(kicad_sch (version 20211123) (generator eeschema)
  (uuid f71da641-16e6-4257-80c3-0b9d804fee4f)
  (paper "A2")
  (lib_symbols
    (symbol "Connector:TestPoint" (pin_numbers hide) (pin_names (offset 0.762) hide) (in_bom yes) (on_board yes)
      (property "Reference" "TP" (id 0) (at 0 6.858 0)
        (effects (font (size 1.27 1.27)))
      (property "Value" "TestPoint" (id 1) (at 0 5.08 0)
      (property "Footprint" "" (id 2) (at 5.08 0 0)
        (effects (font (size 1.27 1.27)) hide)
      (property "Datasheet" "~" (id 3) (at 5.08 0 0)
      (property "ki_keywords" "test point tp" (id 4) (at 0 0 0)
      (property "ki_description" "test point" (id 5) (at 0 0 0)
      (property "ki_fp_filters" "Pin* Test*" (id 6) (at 0 0 0)
      (symbol "TestPoint_0_1"
        (circle (center 0 3.302) (radius 0.762)
          (stroke (width 0) (type default) (color 0 0 0 0))
          (fill (type none))
      (symbol "TestPoint_1_1"
        (pin passive line (at 0 0 90) (length 2.54)
          (name "1" (effects (font (size 1.27 1.27))))
          (number "1" (effects (font (size 1.27 1.27))))
    (symbol "Device:D_Schottky_Small" (pin_numbers hide) (pin_names (offset 0.254) hide) (in_bom yes) (on_board yes)
      (property "Reference" "D" (id 0) (at -1.27 2.032 0)
        (effects (font (size 1.27 1.27)) (justify left))
      (property "Value" "D_Schottky_Small" (id 1) (at -7.112 -2.032 0)
      (property "Footprint" "" (id 2) (at 0 0 90)
      (property "Datasheet" "~" (id 3) (at 0 0 90)
      (property "ki_keywords" "diode Schottky" (id 4) (at 0 0 0)
      (property "ki_description" "Schottky diode, small symbol" (id 5) (at 0 0 0)
      (property "ki_fp_filters" "TO-???* *_Diode_* *SingleDiode* D_*" (id 6) (at 0 0 0)
      (symbol "D_Schottky_Small_0_1"
        (polyline
          (pts
            (xy -0.762 0)
            (xy 0.762 0)
          (fill (type none))
        (polyline
          (pts
            (xy 0.762 -1.016)
            (xy -0.762 0)
            (xy 0.762 1.016)
            (xy 0.762 -1.016)
          (stroke (width 0.254) (type default) (color 0 0 0 0))
          (fill (type none))
        (polyline
          (pts
            (xy -1.27 0.762)
            (xy -1.27 1.016)
            (xy -0.762 1.016)
            (xy -0.762 -1.016)
            (xy -0.254 -1.016)
            (xy -0.254 -0.762)
          (fill (type none))
      (symbol "D_Schottky_Small_1_1"
        (pin passive line (at -2.54 0 0) (length 1.778)
          (name "K" (effects (font (size 1.27 1.27))))
        (pin passive line (at 2.54 0 180) (length 1.778)
          (name "A" (effects (font (size 1.27 1.27))))
          (number "2" (effects (font (size 1.27 1.27))))
    (symbol "Device:D_Small" (pin_numbers hide) (pin_names (offset 0.254) hide) (in_bom yes) (on_board yes)
      (property "Value" "D_Small" (id 1) (at -3.81 -2.032 0)
      (property "ki_keywords" "diode" (id 4) (at 0 0 0)
      (property "ki_description" "Diode, small symbol" (id 5) (at 0 0 0)
      (symbol "D_Small_0_1"
        (polyline
          (pts
            (xy -0.762 -1.016)
            (xy -0.762 1.016)
          (fill (type none))
        (polyline
          (pts
            (xy -0.762 0)
            (xy 0.762 0)
          (fill (type none))
        (polyline
          (pts
            (xy 0.762 -1.016)
            (xy -0.762 0)
            (xy 0.762 1.016)
            (xy 0.762 -1.016)
          (fill (type none))
      (symbol "D_Small_1_1"
    (symbol "Device:R_Small" (pin_numbers hide) (pin_names (offset 0.254) hide) (in_bom yes) (on_board yes)
      (property "Reference" "R" (id 0) (at 0.762 0.508 0)
      (property "Value" "R_Small" (id 1) (at 0.762 -1.016 0)
      (property "Footprint" "" (id 2) (at 0 0 0)
      (property "Datasheet" "~" (id 3) (at 0 0 0)
      (property "ki_keywords" "R resistor" (id 4) (at 0 0 0)
      (property "ki_description" "Resistor, small symbol" (id 5) (at 0 0 0)
      (property "ki_fp_filters" "R_*" (id 6) (at 0 0 0)
      (symbol "R_Small_0_1"
        (rectangle (start -0.762 1.778) (end 0.762 -1.778)
          (stroke (width 0.2032) (type default) (color 0 0 0 0))
          (fill (type none))
      (symbol "R_Small_1_1"
        (pin passive line (at 0 2.54 270) (length 0.762)
          (name "~" (effects (font (size 1.27 1.27))))
        (pin passive line (at 0 -2.54 90) (length 0.762)
    (symbol "RDS80-rescue:4051-4xxx-RDS80-rescue" (pin_names (offset 1.016)) (in_bom yes) (on_board yes)
      (property "Reference" "U" (id 0) (at -7.62 19.05 0)
      (property "Value" "4051-4xxx-RDS80-rescue" (id 1) (at -7.62 -19.05 0)
      (property "Datasheet" "" (id 3) (at 0 0 0)
      (property "ki_locked" "" (id 4) (at 0 0 0)
      (property "ki_fp_filters" "DIP?16*" (id 5) (at 0 0 0)
      (symbol "4051-4xxx-RDS80-rescue_1_0"
        (pin passive line (at -12.7 5.08 0) (length 5.08)
          (name "X4" (effects (font (size 1.27 1.27))))
        (pin input line (at -12.7 -12.7 0) (length 5.08)
          (name "B" (effects (font (size 1.27 1.27))))
          (number "10" (effects (font (size 1.27 1.27))))
        (pin input line (at -12.7 -10.16 0) (length 5.08)
          (number "11" (effects (font (size 1.27 1.27))))
        (pin passive line (at -12.7 7.62 0) (length 5.08)
          (name "X3" (effects (font (size 1.27 1.27))))
          (number "12" (effects (font (size 1.27 1.27))))
        (pin passive line (at -12.7 15.24 0) (length 5.08)
          (name "X0" (effects (font (size 1.27 1.27))))
          (number "13" (effects (font (size 1.27 1.27))))
        (pin passive line (at -12.7 12.7 0) (length 5.08)
          (name "X1" (effects (font (size 1.27 1.27))))
          (number "14" (effects (font (size 1.27 1.27))))
        (pin passive line (at -12.7 10.16 0) (length 5.08)
          (name "X2" (effects (font (size 1.27 1.27))))
          (number "15" (effects (font (size 1.27 1.27))))
        (pin power_in line (at 0 22.86 270) (length 5.08)
          (name "VDD" (effects (font (size 1.27 1.27))))
          (number "16" (effects (font (size 1.27 1.27))))
        (pin passive line (at -12.7 0 0) (length 5.08)
          (name "X6" (effects (font (size 1.27 1.27))))
        (pin passive line (at 12.7 15.24 180) (length 5.08)
          (name "X" (effects (font (size 1.27 1.27))))
          (number "3" (effects (font (size 1.27 1.27))))
        (pin passive line (at -12.7 -2.54 0) (length 5.08)
          (name "X7" (effects (font (size 1.27 1.27))))
          (number "4" (effects (font (size 1.27 1.27))))
        (pin passive line (at -12.7 2.54 0) (length 5.08)
          (name "X5" (effects (font (size 1.27 1.27))))
          (number "5" (effects (font (size 1.27 1.27))))
        (pin input line (at -12.7 -7.62 0) (length 5.08)
          (name "Inh" (effects (font (size 1.27 1.27))))
          (number "6" (effects (font (size 1.27 1.27))))
        (pin power_in line (at 2.54 -22.86 90) (length 5.08)
          (name "VEE" (effects (font (size 1.27 1.27))))
          (number "7" (effects (font (size 1.27 1.27))))
        (pin power_in line (at 0 -22.86 90) (length 5.08)
          (name "VSS" (effects (font (size 1.27 1.27))))
          (number "8" (effects (font (size 1.27 1.27))))
        (pin input line (at -12.7 -15.24 0) (length 5.08)
          (name "C" (effects (font (size 1.27 1.27))))
          (number "9" (effects (font (size 1.27 1.27))))
      (symbol "4051-4xxx-RDS80-rescue_1_1"
        (rectangle (start -7.62 17.78) (end 7.62 -17.78)
          (fill (type background))
    (symbol "RDS80-rescue:C_Small-Device-RDS80-rescue" (pin_numbers hide) (pin_names (offset 0.254) hide) (in_bom yes) (on_board yes)
      (property "Reference" "C" (id 0) (at 0.254 1.778 0)
      (property "Value" "C_Small-Device-RDS80-rescue" (id 1) (at 0.254 -2.032 0)
      (property "ki_fp_filters" "C_*" (id 4) (at 0 0 0)
      (symbol "C_Small-Device-RDS80-rescue_0_1"
        (polyline
          (pts
            (xy -1.524 -0.508)
            (xy 1.524 -0.508)
          (stroke (width 0.3302) (type default) (color 0 0 0 0))
          (fill (type none))
        (polyline
          (pts
            (xy -1.524 0.508)
            (xy 1.524 0.508)
          (stroke (width 0.3048) (type default) (color 0 0 0 0))
          (fill (type none))
      (symbol "C_Small-Device-RDS80-rescue_1_1"
        (pin passive line (at 0 2.54 270) (length 2.032)
        (pin passive line (at 0 -2.54 90) (length 2.032)
    (symbol "RDS80-rescue:D_Small-Device-RDS80-rescue" (pin_numbers hide) (pin_names (offset 0.254) hide) (in_bom yes) (on_board yes)
      (property "Value" "D_Small-Device-RDS80-rescue" (id 1) (at -3.81 -2.032 0)
      (property "Datasheet" "" (id 3) (at 0 0 90)
      (property "ki_fp_filters" "TO-???* *_Diode_* *SingleDiode* D_*" (id 4) (at 0 0 0)
      (symbol "D_Small-Device-RDS80-rescue_0_1"
        (polyline
          (pts
            (xy -0.762 -1.016)
            (xy -0.762 1.016)
          (fill (type none))
        (polyline
          (pts
            (xy -0.762 0)
            (xy 0.762 0)
          (fill (type none))
        (polyline
          (pts
            (xy 0.762 -1.016)
            (xy -0.762 0)
            (xy 0.762 1.016)
            (xy 0.762 -1.016)
          (fill (type none))
      (symbol "D_Small-Device-RDS80-rescue_1_1"
    (symbol "RDS80-rescue:Q_NPN_BEC-Device-RDS80-rescue" (pin_names (offset 0) hide) (in_bom yes) (on_board yes)
      (property "Reference" "Q" (id 0) (at 5.08 1.27 0)
      (property "Value" "Q_NPN_BEC-Device-RDS80-rescue" (id 1) (at 5.08 -1.27 0)
      (property "Footprint" "" (id 2) (at 5.08 2.54 0)
      (symbol "Q_NPN_BEC-Device-RDS80-rescue_0_1"
        (polyline
          (pts
            (xy 0.635 0.635)
            (xy 2.54 2.54)
          (fill (type none))
        (polyline
          (pts
            (xy 0.635 -0.635)
            (xy 2.54 -2.54)
            (xy 2.54 -2.54)
          (fill (type none))
        (polyline
          (pts
            (xy 0.635 1.905)
            (xy 0.635 -1.905)
            (xy 0.635 -1.905)
          (stroke (width 0.508) (type default) (color 0 0 0 0))
          (fill (type none))
        (polyline
          (pts
            (xy 1.27 -1.778)
            (xy 1.778 -1.27)
            (xy 2.286 -2.286)
            (xy 1.27 -1.778)
            (xy 1.27 -1.778)
          (fill (type outline))
        (circle (center 1.27 0) (radius 2.8194)
          (fill (type none))
      (symbol "Q_NPN_BEC-Device-RDS80-rescue_1_1"
        (pin input line (at -5.08 0 0) (length 5.715)
        (pin passive line (at 2.54 -5.08 90) (length 2.54)
          (name "E" (effects (font (size 1.27 1.27))))
        (pin passive line (at 2.54 5.08 270) (length 2.54)
    (symbol "RDS80-rescue:Q_PNP_BEC-Device-RDS80-rescue" (pin_names (offset 0) hide) (in_bom yes) (on_board yes)
      (property "Value" "Q_PNP_BEC-Device-RDS80-rescue" (id 1) (at 5.08 -1.27 0)
      (symbol "Q_PNP_BEC-Device-RDS80-rescue_0_1"
        (polyline
          (pts
            (xy 0.635 0.635)
            (xy 2.54 2.54)
          (fill (type none))
        (polyline
          (pts
            (xy 0.635 -0.635)
            (xy 2.54 -2.54)
            (xy 2.54 -2.54)
          (fill (type none))
        (polyline
          (pts
            (xy 0.635 1.905)
            (xy 0.635 -1.905)
            (xy 0.635 -1.905)
          (fill (type none))
        (polyline
          (pts
            (xy 2.286 -1.778)
            (xy 1.778 -2.286)
            (xy 1.27 -1.27)
            (xy 2.286 -1.778)
            (xy 2.286 -1.778)
          (fill (type none))
      (symbol "Q_PNP_BEC-Device-RDS80-rescue_1_1"
    (symbol "RDS80-rescue:Q_TRIAC_A1A2G-Device-RDS80-rescue" (pin_names (offset 0)) (in_bom yes) (on_board yes)
      (property "Reference" "D" (id 0) (at 3.175 0.635 0)
      (property "Value" "Q_TRIAC_A1A2G-Device-RDS80-rescue" (id 1) (at 3.175 -1.27 0)
      (property "Footprint" "" (id 2) (at 1.905 0.635 90)
      (symbol "Q_TRIAC_A1A2G-Device-RDS80-rescue_0_1"
        (polyline
          (pts
            (xy -2.54 -1.27)
            (xy 2.54 -1.27)
          (fill (type none))
        (polyline
          (pts
            (xy -2.54 1.27)
            (xy 2.54 1.27)
          (fill (type none))
        (polyline
          (pts
            (xy -1.27 -2.54)
            (xy -0.635 -1.27)
          (fill (type none))
        (polyline
          (pts
