 56.043444 93.238736)
        (xy 56.052416 93.2389)
        (xy 56.052419 93.238901)
        (xy 56.090204 93.239593)
        (xy 56.091497 93.239617)
        (xy 56.159239 93.260865)
        (xy 56.178282 93.276501)
        (xy 56.828471 93.92669)
        (xy 56.830223 93.92872)
        (xy 56.832561 93.933502)
        (xy 56.84109 93.941413)
        (xy 56.841091 93.941415)
        (xy 56.868435 93.966779)
        (xy 56.871842 93.97006)
        (xy 56.885262 93.983481)
        (xy 56.889238 93.986208)
        (xy 56.891892 93.98854)
        (xy 56.914632 94.009634)
        (xy 56.925439 94.013945)
        (xy 56.929434 94.016471)
        (xy 56.940228 94.022234)
        (xy 56.94454 94.024145)
        (xy 56.954132 94.030725)
        (xy 56.965449 94.033411)
        (xy 56.96545 94.033411)
        (xy 56.978113 94.036416)
        (xy 56.99571 94.041981)
        (xy 57.010348 94.047821)
        (xy 57.010351 94.047822)
        (xy 57.018608 94.051116)
        (xy 57.024901 94.051733)
        (xy 57.02798 94.051733)
        (xy 57.031053 94.051883)
        (xy 57.031042 94.052099)
        (xy 57.042417 94.053431)
        (xy 57.051732 94.053887)
        (xy 57.063052 94.056573)
        (xy 57.074581 94.055004)
        (xy 57.074582 94.055004)
        (xy 57.090159 94.052884)
        (xy 57.10715 94.051733)
        (xy 57.417281 94.051733)
        (xy 57.485402 94.071735)
        (xy 57.501149 94.083715)
        (xy 57.506872 94.090524)
        (xy 57.514343 94.095497)
        (xy 57.514344 94.095498)
        (xy 57.523229 94.101412)
        (xy 57.614293 94.162029)
        (xy 57.737466 94.200511)
        (xy 57.746436 94.200675)
        (xy 57.74644 94.200676)
        (xy 57.805175 94.201752)
        (xy 57.866488 94.202876)
        (xy 57.928738 94.185904)
        (xy 57.982325 94.171295)
        (xy 57.982326 94.171295)
        (xy 57.990988 94.168933)
        (xy 57.998638 94.164236)
        (xy 57.99864 94.164235)
        (xy 58.093305 94.106111)
        (xy 58.093308 94.106108)
        (xy 58.100957 94.101412)
        (xy 58.109778 94.091667)
        (xy 58.181533 94.012394)
        (xy 58.181536 94.01239)
        (xy 58.187555 94.00574)
        (xy 58.243821 93.889608)
        (xy 58.26523 93.762353)
        (xy 58.265366 93.751233)
        (xy 58.247072 93.623492)
        (xy 58.209312 93.540443)
        (xy 58.197378 93.514195)
        (xy 58.197376 93.514192)
        (xy 58.193661 93.506021)
        (xy 58.141838 93.445877)
        (xy 58.115284 93.415059)
        (xy 58.115282 93.415057)
        (xy 58.109426 93.408261)
        (xy 58.073768 93.385149)
        (xy 58.027484 93.331313)
        (xy 58.017653 93.261001)
        (xy 58.047396 93.196535)
        (xy 58.109157 93.157853)
        (xy 58.146358 93.147711)
        (xy 58.219755 93.1277)
        (xy 58.227405 93.123003)
        (xy 58.227407 93.123002)
        (xy 58.288583 93.08544)
        (xy 64.759198 93.08544)
        (xy 64.760362 93.094342)
        (xy 64.760362 93.094345)
        (xy 64.774765 93.204489)
        (xy 64.774766 93.204493)
        (xy 64.77593 93.213394)
        (xy 64.827902 93.33151)
        (xy 64.833679 93.338383)
        (xy 64.83368 93.338384)
        (xy 64.900127 93.417432)
        (xy 64.910936 93.430291)
        (xy 65.018357 93.501796)
        (xy 65.14153 93.540278)
        (xy 65.1505 93.540442)
        (xy 65.150504 93.540443)
        (xy 65.209239 93.541519)
        (xy 65.270552 93.542643)
        (xy 65.374897 93.514195)
        (xy 65.386389 93.511062)
        (xy 65.38639 93.511062)
        (xy 65.395052 93.5087)
        (xy 65.402702 93.504003)
        (xy 65.402704 93.504002)
        (xy 65.450037 93.474939)
        (xy 65.505021 93.441179)
        (xy 65.505624 93.442161)
        (xy 65.562944 93.417432)
        (xy 65.578241 93.4165)
        (xy 69.946318 93.4165)
        (xy 70.016137 93.437613)
        (xy 70.112558 93.501796)
        (xy 70.235731 93.540278)
        (xy 70.244701 93.540442)
        (xy 70.244705 93.540443)
        (xy 70.30344 93.541519)
        (xy 70.364753 93.542643)
        (xy 70.469098 93.514195)
        (xy 70.48059 93.511062)
        (xy 70.480591 93.511062)
        (xy 70.489253 93.5087)
        (xy 70.496903 93.504003)
        (xy 70.496905 93.504002)
        (xy 70.59157 93.445878)
        (xy 70.591573 93.445875)
        (xy 70.599222 93.441179)
        (xy 70.608679 93.430731)
        (xy 70.679798 93.352161)
        (xy 70.679801 93.352157)
        (xy 70.68582 93.345507)
        (xy 70.742086 93.229375)
        (xy 70.759192 93.1277)
        (xy 70.762688 93.106917)
        (xy 70.763495 93.10212)
        (xy 70.763631 93.091)
        (xy 70.745337 92.963259)
        (xy 70.741623 92.95509)
        (xy 70.695643 92.853962)
        (xy 70.695641 92.853959)
        (xy 70.691926 92.845788)
        (xy 70.651888 92.799321)
        (xy 70.613549 92.754826)
        (xy 70.613547 92.754824)
        (xy 70.607691 92.748028)
        (xy 70.499404 92.677841)
        (xy 70.490809 92.675271)
        (xy 70.490808 92.67527)
        (xy 70.384372 92.643438)
        (xy 70.38437 92.643438)
        (xy 70.375771 92.640866)
        (xy 70.366796 92.640811)
        (xy 70.366795 92.640811)
        (xy 70.312139 92.640477)
        (xy 70.246729 92.640078)
        (xy 70.199598 92.653548)
        (xy 70.131284 92.673072)
        (xy 70.131282 92.673073)
        (xy 70.122653 92.675539)
        (xy 70.013517 92.744399)
        (xy 70.011851 92.741759)
        (xy 69.96115 92.764372)
        (xy 69.944327 92.7655)
        (xy 65.57771 92.7655)
        (xy 65.509179 92.745233)
        (xy 65.412735 92.682722)
        (xy 65.41273 92.68272)
        (xy 65.405203 92.677841)
        (xy 65.396608 92.675271)
        (xy 65.396607 92.67527)
        (xy 65.290171 92.643438)
        (xy 65.290169 92.643438)
        (xy 65.28157 92.640866)
        (xy 65.272595 92.640811)
        (xy 65.272594 92.640811)
        (xy 65.217938 92.640477)
        (xy 65.152528 92.640078)
        (xy 65.105397 92.653548)
        (xy 65.037083 92.673072)
        (xy 65.037081 92.673073)
        (xy 65.028452 92.675539)
        (xy 65.020862 92.680328)
        (xy 64.963917 92.716258)
        (xy 64.919316 92.744399)
        (xy 64.913373 92.751128)
        (xy 64.913372 92.751129)
        (xy 64.879521 92.789458)
        (xy 64.833893 92.841122)
        (xy 64.830079 92.849245)
        (xy 64.830078 92.849247)
        (xy 64.804866 92.902947)
        (xy 64.779051 92.957932)
        (xy 64.776838 92.972145)
        (xy 64.760579 93.076567)
        (xy 64.760579 93.076571)
        (xy 58.322072 93.064878)
        (xy 58.322075 93.064875)
        (xy 58.329724 93.060179)
        (xy 58.33575 93.053522)
        (xy 58.4103 92.971161)
        (xy 58.410303 92.971157)
        (xy 58.416322 92.964507)
        (xy 58.472588 92.848375)
        (xy 58.479554 92.806973)
        (xy 58.49319 92.725917)
        (xy 58.49319 92.725915)
        (xy 58.493997 92.72112)
        (xy 58.494133 92.71)
        (xy 58.484119 92.640078)
        (xy 58.477112 92.591145)
        (xy 58.477111 92.591142)
        (xy 58.475839 92.582259)
        (xy 58.460128 92.547705)
        (xy 58.426145 92.472962)
        (xy 58.426143 92.472959)
        (xy 58.422428 92.464788)
        (xy 58.416569 92.457989)
        (xy 58.416567 92.457985)
        (xy 58.395047 92.433011)
        (xy 58.374614 92.38794)
        (xy 72.061901 92.38794)
        (xy 72.063065 92.396842)
        (xy 72.063065 92.396845)
        (xy 72.077468 92.506989)
        (xy 72.077469 92.506993)
        (xy 72.078633 92.515894)
        (xy 72.130605 92.63401)
        (xy 72.136382 92.640883)
        (xy 72.136383 92.640884)
        (xy 72.207859 92.725915)
        (xy 72.213639 92.732791)
        (xy 72.32106 92.804296)
        (xy 72.382493 92.823489)
        (xy 72.417398 92.834394)
        (xy 72.444233 92.842778)
        (xy 72.453203 92.842942)
        (xy 72.453207 92.842943)
        (xy 72.511942 92.844019)
        (xy 72.573255 92.845143)
        (xy 72.677358 92.816761)
        (xy 72.689092 92.813562)
        (xy 72.689093 92.813562)
        (xy 72.697755 92.8112)
        (xy 72.705405 92.806503)
        (xy 72.705407 92.806502)
        (xy 72.800072 92.748378)
        (xy 72.800075 92.748375)
        (xy 72.807724 92.743679)
        (xy 72.81375 92.737022)
        (xy 72.8883 92.654661)
        (xy 72.888303 92.654657)
        (xy 72.894322 92.648007)
        (xy 72.950588 92.531875)
        (xy 72.9605 92.472962)
        (xy 72.97119 92.409417)
        (xy 72.971997 92.40462)
        (xy 72.972133 92.3935)
        (xy 72.964374 92.339324)
        (xy 72.955112 92.274645)
        (xy 72.955111 92.274642)
        (xy 72.953839 92.265759)
        (xy 72.932368 92.218536)
        (xy 72.904145 92.156462)
        (xy 72.904143 92.156459)
        (xy 72.900428 92.148288)
        (xy 72.894569 92.141489)
        (xy 72.894567 92.141485)
        (xy 72.873047 92.116511)
        (xy 72.843733 92.051849)
        (xy 72.8425 92.034263)
        (xy 72.8425 91.354815)
        (xy 72.862502 91.286694)
        (xy 72.87508 91.270265)
        (xy 72.894322 91.249007)
        (xy 72.950588 91.132875)
        (xy 72.954081 91.112116)
        (xy 72.97119 91.010417)
        (xy 72.971997 91.00562)
        (xy 72.972133 90.9945)
        (xy 72.958236 90.897462)
        (xy 72.955112 90.875645)
        (xy 72.955111 90.875642)
        (xy 72.953839 90.866759)
        (xy 72.92786 90.809621)
        (xy 72.904145 90.757462)
        (xy 72.904143 90.757459)
        (xy 72.900428 90.749288)
        (xy 72.874625 90.719342)
        (xy 72.822051 90.658326)
        (xy 72.822049 90.658324)
        (xy 72.816193 90.651528)
        (xy 72.707906 90.581341)
        (xy 72.699311 90.578771)
        (xy 72.69931 90.57877)
        (xy 72.592874 90.546938)
        (xy 72.592872 90.546938)
        (xy 72.584273 90.544366)
        (xy 72.575298 90.544311)
        (xy 72.575297 90.544311)
        (xy 72.520641 90.543977)
        (xy 72.455231 90.543578)
        (xy 72.406344 90.55755)
        (xy 72.339786 90.576572)
        (xy 72.339784 90.576573)
        (xy 72.331155 90.579039)
        (xy 72.222019 90.647899)
        (xy 72.216076 90.654628)
        (xy 72.216075 90.654629)
        (xy 72.148351 90.731312)
        (xy 72.136596 90.744622)
        (xy 72.132782 90.752745)
        (xy 72.132781 90.752747)
        (xy 72.116566 90.787285)
        (xy 72.081754 90.861432)
        (xy 72.072626 90.920058)
        (xy 72.063282 90.980067)
        (xy 72.063282 90.980071)
        (xy 72.061901 90.98894)
        (xy 72.063065 90.997842)
        (xy 72.063065 90.997845)
        (xy 72.077468 91.107989)
        (xy 72.077469 91.107993)
        (xy 72.078633 91.116894)
        (xy 72.130605 91.23501)
        (xy 72.13638 91.24188)
        (xy 72.136383 91.241885)
        (xy 72.16195 91.2723)
        (xy 72.190472 91.337315)
        (xy 72.1915 91.353376)
        (xy 72.1915 92.033781)
        (xy 72.171498 92.101902)
        (xy 72.159942 92.117188)
        (xy 72.136596 92.143622)
        (xy 72.132782 92.151745)
        (xy 72.132781 92.151747)
        (xy 72.126793 92.164502)
        (xy 72.081754 92.260432)
        (xy 72.075811 92.298604)
        (xy 72.063282 92.379067)
        (xy 72.063282 92.379071)
        (xy 58.365733 92.368349)
        (xy 58.3645 92.350763)
        (xy 58.3645 91.694)
        (xy 64.291318 91.694)
        (xy 64.311956 91.850762)
        (xy 64.372464 91.996841)
        (xy 64.468718 92.122282)
        (xy 64.594159 92.218536)
        (xy 64.740238 92.279044)
        (xy 64.897 92.299682)
        (xy 64.905188 92.298604)
        (xy 65.045574 92.280122)
        (xy 65.053762 92.279044)
        (xy 65.199841 92.218536)
        (xy 65.262395 92.170537)
        (xy 65.328616 92.144937)
        (xy 65.339099 92.1445)
        (xy 70.415919 92.1445)
        (xy 70.48404 92.164502)
        (xy 70.492623 92.170537)
        (xy 70.555177 92.218536)
        (xy 70.701256 92.279044)
        (xy 70.858018 92.299682)
        (xy 70.866206 92.298604)
        (xy 71.006592 92.280122)
        (xy 71.01478 92.279044)
        (xy 71.160859 92.218536)
        (xy 71.2863 92.122282)
        (xy 71.382554 91.996841)
        (xy 71.443062 91.850762)
        (xy 71.4637 91.694)
        (xy 71.443062 91.537238)
        (xy 71.382554 91.391159)
        (xy 71.2863 91.265718)
        (xy 71.160859 91.169464)
        (xy 71.01478 91.108956)
        (xy 70.858018 91.088318)
        (xy 70.701256 91.108956)
        (xy 70.555177 91.169464)
        (xy 70.548626 91.174491)
        (xy 70.492623 91.217463)
        (xy 70.426402 91.243063)
        (xy 70.415919 91.2435)
        (xy 65.339099 91.2435)
        (xy 65.270978 91.223498)
        (xy 65.262395 91.217463)
        (xy 65.206392 91.174491)
        (xy 65.199841 91.169464)
        (xy 65.053762 91.108956)
        (xy 64.897 91.088318)
        (xy 64.740238 91.108956)
        (xy 64.594159 91.169464)
        (xy 64.468718 91.265718)
        (xy 64.372464 91.391159)
        (xy 64.311956 91.537238)
        (xy 58.3645 91.694)
        (xy 58.3645 89.595016)
        (xy 58.384502 89.526895)
        (xy 58.401405 89.505921)
        (xy 59.154788 88.752538)
        (xy 59.2171 88.718512)
        (xy 59.228309 88.716599)
        (xy 59.229277 88.716478)
        (xy 59.238255 88.716643)
        (xy 59.300505 88.699672)
        (xy 59.354092 88.685062)
        (xy 59.354093 88.685062)
        (xy 59.362755 88.6827)
        (xy 59.370405 88.678003)
        (xy 59.370407 88.678002)
        (xy 59.465072 88.619878)
        (xy 59.465075 88.619875)
        (xy 59.472724 88.615179)
        (xy 59.47875 88.608522)
        (xy 59.5533 88.526161)
        (xy 59.553303 88.526157)
        (xy 59.559322 88.519507)
        (xy 59.615588 88.403375)
        (xy 59.636997 88.27612)
        (xy 59.637133 88.265)
        (xy 59.623408 88.16916)
        (xy 59.620112 88.146145)
        (xy 59.620111 88.146142)
        (xy 59.618839 88.137259)
        (xy 59.612724 88.123809)
        (xy 59.569145 88.027962)
        (xy 59.569143 88.027959)
        (xy 59.565428 88.019788)
        (xy 59.539625 87.989842)
        (xy 59.487051 87.928826)
        (xy 59.487049 87.928824)
        (xy 59.481193 87.922028)
        (xy 59.372906 87.851841)
        (xy 59.364311 87.849271)
        (xy 59.36431 87.84927)
        (xy 59.257874 87.817438)
        (xy 59.257872 87.817438)
        (xy 59.249273 87.814866)
        (xy 59.240298 87.814811)
        (xy 59.240297 87.814811)
        (xy 59.185641 87.814477)
        (xy 59.120231 87.814078)
        (xy 59.108475 87.817438)
        (xy 59.004786 87.847072)
        (xy 59.004784 87.847073)
        (xy 58.996155 87.849539)
        (xy 58.887019 87.918399)
        (xy 58.881076 87.925128)
        (xy 58.881075 87.925129)
        (xy 58.813351 88.001812)
        (xy 58.801596 88.015122)
        (xy 58.797782 88.023245)
        (xy 58.797781 88.023247)
        (xy 58.771794 88.078598)
        (xy 58.746754 88.131932)
        (xy 58.745374 88.140798)
        (xy 58.733166 88.219203)
        (xy 58.702922 88.283435)
        (xy 58.697761 88.288913)
        (xy 57.822785 89.163889)
        (xy 57.814681 89.171316)
        (xy 57.785806 89.195545)
        (xy 57.780293 89.205094)
        (xy 57.766961 89.228185)
        (xy 57.761055 89.237456)
        (xy 57.739446 89.268316)
        (xy 57.736592 89.278966)
        (xy 57.735115 89.282134)
        (xy 57.733923 89.28541)
        (xy 57.728412 89.294955)
        (xy 57.723864 89.320749)
        (xy 57.72187 89.332058)
        (xy 57.719492 89.342785)
        (xy 57.709736 89.379193)
        (xy 57.710697 89.390178)
        (xy 57.710697 89.39018)
        (xy 57.71302 89.416728)
        (xy 57.7135 89.42771)
        (xy 57.7135 92.350281)
        (xy 57.693498 92.418402)
        (xy 57.681942 92.433688)
        (xy 57.658596 92.460122)
        (xy 57.654782 92.468245)
        (xy 57.654781 92.468247)
        (xy 57.636592 92.506989)
        (xy 57.603754 92.576932)
        (xy 57.602374 92.585798)
        (xy 57.585282 92.695567)
        (xy 57.585282 92.695571)
        (xy 57.583901 92.70444)
        (xy 57.585065 92.713342)
        (xy 57.585065 92.713345)
        (xy 57.599468 92.823489)
        (xy 57.599469 92.823493)
        (xy 57.600633 92.832394)
        (xy 57.652605 92.95051)
        (xy 57.658382 92.957383)
        (xy 57.658383 92.957384)
        (xy 57.729859 93.042415)
        (xy 57.735639 93.049291)
        (xy 57.743116 93.054268)
        (xy 57.776322 93.076372)
        (xy 57.821945 93.130769)
        (xy 57.830916 93.201197)
        (xy 57.800386 93.265294)
        (xy 57.741127 93.302408)
        (xy 57.633021 93.333304)
        (xy 57.633017 93.333306)
        (xy 57.624388 93.335772)
        (xy 57.616798 93.340561)
        (xy 57.546131 93.385149)
        (xy 57.515252 93.404632)
        (xy 57.509308 93.411362)
        (xy 57.502476 93.417177)
        (xy 57.500844 93.415259)
        (xy 57.452068 93.445959)
        (xy 57.417712 93.450733)
        (xy 57.254647 93.450733)
        (xy 57.186526 93.430731)
        (xy 57.165552 93.413828)
        (xy 56.606067 92.854343)
        (xy 56.572041 92.792031)
        (xy 56.570435 92.783111)
        (xy 56.563941 92.737768)
        (xy 56.55305 92.661717)
        (xy 56.546935 92.648267)
        (xy 56.503356 92.55242)
        (xy 56.503354 92.552417)
        (xy 56.499639 92.544246)
        (xy 56.473836 92.5143)
        (xy 56.421262 92.453284)
        (xy 56.42126 92.453282)
        (xy 56.415404 92.446486)
        (xy 56.307117 92.376299)
        (xy 56.298522 92.373729)
        (xy 56.298521 92.373728)
        (xy 56.192085 92.341896)
        (xy 56.192083 92.341896)
        (xy 56.183484 92.339324)
        (xy 56.174509 92.339269)
        (xy 56.174508 92.339269)
        (xy 56.119852 92.338935)
        (xy 56.054442 92.338536)
        (xy 55.992404 92.356267)
        (xy 55.938997 92.37153)
        (xy 55.938995 92.371531)
        (xy 55.930366 92.373997)
        (xy 55.82123 92.442857)
        (xy 55.735807 92.53958)
        (xy 55.731993 92.547703)
        (xy 55.731992 92.547705)
        (xy 55.71827 92.576932)
        (xy 55.680965 92.65639)
        (xy 55.676865 92.682722)
        (xy 55.662493 92.775025)
        (xy 55.662493 92.775029)
        (xy 15.189373 89.993665)
        (xy 24.571994 89.993665)
        (xy 24.587592 90.179414)
        (xy 24.638971 90.358595)
        (xy 24.724176 90.524385)
        (xy 24.839959 90.670468)
        (xy 24.981912 90.791279)
        (xy 25.144627 90.882217)
        (xy 25.321907 90.939819)
        (xy 25.506998 90.96189)
        (xy 25.513133 90.961418)
        (xy 25.513135 90.961418)
        (xy 25.68671 90.948062)
        (xy 25.686715 90.948061)
        (xy 25.692851 90.947589)
        (xy 25.698781 90.945933)
        (xy 25.698783 90.945933)
        (xy 25.866459 90.899117)
        (xy 25.866458 90.899117)
        (xy 25.872387 90.897462)
        (xy 26.038768 90.813417)
        (xy 26.063255 90.794286)
        (xy 26.180794 90.702454)
        (xy 26.180795 90.702453)
        (xy 26.185655 90.698656)
        (xy 26.307454 90.55755)
        (xy 26.313483 90.546938)
        (xy 26.396479 90.400837)
        (xy 26.399526 90.395474)
        (xy 26.458364 90.218601)
        (xy 26.465106 90.165231)
        (xy 26.481285 90.03717)
        (xy 26.481286 90.037163)
        (xy 26.481727 90.033668)
        (xy 26.482099 90.007)
        (xy 26.463909 89.821487)
        (xy 26.462128 89.815588)
        (xy 26.462127 89.815583)
        (xy 26.411814 89.648939)
        (xy 26.410033 89.64304)
        (xy 26.348278 89.526895)
        (xy 26.325416 89.483898)
        (xy 26.325414 89.483895)
        (xy 26.322522 89.478456)
        (xy 26.318632 89.473686)
        (xy 26.318629 89.473682)
        (xy 26.208605 89.33878)
        (xy 26.208602 89.338777)
        (xy 26.20471 89.334005)
        (xy 26.199056 89.329327)
        (xy 26.082552 89.232946)
        (xy 26.061085 89.215187)
        (xy 25.897116 89.126529)
        (xy 25.808083 89.098969)
        (xy 25.724936 89.073231)
        (xy 25.724933 89.07323)
        (xy 25.719049 89.071409)
        (xy 25.712924 89.070765)
        (xy 25.712923 89.070765)
        (xy 25.539796 89.052568)
        (xy 25.539795 89.052568)
        (xy 25.533668 89.051924)
        (xy 25.455549 89.059033)
        (xy 25.354171 89.068259)
        (xy 25.354168 89.06826)
        (xy 25.348032 89.068818)
        (xy 25.342122 89.070557)
        (xy 25.342119 89.070558)
        (xy 25.175129 89.119707)
        (xy 25.169214 89.121448)
        (xy 25.004023 89.207807)
        (xy 24.858752 89.324608)
        (xy 24.738935 89.467401)
        (xy 24.735971 89.472793)
        (xy 24.735968 89.472797)
        (xy 24.668778 89.595016)
        (xy 24.649135 89.630746)
        (xy 24.592772 89.808424)
        (xy 15.189373 84.313963)
        (xy 22.255757 84.313963)
        (xy 22.272175 84.509483)
        (xy 22.326258 84.698091)
        (xy 22.329076 84.703574)
        (xy 22.413123 84.867113)
        (xy 22.413126 84.867117)
        (xy 22.415944 84.872601)
        (xy 22.537818 85.026369)
        (xy 22.542511 85.030363)
        (xy 22.542512 85.030364)
        (xy 22.659721 85.130116)
        (xy 22.687238 85.153535)
        (xy 22.692616 85.156541)
        (xy 22.692618 85.156542)
        (xy 22.728932 85.176837)
        (xy 22.858513 85.249257)
        (xy 23.045118 85.309889)
        (xy 23.239946 85.333121)
        (xy 23.246081 85.332649)
        (xy 23.246083 85.332649)
        (xy 23.429434 85.318541)
        (xy 23.429438 85.31854)
        (xy 23.435576 85.318068)
        (xy 23.624556 85.265303)
        (xy 23.656302 85.249267)
        (xy 25.024488 85.249267)
        (xy 25.03437 85.261756)
        (xy 25.190737 85.366237)
        (xy 25.20085 85.371728)
        (xy 25.389495 85.452776)
        (xy 25.400428 85.456328)
        (xy 25.600683 85.501642)
        (xy 25.612092 85.503144)
        (xy 25.817253 85.511204)
        (xy 25.828735 85.510602)
        (xy 26.031932 85.481141)
        (xy 26.043115 85.478456)
        (xy 26.237537 85.412458)
        (xy 26.24804 85.407782)
        (xy 26.427178 85.30746)
        (xy 26.436672 85.300935)
        (xy 26.486978 85.259095)
        (xy 26.49543 85.24651)
        (xy 26.489257 85.235862)
        (xy 26.464835 85.21144)
        (xy 53.646901 85.21144)
        (xy 53.648065 85.220342)
        (xy 53.648065 85.220345)
        (xy 53.662468 85.330489)
        (xy 53.662469 85.330493)
        (xy 53.663633 85.339394)
        (xy 53.715605 85.45751)
        (xy 53.721382 85.464383)
        (xy 53.721383 85.464384)
        (xy 53.75134 85.500022)
        (xy 53.798639 85.556291)
        (xy 53.829092 85.576562)
        (xy 53.876536 85.608143)
        (xy 53.90606 85.627796)
        (xy 54.029233 85.666278)
        (xy 54.038203 85.666442)
        (xy 54.038207 85.666443)
        (xy 54.096942 85.667519)
        (xy 54.158255 85.668643)
        (xy 54.220505 85.651671)
        (xy 54.274092 85.637062)
        (xy 54.274093 85.637062)
        (xy 54.282755 85.6347)
        (xy 54.290405 85.630003)
        (xy 54.290407 85.630002)
        (xy 54.385072 85.571878)
        (xy 54.385075 85.571875)
        (xy 54.392724 85.567179)
        (xy 54.39875 85.560522)
        (xy 54.4733 85.478161)
        (xy 54.473303 85.478157)
        (xy 54.479322 85.471507)
        (xy 54.535588 85.355375)
        (xy 54.539412 85.332649)
        (xy 54.55619 85.232917)
        (xy 54.556997 85.22812)
        (xy 54.557133 85.217)
        (xy 54.548044 85.153535)
        (xy 54.547672 85.15094)
        (xy 58.218901 85.15094)
        (xy 58.220065 85.159842)
        (xy 58.220065 85.159845)
        (xy 58.234468 85.269989)
        (xy 58.234469 85.269993)
        (xy 58.235633 85.278894)
        (xy 58.287605 85.39701)
        (xy 58.370639 85.495791)
        (xy 58.378116 85.500768)
        (xy 58.467884 85.560522)
        (xy 58.47806 85.567296)
        (xy 58.601233 85.605778)
        (xy 58.610203 85.605942)
        (xy 58.610207 85.605943)
        (xy 58.668942 85.607019)
        (xy 58.730255 85.608143)
        (xy 58.792505 85.591171)
        (xy 58.846092 85.576562)
        (xy 58.846093 85.576562)
        (xy 58.854755 85.5742)
        (xy 58.862405 85.569503)
        (xy 58.862407 85.569502)
        (xy 58.957072 85.511378)
        (xy 58.957075 85.511375)
        (xy 58.964724 85.506679)
        (xy 58.97075 85.500022)
        (xy 59.0453 85.417661)
        (xy 59.045303 85.417657)
        (xy 59.051322 85.411007)
        (xy 59.107588 85.294875)
        (xy 59.128997 85.16762)
        (xy 59.129002 85.167212)
        (xy 59.154566 85.102287)
        (xy 59.164956 85.090515)
        (xy 60.424252 83.831219)
        (xy 60.426286 83.829463)
        (xy 60.431069 83.827125)
        (xy 60.464373 83.791223)
        (xy 60.467653 83.787818)
        (xy 60.481048 83.774423)
        (xy 60.483772 83.770453)
        (xy 60.486097 83.767805)
        (xy 60.49929 83.753582)
        (xy 60.507201 83.745054)
        (xy 60.511513 83.734247)
        (xy 60.514032 83.730262)
        (xy 60.519804 83.719453)
        (xy 60.521711 83.715148)
        (xy 60.528293 83.705554)
        (xy 60.533986 83.681564)
        (xy 60.539551 83.663968)
        (xy 60.545386 83.649342)
        (xy 60.548683 83.641078)
        (xy 60.5493 83.634785)
        (xy 60.5493 83.631703)
        (xy 60.54945 83.628633)
        (xy 60.549666 83.628644)
        (xy 60.550998 83.617269)
        (xy 60.551453 83.607955)
        (xy 60.55414 83.596634)
        (xy 60.55108 83.574145)
        (xy 60.550451 83.569527)
        (xy 60.5493 83.552536)
        (xy 60.5493 82.987937)
        (xy 64.908401 82.987937)
        (xy 64.909565 82.996839)
        (xy 64.909565 82.996842)
        (xy 64.923968 83.106986)
        (xy 64.923969 83.10699)
        (xy 64.925133 83.115891)
        (xy 64.938678 83.146674)
        (xy 64.973155 83.225029)
        (xy 64.977105 83.234007)
        (xy 64.982882 83.24088)
        (xy 64.982883 83.240881)
        (xy 65.044449 83.314123)
        (xy 65.060139 83.332788)
        (xy 65.067615 83.337765)
        (xy 65.067618 83.337767)
        (xy 65.141245 83.386777)
        (xy 65.186868 83.441174)
        (xy 65.19584 83.511601)
        (xy 65.185483 83.545211)
        (xy 65.178571 83.559932)
        (xy 65.172256 83.600491)
        (xy 65.160099 83.678567)
        (xy 65.160099 83.678571)
        (xy 65.158718 83.68744)
        (xy 65.159882 83.696342)
        (xy 65.159882 83.696345)
        (xy 65.174285 83.806489)
        (xy 65.174286 83.806493)
        (xy 65.17545 83.815394)
        (xy 65.227422 83.93351)
        (xy 65.310456 84.032291)
        (xy 65.417877 84.103796)
        (xy 65.491585 84.126824)
        (xy 65.529966 84.138815)
        (xy 65.54105 84.142278)
        (xy 65.55002 84.142442)
        (xy 65.550024 84.142443)
        (xy 65.608759 84.143519)
        (xy 65.670072 84.144643)
        (xy 65.764209 84.118978)
        (xy 65.785909 84.113062)
        (xy 65.78591 84.113062)
        (xy 65.794572 84.1107)
        (xy 65.802222 84.106003)
        (xy 65.802224 84.106002)
        (xy 65.850927 84.076098)
        (xy 65.904541 84.043179)
        (xy 65.905144 84.044161)
        (xy 65.962464 84.019432)
        (xy 65.977761 84.0185)
        (xy 69.19232 84.0185)
        (xy 69.262139 84.039613)
        (xy 69.35856 84.103796)
        (xy 69.432268 84.126824)
        (xy 69.470649 84.138815)
        (xy 69.481733 84.142278)
        (xy 69.490703 84.142442)
        (xy 69.490707 84.142443)
        (xy 69.549442 84.143519)
        (xy 69.610755 84.144643)
        (xy 69.704892 84.118978)
        (xy 69.726592 84.113062)
        (xy 69.726593 84.113062)
        (xy 69.735255 84.1107)
        (xy 69.742905 84.106003)
        (xy 69.742907 84.106002)
        (xy 69.837572 84.047878)
        (xy 69.837575 84.047875)
        (xy 69.845224 84.043179)
        (xy 69.85125 84.036522)
        (xy 69.9258 83.954161)
        (xy 69.925803 83.954157)
        (xy 69.931822 83.947507)
        (xy 69.988088 83.831375)
        (xy 69.996979 83.77853)
        (xy 70.00869 83.708917)
        (xy 70.009497 83.70412)
        (xy 70.009633 83.693)
        (xy 70.001133 83.633648)
        (xy 69.992612 83.574145)
        (xy 69.992611 83.574142)
        (xy 69.991339 83.565259)
        (xy 69.985554 83.552536)
        (xy 69.941645 83.455962)
        (xy 69.941643 83.455959)
        (xy 69.937928 83.447788)
        (xy 69.901049 83.404988)
        (xy 69.859551 83.356826)
        (xy 69.859549 83.356824)
        (xy 69.853693 83.350028)
        (xy 69.745406 83.279841)
        (xy 69.736811 83.277271)
        (xy 69.73681 83.27727)
        (xy 69.630374 83.245438)
        (xy 69.630372 83.245438)
        (xy 69.621773 83.242866)
        (xy 69.612798 83.242811)
        (xy 69.612797 83.242811)
        (xy 69.558141 83.242477)
        (xy 69.492731 83.242078)
        (xy 69.480975 83.245438)
        (xy 69.377286 83.275072)
        (xy 69.377284 83.275073)
        (xy 69.368655 83.277539)
        (xy 69.361066 83.282327)
        (xy 69.36106 83.28233)
        (xy 69.308875 83.315257)
        (xy 69.24059 83.334692)
        (xy 69.172638 83.314123)
        (xy 69.126594 83.260083)
        (xy 69.117075 83.189727)
        (xy 69.128246 83.153759)
        (xy 69.140104 83.129283)
        (xy 69.144017 83.121207)
        (xy 69.14641 83.106986)
        (xy 69.164619 82.998749)
        (xy 69.165426 82.993952)
        (xy 69.165562 82.982832)
        (xy 69.157286 82.925045)
        (xy 69.148541 82.863977)
        (xy 69.14854 82.863974)
        (xy 69.147268 82.855091)
        (xy 69.127474 82.811556)
        (xy 69.097574 82.745794)
        (xy 69.097572 82.745791)
        (xy 69.093857 82.73762)
        (xy 69.068054 82.707674)
        (xy 69.01548 82.646658)
        (xy 69.015478 82.646656)
        (xy 69.009622 82.63986)
        (xy 68.901335 82.569673)
        (xy 68.89274 82.567103)
        (xy 68.892739 82.567102)
        (xy 68.786303 82.53527)
        (xy 68.786301 82.53527)
        (xy 68.777702 82.532698)
        (xy 68.768727 82.532643)
        (xy 68.768726 82.532643)
        (xy 68.71407 82.532309)
        (xy 68.64866 82.53191)
        (xy 68.586622 82.549641)
        (xy 68.533215 82.564904)
        (xy 68.533213 82.564905)
        (xy 68.524584 82.567371)
        (xy 68.516994 82.57216)
        (xy 68.428733 82.627849)
        (xy 68.415448 82.636231)
        (xy 68.409505 82.64296)
        (xy 68.409504 82.642961)
        (xy 68.345963 82.714908)
        (xy 68.285878 82.752726)
        (xy 68.251522 82.7575)
        (xy 65.812622 82.7575)
        (xy 65.744501 82.737498)
        (xy 65.717168 82.713747)
        (xy 65.66855 82.657322)
        (xy 65.668549 82.657321)
        (xy 65.662693 82.650525)
        (xy 65.554406 82.580338)
        (xy 65.545811 82.577768)
        (xy 65.54581 82.577767)
        (xy 65.439374 82.545935)
        (xy 65.439372 82.545935)
        (xy 65.430773 82.543363)
        (xy 65.421798 82.543308)
        (xy 65.421797 82.543308)
        (xy 65.367141 82.542974)
        (xy 65.301731 82.542575)
        (xy 65.242368 82.559541)
        (xy 65.186286 82.575569)
        (xy 65.186284 82.57557)
        (xy 65.177655 82.578036)
        (xy 65.170065 82.582825)
        (xy 65.085679 82.636069)
        (xy 65.068519 82.646896)
        (xy 65.062576 82.653625)
        (xy 65.062575 82.653626)
        (xy 65.059311 82.657322)
        (xy 64.983096 82.743619)
        (xy 64.979282 82.751742)
        (xy 64.979281 82.751744)
        (xy 64.95381 82.805996)
        (xy 64.928254 82.860429)
        (xy 64.926874 82.869295)
        (xy 64.909782 82.979064)
        (xy 64.909782 82.979068)
        (xy 60.5493 82.582334)
        (xy 60.569302 82.514213)
        (xy 60.581878 82.497788)
        (xy 60.626122 82.448907)
        (xy 60.682388 82.332775)
        (xy 60.684913 82.31777)
        (xy 60.70299 82.210317)
        (xy 60.703797 82.20552)
        (xy 60.703933 82.1944)
        (xy 60.693693 82.122894)
        (xy 60.686912 82.075545)
        (xy 60.686911 82.075542)
        (xy 60.685639 82.066659)
        (xy 60.679524 82.053209)
        (xy 60.635945 81.957362)
        (xy 60.635943 81.957359)
        (xy 60.632228 81.949188)
        (xy 60.589614 81.899732)
        (xy 60.553851 81.858226)
        (xy 60.553849 81.858224)
        (xy 60.547993 81.851428)
        (xy 60.439706 81.781241)
        (xy 60.431111 81.778671)
        (xy 60.43111 81.77867)
        (xy 60.324674 81.746838)
        (xy 60.324672 81.746838)
        (xy 60.316073 81.744266)
        (xy 60.307098 81.744211)
        (xy 60.307097 81.744211)
        (xy 60.252441 81.743877)
        (xy 60.187031 81.743478)
        (xy 60.133606 81.758747)
        (xy 60.071586 81.776472)
        (xy 60.071584 81.776473)
        (xy 60.062955 81.778939)
        (xy 60.055365 81.783728)
        (xy 59.984912 81.828181)
        (xy 59.953819 81.847799)
        (xy 59.947876 81.854528)
        (xy 59.947875 81.854529)
        (xy 59.931893 81.872625)
        (xy 59.868396 81.944522)
        (xy 59.864582 81.952645)
        (xy 59.864581 81.952647)
        (xy 59.842114 82.0005)
        (xy 59.813554 82.061332)
        (xy 59.808944 82.090941)
        (xy 59.795082 82.179967)
        (xy 59.795082 82.179971)
        (xy 59.793701 82.18884)
        (xy 59.794865 82.197742)
        (xy 59.794865 82.197745)
        (xy 59.809268 82.307889)
        (xy 59.809269 82.307893)
        (xy 59.810433 82.316794)
        (xy 59.862405 82.43491)
        (xy 59.868182 82.441783)
        (xy 59.868183 82.441784)
        (xy 59.918751 82.501942)
        (xy 59.947272 82.566958)
        (xy 59.9483 82.583017)
        (xy 59.9483 83.405039)
        (xy 59.928298 83.47316)
        (xy 59.911395 83.494134)
        (xy 58.736643 84.668886)
        (xy 58.674331 84.702912)
        (xy 58.64678 84.705789)
        (xy 58.612231 84.705578)
        (xy 58.568841 84.717979)
        (xy 58.496786 84.738572)
        (xy 58.496784 84.738573)
        (xy 58.488155 84.741039)
        (xy 58.379019 84.809899)
        (xy 58.373076 84.816628)
        (xy 58.373075 84.816629)
        (xy 58.336747 84.857763)
        (xy 58.293596 84.906622)
        (xy 58.289782 84.914745)
        (xy 58.289781 84.914747)
        (xy 58.26835 84.960394)
        (xy 58.238754 85.023432)
        (xy 58.237374 85.032298)
        (xy 58.220282 85.142067)
        (xy 58.220282 85.142071)
        (xy 54.540112 85.098145)
        (xy 54.540111 85.098142)
        (xy 54.538839 85.089259)
        (xy 54.523305 85.055094)
        (xy 54.489145 84.979962)
        (xy 54.489143 84.979959)
        (xy 54.485428 84.971788)
        (xy 54.479569 84.964989)
        (xy 54.479567 84.964985)
        (xy 54.458047 84.940011)
        (xy 54.428733 84.875349)
        (xy 54.4275 84.857763)
        (xy 54.4275 82.360815)
        (xy 54.447502 82.292694)
        (xy 54.46008 82.276265)
        (xy 54.479322 82.255007)
        (xy 54.535588 82.138875)
        (xy 54.543626 82.091101)
        (xy 54.55619 82.016417)
        (xy 54.556997 82.01162)
        (xy 54.557133 82.0005)
        (xy 54.538839 81.872759)
        (xy 54.532231 81.858226)
        (xy 54.489145 81.763462)
        (xy 54.489143 81.763459)
        (xy 54.485428 81.755288)
        (xy 54.437229 81.69935)
        (xy 54.407051 81.664326)
        (xy 54.407049 81.664324)
        (xy 54.401193 81.657528)
        (xy 54.292906 81.587341)
        (xy 54.284311 81.584771)
        (xy 54.28431 81.58477)
        (xy 54.177874 81.552938)
        (xy 54.177872 81.552938)
        (xy 54.169273 81.550366)
        (xy 54.160298 81.550311)
        (xy 54.160297 81.550311)
        (xy 54.105641 81.549977)
        (xy 54.040231 81.549578)
        (xy 54.028475 81.552938)
        (xy 53.924786 81.582572)
        (xy 53.924784 81.582573)
        (xy 53.916155 81.585039)
        (xy 53.908565 81.589828)
        (xy 53.814752 81.64902)
        (xy 53.807019 81.653899)
        (xy 53.801076 81.660628)
        (xy 53.801075 81.660629)
        (xy 53.766878 81.69935)
        (xy 53.721596 81.750622)
        (xy 53.717782 81.758745)
        (xy 53.717781 81.758747)
        (xy 53.69726 81.802457)
        (xy 53.666754 81.867432)
        (xy 53.661725 81.899732)
        (xy 53.648282 81.986067)
        (xy 53.648282 81.986071)
        (xy 53.646901 81.99494)
        (xy 53.648065 82.003842)
        (xy 53.648065 82.003845)
        (xy 53.662468 82.113989)
        (xy 53.662469 82.113993)
        (xy 53.663633 82.122894)
        (xy 53.715605 82.24101)
        (xy 53.72138 82.24788)
        (xy 53.721383 82.247885)
        (xy 53.74695 82.2783)
        (xy 53.775472 82.343315)
        (xy 53.7765 82.359376)
        (xy 53.7765 84.857281)
        (xy 53.756498 84.925402)
        (xy 53.744942 84.940688)
        (xy 53.721596 84.967122)
        (xy 53.717782 84.975245)
        (xy 53.717781 84.975247)
        (xy 53.708893 84.994178)
        (xy 53.666754 85.083932)
        (xy 53.665374 85.092798)
        (xy 53.648282 85.202567)
        (xy 53.648282 85.202571)
        (xy 25.773812 84.520417)
        (xy 25.759868 84.512803)
        (xy 25.758035 84.512934)
        (xy 25.75142 84.517185)
        (xy 25.030684 85.237921)
        (xy 23.799689 85.176837)
        (xy 23.811487 85.16762)
        (xy 23.92224 85.08109)
        (xy 23.954303 85.05604)
        (xy 23.974797 85.032298)
        (xy 24.078485 84.912173)
        (xy 24.078485 84.912172)
        (xy 24.082509 84.907511)
        (xy 24.179425 84.736909)
        (xy 24.241358 84.550732)
        (xy 24.265949 84.356071)
        (xy 24.266341 84.328)
        (xy 24.263865 84.302745)
        (xy 24.576729 84.302745)
        (xy 24.590157 84.507615)
        (xy 24.591958 84.518985)
        (xy 24.642496 84.717979)
        (xy 24.646337 84.728826)
        (xy 24.732294 84.915282)
        (xy 24.738045 84.925243)
        (xy 24.829498 85.054646)
        (xy 24.840088 85.063035)
        (xy 24.853388 85.056007)
        (xy 25.568583 84.340812)
        (xy 25.574961 84.329132)
        (xy 25.945803 84.329132)
        (xy 25.945934 84.330965)
        (xy 25.950185 84.33758)
        (xy 26.667699 85.055094)
        (xy 26.681007 85.062361)
        (xy 26.691046 85.055239)
        (xy 26.733935 85.003672)
        (xy 26.74046 84.994178)
        (xy 26.840782 84.81504)
        (xy 26.845458 84.804537)
        (xy 26.911456 84.610115)
        (xy 26.914141 84.598932)
        (xy 26.943898 84.393695)
        (xy 26.944528 84.386312)
        (xy 26.945958 84.331704)
        (xy 26.945715 84.324305)
        (xy 26.92674 84.117798)
        (xy 26.924642 84.106477)
        (xy 26.868913 83.908878)
        (xy 26.864788 83.898131)
        (xy 26.77398 83.713991)
        (xy 26.76797 83.704183)
        (xy 26.691792 83.602169)
        (xy 26.680532 83.59372)
        (xy 26.668114 83.600491)
        (xy 25.953417 84.315188)
        (xy 25.576197 84.326868)
        (xy 25.576066 84.325035)
        (xy 25.571815 84.31842)
        (xy 24.854369 83.600974)
        (xy 24.841528 83.593962)
        (xy 24.830839 83.601757)
        (xy 24.770707 83.678035)
        (xy 24.764436 83.687691)
        (xy 24.668845 83.86938)
        (xy 24.664437 83.880023)
        (xy 24.603553 84.076098)
        (xy 24.601163 84.087342)
        (xy 24.57703 84.291244)
        (xy 24.247194 84.132728)
        (xy 24.245413 84.126829)
        (xy 24.245412 84.126824)
        (xy 24.192265 83.950793)
        (xy 24.190484 83.944894)
        (xy 24.09837 83.771653)
        (xy 23.974361 83.619602)
        (xy 23.82318 83.494535)
        (xy 23.665247 83.409141)
        (xy 25.025678 83.409141)
        (xy 25.031512 83.418907)
        (xy 25.748188 84.135583)
        (xy 25.762132 84.143197)
        (xy 25.763965 84.143066)
        (xy 25.77058 84.138815)
        (xy 26.489946 83.419449)
        (xy 26.49756 83.405505)
        (xy 26.497523 83.404988)
        (xy 26.491893 83.396593)
        (xy 26.486656 83.391753)
        (xy 26.477533 83.384752)
        (xy 26.303884 83.275187)
        (xy 26.293641 83.269969)
        (xy 26.102938 83.193886)
        (xy 26.09191 83.190619)
        (xy 25.890539 83.150564)
        (xy 25.879093 83.149361)
        (xy 25.673804 83.146674)
