/* * ESPRESSIF MIT License * * Copyright (c) 2020 * * Permission is hereby granted for use on all ESPRESSIF SYSTEMS products, in which case, * it is free of charge, to any person obtaining a copy of this software and associated * documentation files (the "Software"), to deal in the Software without restriction, including * without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, * and/or sell copies of the Software, and to permit persons to whom the Software is furnished * to do so, subject to the following conditions: * * The above copyright notice and this permission notice shall be included in all copies or * substantial portions of the Software. * * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS * FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR * COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER * IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN * CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. * */ #include #include #include "lwip/sockets.h" #include "esp_transport_tcp.h" #include "esp_log.h" #include "esp_err.h" #include "audio_mem.h" #include "snapcast_stream.h" #include "freertos/FreeRTOS.h" #include "freertos/timers.h" #include "freertos/task.h" static const char *TAG = "SNAPCAST_STREAM"; static const char *TAG_TIME = "SNAPCAST_STREAM_TIME"; typedef struct snapcast_stream_ringbuffer_bits{ unsigned new_wire_chunk:1; unsigned enabled:1; unsigned sync:1; unsigned :13; }snapcast_stream_ringbuffer_bits_t; typedef struct snapcast_stream_ringbuffer_node{ int position; int data_size; int ringbuffer_size; int64_t timestamp; //char data[SNAPCAST_STREAM_RINGBUFFER_SIZE]; char data[SNAPCAST_STREAM_RINGBUFFER_SIZE ]; struct snapcast_stream_ringbuffer_node *last; struct snapcast_stream_ringbuffer_node *next; }snapcast_stream_ringbuffer_node_t; /* typedef struct snapcast_stream_custom_ringbuffer{ char *rb; char *audio_buffer; uint16_t *write_length_buffer; uint16_t counter_write; uint16_t counter_read; char sync; char new_data; char start_audio; }snapcast_stream_custom_ringbuffer_t; */ typedef struct snapcast_stream { esp_transport_handle_t t; audio_stream_type_t type; int sock; int port; char *host; bool is_open; int timeout_ms; snapcast_stream_event_handle_cb hook; void *ctx; bool received_header; struct timeval last_sync; int id_counter; struct timeval server_uptime; char *audio_buffer; base_message_t base_message; codec_header_message_t codec_header_message; wire_chunk_message_t wire_chunk_message; server_settings_message_t server_settings_message; time_message_t time_message; snapcast_stream_status_t state; snapcast_stream_ringbuffer_node_t *rb; snapcast_stream_ringbuffer_node_t *write_rb; snapcast_stream_ringbuffer_node_t *read_rb; int read_len; int write_len; int wire_chunk_len; char *tcp_buffer; union{ uint16_t bits_buffer; snapcast_stream_ringbuffer_bits_t bits; }; } snapcast_stream_t; char mac_address[18]; unsigned char base_mac[6]; char base_message_serialized[BASE_MESSAGE_SIZE]; char time_message_serialized[TIME_MESSAGE_SIZE]; static int _get_socket_error_code_reason(const char *str, int sockfd) { uint32_t optlen = sizeof(int); int result; int err; err = getsockopt(sockfd, SOL_SOCKET, SO_ERROR, &result, &optlen); if (err == -1) { ESP_LOGE(TAG, "%s, getsockopt failed", str); return -1; } if (result != 0) { ESP_LOGW(TAG, "%s error, error code: %d, reason: %s", str, err, strerror(result)); } return result; } static TimerHandle_t send_time_tm_handle; snapcast_stream_t *sntp_snapcast; static void log_socket_error(const char *tag, const int sock, const int err, const char *message){ ESP_LOGE(tag, "[sock=%d]: %s\n error=%d: %s", sock, message, err, strerror(err)); } static int _snapcast_stream_socket_send(const char *tag, const int sock, const char * data, const size_t len){ int to_write = len; while (to_write > 0) { int written = send(sock, data + (len - to_write), to_write, 0); if (written < 0 && errno != EINPROGRESS && errno != EAGAIN && errno != EWOULDBLOCK) { log_socket_error(tag, sock, errno, "Error occurred during sending"); return -1; } to_write -= written; } return len; } static int _snapcast_stream_socket_receive(const char *tag, const int sock, char * data, size_t max_len){ int len = recv(sock, data, max_len, 0); // ESP_LOGI(tag, "[sock=%d]: MAX_LEN: %d", sock, max_len); if (len < 0) { if (errno == EINPROGRESS || errno == EAGAIN || errno == EWOULDBLOCK) { return 0; // Not an error } if (errno == ENOTCONN) { ESP_LOGW(tag, "[sock=%d]: Connection closed", sock); return -2; // Socket has been disconnected } log_socket_error(tag, sock, errno, "Error occurred during receiving"); return -1; } return len; } static void send_time_timer_cb(TimerHandle_t xTimer){ // ESP_LOGI(TAG, "Send time cb"); struct timeval now; if (sntp_snapcast == NULL) { ESP_LOGW(TAG, "snapclient not initialized, ignoring"); return; } if (gettimeofday(&now, NULL)) { ESP_LOGI(TAG, "Failed to gettimeofday\r\n"); return; } sntp_snapcast->last_sync.tv_sec = now.tv_sec; sntp_snapcast->last_sync.tv_usec = now.tv_usec; base_message_t base_message = { SNAPCAST_MESSAGE_TIME, // type sntp_snapcast->id_counter++, // id 0x0, // refersTo { now.tv_sec - sntp_snapcast->server_uptime.tv_sec, now.tv_usec }, // sent { now.tv_sec - sntp_snapcast->server_uptime.tv_usec, now.tv_usec }, // received TIME_MESSAGE_SIZE // size }; if (base_message_serialize( &base_message, base_message_serialized, BASE_MESSAGE_SIZE)) { ESP_LOGE(TAG, "Failed to serialize base message for time\r\n"); return; } if (time_message_serialize( &(sntp_snapcast->time_message), time_message_serialized, TIME_MESSAGE_SIZE)) { ESP_LOGI(TAG, "Failed to serialize time message\r\b"); return; } _snapcast_stream_socket_send(TAG, sntp_snapcast->sock, base_message_serialized, BASE_MESSAGE_SIZE); _snapcast_stream_socket_send(TAG, sntp_snapcast->sock, time_message_serialized, TIME_MESSAGE_SIZE); } snapcast_stream_ringbuffer_node_t *snapcast_stream_new_ringbuffer(){ snapcast_stream_ringbuffer_node_t *node = (snapcast_stream_ringbuffer_node_t*) audio_malloc(sizeof(snapcast_stream_ringbuffer_node_t)); AUDIO_MEM_CHECK(TAG, node, return NULL); node->position = 0; node->ringbuffer_size = 1; node->last = node; node->next = node; return node; } snapcast_stream_ringbuffer_node_t *snapcast_stream_ringbuffer_add_element(snapcast_stream_ringbuffer_node_t *last_node, int pos){ snapcast_stream_ringbuffer_node_t *new_node = (snapcast_stream_ringbuffer_node_t*) audio_malloc(sizeof(snapcast_stream_ringbuffer_node_t)); AUDIO_MEM_CHECK(TAG, new_node, return NULL); // new_node->data = data; new_node->position = pos; new_node->last = last_node; new_node->next = last_node->next; new_node->next->ringbuffer_size += 1; last_node->next = new_node; new_node->next->last = new_node; ESP_LOGW("SNAPCAST_STREAM_LIST","### New Element created ###"); ESP_LOGW("SNAPCAST_STREAM_LIST","### New Element Position=%d ###", new_node->position); ESP_LOGW("SNAPCAST_STREAM_LIST","### New List Size=%d ###", new_node->next->ringbuffer_size); return new_node; } snapcast_stream_ringbuffer_node_t *snapcast_stream_ringbuffer_get_element(snapcast_stream_ringbuffer_node_t *rb, int pos){ while(rb->position!=pos){ rb = rb->next; } //ESP_LOGI("SNAPCAST_STREAM_LIST","Element Position=%d", rb->position); return rb; } snapcast_stream_ringbuffer_node_t *snapcast_stream_ringbuffer_delete_element(snapcast_stream_ringbuffer_node_t *node, int pos){ snapcast_stream_ringbuffer_node_t *tmp = node; snapcast_stream_ringbuffer_node_t *el = snapcast_stream_ringbuffer_get_element(node, pos); snapcast_stream_ringbuffer_node_t *first = snapcast_stream_ringbuffer_get_element(tmp, SNAPCAST_STREAM_RINGBUFFER_FIRST); snapcast_stream_ringbuffer_node_t *rb = el->next; int size = first->ringbuffer_size; ESP_LOGI("SNAPCAST_STREAM_LIST","### First Element Position=%d, Size=%d ###", first->position, first->ringbuffer_size); ESP_LOGI("SNAPCAST_STREAM_LIST","!!! Delete Element %d !!!! ", el->position); first->ringbuffer_size -= 1; el->next->last = el->last; el->last->next = el->next; int y = rb->position; for(int x = y;xposition-=1; ESP_LOGI("SNAPCAST_STREAM_LIST", "### Next Element Position=%d, Size=%d ###", rb->position, rb->ringbuffer_size); rb=rb->next; } ESP_LOGI("SNAPCAST_STREAM_LIST","!!! New List Size %d !!!! ", first->ringbuffer_size); size=first->ringbuffer_size; rb = first; for(int x=0;xposition, rb->ringbuffer_size); rb=rb->next; } free(el); return node->last; } static esp_err_t snapcast_stream_rinbuffer_reset(audio_element_handle_t self){ snapcast_stream_t *tcp = (snapcast_stream_t *)audio_element_getdata(self); snapcast_stream_ringbuffer_node_t *node = snapcast_stream_ringbuffer_get_element(tcp->rb, SNAPCAST_STREAM_RINGBUFFER_FIRST); tcp->write_rb=node; tcp->read_rb=node; int size=node->ringbuffer_size; for(int x=0;xtimestamp=0; node->data_size=0; memset(node->data, 0x00, SNAPCAST_STREAM_RINGBUFFER_SIZE); node=node->next; } return ESP_OK; } void print_all(snapcast_stream_ringbuffer_node_t* rb){ snapcast_stream_ringbuffer_node_t *el = snapcast_stream_ringbuffer_get_element(rb, SNAPCAST_STREAM_RINGBUFFER_FIRST); int size = el->ringbuffer_size; for(int x=0;xposition); el=el->next; } } snapcast_stream_ringbuffer_node_t *snapcast_stream_create_ringbuffer(int size){ snapcast_stream_ringbuffer_node_t *head = snapcast_stream_new_ringbuffer(); snapcast_stream_ringbuffer_node_t *current = head; for(int i = 1; i < size; i++){ current=snapcast_stream_ringbuffer_add_element(current, i); } return head; } static esp_err_t _snapcast_dispatch_event(audio_element_handle_t