            (xy -2.54 1.27)
            (xy -1.27 -1.27)
            (xy 0 1.27)
          (fill (type none))
        (polyline
          (pts
            (xy 0 -1.27)
            (xy 1.27 1.27)
            (xy 2.54 -1.27)
          (fill (type none))
      (symbol "Q_TRIAC_A1A2G-Device-RDS80-rescue_1_1"
        (pin passive line (at 0 -3.81 90) (length 2.54)
          (name "A1" (effects (font (size 0.635 0.635))))
        (pin passive line (at 0 3.81 270) (length 2.54)
          (name "A2" (effects (font (size 0.635 0.635))))
        (pin input line (at -3.81 -2.54 0) (length 2.54)
          (name "G" (effects (font (size 0.635 0.635))))
    (symbol "RDS80-rescue:R_Small-Device-RDS80-rescue" (pin_numbers hide) (pin_names (offset 0.254) hide) (in_bom yes) (on_board yes)
      (property "Value" "R_Small-Device-RDS80-rescue" (id 1) (at 0.762 -1.016 0)
      (property "ki_fp_filters" "R_*" (id 4) (at 0 0 0)
      (symbol "R_Small-Device-RDS80-rescue_0_1"
          (fill (type none))
      (symbol "R_Small-Device-RDS80-rescue_1_1"
    (symbol "RDS80-rescue:TLC272-Amplifier_Operational-RDS80-rescue" (pin_names (offset 0.127)) (in_bom yes) (on_board yes)
      (property "Reference" "U" (id 0) (at 0 5.08 0)
      (property "Value" "TLC272-Amplifier_Operational-RDS80-rescue" (id 1) (at 0 -5.08 0)
      (property "ki_fp_filters" "SOIC*3.9x4.9mm*P1.27mm* DIP*W7.62mm* TO*99* OnSemi*Micro8* TSSOP*3x3mm*P0.65mm* TSSOP*4.4x3mm*P0.65mm* MSOP*3x3mm*P0.65mm* SSOP*3.9x4.9mm*P0.635mm* LFCSP*2x2mm*P0.5mm* *SIP* SOIC*5.3x6.2mm*P1.27mm*" (id 5) (at 0 0 0)
      (symbol "TLC272-Amplifier_Operational-RDS80-rescue_1_1"
        (polyline
          (pts
            (xy -5.08 5.08)
            (xy 5.08 0)
            (xy -5.08 -5.08)
            (xy -5.08 5.08)
        (pin output line (at 7.62 0 180) (length 2.54)
        (pin input line (at -7.62 -2.54 0) (length 2.54)
          (name "-" (effects (font (size 1.27 1.27))))
        (pin input line (at -7.62 2.54 0) (length 2.54)
          (name "+" (effects (font (size 1.27 1.27))))
      (symbol "TLC272-Amplifier_Operational-RDS80-rescue_2_1"
        (polyline
          (pts
            (xy -5.08 5.08)
            (xy 5.08 0)
            (xy -5.08 -5.08)
            (xy -5.08 5.08)
      (symbol "TLC272-Amplifier_Operational-RDS80-rescue_3_1"
        (pin power_in line (at -2.54 -7.62 90) (length 3.81)
          (name "V-" (effects (font (size 1.27 1.27))))
        (pin power_in line (at -2.54 7.62 270) (length 3.81)
          (name "V+" (effects (font (size 1.27 1.27))))
    (symbol "RDS80-rescue:TestPoint-Connector-RDS80-rescue" (pin_numbers hide) (pin_names (offset 0.762) hide) (in_bom yes) (on_board yes)
      (property "Value" "TestPoint-Connector-RDS80-rescue" (id 1) (at 0 5.08 0)
      (property "Datasheet" "" (id 3) (at 5.08 0 0)
      (property "ki_fp_filters" "Pin* Test*" (id 4) (at 0 0 0)
      (symbol "TestPoint-Connector-RDS80-rescue_0_1"
          (fill (type none))
      (symbol "TestPoint-Connector-RDS80-rescue_1_1"
    (symbol "RDS80-rescue:Thermistor_PTC-Device-RDS80-rescue" (pin_numbers hide) (pin_names (offset 0)) (in_bom yes) (on_board yes)
      (property "Reference" "TH" (id 0) (at -4.064 0 90)
      (property "Value" "Thermistor_PTC-Device-RDS80-rescue" (id 1) (at 3.048 0 90)
      (property "Footprint" "" (id 2) (at 1.27 -5.08 0)
        (effects (font (size 1.27 1.27)) (justify left) hide)
      (property "ki_fp_filters" "*PTC* *Thermistor* PIN?ARRAY* bornier* *Terminal?Block* R_*" (id 4) (at 0 0 0)
      (symbol "Thermistor_PTC-Device-RDS80-rescue_0_1"
        (arc (start -3.048 2.159) (mid -3.0505 2.3165) (end -3.175 2.413)
          (fill (type none))
        (arc (start -3.048 2.159) (mid -2.9736 1.9794) (end -2.794 1.905)
          (fill (type none))
        (arc (start -3.048 2.794) (mid -2.9736 2.6144) (end -2.794 2.54)
          (fill (type none))
        (arc (start -2.794 1.905) (mid -2.6144 1.9794) (end -2.54 2.159)
          (fill (type none))
        (arc (start -2.794 2.54) (mid -2.434 2.5608) (end -2.159 2.794)
          (fill (type none))
        (arc (start -2.794 3.048) (mid -2.9736 2.9736) (end -3.048 2.794)
          (fill (type none))
        (arc (start -2.54 2.794) (mid -2.6144 2.9736) (end -2.794 3.048)
          (fill (type none))
        (rectangle (start -1.016 2.54) (end 1.016 -2.54)
          (fill (type none))
        (polyline
          (pts
            (xy -2.54 2.159)
            (xy -2.54 2.794)
          (fill (type none))
        (polyline
          (pts
            (xy -1.778 2.54)
            (xy -1.778 1.524)
            (xy 1.778 -1.524)
            (xy 1.778 -2.54)
          (fill (type none))
        (polyline
          (pts
            (xy -2.54 -3.683)
            (xy -2.54 -1.397)
            (xy -2.794 -2.159)
            (xy -2.286 -2.159)
            (xy -2.54 -1.397)
            (xy -2.54 -1.651)
        (polyline
          (pts
            (xy -1.778 -3.683)
            (xy -1.778 -1.397)
            (xy -2.032 -2.159)
            (xy -1.524 -2.159)
            (xy -1.778 -1.397)
            (xy -1.778 -1.651)
      (symbol "Thermistor_PTC-Device-RDS80-rescue_1_1"
        (pin passive line (at 0 3.81 270) (length 1.27)
        (pin passive line (at 0 -3.81 90) (length 1.27)
    (symbol "em:PIC16F1946" (in_bom yes) (on_board yes)
      (property "Reference" "U" (id 0) (at 0 -24.13 0)
      (property "Value" "PIC16F1946" (id 1) (at 0 -21.59 0)
      (symbol "PIC16F1946_0_1"
        (rectangle (start -25.4 -8.89) (end 25.4 -60.96)
          (stroke (width 0.1524) (type default) (color 0 0 0 0))
      (symbol "PIC16F1946_1_1"
        (pin bidirectional line (at -27.94 -16.51 0) (length 2.54)
          (name "RE1" (effects (font (size 1.27 1.27))))
        (pin power_in line (at -27.94 -39.37 0) (length 2.54)
        (pin bidirectional line (at -27.94 -41.91 0) (length 2.54)
          (name "RF7" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at -27.94 -44.45 0) (length 2.54)
          (name "RF6" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at -27.94 -46.99 0) (length 2.54)
          (name "RF5" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at -27.94 -49.53 0) (length 2.54)
          (name "RF4" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at -27.94 -52.07 0) (length 2.54)
          (name "RF3" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at -27.94 -54.61 0) (length 2.54)
          (name "RF2" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at -19.05 -63.5 90) (length 2.54)
          (name "RF1" (effects (font (size 1.27 1.27))))
          (number "17" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at -16.51 -63.5 90) (length 2.54)
          (name "RF0" (effects (font (size 1.27 1.27))))
          (number "18" (effects (font (size 1.27 1.27))))
        (pin power_in line (at -13.97 -63.5 90) (length 2.54)
          (name "AVDD" (effects (font (size 1.27 1.27))))
          (number "19" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at -27.94 -19.05 0) (length 2.54)
          (name "RE0" (effects (font (size 1.27 1.27))))
        (pin power_in line (at -11.43 -63.5 90) (length 2.54)
          (name "AVSS" (effects (font (size 1.27 1.27))))
          (number "20" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at -8.89 -63.5 90) (length 2.54)
          (name "RA3" (effects (font (size 1.27 1.27))))
          (number "21" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at -6.35 -63.5 90) (length 2.54)
          (name "RA2" (effects (font (size 1.27 1.27))))
          (number "22" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at -3.81 -63.5 90) (length 2.54)
          (name "RA1" (effects (font (size 1.27 1.27))))
          (number "23" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at -1.27 -63.5 90) (length 2.54)
          (name "RA0" (effects (font (size 1.27 1.27))))
          (number "24" (effects (font (size 1.27 1.27))))
        (pin power_in line (at 1.27 -63.5 90) (length 2.54)
          (number "25" (effects (font (size 1.27 1.27))))
        (pin power_in line (at 3.81 -63.5 90) (length 2.54)
          (number "26" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at 6.35 -63.5 90) (length 2.54)
          (name "RA5" (effects (font (size 1.27 1.27))))
          (number "27" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at 8.89 -63.5 90) (length 2.54)
          (name "RA4" (effects (font (size 1.27 1.27))))
          (number "28" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at 11.43 -63.5 90) (length 2.54)
          (name "RC1" (effects (font (size 1.27 1.27))))
          (number "29" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at -27.94 -21.59 0) (length 2.54)
          (name "RG0" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at 13.97 -63.5 90) (length 2.54)
          (name "RC0" (effects (font (size 1.27 1.27))))
          (number "30" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at 16.51 -63.5 90) (length 2.54)
          (name "RC6" (effects (font (size 1.27 1.27))))
          (number "31" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at 19.05 -63.5 90) (length 2.54)
          (name "RC7" (effects (font (size 1.27 1.27))))
          (number "32" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at 27.94 -54.61 180) (length 2.54)
          (name "RC2" (effects (font (size 1.27 1.27))))
          (number "33" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at 27.94 -52.07 180) (length 2.54)
          (name "RC3" (effects (font (size 1.27 1.27))))
          (number "34" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at 27.94 -49.53 180) (length 2.54)
          (name "RC4" (effects (font (size 1.27 1.27))))
          (number "35" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at 27.94 -46.99 180) (length 2.54)
          (name "RC5" (effects (font (size 1.27 1.27))))
          (number "36" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at 27.94 -44.45 180) (length 2.54)
          (name "RB7" (effects (font (size 1.27 1.27))))
          (number "37" (effects (font (size 1.27 1.27))))
        (pin power_in line (at 27.94 -41.91 180) (length 2.54)
          (number "38" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at 27.94 -39.37 180) (length 2.54)
          (name "RA7" (effects (font (size 1.27 1.27))))
          (number "39" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at -27.94 -24.13 0) (length 2.54)
          (name "RG1" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at 27.94 -36.83 180) (length 2.54)
          (name "RA6" (effects (font (size 1.27 1.27))))
          (number "40" (effects (font (size 1.27 1.27))))
        (pin power_in line (at 27.94 -34.29 180) (length 2.54)
          (number "41" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at 27.94 -31.75 180) (length 2.54)
          (name "RB6" (effects (font (size 1.27 1.27))))
          (number "42" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at 27.94 -29.21 180) (length 2.54)
          (name "RB5" (effects (font (size 1.27 1.27))))
          (number "43" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at 27.94 -26.67 180) (length 2.54)
          (name "RB4" (effects (font (size 1.27 1.27))))
          (number "44" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at 27.94 -24.13 180) (length 2.54)
          (name "RB3" (effects (font (size 1.27 1.27))))
          (number "45" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at 27.94 -21.59 180) (length 2.54)
          (name "RB2" (effects (font (size 1.27 1.27))))
          (number "46" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at 27.94 -19.05 180) (length 2.54)
          (name "RB1" (effects (font (size 1.27 1.27))))
          (number "47" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at 27.94 -16.51 180) (length 2.54)
          (name "RB0" (effects (font (size 1.27 1.27))))
          (number "48" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at 19.05 -6.35 270) (length 2.54)
          (name "RD7" (effects (font (size 1.27 1.27))))
          (number "49" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at -27.94 -26.67 0) (length 2.54)
          (name "RG2" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at 16.51 -6.35 270) (length 2.54)
          (name "RD6" (effects (font (size 1.27 1.27))))
