;*************************************************************************** ;* ;* Title : AVR ISP (Auto adr inc, 19200bps) ;* Version : 3.2 ;* Last updated : 17/Jan/05 ;* Target : AT90S2313 @ 4Mhz (orig. AT90S1200) ;* File : AVR910_2313_v3_2.asm ;* Author(s) : Ole Saether, Terje Frostad, ;* Ingar Fredriksen, Morten W. Lund ;* Haakon Skar, Paal Kastnes ;* ;See original appnote for more info. ;* ;* HISTORY ;* V3.3 05/Jan/06 (J.Samperi) Fixed bug with page mode. See note at w7: ;* ;* V3.2 17/Jan/05 (J.Samperi)Added support for newer devices supported by AVRprog 1.4 ;* Some doubtfull or non working device codes commented out ;* Make use on newer conditional assembler to switch between ;* standard pinout for Mosi and Miso and the reversed pinout ;* for the Silicon Chip kit (Australia) ;* ;* V3.1 Modified by others to swap Miso and Mosi to original configuration ;* ;* V3.0?? 16/June/03 (J.Samperi) This version works with AT90S2313 because it ;* uses the LPM instruction and also uses the ;* hardware UART. Added lookup table for device ;* codes and program mode. Device can be added or ;* removed by simply changing parameters in one ;* location only. ;* ;* V2.2c 03.06.07 (sjdavies) Changed the 'x' and 'y' commands to make ;* them accept a parameter ('flushing' bugfix) ;* V2.2b 02.08.16 (sc) Swapped MOSI & MISO port bits ;* V2.2 02.04.10 (sjdavies) Ported to AT90S2313 running at 4MHz for ;* Silicon Chip article. ;* V2.2 02.01.23 (sjdavies) Ported from a 4Mhz 1200 to an 8Mhz 8535. ;* Serial IO modified to use hardware UART. ;* Timing updated. ;* Device specific modifications. ;* V2.2 00.03.10 (pkastnes) Added support for multiple new devices ;* V2.1 98.10.26 (mlund) New date marking. ;* Removed support for AT90S1200C. ;* Added support for AT90S4433A. ;* V2.0 98.01.06 (mlund) ATmega103 support ;* V1.7 97.11.06 (mlund) Universial command (':') implemented. ;* Releases all pins when not in ;* programming mode. ;* V1.6e 97.11.04 (mlund) mega103 rev D support ;* V1.6c 97.10.30 (mlund) Auto incrementing / SPI sync ;* also works for mega103. ;* V1.6 97.09.09 (hskar) Created Page Mode Version (mega103) ;* V1.5 97.08.21 (mlund) Modified / Bugfix / Major cleanup ;* ... ... (no records) ;* V?.? 97.03.15 (OS) Created ;* ;See original appnote for more info. ;* ;* LEGEND: ;* ------- ;* Signature - Device Signature Byte ;* Code - Unique device code used by AVRProg to identify device ;* Flash - Flash size in bytes ;* EEProm - EEProm size in bytes ;* Lock - Lockbits ;* Fuse - Fusebits ;* PMode - Indicates if device uses byte or page programming mode ;* ;* R/W - Read and Write Access ;* R - Read Access Only ;* W - Write Access Only ;* NA - Not Accessible ;* ;*************************************************************************** .nolist .include "2313def.inc" .list .equ silicon_chip=1 ;If 1 Mosi and Miso pinout swapped .equ xtal_8mhz=0 ;if 0 then 4MHz Xtal ;*************************************************************************** ;* ;* CONSTANTS ;* device codes ;* ;* DESCRIPTION ;* The following device codes must be used by the host computer. Note ;* that the device codes are arbitrary selected, they do not have any ;* thing in common with the signature bytes stored in the device. ;* ;*************************************************************************** ;See original appnote for more info. ;**** Revision Codes **** .equ SW_MAJOR = '3' ; Major SW revision number .equ SW_MINOR = '3' ; Minor SW revision number .equ HW_MAJOR = '1' ; Major HW revision number .equ HW_MINOR = '0' ; Minor HW revision number ;*************************************************************************** ;* ;* MACROS ;* Program Macros ;* ;* DESCRIPTION ;* Change the following four macros if the RESET pin to the ;* target moves and/or if the SCK/MISO/MOSO moves. ;* ;*************************************************************************** .equ resetpin = 4 .macro set_reset sbi portb,resetpin .endm .macro clr_reset cbi portb,resetpin .endm .macro ddrd_init nop ; sbi ddrd,3 .endm .macro ddrb_init ldi temp1,(0xFF ^ (1<0=page mode .def device = r16 ; Device code .def temp1 = r17 .def temp2 = r18 .def s_data = r19 ;SPI data .def u_data = r20 ;UART data .def addrl = r21 ;Low order byte of address .def addrh = r22 ;High order byte of address .def cmd3 = r23 ;Used to be r30 (V3.0) .def rd_s_data = r24 ;Used to be r31 (V3.0) .def cmd = r25 ;Serial programming command .def count = r26 ;Time out variable for "enter programming mode" .def param1 = r27 .def cmd1 = r28 .def cmd2 = r29 ; =r30 ;Leave Z register free for LPM ; =r31 (V3.0) ;********************* ;* Interrupt Vectors * ;********************* .CSEG rjmp RESET ; Reset Handle ;Initialize UART. u_init: ldi temp1,N ; set baud rate out UBRR,temp1 ldi temp1,1<= 0x20) && (device <= 0x7F) ) brlo s2 tst device brmi s2 s0b: ; { ldi count,32 ; count = 32; s1: ; do { rcall rdser ; if (rdser == 0x53) // SPI read (byte 3) cpi s_data,0x53 breq s3 ; break; ldi s_data,0x00 ; wrser(0x00); // SPI write (byte 4) rcall wrser pulse_sck ; pulse SCK ldi s_data,0xac ; wrser(0xac); // SPI write (byte 1) rcall wrser ldi s_data,0x53 ; wrser(0x53); // SPI write (byte 2) rcall wrser dec count ; } while(--count); brne s1 rjmp s3 ; } ; else s2: ; { ldi s_data,0x00 ; wrser(0x00); // SPI write (byte 3) rcall wrser s3: ; } ldi s_data,0x00 ; wrser(0x00); // SPI write (byte 4) rcall wrser ldi temp1,0x10 ; delay(0x10); rcall delay ret ;Show our ID ("AVR ISP") on the serial line. ;@@ Changes (V3.0) show_id: ldi zl,low(ID*2) ;Point Z to ID string ldi zh,high(ID*2) rcall msg_out ret ;@@ RESET: ldi temp1,low(RAMEND) out SPL,temp1 ; init stack clr temp1 out GIMSK,temp1 ; disable external interrupt ser temp1 ; Initialize out PORTD,temp1 set_reset ; set RESET=1 out PORTB,temp1 ddrb_release rcall u_init ; Initialize UART ;*************************************************************************** ;* ;* PROGRAM ;* waitcmd -> main ;* ;* DESCRIPTION ;* Wait for and execute commands. ;* ;*************************************************************************** waitcmd: rcall getc ; while (getc() == ESC) {}; cpi u_data,0x1b breq waitcmd ;**** Device Type **** cpi u_data,0x54 ; 'T' Device type brne w0 rcall getc ; getc(); // dummy mov device,u_data ; putc(device); rjmp put_ret ;**** Return Software Identifier **** w0: cpi u_data,0x53 ; 'S' Return software identifier brne w1 rcall show_id ; show_id(); rjmp waitcmd ;**** Return Software Version **** w1: cpi u_data,0x56 ;'V' Return software version brne w2 ldi u_data,SW_MAJOR rcall putc ldi u_data,SW_MINOR rcall putc rjmp waitcmd ;**** Return Hardware Version **** w2: cpi u_data,0x76 ;'v' Return hardware version brne w3 ;*** deleted sd 02.04.10 - correct what looks like an Atmel error ; ldi u_data,0x30+HW_MAJOR ; putc(0x30+HW_MAJOR); ;*** end delete ;*** added sd 02.04.10 - correct what looks