// registers for flash control reg [7:0] r_flash_status; reg [15:0] r_flash_ctrl; reg r_flash_ctrl_wr; reg [16:0] r_flash_addr; reg r_flash_write; reg r_flash_autoinc; reg [31:0] r_flash_data_in; reg [31:0] r_flash_data_out; reg r_flash_data_wr; reg r_reconfig; // internal signals reg [7:0] regmem [0:31]; // register block reg [7:0] regread; reg [7:0] bus_value; reg [15:0] bus_ttl; // writing registers integer i; // for loop index used for reset of all registers always @(posedge clkb or negedge rstb) begin if (~rstb) begin // reset condition for (i=0;i<27;i=i+1) regmem[i] <= 8'h00; // do not reset registers 27...31 bus_value <= 8'd0; bus_ttl <= 16'd0; // reset flash control registers r_flash_addr <= 17'd0; r_flash_ctrl <= 16'hFFFF; r_flash_data_out <= 32'd0; r_flash_write <= 1'd0; r_flash_autoinc <= 1'd0; r_flash_ctrl_wr <= 1'b0; r_flash_data_wr <= 1'b0; r_reconfig <= 1'b0; end else begin i=0; // fix warning // when signals are valid write into register memory if (ienb) begin if (flashen & mainreg) begin if (~cs) begin if (~rw) begin case (addr) 5'h01: begin r_flash_ctrl[7:0] <= i_data; r_flash_ctrl[15:8] <= r_flash_ctrl[15:8] | 8'b00000111; r_flash_ctrl_wr <= r_flash_write; end 5'h02: begin r_flash_ctrl[15:8] <= i_data; r_flash_ctrl[7:0] <= r_flash_ctrl[7:0] | {8{&i_data[2:0]}}; r_flash_ctrl_wr <= r_flash_write; end 5'h03: r_flash_addr[7:0] <= i_data; 5'h04: r_flash_addr[15:8] <= i_data; 5'h05: begin r_flash_write <= (~r_flash_write & i_data[7]) ? ({i_data,r_flash_addr[15:0]} == `WRITEPROTECTVALUE) : i_data[7]; r_flash_autoinc <= i_data[6]; r_flash_addr[16] <= i_data[0]; end 5'h06: r_flash_data_out[7:0] <= i_data; 5'h07: r_flash_data_out[15:8] <= i_data; 5'h08: r_flash_data_out[23:16] <= i_data; 5'h09: begin r_flash_data_out[31:24] <= i_data; r_flash_data_wr <= r_flash_write; end 5'h0d: r_reconfig <= i_data[0]; 5'h19: regmem[addr] <= i_data; 5'h1A: regmem[addr] <= i_data; default: ; // nothing endcase end else begin // read condition r_flash_ctrl_wr <= 1'b0; r_flash_data_wr <= 1'b0; if (addr == 5'h09) begin // read from data[31:24] triggers autoinc r_flash_addr <= (~r_flash_write & r_flash_autoinc) ? r_flash_addr + 17'd1 : r_flash_addr; end end end else begin r_flash_ctrl_wr <= 1'b0; r_flash_data_wr <= 1'b0; if (r_flash_data_wr) begin // in case something had been written in the last cycle r_flash_addr <= (r_flash_write & r_flash_autoinc) ? r_flash_addr + 17'd1 : r_flash_addr; end end end // standard write with bitrot else if ( (noextra | magicen) & ( ~(rw|cs)) ) begin regmem[addr] <= i_data; // write condition bus_value <= i_data; bus_ttl <= conf[4] ? `BITROT8580 : `BITROT6581; // well, these values are just values... end else begin if (|bus_ttl) begin bus_ttl <= bus_ttl - 16'd1; bus_value <= bus_value & ( {8{|bus_ttl[15:7]}} // high up to the last 128 samples | {bus_ttl[4],bus_ttl[2],bus_ttl[6]|bus_ttl[5],bus_ttl[1],bus_ttl[6],bus_ttl[3],bus_ttl[7]|bus_ttl[6],bus_ttl[0]}); // above we fade out the last 128 values in a weired but very predictable pattern end else begin // bitrot done bus_value <= 8'd0; bus_ttl <= 16'd0; end end end // update configuration change when nothing else happens else if (config_write) begin regmem[27] <= 8'h00; regmem[28][7:4] <= 4'h0; // upper 4 bits of bias are zero regmem[28][3:0] <= config_reg[configselect_current][3:0]; regmem[29] <= config_reg[configselect_current][15:8]; regmem[30] <= config_reg[configselect_current][23:16]; regmem[31] <= config_reg[configselect_current][31:24]; end end end assign configselect_current = {~configselect_d,mainreg[0]};