          (number "50" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at 13.97 -6.35 270) (length 2.54)
          (name "RD5" (effects (font (size 1.27 1.27))))
          (number "51" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at 11.43 -6.35 270) (length 2.54)
          (name "RD4" (effects (font (size 1.27 1.27))))
          (number "52" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at 8.89 -6.35 270) (length 2.54)
          (name "RD3" (effects (font (size 1.27 1.27))))
          (number "53" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at 6.35 -6.35 270) (length 2.54)
          (name "RD2" (effects (font (size 1.27 1.27))))
          (number "54" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at 3.81 -6.35 270) (length 2.54)
          (name "RD1" (effects (font (size 1.27 1.27))))
          (number "55" (effects (font (size 1.27 1.27))))
        (pin power_in line (at 1.27 -6.35 270) (length 2.54)
          (number "56" (effects (font (size 1.27 1.27))))
        (pin power_in line (at -1.27 -6.35 270) (length 2.54)
          (number "57" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at -3.81 -6.35 270) (length 2.54)
          (name "RD0" (effects (font (size 1.27 1.27))))
          (number "58" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at -6.35 -6.35 270) (length 2.54)
          (name "RE7" (effects (font (size 1.27 1.27))))
          (number "59" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at -27.94 -29.21 0) (length 2.54)
          (name "RG3" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at -8.89 -6.35 270) (length 2.54)
          (name "RE6" (effects (font (size 1.27 1.27))))
          (number "60" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at -11.43 -6.35 270) (length 2.54)
          (name "RE5" (effects (font (size 1.27 1.27))))
          (number "61" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at -13.97 -6.35 270) (length 2.54)
          (name "RE4" (effects (font (size 1.27 1.27))))
          (number "62" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at -16.51 -6.35 270) (length 2.54)
          (name "RE3" (effects (font (size 1.27 1.27))))
          (number "63" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at -19.05 -6.35 270) (length 2.54)
          (name "RE2" (effects (font (size 1.27 1.27))))
          (number "64" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at -27.94 -31.75 0) (length 2.54)
          (name "VPP/MLCR/RG5" (effects (font (size 1.27 1.27))))
        (pin bidirectional line (at -27.94 -34.29 0) (length 2.54)
          (name "RG4" (effects (font (size 1.27 1.27))))
        (pin power_in line (at -27.94 -36.83 0) (length 2.54)
  (junction (at 82.55 129.54) (diameter 0) (color 0 0 0 0)
    (uuid 01e9b6e7-adf9-4ee7-9447-a588630ee4a2)
  (junction (at 101.6 34.29) (diameter 0) (color 0 0 0 0)
    (uuid 0325ec43-0390-4ae2-b055-b1ec6ce17b1c)
  (junction (at 129.54 21.59) (diameter 0) (color 0 0 0 0)
    (uuid 099096e4-8c2a-4d84-a16f-06b4b6330e7a)
  (junction (at 186.69 127) (diameter 0) (color 0 0 0 0)
    (uuid 0a1ec92c-fd4e-4648-b4f0-33fc92ff1918)
  (junction (at 36.83 90.17) (diameter 0) (color 0 0 0 0)
    (uuid 0cc45b5b-96b3-4284-9cae-a3a9e324a916)
  (junction (at 140.97 134.62) (diameter 0) (color 0 0 0 0)
    (uuid 163301a3-8e60-4437-9c75-8437342cce43)
  (junction (at 193.04 111.76) (diameter 0) (color 0 0 0 0)
    (uuid 174764fc-a960-474c-aab8-ca2fe9926057)
  (junction (at 36.83 114.3) (diameter 0) (color 0 0 0 0)
    (uuid 1f8b2c0c-b042-4e2e-80f6-4959a27b238f)
  (junction (at 172.72 46.99) (diameter 0) (color 0 0 0 0)
    (uuid 20cb6c7c-21a2-4704-9fae-202efebc737d)
  (junction (at 60.96 97.79) (diameter 0) (color 0 0 0 0)
    (uuid 25d545dc-8f50-4573-922c-35ef5a2a3a19)
  (junction (at 55.88 129.54) (diameter 0) (color 0 0 0 0)
    (uuid 2dc272bd-3aa2-45b5-889d-1d3c8aac80f8)
  (junction (at 107.95 24.13) (diameter 0) (color 0 0 0 0)
    (uuid 2e842263-c0ba-46fd-a760-6624d4c78278)
  (junction (at 391.16 50.8) (diameter 0) (color 0 0 0 0)
    (uuid 302b3ec5-d5a0-4158-9cc4-f0e259fa3d6f)
  (junction (at 36.83 107.95) (diameter 0) (color 0 0 0 0)
    (uuid 31540a7e-dc9e-4e4d-96b1-dab15efa5f4b)
  (junction (at 52.07 33.02) (diameter 0) (color 0 0 0 0)
    (uuid 36c4f8cd-46de-4cbf-884e-dba27f535fe0)
  (junction (at 77.47 129.54) (diameter 0) (color 0 0 0 0)
    (uuid 4a850cb6-bb24-4274-a902-e49f34f0a0e3)
  (junction (at 189.865 106.68) (diameter 0) (color 0 0 0 0)
    (uuid 53cbaf1a-5750-4534-a1e5-a829a5297574)
  (junction (at 55.88 97.79) (diameter 0) (color 0 0 0 0)
    (uuid 5bcace5d-edd0-4e19-92d0-835e43cf8eb2)
  (junction (at 271.78 40.64) (diameter 0) (color 0 0 0 0)
    (uuid 635fae87-e9e1-48c3-b824-13f59b5c112f)
  (junction (at 161.29 134.62) (diameter 0) (color 0 0 0 0)
    (uuid 6ccbd230-c2c5-4b24-9040-7b02acc6fb58)
  (junction (at 73.66 39.37) (diameter 0) (color 0 0 0 0)
    (uuid 6fd4442e-30b3-428b-9306-61418a63d311)
  (junction (at 87.63 34.29) (diameter 0) (color 0 0 0 0)
    (uuid 721d1be9-236e-470b-ba69-f1cc6c43faf9)
  (junction (at 187.96 46.99) (diameter 0) (color 0 0 0 0)
    (uuid 78edbb06-9263-4d66-9be6-4dc70173b18d)
  (junction (at 148.59 127) (diameter 0) (color 0 0 0 0)
    (uuid 794b25ad-3f2e-425a-a385-bad0c00adb34)
  (junction (at 401.32 54.61) (diameter 0) (color 0 0 0 0)
    (uuid 7b655fc1-0fd7-417a-8f3d-7f313c5c202f)
  (junction (at 391.16 44.45) (diameter 0) (color 0 0 0 0)
    (uuid 7b9f4534-371b-4ca6-903a-b1f0aececb81)
  (junction (at 64.77 129.54) (diameter 0) (color 0 0 0 0)
    (uuid 8e06ba1f-e3ba-4eb9-a10e-887dffd566d6)
  (junction (at 116.84 21.59) (diameter 0) (color 0 0 0 0)
    (uuid 98c78427-acd5-4f90-9ad6-9f61c4809aec)
  (junction (at 36.83 129.54) (diameter 0) (color 0 0 0 0)
    (uuid 998b7fa5-31a5-472e-9572-49d5226d6098)
  (junction (at 406.4 54.61) (diameter 0) (color 0 0 0 0)
    (uuid 9a204d4e-0663-4d10-931f-1dc1e1d02e90)
  (junction (at 129.54 53.34) (diameter 0) (color 0 0 0 0)
    (uuid 9cbf35b8-f4d3-42a3-bb16-04ffd03fd8fd)
  (junction (at 391.16 74.93) (diameter 0) (color 0 0 0 0)
    (uuid aa5081cc-2afd-4741-b13b-b00043a7c75e)
  (junction (at 271.78 29.21) (diameter 0) (color 0 0 0 0)
    (uuid abef3ad0-4d03-4762-af4f-2925ee5e0644)
  (junction (at 406.4 44.45) (diameter 0) (color 0 0 0 0)
    (uuid ad68d0c2-d2cf-412d-99c7-4c852ee8603b)
  (junction (at 186.69 59.69) (diameter 0) (color 0 0 0 0)
    (uuid bcdf00d4-de96-4929-9b4e-0b6441600b8e)
  (junction (at 140.97 101.6) (diameter 0) (color 0 0 0 0)
    (uuid bfc84913-8bb6-4d02-9c41-20a53249f44c)
  (junction (at 60.96 129.54) (diameter 0) (color 0 0 0 0)
    (uuid c25a772d-af9c-4ebc-96f6-0966738c13a8)
  (junction (at 203.2 59.69) (diameter 0) (color 0 0 0 0)
    (uuid cc9d01e5-4db9-4a33-bffe-5b70eecdb775)
  (junction (at 214.63 39.37) (diameter 0) (color 0 0 0 0)
    (uuid cdd8802a-104d-4ecd-913d-63caa2b4f981)
  (junction (at 60.96 19.05) (diameter 0) (color 0 0 0 0)
    (uuid d0fb0864-e79b-4bdc-8e8e-eed0cabe6d56)
  (junction (at 182.88 106.68) (diameter 0) (color 0 0 0 0)
    (uuid d0ff5931-4fa5-480d-bf93-d91a60a8f2d1)
  (junction (at 171.45 101.6) (diameter 0) (color 0 0 0 0)
    (uuid d3c1261b-6036-41d7-b48a-f70da20b76d9)
  (junction (at 177.165 134.62) (diameter 0) (color 0 0 0 0)
    (uuid d7720325-7c88-44fe-a0f5-a5b452a29655)
  (junction (at 58.42 97.79) (diameter 0) (color 0 0 0 0)
    (uuid db36f6e3-e72a-487f-bda9-88cc84536f62)
  (junction (at 64.77 113.03) (diameter 0) (color 0 0 0 0)
    (uuid e502d1d5-04b0-4d4b-b5c3-8c52d09668e7)
  (junction (at 64.77 120.65) (diameter 0) (color 0 0 0 0)
    (uuid ec31c074-17b2-48e1-ab01-071acad3fa04)
  (junction (at 82.55 60.96) (diameter 0) (color 0 0 0 0)
    (uuid ec5c2062-3a41-4636-8803-069e60a1641a)
  (junction (at 46.99 129.54) (diameter 0) (color 0 0 0 0)
    (uuid f449bd37-cc90-4487-aee6-2a20b8d2843a)
  (junction (at 58.42 90.17) (diameter 0) (color 0 0 0 0)
    (uuid f6c644f4-3036-41a6-9e14-2c08c079c6cd)
  (junction (at 82.55 146.05) (diameter 0) (color 0 0 0 0)
    (uuid f9403623-c00c-4b71-bc5c-d763ff009386)
  (no_connect (at 74.93 100.33) (uuid 40165eda-4ba6-4565-9bb4-b9df6dbb08da))
  (no_connect (at 74.93 105.41) (uuid 4780a290-d25c-4459-9579-eba3f7678762))
  (no_connect (at 74.93 102.87) (uuid 7e023245-2c2b-4e2b-bfb9-5d35176e88f2))
  (no_connect (at 74.93 107.95) (uuid df68c26a-03b5-4466-aecf-ba34b7dce6b7))
  (no_connect (at 68.58 175.26) (uuid e4b930d4-e153-4821-a72c-c924db7df444))
  (no_connect (at 71.12 175.26) (uuid f5cebb55-27eb-45e9-9a1a-a69e7e44d3ed))
  (wire (pts (xy 64.77 120.65) (xy 64.77 129.54))
    (uuid 003c2200-0632-4808-a662-8ddd5d30c768)
  (wire (pts (xy 177.165 134.62) (xy 226.06 134.62))
    (uuid 00c9b569-1b4b-437f-9fce-02beb1dd2e53)
  (wire (pts (xy 259.08 29.21) (xy 271.78 29.21))
    (uuid 00e74d54-09df-495b-9a27-66b55a67fac2)
  (wire (pts (xy 391.16 50.8) (xy 391.16 44.45))
    (uuid 01bdaa3b-b8d7-4941-8e59-6c4676121114)
  (wire (pts (xy 68.58 232.41) (xy 68.58 242.57))
    (uuid 065a4429-f8c5-436e-8eee-9bb327dcc1de)
  (wire (pts (xy 177.165 125.73) (xy 177.165 134.62))
    (uuid 095c4326-5a8c-4706-b087-3f02d0e89ed3)
  (wire (pts (xy 107.95 53.34) (xy 129.54 53.34))
    (uuid 097edb1b-8998-4e70-b670-bba125982348)
  (wire (pts (xy 140.97 101.6) (xy 171.45 101.6))
    (uuid 09fe9726-a1ec-4a3a-867a-188d385210f1)
  (wire (pts (xy 400.05 71.12) (xy 410.21 71.12))
    (uuid 0dea0345-6808-4180-bd83-4a32bb9ba8d2)
  (wire (pts (xy 50.8 232.41) (xy 50.8 242.57))
    (uuid 0ef867a3-365c-4f90-9824-41f907a13f60)
  (wire (pts (xy 36.83 129.54) (xy 25.4 129.54))
    (uuid 0f31f11f-c374-4640-b9a4-07bbdba8d354)
  (wire (pts (xy 31.75 205.74) (xy 41.91 205.74))
    (uuid 10f3dfcf-9db2-4e9a-a434-d2de041151c4)
  (wire (pts (xy 391.16 44.45) (xy 394.97 44.45))
    (uuid 11d48756-27ec-488f-baf1-266dc4e919d2)
  (wire (pts (xy 87.63 129.54) (xy 82.55 129.54))
    (uuid 12422a89-3d0c-485c-9386-f77121fd68fd)
  (wire (pts (xy 86.36 166.37) (xy 86.36 175.26))
    (uuid 13a26431-b469-4f09-b99b-d061b7cf52d1)
  (wire (pts (xy 73.66 166.37) (xy 73.66 175.26))
    (uuid 15496bc8-ccca-430d-88de-0ff3fb9264b6)
  (wire (pts (xy 171.45 128.27) (xy 163.83 128.27))
    (uuid 17eaf7ab-a300-442a-8ee0-2bd59c9511fb)
  (wire (pts (xy 36.83 129.54) (xy 46.99 129.54))
    (uuid 18b7e157-ae67-48ad-bd7c-9fef6fe45b22)
  (wire (pts (xy 64.77 113.03) (xy 74.93 113.03))
    (uuid 18ea3245-215a-4186-bfd3-103d2b826964)
  (wire (pts (xy 52.07 33.02) (xy 53.34 33.02))
    (uuid 19a19e2e-dc87-43a8-8279-f50be207cdc6)
  (wire (pts (xy 154.94 125.73) (xy 154.94 127))
    (uuid 1d38e39c-3bfd-4e37-b72c-c7417b377e07)
  (wire (pts (xy 193.04 111.76) (xy 214.63 111.76))
    (uuid 1d9cdadc-9036-4a95-b6db-fa7b3b74c869)
  (wire (pts (xy 271.78 29.21) (xy 271.78 33.02))
    (uuid 22260e2e-af7a-4097-b752-818be707cb91)
  (wire (pts (xy 148.59 125.73) (xy 148.59 127))
    (uuid 22beb590-a4f7-4f48-912f-98d99c0449d6)
  (wire (pts (xy 76.2 166.37) (xy 76.2 175.26))
    (uuid 23381928-a497-4bb7-9e06-3cd22e6d445a)
  (wire (pts (xy 214.63 104.14) (xy 212.09 104.14))
    (uuid 24f7628d-681d-4f0e-8409-40a129e929d9)
  (wire (pts (xy 391.16 77.47) (xy 394.97 77.47))
    (uuid 2520ef0f-2c3f-4f87-8160-b56bbdf830a2)
  (wire (pts (xy 53.34 166.37) (xy 53.34 175.26))
    (uuid 259c047b-4e68-45e1-9a93-222c5fcc69ee)
  (wire (pts (xy 63.5 92.71) (xy 63.5 82.55))
    (uuid 26a5dc24-85c3-4b66-9f46-544b6867474c)
  (wire (pts (xy 71.12 39.37) (xy 73.66 39.37))
    (uuid 27d56953-c620-4d5b-9c1c-e48bc3d9684a)
  (wire (pts (xy 83.82 166.37) (xy 83.82 175.26))
    (uuid 27ddd23f-e5ba-442d-9250-48d762e9a069)
  (wire (pts (xy 60.96 19.05) (xy 68.58 19.05))
    (uuid 29195ea4-8218-44a1-b4bf-466bee0082e4)
  (wire (pts (xy 41.91 33.02) (xy 31.75 33.02))
    (uuid 2a64d97f-817e-497f-86d4-4422911b8573)
  (wire (pts (xy 148.59 111.76) (xy 193.04 111.76))
    (uuid 2d1dad02-6a1d-46d3-b854-5aa81ab4f8f5)
  (wire (pts (xy 127 96.52) (xy 186.69 96.52))
    (uuid 2dc54bac-8640-4dd7-b8ed-3c7acb01a8ea)
  (wire (pts (xy 97.79 223.52) (xy 105.41 223.52))
    (uuid 2ea5102d-0361-4bba-934e-88f71e191a43)
  (wire (pts (xy 76.2 232.41) (xy 76.2 242.57))
    (uuid 312c1ebf-293d-4a47-aba4-f95ebbefa4d8)
  (wire (pts (xy 64.77 129.54) (xy 77.47 129.54))
    (uuid 316d1ce4-a05b-435e-9135-3983d49264ca)
  (wire (pts (xy 177.8 59.69) (xy 186.69 59.69))
    (uuid 32554fc8-cb49-4082-8504-db43b97e1dcd)
  (wire (pts (xy 226.06 118.11) (xy 226.06 134.62))
    (uuid 3322c855-9fe7-4591-a161-4f60c1531eee)
