; DIR/STEP to GRAY code decoder for position interface ; ATtiny13 @ 9.6MHz ; PB0: gray code signal A, output ; PB1: gray code signal B, output ; PB2: DIR, input ; PB3: STEP, input .include "tn13adef.inc" .def tmp = r16 .def c0 = r17 .def c1 = r18 .def c2 = r19 .def c3 = r20 .def tmp2 = r21 .equ DIR_BIT = 2 .equ STEP_BIT = 3 ; macro for rising edge detection of STEP ; includes sampling of DIR for further processing ; sampling loop takes 5 CPU cycles .macro wait_pos_edge loop: mov tmp2, tmp in tmp, PINB sbrs tmp, STEP_BIT rjmp loop sbrc tmp2, STEP_BIT rjmp loop .endm .org 0 ldi tmp, 3 out DDRB, tmp ldi c0, 0 ldi c1, 1 ldi c2, 2 ldi c3, 3 ldi tmp, 0 ldi tmp2, 0 ; FSM with minimal overhead for maximum speed gray0: out portb, c0 wait_pos_edge sbrc tmp, DIR_BIT ; forward rjmp gray2 ; backward gray1: out portb, c1 wait_pos_edge sbrc tmp, DIR_BIT ; forward rjmp gray0 ; backward gray3: out portb, c3 wait_pos_edge sbrc tmp, DIR_BIT ; forward rjmp gray1 ; backward gray2: out portb, c2 wait_pos_edge sbrc tmp, DIR_BIT ; forward rjmp gray3 ; backward end_FSM: rjmp gray0
