/* * SPDX-FileCopyrightText: 2020-2023 Espressif Systems (Shanghai) CO LTD * * SPDX-License-Identifier: Apache-2.0 */ /******************************************************************************* * NOTICE * The hal is not public api, don't use in application code. * See readme.md in soc/include/hal/readme.md ******************************************************************************/ // The LL layer for SPI register operations #pragma once #include //for abs() #include #include "esp_attr.h" #include "esp_types.h" #include "soc/spi_periph.h" #include "soc/spi_struct.h" #include "soc/system_struct.h" #include "soc/lldesc.h" #include "hal/assert.h" #include "hal/misc.h" #include "hal/spi_types.h" #ifdef __cplusplus extern "C" { #endif /// Interrupt not used. Don't use in app. #define SPI_LL_UNUSED_INT_MASK (SPI_TRANS_DONE_INT_ENA | SPI_SLV_WR_DMA_DONE_INT_ENA | SPI_SLV_RD_DMA_DONE_INT_ENA | SPI_SLV_WR_BUF_DONE_INT_ENA | SPI_SLV_RD_BUF_DONE_INT_ENA) /// These 2 masks together will set SPI transaction to one line mode #define SPI_LL_ONE_LINE_CTRL_MASK (SPI_FREAD_QUAD | SPI_FREAD_DUAL | SPI_FCMD_QUAD | SPI_FCMD_DUAL | SPI_FADDR_QUAD | SPI_FADDR_DUAL) #define SPI_LL_ONE_LINE_USER_MASK (SPI_FWRITE_QUAD | SPI_FWRITE_DUAL) /// Swap the bit order to its correct place to send #define HAL_SPI_SWAP_DATA_TX(data, len) HAL_SWAP32((uint32_t)(data) << (32 - len)) #define SPI_LL_GET_HW(ID) (((ID)==1) ? &GPSPI2 : NULL) #define SPI_LL_DMA_MAX_BIT_LEN (1 << 18) //reg len: 18 bits #define SPI_LL_CPU_MAX_BIT_LEN (16 * 32) //Fifo len: 16 words #define SPI_LL_MOSI_FREE_LEVEL 1 //Default level after bus initialized /** * The data structure holding calculated clock configuration. Since the * calculation needs long time, it should be calculated during initialization and * stored somewhere to be quickly used. */ typedef uint32_t spi_ll_clock_val_t; typedef spi_dev_t spi_dma_dev_t; // Type definition of all supported interrupts typedef enum { SPI_LL_INTR_TRANS_DONE = BIT(0), ///< A transaction has done SPI_LL_INTR_RDBUF = BIT(6), ///< Has received RDBUF command. Only available in slave HD. SPI_LL_INTR_WRBUF = BIT(7), ///< Has received WRBUF command. Only available in slave HD. SPI_LL_INTR_RDDMA = BIT(8), ///< Has received RDDMA command. Only available in slave HD. SPI_LL_INTR_WRDMA = BIT(9), ///< Has received WRDMA command. Only available in slave HD. SPI_LL_INTR_CMD7 = BIT(10), ///< Has received CMD7 command. Only available in slave HD. SPI_LL_INTR_CMD8 = BIT(11), ///< Has received CMD8 command. Only available in slave HD. SPI_LL_INTR_CMD9 = BIT(12), ///< Has received CMD9 command. Only available in slave HD. SPI_LL_INTR_CMDA = BIT(13), ///< Has received CMDA command. Only available in slave HD. SPI_LL_INTR_SEG_DONE = BIT(14), } spi_ll_intr_t; // Flags for conditions under which the transaction length should be recorded typedef enum { SPI_LL_TRANS_LEN_COND_WRBUF = BIT(0), ///< WRBUF length will be recorded SPI_LL_TRANS_LEN_COND_RDBUF = BIT(1), ///< RDBUF length will be recorded SPI_LL_TRANS_LEN_COND_WRDMA = BIT(2), ///< WRDMA length will be recorded SPI_LL_TRANS_LEN_COND_RDDMA = BIT(3), ///< RDDMA length will be recorded } spi_ll_trans_len_cond_t; // SPI base command in esp32c3 typedef enum { /* Slave HD Only */ SPI_LL_BASE_CMD_HD_WRBUF = 0x01, SPI_LL_BASE_CMD_HD_RDBUF = 0x02, SPI_LL_BASE_CMD_HD_WRDMA = 0x03, SPI_LL_BASE_CMD_HD_RDDMA = 0x04, SPI_LL_BASE_CMD_HD_SEG_END = 0x05, SPI_LL_BASE_CMD_HD_EN_QPI = 0x06, SPI_LL_BASE_CMD_HD_WR_END = 0x07, SPI_LL_BASE_CMD_HD_INT0 = 0x08, SPI_LL_BASE_CMD_HD_INT1 = 0x09, SPI_LL_BASE_CMD_HD_INT2 = 0x0A, } spi_ll_base_command_t; /*------------------------------------------------------------------------------ * Control *----------------------------------------------------------------------------*/ /** * Enable peripheral register clock * * @param host_id Peripheral index number, see `spi_host_device_t` * @param enable Enable/Disable */ static inline void spi_ll_enable_bus_clock(spi_host_device_t host_id, bool enable) { switch (host_id) { case SPI1_HOST: SYSTEM.perip_clk_en0.reg_spi01_clk_en = enable; break; case SPI2_HOST: SYSTEM.perip_clk_en0.reg_spi2_clk_en = enable; break; default: HAL_ASSERT(false); } } /// use a macro to wrap the function, force the caller to use it in a critical section /// the critical section needs to declare the __DECLARE_RCC_ATOMIC_ENV variable in advance #define spi_ll_enable_bus_clock(...) (void)__DECLARE_RCC_ATOMIC_ENV; spi_ll_enable_bus_clock(__VA_ARGS__) /** * Reset whole peripheral register to init value defined by HW design * * @param host_id Peripheral index number, see `spi_host_device_t` */ static inline void spi_ll_reset_register(spi_host_device_t host_id) { switch (host_id) { case SPI1_HOST: SYSTEM.perip_rst_en0.reg_spi01_rst = 1; SYSTEM.perip_rst_en0.reg_spi01_rst = 0; break; case SPI2_HOST: SYSTEM.perip_rst_en0.reg_spi2_rst = 1; SYSTEM.perip_rst_en0.reg_spi2_rst = 0; break; default: HAL_ASSERT(false); } } /// use a macro to wrap the function, force the caller to use it in a critical section /// the critical section needs to declare the __DECLARE_RCC_ATOMIC_ENV variable in advance #define spi_ll_reset_register(...) (void)__DECLARE_RCC_ATOMIC_ENV; spi_ll_reset_register(__VA_ARGS__) /** * Enable functional output clock within peripheral * * @param host_id Peripheral index number, see `spi_host_device_t` * @param enable Enable/Disable */ static inline void spi_ll_enable_clock(spi_host_device_t host_id, bool enable) { spi_dev_t *hw = SPI_LL_GET_HW(host_id); HAL_ASSERT(hw != NULL); hw->clk_gate.clk_en = enable; } /** * Select SPI peripheral clock source (master). * * @param hw Beginning address of the peripheral registers. * @param clk_source clock source to select, see valid sources in type `spi_clock_source_t` */ __attribute__((always_inline)) static inline void spi_ll_set_clk_source(spi_dev_t *hw, spi_clock_source_t clk_source){ switch (clk_source) { case SPI_CLK_SRC_XTAL: hw->clk_gate.mst_clk_sel = 0; break; default: hw->clk_gate.mst_clk_sel = 1; break; } } /** * Initialize SPI peripheral (master). * * @param hw Beginning address of the peripheral registers. */ static inline void spi_ll_master_init(spi_dev_t *hw) { //Reset timing hw->user1.cs_setup_time = 0; hw->user1.cs_hold_time = 0; //use all 64 bytes of the buffer hw->user.usr_miso_highpart = 0; hw->user.usr_mosi_highpart = 0; //Disable unneeded ints hw->slave.val = 0; hw->user.val = 0; hw->clk_gate.mst_clk_active = 1; hw->clk_gate.mst_clk_sel = 1; hw->dma_conf.val = 0; hw->dma_conf.tx_seg_trans_clr_en = 1; hw->dma_conf.rx_seg_trans_clr_en = 1; hw->dma_conf.dma_seg_trans_en = 0; } /** * Initialize SPI peripheral (slave). * * @param hw Beginning address of the peripheral registers. */ static inline void spi_ll_slave_init(spi_dev_t *hw) { //Configure slave hw->clock.val = 0; hw->user.val = 0; hw->ctrl.val = 0; hw->user.doutdin = 1; //we only support full duplex hw->user.sio = 0; hw->slave.slave_mode = 1; hw->slave.soft_reset = 1; hw->slave.soft_reset = 0; //use all 64 bytes of the buffer hw->user.usr_miso_highpart = 0; hw->user.usr_mosi_highpart = 0; // Configure DMA In-Link to not be terminated when transaction bit counter exceeds hw->dma_conf.rx_eof_en = 0; hw->dma_conf.dma_seg_trans_en = 0; //Disable unneeded ints hw->dma_int_ena.val &= ~SPI_LL_UNUSED_INT_MASK; } /** * Initialize SPI peripheral (slave half duplex mode) * * @param hw Beginning address of the peripheral registers. */ static inline void spi_ll_slave_hd_init(spi_dev_t *hw) { hw->clock.val = 0; hw->user.val = 0; hw->ctrl.val = 0; hw->user.doutdin = 0; hw->user.sio = 0; hw->slave.soft_reset = 1; hw->slave.soft_reset = 0; hw->slave.slave_mode = 1; } /** * Determine and unify the default level of mosi line when bus free * * @param hw Beginning address of the peripheral registers. */ static inline void spi_ll_set_mosi_free_level(spi_dev_t *hw, bool level) { hw->ctrl.d_pol = level; //set default level for MOSI only on IDLE state } /** * Apply the register configurations and wait until it's done * * @param hw Beginning address of the peripheral registers. */ static inline void spi_ll_apply_config(spi_dev_t *hw) { hw->cmd.update = 1; while (hw->cmd.update); //waiting config applied } /** * Check whether user-defined transaction is done. * * @param hw Beginning address of the peripheral registers. * * @return True if transaction is done, otherwise false. */ static inline bool spi_ll_usr_is_done(spi_dev_t *hw) { return hw->dma_int_raw.trans_done; } /** * Trigger start of user-defined transaction. * * @param hw Beginning address of the peripheral registers. */ static inline void spi_ll_user_start(spi_dev_t *hw) { hw->cmd.usr = 1; } /** * Get current running command bit-mask. (Preview) * * @param hw Beginning address of the peripheral registers. * * @return Bitmask of running command, see ``SPI_CMD_REG``. 0 if no in-flight command. */ static inline uint32_t spi_ll_get_running_cmd(spi_dev_t *hw) { return hw->cmd.usr; } /** * Reset the slave peripheral before next transaction. * * @param hw Beginning address of the peripheral registers. */ static inline void spi_ll_slave_reset(spi_dev_t *hw) { hw->slave.soft_reset = 1; hw->slave.soft_reset = 0; } /** * Reset SPI CPU TX FIFO * * On ESP32C3, this function is not seperated * * @param hw Beginning address of the peripheral registers. */ static inline void spi_ll_cpu_tx_fifo_reset(spi_dev_t *hw) { hw->dma_conf.buf_afifo_rst = 1; hw->dma_conf.buf_afifo_rst = 0; } /** * Reset SPI CPU RX FIFO * * On ESP32C3, this function is not seperated * * @param hw Beginning address of the peripheral registers. */ static inline void spi_ll_cpu_rx_fifo_reset(spi_dev_t *hw) { hw->dma_conf.rx_afifo_rst = 1; hw->dma_conf.rx_afifo_rst = 0; } /** * Reset SPI DMA TX FIFO * * @param hw Beginning address of the peripheral registers. */ static inline void spi_ll_dma_tx_fifo_reset(spi_dev_t *hw) { hw->dma_conf.dma_afifo_rst = 1; hw->dma_conf.dma_afifo_rst = 0; } /** * Reset SPI DMA RX FIFO * * @param hw Beginning address of the peripheral registers. */ static inline void spi_ll_dma_rx_fifo_reset(spi_dev_t *hw) { hw->dma_conf.rx_afifo_rst = 1; hw->dma_conf.rx_afifo_rst = 0; } /** * Clear in fifo full error * * @param hw Beginning address of the peripheral registers. */ static inline void spi_ll_infifo_full_clr(spi_dev_t *hw) { hw->dma_int_clr.infifo_full_err = 1; } /** * Clear out fifo empty error * * @param hw Beginning address of the peripheral registers. */ static inline void spi_ll_outfifo_empty_clr(spi_dev_t *hw) { hw->dma_int_clr.outfifo_empty_err = 1; } /*------------------------------------------------------------------------------ * DMA *----------------------------------------------------------------------------*/ /** * Enable/Disable RX DMA (Peripherals->DMA->RAM) * * @param hw Beginning address of the peripheral registers. * @param enable 1: enable; 2: disable */ static inline void spi_ll_dma_rx_enable(spi_dev_t *hw, bool enable) { hw->dma_conf.dma_rx_ena = enable; } /** * Enable/Disable TX DMA (RAM->DMA->Peripherals) * * @param hw Beginning address of the peripheral registers. * @param enable 1: enable; 2: disable */ static inline void spi_ll_dma_tx_enable(spi_dev_t *hw, bool enable) { hw->dma_conf.dma_tx_ena = enable; } /** * Configuration of RX DMA EOF interrupt generation way * * @param hw Beginning address of the peripheral registers. * @param enable 1: spi_dma_inlink_eof is set when the number of dma pushed data bytes is equal to the value of spi_slv/mst_dma_rd_bytelen[19:0] in spi dma transition. 