  (wire (pts (xy 163.83 118.11) (xy 161.29 118.11))
    (uuid 334fb2cc-f220-404d-991e-9dbe70a9d282)
  (wire (pts (xy 271.78 40.64) (xy 276.86 40.64))
    (uuid 35849f21-653e-47cc-93db-d2c5fa6bebfa)
  (wire (pts (xy 382.27 74.93) (xy 391.16 74.93))
    (uuid 39211402-b9fe-4fbe-b865-b92525ce6e3f)
  (wire (pts (xy 214.63 111.76) (xy 214.63 104.14))
    (uuid 3a7648d8-121a-4921-9b92-9b35b76ce39b)
  (wire (pts (xy 50.8 97.79) (xy 55.88 97.79))
    (uuid 3cd1bda0-18db-417d-b581-a0c50623df68)
  (wire (pts (xy 193.04 121.92) (xy 196.85 121.92))
    (uuid 3e903008-0276-4a73-8edb-5d9dfde6297c)
  (wire (pts (xy 60.96 27.94) (xy 60.96 19.05))
    (uuid 3fd54105-4b7e-4004-9801-76ec66108a22)
  (wire (pts (xy 125.73 134.62) (xy 140.97 134.62))
    (uuid 40976bf0-19de-460f-ad64-224d4f51e16b)
  (wire (pts (xy 60.96 232.41) (xy 60.96 242.57))
    (uuid 40c15374-bae6-4384-a6f1-53df7c100630)
  (wire (pts (xy 88.9 232.41) (xy 88.9 242.57))
    (uuid 44c598f7-5851-42ce-a945-a5411a378c02)
  (wire (pts (xy 182.88 106.68) (xy 189.865 106.68))
    (uuid 464db139-83b6-420c-b6b7-8de07adb5312)
  (wire (pts (xy 97.79 220.98) (xy 105.41 220.98))
    (uuid 46ca3ae1-1994-4117-b72a-025a0993282c)
  (wire (pts (xy 406.4 38.1) (xy 406.4 44.45))
    (uuid 49210aa2-6d80-4162-abcd-286e7913d770)
  (wire (pts (xy 53.34 232.41) (xy 53.34 242.57))
    (uuid 4977ccd3-c093-4a84-a940-2b7f24261da0)
  (wire (pts (xy 81.28 166.37) (xy 81.28 175.26))
    (uuid 49b002a6-ca14-46b5-a879-97d24b9068a2)
  (wire (pts (xy 64.77 113.03) (xy 64.77 120.65))
    (uuid 4a21e717-d46d-4d9e-8b98-af4ecb02d3ec)
  (wire (pts (xy 60.96 175.26) (xy 60.96 166.37))
    (uuid 4a83bc96-9905-4b01-adf6-977091a7d3e3)
  (wire (pts (xy 67.31 115.57) (xy 74.93 115.57))
    (uuid 4b7166c5-302a-4199-9323-e655083069b1)
  (wire (pts (xy 391.16 38.1) (xy 391.16 44.45))
    (uuid 4c4fc646-551e-4d3f-988f-1d8d4de6caf2)
  (wire (pts (xy 400.05 44.45) (xy 406.4 44.45))
    (uuid 4dc458bf-95fc-40bc-8603-aeb38121142c)
  (wire (pts (xy 82.55 129.54) (xy 82.55 134.62))
    (uuid 4f66b314-0f62-4fb6-8c3c-f9c6a75cd3ec)
  (wire (pts (xy 129.54 53.34) (xy 137.16 53.34))
    (uuid 4fa10683-33cd-4dcd-8acc-2415cd63c62a)
  (wire (pts (xy 55.88 114.3) (xy 55.88 129.54))
    (uuid 5114c7bf-b955-49f3-a0a8-4b954c81bde0)
  (wire (pts (xy 203.2 59.69) (xy 214.63 59.69))
    (uuid 51f419dc-2b53-4fed-9326-4d14ad4e8b2c)
  (wire (pts (xy 394.97 54.61) (xy 391.16 54.61))
    (uuid 527b74f0-20a9-4164-9d59-d7e9ef4646b7)
  (wire (pts (xy 186.69 125.73) (xy 186.69 127))
    (uuid 55b988b9-e011-489e-a300-e5e1e609cd58)
  (wire (pts (xy 154.94 106.68) (xy 154.94 120.65))
    (uuid 570df70e-049e-4365-90b9-8ef75007965f)
  (wire (pts (xy 97.79 198.12) (xy 106.68 198.12))
    (uuid 5789bcc6-2602-4186-8866-216abdf4705e)
  (wire (pts (xy 97.79 185.42) (xy 106.68 185.42))
    (uuid 59e1579a-4837-4974-838f-379e82e492d3)
  (wire (pts (xy 171.45 101.6) (xy 171.45 128.27))
    (uuid 5a545b35-7bdf-47e6-a456-430566d693dd)
  (wire (pts (xy 87.63 34.29) (xy 82.55 34.29))
    (uuid 5edcefbe-9766-42c8-9529-28d0ec865573)
  (wire (pts (xy 36.83 123.19) (xy 36.83 129.54))
    (uuid 5fc9acb6-6dbb-4598-825b-4b9e7c4c67c4)
  (wire (pts (xy 63.5 92.71) (xy 74.93 92.71))
    (uuid 5fd7fddb-9b46-4af4-bec3-c1f128188e1e)
  (wire (pts (xy 406.4 44.45) (xy 417.83 44.45))
    (uuid 61e1f990-e4bf-4c6d-9000-2762ea2f4563)
  (wire (pts (xy 97.79 21.59) (xy 116.84 21.59))
    (uuid 6284122b-79c3-4e04-925e-3d32cc3ec077)
  (wire (pts (xy 31.75 208.28) (xy 41.91 208.28))
    (uuid 62eefc6c-6a64-4a3c-a3e1-337a09b17783)
  (wire (pts (xy 158.75 59.69) (xy 172.72 59.69))
    (uuid 63d3bbe8-8410-48c6-85e1-af45ba0e2ef0)
  (wire (pts (xy 116.84 21.59) (xy 129.54 21.59))
    (uuid 65134029-dbd2-409a-85a8-13c2a33ff019)
  (wire (pts (xy 66.04 39.37) (xy 60.96 39.37))
    (uuid 6781326c-6e0d-4753-8f28-0f5c687e01f9)
  (wire (pts (xy 64.77 120.65) (xy 74.93 120.65))
    (uuid 6808be3b-445c-41cd-a59b-d445c1208ea1)
  (wire (pts (xy 189.865 106.68) (xy 196.85 106.68))
    (uuid 68122bda-6e04-402b-89a8-3548ffb0d062)
  (wire (pts (xy 31.75 218.44) (xy 41.91 218.44))
    (uuid 6b6a5170-71ed-4b5e-8698-0c07fcb58794)
  (wire (pts (xy 36.83 90.17) (xy 58.42 90.17))
    (uuid 6b7c1048-12b6-46b2-b762-fa3ad30472dd)
  (wire (pts (xy 97.79 215.9) (xy 105.41 215.9))
    (uuid 6bef838d-e89a-4538-a4b1-f0d5e74656c2)
  (wire (pts (xy 193.04 121.92) (xy 193.04 111.76))
    (uuid 6bfe5804-2ef9-4c65-b2a7-f01e4014370a)
  (wire (pts (xy 55.88 129.54) (xy 46.99 129.54))
    (uuid 6c2d26bc-6eca-436c-8025-79f817bf57d6)
  (wire (pts (xy 107.95 35.56) (xy 107.95 53.34))
    (uuid 6c67e4f6-9d04-4539-b356-b76e915ce848)
  (wire (pts (xy 90.17 146.05) (xy 82.55 146.05))
    (uuid 6d1d60ff-408a-47a7-892f-c5cf9ef6ca75)
  (wire (pts (xy 36.83 114.3) (xy 36.83 118.11))
    (uuid 700e8b73-5976-423f-a3f3-ab3d9f3e9760)
  (wire (pts (xy 100.33 90.17) (xy 104.14 90.17))
    (uuid 70fb572d-d5ec-41e7-9482-63d4578b4f47)
  (wire (pts (xy 259.08 40.64) (xy 271.78 40.64))
    (uuid 711d5ec9-3b77-418e-8948-7367a9d44fbd)
  (wire (pts (xy 401.32 54.61) (xy 400.05 54.61))
    (uuid 74f2fa45-e9f6-40d1-b3fc-d3fc6603814d)
  (wire (pts (xy 148.59 120.65) (xy 148.59 111.76))
    (uuid 77f36f29-ab03-4c19-9c6a-a2d42f26a525)
  (wire (pts (xy 74.93 95.25) (xy 64.77 95.25))
    (uuid 789ca812-3e0c-4a3f-97bc-a916dd9bce80)
  (wire (pts (xy 182.88 127) (xy 186.69 127))
    (uuid 7a28d260-15d1-44f1-97c4-409d795b529a)
  (wire (pts (xy 31.75 213.36) (xy 41.91 213.36))
    (uuid 7aa988ee-98d6-4961-ad38-c77e27af450c)
  (wire (pts (xy 186.69 96.52) (xy 186.69 120.65))
    (uuid 7ad3527a-f87f-4c70-85bd-68c8d3162e77)
  (wire (pts (xy 101.6 34.29) (xy 104.14 34.29))
    (uuid 7b044939-8c4d-444f-b9e0-a15fcdeb5a86)
  (wire (pts (xy 46.99 33.02) (xy 52.07 33.02))
    (uuid 7b7d9117-d84d-4524-b07a-e88f7b2cc9f3)
  (wire (pts (xy 73.66 48.26) (xy 73.66 39.37))
    (uuid 7c04618d-9115-4179-b234-a8faf854ea92)
  (wire (pts (xy 87.63 128.27) (xy 87.63 129.54))
    (uuid 7d34f6b1-ab31-49be-b011-c67fe67a8a56)
  (wire (pts (xy 140.97 134.62) (xy 161.29 134.62))
    (uuid 7f8ca547-1d4d-41ba-a7d4-6794b6d59371)
  (wire (pts (xy 214.63 30.48) (xy 214.63 26.67))
    (uuid 816a6024-448e-48dd-b513-a27608d3fa27)
  (wire (pts (xy 82.55 44.45) (xy 82.55 60.96))
    (uuid 81a15393-727e-448b-a777-b18773023d89)
  (wire (pts (xy 406.4 52.07) (xy 406.4 54.61))
    (uuid 8262859e-0cd2-4999-b15a-5711a2500f49)
  (wire (pts (xy 394.97 38.1) (xy 391.16 38.1))
    (uuid 85c70d65-fac0-4544-a1c7-71b1d8717d51)
  (wire (pts (xy 60.96 97.79) (xy 74.93 97.79))
    (uuid 8606b0d8-3007-467b-bbcc-cd90d302faf3)
  (wire (pts (xy 226.06 90.17) (xy 226.06 102.87))
    (uuid 88668202-3f0b-4d07-84d4-dcd790f57272)
  (wire (pts (xy 36.83 105.41) (xy 36.83 107.95))
    (uuid 8c1605f9-6c91-4701-96bf-e753661d5e23)
  (wire (pts (xy 60.96 129.54) (xy 55.88 129.54))
    (uuid 8c514922-ffe1-4e37-a260-e807409f2e0d)
  (wire (pts (xy 73.66 39.37) (xy 74.93 39.37))
    (uuid 8d0c1d66-35ef-4a53-a28f-436a11b54f42)
  (wire (pts (xy 73.66 60.96) (xy 73.66 53.34))
    (uuid 9193c41e-d425-447d-b95c-6986d66ea01c)
  (wire (pts (xy 66.04 232.41) (xy 66.04 242.57))
    (uuid 924c0b42-b0f3-4d80-a50e-554dabbcdae3)
  (wire (pts (xy 401.32 54.61) (xy 406.4 54.61))
    (uuid 92dbbdb2-6bbf-4a62-a4fc-25b484962fd4)
  (wire (pts (xy 382.27 44.45) (xy 391.16 44.45))
    (uuid 92e353b5-558d-4a0c-9c74-40b7145940ec)
  (wire (pts (xy 58.42 90.17) (xy 74.93 90.17))
    (uuid 944389ce-9c44-416c-a649-5fe71f1f2c6b)
  (wire (pts (xy 391.16 50.8) (xy 394.97 50.8))
    (uuid 94980176-fde0-4bc9-891b-c36e62446512)
  (wire (pts (xy 154.94 127) (xy 148.59 127))
    (uuid 95b59f04-10ee-4f10-a09e-ea71f2a01eaa)
  (wire (pts (xy 212.09 124.46) (xy 219.71 124.46))
    (uuid 965308c8-e014-459a-b9db-b8493a601c62)
  (wire (pts (xy 88.9 166.37) (xy 88.9 175.26))
    (uuid 96b4599b-613c-4539-b99d-4044dd304bff)
  (wire (pts (xy 82.55 146.05) (xy 33.02 146.05))
    (uuid 970e0f64-111f-41e3-9f5a-fb0d0f6fa101)
  (wire (pts (xy 391.16 74.93) (xy 391.16 77.47))
    (uuid 97226c85-e3e2-4894-9089-1db62ca23c2d)
  (wire (pts (xy 129.54 53.34) (xy 129.54 39.37))
    (uuid 994b6220-4755-4d84-91b3-6122ac1c2c5e)
  (wire (pts (xy 391.16 54.61) (xy 391.16 50.8))
    (uuid 9a5fce40-8d18-4c42-a1a1-7e331b0cb58d)
  (wire (pts (xy 276.86 33.02) (xy 276.86 29.21))
    (uuid 9bb96b4b-f248-446f-baa7-ba0d3b1fd45d)
  (wire (pts (xy 400.05 38.1) (xy 406.4 38.1))
    (uuid 9d9d7920-ab00-4b20-9a51-5c67aa554926)
  (wire (pts (xy 391.16 71.12) (xy 391.16 74.93))
    (uuid a00f68bb-ee61-4ac7-8c3a-3ba7c93ca3dc)
  (wire (pts (xy 137.16 21.59) (xy 129.54 21.59))
    (uuid a13ab237-8f8d-4e16-8c47-4440653b8534)
  (wire (pts (xy 87.63 78.74) (xy 33.02 78.74))
    (uuid a15a7506-eae4-4933-84da-9ad754258706)
  (wire (pts (xy 186.69 59.69) (xy 194.31 59.69))
    (uuid a1902153-778f-44a1-850e-b194d5d34c13)
  (wire (pts (xy 140.97 101.6) (xy 140.97 119.38))
    (uuid a1a90daa-e2ea-4522-a738-2d7cb47df693)
  (wire (pts (xy 52.07 19.05) (xy 60.96 19.05))
    (uuid a31ccc24-7d73-459c-a1d7-970970c73307)
  (wire (pts (xy 400.05 77.47) (xy 410.21 77.47))
    (uuid a344ec94-dcd9-46ae-9dd4-c95f08a5d127)
  (wire (pts (xy 177.165 120.65) (xy 177.165 86.36))
    (uuid a362f0e0-8a84-4fad-9647-c823b2db680f)
  (wire (pts (xy 36.83 90.17) (xy 36.83 100.33))
    (uuid a53767ed-bb28-4f90-abe0-e0ea734812a4)
  (wire (pts (xy 58.42 166.37) (xy 58.42 175.26))
    (uuid a934829e-8005-4027-96d3-11f35289eb9c)
  (wire (pts (xy 99.06 34.29) (xy 101.6 34.29))
    (uuid aa2ea573-3f20-43c1-aa99-1f9c6031a9aa)
  (wire (pts (xy 97.79 187.96) (xy 106.68 187.96))
    (uuid aa56910f-c586-4ca1-96ae-8f6856e67298)
  (wire (pts (xy 186.69 127) (xy 196.85 127))
    (uuid ad3e6a98-d1db-4bdd-bcf2-51abc7dcf9bb)
  (wire (pts (xy 31.75 203.2) (xy 41.91 203.2))
    (uuid ad504d11-d4b3-4dc0-846f-5ba4b9465c14)
  (wire (pts (xy 161.29 134.62) (xy 177.165 134.62))
    (uuid b0542c08-87d3-42c8-afce-2e4a720cf404)
  (wire (pts (xy 45.72 97.79) (xy 25.4 97.79))
    (uuid b1ddb058-f7b2-429c-9489-f4e2242ad7e5)
  (wire (pts (xy 63.5 82.55) (xy 25.4 82.55))
    (uuid b1ecae92-369a-4bdd-9a4f-4ff32074622c)
  (wire (pts (xy 78.74 232.41) (xy 78.74 242.57))
    (uuid b229c080-39bb-4d52-86fc-3b7f073902c5)
  (wire (pts (xy 36.83 107.95) (xy 36.83 114.3))
    (uuid b4300db7-1220-431a-b7c3-2edbdf8fa6fc)
  (wire (pts (xy 107.95 27.94) (xy 107.95 24.13))
    (uuid b447dbb1-d38e-4a15-93cb-12c25382ea53)
  (wire (pts (xy 31.75 210.82) (xy 41.91 210.82))
    (uuid b85f6e7e-d792-496c-ad82-28250aee6108)
  (wire (pts (xy 52.07 27.94) (xy 52.07 33.02))
    (uuid b8e45bb1-d28d-4a6d-9422-e4384dabcabd)
  (wire (pts (xy 406.4 44.45) (xy 406.4 46.99))
    (uuid bbc7316f-f150-4acd-823a-7f299c6652aa)
  (wire (pts (xy 181.61 46.99) (xy 187.96 46.99))
    (uuid bbf2cda9-b894-4cb2-ba1b-f989e358506e)
  (wire (pts (xy 161.29 118.11) (xy 161.29 134.62))
    (uuid bc7d4562-7670-4cbb-9141-8a8c9fc4fcf6)
  (wire (pts (xy 55.88 97.79) (xy 58.42 97.79))
    (uuid bd065eaf-e495-4837-bdb3-129934de1fc7)
  (wire (pts (xy 177.165 86.36) (xy 127 86.36))
    (uuid bd823c67-b456-4e9f-8ec9-14fb8b2ce4a9)
  (wire (pts (xy 276.86 29.21) (xy 271.78 29.21))
    (uuid bf11d6e8-fbcf-48a2-b959-55952f298e65)
  (wire (pts (xy 226.06 90.17) (xy 127 90.17))
    (uuid c24d6ac8-802d-4df3-a210-9cb1f693e865)
  (wire (pts (xy 60.96 39.37) (xy 60.96 38.1))
    (uuid c701ee8e-1214-4781-a973-17bef7b6e3eb)
  (wire (pts (xy 52.07 19.05) (xy 52.07 22.86))
    (uuid c71e3f01-de98-45c5-b95e-881adde5457e)
  (wire (pts (xy 36.83 90.17) (xy 25.4 90.17))
    (uuid c7e7067c-5f5e-48d8-ab59-df26f9b35863)
  (wire (pts (xy 60.96 109.22) (xy 60.96 97.79))
    (uuid c830e3bc-dc64-4f65-8f47-3b106bae2807)
  (wire (pts (xy 87.63 82.55) (xy 87.63 78.74))
    (uuid c8c79177-94d4-43e2-a654-f0a5554fbb68)
  (wire (pts (xy 55.88 166.37) (xy 55.88 175.26))
    (uuid c99172fb-4ae0-40d3-8d03-8c4989a34042)
  (wire (pts (xy 401.32 50.8) (xy 400.05 50.8))
    (uuid ca569798-2e27-488c-8289-3e66d7d29138)
  (wire (pts (xy 129.54 21.59) (xy 129.54 31.75))
    (uuid ca5a4651-0d1d-441b-b17d-01518ef3b656)
  (wire (pts (xy 82.55 129.54) (xy 77.47 129.54))
    (uuid ca87f11b-5f48-4b57-8535-68d3ec2fe5a9)
  (wire (pts (xy 55.88 109.22) (xy 55.88 97.79))
    (uuid cb24efdd-07c6-4317-9277-131625b065ac)
  (wire (pts (xy 31.75 223.52) (xy 41.91 223.52))
    (uuid cb7c321b-7f68-4ece-8124-825988cc771b)
  (wire (pts (xy 163.83 125.73) (xy 163.83 128.27))
    (uuid cc325c21-bb1b-46fc-a070-cdad4f2ea7f6)
