Place & Route TRACE Report
Lattice TRACE Report - Setup, Version ispLever_v72_PROD_Build (44)
Wed Dec 02 16:18:53 2009
Copyright (c) 1991-1994 by NeoCAD Inc. All rights reserved.
Copyright (c) 1995 AT&T Corp. All rights reserved.
Copyright (c) 1995-2001 Lucent Technologies Inc. All rights reserved.
Copyright (c) 2001 Agere Systems All rights reserved.
Copyright (c) 2002-2008 Lattice Semiconductor Corporation, All rights reserved.
Report Information
Command line: trce.exe -v 1 -o receiver_dpram.twr receiver_dpram.ncd receiver_dpram.prf
Design file: receiver_dpram.ncd
Preference file: receiver_dpram.prf
Device,speed: LCMXO2280C,3
Report level: verbose report, limited to 1 item per preference
Preference Summary
FREQUENCY PORT "RXC" 80.000000 MHz (0 errors) 1011 items scored, 0 timing errors detected.
BLOCK ASYNCPATHS
BLOCK RESETPATHS
Preference: FREQUENCY PORT "RXC" 80.000000 MHz ;
Passed: The following path meets requirements by 1.005ns
Logical Details: Cell type Pin type Cell/ASIC name (clock net +/-)
Source: FF Q RECEIVE_CONTROL/rd_adr_i_3 (from RXC_c -)
Destination: FF Unknown RAM_B/mem_0_0/RAM1 (to RXC_c +)
Delay: 4.577ns (21.5% logic, 78.5% route), 2 logic levels.
Constraint Details:
4.577ns physical path delay RECEIVE_CONTROL/SLICE_7 to RAM_B/mem_0_0/SLICE_24 meets
6.250ns delay constraint less
0.000ns skew and
0.668ns WAD_SET requirement (totaling 5.582ns) by 1.005ns
Physical Path Details:
Name Fanout Delay (ns) Site Resource
REG_DEL --- 0.613 R13C11B.CLK to R13C11B.Q1 RECEIVE_CONTROL/SLICE_7 (from RXC_c)
ROUTE 3 1.108 R13C11B.Q1 to R13C10D.B1 RECEIVE_CONTROL/rd_adr_i_3
CTOF_DEL --- 0.371 R13C10D.B1 to R13C10D.F1 RECEIVE_CONTROL/SLICE_63
ROUTE 8 2.485 R13C10D.F1 to R11C10B.D1 RECEIVE_CONTROL_N_180_i (to RXC_c)
4.577 (21.5% logic, 78.5% route), 2 logic levels.
Clock Skew Details:
Source Clock:
Delay Connection
4.968ns 55.PADDI to R13C11B.CLK
Destination Clock :
Delay Connection
4.968ns 55.PADDI to R11C10B.CLK2
Report: 95.329MHz is the maximum frequency for this preference.
Report Summary
Preference | Constraint| Actual|Levels
FREQUENCY PORT "RXC" 80.000000 MHz ; | 80.000 MHz| 95.329 MHz| 2
All preferences were met.
Clock Domains Analysis
Found 1 clocks:
Clock Domain: RXC_c Source: RXC.PAD Loads: 45
Covered under: FREQUENCY PORT "RXC" 80.000000 MHz ;
Timing summary:
Timing errors: 0 Score: 0
Cumulative negative slack: 0
Constraints cover 1011 paths, 1 nets, and 460 connections (77.1% coverage)
Generated from the file 'C:\ispTOOLS7_2_STRT\work\i2s_ip_25_receiver_v2\receiver_dpram.twr'