0: spi_dma_inlink_eof is set by spi_trans_done in non-seg-trans or spi_dma_seg_trans_done in seg-trans. */ static inline void spi_ll_dma_set_rx_eof_generation(spi_dev_t *hw, bool enable) { hw->dma_conf.rx_eof_en = enable; } /*------------------------------------------------------------------------------ * Buffer *----------------------------------------------------------------------------*/ /** * Write to SPI hardware data buffer. * * @param hw Beginning address of the peripheral registers. * @param buffer_to_send Address of the data to be written to the hardware data buffer. * @param bitlen Length to write, in bits. */ static inline void spi_ll_write_buffer(spi_dev_t *hw, const uint8_t *buffer_to_send, size_t bitlen) { for (int x = 0; x < bitlen; x += 32) { //Use memcpy to get around alignment issues for txdata uint32_t word; memcpy(&word, &buffer_to_send[x / 8], 4); hw->data_buf[(x / 32)] = word; } } /** * Write to SPI hardware data buffer by buffer ID (address) * * @param hw Beginning address of the peripheral registers * @param byte_id Start ID (address) of the hardware buffer to be written * @param data Address of the data to be written to the hardware data buffer. * @param len Length to write, in bytes. */ static inline void spi_ll_write_buffer_byte(spi_dev_t *hw, int byte_id, uint8_t *data, int len) { HAL_ASSERT(byte_id + len <= 64); HAL_ASSERT(len > 0); HAL_ASSERT(byte_id >= 0); while (len > 0) { uint32_t word; int offset = byte_id % 4; int copy_len = 4 - offset; if (copy_len > len) { copy_len = len; } //read-modify-write if (copy_len != 4) { word = hw->data_buf[byte_id / 4]; //read } memcpy(((uint8_t *)&word) + offset, data, copy_len); //modify hw->data_buf[byte_id / 4] = word; //write data += copy_len; byte_id += copy_len; len -= copy_len; } } /** * Read from SPI hardware data buffer. * * @param hw Beginning address of the peripheral registers. * @param buffer_to_rcv Address of a buffer to read data from hardware data buffer * @param bitlen Length to read, in bits. */ static inline void spi_ll_read_buffer(spi_dev_t *hw, uint8_t *buffer_to_rcv, size_t bitlen) { for (int x = 0; x < bitlen; x += 32) { //Do a memcpy to get around possible alignment issues in rx_buffer uint32_t word = hw->data_buf[x / 32]; int len = bitlen - x; if (len > 32) { len = 32; } memcpy(&buffer_to_rcv[x / 8], &word, (len + 7) / 8); } } /** * Read from SPI hardware data buffer by buffer ID (address) * * @param hw Beginning address of the peripheral registers * @param byte_id Start ID (address) of the hardware buffer to be read * @param data Address of a buffer to read data from hardware data buffer * @param len Length to read, in bytes. */ static inline void spi_ll_read_buffer_byte(spi_dev_t *hw, int byte_id, uint8_t *out_data, int len) { while (len > 0) { uint32_t word = hw->data_buf[byte_id / 4]; int offset = byte_id % 4; int copy_len = 4 - offset; if (copy_len > len) { copy_len = len; } memcpy(out_data, ((uint8_t *)&word) + offset, copy_len); byte_id += copy_len; out_data += copy_len; len -= copy_len; } } /*------------------------------------------------------------------------------ * Configs: mode *----------------------------------------------------------------------------*/ /** * Enable/disable the postive-cs feature. * * @param hw Beginning address of the peripheral registers. * @param cs One of the CS (0-2) to enable/disable the feature. * @param pos_cs True to enable the feature, otherwise disable (default). */ static inline void spi_ll_master_set_pos_cs(spi_dev_t *hw, int cs, uint32_t pos_cs) { if (pos_cs) { hw->misc.master_cs_pol |= (1 << cs); } else { hw->misc.master_cs_pol &= ~(1 << cs); } } /** * Enable/disable the LSBFIRST feature for TX data. * * @param hw Beginning address of the peripheral registers. * @param lsbfirst True if LSB of TX data to be sent first, otherwise MSB is sent first (default). */ static inline void spi_ll_set_tx_lsbfirst(spi_dev_t *hw, bool lsbfirst) { hw->ctrl.wr_bit_order = lsbfirst; } /** * Enable/disable the LSBFIRST feature for RX data. * * @param hw Beginning address of the peripheral registers. * @param lsbfirst True if first bit received as LSB, otherwise as MSB (default). */ static inline void spi_ll_set_rx_lsbfirst(spi_dev_t *hw, bool lsbfirst) { hw->ctrl.rd_bit_order = lsbfirst; } /** * Set SPI mode for the peripheral as master. * * @param hw Beginning address of the peripheral registers. * @param mode SPI mode to work at, 0-3. */ static inline void spi_ll_master_set_mode(spi_dev_t *hw, uint8_t mode) { //Configure polarity if (mode == 0) { hw->misc.ck_idle_edge = 0; hw->user.ck_out_edge = 0; } else if (mode == 1) { hw->misc.ck_idle_edge = 0; hw->user.ck_out_edge = 1; } else if (mode == 2) { hw->misc.ck_idle_edge = 1; hw->user.ck_out_edge = 1; } else if (mode == 3) { hw->misc.ck_idle_edge = 1; hw->user.ck_out_edge = 0; } } /** * Set SPI mode for the peripheral as slave. * * @param hw Beginning address of the peripheral registers. * @param mode SPI mode to work at, 0-3. */ static inline void spi_ll_slave_set_mode(spi_dev_t *hw, const int mode, bool dma_used) { if (mode == 0) { hw->misc.ck_idle_edge = 0; hw->user.rsck_i_edge = 0; hw->user.tsck_i_edge = 0; hw->slave.clk_mode_13 = 0; } else if (mode == 1) { hw->misc.ck_idle_edge = 0; hw->user.rsck_i_edge = 1; hw->user.tsck_i_edge = 1; hw->slave.clk_mode_13 = 1; } else if (mode == 2) { hw->misc.ck_idle_edge = 1; hw->user.rsck_i_edge = 1; hw->user.tsck_i_edge = 1; hw->slave.clk_mode_13 = 0; } else if (mode == 3) { hw->misc.ck_idle_edge = 1; hw->user.rsck_i_edge = 0; hw->user.tsck_i_edge = 0; hw->slave.clk_mode_13 = 1; } hw->slave.rsck_data_out = 0; } /** * Set SPI to work in full duplex or half duplex mode. * * @param hw Beginning address of the peripheral registers. * @param half_duplex True to work in half duplex mode, otherwise in full duplex mode. */ static inline void spi_ll_set_half_duplex(spi_dev_t *hw, bool half_duplex) { hw->user.doutdin = !half_duplex; } /** * Set SPI to work in SIO mode or not. * * SIO is a mode which MOSI and MISO share a line. The device MUST work in half-duplexmode. * * @param hw Beginning address of the peripheral registers. * @param sio_mode True to work in SIO mode, otherwise false. */ static inline void spi_ll_set_sio_mode(spi_dev_t *hw, int sio_mode) { hw->user.sio = sio_mode; } /** * Configure the SPI transaction line mode for the master to use. * * @param hw Beginning address of the peripheral registers. * @param line_mode SPI transaction line mode to use, see ``spi_line_mode_t``. */ static inline void spi_ll_master_set_line_mode(spi_dev_t *hw, spi_line_mode_t line_mode) { hw->ctrl.val &= ~SPI_LL_ONE_LINE_CTRL_MASK; hw->user.val &= ~SPI_LL_ONE_LINE_USER_MASK; hw->ctrl.fcmd_dual = (line_mode.cmd_lines == 2); hw->ctrl.fcmd_quad = (line_mode.cmd_lines == 4); hw->ctrl.faddr_dual = (line_mode.addr_lines == 2); hw->ctrl.faddr_quad = (line_mode.addr_lines == 4); hw->ctrl.fread_dual = (line_mode.data_lines == 2); hw->ctrl.fread_quad = (line_mode.data_lines == 4); hw->user.fwrite_dual = (line_mode.data_lines == 2); hw->user.fwrite_quad = (line_mode.data_lines == 4); } /** * Set the SPI slave to work in segment transaction mode * * @param hw Beginning address of the peripheral registers. * @param seg_trans True to work in seg mode, otherwise false. */ static inline void spi_ll_slave_set_seg_mode(spi_dev_t *hw, bool seg_trans) { hw->dma_conf.dma_seg_trans_en = seg_trans; } /** * Select one of the CS to use in current transaction. * * @param hw Beginning address of the peripheral registers. * @param cs_id The cs to use, 0-2, otherwise none of them is used. */ static inline void spi_ll_master_select_cs(spi_dev_t *hw, int cs_id) { hw->misc.cs0_dis = (cs_id == 0) ? 