  (wire (pts (xy 31.75 215.9) (xy 41.91 215.9))
    (uuid cddd0ad0-870d-4f5a-a781-2a7705bca2c4)
  (wire (pts (xy 107.95 24.13) (xy 97.79 24.13))
    (uuid cfa5c16e-7859-460d-a0b8-cea7d7ea629c)
  (wire (pts (xy 214.63 52.07) (xy 214.63 59.69))
    (uuid d06e7250-7798-4036-aa3d-e65bad0ae03e)
  (wire (pts (xy 172.72 46.99) (xy 158.75 46.99))
    (uuid d0e2b213-ef2f-40f2-b3ef-b100cb12562d)
  (wire (pts (xy 148.59 127) (xy 148.59 127.635))
    (uuid d3479ea2-0f7e-4418-8bdb-c12bbda828bd)
  (wire (pts (xy 97.79 218.44) (xy 105.41 218.44))
    (uuid d392203c-6d8c-4b5e-9011-0876a4a9334a)
  (wire (pts (xy 60.96 114.3) (xy 60.96 129.54))
    (uuid d5641ac9-9be7-46bf-90b3-6c83d852b5ba)
  (wire (pts (xy 172.72 46.99) (xy 176.53 46.99))
    (uuid d56d54b8-fdf7-4c56-906a-869536975566)
  (wire (pts (xy 97.79 193.04) (xy 106.68 193.04))
    (uuid d572599c-d288-4803-90df-b8ea553252d0)
  (wire (pts (xy 82.55 60.96) (xy 137.16 60.96))
    (uuid d5b800ca-1ab6-4b66-b5f7-2dda5658b504)
  (wire (pts (xy 140.97 124.46) (xy 140.97 134.62))
    (uuid d5faf3de-82b7-41b5-9fb7-6d67ae14965e)
  (wire (pts (xy 214.63 26.67) (xy 160.02 26.67))
    (uuid d62065da-0076-4f6d-bf70-95b60e8fb860)
  (wire (pts (xy 182.88 127) (xy 182.88 106.68))
    (uuid d672dfaf-1aed-4d57-ab11-7731b52f5a91)
  (wire (pts (xy 67.31 118.11) (xy 74.93 118.11))
    (uuid d7430f2b-baac-46ab-a687-b26fcabfde30)
  (wire (pts (xy 66.04 166.37) (xy 66.04 175.26))
    (uuid d800fa9b-30f2-486b-9133-634f57905fb7)
  (wire (pts (xy 187.96 46.99) (xy 207.01 46.99))
    (uuid dc117da5-d708-4507-9295-edc6f26ee720)
  (wire (pts (xy 82.55 139.7) (xy 82.55 146.05))
    (uuid dc2801a1-d539-4721-b31f-fe196b9f13df)
  (wire (pts (xy 127 101.6) (xy 140.97 101.6))
    (uuid dcaf394c-4bb7-4c28-8e74-b15d997f43ff)
  (wire (pts (xy 406.4 54.61) (xy 417.83 54.61))
    (uuid de42fcee-78c0-4092-96e2-a513d57bb4cd)
  (wire (pts (xy 41.91 220.98) (xy 31.75 220.98))
    (uuid de6af302-5c4e-471e-a8c4-e4b9e98a4602)
  (wire (pts (xy 276.86 40.64) (xy 276.86 38.1))
    (uuid de7506de-4a81-4d95-b5ba-5d3137b4591a)
  (wire (pts (xy 36.83 114.3) (xy 25.4 114.3))
    (uuid df32840e-2912-4088-b54c-9a85f64c0265)
  (wire (pts (xy 271.78 38.1) (xy 271.78 40.64))
    (uuid dfc923b2-bb87-44cd-866b-7fff18cb054f)
  (wire (pts (xy 163.83 120.65) (xy 163.83 118.11))
    (uuid e00d6444-3fbc-495c-9483-3861f395f30a)
  (wire (pts (xy 199.39 59.69) (xy 203.2 59.69))
    (uuid e2142aef-3139-4c61-b677-16ba3cc735da)
  (wire (pts (xy 97.79 195.58) (xy 106.68 195.58))
    (uuid e2bbea79-b940-4f4e-9f7e-3b3815442b5e)
  (wire (pts (xy 90.17 128.27) (xy 90.17 146.05))
    (uuid e4aa537c-eb9d-4dbb-ac87-fae46af42391)
  (wire (pts (xy 58.42 97.79) (xy 60.96 97.79))
    (uuid e4c6fdbb-fdc7-4ad4-a516-240d84cdc120)
  (wire (pts (xy 64.77 113.03) (xy 64.77 95.25))
    (uuid e4d2f565-25a0-48c6-be59-f4bf31ad2558)
  (wire (pts (xy 154.94 106.68) (xy 182.88 106.68))
    (uuid e66deccf-fb14-4717-b395-34d57b9dfc48)
  (wire (pts (xy 73.66 60.96) (xy 82.55 60.96))
    (uuid e67b9f8c-019b-4145-98a4-96545f6bb128)
  (wire (pts (xy 63.5 166.37) (xy 63.5 175.26))
    (uuid e8a78873-7379-4294-9576-9d4b8eb6a057)
  (wire (pts (xy 78.74 166.37) (xy 78.74 175.26))
    (uuid ea244dbe-0b93-425d-adc2-69c6d3ef74c6)
  (wire (pts (xy 214.63 35.56) (xy 214.63 39.37))
    (uuid eaf925ba-3d7c-478a-86b5-a619b4cb31c6)
  (wire (pts (xy 64.77 129.54) (xy 60.96 129.54))
    (uuid ee27d19c-8dca-4ac8-a760-6dfd54d28071)
  (wire (pts (xy 171.45 101.6) (xy 196.85 101.6))
    (uuid ef1e1887-37da-477d-a6c7-978cf931aa6f)
  (wire (pts (xy 401.32 50.8) (xy 401.32 54.61))
    (uuid f1928dd0-4c75-4b03-98ab-91d8bfb2789a)
  (wire (pts (xy 214.63 39.37) (xy 214.63 41.91))
    (uuid f1c7cbbc-6f0c-4a65-bf1f-db7259a4e3e3)
  (wire (pts (xy 97.79 190.5) (xy 106.68 190.5))
    (uuid f2a1e3e8-6eab-4ff5-b5ec-968e2c74b57e)
  (wire (pts (xy 93.98 34.29) (xy 87.63 34.29))
    (uuid f40d350f-0d3e-4f8a-b004-d950f2f8f1ba)
  (wire (pts (xy 83.82 232.41) (xy 83.82 242.57))
    (uuid f9143c05-379b-4137-8b16-9228ffdb5a30)
  (wire (pts (xy 86.36 232.41) (xy 86.36 242.57))
    (uuid fade2fb5-faae-473b-89a8-89b423756445)
  (wire (pts (xy 394.97 71.12) (xy 391.16 71.12))
    (uuid fcf9f414-02c4-4fec-a256-798c611f1c57)
  (text "9CC" (at 381 50.8 0)
    (effects (font (size 1.27 1.27)) (justify left bottom))
    (uuid 4454d033-2ceb-4971-83ce-629e6ace95a9)
  (text "640mV" (at 407.67 50.8 0)
    (uuid 781726c1-b2a4-4d4f-b6bc-3d8f0cc892ba)
  (text "411mV" (at 394.97 58.42 0)
    (uuid 7f4c4266-96e9-4932-832d-4ac5df026346)
  (text "645mV" (at 394.97 43.18 0)
    (uuid 86c311dd-2046-46bc-9732-901cf9c09eb9)
  (text "SOIC-16" (at 96.52 110.49 0)
    (uuid 922058ca-d09a-45fd-8394-05f3e2c1e03a)
  (text "BC858?" (at 379.73 54.61 0)
    (uuid a9ba9d6a-6655-4d8b-aa49-90702935de60)
  (text "411mV" (at 394.97 49.53 0)
    (uuid bfc952c0-acc4-49b7-96b7-5b7bb9f2617e)
  (text "953mV" (at 394.97 36.83 0)
    (uuid f7c9f352-5695-401e-9e3f-e14577bcaa4c)
  (label "LCD23" (at 31.75 218.44 0)
    (uuid 0055d365-84a5-4540-99e1-d6f81fc3593d)
  (label "LCD5" (at 81.28 166.37 270)
    (effects (font (size 1.27 1.27)) (justify right bottom))
    (uuid 010d384a-6926-4b13-a9fb-bf39385f00d3)
  (label "GND" (at 259.08 40.64 0)
    (uuid 0898d812-c3fa-4255-9549-c0b0b661d468)
  (label "LCD3" (at 76.2 166.37 270)
    (uuid 0a749787-a6ba-4649-bf57-70748f82086d)
  (label "Q1-3" (at 417.83 54.61 180)
    (uuid 18752c0c-6bdb-4f4a-8100-fc213a7ce19b)
  (label "Q1-3" (at 410.21 77.47 180)
    (uuid 1a8c4807-51ee-4184-99a5-8ca606ef9a04)
  (label "Q1-2" (at 410.21 71.12 180)
    (uuid 1b521835-2349-436c-8ca1-0d0dfe01c54f)
  (label "LCD31" (at 106.68 185.42 180)
    (uuid 1e5fbb31-1a0c-41a8-bf79-14adcf06eb42)
  (label "LCD19" (at 66.04 242.57 90)
    (uuid 1f84e492-2a66-403d-bdd8-8b6e8e69764a)
  (label "LCD8" (at 88.9 166.37 270)
    (uuid 25e3923c-ca6b-4747-b250-34234d50ccb1)
  (label "+5V" (at 31.75 208.28 0)
    (uuid 26b6eb3f-a5aa-4ab9-acb4-9d321728f07d)
  (label "Temp" (at 137.16 21.59 180)
    (uuid 2846428d-39de-4eae-8ce2-64955d56c493)
  (label "LCD2" (at 73.66 166.37 270)
    (uuid 2cc9a15a-8e80-410e-81a5-82815b023e5b)
  (label "Q1-2" (at 382.27 44.45 0)
    (uuid 305b92d0-78b0-49cb-ad13-72256016dc50)
  (label "LCD13" (at 105.41 215.9 180)
    (uuid 366cf3c7-be6c-4f7c-a51f-b1601a7beabf)
  (label "24Vout" (at 97.79 24.13 0)
    (uuid 37e8181c-a81e-498b-b2e2-0aef0c391059)
  (label "+5V" (at 127 90.17 0)
    (uuid 37f31dec-63fc-4634-a141-5dc5d2b60fe4)
  (label "LCD17" (at 105.41 218.44 180)
    (uuid 439ecfb4-dc55-4fe1-92ba-2cda728bd464)
  (label "+5V" (at 160.02 26.67 0)
    (uuid 49b3239d-93a0-4ed4-a772-483f724876f7)
  (label "LCD26" (at 31.75 210.82 0)
    (uuid 4b5893ab-254a-408e-a775-ee4775099eb0)
  (label "24Vout" (at 158.75 59.69 0)
    (uuid 4da0ce07-0903-4e55-90b8-39dd928d4df1)
  (label "LCD10" (at 106.68 190.5 180)
    (uuid 4fad054a-2505-41de-9a40-b732ac0fb4b0)
  (label "LCD1" (at 66.04 166.37 270)
    (uuid 5aeb1d53-41d9-4803-8b99-0c6a2207fd90)
  (label "X1" (at 127 86.36 0)
    (uuid 5d841968-d13a-47b4-862e-419d30a5db47)
  (label "LCD34" (at 58.42 166.37 270)
    (uuid 61ad34b9-6456-475d-bfb4-391de994726a)
  (label "SEL_A" (at 67.31 115.57 0)
    (uuid 66214d0d-d4a2-4de0-99fb-d165202ac430)
  (label "24Vin" (at 97.79 21.59 0)
    (uuid 67763d19-f622-4e1e-81e5-5b24da7c3f99)
  (label "MCU-18" (at 53.34 242.57 90)
    (uuid 6bb60ebb-cdf0-46c7-bec0-0c57b6b5c96d)
  (label "LCD28" (at 86.36 242.57 90)
    (uuid 6bc454ac-a30f-45a0-b7dd-018a2a8d146c)
  (label "GND" (at 127 101.6 0)
    (uuid 6bf05d19-ba3e-4ba6-8a6f-4e0bc45ea3b2)
  (label "X" (at 104.14 90.17 180)
    (uuid 7afa54c4-2181-41d3-81f7-39efc497ecae)
  (label "Q1-1" (at 382.27 74.93 0)
    (uuid 7e895bde-8d5a-40b7-9647-75bc017e128c)
  (label "LCD15" (at 78.74 242.57 90)
    (uuid 7ec34e4c-545c-47b2-91b6-a10e0ae44c8e)
  (label "LCD24" (at 31.75 215.9 0)
    (uuid 7fb03ecf-13dc-40e1-973b-2e2bad4ef15d)
  (label "SEL_B" (at 67.31 118.11 0)
    (uuid 82a3f88f-2b8f-43c7-bfa2-d6d5a4ee0ffb)
  (label "LCD7" (at 86.36 166.37 270)
    (uuid 85b47e2c-f84c-4ad0-8cb4-44e463e19213)
  (label "GND" (at 137.16 53.34 180)
    (uuid 8bc2c25a-a1f1-4ce8-b96a-a4f8f4c35079)
  (label "Q1-1" (at 417.83 44.45 180)
    (uuid 8c1a4967-fc1d-4405-998b-84ea4995b280)
  (label "LCD20" (at 50.8 242.57 90)
    (uuid 8ccf51c5-127d-4cbf-91e5-fe41389333c5)
  (label "MCU-21" (at 158.75 46.99 0)
    (uuid 8f70850b-3a38-446e-b249-9bc4f982dbb5)
  (label "LCD29" (at 88.9 242.57 90)
    (uuid 93e53a97-c523-4d62-9ab2-da9124759d40)
  (label "LCD22" (at 31.75 220.98 0)
    (uuid 940fc91f-3d28-4131-bfa2-e20f2d08b952)
  (label "+5V" (at 259.08 29.21 0)
    (uuid 966929ba-b557-481c-87ca-90d436516787)
  (label "SEL_A" (at 68.58 242.57 90)
    (uuid 96c33868-d76e-47a5-be6d-c61693b91cc4)
  (label "LCD9" (at 106.68 187.96 180)
    (uuid 98241393-251f-4b9f-9439-323fe018a2c7)
  (label "LCD35" (at 55.88 166.37 270)
    (uuid 989f2937-5c2e-496a-a5b9-ef3208d35304)
  (label "X0" (at 25.4 90.17 0)
    (uuid 9cb12cc8-7f1a-4a01-9256-c119f11a8a02)
  (label "GND" (at 31.75 205.74 0)
    (uuid a281771f-e4f6-486f-a99f-3f7af943f65f)
  (label "LCD25" (at 31.75 213.36 0)
    (uuid a69f55d5-3444-4b57-8d26-f77a558cad5f)
  (label "LCD32" (at 63.5 166.37 270)
    (uuid b147caf6-c117-48cd-b37e-651285beb334)
  (label "X0" (at 219.71 124.46 180)
    (uuid b1c649b1-f44d-46c7-9dea-818e75a1b87e)
  (label "-5V" (at 33.02 146.05 0)
    (uuid b6135480-ace6-42b2-9c47-856ef57cded1)
  (label "MCU-18" (at 31.75 33.02 0)
    (uuid b8c949aa-1ec7-45a4-b041-5d42cec897fd)
  (label "LCD16" (at 76.2 242.57 90)
    (uuid bda428bf-b19a-4535-af2f-10fc1371b354)
  (label "MCU-21" (at 60.96 242.57 90)
    (uuid bf05bfe1-a21c-4d26-adf4-0d3b55ea59cd)
  (label "GND" (at 25.4 129.54 0)
    (uuid c106154f-d948-43e5-abfa-e1b96055d91b)
  (label "TODO" (at 25.4 114.3 0)
    (uuid c332fa55-4168-4f55-88a5-f82c7c21040b)
  (label "LCD12" (at 106.68 195.58 180)
    (uuid c3ebb92a-2e39-449d-9da5-96c125f3f561)
  (label "-5V" (at 137.16 60.96 180)
    (uuid c9667181-b3c7-4b01-b8b4-baa29a9aea63)
  (label "-5V" (at 125.73 134.62 0)
    (uuid cf386a39-fc62-49dd-8ec5-e044f6bd67ce)
  (label "+5V" (at 68.58 19.05 180)
    (uuid cff34251-839c-4da9-a0ad-85d0fc4e32af)
  (label "LCD11" (at 106.68 193.04 180)
    (uuid d001531b-3c03-40cd-8e84-c3362cc0542c)
  (label "LCD30" (at 106.68 198.12 180)
    (uuid d16c041b-64a5-4819-b7a7-621b17a7c159)
  (label "LCD36" (at 53.34 166.37 270)
    (uuid d1f2fca7-ce21-4a21-a30c-e4b18925e679)
  (label "+5V" (at 33.02 78.74 0)
    (uuid d3c11c8f-a73d-4211-934b-a6da255728ad)
  (label "LCD27" (at 31.75 203.2 0)
    (uuid d9e5c0ac-1ffd-4eaf-9458-efff9fe2010d)
  (label "LCD6" (at 83.82 166.37 270)
    (uuid dc7ae2f2-0bec-4bfa-8965-a15c1ebd044d)
  (label "LCD4" (at 78.74 166.37 270)
    (uuid df4a707f-c422-45b9-846e-5f8beda1b995)
  (label "LCD33" (at 60.96 166.37 270)
    (uuid e4452f8c-cb96-44e4-b333-99584bd0897f)
  (label "SEL_B" (at 83.82 242.57 90)
    (uuid e752d96b-3281-4b9e-a872-dc825e6e6a02)
  (label "LCD18" (at 105.41 220.98 180)
    (uuid e9542b9c-ca2e-4e6b-84f5-fb4aba85f723)
  (label "LCD21" (at 31.75 223.52 0)
    (uuid e9e778a1-5a5c-4653-a362-96a1a9887f41)
  (label "X" (at 127 96.52 0)
    (uuid eae0ab9f-65b2-44d3-aba7-873c3227fba7)
  (label "X1" (at 25.4 82.55 0)
    (uuid eda6ce46-4860-4f3b-96c0-cfd9f8393e9e)
  (label "LCD14" (at 105.41 223.52 180)
    (uuid eecece26-a1d3-484a-87ae-0dfae7f7ec29)
  (label "Temp" (at 25.4 97.79 0)
    (uuid eee16674-2d21-45b6-ab5e-d669125df26c)
  (symbol (lib_id "RDS80-rescue:Q_TRIAC_A1A2G-Device-RDS80-rescue") (at 107.95 31.75 0) (unit 1)
    (uuid 00000000-0000-0000-0000-000061324b63)
    (property "Reference" "TC1" (id 0) (at 111.2012 30.5816 0)
    (property "Value" "BT137-600" (id 1) (at 111.2012 32.893 0)
    (property "Footprint" "" (id 2) (at 109.855 31.115 90)
    (property "Datasheet" "~" (id 3) (at 107.95 31.75 90)
    (pin "1" (uuid d66d3c12-11ce-4566-9a45-962e329503d8))
    (pin "2" (uuid 4b1fce17-dec7-457e-ba3b-a77604e77dc9))
    (pin "3" (uuid 869d6302-ae22-478f-9723-3feacbb12eef))
  (symbol (lib_id "RDS80-rescue:R_Small-Device-RDS80-rescue") (at 96.52 34.29 270) (unit 1)
    (uuid 00000000-0000-0000-0000-0000613255f2)
    (property "Reference" "R19" (id 0) (at 96.52 31.75 90))
    (property "Value" "120" (id 1) (at 96.52 36.83 90))
    (property "Footprint" "" (id 2) (at 96.52 34.29 0)
    (property "Datasheet" "~" (id 3) (at 96.52 34.29 0)
