/* * ESPRESSIF MIT License * * Copyright (c) 2020 * * Permission is hereby granted for use on all ESPRESSIF SYSTEMS products, in which case, * it is free of charge, to any person obtaining a copy of this software and associated * documentation files (the "Software"), to deal in the Software without restriction, including * without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, * and/or sell copies of the Software, and to permit persons to whom the Software is furnished * to do so, subject to the following conditions: * * The above copyright notice and this permission notice shall be included in all copies or * substantial portions of the Software. * * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS * FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR * COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER * IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN * CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. * */ #ifndef _SNAPCAST_CLIENT_STREAM_H_ #define _SNAPCAST_CLIENT_STREAM_H_ #include "audio_error.h" #include "audio_element.h" #include "esp_transport.h" #include "snapcast.h" #include "freertos/FreeRTOS.h" #include "freertos/semphr.h" #include "freertos/event_groups.h" #ifdef __cplusplus extern "C" { #endif typedef enum { SNAPCAST_STREAM_STATE_NONE, SNAPCAST_STREAM_STATE_CONNECTED, SNAPCAST_STREAM_STATE_CHANGING_SONG_MESSAGE, SNAPCAST_STREAM_STATE_TCP_SOCKET_TIMEOUT_MESSAGE, SNAPCAST_STREAM_STATE_SNTP_MESSAGE, SNAPCAST_STREAM_STATE_SERVER_SETTINGS_MESAGE, SNAPCAST_STREAM_START_AUDIO_ELEMENT, SNAPCAST_STREAM_STOP_AUDIO_ELEMENT } snapcast_stream_status_t; /** * @brief TCP Stream massage configuration */ typedef struct snapcast_stream_event_msg { void *source; /*!< Element handle */ void *data; /*!< Data of input/output */ int data_len; /*!< Data length of input/output */ esp_transport_handle_t sock_fd; /*!< handle of socket*/ } snapcast_stream_event_msg_t; typedef esp_err_t (*snapcast_stream_event_handle_cb)(snapcast_stream_event_msg_t *msg, snapcast_stream_status_t state, void *event_ctx); /** * @brief TCP Stream configuration, if any entry is zero then the configuration will be set to default values */ typedef struct { audio_stream_type_t type; /*!< Type of stream */ int out_rb_size; /*!< Size of output ringbuffer */ int timeout_ms; /*!< time timeout for read/write*/ int port; /*!< TCP port> */ char *host; /*!< TCP host> */ int task_stack; /*!< Task stack size */ int task_core; /*!< Task running in core (0 or 1) */ int task_prio; /*!< Task priority (based on freeRTOS priority) */ bool ext_stack; /*!< Allocate stack on extern ram */ snapcast_stream_event_handle_cb event_handler; /*!< TCP stream event callback*/ void *event_ctx; /*!< User context*/ int state; } snapcast_stream_cfg_t; /** * @brief TCP stream parameters */ #define SNAPCAST_STREAM_DEFAULT_PORT (8080) #define SNAPCAST_STREAM_RINGBUFFER_SIZE (4096) #define SNAPCAST_STREAM_CUSTOM_RINGBUFFER_ELEMENTS 50 #define SNAPCAST_STREAM_CUSTOM_RINGBUFFER_SIZE (SNAPCAST_STREAM_CUSTOM_RINGBUFFER_ELEMENTS * SNAPCAST_STREAM_RINGBUFFER_SIZE) #define SNAPCAST_STREAM_TASK_STACK (3072) #define SNAPCAST_STREAM_BUF_SIZE (4096) #define SNAPCAST_STREAM_TASK_PRIO (22) #define SNAPCAST_STREAM_TASK_CORE (1) #define SNAPCAST_STREAM_CLIENT_NAME "esp32" #define SNAPCAST_SERVER_DEFAULT_RESPONSE_LENGTH (512) #define SNAPCAST_CONNECT_TIMEOUT_MS 1000 #define ENABLE 1 #define DISABLE 0 #define SNAPCAST_STREAM_RINGBUFFER_FIRST 0 #define SNAPCAST_STREAM_CFG_DEFAULT() { \ .type = AUDIO_STREAM_READER, \ .out_rb_size = SNAPCAST_STREAM_RINGBUFFER_SIZE,\ .timeout_ms = SNAPCAST_CONNECT_TIMEOUT_MS, \ .port = SNAPCAST_STREAM_DEFAULT_PORT, \ .host = NULL, \ .task_stack = SNAPCAST_STREAM_TASK_STACK, \ .task_core = SNAPCAST_STREAM_TASK_CORE, \ .task_prio = SNAPCAST_STREAM_TASK_PRIO, \ .ext_stack = true, \ .event_handler = NULL, \ .event_ctx = NULL, \ } /** * @brief Initialize a SNAPCAST stream to/from an audio element * This function creates a SNAPCAST stream to/from an audio element depending on the stream type configuration (e.g., * AUDIO_STREAM_READER or AUDIO_STREAM_WRITER). The handle of the audio element is the returned. * * @param config The configuration * * @return The audio element handle */ audio_element_handle_t snapcast_stream_init(snapcast_stream_cfg_t *config); #ifdef __cplusplus } #endif #endif
