*GENERAL HELP ABOUT THIS VERSION (V3.30) ... Below lists the changes made on Version 3.30. - Fixed Translator 16V8-to-18CV8 bug. - Fixed Translator EP320-to-18CV8 bug. ABOUT THIS VERSION (V3.20) ... Below lists the feature added on Version 3.20. - Faster programming/verification time. ABOUT VERSION V3.10 ... The following PEEL devices are supported (including program/verify/load, translation, and APEEL) in this version. - PEEL18CV8 - PEEL20CG10 - PEEL273 - PEEL173 - PEEL253 - PEEL153 - PEEL22CV10 - PEEL22CV10Z More Features (Next Page) Features added on Version 3.10 ... (Continue) - COM transmit and receive. - VT Emulation. - File and directory utilities e.g. mkdir, rmdir, rename, and erase. - Translator from PAL 24-pin to PEEL20CG10 and PEEL22CV10/Z. - Loader for PAL 24-pin and Cyp PALC22V10. - Translator from GAL20V8 to PEEL20CG10 and PEEL22CV10/Z. - DOS command shell. - Faster sort routine in the file selection menu. - Faster execution speed (30% faster than Version 3.00). This is only applicable for the 80x86 machines (e.g., 80286, 80386, etc.). THE "MAIN MENU" Once the PEEL Development Kit/Development System software is booted-up, the first screen to appear (after the initialization and sign-on messages) will be the "Main Menu". This main menu is divided into three sections: More on THE "MAIN MENU" (Next Page) THE "MAIN MENU" (Continue) DEVICE: controls operations such as Program, Load, Verify, Test, and other Auxiliary commands. These commands pertain to the device programmer module and are only available in the PEEL Development System. JEDEC FILE: controls operations such as Read from disk, Write to disk, COM transmit/receive, Display/print, Translate and Check sum. UTILITIES: includes Help, Setup, File, Edit, VT Emulator, DOS Command, and Quit to DOS. COMMAND SELECTION To select a command from the main menu, simply press the capital letter that corresponds to its adjacent command word. Some commands will have secondary command menus which must be followed to complete the original command. More (Next Page) EXITING AND RE-ENTERING THE SOFTWARE Exiting the PEEL Development Kit/Development System software is done from the main menu by pressing "Q" for "Quit to DOS". Doing this will cause a prompt to appear asking you to confirm your wish to quit. If confirmed, the software will exit and the DOS prompt will appear. To re-enter the software from DOS, simply type "PEEL" followed by the ENTER key. Pressing the ENTER key twice will allow you to bypass the boot-up messages. If you move the software to another computer, you must re-initialize the software again. COMMAND DESCRIPTIONS (Next Page) *LOAD HELP L = Load Enters Load mode. L = Load device - Loads the contents of the currently selected PLD (i.e., PEEL, PAL, FPLA, EEPLD or EPLD) into memory. Checksum is calculated and updated. Note: To select another PLD to be loaded, please press any key other than "L". *PROGRAM HELP P = Program Erases, programs, verifies and tests (if test vectors are provided in the JEDEC file) the PEEL device to the contents of memory. *VERIFY HELP V = Verify Verifies the PLD to the contents of memory. *TEST HELP T = Test Selects the test vector menu for executing test vectors supplied in JEDEC File. T = Test vectors - Normal testing. S = Single step vectors - Allows single stepping of test vectors. L = Loop vectors - Loops vectors specified by Begin/End. D = Display vectors - Turns ON/OFF screen display of vectors. B = set Begin vector [1] - Begins test from vector number 1. E = set End vector [666] - Ends test at vector number 666 (maximum). More (Next Page) Note: A Test Vector failure is indicated by a "!", "?", or "#". A "!" indicates that a LOW is sensed on the pin. A HIGH test vector is expected. A "?" indicates that a HIGH is sensed on the pin. A LOW test vector is expected. A "#" indicates that the pin is not at HIGH IMPEDANCE. C = Capture - Senses or "captures" the output levels resulting from your specified input test vectors. Output test vectors with an X (don't care) will be captured. *U AUXILIARY HELP U = aUxiliary Selects the menu of secondary functions/ commands that are auxiliary to selected device. S = Secure - Sets security bit. A = Auto-secure - Automatically sets security bit when programmed. B = Spacebar - Sets spacebar to repeat the last command. V = Verify-secure - Verifies if the device is secured. E = Erase all - Global erase (all "1"s). W = Write all - Global write (all "0"s). R = Read signature word - Reads the signature word from the device. P = Program signature - Programs the signature