        (xy 25.662324 83.147577)
        (xy 25.459982 83.182346)
        (xy 25.448862 83.185326)
        (xy 25.256237 83.256389)
        (xy 25.245859 83.261339)
        (xy 25.069405 83.366317)
        (xy 25.060099 83.373079)
        (xy 25.034075 83.395902)
        (xy 23.650585 83.401213)
        (xy 23.537854 83.366317)
        (xy 23.469039 83.345015)
        (xy 23.469036 83.345014)
        (xy 23.463152 83.343193)
        (xy 23.457027 83.342549)
        (xy 23.457026 83.342549)
        (xy 23.274147 83.323327)
        (xy 23.274146 83.323327)
        (xy 23.268019 83.322683)
        (xy 23.154534 83.333011)
        (xy 23.078759 83.339907)
        (xy 23.078758 83.339907)
        (xy 23.072618 83.340466)
        (xy 23.066704 83.342207)
        (xy 23.066702 83.342207)
        (xy 23.011344 83.3585)
        (xy 22.884393 83.395864)
        (xy 22.878928 83.398721)
        (xy 22.715972 83.483912)
        (xy 22.715968 83.483915)
        (xy 22.710512 83.486767)
        (xy 22.705712 83.490627)
        (xy 22.705711 83.490627)
        (xy 22.679625 83.511601)
        (xy 22.5576 83.609711)
        (xy 22.43148 83.760016)
        (xy 22.428516 83.765408)
        (xy 22.428513 83.765412)
        (xy 22.378549 83.856297)
        (xy 22.336956 83.931954)
        (xy 22.277628 84.118978)
        (xy 15.189373 82.805996)
        (xy 35.097345 82.805996)
        (xy 35.098509 82.814898)
        (xy 35.098509 82.814901)
        (xy 35.112912 82.925045)
        (xy 35.112913 82.925049)
        (xy 35.114077 82.93395)
        (xy 35.166049 83.052066)
        (xy 35.171826 83.058939)
        (xy 35.171827 83.05894)
        (xy 35.243303 83.143971)
        (xy 35.249083 83.150847)
        (xy 35.356504 83.222352)
        (xy 35.479677 83.260834)
        (xy 35.488647 83.260998)
        (xy 35.488651 83.260999)
        (xy 35.547386 83.262075)
        (xy 35.608699 83.263199)
        (xy 35.683279 83.242866)
        (xy 35.724536 83.231618)
        (xy 35.724537 83.231618)
        (xy 35.733199 83.229256)
        (xy 35.740849 83.224559)
        (xy 35.740851 83.224558)
        (xy 35.835516 83.166434)
        (xy 35.835519 83.166431)
        (xy 35.843168 83.161735)
        (xy 35.850388 83.153759)
        (xy 35.923744 83.072717)
        (xy 35.923747 83.072713)
        (xy 35.929766 83.066063)
        (xy 35.986032 82.949931)
        (xy 36.007441 82.822676)
        (xy 36.007577 82.811556)
        (xy 35.989283 82.683815)
        (xy 35.983168 82.670365)
        (xy 35.939589 82.574518)
        (xy 35.939587 82.574515)
        (xy 35.935872 82.566344)
        (xy 35.926198 82.555116)
        (xy 35.896883 82.490455)
        (xy 35.90718 82.420209)
        (xy 35.932554 82.383772)
        (xy 36.599485 81.716841)
        (xy 36.661797 81.682815)
        (xy 36.732612 81.68788)
        (xy 36.789448 81.730427)
        (xy 36.814259 81.796947)
        (xy 36.811662 81.82792)
        (xy 36.811558 81.828181)
        (xy 36.810941 81.834474)
        (xy 36.810941 81.837556)
        (xy 36.810791 81.840626)
        (xy 36.810575 81.840615)
        (xy 36.809243 81.85199)
        (xy 36.808787 81.861305)
        (xy 36.806101 81.872625)
        (xy 36.80767 81.884154)
        (xy 36.80767 81.884155)
        (xy 36.80979 81.899732)
        (xy 36.810941 81.916723)
        (xy 36.810941 82.007533)
        (xy 36.790939 82.075654)
        (xy 36.779383 82.090939)
        (xy 36.731037 82.145681)
        (xy 36.727223 82.153804)
        (xy 36.727222 82.153806)
        (xy 36.702943 82.20552)
        (xy 36.676195 82.262491)
        (xy 36.669127 82.307889)
        (xy 36.657723 82.381126)
        (xy 36.657723 82.38113)
        (xy 36.656342 82.389999)
        (xy 36.657506 82.398901)
        (xy 36.657506 82.398904)
        (xy 36.671909 82.509048)
        (xy 36.67191 82.509052)
        (xy 36.673074 82.517953)
        (xy 36.725046 82.636069)
        (xy 36.730823 82.642942)
        (xy 36.730824 82.642943)
        (xy 36.768155 82.687354)
        (xy 36.80808 82.73485)
        (xy 36.915501 82.806355)
        (xy 37.038674 82.844837)
        (xy 37.047644 82.845001)
        (xy 37.047648 82.845002)
        (xy 37.106383 82.846078)
        (xy 37.167696 82.847202)
        (xy 37.24006 82.827473)
        (xy 37.283533 82.815621)
        (xy 37.283534 82.815621)
        (xy 37.292196 82.813259)
        (xy 37.299846 82.808562)
        (xy 37.299848 82.808561)
        (xy 37.394513 82.750437)
        (xy 37.394516 82.750434)
        (xy 37.402165 82.745738)
        (xy 37.409513 82.73762)
        (xy 37.482741 82.65672)
        (xy 37.482744 82.656716)
        (xy 37.488763 82.650066)
        (xy 37.545029 82.533934)
        (xy 37.547381 82.519958)
        (xy 37.565631 82.411476)
        (xy 37.566438 82.406679)
        (xy 37.566574 82.395559)
        (xy 37.555294 82.316794)
        (xy 37.549553 82.276704)
        (xy 37.549552 82.276701)
        (xy 37.54828 82.267818)
        (xy 37.53488 82.238346)
        (xy 37.498586 82.158521)
        (xy 37.498584 82.158518)
        (xy 37.494869 82.150347)
        (xy 37.48901 82.143548)
        (xy 37.489008 82.143544)
        (xy 37.476046 82.128502)
        (xy 37.468829 82.120126)
        (xy 37.439515 82.055466)
        (xy 37.449813 81.98522)
        (xy 37.475187 81.948784)
        (xy 38.402452 81.021519)
        (xy 38.404486 81.019763)
        (xy 38.409269 81.017425)
        (xy 38.442573 80.981523)
        (xy 38.445853 80.978118)
        (xy 38.459248 80.964723)
        (xy 38.461972 80.960753)
        (xy 38.464297 80.958105)
        (xy 38.47749 80.943882)
        (xy 38.485401 80.935354)
        (xy 38.489713 80.924547)
        (xy 38.492232 80.920562)
        (xy 38.498004 80.909753)
        (xy 38.499911 80.905448)
        (xy 38.506493 80.895854)
        (xy 38.512186 80.871864)
        (xy 38.517751 80.854268)
        (xy 38.523586 80.839642)
        (xy 38.526883 80.831378)
        (xy 38.5275 80.825085)
        (xy 38.5275 80.822003)
        (xy 38.52765 80.818933)
        (xy 38.527866 80.818944)
        (xy 38.529198 80.807569)
        (xy 38.529653 80.798255)
        (xy 38.53234 80.786934)
        (xy 38.528651 80.759827)
        (xy 38.5275 80.742836)
        (xy 38.5275 79.49644)
        (xy 59.869901 79.49644)
        (xy 59.871065 79.505342)
        (xy 59.871065 79.505345)
        (xy 59.885468 79.615489)
        (xy 59.885469 79.615493)
        (xy 59.886633 79.624394)
        (xy 59.938605 79.74251)
        (xy 59.944382 79.749383)
        (xy 59.944383 79.749384)
        (xy 60.007477 79.824443)
        (xy 60.021639 79.841291)
        (xy 60.12906 79.912796)
        (xy 60.252233 79.951278)
        (xy 60.261203 79.951442)
        (xy 60.261207 79.951443)
        (xy 60.319942 79.952519)
        (xy 60.381255 79.953643)
        (xy 60.443505 79.936671)
        (xy 60.497092 79.922062)
        (xy 60.497093 79.922062)
        (xy 60.505755 79.9197)
        (xy 60.513405 79.915003)
        (xy 60.513407 79.915002)
        (xy 60.608072 79.856878)
        (xy 60.608075 79.856875)
        (xy 60.615724 79.852179)
        (xy 60.62175 79.845522)
        (xy 60.6963 79.763161)
        (xy 60.696303 79.763157)
        (xy 60.702322 79.756507)
        (xy 60.758588 79.640375)
        (xy 60.760417 79.629507)
        (xy 60.774032 79.548575)
        (xy 60.805058 79.484717)
        (xy 60.817294 79.472958)
        (xy 60.823749 79.467541)
        (xy 60.832194 79.460455)
        (xy 60.837704 79.450912)
        (xy 60.837707 79.450908)
        (xy 60.851036 79.427821)
        (xy 60.856941 79.418551)
        (xy 60.872232 79.396713)
        (xy 60.878554 79.387684)
        (xy 60.881407 79.377036)
        (xy 60.882886 79.373865)
        (xy 60.884079 79.370588)
        (xy 60.889588 79.361045)
        (xy 60.891501 79.350194)
        (xy 60.895273 79.339832)
        (xy 60.897094 79.340495)
        (xy 60.9226 79.289038)
        (xy 60.983516 79.252572)
        (xy 61.054476 79.254828)
        (xy 61.093557 79.277386)
        (xy 61.093583 79.277347)
        (xy 61.094186 79.277749)
        (xy 61.094193 79.277753)
        (xy 61.201004 79.348852)
        (xy 61.324177 79.387334)
        (xy 61.333147 79.387498)
        (xy 61.333151 79.387499)
        (xy 61.391886 79.388575)
        (xy 61.453199 79.389699)
        (xy 61.529371 79.368932)
        (xy 61.569036 79.358118)
        (xy 61.569037 79.358118)
        (xy 61.577699 79.355756)
        (xy 61.585349 79.351059)
        (xy 61.585351 79.351058)
        (xy 61.680016 79.292934)
        (xy 61.680019 79.292931)
        (xy 61.687668 79.288235)
        (xy 61.694571 79.280609)
        (xy 61.768244 79.199217)
        (xy 61.768247 79.199213)
        (xy 61.774266 79.192563)
        (xy 61.830532 79.076431)
        (xy 61.833298 79.059993)
        (xy 61.851134 78.953973)
        (xy 61.851941 78.949176)
        (xy 61.852077 78.938056)
        (xy 61.840817 78.859432)
        (xy 61.835056 78.819201)
        (xy 61.835055 78.819198)
        (xy 61.833783 78.810315)
        (xy 61.806985 78.751375)
        (xy 61.784089 78.701018)
        (xy 61.784087 78.701015)
        (xy 61.780372 78.692844)
        (xy 61.727991 78.632052)
        (xy 61.698677 78.56739)
        (xy 61.697444 78.549805)
        (xy 61.697444 78.352717)
        (xy 61.717446 78.284596)
        (xy 61.734349 78.263622)
        (xy 64.092408 75.905564)
        (xy 64.15472 75.871538)
        (xy 64.167626 75.870272)
        (xy 64.167549 75.869655)
        (xy 64.176456 75.868545)
        (xy 64.185433 75.86871)
        (xy 64.247683 75.851739)
        (xy 64.30127 75.837129)
        (xy 64.301271 75.837129)
        (xy 64.309933 75.834767)
        (xy 64.317583 75.83007)
        (xy 64.317585 75.830069)
        (xy 64.41225 75.771945)
        (xy 64.412253 75.771942)
        (xy 64.419902 75.767246)
        (xy 64.435634 75.749866)
        (xy 64.500478 75.678228)
        (xy 64.500481 75.678224)
        (xy 64.5065 75.671574)
        (xy 64.562766 75.555442)
        (xy 64.584175 75.428187)
        (xy 64.584311 75.417067)
        (xy 64.576657 75.36362)
        (xy 64.56729 75.298212)
        (xy 64.567289 75.298209)
        (xy 64.566017 75.289326)
        (xy 64.562303 75.281157)
        (xy 64.516323 75.180029)
        (xy 64.516321 75.180026)
        (xy 64.512606 75.171855)
        (xy 64.454368 75.104266)
        (xy 64.434229 75.080893)
        (xy 64.434227 75.080891)
        (xy 64.428371 75.074095)
        (xy 64.320084 75.003908)
        (xy 64.311489 75.001338)
        (xy 64.311488 75.001337)
        (xy 64.205052 74.969505)
        (xy 64.20505 74.969505)
        (xy 64.196451 74.966933)
        (xy 64.187476 74.966878)
        (xy 64.186852 74.966785)
        (xy 64.122436 74.936932)
        (xy 64.084386 74.876993)
        (xy 64.080751 74.860032)
        (xy 64.072667 74.803588)
        (xy 64.071395 74.794703)
        (xy 64.06528 74.781253)
        (xy 64.021701 74.685406)
        (xy 64.021699 74.685403)
        (xy 64.017984 74.677232)
        (xy 63.933749 74.579472)
        (xy 63.825462 74.509285)
        (xy 63.816867 74.506715)
        (xy 63.816866 74.506714)
        (xy 63.71043 74.474882)
        (xy 63.710428 74.474882)
        (xy 63.701829 74.47231)
        (xy 63.692854 74.472255)
        (xy 63.692853 74.472255)
        (xy 63.638197 74.471921)
        (xy 63.572787 74.471522)
        (xy 63.561031 74.474882)
        (xy 63.457342 74.504516)
        (xy 63.45734 74.504517)
        (xy 63.448711 74.506983)
        (xy 63.339575 74.575843)
        (xy 63.254152 74.672566)
        (xy 63.250338 74.680689)
        (xy 63.250337 74.680691)
        (xy 63.22435 74.736042)
        (xy 63.19931 74.789376)
        (xy 63.188309 74.860032)
        (xy 63.185722 74.876647)
        (xy 63.155478 74.940879)
        (xy 63.150317 74.946357)
        (xy 60.362785 77.733889)
        (xy 60.354681 77.741316)
        (xy 60.325806 77.765545)
        (xy 60.320293 77.775094)
        (xy 60.306961 77.798185)
        (xy 60.301055 77.807456)
        (xy 60.279446 77.838316)
        (xy 60.276592 77.848966)
        (xy 60.275115 77.852134)
        (xy 60.273923 77.85541)
        (xy 60.268412 77.864955)
        (xy 60.262462 77.898699)
        (xy 60.26187 77.902058)
        (xy 60.259492 77.912785)
        (xy 60.249736 77.949193)
        (xy 60.250697 77.960178)
        (xy 60.250697 77.96018)
        (xy 60.25302 77.986728)
        (xy 60.2535 77.99771)
        (xy 60.2535 78.958825)
        (xy 60.233498 79.026946)
        (xy 60.179842 79.073439)
        (xy 60.162125 79.079974)
        (xy 60.139155 79.086539)
        (xy 60.030019 79.155399)
        (xy 60.024076 79.162128)
        (xy 60.024075 79.162129)
        (xy 60.009321 79.178835)
        (xy 59.944596 79.252122)
        (xy 59.940782 79.260245)
        (xy 59.940781 79.260247)
        (xy 59.932564 79.277749)
        (xy 59.889754 79.368932)
        (xy 59.882028 79.418551)
        (xy 59.871282 79.487567)
        (xy 59.871282 79.487571)
        (xy 38.5275 78.746934)
        (xy 38.547502 78.678813)
        (xy 38.560078 78.662388)
        (xy 38.604322 78.613507)
        (xy 38.660588 78.497375)
        (xy 38.662627 78.485259)
        (xy 38.68119 78.374917)
        (xy 38.681997 78.37012)
        (xy 38.682133 78.359)
        (xy 38.671893 78.2875)
        (xy 38.665112 78.240145)
        (xy 38.665111 78.240142)
        (xy 38.663839 78.231259)
        (xy 38.657724 78.217809)
        (xy 38.614145 78.121962)
        (xy 38.614143 78.121959)
        (xy 38.610428 78.113788)
        (xy 38.575614 78.073384)
        (xy 38.532051 78.022826)
        (xy 38.532049 78.022824)
        (xy 38.526193 78.016028)
        (xy 38.417906 77.945841)
        (xy 38.409311 77.943271)
        (xy 38.40931 77.94327)
        (xy 38.302874 77.911438)
        (xy 38.302872 77.911438)
        (xy 38.294273 77.908866)
        (xy 38.285298 77.908811)
        (xy 38.285297 77.908811)
        (xy 38.230641 77.908477)
        (xy 38.165231 77.908078)
        (xy 38.103193 77.925808)
        (xy 38.049786 77.941072)
        (xy 38.049784 77.941073)
        (xy 38.041155 77.943539)
        (xy 37.932019 78.012399)
        (xy 37.926996 78.018087)
        (xy 37.862792 78.046721)
        (xy 37.792611 78.035993)
        (xy 37.767051 78.019344)
        (xy 37.764193 78.016028)
        (xy 37.655906 77.945841)
        (xy 37.647311 77.943271)
        (xy 37.64731 77.94327)
        (xy 37.540874 77.911438)
        (xy 37.540872 77.911438)
        (xy 37.532273 77.908866)
        (xy 37.523298 77.908811)
        (xy 37.523297 77.908811)
        (xy 37.468641 77.908477)
        (xy 37.403231 77.908078)
        (xy 37.341193 77.925808)
        (xy 37.287786 77.941072)
        (xy 37.287784 77.941073)
        (xy 37.279155 77.943539)
        (xy 37.271565 77.948328)
        (xy 37.1933 77.99771)
        (xy 37.170019 78.012399)
        (xy 37.084596 78.109122)
        (xy 37.080782 78.117245)
        (xy 37.080781 78.117247)
        (xy 37.066553 78.147552)
        (xy 37.029754 78.225932)
        (xy 37.020626 78.284558)
        (xy 37.011282 78.344567)
        (xy 37.011282 78.344571)
        (xy 37.009901 78.35344)
        (xy 37.011065 78.362342)
        (xy 37.011065 78.362345)
        (xy 37.025468 78.472489)
        (xy 37.025469 78.472493)
        (xy 37.026633 78.481394)
        (xy 37.078605 78.59951)
        (xy 37.08438 78.60638)
        (xy 37.084383 78.606385)
        (xy 37.10995 78.6368)
        (xy 37.138472 78.701815)
        (xy 37.1395 78.717876)
        (xy 37.1395 80.203984)
        (xy 37.119498 80.272105)
        (xy 37.102595 80.293079)
        (xy 35.336229 82.059445)
        (xy 35.328125 82.066872)
        (xy 35.29925 82.091101)
        (xy 35.293737 82.10065)
        (xy 35.280405 82.123741)
        (xy 35.274499 82.133012)
        (xy 35.25289 82.163872)
        (xy 35.250036 82.174522)
        (xy 35.248559 82.17769)
        (xy 35.247367 82.180966)
        (xy 35.241856 82.190511)
        (xy 35.23921 82.20552)
        (xy 35.235314 82.227614)
        (xy 35.232936 82.238341)
        (xy 35.22318 82.274749)
        (xy 35.224141 82.285734)
        (xy 35.224141 82.285736)
        (xy 35.226464 82.312284)
        (xy 35.226944 82.323266)
        (xy 35.226944 82.451837)
        (xy 35.206942 82.519958)
        (xy 35.195386 82.535244)
        (xy 35.17204 82.561678)
        (xy 35.168226 82.569801)
        (xy 35.168225 82.569803)
        (xy 35.162021 82.583017)
        (xy 35.117198 82.678488)
        (xy 35.109493 82.727974)
        (xy 35.098726 82.797123)
        (xy 35.098726 82.797127)
        (xy 15.189373 79.306343)
        (xy 19.259841 79.306343)
        (xy 19.261005 79.315245)
        (xy 19.261005 79.315248)
        (xy 19.275408 79.425392)
        (xy 19.275409 79.425396)
        (xy 19.276573 79.434297)
        (xy 19.328545 79.552413)
        (xy 19.334322 79.559286)
        (xy 19.334323 79.559287)
        (xy 19.38264 79.616767)
        (xy 19.411579 79.651194)
        (xy 19.519 79.722699)
        (xy 19.642173 79.761181)
        (xy 19.651143 79.761345)
        (xy 19.651147 79.761346)
        (xy 19.709882 79.762422)
        (xy 19.771195 79.763546)
        (xy 19.848353 79.74251)
        (xy 19.887032 79.731965)
        (xy 19.887033 79.731965)
        (xy 19.895695 79.729603)
        (xy 19.903345 79.724906)
        (xy 19.903347 79.724905)
        (xy 19.998012 79.666781)
        (xy 19.998015 79.666778)
        (xy 20.005664 79.662082)
        (xy 20.013117 79.653848)
        (xy 20.014917 79.652746)
        (xy 20.018595 79.649692)
        (xy 20.019036 79.650223)
        (xy 20.07366 79.616767)
        (xy 20.106532 79.612403)
        (xy 21.564806 79.612403)
        (xy 21.632927 79.632405)
        (xy 21.661256 79.657327)
        (xy 21.709139 79.714291)
        (xy 21.81656 79.785796)
        (xy 21.939733 79.824278)
        (xy 21.948703 79.824442)
        (xy 21.948707 79.824443)
        (xy 22.007442 79.825519)
        (xy 22.068755 79.826643)
        (xy 22.131005 79.809672)
        (xy 22.184592 79.795062)
        (xy 22.184593 79.795062)
        (xy 22.193255 79.7927)
        (xy 22.200905 79.788003)
        (xy 22.200907 79.788002)
        (xy 22.295572 79.729878)
        (xy 22.295575 79.729875)
        (xy 22.303224 79.725179)
        (xy 22.309972 79.717724)
        (xy 22.3838 79.636161)
        (xy 22.383803 79.636157)
        (xy 22.389822 79.629507)
        (xy 22.446088 79.513375)
        (xy 22.45091 79.484717)
        (xy 22.46669 79.390917)
        (xy 22.467497 79.38612)
        (xy 22.467633 79.375)
        (xy 22.449339 79.247259)
        (xy 22.427496 79.199217)
        (xy 22.399645 79.137962)
        (xy 22.399643 79.137959)
        (xy 22.395928 79.129788)
        (xy 22.390067 79.122986)
        (xy 22.385232 79.115426)
        (xy 22.386852 79.11439)
        (xy 22.362192 79.059993)
        (xy 22.372491 78.989747)
        (xy 22.393539 78.957859)
        (xy 22.475322 78.867507)
        (xy 22.531588 78.751375)
        (xy 22.540199 78.700195)
        (xy 22.55219 78.628917)
        (xy 22.552997 78.62412)
        (xy 22.553133 78.613)
        (xy 22.537731 78.50545)
        (xy 22.536112 78.494145)
        (xy 22.536111 78.494142)
        (xy 22.534839 78.485259)
        (xy 22.481428 78.367788)
        (xy 22.397193 78.270028)
        (xy 22.398692 78.268736)
        (xy 22.366677 78.218548)
        (xy 22.366916 78.147552)
        (xy 22.383234 78.112999)
        (xy 22.3838 78.11216)
        (xy 22.389822 78.105507)
        (xy 22.446088 77.989375)
        (xy 22.449641 77.96826)
        (xy 22.46669 77.866917)
        (xy 22.467497 77.86212)
        (xy 22.467633 77.851)
        (xy 22.460069 77.798185)
        (xy 22.450612 77.732145)
        (xy 22.450611 77.732142)
        (xy 22.449339 77.723259)
        (xy 22.395928 77.605788)
        (xy 22.344176 77.545726)
        (xy 22.317551 77.514826)
        (xy 22.317549 77.514824)
        (xy 22.311693 77.508028)
        (xy 22.203406 77.437841)
        (xy 22.194811 77.435271)
        (xy 22.19481 77.43527)
        (xy 22.088374 77.403438)
        (xy 22.088372 77.403438)
        (xy 22.079773 77.400866)
        (xy 22.070798 77.400811)
        (xy 22.070797 77.400811)
        (xy 22.016141 77.400477)
        (xy 21.950731 77.400078)
        (xy 21.938975 77.403438)
        (xy 21.835286 77.433072)
        (xy 21.835284 77.433073)
        (xy 21.826655 77.435539)
        (xy 21.717519 77.504399)
        (xy 21.711575 77.511129)
        (xy 21.704743 77.516944)
        (xy 21.703111 77.515026)
        (xy 21.654335 77.545726)
        (xy 21.619979 77.5505)
        (xy 20.907158 77.5505)
        (xy 20.839037 77.530498)
        (xy 20.824327 77.519447)
        (xy 20.81903 77.514826)
        (xy 20.813173 77.508028)
        (xy 20.704886 77.437841)
        (xy 20.696291 77.435271)
        (xy 20.69629 77.43527)
        (xy 20.589854 77.403438)
        (xy 20.589852 77.403438)
        (xy 20.581253 77.400866)
        (xy 20.572278 77.400811)
        (xy 20.572277 77.400811)
        (xy 20.517621 77.400477)
        (xy 20.452211 77.400078)
        (xy 20.440455 77.403438)
        (xy 20.336766 77.433072)
        (xy 20.336764 77.433073)
        (xy 20.328135 77.435539)
        (xy 20.218999 77.504399)
        (xy 20.213056 77.511128)
        (xy 20.213055 77.511129)
        (xy 20.205709 77.519447)
        (xy 20.133576 77.601122)
        (xy 20.129762 77.609245)
        (xy 20.129761 77.609247)
        (xy 20.103774 77.664598)
        (xy 20.078734 77.717932)
        (xy 20.075643 77.737786)
        (xy 20.060262 77.836567)
        (xy 20.060262 77.836571)
        (xy 20.058881 77.84544)
        (xy 20.060045 77.854342)
        (xy 20.060045 77.854345)
        (xy 20.074448 77.964489)
        (xy 20.074449 77.964493)
        (xy 20.075613 77.973394)
        (xy 20.08863 78.002978)
        (xy 20.097758 78.073384)
        (xy 20.067371 78.137549)
        (xy 20.007925 78.174872)
        (xy 19.937248 78.195071)
        (xy 19.937244 78.195073)
        (xy 19.928615 78.197539)
        (xy 19.921025 78.202328)
        (xy 19.829981 78.259773)
        (xy 19.819479 78.266399)
        (xy 19.734056 78.363122)
        (xy 19.730242 78.371245)
        (xy 19.730241 78.371247)
        (xy 19.704254 78.426598)
        (xy 19.679214 78.479932)
        (xy 19.677834 78.488798)
        (xy 19.660742 78.598567)
        (xy 19.660742 78.598571)
        (xy 19.659361 78.60744)
        (xy 19.660525 78.616342)
        (xy 19.660525 78.616345)
        (xy 19.676093 78.735394)
        (xy 19.674273 78.735632)
        (xy 19.673471 78.79566)
        (xy 19.634292 78.854867)
        (xy 19.587684 78.879697)
        (xy 19.537728 78.893974)
        (xy 19.537724 78.893976)
        (xy 19.529095 78.896442)
        (xy 19.419959 78.965302)
        (xy 19.334536 79.062025)
        (xy 19.279694 79.178835)
        (xy 19.278314 79.187701)
        (xy 19.261222 79.29747)
        (xy 19.261222 79.297474)
        (xy 15.189373 76.19444)
        (xy 34.867881 76.19444)
        (xy 34.869045 76.203342)
        (xy 34.869045 76.203345)
        (xy 34.883448 76.313489)
        (xy 34.883449 76.313493)
        (xy 34.884613 76.322394)
        (xy 34.936585 76.44051)
        (xy 34.942362 76.447383)
        (xy 34.942363 76.447384)
        (xy 35.005457 76.522443)
        (xy 35.019619 76.539291)
        (xy 35.12704 76.610796)
        (xy 35.250213 76.649278)
        (xy 35.259183 76.649442)
        (xy 35.259187 76.649443)
        (xy 35.317922 76.650519)
        (xy 35.379235 76.651643)
        (xy 35.441485 76.634672)
        (xy 35.495072 76.620062)
        (xy 35.495073 76.620062)
        (xy 35.503735 76.6177)
        (xy 35.511385 76.613003)
        (xy 35.511387 76.613002)
        (xy 35.606052 76.554878)
        (xy 35.606055 76.554875)
        (xy 35.613704 76.550179)
        (xy 35.621157 76.541945)
        (xy 35.622957 76.540843)
        (xy 35.626635 76.537789)
        (xy 35.627076 76.53832)
        (xy 35.6817 76.504864)
        (xy 35.714572 76.5005)
        (xy 36.692133 76.5005)
        (xy 36.694807 76.500696)
        (xy 36.699842 76.502425)
        (xy 36.711466 76.501989)
        (xy 36.722973 76.503688)
        (xy 36.722955 76.503813)
        (xy 36.752056 76.507695)
        (xy 36.798733 76.522278)
        (xy 36.807706 76.522442)
        (xy 36.807709 76.522443)
        (xy 36.864353 76.523481)
        (xy 36.927755 76.524643)
        (xy 37.009249 76.502425)
        (xy 37.043592 76.493062)
        (xy 37.043593 76.493062)
        (xy 37.052255 76.4907)
        (xy 37.059905 76.486003)
        (xy 37.059907 76.486002)
        (xy 37.154572 76.427878)
        (xy 37.154575 76.427875)
        (xy 37.162224 76.423179)
        (xy 37.16825 76.416522)
        (xy 37.2428 76.334161)
        (xy 37.242803 76.334157)
        (xy 37.248822 76.327507)
        (xy 37.305088 76.211375)
        (xy 37.326497 76.08412)
        (xy 37.326633 76.073)
        (xy 37.308339 75.945259)
        (xy 37.278762 75.880207)
        (xy 37.258645 75.835962)
        (xy 37.258643 75.835959)
        (xy 37.254928 75.827788)
        (xy 37.219646 75.786841)
        (xy 37.176551 75.736826)
        (xy 37.176549 75.736824)
        (xy 37.170693 75.730028)
        (xy 37.062406 75.659841)
        (xy 37.053811 75.657271)
        (xy 37.05381 75.65727)
        (xy 36.947374 75.625438)
        (xy 36.947372 75.625438)
        (xy 36.938773 75.622866)
        (xy 36.929798 75.622811)
        (xy 36.929797 75.622811)
        (xy 36.875141 75.622477)
        (xy 36.809731 75.622078)
        (xy 36.797975 75.625438)
        (xy 36.694286 75.655072)
        (xy 36.694284 75.655073)
        (xy 36.685655 75.657539)
        (xy 36.576519 75.726399)
        (xy 36.570576 75.733128)
        (xy 36.570575 75.733129)
        (xy 36.541984 75.765502)
        (xy 36.491096 75.823122)
        (xy 36.487281 75.831248)
        (xy 36.482353 75.83875)
        (xy 36.480166 75.837313)
        (xy 36.442202 75.880207)
        (xy 36.375198 75.8995)
        (xy 35.716158 75.8995)
        (xy 35.648037 75.879498)
        (xy 35.633327 75.868447)
        (xy 35.628032 75.863827)
        (xy 35.622173 75.857028)
        (xy 35.513886 75.786841)
        (xy 35.505291 75.784271)
        (xy 35.50529 75.78427)
        (xy 35.398854 75.752438)
        (xy 35.398852 75.752438)
        (xy 35.390253 75.749866)
        (xy 35.381278 75.749811)
        (xy 35.381277 75.749811)
        (xy 35.326621 75.749477)
        (xy 35.261211 75.749078)
        (xy 35.220935 75.760589)
        (xy 35.145766 75.782072)
        (xy 35.145764 75.782073)
        (xy 35.137135 75.784539)
        (xy 35.129545 75.789328)
        (xy 35.053494 75.837313)
        (xy 35.027999 75.853399)
        (xy 35.022056 75.860128)
        (xy 35.022055 75.860129)
        (xy 35.014709 75.868447)
        (xy 34.942576 75.950122)
        (xy 34.887734 76.066932)
        (xy 34.886354 76.075798)
        (xy 34.869262 76.185567)
        (xy 34.869262 76.185571)
        (xy 15.189373 75.34694)
        (xy 53.900901 75.34694)
        (xy 53.902065 75.355842)
        (xy 53.902065 75.355845)
        (xy 53.916468 75.465989)
        (xy 53.916469 75.465993)
        (xy 53.917633 75.474894)
        (xy 53.969605 75.59301)
        (xy 53.975382 75.599883)
        (xy 53.975383 75.599884)
        (xy 54.021773 75.655072)
        (xy 54.052639 75.691791)
        (xy 54.060116 75.696768)
        (xy 54.114741 75.733129)
        (xy 54.16006 75.763296)
        (xy 54.283233 75.801778)
        (xy 54.292203 75.801942)
        (xy 54.292207 75.801943)
        (xy 54.350942 75.803019)
        (xy 54.412255 75.804143)
        (xy 54.484161 75.784539)
        (xy 54.528092 75.772562)
        (xy 54.528093 75.772562)
        (xy 54.536755 75.7702)
        (xy 54.544405 75.765503)
        (xy 54.544407 75.765502)
        (xy 54.608092 75.726399)
        (xy 54.646724 75.702679)
        (xy 54.65275 75.696022)
        (xy 54.656604 75.692822)
        (xy 54.721793 75.664698)
        (xy 54.791838 75.676282)
        (xy 54.814143 75.691201)
        (xy 54.814639 75.691791)
        (xy 54.82211 75.696764)
        (xy 54.822111 75.696765)
        (xy 54.905748 75.752438)
        (xy 54.92206 75.763296)
        (xy 55.045233 75.801778)
        (xy 55.054203 75.801942)
        (xy 55.054207 75.801943)
        (xy 55.112942 75.803019)
        (xy 55.174255 75.804143)
        (xy 55.246161 75.784539)
        (xy 55.290092 75.772562)
        (xy 55.290093 75.772562)
        (xy 55.298755 75.7702)
        (xy 55.306405 75.765503)
        (xy 55.306407 75.765502)
        (xy 55.401072 75.707378)
        (xy 55.401075 75.707375)
        (xy 55.408724 75.702679)
        (xy 55.41492 75.695834)
        (xy 55.4893 75.613661)
        (xy 55.489303 75.613657)
        (xy 55.495322 75.607007)
        (xy 55.551588 75.490875)
        (xy 55.561328 75.432984)
        (xy 55.57219 75.368417)
        (xy 55.572997 75.36362)
        (xy 55.573133 75.3525)
        (xy 55.554839 75.224759)
        (xy 55.548724 75.211309)
        (xy 55.505145 75.115462)
        (xy 55.505143 75.115459)
        (xy 55.501428 75.107288)
        (xy 55.449047 75.046496)
        (xy 55.419733 74.981834)
        (xy 55.4185 74.964249)
        (xy 55.4185 74.241914)
        (xy 55.438502 74.173793)
        (xy 55.451078 74.157368)
        (xy 55.495322 74.108487)
        (xy 55.551588 73.992355)
        (xy 55.555849 73.967032)
        (xy 55.57219 73.869897)
        (xy 55.572997 73.8651)
        (xy 55.573133 73.85398)
        (xy 55.564058 73.790614)
        (xy 55.556112 73.735125)
        (xy 55.556111 73.735122)
        (xy 55.554839 73.726239)
        (xy 55.548724 73.712789)
        (xy 55.505145 73.616942)
        (xy 55.505143 73.616939)
        (xy 55.501428 73.608768)
        (xy 55.417193 73.511008)
        (xy 55.308906 73.440821)
        (xy 55.300311 73.438251)
        (xy 55.30031 73.43825)
        (xy 55.193874 73.406418)
        (xy 55.193872 73.406418)
        (xy 55.185273 73.403846)
        (xy 55.176298 73.403791)
        (xy 55.176297 73.403791)
        (xy 55.121641 73.403457)
        (xy 55.056231 73.403058)
        (xy 54.994193 73.420788)
        (xy 54.940786 73.436052)
        (xy 54.940784 73.436053)
        (xy 54.932155 73.438519)
        (xy 54.823019 73.507379)
        (xy 54.817996 73.513067)
        (xy 54.753792 73.541701)
        (xy 54.683611 73.530973)
        (xy 54.658051 73.514324)
        (xy 54.655193 73.511008)
        (xy 54.546906 73.440821)
        (xy 54.538311 73.438251)
        (xy 54.53831 73.43825)
        (xy 54.431874 73.406418)
        (xy 54.431872 73.406418)
        (xy 54.423273 73.403846)
        (xy 54.414298 73.403791)
        (xy 54.414297 73.403791)
        (xy 54.359641 73.403457)
        (xy 54.294231 73.403058)
        (xy 54.232193 73.420788)
        (xy 54.178786 73.436052)
        (xy 54.178784 73.436053)
        (xy 54.170155 73.438519)
        (xy 54.162565 73.443308)
        (xy 54.106151 73.478903)
        (xy 54.061019 73.507379)
        (xy 54.055076 73.514108)
        (xy 54.055075 73.514109)
        (xy 54.010128 73.565002)
        (xy 53.975596 73.604102)
        (xy 53.971782 73.612225)
        (xy 53.971781 73.612227)
        (xy 53.953695 73.650749)
        (xy 53.920754 73.720912)
        (xy 53.915991 73.751502)
        (xy 53.902282 73.839547)
        (xy 53.902282 73.839551)
        (xy 53.900901 73.84842)
        (xy 53.902065 73.857322)
        (xy 53.902065 73.857325)
        (xy 53.916468 73.967469)
        (xy 53.916469 73.967473)
        (xy 53.917633 73.976374)
        (xy 53.934575 74.014878)
        (xy 53.963257 74.080062)
        (xy 53.969605 74.09449)
        (xy 53.975382 74.101363)
        (xy 53.975383 74.101364)
        (xy 54.025951 74.161522)
        (xy 54.054472 74.226538)
        (xy 54.0555 74.242597)
        (xy 54.0555 74.964474)
        (xy 54.035498 75.032595)
        (xy 54.023942 75.04788)
        (xy 53.975596 75.102622)
        (xy 53.971782 75.110745)
        (xy 53.971781 75.110747)
        (xy 53.946285 75.165052)
        (xy 53.920754 75.219432)
        (xy 53.911626 75.278058)
        (xy 53.902282 75.338067)
        (xy 53.902282 75.338071)
        (xy 15.189373 72.29894)
        (xy 44.756901 72.29894)
        (xy 44.758065 72.307842)
        (xy 44.758065 72.307845)
        (xy 44.772468 72.417989)
        (xy 44.772469 72.417993)
        (xy 44.773633 72.426894)
        (xy 44.825605 72.54501)
        (xy 44.831382 72.551883)
        (xy 44.831383 72.551884)
        (xy 44.901478 72.635272)
        (xy 44.908639 72.643791)
        (xy 45.01606 72.715296)
        (xy 45.104938 72.743064)
        (xy 45.117516 72.746993)
        (xy 45.139233 72.753778)
        (xy 45.148203 72.753942)
        (xy 45.148207 72.753943)
        (xy 45.206942 72.755019)
        (xy 45.268255 72.756143)
        (xy 45.306874 72.745614)
        (xy 45.377857 72.746993)
        (xy 45.429111 72.778082)
        (xy 46.246918 73.595889)
        (xy 46.280944 73.658201)
        (xy 46.282758 73.668642)
        (xy 46.297633 73.782394)
        (xy 46.349605 73.90051)
        (xy 46.355382 73.907383)
        (xy 46.355383 73.907384)
        (xy 46.40589 73.967469)
        (xy 46.432639 73.999291)
        (xy 46.54006 74.070796)
        (xy 46.6159 74.09449)
        (xy 46.63643 74.100904)
        (xy 46.663233 74.109278)
        (xy 46.672203 74.109442)
        (xy 46.672207 74.109443)
        (xy 46.730942 74.110519)
        (xy 46.792255 74.111643)
        (xy 46.885321 74.08627)
        (xy 46.908092 74.080062)
        (xy 46.908093 74.080062)
        (xy 46.916755 74.0777)
        (xy 46.924405 74.073003)
        (xy 46.924407 74.073002)
        (xy 47.019072 74.014878)
        (xy 47.019075 74.014875)
        (xy 47.026724 74.010179)
        (xy 47.03275 74.003522)
        (xy 47.1073 73.921161)
        (xy 47.107303 73.921157)
        (xy 47.113322 73.914507)
        (xy 47.169588 73.798375)
        (xy 47.171852 73.784921)
        (xy 47.180367 73.734304)
        (xy 47.185028 73.706597)
        (xy 47.216054 73.64274)
        (xy 47.27668 73.605793)
        (xy 47.311591 73.601523)
        (xy 47.335712 73.601965)
        (xy 47.427255 73.603643)
        (xy 47.489505 73.586671)
        (xy 47.543092 73.572062)
        (xy 47.543093 73.572062)
        (xy 47.551755 73.5697)
        (xy 47.559405 73.565003)
        (xy 47.559407 73.565002)
        (xy 47.654072 73.506878)
        (xy 47.654075 73.506875)
        (xy 47.661724 73.502179)
        (xy 47.66775 73.495522)
        (xy 47.7423 73.413161)
        (xy 47.742303 73.413157)
        (xy 47.748322 73.406507)
        (xy 47.752233 73.398434)
        (xy 47.757257 73.390986)
        (xy 47.758573 73.391874)
        (xy 47.79949 73.346769)
        (xy 47.868049 73.328323)
        (xy 47.935697 73.34987)
        (xy 47.949165 73.360361)
        (xy 47.950862 73.361878)
        (xy 47.956639 73.368751)
        (xy 48.06406 73.440256)
        (xy 48.187233 73.478738)
        (xy 48.196203 73.478902)
        (xy 48.196207 73.478903)
        (xy 48.254942 73.479979)
        (xy 48.316255 73.481103)
        (xy 48.378505 73.464131)
        (xy 48.432092 73.449522)
        (xy 48.432093 73.449522)
        (xy 48.440755 73.44716)
        (xy 48.448405 73.442463)
        (xy 48.448407 73.442462)
        (xy 48.543072 73.384338)
        (xy 48.543075 73.384335)
        (xy 48.550724 73.379639)
        (xy 48.55675 73.372982)
        (xy 48.6313 73.290621)
        (xy 48.631303 73.290617)
        (xy 48.637322 73.283967)
        (xy 48.693588 73.167835)
        (xy 48.6951 73.158851)
        (xy 48.71419 73.045377)
        (xy 48.714997 73.04058)
        (xy 48.715133 73.02946)
        (xy 48.696839 72.901719)
        (xy 48.688881 72.884216)
        (xy 48.647145 72.792422)
        (xy 48.647143 72.792419)
        (xy 48.643428 72.784248)
        (xy 48.584201 72.715511)
        (xy 48.565051 72.693286)
        (xy 48.565049 72.693284)
        (xy 48.559193 72.686488)
        (xy 48.450906 72.616301)
        (xy 48.442311 72.613731)
        (xy 48.44231 72.61373)
        (xy 48.335874 72.581898)
        (xy 48.335872 72.581898)
        (xy 48.327273 72.579326)
        (xy 48.318297 72.579271)
        (xy 48.309417 72.577944)
        (xy 48.309747 72.575739)
        (xy 48.253578 72.55887)
        (xy 48.233254 72.542388)
        (xy 46.839691 71.148825)
        (xy 46.805665 71.086513)
        (xy 46.804064 71.077625)
        (xy 46.791839 70.992259)
        (xy 46.738428 70.874788)
        (xy 46.668059 70.79312)
        (xy 46.660051 70.783826)
        (xy 46.660049 70.783824)
        (xy 46.654193 70.777028)
        (xy 46.545906 70.706841)
        (xy 46.537311 70.704271)
        (xy 46.53731 70.70427)
        (xy 46.430874 70.672438)
        (xy 46.430872 70.672438)
        (xy 46.422273 70.669866)
        (xy 46.413298 70.669811)
        (xy 46.413297 70.669811)
        (xy 46.358641 70.669477)
        (xy 46.293231 70.669078)
        (xy 46.281475 70.672438)
        (xy 46.177786 70.702072)
        (xy 46.177784 70.702073)
        (xy 46.169155 70.704539)
        (xy 46.060019 70.773399)
        (xy 46.054076 70.780128)
        (xy 46.054075 70.780129)
        (xy 45.986351 70.856812)
        (xy 45.974596 70.870122)
        (xy 45.970782 70.878245)
        (xy 45.970781 70.878247)
        (xy 45.944794 70.933598)
        (xy 45.919754 70.986932)
        (xy 45.918374 70.995798)
        (xy 45.901282 71.105567)
        (xy 45.901282 71.105571)
        (xy 45.899901 71.11444)
        (xy 45.901065 71.123342)
        (xy 45.901065 71.123345)
        (xy 45.906172 71.162396)
        (xy 45.895172 71.232535)
        (xy 45.847997 71.285592)
        (xy 45.798337 71.303567)
        (xy 45.794207 71.304133)
        (xy 45.785231 71.304078)
        (xy 45.723193 71.321808)
        (xy 45.669786 71.337072)
        (xy 45.669784 71.337073)
        (xy 45.661155 71.339539)
        (xy 45.653565 71.344328)
        (xy 45.584692 71.387784)
        (xy 45.552019 71.408399)
        (xy 45.466596 71.505122)
        (xy 45.462782 71.513245)
        (xy 45.462781 71.513247)
        (xy 45.459002 71.521296)
        (xy 45.411754 71.621932)
        (xy 45.410374 71.630796)
        (xy 45.410373 71.630799)
        (xy 45.392175 71.747677)
        (xy 45.361931 71.81191)
        (xy 45.301761 71.849594)
        (xy 45.266906 71.85429)
        (xy 45.190165 71.853822)
        (xy 45.150231 71.853578)
        (xy 45.088193 71.871308)
        (xy 45.034786 71.886572)
        (xy 45.034784 71.886573)
        (xy 45.026155 71.889039)
        (xy 45.018565 71.893828)
        (xy 44.966026 71.926978)
        (xy 44.917019 71.957899)
        (xy 44.831596 72.054622)
        (xy 44.776754 72.171432)
        (xy 44.775374 72.180298)
        (xy 44.758282 72.290067)
        (xy 44.758282 72.290071)
        (xy 15.189373 67.989236)
        (xy 19.053958 67.989236)
        (xy 19.054321 67.993384)
        (xy 19.054321 67.993389)
        (xy 19.062573 68.087708)
        (xy 19.080014 68.287065)
        (xy 19.145232 68.578832)
        (xy 19.146676 68.582756)
        (xy 19.146676 68.582757)
        (xy 19.214142 68.766126)
        (xy 19.248464 68.85941)
        (xy 19.250415 68.86311)
        (xy 19.250417 68.863115)
        (xy 19.342943 69.038606)
        (xy 19.387898 69.12387)
        (xy 19.561084 69.367565)
        (xy 19.764979 69.586216)
        (xy 19.996 69.775979)
        (xy 20.25009 69.933521)
        (xy 20.522783 70.056074)
        (xy 20.697027 70.108018)
        (xy 20.80529 70.140293)
        (xy 20.805292 70.140293)
        (xy 20.809289 70.141485)
        (xy 20.813409 70.142138)
        (xy 20.813411 70.142138)
        (xy 20.931423 70.160829)
        (xy 21.104575 70.188254)
        (xy 21.147135 70.190187)
        (xy 21.196659 70.192436)
        (xy 21.196678 70.192436)
        (xy 21.198078 70.1925)
        (xy 21.384834 70.1925)
        (xy 21.607309 70.177723)
        (xy 21.900377 70.11863)
        (xy 22.183056 70.021296)
        (xy 22.186789 70.019427)
        (xy 22.186793 70.019425)
        (xy 22.44664 69.889303)
        (xy 22.446642 69.889302)
        (xy 22.450378 69.887431)
        (xy 22.697647 69.719387)
        (xy 22.726688 69.693422)
