// // DCC_Decoder.h - Arduino library for NMRA DCC Decoding. // Written by Kevin Snow, MynaBay.com, November, 2011. // Questions: dcc@mynabay.com // Released into the public domain. // #ifndef __DCC_DECODER_H__ #define __DCC_DECODER_H__ #include "Arduino.h" /////////////////////////////////////////////////////////////////////////////////////// #define kDCC_STOP_SPEED 0xFE #define kDCC_ESTOP_SPEED 0xFF // Multifunction Decoders #define kCV_PrimaryAddress 1 #define kCV_Vstart 2 #define kCV_AccelerationRate 3 #define kCV_Deceleration Rate 4 #define kCV_ManufacturerVersionNo 7 #define kCV_ManufacturedID 8 #define kCV_ExtendedAddress1 17 #define kCV_ExtendedAddress2 18 #define kCV_ConfigurationData1 29 // Accessory Decoders #define kCV_AddressLSB 1 #define kCV_AddressMSB 9 // DCC_Decoder results/errors #define kDCC_OK 0 #define kDCC_OK_UNHANDLED 1 #define kDCC_OK_BOOT 2 #define kDCC_OK_IDLE 3 #define kDCC_OK_RESET 4 #define kDCC_OK_RAW 5 #define kDCC_OK_BASELINE 6 #define kDCC_OK_BASIC_ACCESSORY 7 #define kDCC_OK_EXTENDED_ACCESSORY 8 #define kDCC_OK_MAX 99 #define kDCC_ERR_DETECTION_FAILED 100 #define kDCC_ERR_BASELINE_ADDR 101 #define kDCC_ERR_BASELINE_INSTR 102 // Baseline packet instruction isn't 0x01DCSSSS #define kDCC_ERR_MISSED_BITS 103 #define kDCC_ERR_NOT_0_OR_1 104 #define kDCC_ERR_INVALID_LENGTH 105 #define kDCC_ERR_MISSING_END_BIT 106 // Min and max valid packet lengths #define kPACKET_LEN_MIN 3 #define kPACKET_LEN_MAX 6 // CV 1..256 are supported #define kCV_MAX 257 /////////////////////////////////////////////////////////////////////////////////////// typedef boolean (*RawPacket)(byte byteCount, byte* packetBytes); typedef void (*IdleResetPacket)(byte byteCount, byte* packetBytes); typedef void (*BaselineControlPacket)(int address, int speed, int direction); typedef void (*BasicAccDecoderPacket)(int address, boolean activate, byte data); typedef void (*ExtendedAccDecoderPacket)(int address, byte data); typedef void (*DecodingEngineCompletion)(byte resultOfLastPacket); /////////////////////////////////////////////////////////////////////////////////////// typedef void(*StateFunc)(); /////////////////////////////////////////////////////////////////////////////////////// class DCC_Decoder { public: DCC_Decoder(); // Called from setup in Arduino Sketch. Set mfgID, mfgVers and interrupt. Call one SetupXXX void SetupDecoder(byte mfgID, byte mfgVers, byte interrupt); // Used for Decoder void SetupMonitor(byte interrupt); // Used when building a monitor // All packets are sent to RawPacketHandler. Return true to stop dispatching to other handlers. void SetRawPacketHandler(RawPacket func); // S 9.2 defines two special packets. Idle and reset. void SetIdlePacketHandler(IdleResetPacket func); void SetResetPacketHandler(IdleResetPacket func); // Handler for S 9.2 baseline packets. Speed value will be 1-14, 1-28, kDCC_STOP_SPEED or kDCC_ESTOP_SPEED void SetBaselineControlPacketHandler(BaselineControlPacket func, boolean allPackets); // Handler for RP 9.2.1 Accessory Decoders. void SetBasicAccessoryDecoderPacketHandler(BasicAccDecoderPacket func, boolean allPackets); void SetExtendedAccessoryDecoderPacketHandler(ExtendedAccDecoderPacket func, boolean allPackets); // Read/Write CVs byte ReadCV(int cv); void WriteCV(int cv, byte data); // Helper function to read decoder address int Address(); // Call at least once from mainloop. Not calling frequently enough and library will miss data bits! void loop(); // Returns the packet data in string form. char* MakePacketString(char* buffer60Bytes, byte packetByteCount, byte* packet); // Returns the number of bits in last preamble int LastPreambleBitCount(); // Timing functions. These return MS since various packets unsigned long MillisecondsSinceLastValidPacket(); unsigned long MillisecondsSinceLastPacketToThisDecoder(); unsigned long MillisecondsSinceLastIdlePacket(); unsigned long MillisecondsSinceLastResetPacket(); //======================= Debugging =======================// // Everytime the DCC Decoder engine starts looking for preamble bits this will be // called with result of last packet. (Debugging) void SetDecodingEngineCompletionStatusHandler(DecodingEngineCompletion func); // Converts code passed into completionStatusHandler to human readable string. const char PROGMEM* ResultString(byte resultCode); //======================= Library Internals =======================// private: // State machine functions static void State_Boot(); static void State_ReadPreamble(); static void State_ReadPacket(); static void State_Execute(); static void State_Reset(); // Function pointers for the library callbacks static RawPacket func_RawPacket; static IdleResetPacket func_IdlePacket; static IdleResetPacket func_ResetPacket; static BasicAccDecoderPacket func_BasicAccPacket; static boolean func_BasicAccPacket_All_Packets; static ExtendedAccDecoderPacket func_ExtdAccPacket; static boolean func_ExtdAccPacket_All_Packets; static BaselineControlPacket func_BaselineControlPacket; static boolean func_BaselineControlPacket_All_Packets; static DecodingEngineCompletion func_DecodingEngineCompletion; // Current state function pointer static StateFunc gState; // Current state function pointer // Timing data from last interrupt static unsigned int gLastChaos; // Interrupt chaos count we processed // Preamble bit count static int gPreambleCount; // Bit count for reading preamble // Reset reason static byte gResetReason; // Result code of last reason decoder was reset static boolean gHandledAsRawPacket; // Packet data static byte gPacket[kPACKET_LEN_MAX]; // The packet data. static byte gPacketIndex; // Byte index to write to. static byte gPacketMask; // Bit index to write to. 0x80,0x40,0x20,...0x01 static boolean gPacketEndedWith1; // Set true if packet ended on 1. Spec requires that the // packet end bit can count as a bit in next preamble. // CV Storage static byte gCV[kCV_MAX]; // CV Storage (TODO - Storage in PROGMEM) // Packet arrival timing static unsigned long gThisPacketMS; // Milliseconds of this packet being parsed static boolean gLastPacketToThisAddress; // Was last pack processed to this decoder's address? static unsigned long gLastValidPacketMS; // Milliseconds of last valid packet static unsigned long gLastValidPacketToAddressMS; // Milliseconds of last valid packet to this decoder static unsigned long gLastValidIdlePacketMS; // Milliseconds of last valid idle packet static unsigned long gLastValidResetPacketMS; // Milliseconds of last valid reset packet ////////////////////////////////////////////////////// // Interrupt Support static void StartInterrupt(byte interrupt); static void DCC_Interrupt(); static void ShiftInterruptAlignment(); static unsigned long gInterruptMicros; static byte gInterruptTimeIndex; static volatile unsigned int gInterruptTime[2]; static volatile unsigned int gInterruptChaos; }; /////////////////////////////////////////////////////////////////////////////////////// extern DCC_Decoder DCC; /////////////////////////////////////////////////////////////////////////////////////// #endif
