/************************************************************************/ /* */ /* Debouncing 8 Keys */ /* Sampling 4 Times */ /* With Repeat Function */ /* */ /* Author: Peter Dannegger */ /* danni@specs.de */ /* */ /************************************************************************/ #include #include #include #ifndef F_CPU #define F_CPU 1000000 // processor clock frequency #warning kein F_CPU definiert #endif #define KEY_DDR DDRB #define KEY_PORT PORTB #define KEY_PIN PINB #define KEY0 0 #define KEY1 1 #define KEY2 2 #define ALL_KEYS (1<< KEY0|1<< KEY1|1<< KEY2) #define REPEAT_MASK (1<< KEY1|1<< KEY2) // repeat: key1, key2 #define REPEAT_START 50 // after 500ms #define REPEAT_NEXT 20 // every 200ms #define LED_DDR DDRA #define LED_PORT PORTA #define LED0 0 #define LED1 1 #define LED2 2 volatile uint8_t key_state; // debounced and inverted key state: // bit = 1: key pressed volatile uint8_t key_press; // key press detect volatile uint8_t key_rpt; // key long press and repeat ISR( TIMER0_OVF_vect ) // every 10ms { static uint8_t ct0= 0xFF, ct1= 0xFF, rpt; uint8_t i; TCNT0 = (uint8_t)(int16_t)-(F_CPU / 1024 * 10e-3 + 0.5); // preload for 10ms i = key_state ^ ~KEY_PIN; // key changed ? ct0 = ~(ct0 & i); // reset or count ct0 ct1 = ct0 ^ (ct1 & i); // reset or count ct1 i &= ct0 & ct1; // count until roll over ? key_state ^= i; // then toggle debounced state key_press |= key_state & i; // 0->1: key press detect if( (key_state & REPEAT_MASK) == 0 ) // check repeat function rpt = REPEAT_START; // start delay if( --rpt == 0 ){ rpt = REPEAT_NEXT; // repeat delay key_rpt |= key_state & REPEAT_MASK; } } /////////////////////////////////////////////////////////////////// // // check if a key has been pressed. Each pressed key is reported // only once // uint8_t get_key_press( uint8_t key_mask ) { cli(); // read and clear atomic ! key_mask &= key_press; // read key(s) key_press ^= key_mask; // clear key(s) sei(); return key_mask; } /////////////////////////////////////////////////////////////////// // // check if a key has been pressed long enough such that the // key repeat functionality kicks in. After a small setup delay // the key is reported being pressed in subsequent calls // to this function. This simulates the user repeatedly // pressing and releasing the key. // uint8_t get_key_rpt( uint8_t key_mask ) { cli(); // read and clear atomic ! key_mask &= key_rpt; // read key(s) key_rpt ^= key_mask; // clear key(s) sei(); return key_mask; } /////////////////////////////////////////////////////////////////// // // check if a key is pressed right now // uint8_t get_key_state( uint8_t key_mask ) { key_mask &= key_state; return key_mask; } /////////////////////////////////////////////////////////////////// // uint8_t get_key_short( uint8_t key_mask ) { cli(); // read key state and key press atomic ! return get_key_press( ~key_state & key_mask ); } /////////////////////////////////////////////////////////////////// // uint8_t get_key_long( uint8_t key_mask ) { return get_key_press( get_key_rpt( key_mask )); } int main( void ) { LED_PORT = 0xFF; LED_DDR = 0xFF; // Configure debouncing routines KEY_DDR &= ~ALL_KEYS; // configure key port for input KEY_PORT |= ALL_KEYS; // and turn on pull up resistors TCCR0 = 1<< CS02|1<< CS00; // divide by 1024 TCNT0 = (uint8_t)(int16_t)-(F_CPU / 1024 * 10e-3 + 0.5); // preload for 10ms TIMSK |= 1<< TOIE0; // enable timer interrupt sei(); while(1){ if( get_key_short( 1<< KEY1 )) LED_PORT ^= 1<< LED1; if( get_key_long( 1<< KEY1 )) LED_PORT ^= 1<< LED2; // single press and repeat if( get_key_press( 1<< KEY2 ) || get_key_rpt( 1<< KEY2 )){ uint8_t i = LED_PORT; i = (i & 0x07) | ((i<< 1) & 0xF0); if( i < 0xF0 ) i |= 0x08; LED_PORT = i; } } }
