#define IN1 2 #define IN2 3 #define IN3 4 #define IN4 5 #define OUT 10 // PB6, OC1B #define TCCR1B_MODE ((1 << WGM13) | (1 << WGM12)) volatile uint16_t counter; volatile uint8_t tccr1b_setup; void setup() { TIMSK1 |= (1 << OCIE1B); TCCR1B = 0; resetTimer1(HIGH); pinMode(IN1, INPUT_PULLUP); pinMode(IN2, INPUT_PULLUP); pinMode(IN3, INPUT_PULLUP); pinMode(IN4, INPUT_PULLUP); pinMode(OUT, OUTPUT); pinMode(13, OUTPUT); digitalWrite(13, HIGH); // VCC close to PB6 for indicator LED active LOW } void loop() { static uint32_t last; uint32_t now; // cooperative multi tasking // process keys every 5ms now = millis(); if ((now-last) >= 5) { last = now; process_keys(); } // do a lot of other things here! } void process_keys(void) { static uint8_t taste_alt; uint8_t taste; taste = 0; if (!digitalRead(IN1)) taste = 1; // highest priority else if (!digitalRead(IN2)) taste = 2; else if (!digitalRead(IN3)) taste = 3; else if (!digitalRead(IN4)) taste = 4; // lowest priority if (taste != taste_alt) { switch (taste) { case 1: initTimer1( 40, 80, 1, 1, 2); break; case 2: initTimer1(640, 3200, 1, 0, 0); break; case 3: initTimer1(250, 25000, 64, 0, 0); break; case 4: resetTimer1(LOW); break; default: resetTimer1(HIGH); break; } taste_alt = taste; } } void initTimer1 (uint16_t duty, uint16_t periode, uint16_t prescaler, bool pulse_limit, uint16_t pulse_cnt) { uint8_t tccr1b_tmp; //uint16_t periode = periode in ms / prescaler * 16.000 //uint16_t duty = duty in ms * prescaler / 16.000 resetTimer1(HIGH); TCCR1A = (1 << WGM11) | (1 << WGM10) | (1 << COM1B0) | (1 << COM1B1); tccr1b_tmp = TCCR1B_MODE; if (duty > periode) duty = periode; OCR1A = periode - 1; OCR1B = duty - 1; switch (prescaler) { case 1 : tccr1b_tmp |= (1 << CS10); break; case 8 : tccr1b_tmp |= (1 << CS11); break; case 64 : tccr1b_tmp |= (1 << CS11) | (1 << CS10); break; case 256 : tccr1b_tmp |= (1 << CS12); break; case 1024 : tccr1b_tmp |= (1 << CS12) | (1 << CS10); break; default : break; // otherwise timer remains stopped } tccr1b_setup = tccr1b_tmp; if (pulse_limit && pulse_cnt > 0) { counter = pulse_cnt - 1; if (pulse_cnt == 1) tccr1b_setup = TCCR1B_MODE; // TCCR1B prescaler bits = 0 on next interrupt to stop timer } else { counter = 0; } TCCR1B = tccr1b_tmp; // start timer 1 } void resetTimer1 (bool polarity) { tccr1b_setup = TCCR1B_MODE; // stop timer 1, keep mode config while ((TCCR1B & 0x7) != 0); // wait for synchronous stop of timer 1 counter = 0; if (polarity) { TCCR1A = (1 << WGM11) | (1 << WGM10) | (1 << COM1B0) | (1 << COM1B1); // Set on match } else { TCCR1A = (1 << WGM11) | (1 << WGM10) | (1 << COM1B1); // Clear on match } TCCR1C = (1 << FOC1B); // Force match, switch IO pin OCR1A = 0; // Reset periode OCR1B = 0; // Reset duty TCNT1 = 0; // initialize counter value to 0 } ISR(TIMER1_COMPB_vect) { // Interrupt when duty is reached TCCR1B = tccr1b_setup; uint16_t tmp = counter; // temporary copy for faster access to volatile variable if (tmp) { tmp--; if (!tmp) tccr1b_setup = TCCR1B_MODE; // clear prescaler bits, stop timer on next ISR call counter = tmp; } }
