Erfoglose Kommunikation mit dem Body Computer ######################################################################################################################################################################################## 12:29:59.738 ATZCr 12:30:00.537 CrCrELM327 v1.4CrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Device Complete reset like power off and on 12:30:00.537 AT@1Cr 12:30:00.561 AT@1CrOBDII to RS232 InterpreterCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 Device Returned internal device Description 12:30:00.562 STDICr 12:30:00.589 STDICr?CrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 12:30:00.589 ATPP2CSV01Cr 12:30:00.613 ATPP2CSV01CrOKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Prog Parameter 2C Set Value to 01 Protocol B (USER1) CAN Options: Data Format:ISO 15765-4,Receive ID Length 11 bit, Data Length Variable DLC, Transmit ID Length 11 bit 12:30:00.613 ATPP2CONCr 12:30:00.638 ATPP2CONCrOKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General enable Prog Parameter 2C 12:30:00.638 ATPP2DSV01Cr 12:30:00.664 ATPP2DSV01CrOKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Prog Parameter 2D Set Value to 01 Protocol B (USER1) baud rate: baud rate: 500 kbps 12:30:00.664 ATPP2DONCr 12:30:00.679 ATPP2DONCrOKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General enable Prog Parameter 2D 12:30:00.679 ATZCr 12:30:01.487 ATZCrCrCrELM327 v1.4CrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Device Complete reset like power off and on 12:30:01.487 ATE0Cr 12:30:01.511 ATE0CrOKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Echo Off 12:30:01.511 ATV0Cr 12:30:01.535 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 CAN use of Variable DLC Off 12:30:01.535 ATE0Cr 12:30:01.560 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Echo Off 12:30:01.560 ATL0Cr 12:30:01.585 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Linefeeds Off 12:30:01.585 ATH0Cr 12:30:01.610 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD Headers Off 12:30:01.610 ATS0Cr 12:30:01.635 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD printing of Spaces Off 12:30:01.635 ATSPBCr 12:30:01.660 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD Set Protocol to B and save it 12:30:01.660 ATCP18Cr 12:30:01.685 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 Set CAN Priority to 18 12:30:01.685 ATCRA18DAF140Cr 12:30:01.710 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 Set CAN Receive Address to 18DAF140 12:30:01.710 ATSHDA40F1Cr 12:30:01.735 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD Set Header to DA40F1 12:30:01.735 ATAT0Cr 12:30:01.760 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD Adaptive Timing Off 12:30:01.760 ATST19Cr 12:30:01.785 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD Set Timeout to: 100 msec 12:30:01.785 1003Cr 12:30:02.413 7F2278CrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 ######################################################################################################################################################################################## 12:30:24.020 ATZCr 12:30:24.837 CrCrELM327 v1.4CrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Device Complete reset like power off and on 12:30:24.837 AT@1Cr 12:30:24.862 AT@1CrOBDII to RS232 InterpreterCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 Device Returned internal device Description 12:30:24.862 STDICr 12:30:24.887 STDICr?CrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 12:30:24.887 ATPP2CSV01Cr 12:30:24.913 ATPP2CSV01CrOKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Prog Parameter 2C Set Value to 01 Protocol B (USER1) CAN Options: Data Format:ISO 15765-4,Receive ID Length 11 bit, Data Length Variable DLC, Transmit ID Length 11 bit 12:30:24.913 ATPP2CONCr 12:30:24.929 ATPP2CONCrOKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General enable Prog Parameter 2C 12:30:24.929 ATPP2DSV01Cr 12:30:24.963 ATPP2DSV01CrOKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Prog Parameter 2D Set Value to 01 Protocol B (USER1) baud rate: baud rate: 500 kbps 12:30:24.963 ATPP2DONCr 12:30:24.988 ATPP2DONCrOKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General enable Prog Parameter 2D 12:30:24.988 ATZCr 12:30:25.814 ATZCrCrCrELM327 v1.4CrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Device Complete reset like power off and on 12:30:25.814 ATE0Cr 12:30:25.836 ATE0CrOKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Echo Off 12:30:25.837 ATV1Cr 12:30:25.860 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 CAN use of Variable DLC On 12:30:25.860 ATE0Cr 12:30:25.885 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Echo Off 12:30:25.885 