/* * File: Nixie_main.c * Author: N. Brent Burns * Compiler: XC8 v1.43 * * Started: February 25, 2018, 9:33 PM (while drunk) * * Info: This .C code is for a 12-Hour Nixie Tube Clock circuit. * This PIC determines/controls/outputs the accurate 1Hz clock signal. * It also correctly determines and feeds time display values to the shift registers (logic-level). * * Originally started with a 40-pin PIC18F4520 * but switched to a 14-pin PIC16F15325 to reduce overall pin count/size. * * Need an external crystal for final design (way more fucking accurate). * This code needs to produce a 44-bit number (to send out Sync. serially) * to represent the time of a 12-hour clock (H1H0:M1M0:S1S0), details below. * * If you want a 24-hour clock, you have to rework the code and * output a 45-bit number (to account for the additional digit of H1) * * Full details of this project (circuit/SCH/PCB/etc.) can be found at: * "Projects" tab at http://crystal.uta.edu/~burns/ * * This project was inspired by (straight up stolen from honestly): * Threeneuron: https://threeneurons.files.wordpress.com/2015/08/hv_supply_kit.pdf * for the High Voltage Power Supply for my Nixie Circuit * Dave Jones (EEVblog): https://www.youtube.com/watch?v=7uogKucrPks&list=PLvOlSehNtuHutdg1kZkG7aAYhjoJnk2fc * for the general design of driving (logically) the Nixe Tubes */ /* * DETAILED NOTES: * * Want a 12-hour clock format * 12hr x 60min x 60sec = 43,200 dec (use a single global var to store this value, unsigned int of 16 bits will do) * 44-bit binary format for shift registers (H1H0:M1M0:S1S0): * H1: 1,0 H0: 2,1-9,0,1 M1: 0-5 M0: 0-9 S1: 0-5 S0: 0-9 (decimal digits) * H1 H0 M1 M0 S1 S0 * (MSB) xx xxxxxxxxxx xxxxxx xxxxxxxxxx xxxxxx xxxxxxxxxx (LSB) (take up this many binary bits) * * Need to serially shift out this 44-bit number 8-bits at a time * * One-way communication PIC-->Shift Registers * Use the sync. SPI module of the PIC18 * * PIC16F15325 Pins TPIC6595 Shift Register Pins/Buses * SCK (pin 10)---------------SRCK (clock for shifting out serial (binary) data, 44 HIGH-to-LOW pulses, idle low, rising edge data out/in) * max frequency: 50MHz (I think), aim much slower, but still much faster than 1Hz to beat the actual clock display * SDO (pin 9)----------------SER_IN (actual binary data output, 44 bits) * C2 (pin 8)----------------RCK (single clock pulse (idle low, pulse HIGH-to-LOW) to latch in all shifted data at once) * this RCK needs to happen every 1sec (EXACTLY) * * PIC16F15325 Pins Rotary Encoder Connections * INT/RA2 (pin 11)---------------Push Button (Normally pulled HIGH via resistor, pulsed LOW when user pressed the encoder's push button) * (used as an External Interrupt to toggle through User Set Mode to adjust the clock's time) * RC4 (pin 6)--------------------Channel A (Ch. A and B used together to get direction (inc/dec) and adjust time when the user rotates the encoder) * RC3 (pin 7)--------------------Channel B (User must have previously pressed the Push Button for the rotation to adjust the time) * * * General structure (Free Running Mode): * 1. Calculate current time vars (H1H0:M1M0:S1S0) * 2. Encode each var into the correct binary format * 3. Combine into one/two/three binary numbers to send out serially * 4. Load binary number(s), start SRCK, binary number(s) are outputted to shift registers * 5. Stop SRCK when last bit goes out * 6. When 1sec (1Hz) timer interrupt goes off, pulse the RCK (latches the shift registers, Nixie tubes show new numbers) * 7. Increment the current time vars * 8. Go back to step 1 * * General structure (User Set Mode): * 1. External INT pin interrupt connected to the Push Button switch of the Rotary Encoder * 2. This push action cycles through individually adjusting (inc/dec) the HOURS, MINS, and then SECS * 3. One more push puts the clock back into normal Free Running Mode, starting off wherever you adjusted to * 4. The rotary encoder increments/decrements individual digit segments and updates in real-time (as instant as possible) */ // PIC16F15325 Configuration Bit Settings // 'C' source line config statements #pragma config FEXTOSC = HS // External Oscillator mode selection bits (HS (crystal oscillator) above 4MHz; PFM set to high power) #pragma config RSTOSC = EXT1X // Power-up default value for COSC bits (EXTOSC operating per FEXTOSC bits) #pragma config CLKOUTEN = OFF // Clock Out Enable bit (CLKOUT function is disabled; i/o or oscillator function on OSC2) #pragma config CSWEN = ON // Clock Switch Enable bit (Writing to NOSC and NDIV is allowed) #pragma config FCMEN = OFF // Fail-Safe Clock Monitor Enable bit (FSCM timer disabled) #pragma config MCLRE = ON // Master Clear Enable bit (MCLR pin is Master Clear function) #pragma config PWRTE = OFF // Power-up Timer Enable bit (PWRT disabled) #pragma config LPBOREN = OFF // Low-Power BOR enable bit (ULPBOR disabled) #pragma config BOREN = OFF // Brown-out reset enable bits (Brown-out reset disabled) #pragma config BORV = LO // Brown-out Reset Voltage Selection (Brown-out Reset Voltage (VBOR) set to 1.9V on LF, and 2.45V on F Devices) #pragma config ZCD = OFF // Zero-cross detect disable (Zero-cross detect circuit is disabled at POR.) #pragma config PPS1WAY = OFF // Peripheral Pin Select one-way control (The PPSLOCK bit can be set and cleared repeatedly by software) #pragma config STVREN = OFF // Stack Overflow/Underflow Reset Enable bit (Stack Overflow or Underflow will not cause a reset) #pragma config WDTCPS = WDTCPS_31 // WDT Period Select bits (Divider ratio 1:65536; software control of WDTPS) #pragma config WDTE = OFF // WDT operating mode (WDT Disabled, SWDTEN is ignored) #pragma config WDTCWS = WDTCWS_7 // WDT Window Select bits (window always open (100%); software control; keyed access not required) #pragma config WDTCCS = SC // WDT input clock selector (Software Control) #pragma config BBSIZE = BB512 // Boot Block Size Selection bits (512 words boot block size) #pragma config BBEN = OFF // Boot Block Enable bit (Boot Block disabled) #pragma config SAFEN = OFF // SAF Enable bit (SAF disabled) #pragma config WRTAPP = OFF // Application Block Write Protection bit (Application Block not write protected) #pragma config WRTB = OFF // Boot Block Write Protection bit (Boot Block not write protected) #pragma config WRTC = OFF // Configuration Register Write Protection bit (Configuration Register not write protected) #pragma config WRTSAF = OFF // Storage Area Flash Write Protection bit (SAF not write protected) #pragma config LVP = OFF // Low Voltage Programming Enable bit (High Voltage on MCLR/Vpp must be used for programming) #pragma config CP = OFF // UserNVM Program memory code protection bit (UserNVM code protection disabled) #include #include #define _XTAL_FREQ 12288000 // Fosc = 12.288MHz (external crystal) #define RCK_Latch_Signal PORTCbits.RC2 // output IO pulse to latch out Shift Register data #define Encoder_Ch_A PORTCbits.RC4 // input from Channel A of the Encoder (RPG) #define Encoder_Ch_B PORTCbits.RC3 // input from Channel B of the Encoder (RPG) #define MODE_FREE_RUNNING 0 // clock increments freely and normally #define MODE_EDIT_HOURS 1 // user can use the encoder to select/adjust HOURS digits #define MODE_EDIT_MINS 2 // user can use the encoder to select/adjust MINUTES digits #define MODE_EDIT_SECS 3 // user can use the encoder to select/adjust SECONDS digits unsigned char currentMode = 0; // 4 different modes the clock can be in (incremented by the push button of the encoder) unsigned int myTime = 0; // 0 to 43,200 decimal (12hr x 60min x 