        (xy 22.917403 69.522904)
        (xy 22.917404 69.522903)
        (xy 22.92052 69.520117)
        (xy 22.946988 69.489236)
        (xy 55.053958 69.489236)
        (xy 55.054321 69.493384)
        (xy 55.054321 69.493389)
        (xy 55.056903 69.522904)
        (xy 55.080014 69.787065)
        (xy 55.145232 70.078832)
        (xy 55.146676 70.082756)
        (xy 55.146676 70.082757)
        (xy 55.185289 70.187705)
        (xy 55.248464 70.35941)
        (xy 55.387898 70.62387)
        (xy 55.561084 70.867565)
        (xy 55.563934 70.870621)
        (xy 55.685644 71.001139)
        (xy 55.764979 71.086216)
        (xy 55.996 71.275979)
        (xy 56.25009 71.433521)
        (xy 56.522783 71.556074)
        (xy 56.621652 71.585548)
        (xy 56.80529 71.640293)
        (xy 56.805292 71.640293)
        (xy 56.809289 71.641485)
        (xy 56.813409 71.642138)
        (xy 56.813411 71.642138)
        (xy 56.931423 71.660829)
        (xy 57.104575 71.688254)
        (xy 57.147135 71.690187)
        (xy 57.196659 71.692436)
        (xy 57.196678 71.692436)
        (xy 57.198078 71.6925)
        (xy 57.384834 71.6925)
        (xy 57.607309 71.677723)
        (xy 57.900377 71.61863)
        (xy 58.183056 71.521296)
        (xy 58.186789 71.519427)
        (xy 58.186793 71.519425)
        (xy 58.44664 71.389303)
        (xy 58.446642 71.389302)
        (xy 58.450378 71.387431)
        (xy 58.697647 71.219387)
        (xy 58.761389 71.162396)
        (xy 58.917403 71.022904)
        (xy 58.917404 71.022903)
        (xy 58.92052 71.020117)
        (xy 59.115079 70.79312)
        (xy 59.277908 70.542386)
        (xy 59.406145 70.272319)
        (xy 59.497538 69.987664)
        (xy 59.524788 69.836216)
        (xy 59.549741 69.697531)
        (xy 59.549742 69.697526)
        (xy 59.55048 69.693422)
        (xy 59.555349 69.586216)
        (xy 59.563853 69.398934)
        (xy 59.563853 69.398929)
        (xy 59.564042 69.394764)
        (xy 59.561663 69.367565)
        (xy 59.553189 69.270712)
        (xy 59.537986 69.096935)
        (xy 59.472768 68.805168)
        (xy 59.462074 68.776101)
        (xy 59.370983 68.528523)
        (xy 59.369536 68.52459)
        (xy 59.35217 68.491651)
        (xy 59.232055 68.263834)
        (xy 59.232054 68.263833)
        (xy 59.230102 68.26013)
        (xy 59.056916 68.016435)
        (xy 58.853021 67.797784)
        (xy 58.622 67.608021)
        (xy 58.36791 67.450479)
        (xy 58.095217 67.327926)
        (xy 57.882603 67.264543)
        (xy 57.81271 67.243707)
        (xy 57.812708 67.243707)
        (xy 57.808711 67.242515)
        (xy 57.804591 67.241862)
        (xy 57.804589 67.241862)
        (xy 57.686577 67.223171)
        (xy 57.513425 67.195746)
        (xy 57.470865 67.193813)
        (xy 57.421341 67.191564)
        (xy 57.421322 67.191564)
        (xy 57.419922 67.1915)
        (xy 57.233166 67.1915)
        (xy 57.010691 67.206277)
        (xy 56.717623 67.26537)
        (xy 56.434944 67.362704)
        (xy 56.431211 67.364573)
        (xy 56.431207 67.364575)
        (xy 56.255268 67.452679)
        (xy 56.167622 67.496569)
        (xy 55.920353 67.664613)
        (xy 55.917239 67.667397)
        (xy 55.917238 67.667398)
        (xy 55.886644 67.694752)
        (xy 55.69748 67.863883)
        (xy 55.502921 68.09088)
        (xy 55.500647 68.094382)
        (xy 55.375517 68.287065)
        (xy 55.340092 68.341614)
        (xy 55.211855 68.611681)
        (xy 55.210576 68.615664)
        (xy 55.210575 68.615667)
        (xy 55.159065 68.776101)
        (xy 55.120462 68.896336)
        (xy 55.119721 68.900455)
        (xy 55.078909 69.127282)
        (xy 55.06752 69.190578)
        (xy 55.067331 69.194745)
        (xy 55.06733 69.194752)
        (xy 55.055232 69.461174)
        (xy 23.115079 69.29312)
        (xy 23.239778 69.101101)
        (xy 23.275629 69.045896)
        (xy 23.275632 69.045891)
        (xy 23.277908 69.042386)
        (xy 23.406145 68.772319)
        (xy 23.457721 68.611681)
        (xy 23.496258 68.491651)
        (xy 23.496258 68.49165)
        (xy 23.497538 68.487664)
        (xy 23.537811 68.263834)
        (xy 23.549741 68.197531)
        (xy 23.549742 68.197526)
        (xy 23.55048 68.193422)
        (xy 23.554978 68.094382)
        (xy 23.563853 67.898934)
        (xy 23.563853 67.898929)
        (xy 23.564042 67.894764)
        (xy 23.561619 67.86706)
        (xy 23.553189 67.770712)
        (xy 23.537986 67.596935)
        (xy 23.472768 67.305168)
        (xy 23.436282 67.206)
        (xy 23.370983 67.028523)
        (xy 23.369536 67.02459)
        (xy 23.230102 66.76013)
        (xy 23.056916 66.516435)
        (xy 22.853021 66.297784)
        (xy 22.622 66.108021)
        (xy 22.36791 65.950479)
        (xy 22.095217 65.827926)
        (xy 21.880932 65.764045)
        (xy 21.81271 65.743707)
        (xy 21.812708 65.743707)
        (xy 21.808711 65.742515)
        (xy 21.804591 65.741862)
        (xy 21.804589 65.741862)
        (xy 21.588722 65.707672)
        (xy 21.513425 65.695746)
        (xy 21.470865 65.693813)
        (xy 21.421341 65.691564)
        (xy 21.421322 65.691564)
        (xy 21.419922 65.6915)
        (xy 21.233166 65.6915)
        (xy 21.010691 65.706277)
        (xy 20.717623 65.76537)
        (xy 20.434944 65.862704)
        (xy 20.431211 65.864573)
        (xy 20.431207 65.864575)
        (xy 20.255268 65.952679)
        (xy 20.167622 65.996569)
        (xy 19.920353 66.164613)
        (xy 19.69748 66.363883)
        (xy 19.502921 66.59088)
        (xy 19.340092 66.841614)
        (xy 19.211855 67.111681)
        (xy 19.210576 67.115664)
        (xy 19.210575 67.115667)
        (xy 19.184688 67.196295)
        (xy 19.120462 67.396336)
        (xy 19.119721 67.400455)
        (xy 19.071691 67.667398)
        (xy 19.06752 67.690578)
        (xy 19.067331 67.694745)
        (xy 19.06733 67.694752)
        (xy 19.054147 67.985066)
        (xy 15.189373 64.25644)
        (xy 30.087398 64.25644)
        (xy 30.088562 64.265342)
        (xy 30.088562 64.265345)
        (xy 30.102965 64.375489)
        (xy 30.102966 64.375493)
        (xy 30.10413 64.384394)
        (xy 30.156102 64.50251)
        (xy 30.161879 64.509383)
        (xy 30.16188 64.509384)
        (xy 30.165056 64.513162)
        (xy 30.239136 64.601291)
        (xy 30.346557 64.672796)
        (xy 30.432345 64.699598)
        (xy 30.453195 64.706112)
        (xy 30.46973 64.711278)
        (xy 30.4787 64.711442)
        (xy 30.478704 64.711443)
        (xy 30.537439 64.712519)
        (xy 30.598752 64.713643)
        (xy 30.667126 64.695002)
        (xy 30.714589 64.682062)
        (xy 30.71459 64.682062)
        (xy 30.723252 64.6797)
        (xy 30.730902 64.675003)
        (xy 30.730904 64.675002)
        (xy 30.827897 64.615448)
        (xy 30.896414 64.59685)
        (xy 30.963643 64.617935)
        (xy 31.04606 64.672796)
        (xy 31.131848 64.699598)
        (xy 31.152698 64.706112)
        (xy 31.169233 64.711278)
        (xy 31.178203 64.711442)
        (xy 31.178207 64.711443)
        (xy 31.236942 64.712519)
        (xy 31.298255 64.713643)
        (xy 31.366629 64.695002)
        (xy 31.414092 64.682062)
        (xy 31.414093 64.682062)
        (xy 31.422755 64.6797)
        (xy 31.430405 64.675003)
        (xy 31.430407 64.675002)
        (xy 31.489875 64.638488)
        (xy 31.532724 64.612179)
        (xy 31.53875 64.605522)
        (xy 31.542604 64.602322)
        (xy 31.607793 64.574198)
        (xy 31.677838 64.585782)
        (xy 31.700143 64.600701)
        (xy 31.700639 64.601291)
        (xy 31.70811 64.606264)
        (xy 31.708111 64.606265)
        (xy 31.768179 64.646249)
        (xy 31.80806 64.672796)
        (xy 31.893848 64.699598)
        (xy 31.914698 64.706112)
        (xy 31.931233 64.711278)
        (xy 31.940203 64.711442)
        (xy 31.940207 64.711443)
        (xy 31.998942 64.712519)
        (xy 32.060255 64.713643)
        (xy 32.128629 64.695002)
        (xy 32.176092 64.682062)
        (xy 32.176093 64.682062)
        (xy 32.184755 64.6797)
        (xy 32.192405 64.675003)
        (xy 32.192407 64.675002)
        (xy 32.251875 64.638488)
        (xy 32.294724 64.612179)
        (xy 32.295829 64.610959)
        (xy 32.35763 64.584297)
        (xy 32.427675 64.595882)
        (xy 32.456907 64.615434)
        (xy 32.458241 64.616627)
        (xy 32.464016 64.623497)
        (xy 32.471487 64.62847)
        (xy 32.471488 64.628471)
        (xy 32.498196 64.646249)
        (xy 32.571437 64.695002)
        (xy 32.69461 64.733484)
        (xy 32.70358 64.733648)
        (xy 32.703584 64.733649)
        (xy 32.762319 64.734725)
        (xy 32.823632 64.735849)
        (xy 32.913151 64.711443)
        (xy 32.939469 64.704268)
        (xy 32.93947 64.704268)
        (xy 32.948132 64.701906)
        (xy 32.955782 64.697209)
        (xy 32.955784 64.697208)
        (xy 33.050449 64.639084)
        (xy 33.050452 64.639081)
        (xy 33.058101 64.634385)
        (xy 33.064127 64.627728)
        (xy 33.138677 64.545367)
        (xy 33.13868 64.545363)
        (xy 33.144699 64.538713)
        (xy 33.200965 64.422581)
        (xy 33.20739 64.384394)
        (xy 33.221567 64.300123)
        (xy 33.222374 64.295326)
        (xy 33.22251 64.284206)
        (xy 33.215125 64.232639)
        (xy 33.205489 64.165351)
        (xy 33.205488 64.165348)
        (xy 33.204216 64.156465)
        (xy 33.195359 64.136985)
        (xy 33.154522 64.047168)
        (xy 33.15452 64.047165)
        (xy 33.150805 64.038994)
        (xy 33.06657 63.941234)
        (xy 33.068053 63.939956)
        (xy 33.035995 63.889707)
        (xy 33.031009 63.854612)
        (xy 33.031009 63.677384)
        (xy 36.684845 63.677384)
        (xy 36.686009 63.686286)
        (xy 36.686009 63.686289)
        (xy 36.700412 63.796433)
        (xy 36.700413 63.796437)
        (xy 36.701577 63.805338)
        (xy 36.709735 63.823879)
        (xy 36.745976 63.906242)
        (xy 36.753549 63.923454)
        (xy 36.759326 63.930327)
        (xy 36.759327 63.930328)
        (xy 36.821329 64.004088)
        (xy 36.836583 64.022235)
        (xy 36.944004 64.09374)
        (xy 37.067177 64.132222)
        (xy 37.07615 64.132386)
        (xy 37.076154 64.132387)
        (xy 37.079217 64.132443)
        (xy 37.082116 64.133353)
        (xy 37.085015 64.133822)
        (xy 37.084947 64.134241)
        (xy 37.146959 64.153693)
        (xy 37.165999 64.169327)
        (xy 37.481111 64.484439)
        (xy 37.515137 64.546751)
        (xy 37.516951 64.557194)
        (xy 37.526507 64.630268)
        (xy 37.548973 64.681326)
        (xy 37.5715 64.732522)
        (xy 37.578479 64.748384)
        (xy 37.584256 64.755257)
        (xy 37.584257 64.755258)
        (xy 37.633885 64.814298)
        (xy 37.661513 64.847165)
        (xy 37.768934 64.91867)
        (xy 37.852436 64.944758)
        (xy 37.883353 64.954417)
        (xy 37.892107 64.957152)
        (xy 37.901077 64.957316)
        (xy 37.901081 64.957317)
        (xy 37.959816 64.958393)
        (xy 38.021129 64.959517)
        (xy 38.098218 64.9385)
        (xy 38.136966 64.927936)
        (xy 38.136967 64.927936)
        (xy 38.145629 64.925574)
        (xy 38.153279 64.920877)
        (xy 38.153281 64.920876)
        (xy 38.247946 64.862752)
        (xy 38.247949 64.862749)
        (xy 38.255598 64.858053)
        (xy 38.261624 64.851396)
        (xy 38.336174 64.769035)
        (xy 38.336177 64.769031)
        (xy 38.342196 64.762381)
        (xy 38.346108 64.754308)
        (xy 38.34611 64.754304)
        (xy 38.347054 64.752355)
        (xy 38.348498 64.750763)
        (xy 38.351131 64.74686)
        (xy 38.351694 64.74724)
        (xy 38.394756 64.699772)
        (xy 38.463314 64.681326)
        (xy 38.530962 64.702873)
        (xy 38.545612 64.716062)
        (xy 38.546172 64.715436)
        (xy 38.552859 64.721415)
        (xy 38.558639 64.728291)
        (xy 38.66606 64.799796)
        (xy 38.789233 64.838278)
        (xy 38.798203 64.838442)
        (xy 38.798207 64.838443)
        (xy 38.856942 64.839519)
        (xy 38.918255 64.840643)
        (xy 38.995274 64.819645)
        (xy 39.034092 64.809062)
        (xy 39.034093 64.809062)
        (xy 39.042755 64.8067)
        (xy 39.050405 64.802003)
        (xy 39.050407 64.802002)
        (xy 39.145072 64.743878)
        (xy 39.145075 64.743875)
        (xy 39.152724 64.739179)
        (xy 39.160302 64.730807)
        (xy 39.2333 64.650161)
        (xy 39.233303 64.650157)
        (xy 39.239322 64.643507)
        (xy 39.295588 64.527375)
        (xy 39.297417 64.516507)
        (xy 39.31619 64.404917)
        (xy 39.316997 64.40012)
        (xy 39.317133 64.389)
        (xy 39.303718 64.295326)
        (xy 39.300112 64.270145)
        (xy 39.300111 64.270142)
        (xy 39.298839 64.261259)
        (xy 39.292614 64.247567)
        (xy 39.249145 64.151962)
        (xy 39.249143 64.151959)
        (xy 39.245428 64.143788)
        (xy 39.189559 64.078948)
        (xy 39.162095 64.024401)
        (xy 39.160662 64.018044)
        (xy 39.160226 64.00642)
        (xy 39.155634 63.995733)
        (xy 39.154595 63.991121)
        (xy 39.151043 63.979429)
        (xy 39.149339 63.975012)
        (xy 39.147209 63.963576)
        (xy 39.134272 63.942588)
        (xy 39.125769 63.926218)
        (xy 39.119549 63.911741)
        (xy 39.119547 63.911737)
        (xy 39.116036 63.903566)
        (xy 39.112022 63.89868)
        (xy 39.109837 63.896495)
        (xy 39.107785 63.894232)
        (xy 39.107945 63.894087)
        (xy 39.100825 63.88508)
        (xy 39.094573 63.878185)
        (xy 39.088468 63.868281)
        (xy 39.06668 63.851713)
        (xy 39.053861 63.840519)
        (xy 38.573237 63.359895)
        (xy 40.692901 63.359895)
        (xy 40.694065 63.368797)
        (xy 40.694065 63.3688)
        (xy 40.708468 63.478944)
        (xy 40.708469 63.478948)
        (xy 40.709633 63.487849)
        (xy 40.761605 63.605965)
        (xy 40.767382 63.612838)
        (xy 40.767383 63.612839)
        (xy 40.785099 63.633915)
        (xy 40.844639 63.704746)
        (xy 40.95206 63.776251)
        (xy 41.040938 63.804019)
        (xy 41.045162 63.805338)
        (xy 41.075233 63.814733)
        (xy 41.084205 63.814897)
        (xy 41.084208 63.814898)
        (xy 41.121252 63.815577)
        (xy 41.123287 63.815614)
        (xy 41.191029 63.836862)
        (xy 41.210072 63.852498)
        (xy 41.445595 64.088021)
        (xy 41.479621 64.150333)
        (xy 41.4825 64.177116)
        (xy 41.4825 64.550474)
        (xy 41.462498 64.618595)
        (xy 41.450942 64.63388)
        (xy 41.402596 64.688622)
        (xy 41.398782 64.696745)
        (xy 41.398781 64.696747)
        (xy 41.380423 64.735849)
        (xy 41.347754 64.805432)
        (xy 41.340481 64.852142)
        (xy 41.329282 64.924067)
        (xy 41.329282 64.924071)
        (xy 41.327901 64.93294)
        (xy 41.329065 64.941842)
        (xy 41.329065 64.941845)
        (xy 41.343468 65.051989)
        (xy 41.343469 65.051993)
        (xy 41.344633 65.060894)
        (xy 41.34825 65.069114)
        (xy 41.377312 65.135162)
        (xy 41.396605 65.17901)
        (xy 41.402382 65.185883)
        (xy 41.402383 65.185884)
        (xy 41.413964 65.199661)
        (xy 41.479639 65.277791)
        (xy 41.487116 65.282768)
        (xy 41.554551 65.327656)
        (xy 41.58706 65.349296)
        (xy 41.710233 65.387778)
        (xy 41.719203 65.387942)
        (xy 41.719207 65.387943)
        (xy 41.777942 65.389019)
        (xy 41.839255 65.390143)
        (xy 41.912012 65.370307)
        (xy 41.955092 65.358562)
        (xy 41.955093 65.358562)
        (xy 41.963755 65.3562)
        (xy 41.971405 65.351503)
        (xy 41.971407 65.351502)
        (xy 42.066072 65.293378)
        (xy 42.066075 65.293375)
        (xy 42.073724 65.288679)
        (xy 42.07975 65.282022)
        (xy 42.1543 65.199661)
        (xy 42.154303 65.199657)
        (xy 42.160322 65.193007)
        (xy 42.216588 65.076875)
        (xy 42.218243 65.067041)
        (xy 42.23719 64.954417)
        (xy 42.237997 64.94962)
        (xy 42.238133 64.9385)
        (xy 42.223804 64.838443)
        (xy 42.221112 64.819645)
        (xy 42.221111 64.819642)
        (xy 42.219839 64.810759)
        (xy 42.216072 64.802473)
        (xy 42.170145 64.701462)
        (xy 42.170143 64.701459)
        (xy 42.166428 64.693288)
        (xy 42.114047 64.632496)
        (xy 42.084733 64.567834)
        (xy 42.0835 64.550249)
        (xy 42.0835 64.052827)
        (xy 42.083697 64.05015)
        (xy 42.085426 64.045113)
        (xy 42.084649 64.024401)
        (xy 42.083589 63.996185)
        (xy 42.0835 63.991458)
        (xy 42.0835 63.972507)
        (xy 42.082618 63.967774)
        (xy 42.08239 63.964247)
        (xy 42.081663 63.944875)
        (xy 42.081662 63.944873)
        (xy 42.081226 63.933247)
        (xy 42.076632 63.922555)
        (xy 42.075595 63.917952)
        (xy 42.072038 63.906242)
        (xy 42.070339 63.901839)
        (xy 42.068209 63.890402)
        (xy 42.062106 63.880501)
        (xy 42.062105 63.880498)
        (xy 42.055271 63.869411)
        (xy 42.046767 63.85304)
        (xy 42.040546 63.838561)
        (xy 42.040544 63.838558)
        (xy 42.037036 63.830393)
        (xy 42.033023 63.825506)
        (xy 42.030828 63.823311)
        (xy 42.02877 63.821041)
        (xy 42.028932 63.820894)
        (xy 42.021835 63.811916)
        (xy 42.015571 63.805009)
        (xy 42.009468 63.795107)
        (xy 41.987689 63.778546)
        (xy 41.974868 63.767351)
        (xy 41.813471 63.605954)
        (xy 41.637856 63.43034)
        (xy 41.603831 63.368027)
        (xy 41.602364 63.359884)
        (xy 43.352345 63.359884)
        (xy 43.353509 63.368786)
        (xy 43.353509 63.368789)
        (xy 43.367912 63.478933)
        (xy 43.367913 63.478937)
        (xy 43.369077 63.487838)
        (xy 43.421049 63.605954)
        (xy 43.426826 63.612827)
        (xy 43.426827 63.612828)
        (xy 43.477395 63.672986)
        (xy 43.505916 63.738002)
        (xy 43.506944 63.754061)
        (xy 43.506944 65.067041)
        (xy 43.486942 65.135162)
        (xy 43.475387 65.150446)
        (xy 43.434596 65.196633)
        (xy 43.430782 65.204756)
        (xy 43.430781 65.204758)
        (xy 43.404794 65.260109)
        (xy 43.379754 65.313443)
        (xy 43.374172 65.349296)
        (xy 43.361282 65.432078)
        (xy 43.361282 65.432082)
        (xy 43.359901 65.440951)
        (xy 43.361065 65.449853)
        (xy 43.361065 65.449856)
        (xy 43.375468 65.56)
        (xy 43.375469 65.560004)
        (xy 43.376633 65.568905)
        (xy 43.428605 65.687021)
        (xy 43.434382 65.693894)
        (xy 43.434383 65.693895)
        (xy 43.49335 65.764045)
        (xy 43.511639 65.785802)
        (xy 43.61906 65.857307)
        (xy 43.742233 65.895789)
        (xy 43.751203 65.895953)
        (xy 43.751207 65.895954)
        (xy 43.809942 65.89703)
        (xy 43.871255 65.898154)
        (xy 43.933505 65.881183)
        (xy 43.987092 65.866573)
        (xy 43.987093 65.866573)
        (xy 43.995755 65.864211)
        (xy 44.003405 65.859514)
        (xy 44.003407 65.859513)
        (xy 44.098072 65.801389)
        (xy 44.098075 65.801386)
        (xy 44.105724 65.79669)
        (xy 44.11175 65.790033)
        (xy 44.1863 65.707672)
        (xy 44.186303 65.707668)
        (xy 44.192322 65.701018)
        (xy 44.248588 65.584886)
        (xy 44.269997 65.457631)
        (xy 44.270133 65.446511)
        (xy 44.257538 65.358562)
        (xy 44.253112 65.327656)
        (xy 44.253111 65.327653)
        (xy 44.251839 65.31877)
        (xy 44.240294 65.293378)
        (xy 44.202145 65.209473)
        (xy 44.202143 65.20947)
        (xy 44.198428 65.201299)
        (xy 44.13849 65.131737)
        (xy 44.109177 65.067075)
        (xy 44.107944 65.04949)
        (xy 44.107944 63.753378)
        (xy 44.127946 63.685257)
        (xy 44.140522 63.668832)
        (xy 44.184766 63.619951)
        (xy 44.241032 63.503819)
        (xy 44.251569 63.441191)
        (xy 44.261634 63.381361)
        (xy 44.262441 63.376564)
        (xy 44.262577 63.365444)
        (xy 44.248548 63.267483)
        (xy 44.245556 63.246589)
        (xy 44.245555 63.246586)
        (xy 44.244283 63.237703)
        (xy 44.240569 63.229534)
        (xy 44.194589 63.128406)
        (xy 44.194587 63.128403)
        (xy 44.190872 63.120232)
        (xy 44.12771 63.046928)
        (xy 44.112495 63.02927)
        (xy 44.112493 63.029268)
        (xy 44.106637 63.022472)
        (xy 43.99835 62.952285)
        (xy 43.989755 62.949715)
        (xy 43.989754 62.949714)
        (xy 43.883318 62.917882)
        (xy 43.883316 62.917882)
        (xy 43.874717 62.91531)
        (xy 43.865742 62.915255)
        (xy 43.865741 62.915255)
        (xy 43.811085 62.914921)
        (xy 43.745675 62.914522)
        (xy 43.705801 62.925918)
        (xy 43.63023 62.947516)
        (xy 43.630228 62.947517)
        (xy 43.621599 62.949983)
        (xy 43.512463 63.018843)
        (xy 43.50652 63.025572)
        (xy 43.506519 63.025573)
        (xy 43.487659 63.046928)
        (xy 43.42704 63.115566)
        (xy 43.423226 63.123689)
        (xy 43.423225 63.123691)
        (xy 43.403933 63.164783)
        (xy 43.372198 63.232376)
        (xy 43.365986 63.272272)
        (xy 43.353726 63.351011)
        (xy 43.353726 63.351015)
        (xy 41.602224 63.359107)
        (xy 41.598278 63.331552)
        (xy 41.584839 63.237714)
        (xy 41.58112 63.229534)
        (xy 41.535145 63.128417)
        (xy 41.535143 63.128414)
        (xy 41.531428 63.120243)
        (xy 41.498945 63.082544)
        (xy 41.453051 63.029281)
        (xy 41.453049 63.029279)
        (xy 41.447193 63.022483)
        (xy 41.338906 62.952296)
        (xy 41.330311 62.949726)
        (xy 41.33031 62.949725)
        (xy 41.223874 62.917893)
        (xy 41.223872 62.917893)
        (xy 41.215273 62.915321)
        (xy 41.206298 62.915266)
        (xy 41.206297 62.915266)
        (xy 41.151641 62.914932)
        (xy 41.086231 62.914533)
        (xy 41.062722 62.921252)
        (xy 40.970786 62.947527)
        (xy 40.970784 62.947528)
        (xy 40.962155 62.949994)
        (xy 40.954565 62.954783)
        (xy 40.86063 63.014052)
        (xy 40.853019 63.018854)
        (xy 40.767596 63.115577)
        (xy 40.763782 63.1237)
        (xy 40.763781 63.123702)
        (xy 40.76068 63.130308)
        (xy 40.712754 63.232387)
        (xy 40.70729 63.267483)
        (xy 40.694282 63.351022)
        (xy 40.694282 63.351026)
        (xy 38.449357 63.236015)
        (xy 38.415331 63.173703)
        (xy 38.413725 63.164783)
        (xy 38.407157 63.11892)
        (xy 38.39634 63.043389)
        (xy 38.390225 63.029939)
        (xy 38.346646 62.934092)
        (xy 38.346644 62.934089)
        (xy 38.342929 62.925918)
        (xy 38.258694 62.828158)
        (xy 38.150407 62.757971)
        (xy 38.141812 62.755401)
        (xy 38.141811 62.7554)
        (xy 38.035375 62.723568)
        (xy 38.035373 62.723568)
        (xy 38.026774 62.720996)
        (xy 38.017799 62.720941)
        (xy 38.017798 62.720941)
        (xy 37.963142 62.720607)
        (xy 37.897732 62.720208)
        (xy 37.885976 62.723568)
        (xy 37.782287 62.753202)
        (xy 37.782285 62.753203)
        (xy 37.773656 62.755669)
        (xy 37.66452 62.824529)
        (xy 37.579097 62.921252)
        (xy 37.575283 62.929375)
        (xy 37.575282 62.929377)
        (xy 37.564527 62.952285)
        (xy 37.524255 63.038062)
        (xy 37.504402 63.16557)
        (xy 37.503078 63.165364)
        (xy 37.48495 63.224415)
        (xy 37.430728 63.270247)
        (xy 37.360336 63.279489)
        (xy 37.333104 63.271246)
        (xy 37.33085 63.269785)
        (xy 37.322255 63.267215)
        (xy 37.322254 63.267214)
        (xy 37.215818 63.235382)
        (xy 37.215816 63.235382)
        (xy 37.207217 63.23281)
        (xy 37.198242 63.232755)
        (xy 37.198241 63.232755)
        (xy 37.143585 63.232421)
        (xy 37.078175 63.232022)
        (xy 37.027206 63.246589)
        (xy 36.96273 63.265016)
        (xy 36.962728 63.265017)
        (xy 36.954099 63.267483)
        (xy 36.844963 63.336343)
        (xy 36.83902 63.343072)
        (xy 36.839019 63.343073)
        (xy 36.796321 63.391419)
        (xy 36.75954 63.433066)
        (xy 36.755726 63.441189)
        (xy 36.755725 63.441191)
        (xy 36.730476 63.49497)
        (xy 36.704698 63.549876)
        (xy 36.703318 63.558742)
        (xy 36.686226 63.668511)
        (xy 36.686226 63.668515)
        (xy 33.031009 62.082315)
        (xy 33.051011 62.014194)
        (xy 33.063589 61.997765)
        (xy 33.082831 61.976507)
        (xy 33.139097 61.860375)
        (xy 33.160506 61.73312)
        (xy 33.160642 61.722)
        (xy 33.142348 61.594259)
        (xy 33.088937 61.476788)
        (xy 33.063134 61.446842)
        (xy 33.01056 61.385826)
        (xy 33.010558 61.385824)
        (xy 33.004702 61.379028)
        (xy 32.927682 61.329107)
        (xy 59.838962 61.329107)
        (xy 59.857605 61.697135)
        (xy 59.858142 61.70049)
        (xy 59.858143 61.700496)
        (xy 59.895574 61.934182)
        (xy 59.915886 62.060996)
        (xy 60.013123 62.416435)
        (xy 60.148179 62.759293)
        (xy 60.149762 62.762308)
        (xy 60.317889 63.082544)
        (xy 60.317894 63.082552)
        (xy 60.319473 63.08556)
        (xy 60.525002 63.391419)
        (xy 60.762361 63.673292)
        (xy 61.028774 63.927882)
        (xy 61.321124 64.15221)
        (xy 61.350645 64.170159)
        (xy 61.633077 64.341881)
        (xy 61.633082 64.341884)
        (xy 61.635992 64.343653)
        (xy 61.969693 64.49997)
        (xy 62.318325 64.619333)
        (xy 62.321648 64.620082)
        (xy 62.321652 64.620083)
        (xy 62.674484 64.699598)
        (xy 62.67449 64.699599)
        (xy 62.677809 64.700347)
        (xy 62.681188 64.700732)
        (xy 62.681194 64.700733)
        (xy 62.815739 64.716062)
        (xy 63.04394 64.742062)
        (xy 63.047345 64.74208)
        (xy 63.047348 64.74208)
        (xy 63.244323 64.743111)
        (xy 63.412434 64.743991)
        (xy 63.41582 64.743641)
        (xy 63.415822 64.743641)
        (xy 63.775589 64.706463)
        (xy 63.775598 64.706462)
        (xy 63.778981 64.706112)
        (xy 63.782314 64.705397)
        (xy 63.782317 64.705397)
        (xy 64.058218 64.646249)
        (xy 64.139294 64.628868)
        (xy 64.489157 64.513162)
        (xy 64.824477 64.360348)
        (xy 64.999478 64.25644)
        (xy 65.138387 64.173962)
        (xy 65.138392 64.173959)
        (xy 65.141332 64.172213)
        (xy 65.150472 64.165351)
        (xy 65.294263 64.057389)
        (xy 65.436015 63.950959)
        (xy 65.70508 63.699173)
        (xy 65.945378 63.419801)
        (xy 65.975094 63.376564)
        (xy 66.152168 63.11892)
        (xy 66.152173 63.118913)
        (xy 66.154098 63.116111)
        (xy 66.15571 63.113117)
        (xy 66.155715 63.113109)
        (xy 66.305484 62.834956)
        (xy 66.328799 62.791655)
        (xy 66.467438 62.45023)
        (xy 66.568391 62.095829)
        (xy 66.584806 61.9998)
        (xy 66.629908 61.735945)
        (xy 66.629908 61.735943)
        (xy 66.63048 61.732598)
        (xy 66.630746 61.728258)
        (xy 66.652866 61.366583)
        (xy 66.652976 61.364786)
        (xy 66.653059 61.341)
        (xy 66.633131 60.97304)
        (xy 66.57358 60.609384)
        (xy 66.475103 60.254287)
        (xy 66.473845 60.251125)
        (xy 66.473842 60.251117)
        (xy 66.340111 59.915067)
        (xy 66.340107 59.915059)
        (xy 66.338851 59.911902)
        (xy 66.33314 59.901115)
        (xy 66.168014 59.589245)
        (xy 66.168012 59.589241)
        (xy 66.16642 59.586235)
        (xy 65.959824 59.281095)
        (xy 65.957619 59.278495)
        (xy 65.957613 59.278487)
        (xy 65.72369 59.002655)
        (xy 65.721483 59.000052)
        (xy 65.454183 58.746394)
        (xy 65.451476 58.744332)
        (xy 65.451468 58.744325)
        (xy 65.212662 58.562405)
        (xy 65.161051 58.523088)
        (xy 64.889901 58.359519)
        (xy 64.848438 58.334507)
        (xy 64.848437 58.334507)
        (xy 64.845517 58.332745)
        (xy 64.842427 58.331311)
        (xy 64.842422 58.331308)
        (xy 64.514368 58.179031)
        (xy 64.514366 58.17903)
        (xy 64.511272 58.177594)
        (xy 64.508037 58.176499)
        (xy 64.508032 58.176497)
        (xy 64.165461 58.060543)
        (xy 64.162226 58.059448)
        (xy 63.802461 57.97969)
        (xy 63.617608 57.959282)
        (xy 63.439568 57.939626)
        (xy 63.439563 57.939626)
        (xy 63.436187 57.939253)
        (xy 63.432788 57.939247)
        (xy 63.432787 57.939247)
        (xy 63.258708 57.938943)
        (xy 63.067688 57.93861)
        (xy 62.894922 57.957074)
        (xy 62.704659 57.977407)
        (xy 62.704653 57.977408)
        (xy 62.701275 57.977769)
        (xy 62.341235 58.05627)
        (xy 61.991778 58.173197)
        (xy 61.656993 58.32718)
        (xy 61.654059 58.328936)
        (xy 61.654057 58.328937)
        (xy 61.343725 58.514667)
        (xy 61.343717 58.514673)
        (xy 61.340797 58.51642)
        (xy 61.046888 58.738702)
        (xy 60.778704 58.991426)
        (xy 60.776492 58.994016)
        (xy 60.776491 58.994017)
        (xy 60.659044 59.13153)
        (xy 60.539383 59.271635)
        (xy 60.537469 59.274441)
        (xy 60.537465 59.274446)
        (xy 60.436835 59.421963)
        (xy 60.331723 59.576051)
        (xy 60.330122 59.579049)
        (xy 60.330118 59.579056)
        (xy 60.159761 59.898108)
        (xy 60.159757 59.898117)
        (xy 60.158156 59.901115)
        (xy 60.156887 59.904272)
        (xy 60.156885 59.904276)
        (xy 60.152547 59.915067)
        (xy 60.02071 60.243022)
        (xy 60.01979 60.246296)
        (xy 60.019788 60.246301)
        (xy 59.930412 60.564268)
        (xy 59.920994 60.597773)
        (xy 59.920432 60.60113)
        (xy 59.920432 60.601131)
        (xy 59.9113 60.655705)
        (xy 59.860174 60.961219)
        (xy 59.843712 61.246734)
        (xy 32.896415 61.308841)
        (xy 32.88782 61.306271)
        (xy 32.887819 61.30627)
        (xy 32.781383 61.274438)
        (xy 32.781381 61.274438)
        (xy 32.772782 61.271866)
        (xy 32.763807 61.271811)
        (xy 32.763806 61.271811)
        (xy 32.70915 61.271477)
        (xy 32.64374 61.271078)
        (xy 32.631984 61.274438)
        (xy 32.528295 61.304072)
        (xy 32.528293 61.304073)
        (xy 32.519664 61.306539)
        (xy 32.512074 61.311328)
        (xy 32.422467 61.367866)
        (xy 32.354182 61.3873)
        (xy 32.2867 61.367037)
        (xy 32.204444 61.313722)
        (xy 32.204439 61.31372)
        (xy 32.196912 61.308841)
        (xy 32.188317 61.306271)
        (xy 32.188316 61.30627)
        (xy 32.08188 61.274438)
        (xy 32.081878 61.274438)
        (xy 32.073279 61.271866)
        (xy 32.064304 61.271811)
        (xy 32.064303 61.271811)
        (xy 32.009647 61.271477)
        (xy 31.944237 61.271078)
        (xy 31.932481 61.274438)
        (xy 31.828792 61.304072)
        (xy 31.82879 61.304073)
        (xy 31.820161 61.306539)
        (xy 31.812571 61.311328)
        (xy 31.722964 61.367866)
        (xy 31.654679 61.3873)
        (xy 31.587197 61.367037)
        (xy 31.504941 61.313722)
        (xy 31.504936 61.31372)
        (xy 31.497409 61.308841)
        (xy 31.488814 61.306271)
        (xy 31.488813 61.30627)
        (xy 31.382377 61.274438)
        (xy 31.382375 61.274438)
        (xy 31.373776 61.271866)
        (xy 31.364801 61.271811)
        (xy 31.3648 61.271811)
        (xy 31.310144 61.271477)
        (xy 31.244734 61.271078)
        (xy 31.232978 61.274438)
        (xy 31.129289 61.304072)
        (xy 31.129287 61.304073)
        (xy 31.120658 61.306539)
        (xy 31.113068 61.311328)
        (xy 31.023461 61.367866)
        (xy 30.955176 61.3873)
        (xy 30.887694 61.367037)
        (xy 30.805438 61.313722)
        (xy 30.805433 61.31372)
        (xy 30.797906 61.308841)
        (xy 30.789311 61.306271)
        (xy 30.78931 61.30627)
        (xy 30.682874 61.274438)
        (xy 30.682872 61.274438)
        (xy 30.674273 61.271866)
        (xy 30.665298 61.271811)
        (xy 30.665297 61.271811)
        (xy 30.610641 61.271477)
        (xy 30.545231 61.271078)
        (xy 30.533475 61.274438)
        (xy 30.429786 61.304072)
        (xy 30.429784 61.304073)
        (xy 30.421155 61.306539)
        (xy 30.413565 61.311328)
        (xy 30.32884 61.364786)
        (xy 30.312019 61.375399)
        (xy 30.226596 61.472122)
        (xy 30.222782 61.480245)
        (xy 30.222781 61.480247)
        (xy 30.199686 61.529438)
        (xy 30.171754 61.588932)
        (xy 30.170374 61.597798)
        (xy 30.153282 61.707567)
        (xy 30.153282 61.707571)
        (xy 30.151901 61.71644)
        (xy 30.153065 61.725342)
        (xy 30.153065 61.725345)
        (xy 30.167468 61.835489)
        (xy 30.167469 61.835493)
        (xy 30.168633 61.844394)
        (xy 30.220605 61.96251)
        (xy 30.22638 61.96938)
        (xy 30.226383 61.969385)
        (xy 30.25195 61.9998)
        (xy 30.280472 62.064815)
        (xy 30.2815 62.080876)
        (xy 30.2815 63.829927)
        (xy 30.261498 63.898048)
        (xy 30.246846 63.914807)
        (xy 30.247516 63.915399)
        (xy 30.162093 64.012122)
        (xy 30.158279 64.020245)
        (xy 30.158278 64.020247)
        (xy 30.132291 64.075598)
        (xy 30.107251 64.128932)
        (xy 30.100832 64.170159)
        (xy 30.088779 64.247567)
        (xy 30.088779 64.247571)
        (xy 15.189373 54.864)
        (xy 51.845318 54.864)
        (xy 51.865956 55.020762)
        (xy 51.926464 55.166841)
        (xy 52.022718 55.292282)
        (xy 52.148159 55.388536)
        (xy 52.294238 55.449044)
        (xy 52.451 55.469682)
        (xy 52.459188 55.468604)
        (xy 52.599574 55.450122)
        (xy 52.607762 55.449044)
        (xy 52.753841 55.388536)
        (xy 52.879282 55.292282)
        (xy 52.920323 55.238796)
        (xy 52.977661 55.196929)
        (xy 53.020286 55.1895)
        (xy 53.720169 55.1895)
        (xy 53.78829 55.209502)
        (xy 53.834783 55.263158)
        (xy 53.845091 55.331946)
        (xy 53.839818 55.372)
        (xy 53.860456 55.528762)
        (xy 53.920964 55.674841)
        (xy 54.017218 55.800282)
        (xy 54.142659 55.896536)
        (xy 54.288738 55.957044)
        (xy 54.4455 55.977682)
        (xy 54.453688 55.976604)
        (xy 54.594074 55.958122)
        (xy 54.602262 55.957044)
        (xy 54.748341 55.896536)
        (xy 54.873782 55.800282)
        (xy 54.970036 55.674841)
        (xy 55.030544 55.528762)
        (xy 55.051182 55.372)
        (xy 55.030544 55.215238)
        (xy 54.970036 55.069159)
        (xy 54.873782 54.943718)
        (xy 54.748341 54.847464)
        (xy 54.602262 54.786956)
        (xy 54.4455 54.766318)
        (xy 54.378657 54.775118)
        (xy 54.30851 54.764179)
        (xy 54.273117 54.739291)
        (xy 54.18161 54.647784)
        (xy 54.174183 54.63968)
        (xy 54.157041 54.619251)
        (xy 54.149955 54.610806)
        (xy 54.140406 54.605293)
        (xy 54.117315 54.591961)
        (xy 54.108044 54.586055)
        (xy 54.086215 54.57077)
        (xy 54.077184 54.564446)
        (xy 54.066534 54.561592)
        (xy 54.063366 54.560115)
        (xy 54.06009 54.558923)
        (xy 54.050545 54.553412)
        (xy 54.016801 54.547462)
        (xy 54.013442 54.54687)
        (xy 54.002715 54.544492)
        (xy 53.966307 54.534736)
        (xy 53.955322 54.535697)
        (xy 53.95532 54.535697)
        (xy 53.928772 54.53802)
        (xy 53.91779 54.5385)
        (xy 53.020286 54.5385)
        (xy 52.952165 54.518498)
        (xy 52.920323 54.489204)
        (xy 52.884305 54.442264)
        (xy 52.879282 54.435718)
        (xy 52.753841 54.339464)
        (xy 52.607762 54.278956)
        (xy 52.451 54.258318)
        (xy 52.294238 54.278956)
        (xy 52.148159 54.339464)
        (xy 52.022718 54.435718)
        (xy 51.926464 54.561159)
        (xy 51.865956 54.707238)
        (xy 15.189373 50.708611)
        (xy 24.125394 50.708611)
        (xy 24.143999 50.877135)
        (xy 24.202266 51.036356)
        (xy 24.206502 51.042659)
        (xy 24.206502 51.04266)
        (xy 24.219574 51.062113)
        (xy 24.29683 51.177083)
        (xy 24.302442 51.18219)
        (xy 24.302445 51.182193)
        (xy 24.416612 51.286077)
        (xy 24.416616 51.28608)
        (xy 24.422233 51.291191)
        (xy 24.428906 51.294814)
        (xy 24.42891 51.294817)
        (xy 24.564558 51.368467)
        (xy 24.56456 51.368468)
        (xy 24.571235 51.372092)
        (xy 24.578584 51.37402)
        (xy 24.727883 51.413188)
        (xy 24.727885 51.413188)
        (xy 24.735233 51.415116)
        (xy 24.821609 51.416473)
        (xy 24.897161 51.41766)
        (xy 24.897164 51.41766)
        (xy 24.90476 51.417779)
        (xy 24.912165 51.416083)
        (xy 24.912166 51.416083)
        (xy 24.972586 51.402245)
        (xy 25.070029 51.379928)
        (xy 25.221498 51.303747)
        (xy 25.350423 51.193634)
        (xy 25.449361 51.055947)
        (xy 25.457237 51.036356)
        (xy 25.509766 50.905687)
        (xy 25.509767 50.905685)
        (xy 25.512601 50.898634)
        (xy 25.53649 50.730778)
        (xy 25.536645 50.716)
        (xy 25.535751 50.708611)
        (xy 26.025394 50.708611)
        (xy 26.043999 50.877135)
        (xy 26.102266 51.036356)
        (xy 26.106502 51.042659)
        (xy 26.106502 51.04266)
        (xy 26.119574 51.062113)
        (xy 26.19683 51.177083)
        (xy 26.202442 51.18219)
        (xy 26.202445 51.182193)
        (xy 26.316612 51.286077)
        (xy 26.316616 51.28608)
        (xy 26.322233 51.291191)
        (xy 26.328906 51.294814)
        (xy 26.32891 51.294817)
        (xy 26.464558 51.368467)
        (xy 26.46456 51.368468)
        (xy 26.471235 51.372092)
        (xy 26.478584 51.37402)
        (xy 26.627883 51.413188)
        (xy 26.627885 51.413188)
        (xy 26.635233 51.415116)
        (xy 26.721609 51.416473)
        (xy 26.797161 51.41766)
        (xy 26.797164 51.41766)
        (xy 26.80476 51.417779)
        (xy 26.812165 51.416083)
        (xy 26.812166 51.416083)
        (xy 26.872586 51.402245)
        (xy 26.970029 51.379928)
        (xy 27.121498 51.303747)
        (xy 27.250423 51.193634)
        (xy 27.349361 51.055947)
        (xy 27.357237 51.036356)
        (xy 27.409766 50.905687)
        (xy 27.409767 50.905685)
        (xy 27.412601 50.898634)
        (xy 27.43649 50.730778)
        (xy 27.436645 50.716)
        (xy 27.43484 50.70108)
        (xy 27.432004 50.677653)
        (xy 27.416276 50.54768)
        (xy 27.356345 50.389077)
        (xy 27.260312 50.249349)
        (xy 27.254119 50.243831)
        (xy 27.139392 50.141612)
        (xy 27.139388 50.14161)
        (xy 27.133721 50.13656)
        (xy 27.103994 50.12082)
        (xy 27.056612 50.095733)
        (xy 26.983881 50.057224)
        (xy 26.819441 50.015919)
        (xy 26.811843 50.015879)
        (xy 26.811841 50.015879)
        (xy 26.734668 50.015475)
        (xy 26.649895 50.015031)
        (xy 26.642508 50.016805)
        (xy 26.642504 50.016805)
        (xy 26.554274 50.037988)
        (xy 26.485032 50.054612)
        (xy 26.478288 50.058093)
        (xy 26.478285 50.058094)
        (xy 26.378415 50.109641)
        (xy 26.334369 50.132375)
        (xy 26.328647 50.137367)
        (xy 26.328645 50.137368)
        (xy 26.262853 50.194762)
        (xy 26.206604 50.243831)
        (xy 26.109113 50.382547)
        (xy 26.047524 50.540513)
        (xy 25.53484 50.70108)
        (xy 25.532004 50.677653)
        (xy 25.516276 50.54768)
        (xy 25.456345 50.389077)
        (xy 25.360312 50.249349)
        (xy 25.354119 50.243831)
        (xy 25.239392 50.141612)
        (xy 25.239388 50.14161)
        (xy 25.233721 50.13656)
        (xy 25.203994 50.12082)
        (xy 25.156612 50.095733)
        (xy 25.083881 50.057224)
        (xy 24.919441 50.015919)
        (xy 24.911843 50.015879)
        (xy 24.911841 50.015879)
