(kicad_sch (version 20211123) (generator eeschema)
  (uuid f3fa2634-d1ba-4f08-9074-c58b027b5ea8)
  (paper "A4")
  (lib_symbols
    (symbol "Amplifier_Operational:TS912" (pin_names (offset 0.127)) (in_bom yes) (on_board yes)
      (property "Reference" "U" (id 0) (at 0 5.08 0)
        (effects (font (size 1.27 1.27)) (justify left))
      (property "Value" "TS912" (id 1) (at 0 -5.08 0)
      (property "Footprint" "" (id 2) (at 0 0 0)
        (effects (font (size 1.27 1.27)) hide)
      (property "Datasheet" "www.st.com/resource/en/datasheet/ts912.pdf" (id 3) (at 0 0 0)
      (property "ki_locked" "" (id 4) (at 0 0 0)
        (effects (font (size 1.27 1.27)))
      (property "ki_keywords" "dual opamp" (id 5) (at 0 0 0)
      (property "ki_description" "Dual Rail-to-rail CMOS Operational Amplifier, DIP-8/SOIC-8" (id 6) (at 0 0 0)
      (property "ki_fp_filters" "SOIC*3.9x4.9mm*P1.27mm* DIP*W7.62mm* TO*99* OnSemi*Micro8* TSSOP*3x3mm*P0.65mm* TSSOP*4.4x3mm*P0.65mm* MSOP*3x3mm*P0.65mm* SSOP*3.9x4.9mm*P0.635mm* LFCSP*2x2mm*P0.5mm* *SIP* SOIC*5.3x6.2mm*P1.27mm*" (id 7) (at 0 0 0)
      (symbol "TS912_1_1"
        (polyline
          (pts
            (xy -5.08 5.08)
            (xy 5.08 0)
            (xy -5.08 -5.08)
            (xy -5.08 5.08)
          (stroke (width 0.254) (type default) (color 0 0 0 0))
          (fill (type background))
        (pin output line (at 7.62 0 180) (length 2.54)
          (name "~" (effects (font (size 1.27 1.27))))
          (number "1" (effects (font (size 1.27 1.27))))
        (pin input line (at -7.62 -2.54 0) (length 2.54)
          (name "-" (effects (font (size 1.27 1.27))))
          (number "2" (effects (font (size 1.27 1.27))))
        (pin input line (at -7.62 2.54 0) (length 2.54)
          (name "+" (effects (font (size 1.27 1.27))))
          (number "3" (effects (font (size 1.27 1.27))))
      (symbol "TS912_2_1"
        (polyline
          (pts
            (xy -5.08 5.08)
            (xy 5.08 0)
            (xy -5.08 -5.08)
            (xy -5.08 5.08)
          (number "5" (effects (font (size 1.27 1.27))))
          (number "6" (effects (font (size 1.27 1.27))))
          (number "7" (effects (font (size 1.27 1.27))))
      (symbol "TS912_3_1"
        (pin power_in line (at -2.54 -7.62 90) (length 3.81)
          (name "V-" (effects (font (size 1.27 1.27))))
          (number "4" (effects (font (size 1.27 1.27))))
        (pin power_in line (at -2.54 7.62 270) (length 3.81)
          (name "V+" (effects (font (size 1.27 1.27))))
          (number "8" (effects (font (size 1.27 1.27))))
    (symbol "Device:R_Potentiometer" (pin_names (offset 1.016) hide) (in_bom yes) (on_board yes)
      (property "Reference" "RV" (id 0) (at -4.445 0 90)
      (property "Value" "R_Potentiometer" (id 1) (at -2.54 0 90)
      (property "Datasheet" "~" (id 3) (at 0 0 0)
      (property "ki_keywords" "resistor variable" (id 4) (at 0 0 0)
      (property "ki_description" "Potentiometer" (id 5) (at 0 0 0)