    (pin "1" (uuid 96db52e2-6336-4f5e-846e-528c594d0509))
    (pin "2" (uuid 59fc765e-1357-4c94-9529-5635418c7d73))
  (symbol (lib_id "RDS80-rescue:Thermistor_PTC-Device-RDS80-rescue") (at 129.54 35.56 0) (unit 1)
    (uuid 00000000-0000-0000-0000-000061325cfd)
    (property "Reference" "TH?" (id 0) (at 132.0292 34.3916 0)
    (property "Value" "Lötkolben" (id 1) (at 132.0038 35.56 0)
    (property "Footprint" "" (id 2) (at 130.81 40.64 0)
    (property "Datasheet" "~" (id 3) (at 129.54 35.56 0)
    (pin "1" (uuid 582622a2-fad4-4737-9a80-be9fffbba8ab))
    (pin "2" (uuid 1dfbf353-5b24-4c0f-8322-8fcd514ae75e))
  (symbol (lib_id "RDS80-rescue:R_Small-Device-RDS80-rescue") (at 48.26 97.79 270) (unit 1)
    (uuid 00000000-0000-0000-0000-000061327618)
    (property "Reference" "R12" (id 0) (at 48.26 95.25 90))
    (property "Value" "2k4" (id 1) (at 48.26 100.33 90))
    (property "Footprint" "" (id 2) (at 48.26 97.79 0)
    (property "Datasheet" "~" (id 3) (at 48.26 97.79 0)
    (pin "1" (uuid 18d11f32-e1a6-4f29-8e3c-0bfeb07299bd))
    (pin "2" (uuid a90361cd-254c-4d27-ae1f-9a6c85bafe28))
  (symbol (lib_id "RDS80-rescue:4051-4xxx-RDS80-rescue") (at 87.63 105.41 0) (unit 1)
    (uuid 00000000-0000-0000-0000-00006132ae65)
    (property "Reference" "U3" (id 0) (at 96.52 104.14 0)
    (property "Value" "CD4051" (id 1) (at 96.52 106.68 0)
    (property "Footprint" "" (id 2) (at 87.63 105.41 0)
    (property "Datasheet" "http://www.intersil.com/content/dam/Intersil/documents/cd40/cd4051bms-52bms-53bms.pdf" (id 3) (at 87.63 105.41 0)
    (pin "1" (uuid 3b686d17-1000-4762-ba31-589d599a3edf))
    (pin "10" (uuid 9286cf02-1563-41d2-9931-c192c33bab31))
    (pin "11" (uuid 66bc2bca-dab7-4947-a0ff-403cdaf9fb89))
    (pin "12" (uuid 9b6bb172-1ac4-440a-ac75-c1917d9d59c7))
    (pin "13" (uuid 5701b80f-f006-4814-81c9-0c7f006088a9))
    (pin "14" (uuid 63c56ea4-91a3-4172-b9de-a4388cc8f894))
    (pin "15" (uuid c25449d6-d734-4953-b762-98f82a830248))
    (pin "16" (uuid d7e4abd8-69f5-4706-b12e-898194e5bf56))
    (pin "2" (uuid 44646447-0a8e-4aec-a74e-22bf765d0f33))
    (pin "3" (uuid 2878a73c-5447-4cd9-8194-14f52ab9459c))
    (pin "4" (uuid 955cc99e-a129-42cf-abc7-aa99813fdb5f))
    (pin "5" (uuid 04cf2f2c-74bf-400d-b4f6-201720df00ed))
    (pin "6" (uuid 1bdd5841-68b7-42e2-9447-cbdb608d8a08))
    (pin "7" (uuid aeb03be9-98f0-43f6-9432-1bb35aa04bab))
    (pin "8" (uuid 008da5b9-6f95-4113-b7d0-d93ac62efd33))
    (pin "9" (uuid 5d3d7893-1d11-4f1d-9052-85cf0e07d281))
  (symbol (lib_id "RDS80-rescue:R_Small-Device-RDS80-rescue") (at 186.69 123.19 0) (unit 1)
    (uuid 00000000-0000-0000-0000-00006132c856)
    (property "Reference" "R10" (id 0) (at 189.865 120.65 0))
    (property "Value" "22k" (id 1) (at 189.865 123.825 0))
    (property "Footprint" "" (id 2) (at 186.69 123.19 0)
    (property "Datasheet" "~" (id 3) (at 186.69 123.19 0)
    (pin "1" (uuid f8f3a9fc-1e34-4573-a767-508104e8d242))
    (pin "2" (uuid 28e37b45-f843-47c2-85c9-ca19f5430ece))
  (symbol (lib_id "RDS80-rescue:C_Small-Device-RDS80-rescue") (at 163.83 123.19 180) (unit 1)
    (uuid 00000000-0000-0000-0000-00006132e145)
    (property "Reference" "C4" (id 0) (at 167.64 123.19 0))
    (property "Value" "470p" (id 1) (at 168.275 125.73 0))
    (property "Footprint" "" (id 2) (at 163.83 123.19 0)
    (property "Datasheet" "~" (id 3) (at 163.83 123.19 0)
    (pin "1" (uuid 60aa0ce8-9d0e-48ca-bbf9-866403979e9b))
    (pin "2" (uuid bde95c06-433a-4c03-bc48-e3abcdb4e054))
  (symbol (lib_id "RDS80-rescue:C_Small-Device-RDS80-rescue") (at 276.86 35.56 0) (mirror x) (unit 1)
    (uuid 00000000-0000-0000-0000-000061334bb1)
    (property "Reference" "C27" (id 0) (at 279.4 35.56 0)
    (property "Value" "TODO" (id 1) (at 279.1968 34.417 0)
    (property "Footprint" "" (id 2) (at 276.86 35.56 0)
    (property "Datasheet" "" (id 3) (at 276.86 35.56 0)
    (pin "1" (uuid cd5e758d-cb66-484a-ae8b-21f53ceee49e))
    (pin "2" (uuid 7db990e4-92e1-4f99-b4d2-435bbec1ba83))
  (symbol (lib_id "RDS80-rescue:Q_NPN_BEC-Device-RDS80-rescue") (at 80.01 39.37 0) (unit 1)
    (uuid 00000000-0000-0000-0000-000061335528)
    (property "Reference" "T4" (id 0) (at 84.8614 38.2016 0)
    (property "Value" "BC848C" (id 1) (at 84.8614 40.513 0)
    (property "Footprint" "" (id 2) (at 85.09 36.83 0)
    (property "Datasheet" "~" (id 3) (at 80.01 39.37 0)
    (pin "1" (uuid d38aa458-d7c4-47af-ba08-2b6be506a3fd))
    (pin "2" (uuid 3a41dd27-ec14-44d5-b505-aad1d829f79a))
    (pin "3" (uuid 0dfdfa9f-1e3f-4e14-b64b-12bde76a80c7))
  (symbol (lib_id "RDS80-rescue:TLC272-Amplifier_Operational-RDS80-rescue") (at 204.47 104.14 0) (unit 1)
    (uuid 00000000-0000-0000-0000-000061337fa6)
    (property "Reference" "U4" (id 0) (at 204.47 94.8182 0))
    (property "Value" "TLC272BC" (id 1) (at 204.47 97.1296 0))
    (property "Footprint" "" (id 2) (at 204.47 104.14 0)
    (property "Datasheet" "http://www.ti.com/lit/ds/symlink/tlc272.pdf" (id 3) (at 204.47 104.14 0)
    (pin "1" (uuid cc48dd41-7768-48d3-b096-2c4cc2126c9d))
    (pin "2" (uuid 4185c36c-c66e-4dbd-be5d-841e551f4885))
    (pin "3" (uuid a8b4bc7e-da32-4fb8-b71a-d7b47c6f741f))
  (symbol (lib_id "RDS80-rescue:TLC272-Amplifier_Operational-RDS80-rescue") (at 204.47 124.46 0) (unit 2)
    (uuid 00000000-0000-0000-0000-000061338c71)
    (property "Reference" "U4" (id 0) (at 204.47 115.1382 0))
    (property "Value" "TLC272BC" (id 1) (at 204.47 117.4496 0))
    (property "Footprint" "" (id 2) (at 204.47 124.46 0)
      (effects (font (size 1.27 1.27)) hide)
    (property "Datasheet" "http://www.ti.com/lit/ds/symlink/tlc272.pdf" (id 3) (at 204.47 124.46 0)
    (pin "5" (uuid 88cb65f4-7e9e-44eb-8692-3b6e2e788a94))
    (pin "6" (uuid e5b328f6-dc69-4905-ae98-2dc3200a51d6))
    (pin "7" (uuid 1f9ae101-c652-4998-a503-17aedf3d5746))
  (symbol (lib_id "RDS80-rescue:TLC272-Amplifier_Operational-RDS80-rescue") (at 228.6 110.49 0) (unit 3)
    (uuid 00000000-0000-0000-0000-000061339b9c)
    (property "Reference" "U4" (id 0) (at 227.5332 109.3216 0)
    (property "Value" "TLC272BC" (id 1) (at 227.5332 111.633 0)
    (property "Footprint" "" (id 2) (at 228.6 110.49 0)
    (property "Datasheet" "http://www.ti.com/lit/ds/symlink/tlc272.pdf" (id 3) (at 228.6 110.49 0)
    (pin "4" (uuid bdf40d30-88ff-4479-bad1-69529464b61b))
    (pin "8" (uuid 57276367-9ce4-4738-88d7-6e8cb94c966c))
  (symbol (lib_id "RDS80-rescue:D_Small-Device-RDS80-rescue") (at 60.96 111.76 90) (unit 1)
    (uuid 00000000-0000-0000-0000-000061345695)
    (property "Reference" "D6" (id 0) (at 58.42 109.22 90)
      (effects (font (size 1.27 1.27)) (justify right))
    (property "Value" "D_Small" (id 1) (at 62.738 112.903 90)
      (effects (font (size 1.27 1.27)) (justify right) hide)
    (property "Footprint" "" (id 2) (at 60.96 111.76 90)
    (property "Datasheet" "~" (id 3) (at 60.96 111.76 90)
    (pin "1" (uuid 88002554-c459-46e5-8b22-6ea6fe07fd4c))
    (pin "2" (uuid 8cdc8ef9-532e-4bf5-9998-7213b9e692a2))
  (symbol (lib_id "RDS80-rescue:TestPoint-Connector-RDS80-rescue") (at 116.84 21.59 0) (unit 1)
    (uuid 00000000-0000-0000-0000-00006134b7f9)
    (property "Reference" "TP16" (id 0) (at 119.38 16.51 0)
    (property "Value" "TestPoint" (id 1) (at 115.3668 18.6182 0)
    (property "Footprint" "" (id 2) (at 121.92 21.59 0)
    (property "Datasheet" "~" (id 3) (at 121.92 21.59 0)
    (pin "1" (uuid 7760a75a-d74b-4185-b34e-cbc7b2c339b6))
  (symbol (lib_id "RDS80-rescue:C_Small-Device-RDS80-rescue") (at 140.97 121.92 0) (unit 1)
    (uuid 00000000-0000-0000-0000-00006134f52a)
    (property "Reference" "C18" (id 0) (at 137.16 121.92 0))
    (property "Value" "C_Small" (id 1) (at 137.4648 121.92 90)
    (property "Footprint" "" (id 2) (at 140.97 121.92 0)
    (property "Datasheet" "~" (id 3) (at 140.97 121.92 0)
    (pin "1" (uuid 7e1217ba-8a3d-4079-8d7b-b45f90cfbf53))
    (pin "2" (uuid 2e90e294-82e1-45da-9bf1-b91dfe0dc8f6))
  (symbol (lib_id "RDS80-rescue:R_Small-Device-RDS80-rescue") (at 148.59 123.19 0) (unit 1)
    (uuid 00000000-0000-0000-0000-0000613529dc)
    (property "Reference" "R8" (id 0) (at 146.05 123.19 0))
    (property "Value" "47" (id 1) (at 149.86 123.19 0)
      (effects (font (size 1.27 1.27)) (justify left))
    (property "Footprint" "" (id 2) (at 148.59 123.19 0)
    (property "Datasheet" "~" (id 3) (at 148.59 123.19 0)
    (pin "1" (uuid f64497d1-1d62-44a4-8e5e-6fba4ebc969a))
    (pin "2" (uuid 42ff012d-5eb7-42b9-bb45-415cf26799c6))
  (symbol (lib_id "RDS80-rescue:TestPoint-Connector-RDS80-rescue") (at 107.95 24.13 270) (unit 1)
    (uuid 00000000-0000-0000-0000-000061355886)
    (property "Reference" "TP26" (id 0) (at 118.11 24.13 90)
    (property "Value" "TestPoint" (id 1) (at 110.9218 22.6568 0)
    (property "Footprint" "" (id 2) (at 107.95 29.21 0)
    (property "Datasheet" "~" (id 3) (at 107.95 29.21 0)
    (pin "1" (uuid be4b72db-0e02-4d9b-844a-aff689b4e648))
  (symbol (lib_id "RDS80-rescue:TestPoint-Connector-RDS80-rescue") (at 101.6 34.29 180) (unit 1)
    (uuid 00000000-0000-0000-0000-000061356ebe)
    (property "Reference" "TP27" (id 0) (at 100.33 40.64 0)
    (property "Value" "TestPoint-Connector" (id 1) (at 103.0732 37.2618 0)
    (property "Datasheet" "" (id 3) (at 96.52 34.29 0)
    (pin "1" (uuid 05f2859d-2820-4e84-b395-696011feb13b))
  (symbol (lib_id "RDS80-rescue:TestPoint-Connector-RDS80-rescue") (at 87.63 34.29 0) (unit 1)
    (uuid 00000000-0000-0000-0000-000061357a52)
    (property "Reference" "TP28" (id 0) (at 89.1032 32.4612 0)
    (property "Value" "TestPoint-Connector" (id 1) (at 89.1032 33.6042 0)
    (property "Footprint" "" (id 2) (at 92.71 34.29 0)
    (property "Datasheet" "" (id 3) (at 92.71 34.29 0)
    (pin "1" (uuid 252f1275-081d-4d77-8bd5-3b9e6916ef42))
  (symbol (lib_id "RDS80-rescue:R_Small-Device-RDS80-rescue") (at 36.83 102.87 180) (unit 1)
    (uuid 00000000-0000-0000-0000-000061358a03)
    (property "Reference" "R7" (id 0) (at 34.29 102.87 0))
    (property "Value" "10k" (id 1) (at 39.37 102.87 0))
    (property "Footprint" "" (id 2) (at 36.83 102.87 0)
    (property "Datasheet" "" (id 3) (at 36.83 102.87 0)
    (pin "1" (uuid b78cb2c1-ae4b-4d9b-acd8-d7fe342342f2))
    (pin "2" (uuid 90e761f6-1432-4f73-ad28-fa8869b7ec31))
  (symbol (lib_id "RDS80-rescue:D_Small-Device-RDS80-rescue") (at 36.83 120.65 270) (unit 1)
    (uuid 00000000-0000-0000-0000-00006135c8ad)
    (property "Reference" "D1" (id 0) (at 34.29 120.65 90))
    (property "Value" "D_Small-Device" (id 1) (at 33.8836 120.65 0)
    (property "Footprint" "" (id 2) (at 36.83 120.65 90)
    (property "Datasheet" "" (id 3) (at 36.83 120.65 90)
    (pin "1" (uuid a07b6b2b-7179-4297-b163-5e47ffbe76d3))
    (pin "2" (uuid d1a9be32-38ba-44e6-bc35-f031541ab1fe))
  (symbol (lib_id "RDS80-rescue:TestPoint-Connector-RDS80-rescue") (at 36.83 107.95 270) (unit 1)
    (uuid 00000000-0000-0000-0000-000061360fd7)
    (property "Reference" "TP7" (id 0) (at 41.91 107.95 90)
    (property "Value" "TestPoint-Connector" (id 1) (at 37.5158 109.4232 0)
    (property "Footprint" "" (id 2) (at 36.83 113.03 0)
    (property "Datasheet" "" (id 3) (at 36.83 113.03 0)
    (pin "1" (uuid 528fd7da-c9a6-40ae-9f1a-60f6a7f4d534))
  (symbol (lib_id "RDS80-rescue:R_Small-Device-RDS80-rescue") (at 68.58 39.37 270) (unit 1)
    (uuid 00000000-0000-0000-0000-00006136528e)
    (property "Reference" "R18" (id 0) (at 68.58 36.83 90))
    (property "Value" "2k2" (id 1) (at 68.58 41.91 90))
    (property "Footprint" "" (id 2) (at 68.58 39.37 0)
    (property "Datasheet" "~" (id 3) (at 68.58 39.37 0)
    (pin "1" (uuid bb59b92a-e4d0-4b9e-82cd-26304f5c15b8))
    (pin "2" (uuid f6983918-fe05-46ea-b355-bc522ec53440))
  (symbol (lib_id "RDS80-rescue:Q_PNP_BEC-Device-RDS80-rescue") (at 58.42 33.02 0) (mirror x) (unit 1)
    (uuid 00000000-0000-0000-0000-000061366398)
    (property "Reference" "T3" (id 0) (at 63.2714 34.1884 0)
    (property "Value" "BC858C" (id 1) (at 63.2714 31.877 0)
    (property "Footprint" "" (id 2) (at 63.5 35.56 0)
    (property "Datasheet" "~" (id 3) (at 58.42 33.02 0)
    (pin "1" (uuid 13bbfffc-affb-4b43-9eb1-f2ed90a8a919))
    (pin "2" (uuid 71f8d568-0f23-4ff2-8e60-1600ce517a48))
    (pin "3" (uuid 7c00778a-4692-4f9b-87d5-2d355077ce1e))
  (symbol (lib_id "RDS80-rescue:TestPoint-Connector-RDS80-rescue") (at 189.865 106.68 180) (unit 1)
    (uuid 00000000-0000-0000-0000-0000613670c0)