like an Atmel error ldi u_data,HW_MAJOR ; putc(HW_MAJOR); ;*** end add rcall putc ;*** deleted sd 02.04.10 - correct what looks like an Atmel error ; ldi u_data,0x30+HW_MINOR ; putc(0x30+HW_MINOR); ;*** end delete ;*** added sd 02.04.10 - correct what looks like an Atmel error ldi u_data,HW_MINOR ; putc(HW_MINOR); ;*** end add rcall putc rjmp waitcmd ;**** Show Supported Devices **** w3: cpi u_data,0x74 ; 't' Show supported devices brne w4 ;@@ Changes (V3.0) ldi zl,low(device_codes*2) ;Point Z to device code table ldi zh,high(device_codes*2) show_devices: rcall get_codes ;Returns device code in dev_code mov u_data,dev_code cpi u_data,0xff ;Check for end of table breq end_of_devices ;Finished rcall putc ;Not finished, send out rjmp show_devices end_of_devices: clr u_data rcall putc ;End of device list rjmp waitcmd ;@@ ;**** Return Programmer Type **** w4: cpi u_data,0x70 ; 'p' Return programmer type brne w51 ldi u_data,0x53 ; putc('S'); // serial programmer rcall putc rjmp waitcmd ;**** Return autoincrement address support w51: cpi u_data,'a' ; 'a' Return address auto increment brne w5 ldi u_data,'Y' ; putc('Y'); // supports autoinc rcall putc rjmp waitcmd w5: cpi u_data,0x78 ; 'x' Set LED (ignored) brne w6 rcall getc ; ignore data byte rjmp put_ret ;**** Clear LED **** w6: cpi u_data,0x79 ; 'y' Clear LED (ignored) brne w7 rcall getc ; ignore data byte rjmp put_ret ;**** Enter Programming Mode **** ; We require that the device code be selected before any of the other commands w7: ;@@ Changes (V3.0)** V3.3 uses temp2 instead of r16 in V3.0 as temp reg ;r16 is already used for device and caused a bug push temp2 ;Save temp2 ldi zl,low(device_codes*2) ;Point Z to device code table ldi zh,high(device_codes*2) w7_lp: rcall get_codes ;Returns device code in dev_code mov temp2,dev_code cpi temp2,0xff ;Check for end of table breq device_err ;Device code not found cp temp2,device ;Found device code? breq x_w7_lp ;Yes rjmp w7_lp ;Next device code x_w7_lp: pop temp2 ;Restore temp2 rjmp w72 device_err: pop temp2 ;Restore temp2 rjmp put_err ;Goto put_err(); ;@@ w72: cpi u_data,0x50 ; 'P' Enter programming mode brne w8 rcall spiinit ; spiinit(); rjmp put_ret ;**** Write Program Memory, High Byte **** w8: cpi u_data,0x43 ; 'C' Write program memory, high byte brne w9 rcall getc w81: ldi s_data,0x48 ; wrser(0x48); // SPI write (byte 1) rcall wrser mov s_data,addrh ; wrser(addrh); // SPI write (byte 2) rcall wrser mov s_data,addrl ; wrser(addrl); // SPI write (byte 3) rcall wrser mov s_data,u_data ; wrser(u_data); // SPI write (byte 4) rcall wrser ldi temp1,0x01 ; Auto increment address!!!! clr temp2 add addrl,temp1 adc addrh,temp2 rjmp writeFLASHdelay ;**** Write Program Memory, Low Byte **** w9: cpi u_data,0x63 ; 'c' Write program memory, low byte brne w12 rcall getc ldi s_data,0x40 ; wrser(0x40); // SPI write (byte 1) rcall wrser mov s_data,addrh ; s_data = addrh; w91: ; } rcall wrser ; wrser(s_data); // SPI write (byte 2) mov s_data,addrl ; wrser(addrl); // SPI write (byte 3) rcall wrser mov s_data,u_data ; wrser(u_data); // SPI write (byte 4) rcall wrser writeFLASHdelay: ;@@ Changes (V3.0) tst pgm_mode brne w92 ;No delay if page mode (non zero value) ;@@ ldi temp1,0x20 ; delay(0x20); // 24585 cycles delay rcall delay ; // Page mode requires no delay! w92: rjmp put_ret ; goto reply(); ;**** Read Program Memory **** w12: cpi u_data,0x52 ; 'R' Read program memory brne