* Executing task in folder GPIO: C:\Users\OtisToshiba\.platformio\penv\Scripts\platformio.exe run Processing nodemcu (platform: espressif8266; board: nodemcu; framework: arduino) ----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/nodemcu.html PLATFORM: Espressif 8266 (4.2.1) > NodeMCU 0.9 (ESP-12 Module) HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash PACKAGES: - framework-arduinoespressif8266 @ 3.30102.0 (3.1.2) - tool-esptool @ 1.413.0 (4.13) - tool-esptoolpy @ 1.30000.201119 (3.0.0) - toolchain-xtensa @ 2.100300.220621 (10.3.0) LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf LDF Modes: Finder ~ chain, Compatibility ~ soft Found 38 compatible libraries Scanning dependencies... No dependencies Building in release mode Linking .pio\build\nodemcu\firmware.elf c:/users/otistoshiba/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld.exe: .pio\build\nodemcu\src\main.cpp.o:(.text.setup+0x4): undefined reference to `_ZN8GPIO_Pin2OnEh' collect2.exe: error: ld returned 1 exit status *** [.pio\build\nodemcu\firmware.elf] Error 1