el, snapcast_stream_t *tcp, void *data, int len, snapcast_stream_status_t state) { if (el && tcp && tcp->hook) { snapcast_stream_event_msg_t msg = { 0 }; msg.data = data; msg.data_len = len; msg.sock_fd = tcp->t; msg.source = el; return tcp->hook(&msg, state, tcp->ctx); } return ESP_FAIL; } static esp_err_t _snapcast_open(audio_element_handle_t self) { AUDIO_NULL_CHECK(TAG, self, return ESP_FAIL); snapcast_stream_t *tcp = (snapcast_stream_t *)audio_element_getdata(self); char base_message_serialized[BASE_MESSAGE_SIZE]; char *hello_message_serialized; int result; struct timeval now; int sockfd, connfd; struct sockaddr_in servaddr, cli; if (tcp->is_open) { ESP_LOGE(TAG, "Already opened"); return ESP_FAIL; } ESP_LOGI(TAG, "Host is %s, port is %d\n", tcp->host, tcp->port); // assign IP, PORT servaddr.sin_family = AF_INET; servaddr.sin_addr.s_addr = inet_addr(tcp->host); servaddr.sin_port = htons(tcp->port); sockfd = socket(AF_INET, SOCK_STREAM, 0); if (connect(sockfd, (SA*)&servaddr, sizeof(servaddr))!= 0) { ESP_LOGE(TAG,"connection with the server failed...\n"); return ESP_FAIL; } tcp->sock=sockfd; // esp_transport_handle_t t = esp_transport_tcp_init(); // esp_transport_list_handle_t transport_list = esp_transport_list_init(); // esp_transport_list_add(transport_list, t, "http"); // AUDIO_NULL_CHECK(TAG, t, return ESP_FAIL); //tcp->sock = esp_transport_connect(t, tcp->host, tcp->port, SNAPCAST_CONNECT_TIMEOUT_MS); if (tcp->sock < 0) { _get_socket_error_code_reason(__func__, tcp->sock); return ESP_FAIL; } tcp->is_open = true; // tcp->t = t; tcp->base_message.type = SNAPCAST_MESSAGE_BASE; // default state, no current message tcp->base_message.sent.sec = 0; tcp->base_message.sent.usec = 0; tcp->base_message.received.sec = 0; tcp->base_message.received.usec = 0; tcp->received_header = false; tcp->last_sync.tv_sec = 0; tcp->last_sync.tv_usec = 0; tcp->id_counter = 0; tcp->time_message.latency.sec = 0; tcp->time_message.latency.usec = 0; result = gettimeofday(&now, NULL); if (result) { ESP_LOGI(TAG, "Failed to gettimeofday\r\n"); return ESP_FAIL; } esp_read_mac(base_mac, ESP_MAC_WIFI_STA); sprintf(mac_address, "%02X:%02X:%02X:%02X:%02X:%02X", base_mac[0], base_mac[1], base_mac[2], base_mac[3], base_mac[4], base_mac[5]); ESP_LOGI("SNAPCAST_TCP", "%02X:%02X:%02X:%02X:%02X:%02X", base_mac[0], base_mac[1], base_mac[2], base_mac[3], base_mac[4], base_mac[5]); base_message_t base_message = { SNAPCAST_MESSAGE_HELLO, // type 0x0, // id 0x0, // refersTo { now.tv_sec, now.tv_usec }, // sent { 0x0, 0x0 }, // received 0x0, // size }; hello_message_t hello_message = { mac_address, SNAPCAST_STREAM_CLIENT_NAME, // hostname "0.0.2", // client version "libsnapcast", // client name "esp32", // os name "xtensa", // arch 1, // instance mac_address, // id 2, // protocol version }; hello_message_serialized = hello_message_serialize(&hello_message, (size_t *)&(base_message.size)); if (!hello_message_serialized) { ESP_LOGI(TAG, "Failed to serialize hello message\r\b"); return ESP_FAIL; } if (result) { ESP_LOGI(TAG, "Failed to serialize base message\r\n"); return ESP_FAIL; } result=base_message_serialize(&base_message, base_message_serialized, BASE_MESSAGE_SIZE); if (result) { ESP_LOGI(TAG, "Failed to serialize base message\r\n"); return ESP_FAIL; } if(_snapcast_stream_socket_send(TAG, sockfd, base_message_serialized, BASE_MESSAGE_SIZE)<0){ free(hello_message_serialized); return ESP_FAIL; } if(_snapcast_stream_socket_send(TAG, sockfd, hello_message_serialized, base_message.size)<0){ free(hello_message_serialized); return ESP_FAIL; } //_snapcast_dispatch_event(self, tcp, NULL, 0, SNAPCAST_STREAM_STATE_CONNECTED); free(hello_message_serialized); sntp_snapcast=tcp; // send_time_tm_handle = xTimerCreate( "snapclient_timer", 5000 / portTICK_RATE_MS, pdTRUE, NULL, send_time_timer_cb); // xTimerStart(send_time_tm_handle, 0); return ESP_OK; } static esp_err_t _snapcast_read(audio_element_handle_t self, char *buffer, int len, TickType_t ticks_to_wait, void *context){ int rlen = 0; int result = 0; char base_buffer[BASE_MESSAGE_SIZE]; snapcast_stream_t *tcp = (snapcast_stream_t *)audio_element_getdata(self); _start: //rlen = esp_transport_read(tcp->t, buffer, BASE_MESSAGE_SIZE, tcp->timeout_ms); rlen = _snapcast_stream_socket_receive(TAG, tcp->sock, base_buffer, BASE_MESSAGE_SIZE); result = base_message_deserialize(&(tcp->base_message), base_buffer, BASE_MESSAGE_SIZE); //rlen = esp_transport_read(tcp->t, buffer, tcp->base_message.size, tcp->timeout_ms); rlen = _snapcast_stream_socket_receive(TAG, tcp->sock, buffer, tcp->base_message.size); if (result) { ESP_LOGW(TAG, "Failed to read base message: %d\r\n", result); return ESP_FAIL; } tcp->read_len=rlen; if (rlen < 0) { int result = _get_socket_error_code_reason(__func__, tcp->sock); if (result == 0) { ESP_LOGW(TAG, "TCP server actively closes the connection"); return ESP_OK; } return ESP_FAIL; } else if (rlen == 0) { ESP_LOGI(TAG, "Get end of the file"); // tcp->bits.new_wire_chunk=0; // tcp->bits.enabled=0; // tcp->bits.sync=0; // tcp->read_rb=snapcast_stream_ringbuffer_get_element(tcp->rb, SNAPCAST_MESSAGE_FIRST); // tcp->write_rb=snapcast_stream_ringbuffer_get_element(tcp->rb, SNAPCAST_MESSAGE_FIRST); //snapcast_stream_rinbuffer_reset(self); // audio_element_set_byte_pos(self, 0); // audio_element_set_ringbuf_done(self); // audio_element_reset_output_ringbuf(self); // _snapcast_dispatch_event(self, tcp, NULL, 0, SNAPCAST_STREAM_STATE_TCP_SOCKET_TIMEOUT_MESSAGE); goto _start; } else { //audio_element_update_byte_pos(self, rlen); } return rlen; } static esp_err_t _snapcast_write(audio_element_handle_t self, char *buffer, int len, TickType_t ticks_to_wait, void *context){ int w_len = 1; int r_len=0; int tmp=0; int64_t now_ms=0, diff_ms=0; struct timeval now, tv1; char *audio_buffer = NULL; //uint16_t base_message_type = *((uint16_t*)context); snapcast_stream_t *tcp = (snapcast_stream_t *)audio_element_getdata(self); int result = gettimeofday(&now, NULL); if (result) { ESP_LOGI(TAG, "Failed to gettimeofday\r\n"); return ESP_FAIL; } timersub(&now,(&tcp->server_uptime) ,&tv1); now_ms = tv1.tv_sec * 1000; now_ms +=tv1.tv_usec / 1000; if(tcp->base_message.type == SNAPCAST_MESSAGE_WIRE_CHUNK){ tmp= len - tcp->wire_chunk_message.size; ESP_LOGI(TAG,"Read Len - Wire Chunk Size=%d", tmp); tcp->write_rb->timestamp = tcp->wire_chunk_message.timestamp.sec * 1000; tcp->write_rb->timestamp+= tcp->wire_chunk_message.timestamp.usec / 1000; tcp->write_rb->data_size=len; memcpy(tcp->write_rb->data, buffer, tcp->write_rb->data_size); r_len=tcp->read_rb->data_size; audio_buffer = tcp->read_rb->data; w_len=audio_element_output(self, audio_buffer, r_len); }else{ //r_len=len; //audio_buffer = buffer; w_len=1; } if(w_len<1){ w_len=1; } return 1; } static esp_err_t _snapcast_process(audio_element_handle_t self, char *in_buffer, int in_len){ struct timeval now, tv2; //, last_time_sync; int result; int w_size = 1; int r_len = 1; int volume[] ={0, 0}; //char *buffer; if (gettimeofday(&now, NULL)) { ESP_LOGI(TAG, "Failed to gettimeofday\r\n"); } snapcast_stream_t *tcp = (snapcast_stream_t *)audio_element_getdata(self); r_len=_snapcast_read(self, in_buffer, BASE_MESSAGE_SIZE, tcp->timeout_ms, NULL); if(r_len > 0) { if(r_len > 4096){ ESP_LOGI(TAG, "Failed Write Size %d", tcp->wire_chunk_message.size); r_len=4096; }else if(r_len < 0){ return ESP_FAIL; } switch(tcp->base_message.type){ case SNAPCAST_MESSAGE_CODEC_HEADER: ESP_LOGI(TAG, "SNAPCAST_MESSAGE_CODEC_HEADER"); //tcp->bits.enabled=0; break; case SNAPCAST_MESSAGE_WIRE_CHUNK: //ESP_LOGI(TAG, "SNAPCAST_MESSAGE_WIRE_CHUNK"); result=wire_chunk_message_deserialize(&(tcp->wire_chunk_message), in_buffer, 0); if(result){ ESP_LOGI(TAG, "Failed to read wire chunks: %d", result); } //tcp->bits.enabled=1; //tcp->bits.new_wire_chunk=1; //buffer=in_buffer; //ESP_LOGI(TAG, "Message Wire Chunk Size=%d", tcp->wire_chunk_message.size); //ESP_LOGI(TAG, "Message Read Size =%d", r_len - 12); _snapcast_write(self, in_buffer+12, r_len - 12, 0x00, NULL); break; case SNAPCAST_MESSAGE_SERVER_SETTINGS: for(int x=4;xbase_message.size;x++){ ESP_LOGI(TAG, "SNAPCAST_MESSAGE_SERVER_SETTINGS: Buffer [%d]=%c", x, in_buffer[x]); } result = server_settings_message_deserialize(&(tcp->server_settings_message), in_buffer+4); if (result) { ESP_LOGI(TAG, "Failed to read server settings: %d\r\n", result); } ESP_LOGI(TAG, "Buffer length: %d", tcp->server_settings_message.buffer_ms); ESP_LOGI(TAG, "Ringbuffer size:%d", tcp->server_settings_message.buffer_ms*48*4); ESP_LOGI(TAG, "Latency: %d", tcp->server_settings_message.latency); ESP_LOGI(TAG, "Mute: %d", tcp->server_settings_message.muted); ESP_LOGI(TAG, "Setting volume: %d", tcp->server_settings_message.volume); volume[0]=tcp->server_settings_message.volume; volume[1]=tcp->server_settings_message.muted; //_snapcast_dispatch_event(self, tcp, (void*)volume, 4, SNAPCAST_STREAM_STATE_SERVER_SETTINGS_MESAGE); break; case SNAPCAST_MESSAGE_TIME: //ESP_LOGI(TAG, "SNAPCAST_MESSAGE_TIME: Buffer Read=%d", tcp->base_message.size); result = time_message_deserialize(&(tcp->time_message), in_buffer, TIME_MESSAGE_SIZE); if (result) { ESP_LOGI(TAG, "Failed to deserialize time message\r\n"); break; } tv2.tv_sec = tcp->base_message.received.sec; tv2.tv_usec= tcp->base_message.received.usec; timersub(&now,&tv2,&tcp->server_uptime); uint64_t server_uptime_ms = tcp->base_message.received.sec * 1000; server_uptime_ms += tcp->server_uptime.tv_usec / 1000; ESP_LOGI(TAG,"Server Up Time[ms]=%lld", server_uptime_ms); /* timersub(&now, &tcp->server_uptime, &tv1); time_ms=tv1.tv_sec * 1000; time_ms+=tv1.tv_usec/1000; ESP_LOGI(TAG_TIME, "Base Uptime %d.