word word of the device. Checksum is updated. *READ HELP R = Read Allows you to select a JEDEC file to from disk be read from disk to memory. The checksum is updated. File For a description of the options, Selection please QUIT to return to the main Options screen menu and press "H" (for Help). Then, press "O" (for Options). To read a file from disk: (1) Use the right, left, up and down arrow keys to select a file within the list. The current file selected is highlighted. (2) Press the ENTER key to execute the selection. More (Next Page) After reading in the JEDEC file, the PEEL software prompts you to select the PLD type specific to the JEDEC file. Example: The file selected is R8CNTR.JED (written for PAL16R8). The PLD type to be selected should be PAL16R8 (also choose the manufacturer to be used). If a mistake was made in selecting the PLD type, you can read the JEDEC file again, or do the following: 1) press "L" for Load at the main screen menu. 2) press the SPACEBAR key. 3) select the correct PLD type (device type, manufacturer, etc.). 4) press "Q" for Quit when the software prompts you to load a device. Reminder: If you press "L" instead of "Q", the software will start the loading command. This will change the data in the data buffer. *WRITE HELP W = Write to disk Allows a JEDEC file to be written from memory to disk. Filename and checksum are updated. File For a description of the options, Selection please QUIT to return to the main Options screen menu and press "H" (for Help). Then, press "O" (for Options). To write a file to disk: (1) Press W to allow insertion of filename. (2) Then, press ENTER to execute the command. (The above instructions should be displayed on the top left corner of the screen). Filename Format (Next Page) The format for the filename is: filename.JED where filename can be a maximum of 8 characters. The file extension .JED is necessary to differentiate from the translated file which uses the .JEX extension. *COM HELP C = COM transmit/ Allows a JEDEC file to be transmitted or receive received to or from the COM port. C = Com port - toggles COM port between COM1 and COM2. B = Baudrate - selects baudrates ranging from 110 to 9600. D = Data bits - toggles data bits between 7 and 8. S = Stop bits - toggles stop bits between 1 and 2. P = Parity - selects EVEN, ODD or NONE. T = Timeout - selects timeout (in seconds) for transmission or reception. X = Transmit - sends the JEDEC file from the RAM memory to the COM port. You must ensure that the device type and family are specified correctly. R = Receive - receives the JEDEC file from the COM port to the RAM memory. After successful reception, you are prompted for the device type and family. *DISPLAY HELP D = Display/print Allows displaying or printing of the contents in the memory. *XLATE HELP X = Translate Enters Translate mode which allows translation of a JEDEC file from memory or disk. The translated file is automatically saved to disk with the same filename but a .JEX extension. D = translate Device loaded in memory - Translates the contents of the memory to the PEEL JEDEC format. A device must be loaded, or a JEDEC file read in prior to entering the translate mode. F = translate File in disk - Translates a JEDEC file from disk to the PEEL JEDEC format. A JEDEC file READ is not necessary prior to entering the translate mode. You will will be able to select a file from a file selection menu in this mode. More (Next Page) File Selection For a description of the Options options, please QUIT to return to the main screen menu and press "H" (for Help). Then, press "O" (for Options). *K CHECKSUM HELP K = checK sum Shows the current check sum calculated by last read or write of a file or by loading a PLD. A manual checksum can also be invoked by typing "K". *HELP HELP H = Help Lists the basic operation of each command. *SETUP HELP S = Setup Allows mode settings of color, sound, display (during Read, Translate, or APEEL), sort, timer, etc. C = Color mode is ON/OFF - Toggles the color mode ON/OFF. S = Sound mode is ON/OFF - Toggles the sound mode ON/OFF. B = Brief mode is ON/OFF - Toggles the brief mode ON/OFF. When this mode is ON, the file being read or translated will not be displayed on the screen This will speed up the reading or translating process. D = Directory sort is - Toggles the sort mode ON/OFF. ON/OFF This sort mode (when ON) is implemented prior to selecting a file. T = Timer is ON/OFF - Toggles the stop watch ON/OFF. More (Next Page) V = Vector trace is ON/OFF - Toggles the simulation trace mode ON/OFF. When