60sec = 43,200) unsigned char waitFlag = 0; // set in the timer ISR, used in main() to prevent unnec. time calculations // Function Prototypes void interrupt ISR_High(void); void sendDataOut(void); void latchOutData(void); void main(void) { unsigned char i = 0; unsigned char aState_curr = 0; unsigned char aState_prev = 0; unsigned char adjustSecs = 0; // only valid values 0-59 unsigned char adjustMins = 0; // only valid values 0-59 unsigned char adjustHours = 0; // only valid values 1-12, but remember 12 truly means 0 ANSELA = 0; // all digital I/O (no analog inputs) ANSELC = 0; // all digital I/O (no analog inputs) // TRIS I/O Settings // C5 = Don't Care (or output testing BLUE_LED) // C4 = Input for Encoder Channel A // C3 = Input for Encoder Channel B // C2 = Output for RCK Data Latch Output Pulse to shift registers // C1 = SPI SDO 44-bit serial output data (SER_IN) to shift registers // C0 = SPI Clock for the SRCK serial clock to shift registers TRISC = 0b011000; TRISA = 0b111111; //All inputs, OSC pins, Ext. INT, etc. // Turn off everything in the beginning RCK_Latch_Signal = 0; PORTCbits.RC0 = 0; // SCK/SCL PORTCbits.RC1 = 0; // SDO // PPS Settings (Peripheral Pin Select) (mapping) // want SDO on Pin 9 (RC1) & SCK on Pin 10 (RC0) RC0PPS = 0x15; // RC0->MSSP1:SCK1; RC1PPS = 0x16; // RC1->MSSP1:SDO1; // SPI settings (to send data/clock to the shift registers) SSP1CON1bits.SSPEN = 1; // Just turn ON and leave on SSP1STATbits.CKE = 1; // IDLE state is LOW (0), data transmitted out on rising edge of SCK SSP1CON1bits.SSPM3 = 0; // 0010 SPI Clock = Fosc/64 SSP1CON1bits.SSPM2 = 0; // 0010 SPI Clock = Fosc/64 SSP1CON1bits.SSPM1 = 1; // 0010 SPI Clock = Fosc/64 SSP1CON1bits.SSPM0 = 0; // 0010 SPI Clock = Fosc/64 // Clear all the outputs of the shift registers (turn off all Nixies) for(i=0; i<6; i++) { SSP1BUF = 0b00000000; // 6 x 8 bits for all the shift register outputs while(SSP1STATbits.BF == 0); } // Latch everything out of the shift registers all at once latchOutData(); // Timer settings (to generate the exact 1Hz Nixie clock latch signal) /** * d = 1.0sec * Fosc = 12.288MHz = 12,288,000 Hz * Fin = Fosc / 4 = 12.288MHz / 4 = 3.072MHz * * Using 16-bit mode (0-65,535) * Use prescaler 1:64 and postscaler 1:1 to fit into 16-bit register (<65k) * * 3,072,000 / 64 / 1 = 48,000 * Preload = 65,536 - 48,000 = 17,536 = 0x4480 */ T0CON0bits.T0EN = 0; // timer0 off for the moment T0CON0bits.T016BIT = 1; // 16-bit timer0 mode T0CON0bits.T0OUTPS3 = 0; // 0000 1:1 postscaler (no postscaler) T0CON0bits.T0OUTPS2 = 0; // 0000 1:1 postscaler (no postscaler) T0CON0bits.T0OUTPS1 = 0; // 0000 1:1 postscaler (no postscaler) T0CON0bits.T0OUTPS0 = 0; // 0000 1:1 postscaler (no postscaler) T0CON1bits.T0CS2 = 0; // 010 Timer0 clock source = Fosc/4 T0CON1bits.T0CS1 = 1; // 010 Timer0 clock source = Fosc/4 T0CON1bits.T0CS0 = 0; // 010 Timer0 clock source = Fosc/4 T0CON1bits.T0ASYNC = 0; // sync. timer0 counter with Fosc/4 (why the fuck not) T0CON1bits.T0CKPS3 = 0; // 0110 1:64 prescaler T0CON1bits.T0CKPS2 = 1; // 0110 1:64 prescaler T0CON1bits.T0CKPS1 = 1; // 0110 1:64 prescaler T0CON1bits.T0CKPS0 = 0; // 0110 1:64 prescaler TMR0H = 0x44; // preload value = 0x4480 (LOAD HIGH FIRST!!!) TMR0L = 0x80; // preload value = 0x4480 // Interrupt settings (1Hz timer0 interrupt, external switch interrupt) PIE0bits.TMR0IE = 1; // enable timer0 interrupt INTCONbits.INTEDG = 1; // INT rising edge triggered from PB Switch of the Encoder PIE0bits.INTE = 1; // enable external INT interrupt PIR0bits.INTF = 0; INTCONbits.PEIE = 1; INTCONbits.GIE = 1; T0CON0bits.T0EN = 1; // start timer0 // main routine while loop while(1) { while(currentMode == MODE_FREE_RUNNING) { if(waitFlag == 0) // Only do if ready, don't perform unnec. calculations { sendDataOut(); waitFlag = 1; } } // User Set Mode: Adjust the Hours Digits of the Clock while(currentMode == MODE_EDIT_HOURS) { // Read the Encoder (might make it function-based later) aState_curr = PORTCbits.RC4; // Encoder Channel A output if(aState_curr != aState_prev) // Did a rotation occur? { adjustHours = myTime / 3600; // Starting point for Hours adjustment (find the current H1:H0) if(aState_curr != PORTCbits.RC3) // Compare Ch. A vs B, CW or CCW?, increment or decrement? { adjustHours++; // weird case, "adjusting" a 0 to a 12 is done in sendDataOut() if(adjustHours >= 12) // want the incrementing to be cyclical adjustHours = 0; } else { adjustHours--; // weird case again, if decrement lower than zero (rollover to high int value) if(adjustHours >= 13) // want the decrementing to be cyclical adjustHours = 11; } // could combine these next two lines together, but it's a little more clear this way myTime = myTime - ((myTime / 3600)*3600); // subtract all the possible hours from the overall time myTime = myTime + (adjustHours*3600); // add back the new adjusted hours to the overall time sendDataOut(); // Latch everything out of the shift registers all at once latchOutData(); aState_prev = aState_curr; } } // User Set Mode: Adjust the Minutes Digits of the Clock while(currentMode == MODE_EDIT_MINS) { // Read the Encoder (might make it function-based later) aState_curr = PORTCbits.RC4; // Encoder Channel A output if(aState_curr != aState_prev) // Did a rotation occur? { adjustMins = (myTime / 60) % 60; // Starting point for Minutes adjustment (find the current M1:M0) if(aState_curr != PORTCbits.RC3) // Compare Ch. A vs B, CW or CCW?, increment or decrement? { adjustMins++; if(adjustMins >= 60) // want the incrementing to be cyclical adjustMins = 0; } else { adjustMins--; if(adjustMins >= 60) // want the decrementing to be cyclical adjustMins = 59; } myTime = myTime - (((myTime / 60) % 60) * 60); // subtract all the possible minutes from the overall time myTime = myTime + (adjustMins*60); // add back the new adjusted minutes to the overall time sendDataOut(); // Latch everything out of the shift registers all at once latchOutData(); aState_prev = aState_curr; } } // User Set Mode: Adjust the Seconds Digits of the Clock while(currentMode == MODE_EDIT_SECS) { // Read the Encoder (might make it function-based later) aState_curr = PORTCbits.RC4; // Encoder Channel A output if(aState_curr != aState_prev) // Did a rotation occur? { adjustSecs = myTime % 60; // Starting point for Seconds adjustment (find the current S1:S0) if(aState_curr != PORTCbits.RC3) // Compare Ch. A vs B, CW or CCW?, increment or decrement? { adjustSecs++; if(adjustSecs >= 60) // want the incrementing to be cyclical adjustSecs = 0; } else { adjustSecs--; if(adjustSecs >= 60) // want the decrementing to be cyclical adjustSecs = 59; } myTime = myTime - (myTime % 60); // subtract all the possible seconds from the overall time myTime = myTime + adjustSecs; // add back the new adjusted seconds to the overall time sendDataOut(); // Latch everything out of the shift registers all at once latchOutData(); aState_prev = aState_curr; } } } // end of while(1) } // end of void main(void) // HIGH Priority Interrupt Service Routine void interrupt ISR_High(void) { // Was the 1Hz TIMER0 interrupt triggered? if((PIE0bits.TMR0IE == 1) && (PIR0bits.TMR0IF == 1)) { // reload the preload value immediately, CRUCIAL!!! TMR0H = 0x44; // preload value = 0x4480 (LOAD HIGH FIRST!!!) TMR0L = 0x80; // preload value = 0x4480 // Latch everything out of the shift registers all at once latchOutData(); myTime++; waitFlag = 0; PIR0bits.TMR0IF = 0; // Clear flag } // Was the PB Switch of the Encoder pushed? if((PIE0bits.INTE == 1) && (PIR0bits.INTF == 1)) { // __delay_ms(10); PIE0bits.TMR0IE = 