ATL0Cr 12:30:25.910 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Linefeeds Off 12:30:25.910 ATH0Cr 12:30:25.935 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD Headers Off 12:30:25.935 ATS0Cr 12:30:25.960 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD printing of Spaces Off 12:30:25.960 ATSPBCr 12:30:25.985 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD Set Protocol to B and save it 12:30:25.985 ATCP18Cr 12:30:26.010 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 Set CAN Priority to 18 12:30:26.010 ATARCr 12:30:26.035 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD Automatically Receive 12:30:26.035 ATSHDA40F1Cr 12:30:26.061 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD Set Header to DA40F1 12:30:26.061 ATAT0Cr 12:30:26.086 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD Adaptive Timing Off 12:30:26.086 ATST19Cr 12:30:26.115 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD Set Timeout to: 100 msec 12:30:26.115 1003Cr 12:30:26.737 NO DATACrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 12:30:26.738 1003Cr 12:30:27.411 7F2278CrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 ######################################################################################################################################################################################## 12:32:59.416 ATZCr 12:33:00.238 CrCrELM327 v1.4CrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Device Complete reset like power off and on 12:33:00.238 AT@1Cr 12:33:00.266 AT@1CrOBDII to RS232 InterpreterCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 Device Returned internal device Description 12:33:00.266 STDICr 12:33:00.287 STDICr?CrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 12:33:00.288 ATPP2CSV01Cr 12:33:00.315 ATPP2CSV01CrOKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Prog Parameter 2C Set Value to 01 Protocol B (USER1) CAN Options: Data Format:ISO 15765-4,Receive ID Length 11 bit, Data Length Variable DLC, Transmit ID Length 11 bit 12:33:00.315 ATPP2CONCr 12:33:00.339 ATPP2CONCrOKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General enable Prog Parameter 2C 12:33:00.339 ATPP2DSV01Cr 12:33:00.354 ATPP2DSV01CrOKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Prog Parameter 2D Set Value to 01 Protocol B (USER1) baud rate: baud rate: 500 kbps 12:33:00.354 ATPP2DONCr 12:33:00.389 ATPP2DONCrOKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General enable Prog Parameter 2D 12:33:00.389 ATZCr 12:33:01.213 ATZCrCrCrELM327 v1.4CrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Device Complete reset like power off and on 12:33:01.214 ATE0Cr 12:33:01.236 ATE0CrOKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Echo Off 12:33:01.237 ATV1Cr 12:33:01.296 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 CAN use of Variable DLC On 12:33:01.296 ATE0Cr 12:33:01.311 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Echo Off 12:33:01.311 ATL0Cr 12:33:01.336 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Linefeeds Off 12:33:01.336 ATH0Cr 12:33:01.361 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD Headers Off 12:33:01.362 ATS0Cr 12:33:01.386 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD printing of Spaces Off 12:33:01.387 ATSPBCr 12:33:01.411 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD Set Protocol to B and save it 12:33:01.412 ATCP18Cr 12:33:01.437 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 Set CAN Priority to 18 12:33:01.437 ATARCr 12:33:01.461 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD Automatically Receive 12:33:01.461 ATSHDA40F1Cr 12:33:01.489 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD Set Header to DA40F1 12:33:01.489 ATAT0Cr 12:33:01.511 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD Adaptive Timing Off 12:33:01.512 ATST19Cr 12:33:01.536 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD Set Timeout to: 100 msec 12:33:01.537 1003Cr 12:33:02.237 7F2278CrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 ######################################################################################################################################################################################## 12:33:09.339 ATZCr 12:33:10.163 CrCrELM327 v1.4CrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Device Complete reset like power off and on 12:33:10.164 AT@1Cr 12:33:10.188 AT@1CrOBDII to RS232 InterpreterCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 Device Returned internal device Description 12:33:10.188 STDICr 12:33:10.256 STDICr?CrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 12:33:10.256 ATPP2CSV01Cr 12:33:10.289 ATPP2CSV01CrOKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Prog Parameter 