this mode is ON, the simulation trace will be displayed on the screen. A = APEEL output file mode - Toggles the generation of the is ON/OFF APEEL output file (filename.OUT) ON/OFF. F = Fault Grade is ON/OFF - Toggles the fault grade mode ON/OFF. Fault grade will only be allowed if there are no errors in the simulation. R = Reset Program Counter - Clears the counter. P = Printer port is LPT1 - allows selection of printer port (LPT1, LPT2 or LPT3). *FILE HELP F = File Allows subdirectories to be created or removed, and files to be renamed or erased. C = Create directory - creates a new directory. R = Remove directory - removes a directory. N = reName file - renames a file to a new filename. E = Erase file - erases a file. File For a description of the options, please QUIT to Selection return to the main screen menu and press "H" Options (for Help). Then, press "O" (for Options). Note: For the Remove directory, rename file or erase file function, move the cursor to selected directory or file and then press R, N or E to execute the function. This procedure reduces the amount of typing necessary to enter the directory or file name. *EDIT HELP E = Edit Allows selection of a file and then enters a WordStar(TM)-like editor with pulldown menus. Follow the instructions displayed on the upper-right of the screen and/or reference the PEEL manual. File Selection For a description of Options the options, please QUIT to return to the main screen menu and press "H" (for Help). Then, press "O" (for Options). IMPORTANT NOTE: The editor files are located on the Applications disk. These files must be on the drive B disk when using the "dual floppy system mode". *APEEL HELP A = APEEL The "APEEL" command is a boolean logic assembler. Its features are: * Support for advance features of PEEL devices. * ABEL(tm)-like sum-of-product equations input. * ABEL(tm)-like macro cell pin declaration. * Logic simulation. * Fault grading (optional). More (Next Page) File Selection For a description of the options, Options please QUIT to return to the main screen menu and press "H" (for Help). Then, press "O" (for Options). PALASM is a registered trademark of Monolithic Memories Inc. ABEL is a trademark of DATA I/O Corporation *Z VT Emulation HELP Z = VT Emulation Allows video terminal emulation to be performed. Select the proper COM configuration. C = Com port - toggles COM port between COM1 and COM2. B = Baudrate - selects baudrates ranging from 110 to 9600. D = Data bits - toggles data bits between 7 and 8. S = Stop bits - toggles stop bits between 1 and 2. P = Parity - selects EVEN, ODD or NONE. T = Terminal - Starts the video terminal emulation. Emulation Note: Press Esc to abort terminal emulation and return to the main menu. *O DOS HELP D = DOS Enters the DOS shell. The JEDEC file which was read Command into the memory prior to executing this command is undisturbed. Note: In order for the DOS commands to function, you must have a method of accessing the COMMAND.COM file. The two methods which can be used are: (1) Hard-disk system only: Using the PATH environment variable in your AUTOEXEC.BAT file. Example: PATH=C:\;C:\DOS (2) Copying the COMMAND.COM file into the PEEL directory. For dual-floppy system, you must copy the COMMAND.COM file into the PEEL Development Software System diskette (Disk 1). *QUIT HELP Q = Quit Exits program to DOS. to DOS *OPTIONS HELP File Selection These options allows you to select the Options disk drive number and directory, or file mask in the file selection menu. D = Drive Allows selection of the disk drive number. Examples: [a:] selects drive A [C:] selects drive C (usually hard disk) More Options (Next Page) I = dIrectory Selects the disk drive directory. Examples: [\] selects the root directory [\PEEL] selects the PEEL directory Note: Below is an alternative method for selecting the directory. Each sub-directories is preceded by a "/". The directory or sub-directory can be selected by moving the cursor to it and pressing the ENTER key. /. go to root directory /.. go to directory immediately above the current one /FILES go to sub-directory "FILES" More Options (Next Page) M = Mask Allows further specification of the file types to be displayed from the current path selected. A "*" character can be used as a "wild card" allowing any characters to be accepted. Examples: [*.JED] shows only those files with an extension of .JED [*.JE*] shows only those files with an extension of .JED, .JEX, etc. [*.*] shows all files More OPTIONS (Next Page) Q = Quit to Returns to the main screen menu. last menu