0; // temp. disable the timer0 interrupt T0CON0bits.T0EN = 0; // pause/stop timer0 PIR0bits.TMR0IF = 0; currentMode++; if(currentMode >= 4) currentMode = 0; PIR0bits.INTF = 0; if(currentMode == MODE_FREE_RUNNING) // in free-running mode, want timer to increment clock normally at 1Hz { // reload the preload value immediately, CRUCIAL!!! TMR0H = 0x44; // preload value = 0x4480 (LOAD HIGH FIRST!!!) TMR0L = 0x80; // preload value = 0x4480 PIE0bits.TMR0IE = 1; // re-enable timer0 interrupt T0CON0bits.T0EN = 1; // restart timer0 } } } void sendDataOut(void) { // Temp time calculation variables unsigned int hours = 0; unsigned int mins = 0; unsigned int secs = 0; unsigned int h1 = 0; unsigned int h0 = 0; unsigned int m1 = 0; unsigned int m0 = 0; unsigned int s1 = 0; unsigned int s0 = 0; // Vars for the final weird binary format for the shift registers unsigned int bin_hour1 = 0; unsigned int bin_hour0 = 0; unsigned int bin_min1 = 0; unsigned int bin_min0 = 0; unsigned int bin_sec1 = 0; unsigned int bin_sec0 = 0; // Disable external INT when doing stuff below so INT0 user switch // doesn't interrupt during a crucial time PIE0bits.INTE = 0; // STEP 1 // Split the myTime (total seconds) var into hours, minutes, seconds // and then split each once more to extract the individual digits if(myTime >= 43200) // 12 hours expressed in 43,200 seconds myTime = 0; // reset the clock counter var // HH:MM:SS encoding (12-hour format, no AM/PM) // H1 H0 : M1 M0 : S1 S0 (more detailed) secs = myTime % 60; s1 = secs / 10; s0 = secs % 10; mins = (myTime / 60) % 60; m1 = mins / 10; m0 = mins % 10; hours = myTime / 3600; if(hours == 0) //special case hours = 12; h1 = hours / 10; h0 = hours % 10; // STEP 2 // Encode/format the above vars into the "odd" binary output for shift registers // For each individual binary number, only a single bit may be HIGH (1) // 44-bit binary format for shift registers (H1H0:M1M0:S1S0): // H1: 1,0 H0: 2,1-9,0,1 M1: 0-5 M0: 0-9 S1: 0-5 S0: 0-9 // H1 H0 M1 M0 S1 S0 // (MSB) xx xxxxxxxxxx xxxxxx xxxxxxxxxx xxxxxx xxxxxxxxxx (LSB) // H1H0 H0 M1 |M0 M0 S1 |S0 S0 // More Detailed: (MSB) 0000xxxx xxxxxxxx xxxxxxxx xxxxxxxx xxxxxxxx xxxxxxxx (LSB) // Have to send out in 8-bit chunks // Need to serially shift out this 44-bit number 8-bits at a time // Send out starting with the MSB side (hours side) // encode and send data out serially // (but not displayed yet, that's in the Timer ISR which calls latchOutData() and pulses the RCK pin) bin_hour1 = (unsigned int)pow(2,h1); //0-bit of shiftReg is connected to Nixie "0", and logically so on... bin_hour0 = (unsigned int)pow(2,h0); bin_min1 = (unsigned int)pow(2,m1); bin_min0 = (unsigned int)pow(2,m0); bin_sec1 = (unsigned int)pow(2,s1); bin_sec0 = (unsigned int)pow(2,s0); // might need to wrap this stuff with all interrupts disabled to be safe SSP1BUF = 0b00001111 & (((bin_hour1<<2)&0b1100) | ((bin_hour0>>8)&0b11)); while(SSP1STATbits.BF == 0); SSP1BUF = bin_hour0; while(SSP1STATbits.BF == 0); SSP1BUF = ((bin_min1<<2)&0b11111100) | ((bin_min0>>8)&0b11); while(SSP1STATbits.BF == 0); SSP1BUF = bin_min0; while(SSP1STATbits.BF == 0); SSP1BUF = ((bin_sec1<<2)&0b11111100) | ((bin_sec0>>8)&0b11); while(SSP1STATbits.BF == 0); SSP1BUF = bin_sec0; while(SSP1STATbits.BF == 0); // Re-Enable the external INT when waiting PIE0bits.INTE = 1; } void latchOutData(void) { // Disable external INT when doing stuff below so INT0 user switch // doesn't interrupt during a crucial time PIE0bits.INTE = 0; // Pulse RCK, idle LOW then HIGH-LOW pulse // fool around with how fast I can do this // Latch everything out of the shift registers all at once RCK_Latch_Signal = 1; __delay_ms(10); RCK_Latch_Signal = 0; // Re-Enable the external INT when waiting PIE0bits.INTE = 1; } // end of Nixie_main.c (peace)
