1.2-OS-0.92 100Ms/s ; 2us/div - displayed --- Start of recording: 08.10.2009 20:15:43 --- AMDFlash::Write_Config_Flash AMDFlash::Write_Config_Flash AMDFlash::Write_Config_Flash AMDFlash::Write_Config_Flash ,handleInChar(2C) ***************************************************************************** * Variables * * ***************************************************************************** * Channel_1_Active : 1 * Channel_2_Active : 1 * * Channel_3_Active : 1 * Channel_4_Active : 1 * * Selected_Timebase : 7 * Debug Mode : 0 * * SIGNALFaktor_idx : 2 * ADC Debug Mode : 0 * * Timebase_Offset_Pos : -300 * Command Debug Mode : 0 * * SIGNAL_OFFSET : 0 * Calc Mode : 0 * * * ExtraTrg Mode : 0 * * Signal Start : 848 * Search Mode : 0 * * Signal Stop : 3248 * Search Auto : 1 * * Signal Start Calc : 1 * * * Signal Stop Calc : 2401 * Continius : 1 * * Zoomfaktor : 4.000* SingleMode : 0 * * Offset Faktor : 2.826* Single Restart : 0 * * ADC_Data_Available : 1 * VSync Needed : 1 * * Keyboard_Changed : 0 * ZFT_float :4.000 * * Triggering : 1 * : * * SelectedTriggerSource : 1 * SelectedTriggerSourceOld : 1 * * UserIface_request : 0 * OneShotRestart : 0 * * ctrl_reg : 7 * adc_ctrl_reg : 81c1 * * pre_reg : 203 * channel_Adr_add : 5f0a * * trg_val_CHI_reg : bc * trg_val_CHII_reg : a0 * * trg_val_CHIII_reg : a0 * trg_val_CHIV_reg : a0 * * trig_range_reg : 0 * trig_holdoff_reg : 0 * * trig_width_reg : 0 * * * adc_change12_reg : 1000000 * adc_change34_reg : 1000000 * * adc_ctr12_reg : 0 * adc_ctr34_reg : 0 * * Selected_Timebase : 7 * SIGNALFaktor_idx : 2 * * SIGNAL_StartFr_idx : 4 * timebase_reg : fffffffc * * Display_Timebase : 9 * dmode_Selected_Timebase : 9 * * dmode_SIGNALFaktor_idx : 0 * dmode_factor : 0 * * dmode_SIGNAL_StartFr_idx: 4 * Cursor_Delayed_1 : 240 * * Cursor_Delayed_2 : 360 * Cursor_Delayed_Size : 120 * * dmode_Window_Offset_Pos : 0 * * * SelectedEdgeExtern : 0 * TriggerWay : 1 * * Trigger_Pos_CH1 : 75 * Trigger_Pos_CH2 : 150 * * Trigger_Pos_CH3 : 250 * Trigger_Pos_CH4 : 324 * * Trigger_Pos_CHE : 15 * : * * Selected_Voltage_CH1 : 11 * CH1_DAC_Offset : 7900 * * Selected_Voltage_CH2 : 11 * CH2_DAC_Offset : 8135 * * Selected_Voltage_CH3 : 11 * CH3_DAC_Offset : 8449 * * Selected_Voltage_CH4 : 11 * CH4_DAC_Offset : 8681 * * Virtual_ZeroLevelCH1 : -125 * ZeroLevelCH1 : 75 * * Virtual_ZeroLevelCH2 : -50 * ZeroLevelCH2 : 150 * * Virtual_ZeroLevelCH3 : 50 * ZeroLevelCH3 : 250 * * Virtual_ZeroLevelCH4 : 124 * ZeroLevelCH4 : 324 * * SwitchesCH1 : 4042 * SwitchesCH2 : 202 * * SwitchesCH3 : 202 * SwitchesCH4 : 202 * * SwitchesTB : 0 * * * HoldOff_Value : 0 * trig_holdoff_reg : 0 * * CVP_Real1 : 103 * CVP_Real2 : 203 * * CVP_RealXY1 : 103 * CVP_RealXY2 : 203 * * CHP_Real1 : 103 * CHP_Real1 : 203 * * m2k_filter_Mode : 0 * kill_adc : 0 * * zeros_filter_Mode : 0 * tc_hw_version : 8c7 * * draw_dm_ixstart : 1450 * : * * draw_dm_ixfactor : 1 * draw_dm_ixoffset : 0 * * dmode_Window_Offset_Pos : 0 * dmode_Zoom_Index_Table : 11 * * ZIT_short : 14 * ZIT_short_dmode : 11 * * Trig_Pos_Mem : 1920 * Trig_Pos_Display : 430 * * : * MemWinStart : 200 * * Trig_Pos_Mem_old : 300 * Trig_Pos_Display_old : 450 * ***************************************************************************** --- End of recording: 08.10.2009 20:15:49 --- --- Start of recording: 08.10.2009 20:12:00 --- ,handleInChar(2C) 1.2-OS-0.92 JK 50Ms/s ***************************************************************************** * Variables * * ***************************************************************************** * Channel_1_Active : 1 * Channel_2_Active : 1 * * Channel_3_Active : 1 * Channel_4_Active : 1 * * Selected_Timebase : 8 * Debug Mode : 0 * * SIGNALFaktor_idx : 2 * ADC Debug Mode : 0 * * Timebase_Offset_Pos : -300 * Command Debug Mode : 0 * * SIGNAL_OFFSET : 0 * Calc Mode : 0 * * * ExtraTrg Mode : 0 * * Signal Start : 548 * Search Mode : 0 * * Signal Stop : 3548 * Search Auto : 1 * * Signal Start Calc : 1 * * * Signal Stop Calc : 3001 * Continius : 1 * * Zoomfaktor : 5.000* SingleMode : 0 * * Offset Faktor : 1.826* Single Restart : 0 * * ADC_Data_Available : 1 * VSync Needed : 1 * * Keyboard_Changed : 0 * ZFT_float :5.000 * * Triggering : 1 * : * * SelectedTriggerSource : 1 * SelectedTriggerSourceOld : 1 * * UserIface_request : 0 * OneShotRestart : 0 * * ctrl_reg : 7 * adc_ctrl_reg : 81c1 * * pre_reg : 27b * channel_Adr_add : 5f0a * * trg_val_CHI_reg : bc * trg_val_CHII_reg : a0 * * trg_val_CHIII_reg : a0 * trg_val_CHIV_reg : a0 * * trig_range_reg : 0 * trig_holdoff_reg : 0 * * trig_width_reg : 0 * * * adc_change12_reg : 1000000 * adc_change34_reg : 1000000 * * adc_ctr12_reg : 0 * adc_ctr34_reg : 0 * * Selected_Timebase : 8 * SIGNALFaktor_idx : 2 * * SIGNAL_StartFr_idx : 4 * timebase_reg : fffffffb * * Display_Timebase : 10 * dmode_Selected_Timebase : 9 * * dmode_SIGNALFaktor_idx : 0 * dmode_factor : 0 * * dmode_SIGNAL_StartFr_idx: 4 * Cursor_Delayed_1 : 240 * * Cursor_Delayed_2 : 360 * Cursor_Delayed_Size : 120 * * dmode_Window_Offset_Pos : 0 * * * SelectedEdgeExtern : 0 * TriggerWay : 1 * * Trigger_Pos_CH1 : 75 * Trigger_Pos_CH2 : 150 * * Trigger_Pos_CH3 : 250 * Trigger_Pos_CH4 : 324 * * Trigger_Pos_CHE : 15 * : * * Selected_Voltage_CH1 : 11 * CH1_DAC_Offset : 7900 * * Selected_Voltage_CH2 : 11 * CH2_DAC_Offset : 8135 * * Selected_Voltage_CH3 : 11 * CH3_DAC_Offset : 8449 * * Selected_Voltage_CH4 : 11 * CH4_DAC_Offset : 8681 * * Virtual_ZeroLevelCH1 : -125 * ZeroLevelCH1 : 75 * * Virtual_ZeroLevelCH2 : -50 * ZeroLevelCH2 : 150 * * Virtual_ZeroLevelCH3 : 50 * ZeroLevelCH3 : 250 * * Virtual_ZeroLevelCH4 : 124 * ZeroLevelCH4 : 324 * * SwitchesCH1 : 4042 * SwitchesCH2 : 202 * * SwitchesCH3 : 202 * SwitchesCH4 : 202 * * SwitchesTB : 0 * * * HoldOff_Value : 0 * trig_holdoff_reg : 0 * * CVP_Real1 : 103 * CVP_Real2 : 203 * * CVP_RealXY1 : 103 * CVP_RealXY2 : 203 * * CHP_Real1 : 103 * CHP_Real1 : 203 * * m2k_filter_Mode : 0 * kill_adc : 0 * * zeros_filter_Mode : 0 * tc_hw_version : 8c7 * * draw_dm_ixstart : 1450 * : * * draw_dm_ixfactor : 1 * draw_dm_ixoffset : 0 * * dmode_Window_Offset_Pos : 0 * dmode_Zoom_Index_Table : 11 * * ZIT_short : 15 * ZIT_short_dmode : 11 * * Trig_Pos_Mem : 2400 * Trig_Pos_Display : 430 * * : * MemWinStart : 250 * * Trig_Pos_Mem_old : 300 * Trig_Pos_Display_old : 450 * ***************************************************************************** --- End