0 : 1; hw->misc.cs1_dis = (cs_id == 1) ? 0 : 1; hw->misc.cs2_dis = (cs_id == 2) ? 0 : 1; hw->misc.cs3_dis = (cs_id == 3) ? 0 : 1; hw->misc.cs4_dis = (cs_id == 4) ? 0 : 1; hw->misc.cs5_dis = (cs_id == 5) ? 0 : 1; } /** * Keep Chip Select activated after the current transaction. * * @param hw Beginning address of the peripheral registers. * @param keep_active if 0 don't keep CS activated, else keep CS activated */ static inline void spi_ll_master_keep_cs(spi_dev_t *hw, int keep_active) { hw->misc.cs_keep_active = (keep_active != 0) ? 1 : 0; } /*------------------------------------------------------------------------------ * Configs: parameters *----------------------------------------------------------------------------*/ /** * Set the clock for master by stored value. * * @param hw Beginning address of the peripheral registers. * @param val Stored clock configuration calculated before (by ``spi_ll_cal_clock``). */ static inline void spi_ll_master_set_clock_by_reg(spi_dev_t *hw, const spi_ll_clock_val_t *val) { hw->clock.val = *(uint32_t *)val; } /** * Get the frequency of given dividers. Don't use in app. * * @param fapb APB clock of the system. * @param pre Pre devider. * @param n Main divider. * * @return Frequency of given dividers. */ static inline int spi_ll_freq_for_pre_n(int fapb, int pre, int n) { return (fapb / (pre * n)); } /** * Calculate the nearest frequency avaliable for master. * * @param fapb APB clock of the system. * @param hz Frequncy desired. * @param duty_cycle Duty cycle desired. * @param out_reg Output address to store the calculated clock configurations for the return frequency. * * @return Actual (nearest) frequency. */ static inline int spi_ll_master_cal_clock(int fapb, int hz, int duty_cycle, spi_ll_clock_val_t *out_reg) { typeof(GPSPI2.clock) reg; int eff_clk; //In hw, n, h and l are 1-64, pre is 1-8K. Value written to register is one lower than used value. if (hz > ((fapb / 4) * 3)) { //Using Fapb directly will give us the best result here. reg.clkcnt_l = 0; reg.clkcnt_h = 0; reg.clkcnt_n = 0; reg.clkdiv_pre = 0; reg.clk_equ_sysclk = 1; eff_clk = fapb; } else { //For best duty cycle resolution, we want n to be as close to 32 as possible, but //we also need a pre/n combo that gets us as close as possible to the intended freq. //To do this, we bruteforce n and calculate the best pre to go along with that. //If there's a choice between pre/n combos that give the same result, use the one //with the higher n. int pre, n, h, l; int bestn = -1; int bestpre = -1; int besterr = 0; int errval; for (n = 2; n <= 64; n++) { //Start at 2: we need to be able to set h/l so we have at least one high and one low pulse. //Effectively, this does pre=round((fapb/n)/hz). pre = ((fapb / n) + (hz / 2)) / hz; if (pre <= 0) { pre = 1; } if (pre > 16) { pre = 16; } errval = abs(spi_ll_freq_for_pre_n(fapb, pre, n) - hz); if (bestn == -1 || errval <= besterr) { besterr = errval; bestn = n; bestpre = pre; } } n = bestn; pre = bestpre; l = n; //This effectively does round((duty_cycle*n)/256) h = (duty_cycle * n + 127) / 256; if (h <= 0) { h = 1; } reg.clk_equ_sysclk = 0; reg.clkcnt_n = n - 1; reg.clkdiv_pre = pre - 1; reg.clkcnt_h = h - 1; reg.clkcnt_l = l - 1; eff_clk = spi_ll_freq_for_pre_n(fapb, pre, n); } if (out_reg != NULL) { *(uint32_t *)out_reg = reg.val; } return eff_clk; } /** * Calculate and set clock for SPI master according to desired parameters. * * This takes long, suggest to calculate the configuration during * initialization by ``spi_ll_master_cal_clock`` and store the result, then * configure the clock by stored value when used by * ``spi_ll_msater_set_clock_by_reg``. * * @param hw Beginning address of the peripheral registers. * @param fapb APB clock of the system. * @param hz Frequncy desired. * @param duty_cycle Duty cycle desired. * * @return Actual frequency that is used. */ static inline int spi_ll_master_set_clock(spi_dev_t *hw, int fapb, int hz, int duty_cycle) { spi_ll_clock_val_t reg_val; int freq = spi_ll_master_cal_clock(fapb, hz, duty_cycle, ®_val); spi_ll_master_set_clock_by_reg(hw, ®_val); return freq; } /** * Set the mosi delay after the output edge to the signal. (Preview) * * The delay mode/num is a Espressif conception, may change in the new chips. * * @param hw Beginning address of the peripheral registers. * @param delay_mode Delay mode, see TRM. * @param delay_num APB clocks to delay. */ static inline void spi_ll_set_mosi_delay(spi_dev_t *hw, int delay_mode, int delay_num) { } /** * Set the miso delay applied to the input signal before the internal peripheral. (Preview) * * The delay mode/num is a Espressif conception, may change in the new chips. * * @param hw Beginning address of the peripheral registers. * @param delay_mode Delay mode, see TRM. * @param delay_num APB clocks to delay. */ static inline void spi_ll_set_miso_delay(spi_dev_t *hw, int delay_mode, int delay_num) { } /** * Set the delay of SPI clocks before the CS inactive edge after the last SPI clock. * * @param hw Beginning address of the peripheral registers. * @param hold Delay of SPI clocks after the last clock, 0 to disable the hold phase. */ static inline void spi_ll_master_set_cs_hold(spi_dev_t *hw, int hold) { hw->user1.cs_hold_time = hold; hw->user.cs_hold = hold ? 