pi@raspberrypi:~ $ systemctl start mariadb ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units === Legitimierung ist zum Starten von »mariadb.service« notwendig. Multiple identities can be used for authentication: 1. ,,, (pi) 2. root Choose identity to authenticate as (1-2): 1 Password: ==== AUTHENTICATION COMPLETE === Job for mariadb.service failed because the control process exited with error cod e. See "systemctl status mariadb.service" and "journalctl -xe" for details. pi@raspberrypi:~ $ sudo systemctl start mariadb Job for mariadb.service failed because the control process exited with error cod e. See "systemctl status mariadb.service" and "journalctl -xe" for details. pi@raspberrypi:~ $ ^C pi@raspberrypi:~ $ systemctl status mariadb.service ● mariadb.service - MariaDB database server Loaded: loaded (/lib/systemd/system/mariadb.service; enabled; vendor preset: Active: failed (Result: exit-code) since Sat 2023-05-13 18:10:16 CEST; 26s ag Process: 9124 ExecStart=/usr/sbin/mysqld $MYSQLD_OPTS $_WSREP_NEW_CLUSTER $_WS Process: 9032 ExecStartPre=/bin/sh -c [ ! -e /usr/bin/galera_recovery ] && VAR Process: 9028 ExecStartPre=/bin/sh -c systemctl unset-environment _WSREP_START Process: 9025 ExecStartPre=/usr/bin/install -m 755 -o mysql -g root -d /var/ru Main PID: 9124 (code=exited, status=1/FAILURE) Status: "MariaDB server is down" Mai 13 18:10:11 raspberrypi systemd[1]: Starting MariaDB database server... Mai 13 18:10:13 raspberrypi mysqld[9124]: 2023-05-13 18:10:13 1995526144 [Note] Mai 13 18:10:16 raspberrypi systemd[1]: mariadb.service: Main process exited, co Mai 13 18:10:16 raspberrypi systemd[1]: Failed to start MariaDB database server. Mai 13 18:10:16 raspberrypi systemd[1]: mariadb.service: Unit entered failed sta Mai 13 18:10:16 raspberrypi systemd[1]: mariadb.service: Failed with result 'exi lines 1-16/16 (END) ● mariadb.service - MariaDB database server Loaded: loaded (/lib/systemd/system/mariadb.service; enabled; vendor preset: enabled) Active: failed (Result: exit-code) since Sat 2023-05-13 18:10:16 CEST; 26s ago Process: 9124 ExecStart=/usr/sbin/mysqld $MYSQLD_OPTS $_WSREP_NEW_CLUSTER $_WSREP_START_POSITION (code=exited, stat Process: 9032 ExecStartPre=/bin/sh -c [ ! -e /usr/bin/galera_recovery ] && VAR= || VAR=`/usr/bin/galera_recovery` Process: 9028 ExecStartPre=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCC Process: 9025 ExecStartPre=/usr/bin/install -m 755 -o mysql -g root -d /var/run/mysqld (code=exited, status=0/SUCCE Main PID: 9124 (code=exited, status=1/FAILURE) Status: "MariaDB server is down" Mai 13 18:10:11 raspberrypi systemd[1]: Starting MariaDB database server... Mai 13 18:10:13 raspberrypi mysqld[9124]: 2023-05-13 18:10:13 1995526144 [Note] /usr/sbin/mysqld (mysqld 10.1.23-Mari Mai 13 18:10:16 raspberrypi systemd[1]: mariadb.service: Main process exited, code=exited, status=1/FAILURE Mai 13 18:10:16 raspberrypi systemd[1]: Failed to start MariaDB database server. Mai 13 18:10:16 raspberrypi systemd[1]: mariadb.service: Unit entered failed state. Mai 13 18:10:16 raspberrypi systemd[1]: mariadb.service: Failed with result 'exit-code'. lines 1-16/16 (END) ● mariadb.service - MariaDB database server Loaded: loaded (/lib/systemd/system/mariadb.service; enabled; vendor preset: enabled) Active: failed (Result: exit-code) since Sat 2023-05-13 18:10:16 CEST; 26s ago Process: 9124 ExecStart=/usr/sbin/mysqld $MYSQLD_OPTS $_WSREP_NEW_CLUSTER $_WSREP_START_POSITION (code=exited, status=1/FAILURE) Process: 9032 ExecStartPre=/bin/sh -c [ ! -e /usr/bin/galera_recovery ] && VAR= || VAR=`/usr/bin/galera_recovery`; [ $? -eq 0 ] && systemctl set-environment _WSR Process: 9028 ExecStartPre=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS) Process: 9025 ExecStartPre=/usr/bin/install -m 755 -o mysql -g root -d /var/run/mysqld (code=exited, status=0/SUCCESS) Main PID: 9124 (code=exited, status=1/FAILURE) Status: "MariaDB server is down" Mai 13 18:10:11 raspberrypi systemd[1]: Starting MariaDB database server... Mai 13 18:10:13 raspberrypi mysqld[9124]: 2023-05-13 18:10:13 1995526144 [Note] /usr/sbin/mysqld (mysqld 10.1.23-MariaDB-9+deb9u1) starting as process 9124 ... Mai 13 18:10:16 raspberrypi systemd[1]: mariadb.service: Main process exited, code=exited, status=1/FAILURE Mai 13 18:10:16 raspberrypi systemd[1]: Failed to start MariaDB database server. Mai 13 18:10:16 raspberrypi systemd[1]: mariadb.service: Unit entered failed state. Mai 13 18:10:16 raspberrypi systemd[1]: mariadb.service: Failed with result 'exit-code'. pi@raspberrypi:~ $
