; Copyright (c) 2010, Roboterclub Aachen e.V. ; All rights reserved. ; ; Redistribution and use in source and binary forms, with or without ; modification, are permitted provided that the following conditions are met: ; ; * Redistributions of source code must retain the above copyright ; notice, this list of conditions and the following disclaimer. ; * Redistributions in binary form must reproduce the above copyright ; notice, this list of conditions and the following disclaimer in the ; documentation and/or other materials provided with the distribution. ; * Neither the name of the Roboterclub Aachen e.V. nor the ; names of its contributors may be used to endorse or promote products ; derived from this software without specific prior written permission. ; ; THIS SOFTWARE IS PROVIDED BY ROBOTERCLUB AACHEN E.V. ''AS IS'' AND ANY ; EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED ; WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE ; DISCLAIMED. IN NO EVENT SHALL ROBOTERCLUB AACHEN E.V. BE LIABLE FOR ANY ; DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES ; (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; ; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ; ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT ; (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF ; THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. ; ; $Id$ ; ; ---------------------------------------------------------------------------- #include #include "config.h" #include "mcp2515_defs.h" ; ----------------------------------------------------------------------------- #define RESET(x) _XRS(x) #define SET(x) _XS(x) #define TOGGLE(x) _XT(x) #define _port2(x) PORT ## x #define _pin2(x) PIN ## x #define _XRS(x,y) cbi _SFR_IO_ADDR(_port2(x)), y #define _XS(x,y) sbi _SFR_IO_ADDR(_port2(x)), y #define _XT(x,y) sbi _SFR_IO_ADDR(_pin2(x)), y #define _FUNCTION(A) \ .global A $ \ .func A #define _ENDFUNC .endfunc #define _GLOBAL(label, size) .comm label, size #define _STATIC(label, size) .lcomm label, size #define _DATA_SECTION .section .bss #define _CODE_SECTION .section .text #define NO_MESSAGE 0x3f ; ----------------------------------------------------------------------------- .equ Zh, 31 .equ Zl, 30 .equ Yh, 29 .equ Yl, 28 .equ Xh, 27 .equ Xl, 26 .equ temp_reg, 0 ; ----------------------------------------------------------------------------- ; Variables ; ----------------------------------------------------------------------------- .section .bss _GLOBAL( message_number, 1 ) _GLOBAL( message_data_counter, 1 ) _GLOBAL( message_data_length, 1 ) _GLOBAL( message_data, 4 ) .section .text ; ----------------------------------------------------------------------------- ; writes one byte per SPI _FUNCTION(spi_putc) spi_putc_rs: RESET(MCP2515_CS) spi_putc: out _SFR_IO_ADDR(SPDR), 24 spi_putc_1: in temp_reg, _SFR_IO_ADDR(SPSR) sbrs temp_reg, SPIF rjmp spi_putc_1 in 24, _SFR_IO_ADDR(SPDR) clr 25 ret _ENDFUNC ; ----------------------------------------------------------------------------- ; adress in r24 and data in r22 _FUNCTION(mcp2515_write_register) mcp2515_write_register: RESET(MCP2515_CS) mov 18, 24 ldi 24, SPI_WRITE rcall spi_putc mov 24, 18 rcall spi_putc mov 24, 22 rcall spi_putc rjmp cs_ret ; SET(MCP2515_CS) ; ret _ENDFUNC ; ----------------------------------------------------------------------------- ; type in r24, return status in r24 _FUNCTION(mcp2515_read_status) mcp2515_read_status: ;RESET(MCP2515_CS) ; the value is already in r24 rcall spi_putc_rs ; write a undefined value => only the return value is interesting rcall spi_putc rjmp cs_ret ; SET(MCP2515_CS) ; ret _ENDFUNC ; ----------------------------------------------------------------------------- ; return type of message, 0x3f = no message _FUNCTION(mcp2515_get_message) get_message_ret_: ldi 24, NO_MESSAGE ret mcp2515_get_message: ; read status ldi 24, SPI_RX_STATUS rcall mcp2515_read_status mov 20, 24 clr 18 sbrc 20, 7 ldi 18, RXB1DLC sbrc 20, 6 ldi 18, RXB0DLC tst 18 breq get_message_ret_ ; no message avilable ; check for rtr-frames andi 24, 0x18 tst 24 brne get_message_reject ; read message ;RESET(MCP2515_CS) ldi 24, SPI_READ rcall spi_putc_rs mov 24, 18 rcall spi_putc ; read DLC rcall spi_putc ; length must be greater than 4 mov 18, 24 andi 18, 0x0F subi 18, 4 cpi 18, 5 brge get_message_reject ; store length sts message_data_length, 18 ; first byte is the board-id rcall spi_putc cpi 24, BOOTLOADER_BOARD_ID brne get_message_reject ; second byte is the type of the message ; (which will be return at the end) rcall spi_putc mov 19, 24 ; third byte is the message number rcall spi_putc sts message_number, 24 ; next one is the counter for multi-data-commands rcall spi_putc sts message_data_counter, 24 ; read data ldi Zh, hi8(message_data) ldi Zl, lo8(message_data) read_data_loop: dec 18 brlt read_data_end rcall spi_putc st Z+, 24 rjmp read_data_loop read_data_end: get_message_reject: SET(MCP2515_CS) ; clear interrupt flag sbrc 20, 7 ldi 21, (1< TODO check length mov 24, 22 subi 24, 256-4 ; four extra bytes rcall spi_putc ; write board-id and type ldi 24, BOOTLOADER_BOARD_ID rcall spi_putc mov 24, 19 rcall spi_putc lds 24, message_number rcall spi_putc lds 24, message_data_counter rcall spi_putc ; write payload-data ldi Zh, hi8(message_data) ldi Zl, lo8(message_data) write_data_loop: dec 22 brlt write_data_end ld 24, Z+ rcall spi_putc rjmp write_data_loop write_data_end: SET(MCP2515_CS) ; nop ; nop ldi 24, SPI_RTS | 1 ; send buffer rcall spi_putc_rs cs_ret: SET(MCP2515_CS) ret _ENDFUNC
