LIBRARY ieee; USE ieee.std_logic_1164.ALL; USE ieee.numeric_std.ALL; ENTITY tb_berlinuhr IS END tb_berlinuhr; ARCHITECTURE behavior OF tb_berlinuhr IS -- Component Declaration for the Unit Under Test (UUT) COMPONENT berlinuhr PORT( clk32k : IN std_logic; setslow : IN std_logic; setfast : IN std_logic; sec : OUT std_logic; min : BUFFER std_logic_vector(3 downto 0); min5 : BUFFER std_logic_vector(10 downto 0); hr : BUFFER std_logic_vector(3 downto 0); hr5 : BUFFER std_logic_vector(3 downto 0) ); END COMPONENT; --Inputs signal clk32k : std_logic := '0'; signal setslow : std_logic := '0'; signal setfast : std_logic := '0'; --Outputs signal sec : std_logic; signal min : std_logic_vector(3 downto 0); signal min5 : std_logic_vector(10 downto 0); signal hr : std_logic_vector(3 downto 0); signal hr5 : std_logic_vector(3 downto 0); -- Clock period definitions constant clk32k_period : time := 30517 ns; BEGIN -- Instantiate the Unit Under Test (UUT) uut: berlinuhr PORT MAP ( clk32k => clk32k, setslow => setslow, setfast => setfast, sec => sec, min => min, min5 => min5, hr => hr, hr5 => hr5 ); -- Clock definitions clk32k <= not clk32k after clk32k_period/2; set_test: process begin wait for 100000 ms; setfast <= '1'; wait for 100000 ms; setfast <= '0'; wait for 100000 ms; setslow <= '1'; wait for 100000 ms; setslow <= '0'; wait; end process; END;