2C Set Value to 01 Protocol B (USER1) CAN Options: Data Format:ISO 15765-4,Receive ID Length 11 bit, Data Length Variable DLC, Transmit ID Length 11 bit 12:33:10.289 ATPP2CONCr 12:33:10.304 ATPP2CONCrOKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General enable Prog Parameter 2C 12:33:10.304 ATPP2DSV01Cr 12:33:10.339 ATPP2DSV01CrOKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Prog Parameter 2D Set Value to 01 Protocol B (USER1) baud rate: baud rate: 500 kbps 12:33:10.339 ATPP2DONCr 12:33:10.364 ATPP2DONCrOKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General enable Prog Parameter 2D 12:33:10.364 ATZCr 12:33:11.188 ATZCrCrCrELM327 v1.4CrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Device Complete reset like power off and on 12:33:11.189 ATE0Cr 12:33:11.212 ATE0CrOKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Echo Off 12:33:11.213 ATV1Cr 12:33:11.236 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 CAN use of Variable DLC On 12:33:11.237 ATE0Cr 12:33:11.261 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Echo Off 12:33:11.262 ATL0Cr 12:33:11.286 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Linefeeds Off 12:33:11.287 ATH0Cr 12:33:11.311 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD Headers Off 12:33:11.312 ATS0Cr 12:33:11.339 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD printing of Spaces Off 12:33:11.339 ATSPBCr 12:33:11.361 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD Set Protocol to B and save it 12:33:11.362 ATCP18Cr 12:33:11.386 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 Set CAN Priority to 18 12:33:11.387 ATARCr 12:33:11.411 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD Automatically Receive 12:33:11.412 ATSHDA40F1Cr 12:33:11.436 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD Set Header to DA40F1 12:33:11.436 ATAT0Cr 12:33:11.463 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD Adaptive Timing Off 12:33:11.463 ATST19Cr 12:33:11.486 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD Set Timeout to: 100 msec 12:33:11.487 1003Cr 12:33:12.237 7F2278CrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 ######################################################################################################################################################################################## 12:34:32.472 ATZCr 12:34:33.289 CrCrELM327 v1.4CrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Device Complete reset like power off and on 12:34:33.289 AT@1Cr 12:34:33.314 AT@1CrOBDII to RS232 InterpreterCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 Device Returned internal device Description 12:34:33.314 STDICr 12:34:33.338 STDICr?CrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 12:34:33.338 ATPP2CSV01Cr 12:34:33.365 ATPP2CSV01CrOKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Prog Parameter 2C Set Value to 01 Protocol B (USER1) CAN Options: Data Format:ISO 15765-4,Receive ID Length 11 bit, Data Length Variable DLC, Transmit ID Length 11 bit 12:34:33.365 ATPP2CONCr 12:34:33.379 ATPP2CONCrOKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General enable Prog Parameter 2C 12:34:33.380 ATPP2DSV01Cr 12:34:33.458 ATPP2DSV01CrOKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Prog Parameter 2D Set Value to 01 Protocol B (USER1) baud rate: baud rate: 500 kbps 12:34:33.458 ATPP2DONCr 12:34:33.493 ATPP2DONCrOKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General enable Prog Parameter 2D 12:34:33.493 ATZCr 12:34:34.314 ATZCrCrCrELM327 v1.4CrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Device Complete reset like power off and on 12:34:34.314 ATE0Cr 12:34:34.338 ATE0CrOKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Echo Off 12:34:34.338 ATV0Cr 12:34:34.362 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 CAN use of Variable DLC Off 12:34:34.362 ATE0Cr 12:34:34.387 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Echo Off 12:34:34.387 ATL0Cr 12:34:34.412 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Linefeeds Off 12:34:34.412 ATH0Cr 12:34:34.437 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD Headers Off 12:34:34.437 ATS0Cr 12:34:34.462 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD printing of Spaces Off 12:34:34.462 ATSPBCr 12:34:34.487 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD Set Protocol to B and save it 12:34:34.487 ATCP18Cr 12:34:34.512 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 Set CAN Priority to 18 12:34:34.513 ATCRA18DAF140Cr 12:34:34.537 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 Set CAN Receive Address to 18DAF140 12:34:34.537 ATSHDA40F1Cr 12:34:34.562 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD Set Header to DA40F1 