        (xy 24.834668 50.015475)
        (xy 24.749895 50.015031)
        (xy 24.742508 50.016805)
        (xy 24.742504 50.016805)
        (xy 24.654274 50.037988)
        (xy 24.585032 50.054612)
        (xy 24.578288 50.058093)
        (xy 24.578285 50.058094)
        (xy 24.478415 50.109641)
        (xy 24.434369 50.132375)
        (xy 24.428647 50.137367)
        (xy 24.428645 50.137368)
        (xy 24.362853 50.194762)
        (xy 24.306604 50.243831)
        (xy 24.209113 50.382547)
        (xy 24.147524 50.540513)
        (xy 15.189373 46.724107)
        (xy 15.483962 46.724107)
        (xy 15.484134 46.727502)
        (xy 15.484134 46.727503)
        (xy 15.487832 46.8005)
        (xy 15.502605 47.092135)
        (xy 15.503142 47.09549)
        (xy 15.503143 47.095496)
        (xy 15.536072 47.301078)
        (xy 15.560886 47.455996)
        (xy 15.658123 47.811435)
        (xy 15.793179 48.154293)
        (xy 15.794762 48.157308)
        (xy 15.962889 48.477544)
        (xy 15.962894 48.477552)
        (xy 15.964473 48.48056)
        (xy 16.170002 48.786419)
        (xy 16.407361 49.068292)
        (xy 16.673774 49.322882)
        (xy 16.966124 49.54721)
        (xy 16.991097 49.562394)
        (xy 17.278077 49.736881)
        (xy 17.278082 49.736884)
        (xy 17.280992 49.738653)
        (xy 17.614693 49.89497)
        (xy 17.963325 50.014333)
        (xy 17.966648 50.015082)
        (xy 17.966652 50.015083)
        (xy 18.319484 50.094598)
        (xy 18.31949 50.094599)
        (xy 18.322809 50.095347)
        (xy 18.326188 50.095732)
        (xy 18.326194 50.095733)
        (xy 18.460765 50.111065)
        (xy 18.68894 50.137062)
        (xy 18.692345 50.13708)
        (xy 18.692348 50.13708)
        (xy 18.889323 50.138111)
        (xy 19.057434 50.138991)
        (xy 19.06082 50.138641)
        (xy 19.060822 50.138641)
        (xy 19.420589 50.101463)
        (xy 19.420598 50.101462)
        (xy 19.423981 50.101112)
        (xy 19.427314 50.100397)
        (xy 19.427317 50.100397)
        (xy 19.640885 50.054612)
        (xy 19.784294 50.023868)
        (xy 20.134157 49.908162)
        (xy 20.469477 49.755348)
        (xy 20.657869 49.643489)
        (xy 20.783387 49.568962)
        (xy 20.783392 49.568959)
        (xy 20.786332 49.567213)
        (xy 20.792751 49.562394)
        (xy 20.843301 49.52444)
        (xy 39.422901 49.52444)
        (xy 39.424065 49.533342)
        (xy 39.424065 49.533345)
        (xy 39.438468 49.643489)
        (xy 39.438469 49.643493)
        (xy 39.439633 49.652394)
        (xy 39.44325 49.660614)
        (xy 39.485558 49.756766)
        (xy 39.491605 49.77051)
        (xy 39.497382 49.777383)
        (xy 39.497383 49.777384)
        (xy 39.568859 49.862415)
        (xy 39.574639 49.869291)
        (xy 39.68206 49.940796)
        (xy 39.805233 49.979278)
        (xy 39.814205 49.979442)
        (xy 39.814209 49.979443)
        (xy 39.815865 49.979473)
        (xy 39.817433 49.979965)
        (xy 39.823071 49.980878)
        (xy 39.822939 49.981692)
        (xy 39.883608 50.000721)
        (xy 39.910074 50.024459)
        (xy 39.910176 50.02458)
        (xy 39.927101 50.04475)
        (xy 39.93665 50.050263)
        (xy 39.959741 50.063595)
        (xy 39.969012 50.069501)
        (xy 39.999872 50.09111)
        (xy 40.010522 50.093964)
        (xy 40.01369 50.095441)
        (xy 40.016966 50.096633)
        (xy 40.026511 50.102144)
        (xy 40.060255 50.108094)
        (xy 40.063614 50.108686)
        (xy 40.074341 50.111064)
        (xy 40.110749 50.12082)
        (xy 40.121734 50.119859)
        (xy 40.121736 50.119859)
        (xy 40.148284 50.117536)
        (xy 40.159266 50.117056)
        (xy 41.682376 50.117056)
        (xy 41.752195 50.138169)
        (xy 41.848616 50.202352)
        (xy 41.971789 50.240834)
        (xy 41.980759 50.240998)
        (xy 41.980763 50.240999)
        (xy 42.039498 50.242075)
        (xy 42.100811 50.243199)
        (xy 42.163061 50.226228)
        (xy 42.216648 50.211618)
        (xy 42.216649 50.211618)
        (xy 42.225311 50.209256)
        (xy 42.232961 50.204559)
        (xy 42.232963 50.204558)
        (xy 42.327628 50.146434)
        (xy 42.327631 50.146431)
        (xy 42.33528 50.141735)
        (xy 42.341306 50.135078)
        (xy 42.415856 50.052717)
        (xy 42.415859 50.052713)
        (xy 42.421878 50.046063)
        (xy 42.478144 49.929931)
        (xy 42.481627 49.909232)
        (xy 42.498746 49.807473)
        (xy 42.499553 49.802676)
        (xy 42.499689 49.791556)
        (xy 42.489627 49.721295)
        (xy 42.482668 49.672701)
        (xy 42.482667 49.672698)
        (xy 42.481395 49.663815)
        (xy 42.472729 49.644755)
        (xy 42.431701 49.554518)
        (xy 42.431699 49.554515)
        (xy 42.427984 49.546344)
        (xy 42.343749 49.448584)
        (xy 42.235462 49.378397)
        (xy 42.226867 49.375827)
        (xy 42.226866 49.375826)
        (xy 42.12043 49.343994)
        (xy 42.120428 49.343994)
        (xy 42.111829 49.341422)
        (xy 42.102854 49.341367)
        (xy 42.102853 49.341367)
        (xy 42.048197 49.341033)
        (xy 41.982787 49.340634)
        (xy 41.920749 49.358365)
        (xy 41.867342 49.373628)
        (xy 41.86734 49.373629)
        (xy 41.858711 49.376095)
        (xy 41.749575 49.444955)
        (xy 41.747909 49.442315)
        (xy 41.697208 49.464928)
        (xy 41.680385 49.466056)
        (xy 40.42497 49.466056)
        (xy 40.356849 49.446054)
        (xy 40.31027 49.392208)
        (xy 40.265147 49.292965)
        (xy 40.265143 49.292959)
        (xy 40.261428 49.284788)
        (xy 40.235625 49.254842)
        (xy 40.183051 49.193826)
        (xy 40.183049 49.193824)
        (xy 40.177193 49.187028)
        (xy 40.068906 49.116841)
        (xy 40.060311 49.114271)
        (xy 40.06031 49.11427)
        (xy 39.953874 49.082438)
        (xy 39.953872 49.082438)
        (xy 39.945273 49.079866)
        (xy 39.936298 49.079811)
        (xy 39.936297 49.079811)
        (xy 39.881641 49.079477)
        (xy 39.816231 49.079078)
        (xy 39.755286 49.096496)
        (xy 39.700786 49.112072)
        (xy 39.700784 49.112073)
        (xy 39.692155 49.114539)
        (xy 39.684565 49.119328)
        (xy 39.598721 49.173492)
        (xy 39.583019 49.183399)
        (xy 39.497596 49.280122)
        (xy 39.493782 49.288245)
        (xy 39.493781 49.288247)
        (xy 39.480211 49.31715)
        (xy 39.442754 49.396932)
        (xy 39.436109 49.439608)
        (xy 39.424282 49.515567)
        (xy 39.424282 49.515571)
        (xy 20.947701 49.446054)
        (xy 21.081015 49.345959)
        (xy 21.35008 49.094173)
        (xy 21.590378 48.814801)
        (xy 21.686629 48.674755)
        (xy 21.797168 48.51392)
        (xy 21.797173 48.513913)
        (xy 21.799098 48.511111)
        (xy 21.80071 48.508117)
        (xy 21.800715 48.508109)
        (xy 21.965451 48.202159)
        (xy 21.973799 48.186655)
        (xy 22.112438 47.84523)
        (xy 22.135828 47.76312)
        (xy 22.140579 47.74644)
        (xy 50.852901 47.74644)
        (xy 50.854065 47.755342)
        (xy 50.854065 47.755345)
        (xy 50.868468 47.865489)
        (xy 50.868469 47.865493)
        (xy 50.869633 47.874394)
        (xy 50.921605 47.99251)
        (xy 51.004639 48.091291)
        (xy 51.11206 48.162796)
        (xy 51.235233 48.201278)
        (xy 51.244205 48.201442)
        (xy 51.244208 48.201443)
        (xy 51.281993 48.202135)
        (xy 51.283286 48.202159)
        (xy 51.351028 48.223407)
        (xy 51.370071 48.239043)
        (xy 52.368151 49.237123)
        (xy 52.402177 49.299435)
        (xy 52.403992 49.309879)
        (xy 52.418866 49.423627)
        (xy 52.437039 49.464928)
        (xy 52.463225 49.52444)
        (xy 52.470838 49.541743)
        (xy 52.476615 49.548616)
        (xy 52.476616 49.548617)
        (xy 52.548092 49.633648)
        (xy 52.553872 49.640524)
        (xy 52.661293 49.712029)
        (xy 52.784466 49.750511)
        (xy 52.793436 49.750675)
        (xy 52.79344 49.750676)
        (xy 52.852175 49.751752)
        (xy 52.913488 49.752876)
        (xy 52.978472 49.735159)
        (xy 53.029325 49.721295)
        (xy 53.029326 49.721295)
        (xy 53.037988 49.718933)
        (xy 53.045638 49.714236)
        (xy 53.04564 49.714235)
        (xy 53.140305 49.656111)
        (xy 53.140308 49.656108)
        (xy 53.147957 49.651412)
        (xy 53.155129 49.643489)
        (xy 53.228533 49.562394)
        (xy 53.228536 49.56239)
        (xy 53.234555 49.55574)
        (xy 53.290821 49.439608)
        (xy 53.297105 49.402259)
        (xy 53.311423 49.31715)
        (xy 53.31223 49.312353)
        (xy 53.312366 49.301233)
        (xy 53.299267 49.209766)
        (xy 53.30941 49.139498)
        (xy 53.355932 49.085868)
        (xy 53.424064 49.065904)
        (xy 53.461565 49.071636)
        (xy 53.521233 49.090278)
        (xy 53.530203 49.090442)
        (xy 53.530207 49.090443)
        (xy 53.588942 49.091519)
        (xy 53.650255 49.092643)
        (xy 53.730938 49.070646)
        (xy 53.766092 49.061062)
        (xy 53.766093 49.061062)
        (xy 53.774755 49.0587)
        (xy 53.782405 49.054003)
        (xy 53.782407 49.054002)
        (xy 53.877072 48.995878)
        (xy 53.877075 48.995875)
        (xy 53.884724 48.991179)
        (xy 53.89075 48.984522)
        (xy 53.9653 48.902161)
        (xy 53.965303 48.902157)
        (xy 53.971322 48.895507)
        (xy 54.027588 48.779375)
        (xy 54.048997 48.65212)
        (xy 54.049133 48.641)
        (xy 54.030839 48.513259)
        (xy 54.015972 48.48056)
        (xy 53.981145 48.403962)
        (xy 53.981143 48.403959)
        (xy 53.977428 48.395788)
        (xy 53.893193 48.298028)
        (xy 53.784906 48.227841)
        (xy 53.776311 48.225271)
        (xy 53.77631 48.22527)
        (xy 53.669874 48.193438)
        (xy 53.669872 48.193438)
        (xy 53.661273 48.190866)
        (xy 53.652297 48.190811)
        (xy 53.643417 48.189484)
        (xy 53.643747 48.187279)
        (xy 53.587578 48.17041)
        (xy 53.567254 48.153928)
        (xy 52.419013 47.005687)
        (xy 52.384987 46.943375)
        (xy 52.383854 46.895688)
        (xy 52.39719 46.816417)
        (xy 52.397997 46.81162)
        (xy 52.398133 46.8005)
        (xy 52.389474 46.740036)
        (xy 52.381112 46.681645)
        (xy 52.381111 46.681642)
        (xy 52.379839 46.672759)
        (xy 52.347766 46.602218)
        (xy 52.330145 46.563462)
        (xy 52.330143 46.563459)
        (xy 52.326428 46.555288)
        (xy 52.294593 46.518341)
        (xy 52.248051 46.464326)
        (xy 52.248049 46.464324)
        (xy 52.242193 46.457528)
        (xy 52.133906 46.387341)
        (xy 52.125311 46.384771)
        (xy 52.12531 46.38477)
        (xy 52.018874 46.352938)
        (xy 52.018872 46.352938)
        (xy 52.010273 46.350366)
        (xy 52.001298 46.350311)
        (xy 52.001297 46.350311)
        (xy 51.946641 46.349977)
        (xy 51.881231 46.349578)
        (xy 51.869475 46.352938)
        (xy 51.765786 46.382572)
        (xy 51.765784 46.382573)
        (xy 51.757155 46.385039)
        (xy 51.648019 46.453899)
        (xy 51.562596 46.550622)
        (xy 51.558782 46.558745)
        (xy 51.558781 46.558747)
        (xy 51.546317 46.585295)
        (xy 51.507754 46.667432)
        (xy 51.50456 46.687946)
        (xy 51.489282 46.786067)
        (xy 51.489282 46.786071)
        (xy 51.487901 46.79494)
        (xy 51.489065 46.803842)
        (xy 51.489065 46.803845)
        (xy 51.503468 46.913989)
        (xy 51.503469 46.913993)
        (xy 51.504633 46.922894)
        (xy 51.556605 47.04101)
        (xy 51.562382 47.047883)
        (xy 51.562383 47.047884)
        (xy 51.639639 47.139791)
        (xy 51.637391 47.141681)
        (xy 51.667017 47.189377)
        (xy 51.665925 47.260365)
        (xy 51.626627 47.319494)
        (xy 51.561601 47.34799)
        (xy 51.499048 47.338365)
        (xy 51.498906 47.338841)
        (xy 51.42945 47.318069)
        (xy 51.383874 47.304438)
        (xy 51.383872 47.304438)
        (xy 51.375273 47.301866)
        (xy 51.366298 47.301811)
        (xy 51.366297 47.301811)
        (xy 51.311641 47.301477)
        (xy 51.246231 47.301078)
        (xy 51.234475 47.304438)
        (xy 51.130786 47.334072)
        (xy 51.130784 47.334073)
        (xy 51.122155 47.336539)
        (xy 51.013019 47.405399)
        (xy 51.007076 47.412128)
        (xy 51.007075 47.412129)
        (xy 50.971306 47.45263)
        (xy 50.927596 47.502122)
        (xy 50.872754 47.618932)
        (xy 50.867552 47.652341)
        (xy 50.854282 47.737567)
        (xy 50.854282 47.737571)
        (xy 22.187084 47.583182)
        (xy 22.213391 47.490829)
        (xy 22.239371 47.338841)
        (xy 22.274908 47.130945)
        (xy 22.274908 47.130943)
        (xy 22.27548 47.127598)
        (xy 22.277444 47.095496)
        (xy 22.297866 46.761583)
        (xy 22.297976 46.759786)
        (xy 22.298015 46.748713)
        (xy 22.298053 46.73782)
        (xy 22.298053 46.737808)
        (xy 22.298059 46.736)
        (xy 22.278131 46.36804)
        (xy 22.21858 46.004384)
        (xy 22.120103 45.649287)
        (xy 22.118845 45.646125)
        (xy 22.118842 45.646117)
        (xy 21.985111 45.310067)
        (xy 21.985107 45.310059)
        (xy 21.983851 45.306902)
        (xy 21.97814 45.296115)
        (xy 21.813014 44.984245)
        (xy 21.813012 44.984241)
        (xy 21.81142 44.981235)
        (xy 21.604824 44.676095)
        (xy 21.602619 44.673495)
        (xy 21.602613 44.673487)
        (xy 21.414743 44.451959)
        (xy 21.366483 44.395052)
        (xy 21.099183 44.141394)
        (xy 21.096476 44.139332)
        (xy 21.096468 44.139325)
        (xy 20.857662 43.957405)
        (xy 20.806051 43.918088)
        (xy 20.56369 43.771886)
        (xy 20.493438 43.729507)
        (xy 20.493437 43.729507)
        (xy 20.490517 43.727745)
        (xy 20.487427 43.726311)
        (xy 20.487422 43.726308)
        (xy 20.159368 43.574031)
        (xy 20.159366 43.57403)
        (xy 20.156272 43.572594)
        (xy 20.153037 43.571499)
        (xy 20.153032 43.571497)
        (xy 19.810461 43.455543)
        (xy 19.807226 43.454448)
        (xy 19.447461 43.37469)
        (xy 19.318574 43.360461)
        (xy 19.084568 43.334626)
        (xy 19.084563 43.334626)
        (xy 19.081187 43.334253)
        (xy 19.077788 43.334247)
        (xy 19.077787 43.334247)
        (xy 18.903708 43.333943)
        (xy 18.712688 43.33361)
        (xy 18.5482 43.351189)
        (xy 18.349659 43.372407)
        (xy 18.349653 43.372408)
        (xy 18.346275 43.372769)
        (xy 17.986235 43.45127)
        (xy 17.636778 43.568197)
        (xy 17.301993 43.72218)
        (xy 17.299059 43.723936)
        (xy 17.299057 43.723937)
        (xy 16.988725 43.909667)
        (xy 16.988717 43.909673)
        (xy 16.985797 43.91142)
        (xy 16.691888 44.133702)
        (xy 16.423704 44.386426)
        (xy 16.421492 44.389016)
        (xy 16.421491 44.389017)
        (xy 16.304626 44.525848)
        (xy 16.184383 44.666635)
        (xy 16.182469 44.669441)
        (xy 16.182465 44.669446)
        (xy 15.985955 44.957517)
        (xy 15.976723 44.971051)
        (xy 15.975122 44.974049)
        (xy 15.975118 44.974056)
        (xy 15.804761 45.293108)
        (xy 15.804757 45.293117)
        (xy 15.803156 45.296115)
        (xy 15.801887 45.299272)
        (xy 15.801885 45.299276)
        (xy 15.797547 45.310067)
        (xy 15.66571 45.638022)
        (xy 15.66479 45.641296)
        (xy 15.664788 45.641301)
        (xy 15.57168 45.972546)
        (xy 15.565994 45.992773)
        (xy 15.565432 45.99613)
        (xy 15.565432 45.996131)
        (xy 15.5563 46.050705)
        (xy 15.505174 46.356219)
        (xy 15.488712 46.641734)
        (xy 15.189373 32.942784)
        (xy 20.514 32.942784)
        (xy 20.514238 32.945501)
        (xy 20.514238 32.945508)
        (xy 20.517534 32.983175)
        (xy 20.528865 33.112692)
        (xy 20.530289 33.118005)
        (xy 20.530289 33.118007)
        (xy 20.577916 33.295752)
        (xy 20.587761 33.332496)
        (xy 20.590083 33.337476)
        (xy 20.590084 33.337478)
        (xy 20.634759 33.433282)
        (xy 20.683932 33.538734)
        (xy 20.814453 33.725139)
        (xy 20.975361 33.886047)
        (xy 21.161766 34.016568)
        (xy 21.166744 34.018889)
        (xy 21.166747 34.018891)
        (xy 21.357264 34.107731)
        (xy 21.368004 34.112739)
        (xy 21.373312 34.114161)
        (xy 21.373314 34.114162)
        (xy 21.582493 34.170211)
        (xy 21.582495 34.170211)
        (xy 21.587808 34.171635)
        (xy 21.8145 34.191468)
        (xy 22.041192 34.171635)
        (xy 22.046505 34.170211)
        (xy 22.046507 34.170211)
        (xy 22.255686 34.114162)
        (xy 22.255688 34.114161)
        (xy 22.260996 34.112739)
        (xy 22.271736 34.107731)
        (xy 22.462253 34.018891)
        (xy 22.462256 34.018889)
        (xy 22.467234 34.016568)
        (xy 22.653639 33.886047)
        (xy 22.814547 33.725139)
        (xy 22.945068 33.538734)
        (xy 22.994242 33.433282)
        (xy 23.038916 33.337478)
        (xy 23.038917 33.337476)
        (xy 23.041239 33.332496)
        (xy 23.051085 33.295752)
        (xy 23.098711 33.118007)
        (xy 23.098711 33.118005)
        (xy 23.100135 33.112692)
        (xy 23.111466 32.983175)
        (xy 23.114762 32.945508)
        (xy 23.114762 32.945501)
        (xy 23.115 32.942784)
        (xy 23.115 32.229216)
        (xy 23.100135 32.059308)
        (xy 23.09761 32.049883)
        (xy 23.042662 31.844814)
        (xy 23.042661 31.844812)
        (xy 23.041239 31.839504)
        (xy 23.016327 31.78608)
        (xy 22.947391 31.638247)
        (xy 22.947389 31.638244)
        (xy 22.945068 31.633266)
        (xy 22.814547 31.446861)
        (xy 22.653639 31.285953)
        (xy 22.467234 31.155432)
        (xy 22.462256 31.153111)
        (xy 22.462253 31.153109)
        (xy 22.265978 31.061584)
        (xy 22.265976 31.061583)
        (xy 22.260996 31.059261)
        (xy 22.255688 31.057839)
        (xy 22.255686 31.057838)
        (xy 22.046507 31.001789)
        (xy 22.046505 31.001789)
        (xy 22.041192 31.000365)
        (xy 21.8145 30.980532)
        (xy 21.587808 31.000365)
        (xy 21.582495 31.001789)
        (xy 21.582493 31.001789)
        (xy 21.373314 31.057838)
        (xy 21.373312 31.057839)
        (xy 21.368004 31.059261)
        (xy 21.363024 31.061583)
        (xy 21.363022 31.061584)
        (xy 21.166747 31.153109)
        (xy 21.166744 31.153111)
        (xy 21.161766 31.155432)
        (xy 20.975361 31.285953)
        (xy 20.814453 31.446861)
        (xy 20.683932 31.633266)
        (xy 20.681611 31.638244)
        (xy 20.681609 31.638247)
        (xy 20.612673 31.78608)
        (xy 20.587761 31.839504)
        (xy 20.586339 31.844812)
        (xy 20.586338 31.844814)
        (xy 20.53139 32.049883)
        (xy 20.528865 32.059308)
        (xy 20.514 32.229216)
        (xy 15.189373 27.945104)
        (xy 23.7345 27.945104)
        (xy 23.734712 27.950277)
        (xy 23.748945 28.12339)
        (xy 23.75063 28.13357)
        (xy 23.807399 28.359576)
        (xy 23.810719 28.369327)
        (xy 23.903641 28.583035)
        (xy 23.908507 28.59211)
        (xy 24.035083 28.787765)
        (xy 24.041375 28.795936)
        (xy 24.198205 28.968291)
        (xy 24.205738 28.975316)
        (xy 24.38862 29.119747)
        (xy 24.397193 29.125443)
        (xy 24.601211 29.238067)
        (xy 24.610608 29.24229)
        (xy 24.83027 29.320076)
        (xy 24.840241 29.32271)
        (xy 25.069652 29.363574)
        (xy 25.071697 29.363768)
        (xy 25.084679 29.360127)
        (xy 25.085629 29.359058)
        (xy 25.0875 29.350703)
        (xy 25.0875 29.345757)
        (xy 25.3415 29.345757)
        (xy 25.345418 29.359101)
        (xy 25.359694 29.361088)
        (xy 25.55355 29.331424)
        (xy 25.563577 29.329035)
        (xy 25.785071 29.25664)
        (xy 25.794581 29.252643)
        (xy 26.001271 29.145047)
        (xy 26.009996 29.139553)
        (xy 26.196343 28.999639)
        (xy 26.20405 28.992796)
        (xy 26.365047 28.824323)
        (xy 26.371533 28.816313)
        (xy 26.502846 28.623815)
        (xy 26.507939 28.614851)
        (xy 26.606057 28.403473)
        (xy 26.609609 28.39382)
        (xy 26.671888 28.169249)
        (xy 26.673816 28.159142)
        (xy 26.694144 27.968932)
        (xy 26.6945 27.962241)
        (xy 26.6945 27.731115)
        (xy 26.690025 27.715876)
        (xy 26.688635 27.714671)
        (xy 26.680952 27.713)
        (xy 25.359615 27.713)
        (xy 25.344376 27.717475)
        (xy 25.343171 27.718865)
        (xy 25.3415 27.726548)
        (xy 25.0875 27.731115)
        (xy 25.083025 27.715876)
        (xy 25.081635 27.714671)
        (xy 25.073952 27.713)
        (xy 23.752615 27.713)
        (xy 23.737376 27.717475)
        (xy 23.736171 27.718865)
        (xy 23.7345 27.726548)
        (xy 15.189373 27.440885)
        (xy 23.7345 27.440885)
        (xy 23.738975 27.456124)
        (xy 23.740365 27.457329)
        (xy 23.748048 27.459)
        (xy 25.069385 27.459)
        (xy 25.084624 27.454525)
        (xy 25.085829 27.453135)
        (xy 25.0875 27.445452)
        (xy 25.0875 27.440885)
        (xy 25.3415 27.440885)
        (xy 25.345975 27.456124)
        (xy 25.347365 27.457329)
        (xy 25.355048 27.459)
        (xy 26.676385 27.459)
        (xy 26.691624 27.454525)
        (xy 26.692829 27.453135)
        (xy 26.6945 27.445452)
        (xy 26.6945 27.226896)
        (xy 26.694288 27.221723)
        (xy 26.680055 27.04861)
        (xy 26.67837 27.03843)
        (xy 26.621601 26.812424)
        (xy 26.618281 26.802673)
        (xy 26.525359 26.588965)
        (xy 26.520493 26.57989)
        (xy 26.393917 26.384235)
        (xy 26.387625 26.376064)
        (xy 26.230795 26.203709)
        (xy 26.223262 26.196684)
        (xy 26.04038 26.052253)
        (xy 26.031807 26.046557)
        (xy 25.827789 25.933933)
        (xy 25.818392 25.92971)
        (xy 25.59873 25.851924)
        (xy 25.588759 25.84929)
        (xy 25.359348 25.808426)
        (xy 25.357303 25.808232)
        (xy 25.344321 25.811873)
        (xy 25.343371 25.812942)
        (xy 25.3415 25.821297)
        (xy 25.0875 25.826243)
        (xy 25.083582 25.812899)
        (xy 25.069306 25.810912)
        (xy 24.87545 25.840576)
        (xy 24.865423 25.842965)
        (xy 24.643929 25.91536)
        (xy 24.634419 25.919357)
        (xy 24.427729 26.026953)
        (xy 24.419004 26.032447)
        (xy 24.232657 26.172361)
        (xy 24.22495 26.179204)
        (xy 24.063953 26.347677)
        (xy 24.057467 26.355687)
        (xy 23.926154 26.548185)
        (xy 23.921061 26.557149)
        (xy 23.822943 26.768527)
        (xy 23.819391 26.77818)
        (xy 23.757112 27.002751)
        (xy 23.755184 27.012858)
        (xy 23.734856 27.203068)
        (xy 23.7345 27.209759)
        (xy 15.189373 23.242784)
        (xy 20.514 23.242784)
        (xy 20.528865 23.412692)
        (xy 20.530289 23.418005)
        (xy 20.530289 23.418007)
        (xy 20.574442 23.582787)
        (xy 20.587761 23.632496)
        (xy 20.683932 23.838734)
        (xy 20.814453 24.025139)
        (xy 20.975361 24.186047)
        (xy 21.161766 24.316568)
        (xy 21.166744 24.318889)
        (xy 21.166747 24.318891)
        (xy 21.363022 24.410416)
        (xy 21.368004 24.412739)
        (xy 21.373312 24.414161)
        (xy 21.373314 24.414162)
        (xy 21.582493 24.470211)
        (xy 21.582495 24.470211)
        (xy 21.587808 24.471635)
        (xy 21.8145 24.491468)
        (xy 22.041192 24.471635)
        (xy 22.046505 24.470211)
        (xy 22.046507 24.470211)
        (xy 22.255686 24.414162)
        (xy 22.255688 24.414161)
        (xy 22.260996 24.412739)
        (xy 22.265978 24.410416)
        (xy 22.462253 24.318891)
        (xy 22.462256 24.318889)
        (xy 22.467234 24.316568)
        (xy 22.653639 24.186047)
        (xy 22.814547 24.025139)
        (xy 22.945068 23.838734)
        (xy 23.041239 23.632496)
        (xy 23.054559 23.582787)
        (xy 23.098711 23.418007)
        (xy 23.098711 23.418005)
        (xy 23.100135 23.412692)
        (xy 23.115 23.242784)
        (xy 23.115 22.529216)
        (xy 23.113863 22.516213)
        (xy 23.100614 22.364788)
        (xy 23.100135 22.359308)
        (xy 23.082893 22.294959)
        (xy 23.042662 22.144814)
        (xy 23.042661 22.144812)
        (xy 23.041239 22.139504)
        (xy 22.984237 22.017263)
        (xy 22.947391 21.938247)
        (xy 22.947389 21.938244)
        (xy 22.945068 21.933266)
        (xy 22.814547 21.746861)
        (xy 22.653639 21.585953)
        (xy 22.467234 21.455432)
        (xy 22.462256 21.453111)
        (xy 22.462253 21.453109)
        (xy 22.265978 21.361584)
        (xy 22.265976 21.361583)
        (xy 22.260996 21.359261)
        (xy 22.255688 21.357839)
        (xy 22.255686 21.357838)
        (xy 22.046507 21.301789)
        (xy 22.046505 21.301789)
        (xy 22.041192 21.300365)
        (xy 21.8145 21.280532)
        (xy 21.587808 21.300365)
        (xy 21.582495 21.301789)
        (xy 21.582493 21.301789)
        (xy 21.373314 21.357838)
        (xy 21.373312 21.357839)
        (xy 21.368004 21.359261)
        (xy 21.363024 21.361583)
        (xy 21.363022 21.361584)
        (xy 21.166747 21.453109)
        (xy 21.166744 21.453111)
        (xy 21.161766 21.455432)
        (xy 20.975361 21.585953)
        (xy 20.814453 21.746861)
        (xy 20.683932 21.933266)
        (xy 20.681611 21.938244)
        (xy 20.681609 21.938247)
        (xy 20.644763 22.017263)
        (xy 20.587761 22.139504)
        (xy 20.586339 22.144812)
        (xy 20.586338 22.144814)
        (xy 20.546107 22.294959)
        (xy 20.528865 22.359308)
        (xy 20.528386 22.364788)
        (xy 20.515138 22.516213)
        (xy 20.514 22.529216)
        (xy 15.189373 15.619495)
        (xy 15.209375 15.551374)
        (xy 15.263031 15.504881)
        (xy 15.315373 15.493495)
        (xy 27.763597 15.493495)
  (zone (net 135) (net_name "Net-(J13-Pad9)") (layer "B.Cu") (tstamp b98f3fd3-cc89-4c23-9dd0-7793be575c6d) (hatch edge 0.508)
    (connect_pads (clearance 0.508))
    (min_thickness 0.254) (filled_areas_thickness no)
    (fill yes (thermal_gap 0.508) (thermal_bridge_width 0.508))
    (polygon
      (pts
        (xy 172.72 167.64)
        (xy 96.52 167.64)
        (xy 96.52 115.57)
        (xy 172.72 115.57)
    (filled_polygon
      (layer "B.Cu")
      (pts
        (xy 172.662121 115.590002)
        (xy 172.708614 115.643658)
        (xy 172.72 115.696)
        (xy 172.72 167.514)
        (xy 172.699998 167.582121)
        (xy 172.646342 167.628614)
        (xy 172.594 167.64)
        (xy 96.646 167.64)
        (xy 96.577879 167.619998)
        (xy 96.531386 167.566342)
        (xy 96.52 167.514)
        (xy 96.52 162.660339)
        (xy 98.015091 162.660339)
        (xy 98.050747 162.893349)
        (xy 98.12398 163.117407)
        (xy 98.232825 163.326496)
        (xy 98.235928 163.330629)
        (xy 98.23593 163.330632)
        (xy 98.258026 163.360061)
        (xy 98.374358 163.515)
        (xy 98.544777 163.677857)
        (xy 98.739508 163.810693)
        (xy 98.744192 163.812867)
        (xy 98.744195 163.812869)
        (xy 98.948628 163.907764)
        (xy 98.948633 163.907766)
        (xy 98.953319 163.909941)
        (xy 99.180468 163.972935)
        (xy 99.185605 163.973484)
        (xy 99.369563 163.993144)
        (xy 99.369571 163.993144)
        (xy 99.372898 163.9935)
        (xy 100.707757 163.9935)
        (xy 100.71033 163.993288)
        (xy 100.710341 163.993288)
        (xy 100.877779 163.979522)
        (xy 100.877785 163.979521)
        (xy 100.88293 163.979098)
        (xy 101.111551 163.921673)
        (xy 101.327723 163.827678)
        (xy 101.525641 163.69964)
        (xy 101.549581 163.677857)
        (xy 101.696167 163.544473)
        (xy 101.696168 163.544471)
        (xy 101.699989 163.540995)
        (xy 101.703188 163.536944)
        (xy 101.703192 163.53694)
        (xy 101.842883 163.360061)
        (xy 101.842885 163.360057)
        (xy 101.846085 163.356006)
        (xy 101.960005 163.149639)
        (xy 101.969794 163.121998)
        (xy 102.036965 162.932311)
        (xy 102.036966 162.932307)
        (xy 102.038691 162.927436)
        (xy 102.042463 162.906263)
        (xy 102.079123 162.700456)
        (xy 102.079124 162.70045)
        (xy 102.080029 162.695367)
        (xy 102.080457 162.660339)
        (xy 110.515091 162.660339)
        (xy 110.550747 162.893349)
        (xy 110.62398 163.117407)
        (xy 110.732825 163.326496)
        (xy 110.735928 163.330629)
        (xy 110.73593 163.330632)
        (xy 110.758026 163.360061)
        (xy 110.874358 163.515)
        (xy 111.044777 163.677857)
        (xy 111.239508 163.810693)
        (xy 111.244192 163.812867)
        (xy 111.244195 163.812869)
        (xy 111.448628 163.907764)
        (xy 111.448633 163.907766)
        (xy 111.453319 163.909941)
        (xy 111.680468 163.972935)
        (xy 111.685605 163.973484)
        (xy 111.869563 163.993144)
        (xy 111.869571 163.993144)
        (xy 111.872898 163.9935)
        (xy 113.207757 163.9935)
        (xy 113.21033 163.993288)
        (xy 113.210341 163.993288)
        (xy 113.377779 163.979522)
        (xy 113.377785 163.979521)
        (xy 113.38293 163.979098)
        (xy 113.611551 163.921673)
        (xy 113.827723 163.827678)
        (xy 114.025641 163.69964)
        (xy 114.049581 163.677857)
        (xy 114.17577 163.563033)
        (xy 116.046193 163.563033)
        (xy 116.046343 163.566214)
        (xy 116.063165 163.922932)
        (xy 116.063899 163.938504)
        (xy 116.064371 163.941661)
        (xy 116.064371 163.941663)
        (xy 116.068838 163.971553)
        (xy 116.119459 164.310263)
        (xy 116.212303 164.674505)
        (xy 116.341481 165.0275)
        (xy 116.50567 165.365633)
        (xy 116.703188 165.685443)
        (xy 116.932015 165.983655)
        (xy 117.189806 166.257217)
        (xy 117.192211 166.259301)
        (xy 117.192217 166.259306)
        (xy 117.220719 166.283995)
        (xy 117.473922 166.503326)
        (xy 117.781455 166.719464)
        (xy 118.109256 166.903417)
        (xy 118.11217 166.904684)
        (xy 118.112174 166.904686)
        (xy 118.253491 166.966132)
        (xy 118.453968 167.053302)
        (xy 118.812062 167.167585)
        (xy 118.815195 167.168245)
        (xy 118.815198 167.168246)
        (xy 119.176745 167.244435)
        (xy 119.176748 167.244435)
        (xy 119.179873 167.245094)
        (xy 119.553633 167.285038)
        (xy 119.55682 167.285055)
        (xy 119.556826 167.285055)
        (xy 119.727357 167.285948)
        (xy 119.929516 167.287006)
        (xy 120.030492 167.277283)
        (xy 120.30049 167.251286)
        (xy 120.300498 167.251285)
        (xy 120.303674 167.250979)
        (xy 120.672275 167.177325)
        (xy 120.675311 167.176391)
        (xy 120.675319 167.176389)
        (xy 121.028505 167.067734)
        (xy 121.028508 167.067733)
        (xy 121.031547 167.066798)
        (xy 121.034475 167.065561)
        (xy 121.034481 167.065559)
        (xy 121.190096 166.999824)
        (xy 121.37781 166.920531)
        (xy 121.380613 166.918996)
        (xy 121.380618 166.918994)
        (xy 121.522369 166.841388)
        (xy 121.707519 166.740021)
        (xy 122.017298 166.527115)
        (xy 122.019737 166.525047)
        (xy 122.019743 166.525042)
        (xy 122.301536 166.286065)
        (xy 122.301544 166.286057)
        (xy 122.303976 166.283995)
        (xy 122.306184 166.2817)
        (xy 122.306192 166.281693)
        (xy 122.562403 166.01545)
        (xy 122.562405 166.015447)
        (xy 122.564618 166.013148)
        (xy 122.619849 165.942709)
        (xy 122.79458 165.719866)
        (xy 122.794583 165.719861)
        (xy 122.796554 165.717348)
        (xy 122.997411 165.399624)
        (xy 123.165132 165.063229)
        (xy 123.297999 164.711606)
        (xy 123.394652 164.348357)
        (xy 123.419863 164.190963)
        (xy 123.453597 163.98035)
        (xy 123.454102 163.977199)
        (xy 123.454317 163.973484)
        (xy 123.465562 163.778442)
        (xy 123.475739 163.601934)
        (xy 123.47583 163.576)
        (xy 123.475745 163.574317)
        (xy 123.456974 163.203766)
        (xy 123.456973 163.203761)
        (xy 123.456813 163.200593)
        (xy 123.415014 162.927436)
        (xy 123.40044 162.83219)
        (xy 123.400438 162.832181)
        (xy 123.399956 162.82903)
        (xy 123.366705 162.700456)
        (xy 123.35633 162.660339)
        (xy 125.955091 162.660339)
        (xy 125.990747 162.893349)
        (xy 126.06398 163.117407)
        (xy 126.172825 163.326496)
        (xy 126.175928 163.330629)
        (xy 126.17593 163.330632)
        (xy 126.198026 163.360061)
        (xy 126.314358 163.515)
        (xy 126.484777 163.677857)
        (xy 126.679508 163.810693)
        (xy 126.684192 163.812867)
        (xy 126.684195 163.812869)
        (xy 126.888628 163.907764)
        (xy 126.888633 163.907766)
        (xy 126.893319 163.909941)
        (xy 127.120468 163.972935)
        (xy 127.125605 163.973484)
        (xy 127.309563 163.993144)
        (xy 127.309571 163.993144)
        (xy 127.312898 163.9935)
        (xy 128.647757 163.9935)
        (xy 128.65033 163.993288)
        (xy 128.650341 163.993288)
        (xy 128.817779 163.979522)
        (xy 128.817785 163.979521)
        (xy 128.82293 163.979098)
        (xy 129.051551 163.921673)
        (xy 129.267723 163.827678)
        (xy 129.465641 163.69964)
        (xy 129.489581 163.677857)
        (xy 129.636167 163.544473)
        (xy 129.636168 163.544471)
        (xy 129.639989 163.540995)
        (xy 129.643188 163.536944)
        (xy 129.643192 163.53694)
        (xy 129.782883 163.360061)
        (xy 129.782885 163.360057)
        (xy 129.786085 163.356006)
        (xy 129.900005 163.149639)
        (xy 129.909794 163.121998)
        (xy 129.976965 162.932311)
        (xy 129.976966 162.932307)
        (xy 129.978691 162.927436)
        (xy 129.982463 162.906263)
        (xy 130.019123 162.700456)
        (xy 130.019124 162.70045)
        (xy 130.020029 162.695367)
        (xy 130.020457 162.660339)
        (xy 138.455091 162.660339)
        (xy 138.490747 162.893349)
        (xy 138.56398 163.117407)
        (xy 138.672825 163.326496)
        (xy 138.675928 163.330629)
        (xy 138.67593 163.330632)
        (xy 138.698026 163.360061)
        (xy 138.814358 163.515)
        (xy 138.984777 163.677857)
        (xy 139.179508 163.810693)
        (xy 139.184192 163.812867)
        (xy 139.184195 163.812869)
        (xy 139.388628 163.907764)
        (xy 139.388633 163.907766)
        (xy 139.393319 163.909941)
        (xy 139.620468 163.972935)
        (xy 139.625605 163.973484)
        (xy 139.809563 163.993144)
        (xy 139.809571 163.993144)
        (xy 139.812898 163.9935)
        (xy 141.147757 163.9935)
        (xy 141.15033 163.993288)
        (xy 141.150341 163.993288)
        (xy 141.317779 163.979522)
        (xy 141.317785 163.979521)
        (xy 141.32293 163.979098)
        (xy 141.551551 163.921673)
        (xy 141.767723 163.827678)
        (xy 141.965641 163.69964)
        (xy 141.989581 163.677857)
        (xy 142.11577 163.563033)
        (xy 145.256193 163.563033)
        (xy 145.256343 163.566214)
        (xy 145.273165 163.922932)
        (xy 145.273899 163.938504)
        (xy 145.274371 163.941661)
        (xy 145.274371 163.941663)
        (xy 145.278838 163.971553)
        (xy 145.329459 164.310263)
        (xy 145.422303 164.674505)
        (xy 145.551481 165.0275)
        (xy 145.71567 165.365633)
        (xy 145.913188 165.685443)
        (xy 146.142015 165.983655)
        (xy 146.399806 166.257217)
        (xy 146.402211 166.259301)
        (xy 146.402217 166.259306)
        (xy 146.430719 166.283995)
        (xy 146.683922 166.503326)
        (xy 146.991455 166.719464)
        (xy 147.319256 166.903417)
        (xy 147.32217 166.904684)
        (xy 147.322174 166.904686)
        (xy 147.463491 166.966132)
        (xy 147.663968 167.053302)
        (xy 148.022062 167.167585)
        (xy 148.025195 167.168245)
        (xy 148.025198 167.168246)
        (xy 148.386745 167.244435)
        (xy 148.386748 167.244435)
        (xy 148.389873 167.245094)
        (xy 148.763633 167.285038)
        (xy 148.76682 167.285055)
        (xy 148.766826 167.285055)
        (xy 148.937357 167.285948)
        (xy 149.139516 167.287006)
        (xy 149.240492 167.277283)
        (xy 149.51049 167.251286)
        (xy 149.510498 167.251285)
        (xy 149.513674 167.250979)
        (xy 149.882275 167.177325)
        (xy 149.885311 167.176391)
        (xy 149.885319 167.176389)
        (xy 150.238505 167.067734)
        (xy 150.238508 167.067733)
        (xy 150.241547 167.066798)
        (xy 150.244475 167.065561)
        (xy 150.244481 167.065559)
        (xy 150.400096 166.999824)
        (xy 150.58781 166.920531)
        (xy 150.590613 166.918996)
        (xy 150.590618 166.918994)
        (xy 150.732369 166.841388)
        (xy 150.917519 166.740021)
        (xy 151.227298 166.527115)
        (xy 151.229737 166.525047)
        (xy 151.229743 166.525042)
        (xy 151.511536 166.286065)
        (xy 151.511544 166.286057)
        (xy 151.513976 166.283995)
        (xy 151.516184 166.2817)
        (xy 151.516192 166.281693)
        (xy 151.772403 166.01545)
        (xy 151.772405 166.015447)
        (xy 151.774618 166.013148)
        (xy 151.829849 165.942709)
        (xy 152.00458 165.719866)
        (xy 152.004583 165.719861)
        (xy 152.006554 165.717348)
        (xy 152.207411 165.399624)
        (xy 152.375132 165.063229)
        (xy 152.507999 164.711606)
        (xy 152.604652 164.348357)
        (xy 152.629863 164.190963)
        (xy 152.663597 163.98035)
        (xy 152.664102 163.977199)
        (xy 152.664317 163.973484)
        (xy 152.675562 163.778442)
        (xy 152.685739 163.601934)
        (xy 152.68583 163.576)
        (xy 152.685745 163.574317)
        (xy 152.666974 163.203766)
        (xy 152.666973 163.203761)
        (xy 152.666813 163.200593)
        (xy 152.625014 162.927436)
        (xy 152.61044 162.83219)
        (xy 152.610438 162.832181)
        (xy 152.609956 162.82903)
        (xy 152.576705 162.700456)
        (xy 152.56633 162.660339)
        (xy 153.895091 162.660339)
        (xy 153.930747 162.893349)
        (xy 154.00398 163.117407)
        (xy 154.112825 163.326496)
        (xy 154.115928 163.330629)
        (xy 154.11593 163.330632)
        (xy 154.138026 163.360061)
        (xy 154.254358 163.515)
        (xy 154.424777 163.677857)
        (xy 154.619508 163.810693)
        (xy 154.624192 163.812867)
        (xy 154.624195 163.812869)
        (xy 154.828628 163.907764)
        (xy 154.828633 163.907766)
        (xy 154.833319 163.909941)
        (xy 155.060468 163.972935)
        (xy 155.065605 163.973484)
        (xy 155.249563 163.993144)
        (xy 155.249571 163.993144)
        (xy 155.252898 163.9935)
        (xy 156.587757 163.9935)
        (xy 156.59033 163.993288)
        (xy 156.590341 163.993288)
        (xy 156.757779 163.979522)
        (xy 156.757785 163.979521)
        (xy 156.76293 163.979098)
        (xy 156.991551 163.921673)
        (xy 157.207723 163.827678)
        (xy 157.405641 163.69964)
        (xy 157.429581 163.677857)
        (xy 157.576167 163.544473)
        (xy 157.576168 163.544471)
        (xy 157.579989 163.540995)
        (xy 157.583188 163.536944)
        (xy 157.583192 163.53694)
        (xy 157.722883 163.360061)
        (xy 157.722885 163.360057)
        (xy 157.726085 163.356006)
        (xy 157.840005 163.149639)
        (xy 157.849794 163.121998)
        (xy 157.916965 162.932311)
        (xy 157.916966 162.932307)
        (xy 157.918691 162.927436)
        (xy 157.922463 162.906263)
        (xy 157.959123 162.700456)
        (xy 157.959124 162.70045)
        (xy 157.960029 162.695367)