    (property "Reference" "TP34" (id 0) (at 191.3382 108.5088 0)
    (property "Value" "TestPoint" (id 1) (at 191.3382 109.6518 0)
    (property "Footprint" "" (id 2) (at 184.785 106.68 0)
    (property "Datasheet" "~" (id 3) (at 184.785 106.68 0)
    (pin "1" (uuid 4ec618ae-096f-4256-9328-005ee04f13d6))
  (symbol (lib_id "RDS80-rescue:R_Small-Device-RDS80-rescue") (at 73.66 50.8 0) (unit 1)
    (uuid 00000000-0000-0000-0000-000061367d84)
    (property "Reference" "R20" (id 0) (at 68.58 50.8 0)
    (property "Value" "10k" (id 1) (at 74.93 50.8 0)
    (property "Footprint" "" (id 2) (at 73.66 50.8 0)
    (property "Datasheet" "~" (id 3) (at 73.66 50.8 0)
    (pin "1" (uuid f447e585-df78-4239-b8cb-4653b3837bb1))
    (pin "2" (uuid 62a1f3d4-027d-4ecf-a37a-6fcf4263e9d2))
  (symbol (lib_id "RDS80-rescue:TestPoint-Connector-RDS80-rescue") (at 58.42 90.17 0) (unit 1)
    (uuid 00000000-0000-0000-0000-000061368266)
    (property "Reference" "TP8" (id 0) (at 57.15 85.09 0)
    (property "Value" "TestPoint-Connector" (id 1) (at 59.8932 89.4842 0)
    (property "Footprint" "" (id 2) (at 63.5 90.17 0)
    (property "Datasheet" "" (id 3) (at 63.5 90.17 0)
    (pin "1" (uuid c8a7af6e-c432-4fa3-91ee-c8bf0c5a9ebe))
  (symbol (lib_id "RDS80-rescue:R_Small-Device-RDS80-rescue") (at 52.07 25.4 0) (mirror y) (unit 1)
    (uuid 00000000-0000-0000-0000-000061369551)
    (property "Reference" "R16" (id 0) (at 48.26 25.4 0))
    (property "Value" "10k" (id 1) (at 54.737 25.4 0))
    (property "Footprint" "" (id 2) (at 52.07 25.4 0)
    (property "Datasheet" "~" (id 3) (at 52.07 25.4 0)
    (pin "1" (uuid e70b6168-f98e-4322-bc55-500948ef7b77))
    (pin "2" (uuid 3c8d03bf-f31d-4aa0-b8db-a227ffd7d8d6))
  (symbol (lib_id "RDS80-rescue:C_Small-Device-RDS80-rescue") (at 82.55 137.16 180) (unit 1)
    (uuid 00000000-0000-0000-0000-00006136abfd)
    (property "Reference" "C17" (id 0) (at 87.63 137.16 0))
    (property "Value" "C_Small-Device" (id 1) (at 86.0552 137.16 90)
    (property "Footprint" "" (id 2) (at 82.55 137.16 0)
    (property "Datasheet" "" (id 3) (at 82.55 137.16 0)
    (pin "1" (uuid 626679e8-6101-4722-ac57-5b8d9dab4c8b))
    (pin "2" (uuid b7bf6e08-7978-4190-aff5-c90d967f0f9c))
  (symbol (lib_id "RDS80-rescue:TestPoint-Connector-RDS80-rescue") (at 46.99 129.54 0) (unit 1)
    (uuid 00000000-0000-0000-0000-00006136f674)
    (property "Reference" "TP20" (id 0) (at 48.4632 127.7112 0)
    (property "Value" "TestPoint-Connector" (id 1) (at 48.4632 128.8542 0)
    (property "Footprint" "" (id 2) (at 52.07 129.54 0)
    (property "Datasheet" "" (id 3) (at 52.07 129.54 0)
    (pin "1" (uuid 66218487-e316-4467-9eba-79d4626ab24e))
  (symbol (lib_id "RDS80-rescue:C_Small-Device-RDS80-rescue") (at 271.78 35.56 0) (unit 1)
    (uuid 00000000-0000-0000-0000-00006138cc93)
    (property "Reference" "C28" (id 0) (at 265.43 35.56 0)
    (property "Value" "C_Small-Device" (id 1) (at 274.1168 36.703 0)
    (property "Footprint" "" (id 2) (at 271.78 35.56 0)
    (property "Datasheet" "" (id 3) (at 271.78 35.56 0)
    (pin "1" (uuid 9c607e49-ee5c-4e85-a7da-6fede9912412))
    (pin "2" (uuid e5e5220d-5b7e-47da-a902-b997ec8d4d58))
  (symbol (lib_id "RDS80-rescue:TestPoint-Connector-RDS80-rescue") (at 58.42 97.79 0) (unit 1)
    (uuid 00000000-0000-0000-0000-0000613dc089)
    (property "Reference" "TP17" (id 0) (at 57.15 92.71 0)
    (property "Value" "TestPoint-Connector" (id 1) (at 59.8932 97.1042 0)
    (property "Footprint" "" (id 2) (at 63.5 97.79 0)
    (property "Datasheet" "" (id 3) (at 63.5 97.79 0)
    (pin "1" (uuid 1e48966e-d29d-4521-8939-ec8ac570431d))
  (symbol (lib_id "RDS80-rescue:D_Small-Device-RDS80-rescue") (at 55.88 111.76 270) (unit 1)
    (uuid 00000000-0000-0000-0000-0000613e475d)
    (property "Reference" "D5" (id 0) (at 53.34 109.22 90)
    (property "Value" "D_Small-Device" (id 1) (at 58.8264 111.76 0)
    (property "Footprint" "" (id 2) (at 55.88 111.76 90)
    (property "Datasheet" "" (id 3) (at 55.88 111.76 90)
    (pin "1" (uuid c8a44971-63c1-4a19-879d-b6647b2dc08d))
    (pin "2" (uuid 2b5a9ad3-7ec4-447d-916c-47adf5f9674f))
  (symbol (lib_id "RDS80-rescue:TestPoint-Connector-RDS80-rescue") (at 77.47 129.54 180) (unit 1)
    (uuid 00000000-0000-0000-0000-000061408dc5)
    (property "Reference" "TP15" (id 0) (at 78.74 134.62 0)
    (property "Value" "TestPoint-Connector" (id 1) (at 75.9968 130.2258 0)
    (property "Footprint" "" (id 2) (at 72.39 129.54 0)
    (property "Datasheet" "" (id 3) (at 72.39 129.54 0)
    (pin "1" (uuid 12a24e86-2c38-4685-bba9-fff8dddb4cb0))
  (symbol (lib_id "Device:R_Small") (at 214.63 33.02 0) (unit 1)
    (in_bom yes) (on_board yes) (fields_autoplaced)
    (uuid 03fbc68e-492a-49c1-a703-e3e7df3e4be6)
    (property "Reference" "R6" (id 0) (at 216.1286 32.1853 0)
    (property "Value" "56" (id 1) (at 216.1286 34.7222 0)
    (property "Footprint" "" (id 2) (at 214.63 33.02 0)
    (property "Datasheet" "~" (id 3) (at 214.63 33.02 0)
    (pin "1" (uuid ea34af66-8e31-412a-b988-da3f04588440))
    (pin "2" (uuid 2ecca125-5f2c-4a83-8c1f-a9abb41956ce))
  (symbol (lib_id "em:PIC16F1946") (at 69.85 168.91 0) (unit 1)
    (uuid 041d8702-cc47-4459-b42e-9c07627392bd)
    (property "Reference" "U?" (id 0) (at 100.33 172.72 0))
    (property "Value" "PIC16F1946" (id 1) (at 100.33 175.26 0))
    (property "Footprint" "" (id 2) (at 69.85 168.91 0)
    (property "Datasheet" "" (id 3) (at 69.85 168.91 0)
    (pin "1" (uuid 6821e406-9c56-4b9d-9be2-2662789855a8))
    (pin "10" (uuid 29fce808-6d36-40d4-9602-9f4120d8ea77))
    (pin "11" (uuid 2f8c8f9d-10c2-46cd-ad08-05fba6e1e6d9))
    (pin "12" (uuid da57d72d-d1aa-4cd8-85b5-5af7f2523702))
    (pin "13" (uuid 97b729b0-0ed3-4238-aad8-5c52cebaff98))
    (pin "14" (uuid fdd7b420-b72d-452f-b662-06bac874af43))
    (pin "15" (uuid a6b5a8f8-a35b-459f-990a-54c446f3692f))
    (pin "16" (uuid 80a2c066-b249-4b41-bf89-99e2cdf92058))
    (pin "17" (uuid 44e57fbc-4b2f-44a8-ac76-6963d6d9886c))
    (pin "18" (uuid 74418ed4-96f5-48b2-bd7b-98bcc51c612e))
    (pin "19" (uuid 976c9ba6-a413-4b99-894e-8441516220e8))
    (pin "2" (uuid 759b1a55-294e-410b-9a7a-1887fe40748d))
    (pin "20" (uuid f0cc9c45-beb1-4928-968d-9d5a89888ff2))
    (pin "21" (uuid f6edacb3-ed2a-4d99-a716-89f64b4dcba7))
    (pin "22" (uuid 0632debb-924b-47c7-88a0-ad38de196408))
    (pin "23" (uuid 158e0fe2-d252-4f8a-b7ef-2330c8f02849))
    (pin "24" (uuid 4bcf2fe0-0e19-4a32-a842-e634f241150c))
    (pin "25" (uuid c58d3384-9ed8-4119-912e-c225860c48cc))
    (pin "26" (uuid 878c18f5-3164-4602-a59e-dbe2634031e5))
    (pin "27" (uuid e5f10d73-0239-467c-b789-37bd408d0271))
    (pin "28" (uuid b1102f32-43b4-41c7-8ea5-36f6e626ed0b))
    (pin "29" (uuid 5b97347f-67e2-4703-a927-2430b79e569b))
    (pin "3" (uuid c06bdfe4-733c-441d-83f6-fb36ff756c3c))
    (pin "30" (uuid a8bed542-67f1-497b-acba-983122b53f61))
    (pin "31" (uuid c602e1ba-5189-49b0-b448-dba777b6befb))
    (pin "32" (uuid 49d2b1cd-0b17-46eb-b7bd-ab73d910b989))
    (pin "33" (uuid 63359286-beaf-4c54-b415-0bbfefb3f9c6))
    (pin "34" (uuid a3c6a02a-863f-4e1a-8b76-5123c1b7b847))
    (pin "35" (uuid 72c68ce1-de2f-4610-adad-51a6d09253a2))
    (pin "36" (uuid 3ea18efd-5ee3-44b1-a04a-6354580d5d75))
    (pin "37" (uuid 3656d7be-4996-4f8b-83cb-0af5c180502d))
    (pin "38" (uuid 3e5a7fc5-22db-46fb-b1bb-84a50b2d6d9f))
    (pin "39" (uuid e1833d7e-e5a2-438d-b465-87d447e8f0e8))
    (pin "4" (uuid 9def1d97-a4b0-47a7-b3e6-36476eaaa577))
    (pin "40" (uuid 6b7584cc-3799-4a89-8038-ca2ac301aaec))
    (pin "41" (uuid be806d61-ae7c-467e-83e3-23016bd8ee4d))
    (pin "42" (uuid affdef73-963b-44c1-b399-70fd34816a04))
    (pin "43" (uuid 4823b820-ba1b-421c-ab78-da35fdaf6454))
    (pin "44" (uuid 262d246a-3568-47c7-933b-1cd3e64b55f6))
    (pin "45" (uuid 4d12daee-81af-4409-a06f-f64938a18d76))
    (pin "46" (uuid 23260b48-c011-4971-b14c-1169c3d46f20))
    (pin "47" (uuid 3cb1ead1-67b3-42c8-a113-f57b7ed39d5a))
    (pin "48" (uuid 7b6faf78-a0d7-4ec6-b769-15579cbb9bb5))
    (pin "49" (uuid b5532aa0-b3ba-4507-9815-c90ee3156ba2))
    (pin "5" (uuid fe24e6d3-3836-4c61-b3a3-8777f8ad4a6a))
    (pin "50" (uuid 857a2058-8c3d-4f43-8596-793c3a141cbe))
    (pin "51" (uuid 75b699ad-756e-4dd0-a05e-bff12b1b314b))
    (pin "52" (uuid 1448d719-043e-483a-a163-24b34f3b0020))
    (pin "53" (uuid 226aaa63-d067-4f6d-a8bb-07141cab1d34))
    (pin "54" (uuid 0f18acd3-b4c7-4d09-b05d-f1b375bbc670))
    (pin "55" (uuid 793cbc9a-d991-4452-949f-3c10a4a009fa))
    (pin "56" (uuid 37e93e98-6072-4061-ba9a-79645f5ffcde))
    (pin "57" (uuid c96ad8f7-d1d1-4065-9baf-198e97b1352f))
    (pin "58" (uuid 93b3207b-e1ce-46d7-a52b-3e8fb1ae6901))
    (pin "59" (uuid ade9cd02-a26a-4185-a4d0-4e504ce51245))
    (pin "6" (uuid 4cc7fa40-dca3-4385-8554-a5d5782d049d))
    (pin "60" (uuid 27677dd4-8775-406f-b286-ab078d7f612f))
    (pin "61" (uuid 802b705d-7b74-4fec-8859-337e18f0baf4))
    (pin "62" (uuid 8ba612fe-c7cf-4c60-853b-1c1b31b9b885))
    (pin "63" (uuid b18669f1-8123-45cb-b648-5a45107310c2))
    (pin "64" (uuid f75e7a61-ab39-42c7-b1d2-8fa776ed27d2))
    (pin "7" (uuid f16a6529-34cc-45d3-b796-fa1b9f3df7d3))
    (pin "8" (uuid 23c7e4f2-40f5-4840-8d08-1acb173866b4))
    (pin "9" (uuid f7bb6dd8-be37-4d99-8249-ec14654754f9))
  (symbol (lib_id "Device:D_Small") (at 397.51 38.1 0) (unit 1)
    (uuid 239c060f-4b27-4497-9d88-b1c5b3708cc6)
    (property "Reference" "D?" (id 0) (at 397.51 40.2788 0)
    (property "Value" "D_Small" (id 1) (at 397.51 40.2789 0)
    (property "Footprint" "" (id 2) (at 397.51 38.1 90)
    (property "Datasheet" "~" (id 3) (at 397.51 38.1 90)
    (pin "1" (uuid a8d44d4c-67ac-48cc-a36b-ea94778ddc57))
    (pin "2" (uuid b6dd002f-c8ce-42d9-abd8-2e3d53066dec))
  (symbol (lib_id "Connector:TestPoint") (at 187.96 46.99 0) (unit 1)
    (uuid 23c5804b-9d9c-40a2-86dd-f120c4503b29)
    (property "Reference" "TP12" (id 0) (at 189.357 44.1218 0)
    (property "Value" "TestPoint" (id 1) (at 189.357 45.3902 0)
      (effects (font (size 1.27 1.27)) (justify left) hide)
    (property "Footprint" "" (id 2) (at 193.04 46.99 0)
    (property "Datasheet" "~" (id 3) (at 193.04 46.99 0)
    (pin "1" (uuid d4fd8c18-e985-4940-be8e-8864b6d9ef68))
  (symbol (lib_id "RDS80-rescue:Q_PNP_BEC-Device-RDS80-rescue") (at 212.09 46.99 0) (mirror x) (unit 1)
    (uuid 2af67c9f-1758-4649-8401-6b678ded3579)
    (property "Reference" "Q1" (id 0) (at 216.9414 48.1584 0)
    (property "Value" "BC858C" (id 1) (at 216.9414 45.847 0)
    (property "Footprint" "" (id 2) (at 217.17 49.53 0)
    (property "Datasheet" "~" (id 3) (at 212.09 46.99 0)
    (pin "1" (uuid efcd783b-122c-443e-8bfd-32f779ffa29b))
    (pin "2" (uuid 4e741225-715b-4a98-b214-a966a085dc44))
    (pin "3" (uuid bc703488-d0cb-41d1-978a-d7199d33e932))
  (symbol (lib_id "Device:D_Schottky_Small") (at 397.51 54.61 180) (unit 1)
    (uuid 2b8edd2f-d3d2-45fa-bbdb-2896a7eb66f2)
    (property "Reference" "D?" (id 0) (at 397.764 59.3258 0)
    (property "Value" "D_Schottky_Small" (id 1) (at 397.764 56.7888 0)
    (property "Footprint" "" (id 2) (at 397.51 54.61 90)
    (property "Datasheet" "~" (id 3) (at 397.51 54.61 90)
    (pin "1" (uuid 457347a8-c1f4-4d50-be59-45ee9f4f2f43))
    (pin "2" (uuid d6ac25d9-0ede-4a22-8e34-422ce4f30803))
  (symbol (lib_id "RDS80-rescue:R_Small-Device-RDS80-rescue") (at 177.165 123.19 0) (unit 1)
    (uuid 2e586188-20da-44b2-8162-f49779759fcb)
    (property "Reference" "R13" (id 0) (at 180.34 121.285 0))
    (property "Value" "1M" (id 1) (at 178.435 123.19 0)
    (property "Footprint" "" (id 2) (at 177.165 123.19 0)
    (property "Datasheet" "~" (id 3) (at 177.165 123.19 0)
    (pin "1" (uuid 671c75fc-acdd-4b69-81e4-5724da1b91ee))
    (pin "2" (uuid d155ad49-6117-48b3-b161-d4830d152e09))
  (symbol (lib_id "Device:D_Schottky_Small") (at 397.51 50.8 0) (unit 1)
    (uuid 3541efea-23c3-4dce-9549-0e50a1d88610)
    (property "Reference" "D?" (id 0) (at 397.256 46.0842 0)
    (property "Value" "D_Schottky_Small" (id 1) (at 397.256 48.6212 0)
    (property "Footprint" "" (id 2) (at 397.51 50.8 90)
    (property "Datasheet" "~" (id 3) (at 397.51 50.8 90)
    (pin "1" (uuid 9e38c195-9e95-4124-9a73-3912e3d8adb9))
    (pin "2" (uuid d281e302-963d-4e62-8db4-039301c9dfc3))
  (symbol (lib_id "RDS80-rescue:TestPoint-Connector-RDS80-rescue") (at 148.59 127.635 180) (unit 1)
    (uuid 48ff0ceb-ea44-48a3-b980-0dcbba8daca9)
    (property "Reference" "TP9" (id 0) (at 150.0632 129.4638 0)
    (property "Value" "TestPoint" (id 1) (at 150.0632 130.6068 0)
