>D ;start, define variables cnt=0 tmp=0 cntr=0 tmp=0 res=0 >B ;setup sensor =>sensor53 r >F ;100ms iterations cntr+=1 switch cntr case 10 print ===== ctr: %cntr% wakeup start ===== ;set serial protocol sml(-1 1 "2400:8N1") ; end 2f just like in the minicom3 software sml(1 1 "2f") ;send (132x) 0x55 with 2400 baud (wakeup sequence) for cnt 1 132 1 sml(1 1 "55") next print ===== wakeup end, wait for the meter ===== case 15 print ===== ctr: %cntr% --SET BAUDRATE TO 2400:8E1-- ===== ;switch serial protocol sml(-1 1 "2400:8E1") print ===== request data ===== case 20 sml(1 1 "1040004016") case 26 sml(1 1 "105b005b16") case 32 sml(1 1 "1040004016") case 38 res=sml(1 1 "105b005b16") print ===== ctr: %cntr% sent successfully %res% ===== case 60 if tmp<1 then print ===== 1x repeat for to ensure stable and reliable readout ===== cntr=0 tmp+=1 endif ; repeat after a little less than hour to prevent the meter from falling asleep case 35500 print ===== --REPEAT SEQUENCE -- ===== cntr=0 cnt=0 tmp=0 ends >M 1 +1,3,rE1,0,2400,K_WW,1 1,0C06bcd8@1,Total Energy,kWh,w_total,0 1,0C13bcd8@1000,Total volume,m³,v_total,3 1,0C2bbcd8@1,Current power,W,p_act,0 1,0C3bbcd8@1000,Current flow,m³/h,F_akt,3 1,025AuuUU@10,Flow temp,°C,t_flow,1 1,025euuUU@10,Return temp,°C,t_return,1 #