      (property "ki_fp_filters" "Potentiometer*" (id 6) (at 0 0 0)
      (symbol "R_Potentiometer_0_1"
        (polyline
          (pts
            (xy 2.54 0)
            (xy 1.524 0)
          (stroke (width 0) (type default) (color 0 0 0 0))
          (fill (type none))
        (polyline
          (pts
            (xy 1.143 0)
            (xy 2.286 0.508)
            (xy 2.286 -0.508)
            (xy 1.143 0)
          (fill (type outline))
        (rectangle (start 1.016 2.54) (end -1.016 -2.54)
          (fill (type none))
      (symbol "R_Potentiometer_1_1"
        (pin passive line (at 0 3.81 270) (length 1.27)
          (name "1" (effects (font (size 1.27 1.27))))
        (pin passive line (at 3.81 0 180) (length 1.27)
          (name "2" (effects (font (size 1.27 1.27))))
        (pin passive line (at 0 -3.81 90) (length 1.27)
          (name "3" (effects (font (size 1.27 1.27))))
    (symbol "Device:Thermistor_NTC" (pin_numbers hide) (pin_names (offset 0)) (in_bom yes) (on_board yes)
      (property "Reference" "TH" (id 0) (at -4.445 0 90)
      (property "Value" "Thermistor_NTC" (id 1) (at 3.175 0 90)
      (property "Footprint" "" (id 2) (at 0 1.27 0)
      (property "Datasheet" "~" (id 3) (at 0 1.27 0)
      (property "ki_keywords" "thermistor NTC resistor sensor RTD" (id 4) (at 0 0 0)
      (property "ki_description" "Temperature dependent resistor, negative temperature coefficient" (id 5) (at 0 0 0)
      (property "ki_fp_filters" "*NTC* *Thermistor* PIN?ARRAY* bornier* *Terminal?Block* R_*" (id 6) (at 0 0 0)
      (symbol "Thermistor_NTC_0_1"
        (arc (start -3.048 2.159) (mid -3.0495 2.3143) (end -3.175 2.413)
          (fill (type none))
        (arc (start -3.048 2.159) (mid -2.9736 1.9794) (end -2.794 1.905)
          (fill (type none))
        (arc (start -3.048 2.794) (mid -2.9736 2.6144) (end -2.794 2.54)
          (fill (type none))
        (arc (start -2.794 1.905) (mid -2.6144 1.9794) (end -2.54 2.159)
          (fill (type none))
        (arc (start -2.794 2.54) (mid -2.4393 2.5587) (end -2.159 2.794)
          (fill (type none))
        (arc (start -2.794 3.048) (mid -2.9736 2.9736) (end -3.048 2.794)
          (fill (type none))
        (arc (start -2.54 2.794) (mid -2.6144 2.9736) (end -2.794 3.048)
          (fill (type none))
        (rectangle (start -1.016 2.54) (end 1.016 -2.54)
          (fill (type none))
        (polyline
          (pts
            (xy -2.54 2.159)
            (xy -2.54 2.794)
          (fill (type none))
        (polyline
          (pts
            (xy -1.778 2.54)
            (xy -1.778 1.524)
            (xy 1.778 -1.524)
            (xy 1.778 -2.54)
          (fill (type none))
        (polyline
          (pts
            (xy -2.54 -3.683)
            (xy -2.54 -1.397)
            (xy -2.794 -2.159)
            (xy -2.286 -2.159)
            (xy -2.54 -1.397)
            (xy -2.54 -1.651)
        (polyline
          (pts
            (xy -1.778 -1.397)
            (xy -1.778 -3.683)
            (xy -2.032 -2.921)
