/* Copyright (c) 2005 Anatoly Sokolov All rights reserved. Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met: * Redistributions of source code must retain the above copyright notice, this list of conditions and the following disclaimer. * Redistributions in binary form must reproduce the above copyright notice, this list of conditions and the following disclaimer in the documentation and/or other materials provided with the distribution. * Neither the name of the copyright holders nor the names of contributors may be used to endorse or promote products derived from this software without specific prior written permission. THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ /* $Id: iomxx0_1.h 2235 2011-03-17 04:13:14Z arcanum $ */ /* avr/iomxx0_1.h - definitions for ATmega640, Atmega1280, ATmega1281, ATmega2560 and ATmega2561. */ #ifndef _AVR_IOMXX0_1_H_ #define _AVR_IOMXX0_1_H_ 1 /* This file should only be included from , never directly. */ #ifndef _AVR_IO_H_ # error "Include instead of this file." #endif #ifndef _AVR_IOXXX_H_ # define _AVR_IOXXX_H_ "iomxx0_1.h" #else # error "Attempt to include more than one file." #endif #if defined(__AVR_ATmega640__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__) # define __ATmegaxx0__ #elif defined(__AVR_ATmega1281__) || defined(__AVR_ATmega2561__) # define __ATmegaxx1__ #endif /* Registers and associated bit numbers */ #define PINA _SFR_IO8(0X00) #define PINA7 7 #define PINA6 6 #define PINA5 5 #define PINA4 4 #define PINA3 3 #define PINA2 2 #define PINA1 1 #define PINA0 0 #define DDRA _SFR_IO8(0X01) #define DDA7 7 #define DDA6 6 #define DDA5 5 #define DDA4 4 #define DDA3 3 #define DDA2 2 #define DDA1 1 #define DDA0 0 #define PORTA _SFR_IO8(0X02) #define PA7 7 #define PA6 6 #define PA5 5 #define PA4 4 #define PA3 3 #define PA2 2 #define PA1 1 #define PA0 0 #define PINB _SFR_IO8(0X03) #define PINB7 7 #define PINB6 6 #define PINB5 5 #define PINB4 4 #define PINB3 3 #define PINB2 2 #define PINB1 1 #define PINB0 0 #define DDRB _SFR_IO8(0x04) #define DDB7 7 #define DDB6 6 #define DDB5 5 #define DDB4 4 #define DDB3 3 #define DDB2 2 #define DDB1 1 #define DDB0 0 #define PORTB _SFR_IO8(0x05) #define PB7 7 #define PB6 6 #define PB5 5 #define PB4 4 #define PB3 3 #define PB2 2 #define PB1 1 #define PB0 0 #define PINC _SFR_IO8(0x06) #define PINC7 7 #define PINC6 6 #define PINC5 5 #define PINC4 4 #define PINC3 3 #define PINC2 2 #define PINC1 1 #define PINC0 0 #define DDRC _SFR_IO8(0x07) #define DDC7 7 #define DDC6 6 #define DDC5 5 #define DDC4 4 #define DDC3 3 #define DDC2 2 #define DDC1 1 #define DDC0 0 #define PORTC _SFR_IO8(0x08) #define PC7 7 #define PC6 6 #define PC5 5 #define PC4 4 #define PC3 3 #define PC2 2 #define PC1 1 #define PC0 0 #define PIND _SFR_IO8(0x09) #define PIND7 7 #define PIND6 6 #define PIND5 5 #define PIND4 4 #define PIND3 3 #define PIND2 2 #define PIND1 1 #define PIND0 0 #define DDRD _SFR_IO8(0x0A) #define DDD7 7 #define DDD6 6 #define DDD5 5 #define DDD4 4 #define DDD3 3 #define DDD2 2 #define DDD1 1 #define DDD0 0 #define PORTD _SFR_IO8(0x0B) #define PD7 7 #define PD6 6 #define PD5 5 #define PD4 4 #define PD3 3 #define PD2 2 #define PD1 1 #define PD0 0 #define PINE _SFR_IO8(0x0C) #define PINE7 7 #define PINE6 6 #define PINE5 5 #define PINE4 4 #define PINE3 3 #define PINE2 2 #define PINE1 1 #define PINE0 0 #define DDRE _SFR_IO8(0x0D) #define DDE7 7 #define DDE6 6 #define DDE5 5 #define DDE4 4 #define DDE3 3 #define DDE2 2 #define DDE1 1 #define DDE0 0 #define PORTE _SFR_IO8(0x0E) #define PE7 7 #define PE6 6 #define PE5 5 #define PE4 4 #define PE3 3 #define PE2 2 #define PE1 1 #define PE0 0 #define PINF _SFR_IO8(0x0F) #define PINF7 7 #define PINF6 6 #define PINF5 5 #define PINF4 4 #define PINF3 3 #define PINF2 2 #define PINF1 1 #define PINF0 0 #define DDRF _SFR_IO8(0x10) #define DDF7 7 #define DDF6 6 #define DDF5 5 #define DDF4 4 #define DDF3 3 #define DDF2 2 #define DDF1 1 #define DDF0 0 #define PORTF _SFR_IO8(0x11) #define PF7 7 #define PF6 6 #define PF5 5 #define PF4 4 #define PF3 3 #define PF2 2 #define PF1 1 #define PF0 0 #define PING _SFR_IO8(0x12) #define PING5 5 #define PING4 4 #define PING3 3 #define PING2 2 #define PING1 1 #define PING0 0 #define DDRG _SFR_IO8(0x13) #define DDG5 5 #define DDG4 4 #define DDG3 3 #define DDG2 2 #define DDG1 1 #define DDG0 0 #define PORTG _SFR_IO8(0x14) #define PG5 5 #define PG4 4 #define PG3 3 #define PG2 2 #define PG1 1 #define PG0 0 #define TIFR0 _SFR_IO8(0x15) #define OCF0B 2 #define OCF0A 1 #define TOV0 0 #define TIFR1 _SFR_IO8(0x16) #define ICF1 5 #define OCF1C 3 #define OCF1B 2 #define OCF1A 1 #define TOV1 0 #define TIFR2 _SFR_IO8(0x17) #define OCF2B 2 #define OCF2A 1 #define TOV2 0 #define TIFR3 _SFR_IO8(0x18) #define ICF3 5 #define OCF3C 3 #define OCF3B 2 #define OCF3A 1 #define TOV3 0 #define TIFR4 _SFR_IO8(0x19) #define ICF4 5 #define OCF4C 3 #define OCF4B 2 #define OCF4A 1 #define TOV4 0 #define TIFR5 _SFR_IO8(0x1A) #define ICF5 5 #define OCF5C 3 #define OCF5B 2 #define OCF5A 1 #define TOV5 0 #define PCIFR _SFR_IO8(0x1B) #if defined(__ATmegaxx0__) # define PCIF2 2 #endif /* __ATmegaxx0__ */ #define PCIF1 1 #define PCIF0 0 #define EIFR _SFR_IO8(0x1C) #define INTF7 7 #define INTF6 6 #define INTF5 5 #define INTF4 4 #define INTF3 3 #define INTF2 2 #define INTF1 1 #define INTF0 0 #define EIMSK _SFR_IO8(0x1D) #define INT7 7 #define INT6 6 #define INT5 5 #define INT4 4 #define INT3 3 #define INT2 2 #define INT1 1 #define INT0 0 #define GPIOR0 _SFR_IO8(0x1E) #define EECR _SFR_IO8(0x1F) #define EEPM1 5 #define EEPM0 4 #define EERIE 3 #define EEMPE 2 #define EEPE 1 #define EERE 0 #define EEDR _SFR_IO8(0X20) /* Combine EEARL and EEARH */ #define EEAR _SFR_IO16(0x21) #define EEARL _SFR_IO8(0x21) #define EEARH _SFR_IO8(0X22) /* 6-char sequence denoting where to find the EEPROM registers in memory space. Adresses denoted in hex syntax with uppercase letters. Used by the EEPROM subroutines. First two letters: EECR address. Second two letters: EEDR address. Last two letters: EEAR address. */ #define __EEPROM_REG_LOCATIONS__ 1F2021 #define GTCCR _SFR_IO8(0x23) #define TSM 7 #define PSRASY 1 #define PSRSYNC 0 #define TCCR0A _SFR_IO8(0x24) #define COM0A1 7 #define COM0A0 6 #define COM0B1 5 #define COM0B0 4 #define WGM01 1 #define WGM00 0 #define TCCR0B _SFR_IO8(0x25) #define FOC0A 7 #define FOC0B 6 #define WGM02 3 #define CS02 2 #define CS01 1 #define CS00 0 #define TCNT0 _SFR_IO8(0X26) #define OCR0A _SFR_IO8(0X27) #define OCR0B _SFR_IO8(0X28) /* Reserved [0x29] */ #define GPIOR1 _SFR_IO8(0x2A) #define GPIOR2 _SFR_IO8(0x2B) #define SPCR _SFR_IO8(0x2C) #define SPIE 7 #define SPE 6 #define DORD 5 #define MSTR 4 #define CPOL 3 #define CPHA 2 #define SPR1 1 #define SPR0 0 #define SPSR _SFR_IO8(0x2D) #define SPIF 7 #define WCOL 6 #define SPI2X 0 #define SPDR _SFR_IO8(0X2E) /* Reserved [0x2F] */ #define ACSR _SFR_IO8(0x30) #define ACD 7 #define ACBG 6 #define ACO 5 #define ACI 4 #define ACIE 3 #define ACIC 2 #define ACIS1 1 #define ACIS0 0 #define MONDR _SFR_IO8(0x31) #define OCDR _SFR_IO8(0x31) #define IDRD 7 #define OCDR7 7 #define OCDR6 6 #define OCDR5 5 #define OCDR4 4 #define OCDR3 3 #define OCDR2 2 #define OCDR1 1 #define OCDR0 0 /* Reserved [0x32] */ #define SMCR _SFR_IO8(0x33) #define SM2 3 #define SM1 2 #define SM0 1 #define SE 0 #define MCUSR _SFR_IO8(0x34) #define JTRF 4 #define WDRF 3 #define BORF 2 #define EXTRF 1 #define PORF 0 #define MCUCR _SFR_IO8(0X35) #define JTD 7 #define PUD 4 #define IVSEL 1 #define IVCE 0 /* Reserved [0x36] */ #define SPMCSR _SFR_IO8(0x37) #define SPMIE 7 #define RWWSB 6 #define SIGRD 5 #define RWWSRE 4 #define BLBSET 3 #define PGWRT 2 #define PGERS 1 #define SPMEN 0 /* Reserved [0x38..0x3A] */ #define RAMPZ _SFR_IO8(0X3B) #define RAMPZ0 0 #define EIND _SFR_IO8(0X3C) #define EIND0 0 /* SP [0x3D..0x3E] */ /* SREG [0x3F] */ #define WDTCSR _SFR_MEM8(0x60) #define WDIF 7 #define WDIE 6 #define WDP3 5 #define WDCE 4 #define WDE 3 #define WDP2 2 #define WDP1 1 #define WDP0 0 #define CLKPR _SFR_MEM8(0x61) #define CLKPCE 7 #define CLKPS3 3 #define CLKPS2 2 #define CLKPS1 1 #define CLKPS0 0 /* Reserved [0x62..0x63] */ #define PRR0 _SFR_MEM8(0x64) #define PRTWI 7 #define PRTIM2 6 #define PRTIM0 5 #define PRTIM1 3 #define PRSPI 2 #define PRUSART0 1 #define PRADC 0 #define __AVR_HAVE_PRR0 ((1<
