/* ************************************************************************ * * L/C meter (hardware option) * * (c) 2020-2023 by Markus Reschke * * ************************************************************************ */ /* * local constants */ /* source management */ #define TOOLS_LC_METER_C /* * include header files */ /* local includes */ #include "config.h" /* global configuration */ #include "common.h" /* common header file */ #include "variables.h" /* global variables */ #include "functions.h" /* external functions */ #include "colors.h" /* color definitions */ /* global includes */ #include /* fixed-point math */ /* * local constants */ /* calculation modi */ #define CALC_CI 0 /* calculate C_i */ #define CALC_CX 1 /* calculate C_x */ /* math */ #define PI 3.14159265358979323846 /* pi */ /* limits for f_i (base frequency, around 595 kHz) */ #define FI_MIN 550000 /* 550 kHz */ #define FI_MAX 650000 /* 650 kHz */ /* limits for f_p (frequency with C_p, around 423 kHz) */ #define FP_MIN 400000 /* 400 kHz */ #define FP_MAX 440000 /* 440 kHz */ /* * local variables */ #ifdef HW_LC_METER /* pulse counter (from tools_counter.c) */ extern volatile uint32_t Pulses; /* number of pulses */ /* frequencies */ uint32_t LC_Freq; /* measured frequency (in Hz) */ uint32_t f_i; /* base frequency (in Hz) */ uint32_t f_x; /* frequency with C_x/L_x (in Hz) */ /* capacitances */ uint32_t C_i; /* C_i (in 0.1 pF) */ #endif /* ************************************************************************ * L/C meter hardware option * - uses shared ISRs in tools_signal.c for frequency counter * - circuit based on AADE L/C meter from Neil Hecht * - It's basically an LC oscillator (parallel mode) with an additional * known reference cap which can be enabled via a relay. A second relay * selects the DUT (L or C). C_x is connected in parallel to the LC * tank circuit, and L_x in series with L from the LC tank circuit. * - max. frequency of LC oscillator (L_i 82µH / C_i 1nF): about 600kHz * ************************************************************************ */ /* * hints: * - pin assigment: * f_out COUNTER_IN T0 * C_p LC_CTRL_CP reference cap * L/C LC_CTRL_LC L/C mode selection * - control lines: * - C_p (parallel reference cap) * low - disable C_p * high/HiZ - enable C_p * - L/C (L/C mode selection) * low - C * high - L * - reference cap: LC_METER_C_REF (in 0.1 pF) */ /* Measuring C - Parallel resonance: f_i = 1 / (2pi * sqrt(L_i * C_i)) - Adding an unknown capacitor C_x in parallel: f_x = 1 / (2pi * sqrt(L_i * (C_i + C_x))) - With f_i/f_x we get: f_i/f_x = (2pi * sqrt(L_i * (C_i + C_x))) / (2pi * sqrt (L_i * C_i))) (f_i/f_x)^2 = (L_i * (C_i + C_x)) / (L_i * C_i) = (C_i + C_x) / C_i C_x = C_i * ((f_i/f_x)^2 - 1) Measurement of C_i by using a known reference cap C_p - same as above, just with C_p instead of C_x: f_p = 1 / (2pi * sqrt(L_i * (C_i + C_p))) - C_i = C_p / ((f_i/f_p)^2 - 1) Measuring L - Parallel resonance: f_i = 1 / (2pi * sqrt(L_i * C_i)) - resolve for L_i: L_i = 1 / (C_i * (2pi * f_i)^2) - add unknown inductance L_x in series with L_i: f_s = 1 / (2pi * sqrt(L_s * C_i)) L_s = 1 / (C_i * (2pi * f_s)^2) - with L_s = L_i + L_x L_x = L_s - L_i = (1 / (C_i * (2pi * f_s)^2)) - (1 / (C_i * (2pi * f_i)^2)) = (1 / (C_i * (2pi)^2)) * ((1 / f_s^2) - (1 / f_i^2)) Measurement ranges: - L_i 82µH / C_i 1nF (base frequency around 595 kHz) firmware enforces a lower frequency limit of 10 kHz Mode feasible theoretically PIC LC Meter ------------------------------------------------------ L 1nH - 150mH 0.2nH - 250mH 10nH - 100mH C 10fF - 33nF 3.3fF - 3.5µF 0.1pF - 900nF - 120nF with signal clean-up */ #ifdef HW_LC_METER /* * measure frequency of LC oscillator * - frequency input: T0 * - requires idle sleep mode to keep timers running when MCU is sleeping * - max. frequency is 1/4 of MCU clock * - stores frequency in global variable xxx * * returns: * - 0 for measurement done * - key code >0 in case of any user feedback */ uint8_t Get_LC_Frequency(void) { uint8_t Flag; /* loop control flag */ uint8_t Test = 0; /* user feedback */ uint8_t Old_DDR; /* old DDR state */ uint8_t Index; /* prescaler table index */ uint8_t Bits; /* prescaler register bits */ uint16_t GateTime; /* gate time in ms */ uint16_t Top; /* top value for timer */ uint32_t Value; /* temporary value */ /* control flags */ #define RUN_FLAG 1 /* run flag */ #define WAIT_FLAG 2 /* enter/run waiting loop */ #define GATE_FLAG 3 /* gatetime flag */ /* * We use Timer1 for the gate time and Timer0 to count pulses of the * unknown signal. Max. frequency for Timer0 is 1/4 of the MCU clock. */ LC_Freq = 0; /* reset frequency value */ Flag = RUN_FLAG; /* enter measurement loop */ /* auto ranging Timer1 top value (gate time) - top = gatetime * MCU_cycles / prescaler - gate time in µs - MCU cycles per µs - top max. 2^16 - 1 Frequency - f = pulses / gatetime - pulses = f * gatetime range gate time prescaler MCU clock remark ---------------------------------------------------------- >= 400kHz 1000ms 1024 > 16MHz < 1nF 1000ms 256 <= 16MHz < 400kHz 100ms 64 all > 1nF */ /* start values for autoranging (assuming high frequency) */ GateTime = 100; /* gate time 100ms */ Index = 2; /* prescaler table index (prescaler 64:1) */ /* set up Timer0 (pulse counter) */ TCCR0A = 0; /* normal mode (count up) */ TIFR0 = (1 << TOV0); /* clear overflow flag */ TIMSK0 = (1 << TOIE0); /* enable overflow interrupt */ /* set up Timer1 (gate time) */ TCCR1A = 0; /* normal mode (count up) */ TIFR1 = (1 << OCF1A); /* clear output compare A match flag */ TIMSK1 = (1 << OCIE1A); /* enable output compare A match interrupt */ /* set up T0 as input (pin might be shared with display) */ Old_DDR = COUNTER_DDR; /* save current settings */ COUNTER_DDR &= ~(1 << COUNTER_IN); /* signal input */ wait500us(); /* settle time */ /* * measurement loop */ while (Flag) { /* update prescaler */ Top = DATA_read_word(&T1_Prescaler_table[Index]); /* prescaler value */ Bits = DATA_read_byte(&T1_RegBits_table[Index]); /* prescaler bits */ /* calculate compare value for Timer1 (gate time) */ /* top = gatetime * MCU_cycles / timer prescaler */ Value = GateTime; /* gatetime (in ms) */ /* * MCU cycles per µs and scale gatetime to µs */ Value *= (MCU_CYCLES_PER_US * 1000); Value /= Top; /* divide by timer prescaler */ Top = (uint16_t)Value; /* use lower 16 bit */ /* start timers */ Pulses = 0; /* reset pulse counter */ Flag = WAIT_FLAG; /* enter waiting loop */ TCNT0 = 0; /* Timer0: reset pulse counter */ TCNT1 = 0; /* Timer1: reset gate time counter */ OCR1A = Top; /* Timer1: set gate time */ TCCR1B = Bits; /* start Timer1: prescaler */ TCCR0B = (1 << CS02) | (1 << CS01); /* start Timer0: clock source T0 - falling edge */ /* for rising edge: | (1 << CS00) */ /* wait for timer1 or key press */ while (Flag == WAIT_FLAG) { if (TCCR1B == 0) /* Timer1 stopped by ISR */ { Flag = GATE_FLAG; /* end loop and signal Timer1 event */ } else /* Timer1 still running */ { /* wait for user feedback */ Test = TestKey(0, CHECK_KEY_TWICE | CHECK_BAT); if (Test) /* anything but timeout */ { Flag = 0; /* end processing loop */ } } } Cfg.OP_Control &= ~OP_BREAK_KEY; /* clear break signal (just in case) */ /* * process measurement */ if (Flag == GATE_FLAG) /* got measurement */ { /* total sum of pulses during gate period */ Pulses += TCNT0; /* add counter of Timer0 */ /* * calculate frequency * - f = pulses / gatetime * - 20MHz MCU: 5M pulses per second at maximum */ Value = Pulses; /* number of pulses */ Value *= 1000; /* scale to ms */ Value /= GateTime; /* divide by gatetime (in ms) */ Flag = 0; /* end loop */ /* autoranging */ if (Value < 400000UL) /* range overrun */ { if (GateTime == 1000) /* in bottom range */ { GateTime = 100; /* change to top range */ Index = 2; /* prescaler 64:1 */ Flag = RUN_FLAG; /* keep going */ } /* else: already in top range */ } else /* range underrun */ { if (GateTime == 100) /* in top range */ { GateTime = 1000; /* change to bottom range */ #if CPU_FREQ > 16000000 Index = 4; /* prescaler 1024:1 */ #else Index = 3; /* prescaler 256:1 */ #endif Flag = RUN_FLAG; /* keep going */ } /* else: already in bottom range */ } if (Flag == 0) /* no change of range */ { LC_Freq = Value; /* save frequency */ } } } /* * clean up */ /* T0 pin might be shared with display */ COUNTER_DDR = Old_DDR; /* restore old settings */ TIMSK0 = 0; /* disable all interrupts for Timer0 */ TIMSK1 = 0; /* disable all interrupts for Timer1 */ /* local constants */ #undef RUN_FLAG #undef WAIT_FLAG #undef GATE_FLAG return Test; } /* * calculate C_x or C_i * - C_x = C_i * ((f_i/f_x)^2 - 1) * - C_i = C_p / ((f_i/f_p)^2 - 1) * - expects f_i >= f_x or f_i > f_p * * requires: * - Mode * CALC_CI: calculate C_i * CALC_CX: calculate C_x */ void LC_Calc_C(uint8_t Mode) { unsigned long accum t_r; /* frequency term */ unsigned long accum C_x; /* capacitance */ /* * Simplifications: * - max. C_x is about 900nF -> f_x = 20kHz * so we assume lowest f_x to be 10kHz * - highest f_x is f_i (around 600kHz) * - f_x: 10kHz up to 600kHz * f_i/f_x: 60 down to 1 * (f_i/f_x)^2: 3600 down to 1 */ /* frequency term t_r = (f_i/f_x)^2 - 1 */ t_r = (unsigned long accum)f_i; /* base frequency (C_i/L_i) */ t_r /= (unsigned long accum)f_x; /* frequency with C_x */ t_r *= t_r; /* ^2 */ t_r -= 1; /* -1 */ /* capacitance value */ if (Mode == CALC_CI) /* calculate C_i */ { /* C_i = C_p / ((f_i/f_p)^2 - 1) = C_p / t_r */ /* C_p in 0.1 pF */ C_x = (unsigned long accum)LC_METER_C_REF*10 / t_r; /* in 0.1 pF */ /* get integer part incl. rounding */ C_i = bitsulk(C_x + 0.5ULK) >> ULACCUM_FBIT; /* in 0.1 pF */ } else /* calculate C_x */ { /* C_x = C_i * ((f_i/f_x)^2 - 1) = C_i * t_r */ /* C_i in 0.1 pF */ C_x = (unsigned long