#ifndef __DELAY_H__ #define __DELAY_H__ #if !defined(F_CPU) #error "F_CPU is not defined!" #endif #include #if !defined(MAX) #define MAX(a,b) ((a)>(b)?(a):(b)) #endif #define NS_TO_CYCLES(ns) ((ns)/(1000000000L/F_CPU)) #define US_TO_CYCLES(us) (NS_TO_CYCLES(us*1000L)) #define MS_TO_CYCLES(ms) (NS_TO_CYCLES(ms*1000000L)) #define LOOP_CTR(cycles,ovh,lp) (MAX(0,(cycles-ovh-lp)/lp)+1) #define LOOP_CTR_8(cycles) LOOP_CTR(cycles,7,3) #define LOOP_CTR_16(cycles) LOOP_CTR(cycles,9,8) #define LOOP_CTR_32(cycles) LOOP_CTR(cycles,13,12) #define _delay_us(us) \ (LOOP_CTR_8(US_TO_CYCLES(us)) < 256L) ? \ _delay_loop_8((uint8_t)LOOP_CTR_8(US_TO_CYCLES(us))) : \ _delay_loop_16((uint16_t)LOOP_CTR_16(US_TO_CYCLES(us))) #define _delay_ms(ms) \ (LOOP_CTR_16(MS_TO_CYCLES(ms)) < 65536L) ? \ _delay_loop_16((uint16_t)LOOP_CTR_16(MS_TO_CYCLES(ms))) : \ _delay_loop_32((uint32_t)LOOP_CTR_32(MS_TO_CYCLES(ms))) #define delay(ms) _delay_ms(ms) #define delay_us(us) _delay_us(us) // 3 cycles per loop, 7 cycles overhead void _delay_loop_8(uint8_t loop_ctr) { loop_ctr; // Ignore unreferenced function argument warning __asm // mov a, #(loop_ctr) ; 1 cycle // mov __delay_loop_8_PARM_1, a ; 1 cycle // call __delay_loop_8 ; 2 cycles 00001$: ; 4 cycles per loop dzsn __delay_loop_8_PARM_1 ; 1 cycle + 1 cycle for final skip goto 00001$ ; 2 cycles // ret ; 2 cycles __endasm; } // 8 cycles per loop, 9 cycles overhead void _delay_loop_16(uint16_t loop_ctr) { loop_ctr; // Ignore unreferenced function argument warning __asm // mov a, #(loop_ctr) ; 1 cycle // mov __delay_loop_16_PARM_1+0, a ; 1 cycle // mov a, #(loop_ctr<<8) ; 1 cycle // mov __delay_loop_16_PARM_1+1, a ; 1 cycle // call __delay_loop_16 ; 2 cycles 00001$: ; 8 cycles per loop nop ; 1 cycle dec __delay_loop_16_PARM_1+0 ; 1 cycle subc __delay_loop_16_PARM_1+1 ; 1 cycle mov a, __delay_loop_16_PARM_1+0 ; 1 cycle or a, __delay_loop_16_PARM_1+1 ; 1 cycle t1sn.io f, z ; 1 cycle + 1 cycle for final skip goto 00001$ ; 2 cycles // ret ; 2 cycles __endasm; } // 12 cycles per loop, 13 cycles overhead void _delay_loop_32(uint32_t loop_ctr) { loop_ctr; // Ignore unreferenced function argument warning __asm // mov a, #(loop_ctr) ; 1 cycle // mov __delay_loop_32_PARM_1+0, a ; 1 cycle // mov a, #(loop_ctr<<8) ; 1 cycle // mov __delay_loop_32_PARM_1+1, a ; 1 cycle // mov a, #(loop_ctr<<16) ; 1 cycle // mov __delay_loop_32_PARM_1+1, a ; 1 cycle // mov a, #(loop_ctr<<24) ; 1 cycle // mov __delay_loop_32_PARM_1+1, a ; 1 cycle // call __delay_loop_32 ; 2 cycles 00001$: ; 12 cycles per loop nop ; 1 cycle dec __delay_loop_32_PARM_1+0 ; 1 cycle subc __delay_loop_32_PARM_1+1 ; 1 cycle subc __delay_loop_32_PARM_1+2 ; 1 cycle subc __delay_loop_32_PARM_1+3 ; 1 cycle mov a, __delay_loop_32_PARM_1+0 ; 1 cycle or a, __delay_loop_32_PARM_1+1 ; 1 cycle or a, __delay_loop_32_PARM_1+2 ; 1 cycle or a, __delay_loop_32_PARM_1+3 ; 1 cycle t1sn.io f, z ; 1 cycle + 1 cycle for final skip goto 00001$ ; 2 cycles // ret ; 2 cycles __endasm; } #endif //__DELAY_H__