of recording: 08.10.2009 20:12:06 --- 1.2-OS-0.92 --- Start of recording: 08.10.2009 20:14:05 --- 25Ms/s diplayed ***************************************************************************** * Variables * * ***************************************************************************** * Channel_1_Active : 1 * Channel_2_Active : 1 * * Channel_3_Active : 1 * Channel_4_Active : 1 * * Selected_Timebase : 9 * Debug Mode : 0 * * SIGNALFaktor_idx : 2 * ADC Debug Mode : 0 * * Timebase_Offset_Pos : -300 * Command Debug Mode : 0 * * SIGNAL_OFFSET : 0 * Calc Mode : 0 * * * ExtraTrg Mode : 0 * * Signal Start : 548 * Search Mode : 0 * * Signal Stop : 3548 * Search Auto : 1 * * Signal Start Calc : 1 * * * Signal Stop Calc : 3001 * Continius : 1 * * Zoomfaktor : 5.000* SingleMode : 0 * * Offset Faktor : 1.826* Single Restart : 0 * * ADC_Data_Available : 1 * VSync Needed : 1 * * Keyboard_Changed : 0 * ZFT_float :5.000 * * Triggering : 1 * : * * SelectedTriggerSource : 1 * SelectedTriggerSourceOld : 1 * * UserIface_request : 0 * OneShotRestart : 0 * * ctrl_reg : 7 * adc_ctrl_reg : 81c1 * * pre_reg : 983 * channel_Adr_add : 5f0a * * trg_val_CHI_reg : bc * trg_val_CHII_reg : a0 * * trg_val_CHIII_reg : a0 * trg_val_CHIV_reg : a0 * * trig_range_reg : 0 * trig_holdoff_reg : 0 * * trig_width_reg : 0 * * * adc_change12_reg : 1000000 * adc_change34_reg : 1000000 * * adc_ctr12_reg : 0 * adc_ctr34_reg : 0 * * Selected_Timebase : 9 * SIGNALFaktor_idx : 2 * * SIGNAL_StartFr_idx : 2 * timebase_reg : fffffffb * * Display_Timebase : 11 * dmode_Selected_Timebase : 9 * * dmode_SIGNALFaktor_idx : 0 * dmode_factor : 0 * * dmode_SIGNAL_StartFr_idx: 4 * Cursor_Delayed_1 : 240 * * Cursor_Delayed_2 : 360 * Cursor_Delayed_Size : 120 * * dmode_Window_Offset_Pos : 0 * * * SelectedEdgeExtern : 0 * TriggerWay : 1 * * Trigger_Pos_CH1 : 75 * Trigger_Pos_CH2 : 150 * * Trigger_Pos_CH3 : 250 * Trigger_Pos_CH4 : 324 * * Trigger_Pos_CHE : 15 * : * * Selected_Voltage_CH1 : 11 * CH1_DAC_Offset : 7900 * * Selected_Voltage_CH2 : 11 * CH2_DAC_Offset : 8135 * * Selected_Voltage_CH3 : 11 * CH3_DAC_Offset : 8449 * * Selected_Voltage_CH4 : 11 * CH4_DAC_Offset : 8681 * * Virtual_ZeroLevelCH1 : -125 * ZeroLevelCH1 : 75 * * Virtual_ZeroLevelCH2 : -50 * ZeroLevelCH2 : 150 * * Virtual_ZeroLevelCH3 : 50 * ZeroLevelCH3 : 250 * * Virtual_ZeroLevelCH4 : 124 * ZeroLevelCH4 : 324 * * SwitchesCH1 : 4042 * SwitchesCH2 : 202 * * SwitchesCH3 : 202 * SwitchesCH4 : 202 * * SwitchesTB : 0 * * * HoldOff_Value : 0 * trig_holdoff_reg : 0 * * CVP_Real1 : 103 * CVP_Real2 : 203 * * CVP_RealXY1 : 103 * CVP_RealXY2 : 203 * * CHP_Real1 : 103 * CHP_Real1 : 203 * * m2k_filter_Mode : 0 * kill_adc : 0 * * zeros_filter_Mode : 0 * tc_hw_version : 8c7 * * draw_dm_ixstart : 1450 * : * * draw_dm_ixfactor : 1 * draw_dm_ixoffset : 0 * * dmode_Window_Offset_Pos : 0 * dmode_Zoom_Index_Table : 11 * * ZIT_short : 15 * ZIT_short_dmode : 11 * * Trig_Pos_Mem : 2400 * Trig_Pos_Display : 430 * * : * MemWinStart : 250 * * Trig_Pos_Mem_old : 300 * Trig_Pos_Display_old : 450 * ***************************************************************************** --- End of recording: 08.10.2009 20:14:13 ---
