        .global main                    // int main(void)
        .global _etext                  // -> .data initial values in ROM
        .global _data                   // -> .data area in RAM
        .global _edata                  // end of .data area
        .global __bss_start             // -> .bss area in RAM
        .global __bss_end__             // end of .bss area
        .global _stack                  // top of stack
// Stack Sizes
        .set  UND_STACK_SIZE, 0x00000004
        .set  ABT_STACK_SIZE, 0x00000004
        .set  FIQ_STACK_SIZE, 0x00000004
        .set  IRQ_STACK_SIZE, 0X00000080
        .set  SVC_STACK_SIZE, 0x00000004
        .set  USR_STACK_SIZE, 0x00000500
// Standard definitions of Mode bits and Interrupt (I & F) flags in PSRs
        .set  MODE_USR, 0x10            // User Mode
        .set  MODE_FIQ, 0x11            // FIQ Mode
        .set  MODE_IRQ, 0x12            // IRQ Mode
        .set  MODE_SVC, 0x13            // Supervisor Mode
        .set  MODE_ABT, 0x17            // Abort Mode
        .set  MODE_UND, 0x1B            // Undefined Mode
        .set  MODE_SYS, 0x1F            // System Mode
        .equ  I_BIT, 0x80               // when I bit is set, IRQ is disabled
        .equ  F_BIT, 0x40               // when F bit is set, FIQ is disabled
        .text
        .code 32
        .align 2
        .global _boot
        .func   _boot
_boot:
// Runtime Interrupt Vectors
Vectors:
        b     _start                    // reset - _start
        ldr   pc,_undf                  // undefined - _undf
        ldr   pc,_swi                   // SWI - _swi
        ldr   pc,_pabt                  // program abort - _pabt
        ldr   pc,_dabt                  // data abort - _dabt
        nop                             // reserved
        ldr   pc,[pc,#-0xFF0]           // IRQ - read the VIC
        ldr   pc,_fiq                   // FIQ - _fiq
#if 0
// Use this group for production
_undf:  .word _reset                    // undefined - _reset
_swi:   .word _reset                    // SWI - _reset
_pabt:  .word _reset                    // program abort - _reset
_dabt:  .word _reset                    // data abort - _reset
_irq:   .word _reset                    // IRQ - _reset
_fiq:   .word _reset                    // FIQ - _reset
#else
// Use this group for development
_undf:  .word __undf                    // undefined
_swi:   .word __swi                     // SWI
_pabt:  .word __pabt                    // program abort
_dabt:  .word __dabt                    // data abort
_irq:   .word __irq                     // IRQ
_fiq:   .word __fiq                     // FIQ
__undf: b     .                         // undefined
__swi:  b     .                         // SWI
__pabt: b     .                         // program abort
__dabt: b     .                         // data abort
__irq:  b     .              			// IRQ
__fiq:  b     .                         // FIQ
#endif
        .size _boot, . - _boot
        .endfunc
// Setup the operating mode & stack.
        .global _start, start, _mainCRTStartup
        .func   _start
_start:
start:
_mainCRTStartup:
// Initialize Interrupt System
// - Set stack location for each mode
// - Leave in System Mode with Interrupts Disabled
        ldr   r0,=_stack
        msr   CPSR_c,#MODE_UND|I_BIT|F_BIT // Undefined Instruction Mode
        mov   sp,r0
        sub   r0,r0,#UND_STACK_SIZE
        msr   CPSR_c,#MODE_ABT|I_BIT|F_BIT // Abort Mode
        mov   sp,r0
        sub   r0,r0,#ABT_STACK_SIZE
        msr   CPSR_c,#MODE_FIQ|I_BIT|F_BIT // FIQ Mode
        mov   sp,r0
        sub   r0,r0,#FIQ_STACK_SIZE
        msr   CPSR_c,#MODE_IRQ|I_BIT|F_BIT // IRQ Mode
        mov   sp,r0
        sub   r0,r0,#IRQ_STACK_SIZE
        msr   CPSR_c,#MODE_SVC|I_BIT|F_BIT // Supervisor Mode
        mov   sp,r0
        sub   r0,r0,#SVC_STACK_SIZE
        msr   CPSR_c,#MODE_SYS|I_BIT|F_BIT // System Mode
        mov   sp,r0
// Copy initialized data to its execution address in RAM
        ldr   r1,=_etext                // -> ROM data start
        ldr   r2,=_data                 // -> data start
        ldr   r3,=_edata                // -> end of data
1:      cmp   r2,r3                     // check if data to move
        ldrlo r0,[r1],#4                // copy it
        strlo r0,[r2],#4
        blo   1b                        // loop until done
// Clear .bss
        mov   r0,#0                     // get a zero
        ldr   r1,=__bss_start           // -> bss start
        ldr   r2,=__bss_end__           // -> bss end
2:      cmp   r1,r2                     // check if data to clear
        strlo r0,[r1],#4                // clear 4 bytes
        blo   2b                        // loop until done
// Call main program: main(0)
        mov   r0,#0                     // no arguments (argc = 0)
        mov   r1,r0
        mov   r2,r0
        mov   fp,r0                     // null frame pointer
        mov   r7,r0                     // null frame pointer for thumb
        ldr   r10,=main
        mov   lr,pc
        bx    r10                       // enter main()
        .size   _start, . - _start
        .endfunc
        .global _reset, reset, exit, abort
        .func   _reset
_reset:
reset:
exit:
abort:
#if 0
// Disable interrupts, then force a hardware reset by driving P23 low
        mrs   r0,cpsr                   // get PSR
        orr   r0,r0,#I_BIT|F_BIT        // disable IRQ and FIQ
        msr   cpsr,r0                   // set up status register
        ldr   r1,=(PS_BASE)             // PS Base Address
        ldr   r0,=(PS_PIO)              // PIO Module
        str   r0,[r1,#PS_PCER_OFF]      // enable its clock
        ldr   r1,=(PIO_BASE)            // PIO Base Address
        ldr   r0,=(1<<23)               // P23
        str   r0,[r1,#PIO_PER_OFF]      // make sure pin is contolled by PIO
        str   r0,[r1,#PIO_CODR_OFF]     // set the pin low
        str   r0,[r1,#PIO_OER_OFF]      // make it an output
#endif
        b     .                         // loop until reset
        .size _reset, . - _reset
        .endfunc
        .end