12:34:34.562 ATAT0Cr 12:34:34.587 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD Adaptive Timing Off 12:34:34.587 ATST19Cr 12:34:34.612 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD Set Timeout to: 100 msec 12:34:34.612 1003Cr 12:34:35.238 NO DATACrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 12:34:35.238 1003Cr 12:34:35.864 NO DATACrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 12:34:35.864 1003Cr 12:34:36.517 NO DATACrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 12:34:36.518 1003Cr 12:34:37.163 7F2278CrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 ######################################################################################################################################################################################## 12:36:24.300 ATZCr 12:36:25.116 CrCrELM327 v1.4CrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Device Complete reset like power off and on 12:36:25.116 AT@1Cr 12:36:25.166 AT@1CrOBDII to RS232 InterpreterCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 Device Returned internal device Description 12:36:25.167 STDICr 12:36:25.189 STDICr?CrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 12:36:25.189 ATPP2CSV01Cr 12:36:25.215 ATPP2CSV01CrOKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Prog Parameter 2C Set Value to 01 Protocol B (USER1) CAN Options: Data Format:ISO 15765-4,Receive ID Length 11 bit, Data Length Variable DLC, Transmit ID Length 11 bit 12:36:25.215 ATPP2CONCr 12:36:25.230 ATPP2CONCrOKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General enable Prog Parameter 2C 12:36:25.230 ATPP2DSV01Cr 12:36:25.265 ATPP2DSV01CrOKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Prog Parameter 2D Set Value to 01 Protocol B (USER1) baud rate: baud rate: 500 kbps 12:36:25.265 ATPP2DONCr 12:36:25.290 ATPP2DONCrOKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General enable Prog Parameter 2D 12:36:25.290 ATZCr 12:36:26.098 ATZCrCrCrELM327 v1.4CrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Device Complete reset like power off and on 12:36:26.098 ATE0Cr 12:36:26.114 ATE0CrOKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Echo Off 12:36:26.114 ATV0Cr 12:36:26.138 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 CAN use of Variable DLC Off 12:36:26.138 ATE0Cr 12:36:26.163 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Echo Off 12:36:26.163 ATL0Cr 12:36:26.188 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Linefeeds Off 12:36:26.188 ATH0Cr 12:36:26.213 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD Headers Off 12:36:26.213 ATS0Cr 12:36:26.239 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD printing of Spaces Off 12:36:26.239 ATSPBCr 12:36:26.263 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD Set Protocol to B and save it 12:36:26.263 ATCP18Cr 12:36:26.288 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 Set CAN Priority to 18 12:36:26.289 ATCRA18DAF140Cr 12:36:26.313 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 Set CAN Receive Address to 18DAF140 12:36:26.313 ATSHDA40F1Cr 12:36:26.338 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD Set Header to DA40F1 12:36:26.338 ATAT0Cr 12:36:26.363 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD Adaptive Timing Off 12:36:26.363 ATST19Cr 12:36:26.388 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD Set Timeout to: 100 msec 12:36:26.388 1003Cr 12:36:27.038 7F2278CrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 12:36:27.039 1003Cr 12:36:27.667 NO DATACrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 12:36:27.668 1003Cr 12:36:28.290 NO DATACrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 12:36:28.290 1003Cr 12:36:28.915 NO DATACrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 ######################################################################################################################################################################################## 12:45:41.872 ATZCr 12:45:42.796 CrCrELM327 v1.4CrCr> MES Test 01.01.2023 290 BCM General Device Complete reset like power off and on 12:45:42.819 ATPP2CSV01Cr 12:45:42.901 ATPP2CSV01CrOKCrCr> MES Test 01.01.2023 290 BCM General Prog Parameter 2C Set Value to 01 Protocol B (USER1) CAN Options: Data Format:ISO 15765-4,Receive ID Length 11 bit, Data Length Variable DLC, Transmit ID Length 11 bit 12:45:42.923 ATPP2CONCr 12:45:43.012 ATPP2CONCrOKCrCr> MES Test 01.01.2023 290 BCM General enable Prog Parameter 2C 12:45:43.033 ATPP2DSV0ACr 12:45:43.118 ATPP2DSV0ACrOKCrCr> MES Test 01.01.2023 290 BCM General Prog Parameter 2D Set Value to 0A Protocol B (USER1) baud rate: baud rate: 50 kbps 12:45:43.138 ATPP2DONCr 12:45:43.223 ATPP2DONCrOKCrCr> MES Test 01.01.2023 290 BCM