        (xy 157.960457 162.660339)
        (xy 166.395091 162.660339)
        (xy 166.430747 162.893349)
        (xy 166.50398 163.117407)
        (xy 166.612825 163.326496)
        (xy 166.615928 163.330629)
        (xy 166.61593 163.330632)
        (xy 166.638026 163.360061)
        (xy 166.754358 163.515)
        (xy 166.924777 163.677857)
        (xy 167.119508 163.810693)
        (xy 167.124192 163.812867)
        (xy 167.124195 163.812869)
        (xy 167.328628 163.907764)
        (xy 167.328633 163.907766)
        (xy 167.333319 163.909941)
        (xy 167.560468 163.972935)
        (xy 167.565605 163.973484)
        (xy 167.749563 163.993144)
        (xy 167.749571 163.993144)
        (xy 167.752898 163.9935)
        (xy 169.087757 163.9935)
        (xy 169.09033 163.993288)
        (xy 169.090341 163.993288)
        (xy 169.257779 163.979522)
        (xy 169.257785 163.979521)
        (xy 169.26293 163.979098)
        (xy 169.491551 163.921673)
        (xy 169.707723 163.827678)
        (xy 169.905641 163.69964)
        (xy 169.929581 163.677857)
        (xy 170.076167 163.544473)
        (xy 170.076168 163.544471)
        (xy 170.079989 163.540995)
        (xy 170.083188 163.536944)
        (xy 170.083192 163.53694)
        (xy 170.222883 163.360061)
        (xy 170.222885 163.360057)
        (xy 170.226085 163.356006)
        (xy 170.340005 163.149639)
        (xy 170.349794 163.121998)
        (xy 170.416965 162.932311)
        (xy 170.416966 162.932307)
        (xy 170.418691 162.927436)
        (xy 170.422463 162.906263)
        (xy 170.459123 162.700456)
        (xy 170.459124 162.70045)
        (xy 170.460029 162.695367)
        (xy 170.462805 162.468194)
        (xy 170.462846 162.46483)
        (xy 170.462846 162.464828)
        (xy 170.462909 162.459661)
        (xy 170.427253 162.226651)
        (xy 170.35402 162.002593)
        (xy 170.245175 161.793504)
        (xy 170.233456 161.777895)
        (xy 170.106747 161.609135)
        (xy 170.106745 161.609132)
        (xy 170.103642 161.605)
        (xy 170.030022 161.534647)
        (xy 169.93696 161.445714)
        (xy 169.936959 161.445713)
        (xy 169.933223 161.442143)
        (xy 169.738492 161.309307)
        (xy 169.733808 161.307133)
        (xy 169.733805 161.307131)
        (xy 169.529372 161.212236)
        (xy 169.529367 161.212234)
        (xy 169.524681 161.210059)
        (xy 169.297532 161.147065)
        (xy 169.290804 161.146346)
        (xy 169.108437 161.126856)
        (xy 169.108429 161.126856)
        (xy 169.105102 161.1265)
        (xy 167.770243 161.1265)
        (xy 167.76767 161.126712)
        (xy 167.767659 161.126712)
        (xy 167.600221 161.140478)
        (xy 167.600215 161.140479)
        (xy 167.59507 161.140902)
        (xy 167.366449 161.198327)
        (xy 167.150277 161.292322)
        (xy 166.952359 161.42036)
        (xy 166.948536 161.423839)
        (xy 166.948533 161.423841)
        (xy 166.910328 161.458605)
        (xy 166.778011 161.579005)
        (xy 166.774812 161.583056)
        (xy 166.774808 161.58306)
        (xy 166.635117 161.759939)
        (xy 166.631915 161.763994)
        (xy 166.517995 161.970361)
        (xy 166.516271 161.97523)
        (xy 166.516269 161.975234)
        (xy 166.468653 162.109698)
        (xy 166.439309 162.192564)
        (xy 166.438402 162.197657)
        (xy 166.438401 162.19766)
        (xy 166.419568 162.303391)
        (xy 166.397971 162.424633)
        (xy 157.962805 162.468194)
        (xy 157.962846 162.46483)
        (xy 157.962846 162.464828)
        (xy 157.962909 162.459661)
        (xy 157.927253 162.226651)
        (xy 157.85402 162.002593)
        (xy 157.745175 161.793504)
        (xy 157.733456 161.777895)
        (xy 157.606747 161.609135)
        (xy 157.606745 161.609132)
        (xy 157.603642 161.605)
        (xy 157.530022 161.534647)
        (xy 157.43696 161.445714)
        (xy 157.436959 161.445713)
        (xy 157.433223 161.442143)
        (xy 157.238492 161.309307)
        (xy 157.233808 161.307133)
        (xy 157.233805 161.307131)
        (xy 157.029372 161.212236)
        (xy 157.029367 161.212234)
        (xy 157.024681 161.210059)
        (xy 156.797532 161.147065)
        (xy 156.790804 161.146346)
        (xy 156.608437 161.126856)
        (xy 156.608429 161.126856)
        (xy 156.605102 161.1265)
        (xy 155.270243 161.1265)
        (xy 155.26767 161.126712)
        (xy 155.267659 161.126712)
        (xy 155.100221 161.140478)
        (xy 155.100215 161.140479)
        (xy 155.09507 161.140902)
        (xy 154.866449 161.198327)
        (xy 154.650277 161.292322)
        (xy 154.452359 161.42036)
        (xy 154.448536 161.423839)
        (xy 154.448533 161.423841)
        (xy 154.410328 161.458605)
        (xy 154.278011 161.579005)
        (xy 154.274812 161.583056)
        (xy 154.274808 161.58306)
        (xy 154.135117 161.759939)
        (xy 154.131915 161.763994)
        (xy 154.017995 161.970361)
        (xy 154.016271 161.97523)
        (xy 154.016269 161.975234)
        (xy 153.968653 162.109698)
        (xy 153.939309 162.192564)
        (xy 153.938402 162.197657)
        (xy 153.938401 162.19766)
        (xy 153.919568 162.303391)
        (xy 153.897971 162.424633)
        (xy 152.516638 162.468194)
        (xy 152.516635 162.468186)
        (xy 152.515841 162.465114)
        (xy 152.511932 162.454547)
        (xy 152.386541 162.11557)
        (xy 152.386538 162.115564)
        (xy 152.385432 162.112573)
        (xy 152.229122 161.793504)
        (xy 152.221475 161.777895)
        (xy 152.221474 161.777893)
        (xy 152.220064 161.775015)
        (xy 152.21602 161.768517)
        (xy 152.023116 161.458605)
        (xy 152.02143 161.455896)
        (xy 151.943615 161.355215)
        (xy 151.793516 161.161009)
        (xy 151.793511 161.161004)
        (xy 151.791564 161.158484)
        (xy 151.532819 160.885825)
        (xy 151.247846 160.640708)
        (xy 151.239448 160.634849)
        (xy 150.942173 160.427468)
        (xy 150.93956 160.425645)
        (xy 150.611119 160.242838)
        (xy 150.608199 160.24158)
        (xy 150.608194 160.241578)
        (xy 150.26882 160.09542)
        (xy 150.26881 160.095416)
        (xy 150.265886 160.094157)
        (xy 149.907395 159.981125)
        (xy 149.643121 159.926397)
        (xy 149.542441 159.905547)
        (xy 149.542438 159.905547)
        (xy 149.539316 159.9049)
        (xy 149.252755 159.875286)
        (xy 149.168575 159.866587)
        (xy 149.168572 159.866587)
        (xy 149.165419 159.866261)
        (xy 149.162253 159.866255)
        (xy 149.162244 159.866255)
        (xy 148.976771 159.865932)
        (xy 148.789531 159.865605)
        (xy 148.641122 159.880418)
        (xy 148.418675 159.902621)
        (xy 148.418669 159.902622)
        (xy 148.415502 159.902938)
        (xy 148.2243 159.941838)
        (xy 148.050284 159.977242)
        (xy 148.05028 159.977243)
        (xy 148.047159 159.977878)
        (xy 148.044117 159.978825)
        (xy 148.044111 159.978827)
        (xy 147.867718 160.033768)
        (xy 147.688276 160.089658)
        (xy 147.685336 160.090912)
        (xy 147.345463 160.23588)
        (xy 147.345459 160.235882)
        (xy 147.342526 160.237133)
        (xy 147.339739 160.238672)
        (xy 147.339738 160.238672)
        (xy 147.177987 160.327963)
        (xy 147.013449 160.418793)
        (xy 147.010828 160.420608)
        (xy 147.010823 160.420611)
        (xy 146.707038 160.630962)
        (xy 146.704414 160.632779)
        (xy 146.418587 160.876899)
        (xy 146.41639 160.879198)
        (xy 146.416389 160.879199)
        (xy 146.161097 161.146346)
        (xy 146.161092 161.146352)
        (xy 146.158892 161.148654)
        (xy 145.927989 161.445261)
        (xy 145.728243 161.763684)
        (xy 145.726829 161.766545)
        (xy 145.715549 161.789368)
        (xy 145.561698 162.100663)
        (xy 145.430059 162.452747)
        (xy 145.429251 162.455826)
        (xy 145.429249 162.455833)
        (xy 145.39202 162.597742)
        (xy 145.334674 162.816332)
        (xy 145.33418 162.819487)
        (xy 145.281771 163.154165)
        (xy 145.27652 163.187695)
        (xy 145.276349 163.190857)
        (xy 145.276348 163.190864)
        (xy 145.269003 163.326496)
        (xy 145.257018 163.547799)
        (xy 142.136167 163.544473)
        (xy 142.136168 163.544471)
        (xy 142.139989 163.540995)
        (xy 142.143188 163.536944)
        (xy 142.143192 163.53694)
        (xy 142.282883 163.360061)
        (xy 142.282885 163.360057)
        (xy 142.286085 163.356006)
        (xy 142.400005 163.149639)
        (xy 142.409794 163.121998)
        (xy 142.476965 162.932311)
        (xy 142.476966 162.932307)
        (xy 142.478691 162.927436)
        (xy 142.482463 162.906263)
        (xy 142.519123 162.700456)
        (xy 142.519124 162.70045)
        (xy 142.520029 162.695367)
        (xy 142.522805 162.468194)
        (xy 142.522846 162.46483)
        (xy 142.522846 162.464828)
        (xy 142.522909 162.459661)
        (xy 142.487253 162.226651)
        (xy 142.41402 162.002593)
        (xy 142.305175 161.793504)
        (xy 142.293456 161.777895)
        (xy 142.166747 161.609135)
        (xy 142.166745 161.609132)
        (xy 142.163642 161.605)
        (xy 142.090022 161.534647)
        (xy 141.99696 161.445714)
        (xy 141.996959 161.445713)
        (xy 141.993223 161.442143)
        (xy 141.798492 161.309307)
        (xy 141.793808 161.307133)
        (xy 141.793805 161.307131)
        (xy 141.589372 161.212236)
        (xy 141.589367 161.212234)
        (xy 141.584681 161.210059)
        (xy 141.357532 161.147065)
        (xy 141.350804 161.146346)
        (xy 141.168437 161.126856)
        (xy 141.168429 161.126856)
        (xy 141.165102 161.1265)
        (xy 139.830243 161.1265)
        (xy 139.82767 161.126712)
        (xy 139.827659 161.126712)
        (xy 139.660221 161.140478)
        (xy 139.660215 161.140479)
        (xy 139.65507 161.140902)
        (xy 139.426449 161.198327)
        (xy 139.210277 161.292322)
        (xy 139.012359 161.42036)
        (xy 139.008536 161.423839)
        (xy 139.008533 161.423841)
        (xy 138.970328 161.458605)
        (xy 138.838011 161.579005)
        (xy 138.834812 161.583056)
        (xy 138.834808 161.58306)
        (xy 138.695117 161.759939)
        (xy 138.691915 161.763994)
        (xy 138.577995 161.970361)
        (xy 138.576271 161.97523)
        (xy 138.576269 161.975234)
        (xy 138.528653 162.109698)
        (xy 138.499309 162.192564)
        (xy 138.498402 162.197657)
        (xy 138.498401 162.19766)
        (xy 138.479568 162.303391)
        (xy 138.457971 162.424633)
        (xy 130.022805 162.468194)
        (xy 130.022846 162.46483)
        (xy 130.022846 162.464828)
        (xy 130.022909 162.459661)
        (xy 129.987253 162.226651)
        (xy 129.91402 162.002593)
        (xy 129.805175 161.793504)
        (xy 129.793456 161.777895)
        (xy 129.666747 161.609135)
        (xy 129.666745 161.609132)
        (xy 129.663642 161.605)
        (xy 129.590022 161.534647)
        (xy 129.49696 161.445714)
        (xy 129.496959 161.445713)
        (xy 129.493223 161.442143)
        (xy 129.298492 161.309307)
        (xy 129.293808 161.307133)
        (xy 129.293805 161.307131)
        (xy 129.089372 161.212236)
        (xy 129.089367 161.212234)
        (xy 129.084681 161.210059)
        (xy 128.857532 161.147065)
        (xy 128.850804 161.146346)
        (xy 128.668437 161.126856)
        (xy 128.668429 161.126856)
        (xy 128.665102 161.1265)
        (xy 127.330243 161.1265)
        (xy 127.32767 161.126712)
        (xy 127.327659 161.126712)
        (xy 127.160221 161.140478)
        (xy 127.160215 161.140479)
        (xy 127.15507 161.140902)
        (xy 126.926449 161.198327)
        (xy 126.710277 161.292322)
        (xy 126.512359 161.42036)
        (xy 126.508536 161.423839)
        (xy 126.508533 161.423841)
        (xy 126.470328 161.458605)
        (xy 126.338011 161.579005)
        (xy 126.334812 161.583056)
        (xy 126.334808 161.58306)
        (xy 126.195117 161.759939)
        (xy 126.191915 161.763994)
        (xy 126.077995 161.970361)
        (xy 126.076271 161.97523)
        (xy 126.076269 161.975234)
        (xy 126.028653 162.109698)
        (xy 125.999309 162.192564)
        (xy 125.998402 162.197657)
        (xy 125.998401 162.19766)
        (xy 125.979568 162.303391)
        (xy 125.957971 162.424633)
        (xy 123.306638 162.468194)
        (xy 123.306635 162.468186)
        (xy 123.305841 162.465114)
        (xy 123.301932 162.454547)
        (xy 123.176541 162.11557)
        (xy 123.176538 162.115564)
        (xy 123.175432 162.112573)
        (xy 123.019122 161.793504)
        (xy 123.011475 161.777895)
        (xy 123.011474 161.777893)
        (xy 123.010064 161.775015)
        (xy 123.00602 161.768517)
        (xy 122.813116 161.458605)
        (xy 122.81143 161.455896)
        (xy 122.733615 161.355215)
        (xy 122.583516 161.161009)
        (xy 122.583511 161.161004)
        (xy 122.581564 161.158484)
        (xy 122.322819 160.885825)
        (xy 122.037846 160.640708)
        (xy 122.029448 160.634849)
        (xy 121.732173 160.427468)
        (xy 121.72956 160.425645)
        (xy 121.401119 160.242838)
        (xy 121.398199 160.24158)
        (xy 121.398194 160.241578)
        (xy 121.05882 160.09542)
        (xy 121.05881 160.095416)
        (xy 121.055886 160.094157)
        (xy 120.697395 159.981125)
        (xy 120.433121 159.926397)
        (xy 120.332441 159.905547)
        (xy 120.332438 159.905547)
        (xy 120.329316 159.9049)
        (xy 120.042755 159.875286)
        (xy 119.958575 159.866587)
        (xy 119.958572 159.866587)
        (xy 119.955419 159.866261)
        (xy 119.952253 159.866255)
        (xy 119.952244 159.866255)
        (xy 119.766771 159.865932)
        (xy 119.579531 159.865605)
        (xy 119.431122 159.880418)
        (xy 119.208675 159.902621)
        (xy 119.208669 159.902622)
        (xy 119.205502 159.902938)
        (xy 119.0143 159.941838)
        (xy 118.840284 159.977242)
        (xy 118.84028 159.977243)
        (xy 118.837159 159.977878)
        (xy 118.834117 159.978825)
        (xy 118.834111 159.978827)
        (xy 118.657718 160.033768)
        (xy 118.478276 160.089658)
        (xy 118.475336 160.090912)
        (xy 118.135463 160.23588)
        (xy 118.135459 160.235882)
        (xy 118.132526 160.237133)
        (xy 118.129739 160.238672)
        (xy 118.129738 160.238672)
        (xy 117.967987 160.327963)
        (xy 117.803449 160.418793)
        (xy 117.800828 160.420608)
        (xy 117.800823 160.420611)
        (xy 117.497038 160.630962)
        (xy 117.494414 160.632779)
        (xy 117.208587 160.876899)
        (xy 117.20639 160.879198)
        (xy 117.206389 160.879199)
        (xy 116.951097 161.146346)
        (xy 116.951092 161.146352)
        (xy 116.948892 161.148654)
        (xy 116.717989 161.445261)
        (xy 116.518243 161.763684)
        (xy 116.516829 161.766545)
        (xy 116.505549 161.789368)
        (xy 116.351698 162.100663)
        (xy 116.220059 162.452747)
        (xy 116.219251 162.455826)
        (xy 116.219249 162.455833)
        (xy 116.18202 162.597742)
        (xy 116.124674 162.816332)
        (xy 116.12418 162.819487)
        (xy 116.071771 163.154165)
        (xy 116.06652 163.187695)
        (xy 116.066349 163.190857)
        (xy 116.066348 163.190864)
        (xy 116.059003 163.326496)
        (xy 116.047018 163.547799)
        (xy 114.196167 163.544473)
        (xy 114.196168 163.544471)
        (xy 114.199989 163.540995)
        (xy 114.203188 163.536944)
        (xy 114.203192 163.53694)
        (xy 114.342883 163.360061)
        (xy 114.342885 163.360057)
        (xy 114.346085 163.356006)
        (xy 114.460005 163.149639)
        (xy 114.469794 163.121998)
        (xy 114.536965 162.932311)
        (xy 114.536966 162.932307)
        (xy 114.538691 162.927436)
        (xy 114.542463 162.906263)
        (xy 114.579123 162.700456)
        (xy 114.579124 162.70045)
        (xy 114.580029 162.695367)
        (xy 114.582805 162.468194)
        (xy 114.582846 162.46483)
        (xy 114.582846 162.464828)
        (xy 114.582909 162.459661)
        (xy 114.547253 162.226651)
        (xy 114.47402 162.002593)
        (xy 114.365175 161.793504)
        (xy 114.353456 161.777895)
        (xy 114.226747 161.609135)
        (xy 114.226745 161.609132)
        (xy 114.223642 161.605)
        (xy 114.150022 161.534647)
        (xy 114.05696 161.445714)
        (xy 114.056959 161.445713)
        (xy 114.053223 161.442143)
        (xy 113.858492 161.309307)
        (xy 113.853808 161.307133)
        (xy 113.853805 161.307131)
        (xy 113.649372 161.212236)
        (xy 113.649367 161.212234)
        (xy 113.644681 161.210059)
        (xy 113.417532 161.147065)
        (xy 113.410804 161.146346)
        (xy 113.228437 161.126856)
        (xy 113.228429 161.126856)
        (xy 113.225102 161.1265)
        (xy 111.890243 161.1265)
        (xy 111.88767 161.126712)
        (xy 111.887659 161.126712)
        (xy 111.720221 161.140478)
        (xy 111.720215 161.140479)
        (xy 111.71507 161.140902)
        (xy 111.486449 161.198327)
        (xy 111.270277 161.292322)
        (xy 111.072359 161.42036)
        (xy 111.068536 161.423839)
        (xy 111.068533 161.423841)
        (xy 111.030328 161.458605)
        (xy 110.898011 161.579005)
        (xy 110.894812 161.583056)
        (xy 110.894808 161.58306)
        (xy 110.755117 161.759939)
        (xy 110.751915 161.763994)
        (xy 110.637995 161.970361)
        (xy 110.636271 161.97523)
        (xy 110.636269 161.975234)
        (xy 110.588653 162.109698)
        (xy 110.559309 162.192564)
        (xy 110.558402 162.197657)
        (xy 110.558401 162.19766)
        (xy 110.539568 162.303391)
        (xy 110.517971 162.424633)
        (xy 102.082805 162.468194)
        (xy 102.082846 162.46483)
        (xy 102.082846 162.464828)
        (xy 102.082909 162.459661)
        (xy 102.047253 162.226651)
        (xy 101.97402 162.002593)
        (xy 101.865175 161.793504)
        (xy 101.853456 161.777895)
        (xy 101.726747 161.609135)
        (xy 101.726745 161.609132)
        (xy 101.723642 161.605)
        (xy 101.650022 161.534647)
        (xy 101.55696 161.445714)
        (xy 101.556959 161.445713)
        (xy 101.553223 161.442143)
        (xy 101.358492 161.309307)
        (xy 101.353808 161.307133)
        (xy 101.353805 161.307131)
        (xy 101.149372 161.212236)
        (xy 101.149367 161.212234)
        (xy 101.144681 161.210059)
        (xy 100.917532 161.147065)
        (xy 100.910804 161.146346)
        (xy 100.728437 161.126856)
        (xy 100.728429 161.126856)
        (xy 100.725102 161.1265)
        (xy 99.390243 161.1265)
        (xy 99.38767 161.126712)
        (xy 99.387659 161.126712)
        (xy 99.220221 161.140478)
        (xy 99.220215 161.140479)
        (xy 99.21507 161.140902)
        (xy 98.986449 161.198327)
        (xy 98.770277 161.292322)
        (xy 98.572359 161.42036)
        (xy 98.568536 161.423839)
        (xy 98.568533 161.423841)
        (xy 98.530328 161.458605)
        (xy 98.398011 161.579005)
        (xy 98.394812 161.583056)
        (xy 98.394808 161.58306)
        (xy 98.255117 161.759939)
        (xy 98.251915 161.763994)
        (xy 98.137995 161.970361)
        (xy 98.136271 161.97523)
        (xy 98.136269 161.975234)
        (xy 98.088653 162.109698)
        (xy 98.059309 162.192564)
        (xy 98.058402 162.197657)
        (xy 98.058401 162.19766)
        (xy 98.039568 162.303391)
        (xy 98.017971 162.424633)
        (xy 96.52 157.660339)
        (xy 98.015091 157.660339)
        (xy 98.050747 157.893349)
        (xy 98.12398 158.117407)
        (xy 98.232825 158.326496)
        (xy 98.235928 158.330629)
        (xy 98.23593 158.330632)
        (xy 98.258026 158.360061)
        (xy 98.374358 158.515)
        (xy 98.544777 158.677857)
        (xy 98.739508 158.810693)
        (xy 98.744192 158.812867)
        (xy 98.744195 158.812869)
        (xy 98.948628 158.907764)
        (xy 98.948633 158.907766)
        (xy 98.953319 158.909941)
        (xy 99.180468 158.972935)
        (xy 99.185605 158.973484)
        (xy 99.369563 158.993144)
        (xy 99.369571 158.993144)
        (xy 99.372898 158.9935)
        (xy 100.707757 158.9935)
        (xy 100.71033 158.993288)
        (xy 100.710341 158.993288)
        (xy 100.877779 158.979522)
        (xy 100.877785 158.979521)
        (xy 100.88293 158.979098)
        (xy 101.111551 158.921673)
        (xy 101.327723 158.827678)
        (xy 101.525641 158.69964)
        (xy 101.549581 158.677857)
        (xy 101.696167 158.544473)
        (xy 101.696168 158.544471)
        (xy 101.699989 158.540995)
        (xy 101.703188 158.536944)
        (xy 101.703192 158.53694)
        (xy 101.842883 158.360061)
        (xy 101.842885 158.360057)
        (xy 101.846085 158.356006)
        (xy 101.960005 158.149639)
        (xy 101.969794 158.121998)
        (xy 102.036965 157.932311)
        (xy 102.036966 157.932307)
        (xy 102.038691 157.927436)
        (xy 102.039599 157.92234)
        (xy 102.079123 157.700456)
        (xy 102.079124 157.70045)
        (xy 102.080029 157.695367)
        (xy 102.080457 157.660339)
        (xy 110.515091 157.660339)
        (xy 110.550747 157.893349)
        (xy 110.62398 158.117407)
        (xy 110.732825 158.326496)
        (xy 110.735928 158.330629)
        (xy 110.73593 158.330632)
        (xy 110.758026 158.360061)
        (xy 110.874358 158.515)
        (xy 111.044777 158.677857)
        (xy 111.239508 158.810693)
        (xy 111.244192 158.812867)
        (xy 111.244195 158.812869)
        (xy 111.448628 158.907764)
        (xy 111.448633 158.907766)
        (xy 111.453319 158.909941)
        (xy 111.680468 158.972935)
        (xy 111.685605 158.973484)
        (xy 111.869563 158.993144)
        (xy 111.869571 158.993144)
        (xy 111.872898 158.9935)
        (xy 113.207757 158.9935)
        (xy 113.21033 158.993288)
        (xy 113.210341 158.993288)
        (xy 113.377779 158.979522)
        (xy 113.377785 158.979521)
        (xy 113.38293 158.979098)
        (xy 113.611551 158.921673)
        (xy 113.827723 158.827678)
        (xy 114.025641 158.69964)
        (xy 114.049581 158.677857)
        (xy 114.196167 158.544473)
        (xy 114.196168 158.544471)
        (xy 114.199989 158.540995)
        (xy 114.203188 158.536944)
        (xy 114.203192 158.53694)
        (xy 114.342883 158.360061)
        (xy 114.342885 158.360057)
        (xy 114.346085 158.356006)
        (xy 114.460005 158.149639)
        (xy 114.469794 158.121998)
        (xy 114.536965 157.932311)
        (xy 114.536966 157.932307)
        (xy 114.538691 157.927436)
        (xy 114.539599 157.92234)
        (xy 114.579123 157.700456)
        (xy 114.579124 157.70045)
        (xy 114.580029 157.695367)
        (xy 114.580457 157.660339)
        (xy 125.955091 157.660339)
        (xy 125.990747 157.893349)
        (xy 126.06398 158.117407)
        (xy 126.172825 158.326496)
        (xy 126.175928 158.330629)
        (xy 126.17593 158.330632)
        (xy 126.198026 158.360061)
        (xy 126.314358 158.515)
        (xy 126.484777 158.677857)
        (xy 126.679508 158.810693)
        (xy 126.684192 158.812867)
        (xy 126.684195 158.812869)
        (xy 126.888628 158.907764)
        (xy 126.888633 158.907766)
        (xy 126.893319 158.909941)
        (xy 127.120468 158.972935)
        (xy 127.125605 158.973484)
        (xy 127.309563 158.993144)
        (xy 127.309571 158.993144)
        (xy 127.312898 158.9935)
        (xy 128.647757 158.9935)
        (xy 128.65033 158.993288)
        (xy 128.650341 158.993288)
        (xy 128.817779 158.979522)
        (xy 128.817785 158.979521)
        (xy 128.82293 158.979098)
        (xy 129.051551 158.921673)
        (xy 129.267723 158.827678)
        (xy 129.465641 158.69964)
        (xy 129.489581 158.677857)
        (xy 129.636167 158.544473)
        (xy 129.636168 158.544471)
        (xy 129.639989 158.540995)
        (xy 129.643188 158.536944)
        (xy 129.643192 158.53694)
        (xy 129.782883 158.360061)
        (xy 129.782885 158.360057)
        (xy 129.786085 158.356006)
        (xy 129.900005 158.149639)
        (xy 129.909794 158.121998)
        (xy 129.976965 157.932311)
        (xy 129.976966 157.932307)
        (xy 129.978691 157.927436)
        (xy 129.979599 157.92234)
        (xy 130.019123 157.700456)
        (xy 130.019124 157.70045)
        (xy 130.020029 157.695367)
        (xy 130.020457 157.660339)
        (xy 138.455091 157.660339)
        (xy 138.490747 157.893349)
        (xy 138.56398 158.117407)
        (xy 138.672825 158.326496)
        (xy 138.675928 158.330629)
        (xy 138.67593 158.330632)
        (xy 138.698026 158.360061)
        (xy 138.814358 158.515)
        (xy 138.984777 158.677857)
        (xy 139.179508 158.810693)
        (xy 139.184192 158.812867)
        (xy 139.184195 158.812869)
        (xy 139.388628 158.907764)
        (xy 139.388633 158.907766)
        (xy 139.393319 158.909941)
        (xy 139.620468 158.972935)
        (xy 139.625605 158.973484)
        (xy 139.809563 158.993144)
        (xy 139.809571 158.993144)
        (xy 139.812898 158.9935)
        (xy 141.147757 158.9935)
        (xy 141.15033 158.993288)
        (xy 141.150341 158.993288)
        (xy 141.317779 158.979522)
        (xy 141.317785 158.979521)
        (xy 141.32293 158.979098)
        (xy 141.551551 158.921673)
        (xy 141.767723 158.827678)
        (xy 141.965641 158.69964)
        (xy 141.989581 158.677857)
        (xy 142.136167 158.544473)
        (xy 142.136168 158.544471)
        (xy 142.139989 158.540995)
        (xy 142.143188 158.536944)
        (xy 142.143192 158.53694)
        (xy 142.282883 158.360061)
        (xy 142.282885 158.360057)
        (xy 142.286085 158.356006)
        (xy 142.400005 158.149639)
        (xy 142.409794 158.121998)
        (xy 142.476965 157.932311)
        (xy 142.476966 157.932307)
        (xy 142.478691 157.927436)
        (xy 142.479599 157.92234)
        (xy 142.519123 157.700456)
        (xy 142.519124 157.70045)
        (xy 142.520029 157.695367)
        (xy 142.520457 157.660339)
        (xy 153.895091 157.660339)
        (xy 153.930747 157.893349)
        (xy 154.00398 158.117407)
        (xy 154.112825 158.326496)
        (xy 154.115928 158.330629)
        (xy 154.11593 158.330632)
        (xy 154.138026 158.360061)
        (xy 154.254358 158.515)
        (xy 154.424777 158.677857)
        (xy 154.619508 158.810693)
        (xy 154.624192 158.812867)
        (xy 154.624195 158.812869)
        (xy 154.828628 158.907764)
        (xy 154.828633 158.907766)
        (xy 154.833319 158.909941)
        (xy 155.060468 158.972935)
        (xy 155.065605 158.973484)
        (xy 155.249563 158.993144)
        (xy 155.249571 158.993144)
        (xy 155.252898 158.9935)
        (xy 156.587757 158.9935)
        (xy 156.59033 158.993288)
        (xy 156.590341 158.993288)
        (xy 156.757779 158.979522)
        (xy 156.757785 158.979521)
        (xy 156.76293 158.979098)
        (xy 156.991551 158.921673)
        (xy 157.207723 158.827678)
        (xy 157.405641 158.69964)
        (xy 157.429581 158.677857)
        (xy 157.576167 158.544473)
        (xy 157.576168 158.544471)
        (xy 157.579989 158.540995)
        (xy 157.583188 158.536944)
        (xy 157.583192 158.53694)
        (xy 157.722883 158.360061)
        (xy 157.722885 158.360057)
        (xy 157.726085 158.356006)
        (xy 157.840005 158.149639)
        (xy 157.849794 158.121998)
        (xy 157.916965 157.932311)
        (xy 157.916966 157.932307)
        (xy 157.918691 157.927436)
        (xy 157.919599 157.92234)
        (xy 157.959123 157.700456)
        (xy 157.959124 157.70045)
        (xy 157.960029 157.695367)
        (xy 157.960457 157.660339)
        (xy 166.395091 157.660339)
        (xy 166.430747 157.893349)
        (xy 166.50398 158.117407)
        (xy 166.612825 158.326496)
        (xy 166.615928 158.330629)
        (xy 166.61593 158.330632)
        (xy 166.638026 158.360061)
        (xy 166.754358 158.515)
        (xy 166.924777 158.677857)
        (xy 167.119508 158.810693)
        (xy 167.124192 158.812867)
        (xy 167.124195 158.812869)
        (xy 167.328628 158.907764)
        (xy 167.328633 158.907766)
        (xy 167.333319 158.909941)
        (xy 167.560468 158.972935)
        (xy 167.565605 158.973484)
        (xy 167.749563 158.993144)
        (xy 167.749571 158.993144)
        (xy 167.752898 158.9935)
        (xy 169.087757 158.9935)
        (xy 169.09033 158.993288)
        (xy 169.090341 158.993288)
        (xy 169.257779 158.979522)
        (xy 169.257785 158.979521)
        (xy 169.26293 158.979098)
        (xy 169.491551 158.921673)
        (xy 169.707723 158.827678)
        (xy 169.905641 158.69964)
        (xy 169.929581 158.677857)
        (xy 170.076167 158.544473)
        (xy 170.076168 158.544471)
        (xy 170.079989 158.540995)
        (xy 170.083188 158.536944)
        (xy 170.083192 158.53694)
        (xy 170.222883 158.360061)
        (xy 170.222885 158.360057)
        (xy 170.226085 158.356006)
        (xy 170.340005 158.149639)
        (xy 170.349794 158.121998)
        (xy 170.416965 157.932311)
        (xy 170.416966 157.932307)
        (xy 170.418691 157.927436)
        (xy 170.419599 157.92234)
        (xy 170.459123 157.700456)
        (xy 170.459124 157.70045)
        (xy 170.460029 157.695367)
        (xy 170.462909 157.459661)
        (xy 170.427253 157.226651)
        (xy 170.35402 157.002593)
        (xy 170.245175 156.793504)
        (xy 170.226415 156.768517)
        (xy 170.106747 156.609135)
        (xy 170.106745 156.609132)
        (xy 170.103642 156.605)
        (xy 169.933223 156.442143)
        (xy 169.738492 156.309307)
        (xy 169.733808 156.307133)
        (xy 169.733805 156.307131)
        (xy 169.529372 156.212236)
        (xy 169.529367 156.212234)
        (xy 169.524681 156.210059)
        (xy 169.297532 156.147065)
        (xy 169.292395 156.146516)
        (xy 169.108437 156.126856)
        (xy 169.108429 156.126856)
        (xy 169.105102 156.1265)
        (xy 167.770243 156.1265)
        (xy 167.76767 156.126712)
        (xy 167.767659 156.126712)
        (xy 167.600221 156.140478)
        (xy 167.600215 156.140479)
        (xy 167.59507 156.140902)
        (xy 167.366449 156.198327)
        (xy 167.150277 156.292322)
        (xy 166.952359 156.42036)
        (xy 166.948536 156.423839)
        (xy 166.948533 156.423841)
        (xy 166.924495 156.445714)
        (xy 166.778011 156.579005)
        (xy 166.774812 156.583056)
        (xy 166.774808 156.58306)
        (xy 166.635117 156.759939)
        (xy 166.631915 156.763994)
        (xy 166.517995 156.970361)
        (xy 166.516271 156.97523)
        (xy 166.516269 156.975234)
        (xy 166.441035 157.187689)
        (xy 166.439309 157.192564)
        (xy 166.438402 157.197657)
        (xy 166.438401 157.19766)
        (xy 166.434113 157.221736)
        (xy 166.397971 157.424633)
        (xy 157.962909 157.459661)
        (xy 157.927253 157.226651)
        (xy 157.85402 157.002593)
        (xy 157.745175 156.793504)
        (xy 157.726415 156.768517)
        (xy 157.606747 156.609135)
        (xy 157.606745 156.609132)
        (xy 157.603642 156.605)
        (xy 157.433223 156.442143)
        (xy 157.238492 156.309307)
        (xy 157.233808 156.307133)
        (xy 157.233805 156.307131)
        (xy 157.029372 156.212236)
        (xy 157.029367 156.212234)
        (xy 157.024681 156.210059)
        (xy 156.797532 156.147065)
        (xy 156.792395 156.146516)
        (xy 156.608437 156.126856)
        (xy 156.608429 156.126856)
        (xy 156.605102 156.1265)
        (xy 155.270243 156.1265)
        (xy 155.26767 156.126712)
        (xy 155.267659 156.126712)
        (xy 155.100221 156.140478)
        (xy 155.100215 156.140479)
        (xy 155.09507 156.140902)
        (xy 154.866449 156.198327)
        (xy 154.650277 156.292322)
        (xy 154.452359 156.42036)
        (xy 154.448536 156.423839)
        (xy 154.448533 156.423841)
        (xy 154.424495 156.445714)
        (xy 154.278011 156.579005)
        (xy 154.274812 156.583056)
        (xy 154.274808 156.58306)
        (xy 154.135117 156.759939)
        (xy 154.131915 156.763994)
        (xy 154.017995 156.970361)
        (xy 154.016271 156.97523)
        (xy 154.016269 156.975234)
        (xy 153.941035 157.187689)
        (xy 153.939309 157.192564)
        (xy 153.938402 157.197657)
        (xy 153.938401 157.19766)
        (xy 153.934113 157.221736)
        (xy 153.897971 157.424633)
        (xy 142.522909 157.459661)
        (xy 142.487253 157.226651)
        (xy 142.41402 157.002593)
        (xy 142.305175 156.793504)
        (xy 142.286415 156.768517)
        (xy 142.166747 156.609135)
        (xy 142.166745 156.609132)
        (xy 142.163642 156.605)
        (xy 141.993223 156.442143)
        (xy 141.798492 156.309307)
        (xy 141.793808 156.307133)
        (xy 141.793805 156.307131)
        (xy 141.589372 156.212236)
        (xy 141.589367 156.212234)
        (xy 141.584681 156.210059)
        (xy 141.357532 156.147065)
        (xy 141.352395 156.146516)
        (xy 141.168437 156.126856)
        (xy 141.168429 156.126856)
        (xy 141.165102 156.1265)
        (xy 139.830243 156.1265)
        (xy 139.82767 156.126712)
        (xy 139.827659 156.126712)
        (xy 139.660221 156.140478)
        (xy 139.660215 156.140479)
        (xy 139.65507 156.140902)
        (xy 139.426449 156.198327)
        (xy 139.210277 156.292322)
        (xy 139.012359 156.42036)
        (xy 139.008536 156.423839)
        (xy 139.008533 156.423841)
        (xy 138.984495 156.445714)
        (xy 138.838011 156.579005)
        (xy 138.834812 156.583056)
        (xy 138.834808 156.58306)
        (xy 138.695117 156.759939)
        (xy 138.691915 156.763994)
        (xy 138.577995 156.970361)
        (xy 138.576271 156.97523)
        (xy 138.576269 156.975234)
        (xy 138.501035 157.187689)
        (xy 138.499309 157.192564)
        (xy 138.498402 157.197657)
        (xy 138.498401 157.19766)
        (xy 138.494113 157.221736)
        (xy 138.457971 157.424633)
        (xy 130.022909 157.459661)
        (xy 129.987253 157.226651)
        (xy 129.91402 157.002593)
        (xy 129.805175 156.793504)
        (xy 129.786415 156.768517)
        (xy 129.666747 156.609135)
        (xy 129.666745 156.609132)
        (xy 129.663642 156.605)
        (xy 129.493223 156.442143)
        (xy 129.298492 156.309307)
        (xy 129.293808 156.307133)
        (xy 129.293805 156.307131)
        (xy 129.089372 156.212236)
        (xy 129.089367 156.212234)
        (xy 129.084681 156.210059)
        (xy 128.857532 156.147065)
        (xy 128.852395 156.146516)
        (xy 128.668437 156.126856)
        (xy 128.668429 156.126856)
        (xy 128.665102 156.1265)
        (xy 127.330243 156.1265)
        (xy 127.32767 156.126712)
        (xy 127.327659 156.126712)
        (xy 127.160221 156.140478)
        (xy 127.160215 156.140479)
        (xy 127.15507 156.140902)
        (xy 126.926449 156.198327)
        (xy 126.710277 156.292322)
        (xy 126.512359 156.42036)
        (xy 126.508536 156.423839)
        (xy 126.508533 156.423841)
        (xy 126.484495 156.445714)
        (xy 126.338011 156.579005)
        (xy 126.334812 156.583056)
        (xy 126.334808 156.58306)
        (xy 126.195117 156.759939)
        (xy 126.191915 156.763994)
        (xy 126.077995 156.970361)
        (xy 126.076271 156.97523)
        (xy 126.076269 156.975234)
        (xy 126.001035 157.187689)
        (xy 125.999309 157.192564)
        (xy 125.998402 157.197657)
        (xy 125.998401 157.19766)
        (xy 125.994113 157.221736)
        (xy 125.957971 157.424633)
        (xy 114.582909 157.459661)
        (xy 114.547253 157.226651)
        (xy 114.47402 157.002593)
        (xy 114.365175 156.793504)
        (xy 114.346415 156.768517)
        (xy 114.226747 156.609135)
        (xy 114.226745 156.609132)
        (xy 114.223642 156.605)
        (xy 114.053223 156.442143)
        (xy 113.858492 156.309307)
        (xy 113.853808 156.307133)
        (xy 113.853805 156.307131)
        (xy 113.649372 156.212236)
        (xy 113.649367 156.212234)
        (xy 113.644681 156.210059)
        (xy 113.417532 156.147065)
        (xy 113.412395 156.146516)
        (xy 113.228437 156.126856)
        (xy 113.228429 156.126856)
        (xy 113.225102 156.1265)
        (xy 111.890243 156.1265)
        (xy 111.88767 156.126712)
        (xy 111.887659 156.126712)
        (xy 111.720221 156.140478)
        (xy 111.720215 156.140479)
        (xy 111.71507 156.140902)
        (xy 111.486449 156.198327)
        (xy 111.270277 156.292322)
        (xy 111.072359 156.42036)
        (xy 111.068536 156.423839)
        (xy 111.068533 156.423841)
        (xy 111.044495 156.445714)
        (xy 110.898011 156.579005)
        (xy 110.894812 156.583056)
        (xy 110.894808 156.58306)
        (xy 110.755117 156.759939)
        (xy 110.751915 156.763994)
        (xy 110.637995 156.970361)
        (xy 110.636271 156.97523)
        (xy 110.636269 156.975234)
        (xy 110.561035 157.187689)
        (xy 110.559309 157.192564)
        (xy 110.558402 157.197657)
        (xy 110.558401 157.19766)
        (xy 110.554113 157.221736)
        (xy 110.517971 157.424633)
        (xy 102.082909 157.459661)
        (xy 102.047253 157.226651)
        (xy 101.97402 157.002593)
        (xy 101.865175 156.793504)
        (xy 101.846415 156.768517)
        (xy 101.726747 156.609135)
        (xy 101.726745 156.609132)
        (xy 101.723642 156.605)
        (xy 101.553223 156.442143)
        (xy 101.358492 156.309307)
        (xy 101.353808 156.307133)
        (xy 101.353805 156.307131)
        (xy 101.149372 156.212236)
        (xy 101.149367 156.212234)
        (xy 101.144681 156.210059)
        (xy 100.917532 156.147065)
        (xy 100.912395 156.146516)
        (xy 100.728437 156.126856)
        (xy 100.728429 156.126856)
        (xy 100.725102 156.1265)
        (xy 99.390243 156.1265)
        (xy 99.38767 156.126712)
        (xy 99.387659 156.126712)
        (xy 99.220221 156.140478)
        (xy 99.220215 156.140479)
        (xy 99.21507 156.140902)
        (xy 98.986449 156.198327)
        (xy 98.770277 156.292322)
        (xy 98.572359 156.42036)
        (xy 98.568536 156.423839)
        (xy 98.568533 156.423841)
        (xy 98.544495 156.445714)
        (xy 98.398011 156.579005)
        (xy 98.394812 156.583056)
        (xy 98.394808 156.58306)
        (xy 98.255117 156.759939)
        (xy 98.251915 156.763994)
        (xy 98.137995 156.970361)
        (xy 98.136271 156.97523)
        (xy 98.136269 156.975234)
        (xy 98.061035 157.187689)
        (xy 98.059309 157.192564)
        (xy 98.058402 157.197657)
        (xy 98.058401 157.19766)
        (xy 98.054113 157.221736)
        (xy 98.017971 157.424633)
        (xy 96.52 148.690339)
        (xy 98.015091 148.690339)
        (xy 98.050747 148.923349)
        (xy 98.12398 149.147407)
        (xy 98.232825 149.356496)
        (xy 98.235928 149.360629)
        (xy 98.23593 149.360632)
        (xy 98.331894 149.488444)
        (xy 98.374358 149.545)
        (xy 98.378096 149.548572)
        (xy 98.505238 149.670072)
        (xy 98.544777 149.707857)
        (xy 98.739508 149.840693)
        (xy 98.744192 149.842867)
        (xy 98.744195 149.842869)
        (xy 98.948628 149.937764)
        (xy 98.948633 149.937766)
        (xy 98.953319 149.939941)
        (xy 99.180468 150.002935)
        (xy 99.185605 150.003484)
        (xy 99.369563 150.023144)
        (xy 99.369571 150.023144)
        (xy 99.372898 150.0235)
        (xy 100.707757 150.0235)
        (xy 100.71033 150.023288)
        (xy 100.710341 150.023288)
        (xy 100.877779 150.009522)
        (xy 100.877785 150.009521)
        (xy 100.88293 150.009098)
        (xy 101.111551 149.951673)
        (xy 101.327723 149.857678)
        (xy 101.525641 149.72964)
        (xy 101.549581 149.707857)
        (xy 101.696167 149.574473)