            (xy -1.524 -2.921)
            (xy -1.778 -3.683)
            (xy -1.778 -3.429)
      (symbol "Thermistor_NTC_1_1"
    (symbol "power:+12V" (power) (pin_names (offset 0)) (in_bom yes) (on_board yes)
      (property "Reference" "#PWR" (id 0) (at 0 -3.81 0)
      (property "Value" "+12V" (id 1) (at 0 3.556 0)
      (property "Datasheet" "" (id 3) (at 0 0 0)
      (property "ki_keywords" "global power" (id 4) (at 0 0 0)
      (property "ki_description" "Power symbol creates a global label with name \"+12V\"" (id 5) (at 0 0 0)
      (symbol "+12V_0_1"
        (polyline
          (pts
            (xy -0.762 1.27)
            (xy 0 2.54)
          (fill (type none))
        (polyline
          (pts
            (xy 0 0)
            (xy 0 2.54)
          (fill (type none))
        (polyline
          (pts
            (xy 0 2.54)
            (xy 0.762 1.27)
          (fill (type none))
      (symbol "+12V_1_1"
        (pin power_in line (at 0 0 90) (length 0) hide
          (name "+12V" (effects (font (size 1.27 1.27))))
    (symbol "power:GND" (power) (pin_names (offset 0)) (in_bom yes) (on_board yes)
      (property "Reference" "#PWR" (id 0) (at 0 -6.35 0)
      (property "Value" "GND" (id 1) (at 0 -3.81 0)
      (property "ki_description" "Power symbol creates a global label with name \"GND\" , ground" (id 5) (at 0 0 0)
      (symbol "GND_0_1"
        (polyline
          (pts
            (xy 0 0)
            (xy 0 -1.27)
            (xy 1.27 -1.27)
            (xy 0 -2.54)
            (xy -1.27 -1.27)
            (xy 0 -1.27)
          (fill (type none))
      (symbol "GND_1_1"
        (pin power_in line (at 0 0 270) (length 0) hide
          (name "GND" (effects (font (size 1.27 1.27))))
  (junction (at 43.18 83.82) (diameter 0) (color 0 0 0 0)
    (uuid 05f4d20b-2693-446e-9ddc-542cab5f3065)
  (junction (at 91.44 66.04) (diameter 0) (color 0 0 0 0)
    (uuid 0e26c041-cd1c-4eeb-bf01-0ab09e59313e)
  (junction (at 72.39 68.58) (diameter 0) (color 0 0 0 0)
    (uuid 5259172f-295c-4060-8915-f7d03716b18b)
  (junction (at 43.18 46.99) (diameter 0) (color 0 0 0 0)
    (uuid 6ed51ef3-80f1-4b45-b75b-07ae80b36ad6)
  (junction (at 49.53 63.5) (diameter 0) (color 0 0 0 0)
    (uuid f31ecb57-dbe3-4abc-ba80-c82ac325ab3f)
  (no_connect (at 68.58 78.74) (uuid fae90a94-594e-4d5c-83b5-80a33df81ee4))
  (wire (pts (xy 43.18 41.91) (xy 43.18 46.99))
    (uuid 04aa0fb2-4827-4432-a4ea-373502e8f42f)
  (wire (pts (xy 49.53 63.5) (xy 73.66 63.5))
    (uuid 180a56dc-3f11-4cd6-84c2-ea0a1acebdce)
  (wire (pts (xy 49.53 46.99) (xy 43.18 46.99))
    (uuid 2c669883-15aa-48ce-85ec-8f28a8b50bb1)
  (wire (pts (xy 91.44 78.74) (xy 91.44 66.04))
    (uuid 30661340-bc71-4762-bcb7-4495e09054f0)
  (wire (pts (xy 49.53 81.28) (xy 49.53 83.82))
    (uuid 379c2586-798f-4576-8242-ac39293269e4)
  (wire (pts (xy 49.53 57.15) (xy 49.53 63.5))
    (uuid 37b18953-9014-4ded-8969-2369bf81160a)
  (wire (pts (xy 43.18 83.82) (xy 43.18 88.9))
    (uuid 3bca985a-38e9-4000-8449-657dcee4b3ba)
