/* Controlling two stepper with the AccelStepper library by Dejan, https://howtomechatronics.com */ #include // Define the stepper motor and the pins that is connected to AccelStepper stepper1(1, 37, 39); // (Typeof driver: with 2 pins, STEP, DIR) AccelStepper stepper2(1, 31, 33); void setup() { stepper1.setMaxSpeed(1000); // Set maximum speed value for the stepper stepper1.setAcceleration(500); // Set acceleration value for the stepper stepper1.setCurrentPosition(0); // Set the current position to 0 steps stepper2.setMaxSpeed(1000); stepper2.setAcceleration(500); stepper2.setCurrentPosition(0); } void loop() { stepper1.moveTo(800); // Set desired move: 800 steps (in quater-step resolution that's one rotation) stepper1.runToPosition(); // Moves the motor to target position w/ acceleration/ deceleration and it blocks until is in position stepper2.moveTo(1600); stepper2.runToPosition(); // Move back to position 0, using run() which is non-blocking - both motors will move at the same time stepper1.moveTo(0); stepper2.moveTo(0); while (stepper1.currentPosition() != 0 || stepper2.currentPosition() != 0) { stepper1.run(); // Move or step the motor implementing accelerations and decelerations to achieve the target position. Non-blocking function stepper2.run(); // // } }