        (xy 101.696168 149.574471)
        (xy 101.699989 149.570995)
        (xy 101.703188 149.566944)
        (xy 101.703192 149.56694)
        (xy 101.842883 149.390061)
        (xy 101.842885 149.390057)
        (xy 101.846085 149.386006)
        (xy 101.960005 149.179639)
        (xy 101.969794 149.151998)
        (xy 102.036965 148.962311)
        (xy 102.036966 148.962307)
        (xy 102.038691 148.957436)
        (xy 102.039599 148.95234)
        (xy 102.079123 148.730456)
        (xy 102.079124 148.73045)
        (xy 102.080029 148.725367)
        (xy 102.080457 148.690339)
        (xy 110.515091 148.690339)
        (xy 110.550747 148.923349)
        (xy 110.62398 149.147407)
        (xy 110.732825 149.356496)
        (xy 110.735928 149.360629)
        (xy 110.73593 149.360632)
        (xy 110.831894 149.488444)
        (xy 110.874358 149.545)
        (xy 110.878096 149.548572)
        (xy 111.005238 149.670072)
        (xy 111.044777 149.707857)
        (xy 111.239508 149.840693)
        (xy 111.244192 149.842867)
        (xy 111.244195 149.842869)
        (xy 111.448628 149.937764)
        (xy 111.448633 149.937766)
        (xy 111.453319 149.939941)
        (xy 111.680468 150.002935)
        (xy 111.685605 150.003484)
        (xy 111.869563 150.023144)
        (xy 111.869571 150.023144)
        (xy 111.872898 150.0235)
        (xy 113.207757 150.0235)
        (xy 113.21033 150.023288)
        (xy 113.210341 150.023288)
        (xy 113.377779 150.009522)
        (xy 113.377785 150.009521)
        (xy 113.38293 150.009098)
        (xy 113.611551 149.951673)
        (xy 113.827723 149.857678)
        (xy 114.025641 149.72964)
        (xy 114.049581 149.707857)
        (xy 114.196167 149.574473)
        (xy 114.196168 149.574471)
        (xy 114.199989 149.570995)
        (xy 114.203188 149.566944)
        (xy 114.203192 149.56694)
        (xy 114.342883 149.390061)
        (xy 114.342885 149.390057)
        (xy 114.346085 149.386006)
        (xy 114.460005 149.179639)
        (xy 114.469794 149.151998)
        (xy 114.536965 148.962311)
        (xy 114.536966 148.962307)
        (xy 114.538691 148.957436)
        (xy 114.539599 148.95234)
        (xy 114.579123 148.730456)
        (xy 114.579124 148.73045)
        (xy 114.580029 148.725367)
        (xy 114.580457 148.690339)
        (xy 115.795091 148.690339)
        (xy 115.830747 148.923349)
        (xy 115.90398 149.147407)
        (xy 116.012825 149.356496)
        (xy 116.015928 149.360629)
        (xy 116.01593 149.360632)
        (xy 116.111894 149.488444)
        (xy 116.154358 149.545)
        (xy 116.158096 149.548572)
        (xy 116.285238 149.670072)
        (xy 116.324777 149.707857)
        (xy 116.519508 149.840693)
        (xy 116.524192 149.842867)
        (xy 116.524195 149.842869)
        (xy 116.728628 149.937764)
        (xy 116.728633 149.937766)
        (xy 116.733319 149.939941)
        (xy 116.960468 150.002935)
        (xy 116.965605 150.003484)
        (xy 117.149563 150.023144)
        (xy 117.149571 150.023144)
        (xy 117.152898 150.0235)
        (xy 118.487757 150.0235)
        (xy 118.49033 150.023288)
        (xy 118.490341 150.023288)
        (xy 118.657779 150.009522)
        (xy 118.657785 150.009521)
        (xy 118.66293 150.009098)
        (xy 118.891551 149.951673)
        (xy 119.107723 149.857678)
        (xy 119.305641 149.72964)
        (xy 119.329581 149.707857)
        (xy 119.476167 149.574473)
        (xy 119.476168 149.574471)
        (xy 119.479989 149.570995)
        (xy 119.483188 149.566944)
        (xy 119.483192 149.56694)
        (xy 119.622883 149.390061)
        (xy 119.622885 149.390057)
        (xy 119.626085 149.386006)
        (xy 119.740005 149.179639)
        (xy 119.749794 149.151998)
        (xy 119.816965 148.962311)
        (xy 119.816966 148.962307)
        (xy 119.818691 148.957436)
        (xy 119.819599 148.95234)
        (xy 119.859123 148.730456)
        (xy 119.859124 148.73045)
        (xy 119.860029 148.725367)
        (xy 119.860457 148.690339)
        (xy 128.295091 148.690339)
        (xy 128.330747 148.923349)
        (xy 128.40398 149.147407)
        (xy 128.512825 149.356496)
        (xy 128.515928 149.360629)
        (xy 128.51593 149.360632)
        (xy 128.611894 149.488444)
        (xy 128.654358 149.545)
        (xy 128.658096 149.548572)
        (xy 128.785238 149.670072)
        (xy 128.824777 149.707857)
        (xy 129.019508 149.840693)
        (xy 129.024192 149.842867)
        (xy 129.024195 149.842869)
        (xy 129.228628 149.937764)
        (xy 129.228633 149.937766)
        (xy 129.233319 149.939941)
        (xy 129.460468 150.002935)
        (xy 129.465605 150.003484)
        (xy 129.649563 150.023144)
        (xy 129.649571 150.023144)
        (xy 129.652898 150.0235)
        (xy 130.987757 150.0235)
        (xy 130.99033 150.023288)
        (xy 130.990341 150.023288)
        (xy 131.157779 150.009522)
        (xy 131.157785 150.009521)
        (xy 131.16293 150.009098)
        (xy 131.391551 149.951673)
        (xy 131.607723 149.857678)
        (xy 131.805641 149.72964)
        (xy 131.829581 149.707857)
        (xy 131.976167 149.574473)
        (xy 131.976168 149.574471)
        (xy 131.979989 149.570995)
        (xy 131.983188 149.566944)
        (xy 131.983192 149.56694)
        (xy 132.122883 149.390061)
        (xy 132.122885 149.390057)
        (xy 132.126085 149.386006)
        (xy 132.240005 149.179639)
        (xy 132.249794 149.151998)
        (xy 132.316965 148.962311)
        (xy 132.316966 148.962307)
        (xy 132.318691 148.957436)
        (xy 132.319599 148.95234)
        (xy 132.359123 148.730456)
        (xy 132.359124 148.73045)
        (xy 132.360029 148.725367)
        (xy 132.360457 148.690339)
        (xy 136.115091 148.690339)
        (xy 136.150747 148.923349)
        (xy 136.22398 149.147407)
        (xy 136.332825 149.356496)
        (xy 136.335928 149.360629)
        (xy 136.33593 149.360632)
        (xy 136.431894 149.488444)
        (xy 136.474358 149.545)
        (xy 136.478096 149.548572)
        (xy 136.605238 149.670072)
        (xy 136.644777 149.707857)
        (xy 136.839508 149.840693)
        (xy 136.844192 149.842867)
        (xy 136.844195 149.842869)
        (xy 137.048628 149.937764)
        (xy 137.048633 149.937766)
        (xy 137.053319 149.939941)
        (xy 137.280468 150.002935)
        (xy 137.285605 150.003484)
        (xy 137.469563 150.023144)
        (xy 137.469571 150.023144)
        (xy 137.472898 150.0235)
        (xy 138.807757 150.0235)
        (xy 138.81033 150.023288)
        (xy 138.810341 150.023288)
        (xy 138.977779 150.009522)
        (xy 138.977785 150.009521)
        (xy 138.98293 150.009098)
        (xy 139.211551 149.951673)
        (xy 139.427723 149.857678)
        (xy 139.625641 149.72964)
        (xy 139.649581 149.707857)
        (xy 139.796167 149.574473)
        (xy 139.796168 149.574471)
        (xy 139.799989 149.570995)
        (xy 139.803188 149.566944)
        (xy 139.803192 149.56694)
        (xy 139.942883 149.390061)
        (xy 139.942885 149.390057)
        (xy 139.946085 149.386006)
        (xy 140.060005 149.179639)
        (xy 140.069794 149.151998)
        (xy 140.136965 148.962311)
        (xy 140.136966 148.962307)
        (xy 140.138691 148.957436)
        (xy 140.139599 148.95234)
        (xy 140.179123 148.730456)
        (xy 140.179124 148.73045)
        (xy 140.180029 148.725367)
        (xy 140.180457 148.690339)
        (xy 148.615091 148.690339)
        (xy 148.650747 148.923349)
        (xy 148.72398 149.147407)
        (xy 148.832825 149.356496)
        (xy 148.835928 149.360629)
        (xy 148.83593 149.360632)
        (xy 148.931894 149.488444)
        (xy 148.974358 149.545)
        (xy 148.978096 149.548572)
        (xy 149.105238 149.670072)
        (xy 149.144777 149.707857)
        (xy 149.339508 149.840693)
        (xy 149.344192 149.842867)
        (xy 149.344195 149.842869)
        (xy 149.548628 149.937764)
        (xy 149.548633 149.937766)
        (xy 149.553319 149.939941)
        (xy 149.780468 150.002935)
        (xy 149.785605 150.003484)
        (xy 149.969563 150.023144)
        (xy 149.969571 150.023144)
        (xy 149.972898 150.0235)
        (xy 151.307757 150.0235)
        (xy 151.31033 150.023288)
        (xy 151.310341 150.023288)
        (xy 151.477779 150.009522)
        (xy 151.477785 150.009521)
        (xy 151.48293 150.009098)
        (xy 151.588415 149.982602)
        (xy 151.613096 149.976403)
        (xy 151.684037 149.979207)
        (xy 151.7422 150.01992)
        (xy 151.763623 150.05967)
        (xy 151.819473 150.231556)
        (xy 151.91496 150.396944)
        (xy 152.042747 150.538866)
        (xy 152.197248 150.651118)
        (xy 152.203276 150.653802)
        (xy 152.203278 150.653803)
        (xy 152.365681 150.726109)
        (xy 152.371712 150.728794)
        (xy 152.465112 150.748647)
        (xy 152.552056 150.767128)
        (xy 152.552061 150.767128)
        (xy 152.558513 150.7685)
        (xy 152.749487 150.7685)
        (xy 152.755939 150.767128)
        (xy 152.755944 150.767128)
        (xy 152.842888 150.748647)
        (xy 152.936288 150.728794)
        (xy 152.942319 150.726109)
        (xy 153.104722 150.653803)
        (xy 153.104724 150.653802)
        (xy 153.110752 150.651118)
        (xy 153.265253 150.538866)
        (xy 153.39304 150.396944)
        (xy 153.488527 150.231556)
        (xy 153.547542 150.049928)
        (xy 153.551834 150.009098)
        (xy 153.566814 149.866565)
        (xy 153.567504 149.86)
        (xy 153.553437 149.726159)
        (xy 153.548232 149.676635)
        (xy 153.548232 149.676633)
        (xy 153.547542 149.670072)
        (xy 153.488527 149.488444)
        (xy 153.444681 149.4125)
        (xy 153.427943 149.343504)
        (xy 153.451164 149.276413)
        (xy 153.506971 149.232526)
        (xy 153.5538 149.2235)
        (xy 153.967134 149.2235)
        (xy 154.035255 149.243502)
        (xy 154.078895 149.291317)
        (xy 154.112825 149.356496)
        (xy 154.115928 149.360629)
        (xy 154.11593 149.360632)
        (xy 154.211894 149.488444)
        (xy 154.254358 149.545)
        (xy 154.258096 149.548572)
        (xy 154.385238 149.670072)
        (xy 154.424777 149.707857)
        (xy 154.619508 149.840693)
        (xy 154.624192 149.842867)
        (xy 154.624195 149.842869)
        (xy 154.828628 149.937764)
        (xy 154.828633 149.937766)
        (xy 154.833319 149.939941)
        (xy 155.060468 150.002935)
        (xy 155.065605 150.003484)
        (xy 155.249563 150.023144)
        (xy 155.249571 150.023144)
        (xy 155.252898 150.0235)
        (xy 156.587757 150.0235)
        (xy 156.59033 150.023288)
        (xy 156.590341 150.023288)
        (xy 156.757779 150.009522)
        (xy 156.757785 150.009521)
        (xy 156.76293 150.009098)
        (xy 156.991551 149.951673)
        (xy 157.207723 149.857678)
        (xy 157.405641 149.72964)
        (xy 157.429581 149.707857)
        (xy 157.576167 149.574473)
        (xy 157.576168 149.574471)
        (xy 157.579989 149.570995)
        (xy 157.583188 149.566944)
        (xy 157.583192 149.56694)
        (xy 157.722883 149.390061)
        (xy 157.722885 149.390057)
        (xy 157.726085 149.386006)
        (xy 157.840005 149.179639)
        (xy 157.849794 149.151998)
        (xy 157.916965 148.962311)
        (xy 157.916966 148.962307)
        (xy 157.918691 148.957436)
        (xy 157.919599 148.95234)
        (xy 157.959123 148.730456)
        (xy 157.959124 148.73045)
        (xy 157.960029 148.725367)
        (xy 157.960457 148.690339)
        (xy 166.395091 148.690339)
        (xy 166.430747 148.923349)
        (xy 166.50398 149.147407)
        (xy 166.612825 149.356496)
        (xy 166.615928 149.360629)
        (xy 166.61593 149.360632)
        (xy 166.711894 149.488444)
        (xy 166.754358 149.545)
        (xy 166.758096 149.548572)
        (xy 166.885238 149.670072)
        (xy 166.924777 149.707857)
        (xy 167.119508 149.840693)
        (xy 167.124192 149.842867)
        (xy 167.124195 149.842869)
        (xy 167.328628 149.937764)
        (xy 167.328633 149.937766)
        (xy 167.333319 149.939941)
        (xy 167.560468 150.002935)
        (xy 167.565605 150.003484)
        (xy 167.749563 150.023144)
        (xy 167.749571 150.023144)
        (xy 167.752898 150.0235)
        (xy 169.087757 150.0235)
        (xy 169.09033 150.023288)
        (xy 169.090341 150.023288)
        (xy 169.257779 150.009522)
        (xy 169.257785 150.009521)
        (xy 169.26293 150.009098)
        (xy 169.491551 149.951673)
        (xy 169.707723 149.857678)
        (xy 169.905641 149.72964)
        (xy 169.929581 149.707857)
        (xy 170.076167 149.574473)
        (xy 170.076168 149.574471)
        (xy 170.079989 149.570995)
        (xy 170.083188 149.566944)
        (xy 170.083192 149.56694)
        (xy 170.222883 149.390061)
        (xy 170.222885 149.390057)
        (xy 170.226085 149.386006)
        (xy 170.340005 149.179639)
        (xy 170.349794 149.151998)
        (xy 170.416965 148.962311)
        (xy 170.416966 148.962307)
        (xy 170.418691 148.957436)
        (xy 170.419599 148.95234)
        (xy 170.459123 148.730456)
        (xy 170.459124 148.73045)
        (xy 170.460029 148.725367)
        (xy 170.462909 148.489661)
        (xy 170.427253 148.256651)
        (xy 170.35402 148.032593)
        (xy 170.280516 147.891394)
        (xy 170.247564 147.828093)
        (xy 170.247563 147.828092)
        (xy 170.245175 147.823504)
        (xy 170.226415 147.798517)
        (xy 170.106747 147.639135)
        (xy 170.106745 147.639132)
        (xy 170.103642 147.635)
        (xy 169.979332 147.516206)
        (xy 169.93696 147.475714)
        (xy 169.936959 147.475713)
        (xy 169.933223 147.472143)
        (xy 169.738492 147.339307)
        (xy 169.733808 147.337133)
        (xy 169.733805 147.337131)
        (xy 169.529372 147.242236)
        (xy 169.529367 147.242234)
        (xy 169.524681 147.240059)
        (xy 169.297532 147.177065)
        (xy 169.292395 147.176516)
        (xy 169.108437 147.156856)
        (xy 169.108429 147.156856)
        (xy 169.105102 147.1565)
        (xy 167.770243 147.1565)
        (xy 167.76767 147.156712)
        (xy 167.767659 147.156712)
        (xy 167.600221 147.170478)
        (xy 167.600215 147.170479)
        (xy 167.59507 147.170902)
        (xy 167.366449 147.228327)
        (xy 167.150277 147.322322)
        (xy 166.952359 147.45036)
        (xy 166.948536 147.453839)
        (xy 166.948533 147.453841)
        (xy 166.879995 147.516206)
        (xy 166.778011 147.609005)
        (xy 166.774812 147.613056)
        (xy 166.774808 147.61306)
        (xy 166.635117 147.789939)
        (xy 166.631915 147.793994)
        (xy 166.517995 148.000361)
        (xy 166.516271 148.00523)
        (xy 166.516269 148.005234)
        (xy 166.441035 148.217689)
        (xy 166.439309 148.222564)
        (xy 166.438402 148.227657)
        (xy 166.438401 148.22766)
        (xy 166.434113 148.251736)
        (xy 166.397971 148.454633)
        (xy 157.962909 148.489661)
        (xy 157.927253 148.256651)
        (xy 157.85402 148.032593)
        (xy 157.780516 147.891394)
        (xy 157.747564 147.828093)
        (xy 157.747563 147.828092)
        (xy 157.745175 147.823504)
        (xy 157.726415 147.798517)
        (xy 157.606747 147.639135)
        (xy 157.606745 147.639132)
        (xy 157.603642 147.635)
        (xy 157.479332 147.516206)
        (xy 157.43696 147.475714)
        (xy 157.436959 147.475713)
        (xy 157.433223 147.472143)
        (xy 157.238492 147.339307)
        (xy 157.233808 147.337133)
        (xy 157.233805 147.337131)
        (xy 157.029372 147.242236)
        (xy 157.029367 147.242234)
        (xy 157.024681 147.240059)
        (xy 156.797532 147.177065)
        (xy 156.792395 147.176516)
        (xy 156.608437 147.156856)
        (xy 156.608429 147.156856)
        (xy 156.605102 147.1565)
        (xy 155.270243 147.1565)
        (xy 155.26767 147.156712)
        (xy 155.267659 147.156712)
        (xy 155.100221 147.170478)
        (xy 155.100215 147.170479)
        (xy 155.09507 147.170902)
        (xy 154.866449 147.228327)
        (xy 154.650277 147.322322)
        (xy 154.452359 147.45036)
        (xy 154.448536 147.453839)
        (xy 154.448533 147.453841)
        (xy 154.379995 147.516206)
        (xy 154.278011 147.609005)
        (xy 154.274812 147.613056)
        (xy 154.274808 147.61306)
        (xy 154.212816 147.691556)
        (xy 154.131915 147.793994)
        (xy 154.129422 147.798509)
        (xy 154.129414 147.798522)
        (xy 154.078146 147.891394)
        (xy 154.027714 147.941364)
        (xy 153.967838 147.9565)
        (xy 153.5538 147.9565)
        (xy 153.485679 147.936498)
        (xy 153.439186 147.882842)
        (xy 153.429082 147.812568)
        (xy 153.444681 147.7675)
        (xy 153.485223 147.697279)
        (xy 153.485224 147.697278)
        (xy 153.488527 147.691556)
        (xy 153.547542 147.509928)
        (xy 153.55182 147.469231)
        (xy 153.566814 147.326565)
        (xy 153.567504 147.32)
        (xy 153.555576 147.206509)
        (xy 153.548232 147.136635)
        (xy 153.548232 147.136633)
        (xy 153.547542 147.130072)
        (xy 153.488527 146.948444)
        (xy 153.39304 146.783056)
        (xy 153.265253 146.641134)
        (xy 153.110752 146.528882)
        (xy 153.104724 146.526198)
        (xy 153.104722 146.526197)
        (xy 152.942319 146.453891)
        (xy 152.942318 146.453891)
        (xy 152.936288 146.451206)
        (xy 152.842887 146.431353)
        (xy 152.755944 146.412872)
        (xy 152.755939 146.412872)
        (xy 152.749487 146.4115)
        (xy 152.558513 146.4115)
        (xy 152.552061 146.412872)
        (xy 152.552056 146.412872)
        (xy 152.465113 146.431353)
        (xy 152.371712 146.451206)
        (xy 152.365682 146.453891)
        (xy 152.365681 146.453891)
        (xy 152.203278 146.526197)
        (xy 152.203276 146.526198)
        (xy 152.197248 146.528882)
        (xy 152.042747 146.641134)
        (xy 151.91496 146.783056)
        (xy 151.819473 146.948444)
        (xy 151.817432 146.954726)
        (xy 151.763644 147.120267)
        (xy 151.72357 147.178872)
        (xy 151.658173 147.206509)
        (xy 151.610143 147.202748)
        (xy 151.517532 147.177065)
        (xy 151.512395 147.176516)
        (xy 151.328437 147.156856)
        (xy 151.328429 147.156856)
        (xy 151.325102 147.1565)
        (xy 149.990243 147.1565)
        (xy 149.98767 147.156712)
        (xy 149.987659 147.156712)
        (xy 149.820221 147.170478)
        (xy 149.820215 147.170479)
        (xy 149.81507 147.170902)
        (xy 149.586449 147.228327)
        (xy 149.370277 147.322322)
        (xy 149.172359 147.45036)
        (xy 149.168536 147.453839)
        (xy 149.168533 147.453841)
        (xy 149.099995 147.516206)
        (xy 148.998011 147.609005)
        (xy 148.994812 147.613056)
        (xy 148.994808 147.61306)
        (xy 148.855117 147.789939)
        (xy 148.851915 147.793994)
        (xy 148.737995 148.000361)
        (xy 148.736271 148.00523)
        (xy 148.736269 148.005234)
        (xy 148.661035 148.217689)
        (xy 148.659309 148.222564)
        (xy 148.658402 148.227657)
        (xy 148.658401 148.22766)
        (xy 148.654113 148.251736)
        (xy 148.617971 148.454633)
        (xy 140.182909 148.489661)
        (xy 140.147253 148.256651)
        (xy 140.07402 148.032593)
        (xy 140.000516 147.891394)
        (xy 139.967564 147.828093)
        (xy 139.967563 147.828092)
        (xy 139.965175 147.823504)
        (xy 139.946415 147.798517)
        (xy 139.826747 147.639135)
        (xy 139.826745 147.639132)
        (xy 139.823642 147.635)
        (xy 139.699332 147.516206)
        (xy 139.65696 147.475714)
        (xy 139.656959 147.475713)
        (xy 139.653223 147.472143)
        (xy 139.458492 147.339307)
        (xy 139.453808 147.337133)
        (xy 139.453805 147.337131)
        (xy 139.249372 147.242236)
        (xy 139.249367 147.242234)
        (xy 139.244681 147.240059)
        (xy 139.017532 147.177065)
        (xy 139.012395 147.176516)
        (xy 138.828437 147.156856)
        (xy 138.828429 147.156856)
        (xy 138.825102 147.1565)
        (xy 137.490243 147.1565)
        (xy 137.48767 147.156712)
        (xy 137.487659 147.156712)
        (xy 137.320221 147.170478)
        (xy 137.320215 147.170479)
        (xy 137.31507 147.170902)
        (xy 137.086449 147.228327)
        (xy 136.870277 147.322322)
        (xy 136.672359 147.45036)
        (xy 136.668536 147.453839)
        (xy 136.668533 147.453841)
        (xy 136.599995 147.516206)
        (xy 136.498011 147.609005)
        (xy 136.494812 147.613056)
        (xy 136.494808 147.61306)
        (xy 136.355117 147.789939)
        (xy 136.351915 147.793994)
        (xy 136.237995 148.000361)
        (xy 136.236271 148.00523)
        (xy 136.236269 148.005234)
        (xy 136.161035 148.217689)
        (xy 136.159309 148.222564)
        (xy 136.158402 148.227657)
        (xy 136.158401 148.22766)
        (xy 136.154113 148.251736)
        (xy 136.117971 148.454633)
        (xy 132.362909 148.489661)
        (xy 132.327253 148.256651)
        (xy 132.25402 148.032593)
        (xy 132.180516 147.891394)
        (xy 132.147564 147.828093)
        (xy 132.147563 147.828092)
        (xy 132.145175 147.823504)
        (xy 132.126415 147.798517)
        (xy 132.006747 147.639135)
        (xy 132.006745 147.639132)
        (xy 132.003642 147.635)
        (xy 131.879332 147.516206)
        (xy 131.83696 147.475714)
        (xy 131.836959 147.475713)
        (xy 131.833223 147.472143)
        (xy 131.638492 147.339307)
        (xy 131.633808 147.337133)
        (xy 131.633805 147.337131)
        (xy 131.429372 147.242236)
        (xy 131.429367 147.242234)
        (xy 131.424681 147.240059)
        (xy 131.197532 147.177065)
        (xy 131.192395 147.176516)
        (xy 131.008437 147.156856)
        (xy 131.008429 147.156856)
        (xy 131.005102 147.1565)
        (xy 129.670243 147.1565)
        (xy 129.66767 147.156712)
        (xy 129.667659 147.156712)
        (xy 129.500221 147.170478)
        (xy 129.500215 147.170479)
        (xy 129.49507 147.170902)
        (xy 129.266449 147.228327)
        (xy 129.050277 147.322322)
        (xy 128.852359 147.45036)
        (xy 128.848536 147.453839)
        (xy 128.848533 147.453841)
        (xy 128.779995 147.516206)
        (xy 128.678011 147.609005)
        (xy 128.674812 147.613056)
        (xy 128.674808 147.61306)
        (xy 128.535117 147.789939)
        (xy 128.531915 147.793994)
        (xy 128.417995 148.000361)
        (xy 128.416271 148.00523)
        (xy 128.416269 148.005234)
        (xy 128.341035 148.217689)
        (xy 128.339309 148.222564)
        (xy 128.338402 148.227657)
        (xy 128.338401 148.22766)
        (xy 128.334113 148.251736)
        (xy 128.297971 148.454633)
        (xy 119.862909 148.489661)
        (xy 119.827253 148.256651)
        (xy 119.75402 148.032593)
        (xy 119.680516 147.891394)
        (xy 119.647564 147.828093)
        (xy 119.647563 147.828092)
        (xy 119.645175 147.823504)
        (xy 119.626415 147.798517)
        (xy 119.506747 147.639135)
        (xy 119.506745 147.639132)
        (xy 119.503642 147.635)
        (xy 119.379332 147.516206)
        (xy 119.33696 147.475714)
        (xy 119.336959 147.475713)
        (xy 119.333223 147.472143)
        (xy 119.138492 147.339307)
        (xy 119.133808 147.337133)
        (xy 119.133805 147.337131)
        (xy 118.929372 147.242236)
        (xy 118.929367 147.242234)
        (xy 118.924681 147.240059)
        (xy 118.697532 147.177065)
        (xy 118.692395 147.176516)
        (xy 118.508437 147.156856)
        (xy 118.508429 147.156856)
        (xy 118.505102 147.1565)
        (xy 117.170243 147.1565)
        (xy 117.16767 147.156712)
        (xy 117.167659 147.156712)
        (xy 117.000221 147.170478)
        (xy 117.000215 147.170479)
        (xy 116.99507 147.170902)
        (xy 116.766449 147.228327)
        (xy 116.550277 147.322322)
        (xy 116.352359 147.45036)
        (xy 116.348536 147.453839)
        (xy 116.348533 147.453841)
        (xy 116.279995 147.516206)
        (xy 116.178011 147.609005)
        (xy 116.174812 147.613056)
        (xy 116.174808 147.61306)
        (xy 116.035117 147.789939)
        (xy 116.031915 147.793994)
        (xy 115.917995 148.000361)
        (xy 115.916271 148.00523)
        (xy 115.916269 148.005234)
        (xy 115.841035 148.217689)
        (xy 115.839309 148.222564)
        (xy 115.838402 148.227657)
        (xy 115.838401 148.22766)
        (xy 115.834113 148.251736)
        (xy 115.797971 148.454633)
        (xy 114.582909 148.489661)
        (xy 114.547253 148.256651)
        (xy 114.47402 148.032593)
        (xy 114.400516 147.891394)
        (xy 114.367564 147.828093)
        (xy 114.367563 147.828092)
        (xy 114.365175 147.823504)
        (xy 114.346415 147.798517)
        (xy 114.226747 147.639135)
        (xy 114.226745 147.639132)
        (xy 114.223642 147.635)
        (xy 114.099332 147.516206)
        (xy 114.05696 147.475714)
        (xy 114.056959 147.475713)
        (xy 114.053223 147.472143)
        (xy 113.858492 147.339307)
        (xy 113.853808 147.337133)
        (xy 113.853805 147.337131)
        (xy 113.649372 147.242236)
        (xy 113.649367 147.242234)
        (xy 113.644681 147.240059)
        (xy 113.417532 147.177065)
        (xy 113.412395 147.176516)
        (xy 113.228437 147.156856)
        (xy 113.228429 147.156856)
        (xy 113.225102 147.1565)
        (xy 111.890243 147.1565)
        (xy 111.88767 147.156712)
        (xy 111.887659 147.156712)
        (xy 111.720221 147.170478)
        (xy 111.720215 147.170479)
        (xy 111.71507 147.170902)
        (xy 111.486449 147.228327)
        (xy 111.270277 147.322322)
        (xy 111.072359 147.45036)
        (xy 111.068536 147.453839)
        (xy 111.068533 147.453841)
        (xy 110.999995 147.516206)
        (xy 110.898011 147.609005)
        (xy 110.894812 147.613056)
        (xy 110.894808 147.61306)
        (xy 110.755117 147.789939)
        (xy 110.751915 147.793994)
        (xy 110.637995 148.000361)
        (xy 110.636271 148.00523)
        (xy 110.636269 148.005234)
        (xy 110.561035 148.217689)
        (xy 110.559309 148.222564)
        (xy 110.558402 148.227657)
        (xy 110.558401 148.22766)
        (xy 110.554113 148.251736)
        (xy 110.517971 148.454633)
        (xy 102.082909 148.489661)
        (xy 102.047253 148.256651)
        (xy 101.97402 148.032593)
        (xy 101.900516 147.891394)
        (xy 101.867564 147.828093)
        (xy 101.867563 147.828092)
        (xy 101.865175 147.823504)
        (xy 101.846415 147.798517)
        (xy 101.726747 147.639135)
        (xy 101.726745 147.639132)
        (xy 101.723642 147.635)
        (xy 101.599332 147.516206)
        (xy 101.55696 147.475714)
        (xy 101.556959 147.475713)
        (xy 101.553223 147.472143)
        (xy 101.358492 147.339307)
        (xy 101.353808 147.337133)
        (xy 101.353805 147.337131)
        (xy 101.149372 147.242236)
        (xy 101.149367 147.242234)
        (xy 101.144681 147.240059)
        (xy 100.917532 147.177065)
        (xy 100.912395 147.176516)
        (xy 100.728437 147.156856)
        (xy 100.728429 147.156856)
        (xy 100.725102 147.1565)
        (xy 99.390243 147.1565)
        (xy 99.38767 147.156712)
        (xy 99.387659 147.156712)
        (xy 99.220221 147.170478)
        (xy 99.220215 147.170479)
        (xy 99.21507 147.170902)
        (xy 98.986449 147.228327)
        (xy 98.770277 147.322322)
        (xy 98.572359 147.45036)
        (xy 98.568536 147.453839)
        (xy 98.568533 147.453841)
        (xy 98.499995 147.516206)
        (xy 98.398011 147.609005)
        (xy 98.394812 147.613056)
        (xy 98.394808 147.61306)
        (xy 98.255117 147.789939)
        (xy 98.251915 147.793994)
        (xy 98.137995 148.000361)
        (xy 98.136271 148.00523)
        (xy 98.136269 148.005234)
        (xy 98.061035 148.217689)
        (xy 98.059309 148.222564)
        (xy 98.058402 148.227657)
        (xy 98.058401 148.22766)
        (xy 98.054113 148.251736)
        (xy 98.017971 148.454633)
        (xy 96.52 143.690339)
        (xy 98.015091 143.690339)
        (xy 98.050747 143.923349)
        (xy 98.12398 144.147407)
        (xy 98.232825 144.356496)
        (xy 98.235928 144.360629)
        (xy 98.23593 144.360632)
        (xy 98.258026 144.390061)
        (xy 98.374358 144.545)
        (xy 98.544777 144.707857)
        (xy 98.739508 144.840693)
        (xy 98.744192 144.842867)
        (xy 98.744195 144.842869)
        (xy 98.948628 144.937764)
        (xy 98.948633 144.937766)
        (xy 98.953319 144.939941)
        (xy 99.180468 145.002935)
        (xy 99.185605 145.003484)
        (xy 99.369563 145.023144)
        (xy 99.369571 145.023144)
        (xy 99.372898 145.0235)
        (xy 100.707757 145.0235)
        (xy 100.71033 145.023288)
        (xy 100.710341 145.023288)
        (xy 100.877779 145.009522)
        (xy 100.877785 145.009521)
        (xy 100.88293 145.009098)
        (xy 101.111551 144.951673)
        (xy 101.327723 144.857678)
        (xy 101.525641 144.72964)
        (xy 101.549581 144.707857)
        (xy 101.696167 144.574473)
        (xy 101.696168 144.574471)
        (xy 101.699989 144.570995)
        (xy 101.703188 144.566944)
        (xy 101.703192 144.56694)
        (xy 101.842883 144.390061)
        (xy 101.842885 144.390057)
        (xy 101.846085 144.386006)
        (xy 101.960005 144.179639)
        (xy 101.969794 144.151998)
        (xy 102.036965 143.962311)
        (xy 102.036966 143.962307)
        (xy 102.038691 143.957436)
        (xy 102.039599 143.95234)
        (xy 102.079123 143.730456)
        (xy 102.079124 143.73045)
        (xy 102.080029 143.725367)
        (xy 102.080457 143.690339)
        (xy 110.515091 143.690339)
        (xy 110.550747 143.923349)
        (xy 110.62398 144.147407)
        (xy 110.732825 144.356496)
        (xy 110.735928 144.360629)
        (xy 110.73593 144.360632)
        (xy 110.758026 144.390061)
        (xy 110.874358 144.545)
        (xy 111.044777 144.707857)
        (xy 111.239508 144.840693)
        (xy 111.244192 144.842867)
        (xy 111.244195 144.842869)
        (xy 111.448628 144.937764)
        (xy 111.448633 144.937766)
        (xy 111.453319 144.939941)
        (xy 111.680468 145.002935)
        (xy 111.685605 145.003484)
        (xy 111.869563 145.023144)
        (xy 111.869571 145.023144)
        (xy 111.872898 145.0235)
        (xy 113.207757 145.0235)
        (xy 113.21033 145.023288)
        (xy 113.210341 145.023288)
        (xy 113.377779 145.009522)
        (xy 113.377785 145.009521)
        (xy 113.38293 145.009098)
        (xy 113.611551 144.951673)
        (xy 113.827723 144.857678)
        (xy 114.025641 144.72964)
        (xy 114.049581 144.707857)
        (xy 114.196167 144.574473)
        (xy 114.196168 144.574471)
        (xy 114.199989 144.570995)
        (xy 114.203188 144.566944)
        (xy 114.203192 144.56694)
        (xy 114.342883 144.390061)
        (xy 114.342885 144.390057)
        (xy 114.346085 144.386006)
        (xy 114.460005 144.179639)
        (xy 114.469794 144.151998)
        (xy 114.536965 143.962311)
        (xy 114.536966 143.962307)
        (xy 114.538691 143.957436)
        (xy 114.539599 143.95234)
        (xy 114.579123 143.730456)
        (xy 114.579124 143.73045)
        (xy 114.580029 143.725367)
        (xy 114.580457 143.690339)
        (xy 115.795091 143.690339)
        (xy 115.830747 143.923349)
        (xy 115.90398 144.147407)
        (xy 116.012825 144.356496)
        (xy 116.015928 144.360629)
        (xy 116.01593 144.360632)
        (xy 116.038026 144.390061)
        (xy 116.154358 144.545)
        (xy 116.324777 144.707857)
        (xy 116.519508 144.840693)
        (xy 116.524192 144.842867)
        (xy 116.524195 144.842869)
        (xy 116.728628 144.937764)
        (xy 116.728633 144.937766)
        (xy 116.733319 144.939941)
        (xy 116.960468 145.002935)
        (xy 116.965605 145.003484)
        (xy 117.149563 145.023144)
        (xy 117.149571 145.023144)
        (xy 117.152898 145.0235)
        (xy 118.487757 145.0235)
        (xy 118.49033 145.023288)
        (xy 118.490341 145.023288)
        (xy 118.657779 145.009522)
        (xy 118.657785 145.009521)
        (xy 118.66293 145.009098)
        (xy 118.891551 144.951673)
        (xy 119.107723 144.857678)
        (xy 119.305641 144.72964)
        (xy 119.329581 144.707857)
        (xy 119.476167 144.574473)
        (xy 119.476168 144.574471)
        (xy 119.479989 144.570995)
        (xy 119.483188 144.566944)
        (xy 119.483192 144.56694)
        (xy 119.622883 144.390061)
        (xy 119.622885 144.390057)
        (xy 119.626085 144.386006)
        (xy 119.740005 144.179639)
        (xy 119.749794 144.151998)
        (xy 119.816965 143.962311)
        (xy 119.816966 143.962307)
        (xy 119.818691 143.957436)
        (xy 119.819599 143.95234)
        (xy 119.859123 143.730456)
        (xy 119.859124 143.73045)
        (xy 119.860029 143.725367)
        (xy 119.860457 143.690339)
        (xy 128.295091 143.690339)
        (xy 128.330747 143.923349)
        (xy 128.40398 144.147407)
        (xy 128.512825 144.356496)
        (xy 128.515928 144.360629)
        (xy 128.51593 144.360632)
        (xy 128.538026 144.390061)
        (xy 128.654358 144.545)
        (xy 128.824777 144.707857)
        (xy 129.019508 144.840693)
        (xy 129.024192 144.842867)
        (xy 129.024195 144.842869)
        (xy 129.228628 144.937764)
        (xy 129.228633 144.937766)
        (xy 129.233319 144.939941)
        (xy 129.460468 145.002935)
        (xy 129.465605 145.003484)
        (xy 129.649563 145.023144)
        (xy 129.649571 145.023144)
        (xy 129.652898 145.0235)
        (xy 130.987757 145.0235)
        (xy 130.99033 145.023288)
        (xy 130.990341 145.023288)
        (xy 131.157779 145.009522)
        (xy 131.157785 145.009521)
        (xy 131.16293 145.009098)
        (xy 131.391551 144.951673)
        (xy 131.607723 144.857678)
        (xy 131.805641 144.72964)
        (xy 131.829581 144.707857)
        (xy 131.976167 144.574473)
        (xy 131.976168 144.574471)
        (xy 131.979989 144.570995)
        (xy 131.983188 144.566944)
        (xy 131.983192 144.56694)
        (xy 132.122883 144.390061)
        (xy 132.122885 144.390057)
        (xy 132.126085 144.386006)
        (xy 132.240005 144.179639)
        (xy 132.249794 144.151998)
        (xy 132.316965 143.962311)
        (xy 132.316966 143.962307)
        (xy 132.318691 143.957436)
        (xy 132.319599 143.95234)
        (xy 132.359123 143.730456)
        (xy 132.359124 143.73045)
        (xy 132.360029 143.725367)
        (xy 132.360457 143.690339)
        (xy 136.115091 143.690339)
        (xy 136.150747 143.923349)
        (xy 136.22398 144.147407)
        (xy 136.332825 144.356496)
        (xy 136.335928 144.360629)
        (xy 136.33593 144.360632)
        (xy 136.358026 144.390061)
        (xy 136.474358 144.545)
        (xy 136.644777 144.707857)
        (xy 136.839508 144.840693)
        (xy 136.844192 144.842867)
        (xy 136.844195 144.842869)
        (xy 137.048628 144.937764)
        (xy 137.048633 144.937766)
        (xy 137.053319 144.939941)
        (xy 137.280468 145.002935)
        (xy 137.285605 145.003484)
        (xy 137.469563 145.023144)
        (xy 137.469571 145.023144)
        (xy 137.472898 145.0235)
        (xy 138.807757 145.0235)
        (xy 138.81033 145.023288)
        (xy 138.810341 145.023288)
        (xy 138.977779 145.009522)
        (xy 138.977785 145.009521)
        (xy 138.98293 145.009098)
        (xy 139.211551 144.951673)
        (xy 139.427723 144.857678)
        (xy 139.625641 144.72964)
        (xy 139.649581 144.707857)
        (xy 139.796167 144.574473)
        (xy 139.796168 144.574471)
        (xy 139.799989 144.570995)
        (xy 139.803188 144.566944)
        (xy 139.803192 144.56694)
        (xy 139.942883 144.390061)
        (xy 139.942885 144.390057)
        (xy 139.946085 144.386006)
        (xy 140.060005 144.179639)
        (xy 140.069794 144.151998)
        (xy 140.136965 143.962311)
        (xy 140.136966 143.962307)
        (xy 140.138691 143.957436)
        (xy 140.139599 143.95234)
        (xy 140.179123 143.730456)
        (xy 140.179124 143.73045)
        (xy 140.180029 143.725367)
        (xy 140.180457 143.690339)
        (xy 148.615091 143.690339)
        (xy 148.650747 143.923349)
        (xy 148.72398 144.147407)
        (xy 148.832825 144.356496)
        (xy 148.835928 144.360629)
        (xy 148.83593 144.360632)
        (xy 148.858026 144.390061)
        (xy 148.974358 144.545)
        (xy 149.144777 144.707857)
        (xy 149.339508 144.840693)
        (xy 149.344192 144.842867)
        (xy 149.344195 144.842869)
        (xy 149.548628 144.937764)
        (xy 149.548633 144.937766)
        (xy 149.553319 144.939941)
        (xy 149.780468 145.002935)
        (xy 149.785605 145.003484)
        (xy 149.969563 145.023144)
        (xy 149.969571 145.023144)
        (xy 149.972898 145.0235)
        (xy 151.307757 145.0235)
        (xy 151.31033 145.023288)
        (xy 151.310341 145.023288)
        (xy 151.477779 145.009522)
        (xy 151.477785 145.009521)
        (xy 151.48293 145.009098)
        (xy 151.711551 144.951673)
        (xy 151.927723 144.857678)
        (xy 152.125641 144.72964)
        (xy 152.149581 144.707857)
        (xy 152.296167 144.574473)
        (xy 152.296168 144.574471)
        (xy 152.299989 144.570995)
        (xy 152.303188 144.566944)
        (xy 152.303192 144.56694)
        (xy 152.442883 144.390061)
        (xy 152.442885 144.390057)
        (xy 152.446085 144.386006)
        (xy 152.560005 144.179639)
        (xy 152.569794 144.151998)
        (xy 152.636965 143.962311)
        (xy 152.636966 143.962307)
        (xy 152.638691 143.957436)
        (xy 152.639599 143.95234)
        (xy 152.679123 143.730456)
        (xy 152.679124 143.73045)
        (xy 152.680029 143.725367)
        (xy 152.680457 143.690339)
        (xy 153.895091 143.690339)
        (xy 153.930747 143.923349)
        (xy 154.00398 144.147407)
        (xy 154.112825 144.356496)
        (xy 154.115928 144.360629)
        (xy 154.11593 144.360632)
        (xy 154.138026 144.390061)
        (xy 154.254358 144.545)
        (xy 154.424777 144.707857)
        (xy 154.619508 144.840693)
        (xy 154.624192 144.842867)
        (xy 154.624195 144.842869)
        (xy 154.828628 144.937764)
        (xy 154.828633 144.937766)
        (xy 154.833319 144.939941)
        (xy 155.060468 145.002935)
        (xy 155.065605 145.003484)
        (xy 155.249563 145.023144)
        (xy 155.249571 145.023144)
        (xy 155.252898 145.0235)
        (xy 156.587757 145.0235)
        (xy 156.59033 145.023288)
        (xy 156.590341 145.023288)
        (xy 156.757779 145.009522)
        (xy 156.757785 145.009521)
        (xy 156.76293 145.009098)
        (xy 156.991551 144.951673)
        (xy 157.207723 144.857678)
        (xy 157.405641 144.72964)
        (xy 157.429581 144.707857)
        (xy 157.576167 144.574473)
        (xy 157.576168 144.574471)
        (xy 157.579989 144.570995)
        (xy 157.583188 144.566944)
        (xy 157.583192 144.56694)
        (xy 157.722883 144.390061)
        (xy 157.722885 144.390057)
        (xy 157.726085 144.386006)
        (xy 157.840005 144.179639)
        (xy 157.849794 144.151998)
        (xy 157.916965 143.962311)
        (xy 157.916966 143.962307)
        (xy 157.918691 143.957436)
        (xy 157.919599 143.95234)
        (xy 157.959123 143.730456)
        (xy 157.959124 143.73045)
        (xy 157.960029 143.725367)
        (xy 157.960457 143.690339)
        (xy 166.395091 143.690339)
        (xy 166.430747 143.923349)
        (xy 166.50398 144.147407)
        (xy 166.612825 144.356496)
        (xy 166.615928 144.360629)
        (xy 166.61593 144.360632)
        (xy 166.638026 144.390061)
