nort@nort-laptop:~$ cd Treiber/ nort@nort-laptop:~/Treiber$ ls hello.c Makefile Makefile~ mod1.c nort@nort-laptop:~/Treiber$ make make -C /usr/local/carmeva/sw/linux/prepare.kernel/linux-2.6.15 SUBDIRS=/home/nort/Treiber modules make[1]: Betrete Verzeichnis '/usr/local/carmeva/sw/linux/prepare.kernel/linux-2.6.15' CC [M] /home/nort/Treiber/hello.o In file included from include/asm/hardirq.h:7, from include/linux/hardirq.h:7, from include/linux/interrupt.h:11, from include/linux/rcuref.h:36, from include/linux/fs.h:12, from /home/nort/Treiber/hello.c:1: include/asm/irq.h:4:27: asm/arch/irqs.h: No such file or directory In file included from include/linux/sched.h:4, from include/linux/interrupt.h:12, from include/linux/rcuref.h:36, from include/linux/fs.h:12, from /home/nort/Treiber/hello.c:1: include/asm/param.h:14:61: asm/arch/param.h: No such file or directory In file included from include/linux/timex.h:61, from include/linux/sched.h:11, from include/linux/interrupt.h:12, from include/linux/rcuref.h:36, from include/linux/fs.h:12, from /home/nort/Treiber/hello.c:1: include/asm/timex.h:15:28: asm/arch/timex.h: No such file or directory In file included from include/linux/sched.h:12, from include/linux/interrupt.h:12, from include/linux/rcuref.h:36, from include/linux/fs.h:12, from /home/nort/Treiber/hello.c:1: include/linux/jiffies.h:213:31: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:213:31: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:213:31: division by zero in #if include/linux/jiffies.h:213:31: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:213:31: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:213:31: division by zero in #if include/linux/jiffies.h:213:31: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:213:31: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:213:31: division by zero in #if include/linux/jiffies.h:213:31: division by zero in #if include/linux/jiffies.h:213:31: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:213:31: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:213:31: division by zero in #if include/linux/jiffies.h:213:31: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:213:31: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:213:31: division by zero in #if include/linux/jiffies.h:213:31: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:213:31: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:213:31: division by zero in #if include/linux/jiffies.h:213:31: division by zero in #if include/linux/jiffies.h:213:31: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:213:31: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:213:31: division by zero in #if include/linux/jiffies.h:213:31: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:213:31: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:213:31: division by zero in #if include/linux/jiffies.h:213:31: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:213:31: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:213:31: division by zero in #if include/linux/jiffies.h:213:31: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:213:31: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:213:31: division by zero in #if include/linux/jiffies.h:213:31: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:213:31: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:213:31: division by zero in #if include/linux/jiffies.h:213:31: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:213:31: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:213:31: division by zero in #if include/linux/jiffies.h:213:31: division by zero in #if In file included from include/linux/sched.h:12, from include/linux/interrupt.h:12, from include/linux/rcuref.h:36, from include/linux/fs.h:12, from /home/nort/Treiber/hello.c:1: include/linux/jiffies.h: In function `timespec_to_jiffies': include/linux/jiffies.h:318: error: `CLOCK_TICK_RATE' undeclared (first use in this function) include/linux/jiffies.h:318: error: (Each undeclared identifier is reported only once include/linux/jiffies.h:318: error: for each function it appears in.) include/linux/jiffies.h: In function `jiffies_to_timespec': include/linux/jiffies.h:337: error: `CLOCK_TICK_RATE' undeclared (first use in this function) include/linux/jiffies.h: In function `timeval_to_jiffies': include/linux/jiffies.h:359: error: `CLOCK_TICK_RATE' undeclared (first use in this function) include/linux/jiffies.h: In function `jiffies_to_timeval': include/linux/jiffies.h:375: error: `CLOCK_TICK_RATE' undeclared (first use in this function) include/linux/jiffies.h:385:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:385:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:385:6: division by zero in #if include/linux/jiffies.h:385:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:385:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:385:6: division by zero in #if include/linux/jiffies.h:385:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:385:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:385:6: division by zero in #if include/linux/jiffies.h:385:6: division by zero in #if include/linux/jiffies.h:385:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:385:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:385:6: division by zero in #if include/linux/jiffies.h:385:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:385:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:385:6: division by zero in #if include/linux/jiffies.h:385:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:385:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:385:6: division by zero in #if include/linux/jiffies.h:385:6: division by zero in #if include/linux/jiffies.h:385:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:385:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:385:6: division by zero in #if include/linux/jiffies.h:385:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:385:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:385:6: division by zero in #if include/linux/jiffies.h:385:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:385:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:385:6: division by zero in #if include/linux/jiffies.h:385:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:385:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:385:6: division by zero in #if include/linux/jiffies.h:385:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:385:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:385:6: division by zero in #if include/linux/jiffies.h:385:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:385:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:385:6: division by zero in #if include/linux/jiffies.h:385:6: division by zero in #if include/linux/jiffies.h:416:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:416:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:416:6: division by zero in #if include/linux/jiffies.h:416:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:416:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:416:6: division by zero in #if include/linux/jiffies.h:416:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:416:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:416:6: division by zero in #if include/linux/jiffies.h:416:6: division by zero in #if include/linux/jiffies.h:416:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:416:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:416:6: division by zero in #if include/linux/jiffies.h:416:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:416:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:416:6: division by zero in #if include/linux/jiffies.h:416:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:416:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:416:6: division by zero in #if include/linux/jiffies.h:416:6: division by zero in #if include/linux/jiffies.h:416:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:416:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:416:6: division by zero in #if include/linux/jiffies.h:416:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:416:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:416:6: division by zero in #if include/linux/jiffies.h:416:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:416:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:416:6: division by zero in #if include/linux/jiffies.h:416:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:416:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:416:6: division by zero in #if include/linux/jiffies.h:416:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:416:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:416:6: division by zero in #if include/linux/jiffies.h:416:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:416:6: warning: "CLOCK_TICK_RATE" is not defined include/linux/jiffies.h:416:6: division by zero in #if include/linux/jiffies.h:416:6: division by zero in #if In file included from include/asm/page.h:166, from include/linux/sched.h:21, from include/linux/interrupt.h:12, from include/linux/rcuref.h:36, from include/linux/fs.h:12, from /home/nort/Treiber/hello.c:1: include/asm/memory.h:27:29: asm/arch/memory.h: No such file or directory In file included from include/asm/page.h:166, from include/linux/sched.h:21, from include/linux/interrupt.h:12, from include/linux/rcuref.h:36, from include/linux/fs.h:12, from /home/nort/Treiber/hello.c:1: include/asm/memory.h: In function `virt_to_phys': include/asm/memory.h:112: error: `PHYS_OFFSET' undeclared (first use in this function) include/asm/memory.h: In function `phys_to_virt': include/asm/memory.h:117: error: `PHYS_OFFSET' undeclared (first use in this function) include/asm/memory.h: In function `virt_to_bus': include/asm/memory.h:135: warning: implicit declaration of function `__virt_to_bus' include/asm/memory.h: In function `bus_to_virt': include/asm/memory.h:140: warning: implicit declaration of function `__bus_to_virt' make[2]: *** [/home/nort/Treiber/hello.o] Fehler 1 make[1]: *** [_module_/home/nort/Treiber] Fehler 2 make[1]: Verlasse Verzeichnis '/usr/local/carmeva/sw/linux/prepare.kernel/linux-2.6.15' make: *** [default] Fehler 2 nort@nort-laptop:~/Treiber$ nort@nort-laptop:~/Treiber$