%3d", tcp->base_message.received.sec, tcp->base_message.received.usec/1000); ESP_LOGI(TAG_TIME, "Server Uptime %ld.%3ld", tv1.tv_sec, tv1.tv_usec/1000); ESP_LOGI(TAG_TIME, "Server Uptime %lldms", time_ms);*/ //ESP_LOGI(TAG, "Setting volume: %d", tcp->server_settings_message.volume); break; case SNAPCAST_MESSAGE_STREAM_TAGS: ESP_LOGI(TAG, "SNAPCAST_MESSAGE_STREAM_TAGS "); break; } /*if(size>1){ }*/ }/* else { w_size = r_len; }*/ memset(in_buffer, 0x00, 4096); return 1; } static esp_err_t _snapcast_close(audio_element_handle_t self) { AUDIO_NULL_CHECK(TAG, self, return ESP_FAIL); snapcast_stream_t *tcp = (snapcast_stream_t *)audio_element_getdata(self); AUDIO_NULL_CHECK(TAG, tcp, return ESP_FAIL); if (!tcp->is_open) { ESP_LOGE(TAG, "Already closed"); return ESP_FAIL; } /* if (-1 == esp_transport_close(tcp->t)) { ESP_LOGE(TAG, "TCP stream close failed"); return ESP_FAIL; }*/ tcp->is_open = false; if (AEL_STATE_PAUSED != audio_element_get_state(self)) { audio_element_set_byte_pos(self, 0); } return ESP_OK; } static esp_err_t _snapcast_destroy(audio_element_handle_t self) { AUDIO_NULL_CHECK(TAG, self, return ESP_FAIL); snapcast_stream_t *tcp = (snapcast_stream_t *)audio_element_getdata(self); AUDIO_NULL_CHECK(TAG, tcp, return ESP_FAIL); if (tcp->t) { esp_transport_destroy(tcp->t); tcp->t = NULL; } audio_free(tcp); return ESP_OK; } audio_element_handle_t snapcast_stream_init(snapcast_stream_cfg_t *config) { AUDIO_NULL_CHECK(TAG, config, return NULL); audio_element_cfg_t cfg = DEFAULT_AUDIO_ELEMENT_CONFIG(); audio_element_handle_t el; cfg.open = _snapcast_open; cfg.close = _snapcast_close; cfg.process = _snapcast_process; cfg.destroy = _snapcast_destroy; cfg.task_stack = config->task_stack; cfg.task_prio = config->task_prio; cfg.task_core = config->task_core; cfg.stack_in_ext = config->ext_stack; cfg.tag = "snapcast_client"; if (cfg.buffer_len == 0) { cfg.buffer_len = SNAPCAST_STREAM_BUF_SIZE; } snapcast_stream_t *tcp = audio_calloc(1, sizeof(snapcast_stream_t)); AUDIO_MEM_CHECK(TAG, tcp, return NULL); char *audio_buffer = audio_malloc(SNAPCAST_STREAM_RINGBUFFER_SIZE); AUDIO_MEM_CHECK(TAG, audio_buffer, return NULL); tcp->audio_buffer=audio_buffer; tcp->state= config->state; tcp->type = config->type; tcp->port = config->port; tcp->host = config->host; tcp->timeout_ms = config->timeout_ms; if (config->event_handler) { tcp->hook = config->event_handler; if (config->event_ctx) { tcp->ctx = config->event_ctx; } } tcp->rb=snapcast_stream_create_ringbuffer(SNAPCAST_STREAM_CUSTOM_RINGBUFFER_ELEMENTS); tcp->write_rb=snapcast_stream_ringbuffer_get_element(tcp->rb, SNAPCAST_STREAM_RINGBUFFER_FIRST); tcp->read_rb= snapcast_stream_ringbuffer_get_element(tcp->rb, SNAPCAST_STREAM_RINGBUFFER_FIRST); tcp->bits.new_wire_chunk=0; tcp->bits.enabled=0; tcp->bits.sync=0; cfg.read = _snapcast_read; cfg.write = NULL; el = audio_element_init(&cfg); AUDIO_MEM_CHECK(TAG, el, goto _snapcast_init_exit); audio_element_setdata(el, tcp); return el; _snapcast_init_exit: audio_free(tcp); return NULL; }