        (xy 166.754358 144.545)
        (xy 166.924777 144.707857)
        (xy 167.119508 144.840693)
        (xy 167.124192 144.842867)
        (xy 167.124195 144.842869)
        (xy 167.328628 144.937764)
        (xy 167.328633 144.937766)
        (xy 167.333319 144.939941)
        (xy 167.560468 145.002935)
        (xy 167.565605 145.003484)
        (xy 167.749563 145.023144)
        (xy 167.749571 145.023144)
        (xy 167.752898 145.0235)
        (xy 169.087757 145.0235)
        (xy 169.09033 145.023288)
        (xy 169.090341 145.023288)
        (xy 169.257779 145.009522)
        (xy 169.257785 145.009521)
        (xy 169.26293 145.009098)
        (xy 169.491551 144.951673)
        (xy 169.707723 144.857678)
        (xy 169.905641 144.72964)
        (xy 169.929581 144.707857)
        (xy 170.076167 144.574473)
        (xy 170.076168 144.574471)
        (xy 170.079989 144.570995)
        (xy 170.083188 144.566944)
        (xy 170.083192 144.56694)
        (xy 170.222883 144.390061)
        (xy 170.222885 144.390057)
        (xy 170.226085 144.386006)
        (xy 170.340005 144.179639)
        (xy 170.349794 144.151998)
        (xy 170.416965 143.962311)
        (xy 170.416966 143.962307)
        (xy 170.418691 143.957436)
        (xy 170.419599 143.95234)
        (xy 170.459123 143.730456)
        (xy 170.459124 143.73045)
        (xy 170.460029 143.725367)
        (xy 170.462909 143.489661)
        (xy 170.427253 143.256651)
        (xy 170.35402 143.032593)
        (xy 170.245175 142.823504)
        (xy 170.226415 142.798517)
        (xy 170.106747 142.639135)
        (xy 170.106745 142.639132)
        (xy 170.103642 142.635)
        (xy 169.933223 142.472143)
        (xy 169.738492 142.339307)
        (xy 169.733808 142.337133)
        (xy 169.733805 142.337131)
        (xy 169.529372 142.242236)
        (xy 169.529367 142.242234)
        (xy 169.524681 142.240059)
        (xy 169.297532 142.177065)
        (xy 169.292395 142.176516)
        (xy 169.108437 142.156856)
        (xy 169.108429 142.156856)
        (xy 169.105102 142.1565)
        (xy 167.770243 142.1565)
        (xy 167.76767 142.156712)
        (xy 167.767659 142.156712)
        (xy 167.600221 142.170478)
        (xy 167.600215 142.170479)
        (xy 167.59507 142.170902)
        (xy 167.366449 142.228327)
        (xy 167.150277 142.322322)
        (xy 166.952359 142.45036)
        (xy 166.948536 142.453839)
        (xy 166.948533 142.453841)
        (xy 166.924495 142.475714)
        (xy 166.778011 142.609005)
        (xy 166.774812 142.613056)
        (xy 166.774808 142.61306)
        (xy 166.635117 142.789939)
        (xy 166.631915 142.793994)
        (xy 166.517995 143.000361)
        (xy 166.516271 143.00523)
        (xy 166.516269 143.005234)
        (xy 166.441035 143.217689)
        (xy 166.439309 143.222564)
        (xy 166.438402 143.227657)
        (xy 166.438401 143.22766)
        (xy 166.434113 143.251736)
        (xy 166.397971 143.454633)
        (xy 157.962909 143.489661)
        (xy 157.927253 143.256651)
        (xy 157.85402 143.032593)
        (xy 157.745175 142.823504)
        (xy 157.726415 142.798517)
        (xy 157.606747 142.639135)
        (xy 157.606745 142.639132)
        (xy 157.603642 142.635)
        (xy 157.433223 142.472143)
        (xy 157.238492 142.339307)
        (xy 157.233808 142.337133)
        (xy 157.233805 142.337131)
        (xy 157.029372 142.242236)
        (xy 157.029367 142.242234)
        (xy 157.024681 142.240059)
        (xy 156.797532 142.177065)
        (xy 156.792395 142.176516)
        (xy 156.608437 142.156856)
        (xy 156.608429 142.156856)
        (xy 156.605102 142.1565)
        (xy 155.270243 142.1565)
        (xy 155.26767 142.156712)
        (xy 155.267659 142.156712)
        (xy 155.100221 142.170478)
        (xy 155.100215 142.170479)
        (xy 155.09507 142.170902)
        (xy 154.866449 142.228327)
        (xy 154.650277 142.322322)
        (xy 154.452359 142.45036)
        (xy 154.448536 142.453839)
        (xy 154.448533 142.453841)
        (xy 154.424495 142.475714)
        (xy 154.278011 142.609005)
        (xy 154.274812 142.613056)
        (xy 154.274808 142.61306)
        (xy 154.135117 142.789939)
        (xy 154.131915 142.793994)
        (xy 154.017995 143.000361)
        (xy 154.016271 143.00523)
        (xy 154.016269 143.005234)
        (xy 153.941035 143.217689)
        (xy 153.939309 143.222564)
        (xy 153.938402 143.227657)
        (xy 153.938401 143.22766)
        (xy 153.934113 143.251736)
        (xy 153.897971 143.454633)
        (xy 152.682909 143.489661)
        (xy 152.647253 143.256651)
        (xy 152.57402 143.032593)
        (xy 152.465175 142.823504)
        (xy 152.446415 142.798517)
        (xy 152.326747 142.639135)
        (xy 152.326745 142.639132)
        (xy 152.323642 142.635)
        (xy 152.153223 142.472143)
        (xy 151.958492 142.339307)
        (xy 151.953808 142.337133)
        (xy 151.953805 142.337131)
        (xy 151.749372 142.242236)
        (xy 151.749367 142.242234)
        (xy 151.744681 142.240059)
        (xy 151.517532 142.177065)
        (xy 151.512395 142.176516)
        (xy 151.328437 142.156856)
        (xy 151.328429 142.156856)
        (xy 151.325102 142.1565)
        (xy 149.990243 142.1565)
        (xy 149.98767 142.156712)
        (xy 149.987659 142.156712)
        (xy 149.820221 142.170478)
        (xy 149.820215 142.170479)
        (xy 149.81507 142.170902)
        (xy 149.586449 142.228327)
        (xy 149.370277 142.322322)
        (xy 149.172359 142.45036)
        (xy 149.168536 142.453839)
        (xy 149.168533 142.453841)
        (xy 149.144495 142.475714)
        (xy 148.998011 142.609005)
        (xy 148.994812 142.613056)
        (xy 148.994808 142.61306)
        (xy 148.855117 142.789939)
        (xy 148.851915 142.793994)
        (xy 148.737995 143.000361)
        (xy 148.736271 143.00523)
        (xy 148.736269 143.005234)
        (xy 148.661035 143.217689)
        (xy 148.659309 143.222564)
        (xy 148.658402 143.227657)
        (xy 148.658401 143.22766)
        (xy 148.654113 143.251736)
        (xy 148.617971 143.454633)
        (xy 140.182909 143.489661)
        (xy 140.147253 143.256651)
        (xy 140.07402 143.032593)
        (xy 139.965175 142.823504)
        (xy 139.946415 142.798517)
        (xy 139.826747 142.639135)
        (xy 139.826745 142.639132)
        (xy 139.823642 142.635)
        (xy 139.653223 142.472143)
        (xy 139.458492 142.339307)
        (xy 139.453808 142.337133)
        (xy 139.453805 142.337131)
        (xy 139.249372 142.242236)
        (xy 139.249367 142.242234)
        (xy 139.244681 142.240059)
        (xy 139.017532 142.177065)
        (xy 139.012395 142.176516)
        (xy 138.828437 142.156856)
        (xy 138.828429 142.156856)
        (xy 138.825102 142.1565)
        (xy 137.490243 142.1565)
        (xy 137.48767 142.156712)
        (xy 137.487659 142.156712)
        (xy 137.320221 142.170478)
        (xy 137.320215 142.170479)
        (xy 137.31507 142.170902)
        (xy 137.086449 142.228327)
        (xy 136.870277 142.322322)
        (xy 136.672359 142.45036)
        (xy 136.668536 142.453839)
        (xy 136.668533 142.453841)
        (xy 136.644495 142.475714)
        (xy 136.498011 142.609005)
        (xy 136.494812 142.613056)
        (xy 136.494808 142.61306)
        (xy 136.355117 142.789939)
        (xy 136.351915 142.793994)
        (xy 136.237995 143.000361)
        (xy 136.236271 143.00523)
        (xy 136.236269 143.005234)
        (xy 136.161035 143.217689)
        (xy 136.159309 143.222564)
        (xy 136.158402 143.227657)
        (xy 136.158401 143.22766)
        (xy 136.154113 143.251736)
        (xy 136.117971 143.454633)
        (xy 132.362909 143.489661)
        (xy 132.327253 143.256651)
        (xy 132.25402 143.032593)
        (xy 132.145175 142.823504)
        (xy 132.126415 142.798517)
        (xy 132.006747 142.639135)
        (xy 132.006745 142.639132)
        (xy 132.003642 142.635)
        (xy 131.833223 142.472143)
        (xy 131.638492 142.339307)
        (xy 131.633808 142.337133)
        (xy 131.633805 142.337131)
        (xy 131.429372 142.242236)
        (xy 131.429367 142.242234)
        (xy 131.424681 142.240059)
        (xy 131.197532 142.177065)
        (xy 131.192395 142.176516)
        (xy 131.008437 142.156856)
        (xy 131.008429 142.156856)
        (xy 131.005102 142.1565)
        (xy 129.670243 142.1565)
        (xy 129.66767 142.156712)
        (xy 129.667659 142.156712)
        (xy 129.500221 142.170478)
        (xy 129.500215 142.170479)
        (xy 129.49507 142.170902)
        (xy 129.266449 142.228327)
        (xy 129.050277 142.322322)
        (xy 128.852359 142.45036)
        (xy 128.848536 142.453839)
        (xy 128.848533 142.453841)
        (xy 128.824495 142.475714)
        (xy 128.678011 142.609005)
        (xy 128.674812 142.613056)
        (xy 128.674808 142.61306)
        (xy 128.535117 142.789939)
        (xy 128.531915 142.793994)
        (xy 128.417995 143.000361)
        (xy 128.416271 143.00523)
        (xy 128.416269 143.005234)
        (xy 128.341035 143.217689)
        (xy 128.339309 143.222564)
        (xy 128.338402 143.227657)
        (xy 128.338401 143.22766)
        (xy 128.334113 143.251736)
        (xy 128.297971 143.454633)
        (xy 119.862909 143.489661)
        (xy 119.827253 143.256651)
        (xy 119.75402 143.032593)
        (xy 119.645175 142.823504)
        (xy 119.626415 142.798517)
        (xy 119.506747 142.639135)
        (xy 119.506745 142.639132)
        (xy 119.503642 142.635)
        (xy 119.333223 142.472143)
        (xy 119.138492 142.339307)
        (xy 119.133808 142.337133)
        (xy 119.133805 142.337131)
        (xy 118.929372 142.242236)
        (xy 118.929367 142.242234)
        (xy 118.924681 142.240059)
        (xy 118.697532 142.177065)
        (xy 118.692395 142.176516)
        (xy 118.508437 142.156856)
        (xy 118.508429 142.156856)
        (xy 118.505102 142.1565)
        (xy 117.170243 142.1565)
        (xy 117.16767 142.156712)
        (xy 117.167659 142.156712)
        (xy 117.000221 142.170478)
        (xy 117.000215 142.170479)
        (xy 116.99507 142.170902)
        (xy 116.766449 142.228327)
        (xy 116.550277 142.322322)
        (xy 116.352359 142.45036)
        (xy 116.348536 142.453839)
        (xy 116.348533 142.453841)
        (xy 116.324495 142.475714)
        (xy 116.178011 142.609005)
        (xy 116.174812 142.613056)
        (xy 116.174808 142.61306)
        (xy 116.035117 142.789939)
        (xy 116.031915 142.793994)
        (xy 115.917995 143.000361)
        (xy 115.916271 143.00523)
        (xy 115.916269 143.005234)
        (xy 115.841035 143.217689)
        (xy 115.839309 143.222564)
        (xy 115.838402 143.227657)
        (xy 115.838401 143.22766)
        (xy 115.834113 143.251736)
        (xy 115.797971 143.454633)
        (xy 114.582909 143.489661)
        (xy 114.547253 143.256651)
        (xy 114.47402 143.032593)
        (xy 114.365175 142.823504)
        (xy 114.346415 142.798517)
        (xy 114.226747 142.639135)
        (xy 114.226745 142.639132)
        (xy 114.223642 142.635)
        (xy 114.053223 142.472143)
        (xy 113.858492 142.339307)
        (xy 113.853808 142.337133)
        (xy 113.853805 142.337131)
        (xy 113.649372 142.242236)
        (xy 113.649367 142.242234)
        (xy 113.644681 142.240059)
        (xy 113.417532 142.177065)
        (xy 113.412395 142.176516)
        (xy 113.228437 142.156856)
        (xy 113.228429 142.156856)
        (xy 113.225102 142.1565)
        (xy 111.890243 142.1565)
        (xy 111.88767 142.156712)
        (xy 111.887659 142.156712)
        (xy 111.720221 142.170478)
        (xy 111.720215 142.170479)
        (xy 111.71507 142.170902)
        (xy 111.486449 142.228327)
        (xy 111.270277 142.322322)
        (xy 111.072359 142.45036)
        (xy 111.068536 142.453839)
        (xy 111.068533 142.453841)
        (xy 111.044495 142.475714)
        (xy 110.898011 142.609005)
        (xy 110.894812 142.613056)
        (xy 110.894808 142.61306)
        (xy 110.755117 142.789939)
        (xy 110.751915 142.793994)
        (xy 110.637995 143.000361)
        (xy 110.636271 143.00523)
        (xy 110.636269 143.005234)
        (xy 110.561035 143.217689)
        (xy 110.559309 143.222564)
        (xy 110.558402 143.227657)
        (xy 110.558401 143.22766)
        (xy 110.554113 143.251736)
        (xy 110.517971 143.454633)
        (xy 102.082909 143.489661)
        (xy 102.047253 143.256651)
        (xy 101.97402 143.032593)
        (xy 101.865175 142.823504)
        (xy 101.846415 142.798517)
        (xy 101.726747 142.639135)
        (xy 101.726745 142.639132)
        (xy 101.723642 142.635)
        (xy 101.553223 142.472143)
        (xy 101.358492 142.339307)
        (xy 101.353808 142.337133)
        (xy 101.353805 142.337131)
        (xy 101.149372 142.242236)
        (xy 101.149367 142.242234)
        (xy 101.144681 142.240059)
        (xy 100.917532 142.177065)
        (xy 100.912395 142.176516)
        (xy 100.728437 142.156856)
        (xy 100.728429 142.156856)
        (xy 100.725102 142.1565)
        (xy 99.390243 142.1565)
        (xy 99.38767 142.156712)
        (xy 99.387659 142.156712)
        (xy 99.220221 142.170478)
        (xy 99.220215 142.170479)
        (xy 99.21507 142.170902)
        (xy 98.986449 142.228327)
        (xy 98.770277 142.322322)
        (xy 98.572359 142.45036)
        (xy 98.568536 142.453839)
        (xy 98.568533 142.453841)
        (xy 98.544495 142.475714)
        (xy 98.398011 142.609005)
        (xy 98.394812 142.613056)
        (xy 98.394808 142.61306)
        (xy 98.255117 142.789939)
        (xy 98.251915 142.793994)
        (xy 98.137995 143.000361)
        (xy 98.136271 143.00523)
        (xy 98.136269 143.005234)
        (xy 98.061035 143.217689)
        (xy 98.059309 143.222564)
        (xy 98.058402 143.227657)
        (xy 98.058401 143.22766)
        (xy 98.054113 143.251736)
        (xy 98.017971 143.454633)
        (xy 96.52 134.172339)
        (xy 98.015091 134.172339)
        (xy 98.050747 134.405349)
        (xy 98.12398 134.629407)
        (xy 98.12637 134.633998)
        (xy 98.186863 134.750203)
        (xy 98.232825 134.838496)
        (xy 98.235928 134.842629)
        (xy 98.23593 134.842632)
        (xy 98.371253 135.022865)
        (xy 98.374358 135.027)
        (xy 98.378096 135.030572)
        (xy 98.526603 135.172489)
        (xy 98.544777 135.189857)
        (xy 98.739508 135.322693)
        (xy 98.744192 135.324867)
        (xy 98.744195 135.324869)
        (xy 98.948628 135.419764)
        (xy 98.948633 135.419766)
        (xy 98.953319 135.421941)
        (xy 99.180468 135.484935)
        (xy 99.185605 135.485484)
        (xy 99.369563 135.505144)
        (xy 99.369571 135.505144)
        (xy 99.372898 135.5055)
        (xy 100.707757 135.5055)
        (xy 100.71033 135.505288)
        (xy 100.710341 135.505288)
        (xy 100.877779 135.491522)
        (xy 100.877785 135.491521)
        (xy 100.88293 135.491098)
        (xy 101.111551 135.433673)
        (xy 101.327723 135.339678)
        (xy 101.525641 135.21164)
        (xy 101.533196 135.204766)
        (xy 101.696167 135.056473)
        (xy 101.696168 135.056471)
        (xy 101.699989 135.052995)
        (xy 101.703188 135.048944)
        (xy 101.703192 135.04894)
        (xy 101.842883 134.872061)
        (xy 101.842885 134.872057)
        (xy 101.846085 134.868006)
        (xy 101.960005 134.661639)
        (xy 101.969794 134.633998)
        (xy 102.036965 134.444311)
        (xy 102.036966 134.444307)
        (xy 102.038691 134.439436)
        (xy 102.039599 134.43434)
        (xy 102.079123 134.212456)
        (xy 102.079124 134.21245)
        (xy 102.080029 134.207367)
        (xy 102.080457 134.172339)
        (xy 110.515091 134.172339)
        (xy 110.550747 134.405349)
        (xy 110.62398 134.629407)
        (xy 110.62637 134.633998)
        (xy 110.686863 134.750203)
        (xy 110.732825 134.838496)
        (xy 110.735928 134.842629)
        (xy 110.73593 134.842632)
        (xy 110.871253 135.022865)
        (xy 110.874358 135.027)
        (xy 110.878096 135.030572)
        (xy 111.026603 135.172489)
        (xy 111.044777 135.189857)
        (xy 111.239508 135.322693)
        (xy 111.244192 135.324867)
        (xy 111.244195 135.324869)
        (xy 111.448628 135.419764)
        (xy 111.448633 135.419766)
        (xy 111.453319 135.421941)
        (xy 111.680468 135.484935)
        (xy 111.685605 135.485484)
        (xy 111.869563 135.505144)
        (xy 111.869571 135.505144)
        (xy 111.872898 135.5055)
        (xy 113.207757 135.5055)
        (xy 113.21033 135.505288)
        (xy 113.210341 135.505288)
        (xy 113.377779 135.491522)
        (xy 113.377785 135.491521)
        (xy 113.38293 135.491098)
        (xy 113.611551 135.433673)
        (xy 113.827723 135.339678)
        (xy 114.025641 135.21164)
        (xy 114.033196 135.204766)
        (xy 114.196167 135.056473)
        (xy 114.196168 135.056471)
        (xy 114.199989 135.052995)
        (xy 114.203188 135.048944)
        (xy 114.203192 135.04894)
        (xy 114.342883 134.872061)
        (xy 114.342885 134.872057)
        (xy 114.346085 134.868006)
        (xy 114.427601 134.720339)
        (xy 125.955091 134.720339)
        (xy 125.990747 134.953349)
        (xy 126.06398 135.177407)
        (xy 126.172825 135.386496)
        (xy 126.175928 135.390629)
        (xy 126.17593 135.390632)
        (xy 126.311253 135.570865)
        (xy 126.314358 135.575)
        (xy 126.484777 135.737857)
        (xy 126.679508 135.870693)
        (xy 126.684192 135.872867)
        (xy 126.684195 135.872869)
        (xy 126.888628 135.967764)
        (xy 126.888633 135.967766)
        (xy 126.893319 135.969941)
        (xy 127.120468 136.032935)
        (xy 127.125605 136.033484)
        (xy 127.309563 136.053144)
        (xy 127.309571 136.053144)
        (xy 127.312898 136.0535)
        (xy 128.647757 136.0535)
        (xy 128.65033 136.053288)
        (xy 128.650341 136.053288)
        (xy 128.817779 136.039522)
        (xy 128.817785 136.039521)
        (xy 128.82293 136.039098)
        (xy 129.051551 135.981673)
        (xy 129.267723 135.887678)
        (xy 129.465641 135.75964)
        (xy 129.489581 135.737857)
        (xy 129.636167 135.604473)
        (xy 129.636168 135.604471)
        (xy 129.639989 135.600995)
        (xy 129.643188 135.596944)
        (xy 129.643192 135.59694)
        (xy 129.782883 135.420061)
        (xy 129.782885 135.420057)
        (xy 129.786085 135.416006)
        (xy 129.900005 135.209639)
        (xy 129.907011 135.189857)
        (xy 129.976965 134.992311)
        (xy 129.976966 134.992307)
        (xy 129.978691 134.987436)
        (xy 129.979599 134.98234)
        (xy 130.019123 134.760456)
        (xy 130.019124 134.76045)
        (xy 130.020029 134.755367)
        (xy 130.020457 134.720339)
        (xy 138.455091 134.720339)
        (xy 138.490747 134.953349)
        (xy 138.56398 135.177407)
        (xy 138.672825 135.386496)
        (xy 138.675928 135.390629)
        (xy 138.67593 135.390632)
        (xy 138.811253 135.570865)
        (xy 138.814358 135.575)
        (xy 138.984777 135.737857)
        (xy 139.179508 135.870693)
        (xy 139.184192 135.872867)
        (xy 139.184195 135.872869)
        (xy 139.388628 135.967764)
        (xy 139.388633 135.967766)
        (xy 139.393319 135.969941)
        (xy 139.620468 136.032935)
        (xy 139.625605 136.033484)
        (xy 139.809563 136.053144)
        (xy 139.809571 136.053144)
        (xy 139.812898 136.0535)
        (xy 141.147757 136.0535)
        (xy 141.15033 136.053288)
        (xy 141.150341 136.053288)
        (xy 141.317779 136.039522)
        (xy 141.317785 136.039521)
        (xy 141.32293 136.039098)
        (xy 141.551551 135.981673)
        (xy 141.767723 135.887678)
        (xy 141.965641 135.75964)
        (xy 141.989581 135.737857)
        (xy 142.136167 135.604473)
        (xy 142.136168 135.604471)
        (xy 142.139989 135.600995)
        (xy 142.143188 135.596944)
        (xy 142.143192 135.59694)
        (xy 142.282883 135.420061)
        (xy 142.282885 135.420057)
        (xy 142.286085 135.416006)
        (xy 142.400005 135.209639)
        (xy 142.407011 135.189857)
        (xy 142.476965 134.992311)
        (xy 142.476966 134.992307)
        (xy 142.478691 134.987436)
        (xy 142.479599 134.98234)
        (xy 142.519123 134.760456)
        (xy 142.519124 134.76045)
        (xy 142.520029 134.755367)
        (xy 142.522909 134.519661)
        (xy 142.487253 134.286651)
        (xy 142.41402 134.062593)
        (xy 142.364022 133.966547)
        (xy 142.307564 133.858093)
        (xy 142.307563 133.858092)
        (xy 142.305175 133.853504)
        (xy 142.286415 133.828517)
        (xy 142.166747 133.669135)
        (xy 142.166745 133.669132)
        (xy 142.163642 133.665)
        (xy 142.090022 133.594647)
        (xy 141.99696 133.505714)
        (xy 141.996959 133.505713)
        (xy 141.993223 133.502143)
        (xy 141.798492 133.369307)
        (xy 141.793808 133.367133)
        (xy 141.793805 133.367131)
        (xy 141.589372 133.272236)
        (xy 141.589367 133.272234)
        (xy 141.584681 133.270059)
        (xy 141.357532 133.207065)
        (xy 141.352395 133.206516)
        (xy 141.168437 133.186856)
        (xy 141.168429 133.186856)
        (xy 141.165102 133.1865)
        (xy 139.830243 133.1865)
        (xy 139.82767 133.186712)
        (xy 139.827659 133.186712)
        (xy 139.660221 133.200478)
        (xy 139.660215 133.200479)
        (xy 139.65507 133.200902)
        (xy 139.426449 133.258327)
        (xy 139.210277 133.352322)
        (xy 139.012359 133.48036)
        (xy 139.008536 133.483839)
        (xy 139.008533 133.483841)
        (xy 138.841833 133.635527)
        (xy 138.838011 133.639005)
        (xy 138.834812 133.643056)
        (xy 138.834808 133.64306)
        (xy 138.759315 133.738651)
        (xy 138.691915 133.823994)
        (xy 138.577995 134.030361)
        (xy 138.576271 134.03523)
        (xy 138.576269 134.035234)
        (xy 138.515314 134.207367)
        (xy 138.499309 134.252564)
        (xy 138.498402 134.257657)
        (xy 138.498401 134.25766)
        (xy 138.466022 134.439436)
        (xy 138.457971 134.484633)
        (xy 130.022909 134.519661)
        (xy 129.987253 134.286651)
        (xy 129.91402 134.062593)
        (xy 129.864022 133.966547)
        (xy 129.807564 133.858093)
        (xy 129.807563 133.858092)
        (xy 129.805175 133.853504)
        (xy 129.786415 133.828517)
        (xy 129.666747 133.669135)
        (xy 129.666745 133.669132)
        (xy 129.663642 133.665)
        (xy 129.590022 133.594647)
        (xy 129.49696 133.505714)
        (xy 129.496959 133.505713)
        (xy 129.493223 133.502143)
        (xy 129.298492 133.369307)
        (xy 129.293808 133.367133)
        (xy 129.293805 133.367131)
        (xy 129.089372 133.272236)
        (xy 129.089367 133.272234)
        (xy 129.084681 133.270059)
        (xy 128.857532 133.207065)
        (xy 128.852395 133.206516)
        (xy 128.668437 133.186856)
        (xy 128.668429 133.186856)
        (xy 128.665102 133.1865)
        (xy 127.330243 133.1865)
        (xy 127.32767 133.186712)
        (xy 127.327659 133.186712)
        (xy 127.160221 133.200478)
        (xy 127.160215 133.200479)
        (xy 127.15507 133.200902)
        (xy 126.926449 133.258327)
        (xy 126.710277 133.352322)
        (xy 126.512359 133.48036)
        (xy 126.508536 133.483839)
        (xy 126.508533 133.483841)
        (xy 126.341833 133.635527)
        (xy 126.338011 133.639005)
        (xy 126.334812 133.643056)
        (xy 126.334808 133.64306)
        (xy 126.259315 133.738651)
        (xy 126.191915 133.823994)
        (xy 126.077995 134.030361)
        (xy 126.076271 134.03523)
        (xy 126.076269 134.035234)
        (xy 126.015314 134.207367)
        (xy 125.999309 134.252564)
        (xy 125.998402 134.257657)
        (xy 125.998401 134.25766)
        (xy 125.966022 134.439436)
        (xy 125.957971 134.484633)
        (xy 114.460005 134.661639)
        (xy 114.469794 134.633998)
        (xy 114.536965 134.444311)
        (xy 114.536966 134.444307)
        (xy 114.538691 134.439436)
        (xy 114.539599 134.43434)
        (xy 114.579123 134.212456)
        (xy 114.579124 134.21245)
        (xy 114.580029 134.207367)
        (xy 114.582909 133.971661)
        (xy 114.547253 133.738651)
        (xy 114.47402 133.514593)
        (xy 114.365175 133.305504)
        (xy 114.346415 133.280517)
        (xy 114.226747 133.121135)
        (xy 114.226745 133.121132)
        (xy 114.223642 133.117)
        (xy 114.053223 132.954143)
        (xy 113.858492 132.821307)
        (xy 113.853808 132.819133)
        (xy 113.853805 132.819131)
        (xy 113.649372 132.724236)
        (xy 113.649367 132.724234)
        (xy 113.644681 132.722059)
        (xy 113.417532 132.659065)
        (xy 113.412395 132.658516)
        (xy 113.228437 132.638856)
        (xy 113.228429 132.638856)
        (xy 113.225102 132.6385)
        (xy 111.890243 132.6385)
        (xy 111.88767 132.638712)
        (xy 111.887659 132.638712)
        (xy 111.720221 132.652478)
        (xy 111.720215 132.652479)
        (xy 111.71507 132.652902)
        (xy 111.486449 132.710327)
        (xy 111.270277 132.804322)
        (xy 111.072359 132.93236)
        (xy 111.068536 132.935839)
        (xy 111.068533 132.935841)
        (xy 111.044495 132.957714)
        (xy 110.898011 133.091005)
        (xy 110.894812 133.095056)
        (xy 110.894808 133.09506)
        (xy 110.756602 133.270059)
        (xy 110.751915 133.275994)
        (xy 110.637995 133.482361)
        (xy 110.636271 133.48723)
        (xy 110.636269 133.487234)
        (xy 110.574584 133.661428)
        (xy 110.559309 133.704564)
        (xy 110.558402 133.709657)
        (xy 110.558401 133.70966)
        (xy 110.532779 133.853504)
        (xy 110.517971 133.936633)
        (xy 102.082909 133.971661)
        (xy 102.047253 133.738651)
        (xy 101.97402 133.514593)
        (xy 101.865175 133.305504)
        (xy 101.846415 133.280517)
        (xy 101.726747 133.121135)
        (xy 101.726745 133.121132)
        (xy 101.723642 133.117)
        (xy 101.553223 132.954143)
        (xy 101.358492 132.821307)
        (xy 101.353808 132.819133)
        (xy 101.353805 132.819131)
        (xy 101.149372 132.724236)
        (xy 101.149367 132.724234)
        (xy 101.144681 132.722059)
        (xy 100.917532 132.659065)
        (xy 100.912395 132.658516)
        (xy 100.728437 132.638856)
        (xy 100.728429 132.638856)
        (xy 100.725102 132.6385)
        (xy 99.390243 132.6385)
        (xy 99.38767 132.638712)
        (xy 99.387659 132.638712)
        (xy 99.220221 132.652478)
        (xy 99.220215 132.652479)
        (xy 99.21507 132.652902)
        (xy 98.986449 132.710327)
        (xy 98.770277 132.804322)
        (xy 98.572359 132.93236)
        (xy 98.568536 132.935839)
        (xy 98.568533 132.935841)
        (xy 98.544495 132.957714)
        (xy 98.398011 133.091005)
        (xy 98.394812 133.095056)
        (xy 98.394808 133.09506)
        (xy 98.256602 133.270059)
        (xy 98.251915 133.275994)
        (xy 98.137995 133.482361)
        (xy 98.136271 133.48723)
        (xy 98.136269 133.487234)
        (xy 98.074584 133.661428)
        (xy 98.059309 133.704564)
        (xy 98.058402 133.709657)
        (xy 98.058401 133.70966)
        (xy 98.032779 133.853504)
        (xy 98.017971 133.936633)
        (xy 96.52 129.172339)
        (xy 98.015091 129.172339)
        (xy 98.050747 129.405349)
        (xy 98.12398 129.629407)
        (xy 98.12637 129.633998)
        (xy 98.186863 129.750203)
        (xy 98.232825 129.838496)
        (xy 98.235928 129.842629)
        (xy 98.23593 129.842632)
        (xy 98.371253 130.022865)
        (xy 98.374358 130.027)
        (xy 98.378096 130.030572)
        (xy 98.526603 130.172489)
        (xy 98.544777 130.189857)
        (xy 98.739508 130.322693)
        (xy 98.744192 130.324867)
        (xy 98.744195 130.324869)
        (xy 98.948628 130.419764)
        (xy 98.948633 130.419766)
        (xy 98.953319 130.421941)
        (xy 99.180468 130.484935)
        (xy 99.185605 130.485484)
        (xy 99.369563 130.505144)
        (xy 99.369571 130.505144)
        (xy 99.372898 130.5055)
        (xy 100.707757 130.5055)
        (xy 100.71033 130.505288)
        (xy 100.710341 130.505288)
        (xy 100.877779 130.491522)
        (xy 100.877785 130.491521)
        (xy 100.88293 130.491098)
        (xy 101.111551 130.433673)
        (xy 101.327723 130.339678)
        (xy 101.525641 130.21164)
        (xy 101.533196 130.204766)
        (xy 101.696167 130.056473)
        (xy 101.696168 130.056471)
        (xy 101.699989 130.052995)
        (xy 101.703188 130.048944)
        (xy 101.703192 130.04894)
        (xy 101.842883 129.872061)
        (xy 101.842885 129.872057)
        (xy 101.846085 129.868006)
        (xy 101.960005 129.661639)
        (xy 101.969794 129.633998)
        (xy 102.036965 129.444311)
        (xy 102.036966 129.444307)
        (xy 102.038691 129.439436)
        (xy 102.039599 129.43434)
        (xy 102.079123 129.212456)
        (xy 102.079124 129.21245)
        (xy 102.080029 129.207367)
        (xy 102.080457 129.172339)
        (xy 110.515091 129.172339)
        (xy 110.550747 129.405349)
        (xy 110.62398 129.629407)
        (xy 110.62637 129.633998)
        (xy 110.686863 129.750203)
        (xy 110.732825 129.838496)
        (xy 110.735928 129.842629)
        (xy 110.73593 129.842632)
        (xy 110.871253 130.022865)
        (xy 110.874358 130.027)
        (xy 110.878096 130.030572)
        (xy 111.026603 130.172489)
        (xy 111.044777 130.189857)
        (xy 111.239508 130.322693)
        (xy 111.244192 130.324867)
        (xy 111.244195 130.324869)
        (xy 111.448628 130.419764)
        (xy 111.448633 130.419766)
        (xy 111.453319 130.421941)
        (xy 111.680468 130.484935)
        (xy 111.685605 130.485484)
        (xy 111.869563 130.505144)
        (xy 111.869571 130.505144)
        (xy 111.872898 130.5055)
        (xy 113.207757 130.5055)
        (xy 113.21033 130.505288)
        (xy 113.210341 130.505288)
        (xy 113.377779 130.491522)
        (xy 113.377785 130.491521)
        (xy 113.38293 130.491098)
        (xy 113.611551 130.433673)
        (xy 113.827723 130.339678)
        (xy 114.025641 130.21164)
        (xy 114.033196 130.204766)
        (xy 114.196167 130.056473)
        (xy 114.196168 130.056471)
        (xy 114.199989 130.052995)
        (xy 114.203188 130.048944)
        (xy 114.203192 130.04894)
        (xy 114.342883 129.872061)
        (xy 114.342885 129.872057)
        (xy 114.346085 129.868006)
        (xy 114.427601 129.720339)
        (xy 125.955091 129.720339)
        (xy 125.990747 129.953349)
        (xy 126.06398 130.177407)
        (xy 126.172825 130.386496)
        (xy 126.175928 130.390629)
        (xy 126.17593 130.390632)
        (xy 126.311253 130.570865)
        (xy 126.314358 130.575)
        (xy 126.484777 130.737857)
        (xy 126.679508 130.870693)
        (xy 126.684192 130.872867)
        (xy 126.684195 130.872869)
        (xy 126.888628 130.967764)
        (xy 126.888633 130.967766)
        (xy 126.893319 130.969941)
        (xy 127.120468 131.032935)
        (xy 127.125605 131.033484)
        (xy 127.309563 131.053144)
        (xy 127.309571 131.053144)
        (xy 127.312898 131.0535)
        (xy 128.647757 131.0535)
        (xy 128.65033 131.053288)
        (xy 128.650341 131.053288)
        (xy 128.817779 131.039522)
        (xy 128.817785 131.039521)
        (xy 128.82293 131.039098)
        (xy 129.051551 130.981673)
        (xy 129.267723 130.887678)
        (xy 129.465641 130.75964)
        (xy 129.489581 130.737857)
        (xy 129.636167 130.604473)
        (xy 129.636168 130.604471)
        (xy 129.639989 130.600995)
        (xy 129.643188 130.596944)
        (xy 129.643192 130.59694)
        (xy 129.782883 130.420061)
        (xy 129.782885 130.420057)
        (xy 129.786085 130.416006)
        (xy 129.900005 130.209639)
        (xy 129.907011 130.189857)
        (xy 129.976965 129.992311)
        (xy 129.976966 129.992307)
        (xy 129.978691 129.987436)
        (xy 129.979599 129.98234)
        (xy 130.019123 129.760456)
        (xy 130.019124 129.76045)
        (xy 130.020029 129.755367)
        (xy 130.020457 129.720339)
        (xy 138.455091 129.720339)
        (xy 138.490747 129.953349)
        (xy 138.56398 130.177407)
        (xy 138.672825 130.386496)
        (xy 138.675928 130.390629)
        (xy 138.67593 130.390632)
        (xy 138.811253 130.570865)
        (xy 138.814358 130.575)
        (xy 138.984777 130.737857)
        (xy 139.179508 130.870693)
        (xy 139.184192 130.872867)
        (xy 139.184195 130.872869)
        (xy 139.388628 130.967764)
        (xy 139.388633 130.967766)
        (xy 139.393319 130.969941)
        (xy 139.620468 131.032935)
        (xy 139.625605 131.033484)
        (xy 139.809563 131.053144)
        (xy 139.809571 131.053144)
        (xy 139.812898 131.0535)
        (xy 141.147757 131.0535)
        (xy 141.15033 131.053288)
        (xy 141.150341 131.053288)
        (xy 141.317779 131.039522)
        (xy 141.317785 131.039521)
        (xy 141.32293 131.039098)
        (xy 141.551551 130.981673)
        (xy 141.767723 130.887678)
        (xy 141.965641 130.75964)
        (xy 141.989581 130.737857)
        (xy 142.136167 130.604473)
        (xy 142.136168 130.604471)
        (xy 142.139989 130.600995)
        (xy 142.143188 130.596944)
        (xy 142.143192 130.59694)
        (xy 142.282883 130.420061)
        (xy 142.282885 130.420057)
        (xy 142.286085 130.416006)
        (xy 142.400005 130.209639)
        (xy 142.407011 130.189857)
        (xy 142.476965 129.992311)
        (xy 142.476966 129.992307)
        (xy 142.478691 129.987436)
        (xy 142.479599 129.98234)
        (xy 142.519123 129.760456)
        (xy 142.519124 129.76045)
        (xy 142.520029 129.755367)
        (xy 142.522909 129.519661)
        (xy 142.487253 129.286651)
        (xy 142.41402 129.062593)
        (xy 142.364022 128.966547)
        (xy 142.307564 128.858093)
        (xy 142.307563 128.858092)
        (xy 142.305175 128.853504)
        (xy 142.286415 128.828517)
        (xy 142.166747 128.669135)
        (xy 142.166745 128.669132)
        (xy 142.163642 128.665)
        (xy 142.090022 128.594647)
        (xy 141.99696 128.505714)
        (xy 141.996959 128.505713)
        (xy 141.993223 128.502143)
        (xy 141.798492 128.369307)
        (xy 141.793808 128.367133)
        (xy 141.793805 128.367131)
        (xy 141.589372 128.272236)
        (xy 141.589367 128.272234)
        (xy 141.584681 128.270059)
        (xy 141.357532 128.207065)
        (xy 141.352395 128.206516)
        (xy 141.168437 128.186856)
        (xy 141.168429 128.186856)
        (xy 141.165102 128.1865)
        (xy 139.830243 128.1865)
        (xy 139.82767 128.186712)
        (xy 139.827659 128.186712)
        (xy 139.660221 128.200478)
        (xy 139.660215 128.200479)
        (xy 139.65507 128.200902)
        (xy 139.426449 128.258327)
        (xy 139.210277 128.352322)
        (xy 139.012359 128.48036)
        (xy 139.008536 128.483839)
        (xy 139.008533 128.483841)
        (xy 138.841833 128.635527)
        (xy 138.838011 128.639005)
        (xy 138.834812 128.643056)
        (xy 138.834808 128.64306)
        (xy 138.759315 128.738651)
        (xy 138.691915 128.823994)
        (xy 138.577995 129.030361)
        (xy 138.576271 129.03523)
        (xy 138.576269 129.035234)
        (xy 138.515314 129.207367)
        (xy 138.499309 129.252564)
        (xy 138.498402 129.257657)
        (xy 138.498401 129.25766)
        (xy 138.466022 129.439436)
        (xy 138.457971 129.484633)
        (xy 130.022909 129.519661)
        (xy 129.987253 129.286651)
        (xy 129.91402 129.062593)
        (xy 129.864022 128.966547)
        (xy 129.807564 128.858093)
        (xy 129.807563 128.858092)
        (xy 129.805175 128.853504)
        (xy 129.786415 128.828517)
        (xy 129.666747 128.669135)
        (xy 129.666745 128.669132)
        (xy 129.663642 128.665)
        (xy 129.590022 128.594647)
        (xy 129.49696 128.505714)
        (xy 129.496959 128.505713)
        (xy 129.493223 128.502143)
        (xy 129.298492 128.369307)
        (xy 129.293808 128.367133)
        (xy 129.293805 128.367131)
        (xy 129.089372 128.272236)
        (xy 129.089367 128.272234)
        (xy 129.084681 128.270059)
        (xy 128.857532 128.207065)
        (xy 128.852395 128.206516)
        (xy 128.668437 128.186856)
        (xy 128.668429 128.186856)
        (xy 128.665102 128.1865)
        (xy 127.330243 128.1865)
        (xy 127.32767 128.186712)
        (xy 127.327659 128.186712)
        (xy 127.160221 128.200478)
        (xy 127.160215 128.200479)
        (xy 127.15507 128.200902)
        (xy 126.926449 128.258327)
        (xy 126.710277 128.352322)
        (xy 126.512359 128.48036)
        (xy 126.508536 128.483839)
        (xy 126.508533 128.483841)
        (xy 126.341833 128.635527)
        (xy 126.338011 128.639005)
        (xy 126.334812 128.643056)
        (xy 126.334808 128.64306)
        (xy 126.259315 128.738651)
        (xy 126.191915 128.823994)
        (xy 126.077995 129.030361)
        (xy 126.076271 129.03523)
        (xy 126.076269 129.035234)
        (xy 126.015314 129.207367)
        (xy 125.999309 129.252564)
        (xy 125.998402 129.257657)
        (xy 125.998401 129.25766)
        (xy 125.966022 129.439436)
        (xy 125.957971 129.484633)
        (xy 114.460005 129.661639)
        (xy 114.469794 129.633998)
        (xy 114.536965 129.444311)
        (xy 114.536966 129.444307)
        (xy 114.538691 129.439436)
        (xy 114.539599 129.43434)
        (xy 114.579123 129.212456)
        (xy 114.579124 129.21245)
        (xy 114.580029 129.207367)
        (xy 114.582909 128.971661)
        (xy 114.547253 128.738651)
        (xy 114.47402 128.514593)
        (xy 114.365175 128.305504)
        (xy 114.346415 128.280517)
        (xy 114.226747 128.121135)
        (xy 114.226745 128.121132)
        (xy 114.223642 128.117)
        (xy 114.053223 127.954143)
        (xy 113.858492 127.821307)
        (xy 113.853808 127.819133)
        (xy 113.853805 127.819131)
        (xy 113.649372 127.724236)
        (xy 113.649367 127.724234)
        (xy 113.644681 127.722059)
        (xy 113.417532 127.659065)
        (xy 113.412395 127.658516)
        (xy 113.228437 127.638856)
        (xy 113.228429 127.638856)
        (xy 113.225102 127.6385)
        (xy 111.890243 127.6385)
        (xy 111.88767 127.638712)
        (xy 111.887659 127.638712)
        (xy 111.720221 127.652478)
        (xy 111.720215 127.652479)
        (xy 111.71507 127.652902)
        (xy 111.486449 127.710327)
        (xy 111.270277 127.804322)
        (xy 111.072359 127.93236)
        (xy 111.068536 127.935839)
        (xy 111.068533 127.935841)
        (xy 111.044495 127.957714)
        (xy 110.898011 128.091005)
        (xy 110.894812 128.095056)
        (xy 110.894808 128.09506)
        (xy 110.756602 128.270059)
        (xy 110.751915 128.275994)
        (xy 110.637995 128.482361)
        (xy 110.636271 128.48723)
        (xy 110.636269 128.487234)
        (xy 110.574584 128.661428)
        (xy 110.559309 128.704564)
        (xy 110.558402 128.709657)
        (xy 110.558401 128.70966)
        (xy 110.532779 128.853504)
        (xy 110.517971 128.936633)
        (xy 102.082909 128.971661)
        (xy 102.047253 128.738651)
        (xy 101.97402 128.514593)
        (xy 101.865175 128.305504)
        (xy 101.846415 128.280517)
        (xy 101.726747 128.121135)
        (xy 101.726745 128.121132)
        (xy 101.723642 128.117)
        (xy 101.553223 127.954143)
        (xy 101.358492 127.821307)
        (xy 101.353808 127.819133)
        (xy 101.353805 127.819131)
        (xy 101.149372 127.724236)
        (xy 101.149367 127.724234)
        (xy 101.144681 127.722059)
        (xy 100.917532 127.659065)
