Platformui.ini [env:esp12e] platform = espressif8266 board = esp12e upload_port = COM[6] framework = arduino lib_deps = paulstoffregen/OneWire@^2.3.8 milesburton/DallasTemperature@^3.11.0 Uploading .pio\build\esp12e\firmware.bin esptool.py v3.0 Serial port COM6 Traceback (most recent call last): File "C:\Users\OtisToshiba\.platformio\packages\tool-esptoolpy@1.30000.201119\esptool.py", line 3969, in _main() File "C:\Users\OtisToshiba\.platformio\packages\tool-esptoolpy@1.30000.201119\esptool.py", line 3962, in _main main() File "C:\Users\OtisToshiba\.platformio\packages\tool-esptoolpy@1.30000.201119\esptool.py", line 3551, in main esp = chip_class(each_port, initial_baud, args.trace) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\OtisToshiba\.platformio\packages\tool-esptoolpy@1.30000.201119\esptool.py", line 271, in __init__ self._port = serial.serial_for_url(port) ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\OtisToshiba\.platformio\penv\Lib\site-packages\serial\__init__.py", line 90, in serial_for_url instance.open() File "C:\Users\OtisToshiba\.platformio\penv\Lib\site-packages\serial\serialwin32.py", line 64, in open raise SerialException("could not open port {!r}: {!r}".format(self.portstr, ctypes.WinError())) serial.serialutil.SerialException: could not open port 'COM6': PermissionError(13, 'Zugriff verweigert', None, 5) *** [upload] Error 1 ========================================================================================== [FAILED] Took 9.94 seconds ========================================================================================== * The terminal process "C:\Users\OtisToshiba\.platformio\penv\Scripts\platformio.exe 'run', '--target', 'upload'" terminated with exit code: 1. * Terminal will be reused by tasks, press any key to close it. Platformui.ini [env:nodemcu] platform = espressif8266 board = nodemcu framework = arduino lib_deps = paulstoffregen/OneWire@^2.3.8 milesburton/DallasTemperature@^3.11.0 Looking for upload port... Auto-detected: COM6 Uploading .pio\build\nodemcu\firmware.bin esptool.py v3.0 Serial port COM6 Traceback (most recent call last): File "C:\Users\OtisToshiba\.platformio\packages\tool-esptoolpy@1.30000.201119\esptool.py", line 3969, in _main() File "C:\Users\OtisToshiba\.platformio\packages\tool-esptoolpy@1.30000.201119\esptool.py", line 3962, in _main main() File "C:\Users\OtisToshiba\.platformio\packages\tool-esptoolpy@1.30000.201119\esptool.py", line 3551, in main esp = chip_class(each_port, initial_baud, args.trace) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\OtisToshiba\.platformio\packages\tool-esptoolpy@1.30000.201119\esptool.py", line 271, in __init__ self._port = serial.serial_for_url(port) ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\OtisToshiba\.platformio\penv\Lib\site-packages\serial\__init__.py", line 90, in serial_for_url instance.open() File "C:\Users\OtisToshiba\.platformio\penv\Lib\site-packages\serial\serialwin32.py", line 64, in open raise SerialException("could not open port {!r}: {!r}".format(self.portstr, ctypes.WinError())) serial.serialutil.SerialException: could not open port 'COM6': PermissionError(13, 'Zugriff verweigert', None, 5) *** [upload] Error 1 ARDUINO IDE . Variables and constants in RAM (global, static), used 28552 / 80192 bytes (35%) ║ SEGMENT BYTES DESCRIPTION ╠══ DATA 1516 initialized variables ╠══ RODATA 1164 constants ╚══ BSS 25872 zeroed variables . Instruction RAM (IRAM_ATTR, ICACHE_RAM_ATTR), used 60267 / 65536 bytes (91%) ║ SEGMENT BYTES DESCRIPTION ╠══ ICACHE 32768 reserved space for flash instruction cache ╚══ IRAM 27499 code in IRAM . Code in flash (default, ICACHE_FLASH_ATTR), used 241108 / 1048576 bytes (22%) ║ SEGMENT BYTES DESCRIPTION ╚══ IROM 241108 code in flash esptool.py v3.0 Serial port COM6 Connecting........_ Chip is ESP8266EX Features: WiFi Crystal is 26MHz MAC: b4:e6:2d:45:60:bc Uploading stub... Running stub... Stub running... Configuring flash size... Auto-detected Flash size: 4MB Compressed 275440 bytes to 202296... Writing at 0x00000000... (7 %) Writing at 0x00004000... (15 %) Writing at 0x00008000... (23 %) Writing at 0x0000c000... (30 %) Writing at 0x00010000... (38 %) Writing at 0x00014000... (46 %) Writing at 0x00018000... (53 %) Writing at 0x0001c000... (61 %) Writing at 0x00020000... (69 %) Writing at 0x00024000... (76 %) Writing at 0x00028000... (84 %) Writing at 0x0002c000... (92 %) Writing at 0x00030000... (100 %) Wrote 275440 bytes (202296 compressed) at 0x00000000 in 18.0 seconds (effective 122.1 kbit/s)... Hash of data verified. Leaving... Hard resetting via RTS pin...