w10 ; ldi s_data,0x28 ; wrser(0x28); // SPI write (byte 1) rcall wrser mov s_data,addrh ; s_data = addrh; rcall wrser ; wrser(s_data); // SPI write (byte 2) mov s_data,addrl ; wrser(addrl); // SPI write (byte 3) rcall wrser rcall rdser ; putc(rdser()); // Send data (byte 4) mov u_data,s_data rcall putc ldi s_data,0x20 ; wrser(0x20); // SPI write (byte 1) rcall wrser mov s_data,addrh ; wrser(addrh); // SPI write (byte 2) rcall wrser mov s_data,addrl ; wrser(addrl); // SPI write (byte 3) rcall wrser rcall rdser ; putc(rdser()); // Send data (byte 4) mov u_data,s_data rcall putc rjmp readaddrinc ;**** Load Address **** w10: cpi u_data,0x41 ; 'A' Load address brne w11 rcall getc ; addrh = getc(); mov addrh,u_data rcall getc ; addrl = getc(); mov addrl,u_data rjmp put_ret ; goto reply(); ;**** Write Data Memory **** w11: cpi u_data,0x44 ; 'D' Write data memory brne w13 rcall getc ldi s_data,0xc0 rcall wrser mov s_data,addrh rcall wrser mov s_data,addrl rcall wrser mov s_data,u_data rcall wrser ldi temp1,0x20 rcall delay ldi temp1,0x01 ; Auto increment address!!!! clr temp2 add addrl,temp1 adc addrh,temp2 rjmp put_ret ;**** Read Data Memory **** w13: cpi u_data,0x64 ; 'd' Read data memory brne w14 ldi s_data,0xa0 ; wrser(0xA0); // SPI write (byte 1) rcall wrser mov s_data,addrh ; s_data = addrh; rcall wrser ; wrser(s_data); // SPI write (byte 2) mov s_data,addrl ; wrser(addrl); // SPI write (byte 3) rcall wrser rcall rdser ; putc(rdser()); // Send data (byte 4) mov u_data,s_data rcall putc readaddrinc: ldi temp1,0x01 ; Auto increment address!!!! clr temp2 add addrl,temp1 adc addrh,temp2 rjmp waitcmd ; goto waitcmd(); ;**** Leave Programming Mode **** w14: cpi u_data,0x4c ; 'L' Leave programming mode brne w15 ddrb_release set_reset ; set RESET = 1 rjmp put_ret ;**** Chip Erase **** w15: cpi u_data,0x65 ; 'e' Chip erase brne w16 ldi s_data,0xac rcall wrser ldi s_data,0x80 rcall wrser ldi s_data,0x04 rcall wrser ldi s_data,0x00 rcall wrser ldi temp1,0x30 rcall delay rjmp put_ret ;**** Write Lock Bits **** w16: cpi u_data,0x6c ; 'l' Write lock bits brne w17 rcall getc ldi s_data,0xac rcall wrser mov s_data,u_data andi s_data,0x06 ori s_data,0xe0 rcall wrser ldi s_data,0x00 rcall wrser w162: ldi s_data,0x00 rcall wrser ldi temp1,0x30 rcall delay rjmp put_ret ;**** Read Signature Bytes **** w17: cpi u_data,0x73 ; 's' Read signature bytes brne w18 ldi param1,0x02 rcall w17call ldi param1,0x01 rcall w17call ldi param1,0x00 rcall w17call rjmp waitcmd w17call: ldi s_data,0x30 rcall wrser ldi s_data,0x00 rcall wrser mov s_data,param1 rcall wrser rcall rdser mov u_data,s_data rcall putc ret ;**** Write Program Memory Page **** w18: cpi u_data,0x6D ; 'm' Write Program Memory Page brne w19 ldi s_data,0x4c ; wrser(0x4c); // SPI write (byte 1) rcall wrser mov s_data,addrh ; wrser(addrh); // SPI write (byte 2) rcall wrser mov s_data,addrl ; wrser(addrl); // SPI write (byte 3) rcall wrser ldi s_data,0x00 ; wrser(0x00); // SPI write (byte 4) rcall wrser ldi temp1,0xff ; delay(0xFF); // 0x20 = 24585 cycles delay rcall delay rjmp put_ret ;**** Universal Command **** w19: cpi u_data,0x3A ; ':' Universal Command brne w191 rcall getc mov cmd1,u_data rcall getc mov cmd2,u_data rcall getc mov cmd3,u_data clr u_data rcall NewUniversal ldi temp1,0xff ; delay(0xFF); // 0x20 = 24585 cycles delay rcall delay rjmp put_ret ;**** New Universal Command **** w191: cpi u_data,'.' ; '.' New