        (xy 100.912395 127.658516)
        (xy 100.728437 127.638856)
        (xy 100.728429 127.638856)
        (xy 100.725102 127.6385)
        (xy 99.390243 127.6385)
        (xy 99.38767 127.638712)
        (xy 99.387659 127.638712)
        (xy 99.220221 127.652478)
        (xy 99.220215 127.652479)
        (xy 99.21507 127.652902)
        (xy 98.986449 127.710327)
        (xy 98.770277 127.804322)
        (xy 98.572359 127.93236)
        (xy 98.568536 127.935839)
        (xy 98.568533 127.935841)
        (xy 98.544495 127.957714)
        (xy 98.398011 128.091005)
        (xy 98.394812 128.095056)
        (xy 98.394808 128.09506)
        (xy 98.256602 128.270059)
        (xy 98.251915 128.275994)
        (xy 98.137995 128.482361)
        (xy 98.136271 128.48723)
        (xy 98.136269 128.487234)
        (xy 98.074584 128.661428)
        (xy 98.059309 128.704564)
        (xy 98.058402 128.709657)
        (xy 98.058401 128.70966)
        (xy 98.032779 128.853504)
        (xy 98.017971 128.936633)
        (xy 96.52 126.492)
        (xy 121.635476 126.492)
        (xy 121.655438 126.681928)
        (xy 121.714453 126.863556)
        (xy 121.80994 127.028944)
        (xy 121.937727 127.170866)
        (xy 122.092228 127.283118)
        (xy 122.098256 127.285802)
        (xy 122.098258 127.285803)
        (xy 122.260661 127.358109)
        (xy 122.266692 127.360794)
        (xy 122.360093 127.380647)
        (xy 122.447036 127.399128)
        (xy 122.447041 127.399128)
        (xy 122.453493 127.4005)
        (xy 122.644467 127.4005)
        (xy 122.650919 127.399128)
        (xy 122.650924 127.399128)
        (xy 122.737867 127.380647)
        (xy 122.831268 127.360794)
        (xy 122.837299 127.358109)
        (xy 122.999702 127.285803)
        (xy 122.999704 127.285802)
        (xy 123.005732 127.283118)
        (xy 123.160233 127.170866)
        (xy 123.164648 127.165963)
        (xy 123.16956 127.16154)
        (xy 123.170685 127.162789)
        (xy 123.223994 127.129949)
        (xy 123.25718 127.1255)
        (xy 123.7518 127.1255)
        (xy 123.819921 127.145502)
        (xy 123.839147 127.161843)
        (xy 123.83942 127.16154)
        (xy 123.844332 127.165963)
        (xy 123.848747 127.170866)
        (xy 124.003248 127.283118)
        (xy 124.009276 127.285802)
        (xy 124.009278 127.285803)
        (xy 124.171681 127.358109)
        (xy 124.177712 127.360794)
        (xy 124.271113 127.380647)
        (xy 124.358056 127.399128)
        (xy 124.358061 127.399128)
        (xy 124.364513 127.4005)
        (xy 124.555487 127.4005)
        (xy 124.561939 127.399128)
        (xy 124.561944 127.399128)
        (xy 124.648887 127.380647)
        (xy 124.742288 127.360794)
        (xy 124.748319 127.358109)
        (xy 124.910722 127.285803)
        (xy 124.910724 127.285802)
        (xy 124.916752 127.283118)
        (xy 125.071253 127.170866)
        (xy 125.19904 127.028944)
        (xy 125.294527 126.863556)
        (xy 125.353542 126.681928)
        (xy 125.373504 126.492)
        (xy 125.353542 126.302072)
        (xy 125.332724 126.238)
        (xy 143.612496 126.238)
        (xy 143.632458 126.427928)
        (xy 143.691473 126.609556)
        (xy 143.78696 126.774944)
        (xy 143.791378 126.779851)
        (xy 143.791379 126.779852)
        (xy 143.873899 126.8715)
        (xy 143.914747 126.916866)
        (xy 144.069248 127.029118)
        (xy 144.075276 127.031802)
        (xy 144.075278 127.031803)
        (xy 144.237681 127.104109)
        (xy 144.243712 127.106794)
        (xy 144.331716 127.1255)
        (xy 144.424056 127.145128)
        (xy 144.424061 127.145128)
        (xy 144.430513 127.1465)
        (xy 144.621487 127.1465)
        (xy 144.627939 127.145128)
        (xy 144.627944 127.145128)
        (xy 144.720284 127.1255)
        (xy 144.808288 127.106794)
        (xy 144.814319 127.104109)
        (xy 144.976722 127.031803)
        (xy 144.976724 127.031802)
        (xy 144.982752 127.029118)
        (xy 145.137253 126.916866)
        (xy 145.141668 126.911963)
        (xy 145.14658 126.90754)
        (xy 145.147705 126.908789)
        (xy 145.201014 126.875949)
        (xy 145.2342 126.8715)
        (xy 146.3578 126.8715)
        (xy 146.425921 126.891502)
        (xy 146.445147 126.907843)
        (xy 146.44542 126.90754)
        (xy 146.450332 126.911963)
        (xy 146.454747 126.916866)
        (xy 146.609248 127.029118)
        (xy 146.615276 127.031802)
        (xy 146.615278 127.031803)
        (xy 146.777681 127.104109)
        (xy 146.783712 127.106794)
        (xy 146.871716 127.1255)
        (xy 146.964056 127.145128)
        (xy 146.964061 127.145128)
        (xy 146.970513 127.1465)
        (xy 147.161487 127.1465)
        (xy 147.167939 127.145128)
        (xy 147.167944 127.145128)
        (xy 147.260284 127.1255)
        (xy 147.348288 127.106794)
        (xy 147.354319 127.104109)
        (xy 147.516722 127.031803)
        (xy 147.516724 127.031802)
        (xy 147.522752 127.029118)
        (xy 147.677253 126.916866)
        (xy 147.718101 126.8715)
        (xy 147.800621 126.779852)
        (xy 147.800622 126.779851)
        (xy 147.80504 126.774944)
        (xy 147.900527 126.609556)
        (xy 147.959542 126.427928)
        (xy 147.979504 126.238)
        (xy 147.959542 126.048072)
        (xy 147.900527 125.866444)
        (xy 147.80504 125.701056)
        (xy 147.677253 125.559134)
        (xy 147.522752 125.446882)
        (xy 147.516724 125.444198)
        (xy 147.516722 125.444197)
        (xy 147.354319 125.371891)
        (xy 147.354318 125.371891)
        (xy 147.348288 125.369206)
        (xy 147.254887 125.349353)
        (xy 147.167944 125.330872)
        (xy 147.167939 125.330872)
        (xy 147.161487 125.3295)
        (xy 146.970513 125.3295)
        (xy 146.964061 125.330872)
        (xy 146.964056 125.330872)
        (xy 146.877113 125.349353)
        (xy 146.783712 125.369206)
        (xy 146.777682 125.371891)
        (xy 146.777681 125.371891)
        (xy 146.615278 125.444197)
        (xy 146.615276 125.444198)
        (xy 146.609248 125.446882)
        (xy 146.454747 125.559134)
        (xy 146.450332 125.564037)
        (xy 146.44542 125.56846)
        (xy 146.444295 125.567211)
        (xy 146.390986 125.600051)
        (xy 146.3578 125.6045)
        (xy 145.2342 125.6045)
        (xy 145.166079 125.584498)
        (xy 145.146853 125.568157)
        (xy 145.14658 125.56846)
        (xy 145.141668 125.564037)
        (xy 145.137253 125.559134)
        (xy 144.982752 125.446882)
        (xy 144.976724 125.444198)
        (xy 144.976722 125.444197)
        (xy 144.814319 125.371891)
        (xy 144.814318 125.371891)
        (xy 144.808288 125.369206)
        (xy 144.714887 125.349353)
        (xy 144.627944 125.330872)
        (xy 144.627939 125.330872)
        (xy 144.621487 125.3295)
        (xy 144.430513 125.3295)
        (xy 144.424061 125.330872)
        (xy 144.424056 125.330872)
        (xy 144.337113 125.349353)
        (xy 144.243712 125.369206)
        (xy 144.237682 125.371891)
        (xy 144.237681 125.371891)
        (xy 144.075278 125.444197)
        (xy 144.075276 125.444198)
        (xy 144.069248 125.446882)
        (xy 143.914747 125.559134)
        (xy 143.78696 125.701056)
        (xy 143.691473 125.866444)
        (xy 143.632458 126.048072)
        (xy 125.294527 126.120444)
        (xy 125.19904 125.955056)
        (xy 125.119254 125.866444)
        (xy 125.075675 125.818045)
        (xy 125.075674 125.818044)
        (xy 125.071253 125.813134)
        (xy 124.916752 125.700882)
        (xy 124.910724 125.698198)
        (xy 124.910722 125.698197)
        (xy 124.748319 125.625891)
        (xy 124.748318 125.625891)
        (xy 124.742288 125.623206)
        (xy 124.633353 125.600051)
        (xy 124.561944 125.584872)
        (xy 124.561939 125.584872)
        (xy 124.555487 125.5835)
        (xy 124.364513 125.5835)
        (xy 124.358061 125.584872)
        (xy 124.358056 125.584872)
        (xy 124.286647 125.600051)
        (xy 124.177712 125.623206)
        (xy 124.171682 125.625891)
        (xy 124.171681 125.625891)
        (xy 124.009278 125.698197)
        (xy 124.009276 125.698198)
        (xy 124.003248 125.700882)
        (xy 123.848747 125.813134)
        (xy 123.844332 125.818037)
        (xy 123.83942 125.82246)
        (xy 123.838295 125.821211)
        (xy 123.784986 125.854051)
        (xy 123.7518 125.8585)
        (xy 123.25718 125.8585)
        (xy 123.189059 125.838498)
        (xy 123.169833 125.822157)
        (xy 123.16956 125.82246)
        (xy 123.164648 125.818037)
        (xy 123.160233 125.813134)
        (xy 123.005732 125.700882)
        (xy 122.999704 125.698198)
        (xy 122.999702 125.698197)
        (xy 122.837299 125.625891)
        (xy 122.837298 125.625891)
        (xy 122.831268 125.623206)
        (xy 122.722333 125.600051)
        (xy 122.650924 125.584872)
        (xy 122.650919 125.584872)
        (xy 122.644467 125.5835)
        (xy 122.453493 125.5835)
        (xy 122.447041 125.584872)
        (xy 122.447036 125.584872)
        (xy 122.375627 125.600051)
        (xy 122.266692 125.623206)
        (xy 122.260662 125.625891)
        (xy 122.260661 125.625891)
        (xy 122.098258 125.698197)
        (xy 122.098256 125.698198)
        (xy 122.092228 125.700882)
        (xy 121.937727 125.813134)
        (xy 121.933306 125.818044)
        (xy 121.933305 125.818045)
        (xy 121.889727 125.866444)
        (xy 121.80994 125.955056)
        (xy 121.714453 126.120444)
        (xy 121.655438 126.302072)
        (xy 96.52 126.492)
        (xy 96.52 120.383033)
        (xy 98.266193 120.383033)
        (xy 98.266343 120.386214)
        (xy 98.282745 120.73403)
        (xy 98.283899 120.758504)
        (xy 98.284371 120.761661)
        (xy 98.284371 120.761663)
        (xy 98.286897 120.778567)
        (xy 98.339459 121.130263)
        (xy 98.340245 121.133345)
        (xy 98.340245 121.133347)
        (xy 98.42769 121.476406)
        (xy 98.432303 121.494505)
        (xy 98.561481 121.8475)
        (xy 98.72567 122.185633)
        (xy 98.850575 122.387872)
        (xy 98.902081 122.471267)
        (xy 98.923188 122.505443)
        (xy 98.925129 122.507973)
        (xy 98.92513 122.507974)
        (xy 99.093736 122.727704)
        (xy 99.152015 122.803655)
        (xy 99.409806 123.077217)
        (xy 99.412211 123.079301)
        (xy 99.412217 123.079306)
        (xy 99.663395 123.296883)
        (xy 99.693922 123.323326)
        (xy 100.001455 123.539464)
        (xy 100.329256 123.723417)
        (xy 100.33217 123.724684)
        (xy 100.332174 123.724686)
        (xy 100.473491 123.786132)
        (xy 100.673968 123.873302)
        (xy 101.032062 123.987585)
        (xy 101.035195 123.988245)
        (xy 101.035198 123.988246)
        (xy 101.396745 124.064435)
        (xy 101.396748 124.064435)
        (xy 101.399873 124.065094)
        (xy 101.773633 124.105038)
        (xy 101.77682 124.105055)
        (xy 101.776826 124.105055)
        (xy 101.947357 124.105948)
        (xy 102.149516 124.107006)
        (xy 102.250492 124.097283)
        (xy 102.52049 124.071286)
        (xy 102.520498 124.071285)
        (xy 102.523674 124.070979)
        (xy 102.892275 123.997325)
        (xy 102.895311 123.996391)
        (xy 102.895319 123.996389)
        (xy 103.248505 123.887734)
        (xy 103.248508 123.887733)
        (xy 103.251547 123.886798)
        (xy 103.254475 123.885561)
        (xy 103.254481 123.885559)
        (xy 103.410096 123.819824)
        (xy 103.59781 123.740531)
        (xy 103.600613 123.738996)
        (xy 103.600618 123.738994)
        (xy 103.742369 123.661388)
        (xy 103.927519 123.560021)
        (xy 104.237298 123.347115)
        (xy 104.239737 123.345047)
        (xy 104.239743 123.345042)
        (xy 104.521536 123.106065)
        (xy 104.521544 123.106057)
        (xy 104.523976 123.103995)
        (xy 104.526184 123.1017)
        (xy 104.526192 123.101693)
        (xy 104.782403 122.83545)
        (xy 104.782405 122.835447)
        (xy 104.784618 122.833148)
        (xy 104.873446 122.719861)
        (xy 105.01458 122.539866)
        (xy 105.014583 122.539861)
        (xy 105.016554 122.537348)
        (xy 105.217411 122.219624)
        (xy 105.385132 121.883229)
        (xy 105.493587 121.59621)
        (xy 105.516875 121.534581)
        (xy 105.516876 121.534578)
        (xy 105.517999 121.531606)
        (xy 105.614652 121.168357)
        (xy 105.622756 121.117766)
        (xy 105.659133 120.890652)
        (xy 105.674102 120.797199)
        (xy 105.674705 120.786753)
        (xy 105.690313 120.516033)
        (xy 105.695739 120.421934)
        (xy 105.69583 120.396)
        (xy 105.695745 120.394317)
        (xy 105.676974 120.023766)
        (xy 105.676973 120.023761)
        (xy 105.676813 120.020593)
        (xy 105.63596 119.753615)
        (xy 105.62044 119.65219)
        (xy 105.620438 119.652181)
        (xy 105.619956 119.64903)
        (xy 105.553405 119.391695)
        (xy 127.791251 119.391695)
        (xy 127.791548 119.396848)
        (xy 127.791548 119.396851)
        (xy 127.797011 119.49159)
        (xy 127.80411 119.614715)
        (xy 127.805247 119.619761)
        (xy 127.805248 119.619767)
        (xy 127.811147 119.645941)
        (xy 127.853222 119.832639)
        (xy 127.891461 119.926811)
        (xy 127.929542 120.020593)
        (xy 127.937266 120.039616)
        (xy 127.988019 120.122438)
        (xy 128.051291 120.225688)
        (xy 128.053987 120.230088)
        (xy 128.20025 120.398938)
        (xy 128.264644 120.452399)
        (xy 128.270344 120.457131)
        (xy 128.309979 120.516033)
        (xy 128.311477 120.587014)
        (xy 128.274363 120.647537)
        (xy 128.243312 120.668175)
        (xy 128.236996 120.671134)
        (xy 128.230054 120.67345)
        (xy 128.079652 120.766522)
        (xy 127.954695 120.891697)
        (xy 127.950855 120.897927)
        (xy 127.950854 120.897928)
        (xy 127.866466 121.034831)
        (xy 127.861885 121.042262)
        (xy 127.806203 121.210139)
        (xy 127.7955 121.3146)
        (xy 127.7955 122.6154)
        (xy 127.795837 122.618646)
        (xy 127.795837 122.61865)
        (xy 127.800961 122.668028)
        (xy 127.806474 122.721166)
        (xy 127.808655 122.727702)
        (xy 127.808655 122.727704)
        (xy 127.852728 122.859806)
        (xy 127.86245 122.888946)
        (xy 127.955522 123.039348)
        (xy 128.080697 123.164305)
        (xy 128.086927 123.168145)
        (xy 128.086928 123.168146)
        (xy 128.22409 123.252694)
        (xy 128.231262 123.257115)
        (xy 128.283915 123.274579)
        (xy 128.392611 123.310632)
        (xy 128.392613 123.310632)
        (xy 128.399139 123.312797)
        (xy 128.405975 123.313497)
        (xy 128.405978 123.313498)
        (xy 128.440531 123.317038)
        (xy 128.5036 123.3235)
        (xy 129.8044 123.3235)
        (xy 129.807646 123.323163)
        (xy 129.80765 123.323163)
        (xy 129.903308 123.313238)
        (xy 129.903312 123.313237)
        (xy 129.910166 123.312526)
        (xy 129.916702 123.310345)
        (xy 129.916704 123.310345)
        (xy 130.048806 123.266272)
        (xy 130.077946 123.25655)
        (xy 130.228348 123.163478)
        (xy 130.353305 123.038303)
        (xy 130.446115 122.887738)
        (xy 130.448418 122.880795)
        (xy 130.450763 122.875766)
        (xy 130.49768 122.822481)
        (xy 130.565958 122.803021)
        (xy 130.633918 122.823564)
        (xy 130.660194 122.84652)
        (xy 130.73686 122.935025)
        (xy 130.74025 122.938938)
        (xy 130.912126 123.081632)
        (xy 131.105 123.194338)
        (xy 131.313692 123.27403)
        (xy 131.31876 123.275061)
        (xy 131.318763 123.275062)
        (xy 131.423604 123.296392)
        (xy 131.532597 123.318567)
        (xy 131.537772 123.318757)
        (xy 131.537774 123.318757)
        (xy 131.750673 123.326564)
        (xy 131.750677 123.326564)
        (xy 131.755837 123.326753)
        (xy 131.760957 123.326097)
        (xy 131.760959 123.326097)
        (xy 131.972288 123.299025)
        (xy 131.972289 123.299025)
        (xy 131.977416 123.298368)
        (xy 131.982366 123.296883)
        (xy 132.186429 123.235661)
        (xy 132.186434 123.235659)
        (xy 132.191384 123.234174)
        (xy 132.391994 123.135896)
        (xy 132.57386 123.006173)
        (xy 132.57914 123.000912)
        (xy 132.680459 122.899946)
        (xy 132.732096 122.848489)
        (xy 132.741466 122.83545)
        (xy 132.862453 122.667077)
        (xy 132.863776 122.668028)
        (xy 132.910645 122.624857)
        (xy 132.98058 122.612625)
        (xy 133.046026 122.640144)
        (xy 133.073875 122.671994)
        (xy 133.133987 122.770088)
        (xy 133.28025 122.938938)
        (xy 133.452126 123.081632)
        (xy 133.645 123.194338)
        (xy 133.853692 123.27403)
        (xy 133.85876 123.275061)
        (xy 133.858763 123.275062)
        (xy 133.963604 123.296392)
        (xy 134.072597 123.318567)
        (xy 134.077772 123.318757)
        (xy 134.077774 123.318757)
        (xy 134.290673 123.326564)
        (xy 134.290677 123.326564)
        (xy 134.295837 123.326753)
        (xy 134.300957 123.326097)
        (xy 134.300959 123.326097)
        (xy 134.512288 123.299025)
        (xy 134.512289 123.299025)
        (xy 134.517416 123.298368)
        (xy 134.522366 123.296883)
        (xy 134.726429 123.235661)
        (xy 134.726434 123.235659)
        (xy 134.731384 123.234174)
        (xy 134.931994 123.135896)
        (xy 135.11386 123.006173)
        (xy 135.11914 123.000912)
        (xy 135.220459 122.899946)
        (xy 135.272096 122.848489)
        (xy 135.281466 122.83545)
        (xy 135.402453 122.667077)
        (xy 135.403776 122.668028)
        (xy 135.450645 122.624857)
        (xy 135.52058 122.612625)
        (xy 135.586026 122.640144)
        (xy 135.613875 122.671994)
        (xy 135.673987 122.770088)
        (xy 135.82025 122.938938)
        (xy 135.992126 123.081632)
        (xy 136.185 123.194338)
        (xy 136.393692 123.27403)
        (xy 136.39876 123.275061)
        (xy 136.398763 123.275062)
        (xy 136.503604 123.296392)
        (xy 136.612597 123.318567)
        (xy 136.617772 123.318757)
        (xy 136.617774 123.318757)
        (xy 136.830673 123.326564)
        (xy 136.830677 123.326564)
        (xy 136.835837 123.326753)
        (xy 136.840957 123.326097)
        (xy 136.840959 123.326097)
        (xy 137.052288 123.299025)
        (xy 137.052289 123.299025)
        (xy 137.057416 123.298368)
        (xy 137.062366 123.296883)
        (xy 137.266429 123.235661)
        (xy 137.266434 123.235659)
        (xy 137.271384 123.234174)
        (xy 137.471994 123.135896)
        (xy 137.536544 123.089853)
        (xy 138.553977 123.089853)
        (xy 138.559258 123.096907)
        (xy 138.720756 123.191279)
        (xy 138.730042 123.195729)
        (xy 138.929001 123.271703)
        (xy 138.938899 123.274579)
        (xy 139.147595 123.317038)
        (xy 139.157823 123.318257)
        (xy 139.37065 123.326062)
        (xy 139.380936 123.325595)
        (xy 139.592185 123.298534)
        (xy 139.602262 123.296392)
        (xy 139.806255 123.235191)
        (xy 139.815842 123.231433)
        (xy 140.007098 123.137738)
        (xy 140.015944 123.132465)
        (xy 140.063247 123.098723)
        (xy 140.071648 123.088023)
        (xy 140.06466 123.07487)
        (xy 139.326812 122.337022)
        (xy 139.312868 122.329408)
        (xy 139.311035 122.329539)
        (xy 139.30442 122.33379)
        (xy 138.560737 123.077473)
        (xy 137.65386 123.006173)
        (xy 137.65914 123.000912)
        (xy 137.760459 122.899946)
        (xy 137.812096 122.848489)
        (xy 137.821466 122.83545)
        (xy 137.942453 122.667077)
        (xy 137.94364 122.66793)
        (xy 137.99096 122.624362)
        (xy 138.060897 122.612145)
        (xy 138.126338 122.639678)
        (xy 138.154166 122.671512)
        (xy 138.180459 122.714419)
        (xy 138.190916 122.72388)
        (xy 138.199694 122.720096)
        (xy 138.941978 121.977812)
        (xy 138.948356 121.966132)
        (xy 139.678408 121.966132)
        (xy 139.678539 121.967965)
        (xy 139.68279 121.97458)
        (xy 140.424474 122.716264)
        (xy 140.436484 122.722823)
        (xy 140.448223 122.713855)
        (xy 140.479004 122.671019)
        (xy 140.484315 122.66218)
        (xy 140.57867 122.471267)
        (xy 140.582469 122.461672)
        (xy 140.644376 122.257915)
        (xy 140.646555 122.247834)
        (xy 140.67459 122.034887)
        (xy 140.675109 122.028212)
        (xy 140.676572 121.968364)
        (xy 140.676378 121.961646)
        (xy 140.658781 121.747604)
        (xy 140.657096 121.737424)
        (xy 140.605214 121.530875)
        (xy 140.601894 121.521124)
        (xy 140.516972 121.325814)
        (xy 140.512105 121.316739)
        (xy 140.447063 121.216197)
        (xy 140.436377 121.206995)
        (xy 140.426812 121.211398)
        (xy 139.686022 121.952188)
        (xy 138.949592 121.963868)
        (xy 138.949461 121.962035)
        (xy 138.94521 121.95542)
        (xy 138.203849 121.214059)
        (xy 138.192313 121.207759)
        (xy 138.180031 121.217382)
        (xy 138.147499 121.265072)
        (xy 138.092587 121.310075)
        (xy 138.022063 121.318246)
        (xy 137.958316 121.286992)
        (xy 137.937618 121.262508)
        (xy 137.856822 121.137617)
        (xy 137.85682 121.137614)
        (xy 137.854014 121.133277)
        (xy 137.70367 120.968051)
        (xy 137.699619 120.964852)
        (xy 137.699615 120.964848)
        (xy 137.532414 120.8328)
        (xy 137.53241 120.832798)
        (xy 137.528359 120.829598)
        (xy 137.487053 120.806796)
        (xy 137.437084 120.756364)
        (xy 137.422312 120.686921)
        (xy 137.447428 120.620516)
        (xy 137.47478 120.593909)
        (xy 137.529363 120.554975)
        (xy 137.65386 120.466173)
        (xy 137.812096 120.308489)
        (xy 137.871594 120.225689)
        (xy 137.942453 120.127077)
        (xy 137.943776 120.128028)
        (xy 137.990645 120.084857)
        (xy 138.06058 120.072625)
        (xy 138.126026 120.100144)
        (xy 138.153875 120.131994)
        (xy 138.213987 120.230088)
        (xy 138.36025 120.398938)
        (xy 138.532126 120.541632)
        (xy 138.55496 120.554975)
        (xy 138.605955 120.584774)
        (xy 138.654679 120.636412)
        (xy 138.66775 120.706195)
        (xy 138.641019 120.771967)
        (xy 138.600562 120.805327)
        (xy 138.59246 120.809544)
        (xy 138.583734 120.815039)
        (xy 138.563677 120.830099)
        (xy 138.555223 120.841427)
        (xy 138.561968 120.853758)
        (xy 139.301188 121.592978)
        (xy 139.315132 121.600592)
        (xy 139.316965 121.600461)
        (xy 139.32358 121.59621)
        (xy 140.067389 120.852401)
        (xy 140.07441 120.839544)
        (xy 140.067611 120.830213)
        (xy 140.063559 120.827521)
        (xy 140.026602 120.80712)
        (xy 139.976631 120.756687)
        (xy 139.961859 120.687245)
        (xy 139.986975 120.620839)
        (xy 140.014327 120.594232)
        (xy 140.069363 120.554975)
        (xy 140.19386 120.466173)
        (xy 140.277291 120.383033)
        (xy 163.036193 120.383033)
        (xy 163.036343 120.386214)
        (xy 163.052745 120.73403)
        (xy 163.053899 120.758504)
        (xy 163.054371 120.761661)
        (xy 163.054371 120.761663)
        (xy 163.056897 120.778567)
        (xy 163.109459 121.130263)
        (xy 163.110245 121.133345)
        (xy 163.110245 121.133347)
        (xy 163.19769 121.476406)
        (xy 163.202303 121.494505)
        (xy 163.331481 121.8475)
        (xy 163.49567 122.185633)
        (xy 163.620575 122.387872)
        (xy 163.672081 122.471267)
        (xy 163.693188 122.505443)
        (xy 163.695129 122.507973)
        (xy 163.69513 122.507974)
        (xy 163.863736 122.727704)
        (xy 163.922015 122.803655)
        (xy 164.179806 123.077217)
        (xy 164.182211 123.079301)
        (xy 164.182217 123.079306)
        (xy 164.433395 123.296883)
        (xy 164.463922 123.323326)
        (xy 164.771455 123.539464)
        (xy 165.099256 123.723417)
        (xy 165.10217 123.724684)
        (xy 165.102174 123.724686)
        (xy 165.243491 123.786132)
        (xy 165.443968 123.873302)
        (xy 165.802062 123.987585)
        (xy 165.805195 123.988245)
        (xy 165.805198 123.988246)
        (xy 166.166745 124.064435)
        (xy 166.166748 124.064435)
        (xy 166.169873 124.065094)
        (xy 166.543633 124.105038)
        (xy 166.54682 124.105055)
        (xy 166.546826 124.105055)
        (xy 166.717357 124.105948)
        (xy 166.919516 124.107006)
        (xy 167.020492 124.097283)
        (xy 167.29049 124.071286)
        (xy 167.290498 124.071285)
        (xy 167.293674 124.070979)
        (xy 167.662275 123.997325)
        (xy 167.665311 123.996391)
        (xy 167.665319 123.996389)
        (xy 168.018505 123.887734)
        (xy 168.018508 123.887733)
        (xy 168.021547 123.886798)
        (xy 168.024475 123.885561)
        (xy 168.024481 123.885559)
        (xy 168.180096 123.819824)
        (xy 168.36781 123.740531)
        (xy 168.370613 123.738996)
        (xy 168.370618 123.738994)
        (xy 168.512369 123.661388)
        (xy 168.697519 123.560021)
        (xy 169.007298 123.347115)
        (xy 169.009737 123.345047)
        (xy 169.009743 123.345042)
        (xy 169.291536 123.106065)
        (xy 169.291544 123.106057)
        (xy 169.293976 123.103995)
        (xy 169.296184 123.1017)
        (xy 169.296192 123.101693)
        (xy 169.552403 122.83545)
        (xy 169.552405 122.835447)
        (xy 169.554618 122.833148)
        (xy 169.643446 122.719861)
        (xy 169.78458 122.539866)
        (xy 169.784583 122.539861)
        (xy 169.786554 122.537348)
        (xy 169.987411 122.219624)
        (xy 170.155132 121.883229)
        (xy 170.263587 121.59621)
        (xy 170.286875 121.534581)
        (xy 170.286876 121.534578)
        (xy 170.287999 121.531606)
        (xy 170.384652 121.168357)
        (xy 170.392756 121.117766)
        (xy 170.429133 120.890652)
        (xy 170.444102 120.797199)
        (xy 170.444705 120.786753)
        (xy 170.460313 120.516033)
        (xy 170.465739 120.421934)
        (xy 170.46583 120.396)
        (xy 170.465745 120.394317)
        (xy 170.446974 120.023766)
        (xy 170.446973 120.023761)
        (xy 170.446813 120.020593)
        (xy 170.40596 119.753615)
        (xy 170.39044 119.65219)
        (xy 170.390438 119.652181)
        (xy 170.389956 119.64903)
        (xy 170.323405 119.391695)
        (xy 170.296638 119.288194)
        (xy 170.296635 119.288186)
        (xy 170.295841 119.285114)
        (xy 170.292408 119.275833)
        (xy 170.166541 118.93557)
        (xy 170.166538 118.935564)
        (xy 170.165432 118.932573)
        (xy 170.000064 118.595015)
        (xy 169.996605 118.589457)
        (xy 169.803116 118.278605)
        (xy 169.80143 118.275896)
        (xy 169.720162 118.170747)
        (xy 169.573516 117.981009)
        (xy 169.573511 117.981004)
        (xy 169.571564 117.978484)
        (xy 169.312819 117.705825)
        (xy 169.027846 117.460708)
        (xy 169.019448 117.454849)
        (xy 168.722173 117.247468)
        (xy 168.71956 117.245645)
        (xy 168.391119 117.062838)
        (xy 168.388199 117.06158)
        (xy 168.388194 117.061578)
        (xy 168.04882 116.91542)
        (xy 168.04881 116.915416)
        (xy 168.045886 116.914157)
        (xy 167.687395 116.801125)
        (xy 167.423121 116.746397)
        (xy 167.322441 116.725547)
        (xy 167.322438 116.725547)
        (xy 167.319316 116.7249)
        (xy 167.032755 116.695286)
        (xy 166.948575 116.686587)
        (xy 166.948572 116.686587)
        (xy 166.945419 116.686261)
        (xy 166.942253 116.686255)
        (xy 166.942244 116.686255)
        (xy 166.756771 116.685932)
        (xy 166.569531 116.685605)
        (xy 166.421122 116.700418)
        (xy 166.198675 116.722621)
        (xy 166.198669 116.722622)
        (xy 166.195502 116.722938)
        (xy 166.0043 116.761838)
        (xy 165.830284 116.797242)
        (xy 165.83028 116.797243)
        (xy 165.827159 116.797878)
        (xy 165.824117 116.798825)
        (xy 165.824111 116.798827)
        (xy 165.647718 116.853768)
        (xy 165.468276 116.909658)
        (xy 165.465336 116.910912)
        (xy 165.125463 117.05588)
        (xy 165.125459 117.055882)
        (xy 165.122526 117.057133)
        (xy 165.119739 117.058672)
        (xy 165.119738 117.058672)
        (xy 164.957988 117.147963)
        (xy 164.793449 117.238793)
        (xy 164.790828 117.240608)
        (xy 164.790823 117.240611)
        (xy 164.487038 117.450962)
        (xy 164.484414 117.452779)
        (xy 164.198587 117.696899)
        (xy 164.19639 117.699198)
        (xy 164.196389 117.699199)
        (xy 163.941097 117.966346)
        (xy 163.941092 117.966352)
        (xy 163.938892 117.968654)
        (xy 163.707989 118.265261)
        (xy 163.706289 118.267971)
        (xy 163.704071 118.271507)
        (xy 163.508243 118.583684)
        (xy 163.506829 118.586545)
        (xy 163.492743 118.615046)
        (xy 163.341698 118.920663)
        (xy 163.210059 119.272747)
        (xy 163.209251 119.275826)
        (xy 163.209249 119.275833)
        (xy 163.1802 119.386562)
        (xy 163.114674 119.636332)
        (xy 163.11418 119.639487)
        (xy 163.083184 119.837425)
        (xy 163.05652 120.007695)
        (xy 163.056349 120.010857)
        (xy 163.056348 120.010864)
        (xy 163.040457 120.304292)
        (xy 163.037018 120.367799)
        (xy 140.352096 120.308489)
        (xy 140.411594 120.225689)
        (xy 140.479435 120.131277)
        (xy 140.482453 120.127077)
        (xy 140.50332 120.084857)
        (xy 140.579136 119.931453)
        (xy 140.579137 119.931451)
        (xy 140.58143 119.926811)
        (xy 140.64637 119.713069)
        (xy 140.675529 119.49159)
        (xy 140.677156 119.425)
        (xy 140.658852 119.202361)
        (xy 140.604431 118.985702)
        (xy 140.515354 118.78084)
        (xy 140.394014 118.593277)
        (xy 140.24367 118.428051)
        (xy 140.239619 118.424852)
        (xy 140.239615 118.424848)
        (xy 140.072414 118.2928)
        (xy 140.07241 118.292798)
        (xy 140.068359 118.289598)
        (xy 139.872789 118.181638)
        (xy 139.86792 118.179914)
        (xy 139.867916 118.179912)
        (xy 139.667087 118.108795)
        (xy 139.667083 118.108794)
        (xy 139.662212 118.107069)
        (xy 139.657119 118.106162)
        (xy 139.657116 118.106161)
        (xy 139.447373 118.0688)
        (xy 139.447367 118.068799)
        (xy 139.442284 118.067894)
        (xy 139.368452 118.066992)
        (xy 139.224081 118.065228)
        (xy 139.224079 118.065228)
        (xy 139.218911 118.065165)
        (xy 138.998091 118.098955)
        (xy 138.785756 118.168357)
        (xy 138.755443 118.184137)
        (xy 138.5944 118.267971)
        (xy 138.587607 118.271507)
        (xy 138.583474 118.27461)
        (xy 138.583471 118.274612)
        (xy 138.559247 118.2928)
        (xy 138.408965 118.405635)
        (xy 138.254629 118.567138)
        (xy 138.147201 118.724621)
        (xy 138.092293 118.769621)
        (xy 138.021768 118.777792)
        (xy 137.958021 118.746538)
        (xy 137.937324 118.722054)
        (xy 137.856822 118.597617)
        (xy 137.85682 118.597614)
        (xy 137.854014 118.593277)
        (xy 137.70367 118.428051)
        (xy 137.699619 118.424852)
        (xy 137.699615 118.424848)
        (xy 137.532414 118.2928)
        (xy 137.53241 118.292798)
        (xy 137.528359 118.289598)
        (xy 137.332789 118.181638)
        (xy 137.32792 118.179914)
        (xy 137.327916 118.179912)
        (xy 137.127087 118.108795)
        (xy 137.127083 118.108794)
        (xy 137.122212 118.107069)
        (xy 137.117119 118.106162)
        (xy 137.117116 118.106161)
        (xy 136.907373 118.0688)
        (xy 136.907367 118.068799)
        (xy 136.902284 118.067894)
        (xy 136.828452 118.066992)
        (xy 136.684081 118.065228)
        (xy 136.684079 118.065228)
        (xy 136.678911 118.065165)
        (xy 136.458091 118.098955)
        (xy 136.245756 118.168357)
        (xy 136.215443 118.184137)
        (xy 136.0544 118.267971)
        (xy 136.047607 118.271507)
        (xy 136.043474 118.27461)
        (xy 136.043471 118.274612)
        (xy 136.019247 118.2928)
        (xy 135.868965 118.405635)
        (xy 135.714629 118.567138)
        (xy 135.607201 118.724621)
        (xy 135.552293 118.769621)
        (xy 135.481768 118.777792)
        (xy 135.418021 118.746538)
        (xy 135.397324 118.722054)
        (xy 135.316822 118.597617)
        (xy 135.31682 118.597614)
        (xy 135.314014 118.593277)
        (xy 135.16367 118.428051)
        (xy 135.159619 118.424852)
        (xy 135.159615 118.424848)
        (xy 134.992414 118.2928)
        (xy 134.99241 118.292798)
        (xy 134.988359 118.289598)
        (xy 134.792789 118.181638)
        (xy 134.78792 118.179914)
        (xy 134.787916 118.179912)
        (xy 134.587087 118.108795)
        (xy 134.587083 118.108794)
        (xy 134.582212 118.107069)
        (xy 134.577119 118.106162)
        (xy 134.577116 118.106161)
        (xy 134.367373 118.0688)
        (xy 134.367367 118.068799)
        (xy 134.362284 118.067894)
        (xy 134.288452 118.066992)
        (xy 134.144081 118.065228)
        (xy 134.144079 118.065228)
        (xy 134.138911 118.065165)
        (xy 133.918091 118.098955)
        (xy 133.705756 118.168357)
        (xy 133.675443 118.184137)
        (xy 133.5144 118.267971)
        (xy 133.507607 118.271507)
        (xy 133.503474 118.27461)
        (xy 133.503471 118.274612)
        (xy 133.479247 118.2928)
        (xy 133.328965 118.405635)
        (xy 133.174629 118.567138)
        (xy 133.067201 118.724621)
        (xy 133.012293 118.769621)
        (xy 132.941768 118.777792)
        (xy 132.878021 118.746538)
        (xy 132.857324 118.722054)
        (xy 132.776822 118.597617)
        (xy 132.77682 118.597614)
        (xy 132.774014 118.593277)
        (xy 132.62367 118.428051)
        (xy 132.619619 118.424852)
        (xy 132.619615 118.424848)
        (xy 132.452414 118.2928)
        (xy 132.45241 118.292798)
        (xy 132.448359 118.289598)
        (xy 132.252789 118.181638)
        (xy 132.24792 118.179914)
        (xy 132.247916 118.179912)
        (xy 132.047087 118.108795)
        (xy 132.047083 118.108794)
        (xy 132.042212 118.107069)
        (xy 132.037119 118.106162)
        (xy 132.037116 118.106161)
        (xy 131.827373 118.0688)
        (xy 131.827367 118.068799)
        (xy 131.822284 118.067894)
        (xy 131.748452 118.066992)
        (xy 131.604081 118.065228)
        (xy 131.604079 118.065228)
        (xy 131.598911 118.065165)
        (xy 131.378091 118.098955)
        (xy 131.165756 118.168357)
        (xy 131.135443 118.184137)
        (xy 130.9744 118.267971)
        (xy 130.967607 118.271507)
        (xy 130.963474 118.27461)
        (xy 130.963471 118.274612)
        (xy 130.939247 118.2928)
        (xy 130.788965 118.405635)
        (xy 130.634629 118.567138)
        (xy 130.527201 118.724621)
        (xy 130.472293 118.769621)
        (xy 130.401768 118.777792)
        (xy 130.338021 118.746538)
        (xy 130.317324 118.722054)
        (xy 130.236822 118.597617)
        (xy 130.23682 118.597614)
        (xy 130.234014 118.593277)
        (xy 130.08367 118.428051)
        (xy 130.079619 118.424852)
        (xy 130.079615 118.424848)
        (xy 129.912414 118.2928)
        (xy 129.91241 118.292798)
        (xy 129.908359 118.289598)
        (xy 129.712789 118.181638)
        (xy 129.70792 118.179914)
        (xy 129.707916 118.179912)
        (xy 129.507087 118.108795)
        (xy 129.507083 118.108794)
        (xy 129.502212 118.107069)
        (xy 129.497119 118.106162)
        (xy 129.497116 118.106161)
        (xy 129.287373 118.0688)
        (xy 129.287367 118.068799)
        (xy 129.282284 118.067894)
        (xy 129.208452 118.066992)
        (xy 129.064081 118.065228)
        (xy 129.064079 118.065228)
        (xy 129.058911 118.065165)
        (xy 128.838091 118.098955)
        (xy 128.625756 118.168357)
        (xy 128.595443 118.184137)
        (xy 128.4344 118.267971)
        (xy 128.427607 118.271507)
        (xy 128.423474 118.27461)
        (xy 128.423471 118.274612)
        (xy 128.399247 118.2928)
        (xy 128.248965 118.405635)
        (xy 128.094629 118.567138)
        (xy 128.09172 118.571403)
        (xy 128.091714 118.571411)
        (xy 128.073838 118.597617)
        (xy 127.968743 118.75168)
        (xy 127.953003 118.78559)
        (xy 127.884776 118.932573)
        (xy 127.874688 118.954305)
        (xy 127.814989 119.16957)
        (xy 105.526638 119.288194)
        (xy 105.526635 119.288186)
        (xy 105.525841 119.285114)
        (xy 105.522408 119.275833)
        (xy 105.396541 118.93557)
        (xy 105.396538 118.935564)
        (xy 105.395432 118.932573)
        (xy 105.230064 118.595015)
        (xy 105.226605 118.589457)
        (xy 105.033116 118.278605)
        (xy 105.03143 118.275896)
        (xy 104.950162 118.170747)
        (xy 104.803516 117.981009)
        (xy 104.803511 117.981004)
        (xy 104.801564 117.978484)
        (xy 104.542819 117.705825)
        (xy 104.257846 117.460708)
        (xy 104.249448 117.454849)
        (xy 103.952173 117.247468)
        (xy 103.94956 117.245645)
        (xy 103.621119 117.062838)
        (xy 103.618199 117.06158)
        (xy 103.618194 117.061578)
        (xy 103.27882 116.91542)
        (xy 103.27881 116.915416)
        (xy 103.275886 116.914157)
        (xy 102.917395 116.801125)
        (xy 102.653121 116.746397)
        (xy 102.552441 116.725547)
        (xy 102.552438 116.725547)
        (xy 102.549316 116.7249)
        (xy 102.262755 116.695286)
        (xy 102.178575 116.686587)
        (xy 102.178572 116.686587)
        (xy 102.175419 116.686261)
        (xy 102.172253 116.686255)
        (xy 102.172244 116.686255)
        (xy 101.986771 116.685932)
        (xy 101.799531 116.685605)
        (xy 101.651122 116.700418)
        (xy 101.428675 116.722621)
        (xy 101.428669 116.722622)
        (xy 101.425502 116.722938)
        (xy 101.2343 116.761838)
        (xy 101.060284 116.797242)
        (xy 101.06028 116.797243)
        (xy 101.057159 116.797878)
        (xy 101.054117 116.798825)
        (xy 101.054111 116.798827)
        (xy 100.877718 116.853768)
        (xy 100.698276 116.909658)
        (xy 100.695336 116.910912)
        (xy 100.355463 117.05588)
        (xy 100.355459 117.055882)
        (xy 100.352526 117.057133)
        (xy 100.349739 117.058672)
        (xy 100.349738 117.058672)
        (xy 100.187988 117.147963)
        (xy 100.023449 117.238793)
        (xy 100.020828 117.240608)
        (xy 100.020823 117.240611)
        (xy 99.717038 117.450962)
        (xy 99.714414 117.452779)
        (xy 99.428587 117.696899)
        (xy 99.42639 117.699198)
        (xy 99.426389 117.699199)
        (xy 99.171097 117.966346)
        (xy 99.171092 117.966352)
        (xy 99.168892 117.968654)
        (xy 98.937989 118.265261)
        (xy 98.936289 118.267971)
        (xy 98.934071 118.271507)
        (xy 98.738243 118.583684)
        (xy 98.736829 118.586545)
        (xy 98.722743 118.615046)
        (xy 98.571698 118.920663)
        (xy 98.440059 119.272747)
        (xy 98.439251 119.275826)
        (xy 98.439249 119.275833)
        (xy 98.4102 119.386562)
        (xy 98.344674 119.636332)
        (xy 98.34418 119.639487)
        (xy 98.313184 119.837425)
        (xy 98.28652 120.007695)
        (xy 98.286349 120.010857)
        (xy 98.286348 120.010864)
        (xy 98.270457 120.304292)
        (xy 98.267018 120.367799)
        (xy 96.52 115.696)
        (xy 96.540002 115.627879)
        (xy 96.593658 115.581386)
        (xy 96.646 115.57)
        (xy 172.594 115.57)