    (property "Footprint" "" (id 2) (at 143.51 127.635 0)
    (property "Datasheet" "~" (id 3) (at 143.51 127.635 0)
    (pin "1" (uuid 8b4cea25-2302-4a72-ae06-3b8b0b6c64b4))
  (symbol (lib_id "Device:D_Small") (at 406.4 49.53 270) (unit 1)
    (uuid 5237ab62-e664-440d-b632-36d9c73b7474)
    (property "Reference" "D?" (id 0) (at 404.2212 49.53 0)
    (property "Value" "D_Small" (id 1) (at 404.2211 49.53 0)
    (property "Footprint" "" (id 2) (at 406.4 49.53 90)
    (property "Datasheet" "~" (id 3) (at 406.4 49.53 90)
    (pin "1" (uuid a3cf8414-8206-43f3-ab0d-81d9406a49b4))
    (pin "2" (uuid d59b28a0-e705-4fea-bcba-121683085722))
  (symbol (lib_id "Device:R_Small") (at 179.07 46.99 90) (unit 1)
    (uuid 54e308dc-3c0f-4ffb-a960-81104ad37a1f)
    (property "Reference" "R9" (id 0) (at 179.07 44.45 90))
    (property "Value" "1k" (id 1) (at 179.07 49.53 90))
    (property "Footprint" "" (id 2) (at 179.07 46.99 0)
    (property "Datasheet" "~" (id 3) (at 179.07 46.99 0)
    (pin "1" (uuid 6c35aba3-69c6-4c39-bd51-ff6e08bb6b9b))
    (pin "2" (uuid 55fe2c1a-4c16-4a3a-8802-379f4abc68c5))
  (symbol (lib_id "Connector:TestPoint") (at 203.2 59.69 0) (unit 1)
    (uuid 6f1ef841-cc74-4642-881d-accbd23cf024)
    (property "Reference" "TP14" (id 0) (at 204.597 56.8218 0)
    (property "Value" "TestPoint" (id 1) (at 204.597 58.0902 0)
    (property "Footprint" "" (id 2) (at 208.28 59.69 0)
    (property "Datasheet" "~" (id 3) (at 208.28 59.69 0)
    (pin "1" (uuid d0098f33-ce84-48c3-be03-b53eb776b554))
  (symbol (lib_id "Device:D_Small") (at 196.85 59.69 0) (unit 1)
    (uuid 93373bf3-0370-4975-9726-0dffadc80388)
    (property "Reference" "D3" (id 0) (at 196.85 57.5112 0))
    (property "Value" "D_Small" (id 1) (at 196.85 57.5111 0)
    (property "Footprint" "" (id 2) (at 196.85 59.69 90)
    (property "Datasheet" "~" (id 3) (at 196.85 59.69 90)
    (pin "1" (uuid 41fa75b7-757b-4f62-88ac-b243d9269c66))
    (pin "2" (uuid 8f38c1b8-34ef-4e9f-bd87-649706688d00))
  (symbol (lib_id "Connector:TestPoint") (at 214.63 39.37 90) (unit 1)
    (uuid 9edf5f95-96cb-46d0-9a3c-b14fd7f93ac0)
    (property "Reference" "TP11" (id 0) (at 211.328 37.5722 90))
    (property "Value" "TestPoint" (id 1) (at 213.0302 37.973 0)
    (property "Footprint" "" (id 2) (at 214.63 34.29 0)
    (property "Datasheet" "~" (id 3) (at 214.63 34.29 0)
    (pin "1" (uuid 59675a0f-054e-4551-8a98-6678f919d50b))
  (symbol (lib_id "Device:D_Small") (at 397.51 44.45 180) (unit 1)
    (uuid a232a4d4-45a8-4a68-81af-39c427c0b1dd)
    (property "Reference" "D?" (id 0) (at 397.51 42.2712 0)
    (property "Value" "D_Small" (id 1) (at 397.51 42.2711 0)
    (property "Footprint" "" (id 2) (at 397.51 44.45 90)
    (property "Datasheet" "~" (id 3) (at 397.51 44.45 90)
    (pin "1" (uuid 7e0c9fdd-664e-43a0-b1ac-e15b5acd8988))
    (pin "2" (uuid 69df78d3-e5e0-486c-8237-5938a2750805))
  (symbol (lib_id "RDS80-rescue:C_Small-Device-RDS80-rescue") (at 154.94 123.19 180) (unit 1)
    (uuid a8c608fb-7075-43f3-b9db-ce4600d00b0f)
    (property "Reference" "C11" (id 0) (at 158.75 123.19 0))
    (property "Value" "47n" (id 1) (at 157.48 125.095 0))
    (property "Footprint" "" (id 2) (at 154.94 123.19 0)
    (property "Datasheet" "~" (id 3) (at 154.94 123.19 0)
    (pin "1" (uuid 633d96b3-1d31-4dd0-ae85-bb940cb32dc1))
    (pin "2" (uuid ad622ffb-d761-47c2-bff6-0d5388b8b695))
  (symbol (lib_id "Connector:TestPoint") (at 186.69 59.69 0) (unit 1)
    (uuid b26c9359-6f3c-4083-aaf0-0453f933cdca)
    (property "Reference" "TP15" (id 0) (at 188.087 56.8218 0)
    (property "Value" "TestPoint" (id 1) (at 188.087 58.0902 0)
    (property "Footprint" "" (id 2) (at 191.77 59.69 0)
    (property "Datasheet" "~" (id 3) (at 191.77 59.69 0)
    (pin "1" (uuid 65b92e80-d264-48db-add6-818ca883bb66))
  (symbol (lib_id "Device:R_Small") (at 44.45 33.02 270) (unit 1)
    (uuid c20884ff-e35c-4d65-a5ff-7d5e8da129c8)
    (property "Reference" "R17" (id 0) (at 43.18 30.48 90)
    (property "Value" "2k2" (id 1) (at 43.18 35.56 90)
    (property "Footprint" "" (id 2) (at 44.45 33.02 0)
    (property "Datasheet" "~" (id 3) (at 44.45 33.02 0)
    (pin "1" (uuid de47399f-2718-4733-949c-277906031e19))
    (pin "2" (uuid 759f616a-42df-4419-84c6-e64ac40b626e))
  (symbol (lib_id "Device:R_Small") (at 175.26 59.69 90) (unit 1)
    (uuid d0c27b72-1400-443f-aa3c-6fabd30b42e0)
    (property "Reference" "R11" (id 0) (at 175.26 57.15 90))
    (property "Value" "39" (id 1) (at 175.26 62.23 90))
    (property "Footprint" "" (id 2) (at 175.26 59.69 0)
    (property "Datasheet" "~" (id 3) (at 175.26 59.69 0)
    (pin "1" (uuid 4e32c2ee-2f32-4c2c-92af-317367d93871))
    (pin "2" (uuid 0c80b0f5-b16c-4843-8969-0ff7dd71866d))
  (symbol (lib_id "Device:D_Small") (at 397.51 71.12 0) (unit 1)
    (uuid e4570e31-f9dd-4e13-a8d5-42733b999b4d)
    (property "Reference" "D?" (id 0) (at 397.51 73.2988 0)
    (property "Value" "D_Small" (id 1) (at 397.51 73.2989 0)
    (property "Footprint" "" (id 2) (at 397.51 71.12 90)
    (property "Datasheet" "~" (id 3) (at 397.51 71.12 90)
    (pin "1" (uuid 09578cae-3e9a-4372-a934-d377a0227b7c))
    (pin "2" (uuid 8a3add20-c253-4adc-b840-becd588ad034))
  (symbol (lib_id "Device:D_Small") (at 397.51 77.47 0) (unit 1)
    (uuid ece535e5-4fc3-4a25-aa21-10feba6cc504)
    (property "Reference" "D?" (id 0) (at 397.51 79.6488 0)
    (property "Value" "D_Small" (id 1) (at 397.51 79.6489 0)
    (property "Footprint" "" (id 2) (at 397.51 77.47 90)
    (property "Datasheet" "~" (id 3) (at 397.51 77.47 90)
    (pin "1" (uuid 53fd8e67-1cc5-4525-a97f-f53cc240a3a6))
    (pin "2" (uuid b3781123-3187-48a3-85dc-d86e4def0d6a))
  (symbol (lib_id "Connector:TestPoint") (at 172.72 46.99 0) (mirror y) (unit 1)
    (uuid f2318b86-b749-45ec-8d29-9c0546ae9c3c)
    (property "Reference" "TP13" (id 0) (at 171.323 44.1218 0)
    (property "Value" "TestPoint" (id 1) (at 171.323 45.3902 0)
    (property "Footprint" "" (id 2) (at 167.64 46.99 0)
    (property "Datasheet" "~" (id 3) (at 167.64 46.99 0)
    (pin "1" (uuid 6b4a7893-d7d8-484d-a9a0-019a51054232))
  (sheet_instances
    (path "/" (page "1"))
  (symbol_instances
    (path "/00000000-0000-0000-0000-00006132e145"
      (reference "C4") (unit 1) (value "470p") (footprint "")
    (path "/a8c608fb-7075-43f3-b9db-ce4600d00b0f"
      (reference "C11") (unit 1) (value "47n") (footprint "")
    (path "/00000000-0000-0000-0000-00006136abfd"
      (reference "C17") (unit 1) (value "C_Small-Device") (footprint "")
    (path "/00000000-0000-0000-0000-00006134f52a"
      (reference "C18") (unit 1) (value "C_Small") (footprint "")
    (path "/00000000-0000-0000-0000-000061334bb1"
      (reference "C27") (unit 1) (value "TODO") (footprint "")
    (path "/00000000-0000-0000-0000-00006138cc93"
      (reference "C28") (unit 1) (value "C_Small-Device") (footprint "")
    (path "/00000000-0000-0000-0000-00006135c8ad"
      (reference "D1") (unit 1) (value "D_Small-Device") (footprint "")
    (path "/93373bf3-0370-4975-9726-0dffadc80388"
      (reference "D3") (unit 1) (value "D_Small") (footprint "")
    (path "/00000000-0000-0000-0000-0000613e475d"
      (reference "D5") (unit 1) (value "D_Small-Device") (footprint "")
    (path "/00000000-0000-0000-0000-000061345695"
      (reference "D6") (unit 1) (value "D_Small") (footprint "")
    (path "/239c060f-4b27-4497-9d88-b1c5b3708cc6"
      (reference "D?") (unit 1) (value "D_Small") (footprint "")
    (path "/2b8edd2f-d3d2-45fa-bbdb-2896a7eb66f2"
      (reference "D?") (unit 1) (value "D_Schottky_Small") (footprint "")
    (path "/3541efea-23c3-4dce-9549-0e50a1d88610"
    (path "/5237ab62-e664-440d-b632-36d9c73b7474"
    (path "/a232a4d4-45a8-4a68-81af-39c427c0b1dd"
    (path "/e4570e31-f9dd-4e13-a8d5-42733b999b4d"
    (path "/ece535e5-4fc3-4a25-aa21-10feba6cc504"
    (path "/2af67c9f-1758-4649-8401-6b678ded3579"
      (reference "Q1") (unit 1) (value "BC858C") (footprint "")
    (path "/03fbc68e-492a-49c1-a703-e3e7df3e4be6"
      (reference "R6") (unit 1) (value "56") (footprint "")
    (path "/00000000-0000-0000-0000-000061358a03"
      (reference "R7") (unit 1) (value "10k") (footprint "")
    (path "/00000000-0000-0000-0000-0000613529dc"
      (reference "R8") (unit 1) (value "47") (footprint "")
    (path "/54e308dc-3c0f-4ffb-a960-81104ad37a1f"
      (reference "R9") (unit 1) (value "1k") (footprint "")
    (path "/00000000-0000-0000-0000-00006132c856"
      (reference "R10") (unit 1) (value "22k") (footprint "")
    (path "/d0c27b72-1400-443f-aa3c-6fabd30b42e0"
      (reference "R11") (unit 1) (value "39") (footprint "")
    (path "/00000000-0000-0000-0000-000061327618"
      (reference "R12") (unit 1) (value "2k4") (footprint "")
    (path "/2e586188-20da-44b2-8162-f49779759fcb"
      (reference "R13") (unit 1) (value "1M") (footprint "")
    (path "/00000000-0000-0000-0000-000061369551"
      (reference "R16") (unit 1) (value "10k") (footprint "")
    (path "/c20884ff-e35c-4d65-a5ff-7d5e8da129c8"
      (reference "R17") (unit 1) (value "2k2") (footprint "")
    (path "/00000000-0000-0000-0000-00006136528e"
      (reference "R18") (unit 1) (value "2k2") (footprint "")
    (path "/00000000-0000-0000-0000-0000613255f2"
      (reference "R19") (unit 1) (value "120") (footprint "")
    (path "/00000000-0000-0000-0000-000061367d84"
      (reference "R20") (unit 1) (value "10k") (footprint "")
    (path "/00000000-0000-0000-0000-000061366398"
      (reference "T3") (unit 1) (value "BC858C") (footprint "")
    (path "/00000000-0000-0000-0000-000061335528"
      (reference "T4") (unit 1) (value "BC848C") (footprint "")
    (path "/00000000-0000-0000-0000-000061324b63"
      (reference "TC1") (unit 1) (value "BT137-600") (footprint "")
    (path "/00000000-0000-0000-0000-000061325cfd"
      (reference "TH?") (unit 1) (value "Lötkolben") (footprint "")
    (path "/00000000-0000-0000-0000-000061360fd7"
      (reference "TP7") (unit 1) (value "TestPoint-Connector") (footprint "")
    (path "/00000000-0000-0000-0000-000061368266"
      (reference "TP8") (unit 1) (value "TestPoint-Connector") (footprint "")
    (path "/48ff0ceb-ea44-48a3-b980-0dcbba8daca9"
      (reference "TP9") (unit 1) (value "TestPoint") (footprint "")
    (path "/9edf5f95-96cb-46d0-9a3c-b14fd7f93ac0"
      (reference "TP11") (unit 1) (value "TestPoint") (footprint "")
    (path "/23c5804b-9d9c-40a2-86dd-f120c4503b29"
      (reference "TP12") (unit 1) (value "TestPoint") (footprint "")
    (path "/f2318b86-b749-45ec-8d29-9c0546ae9c3c"
      (reference "TP13") (unit 1) (value "TestPoint") (footprint "")
    (path "/6f1ef841-cc74-4642-881d-accbd23cf024"
      (reference "TP14") (unit 1) (value "TestPoint") (footprint "")
    (path "/00000000-0000-0000-0000-000061408dc5"
      (reference "TP15") (unit 1) (value "TestPoint-Connector") (footprint "")
    (path "/b26c9359-6f3c-4083-aaf0-0453f933cdca"
      (reference "TP15") (unit 1) (value "TestPoint") (footprint "")
    (path "/00000000-0000-0000-0000-00006134b7f9"
      (reference "TP16") (unit 1) (value "TestPoint") (footprint "")
    (path "/00000000-0000-0000-0000-0000613dc089"
      (reference "TP17") (unit 1) (value "TestPoint-Connector") (footprint "")
    (path "/00000000-0000-0000-0000-00006136f674"
      (reference "TP20") (unit 1) (value "TestPoint-Connector") (footprint "")
    (path "/00000000-0000-0000-0000-000061355886"
      (reference "TP26") (unit 1) (value "TestPoint") (footprint "")
    (path "/00000000-0000-0000-0000-000061356ebe"
      (reference "TP27") (unit 1) (value "TestPoint-Connector") (footprint "")
    (path "/00000000-0000-0000-0000-000061357a52"
      (reference "TP28") (unit 1) (value "TestPoint-Connector") (footprint "")
    (path "/00000000-0000-0000-0000-0000613670c0"
      (reference "TP34") (unit 1) (value "TestPoint") (footprint "")
    (path "/00000000-0000-0000-0000-00006132ae65"
      (reference "U3") (unit 1) (value "CD4051") (footprint "")
    (path "/00000000-0000-0000-0000-000061337fa6"
      (reference "U4") (unit 1) (value "TLC272BC") (footprint "")
    (path "/00000000-0000-0000-0000-000061338c71"
      (reference "U4") (unit 2) (value "TLC272BC") (footprint "")
    (path "/00000000-0000-0000-0000-000061339b9c"
      (reference "U4") (unit 3) (value "TLC272BC") (footprint "")
    (path "/041d8702-cc47-4459-b42e-9c07627392bd"
      (reference "U?") (unit 1) (value "PIC16F1946") (footprint "")
