/***************************************************************************** * * Atmel Corporation * * File : USI_TWI_Master.h * Date : $Date: 2016-7-15 $ * Updated by : $Author: Atmel $ * * Support mail : avr@atmel.com * * Supported devices : All device with USI module can be used. * The example is written for the ATmega169, ATtiny26 and ATtiny2313 * * AppNote : AVR310 - Using the USI module as a TWI Master * * Description : This is an implementation of an TWI master using * the USI module as basis. The implementation assumes the AVR to * be the only TWI master in the system and can therefore not be * used in a multi-master system. * Usage : Initialize the USI module by calling the USI_TWI_Master_Initialise() * function. Hence messages/data are transceived on the bus using * the USI_TWI_Start_Transceiver_With_Data() function. If the transceiver * returns with a fail, then use USI_TWI_Get_Status_Info to evaluate the * couse of the failure. * ****************************************************************************/ #ifndef USI_TWI_MASTER_H #define USI_TWI_MASTER_H #if __GNUC__ #ifndef F_CPU #define F_CPU 4000000 #endif #include #include #endif //********** Defines **********// // Defines controlling timing limits #define TWI_FAST_MODE #define SYS_CLK 4000.0 // [kHz] #ifdef TWI_FAST_MODE // TWI FAST mode timing limits. SCL = 100-400kHz #define T2_TWI ((SYS_CLK * 1300) / 1000000) + 1 // >1,3us #define T4_TWI ((SYS_CLK * 600) / 1000000) + 1 // >0,6us #else // TWI STANDARD mode timing limits. SCL <= 100kHz #define T2_TWI ((SYS_CLK * 4700) / 1000000) + 1 // >4,7us #define T4_TWI ((SYS_CLK * 4000) / 1000000) + 1 // >4,0us #endif // Defines controling code generating //#define PARAM_VERIFICATION //#define NOISE_TESTING #define SIGNAL_VERIFY // USI_TWI messages and flags and bit masks //#define SUCCESS 7 //#define MSG 0 /**************************************************************************** Bit and byte definitions ****************************************************************************/ #define TWI_READ_BIT 0 // Bit position for R/W bit in "address byte". #define TWI_ADR_BITS 1 // Bit position for LSB of the slave address bits in the init byte. #define TWI_NACK_BIT 0 // Bit position for (N)ACK bit. #define USI_TWI_NO_DATA 0x00 // Transmission buffer is empty #define USI_TWI_DATA_OUT_OF_BOUND 0x01 // Transmission buffer is outside SRAM space #define USI_TWI_UE_START_CON 0x02 // Unexpected Start Condition #define USI_TWI_UE_STOP_CON 0x03 // Unexpected Stop Condition #define USI_TWI_UE_DATA_COL 0x04 // Unexpected Data Collision (arbitration) #define USI_TWI_NO_ACK_ON_DATA 0x05 // The slave did not acknowledge all data #define USI_TWI_NO_ACK_ON_ADDRESS 0x06 // The slave did not acknowledge the address #define USI_TWI_MISSING_START_CON 0x07 // Generated Start Condition not detected on bus #define USI_TWI_MISSING_STOP_CON 0x08 // Generated Stop Condition not detected on bus // Device dependant defines #if __GNUC__ #include "usi_io.h" #else //__GNUC__ #if defined(__AT90Mega169__) || defined(__ATmega169__) || defined(__AT90Mega165__) || defined(__ATmega165__) \ || defined(__ATmega325__) || defined(__ATmega3250__) || defined(__ATmega645__) || defined(__ATmega6450__) \ || defined(__ATmega329__) || defined(__ATmega3290__) || defined(__ATmega649__) || defined(__ATmega6490__) #define DDR_USI DDRE #define PORT_USI PORTE #define PIN_USI PINE #define PORT_USI_SDA PORTE5 #define PORT_USI_SCL PORTE4 #define PIN_USI_SDA PINE5 #define PIN_USI_SCL PINE4 #endif #if defined(__ATtiny25__) || defined(__ATtiny45__) || defined(__ATtiny85__) || defined(__AT90Tiny26__) \ || defined(__ATtiny26__) #define DDR_USI DDRB #define PORT_USI PORTB #define PIN_USI PINB #define PORT_USI_SDA PORTB0 #define PORT_USI_SCL PORTB2 #define PIN_USI_SDA PINB0 #define PIN_USI_SCL PINB2 #endif #if defined(__AT90Tiny2313__) || defined(__ATtiny2313__) #define DDR_USI DDRB #define PORT_USI PORTB #define PIN_USI PINB #define PORT_USI_SDA PORTB5 #define PORT_USI_SCL PORTB7 #define PIN_USI_SDA PINB5 #define PIN_USI_SCL PINB7 #endif #ifndef DDR_USI_CL #define DDR_USI_CL DDR_USI #define PORT_USI_CL PORT_USI #define PIN_USI_CL PIN_USI #endif #endif //__GNUC__ // General defines #define TRUE 1 #define FALSE 0 #if __GNUC__ #define DELAY_T2TWI (_delay_us(T2_TWI / 4)) #define DELAY_T4TWI (_delay_us(T4_TWI / 4)) #else #define DELAY_T2TWI (__delay_cycles(T2_TWI)) #define DELAY_T4TWI (__delay_cycles(T4_TWI)) #endif //********** Prototypes **********// void USI_TWI_Master_Initialise(void); #ifndef __GNUC__ __x // AVR compiler #endif unsigned char USI_TWI_Start_Transceiver_With_Data_Stop(unsigned char *, unsigned char, unsigned char); unsigned char USI_TWI_Start_Transceiver_With_Data(unsigned char *, unsigned char); unsigned char USI_TWI_Get_State_Info(void); #endif
