***************************************************************** * Hardware protocol of the TIxx calculators * * Documentation by Romain Lievin * * programmer of the GtkTiLink: http://gtktilink.ticalc.org * * Begin: 28/03/2000 * * Last update: 28/03/2000 * * Latest version of this doc can be found at * * http://gtktilink.ticalc.org/download/docs ***************************************************************** 0) Remark --------- If you need this doc in order to write some code to handle link cables, you should know that I have already developped a complete and well-documented library for Linux/Windows9x/WindowsNT4. This lib can handle any link cable (parallel, serial, Black and Grey TIGraphLink cable). The source code is available on the web site or also on . I) The hardware --------------- The TI bus is a two-wire serial interface consisting of a 'red' line and a 'white' line. Both lines are bi-directionnal therefore outputs must be of an open-drain or an open-collector type. Each line is connected to the supply voltage via a pull-up resistor. A line is then logic high when none of the connected devices drives the line, and logic low if one or more is drives the line low. Vdd --- | < 10 Kohms > | V Diode | out--O---------- input | < 470 ohms > | NPN \__/\/\____ output / 33 Kohms | __|___ Gnd II) The protocol ---------------- An example of sample: the byte represented is 0x09 (00001001 in binary); the first bit transmitted is the least significant bit (LSb) and the last one is the most significant bit (MSb) as a RS232 serial stream. 1 0 0 R = XF0|1: ______ ______|______ __________|________ __________ R = XF0|0: ________ | ____ | ____ W = XF1|1: ____________|________ ______|__________ _____ W = XF1|0: ________ | ______ | _______ 1 0 0 R = XF0|1: ___|__________ ______|________ _________|_________ R = XF0|0: | _______ | _____ | ____ W = XF1|1: ___|_____ ___________|___________ _____|___________ W = XF1|0: | _______ | ______ | __ 0 0 R = XF0|1: ____________|______ ___________|________ __________|______ R = XF0|0: | ____ | ____ | W = XF1|1: _______|________ ______|__________ ______|______ W = XF1|0: _____ | _______ | ______ | Legend: R is the red wire and W is the white wire. Each bit is made of two impulsions on two differents wires. This is the order of these two impulsions that determine the state of the bit. See the example below. At last, the transfer rate is of 45 to 50 Kbits/seconds. For a program example, see in the lib_ticable archive of the GtkTiLink code source and more particularly 'parlink.c' and 'serlink.c' which provide a complete library of functions to drive a parallel/serial homemade cable. A preview is given below: int par_put(byte data) { int bit; int i; clock_t clk; int b; for(bit=0; bit<8; bit++) { if(data & 1) { outb(2, lpt_out); clk=clock(); do { b=(clock()-clk) < time_out/10.0*CLOCKS_PER_SEC; if(!b) return 2; } while((inb(lpt_in) & 0x10)); outb(3, lpt_out); clk=clock(); do { b=(clock()-clk) < time_out/10.0*CLOCKS_PER_SEC; if(!b) return 2; } while((inb(lpt_in) & 0x10)==0x00); } else { outb(1, lpt_out); clk=clock(); do { b=(clock()-clk) < time_out/10.0*CLOCKS_PER_SEC; if(!b) return 2; } while(inb(lpt_in) & 0x20); outb(3, lpt_out); clk=clock(); do { b=(clock()-clk) < time_out/10.0*CLOCKS_PER_SEC; if(!b) return 2; } while((inb(lpt_in) & 0x20)==0x00); } data>>=1; for(i=0; i