accum)C_i * t_r; /* in 0.1 pF */ /* additional scaling for low values */ if (C_x < 10000ULK) /* < 1 nF */ { /* rescale to 10 fF */ C_x *= 10; /* rescale to 10^-14 */ Caps[0].Scale = -14; /* for 10 fF */ } else /* >= 1 nF */ { /* keep 0.1 pF scale */ Caps[0].Scale = -13; /* for 0.1 pF */ } /* get integer part incl. rounding */ Caps[0].Value = bitsulk(C_x + 0.5ULK) >> ULACCUM_FBIT; } } /* * calculate L_x * - L_x = (1 / (C_i * (2pi)^2)) * ((1 / f_s^2) - (1 / f_i^2)) * - expects f_i >= f_s */ void LC_Calc_L() { unsigned long accum t_i; /* frequency term #1 */ unsigned long accum t_s; /* frequency term #2 */ /* * Simplifications: * - max. L_x is about 100mH -> f_s = 17kHz * so we assume lowest f_s to be 10kHz * - highest f_s is f_i (around 600kHz) * - f_s: 10kHz up to 600kHz * f_i^2: 3.6 * 10^11 * 1 / f_i^2: 2.77 * 10^-12 * f_s^2: 1 * 10^8 up to 3.6 * 10^11 * 1 / f_s^2: 1 * 10^-8 down to 2.77 * 10^-12 * - 1 / (C_i * (2pi)^2): ? */ /* frequency term t_s = 1 / f_s^2 */ t_s = (unsigned long accum)f_x; /* frequency with L_x */ t_s /= 10000; /* rescale to 10k */ t_s *= t_s; /* ^2 */ t_s = 1 / t_s; /* in 10^-8 */ /* frequency term t_i = 1 / f_i^2 */ t_i = (unsigned long accum)f_i; /* base frequency (C_i/L_i) */ t_i /= 10000; /* rescale to 10^4 */ t_i *= t_i; /* ^2 */ t_i = 1 / t_i; /* in 10^-8 */ /* (1 / f_s^2) - (1 / f_i^2) = t_s - t_i */ t_s -= t_i; /* in 10^-8 */ /* reuse t_i for capacitance term: 1 / (C_i * (2pi)^2) */ /* C_i in 0.1pF (10^-13) */ t_i = (unsigned long accum)(PI * PI * 4); /* (2pi)^2) */ t_i *= C_i; /* * C_i */ t_i /= 100000; /* rescale to 10^-8 */ t_i = 1 / t_i; /* in 10^8 */ t_i *= 1000000; /* rescale to 10^-2 */ /* L_x = * */ t_i *= t_s; /* in µH (10^-6) */ /* additional scaling for low values */ if (t_i < 1000ULK) /* < 1 mH */ { /* rescale to nH */ t_i *= 1000; /* rescale to 10^-9 */ Inductor.Scale = -9; /* for nH */ } else /* >= 1 nH */ { /* keep µH scale */ Inductor.Scale = -6; /* for µH */ } /* get integer part incl. rounding */ Inductor.Value = bitsulk(t_i + 0.5ULK) >> ULACCUM_FBIT; } /* * L/C meter self-adjustment * - measure base frequency f_i (C_i/L_i) * - measure C_i with help of C_p * * returns: * - 0 on any problem * - 1 on success */ uint8_t LC_SelfAdjust(void) { uint8_t Flag = 0; /* return value */ uint8_t Test; /* user feedback */ uint8_t OldState; /* old state of L/C selection */ /* inform user */ LCD_ClearLine2(); /* clear line #2 */ SmoothLongKeyPress(); /* smooth UI after long key press */ Display_EEString(Adjusting_str); /* display: adjusting */ /* get current state of L/C selection */ OldState = LC_CTRL_PORT & (1 << LC_CTRL_LC); /* filter bit for L/C */ /* select C mode: set control line for L/C selection low */ LC_CTRL_PORT &= ~(1 << LC_CTRL_LC); /* clear bit */ MilliSleep(100); /* settling time */ /* measure base frequency f_i */ Test = Get_LC_Frequency(); if (Test == 0) /* got frequency */ { /* check if f_i is fine (roughly around 600 kHz */ if ((LC_Freq >= FI_MIN) && (LC_Freq <= FI_MAX)) { f_i = LC_Freq; /* save f_i */ /* enable reference cap C_p */ LC_CTRL_PORT |= (1 << LC_CTRL_CP); /* High level +5V enable reference cap C_p */ MilliSleep(100); /* settling time */ /* measure f_p */ Test = Get_LC_Frequency(); if (Test == 0) /* got frequency */ { /* check if f_p is fine (roughly around 423 kHz) */ if ((LC_Freq >= FP_MIN) && (LC_Freq <= FP_MAX)) { f_x = LC_Freq; /* update f_p */ LC_Calc_C(CALC_CI); /* calculate C_i */ Flag = 1; /* signal success */ } /* else: invalid f_p */ } /* else: aborted by user feedback */ /* disable reference cap C_p */ LC_CTRL_PORT &= ~(1 << LC_CTRL_CP); /*Low level 0V disable reference cap C_p */ MilliSleep(100); } /* else: f_i out of range */ } /* else: aborted by user feedback */ /* restore old state of L/C selection */ LC_CTRL_PORT |= OldState; /* set bit (when set in OldState) */ return Flag; } /* * L/C meter * * returns: * - 1 on success * - 0 on any error */ uint8_t LC_Meter(void) { // R_DDR = 0; uint8_t Flag = 1; /* return value */ uint8_t Run = 0; /* loop control flag */ uint8_t Test; /* user feedback */ uint8_t CtrlDir; /* control DDR state */ uint8_t Mode; /* measurement mode (L/C) */ uint8_t Delay; /* delay flag */ /* control flags */ #define RUN_FLAG 0b00000001 /* run flag */ #define UPDATE_MODE 0b00000010 /* update mode (L/C) */ #define SHOW_VALUE 0b00000100 /* show value */ #define NO_VALUE 0b00001000 /* no value available */ /* measurement mode */ #define MODE_C 0 /* C */ #define MODE_L 1 /* L */ /* show info */ LCD_Clear(); /* clear display */ #ifdef UI_COLORED_TITLES /* display: LC Meter */ Display_ColoredEEString(LC_Meter_str, COLOR_TITLE); #else Display_EEString(LC_Meter_str); /* display: LC Meter */ #endif /* * init */ /* set up control lines */ CtrlDir = LC_CTRL_DDR; /* get current direction */ LC_CTRL_DDR |= (1 << LC_CTRL_CP); /* set C_p to HiZ mode (disable C_p) */ LC_CTRL_DDR |= (1 << LC_CTRL_LC); /* set L/C selection to output mode */ /* initial self-adjustment */ Test = LC_SelfAdjust(); /* run adjustment */ if (Test) /* adjustment done */ { /* set start values */ Mode = MODE_C; /* start with C */ Run = RUN_FLAG | UPDATE_MODE; /* set control flags */ } else /* adjustment error */ { Flag = 0; /* signal error */ } /* * processing loop */ while (Run) { /* * set measurement mode */ if (Run & UPDATE_MODE) { /* select mode */ if (Mode == MODE_C) /* measure C */ { /* set control line for L/C selection low */ LC_CTRL_PORT &= ~(1 << LC_CTRL_LC); /* clear bit */ } else /* measue L */ { /* set control line for L/C selection high */ LC_CTRL_PORT |= (1 << LC_CTRL_LC); /* set bit */ } /* trigger output of "no value" */ Run |= SHOW_VALUE | NO_VALUE; Run &= ~UPDATE_MODE; /* clear flag */ } /* * manage measurement */ Test = 0; /* reset value */ if (! (Run & NO_VALUE)) { Test = Get_LC_Frequency(); /* measure f_x/f_s */ if (Test == 0) /* got frequency */ { f_x = LC_Freq; /* save f_x/f_s */ /* f_x must be lower than f_i */ if (f_i >= f_x) /* f_x lower than f_i */ { Delay = 0; /* reset flag */ if (f_x < 400000UL) /* < 400 kHz / 100 ms gate time */ { Delay = 1; /* set flag for short gate time */ } if (Mode == MODE_C) /* C */ { /* check for minimum frequency */ if (f_x >= 10000UL) /* >= 10 kHz */ { /* frequency is fine */ LC_Calc_C(CALC_CX); /* calculate C_x */ } else /* < 10 kHz */ { /* frequency too low */ Run |= NO_VALUE; /* show "no value" */ } } else /* L */ { /* missing L_x causes open LC tank with 0 Hz */ if (f_x <= 10) /* allow some slack */ { /* we like to see 0.0nH */ f_x = f_i; /* simply take f_i as f_x */ } /* check for minimum frequency */ if (f_x >= 10000UL) /* >= 10 kHz */ { /* frequency is fine */ LC_Calc_L(); /* calculate L_x */ } else /* < 10 kHz */ { /* frequency too low */ Run |= NO_VALUE; /* show "no value" */ } } if (Delay) /* short gate time */ { /* delay the measurement update */ Test = TestKey(500, CHECK_KEY_TWICE | CHECK_BAT); } } else /* f_x higher than f_i */ { /* f_i has drifted (increased) */ Run |= NO_VALUE; /* show "no value" */ /* todo: update f_i (auto-adjust)? */ } #ifdef LC_METER_SHOW_FREQ /* display frequency of LC oscillator in line #3 */ LCD_ClearLine3(); /* clear line #3 */ Display_Char('f'); /* display: f */ Display_Colon(); /* display: : */ Display_Space(); Display_FullValue(LC_Freq, 0, 0); /* display frequency */ Display_EEString(Hertz_str); /* display: Hz */ #endif Run |= SHOW_VALUE; /* show value */ } } /* * process user feedback */ if (Test) /* any user feedback */ { #ifdef HW_KEYS /* short key press, right key or left key */ if ((Test == KEY_SHORT) || (Test == KEY_RIGHT) || (Test == KEY_LEFT)) #else if (Test == KEY_SHORT) /* short key press */ #endif { /* change mode */ if (Mode == MODE_C) /* from C */ { Mode = MODE_L; /* to L */ } else /* from L */ { Mode = MODE_C; /* to C */ } Run |= UPDATE_MODE; /* update mode */ } else if (Test == KEY_LONG) /* long key press */ { /* repeat self-ajustment */ Test = LC_SelfAdjust(); /* run self-ajustment */ if (Test) /* adjustment done */ { Run |= SHOW_VALUE | NO_VALUE; /* display "no value" */ } else /* adjustment error */ { Run = 0; /* end processing loop */ Flag = 0; /* signal error */ } } else if (Test == KEY_TWICE) /* two short key presses */ { /* end tool */ Run = 0; /* end processing loop */ } } /* * display measurement value in line #2 */ if (Run & SHOW_VALUE) { /* display mode */ LCD_ClearLine2(); /* clear line */ if (Mode == MODE_C) /* C */ { Test = 'C'; } else /* L */ { Test = 'L'; } Display_Char(Test); /* display L/C */ Display_Colon(); /* display value */ Display_Space(); if (Run & NO_VALUE) /* no value */ { Display_Minus(); /* display: -*/ } else /* value */ { if (Mode == MODE_C) /* C */ { /* display capacitance */ Display_Value(Caps[0].Value, Caps[0].Scale, 'F'); } else /* L */ { /* display inductance */ Display_Value(Inductor.Value, Inductor.Scale, 'H'); } } Run &= ~(SHOW_VALUE | NO_VALUE); /* clear flags */ } } /* * clean up */ /* filter control lines which were in input mode */ CtrlDir ^= (1 << LC_CTRL_CP) | (1 << LC_CTRL_LC); CtrlDir &= (1 << LC_CTRL_CP) | (1 << LC_CTRL_LC); LC_CTRL_DDR &= ~CtrlDir; /* set former direction */ /* local constants */ #undef RUN_FLAG #undef UPDATE_MODE #undef SHOW_VALUE #undef NO_VALUE #undef MODE_C #undef MODE_L return Flag; } #endif /* ************************************************************************ * clean-up of local constants * ************************************************************************ */ /* misc constants */ #undef CALC_CI #undef CALC_CX #undef PI #undef FI_MIN #undef FI_MAX #undef FP_MIN #undef FP_MAX /* source management */ #undef TOOLS_LC_METER_C /* ************************************************************************ * EOF * ************************************************************************ */