  (wire (pts (xy 35.56 83.82) (xy 35.56 72.39))
    (uuid 4cf76248-66af-427d-bfdb-75b5c3a6d0a8)
  (wire (pts (xy 35.56 46.99) (xy 35.56 64.77))
    (uuid 67e1128d-204e-4984-85db-52fb89f42425)
  (wire (pts (xy 91.44 66.04) (xy 100.33 66.04))
    (uuid 747621f2-bda3-4b13-a975-7a07f4a85c02)
  (wire (pts (xy 88.9 66.04) (xy 91.44 66.04))
    (uuid 82813a74-12fd-4668-ab32-118eb1ac041b)
  (wire (pts (xy 39.37 68.58) (xy 72.39 68.58))
    (uuid 88359f9d-013e-487c-a3f9-47ff008e924b)
  (wire (pts (xy 43.18 83.82) (xy 35.56 83.82))
    (uuid 8cbff944-de68-4aa8-bd4d-d07a4494ff98)
  (wire (pts (xy 49.53 83.82) (xy 43.18 83.82))
    (uuid 944dcdf2-136e-4b00-9550-b562cb618717)
  (wire (pts (xy 49.53 49.53) (xy 49.53 46.99))
    (uuid 9917a98c-1968-4d05-8868-8565a2a127cd)
  (wire (pts (xy 43.18 46.99) (xy 35.56 46.99))
    (uuid a9587e9b-a97e-4053-91ef-bd43da419a2f)
  (wire (pts (xy 72.39 68.58) (xy 72.39 74.93))
    (uuid b2b49ebc-8651-441a-8386-e5129ab177e9)
  (wire (pts (xy 72.39 68.58) (xy 73.66 68.58))
    (uuid eb56123d-3c8c-4b52-b639-33cddfe48cf0)
  (wire (pts (xy 49.53 63.5) (xy 49.53 73.66))
    (uuid ec4db59e-3703-47c2-bcde-f1cb5b66a2ce)
  (wire (pts (xy 76.2 78.74) (xy 91.44 78.74))
    (uuid f3b283fc-2dfc-4c1c-b3f1-09dea905c6d9)
  (text "Out" (at 102.87 67.31 0)
    (effects (font (size 1.27 1.27)) (justify left bottom))
    (uuid d847d1d9-2077-43d1-b7b5-174e957fbd60)
  (symbol (lib_id "Amplifier_Operational:TS912") (at 81.28 66.04 0) (unit 1)
    (in_bom yes) (on_board yes) (fields_autoplaced)
    (uuid 5ff0f023-cec0-4fd5-8744-e34fa795b44e)
    (property "Reference" "U1" (id 0) (at 81.28 55.88 0))
    (property "Value" "TS912" (id 1) (at 81.28 58.42 0))
    (property "Footprint" "" (id 2) (at 81.28 66.04 0)
    (property "Datasheet" "www.st.com/resource/en/datasheet/ts912.pdf" (id 3) (at 81.28 66.04 0)
    (pin "1" (uuid b496c067-0ff3-476b-b21f-43ea0a03823b))
    (pin "2" (uuid 416e3850-3502-4466-b515-509cb8bb2867))
    (pin "3" (uuid 491ac51e-50ac-4adf-964c-436c011e9ae0))
    (pin "5" (uuid 99220657-2090-4805-8b01-db04c1a73b8b))
    (pin "6" (uuid e6135ac5-2381-4f19-b92d-e72664ca6522))
    (pin "7" (uuid ca20690d-194d-4114-aaa0-4cb2e77a4ac0))
    (pin "4" (uuid b16e97f1-6ea0-48b9-8fbe-4338db2261e1))
    (pin "8" (uuid f1dc3db3-cd6b-4ee3-a0bb-9cf0717d5f7c))
  (symbol (lib_id "power:GND") (at 43.18 88.9 0) (unit 1)
    (uuid ad984810-6147-4d3d-ad0b-01d6dde35fe0)
    (property "Reference" "#PWR02" (id 0) (at 43.18 95.25 0)
    (property "Value" "GND" (id 1) (at 43.18 93.98 0))
    (property "Footprint" "" (id 2) (at 43.18 88.9 0)
    (property "Datasheet" "" (id 3) (at 43.18 88.9 0)
    (pin "1" (uuid 31b10535-6f2e-4767-8815-270137ff954f))
  (symbol (lib_id "Device:R_Potentiometer") (at 35.56 68.58 0) (unit 1)
    (uuid b6bfdb7e-9a07-4463-9f4e-15ce66f3e685)
    (property "Reference" "RV1" (id 0) (at 33.02 67.3099 0)
      (effects (font (size 1.27 1.27)) (justify right))
    (property "Value" "10k" (id 1) (at 33.02 69.8499 0)