Universal Command brne w99 rcall getc mov cmd1,u_data rcall getc mov cmd2,u_data rcall getc mov cmd3,u_data rcall getc rcall NewUniversal ldi temp1,0xff ; delay(0xFF); // 0x20 = 24585 cycles delay rcall delay rjmp put_ret NewUniversal: mov s_data,cmd1 rcall wrser mov s_data,cmd2 rcall wrser mov s_data,cmd3 rcall wrser mov s_data,u_data rcall wrser mov u_data,rd_s_data rcall putc ret w99: ;**** Command Error **** put_err: ldi u_data,0x3f ; putc('?'); \\ send '?' rcall putc rjmp waitcmd ;**** Reply Command **** put_ret: ldi u_data,0x0d ; putc(0x0D); \\ send CR rcall putc rjmp waitcmd delay1us: ; count R16 nop cpi temp1,0x03 breq finished nop nop loop: dec temp1 cpi temp1,0x03 brne loop finished: ret ;@@ Changes (V3.0) ;MSG_OUT Output string of ASCII bytes starting at Z ;until end of message ($00) MSG_OUT: lpm ;read char into r0 mov u_data,r0 ;Copy to r20 cpi u_data,0x00 ;End of message? breq END_MSG ;Yes rcall PUTC ;output character adiw ZL,1 rjmp MSG_OUT END_MSG: ret ;get_codes return code in dev_code and program mode in pgm_mode get_codes: lpm ;Read device code from table mov dev_code,r0 ;Copy to dev_code adiw ZL,1 ;Increment pointer lpm ;Read program mode from table mov pgm_mode,r0 ;Copy to pgm_mode adiw ZL,1 ;Increment pointer ret ;Programmer ID ID: .db "AVR ISP",0 ;Device codes and program mode table (0(zero)=byte mode, <>0=page mode) ;i.e. 'P' can be used for page mode for easier reading. device_codes: ;AT90S1200 rev. A ;From 0x00-0x0f unused yet .db 0x10,0 ;AT90S1200 rev. B .db 0x11,0 ;AT90S1200 rev. C .db 0x12,0 ;AT90S1200 .db 0x13,0 ;From 0x14-0x1f unused yet ;AT90S2313 .db 0x20,0 ;From 0x21-0x27 unused yet ;AT90S4414 .db 0x28,0 ;From 0x29-0x2f unused yet ;AT90S4433 .db 0x30,0 ;From 0x31-0x33 unused yet ;AT90S2333 .db 0x34,0 ;From 0x35-0x37 unused yet ;AT90S8515 .db 0x38,0 ;0x39 unused yet ;ATmega8515 .db 0x3A,'P' ;ATmega8515 BOOT .db 0x3B,'P' ;From 0x3c-0x40 unused yet ;ATmega103 .db 0x41,'P' ;ATmega603 .db 0x42,'P' ;ATmega128 .db 0x43,'P' ;ATmega128 BOOT .db 0x44,'P' ;ATmega64 .db 0x45,'P' ;* v1.40 ;ATmega64 BOOT .db 0x46,'P' ;* v1.40 0x47 unused yet ;AT90S2323 .db 0x48,0 ;From 0x49-0x4b unused yet ;AT90S2343 .db 0x4C,0 ;From 0x4d-0x4f unused yet ;0x50,0x51 used. From 0x52-0x54 unused yet ; ;ATtiny12 .db 0x55,0 ;ATtiny15 .db 0x56,0 ;0x57 unused yet ;ATtiny19 .db 0x58,0 ;From 0x59-0x5b unused yet ;ATtiny28 .db 0x5C,0 ;0x5d unused yet ;ATtiny26 .db 0x5E,'P' ;0x5f unused yet ; ;ATmega161 .db 0x60,'P' ;ATmega161 BOOT .db 0x61,'P' ;0x62-0x63 unused yet ;ATmega163 .db 0x64,'P' ;ATmega83 .db 0x65,'P' ;ATmega163 BOOT .db 0x66,'P' ;ATmega83 BOOT .db 0x67,'P' ;AT90S8535 .db 0x68,0 ;ATmega8535 .db 0x69,'P' ;* v1.40 From 0x6a-0x6b unused yet ;***ATmega8535 BOOT?? ; .db 0x6a,'P' ; ;AT90S4434 .db 0x6C,0 ;From 0x6d-0x6f unused yet ;AT90C8534 .db 0x70,0 ;AT90C8544 .db 0x71,0 ;ATmega32 .db 0x72,'P' ;ATmega32 BOOT .db 0x73,'P' ;ATmega16 .db 0x74,'P' ;ATmega16 BOOT .db 0x75,'P' ;ATmega8 .db 0x76,'P' ;ATmega8 BOOT .db 0x77,'P' ;ATmega169 .db 0x78,'P' ;* v1.40 ;ATmega169 BOOT .db 0x79,'P' ;* v1.40 From 0x7a-0x7f unused yet ;test ; .db 0x08,'P' ; .db 0x09,'P' ; .db 0x0a,'P' ; .db 0x0b,'P' ;These devices are not supported by this hardware ;ATtiny10 ; .db 0x51,0 ;ATtiny11 ; .db 0x50,0 ;AT89C1051 ; .db 0x80,0 ;AT89C2051 ; .db 0x81,0 ;From 0x82-0x85 unused yet ;AT89S8252 ; .db 0x86,0 ;AT89S53 ; .db 0x87,0 ;From 0x88-0x9f unused yet end_of_device_codes: .dw 0xffff ;@@
