>D ;start, define variables cnt=1 timer=1 w_new=0 w_corr=0 w_delta=0 p:w_last=0 >B ;setup sensor ->sensor53 r >T w_new=WAERME#w_total >S timer=int(time) if chg[timer]>0 then switch timer case 0 print It is midnight print wakeup start sml(-1 1 "2400:8N1") for cnt 1 72 1 sml(1 1 "55555555555555555555") next print wakeup end print wait for the meter delay(350) sml(-1 1 "2400:8E1") print request data sml(1 1 "105BFE5916") case 1 print It is a minute after midnight print calculating daily value print w_last %0w_last% w_delta=w_new-w_last w_corr=w_new ;Plausibilitaetstest if w_delta>100000 or w_delta<9 then if w_last>10 then w_corr=w_last endif w_delta=0 endif w_last=w_corr svars print w_new %0w_new% print w_delta %0w_delta% print w_corr %0w_corr% ends endif >J ,"w_delta":%w_delta%,"w_corr":%w_corr%,"w_last":%w_last% >W =============== Waerme corr : {m} %3w_corr% KWh Waerme last : {m} %3w_last% KWh Vortagsverbrauch: {m} %3w_delta% KWh >M 1 +1,3,rE1,0,2400,WAERME,1 1,0C06bcd8@1,Total Energy,kWh,w_total,0 1,0C13bcd8@1000,Total volume,m³,v_total,2 1,0C2Bbcd8@1,Current power,W,p_act,0 1,0B3Bbcd6@1000,Current flow,m³/h,F_akt,3 1,0A5Abcd4@10,Flow temp,°C,t_flow,1 1,0A5Ebcd4@10,Return temp,°C,t_return,1 1,0A62bcd4@10,Temp diff,°C,t_diff,2 #