1 : 0; } /** * Set the delay of SPI clocks before the first SPI clock after the CS active edge. * * Note ESP32 doesn't support to use this feature when command/address phases * are used in full duplex mode. * * @param hw Beginning address of the peripheral registers. * @param setup Delay of SPI clocks after the CS active edge, 0 to disable the setup phase. */ static inline void spi_ll_master_set_cs_setup(spi_dev_t *hw, uint8_t setup) { hw->user1.cs_setup_time = setup - 1; hw->user.cs_setup = setup ? 1 : 0; } /*------------------------------------------------------------------------------ * Configs: data *----------------------------------------------------------------------------*/ /** * Set the output length (master). * This should be called before master setting MISO(input) length * * @param hw Beginning address of the peripheral registers. * @param bitlen output length, in bits. */ static inline void spi_ll_set_mosi_bitlen(spi_dev_t *hw, size_t bitlen) { if (bitlen > 0) { hw->ms_dlen.ms_data_bitlen = bitlen - 1; } } /** * Set the input length (master). * * @param hw Beginning address of the peripheral registers. * @param bitlen input length, in bits. */ static inline void spi_ll_set_miso_bitlen(spi_dev_t *hw, size_t bitlen) { if (bitlen > 0) { hw->ms_dlen.ms_data_bitlen = bitlen - 1; } } /** * Set the maximum input length (slave). * * @param hw Beginning address of the peripheral registers. * @param bitlen Input length, in bits. */ static inline void spi_ll_slave_set_rx_bitlen(spi_dev_t *hw, size_t bitlen) { //This is not used in esp32c3 } /** * Set the maximum output length (slave). * * @param hw Beginning address of the peripheral registers. * @param bitlen Output length, in bits. */ static inline void spi_ll_slave_set_tx_bitlen(spi_dev_t *hw, size_t bitlen) { //This is not used in esp32c3 } /** * Set the length of command phase. * * When in 4-bit mode, the SPI cycles of the phase will be shorter. E.g. 16-bit * command phases takes 4 cycles in 4-bit mode. * * @param hw Beginning address of the peripheral registers. * @param bitlen Length of command phase, in bits. 0 to disable the command phase. */ static inline void spi_ll_set_command_bitlen(spi_dev_t *hw, int bitlen) { hw->user2.usr_command_bitlen = bitlen - 1; hw->user.usr_command = bitlen ? 1 : 0; } /** * Set the length of address phase. * * When in 4-bit mode, the SPI cycles of the phase will be shorter. E.g. 16-bit * address phases takes 4 cycles in 4-bit mode. * * @param hw Beginning address of the peripheral registers. * @param bitlen Length of address phase, in bits. 0 to disable the address phase. */ static inline void spi_ll_set_addr_bitlen(spi_dev_t *hw, int bitlen) { hw->user1.usr_addr_bitlen = bitlen - 1; hw->user.usr_addr = bitlen ? 1 : 0; } /** * Set the address value in an intuitive way. * * The length and lsbfirst is required to shift and swap the address to the right place. * * @param hw Beginning address of the peripheral registers. * @param address Address to set * @param addrlen Length of the address phase * @param lsbfirst Whether the LSB first feature is enabled. */ static inline void spi_ll_set_address(spi_dev_t *hw, uint64_t addr, int addrlen, uint32_t lsbfirst) { if (lsbfirst) { /* The output address start from the LSB of the highest byte, i.e. * addr[24] -> addr[31] * ... * addr[0] -> addr[7] * So swap the byte order to let the LSB sent first. */ addr = HAL_SWAP32(addr); //otherwise only addr register is sent hw->addr = addr; } else { // shift the address to MSB of addr register. // output address will be sent from MSB to LSB of addr register hw->addr = addr << (32 - addrlen); } } /** * Set the command value in an intuitive way. * * The length and lsbfirst is required to shift and swap the command to the right place. * * @param hw Beginning command of the peripheral registers. * @param command Command to set * @param addrlen Length of the command phase * @param lsbfirst Whether the LSB first feature is enabled. */ static inline void spi_ll_set_command(spi_dev_t *hw, uint16_t cmd, int cmdlen, bool lsbfirst) { if (lsbfirst) { // The output command start from bit0 to bit 15, kept as is. HAL_FORCE_MODIFY_U32_REG_FIELD(hw->user2, usr_command_value, cmd); } else { /* Output command will be sent from bit 7 to 0 of command_value, and * then bit 15 to 8 of the same register field. Shift and swap to send * more straightly. */ HAL_FORCE_MODIFY_U32_REG_FIELD(hw->user2, usr_command_value, HAL_SPI_SWAP_DATA_TX(cmd, cmdlen)); } } /** * Set dummy clocks to output before RX phase (master), or clocks to skip * before the data phase and after the address phase (slave). * * Note this phase is also used to compensate RX timing in half duplex mode. * * @param hw Beginning address of the peripheral registers. * @param dummy_n Dummy cycles used. 0 to disable the dummy phase. */ static inline void spi_ll_set_dummy(spi_dev_t *hw, int dummy_n) { hw->user.usr_dummy = dummy_n ? 1 : 0; HAL_FORCE_MODIFY_U32_REG_FIELD(hw->user1, usr_dummy_cyclelen, dummy_n - 1); } /** * Enable/disable the RX data phase. * * @param hw Beginning address of the peripheral registers. * @param enable True if RX phase exist, otherwise false. */ static inline void spi_ll_enable_miso(spi_dev_t *hw, int enable) { hw->user.usr_miso = enable; } /** * Enable/disable the TX data phase. * * @param hw Beginning address of the peripheral registers. * @param enable True if TX phase exist, otherwise false. */ static inline void spi_ll_enable_mosi(spi_dev_t *hw, int enable) { hw->user.usr_mosi = enable; } /** * Get the received bit length of the slave. * * @param hw Beginning address of the peripheral registers. * * @return Received bits of the slave. */ static inline uint32_t spi_ll_slave_get_rcv_bitlen(spi_dev_t *hw) { return hw->slave1.data_bitlen; } /*------------------------------------------------------------------------------ * Interrupts *----------------------------------------------------------------------------*/ //helper macros to generate code for each interrupts #define FOR_EACH_ITEM(op, list) do { list(op) } while(0) #define INTR_LIST(item) \ item(SPI_LL_INTR_TRANS_DONE, dma_int_ena.trans_done, dma_int_raw.trans_done, dma_int_clr.trans_done=1) \ item(SPI_LL_INTR_RDBUF, dma_int_ena.rd_buf_done, dma_int_raw.rd_buf_done, dma_int_clr.rd_buf_done=1) \ item(SPI_LL_INTR_WRBUF, dma_int_ena.wr_buf_done, dma_int_raw.wr_buf_done, dma_int_clr.wr_buf_done=1) \ item(SPI_LL_INTR_RDDMA, dma_int_ena.rd_dma_done, dma_int_raw.rd_dma_done, dma_int_clr.rd_dma_done=1) \ item(SPI_LL_INTR_WRDMA, dma_int_ena.wr_dma_done, dma_int_raw.wr_dma_done, dma_int_clr.wr_dma_done=1) \ item(SPI_LL_INTR_SEG_DONE, dma_int_ena.dma_seg_trans_done, dma_int_raw.dma_seg_trans_done, dma_int_clr.dma_seg_trans_done=1) \ item(SPI_LL_INTR_CMD7, dma_int_ena.cmd7, dma_int_raw.cmd7, dma_int_clr.cmd7=1) \ item(SPI_LL_INTR_CMD8, dma_int_ena.cmd8, dma_int_raw.cmd8, dma_int_clr.cmd8=1) \ item(SPI_LL_INTR_CMD9, dma_int_ena.cmd9, dma_int_raw.cmd9, dma_int_clr.cmd9=1) \ item(SPI_LL_INTR_CMDA, dma_int_ena.cmda, dma_int_raw.cmda, dma_int_clr.cmda=1) static inline void spi_ll_enable_intr(spi_dev_t *hw, spi_ll_intr_t intr_mask) { #define ENA_INTR(intr_bit, en_reg, ...) if (intr_mask & (intr_bit)) hw->en_reg = 1; FOR_EACH_ITEM(ENA_INTR, INTR_LIST); #undef ENA_INTR } static inline void spi_ll_disable_intr(spi_dev_t *hw, spi_ll_intr_t intr_mask) { #define DIS_INTR(intr_bit, en_reg, ...) if (intr_mask & (intr_bit)) hw->en_reg = 0; FOR_EACH_ITEM(DIS_INTR, INTR_LIST); #undef DIS_INTR } static inline void spi_ll_set_intr(spi_dev_t *hw, spi_ll_intr_t intr_mask) { #define SET_INTR(intr_bit, _, st_reg, ...) if (intr_mask & (intr_bit)) hw->st_reg = 1; FOR_EACH_ITEM(SET_INTR, INTR_LIST); #undef SET_INTR } static inline void spi_ll_clear_intr(spi_dev_t *hw, spi_ll_intr_t intr_mask) { #define CLR_INTR(intr_bit, _, __, clr_reg) if (intr_mask & (intr_bit)) hw->clr_reg; FOR_EACH_ITEM(CLR_INTR, INTR_LIST); #undef CLR_INTR } static inline bool spi_ll_get_intr(spi_dev_t *hw, spi_ll_intr_t intr_mask) { #define GET_INTR(intr_bit, _, st_reg, ...) if (intr_mask & (intr_bit) && hw->st_reg) return true; FOR_EACH_ITEM(GET_INTR, INTR_LIST); return false; #undef GET_INTR } #undef FOR_EACH_ITEM #undef INTR_LIST /** * Disable the trans_done interrupt. * * @param hw Beginning address of the peripheral registers. */ static inline void spi_ll_disable_int(spi_dev_t *hw) { hw->dma_int_ena.trans_done = 0; } /** * Clear the trans_done interrupt. * * @param hw Beginning address of the peripheral registers. */ static inline void spi_ll_clear_int_stat(spi_dev_t *hw) { hw->dma_int_raw.trans_done = 0; } /** * Set the trans_done interrupt. * * @param hw Beginning address of the peripheral registers. */ static inline void spi_ll_set_int_stat(spi_dev_t *hw) { hw->dma_int_raw.trans_done = 1; } /** * Enable the trans_done interrupt. * * @param hw Beginning address of the peripheral registers. */ static inline void spi_ll_enable_int(spi_dev_t *hw) { hw->dma_int_ena.trans_done = 1; } /*------------------------------------------------------------------------------ * Slave HD *----------------------------------------------------------------------------*/ static inline void spi_ll_slave_hd_set_len_cond(spi_dev_t *hw, spi_ll_trans_len_cond_t cond_mask) { hw->slave.rdbuf_bitlen_en = (cond_mask & SPI_LL_TRANS_LEN_COND_RDBUF) ? 1 : 0; hw->slave.wrbuf_bitlen_en = (cond_mask & SPI_LL_TRANS_LEN_COND_WRBUF) ? 1 : 0; hw->slave.rddma_bitlen_en = (cond_mask & SPI_LL_TRANS_LEN_COND_RDDMA) ? 1 : 0; hw->slave.wrdma_bitlen_en = (cond_mask & SPI_LL_TRANS_LEN_COND_WRDMA) ? 1 : 0; } static inline int spi_ll_slave_get_rx_byte_len(spi_dev_t *hw) { return hw->slave1.data_bitlen / 8; } static inline uint32_t spi_ll_slave_hd_get_last_addr(spi_dev_t *hw) { return hw->slave1.last_addr; } /*------------------------------------------------------------------------------ * Segmented-Configure-Transfer *----------------------------------------------------------------------------*/ #define SPI_LL_CONF_BUF_SET_BIT(_w, _m) ({ \ (_w) |= (_m); \ }) #define SPI_LL_CONF_BUF_CLR_BIT(_w, _m) ({ \ (_w) &= ~(_m); \ }) #define SPI_LL_CONF_BUF_SET_FIELD(_w, _f, val) ({ \ ((_w) = (((_w) & ~((_f##_V) << (_f##_S))) | (((val) & (_f##_V))<<(_f##_S)))); \ }) #define SPI_LL_CONF_BUF_GET_FIELD(_w, _f) ({ \ (((_w) >> (_f##_S)) & (_f##_V)); \ }) //This offset is 1, for bitmap #define SPI_LL_CONF_BUFFER_OFFSET (1) //bitmap must be the first #define SPI_LL_CONF_BITMAP_POS (0) #define SPI_LL_ADDR_REG_POS (0) #define SPI_LL_CTRL_REG_POS (1) #define SPI_LL_CLOCK_REG_POS (2) #define SPI_LL_USER_REG_POS (3) #define SPI_LL_USER1_REG_POS (4) #define SPI_LL_USER2_REG_POS (5) #define SPI_LL_MS_DLEN_REG_POS (6) #define SPI_LL_MISC_REG_POS (7) #define SPI_LL_DIN_MODE_REG_POS (8) #define SPI_LL_DIN_NUM_REG_POS (9) #define SPI_LL_DOUT_MODE_REG_POS (10) #define SPI_LL_DMA_CONF_REG_POS (11) #define SPI_LL_DMA_INT_ENA_REG_POS (12) #define SPI_LL_DMA_INT_CLR_REG_POS (13) #define SPI_LL_SCT_MAGIC_NUMBER (0x2) /** * Set conf phase bits len to HW for segment config trans mode. * * @param hw Beginning address of the peripheral registers. * @param conf_bitlen Value of field conf_bitslen in cmd reg. */ static inline void spi_ll_set_conf_phase_bits_len(spi_dev_t *hw, uint32_t conf_bitlen) { if (conf_bitlen <= SOC_SPI_SCT_CONF_BITLEN_MAX) { hw->cmd.conf_bitlen = conf_bitlen; } } /** * Update the conf buffer for conf phase * * @param hw Beginning address of the peripheral registers. * @param is_end Is this transaction the end of this segment. * @param conf_buffer Conf buffer to be updated. */ static inline void spi_ll_format_conf_phase_conf_buffer(spi_dev_t *hw, bool is_end, uint32_t conf_buffer[SOC_SPI_SCT_BUFFER_NUM_MAX]) { //user reg: usr_conf_nxt if (is_end) { SPI_LL_CONF_BUF_CLR_BIT(conf_buffer[SPI_LL_USER_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_USR_CONF_NXT_M); } else { SPI_LL_CONF_BUF_SET_BIT(conf_buffer[SPI_LL_USER_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_USR_CONF_NXT_M); } } /** * Update the line mode of conf buffer for conf phase * * @param hw Beginning address of the peripheral registers. * @param line_mode line mode struct of each phase. * @param conf_buffer Conf buffer to be updated. */ static inline void spi_ll_format_line_mode_conf_buff(spi_dev_t *hw, spi_line_mode_t line_mode, uint32_t conf_buffer[SOC_SPI_SCT_BUFFER_NUM_MAX]) { conf_buffer[SPI_LL_CTRL_REG_POS + SPI_LL_CONF_BUFFER_OFFSET] &= ~SPI_LL_ONE_LINE_CTRL_MASK; conf_buffer[SPI_LL_USER_REG_POS + SPI_LL_CONF_BUFFER_OFFSET] &= ~SPI_LL_ONE_LINE_USER_MASK; switch (line_mode.cmd_lines) { case 2: SPI_LL_CONF_BUF_SET_BIT(conf_buffer[SPI_LL_CTRL_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_FCMD_DUAL_M); break; case 4: SPI_LL_CONF_BUF_SET_BIT(conf_buffer[SPI_LL_CTRL_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_FCMD_QUAD_M); break; default: break; } switch (line_mode.addr_lines) { case 2: SPI_LL_CONF_BUF_SET_BIT(conf_buffer[SPI_LL_CTRL_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_FADDR_DUAL_M); break; case 4: SPI_LL_CONF_BUF_SET_BIT(conf_buffer[SPI_LL_CTRL_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_FADDR_QUAD_M); break; default: break; } switch (line_mode.data_lines) { case 2: SPI_LL_CONF_BUF_SET_BIT(conf_buffer[SPI_LL_CTRL_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_FREAD_DUAL_M ); SPI_LL_CONF_BUF_SET_BIT(conf_buffer[SPI_LL_USER_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_FWRITE_DUAL_M); break; case 4: SPI_LL_CONF_BUF_SET_BIT(conf_buffer[SPI_LL_CTRL_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_FREAD_QUAD_M ); SPI_LL_CONF_BUF_SET_BIT(conf_buffer[SPI_LL_USER_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_FWRITE_QUAD_M); break; default: break; } } /** * Update the conf buffer for prep phase * * @param hw Beginning address of the peripheral registers. * @param setup CS setup time * @param conf_buffer Conf buffer to be updated. */ static inline void spi_ll_format_prep_phase_conf_buffer(spi_dev_t *hw, uint8_t setup, uint32_t conf_buffer[SOC_SPI_SCT_BUFFER_NUM_MAX]) { //user reg: cs_setup if(setup) { SPI_LL_CONF_BUF_SET_BIT(conf_buffer[SPI_LL_USER_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_CS_SETUP_M); } else { SPI_LL_CONF_BUF_CLR_BIT(conf_buffer[SPI_LL_USER_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_CS_SETUP_M); } //user1 reg: cs_setup_time SPI_LL_CONF_BUF_SET_FIELD(conf_buffer[SPI_LL_USER1_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_CS_SETUP_TIME, setup - 1); } /** * Update the conf buffer for cmd phase * * @param hw Beginning address of the peripheral registers. * @param cmd Command value * @param cmdlen Length of the cmd phase * @param lsbfirst Whether LSB first * @param conf_buffer Conf buffer to be updated. */ static inline void spi_ll_format_cmd_phase_conf_buffer(spi_dev_t *hw, uint16_t cmd, int cmdlen, bool lsbfirst, uint32_t conf_buffer[SOC_SPI_SCT_BUFFER_NUM_MAX]) { //user reg: usr_command if (cmdlen) { SPI_LL_CONF_BUF_SET_BIT(conf_buffer[SPI_LL_USER_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_USR_COMMAND_M); } else { SPI_LL_CONF_BUF_CLR_BIT(conf_buffer[SPI_LL_USER_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_USR_COMMAND_M); } //user2 reg: usr_command_bitlen SPI_LL_CONF_BUF_SET_FIELD(conf_buffer[SPI_LL_USER2_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_USR_COMMAND_BITLEN, cmdlen - 1); //user2 reg: usr_command_value if (lsbfirst) { SPI_LL_CONF_BUF_SET_FIELD(conf_buffer[SPI_LL_USER2_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_USR_COMMAND_VALUE, cmd); } else { SPI_LL_CONF_BUF_SET_FIELD(conf_buffer[SPI_LL_USER2_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_USR_COMMAND_VALUE, HAL_SPI_SWAP_DATA_TX(cmd, cmdlen)); } } /** * Update the conf buffer for addr phase * * @param hw Beginning address of the peripheral registers. * @param addr Address to set * @param addrlen Length of the address phase * @param lsbfirst whether the LSB first feature is enabled. * @param conf_buffer Conf buffer to be updated. */ static inline void spi_ll_format_addr_phase_conf_buffer(spi_dev_t *hw, uint64_t addr, int addrlen, bool lsbfirst, uint32_t conf_buffer[SOC_SPI_SCT_BUFFER_NUM_MAX]) { //user reg: usr_addr if (addrlen) { SPI_LL_CONF_BUF_SET_BIT(conf_buffer[SPI_LL_USER_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_USR_ADDR_M); } else { SPI_LL_CONF_BUF_CLR_BIT(conf_buffer[SPI_LL_USER_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_USR_ADDR_M); } //user1 reg: usr_addr_bitlen SPI_LL_CONF_BUF_SET_FIELD(conf_buffer[SPI_LL_USER1_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_USR_ADDR_BITLEN, addrlen - 1); //addr reg: addr if (lsbfirst) { SPI_LL_CONF_BUF_SET_FIELD(conf_buffer[SPI_LL_ADDR_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_USR_ADDR_VALUE, HAL_SWAP32(addr)); } else { SPI_LL_CONF_BUF_SET_FIELD(conf_buffer[SPI_LL_ADDR_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_USR_ADDR_VALUE, (addr << (32 - addrlen))); } } /** * Update the conf buffer for dummy phase * * @param hw Beginning address of the peripheral registers. * @param dummy_n Dummy cycles used. 0 to disable the dummy phase. * @param conf_buffer Conf buffer to be updated. */ static inline void spi_ll_format_dummy_phase_conf_buffer(spi_dev_t *hw, int dummy_n, uint32_t conf_buffer[SOC_SPI_SCT_BUFFER_NUM_MAX]) { //user reg: usr_dummy if (dummy_n) { SPI_LL_CONF_BUF_SET_BIT(conf_buffer[SPI_LL_USER_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_USR_DUMMY_M); } else { SPI_LL_CONF_BUF_CLR_BIT(conf_buffer[SPI_LL_USER_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_USR_DUMMY_M); } //user1 reg: usr_dummy_cyclelen SPI_LL_CONF_BUF_SET_FIELD(conf_buffer[SPI_LL_USER1_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_USR_DUMMY_CYCLELEN, dummy_n - 1); } /** * Update the conf buffer for dout phase * * @param hw Beginning address of the peripheral registers. * @param bitlen output length, in bits. * @param conf_buffer Conf buffer to be updated. */ static inline void spi_ll_format_dout_phase_conf_buffer(spi_dev_t *hw, int bitlen, uint32_t conf_buffer[SOC_SPI_SCT_BUFFER_NUM_MAX]) { if (bitlen) { //user reg: usr_mosi SPI_LL_CONF_BUF_SET_BIT(conf_buffer[SPI_LL_USER_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_USR_MOSI_M); //dma_conf reg: dma_tx_ena SPI_LL_CONF_BUF_SET_BIT(conf_buffer[SPI_LL_DMA_CONF_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_DMA_TX_ENA_M); //ms_dlen reg: ms_data_bitlen SPI_LL_CONF_BUF_SET_FIELD(conf_buffer[SPI_LL_MS_DLEN_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_MS_DATA_BITLEN, bitlen - 1); } else { //user reg: usr_mosi SPI_LL_CONF_BUF_CLR_BIT(conf_buffer[SPI_LL_USER_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_USR_MOSI_M); //dma_conf reg: dma_tx_ena SPI_LL_CONF_BUF_CLR_BIT(conf_buffer[SPI_LL_DMA_CONF_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_DMA_TX_ENA_M); } } /** * Update the conf buffer for din phase * * @param hw Beginning address of the peripheral registers. * @param bitlen input length, in bits. * @param conf_buffer Conf buffer to be updated. */ static inline void spi_ll_format_din_phase_conf_buffer(spi_dev_t *hw, int bitlen, uint32_t conf_buffer[SOC_SPI_SCT_BUFFER_NUM_MAX]) { if (bitlen) { //user reg: usr_miso SPI_LL_CONF_BUF_SET_BIT(conf_buffer[SPI_LL_USER_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_USR_MISO_M); //dma_conf reg: dma_rx_ena SPI_LL_CONF_BUF_SET_BIT(conf_buffer[SPI_LL_DMA_CONF_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_DMA_RX_ENA_M); //ms_dlen reg: ms_data_bitlen SPI_LL_CONF_BUF_SET_FIELD(conf_buffer[SPI_LL_MS_DLEN_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_MS_DATA_BITLEN, bitlen - 1); } else { //user reg: usr_miso SPI_LL_CONF_BUF_CLR_BIT(conf_buffer[SPI_LL_USER_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_USR_MISO_M); //dma_conf reg: dma_rx_ena SPI_LL_CONF_BUF_CLR_BIT(conf_buffer[SPI_LL_DMA_CONF_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_DMA_RX_ENA_M); } } /** * Update the conf buffer for done phase * * @param hw Beginning address of the peripheral registers. * @param setup CS hold time * @param conf_buffer Conf buffer to be updated. */ static inline void spi_ll_format_done_phase_conf_buffer(spi_dev_t *hw, int hold, uint32_t conf_buffer[SOC_SPI_SCT_BUFFER_NUM_MAX]) { //user reg: cs_hold if(hold) { SPI_LL_CONF_BUF_SET_BIT(conf_buffer[SPI_LL_USER_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_CS_HOLD_M); } else { SPI_LL_CONF_BUF_CLR_BIT(conf_buffer[SPI_LL_USER_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_CS_HOLD_M); } //user1 reg: cs_hold_time SPI_LL_CONF_BUF_SET_FIELD(conf_buffer[SPI_LL_USER1_REG_POS + SPI_LL_CONF_BUFFER_OFFSET], SPI_CS_HOLD_TIME, hold); } /** * Initialize the conf buffer: * * - init bitmap * - save all register values into the rest of the conf buffer words * * @param hw Beginning address of the peripheral registers. * @param conf_buffer Conf buffer to be updated. */ __attribute__((always_inline)) static inline void spi_ll_init_conf_buffer(spi_dev_t *hw, uint32_t conf_buffer[SOC_SPI_SCT_BUFFER_NUM_MAX]) { conf_buffer[SPI_LL_CONF_BITMAP_POS] = 0x7FFF | (SPI_LL_SCT_MAGIC_NUMBER << 28); conf_buffer[SPI_LL_ADDR_REG_POS + SPI_LL_CONF_BUFFER_OFFSET] = hw->addr; conf_buffer[SPI_LL_CTRL_REG_POS + SPI_LL_CONF_BUFFER_OFFSET] = hw->ctrl.val; conf_buffer[SPI_LL_CLOCK_REG_POS + SPI_LL_CONF_BUFFER_OFFSET] = hw->clock.val; conf_buffer[SPI_LL_USER_REG_POS + SPI_LL_CONF_BUFFER_OFFSET] = hw->user.val; conf_buffer[SPI_LL_USER1_REG_POS + SPI_LL_CONF_BUFFER_OFFSET] = hw->user1.val; conf_buffer[SPI_LL_USER2_REG_POS + SPI_LL_CONF_BUFFER_OFFSET] = hw->user2.val; conf_buffer[SPI_LL_MS_DLEN_REG_POS + SPI_LL_CONF_BUFFER_OFFSET] = hw->ms_dlen.val; conf_buffer[SPI_LL_MISC_REG_POS + SPI_LL_CONF_BUFFER_OFFSET] = hw->misc.val; conf_buffer[SPI_LL_DIN_MODE_REG_POS + SPI_LL_CONF_BUFFER_OFFSET] = hw->din_mode.val; conf_buffer[SPI_LL_DIN_NUM_REG_POS + SPI_LL_CONF_BUFFER_OFFSET] = hw->din_num.val; conf_buffer[SPI_LL_DOUT_MODE_REG_POS + SPI_LL_CONF_BUFFER_OFFSET] = hw->dout_mode.val; conf_buffer[SPI_LL_DMA_CONF_REG_POS + SPI_LL_CONF_BUFFER_OFFSET] = hw->dma_conf.val; conf_buffer[SPI_LL_DMA_INT_ENA_REG_POS + SPI_LL_CONF_BUFFER_OFFSET] = hw->dma_int_ena.val; conf_buffer[SPI_LL_DMA_INT_CLR_REG_POS + SPI_LL_CONF_BUFFER_OFFSET] = hw->dma_int_clr.val; } /** * Enable/Disable the conf phase * * @param hw Beginning address of the peripheral registers. * @param enable True: enable; False: disable */ static inline void spi_ll_conf_state_enable(spi_dev_t *hw, bool enable) { hw->slave.usr_conf = enable; } /** * Set Segmented-Configure-Transfer required magic value * * @param hw Beginning address of the peripheral registers. * @param magic_value magic value */ static inline void spi_ll_set_magic_number(spi_dev_t *hw, uint8_t magic_value) { hw->slave.dma_seg_magic_value = magic_value; } #undef SPI_LL_RST_MASK #undef SPI_LL_UNUSED_INT_MASK /** * Get the base spi command in esp32c3 * * @param cmd_t Command value */ static inline uint8_t spi_ll_get_slave_hd_base_command(spi_command_t cmd_t) { uint8_t cmd_base = 0x00; switch (cmd_t) { case SPI_CMD_HD_WRBUF: cmd_base = SPI_LL_BASE_CMD_HD_WRBUF; break; case SPI_CMD_HD_RDBUF: cmd_base = SPI_LL_BASE_CMD_HD_RDBUF; break; case SPI_CMD_HD_WRDMA: cmd_base = SPI_LL_BASE_CMD_HD_WRDMA; break; case SPI_CMD_HD_RDDMA: cmd_base = SPI_LL_BASE_CMD_HD_RDDMA; break; case SPI_CMD_HD_SEG_END: cmd_base = SPI_LL_BASE_CMD_HD_SEG_END; break; case SPI_CMD_HD_EN_QPI: cmd_base = SPI_LL_BASE_CMD_HD_EN_QPI; break; case SPI_CMD_HD_WR_END: cmd_base = SPI_LL_BASE_CMD_HD_WR_END; break; case SPI_CMD_HD_INT0: cmd_base = SPI_LL_BASE_CMD_HD_INT0; break; case SPI_CMD_HD_INT1: cmd_base = SPI_LL_BASE_CMD_HD_INT1; break; case SPI_CMD_HD_INT2: cmd_base = SPI_LL_BASE_CMD_HD_INT2; break; default: HAL_ASSERT(cmd_base); } return cmd_base; } /** * Get the spi communication command * * @param cmd_t Base command value * @param line_mode Line mode of SPI transaction phases: CMD, ADDR, DOUT/DIN. */ static inline uint16_t spi_ll_get_slave_hd_command(spi_command_t cmd_t, spi_line_mode_t line_mode) { uint8_t cmd_base = spi_ll_get_slave_hd_base_command(cmd_t); uint8_t cmd_mod = 0x00; //CMD:1-bit, ADDR:1-bit, DATA:1-bit if (line_mode.data_lines == 2) { if (line_mode.addr_lines == 2) { cmd_mod = 0x50; //CMD:1-bit, ADDR:2-bit, DATA:2-bit } else { cmd_mod = 0x10; //CMD:1-bit, ADDR:1-bit, DATA:2-bit } } else if (line_mode.data_lines == 4) { if (line_mode.addr_lines == 4) { cmd_mod = 0xA0; //CMD:1-bit, ADDR:4-bit, DATA:4-bit } else { cmd_mod = 0x20; //CMD:1-bit, ADDR:1-bit, DATA:4-bit } } if (cmd_base == SPI_LL_BASE_CMD_HD_SEG_END || cmd_base == SPI_LL_BASE_CMD_HD_EN_QPI) { cmd_mod = 0x00; } return cmd_base | cmd_mod; } /** * Get the dummy bits * * @param line_mode Line mode of SPI transaction phases: CMD, ADDR, DOUT/DIN. */ static inline int spi_ll_get_slave_hd_dummy_bits(spi_line_mode_t line_mode) { return 8; } #ifdef __cplusplus } #endif