General enable Prog Parameter 2D 12:45:43.243 ATZCr 12:45:44.117 CrCrELM327 v1.4CrCr> MES Test 01.01.2023 290 BCM General Device Complete reset like power off and on 12:45:44.136 ATV1Cr 12:45:44.207 ATV1CrOKCrCr> MES Test 01.01.2023 290 BCM CAN use of Variable DLC On 12:45:44.226 ATE0Cr 12:45:44.311 ATE0CrOKCrCr> MES Test 01.01.2023 290 BCM General Echo Off 12:45:44.328 ATL0Cr 12:45:44.411 OKCrCr> MES Test 01.01.2023 290 BCM General Linefeeds Off 12:45:44.427 ATH0Cr 12:45:44.507 OKCrCr> MES Test 01.01.2023 290 BCM OBD Headers Off 12:45:44.527 ATSPBCr 12:45:44.606 OKCrCr> MES Test 01.01.2023 290 BCM OBD Set Protocol to B and save it 12:45:44.626 ATALCr 12:45:44.711 OKCrCr> MES Test 01.01.2023 290 BCM OBD Allow Long ( > 7 byte) messages 12:45:44.728 ATS0Cr 12:45:44.811 OKCrCr> MES Test 01.01.2023 290 BCM OBD printing of Spaces Off 12:45:44.828 ATCP18Cr 12:45:44.911 OKCrCr> MES Test 01.01.2023 290 BCM Set CAN Priority to 18 12:45:44.928 ATCRA18DAF140Cr 12:45:45.009 OKCrCr> MES Test 01.01.2023 290 BCM Set CAN Receive Address to 18DAF140 12:45:45.027 ATSHDA40F1Cr 12:45:45.100 OKCrCr> MES Test 01.01.2023 290 BCM OBD Set Header to DA40F1 12:45:45.117 ATAT1Cr 12:45:45.193 OKCrCr> MES Test 01.01.2023 290 BCM OBD Adaptive Timing Auto1 12:45:45.211 ATSTF0Cr 12:45:45.292 OKCrCr> MES Test 01.01.2023 290 BCM OBD Set Timeout to: 960 msec 12:45:45.310 1003Cr 12:45:46.385 NO DATACrCr> MES Test 01.01.2023 290 BCM 12:45:46.408 ATV0Cr 12:45:46.485 OKCrCr> MES Test 01.01.2023 290 BCM CAN use of Variable DLC Off 12:45:46.504 1003Cr 12:45:47.586 NO DATACrCr> MES Test 01.01.2023 290 BCM 12:45:48.118 ATPCCr 12:45:48.192 OKCrCr> MES Test 01.01.2023 290 BCM OBD Protocol Close Kommunikation mit Motorsteuergerät: ######################################################################################################################################################################################## 12:35:19.604 ATZCr 12:35:20.414 CrCrELM327 v1.4CrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Device Complete reset like power off and on 12:35:20.415 AT@1Cr 12:35:20.444 AT@1CrOBDII to RS232 InterpreterCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 Device Returned internal device Description 12:35:20.444 STDICr 12:35:20.465 STDICr?CrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 12:35:20.465 ATPP2CSV01Cr 12:35:20.490 ATPP2CSV01CrOKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Prog Parameter 2C Set Value to 01 Protocol B (USER1) CAN Options: Data Format:ISO 15765-4,Receive ID Length 11 bit, Data Length Variable DLC, Transmit ID Length 11 bit 12:35:20.490 ATPP2CONCr 12:35:20.508 ATPP2CONCrOKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General enable Prog Parameter 2C 12:35:20.508 ATPP2DSV01Cr 12:35:20.540 ATPP2DSV01CrOKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Prog Parameter 2D Set Value to 01 Protocol B (USER1) baud rate: baud rate: 500 kbps 12:35:20.540 ATPP2DONCr 12:35:20.565 ATPP2DONCrOKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General enable Prog Parameter 2D 12:35:20.565 ATZCr 12:35:21.389 ATZCrCrCrELM327 v1.4CrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Device Complete reset like power off and on 12:35:21.389 ATE0Cr 12:35:21.413 ATE0CrOKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Echo Off 12:35:21.413 ATV0Cr 12:35:21.437 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 CAN use of Variable DLC Off 12:35:21.437 ATE0Cr 12:35:21.462 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Echo Off 12:35:21.462 ATL0Cr 12:35:21.487 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 General Linefeeds Off 12:35:21.487 ATH0Cr 12:35:21.512 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD Headers Off 12:35:21.512 ATS0Cr 12:35:21.537 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD printing of Spaces Off 12:35:21.537 ATSPBCr 12:35:21.562 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD Set Protocol to B and save it 12:35:21.562 ATCP18Cr 12:35:21.587 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 Set CAN Priority to 18 12:35:21.587 ATCRA18DAF110Cr 12:35:21.612 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 Set CAN Receive Address to 18DAF110 12:35:21.612 ATSHDA10F1Cr 12:35:21.639 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD Set Header to DA10F1 12:35:21.639 ATAT0Cr 12:35:21.662 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD Adaptive Timing Off 12:35:21.662 ATST19Cr 12:35:21.687 OKCrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 OBD Set Timeout to: 100 msec 12:35:21.687 1003Cr 12:35:21.813 5003003201F4CrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022 12:35:21.860 22F1A5Cr 12:35:21.988 008Cr0:62F1A5000150Cr1:0814CrCr> AlfaObd Android ECM + BCM-Tests 27.12.2022