    (property "Footprint" "" (id 2) (at 35.56 68.58 0)
    (property "Datasheet" "~" (id 3) (at 35.56 68.58 0)
    (pin "1" (uuid 7ac347e9-de5f-4866-8f7c-ea44b2bc64ca))
    (pin "2" (uuid fb70e9ec-1063-4730-865f-9037a37ec496))
    (pin "3" (uuid 46abae76-2954-46f6-8105-ca28e98a6129))
  (symbol (lib_id "power:+12V") (at 43.18 41.91 0) (unit 1)
    (uuid d2611114-fe0d-438d-9606-83a090a2162a)
    (property "Reference" "#PWR01" (id 0) (at 43.18 45.72 0)
    (property "Value" "+12V" (id 1) (at 43.18 36.83 0))
    (property "Footprint" "" (id 2) (at 43.18 41.91 0)
    (property "Datasheet" "" (id 3) (at 43.18 41.91 0)
    (pin "1" (uuid d01dfb24-8a16-4d1e-b243-b38199761068))
  (symbol (lib_id "Device:R_Potentiometer") (at 72.39 78.74 90) (unit 1)
    (uuid d8bec03a-d622-47ca-b965-e384529bf9e6)
    (property "Reference" "RV2" (id 0) (at 72.39 82.55 90))
    (property "Value" "100k" (id 1) (at 72.39 85.09 90))
    (property "Footprint" "" (id 2) (at 72.39 78.74 0)
    (property "Datasheet" "~" (id 3) (at 72.39 78.74 0)
    (pin "1" (uuid b72f7095-9561-46f7-a3c5-21b282db7d11))
    (pin "2" (uuid bec887de-0ae8-4e10-ab62-8ad32df69def))
    (pin "3" (uuid b418cf30-6032-4fde-a0f3-74e27c6f12fc))
  (symbol (lib_id "Device:Thermistor_NTC") (at 49.53 77.47 0) (unit 1)
    (uuid e04dd129-8744-43e3-b8ed-32288fbba258)
    (property "Reference" "TH2" (id 0) (at 52.07 76.5174 0)
    (property "Value" "NTC 10k" (id 1) (at 52.07 79.0574 0)
    (property "Footprint" "" (id 2) (at 49.53 76.2 0)
    (property "Datasheet" "~" (id 3) (at 49.53 76.2 0)
    (pin "1" (uuid 171d1f60-800b-4675-8d0d-d2672aa7f147))
    (pin "2" (uuid 0353518c-0ec9-4dba-a541-83061c5fed0d))
  (symbol (lib_id "Device:Thermistor_NTC") (at 49.53 53.34 0) (unit 1)
    (uuid fe36449d-59b8-47d7-8be1-6647d552e0d9)
    (property "Reference" "TH1" (id 0) (at 52.07 52.3874 0)
    (property "Value" "NTC 10k" (id 1) (at 52.07 54.9274 0)
    (property "Footprint" "" (id 2) (at 49.53 52.07 0)
    (property "Datasheet" "~" (id 3) (at 49.53 52.07 0)
    (pin "1" (uuid 72b7ec10-f4b0-48dd-93a2-6244c0d06ee8))
    (pin "2" (uuid 89cb7859-4100-4916-9790-9102026f2ce6))
  (sheet_instances
    (path "/" (page "1"))
  (symbol_instances
    (path "/d2611114-fe0d-438d-9606-83a090a2162a"
      (reference "#PWR01") (unit 1) (value "+12V") (footprint "")
    (path "/ad984810-6147-4d3d-ad0b-01d6dde35fe0"
      (reference "#PWR02") (unit 1) (value "GND") (footprint "")
    (path "/b6bfdb7e-9a07-4463-9f4e-15ce66f3e685"
      (reference "RV1") (unit 1) (value "10k") (footprint "")
    (path "/d8bec03a-d622-47ca-b965-e384529bf9e6"
      (reference "RV2") (unit 1) (value "100k") (footprint "")
    (path "/fe36449d-59b8-47d7-8be1-6647d552e0d9"
      (reference "TH1") (unit 1) (value "NTC 10k") (footprint "")
    (path "/e04dd129-8744-43e3-b8ed-32288fbba258"
      (reference "TH2") (unit 1) (value "NTC 10k") (footprint "")
    (path "/5ff0f023-cec0-4fd5-8744-e34fa795b44e"
      (reference "U1") (unit 1) (value "TS912") (footprint "")
