// -------------------------------------- Umbenenen der STM Pins // Bliotheken //------------------------------------------------------------------------------------------------------------Testweise auskommentiert #include #include "stm32f103.h" // Bei selbst erstellten Bibliotheken der name immer in Anführungszeichen!! Nicht in größer kleiner als Zeichen! // EIngänge // Taster const int Taster = PB6; int TasterState = 0; // Ausgänge const int LED = PA0; const int LED2 = PA3; uint8_t counter = 0; uint8_t frameLength = 0; unsigned long previousMillis = 0; // stores last time output was updated const long interval = 1000; // transmission interval (milliseconds) void setup() { // -------------------------------------- pinMode pinMode(Taster, INPUT); pinMode(LED, OUTPUT); pinMode(LED2, OUTPUT); pinMode(LED_BUILTIN, OUTPUT); //LED auf Arduino auf HIGH // CAN aktivieren { Serial.begin(115200); // bool ret = CANInit(CAN_500KBPS, 0); // CAN_RX mapped to PA11, CAN_TX mapped to PA12 bool ret = CANInit(CAN_500KBPS, 2); // CAN_RX to PB8, CAN_TX to PB9 if (!ret) while (true); } } void loop() { { CAN_msg_t CAN_TX_msg; CAN_msg_t CAN_RX_msg; CAN_TX_msg.data[0] = 0x00; CAN_TX_msg.data[1] = 0x01; CAN_TX_msg.data[2] = 0x02; CAN_TX_msg.data[3] = 0x03; CAN_TX_msg.data[4] = 0x04; CAN_TX_msg.data[5] = 0x05; CAN_TX_msg.data[6] = 0x06; CAN_TX_msg.data[7] = 0x07; CAN_TX_msg.len = frameLength; unsigned long currentMillis = millis(); if (currentMillis - previousMillis >= interval) { previousMillis = currentMillis; if ( ( counter % 2) == 0) { CAN_TX_msg.type = DATA_FRAME; if (CAN_TX_msg.len == 0) CAN_TX_msg.type = REMOTE_FRAME; CAN_TX_msg.format = EXTENDED_FORMAT; CAN_TX_msg.id = 0x32F103; } else { CAN_TX_msg.type = DATA_FRAME; if (CAN_TX_msg.len == 0) CAN_TX_msg.type = REMOTE_FRAME; CAN_TX_msg.format = STANDARD_FORMAT; CAN_TX_msg.id = 0x103; } CANSend(&CAN_TX_msg); frameLength++; if (frameLength == 9) frameLength = 0; counter++; } if (CANMsgAvail()) { CANReceive(&CAN_RX_msg); if (CAN_RX_msg.format == EXTENDED_FORMAT) { Serial.print("Extended ID: 0x"); if (CAN_RX_msg.id < 0x10000000) Serial.print("0"); if (CAN_RX_msg.id < 0x1000000) Serial.print("00"); if (CAN_RX_msg.id < 0x100000) Serial.print("000"); if (CAN_RX_msg.id < 0x10000) Serial.print("0000"); Serial.print(CAN_RX_msg.id, HEX); } else { Serial.print("Standard ID: 0x"); if (CAN_RX_msg.id < 0x100) Serial.print("0"); if (CAN_RX_msg.id < 0x10) Serial.print("00"); Serial.print(CAN_RX_msg.id, HEX); Serial.print(" "); } Serial.print(" DLC: "); Serial.print(CAN_RX_msg.len); if (CAN_RX_msg.type == DATA_FRAME) { Serial.print(" Data: "); for (int i = 0; i < CAN_RX_msg.len; i++) { Serial.print("0x"); Serial.print(CAN_RX_msg.data[i], HEX); if (i != (CAN_RX_msg.len - 1)) Serial.print(" "); } Serial.println(); } else { Serial.println(" Data: REMOTE REQUEST FRAME"); } } } digitalWrite(LED2, HIGH); TasterState = digitalRead(Taster); // Taster abfragen if (TasterState == LOW) { digitalWrite(LED, LOW); } else { digitalWrite(LED, HIGH); } }
